您好、TI 专家:
我们有基于 AM69 SoC 的定制硬件、打算使用 PCIe_SOC_REFCLK0_OUT、PCIE_SOC_REFCLK1_OUT、PCIE_SOC_REFCLK2_OUT 和 PCIE_SOC_REFCLK3_OUT 引脚为 PCIe 器件提供基准时钟。
根据 AM69 TRM 和来自 J784S4 EVM 板的补丁、我确定需要在器件树中启用 ACSPCIE0和 ACSPCIE1模块(下面的补丁)。
我有以下问题:
- 对于 PCIe3_RC (PCIe@2930000)节点、PCIe 参考时钟仅在 ti、syscon-acspcie-proxy-ctrl =<&acspcie0_proxy_ctrl 0x3>时起作用。 同样、PCIe2_RC (PCIe@2920000)节点是否应该具有 ti、syscon-acspcie-proxy-ctrl =<&acspcie1_proxy_ctrl 0x3>? 当 bit-mask 为0x2或0x1而不是0x3时、PCIe 参考时钟不起作用。
此配置是否正确? 另外、如何为每个 SERDES 映射 ACSPCIE 时钟缓冲器? - 尽管在实际硬件上 PCIe 参考时钟在100MHz 上运行、k3conf 转储时钟命令会将所有 DEV_BOARD0_PCIe_REFCLK*值显示为0。 您能解释一下为什么会发生这种情况吗?
From 889e4f447920cba44bc61a6fb4e9f3a4545bdc1d Mon Sep 17 00:00:00 2001
Date: Fri, 7 Mar 2025 11:02:20 +0100
Subject: [PATCH 1/2] arm64: dts: ti: k3-j784s4-main: Enable ACSPCIE0 output
for PCIe3
The PCIe reference clock required by the PCIe Endpoints corresponding to the
PCIe3 instance could be driven by the ACSPCIE0 module. Add the device-tree
support for enabling the same.
TODO: bitmask 0x3 for '<&acspcie0_proxy_ctrl 0x3>' is not clear.
Upstream-Status: Pending
Signed-off-by: Parth Pancholi <parth.pancholi@toradex.com>
arch/arm64/boot/dts/ti/k3-j784s4-main.dtsi | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm64/boot/dts/ti/k3-j784s4-main.dtsi b/arch/arm64/boot/dts/ti/k3-j784s4-main.dtsi
index ab4a8c4444bb..f7557d2341e6 100644
--- a/arch/arm64/boot/dts/ti/k3-j784s4-main.dtsi
+++ b/arch/arm64/boot/dts/ti/k3-j784s4-main.dtsi
@@ -1205,11 +1205,12 @@ pcie3_rc: pcie@2930000 {
interrupts = <GIC_SPI 354 IRQ_TYPE_EDGE_RISING>;
device_type = "pci";
ti,syscon-pcie-ctrl = <&pcie3_ctrl 0x0>;
+ ti,syscon-acspcie-proxy-ctrl = <&acspcie0_proxy_ctrl 0x3>;
max-link-speed = <3>;
num-lanes = <2>;
power-domains = <&k3_pds 335 TI_SCI_PD_EXCLUSIVE>;
- clocks = <&k3_clks 335 0>;
- clock-names = "fck";
+ clocks = <&k3_clks 335 0>, <&serdes0 CDNS_TORRENT_REFCLK_DRIVER>;
+ clock-names = "fck", "pcie_refclk";
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x0 0xff>;
2.34.1From 30642b45b151a52c4ad08a73177db0ddd4962112 Mon Sep 17 00:00:00 2001
Date: Fri, 7 Mar 2025 11:14:34 +0100
Subject: [PATCH 2/2] arm64: dts: ti: k3-j784s4-main: Enable ACSPCIE1 output
for PCIe0 and PCIe2
PCIe0 and PCIe2 instances could be driven by the ACSPCIE1 module. Add the
device-tree support for enabling the same.
TODO: bitmask 0x3 for '<&acspcie1_proxy_ctrl 0x3>' is not clear.
arch/arm64/boot/dts/ti/k3-j784s4-main.dtsi | 15 +++++++++++----
1 file changed, 11 insertions(+), 4 deletions(-)
index f7557d2341e6..46ea13f049b7 100644
@@ -147,6 +147,11 @@ acspcie0_proxy_ctrl: acspcie0-ctrl@1a090 {
reg = <0x1a090 0x4>;
+ acspcie1_proxy_ctrl: acspcie1-ctrl@1a094 {
+ compatible = "ti,j784s4-acspcie-proxy-ctrl", "syscon";
+ reg = <0x1a094 0x4>;
serdes_ln_ctrl: mux-controller@4080 {
compatible = "reg-mux";
reg = <0x00004080 0x30>;
@@ -1117,11 +1122,12 @@ pcie0_rc: pcie@2900000 {
interrupts = <GIC_SPI 318 IRQ_TYPE_EDGE_RISING>;
ti,syscon-pcie-ctrl = <&pcie0_ctrl 0x0>;
+ ti,syscon-acspcie-proxy-ctrl = <&acspcie1_proxy_ctrl 0x1>;
num-lanes = <4>;
power-domains = <&k3_pds 332 TI_SCI_PD_EXCLUSIVE>;
- clocks = <&k3_clks 332 0>;
+ clocks = <&k3_clks 332 0>, <&serdes1 CDNS_TORRENT_REFCLK_DRIVER>;
#size-cells = <2>;
@@ -1176,11 +1182,12 @@ pcie2_rc: pcie@2920000 {
interrupts = <GIC_SPI 342 IRQ_TYPE_EDGE_RISING>;
ti,syscon-pcie-ctrl = <&pcie2_ctrl 0x0>;
+ ti,syscon-acspcie-proxy-ctrl = <&acspcie1_proxy_ctrl 0x3>;
num-lanes = <2>;
power-domains = <&k3_pds 334 TI_SCI_PD_EXCLUSIVE>;
- clocks = <&k3_clks 334 0>;
+ clocks = <&k3_clks 334 0>, <&serdes1 CDNS_TORRENT_REFCLK_DRIVER>;
#size-cells = <2>;
2.34.1谢谢你。
Parth P
