器件型号:SK-AM62P-LP 主题中讨论的其他器件:AM62P
我们正在测试电路板上的电源管理、我们希望使将电路板置于低功耗模式并通过触摸屏 交互将其唤醒成为可能。 我们对主板的设备树进行了以下更改、将"唤醒源"添加到扩展器1节点和触摸屏节点、如下所示。
&main_i2c0 {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&main_i2c0_pins_default>;
clock-frequency = <400000>;
touchscreen_ga657x@5d{
status = "okay";
compatible = "goodix,ga657x";
reg = <0x5d>;
interrupt-parent = <&exp1>;
interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
irq-gpios = <&exp1 0 GPIO_ACTIVE_LOW>;
+ wakeup-source; /* Allow WakeUp trough touch */
reset-gpios = <&exp2 20 GPIO_ACTIVE_LOW>;
irq-flags = <2>;
touchscreen-max-id = <11>;
touchscreen-size-x = <1280>;
touchscreen-size-y = <720>;
touchscreen-max-w = <512>;
touchscreen-max-p = <512>;
touchscreen-key-map = <172>, <158>; /*KEY_HOMEPAGE=172, KEY_BACK=158, KEY_MENU=139*/
goodix,slide-wakeup = <0>;
goodix,type-a-report = <0>;
goodix,driver-send-cfg = <0>;
goodix,resume-in-workqueue = <0>;
goodix,swap-x2y = <0>;
goodix,esd-protect = <1>;
goodix,auto-update = <0>;
goodix,auto-update-cfg = <0>;
goodix,power-off-sleep = <0>;
goodix,pen-suppress-finger = <0>;
goodix,cfg-group0 = [ 53 D0 02 00 05 05 F5 D5 21 48 2D 0F 5A 41 0E 05 00 00 32 32 20 00 05 14 14 1A 14 8B 2B 00 ];
typec_pd0: usb-power-controller@3f {
compatible = "ti,tps6598x";
reg = <0x3f>;
connector {
compatible = "usb-c-connector";
label = "USB-C";
self-powered;
data-role = "dual";
power-role = "sink";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
usb_con_hs: endpoint {
remote-endpoint = <&usb0_hs_ep>;
};&main_i2c1 {
status = "okay";
pinctrl-0 = <&main_i2c1_pins_default>;
bootph-all;
tlv320aic3106: audio-codec@1b {
status = "disabled";
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x1b>;
ai3x-micbias-vg = <1>; /* 2.0V */
exp1: gpio@22 {
compatible = "ti,tca6424";
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
gpio-line-names = "OLDI_INT#", "x8_NAND_DETECT",
"UART1_FET_SEL", "MMC1_SD_EN",
"VPP_EN", "EXP_PS_3V3_EN",
"UART1_FET_BUF_EN", "EXP_HAT_DETECT",
"DSI_GPIO0", "DSI_GPIO1",
"OLDI_EDID", "BT_UART_WAKE_SOC_3V3",
"USB_TYPEA_OC_INDICATION", "CSI_GPIO0",
"CSI_GPIO1", "WLAN_ALERTn",
"HDMI_INTn", "TEST_GPIO2",
"MCASP1_FET_EN", "MCASP1_BUF_BT_EN",
"MCASP1_FET_SEL", "DSI_EDID",
"PD_I2C_IRQ", "IO_EXP_TEST_LED";
interrupt-parent = <&main_gpio1>;
interrupts = <23 IRQ_TYPE_EDGE_FALLING>;
interrupt-controller;
#interrupt-cells = <2>;
+ wakeup-source; /* Allow WakeUp through expander IRQ */
pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>;
bootph-all;
};我们还需要进行其他修改吗?
