[参考译文] J784S4XEVM:UFS 闪存不在/dev 下
Guru**** 2952510 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1640134/j784s4xevm-ufs-flash-is-not-under-dev
器件型号: J784S4XEVM
你好
UFS 闪存不在/dev 下、因此我无法安装和使用它。 请帮帮我。
我将使用 ti-processor-sdk-linux-adas-j784s4-evm-11_02_00_04-linux-x86-Install.bin。 我已使用 bin/create-sdcard.sh 创建 SD 卡。
Mehmet
root@j784s4-evm:~# dmesg | grep ufs
[   14.825796] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[   14.836142] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[   14.847544] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[   14.865866] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[   14.902613] scsi host0: ufshcd
[   14.967958] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found
root@j784s4-evm:~#
root@j784s4-evm:~# lsblk
NAME         MAJ:MIN RM  SIZE RO TYPE MOUNTPOINTS
mtdblock0     31:0    0    1M  0 disk
mtdblock1     31:1    0    2M  0 disk
mtdblock2     31:2    0    4M  0 disk
mtdblock3     31:3    0  256K  0 disk
mtdblock4     31:4    0  256K  0 disk
mtdblock5     31:5    0 95.8M  0 disk
mtdblock6     31:6    0  256K  0 disk
mtdblock7     31:7    0  512K  0 disk
mtdblock8     31:8    0    2M  0 disk
mtdblock9     31:9    0    4M  0 disk
mtdblock10    31:10   0  256K  0 disk
mtdblock11    31:11   0  256K  0 disk
mtdblock12    31:12   0 55.8M  0 disk
mtdblock13    31:13   0  256K  0 disk
mmcblk0      179:0    0 29.6G  0 disk
`-mmcblk0p1  179:1    0 29.6G  0 part /run/media/eMMC-mmcblk0p1
mmcblk0boot0 179:32   0 31.5M  1 disk
mmcblk0boot1 179:64   0 31.5M  1 disk
mmcblk1      179:96   0 29.7G  0 disk
|-mmcblk1p1  179:97   0  128M  0 part /run/media/boot-mmcblk1p1
`-mmcblk1p2  179:98   0 29.6G  0 part /run/media/root-mmcblk1p2
root@j784s4-evm:~# ls /dev
autofs              gpiochip2  iio:device0   mapper        mtd10    mtd5        mtdblock13   ptp0   ptypb         remoteproc7  teepriv0  tty20  tty34  tty48  tty61   ttyS7  ttypc     vcsu7     watchdog3
block               gpiochip3  iio:device1   mem           mtd10ro  mtd5ro      mtdblock2    ptp1   ptypc         remoteproc8  tty       tty21  tty35  tty49  tty62   ttyS8  ttypd     vfio     watchdog4
bsg                 gpiochip4  initctl       mmcblk0       mtd11    mtd6        mtdblock3    ptp2   ptypd         remoteproc9  tty0      tty22  tty36  tty5   tty63   ttyS9  ttype     vga_arbiter  watchdog5
char                gpiochip5  kmsg          mmcblk0boot0  mtd11ro  mtd6ro      mtdblock4    pts    ptype         rfkill       tty1      tty23  tty37  tty50  tty7    ttyp0  ttypf     video-dec0   watchdog6
console             gpiochip6  kvm           mmcblk0boot1  mtd12    mtd7        mtdblock5    ptyp0  ptypf         rpmsg0       tty10     tty24  tty38  tty51  tty8    ttyp1  ubi_ctrl  video-dec1   watchdog7
cpu_dma_latency     gpiochip7  log           mmcblk0p1     mtd12ro  mtd7ro      mtdblock6    ptyp1  random        rpmsg_ctrl0  tty11     tty25  tty39  tty52  tty9    ttyp2  urandom   video-enc0   zero
cpu_wakeup_latency  hugepages  loop-control  mmcblk0rpmb   mtd13    mtd8        mtdblock7    ptyp2  remoteproc0   rtc          tty12     tty26  tty4   tty53  ttyS0   ttyp3  v4l       video-enc1
disk                hwrng      loop0         mmcblk1       mtd13ro  mtd8ro      mtdblock8    ptyp3  remoteproc1   rtc0         tty13     tty27  tty40  tty54  ttyS1   ttyp4  vcs       video0
dma_heap            i2c-0      loop1         mmcblk1p1     mtd1ro   mtd9        mtdblock9    ptyp4  remoteproc10  shm          tty14     tty28  tty41  tty55  ttyS10  ttyp5  vcs1      video1
dri                 i2c-3      loop2         mmcblk1p2     mtd2     mtd9ro      net          ptyp5  remoteproc11  snapshot     tty15     tty29  tty42  tty56  ttyS11  ttyp6  vcs7      video2
fd                  i2c-4      loop3         mqueue        mtd2ro   mtdblock0   null         ptyp6  remoteproc2   snd          tty16     tty3   tty43  tty57  ttyS2   ttyp7  vcsa      video3
full                i2c-5      loop4         mtd           mtd3     mtdblock1   pfsm-0-0x48  ptyp7  remoteproc3   stderr       tty17     tty30  tty44  tty58  ttyS3   ttyp8  vcsa1     watchdog
fuse                i2c-6      loop5         mtd0          mtd3ro   mtdblock10  port         ptyp8  remoteproc4   stdin        tty18     tty31  tty45  tty59  ttyS4   ttyp9  vcsa7     watchdog0
gpiochip0           i2c-7      loop6         mtd0ro        mtd4     mtdblock11  pps0         ptyp9  remoteproc5   stdout       tty19     tty32  tty46  tty6   ttyS5   ttypa  vcsu      watchdog1
gpiochip1           i2c-8      loop7         mtd1          mtd4ro   mtdblock12  ptmx         ptypa  remoteproc6   tee0         tty2      tty33  tty47  tty60  ttyS6   ttypb  vcsu1     watchdog2
root@j784s4-evm:~#
