[参考译文] TDA4VM:SBL_Boot_Problem
Guru**** 2680875 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1078023/tda4vm-sbl_boot_problem
部件号:TDA4VM
您好,先生:
我使用 SBL 启动并使用 NFS 装载文件系统,但 SD 卡崩溃。
是否有办法解决这一问题?
PSDK vserion:8.1
Rootfs: tisdk-default-image-j7-EVM-EVM-EVM-EVM-EVM-tar.xz
NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
NOTICE:  BL31: Built : 19:52:11, Dec 20 2021
ERROR:   GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[    0.000000] Linux version 5.10.65-rt53 (pierrehsieh@jetson-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT_RT Tue Feb 15 15:20:00 CST 2022
[    0.000000] Machine model: Texas Instruments K3 J721E SoC
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
[    0.000000] OF: reserved mem: OVERLAP DETECTED!
[    0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-eth-queues@ac000000 (0x00000000ac000000--0x00000000ac200000)
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
[    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
[    0.000000] Carveout Heap: regions without no-map are not yet supported
[    0.000000] OF: reserved mem: node vision_apps_shared-memories compatible matching fail
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
[    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
[    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
[    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
[    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
[    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000fbffffff]
[    0.000000]   node   0: [mem 0x00000000fc000000-0x00000000ffffffff]
[    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
[    0.000000]   node   0: [mem 0x00000008c0000000-0x00000008ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[    0.000000] On node 0 totalpages: 1048576
[    0.000000]   DMA zone: 8192 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 524288 pages, LIFO batch:63
[    0.000000]   Normal zone: 8192 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, LIFO batch:63
[    0.000000] cma: Reserved 24 MiB at 0x00000000fe800000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.2
[    0.000000] percpu: Embedded 18 pages/cpu s34752 r8192 d30784 u73728
[    0.000000] pcpu-alloc: s34752 r8192 d30784 u73728 alloc=18*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: EL2 vector hardening
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nfs rw rootfstype=nfs root=/dev/nfs rw nfsroot=192.168.100.100:/home/user/net_nfsshare/PSDKv81_targetNFS,nolock,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB)
[    0.000000] Memory: 1969216K/4194304K available (10624K kernel code, 1156K rwdata, 4108K rodata, 1728K init, 438K bss, 2200512K reserved, 24576K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] rcu: 	RCU_SOFTIRQ processing moved to rcuc kthreads.
[    0.000000] 	No expedited grace period (rcu_normal_after_boot).
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 960 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] GICv3: Distributor has no Range Selector support
[    0.000000] GICv3: 16 PPIs implemented
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x00000008c0030000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0040000
[    0.000000] random: get_random_bytes called from start_kernel+0x320/0x4c8 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008345] Console: colour dummy device 80x25
[    0.012910] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023579] pid_max: default: 32768 minimum: 301
[    0.028333] LSM: Security Framework initializing
[    0.033084] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040659] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049459] rcu: Hierarchical SRCU implementation.
[    0.054586] Platform MSI: msi-controller@1820000 domain created
[    0.060809] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070115] EFI services will not be available.
[    0.074841] smp: Bringing up secondary CPUs ...
[    0.085785] Detected PIPT I-cache on CPU1
[    0.089939] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.096970] GICv3: CPU1: using allocated LPI pending table @0x00000008c0050000
[    0.104377] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.111097] smp: Brought up 1 node, 2 CPUs
[    0.115291] SMP: Total of 2 processors activated.
[    0.120100] CPU features: detected: 32-bit EL0 Support
[    0.125354] CPU features: detected: CRC32 instructions
[    0.138877] CPU: All CPU(s) started at EL2
[    0.143072] alternatives: patching kernel code
[    0.148109] devtmpfs: initialized
[    0.157215] KASLR disabled due to lack of seed
[    0.161844] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.171808] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
[    0.179277] pinctrl core: initialized pinctrl subsystem
[    0.184851] DMI not present or invalid.
[    0.189013] NET: Registered protocol family 16
[    0.194226] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.201498] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.209488] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.217807] thermal_sys: Registered thermal governor 'step_wise'
[    0.218082] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.231180] ASID allocator initialised with 32768 entries
[    0.248616] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.255496] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.262353] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.269210] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.276601] cryptd: max_cpu_qlen set to 1000
[    0.282536] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
[    0.291338] vsys_3v3: supplied by evm_12v0
[    0.295708] vsys_5v0: supplied by evm_12v0
[    0.300073] vdd_mmc1: supplied by vsys_3v3
[    0.304549] vdd_sd_dv_alt: supplied by vsys_3v3
[    0.309673] iommu: Default domain type: Translated
[    0.314814] SCSI subsystem initialized
[    0.318923] mc: Linux media interface: v0.10
[    0.323298] videodev: Linux video capture interface: v2.00
[    0.328927] pps_core: LinuxPPS API ver. 1 registered
[    0.333997] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.343333] PTP clock support registered
[    0.347350] EDAC MC: Ver: 3.0.0
[    0.351063] FPGA manager framework
[    0.354581] Advanced Linux Sound Architecture Driver Initialized.
[    0.361184] clocksource: Switched to clocksource arch_sys_counter
[    0.367512] VFS: Disk quotas dquot_6.6.0
[    0.371543] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.381382] NET: Registered protocol family 2
[    0.386082] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.394689] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.403596] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.411826] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
[    0.420475] TCP: Hash tables configured (established 32768 bind 32768)
[    0.427379] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
[    0.434553] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
[    0.442260] NET: Registered protocol family 1
[    0.447063] RPC: Registered named UNIX socket transport module.
[    0.453125] RPC: Registered udp transport module.
[    0.457929] RPC: Registered tcp transport module.
[    0.462731] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.469315] PCI: CLS 0 bytes, default 64
[    0.473707] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.484000] Initialise system trusted keyrings
[    0.488641] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.497151] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.503398] NFS: Registering the id_resolver key type
[    0.508692] Key type id_resolver registered
[    0.512975] Key type id_legacy registered
[    0.517103] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.523963] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.531652] 9p: Installing v9fs 9p2000 file system support
[    0.556731] Key type asymmetric registered
[    0.560926] Asymmetric key parser 'x509' registered
[    0.565936] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.573508] io scheduler mq-deadline registered
[    0.578135] io scheduler kyber registered
[    0.583205] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.589406] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.597351] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.603620] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.611440] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.619387] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.627513] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.634657] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.643205] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.656146] brd: module loaded
[    0.663103] loop: module loaded
[    0.666725] megasas: 07.714.04.00-rc1
[    0.671648] libphy: Fixed MDIO Bus: probed
[    0.676314] tun: Universal TUN/TAP device driver, 1.6
[    0.681713] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.688128] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.694215] sky2: driver version 1.30
[    0.698425] VFIO - User Level meta-driver version: 0.3
[    0.704063] i2c /dev entries driver
[    0.708094] sdhci: Secure Digital Host Controller Interface driver
[    0.714417] sdhci: Copyright(c) Pierre Ossman
[    0.719088] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.725435] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.732579] optee: probing for conduit method.
[    0.737149] optee: revision 3.12 (3d47a131)
[    0.737407] optee: initialized driver
[    0.746308] NET: Registered protocol family 17
[    0.750947] 9pnet: Installing 9P2000 support
[    0.755343] Key type dns_resolver registered
[    0.759867] printk: bootconsole [ns16550a0]: printing thread started
[    0.759891] Loading compiled-in X.509 certificates
[    0.763956] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.764053] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.765669] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
[    0.781793] random: fast init done
[    0.803723] printk: console [ttyS2]: printing thread started
[    0.803728] printk: console [ttyS2] enabled
[    0.803730] printk: bootconsole [ns16550a0] disabled
[    0.803740] printk: bootconsole [ns16550a0]: printing thread stopped
[    0.809588] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250
[    0.817239] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250
[    0.825242] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    0.825248] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    0.825251] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    0.825253] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    0.873783] scsi host0: ufshcd
[    0.925193] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    0.925203] libphy: 46000f00.mdio: probed
[    0.926400] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    0.926448] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    0.927464] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    0.928133] mmc0: CQHCI version 5.10
[    0.928447] mmc1: CQHCI version 5.10
[    0.941292] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    0.945236] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    0.953240] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    0.953743] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    0.957212] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    0.969443] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    0.978272] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    0.978740] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    1.010057] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    1.012339] mmc1: new high speed SDHC card at address aaaa
[    1.012760] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
[    1.015128]  mmcblk1: p1 p2
[    1.056209] mmc0: Command Queue Engine enabled
[    1.056218] mmc0: new HS200 MMC card at address 0001
[    1.056513] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
[    1.056630] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
[    1.056741] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
[    1.056844] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
[    1.057576]  mmcblk0: p1 p2
[    1.085200] spi-nor spi0.0: mt35xu02g (262144 Kbytes)
[    1.133198] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.133207] libphy: 46000f00.mdio: probed
[    1.134412] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    1.134456] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    1.135324] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    1.135768] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    1.135772] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    1.136104] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    1.137072] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    1.137097] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    1.138484] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    1.138510] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    1.138537] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    1.138567] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    1.291022] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    1.291029] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    1.291032] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    1.291034] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    1.291037] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    1.291039] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    1.291042] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    1.291044] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    1.291046] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    1.291048] cdns-ufshcd 4e84000.ufs: last intr at 1180725 us, last intr status=0x404
[    1.291051] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    1.291054] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    1.291056] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    1.291059] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    1.291062] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    1.291064] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    1.291067] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    1.291086] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    1.291089] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    1.291092] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    1.291095] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    1.291097] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    1.291099] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    1.291101] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    1.291103] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    1.291105] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    1.291107] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    1.291110] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    1.291112] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    1.291114] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    1.291116] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    1.291118] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    1.291120] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    1.291122] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    1.291124] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1181841 us
[    1.291127] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    1.291129] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    1.291131] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    1.291133] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    1.291135] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    1.300696] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[    1.303210] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[    5.390657] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[    5.413199] Sending DHCP requests ., OK
[    6.425215] IP-Config: Got DHCP answer from 192.168.5.1, my address is 192.168.5.16
[    6.425220] IP-Config: Complete:
[    6.425222]      device=eth0, hwaddr=50:51:a9:8e:61:50, ipaddr=192.168.5.16, mask=255.255.255.0, gw=192.168.5.1
[    6.425226]      host=192.168.5.16, domain=, nis-domain=(none)
[    6.425228]      bootserver=0.0.0.0, rootserver=192.168.5.231, rootpath=
[    6.425230]      nameserver0=192.168.5.20, nameserver1=192.168.1.1, nameserver2=168.95.1.1
[    6.430644] ALSA device list:
[    6.430648]   No soundcards found.
[    6.439621] VFS: Mounted root (nfs filesystem) on device 0:20.
[    6.439754] devtmpfs: mounted
[    6.440525] Freeing unused kernel memory: 1728K
[    6.453281] Run /sbin/init as init process
[    6.643143] systemd[1]: System time before build time, advancing clock.
[    6.664450] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    6.664651] systemd[1]: Detected architecture arm64.
Welcome to Arago 2021.09!
[    6.710664] systemd[1]: Set hostname to <j7-evm>.
[    7.098091] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    7.098121] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    7.129888] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[  OK  ] Created slice system-getty.slice    7.227793] random: systemd: uninitialized urandom read (16 bytes read)
[    7.227904] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
m.
[    7.227910] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    7.229615] systemd[1]: Created slice system-getty.slice.
[    7.268697] random: systemd: uninitialized urandom read (16 bytes read)
[    7.269628] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice User and Session Slice.
[    7.297267] random: systemd: uninitialized urandom read (16 bytes read)
[    7.297958] systemd[1]: Created slice User and Session Slice.
[    7.313418] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    7.349343] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    7.365315] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[  OK  ] Reached target Remote File Systems.
[    7.393260] systemd[1]: Reached target Remote File Systems.
[    7.409254] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[  OK  ] Reached target Swap.[    7.433269] systemd[1]: Reached target Swap.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    7.455391] systemd[1]: Listening on RPCbind Server Activation Socket.
[    7.469295] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[  OK  ] Listening on Process Core Dump Socket.
[    7.502754] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on initctl Compatibility [    7.523237] systemd[1]: Listening on initctl Compatibility Named Pipe.
Named Pipe.
[  OK  ] Listening on Journal Socket (/dev/log).
[    7.554659] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    7.555455] systemd[1]: Listening on Journal Socket (/dev/log).
[    7.569583] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    7.607202] systemd[1]: Listening on Network Service Netlink Socket.
[    7.623328] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[  OK  ] Listening on udev Kernel Socket.
[    7.649464] systemd[1]: Listening on udev Kernel Socket.
[    7.667666] systemd[1]: Mounting Huge Pages File System...
         Mounting POSIX Message Queue File System..[    7.691636] systemd[1]: Mounting POSIX Message Queue File System...
         Mounting Kernel Debug File System...
[    7.715656] systemd[1]: Mounting Kernel Debug File System...
         Mounting Temporary Directory (/tmp)...
[    7.739634] systemd[1]: Mounting Temporary Directory (/tmp)...
         Starting Start psplash boot splash screen.[    7.751357] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[    7.754111] systemd[1]: Starting Start psplash boot splash screen...
         Starting RPC Bind...
[    7.784669] systemd[1]: Starting RPC Bind...
         Starting Journal Service...
[    7.793711] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
         Starting Load Kernel Modules...
[    7.796969] systemd[1]: Starting Journal Service...
         Starting Remount Root and Kernel File Systems systemd[1]: Starting Load Kernel Modules...
[0m...
[    7.836046] systemd[1]: Starting Remount Root and Kernel File Systems...
         Starting udev Coldplug all Devices...
[    7.864538] systemd[1]: Starting udev Coldplug all Devices...
[  OK  ] Mounted Huge Pages File System.[    7.883278] systemd[1]: Mounted Huge Pages File System.
[  OK  ] Mounted POSIX Message Queue File Sy[    7.905865] systemd[1]: Mounted POSIX Message Queue File System.
stem.
[  OK  ] Started Journal Service.[    7.931666] systemd[1]: Started Journal Service.
[    7.937576] random: crng init done
[    7.937582] random: 7 urandom warning(s) missed due to ratelimiting
[  OK  ] Started RPC Bind.
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Mounted Temporary Directory (/tmp).
[FAILED] Failed to start Start psplash boot splash screen.
See 'systemctl status psplash-start.service' for details.
[DEPEND] Dependency failed for Star…progress communication helper.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Remount Root and Kernel File Systems.
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
         Starting Apply Kernel Variables...
         Starting Create System Users...
[    8.183519] systemd-journald[191]: Received client request to flush runtime journal.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create System Users.
         Starting Create Static Device Nodes in /dev...
[  OK  ] Started udev Coldplug all Devices.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting udev Wait for Complete Device Initialization...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Rebuild Dynamic Linker Cache...
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Rebuild Journal Catalog...
[FAILED] Failed to start Network Time Synchronization.
See 'systemctl status systemd-timesyncd.service' for details.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Stopped Network Time Synchronization.
[  OK  ] Started Rebuild Journal Catalog.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Found device /dev/mmcblk0p1.
         Starting File System Check on /dev/mmcblk0p1...
[  OK  ] Started File System Check on /dev/mmcblk0p1.
         Mounting /run/media/mmcblk0p1...
[  OK  ] Mounted /run/media/mmcblk0p1.
[  OK  ] Found device /dev/mmcblk1p2.
[  OK  ] Found device /dev/mmcblk1p1.
[  OK  ] Started udev Wait for Complete Device Initialization.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
         Starting File System Check on /dev/mmcblk1p1...
         Starting File System Check on /dev/mmcblk1p2...
[   13.854099] Unable to handle kernel paging request at virtual address ffff80086ebe5000
[   13.857187] Unable to handle kernel paging request at virtual address ffff80086ebd3000
[   13.862010] Mem abort info:
[   13.869900] Mem abort info:
[   13.872678]   ESR = 0x96000005
[   13.875457]   ESR = 0x96000005
[   13.878497]   EC = 0x25: DABT (current EL), IL = 32 bits
[   13.881535]   EC = 0x25: DABT (current EL), IL = 32 bits
[   13.886826]   SET = 0, FnV = 0
[   13.892117]   SET = 0, FnV = 0
[   13.895155]   EA = 0, S1PTW = 0
[   13.898193]   EA = 0, S1PTW = 0
[   13.901317] Data abort info:
[   13.904443] Data abort info:
[   13.907307]   ISV = 0, ISS = 0x00000005
[   13.910171]   ISV = 0, ISS = 0x00000005
[   13.913990]   CM = 0, WnR = 0
[   13.917808]   CM = 0, WnR = 0
[   13.920761] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000080ef8000
[   13.923713] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000080ef8000
[   13.930391] [ffff80086ebe5000] pgd=00000008fffff003, p4d=00000008fffff003, pud=0000000000000000
[   13.937070] [ffff80086ebd3000] pgd=00000008fffff003, p4d=00000008fffff003, pud=0000000000000000
[   13.945744] Internal error: Oops: 96000005 [#1] PREEMPT_RT SMP
[   13.960227] Modules linked in:
[   13.963269] CPU: 1 PID: 753 Comm: rngd Not tainted 5.10.65-rt53 #2
[   13.969431] Hardware name: Texas Instruments K3 J721E SoC (DT)
[   13.975245] pstate: 40000085 (nZcv daIf -PAN -UAO -TCO BTYPE=--)
[   13.981233] pc : cpuacct_charge+0x64/0xa8
[   13.985238] lr : cpuacct_charge+0x40/0xa8
[   13.989233] sp : ffff800013753c90
[   13.992532] x29: ffff800013753c90 x28: ffff0008425b1d80
[   13.997828] x27: 0000000000000000 x26: ffff00087fb6b540
[   14.003122] x25: ffff800010e48600 x24: ffff000840c55880
[   14.008417] x23: ffff00087fb6b4c0 x22: 0000000000000000
[   14.013712] x21: ffff0008425b1d80 x20: 0000000000017719
[   14.019006] x19: 0000000000000000 x18: 0000000000000000
[   14.024300] x17: 0000000000000000 x16: 0000000000000000
[   14.029594] x15: 0000000000000000 x14: 0000000000000000
[   14.034889] x13: 0000000000000000 x12: 0000000000000c2f
[   14.040182] x11: 000000000000012b x10: 000000000030fad7
[   14.045476] x9 : 000000000030fad7 x8 : 0000000000000000
[   14.050770] x7 : ffff00087fb6bfc0 x6 : ffff00087fb6b4c0
[   14.056064] x5 : 0000000000000000 x4 : ffff80086ebe5000
[   14.061358] x3 : ffff80086ebe5000 x2 : ffff000845e18400
[   14.066652] x1 : ffff0008425b1d80 x0 : 0000000000000000
[   14.071947] Call trace:
[   14.074381]  cpuacct_charge+0x64/0xa8
[   14.078029]  update_curr+0xfc/0x1a8
[   14.081504]  put_prev_entity+0x74/0x108
[   14.085325]  pick_next_task_fair+0x218/0x388
[   14.089580]  __schedule+0x120/0x7b8
[   14.093057]  schedule+0x88/0x108
[   14.096271]  do_notify_resume+0x204/0x718
[   14.100268]  work_pending+0xc/0x43c
[   14.103746] Code: d503201f f9406440 d538d084 8b050000 (f8646803)
[   14.109821] ---[ end trace 0000000000000002 ]---
[   14.114491] Internal error: Oops: 96000005 [#2] PREEMPT_RT SMP
[   14.114492] note: rngd[753] exited with preempt_count 2
[   14.120305] Modules linked in:
[   14.125517] Unable to handle kernel paging request at virtual address ffff80086ebe5010
[   14.128549] CPU: 0 PID: 752 Comm: rngd Tainted: G      D           5.10.65-rt53 #2
[   14.136441] Mem abort info:
[   14.143985] Hardware name: Texas Instruments K3 J721E SoC (DT)
[   14.146763]   ESR = 0x96000005
[   14.152575] pstate: 80000085 (Nzcv daIf -PAN -UAO -TCO BTYPE=--)
[   14.155612]   EC = 0x25: DABT (current EL), IL = 32 bits
[   14.161597] pc : cpuacct_account_field+0x4c/0x88
[   14.166890]   SET = 0, FnV = 0
[   14.171488] lr : cpuacct_account_field+0x24/0x88
[   14.174528]   EA = 0, S1PTW = 0
[   14.179126] sp : ffff800010003d70
[   14.182251] Data abort info:
[   14.185549] x29: ffff800010003d70 x28: ffff00087fb56440
[   14.188413]   ISV = 0, ISS = 0x00000005
[   14.193704] x27: ffff00087fb56c18 x26: ffff800010162308
[   14.197522]   CM = 0, WnR = 0
[   14.202813] x25: 0000000000000001 x24: 0000000000000080
[   14.205766] swapper pgtable: 4k pages, 48-bit VAs, pgdp=0000000080ef8000
[   14.211057] x23: 000000000000000f x22: ffff00087fb564e8
[   14.217735] [ffff80086ebe5010] pgd=00000008fffff003, p4d=00000008fffff003, pud=0000000000000000
[   14.223026] x21: ffff0008425b0ec0 x20: 00000000003b1c3f
[   14.236990] x19: 0000000000000000 x18: 0000000000000000
[   14.242286] x17: 0000000000000000 x16: 0000000000000000
[   14.247579] x15: 0000000000000000 x14: 0000000000000000
[   14.252874] x13: 003d090000000000 x12: 00003d0900000000
[   14.258168] x11: 0000000000000000 x10: 00003d0900000000
[   14.263462] x9 : 00000000000c3500 x8 : 0000000000000000
[   14.268756] x7 : 0000000000000008 x6 : ffff8000110d1120
[   14.274049] x5 : 0000000000000000 x4 : ffff80086ebd3000
[   14.279343] x3 : ffff000845e18400 x2 : 00000000003b1c3f
[   14.284637] x1 : ffff0008425b0ec0 x0 : 0000000000000000
[   14.289932] Call trace:
[   14.292365]  cpuacct_account_field+0x4c/0x88
[   14.296621]  account_user_time+0x9c/0xe0
[   14.300531]  irqtime_account_process_tick+0x104/0x148
[   14.305568]  account_process_tick+0xb8/0xc8
[   14.309736]  update_process_times+0x54/0xa0
[   14.313907]  tick_sched_handle.isra.0+0x34/0x50
[   14.318423]  tick_sched_timer+0x4c/0xa8
[   14.322244]  __hrtimer_run_queues+0x128/0x210
[   14.326586]  hrtimer_interrupt+0xe8/0x248
[   14.330581]  arch_timer_handler_phys+0x34/0x48
[   14.335012]  handle_percpu_devid_irq+0x84/0x148
[   14.339529]  generic_handle_irq+0x30/0x48
[   14.343523]  __handle_domain_irq+0x64/0xc0
[   14.347605]  gic_handle_irq+0x58/0x128
[   14.351340]  el0_irq_naked+0x4c/0x54
[   14.354903] Code: 937d7e65 f9406860 d538d084 8b050000 (f8646801)
[   14.360984] ------------[ cut here ]------------
[   14.365584] WARNING: CPU: 0 PID: 752 at kernel/locking/rtmutex.c:2040 __rt_mutex_trylock+0x20/0xe0
[   14.374523] Modules linked in:
[   14.377562] CPU: 0 PID: 752 Comm: rngd Tainted: G      D           5.10.65-rt53 #2
[   14.385111] Hardware name: Texas Instruments K3 J721E SoC (DT)
[   14.390923] pstate: 00000085 (nzcv daIf -PAN -UAO -TCO BTYPE=--)
[   14.396911] pc : __rt_mutex_trylock+0x20/0xe0
[   14.401253] lr : _mutex_trylock+0x10/0x20
[   14.405248] sp : ffff800010003870
[   14.408547] x29: ffff800010003870 x28: ffff0008425b0ec0
[   14.413841] x27: ffff00087fb56c18 x26: ffff800010162308
[   14.419135] x25: 0000000000000001 x24: 0000000000000080
[   14.424428] x23: ffff0008425b0ec0 x22: ffff8000111fee40
[   14.429722] x21: ffff8000111fe000 x20: ffff800010003c20
[   14.435016] x19: ffff0008425b0ec0 x18: 0000000000000010
[   14.440309] x17: 0000000000000000 x16: 0000000000000000
[   14.445603] x15: ffff0008425b1400 x14: ffffffffffffffff
[   14.450897] x13: ffff8000900036d7 x12: ffff8000100036df
[   14.456192] x11: ffff80001112cf80 x10: ffff8000110dd600
[   14.461486] x9 : ffff800011129d10 x8 : 6620353665376437
[   14.466780] x7 : 3339203a65646f43 x6 : ffff80001117d73f
[   14.472073] x5 : ffff00087fb53b30 x4 : ffff8000110ca6b8
[   14.477367] x3 : ffff800010003c20 x2 : ffff0008425b0ec0
[   14.482660] x1 : 0000000000010001 x0 : ffff8000111fee50
[   14.487954] Call trace:
[   14.490387]  __rt_mutex_trylock+0x20/0xe0
[   14.494382]  _mutex_trylock+0x10/0x20
[   14.498031]  __crash_kexec+0x38/0x120
[   14.501679]  crash_kexec+0x58/0x98
[   14.505066]  die+0x1e0/0x268
[   14.507935]  die_kernel_fault+0x64/0x78
[   14.511758]  __do_kernel_fault+0x74/0x148
[   14.515753]  do_bad_area+0x5c/0x68
[   14.519140]  do_translation_fault+0x38/0x68
[   14.523308]  do_mem_abort+0x40/0xa0
[   14.526782]  el1_abort+0x48/0x70
[   14.529996]  el1_sync_handler+0xac/0xc8
[   14.533816]  el1_sync+0x88/0x140
[   14.537030]  cpuacct_account_field+0x4c/0x88
[   14.541285]  account_user_time+0x9c/0xe0
[   14.545193]  irqtime_account_process_tick+0x104/0x148
[   14.550228]  account_process_tick+0xb8/0xc8
[   14.554397]  update_process_times+0x54/0xa0
[   14.558566]  tick_sched_handle.isra.0+0x34/0x50
[   14.563081]  tick_sched_timer+0x4c/0xa8
[   14.566902]  __hrtimer_run_queues+0x128/0x210
[   14.571244]  hrtimer_interrupt+0xe8/0x248
[   14.575239]  arch_timer_handler_phys+0x34/0x48
[   14.579667]  handle_percpu_devid_irq+0x84/0x148
[   14.584183]  generic_handle_irq+0x30/0x48
[   14.588177]  __handle_domain_irq+0x64/0xc0
[   14.592258]  gic_handle_irq+0x58/0x128
[   14.595992]  el0_irq_naked+0x4c/0x54
[   14.599553] ---[ end trace 0000000000000003 ]---
[   14.604187] ---[ end trace 0000000000000004 ]---
[   14.608816] Kernel panic - not syncing:
[   14.612636] Oops: Fatal exception in interrupt
[   14.612668] SMP: stopping secondary CPUs
[   15.675000] SMP: failed to stop secondary CPUs 0-1
[   15.679776] Kernel Offset: 0x80000 from 0xffff800010000000
[   15.685242] PHYS_OFFSET: 0x80000000
[   15.688715] CPU features: 0x0040022,20806008
[   15.692969] Memory Limit: none
[   15.696011] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
我切换到 SD 卡文件系统,我将遇到相同的问题。
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 rw rootfstype=ext4 rootwait loglevel=0
[    0.008347] Console: colour dummy device 80x25
[    0.012912] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023581] pid_max: default: 32768 minimum: 301
[    0.028336] LSM: Security Framework initializing
[    0.033086] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.040661] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.049461] rcu: Hierarchical SRCU implementation.
[    0.054585] Platform MSI: msi-controller@1820000 domain created
[    0.060808] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.070113] EFI services will not be available.
[    0.074836] smp: Bringing up secondary CPUs ...
[    0.085781] Detected PIPT I-cache on CPU1
[    0.089936] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[    0.096966] GICv3: CPU1: using allocated LPI pending table @0x00000008c0050000
[    0.104373] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[    0.111094] smp: Brought up 1 node, 2 CPUs
[    0.115288] SMP: Total of 2 processors activated.
[    0.120096] CPU features: detected: 32-bit EL0 Support
[    0.125349] CPU features: detected: CRC32 instructions
[    0.138784] CPU: All CPU(s) started at EL2
[    0.142977] alternatives: patching kernel code
[    0.148024] devtmpfs: initialized
[    0.157136] KASLR disabled due to lack of seed
[    0.161777] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.171741] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
[    0.179215] pinctrl core: initialized pinctrl subsystem
[    0.184789] DMI not present or invalid.
[    0.188941] NET: Registered protocol family 16
[    0.194153] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.201422] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.209413] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.217734] thermal_sys: Registered thermal governor 'step_wise'
[    0.217993] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.231093] ASID allocator initialised with 32768 entries
[    0.248270] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.255150] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.262007] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.268864] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.276256] cryptd: max_cpu_qlen set to 1000
[    0.282185] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
[    0.290985] vsys_3v3: supplied by evm_12v0
[    0.295356] vsys_5v0: supplied by evm_12v0
[    0.299721] vdd_mmc1: supplied by vsys_3v3
[    0.304191] vdd_sd_dv_alt: supplied by vsys_3v3
[    0.309304] iommu: Default domain type: Translated
[    0.314443] SCSI subsystem initialized
[    0.318554] mc: Linux media interface: v0.10
[    0.322927] videodev: Linux video capture interface: v2.00
[    0.328558] pps_core: LinuxPPS API ver. 1 registered
[    0.333627] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.342964] PTP clock support registered
[    0.346981] EDAC MC: Ver: 3.0.0
[    0.350703] FPGA manager framework
[    0.354224] Advanced Linux Sound Architecture Driver Initialized.
[    0.360830] clocksource: Switched to clocksource arch_sys_counter
[    0.367159] VFS: Disk quotas dquot_6.6.0
[    0.371190] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.381019] NET: Registered protocol family 2
[    0.385729] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.394331] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.403246] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.411478] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
[    0.420918] TCP: Hash tables configured (established 32768 bind 32768)
[    0.427777] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
[    0.434997] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
[    0.442757] NET: Registered protocol family 1
[    0.447540] RPC: Registered named UNIX socket transport module.
[    0.453603] RPC: Registered udp transport module.
[    0.458407] RPC: Registered tcp transport module.
[    0.463210] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.469794] PCI: CLS 0 bytes, default 64
[    0.474154] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.484419] Initialise system trusted keyrings
[    0.489088] workingset: timestamp_bits=46 max_order=19 bucket_order=0
[    0.497615] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.503943] NFS: Registering the id_resolver key type
[    0.509129] Key type id_resolver registered
[    0.513400] Key type id_legacy registered
[    0.517532] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.524388] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.532082] 9p: Installing v9fs 9p2000 file system support
[    0.557906] Key type asymmetric registered
[    0.562105] Asymmetric key parser 'x509' registered
[    0.567111] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    0.574680] io scheduler mq-deadline registered
[    0.579306] io scheduler kyber registered
[    0.584361] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[    0.590548] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[    0.598446] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[    0.604745] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[    0.612565] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.620501] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
[    0.628638] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
[    0.635777] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
[    0.644338] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
[    0.657315] brd: module loaded
[    0.664247] loop: module loaded
[    0.667861] megasas: 07.714.04.00-rc1
[    0.672752] libphy: Fixed MDIO Bus: probed
[    0.677442] tun: Universal TUN/TAP device driver, 1.6
[    0.682840] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    0.689259] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    0.695340] sky2: driver version 1.30
[    0.699547] VFIO - User Level meta-driver version: 0.3
[    0.705204] i2c /dev entries driver
[    0.709230] sdhci: Secure Digital Host Controller Interface driver
[    0.715555] sdhci: Copyright(c) Pierre Ossman
[    0.720195] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.726529] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.733681] optee: probing for conduit method.
[    0.738249] optee: revision 3.12 (3d47a131)
[    0.738480] optee: initialized driver
[    0.747389] NET: Registered protocol family 17
[    0.752041] 9pnet: Installing 9P2000 support
[    0.756428] Key type dns_resolver registered
[    0.798794] printk: console [ttyS2]: printing thread started
[    0.798799] printk: console [ttyS2] enabled
[    0.798802] printk: bootconsole [ns16550a0] disabled
[    0.798812] printk: bootconsole [ns16550a0]: printing thread stopped
[    0.799214] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250
[    0.799565] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250
[    0.800242] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    0.800248] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
[    0.800251] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
[    0.800254] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
[    0.800648] scsi host0: ufshcd
[    0.840841] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    0.840851] libphy: 46000f00.mdio: probed
[    0.842054] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    0.842101] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    0.843118] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
[    0.844023] mmc0: CQHCI version 5.10
[    0.844334] mmc1: CQHCI version 5.10
[    0.849478] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    0.849764] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    0.850047] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    0.850327] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    0.850585] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    0.851162] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[    0.852972] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
[    0.857000] spi-nor spi0.0: mt35xu02g (262144 Kbytes)
[    0.885010] mmc0: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    0.885012] mmc1: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    0.896854] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    0.896863] libphy: 46000f00.mdio: probed
[    0.898066] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[    0.898117] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
[    0.899044] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[    0.899483] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[    0.899487] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[    0.899818] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
[    0.900771] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
[    0.900796] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
[    0.902227] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
[    0.902253] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
[    0.902271] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[    0.902302] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
[    0.908516] ALSA device list:
[    0.908521]   No soundcards found.
[    0.924023] mmc0: new high speed SDHC card at address aaaa
[    0.924380] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[    0.926808]  mmcblk0: p1 p2
[    0.967721] mmc1: Command Queue Engine enabled
[    0.967729] mmc1: new HS200 MMC card at address 0001
[    0.968031] mmcblk1: mmc1:0001 S0J57X 29.6 GiB
[    0.968146] mmcblk1boot0: mmc1:0001 S0J57X partition 1 31.5 MiB
[    0.968260] mmcblk1boot1: mmc1:0001 S0J57X partition 2 31.5 MiB
[    0.968351] mmcblk1rpmb: mmc1:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
[    0.969075]  mmcblk1: p1 p2
[    1.209174] cdns-ufshcd 4e84000.ufs: link startup failed 1
[    1.209182] cdns-ufshcd 4e84000.ufs: UFS Host state=0
[    1.209184] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
[    1.209187] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
[    1.209190] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
[    1.209192] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
[    1.209195] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
[    1.209197] cdns-ufshcd 4e84000.ufs: Clk gate=1
[    1.209200] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
[    1.209202] cdns-ufshcd 4e84000.ufs: last intr at 1099231 us, last intr status=0x404
[    1.209205] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
[    1.209208] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
[    1.209211] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
[    1.209213] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
[    1.209216] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
[    1.209218] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
[    1.209220] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
[    1.209240] host_regs: 00000000: 1587031f 00000000 00000210 00000000
[    1.209243] host_regs: 00000010: 00000000 00000000 00000000 00000000
[    1.209246] host_regs: 00000020: 00000000 00000470 00000000 00000000
[    1.209248] host_regs: 00000030: 00000008 00000001 00000000 00000000
[    1.209251] host_regs: 00000040: 00000000 00000000 00000000 00000000
[    1.209253] host_regs: 00000050: 00000000 00000000 00000000 00000000
[    1.209255] host_regs: 00000060: 00000000 00000000 00000000 00000000
[    1.209257] host_regs: 00000070: 00000000 00000000 00000000 00000000
[    1.209259] host_regs: 00000080: 00000000 00000000 00000000 00000000
[    1.209262] host_regs: 00000090: 00000000 00000000 00000000 00000000
[    1.209264] cdns-ufshcd 4e84000.ufs: No record of pa_err
[    1.209267] cdns-ufshcd 4e84000.ufs: No record of dl_err
[    1.209269] cdns-ufshcd 4e84000.ufs: No record of nl_err
[    1.209271] cdns-ufshcd 4e84000.ufs: No record of tl_err
[    1.209273] cdns-ufshcd 4e84000.ufs: No record of dme_err
[    1.209275] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
[    1.209277] cdns-ufshcd 4e84000.ufs: No record of fatal_err
[    1.209279] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1100348 us
[    1.209282] cdns-ufshcd 4e84000.ufs: No record of resume_fail
[    1.209284] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
[    1.209286] cdns-ufshcd 4e84000.ufs: No record of dev_reset
[    1.209288] cdns-ufshcd 4e84000.ufs: No record of host_reset
[    1.209290] cdns-ufshcd 4e84000.ufs: No record of task_abort
[    1.212182] List of all partitions:
[    1.212187] 0100            4096 ram0
[    1.212189]  (driver?)
[    1.212192] 0101            4096 ram1
[    1.212194]  (driver?)
[    1.212196] 0102            4096 ram2
[    1.212198]  (driver?)
[    1.212200] 0103            4096 ram3
[    1.212202]  (driver?)
[    1.212203] 0104            4096 ram4
[    1.212205]  (driver?)
[    1.212207] 0105            4096 ram5
[    1.212209]  (driver?)
[    1.212211] 0106            4096 ram6
[    1.212213]  (driver?)
[    1.212215] 0107            4096 ram7
[    1.212217]  (driver?)
[    1.212219] 0108            4096 ram8
[    1.212220]  (driver?)
[    1.212222] 0109            4096 ram9
[    1.212223]  (driver?)
[    1.212225] 010a            4096 ram10
[    1.212227]  (driver?)
[    1.212229] 010b            4096 ram11
[    1.212231]  (driver?)
[    1.212233] 010c            4096 ram12
[    1.212234]  (driver?)
[    1.212237] 010d            4096 ram13
[    1.212238]  (driver?)
[    1.212240] 010e            4096 ram14
[    1.212242]  (driver?)
[    1.212244] 010f            4096 ram15
[    1.212245]  (driver?)
[    1.212250] 1f00          262144 mtdblock0
[    1.212251]  (driver?)
[    1.212254] b300        15558144 mmcblk0
[    1.212256]  driver: mmcblk
[    1.212259]   b301          131072 mmcblk0p1 18f0c324-01
[    1.212261]
[    1.212263]   b302        15426048 mmcblk0p2 18f0c324-02
[    1.212265]
[    1.212267] b320        31080448 mmcblk1
[    1.212269]  driver: mmcblk
[    1.212271]   b321          131072 mmcblk1p1 01ac63cf-01
[    1.212273]
[    1.212275]   b322        30948352 mmcblk1p2 01ac63cf-02
[    1.212277]
[    1.212279] No filesystem could mount root, tried:
[    1.212280]  ext4
[    1.212281]
[    1.212282] Kernel panic - not syncing:
[    1.212283] VFS: Unable to mount root fs on unknown-block(179,34)
[    1.212286] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.10.65-rt53 #2
[    1.212290] Hardware name: Texas Instruments K3 J721E SoC (DT)
[    1.212293] Call trace:
[    1.212294]  dump_backtrace+0x0/0x1a0
[    1.212308]  show_stack+0x18/0x68
[    1.212312]  dump_stack+0xd0/0x12c
[    1.212318]  panic+0xcc/0x360
[    1.212321]  mount_block_root+0x238/0x254
[    1.212327]  mount_root+0x10c/0x140
[    1.212330]  prepare_namespace+0x130/0x170
[    1.212333]  kernel_init_freeable+0x25c/0x2a0
[    1.212336]  kernel_init+0x14/0x114
[    1.212340]  ret_from_fork+0x10/0x34
[    2.212465] SMP: stopping secondary CPUs
[    3.046109] Kernel Offset: 0x80000 from 0xffff800010000000
[    3.051576] PHYS_OFFSET: 0x80000000
[    3.055050] CPU features: 0x0040022,20806008
[    3.059305] Memory Limit: none
[    3.062348] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,34) ]---
    您是否已验证使用 SD 卡中的文件系统引导至 Linux?
    凯尔西
    你好,凯尔西:
    我尝试使用 SBL 启动,使用小型文件系统,可以启动。
    但是,我安装了 SD 卡的 EXT4分区,系统在读取数据时崩溃。
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nfs rw rootfstype=nfs root=/dev/nfs rw nfsroot=192.168.5.231:/home/pierre-i3/Desktop/workspace_net_server/net_nfsshare/PSDKv81_targetNFS_Tiny,nolock,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
    [    0.008366] Console: colour dummy device 80x25
    [    0.012929] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023599] pid_max: default: 32768 minimum: 301
    [    0.028353] LSM: Security Framework initializing
    [    0.033103] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040679] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049488] rcu: Hierarchical SRCU implementation.
    [    0.054617] Platform MSI: msi-controller@1820000 domain created
    [    0.060848] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070157] EFI services will not be available.
    [    0.074886] smp: Bringing up secondary CPUs ...
    [    0.085831] Detected PIPT I-cache on CPU1
    [    0.089984] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.097014] GICv3: CPU1: using allocated LPI pending table @0x00000008c0050000
    [    0.104420] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.111141] smp: Brought up 1 node, 2 CPUs
    [    0.115334] SMP: Total of 2 processors activated.
    [    0.120142] CPU features: detected: 32-bit EL0 Support
    [    0.125396] CPU features: detected: CRC32 instructions
    [    0.138827] CPU: All CPU(s) started at EL2
    [    0.143021] alternatives: patching kernel code
    [    0.148064] devtmpfs: initialized
    [    0.157113] KASLR disabled due to lack of seed
    [    0.161741] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.171705] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
    [    0.179140] pinctrl core: initialized pinctrl subsystem
    [    0.184713] DMI not present or invalid.
    [    0.188874] NET: Registered protocol family 16
    [    0.194086] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.201357] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.209348] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.217665] thermal_sys: Registered thermal governor 'step_wise'
    [    0.217930] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.231025] ASID allocator initialised with 32768 entries
    [    0.248510] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.255391] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.262248] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.269105] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.276497] cryptd: max_cpu_qlen set to 1000
    [    0.282417] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
    [    0.291219] vsys_3v3: supplied by evm_12v0
    [    0.295590] vsys_5v0: supplied by evm_12v0
    [    0.299954] vdd_mmc1: supplied by vsys_3v3
    [    0.304424] vdd_sd_dv_alt: supplied by vsys_3v3
    [    0.309535] iommu: Default domain type: Translated
    [    0.314679] SCSI subsystem initialized
    [    0.318789] mc: Linux media interface: v0.10
    [    0.323163] videodev: Linux video capture interface: v2.00
    [    0.328793] pps_core: LinuxPPS API ver. 1 registered
    [    0.333862] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.343199] PTP clock support registered
    [    0.347218] EDAC MC: Ver: 3.0.0
    [    0.350935] FPGA manager framework
    [    0.354452] Advanced Linux Sound Architecture Driver Initialized.
    [    0.361055] clocksource: Switched to clocksource arch_sys_counter
    [    0.367382] VFS: Disk quotas dquot_6.6.0
    [    0.371413] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.381245] NET: Registered protocol family 2
    [    0.385947] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.394560] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.403472] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.411704] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
    [    0.420530] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.427447] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
    [    0.434632] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
    [    0.442346] NET: Registered protocol family 1
    [    0.447141] RPC: Registered named UNIX socket transport module.
    [    0.453202] RPC: Registered udp transport module.
    [    0.458006] RPC: Registered tcp transport module.
    [    0.462808] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.469392] PCI: CLS 0 bytes, default 64
    [    0.473759] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.484041] Initialise system trusted keyrings
    [    0.488682] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.497224] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.503457] NFS: Registering the id_resolver key type
    [    0.508745] Key type id_resolver registered
    [    0.513029] Key type id_legacy registered
    [    0.517165] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.524027] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.531709] 9p: Installing v9fs 9p2000 file system support
    [    0.556441] Key type asymmetric registered
    [    0.560639] Asymmetric key parser 'x509' registered
    [    0.565651] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.573215] io scheduler mq-deadline registered
    [    0.577846] io scheduler kyber registered
    [    0.582902] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.589088] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.596953] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.603244] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.611061] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.619022] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.627159] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.634298] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.642867] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.655737] brd: module loaded
    [    0.662760] loop: module loaded
    [    0.666358] megasas: 07.714.04.00-rc1
    [    0.671260] libphy: Fixed MDIO Bus: probed
    [    0.675930] tun: Universal TUN/TAP device driver, 1.6
    [    0.681324] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.687739] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.693827] sky2: driver version 1.30
    [    0.698031] VFIO - User Level meta-driver version: 0.3
    [    0.703656] i2c /dev entries driver
    [    0.707693] sdhci: Secure Digital Host Controller Interface driver
    [    0.714016] sdhci: Copyright(c) Pierre Ossman
    [    0.718691] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.725014] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.732150] optee: probing for conduit method.
    [    0.736719] optee: revision 3.12 (3d47a131)
    [    0.736949] optee: initialized driver
    [    0.745858] NET: Registered protocol family 17
    [    0.750493] 9pnet: Installing 9P2000 support
    [    0.754887] Key type dns_resolver registered
    [    0.759414] printk: bootconsole [ns16550a0]: printing thread started
    [    0.759440] Loading compiled-in X.509 certificates
    [    0.763515] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.763613] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.765209] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.781387] random: fast init done
    [    0.802922] printk: console [ttyS2]: printing thread started
    [    0.802927] printk: console [ttyS2] enabled
    [    0.802929] printk: bootconsole [ns16550a0] disabled
    [    0.802940] printk: bootconsole [ns16550a0]: printing thread stopped
    [    0.809118] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250
    [    0.817112] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250
    [    0.825101] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    0.825107] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    0.825110] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    0.825112] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    0.883564] scsi host0: ufshcd
    [    0.925065] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.925074] libphy: 46000f00.mdio: probed
    [    0.926262] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    0.926311] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    0.927305] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    0.928094] mmc0: CQHCI version 5.10
    [    0.928427] mmc1: CQHCI version 5.10
    [    0.941162] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    0.945111] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    0.953115] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    0.953612] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    0.957085] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    0.971700] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    0.976552] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    0.978607] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    1.007220] mmc1: new high speed SDHC card at address aaaa
    [    1.007590] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    1.009955] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    [    1.010143]  mmcblk1: p1 p2
    [    1.059753] mmc0: Command Queue Engine enabled
    [    1.059760] mmc0: new HS200 MMC card at address 0001
    [    1.072098] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
    [    1.072214] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
    [    1.072328] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
    [    1.072679] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
    [    1.074505]  mmcblk0: p1 p2
    [    1.078907] spi-nor spi0.0: mt35xu02g (262144 Kbytes)
    [    1.117062] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.117071] libphy: 46000f00.mdio: probed
    [    1.118278] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    1.118326] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    1.119232] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    1.119677] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    1.119681] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    1.120007] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    1.121150] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    1.121176] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    1.122491] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    1.122511] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    1.122529] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    1.122558] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    1.293572] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    1.293579] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    1.293581] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    1.293584] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    1.293587] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    1.293589] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    1.293592] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    1.293594] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    1.293596] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    1.293599] cdns-ufshcd 4e84000.ufs: last intr at 1183403 us, last intr status=0x404
    [    1.293601] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    1.293604] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    1.293606] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    1.293609] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    1.293611] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    1.293614] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    1.293616] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    1.293636] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    1.293639] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    1.293642] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    1.293644] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    1.293646] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    1.293648] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    1.293651] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    1.293653] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    1.293655] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    1.293657] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    1.293659] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    1.293662] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    1.293664] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    1.293666] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    1.293668] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    1.293670] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    1.293672] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    1.293674] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1184519 us
    [    1.293677] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    1.293680] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    1.293682] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    1.293684] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    1.293686] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    1.303264] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [    1.305779] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [    5.390528] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [    5.413062] Sending DHCP requests ., OK
    [    6.437085] IP-Config: Got DHCP answer from 192.168.5.1, my address is 192.168.5.89
    [    6.437091] IP-Config: Complete:
    [    6.437092]      device=eth0, hwaddr=50:51:a9:8e:61:50, ipaddr=192.168.5.89, mask=255.255.255.0, gw=192.168.5.1
    [    6.437097]      host=192.168.5.89, domain=, nis-domain=(none)
    [    6.437098]      bootserver=0.0.0.0, rootserver=192.168.5.231, rootpath=
    [    6.437101]      nameserver0=192.168.5.20, nameserver1=192.168.1.1, nameserver2=168.95.1.1
    [    6.442389] ALSA device list:
    [    6.442392]   No soundcards found.
    [    6.451894] VFS: Mounted root (nfs filesystem) on device 0:20.
    [    6.452029] devtmpfs: mounted
    [    6.452806] Freeing unused kernel memory: 1728K
    [    6.477147] Run /sbin/init as init process
    INIT: version 2.96 booting
    hwclock: can't open '/dev/misc/rtc': No such file or directory
    Mon Dec 20 21:29:46 UTC 2021
    [    7.125168] random: dd: uninitialized urandom read (512 bytes read)
    INIT: Entering runlevel: 5
    NOT configuring network interfaces: / is an NFS mount
    Starting syslogd/klogd: done
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm /dev/ttyS2
    Arago 2021.09 j7-evm /dev/ttyS2
    j7-evm login: root
    root@j7-evm:~#
    root@j7-evm:~# mount
    192.168.5.231:/home/pierre-i3/Desktop/workspace_net_server/net_nfsshare/PSDKv81_targetNFS_Tiny on / type nfs (rw,relatime,vers=3,rsize=4096,wsize=4096,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.5.231,mountvers=3,mountproto=tcp,local_lock=all,addr=192.168.5.231)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=984608k,nr_inodes=246152,mode=755)
    proc on /proc type proc (rw,relatime)
    sysfs on /sys type sysfs (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
    tmpfs on /var/volatile type tmpfs (rw,relatime,size=51200k)
    devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
    root@j7-evm:~#
    root@j7-evm:~# fdisk -l /dev/mmcblk1
    Disk /dev/mmcblk1: 15 GB, 15931539456 bytes, 31116288 sectors
    486192 cylinders, 4 heads, 16 sectors/track
    Units: sectors of 1 * 512 = 512 bytes
    Device       Boot StartCHS    EndCHS        StartLBA     EndLBA    Sectors  Size Id Type
    /dev/mmcblk1p1 *  1,0,1       128,63,32         2048     264191     262144  128M  c Win95 FAT32 (LBA)
    /dev/mmcblk1p2    129,0,1     857,31,32       264192   31116287   30852096 14.7G 83 Linux
    root@j7-evm:~#
    root@j7-evm:~# cd /tmp/
    root@j7-evm:/var/volatile/tmp#
    root@j7-evm:/var/volatile/tmp# mkdir mmcblk1p1
    root@j7-evm:/var/volatile/tmp# mkdir mmcblk1p2
    root@j7-evm:/var/volatile/tmp# mount /dev/mmcblk1p1 mmcblk1p1/ random: crng init done
    [J
    root@j7-evm:/var/volatile/tmp# [   81.417105] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    /dev/mmcblk1p1 on /var/volatile/tmp/mmcblk1p1 type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
    root@j7-evm:/var/volatile/tmp# cd mmcblk1p1/
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# ls
    SBL_Boot_V1_OK                      atf_optee.appimage                  tiboot3.bin                         tikernelimage_linux.appimage
    SBL_Boot_V2_OK_810+app730_rootk0p2  dtb_opt                             tidtb_linux.appimage                v810_uboot
    app                                 nor_spi_patterns.bin                tifs.bin
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# ls -al
    total 19110
    drwxr-xr-x    6 root     root          2560 Jan  1  1970 .
    drwxrwxrwt    4 root     root            80 Dec 20 21:30 ..
    drwxr-xr-x    2 root     root           512 Feb 15  2022 SBL_Boot_V1_OK
    drwxr-xr-x    2 root     root          1024 Feb 17  2022 SBL_Boot_V2_OK_810+app730_rootk0p2
    -rwxr-xr-x    1 root     root        254868 Feb 17  2022 app
    -rwxr-xr-x    1 root     root        418748 Feb 17  2022 atf_optee.appimage
    drwxr-xr-x    5 root     root           512 Feb 17  2022 dtb_opt
    -rwxr-xr-x    1 root     root           128 Nov  2 11:36 nor_spi_patterns.bin
    -rwxr-xr-x    1 root     root        367855 Feb 15  2022 tiboot3.bin
    -rwxr-xr-x    1 root     root         98188 Feb 18  2022 tidtb_linux.appimage
    -rwxr-xr-x    1 root     root        263083 Feb 15  2022 tifs.bin
    -rwxr-xr-x    1 root     root      18158152 Feb 17  2022 tikernelimage_linux.appimage
    drwxr-xr-x    2 root     root          1024 Feb 17  2022 v810_uboot
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# du
    17780	./SBL_Boot_V1_OK
    20311	./v810_uboot
    19105	./SBL_Boot_V2_OK_810+app730_rootk0p2
    97	./dtb_opt/nfs_psdk810_tiny
    97	./dtb_opt/nfs_psdk730
    292	./dtb_opt
    76594	.
    total 19110
    20311	./v810_uboot
    292	./dtb_opt
    76594	.
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# cd ..
    root@j7-evm:/var/volatile/tmp# ls
    mmcblk1p1  mmcblk1p2
    root@j7-evm:/var/volatile/tmp# mount /dev/mmcblk1p2 mmcblk1p2/
    [  115.634299] mmc1: ADMA error: 0x02000002
    [  115.634308] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  115.634310] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  115.634313] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  115.634316] mmc1: sdhci: Argument:  0x00c82ea0 | Trn mode: 0x0000003b
    [  115.634319] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  115.634322] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  115.634324] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  115.634326] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  115.634329] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  115.634331] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  115.634333] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  115.634336] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  115.634338] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
    [  115.634341] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
    [  115.634343] mmc1: sdhci: Host ctl2: 0x00000c00
    [  115.634345] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  115.634347] mmc1: sdhci: ============================================
    [  115.634349] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2b98000, LEN 0x0000, Attr=0x21
    [  115.634352] mmc1: sdhci: 8c19e320c: DMA 0x00000008c2ba8000, LEN 0x0000, Attr=0x21
    [  115.634355] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  115.640118] mmc1: ADMA error: 0x02000002
    [  115.640121] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  115.640123] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  115.640126] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  115.640128] mmc1: sdhci: Argument:  0x00c82ea0 | Trn mode: 0x0000003b
    [  115.640130] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  115.640132] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  115.640135] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  115.640137] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  115.640139] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  115.640141] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  115.640143] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  115.640146] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  115.640148] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
    [  115.640150] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
    [  115.640152] mmc1: sdhci: Host ctl2: 0x00000c00
    [  115.640154] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  115.640156] mmc1: sdhci: ============================================
    [  115.640157] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2b98000, LEN 0x0000, Attr=0x21
    [  115.640159] mmc1: sdhci: 8c19e320c: DMA 0x00000008c2ba8000, LEN 0x0000, Attr=0x21
    [  115.640162] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  115.772879] JBD2: Invalid checksum recovering data block 1049109 in log
    [  115.773266] JBD2: Invalid checksum recovering data block 1049116 in log
    [  115.778567] mmc1: ADMA error: 0x02000002
    [  115.778571] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  115.778573] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  115.778575] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  115.778577] mmc1: sdhci: Argument:  0x00c82930 | Trn mode: 0x0000003b
    [  115.778580] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  115.778582] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  115.778585] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  115.778587] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  115.778589] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  115.778591] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  115.778594] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  115.778596] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  115.778599] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  115.778601] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  115.778603] mmc1: sdhci: Host ctl2: 0x00000c00
    [  115.778605] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  115.778607] mmc1: sdhci: ============================================
    [  115.778609] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bdd000, LEN 0x0000, Attr=0x21
    [  115.778612] mmc1: sdhci: 8c19e320c: DMA 0x00000008c2bed000, LEN 0xe000, Attr=0x21
    [  115.778614] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  115.784092] mmc1: ADMA error: 0x02000002
    [  115.784095] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  115.784097] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  115.784099] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  115.784101] mmc1: sdhci: Argument:  0x00c82930 | Trn mode: 0x0000003b
    [  115.784104] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  115.784106] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  115.784108] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  115.784110] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  115.784112] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  115.784115] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  115.784117] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  115.784119] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  115.784122] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  115.784124] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  115.784126] mmc1: sdhci: Host ctl2: 0x00000c00
    [  115.784128] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  115.784130] mmc1: sdhci: ============================================
    [  115.784131] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bdd000, LEN 0x0000, Attr=0x21
    [  115.784134] mmc1: sdhci: 8c19e320c: DMA 0x00000008c2bed000, LEN 0xe000, Attr=0x21
    [  115.784136] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  115.853825] JBD2: Invalid checksum recovering data block 1049103 in log
    [  115.855597] JBD2: Invalid checksum recovering data block 1049104 in log
    [  115.857374] JBD2: Invalid checksum recovering data block 1049123 in log
    [  115.859150] JBD2: Invalid checksum recovering data block 1049122 in log
    [  115.860935] JBD2: Invalid checksum recovering data block 1049124 in log
    [  115.862721] JBD2: Invalid checksum recovering data block 1049125 in log
    [  115.864503] JBD2: Invalid checksum recovering data block 1049126 in log
    [  115.866299] JBD2: Invalid checksum recovering data block 1049106 in log
    [  115.868088] JBD2: Invalid checksum recovering data block 1049148 in log
    [  115.869859] JBD2: Invalid checksum recovering data block 1049145 in log
    [  115.871630] JBD2: Invalid checksum recovering data block 1049143 in log
    [  115.873401] JBD2: Invalid checksum recovering data block 1049142 in log
    [  115.875179] JBD2: Invalid checksum recovering data block 1049147 in log
    [  115.876960] JBD2: Invalid checksum recovering data block 1049141 in log
    [  115.878737] JBD2: Invalid checksum recovering data block 1049144 in log
    [  115.880530] JBD2: Invalid checksum recovering data block 1048675 in log
    [  115.882323] JBD2: Invalid checksum recovering data block 1048677 in log
    [  115.884089] JBD2: Invalid checksum recovering data block 1048676 in log
    [  115.885855] JBD2: Invalid checksum recovering data block 1048663 in log
    [  115.887623] JBD2: Invalid checksum recovering data block 1048664 in log
    [  115.889402] JBD2: Invalid checksum recovering data block 1048622 in log
    [  115.891180] JBD2: Invalid checksum recovering data block 1048624 in log
    [  115.892960] JBD2: Invalid checksum recovering data block 1048652 in log
    [  115.894754] JBD2: Invalid checksum recovering data block 1048644 in log
    [  115.896538] JBD2: Invalid checksum recovering data block 1048645 in log
    [  115.898305] JBD2: Invalid checksum recovering data block 1048655 in log
    [  115.900067] JBD2: Invalid checksum recovering data block 1048626 in log
    [  115.901836] JBD2: Invalid checksum recovering data block 1048627 in log
    [  115.903606] JBD2: Invalid checksum recovering data block 1048654 in log
    [  115.905381] JBD2: Invalid checksum recovering data block 1048632 in log
    [  115.905850] JBD2: Invalid checksum recovering data block 1048625 in log
    [  115.906243] JBD2: Invalid checksum recovering data block 1048653 in log
    [  115.911546] mmc1: ADMA error: 0x02000002
    [  115.911550] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  115.911552] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  115.911554] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  115.911557] mmc1: sdhci: Argument:  0x00c82a30 | Trn mode: 0x0000003b
    [  115.911559] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  115.911562] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  115.911564] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  115.911567] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  115.911569] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  115.911571] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  115.911573] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  115.911576] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  115.911578] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  115.911581] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  115.911583] mmc1: sdhci: Host ctl2: 0x00000c00
    [  115.911585] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3218
    [  115.911587] mmc1: sdhci: ============================================
    [  115.911588] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bfe000, LEN 0x2000, Attr=0x21
    [  115.911591] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3000000, LEN 0x0000, Attr=0x21
    [  115.911593] mmc1: sdhci: 8c19e3218: DMA 0x00000008c3010000, LEN 0xc000, Attr=0x21
    [  115.911596] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  115.917062] mmc1: ADMA error: 0x02000002
    [  115.917065] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  115.917067] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  115.917069] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  115.917071] mmc1: sdhci: Argument:  0x00c82a30 | Trn mode: 0x0000003b
    [  115.917074] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  115.917076] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  115.917078] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  115.917080] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  115.917082] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  115.917085] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  115.917087] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  115.917089] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  115.917092] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  115.917094] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  115.917096] mmc1: sdhci: Host ctl2: 0x00000c00
    [  115.917098] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3218
    [  115.917100] mmc1: sdhci: ============================================
    [  115.917101] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bfe000, LEN 0x2000, Attr=0x21
    [  115.917104] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3000000, LEN 0x0000, Attr=0x21
    [  115.917106] mmc1: sdhci: 8c19e3218: DMA 0x00000008c3010000, LEN 0xc000, Attr=0x21
    [  115.917108] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  115.987015] JBD2: Invalid checksum recovering data block 1048662 in log
    [  115.988791] JBD2: Invalid checksum recovering data block 1048656 in log
    [  115.990561] JBD2: Invalid checksum recovering data block 1048661 in log
    [  115.992343] JBD2: Invalid checksum recovering data block 1048660 in log
    [  115.994123] JBD2: Invalid checksum recovering data block 1048657 in log
    [  115.995908] JBD2: Invalid checksum recovering data block 1048659 in log
    [  115.997700] JBD2: Invalid checksum recovering data block 1048658 in log
    [  115.999490] JBD2: Invalid checksum recovering data block 1048629 in log
    [  116.001280] JBD2: Invalid checksum recovering data block 1048651 in log
    [  116.003051] JBD2: Invalid checksum recovering data block 1048631 in log
    [  116.004816] JBD2: Invalid checksum recovering data block 1048641 in log
    [  116.006599] JBD2: Invalid checksum recovering data block 1048633 in log
    [  116.008372] JBD2: Invalid checksum recovering data block 1048634 in log
    [  116.010152] JBD2: Invalid checksum recovering data block 1048635 in log
    [  116.011936] JBD2: Invalid checksum recovering data block 1048640 in log
    [  116.013785] JBD2: Invalid checksum recovering data block 1048628 in log
    [  116.015583] JBD2: Invalid checksum recovering data block 1048647 in log
    [  116.017350] JBD2: Invalid checksum recovering data block 1048646 in log
    [  116.019111] JBD2: Invalid checksum recovering data block 1048648 in log
    [  116.020887] JBD2: Invalid checksum recovering data block 1048649 in log
    [  116.022658] JBD2: Invalid checksum recovering data block 1048650 in log
    [  116.024440] JBD2: Invalid checksum recovering data block 1048630 in log
    [  116.026222] JBD2: Invalid checksum recovering data block 1048672 in log
    [  116.028007] JBD2: Invalid checksum recovering data block 1048669 in log
    [  116.029801] JBD2: Invalid checksum recovering data block 1048665 in log
    [  116.031564] JBD2: Invalid checksum recovering data block 1048667 in log
    [  116.033332] JBD2: Invalid checksum recovering data block 1048666 in log
    [  116.035104] JBD2: Invalid checksum recovering data block 1048671 in log
    [  116.036869] JBD2: Invalid checksum recovering data block 1048668 in log
    [  116.038655] JBD2: Invalid checksum recovering data block 1048613 in log
    [  116.039118] JBD2: Invalid checksum recovering data block 1048608 in log
    [  116.039511] JBD2: Invalid checksum recovering data block 1048611 in log
    [  116.044810] mmc1: ADMA error: 0x02000002
    [  116.044813] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.044815] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.044818] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.044821] mmc1: sdhci: Argument:  0x00c82b30 | Trn mode: 0x0000003b
    [  116.044823] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.044826] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.044828] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.044830] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.044832] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.044835] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.044837] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.044839] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.044842] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.044844] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.044846] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.044848] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.044850] mmc1: sdhci: ============================================
    [  116.044852] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3020000, LEN 0x0000, Attr=0x21
    [  116.044854] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3030000, LEN 0xe000, Attr=0x21
    [  116.044857] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.050320] mmc1: ADMA error: 0x02000002
    [  116.050323] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.050325] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.050328] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.050330] mmc1: sdhci: Argument:  0x00c82b30 | Trn mode: 0x0000003b
    [  116.050332] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.050334] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.050336] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.050339] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.050341] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.050343] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.050345] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.050348] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.050350] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.050352] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.050354] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.050356] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.050358] mmc1: sdhci: ============================================
    [  116.050359] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3020000, LEN 0x0000, Attr=0x21
    [  116.050361] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3030000, LEN 0xe000, Attr=0x21
    [  116.050364] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.120032] JBD2: Invalid checksum recovering data block 1048612 in log
    [  116.121805] JBD2: Invalid checksum recovering data block 1048703 in log
    [  116.123580] JBD2: Invalid checksum recovering data block 1048679 in log
    [  116.125362] JBD2: Invalid checksum recovering data block 1048680 in log
    [  116.127138] JBD2: Invalid checksum recovering data block 1048699 in log
    [  116.128927] JBD2: Invalid checksum recovering data block 1048697 in log
    [  116.130717] JBD2: Invalid checksum recovering data block 1048687 in log
    mount: mounting /dev/mmcblk1p2 on mmcblk1p2/ failed: Invalid arg[  116.132506] JBD2: Invalid checksum recovering data block 1048685 in log
    ument[  116.134301] JBD2: Invalid checksum recovering data block 1048688 in log
    [  116.136069] JBD2: Invalid checksum recovering data block 1048690 in log
    root@j7-evm:/var/volatile/tmp# [  116.137843] JBD2: Invalid checksum recovering data block 1048696 in log
    [  116.139618] JBD2: Invalid checksum recovering data block 1048686 in log
    [  116.141398] JBD2: Invalid checksum recovering data block 1048683 in log
    [  116.143180] JBD2: Invalid checksum recovering data block 1048684 in log
    [  116.144964] JBD2: Invalid checksum recovering data block 1048689 in log
    [  116.146758] JBD2: Invalid checksum recovering data block 1048681 in log
    [  116.148546] JBD2: Invalid checksum recovering data block 1572957 in log
    [  116.150317] JBD2: Invalid checksum recovering data block 1573376 in log
    [  116.152087] JBD2: Invalid checksum recovering data block 1573377 in log
    [  116.153858] JBD2: Invalid checksum recovering data block 1573379 in log
    [  116.155633] JBD2: Invalid checksum recovering data block 1573380 in log
    [  116.157410] JBD2: Invalid checksum recovering data block 1573381 in log
    [  116.159192] JBD2: Invalid checksum recovering data block 1572958 in log
    [  116.160987] JBD2: Invalid checksum recovering data block 1572956 in log
    [  116.162774] JBD2: Invalid checksum recovering data block 1061 in log
    [  116.164540] JBD2: Invalid checksum recovering data block 1238 in log
    [  116.166306] JBD2: Invalid checksum recovering data block 1239 in log
    [  116.168074] JBD2: Invalid checksum recovering data block 1441 in log
    [  116.169854] JBD2: Invalid checksum recovering data block 1443 in log
    [  116.171624] JBD2: Invalid checksum recovering data block 1477 in log
    [  116.177915] mmc1: ADMA error: 0x02000002
    [  116.177920] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.177922] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.177925] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.177927] mmc1: sdhci: Argument:  0x00c82c30 | Trn mode: 0x0000003b
    [  116.177930] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.177932] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.177934] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.177937] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.177939] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.177941] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.177944] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.177946] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.177948] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.177951] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.177953] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.177955] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.177957] mmc1: sdhci: ============================================
    [  116.177958] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3040000, LEN 0x0000, Attr=0x21
    [  116.177960] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3050000, LEN 0xe000, Attr=0x21
    [  116.177963] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.183383] mmc1: ADMA error: 0x02000002
    [  116.183387] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.183388] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.183391] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.183393] mmc1: sdhci: Argument:  0x00c82c30 | Trn mode: 0x0000003b
    [  116.183396] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.183398] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.183400] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.183402] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.183404] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.183407] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.183409] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.183411] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.183413] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.183416] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.183418] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.183420] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.183422] mmc1: sdhci: ============================================
    [  116.183423] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3040000, LEN 0x0000, Attr=0x21
    [  116.183425] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3050000, LEN 0xe000, Attr=0x21
    [  116.183428] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.295884] JBD2: Invalid checksum recovering data block 1600 in log
    [  116.299459] JBD2: Invalid checksum recovering data block 1601 in log
    [  116.299524] JBD2: Invalid checksum recovering data block 1583 in log
    [  116.301302] JBD2: Invalid checksum recovering data block 1552 in log
    [  116.303069] JBD2: Invalid checksum recovering data block 1756 in log
    [  116.304846] JBD2: Invalid checksum recovering data block 1765 in log
    [  116.305309] JBD2: Invalid checksum recovering data block 1766 in log
    [  116.305690] JBD2: Invalid checksum recovering data block 1483 in log
    [  116.310943] mmc1: ADMA error: 0x02000002
    [  116.310947] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.310949] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.310952] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.310954] mmc1: sdhci: Argument:  0x00c82d30 | Trn mode: 0x0000003b
    [  116.310957] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.310960] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.310962] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.310965] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.310967] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.310970] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.310972] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.310974] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.310977] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.310979] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.310981] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.310983] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.310985] mmc1: sdhci: ============================================
    [  116.310987] mmc1: sdhci: 8c19e3200: DMA 0x00000008c307e000, LEN 0x0000, Attr=0x21
    [  116.310989] mmc1: sdhci: 8c19e320c: DMA 0x00000008c308e000, LEN 0xe000, Attr=0x21
    [  116.310992] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.316414] mmc1: ADMA error: 0x02000002
    [  116.316417] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.316419] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.316421] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.316423] mmc1: sdhci: Argument:  0x00c82d30 | Trn mode: 0x0000003b
    [  116.316426] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.316428] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.316430] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.316432] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.316434] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.316437] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.316439] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.316441] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.316443] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.316446] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.316448] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.316450] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.316452] mmc1: sdhci: ============================================
    [  116.316454] mmc1: sdhci: 8c19e3200: DMA 0x00000008c307e000, LEN 0x0000, Attr=0x21
    [  116.316456] mmc1: sdhci: 8c19e320c: DMA 0x00000008c308e000, LEN 0xe000, Attr=0x21
    [  116.316458] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.386288] JBD2: Invalid checksum recovering data block 1677 in log
    [  116.388088] JBD2: Invalid checksum recovering data block 1740 in log
    [  116.389892] JBD2: Invalid checksum recovering data block 1620 in log
    [  116.391675] JBD2: Invalid checksum recovering data block 1556 in log
    [  116.393450] JBD2: Invalid checksum recovering data block 1557 in log
    [  116.395237] JBD2: Invalid checksum recovering data block 1642 in log
    [  116.397015] JBD2: Invalid checksum recovering data block 1590 in log
    [  116.398799] JBD2: Invalid checksum recovering data block 1591 in log
    [  116.400590] JBD2: Invalid checksum recovering data block 1638 in log
    [  116.402390] JBD2: Invalid checksum recovering data block 1480 in log
    [  116.404187] JBD2: Invalid checksum recovering data block 1669 in log
    [  116.405965] JBD2: Invalid checksum recovering data block 1612 in log
    [  116.407735] JBD2: Invalid checksum recovering data block 1562 in log
    [  116.409521] JBD2: Invalid checksum recovering data block 1745 in log
    [  116.411292] JBD2: Invalid checksum recovering data block 1544 in log
    [  116.413099] JBD2: Invalid checksum recovering data block 1649 in log
    [  116.414870] JBD2: Invalid checksum recovering data block 1650 in log
    [  116.416665] JBD2: Invalid checksum recovering data block 1664 in log
    [  116.418461] JBD2: Invalid checksum recovering data block 1551 in log
    [  116.420223] JBD2: Invalid checksum recovering data block 1535 in log
    [  116.421997] JBD2: Invalid checksum recovering data block 1539 in log
    [  116.423769] JBD2: Invalid checksum recovering data block 1503 in log
    [  116.425558] JBD2: Invalid checksum recovering data block 1578 in log
    [  116.427347] JBD2: Invalid checksum recovering data block 1499 in log
    [  116.429128] JBD2: Invalid checksum recovering data block 1604 in log
    [  116.430924] JBD2: Invalid checksum recovering data block 1646 in log
    [  116.432716] JBD2: Invalid checksum recovering data block 1647 in log
    [  116.434476] JBD2: Invalid checksum recovering data block 1629 in log
    [  116.436246] JBD2: Invalid checksum recovering data block 1488 in log
    [  116.438010] JBD2: Invalid checksum recovering data block 1667 in log
    [  116.438468] JBD2: Invalid checksum recovering data block 1639 in log
    [  116.438859] JBD2: Invalid checksum recovering data block 1573 in log
    [  116.441441] JBD2: Invalid checksum recovering data block 1574 in log
    [  116.441447] JBD2: Invalid checksum recovering data block 1660 in log
    [  116.441451] JBD2: Invalid checksum recovering data block 1637 in log
    [  116.441455] JBD2: Invalid checksum recovering data block 1553 in log
    [  116.441459] JBD2: Invalid checksum recovering data block 1509 in log
    [  116.441463] JBD2: Invalid checksum recovering data block 1621 in log
    [  116.441467] JBD2: Invalid checksum recovering data block 1659 in log
    [  116.441470] JBD2: Invalid checksum recovering data block 1760 in log
    [  116.441474] JBD2: Invalid checksum recovering data block 1769 in log
    [  116.441478] JBD2: Invalid checksum recovering data block 1770 in log
    [  116.441482] JBD2: Invalid checksum recovering data block 1502 in log
    [  116.441486] JBD2: Invalid checksum recovering data block 1560 in log
    [  116.441490] JBD2: Invalid checksum recovering data block 1640 in log
    [  116.441494] JBD2: Invalid checksum recovering data block 1606 in log
    [  116.447826] mmc1: ADMA error: 0x02000002
    [  116.447832] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.447834] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.447837] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.447839] mmc1: sdhci: Argument:  0x00c82fb0 | Trn mode: 0x0000003b
    [  116.447842] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.447844] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.447846] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.447848] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.447851] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.447853] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.447855] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.447857] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.447860] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.447862] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.447864] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.447866] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.447868] mmc1: sdhci: ============================================
    [  116.447870] mmc1: sdhci: 8c19e3200: DMA 0x00000008c30cc000, LEN 0x0000, Attr=0x21
    [  116.447873] mmc1: sdhci: 8c19e320c: DMA 0x00000008c30dc000, LEN 0xe000, Attr=0x21
    [  116.447875] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.453298] mmc1: ADMA error: 0x02000002
    [  116.453301] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.453303] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.453305] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.453307] mmc1: sdhci: Argument:  0x00c82fb0 | Trn mode: 0x0000003b
    [  116.453310] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.453312] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.453314] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.453316] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.453319] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.453321] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.453323] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.453325] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.453328] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.453330] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.453332] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.453334] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.453336] mmc1: sdhci: ============================================
    [  116.453337] mmc1: sdhci: 8c19e3200: DMA 0x00000008c30cc000, LEN 0x0000, Attr=0x21
    [  116.453340] mmc1: sdhci: 8c19e320c: DMA 0x00000008c30dc000, LEN 0xe000, Attr=0x21
    [  116.453342] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.581715] mmc1: ADMA error: 0x02000002
    [  116.581723] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.581725] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.581727] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.581730] mmc1: sdhci: Argument:  0x00c830b0 | Trn mode: 0x0000003b
    [  116.581733] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.581735] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.581737] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.581740] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.581742] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.581744] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.581747] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.581749] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.581751] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.581754] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.581756] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.581758] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.581760] mmc1: sdhci: ============================================
    [  116.581761] mmc1: sdhci: 8c19e3200: DMA 0x00000008c310f000, LEN 0x0000, Attr=0x21
    [  116.581764] mmc1: sdhci: 8c19e320c: DMA 0x00000008c311f000, LEN 0xe000, Attr=0x21
    [  116.581766] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.587192] mmc1: ADMA error: 0x02000002
    [  116.587194] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.587196] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.587198] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.587201] mmc1: sdhci: Argument:  0x00c830b0 | Trn mode: 0x0000003b
    [  116.587203] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.587205] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.587207] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.587209] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.587212] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.587214] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.587216] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.587218] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.587221] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.587223] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.587225] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.587227] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.587229] mmc1: sdhci: ============================================
    [  116.587230] mmc1: sdhci: 8c19e3200: DMA 0x00000008c310f000, LEN 0x0000, Attr=0x21
    [  116.587232] mmc1: sdhci: 8c19e320c: DMA 0x00000008c311f000, LEN 0xe000, Attr=0x21
    [  116.587234] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.683861] JBD2: Invalid checksum recovering data block 1488 in log
    [  116.685648] JBD2: Invalid checksum recovering data block 1745 in log
    [  116.687438] JBD2: Invalid checksum recovering data block 1548 in log
    [  116.689231] JBD2: Invalid checksum recovering data block 1575 in log
    [  116.691003] JBD2: Invalid checksum recovering data block 1607 in log
    [  116.692771] JBD2: Invalid checksum recovering data block 1747 in log
    [  116.694549] JBD2: Invalid checksum recovering data block 1593 in log
    [  116.696327] JBD2: Invalid checksum recovering data block 1645 in log
    [  116.698109] JBD2: Invalid checksum recovering data block 1592 in log
    [  116.699892] JBD2: Invalid checksum recovering data block 1504 in log
    [  116.701683] JBD2: Invalid checksum recovering data block 1487 in log
    [  116.703478] JBD2: Invalid checksum recovering data block 1509 in log
    [  116.705243] JBD2: Invalid checksum recovering data block 1510 in log
    [  116.707007] JBD2: Invalid checksum recovering data block 1764 in log
    [  116.708781] JBD2: Invalid checksum recovering data block 1762 in log
    [  116.709230] JBD2: Invalid checksum recovering data block 1608 in log
    [  116.709621] JBD2: Invalid checksum recovering data block 1615 in log
    [  116.714881] mmc1: ADMA error: 0x02000002
    [  116.714885] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.714886] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.714889] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.714891] mmc1: sdhci: Argument:  0x00c831b0 | Trn mode: 0x0000003b
    [  116.714894] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.714896] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.714898] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.714900] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.714903] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.714905] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.714908] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.714910] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.714912] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.714914] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.714916] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.714919] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.714920] mmc1: sdhci: ============================================
    [  116.714922] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3140000, LEN 0x0000, Attr=0x21
    [  116.714924] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3150000, LEN 0xe000, Attr=0x21
    [  116.714927] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.720343] mmc1: ADMA error: 0x02000002
    [  116.720345] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.720347] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.720350] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.720352] mmc1: sdhci: Argument:  0x00c831b0 | Trn mode: 0x0000003b
    [  116.720354] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.720356] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.720359] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.720361] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.720363] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.720365] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.720368] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.720370] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.720372] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.720374] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.720376] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.720379] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.720380] mmc1: sdhci: ============================================
    [  116.720382] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3140000, LEN 0x0000, Attr=0x21
    [  116.720384] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3150000, LEN 0xe000, Attr=0x21
    [  116.720386] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.790231] JBD2: Invalid checksum recovering data block 1532 in log
    [  116.792030] JBD2: Invalid checksum recovering data block 1535 in log
    [  116.793837] JBD2: Invalid checksum recovering data block 1563 in log
    [  116.795614] JBD2: Invalid checksum recovering data block 1526 in log
    [  116.797389] JBD2: Invalid checksum recovering data block 1572 in log
    [  116.799167] JBD2: Invalid checksum recovering data block 1508 in log
    [  116.800949] JBD2: Invalid checksum recovering data block 1746 in log
    [  116.802744] JBD2: Invalid checksum recovering data block 1627 in log
    [  116.804565] JBD2: Invalid checksum recovering data block 1641 in log
    [  116.806361] JBD2: Invalid checksum recovering data block 1741 in log
    [  116.808161] JBD2: Invalid checksum recovering data block 1491 in log
    [  116.809935] JBD2: Invalid checksum recovering data block 1591 in log
    [  116.811708] JBD2: Invalid checksum recovering data block 1619 in log
    [  116.813488] JBD2: Invalid checksum recovering data block 1763 in log
    [  116.815264] JBD2: Invalid checksum recovering data block 1547 in log
    [  116.817080] JBD2: Invalid checksum recovering data block 1584 in log
    [  116.818860] JBD2: Invalid checksum recovering data block 1624 in log
    [  116.820655] JBD2: Invalid checksum recovering data block 1643 in log
    [  116.822462] JBD2: Invalid checksum recovering data block 1750 in log
    [  116.824229] JBD2: Invalid checksum recovering data block 1582 in log
    [  116.826000] JBD2: Invalid checksum recovering data block 1513 in log
    [  116.827771] JBD2: Invalid checksum recovering data block 1445 in log
    [  116.829550] JBD2: Invalid checksum recovering data block 1456 in log
    [  116.831334] JBD2: Invalid checksum recovering data block 1453 in log
    [  116.833117] JBD2: Invalid checksum recovering data block 1466 in log
    [  116.834910] JBD2: Invalid checksum recovering data block 1469 in log
    [  116.836699] JBD2: Invalid checksum recovering data block 1449 in log
    [  116.838464] JBD2: Invalid checksum recovering data block 1471 in log
    [  116.840236] JBD2: Invalid checksum recovering data block 1446 in log
    [  116.842004] JBD2: Invalid checksum recovering data block 1447 in log
    [  116.842461] JBD2: Invalid checksum recovering data block 1443 in log
    [  116.848112] mmc1: ADMA error: 0x02000002
    [  116.848116] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.848118] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.848120] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.848123] mmc1: sdhci: Argument:  0x00c832b0 | Trn mode: 0x0000003b
    [  116.848125] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.848127] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.848130] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.848132] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.848134] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.848137] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.848139] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.848141] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.848144] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.848146] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.848148] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.848150] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.848152] mmc1: sdhci: ============================================
    [  116.848153] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3160000, LEN 0x0000, Attr=0x21
    [  116.848156] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3170000, LEN 0xe000, Attr=0x21
    [  116.848158] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.853577] mmc1: ADMA error: 0x02000002
    [  116.853580] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.853582] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  116.853584] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.853586] mmc1: sdhci: Argument:  0x00c832b0 | Trn mode: 0x0000003b
    [  116.853588] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.853591] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.853593] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.853595] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.853597] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.853599] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.853601] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.853603] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.853606] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.853608] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.853610] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.853612] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.853614] mmc1: sdhci: ============================================
    [  116.853615] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3160000, LEN 0x0000, Attr=0x21
    [  116.853618] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3170000, LEN 0xe000, Attr=0x21
    [  116.853620] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.981895] mmc1: ADMA error: 0x02000002
    [  116.981901] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.981903] mmc1: sdhci: Sys addr:  0x000000d8 | Version:  0x00001004
    [  116.981906] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.981908] mmc1: sdhci: Argument:  0x00c833b0 | Trn mode: 0x0000003b
    [  116.981911] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.981913] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.981916] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.981918] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.981920] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.981923] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.981925] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.981927] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.981929] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.981932] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.981934] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.981936] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.981938] mmc1: sdhci: ============================================
    [  116.981939] mmc1: sdhci: 8c19e3200: DMA 0x00000008c31a4000, LEN 0x0000, Attr=0x21
    [  116.981942] mmc1: sdhci: 8c19e320c: DMA 0x00000008c31b4000, LEN 0xb000, Attr=0x21
    [  116.981945] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  116.986862] mmc1: ADMA error: 0x02000002
    [  116.986865] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  116.986867] mmc1: sdhci: Sys addr:  0x000000d8 | Version:  0x00001004
    [  116.986869] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  116.986871] mmc1: sdhci: Argument:  0x00c833b0 | Trn mode: 0x0000003b
    [  116.986873] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  116.986876] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  116.986878] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  116.986880] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  116.986882] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  116.986885] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  116.986887] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  116.986889] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  116.986891] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  116.986894] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  116.986895] mmc1: sdhci: Host ctl2: 0x00000c00
    [  116.986898] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  116.986900] mmc1: sdhci: ============================================
    [  116.986901] mmc1: sdhci: 8c19e3200: DMA 0x00000008c31a4000, LEN 0x0000, Attr=0x21
    [  116.986903] mmc1: sdhci: 8c19e320c: DMA 0x00000008c31b4000, LEN 0xb000, Attr=0x21
    [  116.986906] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  117.203906] JBD2: recovery failed
    [  117.203914] EXT4-fs (mmcblk1p2): error loading journal
    [  117.205116] EXT2-fs (mmcblk1p2): error: couldn't mount because of unsupported optional features (2c4)
    [  136.582138] JBD2: Invalid checksum recovering data block 1049109 in log
    [  136.587623] JBD2: Invalid checksum recovering data block 1049116 in log
    [  136.587630] JBD2: Invalid checksum recovering data block 1049103 in log
    [  136.587635] JBD2: Invalid checksum recovering data block 1049104 in log
    [  136.587639] JBD2: Invalid checksum recovering data block 1049123 in log
    [  136.587642] JBD2: Invalid checksum recovering data block 1049122 in log
    [  136.587646] JBD2: Invalid checksum recovering data block 1049124 in log
    [  136.587650] JBD2: Invalid checksum recovering data block 1049125 in log
    [  136.587654] JBD2: Invalid checksum recovering data block 1049126 in log
    [  136.587658] JBD2: Invalid checksum recovering data block 1049106 in log
    [  136.587662] JBD2: Invalid checksum recovering data block 1049148 in log
    [  136.587666] JBD2: Invalid checksum recovering data block 1049145 in log
    [  136.587671] JBD2: Invalid checksum recovering data block 1049143 in log
    [  136.587675] JBD2: Invalid checksum recovering data block 1049142 in log
    [  136.587679] JBD2: Invalid checksum recovering data block 1049147 in log
    [  136.587683] JBD2: Invalid checksum recovering data block 1049141 in log
    [  136.587688] JBD2: Invalid checksum recovering data block 1049144 in log
    [  136.587692] JBD2: Invalid checksum recovering data block 1048675 in log
    [  136.587696] JBD2: Invalid checksum recovering data block 1048677 in log
    [  136.587701] JBD2: Invalid checksum recovering data block 1048676 in log
    [  136.587705] JBD2: Invalid checksum recovering data block 1048663 in log
    [  136.587708] JBD2: Invalid checksum recovering data block 1048664 in log
    [  136.587712] JBD2: Invalid checksum recovering data block 1048622 in log
    [  136.587716] JBD2: Invalid checksum recovering data block 1048624 in log
    [  136.587720] JBD2: Invalid checksum recovering data block 1048652 in log
    [  136.587724] JBD2: Invalid checksum recovering data block 1048644 in log
    [  136.587728] JBD2: Invalid checksum recovering data block 1048645 in log
    [  136.587732] JBD2: Invalid checksum recovering data block 1048655 in log
    [  136.587736] JBD2: Invalid checksum recovering data block 1048626 in log
    [  136.587740] JBD2: Invalid checksum recovering data block 1048627 in log
    [  136.587744] JBD2: Invalid checksum recovering data block 1048654 in log
    [  136.587747] JBD2: Invalid checksum recovering data block 1048632 in log
    [  136.588199] JBD2: Invalid checksum recovering data block 1048625 in log
    [  136.588592] JBD2: Invalid checksum recovering data block 1048653 in log
    [  136.593928] mmc1: ADMA error: 0x02000002
    [  136.593933] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  136.593936] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  136.593939] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  136.593941] mmc1: sdhci: Argument:  0x00c82a30 | Trn mode: 0x0000003b
    [  136.593944] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  136.593947] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  136.593949] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  136.593952] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  136.593954] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  136.593956] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  136.593959] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  136.593961] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  136.593964] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  136.593966] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  136.593968] mmc1: sdhci: Host ctl2: 0x00000c00
    [  136.593970] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3224
    [  136.593972] mmc1: sdhci: ============================================
    [  136.593974] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bf7000, LEN 0x1000, Attr=0x21
    [  136.593977] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3010000, LEN 0x8000, Attr=0x21
    [  136.593979] mmc1: sdhci: 8c19e3218: DMA 0x00000008c3000000, LEN 0x0000, Attr=0x21
    [  136.593982] mmc1: sdhci: 8c19e3224: DMA 0x00000008c3190000, LEN 0x5000, Attr=0x21
    [  136.593984] mmc1: sdhci: 8c19e3230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  136.599464] mmc1: ADMA error: 0x02000002
    [  136.599467] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  136.599469] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  136.599471] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  136.599473] mmc1: sdhci: Argument:  0x00c82a30 | Trn mode: 0x0000003b
    [  136.599475] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  136.599478] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  136.599480] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  136.599482] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  136.599484] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  136.599486] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  136.599489] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  136.599491] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  136.599493] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  136.599495] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  136.599497] mmc1: sdhci: Host ctl2: 0x00000c00
    [  136.599499] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3224
    [  136.599501] mmc1: sdhci: ============================================
    [  136.599503] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bf7000, LEN 0x1000, Attr=0x21
    [  136.599505] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3010000, LEN 0x8000, Attr=0x21
    [  136.599508] mmc1: sdhci: 8c19e3218: DMA 0x00000008c3000000, LEN 0x0000, Attr=0x21
    [  136.599510] mmc1: sdhci: 8c19e3224: DMA 0x00000008c3190000, LEN 0x5000, Attr=0x21
    [  136.599512] mmc1: sdhci: 8c19e3230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  136.669064] JBD2: Invalid checksum recovering data block 1048662 in log
    [  136.670909] JBD2: Invalid checksum recovering data block 1048656 in log
    [  136.672737] JBD2: Invalid checksum recovering data block 1048661 in log
    [  136.674577] JBD2: Invalid checksum recovering data block 1048660 in log
    [  136.676420] JBD2: Invalid checksum recovering data block 1048657 in log
    [  136.678259] JBD2: Invalid checksum recovering data block 1048659 in log
    [  136.680109] JBD2: Invalid checksum recovering data block 1048658 in log
    [  136.681956] JBD2: Invalid checksum recovering data block 1048629 in log
    [  136.683802] JBD2: Invalid checksum recovering data block 1048651 in log
    [  136.685634] JBD2: Invalid checksum recovering data block 1048631 in log
    [  136.687452] JBD2: Invalid checksum recovering data block 1048641 in log
    [  136.689290] JBD2: Invalid checksum recovering data block 1048633 in log
    [  136.691116] JBD2: Invalid checksum recovering data block 1048634 in log
    [  136.692944] JBD2: Invalid checksum recovering data block 1048635 in log
    [  136.694784] JBD2: Invalid checksum recovering data block 1048640 in log
    [  136.696673] JBD2: Invalid checksum recovering data block 1048628 in log
    [  136.698515] JBD2: Invalid checksum recovering data block 1048647 in log
    [  136.700333] JBD2: Invalid checksum recovering data block 1048646 in log
    [  136.702141] JBD2: Invalid checksum recovering data block 1048648 in log
    [  136.703968] JBD2: Invalid checksum recovering data block 1048649 in log
    [  136.705785] JBD2: Invalid checksum recovering data block 1048650 in log
    [  136.707611] JBD2: Invalid checksum recovering data block 1048630 in log
    [  136.709442] JBD2: Invalid checksum recovering data block 1048672 in log
    [  136.711269] JBD2: Invalid checksum recovering data block 1048669 in log
    [  136.713107] JBD2: Invalid checksum recovering data block 1048665 in log
    [  136.714908] JBD2: Invalid checksum recovering data block 1048667 in log
    [  136.716712] JBD2: Invalid checksum recovering data block 1048666 in log
    [  136.718528] JBD2: Invalid checksum recovering data block 1048671 in log
    [  136.720335] JBD2: Invalid checksum recovering data block 1048668 in log
    [  136.722155] JBD2: Invalid checksum recovering data block 1048613 in log
    [  136.722611] JBD2: Invalid checksum recovering data block 1048608 in log
    [  136.722995] JBD2: Invalid checksum recovering data block 1048611 in log
    [  136.728321] mmc1: ADMA error: 0x02000002
    [  136.728324] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  136.728326] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  136.728328] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  136.728331] mmc1: sdhci: Argument:  0x00c82b30 | Trn mode: 0x0000003b
    [  136.728333] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  136.728335] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  136.728337] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  136.728339] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  136.728342] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  136.728344] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  136.728346] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  136.728348] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  136.728351] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  136.728353] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  136.728355] mmc1: sdhci: Host ctl2: 0x00000c00
    [  136.728357] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3218
    [  136.728359] mmc1: sdhci: ============================================
    [  136.728360] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3197000, LEN 0x9000, Attr=0x21
    [  136.728363] mmc1: sdhci: 8c19e320c: DMA 0x00000008c30b0000, LEN 0x0000, Attr=0x21
    [  136.728365] mmc1: sdhci: 8c19e3218: DMA 0x00000008c30f0000, LEN 0x5000, Attr=0x21
    [  136.728367] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  136.733832] mmc1: ADMA error: 0x02000002
    [  136.733835] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  136.733837] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  136.733839] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  136.733842] mmc1: sdhci: Argument:  0x00c82b30 | Trn mode: 0x0000003b
    [  136.733844] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  136.733846] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  136.733848] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  136.733850] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  136.733853] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  136.733855] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  136.733857] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  136.733859] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  136.733861] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  136.733863] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  136.733865] mmc1: sdhci: Host ctl2: 0x00000c00
    [  136.733867] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3218
    [  136.733869] mmc1: sdhci: ============================================
    [  136.733870] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3197000, LEN 0x9000, Attr=0x21
    [  136.733872] mmc1: sdhci: 8c19e320c: DMA 0x00000008c30b0000, LEN 0x0000, Attr=0x21
    [  136.733875] mmc1: sdhci: 8c19e3218: DMA 0x00000008c30f0000, LEN 0x5000, Attr=0x21
    [  136.733877] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  136.833416] JBD2: Invalid checksum recovering data block 1048612 in log
    [  136.835210] JBD2: Invalid checksum recovering data block 1048703 in log
    [  136.837008] JBD2: Invalid checksum recovering data block 1048679 in log
    [  136.838822] JBD2: Invalid checksum recovering data block 1048680 in log
    [  136.840615] JBD2: Invalid checksum recovering data block 1048699 in log
    [  136.842439] JBD2: Invalid checksum recovering data block 1048697 in log
    [  136.844246] JBD2: Invalid checksum recovering data block 1048687 in log
    [  136.846061] JBD2: Invalid checksum recovering data block 1048685 in log
    [  136.847879] JBD2: Invalid checksum recovering data block 1048688 in log
    [  136.849667] JBD2: Invalid checksum recovering data block 1048690 in log
    [  136.851459] JBD2: Invalid checksum recovering data block 1048696 in log
    [  136.853251] JBD2: Invalid checksum recovering data block 1048686 in log
    [  136.855041] JBD2: Invalid checksum recovering data block 1048683 in log
    [  136.856847] JBD2: Invalid checksum recovering data block 1048684 in log
    [  136.858646] JBD2: Invalid checksum recovering data block 1048689 in log
    [  136.860459] JBD2: Invalid checksum recovering data block 1048681 in log
    [  136.862261] JBD2: Invalid checksum recovering data block 1572957 in log
    [  136.864039] JBD2: Invalid checksum recovering data block 1573376 in log
    [  136.865831] JBD2: Invalid checksum recovering data block 1573377 in log
    [  136.867611] JBD2: Invalid checksum recovering data block 1573379 in log
    [  136.869402] JBD2: Invalid checksum recovering data block 1573380 in log
    [  136.871191] JBD2: Invalid checksum recovering data block 1573381 in log
    [  136.872975] JBD2: Invalid checksum recovering data block 1572958 in log
    [  136.874782] JBD2: Invalid checksum recovering data block 1572956 in log
    [  136.876573] JBD2: Invalid checksum recovering data block 1061 in log
    [  136.878348] JBD2: Invalid checksum recovering data block 1238 in log
    [  136.880117] JBD2: Invalid checksum recovering data block 1239 in log
    [  136.881889] JBD2: Invalid checksum recovering data block 1441 in log
    [  136.883673] JBD2: Invalid checksum recovering data block 1443 in log
    [  136.885509] JBD2: Invalid checksum recovering data block 1477 in log
    [  136.891832] mmc1: ADMA error: 0x02000002
    [  136.891837] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  136.891839] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  136.891841] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  136.891844] mmc1: sdhci: Argument:  0x00c82c30 | Trn mode: 0x0000003b
    [  136.891846] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  136.891849] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  136.891851] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  136.891853] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  136.891855] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  136.891858] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  136.891860] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  136.891862] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  136.891864] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  136.891867] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  136.891869] mmc1: sdhci: Host ctl2: 0x00000c00
    [  136.891871] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3218
    [  136.891873] mmc1: sdhci: ============================================
    [  136.891874] mmc1: sdhci: 8c19e3200: DMA 0x00000008c30fb000, LEN 0x5000, Attr=0x21
    [  136.891877] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3060000, LEN 0x0000, Attr=0x21
    [  136.891879] mmc1: sdhci: 8c19e3218: DMA 0x00000008c31d0000, LEN 0x9000, Attr=0x21
    [  136.891881] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  136.897298] mmc1: ADMA error: 0x02000002
    [  136.897300] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  136.897302] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  136.897304] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  136.897306] mmc1: sdhci: Argument:  0x00c82c30 | Trn mode: 0x0000003b
    [  136.897309] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  136.897311] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  136.897313] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  136.897315] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  136.897317] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  136.897319] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  136.897321] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  136.897323] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  136.897325] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  136.897327] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  136.897329] mmc1: sdhci: Host ctl2: 0x00000c00
    [  136.897332] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e3218
    [  136.897334] mmc1: sdhci: ============================================
    [  136.897335] mmc1: sdhci: 8c19e3200: DMA 0x00000008c30fb000, LEN 0x5000, Attr=0x21
    [  136.897338] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3060000, LEN 0x0000, Attr=0x21
    mount: mounting /dev/mmcblk1p2 on mmcblk1p2/ failed: Invalid arg[  136.897340] mmc1: sdhci: 8c19e3218: DMA 0x00000008c31d0000, LEN 0x9000, Attr=0x21
    ument
    [  136.897342] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    root@j7-evm:/var/volatile/tmp# [  137.042201] JBD2: Invalid checksum recovering data block 1600 in log
    [  137.043982] JBD2: Invalid checksum recovering data block 1601 in log
    [  137.045763] JBD2: Invalid checksum recovering data block 1583 in log
    [  137.047529] JBD2: Invalid checksum recovering data block 1552 in log
    [  137.049287] JBD2: Invalid checksum recovering data block 1756 in log
    [  137.051061] JBD2: Invalid checksum recovering data block 1765 in log
    [  137.051517] JBD2: Invalid checksum recovering data block 1766 in log
    [  137.051892] JBD2: Invalid checksum recovering data block 1483 in log
    [  137.057170] mmc1: ADMA error: 0x02000002
    [  137.057174] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.057176] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.057179] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.057181] mmc1: sdhci: Argument:  0x00c82d30 | Trn mode: 0x0000003b
    [  137.057183] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.057186] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.057188] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.057190] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.057193] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.057195] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.057197] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.057199] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.057202] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.057204] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.057206] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.057208] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.057210] mmc1: sdhci: ============================================
    [  137.057212] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bc7000, LEN 0x0000, Attr=0x21
    [  137.057214] mmc1: sdhci: 8c19e320c: DMA 0x00000008c2bd7000, LEN 0x9000, Attr=0x21
    [  137.057216] mmc1: sdhci: 8c19e3218: DMA 0x00000008c31e0000, LEN 0x5000, Attr=0x21
    [  137.057219] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.062635] mmc1: ADMA error: 0x02000002
    [  137.062638] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.062640] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.062642] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.062644] mmc1: sdhci: Argument:  0x00c82d30 | Trn mode: 0x0000003b
    [  137.062647] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.062649] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.062651] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.062653] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.062655] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.062658] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.062660] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.062662] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.062664] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.062667] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.062668] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.062671] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.062672] mmc1: sdhci: ============================================
    [  137.062673] mmc1: sdhci: 8c19e3200: DMA 0x00000008c2bc7000, LEN 0x0000, Attr=0x21
    [  137.062676] mmc1: sdhci: 8c19e320c: DMA 0x00000008c2bd7000, LEN 0x9000, Attr=0x21
    [  137.062678] mmc1: sdhci: 8c19e3218: DMA 0x00000008c31e0000, LEN 0x5000, Attr=0x21
    [  137.062681] mmc1: sdhci: 8c19e3224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.171107] JBD2: Invalid checksum recovering data block 1677 in log
    [  137.172889] JBD2: Invalid checksum recovering data block 1740 in log
    [  137.174677] JBD2: Invalid checksum recovering data block 1620 in log
    [  137.176444] JBD2: Invalid checksum recovering data block 1556 in log
    [  137.178200] JBD2: Invalid checksum recovering data block 1557 in log
    [  137.179975] JBD2: Invalid checksum recovering data block 1642 in log
    [  137.181743] JBD2: Invalid checksum recovering data block 1590 in log
    [  137.183515] JBD2: Invalid checksum recovering data block 1591 in log
    [  137.185301] JBD2: Invalid checksum recovering data block 1638 in log
    [  137.187083] JBD2: Invalid checksum recovering data block 1480 in log
    [  137.188876] JBD2: Invalid checksum recovering data block 1669 in log
    [  137.190635] JBD2: Invalid checksum recovering data block 1612 in log
    [  137.192395] JBD2: Invalid checksum recovering data block 1562 in log
    [  137.194170] JBD2: Invalid checksum recovering data block 1745 in log
    [  137.195934] JBD2: Invalid checksum recovering data block 1544 in log
    [  137.197714] JBD2: Invalid checksum recovering data block 1649 in log
    [  137.199491] JBD2: Invalid checksum recovering data block 1650 in log
    [  137.201274] JBD2: Invalid checksum recovering data block 1664 in log
    [  137.203064] JBD2: Invalid checksum recovering data block 1551 in log
    [  137.204820] JBD2: Invalid checksum recovering data block 1535 in log
    [  137.206583] JBD2: Invalid checksum recovering data block 1539 in log
    [  137.208354] JBD2: Invalid checksum recovering data block 1503 in log
    [  137.210118] JBD2: Invalid checksum recovering data block 1578 in log
    [  137.211902] JBD2: Invalid checksum recovering data block 1499 in log
    [  137.213675] JBD2: Invalid checksum recovering data block 1604 in log
    [  137.215460] JBD2: Invalid checksum recovering data block 1646 in log
    [  137.217253] JBD2: Invalid checksum recovering data block 1647 in log
    [  137.219010] JBD2: Invalid checksum recovering data block 1629 in log
    [  137.220774] JBD2: Invalid checksum recovering data block 1488 in log
    [  137.222542] JBD2: Invalid checksum recovering data block 1667 in log
    [  137.223000] JBD2: Invalid checksum recovering data block 1639 in log
    [  137.223383] JBD2: Invalid checksum recovering data block 1573 in log
    [  137.225978] JBD2: Invalid checksum recovering data block 1574 in log
    [  137.225983] JBD2: Invalid checksum recovering data block 1660 in log
    [  137.225987] JBD2: Invalid checksum recovering data block 1637 in log
    [  137.225991] JBD2: Invalid checksum recovering data block 1553 in log
    [  137.225994] JBD2: Invalid checksum recovering data block 1509 in log
    [  137.225998] JBD2: Invalid checksum recovering data block 1621 in log
    [  137.226002] JBD2: Invalid checksum recovering data block 1659 in log
    [  137.226006] JBD2: Invalid checksum recovering data block 1760 in log
    [  137.226010] JBD2: Invalid checksum recovering data block 1769 in log
    [  137.226014] JBD2: Invalid checksum recovering data block 1770 in log
    [  137.226018] JBD2: Invalid checksum recovering data block 1502 in log
    [  137.226022] JBD2: Invalid checksum recovering data block 1560 in log
    [  137.226026] JBD2: Invalid checksum recovering data block 1640 in log
    [  137.226029] JBD2: Invalid checksum recovering data block 1606 in log
    [  137.232366] mmc1: ADMA error: 0x02000002
    [  137.232370] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.232372] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.232375] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.232377] mmc1: sdhci: Argument:  0x00c82fb0 | Trn mode: 0x0000003b
    [  137.232379] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.232382] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.232384] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.232386] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.232389] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.232391] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.232393] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.232395] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.232397] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.232400] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.232402] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.232404] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.232406] mmc1: sdhci: ============================================
    [  137.232407] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3215000, LEN 0x0000, Attr=0x21
    [  137.232410] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3225000, LEN 0xe000, Attr=0x21
    [  137.232412] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.237829] mmc1: ADMA error: 0x02000002
    [  137.237831] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.237833] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.237835] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.237838] mmc1: sdhci: Argument:  0x00c82fb0 | Trn mode: 0x0000003b
    [  137.237840] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.237842] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.237844] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.237846] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.237848] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.237850] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.237853] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.237855] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.237857] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.237859] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.237861] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.237863] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.237865] mmc1: sdhci: ============================================
    [  137.237866] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3215000, LEN 0x0000, Attr=0x21
    [  137.237869] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3225000, LEN 0xe000, Attr=0x21
    [  137.237871] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.407933] mmc1: ADMA error: 0x02000002
    [  137.407938] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.407940] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.407943] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.407945] mmc1: sdhci: Argument:  0x00c830b0 | Trn mode: 0x0000003b
    [  137.407947] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.407949] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.407951] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.407954] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.407956] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.407958] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.407960] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.407963] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.407965] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.407967] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.407969] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.407971] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.407973] mmc1: sdhci: ============================================
    [  137.407974] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3254000, LEN 0x0000, Attr=0x21
    [  137.407977] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3264000, LEN 0xe000, Attr=0x21
    [  137.407979] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.413397] mmc1: ADMA error: 0x02000002
    [  137.413399] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.413401] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.413403] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.413406] mmc1: sdhci: Argument:  0x00c830b0 | Trn mode: 0x0000003b
    [  137.413408] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.413410] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.413412] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.413414] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.413417] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.413419] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.413421] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.413423] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.413425] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.413427] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.413429] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.413431] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.413433] mmc1: sdhci: ============================================
    [  137.413434] mmc1: sdhci: 8c19e3200: DMA 0x00000008c3254000, LEN 0x0000, Attr=0x21
    [  137.413436] mmc1: sdhci: 8c19e320c: DMA 0x00000008c3264000, LEN 0xe000, Attr=0x21
    [  137.413438] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.539178] JBD2: Invalid checksum recovering data block 1488 in log
    [  137.540960] JBD2: Invalid checksum recovering data block 1745 in log
    [  137.542745] JBD2: Invalid checksum recovering data block 1548 in log
    [  137.544528] JBD2: Invalid checksum recovering data block 1575 in log
    [  137.546295] JBD2: Invalid checksum recovering data block 1607 in log
    [  137.548052] JBD2: Invalid checksum recovering data block 1747 in log
    [  137.549826] JBD2: Invalid checksum recovering data block 1593 in log
    [  137.551592] JBD2: Invalid checksum recovering data block 1645 in log
    [  137.553365] JBD2: Invalid checksum recovering data block 1592 in log
    [  137.555148] JBD2: Invalid checksum recovering data block 1504 in log
    [  137.556929] JBD2: Invalid checksum recovering data block 1487 in log
    [  137.558722] JBD2: Invalid checksum recovering data block 1509 in log
    [  137.560481] JBD2: Invalid checksum recovering data block 1510 in log
    [  137.562239] JBD2: Invalid checksum recovering data block 1764 in log
    [  137.564014] JBD2: Invalid checksum recovering data block 1762 in log
    [  137.564476] JBD2: Invalid checksum recovering data block 1608 in log
    [  137.564858] JBD2: Invalid checksum recovering data block 1615 in log
    [  137.570133] mmc1: ADMA error: 0x02000002
    [  137.570137] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.570139] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.570142] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.570144] mmc1: sdhci: Argument:  0x00c831b0 | Trn mode: 0x0000003b
    [  137.570147] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.570149] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.570151] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.570153] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.570155] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.570158] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.570160] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.570162] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.570164] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.570167] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.570169] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.570171] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.570173] mmc1: sdhci: ============================================
    [  137.570174] mmc1: sdhci: 8c19e3200: DMA 0x00000008c328a000, LEN 0x0000, Attr=0x21
    [  137.570177] mmc1: sdhci: 8c19e320c: DMA 0x00000008c329a000, LEN 0xe000, Attr=0x21
    [  137.570180] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.575595] mmc1: ADMA error: 0x02000002
    [  137.575597] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.575599] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.575601] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.575603] mmc1: sdhci: Argument:  0x00c831b0 | Trn mode: 0x0000003b
    [  137.575605] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.575608] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.575610] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.575612] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.575614] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.575616] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.575619] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.575621] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.575623] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.575625] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.575627] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.575630] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.575631] mmc1: sdhci: ============================================
    [  137.575632] mmc1: sdhci: 8c19e3200: DMA 0x00000008c328a000, LEN 0x0000, Attr=0x21
    [  137.575635] mmc1: sdhci: 8c19e320c: DMA 0x00000008c329a000, LEN 0xe000, Attr=0x21
    [  137.575637] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.686509] JBD2: Invalid checksum recovering data block 1532 in log
    [  137.688293] JBD2: Invalid checksum recovering data block 1535 in log
    [  137.690087] JBD2: Invalid checksum recovering data block 1563 in log
    [  137.691846] JBD2: Invalid checksum recovering data block 1526 in log
    [  137.693605] JBD2: Invalid checksum recovering data block 1572 in log
    [  137.695379] JBD2: Invalid checksum recovering data block 1508 in log
    [  137.697144] JBD2: Invalid checksum recovering data block 1746 in log
    [  137.698928] JBD2: Invalid checksum recovering data block 1627 in log
    [  137.700737] JBD2: Invalid checksum recovering data block 1641 in log
    [  137.702523] JBD2: Invalid checksum recovering data block 1741 in log
    [  137.704313] JBD2: Invalid checksum recovering data block 1491 in log
    [  137.706070] JBD2: Invalid checksum recovering data block 1591 in log
    [  137.707840] JBD2: Invalid checksum recovering data block 1619 in log
    [  137.709612] JBD2: Invalid checksum recovering data block 1763 in log
    [  137.711377] JBD2: Invalid checksum recovering data block 1547 in log
    [  137.713187] JBD2: Invalid checksum recovering data block 1584 in log
    [  137.714962] JBD2: Invalid checksum recovering data block 1624 in log
    [  137.716752] JBD2: Invalid checksum recovering data block 1643 in log
    [  137.718542] JBD2: Invalid checksum recovering data block 1750 in log
    [  137.720297] JBD2: Invalid checksum recovering data block 1582 in log
    [  137.722069] JBD2: Invalid checksum recovering data block 1513 in log
    [  137.723832] JBD2: Invalid checksum recovering data block 1445 in log
    [  137.725602] JBD2: Invalid checksum recovering data block 1456 in log
    [  137.727386] JBD2: Invalid checksum recovering data block 1453 in log
    [  137.729162] JBD2: Invalid checksum recovering data block 1466 in log
    [  137.730953] JBD2: Invalid checksum recovering data block 1469 in log
    [  137.732733] JBD2: Invalid checksum recovering data block 1449 in log
    [  137.734494] JBD2: Invalid checksum recovering data block 1471 in log
    [  137.736260] JBD2: Invalid checksum recovering data block 1446 in log
    [  137.738028] JBD2: Invalid checksum recovering data block 1447 in log
    [  137.738478] JBD2: Invalid checksum recovering data block 1443 in log
    [  137.744139] mmc1: ADMA error: 0x02000002
    [  137.744143] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.744145] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.744147] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.744149] mmc1: sdhci: Argument:  0x00c832b0 | Trn mode: 0x0000003b
    [  137.744152] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.744154] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.744156] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.744158] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.744161] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.744163] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.744165] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.744168] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.744170] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.744172] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.744174] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.744176] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.744178] mmc1: sdhci: ============================================
    [  137.744179] mmc1: sdhci: 8c19e3200: DMA 0x00000008c32aa000, LEN 0x0000, Attr=0x21
    [  137.744181] mmc1: sdhci: 8c19e320c: DMA 0x00000008c32ba000, LEN 0xe000, Attr=0x21
    [  137.744184] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.749600] mmc1: ADMA error: 0x02000002
    [  137.749603] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.749605] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  137.749607] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.749609] mmc1: sdhci: Argument:  0x00c832b0 | Trn mode: 0x0000003b
    [  137.749612] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.749614] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.749616] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.749618] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.749620] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.749623] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.749625] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.749627] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.749629] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.749631] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.749633] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.749636] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.749637] mmc1: sdhci: ============================================
    [  137.749639] mmc1: sdhci: 8c19e3200: DMA 0x00000008c32aa000, LEN 0x0000, Attr=0x21
    [  137.749641] mmc1: sdhci: 8c19e320c: DMA 0x00000008c32ba000, LEN 0xe000, Attr=0x21
    [  137.749643] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.915770] mmc1: ADMA error: 0x02000002
    [  137.915775] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.915777] mmc1: sdhci: Sys addr:  0x000000d8 | Version:  0x00001004
    [  137.915779] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.915781] mmc1: sdhci: Argument:  0x00c833b0 | Trn mode: 0x0000003b
    [  137.915784] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.915786] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.915788] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.915791] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.915793] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.915795] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.915797] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.915799] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.915801] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.915804] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.915806] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.915808] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.915810] mmc1: sdhci: ============================================
    [  137.915811] mmc1: sdhci: 8c19e3200: DMA 0x00000008c32e9000, LEN 0x0000, Attr=0x21
    [  137.915814] mmc1: sdhci: 8c19e320c: DMA 0x00000008c32f9000, LEN 0xb000, Attr=0x21
    [  137.915816] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  137.920723] mmc1: ADMA error: 0x02000002
    [  137.920725] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  137.920727] mmc1: sdhci: Sys addr:  0x000000d8 | Version:  0x00001004
    [  137.920729] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  137.920731] mmc1: sdhci: Argument:  0x00c833b0 | Trn mode: 0x0000003b
    [  137.920734] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  137.920736] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  137.920738] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  137.920740] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  137.920742] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  137.920744] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  137.920747] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  137.920749] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  137.920751] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  137.920753] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  137.920755] mmc1: sdhci: Host ctl2: 0x00000c00
    [  137.920757] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e320c
    [  137.920759] mmc1: sdhci: ============================================
    [  137.920760] mmc1: sdhci: 8c19e3200: DMA 0x00000008c32e9000, LEN 0x0000, Attr=0x21
    [  137.920763] mmc1: sdhci: 8c19e320c: DMA 0x00000008c32f9000, LEN 0xb000, Attr=0x21
    [  137.920765] mmc1: sdhci: 8c19e3218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  138.225515] JBD2: recovery failed
    [  138.225523] EXT4-fs (mmcblk1p2): error loading journal
    [  138.226706] EXT2-fs (mmcblk1p2): error: couldn't mount because of unsupported optional features (2c4)
     NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 19:52:11, Dec 20 2021
    ERROR:   GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.65-rt53 (pierrehsieh@jetson-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT_RT Tue Feb 15 15:20:00 CST 2022
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
    [    0.000000] OF: reserved mem: OVERLAP DETECTED!
    [    0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-eth-queues@ac000000 (0x00000000ac000000--0x00000000ac200000)
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] Carveout Heap: regions without no-map are not yet supported
    [    0.000000] OF: reserved mem: node vision_apps_shared-memories compatible matching fail
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
    [    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
    [    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000fbffffff]
    [    0.000000]   node   0: [mem 0x00000000fc000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
    [    0.000000]   node   0: [mem 0x00000008c0000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] On node 0 totalpages: 1048576
    [    0.000000]   DMA zone: 8192 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524288 pages, LIFO batch:63
    [    0.000000]   Normal zone: 8192 pages used for memmap
    [    0.000000]   Normal zone: 524288 pages, LIFO batch:63
    [    0.000000] cma: Reserved 24 MiB at 0x00000000fe800000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 18 pages/cpu s34752 r8192 d30784 u73728
    [    0.000000] pcpu-alloc: s34752 r8192 d30784 u73728 alloc=18*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
    [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nfs rw rootfstype=nfs root=/dev/nfs rw nfsroot=192.168.5.231:/home/pierre-i3/Desktop/workspace_net_server/net_nfsshare/PSDKv81_targetNFS_Tiny,nolock,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB)
    [    0.000000] Memory: 1969216K/4194304K available (10624K kernel code, 1156K rwdata, 4108K rodata, 1728K init, 438K bss, 2200512K reserved, 24576K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] rcu: 	RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000] 	No expedited grace period (rcu_normal_after_boot).
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c0030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0040000
    [    0.000000] random: get_random_bytes called from start_kernel+0x320/0x4c8 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008348] Console: colour dummy device 80x25
    [    0.012914] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023583] pid_max: default: 32768 minimum: 301
    [    0.028337] LSM: Security Framework initializing
    [    0.033089] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040664] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049469] rcu: Hierarchical SRCU implementation.
    [    0.054593] Platform MSI: msi-controller@1820000 domain created
    [    0.060817] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070122] EFI services will not be available.
    [    0.074846] smp: Bringing up secondary CPUs ...
    [    0.085792] Detected PIPT I-cache on CPU1
    [    0.089943] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.096975] GICv3: CPU1: using allocated LPI pending table @0x00000008c0050000
    [    0.104382] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.111103] smp: Brought up 1 node, 2 CPUs
    [    0.115296] SMP: Total of 2 processors activated.
    [    0.120105] CPU features: detected: 32-bit EL0 Support
    [    0.125358] CPU features: detected: CRC32 instructions
    [    0.138765] CPU: All CPU(s) started at EL2
    [    0.142959] alternatives: patching kernel code
    [    0.147994] devtmpfs: initialized
    [    0.157098] KASLR disabled due to lack of seed
    [    0.161729] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.171693] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
    [    0.179151] pinctrl core: initialized pinctrl subsystem
    [    0.184722] DMI not present or invalid.
    [    0.188888] NET: Registered protocol family 16
    [    0.194105] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.201374] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.209364] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.217682] thermal_sys: Registered thermal governor 'step_wise'
    [    0.217943] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.231040] ASID allocator initialised with 32768 entries
    [    0.248453] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.255334] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.262191] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.269048] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.276445] cryptd: max_cpu_qlen set to 1000
    [    0.282366] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
    [    0.291171] vsys_3v3: supplied by evm_12v0
    [    0.295519] vsys_5v0: supplied by evm_12v0
    [    0.299898] vdd_mmc1: supplied by vsys_3v3
    [    0.304379] vdd_sd_dv_alt: supplied by vsys_3v3
    [    0.309504] iommu: Default domain type: Translated
    [    0.314646] SCSI subsystem initialized
    [    0.318757] mc: Linux media interface: v0.10
    [    0.323132] videodev: Linux video capture interface: v2.00
    [    0.328762] pps_core: LinuxPPS API ver. 1 registered
    [    0.333832] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.343168] PTP clock support registered
    [    0.347186] EDAC MC: Ver: 3.0.0
    [    0.350906] FPGA manager framework
    [    0.354427] Advanced Linux Sound Architecture Driver Initialized.
    [    0.361039] clocksource: Switched to clocksource arch_sys_counter
    [    0.367363] VFS: Disk quotas dquot_6.6.0
    [    0.371395] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.381228] NET: Registered protocol family 2
    [    0.385932] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.394546] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.403469] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.411700] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
    [    0.421124] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.427982] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
    [    0.435175] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
    [    0.442907] NET: Registered protocol family 1
    [    0.447680] RPC: Registered named UNIX socket transport module.
    [    0.453746] RPC: Registered udp transport module.
    [    0.458549] RPC: Registered tcp transport module.
    [    0.463352] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.469935] PCI: CLS 0 bytes, default 64
    [    0.474307] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.484579] Initialise system trusted keyrings
    [    0.489246] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.497781] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.504111] NFS: Registering the id_resolver key type
    [    0.509299] Key type id_resolver registered
    [    0.513571] Key type id_legacy registered
    [    0.517703] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.524559] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.532252] 9p: Installing v9fs 9p2000 file system support
    [    0.557179] Key type asymmetric registered
    [    0.561377] Asymmetric key parser 'x509' registered
    [    0.566383] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.573951] io scheduler mq-deadline registered
    [    0.578577] io scheduler kyber registered
    [    0.583630] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.589816] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.597720] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.603985] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.611819] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.619765] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.627911] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.635044] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.643591] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.656504] brd: module loaded
    [    0.663457] loop: module loaded
    [    0.667068] megasas: 07.714.04.00-rc1
    [    0.671958] libphy: Fixed MDIO Bus: probed
    [    0.676620] tun: Universal TUN/TAP device driver, 1.6
    [    0.682031] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.688448] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.694537] sky2: driver version 1.30
    [    0.698753] VFIO - User Level meta-driver version: 0.3
    [    0.704398] i2c /dev entries driver
    [    0.708431] sdhci: Secure Digital Host Controller Interface driver
    [    0.714755] sdhci: Copyright(c) Pierre Ossman
    [    0.719404] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.725745] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.732890] optee: probing for conduit method.
    [    0.737452] optee: revision 3.12 (3d47a131)
    [    0.737689] optee: initialized driver
    [    0.746601] NET: Registered protocol family 17
    [    0.751239] 9pnet: Installing 9P2000 support
    [    0.755634] Key type dns_resolver registered
    [    0.760156] printk: bootconsole [ns16550a0]: printing thread started
    [    0.760183] Loading compiled-in X.509 certificates
    [    0.764237] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.764333] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.765957] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.781975] random: fast init done
    [    0.797336] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
    [    0.797757] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
    [    0.798101] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
    [    0.812864] printk: console [ttyS2]: printing thread started
    [    0.798458] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
    [    0.812870] printk: console [ttyS2] enabled
    [    0.812872] printk: bootconsole [ns16550a0] disabled
    [    0.829816] printk: bootconsole [ns16550a0]: printing thread stopped
    [    0.837093] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250
    [    0.841094] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250
    [    0.849097] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    0.849103] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    0.849107] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    0.849109] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    0.884092] scsi host0: ufshcd
    [    0.925039] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.925048] libphy: 46000f00.mdio: probed
    [    0.926239] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    0.926286] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    0.927291] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    0.928100] mmc0: CQHCI version 5.10
    [    0.928667] mmc1: CQHCI version 5.10
    [    0.933776] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    0.934066] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    0.934346] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    0.934624] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    0.934880] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    0.935469] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    0.937300] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    [    0.941363] spi-nor spi0.0: mt35xu02g (262144 Kbytes)
    [    0.969301] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    0.969421] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    0.981040] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.981048] libphy: 46000f00.mdio: probed
    [    0.982236] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    0.982283] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    0.983217] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    0.983665] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    0.983669] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    0.989077] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    0.990929] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    0.990959] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    0.992238] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    0.992268] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    0.992285] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    0.992303] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    1.005053] mmc1: new high speed SDHC card at address aaaa
    [    1.005445] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    1.008099]  mmcblk1: p1 p2
    [    1.054250] mmc0: Command Queue Engine enabled
    [    1.054258] mmc0: new HS200 MMC card at address 0001
    [    1.054551] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
    [    1.054666] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
    [    1.054774] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
    [    1.054878] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
    [    1.055596]  mmcblk0: p1 p2
    [    1.292601] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    1.292610] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    1.292612] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    1.292615] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    1.292617] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    1.292620] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    1.292622] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    1.292625] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    1.292626] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    1.292629] cdns-ufshcd 4e84000.ufs: last intr at 1182460 us, last intr status=0x404
    [    1.292632] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    1.292634] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    1.292637] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    1.292639] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    1.292642] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    1.292644] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    1.292646] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    1.292667] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    1.292670] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    1.292672] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    1.292675] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    1.292677] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    1.292679] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    1.292681] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    1.292683] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    1.292685] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    1.292687] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    1.292690] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    1.292692] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    1.292695] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    1.292697] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    1.292699] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    1.292701] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    1.292703] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    1.292704] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1183575 us
    [    1.292708] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    1.292711] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    1.292713] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    1.292714] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    1.292716] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    1.307812] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [    1.318350] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [    5.422505] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [    5.453036] Sending DHCP requests ., OK
    [    6.573052] IP-Config: Got DHCP answer from 192.168.5.1, my address is 192.168.5.89
    [    6.573059] IP-Config: Complete:
    [    6.573060]      device=eth0, hwaddr=50:51:a9:8e:61:50, ipaddr=192.168.5.89, mask=255.255.255.0, gw=192.168.5.1
    [    6.573064]      host=192.168.5.89, domain=, nis-domain=(none)
    [    6.573066]      bootserver=0.0.0.0, rootserver=192.168.5.231, rootpath=
    [    6.573069]      nameserver0=192.168.5.20, nameserver1=192.168.1.1, nameserver2=168.95.1.1
    [    6.578480] ALSA device list:
    [    6.578484]   No soundcards found.
    [    6.588312] VFS: Mounted root (nfs filesystem) on device 0:20.
    [    6.588453] devtmpfs: mounted
    [    6.589286] Freeing unused kernel memory: 1728K
    [    6.601118] Run /sbin/init as init process
    INIT: version 2.96 booting
    hwclock: can't open '/dev/misc/rtc': No such file or directory
    Mon Dec 20 21:29:46 UTC 2021
    [    7.249886] random: dd: uninitialized urandom read (512 bytes read)
    INIT: Entering runlevel: 5
    NOT configuring network interfaces: / is an NFS mount
    Starting syslogd/klogd: done
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm /dev/ttyS2
    Arago 2021.09 j7-evm /dev/ttyS2
    j7-evm login: root
    root@j7-evm:~# lsblk
    -sh: lsblk: not found
    root@j7-evm:~# ls /dev/
    autofs        log           mmcblk0rpmb   ptyp1         ram1          snd           tty2          tty34         tty49         tty63         ttyp2         vcs
    console       loop-control  mmcblk1       ptyp2         ram10         tee0          tty20         tty35         tty5          tty7          ttyp3         vcs1
    dma_heap      loop0         mmcblk1p1     ptyp3         ram11         teepriv0      tty21         tty36         tty50         tty8          ttyp4         vcsa
    full          loop1         mmcblk1p2     ptyp4         ram12         tty           tty22         tty37         tty51         tty9          ttyp5         vcsa1
    gpiochip0     loop2         mtab          ptyp5         ram13         tty0          tty23         tty38         tty52         ttyS0         ttyp6         vcsu
    gpiochip1     loop3         mtd0          ptyp6         ram14         tty1          tty24         tty39         tty53         ttyS1         ttyp7         vcsu1
    gpiochip2     loop4         mtd0ro        ptyp7         ram15         tty10         tty25         tty4          tty54         ttyS2         ttyp8         vfio
    i2c-0         loop5         mtdblock0     ptyp8         ram2          tty11         tty26         tty40         tty55         ttyS3         ttyp9         zero
    i2c-1         loop6         net           ptyp9         ram3          tty12         tty27         tty41         tty56         ttyS4         ttypa
    i2c-2         loop7         null          ptypa         ram4          tty13         tty28         tty42         tty57         ttyS5         ttypb
    i2c-3         mem           port          ptypb         ram5          tty14         tty29         tty43         tty58         ttyS6         ttypc
    i2c-4         mmcblk0       ptmx          ptypc         ram6          tty15         tty3          tty44         tty59         ttyS7         ttypd
    i2c-5         mmcblk0boot0  ptp0          ptypd         ram7          tty16         tty30         tty45         tty6          ttyS8         ttype
    i2c-6         mmcblk0boot1  ptp1          ptype         ram8          tty17         tty31         tty46         tty60         ttyS9         ttypf
    initctl       mmcblk0p1     pts           ptypf         ram9          tty18         tty32         tty47         tty61         ttyp0         ubi_ctrl
    kmsg          mmcblk0p2     ptyp0         ram0          random        tty19         tty33         tty48         tty62         ttyp1         urandom
    root@j7-evm:~#
    root@j7-evm:~# cd /tmp/
    root@j7-evm:/var/volatile/tmp# mkdir mmcblk1p1
    root@j7-evm:/var/volatile/tmp# mkdir mmcblk1p2
    root@j7-evm:/var/volatile/tmp# fdisk -l /dev/mmcblk1
    Disk /dev/mmcblk1: 15 GB, 15931539456 bytes, 31116288 sectors
    486192 cylinders, 4 heads, 16 sectors/track
    Units: sectors of 1 * 512 = 512 bytes
    Device       Boot StartCHS    EndCHS        StartLBA     EndLBA    Sectors  Size Id Type
    /dev/mmcblk1p1 *  1,0,1       128,63,32         2048     264191     262144  128M  c Win95 FAT32 (LBA)
    /dev/mmcblk1p2    129,0,1     857,31,32       264192   31116287   30852096 14.7G 83 Linux
    root@j7-evm:/var/volatile/tmp# mount /dev/mmc[   79.688877] random: crng init done
    root@j7-evm:/var/volatile/tmp# mount /dev/mmcblk
    mmcblk0       mmcblk0boot0  mmcblk0boot1  mmcblk0p1     mmcblk0p2     mmcblk0rpmb   mmcblk1       mmcblk1p1     mmcblk1p2
    root@j7-evm:/var/volatile/tmp# mount /dev/mmcblk1p1 mmcblk1p1/
    root@j7-evm:/var/volatile/tmp# [  101.361525] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    root@j7-evm:/var/volatile/tmp# mount /dev/mmcblk1p2 mmcblk1p2/
    root@j7-evm:/var/volatile/tmp# [  111.882412] EXT4-fs (mmcblk1p2): recovery complete
    [  111.882424] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
    192.168.5.231:/home/pierre-i3/Desktop/workspace_net_server/net_nfsshare/PSDKv81_targetNFS_Tiny on / type nfs (rw,relatime,vers=3,rsize=4096,wsize=4096,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.5.231,mountvers=3,mountproto=tcp,local_lock=all,addr=192.168.5.231)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=984608k,nr_inodes=246152,mode=755)
    proc on /proc type proc (rw,relatime)
    sysfs on /sys type sysfs (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
    tmpfs on /var/volatile type tmpfs (rw,relatime,size=51200k)
    devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
    /dev/mmcblk1p1 on /var/volatile/tmp/mmcblk1p1 type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
    /dev/mmcblk1p2 on /var/volatile/tmp/mmcblk1p2 type ext4 (rw,relatime)
    root@j7-evm:/var/volatile/tmp# cd mmcblk1p1/
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# ls
    SBL_Boot_V1_OK                      atf_optee.appimage                  tiboot3.bin                         tikernelimage_linux.appimage
    SBL_Boot_V2_OK_810+app730_rootk0p2  dtb_opt                             tidtb_linux.appimage                v810_uboot
    app                                 nor_spi_patterns.bin                tifs.bin
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# ls -al
    total 19110
    drwxr-xr-x    6 root     root          2560 Jan  1  1970 .
    drwxrwxrwt    4 root     root            80 Dec 20 21:30 ..
    drwxr-xr-x    2 root     root           512 Feb 15  2022 SBL_Boot_V1_OK
    drwxr-xr-x    2 root     root          1024 Feb 17  2022 SBL_Boot_V2_OK_810+app730_rootk0p2
    -rwxr-xr-x    1 root     root        254868 Feb 17  2022 app
    -rwxr-xr-x    1 root     root        418748 Feb 17  2022 atf_optee.appimage
    drwxr-xr-x    5 root     root           512 Feb 17  2022 dtb_opt
    -rwxr-xr-x    1 root     root           128 Nov  2 11:36 nor_spi_patterns.bin
    -rwxr-xr-x    1 root     root        367855 Feb 15  2022 tiboot3.bin
    -rwxr-xr-x    1 root     root         98188 Feb 18  2022 tidtb_linux.appimage
    -rwxr-xr-x    1 root     root        263083 Feb 15  2022 tifs.bin
    -rwxr-xr-x    1 root     root      18158152 Feb 17  2022 tikernelimage_linux.appimage
    drwxr-xr-x    2 root     root          1024 Feb 17  2022 v810_uboot
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# cd ../
    root@j7-evm:/var/volatile/tmp# ls
    mmcblk1p1  mmcblk1p2
    root@j7-evm:/var/volatile/tmp# cd mmcblk1p2/
    root@j7-evm:/var/volatile/tmp/mmcblk1p2#
    root@j7-evm:/var/volatile/tmp/mmcblk1p2# ls -al
    [  155.117644] mmc1: ADMA error: 0x02000002
    [  155.117655] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  155.117658] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  155.117661] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  155.117664] mmc1: sdhci: Argument:  0x00c40900 | Trn mode: 0x0000003b
    [  155.117666] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  155.117669] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    total 72
    [  155.117672] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    drwxr-xr-x   19 root     root          4096 Dec 20 21:22 .
    [  155.117674] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    drw[  155.117676] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    xr-xr-x    2 root     root          4096 Dec 20 21:23 bin
    drwxr[  155.117679] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    wxrwx    3 root     root          4096 Feb 17  2022 boot
    drwxr-[  155.117681] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    xr-x    2 root     root          4096 Dec 20 19:53 dev
    drwxr-xr[  155.117683] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    -x   55 root     root          4096 Feb 18  2022 etc
    drwxr-xr-x[  155.117685] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
        3 root     root          4096 Dec 20 19:53 home
    drwxr-xr-x [  155.117688] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
       2 root     root          4096 Dec 20 19:53 include
    lrwxrwxrw[  155.117690] mmc1: sdhci: Host ctl2: 0x00000c00
    x    1 root     root            20 Dec 20 20:05 init -> /lib/sys[  155.117692] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171223c
    temd/systemd
    drwxr-xr-x    9 root     root          4096 Dec 20[  155.117694] mmc1: sdhci: ============================================
     21:21 lib
    lrwxrwxrwx    1 root     root            19 Dec 20 2[  155.117696] mmc1: sdhci: 8c1712200: DMA 0x00000008c2b29000, LEN 0x1000, Attr=0x21
    1:22 linuxrc -> /bin/busybox.nosuid
    drwxr-xr-x    3 root     ro[  155.117699] mmc1: sdhci: 8c171220c: DMA 0x00000008c25be000, LEN 0x2000, Attr=0x21
    ot          4096 Dec 20 19:44 media
    drwxr-xr-x    2 root     ro[  155.117702] mmc1: sdhci: 8c1712218: DMA 0x00000008c2d0c000, LEN 0x4000, Attr=0x21
    ot          4096 Dec 20 19:53 mnt
    drwxrwxrwx    5 root     root[  155.117704] mmc1: sdhci: 8c1712224: DMA 0x00000008c2748000, LEN 0x8000, Attr=0x21
              4096 Dec 20 19:46 opt
    dr-xr-xr-x    2 root     root  [  155.117706] mmc1: sdhci: 8c1712230: DMA 0x00000008c2d20000, LEN 0x0000, Attr=0x21
            4096 Dec 20 19:53 proc
    drwxr-xr-x    2 root     root   [  155.117709] mmc1: sdhci: 8c171223c: DMA 0x00000008c2d30000, LEN 0x1000, Attr=0x21
           4096 Dec 20 21:23 run
    drwxr-xr-x    2 root     root     [  155.117711] mmc1: sdhci: 8c1712248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
         4096 Dec 20 21:23 sbin
    dr-xr-xr-x    2 root     root      [  155.123459] mmc1: ADMA error: 0x02000002
        4096 Dec 20 19:53 sys
    drwxrwxrwt    2 root     root        [  155.123463] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
      4096 Dec 20 19:53 tmp
    drwxr-xr-x   11 root     root          [  155.123465] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    4096 Dec 20 21:19 usr
    drwxr-xr-x    8 root     root          40[  155.123467] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    96 Dec 20 19:44 var
    root@j7-evm:/var/volatile/tmp/mmcblk1p2# [  155.123469] mmc1: sdhci: Argument:  0x00c40900 | Trn mode: 0x0000003b
    [  155.123471] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  155.123474] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  155.123476] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  155.123478] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  155.123480] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  155.123482] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  155.123485] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  155.123487] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  155.123489] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
    [  155.123492] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
    [  155.123493] mmc1: sdhci: Host ctl2: 0x00000c00
    [  155.123496] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171223c
    [  155.123497] mmc1: sdhci: ============================================
    [  155.123498] mmc1: sdhci: 8c1712200: DMA 0x00000008c2b29000, LEN 0x1000, Attr=0x21
    [  155.123501] mmc1: sdhci: 8c171220c: DMA 0x00000008c25be000, LEN 0x2000, Attr=0x21
    [  155.123503] mmc1: sdhci: 8c1712218: DMA 0x00000008c2d0c000, LEN 0x4000, Attr=0x21
    [  155.123505] mmc1: sdhci: 8c1712224: DMA 0x00000008c2748000, LEN 0x8000, Attr=0x21
    [  155.123507] mmc1: sdhci: 8c1712230: DMA 0x00000008c2d20000, LEN 0x0000, Attr=0x21
    [  155.123509] mmc1: sdhci: 8c171223c: DMA 0x00000008c2d30000, LEN 0x1000, Attr=0x21
    [  155.123511] mmc1: sdhci: 8c1712248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    bin      boot     dev      etc      home     include  init     lib      linuxrc  media    mnt      opt      proc     run      sbin     sys      tmp      usr      var
    total 72
    drwxr-xr-x    2 root     root          4096 Dec 20 21:23 bin
    drwxrwxrwx    3 root     root          4096 Feb 17  2022 boot
    drwxr-xr-x    2 root     root          4096 Dec 20 19:53 dev
    drwxr-xr-x   55 root     root          4096 Feb 18  2022 etc
    drwxr-xr-x    3 root     root          4096 Dec 20 19:53 home
    drwxr-xr-x    2 root     root          4096 Dec 20 19:53 include
    lrwxrwxrwx    1 root     root            20 Dec 20 20:05 init -> /lib/systemd/systemd
    drwxr-xr-x    9 root     root          4096 Dec 20 21:21 lib
    lrwxrwxrwx    1 root     root            19 Dec 20 21:22 linuxrc -> /bin/busybox.nosuid
    drwxr-xr-x    3 root     root          4096 Dec 20 19:44 media
    drwxr-xr-x    2 root     root          4096 Dec 20 19:53 mnt
    drwxrwxrwx    5 root     root          4096 Dec 20 19:46 opt
    dr-xr-xr-x    2 root     root          4096 Dec 20 19:53 proc
    drwxr-xr-x    2 root     root          4096 Dec 20 21:23 run
    drwxr-xr-x    2 root     root          4096 Dec 20 21:23 sbin
    dr-xr-xr-x    2 root     root          4096 Dec 20 19:53 sys
    drwxrwxrwt    2 root     root          4096 Dec 20 19:53 tmp
    drwxr-xr-x   11 root     root          4096 Dec 20 21:19 usr
    drwxr-xr-x    8 root     root          4096 Dec 20 19:44 var
    total 72
    total 72
    root@j7-evm:/var/volatile/tmp/mmcblk1p2# du
    4	./proc
    4	./include
    440	./lib/modules/5.10.65-rt53/kernel/sound/usb
    40	./lib/modules/5.10.65-rt53/kernel/sound/soc/ti
    72	./lib/modules/5.10.65-rt53/kernel/sound/soc/generic
    712	./lib/modules/5.1[  178.072227] mmc1: ADMA error: 0x02000002
    0.65-rt53/kernel/sound/soc/codecs
    828	./lib/modules/5.10.65-rt5[  178.072238] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    3/kernel/sound/soc
    84	./lib/modules/5.10.65-rt53/kernel/sound/c[  178.072241] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    ore
    1356	./lib/modules/5.10.65-rt53/kernel/sound
    112	./lib/mod[  178.072243] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    ules/5.10.65-rt53/kernel/lib/raid6
    44	./lib/modules/5.10.65-rt5[  178.072246] mmc1: sdhci: Argument:  0x00841900 | Trn mode: 0x0000003b
    3/kernel/lib/crypto
    12	./lib/modules/5.10.65-rt53/kernel/lib/ma[  178.072249] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    th
    208	./lib/modules/5.10.65-rt53/kernel/lib
    16	./lib/modules/[  178.072251] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    5.10.65-rt53/kernel/samples/rpmsg
    20	./lib/modules/5.10.65-rt53[  178.072254] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    /kernel/samples
    12	./lib/modules/5.10.65-rt53/kernel/arch/arm64[  178.072256] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    /lib
    168	./lib/modules/5.10.65-rt53/kernel/arch/arm64/crypto
    1[  178.072258] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    84	./lib/modules/5.10.65-rt53/kernel/arch/arm64
    188	./lib/modul[  178.072261] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    20	./lib/modules/5.10.65-rt53/kerne[  178.072263] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    l/drivers/phy/freescale
    24	./lib/modules/5.10.65-rt53/kernel/dr[  178.072265] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    ivers/phy/cadence
    24	./lib/modules/5.10.65-rt53/kernel/drivers/[  178.072268] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    phy/ti
    84	./lib/modules/5.10.65-rt53/kernel/drivers/phy
    24	./l[  178.072270] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    ib/modules/5.10.65-rt53/kernel/drivers/misc/uacce
    72	./lib/modu[  178.072272] mmc1: sdhci: Host ctl2: 0x00000c00
    les/5.10.65-rt53/kernel/drivers/misc/eeprom
    128	./lib/modules/5[  178.072274] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    148	./lib/modules/5.10.65-rt53/[  178.072277] mmc1: sdhci: ============================================
    kernel/drivers/soundwire
    16	./lib/modules/5.10.65-rt53/kernel/d[  178.072278] mmc1: sdhci: 8c1712200: DMA 0x00000008c2d39000, LEN 0x0000, Attr=0x21
    rivers/clk
    [  178.072281] mmc1: sdhci: 8c171220c: DMA 0x00000008c2d49000, LEN 0x7000, Attr=0x21
    140	./lib/modules/5.10.65-rt53/kernel/drivers/scsi/libsas
    180	[  178.072284] mmc1: sdhci: 8c1712218: DMA 0x00000008c1fc0000, LEN 0x8000, Attr=0x21
    ./lib/modules/5.10.65-rt53/kernel/drivers/scsi/hisi_sas
    480	./l[  178.072287] mmc1: sdhci: 8c1712224: DMA 0x00000008c2b7c000, LEN 0x1000, Attr=0x21
    ib/modules/5.10.65-rt53/kernel/drivers/scsi/mpt3sas
    880	./lib/m[  178.072289] mmc1: sdhci: 8c1712230: DMA 0x00000008c2d58000, LEN 0x1000, Attr=0x21
    616	./lib/modules/5.10.[  178.072291] mmc1: sdhci: 8c171223c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    65-rt53/kernel/drivers/md
    64	./lib/modules/5.10.65-rt53/kernel/[  178.078207] mmc1: ADMA error: 0x02000002
    drivers/slimbus
    324	./lib/modules/5.10.65-rt53/kernel/drivers/b[  178.078210] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    luetooth
    124	./lib/modules/5.10.65-rt53/kernel/drivers/remotepr[  178.078212] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    oc
    24	./lib/modules/5.10.65-rt53/kernel/drivers/video/backlight[  178.078214] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    28	./lib/modules/5.10.65-rt53/kernel/drivers/video
    88	./lib/m[  178.078216] mmc1: sdhci: Argument:  0x00841900 | Trn mode: 0x0000003b
    odules/5.10.65-rt53/kernel/drivers/ssb
    24	./lib/modules/5.10.65[  178.078219] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    -rt53/kernel/drivers/usb/phy
    76	./lib/modules/5.10.65-rt53/kern[  178.078221] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    el/drivers/usb/misc
    24	./lib/modules/5.10.65-rt53/kernel/driver[  178.078224] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    s/usb/roles
    48	./lib/modules/5.10.65-rt53/kernel/drivers/usb/ga[  178.078226] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    dget/udc
    320	./lib/modules/5.10.65-rt53/kernel/drivers/usb/gadg[  178.078228] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    et/legacy
    712	./lib/modules/5.10.65-rt53/kernel/drivers/usb/gad[  178.078230] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    get/function
    1172	./lib/modules/5.10.65-rt53/kernel/drivers/usb[  178.078232] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    /gadget
    64	./lib/modules/5.10.65-rt53/kernel/drivers/usb/isp176[  178.078234] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    0
    496	./lib/modules/5.10.65-rt53/kernel/drivers/usb/host
    40	./[  178.078237] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    lib/modules/5.10.65-rt53/kernel/drivers/usb/common
    152	./lib/mo[  178.078239] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    dules/5.10.65-rt53/kernel/drivers/usb/musb
    152	./lib/modules/5.[  178.078241] mmc1: sdhci: Host ctl2: 0x00000c00
    10.65-rt53/kernel/drivers/usb/storage
    188	./lib/modules/5.10.65[  178.078243] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    -rt53/kernel/drivers/usb/dwc3
    120	./lib/modules/5.10.65-rt53/ke[  178.078245] mmc1: sdhci: ============================================
    rnel/drivers/usb/typec/tcpm
    212	./lib/modules/5.10.65-rt53/kern[  178.078246] mmc1: sdhci: 8c1712200: DMA 0x00000008c2d39000, LEN 0x0000, Attr=0x21
    64	./lib/modules/5.10.65-rt53/kernel/drive[  178.078248] mmc1: sdhci: 8c171220c: DMA 0x00000008c2d49000, LEN 0x7000, Attr=0x21
    rs/usb/class
    428	./lib/modules/5.10.65-rt53/kernel/drivers/usb/[  178.078250] mmc1: sdhci: 8c1712218: DMA 0x00000008c1fc0000, LEN 0x8000, Attr=0x21
    core
    480	./lib/modules/5.10.65-rt53/kernel/drivers/usb/serial
    [  178.078253] mmc1: sdhci: 8c1712224: DMA 0x00000008c2b7c000, LEN 0x1000, Attr=0x21
    88	./lib/modules/5.10.65-rt53/kernel/drivers/usb/cdns3
    3664	./l[  178.078255] mmc1: sdhci: 8c1712230: DMA 0x00000008c2d58000, LEN 0x1000, Attr=0x21
    180	./lib/modules/5.[  178.078257] mmc1: sdhci: 8c171223c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    10.65-rt53/kernel/drivers/mtd/tests
    184	./lib/modules/5.10.65-rt53/kernel/drivers/mtd
    68	./lib/modules/5.10.65-rt53/kernel/drivers/w1
    32	./lib/modules/5.10.65-rt53/kernel/drivers/soc/ti
    36	./lib/modules/5.10.65-rt53/kernel/drivers/soc
    108	./lib/modules/5.10.65-rt53/kernel/drivers/hwmon
    40	./lib/modules/5.10.65-rt53/kernel/drivers/nfc/s3fwrn5
    44	./lib/modules/5.10.65-rt53/kernel/drivers/nfc
    16	./lib/modules/5.10.65-rt53/kernel/drivers/input/misc
    36	./lib/modules/5.10.65-rt53/kernel/drivers/input/keyboard
    152	./lib/modules/5.10.65-rt53/kernel/drivers/input/touchscreen
    208	./lib/modules/5.10.65-rt53/kernel/drivers/input
    32	./lib/modules/5.10.65-rt53/kernel/drivers/media/spi
    856	./lib/modules/5.10.65-rt53/kernel/drivers/media/tuners
    200	./lib/modules/5.10.65-rt53/kernel/drivers/media/common/videobuf2
    204	./lib/modules/5.10.65-rt53/kernel/drivers/media/common
    48	./lib/modules/5.10.65-rt53/kernel/drivers/media/usb/gspca
    160	./lib/modules/5.10.65-rt53/kernel/drivers/media/usb/uvc
    212	./lib/modules/5.10.65-rt53/kernel/drivers/media/usb
    104	./lib/modules/5.10.65-rt53/kernel/drivers/media/dvb-frontends/cxd2880
    88	./lib/modules/5.10.65-rt53/kernel/drivers/media/dvb-frontends/drx39xyj
    2940	./lib/modules/5.10.65-rt53/kernel/drivers/media/dvb-frontends
    844	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/vxe-vxd
    28	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/cadence
    36	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/ti/j721e-csi2rx
    92	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/ti/cal
    132	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/ti
    1008	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform
    88	./lib/modules/5.10.65-rt53/kernel/drivers/media/v4l2-core
    136	./lib/modules/5.10.65-rt53/kernel/drivers/media/i2c
    5480	./lib/modules/5.10.65-rt53/kernel/drivers/media
    20	./lib/modules/5.10.65-rt53/kernel/drivers/regulator
    24	./lib/modules/5.10.65-rt53/kernel/drivers/ntb/hw/epf
    28	./lib/modules/5.10.65-rt53/kernel/drivers/ntb/hw
    100	./lib/modules/5.10.65-rt53/kernel/drivers/ntb
    76	./lib/modules/5.10.65-rt53/kernel/drivers/rpmsg
    144	./lib/modules/5.10.65-rt53/kernel/drivers/rtc
    176	./lib/modules/5.10.65-rt53/kernel/drivers/crypto/ccree
    232	./lib/modules/5.10.65-rt53/kernel/drivers/crypto
    200	./lib/modules/5.10.65-rt53/kernel/drivers/nvme/host
    204	./lib/modules/5.10.65-rt53/kernel/drivers/nvme
    12	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/rcar-du
    84	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/panel
    112	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/arm
    56	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/bridge/cadence
    96	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/bridge/synopsys
    288	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/bridge
    500	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm
    504	./lib/modules/5.10.65-rt53/kernel/drivers/gpu
    80	./lib/modules/5.10.65-rt53/kernel/drivers/block
    16	./lib/modules/5.10.65-rt53/kernel/drivers/pwm
    68	./lib/modules/5.10.65-rt53/kernel/drivers/gpio
    24	./lib/modules/5.10.65-rt53/kernel/drivers/irqchip
    20	./lib/modules/5.10.65-rt53/kernel/drivers/watchdog
    76	./lib/modules/5.10.65-rt53/kernel/drivers/fpga
    80	./lib/modules/5.10.65-rt53/kernel/drivers/net/phy
    48	./lib/modules/5.10.65-rt53/kernel/drivers/net/can/dev
    48	./lib/modules/5.10.65-rt53/kernel/drivers/net/can/m_can
    52	./lib/modules/5.10.65-rt53/kernel/drivers/net/can/c_can
    188	./lib/modules/5.10.65-rt53/kernel/drivers/net/can
    748	./lib/modules/5.10.65-rt53/kernel/drivers/net/usb
    332	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/intel/e1000e
    208	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/intel/e1000
    544	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/intel
    1196	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/broadcom/bnx2x
    1464	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/broadcom
    300	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/ti
    72	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/marvell
    2384	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet
    476	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel/iwlwifi/mvm
    216	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel/iwlwifi/dvm
    1152	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel/iwlwifi
    1156	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel
    660	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ath/ath10k
    716	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ath
    556	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/b43
    24	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil
    408	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac
    436	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/brcm80211
    996	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom
    184	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ti/wl18xx
    404	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ti/wlcore
    592	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ti
    504	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/marvell/mwifiex
    508	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/marvell
    3972	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless
    7548	./lib/modules/5.10.65-rt53/kernel/drivers/net
    36	./lib/modules/5.10.65-rt53/kernel/drivers/iio/common/cros_ec_sensors
    40	./lib/modules/5.10.65-rt53/kernel/drivers/iio/common
    32	./lib/modules/5.10.65-rt53/kernel/drivers/iio/pressure
    24	./lib/modules/5.10.65-rt53/kernel/drivers/iio/buffer
    40	./lib/modules/5.10.65-rt53/kernel/drivers/iio/light
    92	./lib/modules/5.10.65-rt53/kernel/drivers/iio/adc
    232	./lib/modules/5.10.65-rt53/kernel/drivers/iio
    32	./lib/modules/5.10.65-rt53/kernel/drivers/base/regmap
    36	./lib/modules/5.10.65-rt53/kernel/drivers/base
    44	./lib/modules/5.10.65-rt53/kernel/drivers/hid/i2c-hid
    60	./lib/modules/5.10.65-rt53/kernel/drivers/hid/usbhid
    148	./lib/modules/5.10.65-rt53/kernel/drivers/hid
    44	./lib/modules/5.10.65-rt53/kernel/drivers/platform/chrome
    48	./lib/modules/5.10.65-rt53/kernel/drivers/platform
    664	./lib/modules/5.10.65-rt53/kernel/drivers/ata
    44	./lib/modules/5.10.65-rt53/kernel/drivers/power/supply
    48	./lib/modules/5.10.65-rt53/kernel/drivers/power
    24	./lib/modules/5.10.65-rt53/kernel/drivers/rpmsg-kdrv
    76	./lib/modules/5.10.65-rt53/kernel/drivers/char/hw_random
    244	./lib/modules/5.10.65-rt53/kernel/drivers/char/ipmi
    324	./lib/modules/5.10.65-rt53/kernel/drivers/char
    16	./lib/modules/5.10.65-rt53/kernel/drivers/tty/serial/8250
    20	./lib/modules/5.10.65-rt53/kernel/drivers/tty/serial
    24	./lib/modules/5.10.65-rt53/kernel/drivers/tty
    80	./lib/modules/5.10.65-rt53/kernel/drivers/bcma
    40	./lib/modules/5.10.65-rt53/kernel/drivers/mfd
    23124	./lib/modules/5.10.65-rt53/kernel/drivers
    488	./lib/modules/5.10.65-rt53/kernel/crypto
    1064	./lib/modules/5.10.65-rt53/kernel/net/sched
    24	./lib/modules/5.10.65-rt53/kernel/net/llc
    56	./lib/modules/5.10.65-rt53/kernel/net/8021q
    580	./lib/modules/5.10.65-rt53/kernel/net/netfilter
    56	./lib/modules/5.10.65-rt53/kernel/net/bluetooth/hidp
    728	./lib/modules/5.10.65-rt53/kernel/net/bluetooth
    92	./lib/modules/5.10.65-rt53/kernel/net/hsr
    144	./lib/modules/5.10.65-rt53/kernel/net/can
    44	./lib/modules/5.10.65-rt53/kernel/net/rfkill
    836	./lib/modules/5.10.65-rt53/kernel/net/mac80211
    72	./lib/modules/5.10.65-rt53/kernel/net/nfc/nci
    220	./lib/modules/5.10.65-rt53/kernel/net/nfc
    180	./lib/modules/5.10.65-rt53/kernel/net/ipv4/netfilter
    308	./lib/modules/5.10.65-rt53/kernel/net/ipv4
    80	./lib/modules/5.10.65-rt53/kernel/net/802
    64	./lib/modules/5.10.65-rt53/kernel/net/key
    108	./lib/modules/5.10.65-rt53/kernel/net/dsa
    228	./lib/modules/5.10.65-rt53/kernel/net/bridge/netfilter
    572	./lib/modules/5.10.65-rt53/kernel/net/bridge
    80	./lib/modules/5.10.65-rt53/kernel/net/qrtr
    92	./lib/modules/5.10.65-rt53/kernel/net/xfrm
    140	./lib/modules/5.10.65-rt53/kernel/net/ipv6/netfilter
    1100	./lib/modules/5.10.65-rt53/kernel/net/ipv6
    524	./lib/modules/5.10.65-rt53/kernel/net/sctp
    512	./lib/modules/5.10.65-rt53/kernel/net/wireless
    7232	./lib/modules/5.10.65-rt53/kernel/net
    240	./lib/modules/5.10.65-rt53/kernel/fs/fuse
    192	./lib/modules/5.10.65-rt53/kernel/fs/overlayfs
    952	./lib/modules/5.10.65-rt53/kernel/fs/cifs
    56	./lib/modules/5.10.65-rt53/kernel/fs/nfs/blocklayout
    60	./lib/modules/5.10.65-rt53/kernel/fs/nfs
    1764	./lib/modules/5.10.65-rt53/kernel/fs/btrfs
    3212	./lib/modules/5.10.65-rt53/kernel/fs
    35832	./lib/modules/5.10.65-rt53/kernel
    2424	./lib/modules/5.10.65-rt53/extra
    39500	./lib/modules/5.10.65-rt53
    440	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/usb
    40	./lib/modu[  179.549666] mmc1: ADMA error: 0x02000002
    les/5.10.65-rt53-g541ec9a699/kernel/sound/soc/ti
    68	./lib/modul[  179.549677] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    es/5.10.65-rt53-g541ec9a699/kernel/sound/soc/generic
    708	./lib/[  179.549679] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    modules/5.10.65-rt53-g541ec9a699/kernel/sound/soc/codecs
    820	./[  179.549682] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/soc
    84	./lib/[  179.549685] mmc1: sdhci: Argument:  0x00840a08 | Trn mode: 0x0000003b
    modules/5.10.65-rt53-g541ec9a699/kernel/sound/core
    1348	./lib/m[  179.549688] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  179.549690] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  179.549692] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  179.549695] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  179.549697] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  179.549699] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  179.549701] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  179.549704] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  179.549706] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  179.549709] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  179.549711] mmc1: sdhci: Host ctl2: 0x00000c00
    [  179.549713] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    [  179.549715] mmc1: sdhci: ============================================
    [  179.549716] mmc1: sdhci: 8c1712200: DMA 0x00000008c2d70000, LEN 0x0000, Attr=0x21
    [  179.549720] mmc1: sdhci: 8c171220c: DMA 0x00000008c2d80000, LEN 0x6000, Attr=0x21
    [  179.549722] mmc1: sdhci: 8c1712218: DMA 0x00000008c307b000, LEN 0x1000, Attr=0x21
    [  179.549724] mmc1: sdhci: 8c1712224: DMA 0x00000008c2d86000, LEN 0x8000, Attr=0x21
    [  179.549726] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  179.555346] mmc1: ADMA error: 0x02000002
    112	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib/raid6
    [  179.555348] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib/crypto
    [  179.555350] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    12	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib/math
    [  179.555352] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib
    [  179.555355] mmc1: sdhci: Argument:  0x00840a08 | Trn mode: 0x0000003b
    12	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/samples/rpmsg
    [  179.555357] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/samples
    [  179.555359] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  179.555361] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    168	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/arch/arm64/cr[  179.555364] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    ypto
    184	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/arch/arm[  179.555366] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    64
    188	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/arch
    [  179.555368] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/phy/fre[  179.555370] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    escale
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers[  179.555372] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    /phy/cadence
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/d[  179.555374] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    rivers/phy/ti
    80	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/[  179.555377] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    drivers/phy
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/dr[  179.555379] mmc1: sdhci: Host ctl2: 0x00000c00
    ivers/misc/uacce
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kern[  179.555381] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    128	./lib/modules/5.10.65-rt53-g541ec9a6[  179.555383] mmc1: sdhci: ============================================
    99/kernel/drivers/misc
    144	./lib/modules/5.10.65-rt53-g541ec9a6[  179.555384] mmc1: sdhci: 8c1712200: DMA 0x00000008c2d70000, LEN 0x0000, Attr=0x21
    99/kernel/drivers/soundwire
    16	./lib/modules/5.10.65-rt53-g541e[  179.555386] mmc1: sdhci: 8c171220c: DMA 0x00000008c2d80000, LEN 0x6000, Attr=0x21
    c9a699/kernel/drivers/clk
    48	./lib/modules/5.10.65-rt53-g541ec9[  179.555389] mmc1: sdhci: 8c1712218: DMA 0x00000008c307b000, LEN 0x1000, Attr=0x21
    a699/kernel/drivers/extcon
    140	./lib/modules/5.10.65-rt53-g541e[  179.555391] mmc1: sdhci: 8c1712224: DMA 0x00000008c2d86000, LEN 0x8000, Attr=0x21
    c9a699/kernel/drivers/scsi/libsas
    180	./lib/modules/5.10.65-rt5[  179.555393] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    3-g541ec9a699/kernel/drivers/scsi/hisi_sas
    480	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/scsi/mpt3sas
    880	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/scsi
    616	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/md
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/slimbus
    320	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/bluetooth
    124	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/remoteproc
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/video/backlight
    28	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/video
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ssb
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/phy
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/misc
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/roles
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget/udc
    320	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget/legacy
    696	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget/function
    1156	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/isp1760
    492	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/host
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/common
    152	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/musb
    152	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/storage
    184	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/dwc3
    120	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/typec/tcpm
    212	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/typec
    60	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/class
    424	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/core
    476	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/serial
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/cdns3
    3628	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb
    180	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/mtd/tests
    184	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/mtd
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/w1
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/soc/ti
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/soc
    108	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hwmon
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nfc/s3fwrn5
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nfc
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input/misc
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input/keyboard
    152	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input/touchscreen
    208	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/spi
    836	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/tuners
    200	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/common/videobuf2
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/common
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/usb/gspca
    160	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/usb/uvc
    212	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/usb
    104	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/dvb-frontends/cxd2880
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/dvb-frontends/drx39xyj
    2924	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/dvb-frontends
    840	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/vxe-vxd
    28	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/cadence
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/ti/j721e-csi2rx
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/ti/cal
    128	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/ti
    1000	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform
    84	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/v4l2-core
    136	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/i2c
    5432	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/regulator
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ntb/hw/epf
    28	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ntb/hw
    100	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ntb
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/rpmsg
    144	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/rtc
    176	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/crypto/ccree
    232	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/crypto
    200	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nvme/host
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nvme
    12	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/rcar-du
    84	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/panel
    112	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/arm
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/bridge/cadence
    96	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/bridge/synopsys
    288	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/bridge
    500	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm
    504	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/block
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/pwm
    68	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpio
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/irqchip
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/watchdog
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/fpga
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/phy
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can/dev
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can/m_can
    52	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can/c_can
    188	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can
    748	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/usb
    332	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/intel/e1000e
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/intel/e1000
    540	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/intel
    1196	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/broadcom/bnx2x
    1464	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/broadcom
    300	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/ti
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/marvell
    2380	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet
    476	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel/iwlwifi/mvm
    212	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel/iwlwifi/dvm
    1144	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel/iwlwifi
    1148	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel
    660	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ath/ath10k
    712	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ath
    552	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/b43
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil
    408	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac
    436	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/brcm80211
    992	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom
    180	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ti/wl18xx
    404	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ti/wlcore
    588	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ti
    500	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/marvell/mwifiex
    504	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/marvell
    3948	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless
    7512	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/common/cros_ec_sensors
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/common
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/pressure
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/buffer
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/light
    92	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/adc
    228	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/base/regmap
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/base
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hid/i2c-hid
    60	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hid/usbhid
    148	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hid
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/platform/chrome
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/platform
    660	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ata
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/power/supply
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/power
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/rpmsg-kdrv
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/char/hw_random
    240	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/char/ipmi
    320	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/char
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/tty/serial/8250
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/tty/serial
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/tty
    80	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/bcma
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/mfd
    22964	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers
    472	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/crypto
    1048	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/sched
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/llc
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/8021q
    572	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/netfilter
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bluetooth/hidp
    728	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bluetooth
    92	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/hsr
    140	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/can
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/rfkill
    832	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/mac80211
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/nfc/nci
    220	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/nfc
    176	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv4/netfilter
    300	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv4
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/802
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/key
    104	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/dsa
    228	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bridge/netfilter
    572	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bridge
    80	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/qrtr
    92	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/xfrm
    140	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv6/netfilter
    1096	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv6
    520	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/sctp
    512	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/wireless
    7176	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net
    240	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/fuse
    192	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/overlayfs
    952	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/cifs
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/nfs/blocklayout
    60	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/nfs
    1760	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/btrfs
    3208	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs
    35580	./lib/modules/5.10.65-rt53-g541ec9a699/kernel
    2424	./lib/modules/5.10.65-rt53-g541ec9a699/extra
    39248	./lib/modules/5.10.65-rt53-g541ec9a699
    78752	./lib/modules
    1112	./lib/firmware/ti-connectivity
    2564	./lib/firmware/intel
    132	./lib/firmware/cadence
    11228	./lib/firmware/pdk-ipc
    1140	./lib/firmware/pru
    616	./lib/firmware/ethfw
    63500	./lib/firmware
    172	./lib/udev/rules.d
    6708	./lib/udev/hwdb.d
    15584	./lib/udev
    8	./lib/modprobe.d
    8	./lib/systemd/journald.conf.d
    8	./lib/systemd/ntp-units.d
    8	./lib/systemd/system.conf.d
    120	./lib/systemd/system-preset
    8	./lib/systemd/logind.conf.d
    4	./lib/systemd/system-shutdown
    4	./lib/systemd/system-sleep
    36	./lib/systemd/network
    176	./lib/systemd/system-generators
    4	./lib/systemd/system/runlevel3.target.wants
    4	./lib/systemd/system/runlevel1.target.wants
    4	./lib/systemd/system/rescue.target.wants
    4	./lib/systemd/system/multi-user.target.wants
    4	./lib/systemd/system/runlevel2.target.wants
    4	./lib/systemd/system/runlevel5.target.wants
    4	./lib/systemd/system/sysinit.target.wants
    4	./lib/systemd/system/timers.target.wants
    4	./lib/systemd/system/reboot.target.wants
    4	./lib/systemd/system/graphical.target.wants
    4	./lib/systemd/system/sockets.target.wants
    4	./lib/systemd/system/local-fs.target.wants
    4	./lib/systemd/system/sound.target.wants
    4	./lib/systemd/system/dbus.target.wants
    4	./lib/systemd/system/poweroff.target.wants
    4	./lib/systemd/system/runlevel4.target.wants
    8	./lib/systemd/system/user-.slice.d
    840	./lib/systemd/system
    7696	./lib/systemd
    8	./lib/depmod.d
    624	./lib/security
    172912	./lib
    4	./tmp
    4	./sys
    4	./var/lib/misc
    4	./var/lib/sudo/lectured
    8	./var/lib/sudo
    8	./var/lib/net-snmp
    8	./var/lib/alsa
    4	./var/lib/dbus
    4	./var/lib/nfs/statd/sm.bak
    16	./var/lib/nfs/statd
    4	./var/lib/nfs/v4recovery
    24	./var/lib/nfs
    4	./var/lib/docker/image/overlay2/layerdb
    4	./var/lib/docker/image/overlay2/distribution
    4	./var/lib/docker/image/overlay2/imagedb/metadata/sha256
    8	./var/lib/docker/image/overlay2/imagedb/metadata
    4	./var/lib/docker/image/overlay2/imagedb/content/sha256
    8	./var/lib/docker/image/overlay2/imagedb/content
    20	./var/lib/docker/image/overlay2/imagedb
    36	./var/lib/docker/image/overlay2
    4	./var/lib/docker/image/vfs/layerdb
    4	./var/lib/docker/image/vfs/distribution
    4	./var/lib/docker/image/vfs/imagedb/metadata/sha256
    8	./var/lib/docker/image/vfs/imagedb/metadata
    4	./var/lib/docker/image/vfs/imagedb/content/sha256
    8	./var/lib/docker/image/vfs/imagedb/content
    20	./var/lib/docker/image/vfs/imagedb
    36	./var/lib/docker/image/vfs
    76	./var/lib/docker/image
    4	./var/lib/docker/runtimes
    4	./var/lib/docker/buildkit/executor
    4	./var/lib/docker/buildkit/content/ingest
    8	./var/lib/docker/buildkit/content
    72	./var/lib/docker/buildkit
    4	./var/lib/docker/tmp
    28	./var/lib/docker/volumes
    4	./var/lib/docker/swarm
    20	./var/lib/docker/builder
    4	./var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.native/snapshots
    8	./var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.native
    4	./var/lib/docker/containerd/daemon/io.containerd.content.v1.content/ingest
    8	./var/lib/docker/containerd/daemon/io.containerd.content.v1.content
    4	./var/lib/docker/containerd/daemon/tmpmounts
    4	./var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.overlayfs/snapshots
    8	./var/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.overlayfs
    4	./var/lib/docker/containerd/daemon/io.containerd.runtime.v1.linux
    4	./var/lib/docker/containerd/daemon/io.containerd.runtime.v2.task
    28	./var/lib/docker/containerd/daemon/io.containerd.metadata.v1.bolt
    68	./var/lib/docker/containerd/daemon
    72	./var/lib/docker/containerd
    4	./var/lib/docker/trust
    4	./var/lib/docker/overlay2/l
    8	./var/lib/docker/overlay2
    4	./var/lib/docker/containers
    4	./var/lib/docker/plugins/tmp
    4	./var/lib/docker/plugins/storage/blobs/tmp
    8	./var/lib/docker/plugins/storage/blobs
    12	./var/lib/docker/plugins/storage
    20	./var/lib/docker/plugins
    36	./var/lib/docker/network/files
    40	./var/lib/docker/network
    4	./var/lib/docker/vfs
    364	./var/lib/docker
    4	./var/lib/systemd/catalog
    4	./var/lib/systemd/timers
    4	./var/lib/systemd/timesync
    4	./var/lib/systemd/linger
    4	./var/lib/systemd/coredump
    28	./var/lib/systemd
    [  181.183264] mmc1: ADMA error: 0x02000002
    [  181.183275] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.183278] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  181.183280] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.183283] mmc1: sdhci: Argument:  0x00c40d00 | Trn mode: 0x0000003b
    [  181.183286] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.183288] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.183291] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.183293] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.183295] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.183298] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.183300] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.183302] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.183305] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.183307] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.183309] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.183312] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712218
    [  181.183314] mmc1: sdhci: ============================================
    [  181.183315] mmc1: sdhci: 8c1712200: DMA 0x00000008c2dad000, LEN 0x1000, Attr=0x21
    [  181.183319] mmc1: sdhci: 8c171220c: DMA 0x00000008c2db0000, LEN 0x0000, Attr=0x21
    [  181.183321] mmc1: sdhci: 8c1712218: DMA 0x00000008c2dc0000, LEN 0x8000, Attr=0x21
    [  181.183324] mmc1: sdhci: 8c1712224: DMA 0x00000008c31d5000, LEN 0x1000, Attr=0x21
    [  181.183326] mmc1: sdhci: 8c1712230: DMA 0x00000008c2dc8000, LEN 0x7000, Attr=0x21
    [  181.183329] mmc1: sdhci: 8c171223c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.189306] mmc1: ADMA error: 0x02000002
    [  181.189310] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.189311] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  181.189314] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.189316] mmc1: sdhci: Argument:  0x00c40d00 | Trn mode: 0x0000003b
    [  181.189318] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.189320] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.189323] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.189325] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.189327] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.189329] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.189331] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.189334] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.189336] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.189338] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.189340] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.189342] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712218
    [  181.189344] mmc1: sdhci: ============================================
    [  181.189346] mmc1: sdhci: 8c1712200: DMA 0x00000008c2dad000, LEN 0x1000, Attr=0x21
    [  181.189349] mmc1: sdhci: 8c171220c: DMA 0x00000008c2db0000, LEN 0x0000, Attr=0x21
    [  181.189351] mmc1: sdhci: 8c1712218: DMA 0x00000008c2dc0000, LEN 0x8000, Attr=0x21
    [  181.189353] mmc1: sdhci: 8c1712224: DMA 0x00000008c31d5000, LEN 0x1000, Attr=0x21
    [  181.189355] mmc1: sdhci: 8c1712230: DMA 0x00000008c2dc8000, LEN 0x7000, Attr=0x21
    [  181.189357] mmc1: sdhci: 8c171223c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.333358] mmc1: ADMA error: 0x02000002
    [  181.333364] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.333366] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  181.333369] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.333371] mmc1: sdhci: Argument:  0x00c40e08 | Trn mode: 0x0000003b
    [  181.333374] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.333376] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.333378] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.333380] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.333383] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.333385] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.333387] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.333389] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.333391] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.333393] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.333395] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.333398] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712218
    [  181.333400] mmc1: sdhci: ============================================
    [  181.333401] mmc1: sdhci: 8c1712200: DMA 0x00000008c2dcf000, LEN 0x1000, Attr=0x21
    [  181.333403] mmc1: sdhci: 8c171220c: DMA 0x00000008c2dd8000, LEN 0x0000, Attr=0x21
    [  181.333406] mmc1: sdhci: 8c1712218: DMA 0x00000008c2de8000, LEN 0x5000, Attr=0x21
    [  181.333408] mmc1: sdhci: 8c1712224: DMA 0x00000008c31d6000, LEN 0x1000, Attr=0x21
    [  181.333410] mmc1: sdhci: 8c1712230: DMA 0x00000008c2ded000, LEN 0x9000, Attr=0x21
    [  181.333413] mmc1: sdhci: 8c171223c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.339211] mmc1: ADMA error: 0x02000002
    [  181.339213] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.339215] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  181.339218] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.339220] mmc1: sdhci: Argument:  0x00c40e08 | Trn mode: 0x0000003b
    [  181.339222] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.339224] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.339226] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.339228] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.339231] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.339233] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.339235] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.339238] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.339240] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.339242] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.339244] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.339246] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712218
    [  181.339248] mmc1: sdhci: ============================================
    [  181.339249] mmc1: sdhci: 8c1712200: DMA 0x00000008c2dcf000, LEN 0x1000, Attr=0x21
    [  181.339252] mmc1: sdhci: 8c171220c: DMA 0x00000008c2dd8000, LEN 0x0000, Attr=0x21
    [  181.339254] mmc1: sdhci: 8c1712218: DMA 0x00000008c2de8000, LEN 0x5000, Attr=0x21
    [  181.339256] mmc1: sdhci: 8c1712224: DMA 0x00000008c31d6000, LEN 0x1000, Attr=0x21
    [  181.339259] mmc1: sdhci: 8c1712230: DMA 0x00000008c2ded000, LEN 0x9000, Attr=0x21
    [  181.339261] mmc1: sdhci: 8c171223c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.412579] mmc1: ADMA error: 0x02000002
    [  181.412584] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.412586] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  181.412588] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.412590] mmc1: sdhci: Argument:  0x00c41600 | Trn mode: 0x0000003b
    [  181.412592] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.412594] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.412597] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.412599] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.412601] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.412603] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.412606] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.412608] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.412610] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.412612] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.412614] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.412616] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  181.412618] mmc1: sdhci: ============================================
    [  181.412619] mmc1: sdhci: 8c1712200: DMA 0x00000008c2df6000, LEN 0x9000, Attr=0x21
    [  181.412622] mmc1: sdhci: 8c171220c: DMA 0x00000008c31d7000, LEN 0x1000, Attr=0x21
    33128[  181.412625] mmc1: sdhci: 8c1712218: DMA 0x00000008c2dff000, LEN 0x0000, Attr=0x21
    [  181.412627] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e0f000, LEN 0x7000, Attr=0x21
    [  181.412629] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    	./var/lib/opkg/info[  181.418560] mmc1: ADMA error: 0x02000002
    [  181.418563] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.418565] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  181.418567] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.418569] mmc1: sdhci: Argument:  0x00c41600 | Trn mode: 0x0000003b
    [  181.418571] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.418574] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.418576] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    33880[  181.418578] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.418580] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.418582] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    	./var/lib/opkg[  181.418584] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.418587] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.418589] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.418591] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.418593] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.418595] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    4[  181.418597] mmc1: sdhci: ============================================
    	./var/lib/arpd[  181.418598] mmc1: sdhci: 8c1712200: DMA 0x00000008c2df6000, LEN 0x9000, Attr=0x21
    [  181.418601] mmc1: sdhci: 8c171220c: DMA 0x00000008c31d7000, LEN 0x1000, Attr=0x21
    [  181.418603] mmc1: sdhci: 8c1712218: DMA 0x00000008c2dff000, LEN 0x0000, Attr=0x21
    [  181.418605] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e0f000, LEN 0x7000, Attr=0x21
    [  181.418608] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.484958] mmc1: ADMA error: 0x02000002
    4[  181.484963] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    	./var/lib/private[  181.484964] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  181.484967] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.484969] mmc1: sdhci: Argument:  0x00c40b08 | Trn mode: 0x0000003b
    [  181.484971] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.484973] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    4[  181.484976] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.484978] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    	./var/lib/urandom[  181.484980] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.484983] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.484985] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.484987] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.484989] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.484991] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    34348[  181.484993] mmc1: sdhci: Host ctl2: 0x00000c00
    	./var/lib[  181.484995] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171223c
    [  181.484997] mmc1: sdhci: ============================================
    [  181.484998] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e17000, LEN 0x1000, Attr=0x21
    [  181.485001] mmc1: sdhci: 8c171220c: DMA 0x00000008c2598000, LEN 0x6000, Attr=0x21
    40[  181.485004] mmc1: sdhci: 8c1712218: DMA 0x00000008c31d8000, LEN 0x1000, Attr=0x21
    [  181.485006] mmc1: sdhci: 8c1712224: DMA 0x00000008c259e000, LEN 0x2000, Attr=0x21
    [  181.485008] mmc1: sdhci: 8c1712230: DMA 0x00000008c2e18000, LEN 0x0000, Attr=0x21
    [  181.485010] mmc1: sdhci: 8c171223c: DMA 0x00000008c2e28000, LEN 0x6000, Attr=0x21
    [  181.485013] mmc1: sdhci: 8c1712248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    	./var/cache/ldconfig[  181.490833] mmc1: ADMA error: 0x02000002
    [  181.490838] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.490839] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  181.490842] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.490844] mmc1: sdhci: Argument:  0x00c40b08 | Trn mode: 0x0000003b
    [  181.490846] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    4[  181.490849] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.490851] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.490853] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    	./var/cache/opkg[  181.490855] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.490858] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.490860] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.490862] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.490864] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.490867] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    4[  181.490869] mmc1: sdhci: Host ctl2: 0x00000c00
    	./var/cache/private[  181.490871] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171223c
    [  181.490873] mmc1: sdhci: ============================================
    32	./var/cache/fontconfig
    84[  181.490874] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e17000, LEN 0x1000, Attr=0x21
    	./var/cache
    [  181.490877] mmc1: sdhci: 8c171220c: DMA 0x00000008c2598000, LEN 0x6000, Attr=0x21
    4	./var/local
    [  181.490879] mmc1: sdhci: 8c1712218: DMA 0x00000008c31d8000, LEN 0x1000, Attr=0x21
    4	./var/spool/mail
    [  181.490882] mmc1: sdhci: 8c1712224: DMA 0x00000008c259e000, LEN 0x2000, Attr=0x21
    4	./var/spool/cron
    [  181.490884] mmc1: sdhci: 8c1712230: DMA 0x00000008c2e18000, LEN 0x0000, Attr=0x21
    4	./var/spool/at/jobs
    [  181.490886] mmc1: sdhci: 8c171223c: DMA 0x00000008c2e28000, LEN 0x6000, Attr=0x21
    4	./var/spool/at/spool
    [  181.490889] mmc1: sdhci: 8c1712248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    12	./var/spool/at
    [  181.569503] mmc1: ADMA error: 0x02000002
    24	./var/spool
    [  181.569510] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    4	./var/backups
    [  181.569512] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    4	./var/volatile
    [  181.569515] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    34472	./var
    [  181.569517] mmc1: sdhci: Argument:  0x00c41500 | Trn mode: 0x0000003b
    6576	./bin
    [  181.569519] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.569522] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.569525] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.569527] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.569529] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.569531] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.569534] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.569536] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.569539] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.569541] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.569543] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.569545] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  181.569547] mmc1: sdhci: ============================================
    [  181.569549] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e2e000, LEN 0x9000, Attr=0x21
    [  181.569552] mmc1: sdhci: 8c171220c: DMA 0x00000008c31d9000, LEN 0x1000, Attr=0x21
    [  181.569554] mmc1: sdhci: 8c1712218: DMA 0x00000008c2e37000, LEN 0x0000, Attr=0x21
    [  181.569556] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e47000, LEN 0x6000, Attr=0x21
    [  181.569559] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.575342] mmc1: ADMA error: 0x02000002
    [  181.575345] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.575346] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  181.575349] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.575351] mmc1: sdhci: Argument:  0x00c41500 | Trn mode: 0x0000003b
    [  181.575353] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.575356] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    4	./media/ram
    [  181.575358] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    8	./media
    [  181.575360] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    4	./mnt
    [  181.575362] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    4	./run
    [  181.575364] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    4816	./sbin
    [  181.575367] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    4	./dev
    [  181.575369] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.575371] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.575373] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.575375] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.575378] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  181.575380] mmc1: sdhci: ============================================
    [  181.575381] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e2e000, LEN 0x9000, Attr=0x21
    [  181.575383] mmc1: sdhci: 8c171220c: DMA 0x00000008c31d9000, LEN 0x1000, Attr=0x21
    [  181.575386] mmc1: sdhci: 8c1712218: DMA 0x00000008c2e37000, LEN 0x0000, Attr=0x21
    [  181.575388] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e47000, LEN 0x6000, Attr=0x21
    [  181.575390] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.644451] mmc1: ADMA error: 0x02000002
    [  181.644456] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.644458] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  181.644460] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.644463] mmc1: sdhci: Argument:  0x00c41300 | Trn mode: 0x0000003b
    [  181.644465] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.644468] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.644470] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.644472] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.644475] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.644477] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.644479] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.644481] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.644484] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.644486] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.644488] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.644490] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  181.644492] mmc1: sdhci: ============================================
    [  181.644493] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e4d000, LEN 0x2000, Attr=0x21
    12	./opt/ltp/skips
    [  181.644496] mmc1: sdhci: 8c171220c: DMA 0x00000008c31da000, LEN 0x1000, Attr=0x21
    [  181.644498] mmc1: sdhci: 8c1712218: DMA 0x00000008c2e4f000, LEN 0x0000, Attr=0x21
    [  181.644500] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e5f000, LEN 0xe000, Attr=0x21
    [  181.644502] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.650455] mmc1: ADMA error: 0x02000002
    [  181.650457] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.650459] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  181.650462] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.650464] mmc1: sdhci: Argument:  0x00c41300 | Trn mode: 0x0000003b
    [  181.650466] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.650469] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.650471] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.650473] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.650475] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.650478] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.650480] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.650482] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.650485] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.650487] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.650489] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.650491] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  181.650493] mmc1: sdhci: ============================================
    [  181.650494] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e4d000, LEN 0x2000, Attr=0x21
    [  181.650497] mmc1: sdhci: 8c171220c: DMA 0x00000008c31da000, LEN 0x1000, Attr=0x21
    [  181.650499] mmc1: sdhci: 8c1712218: DMA 0x00000008c2e4f000, LEN 0x0000, Attr=0x21
    [  181.650501] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e5f000, LEN 0xe000, Attr=0x21
    [  181.650503] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.738530] mmc1: ADMA error: 0x02000002
    [  181.738537] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.738539] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  181.738541] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.738544] mmc1: sdhci: Argument:  0x00c41100 | Trn mode: 0x0000003b
    [  181.738547] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.738549] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.738551] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.738554] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.738556] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.738558] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.738561] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.738563] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.738566] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.738568] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.738570] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.738572] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712248
    [  181.738574] mmc1: sdhci: ============================================
    [  181.738576] mmc1: sdhci: 8c1712200: DMA 0x00000008c2757000, LEN 0x1000, Attr=0x21
    [  181.738579] mmc1: sdhci: 8c171220c: DMA 0x00000008c2615000, LEN 0x1000, Attr=0x21
    [  181.738581] mmc1: sdhci: 8c1712218: DMA 0x00000008c2702000, LEN 0x1000, Attr=0x21
    [  181.738583] mmc1: sdhci: 8c1712224: DMA 0x00000008c2cdb000, LEN 0x1000, Attr=0x21
    [  181.738585] mmc1: sdhci: 8c1712230: DMA 0x00000008c2cdd000, LEN 0x3000, Attr=0x21
    [  181.738587] mmc1: sdhci: 8c171223c: DMA 0x00000008c2ce8000, LEN 0x0000, Attr=0x21
    [  181.738589] mmc1: sdhci: 8c1712248: DMA 0x00000008c2cf8000, LEN 0x5000, Attr=0x21
    [  181.738592] mmc1: sdhci: 8c1712254: DMA 0x00000008c2b95000, LEN 0x1000, Attr=0x21
    [  181.738594] mmc1: sdhci: 8c1712260: DMA 0x00000008c2cfd000, LEN 0x3000, Attr=0x21
    [  181.738596] mmc1: sdhci: 8c171226c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.744390] mmc1: ADMA error: 0x02000002
    [  181.744394] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.744395] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  181.744398] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.744400] mmc1: sdhci: Argument:  0x00c41100 | Trn mode: 0x0000003b
    [  181.744402] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.744404] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.744406] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.744409] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.744411] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.744413] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.744415] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.744417] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.744419] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.744421] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.744423] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.744425] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712248
    [  181.744427] mmc1: sdhci: ============================================
    [  181.744428] mmc1: sdhci: 8c1712200: DMA 0x00000008c2757000, LEN 0x1000, Attr=0x21
    [  181.744431] mmc1: sdhci: 8c171220c: DMA 0x00000008c2615000, LEN 0x1000, Attr=0x21
    [  181.744433] mmc1: sdhci: 8c1712218: DMA 0x00000008c2702000, LEN 0x1000, Attr=0x21
    [  181.744435] mmc1: sdhci: 8c1712224: DMA 0x00000008c2cdb000, LEN 0x1000, Attr=0x21
    [  181.744438] mmc1: sdhci: 8c1712230: DMA 0x00000008c2cdd000, LEN 0x3000, Attr=0x21
    [  181.744440] mmc1: sdhci: 8c171223c: DMA 0x00000008c2ce8000, LEN 0x0000, Attr=0x21
    [  181.744442] mmc1: sdhci: 8c1712248: DMA 0x00000008c2cf8000, LEN 0x5000, Attr=0x21
    [  181.744444] mmc1: sdhci: 8c1712254: DMA 0x00000008c2b95000, LEN 0x1000, Attr=0x21
    [  181.744446] mmc1: sdhci: 8c1712260: DMA 0x00000008c2cfd000, LEN 0x3000, Attr=0x21
    [  181.744449] mmc1: sdhci: 8c171226c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  181.887712] mmc1: ADMA error: 0x02000002
    [  181.887717] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  181.887719] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  181.887721] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  181.887724] mmc1: sdhci: Argument:  0x00c41008 | Trn mode: 0x0000003b
    [  181.887726] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  181.887729] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  181.887731] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  181.887733] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  181.887735] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  181.887738] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  181.887740] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  181.887742] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  181.887745] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  181.887747] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  181.887749] mmc1: sdhci: Host ctl2: 0x00000c00
    [  181.887751] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    [  181.887753] mmc1: sdhci: ============================================
    [  181.887754] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e9e000, LEN 0x0000, Attr=0x21
    28	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  181.887757] mmc1: sdhci: 8c171220c: DMA 0x00000008c2eae000, LEN 0x8000, Attr=0x21
    es/pthread_mutex_destroy/speculative
    [  181.887759] mmc1: sdhci: 8c1712218: DMA 0x00000008c2b98000, LEN 0x1000, Attr=0x21
    144	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  181.887762] mmc1: sdhci: 8c1712224: DMA 0x00000008c2eb6000, LEN 0x6000, Attr=0x21
    ces/pthread_mutex_destroy
    60	./opt/ltp/testcases/open_posix_tes[  181.887764] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    tsuite/conformance/interfaces/pthread_rwlock_destroy
    72	./opt/l[  181.893387] mmc1: ADMA error: 0x02000002
    tp/testcases/open_posix_testsuite/conformance/interfaces/pthread[  181.893390] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    _mutexattr_getprioceiling
    120	./opt/ltp/testcases/open_posix_te[  181.893392] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    stsuite/conformance/interfaces/pthread_attr_setinheritsched
    164[  181.893394] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  181.893396] mmc1: sdhci: Argument:  0x00c41008 | Trn mode: 0x0000003b
    /pthread_atfork
    60	./opt/ltp/testcases/open_posix_testsuite/con[  181.893398] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    formance/interfaces/pthread_barrierattr_init
    72	./opt/ltp/testc[  181.893401] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    ases/open_posix_testsuite/conformance/interfaces/pthread_setcanc[  181.893403] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    elstate
    56	./opt/ltp/testcases/open_posix_testsuite/conformance[  181.893405] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    /interfaces/pthread_attr_getschedpolicy
    76	./opt/ltp/testcases/[  181.893407] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    open_posix_testsuite/conformance/interfaces/pthread_attr_setscop[  181.893409] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    e
    148	./opt/ltp/testcases/open_posix_testsuite/conformance/inte[  181.893412] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    rfaces/munmap
    72	./opt/ltp/testcases/open_posix_testsuite/confo[  181.893414] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    rmance/interfaces/pthread_condattr_destroy
    72	./opt/ltp/testcas[  181.893416] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    es/open_posix_testsuite/conformance/interfaces/pthread_mutex_get[  181.893418] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    prioceiling
    108	./opt/ltp/testcases/open_posix_testsuite/confor[  181.893420] mmc1: sdhci: Host ctl2: 0x00000c00
    mance/interfaces/mq_close
    112	./opt/ltp/testcases/open_posix_te[  181.893423] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    stsuite/conformance/interfaces/pthread_rwlock_unlock
    [  181.893424] mmc1: sdhci: ============================================
    [  181.893426] mmc1: sdhci: 8c1712200: DMA 0x00000008c2e9e000, LEN 0x0000, Attr=0x21
    [  181.893428] mmc1: sdhci: 8c171220c: DMA 0x00000008c2eae000, LEN 0x8000, Attr=0x21
    [  181.893430] mmc1: sdhci: 8c1712218: DMA 0x00000008c2b98000, LEN 0x1000, Attr=0x21
    [  181.893432] mmc1: sdhci: 8c1712224: DMA 0x00000008c2eb6000, LEN 0x6000, Attr=0x21
    [  181.893435] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  182.030712] mmc1: ADMA error: 0x02000002
    [  182.030718] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  182.030720] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  182.030722] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  182.030724] mmc1: sdhci: Argument:  0x00c41708 | Trn mode: 0x0000003b
    [  182.030727] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  182.030729] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  182.030732] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  182.030734] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  182.030736] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  182.030738] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  182.030741] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  182.030743] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  182.030745] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    468	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  182.030747] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    ces/shm_open
    [  182.030749] mmc1: sdhci: Host ctl2: 0x00000c00
    316	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  182.030752] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712218
    ces/pthread_cond_timedwait
    136	./opt/ltp/testcases/open_posix_t[  182.030754] mmc1: sdhci: ============================================
    estsuite/conformance/interfaces/pthread_attr_setschedpolicy
    100[  182.030755] mmc1: sdhci: 8c1712200: DMA 0x00000008c2b9b000, LEN 0x1000, Attr=0x21
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  182.030758] mmc1: sdhci: 8c171220c: DMA 0x00000008c2ebc000, LEN 0x0000, Attr=0x21
    /pthread_mutexattr_setpshared
    [  182.030760] mmc1: sdhci: 8c1712218: DMA 0x00000008c2ecc000, LEN 0xe000, Attr=0x21
    [  182.030763] mmc1: sdhci: 8c1712224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  182.036358] mmc1: ADMA error: 0x02000002
    [  182.036361] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  182.036363] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  182.036365] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  182.036367] mmc1: sdhci: Argument:  0x00c41708 | Trn mode: 0x0000003b
    [  182.036369] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  182.036372] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  182.036374] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  182.036376] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  182.036378] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  182.036380] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  182.036382] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  182.036385] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  182.036387] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  182.036389] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  182.036391] mmc1: sdhci: Host ctl2: 0x00000c00
    [  182.036393] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712218
    [  182.036395] mmc1: sdhci: ============================================
    [  182.036396] mmc1: sdhci: 8c1712200: DMA 0x00000008c2b9b000, LEN 0x1000, Attr=0x21
    [  182.036399] mmc1: sdhci: 8c171220c: DMA 0x00000008c2ebc000, LEN 0x0000, Attr=0x21
    [  182.036401] mmc1: sdhci: 8c1712218: DMA 0x00000008c2ecc000, LEN 0xe000, Attr=0x21
    [  182.036403] mmc1: sdhci: 8c1712224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  182.807600] mmc1: ADMA error: 0x02000002
    [  182.807609] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    84	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  182.807611] mmc1: sdhci: Sys addr:  0x000000e8 | Version:  0x00001004
    es/sigdelset
    [  182.807614] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    40	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  182.807617] mmc1: sdhci: Argument:  0x01043c00 | Trn mode: 0x0000003b
    es/pthread_setschedprio
    88	./opt/ltp/testcases/open_posix_tests[  182.807620] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    uite/conformance/interfaces/pthread_attr_setdetachstate
    356	./o[  182.807623] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    pt/ltp/testcases/open_posix_testsuite/conformance/interfaces/sch[  182.807625] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    ed_setscheduler
    [  182.807628] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  182.807630] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  182.807633] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  182.807635] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  182.807637] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  182.807640] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  182.807642] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  182.807644] mmc1: sdhci: Host ctl2: 0x00000c00
    [  182.807647] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712230
    [  182.807649] mmc1: sdhci: ============================================
    [  182.807650] mmc1: sdhci: 8c1712200: DMA 0x00000008c2daf000, LEN 0x1000, Attr=0x21
    [  182.807654] mmc1: sdhci: 8c171220c: DMA 0x00000008c2dae000, LEN 0x1000, Attr=0x21
    [  182.807656] mmc1: sdhci: 8c1712218: DMA 0x00000008c2e6d000, LEN 0x1000, Attr=0x21
    [  182.807659] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e6f000, LEN 0x0000, Attr=0x21
    [  182.807661] mmc1: sdhci: 8c1712230: DMA 0x00000008c2e7f000, LEN 0x9000, Attr=0x21
    [  182.807664] mmc1: sdhci: 8c171223c: DMA 0x00000008c31e6000, LEN 0x1000, Attr=0x21
    [  182.807666] mmc1: sdhci: 8c1712248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  182.812973] mmc1: ADMA error: 0x02000002
    [  182.812977] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  182.812978] mmc1: sdhci: Sys addr:  0x000000e8 | Version:  0x00001004
    [  182.812981] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  182.812983] mmc1: sdhci: Argument:  0x01043c00 | Trn mode: 0x0000003b
    [  182.812985] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  182.812988] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    44	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  182.812990] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    es/strncpy
    [  182.812992] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    28	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  182.812994] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    es/pthread_rwlock_trywrlock/speculative
    [  182.812997] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    84	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  182.812999] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    76	./opt/ltp/testcases/open_posix_t[  182.813001] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    estsuite/conformance/interfaces/pthread_cleanup_pop
    72	./opt/lt[  182.813003] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    p/testcases/open_posix_testsuite/conformance/interfaces/pthread_[  182.813006] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    key_delete
    32	./opt/ltp/testcases/open_posix_testsuite/conforma[  182.813007] mmc1: sdhci: Host ctl2: 0x00000c00
    nce/interfaces/pthread_mutex_init/speculative
    184	./opt/ltp/tes[  182.813010] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712230
    tcases/open_posix_testsuite/conformance/interfaces/pthread_mutex[  182.813012] mmc1: sdhci: ============================================
    _init
    60	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  182.813013] mmc1: sdhci: 8c1712200: DMA 0x00000008c2daf000, LEN 0x1000, Attr=0x21
    nterfaces/pthread_condattr_setpshared
    48	./opt/ltp/testcases/op[  182.813015] mmc1: sdhci: 8c171220c: DMA 0x00000008c2dae000, LEN 0x1000, Attr=0x21
    en_posix_testsuite/conformance/interfaces/pthread_attr_getstacks[  182.813018] mmc1: sdhci: 8c1712218: DMA 0x00000008c2e6d000, LEN 0x1000, Attr=0x21
    ize
    144	./opt/ltp/testcases/open_posix_testsuite/conformance/in[  182.813020] mmc1: sdhci: 8c1712224: DMA 0x00000008c2e6f000, LEN 0x0000, Attr=0x21
    terfaces/sigset
    52	./opt/ltp/testcases/open_posix_testsuite/con[  182.813022] mmc1: sdhci: 8c1712230: DMA 0x00000008c2e7f000, LEN 0x9000, Attr=0x21
    formance/interfaces/timer_create/speculative
    216	./opt/ltp/test[  182.813029] mmc1: sdhci: 8c171223c: DMA 0x00000008c31e6000, LEN 0x1000, Attr=0x21
    cases/open_posix_testsuite/conformance/interfaces/timer_create
    [  182.813032] mmc1: sdhci: 8c1712248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    108	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  183.014866] mmc1: ADMA error: 0x02000002
    ces/aio_return
    36	./opt/ltp/testcases/open_posix_testsuite/conf[  183.014874] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    ormance/interfaces/pthread_self
    92	./opt/ltp/testcases/open_pos[  183.014876] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    ix_testsuite/conformance/interfaces/sigaction/templates
    6660	./[  183.014878] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/si[  183.014881] mmc1: sdhci: Argument:  0x00042e00 | Trn mode: 0x0000003b
    gaction
    152	./opt/ltp/testcases/open_posix_testsuite/conformanc[  183.014883] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    e/interfaces/pthread_rwlock_rdlock
    36	./opt/ltp/testcases/open_[  183.014886] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    posix_testsuite/conformance/interfaces/pthread_attr_setschedpara[  183.014888] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    m/speculative
    136	./opt/ltp/testcases/open_posix_testsuite/conf[  183.014890] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    ormance/interfaces/pthread_attr_setschedparam
    56	./opt/ltp/test[  183.014892] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    cases/open_posix_testsuite/conformance/interfaces/pthread_testca[  183.014895] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    ncel
    28	./opt/ltp/testcases/open_posix_testsuite/conformance/in[  183.014897] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    terfaces/pthread_getcpuclockid/speculative
    76	./opt/ltp/testcas[  183.014899] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    es/open_posix_testsuite/conformance/interfaces/pthread_getcpuclo[  183.014902] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ckid
    100	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  183.014904] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    nterfaces/pthread_spin_init
    200	./opt/ltp/testcases/open_posix_[  183.014906] mmc1: sdhci: Host ctl2: 0x00000c00
    testsuite/conformance/interfaces/aio_fsync
    136	./opt/ltp/testca[  183.014909] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    ses/open_posix_testsuite/conformance/interfaces/sem_wait
    48	./o[  183.014911] mmc1: sdhci: ============================================
    pt/ltp/testcases/open_posix_testsuite/conformance/interfaces/pth[  183.014912] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f1d000, LEN 0x0000, Attr=0x21
    read_mutexattr_init
    64	./opt/ltp/testcases/open_posix_testsuite[  183.014915] mmc1: sdhci: 8c171220c: DMA 0x00000008c2f2d000, LEN 0x6000, Attr=0x21
    /conformance/interfaces/pthread_barrier_destroy
    44	./opt/ltp/te[  183.014917] mmc1: sdhci: 8c1712218: DMA 0x00000008c326f000, LEN 0x1000, Attr=0x21
    [  183.014920] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f33000, LEN 0xa000, Attr=0x21
    188	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  183.014922] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    aces/nanosleep
    24	./opt/ltp/testcases/open_posix_testsuite/conf[  183.020927] mmc1: ADMA error: 0x02000002
    ormance/interfaces/sched_rr_get_interval/speculative
    92	./opt/l[  183.020929] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    tp/testcases/open_posix_testsuite/conformance/interfaces/sched_r[  183.020931] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    r_get_interval
    128	./opt/ltp/testcases/open_posix_testsuite/con[  183.020934] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    formance/interfaces/sem_post
    48	./opt/ltp/testcases/open_posix_[  183.020936] mmc1: sdhci: Argument:  0x00042e00 | Trn mode: 0x0000003b
    testsuite/conformance/interfaces/pthread_attr_getscope
    28	./opt[  183.020938] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    /ltp/testcases/open_posix_testsuite/conformance/interfaces/testf[  183.020940] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    rmw
    28	./opt/ltp/testcases/open_posix_testsuite/conformance/int[  183.020942] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    erfaces/mq_timedsend/speculative
    436	./opt/ltp/testcases/open_p[  183.020945] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    osix_testsuite/conformance/interfaces/mq_timedsend
    60	./opt/ltp[  183.020947] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    /testcases/open_posix_testsuite/conformance/interfaces/pthread_s[  183.020949] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    etspecific
    44	./opt/ltp/testcases/open_posix_testsuite/conforma[  183.020951] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    nce/interfaces/getpid
    172	./opt/ltp/testcases/open_posix_testsu[  183.020954] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    ite/conformance/interfaces/pthread_cond_wait
    44	./opt/ltp/testc[  183.020956] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ases/open_posix_testsuite/conformance/interfaces/difftime
    180	.[  183.020958] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/p[  183.020960] mmc1: sdhci: Host ctl2: 0x00000c00
    thread_mutex_trylock
    24	./opt/ltp/testcases/open_posix_testsuit[  183.020962] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    e/conformance/interfaces/sched_getparam/speculative
    124	./opt/l[  183.020964] mmc1: sdhci: ============================================
    tp/testcases/open_posix_testsuite/conformance/interfaces/sched_g[  183.020965] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f1d000, LEN 0x0000, Attr=0x21
    etparam
    60	./opt/ltp/testcases/open_posix_testsuite/conformance[  183.020968] mmc1: sdhci: 8c171220c: DMA 0x00000008c2f2d000, LEN 0x6000, Attr=0x21
    /interfaces/pthread_rwlockattr_init
    88	./opt/ltp/testcases/open[  183.020970] mmc1: sdhci: 8c1712218: DMA 0x00000008c326f000, LEN 0x1000, Attr=0x21
    _posix_testsuite/conformance/interfaces/clock_getcpuclockid
    204[  183.020972] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f33000, LEN 0xa000, Attr=0x21
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  183.020975] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    /sem_unlink
    100	./opt/ltp/testcases/open_posix_testsuite/confor[  183.275305] mmc1: ADMA error: 0x02000002
    mance/interfaces/pthread_spin_lock
    32	./opt/ltp/testcases/open_[  183.275313] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    posix_testsuite/conformance/interfaces/pthread_cond_destroy/spec[  183.275315] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    ulative
    124	./opt/ltp/testcases/open_posix_testsuite/conformanc[  183.275317] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    168	./opt/ltp/testcases/open_[  183.275320] mmc1: sdhci: Argument:  0x00043500 | Trn mode: 0x0000003b
    posix_testsuite/conformance/interfaces/sem_init
    60	./opt/ltp/te[  183.275322] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    stcases/open_posix_testsuite/conformance/interfaces/pthread_spin[  183.275325] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    _destroy
    72	./opt/ltp/testcases/open_posix_testsuite/conformanc[  183.275327] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    e/interfaces/pthread_attr_init
    32	./opt/ltp/testcases/open_posi[  183.275330] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    x_testsuite/conformance/interfaces/mktime
    168	./opt/ltp/testcas[  183.275332] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    es/open_posix_testsuite/conformance/interfaces/pthread_rwlock_ti[  183.275334] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    medrdlock
    100	./opt/ltp/testcases/open_posix_testsuite/conforma[  183.275336] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    nce/interfaces/sem_getvalue
    120	./opt/ltp/testcases/open_posix_[  183.275339] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    testsuite/conformance/interfaces/sigwaitinfo
    52	./opt/ltp/testc[  183.275341] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ases/open_posix_testsuite/conformance/interfaces/timer_getoverru[  183.275344] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    n/speculative
    160	./opt/ltp/testcases/open_posix_testsuite/conf[  183.275346] mmc1: sdhci: Host ctl2: 0x00000c00
    ormance/interfaces/timer_getoverrun
    352	./opt/ltp/testcases/ope[  183.275348] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712248
    n_posix_testsuite/conformance/interfaces/fork
    56	./opt/ltp/test[  183.275351] mmc1: sdhci: ============================================
    cases/open_posix_testsuite/conformance/interfaces/fsync
    120	./o[  183.275352] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f40000, LEN 0x1000, Attr=0x21
    pt/ltp/testcases/open_posix_testsuite/conformance/interfaces/pth[  183.275355] mmc1: sdhci: 8c171220c: DMA 0x00000008c3276000, LEN 0x1000, Attr=0x21
    read_attr_setstack
    72	./opt/ltp/testcases/open_posix_testsuite/[  183.275358] mmc1: sdhci: 8c1712218: DMA 0x00000008c2f3f000, LEN 0x1000, Attr=0x21
    conformance/interfaces/pthread_spin_trylock
    108	./opt/ltp/testc[  183.275360] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f3e000, LEN 0x1000, Attr=0x21
    ases/open_posix_testsuite/conformance/interfaces/pthread_mutex_u[  183.275362] mmc1: sdhci: 8c1712230: DMA 0x00000008c2f3d000, LEN 0x1000, Attr=0x21
    nlock
    72	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  183.275364] mmc1: sdhci: 8c171223c: DMA 0x00000008c2f42000, LEN 0x0000, Attr=0x21
    nterfaces/aio_error
    80	./opt/ltp/testcases/open_posix_testsuite[  183.275367] mmc1: sdhci: 8c1712248: DMA 0x00000008c2f52000, LEN 0xc000, Attr=0x21
    /conformance/interfaces/sigsuspend
    68	./opt/ltp/testcases/open_[  183.275369] mmc1: sdhci: 8c1712254: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    posix_testsuite/conformance/interfaces/pthread_barrierattr_getps[  183.281381] mmc1: ADMA error: 0x02000002
    hared
    88	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  183.281384] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    nterfaces/pthread_mutexattr_getpshared
    196	./opt/ltp/testcases/[  183.281385] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    open_posix_testsuite/conformance/interfaces/aio_write
    80	./opt/[  183.281388] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    ltp/testcases/open_posix_testsuite/conformance/interfaces/pthrea[  183.281390] mmc1: sdhci: Argument:  0x00043500 | Trn mode: 0x0000003b
    d_rwlockattr_getpshared
    76	./opt/ltp/testcases/open_posix_tests[  183.281392] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    uite/conformance/interfaces/munlock
    92	./opt/ltp/testcases/open[  183.281394] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    _posix_testsuite/conformance/interfaces/sigpause
    116	./opt/ltp/[  183.281396] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    testcases/open_posix_testsuite/conformance/interfaces/aio_suspen[  183.281398] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    d
    180	./opt/ltp/testcases/open_posix_testsuite/conformance/inte[  183.281401] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    rfaces/sigqueue
    84	./opt/ltp/testcases/open_posix_testsuite/con[  183.281403] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    formance/interfaces/sigtimedwait
    148	./opt/ltp/testcases/open_p[  183.281405] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    osix_testsuite/conformance/interfaces/sigwait
    64	./opt/ltp/test[  183.281407] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    cases/open_posix_testsuite/conformance/interfaces/mq_open/specul[  183.281409] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ative
    420	./opt/ltp/testcases/open_posix_testsuite/conformance/[  183.281412] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    interfaces/mq_open
    56	./opt/ltp/testcases/open_posix_testsuite/[  183.281414] mmc1: sdhci: Host ctl2: 0x00000c00
    conformance/interfaces/sigrelse
    72	./opt/ltp/testcases/open_pos[  183.281416] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712248
    ix_testsuite/conformance/interfaces/pthread_condattr_setclock
    2[  183.281418] mmc1: sdhci: ============================================
    84	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  183.281419] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f40000, LEN 0x1000, Attr=0x21
    es/mq_send
    84	./opt/ltp/testcases/open_posix_testsuite/conforma[  183.281422] mmc1: sdhci: 8c171220c: DMA 0x00000008c3276000, LEN 0x1000, Attr=0x21
    nce/interfaces/sem_close
    192	./opt/ltp/testcases/open_posix_tes[  183.281424] mmc1: sdhci: 8c1712218: DMA 0x00000008c2f3f000, LEN 0x1000, Attr=0x21
    tsuite/conformance/interfaces/aio_cancel
    168	./opt/ltp/testcase[  183.281426] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f3e000, LEN 0x1000, Attr=0x21
    s/open_posix_testsuite/conformance/interfaces/pthread_rwlock_tim[  183.281428] mmc1: sdhci: 8c1712230: DMA 0x00000008c2f3d000, LEN 0x1000, Attr=0x21
    edwrlock
    264	./opt/ltp/testcases/open_posix_testsuite/conforman[  183.281431] mmc1: sdhci: 8c171223c: DMA 0x00000008c2f42000, LEN 0x0000, Attr=0x21
    ce/interfaces/pthread_exit
    60	./opt/ltp/testcases/open_posix_te[  183.281433] mmc1: sdhci: 8c1712248: DMA 0x00000008c2f52000, LEN 0xc000, Attr=0x21
    stsuite/conformance/interfaces/pthread_condattr_getclock
    52	./o[  183.281435] mmc1: sdhci: 8c1712254: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    pt/ltp/testcases/open_posix_testsuite/conformance/interfaces/tim[  183.475872] mmc1: ADMA error: 0x02000002
    er_gettime/speculative
    184	./opt/ltp/testcases/open_posix_tests[  183.475877] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    uite/conformance/interfaces/timer_gettime
    72	./opt/ltp/testcase[  183.475880] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    s/open_posix_testsuite/conformance/interfaces/pthread_mutexattr_[  183.475882] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    setprotocol
    156	./opt/ltp/testcases/open_posix_testsuite/confor[  183.475884] mmc1: sdhci: Argument:  0x00043608 | Trn mode: 0x0000003b
    mance/interfaces/sigaltstack
    28	./opt/ltp/testcases/open_posix_[  183.475887] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  183.475890] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    100	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  183.475892] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    aces/pthread_key_create
    72	./opt/ltp/testcases/open_posix_tests[  183.475894] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    uite/conformance/interfaces/pthread_condattr_getpshared
    96	./op[  183.475896] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    t/ltp/testcases/open_posix_testsuite/conformance/interfaces/sign[  183.475898] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    al
    292	./opt/ltp/testcases/open_posix_testsuite/conformance/int[  183.475901] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    erfaces/lio_listio
    380	./opt/ltp/testcases/open_posix_testsuite[  183.475903] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    /conformance/interfaces/sched_setparam
    180	./opt/ltp/testcases/[  183.475905] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    open_posix_testsuite/conformance/interfaces/pthread_detach
    28	.[  183.475907] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/m[  183.475909] mmc1: sdhci: Host ctl2: 0x00000c00
    q_unlink/speculative
    136	./opt/ltp/testcases/open_posix_testsui[  183.475912] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    te/conformance/interfaces/mq_unlink
    96	./opt/ltp/testcases/open[  183.475914] mmc1: sdhci: ============================================
    _posix_testsuite/conformance/interfaces/pthread_setschedparam
    8[  183.475915] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f5f000, LEN 0x4000, Attr=0x21
    0	./opt/ltp/testcases/open_posix_testsuite/conformance/interface[  183.475918] mmc1: sdhci: 8c171220c: DMA 0x00000008c327b000, LEN 0x1000, Attr=0x21
    s/pthread_setcanceltype
    112	./opt/ltp/testcases/open_posix_test[  183.475920] mmc1: sdhci: 8c1712218: DMA 0x00000008c2f63000, LEN 0x0000, Attr=0x21
    suite/conformance/interfaces/pthread_mutex_timedlock
    48	./opt/l[  183.475922] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f73000, LEN 0xb000, Attr=0x21
    tp/testcases/open_posix_testsuite/conformance/interfaces/clock_s[  183.475925] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    ettime/speculative
    308	./opt/ltp/testcases/open_posix_testsuite[  183.481744] mmc1: ADMA error: 0x02000002
    /conformance/interfaces/clock_settime
    88	./opt/ltp/testcases/op[  183.481748] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    en_posix_testsuite/conformance/interfaces/pthread_cond_init
    76	[  183.481750] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    ./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/[  183.481752] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    pthread_cleanup_push
    196	./opt/ltp/testcases/open_posix_testsui[  183.481754] mmc1: sdhci: Argument:  0x00043608 | Trn mode: 0x0000003b
    te/conformance/interfaces/aio_read
    56	./opt/ltp/testcases/open_[  183.481757] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    posix_testsuite/conformance/interfaces/sigismember
    44	./opt/ltp[  183.481759] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    /testcases/open_posix_testsuite/conformance/interfaces/timer_del[  183.481761] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    ete/speculative
    120	./opt/ltp/testcases/open_posix_testsuite/co[  183.481764] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    nformance/interfaces/timer_delete
    48	./opt/ltp/testcases/open_p[  183.481766] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    188[  183.481768] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  183.481770] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    /sem_open
    44	./opt/ltp/testcases/open_posix_testsuite/conforman[  183.481772] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    ce/interfaces/gmtime
    72	./opt/ltp/testcases/open_posix_testsuit[  183.481775] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    e/conformance/interfaces/pthread_mutexattr_setprioceiling
    128	.[  183.481777] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/p[  183.481779] mmc1: sdhci: Host ctl2: 0x00000c00
    thread_mutex_lock
    68	./opt/ltp/testcases/open_posix_testsuite/c[  183.481781] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    onformance/interfaces/pthread_equal
    44	./opt/ltp/testcases/open[  183.481783] mmc1: sdhci: ============================================
    _posix_testsuite/conformance/interfaces/munlockall
    132	./opt/lt[  183.481784] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f5f000, LEN 0x4000, Attr=0x21
    p/testcases/open_posix_testsuite/conformance/interfaces/clock_ge[  183.481786] mmc1: sdhci: 8c171220c: DMA 0x00000008c327b000, LEN 0x1000, Attr=0x21
    tres
    120	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  183.481788] mmc1: sdhci: 8c1712218: DMA 0x00000008c2f63000, LEN 0x0000, Attr=0x21
    nterfaces/pthread_barrier_wait
    232	./opt/ltp/testcases/open_pos[  183.481791] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f73000, LEN 0xb000, Attr=0x21
    ix_testsuite/conformance/interfaces/clock_nanosleep
    52	./opt/lt[  183.481793] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    p/testcases/open_posix_testsuite/conformance/interfaces/pthread_[  183.678046] mmc1: ADMA error: 0x02000002
    attr_getschedparam
    168	./opt/ltp/testcases/open_posix_testsuite[  183.678053] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    /conformance/interfaces/sigprocmask
    28	./opt/ltp/testcases/open[  183.678054] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    _posix_testsuite/conformance/interfaces/mq_getattr/speculative
    [  183.678057] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    128	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  183.678059] mmc1: sdhci: Argument:  0x00043910 | Trn mode: 0x0000003b
    ces/mq_getattr
    132	./opt/ltp/testcases/open_posix_testsuite/con[  183.678061] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    formance/interfaces/pthread_once
    80	./opt/ltp/testcases/open_po[  183.678064] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    six_testsuite/conformance/interfaces/pthread_attr_setstacksize
    [  183.678066] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    28	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  183.678068] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    es/mlockall/speculative
    164	./opt/ltp/testcases/open_posix_test[  183.678070] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    suite/conformance/interfaces/mlockall
    172	./opt/ltp/testcases/o[  183.678073] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    pen_posix_testsuite/conformance/interfaces/shm_unlink
    60	./opt/[  183.678075] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    ltp/testcases/open_posix_testsuite/conformance/interfaces/pthrea[  183.678077] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    d_barrierattr_setpshared
    232	./opt/ltp/testcases/open_posix_tes[  183.678079] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    tsuite/conformance/interfaces/pthread_sigmask
    108	./opt/ltp/tes[  183.678081] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    tcases/open_posix_testsuite/conformance/interfaces/killpg
    128	.[  183.678083] mmc1: sdhci: Host ctl2: 0x00000c00
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/p[  183.678086] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    thread_kill
    52	./opt/ltp/testcases/open_posix_testsuite/conform[  183.678088] mmc1: sdhci: ============================================
    ance/interfaces/timer_settime/speculative
    344	./opt/ltp/testcas[  183.678089] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f81000, LEN 0x0000, Attr=0x21
    es/open_posix_testsuite/conformance/interfaces/timer_settime
    16[  183.678092] mmc1: sdhci: 8c171220c: DMA 0x00000008c2f91000, LEN 0xc000, Attr=0x21
    4	./opt/ltp/testcases/open_posix_testsuite/conformance/interface[  183.678094] mmc1: sdhci: 8c1712218: DMA 0x00000008c3284000, LEN 0x1000, Attr=0x21
    s/sem_timedwait
    96	./opt/ltp/testcases/open_posix_testsuite/con[  183.678097] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f9d000, LEN 0x4000, Attr=0x21
    formance/interfaces/sched_get_priority_max
    92	./opt/ltp/testcas[  183.678099] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    es/open_posix_testsuite/conformance/interfaces/mq_setattr
    28	./[  183.684077] mmc1: ADMA error: 0x02000002
    opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/pt[  183.684079] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    hread_mutexattr_gettype/speculative
    120	./opt/ltp/testcases/ope[  183.684081] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    n_posix_testsuite/conformance/interfaces/pthread_mutexattr_getty[  183.684083] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    pe
    48	./opt/ltp/testcases/open_posix_testsuite/conformance/inte[  183.684086] mmc1: sdhci: Argument:  0x00043910 | Trn mode: 0x0000003b
    rfaces/pthread_barrierattr_destroy
    8	./opt/ltp/testcases/open_p[  183.684088] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    osix_testsuite/conformance/interfaces/access
    52	./opt/ltp/testc[  183.684090] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    ases/open_posix_testsuite/conformance/interfaces/sched_yield
    15[  183.684092] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    6	./opt/ltp/testcases/open_posix_testsuite/conformance/interface[  183.684094] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    s/pthread_cancel
    96	./opt/ltp/testcases/open_posix_testsuite/co[  183.684096] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    nformance/interfaces/sched_getscheduler
    48	./opt/ltp/testcases/[  183.684099] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    open_posix_testsuite/conformance/interfaces/pthread_rwlockattr_s[  183.684101] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    etpshared
    36	./opt/ltp/testcases/open_posix_testsuite/conforman[  183.684103] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    ce/interfaces/pthread_mutex_setprioceiling
    56	./opt/ltp/testcas[  183.684105] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    44	./opt/l[  183.684107] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    tp/testcases/open_posix_testsuite/conformance/interfaces/sigfill[  183.684109] mmc1: sdhci: Host ctl2: 0x00000c00
    set
    60	./opt/ltp/testcases/open_posix_testsuite/conformance/int[  183.684112] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    erfaces/pthread_attr_getdetachstate
    164	./opt/ltp/testcases/ope[  183.684113] mmc1: sdhci: ============================================
    n_posix_testsuite/conformance/interfaces/pthread_cond_signal
    72[  183.684115] mmc1: sdhci: 8c1712200: DMA 0x00000008c2f81000, LEN 0x0000, Attr=0x21
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  183.684117] mmc1: sdhci: 8c171220c: DMA 0x00000008c2f91000, LEN 0xc000, Attr=0x21
    /pthread_mutexattr_destroy
    48	./opt/ltp/testcases/open_posix_te[  183.684119] mmc1: sdhci: 8c1712218: DMA 0x00000008c3284000, LEN 0x1000, Attr=0x21
    stsuite/conformance/interfaces/pthread_attr_getinheritsched
    84	[  183.684121] mmc1: sdhci: 8c1712224: DMA 0x00000008c2f9d000, LEN 0x4000, Attr=0x21
    ./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/[  183.684124] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    sigignore
    28	./opt/ltp/testcases/open_posix_testsuite/conforman[  184.055099] mmc1: ADMA error: 0x02000002
    ce/interfaces/pthread_join/speculative
    204	./opt/ltp/testcases/[  184.055107] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    open_posix_testsuite/conformance/interfaces/pthread_join
    96	./o[  184.055109] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    pt/ltp/testcases/open_posix_testsuite/conformance/interfaces/sch[  184.055112] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    ed_get_priority_min
    48	./opt/ltp/testcases/open_posix_testsuite[  184.055114] mmc1: sdhci: Argument:  0x00043c00 | Trn mode: 0x0000003b
    /conformance/interfaces/pthread_getspecific
    52	./opt/ltp/testca[  184.055117] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    ses/open_posix_testsuite/conformance/interfaces/sem_destroy
    84	[  184.055119] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    ./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/[  184.055121] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    kill
    32	./opt/ltp/testcases/open_posix_testsuite/conformance/in[  184.055123] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    terfaces/asctime
    28	./opt/ltp/testcases/open_posix_testsuite/co[  184.055126] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    nformance/interfaces/mlock/speculative
    128	./opt/ltp/testcases/[  184.055128] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    open_posix_testsuite/conformance/interfaces/mlock
    140	./opt/ltp[  184.055130] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    /testcases/open_posix_testsuite/conformance/interfaces/mq_notify[  184.055133] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    32	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  184.055135] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    aces/time
    80	./opt/ltp/testcases/open_posix_testsuite/conforman[  184.055137] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    ce/interfaces/strftime
    48	./opt/ltp/testcases/open_posix_testsu[  184.055140] mmc1: sdhci: Host ctl2: 0x00000c00
    ite/conformance/interfaces/pthread_mutexattr_getprotocol
    128	./[  184.055142] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/pt[  184.055144] mmc1: sdhci: ============================================
    hread_mutexattr_settype
    28	./opt/ltp/testcases/open_posix_tests[  184.055145] mmc1: sdhci: 8c1712200: DMA 0x00000008c4805000, LEN 0x6000, Attr=0x21
    uite/conformance/interfaces/mq_timedreceive/speculative
    348	./o[  184.055148] mmc1: sdhci: 8c171220c: DMA 0x00000008c3296000, LEN 0x1000, Attr=0x21
    pt/ltp/testcases/open_posix_testsuite/conformance/interfaces/mq_[  184.055150] mmc1: sdhci: 8c1712218: DMA 0x00000008c480b000, LEN 0x0000, Attr=0x21
    timedreceive
    32	./opt/ltp/testcases/open_posix_testsuite/confor[  184.055153] mmc1: sdhci: 8c1712224: DMA 0x00000008c481b000, LEN 0xa000, Attr=0x21
    mance/interfaces/strcpy
    76	./opt/ltp/testcases/open_posix_tests[  184.055155] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    uite/conformance/interfaces/pthread_barrier_init
    184	./opt/ltp/[  184.061126] mmc1: ADMA error: 0x02000002
    testcases/open_posix_testsuite/conformance/interfaces/mq_receive[  184.061129] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    192	./opt/ltp/testcases/open_posix_testsuite/conformance/inter[  184.061130] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    faces/pthread_cond_broadcast
    32	./opt/ltp/testcases/open_posix_[  184.061133] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    testsuite/conformance/interfaces/localtime
    56	./opt/ltp/testcas[  184.061135] mmc1: sdhci: Argument:  0x00043c00 | Trn mode: 0x0000003b
    es/open_posix_testsuite/conformance/interfaces/sighold
    76	./opt[  184.061137] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    /ltp/testcases/open_posix_testsuite/conformance/interfaces/pthre[  184.061140] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    ad_rwlock_wrlock
    84	./opt/ltp/testcases/open_posix_testsuite/co[  184.061142] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    nformance/interfaces/pthread_spin_unlock
    88	./opt/ltp/testcases[  184.061144] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    /open_posix_testsuite/conformance/interfaces/sigaddset
    140	./op[  184.061146] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    t/ltp/testcases/open_posix_testsuite/conformance/interfaces/cloc[  184.061148] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    k_gettime
    68	./opt/ltp/testcases/open_posix_testsuite/conforman[  184.061150] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    ce/interfaces/pthread_getschedparam
    92	./opt/ltp/testcases/open[  184.061152] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    _posix_testsuite/conformance/interfaces/pthread_rwlock_init
    32	[  184.061154] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/[  184.061157] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    ctime
    36	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  184.061159] mmc1: sdhci: Host ctl2: 0x00000c00
    nterfaces/strchr
    32	./opt/ltp/testcases/open_posix_testsuite/co[  184.061161] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    nformance/interfaces/strlen
    60	./opt/ltp/testcases/open_posix_t[  184.061163] mmc1: sdhci: ============================================
    estsuite/conformance/interfaces/pthread_rwlockattr_destroy
    60	.[  184.061164] mmc1: sdhci: 8c1712200: DMA 0x00000008c4805000, LEN 0x6000, Attr=0x21
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/p[  184.061166] mmc1: sdhci: 8c171220c: DMA 0x00000008c3296000, LEN 0x1000, Attr=0x21
    thread_attr_destroy
    332	./opt/ltp/testcases/open_posix_testsuit[  184.061169] mmc1: sdhci: 8c1712218: DMA 0x00000008c480b000, LEN 0x0000, Attr=0x21
    e/conformance/interfaces/pthread_create
    64	./opt/ltp/testcases/[  184.061171] mmc1: sdhci: 8c1712224: DMA 0x00000008c481b000, LEN 0xa000, Attr=0x21
    open_posix_testsuite/conformance/interfaces/pthread_rwlock_tryrd[  184.061173] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    lock
    108	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  184.304046] mmc1: ADMA error: 0x02000002
    nterfaces/raise
    72	./opt/ltp/testcases/open_posix_testsuite/con[  184.304054] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    formance/interfaces/sigpending
    48	./opt/ltp/testcases/open_posi[  184.304056] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    x_testsuite/conformance/interfaces/pthread_condattr_init
    588	./[  184.304059] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/mm[  184.304061] mmc1: sdhci: Argument:  0x00043e00 | Trn mode: 0x0000003b
    ap
    29332	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  184.304064] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    nterfaces
    32	./opt/ltp/testcases/open_posix_testsuite/conforman[  184.304066] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    ce/definitions/unistd_h
    784	./opt/ltp/testcases/open_posix_test[  184.304068] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    suite/conformance/definitions/signal_h
    176	./opt/ltp/testcases/[  184.304071] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    open_posix_testsuite/conformance/definitions/sched_h
    96	./opt/l[  184.304073] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    tp/testcases/open_posix_testsuite/conformance/definitions/sys/sh[  184.304075] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    m_h
    200	./opt/ltp/testcases/open_posix_testsuite/conformance/de[  184.304078] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    finitions/sys/mman_h
    300	./opt/ltp/testcases/open_posix_testsui[  184.304080] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    340	./opt/ltp/testcases/open_pos[  184.304082] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ix_testsuite/conformance/definitions/pthread_h
    420	./opt/ltp/te[  184.304085] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    stcases/open_posix_testsuite/conformance/definitions/time_h
    76	[  184.304087] mmc1: sdhci: Host ctl2: 0x00000c00
    ./opt/ltp/testcases/open_posix_testsuite/conformance/definitions[  184.304089] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    /aio_h
    72	./opt/ltp/testcases/open_posix_testsuite/conformance/[  184.304091] mmc1: sdhci: ============================================
    definitions/errno_h
    128	./opt/ltp/testcases/open_posix_testsuit[  184.304092] mmc1: sdhci: 8c1712200: DMA 0x00000008c4826000, LEN 0x0000, Attr=0x21
    e/conformance/definitions/mqueue_h
    2336	./opt/ltp/testcases/ope[  184.304095] mmc1: sdhci: 8c171220c: DMA 0x00000008c329b000, LEN 0x1000, Attr=0x21
    48	./opt/ltp/testcase[  184.304097] mmc1: sdhci: 8c1712218: DMA 0x00000008c4836000, LEN 0x0000, Attr=0x21
    s/open_posix_testsuite/conformance/behavior/timers
    52	./opt/ltp[  184.304100] mmc1: sdhci: 8c1712224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    /testcases/open_posix_testsuite/conformance/behavior/WIFEXITED
    [  184.310067] mmc1: ADMA error: 0x02000002
    108	./opt/ltp/testcases/open_posix_testsuite/conformance/behavio[  184.310070] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    r
    31784	./opt/ltp/testcases/open_posix_testsuite/conformance
    7[  184.310072] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    6	./opt/ltp/testcases/open_posix_testsuite/Documentation
    44	./o[  184.310074] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    pt/ltp/testcases/open_posix_testsuite/include
    28	./opt/ltp/test[  184.310076] mmc1: sdhci: Argument:  0x00043e00 | Trn mode: 0x0000003b
    cases/open_posix_testsuite/scripts
    32	./opt/ltp/testcases/open_[  184.310079] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    posix_testsuite/bin
    12	./opt/ltp/testcases/open_posix_testsuite[  184.310081] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    /stress/timers
    24	./opt/ltp/testcases/open_posix_testsuite/stre[  184.310083] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    ss/signals
    68	./opt/ltp/testcases/open_posix_testsuite/stress/m[  184.310085] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    queues
    88	./opt/ltp/testcases/open_posix_testsuite/stress/threa[  184.310087] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    ds/pthread_cond_timedwait
    56	./opt/ltp/testcases/open_posix_tes[  184.310090] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    tsuite/stress/threads/pthread_mutex_init
    68	./opt/ltp/testcases[  184.310092] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    /open_posix_testsuite/stress/threads/pthread_self
    76	./opt/ltp/[  184.310094] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  184.310096] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    48	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthr[  184.310098] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    ead_mutex_trylock
    64	./opt/ltp/testcases/open_posix_testsuite/s[  184.310100] mmc1: sdhci: Host ctl2: 0x00000c00
    tress/threads/sem_init
    44	./opt/ltp/testcases/open_posix_testsu[  184.310102] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    ite/stress/threads/sem_getvalue
    60	./opt/ltp/testcases/open_pos[  184.310104] mmc1: sdhci: ============================================
    ix_testsuite/stress/threads/fork
    60	./opt/ltp/testcases/open_po[  184.310106] mmc1: sdhci: 8c1712200: DMA 0x00000008c4826000, LEN 0x0000, Attr=0x21
    six_testsuite/stress/threads/pthread_exit
    56	./opt/ltp/testcase[  184.310108] mmc1: sdhci: 8c171220c: DMA 0x00000008c329b000, LEN 0x1000, Attr=0x21
    s/open_posix_testsuite/stress/threads/pthread_cond_init
    64	./op[  184.310110] mmc1: sdhci: 8c1712218: DMA 0x00000008c4836000, LEN 0x0000, Attr=0x21
    t/ltp/testcases/open_posix_testsuite/stress/threads/sem_open
    84[  184.310113] mmc1: sdhci: 8c1712224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread[  184.543343] mmc1: ADMA error: 0x02000002
    _mutex_lock
    [  184.543350] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  184.543352] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  184.543354] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  184.543357] mmc1: sdhci: Argument:  0x00043f08 | Trn mode: 0x0000003b
    [  184.543359] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  184.543361] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  184.543364] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  184.543366] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  184.543368] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  184.543371] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  184.543373] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  184.543375] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  184.543378] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  184.543380] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  184.543383] mmc1: sdhci: Host ctl2: 0x00000c00
    [  184.543385] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthre[  184.543387] mmc1: sdhci: ============================================
    ad_once
    [  184.543388] mmc1: sdhci: 8c1712200: DMA 0x00000008c485c000, LEN 0x3000, Attr=0x21
    [  184.543391] mmc1: sdhci: 8c171220c: DMA 0x00000008c32a3000, LEN 0x1000, Attr=0x21
    [  184.543393] mmc1: sdhci: 8c1712218: DMA 0x00000008c485f000, LEN 0x0000, Attr=0x21
    [  184.543396] mmc1: sdhci: 8c1712224: DMA 0x00000008c486f000, LEN 0xc000, Attr=0x21
    [  184.543398] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  184.549316] mmc1: ADMA error: 0x02000002
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthre[  184.549319] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    ad_kill[  184.549321] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  184.549323] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthre[  184.549325] mmc1: sdhci: Argument:  0x00043f08 | Trn mode: 0x0000003b
    ad_cancel
    44	./opt/ltp/testcases/open_posix_testsuite/stress/th[  184.549327] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    reads/pthread_getschedparam
    80	./opt/ltp/testcases/open_posix_t[  184.549330] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    estsuite/stress/threads/pthread_create
    1048	./opt/ltp/testcases[  184.549332] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    28	./opt/ltp/testcases/ope[  184.549334] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    n_posix_testsuite/stress/semaphores
    1188	./opt/ltp/testcases/op[  184.549336] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    44	./opt/ltp/testcases/open_posix_tes[  184.549338] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    tsuite/functional/timers/timers
    36	./opt/ltp/testcases/open_pos[  184.549341] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    ix_testsuite/functional/timers/clocks
    104	./opt/ltp/testcases/o[  184.549343] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    pen_posix_testsuite/functional/timers
    60	./opt/ltp/testcases/op[  184.549345] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    en_posix_testsuite/functional/mqueues
    48	./opt/ltp/testcases/op[  184.549347] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    en_posix_testsuite/functional/threads/condvar
    56	./opt/ltp/test[  184.549349] mmc1: sdhci: Host ctl2: 0x00000c00
    cases/open_posix_testsuite/functional/threads/schedule
    116	./op[  184.549352] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    t/ltp/testcases/open_posix_testsuite/functional/threads
    116	./o[  184.549353] mmc1: sdhci: ============================================
    pt/ltp/testcases/open_posix_testsuite/functional/semaphores
    404[  184.549355] mmc1: sdhci: 8c1712200: DMA 0x00000008c485c000, LEN 0x3000, Attr=0x21
    	./opt/ltp/testcases/open_posix_testsuite/functional
    12	./opt/l[  184.549357] mmc1: sdhci: 8c171220c: DMA 0x00000008c32a3000, LEN 0x1000, Attr=0x21
    tp/testcases/open_posix_testsuite/tools
    33760	./opt/ltp/testcas[  184.549359] mmc1: sdhci: 8c1712218: DMA 0x00000008c485f000, LEN 0x0000, Attr=0x21
    [  184.549362] mmc1: sdhci: 8c1712224: DMA 0x00000008c486f000, LEN 0xc000, Attr=0x21
    [  184.549364] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.340830] mmc1: ADMA error: 0x02000002
    [  188.340837] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.340839] mmc1: sdhci: Sys addr:  0x000000d0 | Version:  0x00001004
    [  188.340842] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.340845] mmc1: sdhci: Argument:  0x00840a20 | Trn mode: 0x0000002b
    [  188.340847] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.340850] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.340852] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.340855] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.340857] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.340859] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.340861] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.340863] mmc1: sdhci: Cmd:       0x0000193a | Max curr: 0x00000000
    [  188.340866] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.340868] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.340871] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.340873] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    [  188.340875] mmc1: sdhci: ============================================
    [  188.340877] mmc1: sdhci: 8c1712200: DMA 0x00000008c2d73000, LEN 0x0000, Attr=0x21
    [  188.340880] mmc1: sdhci: 8c171220c: DMA 0x00000008c2d83000, LEN 0x3000, Attr=0x21
    [  188.340882] mmc1: sdhci: 8c1712218: DMA 0x00000008c307b000, LEN 0x1000, Attr=0x21
    [  188.340884] mmc1: sdhci: 8c1712224: DMA 0x00000008c2d86000, LEN 0x6000, Attr=0x21
    [  188.340887] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.454221] mmc1: ADMA error: 0x02000002
    [  188.454227] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.454230] mmc1: sdhci: Sys addr:  0x000000d8 | Version:  0x00001004
    [  188.454232] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.454234] mmc1: sdhci: Argument:  0x008418f8 | Trn mode: 0x0000002b
    [  188.454237] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.454239] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.454241] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.454244] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.454246] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.454248] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.454250] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.454253] mmc1: sdhci: Cmd:       0x0000193a | Max curr: 0x00000000
    [  188.454255] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.454257] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.454259] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.454261] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712218
    [  188.454263] mmc1: sdhci: ============================================
    [  188.454264] mmc1: sdhci: 8c1712200: DMA 0x00000008c2d37000, LEN 0x1000, Attr=0x21
    [  188.454267] mmc1: sdhci: 8c171220c: DMA 0x00000008c2d39000, LEN 0x0000, Attr=0x21
    [  188.454269] mmc1: sdhci: 8c1712218: DMA 0x00000008c2d49000, LEN 0x7000, Attr=0x21
    [  188.454271] mmc1: sdhci: 8c1712224: DMA 0x00000008c1fc0000, LEN 0x3000, Attr=0x21
    [  188.454273] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.715344] mmc1: ADMA error: 0x02000002
    [  188.715353] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.715355] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  188.715357] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.715360] mmc1: sdhci: Argument:  0x00043208 | Trn mode: 0x0000003b
    [  188.715362] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.715365] m
    [  188.715365] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.715367] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.715369] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.715371] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.715373] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.715376] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.715378] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  188.715381] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.715383] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.715385] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.715388] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    [  188.715390] mmc1: sdhci: ============================================
    [  188.715391] mmc1: sdhci: 8c1712200: DMA 0x00000008c48da000, LEN 0x0000, Attr=0x21
    [  188.715394] mmc1: sdhci: 8c171220c: DMA 0x00000008c48ea000, LEN 0x2000, Attr=0x21
    [  188.715396] mmc1: sdhci: 8c1712218: DMA 0x00000008c33b9000, LEN 0x1000, Attr=0x21
    [  188.715399] mmc1: sdhci: 8c1712224: DMA 0x00000008c48ec000, LEN 0xd000, Attr=0x21
    [  188.715401] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.721200] mmc1: ADMA error: 0x02000002
    [  188.721203] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.721205] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  188.721207] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.721209] mmc1: sdhci: Argument:  0x00043208 | Trn mode: 0x0000003b
    [  188.721212] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.721214] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.721216] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.721218] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.721220] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.721223] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.721225] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.721227] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  188.721229] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.721232] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.721233] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.721236] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    [  188.721238] mmc1: sdhci: ============================================
    [  188.721239] mmc1: sdhci: 8c1712200: DMA 0x00000008c48da000, LEN 0x0000, Attr=0x21
    [  188.721241] mmc1: sdhci: 8c171220c: DMA 0x00000008c48ea000, LEN 0x2000, Attr=0x21
    [  188.721244] mmc1: sdhci: 8c1712218: DMA 0x00000008c33b9000, LEN 0x1000, Attr=0x21
    [  188.721246] mmc1: sdhci: 8c1712224: DMA 0x00000008c48ec000, LEN 0xd000, Attr=0x21
    [  188.721248] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.901749] mmc1: ADMA error: 0x02000002
    [  188.901753] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.901755] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  188.901758] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.901760] mmc1: sdhci: Argument:  0x00043000 | Trn mode: 0x0000003b
    [  188.901763] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.901765] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.901767] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.901770] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.901772] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.901774] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.901777] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.901779] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  188.901781] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.901783] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.901785] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.901787] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    [  188.901790] mmc1: sdhci: ============================================
    [  188.901791] mmc1: sdhci: 8c1712200: DMA 0x00000008c48f9000, LEN 0x0000, Attr=0x21
    [  188.901794] mmc1: sdhci: 8c171220c: DMA 0x00000008c4909000, LEN 0x7000, Attr=0x21
    [  188.901796] mmc1: sdhci: 8c1712218: DMA 0x00000008c33ba000, LEN 0x1000, Attr=0x21
    [  188.901799] mmc1: sdhci: 8c1712224: DMA 0x00000008c4910000, LEN 0x8000, Attr=0x21
    [  188.901801] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.907596] mmc1: ADMA error: 0x02000002
    [  188.907598] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.907600] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  188.907602] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.907604] mmc1: sdhci: Argument:  0x00043000 | Trn mode: 0x0000003b
    [  188.907606] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.907608] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.907610] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.907612] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.907614] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.907616] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.907618] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.907620] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  188.907622] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.907625] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.907627] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.907629] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c171220c
    [  188.907631] mmc1: sdhci: ============================================
    [  188.907632] mmc1: sdhci: 8c1712200: DMA 0x00000008c48f9000, LEN 0x0000, Attr=0x21
    [  188.907634] mmc1: sdhci: 8c171220c: DMA 0x00000008c4909000, LEN 0x7000, Attr=0x21
    [  188.907637] mmc1: sdhci: 8c1712218: DMA 0x00000008c33ba000, LEN 0x1000, Attr=0x21
    [  188.907639] mmc1: sdhci: 8c1712224: DMA 0x00000008c4910000, LEN 0x8000, Attr=0x21
    [  188.907641] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.986441] mmc1: ADMA error: 0x02000002
    [  188.986447] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.986449] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  188.986452] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.986454] mmc1: sdhci: Argument:  0x00042f08 | Trn mode: 0x0000003b
    [  188.986456] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.986459] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.986461] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.986464] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.986466] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.986468] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.986470] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.986472] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  188.986474] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.986477] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.986479] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.986481] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  188.986483] mmc1: sdhci: ============================================
    [  188.986484] mmc1: sdhci: 8c1712200: DMA 0x00000008c4918000, LEN 0x1000, Attr=0x21
    [  188.986487] mmc1: sdhci: 8c171220c: DMA 0x00000008c33be000, LEN 0x1000, Attr=0x21
    [  188.986489] mmc1: sdhci: 8c1712218: DMA 0x00000008c4919000, LEN 0x0000, Attr=0x21
    [  188.986492] mmc1: sdhci: 8c1712224: DMA 0x00000008c4929000, LEN 0xd000, Attr=0x21
    [  188.986494] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  188.992131] mmc1: ADMA error: 0x02000002
    [  188.992134] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  188.992136] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  188.992138] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  188.992140] mmc1: sdhci: Argument:  0x00042f08 | Trn mode: 0x0000003b
    [  188.992143] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  188.992145] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  188.992147] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  188.992149] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  188.992151] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  188.992154] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  188.992156] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  188.992158] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  188.992160] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  188.992162] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  188.992164] mmc1: sdhci: Host ctl2: 0x00000c00
    [  188.992167] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  188.992169] mmc1: sdhci: ============================================
    [  188.992170] mmc1: sdhci: 8c1712200: DMA 0x00000008c4918000, LEN 0x1000, Attr=0x21
    [  188.992172] mmc1: sdhci: 8c171220c: DMA 0x00000008c33be000, LEN 0x1000, Attr=0x21
    [  188.992175] mmc1: sdhci: 8c1712218: DMA 0x00000008c4919000, LEN 0x0000, Attr=0x21
    [  188.992177] mmc1: sdhci: 8c1712224: DMA 0x00000008c4929000, LEN 0xd000, Attr=0x21
    [  188.992179] mmc1: sdhci: 8c1712230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  189.069814] mmc1: ADMA error: 0x02000002
    [  189.069819] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  189.069820] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  189.069823] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  189.069825] mmc1: sdhci: Argument:  0x00043308 | Trn mode: 0x0000003b
    [  189.069827] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  189.069830] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  189.069832] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  189.069834] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  189.069836] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  189.069839] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  189.069841] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  189.069843] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  189.069845] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  189.069847] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  189.069849] mmc1: sdhci: Host ctl2: 0x00000c00
    [  189.069852] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c1712224
    [  189.069853] mmc1: sdhci: ============================================
    [  189.069854] mmc1: sdhci: 8c1712200: DMA 0x00000008c4936000, LEN 0x7000, Attr=0x21
    [  189.069857] mmc1: sdhci: 8c171220c: DMA 0x00000008c33bf000, LEN 0x1000, Attr=0x21
    [  189.069859] mmc1: sdhci: 8c1712218: DMA 0x00000008c493d000, LEN 0x0000, Attr=0x21
    [  189.069862] mmc1: sdhci: 8c1712224: DMA 0x00000008c494d000, LEN 0x5000, Attr=0x21
    [  189.069864] mmc1: sdhci: 8c1712230: DMA 0x00000008c4953000, LEN 0x2000, Attr=0x21
    [  189.069866] mmc1: sdhci: 8c171223c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  189.070009] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000040
    [  190.125562] printk: console [ttyS2]: printing thread stopped
    [  190.131217] Mem abort info:
    [  190.134006]   ESR = 0x96000006
    [  190.137054]   EC = 0x25: DABT (current EL), IL = 32 bits
    [  190.142358]   SET = 0, FnV = 0
    [  190.145411]   EA = 0, S1PTW = 0
    [  190.148538] Data abort info:
    [  190.151408]   ISV = 0, ISS = 0x00000006
    [  190.155236]   CM = 0, WnR = 0
    [  190.158201] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008c2c85000
    [  190.164638] [0000000000000040] pgd=00000008c2c7d003, p4d=00000008c2c7d003, pud=00000008c256c003, pmd=0000000000000000
    [  190.175240] Internal error: Oops: 96000006 [#1] PREEMPT_RT SMP
    [  190.181055] Modules linked in:
    [  190.184097] CPU: 0 PID: 149 Comm: kworker/0:1H Not tainted 5.10.65-rt53 #2
    [  190.190953] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [  190.196768] Workqueue: kblockd blk_mq_run_work_fn
    [  190.201464] pstate: 20000005 (nzCv daif -PAN -UAO -TCO BTYPE=--)
    [  190.207452] pc : __blk_rq_map_sg+0x80/0x500
    [  190.211624] lr : mmc_queue_map_sg+0x3c/0x60
    [  190.215793] sp : ffff8000116b39a0
    [  190.219092] x29: ffff8000116b39a0 x28: ffff000841d5a000
    [  190.224387] x27: 0000000000000000 x26: ffff8000116b3a70
    [  190.229683] x25: 0000000000000001 x24: ffff000844952300
    [  190.234977] x23: ffff000841d35280 x22: 000000000001f30a
    [  190.240273] x21: 0000000000000004 x20: ffff000841aa1dd0
    [  190.245567] x19: 0000000000001000 x18: 0000000000000010
    [  190.250862] x17: 0000000000000001 x16: 0000000000000019
    [  190.256157] x15: 000001014a7b22f7 x14: 00000000ffffffff
    [  190.261452] x13: 00000008ffffffff x12: 0000000000000000
    [  190.266747] x11: fffffe0020f24f00 x10: 0000000000007000
    [  190.272041] x9 : 0000000000000004 x8 : ffff000841d35500
    [  190.277337] x7 : 0000000000000001 x6 : 0000000000000000
    [  190.282631] x5 : 0000000000000200 x4 : 0000000000000000
    [  190.287926] x3 : ffff8000116b3a70 x2 : 0000000000000040
    [  190.293220] x1 : fffffe0020f24f00 x0 : 0000000000000040
    [  190.298515] Call trace:
    [  190.300950]  __blk_rq_map_sg+0x80/0x500
    [  190.304772]  mmc_queue_map_sg+0x3c/0x60
    [  190.308593]  mmc_blk_data_prep+0x1a0/0x338
    [  190.312676]  mmc_blk_rw_rq_prep+0x44/0x170
    [  190.316758]  mmc_blk_mq_issue_rq+0x2dc/0x898
    [  190.321011]  mmc_mq_queue_rq+0x118/0x2b0
    [  190.324918]  blk_mq_dispatch_rq_list+0x104/0x708
    [  190.329519]  __blk_mq_sched_dispatch_requests+0x148/0x1d0
    [  190.334902]  blk_mq_sched_dispatch_requests+0x38/0x78
    [  190.339938]  __blk_mq_run_hw_queue+0xc8/0x140
    [  190.344279]  blk_mq_run_work_fn+0x20/0x30
    [  190.348273]  process_one_work+0x1a0/0x328
    [  190.352270]  worker_thread+0x4c/0x420
    [  190.355918]  kthread+0x174/0x198
    [  190.359133]  ret_from_fork+0x10/0x34
    [  190.362698] Code: f9403704 d37c7ea0 2a1503e9 8b000082 (f860688b)
    [  190.368773] ---[ end trace 0000000000000002 ]---
    [  192.131323] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000008
    [  192.140096] Mem abort info:
    [  192.142880]   ESR = 0x96000006
    [  192.145923]   EC = 0x25: DABT (current EL), IL = 32 bits
    [  192.151220]   SET = 0, FnV = 0
    [  192.154262]   EA = 0, S1PTW = 0
    [  192.157391] Data abort info:
    [  192.160257]   ISV = 0, ISS = 0x00000006
    [  192.164080]   CM = 0, WnR = 0
    [  192.167035] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008c2c85000
    [  192.173461] [0000000000000008] pgd=00000008c2c7d003, p4d=00000008c2c7d003, pud=00000008c256c003, pmd=0000000000000000
    [  192.184050] Internal error: Oops: 96000006 [#2] PREEMPT_RT SMP
    [  192.189865] Modules linked in:
    [  192.192907] CPU: 1 PID: 147 Comm: irq/39-46000000 Tainted: G      D           5.10.65-rt53 #2
    [  192.201410] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [  192.207223] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--)
    [  192.213212] pc : skb_release_data+0x84/0x1a0
    [  192.217474] lr : skb_release_all+0x28/0x38
    [  192.221556] sp : ffff8000116ab8e0
    [  192.224855] x29: ffff8000116ab8e0 x28: 0000000000000000
    [  192.230151] x27: ffff0008419bf098 x26: ffff000841af9a00
    [  192.235447] x25: ffff8000110bfc28 x24: ffff8000110bf378
    [  192.240742] x23: 0000000000000001 x22: ffff000842d57e80
    [  192.246037] x21: ffff000841af9a00 x20: ffff000842d57ec0
    [  192.251331] x19: 0000000000000000 x18: 0000000000000002
    [  192.256626] x17: 0000000000000001 x16: 0000000000000019
    [  192.261921] x15: 0000000000000001 x14: 0000000000000000
    [  192.267216] x13: 0000000000000384 x12: 0000000000000000
    [  192.272510] x11: ffff000840368e90 x10: 000000000000001e
    [  192.277805] x9 : 0000000000000002 x8 : 0000000000000000
    [  192.283100] x7 : fffffe0020e99540 x6 : ffff8000110bfb88
    [  192.288395] x5 : ffff000841bf7798 x4 : ffff0008419bf088
    [  192.293689] x3 : ffff000842d57840 x2 : 0000000000000000
    [  192.298984] x1 : 0000000000000640 x0 : 0000000000000000
    [  192.304278] Call trace:
    [  192.306711]  skb_release_data+0x84/0x1a0
    [  192.310619]  skb_release_all+0x28/0x38
    [  192.314355]  kfree_skb+0x30/0x90
    [  192.317569]  __netif_receive_skb_core+0x138/0xde8
    [  192.322258]  __netif_receive_skb_list_core+0xe8/0x210
    [  192.327292]  netif_receive_skb_list_internal+0x18c/0x2a0
    [  192.332588]  napi_complete_done+0xbc/0x208
    [  192.336669]  am65_cpsw_nuss_rx_poll+0x280/0x380
    [  192.341186]  net_rx_action+0x118/0x378
    [  192.344921]  efi_header_end+0x110/0x214
    [  192.348744]  __local_bh_enable_ip+0xcc/0x130
    [  192.352998]  irq_forced_thread_fn+0x80/0xc0
    [  192.357168]  irq_thread+0x150/0x260
    [  192.360642]  kthread+0x174/0x198
    [  192.363857]  ret_from_fork+0x10/0x34
    [  192.367421] Code: 91004294 6b13001f 5400028d f9400280 (f9400401)
    [  192.373497] ---[ end trace 0000000000000003 ]---
    [  192.378264] Kernel panic - not syncing:
    [  192.382084] Oops: Fatal exception in interrupt
    [  192.382167] SMP: stopping secondary CPUs
    [  192.390503] Kernel Offset: 0x80000 from 0xffff800010000000
    [  192.395970] PHYS_OFFSET: 0x80000000
    [  192.399443] CPU features: 0x0040022,20806008
    [  192.403698] Memory Limit: none
    [  192.406741] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
    NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
    NOTICE:  BL31: Built : 19:52:11, Dec 20 2021
    ERROR:   GTC_CNTFID0 is 0! Assuming 200000000 Hz. Fix Bootloader
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
    [    0.000000] Linux version 5.10.65-rt53 (pierrehsieh@jetson-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #2 SMP PREEMPT_RT Tue Feb 15 15:20:00 CST 2022
    [    0.000000] Machine model: Texas Instruments K3 J721E SoC
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] [Firmware Bug]: Kernel image misaligned at boot, please fix your bootloader!
    [    0.000000] OF: reserved mem: OVERLAP DETECTED!
    [    0.000000] vision-apps-c71-memory@aa100000 (0x00000000aa100000--0x00000000af000000) overlaps with r5f-virtual-eth-queues@ac000000 (0x00000000ac000000--0x00000000ac200000)
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a0000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision_apps-r5f-memory@a0100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a1000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a1100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a2000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a2100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a4000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 31 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a4100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a6000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a6100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-dma-memory@a7000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-r5f-memory@a7100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a8100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-dma-memory@a9000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9100000, size 15 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c66-memory@a9100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa000000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-dma-memory@aa000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000aa100000, size 79 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-c71-memory@aa100000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac000000, size 2 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@ac000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000ac200000, size 30 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@ac200000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000b2000000, size 96 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-dma-memory@b2000000, compatible id shared-dma-pool
    [    0.000000] Carveout Heap: regions without no-map are not yet supported
    [    0.000000] OF: reserved mem: node vision_apps_shared-memories compatible matching fail
    [    0.000000] Reserved memory: created DMA memory pool at 0x00000000d8000000, size 576 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-lo@d8000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000880000000, size 1024 MiB
    [    0.000000] OF: reserved mem: initialized node vision-apps-core-heap-memory-hi@880000000, compatible id shared-dma-pool
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
    [    0.000000]   node   0: [mem 0x000000009e800000-0x00000000aeffffff]
    [    0.000000]   node   0: [mem 0x00000000af000000-0x00000000afffffff]
    [    0.000000]   node   0: [mem 0x00000000b0000000-0x00000000b7ffffff]
    [    0.000000]   node   0: [mem 0x00000000b8000000-0x00000000d7ffffff]
    [    0.000000]   node   0: [mem 0x00000000d8000000-0x00000000fbffffff]
    [    0.000000]   node   0: [mem 0x00000000fc000000-0x00000000ffffffff]
    [    0.000000]   node   0: [mem 0x0000000880000000-0x00000008bfffffff]
    [    0.000000]   node   0: [mem 0x00000008c0000000-0x00000008ffffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
    [    0.000000] On node 0 totalpages: 1048576
    [    0.000000]   DMA zone: 8192 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 524288 pages, LIFO batch:63
    [    0.000000]   Normal zone: 8192 pages used for memmap
    [    0.000000]   Normal zone: 524288 pages, LIFO batch:63
    [    0.000000] cma: Reserved 24 MiB at 0x00000000fe800000
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.2
    [    0.000000] percpu: Embedded 18 pages/cpu s34752 r8192 d30784 u73728
    [    0.000000] pcpu-alloc: s34752 r8192 d30784 u73728 alloc=18*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Detected PIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: EL2 vector hardening
    [    0.000000] CPU features: kernel page table isolation forced ON by KASLR
    [    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
    [    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1032192
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/nfs rw rootfstype=nfs root=/dev/nfs rw nfsroot=192.168.5.231:/home/pierre-i3/Desktop/workspace_net_server/net_nfsshare/PSDKv81_targetNFS_Tiny,nolock,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] software IO TLB: mapped [mem 0x00000000d4000000-0x00000000d8000000] (64MB)
    [    0.000000] Memory: 1969216K/4194304K available (10624K kernel code, 1156K rwdata, 4108K rodata, 1728K init, 438K bss, 2200512K reserved, 24576K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU event tracing is enabled.
    [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
    [    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] rcu: 	RCU_SOFTIRQ processing moved to rcuc kthreads.
    [    0.000000] 	No expedited grace period (rcu_normal_after_boot).
    [    0.000000] 	Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 960 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] GICv3: Distributor has no Range Selector support
    [    0.000000] GICv3: 16 PPIs implemented
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x00000008c0030000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008c0040000
    [    0.000000] random: get_random_bytes called from start_kernel+0x320/0x4c8 with crng_init=0
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000000] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008345] Console: colour dummy device 80x25
    [    0.012910] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023578] pid_max: default: 32768 minimum: 301
    [    0.028334] LSM: Security Framework initializing
    [    0.033083] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.040659] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.049455] rcu: Hierarchical SRCU implementation.
    [    0.054574] Platform MSI: msi-controller@1820000 domain created
    [    0.060796] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.070102] EFI services will not be available.
    [    0.074828] smp: Bringing up secondary CPUs ...
    [    0.085773] Detected PIPT I-cache on CPU1
    [    0.089927] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
    [    0.096958] GICv3: CPU1: using allocated LPI pending table @0x00000008c0050000
    [    0.104365] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
    [    0.111086] smp: Brought up 1 node, 2 CPUs
    [    0.115280] SMP: Total of 2 processors activated.
    [    0.120089] CPU features: detected: 32-bit EL0 Support
    [    0.125343] CPU features: detected: CRC32 instructions
    [    0.138750] CPU: All CPU(s) started at EL2
    [    0.142943] alternatives: patching kernel code
    [    0.147981] devtmpfs: initialized
    [    0.157121] KASLR disabled due to lack of seed
    [    0.161748] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.171712] futex hash table entries: 512 (order: 4, 65536 bytes, linear)
    [    0.179176] pinctrl core: initialized pinctrl subsystem
    [    0.184745] DMI not present or invalid.
    [    0.188907] NET: Registered protocol family 16
    [    0.194114] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
    [    0.201383] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.209373] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.217694] thermal_sys: Registered thermal governor 'step_wise'
    [    0.217962] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.231059] ASID allocator initialised with 32768 entries
    [    0.248209] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.255089] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.261946] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.268803] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.276196] cryptd: max_cpu_qlen set to 1000
    [    0.282126] k3-chipinfo 43000014.chipid: Family:J721E rev:SR1.0 JTAGID[0x0bb6402f] Detected
    [    0.290928] vsys_3v3: supplied by evm_12v0
    [    0.295295] vsys_5v0: supplied by evm_12v0
    [    0.299662] vdd_mmc1: supplied by vsys_3v3
    [    0.304135] vdd_sd_dv_alt: supplied by vsys_3v3
    [    0.309248] iommu: Default domain type: Translated
    [    0.314386] SCSI subsystem initialized
    [    0.318495] mc: Linux media interface: v0.10
    [    0.322868] videodev: Linux video capture interface: v2.00
    [    0.328498] pps_core: LinuxPPS API ver. 1 registered
    [    0.333568] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.342905] PTP clock support registered
    [    0.346924] EDAC MC: Ver: 3.0.0
    [    0.350655] FPGA manager framework
    [    0.354173] Advanced Linux Sound Architecture Driver Initialized.
    [    0.360776] clocksource: Switched to clocksource arch_sys_counter
    [    0.367104] VFS: Disk quotas dquot_6.6.0
    [    0.371134] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.380973] NET: Registered protocol family 2
    [    0.385677] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.394286] tcp_listen_portaddr_hash hash table entries: 2048 (order: 5, 131072 bytes, linear)
    [    0.403194] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.411423] TCP bind hash table entries: 32768 (order: 8, 1835008 bytes, linear)
    [    0.420090] TCP: Hash tables configured (established 32768 bind 32768)
    [    0.426996] UDP hash table entries: 2048 (order: 6, 262144 bytes, linear)
    [    0.434166] UDP-Lite hash table entries: 2048 (order: 6, 262144 bytes, linear)
    [    0.441885] NET: Registered protocol family 1
    [    0.446673] RPC: Registered named UNIX socket transport module.
    [    0.452735] RPC: Registered udp transport module.
    [    0.457538] RPC: Registered tcp transport module.
    [    0.462341] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.468924] PCI: CLS 0 bytes, default 64
    [    0.473309] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
    [    0.483576] Initialise system trusted keyrings
    [    0.488213] workingset: timestamp_bits=46 max_order=19 bucket_order=0
    [    0.496715] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.502964] NFS: Registering the id_resolver key type
    [    0.508258] Key type id_resolver registered
    [    0.512542] Key type id_legacy registered
    [    0.516669] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.523530] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.531218] 9p: Installing v9fs 9p2000 file system support
    [    0.556475] Key type asymmetric registered
    [    0.560673] Asymmetric key parser 'x509' registered
    [    0.565685] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
    [    0.573249] io scheduler mq-deadline registered
    [    0.577880] io scheduler kyber registered
    [    0.582927] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
    [    0.589109] pinctrl-single 11c000.pinctrl: 173 pins, size 692
    [    0.597017] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.603275] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.611102] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.619033] arm-smmu-v3 36600000.iommu: ias 48-bit, oas 48-bit (features 0x00001faf)
    [    0.627165] arm-smmu-v3 36600000.iommu: allocated 65536 entries for cmdq
    [    0.634294] arm-smmu-v3 36600000.iommu: allocated 32768 entries for evtq
    [    0.642830] arm-smmu-v3 36600000.iommu: msi_domain absent - falling back to wired irqs
    [    0.655669] brd: module loaded
    [    0.662675] loop: module loaded
    [    0.666274] megasas: 07.714.04.00-rc1
    [    0.671180] libphy: Fixed MDIO Bus: probed
    [    0.675853] tun: Universal TUN/TAP device driver, 1.6
    [    0.681254] igbvf: Intel(R) Gigabit Virtual Function Network Driver
    [    0.687668] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
    [    0.693757] sky2: driver version 1.30
    [    0.697960] VFIO - User Level meta-driver version: 0.3
    [    0.703580] i2c /dev entries driver
    [    0.707616] sdhci: Secure Digital Host Controller Interface driver
    [    0.713940] sdhci: Copyright(c) Pierre Ossman
    [    0.718628] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.724970] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    0.732102] optee: probing for conduit method.
    [    0.736669] optee: revision 3.12 (3d47a131)
    [    0.736929] optee: initialized driver
    [    0.745824] NET: Registered protocol family 17
    [    0.750465] 9pnet: Installing 9P2000 support
    [    0.754861] Key type dns_resolver registered
    [    0.759386] printk: bootconsole [ns16550a0]: printing thread started
    [    0.759411] Loading compiled-in X.509 certificates
    [    0.763473] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
    [    0.763568] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
    [    0.765221] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0015 '21.9.1--v2021.09a (Terrific Lla')
    [    0.781327] random: fast init done
    [    0.802724] printk: console [ttyS2]: printing thread started
    [    0.802729] printk: console [ttyS2] enabled
    [    0.802731] printk: bootconsole [ns16550a0] disabled
    [    0.802742] printk: bootconsole [ns16550a0]: printing thread stopped
    [    0.808840] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 26, base_baud = 3000000) is a 8250
    [    0.816828] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 27, base_baud = 3000000) is a 8250
    [    0.824825] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
    [    0.824831] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled
    [    0.824834] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled
    [    0.824837] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled
    [    0.883293] scsi host0: ufshcd
    [    0.924785] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.924794] libphy: 46000f00.mdio: probed
    [    0.925963] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    0.926008] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    0.927030] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0
    [    0.927811] mmc0: CQHCI version 5.10
    [    0.928146] mmc1: CQHCI version 5.10
    [    0.933300] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
    [    0.933588] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
    [    0.933865] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
    [    0.934143] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
    [    0.934403] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
    [    0.934989] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
    [    0.936743] ti-udma 31150000.dma-controller: Channels: 84 (tchan: 42, rchan: 42, gp-rflow: 16)
    [    0.940867] spi-nor spi0.0: mt35xu02g (262144 Kbytes)
    [    0.969226] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
    [    0.969464] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
    [    0.984789] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    0.984797] libphy: 46000f00.mdio: probed
    [    0.985979] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
    [    0.986026] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 quirks:00000000
    [    0.986934] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
    [    0.987382] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
    [    0.987386] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
    [    0.992824] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:0
    [    0.993855] debugfs: Directory 'pd:27' with parent 'pm_genpd' already present!
    [    0.993888] debugfs: Directory 'pd:26' with parent 'pm_genpd' already present!
    [    0.995170] debugfs: Directory 'pd:242' with parent 'pm_genpd' already present!
    [    0.995198] debugfs: Directory 'pd:241' with parent 'pm_genpd' already present!
    [    0.995217] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
    [    0.995236] debugfs: Directory 'pd:239' with parent 'pm_genpd' already present!
    [    1.010171] mmc1: new high speed SDHC card at address aaaa
    [    1.010540] mmcblk1: mmc1:aaaa SL16G 14.8 GiB
    [    1.013338]  mmcblk1: p1 p2
    [    1.051789] mmc0: Command Queue Engine enabled
    [    1.051796] mmc0: new HS200 MMC card at address 0001
    [    1.052088] mmcblk0: mmc0:0001 S0J57X 29.6 GiB
    [    1.052204] mmcblk0boot0: mmc0:0001 S0J57X partition 1 31.5 MiB
    [    1.052322] mmcblk0boot1: mmc0:0001 S0J57X partition 2 31.5 MiB
    [    1.052435] mmcblk0rpmb: mmc0:0001 S0J57X partition 3 4.00 MiB, chardev (237:0)
    [    1.053189]  mmcblk0: p1 p2
    [    1.293311] cdns-ufshcd 4e84000.ufs: link startup failed 1
    [    1.293318] cdns-ufshcd 4e84000.ufs: UFS Host state=0
    [    1.293320] cdns-ufshcd 4e84000.ufs: outstanding reqs=0x0 tasks=0x0
    [    1.293323] cdns-ufshcd 4e84000.ufs: saved_err=0x0, saved_uic_err=0x0
    [    1.293326] cdns-ufshcd 4e84000.ufs: Device power mode=1, UIC link state=0
    [    1.293328] cdns-ufshcd 4e84000.ufs: PM in progress=0, sys. suspended=0
    [    1.293331] cdns-ufshcd 4e84000.ufs: Auto BKOPS=0, Host self-block=0
    [    1.293333] cdns-ufshcd 4e84000.ufs: Clk gate=1
    [    1.293335] cdns-ufshcd 4e84000.ufs: last_hibern8_exit_tstamp at 0 us, hibern8_exit_cnt=0
    [    1.293338] cdns-ufshcd 4e84000.ufs: last intr at 1183422 us, last intr status=0x404
    [    1.293341] cdns-ufshcd 4e84000.ufs: error handling flags=0x0, req. abort count=0
    [    1.293343] cdns-ufshcd 4e84000.ufs: hba->ufs_version=0x210, Host capabilities=0x1587031f, caps=0x0
    [    1.293346] cdns-ufshcd 4e84000.ufs: quirks=0x0, dev. quirks=0x0
    [    1.293348] cdns-ufshcd 4e84000.ufs: clk: core_clk, rate: 250000000
    [    1.293351] cdns-ufshcd 4e84000.ufs: clk: phy_clk, rate: 19200000
    [    1.293353] cdns-ufshcd 4e84000.ufs: clk: ref_clk, rate: 19200000
    [    1.293355] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[0, 0], lane[0, 0], pwr[INVALID MODE, INVALID MODE], rate = 0
    [    1.293375] host_regs: 00000000: 1587031f 00000000 00000210 00000000
    [    1.293378] host_regs: 00000010: 00000000 00000000 00000000 00000000
    [    1.293380] host_regs: 00000020: 00000000 00000470 00000000 00000000
    [    1.293383] host_regs: 00000030: 00000008 00000001 00000000 00000000
    [    1.293385] host_regs: 00000040: 00000000 00000000 00000000 00000000
    [    1.293387] host_regs: 00000050: 00000000 00000000 00000000 00000000
    [    1.293389] host_regs: 00000060: 00000000 00000000 00000000 00000000
    [    1.293392] host_regs: 00000070: 00000000 00000000 00000000 00000000
    [    1.293394] host_regs: 00000080: 00000000 00000000 00000000 00000000
    [    1.293396] host_regs: 00000090: 00000000 00000000 00000000 00000000
    [    1.293399] cdns-ufshcd 4e84000.ufs: No record of pa_err
    [    1.293401] cdns-ufshcd 4e84000.ufs: No record of dl_err
    [    1.293404] cdns-ufshcd 4e84000.ufs: No record of nl_err
    [    1.293406] cdns-ufshcd 4e84000.ufs: No record of tl_err
    [    1.293408] cdns-ufshcd 4e84000.ufs: No record of dme_err
    [    1.293410] cdns-ufshcd 4e84000.ufs: No record of auto_hibern8_err
    [    1.293412] cdns-ufshcd 4e84000.ufs: No record of fatal_err
    [    1.293414] cdns-ufshcd 4e84000.ufs: link_startup_fail[0] = 0x1 at 1184538 us
    [    1.293417] cdns-ufshcd 4e84000.ufs: No record of resume_fail
    [    1.293420] cdns-ufshcd 4e84000.ufs: No record of suspend_fail
    [    1.293422] cdns-ufshcd 4e84000.ufs: No record of dev_reset
    [    1.293424] cdns-ufshcd 4e84000.ufs: No record of host_reset
    [    1.293426] cdns-ufshcd 4e84000.ufs: No record of task_abort
    [    1.303012] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
    [    1.305529] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
    [    5.390246] am65-cpsw-nuss 46000000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    [    5.412789] Sending DHCP requests ., OK
    [    6.424818] IP-Config: Got DHCP answer from 192.168.5.1, my address is 192.168.5.89
    [    6.424823] IP-Config: Complete:
    [    6.424824]      device=eth0, hwaddr=50:51:a9:8e:61:50, ipaddr=192.168.5.89, mask=255.255.255.0, gw=192.168.5.1
    [    6.424829]      host=192.168.5.89, domain=, nis-domain=(none)
    [    6.424831]      bootserver=0.0.0.0, rootserver=192.168.5.231, rootpath=
    [    6.424833]      nameserver0=192.168.5.20, nameserver1=192.168.1.1, nameserver2=168.95.1.1
    [    6.430219] ALSA device list:
    [    6.430223]   No soundcards found.
    [    6.438719] VFS: Mounted root (nfs filesystem) on device 0:20.
    [    6.438858] devtmpfs: mounted
    [    6.439612] Freeing unused kernel memory: 1728K
    INIT: [    6.456852] Run /sbin/init as init process
    version 2.96 booting
    hwclock: can't open '/dev/misc/rtc': No such file or directory
    Mon Dec 20 21:29:46 UTC 2021
    [    7.042114] random: dd: uninitialized urandom read (512 bytes read)
    INIT: Entering runlevel: 5
    NOT configuring network interfaces: / is an NFS mount
    Starting syslogd/klogd: done
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org j7-evm /dev/ttyS2
    Arago 2021.09 j7-evm /dev/ttyS2
    j7-evm login:
     _____                    _____           _         _
                  |___|                    |___|
    j7-evm login: root
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~#
    root@j7-evm:~# mount
    192.168.5.231:/home/pierre-i3/Desktop/workspace_net_server/net_nfsshare/PSDKv81_targetNFS_Tiny on / type nfs (rw,relatime,vers=3,rsize=4096,wsize=4096,namlen=255,hard,nolock,proto=tcp,timeo=600,retrans=2,sec=sys,mountaddr=192.168.5.231,mountvers=3,mountproto=tcp,local_lock=all,addr=192.168.5.231)
    devtmpfs on /dev type devtmpfs (rw,relatime,size=984608k,nr_inodes=246152,mode=755)
    proc on /proc type proc (rw,relatime)
    sysfs on /sys type sysfs (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    tmpfs on /run type tmpfs (rw,nosuid,nodev,mode=755)
    tmpfs on /var/volatile type tmpfs (rw,relatime,size=51200k)
    devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620,ptmxmode=000)
    root@j7-evm:~#
    root@j7-evm:~# ls /dev/
    autofs        log           mmcblk0rpmb   ptyp1         ram1          snd           tty2          tty34         tty49         tty63         ttyp2         vcs
    console       loop-control  mmcblk1       ptyp2         ram10         tee0          tty20         tty35         tty5          tty7          ttyp3         vcs1
    dma_heap      loop0         mmcblk1p1     ptyp3         ram11         teepriv0      tty21         tty36         tty50         tty8          ttyp4         vcsa
    full          loop1         mmcblk1p2     ptyp4         ram12         tty           tty22         tty37         tty51         tty9          ttyp5         vcsa1
    gpiochip0     loop2         mtab          ptyp5         ram13         tty0          tty23         tty38         tty52         ttyS0         ttyp6         vcsu
    gpiochip1     loop3         mtd0          ptyp6         ram14         tty1          tty24         tty39         tty53         ttyS1         ttyp7         vcsu1
    gpiochip2     loop4         mtd0ro        ptyp7         ram15         tty10         tty25         tty4          tty54         ttyS2         ttyp8         vfio
    i2c-0         loop5         mtdblock0     ptyp8         ram2          tty11         tty26         tty40         tty55         ttyS3         ttyp9         zero
    i2c-1         loop6         net           ptyp9         ram3          tty12         tty27         tty41         tty56         ttyS4         ttypa
    i2c-2         loop7         null          ptypa         ram4          tty13         tty28         tty42         tty57         ttyS5         ttypb
    i2c-3         mem           port          ptypb         ram5          tty14         tty29         tty43         tty58         ttyS6         ttypc
    i2c-4         mmcblk0       ptmx          ptypc         ram6          tty15         tty3          tty44         tty59         ttyS7         ttypd
    i2c-5         mmcblk0boot0  ptp0          ptypd         ram7          tty16         tty30         tty45         tty6          ttyS8         ttype
    i2c-6         mmcblk0boot1  ptp1          ptype         ram8          tty17         tty31         tty46         tty60         ttyS9         ttypf
    initctl       mmcblk0p1     pts           ptypf         ram9          tty18         tty32         tty47         tty61         ttyp0         ubi_ctrl
    kmsg          mmcblk0p2     ptyp0         ram0          random        tty19         tty33         tty48         tty62         ttyp1         urandom
    root@j7-evm:~#
    root@j7-evm:~# fdisk -l /dev/mmcblk1
    Disk /dev/mmcblk1: 15 GB, 15931539456 bytes, 31116288 sectors
    486192 cylinders, 4 heads, 16 sectors/track
    Units: sectors of 1 * 512 = 512 bytes
    Device       Boot StartCHS    EndCHS        StartLBA     EndLBA    Sectors  Size Id Type
    /dev/mmcblk1p1 *  1,0,1       128,63,32         2048     264191     262144  128M  c Win95 FAT32 (LBA)
    /dev/mmcblk1p2    129,0,1     857,31,32       264192   31116287   30852096 14.7G 83 Linux
    root@j7-evm:~#
    root@j7-evm:~# cd /tmp/
    root@j7-evm:/var/volatile/tmp# mkdir mmcblk1p1
    root@j7-evm:/var/volatile/tmp# mkdir mmcblk1p2
    root@j7-evm:/var/volatile/tmp# mount /dev/mmcblk1p1 mmcblk1p1/
    root@j7-evm:/var/volatile/tmp# [   77.261648] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   78.507352] random: crng init done
    root@j7-evm:/var/volatile/tmp# cd mmcblk1p1/
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# ls
    SBL_Boot_V1_OK                      atf_optee.appimage                  tiboot3.bin                         tikernelimage_linux.appimage
    SBL_Boot_V2_OK_810+app730_rootk0p2  dtb_opt                             tidtb_linux.appimage                v810_uboot
    app                                 nor_spi_patterns.bin                tifs.bin
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# ls -al
    total 19110
    drwxr-xr-x    6 root     root          2560 Jan  1  1970 .
    drwxrwxrwt    4 root     root            80 Dec 20 21:30 ..
    drwxr-xr-x    2 root     root           512 Feb 15  2022 SBL_Boot_V1_OK
    drwxr-xr-x    2 root     root          1024 Feb 17  2022 SBL_Boot_V2_OK_810+app730_rootk0p2
    -rwxr-xr-x    1 root     root        254868 Feb 17  2022 app
    -rwxr-xr-x    1 root     root        418748 Feb 17  2022 atf_optee.appimage
    drwxr-xr-x    5 root     root           512 Feb 17  2022 dtb_opt
    -rwxr-xr-x    1 root     root           128 Nov  2 11:36 nor_spi_patterns.bin
    -rwxr-xr-x    1 root     root        367855 Feb 15  2022 tiboot3.bin
    -rwxr-xr-x    1 root     root         98188 Feb 18  2022 tidtb_linux.appimage
    -rwxr-xr-x    1 root     root        263083 Feb 15  2022 tifs.bin
    -rwxr-xr-x    1 root     root      18158152 Feb 17  2022 tikernelimage_linux.appimage
    drwxr-xr-x    2 root     root          1024 Feb 17  2022 v810_uboot
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# du
    17780	./SBL_Boot_V1_OK
    20311	./v810_uboot
    19105	./SBL_Boot_V2_OK_810+app730_rootk0p2
    97	./dtb_opt/nfs_psdk810_tiny
    97	./dtb_opt/nfs_psdk730
    292	./dtb_opt
    76594	.
    root@j7-evm:/var/volatile/tmp/mmcblk1p1# cd ..
    root@j7-evm:/var/volatile/tmp# cd -
    /tmp/mmcblk1p1
    total 19110
    20311	./v810_uboot
    292	./dtb_opt
    76594	.
    20311	./v810_uboot
    292	./dtb_opt
    76594	.
    20311	./v810_uboot
    292	./dtb_opt
    76594	.
    root@j7-evm:/var/volatile/tmp# ls
    mmcblk1p1  mmcblk1p2
    root@j7-evm:/var/volatile/tmp# mount /dev/mmcblk1p2 mmcblk1p2/
    [  118.964029] mmc1: ADMA error: 0x02000002
    [  118.964038] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  118.964040] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  118.964043] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  118.964046] mmc1: sdhci: Argument:  0x00c82c10 | Trn mode: 0x0000003b
    [  118.964048] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  118.964051] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  118.964054] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  118.964056] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  118.964058] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  118.964061] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  118.964063] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  118.964066] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  118.964068] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
    [  118.964070] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
    [  118.964073] mmc1: sdhci: Host ctl2: 0x00000c00
    [  118.964075] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  118.964077] mmc1: sdhci: ============================================
    [  118.964079] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2b73000, LEN 0x9000, Attr=0x21
    [  118.964082] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2bcf000, LEN 0x1000, Attr=0x21
    [  118.964085] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2b7c000, LEN 0x0000, Attr=0x21
    [  118.964087] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2b8c000, LEN 0x4000, Attr=0x21
    [  118.964089] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2bd0000, LEN 0x2000, Attr=0x21
    [  118.964092] mmc1: sdhci: 8c19e023c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  118.969858] mmc1: ADMA error: 0x02000002
    [  118.969861] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  118.969862] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  118.969865] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  118.969867] mmc1: sdhci: Argument:  0x00c82c10 | Trn mode: 0x0000003b
    [  118.969869] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  118.969872] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  118.969874] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  118.969876] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  118.969878] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  118.969881] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  118.969883] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  118.969885] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  118.969887] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x0076b27f
    [  118.969889] mmc1: sdhci: Resp[2]:   0x325b5900 | Resp[3]:  0x00000900
    [  118.969891] mmc1: sdhci: Host ctl2: 0x00000c00
    [  118.969894] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  118.969895] mmc1: sdhci: ============================================
    [  118.969897] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2b73000, LEN 0x9000, Attr=0x21
    [  118.969899] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2bcf000, LEN 0x1000, Attr=0x21
    [  118.969901] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2b7c000, LEN 0x0000, Attr=0x21
    [  118.969903] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2b8c000, LEN 0x4000, Attr=0x21
    [  118.969906] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2bd0000, LEN 0x2000, Attr=0x21
    [  118.969908] mmc1: sdhci: 8c19e023c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.117564] mmc1: ADMA error: 0x02000002
    [  119.117570] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.117572] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  119.117575] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.117577] mmc1: sdhci: Argument:  0x00c832a0 | Trn mode: 0x0000003b
    [  119.117579] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.117582] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.117584] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.117587] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.117589] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.117591] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.117593] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.117596] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.117598] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.117600] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.117602] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.117604] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.117607] mmc1: sdhci: ============================================
    [  119.117608] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2bd5000, LEN 0x0000, Attr=0x21
    [  119.117611] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2be5000, LEN 0xf000, Attr=0x21
    [  119.117613] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.123256] mmc1: ADMA error: 0x02000002
    [  119.123259] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.123260] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  119.123263] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.123265] mmc1: sdhci: Argument:  0x00c832a0 | Trn mode: 0x0000003b
    [  119.123267] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.123269] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.123271] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.123274] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.123276] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.123278] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.123280] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.123283] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.123285] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.123287] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.123289] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.123291] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.123293] mmc1: sdhci: ============================================
    [  119.123294] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2bd5000, LEN 0x0000, Attr=0x21
    [  119.123297] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2be5000, LEN 0xf000, Attr=0x21
    [  119.123299] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.302056] mmc1: ADMA error: 0x02000002
    [  119.302061] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.302063] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  119.302065] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.302068] mmc1: sdhci: Argument:  0x00c82928 | Trn mode: 0x0000003b
    [  119.302070] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.302072] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.302075] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.302077] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.302079] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.302081] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.302084] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.302086] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.302088] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.302091] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.302093] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.302095] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.302097] mmc1: sdhci: ============================================
    [  119.302098] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3014000, LEN 0x0000, Attr=0x21
    [  119.302101] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3024000, LEN 0xf000, Attr=0x21
    [  119.302103] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.307705] mmc1: ADMA error: 0x02000002
    [  119.307707] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.307709] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  119.307711] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.307714] mmc1: sdhci: Argument:  0x00c82928 | Trn mode: 0x0000003b
    [  119.307716] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.307718] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.307720] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.307722] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.307724] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.307727] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.307729] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.307731] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.307733] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.307736] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.307738] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.307740] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.307741] mmc1: sdhci: ============================================
    [  119.307743] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3014000, LEN 0x0000, Attr=0x21
    [  119.307745] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3024000, LEN 0xf000, Attr=0x21
    [  119.307747] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.467794] mmc1: ADMA error: 0x02000002
    [  119.467801] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.467803] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  119.467805] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.467808] mmc1: sdhci: Argument:  0x00c82a30 | Trn mode: 0x0000003b
    [  119.467810] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.467812] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.467814] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.467817] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.467819] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.467821] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.467823] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.467825] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.467828] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.467830] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.467832] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.467835] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.467837] mmc1: sdhci: ============================================
    [  119.467838] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3057000, LEN 0x0000, Attr=0x21
    [  119.467841] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3067000, LEN 0xe000, Attr=0x21
    [  119.467843] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.473268] mmc1: ADMA error: 0x02000002
    [  119.473271] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.473273] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  119.473275] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.473278] mmc1: sdhci: Argument:  0x00c82a30 | Trn mode: 0x0000003b
    [  119.473280] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.473282] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.473284] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.473286] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.473288] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.473291] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.473293] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.473295] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.473297] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.473299] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.473301] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.473303] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.473305] mmc1: sdhci: ============================================
    [  119.473306] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3057000, LEN 0x0000, Attr=0x21
    [  119.473309] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3067000, LEN 0xe000, Attr=0x21
    [  119.473311] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.639934] mmc1: ADMA error: 0x02000002
    [  119.639939] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.639941] mmc1: sdhci: Sys addr:  0x000000e0 | Version:  0x00001004
    [  119.639944] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.639946] mmc1: sdhci: Argument:  0x00c82b30 | Trn mode: 0x0000003b
    [  119.639948] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.639950] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.639952] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.639955] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.639957] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.639959] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.639961] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.639964] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.639966] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.639968] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.639970] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.639972] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.639974] mmc1: sdhci: ============================================
    [  119.639975] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3097000, LEN 0x0000, Attr=0x21
    [  119.639978] mmc1: sdhci: 8c19e020c: DMA 0x00000008c30a7000, LEN 0xc000, Attr=0x21
    [  119.639980] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.645077] mmc1: ADMA error: 0x02000002
    [  119.645080] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.645081] mmc1: sdhci: Sys addr:  0x000000e0 | Version:  0x00001004
    [  119.645084] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.645086] mmc1: sdhci: Argument:  0x00c82b30 | Trn mode: 0x0000003b
    [  119.645088] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.645090] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.645092] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.645094] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.645096] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.645099] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.645101] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.645103] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.645105] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.645107] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.645109] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.645111] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.645113] mmc1: sdhci: ============================================
    [  119.645114] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3097000, LEN 0x0000, Attr=0x21
    [  119.645116] mmc1: sdhci: 8c19e020c: DMA 0x00000008c30a7000, LEN 0xc000, Attr=0x21
    [  119.645118] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.811966] mmc1: ADMA error: 0x02000002
    [  119.811972] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.811973] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  119.811976] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.811979] mmc1: sdhci: Argument:  0x00c82d20 | Trn mode: 0x0000003b
    [  119.811981] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.811983] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.811985] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.811988] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.811990] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.811992] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.811994] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.811997] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.811999] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.812001] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.812003] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.812005] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.812007] mmc1: sdhci: ============================================
    [  119.812008] mmc1: sdhci: 8c19e0200: DMA 0x00000008c30f0000, LEN 0x0000, Attr=0x21
    [  119.812011] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3100000, LEN 0xe000, Attr=0x21
    [  119.812013] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.817429] mmc1: ADMA error: 0x02000002
    [  119.817431] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.817433] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  119.817435] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.817437] mmc1: sdhci: Argument:  0x00c82d20 | Trn mode: 0x0000003b
    [  119.817439] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.817442] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.817444] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.817446] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.817448] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.817450] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.817452] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.817455] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.817457] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.817459] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.817461] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.817463] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.817465] mmc1: sdhci: ============================================
    [  119.817466] mmc1: sdhci: 8c19e0200: DMA 0x00000008c30f0000, LEN 0x0000, Attr=0x21
    [  119.817469] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3100000, LEN 0xe000, Attr=0x21
    [  119.817471] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.975425] mmc1: ADMA error: 0x02000002
    [  119.975431] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.975433] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  119.975436] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.975438] mmc1: sdhci: Argument:  0x00c82e20 | Trn mode: 0x0000003b
    [  119.975441] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.975443] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.975445] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.975447] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.975450] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.975452] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.975454] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.975456] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.975459] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.975461] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.975463] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.975465] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.975467] mmc1: sdhci: ============================================
    [  119.975469] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3134000, LEN 0x0000, Attr=0x21
    [  119.975471] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3144000, LEN 0xe000, Attr=0x21
    [  119.975474] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  119.980888] mmc1: ADMA error: 0x02000002
    [  119.980890] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  119.980892] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  119.980895] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  119.980897] mmc1: sdhci: Argument:  0x00c82e20 | Trn mode: 0x0000003b
    [  119.980899] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  119.980901] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  119.980903] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  119.980905] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  119.980907] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  119.980910] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  119.980912] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  119.980915] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  119.980917] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  119.980919] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  119.980921] mmc1: sdhci: Host ctl2: 0x00000c00
    [  119.980923] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  119.980925] mmc1: sdhci: ============================================
    [  119.980926] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3134000, LEN 0x0000, Attr=0x21
    [  119.980928] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3144000, LEN 0xe000, Attr=0x21
    [  119.980931] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  120.137334] mmc1: ADMA error: 0x02000002
    [  120.137339] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  120.137341] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  120.137344] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  120.137346] mmc1: sdhci: Argument:  0x00c82f20 | Trn mode: 0x0000003b
    [  120.137348] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  120.137350] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  120.137353] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  120.137355] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  120.137357] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  120.137359] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  120.137361] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  120.137363] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  120.137366] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  120.137368] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  120.137370] mmc1: sdhci: Host ctl2: 0x00000c00
    [  120.137372] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  120.137374] mmc1: sdhci: ============================================
    [  120.137375] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3174000, LEN 0x0000, Attr=0x21
    [  120.137378] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3184000, LEN 0xe000, Attr=0x21
    [  120.137380] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  120.142800] mmc1: ADMA error: 0x02000002
    [  120.142802] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  120.142804] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  120.142806] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  120.142808] mmc1: sdhci: Argument:  0x00c82f20 | Trn mode: 0x0000003b
    [  120.142810] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  120.142812] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  120.142815] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  120.142817] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  120.142819] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  120.142821] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  120.142823] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  120.142826] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  120.142828] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  120.142830] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  120.142832] mmc1: sdhci: Host ctl2: 0x00000c00
    [  120.142834] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  120.142836] mmc1: sdhci: ============================================
    [  120.142837] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3174000, LEN 0x0000, Attr=0x21
    [  120.142840] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3184000, LEN 0xe000, Attr=0x21
    [  120.142842] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  120.313656] mmc1: ADMA error: 0x02000002
    [  120.313662] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  120.313664] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  120.313667] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  120.313669] mmc1: sdhci: Argument:  0x00c83020 | Trn mode: 0x0000003b
    [  120.313671] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  120.313673] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  120.313675] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  120.313678] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  120.313680] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  120.313682] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  120.313684] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  120.313687] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    Segmentation fault
    [  120.313689] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    malloc_consolidate(): invalid chunk size
    [  120.313691] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  120.313693] mmc1: sdhci: Host ctl2: 0x00000c00
    [  120.313695] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  120.313697] mmc1: sdhci: ============================================
    [  120.313698] mmc1: sdhci: 8c19e0200: DMA 0x00000008c31b6000, LEN 0x0000, Attr=0x21
    [  120.313701] mmc1: sdhci: 8c19e020c: DMA 0x00000008c31c6000, LEN 0xe000, Attr=0x21
    [  120.313703] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  120.319118] mmc1: ADMA error: 0x02000002
    [  120.319120] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  120.319122] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  120.319124] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  120.319126] mmc1: sdhci: Argument:  0x00c83020 | Trn mode: 0x0000003b
    [  120.319128] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  120.319130] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  120.319132] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  120.319134] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  120.319136] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  120.319138] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  120.319141] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  120.319143] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  120.319145] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  120.319147] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  120.319149] mmc1: sdhci: Host ctl2: 0x00000c00
    [  120.319151] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  120.319153] mmc1: sdhci: ============================================
    [  120.319154] mmc1: sdhci: 8c19e0200: DMA 0x00000008c31b6000, LEN 0x0000, Attr=0x21
    [  120.319157] mmc1: sdhci: 8c19e020c: DMA 0x00000008c31c6000, LEN 0xe000, Attr=0x21
    [  120.319159] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  120.486874] mmc1: ADMA error: 0x02000002
    [  120.486880] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  120.486882] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    [  120.486884] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  120.486886] mmc1: sdhci: Argument:  0x00c83120 | Trn mode: 0x0000003b
    [  120.486889] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  120.486891] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  120.486893] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  120.486896] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  120.486898] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  120.486900] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  120.486902] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  120.486904] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  120.486907] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  120.486909] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  120.486911] mmc1: sdhci: Host ctl2: 0x00000c00
    [  120.486913] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  120.486915] mmc1: sdhci: ============================================
    [  120.486917] mmc1: sdhci: 8c19e0200: DMA 0x00000008c31f7000, LEN 0x0000, Attr=0x21
    [  120.486919] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3207000, LEN 0xe000, Attr=0x21
    [  120.486922] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  120.492352] mmc1: ADMA error: 0x02000002
     _____                    _____           _         _
    [  120.492355] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  120.492356] mmc1: sdhci: Sys addr:  0x000000f0 | Version:  0x00001004
    |__|[  120.492359] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
             [  120.492361] mmc1: sdhci: Argument:  0x00c83120 | Trn mode: 0x0000003b
         |___|                    |___|
    [  120.492364] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  120.492366] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  120.492368] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  120.492371] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  120.492373] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  120.492375] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    j7-evm login: [  120.492377] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  120.492379] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  120.492381] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  120.492384] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  120.492386] mmc1: sdhci: Host ctl2: 0x00000c00
    [  120.492388] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  120.492390] mmc1: sdhci: ============================================
    [  120.492391] mmc1: sdhci: 8c19e0200: DMA 0x00000008c31f7000, LEN 0x0000, Attr=0x21
    [  120.492393] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3207000, LEN 0xe000, Attr=0x21
    [  120.492396] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  121.246374] EXT4-fs (mmcblk1p2): recovery complete
    [  121.247059] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
     _____                    _____           _         _
                  |___|                    |___|
    j7-evm login: root
    Last login: Mon Dec 20 21:29:48 UTC 2021 on ttyS2
    root@j7-evm:~#
    /dev/mmcblk1p1 on /var/volatile/tmp/mmcblk1p1 type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
    /dev/mmcblk1p2 on /var/volatile/tmp/mmcblk1p2 type ext4 (rw,relatime)
    root@j7-evm:/var/volatile/tmp# cd mmcblk1p2/
    root@j7-evm:/var/volatile/tmp/mmcblk1p2#
    root@j7-evm:/var/volatile/tmp/mmcblk1p2# ls
    bin      boot     dev      etc      home     include  init     lib      linuxrc  media    mnt      opt      proc     run      sbin     sys      tmp      usr      var
    root@j7-evm:/var/volatile/tmp/mmcblk1p2# ls -al
    total 72
    drwxr-xr-x   19 root     root          4096 Dec 20 21:22 .
    drwxr-xr-x    2 root     root          4096 Dec 20 21:23 bin
    drwxrwxrwx    3 root     root          4096 Feb 17  2022 boot
    drwxr-xr-x    2 root     root          4096 Dec 20 19:53 dev
    drwxr-xr-x   55 root     root          4096 Feb 18  2022 etc
    drwxr-xr-x    3 root     root          4096 Dec 20 19:53 home
    drwxr-xr-x    2 root     root          4096 Dec 20 19:53 include
    lrwxrwxrwx    1 root     root            20 Dec 20 20:05 init -> /lib/systemd/systemd
    drwxr-xr-x    9 root     root          4096 Dec 20 21:21 lib
    lrwxrwxrwx    1 root     root            19 Dec 20 21:22 linuxrc -> /bin/busybox.nosuid
    drwxr-xr-x    3 root     root          4096 Dec 20 19:44 media
    drwxr-xr-x    2 root     root          4096 Dec 20 19:53 mnt
    drwxrwxrwx    5 root     root          4096 Dec 20 19:46 opt
    dr-xr-xr-x    2 root     root          4096 Dec 20 19:53 proc
    drwxr-xr-x    2 root     root          4096 Dec 20 21:23 run
    drwxr-xr-x    2 root     root          4096 Dec 20 21:23 sbin
    dr-xr-xr-x    2 root     root          4096 Dec 20 19:53 sys
    drwxrwxrwt    2 root     root          4096 Dec 20 19:53 tmp
    drwxr-xr-x   11 root     root          4096 Dec 20 21:19 usr
    drwxr-xr-x    8 root     root          4096 Dec 20 19:44 var
    root@j7-evm:/var/volatile/tmp/mmcblk1p2# du
    4	./proc
    4	./include
    440	./lib/modules/5.10.65-rt53/kernel/sound/usb
    40	./lib/modules/5.10.65-rt53/kernel/sound/soc/ti
    72	./lib/modules/5.10.65-rt53/kernel/sound/soc/generic
    712	./lib/modules/5.10.65-rt53/kernel/sound/soc/codecs
    828	./lib/modules/5.10.65-rt53/kernel/sound/soc
    84	./lib/modules/5.10.65-rt53/kernel/sound/core
    1356	./lib/modules/5.10.65-rt53/kernel/sound
    112	./lib/modules/5.10.65-rt53/kernel/lib/raid6
    44	./lib/modules/5.10.65-rt53/kernel/lib/crypto
    12	./lib/modules/5.10.65-rt53/kernel/lib/math
    208	./lib/modules/5.10.65-rt53/kernel/lib
    16	./lib/modules/5.10.65-rt53/kernel/samples/rpmsg
    20	./lib/modules/5.10.65-rt53/kernel/samples
    12	./lib/modules/5.10.65-rt53/kernel/arch/arm64/lib
    168	./lib/modules/5.10.65-rt53/kernel/arch/arm64/crypto
    184	./lib/modules/5.10.65-rt53/kernel/arch/arm64
    188	./lib/modules/5.10.65-rt53/kernel/arch
    20	./lib/modules/5.10.65-rt53/kernel/drivers/phy/freescale
    24	./lib/modules/5.10.65-rt53/kernel/drivers/phy/cadence
    24	./lib/modules/5.10.65-rt53/kernel/drivers/phy/ti
    84	./lib/modules/5.10.65-rt53/kernel/drivers/phy
    24	./lib/modules/5.10.65-rt53/kernel/drivers/misc/uacce
    72	./lib/modules/5.10.65-rt53/kernel/drivers/misc/eeprom
    128	./lib/modules/5.10.65-rt53/kernel/drivers/misc
    148	./lib/modules/5.10.65-rt53/kernel/drivers/soundwire
    16	./lib/modules/5.10.65-rt53/kernel/drivers/clk
    48	./lib/modules/5.10.65-rt53/kernel/drivers/extcon
    140	./lib/modules/5.10.65-rt53/kernel/drivers/scsi/libsas
    180	./lib/modules/5.10.65-rt53/kernel/drivers/scsi/hisi_sas
    480	./lib/modules/5.10.65-rt53/kernel/drivers/scsi/mpt3sas
    880	./lib/modules/5.10.65-rt53/kernel/drivers/scsi
    616	./lib/modules/5.10.65-rt53/kernel/drivers/md
    64	./lib/modules/5.10.65-rt53/kernel/drivers/slimbus
    324	./lib/modules/5.10.65-rt53/kernel/drivers/bluetooth
    124	./lib/modules/5.10.65-rt53/kernel/drivers/remoteproc
    24	./lib/modules/5.10.65-rt53/kernel/drivers/video/backlight
    28	./lib/modules/5.10.65-rt53/kernel/drivers/video
    88	./lib/modules/5.10.65-rt53/kernel/drivers/ssb
    24	./lib/modules/5.10.65-rt53/kernel/drivers/usb/phy
    76	./lib/modules/5.10.65-rt53/kernel/drivers/usb/misc
    24	./lib/modules/5.10.65-rt53/kernel/drivers/usb/roles
    48	./lib/modules/5.10.65-rt53/kernel/drivers/usb/gadget/udc
    320	./lib/modules/5.10.65-rt53/kernel/drivers/usb/gadget/legacy
    712	./lib/modules/5.10.65-rt53/kernel/drivers/usb/gadget/function
    1172	./lib/modules/5.10.65-rt53/kernel/drivers/usb/gadget
    64	./lib/modules/5.10.65-rt53/kernel/drivers/usb/isp1760
    496	./lib/modules/5.10.65-rt53/kernel/drivers/usb/host
    40	./lib/modules/5.10.65-rt53/kernel/drivers/usb/common
    152	./lib/modules/5.10.65-rt53/kernel/drivers/usb/musb
    152	./lib/modules/5.10.65-rt53/kernel/drivers/usb/storage
    188	./lib/modules/5.10.65-rt53/kernel/drivers/usb/dwc3
    120	./lib/modules/5.10.65-rt53/kernel/drivers/usb/typec/tcpm
    212	./lib/modules/5.10.65-rt53/kernel/drivers/usb/typec
    64	./lib/modules/5.10.65-rt53/kernel/drivers/usb/class
    428	./lib/modules/5.10.65-rt53/kernel/drivers/usb/core
    480	./lib/modules/5.10.65-rt53/kernel/drivers/usb/serial
    88	./lib/modules/5.10.65-rt53/kernel/drivers/usb/cdns3
    3664	./lib/modules/5.10.65-rt53/kernel/drivers/usb
    180	./lib/modules/5.10.65-rt53/kernel/drivers/mtd/tests
    184	./lib/modules/5.10.65-rt53/kernel/drivers/mtd
    68	./lib/modules/5.10.65-rt53/kernel/drivers/w1
    32	./lib/modules/5.10.65-rt53/kernel/drivers/soc/ti
    36	./lib/modules/5.10.65-rt53/kernel/drivers/soc
    108	./lib/modules/5.10.65-rt53/kernel/drivers/hwmon
    40	./lib/modules/5.10.65-rt53/kernel/drivers/nfc/s3fwrn5
    44	./lib/modules/5.10.65-rt53/kernel/drivers/nfc
    16	./lib/modules/5.10.65-rt53/kernel/drivers/input/misc
    36	./lib/modules/5.10.65-rt53/kernel/drivers/input/keyboard
    152	./lib/modules/5.10.65-rt53/kernel/drivers/input/touchscreen
    208	./lib/modules/5.10.65-rt53/kernel/drivers/input
    32	./lib/modules/5.10.65-rt53/kernel/drivers/media/spi
    856	./lib/modules/5.10.65-rt53/kernel/drivers/media/tuners
    200	./lib/modules/5.10.65-rt53/kernel/drivers/media/common/videobuf2
    204	./lib/modules/5.10.65-rt53/kernel/drivers/media/common
    48	./lib/modules/5.10.65-rt53/kernel/drivers/media/usb/gspca
    160	./lib/modules/5.10.65-rt53/kernel/drivers/media/usb/uvc
    212	./lib/modules/5.10.65-rt53/kernel/drivers/media/usb
    104	./lib/modules/5.10.65-rt53/kernel/drivers/media/dvb-frontends/cxd2880
    88	./lib/modules/5.10.65-rt53/kernel/drivers/media/dvb-frontends/drx39xyj
    2940	./lib/modules/5.10.65-rt53/kernel/drivers/media/dvb-frontends
    844	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/vxe-vxd
    28	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/cadence
    36	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/ti/j721e-csi2rx
    92	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/ti/cal
    132	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform/ti
    1008	./lib/modules/5.10.65-rt53/kernel/drivers/media/platform
    88	./lib/modules/5.10.65-rt53/kernel/drivers/media/v4l2-core
    136	./lib/modules/5.10.65-rt53/kernel/drivers/media/i2c
    5480	./lib/modules/5.10.65-rt53/kernel/drivers/media
    20	./lib/modules/5.10.65-rt53/kernel/drivers/regulator
    24	./lib/modules/5.10.65-rt53/kernel/drivers/ntb/hw/epf
    28	./lib/modules/5.10.65-rt53/kernel/drivers/ntb/hw
    100	./lib/modules/5.10.65-rt53/kernel/drivers/ntb
    76	./lib/modules/5.10.65-rt53/kernel/drivers/rpmsg
    144	./lib/modules/5.10.65-rt53/kernel/drivers/rtc
    176	./lib/modules/5.10.65-rt53/kernel/drivers/crypto/ccree
    232	./lib/modules/5.10.65-rt53/kernel/drivers/crypto
    200	./lib/modules/5.10.65-rt53/kernel/drivers/nvme/host
    204	./lib/modules/5.10.65-rt53/kernel/drivers/nvme
    12	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/rcar-du
    84	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/panel
    112	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/arm
    56	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/bridge/cadence
    96	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/bridge/synopsys
    288	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm/bridge
    500	./lib/modules/5.10.65-rt53/kernel/drivers/gpu/drm
    504	./lib/modules/5.10.65-rt53/kernel/drivers/gpu
    80	./lib/modules/5.10.65-rt53/kernel/drivers/block
    16	./lib/modules/5.10.65-rt53/kernel/drivers/pwm
    68	./lib/modules/5.10.65-rt53/kernel/drivers/gpio
    24	./lib/modules/5.10.65-rt53/kernel/drivers/irqchip
    20	./lib/modules/5.10.65-rt53/kernel/drivers/watchdog
    76	./lib/modules/5.10.65-rt53/kernel/drivers/fpga
    80	./lib/modules/5.10.65-rt53/kernel/drivers/net/phy
    48	./lib/modules/5.10.65-rt53/kernel/drivers/net/can/dev
    48	./lib/modules/5.10.65-rt53/kernel/drivers/net/can/m_can
    52	./lib/modules/5.10.65-rt53/kernel/drivers/net/can/c_can
    188	./lib/modules/5.10.65-rt53/kernel/drivers/net/can
    748	./lib/modules/5.10.65-rt53/kernel/drivers/net/usb
    332	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/intel/e1000e
    208	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/intel/e1000
    544	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/intel
    1196	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/broadcom/bnx2x
    1464	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/broadcom
    300	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/ti
    72	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet/marvell
    2384	./lib/modules/5.10.65-rt53/kernel/drivers/net/ethernet
    476	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel/iwlwifi/mvm
    216	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel/iwlwifi/dvm
    1152	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel/iwlwifi
    1156	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/intel
    660	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ath/ath10k
    716	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ath
    556	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/b43
    24	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil
    408	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac
    436	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom/brcm80211
    996	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/broadcom
    184	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ti/wl18xx
    404	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ti/wlcore
    592	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/ti
    504	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/marvell/mwifiex
    508	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless/marvell
    3972	./lib/modules/5.10.65-rt53/kernel/drivers/net/wireless
    7548	./lib/modules/5.10.65-rt53/kernel/drivers/net
    36	./lib/modules/5.10.65-rt53/kernel/drivers/iio/common/cros_ec_sensors
    40	./lib/modules/5.10.65-rt53/kernel/drivers/iio/common
    32	./lib/modules/5.10.65-rt53/kernel/drivers/iio/pressure
    24	./lib/modules/5.10.65-rt53/kernel/drivers/iio/buffer
    40	./lib/modules/5.10.65-rt53/kernel/drivers/iio/light
    92	./lib/modules/5.10.65-rt53/kernel/drivers/iio/adc
    232	./lib/modules/5.10.65-rt53/kernel/drivers/iio
    32	./lib/modules/5.10.65-rt53/kernel/drivers/base/regmap
    36	./lib/modules/5.10.65-rt53/kernel/drivers/base
    44	./lib/modules/5.10.65-rt53/kernel/drivers/hid/i2c-hid
    60	./lib/modules/5.10.65-rt53/kernel/drivers/hid/usbhid
    148	./lib/modules/5.10.65-rt53/kernel/drivers/hid
    44	./lib/modules/5.10.65-rt53/kernel/drivers/platform/chrome
    48	./lib/modules/5.10.65-rt53/kernel/drivers/platform
    664	./lib/modules/5.10.65-rt53/kernel/drivers/ata
    44	./lib/modules/5.10.65-rt53/kernel/drivers/power/supply
    48	./lib/modules/5.10.65-rt53/kernel/drivers/power
    24	./lib/modules/5.10.65-rt53/kernel/drivers/rpmsg-kdrv
    76	./lib/modules/5.10.65-rt53/kernel/drivers/char/hw_random
    244	./lib/modules/5.10.65-rt53/kernel/drivers/char/ipmi
    324	./lib/modules/5.10.65-rt53/kernel/drivers/char
    16	./lib/modules/5.10.65-rt53/kernel/drivers/tty/serial/8250
    20	./lib/modules/5.10.65-rt53/kernel/drivers/tty/serial
    24	./lib/modules/5.10.65-rt53/kernel/drivers/tty
    80	./lib/modules/5.10.65-rt53/kernel/drivers/bcma
    40	./lib/modules/5.10.65-rt53/kernel/drivers/mfd
    23124	./lib/modules/5.10.65-rt53/kernel/drivers
    488	./lib/modules/5.10.65-rt53/kernel/crypto
    1064	./lib/modules/5.10.65-rt53/kernel/net/sched
    24	./lib/modules/5.10.65-rt53/kernel/net/llc
    56	./lib/modules/5.10.65-rt53/kernel/net/8021q
    580	./lib/modules/5.10.65-rt53/kernel/net/netfilter
    56	./lib/modules/5.10.65-rt53/kernel/net/bluetooth/hidp
    728	./lib/modules/5.10.65-rt53/kernel/net/bluetooth
    92	./lib/modules/5.10.65-rt53/kernel/net/hsr
    144	./lib/modules/5.10.65-rt53/kernel/net/can
    44	./lib/modules/5.10.65-rt53/kernel/net/rfkill
    836	./lib/modules/5.10.65-rt53/kernel/net/mac80211
    72	./lib/modules/5.10.65-rt53/kernel/net/nfc/nci
    220	./lib/modules/5.10.65-rt53/kernel/net/nfc
    180	./lib/modules/5.10.65-rt53/kernel/net/ipv4/netfilter
    308	./lib/modules/5.10.65-rt53/kernel/net/ipv4
    80	./lib/modules/5.10.65-rt53/kernel/net/802
    64	./lib/modules/5.10.65-rt53/kernel/net/key
    108	./lib/modules/5.10.65-rt53/kernel/net/dsa
    228	./lib/modules/5.10.65-rt53/kernel/net/bridge/netfilter
    572	./lib/modules/5.10.65-rt53/kernel/net/bridge
    80	./lib/modules/5.10.65-rt53/kernel/net/qrtr
    92	./lib/modules/5.10.65-rt53/kernel/net/xfrm
    140	./lib/modules/5.10.65-rt53/kernel/net/ipv6/netfilter
    1100	./lib/modules/5.10.65-rt53/kernel/net/ipv6
    524	./lib/modules/5.10.65-rt53/kernel/net/sctp
    512	./lib/modules/5.10.65-rt53/kernel/net/wireless
    7232	./lib/modules/5.10.65-rt53/kernel/net
    240	./lib/modules/5.10.65-rt53/kernel/fs/fuse
    192	./lib/modules/5.10.65-rt53/kernel/fs/overlayfs
    952	./lib/modules/5.10.65-rt53/kernel/fs/cifs
    56	./lib/modules/5.10.65-rt53/kernel/fs/nfs/blocklayout
    60	./lib/modules/5.10.65-rt53/kernel/fs/nfs
    1764	./lib/modules/5.10.65-rt53/kernel/fs/btrfs
    3212	./lib/modules/5.10.65-rt53/kernel/fs
    35832	./lib/modules/5.10.65-rt53/kernel
    2424	./lib/modules/5.10.65-rt53/extra
    39500	./lib/modules/5.10.65-rt53
    440	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/usb
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/soc/ti
    68	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/soc/generic
    708	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/soc/codecs
    820	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/soc
    84	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound/core
    1348	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/sound
    112	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib/raid6
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib/crypto
    12	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib/math
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/lib
    12	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/samples/rpmsg
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/samples
    12	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/arch/arm64/lib
    168	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/arch/arm64/crypto
    184	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/arch/arm64
    188	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/arch
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/phy/freescale
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/phy/cadence
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/phy/ti
    80	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/phy
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/misc/uacce
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/misc/eeprom
    128	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/misc
    144	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/soundwire
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/clk
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/extcon
    140	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/scsi/libsas
    180	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/scsi/hisi_sas
    480	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/scsi/mpt3sas
    880	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/scsi
    616	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/md
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/slimbus
    320	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/bluetooth
    124	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/remoteproc
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/video/backlight
    28	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/video
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ssb
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/phy
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/misc
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/roles
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget/udc
    320	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget/legacy
    696	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget/function
    1156	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/gadget
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/isp1760
    492	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/host
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/common
    152	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/musb
    152	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/storage
    184	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/dwc3
    120	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/typec/tcpm
    212	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/typec
    60	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/class
    424	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/core
    476	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/serial
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb/cdns3
    3628	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/usb
    180	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/mtd/tests
    184	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/mtd
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/w1
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/soc/ti
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/soc
    108	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hwmon
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nfc/s3fwrn5
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nfc
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input/misc
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input/keyboard
    152	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input/touchscreen
    208	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/input
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/spi
    836	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/tuners
    200	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/common/videobuf2
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/common
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/usb/gspca
    160	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/usb/uvc
    212	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/usb
    104	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/dvb-frontends/cxd2880
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/dvb-frontends/drx39xyj
    2924	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/dvb-frontends
    840	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/vxe-vxd
    28	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/cadence
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/ti/j721e-csi2rx
    88	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/ti/cal
    128	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform/ti
    1000	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/platform
    84	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/v4l2-core
    136	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media/i2c
    5432	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/media
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/regulator
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ntb/hw/epf
    28	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ntb/hw
    100	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ntb
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/rpmsg
    144	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/rtc
    176	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/crypto/ccree
    232	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/crypto
    200	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nvme/host
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/nvme
    12	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/rcar-du
    84	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/panel
    112	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/arm
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/bridge/cadence
    96	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/bridge/synopsys
    288	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm/bridge
    500	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu/drm
    504	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpu
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/block
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/pwm
    68	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/gpio
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/irqchip
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/watchdog
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/fpga
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/phy
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can/dev
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can/m_can
    52	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can/c_can
    188	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/can
    748	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/usb
    332	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/intel/e1000e
    204	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/intel/e1000
    540	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/intel
    1196	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/broadcom/bnx2x
    1464	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/broadcom
    300	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/ti
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet/marvell
    2380	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/ethernet
    476	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel/iwlwifi/mvm
    212	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel/iwlwifi/dvm
    1144	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel/iwlwifi
    1148	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/intel
    660	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ath/ath10k
    712	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ath
    552	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/b43
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/brcm80211/brcmutil
    408	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/brcm80211/brcmfmac
    436	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom/brcm80211
    992	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/broadcom
    180	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ti/wl18xx
    404	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ti/wlcore
    588	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/ti
    500	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/marvell/mwifiex
    504	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless/marvell
    3948	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net/wireless
    7512	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/net
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/common/cros_ec_sensors
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/common
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/pressure
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/buffer
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/light
    92	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio/adc
    228	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/iio
    32	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/base/regmap
    36	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/base
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hid/i2c-hid
    60	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hid/usbhid
    148	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/hid
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/platform/chrome
    48	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/platform
    660	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/ata
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/power/supply
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/power
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/rpmsg-kdrv
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/char/hw_random
    240	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/char/ipmi
    320	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/char
    16	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/tty/serial/8250
    20	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/tty/serial
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/tty
    80	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/bcma
    40	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers/mfd
    22964	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/drivers
    472	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/crypto
    1048	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/sched
    24	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/llc
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/8021q
    572	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/netfilter
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bluetooth/hidp
    728	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bluetooth
    92	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/hsr
    140	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/can
    44	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/rfkill
    832	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/mac80211
    72	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/nfc/nci
    220	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/nfc
    176	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv4/netfilter
    300	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv4
    76	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/802
    64	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/key
    104	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/dsa
    228	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bridge/netfilter
    572	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/bridge
    80	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/qrtr
    92	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/xfrm
    140	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv6/netfilter
    1096	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/ipv6
    520	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/sctp
    512	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net/wireless
    7176	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/net
    240	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/fuse
    192	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/overlayfs
    952	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/cifs
    56	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/nfs/blocklayout
    60	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/nfs
    1760	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs/btrfs
    3208	./lib/modules/5.10.65-rt53-g541ec9a699/kernel/fs
    35580	./lib/modules/5.10.65-rt53-g541ec9a699/kernel
    2424	./lib/modules/5.10.65-rt53-g541ec9a699/extra
    39248	./lib/modules/5.10.65-rt53-g541ec9a699
    78752	./lib/modules
    1112	./lib/firmware/ti-connectivity
    2564	./lib/firmware/intel
    132	./lib/firmware/cadence
    11228	./lib/firmware/pdk-ipc
    1140	./lib/firmware/pru
    616	./lib/firmware/ethfw
    63500	./lib/firmware
    172	./lib/udev/rules.d
    6708	./lib/udev/hwdb.d
    15584	./lib/udev
    8	./lib/modprobe.d
    8	./lib/systemd/journald.conf.d
    8	./lib/systemd/ntp-units.d
    8	./lib/systemd/system.conf.d
    120	./lib/systemd/system-preset
    8	./lib/systemd/logind.conf.d
    4	./lib/systemd/system-shutdown
    4	./lib/systemd/system-sleep
    36	./lib/systemd/network
    176	./lib/systemd/system-generators
    4	./lib/systemd/system/runlevel3.target.wants
    4	./lib/systemd/system/runlevel1.target.wants
    4	./lib/systemd/system/rescue.target.wants
    4	./lib/systemd/system/multi-user.target.wants
    4	./lib/systemd/system/runlevel2.target.wants
    4	./lib/systemd/system/runlevel5.target.wants
    4	./lib/systemd/system/sysinit.target.wants
    4	./lib/systemd/system/timers.target.wants
    4	./lib/systemd/system/reboot.target.wants
    4	./lib/systemd/system/graphical.target.wants
    4	./lib/systemd/system/sockets.target.wants
    4	./lib/systemd/system/local-fs.target.wants
    4	./lib/systemd/system/sound.target.wants
    4	./lib/systemd/system/dbus.target.wants
    4	./lib/systemd/system/poweroff.target.wants
    4	./lib/systemd/system/runlevel4.tar[  151.838351] mmc1: ADMA error: 0x02000002
    [  151.838363] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    get.wants
    8	./lib/systemd/system/user-.slice.d
    840	./lib/syste[  151.838366] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    md/system
    7696	./lib/systemd
    8	./lib/depmod.d
    624	./lib/secur[  151.838369] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  151.838371] mmc1: sdhci: Argument:  0x00c40e08 | Trn mode: 0x0000003b
    [  151.838374] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    ity
    172912	./lib
    4	./tmp
    4	./sys
    4	./var/lib/misc
    4	./var/l[  151.838376] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  151.838379] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  151.838381] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    ib/sudo/lectured
    8	./var/lib/sudo
    8	./var/lib/net-snmp
    8	./va[  151.838383] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    r/lib/alsa
    4	./var/lib/dbus
    4	./var/lib/nfs/statd/sm.bak
    4	./[  151.838386] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  151.838388] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  151.838390] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  151.838393] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  151.838396] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  151.838398] mmc1: sdhci: Host ctl2: 0x00000c00
    [  151.838400] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  151.838402] mmc1: sdhci: ============================================
    [  151.838403] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2d59000, LEN 0x0000, Attr=0x21
    16	./var/lib/nfs/statd
    4	./var/lib/nfs/v4[  151.838406] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2d69000, LEN 0x6000, Attr=0x21
    [  151.838409] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3879000, LEN 0x1000, Attr=0x21
    recovery
    24	./var/lib/nfs
    4	./var/lib/docker/image/overlay2/la[  151.838411] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2d6f000, LEN 0x9000, Attr=0x21
    [  151.838413] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  151.844221] mmc1: ADMA error: 0x02000002
    [  151.844224] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  151.844226] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  151.844228] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    yerdb
    4	./var/lib/docker/image/overlay2/distribution
    4	./var/l[  151.844231] mmc1: sdhci: Argument:  0x00c40e08 | Trn mode: 0x0000003b
    [  151.844233] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    ib/docker/image/overlay2/imagedb/metadata/sha256
    8	./var/lib/do[  151.844236] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  151.844238] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  151.844240] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  151.844242] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  151.844244] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  151.844246] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  151.844249] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  151.844251] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  151.844253] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  151.844255] mmc1: sdhci: Host ctl2: 0x00000c00
    [  151.844257] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  151.844258] mmc1: sdhci: ============================================
    [  151.844259] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2d59000, LEN 0x0000, Attr=0x21
    [  151.844262] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2d69000, LEN 0x6000, Attr=0x21
    [  151.844264] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3879000, LEN 0x1000, Attr=0x21
    4	./var/lib/docker/image/o[  151.844266] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2d6f000, LEN 0x9000, Attr=0x21
    [  151.844268] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  151.991703] mmc1: ADMA error: 0x02000002
    [  151.991710] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  151.991712] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  151.991715] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  151.991717] mmc1: sdhci: Argument:  0x00c41600 | Trn mode: 0x0000003b
    [  151.991720] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  151.991722] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  151.991725] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    verlay2/imagedb/content/sha256
    8	./var/lib/docker/image/overlay[  151.991727] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  151.991729] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    2/imagedb/content
    20	./var/lib/docker/image/overlay2/imagedb
    3[  151.991731] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  151.991733] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  151.991736] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  151.991738] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    6	./var/lib/docker/image/overlay2
    4	./var/lib/docker/image/vfs/[  151.991741] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  151.991743] mmc1: sdhci: Host ctl2: 0x00000c00
    [  151.991745] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  151.991747] mmc1: sdhci: ============================================
    [  151.991748] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2d78000, LEN 0x9000, Attr=0x21
    [  151.991751] mmc1: sdhci: 8c19e020c: DMA 0x00000008c387a000, LEN 0x1000, Attr=0x21
    [  151.991753] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2d81000, LEN 0x0000, Attr=0x21
    [  151.991756] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2d91000, LEN 0x7000, Attr=0x21
    layerdb
    4	./var/lib/docker/image/vfs/distribution
    4	./var/lib/[  151.991758] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  151.997700] mmc1: ADMA error: 0x02000002
    [  151.997703] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  151.997705] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  151.997707] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  151.997709] mmc1: sdhci: Argument:  0x00c41600 | Trn mode: 0x0000003b
    [  151.997712] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  151.997714] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  151.997716] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    docker/image/vfs/imagedb/metadata/sha256
    8	./var/lib/docker/ima[  151.997718] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  151.997721] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  151.997723] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  151.997725] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  151.997727] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  151.997730] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  151.997732] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  151.997734] mmc1: sdhci: Host ctl2: 0x00000c00
    [  151.997736] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    4	./var/lib/docker/image/vfs/imagedb/co[  151.997738] mmc1: sdhci: ============================================
    [  151.997739] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2d78000, LEN 0x9000, Attr=0x21
    [  151.997742] mmc1: sdhci: 8c19e020c: DMA 0x00000008c387a000, LEN 0x1000, Attr=0x21
    [  151.997744] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2d81000, LEN 0x0000, Attr=0x21
    [  151.997746] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2d91000, LEN 0x7000, Attr=0x21
    ntent/sha256
    8	./var/lib/docker/image/vfs/imagedb/content
    20	.[  151.997749] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    36	./var/lib/docker/image/vfs[  152.087095] mmc1: ADMA error: 0x02000002
    76	./var/lib/docker/image
    4	./var/lib/docker/runtimes
    4	./va[  152.087102] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    r/lib/docker/buildkit/executor
    4	./var/lib/docker/buildkit/cont[  152.087104] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    ent/ingest
    8	./var/lib/docker/buildkit/content
    72	./var/lib/do[  152.087107] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    cker/buildkit
    4	./var/lib/docker/tmp
    28	./var/lib/docker/volum[  152.087109] mmc1: sdhci: Argument:  0x00c41408 | Trn mode: 0x0000003b
    [  152.087112] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  152.087114] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    es
    4	./var/lib/docker/swarm
    20	./var/lib/docker/builder
    4	./v[  152.087117] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  152.087119] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  152.087122] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  152.087124] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  152.087126] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  152.087129] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  152.087131] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  152.087133] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  152.087136] mmc1: sdhci: Host ctl2: 0x00000c00
    [  152.087138] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e023c
    ar/lib/docker/containerd/daemon/io.containerd.snapshotter.v1.nat[  152.087140] mmc1: sdhci: ============================================
    [  152.087142] mmc1: sdhci: 8c19e0200: DMA 0x00000008c24dd000, LEN 0x1000, Attr=0x21
    [  152.087145] mmc1: sdhci: 8c19e020c: DMA 0x00000008c27b0000, LEN 0x1000, Attr=0x21
    [  152.087147] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2da8000, LEN 0x9000, Attr=0x21
    [  152.087149] mmc1: sdhci: 8c19e0224: DMA 0x00000008c3846000, LEN 0x1000, Attr=0x21
    ive/snapshots
    8	./var/lib/docker/containerd/daemon/io.container[  152.087152] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2db1000, LEN 0x0000, Attr=0x21
    [  152.087154] mmc1: sdhci: 8c19e023c: DMA 0x00000008c2dc1000, LEN 0x3000, Attr=0x21
    d.snapshotter.v1.native
    4	./var/lib/docker/containerd/daemon/io[  152.087156] mmc1: sdhci: 8c19e0248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    .containerd.content.v1.content/ingest
    8	./var/lib/docker/contai[  152.092763] mmc1: ADMA error: 0x02000002
    nerd/daemon/io.containerd.content.v1.content
    4	./var/lib/docker[  152.092766] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    /containerd/daemon/tmpmounts
    4	./var/lib/docker/containerd/daem[  152.092768] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    on/io.containerd.snapshotter.v1.overlayfs/snapshots
    8	./var/lib[  152.092774] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    /docker/containerd/daemon/io.containerd.snapshotter.v1.overlayfs[  152.092776] mmc1: sdhci: Argument:  0x00c41408 | Trn mode: 0x0000003b
    4	./var/lib/docker/containerd/daemon/io.containerd.runtime.v1.[  152.092778] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    linux
    4	./var/lib/docker/containerd/daemon/io.containerd.runtim[  152.092781] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    e.v2.task
    28	./var/lib/docker/containerd/daemon/io.containerd.m[  152.092783] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    etadata.v1.bolt
    68	./var/lib/docker/containerd/daemon
    72	./var[  152.092785] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    4	./var/lib/docker/trust
    4	./var/lib/do[  152.092787] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    cker/overlay2/l
    8	./var/lib/docker/overlay2
    4	./var/lib/docker[  152.092789] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    /containers
    4	./var/lib/docker/plugins/tmp
    4	./var/lib/docker/[  152.092791] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    plugins/storage/blobs/tmp
    8	./var/lib/docker/plugins/storage/bl[  152.092794] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    obs
    12	./var/lib/docker/plugins/storage
    20	./var/lib/docker/pl[  152.092796] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ugins
    36	./var/lib/docker/network/files
    40	./var/lib/docker/ne[  152.092798] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    twork
    4	./var/lib/docker/vfs
    364	./var/lib/docker
    4	./var/lib[  152.092799] mmc1: sdhci: Host ctl2: 0x00000c00
    /systemd/catalog
    4	./var/lib/systemd/timers
    4	./var/lib/system[  152.092801] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e023c
    d/timesync
    4	./var/lib/systemd/linger
    4	./var/lib/systemd/core[  152.092803] mmc1: sdhci: ============================================
    dump
    28	./var/lib/systemd
    33128	./var/lib/opkg/info
    33880	./v[  152.092804] mmc1: sdhci: 8c19e0200: DMA 0x00000008c24dd000, LEN 0x1000, Attr=0x21
    ar/lib/opkg
    4	./var/lib/arpd
    4	./var/lib/private
    4	./var/lib/[  152.092807] mmc1: sdhci: 8c19e020c: DMA 0x00000008c27b0000, LEN 0x1000, Attr=0x21
    urandom
    34348	./var/lib
    40	./var/cache/ldconfig
    4	./var/cache[  152.092809] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2da8000, LEN 0x9000, Attr=0x21
    /opkg
    4	./var/cache/private
    32	./var/cache/fontconfig
    84	./va[  152.092811] mmc1: sdhci: 8c19e0224: DMA 0x00000008c3846000, LEN 0x1000, Attr=0x21
    r/cache
    4	./var/local
    4	./var/spool/mail
    4	./var/spool/cron
    [  152.092813] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2db1000, LEN 0x0000, Attr=0x21
    4	./var/spool/at/jobs
    4	./var/spool/at/spool
    12	./var/spool/at[  152.092815] mmc1: sdhci: 8c19e023c: DMA 0x00000008c2dc1000, LEN 0x3000, Attr=0x21
    24	./var/spool
    4	./var/backups
    4	./var/volatile
    34472	./var[  152.092818] mmc1: sdhci: 8c19e0248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    6576	./bin
    4	./media/ram
    8	./media
    [  152.225819] mmc1: ADMA error: 0x02000002
    4	./mnt
    [  152.225824] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    4	./run
    [  152.225826] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    4816	./sbin
    [  152.225828] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    4	./dev
    [  152.225831] mmc1: sdhci: Argument:  0x00c41200 | Trn mode: 0x0000003b
    12	./opt/ltp/skips
    [  152.225833] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    28	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  152.225836] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    es/pthread_mutex_destroy/speculative
    144	./opt/ltp/testcases/op[  152.225838] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  152.225840] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    60	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  152.225842] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    ces/pthread_rwlock_destroy
    72	./opt/ltp/testcases/open_posix_te[  152.225845] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  152.225847] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    120	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  152.225849] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    aces/pthread_attr_setinheritsched
    164	./opt/ltp/testcases/open_[  152.225851] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    posix_testsuite/conformance/interfaces/pthread_atfork
    60	./opt/[  152.225854] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    ltp/testcases/open_posix_testsuite/conformance/interfaces/pthrea[  152.225856] mmc1: sdhci: Host ctl2: 0x00000c00
    d_barrierattr_init
    72	./opt/ltp/testcases/open_posix_testsuite/[  152.225858] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    conformance/interfaces/pthread_setcancelstate
    56	./opt/ltp/test[  152.225860] mmc1: sdhci: ============================================
    cases/open_posix_testsuite/conformance/interfaces/pthread_attr_g[  152.225861] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2dc4000, LEN 0x0000, Attr=0x21
    etschedpolicy
    76	./opt/ltp/testcases/open_posix_testsuite/confo[  152.225864] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3848000, LEN 0x1000, Attr=0x21
    rmance/interfaces/pthread_attr_setscope
    148	./opt/ltp/testcases[  152.225866] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2dd4000, LEN 0xf000, Attr=0x21
    /open_posix_testsuite/conformance/interfaces/munmap
    72	./opt/lt[  152.225868] mmc1: sdhci: 8c19e0224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    p/testcases/open_posix_testsuite/conformance/interfaces/pthread_[  152.231653] mmc1: ADMA error: 0x02000002
    condattr_destroy
    72	./opt/ltp/testcases/open_posix_testsuite/co[  152.231656] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    nformance/interfaces/pthread_mutex_getprioceiling
    108	./opt/ltp[  152.231658] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  152.231661] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    112	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  152.231663] mmc1: sdhci: Argument:  0x00c41200 | Trn mode: 0x0000003b
    aces/pthread_rwlock_unlock
    468	./opt/ltp/testcases/open_posix_t[  152.231665] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    estsuite/conformance/interfaces/shm_open
    [  152.231667] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  152.231670] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  152.231672] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  152.231674] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  152.231676] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  152.231678] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  152.231681] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    316	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  152.231683] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ces/pthread_cond_timedwait
    [  152.231685] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    136	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  152.231687] mmc1: sdhci: Host ctl2: 0x00000c00
    ces/pthread_attr_setschedpolicy
    100	./opt/ltp/testcases/open_po[  152.231689] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    six_testsuite/conformance/interfaces/pthread_mutexattr_setpshare[  152.231691] mmc1: sdhci: ============================================
    d
    84	./opt/ltp/testcases/open_posix_testsuite/conformance/inter[  152.231692] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2dc4000, LEN 0x0000, Attr=0x21
    faces/sigdelset
    40	./opt/ltp/testcases/open_posix_testsuite/con[  152.231695] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3848000, LEN 0x1000, Attr=0x21
    formance/interfaces/pthread_setschedprio
    88	./opt/ltp/testcases[  152.231697] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2dd4000, LEN 0xf000, Attr=0x21
    /open_posix_testsuite/conformance/interfaces/pthread_attr_setdet[  152.231700] mmc1: sdhci: 8c19e0224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    achstate
    356	./opt/ltp/testcases/open_posix_testsuite/conforman[  152.300734] mmc1: ADMA error: 0x02000002
    ce/interfaces/sched_setscheduler
    44	./opt/ltp/testcases/open_po[  152.300738] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    six_testsuite/conformance/interfaces/strncpy
    28	./opt/ltp/testc[  152.300740] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    ases/open_posix_testsuite/conformance/interfaces/pthread_rwlock_[  152.300742] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    trywrlock/speculative
    84	./opt/ltp/testcases/open_posix_testsui[  152.300744] mmc1: sdhci: Argument:  0x00c40f08 | Trn mode: 0x0000003b
    te/conformance/interfaces/pthread_rwlock_trywrlock
    76	./opt/ltp[  152.300747] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    /testcases/open_posix_testsuite/conformance/interfaces/pthread_c[  152.300749] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    leanup_pop
    72	./opt/ltp/testcases/open_posix_testsuite/conforma[  152.300751] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    nce/interfaces/pthread_key_delete
    32	./opt/ltp/testcases/open_p[  152.300754] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    osix_testsuite/conformance/interfaces/pthread_mutex_init/specula[  152.300756] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    tive
    184	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  152.300758] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    60	./opt/ltp/testcases/open_posix_[  152.300760] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    testsuite/conformance/interfaces/pthread_condattr_setpshared
    48[  152.300763] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  152.300765] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    /pthread_attr_getstacksize
    144	./opt/ltp/testcases/open_posix_t[  152.300767] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    estsuite/conformance/interfaces/sigset
    52	./opt/ltp/testcases/o[  152.300769] mmc1: sdhci: Host ctl2: 0x00000c00
    pen_posix_testsuite/conformance/interfaces/timer_create/speculat[  152.300775] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    ive
    216	./opt/ltp/testcases/open_posix_testsuite/conformance/in[  152.300777] mmc1: sdhci: ============================================
    108	./opt/ltp/testcases/open_posix_testsu[  152.300778] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2de3000, LEN 0x0000, Attr=0x21
    ite/conformance/interfaces/aio_return
    36	./opt/ltp/testcases/op[  152.300780] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2df3000, LEN 0x6000, Attr=0x21
    en_posix_testsuite/conformance/interfaces/pthread_self
    [  152.300783] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3849000, LEN 0x1000, Attr=0x21
    [  152.300785] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2df9000, LEN 0x9000, Attr=0x21
    [  152.300787] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  152.306584] mmc1: ADMA error: 0x02000002
    [  152.306587] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  152.306589] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  152.306591] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  152.306593] mmc1: sdhci: Argument:  0x00c40f08 | Trn mode: 0x0000003b
    [  152.306595] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  152.306598] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  152.306600] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  152.306602] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  152.306605] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  152.306607] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  152.306609] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  152.306611] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  152.306613] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  152.306616] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    92	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  152.306617] mmc1: sdhci: Host ctl2: 0x00000c00
    es/sigaction/templates
    [  152.306620] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    6660	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  152.306621] mmc1: sdhci: ============================================
    aces/sigaction
    [  152.306623] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2de3000, LEN 0x0000, Attr=0x21
    152	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  152.306625] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2df3000, LEN 0x6000, Attr=0x21
    ces/pthread_rwlock_rdlock
    36	./opt/ltp/testcases/open_posix_tes[  152.306628] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3849000, LEN 0x1000, Attr=0x21
    tsuite/conformance/interfaces/pthread_attr_setschedparam/specula[  152.306630] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2df9000, LEN 0x9000, Attr=0x21
    tive
    136	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  152.306632] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    56	./opt/ltp/testcases/ope[  152.392192] mmc1: ADMA error: 0x02000002
    n_posix_testsuite/conformance/interfaces/pthread_testcancel
    28	[  152.392199] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    ./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/[  152.392201] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    pthread_getcpuclockid/speculative
    76	./opt/ltp/testcases/open_p[  152.392204] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    osix_testsuite/conformance/interfaces/pthread_getcpuclockid
    100[  152.392206] mmc1: sdhci: Argument:  0x00c41100 | Trn mode: 0x0000003b
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  152.392209] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    /pthread_spin_init
    200	./opt/ltp/testcases/open_posix_testsuite[  152.392211] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    /conformance/interfaces/aio_fsync
    136	./opt/ltp/testcases/open_[  152.392213] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    posix_testsuite/conformance/interfaces/sem_wait
    48	./opt/ltp/te[  152.392216] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    stcases/open_posix_testsuite/conformance/interfaces/pthread_mute[  152.392218] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    xattr_init
    64	./opt/ltp/testcases/open_posix_testsuite/conforma[  152.392220] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    nce/interfaces/pthread_barrier_destroy
    44	./opt/ltp/testcases/o[  152.392223] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    pen_posix_testsuite/conformance/interfaces/sigemptyset
    188	./op[  152.392225] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    t/ltp/testcases/open_posix_testsuite/conformance/interfaces/nano[  152.392227] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    sleep
    24	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  152.392229] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    nterfaces/sched_rr_get_interval/speculative
    92	./opt/ltp/testca[  152.392231] mmc1: sdhci: Host ctl2: 0x00000c00
    ses/open_posix_testsuite/conformance/interfaces/sched_rr_get_int[  152.392233] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    erval
    128	./opt/ltp/testcases/open_posix_testsuite/conformance/[  152.392235] mmc1: sdhci: ============================================
    interfaces/sem_post
    48	./opt/ltp/testcases/open_posix_testsuite[  152.392237] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2e02000, LEN 0x0000, Attr=0x21
    /conformance/interfaces/pthread_attr_getscope
    28	./opt/ltp/test[  152.392239] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2e12000, LEN 0xc000, Attr=0x21
    cases/open_posix_testsuite/conformance/interfaces/testfrmw
    28	.[  152.392242] mmc1: sdhci: 8c19e0218: DMA 0x00000008c384d000, LEN 0x1000, Attr=0x21
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/m[  152.392244] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2e1e000, LEN 0x3000, Attr=0x21
    q_timedsend/speculative
    436	./opt/ltp/testcases/open_posix_test[  152.392247] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    suite/conformance/interfaces/mq_timedsend
    60	./opt/ltp/testcase[  152.398038] mmc1: ADMA error: 0x02000002
    s/open_posix_testsuite/conformance/interfaces/pthread_setspecifi[  152.398040] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    c
    44	./opt/ltp/testcases/open_posix_testsuite/conformance/inter[  152.398042] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    faces/getpid
    172	./opt/ltp/testcases/open_posix_testsuite/confo[  152.398045] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    rmance/interfaces/pthread_cond_wait
    44	./opt/ltp/testcases/open[  152.398047] mmc1: sdhci: Argument:  0x00c41100 | Trn mode: 0x0000003b
    _posix_testsuite/conformance/interfaces/difftime
    180	./opt/ltp/[  152.398049] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    testcases/open_posix_testsuite/conformance/interfaces/pthread_mu[  152.398052] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    tex_trylock
    24	./opt/ltp/testcases/open_posix_testsuite/conform[  152.398054] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    ance/interfaces/sched_getparam/speculative
    124	./opt/ltp/testca[  152.398056] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    ses/open_posix_testsuite/conformance/interfaces/sched_getparam
    [  152.398058] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    60	./opt/ltp/testcases/open_posix_testsuite/conformance/interfac[  152.398060] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    es/pthread_rwlockattr_init
    88	./opt/ltp/testcases/open_posix_te[  152.398063] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    stsuite/conformance/interfaces/clock_getcpuclockid
    204	./opt/lt[  152.398065] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    p/testcases/open_posix_testsuite/conformance/interfaces/sem_unli[  152.398067] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    nk
    100	./opt/ltp/testcases/open_posix_testsuite/conformance/int[  152.398069] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    erfaces/pthread_spin_lock
    32	./opt/ltp/testcases/open_posix_tes[  152.398071] mmc1: sdhci: Host ctl2: 0x00000c00
    tsuite/conformance/interfaces/pthread_cond_destroy/speculative
    [  152.398073] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    124	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  152.398075] mmc1: sdhci: ============================================
    168	./opt/ltp/testcases/open_posix_tes[  152.398076] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2e02000, LEN 0x0000, Attr=0x21
    tsuite/conformance/interfaces/sem_init
    60	./opt/ltp/testcases/o[  152.398079] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2e12000, LEN 0xc000, Attr=0x21
    [  152.398081] mmc1: sdhci: 8c19e0218: DMA 0x00000008c384d000, LEN 0x1000, Attr=0x21
    72	./opt/ltp/testcases/open_posix_testsuite/conformance/interfa[  152.398083] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2e1e000, LEN 0x3000, Attr=0x21
    ces/pthread_attr_init
    32	./opt/ltp/testcases/open_posix_testsui[  152.398086] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    te/conformance/interfaces/mktime
    168	./opt/ltp/testcases/open_p[  152.473967] mmc1: ADMA error: 0x02000002
    osix_testsuite/conformance/interfaces/pthread_rwlock_timedrdlock[  152.473973] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    100	./opt/ltp/testcases/open_posix_testsuite/conformance/inter[  152.473975] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    faces/sem_getvalue
    120	./opt/ltp/testcases/open_posix_testsuite[  152.473978] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    /conformance/interfaces/sigwaitinfo
    52	./opt/ltp/testcases/open[  152.473981] mmc1: sdhci: Argument:  0x00c41008 | Trn mode: 0x0000003b
    _posix_testsuite/conformance/interfaces/timer_getoverrun/specula[  152.473983] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    tive
    160	./opt/ltp/testcases/open_posix_testsuite/conformance/i[  152.473985] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    352	./opt/ltp/testcases/open_posix_t[  152.473988] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    estsuite/conformance/interfaces/fork
    56	./opt/ltp/testcases/ope[  152.473990] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    n_posix_testsuite/conformance/interfaces/fsync
    120	./opt/ltp/te[  152.473992] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    stcases/open_posix_testsuite/conformance/interfaces/pthread_attr[  152.473994] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    _setstack
    72	./opt/ltp/testcases/open_posix_testsuite/conforman[  152.473996] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    ce/interfaces/pthread_spin_trylock
    108	./opt/ltp/testcases/open[  152.473999] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    _posix_testsuite/conformance/interfaces/pthread_mutex_unlock
    72[  152.474001] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  152.474004] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    /aio_error
    80	./opt/ltp/testcases/open_posix_testsuite/conforma[  152.474006] mmc1: sdhci: Host ctl2: 0x00000c00
    nce/interfaces/sigsuspend
    68	./opt/ltp/testcases/open_posix_tes[  152.474008] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    tsuite/conformance/interfaces/pthread_barrierattr_getpshared
    88[  152.474011] mmc1: sdhci: ============================================
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  152.474012] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2e3f000, LEN 0x0000, Attr=0x21
    /pthread_mutexattr_getpshared
    196	./opt/ltp/testcases/open_posi[  152.474015] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2e4f000, LEN 0x8000, Attr=0x21
    x_testsuite/conformance/interfaces/aio_write
    80	./opt/ltp/testc[  152.474017] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3850000, LEN 0x1000, Attr=0x21
    ases/open_posix_testsuite/conformance/interfaces/pthread_rwlocka[  152.474019] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2e57000, LEN 0x6000, Attr=0x21
    ttr_getpshared
    76	./opt/ltp/testcases/open_posix_testsuite/conf[  152.474022] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    ormance/interfaces/munlock
    92	./opt/ltp/testcases/open_posix_te[  152.479645] mmc1: ADMA error: 0x02000002
    stsuite/conformance/interfaces/sigpause
    116	./opt/ltp/testcases[  152.479647] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    /open_posix_testsuite/conformance/interfaces/aio_suspend
    180	./[  152.479649] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/si[  152.479651] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    gqueue
    84	./opt/ltp/testcases/open_posix_testsuite/conformance/[  152.479654] mmc1: sdhci: Argument:  0x00c41008 | Trn mode: 0x0000003b
    interfaces/sigtimedwait
    148	./opt/ltp/testcases/open_posix_test[  152.479656] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    suite/conformance/interfaces/sigwait
    64	./opt/ltp/testcases/ope[  152.479658] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    n_posix_testsuite/conformance/interfaces/mq_open/speculative
    42[  152.479660] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    0	./opt/ltp/testcases/open_posix_testsuite/conformance/interface[  152.479663] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    s/mq_open
    56	./opt/ltp/testcases/open_posix_testsuite/conforman[  152.479665] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    ce/interfaces/sigrelse
    72	./opt/ltp/testcases/open_posix_testsu[  152.479667] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    ite/conformance/interfaces/pthread_condattr_setclock
    284	./opt/[  152.479669] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    ltp/testcases/open_posix_testsuite/conformance/interfaces/mq_sen[  152.479671] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    d
    84	./opt/ltp/testcases/open_posix_testsuite/conformance/inter[  152.479674] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    faces/sem_close
    192	./opt/ltp/testcases/open_posix_testsuite/co[  152.479676] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    nformance/interfaces/aio_cancel
    168	./opt/ltp/testcases/open_po[  152.479678] mmc1: sdhci: Host ctl2: 0x00000c00
    [  152.479680] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    264	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  152.479682] mmc1: sdhci: ============================================
    aces/pthread_exit
    60	./opt/ltp/testcases/open_posix_testsuite/c[  152.479683] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2e3f000, LEN 0x0000, Attr=0x21
    onformance/interfaces/pthread_condattr_getclock
    52	./opt/ltp/te[  152.479686] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2e4f000, LEN 0x8000, Attr=0x21
    stcases/open_posix_testsuite/conformance/interfaces/timer_gettim[  152.479688] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3850000, LEN 0x1000, Attr=0x21
    e/speculative
    184	./opt/ltp/testcases/open_posix_testsuite/conf[  152.479690] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2e57000, LEN 0x6000, Attr=0x21
    ormance/interfaces/timer_gettime
    72	./opt/ltp/testcases/open_po[  152.479692] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    six_testsuite/conformance/interfaces/pthread_mutexattr_setprotoc[  153.331185] mmc1: ADMA error: 0x02000002
    ol
    156	./opt/ltp/testcases/open_posix_testsuite/conformance/int[  153.331195] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    erfaces/sigaltstack
    28	./opt/ltp/testcases/open_posix_testsuite[  153.331198] mmc1: sdhci: Sys addr:  0x00000098 | Version:  0x00001004
    /conformance/interfaces/pthread_key_create/speculative
    100	./op[  153.331201] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    t/ltp/testcases/open_posix_testsuite/conformance/interfaces/pthr[  153.331203] mmc1: sdhci: Argument:  0x00043c70 | Trn mode: 0x0000003b
    ead_key_create
    72	./opt/ltp/testcases/open_posix_testsuite/conf[  153.331206] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    ormance/interfaces/pthread_condattr_getpshared
    96	./opt/ltp/tes[  153.331209] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    tcases/open_posix_testsuite/conformance/interfaces/signal
    292	.[  153.331211] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/l[  153.331214] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    io_listio
    380	./opt/ltp/testcases/open_posix_testsuite/conforma[  153.331216] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    nce/interfaces/sched_setparam
    180	./opt/ltp/testcases/open_posi[  153.331219] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    x_testsuite/conformance/interfaces/pthread_detach
    28	./opt/ltp/[  153.331221] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    testcases/open_posix_testsuite/conformance/interfaces/mq_unlink/[  153.331223] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    speculative
    136	./opt/ltp/testcases/open_posix_testsuite/confor[  153.331226] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    96	./opt/ltp/testcases/open_posix_te[  153.331228] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    stsuite/conformance/interfaces/pthread_setschedparam
    80	./opt/l[  153.331231] mmc1: sdhci: Host ctl2: 0x00000c00
    tp/testcases/open_posix_testsuite/conformance/interfaces/pthread[  153.331233] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    _setcanceltype
    112	./opt/ltp/testcases/open_posix_testsuite/con[  153.331235] mmc1: sdhci: ============================================
    formance/interfaces/pthread_mutex_timedlock
    48	./opt/ltp/testca[  153.331236] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2ed6000, LEN 0x0000, Attr=0x21
    ses/open_posix_testsuite/conformance/interfaces/clock_settime/sp[  153.331240] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2ee6000, LEN 0x3000, Attr=0x21
    eculative
    308	./opt/ltp/testcases/open_posix_testsuite/conforma[  153.331242] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    88	./opt/ltp/testcases/open_posix_[  153.334859] mmc1: ADMA error: 0x02000002
    testsuite/conformance/interfaces/pthread_cond_init
    76	./opt/ltp[  153.334862] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    /testcases/open_posix_testsuite/conformance/interfaces/pthread_c[  153.334863] mmc1: sdhci: Sys addr:  0x00000098 | Version:  0x00001004
    leanup_push
    196	./opt/ltp/testcases/open_posix_testsuite/confor[  153.334866] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    mance/interfaces/aio_read
    56	./opt/ltp/testcases/open_posix_tes[  153.334868] mmc1: sdhci: Argument:  0x00043c70 | Trn mode: 0x0000003b
    tsuite/conformance/interfaces/sigismember
    44	./opt/ltp/testcase[  153.334870] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    s/open_posix_testsuite/conformance/interfaces/timer_delete/specu[  153.334872] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    lative
    120	./opt/ltp/testcases/open_posix_testsuite/conformance[  153.334875] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    48	./opt/ltp/testcases/open_posix_test[  153.334877] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    suite/conformance/interfaces/pthread_attr_getstack
    188	./opt/lt[  153.334879] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    p/testcases/open_posix_testsuite/conformance/interfaces/sem_open[  153.334881] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    44	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  153.334883] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    aces/gmtime
    72	./opt/ltp/testcases/open_posix_testsuite/conform[  153.334885] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    ance/interfaces/pthread_mutexattr_setprioceiling
    128	./opt/ltp/[  153.334887] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    testcases/open_posix_testsuite/conformance/interfaces/pthread_mu[  153.334890] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    tex_lock
    68	./opt/ltp/testcases/open_posix_testsuite/conformanc[  153.334892] mmc1: sdhci: Host ctl2: 0x00000c00
    e/interfaces/pthread_equal
    44	./opt/ltp/testcases/open_posix_te[  153.334894] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    stsuite/conformance/interfaces/munlockall
    132	./opt/ltp/testcas[  153.334896] mmc1: sdhci: ============================================
    es/open_posix_testsuite/conformance/interfaces/clock_getres
    120[  153.334897] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2ed6000, LEN 0x0000, Attr=0x21
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  153.334899] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2ee6000, LEN 0x3000, Attr=0x21
    /pthread_barrier_wait
    232	./opt/ltp/testcases/open_posix_testsu[  153.334902] mmc1: sdhci: 8c19e0218: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    ite/conformance/interfaces/clock_nanosleep
    52	./opt/ltp/testcas[  153.732261] mmc1: ADMA error: 0x02000002
    es/open_posix_testsuite/conformance/interfaces/pthread_attr_gets[  153.732269] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    chedparam
    168	./opt/ltp/testcases/open_posix_testsuite/conforma[  153.732271] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    nce/interfaces/sigprocmask
    28	./opt/ltp/testcases/open_posix_te[  153.732274] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    stsuite/conformance/interfaces/mq_getattr/speculative
    128	./opt[  153.732276] mmc1: sdhci: Argument:  0x00043d08 | Trn mode: 0x0000003b
    /ltp/testcases/open_posix_testsuite/conformance/interfaces/mq_ge[  153.732279] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    tattr
    132	./opt/ltp/testcases/open_posix_testsuite/conformance/[  153.732281] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    interfaces/pthread_once
    80	./opt/ltp/testcases/open_posix_tests[  153.732284] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    uite/conformance/interfaces/pthread_attr_setstacksize
    28	./opt/[  153.732286] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    ltp/testcases/open_posix_testsuite/conformance/interfaces/mlocka[  153.732289] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    ll/speculative
    164	./opt/ltp/testcases/open_posix_testsuite/con[  153.732291] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    formance/interfaces/mlockall
    172	./opt/ltp/testcases/open_posix[  153.732293] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    _testsuite/conformance/interfaces/shm_unlink
    60	./opt/ltp/testc[  153.732295] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    ases/open_posix_testsuite/conformance/interfaces/pthread_barrier[  153.732298] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    attr_setpshared
    232	./opt/ltp/testcases/open_posix_testsuite/co[  153.732300] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    nformance/interfaces/pthread_sigmask
    108	./opt/ltp/testcases/op[  153.732302] mmc1: sdhci: Host ctl2: 0x00000c00
    en_posix_testsuite/conformance/interfaces/killpg
    128	./opt/ltp/[  153.732305] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    testcases/open_posix_testsuite/conformance/interfaces/pthread_ki[  153.732307] mmc1: sdhci: ============================================
    ll
    52	./opt/ltp/testcases/open_posix_testsuite/conformance/inte[  153.732308] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f02000, LEN 0x0000, Attr=0x21
    rfaces/timer_settime/speculative
    344	./opt/ltp/testcases/open_p[  153.732311] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2f12000, LEN 0xa000, Attr=0x21
    osix_testsuite/conformance/interfaces/timer_settime
    164	./opt/l[  153.732314] mmc1: sdhci: 8c19e0218: DMA 0x00000008c395f000, LEN 0x1000, Attr=0x21
    tp/testcases/open_posix_testsuite/conformance/interfaces/sem_tim[  153.732316] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2f1c000, LEN 0x4000, Attr=0x21
    edwait
    96	./opt/ltp/testcases/open_posix_testsuite/conformance/[  153.732318] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    interfaces/sched_get_priority_max
    92	./opt/ltp/testcases/open_p[  153.737962] mmc1: ADMA error: 0x02000002
    osix_testsuite/conformance/interfaces/mq_setattr
    28	./opt/ltp/t[  153.737964] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    estcases/open_posix_testsuite/conformance/interfaces/pthread_mut[  153.737966] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    exattr_gettype/speculative
    120	./opt/ltp/testcases/open_posix_t[  153.737968] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    estsuite/conformance/interfaces/pthread_mutexattr_gettype
    48	./[  153.737970] mmc1: sdhci: Argument:  0x00043d08 | Trn mode: 0x0000003b
    opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/pt[  153.737972] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    hread_barrierattr_destroy
    8	./opt/ltp/testcases/open_posix_test[  153.737974] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    suite/conformance/interfaces/access
    52	./opt/ltp/testcases/open[  153.737976] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    _posix_testsuite/conformance/interfaces/sched_yield
    156	./opt/l[  153.737979] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    tp/testcases/open_posix_testsuite/conformance/interfaces/pthread[  153.737981] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    _cancel
    96	./opt/ltp/testcases/open_posix_testsuite/conformance[  153.737983] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    /interfaces/sched_getscheduler
    48	./opt/ltp/testcases/open_posi[  153.737985] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    x_testsuite/conformance/interfaces/pthread_rwlockattr_setpshared[  153.737988] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    36	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  153.737990] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    aces/pthread_mutex_setprioceiling
    56	./opt/ltp/testcases/open_p[  153.737992] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    44	./opt/ltp/testca[  153.737994] mmc1: sdhci: Host ctl2: 0x00000c00
    ses/open_posix_testsuite/conformance/interfaces/sigfillset
    60	.[  153.737996] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    /opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/p[  153.737998] mmc1: sdhci: ============================================
    thread_attr_getdetachstate
    164	./opt/ltp/testcases/open_posix_t[  153.737999] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f02000, LEN 0x0000, Attr=0x21
    estsuite/conformance/interfaces/pthread_cond_signal
    72	./opt/lt[  153.738002] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2f12000, LEN 0xa000, Attr=0x21
    p/testcases/open_posix_testsuite/conformance/interfaces/pthread_[  153.738004] mmc1: sdhci: 8c19e0218: DMA 0x00000008c395f000, LEN 0x1000, Attr=0x21
    mutexattr_destroy
    48	./opt/ltp/testcases/open_posix_testsuite/c[  153.738006] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2f1c000, LEN 0x4000, Attr=0x21
    onformance/interfaces/pthread_attr_getinheritsched
    84	./opt/ltp[  153.738008] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    /testcases/open_posix_testsuite/conformance/interfaces/sigignore[  154.543665] mmc1: ADMA error: 0x02000002
    28	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  154.543673] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    aces/pthread_join/speculative
    204	./opt/ltp/testcases/open_posi[  154.543675] mmc1: sdhci: Sys addr:  0x00000400 | Version:  0x00001004
    x_testsuite/conformance/interfaces/pthread_join
    96	./opt/ltp/te[  154.543678] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    stcases/open_posix_testsuite/conformance/interfaces/sched_get_pr[  154.543680] mmc1: sdhci: Argument:  0x00c82820 | Trn mode: 0x0000002b
    iority_min
    48	./opt/ltp/testcases/open_posix_testsuite/conforma[  154.543682] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    nce/interfaces/pthread_getspecific
    52	./opt/ltp/testcases/open_[  154.543685] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    posix_testsuite/conformance/interfaces/sem_destroy
    84	./opt/ltp[  154.543687] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    /testcases/open_posix_testsuite/conformance/interfaces/kill
    32	[  154.543689] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    ./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces/[  154.543691] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    asctime
    28	./opt/ltp/testcases/open_posix_testsuite/conformance[  154.543694] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    /interfaces/mlock/speculative
    128	./opt/ltp/testcases/open_posi[  154.543696] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    140	./opt/ltp/testcase[  154.543698] mmc1: sdhci: Cmd:       0x0000193a | Max curr: 0x00000000
    s/open_posix_testsuite/conformance/interfaces/mq_notify
    32	./op[  154.543701] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    t/ltp/testcases/open_posix_testsuite/conformance/interfaces/time[  154.543703] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    80	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  154.543705] mmc1: sdhci: Host ctl2: 0x00000c00
    aces/strftime
    48	./opt/ltp/testcases/open_posix_testsuite/confo[  154.543707] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    rmance/interfaces/pthread_mutexattr_getprotocol
    128	./opt/ltp/t[  154.543710] mmc1: sdhci: ============================================
    estcases/open_posix_testsuite/conformance/interfaces/pthread_mut[  154.543711] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2a40000, LEN 0x1000, Attr=0x21
    exattr_settype
    28	./opt/ltp/testcases/open_posix_testsuite/conf[  154.543714] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2bf4000, LEN 0xc000, Attr=0x21
    ormance/interfaces/mq_timedreceive/speculative
    348	./opt/ltp/te[  154.543716] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3000000, LEN 0x0000, Attr=0x21
    stcases/open_posix_testsuite/conformance/interfaces/mq_timedrece[  154.543719] mmc1: sdhci: 8c19e0224: DMA 0x00000008c3010000, LEN 0x3000, Attr=0x21
    ive
    32	./opt/ltp/testcases/open_posix_testsuite/conformance/int[  154.543721] mmc1: sdhci: 8c19e0230: DMA 0x00000008c3033000, LEN 0x1000, Attr=0x21
    erfaces/strcpy
    76	./opt/ltp/testcases/open_posix_testsuite/conf[  154.543723] mmc1: sdhci: 8c19e023c: DMA 0x00000008c3036000, LEN 0x0000, Attr=0x21
    ormance/interfaces/pthread_barrier_init
    184	./opt/ltp/testcases[  154.543725] mmc1: sdhci: 8c19e0248: DMA 0x00000008c3046000, LEN 0xf000, Attr=0x21
    /open_posix_testsuite/conformance/interfaces/mq_receive
    192	./o[  154.543728] mmc1: sdhci: 8c19e0254: DMA 0x00000008c3075000, LEN 0x0000, Attr=0x21
    pt/ltp/testcases/open_posix_testsuite/conformance/interfaces/pth[  154.543730] mmc1: sdhci: 8c19e0260: DMA 0x00000008c3085000, LEN 0x0000, Attr=0x21
    read_cond_broadcast
    32	./opt/ltp/testcases/open_posix_testsuite[  154.543732] mmc1: sdhci: 8c19e026c: DMA 0x00000008c30b3000, LEN 0x0000, Attr=0x21
    /conformance/interfaces/localtime
    56	./opt/ltp/testcases/open_p[  154.543734] mmc1: sdhci: 8c19e0278: DMA 0x00000008c30c3000, LEN 0x8000, Attr=0x21
    osix_testsuite/conformance/interfaces/sighold
    76	./opt/ltp/test[  154.543736] mmc1: sdhci: 8c19e0284: DMA 0x00000008c30cd000, LEN 0x2000, Attr=0x21
    cases/open_posix_testsuite/conformance/interfaces/pthread_rwlock[  154.543739] mmc1: sdhci: 8c19e0290: DMA 0x00000008c2cb0000, LEN 0x1000, Attr=0x21
    _wrlock
    84	./opt/ltp/testcases/open_posix_testsuite/conformance[  154.543741] mmc1: sdhci: 8c19e029c: DMA 0x00000008c30cf000, LEN 0x5000, Attr=0x21
    /interfaces/pthread_spin_unlock
    88	./opt/ltp/testcases/open_pos[  154.543743] mmc1: sdhci: 8c19e02a8: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    ix_testsuite/conformance/interfaces/sigaddset
    140	./opt/ltp/tes[  154.559057] mmc1: ADMA error: 0x02000002
    tcases/open_posix_testsuite/conformance/interfaces/clock_gettime[  154.559060] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    68	./opt/ltp/testcases/open_posix_testsuite/conformance/interf[  154.559061] mmc1: sdhci: Sys addr:  0x00000280 | Version:  0x00001004
    aces/pthread_getschedparam
    92	./opt/ltp/testcases/open_posix_te[  154.559064] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    stsuite/conformance/interfaces/pthread_rwlock_init
    32	./opt/ltp[  154.559066] mmc1: sdhci: Argument:  0x00c82c20 | Trn mode: 0x0000002b
    /testcases/open_posix_testsuite/conformance/interfaces/ctime
    36[  154.559068] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  154.559070] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    /strchr
    32	./opt/ltp/testcases/open_posix_testsuite/conformance[  154.559072] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    /interfaces/strlen
    60	./opt/ltp/testcases/open_posix_testsuite/[  154.559074] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    conformance/interfaces/pthread_rwlockattr_destroy
    60	./opt/ltp/[  154.559076] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    testcases/open_posix_testsuite/conformance/interfaces/pthread_at[  154.559078] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    tr_destroy
    332	./opt/ltp/testcases/open_posix_testsuite/conform[  154.559081] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    ance/interfaces/pthread_create
    64	./opt/ltp/testcases/open_posi[  154.559083] mmc1: sdhci: Cmd:       0x0000193a | Max curr: 0x00000000
    x_testsuite/conformance/interfaces/pthread_rwlock_tryrdlock
    108[  154.559085] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  154.559087] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    /raise
    72	./opt/ltp/testcases/open_posix_testsuite/conformance/[  154.559089] mmc1: sdhci: Host ctl2: 0x00000c00
    interfaces/sigpending
    48	./opt/ltp/testcases/open_posix_testsui[  154.559092] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    te/conformance/interfaces/pthread_condattr_init
    588	./opt/ltp/t[  154.559093] mmc1: sdhci: ============================================
    estcases/open_posix_testsuite/conformance/interfaces/mmap
    29332[  154.559095] mmc1: sdhci: 8c19e0200: DMA 0x00000008c30d4000, LEN 0x0000, Attr=0x21
    	./opt/ltp/testcases/open_posix_testsuite/conformance/interfaces[  154.559097] mmc1: sdhci: 8c19e020c: DMA 0x00000008c30e4000, LEN 0xa000, Attr=0x21
    32	./opt/ltp/testcases/open_posix_testsuite/conformance/defini[  154.559099] mmc1: sdhci: 8c19e0218: DMA 0x00000008c310e000, LEN 0x2000, Attr=0x21
    tions/unistd_h
    784	./opt/ltp/testcases/open_posix_testsuite/con[  154.559101] mmc1: sdhci: 8c19e0224: DMA 0x00000008c3114000, LEN 0x0000, Attr=0x21
    formance/definitions/signal_h
    176	./opt/ltp/testcases/open_posi[  154.559104] mmc1: sdhci: 8c19e0230: DMA 0x00000008c3124000, LEN 0xe000, Attr=0x21
    x_testsuite/conformance/definitions/sched_h
    96	./opt/ltp/testca[  154.559106] mmc1: sdhci: 8c19e023c: DMA 0x00000008c3152000, LEN 0x0000, Attr=0x21
    ses/open_posix_testsuite/conformance/definitions/sys/shm_h
    200	[  154.559108] mmc1: sdhci: 8c19e0248: DMA 0x00000008c3162000, LEN 0x6000, Attr=0x21
    ./opt/ltp/testcases/open_posix_testsuite/conformance/definitions[  154.559110] mmc1: sdhci: 8c19e0254: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    /sys/mman_h
    300	./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/sys
    340	./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/pthread_h
    420	./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/time_h
    76	./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/aio_h
    72	./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/errno_h
    128	./opt/ltp/testcases/open_posix_testsuite/conformance/definitions/mqueue_h
    2336	./opt/ltp/testcases/open_posix_testsuite/conformance/definitions
    48	./opt/ltp/testcases/open_posix_testsuite/conformance/behavior/timers
    52	./opt/ltp/testcases/open_posix_testsuite/conformance/behavior/WIFEXITED
    108	./opt/ltp/testcases/open_posix_testsuite/conformance/behavior
    31784	./opt/ltp/testcases/open_posix_testsuite/conformance
    76	./opt/ltp/testcases/open_posix_testsuite/Documentation
    44	./opt/ltp/testcases/open_posix_testsuite/include
    28	./opt/ltp/testcases/open_posix_testsuite/scripts
    32	./opt/ltp/testcases/open_posix_testsuite/bin
    12	./opt/ltp/testcases/open_posix_testsuite/stress/timers
    24	./opt/ltp/testcases/open_posix_testsuite/stress/signals
    68	./opt/ltp/testcases/open_posix_testsuite/stress/mqueues
    88	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_cond_timedwait
    56	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_mutex_init
    68	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_self
    76	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_cond_wait
    48	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_mutex_trylock
    64	./opt/ltp/testcases/open_posix_testsuite/stress/threads/sem_init
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/sem_getvalue
    60	./opt/ltp/testcases/open_posix_testsuite/stress/threads/fork
    60	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_exit
    56	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_cond_init
    64	./opt/ltp/testcases/open_posix_testsuite/stress/threads/sem_open
    84	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_mutex_lock
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_once
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_kill
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_cancel
    44	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_getschedparam
    80	./opt/ltp/testcases/open_posix_testsuite/stress/threads/pthread_create
    1048	./opt/ltp/testcases/open_posix_testsuite/stress/threads
    28	./opt/ltp/testcases/open_posix_testsuite/stress/semaphores
    1188	./opt/ltp/testcases/open_posix_testsuite/stress
    44	./opt/ltp/testcases/open_posix_testsuite/functional/timers/timers
    36	./opt/ltp/testcases/open_posix_testsuite/functional/timers/clocks
    104	./opt/ltp/testcases/open_posix_testsuite/functional/timers
    60	./opt/ltp/testcases/open_posix_testsuite/functional/mqueues
    48	./opt/ltp/testcases/open_posix_testsuite/functional/threads/cond[  157.172234] mmc1: ADMA error: 0x02000002
    [  157.172243] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  157.172245] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  157.172248] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  157.172250] mmc1: sdhci: Argument:  0x00043100 | Trn mode: 0x0000003b
    [  157.172253] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.172255] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.172258] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.172260] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.172262] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  157.172265] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    var
    56	./opt/ltp/testcases/open_posix_testsuite/functional/thre[  157.172267] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    ads/schedule
    116	./opt/ltp/testcases/open_posix_testsuite/funct[  157.172269] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  157.172271] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  157.172273] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  157.172275] mmc1: sdhci: Host ctl2: 0x00000c00
    [  157.172277] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  157.172279] mmc1: sdhci: ============================================
    [  157.172280] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f52000, LEN 0x4000, Attr=0x21
    ional/threads
    116	./opt/ltp/testcases/open_posix_testsuite/func[  157.172284] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3a54000, LEN 0x1000, Attr=0x21
    tional/semaphores
    404	./opt/ltp/testcases/open_posix_testsuite/[  157.172286] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2f56000, LEN 0x0000, Attr=0x21
    [  157.172288] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2f66000, LEN 0x2000, Attr=0x21
    functional
    12	./opt/ltp/testcases/open_posix_testsuite/tools
    3[  157.172291] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2670000, LEN 0x8000, Attr=0x21
    [  157.172293] mmc1: sdhci: 8c19e023c: DMA 0x00000008c2f70000, LEN 0x2000, Attr=0x21
    3760	./opt/ltp/testcases/open_posix_testsuite
    [  157.172296] mmc1: sdhci: 8c19e0248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  157.178288] mmc1: ADMA error: 0x02000002
    [  157.178291] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  157.178293] mmc1: sdhci: Sys addr:  0x00000108 | Version:  0x00001004
    [  157.178295] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  157.178297] mmc1: sdhci: Argument:  0x00043100 | Trn mode: 0x0000003b
    [  157.178300] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.178302] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.178304] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.178306] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.178308] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  157.178311] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  157.178313] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  157.178315] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  157.178317] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  157.178319] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  157.178321] mmc1: sdhci: Host ctl2: 0x00000c00
    [  157.178323] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  157.178325] mmc1: sdhci: ============================================
    [  157.178326] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f52000, LEN 0x4000, Attr=0x21
    [  157.178329] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3a54000, LEN 0x1000, Attr=0x21
    [  157.178331] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2f56000, LEN 0x0000, Attr=0x21
    [  157.178334] mmc1: sdhci: 8c19e0224: DMA 0x00000008c2f66000, LEN 0x2000, Attr=0x21
    [  157.178336] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2670000, LEN 0x8000, Attr=0x21
    [  157.178338] mmc1: sdhci: 8c19e023c: DMA 0x00000008c2f70000, LEN 0x2000, Attr=0x21
    [  157.178341] mmc1: sdhci: 8c19e0248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  157.334097] mmc1: ADMA error: 0x02000002
    [  157.334103] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  157.334105] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  157.334107] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  157.334110] mmc1: sdhci: Argument:  0x00043400 | Trn mode: 0x0000003b
    [  157.334112] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.334114] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.334116] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.334119] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.334121] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  157.334124] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  157.334126] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  157.334129] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  157.334131] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  157.334133] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  157.334135] mmc1: sdhci: Host ctl2: 0x00000c00
    [  157.334137] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  157.334139] mmc1: sdhci: ============================================
    [  157.334140] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f72000, LEN 0xf000, Attr=0x21
    [  157.334143] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3a55000, LEN 0x1000, Attr=0x21
    [  157.334146] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2f81000, LEN 0x0000, Attr=0x21
    [  157.334148] mmc1: sdhci: 8c19e0224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  157.339961] mmc1: ADMA error: 0x02000002
    [  157.339964] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  157.339966] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  157.339968] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  157.339970] mmc1: sdhci: Argument:  0x00043400 | Trn mode: 0x0000003b
    [  157.339973] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.339975] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.339977] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.339980] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.339982] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  157.339984] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  157.339987] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  157.339989] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  157.339991] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  157.339994] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  157.339995] mmc1: sdhci: Host ctl2: 0x00000c00
    [  157.339997] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  157.339999] mmc1: sdhci: ============================================
    [  157.340000] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f72000, LEN 0xf000, Attr=0x21
    [  157.340003] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3a55000, LEN 0x1000, Attr=0x21
    [  157.340005] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2f81000, LEN 0x0000, Attr=0x21
    [  157.340007] mmc1: sdhci: 8c19e0224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    2652[  157.435070] mmc1: ADMA error: 0x02000002
    [  157.435077] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  157.435079] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  157.435082] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    	./opt/ltp/testcases/bin/datafiles[  157.435084] mmc1: sdhci: Argument:  0x00043000 | Trn mode: 0x0000003b
    [  157.435087] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.435089] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.435091] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.435094] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.435096] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  157.435098] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    32[  157.435100] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  157.435103] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  157.435105] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  157.435107] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  157.435110] mmc1: sdhci: Host ctl2: 0x00000c00
    	./opt/ltp/testcases/bin/fs_bind/cloneNS[  157.435112] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0218
    [  157.435114] mmc1: sdhci: ============================================
    [  157.435115] mmc1: sdhci: 8c19e0200: DMA 0x00000008c24d9000, LEN 0x1000, Attr=0x21
    [  157.435119] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2e7b000, LEN 0x0000, Attr=0x21
    16[  157.435121] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2e8b000, LEN 0x6000, Attr=0x21
    [  157.435124] mmc1: sdhci: 8c19e0224: DMA 0x00000008c386c000, LEN 0x1000, Attr=0x21
    [  157.435126] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2e91000, LEN 0x8000, Attr=0x21
    [  157.435128] mmc1: sdhci: 8c19e023c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    	./opt/ltp/testcases/bin/fs_bind/regression[  157.440927] mmc1: ADMA error: 0x02000002
    [  157.440929] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  157.440931] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  157.440934] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  157.440936] mmc1: sdhci: Argument:  0x00043000 | Trn mode: 0x0000003b
    [  157.440938] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.440940] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.440942] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.440945] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    104[  157.440947] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  157.440949] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    	./opt/ltp/testcases/bin/fs_bind/bind[  157.440951] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  157.440954] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  157.440956] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  157.440959] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  157.440960] mmc1: sdhci: Host ctl2: 0x00000c00
    44[  157.440963] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0218
    	./opt/ltp/testcases/bin/fs_bind/bin[  157.440965] mmc1: sdhci: ============================================
    [  157.440966] mmc1: sdhci: 8c19e0200: DMA 0x00000008c24d9000, LEN 0x1000, Attr=0x21
    92	./opt/ltp/testcases/bin/fs_bind/move
    [  157.440968] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2e7b000, LEN 0x0000, Attr=0x21
    164	./opt/ltp/testcases/bin/fs_bind/rbind
    [  157.440970] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2e8b000, LEN 0x6000, Attr=0x21
    456	./opt/ltp/testcases/bin/fs_bind
    [  157.440972] mmc1: sdhci: 8c19e0224: DMA 0x00000008c386c000, LEN 0x1000, Attr=0x21
    76	./opt/ltp/testcases/bin/ftrace_stress
    [  157.440975] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2e91000, LEN 0x8000, Attr=0x21
    16	./opt/ltp/testcases/bin/ddt/jailhouse
    [  157.440977] mmc1: sdhci: 8c19e023c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    40	./opt/ltp/testcases/bin/ddt/powermgr
    [  157.594696] mmc1: ADMA error: 0x02000002
    12	./opt/ltp/testcases/bin/ddt/graphics
    [  157.594703] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    48	./opt/ltp/testcases/bin/ddt/alsa
    [  157.594705] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    240	./opt/ltp/testcases/bin/ddt/common
    [  157.594707] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    44	./opt/ltp/testcases/bin/ddt/pci
    [  157.594710] mmc1: sdhci: Argument:  0x00042f08 | Trn mode: 0x0000003b
    12	./opt/ltp/testcases/bin/ddt/scsi
    [  157.594712] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    8	./opt/ltp/testcases/bin/ddt/mailbox
    [  157.594715] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    48	./opt/ltp/testcases/bin/ddt/drm
    [  157.594717] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    8	./opt/ltp/testcases/bin/ddt/weston
    [  157.594719] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    12	./opt/ltp/testcases/bin/ddt/can
    [  157.594721] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    48	./opt/ltp/testcases/bin/ddt/video
    [  157.594724] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    12	./opt/ltp/testcases/bin/ddt/dmtimer
    [  157.594726] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    64	./opt/ltp/testcases/bin/ddt/usb
    [  157.594728] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    64	./opt/ltp/testcases/bin/ddt/mtd
    [  157.594731] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    8	./opt/ltp/testcases/bin/ddt/touchscreen
    [  157.594733] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    208	./opt/ltp/testcases/bin/ddt/clk_fw
    [  157.594735] mmc1: sdhci: Host ctl2: 0x00000c00
    36	./opt/ltp/testcases/bin/ddt/thermal
    [  157.594737] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0230
    12	./opt/ltp/testcases/bin/ddt/rtc
    [  157.594739] mmc1: sdhci: ============================================
    8	./opt/ltp/testcases/bin/ddt/crypto
    [  157.594741] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2ff2000, LEN 0x1000, Attr=0x21
    12	./opt/ltp/testcases/bin/ddt/rng
    [  157.594743] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3870000, LEN 0x1000, Attr=0x21
    36	./opt/ltp/testcases/bin/ddt/ipc
    [  157.594746] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2ff3000, LEN 0xd000, Attr=0x21
    8	./opt/ltp/testcases/bin/ddt/uart
    [  157.594748] mmc1: sdhci: 8c19e0224: DMA 0x00000008c5400000, LEN 0x0000, Attr=0x21
    16	./opt/ltp/testcases/bin/ddt/pwm
    [  157.594750] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    40	./opt/ltp/testcases/bin/ddt/gpio
    [  157.600390] mmc1: ADMA error: 0x02000002
    116	./opt/ltp/testcases/bin/ddt/blk
    [  157.600393] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    8	./opt/ltp/testcases/bin/ddt/adc
    [  157.600394] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    12	./opt/ltp/testcases/bin/ddt/wlan
    [  157.600397] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    8	./opt/ltp/testcases/bin/ddt/hwspinlock
    [  157.600399] mmc1: sdhci: Argument:  0x00042f08 | Trn mode: 0x0000003b
    52	./opt/ltp/testcases/bin/ddt/i2c
    [  157.600401] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    104	./opt/ltp/testcases/bin/ddt/eth
    [  157.600403] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    5836	./opt/ltp/testcases/bin/ddt
    [  157.600405] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.600407] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.600409] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    277600	./opt/ltp/testcases/bin
    [  157.600412] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    12	./opt/ltp/testcases/data/lvm
    [  157.600413] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    12	./opt/ltp/testcases/data/ima_policy
    [  157.600416] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    8	./opt/ltp/testcases/data/ima_selinux
    [  157.600418] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    8	./opt/ltp/testcases/data/ima_kexec
    [  157.600420] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    24	./opt/ltp/testcases/data/ar01
    [  157.600422] mmc1: sdhci: Host ctl2: 0x00000c00
    52	./opt/ltp/testcases/data/ldd01
    [  157.600424] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0230
    12	./opt/ltp/testcases/data/mc_member
    [  157.600426] mmc1: sdhci: ============================================
    12	./opt/ltp/testcases/data/unzip01
    [  157.600427] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2ff2000, LEN 0x1000, Attr=0x21
    12	./opt/ltp/testcases/data/rpc01
    [  157.600430] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3870000, LEN 0x1000, Attr=0x21
    100	./opt/ltp/testcases/data/file01
    [  157.600432] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2ff3000, LEN 0xd000, Attr=0x21
    52	./opt/ltp/testcases/data/nm01
    [  157.600435] mmc1: sdhci: 8c19e0224: DMA 0x00000008c5400000, LEN 0x0000, Attr=0x21
    12	[  157.600437] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    ./opt/ltp/testcases/data/binfmt_misc02
    [  157.746934] mmc1: ADMA error: 0x02000002
    12	./opt/ltp/testcases/data/ima_keys
    [  157.746939] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    24	./opt/ltp/testcases/data/ld01
    [  157.746942] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    1476	./opt/ltp/testcases/data/stress_floppy/dumpdir
    [  157.746944] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    2920	./opt/ltp/testcases/data/stress_floppy
    [  157.746946] mmc1: sdhci: Argument:  0x00043308 | Trn mode: 0x0000003b
    3276	./opt/ltp/testcases/data
    [  157.746949] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.746951] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.746953] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.746956] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.746958] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  157.746960] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  157.746963] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  157.746965] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  157.746967] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  157.746970] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  157.746972] mmc1: sdhci: Host ctl2: 0x00000c00
    [  157.746974] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    [  157.746976] mmc1: sdhci: ============================================
    [  157.746977] mmc1: sdhci: 8c19e0200: DMA 0x00000008c5410000, LEN 0x7000, Attr=0x21
    [  157.746980] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3876000, LEN 0x1000, Attr=0x21
    [  157.746982] mmc1: sdhci: 8c19e0218: DMA 0x00000008c5417000, LEN 0x0000, Attr=0x21
    [  157.746985] mmc1: sdhci: 8c19e0224: DMA 0x00000008c5427000, LEN 0x7000, Attr=0x21
    [  157.746987] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  157.752611] mmc1: ADMA error: 0x02000002
    [  157.752613] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  157.752615] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  157.752618] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  157.752620] mmc1: sdhci: Argument:  0x00043308 | Trn mode: 0x0000003b
    [  157.752622] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  157.752624] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  157.752627] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  157.752629] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  157.752631] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    80	./opt/ltp/testcases/realtime/perf/latency
    [  157.752633] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    84	./opt/ltp/testcases/realtime/perf
    [  157.752636] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    16	./opt/ltp/testcases/realtime/scripts
    [  157.752638] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    8	./opt/ltp/testcases/realtime/profiles
    [  157.752640] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    64	./opt/ltp/testcases/realtime/stress/pi-tests
    [  157.752642] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    68	./opt/ltp/testcases/realtime/stress
    [  157.752644] mmc1: sdhci: Host ctl2: 0x00000c00
    64	./opt/ltp/testcases/realtime/func/gtod_latency
    [  157.752647] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0224
    44	./opt/ltp/testcases/realtime/func/matrix_mult
    [  157.752648] mmc1: sdhci: ============================================
    36	./opt/ltp/testcases/realtime/func/hrtimer-prio
    [  157.752649] mmc1: sdhci: 8c19e0200: DMA 0x00000008c5410000, LEN 0x7000, Attr=0x21
    60	./opt/ltp/testcases/realtime/func/measurement
    [  157.752652] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3876000, LEN 0x1000, Attr=0x21
    64	./opt/ltp/testcases/realtime/func/periodic_cpu_load
    [  157.752655] mmc1: sdhci: 8c19e0218: DMA 0x00000008c5417000, LEN 0x0000, Attr=0x21
    92	./opt/ltp/testcases/realtime/func/async_handler
    [  157.752657] mmc1: sdhci: 8c19e0224: DMA 0x00000008c5427000, LEN 0x7000, Attr=0x21
    36	./opt/ltp/testcases/realtime/func/prio-wake
    [  157.752659] mmc1: sdhci: 8c19e0230: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    40	./opt/ltp/testcases/realtime/func/pthread_kill_latency
    [  158.673692] mmc1: ADMA error: 0x02000002
    40	./opt/ltp/testcases/realtime/func/sched_latency
    [  158.673702] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    36	./opt/ltp/testcases/realtime/func/pi_perf
    [  158.673704] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    248	./opt/ltp/testcases/realtime/func/pi-tests
    [  158.673706] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    40	./opt/ltp/testcases/realtime/func/sched_jitter
    [  158.673709] mmc1: sdhci: Argument:  0x00044008 | Trn mode: 0x0000003b
    36	./opt/ltp/testcases/realtime/func/sched_football
    [  158.673712] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    36	./opt/ltp/testcases/realtime/func/prio-preempt
    [  158.673715] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    36	./opt/ltp/testcases/realtime/func/thread_clock
    [  158.673717] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    40	./opt/ltp/testcases/realtime/func/rt-migrate
    [  158.673720] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    952	./opt/ltp/testcases/realtime/func
    [  158.673722] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    1132	./opt/ltp/testcases/realtime
    [  158.673724] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    315772	./opt/ltp/testcases
    [  158.673726] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  158.673729] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  158.673731] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  158.673734] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  158.673736] mmc1: sdhci: Host ctl2: 0x00000c00
    [  158.673738] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0248
    [  158.673740] mmc1: sdhci: ============================================
    [  158.673741] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f20000, LEN 0x1000, Attr=0x21
    [  158.673744] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2f3e000, LEN 0x1000, Attr=0x21
    [  158.673747] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2ecf000, LEN 0x1000, Attr=0x21
    [  158.673749] mmc1: sdhci: 8c19e0224: DMA 0x00000008c3a8f000, LEN 0x1000, Attr=0x21
    [  158.673751] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2eca000, LEN 0x1000, Attr=0x21
    [  158.673753] mmc1: sdhci: 8c19e023c: DMA 0x00000008c2fb0000, LEN 0x0000, Attr=0x21
    [  158.673756] mmc1: sdhci: 8c19e0248: DMA 0x00000008c2fc0000, LEN 0xb000, Attr=0x21
    [  158.673758] mmc1: sdhci: 8c19e0254: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  158.679565] mmc1: ADMA error: 0x02000002
    [  158.679568] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  158.679569] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  158.679572] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  158.679574] mmc1: sdhci: Argument:  0x00044008 | Trn mode: 0x0000003b
    [  158.679576] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  158.679578] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  158.679580] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  158.679583] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  158.679585] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  158.679587] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  158.679589] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  158.679592] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    16	./opt/ltp/conformance/interfaces/pthread_mutex_destroy/specul[  158.679594] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ative
    [  158.679596] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    80	./opt/ltp/conformance/interfaces/pthread_mutex_destroy
    [  158.679598] mmc1: sdhci: Host ctl2: 0x00000c00
    [  158.679600] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0248
    [  158.679602] mmc1: sdhci: ============================================
    [  158.679603] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2f20000, LEN 0x1000, Attr=0x21
    [  158.679606] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2f3e000, LEN 0x1000, Attr=0x21
    [  158.679608] mmc1: sdhci: 8c19e0218: DMA 0x00000008c2ecf000, LEN 0x1000, Attr=0x21
    [  158.679610] mmc1: sdhci: 8c19e0224: DMA 0x00000008c3a8f000, LEN 0x1000, Attr=0x21
    [  158.679613] mmc1: sdhci: 8c19e0230: DMA 0x00000008c2eca000, LEN 0x1000, Attr=0x21
    [  158.679615] mmc1: sdhci: 8c19e023c: DMA 0x00000008c2fb0000, LEN 0x0000, Attr=0x21
    [  158.679617] mmc1: sdhci: 8c19e0248: DMA 0x00000008c2fc0000, LEN 0xb000, Attr=0x21
    [  158.679619] mmc1: sdhci: 8c19e0254: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  159.104792] mmc1: ADMA error: 0x02000002
    [  159.104799] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  159.104801] mmc1: sdhci: Sys addr:  0x000000e8 | Version:  0x00001004
    [  159.104804] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  159.104806] mmc1: sdhci: Argument:  0x00042a20 | Trn mode: 0x0000003b
    [  159.104809] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  159.104811] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  159.104814] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  159.104816] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  159.104818] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  159.104820] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  159.104822] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  159.104825] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  159.104827] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  159.104829] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  159.104831] mmc1: sdhci: Host ctl2: 0x00000c00
    [  159.104834] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  159.104836] mmc1: sdhci: ============================================
    [  159.104837] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2fcc000, LEN 0x0000, Attr=0x21
    28	./opt/ltp/conformance/interfaces/pthread_rwlock_destroy
    [  159.104839] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2fdc000, LEN 0x3000, Attr=0x21
    36	./opt/ltp/conformance/interfaces/pthread_mutexattr_getpriocei[  159.104842] mmc1: sdhci: 8c19e0218: DMA 0x00000008c545d000, LEN 0x3000, Attr=0x21
    ling
    [  159.104844] mmc1: sdhci: 8c19e0224: DMA 0x00000008c25b8000, LEN 0x4000, Attr=0x21
    68	./opt/ltp/conformance/interfaces/pthread_attr_setinheritsched[  159.104846] mmc1: sdhci: 8c19e0230: DMA 0x00000008c3aaf000, LEN 0x1000, Attr=0x21
    88	./opt/ltp/conformance/interfaces/pthread_atfork
    [  159.104849] mmc1: sdhci: 8c19e023c: DMA 0x00000008c25bc000, LEN 0x2000, Attr=0x21
    28	./opt/ltp/conformance/interfaces/pthread_barrierattr_init
    [  159.104851] mmc1: sdhci: 8c19e0248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    40	./opt/ltp/conformance/interfaces/pthread_setcancelstate
    [  159.110146] mmc1: ADMA error: 0x02000002
    [  159.110149] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  159.110150] mmc1: sdhci: Sys addr:  0x000000e8 | Version:  0x00001004
    [  159.110153] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  159.110155] mmc1: sdhci: Argument:  0x00042a20 | Trn mode: 0x0000003b
    [  159.110157] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  159.110159] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    40	./opt/ltp/conformance/interfaces/pthread_attr_setscope
    [  159.110162] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    92	./opt/ltp/conformance/interfaces/munmap
    [  159.110164] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    40	./opt/ltp/conformance/interfaces/pthread_condattr_destroy
    [  159.110166] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    40	./opt/ltp/conformance/interfaces/pthread_mutex_getprioceiling[  159.110168] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    60	./opt/ltp/conformance/interfaces/mq_close
    [  159.110170] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    60	./opt/ltp/conformance/interfaces/pthread_rwlock_unlock
    [  159.110172] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    284	./opt/ltp/conformance/interfaces/shm_open
    [  159.110175] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    184	./opt/ltp/conformance/interfaces/pthread_cond_timedwait
    [  159.110177] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  159.110179] mmc1: sdhci: Host ctl2: 0x00000c00attr_setschedpolicy
    56	./opt/ltp/conformance/interfaces/pthread_mutexattr_setpshare[  159.110181] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    d
    [  159.110183] mmc1: sdhci: ============================================
    [  159.110184] mmc1: sdhci: 8c19e0200: DMA 0x00000008c2fcc000, LEN 0x0000, Attr=0x21
    [  159.110187] mmc1: sdhci: 8c19e020c: DMA 0x00000008c2fdc000, LEN 0x3000, Attr=0x21
    [  159.110189] mmc1: sdhci: 8c19e0218: DMA 0x00000008c545d000, LEN 0x3000, Attr=0x21
    [  159.110191] mmc1: sdhci: 8c19e0224: DMA 0x00000008c25b8000, LEN 0x4000, Attr=0x21
    [  159.110193] mmc1: sdhci: 8c19e0230: DMA 0x00000008c3aaf000, LEN 0x1000, Attr=0x21
    [  159.110196] mmc1: sdhci: 8c19e023c: DMA 0x00000008c25bc000, LEN 0x2000, Attr=0x21
    [  159.110198] mmc1: sdhci: 8c19e0248: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  159.312386] mmc1: ADMA error: 0x02000002
    [  159.312392] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  159.312394] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    [  159.312397] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  159.312399] mmc1: sdhci: Argument:  0x00042b08 | Trn mode: 0x0000003b
    [  159.312402] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  159.312404] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  159.312406] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  159.312408] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  159.312411] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  159.312413] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  159.312415] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  159.312417] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  159.312420] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  159.312422] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  159.312424] mmc1: sdhci: Host ctl2: 0x00000c00
    [  159.312426] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0230
    [  159.312428] mmc1: sdhci: ============================================
    48	./opt/ltp/conformance/interfaces/sigdelset
    [  159.312429] mmc1: sdhci: 8c19e0200: DMA 0x00000008c25be000, LEN 0x2000, Attr=0x21
    [  159.312432] mmc1: sdhci: 8c19e020c: DMA 0x00000008c5468000, LEN 0x3000, Attr=0x21
    20	./opt/ltp/conformance/interfaces/pthread_setschedprio
    [  159.312435] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3ab2000, LEN 0x1000, Attr=0x21
    [  159.312437] mmc1: sdhci: 8c19e0224: DMA 0x00000008c546b000, LEN 0x0000, Attr=0x21
    [  159.312439] mmc1: sdhci: 8c19e0230: DMA 0x00000008c547b000, LEN 0xa000, Attr=0x21
    224	./opt/ltp/conformance/interfaces/sched_setscheduler
    [  159.312441] mmc1: sdhci: 8c19e023c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    24	./opt/ltp/conformance/interfaces/strncpy
    [  159.318264] mmc1: ADMA error: 0x02000002
    16	./opt/ltp/conformance/interfaces/pthread_rwlock_trywrlock/spe[  159.318267] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    culative
    40	./opt/ltp/conformance/interfaces/pthread_rwlock_try[  159.318269] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    wrlock
    [  159.318271] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    36	./opt/ltp/conformance/interfaces/pthread_key_delete
    [  159.318273] mmc1: sdhci: Argument:  0x00042b08 | Trn mode: 0x0000003b
    20	./opt/ltp/conformance/interfaces/pthread_mutex_init/speculati[  159.318275] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    ve
    104	./opt/ltp/conformance/interfaces/pthread_mutex_init
    [  159.318278] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  159.318280] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    20	./opt/ltp/conformance/interfaces/pthread_attr_getstacksize
    [  159.318282] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    88	./opt/ltp/conformance/interfaces/sigset
    [  159.318284] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    32	./opt/ltp/conformance/interfaces/timer_create/speculative
    [  159.318286] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    124	./opt/ltp/conformance/interfaces/timer_create
    [  159.318288] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    68	./opt/ltp/conformance/interfaces/aio_return
    [  159.318291] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    16	./opt/ltp/conformance/interfaces/pthread_self
    [  159.318293] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  159.318295] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  159.318297] mmc1: sdhci: Host ctl2: 0x00000c00
    [  159.318300] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0230
    [  159.318301] mmc1: sdhci: ============================================
    [  159.318302] mmc1: sdhci: 8c19e0200: DMA 0x00000008c25be000, LEN 0x2000, Attr=0x21
    [  159.318305] mmc1: sdhci: 8c19e020c: DMA 0x00000008c5468000, LEN 0x3000, Attr=0x21
    [  159.318307] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3ab2000, LEN 0x1000, Attr=0x21
    [  159.318309] mmc1: sdhci: 8c19e0224: DMA 0x00000008c546b000, LEN 0x0000, Attr=0x21
    [  159.318312] mmc1: sdhci: 8c19e0230: DMA 0x00000008c547b000, LEN 0xa000, Attr=0x21
    [  159.318314] mmc1: sdhci: 8c19e023c: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  159.586477] mmc1: ADMA error: 0x02000002
    [  159.586484] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  159.586486] mmc1: sdhci: Sys addr:  0x00000400 | Version:  0x00001004
    [  159.586489] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  159.586491] mmc1: sdhci: Argument:  0x00c82ea8 | Trn mode: 0x0000002b
    [  159.586493] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  159.586496] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  159.586498] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  159.586500] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  159.586503] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  159.586505] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  159.586507] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  159.586509] mmc1: sdhci: Cmd:       0x0000193a | Max curr: 0x00000000
    [  159.586512] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  159.586514] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  159.586516] mmc1: sdhci: Host ctl2: 0x00000c00
    [  159.586518] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e0314
    [  159.586520] mmc1: sdhci: ============================================
    [  159.586521] mmc1: sdhci: 8c19e0200: DMA 0x00000008c3145000, LEN 0x1000, Attr=0x21
    [  159.586524] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3168000, LEN 0xa000, Attr=0x21
    [  159.586527] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3192000, LEN 0x2000, Attr=0x21
    [  159.586529] mmc1: sdhci: 8c19e0224: DMA 0x00000008c3196000, LEN 0x3000, Attr=0x21
    [  159.586531] mmc1: sdhci: 8c19e0230: DMA 0x00000008c3114000, LEN 0x1000, Attr=0x21
    4164	./opt/ltp/conformance/interfaces/sigaction
    [  159.586533] mmc1: sdhci: 8c19e023c: DMA 0x00000008c3199000, LEN 0x2000, Attr=0x21
    80	./opt/ltp/conformance/interfaces/pthread_rwlock_rdlock
    [  159.586536] mmc1: sdhci: 8c19e0248: DMA 0x00000008c30d3000, LEN 0x1000, Attr=0x21
    24	./opt/ltp/conformance/interfaces/pthread_attr_setschedparam/s[  159.586538] mmc1: sdhci: 8c19e0254: DMA 0x00000008c319b000, LEN 0xc000, Attr=0x21
    peculative
    [  159.586540] mmc1: sdhci: 8c19e0260: DMA 0x00000008c312a000, LEN 0x1000, Attr=0x21
    84	./opt/ltp/conformance/interfaces/pthread_attr_setschedparam
    [  159.586542] mmc1: sdhci: 8c19e026c: DMA 0x00000008c31a7000, LEN 0x1000, Attr=0x21
    28	./opt/ltp/conformance/interfaces/pthread_testcancel
    [  159.586544] mmc1: sdhci: 8c19e0278: DMA 0x00000008c312e000, LEN 0x1000, Attr=0x21
    16	./opt/ltp/conformance/interfaces/pthread_getcpuclockid/specul[  159.586547] mmc1: sdhci: 8c19e0284: DMA 0x00000008c31a8000, LEN 0x6000, Attr=0x21
    ative
    36	./opt/ltp/conformance/interfaces/pthread_getcpuclockid[  159.586549] mmc1: sdhci: 8c19e0290: DMA 0x00000008c315a000, LEN 0x1000, Attr=0x21
    52	./opt/ltp/conformance/interfaces/pthread_spin_init
    [  159.586551] mmc1: sdhci: 8c19e029c: DMA 0x00000008c31ae000, LEN 0x4000, Attr=0x21
    136	./opt/ltp/conformance/interfaces/aio_fsync
    [  159.586553] mmc1: sdhci: 8c19e02a8: DMA 0x00000008c3115000, LEN 0x1000, Attr=0x21
    80	./opt/ltp/conformance/interfaces/sem_wait
    [  159.586555] mmc1: sdhci: 8c19e02b4: DMA 0x00000008c31b2000, LEN 0x1000, Attr=0x21
    24	./opt/ltp/conformance/interfaces/pthread_mutexattr_init
    [  159.586557] mmc1: sdhci: 8c19e02c0: DMA 0x00000008c312f000, LEN 0x1000, Attr=0x21
    32	./opt/ltp/conformance/interfaces/pthread_barrier_destroy
    [  159.586560] mmc1: sdhci: 8c19e02cc: DMA 0x00000008c3125000, LEN 0x1000, Attr=0x21
    24	./opt/ltp/conformance/interfaces/sigemptyset
    [  159.586562] mmc1: sdhci: 8c19e02d8: DMA 0x00000008c31b3000, LEN 0x1000, Attr=0x21
    112	./opt/ltp/conformance/interfaces/nanosleep
    [  159.586564] mmc1: sdhci: 8c19e02e4: DMA 0x00000008c31d4000, LEN 0x1000, Attr=0x21
    16	./opt/ltp/conformance/interfaces/sched_rr_get_interval/specul[  159.586567] mmc1: sdhci: 8c19e02f0: DMA 0x00000008c30de000, LEN 0x1000, Attr=0x21
    ative
    52	./opt/ltp/conformance/interfaces/sched_rr_get_interval[  159.586569] mmc1: sdhci: 8c19e02fc: DMA 0x00000008c31d5000, LEN 0x1000, Attr=0x21
    72	./opt/ltp/conformance/interfaces/sem_post
    [  159.586571] mmc1: sdhci: 8c19e0308: DMA 0x00000008c31d7000, LEN 0x0000, Attr=0x21
    20	./opt/ltp/conformance/interfaces/pthread_attr_getscope
    [  159.586574] mmc1: sdhci: 8c19e0314: DMA 0x00000008c31e7000, LEN 0xa000, Attr=0x21
    16	./opt/ltp/conformance/interfaces/mq_timedsend/speculative
    [  159.586576] mmc1: sdhci: 8c19e0320: DMA 0x00000008c3156000, LEN 0x1000, Attr=0x21
    284	./opt/ltp/conformance/interfaces/mq_timedsend
    [  159.586578] mmc1: sdhci: 8c19e032c: DMA 0x00000008c3127000, LEN 0x1000, Attr=0x21
    28	./opt/ltp/conformance/interfaces/pthread_setspecific
    [  159.586581] mmc1: sdhci: 8c19e0338: DMA 0x00000008c31f1000, LEN 0x4000, Attr=0x21
    20	./opt/ltp/conformance/interfaces/getpid
    [  159.586583] mmc1: sdhci: 8c19e0344: DMA 0x00000008c3215000, LEN 0x2000, Attr=0x21
    96	./opt/ltp/conformance/interfaces/pthread_cond_wait
    [  159.586585] mmc1: sdhci: 8c19e0350: DMA 0x00000008c3218000, LEN 0x3000, Attr=0x21
    20	./opt/ltp/conformance/interfaces/difftime
    [  159.586587] mmc1: sdhci: 8c19e035c: DMA 0x00000008c315e000, LEN 0x1000, Attr=0x21
    100	./opt/ltp/conformance/interfaces/pthread_mutex_trylock
    [  159.586589] mmc1: sdhci: 8c19e0368: DMA 0x00000008c321b000, LEN 0x1000, Attr=0x21
    16	./opt/ltp/conformance/interfaces/sched_getparam/speculative
    [  159.586592] mmc1: sdhci: 8c19e0374: DMA 0x00000008c30ea000, LEN 0x1000, Attr=0x21
    72	./opt/ltp/conformance/interfaces/sched_getparam
    [  159.586594] mmc1: sdhci: 8c19e0380: DMA 0x00000008c321c000, LEN 0x1000, Attr=0x21
    28	./opt/ltp/conformance/interfaces/pthread_rwlockattr_init
    [  159.586596] mmc1: sdhci: 8c19e038c: DMA 0x00000008c30d7000, LEN 0x1000, Attr=0x21
    48	./opt/ltp/conformance/interfaces/clock_getcpuclockid
    [  159.586599] mmc1: sdhci: 8c19e0398: DMA 0x00000008c321d000, LEN 0x2000, Attr=0x21
    116	./opt/ltp/conformance/interfaces/sem_unlink
    [  159.586601] mmc1: sdhci: 8c19e03a4: DMA 0x00000008c312d000, LEN 0x1000, Attr=0x21
    56	./opt/ltp/conformance/interfaces/pthread_spin_lock
    [  159.586603] mmc1: sdhci: 8c19e03b0: DMA 0x00000008c321f000, LEN 0x9000, Attr=0x21
    20	./opt/ltp/conformance/interfaces/pthread_cond_destroy/specula[  159.586605] mmc1: sdhci: 8c19e03bc: DMA 0x00000008c3121000, LEN 0x1000, Attr=0x21
    tive
    64	./opt/ltp/conformance/interfaces/pthread_cond_destroy
    [  159.586608] mmc1: sdhci: 8c19e03c8: DMA 0x00000008c3228000, LEN 0xe000, Attr=0x21
    100	./opt/ltp/conformance/interfaces/sem_init
    [  159.586610] mmc1: sdhci: 8c19e03d4: DMA 0x00000008c3247000, LEN 0x4000, Attr=0x21
    28	./opt/ltp/conformance/interfaces/pthread_spin_destroy
    [  159.586612] mmc1: sdhci: 8c19e03e0: DMA 0x00000008c30d2000, LEN 0x1000, Attr=0x21
    40	./opt/ltp/conformance/interfaces/pthread_attr_init
    [  159.586614] mmc1: sdhci: 8c19e03ec: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    16	./opt/ltp/conformance/interfaces/mktime
    [  159.735959] mmc1: ADMA error: 0x02000002
    88	./opt/ltp/conformance/interfaces/pthread_rwlock_timedrdlock
    [  159.735966] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    52	./opt/ltp/conformance/interfaces/sem_getvalue
    [  159.735968] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    72	./opt/ltp/conformance/interfaces/sigwaitinfo
    [  159.735971] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    32	./opt/ltp/conformance/interfaces/timer_getoverrun/speculative[  159.735973] mmc1: sdhci: Argument:  0x00042d00 | Trn mode: 0x0000003b
    92	./opt/ltp/conformance/interfaces/timer_getoverrun
    [  159.735976] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    236	./opt/ltp/conformance/interfaces/fork
    [  159.735978] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    32	./opt/ltp/conformance/interfaces/fsync
    [  159.735980] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    68	./opt/ltp/conformance/interfaces/pthread_attr_setstack
    [  159.735983] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    36	./opt/ltp/conformance/interfaces/pthread_spin_trylock
    [  159.735985] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    60	./opt/ltp/conformance/interfaces/pthread_mutex_unlock
    [  159.735987] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    44	./opt/ltp/conformance/interfaces/aio_error
    [  159.735989] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    48	./opt/ltp/conformance/interfaces/sigsuspend
    [  159.735991] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    32	./opt/ltp/conformance/interfaces/pthread_barrierattr_getpshar[  159.735994] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    ed
    44	./opt/ltp/conformance/interfaces/pthread_mutexattr_getpsh[  159.735996] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    ared
    132	./opt/ltp/conformance/interfaces/aio_write
    [  159.735998] mmc1: sdhci: Host ctl2: 0x00000c00
    40	./opt/ltp/conformance/interfaces/pthread_rwlockattr_getpshare[  159.736000] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e026c
    d
    40	./opt/ltp/conformance/interfaces/munlock
    [  159.736002] mmc1: sdhci: ============================================
    52	./opt/ltp/conformance/interfaces/sigpause
    [  159.736004] mmc1: sdhci: 8c19e0200: DMA 0x00000008c548a000, LEN 0x1000, Attr=0x21
    64	./opt/ltp/conformance/interfaces/aio_suspend
    [  159.736006] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3abf000, LEN 0x1000, Attr=0x21
    112	./opt/ltp/conformance/interfaces/sigqueue
    [  159.736009] mmc1: sdhci: 8c19e0218: DMA 0x00000008c5489000, LEN 0x1000, Attr=0x21
    48	./opt/ltp/conformance/interfaces/sigtimedwait
    [  159.736011] mmc1: sdhci: 8c19e0224: DMA 0x00000008c5488000, LEN 0x1000, Attr=0x21
    84	./opt/ltp/conformance/interfaces/sigwait
    [  159.736013] mmc1: sdhci: 8c19e0230: DMA 0x00000008c5487000, LEN 0x1000, Attr=0x21
    40	./opt/ltp/conformance/interfaces/mq_open/speculative
    [  159.736016] mmc1: sdhci: 8c19e023c: DMA 0x00000008c5486000, LEN 0x1000, Attr=0x21
    260	./opt/ltp/conformance/interfaces/mq_open
    [  159.736018] mmc1: sdhci: 8c19e0248: DMA 0x00000008c5485000, LEN 0x1000, Attr=0x21
    32	./opt/ltp/conformance/interfaces/sigrelse
    [  159.736020] mmc1: sdhci: 8c19e0254: DMA 0x00000008c2761000, LEN 0x1000, Attr=0x21
    40	./opt/ltp/conformance/interfaces/pthread_condattr_setclock
    [  159.736022] mmc1: sdhci: 8c19e0260: DMA 0x00000008c548d000, LEN 0x0000, Attr=0x21
    184	./opt/ltp/conformance/interfaces/mq_send
    [  159.736024] mmc1: sdhci: 8c19e026c: DMA 0x00000008c549d000, LEN 0x3000, Attr=0x21
    44	./opt/ltp/conformance/interfaces/sem_close
    [  159.736027] mmc1: sdhci: 8c19e0278: DMA 0x00000008c2668000, LEN 0x5000, Attr=0x21
    128	./opt/ltp/conformance/interfaces/aio_cancel
    [  159.736029] mmc1: sdhci: 8c19e0284: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    88	./opt/ltp/conformance/interfaces/pthread_rwlock_timedwrlock
    [  159.741820] mmc1: ADMA error: 0x02000002
    176	./opt/ltp/conformance/interfaces/pthread_exit
    [  159.741823] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    28	./opt/ltp/conformance/interfaces/pthread_condattr_getclock
    [  159.741824] mmc1: sdhci: Sys addr:  0x00000100 | Version:  0x00001004
    32	./opt/ltp/conformance/interfaces/timer_gettime/speculative
    [  159.741827] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    104	./opt/ltp/conformance/interfaces/timer_gettime
    [  159.741829] mmc1: sdhci: Argument:  0x00042d00 | Trn mode: 0x0000003b
    36	./opt/ltp/conformance/interfaces/pthread_mutexattr_setprotoco[  159.741831] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    l
    96	./opt/ltp/conformance/interfaces/sigaltstack
    [  159.741833] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    16	./opt/ltp/conformance/interfaces/pthread_key_create/speculati[  159.741836] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    ve
    56	./opt/ltp/conformance/interfaces/pthread_key_create
    [  159.741838] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  159.741840] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    56	./opt/ltp/conformance/interfaces/signal
    [  159.741842] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    188	./opt/ltp/conformance/interfaces/lio_listio
    [  159.741844] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    232	./opt/ltp/conformance/interfaces/sched_setparam
    [  159.741846] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    112	./opt/ltp/conformance/interfaces/pthread_detach
    [  159.741849] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    16	./opt/ltp/conformance/interfaces/mq_unlink/speculative
    [  159.741851] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    72	./opt/ltp/conformance/interfaces/mq_unlink
    [  159.741853] mmc1: sdhci: Host ctl2: 0x00000c00
    52	./opt/ltp/conformance/interfaces/pthread_setschedparam
    [  159.741855] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e026c
    44	./opt/ltp/conformance/interfaces/pthread_setcanceltype
    [  159.741857] mmc1: sdhci: ============================================
    64	./opt/ltp/conformance/interfaces/pthread_mutex_timedlock
    [  159.741858] mmc1: sdhci: 8c19e0200: DMA 0x00000008c548a000, LEN 0x1000, Attr=0x21
    32	./opt/ltp/conformance/interfaces/clock_settime/speculative
    [  159.741860] mmc1: sdhci: 8c19e020c: DMA 0x00000008c3abf000, LEN 0x1000, Attr=0x21
    188	./opt/ltp/conformance/interfaces/clock_settime[  159.741863] mmc1: sdhci: 8c19e0218: DMA 0x00000008c5489000, LEN 0x1000, Attr=0x21
    [  159.741865] mmc1: sdhci: 8c19e0224: DMA 0x00000008c5488000, LEN 0x1000, Attr=0x21
    48	./opt/ltp/conformance/interfaces/pthread_cond_init
    [  159.741867] mmc1: sdhci: 8c19e0230: DMA 0x00000008c5487000, LEN 0x1000, Attr=0x21
    40	./opt/ltp/conformance/interfaces/pthread_cleanup_push
    [  159.741870] mmc1: sdhci: 8c19e023c: DMA 0x00000008c5486000, LEN 0x1000, Attr=0x21
    132	./opt/ltp/conformance/interfaces/aio_read
    [  159.741872] mmc1: sdhci: 8c19e0248: DMA 0x00000008c5485000, LEN 0x1000, Attr=0x21
    32	./opt/ltp/conformance/interfaces/sigismember
    [  159.741875] mmc1: sdhci: 8c19e0254: DMA 0x00000008c2761000, LEN 0x1000, Attr=0x21
    28	./opt/ltp/conformance/interfaces/timer_delete/speculative
    [  159.741877] mmc1: sdhci: 8c19e0260: DMA 0x00000008c548d000, LEN 0x0000, Attr=0x21
    64	./opt/ltp/conformance/interfaces/timer_delete
    [  159.741879] mmc1: sdhci: 8c19e026c: DMA 0x00000008c549d000, LEN 0x3000, Attr=0x21
    [  159.741882] mmc1: sdhci: 8c19e0278: DMA 0x00000008c2668000, LEN 0x5000, Attr=0x21
    112	./opt/ltp/conformance/interfaces/sem_open
    [  159.741884] mmc1: sdhci: 8c19e0284: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    24	./opt/ltp/conformance/interfaces/gmtime
    [  160.133007] mmc1: ADMA error: 0x02000002
    36	./opt/ltp/conformance/interfaces/pthread_mutexattr_setpriocei[  160.133015] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    ling
    68	./opt/ltp/conformance/interfaces/pthread_mutex_lock
    [  160.133017] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    36	./opt/ltp/conformance/interfaces/pthread_equal
    [  160.133019] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    20	./opt/ltp/conformance/interfaces/munlockall
    [  160.133022] mmc1: sdhci: Argument:  0x00042c08 | Trn mode: 0x0000003b
    72	./opt/ltp/conformance/interfaces/clock_getres
    [  160.133024] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    64	./opt/ltp/conformance/interfaces/pthread_barrier_wait
    [  160.133027] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    132	./opt/ltp/conformance/interfaces/clock_nanosleep
    [  160.133029] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    24	./opt/ltp/conformance/interfaces/pthread_attr_getschedparam
    [  160.133032] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    104	./opt/ltp/conformance/interfaces/sigprocmask
    [  160.133034] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    16	./opt/ltp/conformance/interfaces/mq_getattr/speculative
    [  160.133036] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    68	./opt/ltp/conformance/interfaces/mq_getattr
    [  160.133038] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    72	./opt/ltp/conformance/interfaces/pthread_once
    [  160.133041] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    44	./opt/ltp/conformance/interfaces/pthread_attr_setstacksize
    [  160.133043] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    20	./opt/ltp/conformance/interfaces/mlockall/speculative
    [  160.133045] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    96	./opt/ltp/conformance/interfaces/mlockall
    [  160.133047] mmc1: sdhci: Host ctl2: 0x00000c00
    100	./opt/ltp/conformance/interfaces/shm_unlink
    [  160.133049] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    28	./opt/ltp/conformance/interfaces/pthread_barrierattr_setpshar[  160.133052] mmc1: sdhci: ========================================
    [  160.133052] mmc1: sdhci: ============================================
    [  160.133053] mmc1: sdhci: 8c19e0200: DMA 0x00000008c54a8000, LEN 0x0000, Attr=0x21
    [  160.133056] mmc1: sdhci: 8c19e020c: DMA 0x00000008c54b8000, LEN 0xe000, Attr=0x21
    [  160.133058] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3aeb000, LEN 0x1000, Attr=0x21
    [  160.133061] mmc1: sdhci: 8c19e0224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  160.138691] mmc1: ADMA error: 0x02000002
    [  160.138694] mmc1: sdhci: ============ SDHCI REGISTER DUMP ===========
    [  160.138696] mmc1: sdhci: Sys addr:  0x000000f8 | Version:  0x00001004
    [  160.138698] mmc1: sdhci: Blk size:  0x00007200 | Blk cnt:  0x00000000
    [  160.138700] mmc1: sdhci: Argument:  0x00042c08 | Trn mode: 0x0000003b
    [  160.138703] mmc1: sdhci: Present:   0x01f70000 | Host ctl: 0x0000001b
    [  160.138705] mmc1: sdhci: Power:     0x0000000f | Blk gap:  0x00000080
    [  160.138707] mmc1: sdhci: Wake-up:   0x00000000 | Clock:    0x00000207
    [  160.138710] mmc1: sdhci: Timeout:   0x00000000 | Int stat: 0x00000000
    [  160.138712] mmc1: sdhci: Int enab:  0x03ff008b | Sig enab: 0x03ff008b
    [  160.138714] mmc1: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
    [  160.138716] mmc1: sdhci: Caps:      0x3fe8c801 | Caps_1:   0x18002407
    [  160.138719] mmc1: sdhci: Cmd:       0x0000123a | Max curr: 0x00000000
    [  160.138721] mmc1: sdhci: Resp[0]:   0x00000900 | Resp[1]:  0x4780ba5c
    [  160.138723] mmc1: sdhci: Resp[2]:   0x534c3136 | Resp[3]:  0x00000900
    [  160.138725] mmc1: sdhci: Host ctl2: 0x00000c00
    [  160.138727] mmc1: sdhci: ADMA Err:  0x00000000 | ADMA Ptr: 0x00000008c19e020c
    [  160.138729] mmc1: sdhci: ============================================
    [  160.138731] mmc1: sdhci: 8c19e0200: DMA 0x00000008c54a8000, LEN 0x0000, Attr=0x21
    [  160.138734] mmc1: sdhci: 8c19e020c: DMA 0x00000008c54b8000, LEN 0xe000, Attr=0x21
    [  160.138736] mmc1: sdhci: 8c19e0218: DMA 0x00000008c3aeb000, LEN 0x1000, Attr=0x21
    [  160.138739] mmc1: sdhci: 8c19e0224: DMA 0x0000000000000000, LEN 0x0000, Attr=0x03
    [  161.690387] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000008
    [  161.881936] Mem abort info:
    [  161.884971]   ESR = 0x96000006
    [  161.888265]   EC = 0x25: DABT (current EL), IL = 32 bits
    [  161.893818]   SET = 0, FnV = 0
    [  161.897115]   EA = 0, S1PTW = 0
    [  161.900497] Data abort info:
    [  161.903450]   ISV = 0, ISS = 0x00000006
    [  161.903473] printk: console [ttyS2]: printing thread stopped
    [  161.907274]   CM = 0, WnR = 0
    [ed
    144	./opt/ltp/conformance/interfaces/pthread_sigmask
      161.915863] user pgtable: 4k pages, 48-bit VAs, pgdp=00000008c2c8e000
    [  161.927320] [0000000000000008] pgd=00000008c2c40003, p4d=00000008c2c40003, pud=00000008c2c4d003, pmd=0000000000000000
    [  161.937910] Internal error: Oops: 96000006 [#1] PREEMPT_RT SMP
    [  161.943726] Modules linked in:
    [  161.946768] CPU: 1 PID: 150 Comm: irq/39-46000000 Not tainted 5.10.65-rt53 #2
    [  161.953885] Hardware name: Texas Instruments K3 J721E SoC (DT)
    [  161.959698] pstate: 40000005 (nZcv daif -PAN -UAO -TCO BTYPE=--)
    [  161.965687] pc : skb_release_data+0x84/0x1a0
    [  161.969952] lr : skb_release_all+0x28/0x38
    [  161.974034] sp : ffff8000116c36e0
    [  161.977333] x29: ffff8000116c36e0 x28: ffff8000111ae540
    [  161.982628] x27: ffff000842f6f8a2 x26: 0000000000000000
    [  161.987923] x25: 0000000000000000 x24: ffffffffffffff98
    [  161.993219] x23: 0000000000000001 x22: ffff000842f6fe80
    [  161.998512] x21: ffff0008419ff800 x20: ffff000842f6fec0
    [  162.003807] x19: 0000000000000000 x18: 0000000000000000
    [  162.009102] x17: 0000000000000000 x16: 0000000000000000
    [  162.014397] x15: 0000000000000001 x14: ffff8000116c37f0
    [  162.019692] x13: 00000000c0a805ff x12: 0000000000000001
    [  162.024987] x11: 0000000000000000 x10: 0000000000000000
    [  162.030281] x9 : ffff8000111ae540 x8 : 0000000000000062
    [  162.035576] x7 : ffff8000116c37e8 x6 : ffff000841c78000
    [  162.040871] x5 : 000000000000d683 x4 : 0000000000000000
    [  162.046166] x3 : 00000000000007ff x2 : ffff000840ec0000
    [  162.051461] x1 : 0000000000000640 x0 : 0000000000000000
    [  162.056756] Call trace:
    [  162.059189]  skb_release_data+0x84/0x1a0
    [  162.063097]  skb_release_all+0x28/0x38
    [  162.066833]  kfree_skb+0x30/0x90
    [  162.070047]  __udp4_lib_rcv+0x824/0x978
    [  162.073871]  udp_rcv+0x20/0x30
    [  162.076911]  ip_protocol_deliver_rcu+0x40/0x208
    [  162.081427]  ip_local_deliver_finish+0x68/0x88
    [  162.085855]  ip_local_deliver+0x7c/0x120
    [  162.089762]  ip_sublist_rcv_finish+0x48/0x68
    [  162.094016]  ip_sublist_rcv+0x110/0x190
    [  162.097836]  ip_list_rcv+0x104/0x1b0
    [  162.101397]  __netif_receive_skb_list_core+0x184/0x210
    [  162.106520]  netif_receive_skb_list_internal+0x18c/0x2a0
    [  162.111815]  napi_complete_done+0xbc/0x208
    [  162.115897]  am65_cpsw_nuss_rx_poll+0x280/0x380
    [  162.120414]  net_rx_action+0x118/0x378
    [  162.124148]  efi_header_end+0x110/0x214
    [  162.127971]  __local_bh_enable_ip+0xcc/0x130
    [  162.132225]  irq_forced_thread_fn+0x80/0xc0
    [  162.136394]  irq_thread+0x150/0x260
    [  162.139869]  kthread+0x174/0x198
    [  162.143084]  ret_from_fork+0x10/0x34
    [  162.146649] Code: 91004294 6b13001f 5400028d f9400280 (f9400401)
    [  162.152725] ---[ end trace 0000000000000002 ]---
    [  162.157623] Kernel panic - not syncing:
    [  162.161442] Oops: Fatal exception in interrupt
    [  162.161539] SMP: stopping secondary CPUs
    [  162.169875] Kernel Offset: 0x80000 from 0xffff800010000000
    [  162.175342] PHYS_OFFSET: 0x80000000
    [  162.178815] CPU features: 0x0040022,20806008
    [  162.183071] Memory Limit: none
    [  162.186112] ---[ end Kernel panic - not syncing: Oops: Fatal exception in interrupt ]---
    您使用的 SD 卡大小是多少?
    此致,
    帕斯
