[参考译文] AM69A:edgeai SDK 为 11.00.00.08 时发生 yotco 构建错误
Guru**** 2652575 points
Other Parts Discussed in Thread: AM69, AM67A
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1582790/am69a-yotco-build-error-with-edgeai-sdk-11-00-00-08
器件型号: AM69A
Thread 中讨论的其他器件: AM69AM67A
尊敬的 TI 团队:
执行中的步骤时、我会遇到两个获取错误
https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-am69a/11_00_00/exports/docs/linux/Overview_Building_the_SDK.html
来构建 tisdk-edgeai-image。
以下是错误日志:
警告:TI-vision-apps-11.00.00 -r0_edgeai_13 do_fetch:获取 URL 存储库:/git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.psdk.analytics.11.00.00.06;manify=vision_apps_yocto.xml 失败、尝试镜像(如果可用)
错误:TI-vision-apps-11.00.00-r0_edgeai_13 do_fetch:fetcher 失败:fetcher 命令 export pseude_disable=1 /run/user/1000/bus;export DBUS_Session_bus_address=“unix:path=unix“/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin/aarch64-oe-linux;export SSH_AUTH_SOCK=“;export PATH=“:/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/bin /home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/hosttools:/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/sbin:/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot/usr/bin/crossscripts:/run/user/1000/keyring/ssh:/home/j/ti-sdk-e-11000008/yocto-build/sources/bitbake/bin /home/j:/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/bin:/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/recipe-sysroot-native/usr/sbin:/home/j/ti-sdk-e-11000008/yocto-build/sources/oe-core/scripts:export /usr/bin/env 存储库同步失败、退出代码 1、输出:
警告:repo 没有跟踪远程分支、因此它不会接收更新;运行`repo init --repo-rev=stable`修复。
错误:在`s同步`:错误分析清单/home/j/ti-sdk-e-11000008/yocto-build/downloads/repo/git.ti.com.git.processor-sdk.psdk_repo_manifests.git/vision_apps_yocto.xml/repo/.repo/manifest.xml :[errno 2]没有这样的文件或目录:'/home/j/ti-sdk-e-11000008/yocto-build/downloads/repo/git.ti.com.git.processor-sdk.psdk_repo_manifests.git/vision_apps_yocto.xml/repo/.repo/manifest.xml '
错误:TI-vision-apps-11.00.00;r0_edgeai_13 do_fetch:Bitbake Fetcher 错误:FetchError(“无法从任何源获取 URL。“、“REPO:/git.ti.com/git/processor-sdk/psdk_repo_manifests.git;protocol=https;branch=refs/tags/REL.psdk.analytical.11.00.06;manifestive=vision_apps_ys.xml“)
错误:存储在/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/aarch64-oe-linux/ti-vision-apps/11.00.00/temp/log.do_fetch.3637817 中的失败日志文件
错误:任务 (/home/j/ti-sdk-e-11000008/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-vision-apps.bb:do_fetch) 失败、退出代码为“1"</s>“
警告:TI-edgeai-firmware-1.0.0-r0 do_fetch:无法获取 URL git:/git.ti.com/git/processor-sdk/psdk_fw.git;protocol=https;branch=main、尝试镜像(如果可用)
错误:TI-edgeai-firmware-1.0.0-r0 do_fetch:fetcher 故障:即使是从上游在分支 main 中也无法找到修订版 e00793be1432e02103b71c37bc612e1f34a7a388
错误:TI-edgeai-firmware-1.0.0-r0 do_fetch:Bitbake Fetcher 错误:FetchError(“无法从任何源获取 URL。“、“git://git.ti.com/git/processor-sdk/psdk_fw.git;protocol=https;branch=main“)
错误:存储在/home/j/ti-sdk-e-11000008/yocto-build/build/arago-tmp-default-glibc/work/am69_sk-oe-linux/ti-edgeai-firmware/1.0.0/temp/log.do_fetch.3637824 中的失败日志文件
错误:任务 (/home/j/ti-sdk-e-11000008/yocto-build/sources/meta-edgeai/recipes-tisdk/ti-psdk-rtos/ti-edgeai-firmware.bb:do_fetch) 失败、退出代码为“1"</s>“
Jason Lee
