器件型号:TDA4VM工具/软件:
尊敬的专家:
之前、我们已 通过 DPI0 成功输出 BT656 格式图像。
现在、我们计划将输出切换到 DPI1、同时保持所有其他设置不变。
基于上述情况、我进行了以下修改。
在文件 app_dss_defaults.c 中、nodeDpiId 的值已更改为 APP_DCTRL_NODE_DPI_DPI1。
在 J721E_pinmux_data.c 文件中、添加了 Vout1 的 pinmux 配置。
static pinmuxPerCfg_t gVout0PinCfg[] =
/* MyVOUT0 -> VOUT0_DATA2 -> AF23 */
PIN_PRG1_PRU1_GPO2, PIN_MODE(10) | \
((PIN_PULL_DISABLE) & (~PIN_PULL_DIRECTION & ~PIN_INPUT_ENABLE))
/* MyVOUT0 -> VOUT0_DATA3 -> AD23 */
PIN_PRG1_PRU1_GPO3, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_DATA4 -> AH24 */
PIN_PRG1_PRU1_GPO4, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_DATA5 -> AG21 */
PIN_PRG1_PRU1_GPO5, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_DATA6 -> AE23 */
PIN_PRG1_PRU1_GPO6, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_DATA7 -> AC21 */
PIN_PRG1_PRU1_GPO7, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_DATA8 -> Y23 */
PIN_PRG1_PRU1_GPO8, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_DATA9 -> AF21 */
PIN_PRG1_PRU1_GPO9, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_HSYNC -> AJ26 */
PIN_PRG1_PRU1_GPO16, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_PCLK -> AH22 */
PIN_PRG1_PRU1_GPO19, PIN_MODE(10) | \
/* MyVOUT0 -> VOUT0_VSYNC -> AJ22 */
PIN_PRG1_PRU1_GPO18, PIN_MODE(10) | \
{PINMUX_END}
static pinmuxPerCfg_t gVout1PinCfg[] =
/* MyVOUT1 -> VOUT1_DATA2 -> V28 */
PIN_RGMII5_TD3, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA3 -> V29 */
PIN_RGMII5_TD2, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA4 -> V27 */
PIN_RGMII5_TD1, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA5 -> U28 */
PIN_RGMII5_TD0, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA6 -> U29 */
PIN_RGMII5_TXC, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA7 -> U25 */
PIN_RGMII5_RXC, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA8 -> U27 */
PIN_RGMII5_RD3, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_DATA9 -> U24 */
PIN_RGMII5_RD2, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_HSYNC -> W27 */
PIN_RGMII6_TD0, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_PCLK -> W29 */
PIN_RGMII6_TXC, PIN_MODE(4) | \
/* MyVOUT1 -> VOUT1_VSYNC -> V25 */
PIN_RGMII6_TD1, PIN_MODE(4) | \
{PINMUX_END}
static pinmuxModuleCfg_t gVoutPinCfg[] =
{0, TRUE, gVout0PinCfg},
{1, TRUE, gVout1PinCfg},
{PINMUX_END}
但是、在切换到 DPI1 时、我发现 Vout1 的 PCLK 波形非常奇怪。 波形图如下所示。
再次切换回 DPI0 时、我发现 Vout0 的 PCLK 波形看起来非常好。波形图如下所示。
您能帮我确认我的修改中是否有任何遗漏导致 PCLK 异常吗?
