[参考译文] TDA4VM:tda4 CAN#39;t boot form ospi
Guru**** 2538955 points
Other Parts Discussed in Thread: SK-TDA4VM
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1124619/tda4vm-tda4-can-t-boot-form-ospi
器件型号:TDA4VM
您好、TI 专家:
 tda4无法从 ospi 引导。
 引导日志如下所示:
TI_sci dmsc@44083000:zyp ti_sci_cmd_core_reboot mbox 发送失败-110
TI-sci-sysreset sysreset-controller:zyp ti_sci_sysreset_request:reboot_device failed (-110)
TI-sci-sysreset sysreset-controller:TI_sci_sysreset_request (dev=41c85f0c、type=2)
zyp11 ti_sci_cmd_core_reboot
zyp ti_sci_do_xfer
mbox_recv (chan=41ccc8fc、data=41ccc914、timeout_us=10000000)
TI_sci dmsc@44083000:TI_sci_get_response:消息接收失败。RET =-110
TI-sci-sysreset sysreset-controller:TI_sci_sysreset_request (dev=41c85f0c、type=3)
zyp ti_sci_do_xfer
此平台不支持系统重置
###错误###请重置电路板###
 我们使用 spl 模式以从 ospi 启动、 ospi 为  SDK 版本为 08_01_00_07,
引导模式为:
SYS_mode0:1
SYS_mode1:0
SYS_mode2:0
SYS_mode3:0
SYS_Mode4:0
SYS_mode5:0
SYS_mode6:0
SYS_mode7:0
MCU_mode0:0
MCU_mode1:0
MCU_mode2:0
MCU_mode3:0
MCU_mode4:1.
MCU_mode5:1.
MCU_mode6:0
MCU_mode7:0
ospi 刷写日志位于此处:
SF 探头
zyp argv[0]=探针
zyp 模式:0x3
zyp bus:0x0、cs:0x0、speeded:0xf4240、mode:0x3
zyp do spi_flash_probe、bus:0x0、cs:0x0、speeded:0xf4240、mode:0x3
zyp ti_sci_set_device_state
zyp ti_sci_do_xfer
mbox_recv (cha=0000fdecd8b8、data=00000000fdecd8e8、timeout_us=10000000)
zyp ti_sci_cmd_clk_get_num_父 项
zyp ti_sci_do_xfer
zyp ti_sci_cmd_clk_set_parent
zyp ti_sci_do_xfer
zyp ti_sci_cmd_clk_set_freq
zyp ti_sci_do_xfer
zyp ti_sci_cmd_clk_get_freq
zyp ti_sci_do_xfer
Cadence_SPI@47040000:无法获得复位:-2
JEDEC SPI_NOR FLASH@0:尚不支持不一致的擦除扇区映射。
zyp ti_sci_get_resource_range
zyp ti_sci_do_xfer
k3-navss-ringacc ringacc@2b800000:环形加速器探测环:286、gp-ring [96、20] sci-dev-id:235
k3-navss-ringacc ringacc@2b800000:dma-ring-reset-quirk:禁用
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
TI-uDMA dma-controller@285c0000:zyp udma_alloc_chan_resources:chan:0 as MEM_TO_MEM
zyp ti_sci_cmd_ring _config
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_cmd_rm_udmap_TX_ch_cfg
zyp ti_sci_do_xfer
zyp ti_sci_cmd_rm_udmap_rx_ch_cfg
zyp ti_sci_do_xfer
zyp ti_sci_cmd_rm_psil_pair
zyp ti_sci_do_xfer
zyp ti_sci_cmd_rm_psil_unpair
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
SF:检测到 s28hs512t、页面大小为256字节、擦除大小为256 KiB、总共64 MIB
=> Fatload MMC 1 ${loadaddr}tiboot3.bin
zyp ti_sci_do_xfer
290616字节在21ms 内读取(13.2 MIB/s)
=> SF 更新${loadaddr}0x0 0x${filesize}
器件0偏移量0x0、大小0x46f38
offset=0x0、sector_size=0x40000、len=0x40000
zyp spi_flash_read_dm
zyp SPI_FLASH_std_read
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp SPI_FLASH_ERASE_dm
zyp spi_flash_write_dm
zyp SPI_FLASH_std_write
正在更新、91% 171414 B/soffset=0x40000、sector_size=0x40000、len=0x6f38
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
290616字节被写入、在3.128s 内跳过0字节、速度95016 B/s
=> Fatload MMC 1 ${loadaddr}tispl.bin
48 ms 内读取的928708字节(18.5 MIB/s)
=> SF 更新${loadaddr}0x80000 0x${filesize}
器件0偏移量0x80000、大小0xe2bc4
offset=0x80000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
正在更新、29% 172184 B/soffset=0xc0000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
正在更新、57% 171688 B/soffset=0x100000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
正在更新、85% 170869 B/soffset=0x140000、sector_size=0x40000、len=0x22bc4
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
已写入928708字节、6.139秒内跳过0字节、速度为154809 B/s
=> fatload MMC 1 ${loadaddr}u-boot.img
在61ms (19.5 MIB/s)内读取1249312个字节
=> SF 更新${loadaddr}0x280000 0x${filesize}
器件0偏移量0x280000、大小0x131020
offset=0x280000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
正在更新、21% 157532 B/soffset=0x2c0000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
更新、42% 157347 B/soffset=0x300000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
正在更新、63% 156430 B/soffset=0x340000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
正在更新、84% 156248 B/soffset=0x380000、sector_size=0x40000、len=0x31020
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
写入1249312字节、在8.336s 内跳过0字节、速度153411 B/s
=> fatload MMC 1 ${loadaddr}sysfw.itb
268990字节在21ms 内读取(12.2MiB/s)
=> SF 更新${loadaddr}0x6C0000 0x${filesize}
器件0偏移量0x6c0000、大小0x41abe
offset=0x6c0000、sector_size=0x40000、len=0x40000
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
正在更新、98% 184745 B/soffset=0x700000、sector_size=0x40000、len=0x1abe
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
zyp ti_sci_do_xfer
268990字节已写入、2.697s 内跳过0字节、速度101979 B/s
    下面几个问题:
    • 正在使用哪个 SDK 版本?
    • 这是定制板还是 TI EVM?
    • 是否有其他引导模式可以正常工作?
    • 请从头开始共享引导日志。
    基尔西
    您好  、TI 专家:
    SDK 版本为 08_01_00_07。
    2.这是一个定制板, 我们还尝试从 TI EVM 板中的 ospi 引导,它启动正常 ;
     我们的定制板是 SK-TDA4VM 电路板的参考设计,除了一些差异外:
      来自 FPGA 的 SK-TDA4VM 配置引导模式和 来自跳线,的定制电路板配置引导模式
     我们的自定义电路板引导模式为:
    SYS_mode0:1     SYS_mode1:0    SYS_mode2:0    SYS_mode3:0
    SYS_mode4:0     SYS_mode5:0    SYS_mode6:0    SYS_mode7:0
    MCU_mode0:0    MCU_mode1:0    MCU_mode2:0    MCU_mode3:0
    MCU_mode4:1    MCU_mode5:1    MCU_mode6:0    MCU_mode7:0
    我们的定制电路板原理图设计为:
    3、eMMC 引导和 SD 引导在我们的定制板中正常。
    4.启动日志位于以下位置:
    zyp ti_sci_do_xfer
    zyp ti_sci_do_xfer
    此平台不支持系统重置
    ###错误###请重置电路板###
    您好  、TI 专家:
     我们的自定义电路板引导模式为:
    我们的定制电路板原理图设计为:
    4.启动日志位于以下位置:
    zyp ti_sci_do_xfer
    zyp ti_sci_do_xfer
    此平台不支持系统重置
    ###错误###请重置电路板###
    5.我们定制板中的读取表单 ospi 看起来错误、 它移位了8位、从 TI EVM 板中的 ospi 读取正常、 我们定制板中的读取记录如下:
    SF 探头
    zyp argv[0]=探针
    zyp 模式:0x3
    在19ms 内读取289428字节(14.5 MIB/s)
    => MD.b 0x82000000
    82000000:30 82 03 A8 30 82 03 11 a0 03 02 01 02 14 7e 0...0 ......... ~μ A
    82000010:B0 4c 61 98 64 41 25 76 44 E3 ac 4a ef cc 9b .L.A.da.j...
    82000020:F4 12 D4 30 0d 06 09 2a 86 48 86 F7 0d 01 0d ...0...*.H......
    82000030:05 00 30 81 9d 31 0b 30 09 06 03 55 04 06 13 02 .0...1.0... U....
    => SF 读取0x82000000 0 0x100000
    器件0偏移量0x0、大小0x100000
    @ti-uDMA dma-controller@285c0000:zyp udma_alloc_chan_resources:chan:0 as MEM_TO_MEM
    zyp argv[0]:0x0。
    zyp argv[1]:0x30。
    zyp argv[2]:0x82。
    zyp argv[3]:0x3。
    zyp argv[4]:0xa8。
    zyp argv[5]:0x30。
    zyp argv[6]:0x82。
    zyp argv[7]:0x3。
    zyp argv[8]:0x11。
    zyp argv[9]:0xa0。
    zyp argv[10]:0x3。
    zyp argv[11]:0x2。
    zyp argv[12]:0x1。
    zyp argv[13]:0x2。
    zyp argv[14]:0x2。
    zyp argv[15]:0x14。
    zyp argv[16]:0x7E。
    zyp argv[17]:b0.
    zyp argv[18]:0x4c。
    zyp argv[19]:0xcc。
    SF:1048576字节@ 0x0读取:正常
    => MD.b 0x82000000
    82000000:00 30 82 03 A8 30 82 03 11 a0 03 02 01 02 14 .0...0 .........
    82000010:7E b0 4c 61 98 64 41 25 76 44 E3 ac 4a ef cc ~.L.A.d%VD...J.
    82000020:9B F4 12 D4 30 0d 06 09 2a 86 86 86 F7 0d 01……0...*.h
    82000030:0D 05 00 30 81 9d 31 0b 30 09 06 03 55 04 06 13...0...1.0...美国
    您能否查看此链接:
    https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/08_01_00_07/exports/docs/linux/Foundational_Components/Kernel/Kernel_Drivers/QSPI.html
    请查看描述的部分:在 J721E 上使用 Cypress S28HS512TGABHM010闪存
    基尔西
    尊敬的 Keerty J:
    感谢您的回复。
     修改 uboot DTS 后、在 SD uboot 模式下 Cypress S28HS512TGABHM010闪存读取和写入正常、
    但 tda4仍然无法从 S28HS512TGABHM010闪存引导。
    整个引导日志如下所示:
    zyp1 sysreset_walk 停止...
    zyp sysreset_walk
    TI-sci-sysreset sysreset-controller:TI_sci_sysreset_probe (dev=41c85f0c)
    zyp1112 sysreset_request
    TI-sci-sysreset sysreset-controller:zyp ti_sci_sysreset_request (dev=41c85f0c、type=1)
    TI-sci-sysreset sysreset-controller:zyp ti_sci_sysreset_request (dev=41c85f0c、type=2)
    TI-sci-sysreset sysreset-controller:zyp ti_sci_sysreset_request (dev=41c85f0c、type=3)
    此平台不支持系统1重置
    zyp ###错误###请重置电路板###
    我的引导模式 cfg 位于此处:
    尊敬的 Keerty J:
    如果我配置 ospi 引导模式,tda4没有引导日志,它看起来不 是启动,tda4数据表中是否存在 有关 ospi 引导模式的错误?
    下面是有关 ospi 引导模式的 tda4数据表:
    我们的定制电路板原理图设计如下
    我们的 ospi 引导模式 cfg 如下所示:
    SYS_mode0:0     SYS_mode1:0    SYS_mode2:0    SYS_mode3:0
    SYS_mode4:0     SYS_mode5: 1    SYS_mode6:0    SYS_mode7:0
    MCU_mode0:0    MCU_mode1:0    MCU_mode2:0    MCU_mode3: 1
    MCU_mode4: 0    MCU_mode5: 0   MCU_mode6:0    MCU_mode7:0
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1039583/tda4vm-how-to-transplant-cypress-s-s28hs512t-ospi-based-on-the-sdk-version-7-2-of-the-j721e-platform/3857212#3857212
    TDA4-SK 板具有 存储器、xSPI NOR 闪存 MCU_OSPI0 Cypress S28HS512TGABHM010
    您可以尝试 xSPI 引导模式吗?
    EVM 上的 DIP 开关设置:
    SW8:10000010
    SW9:00110000
    SW3:0111001010
    此外、请确保您具有 PG1.1、因为已知 PG1.0不能与 Cypress 闪存配合使用。
    -凯尔西
