[参考译文] PROCESSOR-SDK-J7200:其中为 j7200-mcu-R5f0_0-fw
Guru**** 2595805 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1544041/processor-sdk-j7200-where-is-j7200-mcu-r5f0_0-fw
器件型号:PROCESSOR-SDK-J7200
ENV:PROCESSOR-SDK-LINUX-j7200-evm-11_00_10_01
我想使用 SDK 测试 IPC、 用户指南中指出:
创建新的软链接
ln -s /lib/firmware/pdk-ipc/ipc_echo_test_mcu2_0_release.xer5f j7200-main-R5f0_0-fw
ln -s /lib/firmware/pdk-ipc/ipc_echo_test_mcu2_1_release.xer5f j7200-main-R5f0_1-fw
ln -s /lib/firmware/pdk-ipc/ipc_echo_testb_mcu1_0_release.xer5f j7200-mcu-R5f0_0-fw
ln -s /lib/firmware/pdk-ipc/ipc_echo_test_mcu1_1_release.xer5f j7200-mcu-r5f0_1-fw
问题是我找不到 j7200-mcu-R5f0_0-fw:
如何 在 MCU-r5f0_0 中使用自定义 MCU-R5F-application?
