[参考译文] J721S2XSOMXEVM:如何生成 freertos_mcu1_0_release.xer5f.map 的.cinit?
Guru**** 2478765 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1539074/j721s2xsomxevm-who-and-what-to-generate-the-cinit-of-freertos_mcu1_0_release-xer5f-map
器件型号:J721S2XSOMXEVM
尊敬的 TI
J721S2 10.01.00.04:rtos-build\pdk_j721s2_10_01_00_25\packages\ti\binary\ipc_echo_testb_freertos\bin\j721s2_evm\ipc_echo_testb_freertos_mcu1_0_release.xer5f.map
.cinit 0 a05f82d8 00002428
a05f82d8 000023df (.cinit .data.load)[加载映像、压缩= lzss]
a05fa6b7 00000001 ------[填充= 00000000]
a05fa6b8 0000000c (_TI_HANDLER_TABLE)
a05fa6c4 00000008 (.cinit..bss.devgroup.load)[加载映像、压缩= zero_init]
a05fa6cc 00000008 (.cinit。bss.load)[加载映像、压缩= zero_init]
a05fa6d4 00000008 (.cinit .tracebuf.load)[加载映像、压缩= zero_init]
a05fa6dc 00000020 (_TI_cinit_table)
a05fa6fc 00000004 --hole--[填充= 00000000]
佳豪
