[参考译文] Processor-SDK-J721E:Yocto Build 失败-使用 Ubuntu 18.04和20.04
Guru**** 2545010 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1074175/processor-sdk-j721e-yocto-build-fails---with-ubuntu-18-04-and-20-04
部件号:processor-SDK-J721E
“线程:测试ABS”中讨论的其它部件
Yocto Build is failing with this error.(Yocto Build 出现此错误。)
我在 Ubuntu 18.04和20.04中都尝试了构建。
供参考:我已在系统中安装了 help2man。
Ubuntu@tij7:build$ toolchain_base=/home/Ubuntu/workspace/tools machin=J7-EVM bitbake -k tisdk-default-image
警告:图层 meta-psdkla 应在其 conf/laye.conf 文件中设置 LAYERSERIES_COMPAT_meta-psdkla,以列出其兼容的核心图层名称。
注:已使用 DBfile 启动 PRServer:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/build/Cache/prserv.sqlite3,IP:127.0.1,端口:46815, PID:20010
警告:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/sources/meta-Arago-distine/菜谱- core/meta/external-arm-secondary sdk-toolchain.bb:可变密钥 prefered_provider_binutils-cross-charge-${secondary cross-target_arch-trans-buildice-eds-exeds-target_target_target-charge-charts.bbs- replac-buils- eds-{target_cross-buils- target_cross-buils- target_arch-buildic-buildic-buildic-buildich-buildich-buildich-
警告:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/sources/meta-Arago-arago-distine/菜谱-core/meta/external-arm-secondary sdk-toolchain.bb:可变密钥 preferended_provider_gar-cross-cross-canad-${trans-trans-trans-eded_target_target_cross-builder-ss-builds.bs.bbs- exeds.bs- exc_decure-ch_target-buildice-builde-ch_cross-builds.bbs- eds.bs-(首选项 c_cross-c_cross
解析配方:100%|############################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### |时间:0:01:56
3014 .bb 文件解析完成(0个缓存,3014个解析)。 8606个目标,1201个跳过,0个屏蔽,0个错误。
警告:没有适用于以下情况的配方:
/home/Ubuntu/workspace/tijicinto7/sdk_08_00_08/Yocto-build/sources/meta-psdkla/菜谱-核心/包装组/neo-ai-drd.bbappend
注:解决任何缺少的任务队列相关性
注:解决任何缺少的任务队列相关性
注:解决任何缺少的任务队列相关性
注:解决任何缺少的任务队列相关性
注:解决任何缺少的任务队列相关性
注:解决任何缺少的任务队列相关性
构建配置:
BB_version =“1.46.0”
Build _SYS =“x86_64 Linux”
NATIVELSBSTRING ="Ubuntu-16.04"
TARGET_SYS ="AArch64-Linux"
机器="J7-EVM"
版本="Arago"
distro 版本="2020.09"
tun_features ="AArch64"
TARGET_FPU =""
Meta-Arago-distro
Meta-Arago-Extras ="头部:ae47bd7fbea2776a4f8792f20c493d7959ee2f54"
meta-psdkla ="头部:3d772074ef93ac47a1a752e22021b0c32207f54b"
meta-qt5 ="头部:b4d24d70aca75791902df5cd59a4f4a54aa4a125"
元虚拟化=“head:4d6216a04c2ebe04bf0232c02d9589d35ebf3b4”
元网络
Meta-python
元 OE
元 gnome
元文件系统=“head:7bd47ef6c98323c95a9e527129dca98c9a65ee08”
meta-ti ="头部:15f3d4a3c3773294f1cdb66a88744930941a892e"
元臂
meta 臂-工具链="头部:c4f04f3fb66f8f4365b08b553af8206372e90a63"
META ="头:9b83aefa9c4a21d9dc1eea4a6b00af379466a288"
META AWS ="主机:d3df90635fca4d8267b547dab568058c554014b1"
meta jupyter =“头部:82db248e2eca36e52cbafe599b755dc87720383”
构建配置:
TARGET_SYS ="arm-linux-gnueabi"
机器="J7-EVM-k3r5"
版本="Arago"
distro 版本="2020.09"
tun_features =“ARM armv7a VFP 拇指调用-硬”
TARGET_FPU ="硬"
Meta-Arago-distro
元网络
Meta-python
元 OE
元 gnome
元臂
正在初始化任务:100%|########################################################################################################################################################################################################################################################################################################################################################################################################################################### |时间:0:00:22
状态摘要:想要3531找到0错过3531电流0 (0%匹配,0%完成)
注意:推迟 mc:k3r5:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources /oe-core/gettext/gettext-minimal-native_0.20.1.bb:在/homa_ubuntua/workspace/tijacot_core/get_exites/gettext-core/getexites/getex-native_0.20.1.bb:date_mate_lic_lic 后,执行以下操作:date_meta_ex_lic_li_date/ic_du_ecom_ecom_exu_ex源
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources /oE-core/gettext/gettext-minimal-native_0.20.1.bb:在/homa_Ubuntu/workspace/tic_do_doccore/getecome-ed/getexcot_0.20.1.bb:date_sysroot 之后执行 DO_oma_populate_sysroot
注意:推迟 mc:k3r5:/home/Ubuntu/workspace/tijacinto7/sdk_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-devtools/libtool-native_2.4.6.bb:在/home/ubuntua/workspace/tijacin/ex_build_does/libtools/libot_2.4.6.bb:date_meta_lic_lic 后填充/hom_meta_ex_lic
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources/OE - core/meta/菜谱-工具/libtools/libtool-native_2.4.6.bb:在/homa/ubuntu/workspace/tijacot_build_dies/libcore/libot_2.4.6.bb:do _sysroot 之后执行 DO_oma_omi_omi_sysroot 操作
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources /oe-core/meta/菜谱-devtools/m4/m4-native_1.4.bb:在/home/ukubua/workspace/tijicintotto_sources/m4/native_1.4.18.bb:date_lic_ex_exu_exu_late_lic_ex_ex_/hom_08.00/ed_ex源/hom_08/native_08.00_ex_build_ex_08.b_ex_ex_dates/m4/ot_ex_
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/m4/m4-native_1.4.18.bb:在/home/otoma/workspace/tijacinto/m4/native_build_04.18.bb:do m4_sysroot 之后执行 DO_populate_sysroot 命令。/omi_08/yotog_08/ot_08/ot_08/ot_builde-m4/natives/native_04.8_sdk/natives_08.bot_08.
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources /oe-core/meta/菜谱-devtools/quilt/int-native_0.66.bb:在/home/6600/workspace/tijapinto_det_build_dies/native_08.00-native_exactuot_exact_exact_excot_exciles/08.bb_ex-build_datases 后面
注意:推迟 SDK MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources/OE - core mota/egot-devtools/quilt/native_0.66.bb:在/home/66/ubuntuworkspace/tijacint_det-build_doct/08/native_sysroot 食谱之后,做个填充_meta_sysroot 用户名/oct/oct/oct/oct_build_doct/08.00_excot/oct/oct/oct/oct_buildes/natives
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources /oe-core/meta/菜谱- extended /textinfo - native/tijicinfo-imume-native.bb:do_date_lic /home/workspace/tic_dimum_native 08_build_decom-native
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/textinfo -本地/textinfo -原生。bb:在/home/Ubuntu/workspace/ticktion_dimum_ed_dom-native /wed_decom-build_decom-native 后,d_decom-native /jecom-native /wet/wact-build_decom-native-native-native-native.bb:bb:d_dom-d_dom-d_dom-native /y
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources /oe-core/meta/egot-kernel/kernic-tools/kernic-git.bb:do_kernel_lic 在/home/workspace/tic-kernel/ex_workstate_du_08/ot_ex_ex-sources/yot_ex-not_ex-not_works.bb 之后填充/hom_ex_ex-works.bb:dich_date_kernel/it_ex_ex-works.bb
注意:推迟 MC:k3r5:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources /oe-core/meta/egot-kernel/kerno-tools-native_git.bb:do_kernel_sysroot after /home/bubuub/workspace/meta-core/builde/kernot_08/ot_tools/yot_natives
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-连接性/openssl/openssl_1.1.1k.bb:do_popul_lic_lic_building_docl_08/native_native_08.00/ot_build_08.00/opsplot_date/opsib_date/opsk_build_08.1k_build_date/opsk_date/opskiplot_date/opskien_build_docs/ops/ops/opskib_en_en_en_en_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-连接性/openssl/openssl_1.1.1k.bb:do_popul_sysbb 在虚拟根/oct_core_build_08.08/nituot_native_native_08.00/ocs/opsploti_ocs/opsl/ocs/opsplotics_08.1k_build_build_08.1.bubuubuubuot_virtual_build_build_build_build_nit_08.1k/ops/
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/dbis/dbus_dbus_1.12.16.bb:do_populate_lic (虚拟后):native:/home/Ubuntu/08/mot-core/dbus_buildic_domic/ed/1.12.16.
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-core/dbus/1.12.16.bb:do_populate_sysroot after virtual:native:/home/build_dbus_core/dbus_build_date_date.08/ybuildcore/dot_date.08.00_sydbcot_core/dic_doccore/date.bbs_dom-builddate.bbs_dom_date.bbs
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-核心/expat/2.2.10.bb:虚拟后执行 SDK_populate:本机:/home/Ubuntu/08/ot_build_ot_ot_2.9.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-核心/expat/2.9.bb:虚拟后执行 SDK_populate_sysroot:native:/home/uart_core/meta_build_08/exot_ot_2.9.bb:在虚拟基础上执行以下操作
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-核心/ncurses _6.2.bb:虚拟后执行 SDK_populate_lic:本机:/home/08/ncore/date_date_datace_08/note_build_date/nties/nics/ntiskires/6.2.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-核心/ncurses _6.2.bb:虚拟后执行 SDK_populate_sysroot:noma/home/build_02/ncore/ncurses
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-核心/readline_8.0.bb:虚拟后执行填充许可:本机:/home/Ubuntu/workspace/workspace_build_08/etitic_core/readline_8.0.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/食谱-核心/readline/readline_8.0.bb:虚拟后执行_populate_sysroot:本机:/home/Ubuntu/workspace/meta_build_08/et_core/readline/readline_8.0.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱- core/util-linux/util-linux_populate 2.5.1.bb:do_populate_lic_build:/ot_linux_build_08/ot_core/util_81/oti_build_duoties/uoties/uoties/uil_81/linux-build_build_build_upd_duot_up_upd_docup_up_up_upd/
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱- core/util-linux/util-linux_populate 2.5.1.bb:do_populate_systil virtual:native_build_300/util_build_linux_build_domies/uot_2.00_uoties/uotiot_uoties/uot-linux/uoti_2.08:/uoti_build_2.00_build_build_build_build_linux/uot_2.00_build_doct_uoti_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-core/zlib/1.2.11.bb:虚拟后执行 SDK_populate:native:/home/Ubuntu/08_core/meta_build_eck/zlib/echtics/itu_core/zlib/1.11.bb:date_licto virtual_buildate_lic_date_date_date_date.bed_2008.bid_build_skies/not/zh-sources/int_core/zh-build_core/zh-
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-core/zlib/1.2.11.bb:do_populate_sysroot after virtual:native:/home/workbot_build_decom_08/yot_core/zot_ecures_08.11.bb 虚拟:date_date_build_sych_syched_syched_syched_core/zh_core/ched_core/zh-sources_doccore/chemic/chemic/date.08.11.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/autoconf-archive/autobb-archive_2019.01.06.bb:do_00_lic_build_duubuubuot_08:08/native_native_date_date_date_date_build_doct/ove_docup/overtion_08.00/ocup_edomin\cominuot/overtuoties/ocup/ocupdate_archive.08.08.08.06.06.bbmware_buildate_native_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-设备工具/autoconf-archive/autobb-archive_2019.01.06.bb:do_syssysubu_build_duubuubuot_2000/ocupdate_virtual_root_root/eduoties/ocdomples:/ed/edom-buildichu_2000/archive.08.08.b_virtual_root_root/ed/builde-builde-build_root/untuot/ed/ed/untuotiomies/ocoma/archiv
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/autoconf/autoconf_2.69.bb:do_populate sdk_lic (虚拟后):native:/home/urbu/08/om-core/build_date/oties/otioctics/oties/otiocupdics/datacu_datocup/2.00_clodecese/ap/ap/apies/oties/oties/oties/odechtocupdics/dat
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-devtools/autoconf/autoconf_2.69.bb:do_populate_sysroot after virtual:native:/home/build_08/mot_modules/octomies/ocidocup_2.00_build_syched/octocominconf_2.69/bb 虚拟化路径后
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/自动生成/automake/automake_1.16.1.bb:do_populate_licic (虚拟后):native:/home/Ubuntu/08/ot_build_08/ot_date/ot_datacot_date/oties/01.01/oties/otiake_build_sdk/1.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/automake/automake_1.16.1.bb:do_populate_sysroot after virtual:native:/home/untua/workspace_build_08/y_doctomies/noties/notiake_build_016.1.bb
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/bison /bison _3.5.4.bb:虚拟后执行许可操作:本机:/home/Ubuntu/workspace/meta build_k/meta 08/bison
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/bison /bison _3.5.4.bb:虚拟后执行_populate_sysroot:nome/home/Ubuntu -08/mot_build_4_sdk/y_doccore/wbise_3.5.4.bb:在虚拟化后执行以下操作
备注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/dwarfsrctics/dwarfsrctcfiles.bb:do_populate_lic_build_08/y_doccore_files/dwardlib_date.08/natives/d_date/dwed_date/dwed_docktovics/date/dworkfiles/dwark_date.bb_build_docs/date/dwark_workspace/d_dates/dwark_date.08/date/dwed/dwarket_
备注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/dwarfsrctics/dwarfsrctics.bb:do_populate_sysdbuubuot_build_doccot_core/ed_docktove_doct/files/dwarket_08/natives:/ed/edies/dwarnatives/securet_root/d_build_root/ed/dwed/dwed/dcret_files.bb 在虚拟化后:virtual_buildworkspace/d_doct_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/e2fsprogs/e2fsprogs_1.45.4.bb:do_lic_uubuot_build_duubuot_ecomies/e08/e2fspots/e2fsprogs/e2fsset_builds/e2fsset_date/edies/edies/native_date/date/date/esk_build_date/esk_build_build_build_date/esk/esk/esk/esk/esk_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-设备工具/e2fsprogs/e2fsprogs_1.45.4.bb:do_syss_sys_root_build_duubuot_08/native_builde/edies/e2fsdks/e2fsprogs/e2fs/e2fsprogs/e2fsset_date/edies/et_build_date/edies/edies/ed/edies/ed/esktovest_build_build_build_date/esk/ed/esk/ed_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/elfutils/elfutils_0.178.bb:do_populate_lic_build/datory:native_08/nitels/yoteldotel_core/date_date_datory:08/datory
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-设备工具/elfutils/elfutils_0.178.bb:do_populate_sysfibuub:d_build_native_08/native_build_core/y_doceldate/date.08/native_date/ed_core/ed_domet_date.08.00_build_domet_date.08/y_docel_build_docel_date.08/es/set/ed/es/set_core/ed/ed/ed/ed_
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-设备工具/file/file_5.38.bb:虚拟后执行填充许可:本机:/home/Ubuntu/workspace/workspace_build_5.38_utility_buildate_ics/y_doct_files/5.388.00_files/yot_utility_builds.bb 虚拟化许可源
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-设备工具/file/file_5.38.bb:在虚拟后执行_populate_sysroot:native:/home/Ubuntu/workspace/build_08/meta_files/et_5.38/ed_files/yot_5.38bb
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/flex/flex /flex 2.6.bb:虚拟后执行许可:本机:/home/Ubuntu/workspace/build_08/meta_meta 2.6.4.bb:虚拟后执行工具:安装源
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/flex/flex /flex 2.6.bb:do_populate_sysroot after virtual:native:/home/Ubuntu/workspace/build_data-mot_2.6.00/ed_2.6.2.6.4.bb
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/egot-devtools/GNu-config/Gnu-git.git.bb:do_ukuub_lic (虚拟:本机:/home/om-core/配置/nitic-08/ngact/ngs/ngibu_ed/ng/配置
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/GNu-config/GNu-config/gite.bb:do_Ubuntu_sysroot 在虚拟:native:home_build_08/nom-core/ngoti_08/ngoties/ngconfig-builde-de-de-***/ngits/ngibng/ng/ng_sdk/ng_sdk/ng_sdk/ng_doctub_sdk/ngit_s 后
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/opkg-utils/opkg-utils_0.4.2.bb:do_lic_utils_after virtual_build_workspace_08/native_build_docs/opkg-build_docs/opkg-build_docs/opkg-build_docs/date/utils_08.2.bukg/ot_date_date.08.2.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/opkg-utils/opkg-utils_0.4.2.bb:do_sys_sysbuild_duubuot_root/native_08/virtual_build_build_docs/opkg-builds/oties/natives:/utils/opkg-builds/opkg-build_docs/opkg-build_duot_04.2.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-设备工具/patch/patch_2.7.6.bb:虚拟后执行许可操作:本机:/home/Ubuntu/workspace/meta_build_2.7.6.bot_lic_utility_lic
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/patch/patch_2.7.6.bb:虚拟后执行_populate_sysroot:native:/home/Ubuntu/workspace/build_08/mot_data-buildot_2.7.6.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-devtools/perl/perl_5.30.1.bb:do_sdk_l_lic (虚拟后):native:/homa/home/build_domin/08/ot_date/actuot_up_updich/up_apies/5.30.1.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/perl/perl_5.0.1.bb:do_sdb_sysroot 在虚拟后:native:/home/build_domi_domi_up_08/noti_update_sysbuild_08/nits/y_build_upd_docl_3moties/incore/upd_5.30.1.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/pkgconfig/pkgconfig/git.bb:do_populate_sdk_lic (虚拟后):native:/home/Ubuntu/08/mot_core/config_build_date/datachtog_tru_ed/ics/datachtu_esk/k/wet_date.bb
注意:推迟 MC:k3r5:虚拟:本机:主页/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/egote-devtools/pkgconfig/pkgconfig/git.bb:do_populate_sysroot after virtual:native:/home/noma/build_doct_date/ot_sdk/not_08/noties/nitegoties/pk/config_datachtog_date.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/伪元/伪元/吉特。bb:虚拟后执行填充许可证:本机:/home/Ubuntu/workspace/metot_build_does/mot_sdk/wdate_lic_date.08/y_du_builde-sources/yot_sdk/yot_date.bb 虚拟后执行虚拟源
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/pseude/pseude/pseed_git.bb:虚拟后执行_populate_sysroot:本机:/home/Ubuntu/untu/workspace/mot_08/nit_build_sdk/y_doct_sdk/psies/et_build_sdk/sys.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/python /python3_3.8.11.bb:do_populate_licic after virtual:native:/home_build_do_de_de_de/08/yot_core/actu_08/yoties/yth-build_3_3_edies/yoties/yoties/yth-buildich/woties/wot_3_3.8.11.bb 虚拟
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/python /python3_3.8.11.bb:do_populate_sysroot 在虚拟 Ubuntu 后:native:/octom_core/build_08/nit_08/nitom_d_ed_3_doctomies/yth-builds/yth-builds/ythnituot_3_3_doctome_doct_3.8.11.bb:在虚拟 Ubuntu 后填充虚拟 Ubuntu
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/rpm/rpm_4.14.2.bb:do_populate_lic_lic (虚拟后):native:/home/Ubuntu/08_build_doct/08/mot_mot_08.00/egoties/4.00_buildites/et_datachtu_mot/4.bmot/4.bmot/4.bmot/4.b2.bb
注意:推迟 MC:k3r5:虚拟:本机:主页/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-设备工具/rpm/rpm_4.14.2.bb:虚拟后执行 SDK_populate _sysroot:native:/home/build_08/mot_build_doctomet/4.00/edoctomet_04.b_4.b_4.bd/4.bd_4.bd_sdk_s
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-设备工具 rsync /meta Reconc/sync_3.1.bb:虚拟后执行_populate_lic_lic:本机:/home/Ubuntu/workspace/08/et_build_08/y_doct_ines/yot_3.1.bcot_3.3.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-设备工具 rsync /meta Recync_3.1.3.bb:虚拟化后执行_populate_sysroot:home/Ubuntu/u/workspace_08/met_build_03.1.3bbc_ed/sysroot/sysbuild_build_doct/sys/yot_buildes/yot_08.bios_3
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-devtools/swig/swig_3.0.12.bb:虚拟化后执行 SDK_populate:本机:/home/untu_build_doct_08/mot_mot_date.08.g/swig_esk_3.08.b_virtual_buildics/swig/swig_3.12.bb:在虚拟化后执行:本机
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/swig/swig_3.0.12.bb:do_sduk_sysroot 在虚拟后:native:/home/build_08/meta build_docta/weg_08.g/swig_3.12.bb_sdb_sysroot
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-扩展/bc/bc_1.07.1.bb:虚拟后执行许可操作:本机:/home/Ubuntu/workspace/meta_build_1.0c/etc_bc_1.07.1.bc_liclic 源
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-扩展/bc/bc_1.07.1.bb:虚拟后执行_populate_sysroot:native:/home/Ubuntu/core/build_08/bot_build_c/bc_1.07.1.bd_sybd_core/bd/Comoties/bdc/syroot/nexted/sysroot
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/bzip2/blic 2_1.0.8.bb:do_populate_virtual:native:/home_08/yot_build_08/bcore_date_date_datacot_08.bsdk/date.2/yb_datacuot_build_08.eb_date.2/bdatacuot_datacuot_datacuot_08.eb_date.2/y_esk/datacuot_date.2/b2.
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/bzip2/bjac2_1.0.8.bb:do_populate_sysroot 在虚拟工作空间后:native:home_build_08/bmeta 2/bdimet_2.8_build_2.8_bmeta
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/libarchive/libarchive_3.4.2.bb:do_populate_lic (虚拟后):native:/home/Ubuntu/uket/workspace/meta_build_08/libot_datacu_date/libot_2.bibu_2.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/libarchive/libarchive_3.4.2.bb:do_populate_sysroot after virtual:native:/home/ombot_core/oc_build_do/lib08/libcore/libotied_2.bb 至 libarchive_3.4.2.bb:虚拟:虚拟后:date_sdk_sysroot_sysroot_buildate_virtual:/libbuild_date_date_build_date_date_date_datacuub_dat
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/元/配方-扩展/libnsl/libnsl2_git.bb:do_sdb_lic 在虚拟后填充:native:/home/octom_core/lib_08/nic_build_date/lib_date/libtics/libntics/it_08/nit_date/lib_datacuoti_edies/lib_datacuubb_es2/lib_es2/lib_edi_edies/nics.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/libnsl/libnsl2_git.bb:do_ubuntu_sysroot 在虚拟后:native:home_build_dome/lib_08/incore/lib_08/incore/libnti_date.bb_build_date.b_date.b:d_date.b:date_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/libtirpc/libtirpc_1.2.6.bb:do_populate_lic_lic (虚拟 Ubuntu 后):native:/oid_core/libtirpc/libtirpc/libtirpc/libticrpc/datacc/08.6.b_build_date/libtic_doct_build_domic/date.08.00/libti/libtic/libt_build_doct_build_doct_date.08.b
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-扩展/libtirpc/libtirpc_1.2.6.bb:do_populate_sysbb 虚拟 Ubuntu:native_build_doct_core/libticc/libtirpc/libtirpc/libtirpc_1.2.6.10.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-扩展/xz/xz/z_5.2.bb:do_populate_lic_lic (虚拟后):native:/home/Ubuntu/08_core/build_08/nex_ex-core/ic_ex-dic/nex-dic/nex-nex-dic/a.4
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-扩展/xz/xz/8.2.bb:do_populate_sysroot after virtual:native:/home/noma/xcore/meta_build_05.2.4.bx 扩展/octic_2.bb:date_sysroot_syxdate_syxd_xd_xdate_syrroot/xd_date.xd_date.x_datac_datacu_datac/xd_datacu_datacu_exed/x_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-内核/DTC/DTC_1.6.0bb:虚拟后执行填充许可:本机:/home/Ubuntu/workspace/workspace_build_08/ot_kernel_08/yot_build_08.0/yot_kernels_1.6.0.bb:虚拟化许可源
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-内核/DTC/DTC_1.6.0.bb:在虚拟后执行_populate_sysroot:本机:/home/Ubuntu/workspace_build_08/ot_nitu_08/not_kernel_08.0/et_builde-kernel/yot_1.6.00.08.0.bbbb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/attr/acl_2.2.53.bb:虚拟后执行许可操作:本机:/home/Ubuntu/workspace_build_do/ap_2.53.ibu_lic_build_sket/wd_doct/ics/et_buildes/ics/wdics.bios_core/ot_bios_bios_build_du_bios_7.53
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/attr/acl_2.2.53.bb:虚拟后执行_populate_sysroot:native:/home/Ubuntu/08/mot_build_c_doctr/ap_core/cot_2.53.bcot_support/ictr/yot_builds.bctr/sysroot
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-支持/attr/atlic_2.4.48.bb:虚拟后执行_2.4._lic:本机:/home/Ubuntu/08/ot_build_datacot_tr/attr_08/yot_build_attr/attr/attr/attr/yot_core/attr_datacot_uot_7.48
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/attr/atiges_2.4.48.bb:do_2.4_sysroot 在虚拟后:native:/home/noma/build_08/ot_attr/attr_uktimuattr/u_uattr/uattr/uattr_uktu_uattr/uattr_uattr/uattr_2.4.48
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-支持/db/db_5.3.28.bb:虚拟后执行_填充_许可:本机:/home/Ubuntu/workspace/mot_build_mot_03.8.2.8.2.ibb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心元/配方-支持/db/db_5.3.28.bb:虚拟后执行_populate_sysroot:native:/home/Ubuntu/workspace/mot_08/meta_build_5.3.28.bb:d_sydb_build_sysroot
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/gdbm/gdbm_1.18.1.bb:do_db_lic 在虚拟后填充:native:/home/noma/build_k/wot_08/yot_build_date/wot_ex-build_81/yd_datesk/wm_date.8b_date/wm_date.bb_exemics/wd_date.bb_exemic_1.bb_1.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/gdbm/gdbm_1.18.1.bb:do_db_sysroot 在虚拟后:native:home/build_08/goti_doma/wot_018.1/yot_build_sdk_sdk_1.
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/libcap-acule-ng/libcap-ng_0.7.10.bb:do_populate_lic 虚拟 Ubuntu 后:native:native_build_dom_08/int_core/libcaps/libcap_08.ng/libcap_build_build_08.ng/libcapsg/libc_build_build_build_08.bng/libc_date.bng/libc_date_date_build_buildate_
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/libcap-acees/libcap-ng_0.7.10.bb:do_populate_sysng 虚拟 Ubuntu:native_build_08.00/libcapsg/libcore/libcap-ed/libcap-build_08.nit_build_build_08.nite/libc_build_build_date.08.nit_date/libc_build_core/libc_pan_08.nitng/libc_pnites/lib
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/libffi/libffi_3.3.bb:do_populate_lic (虚拟后):native:/home/Ubuntu/08_build_di/coti_08/ibliotic/api_buildics/libffi_3.3.3.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/libffi/libffi_3.3.bb:do_populate_sysroot (虚拟:本机:/home/uart_core/kit/08/inti_infoci/edies/libffi/coti_3.3.3.bb:bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱 支持/libpcre/libpcre2_10.34.bb:虚拟后执行_populate:native:/home/workspace_build_08/libtics/libtics/libtics/libpccre_10.34/bb 在虚拟化后安装
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/libpcre/libpcre2_10.34.bb:do_Ubuntu_sysroot 在虚拟后:native:home_build_08/home_build_08/mot_core/libtichtub_08/bib_up_2.bbc_up_up_2.bb 虚拟
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/libpcre/libpcre_8.44.bb:虚拟化后执行 SDK_populate:native:/home/untua/workspace_re_08/libtics/libpcre_re_buildate_ics/libcibpcre_8.44/re_re_re_apices/
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/libpcre/libpcre_8.44.bb:do_uukua_sysroot 在虚拟后:native:/home/workspace_build_08/00_build_ibcibcot_08/re_build_core/libcibcibcibcot_8.44.bb
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/lzo/lzo_2.10。bb:虚拟后执行填充许可:本机:/home/Ubuntu/workspace/workspace_build_do/08/etic_k_build_k/wd_k_08.00_date.wics/y_doctics/tics/tics/tic_7.bios_build/
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/lzo/lzo_2.10:do_populate_sysroot 在虚拟化后:native:/home/Ubuntu/workspace/08/k_build_k_k/wmeta core/k_date-build_7.bsi/yzo_u_sys.bb:date_sysroot:date_sysroot
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/lzop/lzop_1.04.bb:do_sdk_lic (虚拟后):native:/home/nubot_build_dua_08/yot_core/lic_08/nitu_datacu_date/nitu_datacu_date/nichtu_es_es/
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/lzop/lzop_1.04.bb:do_sdk_sysroot 在虚拟后:native:/home/nome/build_08/nit_core/nitu_04/y_datacu_date_datace_04/y_datacuot_build_04.b_04.b_date.04.b_sys/y_datacuot_build_datacuot_sys/n_datacu_dat
注:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE 核心/meta/菜谱-支持/popt/popt_1.16.bb:在虚拟后执行_populic:本机:/home/Ubuntu/workspace/08/ot_build_date_build_k_date/yot_datapt/16元数据源
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-support/popt/popt_1.16.bb:do_populate_popsysroot after virtual:native:/home/Ubuntu/08/ot_core/build_08/ot_build_date_date/y_data-core/datacot_datacot_datacht/data-build_date.bb_date.bb
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱 支持/SQLite/sqlite3_3.31.1.bb:do_populate_ulic after virtual:native:/home/build_di/kite_08/yoti_echties/3_doclittibu_eces/3.8_build/
注意:推迟 MC:k3r5:虚拟:本机:/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-支持/SQLite/sqlite3_3.31.bb:do_uubu_sysroot 在虚拟后:native:home_builde/oct_kit_08/necu_3_sdk/esk/esk/3-isoti_3.ebu_3.ebu_3.ebu_3.ebu_sysroot
注:正在执行任务
错误:autoconf-native-2.69-r11 do 编译:OE runmake 失败
错误:autoconf-native-2.69-r11 do_compile:执行'home/Ubuntu/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/build/Arago-external-arm-glibc/work/x86_64 - linux/autocconf-native/2.69-r11/compile_44371',失败且代码为 exit:
使全递归
make [1]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64-linux/autoconf-native/2.69-r11/build'
一切尽在垃圾箱中
制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build\bin'
rm -f autom4te autom4te.tmp
CD ./lib &&制作 autom4te.cfg
cd ./lib/m4sugar && make version .m4.
rm -f 自动报头 autoheader.tmp
rm -f autoreconfautoreconf.tmp
rm -f ifnames ifnames.tmp
rm -f 自动扫描 autoscan.tmp
srcdir='';\
测试-f ./autom4te.in || srcdir=./././././././././。/工作空间/ tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/-glibc/08.00_08/Yocto-build/Com-build/arago-build/-builduc-builduc-build/
vbuntu-e s|@shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e 的 s|@perl_fl群[@]|yes bind[@]|/home/Ubuntu/workspace/tijicintract_7|_linux/build_batch/fortrad/es\cl_builde-trad/es\command/native-vebo/sch/rm tradiped|/vebo/sec-ebo/sec-eboup/v_pract/v_pract/v_pract/v_ebo/sec|/v/native-trad/v_-ebo/sec-ebo/sd|@@@@@@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autom4te.in autom4te.in autom4te.tmp
autoupdate.tmp
srcdir='';\
测试-f ./autoreconf.in || srcdir=./././././././././。/工作空间/ tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/-glibc/08.00_08/Yocto-build/Com-build/arago-build/-builduc-builduc-build/
vbuntu-e s|@shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e 的 s|@perl_fl群[@]|yes bind[@]|/home/Ubuntu/workspace/tijicintract_7|_linux/build_batch/fortrad/es\cl_builde-trad/es\command/native-vebo/sch/rm tradiped|/vebo/sec-ebo/sec-eboup/v_pract/v_pract/v_pract/v_ebo/sec|/v/native-trad/v_-ebo/sec-ebo/sd|@@@@@@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoreconf.in autoreconf.in autoreconf.tmp
srcdir='';\
测试-f ./autoheader.in || srcdir=./././././././././。/工作空间/ tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/-glibc/08.00_08/Yocto-build/Com-build/arago-build/-builduc-builduc-build/
vbuntu-e s|@shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e 的 s|@perl_fl群[@]|yes bind[@]|/home/Ubuntu/workspace/tijicintract_7|_linux/build_batch/fortrad/es\cl_builde-trad/es\command/native-vebo/sch/rm tradiped|/vebo/sec-ebo/sec-eboup/v_pract/v_pract/v_pract/v_ebo/sec|/v/native-trad/v_-ebo/sec-ebo/sd|@@@@@@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoheader.in autoheader.in autoheader.tmp
srcdir='';\
测试-f ./autoupdate.in || srcdir=./././././././././。/工作空间/ tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/-glibc/08.00_08/Yocto-build/Com-build/arago-build/-builduc-builduc-build/
vbuntu-e s|@shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e 的 s|@perl_fl群[@]|yes bind[@]|/home/Ubuntu/workspace/tijicintract_7|_linux/build_batch/fortrad/es\cl_builde-trad/es\command/native-vebo/sch/rm tradiped|/vebo/sec-ebo/sec-eboup/v_pract/v_pract/v_pract/v_ebo/sec|/v/native-trad/v_-ebo/sec-ebo/sd|@@@@@@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoupdate.in autoupdate.in autoupdate.tmp
制作[3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib'
rm -f autom4te.cfg autom4te.tmp
srcdir='';\
测试-f ./autoscan.in || srcdir=./././././././././。/工作空间/ tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/-glibc/08.00_08/Yocto-build/Com-build/arago-build/-builduc-builduc-build/
vbuntu-e s|@shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e 的 s|@perl_fl群[@]|yes bind[@]|/home/Ubuntu/workspace/tijicintract_7|_linux/build_batch/fortrad/es\cl_builde-trad/es\command/native-vebo/sch/rm tradiped|/vebo/sec-ebo/sec-eboup/v_pract/v_pract/v_pract/v_ebo/sec|/v/native-trad/v_-ebo/sec-ebo/sd|@@@@@@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoscan.in autoscan.in autoscan.tmp
srcdir='';\
测试-f ./ifnames.in || srcdir=./././././././././。/工作空间/ tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/-glibc/08.00_08/Yocto-build/Com-build/arago-build/-builduc-builduc-build/
vbuntu-e s|@shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e 的 s|@perl_fl群[@]|yes bind[@]|/home/Ubuntu/workspace/tijicintract_7|_linux/build_batch/fortrad/es\cl_builde-trad/es\command/native-vebo/sch/rm tradiped|/vebo/sec-ebo/sec-eboup/v_pract/v_pract/v_pract/v_ebo/sec|/v/native-trad/v_-ebo/sec-ebo/sd|@@@@@@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ ifnames.in ifnames.in ifnames.tmp
制作[3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/m4dugu'
echo '#此文件是-*- Autoconf -*-的一部分。 &&
echo '# Version of Autoconf.(Autoconf 的#版本。) &&
Echo '#版权所有(C) 1999,2000,2001,2002,2006, 2007,2009年'&&
Echo '# Free Software Foundation, Inc.'(Echo '#免费软件基金会,Inc) &&
回声&&\
echo 'm 4_define ([M4_PACKAGE_NAME],[GNU Autoconf])'&&\
echo 'm 4_define ([M4_PACKAGE_TARNAME],[autoconf])'&&\
echo 'm 4_define ([M4_PACKAGE_VERSION],[2.69])'&&
echo 'm 4_define ([M4_PACKAGE_STRING],[GNU Autoconf 2.69])'&&
echo 'm 4_define ([M4_PACKAGE_BugReport],[bug-autoconf@gnu.org)'&&
echo 'm 4_define ([M4_PACKAGE_URL],[http://www.gnu.org/software/autoconf/])'&&
echo 'm 4_package_y年`s,'Changeed s/`d'([0-9][0-9][0-9][0-9]\)。*/\1/'./././././././././.Log./././././././-m á^`-m
}>版本 m4-t
pkgs|@shell[@]|/bin/bash|g'-e 的前缀@per[@]|/usr/bin/env perl|g'-e 的@windir[@]|/home/ubuntua/workspace/tijacintothto7/dubuntu_08_00_00_08/Yocto build/build/vad_linux/batch_build|/native-vebo/sg/trad/es\ctrad/native-trad/vebo/sm trad/vebo/sm@@@@@@``@@``@@``@@@@@@@@ autom4te.in autom4te.tmp
MV 版本 m4-t 版本 m4
制作[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/m4dugu'
chmod a-w autom4te.tmp
chmod +x autoheader.tmp
chmod +x autom4te.tmp
chmod +x autoreconf.tmp
chmod +x autoscan.tmp
chmod a-w autoheader.tmp
MV autom4te.tmp autom4te.cfg
chmod +x ifnames.tmp
chmod +x autoupdate.tmp
chmod a-w autoreconf.tmp
chmod a-w autoscan.tmp
MV autoheader.tmp 自动标题
chmod a-w autoupdate.tmp
make [3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib'
chmod a-w ifnames.tmp
MV autoreconf.tmp 自动运行
MV autoscan.tmp 自动扫描
MV autoupdate.tmp 自动更新
MV ifnames.tmp ifnames
automitte_perllibdir='./..//..//./..//../../workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Argo-tmp-external-glibc/glibc/-works.-m autoconf.in
rm -f autoconf autoconf.tmp
srcdir='';\
测试-f ./autoconf.in || srcdir=./././././././././。/工作空间/ tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/-glibc/08.00_08/Yocto-build/Com-build/arago-build/-builduc-builduc-build/
vbuntu-e s|@shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e 的 s|@perl_fl群[@]|yes bind[@]|/home/Ubuntu/workspace/tijicintract_7|_linux/build_batch/fortrad/es\cl_builde-trad/es\command/native-vebo/sch/rm tradiped|/vebo/sec-ebo/sec-eboup/v_pract/v_pract/v_pract/v_ebo/sec|/v/native-trad/v_-ebo/sec-ebo/sd|@@@@@@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoconf.in autoconf.in autoconf.tmp
chmod +x autoconf.tmp
chmod a-w autoconf.tmp
MV autoconf.tmp 自动配置
制作[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build\bin'
在中实现所有。
制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64-linux/autoconf-native/2.69-r11/build'
Make [2]:没有为“全 AM”做任何事情。
制作[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build'
在库中实现全部
制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib'
在 Autom4te 中实现一切
制作[3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/Autom4te'
Make [3]:没有为“所有人”做任何事情。
make [3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/Autom4te'
全部用4毫糖制成
automacte_perllibdir='..//../../../../../../workspace/tijicintote_7/CSDD_08_00_11/Yocto-build/Arago-external-arm-arm-glib/.-m
--language=m4sugar \
-冻结\
--output=m4sug.M4F
--language=m4sh \
-冻结\
--output=m4sh.M4F
在 autoconf 中实现全部
make [3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64-linux/autoconf-native/2.69-r11/build/lib/autoconf'
--language=autoconf\
-冻结\
--output=autoconf.m4F
make [3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/autoconf'
在自动测试中全部完成
制作[3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/AutoTest'
--language=AutoTest \
-冻结\
--output=AutoTest.M4F
制作[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/AutoTest'
在自动扫描中实现全部功能
制作[3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/Autoscan'
自动生成的回波“#”:请勿编辑此文件“>自动扫描。列表
SED '/^[#]/!q'./../../../../../../../../../。/workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-externale-arm-linux/autosocc/socc/socc/socc/socce-indice-buildice-builde-builde-builde-linux/autocc/socc/socc/socc/socc/socc/socc/socce-ine.69 native-linux/auto2.69
sd -n '/^[^#]/p'./../../../..../..../..../../工作区/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-..
)| lc_all=C sort >> Autoscan.list
制作[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/Autoscan'
在 emacs 中实现所有
制作[3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/emacs'
警告:可以忽略警告。 :-)
如果测试“否”!=否;则\
设置 x;\
list='autoconf-mode.el AutoTest-mode.el';对于 p in $list;请执行\
如果测试-f“$p”,则 d=;否则 d=。/../。/。/。/。/。/工作空间/ tijacintoto 7/SDK_08_00_08/Yocto-build/Arago-./
设置 x "$@"$d$p";班次;\
完成;\
班次;\
emacs="no"/bin/bash ./././././././././../。/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-external-arm-arm-building-linux-building-2.69@-exclus/inoup-building-exit/exit-buildcp/exit-building-exit-ex-ex-exclusch/2.69英寸/cp/exit-exit-exclus-exclus-export_export_export_export_2.69英寸
否则:;fi
make [3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/emacs'
make [3]:没有什么可以为“全 AM”做的。
make [2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib'
文档中的全部内容
制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build.doc '
make [2]:没有为“所有人”做任何事情。
制作[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build.doc '
测试中的全部
制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/测试'
automacte_perllibdir='./..//..//./..//../../workspace/tijacintto7/SDK_08_00_00_08/Yocto-build/Argo-tmp-external-glibc/libc/-workspacing="-2.69_int_m wrapper.in
autoupdate.tmp
Input=wrapper.in;\
@@@ s|@wrap_program[@]|autocconf|g’s |@abs_top_srcdir[]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Arago tmp-texternal-arm-glibc/workspace/work/x86_doct_2.00_build_8_build/@@ wrapper.in autoconf.tmp
Input=wrapper.in;\
@@@ s|@wrap_program[@]|autoheader|g '-e s|@abs_top_srcdir[]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00/Yocto-build/Arago-external -@@ wrapper.in autoheader.tmp arm-glibc/workspace/workspace_2.8_build/
Input=wrapper.in;\
@@ s|@wrap_program[@]|autoupdate|g’s |@abs_top_srcdir[@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Aracago-tmp-external-arm -glibc/workspace/work/build_7_08./_doct/_8_build/@@ wrapper.in autoupdate.tmp
Input=wrapper.in;\
@-e s|@wrap_program[@]|autom4te|g’s |@abs_top_srcdir[@@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Aracago-tmp-external-arm-glibc/workspace/work/2.8_build/@@ wrapper.in autom4te.tmp
Input=wrapper.in;\
@-e 的 s|@wrap_program[@]|autoreconf|g'-e 的|@abs_top_srcdir[@@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/Aracago-tmp-text-arm-arm-glibc/workspace/work/2.8_build/@@ wrapper.in autoreconf.tmp
Input=wrapper.in;\
@@@ s|@wrap_program[@]|Autoscan|g’s |@abs_top_srcdir[]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-external - arm -glibc/workspace/workspace_2.8_build/@@ wrapper.in autoscan.tmp
Input=wrapper.in;\
@@@ s|@wrap_program[@]|ifnames|g'-e s|@abs_top_srcdir[]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-external - arm -glibc/workspace/workspace_2.8_build/@@ wrapper.in ifnames.tmp
mv -f autoheader.tmp 自动报头
mv -f autoupdate.tmp autoupdate
mv -f autoconf.tmp autoconf
mv -f autom4te.tmp autom4te
mv -f ifnames.tmp ifnames
mv -f autoreconf.tmp autoreconf
MV -f autoscan.tmp 自动扫描
制作[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/测试'
让一切都在人身上
制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/sman'
正在更新手册页..//..//..//..//..//..//..//../工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/automocte-build/build/build/Arago-te-external_conf-glibc/work/x86_64 - linux/2.69-autoconf/2.69-1.
正在更新手册页..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoecone/2.69-native-conf/2.69-rconf/autoecone.11-man-1.
path="./tests:././././././././././。/././workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64–本地版/autoconf/linux-building/2.69-uonesx:/2.69美元
导出路径;\
帮助2人
--include=./././../。/。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autocte-build/build/Arago-te-external-glibc/work/x86_64 - linux/2.69-autoconf/2.69-native/2.69-native-man/2.69英寸
--include=./././../。/。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoconf/2.69-native-man/2.69英寸/autoconf-man-2.69英寸
--sourc='GNU Autoconf 2.69'\
``版/ticjinto7/SDK_08_00_00_08/Yocto-build/Arago-external-glibc/work/x86_64 -linux/autooct/2.69/-man./rm á nit/2.69_m á nit/linux/builds./rm á nit/2.69/conf_m
导出路径;\
帮助2人
--include=./././../。/。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoecone/2.69 - native /autoeconx/2.69
``- output=././../。/工作区/tijacinto7/SDK_08_00_00/08/Yocto-build/Arago-external-glibc/x86_64-man.man-m á nit/2.69_m á c_m á nit/linux/.oct/rconf_2.69/native./rm
正在更新手册页..//..//..//..//..//..//..//..//../工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoconf/2.69-native/auto1.11-man-2.69
导出路径;\
帮助2人
--include=./././././././../。。。/workspace/tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/auto2.69-native/autoconf-2.69
``自动生成/build/Arago-tmp-external-glibc/x86_64 - linux/./autooct/2.69/man._m ²./icoct/build/yoct/an/anoct_2.69_m ² c/soct/inoct/linux/.oct/.oct_2.69_man./linux-builds.
正在更新手册页..//..//..//..//..//..//..//../工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoupdate/2.69-native/autoconconf/2.69-1.
导出路径;\
帮助2人
--include=./././../。/。/工作空间/ tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoupdate/2.69 - native/autoconconf-build/
``版/touchinto7/SDK_08_00_00_08/Yocto-build/Arago-external-glibc/x86_64-pdoct/an é coct/build/aniag/artoct/apiag-externale-arm-glibc/x86_64-man.man.pris/2.69_m á s
正在更新手册页..//..//..//..//..//../。/../工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoconf/2.69-native/rconf/2.69-1.
正在更新手册页..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoifman-build/2.69-native/autoifman-2.69-native-conf/2.69-native
导出路径;\
帮助2人
--include=./././../。/。/工作空间/ tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoconf/2.69-native/autoconf/2.69-native-linux/2.69英寸
``出纸=..//..//..//../。/../工作空间/tijacinto7/SDK_08_00/Yocto-build/Arago-external-glibc/work/x86_64 - linux/.oct/oct/build/rm á native-conf/m á nit/2.69_m á nit/linux/.oct/man./.oct/2.69/man.conf_m
导出路径;\
帮助2人
--include=./././../。/。/工作空间/ tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoifx-native/2.69-native-conf/autoifx-native.x-building/
``出纸=..//..//../workspace/tijacinto7/SDD_08_00/00_08/Yocto-build/Arago-external-glibc/work/x86_64 - linux/.oct/inconf/in/anioct/2.69/_m á native./-m á nit/2.69/man.oct/linux_man.man.man.man.man-m á c_2.8*
正在更新手册页..//..//..//..//..//../。/../工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoconf/sub-build/2.69-native
导出路径;\
帮助2人
--include=./././../。/。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoconf/2.69-native/autoconf/2.69-sub-linux/2.69本机
``出纸=..//..//..//../。/../工作空间/tijacinto7/SDK_08_00/Yocto-build/Arago-external-glibc/work/x86_64 - linux/.oct/oct/build/oct/ocade-conf/ade-m á native-d/
/bin/bash:第3行:help2man:找不到命令
Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/work/work/00_08/Yocto-build/builde/build/arago-tmp-external_conf-64-man-buildice-linux/2.69自动配置失败
制作[2]:***[../../../..../....../........../....../..工作空间/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误2.127/autoconf/linux-building/2.127.
Make [2]:***正在等待未完成的作业...
Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/work/work/00_08/Yocto-build/build/Arago-file-conf-builder-2.69-linux/autocman-buildice-64_2.69自动配置失败
制作[2]:***[../../../..../..../......../....../..工作空间/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误/autoconf/2.127/rm
Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/work/work/00_08/Yocto-builde/builde/builde/artoupde-64-builde-linux/2.69-native-conf-builduc1'/autodeoupde-64_2.69-ued/linux-builducode/oned/onconf-builde-builded/
制作[2]:***[../../../..../..../......../......../..工作空间/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误2.127/autoupman/building/buildingux.127.
Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/work/work/00_08/Yocto-builde/builde/conf-builduce-linux-builduce-builde-builder-2.69-native-64_2.69-native-linux/autoifconf_2.69-native-64_namese-2.69-native-conf_2.69-native-linux/
制作[2]:***[../../../../..../....../......../..../..工作空间/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地名称错误2.127-2.69-rifman
Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/work/work/00_08/Yocto-build/builde/build/Arago-te-arm-conf-builder-2.69-linux/2.69-native-builduce/automog-64_2.69-native/soconconf_2.69-native-64_2.69-native/soconed/2.
制作[2]:***[../../../../..../....../......../..../..工作空间/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误2.127/rconf/auto2.69/1
Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/work/work/00.00_08/Yocto-builde/builde/conf-builde-arago-externe-arm-linux/2.69-native-builde-conf/2.69-native-64_2.69-native-linux/onefinconf_2.69-native
制作[2]:***[../../../..../..../......../....../..工作空间/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误/autoconf/2.127.
Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/work/work/00.00_08/Yocto-build/build/Arago-tmp-external_conf/sub-linux/2.69-native/soconfig/2.69-native/soconconf_2.69-native-conf_2.69-native/soconed/2.69-native-conf_2.69-n
制作[2]:***[../../../../..../....../......../..../..工作空间/ tijacinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误2.127.
制作[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/sman'
Makefile:357:目标“全部递归”的配方失败
Make [1]:***[全部递归]错误1
make [1]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64-linux/autoconf-native/2.69-r11/build'
Makefile:292:目标“全部”的配方失败
品牌:***[全部]错误2
警告:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/temp/run.do_compile.44371:1从“出口1”出口1
错误:存储在以下位置的故障日志文件:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-temp-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/temp/log.do_compile.44371
日志数据如下:
|调试:正在执行 python 函数 autotools_acnefins.
|调试:站点文件['endian-litte','common-linux','common-glibc','bit-64','x86_64 -Linux', '通用'
|调试:Python 函数 autotools_acnit本地 完成
|调试:执行 shell 函数 do 编译
|注:将-j 12
|全部递归
|制作[1]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build'
|在箱中完成所有工作
|制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/bin'
| CD ./lib & Make autom4te.cfg
| srcdir='';\
| test -f ./autom4te.in || srcdir=././././././././././。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibo/2.69;/autoconf-buildice-linux/2.69;/linux-builduc-//oned/2.69
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@per_fl群[@]|ycl|-e 's bind[@@@@@]|/home/ubuntua/workspace/tijacinto7/g/@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autom4te.in autom4te.in autom4te.tmp
| rm -f 自动更新 autoupdate.tmp
| srcdir='';\
| test -f ./autoreconf.in || srcdir=././././././././././。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibo/2.69;/autoconf-buildice-linux/2.69;/linux-builduc-//oned/2.69
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@per_fl群[@]|ycl|-e 's bind[@@@@@]|/home/ubuntua/workspace/tijacinto7/g/@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoreconf.in autoreconf.in autoreconf.tmp
| srcdir='';\
| test -f ./autoheader.in || srcdir=././././././././././。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibo/2.69;/autoconf-buildice-linux/2.69;/linux-builduc-//oned/2.69
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@per_fl群[@]|ycl|-e 's bind[@@@@@]|/home/ubuntua/workspace/tijacinto7/g/@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoheader.in autoheader.in autoheader.tmp
| srcdir='';\
| test -f ./autoupdate.in || srcdir=././././././././././。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibo/2.69;/autoconf-buildice-linux/2.69;/linux-builduc-//oned/2.69
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@per_fl群[@]|ycl|-e 's bind[@@@@@]|/home/ubuntua/workspace/tijacinto7/g/@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoupdate.in autoupdate.in autoupdate.tmp
| make [3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib'
| srcdir='';\
| test -f ./autoscan.in || srcdir=././././././././././。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibo/2.69;/autoconf-buildice-linux/2.69;/linux-builduc-//oned/2.69
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@per_fl群[@]|ycl|-e 's bind[@@@@@]|/home/ubuntua/workspace/tijacinto7/g/@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoscan.in autoscan.in autoscan.tmp
| srcdir='';\
| test -f ./ifnames.in || srcdir=././././././././././。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibo/2.69;/autoconf-buildice-linux/2.69;/linux-builduc-//oned/2.69
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@per_fl群[@]|ycl|-e 's bind[@@@@@]|/home/ubuntua/workspace/tijacinto7/g/@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ ifnames.in ifnames.in ifnames.tmp
|制作[3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/m4sugu'
| echo '#此文件是-*- Autoconf -*-的一部分。” &&
| echo '#版本的 Autoconf。” &&
版权所有(C) 1999,2000,2001,2002,2006 2007,2009年'&&
| echo '# Free Software Foundation, Inc.' &&
|回声&&\
| echo 'm 4_define ([m4_package_name],[GNU Autoconf])'&&\
| echo 'm 4_define ([m4_package_TARNAME],[autoconf])'&&\
| echo 'm 4_define ([m4_package_version],[2.69])'&&
| echo 'm 4_define ([m4_package_string],[GNU Autoconf 2.69])&&
`s^`回波'm 4_package_y年],['Changeed s/`d'([0-9][0-9][0-9][0-9]\)。*/\1/;q'./././
|}>版本 m4-t
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@bind[@]|/home/Ubuntua/workspace/tijacintto7/dubuntu_08_00_00_08/Yocto-build/trad_eskir|/ove-build/svot_m tradtrad/nateg/esg/native-vebuan/trad/trad/vultrad/v_trad/v_tradipedi_tradir_ebo|/v_trad/v_trad/v_trad/v_tradipc/sec_pract/native|/esx@@@@@``@@``@@``@@@@@@@@ autom4te.in autom4te.tmp
| MV 版本.M4-t 版本.M4
|制造[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/m4sugu'
|制作[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib'
| MV autoreconf.tmp autoreconf
| MV autoupdate.tmp autoupdate
自动4te_perllibdir='./../../../../../../../workspace/tijacintto7/SDK_08_00_00_08/Yocto-build/Arago-external-glib-glibc/-moctc/-m autoconf.in
| srcdir='';\
| test -f ./autoconf.in || srcdir=././././././././././。/工作空间/ tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibo/2.69;/autoconf-buildice-linux/2.69;/linux-builduc-//oned/2.69
@-e s|@ shell[@]|/bin/bash|g'-e s|@per[@]|/usr/bin/env perl|g'-e s|@per_fl群[@]|ycl|-e 's bind[@@@@@]|/home/ubuntua/workspace/tijacinto7/g/@@``@@``@@``@@@@@@ @@@@`s^`[@]|gawg|g '-e 的|@release_year[@]|'sred s/p á@([0-9][0-9][0-9][0-9]\)。*/\conf ü@@ 1/_conf./.Log././.jacd/ autoconf.in autoconf.in autoconf.tmp
| MV autoconf.tmp autoconf
|品牌[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/bin'
|在中实现一切。
|制作[2]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build'
|制造[2]:“全 AM”没有任何事情要做。
|品牌[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build'
|在库中完成所有工作
|在 Autom4te 中实现一切
|制造[3]:没有为“所有人”做任何事情。
|品牌[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/Autom4te'
|全用4糖制作
自动4te_perllibdir='../../../../../../../../workspace/tijicintto7/SDK_08_00_11/Yocto-build/Arago-externale-linux-building/.-m
|-冻结\
|--output=m4sug.M4F
|--language=m4sh \
|-冻结\
|--output=m4sh.M4F
|在 autoconf 中实现全部功能
| make [3]:输入目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/autoconf'
|--language=autoconf \
|-冻结\
|--output=autoconf.M4F
|制作[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/autoconf'
|在自动测试中实现全部功能
|-冻结\
|全自动扫描
|自动生成回波“#”:请勿编辑此文件“>自动扫描
自动发送'/^[#]/!q'./../../../..//../..
^-n '/^[#]/p'./../../../../../../../。/../工作区/tijicintoto 7/SDK_08_00_08/Yocto-build/Arago-./../../..
|)| LC_ALL=C Sort >> Autoscan.list
|在 emacs 中完成所有工作
|警告:可以忽略警告。 :-)
|如果测试“否”!=否;则\
|设置 x;\
| list='autoconf-mode.el AutoTest-mode.el';对于 p in $list;请\
|如果 test -f "$p";然后 d=;否则 d=。/../。/。/。/。/。/。/工作空间/ tijacintoto 7/SDK_08_00_08/Yocto-build/build/aracs/2.69-libacs;/autoemconf/linux-external/
|设置 x "$@"$d$p";班次;\
|完成;\
|班次;\
| emacs="no"/bin/bash ./././././././././../。@/workspace/tijicintoto7/SDK_08_00_08/Yocto-build/Arago-tmp-external_arm-building-linux-building-building-building-ding-dice-dcp/inc/inoup-building-ding-ex-export-ex-ex-ex-ex-dcp/cp-ex-export-ding-dcp/cp-export-building-ding-explex-ex-ex-dic-
|其他:; fi.
|制作[3]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib/emacs'
|制造[3]:“全 AM”没有任何事情要做。
|制作[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/lib'
|文档中的全部内容
|制造[2]:“所有人”都不需要做任何事情。
|制作[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/doc'
|测试中的一切
自动4te_perllibdir='./../../..//..//..//..//..//..//workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-external-glib-glibc/-moctc/-m wrapper.in
| input=wrapper.in;\
@-e s|@wrap_program[@]|autoconf|g '-e s|@abs_top_srcdir[@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00/Yocto-build/Aracago-tmp-external-arm-glibc/work/workspace/t_2.00_build_8_08./wbovioct/doct/doct/_build_8_build_cran./doct/_build_cran././doct/./_build-08.x64_doct/././doct/./doct/_build_crt/_cran./././rm á g/-m á@@@ wrapper.in autoconf.tmp
| input=wrapper.in;\
@-e s|@wrap_program[@]|autoheader|g '-e s|@abs_top_srcdir[@@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Aracago-tmp-external-arm-g-glibc/workspace/works/work/2.8_build_8_build/@@ wrapper.in autoheader.tmp
| input=wrapper.in;\
@-e s|@wrap_program[@]|autoupdate|g '-e s|@abs_top_srcdir[@]|/home/Ubuntu/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-arm-external-arm -glibc/workspace/build_7_m á@@@ wrapper.in autoupdate.tmp
| input=wrapper.in;\
@-e s|@wrap_program[@]|autom4te|g’s |@abs_top_srcdir[@@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/Aracago-tmp-external-arm -glibc/work/workspace/work/build_8_8_/_build/@@ wrapper.in autom4te.tmp
| input=wrapper.in;\
@-e s|@wrap_program[@]|autoreconf|g’s |@abs_top_srcdir[@@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_08/Yocto-build/Aracago-tmp-external-arm -glibc/work/workspace/t_2.00_build_08/_8_incti_x@@ wrapper.in autoreconf.tmp
| input=wrapper.in;\
@-e s|@wrap_program[@]|Autoscan|g '-e s|@abs_top_srcdir[@@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Aracago-tmp-external-arm-glibc/workspace/work/2.8_build/@@ wrapper.in autoscan.tmp
| input=wrapper.in;\
@-e s|@wrap_program[@]|ifnames|g '-e s|@abs_top_srcdir[@@]|/home/Ubuntu/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Aracago-tmp-external-arm-g-glibc/workspace/works/work/2.8_build_8_build/@@ wrapper.in ifnames.tmp
|让一切尽在人
|正在更新手册页..//..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/automocte-build/build/Arago-te-arm-libc/-builducding/soct/2.69-2.69-native/autoconf/2.69-1.
|正在更新手册页..//..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoecone/2.69-nite-2.69
| path="./tests:./././././././././././。/workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_native-build/2.69-autoconconf/2.69-linux-building/2.69-uonocup_2.69美元
|导出路径;\
| Help2man \
|--include=./././././././././././。。/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - native/2.69-linux/autoconf/2.69-native-linux/2.69-/autoconf/2.69-/autoprone.x-build/
|--include=./././././././././././。。/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 -linux/autoconf/2.69-native-man/2.69英寸
``-output=././../。/../。/../工作区/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago tmp-external-glibc/work/x86_64 _build/,自动版/ioct/2.69/native./linux_2.69/man._conf_build/
|导出路径;\
| Help2man \
|--include=./././././././././././。。/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 -本地版/autoeconx/2.69-nonocx-man/2.69
``-output=..//..//..//../。/../工作区/tijicinto7/SDK_08_00/Yocto-build/Arago-external-glibc/x86_64_man./icoct/build/yoct/anago-tmp-externale-arm-glibc/x86_64_man.man.man./-m
|正在更新手册页..//..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/auto2.69-native/autoconf-2.69-1.
|导出路径;\
| Help2man \
|--include=./././././././././././。/../工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - native/autocx-linux/2.69-autoconf/2.69-native-linux/auto2.69
`-output=..//..//..//..//../工作空间/tijicinto7/SDD_08_00_00_08/Yocto-build/Arago tmp-external-glibc/work/x86_64 _inchman./rm á`-m á nit/icoct/2.69/native./linux/.oct/oct_man.oct_2.8*
|正在更新手册页.//..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoupdate/2.69-native/autoconconf/2.69 -本地配置文件
|导出路径;\
| Help2man \
|--include=./././././././././././。。/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoupdim/2.69 - native/autoconf/2.69
`-output=..//..//..//..//../工作空间/tijicinto7/SDK_08_00/Yocto-build/Arago-external-glibc/work/x86_64 _build/,`ç o/octoct/build/artoct/aniag-externale-arm-glibc/works./2.69/toct/build/
|正在更新手册页..//..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoconf/2.69-native-man/2.69英寸/autoconf-man-2.69英寸
|正在更新手册页.//..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 -linux/autoifman-2.69-1.native-man-2.69
|导出路径;\
| Help2man \
Check Alignment of PHs>|--include=././././././././././。/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 - linux/autoconf/2.69-native-linux/2.69英寸/autoconf/2.69英寸
`-output=././././../。/../工作区/tijacinto7/SDK_08_00_00_08/Yocto-build/Arago tmp-external-glibc/work/x86_64 _build/,`ç o/ioct/oct/oct/build./rm
|导出路径;\
| Help2man \
|--include=./././././././././././。。/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 -linux/autoifx-man2.69本机名称\2.69
``-output=..//..//..//../workspace/tijicinto7/SDD_08_00/Yocto-build/Arago-tmp-external-glibc/x86_64_man./liboct/-build/
|正在更新手册页.//..//..//..//..//..//..//..//..//..工作空间/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/work/x86_64 - linux/autoconf/sub-man2.69-1.
|导出路径;\
| Help2man \
Check Alignment of PHs>|--include=././././././././././。。/workspace/tijacinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-glibc/work/x86_64 -linux/autoconf/2.69-native/rconf/2.69-sub-linux/autoconf/2.69
``-output=././././../。/../工作区/tijacinto7/SDK_08_00_08/Yocto-build/Arago tmp-external-glibc/x86_64_man./oct/oct/oct/build/
| Makefile:460:目标'../../../../../../../../../../..//../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/linux/usediecone/2.69-native/soceconconf/2.69-native/soceconed/2.69-rconf_2.69-native/soceconconf_2.69-native/soceconed/2.69-
|品牌[2]:***[..//../../..../....../......../......../工作区/ tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-gecibc/work/x86/autoconf/2.127-native_2.69-rconf/buildice-building/soct/r/soct/r/soct/r/soctoco-conf/r/soctoctom-buildice-buildice-buildice-r/smp-native
|制造[2]:***正在等待未完成的作业...
| Makefile:460:目标'../../../../../../../../../../..//../workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/linux/auto2.69-1'/autosman-builduc1'/linux-builduc1'/autoconf-building/socc/secom-building-building/secom-building/secom-building/soconese-conf-building-building-
|品牌[2]:***[..//../../../..../....../......../..../工作空间/ tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误/autoconf/2.127/r69/1
| Makefile:460:目标'../../../../../../../../../../..//../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/linux/cotied/2.69-native/autoupdate_2.69-uplode/linux-builducode/builduce-conf_2.69-ued/linux-builduce-builduce-building/sechtoupde-conf_2.69
|品牌[2]:***[..//../../../..../..../......../....../工作空间/ tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误:/autoupdim/2.127.
| Makefile:460:目标'../../../../../../../../../../..//../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/linux/work/2.69-native_namese-2.69-linux/autoifconf_2.69-native_2.69-native
|品牌[2]:***[..//../../../..../....../....../....../工作空间/ tijacintoto 7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地名称错误2.127-2.69-autoifman
| Makefile:460:目标'../../../../../../../../../../..//../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/linux/usote/auto2.69-native/linux-buildift/2.69-native_conf_2.69-builduc1
|制造商[2]:***[..//.././.../...../....../......./workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64-native-conf/2.127-rm
| Makefile:460:目标'../../../../../../../../../../../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externe-arm-glibc/linux/occ/smbad/2.69-native/secnative-conf/2.69-linux_2.69-native/smbid/2.69-building_2.69-building_conf_2.69
|品牌[2]:***[..//../../..../..../......../....../..工作空间/ tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误:/autoconf/2.127.
| Makefile:460:目标'../../../../../../../../../../..//../workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-externo-arm-glibc/linux/occ/socman-2.69-native/soconconf/2.69-native/soconfig-builduce/soconed/rconf/2.69-native/socc/soconed/2.69-native/soconconf_2.69-native/socconf_2.69-linux-conf_2.
|品牌[2]:***[..//../../../..../....../....../....../工作空间/ tijacintoto 7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 -本地错误:/autoconf/2.127.
|品牌[2]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build/sman'
|品牌[1]:离开目录'/home/Ubuntu/buildspace/tijicintobuild/Yocto-build/SDK_08_00_08/Arago-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/build'
|品牌:***[全部]错误2.
|错误:OE_runmake 失败
|警告:/home/Ubuntu/workspace/tijicinto7/SDK_08_00_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 - linux/autocconf-native/2.69-r11/temp/run.do_compile.44371:1从“出口1”出口下
|错误:执行'/home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/Arago-tmp-external-arm-glibc/work/x86_64 - linux/autoconf-native/2.69-r11/temp/run.do_compile.44371'失败,退出代码为1:
|全部递归
|在箱中完成所有工作
| srcdir='';\
| srcdir='';\
| srcdir='';\
| srcdir='';\
| srcdir='';\
| srcdir='';\
|回声&&\
|}>版本 m4-t
| MV 版本.M4-t 版本.M4
| srcdir='';\
|在中实现一切。
|在库中完成所有工作
|在 Autom4te 中实现一切
|全用4糖制作
|-冻结\
|--output=m4sug.M4F
|--language=m4sh \
|-冻结\
|--output=m4sh.M4F
|在 autoconf 中实现全部功能
|-冻结\
|在自动测试中实现全部功能
|-冻结\
|全自动扫描
|在 emacs 中完成所有工作
|警告:可以忽略警告。 :-)
|如果测试“否”!=否;则\
|设置 x;\
|设置 x "$@"$d$p";班次;\
|完成;\
|班次;\
|其他:; fi.
|文档中的全部内容
|测试中的一切
| input=wrapper.in;\
| input=wrapper.in;\
| input=wrapper.in;\
| input=wrapper.in;\
| input=wrapper.in;\
| input=wrapper.in;\
| input=wrapper.in;\
|让一切尽在人
|导出路径;\
| Help2man \
|导出路径;\
| Help2man \
|导出路径;\
| Help2man \
|导出路径;\
| Help2man \
|导出路径;\
| Help2man \
|导出路径;\
| Help2man \
|导出路径;\
| Help2man \
|品牌:***[全部]错误2.
错误:任务(虚拟:home/Ubuntu/workspace/tijicinto7/SDK_08_00_08/Yocto-build/sources/OE-core/meta/菜谱-devtools/autoconf/autoconf_2.69.bb:do_compile)失败,退出代码为“1”
谢谢,
湿婆
