[参考译文] TDA4VM:使 Linux_FS_INSTALL_SD 失败
Guru**** 2460850 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1492192/tda4vm-make-linux_fs_install_sd-failed
器件型号:TDA4VM
团队成员、您好!
当我尝试  通过" make linux_fs_install_sd "命令将文件复制到 SD 卡时、失败了。 请在下面找到所附的日志。
#从文件系统中删除旧的远程文件
RM -f /media/Shabeer/rootfs/lib/firmware/j7-*-FW
RM -RF /media/Shabeer/rootfs/lib/firmware/vision_apps_evm
RM -RF /media/Shabeer/rootfs/opt/tidl_test /*
RM -RF /media/Shabeer/rootfs/usr/include/processor_sdk /*
#创建新目录
mkdir -p /media/Shabeer/rootfs/usr/include/processor_sdk
#将 full vision apps Linux fs Stage 目录复制到 Linux fs
cp -r /tmp/tivision_apps_targetfs_stage /*/media/Shabeer/rootfs/.
同步
# copy uEnv.txt and sysfw.itb for PSDK RTOS
CP /home/Shabeer/TDA4X/TI_SDK_07_03/RTOS_SDK/Shabeer/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/vision_apps/apps/basic_demos/app_linux_fs_files/uEnv.txt /media/Shabeer/BOOT
#CP /media/root/BOOT/sysfw-psdkra.itb /media/root/BOOT/sysfw.itb
#更新文件系统中特定于 PSDK RTOS 的任何其他文件
cp /home/Shabeer/TDA4X/TI_SDK_07_03/RTOS_SDK/Shabeer/ti-processor-sdk-rtos-j721e-evm-07_03_00_07/vision_apps/apps/basic_demos/app_linux_fs_files/limits.conf /media/Shabeer/rootfs/etc/security/limits.conf 2>/dev/null
makerules/makefile_linux_arm.mak:164:目标"linux_fs_install_sd"的配方失败
make:[LINUX_FS_INSTALL_SD]错误1 (已忽略)
同步
完整日志
e2e.ti.com/.../make-linux_5F00_fs_5F00_install_5F00_sd_5F00_log.txt
谢谢、此致
Shabeer
