器件型号: AM62A7-Q1
你好
我在使用 DFU 下载(它在 EVM 板上提供)时在启动阶段遇到问题。
我收到了以下错误:
完成下载 tiboot3.bin 、我无法像那样下载其他固件 tispl.bin\u-boot.img
但是、U-Boot 中不会报告错误
DDR 配置是否不正确? 您是否有必要的 DDR 配置工具?
还是有任何调试方法?
Uboot 输出: U-Boot SPL 2025.01-g00064dce6f98-dirty (Dec 05 2025 - 17:41:31 +0800)SYSFW ABI: 4.0 (firmware rev 0x000b '11.1.5--v11.01.05 (Fancy Rat)')SPL initial stack usage: 13568 bytesTrying to boot from DFU
DFU 下载日志:
C:\Project\dfu>dfu-util.exe -d 0451:6165 -R -a 0 -D C:\Project\dfu\ospi\HS-FS\tiboot3.bindfu-util 0.11
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.Copyright 2010-2021 Tormod Volden and Stefan SchmidtThis program is Free Software and has ABSOLUTELY NO WARRANTYPlease report bugs to http://sourceforge.net/p/dfu-util/tickets/
Warning: Invalid DFU suffix signatureA valid DFU suffix will be required in a future dfu-util releaseOpening DFU capable USB device...Device ID 0451:6165Device DFU version 0110Claiming USB DFU Interface...Setting Alternate Interface #0 ...Determining device status...DFU state(2) = dfuIDLE, status(0) = No error condition is presentDFU mode device DFU version 0110Device returned transfer size 512Copying data from PC to DFU deviceDownload [=========================] 100% 313735 bytesDownload done.DFU state(6) = dfuMANIFEST-SYNC, status(0) = No error condition is presentDFU state(2) = dfuIDLE, status(0) = No error condition is presentDone!Resetting USB to switch back to Run-Time mode
C:\Project\dfu>dfu-util.exe -ldfu-util 0.11
Cannot open DFU device 17e9:4307 found on devnum 7 (LIBUSB_ERROR_NOT_FOUND)Failed to retrieve language identifiersFailed to retrieve language identifiersFailed to retrieve language identifiersFailed to retrieve language identifiersFound DFU: [0451:6165] ver=0200, devnum=14, cfg=1, intf=0, path="2-1.2.1.1", alt=1, name="UNKNOWN", serial="UNKNOWN"Found DFU: [0451:6165] ver=0200, devnum=14, cfg=1, intf=0, path="2-1.2.1.1", alt=0, name="UNKNOWN", serial="UNKNOWN"
