[参考译文] AM62A7:未找到 OTP Keywriter 安装程序文件
Guru**** 2952510 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1632379/am62a7-otp-keywriter-installer-file-not-found
器件型号: AM62A7
您好:
当我按照教程: https://dev.ti.com/tirex/explore/node?isTheia=false&node=A__ATqvV6-wrBeU0tHY69Ed3g__AM62A-ACADEMY__WeZ9SsL__LATEST
当我尝试从 am62a 安装 otp_keywriter 时,我得到这个错误:
~$ ./otp_keywriter_am62ax-linux-installer.run
-bash: ./otp_keywriter_am62ax-linux-installer.run: cannot execute: required file not found
如何识别丢失的文件?
Benjamin
    默认文件对应于 SDK 09.X.X;使用最新 SDK 的文件 (otp_keywriter_am62ax_11_01_00-linux-x64-installer.run) 可解决该问题。
