[参考译文] PROCESSOR-SDK-AM57X:RTOS SDK:IPC RTOS 示例无法构建
Guru**** 2478765 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1529301/processor-sdk-am57x-rtos-sdk-ipc-rtos-examples-wont-build
器件型号:PROCESSOR-SDK-AM57X
您好:
我已下载 SDK 9.03 RTOS Processor SDK 和 SDK 9.03 Processor SDK Linux。 我讲解了发行说明中列出的构建 IPC RTOS 示例的说明。
https://software-dl.ti.com/processor-sdk-linux/esd/AM57X/09_03_06_05/exports/docs/linux/Foundational_Components_ ipc.html#ipc-quick-start-guide
我运行了以下命令以导出必要的环境变量并获取正确的设置脚本
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ export TI_SDK_PATH=$HOME/ti-processor-sdk-linux-am57xx-evm-09_03_06_05
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ export PATH=$TI_SDK_PATH/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/:$PATH
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ export TI_RTOS_PATH=$HOME/processor_sdk_rtos_am57xx_09_03_00_00
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ export IPC_INSTALL_PATH=$TI_RTOS_PATH/ipc_3_52_00_00
# Env variables for ipc_bios compile
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ export SDK_INSTALL_PATH=$TI_RTOS_PATH
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ export TOOLS_INSTALL_PATH=$TI_RTOS_PATH
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ source setupenv.sh
我首先尝试运行您的说明中指定的命令
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00/processor_sdk_rtos_am57xx_09_03_00_00$ make ipc_examples
构建成功完成、但当我检查发行说明中说明 server_dsp1.xe66 二进制文件应该是的目录时、它是空的。
jsava@laptop-183:/export/home/jsava/processor_sdk_rtos_am57xx_09_03_00_00$ ls ipc_3_52_00_00/examples/DRA7XX_linux_elf/ex02_messageq/dsp1/bin/debug/
obj
然后、我尝试运行 IPC_BIOS make 选项并且仍然获得相同的结果。 最后、我决定运行“make all“以查看这是否会构建我要查找的二进制文件、但构建失败。 我已附上该故障的日志。
e2e.ti.com/.../RTOS_5F00_build_5F00_failure.txt
我做了不正确的事情吗? 您以前遇到过这个问题吗?
-工作
    您好作业、
    我将尝试在本周重现并通知您。
    -Josue
    作业、
    我复制了此问题、正在处理此问题、但您似乎找到了解决方案: e2e.ti.com/.../5911418
    Josue
