器件型号:J784S4XEVM工具/软件:
ti-edgeai-image从 SDK 11 运行的 J784S4XEVM 电路板上存在网络稳定性问题。
这一问题表现在高网络流量下,我们可以在从 AWS S3 存储桶 以大约 100 Mbit/s 的吞吐量下载数据时可靠地重现 此活动会触发许多内核错误消息、我已将其粘贴在下面:
[ 394.266696] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.278107] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.289570] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.300994] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.312471] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.323887] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.335336] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.346785] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.358314] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.369755] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.381170] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.392590] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.404039] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.415473] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.426923] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.438387] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.449831] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.461270] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.472714] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.484161] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.564155] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.573735] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.585243] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.596669] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.608069] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.619531] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.630963] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 394.642421] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 398.922649] swiotlb_tbl_map_single: 4200 callbacks suppressed [ 398.928414] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 398.939808] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 398.951194] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 398.962565] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 398.979479] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 398.991271] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 399.008180] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 399.025088] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 399.036969] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 399.053875] am65-cpsw-nuss 46000000.ethernet: swiotlb buffer is full (sz: 4096 bytes), total 32768 (slots), used 32768 (slots) [ 399.071041] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.082344] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.093781] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.105247] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.116697] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.128118] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.139571] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.151026] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.162462] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.173909] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.185390] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.196827] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.208259] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.219703] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.231149] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.242627] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.254063] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.265489] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.276943] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.288412] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.299829] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.311276] am65-cpsw-nuss 46000000.ethernet: page alloc failed [ 399.322727] am65-cpsw-nuss 46000000.ethernet: page alloc failed
出现这些错误后、电路板的网络堆栈最终会完全失败。 我们将失去所有连接—设备不再响应 ping 请求、并且 SSH 访问将丢失。 还原网络功能的唯一方法是执行硬重启。
您能否就如何诊断和解决此问题提供一些指导?
感谢您的支持。
