[参考译文] TDA4VM:TDA4是否支持32位 DDR4和 LPDDR4? 如果我们有任何主要用于 TDA4的 PUSH DDR 器件型号?
Guru**** 2534260 points
Other Parts Discussed in Thread: TDA4VM
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1029655/tda4vm-whether-tda4-support-32bit-ddr4-and-lpddr4-if-we-have-any-mainly-push-ddr-part-number-for-tda4
器件型号:TDA4VM
