您好 TI
我们使用的是 Yocto SDK 9.0
我们需要设置工具链来为 AM62开发 QT 应用(QT Creator)。
我们 从 TI 网站下载并安装了 ti-processor-sdk-linux-am62xx-evm-09.00.00.03.bin、还可以在 SDK 中尝试使用 bitbake -c opulate_sdk tisdk-default-image。
则无法找到交叉编译器、 Arm-Arago-Linux-*、但仅提供以下版本、但不适合 QT。
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-readelf
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-size
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-g ++
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-cpp
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-tool
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-c ++filt
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-as
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objdump
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strip
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ar
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-nm
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-dump
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-7.3.1
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ranlib
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-nm
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gprof
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb-py
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ld.bfd
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ranlib
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objcopy
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-addr2line
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strings
/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-elfedit
/usr/share/ti/cgt-pru/example/arm.c
/usr/share/gdb/syscalls/arm-linux.xml
/usr/include/linux/arm_sdei.h
/usr/include/drm/armada_drm.h
Paul@43Server:~/ti-processor-sdk-linux-am62xx-evm-09.00.00.03/linux-devkit/sysroots/x86_64-arago-linux$
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-readelf
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-size
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-g++
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-cpp
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-tool
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-c++filt
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-as
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objdump
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strip
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ar
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-nm
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcov-dump
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-7.3.1
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ranlib
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-nm
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gprof
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gdb-py
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ld.bfd
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-gcc-ranlib
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-objcopy
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-addr2line
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-ar
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-strings
./x86_64-arago-linux/usr/share/ti/gcc-arm-none-eabi/bin/arm-none-eabi-elfedit
./x86_64-Arago-Linux/usr/share/ti/cgt-pr/example/arm.c
./x86_64-arago-linux/usr/share/gdb/syscalls/arm-linux.xml
./x86_64-arago-linux/usr/include/linux/arm_sdei.h
./x86_64-arago-linux/usr/include/DRM/armada_drm.h
[Linux-DevKit]:~ë/Arago-2023.04/sysroots>
