[参考译文] TDA4VM:运行 single_cam 演示错误。 传感器:ar0233
Guru**** 2546020 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1021972/tda4vm-run-single_cam-demo-error-sensor-ar0233
器件型号:TDA4VM
您好 ,当我执行./run_app_single_cam.sh,时,图像错误。
SDK_ver:TI-processor-sdk-rtos-j721e-evm-07_03_00_07
传感器:ar0233+ub953
TDA4 EVM + Fusion 应用板。(ub960)
我的传感器为 ar0233、该样本支持该传感器。 当我在传感器中读取寄存器时、值是正确的。 以下是日志:
root@j7-evm:/opt/vision_apps# ./run_app_single_cam.sh
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
   246.458962 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
   246.460781 s:  VX_ZONE_INIT:Enabled
   246.460800 s:  VX_ZONE_ERROR:Enabled
   246.460805 s:  VX_ZONE_WARNING:Enabled
   246.464439 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
   246.464635 s:  VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!!
Invalid token [
sensor_selection = [0]
Invalid token [
ldc_enable = [0]
Invalid token [
num_frames_to_run = [1000000000]
Invalid token [
is_interactive = [1]
IttCtrl_registerHandler: command echo registered at location 0
IttCtrl_registerHandler: command iss_read_2a_params registered at location 1
IttCtrl_registerHandler: command iss_write_2a_params registered at location 2
IttCtrl_registerHandler: command iss_raw_save registered at location 3
IttCtrl_registerHandler: command iss_yuv_save registered at location 4
IttCtrl_registerHandler: command iss_read_sensor_reg registered at location 5
IttCtrl_registerHandler: command iss_write_sensor_reg registered at location 6
IttCtrl_registerHandler: command dev_ctrl registered at location 7
IttCtrl_registerHandler: command iss_send_dcc_file registered at location 8
 NETWORK: Opened at IP Addr = 192.168.10.11, socket port=5000!!!
tivxImagingLoadKernels done
   246.466228 s: ISS: Enumerating sensors ... !!!
[MCU2_0]    246.466321 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CREATE
[MCU2_0]    246.466448 s: LXC DBG: IssSensor_DeserializerInit, 634 print
[MCU2_0]    246.466548 s: UB960 config start
[MCU2_0]    246.666654 s: End of UB960 config
[MCU2_0]    246.666710 s: UB960 config start
   246.866638 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
   246.866658 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
   246.866678 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
   246.866683 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
   246.866687 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
   246.866692 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
Select camera port index 0-7 : [MCU2_0]    246.866494 s: End of UB960 config
1
0x6 registered sensor drivers
a : IMX390-UB953_D3
b : AR0233-UB953_MARS
c : AR0820-UB953_LI
d : UB9xxx_RAW12_TESTPATTERN
e : UB96x_UYVY_TESTPATTERN
f : GW_AR0233_UYVY
Select a sensor above or press '0' to autodetect the sensor : Invalid selection
. Try again
a : IMX390-UB953_D3
c : AR0820-UB953_LI
f : GW_AR0233_UYVY
Select a sensor above or press '0' to autodetect the sensor : b
Sensor selected : AR0233-UB953_MARS
LDC Selection Yes(1)/No(0) : LDC Selection Yes(1)/No(0) : 1
app_init done
Querying AR0233-UB953_MARS
   252.989047 s: ISS: Querying sensor [AR0233-UB953_MARS] ... !!!
   252.989297 s: ISS: Querying sensor [AR0233-UB953_MARS] ... Done !!!
WDR mode is supported
Expsoure control is supported
Gain control is supported
obj->aewb_cfg.ae_mode = 0
obj->aewb_cfg.awb_mode = 0
Sensor DCC is enabled
Sensor width = 1920
Sensor height = 1280
Sensor DCC ID = 233
Sensor Supported Features = 0x178
Sensor Enabled Features = 0x158
   252.989334 s: ISS: Initializing sensor [AR0233-UB953_MARS], doing IM_SENSOR_CMD_PWRON ... !!!
   252.990221 s: ISS: Initializing sensor [AR0233-UB953_MARS], doing IM_SENSOR_CMD_CONFIG ... !!!
[MCU2_0]    252.989142 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY
[MCU2_0]    252.989209 s: Received Query for AR0233-UB953_MARS
[MCU2_0]    252.989409 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON
[MCU2_0]    252.989463 s: IM_SENSOR_CMD_PWRON : channel_mask = 0x2
[MCU2_0]    252.989533 s: LXC DBG: AR0233_PowerOn, 429 print
[MCU2_0]    252.989575 s: LXC DBG: AR0233_Debug, 795 print
[MCU2_0]    252.989683 s: AR0233 Debug Reg 0 : FRAME_COUNT2, Addr 0x2000, Value 0xabcd
[MCU2_0]    252.989723 s: AR0233 Debug status =  -1
[MCU2_0]    252.989821 s: AR0233 Debug Reg 1 : FRAME_COUNT, Addr 0x2002, Value 0xabcd
[MCU2_0]    252.989858 s: AR0233 Debug status =  -1
[MCU2_0]    252.989951 s: AR0233 Debug Reg 2 : FRAME_STATUS, Addr 0x2008, Value 0xabcd
[MCU2_0]    252.989985 s: AR0233 Debug status =  -1
[MCU2_0]    252.990075 s: AR0233 Debug Reg 3 : CHIP_VERSION_REG, Addr 0x3000, Value 0xabcd
[MCU2_0]    252.990113 s: AR0233 Debug status =  -1
[MCU2_0]    252.990154 s: LXC DBG: AR0233_Debug, 814 print , status = -1
[MCU2_0]    252.990289 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG
[MCU2_0]    252.990347 s: Application requested features = 0x158
[MCU2_0]
[MCU2_0]    252.990403 s: UB960 config start
[MCU2_0]    253.246473 s: End of UB960 config
[MCU2_0]    253.246531 s: UB960 config start
[MCU2_0]    253.502423 s: End of UB960 config
[MCU2_0]    253.502477 s: Configuring camera # 1
[MCU2_0]    253.502536 s: LXC DBG: AR0233_Config, 274 print
[MCU2_0]    253.502701 s: UB960 config start
[MCU2_0]    253.506474 s: End of UB960 config
[MCU2_0]    253.556384 s: ub953 config start : slaveAddr = 0x76
[MCU2_0]    254.561478 s:  End of UB953 config
[MCU2_0]    254.611383 s:  Configuring AR0233 imager .. Please wait till it finishes
   255.591614 s: ISS: Initializing sensor [AR0233-UB953_MARS] ... Done !!!
Creating graph
Initializing params for capture node
capture_config = 0x0x6e0410
Creating capture node
obj->capture_node = 0x0x69ad10
read_test_image_raw : Unable to open file /opt/vision_apps/test_data/img_test.raw
app_create_viss : sensor_dcc_id = 233
AEWB Set Reference done
Enabling LDC
Creating LDC
[MCU2_0]    255.591381 s:  AR0233 config done
[MCU2_0]    255.591471 s: LXC DBG: AR0233_Config, 367 print , status = 0
[MCU2_0]    255.591507 s: IM_SENSOR_CMD_CONFIG returning status = 0
Display Set Target done
vxSetGraphScheduleConfig done
Scaler is disabled
app_create_graph exiting
app_create_graph done
 Demo : Single Camera w/ 2A
 p: Print performance statistics
 s: Save Sensor RAW, VISS Output and H3A output images to File System
 e: Export performance statistics
 u: Update DCC from File System
 x: Exit
 Enter Choice:
Unsupported command
 x: Exit
 Enter Choice:    255.629466 s: ISS: Starting sensor [AR0233-UB953_MARS] ... !!!
[MCU2_0]    255.629582 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_STREAM_ON
[MCU2_0]    255.629654 s: IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0x2
[MCU2_0]    255.629689 s: UB960 config start
[MCU2_0]    255.885472 s: End of UB960 config
[MCU2_0]    255.885533 s: UB960 config start
[MCU2_0]    256.141427 s: End of UB960 config
[MCU2_0]    256.141516 s: LXC DBG: AR0233_StreamOn, 377 print
[MCU2_0]    256.141560 s: LXC DBG: AR0233_Debug, 795 print
[MCU2_0]    256.142870 s: AR0233 Debug Reg 0 : FRAME_COUNT2, Addr 0x2000, Value 0xffff
[MCU2_0]    256.142921 s: AR0233 Debug status =  0
[MCU2_0]    256.144224 s: AR0233 Debug Reg 1 : FRAME_COUNT, Addr 0x2002, Value 0xffff
[MCU2_0]    256.144268 s: AR0233 Debug status =  0
[MCU2_0]    256.145570 s: AR0233 Debug Reg 2 : FRAME_STATUS, Addr 0x2008, Value 0x2
[MCU2_0]    256.145610 s: AR0233 Debug status =  0
[MCU2_0]    256.146911 s: AR0233 Debug Reg 3 : CHIP_VERSION_REG, Addr 0x3000, Value 0x956
[MCU2_0]    256.146954 s: AR0233 Debug status =  0
[MCU2_0]    256.147001 s: LXC DBG: AR0233_Debug, 814 print , status = 0
[MCU2_0]    256.157382 s: UB960 config start
   256.173664 s: ISS: Starting sensor [AR0233-UB953_MARS] ... !!!
[MCU2_0]    256.173477 s: End of UB960 config
[MCU2_0]    256.173553 s: LXC DBG: AR0233_StreamOn, 395 print , status = 0
get_dcc_dir_size : Could not open directory or directory is empty /opt/vision_apps/dcc/AR0233-UB953_MARS/wdr
Unsupported command
 x: Exit
 Enter Choice: s
RAW file name /opt/vision_apps/test_data/img_0000.raw
in width =  1920
in height =  1280
in format =  1052672
4915200 bytes written to /opt/vision_apps/test_data/img_0000.raw
YUV file name /opt/vision_apps/test_data/img_viss_0000.yuv
imgaddr_width = 1920
imgaddr_height = 1280
imgaddr_stride = 1920
width = 1920
height = 1280
Written 3686400 bytes
3686400 bytes written to /opt/vision_apps/test_data/img_viss_0000.yuv
H3A file name /opt/vision_apps/test_data/h3a_0000.bin
24576 bytes saved from H3A output buffer
YUV file name /opt/vision_apps/test_data/img_ldc_0000.yuv
imgaddr_height = 1080
width = 1920
height = 1080
Written 3110400 bytes
3110400 bytes written to /opt/vision_apps/test_data/img_ldc_0000.yuv
 x: Exit
 Enter Choice:
Unsupported command
 x: Exit
 Enter Choice: s
RAW file name /opt/vision_apps/test_data/img_0001.raw
in width =  1920
in height =  1280
in format =  1052672
4915200 bytes written to /opt/vision_apps/test_data/img_0001.raw
YUV file name /opt/vision_apps/test_data/img_viss_0001.yuv
width = 1920
height = 1280
3686400 bytes written to /opt/vision_apps/test_data/img_viss_0001.yuv
H3A file name /opt/vision_apps/test_data/h3a_0001.bin
YUV file name /opt/vision_apps/test_data/img_ldc_0001.yuv
width = 1920
height = 1080
3110400 bytes written to /opt/vision_apps/test_data/img_ldc_0001.yuv
 x: Exit
 Enter Choice:
Unsupported command
 x: Exit
 Enter Choice: s
RAW file name /opt/vision_apps/test_data/img_0002.raw
in width =  1920
in height =  1280
in format =  1052672
4915200 bytes written to /opt/vision_apps/test_data/img_0002.raw
YUV file name /opt/vision_apps/test_data/img_viss_0002.yuv
width = 1920
height = 1280
3686400 bytes written to /opt/vision_apps/test_data/img_viss_0002.yuv
H3A file name /opt/vision_apps/test_data/h3a_0002.bin
YUV file name /opt/vision_apps/test_data/img_ldc_0002.yuv
width = 1920
height = 1080
3110400 bytes written to /opt/vision_apps/test_data/img_ldc_0002.yuv
 x: Exit
 Enter Choice:
Unsupported command
 x: Exit
 Enter Choice: ^C
Clean up and exit while handling signal 2
Application did not close some rpmsg_char devices
root@j7-evm:/opt/vision_apps# [MCU2_0]    315.860488 s: DHCP client timed out. Retrying.....
[MCU2_0]    483.860492 s: DHCP client timed out. Retrying....
    手动添加 WDR 相关文件后,日志如下所示:
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       160.468064 s: GTC Frequency = 200 MHz
       160.469744 s:  VX_ZONE_INIT:Enabled
       160.469774 s:  VX_ZONE_ERROR:Enabled
       160.469779 s:  VX_ZONE_WARNING:Enabled
       160.476655 s:  VX_ZONE_INIT:[tivxInit:71] Initialization Done !!!
       160.476917 s:  VX_ZONE_INIT:[tivxHostInit:48] Initialization Done for HOST !!!
    Invalid token [
    Invalid token [
    ldc_enable = [0]
    Invalid token [
    Invalid token [
       160.482160 s: ISS: Enumerating sensors ... !!!
    [MCU2_0]    160.482291 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CREATE
    [MCU2_0]    160.482408 s: LXC DBG: IssSensor_DeserializerInit, 634 print
    [MCU2_0]    160.482524 s: UB960 config start
    [MCU2_0]    160.682490 s: End of UB960 config
    [MCU2_0]    160.682546 s: UB960 config start
       160.882472 s: ISS: Enumerating sensors ... found 0 : IMX390-UB953_D3
       160.882496 s: ISS: Enumerating sensors ... found 1 : AR0233-UB953_MARS
       160.882518 s: ISS: Enumerating sensors ... found 2 : AR0820-UB953_LI
       160.882523 s: ISS: Enumerating sensors ... found 3 : UB9xxx_RAW12_TESTPATTERN
       160.882528 s: ISS: Enumerating sensors ... found 4 : UB96x_UYVY_TESTPATTERN
       160.882533 s: ISS: Enumerating sensors ... found 5 : GW_AR0233_UYVY
    Select camera port index 0-7 : [MCU2_0]    160.882334 s: End of UB960 config
    1
    a : IMX390-UB953_D3
    c : AR0820-UB953_LI
    f : GW_AR0233_UYVY
    . Try again
    a : IMX390-UB953_D3
    c : AR0820-UB953_LI
    f : GW_AR0233_UYVY
    app_init done
       167.400481 s: ISS: Querying sensor [AR0233-UB953_MARS] ... !!!
       167.400756 s: ISS: Querying sensor [AR0233-UB953_MARS] ... Done !!!
    Sensor width = 1920
    Sensor DCC ID = 233
       167.400791 s: ISS: Initializing sensor [AR0233-UB953_MARS], doing IM_SENSOR_CMD_PWRON ... !!!
       167.401743 s: ISS: Initializing sensor [AR0233-UB953_MARS], doing IM_SENSOR_CMD_CONFIG ... !!!
    [MCU2_0]    167.400607 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_QUERY
    [MCU2_0]    167.400673 s: Received Query for AR0233-UB953_MARS
    [MCU2_0]    167.400853 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_PWRON
    [MCU2_0]    167.400907 s: IM_SENSOR_CMD_PWRON : channel_mask = 0x2
    [MCU2_0]    167.400975 s: LXC DBG: AR0233_PowerOn, 429 print
    [MCU2_0]    167.401018 s: LXC DBG: AR0233_Debug, 795 print
    [MCU2_0]    167.401123 s: AR0233 Debug Reg 0 : FRAME_COUNT2, Addr 0x2000, Value 0xabcd
    [MCU2_0]    167.401169 s: AR0233 Debug status =  -1
    [MCU2_0]    167.401297 s: AR0233 Debug Reg 1 : FRAME_COUNT, Addr 0x2002, Value 0xabcd
    [MCU2_0]    167.401346 s: AR0233 Debug status =  -1
    [MCU2_0]    167.401456 s: AR0233 Debug Reg 2 : FRAME_STATUS, Addr 0x2008, Value 0xabcd
    [MCU2_0]    167.401496 s: AR0233 Debug status =  -1
    [MCU2_0]    167.401591 s: AR0233 Debug Reg 3 : CHIP_VERSION_REG, Addr 0x3000, Value 0xabcd
    [MCU2_0]    167.401630 s: AR0233 Debug status =  -1
    [MCU2_0]    167.401675 s: LXC DBG: AR0233_Debug, 814 print , status = -1
    [MCU2_0]    167.401813 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_CONFIG
    [MCU2_0]    167.401861 s: Application requested features = 0x158
    [MCU2_0]
    [MCU2_0]    167.401897 s: UB960 config start
    [MCU2_0]    167.657310 s: End of UB960 config
    [MCU2_0]    167.657372 s: UB960 config start
    [MCU2_0]    167.913262 s: End of UB960 config
    [MCU2_0]    167.913318 s: Configuring camera # 1
    [MCU2_0]    167.913379 s: LXC DBG: AR0233_Config, 274 print
    [MCU2_0]    167.913548 s: UB960 config start
    [MCU2_0]    167.917317 s: End of UB960 config
    [MCU2_0]    167.967221 s: ub953 config start : slaveAddr = 0x76
    [MCU2_0]    168.972321 s:  End of UB953 config
    [MCU2_0]    169.022224 s:  Configuring AR0233 imager .. Please wait till it finishes
       170.002463 s: ISS: Initializing sensor [AR0233-UB953_MARS] ... Done !!!
    Creating graph
    [MCU2_0]    170.002227 s:  AR0233 config done
    [MCU2_0]    170.002317 s: LXC DBG: AR0233_Config, 367 print , status = 0
    [MCU2_0]    170.002353 s: IM_SENSOR_CMD_CONFIG returning status = 0
    Enabling LDC
    Creating LDC
    Scaler is disabled
     x: Exit
     Enter Choice:
    Unsupported command
     x: Exit
     Enter Choice:    170.048380 s: ISS: Starting sensor [AR0233-UB953_MARS] ... !!!
    [MCU2_0]    170.048496 s: ImageSensor_RemoteServiceHandler: IM_SENSOR_CMD_STREAM_ON
    [MCU2_0]    170.048569 s: IM_SENSOR_CMD_STREAM_ON:  channel_mask = 0x2
    [MCU2_0]    170.048608 s: UB960 config start
    [MCU2_0]    170.304315 s: End of UB960 config
    [MCU2_0]    170.304376 s: UB960 config start
    [MCU2_0]    170.560269 s: End of UB960 config
    [MCU2_0]    170.560360 s: LXC DBG: AR0233_StreamOn, 377 print
    [MCU2_0]    170.560408 s: LXC DBG: AR0233_Debug, 795 print
    [MCU2_0]    170.561718 s: AR0233 Debug Reg 0 : FRAME_COUNT2, Addr 0x2000, Value 0xffff
    [MCU2_0]    170.561770 s: AR0233 Debug status =  0
    [MCU2_0]    170.563075 s: AR0233 Debug Reg 1 : FRAME_COUNT, Addr 0x2002, Value 0xffff
    [MCU2_0]    170.563120 s: AR0233 Debug status =  0
    [MCU2_0]    170.564424 s: AR0233 Debug Reg 2 : FRAME_STATUS, Addr 0x2008, Value 0x2
    [MCU2_0]    170.564468 s: AR0233 Debug status =  0
    [MCU2_0]    170.565772 s: AR0233 Debug Reg 3 : CHIP_VERSION_REG, Addr 0x3000, Value 0x956
    [MCU2_0]    170.565812 s: AR0233 Debug status =  0
    [MCU2_0]    170.565857 s: LXC DBG: AR0233_Debug, 814 print , status = 0
    [MCU2_0]    170.576223 s: UB960 config start
       170.592511 s: ISS: Starting sensor [AR0233-UB953_MARS] ... !!!
    [MCU2_0]    170.592320 s: End of UB960 config
    [MCU2_0]    170.592405 s: LXC DBG: AR0233_StreamOn, 395 print , status = 0
    Unsupported command
     x: Exit
     Enter Choice: s
    in width =  1920
    in height =  1280
    in format =  1052672
    width = 1920
    height = 1280
    width = 1920
    height = 1080
     x: Exit
     Enter Choice:
    Unsupported command
     x: Exit
     Enter Choice: s
    in width =  1920
    in height =  1280
    in format =  1052672
    width = 1920
    height = 1280
    width = 1920
    height = 1080
     x: Exit
     Enter Choice:
    Unsupported command
     x: Exit
     Enter Choice: x
    [MCU2_0]    193.246330 s: DHCP client timed out. Retrying.....
    输出文件为:
    您好、Xianchou、
    我无法访问您附加的文件。 您可以重新上传吗? 几个问题:
    1.屏幕上的图像是否正确?
    2.您使用的是火星模块还是其他一些 AR0233模块?
    3.您是否对 SDK 07_03_00_07的源代码进行了任何更改?
    1.屏幕看不到任何内容。 它看起来像是没有 DP 的信号输出。
    2.我不确定 ar0233是否是火星模块。 它是自定义的第三方
    3.由于 Fusion 板只有一个 ub960,所以我只注释掉下面的一些代码:
    //ti-processor-sdk-rtos-j721e-evm-07_03_00_07/imaging/sensor_drv/src/iss_sensors.c  ImageSensor_RemoteServiceHandler
    case IM_SENSOR_CMD_DETECT:
                    uint8_t chId = 0;
                    int32_t probeStatus;
                    uint8_t serializers_detected = 0;
                    memcpy(&channel_mask, cmd_param, sizeof(uint32_t));
                    probeStatus = IssSensor_detect_serializer(BOARD_CSI_INST_0, &serializers_detected);
                    if(probeStatus != 0)
                        printf("LXC: BOARD_CSI_INST_0 = %d\n" , BOARD_CSI_INST_0);
                        issLogPrintf("IssSensor_detect_serializer returned 0x%x \n", probeStatus);
                        return -1;
                    printf("LXC: serializers_detected = 0x%x\n" , serializers_detected);
                    // probeStatus = IssSensor_detect_serializer(BOARD_CSI_INST_1, &serializers_detected);
                    // if(probeStatus != 0)
                    //     printf("LXC: BOARD_CSI_INST_1 = %d\n" , BOARD_CSI_INST_1);
                    //     issLogPrintf("IssSensor_detect_serializer returned 0x%x \n", probeStatus);
                    //     return -1;
    我无法从 PC 上传图片。 错误的方式吗?
    "插入->图像/视频/文件->文件/URL"、然后"不允许插入文件或 URL "
    您好、Xianchao、
    驱动程序通常是特定于模块的。 TI 的驱动程序仅用于 MARS 模块。 您的第三方摄像头可能需要不同的电源/复位序列。 我建议从您的模块供应商处获取串行器和传感器设置并更新驱动程序。
    梅扬克
    好的,我会尝试它。 谢谢
    Mayank、您好、这是我的行照片。 图片中似乎有一些东西、但我看不清。 我尝试了许多分辨率和图像格式、但它不起作用。
    您能否连接从单个凸轮应用程序转储的原始帧?
    数据1:
    e2e.ti.com/.../4035.testdata1.tar.gz
    数据2:
    e2e.ti.com/.../6523.testdata2.tar.gz
    此图像仅包含噪声。 请与您的模块供应商合作、获取摄像头+串行器/解串器设置并更新驱动程序。
