[参考译文] Linux/TDA2EVM5777:使用 Yocto 构建 tisdk-rootfs-image 失败。
Guru**** 2538960 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/770787/linux-tda2evm5777-building-tisdk-rootfs-image-with-yocto-fails
器件型号:TDA2EVM5777
工具/软件:Linux
我按照本指南() 为 tda2evm5777板构建文件系统,并遇到以下问题:
1. libleoki 的 md5sum 错误,因此我按照此主题 ()来修复它。
2.出现以下错误,我无法修复。
[PSDKLA]>[PSDKLA]>
当前目录为/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers
[PSDKLA]>路径为/home/bmann/projects/ti/PROCESSOR_SDK_VISION_03_06_00_00/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01:/usr/local/sbin:/usr/local/bin:/home/bmann/.local/bin:/usr/bin:/sbin:/home/bmann/bin /usr/games:/usr/sbin /usr/local/games:/snap/bin
:[PSDKLA]>在运行 Linux bmann-VirtualBox 4.03-45-generic #48~:UTC x86_PSDKLA]>上构建于2019年1
ש 月29 פבר:PSDKLA][PSDKLA][PSDKLA]64:PSDKLA][PSDKLA]64:PSDKLA][PSDKLA]。[PSDKLA]
CONF/setenv
[PSDKLA]>CP conf/local.conf conf/local.conf.prine.[PSDKLA]>MACHINE=dra7xx-EVM
bittisdk-rootfs-image
注:已启动具有 DBfile 的 PRServer:/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/cache/prserv.sqlite3、IP:127.0.0.1、端口:42247、PID:13920
正在加载缓存:100%###################################################################################################################################################################################################################### | ETA:00:00:00
从依赖关系缓存加载2849个条目。
注意:解决任何缺失的任务队列相关性
生成配置:
BB_VERSION ="1.30.0"
BUIL_SYS ="x86_64-Linux"
NATIVELSBSTRING ="Ubuntu-16.04"
TARGET_SYS ="arm-linux-gnueabi"
机器 ="dra7xx-evm"
发行版 ="Arago "
distro_version ="2016.12"
tune 特性 ="arm armv7a VFP thumb NEON callconvention-hard"
target_FPU ="硬"
元-格尔斯克 ="标题:66cfd8ef55344508d6e7b306259f34c05b828194"
meta-arago-destro
meta-arago-exase-exas="标题:4c01410ffde8853224567fb6078d7d9f190b942f"
meta-qt5 ="标题:f8584d7a7c90afc71484a40279aa3df651d0e04f"
meta 网络
meta-ruby
Meta-python
Meta-OE ="标题:55c8a76da5dc099a7bc38495c672140cedb78e"
meta-ti ="标题:5f3a1169d307fect41626f850f5c700437dedbe93"
meta-linaro-toolchain
meta-optee. =
"标题:2f51d38048599d9878f149d6d15539fb97603f8f"元数据 ="head:bfa04fa71c47e8fe9528208848cfcec2e232777d"
注意:Preparing RunQueue
注意:执行 SetScene 任务
注意:执行 RunQueue 任务
错误:qtAUTOINC-5.6.2+gitAUTOINC+074571305e-r0:OE_rungmake 失败
/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2
记录:/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2文件:rmctrategategure+08+071305+gr:rmctrategature+07805.6+g/trategtrue+ene+ene+trategtrue+ene+ene+enu+07805.6+enu+true+true_log+true+true+true+enue.tenue.tenu+true+true+true_enue.tenue.tenu+true_files+true+true+true+true+true+true+true+true+tr make -j 4 maKEFLAGS=-j 4 OE_qmake_Compiler=arm-linux-gnueabihf-gcc -March =armv7-a -marm -mfloat-abi=hard --mfroot=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm oe_linux-gnueabiabiabio-mue-mue-linux-ma-remoti=-linux-linux-from-mspo=ma-linux-remoti=ma-linux-linux-f=ma-gh-mspoid-linux-mspoid-linux-m-m-mspue-f=ma-linux-m-mspue-f=ma-mspu-m-m-m-m-m-m-m-mspu-m-m-mu-m-m-m-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mu-mspu-mu-mu-m-/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux=/usr/src/debug/qtxmlpatterns/5.6.2 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux=/usr/src/debug/qtxmlpatterns/5.6.2 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm sysroot=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm /home/bmann/projects/ti/PROCESSOR_SDK_VISION_03_06_00_00/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/lib /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm
src.pro os_qmake_LDFLAGS=-L/home/bmann/projects/ti/processor_sdk_vision_03_00_00/ti_compons/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64 arm-linux-gebiabihf/arm-make_linux-make_linux-make_linux-make_linux-make-opruebrf=e&oeqwl+e+rqwl=e&o+eq-make_linux-make_linux-make_linux-make_enoe&oeqwl+e&o+eqwl=e&o+e&o+eq-eq-eq-rf=e&o+eq-eq-rf=e&o+eq-eq-e&o+eq-r&o+eq-rf=e&o+eqwl=e&o+eq-e&o+e&o+eq-eq-r&o+e&o+r /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/qt5/qmake /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2 /usr/include/qt5 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/wayland-scanner
进入目录'/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2
/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2 +gitAUTOINC+074571305e-r0/build/sr'| cd xmlpatterns/&&(test -e Makefile ||/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/qt5/qmake /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2
/../lib/libQt5XmlPatterns.so.5.6.2 +gitAUTOINC+074571305e-r0/git/src/xmlpatterns/xmlpatterns.pro -o Makefile)& make -f Makefile | maked[2]+gitPatterns+07457ns.html| libtobrms/gtrabole1.07gmes+1.07gms/gtrabole.q5ns/gms/gmes/smes:tobole1.07gmes+g5r.ldo directory.q5r.ldo directory.q.ldo directory.ldo directory.ldo.q.ldo.ldo.ldo.ldo.ldo.ldo.ldo.ldo.ldo.ldo.ldo.ldo.ldo.ldo.
LD 返回1退出状态
| Makefile:1415:目标'./../lib/libQt5XmlPatterns.so.5.6.2
/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2的配方失败| make[2]:***[./../lib/libQt5XmlPatterns.so.5.6.2错误1 | make[2]:离开目录'/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2 +gitxmlAUTOINC+074571305e-r0/build/srub/UB'| Makefile.42:目标'sub 's'sub '+xml+make+make+make'|make+make+make's'|'s's's'r07451'|make+make'|'s'r1'rxml1'|make+make'|make'-make+make'|make'r1'|make'|make'r1'rxml1'|make+make'|make+make'
OE [sub-src-make_first]错误2
|错误:OE_runmake 失败
|错误:函数失败:do_compile (日志文件位于/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/qtxmlpatterns/5.6.2 +gitAUTO12.0+074571305e-r0/temp/log.do_compile.13965)
错误:任务4698 (/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-qt5/recipes-qt/qt5/qtxmlpatterns_git.bb、do_compile)失败、退出代码为"1"、
错误
:/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/temp/log.do_install.13989 run_install_log.1.1e:r.pr-run_log.pr-un.pr-install_log.pr-un.pr-un.pr-un.pr-log.e.g.pr-un.pr-un.e.g.pr-un.pr-un.pr-un.pr-un.pr-un.pr-log
存储在以下位置的故障日志文件
/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake 记录数据:|调试:执行 shell 函数 do_install |注意:make -j 4 destdir=/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/image /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build/CMakeFiles /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build/CMakeFiles/progress.marks install |/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake -H/home/bmann/projects/ti-processor-sdk-linux-dra7xx-evm-5_00_01_yoctol层/build/arie-linux-memor/make-ex-linux-make/linux-make-ex-linux-date-ex-recor/linux-make/linux-recor/linux-make-ex-rf-necor/linux-make/ement-rf-necht-rex-rex-rf-necor/linux-make/linux-rf-necor/linux-rex-rex-rex-rf-necor/make/linux-rex-rex-rf-necor/linux-rf-necor/linux-rf-necor/linux-rex-pf-necor/make/linux-rex-rex-rf-necf-necor/linux-rex-rex-r
没有为"所有人"做任何事情。
| make[1]:离开目录'/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build
|/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake -E cmake_progress_start /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build/CMakeFiles 0
| make -f CMakeFiles/Makefile2 preinstall
| make[1]:进入目录'/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/build
| make[1]:对于'preinstall'不执行任何操作。
|安装项目...
|/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/cmake -P cmake_install.cmake
|--安装配置:""
| make[1]:警告:-Jn 在子 make 中强制:禁用 jobserver 模式。
| make[1]:进入目录'/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor
/builtins/dsp.lib /libm/libm.lib |链接 dsp0.out | monitor0/linker.cmd |/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-c6x/bin/cl6x /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ulm/libtiulm.ae66 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66 -o3 -mv6600 -abi=e-gcc -mem_model:const=data -mem_model:data=far -z -x -abi=eabi=-gb -gcc -m_model/rgtrads.org/tobj tobt.obj -linux-mem/builds.htm-linux-direct/linux-direct.pr-linux-mem/builds.org/linux-direct.obj /linux-direct.pr-mem/direct.ob.obj /linux-direct.pr-rom-linux-mem/director/direct.pr-linux-mem/direct.ob.obj /linux-directors.org/director/director/director.ob.pr-linux-direct.ob.pr-linux-direct.ob.ob.ob.ob.ob.ob.obj
|链接 dsp1.out
| yor1/linker.cmd
|/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/ti/cgt-c6x/bin/cl6x /builtins/dsp.lib /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ulm/libtiulm.ae66 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66 -o3 -mv6600 --abi=eabi -gcc -mem_model:const=data -mem_model:data=far -z -priority -w -x -mdsp1.out.map -define ddr3_fcsec_model -msp/linux-monitor/latits.org/latitudc/linux-rom-linux-buildsmt/ap.obj /latitude/ap.htm-linux-buildsmt/latits.org/linux-linux-linux-mem/later.obj t/latits/ap.htm-buildsmot/latits.org/linux-linux-linux-mem/later.htm-buildsmot/laters/latits.htm-linux-buildsmt/laters.htm-linux-builds.htm/latitude/ap.obt.htm-linux-builds.htm-linux-builds.htm/latitude/ap.htm.htm-linux-builds.htm-linux-mem /libm/libm.lib
|错误:找不到文件
|"/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0
| 0_01/Yocto-lages/build/Arago-tmp-external/linaro-toolchain/work / dra7xx_evm-
| linux-gnueabi/opencl-monitor/1.1.0-r0.0/git/monitor/apro-linux-updori/linux-monitor/linux-upd.pnec/linux-r66-01/linux-tool/linux-build/linux-rmp-/linux-/linux-r66-01.0-/linux-build/linux-tool/ram_upd/linux-/linux-/monitor/linux-/linux-/linux-r66_updmp-/linux-/linux-/linux-/linux-/linux-/monitor/linux-/gnopr-/linux-/linux-/linux-/monitor/linux-/tool/linux-rec/linux-/linux-r.org/gnuorti-/linux-/build.pnec/linux-/linux-/build/linux-/gnuorti-/linux-/linux-
/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0
无法找到
|文件|"/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_0 | 0_01/Yocto-lages/build/arago-tmp-external_linaro-toolchain/work / dra7xx_evm-| linux-gnueabi/OpenCL-monitor/1.1.0-r0.0/monitor/monitor/monitor/appre0/example/linux-66x_ex-board/linux-board/linux-board/linux-r66-01.0-/linux-boards/ex-ex-build/linux-/linux-board/linux-/utili.pnec/linux-/linux-/linux-r66-01.0-/linux-board/linux-boards/ex-/linux-/linux-/linux-/linux-/linux-board/linux-/linux-/board-/linux-/linux-/board-/linux-/linux-/linux-/board-/linux-/board-/linux-/linux-/linux-/builds/ex-/linux-/board-/util-/linux-/linux-/linux-/linux-/linux-/linux-/linux-/linux-/linux-/
sysv 或-rom
|(已忽略)
|"cmds/monitor.am57x.cmd"、第89行:警告:绝对符号"_argsize"正在
重新定义
|警告:选项--export 在没有--dynamic 或--sysv 或--rom
的情况下无效|(已忽略)
|"cmds/monitor.am57x.cmd"、行
|警告:"arg_size:":"
输出段".fardata.2"是指加载符号
|"ti_sysbios_timer_dmtimer_stub__e"、因此无法压缩;
|忽略压缩"rle"
|警告:输出段".fardata.3"是指加载符号
|"ti_sysbios_family_c64p_Combiner_EventLE_unused_re
;因此无法忽略"|
警告|不使用|警告|" 输出段".fardata.2"是指加载符号
|"ti_sysbios_timer_dmtimer_stub__e"、因此无法进行压缩;
|忽略压缩"rle"
|"ti_sysbios_family_c64p_Combiner_rle_unused_|无法
忽略|
未定义|"|未定义|未定义" 首次引用
|符号 在文件
中|--- --------
| IpcMgr_callIpcStart /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| IpcMgr_ipcStartup /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| IPC_START /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-omp-tree/packages/ti/runtime/ompbios/lib/ti_runtime_ompbios_release_e66.ae66
| MessageQ_Params_init__S monitor.obj
| MessageQ_alloc monitor.obj
| MessageQ_create monitor.obj
| MessageQ_delete monitor.obj
| MessageQ_free monitor.obj
| MessageQ_get monitor.obj
| MessageQ_put monitor.obj
| MessageQ_setReplyQueue monitor.obj
| MultiProc_getid device_am57.obj
| MultiProc_setLocalId device_am57.obj
| ti_ipc_remoteproc_Resource_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_attach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_detach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_isRegistered__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_sharedMemReq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_registerTransport___F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_unregisterTransport___F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_Notify_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_family_vayu_NotifySetup_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_gates_GateHWSpinlock_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_utils_nameserver_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_BIOS_getThreadType__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66
| ti_sysBIOS_BIOS_linedWithIncorrectBootLibrary__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_BIOS_setThreadType__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_BIOS_start__E monitor.obj
| ti_sysbios_family_C62_IntrinsicsSupport_maxbit__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_checkStack__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_getCheckValueAddr__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_getDefaultStackSize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_getStackAlignment__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_stackUsed__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_swap_E_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_EventCombiner_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_EventCombiner_unused__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_exception_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_exception_dispation__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_Hwi_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_hwi_d调度 Always /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_family_c64p_Hwi_enableInterrupt__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_Hwi_EventMap___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66
| ti_sysbios_family_c64p_Hwi_plug__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66
| ti_sysbios_family_c64p_TimestampProvider_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_TimestampProvider_get64_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_enable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_inV_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66
| ti_sysbios_family_c66_cache_startup____i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wait__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wbAll_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wbInvAll__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wbInv___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/gdbc6x/lib/gdb_server.ae66
| ti_sysbios_family_C66_cache_wb__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c66_vayu_Power_resetFxn_i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_Shared_vayu_IntXbar_initIntXbar__i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_Shared_vayu_TimerSupport_Module_Startup_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_query_E_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_checkStack /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_initStackMin /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_instance_final__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getCount__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getCurrentTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getExpiredCounts__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_hal_TimerNull_getExpiredTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getFreq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_hal_TimerNull_getMaxTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getNumTimer__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getPeriod__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getStatus__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_setFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_setNextTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_hal_TimerNull_setPeriodMicroSecs__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_setPeriod___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_stop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_trigger__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_b堆_HeapBuf_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_b堆_HeapMem_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_b堆_HeapMem_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_init__i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_getTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/trace/lib/release/ti.trace.ae66
| ti_SysBIOS_KNL_Clock_logTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_setTicks__E monitor.obj
| ti_SysBIOS_KNL_Clock_setTimeout___E monitor.obj
| ti_SysBIOS_KNL_Clock_start__E monitor.obj
| ti_SysBIOS_KNL_Clock_stop__E monitor.obj
| ti_SysBIOS_KNL_Clock_tick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66
| ti_SysBIOS_KNL_Clock_workFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Idle_loop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Queue_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Queue_empty__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Semaphore_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Semaphore_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Semaphore_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66
| ti_SysBIOS_KNL_Semaphore_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-ipc-tree/packages/ti/pm/lib/release/ti.pm_vayu.ae66
| ti_sysbios_KNL_Swi_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Swi_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_post __E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Swi_restore__E EDMA.obj
| ti_SysBIOS_KNL_Swi_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-framework-components-tree/packages/ti/sdo/fc/edma3/lib/release/edma3.ae66
| ti_SysBIOS_KNL_Task_getModuleStateCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_getObjectCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_moduleStateCheck__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_objectCheck___I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_restore__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/share/ti/ti-framework-components-tree/packages/ti/sdo/fc/edma3/lib/release/edma3.ae66
| ti_sysbios_KNL_Task_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_timers_dmtimer_Timer_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_timers_dmtimer_Timer_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_timers_dmtimer_timer_stub__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_instance_finald_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_instance_finalance_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor1/package/cfg/monitor.am57x_pe66.oe66
|错误:未解析的符号保持
|未定义 首次引用
|符号 在文件
中|--- --------
| IpcMgr_callIpcStart /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| IpcMgr_ipcStartup /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_remoteproc_Resource_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_attach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_detach__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_isRegistered__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_ipc_transport_TransportRpmsgSetup_sharedMemReq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_registerTransport___F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_MessageQ_unregisterTransport___F /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_Notify_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_family_vayu_NotifySetup_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_ipc_gates_GateHWSpinlock_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sdo_utils_nameserver_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysBIOS_BIOS_linedWithIncorrectBootLibrary__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_BIOS_setThreadType__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_IntrinsicsSupport_maxbit__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_checkStack__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_getCheckValueAddr__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_getDefaultStackSize__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_getStackAlignment__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_stackUsed__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C62_TaskSupport_swap_E_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_EventCombiner_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_EventCombiner_unused__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_exception_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_exception_dispation__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_Hwi_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_hwi_d调度 Always /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_family_c64p_Hwi_enableInterrupt__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_TimestampProvider_Module_startup__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c64p_TimestampProvider_get64_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_enable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c66_cache_startup____i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wait__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wbAll_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wbInvAll__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_C66_cache_wb__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_c66_vayu_Power_resetFxn_i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_Shared_vayu_IntXbar_initIntXbar__i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_family_Shared_vayu_TimerSupport_Module_Startup_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateAll_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateHwi_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutexPri_query_E_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateMutex_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_gates_GateSwi_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_checkStack /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_initStackMin /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_hwi_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_instance_final__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getCount__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getCurrentTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getExpiredCounts__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_hal_TimerNull_getExpiredTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getFreq__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_hal_TimerNull_getMaxTicks__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getNumTimer__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getPeriod__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_getStatus__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_setFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_setNextTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_hal_TimerNull_setPeriodMicroSecs__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_setPeriod___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_start__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_stop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_hal_TimerNull_trigger__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_b堆_HeapBuf_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapBuf_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_alloc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_b堆_HeapMem_free__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_b堆_HeapMem_getStats__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_init__i /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_堆_HeapMem_isBlocking__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_logTick__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Clock_workFunc__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Idle_loop__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Queue_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Queue_empty__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Semaphore_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Semaphore_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Swi_disable__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_post __E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Swi_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Swi_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_getModuleStateCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_getObjectCheckValue__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_moduleStateCheck__I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_KNL_Task_objectCheck___I /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_restoreHwi__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_KNL_Task_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_timers_dmtimer_Timer_Module_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_SysBIOS_timers_dmtimer_Timer_startup___E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_timers_dmtimer_timer_stub__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateProcessSupport_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_instance_finald_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_enter__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_leave__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_GateThreadSupport_query_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_instance_finaling__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_instance_init__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemProcessSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_instance_finalance_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_instance_init_E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_pend__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
| ti_sysbios_xdcruntime_SemThreadSupport_post__E /home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/monitor0/package/cfg/monitor.am57x_pe66.oe66
|错误:未解析的符号仍然存在
|错误:链接期间遇到错误;"dsp1.out"未生成
>>编译失败
| Makefile.am57x:133:目标'dsp1.out'的配方失败
| make[1]:***[dsp1.out]错误1
| make[1]:***正在等待未完成的作业...
|错误:链接过程中遇到错误;"dsp0.out"未生成
|>>编译失败
| Makefile.am57x:128:目标'dsp0.out'的配方失败
| make[1]:离开目录'/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor
| make[1]:***[dsp0.out]错误1
| cmake_install.cmake:48 (
无法找到/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/git/monitor/dsp0.syms 文件)|
|| Makefile:64:目标'install'的配置失败
| make:***[install]错误1
|错误:OE_runmake 失败
|错误:函数失败:DO 安装(日志文件位于/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/build/arago-tmp-external-linaro-toolchain/work/dra7xx_evm-linux-gnueabi/opencl-monitor/1.1.12.0-r0.0/temp/log.do_install.13989)
错误:任务4923 (/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-ti/ocl/opencl-monitor_git.bb、DO 安装)失败,退出代码为'1'
注:任务摘要: 已尝试1780个任务、其中1778不需要重新运行、2个任务失败。
注意:写入 buildhistory
等待0个正在运行的任务完成:
摘要:2个任务失败:
/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-qt5/recipes-qt/qt5/qtxmlpatterns_git.bb、DO_COMPLETE
/home/bmann/projects/ti/ti-processor-sdk-linux-automotive-dra7xx-evm-5_00_00_01/yocto-layers/sources/meta-arago/meta-arago-extras/recipes-ti/ocl/opencl-monitor_git.bb、DO_INSTALL
摘要:显示4条错误消息、返回非零退出代码。
[PSDKLA]>[PSDKLA]>
在 ש פבר 9 19:29:40 IST 2019
中完成了 Yocto 构建[PSDKLA]>
非常感谢您对此提供的帮助。
    Daniel、您好!
    您是否在某些配方中进行了任何修改、或者它是干净的构建(除了 md5sum 的更改)?
    您第一次运行构建时是否也发生了这种情况? make 可能返回此错误:
    .obj/qboole.o:无法识别文件:文件被截断
    如果先前的构建中断、并且未完全生成目标文件。
    Yordan
    Yordan、您好!
    我通过重新启动 Ubuntu 14.04来解决了该问题、问题是我使用的是 Ubuntu 16.04。
