[参考译文] DRA821U:DRA821:SDK8.0中的 ethfw 编译失败
Guru**** 2553450 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1044767/dra821u-dra821-ethfw-compilation-failed-in-sdk8-0
器件型号:DRA821U
Thread 中讨论的其他器件:SYSBIOS
您好 TI!
尝试在 SDK8.0 TI RTOS 默认代码中使用以下命令编译以太网固件失败。(J7200)
/ethfw > make -s ethfw_all build_SOC_list=J7200
构建日志如下所示、您能提供帮助吗?
dongsukkim@auto-dev131:~/dasan/1012/tisdk/RTOS/ethfw$ make -s ethfw_all BUILD_SOC_LIST=J7200
SHELL=/bin/sh
TARGET_MAKEFILES=apps/app_remoteswitchcfg_client/mcu_2_1/concerto.mak apps/app_remoteswitchcfg_server/mcu_2_0/concerto.mak ethfw/concerto.mak ethremotecfg/client/src/concerto.mak ethremotecfg/server/src/concerto.mak utils/console_io/concerto.mak utils/ctoolslib/concerto.mak utils/ethfw_callbacks/concerto.mak utils/ethfw_lwip/concerto.mak utils/ethfw_stats/concerto.mak utils/intervlan/concerto.mak utils/mem/concerto.mak utils/perf_stats/concerto.mak utils/profile/concerto.mak utils/remote_service/concerto.mak
undefined TIARMCGT_ROOT_=
file GCC_SYSBIOS_ARM_ROOT=$(PSDK_PATH)/gcc-linaro-9.2-2019.12-x86_64_aarch64-elf
undefined CGT6X_ROOT=
undefined CGT7X_ROOT=
undefined GCC_WINDOWS_ROOT=
file GCC_LINUX_ROOT=/usr/
TARGET_COMBO=J7200:FREERTOS:R5Ft:2:release:TIARMCGT
SHELL=/bin/sh
Nothing to be done for j7200 csl_intc
Nothing to be done for j7200 pm_hal
Nothing to be done for j7200 pm_hal_optimized
Nothing to be done for j7200 mcu2_0 sbl_lib_mmcsd
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi
Nothing to be done for j7200 mcu2_0 sbl_lib_uart
Nothing to be done for j7200 sbl_lib_hyperflash
Nothing to be done for j7200 mcu2_0 sbl_lib_cust
Nothing to be done for j7200 mcu2_0 sbl_lib_mmcsd_hlos
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi_hlos
Nothing to be done for j7200 sbl_lib_hyperflash_hlos
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi_nondma
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi_nondma_hlos
Nothing to be done for j7200 mcu2_0 sbl_lib_mmcsd_hs
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi_hs
Nothing to be done for j7200 mcu2_0 sbl_lib_uart_hs
Nothing to be done for j7200 sbl_lib_hyperflash_hs
Nothing to be done for j7200 mcu2_0 sbl_lib_cust_hs
Nothing to be done for j7200 mcu2_0 sbl_lib_mmcsd_hlos_hs
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi_hlos_hs
Nothing to be done for j7200 sbl_lib_hyperflash_hlos_hs
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi_nondma_hlos_hs
Nothing to be done for j7200 mcu2_0 sbl_lib_ospi_nondma_hs
Nothing to be done for j7200 dmautils
Nothing to be done for j7200 mcu2_0 rm_pm_hal
Nothing to be done for j7200 mcu2_0 sciserver_tirtos
Nothing to be done for j7200 mcu2_0 sciserver_baremetal
Nothing to be done for j7200 mcu2_0 sciclient_direct
Nothing to be done for j7200 osal_nonos_indp
Nothing to be done for j7200 mcu2_0 sciclient_direct_hs
Nothing to be done for j7200 osal_tirtos_indp
Nothing to be done for j7200 i2c_indp
Nothing to be done for j7200 i2c_profile
Nothing to be done for j7200 i2c_profile_indp
Nothing to be done for j7200 i2c_icss0
Nothing to be done for j7200 uart_profile
Nothing to be done for j7200 uart_dma_profile
Nothing to be done for j7200 uart_profile_indp
Nothing to be done for j7200 uart_indp
Nothing to be done for j7200 gpio_indp
Nothing to be done for j7200 gpio_profile
Nothing to be done for j7200 gpio_profile_indp
Nothing to be done for j7200 mcu2_0 copyvecs
Nothing to be done for j7200 fatfs_multi_indp
Nothing to be done for j7200 fatfs_profile_indp
Nothing to be done for j7200 mcasp_indp
Nothing to be done for j7200 mcasp_profile_indp
Nothing to be done for j7200 spi_profile
Nothing to be done for j7200 spi_dma_profile
Nothing to be done for j7200 spi_indp
Nothing to be done for j7200 spi_profile_indp
Nothing to be done for j7200 mcu2_1 sbl_lib_mmcsd
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi
Nothing to be done for j7200 mcu2_1 sbl_lib_uart
Nothing to be done for j7200 mcu2_1 sbl_lib_cust
Nothing to be done for j7200 mcu2_1 sbl_lib_mmcsd_hlos
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi_hlos
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi_nondma
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi_nondma_hlos
Nothing to be done for j7200 mcu2_1 sbl_lib_mmcsd_hs
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi_hs
Nothing to be done for j7200 mcu2_1 sbl_lib_uart_hs
Nothing to be done for j7200 mcu2_1 sbl_lib_cust_hs
Nothing to be done for j7200 mcu2_1 sbl_lib_mmcsd_hlos_hs
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi_hlos_hs
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi_nondma_hs
Nothing to be done for j7200 mcu2_1 sbl_lib_ospi_nondma_hlos_hs
Nothing to be done for j7200 mcu2_1 rm_pm_hal
Nothing to be done for j7200 mcu2_1 sciserver_tirtos
Nothing to be done for j7200 mcu2_1 sciserver_baremetal
Nothing to be done for j7200 mcu2_1 sciclient_direct
Nothing to be done for j7200 mcu2_1 sciclient_direct_hs
Nothing to be done for j7200 mcu2_1 copyvecs
Nothing to be done for j7200 mcu2_1 timeSync
Nothing to be done for j7200 mcu2_1 timeSync_hal
Nothing to be done for j7200 mcu2_1 timeSync_ptp
Nothing to be done for j7200 mcu2_1 mcasp
Makefile:45: /concerto/rules.mak: No such file or directory
make[1]: *** No rule to make target '/concerto/rules.mak'.  Stop.
makefile:119: recipe for target 'remotedevicefw' failed
make: *** [remotedevicefw] Error 2
谢谢你
    Concerto 的路径似乎是 REMOLE_DEVICE 中的问题。 您能否附加以下文件
    1。  /ethfw/makefile
    2. /remote_device/Makefile
    3.  /remote_device/concerto /rules.mak
    Tanmay
