部件号:TMS320C6678 “线程:测试”中讨论的其它部件
你(们)好
使用 C6000 V8.3.2构建的函数的性能低于使用 v7.4.21构建的同一源代码。 下面是函数源代码
/* * test_adap_emph.cpp * * Created on: Feb 28, 2022 * Author: Wai.Kwok.Law */ #include "image_process_be_filter_aniso2d.h" #include "nam_tool.h" #include "image_process_be.h" #include "image_process_be_main.h" #include <c6x.h> using XtNamApi::RangeClip; #pragma CODE_SECTION(".sect_DDR2_code") void adap_emph(ip_int* restrict adap, const ip_int* restrict lineBufOrig, const ip_int* restrict lineBufFilter, const ip_int* restrict range, const tbl_int* restrict wghtTblS, const tbl_int* restrict emphTbl, const Int32 sx, const Int32 y, const ImageInfo* info, const Int32 scale, const Int32 alphaI, const Int32 betaI, const Int32 gammaI) { const Int32 scaleT = (1 << (IMAGECALC_ACCURACY)) - 1; const Int32 scale2 = (1 << (IMAGECALC_ACCURACY - 1)) - 1; #pragma MUST_ITERATE(16, MAX_IMAGE_PROCESS_BE_Y_SIZE, 2) for (Int32 x = 0; x < sx; ++x) { Int32 idx = GetViewIndex(x, y, info); Int32 value = lineBufOrig[x]; Int32 edge = range[idx]; edge = RangeClip(edge, 0, scale2); Int32 w = wghtTblS[edge]; Int32 value2 = lineBufFilter[x]; Int32 wb = (1 << IMAGECALC_ACCURACY) - w; Int32 tmp2 = (value * alphaI) >> 11; Int32 tmp3 = (value * betaI + value2 * gammaI) >> 11; Int32 tmp = (tmp2 * wb + tmp3 * w) >> IMAGECALC_ACCURACY; tmp = RangeClip(tmp, -scale2 - 1, scale2);//actually image range is +2^15~-2^15, but original algorithm is clip under 2^14. It will help image saturate. tmp = emphTbl[tmp + scaleT + 1]; adap[idx] = tmp; } }
#ifndef NAM_TOOL_H #define NAM_TOOL_H namespace XtNamApi { /*! * zero or not decision * @param[in] value evaluated value * @retval true zero * @retval false not zero */ template <typename T> static inline bool IsZero(T value) { return ( value == static_cast<T>(0) ); } /*! * Is equal decision * @param[in] a Input1 * @param[in] b Input2 * @retval true a == b * @retval false b != b */ static inline bool IsEqual( float a, float b ) { union { float f32; int i32; } va, vb; va.f32 = a; vb.f32 = b; if ( va.i32 == vb.i32 ) { return true; } return false; } /*! * Min * @param[in] a Evaluated value * @param[in] b Evaluated value * @return Min value */ template< class T > static inline T Min( T a, T b ) { T retVal = (a <= b) ? a : b; return retVal; } /*! * Max * @param[in] a Evaluated value * @param[in] b Evaluated value * @return Min value */ template< class T > static inline T Max( T a, T b ) { T retVal = (a <= b) ? b : a; return retVal; } /*! * clip * @param[in] value value * @param[in] low bottom * @param[in] high top * @return clipped value */ template< class T > static inline T RangeClip( T value, T low, T high ) { T retVal = (value < low) ? low : value; retVal = (retVal > high) ? high : retVal; return retVal; } /*! * rounding * @date 2012/06/12 fix round off(minus) * @param[in] value evalueted value * @reurn rounded value */ static inline int RoundF2I( float value ) { if ( value < 0.0F ) { return int( value - 0.5F ); } return int( value + 0.5F ); } } // End namespace XtNamApi #endif // NAM_TOOL_H
使用两个编译器版本生成的汇编代码是
;****************************************************************************** ;* TMS320C6x C/C++ Codegen PC v7.4.21 * ;* Date/Time created: Mon Feb 28 22:34:52 2022 * ;****************************************************************************** .compiler_opts --abi=eabi --c64p_l1d_workaround=off --endian=little --hll_source=on --long_precision_bits=32 --mem_model:code=near --mem_model:const=data --mem_model:data=far --object_format=elf --silicon_version=6600 --symdebug:dwarf --symdebug:dwarf_version=3 ;****************************************************************************** ;* GLOBAL FILE PARAMETERS * ;* * ;* Architecture : TMS320C66xx * ;* Optimization : Enabled at level 3 * ;* Optimizing for : Speed * ;* Based on options: -o3, no -ms * ;* Endian : Little * ;* Interrupt Thrshld : Disabled * ;* Data Access Model : Far * ;* Pipelining : Enabled * ;* Speculate Loads : Enabled with threshold = 0 * ;* Memory Aliases : Presume are aliases (pessimistic) * ;* Debug Info : DWARF Debug w/Optimization * ;* * ;****************************************************************************** .asg A15, FP .asg B14, DP .asg B15, SP .global $bss $C$DW$CU .dwtag DW_TAG_compile_unit .dwattr $C$DW$CU, DW_AT_name("../App/BMode/Integ/src/test_adap_emph.cpp") .dwattr $C$DW$CU, DW_AT_producer("TI TMS320C6x C/C++ Codegen PC v7.4.21 Copyright (c) 1996-2017 Texas Instruments Incorporated") .dwattr $C$DW$CU, DW_AT_TI_version(0x01) .dwattr $C$DW$CU, DW_AT_comp_dir("C:\git\phx_main_1\DevProjects\Apollo_DEBUG") ; C:\ti\c6000_7.4.21\bin\opt6x.exe C:\\Users\\wlaw\\AppData\\Local\\Temp\\447082 C:\\Users\\wlaw\\AppData\\Local\\Temp\\447084 .sect ".sect_DDR2_code" .clink .global _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii $C$DW$1 .dwtag DW_TAG_subprogram, DW_AT_name("adap_emph") .dwattr $C$DW$1, DW_AT_low_pc(_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii) .dwattr $C$DW$1, DW_AT_high_pc(0x00) .dwattr $C$DW$1, DW_AT_TI_symbol_name("_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii") .dwattr $C$DW$1, DW_AT_external .dwattr $C$DW$1, DW_AT_TI_begin_file("../App/BMode/Integ/src/test_adap_emph.cpp") .dwattr $C$DW$1, DW_AT_TI_begin_line(0x12) .dwattr $C$DW$1, DW_AT_TI_begin_column(0x06) .dwattr $C$DW$1, DW_AT_decl_file("../App/BMode/Integ/src/test_adap_emph.cpp") .dwattr $C$DW$1, DW_AT_decl_line(0x12) .dwattr $C$DW$1, DW_AT_decl_column(0x06) .dwattr $C$DW$1, DW_AT_TI_max_frame_size(0x08) .dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 31,column 1,is_stmt,address _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii,isa 0 .dwfde $C$DW$CIE, _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii $C$DW$208 .dwtag DW_TAG_formal_parameter, DW_AT_name("adap") .dwattr $C$DW$208, DW_AT_TI_symbol_name("adap") .dwattr $C$DW$208, DW_AT_type(*$C$DW$T$1714) .dwattr $C$DW$208, DW_AT_location[DW_OP_reg4] $C$DW$209 .dwtag DW_TAG_formal_parameter, DW_AT_name("lineBufOrig") .dwattr $C$DW$209, DW_AT_TI_symbol_name("lineBufOrig") .dwattr $C$DW$209, DW_AT_type(*$C$DW$T$1717) .dwattr $C$DW$209, DW_AT_location[DW_OP_reg20] $C$DW$210 .dwtag DW_TAG_formal_parameter, DW_AT_name("lineBufFilter") .dwattr $C$DW$210, DW_AT_TI_symbol_name("lineBufFilter") .dwattr $C$DW$210, DW_AT_type(*$C$DW$T$1717) .dwattr $C$DW$210, DW_AT_location[DW_OP_reg6] $C$DW$211 .dwtag DW_TAG_formal_parameter, DW_AT_name("range") .dwattr $C$DW$211, DW_AT_TI_symbol_name("range") .dwattr $C$DW$211, DW_AT_type(*$C$DW$T$1717) .dwattr $C$DW$211, DW_AT_location[DW_OP_reg22] $C$DW$212 .dwtag DW_TAG_formal_parameter, DW_AT_name("wghtTblS") .dwattr $C$DW$212, DW_AT_TI_symbol_name("wghtTblS") .dwattr $C$DW$212, DW_AT_type(*$C$DW$T$1718) .dwattr $C$DW$212, DW_AT_location[DW_OP_reg8] $C$DW$213 .dwtag DW_TAG_formal_parameter, DW_AT_name("emphTbl") .dwattr $C$DW$213, DW_AT_TI_symbol_name("emphTbl") .dwattr $C$DW$213, DW_AT_type(*$C$DW$T$1718) .dwattr $C$DW$213, DW_AT_location[DW_OP_reg24] $C$DW$214 .dwtag DW_TAG_formal_parameter, DW_AT_name("sx") .dwattr $C$DW$214, DW_AT_TI_symbol_name("sx") .dwattr $C$DW$214, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$214, DW_AT_location[DW_OP_reg10] $C$DW$215 .dwtag DW_TAG_formal_parameter, DW_AT_name("y") .dwattr $C$DW$215, DW_AT_TI_symbol_name("y") .dwattr $C$DW$215, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$215, DW_AT_location[DW_OP_reg26] $C$DW$216 .dwtag DW_TAG_formal_parameter, DW_AT_name("info") .dwattr $C$DW$216, DW_AT_TI_symbol_name("info") .dwattr $C$DW$216, DW_AT_type(*$C$DW$T$1720) .dwattr $C$DW$216, DW_AT_location[DW_OP_reg12] $C$DW$217 .dwtag DW_TAG_formal_parameter, DW_AT_name("scale") .dwattr $C$DW$217, DW_AT_TI_symbol_name("scale") .dwattr $C$DW$217, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$217, DW_AT_location[DW_OP_reg28] $C$DW$218 .dwtag DW_TAG_formal_parameter, DW_AT_name("alphaI") .dwattr $C$DW$218, DW_AT_TI_symbol_name("alphaI") .dwattr $C$DW$218, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$218, DW_AT_location[DW_OP_breg31 12] $C$DW$219 .dwtag DW_TAG_formal_parameter, DW_AT_name("betaI") .dwattr $C$DW$219, DW_AT_TI_symbol_name("betaI") .dwattr $C$DW$219, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$219, DW_AT_location[DW_OP_breg31 16] $C$DW$220 .dwtag DW_TAG_formal_parameter, DW_AT_name("gammaI") .dwattr $C$DW$220, DW_AT_TI_symbol_name("gammaI") .dwattr $C$DW$220, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$220, DW_AT_location[DW_OP_breg31 20] ;****************************************************************************** ;* FUNCTION NAME: adap_emph(short *, const short *, const short *, const short *, const short *, const short *, int, int, const ImageInfo *, int, int, int, int)* ;* * ;* Regs Modified : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,B0,B4,B5,B6,B7,B8,B9, * ;* SP,FP,A16,A17,A18,A19,A20,A21,A22,A23,A24,A25, * ;* A26,A27,A28,A29,A30,A31,B16,B17,B18,B19,B20,B21, * ;* B22,B23,B24,B25,B26,B27 * ;* Regs Used : A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A12,B0,B3,B4,B5,B6,* ;* B7,B8,B9,B10,SP,FP,A16,A17,A18,A19,A20,A21,A22, * ;* A23,A24,A25,A26,A27,A28,A29,A30,A31,B16,B17,B18, * ;* B19,B20,B21,B22,B23,B24,B25,B26,B27 * ;* Local Frame Size : 0 Args + 0 Auto + 4 Save = 4 byte * ;****************************************************************************** ;****************************************************************************** ;* * ;* Using -g (debug) with optimization (-o3) may disable key optimizations! * ;* * ;****************************************************************************** _Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii: ;** --------------------------------------------------------------------------* ; EXCLUSIVE CPU CYCLES: 8 ;** 31 ----------------------- adap = adap; ;** 31 ----------------------- lineBufOrig = lineBufOrig; ;** 31 ----------------------- lineBufFilter = lineBufFilter; ;** 31 ----------------------- range = range; ;** 31 ----------------------- wghtTblS = wghtTblS; ;** 31 ----------------------- emphTbl = emphTbl; ;** 36 ----------------------- if ( sx <= 0 ) goto g4; .dwcfi cfa_offset, 0 MV .L1X SP,FP ; |31| || STW .D2T1 FP,*SP--(8) ; |31| .dwcfi cfa_offset, 8 .dwcfi save_reg_to_mem, 32, 0 $C$DW$221 .dwtag DW_TAG_variable, DW_AT_name("$O$C3") .dwattr $C$DW$221, DW_AT_TI_symbol_name("$O$C3") .dwattr $C$DW$221, DW_AT_type(*$C$DW$T$11) .dwattr $C$DW$221, DW_AT_location[DW_OP_reg3] $C$DW$222 .dwtag DW_TAG_variable, DW_AT_name("$O$C4") .dwattr $C$DW$222, DW_AT_TI_symbol_name("$O$C4") .dwattr $C$DW$222, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$222, DW_AT_location[DW_OP_reg5] $C$DW$223 .dwtag DW_TAG_variable, DW_AT_name("$O$C5") .dwattr $C$DW$223, DW_AT_TI_symbol_name("$O$C5") .dwattr $C$DW$223, DW_AT_type(*$C$DW$T$8) .dwattr $C$DW$223, DW_AT_location[DW_OP_reg2] $C$DW$224 .dwtag DW_TAG_variable, DW_AT_name("$O$C6") .dwattr $C$DW$224, DW_AT_TI_symbol_name("$O$C6") .dwattr $C$DW$224, DW_AT_type(*$C$DW$T$8) .dwattr $C$DW$224, DW_AT_location[DW_OP_regx 0x26] $C$DW$225 .dwtag DW_TAG_variable, DW_AT_name("$O$C7") .dwattr $C$DW$225, DW_AT_TI_symbol_name("$O$C7") .dwattr $C$DW$225, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$225, DW_AT_location[DW_OP_reg1] $C$DW$226 .dwtag DW_TAG_variable, DW_AT_name("$O$C8") .dwattr $C$DW$226, DW_AT_TI_symbol_name("$O$C8") .dwattr $C$DW$226, DW_AT_type(*$C$DW$T$8) .dwattr $C$DW$226, DW_AT_location[DW_OP_regx 0x26] $C$DW$227 .dwtag DW_TAG_variable, DW_AT_name("$O$C9") .dwattr $C$DW$227, DW_AT_TI_symbol_name("$O$C9") .dwattr $C$DW$227, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$227, DW_AT_location[DW_OP_regx 0x40] $C$DW$228 .dwtag DW_TAG_variable, DW_AT_name("$O$C10") .dwattr $C$DW$228, DW_AT_TI_symbol_name("$O$C10") .dwattr $C$DW$228, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$228, DW_AT_location[DW_OP_reg23] $C$DW$229 .dwtag DW_TAG_variable, DW_AT_name("$O$C11") .dwattr $C$DW$229, DW_AT_TI_symbol_name("$O$C11") .dwattr $C$DW$229, DW_AT_type(*$C$DW$T$8) .dwattr $C$DW$229, DW_AT_location[DW_OP_regx 0x3f] $C$DW$230 .dwtag DW_TAG_variable, DW_AT_name("$O$C12") .dwattr $C$DW$230, DW_AT_TI_symbol_name("$O$C12") .dwattr $C$DW$230, DW_AT_type(*$C$DW$T$8) .dwattr $C$DW$230, DW_AT_location[DW_OP_reg25] $C$DW$231 .dwtag DW_TAG_variable, DW_AT_name("$O$C13") .dwattr $C$DW$231, DW_AT_TI_symbol_name("$O$C13") .dwattr $C$DW$231, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$231, DW_AT_location[DW_OP_regx 0x37] $C$DW$232 .dwtag DW_TAG_variable, DW_AT_name("$O$C14") .dwattr $C$DW$232, DW_AT_TI_symbol_name("$O$C14") .dwattr $C$DW$232, DW_AT_type(*$C$DW$T$8) .dwattr $C$DW$232, DW_AT_location[DW_OP_regx 0x36] $C$DW$233 .dwtag DW_TAG_variable, DW_AT_name("$O$C15") .dwattr $C$DW$233, DW_AT_TI_symbol_name("$O$C15") .dwattr $C$DW$233, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$233, DW_AT_location[DW_OP_regx 0x29] $C$DW$234 .dwtag DW_TAG_variable, DW_AT_name("$O$s32") .dwattr $C$DW$234, DW_AT_TI_symbol_name("$O$s32") .dwattr $C$DW$234, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$234, DW_AT_location[DW_OP_reg24] $C$DW$235 .dwtag DW_TAG_variable, DW_AT_name("$O$s42") .dwattr $C$DW$235, DW_AT_TI_symbol_name("$O$s42") .dwattr $C$DW$235, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$235, DW_AT_location[DW_OP_reg4] $C$DW$236 .dwtag DW_TAG_variable, DW_AT_name("x") .dwattr $C$DW$236, DW_AT_TI_symbol_name("x") .dwattr $C$DW$236, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$236, DW_AT_location[DW_OP_regx 0x35] $C$DW$237 .dwtag DW_TAG_variable, DW_AT_name("gammaI") .dwattr $C$DW$237, DW_AT_TI_symbol_name("gammaI") .dwattr $C$DW$237, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$237, DW_AT_location[DW_OP_regx 0x32] $C$DW$238 .dwtag DW_TAG_variable, DW_AT_name("betaI") .dwattr $C$DW$238, DW_AT_TI_symbol_name("betaI") .dwattr $C$DW$238, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$238, DW_AT_location[DW_OP_regx 0x31] $C$DW$239 .dwtag DW_TAG_variable, DW_AT_name("alphaI") .dwattr $C$DW$239, DW_AT_TI_symbol_name("alphaI") .dwattr $C$DW$239, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$239, DW_AT_location[DW_OP_regx 0x30] $C$DW$240 .dwtag DW_TAG_variable, DW_AT_name("y") .dwattr $C$DW$240, DW_AT_TI_symbol_name("y") .dwattr $C$DW$240, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$240, DW_AT_location[DW_OP_reg26] $C$DW$241 .dwtag DW_TAG_variable, DW_AT_name("sx") .dwattr $C$DW$241, DW_AT_TI_symbol_name("sx") .dwattr $C$DW$241, DW_AT_type(*$C$DW$T$1719) .dwattr $C$DW$241, DW_AT_location[DW_OP_reg10] $C$DW$242 .dwtag DW_TAG_variable, DW_AT_name("emphTbl") .dwattr $C$DW$242, DW_AT_TI_symbol_name("emphTbl") .dwattr $C$DW$242, DW_AT_type(*$C$DW$T$1718) .dwattr $C$DW$242, DW_AT_location[DW_OP_reg24] $C$DW$243 .dwtag DW_TAG_variable, DW_AT_name("wghtTblS") .dwattr $C$DW$243, DW_AT_TI_symbol_name("wghtTblS") .dwattr $C$DW$243, DW_AT_type(*$C$DW$T$1718) .dwattr $C$DW$243, DW_AT_location[DW_OP_reg20] $C$DW$244 .dwtag DW_TAG_variable, DW_AT_name("range") .dwattr $C$DW$244, DW_AT_TI_symbol_name("range") .dwattr $C$DW$244, DW_AT_type(*$C$DW$T$1717) .dwattr $C$DW$244, DW_AT_location[DW_OP_reg21] $C$DW$245 .dwtag DW_TAG_variable, DW_AT_name("adap") .dwattr $C$DW$245, DW_AT_TI_symbol_name("adap") .dwattr $C$DW$245, DW_AT_type(*$C$DW$T$1714) .dwattr $C$DW$245, DW_AT_location[DW_OP_reg4] $C$DW$246 .dwtag DW_TAG_variable, DW_AT_name("info") .dwattr $C$DW$246, DW_AT_TI_symbol_name("info") .dwattr $C$DW$246, DW_AT_type(*$C$DW$T$1720) .dwattr $C$DW$246, DW_AT_location[DW_OP_reg12] $C$DW$247 .dwtag DW_TAG_variable, DW_AT_name("$O$L1") .dwattr $C$DW$247, DW_AT_TI_symbol_name("$O$L1") .dwattr $C$DW$247, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$247, DW_AT_location[DW_OP_reg5] $C$DW$248 .dwtag DW_TAG_variable, DW_AT_name("$O$U81") .dwattr $C$DW$248, DW_AT_TI_symbol_name("$O$U81") .dwattr $C$DW$248, DW_AT_type(*$C$DW$T$1740) .dwattr $C$DW$248, DW_AT_location[DW_OP_reg22] $C$DW$249 .dwtag DW_TAG_variable, DW_AT_name("$O$K76") .dwattr $C$DW$249, DW_AT_TI_symbol_name("$O$K76") .dwattr $C$DW$249, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$249, DW_AT_location[DW_OP_regx 0x2b] $C$DW$250 .dwtag DW_TAG_variable, DW_AT_name("$O$K57") .dwattr $C$DW$250, DW_AT_TI_symbol_name("$O$K57") .dwattr $C$DW$250, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$250, DW_AT_location[DW_OP_reg23] $C$DW$251 .dwtag DW_TAG_variable, DW_AT_name("$O$U50") .dwattr $C$DW$251, DW_AT_TI_symbol_name("$O$U50") .dwattr $C$DW$251, DW_AT_type(*$C$DW$T$1740) .dwattr $C$DW$251, DW_AT_location[DW_OP_regx 0x3d] $C$DW$252 .dwtag DW_TAG_variable, DW_AT_name("$O$U63") .dwattr $C$DW$252, DW_AT_TI_symbol_name("$O$U63") .dwattr $C$DW$252, DW_AT_type(*$C$DW$T$1740) .dwattr $C$DW$252, DW_AT_location[DW_OP_reg3] $C$DW$253 .dwtag DW_TAG_variable, DW_AT_name("$O$U33") .dwattr $C$DW$253, DW_AT_TI_symbol_name("$O$U33") .dwattr $C$DW$253, DW_AT_type(*$C$DW$T$11) .dwattr $C$DW$253, DW_AT_location[DW_OP_regx 0x28] $C$DW$254 .dwtag DW_TAG_variable, DW_AT_name("$O$K28") .dwattr $C$DW$254, DW_AT_TI_symbol_name("$O$K28") .dwattr $C$DW$254, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$254, DW_AT_location[DW_OP_regx 0x27] CMPGT .L1 A10,0,A0 ; |36| || ZERO .L2 B7 || MVK .S2 8192,B9 || MV .D2 B6,B5 ; |31| || LDW .D1T1 *+FP(4),A27 ; |31| || SHR .S1 A10,1,A5 [ A0] LDW .D1T1 *+A12(12),A20 || [!A0] B .S1 $C$L4 ; |36| || ADDAD .D2 B8,B9,B6 || SET .S2 B7,0xf,0xf,B7 || SUB .L1 A6,4,A3 || ZERO .L2 B16 ; |36| [ A0] LDW .D1T1 *A12,A19 || MVK .S1 0x3fff,A18 || SUB .L2 B4,4,B24 || MV .S2X A8,B4 ; |31| MVK .S1 0xffffc000,A22 LDW .D1T1 *+FP(8),A28 ; |31| LDW .D1T1 *+FP(12),A29 ; |31| ADD .L2X B10,A20,B8 .dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 36,column 23,is_stmt,isa 0 ; BRANCHCC OCCURS {$C$L4} ; |36| ;** --------------------------------------------------------------------------* ; EXCLUSIVE CPU CYCLES: 5 ;** ----------------------- K$28 = 16383; ;** ----------------------- C$15 = (*info).margin; ;** ----------------------- U$33 = ((unsigned)C$15+(unsigned)y)*(*info).xSize+(unsigned)C$15; ;** ----------------------- U$50 = &lineBufOrig[-2]; ;** ----------------------- K$57 = 32768; ;** ----------------------- U$63 = &lineBufFilter[-2]; ;** ----------------------- K$76 = (-16384); ;** ----------------------- U$81 = &emphTbl[32768]; ;** ----------------------- L$1 = sx>>1; ;** 36 ----------------------- x = 0; ;** ----------------------- #pragma MUST_ITERATE(8, 436, 1) ;** ----------------------- // LOOP BELOW UNROLLED BY FACTOR(2) ;** ----------------------- #pragma LOOP_FLAGS(4098u) ;** -----------------------g3: ;** 51 ----------------------- C$11 = *(U$50 += 2); ;** 51 ----------------------- C$9 = (int)U$33+x; ;** 51 ----------------------- C$14 = range[C$9]; ;** 51 ----------------------- C$13 = _mpy(C$14 >= 0, C$14); ;** 51 ----------------------- C$12 = wghtTblS[((C$13 < K$28) ? C$13 : K$28)]; ;** 51 ----------------------- C$10 = ((int)_lo(_mpyli(C$11, alphaI))>>11)*(K$57-C$12)+(int)_lo(_mpyli(C$12, (int)_lo(_mpyli(C$11, betaI))+(int)_lo(_mpyli(*(U$63 += 2), gammaI))>>11))>>15; ;** 51 ----------------------- (C$10 < K$76) ? (s$32 = K$76) : (s$32 = C$10); ;** 51 ----------------------- adap[C$9] = U$81[((s$32 < K$28) ? s$32 : K$28)]; ;** 51 ----------------------- C$5 = U$50[1]; ;** 51 ----------------------- C$3 = (unsigned)x+U$33+1u; ;** 51 ----------------------- C$8 = range[C$3]; ;** 51 ----------------------- C$7 = _mpy(C$8 >= 0, C$8); ;** 51 ----------------------- C$6 = wghtTblS[((C$7 < K$28) ? C$7 : K$28)]; ;** 51 ----------------------- C$4 = ((int)_lo(_mpyli(C$5, alphaI))>>11)*(K$57-C$6)+(int)_lo(_mpyli(C$6, (int)_lo(_mpyli(C$5, betaI))+(int)_lo(_mpyli(U$63[1], gammaI))>>11))>>15; ;** 51 ----------------------- (C$4 < K$76) ? (s$42 = K$76) : (s$42 = C$4); ;** 51 ----------------------- adap[C$3] = U$81[((s$42 < K$28) ? s$42 : K$28)]; ;** 36 ----------------------- x += 2; ;** 36 ----------------------- if ( L$1 = L$1-1 ) goto g3; ;** -----------------------g4: ;** ----------------------- return; SUB .L1 A5,1,A21 MPY32 .M1X A19,B8,A19 NOP 3 ;*----------------------------------------------------------------------------* ;* SOFTWARE PIPELINE INFORMATION ;* ;* Loop found in file : ../App/BMode/Integ/src/test_adap_emph.cpp ;* Loop source line : 36 ;* Loop opening brace source line : 36 ;* Loop closing brace source line : 55 ;* Loop Unroll Multiple : 2x ;* Known Minimum Trip Count : 8 ;* Known Maximum Trip Count : 436 ;* Known Max Trip Count Factor : 1 ;* Loop Carried Dependency Bound(^) : 2 ;* Unpartitioned Resource Bound : 9 ;* Partitioned Resource Bound(*) : 10 ;* Resource Partition: ;* A-side B-side ;* .L units 4 4 ;* .S units 3 3 ;* .D units 6 6 ;* .M units 6 6 ;* .X cross paths 2 7 ;* .T address paths 6 6 ;* Long read paths 0 0 ;* Long write paths 0 0 ;* Logical ops (.LS) 0 1 (.L or .S unit) ;* Addition ops (.LSD) 15 9 (.L or .S or .D unit) ;* Bound(.L .S .LS) 4 4 ;* Bound(.L .S .D .LS .LSD) 10* 8 ;* ;* Searching for software pipeline schedule at ... ;* ii = 10 no sploop: Dynlen of 70 > 48 ;* ii = 10 Schedule found with 5 iterations in parallel ;* ;* Register Usage Table: ;* +-----------------------------------------------------------------+ ;* |AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA|BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB| ;* |00000000001111111111222222222233|00000000001111111111222222222233| ;* |01234567890123456789012345678901|01234567890123456789012345678901| ;* |--------------------------------+--------------------------------| ;* 0: | ** **** ***************|* ***** ********** | ;* 1: |* **** ** ****************| *** ** ********** | ;* 2: |* ***** ** ****************| *** ** *********** | ;* 3: |* **** *** ****************|* ****** ************ | ;* 4: | ******** ****************|* ** * * * ********** | ;* 5: |********** * **************|* ** * * * ********** | ;* 6: | **** ** * * **************| *** ** * ********* | ;* 7: | * * ** * ****************| **** * ********* | ;* 8: |** ** ** * *************** | *** * ** ******** | ;* 9: | ******* ************** | ***** *** ****** * | ;* +-----------------------------------------------------------------+ ;* ;* Done ;* ;* Loop will be splooped ;* Collapsed epilog stages : 0 ;* Collapsed prolog stages : 0 ;* Minimum required memory pad : 0 bytes ;* ;* Minimum safe trip count : 1 (after unrolling) ;* Min. prof. trip count (est.) : 3 (after unrolling) ;* ;* Mem bank conflicts/iter(est.) : { min 1.000, est 1.250, max 3.000 } ;* Mem bank perf. penalty (est.) : 11.1% ;* ;* Effective ii : { min 11.00, est 11.25, max 13.00 } ;* ;* ;* Total cycles (est.) : 40 + trip_cnt * 10 = Between 120 and 4400 ;*----------------------------------------------------------------------------* ;* SETUP CODE ;* ;* MV A20,B24 ;* ADD 6,B24,B24 ;* ADD 4,A20,A20 ;* MV B25,B23 ;* ADD 6,B23,B23 ;* ADD 4,B25,B25 ;* MV A30,B16 ;* MV A26,B4 ;* MV A25,B5 ;* MV A24,B22 ;* MV A18,B20 ;* ;* SINGLE SCHEDULED ITERATION ;* ;* $C$C57: ;* 0 ADD .L1 A19,A30,A0 ; |51| ;* 1 ADD .S1 1,A0,A3 ; |51| ;* 2 ADD .D2X B16,A19,B27 ; |51| ;* || LDH .D1T1 *+A25[A3],A17 ; |51| ;* 3 LDH .D2T2 *+B5[B27],B17 ; |51| ;* 4 NOP 1 ;* 5 LDH .D2T1 *B23++(4),A31 ; |51| ;* 6 NOP 1 ;* 7 LDH .D1T2 *A20++(4),B26 ; |51| ;* || LDH .D2T1 *B24++(4),A2 ; |51| ;* || ADD .S1 2,A30,A30 ; |36| Define a twin register ;* 8 CMPLT .L2 B17,0,B18 ; |51| ;* || LDH .D2T2 *B25++(4),B7 ; |51| ;* 9 MVD .M2 B27,B9 ; |51| Split a long life ;* || XOR .S2 1,B18,B18 ; |51| ;* || CMPLT .L1 A17,0,A7 ; |51| ;* 10 MVD .M1 A3,A6 ; |51| Split a long life ;* || XOR .D1 1,A7,A16 ; |51| ;* 11 MPY .M2 B18,B17,B18 ; |51| ;* || ADD .D2 2,B16,B16 ; |36| ;* 12 MPYLI .M1 A2,A27,A17:A16 ; |51| ;* 13 MPY .M1 A16,A17,A1 ; |51| ;* 14 CMPLT .L2 B18,B20,B0 ; |51| ;* || MPYLI .M2X B26,A28,B7:B6 ; |51| ;* 15 [ B0] MV .L2 B18,B8 ; |51| ;* || [!B0] MV .S2 B20,B8 ; |51| ;* || MPYLI .M2X B7,A29,B9:B8 ; |51| ;* 16 MVD .M2 B9,B19 ; |51| Split a long life ;* || LDH .D2T2 *+B4[B8],B9 ; |51| ;* || MPYLI .M1 A2,A28,A5:A4 ; |51| ;* 17 CMPLT .L1 A1,A18,A0 ; |51| ;* || MPYLI .M1 A31,A29,A7:A6 ; |51| ;* 18 MPYLI .M2X B26,A27,B7:B6 ; |51| ;* || [ A0] MV .D1 A1,A7 ; |51| ;* || [!A0] MV .L1 A18,A7 ; |51| ;* || SHR .S1 A16,11,A8 ; |51| ;* 19 ADD .D2 B8,B6,B6 ; |51| ;* || MVD .M1 A6,A7 ; |51| Split a long life ;* || LDH .D1T1 *+A26[A7],A17 ; |51| ;* 20 NOP 1 ;* 21 SUB .L2X A21,B9,B17 ; |51| ;* || SHR .S2 B6,11,B18 ; |51| ;* 22 SHR .S2 B6,11,B6 ; |51| ;* || MPYLI .M2 B9,B18,B7:B6 ; |51| ;* || ADD .L1 A6,A4,A5 ; |51| ;* 23 MPY32 .M2 B17,B6,B7 ; |51| ;* || SHR .S1 A5,11,A16 ; |51| ;* 24 SUB .S1 A21,A17,A16 ; |51| ;* || MPYLI .M1 A17,A16,A5:A4 ; |51| ;* 25 MPY32 .M1 A16,A8,A5 ; |51| ;* 26 NOP 1 ;* 27 MVD .M2 B19,B21 ; |51| Split a long life ;* || ADD .L2 B6,B7,B8 ; |51| ;* 28 SHR .S2 B8,15,B7 ; |51| ;* || MVD .M1 A7,A9 ; |51| Split a long life ;* 29 CMPLT .L2X B7,A22,B0 ; |51| ;* || ADD .S1 A4,A5,A6 ; |51| ;* 30 [ B0] MV .S2X A22,B8 ; |51| ;* || [!B0] MV .L2 B7,B8 ; |51| ;* || SHR .S1 A6,15,A5 ; |51| ;* 31 CMPLT .L1 A5,A22,A0 ; |51| ;* 32 CMPLT .L2 B8,B20,B0 ; |51| ;* || [!A0] MV .S1 A5,A4 ; |51| ;* 33 [ B0] MV .D1X B8,A5 ; |51| Define a twin register ;* || [ A0] MV .L1 A22,A4 ; |51| ;* 34 [!B0] MV .D1X B20,A5 ; |51| Define a twin register ;* || CMPLT .L1 A4,A18,A0 ; |51| ;* 35 LDH .D1T2 *+A23[A5],B8 ; |51| ;* || [!A0] MV .S1 A18,A4 ; |51| ;* 36 LDH .D1T1 *+A23[A4],A3 ; |51| ;* 37 NOP 3 ;* 40 STH .D2T2 B8,*+B22[B21] ; |51| ^ ;* 41 STH .D1T1 A3,*+A24[A9] ; |51| ^ ;* || SPBR $C$C57 ;* 42 NOP 8 ;* 50 ; BRANCHCC OCCURS {$C$C57} ; |36| ;*----------------------------------------------------------------------------* $C$L1: ; PIPED LOOP PROLOG ; EXCLUSIVE CPU CYCLES: 41 SPLOOPD 10 ;50 ; (P) || MV .L1X B16,A30 || MVC .S2X A21,ILC || ADD .S1 A20,A19,A19 ;** --------------------------------------------------------------------------* $C$L2: ; PIPED LOOP KERNEL .dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 36,column 16,is_stmt,isa 0 $C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$B: ; EXCLUSIVE CPU CYCLES: 10 SPMASK L2 || ADD .L2X 4,A3,B25 || ADD .L1 A19,A30,A0 ; |51| (P) <0,0> SPMASK L1,L2 || ADD .L2X 6,A3,B23 || MV .L1X B5,A25 || ADD .S1 1,A0,A3 ; |51| (P) <0,1> ADD .D2X B16,A19,B27 ; |51| (P) <0,2> || LDH .D1T1 *+A25[A3],A17 ; |51| (P) <0,2> .dwpsn file "../App/BMode/Integ/src/test_adap_emph.cpp",line 51,column 9,is_stmt,isa 0 LDH .D2T2 *+B5[B27],B17 ; |51| (P) <0,3> NOP 1 LDH .D2T1 *B23++(4),A31 ; |51| (P) <0,5> SPMASK L1,L2 || ADD .L1X 4,B24,A20 || ADD .L2 6,B24,B24 LDH .D1T2 *A20++(4),B26 ; |51| (P) <0,7> || LDH .D2T1 *B24++(4),A2 ; |51| (P) <0,7> || ADD .S1 2,A30,A30 ; |36| (P) <0,7> Define a twin register SPMASK L1 || MV .L1X B7,A21 || LDH .D2T2 *B25++(4),B7 ; |51| (P) <0,8> || CMPLT .L2 B17,0,B18 ; |51| (P) <0,8> MVD .M2 B27,B9 ; |51| (P) <0,9> Split a long life || XOR .S2 1,B18,B18 ; |51| (P) <0,9> || CMPLT .L1 A17,0,A7 ; |51| (P) <0,9> MVD .M1 A3,A6 ; |51| (P) <0,10> Split a long life || XOR .D1 1,A7,A16 ; |51| (P) <0,10> ADD .D2 2,B16,B16 ; |36| (P) <0,11> || MPY .M2 B18,B17,B18 ; |51| (P) <0,11> MPYLI .M1 A2,A27,A17:A16 ; |51| (P) <0,12> SPMASK L2 || MV .L2X A18,B20 || MPY .M1 A16,A17,A1 ; |51| (P) <0,13> SPMASK L1 || MV .L1X B6,A23 || CMPLT .L2 B18,B20,B0 ; |51| (P) <0,14> || MPYLI .M2X B26,A28,B7:B6 ; |51| (P) <0,14> [ B0] MV .L2 B18,B8 ; |51| (P) <0,15> || [!B0] MV .S2 B20,B8 ; |51| (P) <0,15> || MPYLI .M2X B7,A29,B9:B8 ; |51| (P) <0,15> SPMASK L1,S1,L2 || MV .L1X B4,A26 || MV .L2X A4,B22 || MV .S1 A4,A24 || MVD .M2 B9,B19 ; |51| (P) <0,16> Split a long life || LDH .D2T2 *+B4[B8],B9 ; |51| (P) <0,16> || MPYLI .M1 A2,A28,A5:A4 ; |51| (P) <0,16> MPYLI .M1 A31,A29,A7:A6 ; |51| (P) <0,17> || CMPLT .L1 A1,A18,A0 ; |51| (P) <0,17> SHR .S1 A16,11,A8 ; |51| (P) <0,18> || [!A0] MV .L1 A18,A7 ; |51| (P) <0,18> || [ A0] MV .D1 A1,A7 ; |51| (P) <0,18> || MPYLI .M2X B26,A27,B7:B6 ; |51| (P) <0,18> MVD .M1 A6,A7 ; |51| (P) <0,19> Split a long life || LDH .D1T1 *+A26[A7],A17 ; |51| (P) <0,19> || ADD .D2 B8,B6,B6 ; |51| (P) <0,19> NOP 1 SHR .S2 B6,11,B18 ; |51| (P) <0,21> || SUB .L2X A21,B9,B17 ; |51| (P) <0,21> SHR .S2 B6,11,B6 ; |51| (P) <0,22> || ADD .L1 A6,A4,A5 ; |51| (P) <0,22> || MPYLI .M2 B9,B18,B7:B6 ; |51| (P) <0,22> SHR .S1 A5,11,A16 ; |51| (P) <0,23> || MPY32 .M2 B17,B6,B7 ; |51| (P) <0,23> MPYLI .M1 A17,A16,A5:A4 ; |51| (P) <0,24> || SUB .S1 A21,A17,A16 ; |51| (P) <0,24> MPY32 .M1 A16,A8,A5 ; |51| (P) <0,25> NOP 1 MVD .M2 B19,B21 ; |51| (P) <0,27> Split a long life || ADD .L2 B6,B7,B8 ; |51| (P) <0,27> MVD .M1 A7,A9 ; |51| (P) <0,28> Split a long life || SHR .S2 B8,15,B7 ; |51| (P) <0,28> ADD .S1 A4,A5,A6 ; |51| (P) <0,29> || CMPLT .L2X B7,A22,B0 ; |51| (P) <0,29> SHR .S1 A6,15,A5 ; |51| (P) <0,30> || [!B0] MV .L2 B7,B8 ; |51| (P) <0,30> || [ B0] MV .S2X A22,B8 ; |51| (P) <0,30> CMPLT .L1 A5,A22,A0 ; |51| (P) <0,31> CMPLT .L2 B8,B20,B0 ; |51| (P) <0,32> || [!A0] MV .S1 A5,A4 ; |51| (P) <0,32> [ A0] MV .L1 A22,A4 ; |51| (P) <0,33> || [ B0] MV .D1X B8,A5 ; |51| (P) <0,33> Define a twin register [!B0] MV .D1X B20,A5 ; |51| (P) <0,34> Define a twin register || CMPLT .L1 A4,A18,A0 ; |51| (P) <0,34> LDH .D1T2 *+A23[A5],B8 ; |51| (P) <0,35> || [!A0] MV .S1 A18,A4 ; |51| (P) <0,35> LDH .D1T1 *+A23[A4],A3 ; |51| (P) <0,36> NOP 3 STH .D2T2 B8,*+B22[B21] ; |51| <0,40> ^ SPKERNEL 3,0 || STH .D1T1 A3,*+A24[A9] ; |51| <0,41> ^ $C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$E: ;** --------------------------------------------------------------------------* $C$L3: ; PIPED LOOP EPILOG ; EXCLUSIVE CPU CYCLES: 32 NOP 2 ;** --------------------------------------------------------------------------* $C$L4: ; EXCLUSIVE CPU CYCLES: 7 MV .L2X FP,SP ; |56| || LDW .D1T1 *FP,FP ; |56| .dwcfi cfa_offset, 0 .dwcfi restore_reg, 32 .dwcfi cfa_offset, 0 $C$DW$255 .dwtag DW_TAG_TI_branch .dwattr $C$DW$255, DW_AT_low_pc(0x00) .dwattr $C$DW$255, DW_AT_TI_return RETNOP .S2 B3,5 ; BRANCH OCCURS {B3} $C$DW$256 .dwtag DW_TAG_TI_loop .dwattr $C$DW$256, DW_AT_name("C:\git\phx_main_1\DevProjects\Apollo_DEBUG\test_adap_emph.asm:$C$L2:1:1646116492") .dwattr $C$DW$256, DW_AT_TI_begin_file("../App/BMode/Integ/src/test_adap_emph.cpp") .dwattr $C$DW$256, DW_AT_TI_begin_line(0x24) .dwattr $C$DW$256, DW_AT_TI_end_line(0x37) $C$DW$257 .dwtag DW_TAG_TI_loop_range .dwattr $C$DW$257, DW_AT_low_pc($C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$B) .dwattr $C$DW$257, DW_AT_high_pc($C$DW$L$_Z9adap_emphPsPKsS1_S1_S1_S1_iiPK9ImageInfoiiii$4$E) .dwendtag $C$DW$256 .dwattr $C$DW$1, DW_AT_TI_end_file("../App/BMode/Integ/src/test_adap_emph.cpp") .dwattr $C$DW$1, DW_AT_TI_end_line(0x38) .dwattr $C$DW$1, DW_AT_TI_end_column(0x01) .dwendentry .dwendtag $C$DW$1 ;****************************************************************************** ;* BUILD ATTRIBUTES * ;****************************************************************************** .battr "TI", Tag_File, 1, Tag_Long_Precision_Bits(2) .battr "TI", Tag_File, 1, Tag_Bitfield_layout(0) .battr "TI", Tag_File, 1, Tag_ABI_enum_size(2) .battr "c6xabi", Tag_File, 1, Tag_ABI_wchar_t(1) .battr "c6xabi", Tag_File, 1, Tag_ABI_array_object_alignment(0) .battr "c6xabi", Tag_File, 1, Tag_ABI_array_object_align_expected(0) .battr "c6xabi", Tag_File, 1, Tag_ABI_PIC(0) .battr "c6xabi", Tag_File, 1, Tag_ABI_PID(0) .battr "c6xabi", Tag_File, 1, Tag_ABI_DSBT(0) .battr "c6xabi", Tag_File, 1, Tag_ABI_stack_align_needed(0) .battr "c6xabi", Tag_File, 1, Tag_ABI_stack_align_preserved(0) .battr "TI", Tag_File, 1, Tag_Tramps_Use_SOC(1) ;****************************************************************************** ;* TYPE INFORMATION * ;****************************************************************************** $C$DW$T$1590 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1590, DW_AT_byte_size(0x04) $C$DW$258 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_FORMAT_VER"), DW_AT_const_value(0x0b) .dwattr $C$DW$258, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$258, DW_AT_decl_line(0x1a6) .dwattr $C$DW$258, DW_AT_decl_column(0x05) $C$DW$259 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_COMMANDS"), DW_AT_const_value(0x05) .dwattr $C$DW$259, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$259, DW_AT_decl_line(0x1aa) .dwattr $C$DW$259, DW_AT_decl_column(0x05) $C$DW$260 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_FOV"), DW_AT_const_value(0x04) .dwattr $C$DW$260, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$260, DW_AT_decl_line(0x1ab) .dwattr $C$DW$260, DW_AT_decl_column(0x05) $C$DW$261 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_CORE"), DW_AT_const_value(0x08) .dwattr $C$DW$261, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$261, DW_AT_decl_line(0x1ac) .dwattr $C$DW$261, DW_AT_decl_column(0x05) $C$DW$262 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_NUM_SPDATATYPE"), DW_AT_const_value(0x06) .dwattr $C$DW$262, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$262, DW_AT_decl_line(0x1ad) .dwattr $C$DW$262, DW_AT_decl_column(0x05) $C$DW$263 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NUM_DSP_CORES"), DW_AT_const_value(0x08) .dwattr $C$DW$263, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$263, DW_AT_decl_line(0x1ae) .dwattr $C$DW$263, DW_AT_decl_column(0x05) $C$DW$264 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NUM_AXIAL_SEGMENTS"), DW_AT_const_value(0x20) .dwattr $C$DW$264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$264, DW_AT_decl_line(0x1af) .dwattr $C$DW$264, DW_AT_decl_column(0x05) $C$DW$265 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_RESERVED_SIZE"), DW_AT_const_value(0x10) .dwattr $C$DW$265, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$265, DW_AT_decl_line(0x1b0) .dwattr $C$DW$265, DW_AT_decl_column(0x05) $C$DW$266 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_SPCTL_RFBUF_HASHTABLE_SIZE"), DW_AT_const_value(0x20) .dwattr $C$DW$266, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$266, DW_AT_decl_line(0x1b1) .dwattr $C$DW$266, DW_AT_decl_column(0x05) $C$DW$267 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_CMD_PER_SP"), DW_AT_const_value(0x0a) .dwattr $C$DW$267, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$267, DW_AT_decl_line(0x1b2) .dwattr $C$DW$267, DW_AT_decl_column(0x05) $C$DW$268 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_RTHETA_RAYS"), DW_AT_const_value(0x400) .dwattr $C$DW$268, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$268, DW_AT_decl_line(0x1b7) .dwattr $C$DW$268, DW_AT_decl_column(0x05) $C$DW$269 .dwtag DW_TAG_enumerator, DW_AT_name("IMAGE_BE_FILL_HOLE_PTMASK_MAX"), DW_AT_const_value(0x19) .dwattr $C$DW$269, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$269, DW_AT_decl_line(0x1bb) .dwattr $C$DW$269, DW_AT_decl_column(0x05) $C$DW$270 .dwtag DW_TAG_enumerator, DW_AT_name("IMAGE_BE_MAX_LEV"), DW_AT_const_value(0x04) .dwattr $C$DW$270, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$270, DW_AT_decl_line(0x1bc) .dwattr $C$DW$270, DW_AT_decl_column(0x05) $C$DW$271 .dwtag DW_TAG_enumerator, DW_AT_name("IMAGE_BE_MAX_LEV_P1"), DW_AT_const_value(0x05) .dwattr $C$DW$271, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$271, DW_AT_decl_line(0x1bd) .dwattr $C$DW$271, DW_AT_decl_column(0x05) $C$DW$272 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NEEDLE_VIS_LOOKS"), DW_AT_const_value(0x03) .dwattr $C$DW$272, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$272, DW_AT_decl_line(0x1be) .dwattr $C$DW$272, DW_AT_decl_column(0x05) $C$DW$273 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_MBEAM_LOOKS"), DW_AT_const_value(0x09) .dwattr $C$DW$273, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$273, DW_AT_decl_line(0x1bf) .dwattr $C$DW$273, DW_AT_decl_column(0x05) $C$DW$274 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_MBEAM_TAPER_LENGTH"), DW_AT_const_value(0x10) .dwattr $C$DW$274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$274, DW_AT_decl_line(0x1c0) .dwattr $C$DW$274, DW_AT_decl_column(0x05) $C$DW$275 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_NUM_CMPD_CORRECTION_FACTOR"), DW_AT_const_value(0x05) .dwattr $C$DW$275, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$275, DW_AT_decl_line(0x1c1) .dwattr $C$DW$275, DW_AT_decl_column(0x05) $C$DW$276 .dwtag DW_TAG_enumerator, DW_AT_name("REMAP_TABLE_SIZE"), DW_AT_const_value(0x400) .dwattr $C$DW$276, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$276, DW_AT_decl_line(0x1c2) .dwattr $C$DW$276, DW_AT_decl_column(0x05) $C$DW$277 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_KERNEL_LENGTH"), DW_AT_const_value(0x19) .dwattr $C$DW$277, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$277, DW_AT_decl_line(0x1c3) .dwattr $C$DW$277, DW_AT_decl_column(0x05) $C$DW$278 .dwtag DW_TAG_enumerator, DW_AT_name("TWOD_MAX_INP_EST_PER_LINE"), DW_AT_const_value(0x368) .dwattr $C$DW$278, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$278, DW_AT_decl_line(0x1c4) .dwattr $C$DW$278, DW_AT_decl_column(0x05) $C$DW$279 .dwtag DW_TAG_enumerator, DW_AT_name("MMODE_ESTIMATES_PER_LINE_MAX"), DW_AT_const_value(0x380) .dwattr $C$DW$279, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$279, DW_AT_decl_line(0x1d0) .dwattr $C$DW$279, DW_AT_decl_column(0x05) $C$DW$280 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_DOPPLER_DISPLAY_WIDTH"), DW_AT_const_value(0x480) .dwattr $C$DW$280, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$280, DW_AT_decl_line(0x1d4) .dwattr $C$DW$280, DW_AT_decl_column(0x05) $C$DW$281 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_DOPPLER_DISPLAY_HEIGHT"), DW_AT_const_value(0x380) .dwattr $C$DW$281, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$281, DW_AT_decl_line(0x1d5) .dwattr $C$DW$281, DW_AT_decl_column(0x05) $C$DW$282 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_FFT_RATE_IN_HZ"), DW_AT_const_value(0x320) .dwattr $C$DW$282, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$282, DW_AT_decl_line(0x1d6) .dwattr $C$DW$282, DW_AT_decl_column(0x05) $C$DW$283 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_MAX_DBELL_RATE"), DW_AT_const_value(0x7d0) .dwattr $C$DW$283, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$283, DW_AT_decl_line(0x1d7) .dwattr $C$DW$283, DW_AT_decl_column(0x05) $C$DW$284 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_SHIFTS_DEFAULT"), DW_AT_const_value(0x00) .dwattr $C$DW$284, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$284, DW_AT_decl_line(0x1d8) .dwattr $C$DW$284, DW_AT_decl_column(0x05) $C$DW$285 .dwtag DW_TAG_enumerator, DW_AT_name("LINE_INTERLEAVE_MIN_COLOR_ENSEMBLE_SIZE"), DW_AT_const_value(0x08) .dwattr $C$DW$285, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$285, DW_AT_decl_line(0x1d9) .dwattr $C$DW$285, DW_AT_decl_column(0x05) $C$DW$286 .dwtag DW_TAG_enumerator, DW_AT_name("LINE_INTERLEAVE_MAX_TOTAL_COLOR_GROUPS"), DW_AT_const_value(0x32) .dwattr $C$DW$286, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$286, DW_AT_decl_line(0x1da) .dwattr $C$DW$286, DW_AT_decl_column(0x05) $C$DW$287 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_GAP_WINDOWS"), DW_AT_const_value(0x02) .dwattr $C$DW$287, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$287, DW_AT_decl_line(0x1db) .dwattr $C$DW$287, DW_AT_decl_column(0x05) $C$DW$288 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_GAP_SIZE_MSEC"), DW_AT_const_value(0x14) .dwattr $C$DW$288, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$288, DW_AT_decl_line(0x1dc) .dwattr $C$DW$288, DW_AT_decl_column(0x05) $C$DW$289 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_NUM_GAP_SAMPLES"), DW_AT_const_value(0x190) .dwattr $C$DW$289, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$289, DW_AT_decl_line(0x1df) .dwattr $C$DW$289, DW_AT_decl_column(0x05) $C$DW$290 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MIN_NUM_GAP_SAMPLES"), DW_AT_const_value(0x08) .dwattr $C$DW$290, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$290, DW_AT_decl_line(0x1e2) .dwattr $C$DW$290, DW_AT_decl_column(0x05) $C$DW$291 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_NUM_INPUT_SAMPLES"), DW_AT_const_value(0x40) .dwattr $C$DW$291, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$291, DW_AT_decl_line(0x1e3) .dwattr $C$DW$291, DW_AT_decl_column(0x05) $C$DW$292 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MIN_NUM_INPUT_SAMPLES"), DW_AT_const_value(0x09) .dwattr $C$DW$292, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$292, DW_AT_decl_line(0x1e4) .dwattr $C$DW$292, DW_AT_decl_column(0x05) $C$DW$293 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MAX_ORDER"), DW_AT_const_value(0x10) .dwattr $C$DW$293, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$293, DW_AT_decl_line(0x1e5) .dwattr $C$DW$293, DW_AT_decl_column(0x05) $C$DW$294 .dwtag DW_TAG_enumerator, DW_AT_name("BLOCK_INTERLEAVE_MIN_ORDER"), DW_AT_const_value(0x08) .dwattr $C$DW$294, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$294, DW_AT_decl_line(0x1e6) .dwattr $C$DW$294, DW_AT_decl_column(0x05) $C$DW$295 .dwtag DW_TAG_enumerator, DW_AT_name("DOP_ENDOFDATA_DFLT_VALUE"), DW_AT_const_value(-1163015426) .dwattr $C$DW$295, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$295, DW_AT_decl_line(0x1e8) .dwattr $C$DW$295, DW_AT_decl_column(0x05) $C$DW$296 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_COLORFLOW_MULTILINES"), DW_AT_const_value(0x04) .dwattr $C$DW$296, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$296, DW_AT_decl_line(0x1ec) .dwattr $C$DW$296, DW_AT_decl_column(0x05) $C$DW$297 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_COLORFLOW_MPFIR_LENGTH"), DW_AT_const_value(0x08) .dwattr $C$DW$297, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$297, DW_AT_decl_line(0x1ed) .dwattr $C$DW$297, DW_AT_decl_column(0x05) $C$DW$298 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_COLORFLOW_ESTIMATES"), DW_AT_const_value(0x368) .dwattr $C$DW$298, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$298, DW_AT_decl_line(0x1ee) .dwattr $C$DW$298, DW_AT_decl_column(0x05) $C$DW$299 .dwtag DW_TAG_enumerator, DW_AT_name("MIN_NUM_LINES_COLOR_SC"), DW_AT_const_value(0x08) .dwattr $C$DW$299, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$299, DW_AT_decl_line(0x1ef) .dwattr $C$DW$299, DW_AT_decl_column(0x05) $C$DW$300 .dwtag DW_TAG_enumerator, DW_AT_name("ECG_DISPLAY_WIDTH"), DW_AT_const_value(0x480) .dwattr $C$DW$300, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$300, DW_AT_decl_line(0x1f5) .dwattr $C$DW$300, DW_AT_decl_column(0x05) $C$DW$301 .dwtag DW_TAG_enumerator, DW_AT_name("ECG_DISPLAY_HEIGHT"), DW_AT_const_value(0x40) .dwattr $C$DW$301, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$301, DW_AT_decl_line(0x1f6) .dwattr $C$DW$301, DW_AT_decl_column(0x05) $C$DW$302 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_ERROR_FILENAME_SIZE"), DW_AT_const_value(0x40) .dwattr $C$DW$302, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$302, DW_AT_decl_line(0x1fa) .dwattr $C$DW$302, DW_AT_decl_column(0x05) $C$DW$303 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SOFT_ERR_HISTORY_SIZE"), DW_AT_const_value(0x10) .dwattr $C$DW$303, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$303, DW_AT_decl_line(0x1fb) .dwattr $C$DW$303, DW_AT_decl_column(0x05) $C$DW$304 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_DEBUG_PRINT_BUFF"), DW_AT_const_value(0x20) .dwattr $C$DW$304, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$304, DW_AT_decl_line(0x1fc) .dwattr $C$DW$304, DW_AT_decl_column(0x05) $C$DW$305 .dwtag DW_TAG_enumerator, DW_AT_name("NUM_MAIN_CTLR_DEBUG_INFO_ENTRY"), DW_AT_const_value(0x0a) .dwattr $C$DW$305, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$305, DW_AT_decl_line(0x1fd) .dwattr $C$DW$305, DW_AT_decl_column(0x05) $C$DW$306 .dwtag DW_TAG_enumerator, DW_AT_name("NUM_HISTORY_LOG_ENTRIES"), DW_AT_const_value(0x20) .dwattr $C$DW$306, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$306, DW_AT_decl_line(0x1fe) .dwattr $C$DW$306, DW_AT_decl_column(0x05) $C$DW$307 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_CINE_PROCESS_QUEUE_ENTRIES"), DW_AT_const_value(0x08) .dwattr $C$DW$307, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$307, DW_AT_decl_line(0x202) .dwattr $C$DW$307, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1590 .dwattr $C$DW$T$1590, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1590, DW_AT_decl_line(0x1a3) .dwattr $C$DW$T$1590, DW_AT_decl_column(0x01) $C$DW$T$1591 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1591, DW_AT_byte_size(0x04) $C$DW$308 .dwtag DW_TAG_enumerator, DW_AT_name("PROCESS_COMMAND_START"), DW_AT_const_value(0x01) .dwattr $C$DW$308, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$308, DW_AT_decl_line(0x33) .dwattr $C$DW$308, DW_AT_decl_column(0x05) $C$DW$309 .dwtag DW_TAG_enumerator, DW_AT_name("PROCESS_COMMAND_END"), DW_AT_const_value(0x1f) .dwattr $C$DW$309, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$309, DW_AT_decl_line(0x34) .dwattr $C$DW$309, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1591 .dwattr $C$DW$T$1591, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1591, DW_AT_decl_line(0x32) .dwattr $C$DW$T$1591, DW_AT_decl_column(0x06) $C$DW$T$130 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$130, DW_AT_name("AMM_Param") .dwattr $C$DW$T$130, DW_AT_byte_size(0x20) $C$DW$310 .dwtag DW_TAG_member .dwattr $C$DW$310, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$310, DW_AT_name("xStart") .dwattr $C$DW$310, DW_AT_TI_symbol_name("xStart") .dwattr $C$DW$310, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$310, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$310, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$310, DW_AT_decl_line(0x4c9) .dwattr $C$DW$310, DW_AT_decl_column(0x05) $C$DW$311 .dwtag DW_TAG_member .dwattr $C$DW$311, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$311, DW_AT_name("yStart") .dwattr $C$DW$311, DW_AT_TI_symbol_name("yStart") .dwattr $C$DW$311, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$311, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$311, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$311, DW_AT_decl_line(0x4ca) .dwattr $C$DW$311, DW_AT_decl_column(0x05) $C$DW$312 .dwtag DW_TAG_member .dwattr $C$DW$312, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$312, DW_AT_name("xEnd") .dwattr $C$DW$312, DW_AT_TI_symbol_name("xEnd") .dwattr $C$DW$312, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$312, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$312, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$312, DW_AT_decl_line(0x4cc) .dwattr $C$DW$312, DW_AT_decl_column(0x05) $C$DW$313 .dwtag DW_TAG_member .dwattr $C$DW$313, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$313, DW_AT_name("yEnd") .dwattr $C$DW$313, DW_AT_TI_symbol_name("yEnd") .dwattr $C$DW$313, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$313, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$313, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$313, DW_AT_decl_line(0x4cd) .dwattr $C$DW$313, DW_AT_decl_column(0x05) $C$DW$2 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$2, DW_AT_declaration .dwattr $C$DW$2, DW_AT_TI_symbol_name("_ZN9AMM_ParamaSERKS_") .dwattr $C$DW$2, DW_AT_type(*$C$DW$T$126) .dwattr $C$DW$2, DW_AT_accessibility(DW_ACCESS_public) $C$DW$314 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$314, DW_AT_type(*$C$DW$T$128) .dwendtag $C$DW$2 .dwendtag $C$DW$T$130 .dwattr $C$DW$T$130, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$130, DW_AT_decl_line(0x4c8) .dwattr $C$DW$T$130, DW_AT_decl_column(0x01) $C$DW$T$127 .dwtag DW_TAG_const_type .dwattr $C$DW$T$127, DW_AT_type(*$C$DW$T$130) $C$DW$T$128 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$128, DW_AT_type(*$C$DW$T$127) .dwattr $C$DW$T$128, DW_AT_address_class(0x20) $C$DW$T$135 .dwtag DW_TAG_typedef, DW_AT_name("AMM_Param") .dwattr $C$DW$T$135, DW_AT_type(*$C$DW$T$130) .dwattr $C$DW$T$135, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$135, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$135, DW_AT_decl_line(0x4d0) .dwattr $C$DW$T$135, DW_AT_decl_column(0x03) $C$DW$T$126 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$126, DW_AT_type(*$C$DW$T$130) .dwattr $C$DW$T$126, DW_AT_address_class(0x20) $C$DW$T$129 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$129, DW_AT_type(*$C$DW$T$126) .dwattr $C$DW$T$129, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$315 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$315, DW_AT_type(*$C$DW$T$128) .dwendtag $C$DW$T$129 $C$DW$T$1566 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1566, DW_AT_name("AutoGain_Param") .dwattr $C$DW$T$1566, DW_AT_byte_size(0x200) $C$DW$316 .dwtag DW_TAG_member .dwattr $C$DW$316, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$316, DW_AT_name("refFrameGainDelta") .dwattr $C$DW$316, DW_AT_TI_symbol_name("refFrameGainDelta") .dwattr $C$DW$316, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$316, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$316, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$316, DW_AT_decl_line(0x2e2) .dwattr $C$DW$316, DW_AT_decl_column(0x05) $C$DW$317 .dwtag DW_TAG_member .dwattr $C$DW$317, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$317, DW_AT_name("pixelThresholdOffset") .dwattr $C$DW$317, DW_AT_TI_symbol_name("pixelThresholdOffset") .dwattr $C$DW$317, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$317, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$317, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$317, DW_AT_decl_line(0x2e3) .dwattr $C$DW$317, DW_AT_decl_column(0x05) $C$DW$318 .dwtag DW_TAG_member .dwattr $C$DW$318, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$318, DW_AT_name("crdApicalCompDepthMm") .dwattr $C$DW$318, DW_AT_TI_symbol_name("crdApicalCompDepthMm") .dwattr $C$DW$318, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$318, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$318, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$318, DW_AT_decl_line(0x2e4) .dwattr $C$DW$318, DW_AT_decl_column(0x05) $C$DW$319 .dwtag DW_TAG_member .dwattr $C$DW$319, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$319, DW_AT_name("pixelThresholdLow") .dwattr $C$DW$319, DW_AT_TI_symbol_name("pixelThresholdLow") .dwattr $C$DW$319, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$319, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$319, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$319, DW_AT_decl_line(0x2e5) .dwattr $C$DW$319, DW_AT_decl_column(0x05) $C$DW$320 .dwtag DW_TAG_member .dwattr $C$DW$320, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$320, DW_AT_name("pixelThresholdHigh") .dwattr $C$DW$320, DW_AT_TI_symbol_name("pixelThresholdHigh") .dwattr $C$DW$320, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$320, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$320, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$320, DW_AT_decl_line(0x2e6) .dwattr $C$DW$320, DW_AT_decl_column(0x05) $C$DW$321 .dwtag DW_TAG_member .dwattr $C$DW$321, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$321, DW_AT_name("lateralLineSkip") .dwattr $C$DW$321, DW_AT_TI_symbol_name("lateralLineSkip") .dwattr $C$DW$321, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$321, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$321, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$321, DW_AT_decl_line(0x2e7) .dwattr $C$DW$321, DW_AT_decl_column(0x05) $C$DW$322 .dwtag DW_TAG_member .dwattr $C$DW$322, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$322, DW_AT_name("roiSectionFraction") .dwattr $C$DW$322, DW_AT_TI_symbol_name("roiSectionFraction") .dwattr $C$DW$322, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$322, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$322, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$322, DW_AT_decl_line(0x2e8) .dwattr $C$DW$322, DW_AT_decl_column(0x05) $C$DW$323 .dwtag DW_TAG_member .dwattr $C$DW$323, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$323, DW_AT_name("startSampleSkip") .dwattr $C$DW$323, DW_AT_TI_symbol_name("startSampleSkip") .dwattr $C$DW$323, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$323, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$323, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$323, DW_AT_decl_line(0x2e9) .dwattr $C$DW$323, DW_AT_decl_column(0x05) $C$DW$324 .dwtag DW_TAG_member .dwattr $C$DW$324, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$324, DW_AT_name("numAxialSegments") .dwattr $C$DW$324, DW_AT_TI_symbol_name("numAxialSegments") .dwattr $C$DW$324, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$324, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$324, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$324, DW_AT_decl_line(0x2ea) .dwattr $C$DW$324, DW_AT_decl_column(0x05) $C$DW$325 .dwtag DW_TAG_member .dwattr $C$DW$325, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$325, DW_AT_name("desiredPixelSlope") .dwattr $C$DW$325, DW_AT_TI_symbol_name("desiredPixelSlope") .dwattr $C$DW$325, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$325, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$325, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$325, DW_AT_decl_line(0x2eb) .dwattr $C$DW$325, DW_AT_decl_column(0x05) $C$DW$326 .dwtag DW_TAG_member .dwattr $C$DW$326, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$326, DW_AT_name("maxGainCorrectionDb") .dwattr $C$DW$326, DW_AT_TI_symbol_name("maxGainCorrectionDb") .dwattr $C$DW$326, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$326, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$326, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$326, DW_AT_decl_line(0x2ec) .dwattr $C$DW$326, DW_AT_decl_column(0x05) $C$DW$327 .dwtag DW_TAG_member .dwattr $C$DW$327, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$327, DW_AT_name("skinlineRolloffDepthMm") .dwattr $C$DW$327, DW_AT_TI_symbol_name("skinlineRolloffDepthMm") .dwattr $C$DW$327, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$327, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$327, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$327, DW_AT_decl_line(0x2ed) .dwattr $C$DW$327, DW_AT_decl_column(0x05) $C$DW$328 .dwtag DW_TAG_member .dwattr $C$DW$328, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$328, DW_AT_name("skinlineRolloffDb") .dwattr $C$DW$328, DW_AT_TI_symbol_name("skinlineRolloffDb") .dwattr $C$DW$328, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$328, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$328, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$328, DW_AT_decl_line(0x2ee) .dwattr $C$DW$328, DW_AT_decl_column(0x05) $C$DW$329 .dwtag DW_TAG_member .dwattr $C$DW$329, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$329, DW_AT_name("targetMeanPixel") .dwattr $C$DW$329, DW_AT_TI_symbol_name("targetMeanPixel") .dwattr $C$DW$329, DW_AT_data_member_location[DW_OP_plus_uconst 0x68] .dwattr $C$DW$329, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$329, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$329, DW_AT_decl_line(0x2ef) .dwattr $C$DW$329, DW_AT_decl_column(0x05) $C$DW$330 .dwtag DW_TAG_member .dwattr $C$DW$330, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$330, DW_AT_name("actualSegUsed") .dwattr $C$DW$330, DW_AT_TI_symbol_name("actualSegUsed") .dwattr $C$DW$330, DW_AT_data_member_location[DW_OP_plus_uconst 0x70] .dwattr $C$DW$330, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$330, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$330, DW_AT_decl_line(0x2f2) .dwattr $C$DW$330, DW_AT_decl_column(0x05) $C$DW$331 .dwtag DW_TAG_member .dwattr $C$DW$331, DW_AT_type(*$C$DW$T$1561) .dwattr $C$DW$331, DW_AT_name("depthArrayMm") .dwattr $C$DW$331, DW_AT_TI_symbol_name("depthArrayMm") .dwattr $C$DW$331, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$331, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$331, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$331, DW_AT_decl_line(0x2f3) .dwattr $C$DW$331, DW_AT_decl_column(0x05) $C$DW$332 .dwtag DW_TAG_member .dwattr $C$DW$332, DW_AT_type(*$C$DW$T$1561) .dwattr $C$DW$332, DW_AT_name("depthCurve") .dwattr $C$DW$332, DW_AT_TI_symbol_name("depthCurve") .dwattr $C$DW$332, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8] .dwattr $C$DW$332, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$332, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$332, DW_AT_decl_line(0x2f4) .dwattr $C$DW$332, DW_AT_decl_column(0x05) $C$DW$333 .dwtag DW_TAG_member .dwattr $C$DW$333, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$333, DW_AT_name("meanCorrection") .dwattr $C$DW$333, DW_AT_TI_symbol_name("meanCorrection") .dwattr $C$DW$333, DW_AT_data_member_location[DW_OP_plus_uconst 0x178] .dwattr $C$DW$333, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$333, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$333, DW_AT_decl_line(0x2f5) .dwattr $C$DW$333, DW_AT_decl_column(0x05) $C$DW$334 .dwtag DW_TAG_member .dwattr $C$DW$334, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$334, DW_AT_name("reserved") .dwattr $C$DW$334, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$334, DW_AT_data_member_location[DW_OP_plus_uconst 0x180] .dwattr $C$DW$334, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$334, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$334, DW_AT_decl_line(0x2f8) .dwattr $C$DW$334, DW_AT_decl_column(0x05) $C$DW$3 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$3, DW_AT_declaration .dwattr $C$DW$3, DW_AT_TI_symbol_name("_ZN14AutoGain_ParamaSERKS_") .dwattr $C$DW$3, DW_AT_type(*$C$DW$T$1562) .dwattr $C$DW$3, DW_AT_accessibility(DW_ACCESS_public) $C$DW$335 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$335, DW_AT_type(*$C$DW$T$1564) .dwendtag $C$DW$3 .dwendtag $C$DW$T$1566 .dwattr $C$DW$T$1566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1566, DW_AT_decl_line(0x2e0) .dwattr $C$DW$T$1566, DW_AT_decl_column(0x01) $C$DW$T$1563 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1563, DW_AT_type(*$C$DW$T$1566) $C$DW$T$1564 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1564, DW_AT_type(*$C$DW$T$1563) .dwattr $C$DW$T$1564, DW_AT_address_class(0x20) $C$DW$T$1584 .dwtag DW_TAG_typedef, DW_AT_name("AutoGain_Param") .dwattr $C$DW$T$1584, DW_AT_type(*$C$DW$T$1566) .dwattr $C$DW$T$1584, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1584, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1584, DW_AT_decl_line(0x2f9) .dwattr $C$DW$T$1584, DW_AT_decl_column(0x03) $C$DW$T$1562 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1562, DW_AT_type(*$C$DW$T$1566) .dwattr $C$DW$T$1562, DW_AT_address_class(0x20) $C$DW$T$1565 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1565, DW_AT_type(*$C$DW$T$1562) .dwattr $C$DW$T$1565, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$336 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$336, DW_AT_type(*$C$DW$T$1564) .dwendtag $C$DW$T$1565 $C$DW$T$19 .dwtag DW_TAG_class_type .dwattr $C$DW$T$19, DW_AT_name("BModeFrameBoundary") .dwattr $C$DW$T$19, DW_AT_declaration .dwendtag $C$DW$T$19 .dwattr $C$DW$T$19, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/include/ClearVisualization.h") .dwattr $C$DW$T$19, DW_AT_decl_line(0x6a) .dwattr $C$DW$T$19, DW_AT_decl_column(0x07) $C$DW$T$1041 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1041, DW_AT_name("BlackHoleFill_Param") .dwattr $C$DW$T$1041, DW_AT_byte_size(0x90) $C$DW$337 .dwtag DW_TAG_member .dwattr $C$DW$337, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$337, DW_AT_name("axialThreshold") .dwattr $C$DW$337, DW_AT_TI_symbol_name("axialThreshold") .dwattr $C$DW$337, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$337, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$337, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$337, DW_AT_decl_line(0x2fd) .dwattr $C$DW$337, DW_AT_decl_column(0x05) $C$DW$338 .dwtag DW_TAG_member .dwattr $C$DW$338, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$338, DW_AT_name("lateralThreshold") .dwattr $C$DW$338, DW_AT_TI_symbol_name("lateralThreshold") .dwattr $C$DW$338, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$338, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$338, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$338, DW_AT_decl_line(0x2fe) .dwattr $C$DW$338, DW_AT_decl_column(0x05) $C$DW$339 .dwtag DW_TAG_member .dwattr $C$DW$339, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$339, DW_AT_name("reserved") .dwattr $C$DW$339, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$339, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$339, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$339, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$339, DW_AT_decl_line(0x2ff) .dwattr $C$DW$339, DW_AT_decl_column(0x05) $C$DW$4 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$4, DW_AT_declaration .dwattr $C$DW$4, DW_AT_TI_symbol_name("_ZN19BlackHoleFill_ParamaSERKS_") .dwattr $C$DW$4, DW_AT_type(*$C$DW$T$1037) .dwattr $C$DW$4, DW_AT_accessibility(DW_ACCESS_public) $C$DW$340 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$340, DW_AT_type(*$C$DW$T$1039) .dwendtag $C$DW$4 .dwendtag $C$DW$T$1041 .dwattr $C$DW$T$1041, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1041, DW_AT_decl_line(0x2fc) .dwattr $C$DW$T$1041, DW_AT_decl_column(0x01) $C$DW$T$1038 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1038, DW_AT_type(*$C$DW$T$1041) $C$DW$T$1039 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1039, DW_AT_type(*$C$DW$T$1038) .dwattr $C$DW$T$1039, DW_AT_address_class(0x20) $C$DW$T$1582 .dwtag DW_TAG_typedef, DW_AT_name("BlackHoleFill_Param") .dwattr $C$DW$T$1582, DW_AT_type(*$C$DW$T$1041) .dwattr $C$DW$T$1582, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1582, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1582, DW_AT_decl_line(0x300) .dwattr $C$DW$T$1582, DW_AT_decl_column(0x03) $C$DW$T$1037 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1037, DW_AT_type(*$C$DW$T$1041) .dwattr $C$DW$T$1037, DW_AT_address_class(0x20) $C$DW$T$1040 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1040, DW_AT_type(*$C$DW$T$1037) .dwattr $C$DW$T$1040, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$341 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$341, DW_AT_type(*$C$DW$T$1039) .dwendtag $C$DW$T$1040 $C$DW$T$1490 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1490, DW_AT_name("BspFilterParam") .dwattr $C$DW$T$1490, DW_AT_byte_size(0x14) $C$DW$342 .dwtag DW_TAG_member .dwattr $C$DW$342, DW_AT_type(*$C$DW$T$1485) .dwattr $C$DW$342, DW_AT_name("coef") .dwattr $C$DW$342, DW_AT_TI_symbol_name("coef") .dwattr $C$DW$342, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$342, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$342, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$342, DW_AT_decl_line(0x73) .dwattr $C$DW$342, DW_AT_decl_column(0x07) $C$DW$343 .dwtag DW_TAG_member .dwattr $C$DW$343, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$343, DW_AT_name("accuracyBits") .dwattr $C$DW$343, DW_AT_TI_symbol_name("accuracyBits") .dwattr $C$DW$343, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$343, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$343, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$343, DW_AT_decl_line(0x74) .dwattr $C$DW$343, DW_AT_decl_column(0x07) $C$DW$5 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$5, DW_AT_declaration .dwattr $C$DW$5, DW_AT_TI_symbol_name("_ZN14BspFilterParamaSERKS_") .dwattr $C$DW$5, DW_AT_type(*$C$DW$T$1486) .dwattr $C$DW$5, DW_AT_accessibility(DW_ACCESS_public) $C$DW$344 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$344, DW_AT_type(*$C$DW$T$1488) .dwendtag $C$DW$5 .dwendtag $C$DW$T$1490 .dwattr $C$DW$T$1490, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$1490, DW_AT_decl_line(0x71) .dwattr $C$DW$T$1490, DW_AT_decl_column(0x08) $C$DW$T$1487 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1487, DW_AT_type(*$C$DW$T$1490) $C$DW$T$1488 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1488, DW_AT_type(*$C$DW$T$1487) .dwattr $C$DW$T$1488, DW_AT_address_class(0x20) $C$DW$T$1486 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1486, DW_AT_type(*$C$DW$T$1490) .dwattr $C$DW$T$1486, DW_AT_address_class(0x20) $C$DW$T$1489 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1489, DW_AT_type(*$C$DW$T$1486) .dwattr $C$DW$T$1489, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$345 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$345, DW_AT_type(*$C$DW$T$1488) .dwendtag $C$DW$T$1489 $C$DW$T$124 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$124, DW_AT_name("CBufferMgr_Buffer") .dwattr $C$DW$T$124, DW_AT_byte_size(0x20) $C$DW$346 .dwtag DW_TAG_member .dwattr $C$DW$346, DW_AT_type(*$C$DW$T$105) .dwattr $C$DW$346, DW_AT_name("storage") .dwattr $C$DW$346, DW_AT_TI_symbol_name("storage") .dwattr $C$DW$346, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$346, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$346, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$346, DW_AT_decl_line(0x2d) .dwattr $C$DW$346, DW_AT_decl_column(0x05) $C$DW$347 .dwtag DW_TAG_member .dwattr $C$DW$347, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$347, DW_AT_name("packetSize") .dwattr $C$DW$347, DW_AT_TI_symbol_name("packetSize") .dwattr $C$DW$347, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$347, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$347, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$347, DW_AT_decl_line(0x2e) .dwattr $C$DW$347, DW_AT_decl_column(0x0c) $C$DW$348 .dwtag DW_TAG_member .dwattr $C$DW$348, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$348, DW_AT_name("packetStride") .dwattr $C$DW$348, DW_AT_TI_symbol_name("packetStride") .dwattr $C$DW$348, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$348, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$348, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$348, DW_AT_decl_line(0x2f) .dwattr $C$DW$348, DW_AT_decl_column(0x0c) $C$DW$349 .dwtag DW_TAG_member .dwattr $C$DW$349, DW_AT_type(*$C$DW$T$113) .dwattr $C$DW$349, DW_AT_name("numPackets") .dwattr $C$DW$349, DW_AT_TI_symbol_name("numPackets") .dwattr $C$DW$349, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$349, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$349, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$349, DW_AT_decl_line(0x31) .dwattr $C$DW$349, DW_AT_decl_column(0x0c) $C$DW$350 .dwtag DW_TAG_member .dwattr $C$DW$350, DW_AT_type(*$C$DW$T$113) .dwattr $C$DW$350, DW_AT_name("count") .dwattr $C$DW$350, DW_AT_TI_symbol_name("count") .dwattr $C$DW$350, DW_AT_data_member_location[DW_OP_plus_uconst 0xe] .dwattr $C$DW$350, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$350, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$350, DW_AT_decl_line(0x32) .dwattr $C$DW$350, DW_AT_decl_column(0x0c) $C$DW$351 .dwtag DW_TAG_member .dwattr $C$DW$351, DW_AT_type(*$C$DW$T$113) .dwattr $C$DW$351, DW_AT_name("numCompletedPackets") .dwattr $C$DW$351, DW_AT_TI_symbol_name("numCompletedPackets") .dwattr $C$DW$351, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$351, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$351, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$351, DW_AT_decl_line(0x33) .dwattr $C$DW$351, DW_AT_decl_column(0x0c) $C$DW$352 .dwtag DW_TAG_member .dwattr $C$DW$352, DW_AT_type(*$C$DW$T$113) .dwattr $C$DW$352, DW_AT_name("readIndex") .dwattr $C$DW$352, DW_AT_TI_symbol_name("readIndex") .dwattr $C$DW$352, DW_AT_data_member_location[DW_OP_plus_uconst 0x12] .dwattr $C$DW$352, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$352, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$352, DW_AT_decl_line(0x34) .dwattr $C$DW$352, DW_AT_decl_column(0x0c) $C$DW$353 .dwtag DW_TAG_member .dwattr $C$DW$353, DW_AT_type(*$C$DW$T$113) .dwattr $C$DW$353, DW_AT_name("writeIndex") .dwattr $C$DW$353, DW_AT_TI_symbol_name("writeIndex") .dwattr $C$DW$353, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$353, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$353, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$353, DW_AT_decl_line(0x35) .dwattr $C$DW$353, DW_AT_decl_column(0x0c) $C$DW$354 .dwtag DW_TAG_member .dwattr $C$DW$354, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$354, DW_AT_name("wrapCount") .dwattr $C$DW$354, DW_AT_TI_symbol_name("wrapCount") .dwattr $C$DW$354, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$354, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$354, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$354, DW_AT_decl_line(0x37) .dwattr $C$DW$354, DW_AT_decl_column(0x09) $C$DW$355 .dwtag DW_TAG_member .dwattr $C$DW$355, DW_AT_type(*$C$DW$T$119) .dwattr $C$DW$355, DW_AT_name("storageClass") .dwattr $C$DW$355, DW_AT_TI_symbol_name("storageClass") .dwattr $C$DW$355, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c] .dwattr $C$DW$355, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$355, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$355, DW_AT_decl_line(0x38) .dwattr $C$DW$355, DW_AT_decl_column(0x17) $C$DW$6 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$6, DW_AT_declaration .dwattr $C$DW$6, DW_AT_TI_symbol_name("_ZN17CBufferMgr_BufferaSERKS_") .dwattr $C$DW$6, DW_AT_type(*$C$DW$T$120) .dwattr $C$DW$6, DW_AT_accessibility(DW_ACCESS_public) $C$DW$356 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$356, DW_AT_type(*$C$DW$T$122) .dwendtag $C$DW$6 .dwendtag $C$DW$T$124 .dwattr $C$DW$T$124, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$T$124, DW_AT_decl_line(0x2b) .dwattr $C$DW$T$124, DW_AT_decl_column(0x01) $C$DW$T$121 .dwtag DW_TAG_const_type .dwattr $C$DW$T$121, DW_AT_type(*$C$DW$T$124) $C$DW$T$122 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$122, DW_AT_type(*$C$DW$T$121) .dwattr $C$DW$T$122, DW_AT_address_class(0x20) $C$DW$T$499 .dwtag DW_TAG_typedef, DW_AT_name("CBufferMgr_Buffer") .dwattr $C$DW$T$499, DW_AT_type(*$C$DW$T$124) .dwattr $C$DW$T$499, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$499, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$T$499, DW_AT_decl_line(0x3a) .dwattr $C$DW$T$499, DW_AT_decl_column(0x03) $C$DW$T$500 .dwtag DW_TAG_array_type .dwattr $C$DW$T$500, DW_AT_type(*$C$DW$T$499) .dwattr $C$DW$T$500, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$500, DW_AT_byte_size(0x40) $C$DW$357 .dwtag DW_TAG_subrange_type .dwattr $C$DW$357, DW_AT_upper_bound(0x01) .dwendtag $C$DW$T$500 $C$DW$T$521 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$521, DW_AT_type(*$C$DW$T$499) .dwattr $C$DW$T$521, DW_AT_address_class(0x20) $C$DW$T$522 .dwtag DW_TAG_array_type .dwattr $C$DW$T$522, DW_AT_type(*$C$DW$T$521) .dwattr $C$DW$T$522, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$522, DW_AT_byte_size(0x08) $C$DW$358 .dwtag DW_TAG_subrange_type .dwattr $C$DW$358, DW_AT_upper_bound(0x01) .dwendtag $C$DW$T$522 $C$DW$T$120 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$120, DW_AT_type(*$C$DW$T$124) .dwattr $C$DW$T$120, DW_AT_address_class(0x20) $C$DW$T$123 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$123, DW_AT_type(*$C$DW$T$120) .dwattr $C$DW$T$123, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$359 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$359, DW_AT_type(*$C$DW$T$122) .dwendtag $C$DW$T$123 $C$DW$T$1592 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1592, DW_AT_name("CBufferMgr_CacheWbInvEnum") .dwattr $C$DW$T$1592, DW_AT_byte_size(0x04) $C$DW$360 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFFERMGR_CACHE_WB_INVALIDATE"), DW_AT_const_value(0x00) .dwattr $C$DW$360, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$360, DW_AT_decl_line(0xec) .dwattr $C$DW$360, DW_AT_decl_column(0x05) $C$DW$361 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFFERMGR_CACHE_INVALIDATE"), DW_AT_const_value(0x01) .dwattr $C$DW$361, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$361, DW_AT_decl_line(0xed) .dwattr $C$DW$361, DW_AT_decl_column(0x05) $C$DW$362 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFFERMGR_CACHE_WB"), DW_AT_const_value(0x02) .dwattr $C$DW$362, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$362, DW_AT_decl_line(0xee) .dwattr $C$DW$362, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1592 .dwattr $C$DW$T$1592, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$T$1592, DW_AT_decl_line(0xeb) .dwattr $C$DW$T$1592, DW_AT_decl_column(0x0e) $C$DW$T$1593 .dwtag DW_TAG_typedef, DW_AT_name("CBufferMgr_CacheWbInvEnum") .dwattr $C$DW$T$1593, DW_AT_type(*$C$DW$T$1592) .dwattr $C$DW$T$1593, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1593, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$T$1593, DW_AT_decl_line(0xef) .dwattr $C$DW$T$1593, DW_AT_decl_column(0x03) $C$DW$T$1596 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1596, DW_AT_name("CSL_OpenMode") .dwattr $C$DW$T$1596, DW_AT_byte_size(0x04) $C$DW$363 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_EXCLUSIVE"), DW_AT_const_value(0x00) .dwattr $C$DW$363, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$363, DW_AT_decl_line(0x4a) .dwattr $C$DW$363, DW_AT_decl_column(0x03) $C$DW$364 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_SHARED"), DW_AT_const_value(0x01) .dwattr $C$DW$364, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$364, DW_AT_decl_line(0x4b) .dwattr $C$DW$364, DW_AT_decl_column(0x03) .dwendtag $C$DW$T$1596 .dwattr $C$DW$T$1596, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$T$1596, DW_AT_decl_line(0x49) .dwattr $C$DW$T$1596, DW_AT_decl_column(0x0e) $C$DW$T$1597 .dwtag DW_TAG_typedef, DW_AT_name("CSL_OpenMode") .dwattr $C$DW$T$1597, DW_AT_type(*$C$DW$T$1596) .dwattr $C$DW$T$1597, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1597, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$T$1597, DW_AT_decl_line(0x4c) .dwattr $C$DW$T$1597, DW_AT_decl_column(0x03) $C$DW$T$1598 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1598, DW_AT_name("CSL_Test") .dwattr $C$DW$T$1598, DW_AT_byte_size(0x04) $C$DW$365 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_FAIL"), DW_AT_const_value(0x00) .dwattr $C$DW$365, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$365, DW_AT_decl_line(0x4f) .dwattr $C$DW$365, DW_AT_decl_column(0x03) $C$DW$366 .dwtag DW_TAG_enumerator, DW_AT_name("CSL_PASS"), DW_AT_const_value(0x01) .dwattr $C$DW$366, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$366, DW_AT_decl_line(0x50) .dwattr $C$DW$366, DW_AT_decl_column(0x03) .dwendtag $C$DW$T$1598 .dwattr $C$DW$T$1598, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$T$1598, DW_AT_decl_line(0x4e) .dwattr $C$DW$T$1598, DW_AT_decl_column(0x0e) $C$DW$T$1599 .dwtag DW_TAG_typedef, DW_AT_name("CSL_Test") .dwattr $C$DW$T$1599, DW_AT_type(*$C$DW$T$1598) .dwattr $C$DW$T$1599, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1599, DW_AT_decl_file("C:/ti/pdk_c667x_2_0_5/packages/ti/csl/csl_types.h") .dwattr $C$DW$T$1599, DW_AT_decl_line(0x51) .dwattr $C$DW$T$1599, DW_AT_decl_column(0x03) $C$DW$T$212 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$212, DW_AT_name("CVizBase_Param") .dwattr $C$DW$T$212, DW_AT_byte_size(0xc18) $C$DW$367 .dwtag DW_TAG_member .dwattr $C$DW$367, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$367, DW_AT_name("baseId") .dwattr $C$DW$367, DW_AT_TI_symbol_name("baseId") .dwattr $C$DW$367, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$367, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$367, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$367, DW_AT_decl_line(0x37f) .dwattr $C$DW$367, DW_AT_decl_column(0x05) $C$DW$368 .dwtag DW_TAG_member .dwattr $C$DW$368, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$368, DW_AT_name("enabled") .dwattr $C$DW$368, DW_AT_TI_symbol_name("enabled") .dwattr $C$DW$368, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$368, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$368, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$368, DW_AT_decl_line(0x380) .dwattr $C$DW$368, DW_AT_decl_column(0x05) $C$DW$369 .dwtag DW_TAG_member .dwattr $C$DW$369, DW_AT_type(*$C$DW$T$195) .dwattr $C$DW$369, DW_AT_name("resolution") .dwattr $C$DW$369, DW_AT_TI_symbol_name("resolution") .dwattr $C$DW$369, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$369, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$369, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$369, DW_AT_decl_line(0x381) .dwattr $C$DW$369, DW_AT_decl_column(0x05) $C$DW$370 .dwtag DW_TAG_member .dwattr $C$DW$370, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$370, DW_AT_name("dBRange") .dwattr $C$DW$370, DW_AT_TI_symbol_name("dBRange") .dwattr $C$DW$370, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0] .dwattr $C$DW$370, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$370, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$370, DW_AT_decl_line(0x382) .dwattr $C$DW$370, DW_AT_decl_column(0x05) $C$DW$371 .dwtag DW_TAG_member .dwattr $C$DW$371, DW_AT_type(*$C$DW$T$196) .dwattr $C$DW$371, DW_AT_name("fill") .dwattr $C$DW$371, DW_AT_TI_symbol_name("fill") .dwattr $C$DW$371, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$371, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$371, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$371, DW_AT_decl_line(0x383) .dwattr $C$DW$371, DW_AT_decl_column(0x05) $C$DW$372 .dwtag DW_TAG_member .dwattr $C$DW$372, DW_AT_type(*$C$DW$T$197) .dwattr $C$DW$372, DW_AT_name("gaussian") .dwattr $C$DW$372, DW_AT_TI_symbol_name("gaussian") .dwattr $C$DW$372, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c8] .dwattr $C$DW$372, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$372, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$372, DW_AT_decl_line(0x384) .dwattr $C$DW$372, DW_AT_decl_column(0x05) $C$DW$373 .dwtag DW_TAG_member .dwattr $C$DW$373, DW_AT_type(*$C$DW$T$198) .dwattr $C$DW$373, DW_AT_name("edgeDetection") .dwattr $C$DW$373, DW_AT_TI_symbol_name("edgeDetection") .dwattr $C$DW$373, DW_AT_data_member_location[DW_OP_plus_uconst 0x258] .dwattr $C$DW$373, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$373, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$373, DW_AT_decl_line(0x385) .dwattr $C$DW$373, DW_AT_decl_column(0x05) $C$DW$374 .dwtag DW_TAG_member .dwattr $C$DW$374, DW_AT_type(*$C$DW$T$199) .dwattr $C$DW$374, DW_AT_name("edgeDirection") .dwattr $C$DW$374, DW_AT_TI_symbol_name("edgeDirection") .dwattr $C$DW$374, DW_AT_data_member_location[DW_OP_plus_uconst 0x370] .dwattr $C$DW$374, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$374, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$374, DW_AT_decl_line(0x386) .dwattr $C$DW$374, DW_AT_decl_column(0x05) $C$DW$375 .dwtag DW_TAG_member .dwattr $C$DW$375, DW_AT_type(*$C$DW$T$200) .dwattr $C$DW$375, DW_AT_name("edgeReliability") .dwattr $C$DW$375, DW_AT_TI_symbol_name("edgeReliability") .dwattr $C$DW$375, DW_AT_data_member_location[DW_OP_plus_uconst 0x488] .dwattr $C$DW$375, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$375, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$375, DW_AT_decl_line(0x387) .dwattr $C$DW$375, DW_AT_decl_column(0x05) $C$DW$376 .dwtag DW_TAG_member .dwattr $C$DW$376, DW_AT_type(*$C$DW$T$201) .dwattr $C$DW$376, DW_AT_name("emphasis") .dwattr $C$DW$376, DW_AT_TI_symbol_name("emphasis") .dwattr $C$DW$376, DW_AT_data_member_location[DW_OP_plus_uconst 0x538] .dwattr $C$DW$376, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$376, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$376, DW_AT_decl_line(0x388) .dwattr $C$DW$376, DW_AT_decl_column(0x05) $C$DW$377 .dwtag DW_TAG_member .dwattr $C$DW$377, DW_AT_type(*$C$DW$T$202) .dwattr $C$DW$377, DW_AT_name("directionFilter") .dwattr $C$DW$377, DW_AT_TI_symbol_name("directionFilter") .dwattr $C$DW$377, DW_AT_data_member_location[DW_OP_plus_uconst 0x678] .dwattr $C$DW$377, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$377, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$377, DW_AT_decl_line(0x389) .dwattr $C$DW$377, DW_AT_decl_column(0x05) $C$DW$378 .dwtag DW_TAG_member .dwattr $C$DW$378, DW_AT_type(*$C$DW$T$203) .dwattr $C$DW$378, DW_AT_name("nepS") .dwattr $C$DW$378, DW_AT_TI_symbol_name("nepS") .dwattr $C$DW$378, DW_AT_data_member_location[DW_OP_plus_uconst 0x770] .dwattr $C$DW$378, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$378, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$378, DW_AT_decl_line(0x38a) .dwattr $C$DW$378, DW_AT_decl_column(0x05) $C$DW$379 .dwtag DW_TAG_member .dwattr $C$DW$379, DW_AT_type(*$C$DW$T$201) .dwattr $C$DW$379, DW_AT_name("emphasis2") .dwattr $C$DW$379, DW_AT_TI_symbol_name("emphasis2") .dwattr $C$DW$379, DW_AT_data_member_location[DW_OP_plus_uconst 0x898] .dwattr $C$DW$379, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$379, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$379, DW_AT_decl_line(0x38b) .dwattr $C$DW$379, DW_AT_decl_column(0x05) $C$DW$380 .dwtag DW_TAG_member .dwattr $C$DW$380, DW_AT_type(*$C$DW$T$204) .dwattr $C$DW$380, DW_AT_name("path") .dwattr $C$DW$380, DW_AT_TI_symbol_name("path") .dwattr $C$DW$380, DW_AT_data_member_location[DW_OP_plus_uconst 0x9d8] .dwattr $C$DW$380, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$380, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$380, DW_AT_decl_line(0x38c) .dwattr $C$DW$380, DW_AT_decl_column(0x05) $C$DW$381 .dwtag DW_TAG_member .dwattr $C$DW$381, DW_AT_type(*$C$DW$T$205) .dwattr $C$DW$381, DW_AT_name("ftc") .dwattr $C$DW$381, DW_AT_TI_symbol_name("ftc") .dwattr $C$DW$381, DW_AT_data_member_location[DW_OP_plus_uconst 0xa68] .dwattr $C$DW$381, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$381, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$381, DW_AT_decl_line(0x38d) .dwattr $C$DW$381, DW_AT_decl_column(0x05) $C$DW$382 .dwtag DW_TAG_member .dwattr $C$DW$382, DW_AT_type(*$C$DW$T$206) .dwattr $C$DW$382, DW_AT_name("lineThin") .dwattr $C$DW$382, DW_AT_TI_symbol_name("lineThin") .dwattr $C$DW$382, DW_AT_data_member_location[DW_OP_plus_uconst 0xb18] .dwattr $C$DW$382, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$382, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$382, DW_AT_decl_line(0x38e) .dwattr $C$DW$382, DW_AT_decl_column(0x05) $C$DW$383 .dwtag DW_TAG_member .dwattr $C$DW$383, DW_AT_type(*$C$DW$T$207) .dwattr $C$DW$383, DW_AT_name("dummy") .dwattr $C$DW$383, DW_AT_TI_symbol_name("dummy") .dwattr $C$DW$383, DW_AT_data_member_location[DW_OP_plus_uconst 0xbb8] .dwattr $C$DW$383, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$383, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$383, DW_AT_decl_line(0x38f) .dwattr $C$DW$383, DW_AT_decl_column(0x05) $C$DW$7 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$7, DW_AT_declaration .dwattr $C$DW$7, DW_AT_TI_symbol_name("_ZN14CVizBase_ParamaSERKS_") .dwattr $C$DW$7, DW_AT_type(*$C$DW$T$208) .dwattr $C$DW$7, DW_AT_accessibility(DW_ACCESS_public) $C$DW$384 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$384, DW_AT_type(*$C$DW$T$210) .dwendtag $C$DW$7 .dwendtag $C$DW$T$212 .dwattr $C$DW$T$212, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$212, DW_AT_decl_line(0x37e) .dwattr $C$DW$T$212, DW_AT_decl_column(0x10) $C$DW$T$209 .dwtag DW_TAG_const_type .dwattr $C$DW$T$209, DW_AT_type(*$C$DW$T$212) $C$DW$T$210 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$210, DW_AT_type(*$C$DW$T$209) .dwattr $C$DW$T$210, DW_AT_address_class(0x20) $C$DW$T$1202 .dwtag DW_TAG_typedef, DW_AT_name("CVizBase_Param") .dwattr $C$DW$T$1202, DW_AT_type(*$C$DW$T$212) .dwattr $C$DW$T$1202, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1202, DW_AT_decl_line(0x390) .dwattr $C$DW$T$1202, DW_AT_decl_column(0x03) $C$DW$T$208 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$208, DW_AT_type(*$C$DW$T$212) .dwattr $C$DW$T$208, DW_AT_address_class(0x20) $C$DW$T$211 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$211, DW_AT_type(*$C$DW$T$208) .dwattr $C$DW$T$211, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$385 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$385, DW_AT_type(*$C$DW$T$210) .dwendtag $C$DW$T$211 $C$DW$T$225 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$225, DW_AT_name("CVizUser_Param") .dwattr $C$DW$T$225, DW_AT_byte_size(0x440) $C$DW$386 .dwtag DW_TAG_member .dwattr $C$DW$386, DW_AT_type(*$C$DW$T$213) .dwattr $C$DW$386, DW_AT_name("speckleReduction") .dwattr $C$DW$386, DW_AT_TI_symbol_name("speckleReduction") .dwattr $C$DW$386, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$386, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$386, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$386, DW_AT_decl_line(0x3c5) .dwattr $C$DW$386, DW_AT_decl_column(0x05) $C$DW$387 .dwtag DW_TAG_member .dwattr $C$DW$387, DW_AT_type(*$C$DW$T$214) .dwattr $C$DW$387, DW_AT_name("edgeEnhance") .dwattr $C$DW$387, DW_AT_TI_symbol_name("edgeEnhance") .dwattr $C$DW$387, DW_AT_data_member_location[DW_OP_plus_uconst 0x88] .dwattr $C$DW$387, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$387, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$387, DW_AT_decl_line(0x3c6) .dwattr $C$DW$387, DW_AT_decl_column(0x05) $C$DW$388 .dwtag DW_TAG_member .dwattr $C$DW$388, DW_AT_type(*$C$DW$T$215) .dwattr $C$DW$388, DW_AT_name("sharpness") .dwattr $C$DW$388, DW_AT_TI_symbol_name("sharpness") .dwattr $C$DW$388, DW_AT_data_member_location[DW_OP_plus_uconst 0x118] .dwattr $C$DW$388, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$388, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$388, DW_AT_decl_line(0x3c7) .dwattr $C$DW$388, DW_AT_decl_column(0x05) $C$DW$389 .dwtag DW_TAG_member .dwattr $C$DW$389, DW_AT_type(*$C$DW$T$216) .dwattr $C$DW$389, DW_AT_name("blackSpotFill") .dwattr $C$DW$389, DW_AT_TI_symbol_name("blackSpotFill") .dwattr $C$DW$389, DW_AT_data_member_location[DW_OP_plus_uconst 0x1b0] .dwattr $C$DW$389, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$389, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$389, DW_AT_decl_line(0x3c8) .dwattr $C$DW$389, DW_AT_decl_column(0x05) $C$DW$390 .dwtag DW_TAG_member .dwattr $C$DW$390, DW_AT_type(*$C$DW$T$217) .dwattr $C$DW$390, DW_AT_name("lineThinning") .dwattr $C$DW$390, DW_AT_TI_symbol_name("lineThinning") .dwattr $C$DW$390, DW_AT_data_member_location[DW_OP_plus_uconst 0x240] .dwattr $C$DW$390, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$390, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$390, DW_AT_decl_line(0x3c9) .dwattr $C$DW$390, DW_AT_decl_column(0x05) $C$DW$391 .dwtag DW_TAG_member .dwattr $C$DW$391, DW_AT_type(*$C$DW$T$218) .dwattr $C$DW$391, DW_AT_name("edgeThreshold") .dwattr $C$DW$391, DW_AT_TI_symbol_name("edgeThreshold") .dwattr $C$DW$391, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d0] .dwattr $C$DW$391, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$391, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$391, DW_AT_decl_line(0x3ca) .dwattr $C$DW$391, DW_AT_decl_column(0x05) $C$DW$392 .dwtag DW_TAG_member .dwattr $C$DW$392, DW_AT_type(*$C$DW$T$219) .dwattr $C$DW$392, DW_AT_name("hContrast") .dwattr $C$DW$392, DW_AT_TI_symbol_name("hContrast") .dwattr $C$DW$392, DW_AT_data_member_location[DW_OP_plus_uconst 0x370] .dwattr $C$DW$392, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$392, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$392, DW_AT_decl_line(0x3cb) .dwattr $C$DW$392, DW_AT_decl_column(0x05) $C$DW$393 .dwtag DW_TAG_member .dwattr $C$DW$393, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$393, DW_AT_name("adaptiveFilterRatio") .dwattr $C$DW$393, DW_AT_TI_symbol_name("adaptiveFilterRatio") .dwattr $C$DW$393, DW_AT_data_member_location[DW_OP_plus_uconst 0x410] .dwattr $C$DW$393, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$393, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$393, DW_AT_decl_line(0x3cc) .dwattr $C$DW$393, DW_AT_decl_column(0x05) $C$DW$394 .dwtag DW_TAG_member .dwattr $C$DW$394, DW_AT_type(*$C$DW$T$220) .dwattr $C$DW$394, DW_AT_name("reserve") .dwattr $C$DW$394, DW_AT_TI_symbol_name("reserve") .dwattr $C$DW$394, DW_AT_data_member_location[DW_OP_plus_uconst 0x418] .dwattr $C$DW$394, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$394, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$394, DW_AT_decl_line(0x3cd) .dwattr $C$DW$394, DW_AT_decl_column(0x05) $C$DW$8 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$8, DW_AT_declaration .dwattr $C$DW$8, DW_AT_TI_symbol_name("_ZN14CVizUser_ParamaSERKS_") .dwattr $C$DW$8, DW_AT_type(*$C$DW$T$221) .dwattr $C$DW$8, DW_AT_accessibility(DW_ACCESS_public) $C$DW$395 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$395, DW_AT_type(*$C$DW$T$223) .dwendtag $C$DW$8 .dwendtag $C$DW$T$225 .dwattr $C$DW$T$225, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$225, DW_AT_decl_line(0x3c4) .dwattr $C$DW$T$225, DW_AT_decl_column(0x01) $C$DW$T$222 .dwtag DW_TAG_const_type .dwattr $C$DW$T$222, DW_AT_type(*$C$DW$T$225) $C$DW$T$223 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$223, DW_AT_type(*$C$DW$T$222) .dwattr $C$DW$T$223, DW_AT_address_class(0x20) $C$DW$T$1583 .dwtag DW_TAG_typedef, DW_AT_name("CVizUser_Param") .dwattr $C$DW$T$1583, DW_AT_type(*$C$DW$T$225) .dwattr $C$DW$T$1583, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1583, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1583, DW_AT_decl_line(0x3ce) .dwattr $C$DW$T$1583, DW_AT_decl_column(0x03) $C$DW$T$221 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$221, DW_AT_type(*$C$DW$T$225) .dwattr $C$DW$T$221, DW_AT_address_class(0x20) $C$DW$T$224 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$224, DW_AT_type(*$C$DW$T$221) .dwattr $C$DW$T$224, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$396 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$396, DW_AT_type(*$C$DW$T$223) .dwendtag $C$DW$T$224 $C$DW$T$1922 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1922, DW_AT_name("CbufErrorSourceType") .dwattr $C$DW$T$1922, DW_AT_byte_size(0x04) $C$DW$397 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ALLOCATE"), DW_AT_const_value(0x10) .dwattr $C$DW$397, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$397, DW_AT_decl_line(0x5a) .dwattr $C$DW$397, DW_AT_decl_column(0x05) $C$DW$398 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_RECYCLE"), DW_AT_const_value(0x11) .dwattr $C$DW$398, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$398, DW_AT_decl_line(0x5b) .dwattr $C$DW$398, DW_AT_decl_column(0x05) $C$DW$399 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_0"), DW_AT_const_value(0x100) .dwattr $C$DW$399, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$399, DW_AT_decl_line(0x5e) .dwattr $C$DW$399, DW_AT_decl_column(0x05) $C$DW$400 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_1"), DW_AT_const_value(0x101) .dwattr $C$DW$400, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$400, DW_AT_decl_line(0x5f) .dwattr $C$DW$400, DW_AT_decl_column(0x05) $C$DW$401 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_2"), DW_AT_const_value(0x102) .dwattr $C$DW$401, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$401, DW_AT_decl_line(0x60) .dwattr $C$DW$401, DW_AT_decl_column(0x05) $C$DW$402 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_3"), DW_AT_const_value(0x103) .dwattr $C$DW$402, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$402, DW_AT_decl_line(0x61) .dwattr $C$DW$402, DW_AT_decl_column(0x05) $C$DW$403 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_4"), DW_AT_const_value(0x104) .dwattr $C$DW$403, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$403, DW_AT_decl_line(0x62) .dwattr $C$DW$403, DW_AT_decl_column(0x05) $C$DW$404 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_5"), DW_AT_const_value(0x105) .dwattr $C$DW$404, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$404, DW_AT_decl_line(0x63) .dwattr $C$DW$404, DW_AT_decl_column(0x05) $C$DW$405 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_6"), DW_AT_const_value(0x106) .dwattr $C$DW$405, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$405, DW_AT_decl_line(0x64) .dwattr $C$DW$405, DW_AT_decl_column(0x05) $C$DW$406 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_7"), DW_AT_const_value(0x107) .dwattr $C$DW$406, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$406, DW_AT_decl_line(0x65) .dwattr $C$DW$406, DW_AT_decl_column(0x05) $C$DW$407 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_8"), DW_AT_const_value(0x108) .dwattr $C$DW$407, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$407, DW_AT_decl_line(0x66) .dwattr $C$DW$407, DW_AT_decl_column(0x05) $C$DW$408 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_9"), DW_AT_const_value(0x109) .dwattr $C$DW$408, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$408, DW_AT_decl_line(0x67) .dwattr $C$DW$408, DW_AT_decl_column(0x05) $C$DW$409 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_10"), DW_AT_const_value(0x10a) .dwattr $C$DW$409, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$409, DW_AT_decl_line(0x68) .dwattr $C$DW$409, DW_AT_decl_column(0x05) $C$DW$410 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_11"), DW_AT_const_value(0x10b) .dwattr $C$DW$410, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$410, DW_AT_decl_line(0x69) .dwattr $C$DW$410, DW_AT_decl_column(0x05) $C$DW$411 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_12"), DW_AT_const_value(0x10c) .dwattr $C$DW$411, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$411, DW_AT_decl_line(0x6a) .dwattr $C$DW$411, DW_AT_decl_column(0x05) $C$DW$412 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_13"), DW_AT_const_value(0x10d) .dwattr $C$DW$412, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$412, DW_AT_decl_line(0x6b) .dwattr $C$DW$412, DW_AT_decl_column(0x05) $C$DW$413 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_14"), DW_AT_const_value(0x10e) .dwattr $C$DW$413, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$413, DW_AT_decl_line(0x6c) .dwattr $C$DW$413, DW_AT_decl_column(0x05) $C$DW$414 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_CINE_MGR_15"), DW_AT_const_value(0x10f) .dwattr $C$DW$414, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$414, DW_AT_decl_line(0x6d) .dwattr $C$DW$414, DW_AT_decl_column(0x05) $C$DW$415 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_HEAP_MEM_MGR_0"), DW_AT_const_value(0x200) .dwattr $C$DW$415, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$415, DW_AT_decl_line(0x6f) .dwattr $C$DW$415, DW_AT_decl_column(0x05) $C$DW$416 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_HOST_MGR_0"), DW_AT_const_value(0x300) .dwattr $C$DW$416, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$416, DW_AT_decl_line(0x71) .dwattr $C$DW$416, DW_AT_decl_column(0x05) $C$DW$417 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_IN_MGR_0"), DW_AT_const_value(0x400) .dwattr $C$DW$417, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$417, DW_AT_decl_line(0x73) .dwattr $C$DW$417, DW_AT_decl_column(0x05) $C$DW$418 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_0"), DW_AT_const_value(0x500) .dwattr $C$DW$418, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$418, DW_AT_decl_line(0x75) .dwattr $C$DW$418, DW_AT_decl_column(0x05) $C$DW$419 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_1"), DW_AT_const_value(0x501) .dwattr $C$DW$419, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$419, DW_AT_decl_line(0x76) .dwattr $C$DW$419, DW_AT_decl_column(0x05) $C$DW$420 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_2"), DW_AT_const_value(0x502) .dwattr $C$DW$420, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$420, DW_AT_decl_line(0x77) .dwattr $C$DW$420, DW_AT_decl_column(0x05) $C$DW$421 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_3"), DW_AT_const_value(0x503) .dwattr $C$DW$421, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$421, DW_AT_decl_line(0x78) .dwattr $C$DW$421, DW_AT_decl_column(0x05) $C$DW$422 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_4"), DW_AT_const_value(0x504) .dwattr $C$DW$422, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$422, DW_AT_decl_line(0x79) .dwattr $C$DW$422, DW_AT_decl_column(0x05) $C$DW$423 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_5"), DW_AT_const_value(0x505) .dwattr $C$DW$423, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$423, DW_AT_decl_line(0x7a) .dwattr $C$DW$423, DW_AT_decl_column(0x05) $C$DW$424 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_6"), DW_AT_const_value(0x506) .dwattr $C$DW$424, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$424, DW_AT_decl_line(0x7b) .dwattr $C$DW$424, DW_AT_decl_column(0x05) $C$DW$425 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_7"), DW_AT_const_value(0x507) .dwattr $C$DW$425, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$425, DW_AT_decl_line(0x7c) .dwattr $C$DW$425, DW_AT_decl_column(0x05) $C$DW$426 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MULTICORE_MGR_ECG_CINE"), DW_AT_const_value(0x508) .dwattr $C$DW$426, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$426, DW_AT_decl_line(0x7d) .dwattr $C$DW$426, DW_AT_decl_column(0x05) $C$DW$427 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_0"), DW_AT_const_value(0x600) .dwattr $C$DW$427, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$427, DW_AT_decl_line(0x7f) .dwattr $C$DW$427, DW_AT_decl_column(0x05) $C$DW$428 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_1"), DW_AT_const_value(0x601) .dwattr $C$DW$428, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$428, DW_AT_decl_line(0x80) .dwattr $C$DW$428, DW_AT_decl_column(0x05) $C$DW$429 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_2"), DW_AT_const_value(0x602) .dwattr $C$DW$429, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$429, DW_AT_decl_line(0x81) .dwattr $C$DW$429, DW_AT_decl_column(0x05) $C$DW$430 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_3"), DW_AT_const_value(0x603) .dwattr $C$DW$430, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$430, DW_AT_decl_line(0x82) .dwattr $C$DW$430, DW_AT_decl_column(0x05) $C$DW$431 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_4"), DW_AT_const_value(0x604) .dwattr $C$DW$431, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$431, DW_AT_decl_line(0x83) .dwattr $C$DW$431, DW_AT_decl_column(0x05) $C$DW$432 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_OUT_MGR_ECG_READ"), DW_AT_const_value(0x605) .dwattr $C$DW$432, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$432, DW_AT_decl_line(0x84) .dwattr $C$DW$432, DW_AT_decl_column(0x05) $C$DW$433 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_PLAYLIST_0"), DW_AT_const_value(0x700) .dwattr $C$DW$433, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$433, DW_AT_decl_line(0x86) .dwattr $C$DW$433, DW_AT_decl_column(0x05) $C$DW$434 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_PLAYLIST_1"), DW_AT_const_value(0x701) .dwattr $C$DW$434, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$434, DW_AT_decl_line(0x87) .dwattr $C$DW$434, DW_AT_decl_column(0x05) $C$DW$435 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_PLAYLIST_2"), DW_AT_const_value(0x702) .dwattr $C$DW$435, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$435, DW_AT_decl_line(0x88) .dwattr $C$DW$435, DW_AT_decl_column(0x05) $C$DW$436 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_0"), DW_AT_const_value(0x800) .dwattr $C$DW$436, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$436, DW_AT_decl_line(0x89) .dwattr $C$DW$436, DW_AT_decl_column(0x05) $C$DW$437 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_1"), DW_AT_const_value(0x801) .dwattr $C$DW$437, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$437, DW_AT_decl_line(0x8a) .dwattr $C$DW$437, DW_AT_decl_column(0x05) $C$DW$438 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_2"), DW_AT_const_value(0x802) .dwattr $C$DW$438, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$438, DW_AT_decl_line(0x8b) .dwattr $C$DW$438, DW_AT_decl_column(0x05) $C$DW$439 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_3"), DW_AT_const_value(0x803) .dwattr $C$DW$439, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$439, DW_AT_decl_line(0x8c) .dwattr $C$DW$439, DW_AT_decl_column(0x05) $C$DW$440 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_ASYNC_LIST_TWOD"), DW_AT_const_value(0x810) .dwattr $C$DW$440, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$440, DW_AT_decl_line(0x8e) .dwattr $C$DW$440, DW_AT_decl_column(0x05) $C$DW$441 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_ASYNC_LIST_COLOR"), DW_AT_const_value(0x811) .dwattr $C$DW$441, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$441, DW_AT_decl_line(0x8f) .dwattr $C$DW$441, DW_AT_decl_column(0x05) $C$DW$442 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_ASYNC_LIST_COLOR_VAR"), DW_AT_const_value(0x812) .dwattr $C$DW$442, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$442, DW_AT_decl_line(0x90) .dwattr $C$DW$442, DW_AT_decl_column(0x05) $C$DW$443 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_AUDIO"), DW_AT_const_value(0x830) .dwattr $C$DW$443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$443, DW_AT_decl_line(0x92) .dwattr $C$DW$443, DW_AT_decl_column(0x05) $C$DW$444 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_DOPPLER"), DW_AT_const_value(0x831) .dwattr $C$DW$444, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$444, DW_AT_decl_line(0x93) .dwattr $C$DW$444, DW_AT_decl_column(0x05) $C$DW$445 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_PK_MN0"), DW_AT_const_value(0x832) .dwattr $C$DW$445, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$445, DW_AT_decl_line(0x94) .dwattr $C$DW$445, DW_AT_decl_column(0x05) $C$DW$446 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_RAW_PK_MN1"), DW_AT_const_value(0x833) .dwattr $C$DW$446, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$446, DW_AT_decl_line(0x95) .dwattr $C$DW$446, DW_AT_decl_column(0x05) $C$DW$447 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_MMODE"), DW_AT_const_value(0x834) .dwattr $C$DW$447, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$447, DW_AT_decl_line(0x96) .dwattr $C$DW$447, DW_AT_decl_column(0x05) $C$DW$448 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_ECG"), DW_AT_const_value(0x835) .dwattr $C$DW$448, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$448, DW_AT_decl_line(0x97) .dwattr $C$DW$448, DW_AT_decl_column(0x05) $C$DW$449 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_OUTMGR_PLAYLIST"), DW_AT_const_value(0x836) .dwattr $C$DW$449, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$449, DW_AT_decl_line(0x98) .dwattr $C$DW$449, DW_AT_decl_column(0x05) $C$DW$450 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_SRIO_SYNC_LIST_ECGTEST_SPCTL"), DW_AT_const_value(0x840) .dwattr $C$DW$450, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$450, DW_AT_decl_line(0x99) .dwattr $C$DW$450, DW_AT_decl_column(0x05) $C$DW$451 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_WORKER_0"), DW_AT_const_value(0x900) .dwattr $C$DW$451, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$451, DW_AT_decl_line(0x9b) .dwattr $C$DW$451, DW_AT_decl_column(0x05) $C$DW$452 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_COLOR_0"), DW_AT_const_value(0x1000) .dwattr $C$DW$452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$452, DW_AT_decl_line(0x9e) .dwattr $C$DW$452, DW_AT_decl_column(0x05) $C$DW$453 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_0"), DW_AT_const_value(0x1200) .dwattr $C$DW$453, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$453, DW_AT_decl_line(0xa0) .dwattr $C$DW$453, DW_AT_decl_column(0x05) $C$DW$454 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_1"), DW_AT_const_value(0x1201) .dwattr $C$DW$454, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$454, DW_AT_decl_line(0xa1) .dwattr $C$DW$454, DW_AT_decl_column(0x05) $C$DW$455 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_2"), DW_AT_const_value(0x1202) .dwattr $C$DW$455, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$455, DW_AT_decl_line(0xa2) .dwattr $C$DW$455, DW_AT_decl_column(0x05) $C$DW$456 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_3"), DW_AT_const_value(0x1203) .dwattr $C$DW$456, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$456, DW_AT_decl_line(0xa3) .dwattr $C$DW$456, DW_AT_decl_column(0x05) $C$DW$457 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_4"), DW_AT_const_value(0x1204) .dwattr $C$DW$457, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$457, DW_AT_decl_line(0xa4) .dwattr $C$DW$457, DW_AT_decl_column(0x05) $C$DW$458 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_5"), DW_AT_const_value(0x1205) .dwattr $C$DW$458, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$458, DW_AT_decl_line(0xa5) .dwattr $C$DW$458, DW_AT_decl_column(0x05) $C$DW$459 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_6"), DW_AT_const_value(0x1206) .dwattr $C$DW$459, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$459, DW_AT_decl_line(0xa6) .dwattr $C$DW$459, DW_AT_decl_column(0x05) $C$DW$460 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_7"), DW_AT_const_value(0x1207) .dwattr $C$DW$460, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$460, DW_AT_decl_line(0xa7) .dwattr $C$DW$460, DW_AT_decl_column(0x05) $C$DW$461 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_8"), DW_AT_const_value(0x1208) .dwattr $C$DW$461, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$461, DW_AT_decl_line(0xa8) .dwattr $C$DW$461, DW_AT_decl_column(0x05) $C$DW$462 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_9"), DW_AT_const_value(0x1209) .dwattr $C$DW$462, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$462, DW_AT_decl_line(0xa9) .dwattr $C$DW$462, DW_AT_decl_column(0x05) $C$DW$463 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_10"), DW_AT_const_value(0x120a) .dwattr $C$DW$463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$463, DW_AT_decl_line(0xaa) .dwattr $C$DW$463, DW_AT_decl_column(0x05) $C$DW$464 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_11"), DW_AT_const_value(0x120b) .dwattr $C$DW$464, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$464, DW_AT_decl_line(0xab) .dwattr $C$DW$464, DW_AT_decl_column(0x05) $C$DW$465 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_12"), DW_AT_const_value(0x120c) .dwattr $C$DW$465, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$465, DW_AT_decl_line(0xac) .dwattr $C$DW$465, DW_AT_decl_column(0x05) $C$DW$466 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_13"), DW_AT_const_value(0x120d) .dwattr $C$DW$466, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$466, DW_AT_decl_line(0xad) .dwattr $C$DW$466, DW_AT_decl_column(0x05) $C$DW$467 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_14"), DW_AT_const_value(0x120e) .dwattr $C$DW$467, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$467, DW_AT_decl_line(0xae) .dwattr $C$DW$467, DW_AT_decl_column(0x05) $C$DW$468 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_16"), DW_AT_const_value(0x1210) .dwattr $C$DW$468, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$468, DW_AT_decl_line(0xaf) .dwattr $C$DW$468, DW_AT_decl_column(0x05) $C$DW$469 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_17"), DW_AT_const_value(0x1211) .dwattr $C$DW$469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$469, DW_AT_decl_line(0xb0) .dwattr $C$DW$469, DW_AT_decl_column(0x05) $C$DW$470 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_18"), DW_AT_const_value(0x1212) .dwattr $C$DW$470, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$470, DW_AT_decl_line(0xb1) .dwattr $C$DW$470, DW_AT_decl_column(0x05) $C$DW$471 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_19"), DW_AT_const_value(0x1213) .dwattr $C$DW$471, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$471, DW_AT_decl_line(0xb2) .dwattr $C$DW$471, DW_AT_decl_column(0x05) $C$DW$472 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_20"), DW_AT_const_value(0x1214) .dwattr $C$DW$472, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$472, DW_AT_decl_line(0xb3) .dwattr $C$DW$472, DW_AT_decl_column(0x05) $C$DW$473 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_21"), DW_AT_const_value(0x1215) .dwattr $C$DW$473, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$473, DW_AT_decl_line(0xb4) .dwattr $C$DW$473, DW_AT_decl_column(0x05) $C$DW$474 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_DOPPLER_22"), DW_AT_const_value(0x1216) .dwattr $C$DW$474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$474, DW_AT_decl_line(0xb5) .dwattr $C$DW$474, DW_AT_decl_column(0x05) $C$DW$475 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_0"), DW_AT_const_value(0x1300) .dwattr $C$DW$475, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$475, DW_AT_decl_line(0xb8) .dwattr $C$DW$475, DW_AT_decl_column(0x05) $C$DW$476 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_1"), DW_AT_const_value(0x1301) .dwattr $C$DW$476, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$476, DW_AT_decl_line(0xb9) .dwattr $C$DW$476, DW_AT_decl_column(0x05) $C$DW$477 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_2"), DW_AT_const_value(0x1302) .dwattr $C$DW$477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$477, DW_AT_decl_line(0xba) .dwattr $C$DW$477, DW_AT_decl_column(0x05) $C$DW$478 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_3"), DW_AT_const_value(0x1303) .dwattr $C$DW$478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$478, DW_AT_decl_line(0xbb) .dwattr $C$DW$478, DW_AT_decl_column(0x05) $C$DW$479 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_4"), DW_AT_const_value(0x1304) .dwattr $C$DW$479, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$479, DW_AT_decl_line(0xbc) .dwattr $C$DW$479, DW_AT_decl_column(0x05) $C$DW$480 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_5"), DW_AT_const_value(0x1305) .dwattr $C$DW$480, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$480, DW_AT_decl_line(0xbd) .dwattr $C$DW$480, DW_AT_decl_column(0x05) $C$DW$481 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_6"), DW_AT_const_value(0x1306) .dwattr $C$DW$481, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$481, DW_AT_decl_line(0xbe) .dwattr $C$DW$481, DW_AT_decl_column(0x05) $C$DW$482 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_7"), DW_AT_const_value(0x1307) .dwattr $C$DW$482, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$482, DW_AT_decl_line(0xbf) .dwattr $C$DW$482, DW_AT_decl_column(0x05) $C$DW$483 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_8"), DW_AT_const_value(0x1308) .dwattr $C$DW$483, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$483, DW_AT_decl_line(0xc0) .dwattr $C$DW$483, DW_AT_decl_column(0x05) $C$DW$484 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_GAP_FILL_9"), DW_AT_const_value(0x1309) .dwattr $C$DW$484, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$484, DW_AT_decl_line(0xc1) .dwattr $C$DW$484, DW_AT_decl_column(0x05) $C$DW$485 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_0"), DW_AT_const_value(0x1320) .dwattr $C$DW$485, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$485, DW_AT_decl_line(0xc3) .dwattr $C$DW$485, DW_AT_decl_column(0x05) $C$DW$486 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_1"), DW_AT_const_value(0x1321) .dwattr $C$DW$486, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$486, DW_AT_decl_line(0xc4) .dwattr $C$DW$486, DW_AT_decl_column(0x05) $C$DW$487 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_2"), DW_AT_const_value(0x1322) .dwattr $C$DW$487, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$487, DW_AT_decl_line(0xc5) .dwattr $C$DW$487, DW_AT_decl_column(0x05) $C$DW$488 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_3"), DW_AT_const_value(0x1323) .dwattr $C$DW$488, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$488, DW_AT_decl_line(0xc6) .dwattr $C$DW$488, DW_AT_decl_column(0x05) $C$DW$489 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_4"), DW_AT_const_value(0x1324) .dwattr $C$DW$489, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$489, DW_AT_decl_line(0xc7) .dwattr $C$DW$489, DW_AT_decl_column(0x05) $C$DW$490 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_5"), DW_AT_const_value(0x1325) .dwattr $C$DW$490, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$490, DW_AT_decl_line(0xc8) .dwattr $C$DW$490, DW_AT_decl_column(0x05) $C$DW$491 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_6"), DW_AT_const_value(0x1326) .dwattr $C$DW$491, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$491, DW_AT_decl_line(0xc9) .dwattr $C$DW$491, DW_AT_decl_column(0x05) $C$DW$492 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_7"), DW_AT_const_value(0x1327) .dwattr $C$DW$492, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$492, DW_AT_decl_line(0xca) .dwattr $C$DW$492, DW_AT_decl_column(0x05) $C$DW$493 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_8"), DW_AT_const_value(0x1328) .dwattr $C$DW$493, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$493, DW_AT_decl_line(0xcb) .dwattr $C$DW$493, DW_AT_decl_column(0x05) $C$DW$494 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_9"), DW_AT_const_value(0x1329) .dwattr $C$DW$494, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$494, DW_AT_decl_line(0xcc) .dwattr $C$DW$494, DW_AT_decl_column(0x05) $C$DW$495 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_10"), DW_AT_const_value(0x132a) .dwattr $C$DW$495, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$495, DW_AT_decl_line(0xcd) .dwattr $C$DW$495, DW_AT_decl_column(0x05) $C$DW$496 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_11"), DW_AT_const_value(0x132b) .dwattr $C$DW$496, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$496, DW_AT_decl_line(0xce) .dwattr $C$DW$496, DW_AT_decl_column(0x05) $C$DW$497 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_12"), DW_AT_const_value(0x132c) .dwattr $C$DW$497, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$497, DW_AT_decl_line(0xcf) .dwattr $C$DW$497, DW_AT_decl_column(0x05) $C$DW$498 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_13"), DW_AT_const_value(0x132d) .dwattr $C$DW$498, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$498, DW_AT_decl_line(0xd0) .dwattr $C$DW$498, DW_AT_decl_column(0x05) $C$DW$499 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_14"), DW_AT_const_value(0x132e) .dwattr $C$DW$499, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$499, DW_AT_decl_line(0xd1) .dwattr $C$DW$499, DW_AT_decl_column(0x05) $C$DW$500 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_15"), DW_AT_const_value(0x132f) .dwattr $C$DW$500, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$500, DW_AT_decl_line(0xd2) .dwattr $C$DW$500, DW_AT_decl_column(0x05) $C$DW$501 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_16"), DW_AT_const_value(0x1330) .dwattr $C$DW$501, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$501, DW_AT_decl_line(0xd3) .dwattr $C$DW$501, DW_AT_decl_column(0x05) $C$DW$502 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_LINE_INTERLEAVE_17"), DW_AT_const_value(0x1331) .dwattr $C$DW$502, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$502, DW_AT_decl_line(0xd4) .dwattr $C$DW$502, DW_AT_decl_column(0x05) $C$DW$503 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_0"), DW_AT_const_value(0x1400) .dwattr $C$DW$503, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$503, DW_AT_decl_line(0xd6) .dwattr $C$DW$503, DW_AT_decl_column(0x05) $C$DW$504 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_1"), DW_AT_const_value(0x1401) .dwattr $C$DW$504, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$504, DW_AT_decl_line(0xd7) .dwattr $C$DW$504, DW_AT_decl_column(0x05) $C$DW$505 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_2"), DW_AT_const_value(0x1402) .dwattr $C$DW$505, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$505, DW_AT_decl_line(0xd8) .dwattr $C$DW$505, DW_AT_decl_column(0x05) $C$DW$506 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_3"), DW_AT_const_value(0x1403) .dwattr $C$DW$506, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$506, DW_AT_decl_line(0xd9) .dwattr $C$DW$506, DW_AT_decl_column(0x02) $C$DW$507 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MMODE_4"), DW_AT_const_value(0x1404) .dwattr $C$DW$507, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$507, DW_AT_decl_line(0xda) .dwattr $C$DW$507, DW_AT_decl_column(0x02) $C$DW$508 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_ENQUEUE_WRITE"), DW_AT_const_value(0x1500) .dwattr $C$DW$508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$508, DW_AT_decl_line(0xdc) .dwattr $C$DW$508, DW_AT_decl_column(0x02) $C$DW$509 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_PROCESS_INPUT"), DW_AT_const_value(0x1501) .dwattr $C$DW$509, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$509, DW_AT_decl_line(0xdd) .dwattr $C$DW$509, DW_AT_decl_column(0x02) $C$DW$510 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_PROCESS_READ"), DW_AT_const_value(0x1502) .dwattr $C$DW$510, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$510, DW_AT_decl_line(0xde) .dwattr $C$DW$510, DW_AT_decl_column(0x02) $C$DW$511 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_3"), DW_AT_const_value(0x1503) .dwattr $C$DW$511, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$511, DW_AT_decl_line(0xdf) .dwattr $C$DW$511, DW_AT_decl_column(0x05) $C$DW$512 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_ECG_4"), DW_AT_const_value(0x1504) .dwattr $C$DW$512, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$512, DW_AT_decl_line(0xe0) .dwattr $C$DW$512, DW_AT_decl_column(0x05) $C$DW$513 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_TWOD_0"), DW_AT_const_value(0x1600) .dwattr $C$DW$513, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$513, DW_AT_decl_line(0xe2) .dwattr $C$DW$513, DW_AT_decl_column(0x05) $C$DW$514 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_TWOD_1"), DW_AT_const_value(0x1601) .dwattr $C$DW$514, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$514, DW_AT_decl_line(0xe3) .dwattr $C$DW$514, DW_AT_decl_column(0x05) $C$DW$515 .dwtag DW_TAG_enumerator, DW_AT_name("CBUF_ERROR_MAX_VALUE"), DW_AT_const_value(0xffff) .dwattr $C$DW$515, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$515, DW_AT_decl_line(0xe5) .dwattr $C$DW$515, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1922 .dwattr $C$DW$T$1922, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$T$1922, DW_AT_decl_line(0x59) .dwattr $C$DW$T$1922, DW_AT_decl_column(0x01) $C$DW$T$1923 .dwtag DW_TAG_typedef, DW_AT_name("CbufErrorSourceType") .dwattr $C$DW$T$1923, DW_AT_type(*$C$DW$T$1922) .dwattr $C$DW$T$1923, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1923, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/CBufferMgr.h") .dwattr $C$DW$T$1923, DW_AT_decl_line(0xe6) .dwattr $C$DW$T$1923, DW_AT_decl_column(0x03) $C$DW$T$118 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$118, DW_AT_name("CbufStorageClassType") .dwattr $C$DW$T$118, DW_AT_byte_size(0x04) $C$DW$516 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFF_STORAGE_CLASS_NOT_FREEABLE"), DW_AT_const_value(0x00) .dwattr $C$DW$516, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$516, DW_AT_decl_line(0x1f) .dwattr $C$DW$516, DW_AT_decl_column(0x05) $C$DW$517 .dwtag DW_TAG_enumerator, DW_AT_name("CBUFF_STORAGE_CLASS_FREEABLE"), DW_AT_const_value(0x01) .dwattr $C$DW$517, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$517, DW_AT_decl_line(0x23) .dwattr $C$DW$517, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$118 .dwattr $C$DW$T$118, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$T$118, DW_AT_decl_line(0x1b) .dwattr $C$DW$T$118, DW_AT_decl_column(0x01) $C$DW$T$119 .dwtag DW_TAG_typedef, DW_AT_name("CbufStorageClassType") .dwattr $C$DW$T$119, DW_AT_type(*$C$DW$T$118) .dwattr $C$DW$T$119, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$119, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/CBufMgr/include/CBufferDataStructure.h") .dwattr $C$DW$T$119, DW_AT_decl_line(0x24) .dwattr $C$DW$T$119, DW_AT_decl_column(0x04) $C$DW$T$994 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$994, DW_AT_name("CineIqInfo") .dwattr $C$DW$T$994, DW_AT_byte_size(0x20) $C$DW$518 .dwtag DW_TAG_member .dwattr $C$DW$518, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$518, DW_AT_name("lineSize") .dwattr $C$DW$518, DW_AT_TI_symbol_name("lineSize") .dwattr $C$DW$518, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$518, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$518, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$518, DW_AT_decl_line(0xbf) .dwattr $C$DW$518, DW_AT_decl_column(0x09) $C$DW$519 .dwtag DW_TAG_member .dwattr $C$DW$519, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$519, DW_AT_name("sampleSize") .dwattr $C$DW$519, DW_AT_TI_symbol_name("sampleSize") .dwattr $C$DW$519, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$519, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$519, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$519, DW_AT_decl_line(0xc0) .dwattr $C$DW$519, DW_AT_decl_column(0x09) $C$DW$520 .dwtag DW_TAG_member .dwattr $C$DW$520, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$520, DW_AT_name("lineStart") .dwattr $C$DW$520, DW_AT_TI_symbol_name("lineStart") .dwattr $C$DW$520, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$520, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$520, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$520, DW_AT_decl_line(0xc2) .dwattr $C$DW$520, DW_AT_decl_column(0x09) $C$DW$521 .dwtag DW_TAG_member .dwattr $C$DW$521, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$521, DW_AT_name("sampleStart") .dwattr $C$DW$521, DW_AT_TI_symbol_name("sampleStart") .dwattr $C$DW$521, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$521, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$521, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$521, DW_AT_decl_line(0xc3) .dwattr $C$DW$521, DW_AT_decl_column(0x09) $C$DW$522 .dwtag DW_TAG_member .dwattr $C$DW$522, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$522, DW_AT_name("lineScale") .dwattr $C$DW$522, DW_AT_TI_symbol_name("lineScale") .dwattr $C$DW$522, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$522, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$522, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$522, DW_AT_decl_line(0xc5) .dwattr $C$DW$522, DW_AT_decl_column(0x0b) $C$DW$523 .dwtag DW_TAG_member .dwattr $C$DW$523, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$523, DW_AT_name("sampleScale") .dwattr $C$DW$523, DW_AT_TI_symbol_name("sampleScale") .dwattr $C$DW$523, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$523, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$523, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$523, DW_AT_decl_line(0xc6) .dwattr $C$DW$523, DW_AT_decl_column(0x0b) $C$DW$524 .dwtag DW_TAG_member .dwattr $C$DW$524, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$524, DW_AT_name("samplePerMm") .dwattr $C$DW$524, DW_AT_TI_symbol_name("samplePerMm") .dwattr $C$DW$524, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$524, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$524, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$524, DW_AT_decl_line(0xc8) .dwattr $C$DW$524, DW_AT_decl_column(0x0b) $C$DW$525 .dwtag DW_TAG_member .dwattr $C$DW$525, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$525, DW_AT_name("adClock") .dwattr $C$DW$525, DW_AT_TI_symbol_name("adClock") .dwattr $C$DW$525, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c] .dwattr $C$DW$525, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$525, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$525, DW_AT_decl_line(0xc9) .dwattr $C$DW$525, DW_AT_decl_column(0x0b) $C$DW$9 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$9, DW_AT_declaration .dwattr $C$DW$9, DW_AT_TI_symbol_name("_ZN10CineIqInfoaSERKS_") .dwattr $C$DW$9, DW_AT_type(*$C$DW$T$990) .dwattr $C$DW$9, DW_AT_accessibility(DW_ACCESS_public) $C$DW$526 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$526, DW_AT_type(*$C$DW$T$992) .dwendtag $C$DW$9 .dwendtag $C$DW$T$994 .dwattr $C$DW$T$994, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$994, DW_AT_decl_line(0xbd) .dwattr $C$DW$T$994, DW_AT_decl_column(0x08) $C$DW$T$991 .dwtag DW_TAG_const_type .dwattr $C$DW$T$991, DW_AT_type(*$C$DW$T$994) $C$DW$T$992 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$992, DW_AT_type(*$C$DW$T$991) .dwattr $C$DW$T$992, DW_AT_address_class(0x20) $C$DW$T$990 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$990, DW_AT_type(*$C$DW$T$994) .dwattr $C$DW$T$990, DW_AT_address_class(0x20) $C$DW$T$993 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$993, DW_AT_type(*$C$DW$T$990) .dwattr $C$DW$T$993, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$527 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$527, DW_AT_type(*$C$DW$T$992) .dwendtag $C$DW$T$993 $C$DW$T$1018 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1018, DW_AT_name("CinePlayback_Speed") .dwattr $C$DW$T$1018, DW_AT_byte_size(0x04) $C$DW$528 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_FULL"), DW_AT_const_value(0x00) .dwattr $C$DW$528, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$528, DW_AT_decl_line(0x160) .dwattr $C$DW$528, DW_AT_decl_column(0x05) $C$DW$529 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_HALF"), DW_AT_const_value(0x01) .dwattr $C$DW$529, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$529, DW_AT_decl_line(0x161) .dwattr $C$DW$529, DW_AT_decl_column(0x05) $C$DW$530 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_QTR"), DW_AT_const_value(0x02) .dwattr $C$DW$530, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$530, DW_AT_decl_line(0x162) .dwattr $C$DW$530, DW_AT_decl_column(0x05) $C$DW$531 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PLAYBACK_SPEED_EOL"), DW_AT_const_value(0x03) .dwattr $C$DW$531, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$531, DW_AT_decl_line(0x163) .dwattr $C$DW$531, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1018 .dwattr $C$DW$T$1018, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1018, DW_AT_decl_line(0x15f) .dwattr $C$DW$T$1018, DW_AT_decl_column(0x01) $C$DW$T$1019 .dwtag DW_TAG_typedef, DW_AT_name("CinePlayback_Speed") .dwattr $C$DW$T$1019, DW_AT_type(*$C$DW$T$1018) .dwattr $C$DW$T$1019, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1019, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1019, DW_AT_decl_line(0x164) .dwattr $C$DW$T$1019, DW_AT_decl_column(0x03) $C$DW$T$1016 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1016, DW_AT_name("CineProcessType") .dwattr $C$DW$T$1016, DW_AT_byte_size(0x04) $C$DW$532 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_FRAME"), DW_AT_const_value(0x00) .dwattr $C$DW$532, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$532, DW_AT_decl_line(0x168) .dwattr $C$DW$532, DW_AT_decl_column(0x05) $C$DW$533 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_COL"), DW_AT_const_value(0x02) .dwattr $C$DW$533, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$533, DW_AT_decl_line(0x169) .dwattr $C$DW$533, DW_AT_decl_column(0x05) $C$DW$534 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_SIMULT"), DW_AT_const_value(0x03) .dwattr $C$DW$534, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$534, DW_AT_decl_line(0x16a) .dwattr $C$DW$534, DW_AT_decl_column(0x05) $C$DW$535 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESSTYPE_EOL"), DW_AT_const_value(0x04) .dwattr $C$DW$535, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$535, DW_AT_decl_line(0x16b) .dwattr $C$DW$535, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1016 .dwattr $C$DW$T$1016, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1016, DW_AT_decl_line(0x167) .dwattr $C$DW$T$1016, DW_AT_decl_column(0x01) $C$DW$T$1017 .dwtag DW_TAG_typedef, DW_AT_name("CineProcessType") .dwattr $C$DW$T$1017, DW_AT_type(*$C$DW$T$1016) .dwattr $C$DW$T$1017, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1017, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1017, DW_AT_decl_line(0x16c) .dwattr $C$DW$T$1017, DW_AT_decl_column(0x03) $C$DW$T$1000 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1000, DW_AT_name("CineProcess_Commands") .dwattr $C$DW$T$1000, DW_AT_byte_size(0x660) $C$DW$536 .dwtag DW_TAG_member .dwattr $C$DW$536, DW_AT_type(*$C$DW$T$995) .dwattr $C$DW$536, DW_AT_name("cineProcessQueue") .dwattr $C$DW$536, DW_AT_TI_symbol_name("cineProcessQueue") .dwattr $C$DW$536, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$536, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$536, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$536, DW_AT_decl_line(0x543) .dwattr $C$DW$536, DW_AT_decl_column(0x05) $C$DW$537 .dwtag DW_TAG_member .dwattr $C$DW$537, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$537, DW_AT_name("reserved") .dwattr $C$DW$537, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$537, DW_AT_data_member_location[DW_OP_plus_uconst 0x5e0] .dwattr $C$DW$537, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$537, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$537, DW_AT_decl_line(0x544) .dwattr $C$DW$537, DW_AT_decl_column(0x05) $C$DW$10 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$10, DW_AT_declaration .dwattr $C$DW$10, DW_AT_TI_symbol_name("_ZN20CineProcess_CommandsaSERKS_") .dwattr $C$DW$10, DW_AT_type(*$C$DW$T$996) .dwattr $C$DW$10, DW_AT_accessibility(DW_ACCESS_public) $C$DW$538 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$538, DW_AT_type(*$C$DW$T$998) .dwendtag $C$DW$10 .dwendtag $C$DW$T$1000 .dwattr $C$DW$T$1000, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1000, DW_AT_decl_line(0x542) .dwattr $C$DW$T$1000, DW_AT_decl_column(0x01) $C$DW$T$997 .dwtag DW_TAG_const_type .dwattr $C$DW$T$997, DW_AT_type(*$C$DW$T$1000) $C$DW$T$998 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$998, DW_AT_type(*$C$DW$T$997) .dwattr $C$DW$T$998, DW_AT_address_class(0x20) $C$DW$T$1367 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Commands") .dwattr $C$DW$T$1367, DW_AT_type(*$C$DW$T$1000) .dwattr $C$DW$T$1367, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1367, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1367, DW_AT_decl_line(0x545) .dwattr $C$DW$T$1367, DW_AT_decl_column(0x03) $C$DW$T$996 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$996, DW_AT_type(*$C$DW$T$1000) .dwattr $C$DW$T$996, DW_AT_address_class(0x20) $C$DW$T$999 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$999, DW_AT_type(*$C$DW$T$996) .dwattr $C$DW$T$999, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$539 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$539, DW_AT_type(*$C$DW$T$998) .dwendtag $C$DW$T$999 $C$DW$T$1008 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1008, DW_AT_name("CineProcess_Entry") .dwattr $C$DW$T$1008, DW_AT_byte_size(0xa8) $C$DW$540 .dwtag DW_TAG_member .dwattr $C$DW$540, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$540, DW_AT_name("frameColIdx") .dwattr $C$DW$540, DW_AT_TI_symbol_name("frameColIdx") .dwattr $C$DW$540, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$540, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$540, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$540, DW_AT_decl_line(0x52f) .dwattr $C$DW$540, DW_AT_decl_column(0x05) $C$DW$541 .dwtag DW_TAG_member .dwattr $C$DW$541, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$541, DW_AT_name("simultCursor") .dwattr $C$DW$541, DW_AT_TI_symbol_name("simultCursor") .dwattr $C$DW$541, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$541, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$541, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$541, DW_AT_decl_line(0x530) .dwattr $C$DW$541, DW_AT_decl_column(0x05) $C$DW$542 .dwtag DW_TAG_member .dwattr $C$DW$542, DW_AT_type(*$C$DW$T$1002) .dwattr $C$DW$542, DW_AT_name("status") .dwattr $C$DW$542, DW_AT_TI_symbol_name("status") .dwattr $C$DW$542, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$542, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$542, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$542, DW_AT_decl_line(0x531) .dwattr $C$DW$542, DW_AT_decl_column(0x05) $C$DW$543 .dwtag DW_TAG_member .dwattr $C$DW$543, DW_AT_type(*$C$DW$T$1003) .dwattr $C$DW$543, DW_AT_name("modeIssued") .dwattr $C$DW$543, DW_AT_TI_symbol_name("modeIssued") .dwattr $C$DW$543, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$543, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$543, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$543, DW_AT_decl_line(0x532) .dwattr $C$DW$543, DW_AT_decl_column(0x05) $C$DW$544 .dwtag DW_TAG_member .dwattr $C$DW$544, DW_AT_type(*$C$DW$T$1003) .dwattr $C$DW$544, DW_AT_name("modeCompleted") .dwattr $C$DW$544, DW_AT_TI_symbol_name("modeCompleted") .dwattr $C$DW$544, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$544, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$544, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$544, DW_AT_decl_line(0x533) .dwattr $C$DW$544, DW_AT_decl_column(0x05) $C$DW$545 .dwtag DW_TAG_member .dwattr $C$DW$545, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$545, DW_AT_name("reserved") .dwattr $C$DW$545, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$545, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$545, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$545, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$545, DW_AT_decl_line(0x534) .dwattr $C$DW$545, DW_AT_decl_column(0x05) $C$DW$11 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$11, DW_AT_declaration .dwattr $C$DW$11, DW_AT_TI_symbol_name("_ZN17CineProcess_EntryaSERKS_") .dwattr $C$DW$11, DW_AT_type(*$C$DW$T$1004) .dwattr $C$DW$11, DW_AT_accessibility(DW_ACCESS_public) $C$DW$546 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$546, DW_AT_type(*$C$DW$T$1006) .dwendtag $C$DW$11 .dwendtag $C$DW$T$1008 .dwattr $C$DW$T$1008, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1008, DW_AT_decl_line(0x52d) .dwattr $C$DW$T$1008, DW_AT_decl_column(0x01) $C$DW$T$1005 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1005, DW_AT_type(*$C$DW$T$1008) $C$DW$T$1006 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1006, DW_AT_type(*$C$DW$T$1005) .dwattr $C$DW$T$1006, DW_AT_address_class(0x20) $C$DW$T$1009 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Entry") .dwattr $C$DW$T$1009, DW_AT_type(*$C$DW$T$1008) .dwattr $C$DW$T$1009, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1009, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1009, DW_AT_decl_line(0x535) .dwattr $C$DW$T$1009, DW_AT_decl_column(0x03) $C$DW$T$1010 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1010, DW_AT_type(*$C$DW$T$1009) .dwattr $C$DW$T$1010, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1010, DW_AT_byte_size(0x540) $C$DW$547 .dwtag DW_TAG_subrange_type .dwattr $C$DW$547, DW_AT_upper_bound(0x07) .dwendtag $C$DW$T$1010 $C$DW$T$1004 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1004, DW_AT_type(*$C$DW$T$1008) .dwattr $C$DW$T$1004, DW_AT_address_class(0x20) $C$DW$T$1007 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1007, DW_AT_type(*$C$DW$T$1004) .dwattr $C$DW$T$1007, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$548 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$548, DW_AT_type(*$C$DW$T$1006) .dwendtag $C$DW$T$1007 $C$DW$T$1015 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1015, DW_AT_name("CineProcess_Queue") .dwattr $C$DW$T$1015, DW_AT_byte_size(0x5e0) $C$DW$549 .dwtag DW_TAG_member .dwattr $C$DW$549, DW_AT_type(*$C$DW$T$1010) .dwattr $C$DW$549, DW_AT_name("entry") .dwattr $C$DW$549, DW_AT_TI_symbol_name("entry") .dwattr $C$DW$549, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$549, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$549, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$549, DW_AT_decl_line(0x539) .dwattr $C$DW$549, DW_AT_decl_column(0x05) $C$DW$550 .dwtag DW_TAG_member .dwattr $C$DW$550, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$550, DW_AT_name("curIdx") .dwattr $C$DW$550, DW_AT_TI_symbol_name("curIdx") .dwattr $C$DW$550, DW_AT_data_member_location[DW_OP_plus_uconst 0x540] .dwattr $C$DW$550, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$550, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$550, DW_AT_decl_line(0x53a) .dwattr $C$DW$550, DW_AT_decl_column(0x05) $C$DW$551 .dwtag DW_TAG_member .dwattr $C$DW$551, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$551, DW_AT_name("writeIdx") .dwattr $C$DW$551, DW_AT_TI_symbol_name("writeIdx") .dwattr $C$DW$551, DW_AT_data_member_location[DW_OP_plus_uconst 0x548] .dwattr $C$DW$551, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$551, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$551, DW_AT_decl_line(0x53b) .dwattr $C$DW$551, DW_AT_decl_column(0x05) $C$DW$552 .dwtag DW_TAG_member .dwattr $C$DW$552, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$552, DW_AT_name("readIdx") .dwattr $C$DW$552, DW_AT_TI_symbol_name("readIdx") .dwattr $C$DW$552, DW_AT_data_member_location[DW_OP_plus_uconst 0x550] .dwattr $C$DW$552, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$552, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$552, DW_AT_decl_line(0x53c) .dwattr $C$DW$552, DW_AT_decl_column(0x05) $C$DW$553 .dwtag DW_TAG_member .dwattr $C$DW$553, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$553, DW_AT_name("count") .dwattr $C$DW$553, DW_AT_TI_symbol_name("count") .dwattr $C$DW$553, DW_AT_data_member_location[DW_OP_plus_uconst 0x558] .dwattr $C$DW$553, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$553, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$553, DW_AT_decl_line(0x53d) .dwattr $C$DW$553, DW_AT_decl_column(0x05) $C$DW$554 .dwtag DW_TAG_member .dwattr $C$DW$554, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$554, DW_AT_name("reserved") .dwattr $C$DW$554, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$554, DW_AT_data_member_location[DW_OP_plus_uconst 0x560] .dwattr $C$DW$554, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$554, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$554, DW_AT_decl_line(0x53e) .dwattr $C$DW$554, DW_AT_decl_column(0x05) $C$DW$12 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$12, DW_AT_declaration .dwattr $C$DW$12, DW_AT_TI_symbol_name("_ZN17CineProcess_QueueaSERKS_") .dwattr $C$DW$12, DW_AT_type(*$C$DW$T$1011) .dwattr $C$DW$12, DW_AT_accessibility(DW_ACCESS_public) $C$DW$555 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$555, DW_AT_type(*$C$DW$T$1013) .dwendtag $C$DW$12 .dwendtag $C$DW$T$1015 .dwattr $C$DW$T$1015, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1015, DW_AT_decl_line(0x538) .dwattr $C$DW$T$1015, DW_AT_decl_column(0x01) $C$DW$T$995 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Queue") .dwattr $C$DW$T$995, DW_AT_type(*$C$DW$T$1015) .dwattr $C$DW$T$995, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$995, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$995, DW_AT_decl_line(0x53f) .dwattr $C$DW$T$995, DW_AT_decl_column(0x03) $C$DW$T$1012 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1012, DW_AT_type(*$C$DW$T$1015) $C$DW$T$1013 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1013, DW_AT_type(*$C$DW$T$1012) .dwattr $C$DW$T$1013, DW_AT_address_class(0x20) $C$DW$T$1011 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1011, DW_AT_type(*$C$DW$T$1015) .dwattr $C$DW$T$1011, DW_AT_address_class(0x20) $C$DW$T$1014 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1014, DW_AT_type(*$C$DW$T$1011) .dwattr $C$DW$T$1014, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$556 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$556, DW_AT_type(*$C$DW$T$1013) .dwendtag $C$DW$T$1014 $C$DW$T$1001 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1001, DW_AT_name("CineProcess_Status") .dwattr $C$DW$T$1001, DW_AT_byte_size(0x04) $C$DW$557 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_INVALID"), DW_AT_const_value(0x00) .dwattr $C$DW$557, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$557, DW_AT_decl_line(0x157) .dwattr $C$DW$557, DW_AT_decl_column(0x05) $C$DW$558 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_REQUESTED"), DW_AT_const_value(0x01) .dwattr $C$DW$558, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$558, DW_AT_decl_line(0x158) .dwattr $C$DW$558, DW_AT_decl_column(0x05) $C$DW$559 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_IN_PROGRESS"), DW_AT_const_value(0x02) .dwattr $C$DW$559, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$559, DW_AT_decl_line(0x159) .dwattr $C$DW$559, DW_AT_decl_column(0x05) $C$DW$560 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_COMPLETE"), DW_AT_const_value(0x03) .dwattr $C$DW$560, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$560, DW_AT_decl_line(0x15a) .dwattr $C$DW$560, DW_AT_decl_column(0x05) $C$DW$561 .dwtag DW_TAG_enumerator, DW_AT_name("CINE_PROCESS_EOL"), DW_AT_const_value(0x04) .dwattr $C$DW$561, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$561, DW_AT_decl_line(0x15b) .dwattr $C$DW$561, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1001 .dwattr $C$DW$T$1001, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1001, DW_AT_decl_line(0x156) .dwattr $C$DW$T$1001, DW_AT_decl_column(0x01) $C$DW$T$1002 .dwtag DW_TAG_typedef, DW_AT_name("CineProcess_Status") .dwattr $C$DW$T$1002, DW_AT_type(*$C$DW$T$1001) .dwattr $C$DW$T$1002, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1002, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1002, DW_AT_decl_line(0x15c) .dwattr $C$DW$T$1002, DW_AT_decl_column(0x03) $C$DW$T$1024 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1024, DW_AT_name("Cine_Param") .dwattr $C$DW$T$1024, DW_AT_byte_size(0xe8) $C$DW$562 .dwtag DW_TAG_member .dwattr $C$DW$562, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$562, DW_AT_name("numCineFrame") .dwattr $C$DW$562, DW_AT_TI_symbol_name("numCineFrame") .dwattr $C$DW$562, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$562, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$562, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$562, DW_AT_decl_line(0x516) .dwattr $C$DW$562, DW_AT_decl_column(0x05) $C$DW$563 .dwtag DW_TAG_member .dwattr $C$DW$563, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$563, DW_AT_name("currentCineFrame") .dwattr $C$DW$563, DW_AT_TI_symbol_name("currentCineFrame") .dwattr $C$DW$563, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$563, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$563, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$563, DW_AT_decl_line(0x517) .dwattr $C$DW$563, DW_AT_decl_column(0x05) $C$DW$564 .dwtag DW_TAG_member .dwattr $C$DW$564, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$564, DW_AT_name("startCineFrame") .dwattr $C$DW$564, DW_AT_TI_symbol_name("startCineFrame") .dwattr $C$DW$564, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$564, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$564, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$564, DW_AT_decl_line(0x518) .dwattr $C$DW$564, DW_AT_decl_column(0x05) $C$DW$565 .dwtag DW_TAG_member .dwattr $C$DW$565, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$565, DW_AT_name("stopCineFrame") .dwattr $C$DW$565, DW_AT_TI_symbol_name("stopCineFrame") .dwattr $C$DW$565, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$565, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$565, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$565, DW_AT_decl_line(0x519) .dwattr $C$DW$565, DW_AT_decl_column(0x05) $C$DW$566 .dwtag DW_TAG_member .dwattr $C$DW$566, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$566, DW_AT_name("currentCineCol") .dwattr $C$DW$566, DW_AT_TI_symbol_name("currentCineCol") .dwattr $C$DW$566, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$566, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$566, DW_AT_decl_line(0x51a) .dwattr $C$DW$566, DW_AT_decl_column(0x05) $C$DW$567 .dwtag DW_TAG_member .dwattr $C$DW$567, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$567, DW_AT_name("isCineReady") .dwattr $C$DW$567, DW_AT_TI_symbol_name("isCineReady") .dwattr $C$DW$567, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$567, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$567, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$567, DW_AT_decl_line(0x51c) .dwattr $C$DW$567, DW_AT_decl_column(0x05) $C$DW$568 .dwtag DW_TAG_member .dwattr $C$DW$568, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$568, DW_AT_name("firstCineColumn") .dwattr $C$DW$568, DW_AT_TI_symbol_name("firstCineColumn") .dwattr $C$DW$568, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$568, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$568, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$568, DW_AT_decl_line(0x51f) .dwattr $C$DW$568, DW_AT_decl_column(0x05) $C$DW$569 .dwtag DW_TAG_member .dwattr $C$DW$569, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$569, DW_AT_name("lastCineColumn") .dwattr $C$DW$569, DW_AT_TI_symbol_name("lastCineColumn") .dwattr $C$DW$569, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$569, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$569, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$569, DW_AT_decl_line(0x520) .dwattr $C$DW$569, DW_AT_decl_column(0x05) $C$DW$570 .dwtag DW_TAG_member .dwattr $C$DW$570, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$570, DW_AT_name("last2DFrameColumnOffset") .dwattr $C$DW$570, DW_AT_TI_symbol_name("last2DFrameColumnOffset") .dwattr $C$DW$570, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$570, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$570, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$570, DW_AT_decl_line(0x521) .dwattr $C$DW$570, DW_AT_decl_column(0x05) $C$DW$571 .dwtag DW_TAG_member .dwattr $C$DW$571, DW_AT_type(*$C$DW$T$1017) .dwattr $C$DW$571, DW_AT_name("cineProcessType") .dwattr $C$DW$571, DW_AT_TI_symbol_name("cineProcessType") .dwattr $C$DW$571, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$571, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$571, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$571, DW_AT_decl_line(0x524) .dwattr $C$DW$571, DW_AT_decl_column(0x05) $C$DW$572 .dwtag DW_TAG_member .dwattr $C$DW$572, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$572, DW_AT_name("layoutChgLeftMostCol") .dwattr $C$DW$572, DW_AT_TI_symbol_name("layoutChgLeftMostCol") .dwattr $C$DW$572, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$572, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$572, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$572, DW_AT_decl_line(0x525) .dwattr $C$DW$572, DW_AT_decl_column(0x05) $C$DW$573 .dwtag DW_TAG_member .dwattr $C$DW$573, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$573, DW_AT_name("layoutChgColMarker") .dwattr $C$DW$573, DW_AT_TI_symbol_name("layoutChgColMarker") .dwattr $C$DW$573, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$573, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$573, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$573, DW_AT_decl_line(0x526) .dwattr $C$DW$573, DW_AT_decl_column(0x05) $C$DW$574 .dwtag DW_TAG_member .dwattr $C$DW$574, DW_AT_type(*$C$DW$T$1019) .dwattr $C$DW$574, DW_AT_name("playbackSpeed") .dwattr $C$DW$574, DW_AT_TI_symbol_name("playbackSpeed") .dwattr $C$DW$574, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$574, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$574, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$574, DW_AT_decl_line(0x527) .dwattr $C$DW$574, DW_AT_decl_column(0x05) $C$DW$575 .dwtag DW_TAG_member .dwattr $C$DW$575, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$575, DW_AT_name("reserved") .dwattr $C$DW$575, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$575, DW_AT_data_member_location[DW_OP_plus_uconst 0x68] .dwattr $C$DW$575, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$575, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$575, DW_AT_decl_line(0x529) .dwattr $C$DW$575, DW_AT_decl_column(0x05) $C$DW$13 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$13, DW_AT_declaration .dwattr $C$DW$13, DW_AT_TI_symbol_name("_ZN10Cine_ParamaSERKS_") .dwattr $C$DW$13, DW_AT_type(*$C$DW$T$1020) .dwattr $C$DW$13, DW_AT_accessibility(DW_ACCESS_public) $C$DW$576 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$576, DW_AT_type(*$C$DW$T$1022) .dwendtag $C$DW$13 .dwendtag $C$DW$T$1024 .dwattr $C$DW$T$1024, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1024, DW_AT_decl_line(0x514) .dwattr $C$DW$T$1024, DW_AT_decl_column(0x01) $C$DW$T$1021 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1021, DW_AT_type(*$C$DW$T$1024) $C$DW$T$1022 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1022, DW_AT_type(*$C$DW$T$1021) .dwattr $C$DW$T$1022, DW_AT_address_class(0x20) $C$DW$T$2191 .dwtag DW_TAG_typedef, DW_AT_name("Cine_Param") .dwattr $C$DW$T$2191, DW_AT_type(*$C$DW$T$1024) .dwattr $C$DW$T$2191, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2191, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$2191, DW_AT_decl_line(0x52a) .dwattr $C$DW$T$2191, DW_AT_decl_column(0x03) $C$DW$T$1020 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1020, DW_AT_type(*$C$DW$T$1024) .dwattr $C$DW$T$1020, DW_AT_address_class(0x20) $C$DW$T$1023 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1023, DW_AT_type(*$C$DW$T$1020) .dwattr $C$DW$T$1023, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$577 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$577, DW_AT_type(*$C$DW$T$1022) .dwendtag $C$DW$T$1023 $C$DW$T$1179 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1179, DW_AT_name("ColorFlow_MP_FIR_Coeff") .dwattr $C$DW$T$1179, DW_AT_byte_size(0xd0) $C$DW$578 .dwtag DW_TAG_member .dwattr $C$DW$578, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$578, DW_AT_name("useMP_FIR_Coefficients") .dwattr $C$DW$578, DW_AT_TI_symbol_name("useMP_FIR_Coefficients") .dwattr $C$DW$578, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$578, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$578, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$578, DW_AT_decl_line(0x41f) .dwattr $C$DW$578, DW_AT_decl_column(0x05) $C$DW$579 .dwtag DW_TAG_member .dwattr $C$DW$579, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$579, DW_AT_name("length") .dwattr $C$DW$579, DW_AT_TI_symbol_name("length") .dwattr $C$DW$579, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$579, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$579, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$579, DW_AT_decl_line(0x420) .dwattr $C$DW$579, DW_AT_decl_column(0x05) $C$DW$580 .dwtag DW_TAG_member .dwattr $C$DW$580, DW_AT_type(*$C$DW$T$1174) .dwattr $C$DW$580, DW_AT_name("coeffs") .dwattr $C$DW$580, DW_AT_TI_symbol_name("coeffs") .dwattr $C$DW$580, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$580, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$580, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$580, DW_AT_decl_line(0x421) .dwattr $C$DW$580, DW_AT_decl_column(0x05) $C$DW$581 .dwtag DW_TAG_member .dwattr $C$DW$581, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$581, DW_AT_name("reserved") .dwattr $C$DW$581, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$581, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$581, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$581, DW_AT_decl_line(0x422) .dwattr $C$DW$581, DW_AT_decl_column(0x05) $C$DW$14 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$14, DW_AT_declaration .dwattr $C$DW$14, DW_AT_TI_symbol_name("_ZN22ColorFlow_MP_FIR_CoeffaSERKS_") .dwattr $C$DW$14, DW_AT_type(*$C$DW$T$1175) .dwattr $C$DW$14, DW_AT_accessibility(DW_ACCESS_public) $C$DW$582 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$582, DW_AT_type(*$C$DW$T$1177) .dwendtag $C$DW$14 .dwendtag $C$DW$T$1179 .dwattr $C$DW$T$1179, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1179, DW_AT_decl_line(0x41e) .dwattr $C$DW$T$1179, DW_AT_decl_column(0x01) $C$DW$T$1176 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1176, DW_AT_type(*$C$DW$T$1179) $C$DW$T$1177 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1177, DW_AT_type(*$C$DW$T$1176) .dwattr $C$DW$T$1177, DW_AT_address_class(0x20) $C$DW$T$1184 .dwtag DW_TAG_typedef, DW_AT_name("ColorFlow_MP_FIR_Coeff") .dwattr $C$DW$T$1184, DW_AT_type(*$C$DW$T$1179) .dwattr $C$DW$T$1184, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1184, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1184, DW_AT_decl_line(0x423) .dwattr $C$DW$T$1184, DW_AT_decl_column(0x03) $C$DW$T$1175 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1175, DW_AT_type(*$C$DW$T$1179) .dwattr $C$DW$T$1175, DW_AT_address_class(0x20) $C$DW$T$1178 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1178, DW_AT_type(*$C$DW$T$1175) .dwattr $C$DW$T$1178, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$583 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$583, DW_AT_type(*$C$DW$T$1177) .dwendtag $C$DW$T$1178 $C$DW$T$1185 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1185, DW_AT_name("ColorFlow_MP_FIR_Source") .dwattr $C$DW$T$1185, DW_AT_byte_size(0x04) $C$DW$584 .dwtag DW_TAG_enumerator, DW_AT_name("COLORFLOW_MP_FIR_SOURCE_CTURN"), DW_AT_const_value(0x00) .dwattr $C$DW$584, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$584, DW_AT_decl_line(0x109) .dwattr $C$DW$584, DW_AT_decl_column(0x05) $C$DW$585 .dwtag DW_TAG_enumerator, DW_AT_name("COLORFLOW_MP_FIR_SOURCE_WF"), DW_AT_const_value(0x01) .dwattr $C$DW$585, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$585, DW_AT_decl_line(0x10a) .dwattr $C$DW$585, DW_AT_decl_column(0x05) $C$DW$586 .dwtag DW_TAG_enumerator, DW_AT_name("COLORFLOW_MP_FIR_SOURCE_WF_TIS"), DW_AT_const_value(0x02) .dwattr $C$DW$586, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$586, DW_AT_decl_line(0x10b) .dwattr $C$DW$586, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1185 .dwattr $C$DW$T$1185, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1185, DW_AT_decl_line(0x108) .dwattr $C$DW$T$1185, DW_AT_decl_column(0x0e) $C$DW$T$1186 .dwtag DW_TAG_typedef, DW_AT_name("ColorFlow_MP_FIR_Source") .dwattr $C$DW$T$1186, DW_AT_type(*$C$DW$T$1185) .dwattr $C$DW$T$1186, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1186, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1186, DW_AT_decl_line(0x10c) .dwattr $C$DW$T$1186, DW_AT_decl_column(0x03) $C$DW$T$1191 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1191, DW_AT_name("ColorFlow_Param") .dwattr $C$DW$T$1191, DW_AT_byte_size(0x338) $C$DW$587 .dwtag DW_TAG_member .dwattr $C$DW$587, DW_AT_type(*$C$DW$T$1181) .dwattr $C$DW$587, DW_AT_name("subMode") .dwattr $C$DW$587, DW_AT_TI_symbol_name("subMode") .dwattr $C$DW$587, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$587, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$587, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$587, DW_AT_decl_line(0x427) .dwattr $C$DW$587, DW_AT_decl_column(0x05) $C$DW$588 .dwtag DW_TAG_member .dwattr $C$DW$588, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$588, DW_AT_name("varianceFlag") .dwattr $C$DW$588, DW_AT_TI_symbol_name("varianceFlag") .dwattr $C$DW$588, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$588, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$588, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$588, DW_AT_decl_line(0x429) .dwattr $C$DW$588, DW_AT_decl_column(0x05) $C$DW$589 .dwtag DW_TAG_member .dwattr $C$DW$589, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$589, DW_AT_name("persistence") .dwattr $C$DW$589, DW_AT_TI_symbol_name("persistence") .dwattr $C$DW$589, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$589, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$589, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$589, DW_AT_decl_line(0x42a) .dwattr $C$DW$589, DW_AT_decl_column(0x05) $C$DW$590 .dwtag DW_TAG_member .dwattr $C$DW$590, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$590, DW_AT_name("logPwrThreshLower") .dwattr $C$DW$590, DW_AT_TI_symbol_name("logPwrThreshLower") .dwattr $C$DW$590, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$590, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$590, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$590, DW_AT_decl_line(0x42b) .dwattr $C$DW$590, DW_AT_decl_column(0x05) $C$DW$591 .dwtag DW_TAG_member .dwattr $C$DW$591, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$591, DW_AT_name("invLogPwrTaperRngM") .dwattr $C$DW$591, DW_AT_TI_symbol_name("invLogPwrTaperRngM") .dwattr $C$DW$591, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$591, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$591, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$591, DW_AT_decl_line(0x42c) .dwattr $C$DW$591, DW_AT_decl_column(0x05) $C$DW$592 .dwtag DW_TAG_member .dwattr $C$DW$592, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$592, DW_AT_name("invLogPwrTaperRngE") .dwattr $C$DW$592, DW_AT_TI_symbol_name("invLogPwrTaperRngE") .dwattr $C$DW$592, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$592, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$592, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$592, DW_AT_decl_line(0x42d) .dwattr $C$DW$592, DW_AT_decl_column(0x05) $C$DW$593 .dwtag DW_TAG_member .dwattr $C$DW$593, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$593, DW_AT_name("logRatioThreshLower") .dwattr $C$DW$593, DW_AT_TI_symbol_name("logRatioThreshLower") .dwattr $C$DW$593, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$593, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$593, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$593, DW_AT_decl_line(0x42e) .dwattr $C$DW$593, DW_AT_decl_column(0x05) $C$DW$594 .dwtag DW_TAG_member .dwattr $C$DW$594, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$594, DW_AT_name("invLogRatioTaperRngM") .dwattr $C$DW$594, DW_AT_TI_symbol_name("invLogRatioTaperRngM") .dwattr $C$DW$594, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$594, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$594, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$594, DW_AT_decl_line(0x42f) .dwattr $C$DW$594, DW_AT_decl_column(0x05) $C$DW$595 .dwtag DW_TAG_member .dwattr $C$DW$595, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$595, DW_AT_name("invLogRatioTaperRngE") .dwattr $C$DW$595, DW_AT_TI_symbol_name("invLogRatioTaperRngE") .dwattr $C$DW$595, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$595, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$595, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$595, DW_AT_decl_line(0x430) .dwattr $C$DW$595, DW_AT_decl_column(0x05) $C$DW$596 .dwtag DW_TAG_member .dwattr $C$DW$596, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$596, DW_AT_name("numPingPackets") .dwattr $C$DW$596, DW_AT_TI_symbol_name("numPingPackets") .dwattr $C$DW$596, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$596, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$596, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$596, DW_AT_decl_line(0x432) .dwattr $C$DW$596, DW_AT_decl_column(0x05) $C$DW$597 .dwtag DW_TAG_member .dwattr $C$DW$597, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$597, DW_AT_name("nEstimates") .dwattr $C$DW$597, DW_AT_TI_symbol_name("nEstimates") .dwattr $C$DW$597, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$597, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$597, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$597, DW_AT_decl_line(0x434) .dwattr $C$DW$597, DW_AT_decl_column(0x05) $C$DW$598 .dwtag DW_TAG_member .dwattr $C$DW$598, DW_AT_type(*$C$DW$T$1182) .dwattr $C$DW$598, DW_AT_name("multiline") .dwattr $C$DW$598, DW_AT_TI_symbol_name("multiline") .dwattr $C$DW$598, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$598, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$598, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$598, DW_AT_decl_line(0x437) .dwattr $C$DW$598, DW_AT_decl_column(0x05) $C$DW$599 .dwtag DW_TAG_member .dwattr $C$DW$599, DW_AT_type(*$C$DW$T$1183) .dwattr $C$DW$599, DW_AT_name("colorKernel") .dwattr $C$DW$599, DW_AT_TI_symbol_name("colorKernel") .dwattr $C$DW$599, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8] .dwattr $C$DW$599, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$599, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$599, DW_AT_decl_line(0x439) .dwattr $C$DW$599, DW_AT_decl_column(0x05) $C$DW$600 .dwtag DW_TAG_member .dwattr $C$DW$600, DW_AT_type(*$C$DW$T$1184) .dwattr $C$DW$600, DW_AT_name("MP_Fir") .dwattr $C$DW$600, DW_AT_TI_symbol_name("MP_Fir") .dwattr $C$DW$600, DW_AT_data_member_location[DW_OP_plus_uconst 0x1b8] .dwattr $C$DW$600, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$600, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$600, DW_AT_decl_line(0x43d) .dwattr $C$DW$600, DW_AT_decl_column(0x05) $C$DW$601 .dwtag DW_TAG_member .dwattr $C$DW$601, DW_AT_type(*$C$DW$T$1186) .dwattr $C$DW$601, DW_AT_name("mpFirSource") .dwattr $C$DW$601, DW_AT_TI_symbol_name("mpFirSource") .dwattr $C$DW$601, DW_AT_data_member_location[DW_OP_plus_uconst 0x288] .dwattr $C$DW$601, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$601, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$601, DW_AT_decl_line(0x43e) .dwattr $C$DW$601, DW_AT_decl_column(0x05) $C$DW$602 .dwtag DW_TAG_member .dwattr $C$DW$602, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$602, DW_AT_name("logFlashSupThreshLower") .dwattr $C$DW$602, DW_AT_TI_symbol_name("logFlashSupThreshLower") .dwattr $C$DW$602, DW_AT_data_member_location[DW_OP_plus_uconst 0x290] .dwattr $C$DW$602, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$602, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$602, DW_AT_decl_line(0x442) .dwattr $C$DW$602, DW_AT_decl_column(0x05) $C$DW$603 .dwtag DW_TAG_member .dwattr $C$DW$603, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$603, DW_AT_name("invLogFlashSupTaperRngM") .dwattr $C$DW$603, DW_AT_TI_symbol_name("invLogFlashSupTaperRngM") .dwattr $C$DW$603, DW_AT_data_member_location[DW_OP_plus_uconst 0x298] .dwattr $C$DW$603, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$603, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$603, DW_AT_decl_line(0x443) .dwattr $C$DW$603, DW_AT_decl_column(0x05) $C$DW$604 .dwtag DW_TAG_member .dwattr $C$DW$604, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$604, DW_AT_name("invLogFlashSupTaperRngE") .dwattr $C$DW$604, DW_AT_TI_symbol_name("invLogFlashSupTaperRngE") .dwattr $C$DW$604, DW_AT_data_member_location[DW_OP_plus_uconst 0x2a0] .dwattr $C$DW$604, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$604, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$604, DW_AT_decl_line(0x444) .dwattr $C$DW$604, DW_AT_decl_column(0x05) $C$DW$605 .dwtag DW_TAG_member .dwattr $C$DW$605, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$605, DW_AT_name("scalingFactor") .dwattr $C$DW$605, DW_AT_TI_symbol_name("scalingFactor") .dwattr $C$DW$605, DW_AT_data_member_location[DW_OP_plus_uconst 0x2a8] .dwattr $C$DW$605, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$605, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$605, DW_AT_decl_line(0x44f) .dwattr $C$DW$605, DW_AT_decl_column(0x05) $C$DW$606 .dwtag DW_TAG_member .dwattr $C$DW$606, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$606, DW_AT_name("colorOutLen") .dwattr $C$DW$606, DW_AT_TI_symbol_name("colorOutLen") .dwattr $C$DW$606, DW_AT_data_member_location[DW_OP_plus_uconst 0x2b0] .dwattr $C$DW$606, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$606, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$606, DW_AT_decl_line(0x451) .dwattr $C$DW$606, DW_AT_decl_column(0x05) $C$DW$607 .dwtag DW_TAG_member .dwattr $C$DW$607, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$607, DW_AT_name("reserved") .dwattr $C$DW$607, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$607, DW_AT_data_member_location[DW_OP_plus_uconst 0x2b8] .dwattr $C$DW$607, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$607, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$607, DW_AT_decl_line(0x453) .dwattr $C$DW$607, DW_AT_decl_column(0x05) $C$DW$15 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$15, DW_AT_declaration .dwattr $C$DW$15, DW_AT_TI_symbol_name("_ZN15ColorFlow_ParamaSERKS_") .dwattr $C$DW$15, DW_AT_type(*$C$DW$T$1187) .dwattr $C$DW$15, DW_AT_accessibility(DW_ACCESS_public) $C$DW$608 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$608, DW_AT_type(*$C$DW$T$1189) .dwendtag $C$DW$15 .dwendtag $C$DW$T$1191 .dwattr $C$DW$T$1191, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1191, DW_AT_decl_line(0x426) .dwattr $C$DW$T$1191, DW_AT_decl_column(0x01) $C$DW$T$1188 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1188, DW_AT_type(*$C$DW$T$1191) $C$DW$T$1189 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1189, DW_AT_type(*$C$DW$T$1188) .dwattr $C$DW$T$1189, DW_AT_address_class(0x20) $C$DW$T$2195 .dwtag DW_TAG_typedef, DW_AT_name("ColorFlow_Param") .dwattr $C$DW$T$2195, DW_AT_type(*$C$DW$T$1191) .dwattr $C$DW$T$2195, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2195, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$2195, DW_AT_decl_line(0x454) .dwattr $C$DW$T$2195, DW_AT_decl_column(0x03) $C$DW$T$1187 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1187, DW_AT_type(*$C$DW$T$1191) .dwattr $C$DW$T$1187, DW_AT_address_class(0x20) $C$DW$T$1190 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1190, DW_AT_type(*$C$DW$T$1187) .dwattr $C$DW$T$1190, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$609 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$609, DW_AT_type(*$C$DW$T$1189) .dwendtag $C$DW$T$1190 $C$DW$T$1215 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1215, DW_AT_name("ContextBe") .dwattr $C$DW$T$1215, DW_AT_byte_size(0x3eb570) $C$DW$610 .dwtag DW_TAG_member .dwattr $C$DW$610, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$610, DW_AT_name("sSize") .dwattr $C$DW$610, DW_AT_TI_symbol_name("sSize") .dwattr $C$DW$610, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$610, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$610, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$610, DW_AT_decl_line(0xd3) .dwattr $C$DW$610, DW_AT_decl_column(0x0b) $C$DW$611 .dwtag DW_TAG_member .dwattr $C$DW$611, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$611, DW_AT_name("lSize") .dwattr $C$DW$611, DW_AT_TI_symbol_name("lSize") .dwattr $C$DW$611, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$611, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$611, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$611, DW_AT_decl_line(0xd4) .dwattr $C$DW$611, DW_AT_decl_column(0x0b) $C$DW$612 .dwtag DW_TAG_member .dwattr $C$DW$612, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$612, DW_AT_name("startLine") .dwattr $C$DW$612, DW_AT_TI_symbol_name("startLine") .dwattr $C$DW$612, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$612, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$612, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$612, DW_AT_decl_line(0xd6) .dwattr $C$DW$612, DW_AT_decl_column(0x0b) $C$DW$613 .dwtag DW_TAG_member .dwattr $C$DW$613, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$613, DW_AT_name("startSample") .dwattr $C$DW$613, DW_AT_TI_symbol_name("startSample") .dwattr $C$DW$613, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$613, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$613, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$613, DW_AT_decl_line(0xd7) .dwattr $C$DW$613, DW_AT_decl_column(0x0b) $C$DW$614 .dwtag DW_TAG_member .dwattr $C$DW$614, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$614, DW_AT_name("level") .dwattr $C$DW$614, DW_AT_TI_symbol_name("level") .dwattr $C$DW$614, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$614, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$614, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$614, DW_AT_decl_line(0xd9) .dwattr $C$DW$614, DW_AT_decl_column(0x0b) $C$DW$615 .dwtag DW_TAG_member .dwattr $C$DW$615, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$615, DW_AT_name("samplePerMm") .dwattr $C$DW$615, DW_AT_TI_symbol_name("samplePerMm") .dwattr $C$DW$615, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$615, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$615, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$615, DW_AT_decl_line(0xdb) .dwattr $C$DW$615, DW_AT_decl_column(0x0c) $C$DW$616 .dwtag DW_TAG_member .dwattr $C$DW$616, DW_AT_type(*$C$DW$T$1109) .dwattr $C$DW$616, DW_AT_name("inInfo") .dwattr $C$DW$616, DW_AT_TI_symbol_name("inInfo") .dwattr $C$DW$616, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$616, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$616, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$616, DW_AT_decl_line(0xdd) .dwattr $C$DW$616, DW_AT_decl_column(0x10) $C$DW$617 .dwtag DW_TAG_member .dwattr $C$DW$617, DW_AT_type(*$C$DW$T$1192) .dwattr $C$DW$617, DW_AT_name("inInfoSub") .dwattr $C$DW$617, DW_AT_TI_symbol_name("inInfoSub") .dwattr $C$DW$617, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$617, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$617, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$617, DW_AT_decl_line(0xde) .dwattr $C$DW$617, DW_AT_decl_column(0x10) $C$DW$618 .dwtag DW_TAG_member .dwattr $C$DW$618, DW_AT_type(*$C$DW$T$1193) .dwattr $C$DW$618, DW_AT_name("info") .dwattr $C$DW$618, DW_AT_TI_symbol_name("info") .dwattr $C$DW$618, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$618, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$618, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$618, DW_AT_decl_line(0xdf) .dwattr $C$DW$618, DW_AT_decl_column(0x10) $C$DW$619 .dwtag DW_TAG_member .dwattr $C$DW$619, DW_AT_type(*$C$DW$T$1109) .dwattr $C$DW$619, DW_AT_name("outInfo") .dwattr $C$DW$619, DW_AT_TI_symbol_name("outInfo") .dwattr $C$DW$619, DW_AT_data_member_location[DW_OP_plus_uconst 0xd8] .dwattr $C$DW$619, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$619, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$619, DW_AT_decl_line(0xe0) .dwattr $C$DW$619, DW_AT_decl_column(0x10) $C$DW$620 .dwtag DW_TAG_member .dwattr $C$DW$620, DW_AT_type(*$C$DW$T$1194) .dwattr $C$DW$620, DW_AT_name("infoSub") .dwattr $C$DW$620, DW_AT_TI_symbol_name("infoSub") .dwattr $C$DW$620, DW_AT_data_member_location[DW_OP_plus_uconst 0xf0] .dwattr $C$DW$620, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$620, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$620, DW_AT_decl_line(0xe1) .dwattr $C$DW$620, DW_AT_decl_column(0x10) $C$DW$621 .dwtag DW_TAG_member .dwattr $C$DW$621, DW_AT_type(*$C$DW$T$1195) .dwattr $C$DW$621, DW_AT_name("inLineOffset") .dwattr $C$DW$621, DW_AT_TI_symbol_name("inLineOffset") .dwattr $C$DW$621, DW_AT_data_member_location[DW_OP_plus_uconst 0x1e0] .dwattr $C$DW$621, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$621, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$621, DW_AT_decl_line(0xe3) .dwattr $C$DW$621, DW_AT_decl_column(0x0b) $C$DW$622 .dwtag DW_TAG_member .dwattr $C$DW$622, DW_AT_type(*$C$DW$T$1195) .dwattr $C$DW$622, DW_AT_name("outLineOffset") .dwattr $C$DW$622, DW_AT_TI_symbol_name("outLineOffset") .dwattr $C$DW$622, DW_AT_data_member_location[DW_OP_plus_uconst 0x1e8] .dwattr $C$DW$622, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$622, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$622, DW_AT_decl_line(0xe4) .dwattr $C$DW$622, DW_AT_decl_column(0x0b) $C$DW$623 .dwtag DW_TAG_member .dwattr $C$DW$623, DW_AT_type(*$C$DW$T$994) .dwattr $C$DW$623, DW_AT_name("iqInfo") .dwattr $C$DW$623, DW_AT_TI_symbol_name("iqInfo") .dwattr $C$DW$623, DW_AT_data_member_location[DW_OP_plus_uconst 0x1f0] .dwattr $C$DW$623, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$623, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$623, DW_AT_decl_line(0xe6) .dwattr $C$DW$623, DW_AT_decl_column(0x10) $C$DW$624 .dwtag DW_TAG_member .dwattr $C$DW$624, DW_AT_type(*$C$DW$T$253) .dwattr $C$DW$624, DW_AT_name("imageB") .dwattr $C$DW$624, DW_AT_TI_symbol_name("imageB") .dwattr $C$DW$624, DW_AT_data_member_location[DW_OP_plus_uconst 0x210] .dwattr $C$DW$624, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$624, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$624, DW_AT_decl_line(0xe9) .dwattr $C$DW$624, DW_AT_decl_column(0x22) $C$DW$625 .dwtag DW_TAG_member .dwattr $C$DW$625, DW_AT_type(*$C$DW$T$1549) .dwattr $C$DW$625, DW_AT_name("fill") .dwattr $C$DW$625, DW_AT_TI_symbol_name("fill") .dwattr $C$DW$625, DW_AT_data_member_location[DW_OP_plus_uconst 0x854] .dwattr $C$DW$625, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$625, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$625, DW_AT_decl_line(0xeb) .dwattr $C$DW$625, DW_AT_decl_column(0x0f) $C$DW$626 .dwtag DW_TAG_member .dwattr $C$DW$626, DW_AT_type(*$C$DW$T$1196) .dwattr $C$DW$626, DW_AT_name("emphasis1") .dwattr $C$DW$626, DW_AT_TI_symbol_name("emphasis1") .dwattr $C$DW$626, DW_AT_data_member_location[DW_OP_plus_uconst 0x860] .dwattr $C$DW$626, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$626, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$626, DW_AT_decl_line(0xed) .dwattr $C$DW$626, DW_AT_decl_column(0x0f) $C$DW$627 .dwtag DW_TAG_member .dwattr $C$DW$627, DW_AT_type(*$C$DW$T$1196) .dwattr $C$DW$627, DW_AT_name("emphasis2") .dwattr $C$DW$627, DW_AT_TI_symbol_name("emphasis2") .dwattr $C$DW$627, DW_AT_data_member_location[DW_OP_plus_uconst 0x89c] .dwattr $C$DW$627, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$627, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$627, DW_AT_decl_line(0xee) .dwattr $C$DW$627, DW_AT_decl_column(0x0f) $C$DW$628 .dwtag DW_TAG_member .dwattr $C$DW$628, DW_AT_type(*$C$DW$T$989) .dwattr $C$DW$628, DW_AT_name("gauss") .dwattr $C$DW$628, DW_AT_TI_symbol_name("gauss") .dwattr $C$DW$628, DW_AT_data_member_location[DW_OP_plus_uconst 0x8d8] .dwattr $C$DW$628, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$628, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$628, DW_AT_decl_line(0xf1) .dwattr $C$DW$628, DW_AT_decl_column(0x12) $C$DW$629 .dwtag DW_TAG_member .dwattr $C$DW$629, DW_AT_type(*$C$DW$T$989) .dwattr $C$DW$629, DW_AT_name("gaussPyramid") .dwattr $C$DW$629, DW_AT_TI_symbol_name("gaussPyramid") .dwattr $C$DW$629, DW_AT_data_member_location[DW_OP_plus_uconst 0x960] .dwattr $C$DW$629, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$629, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$629, DW_AT_decl_line(0xf2) .dwattr $C$DW$629, DW_AT_decl_column(0x12) $C$DW$630 .dwtag DW_TAG_member .dwattr $C$DW$630, DW_AT_type(*$C$DW$T$1233) .dwattr $C$DW$630, DW_AT_name("edgeRange") .dwattr $C$DW$630, DW_AT_TI_symbol_name("edgeRange") .dwattr $C$DW$630, DW_AT_data_member_location[DW_OP_plus_uconst 0x9e8] .dwattr $C$DW$630, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$630, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$630, DW_AT_decl_line(0xf4) .dwattr $C$DW$630, DW_AT_decl_column(0x16) $C$DW$631 .dwtag DW_TAG_member .dwattr $C$DW$631, DW_AT_type(*$C$DW$T$1227) .dwattr $C$DW$631, DW_AT_name("edgeDir") .dwattr $C$DW$631, DW_AT_TI_symbol_name("edgeDir") .dwattr $C$DW$631, DW_AT_data_member_location[DW_OP_plus_uconst 0x140ccc] .dwattr $C$DW$631, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$631, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$631, DW_AT_decl_line(0xf5) .dwattr $C$DW$631, DW_AT_decl_column(0x16) $C$DW$632 .dwtag DW_TAG_member .dwattr $C$DW$632, DW_AT_type(*$C$DW$T$1490) .dwattr $C$DW$632, DW_AT_name("bspFilter") .dwattr $C$DW$632, DW_AT_TI_symbol_name("bspFilter") .dwattr $C$DW$632, DW_AT_data_member_location[DW_OP_plus_uconst 0x142fdc] .dwattr $C$DW$632, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$632, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$632, DW_AT_decl_line(0xf7) .dwattr $C$DW$632, DW_AT_decl_column(0x14) $C$DW$633 .dwtag DW_TAG_member .dwattr $C$DW$633, DW_AT_type(*$C$DW$T$1197) .dwattr $C$DW$633, DW_AT_name("lapDir0") .dwattr $C$DW$633, DW_AT_TI_symbol_name("lapDir0") .dwattr $C$DW$633, DW_AT_data_member_location[DW_OP_plus_uconst 0x142ff0] .dwattr $C$DW$633, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$633, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$633, DW_AT_decl_line(0xf9) .dwattr $C$DW$633, DW_AT_decl_column(0x12) $C$DW$634 .dwtag DW_TAG_member .dwattr $C$DW$634, DW_AT_type(*$C$DW$T$1198) .dwattr $C$DW$634, DW_AT_name("drange") .dwattr $C$DW$634, DW_AT_TI_symbol_name("drange") .dwattr $C$DW$634, DW_AT_data_member_location[DW_OP_plus_uconst 0x143298] .dwattr $C$DW$634, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$634, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$634, DW_AT_decl_line(0xfb) .dwattr $C$DW$634, DW_AT_decl_column(0x14) $C$DW$635 .dwtag DW_TAG_member .dwattr $C$DW$635, DW_AT_type(*$C$DW$T$1199) .dwattr $C$DW$635, DW_AT_name("pCvizRemapTable") .dwattr $C$DW$635, DW_AT_TI_symbol_name("pCvizRemapTable") .dwattr $C$DW$635, DW_AT_data_member_location[DW_OP_plus_uconst 0x14329c] .dwattr $C$DW$635, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$635, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$635, DW_AT_decl_line(0xfe) .dwattr $C$DW$635, DW_AT_decl_column(0x14) $C$DW$636 .dwtag DW_TAG_member .dwattr $C$DW$636, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$636, DW_AT_name("activeRemapTableIndex") .dwattr $C$DW$636, DW_AT_TI_symbol_name("activeRemapTableIndex") .dwattr $C$DW$636, DW_AT_data_member_location[DW_OP_plus_uconst 0x1432a4] .dwattr $C$DW$636, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$636, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$636, DW_AT_decl_line(0xff) .dwattr $C$DW$636, DW_AT_decl_column(0x14) $C$DW$637 .dwtag DW_TAG_member .dwattr $C$DW$637, DW_AT_type(*$C$DW$T$1200) .dwattr $C$DW$637, DW_AT_name("nep") .dwattr $C$DW$637, DW_AT_TI_symbol_name("nep") .dwattr $C$DW$637, DW_AT_data_member_location[DW_OP_plus_uconst 0x1432a8] .dwattr $C$DW$637, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$637, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$637, DW_AT_decl_line(0x102) .dwattr $C$DW$637, DW_AT_decl_column(0x12) $C$DW$638 .dwtag DW_TAG_member .dwattr $C$DW$638, DW_AT_type(*$C$DW$T$1200) .dwattr $C$DW$638, DW_AT_name("nepS") .dwattr $C$DW$638, DW_AT_TI_symbol_name("nepS") .dwattr $C$DW$638, DW_AT_data_member_location[DW_OP_plus_uconst 0x2832f8] .dwattr $C$DW$638, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$638, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$638, DW_AT_decl_line(0x103) .dwattr $C$DW$638, DW_AT_decl_column(0x12) $C$DW$639 .dwtag DW_TAG_member .dwattr $C$DW$639, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$639, DW_AT_name("resample") .dwattr $C$DW$639, DW_AT_TI_symbol_name("resample") .dwattr $C$DW$639, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c3348] .dwattr $C$DW$639, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$639, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$639, DW_AT_decl_line(0x104) .dwattr $C$DW$639, DW_AT_decl_column(0x15) $C$DW$640 .dwtag DW_TAG_member .dwattr $C$DW$640, DW_AT_type(*$C$DW$T$1201) .dwattr $C$DW$640, DW_AT_name("calcNepWeightTblWorkBuf") .dwattr $C$DW$640, DW_AT_TI_symbol_name("calcNepWeightTblWorkBuf") .dwattr $C$DW$640, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c334c] .dwattr $C$DW$640, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$640, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$640, DW_AT_decl_line(0x106) .dwattr $C$DW$640, DW_AT_decl_column(0x0e) $C$DW$641 .dwtag DW_TAG_member .dwattr $C$DW$641, DW_AT_type(*$C$DW$T$1221) .dwattr $C$DW$641, DW_AT_name("image") .dwattr $C$DW$641, DW_AT_TI_symbol_name("image") .dwattr $C$DW$641, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e334c] .dwattr $C$DW$641, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$641, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$641, DW_AT_decl_line(0x109) .dwattr $C$DW$641, DW_AT_decl_column(0x14) $C$DW$642 .dwtag DW_TAG_member .dwattr $C$DW$642, DW_AT_type(*$C$DW$T$1202) .dwattr $C$DW$642, DW_AT_name("actualParam") .dwattr $C$DW$642, DW_AT_TI_symbol_name("actualParam") .dwattr $C$DW$642, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e3450] .dwattr $C$DW$642, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$642, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$642, DW_AT_decl_line(0x10c) .dwattr $C$DW$642, DW_AT_decl_column(0x14) $C$DW$643 .dwtag DW_TAG_member .dwattr $C$DW$643, DW_AT_type(*$C$DW$T$1202) .dwattr $C$DW$643, DW_AT_name("tempParam") .dwattr $C$DW$643, DW_AT_TI_symbol_name("tempParam") .dwattr $C$DW$643, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e4068] .dwattr $C$DW$643, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$643, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$643, DW_AT_decl_line(0x10f) .dwattr $C$DW$643, DW_AT_decl_column(0x14) $C$DW$644 .dwtag DW_TAG_member .dwattr $C$DW$644, DW_AT_type(*$C$DW$T$1203) .dwattr $C$DW$644, DW_AT_name("anisoTmpFloat") .dwattr $C$DW$644, DW_AT_TI_symbol_name("anisoTmpFloat") .dwattr $C$DW$644, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e4c80] .dwattr $C$DW$644, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$644, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$644, DW_AT_decl_line(0x112) .dwattr $C$DW$644, DW_AT_decl_column(0x0b) $C$DW$645 .dwtag DW_TAG_member .dwattr $C$DW$645, DW_AT_type(*$C$DW$T$1204) .dwattr $C$DW$645, DW_AT_name("anisoTmpIpInt") .dwattr $C$DW$645, DW_AT_TI_symbol_name("anisoTmpIpInt") .dwattr $C$DW$645, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e4fa0] .dwattr $C$DW$645, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$645, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$645, DW_AT_decl_line(0x115) .dwattr $C$DW$645, DW_AT_decl_column(0x0c) $C$DW$646 .dwtag DW_TAG_member .dwattr $C$DW$646, DW_AT_type(*$C$DW$T$248) .dwattr $C$DW$646, DW_AT_name("multiProcEnabled") .dwattr $C$DW$646, DW_AT_TI_symbol_name("multiProcEnabled") .dwattr $C$DW$646, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5130] .dwattr $C$DW$646, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$646, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$646, DW_AT_decl_line(0x117) .dwattr $C$DW$646, DW_AT_decl_column(0x0a) $C$DW$647 .dwtag DW_TAG_member .dwattr $C$DW$647, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$647, DW_AT_name("expandSizeX") .dwattr $C$DW$647, DW_AT_TI_symbol_name("expandSizeX") .dwattr $C$DW$647, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5134] .dwattr $C$DW$647, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$647, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$647, DW_AT_decl_line(0x119) .dwattr $C$DW$647, DW_AT_decl_column(0x0b) $C$DW$648 .dwtag DW_TAG_member .dwattr $C$DW$648, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$648, DW_AT_name("expandSizeY") .dwattr $C$DW$648, DW_AT_TI_symbol_name("expandSizeY") .dwattr $C$DW$648, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5138] .dwattr $C$DW$648, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$648, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$648, DW_AT_decl_line(0x11a) .dwattr $C$DW$648, DW_AT_decl_column(0x0b) $C$DW$649 .dwtag DW_TAG_member .dwattr $C$DW$649, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$649, DW_AT_name("procType") .dwattr $C$DW$649, DW_AT_TI_symbol_name("procType") .dwattr $C$DW$649, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e513c] .dwattr $C$DW$649, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$649, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$649, DW_AT_decl_line(0x11c) .dwattr $C$DW$649, DW_AT_decl_column(0x0b) $C$DW$650 .dwtag DW_TAG_member .dwattr $C$DW$650, DW_AT_type(*$C$DW$T$1205) .dwattr $C$DW$650, DW_AT_name("lineOffset") .dwattr $C$DW$650, DW_AT_TI_symbol_name("lineOffset") .dwattr $C$DW$650, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5140] .dwattr $C$DW$650, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$650, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$650, DW_AT_decl_line(0x11f) .dwattr $C$DW$650, DW_AT_decl_column(0x0b) $C$DW$651 .dwtag DW_TAG_member .dwattr $C$DW$651, DW_AT_type(*$C$DW$T$1205) .dwattr $C$DW$651, DW_AT_name("numLateralEst") .dwattr $C$DW$651, DW_AT_TI_symbol_name("numLateralEst") .dwattr $C$DW$651, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e5ee0] .dwattr $C$DW$651, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$651, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$651, DW_AT_decl_line(0x120) .dwattr $C$DW$651, DW_AT_decl_column(0x0b) $C$DW$652 .dwtag DW_TAG_member .dwattr $C$DW$652, DW_AT_type(*$C$DW$T$1206) .dwattr $C$DW$652, DW_AT_name("estOffset") .dwattr $C$DW$652, DW_AT_TI_symbol_name("estOffset") .dwattr $C$DW$652, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e6c80] .dwattr $C$DW$652, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$652, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$652, DW_AT_decl_line(0x121) .dwattr $C$DW$652, DW_AT_decl_column(0x0b) $C$DW$653 .dwtag DW_TAG_member .dwattr $C$DW$653, DW_AT_type(*$C$DW$T$1206) .dwattr $C$DW$653, DW_AT_name("numAxialEst") .dwattr $C$DW$653, DW_AT_TI_symbol_name("numAxialEst") .dwattr $C$DW$653, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e7c80] .dwattr $C$DW$653, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$653, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$653, DW_AT_decl_line(0x122) .dwattr $C$DW$653, DW_AT_decl_column(0x0b) $C$DW$654 .dwtag DW_TAG_member .dwattr $C$DW$654, DW_AT_type(*$C$DW$T$1207) .dwattr $C$DW$654, DW_AT_name("numAxialOffsetSub") .dwattr $C$DW$654, DW_AT_TI_symbol_name("numAxialOffsetSub") .dwattr $C$DW$654, DW_AT_data_member_location[DW_OP_plus_uconst 0x3e8c80] .dwattr $C$DW$654, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$654, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$654, DW_AT_decl_line(0x123) .dwattr $C$DW$654, DW_AT_decl_column(0x0b) $C$DW$655 .dwtag DW_TAG_member .dwattr $C$DW$655, DW_AT_type(*$C$DW$T$1208) .dwattr $C$DW$655, DW_AT_name("numAxialOffset") .dwattr $C$DW$655, DW_AT_TI_symbol_name("numAxialOffset") .dwattr $C$DW$655, DW_AT_data_member_location[DW_OP_plus_uconst 0x3ea7c0] .dwattr $C$DW$655, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$655, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$655, DW_AT_decl_line(0x124) .dwattr $C$DW$655, DW_AT_decl_column(0x0c) $C$DW$656 .dwtag DW_TAG_member .dwattr $C$DW$656, DW_AT_type(*$C$DW$T$1210) .dwattr $C$DW$656, DW_AT_name("numAxialOffsetSub2") .dwattr $C$DW$656, DW_AT_TI_symbol_name("numAxialOffsetSub2") .dwattr $C$DW$656, DW_AT_data_member_location[DW_OP_plus_uconst 0x3ea7c4] .dwattr $C$DW$656, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$656, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$656, DW_AT_decl_line(0x125) .dwattr $C$DW$656, DW_AT_decl_column(0x0b) $C$DW$657 .dwtag DW_TAG_member .dwattr $C$DW$657, DW_AT_type(*$C$DW$T$1208) .dwattr $C$DW$657, DW_AT_name("numAxialOffset2") .dwattr $C$DW$657, DW_AT_TI_symbol_name("numAxialOffset2") .dwattr $C$DW$657, DW_AT_data_member_location[DW_OP_plus_uconst 0x3eb564] .dwattr $C$DW$657, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$657, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$657, DW_AT_decl_line(0x126) .dwattr $C$DW$657, DW_AT_decl_column(0x0c) $C$DW$658 .dwtag DW_TAG_member .dwattr $C$DW$658, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$658, DW_AT_name("frameBoundaryMode") .dwattr $C$DW$658, DW_AT_TI_symbol_name("frameBoundaryMode") .dwattr $C$DW$658, DW_AT_data_member_location[DW_OP_plus_uconst 0x3eb568] .dwattr $C$DW$658, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$658, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$658, DW_AT_decl_line(0x127) .dwattr $C$DW$658, DW_AT_decl_column(0x0b) $C$DW$16 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$16, DW_AT_declaration .dwattr $C$DW$16, DW_AT_TI_symbol_name("_ZN9ContextBeaSERKS_") .dwattr $C$DW$16, DW_AT_type(*$C$DW$T$1211) .dwattr $C$DW$16, DW_AT_accessibility(DW_ACCESS_public) $C$DW$659 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$659, DW_AT_type(*$C$DW$T$1213) .dwendtag $C$DW$16 .dwendtag $C$DW$T$1215 .dwattr $C$DW$T$1215, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$1215, DW_AT_decl_line(0xd1) .dwattr $C$DW$T$1215, DW_AT_decl_column(0x08) $C$DW$T$1212 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1212, DW_AT_type(*$C$DW$T$1215) $C$DW$T$1213 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1213, DW_AT_type(*$C$DW$T$1212) .dwattr $C$DW$T$1213, DW_AT_address_class(0x20) $C$DW$T$387 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$387, DW_AT_type(*$C$DW$T$1215) .dwattr $C$DW$T$387, DW_AT_address_class(0x20) $C$DW$T$2196 .dwtag DW_TAG_typedef, DW_AT_name("CVIZ_Context") .dwattr $C$DW$T$2196, DW_AT_type(*$C$DW$T$387) .dwattr $C$DW$T$2196, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2196, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/include/ClearVisualization.h") .dwattr $C$DW$T$2196, DW_AT_decl_line(0x67) .dwattr $C$DW$T$2196, DW_AT_decl_column(0x1b) $C$DW$T$1211 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1211, DW_AT_type(*$C$DW$T$1215) .dwattr $C$DW$T$1211, DW_AT_address_class(0x20) $C$DW$T$1214 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1214, DW_AT_type(*$C$DW$T$1211) .dwattr $C$DW$T$1214, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$660 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$660, DW_AT_type(*$C$DW$T$1213) .dwendtag $C$DW$T$1214 $C$DW$T$1221 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1221, DW_AT_name("ContextBeImage") .dwattr $C$DW$T$1221, DW_AT_byte_size(0x104) $C$DW$661 .dwtag DW_TAG_member .dwattr $C$DW$661, DW_AT_type(*$C$DW$T$416) .dwattr $C$DW$661, DW_AT_name("outTrape") .dwattr $C$DW$661, DW_AT_TI_symbol_name("outTrape") .dwattr $C$DW$661, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$661, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$661, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$661, DW_AT_decl_line(0x95) .dwattr $C$DW$661, DW_AT_decl_column(0x0f) $C$DW$662 .dwtag DW_TAG_member .dwattr $C$DW$662, DW_AT_type(*$C$DW$T$416) .dwattr $C$DW$662, DW_AT_name("pre") .dwattr $C$DW$662, DW_AT_TI_symbol_name("pre") .dwattr $C$DW$662, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$662, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$662, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$662, DW_AT_decl_line(0x96) .dwattr $C$DW$662, DW_AT_decl_column(0x12) $C$DW$663 .dwtag DW_TAG_member .dwattr $C$DW$663, DW_AT_type(*$C$DW$T$1065) .dwattr $C$DW$663, DW_AT_name("gaussian") .dwattr $C$DW$663, DW_AT_TI_symbol_name("gaussian") .dwattr $C$DW$663, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$663, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$663, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$663, DW_AT_decl_line(0x97) .dwattr $C$DW$663, DW_AT_decl_column(0x12) $C$DW$664 .dwtag DW_TAG_member .dwattr $C$DW$664, DW_AT_type(*$C$DW$T$1065) .dwattr $C$DW$664, DW_AT_name("edgeRange") .dwattr $C$DW$664, DW_AT_TI_symbol_name("edgeRange") .dwattr $C$DW$664, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c] .dwattr $C$DW$664, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$664, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$664, DW_AT_decl_line(0x98) .dwattr $C$DW$664, DW_AT_decl_column(0x12) $C$DW$665 .dwtag DW_TAG_member .dwattr $C$DW$665, DW_AT_type(*$C$DW$T$1065) .dwattr $C$DW$665, DW_AT_name("edgeDir") .dwattr $C$DW$665, DW_AT_TI_symbol_name("edgeDir") .dwattr $C$DW$665, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$665, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$665, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$665, DW_AT_decl_line(0x99) .dwattr $C$DW$665, DW_AT_decl_column(0x12) $C$DW$666 .dwtag DW_TAG_member .dwattr $C$DW$666, DW_AT_type(*$C$DW$T$1065) .dwattr $C$DW$666, DW_AT_name("lapPyramid") .dwattr $C$DW$666, DW_AT_TI_symbol_name("lapPyramid") .dwattr $C$DW$666, DW_AT_data_member_location[DW_OP_plus_uconst 0x44] .dwattr $C$DW$666, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$666, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$666, DW_AT_decl_line(0x9a) .dwattr $C$DW$666, DW_AT_decl_column(0x12) $C$DW$667 .dwtag DW_TAG_member .dwattr $C$DW$667, DW_AT_type(*$C$DW$T$1216) .dwattr $C$DW$667, DW_AT_name("lapDir") .dwattr $C$DW$667, DW_AT_TI_symbol_name("lapDir") .dwattr $C$DW$667, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$667, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$667, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$667, DW_AT_decl_line(0x9b) .dwattr $C$DW$667, DW_AT_decl_column(0x12) $C$DW$668 .dwtag DW_TAG_member .dwattr $C$DW$668, DW_AT_type(*$C$DW$T$1071) .dwattr $C$DW$668, DW_AT_name("edgeDirWork") .dwattr $C$DW$668, DW_AT_TI_symbol_name("edgeDirWork") .dwattr $C$DW$668, DW_AT_data_member_location[DW_OP_plus_uconst 0x80] .dwattr $C$DW$668, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$668, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$668, DW_AT_decl_line(0x9c) .dwattr $C$DW$668, DW_AT_decl_column(0x12) $C$DW$669 .dwtag DW_TAG_member .dwattr $C$DW$669, DW_AT_type(*$C$DW$T$1065) .dwattr $C$DW$669, DW_AT_name("adapt") .dwattr $C$DW$669, DW_AT_TI_symbol_name("adapt") .dwattr $C$DW$669, DW_AT_data_member_location[DW_OP_plus_uconst 0xe4] .dwattr $C$DW$669, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$669, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$669, DW_AT_decl_line(0x9d) .dwattr $C$DW$669, DW_AT_decl_column(0x12) $C$DW$670 .dwtag DW_TAG_member .dwattr $C$DW$670, DW_AT_type(*$C$DW$T$416) .dwattr $C$DW$670, DW_AT_name("lapDirCoef") .dwattr $C$DW$670, DW_AT_TI_symbol_name("lapDirCoef") .dwattr $C$DW$670, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8] .dwattr $C$DW$670, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$670, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$670, DW_AT_decl_line(0x9e) .dwattr $C$DW$670, DW_AT_decl_column(0x12) $C$DW$671 .dwtag DW_TAG_member .dwattr $C$DW$671, DW_AT_type(*$C$DW$T$416) .dwattr $C$DW$671, DW_AT_name("lineBuf") .dwattr $C$DW$671, DW_AT_TI_symbol_name("lineBuf") .dwattr $C$DW$671, DW_AT_data_member_location[DW_OP_plus_uconst 0xfc] .dwattr $C$DW$671, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$671, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$671, DW_AT_decl_line(0x9f) .dwattr $C$DW$671, DW_AT_decl_column(0x12) $C$DW$672 .dwtag DW_TAG_member .dwattr $C$DW$672, DW_AT_type(*$C$DW$T$416) .dwattr $C$DW$672, DW_AT_name("stitch") .dwattr $C$DW$672, DW_AT_TI_symbol_name("stitch") .dwattr $C$DW$672, DW_AT_data_member_location[DW_OP_plus_uconst 0x100] .dwattr $C$DW$672, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$672, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$672, DW_AT_decl_line(0xa0) .dwattr $C$DW$672, DW_AT_decl_column(0x12) $C$DW$17 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$17, DW_AT_declaration .dwattr $C$DW$17, DW_AT_TI_symbol_name("_ZN14ContextBeImageaSERKS_") .dwattr $C$DW$17, DW_AT_type(*$C$DW$T$1217) .dwattr $C$DW$17, DW_AT_accessibility(DW_ACCESS_public) $C$DW$673 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$673, DW_AT_type(*$C$DW$T$1219) .dwendtag $C$DW$17 .dwendtag $C$DW$T$1221 .dwattr $C$DW$T$1221, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$1221, DW_AT_decl_line(0x93) .dwattr $C$DW$T$1221, DW_AT_decl_column(0x08) $C$DW$T$1218 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1218, DW_AT_type(*$C$DW$T$1221) $C$DW$T$1219 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1219, DW_AT_type(*$C$DW$T$1218) .dwattr $C$DW$T$1219, DW_AT_address_class(0x20) $C$DW$T$1217 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1217, DW_AT_type(*$C$DW$T$1221) .dwattr $C$DW$T$1217, DW_AT_address_class(0x20) $C$DW$T$1220 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1220, DW_AT_type(*$C$DW$T$1217) .dwattr $C$DW$T$1220, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$674 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$674, DW_AT_type(*$C$DW$T$1219) .dwendtag $C$DW$T$1220 $C$DW$T$1227 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1227, DW_AT_name("ContextEdgeDir") .dwattr $C$DW$T$1227, DW_AT_byte_size(0x2310) $C$DW$675 .dwtag DW_TAG_member .dwattr $C$DW$675, DW_AT_type(*$C$DW$T$1197) .dwattr $C$DW$675, DW_AT_name("filter") .dwattr $C$DW$675, DW_AT_TI_symbol_name("filter") .dwattr $C$DW$675, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$675, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$675, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$675, DW_AT_decl_line(0xae) .dwattr $C$DW$675, DW_AT_decl_column(0x19) $C$DW$676 .dwtag DW_TAG_member .dwattr $C$DW$676, DW_AT_type(*$C$DW$T$1222) .dwattr $C$DW$676, DW_AT_name("dirFilter") .dwattr $C$DW$676, DW_AT_TI_symbol_name("dirFilter") .dwattr $C$DW$676, DW_AT_data_member_location[DW_OP_plus_uconst 0x2a8] .dwattr $C$DW$676, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$676, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$676, DW_AT_decl_line(0xb0) .dwattr $C$DW$676, DW_AT_decl_column(0x15) $C$DW$677 .dwtag DW_TAG_member .dwattr $C$DW$677, DW_AT_type(*$C$DW$T$1036) .dwattr $C$DW$677, DW_AT_name("dirParam") .dwattr $C$DW$677, DW_AT_TI_symbol_name("dirParam") .dwattr $C$DW$677, DW_AT_data_member_location[DW_OP_plus_uconst 0x378] .dwattr $C$DW$677, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$677, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$677, DW_AT_decl_line(0xb1) .dwattr $C$DW$677, DW_AT_decl_column(0x13) $C$DW$678 .dwtag DW_TAG_member .dwattr $C$DW$678, DW_AT_type(*$C$DW$T$1490) .dwattr $C$DW$678, DW_AT_name("bspFilter") .dwattr $C$DW$678, DW_AT_TI_symbol_name("bspFilter") .dwattr $C$DW$678, DW_AT_data_member_location[DW_OP_plus_uconst 0x22c0] .dwattr $C$DW$678, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$678, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$678, DW_AT_decl_line(0xb2) .dwattr $C$DW$678, DW_AT_decl_column(0x15) $C$DW$679 .dwtag DW_TAG_member .dwattr $C$DW$679, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$679, DW_AT_name("calc") .dwattr $C$DW$679, DW_AT_TI_symbol_name("calc") .dwattr $C$DW$679, DW_AT_data_member_location[DW_OP_plus_uconst 0x22d4] .dwattr $C$DW$679, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$679, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$679, DW_AT_decl_line(0xb4) .dwattr $C$DW$679, DW_AT_decl_column(0x09) $C$DW$680 .dwtag DW_TAG_member .dwattr $C$DW$680, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$680, DW_AT_name("calcDir") .dwattr $C$DW$680, DW_AT_TI_symbol_name("calcDir") .dwattr $C$DW$680, DW_AT_data_member_location[DW_OP_plus_uconst 0x22e8] .dwattr $C$DW$680, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$680, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$680, DW_AT_decl_line(0xb5) .dwattr $C$DW$680, DW_AT_decl_column(0x09) $C$DW$681 .dwtag DW_TAG_member .dwattr $C$DW$681, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$681, DW_AT_name("calcDet") .dwattr $C$DW$681, DW_AT_TI_symbol_name("calcDet") .dwattr $C$DW$681, DW_AT_data_member_location[DW_OP_plus_uconst 0x22fc] .dwattr $C$DW$681, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$681, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$681, DW_AT_decl_line(0xb6) .dwattr $C$DW$681, DW_AT_decl_column(0x09) $C$DW$18 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$18, DW_AT_declaration .dwattr $C$DW$18, DW_AT_TI_symbol_name("_ZN14ContextEdgeDiraSERKS_") .dwattr $C$DW$18, DW_AT_type(*$C$DW$T$1223) .dwattr $C$DW$18, DW_AT_accessibility(DW_ACCESS_public) $C$DW$682 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$682, DW_AT_type(*$C$DW$T$1225) .dwendtag $C$DW$18 .dwendtag $C$DW$T$1227 .dwattr $C$DW$T$1227, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$1227, DW_AT_decl_line(0xac) .dwattr $C$DW$T$1227, DW_AT_decl_column(0x08) $C$DW$T$1224 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1224, DW_AT_type(*$C$DW$T$1227) $C$DW$T$1225 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1225, DW_AT_type(*$C$DW$T$1224) .dwattr $C$DW$T$1225, DW_AT_address_class(0x20) $C$DW$T$386 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$386, DW_AT_type(*$C$DW$T$1227) .dwattr $C$DW$T$386, DW_AT_address_class(0x20) $C$DW$T$1223 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1223, DW_AT_type(*$C$DW$T$1227) .dwattr $C$DW$T$1223, DW_AT_address_class(0x20) $C$DW$T$1226 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1226, DW_AT_type(*$C$DW$T$1223) .dwattr $C$DW$T$1226, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$683 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$683, DW_AT_type(*$C$DW$T$1225) .dwendtag $C$DW$T$1226 $C$DW$T$1233 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1233, DW_AT_name("ContextEdgeRange") .dwattr $C$DW$T$1233, DW_AT_byte_size(0x1402e4) $C$DW$684 .dwtag DW_TAG_member .dwattr $C$DW$684, DW_AT_type(*$C$DW$T$1228) .dwattr $C$DW$684, DW_AT_name("edgeNorm") .dwattr $C$DW$684, DW_AT_TI_symbol_name("edgeNorm") .dwattr $C$DW$684, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$684, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$684, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$684, DW_AT_decl_line(0xa6) .dwattr $C$DW$684, DW_AT_decl_column(0x14) $C$DW$685 .dwtag DW_TAG_member .dwattr $C$DW$685, DW_AT_type(*$C$DW$T$1197) .dwattr $C$DW$685, DW_AT_name("filter") .dwattr $C$DW$685, DW_AT_TI_symbol_name("filter") .dwattr $C$DW$685, DW_AT_data_member_location[DW_OP_plus_uconst 0x140028] .dwattr $C$DW$685, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$685, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$685, DW_AT_decl_line(0xa7) .dwattr $C$DW$685, DW_AT_decl_column(0x19) $C$DW$686 .dwtag DW_TAG_member .dwattr $C$DW$686, DW_AT_type(*$C$DW$T$1490) .dwattr $C$DW$686, DW_AT_name("bspFilter") .dwattr $C$DW$686, DW_AT_TI_symbol_name("bspFilter") .dwattr $C$DW$686, DW_AT_data_member_location[DW_OP_plus_uconst 0x1402d0] .dwattr $C$DW$686, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$686, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$686, DW_AT_decl_line(0xa8) .dwattr $C$DW$686, DW_AT_decl_column(0x15) $C$DW$19 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$19, DW_AT_declaration .dwattr $C$DW$19, DW_AT_TI_symbol_name("_ZN16ContextEdgeRangeaSERKS_") .dwattr $C$DW$19, DW_AT_type(*$C$DW$T$1229) .dwattr $C$DW$19, DW_AT_accessibility(DW_ACCESS_public) $C$DW$687 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$687, DW_AT_type(*$C$DW$T$1231) .dwendtag $C$DW$19 .dwendtag $C$DW$T$1233 .dwattr $C$DW$T$1233, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$1233, DW_AT_decl_line(0xa4) .dwattr $C$DW$T$1233, DW_AT_decl_column(0x08) $C$DW$T$1230 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1230, DW_AT_type(*$C$DW$T$1233) $C$DW$T$1231 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1231, DW_AT_type(*$C$DW$T$1230) .dwattr $C$DW$T$1231, DW_AT_address_class(0x20) $C$DW$T$1229 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1229, DW_AT_type(*$C$DW$T$1233) .dwattr $C$DW$T$1229, DW_AT_address_class(0x20) $C$DW$T$1232 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1232, DW_AT_type(*$C$DW$T$1229) .dwattr $C$DW$T$1232, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$688 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$688, DW_AT_type(*$C$DW$T$1231) .dwendtag $C$DW$T$1232 $C$DW$T$498 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$498, DW_AT_name("DbellMsg") .dwattr $C$DW$T$498, DW_AT_byte_size(0x30) $C$DW$689 .dwtag DW_TAG_member .dwattr $C$DW$689, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$689, DW_AT_name("info") .dwattr $C$DW$689, DW_AT_TI_symbol_name("info") .dwattr $C$DW$689, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$689, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$689, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$689, DW_AT_decl_line(0xa8) .dwattr $C$DW$689, DW_AT_decl_column(0x19) $C$DW$690 .dwtag DW_TAG_member .dwattr $C$DW$690, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$690, DW_AT_name("timeStamp") .dwattr $C$DW$690, DW_AT_TI_symbol_name("timeStamp") .dwattr $C$DW$690, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$690, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$690, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$690, DW_AT_decl_line(0xab) .dwattr $C$DW$690, DW_AT_decl_column(0x19) $C$DW$691 .dwtag DW_TAG_member .dwattr $C$DW$691, DW_AT_type(*$C$DW$T$493) .dwattr $C$DW$691, DW_AT_name("data") .dwattr $C$DW$691, DW_AT_TI_symbol_name("data") .dwattr $C$DW$691, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$691, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$691, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$691, DW_AT_decl_line(0xac) .dwattr $C$DW$691, DW_AT_decl_column(0x19) $C$DW$20 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$20, DW_AT_declaration .dwattr $C$DW$20, DW_AT_TI_symbol_name("_ZN8DbellMsgaSERKS_") .dwattr $C$DW$20, DW_AT_type(*$C$DW$T$494) .dwattr $C$DW$20, DW_AT_accessibility(DW_ACCESS_public) $C$DW$692 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$692, DW_AT_type(*$C$DW$T$496) .dwendtag $C$DW$20 .dwendtag $C$DW$T$498 .dwattr $C$DW$T$498, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$498, DW_AT_decl_line(0xa7) .dwattr $C$DW$T$498, DW_AT_decl_column(0x01) $C$DW$T$495 .dwtag DW_TAG_const_type .dwattr $C$DW$T$495, DW_AT_type(*$C$DW$T$498) $C$DW$T$496 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$496, DW_AT_type(*$C$DW$T$495) .dwattr $C$DW$T$496, DW_AT_address_class(0x20) $C$DW$T$1478 .dwtag DW_TAG_typedef, DW_AT_name("DbellMsg") .dwattr $C$DW$T$1478, DW_AT_type(*$C$DW$T$498) .dwattr $C$DW$T$1478, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1478, DW_AT_decl_line(0xad) .dwattr $C$DW$T$1478, DW_AT_decl_column(0x03) $C$DW$T$494 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$494, DW_AT_type(*$C$DW$T$498) .dwattr $C$DW$T$494, DW_AT_address_class(0x20) $C$DW$T$497 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$497, DW_AT_type(*$C$DW$T$494) .dwattr $C$DW$T$497, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$693 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$693, DW_AT_type(*$C$DW$T$496) .dwendtag $C$DW$T$497 $C$DW$T$1030 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1030, DW_AT_name("DirFilterParam") .dwattr $C$DW$T$1030, DW_AT_byte_size(0x34) $C$DW$694 .dwtag DW_TAG_member .dwattr $C$DW$694, DW_AT_type(*$C$DW$T$1025) .dwattr $C$DW$694, DW_AT_name("coef") .dwattr $C$DW$694, DW_AT_TI_symbol_name("coef") .dwattr $C$DW$694, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$694, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$694, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$694, DW_AT_decl_line(0x7e) .dwattr $C$DW$694, DW_AT_decl_column(0x07) $C$DW$695 .dwtag DW_TAG_member .dwattr $C$DW$695, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$695, DW_AT_name("accuracyBits") .dwattr $C$DW$695, DW_AT_TI_symbol_name("accuracyBits") .dwattr $C$DW$695, DW_AT_data_member_location[DW_OP_plus_uconst 0x24] .dwattr $C$DW$695, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$695, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$695, DW_AT_decl_line(0x7f) .dwattr $C$DW$695, DW_AT_decl_column(0x07) $C$DW$696 .dwtag DW_TAG_member .dwattr $C$DW$696, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$696, DW_AT_name("maskh") .dwattr $C$DW$696, DW_AT_TI_symbol_name("maskh") .dwattr $C$DW$696, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$696, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$696, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$696, DW_AT_decl_line(0x80) .dwattr $C$DW$696, DW_AT_decl_column(0x07) $C$DW$697 .dwtag DW_TAG_member .dwattr $C$DW$697, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$697, DW_AT_name("alpha") .dwattr $C$DW$697, DW_AT_TI_symbol_name("alpha") .dwattr $C$DW$697, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c] .dwattr $C$DW$697, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$697, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$697, DW_AT_decl_line(0x81) .dwattr $C$DW$697, DW_AT_decl_column(0x0a) $C$DW$698 .dwtag DW_TAG_member .dwattr $C$DW$698, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$698, DW_AT_name("filterType") .dwattr $C$DW$698, DW_AT_TI_symbol_name("filterType") .dwattr $C$DW$698, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$698, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$698, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$698, DW_AT_decl_line(0x82) .dwattr $C$DW$698, DW_AT_decl_column(0x0a) $C$DW$21 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$21, DW_AT_declaration .dwattr $C$DW$21, DW_AT_TI_symbol_name("_ZN14DirFilterParamaSERKS_") .dwattr $C$DW$21, DW_AT_type(*$C$DW$T$1026) .dwattr $C$DW$21, DW_AT_accessibility(DW_ACCESS_public) $C$DW$699 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$699, DW_AT_type(*$C$DW$T$1028) .dwendtag $C$DW$21 .dwendtag $C$DW$T$1030 .dwattr $C$DW$T$1030, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$1030, DW_AT_decl_line(0x7c) .dwattr $C$DW$T$1030, DW_AT_decl_column(0x08) $C$DW$T$1027 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1027, DW_AT_type(*$C$DW$T$1030) $C$DW$T$1028 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1028, DW_AT_type(*$C$DW$T$1027) .dwattr $C$DW$T$1028, DW_AT_address_class(0x20) $C$DW$T$1026 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1026, DW_AT_type(*$C$DW$T$1030) .dwattr $C$DW$T$1026, DW_AT_address_class(0x20) $C$DW$T$1029 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1029, DW_AT_type(*$C$DW$T$1026) .dwattr $C$DW$T$1029, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$700 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$700, DW_AT_type(*$C$DW$T$1028) .dwendtag $C$DW$T$1029 $C$DW$T$1222 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1222, DW_AT_type(*$C$DW$T$1030) .dwattr $C$DW$T$1222, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1222, DW_AT_byte_size(0xd0) $C$DW$701 .dwtag DW_TAG_subrange_type .dwattr $C$DW$701, DW_AT_upper_bound(0x03) .dwendtag $C$DW$T$1222 $C$DW$T$1036 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1036, DW_AT_name("DirLutParam") .dwattr $C$DW$T$1036, DW_AT_byte_size(0x1f48) $C$DW$702 .dwtag DW_TAG_member .dwattr $C$DW$702, DW_AT_type(*$C$DW$T$1031) .dwattr $C$DW$702, DW_AT_name("lut") .dwattr $C$DW$702, DW_AT_TI_symbol_name("lut") .dwattr $C$DW$702, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$702, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$702, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$702, DW_AT_decl_line(0x41) .dwattr $C$DW$702, DW_AT_decl_column(0x07) $C$DW$703 .dwtag DW_TAG_member .dwattr $C$DW$703, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$703, DW_AT_name("dirNum") .dwattr $C$DW$703, DW_AT_TI_symbol_name("dirNum") .dwattr $C$DW$703, DW_AT_data_member_location[DW_OP_plus_uconst 0x1f44] .dwattr $C$DW$703, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$703, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$703, DW_AT_decl_line(0x42) .dwattr $C$DW$703, DW_AT_decl_column(0x07) $C$DW$22 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$22, DW_AT_declaration .dwattr $C$DW$22, DW_AT_TI_symbol_name("_ZN11DirLutParamaSERKS_") .dwattr $C$DW$22, DW_AT_type(*$C$DW$T$1032) .dwattr $C$DW$22, DW_AT_accessibility(DW_ACCESS_public) $C$DW$704 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$704, DW_AT_type(*$C$DW$T$1034) .dwendtag $C$DW$22 .dwendtag $C$DW$T$1036 .dwattr $C$DW$T$1036, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$1036, DW_AT_decl_line(0x3f) .dwattr $C$DW$T$1036, DW_AT_decl_column(0x08) $C$DW$T$1033 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1033, DW_AT_type(*$C$DW$T$1036) $C$DW$T$1034 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1034, DW_AT_type(*$C$DW$T$1033) .dwattr $C$DW$T$1034, DW_AT_address_class(0x20) $C$DW$T$1032 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1032, DW_AT_type(*$C$DW$T$1036) .dwattr $C$DW$T$1032, DW_AT_address_class(0x20) $C$DW$T$1035 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1035, DW_AT_type(*$C$DW$T$1032) .dwattr $C$DW$T$1035, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$705 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$705, DW_AT_type(*$C$DW$T$1034) .dwendtag $C$DW$T$1035 $C$DW$T$2197 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$2197, DW_AT_name("DopplerGapBlankAction") .dwattr $C$DW$T$2197, DW_AT_byte_size(0x04) $C$DW$706 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLANK_COUNT_RESET"), DW_AT_const_value(0x00) .dwattr $C$DW$706, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$706, DW_AT_decl_line(0x1c) .dwattr $C$DW$706, DW_AT_decl_column(0x05) $C$DW$707 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLANK_COUNTDOWN"), DW_AT_const_value(0x01) .dwattr $C$DW$707, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$707, DW_AT_decl_line(0x1d) .dwattr $C$DW$707, DW_AT_decl_column(0x05) $C$DW$708 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLANK_DEACTIVATE_COUNTDOWN"), DW_AT_const_value(0x02) .dwattr $C$DW$708, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$708, DW_AT_decl_line(0x1e) .dwattr $C$DW$708, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$2197 .dwattr $C$DW$T$2197, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$T$2197, DW_AT_decl_line(0x1b) .dwattr $C$DW$T$2197, DW_AT_decl_column(0x01) $C$DW$T$2198 .dwtag DW_TAG_typedef, DW_AT_name("DopplerGapBlankAction") .dwattr $C$DW$T$2198, DW_AT_type(*$C$DW$T$2197) .dwattr $C$DW$T$2198, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2198, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$T$2198, DW_AT_decl_line(0x1f) .dwattr $C$DW$T$2198, DW_AT_decl_column(0x03) $C$DW$T$1243 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1243, DW_AT_name("DopplerInputData") .dwattr $C$DW$T$1243, DW_AT_byte_size(0x18) $C$DW$709 .dwtag DW_TAG_member .dwattr $C$DW$709, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$709, DW_AT_name("timeStamp") .dwattr $C$DW$709, DW_AT_TI_symbol_name("timeStamp") .dwattr $C$DW$709, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$709, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$709, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$709, DW_AT_decl_line(0x2b) .dwattr $C$DW$709, DW_AT_decl_column(0x19) $C$DW$710 .dwtag DW_TAG_member .dwattr $C$DW$710, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$710, DW_AT_name("rfBufIdx") .dwattr $C$DW$710, DW_AT_TI_symbol_name("rfBufIdx") .dwattr $C$DW$710, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$710, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$710, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$710, DW_AT_decl_line(0x2c) .dwattr $C$DW$710, DW_AT_decl_column(0x19) $C$DW$711 .dwtag DW_TAG_member .dwattr $C$DW$711, DW_AT_type(*$C$DW$T$520) .dwattr $C$DW$711, DW_AT_name("data") .dwattr $C$DW$711, DW_AT_TI_symbol_name("data") .dwattr $C$DW$711, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$711, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$711, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$711, DW_AT_decl_line(0x2d) .dwattr $C$DW$711, DW_AT_decl_column(0x19) $C$DW$23 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$23, DW_AT_declaration .dwattr $C$DW$23, DW_AT_TI_symbol_name("_ZN16DopplerInputDataaSERKS_") .dwattr $C$DW$23, DW_AT_type(*$C$DW$T$1239) .dwattr $C$DW$23, DW_AT_accessibility(DW_ACCESS_public) $C$DW$712 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$712, DW_AT_type(*$C$DW$T$1241) .dwendtag $C$DW$23 .dwendtag $C$DW$T$1243 .dwattr $C$DW$T$1243, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1243, DW_AT_decl_line(0x29) .dwattr $C$DW$T$1243, DW_AT_decl_column(0x01) $C$DW$T$1164 .dwtag DW_TAG_typedef, DW_AT_name("DopplerInputData") .dwattr $C$DW$T$1164, DW_AT_type(*$C$DW$T$1243) .dwattr $C$DW$T$1164, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1164, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1164, DW_AT_decl_line(0x2e) .dwattr $C$DW$T$1164, DW_AT_decl_column(0x03) $C$DW$T$1240 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1240, DW_AT_type(*$C$DW$T$1243) $C$DW$T$1241 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1241, DW_AT_type(*$C$DW$T$1240) .dwattr $C$DW$T$1241, DW_AT_address_class(0x20) $C$DW$T$1239 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1239, DW_AT_type(*$C$DW$T$1243) .dwattr $C$DW$T$1239, DW_AT_address_class(0x20) $C$DW$T$1242 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1242, DW_AT_type(*$C$DW$T$1239) .dwattr $C$DW$T$1242, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$713 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$713, DW_AT_type(*$C$DW$T$1241) .dwendtag $C$DW$T$1242 $C$DW$T$1248 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1248, DW_AT_name("Doppler_GapConfig") .dwattr $C$DW$T$1248, DW_AT_byte_size(0xa8) $C$DW$714 .dwtag DW_TAG_member .dwattr $C$DW$714, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$714, DW_AT_name("burgOrder") .dwattr $C$DW$714, DW_AT_TI_symbol_name("burgOrder") .dwattr $C$DW$714, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$714, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$714, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$714, DW_AT_decl_line(0x46a) .dwattr $C$DW$714, DW_AT_decl_column(0x05) $C$DW$715 .dwtag DW_TAG_member .dwattr $C$DW$715, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$715, DW_AT_name("size") .dwattr $C$DW$715, DW_AT_TI_symbol_name("size") .dwattr $C$DW$715, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$715, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$715, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$715, DW_AT_decl_line(0x46b) .dwattr $C$DW$715, DW_AT_decl_column(0x05) $C$DW$716 .dwtag DW_TAG_member .dwattr $C$DW$716, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$716, DW_AT_name("numModelSamples") .dwattr $C$DW$716, DW_AT_TI_symbol_name("numModelSamples") .dwattr $C$DW$716, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$716, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$716, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$716, DW_AT_decl_line(0x46e) .dwattr $C$DW$716, DW_AT_decl_column(0x05) $C$DW$717 .dwtag DW_TAG_member .dwattr $C$DW$717, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$717, DW_AT_name("numTotalSamples") .dwattr $C$DW$717, DW_AT_TI_symbol_name("numTotalSamples") .dwattr $C$DW$717, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$717, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$717, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$717, DW_AT_decl_line(0x470) .dwattr $C$DW$717, DW_AT_decl_column(0x05) $C$DW$718 .dwtag DW_TAG_member .dwattr $C$DW$718, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$718, DW_AT_name("alpha") .dwattr $C$DW$718, DW_AT_TI_symbol_name("alpha") .dwattr $C$DW$718, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$718, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$718, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$718, DW_AT_decl_line(0x471) .dwattr $C$DW$718, DW_AT_decl_column(0x05) $C$DW$719 .dwtag DW_TAG_member .dwattr $C$DW$719, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$719, DW_AT_name("reserved") .dwattr $C$DW$719, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$719, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$719, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$719, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$719, DW_AT_decl_line(0x472) .dwattr $C$DW$719, DW_AT_decl_column(0x05) $C$DW$24 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$24, DW_AT_declaration .dwattr $C$DW$24, DW_AT_TI_symbol_name("_ZN17Doppler_GapConfigaSERKS_") .dwattr $C$DW$24, DW_AT_type(*$C$DW$T$1244) .dwattr $C$DW$24, DW_AT_accessibility(DW_ACCESS_public) $C$DW$720 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$720, DW_AT_type(*$C$DW$T$1246) .dwendtag $C$DW$24 .dwendtag $C$DW$T$1248 .dwattr $C$DW$T$1248, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1248, DW_AT_decl_line(0x469) .dwattr $C$DW$T$1248, DW_AT_decl_column(0x01) $C$DW$T$1245 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1245, DW_AT_type(*$C$DW$T$1248) $C$DW$T$1246 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1246, DW_AT_type(*$C$DW$T$1245) .dwattr $C$DW$T$1246, DW_AT_address_class(0x20) $C$DW$T$1264 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_GapConfig") .dwattr $C$DW$T$1264, DW_AT_type(*$C$DW$T$1248) .dwattr $C$DW$T$1264, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1264, DW_AT_decl_line(0x473) .dwattr $C$DW$T$1264, DW_AT_decl_column(0x03) $C$DW$T$1265 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1265, DW_AT_type(*$C$DW$T$1264) .dwattr $C$DW$T$1265, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1265, DW_AT_byte_size(0x150) $C$DW$721 .dwtag DW_TAG_subrange_type .dwattr $C$DW$721, DW_AT_upper_bound(0x01) .dwendtag $C$DW$T$1265 $C$DW$T$1244 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1244, DW_AT_type(*$C$DW$T$1248) .dwattr $C$DW$T$1244, DW_AT_address_class(0x20) $C$DW$T$1247 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1247, DW_AT_type(*$C$DW$T$1244) .dwattr $C$DW$T$1247, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$722 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$722, DW_AT_type(*$C$DW$T$1246) .dwendtag $C$DW$T$1247 $C$DW$T$1254 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1254, DW_AT_name("Doppler_ImagingState") .dwattr $C$DW$T$1254, DW_AT_byte_size(0x0c) $C$DW$723 .dwtag DW_TAG_member .dwattr $C$DW$723, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$723, DW_AT_name("blankOn") .dwattr $C$DW$723, DW_AT_TI_symbol_name("blankOn") .dwattr $C$DW$723, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$723, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$723, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$723, DW_AT_decl_line(0x29) .dwattr $C$DW$723, DW_AT_decl_column(0x0a) $C$DW$724 .dwtag DW_TAG_member .dwattr $C$DW$724, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$724, DW_AT_name("wfUpdatePending") .dwattr $C$DW$724, DW_AT_TI_symbol_name("wfUpdatePending") .dwattr $C$DW$724, DW_AT_data_member_location[DW_OP_plus_uconst 0x2] .dwattr $C$DW$724, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$724, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$724, DW_AT_decl_line(0x2a) .dwattr $C$DW$724, DW_AT_decl_column(0x0a) $C$DW$725 .dwtag DW_TAG_member .dwattr $C$DW$725, DW_AT_type(*$C$DW$T$113) .dwattr $C$DW$725, DW_AT_name("wfPingPongRdIdx") .dwattr $C$DW$725, DW_AT_TI_symbol_name("wfPingPongRdIdx") .dwattr $C$DW$725, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$725, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$725, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$725, DW_AT_decl_line(0x2b) .dwattr $C$DW$725, DW_AT_decl_column(0x0c) $C$DW$726 .dwtag DW_TAG_member .dwattr $C$DW$726, DW_AT_type(*$C$DW$T$113) .dwattr $C$DW$726, DW_AT_name("wallFilterLength") .dwattr $C$DW$726, DW_AT_TI_symbol_name("wallFilterLength") .dwattr $C$DW$726, DW_AT_data_member_location[DW_OP_plus_uconst 0x6] .dwattr $C$DW$726, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$726, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$726, DW_AT_decl_line(0x2c) .dwattr $C$DW$726, DW_AT_decl_column(0x0c) $C$DW$727 .dwtag DW_TAG_member .dwattr $C$DW$727, DW_AT_type(*$C$DW$T$1249) .dwattr $C$DW$727, DW_AT_name("wallFilterCoefAddr") .dwattr $C$DW$727, DW_AT_TI_symbol_name("wallFilterCoefAddr") .dwattr $C$DW$727, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$727, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$727, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$727, DW_AT_decl_line(0x2d) .dwattr $C$DW$727, DW_AT_decl_column(0x0c) $C$DW$25 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$25, DW_AT_declaration .dwattr $C$DW$25, DW_AT_TI_symbol_name("_ZN20Doppler_ImagingStateaSERKS_") .dwattr $C$DW$25, DW_AT_type(*$C$DW$T$1250) .dwattr $C$DW$25, DW_AT_accessibility(DW_ACCESS_public) $C$DW$728 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$728, DW_AT_type(*$C$DW$T$1252) .dwendtag $C$DW$25 .dwendtag $C$DW$T$1254 .dwattr $C$DW$T$1254, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$T$1254, DW_AT_decl_line(0x28) .dwattr $C$DW$T$1254, DW_AT_decl_column(0x01) $C$DW$T$548 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_ImagingState") .dwattr $C$DW$T$548, DW_AT_type(*$C$DW$T$1254) .dwattr $C$DW$T$548, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$548, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Doppler/include/DopplerImagingState.h") .dwattr $C$DW$T$548, DW_AT_decl_line(0x2e) .dwattr $C$DW$T$548, DW_AT_decl_column(0x03) $C$DW$T$1251 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1251, DW_AT_type(*$C$DW$T$1254) $C$DW$T$1252 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1252, DW_AT_type(*$C$DW$T$1251) .dwattr $C$DW$T$1252, DW_AT_address_class(0x20) $C$DW$T$1250 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1250, DW_AT_type(*$C$DW$T$1254) .dwattr $C$DW$T$1250, DW_AT_address_class(0x20) $C$DW$T$1253 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1253, DW_AT_type(*$C$DW$T$1250) .dwattr $C$DW$T$1253, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$729 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$729, DW_AT_type(*$C$DW$T$1252) .dwendtag $C$DW$T$1253 $C$DW$T$1259 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1259, DW_AT_name("Doppler_LineInterleave") .dwattr $C$DW$T$1259, DW_AT_byte_size(0x48) $C$DW$730 .dwtag DW_TAG_member .dwattr $C$DW$730, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$730, DW_AT_name("pwsPerColorGroup") .dwattr $C$DW$730, DW_AT_TI_symbol_name("pwsPerColorGroup") .dwattr $C$DW$730, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$730, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$730, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$730, DW_AT_decl_line(0x45a) .dwattr $C$DW$730, DW_AT_decl_column(0x05) $C$DW$731 .dwtag DW_TAG_member .dwattr $C$DW$731, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$731, DW_AT_name("colorGroupCrossingDline") .dwattr $C$DW$731, DW_AT_TI_symbol_name("colorGroupCrossingDline") .dwattr $C$DW$731, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$731, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$731, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$731, DW_AT_decl_line(0x45b) .dwattr $C$DW$731, DW_AT_decl_column(0x05) $C$DW$732 .dwtag DW_TAG_member .dwattr $C$DW$732, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$732, DW_AT_name("colorGroupNextClosestToDline") .dwattr $C$DW$732, DW_AT_TI_symbol_name("colorGroupNextClosestToDline") .dwattr $C$DW$732, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$732, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$732, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$732, DW_AT_decl_line(0x45c) .dwattr $C$DW$732, DW_AT_decl_column(0x05) $C$DW$733 .dwtag DW_TAG_member .dwattr $C$DW$733, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$733, DW_AT_name("numClrGrpsToCorrect") .dwattr $C$DW$733, DW_AT_TI_symbol_name("numClrGrpsToCorrect") .dwattr $C$DW$733, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$733, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$733, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$733, DW_AT_decl_line(0x45d) .dwattr $C$DW$733, DW_AT_decl_column(0x05) $C$DW$734 .dwtag DW_TAG_member .dwattr $C$DW$734, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$734, DW_AT_name("totalColorGroups") .dwattr $C$DW$734, DW_AT_TI_symbol_name("totalColorGroups") .dwattr $C$DW$734, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$734, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$734, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$734, DW_AT_decl_line(0x45f) .dwattr $C$DW$734, DW_AT_decl_column(0x05) $C$DW$735 .dwtag DW_TAG_member .dwattr $C$DW$735, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$735, DW_AT_name("bmodeCrossingDline") .dwattr $C$DW$735, DW_AT_TI_symbol_name("bmodeCrossingDline") .dwattr $C$DW$735, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$735, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$735, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$735, DW_AT_decl_line(0x460) .dwattr $C$DW$735, DW_AT_decl_column(0x05) $C$DW$736 .dwtag DW_TAG_member .dwattr $C$DW$736, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$736, DW_AT_name("numPwSamplesPerBModeFrame") .dwattr $C$DW$736, DW_AT_TI_symbol_name("numPwSamplesPerBModeFrame") .dwattr $C$DW$736, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$736, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$736, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$736, DW_AT_decl_line(0x461) .dwattr $C$DW$736, DW_AT_decl_column(0x05) $C$DW$737 .dwtag DW_TAG_member .dwattr $C$DW$737, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$737, DW_AT_name("numPwSamplesAffectedByBmode") .dwattr $C$DW$737, DW_AT_TI_symbol_name("numPwSamplesAffectedByBmode") .dwattr $C$DW$737, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$737, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$737, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$737, DW_AT_decl_line(0x462) .dwattr $C$DW$737, DW_AT_decl_column(0x05) $C$DW$738 .dwtag DW_TAG_member .dwattr $C$DW$738, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$738, DW_AT_name("stdDerivativeThreshold") .dwattr $C$DW$738, DW_AT_TI_symbol_name("stdDerivativeThreshold") .dwattr $C$DW$738, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$738, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$738, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$738, DW_AT_decl_line(0x464) .dwattr $C$DW$738, DW_AT_decl_column(0x05) $C$DW$26 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$26, DW_AT_declaration .dwattr $C$DW$26, DW_AT_TI_symbol_name("_ZN22Doppler_LineInterleaveaSERKS_") .dwattr $C$DW$26, DW_AT_type(*$C$DW$T$1255) .dwattr $C$DW$26, DW_AT_accessibility(DW_ACCESS_public) $C$DW$739 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$739, DW_AT_type(*$C$DW$T$1257) .dwendtag $C$DW$26 .dwendtag $C$DW$T$1259 .dwattr $C$DW$T$1259, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1259, DW_AT_decl_line(0x459) .dwattr $C$DW$T$1259, DW_AT_decl_column(0x01) $C$DW$T$1256 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1256, DW_AT_type(*$C$DW$T$1259) $C$DW$T$1257 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1257, DW_AT_type(*$C$DW$T$1256) .dwattr $C$DW$T$1257, DW_AT_address_class(0x20) $C$DW$T$1266 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_LineInterleave") .dwattr $C$DW$T$1266, DW_AT_type(*$C$DW$T$1259) .dwattr $C$DW$T$1266, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1266, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1266, DW_AT_decl_line(0x465) .dwattr $C$DW$T$1266, DW_AT_decl_column(0x03) $C$DW$T$1255 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1255, DW_AT_type(*$C$DW$T$1259) .dwattr $C$DW$T$1255, DW_AT_address_class(0x20) $C$DW$T$1258 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1258, DW_AT_type(*$C$DW$T$1255) .dwattr $C$DW$T$1258, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$740 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$740, DW_AT_type(*$C$DW$T$1257) .dwendtag $C$DW$T$1258 $C$DW$T$1273 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1273, DW_AT_name("Doppler_Param") .dwattr $C$DW$T$1273, DW_AT_byte_size(0x360) $C$DW$741 .dwtag DW_TAG_member .dwattr $C$DW$741, DW_AT_type(*$C$DW$T$1261) .dwattr $C$DW$741, DW_AT_name("subMode") .dwattr $C$DW$741, DW_AT_TI_symbol_name("subMode") .dwattr $C$DW$741, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$741, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$741, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$741, DW_AT_decl_line(0x479) .dwattr $C$DW$741, DW_AT_decl_column(0x05) $C$DW$742 .dwtag DW_TAG_member .dwattr $C$DW$742, DW_AT_type(*$C$DW$T$134) .dwattr $C$DW$742, DW_AT_name("pResamplingFilterCoeffsBuf") .dwattr $C$DW$742, DW_AT_TI_symbol_name("pResamplingFilterCoeffsBuf") .dwattr $C$DW$742, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$742, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$742, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$742, DW_AT_decl_line(0x47b) .dwattr $C$DW$742, DW_AT_decl_column(0x05) $C$DW$743 .dwtag DW_TAG_member .dwattr $C$DW$743, DW_AT_type(*$C$DW$T$134) .dwattr $C$DW$743, DW_AT_name("pQbpCoeffsBuf") .dwattr $C$DW$743, DW_AT_TI_symbol_name("pQbpCoeffsBuf") .dwattr $C$DW$743, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$743, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$743, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$743, DW_AT_decl_line(0x47c) .dwattr $C$DW$743, DW_AT_decl_column(0x05) $C$DW$744 .dwtag DW_TAG_member .dwattr $C$DW$744, DW_AT_type(*$C$DW$T$134) .dwattr $C$DW$744, DW_AT_name("pWallFilterCoeffsBuf") .dwattr $C$DW$744, DW_AT_TI_symbol_name("pWallFilterCoeffsBuf") .dwattr $C$DW$744, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$744, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$744, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$744, DW_AT_decl_line(0x47e) .dwattr $C$DW$744, DW_AT_decl_column(0x05) $C$DW$745 .dwtag DW_TAG_member .dwattr $C$DW$745, DW_AT_type(*$C$DW$T$134) .dwattr $C$DW$745, DW_AT_name("pCompressionLUT") .dwattr $C$DW$745, DW_AT_TI_symbol_name("pCompressionLUT") .dwattr $C$DW$745, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$745, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$745, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$745, DW_AT_decl_line(0x47f) .dwattr $C$DW$745, DW_AT_decl_column(0x05) $C$DW$746 .dwtag DW_TAG_member .dwattr $C$DW$746, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$746, DW_AT_name("resamplingCoeffsBufSize") .dwattr $C$DW$746, DW_AT_TI_symbol_name("resamplingCoeffsBufSize") .dwattr $C$DW$746, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$746, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$746, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$746, DW_AT_decl_line(0x481) .dwattr $C$DW$746, DW_AT_decl_column(0x05) $C$DW$747 .dwtag DW_TAG_member .dwattr $C$DW$747, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$747, DW_AT_name("qbpCoeffsBufSize") .dwattr $C$DW$747, DW_AT_TI_symbol_name("qbpCoeffsBufSize") .dwattr $C$DW$747, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$747, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$747, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$747, DW_AT_decl_line(0x483) .dwattr $C$DW$747, DW_AT_decl_column(0x05) $C$DW$748 .dwtag DW_TAG_member .dwattr $C$DW$748, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$748, DW_AT_name("qbpFilterLen") .dwattr $C$DW$748, DW_AT_TI_symbol_name("qbpFilterLen") .dwattr $C$DW$748, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$748, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$748, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$748, DW_AT_decl_line(0x484) .dwattr $C$DW$748, DW_AT_decl_column(0x05) $C$DW$749 .dwtag DW_TAG_member .dwattr $C$DW$749, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$749, DW_AT_name("wallFitlerCoeffsBufSize") .dwattr $C$DW$749, DW_AT_TI_symbol_name("wallFitlerCoeffsBufSize") .dwattr $C$DW$749, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$749, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$749, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$749, DW_AT_decl_line(0x486) .dwattr $C$DW$749, DW_AT_decl_column(0x05) $C$DW$750 .dwtag DW_TAG_member .dwattr $C$DW$750, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$750, DW_AT_name("wallFilterLen") .dwattr $C$DW$750, DW_AT_TI_symbol_name("wallFilterLen") .dwattr $C$DW$750, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$750, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$750, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$750, DW_AT_decl_line(0x487) .dwattr $C$DW$750, DW_AT_decl_column(0x05) $C$DW$751 .dwtag DW_TAG_member .dwattr $C$DW$751, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$751, DW_AT_name("wallFilterGainExp") .dwattr $C$DW$751, DW_AT_TI_symbol_name("wallFilterGainExp") .dwattr $C$DW$751, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$751, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$751, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$751, DW_AT_decl_line(0x489) .dwattr $C$DW$751, DW_AT_decl_column(0x05) $C$DW$752 .dwtag DW_TAG_member .dwattr $C$DW$752, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$752, DW_AT_name("wallFilterGainMant") .dwattr $C$DW$752, DW_AT_TI_symbol_name("wallFilterGainMant") .dwattr $C$DW$752, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$752, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$752, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$752, DW_AT_decl_line(0x48a) .dwattr $C$DW$752, DW_AT_decl_column(0x05) $C$DW$753 .dwtag DW_TAG_member .dwattr $C$DW$753, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$753, DW_AT_name("usecsPerPri") .dwattr $C$DW$753, DW_AT_TI_symbol_name("usecsPerPri") .dwattr $C$DW$753, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$753, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$753, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$753, DW_AT_decl_line(0x48c) .dwattr $C$DW$753, DW_AT_decl_column(0x05) $C$DW$754 .dwtag DW_TAG_member .dwattr $C$DW$754, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$754, DW_AT_name("usecsPerFft") .dwattr $C$DW$754, DW_AT_TI_symbol_name("usecsPerFft") .dwattr $C$DW$754, DW_AT_data_member_location[DW_OP_plus_uconst 0x68] .dwattr $C$DW$754, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$754, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$754, DW_AT_decl_line(0x48d) .dwattr $C$DW$754, DW_AT_decl_column(0x05) $C$DW$755 .dwtag DW_TAG_member .dwattr $C$DW$755, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$755, DW_AT_name("fftsPerColumn") .dwattr $C$DW$755, DW_AT_TI_symbol_name("fftsPerColumn") .dwattr $C$DW$755, DW_AT_data_member_location[DW_OP_plus_uconst 0x70] .dwattr $C$DW$755, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$755, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$755, DW_AT_decl_line(0x48e) .dwattr $C$DW$755, DW_AT_decl_column(0x05) $C$DW$756 .dwtag DW_TAG_member .dwattr $C$DW$756, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$756, DW_AT_name("compressionLUTSize") .dwattr $C$DW$756, DW_AT_TI_symbol_name("compressionLUTSize") .dwattr $C$DW$756, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$756, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$756, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$756, DW_AT_decl_line(0x490) .dwattr $C$DW$756, DW_AT_decl_column(0x05) $C$DW$757 .dwtag DW_TAG_member .dwattr $C$DW$757, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$757, DW_AT_name("audioGain") .dwattr $C$DW$757, DW_AT_TI_symbol_name("audioGain") .dwattr $C$DW$757, DW_AT_data_member_location[DW_OP_plus_uconst 0x80] .dwattr $C$DW$757, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$757, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$757, DW_AT_decl_line(0x492) .dwattr $C$DW$757, DW_AT_decl_column(0x05) $C$DW$758 .dwtag DW_TAG_member .dwattr $C$DW$758, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$758, DW_AT_name("audioRampLen") .dwattr $C$DW$758, DW_AT_TI_symbol_name("audioRampLen") .dwattr $C$DW$758, DW_AT_data_member_location[DW_OP_plus_uconst 0x88] .dwattr $C$DW$758, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$758, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$758, DW_AT_decl_line(0x493) .dwattr $C$DW$758, DW_AT_decl_column(0x05) $C$DW$759 .dwtag DW_TAG_member .dwattr $C$DW$759, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$759, DW_AT_name("baselineIndex") .dwattr $C$DW$759, DW_AT_TI_symbol_name("baselineIndex") .dwattr $C$DW$759, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$759, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$759, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$759, DW_AT_decl_line(0x495) .dwattr $C$DW$759, DW_AT_decl_column(0x05) $C$DW$760 .dwtag DW_TAG_member .dwattr $C$DW$760, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$760, DW_AT_name("graphicsInvert") .dwattr $C$DW$760, DW_AT_TI_symbol_name("graphicsInvert") .dwattr $C$DW$760, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$760, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$760, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$760, DW_AT_decl_line(0x496) .dwattr $C$DW$760, DW_AT_decl_column(0x05) $C$DW$761 .dwtag DW_TAG_member .dwattr $C$DW$761, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$761, DW_AT_name("graphicsHeight") .dwattr $C$DW$761, DW_AT_TI_symbol_name("graphicsHeight") .dwattr $C$DW$761, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0] .dwattr $C$DW$761, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$761, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$761, DW_AT_decl_line(0x497) .dwattr $C$DW$761, DW_AT_decl_column(0x05) $C$DW$762 .dwtag DW_TAG_member .dwattr $C$DW$762, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$762, DW_AT_name("graphicsWidth") .dwattr $C$DW$762, DW_AT_TI_symbol_name("graphicsWidth") .dwattr $C$DW$762, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$762, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$762, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$762, DW_AT_decl_line(0x498) .dwattr $C$DW$762, DW_AT_decl_column(0x05) $C$DW$763 .dwtag DW_TAG_member .dwattr $C$DW$763, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$763, DW_AT_name("graphicsAlignDelay") .dwattr $C$DW$763, DW_AT_TI_symbol_name("graphicsAlignDelay") .dwattr $C$DW$763, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0] .dwattr $C$DW$763, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$763, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$763, DW_AT_decl_line(0x499) .dwattr $C$DW$763, DW_AT_decl_column(0x05) $C$DW$764 .dwtag DW_TAG_member .dwattr $C$DW$764, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$764, DW_AT_name("unused0") .dwattr $C$DW$764, DW_AT_TI_symbol_name("unused0") .dwattr $C$DW$764, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8] .dwattr $C$DW$764, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$764, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$764, DW_AT_decl_line(0x49b) .dwattr $C$DW$764, DW_AT_decl_column(0x05) $C$DW$765 .dwtag DW_TAG_member .dwattr $C$DW$765, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$765, DW_AT_name("unused1") .dwattr $C$DW$765, DW_AT_TI_symbol_name("unused1") .dwattr $C$DW$765, DW_AT_data_member_location[DW_OP_plus_uconst 0xc0] .dwattr $C$DW$765, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$765, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$765, DW_AT_decl_line(0x49c) .dwattr $C$DW$765, DW_AT_decl_column(0x05) $C$DW$766 .dwtag DW_TAG_member .dwattr $C$DW$766, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$766, DW_AT_name("unused2") .dwattr $C$DW$766, DW_AT_TI_symbol_name("unused2") .dwattr $C$DW$766, DW_AT_data_member_location[DW_OP_plus_uconst 0xc8] .dwattr $C$DW$766, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$766, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$766, DW_AT_decl_line(0x49d) .dwattr $C$DW$766, DW_AT_decl_column(0x05) $C$DW$767 .dwtag DW_TAG_member .dwattr $C$DW$767, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$767, DW_AT_name("unused3") .dwattr $C$DW$767, DW_AT_TI_symbol_name("unused3") .dwattr $C$DW$767, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0] .dwattr $C$DW$767, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$767, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$767, DW_AT_decl_line(0x49e) .dwattr $C$DW$767, DW_AT_decl_column(0x05) $C$DW$768 .dwtag DW_TAG_member .dwattr $C$DW$768, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$768, DW_AT_name("valveClickEnable") .dwattr $C$DW$768, DW_AT_TI_symbol_name("valveClickEnable") .dwattr $C$DW$768, DW_AT_data_member_location[DW_OP_plus_uconst 0xd8] .dwattr $C$DW$768, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$768, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$768, DW_AT_decl_line(0x4a0) .dwattr $C$DW$768, DW_AT_decl_column(0x05) $C$DW$769 .dwtag DW_TAG_member .dwattr $C$DW$769, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$769, DW_AT_name("peakMeanDirFlag") .dwattr $C$DW$769, DW_AT_TI_symbol_name("peakMeanDirFlag") .dwattr $C$DW$769, DW_AT_data_member_location[DW_OP_plus_uconst 0xe0] .dwattr $C$DW$769, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$769, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$769, DW_AT_decl_line(0x4a1) .dwattr $C$DW$769, DW_AT_decl_column(0x05) $C$DW$770 .dwtag DW_TAG_member .dwattr $C$DW$770, DW_AT_type(*$C$DW$T$134) .dwattr $C$DW$770, DW_AT_name("pHilbertCoeffsBuf") .dwattr $C$DW$770, DW_AT_TI_symbol_name("pHilbertCoeffsBuf") .dwattr $C$DW$770, DW_AT_data_member_location[DW_OP_plus_uconst 0xe8] .dwattr $C$DW$770, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$770, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$770, DW_AT_decl_line(0x4a3) .dwattr $C$DW$770, DW_AT_decl_column(0x05) $C$DW$771 .dwtag DW_TAG_member .dwattr $C$DW$771, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$771, DW_AT_name("fftWindowShift") .dwattr $C$DW$771, DW_AT_TI_symbol_name("fftWindowShift") .dwattr $C$DW$771, DW_AT_data_member_location[DW_OP_plus_uconst 0xf0] .dwattr $C$DW$771, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$771, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$771, DW_AT_decl_line(0x4a6) .dwattr $C$DW$771, DW_AT_decl_column(0x05) $C$DW$772 .dwtag DW_TAG_member .dwattr $C$DW$772, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$772, DW_AT_name("audioChanPolarity") .dwattr $C$DW$772, DW_AT_TI_symbol_name("audioChanPolarity") .dwattr $C$DW$772, DW_AT_data_member_location[DW_OP_plus_uconst 0xf8] .dwattr $C$DW$772, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$772, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$772, DW_AT_decl_line(0x4a8) .dwattr $C$DW$772, DW_AT_decl_column(0x05) $C$DW$773 .dwtag DW_TAG_member .dwattr $C$DW$773, DW_AT_type(*$C$DW$T$1263) .dwattr $C$DW$773, DW_AT_name("pkMnSelect") .dwattr $C$DW$773, DW_AT_TI_symbol_name("pkMnSelect") .dwattr $C$DW$773, DW_AT_data_member_location[DW_OP_plus_uconst 0x100] .dwattr $C$DW$773, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$773, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$773, DW_AT_decl_line(0x4a9) .dwattr $C$DW$773, DW_AT_decl_column(0x05) $C$DW$774 .dwtag DW_TAG_member .dwattr $C$DW$774, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$774, DW_AT_name("fftWindowLen") .dwattr $C$DW$774, DW_AT_TI_symbol_name("fftWindowLen") .dwattr $C$DW$774, DW_AT_data_member_location[DW_OP_plus_uconst 0x108] .dwattr $C$DW$774, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$774, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$774, DW_AT_decl_line(0x4aa) .dwattr $C$DW$774, DW_AT_decl_column(0x05) $C$DW$775 .dwtag DW_TAG_member .dwattr $C$DW$775, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$775, DW_AT_name("fftWindowLenMultQ16p16") .dwattr $C$DW$775, DW_AT_TI_symbol_name("fftWindowLenMultQ16p16") .dwattr $C$DW$775, DW_AT_data_member_location[DW_OP_plus_uconst 0x110] .dwattr $C$DW$775, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$775, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$775, DW_AT_decl_line(0x4ac) .dwattr $C$DW$775, DW_AT_decl_column(0x05) $C$DW$776 .dwtag DW_TAG_member .dwattr $C$DW$776, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$776, DW_AT_name("audioGainFloat") .dwattr $C$DW$776, DW_AT_TI_symbol_name("audioGainFloat") .dwattr $C$DW$776, DW_AT_data_member_location[DW_OP_plus_uconst 0x118] .dwattr $C$DW$776, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$776, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$776, DW_AT_decl_line(0x4ad) .dwattr $C$DW$776, DW_AT_decl_column(0x05) $C$DW$777 .dwtag DW_TAG_member .dwattr $C$DW$777, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$777, DW_AT_name("shifts") .dwattr $C$DW$777, DW_AT_TI_symbol_name("shifts") .dwattr $C$DW$777, DW_AT_data_member_location[DW_OP_plus_uconst 0x120] .dwattr $C$DW$777, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$777, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$777, DW_AT_decl_line(0x4ae) .dwattr $C$DW$777, DW_AT_decl_column(0x05) $C$DW$778 .dwtag DW_TAG_member .dwattr $C$DW$778, DW_AT_type(*$C$DW$T$1265) .dwattr $C$DW$778, DW_AT_name("gap") .dwattr $C$DW$778, DW_AT_TI_symbol_name("gap") .dwattr $C$DW$778, DW_AT_data_member_location[DW_OP_plus_uconst 0x128] .dwattr $C$DW$778, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$778, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$778, DW_AT_decl_line(0x4b5) .dwattr $C$DW$778, DW_AT_decl_column(0x05) $C$DW$779 .dwtag DW_TAG_member .dwattr $C$DW$779, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$779, DW_AT_name("gapNumSubBlockSamples") .dwattr $C$DW$779, DW_AT_TI_symbol_name("gapNumSubBlockSamples") .dwattr $C$DW$779, DW_AT_data_member_location[DW_OP_plus_uconst 0x278] .dwattr $C$DW$779, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$779, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$779, DW_AT_decl_line(0x4b6) .dwattr $C$DW$779, DW_AT_decl_column(0x05) $C$DW$780 .dwtag DW_TAG_member .dwattr $C$DW$780, DW_AT_type(*$C$DW$T$1266) .dwattr $C$DW$780, DW_AT_name("lineInterleave") .dwattr $C$DW$780, DW_AT_TI_symbol_name("lineInterleave") .dwattr $C$DW$780, DW_AT_data_member_location[DW_OP_plus_uconst 0x280] .dwattr $C$DW$780, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$780, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$780, DW_AT_decl_line(0x4bb) .dwattr $C$DW$780, DW_AT_decl_column(0x05) $C$DW$781 .dwtag DW_TAG_member .dwattr $C$DW$781, DW_AT_type(*$C$DW$T$1268) .dwattr $C$DW$781, DW_AT_name("simulMode") .dwattr $C$DW$781, DW_AT_TI_symbol_name("simulMode") .dwattr $C$DW$781, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c8] .dwattr $C$DW$781, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$781, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$781, DW_AT_decl_line(0x4bc) .dwattr $C$DW$781, DW_AT_decl_column(0x05) $C$DW$782 .dwtag DW_TAG_member .dwattr $C$DW$782, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$782, DW_AT_name("disableBudsAndBbp") .dwattr $C$DW$782, DW_AT_TI_symbol_name("disableBudsAndBbp") .dwattr $C$DW$782, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d0] .dwattr $C$DW$782, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$782, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$782, DW_AT_decl_line(0x4be) .dwattr $C$DW$782, DW_AT_decl_column(0x05) $C$DW$783 .dwtag DW_TAG_member .dwattr $C$DW$783, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$783, DW_AT_name("endOfData") .dwattr $C$DW$783, DW_AT_TI_symbol_name("endOfData") .dwattr $C$DW$783, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d8] .dwattr $C$DW$783, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$783, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$783, DW_AT_decl_line(0x4c0) .dwattr $C$DW$783, DW_AT_decl_column(0x05) $C$DW$784 .dwtag DW_TAG_member .dwattr $C$DW$784, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$784, DW_AT_name("reserved") .dwattr $C$DW$784, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$784, DW_AT_data_member_location[DW_OP_plus_uconst 0x2e0] .dwattr $C$DW$784, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$784, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$784, DW_AT_decl_line(0x4c2) .dwattr $C$DW$784, DW_AT_decl_column(0x05) $C$DW$27 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$27, DW_AT_declaration .dwattr $C$DW$27, DW_AT_TI_symbol_name("_ZN13Doppler_ParamaSERKS_") .dwattr $C$DW$27, DW_AT_type(*$C$DW$T$1269) .dwattr $C$DW$27, DW_AT_accessibility(DW_ACCESS_public) $C$DW$785 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$785, DW_AT_type(*$C$DW$T$1271) .dwendtag $C$DW$27 .dwendtag $C$DW$T$1273 .dwattr $C$DW$T$1273, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1273, DW_AT_decl_line(0x478) .dwattr $C$DW$T$1273, DW_AT_decl_column(0x01) $C$DW$T$1270 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1270, DW_AT_type(*$C$DW$T$1273) $C$DW$T$1271 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1271, DW_AT_type(*$C$DW$T$1270) .dwattr $C$DW$T$1271, DW_AT_address_class(0x20) $C$DW$T$2199 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_Param") .dwattr $C$DW$T$2199, DW_AT_type(*$C$DW$T$1273) .dwattr $C$DW$T$2199, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2199, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$2199, DW_AT_decl_line(0x4c3) .dwattr $C$DW$T$2199, DW_AT_decl_column(0x03) $C$DW$T$1269 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1269, DW_AT_type(*$C$DW$T$1273) .dwattr $C$DW$T$1269, DW_AT_address_class(0x20) $C$DW$T$1272 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1272, DW_AT_type(*$C$DW$T$1269) .dwattr $C$DW$T$1272, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$786 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$786, DW_AT_type(*$C$DW$T$1271) .dwendtag $C$DW$T$1272 $C$DW$T$1262 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1262, DW_AT_name("Doppler_PeakMeanType") .dwattr $C$DW$T$1262, DW_AT_byte_size(0x04) $C$DW$787 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_DRAW_MEAN"), DW_AT_const_value(0x00) .dwattr $C$DW$787, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$787, DW_AT_decl_line(0x177) .dwattr $C$DW$787, DW_AT_decl_column(0x05) $C$DW$788 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_DRAW_PEAK"), DW_AT_const_value(0x01) .dwattr $C$DW$788, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$788, DW_AT_decl_line(0x178) .dwattr $C$DW$788, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1262 .dwattr $C$DW$T$1262, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1262, DW_AT_decl_line(0x176) .dwattr $C$DW$T$1262, DW_AT_decl_column(0x01) $C$DW$T$1263 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_PeakMeanType") .dwattr $C$DW$T$1263, DW_AT_type(*$C$DW$T$1262) .dwattr $C$DW$T$1263, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1263, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1263, DW_AT_decl_line(0x179) .dwattr $C$DW$T$1263, DW_AT_decl_column(0x03) $C$DW$T$1267 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1267, DW_AT_name("Doppler_SimulMode") .dwattr $C$DW$T$1267, DW_AT_byte_size(0x04) $C$DW$789 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_NORMAL"), DW_AT_const_value(0x00) .dwattr $C$DW$789, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$789, DW_AT_decl_line(0x17d) .dwattr $C$DW$789, DW_AT_decl_column(0x05) $C$DW$790 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_LINE_INTERLEAVE"), DW_AT_const_value(0x01) .dwattr $C$DW$790, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$790, DW_AT_decl_line(0x17e) .dwattr $C$DW$790, DW_AT_decl_column(0x05) $C$DW$791 .dwtag DW_TAG_enumerator, DW_AT_name("DOPPLER_BLOCK_INTERLEAVE"), DW_AT_const_value(0x02) .dwattr $C$DW$791, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$791, DW_AT_decl_line(0x17f) .dwattr $C$DW$791, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1267 .dwattr $C$DW$T$1267, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1267, DW_AT_decl_line(0x17c) .dwattr $C$DW$T$1267, DW_AT_decl_column(0x01) $C$DW$T$1268 .dwtag DW_TAG_typedef, DW_AT_name("Doppler_SimulMode") .dwattr $C$DW$T$1268, DW_AT_type(*$C$DW$T$1267) .dwattr $C$DW$T$1268, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1268, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1268, DW_AT_decl_line(0x180) .dwattr $C$DW$T$1268, DW_AT_decl_column(0x03) $C$DW$T$1495 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1495, DW_AT_name("DspLoadInfo") .dwattr $C$DW$T$1495, DW_AT_byte_size(0xa0) $C$DW$792 .dwtag DW_TAG_member .dwattr $C$DW$792, DW_AT_type(*$C$DW$T$189) .dwattr $C$DW$792, DW_AT_name("coreLd") .dwattr $C$DW$792, DW_AT_TI_symbol_name("coreLd") .dwattr $C$DW$792, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$792, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$792, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$792, DW_AT_decl_line(0x5f4) .dwattr $C$DW$792, DW_AT_decl_column(0x05) $C$DW$793 .dwtag DW_TAG_member .dwattr $C$DW$793, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$793, DW_AT_name("reserved") .dwattr $C$DW$793, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$793, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$793, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$793, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$793, DW_AT_decl_line(0x5f5) .dwattr $C$DW$793, DW_AT_decl_column(0x05) $C$DW$28 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$28, DW_AT_declaration .dwattr $C$DW$28, DW_AT_TI_symbol_name("_ZN11DspLoadInfoaSERKS_") .dwattr $C$DW$28, DW_AT_type(*$C$DW$T$1491) .dwattr $C$DW$28, DW_AT_accessibility(DW_ACCESS_public) $C$DW$794 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$794, DW_AT_type(*$C$DW$T$1493) .dwendtag $C$DW$28 .dwendtag $C$DW$T$1495 .dwattr $C$DW$T$1495, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1495, DW_AT_decl_line(0x5f3) .dwattr $C$DW$T$1495, DW_AT_decl_column(0x01) $C$DW$T$1492 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1492, DW_AT_type(*$C$DW$T$1495) $C$DW$T$1493 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1493, DW_AT_type(*$C$DW$T$1492) .dwattr $C$DW$T$1493, DW_AT_address_class(0x20) $C$DW$T$2205 .dwtag DW_TAG_typedef, DW_AT_name("DspLoadInfo") .dwattr $C$DW$T$2205, DW_AT_type(*$C$DW$T$1495) .dwattr $C$DW$T$2205, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2205, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$2205, DW_AT_decl_line(0x5f6) .dwattr $C$DW$T$2205, DW_AT_decl_column(0x03) $C$DW$T$1491 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1491, DW_AT_type(*$C$DW$T$1495) .dwattr $C$DW$T$1491, DW_AT_address_class(0x20) $C$DW$T$1494 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1494, DW_AT_type(*$C$DW$T$1491) .dwattr $C$DW$T$1494, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$795 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$795, DW_AT_type(*$C$DW$T$1493) .dwendtag $C$DW$T$1494 $C$DW$T$586 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$586, DW_AT_name("Ecg_Param") .dwattr $C$DW$T$586, DW_AT_byte_size(0x138) $C$DW$796 .dwtag DW_TAG_member .dwattr $C$DW$796, DW_AT_type(*$C$DW$T$580) .dwattr $C$DW$796, DW_AT_name("subMode") .dwattr $C$DW$796, DW_AT_TI_symbol_name("subMode") .dwattr $C$DW$796, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$796, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$796, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$796, DW_AT_decl_line(0x503) .dwattr $C$DW$796, DW_AT_decl_column(0x05) $C$DW$797 .dwtag DW_TAG_member .dwattr $C$DW$797, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$797, DW_AT_name("graphicsHeight") .dwattr $C$DW$797, DW_AT_TI_symbol_name("graphicsHeight") .dwattr $C$DW$797, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$797, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$797, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$797, DW_AT_decl_line(0x506) .dwattr $C$DW$797, DW_AT_decl_column(0x05) $C$DW$798 .dwtag DW_TAG_member .dwattr $C$DW$798, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$798, DW_AT_name("graphicsWidth") .dwattr $C$DW$798, DW_AT_TI_symbol_name("graphicsWidth") .dwattr $C$DW$798, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$798, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$798, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$798, DW_AT_decl_line(0x508) .dwattr $C$DW$798, DW_AT_decl_column(0x05) $C$DW$799 .dwtag DW_TAG_member .dwattr $C$DW$799, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$799, DW_AT_name("decimationFactor") .dwattr $C$DW$799, DW_AT_TI_symbol_name("decimationFactor") .dwattr $C$DW$799, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$799, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$799, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$799, DW_AT_decl_line(0x509) .dwattr $C$DW$799, DW_AT_decl_column(0x05) $C$DW$800 .dwtag DW_TAG_member .dwattr $C$DW$800, DW_AT_type(*$C$DW$T$581) .dwattr $C$DW$800, DW_AT_name("ecgDelayParam") .dwattr $C$DW$800, DW_AT_TI_symbol_name("ecgDelayParam") .dwattr $C$DW$800, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$800, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$800, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$800, DW_AT_decl_line(0x50a) .dwattr $C$DW$800, DW_AT_decl_column(0x05) $C$DW$801 .dwtag DW_TAG_member .dwattr $C$DW$801, DW_AT_type(*$C$DW$T$167) .dwattr $C$DW$801, DW_AT_name("heartBeatsPerHREst") .dwattr $C$DW$801, DW_AT_TI_symbol_name("heartBeatsPerHREst") .dwattr $C$DW$801, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0] .dwattr $C$DW$801, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$801, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$801, DW_AT_decl_line(0x50b) .dwattr $C$DW$801, DW_AT_decl_column(0x05) $C$DW$802 .dwtag DW_TAG_member .dwattr $C$DW$802, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$802, DW_AT_name("reserved") .dwattr $C$DW$802, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$802, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8] .dwattr $C$DW$802, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$802, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$802, DW_AT_decl_line(0x50e) .dwattr $C$DW$802, DW_AT_decl_column(0x05) $C$DW$29 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$29, DW_AT_declaration .dwattr $C$DW$29, DW_AT_TI_symbol_name("_ZN9Ecg_ParamaSERKS_") .dwattr $C$DW$29, DW_AT_type(*$C$DW$T$582) .dwattr $C$DW$29, DW_AT_accessibility(DW_ACCESS_public) $C$DW$803 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$803, DW_AT_type(*$C$DW$T$584) .dwendtag $C$DW$29 .dwendtag $C$DW$T$586 .dwattr $C$DW$T$586, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$586, DW_AT_decl_line(0x501) .dwattr $C$DW$T$586, DW_AT_decl_column(0x01) $C$DW$T$583 .dwtag DW_TAG_const_type .dwattr $C$DW$T$583, DW_AT_type(*$C$DW$T$586) $C$DW$T$584 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$584, DW_AT_type(*$C$DW$T$583) .dwattr $C$DW$T$584, DW_AT_address_class(0x20) $C$DW$T$1932 .dwtag DW_TAG_typedef, DW_AT_name("Ecg_Param") .dwattr $C$DW$T$1932, DW_AT_type(*$C$DW$T$586) .dwattr $C$DW$T$1932, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1932, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1932, DW_AT_decl_line(0x50f) .dwattr $C$DW$T$1932, DW_AT_decl_column(0x03) $C$DW$T$582 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$582, DW_AT_type(*$C$DW$T$586) .dwattr $C$DW$T$582, DW_AT_address_class(0x20) $C$DW$T$585 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$585, DW_AT_type(*$C$DW$T$582) .dwattr $C$DW$T$585, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$804 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$804, DW_AT_type(*$C$DW$T$584) .dwendtag $C$DW$T$585 $C$DW$T$1463 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1463, DW_AT_name("ErrorMgr_AbortInfo") .dwattr $C$DW$T$1463, DW_AT_byte_size(0x220) $C$DW$805 .dwtag DW_TAG_member .dwattr $C$DW$805, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$805, DW_AT_name("code") .dwattr $C$DW$805, DW_AT_TI_symbol_name("code") .dwattr $C$DW$805, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$805, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$805, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$805, DW_AT_decl_line(0x20a) .dwattr $C$DW$805, DW_AT_decl_column(0x05) $C$DW$806 .dwtag DW_TAG_member .dwattr $C$DW$806, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$806, DW_AT_name("lineNum") .dwattr $C$DW$806, DW_AT_TI_symbol_name("lineNum") .dwattr $C$DW$806, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$806, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$806, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$806, DW_AT_decl_line(0x20b) .dwattr $C$DW$806, DW_AT_decl_column(0x05) $C$DW$807 .dwtag DW_TAG_member .dwattr $C$DW$807, DW_AT_type(*$C$DW$T$1458) .dwattr $C$DW$807, DW_AT_name("filename") .dwattr $C$DW$807, DW_AT_TI_symbol_name("filename") .dwattr $C$DW$807, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$807, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$807, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$807, DW_AT_decl_line(0x20c) .dwattr $C$DW$807, DW_AT_decl_column(0x05) $C$DW$808 .dwtag DW_TAG_member .dwattr $C$DW$808, DW_AT_type(*$C$DW$T$1458) .dwattr $C$DW$808, DW_AT_name("msg") .dwattr $C$DW$808, DW_AT_TI_symbol_name("msg") .dwattr $C$DW$808, DW_AT_data_member_location[DW_OP_plus_uconst 0xd8] .dwattr $C$DW$808, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$808, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$808, DW_AT_decl_line(0x20d) .dwattr $C$DW$808, DW_AT_decl_column(0x05) $C$DW$809 .dwtag DW_TAG_member .dwattr $C$DW$809, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$809, DW_AT_name("reserved") .dwattr $C$DW$809, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$809, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a0] .dwattr $C$DW$809, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$809, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$809, DW_AT_decl_line(0x20e) .dwattr $C$DW$809, DW_AT_decl_column(0x05) $C$DW$30 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$30, DW_AT_declaration .dwattr $C$DW$30, DW_AT_TI_symbol_name("_ZN18ErrorMgr_AbortInfoaSERKS_") .dwattr $C$DW$30, DW_AT_type(*$C$DW$T$1459) .dwattr $C$DW$30, DW_AT_accessibility(DW_ACCESS_public) $C$DW$810 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$810, DW_AT_type(*$C$DW$T$1461) .dwendtag $C$DW$30 .dwendtag $C$DW$T$1463 .dwattr $C$DW$T$1463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1463, DW_AT_decl_line(0x209) .dwattr $C$DW$T$1463, DW_AT_decl_column(0x10) $C$DW$T$1460 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1460, DW_AT_type(*$C$DW$T$1463) $C$DW$T$1461 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1461, DW_AT_type(*$C$DW$T$1460) .dwattr $C$DW$T$1461, DW_AT_address_class(0x20) $C$DW$T$2202 .dwtag DW_TAG_typedef, DW_AT_name("ErrorMgr_AbortInfo") .dwattr $C$DW$T$2202, DW_AT_type(*$C$DW$T$1463) .dwattr $C$DW$T$2202, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$2202, DW_AT_decl_line(0x20f) .dwattr $C$DW$T$2202, DW_AT_decl_column(0x03) $C$DW$T$1459 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1459, DW_AT_type(*$C$DW$T$1463) .dwattr $C$DW$T$1459, DW_AT_address_class(0x20) $C$DW$T$1462 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1462, DW_AT_type(*$C$DW$T$1459) .dwattr $C$DW$T$1462, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$811 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$811, DW_AT_type(*$C$DW$T$1461) .dwendtag $C$DW$T$1462 $C$DW$T$1468 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1468, DW_AT_name("ErrorMsg") .dwattr $C$DW$T$1468, DW_AT_byte_size(0x02) $C$DW$812 .dwtag DW_TAG_member .dwattr $C$DW$812, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$812, DW_AT_name("isFatalErr") .dwattr $C$DW$812, DW_AT_TI_symbol_name("isFatalErr") .dwattr $C$DW$812, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$812, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$812, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$812, DW_AT_decl_line(0xa0) .dwattr $C$DW$812, DW_AT_decl_column(0x19) $C$DW$31 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$31, DW_AT_declaration .dwattr $C$DW$31, DW_AT_TI_symbol_name("_ZN8ErrorMsgaSERKS_") .dwattr $C$DW$31, DW_AT_type(*$C$DW$T$1464) .dwattr $C$DW$31, DW_AT_accessibility(DW_ACCESS_public) $C$DW$813 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$813, DW_AT_type(*$C$DW$T$1466) .dwendtag $C$DW$31 .dwendtag $C$DW$T$1468 .dwattr $C$DW$T$1468, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1468, DW_AT_decl_line(0x9f) .dwattr $C$DW$T$1468, DW_AT_decl_column(0x01) $C$DW$T$1465 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1465, DW_AT_type(*$C$DW$T$1468) $C$DW$T$1466 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1466, DW_AT_type(*$C$DW$T$1465) .dwattr $C$DW$T$1466, DW_AT_address_class(0x20) $C$DW$T$1477 .dwtag DW_TAG_typedef, DW_AT_name("ErrorMsg") .dwattr $C$DW$T$1477, DW_AT_type(*$C$DW$T$1468) .dwattr $C$DW$T$1477, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1477, DW_AT_decl_line(0xa1) .dwattr $C$DW$T$1477, DW_AT_decl_column(0x03) $C$DW$T$1464 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1464, DW_AT_type(*$C$DW$T$1468) .dwattr $C$DW$T$1464, DW_AT_address_class(0x20) $C$DW$T$1467 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1467, DW_AT_type(*$C$DW$T$1464) .dwattr $C$DW$T$1467, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$814 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$814, DW_AT_type(*$C$DW$T$1466) .dwendtag $C$DW$T$1467 $C$DW$T$2203 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$2203, DW_AT_name("ErrorType") .dwattr $C$DW$T$2203, DW_AT_byte_size(0x04) $C$DW$815 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON"), DW_AT_const_value(0x100) .dwattr $C$DW$815, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$815, DW_AT_decl_line(0x24) .dwattr $C$DW$815, DW_AT_decl_column(0x05) $C$DW$816 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_NULLPTR"), DW_AT_const_value(0x101) .dwattr $C$DW$816, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$816, DW_AT_decl_line(0x25) .dwattr $C$DW$816, DW_AT_decl_column(0x05) $C$DW$817 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_BAD_INIT"), DW_AT_const_value(0x102) .dwattr $C$DW$817, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$817, DW_AT_decl_line(0x26) .dwattr $C$DW$817, DW_AT_decl_column(0x05) $C$DW$818 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_OVERFLOW"), DW_AT_const_value(0x103) .dwattr $C$DW$818, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$818, DW_AT_decl_line(0x27) .dwattr $C$DW$818, DW_AT_decl_column(0x05) $C$DW$819 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_UNDERFLOW"), DW_AT_const_value(0x104) .dwattr $C$DW$819, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$819, DW_AT_decl_line(0x28) .dwattr $C$DW$819, DW_AT_decl_column(0x05) $C$DW$820 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_UNKNOWN_CACHE_CMD"), DW_AT_const_value(0x105) .dwattr $C$DW$820, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$820, DW_AT_decl_line(0x29) .dwattr $C$DW$820, DW_AT_decl_column(0x05) $C$DW$821 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_ABORT"), DW_AT_const_value(0x106) .dwattr $C$DW$821, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$821, DW_AT_decl_line(0x2a) .dwattr $C$DW$821, DW_AT_decl_column(0x05) $C$DW$822 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_NUM_CORES"), DW_AT_const_value(0x107) .dwattr $C$DW$822, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$822, DW_AT_decl_line(0x2b) .dwattr $C$DW$822, DW_AT_decl_column(0x05) $C$DW$823 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FUNCTION_NOT_CORE_COMPATIBLE"), DW_AT_const_value(0x108) .dwattr $C$DW$823, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$823, DW_AT_decl_line(0x2c) .dwattr $C$DW$823, DW_AT_decl_column(0x05) $C$DW$824 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_CBUF_INVALID_OFFSET"), DW_AT_const_value(0x109) .dwattr $C$DW$824, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$824, DW_AT_decl_line(0x2d) .dwattr $C$DW$824, DW_AT_decl_column(0x05) $C$DW$825 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_INVALID_FIR_PARAM"), DW_AT_const_value(0x10a) .dwattr $C$DW$825, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$825, DW_AT_decl_line(0x2e) .dwattr $C$DW$825, DW_AT_decl_column(0x05) $C$DW$826 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_RTOS_ERR_RAISE_HOOK"), DW_AT_const_value(0x10b) .dwattr $C$DW$826, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$826, DW_AT_decl_line(0x2f) .dwattr $C$DW$826, DW_AT_decl_column(0x05) $C$DW$827 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP"), DW_AT_const_value(0x200) .dwattr $C$DW$827, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$827, DW_AT_decl_line(0x31) .dwattr $C$DW$827, DW_AT_decl_column(0x05) $C$DW$828 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CREATE_ERR"), DW_AT_const_value(0x201) .dwattr $C$DW$828, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$828, DW_AT_decl_line(0x32) .dwattr $C$DW$828, DW_AT_decl_column(0x05) $C$DW$829 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_DDR_ERR"), DW_AT_const_value(0x202) .dwattr $C$DW$829, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$829, DW_AT_decl_line(0x33) .dwattr $C$DW$829, DW_AT_decl_column(0x05) $C$DW$830 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_LL2_ERR"), DW_AT_const_value(0x203) .dwattr $C$DW$830, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$830, DW_AT_decl_line(0x34) .dwattr $C$DW$830, DW_AT_decl_column(0x05) $C$DW$831 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_SL2_ERR"), DW_AT_const_value(0x204) .dwattr $C$DW$831, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$831, DW_AT_decl_line(0x35) .dwattr $C$DW$831, DW_AT_decl_column(0x05) $C$DW$832 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_DDR_NONCACHED_ERR"), DW_AT_const_value(0x205) .dwattr $C$DW$832, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$832, DW_AT_decl_line(0x36) .dwattr $C$DW$832, DW_AT_decl_column(0x05) $C$DW$833 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBDDR_ERR"), DW_AT_const_value(0x206) .dwattr $C$DW$833, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$833, DW_AT_decl_line(0x37) .dwattr $C$DW$833, DW_AT_decl_column(0x05) $C$DW$834 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBDDR_1_ERR"), DW_AT_const_value(0x207) .dwattr $C$DW$834, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$834, DW_AT_decl_line(0x38) .dwattr $C$DW$834, DW_AT_decl_column(0x05) $C$DW$835 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBDDR_2_ERR"), DW_AT_const_value(0x208) .dwattr $C$DW$835, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$835, DW_AT_decl_line(0x39) .dwattr $C$DW$835, DW_AT_decl_column(0x05) $C$DW$836 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBLL2_ERR"), DW_AT_const_value(0x209) .dwattr $C$DW$836, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$836, DW_AT_decl_line(0x3a) .dwattr $C$DW$836, DW_AT_decl_column(0x05) $C$DW$837 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBSL2_ERR"), DW_AT_const_value(0x20a) .dwattr $C$DW$837, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$837, DW_AT_decl_line(0x3b) .dwattr $C$DW$837, DW_AT_decl_column(0x05) $C$DW$838 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBSL2_1_ERR"), DW_AT_const_value(0x20b) .dwattr $C$DW$838, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$838, DW_AT_decl_line(0x3c) .dwattr $C$DW$838, DW_AT_decl_column(0x05) $C$DW$839 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBSL2_2_ERR"), DW_AT_const_value(0x20c) .dwattr $C$DW$839, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$839, DW_AT_decl_line(0x3d) .dwattr $C$DW$839, DW_AT_decl_column(0x05) $C$DW$840 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBFOV1_ERR"), DW_AT_const_value(0x20d) .dwattr $C$DW$840, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$840, DW_AT_decl_line(0x3e) .dwattr $C$DW$840, DW_AT_decl_column(0x05) $C$DW$841 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_ALLOC_CBFOV2_ERR"), DW_AT_const_value(0x20e) .dwattr $C$DW$841, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$841, DW_AT_decl_line(0x3f) .dwattr $C$DW$841, DW_AT_decl_column(0x05) $C$DW$842 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_MEM_SEL_ERR"), DW_AT_const_value(0x20f) .dwattr $C$DW$842, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$842, DW_AT_decl_line(0x40) .dwattr $C$DW$842, DW_AT_decl_column(0x05) $C$DW$843 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DDR_HEAP_BASE_TOO_LOW"), DW_AT_const_value(0x210) .dwattr $C$DW$843, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$843, DW_AT_decl_line(0x41) .dwattr $C$DW$843, DW_AT_decl_column(0x05) $C$DW$844 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_DDR_LEAK_ERR"), DW_AT_const_value(0x211) .dwattr $C$DW$844, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$844, DW_AT_decl_line(0x42) .dwattr $C$DW$844, DW_AT_decl_column(0x05) $C$DW$845 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CINE_FOV1_LEAK_ERR"), DW_AT_const_value(0x212) .dwattr $C$DW$845, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$845, DW_AT_decl_line(0x43) .dwattr $C$DW$845, DW_AT_decl_column(0x05) $C$DW$846 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CINE_FOV2_LEAK_ERR"), DW_AT_const_value(0x213) .dwattr $C$DW$846, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$846, DW_AT_decl_line(0x44) .dwattr $C$DW$846, DW_AT_decl_column(0x05) $C$DW$847 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_SL2_LEAK_ERR"), DW_AT_const_value(0x214) .dwattr $C$DW$847, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$847, DW_AT_decl_line(0x45) .dwattr $C$DW$847, DW_AT_decl_column(0x05) $C$DW$848 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_HEAP_CORE0_LL2_LEAK_ERR"), DW_AT_const_value(0x215) .dwattr $C$DW$848, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$848, DW_AT_decl_line(0x46) .dwattr $C$DW$848, DW_AT_decl_column(0x05) $C$DW$849 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_EDMA"), DW_AT_const_value(0x300) .dwattr $C$DW$849, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$849, DW_AT_decl_line(0x48) .dwattr $C$DW$849, DW_AT_decl_column(0x05) $C$DW$850 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_EDMA_BCNT_TOO_LARGE"), DW_AT_const_value(0x301) .dwattr $C$DW$850, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$850, DW_AT_decl_line(0x49) .dwattr $C$DW$850, DW_AT_decl_column(0x05) $C$DW$851 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_EDMA_INVALID_IDX"), DW_AT_const_value(0x302) .dwattr $C$DW$851, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$851, DW_AT_decl_line(0x4a) .dwattr $C$DW$851, DW_AT_decl_column(0x05) $C$DW$852 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO"), DW_AT_const_value(0x400) .dwattr $C$DW$852, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$852, DW_AT_decl_line(0x4c) .dwattr $C$DW$852, DW_AT_decl_column(0x05) $C$DW$853 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_SIZE"), DW_AT_const_value(0x401) .dwattr $C$DW$853, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$853, DW_AT_decl_line(0x4d) .dwattr $C$DW$853, DW_AT_decl_column(0x05) $C$DW$854 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_CREATE"), DW_AT_const_value(0x402) .dwattr $C$DW$854, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$854, DW_AT_decl_line(0x4e) .dwattr $C$DW$854, DW_AT_decl_column(0x05) $C$DW$855 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_DEQ_ERR"), DW_AT_const_value(0x403) .dwattr $C$DW$855, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$855, DW_AT_decl_line(0x4f) .dwattr $C$DW$855, DW_AT_decl_column(0x05) $C$DW$856 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_ENQ_ERR"), DW_AT_const_value(0x404) .dwattr $C$DW$856, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$856, DW_AT_decl_line(0x50) .dwattr $C$DW$856, DW_AT_decl_column(0x05) $C$DW$857 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_FIFO_ITEM_CNT_ERR"), DW_AT_const_value(0x405) .dwattr $C$DW$857, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$857, DW_AT_decl_line(0x51) .dwattr $C$DW$857, DW_AT_decl_column(0x05) $C$DW$858 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DB"), DW_AT_const_value(0x500) .dwattr $C$DW$858, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$858, DW_AT_decl_line(0x53) .dwattr $C$DW$858, DW_AT_decl_column(0x05) $C$DW$859 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DB_SEMAPHORE_CREATE_ERR"), DW_AT_const_value(0x501) .dwattr $C$DW$859, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$859, DW_AT_decl_line(0x54) .dwattr $C$DW$859, DW_AT_decl_column(0x05) $C$DW$860 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMMON_DB_SEMAPHORE_PEND_ERR"), DW_AT_const_value(0x502) .dwattr $C$DW$860, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$860, DW_AT_decl_line(0x55) .dwattr $C$DW$860, DW_AT_decl_column(0x05) $C$DW$861 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_REGULATOR"), DW_AT_const_value(0x600) .dwattr $C$DW$861, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$861, DW_AT_decl_line(0x57) .dwattr $C$DW$861, DW_AT_decl_column(0x05) $C$DW$862 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_REGULATOR_OVERFLOW"), DW_AT_const_value(0x601) .dwattr $C$DW$862, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$862, DW_AT_decl_line(0x58) .dwattr $C$DW$862, DW_AT_decl_column(0x05) $C$DW$863 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_REGULATOR_UNDERFLOW"), DW_AT_const_value(0x602) .dwattr $C$DW$863, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$863, DW_AT_decl_line(0x59) .dwattr $C$DW$863, DW_AT_decl_column(0x05) $C$DW$864 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY"), DW_AT_const_value(0x700) .dwattr $C$DW$864, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$864, DW_AT_decl_line(0x5b) .dwattr $C$DW$864, DW_AT_decl_column(0x05) $C$DW$865 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_CAN_HAVE_ONLY_ONE_WRITER"), DW_AT_const_value(0x701) .dwattr $C$DW$865, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$865, DW_AT_decl_line(0x5c) .dwattr $C$DW$865, DW_AT_decl_column(0x05) $C$DW$866 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_TABLE_SIZE_NOT_POWER_OF_TWO"), DW_AT_const_value(0x702) .dwattr $C$DW$866, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$866, DW_AT_decl_line(0x5d) .dwattr $C$DW$866, DW_AT_decl_column(0x05) $C$DW$867 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_TABLE_ALREADY_ALLOCATED"), DW_AT_const_value(0x703) .dwattr $C$DW$867, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$867, DW_AT_decl_line(0x5e) .dwattr $C$DW$867, DW_AT_decl_column(0x05) $C$DW$868 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_NOT_INITIALIZED"), DW_AT_const_value(0x704) .dwattr $C$DW$868, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$868, DW_AT_decl_line(0x5f) .dwattr $C$DW$868, DW_AT_decl_column(0x05) $C$DW$869 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COMPONENT_FRAME_ID_HISTORY_MUST_INSTANTIATE_FROM_TASK"), DW_AT_const_value(0x705) .dwattr $C$DW$869, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$869, DW_AT_decl_line(0x60) .dwattr $C$DW$869, DW_AT_decl_column(0x05) $C$DW$870 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR"), DW_AT_const_value(0x1000) .dwattr $C$DW$870, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$870, DW_AT_decl_line(0x62) .dwattr $C$DW$870, DW_AT_decl_column(0x05) $C$DW$871 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PERIPH_INIT_ERR"), DW_AT_const_value(0x1001) .dwattr $C$DW$871, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$871, DW_AT_decl_line(0x63) .dwattr $C$DW$871, DW_AT_decl_column(0x05) $C$DW$872 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_INIT_ERR"), DW_AT_const_value(0x1002) .dwattr $C$DW$872, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$872, DW_AT_decl_line(0x64) .dwattr $C$DW$872, DW_AT_decl_column(0x05) $C$DW$873 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_DOORBELL_ERR"), DW_AT_const_value(0x1003) .dwattr $C$DW$873, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$873, DW_AT_decl_line(0x65) .dwattr $C$DW$873, DW_AT_decl_column(0x05) $C$DW$874 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_UNREGISTERED_DOORBELL_ERR"), DW_AT_const_value(0x1004) .dwattr $C$DW$874, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$874, DW_AT_decl_line(0x66) .dwattr $C$DW$874, DW_AT_decl_column(0x05) $C$DW$875 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_GPIO_ERR"), DW_AT_const_value(0x1005) .dwattr $C$DW$875, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$875, DW_AT_decl_line(0x67) .dwattr $C$DW$875, DW_AT_decl_column(0x05) $C$DW$876 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_ERROR_DOORBELL_SWI_NOT_CREATED"), DW_AT_const_value(0x1006) .dwattr $C$DW$876, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$876, DW_AT_decl_line(0x68) .dwattr $C$DW$876, DW_AT_decl_column(0x05) $C$DW$877 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_NULL_NOTIFY_FXN"), DW_AT_const_value(0x1007) .dwattr $C$DW$877, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$877, DW_AT_decl_line(0x69) .dwattr $C$DW$877, DW_AT_decl_column(0x05) $C$DW$878 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLC"), DW_AT_const_value(0x2000) .dwattr $C$DW$878, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$878, DW_AT_decl_line(0x6b) .dwattr $C$DW$878, DW_AT_decl_column(0x05) $C$DW$879 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLC_INIT"), DW_AT_const_value(0x2001) .dwattr $C$DW$879, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$879, DW_AT_decl_line(0x6c) .dwattr $C$DW$879, DW_AT_decl_column(0x05) $C$DW$880 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLC_OPEN"), DW_AT_const_value(0x2002) .dwattr $C$DW$880, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$880, DW_AT_decl_line(0x6d) .dwattr $C$DW$880, DW_AT_decl_column(0x05) $C$DW$881 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLCHWSETUP"), DW_AT_const_value(0x2003) .dwattr $C$DW$881, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$881, DW_AT_decl_line(0x6e) .dwattr $C$DW$881, DW_AT_decl_column(0x05) $C$DW$882 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLCHWCONTROL"), DW_AT_const_value(0x2004) .dwattr $C$DW$882, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$882, DW_AT_decl_line(0x6f) .dwattr $C$DW$882, DW_AT_decl_column(0x05) $C$DW$883 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PLLCGETHWSTATUS"), DW_AT_const_value(0x2005) .dwattr $C$DW$883, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$883, DW_AT_decl_line(0x70) .dwattr $C$DW$883, DW_AT_decl_column(0x05) $C$DW$884 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_HPI"), DW_AT_const_value(0x3000) .dwattr $C$DW$884, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$884, DW_AT_decl_line(0x72) .dwattr $C$DW$884, DW_AT_decl_column(0x05) $C$DW$885 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_HPIINIT"), DW_AT_const_value(0x3001) .dwattr $C$DW$885, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$885, DW_AT_decl_line(0x73) .dwattr $C$DW$885, DW_AT_decl_column(0x05) $C$DW$886 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_HPIOPEN"), DW_AT_const_value(0x3002) .dwattr $C$DW$886, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$886, DW_AT_decl_line(0x74) .dwattr $C$DW$886, DW_AT_decl_column(0x05) $C$DW$887 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2"), DW_AT_const_value(0x4000) .dwattr $C$DW$887, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$887, DW_AT_decl_line(0x76) .dwattr $C$DW$887, DW_AT_decl_column(0x05) $C$DW$888 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2_INIT"), DW_AT_const_value(0x4001) .dwattr $C$DW$888, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$888, DW_AT_decl_line(0x77) .dwattr $C$DW$888, DW_AT_decl_column(0x05) $C$DW$889 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2_OPEN"), DW_AT_const_value(0x4002) .dwattr $C$DW$889, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$889, DW_AT_decl_line(0x78) .dwattr $C$DW$889, DW_AT_decl_column(0x05) $C$DW$890 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_DDR2_HWSETUP"), DW_AT_const_value(0x4003) .dwattr $C$DW$890, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$890, DW_AT_decl_line(0x79) .dwattr $C$DW$890, DW_AT_decl_column(0x05) $C$DW$891 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP"), DW_AT_const_value(0x4100) .dwattr $C$DW$891, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$891, DW_AT_decl_line(0x7b) .dwattr $C$DW$891, DW_AT_decl_column(0x05) $C$DW$892 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP_INIT"), DW_AT_const_value(0x4101) .dwattr $C$DW$892, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$892, DW_AT_decl_line(0x7c) .dwattr $C$DW$892, DW_AT_decl_column(0x05) $C$DW$893 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP_OPEN"), DW_AT_const_value(0x4102) .dwattr $C$DW$893, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$893, DW_AT_decl_line(0x7d) .dwattr $C$DW$893, DW_AT_decl_column(0x05) $C$DW$894 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP0_ENB"), DW_AT_const_value(0x4103) .dwattr $C$DW$894, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$894, DW_AT_decl_line(0x7e) .dwattr $C$DW$894, DW_AT_decl_column(0x05) $C$DW$895 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_MCBSP0_DIS"), DW_AT_const_value(0x4104) .dwattr $C$DW$895, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$895, DW_AT_decl_line(0x7f) .dwattr $C$DW$895, DW_AT_decl_column(0x05) $C$DW$896 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3"), DW_AT_const_value(0x4200) .dwattr $C$DW$896, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$896, DW_AT_decl_line(0x81) .dwattr $C$DW$896, DW_AT_decl_column(0x05) $C$DW$897 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_INIT"), DW_AT_const_value(0x4201) .dwattr $C$DW$897, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$897, DW_AT_decl_line(0x82) .dwattr $C$DW$897, DW_AT_decl_column(0x05) $C$DW$898 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_OPEN"), DW_AT_const_value(0x4202) .dwattr $C$DW$898, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$898, DW_AT_decl_line(0x83) .dwattr $C$DW$898, DW_AT_decl_column(0x05) $C$DW$899 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_HWSETUP"), DW_AT_const_value(0x4203) .dwattr $C$DW$899, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$899, DW_AT_decl_line(0x84) .dwattr $C$DW$899, DW_AT_decl_column(0x05) $C$DW$900 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CW_OPEN"), DW_AT_const_value(0x4204) .dwattr $C$DW$900, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$900, DW_AT_decl_line(0x85) .dwattr $C$DW$900, DW_AT_decl_column(0x05) $C$DW$901 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_AUDIO_OPEN"), DW_AT_const_value(0x4205) .dwattr $C$DW$901, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$901, DW_AT_decl_line(0x86) .dwattr $C$DW$901, DW_AT_decl_column(0x05) $C$DW$902 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_INSTANCE_INIT"), DW_AT_const_value(0x4206) .dwattr $C$DW$902, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$902, DW_AT_decl_line(0x87) .dwattr $C$DW$902, DW_AT_decl_column(0x05) $C$DW$903 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_INTERRUPT_ENABLE"), DW_AT_const_value(0x4207) .dwattr $C$DW$903, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$903, DW_AT_decl_line(0x88) .dwattr $C$DW$903, DW_AT_decl_column(0x05) $C$DW$904 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CREATE_SHADOW_REGION"), DW_AT_const_value(0x4208) .dwattr $C$DW$904, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$904, DW_AT_decl_line(0x89) .dwattr $C$DW$904, DW_AT_decl_column(0x05) $C$DW$905 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_UNOPENED_CHANNEL"), DW_AT_const_value(0x4209) .dwattr $C$DW$905, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$905, DW_AT_decl_line(0x8a) .dwattr $C$DW$905, DW_AT_decl_column(0x05) $C$DW$906 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CHAN_IN_USE"), DW_AT_const_value(0x420a) .dwattr $C$DW$906, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$906, DW_AT_decl_line(0x8b) .dwattr $C$DW$906, DW_AT_decl_column(0x05) $C$DW$907 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_OUT_OF_PHY_CHAN"), DW_AT_const_value(0x420b) .dwattr $C$DW$907, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$907, DW_AT_decl_line(0x8c) .dwattr $C$DW$907, DW_AT_decl_column(0x05) $C$DW$908 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_EXCEEDED_MAX_PHY_CHAN"), DW_AT_const_value(0x420c) .dwattr $C$DW$908, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$908, DW_AT_decl_line(0x8d) .dwattr $C$DW$908, DW_AT_decl_column(0x05) $C$DW$909 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_OUT_OF_LINK_PARAMS"), DW_AT_const_value(0x420d) .dwattr $C$DW$909, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$909, DW_AT_decl_line(0x8e) .dwattr $C$DW$909, DW_AT_decl_column(0x05) $C$DW$910 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_SETUP_FAILURE"), DW_AT_const_value(0x420e) .dwattr $C$DW$910, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$910, DW_AT_decl_line(0x8f) .dwattr $C$DW$910, DW_AT_decl_column(0x05) $C$DW$911 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_TIMER"), DW_AT_const_value(0x4300) .dwattr $C$DW$911, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$911, DW_AT_decl_line(0x91) .dwattr $C$DW$911, DW_AT_decl_column(0x05) $C$DW$912 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_TIMER_ERR"), DW_AT_const_value(0x4301) .dwattr $C$DW$912, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$912, DW_AT_decl_line(0x92) .dwattr $C$DW$912, DW_AT_decl_column(0x05) $C$DW$913 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO"), DW_AT_const_value(0x4400) .dwattr $C$DW$913, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$913, DW_AT_decl_line(0x94) .dwattr $C$DW$913, DW_AT_decl_column(0x05) $C$DW$914 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_PORT_ERR"), DW_AT_const_value(0x4401) .dwattr $C$DW$914, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$914, DW_AT_decl_line(0x95) .dwattr $C$DW$914, DW_AT_decl_column(0x05) $C$DW$915 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_LSU_ERR"), DW_AT_const_value(0x4402) .dwattr $C$DW$915, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$915, DW_AT_decl_line(0x96) .dwattr $C$DW$915, DW_AT_decl_column(0x05) $C$DW$916 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_SETUP_ERR"), DW_AT_const_value(0x4403) .dwattr $C$DW$916, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$916, DW_AT_decl_line(0x97) .dwattr $C$DW$916, DW_AT_decl_column(0x05) $C$DW$917 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_INV_CONF_ERR"), DW_AT_const_value(0x4404) .dwattr $C$DW$917, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$917, DW_AT_decl_line(0x98) .dwattr $C$DW$917, DW_AT_decl_column(0x05) $C$DW$918 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_PSC_ERR"), DW_AT_const_value(0x4405) .dwattr $C$DW$918, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$918, DW_AT_decl_line(0x99) .dwattr $C$DW$918, DW_AT_decl_column(0x05) $C$DW$919 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_TIMEOUT_ERR"), DW_AT_const_value(0x4406) .dwattr $C$DW$919, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$919, DW_AT_decl_line(0x9a) .dwattr $C$DW$919, DW_AT_decl_column(0x05) $C$DW$920 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_INV_SIZE_ERR"), DW_AT_const_value(0x4407) .dwattr $C$DW$920, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$920, DW_AT_decl_line(0x9b) .dwattr $C$DW$920, DW_AT_decl_column(0x05) $C$DW$921 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_LSU_BSY_ERR"), DW_AT_const_value(0x4408) .dwattr $C$DW$921, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$921, DW_AT_decl_line(0x9c) .dwattr $C$DW$921, DW_AT_decl_column(0x05) $C$DW$922 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_RST_TIMEOUT"), DW_AT_const_value(0x4409) .dwattr $C$DW$922, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$922, DW_AT_decl_line(0x9d) .dwattr $C$DW$922, DW_AT_decl_column(0x05) $C$DW$923 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_ASYNC_SIZE_ERR"), DW_AT_const_value(0x440a) .dwattr $C$DW$923, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$923, DW_AT_decl_line(0x9e) .dwattr $C$DW$923, DW_AT_decl_column(0x05) $C$DW$924 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_CLOSE_ERR"), DW_AT_const_value(0x440b) .dwattr $C$DW$924, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$924, DW_AT_decl_line(0x9f) .dwattr $C$DW$924, DW_AT_decl_column(0x05) $C$DW$925 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_OPEN_ERR"), DW_AT_const_value(0x440c) .dwattr $C$DW$925, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$925, DW_AT_decl_line(0xa0) .dwattr $C$DW$925, DW_AT_decl_column(0x05) $C$DW$926 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_MULTIPLE_DOORBELL_INTERRUPT"), DW_AT_const_value(0x440d) .dwattr $C$DW$926, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$926, DW_AT_decl_line(0xa1) .dwattr $C$DW$926, DW_AT_decl_column(0x05) $C$DW$927 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_UNKNOWN"), DW_AT_const_value(0x4500) .dwattr $C$DW$927, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$927, DW_AT_decl_line(0xa3) .dwattr $C$DW$927, DW_AT_decl_column(0x05) $C$DW$928 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_NONFATAL"), DW_AT_const_value(0x4501) .dwattr $C$DW$928, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$928, DW_AT_decl_line(0xa4) .dwattr $C$DW$928, DW_AT_decl_column(0x05) $C$DW$929 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_FATAL"), DW_AT_const_value(0x4502) .dwattr $C$DW$929, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$929, DW_AT_decl_line(0xa5) .dwattr $C$DW$929, DW_AT_decl_column(0x05) $C$DW$930 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_DATA"), DW_AT_const_value(0x4503) .dwattr $C$DW$930, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$930, DW_AT_decl_line(0xa6) .dwattr $C$DW$930, DW_AT_decl_column(0x05) $C$DW$931 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SRIO_COM_RE_INIT"), DW_AT_const_value(0x4504) .dwattr $C$DW$931, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$931, DW_AT_decl_line(0xa7) .dwattr $C$DW$931, DW_AT_decl_column(0x05) $C$DW$932 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL"), DW_AT_const_value(0x4600) .dwattr $C$DW$932, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$932, DW_AT_decl_line(0xa9) .dwattr $C$DW$932, DW_AT_decl_column(0x05) $C$DW$933 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_BUFADDR_NOT_ALIGNED"), DW_AT_const_value(0x4601) .dwattr $C$DW$933, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$933, DW_AT_decl_line(0xaa) .dwattr $C$DW$933, DW_AT_decl_column(0x05) $C$DW$934 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_BUFSIZE_NOT_ALIGNED"), DW_AT_const_value(0x4602) .dwattr $C$DW$934, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$934, DW_AT_decl_line(0xab) .dwattr $C$DW$934, DW_AT_decl_column(0x05) $C$DW$935 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_BUFBLKSIZE_NOT_ALIGNED"), DW_AT_const_value(0x4603) .dwattr $C$DW$935, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$935, DW_AT_decl_line(0xac) .dwattr $C$DW$935, DW_AT_decl_column(0x05) $C$DW$936 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_DBELLINTVL_NOT_ALIGNED"), DW_AT_const_value(0x4604) .dwattr $C$DW$936, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$936, DW_AT_decl_line(0xad) .dwattr $C$DW$936, DW_AT_decl_column(0x05) $C$DW$937 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_TOO_MANY_BLOCKS"), DW_AT_const_value(0x4605) .dwattr $C$DW$937, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$937, DW_AT_decl_line(0xae) .dwattr $C$DW$937, DW_AT_decl_column(0x05) $C$DW$938 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_INVALID_SPB_SPECIFIER"), DW_AT_const_value(0x4606) .dwattr $C$DW$938, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$938, DW_AT_decl_line(0xaf) .dwattr $C$DW$938, DW_AT_decl_column(0x05) $C$DW$939 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_UNSUPPORTED_DATA_TYPE"), DW_AT_const_value(0x4607) .dwattr $C$DW$939, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$939, DW_AT_decl_line(0xb0) .dwattr $C$DW$939, DW_AT_decl_column(0x05) $C$DW$940 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_SPCTL_DBELL_INTERVAL_OVERFLOW"), DW_AT_const_value(0x4608) .dwattr $C$DW$940, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$940, DW_AT_decl_line(0xb1) .dwattr $C$DW$940, DW_AT_decl_column(0x05) $C$DW$941 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_BEC"), DW_AT_const_value(0x4700) .dwattr $C$DW$941, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$941, DW_AT_decl_line(0xb3) .dwattr $C$DW$941, DW_AT_decl_column(0x05) $C$DW$942 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_BEC_INVALID_DATATYPE1"), DW_AT_const_value(0x4701) .dwattr $C$DW$942, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$942, DW_AT_decl_line(0xb4) .dwattr $C$DW$942, DW_AT_decl_column(0x05) $C$DW$943 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_BEC_INVALID_DATATYPE2"), DW_AT_const_value(0x4702) .dwattr $C$DW$943, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$943, DW_AT_decl_line(0xb5) .dwattr $C$DW$943, DW_AT_decl_column(0x05) $C$DW$944 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_INTC_CONTEXT_INIT"), DW_AT_const_value(0x4800) .dwattr $C$DW$944, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$944, DW_AT_decl_line(0xb7) .dwattr $C$DW$944, DW_AT_decl_column(0x05) $C$DW$945 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_EXCEEDED_MAX_SEC_EVENTS"), DW_AT_const_value(0x4801) .dwattr $C$DW$945, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$945, DW_AT_decl_line(0xb8) .dwattr $C$DW$945, DW_AT_decl_column(0x05) $C$DW$946 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_INVALID_SEC_EVENTS"), DW_AT_const_value(0x4802) .dwattr $C$DW$946, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$946, DW_AT_decl_line(0xb9) .dwattr $C$DW$946, DW_AT_decl_column(0x02) $C$DW$947 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_EXCEEDED_MAX_BROAD_EVENTS"), DW_AT_const_value(0x4803) .dwattr $C$DW$947, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$947, DW_AT_decl_line(0xba) .dwattr $C$DW$947, DW_AT_decl_column(0x05) $C$DW$948 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_BROADCAST_INVALID_EVENTS"), DW_AT_const_value(0x4804) .dwattr $C$DW$948, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$948, DW_AT_decl_line(0xbb) .dwattr $C$DW$948, DW_AT_decl_column(0x02) $C$DW$949 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_BROADCAST_EVENT_ALREADY_IN_USE"), DW_AT_const_value(0x4805) .dwattr $C$DW$949, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$949, DW_AT_decl_line(0xbc) .dwattr $C$DW$949, DW_AT_decl_column(0x05) $C$DW$950 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_SERVICED_ON_WRONG_CORE"), DW_AT_const_value(0x4806) .dwattr $C$DW$950, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$950, DW_AT_decl_line(0xbd) .dwattr $C$DW$950, DW_AT_decl_column(0x05) $C$DW$951 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_CREATE"), DW_AT_const_value(0x4807) .dwattr $C$DW$951, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$951, DW_AT_decl_line(0xbe) .dwattr $C$DW$951, DW_AT_decl_column(0x05) $C$DW$952 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_CORE_INTERRUPT_VECTOR_IN_USE"), DW_AT_const_value(0x4808) .dwattr $C$DW$952, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$952, DW_AT_decl_line(0xbf) .dwattr $C$DW$952, DW_AT_decl_column(0x05) $C$DW$953 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_EDMA3_CORE_ISR_VECTOR_SETUP_FAILURE"), DW_AT_const_value(0x4809) .dwattr $C$DW$953, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$953, DW_AT_decl_line(0xc0) .dwattr $C$DW$953, DW_AT_decl_column(0x05) $C$DW$954 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_INTERRUPT_OPEN_CIC_INSTANCE"), DW_AT_const_value(0x480a) .dwattr $C$DW$954, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$954, DW_AT_decl_line(0xc1) .dwattr $C$DW$954, DW_AT_decl_column(0x05) $C$DW$955 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_CORE_INTERRUPT_VECTOR_OUT_OF_RANGE"), DW_AT_const_value(0x480b) .dwattr $C$DW$955, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$955, DW_AT_decl_line(0xc2) .dwattr $C$DW$955, DW_AT_decl_column(0x05) $C$DW$956 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SETUP_ERR"), DW_AT_const_value(0x4900) .dwattr $C$DW$956, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$956, DW_AT_decl_line(0xc4) .dwattr $C$DW$956, DW_AT_decl_column(0x05) $C$DW$957 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_LIST_OVERFLOW"), DW_AT_const_value(0x4901) .dwattr $C$DW$957, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$957, DW_AT_decl_line(0xc5) .dwattr $C$DW$957, DW_AT_decl_column(0x05) $C$DW$958 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_LIST_UNDERFLOW"), DW_AT_const_value(0x4902) .dwattr $C$DW$958, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$958, DW_AT_decl_line(0xc6) .dwattr $C$DW$958, DW_AT_decl_column(0x05) $C$DW$959 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_START_ADDR_INVALID"), DW_AT_const_value(0x4903) .dwattr $C$DW$959, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$959, DW_AT_decl_line(0xc7) .dwattr $C$DW$959, DW_AT_decl_column(0x05) $C$DW$960 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_SEND_END_ADDR_INVALID"), DW_AT_const_value(0x4904) .dwattr $C$DW$960, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$960, DW_AT_decl_line(0xc8) .dwattr $C$DW$960, DW_AT_decl_column(0x05) $C$DW$961 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_TIMEOUT"), DW_AT_const_value(0x4905) .dwattr $C$DW$961, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$961, DW_AT_decl_line(0xc9) .dwattr $C$DW$961, DW_AT_decl_column(0x05) $C$DW$962 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HW_MGR_PCIE_FPGA_TIME_OVERFLOW"), DW_AT_const_value(0x4906) .dwattr $C$DW$962, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$962, DW_AT_decl_line(0xca) .dwattr $C$DW$962, DW_AT_decl_column(0x05) $C$DW$963 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR"), DW_AT_const_value(0x5000) .dwattr $C$DW$963, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$963, DW_AT_decl_line(0xcc) .dwattr $C$DW$963, DW_AT_decl_column(0x05) $C$DW$964 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_COMMAND"), DW_AT_const_value(0x5001) .dwattr $C$DW$964, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$964, DW_AT_decl_line(0xcd) .dwattr $C$DW$964, DW_AT_decl_column(0x05) $C$DW$965 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SUB_COMMAND"), DW_AT_const_value(0x5002) .dwattr $C$DW$965, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$965, DW_AT_decl_line(0xce) .dwattr $C$DW$965, DW_AT_decl_column(0x05) $C$DW$966 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_STATE_TRANSITION"), DW_AT_const_value(0x5003) .dwattr $C$DW$966, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$966, DW_AT_decl_line(0xcf) .dwattr $C$DW$966, DW_AT_decl_column(0x05) $C$DW$967 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SEM_STATE"), DW_AT_const_value(0x5004) .dwattr $C$DW$967, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$967, DW_AT_decl_line(0xd0) .dwattr $C$DW$967, DW_AT_decl_column(0x05) $C$DW$968 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SEM_BORROWER_STATE"), DW_AT_const_value(0x5005) .dwattr $C$DW$968, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$968, DW_AT_decl_line(0xd1) .dwattr $C$DW$968, DW_AT_decl_column(0x05) $C$DW$969 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_MODE_FOR_STOP"), DW_AT_const_value(0x5006) .dwattr $C$DW$969, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$969, DW_AT_decl_line(0xd2) .dwattr $C$DW$969, DW_AT_decl_column(0x05) $C$DW$970 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_RASTERZOOM_DATATYPE"), DW_AT_const_value(0x5007) .dwattr $C$DW$970, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$970, DW_AT_decl_line(0xd3) .dwattr $C$DW$970, DW_AT_decl_column(0x05) $C$DW$971 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_CLEAR_CINE_ON_ACTIVE_DATATYPE"), DW_AT_const_value(0x5008) .dwattr $C$DW$971, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$971, DW_AT_decl_line(0xd4) .dwattr $C$DW$971, DW_AT_decl_column(0x05) $C$DW$972 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_INVALID_SPDATATYPE"), DW_AT_const_value(0x5009) .dwattr $C$DW$972, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$972, DW_AT_decl_line(0xd5) .dwattr $C$DW$972, DW_AT_decl_column(0x05) $C$DW$973 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_STOP_CALLED_WHEN_CINE_NOT_READY"), DW_AT_const_value(0x500a) .dwattr $C$DW$973, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$973, DW_AT_decl_line(0xd6) .dwattr $C$DW$973, DW_AT_decl_column(0x05) $C$DW$974 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_CINE_OUT_OF_RANGE"), DW_AT_const_value(0x500b) .dwattr $C$DW$974, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$974, DW_AT_decl_line(0xd7) .dwattr $C$DW$974, DW_AT_decl_column(0x05) $C$DW$975 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_HOSTMGR_CINE_PROCESSTYPE_OUT_OF_BOUNDS"), DW_AT_const_value(0x500c) .dwattr $C$DW$975, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$975, DW_AT_decl_line(0xd8) .dwattr $C$DW$975, DW_AT_decl_column(0x05) $C$DW$976 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR"), DW_AT_const_value(0x5500) .dwattr $C$DW$976, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$976, DW_AT_decl_line(0xda) .dwattr $C$DW$976, DW_AT_decl_column(0x05) $C$DW$977 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_EVENT"), DW_AT_const_value(0x5501) .dwattr $C$DW$977, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$977, DW_AT_decl_line(0xdb) .dwattr $C$DW$977, DW_AT_decl_column(0x05) $C$DW$978 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_CMD"), DW_AT_const_value(0x5502) .dwattr $C$DW$978, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$978, DW_AT_decl_line(0xdc) .dwattr $C$DW$978, DW_AT_decl_column(0x05) $C$DW$979 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_MODE_COMBINATION"), DW_AT_const_value(0x5503) .dwattr $C$DW$979, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$979, DW_AT_decl_line(0xdd) .dwattr $C$DW$979, DW_AT_decl_column(0x02) $C$DW$980 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MAINCTLR_INVALID_MSG_TYPE"), DW_AT_const_value(0x5504) .dwattr $C$DW$980, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$980, DW_AT_decl_line(0xde) .dwattr $C$DW$980, DW_AT_decl_column(0x05) $C$DW$981 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR"), DW_AT_const_value(0x6000) .dwattr $C$DW$981, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$981, DW_AT_decl_line(0xe0) .dwattr $C$DW$981, DW_AT_decl_column(0x05) $C$DW$982 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_CMD_TABLE_OVERFLOW"), DW_AT_const_value(0x6001) .dwattr $C$DW$982, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$982, DW_AT_decl_line(0xe1) .dwattr $C$DW$982, DW_AT_decl_column(0x05) $C$DW$983 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_DATATYPE0"), DW_AT_const_value(0x6002) .dwattr $C$DW$983, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$983, DW_AT_decl_line(0xe2) .dwattr $C$DW$983, DW_AT_decl_column(0x05) $C$DW$984 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_DATATYPE1"), DW_AT_const_value(0x6003) .dwattr $C$DW$984, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$984, DW_AT_decl_line(0xe3) .dwattr $C$DW$984, DW_AT_decl_column(0x05) $C$DW$985 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_SP_SUBMODE"), DW_AT_const_value(0x6004) .dwattr $C$DW$985, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$985, DW_AT_decl_line(0xe4) .dwattr $C$DW$985, DW_AT_decl_column(0x05) $C$DW$986 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_START_TIMEOUT"), DW_AT_const_value(0x6005) .dwattr $C$DW$986, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$986, DW_AT_decl_line(0xe5) .dwattr $C$DW$986, DW_AT_decl_column(0x05) $C$DW$987 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INIT_TIMEOUT"), DW_AT_const_value(0x6006) .dwattr $C$DW$987, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$987, DW_AT_decl_line(0xe6) .dwattr $C$DW$987, DW_AT_decl_column(0x05) $C$DW$988 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_STOP_TIMEOUT"), DW_AT_const_value(0x6007) .dwattr $C$DW$988, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$988, DW_AT_decl_line(0xe7) .dwattr $C$DW$988, DW_AT_decl_column(0x05) $C$DW$989 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_PROCESS_CMD"), DW_AT_const_value(0x6008) .dwattr $C$DW$989, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$989, DW_AT_decl_line(0xe8) .dwattr $C$DW$989, DW_AT_decl_column(0x05) $C$DW$990 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_MODE_COMBINATION"), DW_AT_const_value(0x6009) .dwattr $C$DW$990, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$990, DW_AT_decl_line(0xe9) .dwattr $C$DW$990, DW_AT_decl_column(0x05) $C$DW$991 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_CINE_MEM_SEL"), DW_AT_const_value(0x600a) .dwattr $C$DW$991, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$991, DW_AT_decl_line(0xea) .dwattr $C$DW$991, DW_AT_decl_column(0x05) $C$DW$992 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_SPDATATYPE_INVALID0"), DW_AT_const_value(0x600b) .dwattr $C$DW$992, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$992, DW_AT_decl_line(0xeb) .dwattr $C$DW$992, DW_AT_decl_column(0x05) $C$DW$993 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_SPDATATYPE_INVALID1"), DW_AT_const_value(0x600c) .dwattr $C$DW$993, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$993, DW_AT_decl_line(0xec) .dwattr $C$DW$993, DW_AT_decl_column(0x05) $C$DW$994 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_SPDATATYPE_INVALID2"), DW_AT_const_value(0x600d) .dwattr $C$DW$994, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$994, DW_AT_decl_line(0xed) .dwattr $C$DW$994, DW_AT_decl_column(0x05) $C$DW$995 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_SUB_COMMAND"), DW_AT_const_value(0x600e) .dwattr $C$DW$995, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$995, DW_AT_decl_line(0xee) .dwattr $C$DW$995, DW_AT_decl_column(0x05) $C$DW$996 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COREMGR_INVALID_UPDATE_COMMAND"), DW_AT_const_value(0x600f) .dwattr $C$DW$996, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$996, DW_AT_decl_line(0xef) .dwattr $C$DW$996, DW_AT_decl_column(0x02) $C$DW$997 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_PLMGR"), DW_AT_const_value(0x7000) .dwattr $C$DW$997, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$997, DW_AT_decl_line(0xf1) .dwattr $C$DW$997, DW_AT_decl_column(0x05) $C$DW$998 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_PLMGR_INVALID_SP_MODE"), DW_AT_const_value(0x7001) .dwattr $C$DW$998, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$998, DW_AT_decl_line(0xf2) .dwattr $C$DW$998, DW_AT_decl_column(0x05) $C$DW$999 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_PLMGR_INVALID_SP_SUBMODE"), DW_AT_const_value(0x7002) .dwattr $C$DW$999, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$999, DW_AT_decl_line(0xf3) .dwattr $C$DW$999, DW_AT_decl_column(0x05) $C$DW$1000 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR"), DW_AT_const_value(0x8000) .dwattr $C$DW$1000, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1000, DW_AT_decl_line(0xf5) .dwattr $C$DW$1000, DW_AT_decl_column(0x05) $C$DW$1001 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_OVERFLOW"), DW_AT_const_value(0x8001) .dwattr $C$DW$1001, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1001, DW_AT_decl_line(0xf6) .dwattr $C$DW$1001, DW_AT_decl_column(0x05) $C$DW$1002 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_NULL_ENQUEUE_FXN"), DW_AT_const_value(0x8002) .dwattr $C$DW$1002, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1002, DW_AT_decl_line(0xf7) .dwattr $C$DW$1002, DW_AT_decl_column(0x05) $C$DW$1003 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_UNSUPP_MODE"), DW_AT_const_value(0x8003) .dwattr $C$DW$1003, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1003, DW_AT_decl_line(0xf8) .dwattr $C$DW$1003, DW_AT_decl_column(0x05) $C$DW$1004 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_INVALID_DOORBELL_INFO"), DW_AT_const_value(0x8004) .dwattr $C$DW$1004, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1004, DW_AT_decl_line(0xf9) .dwattr $C$DW$1004, DW_AT_decl_column(0x05) $C$DW$1005 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_SYSTEM_NOT_READY"), DW_AT_const_value(0x8005) .dwattr $C$DW$1005, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1005, DW_AT_decl_line(0xfa) .dwattr $C$DW$1005, DW_AT_decl_column(0x05) $C$DW$1006 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_MODE_MISMATCH"), DW_AT_const_value(0x8006) .dwattr $C$DW$1006, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1006, DW_AT_decl_line(0xfb) .dwattr $C$DW$1006, DW_AT_decl_column(0x05) $C$DW$1007 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGE_INVALID_MSG_TYPE"), DW_AT_const_value(0x8007) .dwattr $C$DW$1007, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1007, DW_AT_decl_line(0xfc) .dwattr $C$DW$1007, DW_AT_decl_column(0x05) $C$DW$1008 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_FRAME_HISTORY_BAD_SIZE"), DW_AT_const_value(0x8008) .dwattr $C$DW$1008, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1008, DW_AT_decl_line(0xfd) .dwattr $C$DW$1008, DW_AT_decl_column(0x05) $C$DW$1009 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_INPUTMGR_MAX_PRF_OVERFLOW"), DW_AT_const_value(0x8009) .dwattr $C$DW$1009, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1009, DW_AT_decl_line(0xfe) .dwattr $C$DW$1009, DW_AT_decl_column(0x05) $C$DW$1010 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR"), DW_AT_const_value(0x9000) .dwattr $C$DW$1010, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1010, DW_AT_decl_line(0x100) .dwattr $C$DW$1010, DW_AT_decl_column(0x05) $C$DW$1011 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_UNSUPP_MODE"), DW_AT_const_value(0x9001) .dwattr $C$DW$1011, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1011, DW_AT_decl_line(0x101) .dwattr $C$DW$1011, DW_AT_decl_column(0x05) $C$DW$1012 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_UNKNOWN_BUFFER_XFER"), DW_AT_const_value(0x9002) .dwattr $C$DW$1012, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1012, DW_AT_decl_line(0x102) .dwattr $C$DW$1012, DW_AT_decl_column(0x05) $C$DW$1013 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_STRANGE_SWI_WAKEUP"), DW_AT_const_value(0x9003) .dwattr $C$DW$1013, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1013, DW_AT_decl_line(0x103) .dwattr $C$DW$1013, DW_AT_decl_column(0x05) $C$DW$1014 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_OVERFLOW"), DW_AT_const_value(0x9004) .dwattr $C$DW$1014, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1014, DW_AT_decl_line(0x104) .dwattr $C$DW$1014, DW_AT_decl_column(0x05) $C$DW$1015 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_UNDERFLOW"), DW_AT_const_value(0x9005) .dwattr $C$DW$1015, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1015, DW_AT_decl_line(0x105) .dwattr $C$DW$1015, DW_AT_decl_column(0x05) $C$DW$1016 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_SETUP_ERR"), DW_AT_const_value(0x9006) .dwattr $C$DW$1016, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1016, DW_AT_decl_line(0x106) .dwattr $C$DW$1016, DW_AT_decl_column(0x05) $C$DW$1017 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_AUDIO_SHUTDN_ERR"), DW_AT_const_value(0x9007) .dwattr $C$DW$1017, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1017, DW_AT_decl_line(0x107) .dwattr $C$DW$1017, DW_AT_decl_column(0x05) $C$DW$1018 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_SIZE_ERR"), DW_AT_const_value(0x9008) .dwattr $C$DW$1018, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1018, DW_AT_decl_line(0x108) .dwattr $C$DW$1018, DW_AT_decl_column(0x05) $C$DW$1019 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_EXCEED_CPU_MEMORY_CAPACITY"), DW_AT_const_value(0x9009) .dwattr $C$DW$1019, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1019, DW_AT_decl_line(0x109) .dwattr $C$DW$1019, DW_AT_decl_column(0x05) $C$DW$1020 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_DATATYPE"), DW_AT_const_value(0x900a) .dwattr $C$DW$1020, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1020, DW_AT_decl_line(0x10a) .dwattr $C$DW$1020, DW_AT_decl_column(0x05) $C$DW$1021 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_FRAME_SYNC_HOLDOFF_OVERFLOW"), DW_AT_const_value(0x900b) .dwattr $C$DW$1021, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1021, DW_AT_decl_line(0x10b) .dwattr $C$DW$1021, DW_AT_decl_column(0x05) $C$DW$1022 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_FRAME_SYNC_UNEXPECTED_FRAME_ID"), DW_AT_const_value(0x900c) .dwattr $C$DW$1022, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1022, DW_AT_decl_line(0x10c) .dwattr $C$DW$1022, DW_AT_decl_column(0x05) $C$DW$1023 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_MSG_TYPE"), DW_AT_const_value(0x900d) .dwattr $C$DW$1023, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1023, DW_AT_decl_line(0x10d) .dwattr $C$DW$1023, DW_AT_decl_column(0x05) $C$DW$1024 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_DATATYPE_FOR_CLEAR"), DW_AT_const_value(0x900e) .dwattr $C$DW$1024, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1024, DW_AT_decl_line(0x10e) .dwattr $C$DW$1024, DW_AT_decl_column(0x05) $C$DW$1025 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_PLAYLIST_RW_IDX"), DW_AT_const_value(0x900f) .dwattr $C$DW$1025, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1025, DW_AT_decl_line(0x10f) .dwattr $C$DW$1025, DW_AT_decl_column(0x05) $C$DW$1026 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_PLAYLIST_BUF_FULL"), DW_AT_const_value(0x9010) .dwattr $C$DW$1026, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1026, DW_AT_decl_line(0x110) .dwattr $C$DW$1026, DW_AT_decl_column(0x05) $C$DW$1027 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_OUTPUTMGR_INVALID_CORE"), DW_AT_const_value(0x9011) .dwattr $C$DW$1027, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1027, DW_AT_decl_line(0x111) .dwattr $C$DW$1027, DW_AT_decl_column(0x05) $C$DW$1028 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK"), DW_AT_const_value(0xa000) .dwattr $C$DW$1028, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1028, DW_AT_decl_line(0x113) .dwattr $C$DW$1028, DW_AT_decl_column(0x05) $C$DW$1029 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_BADMODE"), DW_AT_const_value(0xa001) .dwattr $C$DW$1029, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1029, DW_AT_decl_line(0x114) .dwattr $C$DW$1029, DW_AT_decl_column(0x05) $C$DW$1030 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_BADCLUSTER"), DW_AT_const_value(0xa002) .dwattr $C$DW$1030, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1030, DW_AT_decl_line(0x115) .dwattr $C$DW$1030, DW_AT_decl_column(0x05) $C$DW$1031 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_BADPHYSPKT"), DW_AT_const_value(0xa003) .dwattr $C$DW$1031, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1031, DW_AT_decl_line(0x116) .dwattr $C$DW$1031, DW_AT_decl_column(0x05) $C$DW$1032 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_FRAMEWORK_ACTIVECLUSTER_OVERFLOW"), DW_AT_const_value(0xa004) .dwattr $C$DW$1032, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1032, DW_AT_decl_line(0x117) .dwattr $C$DW$1032, DW_AT_decl_column(0x05) $C$DW$1033 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC"), DW_AT_const_value(0xb000) .dwattr $C$DW$1033, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1033, DW_AT_decl_line(0x119) .dwattr $C$DW$1033, DW_AT_decl_column(0x05) $C$DW$1034 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_ATTACH_ERR"), DW_AT_const_value(0xb001) .dwattr $C$DW$1034, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1034, DW_AT_decl_line(0x11a) .dwattr $C$DW$1034, DW_AT_decl_column(0x05) $C$DW$1035 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_CREATE_ERR"), DW_AT_const_value(0xb002) .dwattr $C$DW$1035, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1035, DW_AT_decl_line(0x11b) .dwattr $C$DW$1035, DW_AT_decl_column(0x05) $C$DW$1036 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_ALLOC_ERR"), DW_AT_const_value(0xb003) .dwattr $C$DW$1036, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1036, DW_AT_decl_line(0x11c) .dwattr $C$DW$1036, DW_AT_decl_column(0x05) $C$DW$1037 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_PUT_ERR"), DW_AT_const_value(0xb004) .dwattr $C$DW$1037, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1037, DW_AT_decl_line(0x11d) .dwattr $C$DW$1037, DW_AT_decl_column(0x05) $C$DW$1038 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_GET_ERR"), DW_AT_const_value(0xb005) .dwattr $C$DW$1038, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1038, DW_AT_decl_line(0x11e) .dwattr $C$DW$1038, DW_AT_decl_column(0x05) $C$DW$1039 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_FREE_ERR"), DW_AT_const_value(0xb006) .dwattr $C$DW$1039, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1039, DW_AT_decl_line(0x11f) .dwattr $C$DW$1039, DW_AT_decl_column(0x05) $C$DW$1040 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_CREATE_ERR"), DW_AT_const_value(0xb007) .dwattr $C$DW$1040, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1040, DW_AT_decl_line(0x120) .dwattr $C$DW$1040, DW_AT_decl_column(0x05) $C$DW$1041 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_INVALID_ID_ERR"), DW_AT_const_value(0xb008) .dwattr $C$DW$1041, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1041, DW_AT_decl_line(0x121) .dwattr $C$DW$1041, DW_AT_decl_column(0x05) $C$DW$1042 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IPC_MESSAGEQ_SYNC_EVENT_CREATE_ERR"), DW_AT_const_value(0xb009) .dwattr $C$DW$1042, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1042, DW_AT_decl_line(0x122) .dwattr $C$DW$1042, DW_AT_decl_column(0x05) $C$DW$1043 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK"), DW_AT_const_value(0xc000) .dwattr $C$DW$1043, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1043, DW_AT_decl_line(0x124) .dwattr $C$DW$1043, DW_AT_decl_column(0x05) $C$DW$1044 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0xc001) .dwattr $C$DW$1044, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1044, DW_AT_decl_line(0x125) .dwattr $C$DW$1044, DW_AT_decl_column(0x05) $C$DW$1045 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_SP_MODE"), DW_AT_const_value(0xc002) .dwattr $C$DW$1045, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1045, DW_AT_decl_line(0x126) .dwattr $C$DW$1045, DW_AT_decl_column(0x05) $C$DW$1046 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_MSG_TYPE"), DW_AT_const_value(0xc003) .dwattr $C$DW$1046, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1046, DW_AT_decl_line(0x127) .dwattr $C$DW$1046, DW_AT_decl_column(0x05) $C$DW$1047 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_PROCESSCMD_TYPE"), DW_AT_const_value(0xc004) .dwattr $C$DW$1047, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1047, DW_AT_decl_line(0x128) .dwattr $C$DW$1047, DW_AT_decl_column(0x02) $C$DW$1048 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_WKR_TASK_INVALID_UPDATE_COMMAND"), DW_AT_const_value(0xc005) .dwattr $C$DW$1048, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1048, DW_AT_decl_line(0x129) .dwattr $C$DW$1048, DW_AT_decl_column(0x02) $C$DW$1049 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE"), DW_AT_const_value(0xd000) .dwattr $C$DW$1049, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1049, DW_AT_decl_line(0x12b) .dwattr $C$DW$1049, DW_AT_decl_column(0x05) $C$DW$1050 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_MISSING_EOB"), DW_AT_const_value(0xd001) .dwattr $C$DW$1050, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1050, DW_AT_decl_line(0x12c) .dwattr $C$DW$1050, DW_AT_decl_column(0x05) $C$DW$1051 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_DSIZE_ERR"), DW_AT_const_value(0xd002) .dwattr $C$DW$1051, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1051, DW_AT_decl_line(0x12d) .dwattr $C$DW$1051, DW_AT_decl_column(0x05) $C$DW$1052 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_UNEXPECTED_EOB"), DW_AT_const_value(0xd003) .dwattr $C$DW$1052, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1052, DW_AT_decl_line(0x12e) .dwattr $C$DW$1052, DW_AT_decl_column(0x05) $C$DW$1053 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_INVALID_RFBUFIDX"), DW_AT_const_value(0xd004) .dwattr $C$DW$1053, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1053, DW_AT_decl_line(0x12f) .dwattr $C$DW$1053, DW_AT_decl_column(0x05) $C$DW$1054 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_LINE_LENGTH_ERR"), DW_AT_const_value(0xd005) .dwattr $C$DW$1054, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1054, DW_AT_decl_line(0x130) .dwattr $C$DW$1054, DW_AT_decl_column(0x05) $C$DW$1055 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_UNEXPECTED_SEQUENCE_NUMBER"), DW_AT_const_value(0xd006) .dwattr $C$DW$1055, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1055, DW_AT_decl_line(0x131) .dwattr $C$DW$1055, DW_AT_decl_column(0x05) $C$DW$1056 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ENQUEUE_PINGPKT_MAGIC_ERR"), DW_AT_const_value(0xd007) .dwattr $C$DW$1056, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1056, DW_AT_decl_line(0x132) .dwattr $C$DW$1056, DW_AT_decl_column(0x05) $C$DW$1057 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR"), DW_AT_const_value(0xe000) .dwattr $C$DW$1057, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1057, DW_AT_decl_line(0x134) .dwattr $C$DW$1057, DW_AT_decl_column(0x05) $C$DW$1058 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_FRAME_RANGE"), DW_AT_const_value(0xe001) .dwattr $C$DW$1058, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1058, DW_AT_decl_line(0x135) .dwattr $C$DW$1058, DW_AT_decl_column(0x05) $C$DW$1059 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_COL_RANGE"), DW_AT_const_value(0xe002) .dwattr $C$DW$1059, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1059, DW_AT_decl_line(0x136) .dwattr $C$DW$1059, DW_AT_decl_column(0x05) $C$DW$1060 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_ECG_INVALID_COL_RANGE"), DW_AT_const_value(0xe003) .dwattr $C$DW$1060, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1060, DW_AT_decl_line(0x137) .dwattr $C$DW$1060, DW_AT_decl_column(0x05) $C$DW$1061 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_QUEUE_RANGE"), DW_AT_const_value(0xe004) .dwattr $C$DW$1061, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1061, DW_AT_decl_line(0x138) .dwattr $C$DW$1061, DW_AT_decl_column(0x05) $C$DW$1062 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_PLAYBACK_RANGE"), DW_AT_const_value(0xe005) .dwattr $C$DW$1062, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1062, DW_AT_decl_line(0x139) .dwattr $C$DW$1062, DW_AT_decl_column(0x05) $C$DW$1063 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_PLAYBACK_SPEED"), DW_AT_const_value(0xe006) .dwattr $C$DW$1063, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1063, DW_AT_decl_line(0x13a) .dwattr $C$DW$1063, DW_AT_decl_column(0x05) $C$DW$1064 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_PLAYBACK_TIMEOUT"), DW_AT_const_value(0xe007) .dwattr $C$DW$1064, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1064, DW_AT_decl_line(0x13b) .dwattr $C$DW$1064, DW_AT_decl_column(0x05) $C$DW$1065 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_INCBUF_ADDR0"), DW_AT_const_value(0xe008) .dwattr $C$DW$1065, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1065, DW_AT_decl_line(0x13c) .dwattr $C$DW$1065, DW_AT_decl_column(0x05) $C$DW$1066 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_INCBUF_ADDR1"), DW_AT_const_value(0xe009) .dwattr $C$DW$1066, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1066, DW_AT_decl_line(0x13d) .dwattr $C$DW$1066, DW_AT_decl_column(0x05) $C$DW$1067 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_OUTCBUF_ADDR0"), DW_AT_const_value(0xe00a) .dwattr $C$DW$1067, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1067, DW_AT_decl_line(0x13e) .dwattr $C$DW$1067, DW_AT_decl_column(0x05) $C$DW$1068 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_OUTCBUF_ADDR1"), DW_AT_const_value(0xe00b) .dwattr $C$DW$1068, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1068, DW_AT_decl_line(0x13f) .dwattr $C$DW$1068, DW_AT_decl_column(0x05) $C$DW$1069 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_DATATYPE0"), DW_AT_const_value(0xe00c) .dwattr $C$DW$1069, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1069, DW_AT_decl_line(0x140) .dwattr $C$DW$1069, DW_AT_decl_column(0x05) $C$DW$1070 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_DATATYPE1"), DW_AT_const_value(0xe00d) .dwattr $C$DW$1070, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1070, DW_AT_decl_line(0x141) .dwattr $C$DW$1070, DW_AT_decl_column(0x05) $C$DW$1071 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_SUBCMD"), DW_AT_const_value(0xe00e) .dwattr $C$DW$1071, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1071, DW_AT_decl_line(0x142) .dwattr $C$DW$1071, DW_AT_decl_column(0x05) $C$DW$1072 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CINECOL_MMODE"), DW_AT_const_value(0xe00f) .dwattr $C$DW$1072, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1072, DW_AT_decl_line(0x143) .dwattr $C$DW$1072, DW_AT_decl_column(0x05) $C$DW$1073 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CINECOL_DOP"), DW_AT_const_value(0xe010) .dwattr $C$DW$1073, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1073, DW_AT_decl_line(0x144) .dwattr $C$DW$1073, DW_AT_decl_column(0x05) $C$DW$1074 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CINECOL_ECG"), DW_AT_const_value(0xe011) .dwattr $C$DW$1074, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1074, DW_AT_decl_line(0x145) .dwattr $C$DW$1074, DW_AT_decl_column(0x05) $C$DW$1075 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_INVALID_CORE"), DW_AT_const_value(0xe012) .dwattr $C$DW$1075, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1075, DW_AT_decl_line(0x146) .dwattr $C$DW$1075, DW_AT_decl_column(0x05) $C$DW$1076 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CINEMGR_CINE_NOT_READY"), DW_AT_const_value(0xe013) .dwattr $C$DW$1076, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1076, DW_AT_decl_line(0x147) .dwattr $C$DW$1076, DW_AT_decl_column(0x05) $C$DW$1077 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_BOSSTASK"), DW_AT_const_value(0xf000) .dwattr $C$DW$1077, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1077, DW_AT_decl_line(0x149) .dwattr $C$DW$1077, DW_AT_decl_column(0x05) $C$DW$1078 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_BOSSTASK_INVALID_MSG_TYPE"), DW_AT_const_value(0xf001) .dwattr $C$DW$1078, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1078, DW_AT_decl_line(0x14a) .dwattr $C$DW$1078, DW_AT_decl_column(0x05) $C$DW$1079 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER"), DW_AT_const_value(0x10000) .dwattr $C$DW$1079, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1079, DW_AT_decl_line(0x14d) .dwattr $C$DW$1079, DW_AT_decl_column(0x05) $C$DW$1080 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_BADSTATE"), DW_AT_const_value(0x10001) .dwattr $C$DW$1080, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1080, DW_AT_decl_line(0x14e) .dwattr $C$DW$1080, DW_AT_decl_column(0x05) $C$DW$1081 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INPUT_OVERFLOW"), DW_AT_const_value(0x10002) .dwattr $C$DW$1081, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1081, DW_AT_decl_line(0x14f) .dwattr $C$DW$1081, DW_AT_decl_column(0x05) $C$DW$1082 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_EMPTY_INPUT"), DW_AT_const_value(0x10003) .dwattr $C$DW$1082, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1082, DW_AT_decl_line(0x150) .dwattr $C$DW$1082, DW_AT_decl_column(0x05) $C$DW$1083 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_USECS_PER_PRI"), DW_AT_const_value(0x10004) .dwattr $C$DW$1083, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1083, DW_AT_decl_line(0x151) .dwattr $C$DW$1083, DW_AT_decl_column(0x05) $C$DW$1084 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_USECS_PER_FFT"), DW_AT_const_value(0x10005) .dwattr $C$DW$1084, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1084, DW_AT_decl_line(0x152) .dwattr $C$DW$1084, DW_AT_decl_column(0x05) $C$DW$1085 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_FFTS_PER_COLUMN"), DW_AT_const_value(0x10006) .dwattr $C$DW$1085, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1085, DW_AT_decl_line(0x153) .dwattr $C$DW$1085, DW_AT_decl_column(0x05) $C$DW$1086 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_CWQBP_FILTERLEN"), DW_AT_const_value(0x10007) .dwattr $C$DW$1086, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1086, DW_AT_decl_line(0x154) .dwattr $C$DW$1086, DW_AT_decl_column(0x05) $C$DW$1087 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_CWQBP_INVALID_DECIMATION"), DW_AT_const_value(0x10008) .dwattr $C$DW$1087, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1087, DW_AT_decl_line(0x155) .dwattr $C$DW$1087, DW_AT_decl_column(0x05) $C$DW$1088 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_BUFFER_EXCEEDS_SRIO_ATW"), DW_AT_const_value(0x10009) .dwattr $C$DW$1088, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1088, DW_AT_decl_line(0x156) .dwattr $C$DW$1088, DW_AT_decl_column(0x05) $C$DW$1089 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_PROCESS_CMD"), DW_AT_const_value(0x1000a) .dwattr $C$DW$1089, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1089, DW_AT_decl_line(0x157) .dwattr $C$DW$1089, DW_AT_decl_column(0x05) $C$DW$1090 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_DEVELOPMENT"), DW_AT_const_value(0x1000b) .dwattr $C$DW$1090, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1090, DW_AT_decl_line(0x158) .dwattr $C$DW$1090, DW_AT_decl_column(0x05) $C$DW$1091 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_AUDIO"), DW_AT_const_value(0x1000c) .dwattr $C$DW$1091, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1091, DW_AT_decl_line(0x159) .dwattr $C$DW$1091, DW_AT_decl_column(0x05) $C$DW$1092 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_AUDIO_BUF_OVERFLOW"), DW_AT_const_value(0x1000d) .dwattr $C$DW$1092, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1092, DW_AT_decl_line(0x15a) .dwattr $C$DW$1092, DW_AT_decl_column(0x05) $C$DW$1093 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_FILL_TIMER_INIT"), DW_AT_const_value(0x1000e) .dwattr $C$DW$1093, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1093, DW_AT_decl_line(0x15b) .dwattr $C$DW$1093, DW_AT_decl_column(0x05) $C$DW$1094 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_PRI"), DW_AT_const_value(0x1000f) .dwattr $C$DW$1094, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1094, DW_AT_decl_line(0x15c) .dwattr $C$DW$1094, DW_AT_decl_column(0x05) $C$DW$1095 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_SAMP_PER_BLOCK_0"), DW_AT_const_value(0x10010) .dwattr $C$DW$1095, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1095, DW_AT_decl_line(0x15d) .dwattr $C$DW$1095, DW_AT_decl_column(0x05) $C$DW$1096 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_SAMP_PER_BLOCK"), DW_AT_const_value(0x10011) .dwattr $C$DW$1096, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1096, DW_AT_decl_line(0x15e) .dwattr $C$DW$1096, DW_AT_decl_column(0x05) $C$DW$1097 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_TOO_MANY_OUTPUTS"), DW_AT_const_value(0x10012) .dwattr $C$DW$1097, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1097, DW_AT_decl_line(0x15f) .dwattr $C$DW$1097, DW_AT_decl_column(0x05) $C$DW$1098 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_USEC_PER_PRI_ZERO"), DW_AT_const_value(0x10013) .dwattr $C$DW$1098, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1098, DW_AT_decl_line(0x160) .dwattr $C$DW$1098, DW_AT_decl_column(0x05) $C$DW$1099 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INCBUF_NOT_BIG_ENOUGH"), DW_AT_const_value(0x10014) .dwattr $C$DW$1099, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1099, DW_AT_decl_line(0x161) .dwattr $C$DW$1099, DW_AT_decl_column(0x05) $C$DW$1100 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_MKR_IN_BWD_ALG_STATE"), DW_AT_const_value(0x10015) .dwattr $C$DW$1100, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1100, DW_AT_decl_line(0x162) .dwattr $C$DW$1100, DW_AT_decl_column(0x05) $C$DW$1101 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SIZE_0"), DW_AT_const_value(0x10016) .dwattr $C$DW$1101, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1101, DW_AT_decl_line(0x163) .dwattr $C$DW$1101, DW_AT_decl_column(0x05) $C$DW$1102 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SZ_UNKNOWN"), DW_AT_const_value(0x10017) .dwattr $C$DW$1102, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1102, DW_AT_decl_line(0x164) .dwattr $C$DW$1102, DW_AT_decl_column(0x05) $C$DW$1103 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_MRK_WHEN_ZERO"), DW_AT_const_value(0x10018) .dwattr $C$DW$1103, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1103, DW_AT_decl_line(0x165) .dwattr $C$DW$1103, DW_AT_decl_column(0x05) $C$DW$1104 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_UNKNOWN_STATE"), DW_AT_const_value(0x10019) .dwattr $C$DW$1104, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1104, DW_AT_decl_line(0x166) .dwattr $C$DW$1104, DW_AT_decl_column(0x05) $C$DW$1105 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_REMAINDER_NOT_ZERO"), DW_AT_const_value(0x1001a) .dwattr $C$DW$1105, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1105, DW_AT_decl_line(0x167) .dwattr $C$DW$1105, DW_AT_decl_column(0x05) $C$DW$1106 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SAMPLES_AFTER_MKR_BIT"), DW_AT_const_value(0x1001b) .dwattr $C$DW$1106, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1106, DW_AT_decl_line(0x168) .dwattr $C$DW$1106, DW_AT_decl_column(0x05) $C$DW$1107 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_GAP_SAMPLES_AFTER_MKR_BIT1"), DW_AT_const_value(0x1001c) .dwattr $C$DW$1107, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1107, DW_AT_decl_line(0x169) .dwattr $C$DW$1107, DW_AT_decl_column(0x05) $C$DW$1108 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_SPCTL_BUF_SIZE"), DW_AT_const_value(0x1001d) .dwattr $C$DW$1108, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1108, DW_AT_decl_line(0x16a) .dwattr $C$DW$1108, DW_AT_decl_column(0x05) $C$DW$1109 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_FFT_AND_FFTBYN_DIFF_CORE"), DW_AT_const_value(0x1001e) .dwattr $C$DW$1109, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1109, DW_AT_decl_line(0x16b) .dwattr $C$DW$1109, DW_AT_decl_column(0x05) $C$DW$1110 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_UNKNOWN_INIT_CMD"), DW_AT_const_value(0x1001f) .dwattr $C$DW$1110, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1110, DW_AT_decl_line(0x16c) .dwattr $C$DW$1110, DW_AT_decl_column(0x05) $C$DW$1111 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_LINE_INTERLEAVE_ERROR"), DW_AT_const_value(0x10020) .dwattr $C$DW$1111, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1111, DW_AT_decl_line(0x16d) .dwattr $C$DW$1111, DW_AT_decl_column(0x05) $C$DW$1112 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_PARAM"), DW_AT_const_value(0x10021) .dwattr $C$DW$1112, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1112, DW_AT_decl_line(0x16e) .dwattr $C$DW$1112, DW_AT_decl_column(0x05) $C$DW$1113 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_INVALID_IDX"), DW_AT_const_value(0x10022) .dwattr $C$DW$1113, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1113, DW_AT_decl_line(0x16f) .dwattr $C$DW$1113, DW_AT_decl_column(0x05) $C$DW$1114 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_GAP_SZ_TOO_LARGE"), DW_AT_const_value(0x11000) .dwattr $C$DW$1114, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1114, DW_AT_decl_line(0x170) .dwattr $C$DW$1114, DW_AT_decl_column(0x05) $C$DW$1115 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_GAP_SZ_TOO_SMALL"), DW_AT_const_value(0x11001) .dwattr $C$DW$1115, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1115, DW_AT_decl_line(0x171) .dwattr $C$DW$1115, DW_AT_decl_column(0x05) $C$DW$1116 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_IN_SZ_TOO_LARGE"), DW_AT_const_value(0x11002) .dwattr $C$DW$1116, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1116, DW_AT_decl_line(0x172) .dwattr $C$DW$1116, DW_AT_decl_column(0x05) $C$DW$1117 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_IN_SZ_TOO_SMALL"), DW_AT_const_value(0x11003) .dwattr $C$DW$1117, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1117, DW_AT_decl_line(0x173) .dwattr $C$DW$1117, DW_AT_decl_column(0x05) $C$DW$1118 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_BURG_ORDER_TOO_LARGE"), DW_AT_const_value(0x11004) .dwattr $C$DW$1118, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1118, DW_AT_decl_line(0x174) .dwattr $C$DW$1118, DW_AT_decl_column(0x05) $C$DW$1119 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_BURG_ORDER_TOO_SMALL"), DW_AT_const_value(0x11005) .dwattr $C$DW$1119, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1119, DW_AT_decl_line(0x175) .dwattr $C$DW$1119, DW_AT_decl_column(0x05) $C$DW$1120 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_VAR_EXP_G_THAN_31"), DW_AT_const_value(0x11006) .dwattr $C$DW$1120, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1120, DW_AT_decl_line(0x176) .dwattr $C$DW$1120, DW_AT_decl_column(0x05) $C$DW$1121 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_GAPFILL_NOT_ENOUGH_SAMPLES"), DW_AT_const_value(0x11007) .dwattr $C$DW$1121, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1121, DW_AT_decl_line(0x177) .dwattr $C$DW$1121, DW_AT_decl_column(0x05) $C$DW$1122 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_PW_DATATYPE_INCOMPATIBLE"), DW_AT_const_value(0x11008) .dwattr $C$DW$1122, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1122, DW_AT_decl_line(0x178) .dwattr $C$DW$1122, DW_AT_decl_column(0x05) $C$DW$1123 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_CW_DATATYPE_INCOMPATIBLE"), DW_AT_const_value(0x11009) .dwattr $C$DW$1123, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1123, DW_AT_decl_line(0x179) .dwattr $C$DW$1123, DW_AT_decl_column(0x05) $C$DW$1124 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_BASELINE_IDX_OUT_OF_BOUND"), DW_AT_const_value(0x1100a) .dwattr $C$DW$1124, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1124, DW_AT_decl_line(0x17a) .dwattr $C$DW$1124, DW_AT_decl_column(0x05) $C$DW$1125 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_DBELL_SIZE_VIOLATE_SPCTL_SPEC"), DW_AT_const_value(0x1100b) .dwattr $C$DW$1125, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1125, DW_AT_decl_line(0x17b) .dwattr $C$DW$1125, DW_AT_decl_column(0x05) $C$DW$1126 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_IRREGULAR_NUM_OUTPUT_COLS"), DW_AT_const_value(0x1100c) .dwattr $C$DW$1126, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1126, DW_AT_decl_line(0x17c) .dwattr $C$DW$1126, DW_AT_decl_column(0x05) $C$DW$1127 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_PROCESS_LL2_MEMORY_INVALID"), DW_AT_const_value(0x1100d) .dwattr $C$DW$1127, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1127, DW_AT_decl_line(0x17d) .dwattr $C$DW$1127, DW_AT_decl_column(0x05) $C$DW$1128 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DOPPLER_PW_UNKNOWN_SUB_MODE"), DW_AT_const_value(0x1100e) .dwattr $C$DW$1128, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1128, DW_AT_decl_line(0x17e) .dwattr $C$DW$1128, DW_AT_decl_column(0x05) $C$DW$1129 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW"), DW_AT_const_value(0x20000) .dwattr $C$DW$1129, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1129, DW_AT_decl_line(0x180) .dwattr $C$DW$1129, DW_AT_decl_column(0x05) $C$DW$1130 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INPUT_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0x20001) .dwattr $C$DW$1130, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1130, DW_AT_decl_line(0x181) .dwattr $C$DW$1130, DW_AT_decl_column(0x05) $C$DW$1131 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_BUFF_OVF"), DW_AT_const_value(0x20002) .dwattr $C$DW$1131, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1131, DW_AT_decl_line(0x182) .dwattr $C$DW$1131, DW_AT_decl_column(0x05) $C$DW$1132 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_BUFF_UF"), DW_AT_const_value(0x20003) .dwattr $C$DW$1132, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1132, DW_AT_decl_line(0x183) .dwattr $C$DW$1132, DW_AT_decl_column(0x05) $C$DW$1133 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_GRPSZE_INVALID"), DW_AT_const_value(0x20004) .dwattr $C$DW$1133, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1133, DW_AT_decl_line(0x184) .dwattr $C$DW$1133, DW_AT_decl_column(0x05) $C$DW$1134 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_VARSZE_INVALID"), DW_AT_const_value(0x20005) .dwattr $C$DW$1134, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1134, DW_AT_decl_line(0x185) .dwattr $C$DW$1134, DW_AT_decl_column(0x05) $C$DW$1135 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_BADSTATE"), DW_AT_const_value(0x20006) .dwattr $C$DW$1135, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1135, DW_AT_decl_line(0x186) .dwattr $C$DW$1135, DW_AT_decl_column(0x05) $C$DW$1136 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INBUFF_SIZE_INVALID"), DW_AT_const_value(0x20007) .dwattr $C$DW$1136, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1136, DW_AT_decl_line(0x187) .dwattr $C$DW$1136, DW_AT_decl_column(0x05) $C$DW$1137 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_PARAMETER_OUT_OF_BOUNDS"), DW_AT_const_value(0x20008) .dwattr $C$DW$1137, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1137, DW_AT_decl_line(0x188) .dwattr $C$DW$1137, DW_AT_decl_column(0x05) $C$DW$1138 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INVALID_PROCESS_CMD0"), DW_AT_const_value(0x20009) .dwattr $C$DW$1138, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1138, DW_AT_decl_line(0x189) .dwattr $C$DW$1138, DW_AT_decl_column(0x05) $C$DW$1139 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INVALID_PROCESS_CMD1"), DW_AT_const_value(0x2000a) .dwattr $C$DW$1139, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1139, DW_AT_decl_line(0x18a) .dwattr $C$DW$1139, DW_AT_decl_column(0x05) $C$DW$1140 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_INVALID_PROCESS_CMD2"), DW_AT_const_value(0x2000b) .dwattr $C$DW$1140, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1140, DW_AT_decl_line(0x18b) .dwattr $C$DW$1140, DW_AT_decl_column(0x05) $C$DW$1141 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_PING_PKT_HEADER_CORRUPT"), DW_AT_const_value(0x2000c) .dwattr $C$DW$1141, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1141, DW_AT_decl_line(0x18c) .dwattr $C$DW$1141, DW_AT_decl_column(0x05) $C$DW$1142 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_UNSUPPORTED_MPFIR_SOURCE"), DW_AT_const_value(0x2000d) .dwattr $C$DW$1142, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1142, DW_AT_decl_line(0x18d) .dwattr $C$DW$1142, DW_AT_decl_column(0x05) $C$DW$1143 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_UNSUPPORTED_MPFIR_MODE"), DW_AT_const_value(0x2000e) .dwattr $C$DW$1143, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1143, DW_AT_decl_line(0x18e) .dwattr $C$DW$1143, DW_AT_decl_column(0x05) $C$DW$1144 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_ALREADY_INITIALIZED"), DW_AT_const_value(0x2000f) .dwattr $C$DW$1144, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1144, DW_AT_decl_line(0x18f) .dwattr $C$DW$1144, DW_AT_decl_column(0x05) $C$DW$1145 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_COMPUTED_FRAMERATE_BAD"), DW_AT_const_value(0x20010) .dwattr $C$DW$1145, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1145, DW_AT_decl_line(0x190) .dwattr $C$DW$1145, DW_AT_decl_column(0x05) $C$DW$1146 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_COLOROUTLEN_LESS_THAN_NESTIMATES"), DW_AT_const_value(0x20011) .dwattr $C$DW$1146, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1146, DW_AT_decl_line(0x191) .dwattr $C$DW$1146, DW_AT_decl_column(0x05) $C$DW$1147 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_LOCAL_MEMORY_NOT_ALLOCATED"), DW_AT_const_value(0x20012) .dwattr $C$DW$1147, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1147, DW_AT_decl_line(0x192) .dwattr $C$DW$1147, DW_AT_decl_column(0x05) $C$DW$1148 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COLORFLOW_OUTPUT_READY_LATENCY"), DW_AT_const_value(0x20013) .dwattr $C$DW$1148, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1148, DW_AT_decl_line(0x193) .dwattr $C$DW$1148, DW_AT_decl_column(0x05) $C$DW$1149 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD"), DW_AT_const_value(0x30000) .dwattr $C$DW$1149, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1149, DW_AT_decl_line(0x195) .dwattr $C$DW$1149, DW_AT_decl_column(0x05) $C$DW$1150 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_BADSTATE"), DW_AT_const_value(0x30001) .dwattr $C$DW$1150, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1150, DW_AT_decl_line(0x196) .dwattr $C$DW$1150, DW_AT_decl_column(0x05) $C$DW$1151 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_DMAOPEN"), DW_AT_const_value(0x30002) .dwattr $C$DW$1151, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1151, DW_AT_decl_line(0x197) .dwattr $C$DW$1151, DW_AT_decl_column(0x05) $C$DW$1152 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_SUBMODE"), DW_AT_const_value(0x30003) .dwattr $C$DW$1152, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1152, DW_AT_decl_line(0x198) .dwattr $C$DW$1152, DW_AT_decl_column(0x05) $C$DW$1153 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_PROCESS_CMD"), DW_AT_const_value(0x30004) .dwattr $C$DW$1153, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1153, DW_AT_decl_line(0x199) .dwattr $C$DW$1153, DW_AT_decl_column(0x05) $C$DW$1154 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_PARAMS"), DW_AT_const_value(0x30005) .dwattr $C$DW$1154, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1154, DW_AT_decl_line(0x19a) .dwattr $C$DW$1154, DW_AT_decl_column(0x05) $C$DW$1155 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_MB_OUTPUT_EST_GT_INPUT_EST"), DW_AT_const_value(0x30006) .dwattr $C$DW$1155, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1155, DW_AT_decl_line(0x19b) .dwattr $C$DW$1155, DW_AT_decl_column(0x05) $C$DW$1156 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_UNEXPECTED_PADDING"), DW_AT_const_value(0x30007) .dwattr $C$DW$1156, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1156, DW_AT_decl_line(0x19c) .dwattr $C$DW$1156, DW_AT_decl_column(0x05) $C$DW$1157 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_MB_PREFETCH_BUF_UNDERFLOW"), DW_AT_const_value(0x30008) .dwattr $C$DW$1157, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1157, DW_AT_decl_line(0x19d) .dwattr $C$DW$1157, DW_AT_decl_column(0x05) $C$DW$1158 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_POST_PROCESS_INVALID_FORK"), DW_AT_const_value(0x30009) .dwattr $C$DW$1158, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1158, DW_AT_decl_line(0x19e) .dwattr $C$DW$1158, DW_AT_decl_column(0x05) $C$DW$1159 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_RF_BUFFER_INDEX_OUT_OF_BOUNDS"), DW_AT_const_value(0x3000a) .dwattr $C$DW$1159, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1159, DW_AT_decl_line(0x19f) .dwattr $C$DW$1159, DW_AT_decl_column(0x05) $C$DW$1160 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_LL2_BUFFER_POINTER_NULL"), DW_AT_const_value(0x3000b) .dwattr $C$DW$1160, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1160, DW_AT_decl_line(0x1a0) .dwattr $C$DW$1160, DW_AT_decl_column(0x05) $C$DW$1161 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_SL2_BUFFER_POINTER_NULL"), DW_AT_const_value(0x3000c) .dwattr $C$DW$1161, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1161, DW_AT_decl_line(0x1a1) .dwattr $C$DW$1161, DW_AT_decl_column(0x05) $C$DW$1162 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_DDR_BUFFER_POINTER_NULL"), DW_AT_const_value(0x3000d) .dwattr $C$DW$1162, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1162, DW_AT_decl_line(0x1a2) .dwattr $C$DW$1162, DW_AT_decl_column(0x05) $C$DW$1163 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_TWOD_INVALID_DRAW_NUMBER_PARAM"), DW_AT_const_value(0x3000e) .dwattr $C$DW$1163, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1163, DW_AT_decl_line(0x1a3) .dwattr $C$DW$1163, DW_AT_decl_column(0x05) $C$DW$1164 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IMAGING"), DW_AT_const_value(0x40000) .dwattr $C$DW$1164, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1164, DW_AT_decl_line(0x1a5) .dwattr $C$DW$1164, DW_AT_decl_column(0x05) $C$DW$1165 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_IMAGING_BADSTATE"), DW_AT_const_value(0x40001) .dwattr $C$DW$1165, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1165, DW_AT_decl_line(0x1a6) .dwattr $C$DW$1165, DW_AT_decl_column(0x05) $C$DW$1166 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ"), DW_AT_const_value(0x50000) .dwattr $C$DW$1166, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1166, DW_AT_decl_line(0x1a8) .dwattr $C$DW$1166, DW_AT_decl_column(0x05) $C$DW$1167 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_PARAMS"), DW_AT_const_value(0x50001) .dwattr $C$DW$1167, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1167, DW_AT_decl_line(0x1a9) .dwattr $C$DW$1167, DW_AT_decl_column(0x05) $C$DW$1168 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_DDR_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0x50002) .dwattr $C$DW$1168, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1168, DW_AT_decl_line(0x1aa) .dwattr $C$DW$1168, DW_AT_decl_column(0x05) $C$DW$1169 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_OPERATION"), DW_AT_const_value(0x50003) .dwattr $C$DW$1169, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1169, DW_AT_decl_line(0x1ab) .dwattr $C$DW$1169, DW_AT_decl_column(0x05) $C$DW$1170 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_IMAGE_Y_SIZE"), DW_AT_const_value(0x50004) .dwattr $C$DW$1170, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1170, DW_AT_decl_line(0x1ac) .dwattr $C$DW$1170, DW_AT_decl_column(0x05) $C$DW$1171 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_IMAGE_X_SIZE"), DW_AT_const_value(0x50005) .dwattr $C$DW$1171, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1171, DW_AT_decl_line(0x1ad) .dwattr $C$DW$1171, DW_AT_decl_column(0x05) $C$DW$1172 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_IMAGE_MARGIN"), DW_AT_const_value(0x50006) .dwattr $C$DW$1172, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1172, DW_AT_decl_line(0x1ae) .dwattr $C$DW$1172, DW_AT_decl_column(0x05) $C$DW$1173 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_COPYOFFSET"), DW_AT_const_value(0x50007) .dwattr $C$DW$1173, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1173, DW_AT_decl_line(0x1af) .dwattr $C$DW$1173, DW_AT_decl_column(0x05) $C$DW$1174 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_LUT_SCALE"), DW_AT_const_value(0x50008) .dwattr $C$DW$1174, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1174, DW_AT_decl_line(0x1b0) .dwattr $C$DW$1174, DW_AT_decl_column(0x05) $C$DW$1175 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_MAX_LEV"), DW_AT_const_value(0x50009) .dwattr $C$DW$1175, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1175, DW_AT_decl_line(0x1b1) .dwattr $C$DW$1175, DW_AT_decl_column(0x05) $C$DW$1176 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_CVIZ_INVALID_FRAME_BOUNDARY_INPUT_PARAM"), DW_AT_const_value(0x5000a) .dwattr $C$DW$1176, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1176, DW_AT_decl_line(0x1b2) .dwattr $C$DW$1176, DW_AT_decl_column(0x02) $C$DW$1177 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC"), DW_AT_const_value(0x60000) .dwattr $C$DW$1177, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1177, DW_AT_decl_line(0x1b4) .dwattr $C$DW$1177, DW_AT_decl_column(0x05) $C$DW$1178 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_INVALID_DATATYPE"), DW_AT_const_value(0x60001) .dwattr $C$DW$1178, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1178, DW_AT_decl_line(0x1b5) .dwattr $C$DW$1178, DW_AT_decl_column(0x05) $C$DW$1179 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_TBLINIT"), DW_AT_const_value(0x60002) .dwattr $C$DW$1179, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1179, DW_AT_decl_line(0x1b6) .dwattr $C$DW$1179, DW_AT_decl_column(0x05) $C$DW$1180 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_SUBSECTORSIZE"), DW_AT_const_value(0x60003) .dwattr $C$DW$1180, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1180, DW_AT_decl_line(0x1b7) .dwattr $C$DW$1180, DW_AT_decl_column(0x05) $C$DW$1181 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_NUMSUBSECTORS"), DW_AT_const_value(0x60004) .dwattr $C$DW$1181, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1181, DW_AT_decl_line(0x1b8) .dwattr $C$DW$1181, DW_AT_decl_column(0x05) $C$DW$1182 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RASTER_SIZEX"), DW_AT_const_value(0x60005) .dwattr $C$DW$1182, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1182, DW_AT_decl_line(0x1b9) .dwattr $C$DW$1182, DW_AT_decl_column(0x05) $C$DW$1183 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RASTER_SIZEY"), DW_AT_const_value(0x60006) .dwattr $C$DW$1183, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1183, DW_AT_decl_line(0x1ba) .dwattr $C$DW$1183, DW_AT_decl_column(0x05) $C$DW$1184 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_ESTDELTA"), DW_AT_const_value(0x60007) .dwattr $C$DW$1184, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1184, DW_AT_decl_line(0x1bb) .dwattr $C$DW$1184, DW_AT_decl_column(0x05) $C$DW$1185 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_COLDELTA"), DW_AT_const_value(0x60008) .dwattr $C$DW$1185, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1185, DW_AT_decl_line(0x1bc) .dwattr $C$DW$1185, DW_AT_decl_column(0x05) $C$DW$1186 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_ROWDELTA"), DW_AT_const_value(0x60009) .dwattr $C$DW$1186, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1186, DW_AT_decl_line(0x1bd) .dwattr $C$DW$1186, DW_AT_decl_column(0x05) $C$DW$1187 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_RSC_OUTINDEX"), DW_AT_const_value(0x6000a) .dwattr $C$DW$1187, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1187, DW_AT_decl_line(0x1be) .dwattr $C$DW$1187, DW_AT_decl_column(0x05) $C$DW$1188 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE"), DW_AT_const_value(0x70000) .dwattr $C$DW$1188, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1188, DW_AT_decl_line(0x1c0) .dwattr $C$DW$1188, DW_AT_decl_column(0x05) $C$DW$1189 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_INVALID_PARAMS"), DW_AT_const_value(0x70001) .dwattr $C$DW$1189, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1189, DW_AT_decl_line(0x1c1) .dwattr $C$DW$1189, DW_AT_decl_column(0x05) $C$DW$1190 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_INVALID_PROCESS_CMD"), DW_AT_const_value(0x70002) .dwattr $C$DW$1190, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1190, DW_AT_decl_line(0x1c2) .dwattr $C$DW$1190, DW_AT_decl_column(0x05) $C$DW$1191 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_LL2_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0x70003) .dwattr $C$DW$1191, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1191, DW_AT_decl_line(0x1c3) .dwattr $C$DW$1191, DW_AT_decl_column(0x05) $C$DW$1192 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_SAMPLE_PERIOD"), DW_AT_const_value(0x70004) .dwattr $C$DW$1192, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1192, DW_AT_decl_line(0x1c4) .dwattr $C$DW$1192, DW_AT_decl_column(0x05) $C$DW$1193 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_INVALID_SUBMODE"), DW_AT_const_value(0x70005) .dwattr $C$DW$1193, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1193, DW_AT_decl_line(0x1c5) .dwattr $C$DW$1193, DW_AT_decl_column(0x05) $C$DW$1194 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_LL2_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0x70006) .dwattr $C$DW$1194, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1194, DW_AT_decl_line(0x1c6) .dwattr $C$DW$1194, DW_AT_decl_column(0x05) $C$DW$1195 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_ENQUEUE_INFO_ALLOCATION_FAILURE"), DW_AT_const_value(0x70007) .dwattr $C$DW$1195, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1195, DW_AT_decl_line(0x1c7) .dwattr $C$DW$1195, DW_AT_decl_column(0x05) $C$DW$1196 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_SPCTL_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0x70008) .dwattr $C$DW$1196, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1196, DW_AT_decl_line(0x1c8) .dwattr $C$DW$1196, DW_AT_decl_column(0x05) $C$DW$1197 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_RFBUF_OUT_OF_BOUNDS"), DW_AT_const_value(0x70009) .dwattr $C$DW$1197, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1197, DW_AT_decl_line(0x1c9) .dwattr $C$DW$1197, DW_AT_decl_column(0x05) $C$DW$1198 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_PARAMETER"), DW_AT_const_value(0x7000a) .dwattr $C$DW$1198, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1198, DW_AT_decl_line(0x1ca) .dwattr $C$DW$1198, DW_AT_decl_column(0x02) $C$DW$1199 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_BUFFER_PTR"), DW_AT_const_value(0x7000b) .dwattr $C$DW$1199, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1199, DW_AT_decl_line(0x1cb) .dwattr $C$DW$1199, DW_AT_decl_column(0x02) $C$DW$1200 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_BUFFER_SIZE"), DW_AT_const_value(0x7000c) .dwattr $C$DW$1200, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1200, DW_AT_decl_line(0x1cc) .dwattr $C$DW$1200, DW_AT_decl_column(0x02) $C$DW$1201 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_LINE_START_COORD"), DW_AT_const_value(0x7000d) .dwattr $C$DW$1201, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1201, DW_AT_decl_line(0x1cd) .dwattr $C$DW$1201, DW_AT_decl_column(0x02) $C$DW$1202 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_LINE_END_COORD"), DW_AT_const_value(0x7000e) .dwattr $C$DW$1202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1202, DW_AT_decl_line(0x1ce) .dwattr $C$DW$1202, DW_AT_decl_column(0x02) $C$DW$1203 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_START_END_PT_NOT_INIT"), DW_AT_const_value(0x7000f) .dwattr $C$DW$1203, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1203, DW_AT_decl_line(0x1cf) .dwattr $C$DW$1203, DW_AT_decl_column(0x02) $C$DW$1204 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MMODE_AMM_INVALID_COL_TIME_COUNT"), DW_AT_const_value(0x70010) .dwattr $C$DW$1204, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1204, DW_AT_decl_line(0x1d0) .dwattr $C$DW$1204, DW_AT_decl_column(0x02) $C$DW$1205 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB"), DW_AT_const_value(0x80000) .dwattr $C$DW$1205, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1205, DW_AT_decl_line(0x1d2) .dwattr $C$DW$1205, DW_AT_decl_column(0x05) $C$DW$1206 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_LOOKS"), DW_AT_const_value(0x80001) .dwattr $C$DW$1206, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1206, DW_AT_decl_line(0x1d3) .dwattr $C$DW$1206, DW_AT_decl_column(0x05) $C$DW$1207 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_EST"), DW_AT_const_value(0x80002) .dwattr $C$DW$1207, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1207, DW_AT_decl_line(0x1d4) .dwattr $C$DW$1207, DW_AT_decl_column(0x05) $C$DW$1208 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_SH_PARAM"), DW_AT_const_value(0x80003) .dwattr $C$DW$1208, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1208, DW_AT_decl_line(0x1d5) .dwattr $C$DW$1208, DW_AT_decl_column(0x05) $C$DW$1209 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_IMG_PARAM"), DW_AT_const_value(0x80004) .dwattr $C$DW$1209, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1209, DW_AT_decl_line(0x1d6) .dwattr $C$DW$1209, DW_AT_decl_column(0x05) $C$DW$1210 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_NULL_PTR"), DW_AT_const_value(0x80005) .dwattr $C$DW$1210, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1210, DW_AT_decl_line(0x1d7) .dwattr $C$DW$1210, DW_AT_decl_column(0x05) $C$DW$1211 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_LINE"), DW_AT_const_value(0x80006) .dwattr $C$DW$1211, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1211, DW_AT_decl_line(0x1d8) .dwattr $C$DW$1211, DW_AT_decl_column(0x05) $C$DW$1212 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_LINE_IDX"), DW_AT_const_value(0x80007) .dwattr $C$DW$1212, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1212, DW_AT_decl_line(0x1d9) .dwattr $C$DW$1212, DW_AT_decl_column(0x05) $C$DW$1213 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_EST_IDX"), DW_AT_const_value(0x80008) .dwattr $C$DW$1213, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1213, DW_AT_decl_line(0x1da) .dwattr $C$DW$1213, DW_AT_decl_column(0x05) $C$DW$1214 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_SHORT_ARRAY_LEN"), DW_AT_const_value(0x80009) .dwattr $C$DW$1214, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1214, DW_AT_decl_line(0x1db) .dwattr $C$DW$1214, DW_AT_decl_column(0x05) $C$DW$1215 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_FRAME_BOUNDARY_INPUT_PARAM"), DW_AT_const_value(0x8000a) .dwattr $C$DW$1215, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1215, DW_AT_decl_line(0x1dc) .dwattr $C$DW$1215, DW_AT_decl_column(0x05) $C$DW$1216 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_NUM_TAPER_COEFF"), DW_AT_const_value(0x8000b) .dwattr $C$DW$1216, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1216, DW_AT_decl_line(0x1dd) .dwattr $C$DW$1216, DW_AT_decl_column(0x05) $C$DW$1217 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_TAPER_COEFF"), DW_AT_const_value(0x8000c) .dwattr $C$DW$1217, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1217, DW_AT_decl_line(0x1de) .dwattr $C$DW$1217, DW_AT_decl_column(0x05) $C$DW$1218 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_ANGLE_IDX"), DW_AT_const_value(0x8000d) .dwattr $C$DW$1218, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1218, DW_AT_decl_line(0x1df) .dwattr $C$DW$1218, DW_AT_decl_column(0x05) $C$DW$1219 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_ANGLE"), DW_AT_const_value(0x8000e) .dwattr $C$DW$1219, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1219, DW_AT_decl_line(0x1e0) .dwattr $C$DW$1219, DW_AT_decl_column(0x05) $C$DW$1220 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_STRIDE"), DW_AT_const_value(0x8000f) .dwattr $C$DW$1220, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1220, DW_AT_decl_line(0x1e1) .dwattr $C$DW$1220, DW_AT_decl_column(0x05) $C$DW$1221 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_FRAME_DATA_SIZE"), DW_AT_const_value(0x80010) .dwattr $C$DW$1221, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1221, DW_AT_decl_line(0x1e2) .dwattr $C$DW$1221, DW_AT_decl_column(0x05) $C$DW$1222 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_QFMT_VAL_OUT_OF_RANGE"), DW_AT_const_value(0x80011) .dwattr $C$DW$1222, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1222, DW_AT_decl_line(0x1e3) .dwattr $C$DW$1222, DW_AT_decl_column(0x05) $C$DW$1223 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_MB_INVALID_FRAME_DATA_ORDER"), DW_AT_const_value(0x80012) .dwattr $C$DW$1223, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1223, DW_AT_decl_line(0x1e4) .dwattr $C$DW$1223, DW_AT_decl_column(0x05) $C$DW$1224 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_AUTOGAIN"), DW_AT_const_value(0x90000) .dwattr $C$DW$1224, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1224, DW_AT_decl_line(0x1e6) .dwattr $C$DW$1224, DW_AT_decl_column(0x05) $C$DW$1225 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_AUTOGAIN_INVALID_PARAMETER"), DW_AT_const_value(0x90001) .dwattr $C$DW$1225, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1225, DW_AT_decl_line(0x1e7) .dwattr $C$DW$1225, DW_AT_decl_column(0x05) $C$DW$1226 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_AUTOGAIN_NO_QUALIFIED_EST"), DW_AT_const_value(0x90002) .dwattr $C$DW$1226, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1226, DW_AT_decl_line(0x1e8) .dwattr $C$DW$1226, DW_AT_decl_column(0x05) $C$DW$1227 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG"), DW_AT_const_value(0xa0000) .dwattr $C$DW$1227, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1227, DW_AT_decl_line(0x1ea) .dwattr $C$DW$1227, DW_AT_decl_column(0x05) $C$DW$1228 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_PARAMS"), DW_AT_const_value(0xa0001) .dwattr $C$DW$1228, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1228, DW_AT_decl_line(0x1eb) .dwattr $C$DW$1228, DW_AT_decl_column(0x05) $C$DW$1229 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_PROCESS_CMD"), DW_AT_const_value(0xa0002) .dwattr $C$DW$1229, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1229, DW_AT_decl_line(0x1ec) .dwattr $C$DW$1229, DW_AT_decl_column(0x05) $C$DW$1230 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_LL2_PROCESS_BUF_OVERFLOW"), DW_AT_const_value(0xa0003) .dwattr $C$DW$1230, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1230, DW_AT_decl_line(0x1ed) .dwattr $C$DW$1230, DW_AT_decl_column(0x05) $C$DW$1231 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_ARRAY_BOUNDS"), DW_AT_const_value(0xa0004) .dwattr $C$DW$1231, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1231, DW_AT_decl_line(0x1ee) .dwattr $C$DW$1231, DW_AT_decl_column(0x05) $C$DW$1232 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_SYNC_MAX_BOUNDS"), DW_AT_const_value(0xa0005) .dwattr $C$DW$1232, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1232, DW_AT_decl_line(0x1ef) .dwattr $C$DW$1232, DW_AT_decl_column(0x05) $C$DW$1233 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_LOOP_COUNT_NEGATIVE"), DW_AT_const_value(0xa0006) .dwattr $C$DW$1233, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1233, DW_AT_decl_line(0x1f0) .dwattr $C$DW$1233, DW_AT_decl_column(0x05) $C$DW$1234 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_DELAY_SAMP_WRONG"), DW_AT_const_value(0xa0007) .dwattr $C$DW$1234, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1234, DW_AT_decl_line(0x1f1) .dwattr $C$DW$1234, DW_AT_decl_column(0x05) $C$DW$1235 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_IMAGE_START_ON_FIRST_SAMPLE"), DW_AT_const_value(0xa0008) .dwattr $C$DW$1235, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1235, DW_AT_decl_line(0x1f2) .dwattr $C$DW$1235, DW_AT_decl_column(0x05) $C$DW$1236 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_TWO_IMAGE_STARTS"), DW_AT_const_value(0xa0009) .dwattr $C$DW$1236, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1236, DW_AT_decl_line(0x1f3) .dwattr $C$DW$1236, DW_AT_decl_column(0x05) $C$DW$1237 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_LL2_BUFFER_ALLOCATION_FAILURE"), DW_AT_const_value(0xa000a) .dwattr $C$DW$1237, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1237, DW_AT_decl_line(0x1f4) .dwattr $C$DW$1237, DW_AT_decl_column(0x05) $C$DW$1238 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_SCROLL_RATE"), DW_AT_const_value(0xa000b) .dwattr $C$DW$1238, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1238, DW_AT_decl_line(0x1f5) .dwattr $C$DW$1238, DW_AT_decl_column(0x05) $C$DW$1239 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_HEART_RATE_WINDOW_SIZE"), DW_AT_const_value(0xa000c) .dwattr $C$DW$1239, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1239, DW_AT_decl_line(0x1f6) .dwattr $C$DW$1239, DW_AT_decl_column(0x05) $C$DW$1240 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_ENQUEUE_INFO_ALLOCATION_FAILURE"), DW_AT_const_value(0xa000d) .dwattr $C$DW$1240, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1240, DW_AT_decl_line(0x1f7) .dwattr $C$DW$1240, DW_AT_decl_column(0x05) $C$DW$1241 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_CORE"), DW_AT_const_value(0xa000e) .dwattr $C$DW$1241, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1241, DW_AT_decl_line(0x1f8) .dwattr $C$DW$1241, DW_AT_decl_column(0x05) $C$DW$1242 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_ECG_INVALID_SCREEN_WIDTH"), DW_AT_const_value(0xa000f) .dwattr $C$DW$1242, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1242, DW_AT_decl_line(0x1f9) .dwattr $C$DW$1242, DW_AT_decl_column(0x05) $C$DW$1243 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV"), DW_AT_const_value(0xb0000) .dwattr $C$DW$1243, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1243, DW_AT_decl_line(0x1fb) .dwattr $C$DW$1243, DW_AT_decl_column(0x05) $C$DW$1244 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_INVALID_PROBE_TYPE"), DW_AT_const_value(0xb0001) .dwattr $C$DW$1244, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1244, DW_AT_decl_line(0x1fc) .dwattr $C$DW$1244, DW_AT_decl_column(0x05) $C$DW$1245 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_SC_INIT_BUF_SIZE_ERR"), DW_AT_const_value(0xb0002) .dwattr $C$DW$1245, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1245, DW_AT_decl_line(0x1fd) .dwattr $C$DW$1245, DW_AT_decl_column(0x05) $C$DW$1246 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_INVALID_IDX_VAL"), DW_AT_const_value(0xb0003) .dwattr $C$DW$1246, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1246, DW_AT_decl_line(0x1fe) .dwattr $C$DW$1246, DW_AT_decl_column(0x05) $C$DW$1247 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_NV_INVALID_DEC_FACTOR"), DW_AT_const_value(0xb0004) .dwattr $C$DW$1247, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1247, DW_AT_decl_line(0x1ff) .dwattr $C$DW$1247, DW_AT_decl_column(0x05) $C$DW$1248 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG"), DW_AT_const_value(0xf0000) .dwattr $C$DW$1248, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1248, DW_AT_decl_line(0x201) .dwattr $C$DW$1248, DW_AT_decl_column(0x05) $C$DW$1249 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_INVALID_ADDR"), DW_AT_const_value(0xf0001) .dwattr $C$DW$1249, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1249, DW_AT_decl_line(0x202) .dwattr $C$DW$1249, DW_AT_decl_column(0x05) $C$DW$1250 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_BADSTATE"), DW_AT_const_value(0xf0002) .dwattr $C$DW$1250, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1250, DW_AT_decl_line(0x203) .dwattr $C$DW$1250, DW_AT_decl_column(0x05) $C$DW$1251 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_ALREADY_RUNNING"), DW_AT_const_value(0xf0003) .dwattr $C$DW$1251, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1251, DW_AT_decl_line(0x205) .dwattr $C$DW$1251, DW_AT_decl_column(0x05) $C$DW$1252 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_DIAG_UNKNOWN_COMMAND"), DW_AT_const_value(0xf0004) .dwattr $C$DW$1252, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1252, DW_AT_decl_line(0x206) .dwattr $C$DW$1252, DW_AT_decl_column(0x05) $C$DW$1253 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_CHAPTER_NAME_OVERLAP"), DW_AT_const_value(0x100000) .dwattr $C$DW$1253, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1253, DW_AT_decl_line(0x208) .dwattr $C$DW$1253, DW_AT_decl_column(0x05) $C$DW$1254 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_INVALID_ARG_NUMBER"), DW_AT_const_value(0x100001) .dwattr $C$DW$1254, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1254, DW_AT_decl_line(0x209) .dwattr $C$DW$1254, DW_AT_decl_column(0x05) $C$DW$1255 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_TABLE_OF_CONTENTS_OVERFLOW"), DW_AT_const_value(0x100002) .dwattr $C$DW$1255, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1255, DW_AT_decl_line(0x20a) .dwattr $C$DW$1255, DW_AT_decl_column(0x05) $C$DW$1256 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_CORE_NOT_ZERO"), DW_AT_const_value(0x100003) .dwattr $C$DW$1256, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1256, DW_AT_decl_line(0x20b) .dwattr $C$DW$1256, DW_AT_decl_column(0x05) $C$DW$1257 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTI_INVALID_PARAMS"), DW_AT_const_value(0x100004) .dwattr $C$DW$1257, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1257, DW_AT_decl_line(0x20c) .dwattr $C$DW$1257, DW_AT_decl_column(0x02) $C$DW$1258 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTILS_EXCEEDED_MAX_TASK_JOIN"), DW_AT_const_value(0x110000) .dwattr $C$DW$1258, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1258, DW_AT_decl_line(0x20e) .dwattr $C$DW$1258, DW_AT_decl_column(0x05) $C$DW$1259 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UTILS_INVALID_CORE0_ADDRESS"), DW_AT_const_value(0x110001) .dwattr $C$DW$1259, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1259, DW_AT_decl_line(0x20f) .dwattr $C$DW$1259, DW_AT_decl_column(0x05) $C$DW$1260 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INVALID_ARGC_ARGV"), DW_AT_const_value(0x120000) .dwattr $C$DW$1260, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1260, DW_AT_decl_line(0x214) .dwattr $C$DW$1260, DW_AT_decl_column(0x05) $C$DW$1261 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INIT_SUPPORT_MODULE_FAIL"), DW_AT_const_value(0x120001) .dwattr $C$DW$1261, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1261, DW_AT_decl_line(0x215) .dwattr $C$DW$1261, DW_AT_decl_column(0x05) $C$DW$1262 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INVALID_PARAM"), DW_AT_const_value(0x120002) .dwattr $C$DW$1262, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1262, DW_AT_decl_line(0x216) .dwattr $C$DW$1262, DW_AT_decl_column(0x02) $C$DW$1263 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_AUTO_GAIN_FAIL"), DW_AT_const_value(0x120003) .dwattr $C$DW$1263, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1263, DW_AT_decl_line(0x217) .dwattr $C$DW$1263, DW_AT_decl_column(0x05) $C$DW$1264 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_AMM_FAIL"), DW_AT_const_value(0x120004) .dwattr $C$DW$1264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1264, DW_AT_decl_line(0x218) .dwattr $C$DW$1264, DW_AT_decl_column(0x05) $C$DW$1265 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_ASSERT_EQUAL"), DW_AT_const_value(0x120005) .dwattr $C$DW$1265, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1265, DW_AT_decl_line(0x219) .dwattr $C$DW$1265, DW_AT_decl_column(0x02) $C$DW$1266 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_ASSERT_TRUE"), DW_AT_const_value(0x120006) .dwattr $C$DW$1266, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1266, DW_AT_decl_line(0x21a) .dwattr $C$DW$1266, DW_AT_decl_column(0x02) $C$DW$1267 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_UNIT_TEST_INVALI_CYCLE_COUNT_PARM"), DW_AT_const_value(0x120007) .dwattr $C$DW$1267, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1267, DW_AT_decl_line(0x21b) .dwattr $C$DW$1267, DW_AT_decl_column(0x02) $C$DW$1268 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COUNTER_EXTENDER"), DW_AT_const_value(0x130000) .dwattr $C$DW$1268, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1268, DW_AT_decl_line(0x21d) .dwattr $C$DW$1268, DW_AT_decl_column(0x02) $C$DW$1269 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COUNTER_EXTENDER_INVALID_BW"), DW_AT_const_value(0x130001) .dwattr $C$DW$1269, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1269, DW_AT_decl_line(0x21e) .dwattr $C$DW$1269, DW_AT_decl_column(0x02) $C$DW$1270 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_COUNTER_EXTENDER_INVALID_COUNTER_VAL"), DW_AT_const_value(0x130002) .dwattr $C$DW$1270, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1270, DW_AT_decl_line(0x21f) .dwattr $C$DW$1270, DW_AT_decl_column(0x02) $C$DW$1271 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_URATIONAL"), DW_AT_const_value(0x140000) .dwattr $C$DW$1271, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1271, DW_AT_decl_line(0x221) .dwattr $C$DW$1271, DW_AT_decl_column(0x05) $C$DW$1272 .dwtag DW_TAG_enumerator, DW_AT_name("ERROR_TYPE_URATIONAL_TRIGGER_OVERFLOW"), DW_AT_const_value(0x140001) .dwattr $C$DW$1272, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$1272, DW_AT_decl_line(0x222) .dwattr $C$DW$1272, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$2203 .dwattr $C$DW$T$2203, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$T$2203, DW_AT_decl_line(0x23) .dwattr $C$DW$T$2203, DW_AT_decl_column(0x01) $C$DW$T$2204 .dwtag DW_TAG_typedef, DW_AT_name("ErrorType") .dwattr $C$DW$T$2204, DW_AT_type(*$C$DW$T$2203) .dwattr $C$DW$T$2204, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2204, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Components/include/ErrorMgr.h") .dwattr $C$DW$T$2204, DW_AT_decl_line(0x224) .dwattr $C$DW$T$2204, DW_AT_decl_column(0x03) $C$DW$T$149 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$149, DW_AT_name("FOVBase_Param") .dwattr $C$DW$T$149, DW_AT_byte_size(0x88) $C$DW$1273 .dwtag DW_TAG_member .dwattr $C$DW$1273, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1273, DW_AT_name("frameIntervalNumClocks48MHz") .dwattr $C$DW$1273, DW_AT_TI_symbol_name("frameIntervalNumClocks48MHz") .dwattr $C$DW$1273, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1273, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1273, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1273, DW_AT_decl_line(0x571) .dwattr $C$DW$1273, DW_AT_decl_column(0x05) $C$DW$1274 .dwtag DW_TAG_member .dwattr $C$DW$1274, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1274, DW_AT_name("reserved") .dwattr $C$DW$1274, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1274, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1274, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1274, DW_AT_decl_line(0x572) .dwattr $C$DW$1274, DW_AT_decl_column(0x05) $C$DW$32 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$32, DW_AT_declaration .dwattr $C$DW$32, DW_AT_TI_symbol_name("_ZN13FOVBase_ParamaSERKS_") .dwattr $C$DW$32, DW_AT_type(*$C$DW$T$145) .dwattr $C$DW$32, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1275 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1275, DW_AT_type(*$C$DW$T$147) .dwendtag $C$DW$32 .dwendtag $C$DW$T$149 .dwattr $C$DW$T$149, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$149, DW_AT_decl_line(0x570) .dwattr $C$DW$T$149, DW_AT_decl_column(0x01) $C$DW$T$146 .dwtag DW_TAG_const_type .dwattr $C$DW$T$146, DW_AT_type(*$C$DW$T$149) $C$DW$T$147 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$147, DW_AT_type(*$C$DW$T$146) .dwattr $C$DW$T$147, DW_AT_address_class(0x20) $C$DW$T$1595 .dwtag DW_TAG_typedef, DW_AT_name("FOVBase_Param") .dwattr $C$DW$T$1595, DW_AT_type(*$C$DW$T$149) .dwattr $C$DW$T$1595, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1595, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1595, DW_AT_decl_line(0x573) .dwattr $C$DW$T$1595, DW_AT_decl_column(0x03) $C$DW$T$145 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$145, DW_AT_type(*$C$DW$T$149) .dwattr $C$DW$T$145, DW_AT_address_class(0x20) $C$DW$T$148 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$148, DW_AT_type(*$C$DW$T$145) .dwattr $C$DW$T$148, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1276 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1276, DW_AT_type(*$C$DW$T$147) .dwendtag $C$DW$T$148 $C$DW$T$989 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$989, DW_AT_name("FilterParam") .dwattr $C$DW$T$989, DW_AT_byte_size(0x88) $C$DW$1277 .dwtag DW_TAG_member .dwattr $C$DW$1277, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1277, DW_AT_name("maskh") .dwattr $C$DW$1277, DW_AT_TI_symbol_name("maskh") .dwattr $C$DW$1277, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1277, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1277, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1277, DW_AT_decl_line(0x66) .dwattr $C$DW$1277, DW_AT_decl_column(0x08) $C$DW$1278 .dwtag DW_TAG_member .dwattr $C$DW$1278, DW_AT_type(*$C$DW$T$984) .dwattr $C$DW$1278, DW_AT_name("coef") .dwattr $C$DW$1278, DW_AT_TI_symbol_name("coef") .dwattr $C$DW$1278, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1278, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1278, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1278, DW_AT_decl_line(0x67) .dwattr $C$DW$1278, DW_AT_decl_column(0x08) $C$DW$1279 .dwtag DW_TAG_member .dwattr $C$DW$1279, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1279, DW_AT_name("accuracyBits") .dwattr $C$DW$1279, DW_AT_TI_symbol_name("accuracyBits") .dwattr $C$DW$1279, DW_AT_data_member_location[DW_OP_plus_uconst 0x84] .dwattr $C$DW$1279, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1279, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1279, DW_AT_decl_line(0x68) .dwattr $C$DW$1279, DW_AT_decl_column(0x08) $C$DW$33 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$33, DW_AT_declaration .dwattr $C$DW$33, DW_AT_TI_symbol_name("_ZN11FilterParamaSERKS_") .dwattr $C$DW$33, DW_AT_type(*$C$DW$T$985) .dwattr $C$DW$33, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1280 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1280, DW_AT_type(*$C$DW$T$987) .dwendtag $C$DW$33 .dwendtag $C$DW$T$989 .dwattr $C$DW$T$989, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$989, DW_AT_decl_line(0x64) .dwattr $C$DW$T$989, DW_AT_decl_column(0x08) $C$DW$T$986 .dwtag DW_TAG_const_type .dwattr $C$DW$T$986, DW_AT_type(*$C$DW$T$989) $C$DW$T$987 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$987, DW_AT_type(*$C$DW$T$986) .dwattr $C$DW$T$987, DW_AT_address_class(0x20) $C$DW$T$418 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$418, DW_AT_type(*$C$DW$T$989) .dwattr $C$DW$T$418, DW_AT_address_class(0x20) $C$DW$T$985 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$985, DW_AT_type(*$C$DW$T$989) .dwattr $C$DW$T$985, DW_AT_address_class(0x20) $C$DW$T$988 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$988, DW_AT_type(*$C$DW$T$985) .dwattr $C$DW$T$988, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1281 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1281, DW_AT_type(*$C$DW$T$987) .dwendtag $C$DW$T$988 $C$DW$T$1197 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1197, DW_AT_type(*$C$DW$T$989) .dwattr $C$DW$T$1197, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1197, DW_AT_byte_size(0x2a8) $C$DW$1282 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1282, DW_AT_upper_bound(0x04) .dwendtag $C$DW$T$1197 $C$DW$T$274 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$274, DW_AT_name("ImageDirectionFilter") .dwattr $C$DW$T$274, DW_AT_byte_size(0x78) $C$DW$1283 .dwtag DW_TAG_member .dwattr $C$DW$1283, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1283, DW_AT_name("radius") .dwattr $C$DW$1283, DW_AT_TI_symbol_name("radius") .dwattr $C$DW$1283, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1283, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1283, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1283, DW_AT_decl_line(0x7f) .dwattr $C$DW$1283, DW_AT_decl_column(0x07) $C$DW$1284 .dwtag DW_TAG_member .dwattr $C$DW$1284, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1284, DW_AT_name("sigma") .dwattr $C$DW$1284, DW_AT_TI_symbol_name("sigma") .dwattr $C$DW$1284, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1284, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1284, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1284, DW_AT_decl_line(0x80) .dwattr $C$DW$1284, DW_AT_decl_column(0x08) $C$DW$1285 .dwtag DW_TAG_member .dwattr $C$DW$1285, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1285, DW_AT_name("amp") .dwattr $C$DW$1285, DW_AT_TI_symbol_name("amp") .dwattr $C$DW$1285, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1285, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1285, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1285, DW_AT_decl_line(0x81) .dwattr $C$DW$1285, DW_AT_decl_column(0x08) $C$DW$1286 .dwtag DW_TAG_member .dwattr $C$DW$1286, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1286, DW_AT_name("base") .dwattr $C$DW$1286, DW_AT_TI_symbol_name("base") .dwattr $C$DW$1286, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c] .dwattr $C$DW$1286, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1286, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1286, DW_AT_decl_line(0x82) .dwattr $C$DW$1286, DW_AT_decl_column(0x08) $C$DW$1287 .dwtag DW_TAG_member .dwattr $C$DW$1287, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1287, DW_AT_name("val") .dwattr $C$DW$1287, DW_AT_TI_symbol_name("val") .dwattr $C$DW$1287, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$1287, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1287, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1287, DW_AT_decl_line(0x83) .dwattr $C$DW$1287, DW_AT_decl_column(0x08) $C$DW$1288 .dwtag DW_TAG_member .dwattr $C$DW$1288, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1288, DW_AT_name("anisoMaskH") .dwattr $C$DW$1288, DW_AT_TI_symbol_name("anisoMaskH") .dwattr $C$DW$1288, DW_AT_data_member_location[DW_OP_plus_uconst 0x64] .dwattr $C$DW$1288, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1288, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1288, DW_AT_decl_line(0x84) .dwattr $C$DW$1288, DW_AT_decl_column(0x07) $C$DW$34 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$34, DW_AT_declaration .dwattr $C$DW$34, DW_AT_TI_symbol_name("_ZN13XtNamApiParam20ImageDirectionFilteraSERKS0_") .dwattr $C$DW$34, DW_AT_type(*$C$DW$T$270) .dwattr $C$DW$34, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1289 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1289, DW_AT_type(*$C$DW$T$272) .dwendtag $C$DW$34 .dwendtag $C$DW$T$274 .dwattr $C$DW$T$274, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$274, DW_AT_decl_line(0x7d) .dwattr $C$DW$T$274, DW_AT_decl_column(0x08) $C$DW$T$271 .dwtag DW_TAG_const_type .dwattr $C$DW$T$271, DW_AT_type(*$C$DW$T$274) $C$DW$T$272 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$272, DW_AT_type(*$C$DW$T$271) .dwattr $C$DW$T$272, DW_AT_address_class(0x20) $C$DW$T$270 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$270, DW_AT_type(*$C$DW$T$274) .dwattr $C$DW$T$270, DW_AT_address_class(0x20) $C$DW$T$273 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$273, DW_AT_type(*$C$DW$T$270) .dwattr $C$DW$T$273, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1290 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1290, DW_AT_type(*$C$DW$T$272) .dwendtag $C$DW$T$273 $C$DW$T$1053 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1053, DW_AT_name("ImageDirectionFilter") .dwattr $C$DW$T$1053, DW_AT_byte_size(0xf8) $C$DW$1291 .dwtag DW_TAG_member .dwattr $C$DW$1291, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1291, DW_AT_name("radius") .dwattr $C$DW$1291, DW_AT_TI_symbol_name("radius") .dwattr $C$DW$1291, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1291, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1291, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1291, DW_AT_decl_line(0x347) .dwattr $C$DW$1291, DW_AT_decl_column(0x05) $C$DW$1292 .dwtag DW_TAG_member .dwattr $C$DW$1292, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1292, DW_AT_name("sigma") .dwattr $C$DW$1292, DW_AT_TI_symbol_name("sigma") .dwattr $C$DW$1292, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1292, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1292, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1292, DW_AT_decl_line(0x348) .dwattr $C$DW$1292, DW_AT_decl_column(0x05) $C$DW$1293 .dwtag DW_TAG_member .dwattr $C$DW$1293, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1293, DW_AT_name("amp") .dwattr $C$DW$1293, DW_AT_TI_symbol_name("amp") .dwattr $C$DW$1293, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1293, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1293, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1293, DW_AT_decl_line(0x349) .dwattr $C$DW$1293, DW_AT_decl_column(0x05) $C$DW$1294 .dwtag DW_TAG_member .dwattr $C$DW$1294, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1294, DW_AT_name("base") .dwattr $C$DW$1294, DW_AT_TI_symbol_name("base") .dwattr $C$DW$1294, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$1294, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1294, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1294, DW_AT_decl_line(0x34a) .dwattr $C$DW$1294, DW_AT_decl_column(0x05) $C$DW$1295 .dwtag DW_TAG_member .dwattr $C$DW$1295, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1295, DW_AT_name("val") .dwattr $C$DW$1295, DW_AT_TI_symbol_name("val") .dwattr $C$DW$1295, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$1295, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1295, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1295, DW_AT_decl_line(0x34b) .dwattr $C$DW$1295, DW_AT_decl_column(0x05) $C$DW$1296 .dwtag DW_TAG_member .dwattr $C$DW$1296, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1296, DW_AT_name("reserved") .dwattr $C$DW$1296, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1296, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1296, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1296, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1296, DW_AT_decl_line(0x34c) .dwattr $C$DW$1296, DW_AT_decl_column(0x05) $C$DW$35 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$35, DW_AT_declaration .dwattr $C$DW$35, DW_AT_TI_symbol_name("_ZN20ImageDirectionFilteraSERKS_") .dwattr $C$DW$35, DW_AT_type(*$C$DW$T$1049) .dwattr $C$DW$35, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1297 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1297, DW_AT_type(*$C$DW$T$1051) .dwendtag $C$DW$35 .dwendtag $C$DW$T$1053 .dwattr $C$DW$T$1053, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1053, DW_AT_decl_line(0x346) .dwattr $C$DW$T$1053, DW_AT_decl_column(0x10) $C$DW$T$202 .dwtag DW_TAG_typedef, DW_AT_name("ImageDirectionFilter") .dwattr $C$DW$T$202, DW_AT_type(*$C$DW$T$1053) .dwattr $C$DW$T$202, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$202, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$202, DW_AT_decl_line(0x34d) .dwattr $C$DW$T$202, DW_AT_decl_column(0x03) $C$DW$T$1050 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1050, DW_AT_type(*$C$DW$T$1053) $C$DW$T$1051 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1051, DW_AT_type(*$C$DW$T$1050) .dwattr $C$DW$T$1051, DW_AT_address_class(0x20) $C$DW$T$1049 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1049, DW_AT_type(*$C$DW$T$1053) .dwattr $C$DW$T$1049, DW_AT_address_class(0x20) $C$DW$T$1052 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1052, DW_AT_type(*$C$DW$T$1049) .dwattr $C$DW$T$1052, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1298 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1298, DW_AT_type(*$C$DW$T$1051) .dwendtag $C$DW$T$1052 $C$DW$T$237 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$237, DW_AT_name("ImageDummy") .dwattr $C$DW$T$237, DW_AT_byte_size(0x78) $C$DW$1299 .dwtag DW_TAG_member .dwattr $C$DW$1299, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1299, DW_AT_name("edgeRelFilH") .dwattr $C$DW$1299, DW_AT_TI_symbol_name("edgeRelFilH") .dwattr $C$DW$1299, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1299, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1299, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1299, DW_AT_decl_line(0xa4) .dwattr $C$DW$1299, DW_AT_decl_column(0x07) $C$DW$1300 .dwtag DW_TAG_member .dwattr $C$DW$1300, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1300, DW_AT_name("edgeRelFilS") .dwattr $C$DW$1300, DW_AT_TI_symbol_name("edgeRelFilS") .dwattr $C$DW$1300, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1300, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1300, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1300, DW_AT_decl_line(0xa5) .dwattr $C$DW$1300, DW_AT_decl_column(0x08) $C$DW$1301 .dwtag DW_TAG_member .dwattr $C$DW$1301, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1301, DW_AT_name("nepWghtM") .dwattr $C$DW$1301, DW_AT_TI_symbol_name("nepWghtM") .dwattr $C$DW$1301, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1301, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1301, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1301, DW_AT_decl_line(0xa6) .dwattr $C$DW$1301, DW_AT_decl_column(0x07) $C$DW$1302 .dwtag DW_TAG_member .dwattr $C$DW$1302, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1302, DW_AT_name("nepWghtS") .dwattr $C$DW$1302, DW_AT_TI_symbol_name("nepWghtS") .dwattr $C$DW$1302, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c] .dwattr $C$DW$1302, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1302, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1302, DW_AT_decl_line(0xa7) .dwattr $C$DW$1302, DW_AT_decl_column(0x07) $C$DW$1303 .dwtag DW_TAG_member .dwattr $C$DW$1303, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1303, DW_AT_name("reserveInt") .dwattr $C$DW$1303, DW_AT_TI_symbol_name("reserveInt") .dwattr $C$DW$1303, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$1303, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1303, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1303, DW_AT_decl_line(0xa8) .dwattr $C$DW$1303, DW_AT_decl_column(0x0a) $C$DW$1304 .dwtag DW_TAG_member .dwattr $C$DW$1304, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1304, DW_AT_name("reserveFloat") .dwattr $C$DW$1304, DW_AT_TI_symbol_name("reserveFloat") .dwattr $C$DW$1304, DW_AT_data_member_location[DW_OP_plus_uconst 0x64] .dwattr $C$DW$1304, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1304, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1304, DW_AT_decl_line(0xa9) .dwattr $C$DW$1304, DW_AT_decl_column(0x0a) $C$DW$36 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$36, DW_AT_declaration .dwattr $C$DW$36, DW_AT_TI_symbol_name("_ZN13XtNamApiParam10ImageDummyaSERKS0_") .dwattr $C$DW$36, DW_AT_type(*$C$DW$T$233) .dwattr $C$DW$36, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1305 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1305, DW_AT_type(*$C$DW$T$235) .dwendtag $C$DW$36 .dwendtag $C$DW$T$237 .dwattr $C$DW$T$237, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$237, DW_AT_decl_line(0xa2) .dwattr $C$DW$T$237, DW_AT_decl_column(0x08) $C$DW$T$234 .dwtag DW_TAG_const_type .dwattr $C$DW$T$234, DW_AT_type(*$C$DW$T$237) $C$DW$T$235 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$235, DW_AT_type(*$C$DW$T$234) .dwattr $C$DW$T$235, DW_AT_address_class(0x20) $C$DW$T$233 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$233, DW_AT_type(*$C$DW$T$237) .dwattr $C$DW$T$233, DW_AT_address_class(0x20) $C$DW$T$236 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$236, DW_AT_type(*$C$DW$T$233) .dwattr $C$DW$T$236, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1306 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1306, DW_AT_type(*$C$DW$T$235) .dwendtag $C$DW$T$236 $C$DW$T$1058 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1058, DW_AT_name("ImageDummy") .dwattr $C$DW$T$1058, DW_AT_byte_size(0x60) $C$DW$1307 .dwtag DW_TAG_member .dwattr $C$DW$1307, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1307, DW_AT_name("debug1") .dwattr $C$DW$1307, DW_AT_TI_symbol_name("debug1") .dwattr $C$DW$1307, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1307, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1307, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1307, DW_AT_decl_line(0x377) .dwattr $C$DW$1307, DW_AT_decl_column(0x05) $C$DW$1308 .dwtag DW_TAG_member .dwattr $C$DW$1308, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1308, DW_AT_name("debug2") .dwattr $C$DW$1308, DW_AT_TI_symbol_name("debug2") .dwattr $C$DW$1308, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1308, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1308, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1308, DW_AT_decl_line(0x378) .dwattr $C$DW$1308, DW_AT_decl_column(0x05) $C$DW$1309 .dwtag DW_TAG_member .dwattr $C$DW$1309, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1309, DW_AT_name("reserveInt") .dwattr $C$DW$1309, DW_AT_TI_symbol_name("reserveInt") .dwattr $C$DW$1309, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1309, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1309, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1309, DW_AT_decl_line(0x379) .dwattr $C$DW$1309, DW_AT_decl_column(0x05) $C$DW$1310 .dwtag DW_TAG_member .dwattr $C$DW$1310, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1310, DW_AT_name("reserveFloat") .dwattr $C$DW$1310, DW_AT_TI_symbol_name("reserveFloat") .dwattr $C$DW$1310, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$1310, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1310, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1310, DW_AT_decl_line(0x37a) .dwattr $C$DW$1310, DW_AT_decl_column(0x05) $C$DW$37 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$37, DW_AT_declaration .dwattr $C$DW$37, DW_AT_TI_symbol_name("_ZN10ImageDummyaSERKS_") .dwattr $C$DW$37, DW_AT_type(*$C$DW$T$1054) .dwattr $C$DW$37, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1311 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1311, DW_AT_type(*$C$DW$T$1056) .dwendtag $C$DW$37 .dwendtag $C$DW$T$1058 .dwattr $C$DW$T$1058, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1058, DW_AT_decl_line(0x376) .dwattr $C$DW$T$1058, DW_AT_decl_column(0x10) $C$DW$T$207 .dwtag DW_TAG_typedef, DW_AT_name("ImageDummy") .dwattr $C$DW$T$207, DW_AT_type(*$C$DW$T$1058) .dwattr $C$DW$T$207, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$207, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$207, DW_AT_decl_line(0x37b) .dwattr $C$DW$T$207, DW_AT_decl_column(0x03) $C$DW$T$1055 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1055, DW_AT_type(*$C$DW$T$1058) $C$DW$T$1056 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1056, DW_AT_type(*$C$DW$T$1055) .dwattr $C$DW$T$1056, DW_AT_address_class(0x20) $C$DW$T$1054 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1054, DW_AT_type(*$C$DW$T$1058) .dwattr $C$DW$T$1054, DW_AT_address_class(0x20) $C$DW$T$1057 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1057, DW_AT_type(*$C$DW$T$1054) .dwattr $C$DW$T$1057, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1312 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1312, DW_AT_type(*$C$DW$T$1056) .dwendtag $C$DW$T$1057 $C$DW$T$1064 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1064, DW_AT_name("ImageEdgeDetection") .dwattr $C$DW$T$1064, DW_AT_byte_size(0x118) $C$DW$1313 .dwtag DW_TAG_member .dwattr $C$DW$1313, DW_AT_type(*$C$DW$T$1059) .dwattr $C$DW$1313, DW_AT_name("rankCoef") .dwattr $C$DW$1313, DW_AT_TI_symbol_name("rankCoef") .dwattr $C$DW$1313, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1313, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1313, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1313, DW_AT_decl_line(0x323) .dwattr $C$DW$1313, DW_AT_decl_column(0x05) $C$DW$1314 .dwtag DW_TAG_member .dwattr $C$DW$1314, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1314, DW_AT_name("engTblNum") .dwattr $C$DW$1314, DW_AT_TI_symbol_name("engTblNum") .dwattr $C$DW$1314, DW_AT_data_member_location[DW_OP_plus_uconst 0x68] .dwattr $C$DW$1314, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1314, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1314, DW_AT_decl_line(0x324) .dwattr $C$DW$1314, DW_AT_decl_column(0x05) $C$DW$1315 .dwtag DW_TAG_member .dwattr $C$DW$1315, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1315, DW_AT_name("engTblAccuracy") .dwattr $C$DW$1315, DW_AT_TI_symbol_name("engTblAccuracy") .dwattr $C$DW$1315, DW_AT_data_member_location[DW_OP_plus_uconst 0x80] .dwattr $C$DW$1315, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1315, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1315, DW_AT_decl_line(0x325) .dwattr $C$DW$1315, DW_AT_decl_column(0x05) $C$DW$1316 .dwtag DW_TAG_member .dwattr $C$DW$1316, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1316, DW_AT_name("reserved") .dwattr $C$DW$1316, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1316, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$1316, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1316, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1316, DW_AT_decl_line(0x326) .dwattr $C$DW$1316, DW_AT_decl_column(0x05) $C$DW$38 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$38, DW_AT_declaration .dwattr $C$DW$38, DW_AT_TI_symbol_name("_ZN18ImageEdgeDetectionaSERKS_") .dwattr $C$DW$38, DW_AT_type(*$C$DW$T$1060) .dwattr $C$DW$38, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1317 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1317, DW_AT_type(*$C$DW$T$1062) .dwendtag $C$DW$38 .dwendtag $C$DW$T$1064 .dwattr $C$DW$T$1064, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1064, DW_AT_decl_line(0x322) .dwattr $C$DW$T$1064, DW_AT_decl_column(0x10) $C$DW$T$198 .dwtag DW_TAG_typedef, DW_AT_name("ImageEdgeDetection") .dwattr $C$DW$T$198, DW_AT_type(*$C$DW$T$1064) .dwattr $C$DW$T$198, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$198, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$198, DW_AT_decl_line(0x327) .dwattr $C$DW$T$198, DW_AT_decl_column(0x03) $C$DW$T$1061 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1061, DW_AT_type(*$C$DW$T$1064) $C$DW$T$1062 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1062, DW_AT_type(*$C$DW$T$1061) .dwattr $C$DW$T$1062, DW_AT_address_class(0x20) $C$DW$T$1060 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1060, DW_AT_type(*$C$DW$T$1064) .dwattr $C$DW$T$1060, DW_AT_address_class(0x20) $C$DW$T$1063 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1063, DW_AT_type(*$C$DW$T$1060) .dwattr $C$DW$T$1063, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1318 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1318, DW_AT_type(*$C$DW$T$1062) .dwendtag $C$DW$T$1063 $C$DW$T$1071 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1071, DW_AT_name("ImageEdgeDir") .dwattr $C$DW$T$1071, DW_AT_byte_size(0x64) $C$DW$1319 .dwtag DW_TAG_member .dwattr $C$DW$1319, DW_AT_type(*$C$DW$T$1066) .dwattr $C$DW$1319, DW_AT_name("ups") .dwattr $C$DW$1319, DW_AT_TI_symbol_name("ups") .dwattr $C$DW$1319, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1319, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1319, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1319, DW_AT_decl_line(0x8b) .dwattr $C$DW$1319, DW_AT_decl_column(0x0d) $C$DW$39 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$39, DW_AT_declaration .dwattr $C$DW$39, DW_AT_TI_symbol_name("_ZN12ImageEdgeDiraSERKS_") .dwattr $C$DW$39, DW_AT_type(*$C$DW$T$1067) .dwattr $C$DW$39, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1320 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1320, DW_AT_type(*$C$DW$T$1069) .dwendtag $C$DW$39 .dwendtag $C$DW$T$1071 .dwattr $C$DW$T$1071, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$1071, DW_AT_decl_line(0x89) .dwattr $C$DW$T$1071, DW_AT_decl_column(0x08) $C$DW$T$1068 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1068, DW_AT_type(*$C$DW$T$1071) $C$DW$T$1069 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1069, DW_AT_type(*$C$DW$T$1068) .dwattr $C$DW$T$1069, DW_AT_address_class(0x20) $C$DW$T$1067 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1067, DW_AT_type(*$C$DW$T$1071) .dwattr $C$DW$T$1067, DW_AT_address_class(0x20) $C$DW$T$1070 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1070, DW_AT_type(*$C$DW$T$1067) .dwattr $C$DW$T$1070, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1321 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1321, DW_AT_type(*$C$DW$T$1069) .dwendtag $C$DW$T$1070 $C$DW$T$279 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$279, DW_AT_name("ImageEdgeReliability") .dwattr $C$DW$T$279, DW_AT_byte_size(0x14) $C$DW$1322 .dwtag DW_TAG_member .dwattr $C$DW$1322, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1322, DW_AT_name("filRadius") .dwattr $C$DW$1322, DW_AT_TI_symbol_name("filRadius") .dwattr $C$DW$1322, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1322, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1322, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1322, DW_AT_decl_line(0x66) .dwattr $C$DW$1322, DW_AT_decl_column(0x07) $C$DW$40 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$40, DW_AT_declaration .dwattr $C$DW$40, DW_AT_TI_symbol_name("_ZN13XtNamApiParam20ImageEdgeReliabilityaSERKS0_") .dwattr $C$DW$40, DW_AT_type(*$C$DW$T$275) .dwattr $C$DW$40, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1323 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1323, DW_AT_type(*$C$DW$T$277) .dwendtag $C$DW$40 .dwendtag $C$DW$T$279 .dwattr $C$DW$T$279, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$279, DW_AT_decl_line(0x64) .dwattr $C$DW$T$279, DW_AT_decl_column(0x08) $C$DW$T$276 .dwtag DW_TAG_const_type .dwattr $C$DW$T$276, DW_AT_type(*$C$DW$T$279) $C$DW$T$277 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$277, DW_AT_type(*$C$DW$T$276) .dwattr $C$DW$T$277, DW_AT_address_class(0x20) $C$DW$T$275 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$275, DW_AT_type(*$C$DW$T$279) .dwattr $C$DW$T$275, DW_AT_address_class(0x20) $C$DW$T$278 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$278, DW_AT_type(*$C$DW$T$275) .dwattr $C$DW$T$278, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1324 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1324, DW_AT_type(*$C$DW$T$277) .dwendtag $C$DW$T$278 $C$DW$T$1076 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1076, DW_AT_name("ImageEdgeReliability") .dwattr $C$DW$T$1076, DW_AT_byte_size(0xb0) $C$DW$1325 .dwtag DW_TAG_member .dwattr $C$DW$1325, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1325, DW_AT_name("relDrBottom") .dwattr $C$DW$1325, DW_AT_TI_symbol_name("relDrBottom") .dwattr $C$DW$1325, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1325, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1325, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1325, DW_AT_decl_line(0x333) .dwattr $C$DW$1325, DW_AT_decl_column(0x05) $C$DW$1326 .dwtag DW_TAG_member .dwattr $C$DW$1326, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1326, DW_AT_name("relDrTop") .dwattr $C$DW$1326, DW_AT_TI_symbol_name("relDrTop") .dwattr $C$DW$1326, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1326, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1326, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1326, DW_AT_decl_line(0x334) .dwattr $C$DW$1326, DW_AT_decl_column(0x05) $C$DW$1327 .dwtag DW_TAG_member .dwattr $C$DW$1327, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1327, DW_AT_name("reserved") .dwattr $C$DW$1327, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1327, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1327, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1327, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1327, DW_AT_decl_line(0x335) .dwattr $C$DW$1327, DW_AT_decl_column(0x05) $C$DW$41 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$41, DW_AT_declaration .dwattr $C$DW$41, DW_AT_TI_symbol_name("_ZN20ImageEdgeReliabilityaSERKS_") .dwattr $C$DW$41, DW_AT_type(*$C$DW$T$1072) .dwattr $C$DW$41, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1328 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1328, DW_AT_type(*$C$DW$T$1074) .dwendtag $C$DW$41 .dwendtag $C$DW$T$1076 .dwattr $C$DW$T$1076, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1076, DW_AT_decl_line(0x332) .dwattr $C$DW$T$1076, DW_AT_decl_column(0x10) $C$DW$T$200 .dwtag DW_TAG_typedef, DW_AT_name("ImageEdgeReliability") .dwattr $C$DW$T$200, DW_AT_type(*$C$DW$T$1076) .dwattr $C$DW$T$200, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$200, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$200, DW_AT_decl_line(0x336) .dwattr $C$DW$T$200, DW_AT_decl_column(0x03) $C$DW$T$1073 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1073, DW_AT_type(*$C$DW$T$1076) $C$DW$T$1074 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1074, DW_AT_type(*$C$DW$T$1073) .dwattr $C$DW$T$1074, DW_AT_address_class(0x20) $C$DW$T$1072 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1072, DW_AT_type(*$C$DW$T$1076) .dwattr $C$DW$T$1072, DW_AT_address_class(0x20) $C$DW$T$1075 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1075, DW_AT_type(*$C$DW$T$1072) .dwattr $C$DW$T$1075, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1329 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1329, DW_AT_type(*$C$DW$T$1074) .dwendtag $C$DW$T$1075 $C$DW$T$264 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$264, DW_AT_name("ImageEgdeDetection") .dwattr $C$DW$T$264, DW_AT_byte_size(0xe4) $C$DW$1330 .dwtag DW_TAG_member .dwattr $C$DW$1330, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1330, DW_AT_name("dilationRadius") .dwattr $C$DW$1330, DW_AT_TI_symbol_name("dilationRadius") .dwattr $C$DW$1330, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1330, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1330, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1330, DW_AT_decl_line(0x46) .dwattr $C$DW$1330, DW_AT_decl_column(0x09) $C$DW$1331 .dwtag DW_TAG_member .dwattr $C$DW$1331, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1331, DW_AT_name("erosionRadius") .dwattr $C$DW$1331, DW_AT_TI_symbol_name("erosionRadius") .dwattr $C$DW$1331, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1331, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1331, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1331, DW_AT_decl_line(0x47) .dwattr $C$DW$1331, DW_AT_decl_column(0x09) $C$DW$1332 .dwtag DW_TAG_member .dwattr $C$DW$1332, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1332, DW_AT_name("crrgbBase") .dwattr $C$DW$1332, DW_AT_TI_symbol_name("crrgbBase") .dwattr $C$DW$1332, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1332, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1332, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1332, DW_AT_decl_line(0x48) .dwattr $C$DW$1332, DW_AT_decl_column(0x08) $C$DW$1333 .dwtag DW_TAG_member .dwattr $C$DW$1333, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1333, DW_AT_name("crrgbM") .dwattr $C$DW$1333, DW_AT_TI_symbol_name("crrgbM") .dwattr $C$DW$1333, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c] .dwattr $C$DW$1333, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1333, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1333, DW_AT_decl_line(0x49) .dwattr $C$DW$1333, DW_AT_decl_column(0x09) $C$DW$1334 .dwtag DW_TAG_member .dwattr $C$DW$1334, DW_AT_type(*$C$DW$T$259) .dwattr $C$DW$1334, DW_AT_name("rankCoef") .dwattr $C$DW$1334, DW_AT_TI_symbol_name("rankCoef") .dwattr $C$DW$1334, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1334, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1334, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1334, DW_AT_decl_line(0x4a) .dwattr $C$DW$1334, DW_AT_decl_column(0x09) $C$DW$1335 .dwtag DW_TAG_member .dwattr $C$DW$1335, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1335, DW_AT_name("smoothRadius") .dwattr $C$DW$1335, DW_AT_TI_symbol_name("smoothRadius") .dwattr $C$DW$1335, DW_AT_data_member_location[DW_OP_plus_uconst 0x94] .dwattr $C$DW$1335, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1335, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1335, DW_AT_decl_line(0x4c) .dwattr $C$DW$1335, DW_AT_decl_column(0x08) $C$DW$1336 .dwtag DW_TAG_member .dwattr $C$DW$1336, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1336, DW_AT_name("smoothSigma") .dwattr $C$DW$1336, DW_AT_TI_symbol_name("smoothSigma") .dwattr $C$DW$1336, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$1336, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1336, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1336, DW_AT_decl_line(0x4d) .dwattr $C$DW$1336, DW_AT_decl_column(0x09) $C$DW$1337 .dwtag DW_TAG_member .dwattr $C$DW$1337, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1337, DW_AT_name("engTblNum") .dwattr $C$DW$1337, DW_AT_TI_symbol_name("engTblNum") .dwattr $C$DW$1337, DW_AT_data_member_location[DW_OP_plus_uconst 0xbc] .dwattr $C$DW$1337, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1337, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1337, DW_AT_decl_line(0x4f) .dwattr $C$DW$1337, DW_AT_decl_column(0x08) $C$DW$1338 .dwtag DW_TAG_member .dwattr $C$DW$1338, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1338, DW_AT_name("engTblAccuracy") .dwattr $C$DW$1338, DW_AT_TI_symbol_name("engTblAccuracy") .dwattr $C$DW$1338, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0] .dwattr $C$DW$1338, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1338, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1338, DW_AT_decl_line(0x50) .dwattr $C$DW$1338, DW_AT_decl_column(0x08) $C$DW$42 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$42, DW_AT_declaration .dwattr $C$DW$42, DW_AT_TI_symbol_name("_ZN13XtNamApiParam18ImageEgdeDetectionaSERKS0_") .dwattr $C$DW$42, DW_AT_type(*$C$DW$T$260) .dwattr $C$DW$42, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1339 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1339, DW_AT_type(*$C$DW$T$262) .dwendtag $C$DW$42 .dwendtag $C$DW$T$264 .dwattr $C$DW$T$264, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$264, DW_AT_decl_line(0x44) .dwattr $C$DW$T$264, DW_AT_decl_column(0x08) $C$DW$T$261 .dwtag DW_TAG_const_type .dwattr $C$DW$T$261, DW_AT_type(*$C$DW$T$264) $C$DW$T$262 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$262, DW_AT_type(*$C$DW$T$261) .dwattr $C$DW$T$262, DW_AT_address_class(0x20) $C$DW$T$385 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$385, DW_AT_type(*$C$DW$T$261) .dwattr $C$DW$T$385, DW_AT_address_class(0x20) $C$DW$T$260 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$260, DW_AT_type(*$C$DW$T$264) .dwattr $C$DW$T$260, DW_AT_address_class(0x20) $C$DW$T$263 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$263, DW_AT_type(*$C$DW$T$260) .dwattr $C$DW$T$263, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1340 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1340, DW_AT_type(*$C$DW$T$262) .dwendtag $C$DW$T$263 $C$DW$T$269 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$269, DW_AT_name("ImageEgdeDirection") .dwattr $C$DW$T$269, DW_AT_byte_size(0xa0) $C$DW$1341 .dwtag DW_TAG_member .dwattr $C$DW$1341, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1341, DW_AT_name("aveFilRadius") .dwattr $C$DW$1341, DW_AT_TI_symbol_name("aveFilRadius") .dwattr $C$DW$1341, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1341, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1341, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1341, DW_AT_decl_line(0x59) .dwattr $C$DW$1341, DW_AT_decl_column(0x07) $C$DW$1342 .dwtag DW_TAG_member .dwattr $C$DW$1342, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1342, DW_AT_name("aveFilSigma") .dwattr $C$DW$1342, DW_AT_TI_symbol_name("aveFilSigma") .dwattr $C$DW$1342, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1342, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1342, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1342, DW_AT_decl_line(0x5a) .dwattr $C$DW$1342, DW_AT_decl_column(0x08) $C$DW$1343 .dwtag DW_TAG_member .dwattr $C$DW$1343, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1343, DW_AT_name("aveW") .dwattr $C$DW$1343, DW_AT_TI_symbol_name("aveW") .dwattr $C$DW$1343, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1343, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1343, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1343, DW_AT_decl_line(0x5b) .dwattr $C$DW$1343, DW_AT_decl_column(0x09) $C$DW$1344 .dwtag DW_TAG_member .dwattr $C$DW$1344, DW_AT_type(*$C$DW$T$259) .dwattr $C$DW$1344, DW_AT_name("rankCoef") .dwattr $C$DW$1344, DW_AT_TI_symbol_name("rankCoef") .dwattr $C$DW$1344, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c] .dwattr $C$DW$1344, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1344, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1344, DW_AT_decl_line(0x5c) .dwattr $C$DW$1344, DW_AT_decl_column(0x08) $C$DW$43 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$43, DW_AT_declaration .dwattr $C$DW$43, DW_AT_TI_symbol_name("_ZN13XtNamApiParam18ImageEgdeDirectionaSERKS0_") .dwattr $C$DW$43, DW_AT_type(*$C$DW$T$265) .dwattr $C$DW$43, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1345 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1345, DW_AT_type(*$C$DW$T$267) .dwendtag $C$DW$43 .dwendtag $C$DW$T$269 .dwattr $C$DW$T$269, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$269, DW_AT_decl_line(0x57) .dwattr $C$DW$T$269, DW_AT_decl_column(0x08) $C$DW$T$266 .dwtag DW_TAG_const_type .dwattr $C$DW$T$266, DW_AT_type(*$C$DW$T$269) $C$DW$T$267 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$267, DW_AT_type(*$C$DW$T$266) .dwattr $C$DW$T$267, DW_AT_address_class(0x20) $C$DW$T$384 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$384, DW_AT_type(*$C$DW$T$266) .dwattr $C$DW$T$384, DW_AT_address_class(0x20) $C$DW$T$265 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$265, DW_AT_type(*$C$DW$T$269) .dwattr $C$DW$T$265, DW_AT_address_class(0x20) $C$DW$T$268 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$268, DW_AT_type(*$C$DW$T$265) .dwattr $C$DW$T$268, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1346 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1346, DW_AT_type(*$C$DW$T$267) .dwendtag $C$DW$T$268 $C$DW$T$1081 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1081, DW_AT_name("ImageEgdeDirection") .dwattr $C$DW$T$1081, DW_AT_byte_size(0x118) $C$DW$1347 .dwtag DW_TAG_member .dwattr $C$DW$1347, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1347, DW_AT_name("aveFilRadius") .dwattr $C$DW$1347, DW_AT_TI_symbol_name("aveFilRadius") .dwattr $C$DW$1347, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1347, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1347, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1347, DW_AT_decl_line(0x32b) .dwattr $C$DW$1347, DW_AT_decl_column(0x05) $C$DW$1348 .dwtag DW_TAG_member .dwattr $C$DW$1348, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1348, DW_AT_name("aveFilSigma") .dwattr $C$DW$1348, DW_AT_TI_symbol_name("aveFilSigma") .dwattr $C$DW$1348, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1348, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1348, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1348, DW_AT_decl_line(0x32c) .dwattr $C$DW$1348, DW_AT_decl_column(0x05) $C$DW$1349 .dwtag DW_TAG_member .dwattr $C$DW$1349, DW_AT_type(*$C$DW$T$1059) .dwattr $C$DW$1349, DW_AT_name("rankCoef") .dwattr $C$DW$1349, DW_AT_TI_symbol_name("rankCoef") .dwattr $C$DW$1349, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1349, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1349, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1349, DW_AT_decl_line(0x32d) .dwattr $C$DW$1349, DW_AT_decl_column(0x05) $C$DW$1350 .dwtag DW_TAG_member .dwattr $C$DW$1350, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1350, DW_AT_name("reserved") .dwattr $C$DW$1350, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1350, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$1350, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1350, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1350, DW_AT_decl_line(0x32e) .dwattr $C$DW$1350, DW_AT_decl_column(0x05) $C$DW$44 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$44, DW_AT_declaration .dwattr $C$DW$44, DW_AT_TI_symbol_name("_ZN18ImageEgdeDirectionaSERKS_") .dwattr $C$DW$44, DW_AT_type(*$C$DW$T$1077) .dwattr $C$DW$44, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1351 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1351, DW_AT_type(*$C$DW$T$1079) .dwendtag $C$DW$44 .dwendtag $C$DW$T$1081 .dwattr $C$DW$T$1081, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1081, DW_AT_decl_line(0x32a) .dwattr $C$DW$T$1081, DW_AT_decl_column(0x10) $C$DW$T$199 .dwtag DW_TAG_typedef, DW_AT_name("ImageEgdeDirection") .dwattr $C$DW$T$199, DW_AT_type(*$C$DW$T$1081) .dwattr $C$DW$T$199, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$199, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$199, DW_AT_decl_line(0x32f) .dwattr $C$DW$T$199, DW_AT_decl_column(0x03) $C$DW$T$1078 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1078, DW_AT_type(*$C$DW$T$1081) $C$DW$T$1079 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1079, DW_AT_type(*$C$DW$T$1078) .dwattr $C$DW$T$1079, DW_AT_address_class(0x20) $C$DW$T$1077 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1077, DW_AT_type(*$C$DW$T$1081) .dwattr $C$DW$T$1077, DW_AT_address_class(0x20) $C$DW$T$1080 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1080, DW_AT_type(*$C$DW$T$1077) .dwattr $C$DW$T$1080, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1352 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1352, DW_AT_type(*$C$DW$T$1079) .dwendtag $C$DW$T$1080 $C$DW$T$242 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$242, DW_AT_name("ImageEmphasis") .dwattr $C$DW$T$242, DW_AT_byte_size(0xa0) $C$DW$1353 .dwtag DW_TAG_member .dwattr $C$DW$1353, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1353, DW_AT_name("mulW") .dwattr $C$DW$1353, DW_AT_TI_symbol_name("mulW") .dwattr $C$DW$1353, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1353, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1353, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1353, DW_AT_decl_line(0x6f) .dwattr $C$DW$1353, DW_AT_decl_column(0x08) $C$DW$1354 .dwtag DW_TAG_member .dwattr $C$DW$1354, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1354, DW_AT_name("thW") .dwattr $C$DW$1354, DW_AT_TI_symbol_name("thW") .dwattr $C$DW$1354, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1354, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1354, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1354, DW_AT_decl_line(0x70) .dwattr $C$DW$1354, DW_AT_decl_column(0x07) $C$DW$1355 .dwtag DW_TAG_member .dwattr $C$DW$1355, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1355, DW_AT_name("cW") .dwattr $C$DW$1355, DW_AT_TI_symbol_name("cW") .dwattr $C$DW$1355, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1355, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1355, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1355, DW_AT_decl_line(0x71) .dwattr $C$DW$1355, DW_AT_decl_column(0x08) $C$DW$1356 .dwtag DW_TAG_member .dwattr $C$DW$1356, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1356, DW_AT_name("bW") .dwattr $C$DW$1356, DW_AT_TI_symbol_name("bW") .dwattr $C$DW$1356, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c] .dwattr $C$DW$1356, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1356, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1356, DW_AT_decl_line(0x72) .dwattr $C$DW$1356, DW_AT_decl_column(0x08) $C$DW$1357 .dwtag DW_TAG_member .dwattr $C$DW$1357, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1357, DW_AT_name("mulB") .dwattr $C$DW$1357, DW_AT_TI_symbol_name("mulB") .dwattr $C$DW$1357, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$1357, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1357, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1357, DW_AT_decl_line(0x73) .dwattr $C$DW$1357, DW_AT_decl_column(0x08) $C$DW$1358 .dwtag DW_TAG_member .dwattr $C$DW$1358, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1358, DW_AT_name("thB") .dwattr $C$DW$1358, DW_AT_TI_symbol_name("thB") .dwattr $C$DW$1358, DW_AT_data_member_location[DW_OP_plus_uconst 0x64] .dwattr $C$DW$1358, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1358, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1358, DW_AT_decl_line(0x74) .dwattr $C$DW$1358, DW_AT_decl_column(0x07) $C$DW$1359 .dwtag DW_TAG_member .dwattr $C$DW$1359, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1359, DW_AT_name("cB") .dwattr $C$DW$1359, DW_AT_TI_symbol_name("cB") .dwattr $C$DW$1359, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1359, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1359, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1359, DW_AT_decl_line(0x75) .dwattr $C$DW$1359, DW_AT_decl_column(0x08) $C$DW$1360 .dwtag DW_TAG_member .dwattr $C$DW$1360, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1360, DW_AT_name("bB") .dwattr $C$DW$1360, DW_AT_TI_symbol_name("bB") .dwattr $C$DW$1360, DW_AT_data_member_location[DW_OP_plus_uconst 0x8c] .dwattr $C$DW$1360, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1360, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1360, DW_AT_decl_line(0x76) .dwattr $C$DW$1360, DW_AT_decl_column(0x08) $C$DW$45 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$45, DW_AT_declaration .dwattr $C$DW$45, DW_AT_TI_symbol_name("_ZN13XtNamApiParam13ImageEmphasisaSERKS0_") .dwattr $C$DW$45, DW_AT_type(*$C$DW$T$238) .dwattr $C$DW$45, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1361 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1361, DW_AT_type(*$C$DW$T$240) .dwendtag $C$DW$45 .dwendtag $C$DW$T$242 .dwattr $C$DW$T$242, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$242, DW_AT_decl_line(0x6d) .dwattr $C$DW$T$242, DW_AT_decl_column(0x08) $C$DW$T$239 .dwtag DW_TAG_const_type .dwattr $C$DW$T$239, DW_AT_type(*$C$DW$T$242) $C$DW$T$240 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$240, DW_AT_type(*$C$DW$T$239) .dwattr $C$DW$T$240, DW_AT_address_class(0x20) $C$DW$T$238 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$238, DW_AT_type(*$C$DW$T$242) .dwattr $C$DW$T$238, DW_AT_address_class(0x20) $C$DW$T$241 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$241, DW_AT_type(*$C$DW$T$238) .dwattr $C$DW$T$241, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1362 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1362, DW_AT_type(*$C$DW$T$240) .dwendtag $C$DW$T$241 $C$DW$T$1086 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1086, DW_AT_name("ImageEmphasis") .dwattr $C$DW$T$1086, DW_AT_byte_size(0x140) $C$DW$1363 .dwtag DW_TAG_member .dwattr $C$DW$1363, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1363, DW_AT_name("mulW") .dwattr $C$DW$1363, DW_AT_TI_symbol_name("mulW") .dwattr $C$DW$1363, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1363, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1363, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1363, DW_AT_decl_line(0x33a) .dwattr $C$DW$1363, DW_AT_decl_column(0x05) $C$DW$1364 .dwtag DW_TAG_member .dwattr $C$DW$1364, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1364, DW_AT_name("thW") .dwattr $C$DW$1364, DW_AT_TI_symbol_name("thW") .dwattr $C$DW$1364, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1364, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1364, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1364, DW_AT_decl_line(0x33b) .dwattr $C$DW$1364, DW_AT_decl_column(0x05) $C$DW$1365 .dwtag DW_TAG_member .dwattr $C$DW$1365, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1365, DW_AT_name("cW") .dwattr $C$DW$1365, DW_AT_TI_symbol_name("cW") .dwattr $C$DW$1365, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1365, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1365, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1365, DW_AT_decl_line(0x33c) .dwattr $C$DW$1365, DW_AT_decl_column(0x05) $C$DW$1366 .dwtag DW_TAG_member .dwattr $C$DW$1366, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1366, DW_AT_name("bW") .dwattr $C$DW$1366, DW_AT_TI_symbol_name("bW") .dwattr $C$DW$1366, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$1366, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1366, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1366, DW_AT_decl_line(0x33d) .dwattr $C$DW$1366, DW_AT_decl_column(0x05) $C$DW$1367 .dwtag DW_TAG_member .dwattr $C$DW$1367, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1367, DW_AT_name("mulB") .dwattr $C$DW$1367, DW_AT_TI_symbol_name("mulB") .dwattr $C$DW$1367, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$1367, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1367, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1367, DW_AT_decl_line(0x33e) .dwattr $C$DW$1367, DW_AT_decl_column(0x05) $C$DW$1368 .dwtag DW_TAG_member .dwattr $C$DW$1368, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1368, DW_AT_name("thB") .dwattr $C$DW$1368, DW_AT_TI_symbol_name("thB") .dwattr $C$DW$1368, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1368, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1368, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1368, DW_AT_decl_line(0x33f) .dwattr $C$DW$1368, DW_AT_decl_column(0x05) $C$DW$1369 .dwtag DW_TAG_member .dwattr $C$DW$1369, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1369, DW_AT_name("cB") .dwattr $C$DW$1369, DW_AT_TI_symbol_name("cB") .dwattr $C$DW$1369, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$1369, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1369, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1369, DW_AT_decl_line(0x340) .dwattr $C$DW$1369, DW_AT_decl_column(0x05) $C$DW$1370 .dwtag DW_TAG_member .dwattr $C$DW$1370, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1370, DW_AT_name("bB") .dwattr $C$DW$1370, DW_AT_TI_symbol_name("bB") .dwattr $C$DW$1370, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$1370, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1370, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1370, DW_AT_decl_line(0x341) .dwattr $C$DW$1370, DW_AT_decl_column(0x05) $C$DW$1371 .dwtag DW_TAG_member .dwattr $C$DW$1371, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1371, DW_AT_name("reserved") .dwattr $C$DW$1371, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1371, DW_AT_data_member_location[DW_OP_plus_uconst 0xc0] .dwattr $C$DW$1371, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1371, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1371, DW_AT_decl_line(0x342) .dwattr $C$DW$1371, DW_AT_decl_column(0x05) $C$DW$46 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$46, DW_AT_declaration .dwattr $C$DW$46, DW_AT_TI_symbol_name("_ZN13ImageEmphasisaSERKS_") .dwattr $C$DW$46, DW_AT_type(*$C$DW$T$1082) .dwattr $C$DW$46, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1372 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1372, DW_AT_type(*$C$DW$T$1084) .dwendtag $C$DW$46 .dwendtag $C$DW$T$1086 .dwattr $C$DW$T$1086, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1086, DW_AT_decl_line(0x339) .dwattr $C$DW$T$1086, DW_AT_decl_column(0x10) $C$DW$T$201 .dwtag DW_TAG_typedef, DW_AT_name("ImageEmphasis") .dwattr $C$DW$T$201, DW_AT_type(*$C$DW$T$1086) .dwattr $C$DW$T$201, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$201, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$201, DW_AT_decl_line(0x343) .dwattr $C$DW$T$201, DW_AT_decl_column(0x03) $C$DW$T$1083 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1083, DW_AT_type(*$C$DW$T$1086) $C$DW$T$1084 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1084, DW_AT_type(*$C$DW$T$1083) .dwattr $C$DW$T$1084, DW_AT_address_class(0x20) $C$DW$T$1082 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1082, DW_AT_type(*$C$DW$T$1086) .dwattr $C$DW$T$1082, DW_AT_address_class(0x20) $C$DW$T$1085 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1085, DW_AT_type(*$C$DW$T$1082) .dwattr $C$DW$T$1085, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1373 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1373, DW_AT_type(*$C$DW$T$1084) .dwendtag $C$DW$T$1085 $C$DW$T$1093 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1093, DW_AT_name("ImageFTC") .dwattr $C$DW$T$1093, DW_AT_byte_size(0xb0) $C$DW$1374 .dwtag DW_TAG_member .dwattr $C$DW$1374, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1374, DW_AT_name("mode") .dwattr $C$DW$1374, DW_AT_TI_symbol_name("mode") .dwattr $C$DW$1374, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1374, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1374, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1374, DW_AT_decl_line(0x363) .dwattr $C$DW$1374, DW_AT_decl_column(0x05) $C$DW$1375 .dwtag DW_TAG_member .dwattr $C$DW$1375, DW_AT_type(*$C$DW$T$1087) .dwattr $C$DW$1375, DW_AT_name("radius") .dwattr $C$DW$1375, DW_AT_TI_symbol_name("radius") .dwattr $C$DW$1375, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1375, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1375, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1375, DW_AT_decl_line(0x364) .dwattr $C$DW$1375, DW_AT_decl_column(0x05) $C$DW$1376 .dwtag DW_TAG_member .dwattr $C$DW$1376, DW_AT_type(*$C$DW$T$1087) .dwattr $C$DW$1376, DW_AT_name("intBottom") .dwattr $C$DW$1376, DW_AT_TI_symbol_name("intBottom") .dwattr $C$DW$1376, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1376, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1376, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1376, DW_AT_decl_line(0x365) .dwattr $C$DW$1376, DW_AT_decl_column(0x05) $C$DW$1377 .dwtag DW_TAG_member .dwattr $C$DW$1377, DW_AT_type(*$C$DW$T$1087) .dwattr $C$DW$1377, DW_AT_name("intTop") .dwattr $C$DW$1377, DW_AT_TI_symbol_name("intTop") .dwattr $C$DW$1377, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1377, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1377, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1377, DW_AT_decl_line(0x366) .dwattr $C$DW$1377, DW_AT_decl_column(0x05) $C$DW$1378 .dwtag DW_TAG_member .dwattr $C$DW$1378, DW_AT_type(*$C$DW$T$1088) .dwattr $C$DW$1378, DW_AT_name("coefBottom") .dwattr $C$DW$1378, DW_AT_TI_symbol_name("coefBottom") .dwattr $C$DW$1378, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1378, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1378, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1378, DW_AT_decl_line(0x367) .dwattr $C$DW$1378, DW_AT_decl_column(0x05) $C$DW$1379 .dwtag DW_TAG_member .dwattr $C$DW$1379, DW_AT_type(*$C$DW$T$1088) .dwattr $C$DW$1379, DW_AT_name("coefTop") .dwattr $C$DW$1379, DW_AT_TI_symbol_name("coefTop") .dwattr $C$DW$1379, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1379, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1379, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1379, DW_AT_decl_line(0x368) .dwattr $C$DW$1379, DW_AT_decl_column(0x05) $C$DW$1380 .dwtag DW_TAG_member .dwattr $C$DW$1380, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1380, DW_AT_name("reserved") .dwattr $C$DW$1380, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1380, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1380, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1380, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1380, DW_AT_decl_line(0x369) .dwattr $C$DW$1380, DW_AT_decl_column(0x05) $C$DW$47 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$47, DW_AT_declaration .dwattr $C$DW$47, DW_AT_TI_symbol_name("_ZN8ImageFTCaSERKS_") .dwattr $C$DW$47, DW_AT_type(*$C$DW$T$1089) .dwattr $C$DW$47, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1381 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1381, DW_AT_type(*$C$DW$T$1091) .dwendtag $C$DW$47 .dwendtag $C$DW$T$1093 .dwattr $C$DW$T$1093, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1093, DW_AT_decl_line(0x362) .dwattr $C$DW$T$1093, DW_AT_decl_column(0x10) $C$DW$T$205 .dwtag DW_TAG_typedef, DW_AT_name("ImageFTC") .dwattr $C$DW$T$205, DW_AT_type(*$C$DW$T$1093) .dwattr $C$DW$T$205, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$205, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$205, DW_AT_decl_line(0x36a) .dwattr $C$DW$T$205, DW_AT_decl_column(0x03) $C$DW$T$1090 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1090, DW_AT_type(*$C$DW$T$1093) $C$DW$T$1091 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1091, DW_AT_type(*$C$DW$T$1090) .dwattr $C$DW$T$1091, DW_AT_address_class(0x20) $C$DW$T$1089 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1089, DW_AT_type(*$C$DW$T$1093) .dwattr $C$DW$T$1089, DW_AT_address_class(0x20) $C$DW$T$1092 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1092, DW_AT_type(*$C$DW$T$1089) .dwattr $C$DW$T$1092, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1382 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1382, DW_AT_type(*$C$DW$T$1091) .dwendtag $C$DW$T$1092 $C$DW$T$290 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$290, DW_AT_name("ImageFill") .dwattr $C$DW$T$290, DW_AT_byte_size(0x80) $C$DW$1383 .dwtag DW_TAG_member .dwattr $C$DW$1383, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1383, DW_AT_name("patternNwM") .dwattr $C$DW$1383, DW_AT_TI_symbol_name("patternNwM") .dwattr $C$DW$1383, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1383, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1383, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1383, DW_AT_decl_line(0x29) .dwattr $C$DW$1383, DW_AT_decl_column(0x08) $C$DW$1384 .dwtag DW_TAG_member .dwattr $C$DW$1384, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1384, DW_AT_name("patternNwS") .dwattr $C$DW$1384, DW_AT_TI_symbol_name("patternNwS") .dwattr $C$DW$1384, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1384, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1384, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1384, DW_AT_decl_line(0x2a) .dwattr $C$DW$1384, DW_AT_decl_column(0x08) $C$DW$1385 .dwtag DW_TAG_member .dwattr $C$DW$1385, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1385, DW_AT_name("ptMaskH") .dwattr $C$DW$1385, DW_AT_TI_symbol_name("ptMaskH") .dwattr $C$DW$1385, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1385, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1385, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1385, DW_AT_decl_line(0x2b) .dwattr $C$DW$1385, DW_AT_decl_column(0x08) $C$DW$1386 .dwtag DW_TAG_member .dwattr $C$DW$1386, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1386, DW_AT_name("ptMaskW") .dwattr $C$DW$1386, DW_AT_TI_symbol_name("ptMaskW") .dwattr $C$DW$1386, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1386, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1386, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1386, DW_AT_decl_line(0x2c) .dwattr $C$DW$1386, DW_AT_decl_column(0x08) $C$DW$1387 .dwtag DW_TAG_member .dwattr $C$DW$1387, DW_AT_type(*$C$DW$T$285) .dwattr $C$DW$1387, DW_AT_name("ptMask") .dwattr $C$DW$1387, DW_AT_TI_symbol_name("ptMask") .dwattr $C$DW$1387, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1387, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1387, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1387, DW_AT_decl_line(0x2d) .dwattr $C$DW$1387, DW_AT_decl_column(0x09) $C$DW$1388 .dwtag DW_TAG_member .dwattr $C$DW$1388, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1388, DW_AT_name("patternWeight") .dwattr $C$DW$1388, DW_AT_TI_symbol_name("patternWeight") .dwattr $C$DW$1388, DW_AT_data_member_location[DW_OP_plus_uconst 0x74] .dwattr $C$DW$1388, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1388, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1388, DW_AT_decl_line(0x2f) .dwattr $C$DW$1388, DW_AT_decl_column(0x09) $C$DW$1389 .dwtag DW_TAG_member .dwattr $C$DW$1389, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1389, DW_AT_name("ptBackBase") .dwattr $C$DW$1389, DW_AT_TI_symbol_name("ptBackBase") .dwattr $C$DW$1389, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1389, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1389, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1389, DW_AT_decl_line(0x30) .dwattr $C$DW$1389, DW_AT_decl_column(0x08) $C$DW$1390 .dwtag DW_TAG_member .dwattr $C$DW$1390, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1390, DW_AT_name("ptBackM") .dwattr $C$DW$1390, DW_AT_TI_symbol_name("ptBackM") .dwattr $C$DW$1390, DW_AT_data_member_location[DW_OP_plus_uconst 0x7c] .dwattr $C$DW$1390, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1390, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1390, DW_AT_decl_line(0x31) .dwattr $C$DW$1390, DW_AT_decl_column(0x09) $C$DW$48 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$48, DW_AT_declaration .dwattr $C$DW$48, DW_AT_TI_symbol_name("_ZN13XtNamApiParam9ImageFillaSERKS0_") .dwattr $C$DW$48, DW_AT_type(*$C$DW$T$286) .dwattr $C$DW$48, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1391 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1391, DW_AT_type(*$C$DW$T$288) .dwendtag $C$DW$48 .dwendtag $C$DW$T$290 .dwattr $C$DW$T$290, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$290, DW_AT_decl_line(0x27) .dwattr $C$DW$T$290, DW_AT_decl_column(0x08) $C$DW$T$287 .dwtag DW_TAG_const_type .dwattr $C$DW$T$287, DW_AT_type(*$C$DW$T$290) $C$DW$T$288 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$288, DW_AT_type(*$C$DW$T$287) .dwattr $C$DW$T$288, DW_AT_address_class(0x20) $C$DW$T$286 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$286, DW_AT_type(*$C$DW$T$290) .dwattr $C$DW$T$286, DW_AT_address_class(0x20) $C$DW$T$289 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$289, DW_AT_type(*$C$DW$T$286) .dwattr $C$DW$T$289, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1392 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1392, DW_AT_type(*$C$DW$T$288) .dwendtag $C$DW$T$289 $C$DW$T$1099 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1099, DW_AT_name("ImageFill") .dwattr $C$DW$T$1099, DW_AT_byte_size(0x120) $C$DW$1393 .dwtag DW_TAG_member .dwattr $C$DW$1393, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1393, DW_AT_name("patternNwM") .dwattr $C$DW$1393, DW_AT_TI_symbol_name("patternNwM") .dwattr $C$DW$1393, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1393, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1393, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1393, DW_AT_decl_line(0x30f) .dwattr $C$DW$1393, DW_AT_decl_column(0x05) $C$DW$1394 .dwtag DW_TAG_member .dwattr $C$DW$1394, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1394, DW_AT_name("patternNwS") .dwattr $C$DW$1394, DW_AT_TI_symbol_name("patternNwS") .dwattr $C$DW$1394, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1394, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1394, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1394, DW_AT_decl_line(0x310) .dwattr $C$DW$1394, DW_AT_decl_column(0x05) $C$DW$1395 .dwtag DW_TAG_member .dwattr $C$DW$1395, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1395, DW_AT_name("ptMaskH") .dwattr $C$DW$1395, DW_AT_TI_symbol_name("ptMaskH") .dwattr $C$DW$1395, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1395, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1395, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1395, DW_AT_decl_line(0x311) .dwattr $C$DW$1395, DW_AT_decl_column(0x05) $C$DW$1396 .dwtag DW_TAG_member .dwattr $C$DW$1396, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1396, DW_AT_name("ptMaskW") .dwattr $C$DW$1396, DW_AT_TI_symbol_name("ptMaskW") .dwattr $C$DW$1396, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1396, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1396, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1396, DW_AT_decl_line(0x312) .dwattr $C$DW$1396, DW_AT_decl_column(0x05) $C$DW$1397 .dwtag DW_TAG_member .dwattr $C$DW$1397, DW_AT_type(*$C$DW$T$1094) .dwattr $C$DW$1397, DW_AT_name("ptMask") .dwattr $C$DW$1397, DW_AT_TI_symbol_name("ptMask") .dwattr $C$DW$1397, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1397, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1397, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1397, DW_AT_decl_line(0x313) .dwattr $C$DW$1397, DW_AT_decl_column(0x05) $C$DW$1398 .dwtag DW_TAG_member .dwattr $C$DW$1398, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1398, DW_AT_name("patternWeight") .dwattr $C$DW$1398, DW_AT_TI_symbol_name("patternWeight") .dwattr $C$DW$1398, DW_AT_data_member_location[DW_OP_plus_uconst 0x88] .dwattr $C$DW$1398, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1398, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1398, DW_AT_decl_line(0x314) .dwattr $C$DW$1398, DW_AT_decl_column(0x05) $C$DW$1399 .dwtag DW_TAG_member .dwattr $C$DW$1399, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1399, DW_AT_name("ptBackBase") .dwattr $C$DW$1399, DW_AT_TI_symbol_name("ptBackBase") .dwattr $C$DW$1399, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$1399, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1399, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1399, DW_AT_decl_line(0x315) .dwattr $C$DW$1399, DW_AT_decl_column(0x05) $C$DW$1400 .dwtag DW_TAG_member .dwattr $C$DW$1400, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1400, DW_AT_name("ptBackM") .dwattr $C$DW$1400, DW_AT_TI_symbol_name("ptBackM") .dwattr $C$DW$1400, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$1400, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1400, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1400, DW_AT_decl_line(0x316) .dwattr $C$DW$1400, DW_AT_decl_column(0x05) $C$DW$1401 .dwtag DW_TAG_member .dwattr $C$DW$1401, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1401, DW_AT_name("reserved") .dwattr $C$DW$1401, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1401, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0] .dwattr $C$DW$1401, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1401, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1401, DW_AT_decl_line(0x317) .dwattr $C$DW$1401, DW_AT_decl_column(0x05) $C$DW$49 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$49, DW_AT_declaration .dwattr $C$DW$49, DW_AT_TI_symbol_name("_ZN9ImageFillaSERKS_") .dwattr $C$DW$49, DW_AT_type(*$C$DW$T$1095) .dwattr $C$DW$49, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1402 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1402, DW_AT_type(*$C$DW$T$1097) .dwendtag $C$DW$49 .dwendtag $C$DW$T$1099 .dwattr $C$DW$T$1099, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1099, DW_AT_decl_line(0x30e) .dwattr $C$DW$T$1099, DW_AT_decl_column(0x10) $C$DW$T$196 .dwtag DW_TAG_typedef, DW_AT_name("ImageFill") .dwattr $C$DW$T$196, DW_AT_type(*$C$DW$T$1099) .dwattr $C$DW$T$196, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$196, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$196, DW_AT_decl_line(0x318) .dwattr $C$DW$T$196, DW_AT_decl_column(0x03) $C$DW$T$1096 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1096, DW_AT_type(*$C$DW$T$1099) $C$DW$T$1097 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1097, DW_AT_type(*$C$DW$T$1096) .dwattr $C$DW$T$1097, DW_AT_address_class(0x20) $C$DW$T$1095 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1095, DW_AT_type(*$C$DW$T$1099) .dwattr $C$DW$T$1095, DW_AT_address_class(0x20) $C$DW$T$1098 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1098, DW_AT_type(*$C$DW$T$1095) .dwattr $C$DW$T$1098, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1403 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1403, DW_AT_type(*$C$DW$T$1097) .dwendtag $C$DW$T$1098 $C$DW$T$247 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$247, DW_AT_name("ImageGaussian") .dwattr $C$DW$T$247, DW_AT_byte_size(0x08) $C$DW$1404 .dwtag DW_TAG_member .dwattr $C$DW$1404, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1404, DW_AT_name("sigma") .dwattr $C$DW$1404, DW_AT_TI_symbol_name("sigma") .dwattr $C$DW$1404, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1404, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1404, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1404, DW_AT_decl_line(0x3b) .dwattr $C$DW$1404, DW_AT_decl_column(0x08) $C$DW$1405 .dwtag DW_TAG_member .dwattr $C$DW$1405, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1405, DW_AT_name("radius") .dwattr $C$DW$1405, DW_AT_TI_symbol_name("radius") .dwattr $C$DW$1405, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1405, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1405, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1405, DW_AT_decl_line(0x3c) .dwattr $C$DW$1405, DW_AT_decl_column(0x07) $C$DW$50 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$50, DW_AT_declaration .dwattr $C$DW$50, DW_AT_TI_symbol_name("_ZN13XtNamApiParam13ImageGaussianaSERKS0_") .dwattr $C$DW$50, DW_AT_type(*$C$DW$T$243) .dwattr $C$DW$50, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1406 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1406, DW_AT_type(*$C$DW$T$245) .dwendtag $C$DW$50 .dwendtag $C$DW$T$247 .dwattr $C$DW$T$247, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$247, DW_AT_decl_line(0x39) .dwattr $C$DW$T$247, DW_AT_decl_column(0x08) $C$DW$T$244 .dwtag DW_TAG_const_type .dwattr $C$DW$T$244, DW_AT_type(*$C$DW$T$247) $C$DW$T$245 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$245, DW_AT_type(*$C$DW$T$244) .dwattr $C$DW$T$245, DW_AT_address_class(0x20) $C$DW$T$243 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$243, DW_AT_type(*$C$DW$T$247) .dwattr $C$DW$T$243, DW_AT_address_class(0x20) $C$DW$T$246 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$246, DW_AT_type(*$C$DW$T$243) .dwattr $C$DW$T$246, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1407 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1407, DW_AT_type(*$C$DW$T$245) .dwendtag $C$DW$T$246 $C$DW$T$1104 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1104, DW_AT_name("ImageGaussian") .dwattr $C$DW$T$1104, DW_AT_byte_size(0x90) $C$DW$1408 .dwtag DW_TAG_member .dwattr $C$DW$1408, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1408, DW_AT_name("sigma") .dwattr $C$DW$1408, DW_AT_TI_symbol_name("sigma") .dwattr $C$DW$1408, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1408, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1408, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1408, DW_AT_decl_line(0x31c) .dwattr $C$DW$1408, DW_AT_decl_column(0x05) $C$DW$1409 .dwtag DW_TAG_member .dwattr $C$DW$1409, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1409, DW_AT_name("radius") .dwattr $C$DW$1409, DW_AT_TI_symbol_name("radius") .dwattr $C$DW$1409, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1409, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1409, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1409, DW_AT_decl_line(0x31d) .dwattr $C$DW$1409, DW_AT_decl_column(0x05) $C$DW$1410 .dwtag DW_TAG_member .dwattr $C$DW$1410, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1410, DW_AT_name("reserved") .dwattr $C$DW$1410, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1410, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1410, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1410, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1410, DW_AT_decl_line(0x31e) .dwattr $C$DW$1410, DW_AT_decl_column(0x05) $C$DW$51 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$51, DW_AT_declaration .dwattr $C$DW$51, DW_AT_TI_symbol_name("_ZN13ImageGaussianaSERKS_") .dwattr $C$DW$51, DW_AT_type(*$C$DW$T$1100) .dwattr $C$DW$51, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1411 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1411, DW_AT_type(*$C$DW$T$1102) .dwendtag $C$DW$51 .dwendtag $C$DW$T$1104 .dwattr $C$DW$T$1104, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1104, DW_AT_decl_line(0x31b) .dwattr $C$DW$T$1104, DW_AT_decl_column(0x10) $C$DW$T$197 .dwtag DW_TAG_typedef, DW_AT_name("ImageGaussian") .dwattr $C$DW$T$197, DW_AT_type(*$C$DW$T$1104) .dwattr $C$DW$T$197, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$197, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$197, DW_AT_decl_line(0x31f) .dwattr $C$DW$T$197, DW_AT_decl_column(0x03) $C$DW$T$1101 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1101, DW_AT_type(*$C$DW$T$1104) $C$DW$T$1102 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1102, DW_AT_type(*$C$DW$T$1101) .dwattr $C$DW$T$1102, DW_AT_address_class(0x20) $C$DW$T$1100 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1100, DW_AT_type(*$C$DW$T$1104) .dwattr $C$DW$T$1100, DW_AT_address_class(0x20) $C$DW$T$1103 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1103, DW_AT_type(*$C$DW$T$1100) .dwattr $C$DW$T$1103, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1412 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1412, DW_AT_type(*$C$DW$T$1102) .dwendtag $C$DW$T$1103 $C$DW$T$1109 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1109, DW_AT_name("ImageInfo") .dwattr $C$DW$T$1109, DW_AT_byte_size(0x18) $C$DW$1413 .dwtag DW_TAG_member .dwattr $C$DW$1413, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1413, DW_AT_name("xSize") .dwattr $C$DW$1413, DW_AT_TI_symbol_name("xSize") .dwattr $C$DW$1413, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1413, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1413, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1413, DW_AT_decl_line(0x26) .dwattr $C$DW$1413, DW_AT_decl_column(0x07) $C$DW$1414 .dwtag DW_TAG_member .dwattr $C$DW$1414, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1414, DW_AT_name("ySize") .dwattr $C$DW$1414, DW_AT_TI_symbol_name("ySize") .dwattr $C$DW$1414, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1414, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1414, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1414, DW_AT_decl_line(0x27) .dwattr $C$DW$1414, DW_AT_decl_column(0x07) $C$DW$1415 .dwtag DW_TAG_member .dwattr $C$DW$1415, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1415, DW_AT_name("scaleBits") .dwattr $C$DW$1415, DW_AT_TI_symbol_name("scaleBits") .dwattr $C$DW$1415, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1415, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1415, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1415, DW_AT_decl_line(0x28) .dwattr $C$DW$1415, DW_AT_decl_column(0x07) $C$DW$1416 .dwtag DW_TAG_member .dwattr $C$DW$1416, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1416, DW_AT_name("margin") .dwattr $C$DW$1416, DW_AT_TI_symbol_name("margin") .dwattr $C$DW$1416, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1416, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1416, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1416, DW_AT_decl_line(0x29) .dwattr $C$DW$1416, DW_AT_decl_column(0x07) $C$DW$1417 .dwtag DW_TAG_member .dwattr $C$DW$1417, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1417, DW_AT_name("xRotation") .dwattr $C$DW$1417, DW_AT_TI_symbol_name("xRotation") .dwattr $C$DW$1417, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1417, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1417, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1417, DW_AT_decl_line(0x2a) .dwattr $C$DW$1417, DW_AT_decl_column(0x07) $C$DW$1418 .dwtag DW_TAG_member .dwattr $C$DW$1418, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1418, DW_AT_name("yRotation") .dwattr $C$DW$1418, DW_AT_TI_symbol_name("yRotation") .dwattr $C$DW$1418, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1418, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1418, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1418, DW_AT_decl_line(0x2b) .dwattr $C$DW$1418, DW_AT_decl_column(0x07) $C$DW$52 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$52, DW_AT_declaration .dwattr $C$DW$52, DW_AT_TI_symbol_name("_ZN9ImageInfoaSERKS_") .dwattr $C$DW$52, DW_AT_type(*$C$DW$T$1105) .dwattr $C$DW$52, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1419 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1419, DW_AT_type(*$C$DW$T$1107) .dwendtag $C$DW$52 .dwendtag $C$DW$T$1109 .dwattr $C$DW$T$1109, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$1109, DW_AT_decl_line(0x24) .dwattr $C$DW$T$1109, DW_AT_decl_column(0x08) $C$DW$T$1106 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1106, DW_AT_type(*$C$DW$T$1109) $C$DW$T$1107 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1107, DW_AT_type(*$C$DW$T$1106) .dwattr $C$DW$T$1107, DW_AT_address_class(0x20) $C$DW$T$1720 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$1720, DW_AT_type(*$C$DW$T$1106) .dwattr $C$DW$T$1720, DW_AT_address_class(0x20) $C$DW$T$417 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$417, DW_AT_type(*$C$DW$T$1109) .dwattr $C$DW$T$417, DW_AT_address_class(0x20) $C$DW$T$1105 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1105, DW_AT_type(*$C$DW$T$1109) .dwattr $C$DW$T$1105, DW_AT_address_class(0x20) $C$DW$T$1108 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1108, DW_AT_type(*$C$DW$T$1105) .dwattr $C$DW$T$1108, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1420 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1420, DW_AT_type(*$C$DW$T$1107) .dwendtag $C$DW$T$1108 $C$DW$T$1192 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1192, DW_AT_type(*$C$DW$T$1109) .dwattr $C$DW$T$1192, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1192, DW_AT_byte_size(0x30) $C$DW$1421 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1421, DW_AT_upper_bound(0x01) .dwendtag $C$DW$T$1192 $C$DW$T$1193 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1193, DW_AT_type(*$C$DW$T$1109) .dwattr $C$DW$T$1193, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1193, DW_AT_byte_size(0x78) $C$DW$1422 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1422, DW_AT_upper_bound(0x04) .dwendtag $C$DW$T$1193 $C$DW$T$1194 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1194, DW_AT_type(*$C$DW$T$1109) .dwattr $C$DW$T$1194, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1194, DW_AT_byte_size(0xf0) $C$DW$1423 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1423, DW_AT_upper_bound(0x01) $C$DW$1424 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1424, DW_AT_upper_bound(0x04) .dwendtag $C$DW$T$1194 $C$DW$T$1115 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1115, DW_AT_name("ImageLineThin") .dwattr $C$DW$T$1115, DW_AT_byte_size(0xa0) $C$DW$1425 .dwtag DW_TAG_member .dwattr $C$DW$1425, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1425, DW_AT_name("mode") .dwattr $C$DW$1425, DW_AT_TI_symbol_name("mode") .dwattr $C$DW$1425, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1425, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1425, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1425, DW_AT_decl_line(0x36e) .dwattr $C$DW$1425, DW_AT_decl_column(0x05) $C$DW$1426 .dwtag DW_TAG_member .dwattr $C$DW$1426, DW_AT_type(*$C$DW$T$1087) .dwattr $C$DW$1426, DW_AT_name("radius") .dwattr $C$DW$1426, DW_AT_TI_symbol_name("radius") .dwattr $C$DW$1426, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1426, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1426, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1426, DW_AT_decl_line(0x36f) .dwattr $C$DW$1426, DW_AT_decl_column(0x05) $C$DW$1427 .dwtag DW_TAG_member .dwattr $C$DW$1427, DW_AT_type(*$C$DW$T$1088) .dwattr $C$DW$1427, DW_AT_name("coef") .dwattr $C$DW$1427, DW_AT_TI_symbol_name("coef") .dwattr $C$DW$1427, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1427, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1427, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1427, DW_AT_decl_line(0x370) .dwattr $C$DW$1427, DW_AT_decl_column(0x05) $C$DW$1428 .dwtag DW_TAG_member .dwattr $C$DW$1428, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1428, DW_AT_name("offset") .dwattr $C$DW$1428, DW_AT_TI_symbol_name("offset") .dwattr $C$DW$1428, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1428, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1428, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1428, DW_AT_decl_line(0x371) .dwattr $C$DW$1428, DW_AT_decl_column(0x05) $C$DW$1429 .dwtag DW_TAG_member .dwattr $C$DW$1429, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1429, DW_AT_name("reserved") .dwattr $C$DW$1429, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1429, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1429, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1429, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1429, DW_AT_decl_line(0x372) .dwattr $C$DW$1429, DW_AT_decl_column(0x05) $C$DW$53 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$53, DW_AT_declaration .dwattr $C$DW$53, DW_AT_TI_symbol_name("_ZN13ImageLineThinaSERKS_") .dwattr $C$DW$53, DW_AT_type(*$C$DW$T$1111) .dwattr $C$DW$53, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1430 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1430, DW_AT_type(*$C$DW$T$1113) .dwendtag $C$DW$53 .dwendtag $C$DW$T$1115 .dwattr $C$DW$T$1115, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1115, DW_AT_decl_line(0x36d) .dwattr $C$DW$T$1115, DW_AT_decl_column(0x10) $C$DW$T$206 .dwtag DW_TAG_typedef, DW_AT_name("ImageLineThin") .dwattr $C$DW$T$206, DW_AT_type(*$C$DW$T$1115) .dwattr $C$DW$T$206, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$206, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$206, DW_AT_decl_line(0x373) .dwattr $C$DW$T$206, DW_AT_decl_column(0x03) $C$DW$T$1112 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1112, DW_AT_type(*$C$DW$T$1115) $C$DW$T$1113 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1113, DW_AT_type(*$C$DW$T$1112) .dwattr $C$DW$T$1113, DW_AT_address_class(0x20) $C$DW$T$1111 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1111, DW_AT_type(*$C$DW$T$1115) .dwattr $C$DW$T$1111, DW_AT_address_class(0x20) $C$DW$T$1114 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1114, DW_AT_type(*$C$DW$T$1111) .dwattr $C$DW$T$1114, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1431 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1431, DW_AT_type(*$C$DW$T$1113) .dwendtag $C$DW$T$1114 $C$DW$T$284 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$284, DW_AT_name("ImageNEP") .dwattr $C$DW$T$284, DW_AT_byte_size(0xf0) $C$DW$1432 .dwtag DW_TAG_member .dwattr $C$DW$1432, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1432, DW_AT_name("weightM") .dwattr $C$DW$1432, DW_AT_TI_symbol_name("weightM") .dwattr $C$DW$1432, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1432, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1432, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1432, DW_AT_decl_line(0x8e) .dwattr $C$DW$1432, DW_AT_decl_column(0x07) $C$DW$1433 .dwtag DW_TAG_member .dwattr $C$DW$1433, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1433, DW_AT_name("weightS") .dwattr $C$DW$1433, DW_AT_TI_symbol_name("weightS") .dwattr $C$DW$1433, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1433, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1433, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1433, DW_AT_decl_line(0x8f) .dwattr $C$DW$1433, DW_AT_decl_column(0x07) $C$DW$1434 .dwtag DW_TAG_member .dwattr $C$DW$1434, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1434, DW_AT_name("weightA") .dwattr $C$DW$1434, DW_AT_TI_symbol_name("weightA") .dwattr $C$DW$1434, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1434, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1434, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1434, DW_AT_decl_line(0x90) .dwattr $C$DW$1434, DW_AT_decl_column(0x08) $C$DW$1435 .dwtag DW_TAG_member .dwattr $C$DW$1435, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1435, DW_AT_name("weightB") .dwattr $C$DW$1435, DW_AT_TI_symbol_name("weightB") .dwattr $C$DW$1435, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c] .dwattr $C$DW$1435, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1435, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1435, DW_AT_decl_line(0x91) .dwattr $C$DW$1435, DW_AT_decl_column(0x08) $C$DW$1436 .dwtag DW_TAG_member .dwattr $C$DW$1436, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1436, DW_AT_name("alpha") .dwattr $C$DW$1436, DW_AT_TI_symbol_name("alpha") .dwattr $C$DW$1436, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$1436, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1436, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1436, DW_AT_decl_line(0x92) .dwattr $C$DW$1436, DW_AT_decl_column(0x08) $C$DW$1437 .dwtag DW_TAG_member .dwattr $C$DW$1437, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1437, DW_AT_name("beta") .dwattr $C$DW$1437, DW_AT_TI_symbol_name("beta") .dwattr $C$DW$1437, DW_AT_data_member_location[DW_OP_plus_uconst 0x64] .dwattr $C$DW$1437, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1437, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1437, DW_AT_decl_line(0x93) .dwattr $C$DW$1437, DW_AT_decl_column(0x08) $C$DW$1438 .dwtag DW_TAG_member .dwattr $C$DW$1438, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1438, DW_AT_name("gamma") .dwattr $C$DW$1438, DW_AT_TI_symbol_name("gamma") .dwattr $C$DW$1438, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1438, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1438, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1438, DW_AT_decl_line(0x94) .dwattr $C$DW$1438, DW_AT_decl_column(0x08) $C$DW$1439 .dwtag DW_TAG_member .dwattr $C$DW$1439, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1439, DW_AT_name("backWM") .dwattr $C$DW$1439, DW_AT_TI_symbol_name("backWM") .dwattr $C$DW$1439, DW_AT_data_member_location[DW_OP_plus_uconst 0x8c] .dwattr $C$DW$1439, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1439, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1439, DW_AT_decl_line(0x96) .dwattr $C$DW$1439, DW_AT_decl_column(0x07) $C$DW$1440 .dwtag DW_TAG_member .dwattr $C$DW$1440, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1440, DW_AT_name("backWS") .dwattr $C$DW$1440, DW_AT_TI_symbol_name("backWS") .dwattr $C$DW$1440, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0] .dwattr $C$DW$1440, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1440, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1440, DW_AT_decl_line(0x97) .dwattr $C$DW$1440, DW_AT_decl_column(0x07) $C$DW$1441 .dwtag DW_TAG_member .dwattr $C$DW$1441, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1441, DW_AT_name("backWA") .dwattr $C$DW$1441, DW_AT_TI_symbol_name("backWA") .dwattr $C$DW$1441, DW_AT_data_member_location[DW_OP_plus_uconst 0xb4] .dwattr $C$DW$1441, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1441, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1441, DW_AT_decl_line(0x98) .dwattr $C$DW$1441, DW_AT_decl_column(0x08) $C$DW$1442 .dwtag DW_TAG_member .dwattr $C$DW$1442, DW_AT_type(*$C$DW$T$232) .dwattr $C$DW$1442, DW_AT_name("backWB") .dwattr $C$DW$1442, DW_AT_TI_symbol_name("backWB") .dwattr $C$DW$1442, DW_AT_data_member_location[DW_OP_plus_uconst 0xc8] .dwattr $C$DW$1442, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1442, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1442, DW_AT_decl_line(0x99) .dwattr $C$DW$1442, DW_AT_decl_column(0x08) $C$DW$1443 .dwtag DW_TAG_member .dwattr $C$DW$1443, DW_AT_type(*$C$DW$T$231) .dwattr $C$DW$1443, DW_AT_name("backWT") .dwattr $C$DW$1443, DW_AT_TI_symbol_name("backWT") .dwattr $C$DW$1443, DW_AT_data_member_location[DW_OP_plus_uconst 0xdc] .dwattr $C$DW$1443, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1443, DW_AT_decl_line(0x9a) .dwattr $C$DW$1443, DW_AT_decl_column(0x07) $C$DW$54 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$54, DW_AT_declaration .dwattr $C$DW$54, DW_AT_TI_symbol_name("_ZN13XtNamApiParam8ImageNEPaSERKS0_") .dwattr $C$DW$54, DW_AT_type(*$C$DW$T$280) .dwattr $C$DW$54, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1444 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1444, DW_AT_type(*$C$DW$T$282) .dwendtag $C$DW$54 .dwendtag $C$DW$T$284 .dwattr $C$DW$T$284, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$284, DW_AT_decl_line(0x8c) .dwattr $C$DW$T$284, DW_AT_decl_column(0x08) $C$DW$T$281 .dwtag DW_TAG_const_type .dwattr $C$DW$T$281, DW_AT_type(*$C$DW$T$284) $C$DW$T$282 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$282, DW_AT_type(*$C$DW$T$281) .dwattr $C$DW$T$282, DW_AT_address_class(0x20) $C$DW$T$280 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$280, DW_AT_type(*$C$DW$T$284) .dwattr $C$DW$T$280, DW_AT_address_class(0x20) $C$DW$T$283 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$283, DW_AT_type(*$C$DW$T$280) .dwattr $C$DW$T$283, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1445 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1445, DW_AT_type(*$C$DW$T$282) .dwendtag $C$DW$T$283 $C$DW$T$1120 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1120, DW_AT_name("ImageNEP") .dwattr $C$DW$T$1120, DW_AT_byte_size(0x128) $C$DW$1446 .dwtag DW_TAG_member .dwattr $C$DW$1446, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1446, DW_AT_name("weightM") .dwattr $C$DW$1446, DW_AT_TI_symbol_name("weightM") .dwattr $C$DW$1446, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1446, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1446, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1446, DW_AT_decl_line(0x351) .dwattr $C$DW$1446, DW_AT_decl_column(0x05) $C$DW$1447 .dwtag DW_TAG_member .dwattr $C$DW$1447, DW_AT_type(*$C$DW$T$1047) .dwattr $C$DW$1447, DW_AT_name("weightS") .dwattr $C$DW$1447, DW_AT_TI_symbol_name("weightS") .dwattr $C$DW$1447, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1447, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1447, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1447, DW_AT_decl_line(0x352) .dwattr $C$DW$1447, DW_AT_decl_column(0x05) $C$DW$1448 .dwtag DW_TAG_member .dwattr $C$DW$1448, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1448, DW_AT_name("weightA") .dwattr $C$DW$1448, DW_AT_TI_symbol_name("weightA") .dwattr $C$DW$1448, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1448, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1448, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1448, DW_AT_decl_line(0x353) .dwattr $C$DW$1448, DW_AT_decl_column(0x05) $C$DW$1449 .dwtag DW_TAG_member .dwattr $C$DW$1449, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1449, DW_AT_name("weightB") .dwattr $C$DW$1449, DW_AT_TI_symbol_name("weightB") .dwattr $C$DW$1449, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$1449, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1449, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1449, DW_AT_decl_line(0x354) .dwattr $C$DW$1449, DW_AT_decl_column(0x05) $C$DW$1450 .dwtag DW_TAG_member .dwattr $C$DW$1450, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1450, DW_AT_name("alpha") .dwattr $C$DW$1450, DW_AT_TI_symbol_name("alpha") .dwattr $C$DW$1450, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$1450, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1450, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1450, DW_AT_decl_line(0x355) .dwattr $C$DW$1450, DW_AT_decl_column(0x05) $C$DW$1451 .dwtag DW_TAG_member .dwattr $C$DW$1451, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1451, DW_AT_name("beta") .dwattr $C$DW$1451, DW_AT_TI_symbol_name("beta") .dwattr $C$DW$1451, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1451, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1451, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1451, DW_AT_decl_line(0x356) .dwattr $C$DW$1451, DW_AT_decl_column(0x05) $C$DW$1452 .dwtag DW_TAG_member .dwattr $C$DW$1452, DW_AT_type(*$C$DW$T$1048) .dwattr $C$DW$1452, DW_AT_name("gamma") .dwattr $C$DW$1452, DW_AT_TI_symbol_name("gamma") .dwattr $C$DW$1452, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$1452, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1452, DW_AT_decl_line(0x357) .dwattr $C$DW$1452, DW_AT_decl_column(0x05) $C$DW$1453 .dwtag DW_TAG_member .dwattr $C$DW$1453, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1453, DW_AT_name("reserved") .dwattr $C$DW$1453, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1453, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$1453, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1453, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1453, DW_AT_decl_line(0x358) .dwattr $C$DW$1453, DW_AT_decl_column(0x05) $C$DW$55 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$55, DW_AT_declaration .dwattr $C$DW$55, DW_AT_TI_symbol_name("_ZN8ImageNEPaSERKS_") .dwattr $C$DW$55, DW_AT_type(*$C$DW$T$1116) .dwattr $C$DW$55, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1454 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1454, DW_AT_type(*$C$DW$T$1118) .dwendtag $C$DW$55 .dwendtag $C$DW$T$1120 .dwattr $C$DW$T$1120, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1120, DW_AT_decl_line(0x350) .dwattr $C$DW$T$1120, DW_AT_decl_column(0x10) $C$DW$T$203 .dwtag DW_TAG_typedef, DW_AT_name("ImageNEP") .dwattr $C$DW$T$203, DW_AT_type(*$C$DW$T$1120) .dwattr $C$DW$T$203, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$203, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$203, DW_AT_decl_line(0x359) .dwattr $C$DW$T$203, DW_AT_decl_column(0x03) $C$DW$T$1117 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1117, DW_AT_type(*$C$DW$T$1120) $C$DW$T$1118 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1118, DW_AT_type(*$C$DW$T$1117) .dwattr $C$DW$T$1118, DW_AT_address_class(0x20) $C$DW$T$1116 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1116, DW_AT_type(*$C$DW$T$1120) .dwattr $C$DW$T$1116, DW_AT_address_class(0x20) $C$DW$T$1119 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1119, DW_AT_type(*$C$DW$T$1116) .dwattr $C$DW$T$1119, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1455 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1455, DW_AT_type(*$C$DW$T$1118) .dwendtag $C$DW$T$1119 $C$DW$T$253 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$253, DW_AT_name("ImageProcessB") .dwattr $C$DW$T$253, DW_AT_byte_size(0x644) $C$DW$1456 .dwtag DW_TAG_member .dwattr $C$DW$1456, DW_AT_type(*$C$DW$T$248) .dwattr $C$DW$1456, DW_AT_name("enabled") .dwattr $C$DW$1456, DW_AT_TI_symbol_name("enabled") .dwattr $C$DW$1456, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1456, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1456, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1456, DW_AT_decl_line(0x22) .dwattr $C$DW$1456, DW_AT_decl_column(0x0a) $C$DW$1457 .dwtag DW_TAG_member .dwattr $C$DW$1457, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1457, DW_AT_name("gain") .dwattr $C$DW$1457, DW_AT_TI_symbol_name("gain") .dwattr $C$DW$1457, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1457, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1457, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1457, DW_AT_decl_line(0x24) .dwattr $C$DW$1457, DW_AT_decl_column(0x0d) $C$DW$1458 .dwtag DW_TAG_member .dwattr $C$DW$1458, DW_AT_type(*$C$DW$T$258) .dwattr $C$DW$1458, DW_AT_name("resolution") .dwattr $C$DW$1458, DW_AT_TI_symbol_name("resolution") .dwattr $C$DW$1458, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1458, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1458, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1458, DW_AT_decl_line(0x26) .dwattr $C$DW$1458, DW_AT_decl_column(0x1d) $C$DW$1459 .dwtag DW_TAG_member .dwattr $C$DW$1459, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1459, DW_AT_name("dBRange") .dwattr $C$DW$1459, DW_AT_TI_symbol_name("dBRange") .dwattr $C$DW$1459, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1459, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1459, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1459, DW_AT_decl_line(0x27) .dwattr $C$DW$1459, DW_AT_decl_column(0x1d) $C$DW$1460 .dwtag DW_TAG_member .dwattr $C$DW$1460, DW_AT_type(*$C$DW$T$290) .dwattr $C$DW$1460, DW_AT_name("fill") .dwattr $C$DW$1460, DW_AT_TI_symbol_name("fill") .dwattr $C$DW$1460, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1460, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1460, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1460, DW_AT_decl_line(0x28) .dwattr $C$DW$1460, DW_AT_decl_column(0x1d) $C$DW$1461 .dwtag DW_TAG_member .dwattr $C$DW$1461, DW_AT_type(*$C$DW$T$247) .dwattr $C$DW$1461, DW_AT_name("gaussian") .dwattr $C$DW$1461, DW_AT_TI_symbol_name("gaussian") .dwattr $C$DW$1461, DW_AT_data_member_location[DW_OP_plus_uconst 0x94] .dwattr $C$DW$1461, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1461, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1461, DW_AT_decl_line(0x29) .dwattr $C$DW$1461, DW_AT_decl_column(0x1d) $C$DW$1462 .dwtag DW_TAG_member .dwattr $C$DW$1462, DW_AT_type(*$C$DW$T$264) .dwattr $C$DW$1462, DW_AT_name("edgeDetection") .dwattr $C$DW$1462, DW_AT_TI_symbol_name("edgeDetection") .dwattr $C$DW$1462, DW_AT_data_member_location[DW_OP_plus_uconst 0x9c] .dwattr $C$DW$1462, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1462, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1462, DW_AT_decl_line(0x2a) .dwattr $C$DW$1462, DW_AT_decl_column(0x1d) $C$DW$1463 .dwtag DW_TAG_member .dwattr $C$DW$1463, DW_AT_type(*$C$DW$T$269) .dwattr $C$DW$1463, DW_AT_name("edgeDirection") .dwattr $C$DW$1463, DW_AT_TI_symbol_name("edgeDirection") .dwattr $C$DW$1463, DW_AT_data_member_location[DW_OP_plus_uconst 0x180] .dwattr $C$DW$1463, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1463, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1463, DW_AT_decl_line(0x2b) .dwattr $C$DW$1463, DW_AT_decl_column(0x1d) $C$DW$1464 .dwtag DW_TAG_member .dwattr $C$DW$1464, DW_AT_type(*$C$DW$T$279) .dwattr $C$DW$1464, DW_AT_name("edgeReliability") .dwattr $C$DW$1464, DW_AT_TI_symbol_name("edgeReliability") .dwattr $C$DW$1464, DW_AT_data_member_location[DW_OP_plus_uconst 0x220] .dwattr $C$DW$1464, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1464, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1464, DW_AT_decl_line(0x2c) .dwattr $C$DW$1464, DW_AT_decl_column(0x1d) $C$DW$1465 .dwtag DW_TAG_member .dwattr $C$DW$1465, DW_AT_type(*$C$DW$T$242) .dwattr $C$DW$1465, DW_AT_name("emphasis") .dwattr $C$DW$1465, DW_AT_TI_symbol_name("emphasis") .dwattr $C$DW$1465, DW_AT_data_member_location[DW_OP_plus_uconst 0x234] .dwattr $C$DW$1465, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1465, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1465, DW_AT_decl_line(0x2d) .dwattr $C$DW$1465, DW_AT_decl_column(0x1d) $C$DW$1466 .dwtag DW_TAG_member .dwattr $C$DW$1466, DW_AT_type(*$C$DW$T$274) .dwattr $C$DW$1466, DW_AT_name("directionFilter") .dwattr $C$DW$1466, DW_AT_TI_symbol_name("directionFilter") .dwattr $C$DW$1466, DW_AT_data_member_location[DW_OP_plus_uconst 0x2d4] .dwattr $C$DW$1466, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1466, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1466, DW_AT_decl_line(0x2e) .dwattr $C$DW$1466, DW_AT_decl_column(0x1d) $C$DW$1467 .dwtag DW_TAG_member .dwattr $C$DW$1467, DW_AT_type(*$C$DW$T$284) .dwattr $C$DW$1467, DW_AT_name("nep") .dwattr $C$DW$1467, DW_AT_TI_symbol_name("nep") .dwattr $C$DW$1467, DW_AT_data_member_location[DW_OP_plus_uconst 0x34c] .dwattr $C$DW$1467, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1467, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1467, DW_AT_decl_line(0x2f) .dwattr $C$DW$1467, DW_AT_decl_column(0x1d) $C$DW$1468 .dwtag DW_TAG_member .dwattr $C$DW$1468, DW_AT_type(*$C$DW$T$284) .dwattr $C$DW$1468, DW_AT_name("nepS") .dwattr $C$DW$1468, DW_AT_TI_symbol_name("nepS") .dwattr $C$DW$1468, DW_AT_data_member_location[DW_OP_plus_uconst 0x43c] .dwattr $C$DW$1468, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1468, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1468, DW_AT_decl_line(0x30) .dwattr $C$DW$1468, DW_AT_decl_column(0x1d) $C$DW$1469 .dwtag DW_TAG_member .dwattr $C$DW$1469, DW_AT_type(*$C$DW$T$242) .dwattr $C$DW$1469, DW_AT_name("emphasis2") .dwattr $C$DW$1469, DW_AT_TI_symbol_name("emphasis2") .dwattr $C$DW$1469, DW_AT_data_member_location[DW_OP_plus_uconst 0x52c] .dwattr $C$DW$1469, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1469, DW_AT_decl_line(0x31) .dwattr $C$DW$1469, DW_AT_decl_column(0x1d) $C$DW$1470 .dwtag DW_TAG_member .dwattr $C$DW$1470, DW_AT_type(*$C$DW$T$237) .dwattr $C$DW$1470, DW_AT_name("dummy") .dwattr $C$DW$1470, DW_AT_TI_symbol_name("dummy") .dwattr $C$DW$1470, DW_AT_data_member_location[DW_OP_plus_uconst 0x5cc] .dwattr $C$DW$1470, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1470, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$1470, DW_AT_decl_line(0x32) .dwattr $C$DW$1470, DW_AT_decl_column(0x1d) $C$DW$56 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$56, DW_AT_declaration .dwattr $C$DW$56, DW_AT_TI_symbol_name("_ZN13XtNamApiParam13ImageProcessBaSERKS0_") .dwattr $C$DW$56, DW_AT_type(*$C$DW$T$249) .dwattr $C$DW$56, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1471 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1471, DW_AT_type(*$C$DW$T$251) .dwendtag $C$DW$56 .dwendtag $C$DW$T$253 .dwattr $C$DW$T$253, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_bm.h") .dwattr $C$DW$T$253, DW_AT_decl_line(0x20) .dwattr $C$DW$T$253, DW_AT_decl_column(0x09) $C$DW$T$250 .dwtag DW_TAG_const_type .dwattr $C$DW$T$250, DW_AT_type(*$C$DW$T$253) $C$DW$T$251 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$251, DW_AT_type(*$C$DW$T$250) .dwattr $C$DW$T$251, DW_AT_address_class(0x20) $C$DW$T$249 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$249, DW_AT_type(*$C$DW$T$253) .dwattr $C$DW$T$249, DW_AT_address_class(0x20) $C$DW$T$252 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$252, DW_AT_type(*$C$DW$T$249) .dwattr $C$DW$T$252, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1472 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1472, DW_AT_type(*$C$DW$T$251) .dwendtag $C$DW$T$252 $C$DW$T$1126 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1126, DW_AT_name("ImageProcessPath") .dwattr $C$DW$T$1126, DW_AT_byte_size(0x90) $C$DW$1473 .dwtag DW_TAG_member .dwattr $C$DW$1473, DW_AT_type(*$C$DW$T$1121) .dwattr $C$DW$1473, DW_AT_name("flg") .dwattr $C$DW$1473, DW_AT_TI_symbol_name("flg") .dwattr $C$DW$1473, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1473, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1473, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1473, DW_AT_decl_line(0x35d) .dwattr $C$DW$1473, DW_AT_decl_column(0x05) $C$DW$1474 .dwtag DW_TAG_member .dwattr $C$DW$1474, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1474, DW_AT_name("reserved") .dwattr $C$DW$1474, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1474, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1474, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1474, DW_AT_decl_line(0x35e) .dwattr $C$DW$1474, DW_AT_decl_column(0x05) $C$DW$57 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$57, DW_AT_declaration .dwattr $C$DW$57, DW_AT_TI_symbol_name("_ZN16ImageProcessPathaSERKS_") .dwattr $C$DW$57, DW_AT_type(*$C$DW$T$1122) .dwattr $C$DW$57, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1475 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1475, DW_AT_type(*$C$DW$T$1124) .dwendtag $C$DW$57 .dwendtag $C$DW$T$1126 .dwattr $C$DW$T$1126, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1126, DW_AT_decl_line(0x35c) .dwattr $C$DW$T$1126, DW_AT_decl_column(0x10) $C$DW$T$204 .dwtag DW_TAG_typedef, DW_AT_name("ImageProcessPath") .dwattr $C$DW$T$204, DW_AT_type(*$C$DW$T$1126) .dwattr $C$DW$T$204, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$204, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$204, DW_AT_decl_line(0x35f) .dwattr $C$DW$T$204, DW_AT_decl_column(0x03) $C$DW$T$1123 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1123, DW_AT_type(*$C$DW$T$1126) $C$DW$T$1124 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1124, DW_AT_type(*$C$DW$T$1123) .dwattr $C$DW$T$1124, DW_AT_address_class(0x20) $C$DW$T$1122 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1122, DW_AT_type(*$C$DW$T$1126) .dwattr $C$DW$T$1122, DW_AT_address_class(0x20) $C$DW$T$1125 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1125, DW_AT_type(*$C$DW$T$1122) .dwattr $C$DW$T$1125, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1476 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1476, DW_AT_type(*$C$DW$T$1124) .dwendtag $C$DW$T$1125 $C$DW$T$258 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$258, DW_AT_name("ImageResolution") .dwattr $C$DW$T$258, DW_AT_byte_size(0x08) $C$DW$1477 .dwtag DW_TAG_member .dwattr $C$DW$1477, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1477, DW_AT_name("scaleLine") .dwattr $C$DW$1477, DW_AT_TI_symbol_name("scaleLine") .dwattr $C$DW$1477, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1477, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1477, DW_AT_decl_line(0x19) .dwattr $C$DW$1477, DW_AT_decl_column(0x09) $C$DW$1478 .dwtag DW_TAG_member .dwattr $C$DW$1478, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1478, DW_AT_name("frequencySample") .dwattr $C$DW$1478, DW_AT_TI_symbol_name("frequencySample") .dwattr $C$DW$1478, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1478, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$1478, DW_AT_decl_line(0x1a) .dwattr $C$DW$1478, DW_AT_decl_column(0x09) $C$DW$58 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$58, DW_AT_declaration .dwattr $C$DW$58, DW_AT_TI_symbol_name("_ZN13XtNamApiParam15ImageResolutionaSERKS0_") .dwattr $C$DW$58, DW_AT_type(*$C$DW$T$254) .dwattr $C$DW$58, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1479 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1479, DW_AT_type(*$C$DW$T$256) .dwendtag $C$DW$58 .dwendtag $C$DW$T$258 .dwattr $C$DW$T$258, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/param/include/xtnam_image_process_be.h") .dwattr $C$DW$T$258, DW_AT_decl_line(0x17) .dwattr $C$DW$T$258, DW_AT_decl_column(0x08) $C$DW$T$255 .dwtag DW_TAG_const_type .dwattr $C$DW$T$255, DW_AT_type(*$C$DW$T$258) $C$DW$T$256 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$256, DW_AT_type(*$C$DW$T$255) .dwattr $C$DW$T$256, DW_AT_address_class(0x20) $C$DW$T$254 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$254, DW_AT_type(*$C$DW$T$258) .dwattr $C$DW$T$254, DW_AT_address_class(0x20) $C$DW$T$257 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$257, DW_AT_type(*$C$DW$T$254) .dwattr $C$DW$T$257, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1480 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1480, DW_AT_type(*$C$DW$T$256) .dwendtag $C$DW$T$257 $C$DW$T$1131 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1131, DW_AT_name("ImageResolution") .dwattr $C$DW$T$1131, DW_AT_byte_size(0x90) $C$DW$1481 .dwtag DW_TAG_member .dwattr $C$DW$1481, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1481, DW_AT_name("scaleLine") .dwattr $C$DW$1481, DW_AT_TI_symbol_name("scaleLine") .dwattr $C$DW$1481, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1481, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1481, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1481, DW_AT_decl_line(0x308) .dwattr $C$DW$1481, DW_AT_decl_column(0x05) $C$DW$1482 .dwtag DW_TAG_member .dwattr $C$DW$1482, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1482, DW_AT_name("frequencySample") .dwattr $C$DW$1482, DW_AT_TI_symbol_name("frequencySample") .dwattr $C$DW$1482, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1482, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1482, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1482, DW_AT_decl_line(0x309) .dwattr $C$DW$1482, DW_AT_decl_column(0x05) $C$DW$1483 .dwtag DW_TAG_member .dwattr $C$DW$1483, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1483, DW_AT_name("reserved") .dwattr $C$DW$1483, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1483, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1483, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1483, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1483, DW_AT_decl_line(0x30a) .dwattr $C$DW$1483, DW_AT_decl_column(0x05) $C$DW$59 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$59, DW_AT_declaration .dwattr $C$DW$59, DW_AT_TI_symbol_name("_ZN15ImageResolutionaSERKS_") .dwattr $C$DW$59, DW_AT_type(*$C$DW$T$1127) .dwattr $C$DW$59, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1484 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1484, DW_AT_type(*$C$DW$T$1129) .dwendtag $C$DW$59 .dwendtag $C$DW$T$1131 .dwattr $C$DW$T$1131, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1131, DW_AT_decl_line(0x307) .dwattr $C$DW$T$1131, DW_AT_decl_column(0x01) $C$DW$T$195 .dwtag DW_TAG_typedef, DW_AT_name("ImageResolution") .dwattr $C$DW$T$195, DW_AT_type(*$C$DW$T$1131) .dwattr $C$DW$T$195, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$195, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$195, DW_AT_decl_line(0x30b) .dwattr $C$DW$T$195, DW_AT_decl_column(0x03) $C$DW$T$1128 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1128, DW_AT_type(*$C$DW$T$1131) $C$DW$T$1129 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1129, DW_AT_type(*$C$DW$T$1128) .dwattr $C$DW$T$1129, DW_AT_address_class(0x20) $C$DW$T$1127 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1127, DW_AT_type(*$C$DW$T$1131) .dwattr $C$DW$T$1127, DW_AT_address_class(0x20) $C$DW$T$1130 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1130, DW_AT_type(*$C$DW$T$1127) .dwattr $C$DW$T$1130, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1485 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1485, DW_AT_type(*$C$DW$T$1129) .dwendtag $C$DW$T$1130 $C$DW$T$1136 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1136, DW_AT_name("ImagingDelay_Param") .dwattr $C$DW$T$1136, DW_AT_byte_size(0x90) $C$DW$1486 .dwtag DW_TAG_member .dwattr $C$DW$1486, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1486, DW_AT_name("ecgAnalogDelayInUsecs") .dwattr $C$DW$1486, DW_AT_TI_symbol_name("ecgAnalogDelayInUsecs") .dwattr $C$DW$1486, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1486, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1486, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1486, DW_AT_decl_line(0x4f9) .dwattr $C$DW$1486, DW_AT_decl_column(0x05) $C$DW$1487 .dwtag DW_TAG_member .dwattr $C$DW$1487, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1487, DW_AT_name("ecgDigitalDelayInUsecs") .dwattr $C$DW$1487, DW_AT_TI_symbol_name("ecgDigitalDelayInUsecs") .dwattr $C$DW$1487, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1487, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1487, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1487, DW_AT_decl_line(0x4fa) .dwattr $C$DW$1487, DW_AT_decl_column(0x05) $C$DW$1488 .dwtag DW_TAG_member .dwattr $C$DW$1488, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1488, DW_AT_name("reserved") .dwattr $C$DW$1488, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1488, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1488, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1488, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1488, DW_AT_decl_line(0x4fb) .dwattr $C$DW$1488, DW_AT_decl_column(0x05) $C$DW$60 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$60, DW_AT_declaration .dwattr $C$DW$60, DW_AT_TI_symbol_name("_ZN18ImagingDelay_ParamaSERKS_") .dwattr $C$DW$60, DW_AT_type(*$C$DW$T$1132) .dwattr $C$DW$60, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1489 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1489, DW_AT_type(*$C$DW$T$1134) .dwendtag $C$DW$60 .dwendtag $C$DW$T$1136 .dwattr $C$DW$T$1136, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1136, DW_AT_decl_line(0x4f8) .dwattr $C$DW$T$1136, DW_AT_decl_column(0x01) $C$DW$T$581 .dwtag DW_TAG_typedef, DW_AT_name("ImagingDelay_Param") .dwattr $C$DW$T$581, DW_AT_type(*$C$DW$T$1136) .dwattr $C$DW$T$581, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$581, DW_AT_decl_line(0x4fc) .dwattr $C$DW$T$581, DW_AT_decl_column(0x03) $C$DW$T$1133 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1133, DW_AT_type(*$C$DW$T$1136) $C$DW$T$1134 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1134, DW_AT_type(*$C$DW$T$1133) .dwattr $C$DW$T$1134, DW_AT_address_class(0x20) $C$DW$T$1132 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1132, DW_AT_type(*$C$DW$T$1136) .dwattr $C$DW$T$1132, DW_AT_address_class(0x20) $C$DW$T$1135 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1135, DW_AT_type(*$C$DW$T$1132) .dwattr $C$DW$T$1135, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1490 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1490, DW_AT_type(*$C$DW$T$1134) .dwendtag $C$DW$T$1135 $C$DW$T$1141 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1141, DW_AT_name("ImgFilterAnIso2DParam") .dwattr $C$DW$T$1141, DW_AT_byte_size(0x0c) $C$DW$1491 .dwtag DW_TAG_member .dwattr $C$DW$1491, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1491, DW_AT_name("maskw") .dwattr $C$DW$1491, DW_AT_TI_symbol_name("maskw") .dwattr $C$DW$1491, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1491, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1491, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1491, DW_AT_decl_line(0x3f0) .dwattr $C$DW$1491, DW_AT_decl_column(0x09) $C$DW$1492 .dwtag DW_TAG_member .dwattr $C$DW$1492, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1492, DW_AT_name("maskh") .dwattr $C$DW$1492, DW_AT_TI_symbol_name("maskh") .dwattr $C$DW$1492, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1492, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1492, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1492, DW_AT_decl_line(0x3f1) .dwattr $C$DW$1492, DW_AT_decl_column(0x09) $C$DW$1493 .dwtag DW_TAG_member .dwattr $C$DW$1493, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1493, DW_AT_name("accuracyBits") .dwattr $C$DW$1493, DW_AT_TI_symbol_name("accuracyBits") .dwattr $C$DW$1493, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1493, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1493, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1493, DW_AT_decl_line(0x3f2) .dwattr $C$DW$1493, DW_AT_decl_column(0x09) $C$DW$61 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$61, DW_AT_declaration .dwattr $C$DW$61, DW_AT_TI_symbol_name("_ZN21ImgFilterAnIso2DParamaSERKS_") .dwattr $C$DW$61, DW_AT_type(*$C$DW$T$1137) .dwattr $C$DW$61, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1494 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1494, DW_AT_type(*$C$DW$T$1139) .dwendtag $C$DW$61 .dwendtag $C$DW$T$1141 .dwattr $C$DW$T$1141, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$T$1141, DW_AT_decl_line(0x3ee) .dwattr $C$DW$T$1141, DW_AT_decl_column(0x08) $C$DW$T$1138 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1138, DW_AT_type(*$C$DW$T$1141) $C$DW$T$1139 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1139, DW_AT_type(*$C$DW$T$1138) .dwattr $C$DW$T$1139, DW_AT_address_class(0x20) $C$DW$T$1137 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1137, DW_AT_type(*$C$DW$T$1141) .dwattr $C$DW$T$1137, DW_AT_address_class(0x20) $C$DW$T$1140 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1140, DW_AT_type(*$C$DW$T$1137) .dwattr $C$DW$T$1140, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1495 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1495, DW_AT_type(*$C$DW$T$1139) .dwendtag $C$DW$T$1140 $C$DW$T$1161 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1161, DW_AT_name("InitMsg") .dwattr $C$DW$T$1161, DW_AT_byte_size(0x38) $C$DW$1496 .dwtag DW_TAG_member .dwattr $C$DW$1496, DW_AT_type(*$C$DW$T$510) .dwattr $C$DW$1496, DW_AT_name("spDataType") .dwattr $C$DW$1496, DW_AT_TI_symbol_name("spDataType") .dwattr $C$DW$1496, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1496, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1496, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1496, DW_AT_decl_line(0x77) .dwattr $C$DW$1496, DW_AT_decl_column(0x19) $C$DW$1497 .dwtag DW_TAG_member .dwattr $C$DW$1497, DW_AT_type(*$C$DW$T$454) .dwattr $C$DW$1497, DW_AT_name("command") .dwattr $C$DW$1497, DW_AT_TI_symbol_name("command") .dwattr $C$DW$1497, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1497, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1497, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1497, DW_AT_decl_line(0x78) .dwattr $C$DW$1497, DW_AT_decl_column(0x19) $C$DW$1498 .dwtag DW_TAG_member .dwattr $C$DW$1498, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$1498, DW_AT_name("timeStarted") .dwattr $C$DW$1498, DW_AT_TI_symbol_name("timeStarted") .dwattr $C$DW$1498, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1498, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1498, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1498, DW_AT_decl_line(0x79) .dwattr $C$DW$1498, DW_AT_decl_column(0x19) $C$DW$1499 .dwtag DW_TAG_member .dwattr $C$DW$1499, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$1499, DW_AT_name("timeEnded") .dwattr $C$DW$1499, DW_AT_TI_symbol_name("timeEnded") .dwattr $C$DW$1499, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1499, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1499, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1499, DW_AT_decl_line(0x7a) .dwattr $C$DW$1499, DW_AT_decl_column(0x19) $C$DW$1500 .dwtag DW_TAG_member .dwattr $C$DW$1500, DW_AT_type(*$C$DW$T$508) .dwattr $C$DW$1500, DW_AT_name("coreId") .dwattr $C$DW$1500, DW_AT_TI_symbol_name("coreId") .dwattr $C$DW$1500, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1500, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1500, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1500, DW_AT_decl_line(0x7b) .dwattr $C$DW$1500, DW_AT_decl_column(0x19) $C$DW$1501 .dwtag DW_TAG_member .dwattr $C$DW$1501, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$1501, DW_AT_name("enableDryRun") .dwattr $C$DW$1501, DW_AT_TI_symbol_name("enableDryRun") .dwattr $C$DW$1501, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c] .dwattr $C$DW$1501, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1501, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1501, DW_AT_decl_line(0x7c) .dwattr $C$DW$1501, DW_AT_decl_column(0x19) $C$DW$1502 .dwtag DW_TAG_member .dwattr $C$DW$1502, DW_AT_type(*$C$DW$T$522) .dwattr $C$DW$1502, DW_AT_name("pDryRunInCBuf") .dwattr $C$DW$1502, DW_AT_TI_symbol_name("pDryRunInCBuf") .dwattr $C$DW$1502, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1502, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1502, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1502, DW_AT_decl_line(0x7d) .dwattr $C$DW$1502, DW_AT_decl_column(0x19) $C$DW$1503 .dwtag DW_TAG_member .dwattr $C$DW$1503, DW_AT_type(*$C$DW$T$522) .dwattr $C$DW$1503, DW_AT_name("pDryRunOutCBuf") .dwattr $C$DW$1503, DW_AT_TI_symbol_name("pDryRunOutCBuf") .dwattr $C$DW$1503, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1503, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1503, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1503, DW_AT_decl_line(0x7e) .dwattr $C$DW$1503, DW_AT_decl_column(0x19) $C$DW$1504 .dwtag DW_TAG_member .dwattr $C$DW$1504, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1504, DW_AT_name("numInCmd") .dwattr $C$DW$1504, DW_AT_TI_symbol_name("numInCmd") .dwattr $C$DW$1504, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1504, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1504, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1504, DW_AT_decl_line(0x7f) .dwattr $C$DW$1504, DW_AT_decl_column(0x19) $C$DW$1505 .dwtag DW_TAG_member .dwattr $C$DW$1505, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1505, DW_AT_name("numOutCmd") .dwattr $C$DW$1505, DW_AT_TI_symbol_name("numOutCmd") .dwattr $C$DW$1505, DW_AT_data_member_location[DW_OP_plus_uconst 0x34] .dwattr $C$DW$1505, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1505, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1505, DW_AT_decl_line(0x80) .dwattr $C$DW$1505, DW_AT_decl_column(0x19) $C$DW$62 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$62, DW_AT_declaration .dwattr $C$DW$62, DW_AT_TI_symbol_name("_ZN7InitMsgaSERKS_") .dwattr $C$DW$62, DW_AT_type(*$C$DW$T$1157) .dwattr $C$DW$62, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1506 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1506, DW_AT_type(*$C$DW$T$1159) .dwendtag $C$DW$62 .dwendtag $C$DW$T$1161 .dwattr $C$DW$T$1161, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1161, DW_AT_decl_line(0x76) .dwattr $C$DW$T$1161, DW_AT_decl_column(0x01) $C$DW$T$1158 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1158, DW_AT_type(*$C$DW$T$1161) $C$DW$T$1159 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1159, DW_AT_type(*$C$DW$T$1158) .dwattr $C$DW$T$1159, DW_AT_address_class(0x20) $C$DW$T$1473 .dwtag DW_TAG_typedef, DW_AT_name("InitMsg") .dwattr $C$DW$T$1473, DW_AT_type(*$C$DW$T$1161) .dwattr $C$DW$T$1473, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1473, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1473, DW_AT_decl_line(0x81) .dwattr $C$DW$T$1473, DW_AT_decl_column(0x03) $C$DW$T$1157 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1157, DW_AT_type(*$C$DW$T$1161) .dwattr $C$DW$T$1157, DW_AT_address_class(0x20) $C$DW$T$1160 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1160, DW_AT_type(*$C$DW$T$1157) .dwattr $C$DW$T$1160, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1507 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1507, DW_AT_type(*$C$DW$T$1159) .dwendtag $C$DW$T$1160 $C$DW$T$1172 .dwtag DW_TAG_union_type .dwattr $C$DW$T$1172, DW_AT_name("InputMgrData") .dwattr $C$DW$T$1172, DW_AT_byte_size(0x18) $C$DW$1508 .dwtag DW_TAG_member .dwattr $C$DW$1508, DW_AT_type(*$C$DW$T$1162) .dwattr $C$DW$1508, DW_AT_name("MBInputData") .dwattr $C$DW$1508, DW_AT_TI_symbol_name("MBInputData") .dwattr $C$DW$1508, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1508, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1508, DW_AT_decl_line(0x38) .dwattr $C$DW$1508, DW_AT_decl_column(0x1b) $C$DW$1509 .dwtag DW_TAG_member .dwattr $C$DW$1509, DW_AT_type(*$C$DW$T$1163) .dwattr $C$DW$1509, DW_AT_name("nMBInputData") .dwattr $C$DW$1509, DW_AT_TI_symbol_name("nMBInputData") .dwattr $C$DW$1509, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1509, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1509, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1509, DW_AT_decl_line(0x39) .dwattr $C$DW$1509, DW_AT_decl_column(0x1b) $C$DW$1510 .dwtag DW_TAG_member .dwattr $C$DW$1510, DW_AT_type(*$C$DW$T$1164) .dwattr $C$DW$1510, DW_AT_name("dopplerData") .dwattr $C$DW$1510, DW_AT_TI_symbol_name("dopplerData") .dwattr $C$DW$1510, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1510, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1510, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1510, DW_AT_decl_line(0x3a) .dwattr $C$DW$1510, DW_AT_decl_column(0x1b) $C$DW$1511 .dwtag DW_TAG_member .dwattr $C$DW$1511, DW_AT_type(*$C$DW$T$1165) .dwattr $C$DW$1511, DW_AT_name("colorData") .dwattr $C$DW$1511, DW_AT_TI_symbol_name("colorData") .dwattr $C$DW$1511, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1511, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1511, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1511, DW_AT_decl_line(0x3b) .dwattr $C$DW$1511, DW_AT_decl_column(0x1b) $C$DW$1512 .dwtag DW_TAG_member .dwattr $C$DW$1512, DW_AT_type(*$C$DW$T$1166) .dwattr $C$DW$1512, DW_AT_name("mModeData") .dwattr $C$DW$1512, DW_AT_TI_symbol_name("mModeData") .dwattr $C$DW$1512, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1512, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1512, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1512, DW_AT_decl_line(0x3c) .dwattr $C$DW$1512, DW_AT_decl_column(0x1b) $C$DW$1513 .dwtag DW_TAG_member .dwattr $C$DW$1513, DW_AT_type(*$C$DW$T$1167) .dwattr $C$DW$1513, DW_AT_name("ecgData") .dwattr $C$DW$1513, DW_AT_TI_symbol_name("ecgData") .dwattr $C$DW$1513, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1513, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1513, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1513, DW_AT_decl_line(0x3d) .dwattr $C$DW$1513, DW_AT_decl_column(0x1b) $C$DW$63 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$63, DW_AT_declaration .dwattr $C$DW$63, DW_AT_TI_symbol_name("_ZN12InputMgrDataaSERKS_") .dwattr $C$DW$63, DW_AT_type(*$C$DW$T$1168) .dwattr $C$DW$63, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1514 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1514, DW_AT_type(*$C$DW$T$1170) .dwendtag $C$DW$63 .dwendtag $C$DW$T$1172 .dwattr $C$DW$T$1172, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1172, DW_AT_decl_line(0x37) .dwattr $C$DW$T$1172, DW_AT_decl_column(0x01) $C$DW$T$1169 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1169, DW_AT_type(*$C$DW$T$1172) $C$DW$T$1170 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1170, DW_AT_type(*$C$DW$T$1169) .dwattr $C$DW$T$1170, DW_AT_address_class(0x20) $C$DW$T$1469 .dwtag DW_TAG_typedef, DW_AT_name("InputMgrData") .dwattr $C$DW$T$1469, DW_AT_type(*$C$DW$T$1172) .dwattr $C$DW$T$1469, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1469, DW_AT_decl_line(0x3f) .dwattr $C$DW$T$1469, DW_AT_decl_column(0x03) $C$DW$T$1168 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1168, DW_AT_type(*$C$DW$T$1172) .dwattr $C$DW$T$1168, DW_AT_address_class(0x20) $C$DW$T$1171 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1171, DW_AT_type(*$C$DW$T$1168) .dwattr $C$DW$T$1171, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1515 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1515, DW_AT_type(*$C$DW$T$1170) .dwendtag $C$DW$T$1171 $C$DW$T$877 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$877, DW_AT_name("KernelFilter_Coeff") .dwattr $C$DW$T$877, DW_AT_byte_size(0xc0) $C$DW$1516 .dwtag DW_TAG_member .dwattr $C$DW$1516, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$1516, DW_AT_name("length") .dwattr $C$DW$1516, DW_AT_TI_symbol_name("length") .dwattr $C$DW$1516, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1516, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1516, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1516, DW_AT_decl_line(0x40f) .dwattr $C$DW$1516, DW_AT_decl_column(0x05) $C$DW$1517 .dwtag DW_TAG_member .dwattr $C$DW$1517, DW_AT_type(*$C$DW$T$872) .dwattr $C$DW$1517, DW_AT_name("coeffs") .dwattr $C$DW$1517, DW_AT_TI_symbol_name("coeffs") .dwattr $C$DW$1517, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1517, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1517, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1517, DW_AT_decl_line(0x410) .dwattr $C$DW$1517, DW_AT_decl_column(0x05) $C$DW$1518 .dwtag DW_TAG_member .dwattr $C$DW$1518, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1518, DW_AT_name("reserved") .dwattr $C$DW$1518, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1518, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$1518, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1518, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1518, DW_AT_decl_line(0x411) .dwattr $C$DW$1518, DW_AT_decl_column(0x05) $C$DW$64 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$64, DW_AT_declaration .dwattr $C$DW$64, DW_AT_TI_symbol_name("_ZN18KernelFilter_CoeffaSERKS_") .dwattr $C$DW$64, DW_AT_type(*$C$DW$T$873) .dwattr $C$DW$64, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1519 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1519, DW_AT_type(*$C$DW$T$875) .dwendtag $C$DW$64 .dwendtag $C$DW$T$877 .dwattr $C$DW$T$877, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$877, DW_AT_decl_line(0x40e) .dwattr $C$DW$T$877, DW_AT_decl_column(0x01) $C$DW$T$874 .dwtag DW_TAG_const_type .dwattr $C$DW$T$874, DW_AT_type(*$C$DW$T$877) $C$DW$T$875 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$875, DW_AT_type(*$C$DW$T$874) .dwattr $C$DW$T$875, DW_AT_address_class(0x20) $C$DW$T$1183 .dwtag DW_TAG_typedef, DW_AT_name("KernelFilter_Coeff") .dwattr $C$DW$T$1183, DW_AT_type(*$C$DW$T$877) .dwattr $C$DW$T$1183, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1183, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1183, DW_AT_decl_line(0x412) .dwattr $C$DW$T$1183, DW_AT_decl_column(0x03) $C$DW$T$873 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$873, DW_AT_type(*$C$DW$T$877) .dwattr $C$DW$T$873, DW_AT_address_class(0x20) $C$DW$T$876 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$876, DW_AT_type(*$C$DW$T$873) .dwattr $C$DW$T$876, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1520 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1520, DW_AT_type(*$C$DW$T$875) .dwendtag $C$DW$T$876 $C$DW$T$882 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$882, DW_AT_name("KernelFilter_Param") .dwattr $C$DW$T$882, DW_AT_byte_size(0xb8) $C$DW$1521 .dwtag DW_TAG_member .dwattr $C$DW$1521, DW_AT_type(*$C$DW$T$134) .dwattr $C$DW$1521, DW_AT_name("pKernelFiltCoeffs") .dwattr $C$DW$1521, DW_AT_TI_symbol_name("pKernelFiltCoeffs") .dwattr $C$DW$1521, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1521, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1521, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1521, DW_AT_decl_line(0x402) .dwattr $C$DW$1521, DW_AT_decl_column(0x05) $C$DW$1522 .dwtag DW_TAG_member .dwattr $C$DW$1522, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$1522, DW_AT_name("KrnCoeffsSize") .dwattr $C$DW$1522, DW_AT_TI_symbol_name("KrnCoeffsSize") .dwattr $C$DW$1522, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1522, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1522, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1522, DW_AT_decl_line(0x403) .dwattr $C$DW$1522, DW_AT_decl_column(0x05) $C$DW$1523 .dwtag DW_TAG_member .dwattr $C$DW$1523, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$1523, DW_AT_name("KrnFilterLen") .dwattr $C$DW$1523, DW_AT_TI_symbol_name("KrnFilterLen") .dwattr $C$DW$1523, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1523, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1523, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1523, DW_AT_decl_line(0x404) .dwattr $C$DW$1523, DW_AT_decl_column(0x05) $C$DW$1524 .dwtag DW_TAG_member .dwattr $C$DW$1524, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$1524, DW_AT_name("KrnGain") .dwattr $C$DW$1524, DW_AT_TI_symbol_name("KrnGain") .dwattr $C$DW$1524, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1524, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1524, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1524, DW_AT_decl_line(0x405) .dwattr $C$DW$1524, DW_AT_decl_column(0x05) $C$DW$1525 .dwtag DW_TAG_member .dwattr $C$DW$1525, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1525, DW_AT_name("KrnMm5Reg") .dwattr $C$DW$1525, DW_AT_TI_symbol_name("KrnMm5Reg") .dwattr $C$DW$1525, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1525, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1525, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1525, DW_AT_decl_line(0x406) .dwattr $C$DW$1525, DW_AT_decl_column(0x05) $C$DW$1526 .dwtag DW_TAG_member .dwattr $C$DW$1526, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1526, DW_AT_name("KrnMm6Reg") .dwattr $C$DW$1526, DW_AT_TI_symbol_name("KrnMm6Reg") .dwattr $C$DW$1526, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1526, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1526, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1526, DW_AT_decl_line(0x407) .dwattr $C$DW$1526, DW_AT_decl_column(0x05) $C$DW$1527 .dwtag DW_TAG_member .dwattr $C$DW$1527, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1527, DW_AT_name("KrnMm7Reg") .dwattr $C$DW$1527, DW_AT_TI_symbol_name("KrnMm7Reg") .dwattr $C$DW$1527, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1527, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1527, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1527, DW_AT_decl_line(0x408) .dwattr $C$DW$1527, DW_AT_decl_column(0x05) $C$DW$1528 .dwtag DW_TAG_member .dwattr $C$DW$1528, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1528, DW_AT_name("reserved") .dwattr $C$DW$1528, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1528, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$1528, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1528, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1528, DW_AT_decl_line(0x409) .dwattr $C$DW$1528, DW_AT_decl_column(0x05) $C$DW$65 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$65, DW_AT_declaration .dwattr $C$DW$65, DW_AT_TI_symbol_name("_ZN18KernelFilter_ParamaSERKS_") .dwattr $C$DW$65, DW_AT_type(*$C$DW$T$878) .dwattr $C$DW$65, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1529 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1529, DW_AT_type(*$C$DW$T$880) .dwendtag $C$DW$65 .dwendtag $C$DW$T$882 .dwattr $C$DW$T$882, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$882, DW_AT_decl_line(0x401) .dwattr $C$DW$T$882, DW_AT_decl_column(0x10) $C$DW$T$879 .dwtag DW_TAG_const_type .dwattr $C$DW$T$879, DW_AT_type(*$C$DW$T$882) $C$DW$T$880 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$880, DW_AT_type(*$C$DW$T$879) .dwattr $C$DW$T$880, DW_AT_address_class(0x20) $C$DW$T$2146 .dwtag DW_TAG_typedef, DW_AT_name("KernelFilter_Param") .dwattr $C$DW$T$2146, DW_AT_type(*$C$DW$T$882) .dwattr $C$DW$T$2146, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2146, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$2146, DW_AT_decl_line(0x40a) .dwattr $C$DW$T$2146, DW_AT_decl_column(0x03) $C$DW$T$878 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$878, DW_AT_type(*$C$DW$T$882) .dwattr $C$DW$T$878, DW_AT_address_class(0x20) $C$DW$T$881 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$881, DW_AT_type(*$C$DW$T$878) .dwattr $C$DW$T$881, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1530 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1530, DW_AT_type(*$C$DW$T$880) .dwendtag $C$DW$T$881 $C$DW$T$1549 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1549, DW_AT_name("LutParam") .dwattr $C$DW$T$1549, DW_AT_byte_size(0x0c) $C$DW$1531 .dwtag DW_TAG_member .dwattr $C$DW$1531, DW_AT_type(*$C$DW$T$1544) .dwattr $C$DW$1531, DW_AT_name("lut") .dwattr $C$DW$1531, DW_AT_TI_symbol_name("lut") .dwattr $C$DW$1531, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1531, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1531, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1531, DW_AT_decl_line(0x35) .dwattr $C$DW$1531, DW_AT_decl_column(0x0b) $C$DW$1532 .dwtag DW_TAG_member .dwattr $C$DW$1532, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1532, DW_AT_name("accuracyBits") .dwattr $C$DW$1532, DW_AT_TI_symbol_name("accuracyBits") .dwattr $C$DW$1532, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1532, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1532, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1532, DW_AT_decl_line(0x36) .dwattr $C$DW$1532, DW_AT_decl_column(0x06) $C$DW$1533 .dwtag DW_TAG_member .dwattr $C$DW$1533, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1533, DW_AT_name("num") .dwattr $C$DW$1533, DW_AT_TI_symbol_name("num") .dwattr $C$DW$1533, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1533, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1533, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1533, DW_AT_decl_line(0x37) .dwattr $C$DW$1533, DW_AT_decl_column(0x06) $C$DW$66 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$66, DW_AT_declaration .dwattr $C$DW$66, DW_AT_TI_symbol_name("_ZN8LutParamaSERKS_") .dwattr $C$DW$66, DW_AT_type(*$C$DW$T$1545) .dwattr $C$DW$66, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1534 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1534, DW_AT_type(*$C$DW$T$1547) .dwendtag $C$DW$66 .dwendtag $C$DW$T$1549 .dwattr $C$DW$T$1549, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$1549, DW_AT_decl_line(0x33) .dwattr $C$DW$T$1549, DW_AT_decl_column(0x08) $C$DW$T$1546 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1546, DW_AT_type(*$C$DW$T$1549) $C$DW$T$1547 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1547, DW_AT_type(*$C$DW$T$1546) .dwattr $C$DW$T$1547, DW_AT_address_class(0x20) $C$DW$T$444 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$444, DW_AT_type(*$C$DW$T$1549) .dwattr $C$DW$T$444, DW_AT_address_class(0x20) $C$DW$T$1196 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1196, DW_AT_type(*$C$DW$T$1549) .dwattr $C$DW$T$1196, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1196, DW_AT_byte_size(0x3c) $C$DW$1535 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1535, DW_AT_upper_bound(0x04) .dwendtag $C$DW$T$1196 $C$DW$T$1545 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1545, DW_AT_type(*$C$DW$T$1549) .dwattr $C$DW$T$1545, DW_AT_address_class(0x20) $C$DW$T$1548 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1548, DW_AT_type(*$C$DW$T$1545) .dwattr $C$DW$T$1548, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1536 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1536, DW_AT_type(*$C$DW$T$1547) .dwendtag $C$DW$T$1548 $C$DW$T$1555 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1555, DW_AT_name("LutParamFloat") .dwattr $C$DW$T$1555, DW_AT_byte_size(0x40008) $C$DW$1537 .dwtag DW_TAG_member .dwattr $C$DW$1537, DW_AT_type(*$C$DW$T$1550) .dwattr $C$DW$1537, DW_AT_name("lut") .dwattr $C$DW$1537, DW_AT_TI_symbol_name("lut") .dwattr $C$DW$1537, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1537, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1537, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1537, DW_AT_decl_line(0x4c) .dwattr $C$DW$1537, DW_AT_decl_column(0x08) $C$DW$1538 .dwtag DW_TAG_member .dwattr $C$DW$1538, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1538, DW_AT_name("num") .dwattr $C$DW$1538, DW_AT_TI_symbol_name("num") .dwattr $C$DW$1538, DW_AT_data_member_location[DW_OP_plus_uconst 0x40000] .dwattr $C$DW$1538, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1538, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1538, DW_AT_decl_line(0x4d) .dwattr $C$DW$1538, DW_AT_decl_column(0x07) $C$DW$1539 .dwtag DW_TAG_member .dwattr $C$DW$1539, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1539, DW_AT_name("accuracy") .dwattr $C$DW$1539, DW_AT_TI_symbol_name("accuracy") .dwattr $C$DW$1539, DW_AT_data_member_location[DW_OP_plus_uconst 0x40004] .dwattr $C$DW$1539, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1539, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1539, DW_AT_decl_line(0x4e) .dwattr $C$DW$1539, DW_AT_decl_column(0x07) $C$DW$67 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$67, DW_AT_declaration .dwattr $C$DW$67, DW_AT_TI_symbol_name("_ZN13LutParamFloataSERKS_") .dwattr $C$DW$67, DW_AT_type(*$C$DW$T$1551) .dwattr $C$DW$67, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1540 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1540, DW_AT_type(*$C$DW$T$1553) .dwendtag $C$DW$67 .dwendtag $C$DW$T$1555 .dwattr $C$DW$T$1555, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$1555, DW_AT_decl_line(0x4a) .dwattr $C$DW$T$1555, DW_AT_decl_column(0x08) $C$DW$T$1552 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1552, DW_AT_type(*$C$DW$T$1555) $C$DW$T$1553 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1553, DW_AT_type(*$C$DW$T$1552) .dwattr $C$DW$T$1553, DW_AT_address_class(0x20) $C$DW$T$1228 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1228, DW_AT_type(*$C$DW$T$1555) .dwattr $C$DW$T$1228, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1228, DW_AT_byte_size(0x140028) $C$DW$1541 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1541, DW_AT_upper_bound(0x04) .dwendtag $C$DW$T$1228 $C$DW$T$1551 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1551, DW_AT_type(*$C$DW$T$1555) .dwattr $C$DW$T$1551, DW_AT_address_class(0x20) $C$DW$T$1554 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1554, DW_AT_type(*$C$DW$T$1551) .dwattr $C$DW$T$1554, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1542 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1542, DW_AT_type(*$C$DW$T$1553) .dwendtag $C$DW$T$1554 $C$DW$T$1560 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1560, DW_AT_name("LutParamNEP") .dwattr $C$DW$T$1560, DW_AT_byte_size(0x40010) $C$DW$1543 .dwtag DW_TAG_member .dwattr $C$DW$1543, DW_AT_type(*$C$DW$T$1550) .dwattr $C$DW$1543, DW_AT_name("lut") .dwattr $C$DW$1543, DW_AT_TI_symbol_name("lut") .dwattr $C$DW$1543, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1543, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1543, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1543, DW_AT_decl_line(0x58) .dwattr $C$DW$1543, DW_AT_decl_column(0x0e) $C$DW$1544 .dwtag DW_TAG_member .dwattr $C$DW$1544, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1544, DW_AT_name("alpha") .dwattr $C$DW$1544, DW_AT_TI_symbol_name("alpha") .dwattr $C$DW$1544, DW_AT_data_member_location[DW_OP_plus_uconst 0x40000] .dwattr $C$DW$1544, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1544, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1544, DW_AT_decl_line(0x59) .dwattr $C$DW$1544, DW_AT_decl_column(0x0e) $C$DW$1545 .dwtag DW_TAG_member .dwattr $C$DW$1545, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1545, DW_AT_name("beta") .dwattr $C$DW$1545, DW_AT_TI_symbol_name("beta") .dwattr $C$DW$1545, DW_AT_data_member_location[DW_OP_plus_uconst 0x40004] .dwattr $C$DW$1545, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1545, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1545, DW_AT_decl_line(0x5a) .dwattr $C$DW$1545, DW_AT_decl_column(0x0e) $C$DW$1546 .dwtag DW_TAG_member .dwattr $C$DW$1546, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1546, DW_AT_name("gamma") .dwattr $C$DW$1546, DW_AT_TI_symbol_name("gamma") .dwattr $C$DW$1546, DW_AT_data_member_location[DW_OP_plus_uconst 0x40008] .dwattr $C$DW$1546, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1546, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1546, DW_AT_decl_line(0x5b) .dwattr $C$DW$1546, DW_AT_decl_column(0x0e) $C$DW$1547 .dwtag DW_TAG_member .dwattr $C$DW$1547, DW_AT_type(*$C$DW$T$1544) .dwattr $C$DW$1547, DW_AT_name("lutS") .dwattr $C$DW$1547, DW_AT_TI_symbol_name("lutS") .dwattr $C$DW$1547, DW_AT_data_member_location[DW_OP_plus_uconst 0x4000c] .dwattr $C$DW$1547, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1547, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$1547, DW_AT_decl_line(0x5c) .dwattr $C$DW$1547, DW_AT_decl_column(0x0e) $C$DW$68 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$68, DW_AT_declaration .dwattr $C$DW$68, DW_AT_TI_symbol_name("_ZN11LutParamNEPaSERKS_") .dwattr $C$DW$68, DW_AT_type(*$C$DW$T$1556) .dwattr $C$DW$68, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1548 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1548, DW_AT_type(*$C$DW$T$1558) .dwendtag $C$DW$68 .dwendtag $C$DW$T$1560 .dwattr $C$DW$T$1560, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_sub.h") .dwattr $C$DW$T$1560, DW_AT_decl_line(0x56) .dwattr $C$DW$T$1560, DW_AT_decl_column(0x08) $C$DW$T$1557 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1557, DW_AT_type(*$C$DW$T$1560) $C$DW$T$1558 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1558, DW_AT_type(*$C$DW$T$1557) .dwattr $C$DW$T$1558, DW_AT_address_class(0x20) $C$DW$T$1200 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1200, DW_AT_type(*$C$DW$T$1560) .dwattr $C$DW$T$1200, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1200, DW_AT_byte_size(0x140050) $C$DW$1549 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1549, DW_AT_upper_bound(0x04) .dwendtag $C$DW$T$1200 $C$DW$T$1556 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1556, DW_AT_type(*$C$DW$T$1560) .dwattr $C$DW$T$1556, DW_AT_address_class(0x20) $C$DW$T$1559 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1559, DW_AT_type(*$C$DW$T$1556) .dwattr $C$DW$T$1559, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1550 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1550, DW_AT_type(*$C$DW$T$1558) .dwendtag $C$DW$T$1559 $C$DW$T$142 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$142, DW_AT_name("MMode_Param") .dwattr $C$DW$T$142, DW_AT_byte_size(0x150) $C$DW$1551 .dwtag DW_TAG_member .dwattr $C$DW$1551, DW_AT_type(*$C$DW$T$132) .dwattr $C$DW$1551, DW_AT_name("subMode") .dwattr $C$DW$1551, DW_AT_TI_symbol_name("subMode") .dwattr $C$DW$1551, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1551, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1551, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1551, DW_AT_decl_line(0x4d6) .dwattr $C$DW$1551, DW_AT_decl_column(0x05) $C$DW$1552 .dwtag DW_TAG_member .dwattr $C$DW$1552, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1552, DW_AT_name("InpEchoEstimates") .dwattr $C$DW$1552, DW_AT_TI_symbol_name("InpEchoEstimates") .dwattr $C$DW$1552, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1552, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1552, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1552, DW_AT_decl_line(0x4d7) .dwattr $C$DW$1552, DW_AT_decl_column(0x05) $C$DW$1553 .dwtag DW_TAG_member .dwattr $C$DW$1553, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1553, DW_AT_name("InpColorEstimates") .dwattr $C$DW$1553, DW_AT_TI_symbol_name("InpColorEstimates") .dwattr $C$DW$1553, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1553, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1553, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1553, DW_AT_decl_line(0x4d8) .dwattr $C$DW$1553, DW_AT_decl_column(0x05) $C$DW$1554 .dwtag DW_TAG_member .dwattr $C$DW$1554, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1554, DW_AT_name("InputValidEsts") .dwattr $C$DW$1554, DW_AT_TI_symbol_name("InputValidEsts") .dwattr $C$DW$1554, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1554, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1554, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1554, DW_AT_decl_line(0x4d9) .dwattr $C$DW$1554, DW_AT_decl_column(0x05) $C$DW$1555 .dwtag DW_TAG_member .dwattr $C$DW$1555, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1555, DW_AT_name("StartEstimates") .dwattr $C$DW$1555, DW_AT_TI_symbol_name("StartEstimates") .dwattr $C$DW$1555, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1555, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1555, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1555, DW_AT_decl_line(0x4da) .dwattr $C$DW$1555, DW_AT_decl_column(0x05) $C$DW$1556 .dwtag DW_TAG_member .dwattr $C$DW$1556, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1556, DW_AT_name("VerticalScaleFactor") .dwattr $C$DW$1556, DW_AT_TI_symbol_name("VerticalScaleFactor") .dwattr $C$DW$1556, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1556, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1556, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1556, DW_AT_decl_line(0x4db) .dwattr $C$DW$1556, DW_AT_decl_column(0x05) $C$DW$1557 .dwtag DW_TAG_member .dwattr $C$DW$1557, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1557, DW_AT_name("NumScaledPixels") .dwattr $C$DW$1557, DW_AT_TI_symbol_name("NumScaledPixels") .dwattr $C$DW$1557, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1557, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1557, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1557, DW_AT_decl_line(0x4dc) .dwattr $C$DW$1557, DW_AT_decl_column(0x05) $C$DW$1558 .dwtag DW_TAG_member .dwattr $C$DW$1558, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1558, DW_AT_name("MultiLineON") .dwattr $C$DW$1558, DW_AT_TI_symbol_name("MultiLineON") .dwattr $C$DW$1558, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$1558, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1558, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1558, DW_AT_decl_line(0x4dd) .dwattr $C$DW$1558, DW_AT_decl_column(0x05) $C$DW$1559 .dwtag DW_TAG_member .dwattr $C$DW$1559, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1559, DW_AT_name("EchoThreshold") .dwattr $C$DW$1559, DW_AT_TI_symbol_name("EchoThreshold") .dwattr $C$DW$1559, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$1559, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1559, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1559, DW_AT_decl_line(0x4de) .dwattr $C$DW$1559, DW_AT_decl_column(0x05) $C$DW$1560 .dwtag DW_TAG_member .dwattr $C$DW$1560, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1560, DW_AT_name("ColorThreshold") .dwattr $C$DW$1560, DW_AT_TI_symbol_name("ColorThreshold") .dwattr $C$DW$1560, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$1560, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1560, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1560, DW_AT_decl_line(0x4df) .dwattr $C$DW$1560, DW_AT_decl_column(0x05) $C$DW$1561 .dwtag DW_TAG_member .dwattr $C$DW$1561, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1561, DW_AT_name("InputRate") .dwattr $C$DW$1561, DW_AT_TI_symbol_name("InputRate") .dwattr $C$DW$1561, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$1561, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1561, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1561, DW_AT_decl_line(0x4e0) .dwattr $C$DW$1561, DW_AT_decl_column(0x05) $C$DW$1562 .dwtag DW_TAG_member .dwattr $C$DW$1562, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1562, DW_AT_name("OutputRate") .dwattr $C$DW$1562, DW_AT_TI_symbol_name("OutputRate") .dwattr $C$DW$1562, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$1562, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1562, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1562, DW_AT_decl_line(0x4e1) .dwattr $C$DW$1562, DW_AT_decl_column(0x05) $C$DW$1563 .dwtag DW_TAG_member .dwattr $C$DW$1563, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1563, DW_AT_name("persistence") .dwattr $C$DW$1563, DW_AT_TI_symbol_name("persistence") .dwattr $C$DW$1563, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$1563, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1563, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1563, DW_AT_decl_line(0x4e2) .dwattr $C$DW$1563, DW_AT_decl_column(0x05) $C$DW$1564 .dwtag DW_TAG_member .dwattr $C$DW$1564, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1564, DW_AT_name("ColorEstimateDoubling") .dwattr $C$DW$1564, DW_AT_TI_symbol_name("ColorEstimateDoubling") .dwattr $C$DW$1564, DW_AT_data_member_location[DW_OP_plus_uconst 0x68] .dwattr $C$DW$1564, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1564, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1564, DW_AT_decl_line(0x4e3) .dwattr $C$DW$1564, DW_AT_decl_column(0x05) $C$DW$1565 .dwtag DW_TAG_member .dwattr $C$DW$1565, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1565, DW_AT_name("ColorEstimateStart") .dwattr $C$DW$1565, DW_AT_TI_symbol_name("ColorEstimateStart") .dwattr $C$DW$1565, DW_AT_data_member_location[DW_OP_plus_uconst 0x70] .dwattr $C$DW$1565, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1565, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1565, DW_AT_decl_line(0x4e4) .dwattr $C$DW$1565, DW_AT_decl_column(0x05) $C$DW$1566 .dwtag DW_TAG_member .dwattr $C$DW$1566, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1566, DW_AT_name("logPwrThreshLower") .dwattr $C$DW$1566, DW_AT_TI_symbol_name("logPwrThreshLower") .dwattr $C$DW$1566, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1566, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1566, DW_AT_decl_line(0x4e5) .dwattr $C$DW$1566, DW_AT_decl_column(0x05) $C$DW$1567 .dwtag DW_TAG_member .dwattr $C$DW$1567, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1567, DW_AT_name("invLogPwrTaperRngM") .dwattr $C$DW$1567, DW_AT_TI_symbol_name("invLogPwrTaperRngM") .dwattr $C$DW$1567, DW_AT_data_member_location[DW_OP_plus_uconst 0x80] .dwattr $C$DW$1567, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1567, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1567, DW_AT_decl_line(0x4e6) .dwattr $C$DW$1567, DW_AT_decl_column(0x05) $C$DW$1568 .dwtag DW_TAG_member .dwattr $C$DW$1568, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1568, DW_AT_name("invLogPwrTaperRngE") .dwattr $C$DW$1568, DW_AT_TI_symbol_name("invLogPwrTaperRngE") .dwattr $C$DW$1568, DW_AT_data_member_location[DW_OP_plus_uconst 0x88] .dwattr $C$DW$1568, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1568, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1568, DW_AT_decl_line(0x4e7) .dwattr $C$DW$1568, DW_AT_decl_column(0x05) $C$DW$1569 .dwtag DW_TAG_member .dwattr $C$DW$1569, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1569, DW_AT_name("logRatioThreshLower") .dwattr $C$DW$1569, DW_AT_TI_symbol_name("logRatioThreshLower") .dwattr $C$DW$1569, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$1569, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1569, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1569, DW_AT_decl_line(0x4e8) .dwattr $C$DW$1569, DW_AT_decl_column(0x05) $C$DW$1570 .dwtag DW_TAG_member .dwattr $C$DW$1570, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1570, DW_AT_name("invLogRatioTaperRngM") .dwattr $C$DW$1570, DW_AT_TI_symbol_name("invLogRatioTaperRngM") .dwattr $C$DW$1570, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$1570, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1570, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1570, DW_AT_decl_line(0x4e9) .dwattr $C$DW$1570, DW_AT_decl_column(0x05) $C$DW$1571 .dwtag DW_TAG_member .dwattr $C$DW$1571, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1571, DW_AT_name("invLogRatioTaperRngE") .dwattr $C$DW$1571, DW_AT_TI_symbol_name("invLogRatioTaperRngE") .dwattr $C$DW$1571, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0] .dwattr $C$DW$1571, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1571, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1571, DW_AT_decl_line(0x4ea) .dwattr $C$DW$1571, DW_AT_decl_column(0x05) $C$DW$1572 .dwtag DW_TAG_member .dwattr $C$DW$1572, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1572, DW_AT_name("graphicsHeight") .dwattr $C$DW$1572, DW_AT_TI_symbol_name("graphicsHeight") .dwattr $C$DW$1572, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$1572, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1572, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1572, DW_AT_decl_line(0x4eb) .dwattr $C$DW$1572, DW_AT_decl_column(0x05) $C$DW$1573 .dwtag DW_TAG_member .dwattr $C$DW$1573, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1573, DW_AT_name("graphicsWidth") .dwattr $C$DW$1573, DW_AT_TI_symbol_name("graphicsWidth") .dwattr $C$DW$1573, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0] .dwattr $C$DW$1573, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1573, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1573, DW_AT_decl_line(0x4ec) .dwattr $C$DW$1573, DW_AT_decl_column(0x05) $C$DW$1574 .dwtag DW_TAG_member .dwattr $C$DW$1574, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1574, DW_AT_name("VarianceOn") .dwattr $C$DW$1574, DW_AT_TI_symbol_name("VarianceOn") .dwattr $C$DW$1574, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8] .dwattr $C$DW$1574, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1574, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1574, DW_AT_decl_line(0x4ed) .dwattr $C$DW$1574, DW_AT_decl_column(0x05) $C$DW$1575 .dwtag DW_TAG_member .dwattr $C$DW$1575, DW_AT_type(*$C$DW$T$134) .dwattr $C$DW$1575, DW_AT_name("pCMModeKernel") .dwattr $C$DW$1575, DW_AT_TI_symbol_name("pCMModeKernel") .dwattr $C$DW$1575, DW_AT_data_member_location[DW_OP_plus_uconst 0xc0] .dwattr $C$DW$1575, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1575, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1575, DW_AT_decl_line(0x4ee) .dwattr $C$DW$1575, DW_AT_decl_column(0x05) $C$DW$1576 .dwtag DW_TAG_member .dwattr $C$DW$1576, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1576, DW_AT_name("numLinesForAvg") .dwattr $C$DW$1576, DW_AT_TI_symbol_name("numLinesForAvg") .dwattr $C$DW$1576, DW_AT_data_member_location[DW_OP_plus_uconst 0xc8] .dwattr $C$DW$1576, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1576, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1576, DW_AT_decl_line(0x4ef) .dwattr $C$DW$1576, DW_AT_decl_column(0x05) $C$DW$1577 .dwtag DW_TAG_member .dwattr $C$DW$1577, DW_AT_type(*$C$DW$T$135) .dwattr $C$DW$1577, DW_AT_name("amm") .dwattr $C$DW$1577, DW_AT_TI_symbol_name("amm") .dwattr $C$DW$1577, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0] .dwattr $C$DW$1577, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1577, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1577, DW_AT_decl_line(0x4f1) .dwattr $C$DW$1577, DW_AT_decl_column(0x05) $C$DW$1578 .dwtag DW_TAG_member .dwattr $C$DW$1578, DW_AT_type(*$C$DW$T$137) .dwattr $C$DW$1578, DW_AT_name("reserved") .dwattr $C$DW$1578, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1578, DW_AT_data_member_location[DW_OP_plus_uconst 0xf0] .dwattr $C$DW$1578, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1578, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1578, DW_AT_decl_line(0x4f2) .dwattr $C$DW$1578, DW_AT_decl_column(0x05) $C$DW$69 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$69, DW_AT_declaration .dwattr $C$DW$69, DW_AT_TI_symbol_name("_ZN11MMode_ParamaSERKS_") .dwattr $C$DW$69, DW_AT_type(*$C$DW$T$138) .dwattr $C$DW$69, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1579 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1579, DW_AT_type(*$C$DW$T$140) .dwendtag $C$DW$69 .dwendtag $C$DW$T$142 .dwattr $C$DW$T$142, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$142, DW_AT_decl_line(0x4d5) .dwattr $C$DW$T$142, DW_AT_decl_column(0x01) $C$DW$T$139 .dwtag DW_TAG_const_type .dwattr $C$DW$T$139, DW_AT_type(*$C$DW$T$142) $C$DW$T$140 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$140, DW_AT_type(*$C$DW$T$139) .dwattr $C$DW$T$140, DW_AT_address_class(0x20) $C$DW$T$1594 .dwtag DW_TAG_typedef, DW_AT_name("MMode_Param") .dwattr $C$DW$T$1594, DW_AT_type(*$C$DW$T$142) .dwattr $C$DW$T$1594, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1594, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1594, DW_AT_decl_line(0x4f3) .dwattr $C$DW$T$1594, DW_AT_decl_column(0x03) $C$DW$T$138 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$138, DW_AT_type(*$C$DW$T$142) .dwattr $C$DW$T$138, DW_AT_address_class(0x20) $C$DW$T$141 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$141, DW_AT_type(*$C$DW$T$138) .dwattr $C$DW$T$141, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1580 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1580, DW_AT_type(*$C$DW$T$140) .dwendtag $C$DW$T$141 $C$DW$T$332 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$332, DW_AT_name("M_Test") .dwattr $C$DW$T$332, DW_AT_byte_size(0x0c) $C$DW$1581 .dwtag DW_TAG_member .dwattr $C$DW$1581, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1581, DW_AT_name("inputClockPeriodMSec") .dwattr $C$DW$1581, DW_AT_TI_symbol_name("inputClockPeriodMSec") .dwattr $C$DW$1581, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1581, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h") .dwattr $C$DW$1581, DW_AT_decl_line(0x17f) .dwattr $C$DW$1581, DW_AT_decl_column(0x0c) $C$DW$1582 .dwtag DW_TAG_member .dwattr $C$DW$1582, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1582, DW_AT_name("outputClockPeriodMSec") .dwattr $C$DW$1582, DW_AT_TI_symbol_name("outputClockPeriodMSec") .dwattr $C$DW$1582, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1582, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1582, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h") .dwattr $C$DW$1582, DW_AT_decl_line(0x180) .dwattr $C$DW$1582, DW_AT_decl_column(0x0c) $C$DW$1583 .dwtag DW_TAG_member .dwattr $C$DW$1583, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1583, DW_AT_name("numInputMessages") .dwattr $C$DW$1583, DW_AT_TI_symbol_name("numInputMessages") .dwattr $C$DW$1583, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1583, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1583, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h") .dwattr $C$DW$1583, DW_AT_decl_line(0x181) .dwattr $C$DW$1583, DW_AT_decl_column(0x0c) $C$DW$70 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$70, DW_AT_declaration .dwattr $C$DW$70, DW_AT_TI_symbol_name("_ZN6M_TestaSERKS_") .dwattr $C$DW$70, DW_AT_type(*$C$DW$T$328) .dwattr $C$DW$70, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1584 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1584, DW_AT_type(*$C$DW$T$330) .dwendtag $C$DW$70 .dwendtag $C$DW$T$332 .dwattr $C$DW$T$332, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h") .dwattr $C$DW$T$332, DW_AT_decl_line(0x17e) .dwattr $C$DW$T$332, DW_AT_decl_column(0x10) $C$DW$T$329 .dwtag DW_TAG_const_type .dwattr $C$DW$T$329, DW_AT_type(*$C$DW$T$332) $C$DW$T$330 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$330, DW_AT_type(*$C$DW$T$329) .dwattr $C$DW$T$330, DW_AT_address_class(0x20) $C$DW$T$1605 .dwtag DW_TAG_typedef, DW_AT_name("M_Test") .dwattr $C$DW$T$1605, DW_AT_type(*$C$DW$T$332) .dwattr $C$DW$T$1605, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1605, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Test/include/test.h") .dwattr $C$DW$T$1605, DW_AT_decl_line(0x182) .dwattr $C$DW$T$1605, DW_AT_decl_column(0x03) $C$DW$T$328 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$328, DW_AT_type(*$C$DW$T$332) .dwattr $C$DW$T$328, DW_AT_address_class(0x20) $C$DW$T$331 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$331, DW_AT_type(*$C$DW$T$328) .dwattr $C$DW$T$331, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1585 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1585, DW_AT_type(*$C$DW$T$330) .dwendtag $C$DW$T$331 $C$DW$T$370 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$370, DW_AT_name("MainCtlrData") .dwattr $C$DW$T$370, DW_AT_byte_size(0x08) $C$DW$1586 .dwtag DW_TAG_member .dwattr $C$DW$1586, DW_AT_type(*$C$DW$T$363) .dwattr $C$DW$1586, DW_AT_name("senderId") .dwattr $C$DW$1586, DW_AT_TI_symbol_name("senderId") .dwattr $C$DW$1586, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1586, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1586, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1586, DW_AT_decl_line(0x5c) .dwattr $C$DW$1586, DW_AT_decl_column(0x10) $C$DW$1587 .dwtag DW_TAG_member .dwattr $C$DW$1587, DW_AT_type(*$C$DW$T$365) .dwattr $C$DW$1587, DW_AT_name("borrowerId") .dwattr $C$DW$1587, DW_AT_TI_symbol_name("borrowerId") .dwattr $C$DW$1587, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1587, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1587, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1587, DW_AT_decl_line(0x5d) .dwattr $C$DW$1587, DW_AT_decl_column(0x1c) $C$DW$71 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$71, DW_AT_declaration .dwattr $C$DW$71, DW_AT_TI_symbol_name("_ZN12MainCtlrDataaSERKS_") .dwattr $C$DW$71, DW_AT_type(*$C$DW$T$366) .dwattr $C$DW$71, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1588 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1588, DW_AT_type(*$C$DW$T$368) .dwendtag $C$DW$71 .dwendtag $C$DW$T$370 .dwattr $C$DW$T$370, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$370, DW_AT_decl_line(0x5b) .dwattr $C$DW$T$370, DW_AT_decl_column(0x01) $C$DW$T$367 .dwtag DW_TAG_const_type .dwattr $C$DW$T$367, DW_AT_type(*$C$DW$T$370) $C$DW$T$368 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$368, DW_AT_type(*$C$DW$T$367) .dwattr $C$DW$T$368, DW_AT_address_class(0x20) $C$DW$T$1471 .dwtag DW_TAG_typedef, DW_AT_name("MainCtlrData") .dwattr $C$DW$T$1471, DW_AT_type(*$C$DW$T$370) .dwattr $C$DW$T$1471, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1471, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1471, DW_AT_decl_line(0x5e) .dwattr $C$DW$T$1471, DW_AT_decl_column(0x03) $C$DW$T$366 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$366, DW_AT_type(*$C$DW$T$370) .dwattr $C$DW$T$366, DW_AT_address_class(0x20) $C$DW$T$369 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$369, DW_AT_type(*$C$DW$T$366) .dwattr $C$DW$T$369, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1589 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1589, DW_AT_type(*$C$DW$T$368) .dwendtag $C$DW$T$369 $C$DW$T$505 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$505, DW_AT_name("McMgr_CbufBundle") .dwattr $C$DW$T$505, DW_AT_byte_size(0x88) $C$DW$1590 .dwtag DW_TAG_member .dwattr $C$DW$1590, DW_AT_type(*$C$DW$T$500) .dwattr $C$DW$1590, DW_AT_name("inCBuf") .dwattr $C$DW$1590, DW_AT_TI_symbol_name("inCBuf") .dwattr $C$DW$1590, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1590, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1590, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1590, DW_AT_decl_line(0x147) .dwattr $C$DW$1590, DW_AT_decl_column(0x19) $C$DW$1591 .dwtag DW_TAG_member .dwattr $C$DW$1591, DW_AT_type(*$C$DW$T$500) .dwattr $C$DW$1591, DW_AT_name("outCBuf") .dwattr $C$DW$1591, DW_AT_TI_symbol_name("outCBuf") .dwattr $C$DW$1591, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$1591, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1591, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1591, DW_AT_decl_line(0x148) .dwattr $C$DW$1591, DW_AT_decl_column(0x19) $C$DW$1592 .dwtag DW_TAG_member .dwattr $C$DW$1592, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1592, DW_AT_name("numInCBuf") .dwattr $C$DW$1592, DW_AT_TI_symbol_name("numInCBuf") .dwattr $C$DW$1592, DW_AT_data_member_location[DW_OP_plus_uconst 0x80] .dwattr $C$DW$1592, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1592, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1592, DW_AT_decl_line(0x149) .dwattr $C$DW$1592, DW_AT_decl_column(0x13) $C$DW$1593 .dwtag DW_TAG_member .dwattr $C$DW$1593, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1593, DW_AT_name("numOutCBuf") .dwattr $C$DW$1593, DW_AT_TI_symbol_name("numOutCBuf") .dwattr $C$DW$1593, DW_AT_data_member_location[DW_OP_plus_uconst 0x84] .dwattr $C$DW$1593, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1593, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1593, DW_AT_decl_line(0x14a) .dwattr $C$DW$1593, DW_AT_decl_column(0x13) $C$DW$72 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$72, DW_AT_declaration .dwattr $C$DW$72, DW_AT_TI_symbol_name("_ZN16McMgr_CbufBundleaSERKS_") .dwattr $C$DW$72, DW_AT_type(*$C$DW$T$501) .dwattr $C$DW$72, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1594 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1594, DW_AT_type(*$C$DW$T$503) .dwendtag $C$DW$72 .dwendtag $C$DW$T$505 .dwattr $C$DW$T$505, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$505, DW_AT_decl_line(0x146) .dwattr $C$DW$T$505, DW_AT_decl_column(0x01) $C$DW$T$502 .dwtag DW_TAG_const_type .dwattr $C$DW$T$502, DW_AT_type(*$C$DW$T$505) $C$DW$T$503 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$503, DW_AT_type(*$C$DW$T$502) .dwattr $C$DW$T$503, DW_AT_address_class(0x20) $C$DW$T$506 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CbufBundle") .dwattr $C$DW$T$506, DW_AT_type(*$C$DW$T$505) .dwattr $C$DW$T$506, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$506, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$506, DW_AT_decl_line(0x14b) .dwattr $C$DW$T$506, DW_AT_decl_column(0x03) $C$DW$T$501 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$501, DW_AT_type(*$C$DW$T$505) .dwattr $C$DW$T$501, DW_AT_address_class(0x20) $C$DW$T$504 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$504, DW_AT_type(*$C$DW$T$501) .dwattr $C$DW$T$504, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1595 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1595, DW_AT_type(*$C$DW$T$503) .dwendtag $C$DW$T$504 $C$DW$T$517 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$517, DW_AT_name("McMgr_CmdEntries") .dwattr $C$DW$T$517, DW_AT_byte_size(0xc0) $C$DW$1596 .dwtag DW_TAG_member .dwattr $C$DW$1596, DW_AT_type(*$C$DW$T$454) .dwattr $C$DW$1596, DW_AT_name("command") .dwattr $C$DW$1596, DW_AT_TI_symbol_name("command") .dwattr $C$DW$1596, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1596, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1596, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1596, DW_AT_decl_line(0x14f) .dwattr $C$DW$1596, DW_AT_decl_column(0x19) $C$DW$1597 .dwtag DW_TAG_member .dwattr $C$DW$1597, DW_AT_type(*$C$DW$T$506) .dwattr $C$DW$1597, DW_AT_name("cbufBundle") .dwattr $C$DW$1597, DW_AT_TI_symbol_name("cbufBundle") .dwattr $C$DW$1597, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1597, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1597, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1597, DW_AT_decl_line(0x150) .dwattr $C$DW$1597, DW_AT_decl_column(0x19) $C$DW$1598 .dwtag DW_TAG_member .dwattr $C$DW$1598, DW_AT_type(*$C$DW$T$508) .dwattr $C$DW$1598, DW_AT_name("coreAssign") .dwattr $C$DW$1598, DW_AT_TI_symbol_name("coreAssign") .dwattr $C$DW$1598, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$1598, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1598, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1598, DW_AT_decl_line(0x158) .dwattr $C$DW$1598, DW_AT_decl_column(0x19) $C$DW$1599 .dwtag DW_TAG_member .dwattr $C$DW$1599, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$1599, DW_AT_name("isCineData") .dwattr $C$DW$1599, DW_AT_TI_symbol_name("isCineData") .dwattr $C$DW$1599, DW_AT_data_member_location[DW_OP_plus_uconst 0x94] .dwattr $C$DW$1599, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1599, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1599, DW_AT_decl_line(0x159) .dwattr $C$DW$1599, DW_AT_decl_column(0x19) $C$DW$1600 .dwtag DW_TAG_member .dwattr $C$DW$1600, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1600, DW_AT_name("cineOutDelay") .dwattr $C$DW$1600, DW_AT_TI_symbol_name("cineOutDelay") .dwattr $C$DW$1600, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$1600, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1600, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1600, DW_AT_decl_line(0x15e) .dwattr $C$DW$1600, DW_AT_decl_column(0x19) $C$DW$1601 .dwtag DW_TAG_member .dwattr $C$DW$1601, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$1601, DW_AT_name("timeStarted") .dwattr $C$DW$1601, DW_AT_TI_symbol_name("timeStarted") .dwattr $C$DW$1601, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0] .dwattr $C$DW$1601, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1601, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1601, DW_AT_decl_line(0x15f) .dwattr $C$DW$1601, DW_AT_decl_column(0x19) $C$DW$1602 .dwtag DW_TAG_member .dwattr $C$DW$1602, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1602, DW_AT_name("timeDuration") .dwattr $C$DW$1602, DW_AT_TI_symbol_name("timeDuration") .dwattr $C$DW$1602, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$1602, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1602, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1602, DW_AT_decl_line(0x160) .dwattr $C$DW$1602, DW_AT_decl_column(0x19) $C$DW$1603 .dwtag DW_TAG_member .dwattr $C$DW$1603, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1603, DW_AT_name("timeProcessed") .dwattr $C$DW$1603, DW_AT_TI_symbol_name("timeProcessed") .dwattr $C$DW$1603, DW_AT_data_member_location[DW_OP_plus_uconst 0xac] .dwattr $C$DW$1603, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1603, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1603, DW_AT_decl_line(0x161) .dwattr $C$DW$1603, DW_AT_decl_column(0x19) $C$DW$1604 .dwtag DW_TAG_member .dwattr $C$DW$1604, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1604, DW_AT_name("inputSeqId") .dwattr $C$DW$1604, DW_AT_TI_symbol_name("inputSeqId") .dwattr $C$DW$1604, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0] .dwattr $C$DW$1604, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1604, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1604, DW_AT_decl_line(0x162) .dwattr $C$DW$1604, DW_AT_decl_column(0x19) $C$DW$1605 .dwtag DW_TAG_member .dwattr $C$DW$1605, DW_AT_type(*$C$DW$T$510) .dwattr $C$DW$1605, DW_AT_name("spDataType") .dwattr $C$DW$1605, DW_AT_TI_symbol_name("spDataType") .dwattr $C$DW$1605, DW_AT_data_member_location[DW_OP_plus_uconst 0xb4] .dwattr $C$DW$1605, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1605, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1605, DW_AT_decl_line(0x163) .dwattr $C$DW$1605, DW_AT_decl_column(0x19) $C$DW$1606 .dwtag DW_TAG_member .dwattr $C$DW$1606, DW_AT_type(*$C$DW$T$512) .dwattr $C$DW$1606, DW_AT_name("entryStatus") .dwattr $C$DW$1606, DW_AT_TI_symbol_name("entryStatus") .dwattr $C$DW$1606, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8] .dwattr $C$DW$1606, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1606, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1606, DW_AT_decl_line(0x164) .dwattr $C$DW$1606, DW_AT_decl_column(0x19) $C$DW$1607 .dwtag DW_TAG_member .dwattr $C$DW$1607, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$1607, DW_AT_name("updateParam") .dwattr $C$DW$1607, DW_AT_TI_symbol_name("updateParam") .dwattr $C$DW$1607, DW_AT_data_member_location[DW_OP_plus_uconst 0xbc] .dwattr $C$DW$1607, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1607, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1607, DW_AT_decl_line(0x165) .dwattr $C$DW$1607, DW_AT_decl_column(0x19) $C$DW$73 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$73, DW_AT_declaration .dwattr $C$DW$73, DW_AT_TI_symbol_name("_ZN16McMgr_CmdEntriesaSERKS_") .dwattr $C$DW$73, DW_AT_type(*$C$DW$T$513) .dwattr $C$DW$73, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1608 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1608, DW_AT_type(*$C$DW$T$515) .dwendtag $C$DW$73 .dwendtag $C$DW$T$517 .dwattr $C$DW$T$517, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$517, DW_AT_decl_line(0x14e) .dwattr $C$DW$T$517, DW_AT_decl_column(0x01) $C$DW$T$514 .dwtag DW_TAG_const_type .dwattr $C$DW$T$514, DW_AT_type(*$C$DW$T$517) $C$DW$T$515 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$515, DW_AT_type(*$C$DW$T$514) .dwattr $C$DW$T$515, DW_AT_address_class(0x20) $C$DW$T$1924 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdEntries") .dwattr $C$DW$T$1924, DW_AT_type(*$C$DW$T$517) .dwattr $C$DW$T$1924, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1924, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1924, DW_AT_decl_line(0x167) .dwattr $C$DW$T$1924, DW_AT_decl_column(0x03) $C$DW$T$513 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$513, DW_AT_type(*$C$DW$T$517) .dwattr $C$DW$T$513, DW_AT_address_class(0x20) $C$DW$T$516 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$516, DW_AT_type(*$C$DW$T$513) .dwattr $C$DW$T$516, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1609 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1609, DW_AT_type(*$C$DW$T$515) .dwendtag $C$DW$T$516 $C$DW$T$527 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$527, DW_AT_name("McMgr_CmdProperties") .dwattr $C$DW$T$527, DW_AT_byte_size(0x4c) $C$DW$1610 .dwtag DW_TAG_member .dwattr $C$DW$1610, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1610, DW_AT_name("coreCompatible") .dwattr $C$DW$1610, DW_AT_TI_symbol_name("coreCompatible") .dwattr $C$DW$1610, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1610, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1610, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1610, DW_AT_decl_line(0x16b) .dwattr $C$DW$1610, DW_AT_decl_column(0x19) $C$DW$1611 .dwtag DW_TAG_member .dwattr $C$DW$1611, DW_AT_type(*$C$DW$T$518) .dwattr $C$DW$1611, DW_AT_name("inputCmd") .dwattr $C$DW$1611, DW_AT_TI_symbol_name("inputCmd") .dwattr $C$DW$1611, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1611, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1611, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1611, DW_AT_decl_line(0x16c) .dwattr $C$DW$1611, DW_AT_decl_column(0x19) $C$DW$1612 .dwtag DW_TAG_member .dwattr $C$DW$1612, DW_AT_type(*$C$DW$T$518) .dwattr $C$DW$1612, DW_AT_name("outputCmd") .dwattr $C$DW$1612, DW_AT_TI_symbol_name("outputCmd") .dwattr $C$DW$1612, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1612, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1612, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1612, DW_AT_decl_line(0x16d) .dwattr $C$DW$1612, DW_AT_decl_column(0x19) $C$DW$1613 .dwtag DW_TAG_member .dwattr $C$DW$1613, DW_AT_type(*$C$DW$T$519) .dwattr $C$DW$1613, DW_AT_name("triggerCmdAccumulatedCntQ15") .dwattr $C$DW$1613, DW_AT_TI_symbol_name("triggerCmdAccumulatedCntQ15") .dwattr $C$DW$1613, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1613, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1613, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1613, DW_AT_decl_line(0x16e) .dwattr $C$DW$1613, DW_AT_decl_column(0x19) $C$DW$1614 .dwtag DW_TAG_member .dwattr $C$DW$1614, DW_AT_type(*$C$DW$T$520) .dwattr $C$DW$1614, DW_AT_name("triggerCmdIncrCntQ15") .dwattr $C$DW$1614, DW_AT_TI_symbol_name("triggerCmdIncrCntQ15") .dwattr $C$DW$1614, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c] .dwattr $C$DW$1614, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1614, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1614, DW_AT_decl_line(0x16f) .dwattr $C$DW$1614, DW_AT_decl_column(0x19) $C$DW$1615 .dwtag DW_TAG_member .dwattr $C$DW$1615, DW_AT_type(*$C$DW$T$520) .dwattr $C$DW$1615, DW_AT_name("triggerCmdMaxCntQ15") .dwattr $C$DW$1615, DW_AT_TI_symbol_name("triggerCmdMaxCntQ15") .dwattr $C$DW$1615, DW_AT_data_member_location[DW_OP_plus_uconst 0x24] .dwattr $C$DW$1615, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1615, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1615, DW_AT_decl_line(0x170) .dwattr $C$DW$1615, DW_AT_decl_column(0x19) $C$DW$1616 .dwtag DW_TAG_member .dwattr $C$DW$1616, DW_AT_type(*$C$DW$T$522) .dwattr $C$DW$1616, DW_AT_name("inCBuf") .dwattr $C$DW$1616, DW_AT_TI_symbol_name("inCBuf") .dwattr $C$DW$1616, DW_AT_data_member_location[DW_OP_plus_uconst 0x2c] .dwattr $C$DW$1616, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1616, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1616, DW_AT_decl_line(0x172) .dwattr $C$DW$1616, DW_AT_decl_column(0x19) $C$DW$1617 .dwtag DW_TAG_member .dwattr $C$DW$1617, DW_AT_type(*$C$DW$T$522) .dwattr $C$DW$1617, DW_AT_name("outCBuf") .dwattr $C$DW$1617, DW_AT_TI_symbol_name("outCBuf") .dwattr $C$DW$1617, DW_AT_data_member_location[DW_OP_plus_uconst 0x34] .dwattr $C$DW$1617, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1617, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1617, DW_AT_decl_line(0x173) .dwattr $C$DW$1617, DW_AT_decl_column(0x19) $C$DW$1618 .dwtag DW_TAG_member .dwattr $C$DW$1618, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1618, DW_AT_name("numInCmd") .dwattr $C$DW$1618, DW_AT_TI_symbol_name("numInCmd") .dwattr $C$DW$1618, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c] .dwattr $C$DW$1618, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1618, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1618, DW_AT_decl_line(0x175) .dwattr $C$DW$1618, DW_AT_decl_column(0x13) $C$DW$1619 .dwtag DW_TAG_member .dwattr $C$DW$1619, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1619, DW_AT_name("numOutCmd") .dwattr $C$DW$1619, DW_AT_TI_symbol_name("numOutCmd") .dwattr $C$DW$1619, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$1619, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1619, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1619, DW_AT_decl_line(0x176) .dwattr $C$DW$1619, DW_AT_decl_column(0x13) $C$DW$1620 .dwtag DW_TAG_member .dwattr $C$DW$1620, DW_AT_type(*$C$DW$T$521) .dwattr $C$DW$1620, DW_AT_name("inCBufAtStop") .dwattr $C$DW$1620, DW_AT_TI_symbol_name("inCBufAtStop") .dwattr $C$DW$1620, DW_AT_data_member_location[DW_OP_plus_uconst 0x44] .dwattr $C$DW$1620, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1620, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1620, DW_AT_decl_line(0x178) .dwattr $C$DW$1620, DW_AT_decl_column(0x1a) $C$DW$1621 .dwtag DW_TAG_member .dwattr $C$DW$1621, DW_AT_type(*$C$DW$T$521) .dwattr $C$DW$1621, DW_AT_name("outCBufAtStop") .dwattr $C$DW$1621, DW_AT_TI_symbol_name("outCBufAtStop") .dwattr $C$DW$1621, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$1621, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1621, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1621, DW_AT_decl_line(0x179) .dwattr $C$DW$1621, DW_AT_decl_column(0x1a) $C$DW$74 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$74, DW_AT_declaration .dwattr $C$DW$74, DW_AT_TI_symbol_name("_ZN19McMgr_CmdPropertiesaSERKS_") .dwattr $C$DW$74, DW_AT_type(*$C$DW$T$523) .dwattr $C$DW$74, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1622 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1622, DW_AT_type(*$C$DW$T$525) .dwendtag $C$DW$74 .dwendtag $C$DW$T$527 .dwattr $C$DW$T$527, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$527, DW_AT_decl_line(0x16a) .dwattr $C$DW$T$527, DW_AT_decl_column(0x01) $C$DW$T$524 .dwtag DW_TAG_const_type .dwattr $C$DW$T$524, DW_AT_type(*$C$DW$T$527) $C$DW$T$525 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$525, DW_AT_type(*$C$DW$T$524) .dwattr $C$DW$T$525, DW_AT_address_class(0x20) $C$DW$T$1925 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdProperties") .dwattr $C$DW$T$1925, DW_AT_type(*$C$DW$T$527) .dwattr $C$DW$T$1925, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1925, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1925, DW_AT_decl_line(0x17a) .dwattr $C$DW$T$1925, DW_AT_decl_column(0x02) $C$DW$T$523 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$523, DW_AT_type(*$C$DW$T$527) .dwattr $C$DW$T$523, DW_AT_address_class(0x20) $C$DW$T$526 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$526, DW_AT_type(*$C$DW$T$523) .dwattr $C$DW$T$526, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1623 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1623, DW_AT_type(*$C$DW$T$525) .dwendtag $C$DW$T$526 $C$DW$T$532 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$532, DW_AT_name("McMgr_CmdSetup") .dwattr $C$DW$T$532, DW_AT_byte_size(0x20) $C$DW$1624 .dwtag DW_TAG_member .dwattr $C$DW$1624, DW_AT_type(*$C$DW$T$454) .dwattr $C$DW$1624, DW_AT_name("command") .dwattr $C$DW$1624, DW_AT_TI_symbol_name("command") .dwattr $C$DW$1624, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1624, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1624, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1624, DW_AT_decl_line(0x17f) .dwattr $C$DW$1624, DW_AT_decl_column(0x19) $C$DW$1625 .dwtag DW_TAG_member .dwattr $C$DW$1625, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1625, DW_AT_name("numInCmd") .dwattr $C$DW$1625, DW_AT_TI_symbol_name("numInCmd") .dwattr $C$DW$1625, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1625, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1625, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1625, DW_AT_decl_line(0x182) .dwattr $C$DW$1625, DW_AT_decl_column(0x0c) $C$DW$1626 .dwtag DW_TAG_member .dwattr $C$DW$1626, DW_AT_type(*$C$DW$T$520) .dwattr $C$DW$1626, DW_AT_name("inDataPacketSze") .dwattr $C$DW$1626, DW_AT_TI_symbol_name("inDataPacketSze") .dwattr $C$DW$1626, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1626, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1626, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1626, DW_AT_decl_line(0x185) .dwattr $C$DW$1626, DW_AT_decl_column(0x0e) $C$DW$1627 .dwtag DW_TAG_member .dwattr $C$DW$1627, DW_AT_type(*$C$DW$T$520) .dwattr $C$DW$1627, DW_AT_name("numInDataPacket") .dwattr $C$DW$1627, DW_AT_TI_symbol_name("numInDataPacket") .dwattr $C$DW$1627, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1627, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1627, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1627, DW_AT_decl_line(0x186) .dwattr $C$DW$1627, DW_AT_decl_column(0x0e) $C$DW$1628 .dwtag DW_TAG_member .dwattr $C$DW$1628, DW_AT_type(*$C$DW$T$518) .dwattr $C$DW$1628, DW_AT_name("inputCmd") .dwattr $C$DW$1628, DW_AT_TI_symbol_name("inputCmd") .dwattr $C$DW$1628, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1628, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1628, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1628, DW_AT_decl_line(0x189) .dwattr $C$DW$1628, DW_AT_decl_column(0x19) $C$DW$75 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$75, DW_AT_declaration .dwattr $C$DW$75, DW_AT_TI_symbol_name("_ZN14McMgr_CmdSetupaSERKS_") .dwattr $C$DW$75, DW_AT_type(*$C$DW$T$528) .dwattr $C$DW$75, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1629 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1629, DW_AT_type(*$C$DW$T$530) .dwendtag $C$DW$75 .dwendtag $C$DW$T$532 .dwattr $C$DW$T$532, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$532, DW_AT_decl_line(0x17e) .dwattr $C$DW$T$532, DW_AT_decl_column(0x01) $C$DW$T$529 .dwtag DW_TAG_const_type .dwattr $C$DW$T$529, DW_AT_type(*$C$DW$T$532) $C$DW$T$530 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$530, DW_AT_type(*$C$DW$T$529) .dwattr $C$DW$T$530, DW_AT_address_class(0x20) $C$DW$T$533 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdSetup") .dwattr $C$DW$T$533, DW_AT_type(*$C$DW$T$532) .dwattr $C$DW$T$533, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$533, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$533, DW_AT_decl_line(0x18a) .dwattr $C$DW$T$533, DW_AT_decl_column(0x02) $C$DW$T$534 .dwtag DW_TAG_array_type .dwattr $C$DW$T$534, DW_AT_type(*$C$DW$T$533) .dwattr $C$DW$T$534, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$534, DW_AT_byte_size(0x200) $C$DW$1630 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1630, DW_AT_upper_bound(0x0f) .dwendtag $C$DW$T$534 $C$DW$T$528 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$528, DW_AT_type(*$C$DW$T$532) .dwattr $C$DW$T$528, DW_AT_address_class(0x20) $C$DW$T$531 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$531, DW_AT_type(*$C$DW$T$528) .dwattr $C$DW$T$531, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1631 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1631, DW_AT_type(*$C$DW$T$530) .dwendtag $C$DW$T$531 $C$DW$T$539 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$539, DW_AT_name("McMgr_CmdSetupTbl") .dwattr $C$DW$T$539, DW_AT_byte_size(0x204) $C$DW$1632 .dwtag DW_TAG_member .dwattr $C$DW$1632, DW_AT_type(*$C$DW$T$534) .dwattr $C$DW$1632, DW_AT_name("cmdProperties") .dwattr $C$DW$1632, DW_AT_TI_symbol_name("cmdProperties") .dwattr $C$DW$1632, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1632, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1632, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1632, DW_AT_decl_line(0x18f) .dwattr $C$DW$1632, DW_AT_decl_column(0x14) $C$DW$1633 .dwtag DW_TAG_member .dwattr $C$DW$1633, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1633, DW_AT_name("numCmd") .dwattr $C$DW$1633, DW_AT_TI_symbol_name("numCmd") .dwattr $C$DW$1633, DW_AT_data_member_location[DW_OP_plus_uconst 0x200] .dwattr $C$DW$1633, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1633, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1633, DW_AT_decl_line(0x190) .dwattr $C$DW$1633, DW_AT_decl_column(0x0c) $C$DW$76 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$76, DW_AT_declaration .dwattr $C$DW$76, DW_AT_TI_symbol_name("_ZN17McMgr_CmdSetupTblaSERKS_") .dwattr $C$DW$76, DW_AT_type(*$C$DW$T$535) .dwattr $C$DW$76, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1634 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1634, DW_AT_type(*$C$DW$T$537) .dwendtag $C$DW$76 .dwendtag $C$DW$T$539 .dwattr $C$DW$T$539, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$539, DW_AT_decl_line(0x18e) .dwattr $C$DW$T$539, DW_AT_decl_column(0x01) $C$DW$T$536 .dwtag DW_TAG_const_type .dwattr $C$DW$T$536, DW_AT_type(*$C$DW$T$539) $C$DW$T$537 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$537, DW_AT_type(*$C$DW$T$536) .dwattr $C$DW$T$537, DW_AT_address_class(0x20) $C$DW$T$1926 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CmdSetupTbl") .dwattr $C$DW$T$1926, DW_AT_type(*$C$DW$T$539) .dwattr $C$DW$T$1926, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1926, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1926, DW_AT_decl_line(0x191) .dwattr $C$DW$T$1926, DW_AT_decl_column(0x03) $C$DW$T$535 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$535, DW_AT_type(*$C$DW$T$539) .dwattr $C$DW$T$535, DW_AT_address_class(0x20) $C$DW$T$538 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$538, DW_AT_type(*$C$DW$T$535) .dwattr $C$DW$T$538, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1635 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1635, DW_AT_type(*$C$DW$T$537) .dwendtag $C$DW$T$538 $C$DW$T$507 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$507, DW_AT_name("McMgr_CoreIdType") .dwattr $C$DW$T$507, DW_AT_byte_size(0x04) $C$DW$1636 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_NONE"), DW_AT_const_value(0x00) .dwattr $C$DW$1636, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1636, DW_AT_decl_line(0x9c) .dwattr $C$DW$1636, DW_AT_decl_column(0x05) $C$DW$1637 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_0"), DW_AT_const_value(0x01) .dwattr $C$DW$1637, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1637, DW_AT_decl_line(0x9d) .dwattr $C$DW$1637, DW_AT_decl_column(0x05) $C$DW$1638 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_1"), DW_AT_const_value(0x02) .dwattr $C$DW$1638, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1638, DW_AT_decl_line(0x9e) .dwattr $C$DW$1638, DW_AT_decl_column(0x05) $C$DW$1639 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_2"), DW_AT_const_value(0x04) .dwattr $C$DW$1639, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1639, DW_AT_decl_line(0x9f) .dwattr $C$DW$1639, DW_AT_decl_column(0x05) $C$DW$1640 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_3"), DW_AT_const_value(0x08) .dwattr $C$DW$1640, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1640, DW_AT_decl_line(0xa0) .dwattr $C$DW$1640, DW_AT_decl_column(0x05) $C$DW$1641 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_4"), DW_AT_const_value(0x10) .dwattr $C$DW$1641, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1641, DW_AT_decl_line(0xa1) .dwattr $C$DW$1641, DW_AT_decl_column(0x05) $C$DW$1642 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_5"), DW_AT_const_value(0x20) .dwattr $C$DW$1642, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1642, DW_AT_decl_line(0xa2) .dwattr $C$DW$1642, DW_AT_decl_column(0x05) $C$DW$1643 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_6"), DW_AT_const_value(0x40) .dwattr $C$DW$1643, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1643, DW_AT_decl_line(0xa3) .dwattr $C$DW$1643, DW_AT_decl_column(0x05) $C$DW$1644 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_7"), DW_AT_const_value(0x80) .dwattr $C$DW$1644, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1644, DW_AT_decl_line(0xa4) .dwattr $C$DW$1644, DW_AT_decl_column(0x05) $C$DW$1645 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_EOL"), DW_AT_const_value(0x81) .dwattr $C$DW$1645, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1645, DW_AT_decl_line(0xa5) .dwattr $C$DW$1645, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$507 .dwattr $C$DW$T$507, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$507, DW_AT_decl_line(0x9b) .dwattr $C$DW$T$507, DW_AT_decl_column(0x01) $C$DW$T$508 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CoreIdType") .dwattr $C$DW$T$508, DW_AT_type(*$C$DW$T$507) .dwattr $C$DW$T$508, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$508, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$508, DW_AT_decl_line(0xa6) .dwattr $C$DW$T$508, DW_AT_decl_column(0x03) $C$DW$T$540 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$540, DW_AT_name("McMgr_CoreState") .dwattr $C$DW$T$540, DW_AT_byte_size(0x04) $C$DW$1646 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_RESET"), DW_AT_const_value(0x00) .dwattr $C$DW$1646, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1646, DW_AT_decl_line(0x114) .dwattr $C$DW$1646, DW_AT_decl_column(0x05) $C$DW$1647 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STARTING"), DW_AT_const_value(0x01) .dwattr $C$DW$1647, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1647, DW_AT_decl_line(0x115) .dwattr $C$DW$1647, DW_AT_decl_column(0x05) $C$DW$1648 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STARTED"), DW_AT_const_value(0x02) .dwattr $C$DW$1648, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1648, DW_AT_decl_line(0x116) .dwattr $C$DW$1648, DW_AT_decl_column(0x05) $C$DW$1649 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_IDLE"), DW_AT_const_value(0x03) .dwattr $C$DW$1649, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1649, DW_AT_decl_line(0x117) .dwattr $C$DW$1649, DW_AT_decl_column(0x05) $C$DW$1650 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_RUN"), DW_AT_const_value(0x04) .dwattr $C$DW$1650, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1650, DW_AT_decl_line(0x118) .dwattr $C$DW$1650, DW_AT_decl_column(0x05) $C$DW$1651 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_PARAM_UPDATING"), DW_AT_const_value(0x05) .dwattr $C$DW$1651, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1651, DW_AT_decl_line(0x11b) .dwattr $C$DW$1651, DW_AT_decl_column(0x05) $C$DW$1652 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STOPPING"), DW_AT_const_value(0x06) .dwattr $C$DW$1652, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1652, DW_AT_decl_line(0x11c) .dwattr $C$DW$1652, DW_AT_decl_column(0x05) $C$DW$1653 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_STOPPED"), DW_AT_const_value(0x07) .dwattr $C$DW$1653, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1653, DW_AT_decl_line(0x11d) .dwattr $C$DW$1653, DW_AT_decl_column(0x05) $C$DW$1654 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_TERMINATED"), DW_AT_const_value(0x08) .dwattr $C$DW$1654, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1654, DW_AT_decl_line(0x11f) .dwattr $C$DW$1654, DW_AT_decl_column(0x05) $C$DW$1655 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_COREID_STATE_EOL"), DW_AT_const_value(0x09) .dwattr $C$DW$1655, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1655, DW_AT_decl_line(0x120) .dwattr $C$DW$1655, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$540 .dwattr $C$DW$T$540, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$540, DW_AT_decl_line(0x113) .dwattr $C$DW$T$540, DW_AT_decl_column(0x01) $C$DW$T$541 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CoreState") .dwattr $C$DW$T$541, DW_AT_type(*$C$DW$T$540) .dwattr $C$DW$T$541, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$541, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$541, DW_AT_decl_line(0x121) .dwattr $C$DW$T$541, DW_AT_decl_column(0x03) $C$DW$T$547 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$547, DW_AT_name("McMgr_CoreStatus") .dwattr $C$DW$T$547, DW_AT_byte_size(0x54) $C$DW$1656 .dwtag DW_TAG_member .dwattr $C$DW$1656, DW_AT_type(*$C$DW$T$541) .dwattr $C$DW$1656, DW_AT_name("state") .dwattr $C$DW$1656, DW_AT_TI_symbol_name("state") .dwattr $C$DW$1656, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1656, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1656, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1656, DW_AT_decl_line(0x13d) .dwattr $C$DW$1656, DW_AT_decl_column(0x19) $C$DW$1657 .dwtag DW_TAG_member .dwattr $C$DW$1657, DW_AT_type(*$C$DW$T$454) .dwattr $C$DW$1657, DW_AT_name("command") .dwattr $C$DW$1657, DW_AT_TI_symbol_name("command") .dwattr $C$DW$1657, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1657, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1657, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1657, DW_AT_decl_line(0x13e) .dwattr $C$DW$1657, DW_AT_decl_column(0x19) $C$DW$1658 .dwtag DW_TAG_member .dwattr $C$DW$1658, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1658, DW_AT_name("entryIdx") .dwattr $C$DW$1658, DW_AT_TI_symbol_name("entryIdx") .dwattr $C$DW$1658, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1658, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1658, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1658, DW_AT_decl_line(0x13f) .dwattr $C$DW$1658, DW_AT_decl_column(0x19) $C$DW$1659 .dwtag DW_TAG_member .dwattr $C$DW$1659, DW_AT_type(*$C$DW$T$542) .dwattr $C$DW$1659, DW_AT_name("cmdCompatible") .dwattr $C$DW$1659, DW_AT_TI_symbol_name("cmdCompatible") .dwattr $C$DW$1659, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1659, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1659, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1659, DW_AT_decl_line(0x140) .dwattr $C$DW$1659, DW_AT_decl_column(0x19) $C$DW$1660 .dwtag DW_TAG_member .dwattr $C$DW$1660, DW_AT_type(*$C$DW$T$542) .dwattr $C$DW$1660, DW_AT_name("cmdInit") .dwattr $C$DW$1660, DW_AT_TI_symbol_name("cmdInit") .dwattr $C$DW$1660, DW_AT_data_member_location[DW_OP_plus_uconst 0x24] .dwattr $C$DW$1660, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1660, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1660, DW_AT_decl_line(0x141) .dwattr $C$DW$1660, DW_AT_decl_column(0x19) $C$DW$1661 .dwtag DW_TAG_member .dwattr $C$DW$1661, DW_AT_type(*$C$DW$T$542) .dwattr $C$DW$1661, DW_AT_name("paramUpdated") .dwattr $C$DW$1661, DW_AT_TI_symbol_name("paramUpdated") .dwattr $C$DW$1661, DW_AT_data_member_location[DW_OP_plus_uconst 0x3c] .dwattr $C$DW$1661, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1661, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1661, DW_AT_decl_line(0x142) .dwattr $C$DW$1661, DW_AT_decl_column(0x19) $C$DW$77 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$77, DW_AT_declaration .dwattr $C$DW$77, DW_AT_TI_symbol_name("_ZN16McMgr_CoreStatusaSERKS_") .dwattr $C$DW$77, DW_AT_type(*$C$DW$T$543) .dwattr $C$DW$77, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1662 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1662, DW_AT_type(*$C$DW$T$545) .dwendtag $C$DW$77 .dwendtag $C$DW$T$547 .dwattr $C$DW$T$547, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$547, DW_AT_decl_line(0x13c) .dwattr $C$DW$T$547, DW_AT_decl_column(0x01) $C$DW$T$544 .dwtag DW_TAG_const_type .dwattr $C$DW$T$544, DW_AT_type(*$C$DW$T$547) $C$DW$T$545 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$545, DW_AT_type(*$C$DW$T$544) .dwattr $C$DW$T$545, DW_AT_address_class(0x20) $C$DW$T$1927 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_CoreStatus") .dwattr $C$DW$T$1927, DW_AT_type(*$C$DW$T$547) .dwattr $C$DW$T$1927, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1927, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1927, DW_AT_decl_line(0x143) .dwattr $C$DW$T$1927, DW_AT_decl_column(0x03) $C$DW$T$543 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$543, DW_AT_type(*$C$DW$T$547) .dwattr $C$DW$T$543, DW_AT_address_class(0x20) $C$DW$T$546 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$546, DW_AT_type(*$C$DW$T$543) .dwattr $C$DW$T$546, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1663 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1663, DW_AT_type(*$C$DW$T$545) .dwendtag $C$DW$T$546 $C$DW$T$511 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$511, DW_AT_name("McMgr_EntryStatus") .dwattr $C$DW$T$511, DW_AT_byte_size(0x04) $C$DW$1664 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_NONE"), DW_AT_const_value(0x00) .dwattr $C$DW$1664, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1664, DW_AT_decl_line(0x10a) .dwattr $C$DW$1664, DW_AT_decl_column(0x05) $C$DW$1665 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_UNSERVICED"), DW_AT_const_value(0x01) .dwattr $C$DW$1665, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1665, DW_AT_decl_line(0x10b) .dwattr $C$DW$1665, DW_AT_decl_column(0x05) $C$DW$1666 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_INPROGRESS"), DW_AT_const_value(0x02) .dwattr $C$DW$1666, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1666, DW_AT_decl_line(0x10c) .dwattr $C$DW$1666, DW_AT_decl_column(0x05) $C$DW$1667 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_SERVICED"), DW_AT_const_value(0x03) .dwattr $C$DW$1667, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1667, DW_AT_decl_line(0x10d) .dwattr $C$DW$1667, DW_AT_decl_column(0x05) $C$DW$1668 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_ENTRY_EOL"), DW_AT_const_value(0x04) .dwattr $C$DW$1668, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1668, DW_AT_decl_line(0x10e) .dwattr $C$DW$1668, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$511 .dwattr $C$DW$T$511, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$511, DW_AT_decl_line(0x109) .dwattr $C$DW$T$511, DW_AT_decl_column(0x01) $C$DW$T$512 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_EntryStatus") .dwattr $C$DW$T$512, DW_AT_type(*$C$DW$T$511) .dwattr $C$DW$T$512, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$512, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$512, DW_AT_decl_line(0x10f) .dwattr $C$DW$T$512, DW_AT_decl_column(0x03) $C$DW$T$1530 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1530, DW_AT_name("McMgr_IpcMsg") .dwattr $C$DW$T$1530, DW_AT_byte_size(0x04) $C$DW$1669 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_NONE"), DW_AT_const_value(0x00) .dwattr $C$DW$1669, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1669, DW_AT_decl_line(0xdc) .dwattr $C$DW$1669, DW_AT_decl_column(0x05) $C$DW$1670 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_ERROR_CMD"), DW_AT_const_value(0x01) .dwattr $C$DW$1670, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1670, DW_AT_decl_line(0xdf) .dwattr $C$DW$1670, DW_AT_decl_column(0x05) $C$DW$1671 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_ADD_CMD"), DW_AT_const_value(0x02) .dwattr $C$DW$1671, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1671, DW_AT_decl_line(0xe0) .dwattr $C$DW$1671, DW_AT_decl_column(0x05) $C$DW$1672 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_INIT_CMD"), DW_AT_const_value(0x03) .dwattr $C$DW$1672, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1672, DW_AT_decl_line(0xe1) .dwattr $C$DW$1672, DW_AT_decl_column(0x05) $C$DW$1673 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_INIT_RSP"), DW_AT_const_value(0x04) .dwattr $C$DW$1673, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1673, DW_AT_decl_line(0xe2) .dwattr $C$DW$1673, DW_AT_decl_column(0x05) $C$DW$1674 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_START_CMD"), DW_AT_const_value(0x05) .dwattr $C$DW$1674, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1674, DW_AT_decl_line(0xe3) .dwattr $C$DW$1674, DW_AT_decl_column(0x05) $C$DW$1675 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_START_RSP"), DW_AT_const_value(0x06) .dwattr $C$DW$1675, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1675, DW_AT_decl_line(0xe4) .dwattr $C$DW$1675, DW_AT_decl_column(0x05) $C$DW$1676 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_STOP_CMD"), DW_AT_const_value(0x07) .dwattr $C$DW$1676, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1676, DW_AT_decl_line(0xe5) .dwattr $C$DW$1676, DW_AT_decl_column(0x05) $C$DW$1677 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_STOP_RSP"), DW_AT_const_value(0x08) .dwattr $C$DW$1677, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1677, DW_AT_decl_line(0xe6) .dwattr $C$DW$1677, DW_AT_decl_column(0x05) $C$DW$1678 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_RT_PARAM_UPDATE_RSP"), DW_AT_const_value(0x09) .dwattr $C$DW$1678, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1678, DW_AT_decl_line(0xe7) .dwattr $C$DW$1678, DW_AT_decl_column(0x05) $C$DW$1679 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_VSYNC_DISABLED"), DW_AT_const_value(0x0a) .dwattr $C$DW$1679, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1679, DW_AT_decl_line(0xea) .dwattr $C$DW$1679, DW_AT_decl_column(0x05) $C$DW$1680 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_FOV_UPDATE_CMD"), DW_AT_const_value(0x0b) .dwattr $C$DW$1680, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1680, DW_AT_decl_line(0xeb) .dwattr $C$DW$1680, DW_AT_decl_column(0x05) $C$DW$1681 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_FOV_UPDATE_RSP"), DW_AT_const_value(0x0c) .dwattr $C$DW$1681, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1681, DW_AT_decl_line(0xec) .dwattr $C$DW$1681, DW_AT_decl_column(0x05) $C$DW$1682 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_NRT_PARAM_UPDATE_CMD"), DW_AT_const_value(0x0d) .dwattr $C$DW$1682, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1682, DW_AT_decl_line(0xed) .dwattr $C$DW$1682, DW_AT_decl_column(0x05) $C$DW$1683 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_RT_PARAM_UPDATE_CMD"), DW_AT_const_value(0x0e) .dwattr $C$DW$1683, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1683, DW_AT_decl_line(0xee) .dwattr $C$DW$1683, DW_AT_decl_column(0x05) $C$DW$1684 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PLAYLIST_UPDATE_CMD"), DW_AT_const_value(0x0f) .dwattr $C$DW$1684, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1684, DW_AT_decl_line(0xef) .dwattr $C$DW$1684, DW_AT_decl_column(0x05) $C$DW$1685 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PLAYLIST_UPDATE_RT_RSP"), DW_AT_const_value(0x10) .dwattr $C$DW$1685, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1685, DW_AT_decl_line(0xf0) .dwattr $C$DW$1685, DW_AT_decl_column(0x05) $C$DW$1686 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PLAYLIST_UPDATE_NRT_RSP"), DW_AT_const_value(0x11) .dwattr $C$DW$1686, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1686, DW_AT_decl_line(0xf1) .dwattr $C$DW$1686, DW_AT_decl_column(0x05) $C$DW$1687 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PROCESS_CMD"), DW_AT_const_value(0x12) .dwattr $C$DW$1687, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1687, DW_AT_decl_line(0xf4) .dwattr $C$DW$1687, DW_AT_decl_column(0x05) $C$DW$1688 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PROCESS_RSP"), DW_AT_const_value(0x13) .dwattr $C$DW$1688, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1688, DW_AT_decl_line(0xf5) .dwattr $C$DW$1688, DW_AT_decl_column(0x05) $C$DW$1689 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PARAM_UPDATE_CMD"), DW_AT_const_value(0x14) .dwattr $C$DW$1689, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1689, DW_AT_decl_line(0xf6) .dwattr $C$DW$1689, DW_AT_decl_column(0x05) $C$DW$1690 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_PARAM_UPDATE_RSP"), DW_AT_const_value(0x15) .dwattr $C$DW$1690, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1690, DW_AT_decl_line(0xf7) .dwattr $C$DW$1690, DW_AT_decl_column(0x05) $C$DW$1691 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_CINE_PROCESS_DONE"), DW_AT_const_value(0x16) .dwattr $C$DW$1691, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1691, DW_AT_decl_line(0xf8) .dwattr $C$DW$1691, DW_AT_decl_column(0x05) $C$DW$1692 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_SRIO_DBELL"), DW_AT_const_value(0x17) .dwattr $C$DW$1692, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1692, DW_AT_decl_line(0xfc) .dwattr $C$DW$1692, DW_AT_decl_column(0x05) $C$DW$1693 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_VSYNC"), DW_AT_const_value(0x18) .dwattr $C$DW$1693, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1693, DW_AT_decl_line(0xff) .dwattr $C$DW$1693, DW_AT_decl_column(0x05) $C$DW$1694 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_POST_TO_UTI"), DW_AT_const_value(0x19) .dwattr $C$DW$1694, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1694, DW_AT_decl_line(0x102) .dwattr $C$DW$1694, DW_AT_decl_column(0x05) $C$DW$1695 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_IPC_MSG_EOL"), DW_AT_const_value(0x1a) .dwattr $C$DW$1695, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1695, DW_AT_decl_line(0x105) .dwattr $C$DW$1695, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1530 .dwattr $C$DW$T$1530, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1530, DW_AT_decl_line(0xdb) .dwattr $C$DW$T$1530, DW_AT_decl_column(0x01) $C$DW$T$1531 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_IpcMsg") .dwattr $C$DW$T$1531, DW_AT_type(*$C$DW$T$1530) .dwattr $C$DW$T$1531, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1531, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1531, DW_AT_decl_line(0x106) .dwattr $C$DW$T$1531, DW_AT_decl_column(0x03) $C$DW$T$553 .dwtag DW_TAG_union_type .dwattr $C$DW$T$553, DW_AT_name("McMgr_ModuleImagingState") .dwattr $C$DW$T$553, DW_AT_byte_size(0x0c) $C$DW$1696 .dwtag DW_TAG_member .dwattr $C$DW$1696, DW_AT_type(*$C$DW$T$548) .dwattr $C$DW$1696, DW_AT_name("doppler") .dwattr $C$DW$1696, DW_AT_TI_symbol_name("doppler") .dwattr $C$DW$1696, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1696, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1696, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1696, DW_AT_decl_line(0x199) .dwattr $C$DW$1696, DW_AT_decl_column(0x1a) $C$DW$78 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$78, DW_AT_declaration .dwattr $C$DW$78, DW_AT_TI_symbol_name("_ZN24McMgr_ModuleImagingStateaSERKS_") .dwattr $C$DW$78, DW_AT_type(*$C$DW$T$549) .dwattr $C$DW$78, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1697 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1697, DW_AT_type(*$C$DW$T$551) .dwendtag $C$DW$78 .dwendtag $C$DW$T$553 .dwattr $C$DW$T$553, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$553, DW_AT_decl_line(0x195) .dwattr $C$DW$T$553, DW_AT_decl_column(0x01) $C$DW$T$550 .dwtag DW_TAG_const_type .dwattr $C$DW$T$550, DW_AT_type(*$C$DW$T$553) $C$DW$T$551 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$551, DW_AT_type(*$C$DW$T$550) .dwattr $C$DW$T$551, DW_AT_address_class(0x20) $C$DW$T$567 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ModuleImagingState") .dwattr $C$DW$T$567, DW_AT_type(*$C$DW$T$553) .dwattr $C$DW$T$567, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$567, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$567, DW_AT_decl_line(0x19c) .dwattr $C$DW$T$567, DW_AT_decl_column(0x03) $C$DW$T$549 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$549, DW_AT_type(*$C$DW$T$553) .dwattr $C$DW$T$549, DW_AT_address_class(0x20) $C$DW$T$552 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$552, DW_AT_type(*$C$DW$T$549) .dwattr $C$DW$T$552, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1698 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1698, DW_AT_type(*$C$DW$T$551) .dwendtag $C$DW$T$552 $C$DW$T$452 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$452, DW_AT_name("McMgr_ParamUpdateCmd") .dwattr $C$DW$T$452, DW_AT_byte_size(0x04) $C$DW$1699 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_NONE"), DW_AT_const_value(0x00) .dwattr $C$DW$1699, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1699, DW_AT_decl_line(0xd3) .dwattr $C$DW$1699, DW_AT_decl_column(0x05) $C$DW$1700 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_DYN_RANGE_CHG_INIT"), DW_AT_const_value(0x01) .dwattr $C$DW$1700, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1700, DW_AT_decl_line(0xd4) .dwattr $C$DW$1700, DW_AT_decl_column(0x05) $C$DW$1701 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_AMMLINE"), DW_AT_const_value(0x02) .dwattr $C$DW$1701, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1701, DW_AT_decl_line(0xd5) .dwattr $C$DW$1701, DW_AT_decl_column(0x05) $C$DW$1702 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_UPDATE_COMMAND_EOL"), DW_AT_const_value(0x03) .dwattr $C$DW$1702, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1702, DW_AT_decl_line(0xd6) .dwattr $C$DW$1702, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$452 .dwattr $C$DW$T$452, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$452, DW_AT_decl_line(0xd2) .dwattr $C$DW$T$452, DW_AT_decl_column(0x01) $C$DW$T$453 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ParamUpdateCmd") .dwattr $C$DW$T$453, DW_AT_type(*$C$DW$T$452) .dwattr $C$DW$T$453, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$453, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$453, DW_AT_decl_line(0xd7) .dwattr $C$DW$T$453, DW_AT_decl_column(0x03) $C$DW$T$561 .dwtag DW_TAG_union_type .dwattr $C$DW$T$561, DW_AT_name("McMgr_ProcessCmd") .dwattr $C$DW$T$561, DW_AT_byte_size(0x04) $C$DW$1703 .dwtag DW_TAG_member .dwattr $C$DW$1703, DW_AT_type(*$C$DW$T$555) .dwattr $C$DW$1703, DW_AT_name("cmndEnum") .dwattr $C$DW$1703, DW_AT_TI_symbol_name("cmndEnum") .dwattr $C$DW$1703, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1703, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1703, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1703, DW_AT_decl_line(0xcb) .dwattr $C$DW$1703, DW_AT_decl_column(0x1a) $C$DW$1704 .dwtag DW_TAG_member .dwattr $C$DW$1704, DW_AT_type(*$C$DW$T$556) .dwattr $C$DW$1704, DW_AT_name("bits") .dwattr $C$DW$1704, DW_AT_TI_symbol_name("bits") .dwattr $C$DW$1704, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1704, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1704, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1704, DW_AT_decl_line(0xcc) .dwattr $C$DW$1704, DW_AT_decl_column(0x1a) $C$DW$79 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$79, DW_AT_declaration .dwattr $C$DW$79, DW_AT_TI_symbol_name("_ZN16McMgr_ProcessCmdaSERKS_") .dwattr $C$DW$79, DW_AT_type(*$C$DW$T$557) .dwattr $C$DW$79, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1705 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1705, DW_AT_type(*$C$DW$T$559) .dwendtag $C$DW$79 .dwendtag $C$DW$T$561 .dwattr $C$DW$T$561, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$561, DW_AT_decl_line(0xca) .dwattr $C$DW$T$561, DW_AT_decl_column(0x0f) $C$DW$T$454 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessCmd") .dwattr $C$DW$T$454, DW_AT_type(*$C$DW$T$561) .dwattr $C$DW$T$454, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$454, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$454, DW_AT_decl_line(0xcd) .dwattr $C$DW$T$454, DW_AT_decl_column(0x03) $C$DW$T$518 .dwtag DW_TAG_array_type .dwattr $C$DW$T$518, DW_AT_type(*$C$DW$T$454) .dwattr $C$DW$T$518, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$518, DW_AT_byte_size(0x08) $C$DW$1706 .dwtag DW_TAG_subrange_type .dwattr $C$DW$1706, DW_AT_upper_bound(0x01) .dwendtag $C$DW$T$518 $C$DW$T$558 .dwtag DW_TAG_const_type .dwattr $C$DW$T$558, DW_AT_type(*$C$DW$T$561) $C$DW$T$559 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$559, DW_AT_type(*$C$DW$T$558) .dwattr $C$DW$T$559, DW_AT_address_class(0x20) $C$DW$T$557 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$557, DW_AT_type(*$C$DW$T$561) .dwattr $C$DW$T$557, DW_AT_address_class(0x20) $C$DW$T$560 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$560, DW_AT_type(*$C$DW$T$557) .dwattr $C$DW$T$560, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1707 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1707, DW_AT_type(*$C$DW$T$559) .dwendtag $C$DW$T$560 $C$DW$T$566 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$566, DW_AT_name("McMgr_ProcessCmdBits") .dwattr $C$DW$T$566, DW_AT_byte_size(0x04) $C$DW$1708 .dwtag DW_TAG_member .dwattr $C$DW$1708, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1708, DW_AT_name("modeCmdEnum") .dwattr $C$DW$1708, DW_AT_TI_symbol_name("modeCmdEnum") .dwattr $C$DW$1708, DW_AT_bit_offset(0x08), DW_AT_bit_size(0x18) .dwattr $C$DW$1708, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1708, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1708, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1708, DW_AT_decl_line(0xc6) .dwattr $C$DW$1708, DW_AT_decl_column(0x0c) $C$DW$1709 .dwtag DW_TAG_member .dwattr $C$DW$1709, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1709, DW_AT_name("mode") .dwattr $C$DW$1709, DW_AT_TI_symbol_name("mode") .dwattr $C$DW$1709, DW_AT_bit_offset(0x00), DW_AT_bit_size(0x08) .dwattr $C$DW$1709, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1709, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1709, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1709, DW_AT_decl_line(0xc7) .dwattr $C$DW$1709, DW_AT_decl_column(0x0c) $C$DW$80 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$80, DW_AT_declaration .dwattr $C$DW$80, DW_AT_TI_symbol_name("_ZN20McMgr_ProcessCmdBitsaSERKS_") .dwattr $C$DW$80, DW_AT_type(*$C$DW$T$562) .dwattr $C$DW$80, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1710 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1710, DW_AT_type(*$C$DW$T$564) .dwendtag $C$DW$80 .dwendtag $C$DW$T$566 .dwattr $C$DW$T$566, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$566, DW_AT_decl_line(0xc5) .dwattr $C$DW$T$566, DW_AT_decl_column(0x01) $C$DW$T$556 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessCmdBits") .dwattr $C$DW$T$556, DW_AT_type(*$C$DW$T$566) .dwattr $C$DW$T$556, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$556, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$556, DW_AT_decl_line(0xc8) .dwattr $C$DW$T$556, DW_AT_decl_column(0x03) $C$DW$T$563 .dwtag DW_TAG_const_type .dwattr $C$DW$T$563, DW_AT_type(*$C$DW$T$566) $C$DW$T$564 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$564, DW_AT_type(*$C$DW$T$563) .dwattr $C$DW$T$564, DW_AT_address_class(0x20) $C$DW$T$562 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$562, DW_AT_type(*$C$DW$T$566) .dwattr $C$DW$T$562, DW_AT_address_class(0x20) $C$DW$T$565 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$565, DW_AT_type(*$C$DW$T$562) .dwattr $C$DW$T$565, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1711 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1711, DW_AT_type(*$C$DW$T$564) .dwendtag $C$DW$T$565 $C$DW$T$554 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$554, DW_AT_name("McMgr_ProcessCmdEnum") .dwattr $C$DW$T$554, DW_AT_byte_size(0x04) $C$DW$1712 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_NONE"), DW_AT_const_value(0x00) .dwattr $C$DW$1712, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1712, DW_AT_decl_line(0xbc) .dwattr $C$DW$1712, DW_AT_decl_column(0x05) $C$DW$1713 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_EOL"), DW_AT_const_value(0x20) .dwattr $C$DW$1713, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1713, DW_AT_decl_line(0xbd) .dwattr $C$DW$1713, DW_AT_decl_column(0x05) $C$DW$1714 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_START"), DW_AT_const_value(0x01) .dwattr $C$DW$1714, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1714, DW_AT_decl_line(0xbe) .dwattr $C$DW$1714, DW_AT_decl_column(0x05) $C$DW$1715 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_END"), DW_AT_const_value(0x1f) .dwattr $C$DW$1715, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1715, DW_AT_decl_line(0xbf) .dwattr $C$DW$1715, DW_AT_decl_column(0x05) $C$DW$1716 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_START"), DW_AT_const_value(0x01) .dwattr $C$DW$1716, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1716, DW_AT_decl_line(0xc0) .dwattr $C$DW$1716, DW_AT_decl_column(0x05) $C$DW$1717 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_NON_MB_INP_SHIFT"), DW_AT_const_value(0x02) .dwattr $C$DW$1717, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1717, DW_AT_decl_line(0xc0) .dwattr $C$DW$1717, DW_AT_decl_column(0x05) $C$DW$1718 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_NON_MB_PERST_CMPR"), DW_AT_const_value(0x03) .dwattr $C$DW$1718, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1718, DW_AT_decl_line(0xc0) .dwattr $C$DW$1718, DW_AT_decl_column(0x05) $C$DW$1719 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_MB_REG"), DW_AT_const_value(0x04) .dwattr $C$DW$1719, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1719, DW_AT_decl_line(0xc0) .dwattr $C$DW$1719, DW_AT_decl_column(0x05) $C$DW$1720 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_MB_CMPD"), DW_AT_const_value(0x05) .dwattr $C$DW$1720, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1720, DW_AT_decl_line(0xc0) .dwattr $C$DW$1720, DW_AT_decl_column(0x05) $C$DW$1721 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_POST_PROCESS"), DW_AT_const_value(0x06) .dwattr $C$DW$1721, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1721, DW_AT_decl_line(0xc0) .dwattr $C$DW$1721, DW_AT_decl_column(0x05) $C$DW$1722 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ_FULL_FRAME"), DW_AT_const_value(0x07) .dwattr $C$DW$1722, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1722, DW_AT_decl_line(0xc0) .dwattr $C$DW$1722, DW_AT_decl_column(0x05) $C$DW$1723 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ1"), DW_AT_const_value(0x08) .dwattr $C$DW$1723, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1723, DW_AT_decl_line(0xc0) .dwattr $C$DW$1723, DW_AT_decl_column(0x05) $C$DW$1724 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ2"), DW_AT_const_value(0x09) .dwattr $C$DW$1724, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1724, DW_AT_decl_line(0xc0) .dwattr $C$DW$1724, DW_AT_decl_column(0x05) $C$DW$1725 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_CVIZ_STITCH"), DW_AT_const_value(0x0a) .dwattr $C$DW$1725, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1725, DW_AT_decl_line(0xc0) .dwattr $C$DW$1725, DW_AT_decl_column(0x05) $C$DW$1726 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_REMAP"), DW_AT_const_value(0x0b) .dwattr $C$DW$1726, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1726, DW_AT_decl_line(0xc0) .dwattr $C$DW$1726, DW_AT_decl_column(0x05) $C$DW$1727 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_SCAN_CONV"), DW_AT_const_value(0x0c) .dwattr $C$DW$1727, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1727, DW_AT_decl_line(0xc0) .dwattr $C$DW$1727, DW_AT_decl_column(0x05) $C$DW$1728 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_SCALE_ZOOM"), DW_AT_const_value(0x0d) .dwattr $C$DW$1728, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1728, DW_AT_decl_line(0xc0) .dwattr $C$DW$1728, DW_AT_decl_column(0x05) $C$DW$1729 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BMODE_END"), DW_AT_const_value(0x1f) .dwattr $C$DW$1729, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1729, DW_AT_decl_line(0xc0) .dwattr $C$DW$1729, DW_AT_decl_column(0x05) $C$DW$1730 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_COLOR_START"), DW_AT_const_value(0x1000001) .dwattr $C$DW$1730, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1730, DW_AT_decl_line(0xc0) .dwattr $C$DW$1730, DW_AT_decl_column(0x05) $C$DW$1731 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_COLOR_MPFIR_VELVAR"), DW_AT_const_value(0x1000002) .dwattr $C$DW$1731, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1731, DW_AT_decl_line(0xc0) .dwattr $C$DW$1731, DW_AT_decl_column(0x05) $C$DW$1732 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_COLOR_END"), DW_AT_const_value(0x100001f) .dwattr $C$DW$1732, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1732, DW_AT_decl_line(0xc0) .dwattr $C$DW$1732, DW_AT_decl_column(0x05) $C$DW$1733 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_START"), DW_AT_const_value(0x2000001) .dwattr $C$DW$1733, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1733, DW_AT_decl_line(0xc0) .dwattr $C$DW$1733, DW_AT_decl_column(0x05) $C$DW$1734 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_PREPROCESS"), DW_AT_const_value(0x2000002) .dwattr $C$DW$1734, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1734, DW_AT_decl_line(0xc0) .dwattr $C$DW$1734, DW_AT_decl_column(0x05) $C$DW$1735 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_FFT_RATE"), DW_AT_const_value(0x2000003) .dwattr $C$DW$1735, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1735, DW_AT_decl_line(0xc0) .dwattr $C$DW$1735, DW_AT_decl_column(0x05) $C$DW$1736 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_FFT_RATE_BY_N"), DW_AT_const_value(0x2000004) .dwattr $C$DW$1736, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1736, DW_AT_decl_line(0xc0) .dwattr $C$DW$1736, DW_AT_decl_column(0x05) $C$DW$1737 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_FFT_POSTPROCESS"), DW_AT_const_value(0x2000005) .dwattr $C$DW$1737, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1737, DW_AT_decl_line(0xc0) .dwattr $C$DW$1737, DW_AT_decl_column(0x05) $C$DW$1738 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_DOPPLER_END"), DW_AT_const_value(0x200001f) .dwattr $C$DW$1738, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1738, DW_AT_decl_line(0xc0) .dwattr $C$DW$1738, DW_AT_decl_column(0x05) $C$DW$1739 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_START"), DW_AT_const_value(0x3000001) .dwattr $C$DW$1739, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1739, DW_AT_decl_line(0xc0) .dwattr $C$DW$1739, DW_AT_decl_column(0x05) $C$DW$1740 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_AMM_INTERP"), DW_AT_const_value(0x3000002) .dwattr $C$DW$1740, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1740, DW_AT_decl_line(0xc0) .dwattr $C$DW$1740, DW_AT_decl_column(0x05) $C$DW$1741 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_PROCESS"), DW_AT_const_value(0x3000003) .dwattr $C$DW$1741, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1741, DW_AT_decl_line(0xc0) .dwattr $C$DW$1741, DW_AT_decl_column(0x05) $C$DW$1742 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_MMODE_END"), DW_AT_const_value(0x300001f) .dwattr $C$DW$1742, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1742, DW_AT_decl_line(0xc0) .dwattr $C$DW$1742, DW_AT_decl_column(0x05) $C$DW$1743 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_START"), DW_AT_const_value(0x4000001) .dwattr $C$DW$1743, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1743, DW_AT_decl_line(0xc0) .dwattr $C$DW$1743, DW_AT_decl_column(0x05) $C$DW$1744 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_PROCESS"), DW_AT_const_value(0x4000002) .dwattr $C$DW$1744, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1744, DW_AT_decl_line(0xc0) .dwattr $C$DW$1744, DW_AT_decl_column(0x05) $C$DW$1745 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_SCAN_CONV"), DW_AT_const_value(0x4000003) .dwattr $C$DW$1745, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1745, DW_AT_decl_line(0xc0) .dwattr $C$DW$1745, DW_AT_decl_column(0x05) $C$DW$1746 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_SCALE_ZOOM"), DW_AT_const_value(0x4000004) .dwattr $C$DW$1746, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1746, DW_AT_decl_line(0xc0) .dwattr $C$DW$1746, DW_AT_decl_column(0x05) $C$DW$1747 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_PAI_END"), DW_AT_const_value(0x400001f) .dwattr $C$DW$1747, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1747, DW_AT_decl_line(0xc0) .dwattr $C$DW$1747, DW_AT_decl_column(0x05) $C$DW$1748 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_ECG_START"), DW_AT_const_value(0x5000001) .dwattr $C$DW$1748, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1748, DW_AT_decl_line(0xc0) .dwattr $C$DW$1748, DW_AT_decl_column(0x05) $C$DW$1749 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_ECG_PROCESS"), DW_AT_const_value(0x5000002) .dwattr $C$DW$1749, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1749, DW_AT_decl_line(0xc0) .dwattr $C$DW$1749, DW_AT_decl_column(0x05) $C$DW$1750 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_ECG_END"), DW_AT_const_value(0x500001f) .dwattr $C$DW$1750, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1750, DW_AT_decl_line(0xc0) .dwattr $C$DW$1750, DW_AT_decl_column(0x05) $C$DW$1751 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_PROCESS_COMMAND_BOL"), DW_AT_const_value(0x00) .dwattr $C$DW$1751, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1751, DW_AT_decl_line(0xc1) .dwattr $C$DW$1751, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$554 .dwattr $C$DW$T$554, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$554, DW_AT_decl_line(0xbb) .dwattr $C$DW$T$554, DW_AT_decl_column(0x01) $C$DW$T$555 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessCmdEnum") .dwattr $C$DW$T$555, DW_AT_type(*$C$DW$T$554) .dwattr $C$DW$T$555, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$555, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$555, DW_AT_decl_line(0xc2) .dwattr $C$DW$T$555, DW_AT_decl_column(0x03) $C$DW$T$573 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$573, DW_AT_name("McMgr_ProcessState") .dwattr $C$DW$T$573, DW_AT_byte_size(0x10) $C$DW$1752 .dwtag DW_TAG_member .dwattr $C$DW$1752, DW_AT_type(*$C$DW$T$567) .dwattr $C$DW$1752, DW_AT_name("module") .dwattr $C$DW$1752, DW_AT_TI_symbol_name("module") .dwattr $C$DW$1752, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1752, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1752, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1752, DW_AT_decl_line(0x1a0) .dwattr $C$DW$1752, DW_AT_decl_column(0x1e) $C$DW$1753 .dwtag DW_TAG_member .dwattr $C$DW$1753, DW_AT_type(*$C$DW$T$568) .dwattr $C$DW$1753, DW_AT_name("sharedResource") .dwattr $C$DW$1753, DW_AT_TI_symbol_name("sharedResource") .dwattr $C$DW$1753, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1753, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1753, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1753, DW_AT_decl_line(0x1a2) .dwattr $C$DW$1753, DW_AT_decl_column(0x1f) $C$DW$81 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$81, DW_AT_declaration .dwattr $C$DW$81, DW_AT_TI_symbol_name("_ZN18McMgr_ProcessStateaSERKS_") .dwattr $C$DW$81, DW_AT_type(*$C$DW$T$569) .dwattr $C$DW$81, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1754 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1754, DW_AT_type(*$C$DW$T$571) .dwendtag $C$DW$81 .dwendtag $C$DW$T$573 .dwattr $C$DW$T$573, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$573, DW_AT_decl_line(0x19f) .dwattr $C$DW$T$573, DW_AT_decl_column(0x01) $C$DW$T$570 .dwtag DW_TAG_const_type .dwattr $C$DW$T$570, DW_AT_type(*$C$DW$T$573) $C$DW$T$571 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$571, DW_AT_type(*$C$DW$T$570) .dwattr $C$DW$T$571, DW_AT_address_class(0x20) $C$DW$T$1450 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_ProcessState") .dwattr $C$DW$T$1450, DW_AT_type(*$C$DW$T$573) .dwattr $C$DW$T$1450, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1450, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1450, DW_AT_decl_line(0x1a3) .dwattr $C$DW$T$1450, DW_AT_decl_column(0x03) $C$DW$T$569 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$569, DW_AT_type(*$C$DW$T$573) .dwattr $C$DW$T$569, DW_AT_address_class(0x20) $C$DW$T$572 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$572, DW_AT_type(*$C$DW$T$569) .dwattr $C$DW$T$572, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1755 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1755, DW_AT_type(*$C$DW$T$571) .dwendtag $C$DW$T$572 $C$DW$T$578 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$578, DW_AT_name("McMgr_SharedResourceState") .dwattr $C$DW$T$578, DW_AT_byte_size(0x02) $C$DW$1756 .dwtag DW_TAG_member .dwattr $C$DW$1756, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$1756, DW_AT_name("remapTableUpdate") .dwattr $C$DW$1756, DW_AT_TI_symbol_name("remapTableUpdate") .dwattr $C$DW$1756, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1756, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1756, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1756, DW_AT_decl_line(0x12e) .dwattr $C$DW$1756, DW_AT_decl_column(0x0a) $C$DW$82 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$82, DW_AT_declaration .dwattr $C$DW$82, DW_AT_TI_symbol_name("_ZN25McMgr_SharedResourceStateaSERKS_") .dwattr $C$DW$82, DW_AT_type(*$C$DW$T$574) .dwattr $C$DW$82, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1757 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1757, DW_AT_type(*$C$DW$T$576) .dwendtag $C$DW$82 .dwendtag $C$DW$T$578 .dwattr $C$DW$T$578, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$578, DW_AT_decl_line(0x12d) .dwattr $C$DW$T$578, DW_AT_decl_column(0x01) $C$DW$T$568 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_SharedResourceState") .dwattr $C$DW$T$568, DW_AT_type(*$C$DW$T$578) .dwattr $C$DW$T$568, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$568, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$568, DW_AT_decl_line(0x12f) .dwattr $C$DW$T$568, DW_AT_decl_column(0x03) $C$DW$T$575 .dwtag DW_TAG_const_type .dwattr $C$DW$T$575, DW_AT_type(*$C$DW$T$578) $C$DW$T$576 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$576, DW_AT_type(*$C$DW$T$575) .dwattr $C$DW$T$576, DW_AT_address_class(0x20) $C$DW$T$574 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$574, DW_AT_type(*$C$DW$T$578) .dwattr $C$DW$T$574, DW_AT_address_class(0x20) $C$DW$T$577 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$577, DW_AT_type(*$C$DW$T$574) .dwattr $C$DW$T$577, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1758 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1758, DW_AT_type(*$C$DW$T$576) .dwendtag $C$DW$T$577 $C$DW$T$1928 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1928, DW_AT_name("McMgr_SharedResourceType") .dwattr $C$DW$T$1928, DW_AT_byte_size(0x04) $C$DW$1759 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_SHARED_RESOURCE_BMODE_REMAP_TABLE"), DW_AT_const_value(0x00) .dwattr $C$DW$1759, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1759, DW_AT_decl_line(0x127) .dwattr $C$DW$1759, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1928 .dwattr $C$DW$T$1928, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1928, DW_AT_decl_line(0x126) .dwattr $C$DW$T$1928, DW_AT_decl_column(0x01) $C$DW$T$1929 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_SharedResourceType") .dwattr $C$DW$T$1929, DW_AT_type(*$C$DW$T$1928) .dwattr $C$DW$T$1929, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1929, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1929, DW_AT_decl_line(0x128) .dwattr $C$DW$T$1929, DW_AT_decl_column(0x03) $C$DW$T$1930 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1930, DW_AT_name("McMgr_Triggered_Command_Ordinal") .dwattr $C$DW$T$1930, DW_AT_byte_size(0x04) $C$DW$1760 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_TRIG_CMD_BOL"), DW_AT_const_value(0x00) .dwattr $C$DW$1760, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1760, DW_AT_decl_line(0xaa) .dwattr $C$DW$1760, DW_AT_decl_column(0x05) $C$DW$1761 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_FIRST_TRIG_CMD"), DW_AT_const_value(0x00) .dwattr $C$DW$1761, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1761, DW_AT_decl_line(0xab) .dwattr $C$DW$1761, DW_AT_decl_column(0x05) $C$DW$1762 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_SECOND_TRIG_CMD"), DW_AT_const_value(0x01) .dwattr $C$DW$1762, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1762, DW_AT_decl_line(0xac) .dwattr $C$DW$1762, DW_AT_decl_column(0x05) $C$DW$1763 .dwtag DW_TAG_enumerator, DW_AT_name("MCMGR_TRIG_CMD_EOL"), DW_AT_const_value(0x02) .dwattr $C$DW$1763, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1763, DW_AT_decl_line(0xad) .dwattr $C$DW$1763, DW_AT_decl_column(0x05) $C$DW$1764 .dwtag DW_TAG_enumerator, DW_AT_name("MAX_MCMGR_TRIG_CMD_CNT"), DW_AT_const_value(0x02) .dwattr $C$DW$1764, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$1764, DW_AT_decl_line(0xae) .dwattr $C$DW$1764, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1930 .dwattr $C$DW$T$1930, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1930, DW_AT_decl_line(0xa9) .dwattr $C$DW$T$1930, DW_AT_decl_column(0x01) $C$DW$T$1931 .dwtag DW_TAG_typedef, DW_AT_name("McMgr_Triggered_Command_Ordinal") .dwattr $C$DW$T$1931, DW_AT_type(*$C$DW$T$1930) .dwattr $C$DW$T$1931, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1931, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMgr.h") .dwattr $C$DW$T$1931, DW_AT_decl_line(0xaf) .dwattr $C$DW$T$1931, DW_AT_decl_column(0x03) $C$DW$T$889 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$889, DW_AT_name("MessageQ_MsgHeader") .dwattr $C$DW$T$889, DW_AT_byte_size(0x20) $C$DW$1765 .dwtag DW_TAG_member .dwattr $C$DW$1765, DW_AT_type(*$C$DW$T$883) .dwattr $C$DW$1765, DW_AT_name("reserved0") .dwattr $C$DW$1765, DW_AT_TI_symbol_name("reserved0") .dwattr $C$DW$1765, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1765, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1765, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1765, DW_AT_decl_line(0x25a) .dwattr $C$DW$1765, DW_AT_decl_column(0x12) $C$DW$1766 .dwtag DW_TAG_member .dwattr $C$DW$1766, DW_AT_type(*$C$DW$T$883) .dwattr $C$DW$1766, DW_AT_name("reserved1") .dwattr $C$DW$1766, DW_AT_TI_symbol_name("reserved1") .dwattr $C$DW$1766, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1766, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1766, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1766, DW_AT_decl_line(0x25b) .dwattr $C$DW$1766, DW_AT_decl_column(0x12) $C$DW$1767 .dwtag DW_TAG_member .dwattr $C$DW$1767, DW_AT_type(*$C$DW$T$883) .dwattr $C$DW$1767, DW_AT_name("msgSize") .dwattr $C$DW$1767, DW_AT_TI_symbol_name("msgSize") .dwattr $C$DW$1767, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1767, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1767, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1767, DW_AT_decl_line(0x25c) .dwattr $C$DW$1767, DW_AT_decl_column(0x12) $C$DW$1768 .dwtag DW_TAG_member .dwattr $C$DW$1768, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1768, DW_AT_name("flags") .dwattr $C$DW$1768, DW_AT_TI_symbol_name("flags") .dwattr $C$DW$1768, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1768, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1768, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1768, DW_AT_decl_line(0x25d) .dwattr $C$DW$1768, DW_AT_decl_column(0x12) $C$DW$1769 .dwtag DW_TAG_member .dwattr $C$DW$1769, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1769, DW_AT_name("msgId") .dwattr $C$DW$1769, DW_AT_TI_symbol_name("msgId") .dwattr $C$DW$1769, DW_AT_data_member_location[DW_OP_plus_uconst 0xe] .dwattr $C$DW$1769, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1769, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1769, DW_AT_decl_line(0x25e) .dwattr $C$DW$1769, DW_AT_decl_column(0x12) $C$DW$1770 .dwtag DW_TAG_member .dwattr $C$DW$1770, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1770, DW_AT_name("dstId") .dwattr $C$DW$1770, DW_AT_TI_symbol_name("dstId") .dwattr $C$DW$1770, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1770, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1770, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1770, DW_AT_decl_line(0x25f) .dwattr $C$DW$1770, DW_AT_decl_column(0x12) $C$DW$1771 .dwtag DW_TAG_member .dwattr $C$DW$1771, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1771, DW_AT_name("dstProc") .dwattr $C$DW$1771, DW_AT_TI_symbol_name("dstProc") .dwattr $C$DW$1771, DW_AT_data_member_location[DW_OP_plus_uconst 0x12] .dwattr $C$DW$1771, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1771, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1771, DW_AT_decl_line(0x260) .dwattr $C$DW$1771, DW_AT_decl_column(0x12) $C$DW$1772 .dwtag DW_TAG_member .dwattr $C$DW$1772, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1772, DW_AT_name("replyId") .dwattr $C$DW$1772, DW_AT_TI_symbol_name("replyId") .dwattr $C$DW$1772, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1772, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1772, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1772, DW_AT_decl_line(0x261) .dwattr $C$DW$1772, DW_AT_decl_column(0x12) $C$DW$1773 .dwtag DW_TAG_member .dwattr $C$DW$1773, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1773, DW_AT_name("replyProc") .dwattr $C$DW$1773, DW_AT_TI_symbol_name("replyProc") .dwattr $C$DW$1773, DW_AT_data_member_location[DW_OP_plus_uconst 0x16] .dwattr $C$DW$1773, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1773, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1773, DW_AT_decl_line(0x262) .dwattr $C$DW$1773, DW_AT_decl_column(0x12) $C$DW$1774 .dwtag DW_TAG_member .dwattr $C$DW$1774, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1774, DW_AT_name("srcProc") .dwattr $C$DW$1774, DW_AT_TI_symbol_name("srcProc") .dwattr $C$DW$1774, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1774, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1774, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1774, DW_AT_decl_line(0x263) .dwattr $C$DW$1774, DW_AT_decl_column(0x12) $C$DW$1775 .dwtag DW_TAG_member .dwattr $C$DW$1775, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1775, DW_AT_name("heapId") .dwattr $C$DW$1775, DW_AT_TI_symbol_name("heapId") .dwattr $C$DW$1775, DW_AT_data_member_location[DW_OP_plus_uconst 0x1a] .dwattr $C$DW$1775, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1775, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1775, DW_AT_decl_line(0x264) .dwattr $C$DW$1775, DW_AT_decl_column(0x12) $C$DW$1776 .dwtag DW_TAG_member .dwattr $C$DW$1776, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1776, DW_AT_name("seqNum") .dwattr $C$DW$1776, DW_AT_TI_symbol_name("seqNum") .dwattr $C$DW$1776, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c] .dwattr $C$DW$1776, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1776, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1776, DW_AT_decl_line(0x265) .dwattr $C$DW$1776, DW_AT_decl_column(0x12) $C$DW$1777 .dwtag DW_TAG_member .dwattr $C$DW$1777, DW_AT_type(*$C$DW$T$884) .dwattr $C$DW$1777, DW_AT_name("reserved") .dwattr $C$DW$1777, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1777, DW_AT_data_member_location[DW_OP_plus_uconst 0x1e] .dwattr $C$DW$1777, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1777, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1777, DW_AT_decl_line(0x266) .dwattr $C$DW$1777, DW_AT_decl_column(0x12) $C$DW$83 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$83, DW_AT_declaration .dwattr $C$DW$83, DW_AT_TI_symbol_name("_ZN18MessageQ_MsgHeaderaSERKS_") .dwattr $C$DW$83, DW_AT_type(*$C$DW$T$885) .dwattr $C$DW$83, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1778 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1778, DW_AT_type(*$C$DW$T$887) .dwendtag $C$DW$83 .dwendtag $C$DW$T$889 .dwattr $C$DW$T$889, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$889, DW_AT_decl_line(0x259) .dwattr $C$DW$T$889, DW_AT_decl_column(0x10) $C$DW$T$886 .dwtag DW_TAG_const_type .dwattr $C$DW$T$886, DW_AT_type(*$C$DW$T$889) $C$DW$T$887 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$887, DW_AT_type(*$C$DW$T$886) .dwattr $C$DW$T$887, DW_AT_address_class(0x20) $C$DW$T$1529 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_MsgHeader") .dwattr $C$DW$T$1529, DW_AT_type(*$C$DW$T$889) .dwattr $C$DW$T$1529, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1529, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$1529, DW_AT_decl_line(0x267) .dwattr $C$DW$T$1529, DW_AT_decl_column(0x03) $C$DW$T$1647 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$1647, DW_AT_type(*$C$DW$T$1529) .dwattr $C$DW$T$1647, DW_AT_address_class(0x20) $C$DW$T$1648 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Msg") .dwattr $C$DW$T$1648, DW_AT_type(*$C$DW$T$1647) .dwattr $C$DW$T$1648, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1648, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$1648, DW_AT_decl_line(0x26c) .dwattr $C$DW$T$1648, DW_AT_decl_column(0x1d) $C$DW$T$885 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$885, DW_AT_type(*$C$DW$T$889) .dwattr $C$DW$T$885, DW_AT_address_class(0x20) $C$DW$T$888 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$888, DW_AT_type(*$C$DW$T$885) .dwattr $C$DW$T$888, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1779 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1779, DW_AT_type(*$C$DW$T$887) .dwendtag $C$DW$T$888 $C$DW$T$92 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$92, DW_AT_name("MessageQ_Object") .dwattr $C$DW$T$92, DW_AT_declaration .dwendtag $C$DW$T$92 .dwattr $C$DW$T$92, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$92, DW_AT_decl_line(0x1fa) .dwattr $C$DW$T$92, DW_AT_decl_column(0x10) $C$DW$T$2147 .dwtag DW_TAG_pointer_type .dwattr $C$DW$T$2147, DW_AT_type(*$C$DW$T$92) .dwattr $C$DW$T$2147, DW_AT_address_class(0x20) $C$DW$T$2148 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Handle") .dwattr $C$DW$T$2148, DW_AT_type(*$C$DW$T$2147) .dwattr $C$DW$T$2148, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2148, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$2148, DW_AT_decl_line(0x1fa) .dwattr $C$DW$T$2148, DW_AT_decl_column(0x21) $C$DW$T$897 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$897, DW_AT_name("MessageQ_Params") .dwattr $C$DW$T$897, DW_AT_byte_size(0x0c) $C$DW$1780 .dwtag DW_TAG_member .dwattr $C$DW$1780, DW_AT_type(*$C$DW$T$890) .dwattr $C$DW$1780, DW_AT_name("__version") .dwattr $C$DW$1780, DW_AT_TI_symbol_name("__version") .dwattr $C$DW$1780, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1780, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1780, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1780, DW_AT_decl_line(0x201) .dwattr $C$DW$1780, DW_AT_decl_column(0x09) $C$DW$1781 .dwtag DW_TAG_member .dwattr $C$DW$1781, DW_AT_type(*$C$DW$T$3) .dwattr $C$DW$1781, DW_AT_name("synchronizer") .dwattr $C$DW$1781, DW_AT_TI_symbol_name("synchronizer") .dwattr $C$DW$1781, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1781, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1781, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1781, DW_AT_decl_line(0x207) .dwattr $C$DW$1781, DW_AT_decl_column(0x0b) $C$DW$1782 .dwtag DW_TAG_member .dwattr $C$DW$1782, DW_AT_type(*$C$DW$T$892) .dwattr $C$DW$1782, DW_AT_name("queueIndex") .dwattr $C$DW$1782, DW_AT_TI_symbol_name("queueIndex") .dwattr $C$DW$1782, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1782, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1782, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1782, DW_AT_decl_line(0x210) .dwattr $C$DW$1782, DW_AT_decl_column(0x1a) $C$DW$84 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$84, DW_AT_declaration .dwattr $C$DW$84, DW_AT_TI_symbol_name("_ZN15MessageQ_ParamsaSERKS_") .dwattr $C$DW$84, DW_AT_type(*$C$DW$T$893) .dwattr $C$DW$84, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1783 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1783, DW_AT_type(*$C$DW$T$895) .dwendtag $C$DW$84 .dwendtag $C$DW$T$897 .dwattr $C$DW$T$897, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$897, DW_AT_decl_line(0x1ff) .dwattr $C$DW$T$897, DW_AT_decl_column(0x10) $C$DW$T$894 .dwtag DW_TAG_const_type .dwattr $C$DW$T$894, DW_AT_type(*$C$DW$T$897) $C$DW$T$895 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$895, DW_AT_type(*$C$DW$T$894) .dwattr $C$DW$T$895, DW_AT_address_class(0x20) $C$DW$T$2149 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Params") .dwattr $C$DW$T$2149, DW_AT_type(*$C$DW$T$897) .dwattr $C$DW$T$2149, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2149, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$2149, DW_AT_decl_line(0x21f) .dwattr $C$DW$T$2149, DW_AT_decl_column(0x03) $C$DW$T$893 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$893, DW_AT_type(*$C$DW$T$897) .dwattr $C$DW$T$893, DW_AT_address_class(0x20) $C$DW$T$896 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$896, DW_AT_type(*$C$DW$T$893) .dwattr $C$DW$T$896, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1784 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1784, DW_AT_type(*$C$DW$T$895) .dwendtag $C$DW$T$896 $C$DW$T$902 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$902, DW_AT_name("MessageQ_Params2") .dwattr $C$DW$T$902, DW_AT_byte_size(0x08) $C$DW$1785 .dwtag DW_TAG_member .dwattr $C$DW$1785, DW_AT_type(*$C$DW$T$3) .dwattr $C$DW$1785, DW_AT_name("synchronizer") .dwattr $C$DW$1785, DW_AT_TI_symbol_name("synchronizer") .dwattr $C$DW$1785, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1785, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1785, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1785, DW_AT_decl_line(0x23c) .dwattr $C$DW$1785, DW_AT_decl_column(0x0b) $C$DW$1786 .dwtag DW_TAG_member .dwattr $C$DW$1786, DW_AT_type(*$C$DW$T$892) .dwattr $C$DW$1786, DW_AT_name("queueIndex") .dwattr $C$DW$1786, DW_AT_TI_symbol_name("queueIndex") .dwattr $C$DW$1786, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1786, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1786, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1786, DW_AT_decl_line(0x245) .dwattr $C$DW$1786, DW_AT_decl_column(0x1a) $C$DW$85 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$85, DW_AT_declaration .dwattr $C$DW$85, DW_AT_TI_symbol_name("_ZN16MessageQ_Params2aSERKS_") .dwattr $C$DW$85, DW_AT_type(*$C$DW$T$898) .dwattr $C$DW$85, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1787 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1787, DW_AT_type(*$C$DW$T$900) .dwendtag $C$DW$85 .dwendtag $C$DW$T$902 .dwattr $C$DW$T$902, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$902, DW_AT_decl_line(0x23b) .dwattr $C$DW$T$902, DW_AT_decl_column(0x10) $C$DW$T$899 .dwtag DW_TAG_const_type .dwattr $C$DW$T$899, DW_AT_type(*$C$DW$T$902) $C$DW$T$900 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$900, DW_AT_type(*$C$DW$T$899) .dwattr $C$DW$T$900, DW_AT_address_class(0x20) $C$DW$T$2150 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Params2") .dwattr $C$DW$T$2150, DW_AT_type(*$C$DW$T$902) .dwattr $C$DW$T$2150, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2150, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$2150, DW_AT_decl_line(0x254) .dwattr $C$DW$T$2150, DW_AT_decl_column(0x03) $C$DW$T$898 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$898, DW_AT_type(*$C$DW$T$902) .dwattr $C$DW$T$898, DW_AT_address_class(0x20) $C$DW$T$901 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$901, DW_AT_type(*$C$DW$T$898) .dwattr $C$DW$T$901, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1788 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1788, DW_AT_type(*$C$DW$T$900) .dwendtag $C$DW$T$901 $C$DW$T$2151 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$2151, DW_AT_name("MessageQ_Priority") .dwattr $C$DW$T$2151, DW_AT_byte_size(0x04) $C$DW$1789 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_NORMALPRI"), DW_AT_const_value(0x00) .dwattr $C$DW$1789, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1789, DW_AT_decl_line(0x272) .dwattr $C$DW$1789, DW_AT_decl_column(0x05) $C$DW$1790 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_HIGHPRI"), DW_AT_const_value(0x01) .dwattr $C$DW$1790, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1790, DW_AT_decl_line(0x273) .dwattr $C$DW$1790, DW_AT_decl_column(0x05) $C$DW$1791 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_RESERVEDPRI"), DW_AT_const_value(0x02) .dwattr $C$DW$1791, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1791, DW_AT_decl_line(0x274) .dwattr $C$DW$1791, DW_AT_decl_column(0x05) $C$DW$1792 .dwtag DW_TAG_enumerator, DW_AT_name("MessageQ_URGENTPRI"), DW_AT_const_value(0x03) .dwattr $C$DW$1792, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$1792, DW_AT_decl_line(0x275) .dwattr $C$DW$1792, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$2151 .dwattr $C$DW$T$2151, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$2151, DW_AT_decl_line(0x271) .dwattr $C$DW$T$2151, DW_AT_decl_column(0x0e) $C$DW$T$2152 .dwtag DW_TAG_typedef, DW_AT_name("MessageQ_Priority") .dwattr $C$DW$T$2152, DW_AT_type(*$C$DW$T$2151) .dwattr $C$DW$T$2152, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2152, DW_AT_decl_file("C:/ti/ipc_3_44_01_01/packages/ti/ipc/MessageQ.h") .dwattr $C$DW$T$2152, DW_AT_decl_line(0x276) .dwattr $C$DW$T$2152, DW_AT_decl_column(0x03) $C$DW$T$1484 .dwtag DW_TAG_union_type .dwattr $C$DW$T$1484, DW_AT_name("MsgData") .dwattr $C$DW$T$1484, DW_AT_byte_size(0xd8) $C$DW$1793 .dwtag DW_TAG_member .dwattr $C$DW$1793, DW_AT_type(*$C$DW$T$1469) .dwattr $C$DW$1793, DW_AT_name("inputMgrData") .dwattr $C$DW$1793, DW_AT_TI_symbol_name("inputMgrData") .dwattr $C$DW$1793, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1793, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1793, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1793, DW_AT_decl_line(0xb8) .dwattr $C$DW$1793, DW_AT_decl_column(0x1d) $C$DW$1794 .dwtag DW_TAG_member .dwattr $C$DW$1794, DW_AT_type(*$C$DW$T$1470) .dwattr $C$DW$1794, DW_AT_name("outputMgrData") .dwattr $C$DW$1794, DW_AT_TI_symbol_name("outputMgrData") .dwattr $C$DW$1794, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1794, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1794, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1794, DW_AT_decl_line(0xb9) .dwattr $C$DW$1794, DW_AT_decl_column(0x1d) $C$DW$1795 .dwtag DW_TAG_member .dwattr $C$DW$1795, DW_AT_type(*$C$DW$T$1471) .dwattr $C$DW$1795, DW_AT_name("mainCtlrData") .dwattr $C$DW$1795, DW_AT_TI_symbol_name("mainCtlrData") .dwattr $C$DW$1795, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1795, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1795, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1795, DW_AT_decl_line(0xba) .dwattr $C$DW$1795, DW_AT_decl_column(0x1d) $C$DW$1796 .dwtag DW_TAG_member .dwattr $C$DW$1796, DW_AT_type(*$C$DW$T$1472) .dwattr $C$DW$1796, DW_AT_name("processMsg") .dwattr $C$DW$1796, DW_AT_TI_symbol_name("processMsg") .dwattr $C$DW$1796, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1796, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1796, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1796, DW_AT_decl_line(0xbb) .dwattr $C$DW$1796, DW_AT_decl_column(0x1d) $C$DW$1797 .dwtag DW_TAG_member .dwattr $C$DW$1797, DW_AT_type(*$C$DW$T$1473) .dwattr $C$DW$1797, DW_AT_name("initMsg") .dwattr $C$DW$1797, DW_AT_TI_symbol_name("initMsg") .dwattr $C$DW$1797, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1797, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1797, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1797, DW_AT_decl_line(0xbc) .dwattr $C$DW$1797, DW_AT_decl_column(0x1d) $C$DW$1798 .dwtag DW_TAG_member .dwattr $C$DW$1798, DW_AT_type(*$C$DW$T$1474) .dwattr $C$DW$1798, DW_AT_name("startMsg") .dwattr $C$DW$1798, DW_AT_TI_symbol_name("startMsg") .dwattr $C$DW$1798, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1798, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1798, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1798, DW_AT_decl_line(0xbd) .dwattr $C$DW$1798, DW_AT_decl_column(0x1d) $C$DW$1799 .dwtag DW_TAG_member .dwattr $C$DW$1799, DW_AT_type(*$C$DW$T$1475) .dwattr $C$DW$1799, DW_AT_name("stopMsg") .dwattr $C$DW$1799, DW_AT_TI_symbol_name("stopMsg") .dwattr $C$DW$1799, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1799, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1799, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1799, DW_AT_decl_line(0xbe) .dwattr $C$DW$1799, DW_AT_decl_column(0x1d) $C$DW$1800 .dwtag DW_TAG_member .dwattr $C$DW$1800, DW_AT_type(*$C$DW$T$1476) .dwattr $C$DW$1800, DW_AT_name("paramUpdateMsg") .dwattr $C$DW$1800, DW_AT_TI_symbol_name("paramUpdateMsg") .dwattr $C$DW$1800, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1800, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1800, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1800, DW_AT_decl_line(0xbf) .dwattr $C$DW$1800, DW_AT_decl_column(0x1d) $C$DW$1801 .dwtag DW_TAG_member .dwattr $C$DW$1801, DW_AT_type(*$C$DW$T$1477) .dwattr $C$DW$1801, DW_AT_name("errorMsg") .dwattr $C$DW$1801, DW_AT_TI_symbol_name("errorMsg") .dwattr $C$DW$1801, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1801, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1801, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1801, DW_AT_decl_line(0xc0) .dwattr $C$DW$1801, DW_AT_decl_column(0x1d) $C$DW$1802 .dwtag DW_TAG_member .dwattr $C$DW$1802, DW_AT_type(*$C$DW$T$1478) .dwattr $C$DW$1802, DW_AT_name("dbellMsg") .dwattr $C$DW$1802, DW_AT_TI_symbol_name("dbellMsg") .dwattr $C$DW$1802, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1802, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1802, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1802, DW_AT_decl_line(0xc1) .dwattr $C$DW$1802, DW_AT_decl_column(0x1d) $C$DW$1803 .dwtag DW_TAG_member .dwattr $C$DW$1803, DW_AT_type(*$C$DW$T$1479) .dwattr $C$DW$1803, DW_AT_name("testInterfaceMsg") .dwattr $C$DW$1803, DW_AT_TI_symbol_name("testInterfaceMsg") .dwattr $C$DW$1803, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1803, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1803, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1803, DW_AT_decl_line(0xc2) .dwattr $C$DW$1803, DW_AT_decl_column(0x1d) $C$DW$1804 .dwtag DW_TAG_member .dwattr $C$DW$1804, DW_AT_type(*$C$DW$T$152) .dwattr $C$DW$1804, DW_AT_name("data") .dwattr $C$DW$1804, DW_AT_TI_symbol_name("data") .dwattr $C$DW$1804, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1804, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1804, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1804, DW_AT_decl_line(0xc3) .dwattr $C$DW$1804, DW_AT_decl_column(0x1d) $C$DW$86 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$86, DW_AT_declaration .dwattr $C$DW$86, DW_AT_TI_symbol_name("_ZN7MsgDataaSERKS_") .dwattr $C$DW$86, DW_AT_type(*$C$DW$T$1480) .dwattr $C$DW$86, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1805 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1805, DW_AT_type(*$C$DW$T$1482) .dwendtag $C$DW$86 .dwendtag $C$DW$T$1484 .dwattr $C$DW$T$1484, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1484, DW_AT_decl_line(0xb7) .dwattr $C$DW$T$1484, DW_AT_decl_column(0x01) $C$DW$T$1481 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1481, DW_AT_type(*$C$DW$T$1484) $C$DW$T$1482 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1482, DW_AT_type(*$C$DW$T$1481) .dwattr $C$DW$T$1482, DW_AT_address_class(0x20) $C$DW$T$1532 .dwtag DW_TAG_typedef, DW_AT_name("MsgData") .dwattr $C$DW$T$1532, DW_AT_type(*$C$DW$T$1484) .dwattr $C$DW$T$1532, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1532, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1532, DW_AT_decl_line(0xc4) .dwattr $C$DW$T$1532, DW_AT_decl_column(0x03) $C$DW$T$1480 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1480, DW_AT_type(*$C$DW$T$1484) .dwattr $C$DW$T$1480, DW_AT_address_class(0x20) $C$DW$T$1483 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1483, DW_AT_type(*$C$DW$T$1480) .dwattr $C$DW$T$1483, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1806 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1806, DW_AT_type(*$C$DW$T$1482) .dwendtag $C$DW$T$1483 $C$DW$T$1518 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1518, DW_AT_name("MultiBeamInputData") .dwattr $C$DW$T$1518, DW_AT_byte_size(0x10) $C$DW$1807 .dwtag DW_TAG_member .dwattr $C$DW$1807, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$1807, DW_AT_name("timeStamp") .dwattr $C$DW$1807, DW_AT_TI_symbol_name("timeStamp") .dwattr $C$DW$1807, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1807, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1807, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1807, DW_AT_decl_line(0x22) .dwattr $C$DW$1807, DW_AT_decl_column(0x19) $C$DW$1808 .dwtag DW_TAG_member .dwattr $C$DW$1808, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1808, DW_AT_name("rfBufIdx") .dwattr $C$DW$1808, DW_AT_TI_symbol_name("rfBufIdx") .dwattr $C$DW$1808, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1808, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1808, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1808, DW_AT_decl_line(0x23) .dwattr $C$DW$1808, DW_AT_decl_column(0x19) $C$DW$87 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$87, DW_AT_declaration .dwattr $C$DW$87, DW_AT_TI_symbol_name("_ZN18MultiBeamInputDataaSERKS_") .dwattr $C$DW$87, DW_AT_type(*$C$DW$T$1514) .dwattr $C$DW$87, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1809 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1809, DW_AT_type(*$C$DW$T$1516) .dwendtag $C$DW$87 .dwendtag $C$DW$T$1518 .dwattr $C$DW$T$1518, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1518, DW_AT_decl_line(0x20) .dwattr $C$DW$T$1518, DW_AT_decl_column(0x01) $C$DW$T$1165 .dwtag DW_TAG_typedef, DW_AT_name("ColorInputData") .dwattr $C$DW$T$1165, DW_AT_type(*$C$DW$T$1518) .dwattr $C$DW$T$1165, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1165, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1165, DW_AT_decl_line(0x24) .dwattr $C$DW$T$1165, DW_AT_decl_column(0x2e) $C$DW$T$1167 .dwtag DW_TAG_typedef, DW_AT_name("EcgInputData") .dwattr $C$DW$T$1167, DW_AT_type(*$C$DW$T$1518) .dwattr $C$DW$T$1167, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1167, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1167, DW_AT_decl_line(0x24) .dwattr $C$DW$T$1167, DW_AT_decl_column(0x4e) $C$DW$T$1166 .dwtag DW_TAG_typedef, DW_AT_name("MModeInputData") .dwattr $C$DW$T$1166, DW_AT_type(*$C$DW$T$1518) .dwattr $C$DW$T$1166, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1166, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1166, DW_AT_decl_line(0x24) .dwattr $C$DW$T$1166, DW_AT_decl_column(0x3e) $C$DW$T$1162 .dwtag DW_TAG_typedef, DW_AT_name("MultiBeamInputData") .dwattr $C$DW$T$1162, DW_AT_type(*$C$DW$T$1518) .dwattr $C$DW$T$1162, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1162, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1162, DW_AT_decl_line(0x24) .dwattr $C$DW$T$1162, DW_AT_decl_column(0x03) $C$DW$T$1515 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1515, DW_AT_type(*$C$DW$T$1518) $C$DW$T$1516 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1516, DW_AT_type(*$C$DW$T$1515) .dwattr $C$DW$T$1516, DW_AT_address_class(0x20) $C$DW$T$1163 .dwtag DW_TAG_typedef, DW_AT_name("NonMultiBeamInputData") .dwattr $C$DW$T$1163, DW_AT_type(*$C$DW$T$1518) .dwattr $C$DW$T$1163, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1163, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1163, DW_AT_decl_line(0x24) .dwattr $C$DW$T$1163, DW_AT_decl_column(0x17) $C$DW$T$1514 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1514, DW_AT_type(*$C$DW$T$1518) .dwattr $C$DW$T$1514, DW_AT_address_class(0x20) $C$DW$T$1517 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1517, DW_AT_type(*$C$DW$T$1514) .dwattr $C$DW$T$1517, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1810 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1810, DW_AT_type(*$C$DW$T$1516) .dwendtag $C$DW$T$1517 $C$DW$T$1528 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1528, DW_AT_name("MultiBeam_Param") .dwattr $C$DW$T$1528, DW_AT_byte_size(0x1d0) $C$DW$1811 .dwtag DW_TAG_member .dwattr $C$DW$1811, DW_AT_type(*$C$DW$T$1519) .dwattr $C$DW$1811, DW_AT_name("steerAngleParam") .dwattr $C$DW$1811, DW_AT_TI_symbol_name("steerAngleParam") .dwattr $C$DW$1811, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1811, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1811, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1811, DW_AT_decl_line(0x2bf) .dwattr $C$DW$1811, DW_AT_decl_column(0x05) $C$DW$1812 .dwtag DW_TAG_member .dwattr $C$DW$1812, DW_AT_type(*$C$DW$T$1521) .dwattr $C$DW$1812, DW_AT_name("mbeamType") .dwattr $C$DW$1812, DW_AT_TI_symbol_name("mbeamType") .dwattr $C$DW$1812, DW_AT_data_member_location[DW_OP_plus_uconst 0x108] .dwattr $C$DW$1812, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1812, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1812, DW_AT_decl_line(0x2c0) .dwattr $C$DW$1812, DW_AT_decl_column(0x05) $C$DW$1813 .dwtag DW_TAG_member .dwattr $C$DW$1813, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1813, DW_AT_name("taperEnable") .dwattr $C$DW$1813, DW_AT_TI_symbol_name("taperEnable") .dwattr $C$DW$1813, DW_AT_data_member_location[DW_OP_plus_uconst 0x110] .dwattr $C$DW$1813, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1813, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1813, DW_AT_decl_line(0x2c1) .dwattr $C$DW$1813, DW_AT_decl_column(0x05) $C$DW$1814 .dwtag DW_TAG_member .dwattr $C$DW$1814, DW_AT_type(*$C$DW$T$1522) .dwattr $C$DW$1814, DW_AT_name("taperCoeffs") .dwattr $C$DW$1814, DW_AT_TI_symbol_name("taperCoeffs") .dwattr $C$DW$1814, DW_AT_data_member_location[DW_OP_plus_uconst 0x118] .dwattr $C$DW$1814, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1814, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1814, DW_AT_decl_line(0x2c2) .dwattr $C$DW$1814, DW_AT_decl_column(0x05) $C$DW$1815 .dwtag DW_TAG_member .dwattr $C$DW$1815, DW_AT_type(*$C$DW$T$1523) .dwattr $C$DW$1815, DW_AT_name("cmpdFactor") .dwattr $C$DW$1815, DW_AT_TI_symbol_name("cmpdFactor") .dwattr $C$DW$1815, DW_AT_data_member_location[DW_OP_plus_uconst 0x138] .dwattr $C$DW$1815, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1815, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1815, DW_AT_decl_line(0x2c3) .dwattr $C$DW$1815, DW_AT_decl_column(0x05) $C$DW$1816 .dwtag DW_TAG_member .dwattr $C$DW$1816, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$1816, DW_AT_name("num_look_directions") .dwattr $C$DW$1816, DW_AT_TI_symbol_name("num_look_directions") .dwattr $C$DW$1816, DW_AT_data_member_location[DW_OP_plus_uconst 0x148] .dwattr $C$DW$1816, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1816, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1816, DW_AT_decl_line(0x2c4) .dwattr $C$DW$1816, DW_AT_decl_column(0x05) $C$DW$1817 .dwtag DW_TAG_member .dwattr $C$DW$1817, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1817, DW_AT_name("trapezoidEnable") .dwattr $C$DW$1817, DW_AT_TI_symbol_name("trapezoidEnable") .dwattr $C$DW$1817, DW_AT_data_member_location[DW_OP_plus_uconst 0x150] .dwattr $C$DW$1817, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1817, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1817, DW_AT_decl_line(0x2c5) .dwattr $C$DW$1817, DW_AT_decl_column(0x05) $C$DW$1818 .dwtag DW_TAG_member .dwattr $C$DW$1818, DW_AT_type(*$C$DW$T$1291) .dwattr $C$DW$1818, DW_AT_name("reserved") .dwattr $C$DW$1818, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1818, DW_AT_data_member_location[DW_OP_plus_uconst 0x158] .dwattr $C$DW$1818, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1818, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1818, DW_AT_decl_line(0x2c6) .dwattr $C$DW$1818, DW_AT_decl_column(0x05) $C$DW$88 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$88, DW_AT_declaration .dwattr $C$DW$88, DW_AT_TI_symbol_name("_ZN15MultiBeam_ParamaSERKS_") .dwattr $C$DW$88, DW_AT_type(*$C$DW$T$1524) .dwattr $C$DW$88, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1819 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1819, DW_AT_type(*$C$DW$T$1526) .dwendtag $C$DW$88 .dwendtag $C$DW$T$1528 .dwattr $C$DW$T$1528, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1528, DW_AT_decl_line(0x2be) .dwattr $C$DW$T$1528, DW_AT_decl_column(0x01) $C$DW$T$1525 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1525, DW_AT_type(*$C$DW$T$1528) $C$DW$T$1526 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1526, DW_AT_type(*$C$DW$T$1525) .dwattr $C$DW$T$1526, DW_AT_address_class(0x20) $C$DW$T$1581 .dwtag DW_TAG_typedef, DW_AT_name("MultiBeam_Param") .dwattr $C$DW$T$1581, DW_AT_type(*$C$DW$T$1528) .dwattr $C$DW$T$1581, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1581, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1581, DW_AT_decl_line(0x2c7) .dwattr $C$DW$T$1581, DW_AT_decl_column(0x03) $C$DW$T$1524 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1524, DW_AT_type(*$C$DW$T$1528) .dwattr $C$DW$T$1524, DW_AT_address_class(0x20) $C$DW$T$1527 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1527, DW_AT_type(*$C$DW$T$1524) .dwattr $C$DW$T$1527, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1820 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1820, DW_AT_type(*$C$DW$T$1526) .dwendtag $C$DW$T$1527 $C$DW$T$1520 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1520, DW_AT_name("MultiBeam_Type") .dwattr $C$DW$T$1520, DW_AT_byte_size(0x04) $C$DW$1821 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_0_NoSC"), DW_AT_const_value(0x00) .dwattr $C$DW$1821, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1821, DW_AT_decl_line(0xf0) .dwattr $C$DW$1821, DW_AT_decl_column(0x05) $C$DW$1822 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_1_NoSC"), DW_AT_const_value(0x01) .dwattr $C$DW$1822, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1822, DW_AT_decl_line(0xf1) .dwattr $C$DW$1822, DW_AT_decl_column(0x05) $C$DW$1823 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_2_NoSC"), DW_AT_const_value(0x02) .dwattr $C$DW$1823, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1823, DW_AT_decl_line(0xf2) .dwattr $C$DW$1823, DW_AT_decl_column(0x05) $C$DW$1824 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_3_NoSC"), DW_AT_const_value(0x03) .dwattr $C$DW$1824, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1824, DW_AT_decl_line(0xf3) .dwattr $C$DW$1824, DW_AT_decl_column(0x05) $C$DW$1825 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_4_NoSC"), DW_AT_const_value(0x04) .dwattr $C$DW$1825, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1825, DW_AT_decl_line(0xf4) .dwattr $C$DW$1825, DW_AT_decl_column(0x05) $C$DW$1826 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_5_NoSC"), DW_AT_const_value(0x05) .dwattr $C$DW$1826, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1826, DW_AT_decl_line(0xf5) .dwattr $C$DW$1826, DW_AT_decl_column(0x05) $C$DW$1827 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_6_NoSC"), DW_AT_const_value(0x06) .dwattr $C$DW$1827, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1827, DW_AT_decl_line(0xf6) .dwattr $C$DW$1827, DW_AT_decl_column(0x05) $C$DW$1828 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_7_NoSC"), DW_AT_const_value(0x07) .dwattr $C$DW$1828, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1828, DW_AT_decl_line(0xf7) .dwattr $C$DW$1828, DW_AT_decl_column(0x05) $C$DW$1829 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_8_NoSC"), DW_AT_const_value(0x08) .dwattr $C$DW$1829, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1829, DW_AT_decl_line(0xf8) .dwattr $C$DW$1829, DW_AT_decl_column(0x05) $C$DW$1830 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_NV_NoSC"), DW_AT_const_value(0x09) .dwattr $C$DW$1830, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1830, DW_AT_decl_line(0xf9) .dwattr $C$DW$1830, DW_AT_decl_column(0x05) $C$DW$1831 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_ANGLE_SEL_MASK"), DW_AT_const_value(0xfff) .dwattr $C$DW$1831, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1831, DW_AT_decl_line(0xfa) .dwattr $C$DW$1831, DW_AT_decl_column(0x05) $C$DW$1832 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_0_wSC"), DW_AT_const_value(0x1000) .dwattr $C$DW$1832, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1832, DW_AT_decl_line(0xfb) .dwattr $C$DW$1832, DW_AT_decl_column(0x05) $C$DW$1833 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_1_wSC"), DW_AT_const_value(0x1001) .dwattr $C$DW$1833, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1833, DW_AT_decl_line(0xfc) .dwattr $C$DW$1833, DW_AT_decl_column(0x05) $C$DW$1834 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_2_wSC"), DW_AT_const_value(0x1002) .dwattr $C$DW$1834, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1834, DW_AT_decl_line(0xfd) .dwattr $C$DW$1834, DW_AT_decl_column(0x05) $C$DW$1835 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_3_wSC"), DW_AT_const_value(0x1003) .dwattr $C$DW$1835, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1835, DW_AT_decl_line(0xfe) .dwattr $C$DW$1835, DW_AT_decl_column(0x05) $C$DW$1836 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_4_wSC"), DW_AT_const_value(0x1004) .dwattr $C$DW$1836, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1836, DW_AT_decl_line(0xff) .dwattr $C$DW$1836, DW_AT_decl_column(0x05) $C$DW$1837 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_5_wSC"), DW_AT_const_value(0x1005) .dwattr $C$DW$1837, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1837, DW_AT_decl_line(0x100) .dwattr $C$DW$1837, DW_AT_decl_column(0x05) $C$DW$1838 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_6_wSC"), DW_AT_const_value(0x1006) .dwattr $C$DW$1838, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1838, DW_AT_decl_line(0x101) .dwattr $C$DW$1838, DW_AT_decl_column(0x05) $C$DW$1839 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_7_wSC"), DW_AT_const_value(0x1007) .dwattr $C$DW$1839, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1839, DW_AT_decl_line(0x102) .dwattr $C$DW$1839, DW_AT_decl_column(0x05) $C$DW$1840 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_8_wSC"), DW_AT_const_value(0x1008) .dwattr $C$DW$1840, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1840, DW_AT_decl_line(0x103) .dwattr $C$DW$1840, DW_AT_decl_column(0x05) $C$DW$1841 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_LOOK_NV_wSC"), DW_AT_const_value(0x1009) .dwattr $C$DW$1841, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1841, DW_AT_decl_line(0x104) .dwattr $C$DW$1841, DW_AT_decl_column(0x05) $C$DW$1842 .dwtag DW_TAG_enumerator, DW_AT_name("MB_TYPE_NORMAL"), DW_AT_const_value(0x3000) .dwattr $C$DW$1842, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1842, DW_AT_decl_line(0x105) .dwattr $C$DW$1842, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1520 .dwattr $C$DW$T$1520, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1520, DW_AT_decl_line(0xef) .dwattr $C$DW$T$1520, DW_AT_decl_column(0x01) $C$DW$T$1521 .dwtag DW_TAG_typedef, DW_AT_name("MultiBeam_Type") .dwattr $C$DW$T$1521, DW_AT_type(*$C$DW$T$1520) .dwattr $C$DW$T$1521, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1521, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1521, DW_AT_decl_line(0x106) .dwattr $C$DW$T$1521, DW_AT_decl_column(0x03) $C$DW$T$1538 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1538, DW_AT_name("MulticoreMsg_tag") .dwattr $C$DW$T$1538, DW_AT_byte_size(0x200) $C$DW$1843 .dwtag DW_TAG_member .dwattr $C$DW$1843, DW_AT_type(*$C$DW$T$1529) .dwattr $C$DW$1843, DW_AT_name("header") .dwattr $C$DW$1843, DW_AT_TI_symbol_name("header") .dwattr $C$DW$1843, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1843, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1843, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1843, DW_AT_decl_line(0xcd) .dwattr $C$DW$1843, DW_AT_decl_column(0x19) $C$DW$1844 .dwtag DW_TAG_member .dwattr $C$DW$1844, DW_AT_type(*$C$DW$T$1531) .dwattr $C$DW$1844, DW_AT_name("msgType") .dwattr $C$DW$1844, DW_AT_TI_symbol_name("msgType") .dwattr $C$DW$1844, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1844, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1844, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1844, DW_AT_decl_line(0xce) .dwattr $C$DW$1844, DW_AT_decl_column(0x19) $C$DW$1845 .dwtag DW_TAG_member .dwattr $C$DW$1845, DW_AT_type(*$C$DW$T$1532) .dwattr $C$DW$1845, DW_AT_name("content") .dwattr $C$DW$1845, DW_AT_TI_symbol_name("content") .dwattr $C$DW$1845, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1845, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1845, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1845, DW_AT_decl_line(0xcf) .dwattr $C$DW$1845, DW_AT_decl_column(0x19) $C$DW$1846 .dwtag DW_TAG_member .dwattr $C$DW$1846, DW_AT_type(*$C$DW$T$1533) .dwattr $C$DW$1846, DW_AT_name("filler") .dwattr $C$DW$1846, DW_AT_TI_symbol_name("filler") .dwattr $C$DW$1846, DW_AT_data_member_location[DW_OP_plus_uconst 0x100] .dwattr $C$DW$1846, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1846, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1846, DW_AT_decl_line(0xd1) .dwattr $C$DW$1846, DW_AT_decl_column(0x19) $C$DW$89 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$89, DW_AT_declaration .dwattr $C$DW$89, DW_AT_TI_symbol_name("_ZN16MulticoreMsg_tagaSERKS_") .dwattr $C$DW$89, DW_AT_type(*$C$DW$T$1534) .dwattr $C$DW$89, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1847 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1847, DW_AT_type(*$C$DW$T$1536) .dwendtag $C$DW$89 .dwendtag $C$DW$T$1538 .dwattr $C$DW$T$1538, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1538, DW_AT_decl_line(0xcb) .dwattr $C$DW$T$1538, DW_AT_decl_column(0x10) $C$DW$T$2208 .dwtag DW_TAG_typedef, DW_AT_name("MulticoreMsg") .dwattr $C$DW$T$2208, DW_AT_type(*$C$DW$T$1538) .dwattr $C$DW$T$2208, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$2208, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$2208, DW_AT_decl_line(0xd2) .dwattr $C$DW$T$2208, DW_AT_decl_column(0x03) $C$DW$T$1535 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1535, DW_AT_type(*$C$DW$T$1538) $C$DW$T$1536 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1536, DW_AT_type(*$C$DW$T$1535) .dwattr $C$DW$T$1536, DW_AT_address_class(0x20) $C$DW$T$1534 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1534, DW_AT_type(*$C$DW$T$1538) .dwattr $C$DW$T$1534, DW_AT_address_class(0x20) $C$DW$T$1537 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1537, DW_AT_type(*$C$DW$T$1534) .dwattr $C$DW$T$1537, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1848 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1848, DW_AT_type(*$C$DW$T$1536) .dwendtag $C$DW$T$1537 $C$DW$T$1543 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1543, DW_AT_name("Multiline_Param") .dwattr $C$DW$T$1543, DW_AT_byte_size(0xa0) $C$DW$1849 .dwtag DW_TAG_member .dwattr $C$DW$1849, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1849, DW_AT_name("rfBuffNumMl") .dwattr $C$DW$1849, DW_AT_TI_symbol_name("rfBuffNumMl") .dwattr $C$DW$1849, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1849, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1849, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1849, DW_AT_decl_line(0x416) .dwattr $C$DW$1849, DW_AT_decl_column(0x05) $C$DW$1850 .dwtag DW_TAG_member .dwattr $C$DW$1850, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1850, DW_AT_name("mpfOutMl") .dwattr $C$DW$1850, DW_AT_TI_symbol_name("mpfOutMl") .dwattr $C$DW$1850, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1850, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1850, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1850, DW_AT_decl_line(0x417) .dwattr $C$DW$1850, DW_AT_decl_column(0x05) $C$DW$1851 .dwtag DW_TAG_member .dwattr $C$DW$1851, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1851, DW_AT_name("rdBufNumPings") .dwattr $C$DW$1851, DW_AT_TI_symbol_name("rdBufNumPings") .dwattr $C$DW$1851, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1851, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1851, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1851, DW_AT_decl_line(0x418) .dwattr $C$DW$1851, DW_AT_decl_column(0x05) $C$DW$1852 .dwtag DW_TAG_member .dwattr $C$DW$1852, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1852, DW_AT_name("direction") .dwattr $C$DW$1852, DW_AT_TI_symbol_name("direction") .dwattr $C$DW$1852, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1852, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1852, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1852, DW_AT_decl_line(0x419) .dwattr $C$DW$1852, DW_AT_decl_column(0x05) $C$DW$1853 .dwtag DW_TAG_member .dwattr $C$DW$1853, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1853, DW_AT_name("reserved") .dwattr $C$DW$1853, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1853, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1853, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1853, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1853, DW_AT_decl_line(0x41a) .dwattr $C$DW$1853, DW_AT_decl_column(0x05) $C$DW$90 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$90, DW_AT_declaration .dwattr $C$DW$90, DW_AT_TI_symbol_name("_ZN15Multiline_ParamaSERKS_") .dwattr $C$DW$90, DW_AT_type(*$C$DW$T$1539) .dwattr $C$DW$90, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1854 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1854, DW_AT_type(*$C$DW$T$1541) .dwendtag $C$DW$90 .dwendtag $C$DW$T$1543 .dwattr $C$DW$T$1543, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1543, DW_AT_decl_line(0x415) .dwattr $C$DW$T$1543, DW_AT_decl_column(0x01) $C$DW$T$1182 .dwtag DW_TAG_typedef, DW_AT_name("Multiline_Param") .dwattr $C$DW$T$1182, DW_AT_type(*$C$DW$T$1543) .dwattr $C$DW$T$1182, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1182, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1182, DW_AT_decl_line(0x41b) .dwattr $C$DW$T$1182, DW_AT_decl_column(0x03) $C$DW$T$1540 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1540, DW_AT_type(*$C$DW$T$1543) $C$DW$T$1541 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1541, DW_AT_type(*$C$DW$T$1540) .dwattr $C$DW$T$1541, DW_AT_address_class(0x20) $C$DW$T$1539 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1539, DW_AT_type(*$C$DW$T$1543) .dwattr $C$DW$T$1539, DW_AT_address_class(0x20) $C$DW$T$1542 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1542, DW_AT_type(*$C$DW$T$1539) .dwattr $C$DW$T$1542, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1855 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1855, DW_AT_type(*$C$DW$T$1541) .dwendtag $C$DW$T$1542 $C$DW$T$173 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$173, DW_AT_name("NTV_Param") .dwattr $C$DW$T$173, DW_AT_byte_size(0x4c0) $C$DW$1856 .dwtag DW_TAG_member .dwattr $C$DW$1856, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1856, DW_AT_name("startRayInFeRd") .dwattr $C$DW$1856, DW_AT_TI_symbol_name("startRayInFeRd") .dwattr $C$DW$1856, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1856, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1856, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1856, DW_AT_decl_line(0x3e9) .dwattr $C$DW$1856, DW_AT_decl_column(0x05) $C$DW$1857 .dwtag DW_TAG_member .dwattr $C$DW$1857, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1857, DW_AT_name("rayIncrement") .dwattr $C$DW$1857, DW_AT_TI_symbol_name("rayIncrement") .dwattr $C$DW$1857, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1857, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1857, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1857, DW_AT_decl_line(0x3ea) .dwattr $C$DW$1857, DW_AT_decl_column(0x05) $C$DW$1858 .dwtag DW_TAG_member .dwattr $C$DW$1858, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1858, DW_AT_name("numMLs") .dwattr $C$DW$1858, DW_AT_TI_symbol_name("numMLs") .dwattr $C$DW$1858, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1858, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1858, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1858, DW_AT_decl_line(0x3eb) .dwattr $C$DW$1858, DW_AT_decl_column(0x05) $C$DW$1859 .dwtag DW_TAG_member .dwattr $C$DW$1859, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1859, DW_AT_name("inpLinesPerFrame") .dwattr $C$DW$1859, DW_AT_TI_symbol_name("inpLinesPerFrame") .dwattr $C$DW$1859, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1859, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1859, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1859, DW_AT_decl_line(0x3ec) .dwattr $C$DW$1859, DW_AT_decl_column(0x05) $C$DW$1860 .dwtag DW_TAG_member .dwattr $C$DW$1860, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1860, DW_AT_name("inpEstimatesPerLine") .dwattr $C$DW$1860, DW_AT_TI_symbol_name("inpEstimatesPerLine") .dwattr $C$DW$1860, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1860, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1860, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1860, DW_AT_decl_line(0x3ed) .dwattr $C$DW$1860, DW_AT_decl_column(0x05) $C$DW$1861 .dwtag DW_TAG_member .dwattr $C$DW$1861, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1861, DW_AT_name("halfDecRateEnable") .dwattr $C$DW$1861, DW_AT_TI_symbol_name("halfDecRateEnable") .dwattr $C$DW$1861, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1861, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1861, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1861, DW_AT_decl_line(0x3ee) .dwattr $C$DW$1861, DW_AT_decl_column(0x05) $C$DW$1862 .dwtag DW_TAG_member .dwattr $C$DW$1862, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$1862, DW_AT_name("persistenceFactor") .dwattr $C$DW$1862, DW_AT_TI_symbol_name("persistenceFactor") .dwattr $C$DW$1862, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1862, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1862, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1862, DW_AT_decl_line(0x3ef) .dwattr $C$DW$1862, DW_AT_decl_column(0x05) $C$DW$1863 .dwtag DW_TAG_member .dwattr $C$DW$1863, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$1863, DW_AT_name("lateralThreshold") .dwattr $C$DW$1863, DW_AT_TI_symbol_name("lateralThreshold") .dwattr $C$DW$1863, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$1863, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1863, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1863, DW_AT_decl_line(0x3f0) .dwattr $C$DW$1863, DW_AT_decl_column(0x05) $C$DW$1864 .dwtag DW_TAG_member .dwattr $C$DW$1864, DW_AT_type(*$C$DW$T$168) .dwattr $C$DW$1864, DW_AT_name("remapTable") .dwattr $C$DW$1864, DW_AT_TI_symbol_name("remapTable") .dwattr $C$DW$1864, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$1864, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1864, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1864, DW_AT_decl_line(0x3f1) .dwattr $C$DW$1864, DW_AT_decl_column(0x05) $C$DW$1865 .dwtag DW_TAG_member .dwattr $C$DW$1865, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1865, DW_AT_name("reserved") .dwattr $C$DW$1865, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1865, DW_AT_data_member_location[DW_OP_plus_uconst 0x440] .dwattr $C$DW$1865, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1865, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1865, DW_AT_decl_line(0x3f3) .dwattr $C$DW$1865, DW_AT_decl_column(0x05) $C$DW$91 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$91, DW_AT_declaration .dwattr $C$DW$91, DW_AT_TI_symbol_name("_ZN9NTV_ParamaSERKS_") .dwattr $C$DW$91, DW_AT_type(*$C$DW$T$169) .dwattr $C$DW$91, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1866 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1866, DW_AT_type(*$C$DW$T$171) .dwendtag $C$DW$91 .dwendtag $C$DW$T$173 .dwattr $C$DW$T$173, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$173, DW_AT_decl_line(0x3e8) .dwattr $C$DW$T$173, DW_AT_decl_column(0x01) $C$DW$T$170 .dwtag DW_TAG_const_type .dwattr $C$DW$T$170, DW_AT_type(*$C$DW$T$173) $C$DW$T$171 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$171, DW_AT_type(*$C$DW$T$170) .dwattr $C$DW$T$171, DW_AT_address_class(0x20) $C$DW$T$356 .dwtag DW_TAG_typedef, DW_AT_name("NTV_Param") .dwattr $C$DW$T$356, DW_AT_type(*$C$DW$T$173) .dwattr $C$DW$T$356, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$356, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$356, DW_AT_decl_line(0x3f4) .dwattr $C$DW$T$356, DW_AT_decl_column(0x03) $C$DW$T$169 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$169, DW_AT_type(*$C$DW$T$173) .dwattr $C$DW$T$169, DW_AT_address_class(0x20) $C$DW$T$172 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$172, DW_AT_type(*$C$DW$T$169) .dwattr $C$DW$T$172, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1867 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1867, DW_AT_type(*$C$DW$T$171) .dwendtag $C$DW$T$172 $C$DW$T$194 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$194, DW_AT_name("NV_Param") .dwattr $C$DW$T$194, DW_AT_byte_size(0x138) $C$DW$1868 .dwtag DW_TAG_member .dwattr $C$DW$1868, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1868, DW_AT_name("startRayInFeRd") .dwattr $C$DW$1868, DW_AT_TI_symbol_name("startRayInFeRd") .dwattr $C$DW$1868, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1868, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1868, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1868, DW_AT_decl_line(0x2cb) .dwattr $C$DW$1868, DW_AT_decl_column(0x05) $C$DW$1869 .dwtag DW_TAG_member .dwattr $C$DW$1869, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1869, DW_AT_name("rayIncrement") .dwattr $C$DW$1869, DW_AT_TI_symbol_name("rayIncrement") .dwattr $C$DW$1869, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1869, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1869, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1869, DW_AT_decl_line(0x2cc) .dwattr $C$DW$1869, DW_AT_decl_column(0x05) $C$DW$1870 .dwtag DW_TAG_member .dwattr $C$DW$1870, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1870, DW_AT_name("numMLs") .dwattr $C$DW$1870, DW_AT_TI_symbol_name("numMLs") .dwattr $C$DW$1870, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1870, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1870, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1870, DW_AT_decl_line(0x2cd) .dwattr $C$DW$1870, DW_AT_decl_column(0x05) $C$DW$1871 .dwtag DW_TAG_member .dwattr $C$DW$1871, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1871, DW_AT_name("inpLinesPerFrame") .dwattr $C$DW$1871, DW_AT_TI_symbol_name("inpLinesPerFrame") .dwattr $C$DW$1871, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1871, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1871, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1871, DW_AT_decl_line(0x2ce) .dwattr $C$DW$1871, DW_AT_decl_column(0x05) $C$DW$1872 .dwtag DW_TAG_member .dwattr $C$DW$1872, DW_AT_type(*$C$DW$T$186) .dwattr $C$DW$1872, DW_AT_name("inpEstimatesPerLine") .dwattr $C$DW$1872, DW_AT_TI_symbol_name("inpEstimatesPerLine") .dwattr $C$DW$1872, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1872, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1872, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1872, DW_AT_decl_line(0x2cf) .dwattr $C$DW$1872, DW_AT_decl_column(0x05) $C$DW$1873 .dwtag DW_TAG_member .dwattr $C$DW$1873, DW_AT_type(*$C$DW$T$187) .dwattr $C$DW$1873, DW_AT_name("steerAngle") .dwattr $C$DW$1873, DW_AT_TI_symbol_name("steerAngle") .dwattr $C$DW$1873, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1873, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1873, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1873, DW_AT_decl_line(0x2d0) .dwattr $C$DW$1873, DW_AT_decl_column(0x05) $C$DW$1874 .dwtag DW_TAG_member .dwattr $C$DW$1874, DW_AT_type(*$C$DW$T$188) .dwattr $C$DW$1874, DW_AT_name("decimation") .dwattr $C$DW$1874, DW_AT_TI_symbol_name("decimation") .dwattr $C$DW$1874, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$1874, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1874, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1874, DW_AT_decl_line(0x2d1) .dwattr $C$DW$1874, DW_AT_decl_column(0x05) $C$DW$1875 .dwtag DW_TAG_member .dwattr $C$DW$1875, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1875, DW_AT_name("score_window") .dwattr $C$DW$1875, DW_AT_TI_symbol_name("score_window") .dwattr $C$DW$1875, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$1875, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1875, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1875, DW_AT_decl_line(0x2d2) .dwattr $C$DW$1875, DW_AT_decl_column(0x05) $C$DW$1876 .dwtag DW_TAG_member .dwattr $C$DW$1876, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1876, DW_AT_name("score_threshold") .dwattr $C$DW$1876, DW_AT_TI_symbol_name("score_threshold") .dwattr $C$DW$1876, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$1876, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1876, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1876, DW_AT_decl_line(0x2d3) .dwattr $C$DW$1876, DW_AT_decl_column(0x05) $C$DW$1877 .dwtag DW_TAG_member .dwattr $C$DW$1877, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1877, DW_AT_name("blend_type") .dwattr $C$DW$1877, DW_AT_TI_symbol_name("blend_type") .dwattr $C$DW$1877, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$1877, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1877, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1877, DW_AT_decl_line(0x2d4) .dwattr $C$DW$1877, DW_AT_decl_column(0x05) $C$DW$1878 .dwtag DW_TAG_member .dwattr $C$DW$1878, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1878, DW_AT_name("mask_half_width") .dwattr $C$DW$1878, DW_AT_TI_symbol_name("mask_half_width") .dwattr $C$DW$1878, DW_AT_data_member_location[DW_OP_plus_uconst 0x68] .dwattr $C$DW$1878, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1878, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1878, DW_AT_decl_line(0x2d5) .dwattr $C$DW$1878, DW_AT_decl_column(0x05) $C$DW$1879 .dwtag DW_TAG_member .dwattr $C$DW$1879, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1879, DW_AT_name("trk_lo_thresh") .dwattr $C$DW$1879, DW_AT_TI_symbol_name("trk_lo_thresh") .dwattr $C$DW$1879, DW_AT_data_member_location[DW_OP_plus_uconst 0x70] .dwattr $C$DW$1879, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1879, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1879, DW_AT_decl_line(0x2d6) .dwattr $C$DW$1879, DW_AT_decl_column(0x05) $C$DW$1880 .dwtag DW_TAG_member .dwattr $C$DW$1880, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1880, DW_AT_name("trk_hi_thresh") .dwattr $C$DW$1880, DW_AT_TI_symbol_name("trk_hi_thresh") .dwattr $C$DW$1880, DW_AT_data_member_location[DW_OP_plus_uconst 0x78] .dwattr $C$DW$1880, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1880, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1880, DW_AT_decl_line(0x2d7) .dwattr $C$DW$1880, DW_AT_decl_column(0x05) $C$DW$1881 .dwtag DW_TAG_member .dwattr $C$DW$1881, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1881, DW_AT_name("det_dec_facX") .dwattr $C$DW$1881, DW_AT_TI_symbol_name("det_dec_facX") .dwattr $C$DW$1881, DW_AT_data_member_location[DW_OP_plus_uconst 0x80] .dwattr $C$DW$1881, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1881, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1881, DW_AT_decl_line(0x2d8) .dwattr $C$DW$1881, DW_AT_decl_column(0x05) $C$DW$1882 .dwtag DW_TAG_member .dwattr $C$DW$1882, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1882, DW_AT_name("det_dec_facY") .dwattr $C$DW$1882, DW_AT_TI_symbol_name("det_dec_facY") .dwattr $C$DW$1882, DW_AT_data_member_location[DW_OP_plus_uconst 0x88] .dwattr $C$DW$1882, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1882, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1882, DW_AT_decl_line(0x2d9) .dwattr $C$DW$1882, DW_AT_decl_column(0x05) $C$DW$1883 .dwtag DW_TAG_member .dwattr $C$DW$1883, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$1883, DW_AT_name("num_NVlooks") .dwattr $C$DW$1883, DW_AT_TI_symbol_name("num_NVlooks") .dwattr $C$DW$1883, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$1883, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1883, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1883, DW_AT_decl_line(0x2da) .dwattr $C$DW$1883, DW_AT_decl_column(0x05) $C$DW$1884 .dwtag DW_TAG_member .dwattr $C$DW$1884, DW_AT_type(*$C$DW$T$189) .dwattr $C$DW$1884, DW_AT_name("nvContextAddrForDebug") .dwattr $C$DW$1884, DW_AT_TI_symbol_name("nvContextAddrForDebug") .dwattr $C$DW$1884, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$1884, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1884, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1884, DW_AT_decl_line(0x2db) .dwattr $C$DW$1884, DW_AT_decl_column(0x05) $C$DW$1885 .dwtag DW_TAG_member .dwattr $C$DW$1885, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1885, DW_AT_name("reserved") .dwattr $C$DW$1885, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1885, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8] .dwattr $C$DW$1885, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1885, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1885, DW_AT_decl_line(0x2dc) .dwattr $C$DW$1885, DW_AT_decl_column(0x05) $C$DW$92 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$92, DW_AT_declaration .dwattr $C$DW$92, DW_AT_TI_symbol_name("_ZN8NV_ParamaSERKS_") .dwattr $C$DW$92, DW_AT_type(*$C$DW$T$190) .dwattr $C$DW$92, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1886 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1886, DW_AT_type(*$C$DW$T$192) .dwendtag $C$DW$92 .dwendtag $C$DW$T$194 .dwattr $C$DW$T$194, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$194, DW_AT_decl_line(0x2ca) .dwattr $C$DW$T$194, DW_AT_decl_column(0x01) $C$DW$T$191 .dwtag DW_TAG_const_type .dwattr $C$DW$T$191, DW_AT_type(*$C$DW$T$194) $C$DW$T$192 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$192, DW_AT_type(*$C$DW$T$191) .dwattr $C$DW$T$192, DW_AT_address_class(0x20) $C$DW$T$1601 .dwtag DW_TAG_typedef, DW_AT_name("NV_Param") .dwattr $C$DW$T$1601, DW_AT_type(*$C$DW$T$194) .dwattr $C$DW$T$1601, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1601, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1601, DW_AT_decl_line(0x2dd) .dwattr $C$DW$T$1601, DW_AT_decl_column(0x03) $C$DW$T$190 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$190, DW_AT_type(*$C$DW$T$194) .dwattr $C$DW$T$190, DW_AT_address_class(0x20) $C$DW$T$193 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$193, DW_AT_type(*$C$DW$T$190) .dwattr $C$DW$T$193, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1887 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1887, DW_AT_type(*$C$DW$T$192) .dwendtag $C$DW$T$193 $C$DW$T$1571 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1571, DW_AT_name("OutputMgrData") .dwattr $C$DW$T$1571, DW_AT_byte_size(0x04) $C$DW$1888 .dwtag DW_TAG_member .dwattr $C$DW$1888, DW_AT_type(*$C$DW$T$510) .dwattr $C$DW$1888, DW_AT_name("spDataType") .dwattr $C$DW$1888, DW_AT_TI_symbol_name("spDataType") .dwattr $C$DW$1888, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1888, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1888, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1888, DW_AT_decl_line(0x45) .dwattr $C$DW$1888, DW_AT_decl_column(0x16) $C$DW$93 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$93, DW_AT_declaration .dwattr $C$DW$93, DW_AT_TI_symbol_name("_ZN13OutputMgrDataaSERKS_") .dwattr $C$DW$93, DW_AT_type(*$C$DW$T$1567) .dwattr $C$DW$93, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1889 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1889, DW_AT_type(*$C$DW$T$1569) .dwendtag $C$DW$93 .dwendtag $C$DW$T$1571 .dwattr $C$DW$T$1571, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1571, DW_AT_decl_line(0x44) .dwattr $C$DW$T$1571, DW_AT_decl_column(0x01) $C$DW$T$1470 .dwtag DW_TAG_typedef, DW_AT_name("OutputMgrData") .dwattr $C$DW$T$1470, DW_AT_type(*$C$DW$T$1571) .dwattr $C$DW$T$1470, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1470, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1470, DW_AT_decl_line(0x46) .dwattr $C$DW$T$1470, DW_AT_decl_column(0x03) $C$DW$T$1568 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1568, DW_AT_type(*$C$DW$T$1571) $C$DW$T$1569 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1569, DW_AT_type(*$C$DW$T$1568) .dwattr $C$DW$T$1569, DW_AT_address_class(0x20) $C$DW$T$1567 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1567, DW_AT_type(*$C$DW$T$1571) .dwattr $C$DW$T$1567, DW_AT_address_class(0x20) $C$DW$T$1570 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1570, DW_AT_type(*$C$DW$T$1567) .dwattr $C$DW$T$1570, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1890 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1890, DW_AT_type(*$C$DW$T$1569) .dwendtag $C$DW$T$1570 $C$DW$T$348 .dwtag DW_TAG_union_type .dwattr $C$DW$T$348, DW_AT_name("Pack64") .dwattr $C$DW$T$348, DW_AT_byte_size(0x08) $C$DW$1891 .dwtag DW_TAG_member .dwattr $C$DW$1891, DW_AT_type(*$C$DW$T$342) .dwattr $C$DW$1891, DW_AT_name("ll") .dwattr $C$DW$1891, DW_AT_TI_symbol_name("ll") .dwattr $C$DW$1891, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1891, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1891, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$1891, DW_AT_decl_line(0x21) .dwattr $C$DW$1891, DW_AT_decl_column(0x0f) $C$DW$1892 .dwtag DW_TAG_member .dwattr $C$DW$1892, DW_AT_type(*$C$DW$T$343) .dwattr $C$DW$1892, DW_AT_name("p16") .dwattr $C$DW$1892, DW_AT_TI_symbol_name("p16") .dwattr $C$DW$1892, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1892, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1892, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$1892, DW_AT_decl_line(0x22) .dwattr $C$DW$1892, DW_AT_decl_column(0x0f) $C$DW$94 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$94, DW_AT_declaration .dwattr $C$DW$94, DW_AT_TI_symbol_name("_ZN6Pack64aSERKS_") .dwattr $C$DW$94, DW_AT_type(*$C$DW$T$344) .dwattr $C$DW$94, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1893 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1893, DW_AT_type(*$C$DW$T$346) .dwendtag $C$DW$94 .dwendtag $C$DW$T$348 .dwattr $C$DW$T$348, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$T$348, DW_AT_decl_line(0x20) .dwattr $C$DW$T$348, DW_AT_decl_column(0x0f) $C$DW$T$345 .dwtag DW_TAG_const_type .dwattr $C$DW$T$345, DW_AT_type(*$C$DW$T$348) $C$DW$T$346 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$346, DW_AT_type(*$C$DW$T$345) .dwattr $C$DW$T$346, DW_AT_address_class(0x20) $C$DW$T$1919 .dwtag DW_TAG_typedef, DW_AT_name("Pack64") .dwattr $C$DW$T$1919, DW_AT_type(*$C$DW$T$348) .dwattr $C$DW$T$1919, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1919, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$T$1919, DW_AT_decl_line(0x23) .dwattr $C$DW$T$1919, DW_AT_decl_column(0x03) $C$DW$T$344 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$344, DW_AT_type(*$C$DW$T$348) .dwattr $C$DW$T$344, DW_AT_address_class(0x20) $C$DW$T$347 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$347, DW_AT_type(*$C$DW$T$344) .dwattr $C$DW$T$347, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1894 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1894, DW_AT_type(*$C$DW$T$346) .dwendtag $C$DW$T$347 $C$DW$T$353 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$353, DW_AT_name("Pack64_16") .dwattr $C$DW$T$353, DW_AT_byte_size(0x08) $C$DW$1895 .dwtag DW_TAG_member .dwattr $C$DW$1895, DW_AT_type(*$C$DW$T$301) .dwattr $C$DW$1895, DW_AT_name("loLsb") .dwattr $C$DW$1895, DW_AT_TI_symbol_name("loLsb") .dwattr $C$DW$1895, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1895, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1895, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$1895, DW_AT_decl_line(0x1a) .dwattr $C$DW$1895, DW_AT_decl_column(0x0b) $C$DW$1896 .dwtag DW_TAG_member .dwattr $C$DW$1896, DW_AT_type(*$C$DW$T$301) .dwattr $C$DW$1896, DW_AT_name("loMsb") .dwattr $C$DW$1896, DW_AT_TI_symbol_name("loMsb") .dwattr $C$DW$1896, DW_AT_data_member_location[DW_OP_plus_uconst 0x2] .dwattr $C$DW$1896, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1896, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$1896, DW_AT_decl_line(0x1b) .dwattr $C$DW$1896, DW_AT_decl_column(0x0b) $C$DW$1897 .dwtag DW_TAG_member .dwattr $C$DW$1897, DW_AT_type(*$C$DW$T$301) .dwattr $C$DW$1897, DW_AT_name("hiLsb") .dwattr $C$DW$1897, DW_AT_TI_symbol_name("hiLsb") .dwattr $C$DW$1897, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1897, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1897, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$1897, DW_AT_decl_line(0x1c) .dwattr $C$DW$1897, DW_AT_decl_column(0x0b) $C$DW$1898 .dwtag DW_TAG_member .dwattr $C$DW$1898, DW_AT_type(*$C$DW$T$301) .dwattr $C$DW$1898, DW_AT_name("hiMsb") .dwattr $C$DW$1898, DW_AT_TI_symbol_name("hiMsb") .dwattr $C$DW$1898, DW_AT_data_member_location[DW_OP_plus_uconst 0x6] .dwattr $C$DW$1898, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1898, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$1898, DW_AT_decl_line(0x1d) .dwattr $C$DW$1898, DW_AT_decl_column(0x0b) $C$DW$95 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$95, DW_AT_declaration .dwattr $C$DW$95, DW_AT_TI_symbol_name("_ZN9Pack64_16aSERKS_") .dwattr $C$DW$95, DW_AT_type(*$C$DW$T$349) .dwattr $C$DW$95, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1899 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1899, DW_AT_type(*$C$DW$T$351) .dwendtag $C$DW$95 .dwendtag $C$DW$T$353 .dwattr $C$DW$T$353, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$T$353, DW_AT_decl_line(0x19) .dwattr $C$DW$T$353, DW_AT_decl_column(0x10) $C$DW$T$343 .dwtag DW_TAG_typedef, DW_AT_name("Pack64_16") .dwattr $C$DW$T$343, DW_AT_type(*$C$DW$T$353) .dwattr $C$DW$T$343, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$343, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be_filter_aniso2d.h") .dwattr $C$DW$T$343, DW_AT_decl_line(0x1e) .dwattr $C$DW$T$343, DW_AT_decl_column(0x03) $C$DW$T$350 .dwtag DW_TAG_const_type .dwattr $C$DW$T$350, DW_AT_type(*$C$DW$T$353) $C$DW$T$351 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$351, DW_AT_type(*$C$DW$T$350) .dwattr $C$DW$T$351, DW_AT_address_class(0x20) $C$DW$T$349 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$349, DW_AT_type(*$C$DW$T$353) .dwattr $C$DW$T$349, DW_AT_address_class(0x20) $C$DW$T$352 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$352, DW_AT_type(*$C$DW$T$349) .dwattr $C$DW$T$352, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1900 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1900, DW_AT_type(*$C$DW$T$351) .dwendtag $C$DW$T$352 $C$DW$T$361 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$361, DW_AT_name("Pai_Param") .dwattr $C$DW$T$361, DW_AT_byte_size(0x548) $C$DW$1901 .dwtag DW_TAG_member .dwattr $C$DW$1901, DW_AT_type(*$C$DW$T$355) .dwattr $C$DW$1901, DW_AT_name("subMode") .dwattr $C$DW$1901, DW_AT_TI_symbol_name("subMode") .dwattr $C$DW$1901, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1901, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1901, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1901, DW_AT_decl_line(0x3f8) .dwattr $C$DW$1901, DW_AT_decl_column(0x05) $C$DW$1902 .dwtag DW_TAG_member .dwattr $C$DW$1902, DW_AT_type(*$C$DW$T$356) .dwattr $C$DW$1902, DW_AT_name("NTVParam") .dwattr $C$DW$1902, DW_AT_TI_symbol_name("NTVParam") .dwattr $C$DW$1902, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1902, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1902, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1902, DW_AT_decl_line(0x3f9) .dwattr $C$DW$1902, DW_AT_decl_column(0x05) $C$DW$1903 .dwtag DW_TAG_member .dwattr $C$DW$1903, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1903, DW_AT_name("reserved") .dwattr $C$DW$1903, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1903, DW_AT_data_member_location[DW_OP_plus_uconst 0x4c8] .dwattr $C$DW$1903, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1903, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1903, DW_AT_decl_line(0x3fb) .dwattr $C$DW$1903, DW_AT_decl_column(0x05) $C$DW$96 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$96, DW_AT_declaration .dwattr $C$DW$96, DW_AT_TI_symbol_name("_ZN9Pai_ParamaSERKS_") .dwattr $C$DW$96, DW_AT_type(*$C$DW$T$357) .dwattr $C$DW$96, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1904 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1904, DW_AT_type(*$C$DW$T$359) .dwendtag $C$DW$96 .dwendtag $C$DW$T$361 .dwattr $C$DW$T$361, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$361, DW_AT_decl_line(0x3f7) .dwattr $C$DW$T$361, DW_AT_decl_column(0x01) $C$DW$T$358 .dwtag DW_TAG_const_type .dwattr $C$DW$T$358, DW_AT_type(*$C$DW$T$361) $C$DW$T$359 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$359, DW_AT_type(*$C$DW$T$358) .dwattr $C$DW$T$359, DW_AT_address_class(0x20) $C$DW$T$1920 .dwtag DW_TAG_typedef, DW_AT_name("Pai_Param") .dwattr $C$DW$T$1920, DW_AT_type(*$C$DW$T$361) .dwattr $C$DW$T$1920, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1920, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1920, DW_AT_decl_line(0x3fc) .dwattr $C$DW$T$1920, DW_AT_decl_column(0x03) $C$DW$T$357 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$357, DW_AT_type(*$C$DW$T$361) .dwattr $C$DW$T$357, DW_AT_address_class(0x20) $C$DW$T$360 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$360, DW_AT_type(*$C$DW$T$357) .dwattr $C$DW$T$360, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1905 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1905, DW_AT_type(*$C$DW$T$359) .dwendtag $C$DW$T$360 $C$DW$T$378 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$378, DW_AT_name("ParamAniso2DAdpFilEmph") .dwattr $C$DW$T$378, DW_AT_byte_size(0x14) $C$DW$1906 .dwtag DW_TAG_member .dwattr $C$DW$1906, DW_AT_type(*$C$DW$T$373) .dwattr $C$DW$1906, DW_AT_name("wghtTblS") .dwattr $C$DW$1906, DW_AT_TI_symbol_name("wghtTblS") .dwattr $C$DW$1906, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1906, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1906, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1906, DW_AT_decl_line(0x421) .dwattr $C$DW$1906, DW_AT_decl_column(0x14) $C$DW$1907 .dwtag DW_TAG_member .dwattr $C$DW$1907, DW_AT_type(*$C$DW$T$373) .dwattr $C$DW$1907, DW_AT_name("emphTbl") .dwattr $C$DW$1907, DW_AT_TI_symbol_name("emphTbl") .dwattr $C$DW$1907, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1907, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1907, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1907, DW_AT_decl_line(0x422) .dwattr $C$DW$1907, DW_AT_decl_column(0x14) $C$DW$1908 .dwtag DW_TAG_member .dwattr $C$DW$1908, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1908, DW_AT_name("alpha") .dwattr $C$DW$1908, DW_AT_TI_symbol_name("alpha") .dwattr $C$DW$1908, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1908, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1908, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1908, DW_AT_decl_line(0x423) .dwattr $C$DW$1908, DW_AT_decl_column(0x14) $C$DW$1909 .dwtag DW_TAG_member .dwattr $C$DW$1909, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1909, DW_AT_name("beta") .dwattr $C$DW$1909, DW_AT_TI_symbol_name("beta") .dwattr $C$DW$1909, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1909, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1909, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1909, DW_AT_decl_line(0x424) .dwattr $C$DW$1909, DW_AT_decl_column(0x14) $C$DW$1910 .dwtag DW_TAG_member .dwattr $C$DW$1910, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1910, DW_AT_name("gamma") .dwattr $C$DW$1910, DW_AT_TI_symbol_name("gamma") .dwattr $C$DW$1910, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1910, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1910, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1910, DW_AT_decl_line(0x425) .dwattr $C$DW$1910, DW_AT_decl_column(0x14) $C$DW$97 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$97, DW_AT_declaration .dwattr $C$DW$97, DW_AT_TI_symbol_name("_ZN22ParamAniso2DAdpFilEmphaSERKS_") .dwattr $C$DW$97, DW_AT_type(*$C$DW$T$374) .dwattr $C$DW$97, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1911 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1911, DW_AT_type(*$C$DW$T$376) .dwendtag $C$DW$97 .dwendtag $C$DW$T$378 .dwattr $C$DW$T$378, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$T$378, DW_AT_decl_line(0x41f) .dwattr $C$DW$T$378, DW_AT_decl_column(0x08) $C$DW$T$375 .dwtag DW_TAG_const_type .dwattr $C$DW$T$375, DW_AT_type(*$C$DW$T$378) $C$DW$T$376 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$376, DW_AT_type(*$C$DW$T$375) .dwattr $C$DW$T$376, DW_AT_address_class(0x20) $C$DW$T$374 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$374, DW_AT_type(*$C$DW$T$378) .dwattr $C$DW$T$374, DW_AT_address_class(0x20) $C$DW$T$377 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$377, DW_AT_type(*$C$DW$T$374) .dwattr $C$DW$T$377, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1912 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1912, DW_AT_type(*$C$DW$T$376) .dwendtag $C$DW$T$377 $C$DW$T$383 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$383, DW_AT_name("ParamBlackSpotFill") .dwattr $C$DW$T$383, DW_AT_byte_size(0x90) $C$DW$1913 .dwtag DW_TAG_member .dwattr $C$DW$1913, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1913, DW_AT_name("gapThres") .dwattr $C$DW$1913, DW_AT_TI_symbol_name("gapThres") .dwattr $C$DW$1913, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1913, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1913, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1913, DW_AT_decl_line(0x3a8) .dwattr $C$DW$1913, DW_AT_decl_column(0x05) $C$DW$1914 .dwtag DW_TAG_member .dwattr $C$DW$1914, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1914, DW_AT_name("fillingLevel") .dwattr $C$DW$1914, DW_AT_TI_symbol_name("fillingLevel") .dwattr $C$DW$1914, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1914, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1914, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1914, DW_AT_decl_line(0x3a9) .dwattr $C$DW$1914, DW_AT_decl_column(0x05) $C$DW$1915 .dwtag DW_TAG_member .dwattr $C$DW$1915, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1915, DW_AT_name("reserved") .dwattr $C$DW$1915, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1915, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1915, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1915, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1915, DW_AT_decl_line(0x3aa) .dwattr $C$DW$1915, DW_AT_decl_column(0x05) $C$DW$98 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$98, DW_AT_declaration .dwattr $C$DW$98, DW_AT_TI_symbol_name("_ZN18ParamBlackSpotFillaSERKS_") .dwattr $C$DW$98, DW_AT_type(*$C$DW$T$379) .dwattr $C$DW$98, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1916 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1916, DW_AT_type(*$C$DW$T$381) .dwendtag $C$DW$98 .dwendtag $C$DW$T$383 .dwattr $C$DW$T$383, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$383, DW_AT_decl_line(0x3a7) .dwattr $C$DW$T$383, DW_AT_decl_column(0x01) $C$DW$T$216 .dwtag DW_TAG_typedef, DW_AT_name("ParamBlackSpotFill") .dwattr $C$DW$T$216, DW_AT_type(*$C$DW$T$383) .dwattr $C$DW$T$216, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$216, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$216, DW_AT_decl_line(0x3ab) .dwattr $C$DW$T$216, DW_AT_decl_column(0x03) $C$DW$T$380 .dwtag DW_TAG_const_type .dwattr $C$DW$T$380, DW_AT_type(*$C$DW$T$383) $C$DW$T$381 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$381, DW_AT_type(*$C$DW$T$380) .dwattr $C$DW$T$381, DW_AT_address_class(0x20) $C$DW$T$379 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$379, DW_AT_type(*$C$DW$T$383) .dwattr $C$DW$T$379, DW_AT_address_class(0x20) $C$DW$T$382 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$382, DW_AT_type(*$C$DW$T$379) .dwattr $C$DW$T$382, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1917 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1917, DW_AT_type(*$C$DW$T$381) .dwendtag $C$DW$T$382 $C$DW$T$392 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$392, DW_AT_name("ParamEdgeDirProc") .dwattr $C$DW$T$392, DW_AT_byte_size(0x14) $C$DW$1918 .dwtag DW_TAG_member .dwattr $C$DW$1918, DW_AT_type(*$C$DW$T$384) .dwattr $C$DW$1918, DW_AT_name("param") .dwattr $C$DW$1918, DW_AT_TI_symbol_name("param") .dwattr $C$DW$1918, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1918, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1918, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1918, DW_AT_decl_line(0x3f) .dwattr $C$DW$1918, DW_AT_decl_column(0x2e) $C$DW$1919 .dwtag DW_TAG_member .dwattr $C$DW$1919, DW_AT_type(*$C$DW$T$385) .dwattr $C$DW$1919, DW_AT_name("paramDetect") .dwattr $C$DW$1919, DW_AT_TI_symbol_name("paramDetect") .dwattr $C$DW$1919, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1919, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1919, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1919, DW_AT_decl_line(0x40) .dwattr $C$DW$1919, DW_AT_decl_column(0x2e) $C$DW$1920 .dwtag DW_TAG_member .dwattr $C$DW$1920, DW_AT_type(*$C$DW$T$386) .dwattr $C$DW$1920, DW_AT_name("context") .dwattr $C$DW$1920, DW_AT_TI_symbol_name("context") .dwattr $C$DW$1920, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1920, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1920, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1920, DW_AT_decl_line(0x41) .dwattr $C$DW$1920, DW_AT_decl_column(0x15) $C$DW$1921 .dwtag DW_TAG_member .dwattr $C$DW$1921, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1921, DW_AT_name("lev") .dwattr $C$DW$1921, DW_AT_TI_symbol_name("lev") .dwattr $C$DW$1921, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1921, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1921, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1921, DW_AT_decl_line(0x42) .dwattr $C$DW$1921, DW_AT_decl_column(0x09) $C$DW$1922 .dwtag DW_TAG_member .dwattr $C$DW$1922, DW_AT_type(*$C$DW$T$387) .dwattr $C$DW$1922, DW_AT_name("be") .dwattr $C$DW$1922, DW_AT_TI_symbol_name("be") .dwattr $C$DW$1922, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1922, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1922, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1922, DW_AT_decl_line(0x43) .dwattr $C$DW$1922, DW_AT_decl_column(0x10) $C$DW$99 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$99, DW_AT_declaration .dwattr $C$DW$99, DW_AT_TI_symbol_name("_ZN16ParamEdgeDirProcaSERKS_") .dwattr $C$DW$99, DW_AT_type(*$C$DW$T$388) .dwattr $C$DW$99, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1923 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1923, DW_AT_type(*$C$DW$T$390) .dwendtag $C$DW$99 .dwendtag $C$DW$T$392 .dwattr $C$DW$T$392, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$392, DW_AT_decl_line(0x3d) .dwattr $C$DW$T$392, DW_AT_decl_column(0x09) $C$DW$T$389 .dwtag DW_TAG_const_type .dwattr $C$DW$T$389, DW_AT_type(*$C$DW$T$392) $C$DW$T$390 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$390, DW_AT_type(*$C$DW$T$389) .dwattr $C$DW$T$390, DW_AT_address_class(0x20) $C$DW$T$388 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$388, DW_AT_type(*$C$DW$T$392) .dwattr $C$DW$T$388, DW_AT_address_class(0x20) $C$DW$T$391 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$391, DW_AT_type(*$C$DW$T$388) .dwattr $C$DW$T$391, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1924 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1924, DW_AT_type(*$C$DW$T$390) .dwendtag $C$DW$T$391 $C$DW$T$398 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$398, DW_AT_name("ParamEdgeEnhance") .dwattr $C$DW$T$398, DW_AT_byte_size(0x90) $C$DW$1925 .dwtag DW_TAG_member .dwattr $C$DW$1925, DW_AT_type(*$C$DW$T$393) .dwattr $C$DW$1925, DW_AT_name("level") .dwattr $C$DW$1925, DW_AT_TI_symbol_name("level") .dwattr $C$DW$1925, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1925, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1925, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1925, DW_AT_decl_line(0x39a) .dwattr $C$DW$1925, DW_AT_decl_column(0x05) $C$DW$1926 .dwtag DW_TAG_member .dwattr $C$DW$1926, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1926, DW_AT_name("reserved") .dwattr $C$DW$1926, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1926, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1926, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1926, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1926, DW_AT_decl_line(0x39b) .dwattr $C$DW$1926, DW_AT_decl_column(0x05) $C$DW$100 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$100, DW_AT_declaration .dwattr $C$DW$100, DW_AT_TI_symbol_name("_ZN16ParamEdgeEnhanceaSERKS_") .dwattr $C$DW$100, DW_AT_type(*$C$DW$T$394) .dwattr $C$DW$100, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1927 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1927, DW_AT_type(*$C$DW$T$396) .dwendtag $C$DW$100 .dwendtag $C$DW$T$398 .dwattr $C$DW$T$398, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$398, DW_AT_decl_line(0x399) .dwattr $C$DW$T$398, DW_AT_decl_column(0x01) $C$DW$T$214 .dwtag DW_TAG_typedef, DW_AT_name("ParamEdgeEnhance") .dwattr $C$DW$T$214, DW_AT_type(*$C$DW$T$398) .dwattr $C$DW$T$214, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$214, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$214, DW_AT_decl_line(0x39c) .dwattr $C$DW$T$214, DW_AT_decl_column(0x03) $C$DW$T$395 .dwtag DW_TAG_const_type .dwattr $C$DW$T$395, DW_AT_type(*$C$DW$T$398) $C$DW$T$396 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$396, DW_AT_type(*$C$DW$T$395) .dwattr $C$DW$T$396, DW_AT_address_class(0x20) $C$DW$T$394 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$394, DW_AT_type(*$C$DW$T$398) .dwattr $C$DW$T$394, DW_AT_address_class(0x20) $C$DW$T$397 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$397, DW_AT_type(*$C$DW$T$394) .dwattr $C$DW$T$397, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1928 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1928, DW_AT_type(*$C$DW$T$396) .dwendtag $C$DW$T$397 $C$DW$T$404 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$404, DW_AT_name("ParamEdgeReliabilityNorm") .dwattr $C$DW$T$404, DW_AT_byte_size(0x10) $C$DW$1929 .dwtag DW_TAG_member .dwattr $C$DW$1929, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1929, DW_AT_name("inRange") .dwattr $C$DW$1929, DW_AT_TI_symbol_name("inRange") .dwattr $C$DW$1929, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1929, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1929, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1929, DW_AT_decl_line(0x15f) .dwattr $C$DW$1929, DW_AT_decl_column(0x0c) $C$DW$1930 .dwtag DW_TAG_member .dwattr $C$DW$1930, DW_AT_type(*$C$DW$T$399) .dwattr $C$DW$1930, DW_AT_name("top") .dwattr $C$DW$1930, DW_AT_TI_symbol_name("top") .dwattr $C$DW$1930, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1930, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1930, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1930, DW_AT_decl_line(0x160) .dwattr $C$DW$1930, DW_AT_decl_column(0x0c) $C$DW$1931 .dwtag DW_TAG_member .dwattr $C$DW$1931, DW_AT_type(*$C$DW$T$399) .dwattr $C$DW$1931, DW_AT_name("botom") .dwattr $C$DW$1931, DW_AT_TI_symbol_name("botom") .dwattr $C$DW$1931, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1931, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1931, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1931, DW_AT_decl_line(0x161) .dwattr $C$DW$1931, DW_AT_decl_column(0x0c) $C$DW$1932 .dwtag DW_TAG_member .dwattr $C$DW$1932, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1932, DW_AT_name("levelNum") .dwattr $C$DW$1932, DW_AT_TI_symbol_name("levelNum") .dwattr $C$DW$1932, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1932, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1932, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1932, DW_AT_decl_line(0x162) .dwattr $C$DW$1932, DW_AT_decl_column(0x0c) $C$DW$101 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$101, DW_AT_declaration .dwattr $C$DW$101, DW_AT_TI_symbol_name("_ZN24ParamEdgeReliabilityNormaSERKS_") .dwattr $C$DW$101, DW_AT_type(*$C$DW$T$400) .dwattr $C$DW$101, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1933 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1933, DW_AT_type(*$C$DW$T$402) .dwendtag $C$DW$101 .dwendtag $C$DW$T$404 .dwattr $C$DW$T$404, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$404, DW_AT_decl_line(0x15d) .dwattr $C$DW$T$404, DW_AT_decl_column(0x09) $C$DW$T$401 .dwtag DW_TAG_const_type .dwattr $C$DW$T$401, DW_AT_type(*$C$DW$T$404) $C$DW$T$402 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$402, DW_AT_type(*$C$DW$T$401) .dwattr $C$DW$T$402, DW_AT_address_class(0x20) $C$DW$T$400 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$400, DW_AT_type(*$C$DW$T$404) .dwattr $C$DW$T$400, DW_AT_address_class(0x20) $C$DW$T$403 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$403, DW_AT_type(*$C$DW$T$400) .dwattr $C$DW$T$403, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1934 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1934, DW_AT_type(*$C$DW$T$402) .dwendtag $C$DW$T$403 $C$DW$T$409 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$409, DW_AT_name("ParamEdgeThreshold") .dwattr $C$DW$T$409, DW_AT_byte_size(0xa0) $C$DW$1935 .dwtag DW_TAG_member .dwattr $C$DW$1935, DW_AT_type(*$C$DW$T$393) .dwattr $C$DW$1935, DW_AT_name("level") .dwattr $C$DW$1935, DW_AT_TI_symbol_name("level") .dwattr $C$DW$1935, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1935, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1935, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1935, DW_AT_decl_line(0x3b6) .dwattr $C$DW$1935, DW_AT_decl_column(0x05) $C$DW$1936 .dwtag DW_TAG_member .dwattr $C$DW$1936, DW_AT_type(*$C$DW$T$393) .dwattr $C$DW$1936, DW_AT_name("width") .dwattr $C$DW$1936, DW_AT_TI_symbol_name("width") .dwattr $C$DW$1936, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1936, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1936, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1936, DW_AT_decl_line(0x3b7) .dwattr $C$DW$1936, DW_AT_decl_column(0x05) $C$DW$1937 .dwtag DW_TAG_member .dwattr $C$DW$1937, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1937, DW_AT_name("reserved") .dwattr $C$DW$1937, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1937, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1937, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1937, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1937, DW_AT_decl_line(0x3b8) .dwattr $C$DW$1937, DW_AT_decl_column(0x05) $C$DW$102 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$102, DW_AT_declaration .dwattr $C$DW$102, DW_AT_TI_symbol_name("_ZN18ParamEdgeThresholdaSERKS_") .dwattr $C$DW$102, DW_AT_type(*$C$DW$T$405) .dwattr $C$DW$102, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1938 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1938, DW_AT_type(*$C$DW$T$407) .dwendtag $C$DW$102 .dwendtag $C$DW$T$409 .dwattr $C$DW$T$409, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$409, DW_AT_decl_line(0x3b5) .dwattr $C$DW$T$409, DW_AT_decl_column(0x01) $C$DW$T$218 .dwtag DW_TAG_typedef, DW_AT_name("ParamEdgeThreshold") .dwattr $C$DW$T$218, DW_AT_type(*$C$DW$T$409) .dwattr $C$DW$T$218, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$218, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$218, DW_AT_decl_line(0x3b9) .dwattr $C$DW$T$218, DW_AT_decl_column(0x03) $C$DW$T$406 .dwtag DW_TAG_const_type .dwattr $C$DW$T$406, DW_AT_type(*$C$DW$T$409) $C$DW$T$407 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$407, DW_AT_type(*$C$DW$T$406) .dwattr $C$DW$T$407, DW_AT_address_class(0x20) $C$DW$T$405 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$405, DW_AT_type(*$C$DW$T$409) .dwattr $C$DW$T$405, DW_AT_address_class(0x20) $C$DW$T$408 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$408, DW_AT_type(*$C$DW$T$405) .dwattr $C$DW$T$408, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1939 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1939, DW_AT_type(*$C$DW$T$407) .dwendtag $C$DW$T$408 $C$DW$T$414 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$414, DW_AT_name("ParamFTCProc") .dwattr $C$DW$T$414, DW_AT_byte_size(0x20) $C$DW$1940 .dwtag DW_TAG_member .dwattr $C$DW$1940, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1940, DW_AT_name("delay") .dwattr $C$DW$1940, DW_AT_TI_symbol_name("delay") .dwattr $C$DW$1940, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1940, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1940, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1940, DW_AT_decl_line(0xde) .dwattr $C$DW$1940, DW_AT_decl_column(0x15) $C$DW$1941 .dwtag DW_TAG_member .dwattr $C$DW$1941, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1941, DW_AT_name("offset") .dwattr $C$DW$1941, DW_AT_TI_symbol_name("offset") .dwattr $C$DW$1941, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1941, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1941, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1941, DW_AT_decl_line(0xdf) .dwattr $C$DW$1941, DW_AT_decl_column(0x15) $C$DW$1942 .dwtag DW_TAG_member .dwattr $C$DW$1942, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1942, DW_AT_name("alphaS") .dwattr $C$DW$1942, DW_AT_TI_symbol_name("alphaS") .dwattr $C$DW$1942, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1942, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1942, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1942, DW_AT_decl_line(0xe0) .dwattr $C$DW$1942, DW_AT_decl_column(0x15) $C$DW$1943 .dwtag DW_TAG_member .dwattr $C$DW$1943, DW_AT_type(*$C$DW$T$16) .dwattr $C$DW$1943, DW_AT_name("alphaE") .dwattr $C$DW$1943, DW_AT_TI_symbol_name("alphaE") .dwattr $C$DW$1943, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1943, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1943, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1943, DW_AT_decl_line(0xe1) .dwattr $C$DW$1943, DW_AT_decl_column(0x15) $C$DW$1944 .dwtag DW_TAG_member .dwattr $C$DW$1944, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1944, DW_AT_name("thS") .dwattr $C$DW$1944, DW_AT_TI_symbol_name("thS") .dwattr $C$DW$1944, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1944, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1944, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1944, DW_AT_decl_line(0xe2) .dwattr $C$DW$1944, DW_AT_decl_column(0x15) $C$DW$1945 .dwtag DW_TAG_member .dwattr $C$DW$1945, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1945, DW_AT_name("thE") .dwattr $C$DW$1945, DW_AT_TI_symbol_name("thE") .dwattr $C$DW$1945, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1945, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1945, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1945, DW_AT_decl_line(0xe3) .dwattr $C$DW$1945, DW_AT_decl_column(0x15) $C$DW$1946 .dwtag DW_TAG_member .dwattr $C$DW$1946, DW_AT_type(*$C$DW$T$373) .dwattr $C$DW$1946, DW_AT_name("Tbl2") .dwattr $C$DW$1946, DW_AT_TI_symbol_name("Tbl2") .dwattr $C$DW$1946, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1946, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1946, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1946, DW_AT_decl_line(0xe4) .dwattr $C$DW$1946, DW_AT_decl_column(0x15) $C$DW$1947 .dwtag DW_TAG_member .dwattr $C$DW$1947, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1947, DW_AT_name("accuracyBits") .dwattr $C$DW$1947, DW_AT_TI_symbol_name("accuracyBits") .dwattr $C$DW$1947, DW_AT_data_member_location[DW_OP_plus_uconst 0x1c] .dwattr $C$DW$1947, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1947, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$1947, DW_AT_decl_line(0xe5) .dwattr $C$DW$1947, DW_AT_decl_column(0x15) $C$DW$103 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$103, DW_AT_declaration .dwattr $C$DW$103, DW_AT_TI_symbol_name("_ZN12ParamFTCProcaSERKS_") .dwattr $C$DW$103, DW_AT_type(*$C$DW$T$410) .dwattr $C$DW$103, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1948 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1948, DW_AT_type(*$C$DW$T$412) .dwendtag $C$DW$103 .dwendtag $C$DW$T$414 .dwattr $C$DW$T$414, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/BMode/ClearVisualization/ImageProcess/ImageProcessBe/include/image_process_be.h") .dwattr $C$DW$T$414, DW_AT_decl_line(0xdc) .dwattr $C$DW$T$414, DW_AT_decl_column(0x08) $C$DW$T$411 .dwtag DW_TAG_const_type .dwattr $C$DW$T$411, DW_AT_type(*$C$DW$T$414) $C$DW$T$412 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$412, DW_AT_type(*$C$DW$T$411) .dwattr $C$DW$T$412, DW_AT_address_class(0x20) $C$DW$T$410 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$410, DW_AT_type(*$C$DW$T$414) .dwattr $C$DW$T$410, DW_AT_address_class(0x20) $C$DW$T$413 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$413, DW_AT_type(*$C$DW$T$410) .dwattr $C$DW$T$413, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1949 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1949, DW_AT_type(*$C$DW$T$412) .dwendtag $C$DW$T$413 $C$DW$T$423 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$423, DW_AT_name("ParamGaussianProc") .dwattr $C$DW$T$423, DW_AT_byte_size(0x14) $C$DW$1950 .dwtag DW_TAG_member .dwattr $C$DW$1950, DW_AT_type(*$C$DW$T$416) .dwattr $C$DW$1950, DW_AT_name("in") .dwattr $C$DW$1950, DW_AT_TI_symbol_name("in") .dwattr $C$DW$1950, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1950, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1950, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1950, DW_AT_decl_line(0x153) .dwattr $C$DW$1950, DW_AT_decl_column(0x0d) $C$DW$1951 .dwtag DW_TAG_member .dwattr $C$DW$1951, DW_AT_type(*$C$DW$T$417) .dwattr $C$DW$1951, DW_AT_name("info") .dwattr $C$DW$1951, DW_AT_TI_symbol_name("info") .dwattr $C$DW$1951, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1951, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1951, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1951, DW_AT_decl_line(0x154) .dwattr $C$DW$1951, DW_AT_decl_column(0x10) $C$DW$1952 .dwtag DW_TAG_member .dwattr $C$DW$1952, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1952, DW_AT_name("level") .dwattr $C$DW$1952, DW_AT_TI_symbol_name("level") .dwattr $C$DW$1952, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1952, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1952, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1952, DW_AT_decl_line(0x155) .dwattr $C$DW$1952, DW_AT_decl_column(0x09) $C$DW$1953 .dwtag DW_TAG_member .dwattr $C$DW$1953, DW_AT_type(*$C$DW$T$418) .dwattr $C$DW$1953, DW_AT_name("filterGauss") .dwattr $C$DW$1953, DW_AT_TI_symbol_name("filterGauss") .dwattr $C$DW$1953, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1953, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1953, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1953, DW_AT_decl_line(0x156) .dwattr $C$DW$1953, DW_AT_decl_column(0x13) $C$DW$1954 .dwtag DW_TAG_member .dwattr $C$DW$1954, DW_AT_type(*$C$DW$T$3) .dwattr $C$DW$1954, DW_AT_name("workA") .dwattr $C$DW$1954, DW_AT_TI_symbol_name("workA") .dwattr $C$DW$1954, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1954, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1954, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1954, DW_AT_decl_line(0x157) .dwattr $C$DW$1954, DW_AT_decl_column(0x0b) $C$DW$104 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$104, DW_AT_declaration .dwattr $C$DW$104, DW_AT_TI_symbol_name("_ZN17ParamGaussianProcaSERKS_") .dwattr $C$DW$104, DW_AT_type(*$C$DW$T$419) .dwattr $C$DW$104, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1955 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1955, DW_AT_type(*$C$DW$T$421) .dwendtag $C$DW$104 .dwendtag $C$DW$T$423 .dwattr $C$DW$T$423, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$423, DW_AT_decl_line(0x151) .dwattr $C$DW$T$423, DW_AT_decl_column(0x08) $C$DW$T$420 .dwtag DW_TAG_const_type .dwattr $C$DW$T$420, DW_AT_type(*$C$DW$T$423) $C$DW$T$421 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$421, DW_AT_type(*$C$DW$T$420) .dwattr $C$DW$T$421, DW_AT_address_class(0x20) $C$DW$T$419 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$419, DW_AT_type(*$C$DW$T$423) .dwattr $C$DW$T$419, DW_AT_address_class(0x20) $C$DW$T$422 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$422, DW_AT_type(*$C$DW$T$419) .dwattr $C$DW$T$422, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1956 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1956, DW_AT_type(*$C$DW$T$421) .dwendtag $C$DW$T$422 $C$DW$T$428 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$428, DW_AT_name("ParamHContrast") .dwattr $C$DW$T$428, DW_AT_byte_size(0xa0) $C$DW$1957 .dwtag DW_TAG_member .dwattr $C$DW$1957, DW_AT_type(*$C$DW$T$393) .dwattr $C$DW$1957, DW_AT_name("thLevel") .dwattr $C$DW$1957, DW_AT_TI_symbol_name("thLevel") .dwattr $C$DW$1957, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1957, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1957, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1957, DW_AT_decl_line(0x3bd) .dwattr $C$DW$1957, DW_AT_decl_column(0x05) $C$DW$1958 .dwtag DW_TAG_member .dwattr $C$DW$1958, DW_AT_type(*$C$DW$T$393) .dwattr $C$DW$1958, DW_AT_name("suppressionLevel") .dwattr $C$DW$1958, DW_AT_TI_symbol_name("suppressionLevel") .dwattr $C$DW$1958, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1958, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1958, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1958, DW_AT_decl_line(0x3be) .dwattr $C$DW$1958, DW_AT_decl_column(0x05) $C$DW$1959 .dwtag DW_TAG_member .dwattr $C$DW$1959, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1959, DW_AT_name("reserved") .dwattr $C$DW$1959, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1959, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1959, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1959, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1959, DW_AT_decl_line(0x3bf) .dwattr $C$DW$1959, DW_AT_decl_column(0x05) $C$DW$105 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$105, DW_AT_declaration .dwattr $C$DW$105, DW_AT_TI_symbol_name("_ZN14ParamHContrastaSERKS_") .dwattr $C$DW$105, DW_AT_type(*$C$DW$T$424) .dwattr $C$DW$105, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1960 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1960, DW_AT_type(*$C$DW$T$426) .dwendtag $C$DW$105 .dwendtag $C$DW$T$428 .dwattr $C$DW$T$428, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$428, DW_AT_decl_line(0x3bc) .dwattr $C$DW$T$428, DW_AT_decl_column(0x01) $C$DW$T$219 .dwtag DW_TAG_typedef, DW_AT_name("ParamHContrast") .dwattr $C$DW$T$219, DW_AT_type(*$C$DW$T$428) .dwattr $C$DW$T$219, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$219, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$219, DW_AT_decl_line(0x3c0) .dwattr $C$DW$T$219, DW_AT_decl_column(0x03) $C$DW$T$425 .dwtag DW_TAG_const_type .dwattr $C$DW$T$425, DW_AT_type(*$C$DW$T$428) $C$DW$T$426 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$426, DW_AT_type(*$C$DW$T$425) .dwattr $C$DW$T$426, DW_AT_address_class(0x20) $C$DW$T$424 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$424, DW_AT_type(*$C$DW$T$428) .dwattr $C$DW$T$424, DW_AT_address_class(0x20) $C$DW$T$427 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$427, DW_AT_type(*$C$DW$T$424) .dwattr $C$DW$T$427, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1961 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1961, DW_AT_type(*$C$DW$T$426) .dwendtag $C$DW$T$427 $C$DW$T$433 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$433, DW_AT_name("ParamLineThinning") .dwattr $C$DW$T$433, DW_AT_byte_size(0x90) $C$DW$1962 .dwtag DW_TAG_member .dwattr $C$DW$1962, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1962, DW_AT_name("tissueVariationThres") .dwattr $C$DW$1962, DW_AT_TI_symbol_name("tissueVariationThres") .dwattr $C$DW$1962, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1962, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1962, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1962, DW_AT_decl_line(0x3af) .dwattr $C$DW$1962, DW_AT_decl_column(0x05) $C$DW$1963 .dwtag DW_TAG_member .dwattr $C$DW$1963, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1963, DW_AT_name("thinningLevel") .dwattr $C$DW$1963, DW_AT_TI_symbol_name("thinningLevel") .dwattr $C$DW$1963, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1963, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1963, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1963, DW_AT_decl_line(0x3b0) .dwattr $C$DW$1963, DW_AT_decl_column(0x05) $C$DW$1964 .dwtag DW_TAG_member .dwattr $C$DW$1964, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1964, DW_AT_name("reserved") .dwattr $C$DW$1964, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1964, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1964, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1964, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1964, DW_AT_decl_line(0x3b1) .dwattr $C$DW$1964, DW_AT_decl_column(0x05) $C$DW$106 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$106, DW_AT_declaration .dwattr $C$DW$106, DW_AT_TI_symbol_name("_ZN17ParamLineThinningaSERKS_") .dwattr $C$DW$106, DW_AT_type(*$C$DW$T$429) .dwattr $C$DW$106, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1965 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1965, DW_AT_type(*$C$DW$T$431) .dwendtag $C$DW$106 .dwendtag $C$DW$T$433 .dwattr $C$DW$T$433, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$433, DW_AT_decl_line(0x3ae) .dwattr $C$DW$T$433, DW_AT_decl_column(0x01) $C$DW$T$217 .dwtag DW_TAG_typedef, DW_AT_name("ParamLineThinning") .dwattr $C$DW$T$217, DW_AT_type(*$C$DW$T$433) .dwattr $C$DW$T$217, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$217, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$217, DW_AT_decl_line(0x3b2) .dwattr $C$DW$T$217, DW_AT_decl_column(0x03) $C$DW$T$430 .dwtag DW_TAG_const_type .dwattr $C$DW$T$430, DW_AT_type(*$C$DW$T$433) $C$DW$T$431 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$431, DW_AT_type(*$C$DW$T$430) .dwattr $C$DW$T$431, DW_AT_address_class(0x20) $C$DW$T$429 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$429, DW_AT_type(*$C$DW$T$433) .dwattr $C$DW$T$429, DW_AT_address_class(0x20) $C$DW$T$432 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$432, DW_AT_type(*$C$DW$T$429) .dwattr $C$DW$T$432, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1966 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1966, DW_AT_type(*$C$DW$T$431) .dwendtag $C$DW$T$432 $C$DW$T$438 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$438, DW_AT_name("ParamSharpness") .dwattr $C$DW$T$438, DW_AT_byte_size(0x98) $C$DW$1967 .dwtag DW_TAG_member .dwattr $C$DW$1967, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1967, DW_AT_name("levelLow") .dwattr $C$DW$1967, DW_AT_TI_symbol_name("levelLow") .dwattr $C$DW$1967, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1967, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1967, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1967, DW_AT_decl_line(0x3a0) .dwattr $C$DW$1967, DW_AT_decl_column(0x05) $C$DW$1968 .dwtag DW_TAG_member .dwattr $C$DW$1968, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1968, DW_AT_name("levelHigh") .dwattr $C$DW$1968, DW_AT_TI_symbol_name("levelHigh") .dwattr $C$DW$1968, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1968, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1968, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1968, DW_AT_decl_line(0x3a1) .dwattr $C$DW$1968, DW_AT_decl_column(0x05) $C$DW$1969 .dwtag DW_TAG_member .dwattr $C$DW$1969, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1969, DW_AT_name("type") .dwattr $C$DW$1969, DW_AT_TI_symbol_name("type") .dwattr $C$DW$1969, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1969, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1969, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1969, DW_AT_decl_line(0x3a2) .dwattr $C$DW$1969, DW_AT_decl_column(0x05) $C$DW$1970 .dwtag DW_TAG_member .dwattr $C$DW$1970, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1970, DW_AT_name("reserved") .dwattr $C$DW$1970, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1970, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1970, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1970, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1970, DW_AT_decl_line(0x3a3) .dwattr $C$DW$1970, DW_AT_decl_column(0x05) $C$DW$107 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$107, DW_AT_declaration .dwattr $C$DW$107, DW_AT_TI_symbol_name("_ZN14ParamSharpnessaSERKS_") .dwattr $C$DW$107, DW_AT_type(*$C$DW$T$434) .dwattr $C$DW$107, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1971 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1971, DW_AT_type(*$C$DW$T$436) .dwendtag $C$DW$107 .dwendtag $C$DW$T$438 .dwattr $C$DW$T$438, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$438, DW_AT_decl_line(0x39f) .dwattr $C$DW$T$438, DW_AT_decl_column(0x01) $C$DW$T$215 .dwtag DW_TAG_typedef, DW_AT_name("ParamSharpness") .dwattr $C$DW$T$215, DW_AT_type(*$C$DW$T$438) .dwattr $C$DW$T$215, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$215, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$215, DW_AT_decl_line(0x3a4) .dwattr $C$DW$T$215, DW_AT_decl_column(0x03) $C$DW$T$435 .dwtag DW_TAG_const_type .dwattr $C$DW$T$435, DW_AT_type(*$C$DW$T$438) $C$DW$T$436 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$436, DW_AT_type(*$C$DW$T$435) .dwattr $C$DW$T$436, DW_AT_address_class(0x20) $C$DW$T$434 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$434, DW_AT_type(*$C$DW$T$438) .dwattr $C$DW$T$434, DW_AT_address_class(0x20) $C$DW$T$437 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$437, DW_AT_type(*$C$DW$T$434) .dwattr $C$DW$T$437, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1972 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1972, DW_AT_type(*$C$DW$T$436) .dwendtag $C$DW$T$437 $C$DW$T$443 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$443, DW_AT_name("ParamSpeckleReduction") .dwattr $C$DW$T$443, DW_AT_byte_size(0x88) $C$DW$1973 .dwtag DW_TAG_member .dwattr $C$DW$1973, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1973, DW_AT_name("level") .dwattr $C$DW$1973, DW_AT_TI_symbol_name("level") .dwattr $C$DW$1973, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1973, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1973, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1973, DW_AT_decl_line(0x394) .dwattr $C$DW$1973, DW_AT_decl_column(0x05) $C$DW$1974 .dwtag DW_TAG_member .dwattr $C$DW$1974, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1974, DW_AT_name("reserved") .dwattr $C$DW$1974, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1974, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1974, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1974, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1974, DW_AT_decl_line(0x395) .dwattr $C$DW$1974, DW_AT_decl_column(0x05) $C$DW$108 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$108, DW_AT_declaration .dwattr $C$DW$108, DW_AT_TI_symbol_name("_ZN21ParamSpeckleReductionaSERKS_") .dwattr $C$DW$108, DW_AT_type(*$C$DW$T$439) .dwattr $C$DW$108, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1975 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1975, DW_AT_type(*$C$DW$T$441) .dwendtag $C$DW$108 .dwendtag $C$DW$T$443 .dwattr $C$DW$T$443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$443, DW_AT_decl_line(0x393) .dwattr $C$DW$T$443, DW_AT_decl_column(0x01) $C$DW$T$213 .dwtag DW_TAG_typedef, DW_AT_name("ParamSpeckleReduction") .dwattr $C$DW$T$213, DW_AT_type(*$C$DW$T$443) .dwattr $C$DW$T$213, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$213, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$213, DW_AT_decl_line(0x396) .dwattr $C$DW$T$213, DW_AT_decl_column(0x03) $C$DW$T$440 .dwtag DW_TAG_const_type .dwattr $C$DW$T$440, DW_AT_type(*$C$DW$T$443) $C$DW$T$441 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$441, DW_AT_type(*$C$DW$T$440) .dwattr $C$DW$T$441, DW_AT_address_class(0x20) $C$DW$T$439 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$439, DW_AT_type(*$C$DW$T$443) .dwattr $C$DW$T$439, DW_AT_address_class(0x20) $C$DW$T$442 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$442, DW_AT_type(*$C$DW$T$439) .dwattr $C$DW$T$442, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1976 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1976, DW_AT_type(*$C$DW$T$441) .dwendtag $C$DW$T$442 $C$DW$T$449 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$449, DW_AT_name("ParamUnSharpProc") .dwattr $C$DW$T$449, DW_AT_byte_size(0x1c) $C$DW$1977 .dwtag DW_TAG_member .dwattr $C$DW$1977, DW_AT_type(*$C$DW$T$416) .dwattr $C$DW$1977, DW_AT_name("outHif") .dwattr $C$DW$1977, DW_AT_TI_symbol_name("outHif") .dwattr $C$DW$1977, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1977, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1977, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1977, DW_AT_decl_line(0x167) .dwattr $C$DW$1977, DW_AT_decl_column(0x0e) $C$DW$1978 .dwtag DW_TAG_member .dwattr $C$DW$1978, DW_AT_type(*$C$DW$T$417) .dwattr $C$DW$1978, DW_AT_name("info") .dwattr $C$DW$1978, DW_AT_TI_symbol_name("info") .dwattr $C$DW$1978, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1978, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1978, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1978, DW_AT_decl_line(0x168) .dwattr $C$DW$1978, DW_AT_decl_column(0x10) $C$DW$1979 .dwtag DW_TAG_member .dwattr $C$DW$1979, DW_AT_type(*$C$DW$T$10) .dwattr $C$DW$1979, DW_AT_name("level") .dwattr $C$DW$1979, DW_AT_TI_symbol_name("level") .dwattr $C$DW$1979, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1979, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1979, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1979, DW_AT_decl_line(0x169) .dwattr $C$DW$1979, DW_AT_decl_column(0x09) $C$DW$1980 .dwtag DW_TAG_member .dwattr $C$DW$1980, DW_AT_type(*$C$DW$T$418) .dwattr $C$DW$1980, DW_AT_name("filter") .dwattr $C$DW$1980, DW_AT_TI_symbol_name("filter") .dwattr $C$DW$1980, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1980, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1980, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1980, DW_AT_decl_line(0x16a) .dwattr $C$DW$1980, DW_AT_decl_column(0x13) $C$DW$1981 .dwtag DW_TAG_member .dwattr $C$DW$1981, DW_AT_type(*$C$DW$T$444) .dwattr $C$DW$1981, DW_AT_name("emphasis1") .dwattr $C$DW$1981, DW_AT_TI_symbol_name("emphasis1") .dwattr $C$DW$1981, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1981, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1981, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1981, DW_AT_decl_line(0x16b) .dwattr $C$DW$1981, DW_AT_decl_column(0x13) $C$DW$1982 .dwtag DW_TAG_member .dwattr $C$DW$1982, DW_AT_type(*$C$DW$T$3) .dwattr $C$DW$1982, DW_AT_name("workA") .dwattr $C$DW$1982, DW_AT_TI_symbol_name("workA") .dwattr $C$DW$1982, DW_AT_data_member_location[DW_OP_plus_uconst 0x14] .dwattr $C$DW$1982, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1982, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1982, DW_AT_decl_line(0x16c) .dwattr $C$DW$1982, DW_AT_decl_column(0x0b) $C$DW$1983 .dwtag DW_TAG_member .dwattr $C$DW$1983, DW_AT_type(*$C$DW$T$3) .dwattr $C$DW$1983, DW_AT_name("workB") .dwattr $C$DW$1983, DW_AT_TI_symbol_name("workB") .dwattr $C$DW$1983, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1983, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1983, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$1983, DW_AT_decl_line(0x16d) .dwattr $C$DW$1983, DW_AT_decl_column(0x0b) $C$DW$109 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$109, DW_AT_declaration .dwattr $C$DW$109, DW_AT_TI_symbol_name("_ZN16ParamUnSharpProcaSERKS_") .dwattr $C$DW$109, DW_AT_type(*$C$DW$T$445) .dwattr $C$DW$109, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1984 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1984, DW_AT_type(*$C$DW$T$447) .dwendtag $C$DW$109 .dwendtag $C$DW$T$449 .dwattr $C$DW$T$449, DW_AT_decl_file("C:\git\phx_main_1\DevProjects\App\BMode\ClearVisualization\ImageProcess\ImageProcessBe\include\image_process_be_main.h") .dwattr $C$DW$T$449, DW_AT_decl_line(0x165) .dwattr $C$DW$T$449, DW_AT_decl_column(0x08) $C$DW$T$446 .dwtag DW_TAG_const_type .dwattr $C$DW$T$446, DW_AT_type(*$C$DW$T$449) $C$DW$T$447 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$447, DW_AT_type(*$C$DW$T$446) .dwattr $C$DW$T$447, DW_AT_address_class(0x20) $C$DW$T$445 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$445, DW_AT_type(*$C$DW$T$449) .dwattr $C$DW$T$445, DW_AT_address_class(0x20) $C$DW$T$448 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$448, DW_AT_type(*$C$DW$T$445) .dwattr $C$DW$T$448, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1985 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1985, DW_AT_type(*$C$DW$T$447) .dwendtag $C$DW$T$448 $C$DW$T$461 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$461, DW_AT_name("ParamUpdateMsg") .dwattr $C$DW$T$461, DW_AT_byte_size(0x14) $C$DW$1986 .dwtag DW_TAG_member .dwattr $C$DW$1986, DW_AT_type(*$C$DW$T$451) .dwattr $C$DW$1986, DW_AT_name("subCmd") .dwattr $C$DW$1986, DW_AT_TI_symbol_name("subCmd") .dwattr $C$DW$1986, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1986, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1986, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1986, DW_AT_decl_line(0x96) .dwattr $C$DW$1986, DW_AT_decl_column(0x18) $C$DW$1987 .dwtag DW_TAG_member .dwattr $C$DW$1987, DW_AT_type(*$C$DW$T$453) .dwattr $C$DW$1987, DW_AT_name("paramUpdateCmd") .dwattr $C$DW$1987, DW_AT_TI_symbol_name("paramUpdateCmd") .dwattr $C$DW$1987, DW_AT_data_member_location[DW_OP_plus_uconst 0x4] .dwattr $C$DW$1987, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1987, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1987, DW_AT_decl_line(0x97) .dwattr $C$DW$1987, DW_AT_decl_column(0x18) $C$DW$1988 .dwtag DW_TAG_member .dwattr $C$DW$1988, DW_AT_type(*$C$DW$T$454) .dwattr $C$DW$1988, DW_AT_name("processModule") .dwattr $C$DW$1988, DW_AT_TI_symbol_name("processModule") .dwattr $C$DW$1988, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1988, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1988, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1988, DW_AT_decl_line(0x98) .dwattr $C$DW$1988, DW_AT_decl_column(0x1b) $C$DW$1989 .dwtag DW_TAG_member .dwattr $C$DW$1989, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$1989, DW_AT_name("coreId") .dwattr $C$DW$1989, DW_AT_TI_symbol_name("coreId") .dwattr $C$DW$1989, DW_AT_data_member_location[DW_OP_plus_uconst 0xc] .dwattr $C$DW$1989, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1989, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1989, DW_AT_decl_line(0x99) .dwattr $C$DW$1989, DW_AT_decl_column(0x1b) $C$DW$1990 .dwtag DW_TAG_member .dwattr $C$DW$1990, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$1990, DW_AT_name("isRealTime") .dwattr $C$DW$1990, DW_AT_TI_symbol_name("isRealTime") .dwattr $C$DW$1990, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1990, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1990, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$1990, DW_AT_decl_line(0x9a) .dwattr $C$DW$1990, DW_AT_decl_column(0x1b) $C$DW$110 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$110, DW_AT_declaration .dwattr $C$DW$110, DW_AT_TI_symbol_name("_ZN14ParamUpdateMsgaSERKS_") .dwattr $C$DW$110, DW_AT_type(*$C$DW$T$457) .dwattr $C$DW$110, DW_AT_accessibility(DW_ACCESS_public) $C$DW$1991 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1991, DW_AT_type(*$C$DW$T$459) .dwendtag $C$DW$110 .dwendtag $C$DW$T$461 .dwattr $C$DW$T$461, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$461, DW_AT_decl_line(0x95) .dwattr $C$DW$T$461, DW_AT_decl_column(0x01) $C$DW$T$458 .dwtag DW_TAG_const_type .dwattr $C$DW$T$458, DW_AT_type(*$C$DW$T$461) $C$DW$T$459 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$459, DW_AT_type(*$C$DW$T$458) .dwattr $C$DW$T$459, DW_AT_address_class(0x20) $C$DW$T$1476 .dwtag DW_TAG_typedef, DW_AT_name("ParamUpdateMsg") .dwattr $C$DW$T$1476, DW_AT_type(*$C$DW$T$461) .dwattr $C$DW$T$1476, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1476, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1476, DW_AT_decl_line(0x9b) .dwattr $C$DW$T$1476, DW_AT_decl_column(0x03) $C$DW$T$457 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$457, DW_AT_type(*$C$DW$T$461) .dwattr $C$DW$T$457, DW_AT_address_class(0x20) $C$DW$T$460 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$460, DW_AT_type(*$C$DW$T$457) .dwattr $C$DW$T$460, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$1992 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$1992, DW_AT_type(*$C$DW$T$459) .dwendtag $C$DW$T$460 $C$DW$T$1448 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1448, DW_AT_name("Probe_Info") .dwattr $C$DW$T$1448, DW_AT_byte_size(0xb0) $C$DW$1993 .dwtag DW_TAG_member .dwattr $C$DW$1993, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1993, DW_AT_name("numElements") .dwattr $C$DW$1993, DW_AT_TI_symbol_name("numElements") .dwattr $C$DW$1993, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$1993, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1993, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1993, DW_AT_decl_line(0x213) .dwattr $C$DW$1993, DW_AT_decl_column(0x05) $C$DW$1994 .dwtag DW_TAG_member .dwattr $C$DW$1994, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1994, DW_AT_name("pitchMm") .dwattr $C$DW$1994, DW_AT_TI_symbol_name("pitchMm") .dwattr $C$DW$1994, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$1994, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1994, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1994, DW_AT_decl_line(0x214) .dwattr $C$DW$1994, DW_AT_decl_column(0x05) $C$DW$1995 .dwtag DW_TAG_member .dwattr $C$DW$1995, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1995, DW_AT_name("rocMm") .dwattr $C$DW$1995, DW_AT_TI_symbol_name("rocMm") .dwattr $C$DW$1995, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$1995, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1995, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1995, DW_AT_decl_line(0x215) .dwattr $C$DW$1995, DW_AT_decl_column(0x05) $C$DW$1996 .dwtag DW_TAG_member .dwattr $C$DW$1996, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$1996, DW_AT_name("lensThicknessMm") .dwattr $C$DW$1996, DW_AT_TI_symbol_name("lensThicknessMm") .dwattr $C$DW$1996, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$1996, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1996, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1996, DW_AT_decl_line(0x216) .dwattr $C$DW$1996, DW_AT_decl_column(0x05) $C$DW$1997 .dwtag DW_TAG_member .dwattr $C$DW$1997, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$1997, DW_AT_name("frontEndRayDensity") .dwattr $C$DW$1997, DW_AT_TI_symbol_name("frontEndRayDensity") .dwattr $C$DW$1997, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$1997, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1997, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1997, DW_AT_decl_line(0x217) .dwattr $C$DW$1997, DW_AT_decl_column(0x05) $C$DW$1998 .dwtag DW_TAG_member .dwattr $C$DW$1998, DW_AT_type(*$C$DW$T$1443) .dwattr $C$DW$1998, DW_AT_name("probeType") .dwattr $C$DW$1998, DW_AT_TI_symbol_name("probeType") .dwattr $C$DW$1998, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$1998, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1998, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1998, DW_AT_decl_line(0x218) .dwattr $C$DW$1998, DW_AT_decl_column(0x05) $C$DW$1999 .dwtag DW_TAG_member .dwattr $C$DW$1999, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$1999, DW_AT_name("reserved") .dwattr $C$DW$1999, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$1999, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$1999, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$1999, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$1999, DW_AT_decl_line(0x21a) .dwattr $C$DW$1999, DW_AT_decl_column(0x05) $C$DW$111 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$111, DW_AT_declaration .dwattr $C$DW$111, DW_AT_TI_symbol_name("_ZN10Probe_InfoaSERKS_") .dwattr $C$DW$111, DW_AT_type(*$C$DW$T$1444) .dwattr $C$DW$111, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2000 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2000, DW_AT_type(*$C$DW$T$1446) .dwendtag $C$DW$111 .dwendtag $C$DW$T$1448 .dwattr $C$DW$T$1448, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1448, DW_AT_decl_line(0x212) .dwattr $C$DW$T$1448, DW_AT_decl_column(0x01) $C$DW$T$475 .dwtag DW_TAG_typedef, DW_AT_name("Probe_Info") .dwattr $C$DW$T$475, DW_AT_type(*$C$DW$T$1448) .dwattr $C$DW$T$475, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$475, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$475, DW_AT_decl_line(0x21b) .dwattr $C$DW$T$475, DW_AT_decl_column(0x03) $C$DW$T$1445 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1445, DW_AT_type(*$C$DW$T$1448) $C$DW$T$1446 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1446, DW_AT_type(*$C$DW$T$1445) .dwattr $C$DW$T$1446, DW_AT_address_class(0x20) $C$DW$T$1444 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1444, DW_AT_type(*$C$DW$T$1448) .dwattr $C$DW$T$1444, DW_AT_address_class(0x20) $C$DW$T$1447 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1447, DW_AT_type(*$C$DW$T$1444) .dwattr $C$DW$T$1447, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2001 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2001, DW_AT_type(*$C$DW$T$1446) .dwendtag $C$DW$T$1447 $C$DW$T$1457 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1457, DW_AT_name("ProcessMsg") .dwattr $C$DW$T$1457, DW_AT_byte_size(0xd8) $C$DW$2002 .dwtag DW_TAG_member .dwattr $C$DW$2002, DW_AT_type(*$C$DW$T$506) .dwattr $C$DW$2002, DW_AT_name("cbufBundle") .dwattr $C$DW$2002, DW_AT_TI_symbol_name("cbufBundle") .dwattr $C$DW$2002, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2002, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2002, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2002, DW_AT_decl_line(0x63) .dwattr $C$DW$2002, DW_AT_decl_column(0x21) $C$DW$2003 .dwtag DW_TAG_member .dwattr $C$DW$2003, DW_AT_type(*$C$DW$T$510) .dwattr $C$DW$2003, DW_AT_name("spDataType") .dwattr $C$DW$2003, DW_AT_TI_symbol_name("spDataType") .dwattr $C$DW$2003, DW_AT_data_member_location[DW_OP_plus_uconst 0x88] .dwattr $C$DW$2003, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2003, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2003, DW_AT_decl_line(0x64) .dwattr $C$DW$2003, DW_AT_decl_column(0x21) $C$DW$2004 .dwtag DW_TAG_member .dwattr $C$DW$2004, DW_AT_type(*$C$DW$T$454) .dwattr $C$DW$2004, DW_AT_name("command") .dwattr $C$DW$2004, DW_AT_TI_symbol_name("command") .dwattr $C$DW$2004, DW_AT_data_member_location[DW_OP_plus_uconst 0x8c] .dwattr $C$DW$2004, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2004, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2004, DW_AT_decl_line(0x65) .dwattr $C$DW$2004, DW_AT_decl_column(0x21) $C$DW$2005 .dwtag DW_TAG_member .dwattr $C$DW$2005, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$2005, DW_AT_name("isCineData") .dwattr $C$DW$2005, DW_AT_TI_symbol_name("isCineData") .dwattr $C$DW$2005, DW_AT_data_member_location[DW_OP_plus_uconst 0x90] .dwattr $C$DW$2005, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2005, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2005, DW_AT_decl_line(0x66) .dwattr $C$DW$2005, DW_AT_decl_column(0x21) $C$DW$2006 .dwtag DW_TAG_member .dwattr $C$DW$2006, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$2006, DW_AT_name("timeStarted") .dwattr $C$DW$2006, DW_AT_TI_symbol_name("timeStarted") .dwattr $C$DW$2006, DW_AT_data_member_location[DW_OP_plus_uconst 0x98] .dwattr $C$DW$2006, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2006, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2006, DW_AT_decl_line(0x67) .dwattr $C$DW$2006, DW_AT_decl_column(0x21) $C$DW$2007 .dwtag DW_TAG_member .dwattr $C$DW$2007, DW_AT_type(*$C$DW$T$492) .dwattr $C$DW$2007, DW_AT_name("timeEnded") .dwattr $C$DW$2007, DW_AT_TI_symbol_name("timeEnded") .dwattr $C$DW$2007, DW_AT_data_member_location[DW_OP_plus_uconst 0xa0] .dwattr $C$DW$2007, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2007, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2007, DW_AT_decl_line(0x68) .dwattr $C$DW$2007, DW_AT_decl_column(0x21) $C$DW$2008 .dwtag DW_TAG_member .dwattr $C$DW$2008, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$2008, DW_AT_name("jobId") .dwattr $C$DW$2008, DW_AT_TI_symbol_name("jobId") .dwattr $C$DW$2008, DW_AT_data_member_location[DW_OP_plus_uconst 0xa8] .dwattr $C$DW$2008, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2008, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2008, DW_AT_decl_line(0x69) .dwattr $C$DW$2008, DW_AT_decl_column(0x21) $C$DW$2009 .dwtag DW_TAG_member .dwattr $C$DW$2009, DW_AT_type(*$C$DW$T$109) .dwattr $C$DW$2009, DW_AT_name("inputSeqId") .dwattr $C$DW$2009, DW_AT_TI_symbol_name("inputSeqId") .dwattr $C$DW$2009, DW_AT_data_member_location[DW_OP_plus_uconst 0xac] .dwattr $C$DW$2009, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2009, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2009, DW_AT_decl_line(0x6a) .dwattr $C$DW$2009, DW_AT_decl_column(0x21) $C$DW$2010 .dwtag DW_TAG_member .dwattr $C$DW$2010, DW_AT_type(*$C$DW$T$1449) .dwattr $C$DW$2010, DW_AT_name("coreLoad") .dwattr $C$DW$2010, DW_AT_TI_symbol_name("coreLoad") .dwattr $C$DW$2010, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0] .dwattr $C$DW$2010, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2010, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2010, DW_AT_decl_line(0x6b) .dwattr $C$DW$2010, DW_AT_decl_column(0x21) $C$DW$2011 .dwtag DW_TAG_member .dwattr $C$DW$2011, DW_AT_type(*$C$DW$T$1449) .dwattr $C$DW$2011, DW_AT_name("wrIdxIncrement") .dwattr $C$DW$2011, DW_AT_TI_symbol_name("wrIdxIncrement") .dwattr $C$DW$2011, DW_AT_data_member_location[DW_OP_plus_uconst 0xb4] .dwattr $C$DW$2011, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2011, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2011, DW_AT_decl_line(0x6c) .dwattr $C$DW$2011, DW_AT_decl_column(0x1e) $C$DW$2012 .dwtag DW_TAG_member .dwattr $C$DW$2012, DW_AT_type(*$C$DW$T$456) .dwattr $C$DW$2012, DW_AT_name("updateParam") .dwattr $C$DW$2012, DW_AT_TI_symbol_name("updateParam") .dwattr $C$DW$2012, DW_AT_data_member_location[DW_OP_plus_uconst 0xb8] .dwattr $C$DW$2012, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2012, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2012, DW_AT_decl_line(0x6d) .dwattr $C$DW$2012, DW_AT_decl_column(0x21) $C$DW$2013 .dwtag DW_TAG_member .dwattr $C$DW$2013, DW_AT_type(*$C$DW$T$1450) .dwattr $C$DW$2013, DW_AT_name("imagingState") .dwattr $C$DW$2013, DW_AT_TI_symbol_name("imagingState") .dwattr $C$DW$2013, DW_AT_data_member_location[DW_OP_plus_uconst 0xbc] .dwattr $C$DW$2013, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2013, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2013, DW_AT_decl_line(0x6e) .dwattr $C$DW$2013, DW_AT_decl_column(0x21) $C$DW$2014 .dwtag DW_TAG_member .dwattr $C$DW$2014, DW_AT_type(*$C$DW$T$1452) .dwattr $C$DW$2014, DW_AT_name("coreId") .dwattr $C$DW$2014, DW_AT_TI_symbol_name("coreId") .dwattr $C$DW$2014, DW_AT_data_member_location[DW_OP_plus_uconst 0xcc] .dwattr $C$DW$2014, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2014, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2014, DW_AT_decl_line(0x70) .dwattr $C$DW$2014, DW_AT_decl_column(0x21) $C$DW$2015 .dwtag DW_TAG_member .dwattr $C$DW$2015, DW_AT_type(*$C$DW$T$117) .dwattr $C$DW$2015, DW_AT_name("cineOutDelay") .dwattr $C$DW$2015, DW_AT_TI_symbol_name("cineOutDelay") .dwattr $C$DW$2015, DW_AT_data_member_location[DW_OP_plus_uconst 0xd0] .dwattr $C$DW$2015, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2015, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2015, DW_AT_decl_line(0x71) .dwattr $C$DW$2015, DW_AT_decl_column(0x21) $C$DW$112 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$112, DW_AT_declaration .dwattr $C$DW$112, DW_AT_TI_symbol_name("_ZN10ProcessMsgaSERKS_") .dwattr $C$DW$112, DW_AT_type(*$C$DW$T$1453) .dwattr $C$DW$112, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2016 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2016, DW_AT_type(*$C$DW$T$1455) .dwendtag $C$DW$112 .dwendtag $C$DW$T$1457 .dwattr $C$DW$T$1457, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1457, DW_AT_decl_line(0x62) .dwattr $C$DW$T$1457, DW_AT_decl_column(0x01) $C$DW$T$1454 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1454, DW_AT_type(*$C$DW$T$1457) $C$DW$T$1455 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1455, DW_AT_type(*$C$DW$T$1454) .dwattr $C$DW$T$1455, DW_AT_address_class(0x20) $C$DW$T$1472 .dwtag DW_TAG_typedef, DW_AT_name("ProcessMsg") .dwattr $C$DW$T$1472, DW_AT_type(*$C$DW$T$1457) .dwattr $C$DW$T$1472, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1472, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$1472, DW_AT_decl_line(0x72) .dwattr $C$DW$T$1472, DW_AT_decl_column(0x03) $C$DW$T$1453 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1453, DW_AT_type(*$C$DW$T$1457) .dwattr $C$DW$T$1453, DW_AT_address_class(0x20) $C$DW$T$1456 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1456, DW_AT_type(*$C$DW$T$1453) .dwattr $C$DW$T$1456, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2017 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2017, DW_AT_type(*$C$DW$T$1455) .dwendtag $C$DW$T$1456 $C$DW$T$179 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$179, DW_AT_name("RThetaInp_Param") .dwattr $C$DW$T$179, DW_AT_byte_size(0xc8) $C$DW$2018 .dwtag DW_TAG_member .dwattr $C$DW$2018, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$2018, DW_AT_name("numEstimates") .dwattr $C$DW$2018, DW_AT_TI_symbol_name("numEstimates") .dwattr $C$DW$2018, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2018, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2018, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2018, DW_AT_decl_line(0x23e) .dwattr $C$DW$2018, DW_AT_decl_column(0x05) $C$DW$2019 .dwtag DW_TAG_member .dwattr $C$DW$2019, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2019, DW_AT_name("startDepthEstMm") .dwattr $C$DW$2019, DW_AT_TI_symbol_name("startDepthEstMm") .dwattr $C$DW$2019, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$2019, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2019, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2019, DW_AT_decl_line(0x23f) .dwattr $C$DW$2019, DW_AT_decl_column(0x05) $C$DW$2020 .dwtag DW_TAG_member .dwattr $C$DW$2020, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2020, DW_AT_name("stopDepthEstMm") .dwattr $C$DW$2020, DW_AT_TI_symbol_name("stopDepthEstMm") .dwattr $C$DW$2020, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$2020, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2020, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2020, DW_AT_decl_line(0x240) .dwattr $C$DW$2020, DW_AT_decl_column(0x05) $C$DW$2021 .dwtag DW_TAG_member .dwattr $C$DW$2021, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2021, DW_AT_name("initRayOffset") .dwattr $C$DW$2021, DW_AT_TI_symbol_name("initRayOffset") .dwattr $C$DW$2021, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$2021, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2021, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2021, DW_AT_decl_line(0x241) .dwattr $C$DW$2021, DW_AT_decl_column(0x05) $C$DW$2022 .dwtag DW_TAG_member .dwattr $C$DW$2022, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2022, DW_AT_name("steerAngleRads") .dwattr $C$DW$2022, DW_AT_TI_symbol_name("steerAngleRads") .dwattr $C$DW$2022, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$2022, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2022, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2022, DW_AT_decl_line(0x242) .dwattr $C$DW$2022, DW_AT_decl_column(0x05) $C$DW$2023 .dwtag DW_TAG_member .dwattr $C$DW$2023, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$2023, DW_AT_name("lineDensity") .dwattr $C$DW$2023, DW_AT_TI_symbol_name("lineDensity") .dwattr $C$DW$2023, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$2023, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2023, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2023, DW_AT_decl_line(0x243) .dwattr $C$DW$2023, DW_AT_decl_column(0x05) $C$DW$2024 .dwtag DW_TAG_member .dwattr $C$DW$2024, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$2024, DW_AT_name("startRayInFeRd") .dwattr $C$DW$2024, DW_AT_TI_symbol_name("startRayInFeRd") .dwattr $C$DW$2024, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$2024, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2024, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2024, DW_AT_decl_line(0x244) .dwattr $C$DW$2024, DW_AT_decl_column(0x05) $C$DW$2025 .dwtag DW_TAG_member .dwattr $C$DW$2025, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$2025, DW_AT_name("stopRayInFeRd") .dwattr $C$DW$2025, DW_AT_TI_symbol_name("stopRayInFeRd") .dwattr $C$DW$2025, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$2025, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2025, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2025, DW_AT_decl_line(0x245) .dwattr $C$DW$2025, DW_AT_decl_column(0x05) $C$DW$2026 .dwtag DW_TAG_member .dwattr $C$DW$2026, DW_AT_type(*$C$DW$T$174) .dwattr $C$DW$2026, DW_AT_name("rayIncrement") .dwattr $C$DW$2026, DW_AT_TI_symbol_name("rayIncrement") .dwattr $C$DW$2026, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$2026, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2026, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2026, DW_AT_decl_line(0x246) .dwattr $C$DW$2026, DW_AT_decl_column(0x05) $C$DW$2027 .dwtag DW_TAG_member .dwattr $C$DW$2027, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$2027, DW_AT_name("reserved") .dwattr $C$DW$2027, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$2027, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$2027, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2027, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2027, DW_AT_decl_line(0x247) .dwattr $C$DW$2027, DW_AT_decl_column(0x05) $C$DW$113 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$113, DW_AT_declaration .dwattr $C$DW$113, DW_AT_TI_symbol_name("_ZN15RThetaInp_ParamaSERKS_") .dwattr $C$DW$113, DW_AT_type(*$C$DW$T$175) .dwattr $C$DW$113, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2028 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2028, DW_AT_type(*$C$DW$T$177) .dwendtag $C$DW$113 .dwendtag $C$DW$T$179 .dwattr $C$DW$T$179, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$179, DW_AT_decl_line(0x23d) .dwattr $C$DW$T$179, DW_AT_decl_column(0x01) $C$DW$T$176 .dwtag DW_TAG_const_type .dwattr $C$DW$T$176, DW_AT_type(*$C$DW$T$179) $C$DW$T$177 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$177, DW_AT_type(*$C$DW$T$176) .dwattr $C$DW$T$177, DW_AT_address_class(0x20) $C$DW$T$476 .dwtag DW_TAG_typedef, DW_AT_name("RThetaInp_Param") .dwattr $C$DW$T$476, DW_AT_type(*$C$DW$T$179) .dwattr $C$DW$T$476, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$476, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$476, DW_AT_decl_line(0x248) .dwattr $C$DW$T$476, DW_AT_decl_column(0x03) $C$DW$T$175 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$175, DW_AT_type(*$C$DW$T$179) .dwattr $C$DW$T$175, DW_AT_address_class(0x20) $C$DW$T$178 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$178, DW_AT_type(*$C$DW$T$175) .dwattr $C$DW$T$178, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2029 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2029, DW_AT_type(*$C$DW$T$177) .dwendtag $C$DW$T$178 $C$DW$T$185 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$185, DW_AT_name("RThetaOut_Param") .dwattr $C$DW$T$185, DW_AT_byte_size(0x1100) $C$DW$2030 .dwtag DW_TAG_member .dwattr $C$DW$2030, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$2030, DW_AT_name("numRays") .dwattr $C$DW$2030, DW_AT_TI_symbol_name("numRays") .dwattr $C$DW$2030, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2030, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2030, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2030, DW_AT_decl_line(0x260) .dwattr $C$DW$2030, DW_AT_decl_column(0x05) $C$DW$2031 .dwtag DW_TAG_member .dwattr $C$DW$2031, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2031, DW_AT_name("pitchRads") .dwattr $C$DW$2031, DW_AT_TI_symbol_name("pitchRads") .dwattr $C$DW$2031, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$2031, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2031, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2031, DW_AT_decl_line(0x261) .dwattr $C$DW$2031, DW_AT_decl_column(0x05) $C$DW$2032 .dwtag DW_TAG_member .dwattr $C$DW$2032, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2032, DW_AT_name("radsPerRay") .dwattr $C$DW$2032, DW_AT_TI_symbol_name("radsPerRay") .dwattr $C$DW$2032, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$2032, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2032, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2032, DW_AT_decl_line(0x262) .dwattr $C$DW$2032, DW_AT_decl_column(0x05) $C$DW$2033 .dwtag DW_TAG_member .dwattr $C$DW$2033, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2033, DW_AT_name("mmPerEst") .dwattr $C$DW$2033, DW_AT_TI_symbol_name("mmPerEst") .dwattr $C$DW$2033, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$2033, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2033, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2033, DW_AT_decl_line(0x263) .dwattr $C$DW$2033, DW_AT_decl_column(0x05) $C$DW$2034 .dwtag DW_TAG_member .dwattr $C$DW$2034, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2034, DW_AT_name("mmPerRay") .dwattr $C$DW$2034, DW_AT_TI_symbol_name("mmPerRay") .dwattr $C$DW$2034, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$2034, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2034, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2034, DW_AT_decl_line(0x264) .dwattr $C$DW$2034, DW_AT_decl_column(0x05) $C$DW$2035 .dwtag DW_TAG_member .dwattr $C$DW$2035, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2035, DW_AT_name("startRayThetaRads") .dwattr $C$DW$2035, DW_AT_TI_symbol_name("startRayThetaRads") .dwattr $C$DW$2035, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$2035, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2035, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2035, DW_AT_decl_line(0x265) .dwattr $C$DW$2035, DW_AT_decl_column(0x05) $C$DW$2036 .dwtag DW_TAG_member .dwattr $C$DW$2036, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2036, DW_AT_name("startRayLensXmm") .dwattr $C$DW$2036, DW_AT_TI_symbol_name("startRayLensXmm") .dwattr $C$DW$2036, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$2036, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2036, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2036, DW_AT_decl_line(0x266) .dwattr $C$DW$2036, DW_AT_decl_column(0x05) $C$DW$2037 .dwtag DW_TAG_member .dwattr $C$DW$2037, DW_AT_type(*$C$DW$T$180) .dwattr $C$DW$2037, DW_AT_name("rayThetasRads") .dwattr $C$DW$2037, DW_AT_TI_symbol_name("rayThetasRads") .dwattr $C$DW$2037, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$2037, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2037, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2037, DW_AT_decl_line(0x267) .dwattr $C$DW$2037, DW_AT_decl_column(0x05) $C$DW$2038 .dwtag DW_TAG_member .dwattr $C$DW$2038, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2038, DW_AT_name("startEstRmm") .dwattr $C$DW$2038, DW_AT_TI_symbol_name("startEstRmm") .dwattr $C$DW$2038, DW_AT_data_member_location[DW_OP_plus_uconst 0x1038] .dwattr $C$DW$2038, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2038, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2038, DW_AT_decl_line(0x268) .dwattr $C$DW$2038, DW_AT_decl_column(0x05) $C$DW$2039 .dwtag DW_TAG_member .dwattr $C$DW$2039, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2039, DW_AT_name("stopEstRmm") .dwattr $C$DW$2039, DW_AT_TI_symbol_name("stopEstRmm") .dwattr $C$DW$2039, DW_AT_data_member_location[DW_OP_plus_uconst 0x1040] .dwattr $C$DW$2039, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2039, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2039, DW_AT_decl_line(0x269) .dwattr $C$DW$2039, DW_AT_decl_column(0x05) $C$DW$2040 .dwtag DW_TAG_member .dwattr $C$DW$2040, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2040, DW_AT_name("lensFaceMm") .dwattr $C$DW$2040, DW_AT_TI_symbol_name("lensFaceMm") .dwattr $C$DW$2040, DW_AT_data_member_location[DW_OP_plus_uconst 0x1048] .dwattr $C$DW$2040, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2040, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2040, DW_AT_decl_line(0x26a) .dwattr $C$DW$2040, DW_AT_decl_column(0x05) $C$DW$2041 .dwtag DW_TAG_member .dwattr $C$DW$2041, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2041, DW_AT_name("rThetaOriginXmm") .dwattr $C$DW$2041, DW_AT_TI_symbol_name("rThetaOriginXmm") .dwattr $C$DW$2041, DW_AT_data_member_location[DW_OP_plus_uconst 0x1050] .dwattr $C$DW$2041, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2041, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2041, DW_AT_decl_line(0x26b) .dwattr $C$DW$2041, DW_AT_decl_column(0x05) $C$DW$2042 .dwtag DW_TAG_member .dwattr $C$DW$2042, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2042, DW_AT_name("rThetaOriginYmm") .dwattr $C$DW$2042, DW_AT_TI_symbol_name("rThetaOriginYmm") .dwattr $C$DW$2042, DW_AT_data_member_location[DW_OP_plus_uconst 0x1058] .dwattr $C$DW$2042, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2042, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2042, DW_AT_decl_line(0x26c) .dwattr $C$DW$2042, DW_AT_decl_column(0x05) $C$DW$2043 .dwtag DW_TAG_member .dwattr $C$DW$2043, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2043, DW_AT_name("depthExtentMm") .dwattr $C$DW$2043, DW_AT_TI_symbol_name("depthExtentMm") .dwattr $C$DW$2043, DW_AT_data_member_location[DW_OP_plus_uconst 0x1060] .dwattr $C$DW$2043, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2043, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2043, DW_AT_decl_line(0x26d) .dwattr $C$DW$2043, DW_AT_decl_column(0x05) $C$DW$2044 .dwtag DW_TAG_member .dwattr $C$DW$2044, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2044, DW_AT_name("azimuthExtentMm") .dwattr $C$DW$2044, DW_AT_TI_symbol_name("azimuthExtentMm") .dwattr $C$DW$2044, DW_AT_data_member_location[DW_OP_plus_uconst 0x1068] .dwattr $C$DW$2044, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2044, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2044, DW_AT_decl_line(0x26e) .dwattr $C$DW$2044, DW_AT_decl_column(0x05) $C$DW$2045 .dwtag DW_TAG_member .dwattr $C$DW$2045, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2045, DW_AT_name("startEst") .dwattr $C$DW$2045, DW_AT_TI_symbol_name("startEst") .dwattr $C$DW$2045, DW_AT_data_member_location[DW_OP_plus_uconst 0x1070] .dwattr $C$DW$2045, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2045, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2045, DW_AT_decl_line(0x26f) .dwattr $C$DW$2045, DW_AT_decl_column(0x05) $C$DW$2046 .dwtag DW_TAG_member .dwattr $C$DW$2046, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2046, DW_AT_name("stopEst") .dwattr $C$DW$2046, DW_AT_TI_symbol_name("stopEst") .dwattr $C$DW$2046, DW_AT_data_member_location[DW_OP_plus_uconst 0x1078] .dwattr $C$DW$2046, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2046, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2046, DW_AT_decl_line(0x270) .dwattr $C$DW$2046, DW_AT_decl_column(0x05) $C$DW$2047 .dwtag DW_TAG_member .dwattr $C$DW$2047, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$2047, DW_AT_name("reserved") .dwattr $C$DW$2047, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$2047, DW_AT_data_member_location[DW_OP_plus_uconst 0x1080] .dwattr $C$DW$2047, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2047, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2047, DW_AT_decl_line(0x271) .dwattr $C$DW$2047, DW_AT_decl_column(0x05) $C$DW$114 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$114, DW_AT_declaration .dwattr $C$DW$114, DW_AT_TI_symbol_name("_ZN15RThetaOut_ParamaSERKS_") .dwattr $C$DW$114, DW_AT_type(*$C$DW$T$181) .dwattr $C$DW$114, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2048 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2048, DW_AT_type(*$C$DW$T$183) .dwendtag $C$DW$114 .dwendtag $C$DW$T$185 .dwattr $C$DW$T$185, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$185, DW_AT_decl_line(0x25f) .dwattr $C$DW$T$185, DW_AT_decl_column(0x01) $C$DW$T$182 .dwtag DW_TAG_const_type .dwattr $C$DW$T$182, DW_AT_type(*$C$DW$T$185) $C$DW$T$183 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$183, DW_AT_type(*$C$DW$T$182) .dwattr $C$DW$T$183, DW_AT_address_class(0x20) $C$DW$T$477 .dwtag DW_TAG_typedef, DW_AT_name("RThetaOut_Param") .dwattr $C$DW$T$477, DW_AT_type(*$C$DW$T$185) .dwattr $C$DW$T$477, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$477, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$477, DW_AT_decl_line(0x272) .dwattr $C$DW$T$477, DW_AT_decl_column(0x03) $C$DW$T$181 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$181, DW_AT_type(*$C$DW$T$185) .dwattr $C$DW$T$181, DW_AT_address_class(0x20) $C$DW$T$184 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$184, DW_AT_type(*$C$DW$T$181) .dwattr $C$DW$T$184, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2049 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2049, DW_AT_type(*$C$DW$T$183) .dwendtag $C$DW$T$184 $C$DW$T$469 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$469, DW_AT_name("RasterInp_Param") .dwattr $C$DW$T$469, DW_AT_byte_size(0xb0) $C$DW$2050 .dwtag DW_TAG_member .dwattr $C$DW$2050, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$2050, DW_AT_name("sizeX") .dwattr $C$DW$2050, DW_AT_TI_symbol_name("sizeX") .dwattr $C$DW$2050, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2050, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2050, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2050, DW_AT_decl_line(0x255) .dwattr $C$DW$2050, DW_AT_decl_column(0x05) $C$DW$2051 .dwtag DW_TAG_member .dwattr $C$DW$2051, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$2051, DW_AT_name("sizeY") .dwattr $C$DW$2051, DW_AT_TI_symbol_name("sizeY") .dwattr $C$DW$2051, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$2051, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2051, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2051, DW_AT_decl_line(0x256) .dwattr $C$DW$2051, DW_AT_decl_column(0x05) $C$DW$2052 .dwtag DW_TAG_member .dwattr $C$DW$2052, DW_AT_type(*$C$DW$T$463) .dwattr $C$DW$2052, DW_AT_name("zoomType") .dwattr $C$DW$2052, DW_AT_TI_symbol_name("zoomType") .dwattr $C$DW$2052, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$2052, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2052, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2052, DW_AT_decl_line(0x257) .dwattr $C$DW$2052, DW_AT_decl_column(0x05) $C$DW$2053 .dwtag DW_TAG_member .dwattr $C$DW$2053, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$2053, DW_AT_name("rotate") .dwattr $C$DW$2053, DW_AT_TI_symbol_name("rotate") .dwattr $C$DW$2053, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$2053, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2053, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2053, DW_AT_decl_line(0x258) .dwattr $C$DW$2053, DW_AT_decl_column(0x05) $C$DW$2054 .dwtag DW_TAG_member .dwattr $C$DW$2054, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$2054, DW_AT_name("curvedPhasedFitVertical") .dwattr $C$DW$2054, DW_AT_TI_symbol_name("curvedPhasedFitVertical") .dwattr $C$DW$2054, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$2054, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2054, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2054, DW_AT_decl_line(0x259) .dwattr $C$DW$2054, DW_AT_decl_column(0x05) $C$DW$2055 .dwtag DW_TAG_member .dwattr $C$DW$2055, DW_AT_type(*$C$DW$T$464) .dwattr $C$DW$2055, DW_AT_name("zoomBitsAlloc") .dwattr $C$DW$2055, DW_AT_TI_symbol_name("zoomBitsAlloc") .dwattr $C$DW$2055, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$2055, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2055, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2055, DW_AT_decl_line(0x25a) .dwattr $C$DW$2055, DW_AT_decl_column(0x05) $C$DW$2056 .dwtag DW_TAG_member .dwattr $C$DW$2056, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$2056, DW_AT_name("reserved") .dwattr $C$DW$2056, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$2056, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$2056, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2056, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2056, DW_AT_decl_line(0x25b) .dwattr $C$DW$2056, DW_AT_decl_column(0x05) $C$DW$115 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$115, DW_AT_declaration .dwattr $C$DW$115, DW_AT_TI_symbol_name("_ZN15RasterInp_ParamaSERKS_") .dwattr $C$DW$115, DW_AT_type(*$C$DW$T$465) .dwattr $C$DW$115, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2057 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2057, DW_AT_type(*$C$DW$T$467) .dwendtag $C$DW$115 .dwendtag $C$DW$T$469 .dwattr $C$DW$T$469, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$469, DW_AT_decl_line(0x254) .dwattr $C$DW$T$469, DW_AT_decl_column(0x01) $C$DW$T$466 .dwtag DW_TAG_const_type .dwattr $C$DW$T$466, DW_AT_type(*$C$DW$T$469) $C$DW$T$467 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$467, DW_AT_type(*$C$DW$T$466) .dwattr $C$DW$T$467, DW_AT_address_class(0x20) $C$DW$T$478 .dwtag DW_TAG_typedef, DW_AT_name("RasterInp_Param") .dwattr $C$DW$T$478, DW_AT_type(*$C$DW$T$469) .dwattr $C$DW$T$478, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$478, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$478, DW_AT_decl_line(0x25c) .dwattr $C$DW$T$478, DW_AT_decl_column(0x03) $C$DW$T$465 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$465, DW_AT_type(*$C$DW$T$469) .dwattr $C$DW$T$465, DW_AT_address_class(0x20) $C$DW$T$468 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$468, DW_AT_type(*$C$DW$T$465) .dwattr $C$DW$T$468, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2058 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2058, DW_AT_type(*$C$DW$T$467) .dwendtag $C$DW$T$468 $C$DW$T$474 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$474, DW_AT_name("RasterOut_Param") .dwattr $C$DW$T$474, DW_AT_byte_size(0xe0) $C$DW$2059 .dwtag DW_TAG_member .dwattr $C$DW$2059, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2059, DW_AT_name("mmPerPixelBase") .dwattr $C$DW$2059, DW_AT_TI_symbol_name("mmPerPixelBase") .dwattr $C$DW$2059, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2059, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2059, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2059, DW_AT_decl_line(0x276) .dwattr $C$DW$2059, DW_AT_decl_column(0x05) $C$DW$2060 .dwtag DW_TAG_member .dwattr $C$DW$2060, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2060, DW_AT_name("mmPerPixel") .dwattr $C$DW$2060, DW_AT_TI_symbol_name("mmPerPixel") .dwattr $C$DW$2060, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$2060, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2060, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2060, DW_AT_decl_line(0x277) .dwattr $C$DW$2060, DW_AT_decl_column(0x05) $C$DW$2061 .dwtag DW_TAG_member .dwattr $C$DW$2061, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2061, DW_AT_name("rasterOriginXmm") .dwattr $C$DW$2061, DW_AT_TI_symbol_name("rasterOriginXmm") .dwattr $C$DW$2061, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$2061, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2061, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2061, DW_AT_decl_line(0x278) .dwattr $C$DW$2061, DW_AT_decl_column(0x05) $C$DW$2062 .dwtag DW_TAG_member .dwattr $C$DW$2062, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2062, DW_AT_name("rasterOriginYmm") .dwattr $C$DW$2062, DW_AT_TI_symbol_name("rasterOriginYmm") .dwattr $C$DW$2062, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$2062, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2062, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2062, DW_AT_decl_line(0x279) .dwattr $C$DW$2062, DW_AT_decl_column(0x05) $C$DW$2063 .dwtag DW_TAG_member .dwattr $C$DW$2063, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2063, DW_AT_name("centerAngleRad") .dwattr $C$DW$2063, DW_AT_TI_symbol_name("centerAngleRad") .dwattr $C$DW$2063, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$2063, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2063, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2063, DW_AT_decl_line(0x27a) .dwattr $C$DW$2063, DW_AT_decl_column(0x05) $C$DW$2064 .dwtag DW_TAG_member .dwattr $C$DW$2064, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2064, DW_AT_name("rotMmPerPixelBase") .dwattr $C$DW$2064, DW_AT_TI_symbol_name("rotMmPerPixelBase") .dwattr $C$DW$2064, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$2064, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2064, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2064, DW_AT_decl_line(0x27b) .dwattr $C$DW$2064, DW_AT_decl_column(0x05) $C$DW$2065 .dwtag DW_TAG_member .dwattr $C$DW$2065, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2065, DW_AT_name("rotMmPerPixel") .dwattr $C$DW$2065, DW_AT_TI_symbol_name("rotMmPerPixel") .dwattr $C$DW$2065, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$2065, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2065, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2065, DW_AT_decl_line(0x27c) .dwattr $C$DW$2065, DW_AT_decl_column(0x05) $C$DW$2066 .dwtag DW_TAG_member .dwattr $C$DW$2066, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2066, DW_AT_name("rotOriginXmm") .dwattr $C$DW$2066, DW_AT_TI_symbol_name("rotOriginXmm") .dwattr $C$DW$2066, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$2066, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2066, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2066, DW_AT_decl_line(0x27d) .dwattr $C$DW$2066, DW_AT_decl_column(0x05) $C$DW$2067 .dwtag DW_TAG_member .dwattr $C$DW$2067, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2067, DW_AT_name("rotOriginYmm") .dwattr $C$DW$2067, DW_AT_TI_symbol_name("rotOriginYmm") .dwattr $C$DW$2067, DW_AT_data_member_location[DW_OP_plus_uconst 0x40] .dwattr $C$DW$2067, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2067, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2067, DW_AT_decl_line(0x27e) .dwattr $C$DW$2067, DW_AT_decl_column(0x05) $C$DW$2068 .dwtag DW_TAG_member .dwattr $C$DW$2068, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2068, DW_AT_name("minXMm") .dwattr $C$DW$2068, DW_AT_TI_symbol_name("minXMm") .dwattr $C$DW$2068, DW_AT_data_member_location[DW_OP_plus_uconst 0x48] .dwattr $C$DW$2068, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2068, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2068, DW_AT_decl_line(0x27f) .dwattr $C$DW$2068, DW_AT_decl_column(0x05) $C$DW$2069 .dwtag DW_TAG_member .dwattr $C$DW$2069, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2069, DW_AT_name("minYMm") .dwattr $C$DW$2069, DW_AT_TI_symbol_name("minYMm") .dwattr $C$DW$2069, DW_AT_data_member_location[DW_OP_plus_uconst 0x50] .dwattr $C$DW$2069, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2069, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2069, DW_AT_decl_line(0x280) .dwattr $C$DW$2069, DW_AT_decl_column(0x05) $C$DW$2070 .dwtag DW_TAG_member .dwattr $C$DW$2070, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$2070, DW_AT_name("startRow") .dwattr $C$DW$2070, DW_AT_TI_symbol_name("startRow") .dwattr $C$DW$2070, DW_AT_data_member_location[DW_OP_plus_uconst 0x58] .dwattr $C$DW$2070, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2070, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2070, DW_AT_decl_line(0x281) .dwattr $C$DW$2070, DW_AT_decl_column(0x05) $C$DW$2071 .dwtag DW_TAG_member .dwattr $C$DW$2071, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$2071, DW_AT_name("reserved") .dwattr $C$DW$2071, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$2071, DW_AT_data_member_location[DW_OP_plus_uconst 0x60] .dwattr $C$DW$2071, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2071, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2071, DW_AT_decl_line(0x282) .dwattr $C$DW$2071, DW_AT_decl_column(0x05) $C$DW$116 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$116, DW_AT_declaration .dwattr $C$DW$116, DW_AT_TI_symbol_name("_ZN15RasterOut_ParamaSERKS_") .dwattr $C$DW$116, DW_AT_type(*$C$DW$T$470) .dwattr $C$DW$116, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2072 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2072, DW_AT_type(*$C$DW$T$472) .dwendtag $C$DW$116 .dwendtag $C$DW$T$474 .dwattr $C$DW$T$474, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$474, DW_AT_decl_line(0x275) .dwattr $C$DW$T$474, DW_AT_decl_column(0x01) $C$DW$T$471 .dwtag DW_TAG_const_type .dwattr $C$DW$T$471, DW_AT_type(*$C$DW$T$474) $C$DW$T$472 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$472, DW_AT_type(*$C$DW$T$471) .dwattr $C$DW$T$472, DW_AT_address_class(0x20) $C$DW$T$479 .dwtag DW_TAG_typedef, DW_AT_name("RasterOut_Param") .dwattr $C$DW$T$479, DW_AT_type(*$C$DW$T$474) .dwattr $C$DW$T$479, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$479, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$479, DW_AT_decl_line(0x283) .dwattr $C$DW$T$479, DW_AT_decl_column(0x03) $C$DW$T$470 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$470, DW_AT_type(*$C$DW$T$474) .dwattr $C$DW$T$470, DW_AT_address_class(0x20) $C$DW$T$473 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$473, DW_AT_type(*$C$DW$T$470) .dwattr $C$DW$T$473, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2073 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2073, DW_AT_type(*$C$DW$T$472) .dwendtag $C$DW$T$473 $C$DW$T$485 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$485, DW_AT_name("RasterScanConv_Param") .dwattr $C$DW$T$485, DW_AT_byte_size(0x3a70) $C$DW$2074 .dwtag DW_TAG_member .dwattr $C$DW$2074, DW_AT_type(*$C$DW$T$475) .dwattr $C$DW$2074, DW_AT_name("probeInfo") .dwattr $C$DW$2074, DW_AT_TI_symbol_name("probeInfo") .dwattr $C$DW$2074, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2074, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2074, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2074, DW_AT_decl_line(0x287) .dwattr $C$DW$2074, DW_AT_decl_column(0x05) $C$DW$2075 .dwtag DW_TAG_member .dwattr $C$DW$2075, DW_AT_type(*$C$DW$T$476) .dwattr $C$DW$2075, DW_AT_name("rTInpParamB") .dwattr $C$DW$2075, DW_AT_TI_symbol_name("rTInpParamB") .dwattr $C$DW$2075, DW_AT_data_member_location[DW_OP_plus_uconst 0xb0] .dwattr $C$DW$2075, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2075, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2075, DW_AT_decl_line(0x288) .dwattr $C$DW$2075, DW_AT_decl_column(0x05) $C$DW$2076 .dwtag DW_TAG_member .dwattr $C$DW$2076, DW_AT_type(*$C$DW$T$476) .dwattr $C$DW$2076, DW_AT_name("rTInpParamC") .dwattr $C$DW$2076, DW_AT_TI_symbol_name("rTInpParamC") .dwattr $C$DW$2076, DW_AT_data_member_location[DW_OP_plus_uconst 0x178] .dwattr $C$DW$2076, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2076, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2076, DW_AT_decl_line(0x289) .dwattr $C$DW$2076, DW_AT_decl_column(0x05) $C$DW$2077 .dwtag DW_TAG_member .dwattr $C$DW$2077, DW_AT_type(*$C$DW$T$476) .dwattr $C$DW$2077, DW_AT_name("rTInpScZoom") .dwattr $C$DW$2077, DW_AT_TI_symbol_name("rTInpScZoom") .dwattr $C$DW$2077, DW_AT_data_member_location[DW_OP_plus_uconst 0x240] .dwattr $C$DW$2077, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2077, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2077, DW_AT_decl_line(0x28a) .dwattr $C$DW$2077, DW_AT_decl_column(0x05) $C$DW$2078 .dwtag DW_TAG_member .dwattr $C$DW$2078, DW_AT_type(*$C$DW$T$477) .dwattr $C$DW$2078, DW_AT_name("rThetaOutParamB") .dwattr $C$DW$2078, DW_AT_TI_symbol_name("rThetaOutParamB") .dwattr $C$DW$2078, DW_AT_data_member_location[DW_OP_plus_uconst 0x308] .dwattr $C$DW$2078, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2078, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2078, DW_AT_decl_line(0x28b) .dwattr $C$DW$2078, DW_AT_decl_column(0x05) $C$DW$2079 .dwtag DW_TAG_member .dwattr $C$DW$2079, DW_AT_type(*$C$DW$T$477) .dwattr $C$DW$2079, DW_AT_name("rThetaOutParamC") .dwattr $C$DW$2079, DW_AT_TI_symbol_name("rThetaOutParamC") .dwattr $C$DW$2079, DW_AT_data_member_location[DW_OP_plus_uconst 0x1408] .dwattr $C$DW$2079, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2079, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2079, DW_AT_decl_line(0x28c) .dwattr $C$DW$2079, DW_AT_decl_column(0x05) $C$DW$2080 .dwtag DW_TAG_member .dwattr $C$DW$2080, DW_AT_type(*$C$DW$T$477) .dwattr $C$DW$2080, DW_AT_name("rThetaOutParamRef") .dwattr $C$DW$2080, DW_AT_TI_symbol_name("rThetaOutParamRef") .dwattr $C$DW$2080, DW_AT_data_member_location[DW_OP_plus_uconst 0x2508] .dwattr $C$DW$2080, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2080, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2080, DW_AT_decl_line(0x28d) .dwattr $C$DW$2080, DW_AT_decl_column(0x05) $C$DW$2081 .dwtag DW_TAG_member .dwattr $C$DW$2081, DW_AT_type(*$C$DW$T$478) .dwattr $C$DW$2081, DW_AT_name("rasterInpParam") .dwattr $C$DW$2081, DW_AT_TI_symbol_name("rasterInpParam") .dwattr $C$DW$2081, DW_AT_data_member_location[DW_OP_plus_uconst 0x3608] .dwattr $C$DW$2081, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2081, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2081, DW_AT_decl_line(0x28e) .dwattr $C$DW$2081, DW_AT_decl_column(0x05) $C$DW$2082 .dwtag DW_TAG_member .dwattr $C$DW$2082, DW_AT_type(*$C$DW$T$479) .dwattr $C$DW$2082, DW_AT_name("rasterOutParamB") .dwattr $C$DW$2082, DW_AT_TI_symbol_name("rasterOutParamB") .dwattr $C$DW$2082, DW_AT_data_member_location[DW_OP_plus_uconst 0x36b8] .dwattr $C$DW$2082, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2082, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2082, DW_AT_decl_line(0x28f) .dwattr $C$DW$2082, DW_AT_decl_column(0x05) $C$DW$2083 .dwtag DW_TAG_member .dwattr $C$DW$2083, DW_AT_type(*$C$DW$T$479) .dwattr $C$DW$2083, DW_AT_name("rasterOutParamC") .dwattr $C$DW$2083, DW_AT_TI_symbol_name("rasterOutParamC") .dwattr $C$DW$2083, DW_AT_data_member_location[DW_OP_plus_uconst 0x3798] .dwattr $C$DW$2083, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2083, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2083, DW_AT_decl_line(0x290) .dwattr $C$DW$2083, DW_AT_decl_column(0x05) $C$DW$2084 .dwtag DW_TAG_member .dwattr $C$DW$2084, DW_AT_type(*$C$DW$T$480) .dwattr $C$DW$2084, DW_AT_name("rasterZoomParamB") .dwattr $C$DW$2084, DW_AT_TI_symbol_name("rasterZoomParamB") .dwattr $C$DW$2084, DW_AT_data_member_location[DW_OP_plus_uconst 0x3878] .dwattr $C$DW$2084, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2084, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2084, DW_AT_decl_line(0x291) .dwattr $C$DW$2084, DW_AT_decl_column(0x05) $C$DW$2085 .dwtag DW_TAG_member .dwattr $C$DW$2085, DW_AT_type(*$C$DW$T$480) .dwattr $C$DW$2085, DW_AT_name("rasterZoomParamC") .dwattr $C$DW$2085, DW_AT_TI_symbol_name("rasterZoomParamC") .dwattr $C$DW$2085, DW_AT_data_member_location[DW_OP_plus_uconst 0x3930] .dwattr $C$DW$2085, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2085, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2085, DW_AT_decl_line(0x292) .dwattr $C$DW$2085, DW_AT_decl_column(0x05) $C$DW$2086 .dwtag DW_TAG_member .dwattr $C$DW$2086, DW_AT_type(*$C$DW$T$133) .dwattr $C$DW$2086, DW_AT_name("useArrayref") .dwattr $C$DW$2086, DW_AT_TI_symbol_name("useArrayref") .dwattr $C$DW$2086, DW_AT_data_member_location[DW_OP_plus_uconst 0x39e8] .dwattr $C$DW$2086, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2086, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2086, DW_AT_decl_line(0x293) .dwattr $C$DW$2086, DW_AT_decl_column(0x05) $C$DW$2087 .dwtag DW_TAG_member .dwattr $C$DW$2087, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$2087, DW_AT_name("reserved") .dwattr $C$DW$2087, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$2087, DW_AT_data_member_location[DW_OP_plus_uconst 0x39f0] .dwattr $C$DW$2087, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2087, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2087, DW_AT_decl_line(0x294) .dwattr $C$DW$2087, DW_AT_decl_column(0x05) $C$DW$117 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$117, DW_AT_declaration .dwattr $C$DW$117, DW_AT_TI_symbol_name("_ZN20RasterScanConv_ParamaSERKS_") .dwattr $C$DW$117, DW_AT_type(*$C$DW$T$481) .dwattr $C$DW$117, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2088 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2088, DW_AT_type(*$C$DW$T$483) .dwendtag $C$DW$117 .dwendtag $C$DW$T$485 .dwattr $C$DW$T$485, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$485, DW_AT_decl_line(0x286) .dwattr $C$DW$T$485, DW_AT_decl_column(0x01) $C$DW$T$482 .dwtag DW_TAG_const_type .dwattr $C$DW$T$482, DW_AT_type(*$C$DW$T$485) $C$DW$T$483 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$483, DW_AT_type(*$C$DW$T$482) .dwattr $C$DW$T$483, DW_AT_address_class(0x20) $C$DW$T$1921 .dwtag DW_TAG_typedef, DW_AT_name("RasterScanConv_Param") .dwattr $C$DW$T$1921, DW_AT_type(*$C$DW$T$485) .dwattr $C$DW$T$1921, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1921, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1921, DW_AT_decl_line(0x295) .dwattr $C$DW$T$1921, DW_AT_decl_column(0x03) $C$DW$T$481 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$481, DW_AT_type(*$C$DW$T$485) .dwattr $C$DW$T$481, DW_AT_address_class(0x20) $C$DW$T$484 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$484, DW_AT_type(*$C$DW$T$481) .dwattr $C$DW$T$484, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2089 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2089, DW_AT_type(*$C$DW$T$483) .dwendtag $C$DW$T$484 $C$DW$T$490 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$490, DW_AT_name("RasterZoomParam") .dwattr $C$DW$T$490, DW_AT_byte_size(0xb8) $C$DW$2090 .dwtag DW_TAG_member .dwattr $C$DW$2090, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2090, DW_AT_name("zoomRegionStartX") .dwattr $C$DW$2090, DW_AT_TI_symbol_name("zoomRegionStartX") .dwattr $C$DW$2090, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2090, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2090, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2090, DW_AT_decl_line(0x232) .dwattr $C$DW$2090, DW_AT_decl_column(0x05) $C$DW$2091 .dwtag DW_TAG_member .dwattr $C$DW$2091, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2091, DW_AT_name("zoomRegionStartY") .dwattr $C$DW$2091, DW_AT_TI_symbol_name("zoomRegionStartY") .dwattr $C$DW$2091, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$2091, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2091, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2091, DW_AT_decl_line(0x233) .dwattr $C$DW$2091, DW_AT_decl_column(0x05) $C$DW$2092 .dwtag DW_TAG_member .dwattr $C$DW$2092, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2092, DW_AT_name("zoomRegionSizeX") .dwattr $C$DW$2092, DW_AT_TI_symbol_name("zoomRegionSizeX") .dwattr $C$DW$2092, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$2092, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2092, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2092, DW_AT_decl_line(0x234) .dwattr $C$DW$2092, DW_AT_decl_column(0x05) $C$DW$2093 .dwtag DW_TAG_member .dwattr $C$DW$2093, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2093, DW_AT_name("zoomRegionSizeY") .dwattr $C$DW$2093, DW_AT_TI_symbol_name("zoomRegionSizeY") .dwattr $C$DW$2093, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$2093, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2093, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2093, DW_AT_decl_line(0x235) .dwattr $C$DW$2093, DW_AT_decl_column(0x05) $C$DW$2094 .dwtag DW_TAG_member .dwattr $C$DW$2094, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$2094, DW_AT_name("zoomOutSizeX") .dwattr $C$DW$2094, DW_AT_TI_symbol_name("zoomOutSizeX") .dwattr $C$DW$2094, DW_AT_data_member_location[DW_OP_plus_uconst 0x20] .dwattr $C$DW$2094, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2094, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2094, DW_AT_decl_line(0x236) .dwattr $C$DW$2094, DW_AT_decl_column(0x05) $C$DW$2095 .dwtag DW_TAG_member .dwattr $C$DW$2095, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$2095, DW_AT_name("zoomOutSizeY") .dwattr $C$DW$2095, DW_AT_TI_symbol_name("zoomOutSizeY") .dwattr $C$DW$2095, DW_AT_data_member_location[DW_OP_plus_uconst 0x28] .dwattr $C$DW$2095, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2095, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2095, DW_AT_decl_line(0x237) .dwattr $C$DW$2095, DW_AT_decl_column(0x05) $C$DW$2096 .dwtag DW_TAG_member .dwattr $C$DW$2096, DW_AT_type(*$C$DW$T$125) .dwattr $C$DW$2096, DW_AT_name("zoomFactor") .dwattr $C$DW$2096, DW_AT_TI_symbol_name("zoomFactor") .dwattr $C$DW$2096, DW_AT_data_member_location[DW_OP_plus_uconst 0x30] .dwattr $C$DW$2096, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2096, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2096, DW_AT_decl_line(0x238) .dwattr $C$DW$2096, DW_AT_decl_column(0x05) $C$DW$2097 .dwtag DW_TAG_member .dwattr $C$DW$2097, DW_AT_type(*$C$DW$T$144) .dwattr $C$DW$2097, DW_AT_name("reserved") .dwattr $C$DW$2097, DW_AT_TI_symbol_name("reserved") .dwattr $C$DW$2097, DW_AT_data_member_location[DW_OP_plus_uconst 0x38] .dwattr $C$DW$2097, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2097, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2097, DW_AT_decl_line(0x239) .dwattr $C$DW$2097, DW_AT_decl_column(0x05) $C$DW$118 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$118, DW_AT_declaration .dwattr $C$DW$118, DW_AT_TI_symbol_name("_ZN15RasterZoomParamaSERKS_") .dwattr $C$DW$118, DW_AT_type(*$C$DW$T$486) .dwattr $C$DW$118, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2098 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2098, DW_AT_type(*$C$DW$T$488) .dwendtag $C$DW$118 .dwendtag $C$DW$T$490 .dwattr $C$DW$T$490, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$490, DW_AT_decl_line(0x231) .dwattr $C$DW$T$490, DW_AT_decl_column(0x01) $C$DW$T$480 .dwtag DW_TAG_typedef, DW_AT_name("RasterZoomParam") .dwattr $C$DW$T$480, DW_AT_type(*$C$DW$T$490) .dwattr $C$DW$T$480, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$480, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$480, DW_AT_decl_line(0x23a) .dwattr $C$DW$T$480, DW_AT_decl_column(0x03) $C$DW$T$487 .dwtag DW_TAG_const_type .dwattr $C$DW$T$487, DW_AT_type(*$C$DW$T$490) $C$DW$T$488 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$488, DW_AT_type(*$C$DW$T$487) .dwattr $C$DW$T$488, DW_AT_address_class(0x20) $C$DW$T$486 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$486, DW_AT_type(*$C$DW$T$490) .dwattr $C$DW$T$486, DW_AT_address_class(0x20) $C$DW$T$489 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$489, DW_AT_type(*$C$DW$T$486) .dwattr $C$DW$T$489, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2099 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2099, DW_AT_type(*$C$DW$T$488) .dwendtag $C$DW$T$489 $C$DW$T$364 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$364, DW_AT_name("SemaphoreCheckinIDType") .dwattr $C$DW$T$364, DW_AT_byte_size(0x04) $C$DW$2100 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_CINE_MANAGER"), DW_AT_const_value(0x00) .dwattr $C$DW$2100, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2100, DW_AT_decl_line(0x4b) .dwattr $C$DW$2100, DW_AT_decl_column(0x05) $C$DW$2101 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_OUTPUT_MANAGER"), DW_AT_const_value(0x01) .dwattr $C$DW$2101, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2101, DW_AT_decl_line(0x4c) .dwattr $C$DW$2101, DW_AT_decl_column(0x05) $C$DW$2102 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_STOP_COMPLETE"), DW_AT_const_value(0x02) .dwattr $C$DW$2102, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2102, DW_AT_decl_line(0x4d) .dwattr $C$DW$2102, DW_AT_decl_column(0x05) $C$DW$2103 .dwtag DW_TAG_enumerator, DW_AT_name("SEMAPHORE_CHECKIN_ID_DISPLAY_LAYOUT_CHANGE"), DW_AT_const_value(0x03) .dwattr $C$DW$2103, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$2103, DW_AT_decl_line(0x4e) .dwattr $C$DW$2103, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$364 .dwattr $C$DW$T$364, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$364, DW_AT_decl_line(0x4a) .dwattr $C$DW$T$364, DW_AT_decl_column(0x01) $C$DW$T$365 .dwtag DW_TAG_typedef, DW_AT_name("SemaphoreCheckinIDType") .dwattr $C$DW$T$365, DW_AT_type(*$C$DW$T$364) .dwattr $C$DW$T$365, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$365, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/Framework/CoreMgr/include/MultiCoreMsg.h") .dwattr $C$DW$T$365, DW_AT_decl_line(0x4f) .dwattr $C$DW$T$365, DW_AT_decl_column(0x03) $C$DW$T$1368 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1368, DW_AT_name("SpDspRfBuf_Type") .dwattr $C$DW$T$1368, DW_AT_byte_size(0x04) $C$DW$2104 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_INVALID"), DW_AT_const_value(-1) .dwattr $C$DW$2104, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2104, DW_AT_decl_line(0x12c) .dwattr $C$DW$2104, DW_AT_decl_column(0x05) $C$DW$2105 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_ECHO_PI0"), DW_AT_const_value(0x00) .dwattr $C$DW$2105, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2105, DW_AT_decl_line(0x12d) .dwattr $C$DW$2105, DW_AT_decl_column(0x05) $C$DW$2106 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_ECHO_PI1"), DW_AT_const_value(0x01) .dwattr $C$DW$2106, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2106, DW_AT_decl_line(0x12e) .dwattr $C$DW$2106, DW_AT_decl_column(0x05) $C$DW$2107 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG0_PI0"), DW_AT_const_value(0x02) .dwattr $C$DW$2107, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2107, DW_AT_decl_line(0x12f) .dwattr $C$DW$2107, DW_AT_decl_column(0x05) $C$DW$2108 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG0_PI1"), DW_AT_const_value(0x03) .dwattr $C$DW$2108, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2108, DW_AT_decl_line(0x130) .dwattr $C$DW$2108, DW_AT_decl_column(0x05) $C$DW$2109 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG1_PI0"), DW_AT_const_value(0x04) .dwattr $C$DW$2109, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2109, DW_AT_decl_line(0x131) .dwattr $C$DW$2109, DW_AT_decl_column(0x05) $C$DW$2110 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG1_PI1"), DW_AT_const_value(0x05) .dwattr $C$DW$2110, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2110, DW_AT_decl_line(0x132) .dwattr $C$DW$2110, DW_AT_decl_column(0x05) $C$DW$2111 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG2_PI0"), DW_AT_const_value(0x06) .dwattr $C$DW$2111, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2111, DW_AT_decl_line(0x133) .dwattr $C$DW$2111, DW_AT_decl_column(0x05) $C$DW$2112 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG2_PI1"), DW_AT_const_value(0x07) .dwattr $C$DW$2112, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2112, DW_AT_decl_line(0x134) .dwattr $C$DW$2112, DW_AT_decl_column(0x05) $C$DW$2113 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG3_PI0"), DW_AT_const_value(0x08) .dwattr $C$DW$2113, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2113, DW_AT_decl_line(0x135) .dwattr $C$DW$2113, DW_AT_decl_column(0x05) $C$DW$2114 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG3_PI1"), DW_AT_const_value(0x09) .dwattr $C$DW$2114, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2114, DW_AT_decl_line(0x136) .dwattr $C$DW$2114, DW_AT_decl_column(0x05) $C$DW$2115 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG4_PI0"), DW_AT_const_value(0x0a) .dwattr $C$DW$2115, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2115, DW_AT_decl_line(0x137) .dwattr $C$DW$2115, DW_AT_decl_column(0x05) $C$DW$2116 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG4_PI1"), DW_AT_const_value(0x0b) .dwattr $C$DW$2116, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2116, DW_AT_decl_line(0x138) .dwattr $C$DW$2116, DW_AT_decl_column(0x05) $C$DW$2117 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG5_PI0"), DW_AT_const_value(0x0c) .dwattr $C$DW$2117, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2117, DW_AT_decl_line(0x139) .dwattr $C$DW$2117, DW_AT_decl_column(0x05) $C$DW$2118 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG5_PI1"), DW_AT_const_value(0x0d) .dwattr $C$DW$2118, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2118, DW_AT_decl_line(0x13a) .dwattr $C$DW$2118, DW_AT_decl_column(0x05) $C$DW$2119 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG6_PI0"), DW_AT_const_value(0x0e) .dwattr $C$DW$2119, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2119, DW_AT_decl_line(0x13b) .dwattr $C$DW$2119, DW_AT_decl_column(0x05) $C$DW$2120 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG6_PI1"), DW_AT_const_value(0x0f) .dwattr $C$DW$2120, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2120, DW_AT_decl_line(0x13c) .dwattr $C$DW$2120, DW_AT_decl_column(0x05) $C$DW$2121 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG7_PI0"), DW_AT_const_value(0x10) .dwattr $C$DW$2121, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2121, DW_AT_decl_line(0x13d) .dwattr $C$DW$2121, DW_AT_decl_column(0x05) $C$DW$2122 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG7_PI1"), DW_AT_const_value(0x11) .dwattr $C$DW$2122, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2122, DW_AT_decl_line(0x13e) .dwattr $C$DW$2122, DW_AT_decl_column(0x05) $C$DW$2123 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG8_PI0"), DW_AT_const_value(0x12) .dwattr $C$DW$2123, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2123, DW_AT_decl_line(0x13f) .dwattr $C$DW$2123, DW_AT_decl_column(0x05) $C$DW$2124 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MB_ANG8_PI1"), DW_AT_const_value(0x13) .dwattr $C$DW$2124, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2124, DW_AT_decl_line(0x140) .dwattr $C$DW$2124, DW_AT_decl_column(0x05) $C$DW$2125 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_NV_ANG0"), DW_AT_const_value(0x14) .dwattr $C$DW$2125, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2125, DW_AT_decl_line(0x141) .dwattr $C$DW$2125, DW_AT_decl_column(0x05) $C$DW$2126 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_NV_ANG1"), DW_AT_const_value(0x15) .dwattr $C$DW$2126, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2126, DW_AT_decl_line(0x142) .dwattr $C$DW$2126, DW_AT_decl_column(0x05) $C$DW$2127 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_NV_ANG2"), DW_AT_const_value(0x16) .dwattr $C$DW$2127, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2127, DW_AT_decl_line(0x143) .dwattr $C$DW$2127, DW_AT_decl_column(0x05) $C$DW$2128 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_COLOR"), DW_AT_const_value(0x17) .dwattr $C$DW$2128, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2128, DW_AT_decl_line(0x144) .dwattr $C$DW$2128, DW_AT_decl_column(0x05) $C$DW$2129 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MMODE_PI0"), DW_AT_const_value(0x18) .dwattr $C$DW$2129, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2129, DW_AT_decl_line(0x145) .dwattr $C$DW$2129, DW_AT_decl_column(0x05) $C$DW$2130 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_MMODE_PI1"), DW_AT_const_value(0x19) .dwattr $C$DW$2130, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2130, DW_AT_decl_line(0x146) .dwattr $C$DW$2130, DW_AT_decl_column(0x05) $C$DW$2131 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_PW"), DW_AT_const_value(0x1a) .dwattr $C$DW$2131, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2131, DW_AT_decl_line(0x147) .dwattr $C$DW$2131, DW_AT_decl_column(0x05) $C$DW$2132 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_PAI"), DW_AT_const_value(0x1b) .dwattr $C$DW$2132, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2132, DW_AT_decl_line(0x148) .dwattr $C$DW$2132, DW_AT_decl_column(0x05) $C$DW$2133 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_RF_BUF_EOL"), DW_AT_const_value(0x1c) .dwattr $C$DW$2133, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2133, DW_AT_decl_line(0x149) .dwattr $C$DW$2133, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1368 .dwattr $C$DW$T$1368, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1368, DW_AT_decl_line(0x12b) .dwattr $C$DW$T$1368, DW_AT_decl_column(0x01) $C$DW$T$1369 .dwtag DW_TAG_typedef, DW_AT_name("SpDspRfBuf_Type") .dwattr $C$DW$T$1369, DW_AT_type(*$C$DW$T$1368) .dwattr $C$DW$T$1369, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1369, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1369, DW_AT_decl_line(0x14a) .dwattr $C$DW$T$1369, DW_AT_decl_column(0x03) $C$DW$T$1370 .dwtag DW_TAG_array_type .dwattr $C$DW$T$1370, DW_AT_type(*$C$DW$T$1369) .dwattr $C$DW$T$1370, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1370, DW_AT_byte_size(0x80) $C$DW$2134 .dwtag DW_TAG_subrange_type .dwattr $C$DW$2134, DW_AT_upper_bound(0x1f) .dwendtag $C$DW$T$1370 $C$DW$T$1364 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1364, DW_AT_name("SpDspSem_Type") .dwattr $C$DW$T$1364, DW_AT_byte_size(0x04) $C$DW$2135 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SEM_POST"), DW_AT_const_value(0x00) .dwattr $C$DW$2135, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2135, DW_AT_decl_line(0x110) .dwattr $C$DW$2135, DW_AT_decl_column(0x05) $C$DW$2136 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SEM_PEND"), DW_AT_const_value(0x01) .dwattr $C$DW$2136, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2136, DW_AT_decl_line(0x111) .dwattr $C$DW$2136, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1364 .dwattr $C$DW$T$1364, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1364, DW_AT_decl_line(0x10f) .dwattr $C$DW$T$1364, DW_AT_decl_column(0x01) $C$DW$T$1365 .dwtag DW_TAG_typedef, DW_AT_name("SpDspSem_Type") .dwattr $C$DW$T$1365, DW_AT_type(*$C$DW$T$1364) .dwattr $C$DW$T$1365, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1365, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1365, DW_AT_decl_line(0x112) .dwattr $C$DW$T$1365, DW_AT_decl_column(0x03) $C$DW$T$1442 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1442, DW_AT_name("SpDspShdb_Type") .dwattr $C$DW$T$1442, DW_AT_byte_size(0x04) $C$DW$2137 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_INVALID"), DW_AT_const_value(0x00) .dwattr $C$DW$2137, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2137, DW_AT_decl_line(0x14e) .dwattr $C$DW$2137, DW_AT_decl_column(0x05) $C$DW$2138 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_LINEAR_ARRAY"), DW_AT_const_value(0x01) .dwattr $C$DW$2138, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2138, DW_AT_decl_line(0x14f) .dwattr $C$DW$2138, DW_AT_decl_column(0x05) $C$DW$2139 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_CURVED_ARRAY"), DW_AT_const_value(0x02) .dwattr $C$DW$2139, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2139, DW_AT_decl_line(0x150) .dwattr $C$DW$2139, DW_AT_decl_column(0x05) $C$DW$2140 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_PHASED_ARRAY"), DW_AT_const_value(0x03) .dwattr $C$DW$2140, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2140, DW_AT_decl_line(0x151) .dwattr $C$DW$2140, DW_AT_decl_column(0x05) $C$DW$2141 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_SHDB_EOL"), DW_AT_const_value(0x04) .dwattr $C$DW$2141, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2141, DW_AT_decl_line(0x152) .dwattr $C$DW$2141, DW_AT_decl_column(0x05) .dwendtag $C$DW$T$1442 .dwattr $C$DW$T$1442, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1442, DW_AT_decl_line(0x14d) .dwattr $C$DW$T$1442, DW_AT_decl_column(0x01) $C$DW$T$1443 .dwtag DW_TAG_typedef, DW_AT_name("SpDspShdb_Type") .dwattr $C$DW$T$1443, DW_AT_type(*$C$DW$T$1442) .dwattr $C$DW$T$1443, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$1443, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1443, DW_AT_decl_line(0x153) .dwattr $C$DW$T$1443, DW_AT_decl_column(0x03) $C$DW$T$1282 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1282, DW_AT_name("SpDsp_AudioParams") .dwattr $C$DW$T$1282, DW_AT_byte_size(0x18) $C$DW$2142 .dwtag DW_TAG_member .dwattr $C$DW$2142, DW_AT_type(*$C$DW$T$143) .dwattr $C$DW$2142, DW_AT_name("audioTestLength") .dwattr $C$DW$2142, DW_AT_TI_symbol_name("audioTestLength") .dwattr $C$DW$2142, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2142, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2142, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2142, DW_AT_decl_line(0x65b) .dwattr $C$DW$2142, DW_AT_decl_column(0x02) $C$DW$2143 .dwtag DW_TAG_member .dwattr $C$DW$2143, DW_AT_type(*$C$DW$T$1275) .dwattr $C$DW$2143, DW_AT_name("audioTestSignal") .dwattr $C$DW$2143, DW_AT_TI_symbol_name("audioTestSignal") .dwattr $C$DW$2143, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$2143, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2143, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2143, DW_AT_decl_line(0x65c) .dwattr $C$DW$2143, DW_AT_decl_column(0x02) $C$DW$2144 .dwtag DW_TAG_member .dwattr $C$DW$2144, DW_AT_type(*$C$DW$T$1277) .dwattr $C$DW$2144, DW_AT_name("audioTestChannel") .dwattr $C$DW$2144, DW_AT_TI_symbol_name("audioTestChannel") .dwattr $C$DW$2144, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$2144, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2144, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2144, DW_AT_decl_line(0x65d) .dwattr $C$DW$2144, DW_AT_decl_column(0x02) $C$DW$119 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$119, DW_AT_declaration .dwattr $C$DW$119, DW_AT_TI_symbol_name("_ZN17SpDsp_AudioParamsaSERKS_") .dwattr $C$DW$119, DW_AT_type(*$C$DW$T$1278) .dwattr $C$DW$119, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2145 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2145, DW_AT_type(*$C$DW$T$1280) .dwendtag $C$DW$119 .dwendtag $C$DW$T$1282 .dwattr $C$DW$T$1282, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1282, DW_AT_decl_line(0x65a) .dwattr $C$DW$T$1282, DW_AT_decl_column(0x01) $C$DW$T$292 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_AudioParams") .dwattr $C$DW$T$292, DW_AT_type(*$C$DW$T$1282) .dwattr $C$DW$T$292, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$292, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$292, DW_AT_decl_line(0x65e) .dwattr $C$DW$T$292, DW_AT_decl_column(0x03) $C$DW$T$1279 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1279, DW_AT_type(*$C$DW$T$1282) $C$DW$T$1280 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1280, DW_AT_type(*$C$DW$T$1279) .dwattr $C$DW$T$1280, DW_AT_address_class(0x20) $C$DW$T$1278 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1278, DW_AT_type(*$C$DW$T$1282) .dwattr $C$DW$T$1278, DW_AT_address_class(0x20) $C$DW$T$1281 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1281, DW_AT_type(*$C$DW$T$1278) .dwattr $C$DW$T$1281, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2146 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2146, DW_AT_type(*$C$DW$T$1280) .dwendtag $C$DW$T$1281 $C$DW$T$1287 .dwtag DW_TAG_structure_type .dwattr $C$DW$T$1287, DW_AT_name("SpDsp_CodeVers") .dwattr $C$DW$T$1287, DW_AT_byte_size(0x20) $C$DW$2147 .dwtag DW_TAG_member .dwattr $C$DW$2147, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$2147, DW_AT_name("platform") .dwattr $C$DW$2147, DW_AT_TI_symbol_name("platform") .dwattr $C$DW$2147, DW_AT_data_member_location[DW_OP_plus_uconst 0x0] .dwattr $C$DW$2147, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2147, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2147, DW_AT_decl_line(0x54b) .dwattr $C$DW$2147, DW_AT_decl_column(0x05) $C$DW$2148 .dwtag DW_TAG_member .dwattr $C$DW$2148, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$2148, DW_AT_name("release") .dwattr $C$DW$2148, DW_AT_TI_symbol_name("release") .dwattr $C$DW$2148, DW_AT_data_member_location[DW_OP_plus_uconst 0x8] .dwattr $C$DW$2148, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2148, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2148, DW_AT_decl_line(0x54c) .dwattr $C$DW$2148, DW_AT_decl_column(0x05) $C$DW$2149 .dwtag DW_TAG_member .dwattr $C$DW$2149, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$2149, DW_AT_name("major") .dwattr $C$DW$2149, DW_AT_TI_symbol_name("major") .dwattr $C$DW$2149, DW_AT_data_member_location[DW_OP_plus_uconst 0x10] .dwattr $C$DW$2149, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2149, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2149, DW_AT_decl_line(0x54d) .dwattr $C$DW$2149, DW_AT_decl_column(0x05) $C$DW$2150 .dwtag DW_TAG_member .dwattr $C$DW$2150, DW_AT_type(*$C$DW$T$166) .dwattr $C$DW$2150, DW_AT_name("minor") .dwattr $C$DW$2150, DW_AT_TI_symbol_name("minor") .dwattr $C$DW$2150, DW_AT_data_member_location[DW_OP_plus_uconst 0x18] .dwattr $C$DW$2150, DW_AT_accessibility(DW_ACCESS_public) .dwattr $C$DW$2150, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2150, DW_AT_decl_line(0x54e) .dwattr $C$DW$2150, DW_AT_decl_column(0x05) $C$DW$120 .dwtag DW_TAG_subprogram, DW_AT_name("operator =") .dwattr $C$DW$120, DW_AT_declaration .dwattr $C$DW$120, DW_AT_TI_symbol_name("_ZN14SpDsp_CodeVersaSERKS_") .dwattr $C$DW$120, DW_AT_type(*$C$DW$T$1283) .dwattr $C$DW$120, DW_AT_accessibility(DW_ACCESS_public) $C$DW$2151 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2151, DW_AT_type(*$C$DW$T$1285) .dwendtag $C$DW$120 .dwendtag $C$DW$T$1287 .dwattr $C$DW$T$1287, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$1287, DW_AT_decl_line(0x54a) .dwattr $C$DW$T$1287, DW_AT_decl_column(0x01) $C$DW$T$158 .dwtag DW_TAG_typedef, DW_AT_name("SpDsp_CodeVers") .dwattr $C$DW$T$158, DW_AT_type(*$C$DW$T$1287) .dwattr $C$DW$T$158, DW_AT_language(DW_LANG_C_plus_plus) .dwattr $C$DW$T$158, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$T$158, DW_AT_decl_line(0x54f) .dwattr $C$DW$T$158, DW_AT_decl_column(0x03) $C$DW$T$1284 .dwtag DW_TAG_const_type .dwattr $C$DW$T$1284, DW_AT_type(*$C$DW$T$1287) $C$DW$T$1285 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1285, DW_AT_type(*$C$DW$T$1284) .dwattr $C$DW$T$1285, DW_AT_address_class(0x20) $C$DW$T$1283 .dwtag DW_TAG_reference_type .dwattr $C$DW$T$1283, DW_AT_type(*$C$DW$T$1287) .dwattr $C$DW$T$1283, DW_AT_address_class(0x20) $C$DW$T$1286 .dwtag DW_TAG_subroutine_type .dwattr $C$DW$T$1286, DW_AT_type(*$C$DW$T$1283) .dwattr $C$DW$T$1286, DW_AT_language(DW_LANG_C_plus_plus) $C$DW$2152 .dwtag DW_TAG_formal_parameter .dwattr $C$DW$2152, DW_AT_type(*$C$DW$T$1285) .dwendtag $C$DW$T$1286 $C$DW$T$1362 .dwtag DW_TAG_enumeration_type .dwattr $C$DW$T$1362, DW_AT_name("SpDsp_Command") .dwattr $C$DW$T$1362, DW_AT_byte_size(0x04) $C$DW$2153 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_NONE"), DW_AT_const_value(0x00) .dwattr $C$DW$2153, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2153, DW_AT_decl_line(0x37) .dwattr $C$DW$2153, DW_AT_decl_column(0x05) $C$DW$2154 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_STOP"), DW_AT_const_value(0x01) .dwattr $C$DW$2154, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/App/include/SpDsp_Interface.h") .dwattr $C$DW$2154, DW_AT_decl_line(0x38) .dwattr $C$DW$2154, DW_AT_decl_column(0x05) $C$DW$2155 .dwtag DW_TAG_enumerator, DW_AT_name("SPDSP_COMMAND_START"), DW_AT_const_value(0x02) .dwattr $C$DW$2155, DW_AT_decl_file("C:/git/phx_main_1/DevProjects/
