[参考译文] SK-AM62-LP:是否有办法区分唤醒信号在唤醒信号到达时源自哪个引脚?
Guru**** 2442090 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1519930/sk-am62-lp-is-there-a-way-to-distinguish-which-pin-the-wake-up-signal-originates-from-when-a-wake-up-signal-arrives
器件型号:SK-AM62-LP
尊敬的专家:
将 GPIO 引脚配置为低功耗模式的唤醒源时、 是否有任何方法可以区分哪个特定引脚触发了系统从睡眠模式恢复?
BR
