[参考译文] PROCESSOR-SDK-AM62X:引导 AM62x HS-AM62x FS SoM–tiboot3.bin 和身份验证问题
Guru**** 2473260 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1532214/processor-sdk-am62x-booting-am62x-hs-fs-som-tiboot3-bin-and-authentication-issue
器件型号:PROCESSOR-SDK-AM62X
您好、
我们有一个基于 AM62x GP 型号的定制 SoM、可以正常使用。 现在、我们已切换到 FS 型号。
FS 型号的器件代码为:
02000000011a0000616d3632780000000000000048534653010001000100010002a6000000000000d68ecb2c055dff11ade95bd927e837d2a53bc23b0a2800cebce4f106bcf309df2213912d77a157a8b7c2df40672a06a918034aa4c7d603e462481475225d49b8ad0bc40b0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000008244b9b8a68f9fab2c8cf84108108de4fe660cba43ee3eab1f7087767a005690
解码为:
SoC ID Header Info:
NumBlocks            : [2]
SoC ID Public ROM Info:
SubBlockId           :
SubBlockSize         :
DeviceName           : am62x
DeviceType           : HSFS
DMSC ROM Version     : [0, 1, 0, 1]
R5 ROM Version       : [0, 1, 0, 1]
SoC ID Secure ROM Info:
Sec SubBlockId       : 2
Sec SubBlockSize     : 166
Sec Prime            : 0
Sec Key Revision     : 0
Sec Key Count        : 0
Sec TI MPK Hash      : d68ecb2c055dff11ade95bd927e837d2a53bc23b0a2800cebce4f106bcf309df2213912d77a157a8b7c2df40672a06a918034aa4c7d603e462481475225d49b8
Sec Cust MPK Hash    : ad0bc40b000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
Sec Unique ID        : 8244b9b8a68f9fab2c8cf84108108de4fe660cba43ee3eab1f7087767a005690
根据您的迁移指南、我知道 FS 可以通过替换tiboot3.bin SD 卡上的文件在 GP 和 HS-SD 型号之间切换:
  • GP - tiboot3-am62x-gp-evm
  • HS-EVM FS - tiboot3-am62x-hs-FS-EVM
对于 FS 型号、我在串行控制台上看到以下输出:
U-Boot SPL 2023.04-ti-g836606420854 (May 09 2024 - 05:42:45 +0000)
SYSFW ABI: 3.1 (firmware rev 0x0009 '9.2.8--v09.02.08 (Kool Koala)')
SPL initial stack usage: 13408 bytes
Trying to boot from MMC2
ti_sci system-controller@44043000: Message not acknowledgedAuthentication failed!
### ERROR ### Please RESET the board ###
尚未烧录任何电子保险丝。
我们目前正在使用 Yocto Processor SDK 版本 09.02.00.10.
  1. 是否有tiboot3-am62x-hs-fs-evm我们可以尝试的预构建版本?
  2. 您是否对如何从此处继续操作有任何建议?
Jakob Hilmer
    您好:
    对于 HS-BIOS FS 型号、我在串行控制台上看到以下输出:
    日志表明您已在引导预编译的二进制文件。 我看到您正尝试从 SD 卡进行引导。 您是随机还是一致地看到问题? 您是否尝试过不同的 SD 卡以确定问题是否仅与特定的 SD 卡有关?
