[参考译文] AM5728:无法访问'https://arago-project.org/git/projects/meta-processor-sdk/
Guru**** 2535150 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1085713/am5728-unable-to-access-https-arago-project-org-git-projects-meta-processor-sdk
部件号:AM5728
我们正在尝试为   AM57x 构建 TI 的处理器-SDK-LINUX-AM57X 06_02_00_81
  <remote fetch ="git://arago-project.org/git" name="Arago "/>
 <remote fetch ="git://arago-project.org/git/projects" name="Arago-projects"/>
这是我们的错误:
fatal: unable to access 'arago-project.org/.../': Problem with the SSL CA cert (path? access rights?)
meta-processor-sdk:
meta-processor-sdk: sleeping 4.0 seconds before retrying
meta-processor-sdk:
error: Cannot fetch meta-processor-sdk from git://arago-project.org/git/projects/meta-processor-sdk
Fetching: 100% (14/14), done in 13.368s
Garbage collecting: 100% (14/14), done in 0.031s
meta-processor-sdk:
meta-processor-sdk:
Fetching: 100% (1/1), done in 4.172s
Garbage collecting: 100% (1/1), done in 0.002s
error: Unable to fully sync the tree.
error: Downloading network changes failed.
Try re-running with "-j1 --fail-fast" to exit at the first error.
arago-project.org 网站是否已关闭?
    为了快速解决问题, 以下方法有效:
    echo -e '[url "https://github.com/"]\n  insteadOf = "git://github.com/"' >> ~/.gitconfig
    git config --global http.sslverify false
