[参考译文] J721EXSOMXEVM:无法写入 eMMC,错误消息:mmc0:正在运行 CQE 恢复
Guru**** 2824385 points
Other Parts Discussed in Thread: TDA4VM
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1067022/j721exsomxevm-emmc-cannot-be-written-error-message-mmc0-running-cqe-recovery
部件号:J721EXSOMXEVM
“线程”中讨论的其他部件:TDA4TDA4VM
您好,TI 专家:
在我们自定义的 TDA4主板上,eMMC 启动模式存在一些问题:
1.在 uboot 环境中写入“MMC write”命令后,通过 fatls MMC 0:1,发现写入不成功。
2.在 rootfs 下,使用"mount"命令装入/dev/mmcblk0p1分区后,该文件无法写入/dev/mmcblk0p1挂载目录,并显示错误消息:
[  254.175518] mmc0: running CQE recovery
[  254.191763] mmc0: running CQE recovery
[  254.208257] mmc0: running CQE recovery
[  254.223659] mmc0: running CQE recovery
3.  eMMC 的硬件电路与 TDA4VM 板的硬件电路相同
4. 以下系统启动日志信息:
U-Boot SPL 2021.01-00002-gad9e21bc51-dirty (Jan 06 2022 - 17:33:59 +0800)
Model: Texas Instruments K3 J721E SoC
EEPROM not available at 0x50, trying to read at 0x51
Reading on-board EEPROM at 0x51 failed 1
Board: J721EX-PM1-SOM rev E2
SYSFW ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
Trying to boot from MMC2
Starting ATF on ARM64 core...
NOTICE:  BL31: v2.5(release):08.00.00.004-dirty
NOTICE:  BL31: Built : 22:30:09, Aug  4 2021
U-Boot SPL 2021.01-00002-gad9e21bc51-dirty (Jan 06 2022 - 17:33:56 +0800)
U-Boot 2021.01-00002-gad9e21bc51-dirty (Jan 06 2022 - 17:33:56 +0800)
SoC:   J721E SR1.0
DRAM:  4 GiB
Flash: 0 Bytes
MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
Loading Environment from MMC... OK
In:    serial@2800000
Out:   serial@2800000
Err:   serial@2800000
Net:   Could not get PHY for ethernet@46000000: addr 0
am65_cpsw_nuss_slave ethernet@46000000: phy_connect() failed
No ethernet found.
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
SD/MMC found on device 1
Failed to load 'boot.scr'
0 bytes read in 3 ms (0 Bytes/s)
Loaded env from uEnv.txt
Importing environment from mmc1 ...
19137024 bytes read in 864 ms (21.1 MiB/s)
97562 bytes read in 19 ms (4.9 MiB/s)
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Device Tree to 000000008fee5000, end 000000008fffffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.41-g4c2eade9f7 (meta@meta) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 1
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a8ffffff]
[    0.000000]   node   0: [mem 0x00000000a9000000-0x00000000a9ffffff]
[    0.000000]   node   0: [mem 0x00000000aa000000-0x00000000abbfffff]
[    0.000000]   node   0: [mem 0x00000000abc00000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboott
[    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[    0.000000] Memory: 3372032K/4194304K available (10816K kernel code, 1344K rwdata, 4288K rodata, 1856K init, 758K bss, 297984K reser)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008800b0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4d4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008353] Console: colour dummy device 80x25
[    0.012914] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023584] pid_max: default: 32768 minimum: 301
[    0.028329] LSM: Security Framework initializing
[    0.033074] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.040640] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[    0.049584] rcu: Hierarchical SRCU implementation.
[    0.054634] Platform MSI: msi-controller@1820000 domain created
[    0.060859] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070152] EFI services will not be available.
[    0.074900] smp: Bringing up secondary CPUs ...
[    0.080077] Detected PIPT I-cache on CPU1
[    0.080102] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.080113] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[    0.080146] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.080197] smp: Brought up 1 node, 2 CPUs
[    0.109542] SMP: Total of 2 processors activated.
[    0.114347] CPU features: detected: 32-bit EL0 Support
[    0.119601] CPU features: detected: CRC32 instructions
[    0.133271] CPU: All CPU(s) started at EL2
[    0.137464] alternatives: patching kernel code
[    0.142452] devtmpfs: initialized
[    0.150689] KASLR disabled due to lack of seed
[    0.155339] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.165303] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[    0.172974] pinctrl core: initialized pinctrl subsystem
[    0.178546] DMI not present or invalid.
[    0.182761] NET: Registered protocol family 16
[    0.190244] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.197545] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.205549] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.213853] thermal_sys: Registered thermal governor 'step_wise'
[    0.213855] thermal_sys: Registered thermal governor 'power_allocator'
[    0.220264] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.233904] ASID allocator initialised with 65536 entries
[    0.256165] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[    0.263020] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[    0.269781] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.277681] cryptd: max_cpu_qlen set to 1000
[    0.283673] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
[    0.292500] vsys_3v3: supplied by evm_12v0
[    0.296807] vsys_5v0: supplied by evm_12v0
[    0.301095] vdd_mmc1: supplied by vsys_3v3
[    0.305719] iommu: Default domain type: Translated
[    0.310903] SCSI subsystem initialized
[    0.315024] mc: Linux media interface: v0.10
[    0.319396] videodev: Linux video capture interface: v2.00
[    0.325022] pps_core: LinuxPPS API ver. 1 registered
[    0.330092] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.339429] PTP clock support registered
[    0.343448] EDAC MC: Ver: 3.0.0
[    0.347180] FPGA manager framework
[    0.350690] Advanced Linux Sound Architecture Driver Initialized.
[    0.357273] clocksource: Switched to clocksource arch_sys_counter
[    0.363683] VFS: Disk quotas dquot_6.6.0
[    0.367729] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[    0.377416] NET: Registered protocol family 2
[    0.382001] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[    0.390610] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[    0.399379] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[    0.407574] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[    0.415366] TCP: Hash tables configured (established 32768 bind 32768)
[    0.422114] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.429006] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[    0.436403] NET: Registered protocol family 1
[    0.441081] RPC: Registered named UNIX socket transport module.
[    0.447142] RPC: Registered udp transport module.
[    0.451946] RPC: Registered tcp transport module.
[    0.456749] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.463334] PCI: CLS 0 bytes, default 64
[    0.467676] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.477886] Initialise system trusted keyrings
[    0.482501] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[    0.490784] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.496974] NFS: Registering the id_resolver key type
[    0.502165] Key type id_resolver registered
[    0.506436] Key type id_legacy registered
[    0.510555] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.517403] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.525093] 9p: Installing v9fs 9p2000 file system support
[    0.550376] Key type asymmetric registered
[    0.554562] Asymmetric key parser 'x509' registered
[    0.559559] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.567118] io scheduler mq-deadline registered
[    0.571743] io scheduler kyber registered
[    0.576955] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.583111] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.591511] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.597785] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.605649] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.613722] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.622692] arm-smmu-v3 36600000.iommu: allocated 524288 entries for cmdq
[    0.631517] arm-smmu-v3 36600000.iommu: allocated 524288 entries for evtq
[    0.639226] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.651871] brd: module loaded
[    0.657760] loop: module loaded
[    0.661571] megasas: 07.714.04.00-rc1
[    0.666507] libphy: Fixed MDIO Bus: probed
[    0.671150] tun: Universal TUN/TAP device driver, 1.6
[    0.676559] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.682965] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.689037] sky2: driver version 1.30
[    0.693282] VFIO - User Level meta-driver version: 0.3
[    0.698936] i2c /dev entries driver
[    0.703099] sdhci: Secure Digital Host Controller Interface driver
[    0.709418] sdhci: Copyright(c) Pierre Ossman
[    0.714036] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.720343] ledtrig-cpu: registered to indicate activity on CPUs
[    0.726654] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.733767] optee: probing for conduit method.
[    0.738320] optee: revision 3.12 (3d47a131)
[    0.738553] optee: initialized driver
[    0.747833] NET: Registered protocol family 17
[    0.752445] 9pnet: Installing 9P2000 support
[    0.756829] Key type dns_resolver registered
[    0.761282] Loading compiled-in X.509 certificates
[    0.770370] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.776701] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.784765] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.5.0--v2021.05 (Terrific Llam')
[    0.811335] random: fast init done
[    0.837400] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    0.844722] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[    0.850781] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[    0.856821] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[    0.863199] pca953x 3-0020: supply vcc not found, using dummy regulator
[    0.870015] pca953x 3-0020: using no AI
[    0.897317] pca953x 3-0020: failed writing register
[    0.902354] pca953x: probe of 3-0020 failed with error -121
[    0.908393] pca953x 3-0022: supply vcc not found, using dummy regulator
[    0.915192] pca953x 3-0022: using AI
[    0.918891] pca953x 3-0022: failed writing register
[    0.923914] pca953x: probe of 3-0022 failed with error -121
[    0.929651] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[    0.936071] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[    0.946084] omap_i2c 2020000.i2c: bus 5 rev0.12 at 400 kHz
[    0.952379] pca953x 6-0020: supply vcc not found, using dummy regulator
[    0.959198] pca953x 6-0020: using no AI
[    0.985318] pca953x 6-0020: failed writing register
[    0.990352] pca953x: probe of 6-0020 failed with error -121
[    0.996451] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz
[    1.002506] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[    1.008443] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[    1.014674] pca953x 9-0020: supply vcc not found, using dummy regulator
[    1.021482] pca953x 9-0020: using no AI
[    1.049316] pca953x 9-0020: failed writing register
[    1.054346] pca953x: probe of 9-0020 failed with error -121
[    1.060377] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz
[    1.066753] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[    1.076714] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[    1.085510] ti-sci-intr bus@100000:main-navss:interrupt-controller1: Interrupt Router 213 domain created
[    1.095330] ti-sci-inta 33d00000.interrupt-controller: Interrupt Aggregator domain 209 created
[    1.115023] cdns-torrent-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps
[    1.122683] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.130357] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.138634] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.146911] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.155745] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.163409] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.171688] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.179965] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.188724] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.196388] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.204663] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.212939] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.222065] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235
[    1.231945] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[    1.238705] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.247678] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211
[    1.257832] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[    1.264591] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64
[    1.272520] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[    1.281871] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 33, base_baud = 3000000) is a 8250
[    1.290615] printk: console [ttyS2] enabled
[    1.299050] printk: bootconsole [ns16550a0] disabled
[    1.309474] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 34, base_baud = 3000000) is a 8250
[    1.318384] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 35, base_baud = 3000000) is a 8250
[    1.328715] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    1.339229] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    1.349385] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    1.359624] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    1.370380] scsi host0: ufshcd
[    1.413278] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.420925] libphy: 46000f00.mdio: probed
[    1.425138] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.431864] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirk0
[    1.445605] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    1.454378] mmc0: CQHCI version 5.10
[    1.458010] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.469461] pca953x 4-0020: supply vcc not found, using dummy regulator
[    1.476111] pca953x 4-0020: using no AI
[    1.497296] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    1.504848] pca953x 4-0020: failed writing register
[    1.509775] pca953x: probe of 4-0020 failed with error -121
[    1.515704] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    1.522538] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    1.529345] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    1.536151] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    1.542940] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    1.552294] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    1.559788] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    1.567867] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    1.575948] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.584591] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    1.592087] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    1.592764] mmc0: Command Queue Engine enabled
[    1.600167] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    1.604593] mmc0: new HS400 MMC card at address 0001
[    1.612666] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.617860] mmcblk0: mmc0:0001 016GB2 14.7 GiB
[    1.630482] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    1.630515] mmcblk0boot0: mmc0:0001 016GB2 partition 1 8.00 MiB
[    1.637967] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    1.643947] mmcblk0boot1: mmc0:0001 016GB2 partition 2 8.00 MiB
[    1.651933] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    1.657901] mmcblk0rpmb: mmc0:0001 016GB2 partition 3 4.00 MiB, chardev (237:0)
[    1.665900] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    1.679408] mmc0: running CQE recovery
[    1.685729] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.695784] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    1.697741]  mmcblk0: p1 p2
[    1.709807] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    1.716681] spi-nor: probe of spi0.0 failed with error -2
[    1.724038] spi-nor spi1.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[    1.730914] spi-nor: probe of spi1.0 failed with error -2
[    1.773279] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.780925] libphy: 46000f00.mdio: probed
[    1.785140] mdio_bus 46000f00.mdio: MDIO device at address 0 is missing.
[    1.786848] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    1.791865] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirk0
[    1.797295] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    1.797298] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    1.821346] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    1.827777] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    1.834662] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    1.834665] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    1.841260] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    1.841263] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    1.858547] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    1.866710] cdns-ufshcd 4e84000.ufs: last intr at 1680460 us, last intr status=0x404
[    1.866799] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.874438] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    1.881639] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.889099] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    1.904027] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    1.910025] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    1.910231] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    1.916288] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    1.931315] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    1.937403] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate 0
[    1.949569] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    1.955915] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    1.962265] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    1.962290] davinci-mcasp 2ba0000.mcasp: IRQ common not found
[    1.968610] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    1.974610] mmc1: CQHCI version 5.10
[    1.980675] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    1.990587] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    1.996933] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    2.003279] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    2.009622] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    2.015965] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    2.022310] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    2.027613] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    2.032915] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    2.038218] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    2.043520] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    2.048909] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    2.055079] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    2.060643] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1681580 us
[    2.067768] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    2.073503] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    2.079325] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    2.084889] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    2.090537] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    2.099778] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.107275] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.115361] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.123441] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.131998] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.139489] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.147574] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.155652] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.164186] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.171674] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.179758] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.187836] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.197046] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.204532] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.212611] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.220691] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.229230] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.236723] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.244803] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.252881] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.261404] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.268895] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.276977] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.285055] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.294977] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    2.302380] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    2.309698] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    2.317004] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    2.325036] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    2.332294] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    2.339808] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    2.347909] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    2.356000] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.364676] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.372188] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.380277] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.388361] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.396990] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    2.404487] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    2.412572] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    2.420656] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.436959] ALSA device list:
[    2.439934]   No soundcards found.
[    3.027934] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    3.036015] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.043596] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.051684] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.059776] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.068214] Waiting for root device PARTUUID=89349f4e-02...
[    3.068449] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.081292] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.089385] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.097528] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.106232] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.113778] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.121868] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.129991] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.162496] mmc1: new high speed SDXC card at address b368
[    3.168281] mmcblk1: mmc1:b368 NCard 58.2 GiB
[    3.176829]  mmcblk1: p1 p2
[    3.180450] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    3.187951] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    3.196032] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    3.204112] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.212667] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    3.220166] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    3.228245] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    3.236323] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.244852] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    3.252345] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    3.260424] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    3.268504] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    3.969237] EXT4-fs (mmcblk1p2): recovery complete
[    3.977196] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.985304] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    4.003903] devtmpfs: mounted
[    4.007153] Freeing unused kernel memory: 1856K
[    4.011704] Run /sbin/init as init process
[    4.389596] systemd[1]: System time before build time, advancing clock.
[    4.505364] NET: Registered protocol family 10
[    4.510232] Segment Routing with IPv6
[    4.542362] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPT)
[    4.564080] systemd[1]: Detected architecture arm64.
Welcome to Arago 2020.09!
[    4.599126] systemd[1]: Set hostname to <j7-evm>.
[    4.994649] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updat.
[    5.108532] random: systemd: uninitialized urandom read (16 bytes read)
[    5.115253] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewal.
[    5.127578] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    5.137428] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    5.157347] random: systemd: uninitialized urandom read (16 bytes read)
[    5.164607] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    5.185347] random: systemd: uninitialized urandom read (16 bytes read)
[    5.192473] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    5.213467] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password ��…ts to Console Directory Watch.
[    5.237378] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R��…uests to Wall Directory Watch.
[    5.261391] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    5.281328] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    5.301318] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    5.321320] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    5.354404] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    5.377351] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    5.400434] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    5.421447] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    5.466196] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    5.474509] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    5.497530] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    5.517572] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    5.541497] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    5.561439] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    5.584229] systemd[1]: Mounting Huge Pages File System...
[    5.608556] systemd[1]: Mounting POSIX Message Queue File System...
[    5.631471] systemd[1]: Mounting Kernel Debug File System...
[    5.658066] systemd[1]: Mounting Temporary Directory (/tmp)...
[    5.679575] systemd[1]: Starting Create list of static device nodes for the current kernel...
         Starting Create list of st��…odes for the current kernel...
[    5.711912] systemd[1]: Starting Start psplash boot splash screen...
[    5.752504] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[    5.780797] systemd[1]: Starting RPC Bind...
[    5.797466] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    5.809213] systemd[1]: Starting Journal Service...
[    5.839622] systemd[1]: Starting Load Kernel Modules...
[    5.856808] cryptodev: loading out-of-tree module taints kernel.
[    5.867424] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.877648] cryptodev: driver 1.10 loaded.
[    5.889255] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[    5.899593] systemd[1]: Starting udev Coldplug all Devices...
[    5.923803] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    5.937723] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted Huge Pages File System.
[    5.957630] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    5.985653] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Started Create list of sta��… nodes for the current kernel.
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star��…progress communication helper.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[    6.165519] systemd-journald[166]: Received client request to flush runtime journal.
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
[  OK  ] Started udev Coldplug all Devices.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
         Starting Docker Socket for the API.
[  OK  ] Listening on dropbear.socket.
         Starting Reboot and dump vmcore via kexec...
[  OK  ] Listening on Docker Socket for the API.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.[    6.866998] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    6.879245] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    6.891094] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    6.905321] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    6.914941] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[  OK  ] Started Periodic Command Scheduler   6.927745] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[0m.
[    6.942460] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[  OK  ] Started D-Bus System Message Bus    6.956181] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
m.
[    6.973846] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
         Starting Print notice about GPLv3 packages[    6.992238] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000
[    7.006316] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework    7.025404] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x00000
m...
[    7.047547] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.061366] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.071765] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.084135] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started irqbalance daemon.
         Starting Telephony service...
         Starting rc.pvr.service...
         Starting Login Service...
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Reached target Network (Pre).
         Starting Network Service...
[    7.409176] PVR_K:  257: Read BVNC 22.104.208.318 from HW device registers
[    7.417526] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.425232] PVR_K:  257: RGX Device registered with BVNC 22.104.208.318
[    7.431991] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.440137] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.452172] ina2xx 5-0040: error configuring the device: -121
[    7.458048] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.473436] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    7.481315] [drm] Initialized pvr 1.13.5776728 20170530 for 4e20000000.gpu on minor 0
[    7.489219] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    7.498037] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    7.513366] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.532439] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.545357] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.561116] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.576835] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.589401] ina2xx 5-0041: error configuring the device: -121
[    7.595723] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.605243] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.618430] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.633310] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.645135] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    7.645301] ina2xx 5-0042: error configuring the device: -121
[    7.656803] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    7.673361] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    7.681482] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.691264] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.700520] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.710553] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    7.720387] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
         Starting Network Name Resolution...
[  OK  ] Started Telephony service.
[    7.854903] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    7.863919] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    7.879827] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    7.891148] ina2xx 5-0043: error configuring the device: -121
[    7.897003] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.901461] ina2xx 5-0044: error configuring the device: -121
[    7.921553] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    7.930955] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    7.937462] ina2xx 5-0045: error configuring the device: -121
[    7.945316] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    7.957324] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    7.974181] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    7.985318] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    7.993429] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.003247] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.013163] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.013181] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.013190] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.013199] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.014611] Bluetooth: Core ver 2.22
[    8.021157] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.041930] NET: Registered protocol family 31
[    8.049109] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[  OK  ] Started Network Name Resolution[    8.073318] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[  OK  ] Reached target Network.
[    8.077019] Bluetooth: HCI device and connection manager initialized
0;32m  OK  ] Reached target Host and Network Name L[    8.082779] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x00
ookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx b[    8.117305] Bluetooth: HCI socket layer initialized
luetooth stack...
[    8.124589] Bluetooth: L2CAP socket layer initialized
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma�[    8.141693] Bluetooth: SCO socket layer initialized
�…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Login Service.
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS2.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[    8.239887] ina2xx 5-0046: error configuring the device: -121
[    8.259611] img_dec 4300000.video-decoder: decoder registered as /dev/video0
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[    8.356846] ina2xx 5-0047: error configuring the device: -121
[    8.399903] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.409135] k3-dsp-rproc 4d80800000.dsp: assigned reserved memory node c66-dma-memory@a7000000
[    8.417786] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.425897] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.440169] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.457563] ina2xx 5-0048: error configuring the device: -121
[    8.463395] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.471622] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.485377] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.493579] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.495628] k3-dsp-rproc 4d80800000.dsp: configured DSP for remoteproc mode
[    8.508917] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.518300] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    8.527905] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.541313] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.544374] ina2xx 5-0049: error configuring the device: -121
[    8.619724] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.629365] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.643780] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.651949] k3-dsp-rproc 4d80800000.dsp: local reset is deasserted for device
[    8.658601] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.674894] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.684376] remoteproc remoteproc0: 4d80800000.dsp is available
[    8.686942] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.699786] ina2xx 5-004a: error configuring the device: -121
[    8.705341] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.718471] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.732045] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.743377] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    8.747545] k3-dsp-rproc 4d81800000.dsp: assigned reserved memory node c66-dma-memory@a6000000
[    8.753134] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.773300] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.781725] remoteproc remoteproc0: powering up 4d80800000.dsp
[    8.786116] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.787647] remoteproc remoteproc0: Booting fw image j7-c66_0-fw, size 187480
[    8.796967] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.812875] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.814030] ina2xx 5-004b: error configuring the device: -121
[    8.820977] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.826944] k3-dsp-rproc 4d80800000.dsp: booting DSP core using boot addr = 0xa6200000
[    8.842295] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    8.850557]  remoteproc0#vdev0buffer: assigned reserved memory node c66-dma-memory@a7000000
[    8.853063] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    8.860885] virtio_rpmsg_bus virtio0: rpmsg host is online
[    8.870671] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    8.881031]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[    8.883338] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.893275] remoteproc remoteproc0: remote processor 4d80800000.dsp is now up
[    8.899702] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    8.910131] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    8.919110] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    8.929317] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    8.939094] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    8.947226] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.958639] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    8.967481] k3-dsp-rproc 4d81800000.dsp: configured DSP for remoteproc mode
[    8.968071] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    8.983905] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    8.993572] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    8.995176] ina2xx 5-004c: error configuring the device: -121
[    9.006013] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.016263] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.025892] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.035754] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.049188] k3-dsp-rproc 4d81800000.dsp: local reset is deasserted for device
[    9.061299] random: crng init done
[    9.064691] random: 7 urandom warning(s) missed due to ratelimiting
[    9.077392] remoteproc remoteproc1: 4d81800000.dsp is available
[    9.090266] mmc0: running CQE recovery
[    9.094132] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.096702] ina2xx 5-004d: error configuring the device: -121
[    9.105296] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.117481] k3-dsp-rproc 64800000.dsp: assigned reserved memory node c71-dma-memory@a8000000
[    9.121290] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.137345] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.151176] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.158839] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.168447] k3-dsp-rproc 64800000.dsp: configured DSP for remoteproc mode
[    9.173295] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.183338] ina2xx 5-004e: error configuring the device: -121
[    9.185298] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.197505] remoteproc remoteproc1: powering up 4d81800000.dsp
[    9.201350] remoteproc remoteproc2: 64800000.dsp is available
[    9.203368] remoteproc remoteproc1: Booting fw image j7-c66_1-fw, size 187480
[    9.217491] ina2xx 5-004f: error configuring the device: -121
[    9.223356] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.231120] k3-dsp-rproc 4d81800000.dsp: booting DSP core using boot addr = 0xa7200000
[    9.241329] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.249675]  remoteproc1#vdev0buffer: assigned reserved memory node c66-dma-memory@a6000000
[    9.260499] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.269051] virtio_rpmsg_bus virtio1: rpmsg host is online
[    9.276922] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    9.281349]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[    9.296063] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.296067] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    9.314854] remoteproc remoteproc1: remote processor 4d81800000.dsp is now up
[    9.322714] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.333336] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.341430] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.356723] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.366537] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.377335] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.389316] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.397417] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.410079] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.419489] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.433291] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.441383] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.729496] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    9.794149] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.801649] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.817314] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[    9.832572] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.847955] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[    9.861310] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[    9.869452] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[    9.885311] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.896485] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    9.906058] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    9.920200] platform 41000000.r5f: configured R5F for IPC-only mode
[    9.921319] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    9.937210] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    9.957499] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[    9.966378] remoteproc remoteproc2: powering up 64800000.dsp
[    9.972114] remoteproc remoteproc2: Booting fw image j7-c71_0-fw, size 10489872
[    9.980366] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[    9.993369] remoteproc remoteproc2: unsupported resource 65538
[    9.999300] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.008133] k3-dsp-rproc 64800000.dsp: booting DSP core using boot addr = 0xa8e00000
[   10.015911] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.060634] CAN device driver interface
[   10.065499]  remoteproc2#vdev0buffer: assigned reserved memory node c71-dma-memory@a8000000
[   10.077621] virtio_rpmsg_bus virtio2: rpmsg host is online
[   10.083152]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[   10.092075] remoteproc remoteproc2: remote processor 64800000.dsp is now up
[   10.101899] virtio_rpmsg_bus virtio2: creating channel ti.ipc4.ping-pong addr 0xd
[   10.110087] virtio_rpmsg_bus virtio2: creating channel rpmsg_chrdev addr 0xe
[   10.117814] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   10.131056] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   10.145168] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   10.159385] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.171722] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[   10.180967] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   10.188668] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   10.201330] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   10.209443] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.225441] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   10.232952] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   10.245326] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   10.253464] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   10.275191] [drm] Initialized tidss 1.0.0 20180215 for 4a00000.dss on minor 1
[   10.282367] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.290635] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   10.336131] remoteproc remoteproc3: 41000000.r5f is available
[   10.367058] mmc0: running CQE recovery
[   10.382865] mmc0: running CQE recovery
[   10.397851] mmc0: running CQE recovery
[   10.413754] mmc0: running CQE recovery
[   10.485442] remoteproc remoteproc3: attaching to 41000000.r5f
[   10.611646] platform 41000000.r5f: R5F core initialized in IPC-only mode
[   10.657618]  remoteproc3#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[   10.706796] virtio_rpmsg_bus virtio3: rpmsg host is online
[   10.717966] virtio_rpmsg_bus virtio3: creating channel ti.ipc4.ping-pong addr 0xd
[   10.726812] virtio_rpmsg_bus virtio3: creating channel rpmsg_chrdev addr 0xe
[   10.789773]  remoteproc3#vdev0buffer: registered virtio3 (type 7)
[   10.830481] am65-cpsw-nuss 46000000.ethernet: phy /bus@100000/bus@28380000/ethernet@46000000/mdio@f00/ethernet-phy@0 not found on sl1
[   10.880350] remoteproc remoteproc3: remote processor 41000000.r5f is now attached
[   10.965236] platform 5c00000.r5f: configured R5F for remoteproc mode
[   11.024985] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[   11.083847] remoteproc remoteproc4: 5c00000.r5f is available
[   11.116504] mmc0: running CQE recovery
[   11.142043] mmc0: running CQE recovery
[   11.158690] mmc0: running CQE recovery
[   11.210386] platform 5d00000.r5f: configured R5F for remoteproc mode
[   11.278996] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[   11.288731] remoteproc remoteproc4: powering up 5c00000.r5f
[   11.294328] remoteproc remoteproc4: Booting fw image j7-main-r5f0_0-fw, size 527528
[   11.307756]  remoteproc4#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[   11.321585] virtio_rpmsg_bus virtio4: rpmsg host is online
[   11.327125]  remoteproc4#vdev0buffer: registered virtio4 (type 7)
[   11.333223] remoteproc remoteproc4: remote processor 5c00000.r5f is now up
[   11.347884] mmc0: running CQE recovery
[   11.429717] mmc0: running CQE recovery
[  OK  ] Started Simple Network Man��…ement Protocol (SNMP) Daemon..
[   11.569105] mmc0: running CQE recovery
[   11.581530] remoteproc remoteproc5: 5d00000.r5f is available
[   11.644995] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   11.798585] mmc0: running CQE recovery
[   11.827247] mmc0: running CQE recovery
[   11.831160] remoteproc remoteproc5: powering up 5d00000.r5f
[   11.836762] remoteproc remoteproc5: Booting fw image j7-main-r5f0_1-fw, size 78708
[   11.845745] mmc0: running CQE recovery
[   11.852311]  remoteproc5#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[   11.865585] virtio_rpmsg_bus virtio5: rpmsg host is online
[   11.876788]  remoteproc5#vdev0buffer: registered virtio5 (type 7)
[   11.879695] virtio_rpmsg_bus virtio5: creating channel ti.ipc4.ping-pong addr 0xd
[   11.890364] remoteproc remoteproc5: remote processor 5d00000.r5f is now up
[   11.912069] platform 5e00000.r5f: configured R5F for remoteproc mode
[   11.912978] virtio_rpmsg_bus virtio5: creating channel rpmsg_chrdev addr 0xe
[   11.927727] virtio_rpmsg_bus virtio4: creating channel ti.ethfw.notifyservice addr 0x1e
[   11.970952] virtio_rpmsg_bus virtio4: creating channel rpmsg-kdrv addr 0x1a
[   11.979235] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: Device info: permissions: 07FFFFFF uart_id: 2
[   11.993201] rpmsg-kdrv-eth-switch rpmsg-kdrv-2-mpu_1_0_ethswitch-device-0: FW ver 0.1 (rev 1) 13/Jul/2021 SHA:4cb38131
[   12.062138] platform 5e00000.r5f: assigned reserved memory node r5f-dma-memory@a4000000
[   12.083053] mmc0: running CQE recovery
[   12.248589] remoteproc remoteproc6: 5e00000.r5f is available
[   12.304286] mmc0: running CQE recovery
[   12.344697] mmc0: running CQE recovery
[   12.359584] mmc0: running CQE recovery
[   12.413522] platform 5f00000.r5f: configured R5F for remoteproc mode
[   12.414081] mmc0: running CQE recovery
[   12.423782] remoteproc remoteproc6: powering up 5e00000.r5f
[   12.429355] remoteproc remoteproc6: Booting fw image j7-main-r5f1_0-fw, size 78708
[   12.446632]  remoteproc6#vdev0buffer: assigned reserved memory node r5f-dma-memory@a4000000
[   12.460017] virtio_rpmsg_bus virtio6: rpmsg host is online
[   12.470216]  remoteproc6#vdev0buffer: registered virtio6 (type 7)
[   12.474496] virtio_rpmsg_bus virtio6: creating channel ti.ipc4.ping-pong addr 0xd
[   12.485119] virtio_rpmsg_bus virtio6: creating channel rpmsg_chrdev addr 0xe
[   12.485289] remoteproc remoteproc6: remote processor 5e00000.r5f is now up
[   12.651473] platform 5f00000.r5f: assigned reserved memory node r5f-dma-memory@a5000000
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[   12.895798] remoteproc remoteproc7: 5f00000.r5f is available
[   13.037959] remoteproc remoteproc7: powering up 5f00000.r5f
[   13.043577] remoteproc remoteproc7: Booting fw image j7-main-r5f1_1-fw, size 78708
[   13.059616]  remoteproc7#vdev0buffer: assigned reserved memory node r5f-dma-memory@a5000000
[   13.072362] virtio_rpmsg_bus virtio7: rpmsg host is online
[   13.083485]  remoteproc7#vdev0buffer: registered virtio7 (type 7)
[   13.087654] virtio_rpmsg_bus virtio7: creating channel ti.ipc4.ping-pong addr 0xd
[   13.095046] remoteproc remoteproc7: remote processor 5f00000.r5f is now up
[   13.111285] virtio_rpmsg_bus virtio7: creating channel rpmsg_chrdev addr 0xe
[   13.507423] mmc0: running CQE recovery
[   13.521638] mmc0: running CQE recovery
[   13.629611] mmc0: running CQE recovery
[   13.646963] mmc0: running CQE recovery
[   13.669750] EXT4-fs (mmcblk0p2): VFS: Found ext4 filesystem with invalid superblock checksum.  Run e2fsck?
[   13.762930] usbcore: registered new interface driver usbfs
[   13.776804] mmc0: running CQE recovery
[   13.792993] mmc0: running CQE recovery
[   13.806157] cdns-csi2rx 4504000.csi-bridge: Probed CSI2RX with 2/4 lanes, 4 streams, external D-PHY
[   13.848950] mmc0: running CQE recovery
[   13.861579] usbcore: registered new interface driver hub
[   13.883555] mmc0: running CQE recovery
[   13.898762] mmc0: running CQE recovery
[   13.913686] mmc0: running CQE recovery
[   13.920139] cdns-csi2rx: probe of 4514000.csi-bridge failed with error -22
[   13.959692] usbcore: registered new device driver usb
[   14.002480] remoteproc remoteproc8: b034000.pru is available
[   14.045642] omap_rng 4e10000.rng: Random Number Generator ver. 241b34c
[   14.134960] remoteproc remoteproc9: b004000.rtu is available
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org j7-evm ttyS2
Arago 2020.09 j7-evm ttyS2
j7-evm login: [   14.320143] remoteproc remoteproc10: b00a000.txpru is available
[   14.440684] remoteproc remoteproc11: b038000.pru is available
[   14.525896] remoteproc remoteproc12: b006000.rtu is available
[   14.596276] remoteproc remoteproc13: b00c000.txpru is available
[   14.663638] mmc0: running CQE recovery
[   14.672040] remoteproc remoteproc14: b134000.pru is available
[   14.689251] mmc0: running CQE recovery
[   14.689607] remoteproc remoteproc15: b104000.rtu is available
[   14.705444] mmc0: running CQE recovery
[   14.815451] remoteproc remoteproc16: b10a000.txpru is available
[   14.900670] remoteproc remoteproc17: b138000.pru is available
[   14.923573] remoteproc remoteproc18: b106000.rtu is available
[   14.941586] remoteproc remoteproc19: b10c000.txpru is available
[   15.221506] PVR_K:  877: RGX Firmware image 'rgx.fw.22.104.208.318' loaded
[   15.816490] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   15.825405] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[   15.837709] xhci-hcd xhci-hcd.2.auto: hcc params 0x200073c9 hci version 0x100 quirks 0x0000002000010010
[   15.853317] xhci-hcd xhci-hcd.2.auto: irq 614, io mem 0x06410000
[   15.859906] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   15.873290] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.885289] usb usb1: Product: xHCI Host Controller
[   15.893288] usb usb1: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   15.901296] usb usb1: SerialNumber: xhci-hcd.2.auto
[   15.910120] hub 1-0:1.0: USB hub found
[   15.917319] hub 1-0:1.0: 1 port detected
[   15.922067] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[   15.933296] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[   15.945302] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[   15.957324] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.965613] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[   15.981300] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.988649] usb usb2: Product: xHCI Host Controller
[   16.001289] usb usb2: Manufacturer: Linux 5.10.41-g4c2eade9f7 xhci-hcd
[   16.007945] usb usb2: SerialNumber: xhci-hcd.2.auto
[   16.017815] hub 2-0:1.0: USB hub found
[   16.022048] hub 2-0:1.0: 1 port detected
[   16.710399] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   16.717340] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.724590] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   16.730657] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.740971] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.749249] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.760386] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.768682] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.779343] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.787657] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.798339] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.806638] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.816973] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.825323] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   16.836351] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
***************************************************************[   16.848652] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr0
NOTICE: This file system contains the following GPLv3 packages[   16.863351] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        co[   16.872946] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
reutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfsto[   16.887095] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
ols
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
[   16.897225] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav-dev
[   16.912298] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
        gstreamer1.0-libav
        gzip
        less
        libasm1
        libbfd
        libdw1
        [   16.921283] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextl[   16.936294] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
ib
        libgettextsrc
        libgmp-dev
        libgmp10
        libgmpxx4
        libidn2[   16.945291] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
-0
        libidn2-dev
        libmpc3
        libmpfr6
        libreadline-dev
        librea[   16.960293] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
dline8
        libunistring-dev
        libunistring2
        m4-dev
        m4
        make
[   16.970086] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
        nettle-dev
        nettle
        parted
        python3-rfc3987
        python3-strict[   16.984236] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
-rfc3339
        tar
        which
        zeromq
If you do not wish to distrib[   16.994293] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
ute GPLv3 components please remove
the above packages prior to [   17.008520] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
distribution.  This can be done using
the opkg remove command. [   17.018654] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
 i.e.:
    opkg remove <package>
Where <package> is the name p[   17.032802] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
rinted in the list above
NOTE: If the package is a dependency[   17.042937] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
 of another package you
      will be notified of the dependent[   17.056490] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
 packages.  You should
      use the --force-removal-of-depende[   17.067237] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
nt-packages option to
      also remove the dependent packages [   17.082287] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
as well
*******************************************************[   17.091517] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
******************************************************[   17.106287] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.115791] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.126290] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.134515] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.144742] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.152961] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.163194] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.171412] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.182286] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.190508] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.200735] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.208954] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.219186] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.227405] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.238285] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.246505] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.256735] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.264956] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.275189] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.283407] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.294286] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.302505] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.312733] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.320951] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.331182] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.339400] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.350286] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.358505] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   17.365104] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[   17.374147] Console: switching to colour frame buffer device 128x48
[   17.383555] tidss 4a00000.dss: [drm] fb0: tidssdrmfb frame buffer device
[   17.406718] m_can_platform 40568000.can: m_can device registered (irq=25, version=32)
[   17.418578] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   17.428763] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   17.439729] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   17.450627] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.462838] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   17.472623] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   17.483361] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   17.493339] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.505230] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   17.515311] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   17.525288] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   17.536399] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.549627] m_can_platform 40528000.can: m_can device registered (irq=23, version=32)
[   17.629047] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac loaded
[   17.638346] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: rdev_features:00000003 rdev_mtu:1522 flow_id:172 tx_psil_dst_id:4A00
[   17.655064] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[   17.669705] j721e-audio sound@0: devm_snd_soc_register_card() failed: -517
[   17.680509] j721e-pcie 2900000.pcie: host bridge /bus@100000/pcie@2900000 ranges:
[   17.690063] j721e-pcie 2900000.pcie:       IO 0x0010001000..0x0010010fff -> 0x0010001000
[   17.702241] j721e-pcie 2900000.pcie:      MEM 0x0010011000..0x0017ffffff -> 0x0010011000
[   17.713299] j721e-pcie 2900000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.725402] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[   17.735300] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[   17.747301] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[   17.759295] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.772393] j721e-pcie 2920000.pcie: host bridge /bus@100000/pcie@2920000 ranges:
[   17.783306] j721e-pcie 2920000.pcie:       IO 0x4400001000..0x4400010fff -> 0x0000001000
[   17.795299] j721e-pcie 2920000.pcie:      MEM 0x4400011000..0x4407ffffff -> 0x0000011000
[   17.807297] j721e-pcie 2920000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[   17.927948] j721e-cpsw-virt-mac main_r5fss_cpsw9g_virt_mac0: virt_cpsw_nuss mac started
[   23.883690] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   23.890560] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   30.310907] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   30.317781] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   30.352993] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.362602] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.372900] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.385308] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.396329] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.404596] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.415083] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.423341] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.435372] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.443692] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.455362] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.463595] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.474294] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.482524] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.492775] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.501001] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.511253] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.519482] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.530290] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.538519] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.548766] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.556995] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.567230] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.575454] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.586290] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.594516] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.604764] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.612984] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.623219] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.631442] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.642288] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.650514] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.660159] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.668386] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.679293] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.687519] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.698288] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.706524] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.716756] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.724977] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.735211] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.743434] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.754288] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.762514] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.772766] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.780987] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.791228] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.799451] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.810287] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.818519] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.828765] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.836988] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.847222] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.855449] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.866290] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.874516] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.884762] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.892988] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.903221] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.911449] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.922289] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.930518] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.940750] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.948970] cdns-mhdp8546 a000000.dp-bridge: Failed to read DPCD addr 0
[   30.955577] cdns-mhdp8546 a000000.dp-bridge: Failed to read receiver capabilities
[   37.380221] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   37.387095] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
[   43.807871] cdns-mhdp8546 a000000.dp-bridge: get block[0] edid failed: -22
[   43.814742] cdns-mhdp8546 a000000.dp-bridge: Failed to read EDID
请帮助我们分析这个问题,感谢您的支持,并期待您的回复。
    尤华
    你好。  在您共享的 MMC0在 HS400模式下枚举的日志中。  TDA4VM 不支持这种模式;请修改设备树文件 ,以便在默认情况下使用 HS200。
    此致,
    石尾
    感谢您的支持。 将 HS400模式更改为 HS200模式后,问题就会得到有效解决
    延华
    很高兴听到这个问题已经解决!  请单击 上一个帖子上的“已解决”按钮以关闭此线程。
    谢谢,此致,
    石尾
