[参考译文] AM4378:Linux SDK - MMC2问题
Guru**** 2540720 points
Other Parts Discussed in Thread: AM4378
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1033793/am4378-linux-sdk---mmc2-problem
器件型号:AM4378
我正在使用 TI SDK Linux 07.03.00.005开发 ARM MPU AM4378通用 EVM。 我想通过 MMC2接口将 WLAN 芯片连接到 MPU。 在多次尝试失败后、我决定执行一些测试、以确保 MMC2接口正常工作。 我只需将 SD 卡连接到 EVM 板即可检查卡检测过程。 不幸的是、几天后、我仍然没有取得进展。
首先、我使用 EVM 上的摄像头1接头来连接 SD 卡、因此我在*。dts 文件中重新配置了引脚多路复用器。
// SPDX-License-Identifier: GPL-2.0-only
 * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
/* AM437x GP EVM */
/dts-v1/;
#include "am4372.dtsi"
#include <dt-bindings/pinctrl/am43xx.h>
#include <dt-bindings/pwm/pwm.h>
#include <dt-bindings/gpio/gpio.h>
	model = "CMs Controller";
	compatible = "ti,am437x-gp-evm","ti,am4372","ti,am43";
	aliases {
		display0 = &lcd0;
	chosen {
		stdout-path = &uart0;
	evm_v3_3d: fixedregulator-v3_3d {
		compatible = "regulator-fixed";
		regulator-name = "evm_v3_3d";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		enable-active-high;
	vtt_fixed: fixedregulator-vtt {
		regulator-name = "vtt_fixed";
		regulator-min-microvolt = <1500000>;
		regulator-max-microvolt = <1500000>;
		regulator-always-on;
		regulator-boot-on;
		enable-active-high;
		gpio = <&gpio5 7 GPIO_ACTIVE_HIGH>;
	vmmcwl_fixed: fixedregulator-mmcwl {
		regulator-name = "vmmcwl_fixed";
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <1800000>;
		gpio = <&gpio1 20 GPIO_ACTIVE_HIGH>;
		enable-active-high;
	lcd_bl: backlight {
		compatible = "pwm-backlight";
		pwms = <&ecap0 0 50000 PWM_POLARITY_INVERTED>;
		brightness-levels = <0 51 53 56 62 75 101 152 255>;
		default-brightness-level = <8>;
	matrix_keypad: matrix_keypad0 {
		compatible = "gpio-matrix-keypad";
		debounce-delay-ms = <5>;
		col-scan-delay-us = <2>;
		pinctrl-names = "default", "sleep";
		pinctrl-0 = <&matrix_keypad_default>;
		pinctrl-1 = <&matrix_keypad_sleep>;
		wakeup-source;
		row-gpios = <&gpio0 3 GPIO_ACTIVE_HIGH /* Bank0, pin3 */
				&gpio4 3 GPIO_ACTIVE_HIGH /* Bank4, pin3 */
				&gpio4 2 GPIO_ACTIVE_HIGH>; /* Bank4, pin2 */
		col-gpios = <&gpio3 19 GPIO_ACTIVE_HIGH /* Bank3, pin19 */
				&gpio3 20 GPIO_ACTIVE_HIGH>; /* Bank3, pin20 */
		linux,keymap = <0x00000201      /* P1 */
				0x00010202      /* P2 */
				0x01000067      /* UP */
				0x0101006a      /* RIGHT */
				0x02000069      /* LEFT */
				0x0201006c>;      /* DOWN */
	lcd0: display {
		compatible = "osddisplays,osd070t1718-19ts", "panel-dpi";
		label = "lcd";
		backlight = <&lcd_bl>;
		port {
			lcd_in: endpoint {
				remote-endpoint = <&dpi_out>;
	/* fixed 12MHz oscillator */
	refclk: oscillator {
		#clock-cells = <0>;
		compatible = "fixed-clock";
		clock-frequency = <12000000>;
	/* fixed 32k external oscillator clock */
	clk_32k_rtc: clk_32k_rtc {
		#clock-cells = <0>;
		clock-frequency = <32768>;
	sound0: sound0 {
		compatible = "simple-audio-card";
		simple-audio-card,name = "AM437x-GP-EVM";
		simple-audio-card,widgets =
			"Headphone", "Headphone Jack",
			"Line", "Line In";
		simple-audio-card,routing =
			"Headphone Jack",	"HPLOUT",
			"Headphone Jack",	"HPROUT",
			"LINE1L",		"Line In",
			"LINE1R",		"Line In";
		simple-audio-card,format = "dsp_b";
		simple-audio-card,bitclock-master = <&sound0_master>;
		simple-audio-card,frame-master = <&sound0_master>;
		simple-audio-card,bitclock-inversion;
		simple-audio-card,cpu {
			sound-dai = <&mcasp1>;
			system-clock-frequency = <12000000>;
		sound0_master: simple-audio-card,codec {
			sound-dai = <&tlv320aic3106>;
	beeper: beeper {
		compatible = "gpio-beeper";
		pinctrl-names = "default";
		pinctrl-0 = <&beeper_pins_default>;
		pinctrl-1 = <&beeper_pins_sleep>;
		gpios = <&gpio4 12 GPIO_ACTIVE_HIGH>;
	wfx_pwrseq: wfx_pwrseq {
		compatible = "mmc-pwrseq-simple";
		pinctrl-0 = <&wfx_reset>;
		reset-gpios = <&gpio4 8 GPIO_ACTIVE_LOW>;
&am43xx_pinmux {
	pinctrl-0 = <&ddr3_vtt_toggle_default &unused_pins &debugss_pins>;
	ddr3_vtt_toggle_default: ddr_vtt_toggle_default {
		pinctrl-single,pins = <
			0x25C (DS0_PULL_UP_DOWN_EN | PIN_OUTPUT_PULLUP | DS0_FORCE_OFF_MODE | MUX_MODE7) /* spi0_cs0.gpio5_7 */
	i2c0_pins: i2c0_pins {
			AM4372_IOPAD(0x988, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)  /* i2c0_sda.i2c0_sda */
			AM4372_IOPAD(0x98c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)  /* i2c0_scl.i2c0_scl */
	i2c1_pins: i2c1_pins {
			AM4372_IOPAD(0x95c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2)  /* spi0_cs0.i2c1_scl */
			AM4372_IOPAD(0x958, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE2)  /* spi0_d1.i2c1_sda  */
	mmc1_pins: pinmux_mmc1_pins {
			AM4372_IOPAD(0x960, PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */
	ecap0_pins: backlight_pins {
			AM4372_IOPAD(0x964, MUX_MODE0)       /* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out MODE0 */
	pixcir_ts_pins: pixcir_ts_pins {
			AM4372_IOPAD(0xa64, PIN_INPUT_PULLUP | MUX_MODE7)  /* spi2_d0.gpio3_22 */
	cpsw_default: cpsw_default {
			/* Slave 1 */
			AM4372_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txen.rgmii1_txen */
			AM4372_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxdv.rgmii1_rxctl */
			AM4372_IOPAD(0x91c, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd1.rgmii1_txd3 */
			AM4372_IOPAD(0x920, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd0.rgmii1_txd2 */
			AM4372_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd1.rgmii1_txd1 */
			AM4372_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd0.rgmii1_txd0 */
			AM4372_IOPAD(0x92c, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txclk.rmii1_tclk */
			AM4372_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxclk.rmii1_rclk */
			AM4372_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd1.rgmii1_rxd3 */
			AM4372_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd0.rgmii1_rxd2 */
			AM4372_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd1.rgmii1_rxd1 */
			AM4372_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd0.rgmii1_rxd0 */
	cpsw_sleep: cpsw_sleep {
			/* Slave 1 reset value */
			AM4372_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x91c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x920, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x92c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7)
	davinci_mdio_default: davinci_mdio_default {
			/* MDIO */
			AM4372_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)	/* mdio_data.mdio_data */
			AM4372_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0)			/* mdio_clk.mdio_clk */
	davinci_mdio_sleep: davinci_mdio_sleep {
			/* MDIO reset value */
			AM4372_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7)
	nand_flash_x8: nand_flash_x8 {
			AM4372_IOPAD(0x800, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad0.gpmc_ad0 */
			AM4372_IOPAD(0x804, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad1.gpmc_ad1 */
			AM4372_IOPAD(0x808, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad2.gpmc_ad2 */
			AM4372_IOPAD(0x80c, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad3.gpmc_ad3 */
			AM4372_IOPAD(0x810, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad4.gpmc_ad4 */
			AM4372_IOPAD(0x814, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad5.gpmc_ad5 */
			AM4372_IOPAD(0x818, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad6.gpmc_ad6 */
			AM4372_IOPAD(0x81c, PIN_INPUT  | MUX_MODE0)	/* gpmc_ad7.gpmc_ad7 */
			AM4372_IOPAD(0x870, PIN_INPUT_PULLUP | MUX_MODE0)	/* gpmc_wait0.gpmc_wait0 */
			AM4372_IOPAD(0x874, PIN_OUTPUT_PULLUP | MUX_MODE7)	/* gpmc_wpn.gpmc_wpn */
			AM4372_IOPAD(0x87c, PIN_OUTPUT | MUX_MODE0)		/* gpmc_csn0.gpmc_csn0  */
			AM4372_IOPAD(0x890, PIN_OUTPUT | MUX_MODE0)		/* gpmc_advn_ale.gpmc_advn_ale */
			AM4372_IOPAD(0x894, PIN_OUTPUT | MUX_MODE0)		/* gpmc_oen_ren.gpmc_oen_ren */
			AM4372_IOPAD(0x898, PIN_OUTPUT | MUX_MODE0)		/* gpmc_wen.gpmc_wen */
			AM4372_IOPAD(0x89c, PIN_OUTPUT | MUX_MODE0)		/* gpmc_be0n_cle.gpmc_be0n_cle */
	dss_pins: dss_pins {
			AM4372_IOPAD(0x820, PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 8 -> DSS DATA 23 */
			AM4372_IOPAD(0x824, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x828, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x82c, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x830, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x834, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x838, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x83c, PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 15 -> DSS DATA 16 */
			AM4372_IOPAD(0x8a0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 0 */
			AM4372_IOPAD(0x8a4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8a8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8ac, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8b0, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8b4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8b8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8bc, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8c0, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8c4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8c8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8cc, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8d0, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8d4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8d8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8dc, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 15 */
			AM4372_IOPAD(0x8e0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS VSYNC */
			AM4372_IOPAD(0x8e4, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS HSYNC */
			AM4372_IOPAD(0x8e8, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS PCLK */
			AM4372_IOPAD(0x8ec, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS AC BIAS EN */
	display_mux_pins: display_mux_pins {
			/* GPIO 5_8 to select LCD / HDMI */
			AM4372_IOPAD(0xa38, PIN_OUTPUT_PULLUP | MUX_MODE7)
	dcan0_default: dcan0_default_pins {
			AM4372_IOPAD(0x978, PIN_OUTPUT | MUX_MODE2)		/* uart1_ctsn.d_can0_tx */
			AM4372_IOPAD(0x97c, PIN_INPUT_PULLUP | MUX_MODE2)	/* uart1_rtsn.d_can0_rx */
	dcan0_sleep: dcan0_sleep_pins {
			AM4372_IOPAD(0x978, PIN_INPUT_PULLUP | MUX_MODE7)	/* uart1_ctsn.gpio0_12 */
			AM4372_IOPAD(0x97c, PIN_INPUT_PULLUP | MUX_MODE7)	/* uart1_rtsn.gpio0_13 */
	dcan1_default: dcan1_default_pins {
			AM4372_IOPAD(0x980, PIN_OUTPUT | MUX_MODE2)		/* uart1_rxd.d_can1_tx */
			AM4372_IOPAD(0x984, PIN_INPUT_PULLUP | MUX_MODE2)	/* uart1_txd.d_can1_rx */
	dcan1_sleep: dcan1_sleep_pins {
			AM4372_IOPAD(0x980, PIN_INPUT_PULLUP | MUX_MODE7)	/* uart1_rxd.gpio0_14 */
			AM4372_IOPAD(0x984, PIN_INPUT_PULLUP | MUX_MODE7)	/* uart1_txd.gpio0_15 */
	vpfe0_pins_default: vpfe0_pins_default {
			AM4372_IOPAD(0x9b0, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_hd mode 0*/
			AM4372_IOPAD(0x9b4, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_vd mode 0*/
			AM4372_IOPAD(0x9c0, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_pclk mode 0*/
			AM4372_IOPAD(0x9c4, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data8 mode 0*/
			AM4372_IOPAD(0x9c8, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data9 mode 0*/
			AM4372_IOPAD(0xa08, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data0 mode 0*/
			AM4372_IOPAD(0xa0c, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data1 mode 0*/
			AM4372_IOPAD(0xa10, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data2 mode 0*/
			AM4372_IOPAD(0xa14, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data3 mode 0*/
			AM4372_IOPAD(0xa18, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data4 mode 0*/
			AM4372_IOPAD(0xa1c, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data5 mode 0*/
			AM4372_IOPAD(0xa20, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data6 mode 0*/
			AM4372_IOPAD(0xa24, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data7 mode 0*/
	vpfe0_pins_sleep: vpfe0_pins_sleep {
			AM4372_IOPAD(0x9b0, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_hd mode 0*/
			AM4372_IOPAD(0x9b4, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_vd mode 0*/
			AM4372_IOPAD(0x9c0, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_pclk mode 0*/
			AM4372_IOPAD(0x9c4, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data8 mode 0*/
			AM4372_IOPAD(0x9c8, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data9 mode 0*/
			AM4372_IOPAD(0xa08, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data0 mode 0*/
			AM4372_IOPAD(0xa0c, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data1 mode 0*/
			AM4372_IOPAD(0xa10, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data2 mode 0*/
			AM4372_IOPAD(0xa14, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data3 mode 0*/
			AM4372_IOPAD(0xa18, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data4 mode 0*/
			AM4372_IOPAD(0xa1c, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data5 mode 0*/
			AM4372_IOPAD(0xa20, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data6 mode 0*/
			AM4372_IOPAD(0xa24, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data7 mode 0*/
	/* MMC2 pinmux configuration for WFM200S module */
	wfx_pins_default: pinmux_mmc3_pins_default {
			AM4372_IOPAD(0x9f0, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* cam1_data2 mode 3*/
			AM4372_IOPAD(0x9f4, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* cam1_data3 mode 3*/
			AM4372_IOPAD(0x9f8, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* cam1_data4 mode 3*/
			AM4372_IOPAD(0x9fc, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* cam1_data5 mode 3*/
			AM4372_IOPAD(0xa00, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* cam1_data6 mode 3*/
			AM4372_IOPAD(0xa04, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* cam1_data7 mode 3*/
	/* WFM200S Reset pin */
	wfx_reset: pinmux_wfx_reset {
			AM4372_IOPAD(0x9d0, PIN_OUTPUT_PULLUP | MUX_MODE7)  /* cam1_data8 mode 7*/
	/* WFM200S WakeUp pin */
	wfx_wakeup: pinmux_wfx_wakeup {
			AM4372_IOPAD(0x9cc, PIN_OUTPUT | MUX_MODE7)  /* cam1_data9 mode 7*/
	uart3_pins: uart3_pins {
			AM4372_IOPAD(0xa28, PIN_INPUT | MUX_MODE0)		/* uart3_rxd.uart3_rxd */
			AM4372_IOPAD(0xa2c, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart3_txd.uart3_txd */
			AM4372_IOPAD(0xa30, PIN_INPUT_PULLUP | MUX_MODE0)	/* uart3_ctsn.uart3_ctsn */
			AM4372_IOPAD(0xa34, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart3_rtsn.uart3_rtsn */
	mcasp1_pins: mcasp1_pins {
			AM4372_IOPAD(0x908, PIN_OUTPUT_PULLDOWN | MUX_MODE4)	/* mii1_col.mcasp1_axr2 */
			AM4372_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE4)	/* mii1_crs.mcasp1_aclkx */
			AM4372_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE4)	/* mii1_rxerr.mcasp1_fsx */
			AM4372_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE4)	/* rmii1_ref_clk.mcasp1_axr3 */
	mcasp1_sleep_pins: mcasp1_sleep_pins {
			AM4372_IOPAD(0x908, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x90c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x910, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x944, PIN_INPUT_PULLDOWN | MUX_MODE7)
	gpio0_pins: gpio0_pins {
			AM4372_IOPAD(0xa6c, PIN_OUTPUT | MUX_MODE9) /* spi2_cs0.gpio0_23 SEL_eMMCorNANDn */
	emmc_pins_default: emmc_pins_default {
			AM4372_IOPAD(0x800, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */
			AM4372_IOPAD(0x804, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */
			AM4372_IOPAD(0x808, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */
			AM4372_IOPAD(0x80c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */
			AM4372_IOPAD(0x810, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */
			AM4372_IOPAD(0x814, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */
			AM4372_IOPAD(0x818, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */
			AM4372_IOPAD(0x81c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */
			AM4372_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */
			AM4372_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */
	emmc_pins_sleep: emmc_pins_sleep {
			AM4372_IOPAD(0x800, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpio1_0 */
			AM4372_IOPAD(0x804, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpio1_1 */
			AM4372_IOPAD(0x808, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpio1_2 */
			AM4372_IOPAD(0x80c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpio1_3 */
			AM4372_IOPAD(0x810, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpio1_4 */
			AM4372_IOPAD(0x814, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpio1_5 */
			AM4372_IOPAD(0x818, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpio1_6 */
			AM4372_IOPAD(0x81c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpio1_7 */
			AM4372_IOPAD(0x880, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn1.gpio1_30 */
			AM4372_IOPAD(0x884, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn2.gpio1_31 */
	beeper_pins_default: beeper_pins_default {
			AM4372_IOPAD(0x9e0, PIN_OUTPUT_PULLUP | MUX_MODE7)	/* cam1_field.gpio4_12 */
	beeper_pins_sleep: beeper_pins_sleep {
			AM4372_IOPAD(0x9e0, PIN_INPUT_PULLDOWN | MUX_MODE7)	/* cam1_field.gpio4_12 */
	unused_pins: unused_pins {
			AM4372_IOPAD(0x854, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x858, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x860, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x864, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x868, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x86c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x950, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x990, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x994, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x998, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x99c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x9a0, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa3c, PIN_INPUT | PULL_DISABLE | MUX_MODE7)
			AM4372_IOPAD(0xa40, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa44, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa48, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa4c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa50, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa54, PIN_INPUT | PULL_DISABLE | MUX_MODE7)
			AM4372_IOPAD(0xa58, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa60, PIN_INPUT | PULL_DISABLE | MUX_MODE7)
			AM4372_IOPAD(0xa68, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa70, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa78, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa7c, PIN_INPUT | PULL_DISABLE)
			AM4372_IOPAD(0xac8, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xad4, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xad8, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xadc, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xae0, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xae4, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xae8, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaec, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaf0, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaf4, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaf8, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xafc, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb00, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb04, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb08, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb0c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb10, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb14, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb18, PIN_INPUT_PULLDOWN | MUX_MODE7)
	debugss_pins: pinmux_debugss_pins {
			AM4372_IOPAD(0xa90, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xa94, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xa98, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xa9c, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xaa0, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xaa4, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xaa8, PIN_INPUT_PULLDOWN)
	uart0_pins_default: uart0_pins_default {
			AM4372_IOPAD(0x968, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE0) /* uart0_ctsn.uart0_ctsn */
			AM4372_IOPAD(0x96C, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE0) /* uart0_rtsn.uart0_rtsn */
			AM4372_IOPAD(0x970, PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_rxd.uart0_rxd */
			AM4372_IOPAD(0x974, PIN_INPUT | PULL_DISABLE | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
	uart0_pins_sleep: uart0_pins_sleep {
			AM4372_IOPAD(0x968, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* uart0_ctsn.uart0_ctsn */
			AM4372_IOPAD(0x96C, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* uart0_rtsn.uart0_rtsn */
			AM4372_IOPAD(0x974, PIN_INPUT_PULLDOWN | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
	matrix_keypad_default: matrix_keypad_default {
			AM4372_IOPAD(0x9a4, PIN_OUTPUT | MUX_MODE7)
			AM4372_IOPAD(0x9a8, PIN_OUTPUT | MUX_MODE7)
			AM4372_IOPAD(0x9ac, PIN_INPUT | PULL_DISABLE | MUX_MODE9)
			AM4372_IOPAD(0x954, PIN_INPUT_PULLDOWN | MUX_MODE0)
	matrix_keypad_sleep: matrix_keypad_sleep {
			AM4372_IOPAD(0x9a4, PULL_UP | MUX_MODE7)
			AM4372_IOPAD(0x9a8, PULL_UP | MUX_MODE7)
&uart0 {
	status = "okay";
	pinctrl-0 = <&uart0_pins_default>;
	pinctrl-1 = <&uart0_pins_sleep>;
&i2c0 {
	status = "okay";
	pinctrl-0 = <&i2c0_pins>;
	clock-frequency = <100000>;
	tps65218: tps65218@24 {
		reg = <0x24>;
		compatible = "ti,tps65218";
		interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; /* NMIn */
		interrupt-controller;
		#interrupt-cells = <2>;
		dcdc1: regulator-dcdc1 {
			regulator-name = "vdd_core";
			regulator-min-microvolt = <912000>;
			regulator-max-microvolt = <1144000>;
			regulator-boot-on;
		dcdc2: regulator-dcdc2 {
			regulator-name = "vdd_mpu";
			regulator-max-microvolt = <1378000>;
			regulator-boot-on;
		dcdc3: regulator-dcdc3 {
			regulator-name = "vdcdc3";
			regulator-boot-on;
			regulator-state-mem {
				regulator-on-in-suspend;
			regulator-state-disk {
				regulator-off-in-suspend;
		dcdc5: regulator-dcdc5 {
			regulator-name = "v1_0bat";
			regulator-min-microvolt = <1000000>;
			regulator-max-microvolt = <1000000>;
			regulator-boot-on;
		dcdc6: regulator-dcdc6 {
			regulator-name = "v1_8bat";
			regulator-boot-on;
		ldo1: regulator-ldo1 {
			regulator-boot-on;
&i2c1 {
	status = "okay";
	pinctrl-0 = <&i2c1_pins>;
	pixcir_ts@5c {
		compatible = "pixcir,pixcir_tangoc";
		pinctrl-0 = <&pixcir_ts_pins>;
		reg = <0x5c>;
		attb-gpio = <&gpio3 22 GPIO_ACTIVE_HIGH>;
		 * 0x264 represents the offset of padconf register of
		 * gpio3_22 from am43xx_pinmux base.
		interrupts-extended = <&gpio3 22 IRQ_TYPE_EDGE_FALLING>,
				      <&am43xx_pinmux 0x264>;
		interrupt-names = "tsc", "wakeup";
		touchscreen-size-x = <1024>;
		touchscreen-size-y = <600>;
		wakeup-source;
	ov2659@30 {
		compatible = "ovti,ov2659";
		reg = <0x30>;
		clocks = <&refclk 0>;
		clock-names = "xvclk";
		port {
			ov2659_1: endpoint {
				remote-endpoint = <&vpfe0_ep>;
				link-frequencies = /bits/ 64 <70000000>;
	tlv320aic3106: tlv320aic3106@1b {
		#sound-dai-cells = <0>;
		compatible = "ti,tlv320aic3106";
		reg = <0x1b>;
		status = "okay";
		/* Regulators */
		IOVDD-supply = <&evm_v3_3d>; /* V3_3D -> <tps63031> EN: V1_8D -> VBAT */
		AVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
		DRVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
		DVDD-supply = <&ldo1>; /* V1_8D -> LDO1 */
&epwmss0 {
	status = "okay";
&tscadc {
	status = "okay";
	adc {
		ti,adc-channels = <0 1 2 3 4 5 6 7>;
&ecap0 {
	status = "okay";
	pinctrl-0 = <&ecap0_pins>;
&gpio0 {
	pinctrl-0 = <&gpio0_pins>;
	status = "okay";
	p23 {
		gpio-hog;
		gpios = <23 GPIO_ACTIVE_HIGH>;
		/* SelEMMCorNAND selects between eMMC and NAND:
		 * Low: NAND
		 * High: eMMC
		 * When changing this line make sure the newly
		 * selected device node is enabled and the previously
		 * selected device node is disabled.
		output-low;
		line-name = "SelEMMCorNAND";
&gpio1 {
	status = "okay";
&gpio3 {
	status = "okay";
&gpio4 {
	status = "okay";
&gpio5 {
	pinctrl-0 = <&display_mux_pins>;
	status = "okay";
	ti,no-reset-on-init;
	p8 {
		 * SelLCDorHDMI selects between display and audio paths:
		 * Low: HDMI display with audio via HDMI
		 * High: LCD display with analog audio via aic3111 codec
		gpio-hog;
		gpios = <8 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "SelLCDorHDMI";
/* MMC1 is for SDcard */
&mmc1 {
	status = "okay";
	vmmc-supply = <&evm_v3_3d>;
	bus-width = <4>;
	pinctrl-0 = <&mmc1_pins>;
	//cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
/* eMMC sits on mmc2 */
&mmc2 {
	 * When enabling eMMC, disable GPMC/NAND and set
	 * SelEMMCorNAND to output-high
	status = "disabled";
	bus-width = <8>;
	pinctrl-0 = <&emmc_pins_default>;
	pinctrl-1 = <&emmc_pins_sleep>;
	ti,non-removable;
&mmc3 {
	status = "okay";
	/* these are on the crossbar and are outlined in the
	   xbar-event-map element */
	dmas = <&edma_xbar 30 0 1>,
		<&edma_xbar 31 0 2>;
	dma-names = "tx", "rx";
	mmc-pwrseq = <&wfx_pwrseq>;
	bus-width = <4>;
	pinctrl-0 = <&wfx_pins_default>;
	//cap-power-off-card;
	//keep-power-in-suspend;
	//ti,non-removable;
	#address-cells = <1>;
	#size-cells = <0>;
	broken-cd;
	no-1-8-v;
	mmc@1 {
		compatible = "silabs,wf200";
		reg = <1>;
		pinctrl-0 = <&wfx_wakeup>;
		wakeup-gpios = <&gpio4 7 GPIO_ACTIVE_HIGH>;
&uart3 {
	status = "okay";
	pinctrl-0 = <&uart3_pins>;
&usb2_phy1 {
	status = "okay";
&usb1 {
	dr_mode = "otg";
	status = "okay";
&usb2_phy2 {
	status = "okay";
&usb2 {
	dr_mode = "host";
	status = "okay";
&mac {
	slaves = <1>;
	pinctrl-0 = <&cpsw_default>;
	pinctrl-1 = <&cpsw_sleep>;
	status = "okay";
&davinci_mdio {
	pinctrl-0 = <&davinci_mdio_default>;
	pinctrl-1 = <&davinci_mdio_sleep>;
	status = "okay";
	ethphy0: ethernet-phy@0 {
		reg = <0>;
&cpsw_emac0 {
	phy-handle = <&ethphy0>;
	phy-mode = "rgmii";
&elm {
	status = "okay";
&gpmc {
	 * When enabling GPMC, disable eMMC and set
	 * SelEMMCorNAND to output-low
	status = "okay";
	pinctrl-0 = <&nand_flash_x8>;
	ranges = <0 0 0x08000000 0x01000000>;	/* CS0 space. Min partition = 16MB */
	nand@0,0 {
		compatible = "ti,omap2-nand";
		reg = <0 0 4>;		/* device IO registers */
		interrupt-parent = <&gpmc>;
		interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */
			     <1 IRQ_TYPE_NONE>;	/* termcount */
		rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>;	/* gpmc_wait0 */
		ti,nand-xfer-type = "prefetch-dma";
		ti,nand-ecc-opt = "bch16";
		ti,elm-id = <&elm>;
		nand-bus-width = <8>;
		gpmc,device-width = <1>;
		gpmc,sync-clk-ps = <0>;
		gpmc,cs-on-ns = <0>;
		gpmc,cs-rd-off-ns = <40>;
		gpmc,cs-wr-off-ns = <40>;
		gpmc,adv-on-ns = <0>;
		gpmc,adv-rd-off-ns = <25>;
		gpmc,adv-wr-off-ns = <25>;
		gpmc,we-on-ns = <0>;
		gpmc,we-off-ns = <20>;
		gpmc,oe-on-ns = <3>;
		gpmc,oe-off-ns = <30>;
		gpmc,access-ns = <30>;
		gpmc,rd-cycle-ns = <40>;
		gpmc,wr-cycle-ns = <40>;
		gpmc,bus-turnaround-ns = <0>;
		gpmc,cycle2cycle-delay-ns = <0>;
		gpmc,clk-activation-ns = <0>;
		gpmc,wr-access-ns = <40>;
		gpmc,wr-data-mux-bus-ns = <0>;
		/* MTD partition table */
		/* All SPL-* partitions are sized to minimal length
		 * which can be independently programmable. For
		 * NAND flash this is equal to size of erase-block */
		#size-cells = <1>;
		partition@0 {
			label = "NAND.SPL";
			reg = <0x00000000 0x00040000>;
		partition@1 {
			label = "NAND.SPL.backup1";
			reg = <0x00040000 0x00040000>;
		partition@2 {
			label = "NAND.SPL.backup2";
			reg = <0x00080000 0x00040000>;
		partition@3 {
			label = "NAND.SPL.backup3";
			reg = <0x000c0000 0x00040000>;
		partition@4 {
			label = "NAND.u-boot-spl-os";
			reg = <0x00100000 0x00080000>;
		partition@5 {
			label = "NAND.u-boot";
			reg = <0x00180000 0x00100000>;
		partition@6 {
			label = "NAND.u-boot-env";
			reg = <0x00280000 0x00040000>;
		partition@7 {
			label = "NAND.u-boot-env.backup1";
			reg = <0x002c0000 0x00040000>;
		partition@8 {
			label = "NAND.kernel";
			reg = <0x00300000 0x00700000>;
		partition@9 {
			label = "NAND.file-system";
			reg = <0x00a00000 0x1f600000>;
&dss {
	status = "ok";
	pinctrl-0 = <&dss_pins>;
	port {
		dpi_out: endpoint {
			remote-endpoint = <&lcd_in>;
			data-lines = <24>;
&dcan0 {
	pinctrl-0 = <&dcan0_default>;
	pinctrl-1 = <&dcan0_sleep>;
	status = "okay";
&dcan1 {
	pinctrl-0 = <&dcan1_default>;
	pinctrl-1 = <&dcan1_sleep>;
	status = "okay";
&vpfe0 {
	status = "okay";
	pinctrl-0 = <&vpfe0_pins_default>;
	pinctrl-1 = <&vpfe0_pins_sleep>;
	port {
		vpfe0_ep: endpoint {
			remote-endpoint = <&ov2659_1>;
			ti,am437x-vpfe-interface = <0>;
			bus-width = <8>;
			hsync-active = <0>;
			vsync-active = <0>;
&mcasp1 {
	pinctrl-0 = <&mcasp1_pins>;
	pinctrl-1 = <&mcasp1_sleep_pins>;
	status = "okay";
	op-mode = <0>; /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	/* 4 serializers */
	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
		0 0 1 2
	tx-num-evt = <32>;
	rx-num-evt = <32>;
&rtc {
	clocks = <&clk_32k_rtc>, <&clk_32768_ck>;
	clock-names = "ext-clk", "int-clk";
	status = "okay";
&cpu {
	cpu0-supply = <&dcdc2>;
&wkup_m3_ipc {
	ti,set-io-isolation;
	ti,scale-data-fw = "am43x-evm-scale-data.bin";
&pruss_tm {
	status = "okay";
MMC2外设的 pinmux 在此处进行配置(我检查了 AM437x 数据表以获取每个引脚的 padconf 偏移的多路复用模式和参考手册):
MMC2_CLK  - AD21 - MODE3 - cam1_data2
MMC2_CMD  - AE22 - MODE3 - cam1_data3
MMC2_DAT0 - AD22 - MODE3 - cam1_data4
MMC2_DAT1 - AE23 - MODE3 - cam1_data5
MMC2_DAT2 - AD23 - MODE3 - cam1_data6
MMC2_DAT3 - AE24 - MODE3 - cam1_data7
RESET     - AD24 - MODE7 - cam1_data8
WUP       - AC24 - MODE7 - cam1_data9
我检查了 SD 卡和 EVM 接头之间的连接数次-仍然正常。 此外、在示波器上探测引脚 mmc2_clk 和 mmc2_dat 后、我可以看到频率为400kHz 的时钟信号和 dat 引脚上的状态变化。 但是、探测 SD 卡的所有尝试均失败。
dmesg 不显示有用的信息:
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.106-g023faefa70 (plszgor3@plszgor3-vm) (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #3 PREEMPT Mon Sep 6 11:41:24 CEST 2021
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: CMs Controller
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0xfcc00000
[    0.000000] On node 0 totalpages: 524287
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 327679 pages, LIFO batch:63
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM437x ES1.2 (sgx neon)
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522559
[    0.000000] Kernel command line: console=ttyO0,115200n8 video=HDMI-A-1:800x600 root=/dev/nfs nfsroot=10.0.0.1:/home/plszgor3/ti-processor-sdk-linux-am437x-evm-07.03.00.005/targetNFS,nolock,v3,tcp,rsize=4096,wsize=4096 rw ip=dhcp
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 2012156K/2097148K available (10240K kernel code, 663K rwdata, 3492K rodata, 1024K init, 264K bss, 35840K reserved, 49152K cma-reserved, 1261564K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] OMAP L2C310: ROM does not support power control setting
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[    0.000000] random: get_random_bytes called from start_kernel+0x318/0x4e0 with crng_init=0
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000031] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000039] OMAP clocksource: timer1 at 24000000 Hz
[    0.000488] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000498] OMAP clocksource: 32k_counter at 32768 Hz
[    0.001057] Console: colour dummy device 80x30
[    0.001090] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001095] This ensures that you still see kernel messages. Please
[    0.001099] update your kernel commandline.
[    0.001144] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
[    0.060187] pid_max: default: 32768 minimum: 301
[    0.060389] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.060411] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.061289] CPU: Testing write buffer coherency: ok
[    0.061348] CPU0: Spectre v2: using BPIALL workaround
[    0.062217] Setting up static identity map for 0x80100000 - 0x80100060
[    0.062363] rcu: Hierarchical SRCU implementation.
[    0.062470] EFI services will not be available.
[    0.063131] devtmpfs: initialized
[    0.074730] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.075118] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.075141] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.078276] pinctrl core: initialized pinctrl subsystem
[    0.079043] DMI not present or invalid.
[    0.079501] NET: Registered protocol family 16
[    0.081226] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.103220] cpuidle: using governor ladder
[    0.103253] cpuidle: using governor menu
[    0.122514] No ATAGs?
[    0.122534] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.122549] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.137970] debugfs: Directory '49000000.edma' with parent 'dmaengine' already present!
[    0.137999] edma 49000000.edma: TI EDMA DMA engine driver
[    0.138746] reg-fixed-voltage fixedregulator-v3_3d: GPIO lookup for consumer (null)
[    0.138756] reg-fixed-voltage fixedregulator-v3_3d: using device tree for GPIO lookup
[    0.138774] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-v3_3d[0]'
[    0.138785] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-v3_3d[0]'
[    0.138794] reg-fixed-voltage fixedregulator-v3_3d: using lookup tables for GPIO lookup
[    0.138800] reg-fixed-voltage fixedregulator-v3_3d: No GPIO consumer (null) found
[    0.139063] reg-fixed-voltage fixedregulator-vtt: GPIO lookup for consumer (null)
[    0.139071] reg-fixed-voltage fixedregulator-vtt: using device tree for GPIO lookup
[    0.139085] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vtt[0]'
[    0.139107] reg-fixed-voltage fixedregulator-vtt: No GPIO consumer (null) found
[    0.139178] reg-fixed-voltage fixedregulator-mmcwl: GPIO lookup for consumer (null)
[    0.139184] reg-fixed-voltage fixedregulator-mmcwl: using device tree for GPIO lookup
[    0.139197] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-mmcwl[0]'
[    0.139214] reg-fixed-voltage fixedregulator-mmcwl: No GPIO consumer (null) found
[    0.140120] iommu: Default domain type: Translated
[    0.142725] SCSI subsystem initialized
[    0.143236] mc: Linux media interface: v0.10
[    0.143284] videodev: Linux video capture interface: v2.00
[    0.143389] pps_core: LinuxPPS API ver. 1 registered
[    0.143397] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.143415] PTP clock support registered
[    0.143445] EDAC MC: Ver: 3.0.0
[    0.144573] Advanced Linux Sound Architecture Driver Initialized.
[    0.145720] clocksource: Switched to clocksource timer1
[    0.559526] thermal_sys: Registered thermal governor 'fair_share'
[    0.559533] thermal_sys: Registered thermal governor 'bang_bang'
[    0.559547] thermal_sys: Registered thermal governor 'step_wise'
[    0.559552] thermal_sys: Registered thermal governor 'user_space'
[    0.559557] thermal_sys: Registered thermal governor 'power_allocator'
[    0.560232] NET: Registered protocol family 2
[    0.560939] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.560969] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.561030] TCP bind hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.561102] TCP: Hash tables configured (established 8192 bind 8192)
[    0.561276] UDP hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.561301] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.561456] NET: Registered protocol family 1
[    0.562029] RPC: Registered named UNIX socket transport module.
[    0.562040] RPC: Registered udp transport module.
[    0.562044] RPC: Registered tcp transport module.
[    0.562049] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.562062] PCI: CLS 0 bytes, default 64
[    0.563934] Initialise system trusted keyrings
[    0.564239] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.568809] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.569556] NFS: Registering the id_resolver key type
[    0.569593] Key type id_resolver registered
[    0.569599] Key type id_legacy registered
[    0.569645] ntfs: driver 2.1.32 [Flags: R/O].
[    0.570333] Key type asymmetric registered
[    0.570345] Asymmetric key parser 'x509' registered
[    0.570393] bounce: pool size: 64 pages
[    0.570442] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.570452] io scheduler mq-deadline registered
[    0.570458] io scheduler kyber registered
[    0.597216] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
[    0.597307] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio-0-31)
[    0.597349] OMAP GPIO hardware version 0.1
[    0.599605] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.616135] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
[    0.616217] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio-32-63)
[    0.621742] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
[    0.621837] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio-64-95)
[    0.622143] ti-sysc 48322000.target-module: dts flag should be at module level for ti,no-reset-on-init
[    0.633039] pinctrl-single 44e10800.pinmux: 199 pins, size 796
[    0.637271] pwm-backlight backlight: GPIO lookup for consumer enable
[    0.637282] pwm-backlight backlight: using device tree for GPIO lookup
[    0.637303] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[    0.637315] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[    0.637325] pwm-backlight backlight: using lookup tables for GPIO lookup
[    0.637331] pwm-backlight backlight: No GPIO consumer enable found
[    0.637350] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.680077] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.683624] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.684415] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 67, base_baud = 3000000) is a 8250
[    1.380764] printk: console [ttyS0] enabled
[    1.385793] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[    1.394579] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 81, base_baud = 3000000) is a 8250
[    1.406157] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.413716] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
[    1.423220] random: fast init done
[    1.426888] random: crng init done
[    1.436565] panel-simple display: display supply power not found, using dummy regulator
[    1.444707] panel-simple display: GPIO lookup for consumer enable
[    1.444714] panel-simple display: using device tree for GPIO lookup
[    1.444738] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/display[0]'
[    1.444749] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/display[0]'
[    1.444760] panel-simple display: using lookup tables for GPIO lookup
[    1.444766] panel-simple display: No GPIO consumer enable found
[    1.457651] brd: module loaded
[    1.470189] loop: module loaded
[    1.479051] mdio_bus fixed-0: GPIO lookup for consumer reset
[    1.479062] mdio_bus fixed-0: using lookup tables for GPIO lookup
[    1.479069] mdio_bus fixed-0: No GPIO consumer reset found
[    1.479089] libphy: Fixed MDIO Bus: probed
[    1.486881] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset
[    1.486892] mdio_bus 4a101000.mdio: using device tree for GPIO lookup
[    1.486913] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000[0]'
[    1.486927] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000[0]'
[    1.486937] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup
[    1.486943] mdio_bus 4a101000.mdio: No GPIO consumer reset found
[    1.545775] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.553477] libphy: 4a101000.mdio: probed
[    1.558348] mdio_bus 4a101000.mdio:00: GPIO lookup for consumer reset
[    1.558356] mdio_bus 4a101000.mdio:00: using device tree for GPIO lookup
[    1.558378] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000/ethernet-phy@0[0]'
[    1.558391] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000/ethernet-phy@0[0]'
[    1.558400] mdio_bus 4a101000.mdio:00: using lookup tables for GPIO lookup
[    1.558406] mdio_bus 4a101000.mdio:00: No GPIO consumer reset found
[    1.559189] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    1.569118] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.575503] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.580905] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.588208] cpsw 4a100000.ethernet: Detected MACID = 68:9e:19:b8:52:d4
[    1.596655] i2c /dev entries driver
[    1.602769] cpuidle: enable-method property 'ti,am4372' found operations
[    1.610149] pwrseq_simple wfx_pwrseq: GPIO lookup for consumer reset
[    1.610159] pwrseq_simple wfx_pwrseq: using device tree for GPIO lookup
[    1.610194] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '/wfx_pwrseq[0]' - status (0)
[    1.610264] gpio gpiochip2: Persistence not supported for GPIO 8
[    1.610794] sdhci: Secure Digital Host Controller Interface driver
[    1.617099] sdhci: Copyright(c) Pierre Ossman
[    1.622737] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
[    1.622745] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    1.622765] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
[    1.622778] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
[    1.622787] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[    1.622793] omap_hsmmc 48060000.mmc: No GPIO consumer cd found
[    1.622800] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
[    1.622804] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    1.622816] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
[    1.622827] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
[    1.622833] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[    1.622838] omap_hsmmc 48060000.mmc: No GPIO consumer wp found
[    1.649066] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd
[    1.649076] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    1.649097] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
[    1.649109] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
[    1.649118] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    1.649124] omap_hsmmc 47810000.mmc: No GPIO consumer cd found
[    1.649130] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
[    1.649134] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    1.649145] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
[    1.649156] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/target-module@47810000/mmc@0[0]'
[    1.649162] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    1.649167] omap_hsmmc 47810000.mmc: No GPIO consumer wp found
[    1.649195] omap_hsmmc 47810000.mmc: allocated mmc-pwrseq
[    1.678521] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.686138] ledtrig-cpu: registered to indicate activity on CPUs
[    1.696075] davinci-mcasp 4803c000.mcasp: IRQ common not found
[    1.702925] drop_monitor: Initializing network drop monitor service
[    1.710220] NET: Registered protocol family 10
[    1.716060] Segment Routing with IPv6
[    1.719902] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.726695] NET: Registered protocol family 17
[    1.731678] Key type dns_resolver registered
[    1.736262] omap_voltage_late_init: Voltage driver support not added
[    1.742677] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.751409] Loading compiled-in X.509 certificates
[    1.763138] mmc0: new high speed SDHC card at address aaaa
[    1.776816] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[    1.783365] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[    1.790181] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[    1.796536]  mmcblk0: p1 p2
[    1.799577] gpiochip_find_base: found new base at 510
[    1.799965] gpio gpiochip3: (omap-gpmc): added GPIO chardev (254:3)
[    1.800045] gpiochip_setup_dev: registered GPIOs 510 to 511 on device: gpiochip3 (omap-gpmc)
[    1.800986] omap2-nand 8000000.nand: GPIO lookup for consumer rb
[    1.800996] omap2-nand 8000000.nand: using device tree for GPIO lookup
[    1.801032] of_get_named_gpiod_flags: parsed 'rb-gpios' property of node '/ocp@44000000/gpmc@50000000/nand@0,0[0]' - status (0)
[    1.801208] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xdc
[    1.808428] nand: Micron MT29F4G08ABAEAWP
[    1.812465] nand: 512 MiB, SLC, erase size: 256 KiB, page size: 4096, OOB size: 224
[    1.820397] Using OMAP_ECC_BCH16_CODE_HW ECC scheme
[    1.825414] 10 fixed-partitions partitions found on MTD device omap2-nand.0
[    1.832470] Creating 10 MTD partitions on "omap2-nand.0":
[    1.837927] 0x000000000000-0x000000040000 : "NAND.SPL"
[    1.844435] 0x000000040000-0x000000080000 : "NAND.SPL.backup1"
[    1.851583] 0x000000080000-0x0000000c0000 : "NAND.SPL.backup2"
[    1.858684] 0x0000000c0000-0x000000100000 : "NAND.SPL.backup3"
[    1.865784] 0x000000100000-0x000000180000 : "NAND.u-boot-spl-os"
[    1.873100] 0x000000180000-0x000000280000 : "NAND.u-boot"
[    1.879875] 0x000000280000-0x0000002c0000 : "NAND.u-boot-env"
[    1.886974] 0x0000002c0000-0x000000300000 : "NAND.u-boot-env.backup1"
[    1.894646] 0x000000300000-0x000000a00000 : "NAND.kernel"
[    1.902165] 0x000000a00000-0x000020000000 : "NAND.file-system"
[    1.921823] mmc1: error -110 whilst initialising SD card
[    1.978575] reg-fixed-voltage fixedregulator-vtt: GPIO lookup for consumer (null)
[    1.978586] reg-fixed-voltage fixedregulator-vtt: using device tree for GPIO lookup
[    1.978605] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vtt[0]'
[    1.978632] reg-fixed-voltage fixedregulator-vtt: No GPIO consumer (null) found
[    1.979231] reg-fixed-voltage fixedregulator-mmcwl: GPIO lookup for consumer (null)
[    1.979240] reg-fixed-voltage fixedregulator-mmcwl: using device tree for GPIO lookup
[    1.979256] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-mmcwl[0]'
[    1.979282] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0)
[    1.979348] gpio gpiochip0: Persistence not supported for GPIO 20
[    1.980015] gpio gpiochip4: Persistence not supported for GPIO 23
[    1.980028] GPIO line 119 (SelEMMCorNAND) hogged as output/low
[    1.986213] gpio gpiochip4: (gpio-96-127): added GPIO chardev (254:4)
[    1.986304] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip4 (gpio-96-127)
[    2.030865] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
[    2.038254] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz
[    2.044287] gpio gpiochip5: Persistence not supported for GPIO 8
[    2.044298] GPIO line 136 (SelLCDorHDMI) hogged as output/high
[    2.050455] gpio gpiochip5: (gpio-128-159): added GPIO chardev (254:5)
[    2.050540] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip5 (gpio-128-159)
[    2.053700] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
[    2.063205] DSS: OMAP DSS rev 2.0
[    2.067625] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops)
[    2.075915] omapdrm omapdrm.0: DMM not available, disable DMM support
[    2.082685] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.089370] [drm] No driver support for vblank timestamp query.
[    2.158003] Console: switching to colour frame buffer device 100x30
[    2.181090] omapdrm omapdrm.0: fb0: omapdrmdrmfb frame buffer device
[    2.188227] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 0
[    2.196930] reg-fixed-voltage fixedregulator-vtt: GPIO lookup for consumer (null)
[    2.196941] reg-fixed-voltage fixedregulator-vtt: using device tree for GPIO lookup
[    2.196962] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator-vtt[0]'
[    2.196993] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-vtt[0]' - status (0)
[    2.197013] gpio gpiochip5: Persistence not supported for GPIO 7
[    2.198115] hctosys: unable to open rtc device (rtc0)
[    2.204671] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
[    2.312239] Micrel KSZ9031 Gigabit PHY 4a101000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[    3.182443] mmc1: error -110 whilst initialising SD card
[    4.462541] mmc1: error -110 whilst initialising SD card
[    5.742453] mmc1: error -110 whilst initialising SD card
[    6.486983] cpsw 4a100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[    6.495851] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    6.525940] Sending DHCP requests ., OK
[    6.569765] IP-Config: Got DHCP answer from 10.0.0.1, my address is 10.0.0.22
[    6.577050] IP-Config: Complete:
[    6.580318]      device=eth0, hwaddr=68:9e:19:b8:52:d4, ipaddr=10.0.0.22, mask=255.0.0.0, gw=10.0.0.1
[    6.589948]      host=10.0.0.22, domain=example.org, nis-domain=(none)
[    6.596716]      bootserver=10.0.0.1, rootserver=10.0.0.1, rootpath=
[    6.596728]      nameserver0=10.0.0.1
[    6.608224] ALSA device list:
[    6.611216]   No soundcards found.
[    6.627270] VFS: Mounted root (nfs filesystem) on device 0:18.
[    6.633917] devtmpfs: mounted
[    6.639282] Freeing unused kernel memory: 1024K
[    6.646022] Run /sbin/init as init process
[    7.001574] systemd[1]: System time before build time, advancing clock.
[    7.024237] mmc1: error -110 whilst initialising SD card
[    7.044165] systemd[1]: systemd 244.5+ running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    7.066673] systemd[1]: Detected architecture arm.
[    8.302512] mmc1: error -110 whilst initialising SD card
[    9.582580] mmc1: error -110 whilst initialising SD card
[   10.862444] mmc1: error -110 whilst initialising SD card
[   11.208487] systemd[1]: Set hostname to <am437x-evm>.
[   12.142969] mmc1: error -110 whilst initialising SD card
[   12.358618] systemd[1]: /lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock \xe2\x86\x92 /run/docker.sock; please update the unit file accordingly.
[   12.692325] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[   12.705137] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[   12.719606] systemd[1]: Created slice system-getty.slice.
[   12.759373] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   12.802168] systemd[1]: Created slice User and Session Slice.
[   12.836559] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   12.876966] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   12.917052] systemd[1]: Reached target Paths.
[   12.946222] systemd[1]: Reached target Remote File Systems.
[   12.986365] systemd[1]: Reached target Slices.
[   13.017145] systemd[1]: Reached target Swap.
[   13.062517] systemd[1]: Listening on Process Core Dump Socket.
[   13.096592] systemd[1]: Listening on initctl Compatibility Named Pipe.
[   13.203070] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[   13.214207] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.258026] systemd[1]: Listening on Journal Socket.
[   13.300381] systemd[1]: Listening on Network Service Netlink Socket.
[   13.348155] systemd[1]: Listening on udev Control Socket.
[   13.386912] systemd[1]: Listening on udev Kernel Socket.
[   13.427715] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[   13.436393] mmc1: error -110 whilst initialising SD card
[   13.451820] systemd[1]: Mounting POSIX Message Queue File System...
[   13.502546] systemd[1]: Mounting Kernel Debug File System...
[   13.558366] systemd[1]: Mounting Temporary Directory (/tmp)...
[   13.592386] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   13.644353] systemd[1]: Starting Start psplash boot splash screen...
[   13.687086] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[   13.718052] systemd[1]: Starting Journal Service...
[   13.783847] systemd[1]: Starting Load Kernel Modules...
[   13.832727] systemd[1]: Starting Remount Root and Kernel File Systems...
[   13.892635] systemd[1]: Starting udev Coldplug all Devices...
[   13.952355] systemd[1]: Started Start psplash boot splash screen.
[   13.977423] cryptodev: loading out-of-tree module taints kernel.
[   14.037856] systemd[1]: Mounted POSIX Message Queue File System.
[   14.057142] systemd[1]: Mounted Kernel Debug File System.
[   14.072526] cryptodev: driver 1.10 loaded.
[   14.097084] systemd[1]: Mounted Temporary Directory (/tmp).
[   14.119942] systemd[1]: Started Create list of static device nodes for the current kernel.
[   14.181608] systemd[1]: Started Load Kernel Modules.
[   14.229110] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[   14.269386] systemd[1]: Mounting Kernel Configuration File System...
[   14.312445] systemd[1]: Started Start psplash-systemd progress communication helper.
[   14.372887] systemd[1]: Starting Apply Kernel Variables...
[   14.436650] systemd[1]: Started Remount Root and Kernel File Systems.
[   14.452962] systemd[1]: Mounted Kernel Configuration File System.
[   14.490960] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   14.513070] systemd[1]: Condition check resulted in Create System Users being skipped.
[   14.552630] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.616048] systemd[1]: Started Apply Kernel Variables.
[   14.712487] mmc1: error -110 whilst initialising SD card
[   14.735063] systemd[1]: Started Journal Service.
[   14.900708] systemd-journald[83]: Received client request to flush runtime journal.
[   15.982848] mmc1: error -110 whilst initialising SD card
[   17.266151] mmc1: error -110 whilst initialising SD card
[   17.802444] pvrsrvkm: disagrees about version of symbol module_layout
[   18.311501] pvrsrvkm: disagrees about version of symbol module_layout
[   18.341834] remoteproc remoteproc0: wkup_m3 is available
[   18.543279] mmc1: error -110 whilst initialising SD card
[   18.973204] pvrsrvkm: disagrees about version of symbol module_layout
[   19.830998] mmc1: error -110 whilst initialising SD card
[   21.102784] mmc1: error -110 whilst initialising SD card
[   21.813884] omap_rtc 44e3e000.rtc: already running
[   21.905576] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/tlv320aic3106@1b[0]'
[   21.905597] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/tlv320aic3106@1b[0]'
[   22.107117] omap_rtc 44e3e000.rtc: char device (252:0)
[   22.107146] omap_rtc 44e3e000.rtc: registered as rtc0
[   22.382778] mmc1: error -110 whilst initialising SD card
[   22.741054] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   22.754545] pixcir_ts 1-005c: GPIO lookup for consumer attb
[   22.754558] pixcir_ts 1-005c: using device tree for GPIO lookup
[   22.775887] of_get_named_gpiod_flags: can't parse 'attb-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]'
[   22.775931] of_get_named_gpiod_flags: parsed 'attb-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]' - status (0)
[   22.776012] gpio gpiochip1: Persistence not supported for GPIO 22
[   22.776028] pixcir_ts 1-005c: GPIO lookup for consumer reset
[   22.776033] pixcir_ts 1-005c: using device tree for GPIO lookup
[   22.776049] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]'
[   22.776061] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]'
[   22.776070] pixcir_ts 1-005c: using lookup tables for GPIO lookup
[   22.776076] pixcir_ts 1-005c: No GPIO consumer reset found
[   22.776080] pixcir_ts 1-005c: GPIO lookup for consumer wake
[   22.776084] pixcir_ts 1-005c: using device tree for GPIO lookup
[   22.776096] of_get_named_gpiod_flags: can't parse 'wake-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]'
[   22.776108] of_get_named_gpiod_flags: can't parse 'wake-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]'
[   22.776114] pixcir_ts 1-005c: using lookup tables for GPIO lookup
[   22.776119] pixcir_ts 1-005c: No GPIO consumer wake found
[   22.776123] pixcir_ts 1-005c: GPIO lookup for consumer enable
[   22.776127] pixcir_ts 1-005c: using device tree for GPIO lookup
[   22.776139] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]'
[   22.776150] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/pixcir_ts@5c[0]'
[   22.776155] pixcir_ts 1-005c: using lookup tables for GPIO lookup
[   22.776159] pixcir_ts 1-005c: No GPIO consumer enable found
[   22.811429] remoteproc remoteproc0: powering up wkup_m3
[   22.854650] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 243196
[   22.867674] input: pixcir_tangoc as /devices/platform/44000000.ocp/48000000.interconnect/48000000.interconnect:segment@0/4802a000.target-module/4802a000.i2c/i2c-1/1-005c/input/input0
[   22.885068] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   22.891692] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[   22.910035] link-frequencies 0 value 70000000
[   22.914487] ov2659 1-0030: GPIO lookup for consumer powerdown
[   22.914494] ov2659 1-0030: using device tree for GPIO lookup
[   22.914520] of_get_named_gpiod_flags: can't parse 'powerdown-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/ov2659@30[0]'
[   22.914534] of_get_named_gpiod_flags: can't parse 'powerdown-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/ov2659@30[0]'
[   22.914544] ov2659 1-0030: using lookup tables for GPIO lookup
[   22.914550] ov2659 1-0030: No GPIO consumer powerdown found
[   22.914555] ov2659 1-0030: GPIO lookup for consumer reset
[   22.914559] ov2659 1-0030: using device tree for GPIO lookup
[   22.914571] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/ov2659@30[0]'
[   22.914583] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/interconnect@48000000/segment@0/target-module@2a000/i2c@0/ov2659@30[0]'
[   22.914589] ov2659 1-0030: using lookup tables for GPIO lookup
[   22.914594] ov2659 1-0030: No GPIO consumer reset found
[   22.989897] ov2659 1-0030: Found OV2656 sensor
[   23.169847] ov2659 1-0030: ov2659 1-0030 sensor driver registered !!
[   23.662764] mmc1: error -110 whilst initialising SD card
[   24.794433] CAN device driver interface
[   24.943392] mmc1: error -110 whilst initialising SD card
[   25.163570] c_can_platform 481cc000.can: c_can_platform device registered (regs=1067f355, irq=83)
[   25.403532] c_can_platform 481d0000.can: c_can_platform device registered (regs=52ba0666, irq=84)
[   26.222691] mmc1: error -110 whilst initialising SD card
[   26.647799] pvrsrvkm: disagrees about version of symbol module_layout
[   27.502819] mmc1: error -110 whilst initialising SD card
[   27.621173] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
[   27.772261] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
[   27.796298] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
[   27.902192] omap-aes 53501000.aes: will run requests pump with realtime priority
[   27.924116] omap-des 53701000.des: will run requests pump with realtime priority
[   28.783056] mmc1: error -110 whilst initialising SD card
[   30.062824] mmc1: error -110 whilst initialising SD card
[   30.840586] of_get_named_gpiod_flags: parsed 'row-gpios' property of node '/matrix_keypad0[0]' - status (0)
[   30.840611] of_get_named_gpiod_flags: parsed 'row-gpios' property of node '/matrix_keypad0[1]' - status (0)
[   30.840624] of_get_named_gpiod_flags: parsed 'row-gpios' property of node '/matrix_keypad0[2]' - status (0)
[   30.840637] of_get_named_gpiod_flags: parsed 'col-gpios' property of node '/matrix_keypad0[0]' - status (0)
[   30.840650] of_get_named_gpiod_flags: parsed 'col-gpios' property of node '/matrix_keypad0[1]' - status (0)
[   30.841131] input: matrix_keypad0 as /devices/platform/matrix_keypad0/input/input1
[   31.163708] PM: bootloader does not support rtc-only!
[   31.348341] mmc1: error -110 whilst initialising SD card
[   31.417932] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound0[0]'
[   31.417953] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound0[0]'
[   31.521961] asoc-simple-card sound0: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[   31.698013] asoc-simple-card sound0: ASoC: no DMI vendor name!
[   32.622798] mmc1: error -110 whilst initialising SD card
[   33.902730] mmc1: error -110 whilst initialising SD card
[   35.182611] mmc1: error -110 whilst initialising SD card
[   36.463895] mmc1: error -110 whilst initialising SD card
[   36.635883] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[   36.723914] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   36.965880] vmmcwl_fixed: disabling
[   37.742695] mmc1: error -110 whilst initialising SD card
[   39.022809] mmc1: error -110 whilst initialising SD card
[   39.203545] dwc3 48390000.usb: Failed to get clk 'ref': -2
[   39.540372] OF: graph: no port node found in /ocp@44000000/interconnect@48000000/segment@300000/target-module@a8000/ocp2scp@0/phy@8000
[   39.640233] remoteproc remoteproc1: 54434000.pru is available
[   39.809062] pru-rproc 54434000.pru: PRU rproc node /ocp@44000000/target-module@54400000/pruss@0/pru@34000 probed successfully
[   40.068349] dwc3 483d0000.usb: Failed to get clk 'ref': -2
[   40.120205] remoteproc remoteproc2: 54438000.pru is available
[   40.215951] pru-rproc 54438000.pru: PRU rproc node /ocp@44000000/target-module@54400000/pruss@0/pru@38000 probed successfully
[   40.308086] mmc1: error -110 whilst initialising SD card
[   40.552329] remoteproc remoteproc3: 54474000.pru is available
[   40.719084] pru-rproc 54474000.pru: PRU rproc node /ocp@44000000/target-module@54400000/pruss@40000/pru@74000 probed successfully
[   40.921097] remoteproc remoteproc4: 54478000.pru is available
[   41.077814] pru-rproc 54478000.pru: PRU rproc node /ocp@44000000/target-module@54400000/pruss@40000/pru@78000 probed successfully
[   41.315386] usbcore: registered new interface driver usbfs
[   41.543884] usbcore: registered new interface driver hub
[   41.584440] mmc1: error -110 whilst initialising SD card
[   41.714461] usbcore: registered new device driver usb
[   42.441648] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[   42.507128] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 1
[   42.566952] xhci-hcd xhci-hcd.5.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
[   42.609225] xhci-hcd xhci-hcd.5.auto: irq 104, io mem 0x483d0000
[   42.662851] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[   42.711299] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   42.745483] usb usb1: Product: xHCI Host Controller
[   42.770640] usb usb1: Manufacturer: Linux 5.4.106-g023faefa70 xhci-hcd
[   42.799090] usb usb1: SerialNumber: xhci-hcd.5.auto
[   42.835052] hub 1-0:1.0: USB hub found
[   42.857553] hub 1-0:1.0: 1 port detected
[   42.863465] mmc1: error -110 whilst initialising SD card
[   42.906237] xhci-hcd xhci-hcd.5.auto: xHCI Host Controller
[   42.911781] xhci-hcd xhci-hcd.5.auto: new USB bus registered, assigned bus number 2
[   42.980054] xhci-hcd xhci-hcd.5.auto: Host supports USB 3.0 SuperSpeed
[   43.014491] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   43.059354] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[   43.081515] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   43.119964] usb usb2: Product: xHCI Host Controller
[   43.150922] usb usb2: Manufacturer: Linux 5.4.106-g023faefa70 xhci-hcd
[   43.192820] usb usb2: SerialNumber: xhci-hcd.5.auto
[   43.235428] hub 2-0:1.0: USB hub found
[   43.248991] hub 2-0:1.0: 1 port detected
[   44.141746] mmc1: error -110 whilst initialising SD card
[   45.431770] mmc1: error -110 whilst initialising SD card
[   46.703733] mmc1: error -110 whilst initialising SD card
[   47.981198] mmc1: error -110 whilst initialising SD card
[   48.174380] overlayfs: filesystem on '/var/lib/docker/check-overlayfs-support592528676/upper' not supported as upperdir
[   48.267516] overlayfs: filesystem on '/var/lib/docker/check-overlayfs-support072372787/upper' not supported as upperdir
[   48.477948] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[   48.498047] Bridge firewalling registered
[   49.262961] mmc1: error -110 whilst initialising SD card
[   49.888552] Initializing XFRM netlink socket
[   50.542873] mmc1: error -110 whilst initialising SD card
[   51.822642] mmc1: error -110 whilst initialising SD card
[   53.102924] mmc1: error -110 whilst initialising SD card
我在内核中启用了跟踪支持、以查看正在发生的情况:
echo 1 > /sys/kernel/debug/tracing/events/mmc/mmc_request_done/enable
cat /sys/kernel/debug/tracing/trace_pipe
          <idle>-0       [000] d.h1  1944.751692: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=52 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered0
          <idle>-0       [000] d.h1  1944.752125: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=52 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered0
          <idle>-0       [000] d.h1  1944.753673: mmc_request_done: mmc1: end struct mmc_request[c3ab1609]: cmd_opcode=0 cmd_err=0 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0 d0
          <idle>-0       [000] d.h1  1944.756677: mmc_request_done: mmc1: end struct mmc_request[c3ab1609]: cmd_opcode=8 cmd_err=0 cmd_resp=0x1aa 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=00
          <idle>-0       [000] d.h1  1944.757102: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.757522: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=2 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.757939: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=1 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.758356: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.758728: mmc_request_done: mmc1: end struct mmc_request[0ab9d253]: cmd_opcode=55 cmd_err=0 cmd_resp=0x400120 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfer0
          <idle>-0       [000] d.h1  1944.759068: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=41 cmd_err=0 [ 1948.783016] mmc1: error -110 whilst initialising SD card
cmd_resp=0xff8000 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0 data_err=0 tag=0 can_retune=0 doing_retune=0 retune_now=0 need_retune=0 hold_retune=1 retune_period=0
          <idle>-0       [000] d.h1  1944.760538: mmc_request_done: mmc1: end struct mmc_request[8fbaba62]: cmd_opcode=0 cmd_err=0 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0 d0
          <idle>-0       [000] d.h1  1944.763485: mmc_request_done: mmc1: end struct mmc_request[8fbaba62]: cmd_opcode=8 cmd_err=0 cmd_resp=0x1aa 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=00
          <idle>-0       [000] d.h1  1944.763848: mmc_request_done: mmc1: end struct mmc_request[673f9c98]: cmd_opcode=55 cmd_err=0 cmd_resp=0x120 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.764208: mmc_request_done: mmc1: end struct mmc_request[1d16da7e]: cmd_opcode=41 cmd_err=0 cmd_resp=0xff8000 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfer0
          <idle>-0       [000] d.h1  1944.776166: mmc_request_done: mmc1: end struct mmc_request[673f9c98]: cmd_opcode=55 cmd_err=0 cmd_resp=0x120 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.776528: mmc_request_done: mmc1: end struct mmc_request[1d16da7e]: cmd_opcode=41 cmd_err=0 cmd_resp=0xc0ff8000 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xf0
          <idle>-0       [000] d.h1  1944.777110: mmc_request_done: mmc1: end struct mmc_request[6122a8bb]: cmd_opcode=2 cmd_err=0 cmd_resp=0x744a6055 0x53445531 0x202802dd 0x1e0138e5 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sb0
          <idle>-0       [000] d.h1  1944.777486: mmc_request_done: mmc1: end struct mmc_request[7fa23674]: cmd_opcode=3 cmd_err=0 cmd_resp=0x59b40520 0x0 0x0 0x0 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfe0
          <idle>-0       [000] d.h1  1944.778068: mmc_request_done: mmc1: end struct mmc_request[687b2258]: cmd_opcode=9 cmd_err=0 cmd_resp=0x400e0032 0x5b590000 0x3c1d7f80 0xa400063 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc0
          <idle>-0       [000] d.h1  1944.778432: mmc_request_done: mmc1: end struct mmc_request[7fa23674]: cmd_opcode=7 cmd_err=0 cmd_resp=0x700 0x0 0x0 0x0 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=00
          <idle>-0       [000] d.h1  1944.778792: mmc_request_done: mmc1: end struct mmc_request[5a137741]: cmd_opcode=55 cmd_err=0 cmd_resp=0x920 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.942946: mmc_request_done: mmc1: end struct mmc_request[43c58b1b]: cmd_opcode=51 cmd_err=0 cmd_resp=0x920 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1944.948880: mmc_request_done: mmc1: end struct mmc_request[f93e23d9]: cmd_opcode=1 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.031693: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=52 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered0
          <idle>-0       [000] d.h1  1946.032126: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=52 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered0
          <idle>-0       [000] d.h1  1946.033675: mmc_request_done: mmc1: end struct mmc_request[c3ab1609]: cmd_opcode=0 cmd_err=0 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0 d0
          <idle>-0       [000] d.h1  1946.036675: mmc_request_done: mmc1: end struct mmc_request[c3ab1609]: cmd_opcode=8 cmd_err=0 cmd_resp=0x1aa 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=00
          <idle>-0       [000] d.h1  1946.037099: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.037519: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=2 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.037931: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=1 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.038341: mmc_request_done: mmc1: end struct mmc_request[c6684edd]: cmd_opcode=5 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.038704: mmc_request_done: mmc1: end struct mmc_request[0ab9d253]: cmd_opcode=55 cmd_err=0 cmd_resp=0x400120 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfer0
          <idle>-0       [000] d.h1  1946.039040: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=41 cmd_err=0 cmd_resp=0xff8000 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfer0
          <idle>-0       [000] d.h1  1946.040510: mmc_request_done: mmc1: end struct mmc_request[8fbaba62]: cmd_opcode=0 cmd_err=0 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0 d0
          <idle>-0       [000] d.h1  1946.043457: mmc_request_done: mmc1: end struct mmc_request[8fbaba62]: cmd_opcode=8 cmd_err=0 cmd_resp=0x1aa 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=00
          <idle>-0       [000] d.h1  1946.043825: mmc_request_done: mmc1: end struct mmc_request[673f9c98]: cmd_opcode=55 cmd_err=0 cmd_resp=0x120 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.044195: mmc_request_done: mmc1: end struct mmc_request[1d16da7e]: cmd_opcode=41 cmd_err=0 cmd_resp=0xff8000 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfer0
          <idle>-0       [000] d.h1  1946.056794: mmc_request_done: mmc1: end struct mmc_request[673f9c98]: cmd_opcode=55 cmd_err=0 cmd_resp=0x120 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.057167: mmc_request_done: mmc1: end struct mmc_request[1d16da7e]: cmd_opcode=41 cmd_err=0 cmd_resp=0xc0ff8000 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xf0
          <idle>-0       [000] d.h1  1946.057754: mmc_request_done: mmc1: end struct mmc_request[6122a8bb]: cmd_opcode=2 cmd_err=0 cmd_resp=0x744a6055 0x53445531 0x202802dd 0x1e0138e5 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sb0
          <idle>-0       [000] d.h1  1946.058130: mmc_request_done: mmc1: end struct mmc_request[7fa23674]: cmd_opcode=3 cmd_err=0 cmd_resp=0x59b40520 0x0 0x0 0x0 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfe0
          <idle>-0       [000] d.h1  1946.058712: mmc_request_done: mmc1: end struct mmc_request[687b2258]: cmd_opcode=9 cmd_err=0 cmd_resp=0x400e0032 0x5b590000 0x3c1d7f80 0xa400063 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc0
          <idle>-0       [000] d.h1  1946.059075: mmc_request_done: mmc1: end struct mmc_request[7fa23674]: cmd_opcode=7 cmd_err=0 cmd_resp=0x700 0x0 0x0 0x0 cmd_retries=3 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=00
          <idle>-0       [000] d.h1  1946.059437: mmc_request_done: mmc1: end struct mmc_request[5a137741]: cmd_opcode=55 cmd_err=0 cmd_resp=0x920 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop
          <idle>-0       [000] d.h1  1946.223589: mmc_request_done: mmc1: end struct mmc_request[43c58b1b]: cmd_opcode=51 cmd_err=0 cmd_resp=0x920 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1946.229484: mmc_request_done: mmc1: end struct mmc_request[f93e23d9]: cmd_opcode=1 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered=0
          <idle>-0       [000] d.h1  1947.311679: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=52 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered0
          <idle>-0       [000] d.h1  1947.312114: mmc_request_done: mmc1: end struct mmc_request[d34cbcde]: cmd_opcode=52 cmd_err=-110 cmd_resp=0x0 0x0 0x0 0x0 cmd_retries=0 stop_opcode=0 stop_err=0 stop_resp=0x0 0x0 0x0 0x0 stop_retries=0 sbc_opcode=0 sbc_err=0 sbc_resp=0x0 0x0 0x0 0x0 sbc_retries=0 bytes_xfered0
我检查了许多 SD 卡、在 MMC0接口上、始终可以正确检测到它-我从未在迹线上看到 CMD1。 连接到 MMC2的 SD 卡相同-提供错误、并且可以在迹线上看到 CMD1。
我不知道如何解决这个问题。 有人可以帮助我解决这些错误吗?
    您好 Szymon、
    对延迟答复表示歉意。 您是否仍需要帮助?
    请注意、TI 可以支持调试 TI 的软件和硬件、但我们不能支持调试其他公司的软件和硬件。 在 我们的 TI Linux SDK 中、我在文档/或驱动程序/中的任何位置都看不到"slabs、wf200"。 您需要联系 Silicon Labs、以帮助他们的外设在 Linux 系统中运行。 如果您发现 TI 方面的问题(例如、较低级别的 TI 驱动程序导致了问题)、我们可以在这方面提供帮助。
    Nick
    您好、Nick、
    感谢您的回答。 目前我不需要帮助。 我解决了这个 WiFi 芯片的问题(是的,它是 SiliconLabs 芯片)。
    由于芯片无法正常工作、我决定尝试将 SD 卡连接到 MMC2接口-甚至该 SD 卡也无法正常工作-但现在我假设物理有线连接中存在另一个故障 (使用了低质量 MicroSD -> SD 适配器,可能某些针脚未连接)。
    芯片不工作的原因是 CMD0时钟问题- MMC 控制器在发出 CMD0后停止时钟信号-从协议规范的角度来看、这是可以的、因为 CMD0不需要响应。 Hov串 这个特定的芯片初始化过程要求在发出 CMD0后驱动时钟信号、以使芯片响应。 如果在 CMD0之后时钟停止、则发出其他初始化命令、如 CMD5、CMD8会产生超时错误。 这是特定于此第三方芯片的、因此我修改了位 MMC 驱动程序内核、因为 SiliconLabs 建议通知 MMC 控制器 CMD0之后的响应是预期的。 在这些修改之后、最终正确探测芯片并由驱动器进行配置。
    当我写上述帖子时,我不清楚这一点,因为在内核跟踪转储中,我没有注意到芯片在 CMD0之后没有响应,所以我提前提出了 SiliconLabs 的建议-这是我的错:)当我的所有想法都失败了, 我假定也许可以在示波器上检查总线-特别是对于 CMD0 -可能会让我有任何方法来解决这个问题-然后我还记得 SiliconLabs 说过时钟。
    再次感谢您、致以诚挚的问候。
