[参考译文] J7200XSOMXEVM:网络无法正常工作
Guru**** 656470 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1115216/j7200xsomxevm-network-is-not-working
器件型号:J7200XSOMXEVM
以下是客户提出的问题、可能需要您的帮助:
SDK:TI-processor-sdk-rtos-j7200-evm-08_02_00_05
以太网固件已成功编译(未修改 SDK 代码)并在开发板上运行(客户在开发板的/sys/kernel/debug/remoteproc/remoteproc1/trace0路径下添加了打印信息)。
根据运行 演示章节 DRA821以太网固件(ethfw)、在网络电缆连接到 PC1 (端口3)和 PC2 (端口2)后、RJ45 LED 不会亮起。
登录开发板 ifconfig 信息如下所示:
[14:05:33][20220701_14:05:33]
[14:05:40]
[14:05:40]U-Boot SPL 2021.01-g44a87e3ab8 (Mar 24 2022 - 08:53:12 +0000)
[14:05:40]Model: Texas Instruments K3 J7200 SoC
[14:05:40]Board: J7200X-PM2-SOM rev E6
[14:05:40]SYSFW ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
[14:05:40]Trying to boot from MMC2
[14:05:40]Starting ATF on ARM64 core...
[14:05:40]
[14:05:40]NOTICE:  BL31: v2.5(release):08.01.00.006-dirty
[14:05:40]NOTICE:  BL31: Built : 08:20:28, Mar 24 2022
[14:05:40]
[14:05:40]U-Boot SPL 2021.01-g44a87e3ab8 (Mar 24 2022 - 08:21:51 +0000)
[14:05:40]Detected: J7X-BASE-CPB rev E3
[14:05:41]Detected: J7X-VSC8514-ETH rev E2
[14:05:41]Trying to boot from MMC2
[14:05:41]am654_sdhci sdhci@4fb0000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
[14:05:41]
[14:05:41]
[14:05:41]U-Boot 2021.01-g44a87e3ab8 (Mar 24 2022 - 08:21:51 +0000)
[14:05:41]
[14:05:41]SoC:   J7200 SR1.0
[14:05:41]Model: Texas Instruments K3 J7200 SoC
[14:05:41]Board: J7200X-PM2-SOM rev E6
[14:05:41]DRAM:  4 GiB
[14:05:41]Flash: 0 Bytes
[14:05:41]MMC:   sdhci@4f80000: 0, sdhci@4fb0000: 1
[14:05:41]Loading Environment from MMC... OK
[14:05:41]In:    serial@2800000
[14:05:41]Out:   serial@2800000
[14:05:41]Err:   serial@2800000
[14:05:41]am65_cpsw_nuss ethernet@46000000: K3 CPSW: nuss_ver: 0x6BA02102 cpsw_ver: 0x6BA82102 ale_ver: 0x00293904 Ports:1 mdio_freq:1000000
[14:05:41]Detected: J7X-BASE-CPB rev E3
[14:05:41]Net:   eth0: ethernet@46000000port@1
[14:05:43]Hit any key to stop autoboot:  0
[14:05:44]switch to partitions #0, OK
[14:05:44]mmc1 is current device
[14:05:44]SD/MMC found on device 1
[14:05:44]Failed to load 'boot.scr'
[14:05:44]0 bytes read in 1 ms (0 Bytes/s)
[14:05:44]Loaded env from uEnv.txt
[14:05:44]Importing environment from mmc1 ...
[14:05:44]19276288 bytes read in 204 ms (90.1 MiB/s)
[14:05:44]46143 bytes read in 4 ms (11 MiB/s)
[14:05:44]## Flattened Device Tree blob at 88000000
[14:05:44]   Booting using the fdt blob at 0x88000000
[14:05:44]   Loading Device Tree to 000000008fef1000, end 000000008fffffff ... OK
[14:05:44]
[14:05:44]Starting kernel ...
[14:05:44]
[14:05:44][    0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080]
[14:05:44][    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209) #1 SMP PREEMPT Thu Mar 24 08:25:59 UTC 2022
[14:05:44][    0.000000] Machine model: Texas Instruments K3 J7200 SoC
[14:05:44][    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[14:05:44][    0.000000] printk: bootconsole [ns16550a0] enabled
[14:05:44][    0.000000] efi: UEFI not found.
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool
[14:05:44][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB
[14:05:44][    0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool
[14:05:45][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 2 MiB
[14:05:45][    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-queues@a5000000, compatible id shared-dma-pool
[14:05:45][    0.000000] Reserved memory: created DMA memory pool at 0x00000000a5200000, size 30 MiB
[14:05:45][    0.000000] OF: reserved mem: initialized node r5f-virtual-eth-buffers@a5200000, compatible id shared-dma-pool
[14:05:45][    0.000000] Zone ranges:
[14:05:45][    0.000000]   DMA      [mem 0x0000000080000000-0x00000000ffffffff]
[14:05:45][    0.000000]   DMA32    empty
[14:05:45][    0.000000]   Normal   [mem 0x0000000100000000-0x00000008ffffffff]
[14:05:45][    0.000000] Movable zone start for each node
[14:05:45][    0.000000] Early memory node ranges
[14:05:45][    0.000000]   node   0: [mem 0x0000000080000000-0x000000009e7fffff]
[14:05:45][    0.000000]   node   0: [mem 0x000000009e800000-0x00000000a47fffff]
[14:05:45][    0.000000]   node   0: [mem 0x00000000a4800000-0x00000000a4ffffff]
[14:05:45][    0.000000]   node   0: [mem 0x00000000a5000000-0x00000000a6ffffff]
[14:05:45][    0.000000]   node   0: [mem 0x00000000a7000000-0x00000000ffffffff]
[14:05:45][    0.000000]   node   0: [mem 0x0000000880000000-0x00000008ffffffff]
[14:05:45][    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000008ffffffff]
[14:05:45][    0.000000] cma: Reserved 512 MiB at 0x00000000e0000000
[14:05:45][    0.000000] psci: probing for conduit method from DT.
[14:05:45][    0.000000] psci: PSCIv1.1 detected in firmware.
[14:05:45][    0.000000] psci: Using standard PSCI v0.2 function IDs
[14:05:45][    0.000000] psci: Trusted OS migration not required
[14:05:45][    0.000000] psci: SMC Calling Convention v1.2
[14:05:45][    0.000000] percpu: Embedded 2 pages/cpu s49880 r8192 d73000 u131072
[14:05:45][    0.000000] Detected PIPT I-cache on CPU0
[14:05:45][    0.000000] CPU features: detected: GIC system register CPU interface
[14:05:45][    0.000000] CPU features: detected: EL2 vector hardening
[14:05:45][    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[14:05:45][    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 65472
[14:05:45][    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:1m(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),256k(ospi.env),256k(ospi.env.backup),57088k@8m(ospi.rootfs),256k(ospi.phypattern);47034000.hyperbus:1m(hbmc.tiboot3),2m(hbmc.tispl),4m(hbmc.u-boot),256k(hbmc.env),-@8m(hbmc.rootfs) root=PARTUUID=d9117e3b-02 rw rootfstype=ext4 rootwait
[14:05:45][    0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes, linear)
[14:05:45][    0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes, linear)
[14:05:45][    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[14:05:45][    0.000000] software IO TLB: mapped [mem 0x00000000dc000000-0x00000000e0000000] (64MB)
[14:05:45][    0.000000] Memory: 3441792K/4194304K available (10880K kernel code, 1288K rwdata, 4352K rodata, 1856K init, 751K bss, 228224K reserved, 524288K cma-reserved)
[14:05:45][    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[14:05:45][    0.000000] rcu: Preemptible hierarchical RCU implementation.
[14:05:45][    0.000000] rcu:     RCU event tracing is enabled.
[14:05:45][    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=2.
[14:05:45][    0.000000]  Trampoline variant of Tasks RCU enabled.
[14:05:45][    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[14:05:45][    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[14:05:45][    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[14:05:45][    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[14:05:45][    0.000000] GICv3: 960 SPIs implemented
[14:05:45][    0.000000] GICv3: 0 Extended SPIs implemented
[14:05:45][    0.000000] GICv3: Distributor has no Range Selector support
[14:05:45][    0.000000] GICv3: 16 PPIs implemented
[14:05:45][    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000
[14:05:45][    0.000000] ITS [mem 0x01820000-0x0182ffff]
[14:05:45][    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[14:05:45][    0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @880800000 (flat, esz 8, psz 64K, shr 0)
[14:05:45][    0.000000] ITS: using cache flushing for cmd queue
[14:05:45][    0.000000] GICv3: using LPI property table @0x00000008800b0000
[14:05:45][    0.000000] GIC: using cache flushing for LPI property table
[14:05:45][    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000008800c0000
[14:05:45][    0.000000] random: get_random_bytes called from start_kernel+0x31c/0x4c4 with crng_init=0
[14:05:45][    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[14:05:45][    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[14:05:45][    0.000002] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[14:05:45][    0.008296] Console: colour dummy device 80x25
[14:05:45][    0.012855] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[14:05:45][    0.023526] pid_max: default: 32768 minimum: 301
[14:05:45][    0.028274] LSM: Security Framework initializing
[14:05:45][    0.033025] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[14:05:45][    0.040601] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes, linear)
[14:05:45][    0.050156] rcu: Hierarchical SRCU implementation.
[14:05:45][    0.055330] Platform MSI: msi-controller@1820000 domain created
[14:05:45][    0.061511] PCI/MSI: /bus@100000/interrupt-controller@1800000/msi-controller@1820000 domain created
[14:05:45][    0.070800] EFI services will not be available.
[14:05:45][    0.075645] smp: Bringing up secondary CPUs ...
[14:05:45][    0.081042] Detected PIPT I-cache on CPU1
[14:05:45][    0.081070] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000
[14:05:45][    0.081083] GICv3: CPU1: using allocated LPI pending table @0x00000008800d0000
[14:05:45][    0.081125] CPU1: Booted secondary processor 0x0000000001 [0x411fd080]
[14:05:45][    0.081213] smp: Brought up 1 node, 2 CPUs
[14:05:45][    0.110575] SMP: Total of 2 processors activated.
[14:05:45][    0.115383] CPU features: detected: 32-bit EL0 Support
[14:05:45][    0.120642] CPU features: detected: CRC32 instructions
[14:05:45][    0.134210] CPU: All CPU(s) started at EL2
[14:05:45][    0.138417] alternatives: patching kernel code
[14:05:45][    0.143567] devtmpfs: initialized
[14:05:45][    0.149893] KASLR disabled due to lack of seed
[14:05:45][    0.154625] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[14:05:45][    0.164598] futex hash table entries: 512 (order: -1, 32768 bytes, linear)
[14:05:45][    0.172464] pinctrl core: initialized pinctrl subsystem
[14:05:45][    0.178115] DMI not present or invalid.
[14:05:45][    0.182416] NET: Registered protocol family 16
[14:05:45][    0.190475] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[14:05:45][    0.197856] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[14:05:45][    0.205911] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[14:05:45][    0.214280] thermal_sys: Registered thermal governor 'step_wise'
[14:05:45][    0.214284] thermal_sys: Registered thermal governor 'power_allocator'
[14:05:45][    0.220671] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[14:05:45][    0.234337] ASID allocator initialised with 65536 entries
[14:05:45][    0.251301] HugeTLB registered 16.0 GiB page size, pre-allocated 0 pages
[14:05:45][    0.258161] HugeTLB registered 512 MiB page size, pre-allocated 0 pages
[14:05:45][    0.264920] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[14:05:45][    0.274449] cryptd: max_cpu_qlen set to 1000
[14:05:45][    0.281891] k3-chipinfo 43000014.chipid: Family:J7200 rev:SR1.0 JTAGID[0x0bb6d02f] Detected
[14:05:45][    0.290768] vsys_3v3: supplied by evm_12v0
[14:05:45][    0.295261] vsys_5v0: supplied by evm_12v0
[14:05:45][    0.300060] iommu: Default domain type: Translated
[14:05:45][    0.305233] SCSI subsystem initialized
[14:05:45][    0.309423] mc: Linux media interface: v0.10
[14:05:45][    0.313817] videodev: Linux video capture interface: v2.00
[14:05:45][    0.319463] pps_core: LinuxPPS API ver. 1 registered
[14:05:45][    0.324536] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[14:05:45][    0.333877] PTP clock support registered
[14:05:45][    0.337898] EDAC MC: Ver: 3.0.0
[14:05:45][    0.341846] FPGA manager framework
[14:05:45][    0.345375] Advanced Linux Sound Architecture Driver Initialized.
[14:05:45][    0.352142] clocksource: Switched to clocksource arch_sys_counter
[14:05:45][    0.358618] VFS: Disk quotas dquot_6.6.0
[14:05:45][    0.362695] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes)
[14:05:45][    0.372989] NET: Registered protocol family 2
[14:05:45][    0.377764] IP idents hash table entries: 65536 (order: 3, 524288 bytes, linear)
[14:05:45][    0.386639] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes, linear)
[14:05:45][    0.395500] TCP established hash table entries: 32768 (order: 2, 262144 bytes, linear)
[14:05:45][    0.403716] TCP bind hash table entries: 32768 (order: 3, 524288 bytes, linear)
[14:05:45][    0.411687] TCP: Hash tables configured (established 32768 bind 32768)
[14:05:45][    0.418532] UDP hash table entries: 2048 (order: 0, 65536 bytes, linear)
[14:05:45][    0.425438] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes, linear)
[14:05:45][    0.432862] NET: Registered protocol family 1
[14:05:45][    0.437776] RPC: Registered named UNIX socket transport module.
[14:05:45][    0.443852] RPC: Registered udp transport module.
[14:05:45][    0.448677] RPC: Registered tcp transport module.
[14:05:45][    0.453484] RPC: Registered tcp NFSv4.1 backchannel transport module.
[14:05:45][    0.460069] PCI: CLS 0 bytes, default 64
[14:05:45][    0.464454] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[14:05:45][    0.476322] Initialise system trusted keyrings
[14:05:45][    0.481005] workingset: timestamp_bits=46 max_order=16 bucket_order=0
[14:05:45][    0.489515] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[14:05:45][    0.495871] NFS: Registering the id_resolver key type
[14:05:45][    0.501082] Key type id_resolver registered
[14:05:45][    0.505361] Key type id_legacy registered
[14:05:46][    0.509497] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[14:05:46][    0.516348] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[14:05:46][    0.524018] 9p: Installing v9fs 9p2000 file system support
[14:05:46][    0.550004] Key type asymmetric registered
[14:05:46][    0.554203] Asymmetric key parser 'x509' registered
[14:05:46][    0.559214] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[14:05:46][    0.566776] io scheduler mq-deadline registered
[14:05:46][    0.571402] io scheduler kyber registered
[14:05:46][    0.576617] pinctrl-single 4301c000.pinctrl: 94 pins, size 376
[14:05:46][    0.582831] pinctrl-single 11c000.pinctrl: 173 pins, size 692
[14:05:46][    0.591098] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[14:05:46][    0.597406] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[14:05:46][    0.605484] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[14:05:46][    0.619767] brd: module loaded
[14:05:46][    0.627464] loop: module loaded
[14:05:46][    0.631106] megasas: 07.714.04.00-rc1
[14:05:46][    0.636629] tun: Universal TUN/TAP device driver, 1.6
[14:05:46][    0.642096] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[14:05:46][    0.648514] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[14:05:46][    0.654595] sky2: driver version 1.30
[14:05:46][    0.658930] VFIO - User Level meta-driver version: 0.3
[14:05:46][    0.664701] i2c /dev entries driver
[14:05:46][    0.668805] sdhci: Secure Digital Host Controller Interface driver
[14:05:46][    0.675143] sdhci: Copyright(c) Pierre Ossman
[14:05:46][    0.679958] sdhci-pltfm: SDHCI platform and OF driver helper
[14:05:46][    0.686256] ledtrig-cpu: registered to indicate activity on CPUs
[14:05:46][    0.692616] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[14:05:46][    0.699850] optee: probing for conduit method.
[14:05:46][    0.704414] optee: revision 3.12 (3d47a131)
[14:05:46][    0.704752] optee: initialized driver
[14:05:46][    0.714190] NET: Registered protocol family 17
[14:05:46][    0.718826] 9pnet: Installing 9P2000 support
[14:05:46][    0.723230] Key type dns_resolver registered
[14:05:46][    0.727700] Loading compiled-in X.509 certificates
[14:05:46][    0.737573] k3-ringacc 2b800000.ringacc: Failed to get MSI domain
[14:05:46][    0.743963] k3-ringacc 3c000000.ringacc: Failed to get MSI domain
[14:05:46][    0.751928] ti-sci 44083000.dmsc: ABI: 3.1 (firmware rev 0x0016 '22.1.1--v2022.01 (Terrific Llam')
[14:05:46][    0.777387] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz
[14:05:46][    0.783700] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz
[14:05:46][    0.790001] omap_i2c 42120000.i2c: bus 2 rev0.12 at 100 kHz
[14:05:46][    0.796492] pca953x 3-0021: supply vcc not found, using dummy regulator
[14:05:46][    0.803339] pca953x 3-0021: using no AI
[14:05:46][    0.828714] pca953x 3-0020: supply vcc not found, using dummy regulator
[14:05:46][    0.835558] pca953x 3-0020: using no AI
[14:05:46][    0.840193] pca953x 3-0022: supply vcc not found, using dummy regulator
[14:05:46][    0.847017] pca953x 3-0022: using AI
[14:05:46][    0.851106] random: fast init done
[14:05:46][    0.854872] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz
[14:05:46][    0.861286] pca953x 4-0020: supply vcc not found, using dummy regulator
[14:05:46][    0.868148] pca953x 4-0020: using no AI
[14:05:46][    0.892537] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz
[14:05:46][    0.898786] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz
[14:05:46][    0.904992] omap_i2c 2030000.i2c: bus 6 rev0.12 at 100 kHz
[14:05:46][    0.911200] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz
[14:05:46][    0.917405] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz
[14:05:46][    0.923605] omap_i2c 2060000.i2c: bus 9 rev0.12 at 100 kHz
[14:05:46][    0.929828] ti-sci-intr bus@100000:bus@28380000:interrupt-controller2: Interrupt Router 137 domain created
[14:05:46][    0.939840] ti-sci-intr bus@100000:interrupt-controller0: Interrupt Router 131 domain created
[14:05:46][    0.948670] ti-sci-intr bus@100000:bus@30000000:interrupt-controller1: Interrupt Router 213 domain created
[14:05:46][    0.958709] ti-sci-inta 33d00000.msi-controller: Interrupt Aggregator domain 209 created
[14:05:46][    0.968614] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[14:05:46][    0.976300] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[14:05:46][    0.984604] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[14:05:46][    0.992890] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[14:05:47][    2.012429] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[14:05:47][    2.018869] pci_bus 0000:00: root bus resource [bus 00-0f]
[14:05:47][    2.024477] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[14:05:47][    2.034168] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[14:05:47][    2.041227] pci 0000:00:00.0: [104c:b00f] type 01 class 0x060400
[14:05:47][    2.047467] pci 0000:00:00.0: supports D1
[14:05:47][    2.051565] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[14:05:47][    2.057456] pci 0000:00:00.0: reg 0x224: [mem 0x00000000-0x003fffff 64bit]
[14:05:47][    2.064483] pci 0000:00:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00ffffff 64bit] (contains BAR0 for 4 VFs)
[14:05:47][    2.075290] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[14:05:47][    2.084246] pci_bus 0000:01: busn_res: [bus 01-0f] end is updated to 01
[14:05:47][    2.091022] pci 0000:00:00.0: BAR 7: assigned [mem 0x18400000-0x193fffff 64bit]
[14:05:47][    2.098500] pci 0000:00:00.0: PCI bridge to [bus 01]
[14:05:47][    2.103833] pcieport 0000:00:00.0: PME: Signaling with IRQ 36
[14:05:47][    2.110930] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,32] sci-dev-id:235
[14:05:47][    2.120845] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled
[14:05:47][    2.127610] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[14:05:47][    2.137287] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[120,200] sci-dev-id:211
[14:05:47][    2.147466] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled
[14:05:47][    2.154231] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66349100, num_proxies:64
[14:05:47][    2.162270] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 15, base_baud = 6000000) is a 8250
[14:05:47][    2.171867] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250
[14:05:47][    2.180626] printk: console [ttyS2] enabled
[14:05:47][    2.189067] printk: bootconsole [ns16550a0] disabled
[14:05:47][    2.199746] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250
[14:05:47][    2.376153] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
[14:05:47][    2.409574] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[14:05:47][    2.417905] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[14:05:47][    2.433284] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010b, freq:200000000, add_val:4 pps:0
[14:05:47][    2.442581] mmc0: CQHCI version 5.10
[14:05:47][    2.450264] vdd_mmc1: supplied by vsys_3v3
[14:05:47][    2.455248] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc8900
[14:05:47][    2.462164] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc8900
[14:05:47][    2.469338] ti-udma 285c0000.dma-controller: Channels: 26 (tchan: 13, rchan: 13, gp-rflow: 8)
[14:05:47][    2.479289] ti-udma 31150000.dma-controller: Channels: 50 (tchan: 25, rchan: 25, gp-rflow: 8)
[14:05:47][    2.486795] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[14:05:47][    2.497869] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[14:05:47][    2.502852] 7 cmdlinepart partitions found on MTD device 47040000.spi.0
[14:05:48][    2.509454] Creating 7 MTD partitions on "47040000.spi.0":
[14:05:48][    2.514928] 0x000000000000-0x000000100000 : "ospi.tiboot3"
[14:05:48][    2.521114] 0x000000100000-0x000000300000 : "ospi.tispl"
[14:05:48][    2.527137] 0x000000300000-0x000000700000 : "ospi.u-boot"
[14:05:48][    2.533206] 0x000000700000-0x000000740000 : "ospi.env"
[14:05:48][    2.538979] 0x000000740000-0x000000780000 : "ospi.env.backup"
[14:05:48][    2.545436] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[14:05:48][    2.551491] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[14:05:48][    2.582918] mmc0: Command Queue Engine enabled
[14:05:48][    2.587386] mmc0: new HS400 MMC card at address 0001
[14:05:48][    2.592749] mmcblk0: mmc0:0001 S0J56X 14.8 GiB
[14:05:48][    2.597480] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB
[14:05:48][    2.603601] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB
[14:05:48][    2.609646] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (237:0)
[14:05:48][    2.618109]  mmcblk0: p1 p2 p3
[14:05:48][    2.728161] davinci_mdio 46000f00.mdio: davinci mdio revision 9.7, bus freq 20000
[14:05:48][    2.758797] davinci_mdio 46000f00.mdio: phy[0]: device 46000f00.mdio:00, driver TI DP83867
[14:05:48][    2.767127] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA02102, cpsw version 0x6BA82102 Ports: 2 quirks:00000000
[14:05:48][    2.780668] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48
[14:05:48][    2.787705] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 1.4
[14:05:48][    2.794947] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64
[14:05:48][    2.801390] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010b, freq:500000000, add_val:1 pps:0
[14:05:48][    2.811767] debugfs: Directory 'pd:240' with parent 'pm_genpd' already present!
[14:05:48][    2.812051] mmc1: CQHCI version 5.10
[14:05:48][    2.823060] ALSA device list:
[14:05:48][    2.826043]   No soundcards found.
[14:05:48][    2.864163] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[14:05:48][    2.872079] Waiting for root device PARTUUID=d9117e3b-02...
[14:05:48][    2.924198] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
[14:05:48][    2.931336] mmcblk1: mmc1:aaaa SC16G 14.8 GiB
[14:05:48][    2.940932]  mmcblk1: p1 p2
[14:05:48][    3.237285] EXT4-fs (mmcblk1p2): 1 orphan inode deleted
[14:05:48][    3.242539] EXT4-fs (mmcblk1p2): recovery complete
[14:05:48][    3.262091] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[14:05:48][    3.270218] VFS: Mounted root (ext4 filesystem) on device 179:98.
[14:05:48][    3.281204] devtmpfs: mounted
[14:05:48][    3.285378] Freeing unused kernel memory: 1856K
[14:05:48][    3.289971] Run /sbin/init as init process
[14:05:48][    3.408600] systemd[1]: System time before build time, advancing clock.
[14:05:48][    3.455135] NET: Registered protocol family 10
[14:05:48][    3.460267] Segment Routing with IPv6
[14:05:48][    3.480058] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[14:05:49][    3.501950] systemd[1]: Detected architecture arm64.
[14:05:49]
[14:05:49]Welcome to Arago 2021.09!
[14:05:49]
[14:05:49][    3.541001] systemd[1]: Set hostname to <j7200-evm>.
[14:05:49][    3.747546] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock → /run/docker.sock; please update the unit file accordingly.
[14:05:49][    3.838453] random: systemd: uninitialized urandom read (16 bytes read)
[14:05:49][    3.845196] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[14:05:49][    3.857538] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[14:05:49][    3.868016] systemd[1]: Created slice system-getty.slice.
[14:05:49][  OK  ] Created slice system-getty.slice.
[14:05:49][    3.888274] random: systemd: uninitialized urandom read (16 bytes read)
[14:05:49][    3.895849] systemd[1]: Created slice system-serial\x2dgetty.slice.
[14:05:49][  OK  ] Created slice system-serial\x2dgetty.slice.
[14:05:49][    3.916269] random: systemd: uninitialized urandom read (16 bytes read)
[14:05:49][    3.923829] systemd[1]: Created slice system-syslog\x2dng.slice.
[14:05:49][  OK  ] Created slice system-syslog\x2dng.slice.
[14:05:49][    3.945257] systemd[1]: Created slice User and Session Slice.
[14:05:49][  OK  ] Created slice User and Session Slice.
[14:05:49][    3.968450] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[14:05:49][  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[14:05:49][    3.992408] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[14:05:49][  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[14:05:49][    4.016360] systemd[1]: Reached target Paths.
[14:05:49][  OK  ] Reached target Paths.
[14:05:49][    4.032284] systemd[1]: Reached target Remote File Systems.
[14:05:49][  OK  ] Reached target Remote File Systems.
[14:05:49][    4.052270] systemd[1]: Reached target Slices.
[14:05:49][  OK  ] Reached target Slices.
[14:05:49][    4.068284] systemd[1]: Reached target Swap.
[14:05:49][  OK  ] Reached target Swap.
[14:05:49][    4.090823] systemd[1]: Listening on RPCbind Server Activation Socket.
[14:05:49][  OK  ] Listening on RPCbind Server Activation Socket.
[14:05:49][    4.112295] systemd[1]: Reached target RPC Port Mapper.
[14:05:49][  OK  ] Reached target RPC Port Mapper.
[14:05:49][    4.139538] systemd[1]: Listening on Process Core Dump Socket.
[14:05:49][  OK  ] Listening on Process Core Dump Socket.
[14:05:49][    4.160457] systemd[1]: Listening on initctl Compatibility Named Pipe.
[14:05:49][  OK  ] Listening on initctl Compatibility Named Pipe.
[14:05:49][    4.192689] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[14:05:49][    4.201125] systemd[1]: Listening on Journal Socket (/dev/log).
[14:05:49][  OK  ] Listening on Journal Socket (/dev/log).
[14:05:49][    4.224618] systemd[1]: Listening on Journal Socket.
[14:05:49][  OK  ] Listening on Journal Socket.
[14:05:49][    4.240683] systemd[1]: Listening on Network Service Netlink Socket.
[14:05:49][  OK  ] Listening on Network Service Netlink Socket.
[14:05:49][    4.264612] systemd[1]: Listening on udev Control Socket.
[14:05:49][  OK  ] Listening on udev Control Socket.
[14:05:49][    4.284482] systemd[1]: Listening on udev Kernel Socket.
[14:05:49][  OK  ] Listening on udev Kernel Socket.
[14:05:49][    4.308094] systemd[1]: Mounting Huge Pages File System...
[14:05:49]         Mounting Huge Pages File System...
[14:05:49][    4.327688] systemd[1]: Mounting POSIX Message Queue File System...
[14:05:49]         Mounting POSIX Message Queue File System...
[14:05:49][    4.351880] systemd[1]: Mounting Kernel Debug File System...
[14:05:49]         Mounting Kernel Debug File System...
[14:05:49][    4.374246] systemd[1]: Mounting Temporary Directory (/tmp)...
[14:05:49]         Mounting Temporary Directory (/tmp)...
[14:05:49][    4.395728] systemd[1]: Starting Create list of static device nodes for the current kernel...
[14:05:49]         Starting Create list of st…odes for the current kernel...
[14:05:49][    4.423989] systemd[1]: Starting RPC Bind...
[14:05:49]         Starting RPC Bind...
[14:05:49][    4.440360] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[14:05:49][    4.453770] systemd[1]: Starting Journal Service...
[14:05:49]         Starting Journal Service...
[14:05:49][    4.473957] systemd[1]: Starting Load Kernel Modules...
[14:05:49]         Starting Load Kernel Modules...
[14:05:49][    4.495822] systemd[1]: Starting Remount Root and Kernel File Systems...
[14:05:50]         Starting Remount Root and Kernel File Systems...
[14:05:50][    4.509493] cryptodev: loading out-of-tree module taints kernel.
[14:05:50][    4.525382] systemd[1]: Starting udev Coldplug all Devices...
[14:05:50][    4.529901] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[14:05:50][    4.538436] cryptodev: driver 1.10 loaded.
[14:05:50]         Starting udev Coldplug all Devices...
[14:05:50][    4.555606] systemd[1]: Started RPC Bind.
[14:05:50][  OK  ] Started RPC Bind.
[14:05:50][    4.572694] systemd[1]: Started Journal Service.
[14:05:50][  OK  ] Started Journal Service.
[14:05:50][  OK  ] Mounted Huge Pages File System.
[14:05:50][  OK  ] Mounted POSIX Message Queue File System.
[14:05:50][  OK  ] Mounted Kernel Debug File System.
[14:05:50][  OK  ] Mounted Temporary Directory (/tmp).
[14:05:50][  OK  ] Started Create list of sta… nodes for the current kernel.
[14:05:50][  OK  ] Started Load Kernel Modules.
[14:05:50][  OK  ] Started Remount Root and Kernel File Systems.
[14:05:50]         Mounting Kernel Configuration File System...
[14:05:50]         Starting Flush Journal to Persistent Storage...
[14:05:50][    4.756435] systemd-journald[156]: Received client request to flush runtime journal.
[14:05:50]         Starting Apply Kernel Variables...
[14:05:50]         Starting Create Static Device Nodes in /dev...
[14:05:50][  OK  ] Mounted Kernel Configuration File System.
[14:05:50][  OK  ] Started Flush Journal to Persistent Storage.
[14:05:50][  OK  ] Started Apply Kernel Variables.
[14:05:50][  OK  ] Started Create Static Device Nodes in /dev.
[14:05:50][  OK  ] Reached target Local File Systems (Pre).
[14:05:50]         Mounting /media/ram...
[14:05:50]         Mounting /var/volatile...
[14:05:50]         Starting udev Kernel Device Manager...
[14:05:50][  OK  ] Started udev Coldplug all Devices.
[14:05:50][  OK  ] Mounted /media/ram.
[14:05:50][  OK  ] Mounted /var/volatile.
[14:05:50]         Starting udev Wait for Complete Device Initialization...
[14:05:50]         Starting Load/Save Random Seed...
[14:05:50][  OK  ] Reached target Local File Systems.
[14:05:50]         Starting Create Volatile Files and Directories...
[14:05:50][  OK  ] Started udev Kernel Device Manager.
[14:05:50][  OK  ] Started Create Volatile Files and Directories.
[14:05:50]         Starting Network Time Synchronization...
[14:05:50]         Starting Update UTMP about System Boot/Shutdown...
[14:05:50][  OK  ] Started Update UTMP about System Boot/Shutdown.
[14:05:50][  OK  ] Started Network Time Synchronization.
[14:05:50][  OK  ] Reached target System Time Set.
[14:05:50][  OK  ] Reached target System Time Synchronized.
[14:05:51][    5.673930] ti-udma 285c0000.dma-controller: chan1: is running!
[14:05:51][    5.727230] platform 41000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[14:05:51][    5.922062] platform 41000000.r5f: configured R5F for IPC-only mode
[14:05:51][    5.983146] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000
[14:05:51][    6.137636] remoteproc remoteproc0: 41000000.r5f is available
[14:05:51][    6.244250] remoteproc remoteproc0: attaching to 41000000.r5f
[14:05:51][    6.387216] platform 41000000.r5f: R5F core initialized in IPC-only mode
[14:05:51][    6.474777]  remoteproc0#vdev0buffer: assigned reserved memory node r5f-dma-memory@a0000000
[14:05:51][    6.484220] virtio_rpmsg_bus virtio0: rpmsg host is online
[14:05:51][    6.490349]  remoteproc0#vdev0buffer: registered virtio0 (type 7)
[14:05:51][    6.495389] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[14:05:52][    6.504223] remoteproc remoteproc0: remote processor 41000000.r5f is now attached
[14:05:52][    6.507628] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[14:05:52][    6.536853] platform 5c00000.r5f: configured R5F for remoteproc mode
[14:05:52][    6.584242] platform 5c00000.r5f: assigned reserved memory node r5f-dma-memory@a2000000
[14:05:52][    6.736825] remoteproc remoteproc1: 5c00000.r5f is available
[14:05:52][    6.745945] platform 5d00000.r5f: configured R5F for remoteproc mode
[14:05:52][    6.760856] remoteproc remoteproc1: powering up 5c00000.r5f
[14:05:52][    6.766479] remoteproc remoteproc1: Booting fw image j7200-main-r5f0_0-fw, size 634196
[14:05:52][    6.779546] platform 5d00000.r5f: assigned reserved memory node r5f-dma-memory@a3000000
[14:05:52][    6.787685]  remoteproc1#vdev0buffer: assigned reserved memory node r5f-dma-memory@a2000000
[14:05:52][    6.797338] virtio_rpmsg_bus virtio1: rpmsg host is online
[14:05:52][    6.803597]  remoteproc1#vdev0buffer: registered virtio1 (type 7)
[14:05:52][    6.809821] remoteproc remoteproc1: remote processor 5c00000.r5f is now up
[14:05:52][    6.912070] virtio_rpmsg_bus virtio1: creating channel ti.ethfw.notifyservice addr 0x1e
[14:05:52][    6.921956] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a
[14:05:52][    6.934995] virtio_rpmsg_bus virtio1: creating channel rpmsg-kdrv addr 0x1a
[14:05:52][    6.947515] virtio_rpmsg_bus virtio1: channel rpmsg-kdrv:ffffffff:1a already exist
[14:05:52][    6.960615] remoteproc remoteproc2: 5d00000.r5f is available
[14:05:52][    6.960877] virtio_rpmsg_bus virtio1: rpmsg_create_channel failed
[14:05:52][    6.978464] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[14:05:52][    6.985815] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0x15
[14:05:52][    7.000256] virtio_rpmsg_bus virtio1: channel rpmsg_chrdev:ffffffff:15 already exist
[14:05:52][    7.011820] virtio_rpmsg_bus virtio1: rpmsg_create_channel failed
[14:05:52][    7.018078] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: Device info: permissions: 3FFFFFFF uart_id: 3
[14:05:52][    7.037705] rpmsg-kdrv-eth-switch rpmsg-kdrv-1-mpu_1_0_ethswitch-device-0: FW ver 0.2 (rev 0) 26/Jun/2022 SHA:
[14:05:52][    7.052869] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: Device info: permissions: 3FFFFFFF uart_id: 3
[14:05:52][    7.068937] rpmsg-kdrv-eth-switch rpmsg-kdrv-3-mpu_1_0_ethmac-device-1: FW ver 0.2 (rev 0) 26/Jun/2022 SHA:
[14:05:52][    7.084368] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rpmsg attach_ext - rx_mtu:1522 features:0000000B tx_mtu[0]:2024 flow_idx:84 tx_cpsw_psil_dst_id:51712 mac_addr:70:ff:76:1d:92:c1 mac-only:0
[14:05:52][    7.112479] remoteproc remoteproc2: powering up 5d00000.r5f
[14:05:52][    7.118068] remoteproc remoteproc2: Booting fw image j7200-main-r5f0_1-fw, size 2809848
[14:05:52][    7.132382] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac loaded
[14:05:52][    7.140341] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: rdev_features:0000000B rdev_mtu:1522 flow_id:84 tx_psil_dst_id:4A00 mac_only:0
[14:05:52][    7.154172]  remoteproc2#vdev0buffer: assigned reserved memory node r5f-dma-memory@a3000000
[14:05:52][    7.159773] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c1
[14:05:52][    7.166235] virtio_rpmsg_bus virtio2: rpmsg host is online
[14:05:52][    7.180997] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rpmsg attach_ext - rx_mtu:1522 features:00000007 tx_mtu[0]:2024 flow_idx:85 tx_cpsw_psil_dst_id:51713 mac_addr:70:ff:76:1d:92:c2 mac-only:1
[14:05:52][    7.188844]  remoteproc2#vdev0buffer: registered virtio2 (type 7)
[14:05:52][    7.213599] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac loaded
[14:05:52][    7.216469] remoteproc remoteproc2: remote processor 5d00000.r5f is now up
[14:05:52][    7.221564] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: rdev_features:00000007 rdev_mtu:1522 flow_id:85 tx_psil_dst_id:4A01 mac_only:1
[14:05:52][    7.252204] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: local_mac_addr:00:00:00:00:00:00 rdev_mac_addr:70:ff:76:1d:92:c2
[14:05:53][    7.520194] random: crng init done
[14:05:53][    7.523618] random: 7 urandom warning(s) missed due to ratelimiting
[14:05:53][  OK  ] Started Load/Save Random Seed.
[14:05:53][    8.266288] usbcore: registered new interface driver usbfs
[14:05:53][    8.283810] omap_rng 40910000.rng: Random Number Generator ver. 241b34c
[14:05:53][    8.306192] usbcore: registered new interface driver hub
[14:05:53][    8.316632] usbcore: registered new device driver usb
[14:05:53][  OK  ] Created slice system-systemd\x2dfsck.slice.
[14:05:54][  OK  ] Found device /dev/mmcblk0p2.
[14:05:54]         Starting File System Check on /dev/mmcblk0p2...
[14:05:54][  OK  ] Found device /dev/mmcblk0p3.
[14:05:54]         Starting File System Check on /dev/mmcblk0p3...
[14:05:54][  OK  ] Found device /dev/mmcblk0p1.
[14:05:54]         Starting File System Check on /dev/mmcblk0p1...
[14:05:54][  OK  ] Found device /dev/mmcblk1p1.
[14:05:54]         Starting File System Check on /dev/mmcblk1p1...
[14:05:54][  OK  ] Started udev Wait for Complete Device Initialization.
[14:05:54][  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[14:05:54][  OK  ] Reached target System Initialization.
[14:05:54][  OK  ] Started Daily rotation of log files.
[14:05:54][  OK  ] Started Daily Cleanup of Temporary Directories.
[14:05:54][  OK  ] Reached target Timers.
[14:05:54][  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[14:05:54][  OK  ] Listening on D-Bus System Message Bus Socket.
[14:05:54]         Starting Docker Socket for the API.
[14:05:54][  OK  ] Listening on dropbear.socket.
[14:05:54]         Starting Reboot and dump vmcore via kexec...
[14:05:54][  OK  ] Started File System Check on /dev/mmcblk0p2.
[14:05:54][  OK  ] Listening on Docker Socket for the API.
[14:05:54][  OK  ] Reached target Sockets.
[14:05:54][  OK  ] Reached target Basic System.
[14:05:54]         Mounting /run/media/mmcblk0p2...
[14:05:54][  OK  ] Started Job spooling tools.
[14:05:54][  OK  ] Started Periodic Command Scheduler.
[14:05:54][  OK  ] Started D-Bus System Message Bus.
[14:05:54]         Starting Ethernet Bridge Filtering Tables...
[14:05:54]         Starting Print notice about GPLv3 packages...
[14:05:54]         Starting IPv6 Packet Filtering Framework...
[14:05:54]         Starting IPv4 Packet Filtering Framework...
[14:05:54][  OK  ] Started irqbalance daemon.
[14:05:54]         Starting Telephony service...
[14:05:54]         Starting System Logger Daemon "default" instance...
[14:05:54]         Starting Login Service...
[14:05:54][  OK  ] Started TEE Supplicant.
[14:05:54]         Starting telnetd.service...
[14:05:54][  OK  ] Started Reboot and dump vmcore via kexec.
[14:05:54][  OK  ] Mounted /run/media/mmcblk0p2.
[14:05:54][  OK  ] Started IPv4 Packet Filtering Framework.
[14:05:54][  OK  ] Started IPv6 Packet Filtering Framework.
[14:05:54][  OK  ] Reached target Network (Pre).
[14:05:54]         Starting Network Service...
[14:05:54][  OK  ] Started Telephony service.
[14:05:54][  OK  ] Started Ethernet Bridge Filtering Tables.
[14:05:54][  OK  ] Started File System Check on /dev/mmcblk0p1.
[14:05:54]         Mounting /run/media/mmcblk0p1...
[14:05:54][  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[14:05:54][  OK  ] Started telnetd.service.
[14:05:54]         Starting syslog.service...
[14:05:54][    9.180505] Bluetooth: Core ver 2.22
[14:05:54][    9.186127] NET: Registered protocol family 31
[14:05:54][    9.195017] Bluetooth: HCI device and connection manager initialized
[14:05:54][    9.206661] Bluetooth: HCI socket layer initialized
[14:05:54][    9.217297] Bluetooth: L2CAP socket layer initialized
[14:05:54][    9.227667] Bluetooth: SCO socket layer initialized
[14:05:54][  OK  ] Mounted /run/media/mmcblk0p1.
[14:05:54][  OK  ] Started Network Service.
[14:05:54]         Starting Wait for Network to be Configured...
[14:05:54]         Starting Network Name Resolution...
[14:05:54][  OK  ] Started System Logger Daemon "default" instance.
[14:05:54][    9.412357] j721e-cpsw-virt-mac main-r5fss-cpsw9g-virt-mac1: virt_cpsw_nuss mac started
[14:05:55][    9.437987] j721e-cpsw-virt-mac main_r5fss_cpsw5g_virt_mac0: virt_cpsw_nuss mac started
[14:05:55][  OK  ] Started syslog.service.
[14:05:55][  OK  ] Started File System Check on /dev/mmcblk1p1.
[14:05:55]         Mounting /run/media/mmcblk1p1...
[14:05:55][  OK  ] Mounted /run/media/mmcblk1p1.
[14:05:55][  OK  ] Started File System Check on /dev/mmcblk0p3.
[14:05:55]         Mounting /run/media/mmcblk0p3...
[14:05:55][  OK  ] Started Login Service.
[14:05:55][    9.745296] TI DP83867 46000f00.mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=46000f00.mdio:00, irq=POLL)
[14:05:55][  OK  ] Mounted /run/media/mmcblk0p3.
[14:05:55][    9.829890] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down
[14:05:55][  OK  ] Started Network Name Resolution.
[14:05:55][  OK  ] Reached target Network.
[14:05:55][  OK  ] Reached target Host and Network Name Lookups.
[14:05:55]         Starting Avahi mDNS/DNS-SD Stack...
[14:05:55]         Starting Enable and configure wl18xx bluetooth stack...
[14:05:55][  OK  ] Started NFS status monitor for NFSv2/3 locking..
[14:05:55]         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
[14:05:55]         Starting Permit User Sessions...
[14:05:55][  OK  ] Started Vsftpd ftp daemon.
[14:05:55][  OK  ] Started Permit User Sessions.
[14:05:55][  OK  ] Started Getty on tty1.
[14:05:55][  OK  ] Started Serial Getty on ttyS2.
[14:05:55][  OK  ] Started Serial Getty on ttyS3.
[14:05:55][  OK  ] Reached target Login Prompts.
[14:05:55]         Starting Synchronize System and HW clocks...
[14:05:55][  OK  ] Started Enable and configure wl18xx bluetooth stack.
[14:05:55][FAILED] Failed to start Synchronize System and HW clocks.
[14:05:55]See 'systemctl status sync-clocks.service' for details.
[14:05:55][  OK  ] Started Avahi mDNS/DNS-SD Stack.
[14:05:56][  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[14:05:58]         Starting Cleanup of Temporary Directories...
[14:05:58][  OK  ] Started Cleanup of Temporary Directories.
[14:05:59]***************************************************************
[14:05:59]NOTICE: This file system contains the following GPLv3 packages:
[14:05:59]        autoconf
[14:05:59]        bash-dev
[14:05:59]        bash
[14:05:59]        bc
[14:05:59]        binutils
[14:05:59]        cifs-utils
[14:05:59]        coreutils-stdbuf
[14:05:59]        cpio
[14:05:59]        cpp-symlinks
[14:05:59]        cpp
[14:05:59]        dosfstools
[14:05:59]        elfutils
[14:05:59]        g++-symlinks
[14:05:59]        g++
[14:05:59]        gawk
[14:05:59]        gcc-symlinks
[14:05:59]        gcc
[14:05:59]        gdb
[14:05:59]        gdbserver
[14:05:59]        gettext
[14:05:59]        gstreamer1.0-libav-dev
[14:05:59]        gzip
[14:05:59]        less
[14:05:59]        libasm1
[14:05:59]        libbfd
[14:05:59]        libdw1
[14:05:59]        libelf1
[14:05:59]        libgdbm-compat4
[14:05:59]        libgdbm-dev
[14:05:59]        libgdbm6
[14:05:59]        libgettextlib
[14:05:59]        libgettextsrc
[14:05:59]        libgmp-dev
[14:05:59]        libgmp10
[14:05:59]        libgmpxx4
[14:05:59]        libidn2-0
[14:05:59]        libidn2-dev
[14:05:59]        libmpc3
[14:05:59]        libmpfr6
[14:05:59]        libreadline-dev
[14:05:59]        libreadline8
[14:05:59]        libunistring-dev
[14:05:59]        libunistring2
[14:05:59]        m4-dev
[14:05:59]        m4
[14:05:59]        make
[14:05:59]        nettle-dev
[14:05:59]        nettle
[14:05:59]        parted
[14:05:59]        python3-rfc3987
[14:05:59]        python3-strict-rfc3339
[14:05:59]        tar
[14:05:59]        which
[14:05:59]        zeromq
[14:05:59]
[14:05:59]If you do not wish to distribute GPLv3 components please remove
[14:05:59]the above packages prior to distribution.  This can be done using
[14:05:59]the opkg remove command.  i.e.:
[14:05:59]    opkg remove <package>
[14:05:59]Where <package> is the name printed in the list above
[14:05:59]
[14:05:59]NOTE: If the package is a dependency of another package you
[14:05:59]      will be notified of the dependent packages.  You should
[14:05:59]      use the --force-removal-of-dependent-packages option to
[14:05:59]      also remove the dependent packages as well
[14:06:05][  OK  ] Started Print notice about GPLv3 packages.
[14:06:07][  OK  ] Created slice system-systemd\x2dcoredump.slice.
[14:06:07][  OK  ] Started Process Core Dump (PID 929/UID 0).
[14:06:07][  OK  ] Started Process Core Dump (PID 931/UID 0).
[14:06:07][  OK  ] Started Process Core Dump (PID 933/UID 0).
[14:06:07][  OK  ] Started Process Core Dump (PID 932/UID 0).
[14:06:07][  OK  ] Started Process Core Dump (PID 930/UID 0).
[14:06:07][  OK  ] Stopped Login Service.
[14:06:07]         Starting Login Service...
[14:06:07][  OK  ] Stopped Network Time Synchronization.
[14:06:07]         Starting Network Time Synchronization...
[14:06:07][  OK  ] Stopped udev Kernel Device Manager.
[14:06:07]         Starting udev Kernel Device Manager...
[14:06:07][  OK  ] Stopped Network Name Resolution.
[14:06:07]         Starting Network Name Resolution...
[14:06:07][  OK  ] Started Login Service.
[14:06:07][  OK  ] Started udev Kernel Device Manager.
[14:06:08][  OK  ] Started Network Time Synchronization.
[14:06:08][  OK  ] Stopped Network Service.
[14:06:08]         Starting Network Service...
[14:06:08][  OK  ] Started Network Name Resolution.
[14:06:08][  OK  ] Started Network Service.
[14:06:12]
[14:06:12] _____                    _____           _         _
[14:06:12]|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
[14:06:12]|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
[14:06:12]|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
[14:06:12]              |___|                    |___|
[14:06:12]
[14:06:12]Arago Project http://arago-project.org j7200-evm ttyS2
[14:06:12]
[14:06:12]Arago 2021.09 j7200-evm ttyS2
[14:06:12]
[14:06:14]j7200-evm login: root
[14:06:18]root@j7200-evm:~# ifconfig
[14:06:18]eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500  metric 1
[14:06:18]        ether f4:84:4c:f8:68:70  txqueuelen 1000  (Ethernet)
[14:06:18]        RX packets 0  bytes 0 (0.0 B)
[14:06:18]        RX errors 0  dropped 0  overruns 0  frame 0
[14:06:18]        TX packets 0  bytes 0 (0.0 B)
[14:06:18]        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
[14:06:18]
[14:06:18]eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500  metric 1
[14:06:18]        inet6 fe80::72ff:76ff:fe1d:92c1  prefixlen 64  scopeid 0x20<link>
[14:06:18]        ether 70:ff:76:1d:92:c1  txqueuelen 1000  (Ethernet)
[14:06:18]        TX packets 23  bytes 3697 (3.6 KiB)
[14:06:18]
[14:06:18]eth2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500  metric 1
[14:06:18]        inet6 fe80::72ff:76ff:fe1d:92c2  prefixlen 64  scopeid 0x20<link>
[14:06:18]        ether 70:ff:76:1d:92:c2  txqueuelen 1000  (Ethernet)
[14:06:18]        TX packets 24  bytes 3827 (3.7 KiB)
[14:06:18]
[14:06:18]lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536  metric 1
[14:06:18]        inet 127.0.0.1  netmask 255.0.0.0
[14:06:18]        inet6 ::1  prefixlen 128  scopeid 0x10<host>
[14:06:18]        loop  txqueuelen 1000  (Local Loopback)
[14:06:18]        RX packets 82  bytes 6220 (6.0 KiB)
[14:06:18]        TX packets 82  bytes 6220 (6.0 KiB)
[14:06:18]
[14:06:37]root@j7200-evm:~# cat /sys/kernel/debug/remoteproc/remoteproc1/trace0
[14:06:37]
[14:06:37]TTTTTTTTTTTTTTTTTTTTTTTTTTTTTT2
[14:06:37]
[14:06:37]=======================================================
[14:06:37]            CPSW Ethernet Firmware
[14:06:37]ETHFW: Shared multicasts (software fanout):
[14:06:37]  01:00:5e:00:00:01
[14:06:37]  01:00:5e:00:00:fb
[14:06:37]  01:00:5e:00:00:fc
[14:06:37]  33:33:00:00:00:01
[14:06:37]  33:33:ff:1d:92:c2
[14:06:37]  01:80:c2:00:00:00
[14:06:37]  01:80:c2:00:00:03
[14:06:37]ETHFW: Reserved multicasts:
[14:06:37]  01:80:c2:00:00:0e
[14:06:37]  01:1b:19:00:00:00
[14:06:37]EnetMcm: CPSW_5G on MAIN NAVSS
[14:06:37]
[14:06:37]ETHFW Version   : 0.02.00
[14:06:38]ETHFW Build Date: Jun 26, 2022
[14:06:38]ETHFW Build Time: 23:29:01
[14:06:38]ETHFW Commit SHA:
[14:06:38]
[14:06:38]Starting lwIP, local interface IP is 192.168.1.200
[14:06:38]Host MAC address: 70:ff:76:1d:92:c3
[14:06:38][LWIPIF_LWIP] Enet LLD netif initialized successfully
[14:06:38][LWIPIF_LWIP_IC] Interface started successfully
[14:06:38][LWIPIF_LWIP_IC] NETIF INIT SUCCESS
[14:06:38]Added interface 'br4', IP is 192.168.1.200
[14:06:38]EthFw: TimeSync PTP enabled
[14:06:38]Rx Flow for Software Inter-VLAN Routing is up
[14:06:38]CpswProxyServer: Virtual port configuration:
[14:06:38]  mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
[14:06:38]  mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
[14:06:38]  mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
[14:06:38]  mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
[14:06:38]CpswProxyServer: initialization completed (core: mcu2_0)
[14:06:38]REMOTE_SERVICE: Init ... !!!
[14:06:38]REMOTE_SERVICE: Init ... Done !!!
[14:06:38]Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:5
[14:06:38]Function:CpswProxyServer_attachExtHandlerCb,HostId:4,CpswType:5
[14:06:38]Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Cmd:1010401,InArgsLen:0, OutArgsLen:4
[14:06:38]Function:CpswProxyServer_ioctlHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Cmd:1010201,InArgsLen:24, OutArgsLen:4
[14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, MacAddress:70:ff:76:1d:92:c4, FlowIdx:91, FlowIdxOffset:7
[14:06:38]Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:8, Policer Entry:3
[14:06:38]Function:CpswProxyServer_registerRemoteTimerHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, Name:mcu_2_1_ethswitch-device-1, Timer:1, PushNum:2
[14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:4,Handle:a2a596e8,CoreKey:38acb976, MacAddress:70:ff:76:1d:92:c5, FlowIdx:92, FlowIdxOffset:8
[14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:85, FlowIdxOffset:1
[14:06:38]Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6,mode:disable
[14:06:38]Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:84, FlowIdxOffset:0
[14:06:38]Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:11, Policer Entry:6
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterDelMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterDelMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterDelMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
[14:06:38]Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2a596e8,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:84, FlowIdOffset:0
客户希望了解目前如何排除此处的情况。 请帮您检查一下。 谢谢。
樱桃
    我是否可以知道有任何更新?
    谢谢、此致、
    樱桃
    有更新吗?
    谢谢、此致、
    樱桃
    我使用了 TI-processor-SDK-RTOS-J7200-evm-07_02_00_06来修改适配并成功验证了开关功能。要使用 TI-processor-SDK-RTOS-J7200-evm-08_02_00_05、应修改哪些内容?
