[参考译文] EDGE-AI-STUDIO:需要 edgeai-mmpose env 设置中的帮助
Guru**** 2589300 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1485444/edge-ai-studio-need-help-in-edgeai-mmpose-env-setup
器件型号:EDGE-AI-STUDIO
尊敬的专家:
我想使用 edgeai-mmpose 来测试诸如 RTM 之类的 face2D 模型。 当我尝试运行一些演示时、出现了与 edgeai-torchopt 相关的环境问题。 我的 python env:
Package                  Version       Editable project location
addict                   2.4.0
aliyun-python-sdk-core   2.16.0
aliyun-python-sdk-kms    2.16.5
attrs                    25.1.0
certifi                  2025.1.31
cffi                     1.17.1
charset-normalizer       3.4.1
chumpy                   0.70
click                    8.1.8
cmake                    3.25.0
colorama                 0.4.6
coloredlogs              15.0.1
contourpy                1.3.1
coverage                 7.6.12
crcmod                   1.7
cryptography             44.0.2
cycler                   0.12.1
Cython                   3.0.12
edgeai-torchmodelopt     10.0.0+532969
exceptiongroup           1.2.2
filelock                 3.14.0
flake8                   7.1.2
flatbuffers              25.2.10
fonttools                4.56.0
fsspec                   2025.3.0
humanfriendly            10.0
idna                     3.10
iniconfig                2.0.0
interrogate              1.7.0
isort                    4.3.21
Jinja2                   3.1.6
jmespath                 0.10.0
json-tricks              3.17.3
kiwisolver               1.4.8
lit                      15.0.7
Markdown                 3.7
markdown-it-py           3.0.0
MarkupSafe               3.0.2
matplotlib               3.10.1
mccabe                   0.7.0
mdurl                    0.1.2
mmcv                     2.1.0
mmdet                    3.2.0
mmengine                 0.10.7
mmpose                   1.3.1         /home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose
model-index              0.1.11
mpmath                   1.3.0
munkres                  1.1.4
networkx                 3.4.2
numpy                    1.26.4
nvidia-cublas-cu11       11.10.3.66
nvidia-cublas-cu12       12.1.3.1
nvidia-cuda-cupti-cu11   11.7.101
nvidia-cuda-cupti-cu12   12.1.105
nvidia-cuda-nvrtc-cu11   11.7.99
nvidia-cuda-nvrtc-cu12   12.1.105
nvidia-cuda-runtime-cu11 11.7.99
nvidia-cuda-runtime-cu12 12.1.105
nvidia-cudnn-cu11        8.5.0.96
nvidia-cudnn-cu12        8.9.2.26
nvidia-cufft-cu11        10.9.0.58
nvidia-cufft-cu12        11.0.2.54
nvidia-curand-cu11       10.2.10.91
nvidia-curand-cu12       10.3.2.106
nvidia-cusolver-cu11     11.4.0.1
nvidia-cusolver-cu12     11.4.5.107
nvidia-cusparse-cu11     11.7.4.91
nvidia-cusparse-cu12     12.1.0.106
nvidia-cusparselt-cu12   0.6.2
nvidia-nccl-cu11         2.14.3
nvidia-nccl-cu12         2.19.3
nvidia-nvjitlink-cu12    12.4.127
nvidia-nvtx-cu11         11.7.91
nvidia-nvtx-cu12         12.1.105
onnx                     1.17.0
onnxruntime              1.21.0
onnxsim                  0.4.36
opencv-python            4.11.0.86
opendatalab              0.0.10
openmim                  0.3.9
openxlab                 0.1.2
ordered-set              4.1.0
oss2                     2.17.0
packaging                24.2
pandas                   2.2.3
parameterized            0.9.0
pillow                   11.1.0
pip                      23.0.1
platformdirs             4.3.6
pluggy                   1.5.0
progressbar              2.5
protobuf                 6.30.0
py                       1.11.0
pycocotools              2.0.8
pycodestyle              2.12.1
pycparser                2.22
pycryptodome             3.21.0
pydot                    3.0.4
pyflakes                 3.2.0
Pygments                 2.19.1
pyparsing                3.2.1
pytest                   8.3.5
pytest-runner            6.0.1
python-dateutil          2.9.0.post0
pytz                     2023.4
PyYAML                   6.0.2
requests                 2.28.2
rich                     13.4.2
scipy                    1.15.2
setuptools               60.2.0
shapely                  2.0.7
six                      1.17.0
sympy                    1.13.1
tabulate                 0.9.0
termcolor                2.5.0
terminaltables           3.1.10
tomli                    2.2.1
torch                    2.0.1
torchaudio               2.0.2+cu118
torchinfo                1.8.0
torchvision              0.15.2+cu118
tqdm                     4.65.2
triton                   2.0.0
typing_extensions        4.12.2
tzdata                   2025.1
urllib3                  1.26.20
wheel                    0.45.1
xdoctest                 1.2.0
xtcocotools              1.14.3
yapf                     0.43.0
错误日志:
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/torch/serialization.py", line 809, in load
    return _load(opened_zipfile, map_location, pickle_module, **pickle_load_args)
  File "/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/torch/serialization.py", line 1172, in _load
    result = unpickler.load()
  File "/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/torch/serialization.py", line 1165, in find_class
    return super().find_class(mod_name, name)
  File "/home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose/mmpose/models/__init__.py", line 2, in <module>
    from .backbones import *  # noqa
  File "/home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose/mmpose/models/backbones/__init__.py", line 4, in <module>
    from .csp_darknet import CSPDarknet
  File "/home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose/mmpose/models/backbones/csp_darknet.py", line 11, in <module>
    from ..utils import CSPLayer
  File "/home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose/mmpose/models/utils/__init__.py", line 4, in <module>
    from .csp_layer import CSPLayer
  File "/home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose/mmpose/models/utils/csp_layer.py", line 9, in <module>
    from mmpose.utils.typing import ConfigType, OptConfigType, OptMultiConfig
  File "/home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose/mmpose/utils/__init__.py", line 9, in <module>
    from .model_surgery import convert_to_lite_model
  File "/home/ht/edgeai/edgeai-tensorlab/edgeai-mmpose/mmpose/utils/model_surgery.py", line 33, in <module>
    import edgeai_torchmodelopt
  File "/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/edgeai_torchmodelopt/__init__.py", line 32, in <module>
    from . import xnn
  File "/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/edgeai_torchmodelopt/xnn/__init__.py", line 32, in <module>
    from . import utils
  File "/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/edgeai_torchmodelopt/xnn/utils/__init__.py", line 55, in <module>
    from .graph_drawer_utils import *
  File "/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/edgeai_torchmodelopt/xnn/utils/graph_drawer_utils.py", line 6, in <module>
    from torch.fx.graph import _parse_stack_trace
ImportError: cannot import name '_parse_stack_trace' from 'torch.fx.graph' (/home/ht/.pyenv/versions/mmpose/lib/python3.10/site-packages/torch/fx/graph.py)
此问题与另一个 e2e 相关: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1455952/sk-am62a-lp-complie-onnx-split-and-add-node-can-t-pass/5659403#5659403
客户使用了基于 RTM 的模型来执行 face2D 关键点检测、因此我们正在尝试扩展当前 edgeai-mmpose 来测试该模型。
Adam
