[参考译文] TDA4VM:TDA4 CPSW9G RGMII1 PTP
Guru**** 2550480 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1070080/tda4vm-tda4-cpsw9g-rgmii1-ptp
部件号:TDA4VM
您好,专家
我使用 SDK 8.0 QNX+RTOS
我对使用 cpsw9g 下启用的 RGMII1 PTP 有一些疑问
当我使用命令 io-pkt-v6-HC-d cpsw9g PTp=1时
日志 如下所示
[MCU2_0]      5.635813 s: EnetPhy_bindDriver: PHY 1: OUI:0d6414 Model:05 Ver:00 <-> 'dp89836' : OK
[MCU2_0]      5.636034 s: PHY 1 is alive
[MCU2_0]      5.637718 s: ETHFW: Version   : 0.01.01
[MCU2_0]      5.637769 s: ETHFW: Build Date: Jan  2, 2022
[MCU2_0]      5.637796 s: ETHFW: Build Time: 14:51:29
[MCU2_0]      5.637818 s: ETHFW: Commit SHA: ed1a74f0
[MCU2_0]      5.637874 s: ETHFW: Init ... DONE !!!
[MCU2_0]      5.637903 s: ETHFW: Remove server Init ... !!!
[MCU2_0]      5.638686 s: Remote demo device (core : mcu2_0) .....
[MCU2_0]      5.638743 s: ETHFW: Remove server Init ... DONE !!!
[MCU2_0]      5.639670 s: Starting lwIP, local interface IP is 192.168.1.200
[MCU2_0]      5.688510 s: FVID2: Init ... !!!
[MCU2_0]      5.688614 s: FVID2: Init ... Done !!!
[MCU2_0]      5.688661 s: DSS: Init ... !!!
[MCU2_0]      5.688685 s: DSS: Display type is eDP !!!
[MCU2_0]      5.688708 s: DSS: M2M Path is enabled !!!
[MCU2_0]      5.688731 s: DSS: SoC init ... !!!
[MCU2_0]      5.688750 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2
[MCU2_0]      5.724906 s: Host MAC address: 70:ff:76:1d:92:c2
[MCU2_0]      5.735573 s: PHY 1: global soft-reset
[MCU2_0]      5.749355 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.749417 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2
[MCU2_0]      5.751318 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.751353 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2
[MCU2_0]      5.753288 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.753321 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11
[MCU2_0]      5.755240 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]      5.755274 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18
[MCU2_0]      5.757202 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]      5.757234 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2
[MCU2_0]      5.759189 s: SCICLIENT: Sciclient_pmSetModuleClkParent success
[MCU2_0]      5.759221 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000
[MCU2_0]      5.762833 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success
[MCU2_0]      5.762866 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0
[MCU2_0]      5.763224 s: SCICLIENT: Sciclient_pmModuleClkRequest success
[MCU2_0]      5.763251 s: DSS: SoC init ... Done !!!
[MCU2_0]      5.763273 s: DSS: Board init ... !!!
[MCU2_0]      5.763293 s: DSS: Turning on DP_PWR pin for eDP adapters ... !!!
[MCU2_0]      5.763322 s: DSS: Turning on DP_PWR pin for eDP adapters ... Done!!!
[MCU2_0]      5.763351 s: DSS: Board init ... Done !!!
[MCU2_0]      5.781086 s: DSS: Init ... Done !!!
[MCU2_0]      5.781146 s: VHWA: VPAC Init ... !!!
[MCU2_0]      5.781173 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2
[MCU2_0]      5.783301 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      5.783349 s: VHWA: LDC Init ... !!!
[MCU2_0]      5.815400 s: VHWA: LDC Init ... Done !!!
[MCU2_0]      5.815447 s: VHWA: MSC Init ... !!!
[MCU2_0]      5.911438 s: VHWA: MSC Init ... Done !!!
[MCU2_0]      5.911487 s: VHWA: NF Init ... !!!
[MCU2_0]      5.927435 s: VHWA: NF Init ... Done !!!
[MCU2_0]      5.927485 s: VHWA: VISS Init ... !!!
[MCU2_0]      5.999389 s: VHWA: VISS Init ... Done !!!
[MCU2_0]      5.999436 s: VHWA: VPAC Init ... Done !!!
[MCU2_0]      5.999479 s:  VX_ZONE_INIT:Enabled
[MCU2_0]      5.999594 s:  VX_ZONE_ERROR:Enabled
[MCU2_0]      5.999628 s:  VX_ZONE_WARNING:Enabled
[MCU2_0]      6.000665 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target IPU1-0
[MCU2_0]      6.000886 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_NF
[MCU2_0]      6.001077 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_LDC1
[MCU2_0]      6.001267 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC1
[MCU2_0]      6.001453 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_MSC2
[MCU2_0]      6.001812 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target VPAC_VISS1
[MCU2_0]      6.002039 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE1
[MCU2_0]      6.002246 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE2
[MCU2_0]      6.002457 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY1
[MCU2_0]      6.002772 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DISPLAY2
[MCU2_0]      6.002994 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CSITX
[MCU2_0]      6.003209 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE3
[MCU2_0]      6.003427 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE4
[MCU2_0]      6.003738 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE5
[MCU2_0]      6.003963 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE6
[MCU2_0]      6.004168 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE7
[MCU2_0]      6.004365 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAPTURE8
[MCU2_0]      6.004656 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M1
[MCU2_0]      6.004871 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M2
[MCU2_0]      6.005073 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M3
[MCU2_0]      6.005265 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target DSS_M2M4
[MCU2_0]      6.005609 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target CAMERASWITCH
[MCU2_0]      6.005856 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target MCANR1
[MCU2_0]      6.006074 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target MCANSR1
[MCU2_0]      6.006290 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target MCANFR
[MCU2_0]      6.006600 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target MCANSR2
[MCU2_0]      6.006837 s:  VX_ZONE_INIT:[tivxPlatformCreateTargetId:55] Added target IOSWITCH
[MCU2_0]      6.006884 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
[MCU2_0]      6.006913 s: APP: OpenVX Target kernel init ... !!!
[MCU2_0]      6.019457 s: APP: tivxRegisterCameraSwitchTargetR5FKernels !!!
[MCU2_0]      6.019611 s: Start to call tivxAddTargetKernelCameraSwitch
[MCU2_0]      6.019652 s: Start to call tivxAddTargetKernelCameraSwitch 6
[MCU2_0]      6.019686 s: Start to call tivxAddTargetKernelCameraSwitch CAMERASWITCH
[MCU2_0]      6.019818 s: APP: OpenVX Target kernel init ... Done !!!
[MCU2_0]      6.019852 s: CSI2RX: Init ... !!!
[MCU2_0]      6.019874 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0]      6.021237 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.021278 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2
[MCU2_0]      6.023305 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.023348 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2
[MCU2_0]      6.025333 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.025373 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2
[MCU2_0]      6.027310 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.027350 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2
[MCU2_0]      6.029253 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.035464 s: CSI2RX: Init ... Done !!!
[MCU2_0]      6.035581 s: CSI2TX: Init ... !!!
[MCU2_0]      6.035606 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2
[MCU2_0]      6.037262 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.037301 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2
[MCU2_0]      6.039322 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.039363 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2
[MCU2_0]      6.041295 s: SCICLIENT: Sciclient_pmSetModuleState success
[MCU2_0]      6.047531 s: CSI2TX: Init ... Done !!!
[MCU2_0]      6.047605 s: ISS: Init ... !!!
[MCU2_0]      6.047640 s: Found sensor MAX96722_MAX96717_OX03C10 at location 0
[MCU2_0]      6.047676 s: Found sensor MAX96722_MAX96717_X1F at location 1
[MCU2_0]      6.047741 s: IssSensor_x1f_Init success.
[MCU2_0]      6.047773 s: IssSensor_Init ... Done !!!
[MCU2_0]      6.047873 s: vissRemoteServer_Init ... Done !!!
[MCU2_0]      6.047938 s: IttRemoteServer_Init ... Done !!!
[MCU2_0]      6.047971 s: UDMA Copy: Init ... !!!
[MCU2_0]      6.063387 s: UDMA Copy: Init ... Done !!!
[MCU2_0]      6.317389 s: APP: Init ... Done !!!
[MCU2_0]      6.317439 s: APP: Run ... !!!
[MCU2_0]      6.317462 s: IPC: Starting echo test ...
[MCU2_0]      6.319706 s: APP: Run ... Done !!!
[MCU2_0]      6.320630 s: EnetPhy_enableState: PHY 1: falling back to manual mode
[MCU2_0]      6.320687 s: EnetPhy_enableState: PHY 1: new link caps: FD100
[MCU2_0]      6.320855 s: Cpsw_handleLinkUp: Port 1: Link up: 100-Mbps Full-Duplex
[MCU2_0]      6.322078 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[.] C66X_2[P] C7X_1[x]
[MCU2_0]      6.322307 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_0]      6.322392 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.]
[MCU2_0]      6.322639 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P]
[MCU2_0]      6.367567 s: [LWIPIF_LWIP] NETIF INIT SUCCESS
[MCU2_0]      6.367639 s: Added interface 'ti1', IP is 192.168.1.200
[MCU2_0]      6.410724 s: EthFw: TimeSync PTP enabled
[MCU2_0]      6.441456 s: Rx Flow for Software Inter-VLAN Routing is up
[MCU2_0]     19.138617 s: Function:CpswProxyServer_attachHandlerCb,HostId:0,CpswType:6
[MCU2_0]     19.139086 s: Function:CpswProxyServer_allocMacHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6
[MCU2_0]     19.139433 s: Function:CpswProxyServer_registerRemoteTimerHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6, Name:mpu_1_0_ethswitch-device-0, Timer:1, PushNum:3
[MCU2_0]     19.954130 s: Function:CpswProxyServer_allocTxHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6
[MCU2_0]     19.964278 s: Function:CpswProxyServer_allocRxHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6
[MCU2_0]     19.964672 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6, Cmd:1010401,InArgsLen:0, OutArgsLen:4
[MCU2_0]     19.994361 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6, Cmd:1010201,InArgsLen:24, OutArgsLen:4
[MCU2_0]     19.996264 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0
[MCU2_0]     19.996470 s: Cpsw_ioctlInternal: CPSW: Registered MAC address.ALE entry:14, Policer Entry:3
[MCU2_0]     19.997272 s: Function:CpswProxyServer_ioctlHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6, Cmd:1000104,InArgsLen:1, OutArgsLen:1
[MCU2_0]     19.997644 s: Function:CpswProxyServer_registerIpv4MacHandlerCb,HostId:0,Handle:a3038054,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1 IPv4Addr:192.168.1.100
[MCU2_0]     19.997772 s:
[MCU2_0]  SNo.      IP Address          MAC Address
[MCU2_0]     19.997810 s: ------    -------------     -----------------
[MCU2_0]     19.997844 s:   1       192.168.1.100     70:ff:76:1d:92:c1
端口 RGMII1 IP 200处于活动状态。当我使用 PTP 主中继器 ping rgmii1,时,rgmii1回复的消息错误
即使我 ping 了100,结果也是一样的
    您能否详细说明 ping 应答消息的错误?
     ping 应答由相应的堆栈进行组合(ping 200时为 lwIP,ping 100时为 QNX 堆栈),EthFw 随后不会触及这些数据包。
