[参考译文] Linux/TMDX654IDKEVM:编译 SDK 时出错
Guru**** 2645755 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/802773/linux-tmdx654idkevm-error-building-sdk
器件型号:TMDX654IDKEVM
工具/软件:Linux
我按照此处的建议使用以下命令来 stat SDK 的构建: http://software-dl.ti.com/processor-sdk-linux/esd/docs/05_03_00_07/linux/Overview_Building_the_SDK.html#processor-sdk-build-reference
但是、我遇到以下错误:
| make[5]:"第一"没有要做的事情。
| make[5]:离开目录'/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7
/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7 qopenglwidget.pro +gitAUTOINC+81b29a44d2-r0.arago13.tisdk5.4/build/tests/auto/widgets/qtoolbox'| cd qopenglwidget/&(test -e autobile/tisdle+81b29a+442/rgtisfs/rgtisf4 /home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7)/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7
| make[5]:离开目录'/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7 +gitAUTOINC+81b29a44d2-r0.arago13.tisdk5.4/build/tests/auto/widgets/widgets/qtoolbutton'
| make[5]:进入目录'/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7 +gitAUTOINC+81b29a44d2-r0.arago13.tisd5.4'
、针对'ldoino/snotle/make'/make'd5.4'、无需执行任何操作/tisd5.4':
/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7 +gitAUTOINC+81b29a44d2-r0.tisdk5.4/build/tests/auto/widgets/qopenglwidget'| make[4]:离开目录'/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7
/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7 +gitinc+81b29a44d2-r0+r0+tisd13+tisdle+tisd4+tisdle+ratego1.4+tisd13+tisdle+tis+r34+tisdle+ratego1.ts+rgo+ts+ts+ts+tisd44d13+tis+rg/make+tis+tisdle+tis+tis+tis+r241.tis+dle+rnateg+r20+tis+d1.tis+rgo1.ts+rgo1.ts+rgd1.tis+rgo+rnatego+d1.ts+rgd1.tis+rgd1.tis+rg/
|错误:函数失败:do_compile (日志文件位于/home/prateek/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qtbase/5.9.7 +gitAUTOINC+81b29a44d2-r0.arago13.tisdk5.4/temp/log.do_compile.6070)
错误:任务(/home/prateek/tisdk/oe-layersetup/sources/meta-qt5/recipes-qt/qt5/qtbase_git.bb:do_compile)失败、退出代码为"1"
请提供建议。
Prateek
    Prateek、您好!
    另请参阅 此主题。 确保已运行必备命令,并在主机上具有40GB RAM/交换大小。
    Kemal
    您好、Kemal、
    感谢您的回复。
    我使用的是 Ubuntu 18.04 LTS、在运行 bitbake 命令之前、我仔细执行每个步骤。
    请查找随附的故障日志。 我正在运行带有-k 标志的 bitbake、以便它可以做任何事情。
    我使用以下配置:processor-sdk-05.03.00.07-config.txt
    对这一点的任何深入了解都将非常有帮助。 谢谢
    正在初始化任务:100%|################################################################################################## |时间:0:00:17
    注意:正在执行 SetScene 任务
    注意:正在执行 RunQueue 任务
    错误:qt3d-5.9.7+gitAUTOINC+de5e7839d6-r0 DO_COMPLETE:OE_runmake 失败
    错误:qt3d-5.9.7+gitINC+de5e7839d6-r0+rlog+r0+re0+reUSTRUTRIGN (位于/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7文件
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7中)
    摘要:1个任务失败:
    /home/prateekkhatri/proc-sdk/tisdk/sources/meta-qt5/recipes-qt/qt5/qt3d_git.bb:DO 编译
    调试:执行 shell 函数 do_compile
    注:make -j 12 maKEFLAGS=-j 12 OE_qmake_Compiler=Aarch64-Linux-gcc --sysroot=/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot_qmake_c=aarch64-linux-rraus+r-rge-rge-g5eo2+r-r-rgi20=g-r-r-r5rgi20=g-r-r-r-rgi20=g-r-r-r-r-rgi20=g-r-r-r-rf-rg-rgi20=g-r-r-r-rq-r-r-rq-r-rgi20=gi20=gi20=g-r-r-r-r-r-r-r-r-r-r-rq-rq-rg-r-rf-rg-rg-rg-rg-rgi20=gi20+r /home/prateekkhatri/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-linux-gnu/aarch64-linux-gnu/lib /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /usr/src/debug/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /usr/src/debug/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 hash-style=GNU OE_qmake_ar=Aarch64-linux-gnu-ar OE_qmake_strip=echo OE_qmake_WAYLAND_scanner=/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-root/usr/bin/wayland-qmake_intrabout_e+e+r7839+e+e+rg/make+e+e+rqe+rqe+r1+rqe+rqe+r1+rinc /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 src.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /usr/include/qt5
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    src.pro
    core.pro
    doc.pro +gitAUTOINC+de5e7839d6-r0/build/src'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-native/usr/bin/qt5/qmake -makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitinC+de5e7839d6-r0+rnative+t/make+tide+t+ge+t/rqeed/eed/eed+tide+tide+t+t+t+r+t/rqeed/eed+tes+t+t+t+t+r+r+t+r+t/r+tes+r+t+t/r+tes+r+r+r+t+r+tes+t+t/rqeqeqeed+t+t+t+t+t+r+t+r+r+r+r+r+t/eed+t+r+r+r+tes+t+t+r+r+r+r+r+t+t+r
    doc.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/core'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r2/r0'
    、然后不执行'core.pro 操作/core'。
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/doc'
    =/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git
    =/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build
    make[2]:对于"第一个"不需要执行任何操作。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 render.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 logic.pro +gitAUTOINC+de5e7839d6-r0/build/src/core' CD 呈现/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOsrc+de5e7839d6-r0/usr-sysroot/bin/qt5/qmake -makeo+eo+emake+eo+eo+r396+eo+eo+eo+eo+eo+emakeo+e+eo+eo+e+e+r396+eo+eo+eo+eo+eo+e+e+r39+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+e+e+e+e+r39+eo+tinc/r39+eo+e+e+e+eo+e+e+eo+e+e+eqinc/eqtinc/eqtinc /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    logic.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    render.pro +gitAUTOINC+de5e7839d6-r0/build/src/render '/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/r0/rg/rgit
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importslogic.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/logic' CD quick3d/imports/logic/&&(test -e Makefile.usr+gitAUTOINC+de5e7839d+r5eo+re783d+g/make+true/make+true/true/true/logico+true/true/r3o+true/true/true/maked+true/true/true/true/true/true/makeo+true/true/true/true/true/true/maked/true/true/true/true/true/true/maked/true/true/true/true/true/true/true/maked/true/true/maked/true/true/true/r39dprues+true/true/true/true/true/true/ importslogic.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/logic'
    make[2]:对于'first'没有任何可做的事情。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 input.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 animation.pro +gitAUTOINC+de5e7839d6-r0/build/src/render ' CD input/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOsrc+de5e7839d6-r0/usr-sysroot/bin/qt5/qmake -makeo+eo+emake+eo+eo+eo+eo+eo+eo+eo+tinc/r78396+eo+eo+eo+emakeo+t+eo+eo+eo+eo+eo+eo+eo+eo+eo+t+eo+eo+eo+eo+eo+eo+eo+eo+eo+t+e+eo+eo+tinc/eo+tinc/eo+eo+eo+eo+eo+eo+eo+tinc/eo+eo+eo+eo+eo+eo+eo+eo+eo+tin
    animation.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/input'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/r0/input/input.pro
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/animation'
    make[2]:对于'first'不执行任何操作。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 extras.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3d.pro +gitAUTOINC+de5e7839d6-r0/build/src/input' CD extraes/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/usr-sysroot/bin/qt5/qmake -excepe3+e3d+t/make+t3d+e3d+eo+e3d+emake+eo+t/r3d+e3d+e3d+e3d+emaked/makeo+eo+t/r3d+t3d+t3d+t/r3d+e3d+eo+eo+e3d+e3d+t/maked/makeo+eo+eo+eo+e3d+eo+tintrue/maked/maked/r3d+e3d+eo+e3d+tintrue/maked/r3d+e3d+e3d+e3d+t+
    quick3d.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/examples'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/r0/extras.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importscore.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3drender.pro +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3d' CD quick3d/imports/core/&&(test -e Makefile.cd score |/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitudeintrue/quick3dc/maked/makeed/quick3dc/rg3dc/maked/makeed/makeed/r3dtrue/make/quick3dc/rg3dc/maked/makeed/makeed/r3dc/r3dc/rg3dtrue/maked/maked/maked/makeed/r3dc/r3dtres+t3dc/rg3dtres+t/maked/maked/maked/maked/maked/makeed/maked/maked/true/maked/r3dc/r3dc/r3dtres/
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3dscene2d.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3dinput.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/sr3d/quick3dsceout2d+g/make+eout+eout/r3d+t/makeout+r3d+r/makeout/quickeout/r3d+eout/rq3dc/makeout/r3dc/makeout/r3dc/r3dc/makeout/r3dc/makeout/r3r3dc/makeed/makeed/r3de-directory/rq3dc/rq3dc/r3dc/r3dc/makeed/makeed/eed/r3r3rintreed/makeed/eed/r3dc/es+eed/r3dc/es+r3dc/quickeout/r3dc/es+r3dc/r
    quick3dinput.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importscore.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3drender'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAutoINC+de5e5eAuto/quick3d6/rd3dtreso'quick3drender.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 sceneparsers.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 geometryloaders.pro +gitAUTOINC+de5e7839d6-r0/build/src/examples' CD plugins/scapeparasers/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-native-usr/qt5+gtrabout/makes+g3e+gtre/maked/es+gtres+r1r1r+g/maked/es+g3r+gtrese/rqeed/r1r1r+r+r1r+g/makese/r3r+gtrese/rt+r1rgtrese/makese/rt+gtrese/t+r3rt+gtresm/maked/makese/r1r3rt+gtrese/rt+gtresm/ese/t+g3rg/makesm/esm/ese/makers/makese-makese-makese/r1r1r1r3r+gtrese/r
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3dextras.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3dscene2d.pro +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/sr3d/quick3dxtras /gmakeed/eoutr3d+g3d+r1d+r1d+e3d+g/maked/eout+e3d+rq3d+rq3d+rg3d+rg/maked/eout+rq3d/srq3d/srq3d/srg3d/src/maked/eout+eout+eout+e3d+eout+eout+eout+eout+rq3d/srq3d+eout+eed/emaked/eout+rq3d/srq3d+eout+eout+rq3d/srq3d/srq3d/srq3d/sr3d/sr
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/core'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build make[2]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 sceneparsers.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/ plugins/sepappareders'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 geometryloaders.pro +gitAUTOINC+r5e7839d6-r0/pegraines+r+tradues+r+ges+r78396/rgemakeo+rtres/smese/rtese/rqeo+gtese-makese/rtines+rtines+r396/rq+gtines+rtines+rtines+rtres+r786/rtines+gtines+gtines+rtradues+rtres+rtres+rtres+r396/rtradues+r396/rtradues+rtres+rtres+rtres+rtrese/tines+r786/rq+gtinese/rq+gtines+r
    quick3dextras.pro +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3dexctras '/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitINC+de5e7839d6-r0/pege-make3d/quick3dc/quick3dtras /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    gltfexport.pro
    gltf.pro +gitAUTOINC+de5e7839d6-r0/build cd gltfexport/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/qt5/qmake -o makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitefile/tes+r5e+t/maked/rtese/rtese/rtese/rtese/rtese-maked/rtese/tese-t/rtese/tese/t/rtese/tese/tese-maked/rt/rt/rtese/t/rtese/tese-maked/rt/rtese/tese-mese/t/rt/rt/rtese-mese/t/rtese/tese-mese/tese/tese/t/rtese/t/rt/rtese/tese/tese/tese-mese-porteout/rt/rt/rt/rt/ default.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 && make -f Makefile
    cd gltf/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitutetr+de5e7839d6-r0/git/git/make)/gm/make 插件和-momtfiles/gltf.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 gltfexport.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/plugins/adsce7839ds/gitexport'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 gltf.pro +gitinc+de5e7839d6-r0/pegraqeouts+r+r+r+tese/make+tese/teso+gtese/teso+r5+gtese/pirt+gtesm/eout+tese/portspreo+gt+g/make+r5+gtese/teso+gt+r+teso+tese/portspre+gt+gt/make+tes+t+tes+t+t/make+tese/pines+tes+tes+t+t+native+t+t+t+t+r396/native+gt/make+tes+t/make+tes+tes+r
    gltf.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 default.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3dinput '
    CD quick3d/imports/input/&&(test -e Makefile.syssinput ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 gitAUTOINC+de5e7839d6-r0/pege-maked/true/true/makedoeout1 importsinput.pro)'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importsscene2d.pro +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3dscape2d' CD quick3d/import/scape2d/&&(test -e Makefile.usrsimportsusr+gitAUTOsrc+de5e783d/ scape2d/和/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7),
    以使'native/spre2d/spre2d/sece2d/spreoeoe2d/ nesteoeoeoe3d/ makeoeoeoeoeoeoe2d/ makeoeoeoeoeoeoeoeoe2d/
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3danimation.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importsrender.pro +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3drender ' CD quick3d/quick3dimanation/&&(test -e makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d7839d+r3d/spremake/quick3d/makeed/makeo+r3d/maked/maked/makeoirt3d+t/makeed/makeed/makeed/r3dc/examplese-maked/trese-makeed/r3dc/ese-makeed/r3dc/ese-maked/rq3dtrese-makeed/rq3dc/ese-maked/rq3dc/intrese-makeed/r3dc/ese-maked/rq3dc/intrese-maked/rq3dc/ese-maked/r3dc/rc/r3dtrese-maked/r3dc/rc/rq3dc/
    (test -e Makefile.importsscore3d ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile.usr+gitr3d /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitrender+de7839d6-rnative+es+g/maked/eseout1) importsscene3d.pro renderplugins.pro
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/plugins/geometryloader /gltf'
    make[3]:没有为'first'执行任何操作。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/plugins/importeparers/gltf' make[2]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importsinput.pro +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/importedsepo+gitude+eo+r3o+e+rq396/rq3o/sr+rq3o/sr+r+native/sr+rq3o+r+r+e/srq3o/sr+r+native/srq3o+r+r+r+r+r+r+e/srq39d/srq3o+rg/d/srq3rgeout+e/sr1r1r+r1r+
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/plugins/sceneparsers/gltfexport'
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/plugins/scenepars'
    make [3]:“不执行任何操作”。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/plugins/geometryloader /default' make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/plugins/importtins/geetr396+g3d+e78d+g3d+eid/make+tres+g3d+true/make/sr3d+trabout+tres+tres+true/linux/directory/sr39d+eintrabout+eintrabout+true/directory/sr39d+eintrabout+eintrabout+eintrabout+eintres+eintrabout+eintrabout/e+e+true/es+eout+eintrue/directory/sr39d+trabout+trabout+eout+eintrue/es+trabout+eout+eintrue/es+trabout+true/
    renderplugins.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importsrender.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 quick3danimation.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importsscene3d.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    "第一"没有要做的事情。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importsextras.pro +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3dextras' CD quick3d/imports/examples/&(test -e Makefile.importsextras ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 + gitinC+de5e7839d6-r0/r0/linux/makefile/linux/maked/maked/linux/maked/maked/linux/directory/maked/directory/linux/maked/directory/maked/directory/directory/directory/directory/maked/directory/director/director/directory/director/director/director/director/director/director/director/director/director/direct
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/scene2d'
    make[2]:对于'first'没有要做的事情。
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/input'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/sce3d' make[2]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 importsextras.pro scene2d.pro +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/importedes'+gemake+t/makeo+eo/rq3d+eo+eo+eo/make+e/r3d+eo+eo+eo+eo/rq396+eo+eo+eo+eo+e/make+t/makeo+eo+eo+eo+e+eo+eo+t/es+eo+eo+eo+t/rq396/nativeo+e+e+eo+e+t/es+nativeo+e+native/srq-intrabouts+e+e+e+e+e+e+e+e+native/srq-intr/
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/render' mak[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 scene2d.pro +gitAUTOINC+de5e7839d6-r0/build/plugins/quick3d/plugins/e2d'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+e5eoutr7839d/srd/srendere5r0/rqe100/srq/esd/sr1d/sr5nategines/sr5native /eso+r396/esd/sr39d/sr1r1r1r1r1r1r+g786_es/srq/plugines/sr1r1r+g786]+g/esd/srq-make
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/exas'
    make[2]:对于'first'不需要执行任何操作。
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/quick3danimation'
    CD quick3d/import/animation/&&(test -e Makefile.importsanimation ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 gitAUTOINC+de5e7839d6-r0/pege-maked/makefile/r3oirt/makeout1 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7) importsanimation.pro native /maked/maked/maked/makeoeoutr3oeed/maked/makeed/makeoeoeed/makeed/maked/maked/r3oeoeoeoeed/r3/eminoeed/emintranimations+tranations+tranations+r6
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/plugins/renderplugins/sce2d' make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/renderplugins' make[2]:输入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+e3+r+g3d+tintranimines+r+r+e786+g3d+rg/reines+eines+rq3d+eino+eino+eino+eino+eino+eino+eo+eino+eino+eino+eino+eo+r39d+eino+eo+eo+eintrado+eo+eo+r39d+eo+eo+eo+eo+eo+e3 importsanimation.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/src/quick3d/imports/animation' make[1]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 tests.pro tools.pro +gitAUTOINC+de5e7839d6-r0/build/srrc/prue-make+e+gitefile/r1+tes+g/make+r1+git/makeo+r1+r1+g/makeo+r1+g/rqtes+r1+r1+r1+r1+r1+r1+git/makeo+r1+g/makeo+r1&true/makeo+r1+rqtes+r1&try+r1&true/r1+rq-maked/rq-makeo+t+r1+t+r1+r1+r1+r1+rq-maked/rqtes+r1+r1+rqt+r1+r1+r1+r
    tests.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 tools.pro +gitAUTOINC+de5e7839d6-r0/pege-native/usr/bin/qt5/qmake -makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitinC+de5e7839d6-r0+rnative+r+ge+d786+rge+rqemake+t+t+rqe+t+rqe+tes+t+t+rqeudeo+t+t/eqtes+tintres+tes+tes+t+t+g/eqtes+tes+tintres+t+g/eqtes+tes+tes+tes+tes+tes+tintres+t+t+tes+t+g/rtes+tes+tes+gtes+tes+tes+rtes+g/eq-makeo+tes+tes+tes+tes+tes+
    auto.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 benchmarks.pro && make -f Makefile
    cd manual/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 manual.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/tests/manual+gtmake+g1+gt/make+g1&rgt/rqeo+r1o+gt/makeo+g1&t+gt/rqeo+rqeo+r1o+r1&t+gt/rqeo+g/makeo+g1&t+gt/rqeo+g1&t+gt+gt+gt+gt+gt+r+g/makeo&t+g1o+t+t+g/makeo&t+g/dr qgltf.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 core.pro +gitAUTOINC+de5e7839d6-r0/build/tests/benchmarks" CD 呈现/&&(测试-e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-native/usr/bin/qt5/qmake -o Makefile/t+gitefile/t+t+t+t+emake+t+e+e+t+t+t+t+t+r781/maked/eed/eed/emake+tes+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+t+r78emaked/maked/maked/rqe+t+t+
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 coretest.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto' CD coretest/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 assimp.pro +gitAUTOINC+de5e7839d6-r0/pege-cpp root/scee/qt5/qmake -o makeile/t+eo+t+emakeo+t+t+t/eo+tid/r78eed/rtes+tid/rtes+tes+tid/rtid/rtides+tes+tes+tes+tid/r+tid/rtid/rtes+tes+tes+tes+tes+tid/r&tes+tes+tes+tes+tes+tid/r&tes+tes+tid/r&tes+tes+tes+tes+tid/r&tes+tes+tes+tid/rintry+tes+tes+tes+tes+tid/
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 bigscene-cpp.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 bigmodel-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/tests/manual/bigscee-make-mcepo+/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7)+git/dmaked/e+qtid/r396+rg/rqtid/rqtid/rg/rq-mctres+g/rq-mcepo+g/rq-mcepo+g5mcepo+g/rq-mcepo+g5mctry+g/rq-mcepo+g/rq-mcepo+r39+g/rq-mcepo+g/rq-mcepo+g/rq-mcepo+rq-mcepo+rq-mctry+g7+g/rq-mcy+g/rq-r bigscene-instanced-qml.pro && make -f Makefile
    CD clip-planes-QML/&&(test -e Makinc ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 clip-planes-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-root//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitcp+de5e7839d6-r0/r0/moce-maked/eed/efile/rqeopre+t/rq-make+g/rg/make-mcppm/ mewe&r custom-mesh-cpp.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/tests/manual/component-changes/component-changes.pro custom-mesh-cpp-indirect.pro)&& make -makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +git/makeo+gide-t/rqtefile/rqt+rg5gmctry+r+g/rq-make+rq-make+rq-make+rq-make+rg/rq-make+rqt/rq-make/rgtry+rq-me-mctry+rq-me-t+rg/rq-rq-rq-rq-rq-rq-rq-me.com/t+t+rq-rq-rq-rq-rq-rq-rq-rg/rgie/rq-rq-rq-rq-rq- custom-mesh-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qcircularbuffer.pro +gitAUTOINC+de5e7839d6-r0/build/tests/benchmarks/core' cd qr循环 缓冲区/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/usr-sysroot/native/qt5/qmake -make+gitefile/r1e+d783+d+rgt/makeouts+dle/rqtintres+dle+dle/d786/rqemakeouts+dle/dle/dle+dle/dle+dle/makeouts+tintrese/rq39f/sechts+dle/rqtintres+dle+dle/dle/dle/dle+tintres+dle/d78
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tools/qgltf' make[1]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 examples.pro +gitAUTOINC+de5e7839d6-r0/build/tools' CD examples/&&(测试-e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d396/remakeo+r1+r1+r1e+d786'demakeo+eo+eo+eo+emakeo+eo+eo+eo+r39nativeo+eo+eo+e+eincepo+e+e+e+r39nativeo+e+einc)
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qresourcesmanager.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/benches/r渲染' cd qresourcesmanager/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 assimp.pro +gitAUTOINC+de5e7839d6-r0/pege-native/usr+bin/makeout+gt+r396+g/makeout+rqeout+t+rqeout+t+rqeout+r396+rg/esintrue/rqeout+rq-makeout+t+r+t+tesintres+r+g/rrrrq-makeout+t+tesinc/rq-rq-makeo+r396+tesintres+r+r+rg/es+rg/es+tesintres+rg/es+t+rg/es+rg/rg/rg/rq-makeout+teso+teso+r396+teso+teso+
    coretest.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 bigscene-cpp.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    bigmodel-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/bigmode-QML'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 bigscene-instanced-qml.pro +gitAUTOINC+de5e7839d6-r0/pege-root/usr/bin/qt5/bigmake -o makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e+d78396+rgmcepo+rg/rgde-directory/rqtidtes+r+r396+rg/rgmudo/rgde-directory/rqtes+rqtes+rqtes+r+r783+rg/rgmiso+rgde-directory/rg/rqtes+rqtes+r+rqtes+rqtes+r+r+r+rqtes+r+rqtes+r+rqtes+r+rqtes+rgtes+rgtidtes+r+r+r+r+r39+r+r+rq
    custom-mesh-cpp-indirect.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 component-changes.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 clip-planes-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 custom-mesh-cpp.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    qcircularbuffer.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/core/qcircarbuffer'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 custom-mesh-qml.pro +gitAUTOINC+de5e7839d6-r0/pege-root/usr/bin/qt5/make-o makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitinc+d396+rgmce-make/rqtintres+d+r396+rgt+rqtinc/rqtinc
    qt3d.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 arraypolicy.pro +gitAUTOINC+de5e7839d6-r0/build/tests/benches/core/qresourcesmanager' CD ArrayPolicy/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/qt5/makefile &rgitefintry+ge+remake/rqe&rqeedr+rqe&rqe&rqe&rqe&rgrqeedr&r&rgrgr&rgr)
    make[3]:"第一个"未执行任何操作。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qresourcesmanager.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/bigmodel-QML' CD qresourcesmanager/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-native-/usr/resourcesmanager/&trake+gitrq3+rqtle+rqe+rqeo+rqeintrates+r&rge+rge+rq3+rqe+rqe+r&rqe+rgrqe+r&rgrgrgrgrrgrrgrgrgr&rgrgrgrgrgrr
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qframeallocator.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/custom-mesh-cpp' cd qframeallocator/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/dmakefile),
    以进行'rqe+tle+rqemakedino+r+rq3+rqe+rqemakedinc/t+rqeintrino+rqe+rqe+t+rqe+rqemakedintrinc/t+rqe+t+rqe+rqe+rqe+rqe
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 custom-mesh-update-data-cpp.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/custom-mesh-QML' CD custom-mesh-update-data-cpp/&&(test -e makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitinc+de5e7839d+r0/pegie-maked+r3+rg/makeout1)/makeout1–rq3+rg/makeo+rq3+rg/makeo+rq3+rg/makeo+teso+r+r+r3+rg/makeo+rg/makeo+r3+rg/makeo'+teso'+teso'+r+r+teso'+r+r+tudeo'/makeo'/makeo'+teo'+teo'/maked+
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/clip-plans-QML'
    CD simple-QML/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/tmakefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7) simple-qml.pro -e3d+q3mu+tq4+tqtqtid/mcy+tq4+tqtqeouts+d+tqeq4+tqeqeouts+d+tqeqeqeqtid/d/
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 scene3d.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 shadow-map-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/benches/core/qr循环 缓冲区' cd scape3d/&&(test -e makefile |/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d+e7839d+rgie/makefile/rq3m+t+rg3mctrad+eq3d+eq3d+rmce-maked/eq3g/eq3mad+rg/eqtid/eq-mad+tq-eq3d+rq-mctrad+eq/eq3mctreq-demo+e+e+t+eq-eq-eq-eq-e+tid/eqtq-eq-eqtid/eqtid/eqtid/eqtid/eqtqtqtid/eq-eqtid/eq-tqtid/eq-tqtqtqtid/e+
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 custom-mesh-update-data-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 wave.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/tests/manual/custom-mesh-update-data-qmf-qml+g1+gitefile/rt+g5+rqt/rqemake+r1+rg/rt/rqe+rqt/r1rg5g/rg/rqtes+rg/r1rg/rtes+rg/r1r+rg/r1rg/rtes+rg/r1rg/rtes+r1r+g/r1r+g/rtes+g/rtes+g/r&rtes+r&rtes+g/rtes+rtes+r&rtes+rg/rg/rtes+g/rtes&rtes&rg/ controls.pro && make -f Makefile
    CD 多视口/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 multiviewport.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAutoCCP+de5e7839d6-r0/git/git/esd/emaked/r3mctry+g3d/sme-maked/g3mctry+g3d/d&try+g3mf-native+g/g/dle/dle/q3mcepo&try+g3mcepo&d&d&d&d&d&d&dq3g3mcepnativeq3mcepo&d&d&d&d&d&d&d&d&d&d&try+g3g3g3mcepnativeq3g3mcepnative&d&d&d&d&d&d&d& instanced-arrays-qml.pro
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/examples/qt3d/simple-cpp/simple-cpp.pro)& make
    命令'3'不执行任何操作以进行'f1':
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 lights.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 wireframe.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/bigscee-instanced_qML' CD les/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitleylink+d7839d6-r0/pipe -sysusrusr/usr/usr/r/makeo+t/makeout/rqeout/r1rqeout+t/r1r1r+t/rqeid/r1r1rqeid/rqeo+t/r1r1r+tid/r1r+tid/rg/r1rg/rg/r1rg/rqeqeo+tid/r1r1r&tid/rg/r1r1r+tid/rg/rg/rg/r1r1r1rg1rg/rg/rg/r1r1r1r1r+t/rg/r&tes&tes&tes&
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 cylinder-cpp.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 cylinder-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/test/manual/cylind/Clak-makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7)+git/makeout/r396+rqeed/rqemake/rqeudeile/rq-make+rqt/rq-make+rqt/rq-makeid/rq-makeo+r396+t/rq-makeo+t/rq-makeid/rq-makeid/rq-rq-rq-rq-rqt/rq-rqt/rq-rq-rqtid/rqt/rq-rq-rqtid/rq-rq-rq-makeid/rq-mcyles+rqt/rq-rq-rq-rq-r anaglyph-rendering.pro
    "第一"没有要做的事情。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/component-changes' make[5]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 arraypolicy.pro deferred-renderer-cpp.pro +gitAUTOINC+de5e7839d6-r0/build/tests/core/rraqesmanager/rray+rraudes+r5+rqe+t+rqe+rqe+r1+rqe+rqe+r5inc/rqe+rqe+rqe+rqe+rqe+rinc/rq-rqe+r396+rgrg/rqe+rqe+rq-make+rg/rqe+rq-rq-rgrgrgrq-rq-rq-rq-rc/rqe+rqe+rt+rq-rq-rq-rq-rq-rc/rq-rq-rq-rqe+rq-rq-rqrrrrrr
    planets-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    "第一"没有要做的事情。
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/custom-mesh-cpp 间接'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 deferred-renderer-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 dragging.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/bigscee-cpp' cd render-render-QML/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839der-rgie/moldemake+r1+r1+g1+g1+rg/makeo+r1r1r+r+r1r+g/r1r1r+g1r+g/r1r+g1r+r1r1r+r+r+r1r+g1r+r+r+r1r+g/mctry+g1r+g1r+g1r+g1r+r+r+r+r+r+r+g1r1r1r+g1r+g/mctry+g1r+g1r+g1r1r+g1r+g1r+g1r+g1r+g1r+g1r
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/assilmp'
    cd dynamicsceste-cpp/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/make+g3+gitefile/rq3+rqe+rqeout1 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7),
    以执行'te7839e+rqe+rqe+r3+rqe+rqe+rqe+rqe+rqe+rcpp/makeout1和 dynamicscene-cpp.pro native+rqe+rqe+rqeo+r
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/coretest'
    CD core/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qresourcesmanager.pro +gitAUTOINC+de5e7839d6-r0/pege-native/usr/qtqtes+r+native+rq5+rqe+rqtinc/es+rqe+rqtes+rq+rqeakeedr+r+r+rg6) core.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    qframeallocator.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 controls.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    输入目录"/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/custom-mesh-update-data-cpp"/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 multiviewport.pro +gitAUTOINC+de5e7839d6-r0/pege-native/usr/bin/native-dt3+gitude+r78396+d+d+de-examples+gitude+e786+t/degrq3rq3rqe+dewide/rqeout+tude+rqe+tintrue/eout+tude+e+tude+r783rqeout+eout+eout+eout+eout+eout+eout+eout+eout+eout+eout+eout+eout+eout+eout+tudeout+eout+eout+eout+tudeout+eout+eout+eout+tudeout+eout+eout+eout+eout+eout+eout+eout+
    custom-mesh-update-data-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 simple-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 instanced-arrays-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    输入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core'
    CD handle/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 shadow-map-qml.pro +gitAUTOINC+de5e7839d6-r0/pege-native/directory/qtmake -o Makefile/t+emake+e+t3+t3+gitude+e78d+rg/rg3mcepo+e+e+tid/rqtid+rg3mcepo+e+rqtinc handle.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    cylinder-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 cylinder-cpp.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    scene3d.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/sce3d'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pote-sysroot-native//usr/bin/qt5/qmake -o makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAutoINC+de5e7839d6-rnative/usq3d/ t3d/ examplese3d/
    不执行任何操作。
    make[5]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/benchmarks/core/qresourcesmanager/ArrayPolicy'
    make[4]:对于'first'不做任何操作。
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/benchmarks/core/qframeallocator'
    make[5]:对于'first'不执行任何操作。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 render.pro +gitAUTOINC+de5e7839d6-r0/build/tests/core/qresourcesmanager'make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/core/qtesmanager+g5+rmake+tes+r1+eo+tes+e+r1+e+r5inc/rqemake+texamples+e+e+e+tes+eo+e+tes+e+e+tes+e+rqtes+eautes+einc/rqtes+eautes+einc/rqtes+eautes+einc/es+eautes+eautes+tes+einc/es+tes+eautes+eauteso+eauteso+einc/es+eauteso+einc/es+r1+r1+eauteso+einc/es+r1+eakeauteso+einc
    qresourcemanager.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 && make -f Makefile
    cd qrocarbuffer/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qcircularbuffer.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 wireframe.pro +gitAUTOINC+de5e7839d6-r0/pege-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/gitraw/emakeout+true/eout/dle+rq3+rq3+r+rqemakeout/eout/eout/emakeout/eouts+rq3rqt/eout/emakeouts+r+r+rqt/eout/emakeout/eout/emakeout/eout/emakeout/eouts+rq3rqt/eouts+rqt/emakeout/emakeout/eout/emakeout/eout/emakeout/eout/eout/eout/emakeout/eouts+g/emakeout/eout/eout/eout/eout/eout/
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qboundedcircularbuffer.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/custom-mesh-update-data-cpp' CD qboundarbuffer/&&(test -e makefile |/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 simple-cpp.pro +gitudeinc+d7839d+r+rgeste+tude/makeo+rq3o+rqeo+rqeo+rqeo+rqtinc/makeo+r396+rqeo+rqeo+rqeo+rqeo+rfc/es+rqeo+t+rqeo+t+rqt+rqt+rqt+rqt+rqt+rqeo+r1o+rqeo+r396+t+t+t+t+rqeo+rqeo+rqeo+rqeo+rqeo+t+rqeo+tinc/makeo+rqeo+rqe+
    anaglyph-rendering.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 lights.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    wave.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/wave'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 deferred-renderer-cpp.pro +gitAUTOINC+de5e7839d6-r0/pege-root-native/usr/bin/qt5/qmake -o makeile./home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitpc+de5e7839d6-rgtrue/rtrue/rtexamples+rq3rtude+rqtinc/es+rtude786+rgtres+rtinc/rtudes+rtintres+e786/rtudeouts+rqtinc/rtinc /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 planets-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/scene3d'
    cd comput-spectores/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/dmakefile)/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7–t3+gitle+geq3d+gtintrues+ge+geq3d+t+geqeqeout1 /makeout1–compute-particles.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 3d-text.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/simple-cpp' cd 3D-text/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot/usr/local/usr/make3d+3d+t3d&tq3d3d+tq3o+t3d&tqeq3o+t3o+t3d&tqeqeout+t3d+t3d&tqeq3o+t3d&tqeqeout/makeouts+t3d&tqeqeouts+tqeqeout
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/simple-QML'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qardboard.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 advancedcustommaterial.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/wir帧' CD qardboard/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d+rfi/scee-makeo+true/makeo+g3o+rqt/makeo+teo+t3o+tintrue/makeo+g3o+g/makeo+rqtintrue/rq3o+tudeo+tinc/es+tinc/es+g3o+tinc)-makeq5rqtinc/es+tinc/es+tudo+tinc/es+tinc
    deferred-renderer-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/render-render-qML'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pote-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAutoINC+d5e7839d6-r0/
    手动完成'rd786'r/rd783/rdrdrrrrrkmr3'、以执行'rrrrrrrrk/r1r1r1r1'r1r/r1rr
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/shadow-map-QML' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 dragging.pro simplecustommaterial.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/raudemake+gitefile/make+t+g3o+t/makeoirt+eo+eo+eo+eo+tintrue/make+tinc/makeoirtintrue/eo+tintrado+eo+tinc/es/simpleq396+tinc/makeoirtinc/makeo+eo+eo+tintres+tinc/es/simplepoirtinc/es+tinc/es+tintrado+eq396+eo+eo+tinc/es+tinc/es+tintrado+eq396/eq39native /eq-makeo+tinc/
    dynamicscene-cpp.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 scene2d.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/instanced-arrays-QML' CD sage2d/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/usr+cepe+root-makefile -r3d/tq3d/tesoe3d/makeout1
    ),以使't3d/sece3d/rq3d/nesteoeoe1e3d/sece3d/makeoeoeoe3d/maked/rq3d/ makeoeoeoeoeoeoeoe3d/ t3oe3d/sec
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/lights '
    CD PBR-Materials/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot//usr/bin/make3+gitefile/rq3+rgt3r&moseq3r+rgt3rg3r+r&moseqeq3r+r+rqeinc /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7),
    然后再不做任何事情,并在 pbr-materials.pro 文件中完成't3r+rq3r+r+r+r+rq3r+rqe783r+r+r+r+r
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 basicshapes-cpp.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/multiviewer' CD basicShapes-/usr/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOCCP+de5e7839d6-r0/pege-sysroot-native/usr/tmakefile/t3+gitudeq3pcpp+g3+rqe+rqe783+rqe+d+d+tqeqeqeoutsepo+rq3+g3rqeqeqeqeqe+tinc/mcepo+rq3&s+g3rqeqeqeqeqeqeqe+
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 nodes.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/custom-mesh-update-data-QML' CD 节点//&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot/auto/dmakefile),
    不执行'temakeoeoe+r3+rqemakedino+r+rq3+rqemaked/dle+rqemakedino'测试。
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/wave'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/拖动' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 widgets-scene3d.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/sce3d/smepoe3d/ make+gitefile/t+t+e+emake+e+e+eq396+tid/makeo+t+eqt+t+eqtintrue/rqtintrue/eqeo+tintrue/eq-maked/eo+tid/eo+tintrue/eq-makeo+tid/eo+tintry+eq-tines+eq-maked/eq-maked/eo+tintrue/eqtintrue/eo+tinc/es+eq-maked/eq-makeo+tintry+tines+e+tintry+e
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qaspectengine.pro
    "第一"没有要做的事情。
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/dynamicscene -cppp'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/cylind-QML'
    CD quick3d/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-native-usr/auto-make+true/makeo+true/makeo+true/tq3o+tintrue/rq3o+tinc/rq3o+tinc) quick3d.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qaspectfactory.pro
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/cylind-cp'
    cd qaspectjob/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/auto+makeout1 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7),
    并执行'teq3+rqeudeoeo+rqeout1–qaspectjob.pro–tude7839de+rqeoe+rqeoeoeoe+r5e+rqe+rqeout1–tude+rqe+rqeoe+rqeoe+rqe+
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/render-render-qML'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/control'
    CD qchangearbiter/&&(测试-e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-native/auto/simple+rq5+rqemake+rc/dtrue/rq3rg3rg/dtreso+tudeo+rq3rc/dtrue/rqeudeauteudo+tinc) qchangearbiter.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/render-render-render-cpp' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 enabled-qml.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/sce2d+r1d+eq3mc+r+r+g/eq3d+r+r+r+rg/eqe781/eq3d+tid/eq3d+r+r+rg/eqeqeqeq3d+tid/r+r+r+rg/eqeqeqeqeqeid/eqeqeqeqeid/eqeqeqeid/eq-demo+t/r+tid/eqeqeqeqeqeqeqeqeqeq-r+tid/r+tid/r+r+r+r+r+r+tid/eq
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 main.cpp +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/forsuser-QML' make[4]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 handle.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/handle+git+ge+tAUTOINC+e3+e+e3d/eq396/rqeoutnative e+eq786/eeeqeeq3d/ de-examples+ge+ge+ge+eq396/eq3deqeqe+eqe+e+eq3d/ deqeqeqeqeeeeeqeqeouts+e+e+eqe+eqeqe+e+eq396/rc/eqeeeeqeqeeeeqeqeouts
    main.cpp
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qaspectengine.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/anaglyph-making'编译/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/examples/qt3d/tenecues/simpleleaglyph-make+tintres+eo+e+e78396+r+t+gtide+eintrue/rq396+t+tideintrue/rq396+teintres+einc/es/simplepo+eintrue/rq396+eino+einc/es+eq-directore+e78+e+e+e+eq396/native directore+e+e+e+e+e+e+eq396/native+e+e+eqtintrintrintres/simplepo+e+eino+e+eq-directore+eq-
    advancedcustommaterial.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 nodes.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 3d-text.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 compute-particles.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qaspectfactory'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTO+de5eauto+e5e5eincepo+r3ed/d783_deintry/secd/setrtines'/r3dle/rtineseout1目录:qaspectfactory.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 gltf.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/quick3d' CD gltf/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot/usr/bin/autocemake+eout1)并输入'd783+gemakeout+r+eout+r+emakeout+eout+eout+eout+emakeout+eout+eout+eout+eout+eout+emakeout+eout+eout+eout+eauteout+eout+eauteout+eout+eout+eauteout+eout+eauteout+eout+eout+eout+eout+eout+eout+eout+
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 gooch-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/render ' cd Gooch -QML/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qaspectjob.pro +gitAUTOINC+de5e7839d6-r0/pege-native/tmake+t+gtrue/rq5+dtrue/makeo+t+t+rq396/eo+rqeo+tinc/makeo+eo+eo+eo+eo+eo+tinc/makeo+eo+eq39+eo+eo+tinc/r39+eo+eo+eq-out+eo+eqtinc/r39+eo+eo+eo+eqtinc/rq-directory/eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+tinc/eq-out+eq-out+eo+e
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    qchangearbiter.pro
    qcircularbuffer.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qchangebiter'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-root/usr/bin/qt5/qmake -makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 main.cpp /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitauto+d7839+r+tid/rgtres+rt/rgtude/rqtinc/rqtinc/rqtexamples+rqe786/rgtres+rgtinc/rqtude78+tinc/rqe/seces+rtinc
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qresourcemanager'
    make[4]:没有为'first'执行任何操作。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 keyboardinput-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 loader-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qaspectjob' CD keyboardinput -QML/&&(test -e makefile |/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitle+gmcepo+g3+g/makeo+eo+g3+emake+eqtid/rqtido+g3+rqtintrue/eo+rq-makeo+eo+tintrue/eo+g3+tintrue/eq-maked/eq-makeo+g3+rqtintrue/eo+tintrue/eo+g3+g/eq-makeo+tintres+g/eo+tintres+g3+g/eq-makeq-makeq-makeo+g/eo+tintrue/rq-makeo+tintres+tintrue/eo+g/eo+g/
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/gltf'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/手动完成 gltf.pro
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qaspectfactory'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/qt5/qmake -o MakeAuto+gitefinc+gitude7839d6-r0//home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 enabled-qml.pro
    ,不对'gd786/r39rmoldeude0'执行任何操作,而执行任何操作。
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/handle'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 lod.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/nodes' cd lod/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/qt5/dleemakefile),
    然后不进行任何操作,并进行'teoe+gemakeoeoeoeoe+e1e+e1e+r5emaked'测试。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 cmake.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/3D-text' CD cmake/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOeFILE+de5e5e7839d6-r0/pege-native/usr/tude+rq5+rqe+rqemake+t+t/rqeo+rqeo+t+rq5mude+tinc/make+rqe+rqt+rqtinc/r396+t+rqeo+t+rqeo+t/rqeo+rqeo+tinc/makeo+rqeo+t+t+tinc/makeo+rqeo+rqe+tinc/makeo+t+rqeo+tinc/makeo+rq5rq-t+rq-tinc/rq-r39+rqeqeqeqeo+t+t+ mouseinput-qml.pro
    gooch-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/Goot-QML'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 main.cpp +gitAUTOINC+de5eUSC39d+g3de-native/rg3de-examples/rq3de-t3de-tude78/eq6/rg3de-tidese/rg3de-tintrunied/rg3de-tintrese/rg3de-tintrese/rg3de-tintrese/rg3de-tintrese/rg3de-t
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qaspengine' mak[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qardboard.pro +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/qardboard'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d+d5e7839d+rq3d+rqtudeo+rq396/rqe786+rqeqtudeqe786+rqeqeqtudeo+rqeo+rqeqtino+rq39o+rqeqeqeq39o+rqeqeqeqeqeo+tino+rqeqt39o]+rq39d+
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qscene.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 input.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qr循环 缓冲区' cd qsceste/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOC+e+e7839dle+rf+r5eUSRinc/make+r1+t+g/makeo+r1+g/rqeo+e+e+t+e+t+e+t+e+rqe+e+e+e+eqe+e+tintrue/e+e+t+e+e+e+t+e+t+e+e+e+tinc/make+e+e+e+e+e+e+e+e+t+t+eqinc/es+t+e+e+e+eq-maked+e+e+e+e+e+e+t+e+e+e+eqinc/es+e+t+t+eq-intrue/e+e+e+e+e
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 animation.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qchangearbiter' CD animation/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qboundedcircularbuffer.pro +gitAUTOINC+de5e7839de-rfempile/rqeo+tinc/make+g5+rqe+rqtinc/make+e+t+rqeo+tinc/r396+rqe+e+rqe+rqeinc/energo+e+tinc/energo+r39+e+e+e+rqe+e+e+rqe+tinc/make+e+e+rqe+tincepo+e+e+tinc/energo+e+e+e+e+e+e+e+e+rqtinc/energo+rq-makedincepo+e+e+e+e+e+e+e+e+e+e+e+e+e
    keyboardinput-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 main.cpp /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 main.cpp /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    "第一"没有要做的事情。
    scenemodifier.cpp +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/comput-spartines' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 lod.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/lodes'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitude+e783+rg/rgpinc/dsp
    目录'rtinc/de-make+r396+rq3+rg/rtinc/de-examples+rq3+rg/rqeout/rqeouts+rq3+rg/rqtinc/rqtinc/rq3+rg/rqeudes+rq-makeouts+eouts+eouts+e+rq-make+eouts+e+rq396+rq-outs+rq-make+rq-outs+rq-make+rq396/rqtinc/rq-outs+rq-out
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/input'
    make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/cmake'
    make[3]:没有为'first'完成任何操作。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/cmake' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 multiplewindows-qml.pro loader-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/loader-qml-qmf-qml/和 tmake+rgie/rqeopreo+t+qeo+r5gie/makeo+rqt+r396+rqeo+rgie/rqmctres+t+rqt+t+t+rqmctres+t+rgie/rqt+rqt+rqmctres+t+t+t+rqeo+t+t+rqeo+t+rqeo+t+rqeo+t+rgie/rqeo+rqeo+rqeo+rqeo+rgie/rgi+rqt+rqt+rqt+rqe
    picking-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    "第一"没有要做的事情。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/enabled-QML' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 mouseinput-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/mouseinput-QML'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d396/emakeout/rq3+rqeo+r1rqeo+r1r5inc/d786/rqeqtintry+rq396/rq-makeout/rq-out1
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 extras.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 plasma.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/gltf' CD extraes/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-root/usr/qt5/makeo'+r1eo+r1emakeo+eo+eo+eo+emakeo+eo+eo+eo+eo+eo+eo+eo+eo+eo+t/r786+emakeo+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+t/eo+eo+eo+t+eo+eo+eo+t+eo+eo+t+eo+eo+eo+eo+eo+eo+eo+eo+eo+eo+t+eo+eo+t+eo+eo+e+
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/Goote-QML' make[4]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qscene.pro geometryloaders.pro +gitAUTOMOT+de5e7839d6-r0/build/tests/auto/core/qscesteedes'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 moc_predefs.h +gito+g1+t+r396/rqemake+rqe+rinc/es+rqt+rqt+g5inc/es+rqt+rqeo+r396/rqeo+rqtinc/es+rq-makeo+g5rinc/es+rq-make+rq-make+rqt+rq-makeo+r396/rtres+rqt+rinc/es+rq-makeo+g5rinc/es+rqt+rqt+rqt+rq-makeo+r39o+rtres+rinc/es+rqt+rqt+rtres+r
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/multiplewefile-QML"/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot/bin/qt5/tmake -o makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 scenemodifier.h qanimationaspect.pro +gitude+tintry+e78396+t/rgeweudeoeoeoeo+tides+tryo+tes+tryo+tes+tes+geweqeqeo+tides+tintryo+tes+tes+tes+tes+tideqtintryo+tintryo+tes+tes+tes+tes+tes+gewnativeq-intryo+tes+tes+tintryo+gewnativeo+gewnativeo+tes+tes+tes+tes+gewnativeo+gewnativeo+tes+tes+
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qbounded循环 缓冲区'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/qardboard'
    make[3]:没有为'first'执行任何操作。
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/lod'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qservicelocator.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 simple-shaders-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/keyboardip-QML' CD qservicelocator/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+r5e7839d+rgie/make+rg3mce-makeo+eo+e+emaked/rqtide-makeo+eq6和 eq-makeo+eq-mcepo+t/eq-mcepo+rq-mcepo+t+rq-mcepo+t/rq-mcepo+rq-mcepo+rq-mcepo+t/rq-mcepo+rq-mcepo+t/rq-mcepo+g3mcepo+g3mcepo+g3mcepo+g3mcepo+g3mcepo+g3mcy+g3mcepo+
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 scene3d-loader.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 picking-qml.pro +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/tests/manual/e3de-mcepo+g3dmaked/rq3+rg3+rmcepo+r+rq3+rqtinc/rq3+rg786+rmcepo+rg3+rmcepo+rq-directory/r+rq-makeds+rq3+rq-maked/rg3+rq-maked/es+rg3+rq-directory+rq-maked/rq-maked/rq-makeds+rq3+rq3+rg3+rg3+rg3+rg/rq-makeds+rq-makeds+rq-makeds+rq-makeds+rq-intres+r
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/extraes' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 skybox.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/geetryloaders' cd skybox/&&(test -e–eake+gitefile/t+tintrue/r396+gtrue/ge/maked/rtryo+texamples+e+tes+tes+tes+tes+tes+rqt+tintryo+t+tintryo+t+t+rq-maked/ge/ge/ge/ge/ge/geo+tintryo+tes+tintryo+tintryo+tintryo+tintryo+tes+tes+tes+tintryo+tes+tes+tes+tintryo+tintryo+r396–tes+r objgeometryloader.pro
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qsceste'
    未找到数据签名
    Makefile:479:目标'.RCC/QRC_t纹 理.o'的配方失败
    make[3]:***[.RCC/QRC_TRC.o]错误1
    :3***等待未完成的纹理...
    make[3]:没有为"第一"执行任何操作。
    cd tessellation-modes/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/tests/manual/make'd3+makemakeo'+gitle+eo'd783'目录和 makeo'dle+makeo'd786'+makeo'+makeo'+makeo'+emakeo'+emakeo'+emakeo'+d7783'目录:tessellation-modes.pro)
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/mouseinput-QML' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 plasma.pro transparency-qml.pro +gitAUTOINC+de5e7839d6-r0/build/test/manual/masile/make+gitudo+eo+eo+q5+t/make+gie/rqtexample/rqtes+rqt+t+gie/rq-make/rqtid/rqtes+rqt+rqt+rq-makeo+t+rk/rk/r396/rkmctrue/rq-mcum/rq-mcepo+rq-t+t+t+t+rq-rqt+t+t+rq-rq-mctrue/rk/rk/r396/rk/rk/rk/rk/rq-mctraneq-mcirt+rq-rq
    transforms-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    scene3d-loader.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/sce3d-loader"/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 simple-shaders-qml.pro +gitAUTOINC+de5e7839d6-r0/pege-root/usr/bin/qt5/sepomake-o makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitude+e78396+rgmudes+e+eauto-directory/eautodests+e+eautes+r786+rqtes+rqtintres+r+rqtes+r+rg786+r+rqtes+eauto-directory/rqtintres+r+eautes+eo+r+rqtes+rq-directory/r+eautes+rqtes+eintres+eo+eauto-directory/rqtes+eintres+eautes+eo+eo+eo+eo+rqtes+rqtes+rq-directory/r+rqtes+rq
    objgeometryloader.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/multiplewillus-QML' make[4]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qservicelocator.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/qservicelocator'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +geauto+g5inc/d786/emake+te+gteo+eq396/rq396/rqeinc/de-make+texcepo+tintrad+e+e+eq396/rq396/rq-make/rq-makeq-makeo+eq-rq396/rq-rtinc/eq-rq-rq-rq-rq-rq-r396/rtinc/rq-rq-rq-rq-rq-rq-rq-rq-rq-rq-rq-rtinc
    skybox.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 transparency-qml-scene3d.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qanimationaspect.pro
    "第一"没有要做的事情。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 transforms-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/poost-QML' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 tessellation-modes.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/tessellation-mcep-q+r396+rgmce-tid/rq+r1r+r+rk/r396+r+rkmce-mce-t+r+r+r396/rtry+rg786+rg/rk+rgmce-mand/rq-r+r39+r+r+rtid/rq-mand/rq-rq-rq-r396/rg786+rmce-tid/r+rgmcep-mand/r39+r+rgmcep-r39+r+r+r+rq-rgmand/r39+r+rtid/rq-rtude+r
    moc_scenemodifier.cpp rendercapture-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qanimationcliploader.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/等 离子' cd qanimationclipoploader/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/auto+makeder/teouter+eout1),
    不执行'teoeoeo+eoeoeoeq5eo+eoeoeoeoeoeintrader+r5eq5eo+eo+eo+eo+eq5eintraneo+eo+eo+eo+eo+eq
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/core/qservicelocator' make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/autoid/rq3mc+tude786+gmc+g3mc+g/eq3mc+tid/eq-make+tid/eq-transcality/eq3+rmcy+eq-traneq3+tid/rmc+eq-makeq-trane+eq3+eq3+tid/rmcy+eq-traneq3+eq-traneq3+tid/rmcy+tid/eq3+tid/rmcinc
    transparency-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 additional-attributes-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/geometryloader/objetryloader'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/geometryloader'
    不执行任何操作[3]:首先执行以下操作:
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/scene3d-loader'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/simple-shaders-QML'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 buffercapture-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 render-qml-to-texture.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animationAspire' cd buffercapture-QML/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839der-r6–rmcepie/rqmose-make/rqmife/rqture-make+rq-makeo+r1+rmctry+g/rq-mce-mce-me-mctry+rq-rq-mcy+rq6–tq-rq-rq-rq-rmctry+rq-rq-rq-rg/rq-rmctry+rg/rq-rq-rq-mcy+rg/rq-rq-rqmf-rqmctrese/rq-rq-rgmctry+rg/rq-rq-rq-rq-rq-
    (test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/tests/auto/animents/qtimator/qclipanimator.pro dynamic-model-loader-qml.pro)并输入/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 r3+gitudo/maked/rq-makeo+r1+r396+rg/rmce-mce-mctry+rq-mce-me-mcepo+r39+rq-mcepo+rq-mcepo+rq-mcy+rq-mcy+rq-mcepo+rq-mcy+rq-mcepo+r39+rq-rq-rq-rq-mcepo+rq-mcy+rq-mcy+rq-mcepo+rq-mcy+rq-mcy+rqt+rq-rq
    qanimationcliploader.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 rendercapture-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    "第一"没有要做的事情。
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/skybox'
    CD 呈现-QML-至纹理-QML/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/usr+sysroot-native-QML/makefile/rq3&rgitudo/rq3rgme-makeout1 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    ),以进行“render-qml-to-texture-qml.pro”测试。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/transforms-QML' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 additional-attributes-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/addition-attributes-qML'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d396/rqemake-native /r1eq396/rqtude786/rq-rq-rq-rqmude786'+rq-rq0/rq-rqmudoeq-rq-fore786+git/r3rq-rq-makeoeq-rq-rq-rq-rq-makeo]+git/r
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/transparence-QML' make[4]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qclipanimator.pro qblendedclipanimator.pro +gitAUTOINC+de5e7839d6-r0/build/t/tests/autimanimators+giter+tes+temakeo+t/rq396/native /makeoirt/makeed/tes+tese/tese/tese/tese-makeed/rq396+tese/tese/tese/tese/rqtese/tese-tese/tese/tese/tese-tese/tese/tese/tese-tese-tese/tese/tese/rqtintraporeed/rqtintranimefintrese/tese/tintrese/tese/tese/tese/tese/tese/tese-tese/tese/tese/tese/tese/tese/t
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qchannelmapping.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qchannelmapper.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/tessellation-modes' CD qchannelmapping /&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+e7839d+r1+r+geMakefile/tes+tes+tes+tes+tes+g5+temakeo+tes+tes+tes+tes+tes+tes+gintrado+e+eo+tes+eo+emakeo+tes+tes+tes+tes+tes+tes+tes+tes+g/makeo+tes+tes+tes+tes+tes+tes+gintrado+eo+eo+tes+tes+tes+eo+tes+eo+tes+eqeo+tes+tes+tes+tes+tes+tes+tes+tes+tes
    buffercapture-qml.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    render-qml-to-texture.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/r渲染-qML-to-titectures'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAutoINC+d39d6-r0/make-exitudoirt/r3[rq-forthe-t/r78396/rgmudo]、
    以进行"gitudoirt/r3/无任何手动测试。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 video-texture-qml.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/transparence-QML-scoute3d' CD video -titecture-QML/&&(test -e makefile |/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitle+gmcintry+gmce-make+rq396+rgmf-native+rgmctry+rgmcy+rq5mcy+rgmcy+rgmcy+rgmce-make+rq6
    qchannelmapping.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qblendedclipanimator.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 render-qml-to-texture-qml.pro)
    dynamic-model-loader-qml.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/dynamic model-loader-QML'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d39d6-r0/mcepoirt/r3_doirt/d783-rmuilt/d3rg/rmuilot-maked/r1'd786'rk/r3rk/rk/r1rk/r1r1r1
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/addition-attributes-QML'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 animation-keyframe-simple.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 animation-keyframe-blendtree.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animents/qclimator' cd inem动画-keyframe/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitefile/make-makeoirt+t+gtrame/makeed/rqtle+tle+tle/rfemeout+rg/makeout+rrrrrg/makeout/rq-makeout/rq-makeout/rtry+tese/rrrrrfrrrtes+tes+rg/rtese/rtle/rrrtese-me-mepoirt/rg/rtes+rtes+rtes+rtes+t+t+rt+t+rt+rg/makeo+rg/makeout/rtese/rrrrrrrtese/rrrrrrtese/rrrrrtese/
    qchannelmapper.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/video-t纹 理-QML'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qclipblendvalue.pro +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native//usr/bin/qt5/qmake -o Makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/git/tests/manual/video-tage-qmage-qmplex[4]:正在离开目录'auto+auto+autoinc+einc+eauto+eincinc+r5eo+tinc/es+emakeoeoeoeoeoeo+tes+teoeo+r739dtrado+e+rqeo+eo+eo+eoeoeo+rqeoeoeoeo+rqeoeoeqtes+tinc/es+tes+tes+tes+tes+tes+tintradoeqeqeqeoeoeoeoeoeoeoeoeqeoeoeqeo+tes+eo+
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 distancefieldtext.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/rendercaptive-QML' CD distancetext/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-native//usr/make+d3+tle/makeoutrqeout1
    ),不执行'dle+gitude783+rqeo+tintry+rqe+tintrue/makeqeout+tintry+rqeout+rqeout+rqeout+rqeout+rqeout+ting+t+rqeout+
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 mesh-morphing.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/r渲染-qML-to-t纹 理' CD mesh-oriting/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-root/native/rqemakeout1)并
    执行'tle/rqemakeout1 tle/rqeout1 /rqemakeout1测试。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animes/qblendedanimator' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 animation-keyframe-blendtree.pro qanimationcontroller.pro +gitAUTOINC+de5e7839d6-r0/build/intry/animations-medese-tle/rq5+rg/makeo+rqeo+t+rqeo+t/rqeo+r396+rqeo+t+rqeo+rqeo+tinc/makeo+t+rqeo+rqeo+t+rqeo+rqeo+tinc/makeo+t+rqeo+rqeo+tinc/mepoirt+t+t+t+t+tinc/r39+t+eo+eo+rq-makeo+eo+eo+eo+eo+eo+eo+rq-makeoirt+eo+t+eo+
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/r渲染-QML-至纹理-QML'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 anim-viewer.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/dynamic mode-loader-QML' CD anim-viewer/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gito+r77839dey+r+rnative-make+t+tes+tes+g/makeo+teo+teo+r1r1r1+t+rqeo+tintres+t/rqeo+tes+tes+tes+tes+teo+t/makeo+tes+teo+tes+teo+rq-makeo+tintres+teo+tes+teo+tes+teo+tintres+t/eo+tes+tes+tes+rq-makeo+tes+rq-makeo+tes+tes+teo+tintry+teo+teo+tes+r
    qclipblendvalue.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 animation-keyframe-programmatic.pro
    "第一"没有要做的事情。
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/buffercaptive-QML'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/anime-keyframe-simply'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 rendercapture-qml-fbo.pro +gitAUTOINC+de5e7839d6-r0/pege-native-usr/qt5/qmake -o make+gitude+eo+t/rqtide+eo+e+r786+g/makeo+t/rq-makeo+eo+rqtid/rq-makeo+tes+rq-makeo+eo+eo+t/rqt/rqtes+rq-makeo+t/rq-makeo+rq-makeo+r1eo+r396/rq-makeo+t/rq-makeo+tes+rq-makeo+t/rq-makeo+tes+rq-makeo+rq-makeo+t/rq-makeo+rq-
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qanimationgroup.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/mesh-morphing'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/AUTO-root-native//usr/bin/qt5/qmake -o make+gitude+e+e78396+g/make+tide+tes+t/rqeo+tes+eo+tintry+e+e+tes+tes+g/makeo+tes+tes+e+e+tes+e+tintry+tes+g/eq39+eo+tes+tes+eo+eo+eo+tes+eo+eo+tes+tes+tintres+eq-make+eo+e+eo+eo+tes+eo+eo+eo+eo+tes+tes+eo+eo+tintry+e7839+eq-makeo+
    distancefieldtext.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animation/qchannelmapper'
    CD qkeyframeanimation/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/pege-root-native/dqemakefile/rqeout1 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7) qkeyframeanimation.pro
    文件/makeout1 /rqemaked/rq3+tqemaked/rqeout1
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 assimp-cpp.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/video-t纹 理 QML' CD assilp-mp/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOCCP+de5e7839d6-r0/pege-sysroot-native/usr/manual/dq3+rgitefile/rqe+rqe+tinc),
    不进行任何测试。
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/anime-keyframe-blendtree' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 rendercapture-qml-fbo.pro paintedtexture-cpp.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/potedctrape-QML-f-bfoostepo+gted/make+gture/makeo+r396+rq+rqted/makeo+rq-makeo+rteo+r396+rq+rgtrue/rq-makeo+rq-makeo+rtureo+rq-rq-rq-rteo+rteo+r396+rq-rtureo+rq-mepo+rteo+rq-mepo+rq-rq-mepo+r39+rg/rtepo+ted/rq-rq-rtepo+rq
    qanimationgroup.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 anim-viewer.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    输入目录"/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animationcontroller"/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 animation-keyframe-programmatic.pro +gitAUTOINC+de5e7839d6-r0/pege-sysroot-native/usr/bin/qt5/make-o makefile /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitinc+d7839+de-tides+t/rgtranimationouts+r+r+g786+rg/ese-maked/es+tintry+tes+tes+rqtintres+rg/rg396/nativeout/ese-makeout/ese-tese-tintry+tintry+tintres+r+rq-maked/rq-makeouts+tines+tintres+tintres+tines+tines+tintres+tintres+r396/nativeout/es+tes+tintres+rq-intres+tines+tines+tes+r
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/animina-keyframe-simply'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/mesh-morphing'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 paintedtexture-cpp.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 rendercapture-cpp.pro +gitAUTOINC+de5e7839d6-r0/build/tedtedcppmed+gitude+ture/make+eo+eo+eo+eo+tid/rq396+rqeo+true/rtry+r1o+g/rqeo+trendo+true/r39+r1o+g/rqeoprinc/es+r1o+r39+g/r1o+g/rq-makeo+rtry+r1o+r1o+g/r5g/eo+r39+rtrue/rtry+rtrue/eo+rq-makeo+r39+rtrue/eo+rtrue/r1opruepcppmepcppmepcppmepcp /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    qkeyframeanimation.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qmorphinganimation.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animing/qclipmp blendvalu' CD qmorphinganiments/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 assimp-cpp.pro +gitAUTOCCP+de5e+r7839de-intry/m原本 地/makeo+eo+eo+eo+tintry+eo+eo+eo+eo+tinc/makeo+eo+eo+eo+eq396/eo+eo+eoprinc/makeo+eo+eo+eo+eo+t+eo+eo+e+eo+eq396/eoprinc/maked+t+eo+eo+t+e+t+eo+t+eo+t+eqt+eo+eo+eo+eo+eo+eo+eo+eo+tintrinc/r39+eo+t+e+e
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qvertexblendanimation.pro
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qmorphtarget.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/distancefieldtext' CD qvertexblendanimation/&&(test -e Makefile ||/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+e7839de-make+t/makeoute+g/makeoeoeo+texeo+eo+eo+eqtintrue/makeo+eo+eo+eq396/eoeoeoeoeoeo+eqeo+tintranime+e+e+eqt+eqeo+eo+eo+eqtinc/es+eqeqeo+eo+eo+tintrintraneqeq-maked/eo+eo+eo+eo+eqeo+eo+eo+eo+eqeqeo+eo+eo+eqeqtintraneqeo+eo+
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/anim-viewer'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animationgroup' make[3]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 rendercapture-cpp.pro +gitAUTOINC+de5e7839d6-r0/build/tests/manual/rendercapture-cpp'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d3+emake+r5eo/rq396/rqeoutnative /r1rqe786/rqeured/r1rq-makeoutr1r1r1r+g/r1rq-rq-rq-r1r1r+git/rq-makeo+g/r396/rq-rq-rq-makeoprudo]+g/
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/animation-keyframe-Programmed'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animationcontrollers' make[4]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qmorphtarget.pro +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animation/qanimationcontrollers'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+d396/de-make+g3+native/rqeoirtintrue/rq396/rq-makeo/setrq396/rq-nativeout1
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/rendercaptive-QML-FBO'
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/assilmp-cpp' make[4]:进入目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 qmorphinganimation.pro /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animing/qemake+gito+tintry+eo+eo+r786/nativeo+te+tintratego+tinc/es+r396/rqeintranimintraniminc/es+rq5+eo+r786/rqeo+rqeo+tinc/es+tintraniminc/es+r396/rq-makeo+eo+eo+eo+r396/rq-makeo+tintraniminc/r396/rq-makeo+eo+eo+eo+eo+r396/rq-makeo+eo+r396/rqeo+tinc/r396/eo+e qvertexblendanimation.pro
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/painted纹 理-cpp'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual/rendercapt捕捉-cp'
    make[2]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/manual'
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animation/qkeyframeanimation'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/sce2d'
    使'none for 'mone to 'first tone to mone.'。[4]
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animation/q吗 目标'
    make[4]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animina/qvertexblendanimation'
    make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/simpleccesomemateri'
    无需执行任何操作。[4]
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animing/qmorphinganimation' make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/tests/auto/animation' make'd3+gitude+make'd396+rmake'd+dleedintrese's'sub directory's'dle+make'd786+dle+make's'dle'dleedintres'sedintres's'sedintreseedintres's'sedes'sedese7396+g3eedinuedeseedintres'+dingedintres's's's'dingedinuedinuedinuedes'+r396+dingedintreseedinuedes'+r396+d_make7396+d_sleedes
    链接小工具-scape3d
    链接 basictages-cpp
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/build/examples/qt3d/basictages-cpp' make[3]:离开目录'/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7
    /home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitefile.inc+de5e7839d6-r0/build+t3d+q3d+d+d+d+make3d_de3d+e3d+emake3d+eq3d+d+d+emakeq3d+e3d_make3d+d+d_make3d_make3d+d+eed+eq3d_make3d_make3d+d+e3d_make3d_make3d_make3d+d+eed+e3d_makeqeed+eed+eq3d+eq3d+t3d+d+e3d_makeq3d_make3d_makeines+e
    OE_runmake 失败
    警告:/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/temp/run.do_compile.20445:1从'exit 1'退出1
    错误:函数失败:do_compile (日志文件位于/home/prateekkhatri/proc-sdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/aarch64-linux/qt3d/5.9.7 +gitAUTOINC+de5e7839d6-r0/temp/log.do_compile.20445)
    是否可以发布 free -h 命令的输出?
    prateekhatri@PC-10307:~$ FREE -h
    共计 已使用 免费 共享缓冲区/高速缓存可用
    存储器: 62克 3.3G 519万 375M 59政 58G
    交换: 975M 0b 975M
    pratekkhatri@PC-10307:~美元
    Prateek、您好!
    请尝试使用下面的命令清理编译、并在不使用-k 标志的情况下重建软件包、因为这会使事情变得更加复杂。
    machine=am65xx-evm bitbake qtbase qt3d -c cleinstate
    Kemal
    您好、Kemal、
    我已从单独的目录中从零开始删除所有文件并下载(克隆)所有文件、然后运行"machine=am65xx-evm bitbake qt3d"。
    刚刚构建 qt3d 似乎成功。 然后、我使用"machine=am65xx-evm bitbake Arago-base-tisdk-image"和"machine=am65xx-evm bitbake -k Arago-core-tisdk-image"成功完成所有任务。
    不确定导致初始错误的原因是什么。
    感谢你的帮助。
    Prateek
    初始错误是由于缺少 RAM 内存而导致的。 即使您在使用 J12构建12个任务时拥有62g RAM、qtbase chromium-wayland 等两个繁重的编译任务也可能并行构建、甚至超过62g RAM。
    感谢您的深入见解。
