[参考译文] TDA4VM:版本0804是否更改 C7上的存储器布局规则? 取消 PADW? 它只是使用 INPitch 来进行寻址
Guru**** 2540720 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1162652/tda4vm-does-version-0804-change-memory-layout-rules-on-c7-cancel-padw-it-just-uses-inpitch-to-do-the-addressing
器件型号:TDA4VM
