[参考译文] [TDA4VM] V4L2测试应用程序错误
Guru**** 2535750 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1121679/tda4vm-v4l2-test-application-error
大家好、TI 团队成员
我通过  阅读指南试用了 V4L2视频编码器测试应用程序。 (https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/08_02_00_03/exports/docs/linux/Foundational_Components_Multimedia_D5520_VXE384.html)
当我运行" tienc_encode -i 0000.yUV -f NV12 -c h264 -w 640 -h 480 -o video.h264"时、日志如下。
root@j7-evm:/run/media/sda1/dump# tienc_encode -i 0000000000.yuv -f NV12 -c H264 -w 640 -h 480 -o video.h264
query_ctrls Enumerating all non-compound
query_ctrls Got ctrl.id=0x9909cb type=1
query_ctrls     name=GOP size minimum=1 maximum=7200
query_ctrls     step=1 default_value=1800
query_ctrls     flags=00000000
query_ctrls Got ctrl.id=0x9909cf type=1
query_ctrls     name=Video Bitrate minimum=50000 maximum=100000000
query_ctrls     step=1 default_value=500000
query_ctrls Got ctrl.id=0x990a66 type=1
query_ctrls     name=H264 I period minimum=1 maximum=600
query_ctrls     step=1 default_value=30
query_ctrls Enumerating all non-compound ended errno=22 Invalid argument
query_ctrls Enumerating all non-compound ext
query_ctrls Got ext_ctrl.id=0x9909cb type=1
query_ctrls     elem_size=4 elems=1 nr_of_dims=0
query_ctrls Got ext_ctrl.id=0x9909cf type=1
query_ctrls Got ext_ctrl.id=0x990a66 type=1
query_ctrls Enumerating all non-compound ext ended errno=22 Invalid argument
query_ctrls Enumerating all compound ext
query_ctrls Enumerating all compound ext ended errno=22 Invalid argument
query_ctrls Enumerating all controls ext
query_ctrls Enumerating all controls ext ended errno=22 Invalid argument
try_ctrls VIDIOC_TRY_EXT_CTRLS succeeded
set_ctrls VIDIOC_S_EXT_CTRLS succeeded
^C
root@j7-evm:/run/media/sda1/dump# ls -al
total 2560
drwxrwxrwx 1 root root 524288 Mar 23 21:14 .
drwxrwxrwx 1 root root 524288 Jan  1  1970 ..
-rwxrwxrwx 1 root root 460800 Mar 23 20:52 0000000000.yuv
drwxrwxrwx 1 root root 524288 Mar  8 19:38 separate
drwxrwxrwx 1 root root 524288 Mar  8 19:38 topview
-rwxrwxrwx 1 root root      0 Mar 23 21:14 video.h264
此外、我使用了 PSDK8.2。
我想知道我是否错过了像修补程序这样的东西。
永西格。
    您好、Yongsig、
    我怀疑这可能是您使用的目录的问题。
    root@j7-evm:/run/smedia/sda1/dump  此目录是挂载目录,可能不存在写入权限。
    您能否检查 正常的主目录并查看其是否正常工作?
    如果可以、 您能否发送您 正在使用的输入文件(YUV 文件)、以便在我们的结尾重新生成该文件?
    Nikhil
    你(们)好,Nikhil
    感谢您的回复。
    我在常规主目录中尝试过。 但它失败了。 日志与以前相同。
    drwx------ 3 root root   4096 Mar 23 20:56 .
    drwxr-xr-x 3 root root   4096 Mar 23  2022 ..
    -rw------- 1 root root   6410 Mar 23  2022 .bash_history
    drwxr-xr-x 3 root root   4096 Mar 23 20:52 .cache
    root@j7-evm:~# tienc_encode -i 0000000000.yuv -w 640 -h 480 -o test.h264
    No format found. Defaulting to NV12
    No format found. Defaulting to H264
    我认为权限没有问题。
    我附加了 YUV 文件。
    e2e.ti.com/.../0000000000.zip
    永西格
    你(们)好,Nikhil
    我从 https://git.ti.com/cgit/jacinto7_multimedia/下载了 tienc_encode 的源代码
    因此我修复了一些代码、例如、我从 main.c 的第716行禁用到第842行
    然后 、来自 streaming_loop 模块中 POLL (&PFD、1、100)的 ret 值始终为0。
    您知道原因吗?
    永西格
    您好、Yongsig、
    您会看到上述内容、因为在 tienc_encode 框架中、我们需要多个帧(即多个帧)才能开始编码。
    您可以参考下面的函数
    https://git.ti.com/cgit/jacinto7_multimedia/videnc-test-app/tree/main.c?id=a5e7d820bea1be24f25a8369d4d4521c784f869a#n124
    因此、您是否可以尝试提供更多的帧来对其进行编码?
    编码单个图像的另一种方法是使用 gstreamer、如下所示
    gst-launch-1.0文件 rc location=./0000000000.yUV blocksize=460800! VIDEO/x-RAW、FORMAT=NV12、width=640、height=480、framerate=30/1、 隔行模式=逐行、比色法= bt601! v4l2h264enc! h264parse! filesink location=./video_gst.264
    Nikhil
    如果我使用多个帧、它会起作用。
    谢谢 Nikhil。
