[参考译文] SK-AM62-LP:我使用 echo 'DISTROOVERRIDE;DISSUVERRIDES:append =":ti-falcon"'>>conf/local.conf 时出现 U-Boot Falcon 模式构建 u-boot 错误
Guru**** 2482105 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1544392/sk-am62-lp-u-boot-falcon-mode-build-u-boot-error-when-i-use-echo-distrooverrides-append-ti-falcon-conf-local-conf
器件型号:SK-AM62-LP
您好 TI
我使用  U-Boot 猎鹰模式  , https://software-dl.ti.com/processor-sdk-linux/esd/AM62PX/11_01_05_03/exports/docs/linux/Foundational_Components / U-Boot/UG-Falcon-Mode.html
您可以对其进行检查
当我  回显“DISTROOOVERRIDE:append =“:ti-falcon“>> conf/local.conf 时
我  bitbake tisdk-display-cluster-image  use Yocto ,编译正常,但安装有一些错误
这是日志
e2e.ti.com/.../log_5F00_do_5F00_install.txt
