[参考译文] AM3358:SDK 构建问题
Guru**** 2893620 points
Other Parts Discussed in Thread: AM3358
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/659899/am3358-sdk-build-issues
主题中讨论的其他器件:AM3358
尊敬的 TI 支持团队:
我正在尝试根据 processors.wiki.ti.com/.../Processor_SDK_Building_The_SDK 上的说明为 AM335x 入门套件板构建处理器 SDK
我的 Linux 主机是 Ubuntu 16.04。
我的步骤如下:
1、安装 SDK ti-processor-sdk-linux-am335x-evm-04.02.00.09-Linux-x86-Install.bin
2、构建步骤
$ git 克隆 git://arago-project.org/git/projects/oe-layersetup.git tisdk
$ cd tisdk
$./oe-layertool-setup.sh -f configs/processor-sdk/processor-sdk-04.02.00.09-config.txt
$ CD 生成
$。 配置/设置
$导出路径=$HOME/gcc-linaro-6.2.1-2016.11-x86_64 arm-linux-gnueabihf/bin:$path
$ MACHINE=AM335x-EVM bitbake Arago-core-tisdk-image
我的回答失败、如下所示:
错误:linux-libc-headers-4.9-r0.arago2 do_fetch:fetcher 故障:获取命令 export DBUS_Session_bus_address="UNIX:abstract=/tmp/dbus-hVPRX9iF7f;导出 SSH_AUTH_SOCSOC="/run/user/1000/keyring/ssh;导出路径="/home/vial/tisdk/sources/oe-core/scripts:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am335x-evm/usr/bin/crossscripts /home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/oe-core/scripts /home/vial/tisdk/sources/meta-browser/scripts /home/vial/tisdk/sources/bitbake/bin /usr/local/sbin /usr/bin /snap/bin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/meta-ros/scripts /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/oe-core/scripts /home/vial/.local/bin /usr/sbin /usr/local/games /git.ti.com/ti-linux-kernel/ti-linux-kernel.git /home/vial/tisdk/downloads/git2/git.ti.com.ti-linux-kernel.ti-linux-kernel.git:/home/vial/tisdk/sources/meta-browser/scripts:/home/vial/tisdk/sources/bitbake/bin:/home/vial/tisdk/sources/meta-ros/scripts /home/vial/bin /usr/local/bin /usr/games /home/vial:bare.com
正在克隆到裸存储库'/home/vial/tisdk/downloads/git2/git.ti.com.ti-linux-kernel.ti-linux-kernel.git……
致命:无法连接到 git.ti.com:
git.ti.com[0: 198.47.28.207]:errno=连接超时
错误:linux-libc-headers-4.9-r0.arago2 do _fetch:获取 URL 的 fetcher 故障:'Git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol=git;branch=ti-lsk-linux-4.9.y'。 无法从任何源获取 URL。
错误:linux-libc-headers-4.9-r0.arago2 DO 获取:函数失败:base_do 获取
错误:故障日志文件存储在:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/linux-libc-headers/4.9-r0.arago2/temp/log.do_fetch.30468中
错误:任务(/home/vial/tisdk/sources/meta-arago/meta-arago-distro/recipes-kernel/linux-libc-headers/linux-libc-headers_4.9.bb:DO 获取)失败、退出代码为"1"
3、我在 E2E 中搜索、发现其他人在链接 e2e.ti.com/.../2248821上发布了类似的问题。
然后、我从 SDK 版本下载了源软件包的快照、并在下面输入命令。
下载 xvf /home/vial μ C/AM335x-EVM-Linux-SDK-Arago-src-04.02.00.09.tar.xz
$AM335x-EVM-Linux-SDK-Arago-src-04.02.00.09/get_build_sources.sh AM335x-EVM-Linux-SDK-Arago-src-04.02.00.09/source_pkg_list.txt
一整晚后、上述操作成功完成。
4、再次重复构建
$ CD 生成
$。 配置/设置
但最后、我仍然遇到相同的错误:
小瓶@小瓶-Latitude-E7440:~/tisdk/build machine=am335x-evm bitbake Arago-core-tisdk-image
正在加载高速缓存:100%|################################ |时间:0:00:01
已从依赖关系缓存加载3797个条目。
解析配方:100%|############################ |时间:0:00:01
解析3033 .bb 文件完成(3030个缓存、3个已解析)。 3800个目标、571个跳过、0个屏蔽、0个错误。
警告:没有适用于以下各项的配方:
/home/vial/tisdk/sources/meta-openamp/recipes-bsp/device-tree/device-tree-generation_。bbappend
注:解决任何缺失的任务队列相关性
编译配置:
Bb_version ="1.32.0"
Build_SYS ="x86_64 Linux 版"
NATIVELSBSTRING ="Uubuntu-16.04"
Target_SYS ="ARM-Linux-gnueabi"
机器="AM335x-EVM"
DIASTRO ="Arago"
DISTR_VERSION ="2017.10"
TUNE_FUNCures ="arm armv7a VFP thumb neon callconvention-hard "
TARGET_FPU ="硬"
meta-processor-sdk ="标题:eaac6026857bc56bf89625df93935a272b63341"
meta-ROS ="头:e01c6ace0d4f9d700449edad3781e9cd505b5e10"
meta-arago-distro
meta-Arago-Extras ="标题:d34c861f846f35d089e1cafec43079be7b202"
meta 浏览器="标题:26d50665e2f7223c5f4ad7481a8d2431e7cb55fb"
meta-openamp ="标题:8a214032bfb7e8124bc1485c70c69f7d60abb819"
meta-qt5 ="头:2c9f0e4eb0e9097f6f872ec1e1d81768a8ab5f1b"
元网络
meta ruby
Meta-python
Meta-OE
元- gnome
meta-multimedia ="标题:b40116cf457b88a2db14b86fda9627fb34d56ae6"
meta-ti ="头:351ccf1928a18c2b69fd19b09b980c9aa3af2e26"
meta-linaro-toolchain
meta-optee ="标题:5d2cb685217794293ea2bab18d7e62019c329d06"
meta ="标题:1718f0a6c1de9c23660a9bebfd4420e3c4ed37e6"
正在初始化任务:100%|########################## |时间:0:00:18
注:执行 SetScene 任务
注:执行 RunQueue 任务
警告:linux-libc-headers-4.9-r0.arago2 do _fetch:无法获取 URL git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol=git;branch=ti-lsK-linux-4.9.y、尝试镜像(如果可用)
警告:nativesdk-linux-libc-headers-4.9-r0.arago2 do_fetch:无法获取 URL git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol=git;branch=ti-lsK-linux-4.9.y、如果可用、则尝试镜像
错误:nativesdk-linux-libc-headers-4.9-r0.arago2 do_fetch:fetcher 失败:获取命令 export DBUS_Session_bus_address="UNIX:abstract=/tmp/dbus-hVPRX9iF7f;导出 SSH_AULANG_SOCK_d="/run/user/1000/keyring/ssh /home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/x86_64-arago-linux /home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/meta-ros/scripts /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/oe-core/scripts /home/vial/.local/bin /usr/sbin /usr/local/games /git.ti.com/ti-linux-kernel/ti-linux-kernel.git /home/vial/tisdk/downloads/git2/git.ti.com.ti-linux-kernel.ti-linux-kernel.git;导出路径="/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/chrpath-native:/home/vial/tisdk/sources/oe-core/scripts:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-nativesdk-arago-linux/tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/bin/crossscripts:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin /home/vial/tisdk/sources/meta-browser/scripts /home/vial/tisdk/sources/bitbake/bin /home/vial/tisdk/sources/meta-ros/scripts /home/vial/bin /usr/local/bin /usr/games /home/vial /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:/home/vial/tisdk/sources/oe-core/scripts:/home/vial/tisdk/sources/meta-browser/scripts:/home/vial/tisdk/sources/bitbake/bin /usr/local/sbin /usr/bin /snap/bin
错误:nativesdk-linux-libc-headers-4.9-r0.arago2 do_fetch:URL 的 fetcher 故障:'Git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol = git;branch=ti-lsk-linux-4.9.y'。 无法从任何源获取 URL。
错误:nativesdk-linux-libc-headers-4.9-r0.arago2 do_fetch:函数失败:base_do_fetch
错误:故障日志文件存储在:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-nativesdk-arago-linux/nativesdk-linux-libc-headers/4.9-r0.arago2/temp/log.do_fetch.30471中
错误:任务(虚拟:nativesdk:/home/vial/tisdk/sources/meta-arago/meta-arago-distro/recipes-kernel/linux-libc-headers/linux-libc-headers_4.9.bb:do_fetch)失败、退出代码为"1"
警告:pcitest-4.9-r0 DO 获取:无法获取 URL git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;协议=git;分支=ti-lsk-linux-4.9.y、如果可用、则尝试镜像
错误:pcitest-4.9-r0 do_fetch:fetcher 失败:获取命令 export DBUS_Session_bus_address="UNIX:abstract=/tmp/dbus-hVPRX9iF7f;导出 SSH_AUTH_SOCK_="/run/user/1000/keyring/ssh;导出路径:/home/vial/tisdk/sources/oe-core/scripts:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am335x-evm/usr/bin/crossscripts /home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/oe-core/scripts /home/vial/tisdk/sources/meta-browser/scripts /home/vial/tisdk/sources/bitbake/bin /usr/local/sbin /usr/bin /snap/bin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/vial/tisdk/sources/meta-browser/scripts:/home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:/home/vial/tisdk/sources/meta-ros/scripts:/home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:/home/vial/tisdk/sources/oe-core/scripts /home/vial/.local/bin /usr/sbin /usr/local/games /git.ti.com/ti-linux-kernel/ti-linux-kernel.git /home/vial/tisdk/downloads/git2/git.ti.com.ti-linux-kernel.ti-linux-kernel.git:bare.com:/home/vial/tisdk/sources/bitbake/bin /home/vial/tisdk/sources/meta-ros/scripts /home/vial/bin /usr/local/bin /usr/games /home/vial
git.ti.com[0: 198.47.28.208]:errno=连接超时
错误:pcitest-4.9-r0 DO 获取:URL 的 fetcher 失败:'Git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol = git;branch=ti-lsk-linux-4.9.y'。 无法从任何源获取 URL。
错误:pcitest-4.9-r0 DO 获取:函数失败:base_do 获取
错误:故障日志文件存储在:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcitest/4.9-r0/temp/log.do_fetch.30472中
错误:任务(/home/vial/tisdk/sources/meta-arago/meta-arago-extras/recipes-kernel/pcitest/pcitest_4.9.bb:DO 获取)失败、退出代码为"1"
注:任务摘要:已尝试4413个任务,其中3822不需要重新运行,3个任务失败。
摘要:3个任务失败:
摘要:显示了4条警告消息。
摘要:显示了9条错误消息、返回非零退出代码。
接下来该怎么办?
William
    您好、William、
    是否可以发布此命令的输出?
    $ git clone git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;协议=git;分支=ti-lsk-linux-4.9.y
    Kemal
    您好、Kemal、
    非常感谢您的快速响应!
    下面是对上述命令的响应。 我的 git.ti.com 净速度太慢。 我可以看到它正在获取内核。
    小瓶@小瓶-Latitude-E7440:~$ git clone git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol=git;branch=ti-lsK-linux-4.9.y
    正克隆到"ti-linux-kernel"...
    远程:计数对象:7603671,完成。
    远程:压缩对象:100%(1067723/1067723)、完成。
    接收对象中:0%(15318/7603671)、8.57 MIB | 10.00 KiB/s
    最棒的
    William
    现在可以发布此命令的输出吗?
    MACHINE=AM335x-EVM bitbake ptest -c DO 获取
    一整晚后、获取内核命令最终失败。
    远程:计数对象:7603671,完成。
    致命:读取错误:连接超时03671)、93.82 MIB | 23.00 KiB/s
    致命:过早的文件结束符(EOF)
    致命:索引包失败
    您好、Kemal、
    此命令还会响应故障。
    小瓶@小瓶-Latitude-E7440:~/tisdk/build machine=am335x-evm bitbake pcitest -c do_fetch
    已从依赖关系缓存加载3797个条目。
    警告:没有适用于以下各项的配方:
    注:解决任何缺失的任务队列相关性
    编译配置:
    BBB_VERSION ="1.32.0"
    BUIL_SYS ="x86_64 Linux 版"
    Target_SYS ="arm-linux-gnueabi"
    机器 ="AM335x-EVM"
    发行版 ="阿拉戈"
    TUNE_FUNCures ="arm armv7a VFP thumb NEON 难以规避"
    Target_FPU ="硬"
    Meta-ROS ="标题:e01c6ace0d4f9d700449edad3781e9cd505b5e10"
    meta-arago-distro
    元浏览器 ="标题:26d50665e2f7223c5f4ad7481a8d2431e7cb55fb"
    元运算放大器 ="标题:8a214032bfb7e8124bc1485c70c69f7d60abb819"
    meta-qt5. ="标题:2c9f0e4eb0e9097f6f872ec1e1d81768a8ab5f1b"
    元网络
    meta ruby
    Meta-python
    Meta-OE
    元- gnome
    meta-ti ="标题:351ccf1928a18c2b69fd19b09b980c9aa3af2e26"
    元-选项 ="标题:5d2cb685217794293ea2bab18d7e62019c329d06"
    元数据 ="标题:1718f0a6c1de9c23660a9bebfd4420e3c4ed37e6"
    正在初始化任务:100%|########################## |时间:0:00:00
    注:执行 RunQueue 任务
    错误:pcitest-4.9-r0 do_fetch:fetcher 失败:获取命令导出 DBUS_Session_bus_address="UNIX:abstract=/tmp/dbus-hVPRX9iF7f;导出 SSH_AUTH_SOCK_="/run/user/1000/keyring/ssh /home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am335x-evm/usr/bin/crossscripts /home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/oe-core/scripts /home/vial/tisdk/sources/meta-browser/scripts /home/vial/tisdk/sources/bitbake/bin /home/vial/tisdk/sources/meta-ros/scripts /home/vial/bin /usr/local/bin /usr/games /home/vial;导出路径:/home/vial/tisdk/sources/oe-core/scripts:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/vial/tisdk/sources/meta-browser/scripts:/home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:/home/vial/tisdk/sources/meta-ros/scripts:/home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:/home/vial/tisdk/sources/bitbake/bin:/home/vial/tisdk/sources/oe-core/scripts:/home/vial/tisdk/sources/meta-ros/scripts /home/vial/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/vial/tisdk/sources/oe-core/scripts /home/vial/.local/bin /usr/sbin /usr/local/games /git.ti.com/ti-linux-kernel/ti-linux-kernel.git /home/vial/tisdk/downloads/git2/git.ti.com.ti-linux-kernel.ti-linux-kernel.git:/home/vial/tisdk/sources/meta-browser/scripts /home/vial/tisdk/sources/bitbake/bin /usr/local/sbin /usr/bin /snap/bin:bare.com
    远程:计数对象:7603744、完成。
    远程:压缩对象:100%(1067781/1067781),完成。
    致命:远程端意外挂起1.44 GiB | 19.00 KiB/s
    致命:EOF 早期
    致命:索引包失败
    错误:故障日志文件存储在:/home/vial/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/pcitest/4.9-r0/temp/log.do_fetch.10021中
    注:任务摘要:已尝试1个任务、其中0不需要重新运行、1个任务失败。
    摘要:1个任务失败:
    摘要:显示了2条警告消息。
    摘要:显示了3条错误消息、返回非零退出代码。
    您能否发布这两条命令的输出?
    $免费-h
    $ df -h
    小瓶@小瓶-Latitude-E7440:~/tisdk/build 免费-h
    共计 已使用 免费 共享缓存/缓存可用
    内存: 7.7G 1.7G 2.3G 389M 3.7G 5.3G
    交换: 7.9G 0b 7.9G
    小瓶@小瓶-Latitude-E7440:~/tisdk/build df -h
    文件系统 μ A 容量已用可用已用%挂载点
    udev 3.9G 0 3.9G 0%/dev/dev
    tmpfs 789M 18M 771M 3%/run
    /dev/mapper/ubuntu--vg-root 227G 72G 144g 34%/
    tmpfs 3.9G 20M 3.9G 1%/dev/shm
    tmpfs 5.0m 4.0K 5.0m 1%/run/lock
    tmpfs 3.9G 0 3.9G 0%/sys/fs/cgroup
    /dev/sda1 472M 125m 324M 28%/boot
    tmpfs 789M 96K 789M 1%/run/user/1000
    /dev/mmcblk0p1 15g 9.2G 5.8G 62%/media/vial/FA9F-31D6
    还可以附加 dmesg 命令的输出吗? 检查一下 Git 是否被“房间杀手”杀死。
    请参阅以下日志。
    小瓶@小瓶-Latitude-E7440:~$ dmesg
    [0.000000]微码:将微码提前更新为版本0x20、日期= 2017-01-27
    [0.000000]随机:从 start_kernel+0x42/0x504调用 get_random_bytes、crng_init=0
    [0.000000] Linux 版本4.13.0-32-generic (buildd@lgw01-AMDD-004)(gcc 版本5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.5))#35~16.04.1-Ubuntu SMP Thu Jan 25 10:13:43 UTC (Ubuntu 4.13.0-2018~04.13通用)
    [0.000000]命令行:boot_image=/vmlinuz-4.13.0-32-generic root=/dev/mapper/ubuntu--vg-root ro quiet splash VT.handoff=7
    [0.000000]内核支持的 CPU:
    [0.000000]英特尔 GenineIntel
    [0.000000] AMD AuthenticAMD
    [0.0000]Centaur CentaurHauls
    [0.000000] x86/FPU:支持 XSAVE 功能0x001:'x87浮点寄存器'
    [0.000000] x86/FPU:支持 XSAVE 功能0x002:'SSE 寄存器'
    [0.000000] x86/FPU:支持 XSAVE 功能0x004:'AVX 寄存器'
    [0.000000] x86/FPU:xstate_offset[2]:576、xstate_sizes[2]:256
    [0.000000] x86/FPU:启用 xstate 功能0x7、上下文大小为832字节、使用"标准"格式。
    [0.000000] e820:BIOS 提供的物理 RAM 映射:
    [0.000000] BIOS-e820:可用的[MEM 0x0000000000000000000000000000 - 0x0000000913ff]
    [0.000000] BIOS-e820:[MEM 0x000000091400-0x00000009FFF]保留
    [0.000000] BIOS-e820:[MEM 0x0000000e0000-0x0000000fff]保留
    [0.000000] BIOS-e820:可用的[MEM 0x0000000000100000-0x00000000cf63dfff]
    [0.000000] BIOS-e820:[MEM 0x0000cf63e000-0x0000CF644fff] ACPI NVS
    [0.000000] BIOS-e820:[MEM 0x0000CF645000-0x00000000D0275fff]可用
    [0.000000] BIOS-e820:[MEM 0x00000000D0276000-0x00000000D0751fff]保留
    [0.000000] BIOS-e820:[MEM 0x00000000D0752000-0x00000000D7db3fff]可用
    [0.000000] BIOS-e820:[MEM 0x00000000D7db4000-0x00000000D7ffFFF]保留
    [0.000000] BIOS-e820:可用的[MEM 0x00000000D80000-0x00000000D8758fff]
    [0.000000] BIOS-e820:[MEM 0x00000000D8759000-0x00000000D87fff]保留
    [0.000000] BIOS-e820:[MEM 0x00000000d8800000-0x0000d8fa9fff]可用
    [0.000000] BIOS-e820:[MEM 0x00000000d8faa000-0x00000000D8ffFFF] ACPI 数据
    [0.000000] BIOS-e820:可用的[MEM 0x00000000D90000-0x0000000DA71bfff]
    [0.000000] BIOS-e820:[MEM 0x00000000da71c000-0x00000000da7fff] ACPI NVS
    [0.000000] BIOS-e820:[MEM 0x00000000da800000-0x00000000DBCF3fff]可用
    [0.000000] BIOS-e820:[MEM 0x00000000DBCF4000-0x00000000DBFFFFF]保留
    [0.000000] BIOS-e820:[MEM 0x00000000dd000000-0x00000000Df1fff]保留
    [0.000000] BIOS-e820:[MEM 0x00000000f8000000-0x00000000fbffFFF]保留
    [0.000000] BIOS-e820:[MEM 0x00000001 00000-0x00000000 00fff]保留
    [0.000000] BIOS-e820:[MEM 0x0000fed00000-0x0000fed03fff]保留
    [0.000000] BIOS-e820:[MEM 0x0000fed1c000-0x0000fed1FFF]保留
    [0.000000] BIOS-e820:[MEM 0x00000000fee00000-0x00000000fee00ff]保留
    [0.000000] BIOS-e820:[MEM 0x00000000ff0000-0x0000ffFFF]保留
    [0.000000] BIOS-e820:可用的[MEM 0x00000001000000-0x000000021edfff]
    [0.000000] NX (执行禁用)保护:活动
    [0.000000]随机:快速初始化完成
    [0.000000] SMBIOS 2.7存在。
    [0.000000] DMI:Dell Inc. Latitude E7440/03HFCG、BIOS A11 08/28/2014
    [0.000000] TSC:使用 PIT 快速校准 TSC
    [0.000000] e820:更新[mem 0x00000000 0x00000fff]可用=>保留
    [0.000000] e820:删除可用的[mem 0x000a0000-0x000fff]
    [0.000000] e820:LAST_PFN = 0x21e00 max_ar_PFN = 0x400000000
    [0.000000] MTRR 默认类型:不可分离
    [0.000000]启用了 MSRR 固定范围:
    [0.000000] 00000-9FFFF 回写
    [0.000000] A0000-BFFFF 不可分离
    [0.000000] C0000-DBFFF 写保护
    [0.000000] DC000-E7FFF 不可缓存
    [0.000000] E8000-FFFFF 写保护
    [0.000000]启用了 MSRR 变量范围:
    [0.000000] 0 base 0000000000掩码7E00000000回写
    [0.000000] 1 base 0200000000掩码7FE0000000回写
    [0.000000] 2 base 00E0000000 mask 7FE0000000 unachable
    [0.000000] 3 base 00DE000000 mask 7FFE000000不可缓存
    [0.000000] 4 base 00DD000000 mask 7FFF000000不可缓存
    [0.000000] 5 base 021F000000 mask 7FFF000000不可缓存
    [0.000000] 6 base 021EE00000 mask 7FFFE00000 unachable
    [0.000000] 7已禁用
    [0.000000] 8已禁用
    [0.000000] 9已禁用
    [0.000000] x86/PAT:配置[0-7]:WB WC uC-UC WB WC uC-WT
    [0.000000]涵盖的 RAM 总数:8126M
    [0.000000]找到 mtrr 清理的最佳设置
    [0.000000] gran_size:64Kchunch_size:64Mnum_reg:9lose cover RAM:0g
    [0.000000] e820:更新[mem 0xdd000000-0xffFFF]可用=>保留
    [0.000000] e820:LAST_PFN = 0xdbcf4 max_ar_PFN = 0x400000000
    [0.000000]在[ff907b800fd980]映射到[ff907b800fd980]的[mem 0x000fd980-0x000fd98f]找到 SMP MP 表
    [0.000000]扫描1个区域以降低内存损坏
    [0.000000]基本存储器 trampoline、大小为[ff907b8008b000] 8b000、大小为24576
    [0.000000]使用 GB 页面进行直接映射
    [0.000000] BRK [0x1cf12a000、0x1cf12afff] PGTABLE
    [0.000000] BRK [0x1cf12b000、0x1cf12bfff] PGTABLE
    [0.000000] BRK [0x1cf12c000、0x1cf12cfff] PGTABLE
    [0.000000] BRK [0x1cf12d000、0x1cf12dfff] PGTABLE
    [0.000000] BRK [0x1cf12e000、0x1cf12efff] PGTABLE
    [0.000000] BRK [0x1cf12f000、0x1cf12FFF] PGTABLE
    [0.000000] BRK [0x1cf130000、0x1cf130fff] PGTABLE
    [0.000000] BRK [0x1cf131000、0x1cf131fff] PGTABLE
    [0.000000] BRK [0x1cf132000、0x1cf132fff] PGTABLE
    [0.000000] BRK [0x1cf133000、0x1cf133cffff] PGTABLE
    [0.000000] BRK [0x1cf134000、0x1cf134fff] PGTABLE
    [0.000000] BRK [0x1cf135000、0x1cf135fff] PGTABLE
    [0.000000] RAMDISK:[MEM 0x31fc0000-0x34fd7fff]
    [0.000000] ACPI:禁用早期检查床校验和验证
    [0.000000] ACPI:RSDP 0x0000000EEE40 000024 (v02 Dell)
    [0.000000] ACPI:XSDT 0x00000000D8FEB088 00008C (v01 Dell CBX3 01072009 AMI 00010013)
    [0.000000] ACPI:FACP 0x00000000D8FFCA40 00010C (V05 Dell CBX3) 01072009 AMI 00010013)
    [0.000000] ACPI:DSDT 0x00000000D8FEB1A0 01189F (v02 Dell CBX3 00000014 INTL 20120711)
    [0.000000] ACPI:FACS 0x00000000DA7FE080 000040
    [0.000000] ACPI:APIC 0x00000000D8FFCB50 000072 (v03 Dell CBX3 01072009 AMI 00010013)
    [0.000000] ACPI:FPDT 0x00000000D8FFC8 000044 (v01 Dell CBX3 01072009 AMI 00010013)
    [0.000000] ACPI:SLIC 0x00000000D8FFCC10 000176 (v03 Dell CBX3 01072009 MSFT 00010013)
    [0.000000] ACPI:LPIT 0x00000000D8FFCD88 00005C (v01 Dell CBX3 00000000 AMI。 00000005)
    [0.000000] ACPI:SSDT 0x00000000D8FFCDE8 000228 (v01 Intel sensrhub 00000000 INTL 20120711)
    [0.000000] ACPI:SSDT 0x00000000D8FFD010 00051F (v01 PmRef Cpu0Ist 00003000 INTL 20120711)
    [0.000000] ACPI:SSDT 0x00000000D8FFD530 000AD8 (v01 PmRef CpuPm 00003000 INTL 20120711)
    [0.000000] ACPI:HPET 0x00000000D8FFE008 000038 (v01 Dell CBX3 01072009 AMI。 00000005)
    [0.000000] ACPI:SSDT 0x00000000D8FFE040 000455 (v01 SataRe SataTabl 00001000 INTL 20120711)
    [0.000000] ACPI:MCFG 0x00000000D8FFE498 00003C (v01 Dell CBX3 01072009 MSFT 00000097)
    [0.000000] ACPI:ASF! 0x0000D8FFE4D88 0000A5 (v32 Intel HCG 00000001 TFSM 000F4240)
    [0.000000] ACPI:DMAR 0x00000000D8FFE580 0000B0 (v01 Intel HSW 00000001 INTL 00000001)
    [0.000000] ACPI:本地 APIC 地址0xfee00000
    [0.000000]未找到 NUMA 配置
    [0.000000]在[mem 0x0000000000000000000000000000 0x000000021edfff]建立节点
    [0.000000] node_data (0)已分配[mem 0x21edd3000-0x21edfdfff]
    [0.000000]区域范围:
    [0.000000] DMA [MEM 0x00000000000000001000-0x0000000000ffFFF]
    [0.000000] dma32 [mem 0x0000000001000000-0x00000000 ffFFF]
    [0.000000]正常[mem 0x00000001000000-0x000000021edfff]
    [0.000000]器件为空
    [0.000000]每个节点的可移动区域开始
    [0.000000]早期存储器节点范围
    [0.000000]节点0:[MEM 0x000000000000000000001000-0x000000090fff]
    [0.000000]节点0:[MEM 0x0000000000100000-0x000000cf63dfff]
    [0.000000]节点0:[MEM 0x0000CF645000-0x00000000D0275fff]
    [0.000000]节点0:[MEM 0x00000000D0752000-0x00000000D7db3fff]
    [0.000000]节点0:[MEM 0x00000000D8000000-0x00000000D8758fff]
    [0.000000]节点0:[MEM 0x00000000d8800000-0x0000d8fa9fff]
    [0.000000]节点0:[MEM 0x00000000D90000-0x0000000da71bfff]
    [0.000000]节点0:[MEM 0x00000000da800000-0x00000000DBCF3fff]
    [0.000000]节点0:[MEM 0x00000001000000-0x000000021edfff]
    [0.000000] Initmem 设置节点0 [mem 0x000000000000000000001000-0x000000021edfff]
    [0.000000]在节点0上的总页:2072948
    [0.000000] DMA 区域:用于 memmap 的64页
    [0.000000] DMA 区域:保留21页
    [0.000000] DMA 区域:3984页、LIFO 批处理:0
    [0.000000] dma32区域:用于 memmap 的13968页
    [0.000000] dma32区域:893924页、LIFO 批处理:31
    [0.000000]正常区域:用于 memmap 的18360页
    [0.000000]正常区域:1175040页、LIFO 批处理:31
    [0.000000]将英特尔图形内存保留为0x00000000dd200000-0x00000000df1fff
    [0.000000] ACPI:PM-Timer IO 端口:0x1808
    [0.000000] ACPI:LAPIC_NMI (ACPI_ID[0xff]高边缘 lint[0x1])
    [0.000000] IOAPIC[0]:APIC_id 8、版本32、地址0xfec00000、GSI 0-39
    [0.000000] ACPI:INT_SRC_OVR (总线0 BUS_IRQ 0 GLOBAL_IRQ 2 dfl dfl)
    [0.000000] ACPI:INT_SRC_OVR (总线0 BUS_IRQ 9 GLOBAL_IRQ 9高电平)
    [0.000000] ACPI:覆盖使用的 IRQ0。
    [0.000000] ACPI:覆盖所使用的 IRQ9。
    [0.000000]使用 ACPI (MADT)获取 SMP 配置信息
    [0.000000] ACPI:HPET ID:0x8086a701基地址:0xfed00000
    [0.000000] smpboot:允许4个 CPU、0个热插拔 CPU
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0x00000000 0x00000fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0x00091000-0x00091fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0x00092000-0x0009FFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0x000a0000-0x000dFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0x000e0000-0x000fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xcf63e000-0xcf644fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xd0276000-0xd0751fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xd7db4000-0xd7ffFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xd8759000-0xd87fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xd8faa000-0xd8ffFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xda71c000-0xda7fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xdbcf4000-0xdbffFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xdc000000-0xdcffFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xdd000000-0xdf1fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xdf200000-0xf7ffFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xf80000-0xfbffFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfc000000-0xfebfff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfec00000-0xfec00fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfec01000-0xfecfffff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfed00000-0xfed03fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfed040-0xfed1bfff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfed1c000-0xfed1FFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfed20000-0xfedfff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfee00000-0xfee00fff]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0xfee01000-0xfeffFFF]
    [0.000000] PM:寄存式 nosave 存储器:[MEM 0x000000-0xFFFFF]
    [0.000000] e820:[MEM 0xdf200000-0xf7ffFFF]可用于 PCI 设备
    [0.000000]在裸硬件上引导半虚拟化内核
    [0.000000]时钟源:优化的 Jiffies:MASK:0xFFFFFFFF max_cycles:0xFFFFFFFF、max_idle_ns:7645519600211568ns
    [0.000000] setup_perpu:nr_cpus:8192 nr_cpumask_bits:4 nr_cpu_ID:4 nr_node_ID:1
    [0.000000] perpu:嵌入式45页/CPU @ffff907d9ea00000 s146520 r8192 d29608 u524288
    [0.000000] pcpu-alloc:s146520 r8192 d29608 u524288 alloc=1*2097152
    [0.000000] pcpu-alloc:[0] 1 2 3.
    [0.000000]在节点顺序和移动分组中构建了1个区域列表。 总页数:2040535
    [0.000000]策略区域:正常
    [0.000000]内核命令行:boot_image=/vmlinuz-4.13.0-32-generic root=/dev/mapper/ubuntu--vg-root ro quiet splash VT.handoff=7
    [0.000000] PID 哈希表条目:4096 (顺序:3、32768字节)
    [0.000000]卡尔加里:通过 BIOS EBDA 区域检测卡尔加里
    [0.0000]卡尔加里:无法在 EBDA 找到 Rio Grande 桌位-帆船!
    [0.000000]内存:8018612K/8291792K 可用(12300K 内核代码、2481K RWdata、4004K rodata、2364K init、2368K BSS、 273180K 保留、0K CMA 保留)
    [0.000000] slub:HWalign=64、order=0-3、MinObjects=0、CPU=4、Nodes=1
    [0.000000]内核/用户页面表隔离:已启用
    [0.000000] ftrace:在148页中分配37823个条目
    [0.000000]分层 RCU 实现。
    [0.000000]RCU 将 CPU 从 NR_CPU=8192限制为 nr_CPU_IDs=4。
    [0.000000]启用了 RCU 任务。
    [0.000000] RCU:调整 RCU_FANOUT_LEVEE=16的几何结构,nr_CPU_IDs=4
    [0.000000] NR_IRQ:524544、nr_IRQ:728、预分配 IRQ:16
    [0.000000]伪波8259A 中断:IRQ7。
    [0.000000] VT 移交:VT 7上的透明 VT
    [0.000000]控制台:彩色虚拟设备80x25
    [0.000000]控制台[tty0]已启用
    [0.000000]时钟源:HPET:MASK:0xFFFFFFFF max_cycles:0xFFFFFFFF、max_idle_ns:1334882848 ns
    [0.000000]已注册 HPET 时钟事件
    [0.004000] TSC:检测到2693.710 MHz 处理器
    [0.004000]校准延迟环路(跳过)、使用计时器频率计算的值。 5387.42茂物剪(lpj=10774840)
    [0.004000] pid_max:默认值:32768最小值:301
    [0.004000] ACPI:核心版本20170531
    [0.013511] ACPI:成功获取并加载了5个 ACPI AML 表
    [0.013528]安全框架已初始化
    [0.013529] Yama:注意。
    [0.013541] AppArmor:已初始化 AppArmor
    [0.014692]条目高速缓存散列表条目:1048576 (顺序:11、8388608字节)
    [0.015255] inode 高速缓存散列表条目:524288 (顺序:10、4194304字节)
    [0.015281]安装高速缓存散列表条目:16384 (顺序:5、131072字节)
    [0.015299] mountpoint-cache 哈希表条目:16384 (顺序:5、131072字节)
    [0.015453] CPU:物理处理器 ID:0
    [0.015453] CPU:处理器内核 ID:0
    [0.015458] energy_perf_bias:设置为"normal"、为"performance"
    [0.015458] energy_perf_bias:查看并更新 x86_64 energy_perf_policy (8)
    [0.015459]功能规格_CTRL 不存在
    [0.015462] MCE:CPU 支持7个 MCE 组
    [0.015469] CPU0:启用热监测(TM1)
    [0.015477]过程:在空闲线程中使用 Mwait
    [0.015480]最后一级 ITLB 条目:4KB 1024、2MB 1024、4MB 1024
    [0.015480]末级 DTLB 条目:4KB 1024、2MB 1024、4MB 1024、1GB 4.
    [0.015711]释放 SMP 备用内存:36K
    [0.017772] smpboot:最大逻辑包数:2.
    [0.017729] DMAR:主机地址宽度39
    [0.017730] DMAR:DRHD 基础:0x000000fed90000标志:0x0
    [0.017736] DMAR:dmar0:reg_base_addr fed90000 ver 1:0 cap c0000020660462 ecap f0101a
    [0.017736] DMAR:DRHD 基础:0x000000fed91000标志:0x1
    [0.017739] DMAR:dmar1:reg_base_addr fed91000 ver 1:0 cap d2008020660462 ECAP f010da
    [0.017739] DMAR:RMRR 基址:0x000000d7f18000结束:0x000000d7f26fff
    [0.017740] DMAR:RMRR 基址:0x000000dd000000结束:0x000000df1fff
    [0.017742] DMAR-IR:IOapic id 8 under DRHD base 0xfed91000 IOMMU 1.
    [0.017743] DMAR-IR:HPET id 0 under DRHD base 0xfed91000
    [0.017743] DMAR-IR:将启用排队失效以支持 x2apic 和 Intr 重映射。
    [0.018041] DMAR-IR:在 x2apic 模式下启用 IRQ 重映射
    [0.018041] x2apic 被启用
    [0.018046]切换 APIC 路由到群集 x2apic。
    [0.018649].计时 器:vector=0x30 apic1=0 pin1=2 apic2=-1 PIN2=-1
    [0.058347] TSC 截止时间计时器已启用
    [0.058348] smpboot:CPU0:Intel (R) Core (TM) i7-4600U CPU @ 2.10GHz (系列:0x6、型号:0x45、步进:0x1)
    [0.058395]性能事件:PEBS fmt2+、Haswell 事件、16深 LBR、全宽计数器、Intel PMU 驱动程序。
    [0.058428]... 版本: 3.
    [0.058428]... 位宽: 48
    [0.058428]... 通用寄存器: 4.
    [0.058429]... 值掩码: 0000ffffffffffff
    [0.058429]... 最大期间: 00007fffffffffffff
    [0.058429]... 固定用途事件:3.
    [0.058430]... 事件掩码: 000000070000000f
    [0.058453]分层 SRCU 实现。
    [0.059099] NMI 安全装置:在所有 CPU 上启用、永久消耗一个 HW-PMU 计数器。
    [0.059110] SMP:启动辅助 CPU ...
    [0.059159] x86:引导 SMP 配置:
    [0.059160].... 节点#0、CPU: 1 2 3
    [0.060701] SMP:带来1个节点、4个 CPU
    [0.060701] smpboot:总共激活4个处理器(21549.68 BogoMips)
    [0.064227] devtmpfs:已初始化
    [0.064227] x86/mm:内存块大小:128MB
    [0.064470] EVM:security.selinux
    [0.064471] EVM:security.SMACK64
    [0.064471] EVM:security.SMACK64EXEC
    [0.064471] EVM:security.SMACK64TRANSMUTE
    [0.064472] EVM:security.SMACK64MMAP
    [0.064472] EVM:security.IMA
    [0.064473] EVM:security.capability
    [0.064484] PM:注册 ACPI NVS 区域[mem 0xcf63e000-0xcf644fff](28672字节)
    [0.064484] PM:注册 ACPI NVS 区域[mem 0xda71c000-0xda7fff](933888字节)
    [0.064484]时钟源:Jiffies:MASK:0xFFFFFFFF max_cycles:0xFFFFFFFF、max_idle_ns:7645041785100000 ns
    [0.064484] futex 散列表条目:1024 (顺序:4、65536字节)
    [0.064484] pinctrl 内核:已初始化 pinctrl 子系统
    [0.064484] RTC 时间:5:45:40、日期:2018年1月28日
    [0.064484] NET:注册协议系列16.
    [0.064484]空闲:使用调节梯
    [0.064484]空闲:使用调速器菜单
    [0.064484]找不到 PCCT 接头。
    [0.064484] ACPI FADT 声明系统不支持 PCIe ASPM,因此请禁用它
    [0.064484] ACPI:注册的总线类型 PCI
    [0.064484] acpiphp:ACPI 热插拔 PCI 控制器驱动程序版本:0.5
    [0.064484] PCI:在[mem 0xf8000000-0xfbffFFF](base 0xf80000)处针对域0000 [bus 00-3f]的 mmconfig
    [0.064484] PCI:mmconfig at [mem 0xf8000000-0xfbffFFF]保留在 E820中
    [0.064484] PCI:使用配置类型1进行基本访问
    [0.064484]内核:PMU 勘误表 BJ122、BV98、HSD29已解决、HT 已开启
    [0.064817]注册的 HugeTLB 页面大小为1.00 GiB,预分配的0页
    [0.064817] HugeTLB 注册的2.00 MIB 页大小,预分配的0页
    [0.064817] ACPI:添加了_OSI (模块设备)
    [0.064817] ACPI:添加了_OSI (处理器设备)
    [0.064817] ACPI:添加了_OSI (3.0 _SCP 扩展)
    [0.064817] ACPI:添加了_OSI (处理器聚合器设备)
    [0.064817] ACPI:执行1块模块级可执行反洗钱代码
    [0.070093] ACPI:[固件错误]:BIOS _OSI (Linux)查询被忽略
    [0.072537] ACPI:动态 OEM 表加载:
    [0.072537] ACPI:SSDT 0xFFFFFF907D948A9800 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711)
    [0.072537] ACPI:SSDT 0xFFFFFF907D94EC3000 0005AA (v01 PmRef Apst 00003000 INTL 20120711)
    [0.072537] ACPI:SSDT 0xFFFFFF907D94838200 000119 (v01 PmRef ApCst 00003000 INTL 20120711)
    [0.076541] ACPI:EC:EC 已启动
    [0.076542] ACPI:EC:中断被阻止
    [0.077594] ACPI:\_SB_.PCI0.LPCB.ECDV:用作第一个 EC
    [0.077595] ACPI:\_SB_.PCI0.LPCB.ECDV:GPE=0x27、EC_CMD/EC_SC=0x934、EC_DATA=0x930
    [0.077596] ACPI:\_SB_.PCI0.LPCB.ECDV:用作引导 DSDT EC 来处理事务
    [0.077596] ACPI:启用解释器
    [0.077622] ACPI:(支持 S0 S3 S4 S5)
    [0.077622] ACPI:使用 IOAPIC 进行中断路由
    [0.077643] PCI:使用 ACPI 中的主机桥窗口;如有必要、使用"PCI=nocrs"并报告错误
    [0.077866] ACPI:在块00至7F 中启用4 GPE
    [0.091995] ACPI:PCI 根桥[PCI0](域0000 [bus 00-3E])
    [0.091999] ACPI PNP0A08:00:_OSC:OS 支持[ExtendedConfig ASPM ClockPM 段 MSI]
    [0.092164] ACPI PNP0A08:00:_OSC:平台不支持[PCIeHotplug PME]
    [0.092255] ACPI PNP0A08:00:_OSC:OS 现在控制[AER PCIeCapability (AER PCIeCapability)]
    [0.092255] ACPI PNP0A08:00:fadt 表示 ASPM 不受支持、使用 BIOS 配置
    [0.092585] PCI 主机桥至总线0000:00
    [0.092587] PCI_BUS 0000:00:根总线资源[IO 0x0000-0x0CF7窗口]
    [0.092587] PCI_BUS 0000:00:根总线资源[IO 0x0d00-0xFFFF 窗口]
    [0.092588] PCI_BUS 0000:00:根总线资源[mem 0x000a0000-0x000bFFFF 窗口]
    [0.092589] PCI_BUS 0000:00:根总线资源[mem 0x000dc000-0x000dFFFF 窗口]
    [0.092590] PCI_BUS 0000:00:根总线资源[mem 0x000e0000-0x000e3fff 窗口]
    [0.092590] PCI_BUS 0000:00:根总线资源[mem 0x000e4000-0x000e7fff 窗口]
    [0.092591] PCI_BUS 0000:00:根总线资源[mem 0xdf200000-0xfeaffffff 窗口]
    [0.092592] PCI_BUS 0000:00:根总线资源[bus 00-3E]
    [0.092597] PCI 0000:00:00.0:[8086:0a04]类型00类0x060000
    [0.092675] PCI 0000:00:02.0:[8086:0a16]类型00类0x030000
    [0.092683] PCI 0000:00:02.0:寄存器0x10:[MEM 0xf7800000-0xf7bffff 64位]
    [0.092688] PCI 0000:00:02.0:寄存器0x18:[MEM 0xe0000000-0xeffffffff 64位 pref]
    [0.092691] PCI 0000:00:02.0:寄存器0x20:[IO 0xf000-0xf03f]
    [0.092755] PCI 0000:00:03.0:[8086:0a0c]类型00类0x040300
    [0.092762] PCI 0000:00:03.0:寄存器0x10:[MEM 0xf7e34000-0xf7e37fff 64位]
    [0.092847] PCI 0000:00:14.0:[8086:9c31]类型00类0x0c0330
    [0.092862] PCI 0000:00:14.0:寄存器0x10:[MEM 0xf7e20000-0xf7e2FFFF 64位]
    [0.0922907] PCI 0000:00:14.0:D3hot D3cold 支持 PME#
    [0.092964] PCI 0000:00:16.0:[8086:9c3A]类型00类0x078000
    [0.092982] PCI 0000:00:16.0:寄存器0x10:[MEM 0xf7e3f000-0xf7e3f01f 64位]
    [0.093037] PCI 0000:00:16.0:D0 D3hot D3cold 支持 PME#
    [0.093098] PCI 0000:00:19.0:[8086:155A]类型00类0x020000
    [0.093111] PCI 0000:00:19.0:寄存器0x10:[MEM 0xf7e00000-0xf7e1FFF]
    [0.093117] PCI 0000:00:19.0:寄存器0x14:[MEM 0xf7e3c000-0xf7e3cfff]
    [0.093122] PCI 0000:00:19.0:寄存器0x18:[IO 0xf080-0xf09f]
    [0.093165] PCI 0000:00:19.0:D0 D3hot D3cold 支持 PME#
    [0.093222] PCI 0000:00:1b.0:[8086:9c20]类型00类0x040300
    [0.093237] PCI 0000:00:1b.0:寄存器0x10:[MEM 0xf7e30000-0xf7e33fff 64位]
    [0.093288] PCI 0000:00:1b.0:D0 D3hot D3cold 支持 PME#
    [0.093353] PCI 0000:00:1c.0:[8086:9c10]类型01类0x060400
    [0.093416] PCI 0000:00:1c.0:D0 D3Hot D3cold 支持 PME#
    [0.093511] PCI 0000:00:1c.3:[8086:9c16] 01类0x060400
    [0.093577] PCI 0000:00:1c.3:D0 D3hot D3cold 支持 PME#
    [0.093669] PCI 0000:00:1c.4:[8086:9c18]类型01类0x060400
    [0.093735] PCI 0000:00:1c.4:D0 D3Hot D3cold 支持 PME#
    [0.093823] PCI 0000:00:1d.0:[8086:9c26]类型00类0x0c0320
    [0.093840] PCI 0000:00:1d.0:寄存器0x10:[MEM 0xf7e3b000-0xf7e3b3ff]
    [0.093910] PCI 0000:00:1D.0:D0 D3Hot D3cold 支持 PME#
    [0.093972] PCI 0000:00:1f.0:[8086:9c43]类型00类0x060100
    [0.094124] PCI 0000:00:1f.2:[8086:282A]类型00类0x010400
    [0.094135] PCI 0000:00:1f.2:寄存器0x10:[IO 0xf0d0-0xf0d7]
    [0.094140] PCI 0000:00:1f.2:寄存器0x14:[IO 0xf0c0-0xf0c3]
    [0.094145] PCI 0000:00:1f.2:寄存器0x18:[IO 0xf0b0-0xf0b7]
    [0.094150] PCI 0000:00:1f.2:寄存器0x1c:[IO 0xf0a0-0xf0a3]
    [0.094154] PCI 0000:00:1f.2:寄存器0x20:[IO 0xf060-0xf07f]
    [0.094159] PCI 0000:00:1f.2:寄存器0x24:[MEM 0xf7e3a000-0xf7e3a7ff]
    [0.094185] PCI 0000:00:1f.2:D3hot 支持 PME#
    [0.094238] PCI 0000:00:1f.3:[8086:9c22]类型00类0x0c0500
    [0.094250] PCI 0000:00:1f.3:寄存器0x10:[MEM 0xf7e39000-0xf7e390ff 64位]
    [0.094265] PCI 0000:00:1f.3:寄存器0x20:[IO 0xf040-0xf05f]
    [0.094374] PCI 0000:00:1c.0:PCI 桥至[bus 01]
    [0.094492] PCI 0000:02:00.0:[8086:08b1]类型00类0x028000
    [0.044546] PCI 0000:02:00.0:寄存器0x10:[MEM 0xf7d00000-0xf7d01fff 64位]
    [0.094769] PCI 0000:02:00.0:D0 D3hot D3cold 支持 PME#
    [0.104086] PCI 0000:00:1c.3:PCI 桥至[bus 02]
    [0.104090] PCI 0000:00:1c.3:桥接窗口[mem 0xf7d00000-0xf7dfff]
    [0.105971] PCI 0000:03:00.0:[1217:8520]类型00类0x080501
    [0.106003] PCI 0000:03:00.0:寄存器0x10:[MEM 0xf7c01000-0xf7c01fff]
    [0.106015] PCI 0000:03:00.0:寄存器0x14:[MEM 0xf7c00000-0xf7c007ff]
    [0.106149] PCI 0000:03:00.0:D3hot D3cold 支持 PME#
    [0.117834] PCI 0000:00:1c.4:PCI 桥至[bus 03]
    [0.117837] PCI 0000:00:1c.4:桥接窗口[mem 0xf7c00000-0xf7cfff]
    [0.119015] ACPI:PCI 中断链接[LNKA](IRQ 3 4 5 6 10 * 11 12 14 15)
    [0.119052] ACPI:PCI 中断链接[LNKB](IRQ 3 4 5 6 *10 11 12 14 15)
    [0.119089] ACPI:PCI Interrupt Link [LNKC](IRQ 3 4 5 6 10 11 12 14 15)*0,已禁用。
    [0.119126] ACPI:PCI 中断链路[LNKD](IRQ 3 4 5 6 *10 11 12 14 15)
    [0.119162] ACPI:PCI 中断链路[LNKE](IRQ 3 4 * 5 6 10 11 12 14 15)
    [0.119198] ACPI:PCI 中断链路[LNKF](IRQ 3 4 5 6 10 * 11 12 14 15)
    [0.119234] ACPI:PCI 中断链路[LNKG](IRQ *3 4 5 6 10 11 12 14 15)
    [0.119270] ACPI:PCI 中断链接[LNKH](IRQ 3 4 5 6 10 11 12 14 15)*0,已禁用。
    [0.120479] ACPI:EC:中断未被阻止
    [0.120487] ACPI:EC:事件未被阻止
    [0.120502] ACPI:\_SB_.PCI0.LPCB.ECDV:GPE=0x27、EC_CMD/EC_SC=0x934、EC_DATA=0x930
    [0.120503] ACPI:\_SB_.PCI0.LPCB.ECDV:用作引导 DSDT EC 来处理事务和事件
    [0.120733] SCSI 子系统已初始化
    [0.120752]已加载 libata 版本3.00。
    [0.120752] PCI 0000:00:02.0:vgaarb:设置为引导 VGA 设备
    [0.120752] PCI 0000:00:02.0:vgaarb:VGA 设备添加了:解码=io+mem、owns=io+mem、locks=none
    [0.120752] PCI 0000:00:02.0:vgaarb:可实现桥接控制
    [0.120752] vgaarb:已加载
    [0.120752] ACPI:已注册总线类型 USB
    [0.120752] usbcore:注册的新接口驱动程序 usbfs
    [0.120752] usbcore:注册的新接口驱动程序集线器
    [0.120752] usbcore:注册的新设备驱动程序 USB
    [0.120752] EDAC MC:版本:3.0.0
    [0.122081] PCI:使用 ACPI 进行 IRQ 路由
    [0.124882] PCI:PCI_cache_line_size 设置为64字节
    [0.126829] e820:保留 RAM 缓冲器[mem 0x00091400-0x0009FFF]
    [0.126830] e820:保留 RAM 缓冲器[mem 0xcf63e000-0xcffffff]
    [0.126830] e820:保留 RAM 缓冲器[mem 0xd0276000-0xd3ffFFF]
    [0.126831] e820:保留 RAM 缓冲器[mem 0xd7db4000-0xd7ffFFF]
    [0.126832] e820:保留 RAM 缓冲器[mem 0xd8759000-0xdbffFFFFF]
    [0.126832] e820:保留 RAM 缓冲器[mem 0xd8faa000-0xdbffFFF]
    [0.126833] e820:保留 RAM 缓冲器[mem 0xda71c000-0xdbffFFF]
    [0.126834] e820:保留 RAM 缓冲器[mem 0xdbcf4000-0xdbffFFF]
    [0.126835] e820:保留 RAM 缓冲器[mem 0x21ee00000-0x21fffff]
    [0.126897] NetLabel:正在初始化
    [0.126897] NetLabel:域哈希大小= 128
    [0.126898] NetLabel:协议=未标记的 CIPSOv4 CALIPSO
    [0.126909] NetLabel:默认情况下允许未标记的通信
    [0.126922] hpet0:在 MMIO 0xfed00000、IRQ 2、8、0、0、0、 0、0、0、0
    [0.126922] hpet0:8个比较器、64位14.318180 MHz 计数器
    [0.128013]时钟源:切换到时钟源 HPET
    [0.135096] VFS:磁盘配额 dquot_6.6.0
    [0.135109] VFS:Dquot 高速缓存散列表条目:512 (顺序0、4096字节)
    [0.135188] AppArmor:已启用 AppArmor 文件系统
    [0.135222] PNP:PNP ACPI 初始化
    [0.135308]系统00:00:[MEM 0xfed40000-0xfed44fff]已被保留
    [0.135311]系统00:00:即插即用 ACPI 设备、ID PNP0c01 (活动)
    [0.135546]系统00:01:[IO 0x0680-0x069f]已保留
    [0.135547]系统00:01:[IO 0xFFF]已保留
    [0.135548]系统00:01:[IO 0xFFF]已保留
    [0.135549]系统00:01:[IO 0x1c00-0x1cfe]已保留
    [0.135550]系统00:01:[IO 0x1d00-0x1dfe]已保留
    [0.135551]系统00:01:[IO 0x1e00-0x1efe]已保留
    [0.135552]系统00:01:[IO 0x1f00-0x1ffe]已保留
    [0.135552]系统00:01:[IO 0x1800-0x18fe]已保留
    [0.135553]系统00:01:[IO 0x164e-0x164f]已保留
    [0.1355]系统00:01:即插即用 ACPI 设备、ID PNP0c02 (活动)
    [0.135574] PNP 00:02:即插即用 ACPI 设备、ID PNP0b00 (活动)
    [0.135605]系统00:03:[IO 0x1854-0x1857]已保留
    [0.135607]系统00:03:即插即用 ACPI 设备、ID INT3f0d PNP0c02 (活动)
    [0.135638]系统00:04:[IO 0x04d0-0x04d1]已保留
    [0.135640]系统00:04:即插即用 ACPI 设备、ID PNP0c02 (活动)
    [0.135662] PNP 00:05:即插即用 ACPI 设备、ID PNP0303 (活动)
    [0.135674] PNP 00:06:即插即用 ACPI 设备、ID DLL05cb PNP0f13 (正在供货)
    [0.136218] PNP 00:07:即插即用 ACPI 设备、ID PNP0401 (已禁用)
    [0.136422]系统00:08:即插即用 ACPI 设备、ID PNP0c02 (活动)
    [0.136601]系统00:09:[MEM 0xfed1c000-0xfed1FFF]已保留
    [0.136602]系统00:09:[MEM 0xfed10000-0xfed17fff]已保留
    [0.136603]系统00:09:[MEM 0xfed18000-0xfed18fff]已保留
    [0.136604]系统00:09:[MEM 0xfed19000-0xfed19fff]已保留
    [0.136605]系统00:09:[MEM 0xf8000000-0xfbffFFF]已被保留
    [0.136605]系统00:09:[MEM 0xfed20000-0xfed3FFF]已保留
    [0.136606]系统00:09:[MEM 0xfed90000-0xfed93fff]无法保留
    [0.136607]系统00:09:[MEM 0xfed45000-0xfed8FFF]已保留
    [0.136608]系统00:09:[MEM 0x000000-0xFFFFF]已保留
    [0.136609]系统00:09:[MEM 0xfee00000-0xfeefffff]无法保留
    [0.136610]系统00:09:[MEM 0xf7fdf000-0xf7fdFFF]已保留
    [0.136611]系统00:09:[MEM 0xf7fe0000-0xf7effff]已保留
    [0.136612]系统00:09:即插即用 ACPI 设备、ID PNP0c02 (活动)
    [0.137856] PNP:PNP ACPI:找到10个器件
    [0.143667]时钟源:ACPI_PM:屏蔽:0xFFFF max_cycles:0xFFFF、max_idle_ns:2085701024 ns
    [0.143696] PCI 0000:00:1c.0:PCI 桥至[bus 01]
    [0.143707] PCI 0000:00:1c.3:PCI 桥至[bus 02]
    [0.143710] PCI 0000:00:1c.3:桥接窗口[mem 0xf7d00000-0xf7dfff]
    [0.143716] PCI 0000:00:1c.4:PCI 桥至[bus 03]
    [0.143720] PCI 0000:00:1c.4:桥接窗口[mem 0xf7c00000-0xf7cfff]
    [0.143726] PCI_BUS 0000:00:资源4 [IO 0x0000-0x0CF7窗口]
    [0.143727] PCI_BUS 0000:00:资源5 [IO 0x0d00-0xFFFF 窗口]
    [0.143728] PCI_BUS 0000:00:资源6 [mem 0x000a0000-0x000bFFFF 窗口]
    [0.143729] PCI_BUS 0000:00:资源7 [mem 0x000dc000-0x000dFFFF 窗口]
    [0.143729] PCI_BUS 0000:00:资源8 [mem 0x000e0000-0x000e3fff 窗口]
    [0.143730] PCI_BUS 0000:00:资源9 [mem 0x000e4000-0x000e7fff 窗口]
    [0.143731] PCI_BUS 0000:00:资源10 [mem 0xdf200000-0xfeaffffff 窗口]
    [0.143732] PCI_BUS 0000:02:资源1 [mem 0xf7d00000-0xf7dfff]
    [0.143733] PCI_BUS 0000:03:资源1 [mem 0xf7c00000-0xf7cfff]
    [0.143821] NET:注册协议系列2.
    [0.143938] TCP 建立哈希表条目:65536 (顺序:7、524288字节)
    [0.144029] TCP 绑定哈希表条目:65536 (顺序:8、1048576字节)
    [0.144141] TCP:配置哈希表(建立65536 BIND 65536)
    [0.144163] UDP 哈希表条目:4096 (顺序:5、131072字节)
    [0.144183] UP-Lite 哈希表条目:4096 (顺序:5、131072字节)
    [0.144219] NET:注册协议系列1.
    [0.144227] PCI 0000:00:02.0:具有阴影 ROM 的视频设备、位于[mem 0x000c0000-0x000dFFF]
    [0.169956] PCI:CLS 64字节、默认64
    [0.169987]正在解压缩 initramfs...
    [0.739497]释放 initrd 内存:49248K
    [0.739557] PCI-DMA:为 IO 使用软件反弹缓冲(swiotlb)
    [0.739559]软件 IO TLB [mem 0xd3db4000-0xd7db4000](64MB)映射在[ff907c53db4000-ff907c57db3fff]
    [0.739729]每60秒扫描一次内存不足问题
    [0.739952]审核:初始化 netlink 子系统(已禁用)
    [0.739983]审核:type=2000审核(1517118340.739:1):State=initialized audit_enable=0 res=1
    [0.740250]初始化系统受信任的密钥环
    [0.740256]注册密钥类型黑名单
    [0.740284]工作集:timestimer_bits=36 max_order=21 bucke_order=0
    [0.741073] zud:已加载
    [0.741338] squashfs:版本4.0 (2009/01/31) Phillip Lougher
    [0.741434]熔丝初始化(API 版本7.26)
    [0.742244]注册密钥类型非对称
    [0.742245]已注册非对称密钥解析器"x509"
    [0.742264]块层 SCSI 通用(BSG)驱动程序0.4版已加载(主要247)
    [0.742293]已注册 IO 调度程序 NOP
    [0.742293]已登记 IO 调度程序截止日期
    [0.742310]已注册 IO 调度程序 cfq (默认值)
    [0.742748] vesafb:模式为1920x1080x32、线长=7680、页数=0
    [0.742749] vesafb:滚动:重绘
    [0.742750] vesafb:TrueColor:size=8:8:8:8、shif=24:16:8:0
    [0.742758(XXVI)虚拟缓冲区:0xe0000000处的帧缓冲区、映射到0xffaf3301800000、使用8128k、总容量为8128k
    [0.742825]控制台:切换到彩色帧缓冲器器件240x67
    [0.742842] fb0:VESA VGA 帧缓冲器设备
    [0.742850] Intel_Idle:Mbit 子状态:0x11142120
    [0.742850] Intel_IDLE:V0.4-1型号0x45
    [0.742985] Intel_Idle:lapic_timer_relied_stats 0xffffffff
    [0.743473] ACPI:交流适配器[AC](在线)
    [0.743915]输入:盖开关、如/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
    [0.744327] ACPI:盖开关[LID0]
    [0.744355]输入:电源按钮为/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
    [0.744372] ACPI:电源按钮[PBTN]
    [0.744393] input:Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
    [0.744399] ACPI:睡眠按钮[SBTN]
    [0.744420]输入:电源按钮作为/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
    [0.74442] ACPI:电源按钮[PWRF]
    [0.74496](NULL 器件*):hwmon_device_register ()已弃用。 请将驱动程序转换为使用 hwmon_device_register_wo_info()。
    [0.745169]散热 LNXTHERM:00:注册为 Thermal_zone0
    [0.745169] ACPI:散热区[TMH](25 C)
    [0.745200] GHES:Hest 未启用!
    [0.745298]串行:8250/16550驱动程序,32个端口,启用 IRQ 共享
    [0.746758] Linux agpgart 接口 v0.103
    [0.747935]循环:模块已加载
    [0.748044] libphy:固定 MDIO 总线:探测
    [0.748045] Tun:通用 TUN/Tap 器件驱动程序、1.6
    [0.748070] PPP 通用驱动程序版本2.4.2
    [0.748096] EHCI_hcd:USB 2.0 "增强型"主机控制器(EHCI)驱动程序
    [0.748097] EHCI-PCI:EHCI PCI 平台驱动程序
    [0.748186] EHCI-PCI 0000:00:1D.0:EHCI 主机控制器
    [0.748190] EHCI-PCI 0000:00:1D.0:已注册新 USB 总线、分配总线编号1
    [0.748205] EHCI-PCI 0000:00:1D.0:调试端口2
    [0.752116] EHCI-PCI 0000:00:1d.0:不支持64的高速缓存行大小
    [0.752140] EHCI-PCI 0000:00:1d.0:IRQ 21、IO 内存0xf7e3b000
    [0.761007] ACPI:电池槽[BAT0](电池存在)
    [0.761788] ACPI:电池槽[BAT1](电池不存在)
    [0.768070] EHCI-PCI 0000:00:1d.0:USB 2.0已启动、EHCI 1.00
    [0.768113] USB USB1:找到新的 USB 设备、idVendor=1d6b、idProduct=0002
    [0.768114] USB USB1:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    [0.768115] USB USB1:产品:EHCI 主机控制器
    [0.768116] USB USB1:制造商:Linux 4.13.0-32-generic EHCI_hcd
    [0.768116] USB USB1:串行编号:0000:00:1D.0
    [0.768222]集线器1-0:1.0:找到 USB 集线器
    [0.768225]集线器1-0:1.0:检测到2个端口
    [0.768328] EHCI 平台:EHCI 通用平台驱动程序
    [0.768341] ohci_hcd:USB 1.1 'Open'主机控制器(OHCI)驱动程序
    [0.768343] ohci-PCI:OHCI PCI 平台驱动程序
    [0.768349] ohci 平台:OHCI 通用平台驱动程序
    [0.768354] UHCI_hcd:USB 通用主机控制器接口驱动程序
    [0.768477] xhci_hcd 0000:00:14.0:xHCI 主机控制器
    [0.768480] xhci_hcd 0000:00:14.0:已注册新 USB 总线、分配的总线编号2
    [0.769536] xhci_hcd 0000:00:14.0:HCC 参数0x200077c1 HCI 版本0x100查询0x0004b810
    [0.769538] xhci_hcd 0000:00:14.0:不支持缓存行大小为64
    [0.769625] USB USB2:找到新的 USB 器件、idVendor=1d6b、idProduct=0002
    [0.769625] USB USB2:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    [0.769626] USB USB2:产品:XHCI 主机控制器
    [0.769627] USB USB2:制造商:Linux 4.13.0-32-generic xhci-hcd
    [0.769627] USB USB2:Serial Number:0000:00:14.0
    [0.769693]集线器2-0:1.0:找到 USB 集线器
    [0.769702]集线器2-0:1.0:检测到9个端口
    [0.770473] xhci_hcd 0000:00:14.0:xHCI 主机控制器
    [0.770475] xhci_hcd 0000:00:14.0:已注册新 USB 总线、分配的总线编号3
    [0.770493] USB USB3:找到新的 USB 器件、idVendor=1d6b、idProduct=0003
    [0.770494] USB USB3:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    [0.770495] USB USB3:产品:XHCI 主机控制器
    [0.770495] USB USB3:制造商:Linux 4.13.0-32-generic xhci-hcd
    [0.770496] USB USB3:Serial Number:0000:00:14.0
    [0.770560]集线器3-0:1.0:找到 USB 集线器
    [0.770567]集线器3-0:1.0:检测到4个端口
    [0.770787] i8042:PNP:PS/2控制器[PNP0303:PS2K、PNP0f13:PS2M]、位于0x60、0x64 IRQ 1、12
    [0.771321] i8042:警告:钥匙锁处于激活状态
    [0.773600] serio:i8042 KBD 端口位于0x60、0x64 IRQ 1
    [0.773603] serio:i8042 AUX 端口位于0x60、0x64 IRQ 12
    [0.773682] mousedev:PS/2鼠标设备,适用于所有鼠标
    [0.773828] RTC_CMOS 00:02:RTC 可从 S4唤醒
    [0.773942] RTC_CMOS 00:02:RTC 内核:将 RTC_CMOS 注册为 rtc0
    [0.773967] RTC_CMOS 00:02:最多一个月的报警、y3k、242字节 NVRAM、HPET IRQ
    [0.773981] i2c /dev/entries 驱动程序
    [0.774028]设备映射器:uevent:版本1.0.3
    [0.774089]设备映射器:ioctl:4.37.0-ioctl (2017-09-20)已初始化:dm-devel@redhat.com
    [0.774094] Intel_pstate:Intel P-state 驱动程序正在初始化
    [0.774283] ledtrig-CPU:已注册以指示 CPU 上的活动
    [0.774565] NET:注册协议系列10.
    [0.775108] input:在翻译后的 Set 2键盘上作为/devices/platform/i8042/serio0/input/input4
    [0.778695]采用 IPv6的段路由
    [0.778708] NET:注册协议系列17.
    [0.778713]注册的密钥类型 DNS_旋 变传感器
    [0.778880] RAS:可纠正错误收集器已初始化。
    [0.778900]微码:sig=0x40651、pf=0x40、修订版=0x20
    [0.778933]微代码:微代码更新驱动程序:v2.2。
    [0.778971] sched_clock:标记稳定(77893309、0)->(778006480、924829)
    [0.779103]已注册任务统计版本1
    [0.779110]正在加载已编译的 X.509证书
    [0.781305]加载了 X.509认证"生成时间自动生成内核密钥:ea5b2e3dc303efbb5e4e4f76f9dbd395fda5b554"
    [0.781320] zswap:使用池 lso/zud 加载
    [0.783642]注册了密钥类型 BIG_KEY
    [0.783645]密钥类型已注册
    [0.784778]密钥类型已注册
    [0.784781] AppArmor:AppArmor SHA1策略哈希已启用
    [0.784783] IMA:未找到 TPM 芯片,激活 TPM 旁路! (RC=-19)
    [0.784797] EVM:HMAC attrs:0x1.
    [0.786890]魔法号码:2:836:770
    [0.786986] RTC_CMOS 00:02:将系统时钟设置为2018-01-28 05:45:41 UTC (1517118341)
    [0.787040] BIOS EDD 医院 v0.16 2004-Jun-25,0个设备已找到
    [0.787040]未提供 EDD 信息。
    [0.787077] PM:休眠映像不存在或无法加载。
    [0.788507]释放未使用的内核内存:2364K
    [0.788508]写保护内核只读数据:18432k
    [0.788885]释放未使用的内核内存:2024K
    [0.789067]释放未使用的内核内存:92K
    [0.790400] x86/mm:已检查 W+X 映射:已通过、未找到 W+X 页。
    [0.790400] x86/mm:检查用户空间页表
    [0.791620] x86/mm:已检查 W+X 映射:已通过、未找到 W+X 页。
    [0.833401] hirraw:Raw HID 事件驱动程序(C) Jiri Kosina
    [0.838643] sdhci:安全数字主机控制器接口驱动程序
    [0.838644] sdhci:版权所有(c) Pierre Osman
    [0.849351] WMI_BUS WMI_BUS-PNP0C14:00:未找到 WQBC 数据块查询控制方法
    [0.86415] pps_core:LinuxPPS API 版本。 1已注册
    [0.864416] pps_core:软件版本 5.3.6 -版权所有2005-2007 Rodolfo Giometti
    [0.864532] sdhci-PCI 0000:03:00.0:找到 SDHCI 控制器[1217:8520](修订版1)
    [0.866522] mmc0:未知控制器版本(3)。 您可能会遇到问题。
    [0.866531]已注册 PTP 时钟支持
    [0.870402] mmc0:使用 ADMA 的 PCI [0000:03:00.0]上的 SDHCI 控制器
    [0.870455] AHCI 0000:00:1f.2:3.0版
    [0.870613] AHCI 0000:00:1f.2:SSS 标志置1、并行总线扫描禁用
    [0.871040] e1000e:英特尔RegisteredPRO/1000网络驱动程序- 3.2.6-k
    [0.871040] e1000e:版权所有(c) 1999 - 2015英特尔公司。
    [0.880690] AHCI 0000:00:1f.2:AHCI 0001.0300 32插槽4端口6 Gbps 0xb 不支持 RAID 模式
    [0.880692] AHCI 0000:00:1f.2:标志:64位 NCQ ilck stag led clo only pio s贫民 窟零件 sxs deso sadm SDS apst
    [0.881183] SCSI host0:AHCI
    [0.881264] SCSI host1:AHCI
    [0.881334] SCSI host2:AHCI
    [0.881407] SCSI host3:AHCI
    [0.881445] ata1:SATA max UDMA/133 abar m2048@0xf7e3a000 port 0xf7e3a100 IRQ 43
    [0.881446] ata2:SATA max UDMA/133 abar m2048@0xf7e3a000 port 0xf7e3a180 IRQ 43
    [0.881447] AA3:虚拟
    [0.881448] ATA4:SATA max UDMA/133 abar m2048@0xf7e3a000 port 0xf7e3a280 IRQ 43
    [0.881627] e1000e 0000:00:19.0:中断限制率(单位/秒)设置为动态保守模式
    [1.096076] USB 1-1:使用 EHCI-PCI 的新型高速 USB 器件编号2
    [1.097884] USB 2-4:使用 xhci_hcd 的新型高速 USB 器件编号2
    [1.194963] ata1:SATA link down (sStatus 0 SControl 300)
    [1.220571] e1000e 0000:00:19.0 0000:00:19.0 (未初始化):已注册的 PHC 时钟
    [1.244357] USB 1-1:找到新的 USB 设备、idVendor=8087、idProduct=8000
    [1.244359] USB 1-1:新 USB 器件字符串:MFR=0、Product=0、SerialNumber=0
    [1.244597]集线器1-1:1.0:找到 USB 集线器
    [1.244691]集线器1-1:1.0:检测到8个端口
    [1.248972] mmc0:地址1234处的新高速 SDHC 卡
    [1.250511] mmcblk0:mmc0:1234 SA16G 14.9GiB
    [1.253116] mmcblk0:P1
    [1.285336] e1000e 0000:00:19.0 eth0:(PCI Express:2.5GT/s:宽度 x1) 34:E6:D7:0A:48:15
    [1.285338] e1000e 0000:00:19.0 eth0:英特尔(R) PRO/1000网络连接
    [1.285375] e1000e 0000:00:19.0 eth0:mac:11、phy:12、pba 号:FFFFFF-0FF
    图形设备可用的[1.285722][DRM]内存= 2048M
    [1.285724]检查通用(e0000000 7f0000)与硬件(e0000000 10000000)
    [1.285725] fb:从 VESA VGA 切换到 inteldrmfb
    [1.285743]控制台:切换到彩色虚拟设备80x25
    [1.285796][DRM]更换 VGA 控制台驱动程序
    [1.286090] e1000e 0000:00:19.0 eno1:从 eth0重命名
    [1.291864][DRM]支持 vblank 时间戳缓存修订版2 (2013年10月21日)。
    [1.291865][DRM]驱动程序支持精确的 vblank 时间戳查询。
    [1.294411] i915 0000:00:02.0:vgaarb:已更改 VGA 解码:oldDecasions=io+mem、解码=io+mem:owns=io+mem
    [1.301466][DRM]为次要0上的0000:00:02.0初始化了 i915 1.6.0 20170619
    [1.310579] USB 2-4:找到新的 USB 设备、idVendor=0c45、idProduct=64d2
    [1.310581] USB 2-4:新 USB 器件字符串:MFR=2、Product=1、SerialNumber=0
    [1.310582] USB 2-4:产品:笔记本电脑_集成_网络摄像头_HD
    [1.310583] USB 2-4:制造商:CN07YYTT7248749LA7JZA00
    [1.436063] USB 2-6:使用 xhci_hcd 的全新全速 USB 器件编号3
    [1.511275] ata2:SATA link down (sStatus 0 SControl 300)
    [1.532097] USB 1-1.3:使用 EHI-PCI 的全新全速 USB 器件编号3
    [1.578466] USB 2-6:找到新的 USB 器件、idVendor=046d、idProduct=c52b
    [1.578478] USB 2-6:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=0
    [1.578479] USB 2-6:产品:USB 接收器
    [1.578480] USB 2-6:制造商:Logitech
    [1.584219] usbcore:注册的新接口驱动程序 usbhid
    [1.584220] usbhid:USB HID 内核驱动程序
    [1.585680] Logitech -djreceiver 0003:046D:C52B.0003:hiddev0、hirdraw0:USB HID v1.11设备[Logitech USB Receiver] on USB-0000:00:14.0-6/input2
    [1.642488] USB 1-1.3:找到新的 USB 器件、idVendor=8087、idProduct=07dc
    [1.642490] USB 1-1.3:新 USB 器件字符串:MFR=0、Product=0、SerialNumber=0
    [1.659679] ACPI:视频设备[GFX0](多显示端:是 ROM:无法开机自检:否)
    [1.660212]输入:视频总线、如/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input7
    [1.677997] fbcon:inteldrmfb (fb0)是主器件
    [1.678071]控制台:切换到彩色帧缓冲器器件240x67
    [1.678100] i915 0000:00:02.0:fb0:inteldrmfb 帧缓冲器件
    [1.719832]输入:Logitech M325 AS /devices/pci0000:00/0000:00:14.0/USB2/2-6/2-6:1.2/0003:046D:C52B.0003/0003:046D:400A.0004/input8
    [1.719949] Logitech -hidpp-device 0003:046D:400A.0004:输入、抽取1:USB HID v1.11鼠标[Logitech M325]、位于 USB-0000:00:14.0-6:1
    [1.721845]输入:Logitech M315/M235、如/devices/pci0000:00/0000:00:14.0/USB2/2-6/2-6:1.2/0003:046D:C52B.0003/0003:046D:4009.0005/input9
    [1.721937] Logitech-hidpp-device 0003:046D:4009.0005:输入,hraw2:USB HID v1.11鼠标[Logitech M315/M235],位于 USB-0000:00:14.0-6:2
    [1.756405] TSC:改进的 TSC 时钟源校准:2693.764MHz
    [1.756414]时钟源:TSC:屏蔽:0xffffffffffffffffffffff max_cycles:0x26d43bb7f27、max_idle_ns:440795270902 ns
    [1.827180] ATA4:SATA 链路速率高达6.0Gbps (sStatus 133 SControl 300)
    [1.829604] ata4.00:不支持 NCQ 发送/接收日志
    [1.829606] ata4.00:ATA-9:Samsung SSD PM851 mSATA 256GB、EXT4AD0Q、最大 UDMA/133
    [1.829607] ata4.00:500118192扇区、多16:lba48 NCQ (深度31/32)、AA
    [1.830327] ata4.00:不支持 NCQ 发送/接收日志
    [1.830362] ata4.00:针对 UDMA/133配置
    [1.830513] SCSI 3:0:0:0:直接访问 ATA 三星 SSD PM85 AD0Q PQ:0 ANSI:5
    [1.864223] SD 3:0:0:0:已连接 SCSI 通用 sg0类型0
    [ 1.864286] SD 3:0:0:0:0:[SDA] 500118192 512字节逻辑块:(256 GB/238 GiB)
    [ 1.864300] SD 3:0:0:0:0:[SDA]写保护关闭
    [1.864302] SD 3:0:0:0:[SDA]模式检测:00 3a 00
    [ 1.864349] SD 3:0:0:0:[SDA]写入高速缓存:已启用、读取高速缓存:已启用、不支持 DPO 或 FUA
    [1.865039] sda:sda1 sda2 < sda5 >
    [1.865329] SD 3:0:0:0:[SDA]连接的 SCSI 磁盘
    [2.189845]输入:AlpsPS/2 Alps DualPoint Stick AS /devices/platform/i8042/serio1/input/input10
    [2.202431]输入:AlpsPS/2 Alps DualPoint 触摸板,如/devices/platform/i8042/serio1/input/input6
    [2.780243]时钟源:切换到时钟源 TSC
    [6.974105] EXT4-FS (dm-0):已安装的文件系统、具有有序数据模式。 OPTS:(空)
    [7.066711] systemd[1]:systemd 229在系统模式下运行。 (+PAM +audit +SELinux +IMA +AppArmor +smack +sysvinit +utmp +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +blkid +ELFUTILS +KMOD -IDN)
    [7.066808] systemd[1]:检测到的架构 x86-64。
    [7.066962] systemd[1]:将主机名设置为 。
    [7.141732] systemd[1]:侦听 udev 内核套接字。
    [7.141818] systemd[1]:侦听日志审计套接字。
    [7.141844] systemd[1]:侦听设备映射器事件守护程序 FIFO。
    [7.141913] systemd[1]:创建的层用户和会话层。
    [7.141963] systemd[1]:创建的层系统层。
    [7.141989] systemd[1]:侦听 fsck 到 fsck 通信插槽。
    [7.141995] systemd[1]:已达到目标层数。
    [7.159687] LP:驱动程序已加载、但未找到器件
    [7.162638] ppdev:用户空间并行端口驱动程序
    [7.165134] parport_PC 00:07:[IO 0x0378-0x037b]
    [7.167033] parport_PC 00:07:[IRQ 5]
    [7.168264] parport_PC 00:07:已激活
    [7.168266] parport_PC 00:07:由即插即用 ACPI 报告
    [7.218996] EXT4-FS (dm-0):已重新安装。 opts:errors=remount-ro
    [7.225822] systemd-journale[282]:已收到从 PID 1刷新运行时日志的请求
    [7.352534] shpchp:标准热插拔 PCI 控制器驱动程序版本:0.4
    [7.378252] mee_me 0000:00:16.0:NFC Mei 版本:IVN 0x1供应商 ID 0x1类型0x1
    [7.413600]蓝牙:内核版本2.22
    [7.413612] NET:注册协议系列31.
    [7.413612]蓝牙:HCI 设备和连接管理器已初始化
    [7.413615]蓝牙:HCI 套接字层已初始化
    [7.413617]蓝牙:已初始化 L2CAP 套接字层
    [7.413624]蓝牙:已初始化 SCO 套接字层
    [7.415420] dcdbas dcdbas:Dell Systems Management Base Driver (版本5.6.0-3.2)
    [7.422346]介质:Linux 介质接口:v0.10
    [7.42333] usbcore:注册的新接口驱动程序 btusb
    [7.430607] Dell_WMI:检测到 Dell WMI 界面版本1
    [7.4306770] input:Dell WMI hotkeys as /devices/platform/PNP0C14:00/WMI_BUS/WMI_BUS-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input11
    [7.433647] Linux 视频捕捉接口:v2.00
    [7.437038] snd_hda_codec_Realtek hdaudioC1D0:ALC3226的自动配置:LINE_OUT=1 (0x16/0x0/0x0/0x0/0x0/0x0/0x0)类型:LINE
    [7.437041] snd_hda_codec_Realtek hdaudioC1D0:speaker_outs=1 (0x14/0x0/0x0/0x0/0x0/0x0/0x0)
    [7.437042] snd_hda_codec_Realtek hdaudioC1D0:hp_outs=1 (0x15/0x0/0x0/0x0/0x0/0x0/0x0)
    [7.437043] snd_hda_codec_Realtek hdaudioC1D0:Mono:mono_out=0x0
    [7.437044] snd_hda_codec_Realtek hdaudioC1D0:输入:
    [7.437046] snd_hda_codec_Realtek hdaudioC1D0: 坞站麦克风= 0x19
    [7.437047] snd_hda_codec_Realtek hdaudioC1D0: 耳机麦克风= 0x1a
    [7.437048] snd_hda_codec_Realtek hdaudioC1D0: 内部麦克风= 0x12
    [7.442267]蓝牙:hci0:阅读英特尔版本:370710018002030d55
    [7.442269]蓝牙:hci0:英特尔设备已安装补丁。 修补程序编号:55
    [7.453377] RAPL PMU:API 单元为2^-32焦耳、4个固定计数器、655360ms ovfl 计时器
    [7.453379] RAPL PMU:域 pp0-core 2^-14焦耳的硬件单元
    [7.453380] RAPL PMU:域封装的硬件单元2^-14焦耳
    [7.453380] RAPL PMU:域 DRAM 2^-14焦耳的硬件单元
    [7.453381] RAPL PMU:域 pp1-GPU 2^-14焦耳的硬件单元
    [7.454367] Linux 版英特尔Registered无线 WiFi 驱动程序
    [7.454367]版权所有(c) 2003-2015英特尔公司
    [7.461081] uvcvideo:找到 UVC 1.00设备 Laptop_Integral_Webcam _HD (0c45:64d2)
    [7.461367] iwlwifi 0000:02:00.0:已加载固件版本17.608620.0 op_mode iwlmvm
    [7.48269]输入:HDA Intel PCH Dock Mic AS /devices/pci0000:00/0000:00:1b.0/sound/Card1/input12
    [7.482765]输入:HDA Intel PCH Dock Line Out as /devices/pci0000:00/0000:00:1b.0/sound/Card1/input13
    [7.482818]输入:HDA Intel PCH 前耳机,如/devices/pci0000:00/0000:00:1b.0/sound/Card1/input14
    [7.488130]使用了 AVX2版本的 GCM_ENC/解码。
    [7.488131]启用了 AES CTR 模式 by8优化
    [7.491425] iwlwifi 0000:02:00.0:检测到的英特尔Registered双频带无线 AC 7260、REV=0x144
    [7.502859] uvcvideo 2-4:1.0:实体扩展名4的实体类型未初始化!
    [7.502862] uvcvideo 2-4:1.0:实体扩展3的实体类型未初始化!
    [7.502864] uvcvideo 2-4:1.0:实体处理2的实体类型未初始化!
    [7.502865] uvcvideo 2-4:1.0:实体相机1的实体类型未初始化!
    [7.502933]输入:Laptope_Integral_Webcam _HD:IN AS /devices/pci0000:00/0000:00:14.0/USB2/2-4/2-4:1.0/input/input15
    [7.502994] usbcore:注册的新接口驱动程序 uvcvideo
    [7.502995] USB 视频类驱动程序(1.1.1)
    [7.524934] iwlwifi 0000:02:00.0:基本硬件地址:80:19:34:60:E2:3a
    [7.532289] Dell_laptop:使用 Dell-rbtn ACPI 驱动程序接收事件
    [7.607035] Intel_rapl:找到了 RAPL 域包
    [7.607037] Intel_rapl:找到了 RAPL 域内核
    [7.607037] Intel_rapl:找到 RAPL 域 uncore
    [7.607038] Intel_rapl:找到了 RAPL 域 DRAM
    [7.607042] Intel_rapl:RAPL 软件包0域软件包已被 BIOS 锁定
    [7.607045] Intel_rapl:RAPL 软件包0域 DRAM 已被 BIOS 锁定
    [7.633031] NFC:NFC_init:NFC 内核版本0.1
    [7.633052] NET:注册协议系列39.
    [7.651448]探测 NFC pn544
    [7.731410] ieee80211 phy0:选择的速率控制算法"iwl-MVM-Rs"
    [7.733053] iwlwifi 0000:02:00.0 wlp2s0:已从 wlan0重命名
    [7.734907] EXT4-FS (sda1):使用 ext4子系统安装 ext2文件系统
    [7.737781] EXT4-FS (sda1):安装的文件系统不含日志。 OPTS:(空)
    [7.792353]在/dev/mapper/ubuntu--vg-swap_1.上添加了8290300k 交换 在:8290300k SSFS 上优先级:-1扩展:1
    [8.459574] snd_hda_intel 0000:00:03.0:bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
    [8.481147]输入:HDA Intel HDMI HDMI/DP、PCM=3 AS /devices/pci0000:00/0000:00:03.0/sound/card0/input16
    [8.481206]输入:HDA Intel HDMI HDMI/DP、PCM=7 AS /devices/pci0000:00/0000:00:03.0/sound/card0/input17
    [8.481257]输入:HDA Intel HDMI HDMI/DP、PCM=8 AS /devices/pci0000:00/0000:00:03.0/sound/card0/input18
    [8.481307]输入:HDA Intel HDMI HDMI/DP、PCM=9 AS /devices/pci0000:00/0000:00:03.0/sound/card0/input19
    [8.481356]输入:HDA Intel HDMI HDMI/DP、PCM=10 AS /devices/pci0000:00/0000:00:03.0/sound/card0/input20
    [8.847401]审核:type=1400审核(1517118349.560:2):AppArmor ="status" operation="profile_load" profile ="unconfined" name="/sbin/dhclient pid=786 comm="apparmor_parser"
    [8.847964]审核:type=1400审核(1517118349.560:3):AppArmor ="status" operation="profile_load" profile ="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action pid=786 comm="apparmor_parser"
    [8.848509]审核:type=1400审核(1517118349.561:4):AppArmor ="status" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-helper pid=786 comm="apparmor_parser"
    [8.848957]审核:type=1400审核(1517118349.561:5):AppArmor ="status" operation="profile_load" profile ="unconfined" name="/usr/lib/connman/scripts/dhclient-script pid=786 comm="apparmor_parser"
    [8.906751]审核:type=1400审核(1517118349619:6):AppArmor ="status" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session pid=783 comm="apparmor_parser"
    [8.907388]审核:type=1400审核(1517118349620:7):AppArmor ="status" operation="profile_load" profile" file="无限制" name="/usr/lib/lightdm/lightdm-guest-session // chromium" pid=783 comm="apparmor_parser"
    [9.010068]审核:type=1400审核(1517118349.723:8):AppArmor ="status" operation="profile_load" profile ="unconfined" name="/usr/sbin/cups-browsed pid=792 comm="apparmor_parser"
    [9.116847]审核:type=1400审核(1517118349.829:9):AppArmor ="status" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine pid=790 comm="apparmor_parser"
    [9.117178]审核:type=1400审核(1517118349.830:10):AppArmor ="status" operation="profile_load" profile ="unconfined" name="/usr/lib/snapd/snap-confine // mount-namespace-capture-helper" pid=790 comm="apparmor_parser"
    [9.117441]审核:type=1400审核(1517118349.830:11):AppArmor ="status" operation="profile_load" profile ="unconfined" name="/usr/lib/snapd/snap-confine //snapp_update_ns" pid=790 comm="apparmor_parser"
    [10.882601]蓝牙:BNEP (以太网仿真) 1.3版
    [10.882603]蓝牙:BNEP 筛选器:协议多播
    [10.882606]蓝牙:BNEP 套接字层已初始化
    [10.990188] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [11.238781] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [11.242102] IPv6:ADDRCONF (NETDEV_UP):ENO1:链路未就绪
    [11.428240] IPv6:ADDRCONF (NETDEV_UP):ENO1:链路未就绪
    [11.502797] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [14.361060]蓝牙:已初始化 RFCOMM TTY 层
    [14.361065]蓝牙:已初始化 RFCOMM 套接字层
    [14.361069]蓝牙:RFCOMM 版本1.11
    [14.901556] FAT-FS (mmcblk0p1):卷未正确卸载。 某些数据可能已损坏。 请运行 fsck。
    [16.717732] Logitech hidpp-device 0003:046D:400A.0004:HID++ 2.0 device connected。
    [18.071693] wlp2s0:使用38:D5:47:1f:E3:D4进行身份验证
    [18.075450] wlp2s0:将 auth 发送到38:D5:47:1f:E3:D4 (尝试1/3)
    [18.076226] wlp2s0:已认证
    [18.080089] wlp2s0:与38:D5:47:1f:E3:D4相关联(请尝试1/3)
    [18.081193] wlp2s0:Rx AssocResp from 38:D5:47:1f:E3:D4 (capab=0x1011 STATUS=0 AID = 1)
    [18.083797] wlp2s0:已关联
    [18.083857] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [22.823729] random:crng init done
    [2550.826381] wlp2s0:无法从硬件(-22)中删除密钥(2,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [2565.778896] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [2590.763611] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [2695.989777] wlp2s0:使用38:D5:47:1f:E3:D4进行身份验证
    [2695.992497] wlp2s0:将 auth 发送到38:D5:47:1f:E3:D4 (尝试1/3)
    [2695.994070] wlp2s0:已认证
    [2695.997608] wlp2s0:与38:D5:47:1f:E3:D4相关联(请尝试1/3)
    [2695.998385] wlp2s0:Rx 等效值从38:D5:47:1f:E3:D4 (capab=0x1011 STATUS=0 AID = 2)
    [2695.999460] wlp2s0:已关联
    [2695.999489] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [2744.287379] show_signal_msg:13个回调被抑制
    [2744.287381] unity-control-c[2631]:segfault at 28 IP 00007f2ddf8032be sp 00007ffd3597a420 error 4 in libfcitx-config.so.4.1[7f2ddf7f9000+14000]
    [7587.27565] RPC:注册后命名为 UNIX 套接字传输模块。
    [7587.275657] RPC:注册的 UDP 传输模块。
    [7587.275657] RPC:注册的 TCP 传输模块。
    [7587.2756598] RPC:注册的 TCP NFSv4.1反向通道传输模块。
    [7587.291224]安装 knfsd (版权所有(C) 1996 okir@monad.swb.de)。
    [7587.309544] NFSD:使用/var/lib/nfs/v4recovery 作为 NFSv4状态恢复目录
    [7587.309557] NFSD:开始90秒宽限期(净额 ffffff9c5edd80)
    [7638.639623] nfsd:最后一台服务器已退出,正在刷新导出高速缓存
    [7639.657266] NFSD:使用/var/lib/nfs/v4recovery 作为 NFSv4状态恢复目录
    [7639.657279] NFSD:开始90秒宽限期(净额 ffffff9c5edd80)
    [7813.598168] mmc0:在传输过程中移除卡!
    [7813.598173] mmc0:重置控制器。
    [7813.598214] mmcblk0:错误-123正在发送状态命令、正在重试
    [7813.598228] mmcblk0:错误-123正在发送状态命令、正在重试
    [7813.598240] mmcblk0:错误-123正在发送状态命令、正在中止
    [7813.616458] FAT-FS (mmcblk0p1):目录面包(块30520)失败
    [7813.616479] FAT-FS (mmcblk0p1):目录面包(块30521)失败
    [7813.616490] FAT-FS (mmcblk0p1):目录试验(块30522)失败
    [7813.616501] FAT-FS (mmcblk0p1):目录试验(块30523)失败
    [7813.620416] FAT-FS (mmcblk0p1):目录试验(块30524)失败
    [7813.632798] FAT-FS (mmcblk0p1):目录面包(块30525)失败
    [7813.652776] FAT-FS (mmcblk0p1):目录试验(块30526)失败
    [7813.657642] FAT-FS (mmcblk0p1):目录试验(块30527)失败
    [7813.661461] FAT-FS (mmcblk0p1):目录试验(块30528)失败
    [7813.661485] FAT-FS (mmcblk0p1):目录面包(块30529)失败
    [7813.800223] mmc0:已卸下1234卡
    [7818.712153] mmc0:地址1234处的新型高速 SDHC 卡
    [7818.716555] mmcblk0:mmc0:1234 SA16G 14.9GiB
    [7818.721458]毫米波0:P1
    [7819.158351] FAT-FS (mmcblk0p1):卷未正确卸载。 某些数据可能已损坏。 请运行 fsck。
    [8712.705501] mmc0:在传输过程中移除了卡!
    [8712.705510] mmc0:重置控制器。
    [8712.705653] mmcblk0:错误-123正在发送状态命令、正在重试
    [8712.705726] mmcblk0:发送状态命令时出错-123、正在重试
    [8712.705780] mmcblk0:错误-123正在发送状态命令、正在中止
    [8712.907549] mmc0:已卸下1234卡
    [8712.907618] FAT-FS (mmcblk0p1):无法读取 inode 块以进行更新(I_pos 133850665)
    [8712.907634] dev mmcblk0p1上的缓冲器 I/O 错误、逻辑块30515、丢失异步页面写入
    [8713.358520] FAT-FS (mmcblk0p1):FAT 读取失败(块子块11348)
    [8717.781052] mmc0:地址1234处的新高速 SDHC 卡
    [8717.781405] mmcblk0:mmc0:1234 SA16G 14.9GiB
    [8717.785024] mmcblk0:P1
    [8718.175327] FAT-FS (mmcblk0p1):卷未正确卸载。 某些数据可能已损坏。 请运行 fsck。
    [8725.230713] FAT-FS (mmcblk0p1):错误、fat_free_clusters:删除 EOF 之外的 FAT 条目
    [8725.230718] FAT-FS (mmcblk0p1):文件系统已设置为只读
    [8735.936895] FAT-FS (mmcblk0p1):目录试验(块30514)失败
    [8735.936906] FAT-FS (mmcblk0p1):目录试验(块30515)失败
    [8735.936910] FAT-FS (mmcblk0p1):目录试验(块30516)失败
    [8735.936915] FAT-FS (mmcblk0p1):目录试验(块30517)失败
    [8735.936918] FAT-FS (mmcblk0p1):目录面包(块30518)失败
    [8735.936922] FAT-FS (mmcblk0p1):目录试验(块30519)失败
    [8735.936926] FAT-FS (mmcblk0p1):目录试验(块30520)失败
    [8735.936930] FAT-FS (mmcblk0p1):目录面包(块30521)失败
    [8735.936934] FAT-FS (mmcblk0p1):目录试验(块30522)失败
    [8735.936938] FAT-FS (mmcblk0p1):目录试验(块30523)失败
    [9328.922415] mmc0:已卸下1234卡
    [9331.308921] mmc0:地址1234处的新高速 SDHC 卡
    [9331.309226] mmcblk0:mmc0:1234 SA16G 14.9GiB
    [9331.313780] mmcblk0:P1
    [9331.696914] FAT-FS (mmcblk0p1):卷未正确卸载。 某些数据可能已损坏。 请运行 fsck。
    [9941.426684] USB USB2-port2:无法启用。 可能是 USB 电缆损坏了?
    [9942.378705] USB USB2-port2:无法启用。 可能是 USB 电缆损坏了?
    [9943.330719] USB USB2-port2:无法启用。 可能是 USB 电缆损坏了?
    [9944.134707] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号7
    [9944.157321] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9944.157326] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9944.157329] USB 2-2:产品:iPhone
    [9944.157332] USB 2-2:制造商:Apple Inc.
    [9944.157334] USB 2-2:Serial Number:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9944.214150] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9944.214244] usbcore:注册的新接口驱动程序 ipheth
    [9944.218083] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9944.2543433] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9944.255587] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9945.113928] USB 2-2:USB 断开连接、器件编号7
    [9945.134640] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9945.666745] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号8
    [9945.808656] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9945.808661] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9945.808665] USB 2-2:产品:iPhone
    [9945.808668] USB 2-2:制造商:Apple Inc.
    [9945.808671] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9945.843873] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9945.846898] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9945.872921] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9945.873868] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9946.259395] USB 2-2:USB 断开连接、器件编号8
    [9946.274676] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9946.574759] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号9
    [9946.716576] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9946.716582] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9946.716585] USB 2-2:产品:iPhone
    [9946.716587] USB 2-2:制造商:Apple Inc.
    [9946.716590] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9946.751777] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9946.767763] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9946.798863] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9946.801660] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9947.178590] USB 2-2:USB 断开连接、器件编号9
    [9947.19533] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9947.498782] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号10
    [9947.641020] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9947.641026] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9947.641029] USB 2-2:产品:iPhone
    [9947.641032] USB 2-2:制造商:Apple Inc.
    [9947.641034] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9947.675245] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9947.681798] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9947.700599] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9947.701189] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9948.100608] USB 2-2:USB 断开连接、器件编号10
    [9948.126694] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9948.228734] usbmux[29929]:10 IP 00007f5b2d9454c0 sp 00007f5b27876638 libpthread-2.23.SO[7f5b2d93a000+18000]中的 segfault 4
    [9948.390667] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号11
    [9948.532373] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9948.532375] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9948.532376] USB 2-2:产品:iPhone
    [9948.532377] USB 2-2:制造商:Apple Inc.
    [9948.532377] USB 2-2:Serial Number:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9948.566792] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9948.572548] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9948.62367] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9948.624222] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9948.993320] USB 2-2:USB 断开连接、器件编号11
    [9949.018731] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9949.282708] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号12
    [9949.424715] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9949.424717] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9949.424718] USB 2-2:产品:iPhone
    [9949.424720] USB 2-2:制造商:Apple Inc.
    [9949.424721] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9949.457212] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9949.461460] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9949.492608] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9949.495303] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9949.873058] USB 2-2:USB 断开连接、器件编号12
    [9949.890715] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9950.190807] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号13
    [9950.332723] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9950.332728] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9950.332731] USB 2-2:产品:iPhone
    [9950.332734] USB 2-2:制造商:Apple Inc.
    [9950.332736] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9950.36782] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9950.373808] ipheth 2-2:4.2 enp0s20u2c4i2:从 eth0重命名
    [9950.403878] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9950.404724] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9950.781642] USB 2-2:USB 断开连接、器件编号13
    [9950.806771] ipheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [9951.070833] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号14
    [9951.212090] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9951.212094] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9951.212096] USB 2-2:产品:iPhone
    [9951.212097] USB 2-2:制造商:Apple Inc.
    [9951.212099] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9951.242021] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9951.245241] ipheth 2-2:4.2 enp0s20u2c4i2:从 eth0重命名
    [9951.272781] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9951.273538] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9951.660433] USB 2-2:USB 断开连接、器件编号为14
    [9951.682740] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9951.946838] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号15
    [9952.088915] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9952.088921] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9952.088924] USB 2-2:产品:iPhone
    [9952.088927] USB 2-2:制造商:Apple Inc.
    [9952.088929] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9952.122366] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9952.125662] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9952.152683] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9952.153341] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9952.538156] USB 2-2:USB 断开连接、器件编号15
    [9952.578737] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9952.842849] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号16
    [9952.984765] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9952.984771] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9952.984774] USB 2-2:产品:iPhone
    [9952.984777] USB 2-2:制造商:Apple Inc.
    [9952.984779] USB 2-2:Serial Number:Aefa4a39f155f4449a8c976e84c7702d88dae8
    [9953.019510A] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9953.025061] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9953.049143] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9953.049727] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9953.447816] USB 2-2:USB 断开连接、器件型号为16
    [9953.462790] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9953.56434] usbmuxd[30174]:segfault at 10 IP 00007fe0fae7ed44 sp 00007fe0f4db1580 error 4 in libpthread-2.23.SO[7fe0fae7500+18000]
    [9953.762870] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号17
    [9953.904574] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9953.904580] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9953.904583] USB 2-2:产品:iPhone
    [9953.904586] USB 2-2:制造商:Apple Inc.
    [9953.904588] USB 2-2:SerialNumber:afeaa4a39f155f4449a8c976e84c7702d88dae8
    [9953.941757] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9953.945488] ipheth 2-2:4.2 enp0s20u2c4i2:从 eth0重命名
    [9953.970101] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9953.970759] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9954.354921] USB 2-2:USB 断开连接、器件编号17
    [9954.378804] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9954.642885] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号18
    [9954.784748] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9954.784754] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9954.784757] USB 2-2:产品:iPhone
    [9954.784759] USB 2-2:制造商:Apple Inc.
    [9954.784762] USB 2-2:Serial Number:Aefa4a39f155f4449a8c976e84c7702d88dae8
    [9954.815927] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9954.820193] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9954.846319] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9954.846966] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9955.233073] USB 2-2:USB 断开连接、器件编号18
    [9955.246796] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9955.348124] usbmux[30241]:10 IP 00007f9b0ae8a4c0 sp 00007f9b04db638 libpthread-2.23.SO[7f9b07f000+18000]中的 segfault
    [9955.546908] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号19
    [9955.688389] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9955.688395] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9955.688398] USB 2-2:产品:iPhone
    [9955.688401] USB 2-2:制造商:Apple Inc.
    [9955.688403] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9955.723878] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9955.730326] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9955.756502] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9955.757223] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9956.139079] USB 2-2:USB 断开连接、器件编号19
    [9956.154837] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9956.454883] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号20
    [9965.911005] USB 2-2:器件描述符读取/64、错误-110
    [9966.160580] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9966.160586] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9966.160589] USB 2-2:产品:iPhone
    [9966.160591] USB 2-2:制造商:Apple Inc.
    [9966.160594] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9966.245916] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9966.251895] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9966.280748] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9966.281846] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9976.723785] USB 2-2:USB 断开连接、器件编号20
    [9976.747143] IPheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9977.015177] USB 2-2:使用 xhci_hcd 的21号新型高速 USB 器件
    [9977.156860] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9977.156864] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9977.156866] USB 2-2:产品:iPhone
    [9977.1568686868] USB 2-2:制造商:Apple Inc.
    [9977.156870] USB 2-2:Serial Number:Aefa4a39f155f4449a8c976e84c7702d88dae8
    [9977.191520] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9977.195547] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9977.224629] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9977.225316] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9977.617111] USB 2-2:USB 断开连接、器件型号为21
    [9977.647176] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9977.915110] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号22
    [9978.056327] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9978.056332] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9978.056335] USB 2-2:产品:iPhone
    [9978.056338] USB 2-2:制造商:Apple Inc.
    [9978.056341] USB 2-2:SerialNumber:afa4a39f155f4449a8c976e84c7702d88dae8
    [9978.098893] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9978.102995] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9978.130028] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9978.130903] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9978.505228] USB 2-2:USB 断开连接、器件编号为22
    [9978.531150] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9978.799246] USB 2-2:使用 xhci_hcd 的23号新高速 USB 器件
    [9978.941306] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9978.941312] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9978.941315] USB 2-2:产品:iPhone
    [9978.941317] USB 2-2:制造商:Apple Inc.
    [9978.941320] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9978.974117] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9978.980717] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9979.008598] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9979.009215] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9979.396617] USB 2-2:USB 断开连接、器件型号23
    [9979.415149] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9979.727184] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号24
    [9979.868622] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9979.868628] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9979.868631] USB 2-2:产品:iPhone
    [9979.868634] USB 2-2:制造商:Apple Inc.
    [9979.868636] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9979.906841] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9979.911246] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9979.937250] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9979.943859] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9980.329117] USB 2-2:USB 断开连接、器件编号24
    [9980.355177] IPheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9980.619155] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号25
    [9980.761492] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9980.761498] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9980.761501] USB 2-2:产品:iPhone
    [9980.761503] USB 2-2:制造商:Apple Inc.
    [9980.761505] USB 2-2:Serial Number:Aefa4a39f155f4449a8c976e84c7702d88dae8
    [9980.797651] IPheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9980.812725] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9980.837249] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9980.837926] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9981.221766] USB 2-2:USB 断开连接、器件型号为25
    [9981.251176] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9981.527221] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件、编号为26
    [9981.669009] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9981.669013] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9981.669015] USB 2-2:产品:iPhone
    [9981.669017] USB 2-2:制造商:Apple Inc.
    [9981.669019] USB 2-2:SerialNumber:afa4a39f155f4449a8c976e84c7702d88dae8
    [9981.701649] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9981.70633] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9981.733696] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9981.734497] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9982.118199] USB 2-2:USB 断开连接、器件型号26
    [9982.131194] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9982.435238] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号27
    [9982.576907] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9982.576910] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9982.576913] USB 2-2:产品:iPhone
    [9982.576914] USB 2-2:制造商:Apple Inc.
    [9982.576916] USB 2-2:Serial Number:Aefa4a39f155f4449a8c976e84c7702d88dae8
    [9982.608955] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9982.614023] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9982.644864] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9982.645479] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9983.025844] USB 2-2:USB 断开连接、器件型号27
    [9983.043234] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9983.351214] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号28
    [9983.497103] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9983.497108] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9983.497111] USB 2-2:产品:iPhone
    [9983.497113] USB 2-2:制造商:Apple Inc.
    [9983.497116] USB 2-2:串行号:Aefa4a39f155f4449a8c976e84c7702d88dae8
    [9983.535753] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9983.542329] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9983.567926] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9983.570491] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9983.947743] USB 2-2:USB 断开连接、器件型号28
    [9983.975218] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9984.239279] USB 2-2:使用 xhci_hcd 的29号新高速 USB 器件
    [9984.381158] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9984.381162] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9984.381164] USB 2-2:产品:iPhone
    [9984.381165] USB 2-2:制造商:Apple Inc.
    [9984.381167] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9984.417773] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9984.424591] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9984.449258] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9984.449885] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9984.832315] USB 2-2:USB 断开连接、器件编号29
    [9984.859241] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9985.123318] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号30
    [9985.264799] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9985.264804] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9985.264806] USB 2-2:产品:iPhone
    [9985.264808] USB 2-2:制造商:Apple Inc.
    [9985.264810] USB 2-2:Serial Number:Aefa4a39f155f4449a8c976e84c7702d88dae8
    [9985.301955] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9985.309887] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9985.337022] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9985.337681] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9985.713185] USB 2-2:USB 断开连接、器件编号30
    [9985.731243] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9986.031233] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号31
    [9986.172832] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9986.172837] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9986.172839] USB 2-2:产品:iPhone
    [9986.172841] USB 2-2:制造商:Apple Inc.
    [9986.172843] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9986.207697] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9986.211669] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9986.237146] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9986.237758] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9986.622953] USB 2-2:USB 断开连接、器件编号31
    [9986.643257] IPheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9986.943266] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号32
    [9987.084932] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9987.084938] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9987.084941] USB 2-2:产品:iPhone
    [9987.084944] USB 2-2:制造商:Apple Inc.
    [9987.084946] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9987.119561] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9987.131621] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9987.164686] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9987.165353] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9990.920704] USB 2-2:USB 断开连接、器件编号32
    [9990.939319] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9991.239364] USB 2-2:使用 xhci_hcd 的33号新高速 USB 设备
    [9991.380948] USB 2-2:找到新的 USB 设备,idVendor=05ac,idProduct=12a8
    [9991.380953] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9991.380956] USB 2-2:产品:iPhone
    [9991.380959] USB 2-2:制造商:Apple Inc.
    [9991.380962] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9991.413653] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9991.427221] ipheth 2-2:4.2 enp0s20u2c4i2:从 eth0重命名
    [9991.461198] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9991.461808] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9991.840646] USB 2-2:USB 断开连接、器件编号33
    [9991.867388] ipheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [9992.1380] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号34
    [9992.27334] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9992.273381] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [9992.27384] USB 2-2:产品:iPhone
    [9992.273387] USB 2-2:制造商:Apple Inc.
    [9992.27339] USB 2-2:SerialNumber:afa4a39f155f4449a8c976e84c7702d88dae8
    [9992.310600] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9992.312851] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9992.33830] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9992.336438] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9992.733345] USB 2-2:USB 断开连接、器件编号34
    [9992.759362] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9993.027916] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号35
    [9993.168893] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9993.168895] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9993.168897] USB 2-2:产品:iPhone
    [9993.168898] USB 2-2:制造商:Apple Inc.
    [9993.168899] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9993.199417] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9993.216164] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9993.236394] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9993.237357] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9993.629187] USB 2-2:USB 断开连接、器件型号35
    [9993.643360] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [9993.947379] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号36
    [9994.089441] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [9994.089445] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [9994.089447] USB 2-2:产品:iPhone
    [9994.089449] USB 2-2:制造商:Apple Inc.
    [9994.089450] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [9994.125734] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [9994.134420] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [9994.1613] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9994.163287] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [9994.532205] USB 2-2:USB 断开连接、器件编号36
    [9995.599483] ipheth 2-2:4.2:iphet_carrier_set:USB_control_msg:-19
    [9996.591497] ipheth 2-2:4.2:iphth_carrier_set:USB_control_msg:-19
    [9997.615468] ipheth 2-2:4.2:iphet_carrier_set:USB_control_msg:-19
    [9998.607483] ipheth 2-2:4.2:iphet_carrier_set:USB_control_msg:-19
    [9999.599477] ipheth 2-2:4.2:iphet_carrier_set:USB_control_msg:-19.
    [9999.651460] ipheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [9999.919510] USB 2-2:使用 xhci_hcd 的37号新高速 USB 器件
    [10000.061942] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10000.061947] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [10000.061950] USB 2-2:产品:iPhone
    [10000.061953] USB 2-2:制造商:Apple Inc.
    [10000.061956] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10000.099826] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10000.109003] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10000.137098] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10000.138031] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10000.517706] USB 2-2:USB 断开连接、器件编号37
    [10000.531459] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [10000.632814] usbmux[30972]:10 IP 00007fb85bba8d44 sp 00007fb855adb630中的 segfault 错误4 libpthread-2.23.SO[7fb85bb9f000+18000]
    [10000.831522] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号38
    [10000.973522] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10000.973528] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [10000.973531] USB 2-2:产品:iPhone
    [10000.973533] USB 2-2:制造商:Apple Inc.
    [10000.973536] USB 2-2:Serial Number:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10001.009871] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10001.019103] ipheth 2-2:4.2 enp0s20u2c4i2:从 eth0重命名
    [10001.041986] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10001.042985] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10001.434350] USB 2-2:USB 断开连接、器件编号38
    [10001.451506] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [10001.755516] USB 2-2:使用 xhci_hcd 的39号新高速 USB 器件
    [10001.897099] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10001.897104] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [10001.897107] USB 2-2:产品:iPhone
    [10001.897109] USB 2-2:制造商:Apple Inc.
    [10001.897112] USB 2-2:Serial Number:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10001.932201] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10001.943809] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10001.972697] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10001.973403] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10002.356706] USB 2-2:USB 断开连接、器件编号39
    [10002.371518] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [10002.671527] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号40
    [10002.817481] USB 2-2:找到新的 USB 器件、idVendor=05ac、idProduct=12a8
    [10002.817486] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [10002.817489] USB 2-2:产品:iPhone
    [10002.817491] USB 2-2:制造商:Apple Inc.
    [10002.817494] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10002.850892] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10002.854634] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10002.874741] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10002.876243] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10003.278071] USB 2-2:USB 断开连接、器件编号40
    [10003.295513] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [10003.595518] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号41
    [10003.737335] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10003.737337] USB 2-2:新 USB 器件串:MFR=1、Product=2、SerialNumber=3
    [10003.737338] USB 2-2:产品:iPhone
    [10003.737340] USB 2-2:制造商:Apple Inc.
    [10003.737340] USB 2-2:Serial Number:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10003.769545] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10003.782298] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10003.805923] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10003.807067] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10004.199319] USB 2-2:USB 断开连接、器件编号41
    [10004.227525] ipheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [10004.491550] USB 2-2:使用 xhci_hcd 的42号新高速 USB 器件
    [10004.633088] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10004.633094] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [10004.633097] USB 2-2:产品:iPhone
    [10004.633100] USB 2-2:制造商:Apple Inc.
    [10004.633103] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10004.668323] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10004.673185] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10004.698021] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10004.698896] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10005.093935] USB 2-2:USB 断开连接、器件编号42
    [10005.107537] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [10005.407633] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号43
    [10005.549511] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10005.549516] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [10005.549519] USB 2-2:产品:iPhone
    [10005.549522] USB 2-2:制造商:Apple Inc.
    [10005.549524] USB 2-2:串行号:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10005.585661] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10005.590933] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10005.614692] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10005.616005] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10006.010277] USB 2-2:USB 断开连接、器件编号43
    [10006.023547] ipheth 2-2:4.2:Apple iPhone USB 以太网已断开连接
    [10006.323547] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号44
    [10006.465511] USB 2-2:找到新的 USB 器件、idVendor=05ac、idProduct=12a8
    [10006.465516] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [10006.465518] USB 2-2:产品:iPhone
    [10006.465520] USB 2-2:制造商:Apple Inc.
    [10006.465522] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10006.5016] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10006.504724] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10006.523193] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10006.523856] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10006.925381] USB 2-2:USB 断开连接、器件编号44
    [10006.947560] ipheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [10007.211612] USB 2-2:使用 xhci_hcd 的45号新高速 USB 器件
    [10007.353476] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10007.353480] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [10007.353483] USB 2-2:产品:iPhone
    [10007.353484] USB 2-2:制造商:Apple Inc.
    [10007.353486] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10007.385610] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10007.389865] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10007.425445] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10007.426056] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10007.809468] USB 2-2:USB 断开连接、器件编号45
    [10007.843559] ipheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [10008.107643] USB 2-2:使用 xhci_hcd 的新型高速 USB 器件编号46
    [10008.249499] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10008.249502] USB 2-2:新 USB 设备字符串:MFR=1、Product=2、SerialNumber=3
    [10008.249504] USB 2-2:产品:iPhone
    [10008.249505] USB 2-2:制造商:Apple Inc.
    [10008.249507] USB 2-2:Serial Number:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10008.283723] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10008.289382] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10008.313577] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10008.314634] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10008.690736] USB 2-2:USB 断开连接、器件编号46
    [10008.715597] IPheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [10008.979655] USB 2-2:使用 xhci_hcd 的全新高速 USB 器件编号47
    [10009.124181] USB 2-2:找到新的 USB 设备、idVendor=05ac、idProduct=12a8
    [10009.124186] USB 2-2:新 USB 器件字符串:MFR=1、Product=2、SerialNumber=3
    [10009.124188] USB 2-2:产品:iPhone
    [10009.124190] USB 2-2:制造商:Apple Inc.
    [10009.124192] USB 2-2:SerialNumber:eafa4a39f155f4449a8c976e84c7702d88dae8
    [10009.157778] ipheth 2-2:4.2:已连接 Apple iPhone USB 以太网设备
    [10009.162743] ipheth 2-2:4.2 enp0s20u2c4i2:已从 eth0重命名
    [10009.186263] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10009.186932] IPv6:ADDRCONF (NETDEV_UP):enp0s20u2c4i2:链路未就绪
    [10009.225577] ipheth 2-2:4.2:iphth_rcvbulk_callback:URB 状态:-71
    [10009.227444] USB 2-2:USB 断开连接、器件编号47
    [10009.255603] IPheth 2-2:4.2:Apple iPhone USB 以太网现已断开连接
    [10178.760378] mmcblk0:发送状态命令时出错-110、正在重试
    [10178.760461] mmcblk0:错误-110正在发送状态命令、正在重试
    [10178.760540] mmcblk0:错误-110正在发送状态命令、正在中止
    [10183.424797] mmc0:在传输过程中移除卡!
    [10183.424800] mmc0:重置控制器。
    [10183.426945] mmc0:尝试重置卡、得到错误-123
    [10183.426948] print_req_error:I/O error、dev mmcblk0、sector 1122258
    [10183.426954] print_req_error:I/O error、dev mmcblk0、扇区1122266
    [10183.426958] print_req_error:I/O error、dev mmcblk0、sector 1122274
    [10183.426962] print_req_error:I/O error、dev mmcblk0、扇区1122282
    [10183.426965] print_req_error:I/O error、dev mmcblk0、sector 1122290
    [10183.426969] print_req_error:I/O error、dev mmcblk0、扇区1122298
    [10183.426972] print_req_error:I/O error、dev mmcblk0、扇区1122306
    [10183.426975] print_req_error:I/O error、dev mmcblk0、扇区1122314
    [10183.426979] print_req_error:I/O error、dev mmcblk0、扇区1122322
    [10183.426982] print_req_error:I/O error、dev mmcblk0、sector 1122330
    [10183.427433] mmcblk0:发送状态命令时出错-123、正在重试
    [10183.427444] mmcblk0:错误-123正在发送状态命令、正在重试
    [10183.427455] mmcblk0:错误-123正在发送状态命令、正在中止
    [10183.441628] FAT-FS (mmcblk0p1):fat_cluster_flush 中的面包失败
    [10183.506079] FAT-FS (mmcblk0p1):FAT 读取失败(8.块 knr 1569)
    [10183.506105] FAT-FS (mmcblk0p1):FAT 读取失败(8.13 knr 1172)
    [10183.606367] FAT-FS (mmcblk0p1):目录面包(块30516)失败
    [10183.626027] mmc0:已卸下1234卡
    [10183.626149] FAT-FS (mmcblk0p1):fat_cluster_flush 中的面包失败
    [10183.822037] FAT-FS (mmcblk0p1):FAT 读取失败(块11位错误1172)
    [10184.178605] FAT-FS (mmcblk0p1):FAT 读取失败(块子地址13880)
    [10184.186469] mmc0:地址1234处的新高速 SDHC 卡
    [10184.186622] mmcblk0:mmc0:1234 SA16G 14.9GiB
    [10184.187793] mmcblk0:P1
    [10184.576592] FAT-FS (mmcblk0p1):卷未正确卸载。 某些数据可能已损坏。 请运行 fsck。
    [10366.319919] wlp2s0:通过本地选择从38:D5:47:1f:E3:D4进行身份验证(原因:3=DEAUTH_LEASING)
    [10366.325817] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [10366.325894] wlp2s0:无法从硬件(-22)中删除密钥(2、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [10378.324185] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [10378.327352] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (尝试1/3)
    [10378.341126] wlp2s0:已认证
    [10378.344149] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [10378.360538] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status=0 AID = 1)
    [10378.362420] wlp2s0:已关联
    [10378.416937] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [10965.316261] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEASING)
    [10965.322730] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [10968.504113] wlp2s0:使用38:D5:47:1f:E3:D4进行身份验证
    [10968.508718] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试1/3)
    [10968.509848] wlp2s0:已认证
    [10968.513926] wlp2s0:与38:D5:47:1f:E3:D4相关联(请尝试1/3)
    [10968.514802] wlp2s0:来自38:D5:47:1f:E3:D4的 RX 等效值(capab=0x1011 STATUS=0 AID = 1)
    [10968.515823] wlp2s0:已关联
    [11019.006224 ] wlp2s0:通过本地选项从38:D5:47:1f:E3:D4进行身份验证(原因:3=DEAUTH_LEASING)
    [11019.011997] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [11023.787692] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [11023.790069] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [11023.792604] wlp2s0:已认证
    [11023.798060] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [11023.801716] wlp2s0:Rx 等效值从38:D5:47:1f:E3:d0 (capab=0x1411 STATUS=0 AID = 2)
    [11023.803232] wlp2s0:已关联
    [11041.055023] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0取消身份验证(原因:3=DEAUTH_LEFING)
    [11041.060258] wlp2s0:无法从硬件(-22)中删除密钥(1,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [11044.243081] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [11044.246663] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [11044.249215] wlp2s0:已认证
    [11044.250256] wlp2s0:与 A2:be:05:4e:73:97关联(请尝试1/3)
    [11044.354216] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试2/3)
    [11044.358139] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status=0 AID = 1)
    [11044.361497] wlp2s0:已关联
    [11044.376854] wlp2s0:已从 A2:be:05:4e:73:97中取消认证(原因:2=PREV_AUTH_NOT _VALID)
    [11046.845125] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [11046.847343] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [11046.866982] wlp2s0:已通过身份验证
    [11046.870241] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [11046.892111] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [11046.896412] wlp2s0:已关联
    [11047.005741] wlp2s0:从 A2:be:05:4e:73:97中取消认证(原因:2=PREV_AUTH_NOT _ VALID)
    [11053.311038] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [11053.314001] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [11053.326249] wlp2s0:已认证
    [11053.330275] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [11053.337082] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [11053.338630] wlp2s0:已关联
    [11053.435139] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [11823.091380] USB 1-1.3:USB 断开连接、器件编号3
    [187.986103] PERF:中断时间过长(2527 > 2500)、将 kernel.perf_event_max_sample_rate 降低至79000
    [26072.618946] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEFING)
    [26072.633295] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26072.633346] wlp2s0:无法从硬件(-22)中删除密钥(2,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26075.705616] wlp2s0:使用38:D5:47:1f:E3:D4进行身份验证
    [26075.709941] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试1/3)
    [26075.713091] wlp2s0:已通过认证
    [26075.713875] wlp2s0:与38:D5:47:1f:E3:D4相关联(请尝试1/3)
    [26075.714666] wlp2s0:来自38:D5:47:1f:E3:D4的 RX 等效值(capab=0x1011 STATUS=0 AID = 2)
    [26075.715859] wlp2s0:已关联
    [26099.470722] wlp2s0:通过本地选择从38:D5:47:1f:E3:D4进行身份验证(原因:3=DEAUTH_LEFING)
    [26099.483663] wlp2s0:无法从硬件(-22)中删除密钥(2、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26102.561257] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [26102.564601] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [26102.567919] wlp2s0:已认证
    [26102.568884] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [26102.572459] wlp2s0:Rx 等效值从38:D5:47:1f:E3:d0 (capab=0x1411 STATUS=0 AID = 3)
    [26102.574184] wlp2s0:已关联
    [26254.732484] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0取消身份验证(原因:3=DEAUTH_LEFING)
    [26254.745820] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26280.013497] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [26283.088403] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [26283.091349] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [26283.093936] wlp2s0:已认证
    [26283.097689] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [26283.101255] wlp2s0:来自38:D5:47:1f:E3:d0的 RX 等效值(capab=0x1411 STATUS=0 AID = 3)
    [26283.106396] wlp2s0:已关联
    [26283.10649] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [26319.086819] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0取消身份验证(原因:3=DEAUTH_LEFING)
    [26319.094490] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26321.823986] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [26322.177947] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [26322.181185] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [26322.187217] wlp2s0:已认证
    [26322.191256] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [26322.195729] wlp2s0:来自38:D5:47:1f:E3:d0的 RX 等效值(capab=0x1411 STATUS=0 AID = 3)
    [26322.199853] wlp2s0:已关联
    [26322.199895] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [26324.755896] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0进行身份验证(原因:3=DEAUTH_LEFING)
    [26324.774745] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26327.857288] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [26327.860643] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [26327.867093] wlp2s0:已认证
    [26327.867782] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [26327.874166] wlp2s0:来自 A2:be:05:4e:73:97的 RX AssocResp (capab=0x411 status=0 AID = 1)
    [26327.87563] wlp2s0:已关联
    [26328.170171] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [26623.435986] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEFING)
    [26623.441515] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26626.524132] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [26626.528161] wlp2s0:将 auth 发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [26626.532834] wlp2s0:已认证
    [26626.534546] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [26626.538138] wlp2s0:Rx 等效值从38:D5:47:1f:E3:d0 (capab=0x1411 STATUS=0 AID = 3)
    [26626.542030] wlp2s0:已关联
    [26680.110092] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0进行身份验证(原因:3=DEAUTH_LEFING)
    [26680.115729] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [26683.200889] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [26683.204157] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [26683.208691] wlp2s0:已通过身份验证
    [26683.212611] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [26683.219021] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [26683.219644] wlp2s0:已关联
    [26683.285382] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [27262.619705] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEASING)
    [27262.633931] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [27262.634043] wlp2s0:无法从硬件(-22)中删除密钥(2、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [27265.719409] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [27265.725028] wlp2s0:将 auth 发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [27265.730318] wlp2s0:已通过身份验证
    [27265.737121] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [27265.740735] wlp2s0:Rx AssocResp、范围为38:D5:47:1f:E3:d0 (capab=0x1411 STATUS=0 AID = 4)
    [27265.74949495] wlp2s0:已关联
    [27282.793628] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0取消身份验证(原因:3=DEAUTH_LEFING)
    [27282.807623] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [27285.893446] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [27285.897053] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [27285.899652] wlp2s0:已通过身份验证
    [27285.900992] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [27285.907380] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [27285.908736] wlp2s0:已关联
    [27285.999723] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [29746.413684] perf:中断时间过长(3159 > 3158)、将 kernel.perf_event_max_sample_rate 降低到63250
    [36826.483438] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEASING)
    [36826.489513] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [36826.489563] wlp2s0:无法从硬件(-22)中删除密钥(2、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [3629.364721] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [36829.368685] wlp2s0:将 auth 发送到38:D5:47:1f:E3:d0 (请尝试1/3)
    [36829.371421] wlp2s0:已通过身份验证
    [368229.372198] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [368229.375776] wlp2s0:Rx 等效值从38:D5:47:1f:E3:d0 (capab=0x1411 STATUS=0 AID = 2)
    [36829.38668] wlp2s0:已关联
    [36864.438065] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0进行身份验证(原因:3=DEAUTH_LEFING)
    [36864.443785] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [36867.327626] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [36867.331930] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [36867.335806] wlp2s0:已认证
    [36867.337939] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [36867.347178] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [36867.347714] wlp2s0:已关联
    [36867.384599] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [39372.322545] PCI_BUS 0000:01:分配资源
    [39372.322571] pcieport 0000:00:1c.0:桥接窗口[IO 0x1000-0x0fff]至[bus 01] add_size 1000
    [39372.322577] pcieport 0000:00:1c.0:桥接窗口[mem 0x00100000-0x000fff 64位 pref]至[bus 01] add_size 200000 add_align 100000
    [39372.322582] pcieport 0000:00:1c.0:桥接窗口[mem 0x00100000-0x000fff]至[bus 01] add_size 200000 add_align 100000
    [39372.322598] PCI_BUS 0000:02:分配资源
    [39372.322665] pcieport 0000:00:1c.3:桥接窗口[IO 0x1000-0x0fff]至[bus 02] add_size 1000
    [39372.322670] pcieport 0000:00:1c.3:将网桥窗口[mem 0x00100000-0x000fff 64位 pref]更改为[bus 02] add_size 200000 add_align 100000
    [39372.322686] PCI_BUS 0000:03:分配资源
    [39372.325175] pcieport 0000:00:1c.4:桥接窗口[IO 0x1000-0x0fff]至[bus 03] add_size 1000
    [39372.325179] pcieport 0000:00:1c.4:桥接窗口[mem 0x00100000-0x000fff 64位 pref]至[bus 03] add_size 200000 add_align 100000
    [39372.325191] pcieport 0000:00:1c.0:bar 14:已分配[mem 0xdf200000-0xdf3fff]
    [39372.325198] pcieport 0000:00:1c.0:bar 15:已分配[mem 0xdf400000-0xdf5fff 64位 pref]
    [39372.325203] pcieport 0000:00:1c.3:bar 15:已分配[mem 0xdf600000-0xdf7fff 64位 pref]
    [39372.325208] pcieport 0000:00:1c.4:bar 15:已分配[mem 0xdf800000-0xdf9fff 64位 pref]
    [39372.325211] pcieport 0000:00:1c.0:bar 13:已分配[IO 0x2000-0x2fff]
    [39372.325214] pcieport 0000:00:1c.3:bar 13:已分配[IO 0x3000-0x3fff]
    [39372.325216] pcieport 0000:00:1c.4:bar 13:已分配[IO 0x4000-0x4fff]
    [39372.32688] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [39376.713946] PCI_BUS 0000:01:分配资源
    [39376.713963] PCI_BUS 0000:02:分配资源
    [39376.713991] PCI_BUS 0000:03:分配资源
    [39376.717943] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [39405.993479] PCI_BUS 0000:01:分配资源
    [39405.993507] PCI_BUS 0000:02:分配资源
    [39405.993582] PCI_BUS 0000:03:分配资源
    [39405.998084] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [39413.073882] PCI_BUS 0000:01:分配资源
    [39413.073913] PCI_BUS 0000:02:分配资源
    [39413.074051] PCI_BUS 0000:03:分配资源
    [39413.078671] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [39417.953506] PCI_BUS 0000:01:分配资源
    [39417.953520] PCI_BUS 0000:02:分配资源
    [39417.953587] PCI_BUS 0000:03:分配资源
    [39417.955779] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [40197.767155] PCI_BUS 0000:01:分配资源
    [40197.767173] PCI_BUS 0000:02:分配资源
    [40197.767242] PCI_BUS 0000:03:分配资源
    [40197.771749] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [40203.585581] PCI_BUS 0000:01:分配资源
    [40203.585597] PCI_BUS 0000:02:分配资源
    [40203.58566] PCI_BUS 0000:03:分配资源
    [40203.590217] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [40475.798318] PCI_BUS 0000:01:分配资源
    [40475.798337] PCI_BUS 0000:02:分配资源
    [40475.798406] PCI_BUS 0000:03:分配资源
    [40475.802743] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [40900.247775] PCI_BUS 0000:01:分配资源
    [40900.247804] PCI_BUS 0000:02:分配资源
    [40900.247879] PCI_BUS 0000:03:分配资源
    [40900.252781] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [48954.724602] perf:中断花费的时间过长(3975 > 3948)、将 kernel.perf_event_max_sample_rate 降至50250
    [59858.805926] PCI_BUS 0000:01:分配资源
    [59858.805955] PCI_BUS 0000:02:分配资源
    [59858.806030] PCI_BUS 0000:03:分配资源
    [59858.810937] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [59869.545530] PCI_BUS 0000:01:分配资源
    [59869.545547] PCI_BUS 0000:02:分配资源
    [59869.545615] PCI_BUS 0000:03:分配资源
    [59869.549500] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [59974.518806] PCI_BUS 0000:01:分配资源
    [59974.518828] PCI_BUS 0000:02:分配资源
    [59974.518900] PCI_BUS 0000:03:分配资源
    [59974.523866] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [60482.040741] PCI_BUS 0000:01:分配资源
    [60482.040756] PCI_BUS 0000:02:分配资源
    [60482.040821] PCI_BUS 0000:03:分配资源
    [60482.043088] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [69367.015556] PCI_BUS 0000:01:分配资源
    [69367.015577] PCI_BUS 0000:02:分配资源
    [69367.015649] PCI_BUS 0000:03:分配资源
    [69367.020113] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [70380.3555573] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEASING)
    [70380.361071] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [70380.361107] wlp2s0:无法从硬件(-22)中删除密钥(2,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [70383.437173] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [70383.441773] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [70383.445128] wlp2s0:已通过身份验证
    [70383.446866] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [70383.450427] wlp2s0:Rx AssocResp from 38:D5:47:1f:E3:d0 (capab=0x1411 STATUS=0 AID = 3)
    [70383.452453] wlp2s0:已关联
    [70406.893976] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0取消身份验证(原因:3=DEAUTH_LEFING)
    [70406.908357] wlp2s0:无法从硬件(-22)中删除密钥(2,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [70406.922376] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [70409.980059] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [70409.983448] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [70409.987494] wlp2s0:已认证
    [70409.989765] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [70409.993338] wlp2s0:来自38:D5:47:1f:E3:d0的 RX 等效值(capab=0x1411 STATUS=0 AID = 3)
    [70409.997264] wlp2s0:已关联
    [70409.997322] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [70413.437214] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0进行身份验证(原因:3=DEAUTH_LEFING)
    [70413.492762] wlp2s0:无法从硬件(-22)中删除密钥(2、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [70416.822880] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [70416.826421] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [70416.833884] wlp2s0:已通过身份验证
    [70416.837473] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [70416.843977] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [70416.853443] wlp2s0:已关联
    [70416.877375] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [70433.916799] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEASING)
    [70433.923457] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [70433.923497] wlp2s0:无法从硬件(-22)中删除密钥(2,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [70437.017147] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [70437.021284] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (请尝试1/3)
    [70437.026893] wlp2s0:已认证
    [70437.028654] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [70437.032224] wlp2s0:来自38:D5:47:1f:E3:d0的 RX 等效值(capab=0x1411 STATUS=0 AID = 3)
    [70437.037270] wlp2s0:已关联
    [70456.320884] PCI_BUS 0000:01:分配资源
    [70456.320913] PCI_BUS 0000:02:分配资源
    [70456.320986] PCI_BUS 0000:03:分配资源
    [70456.325811] ACPI 设备:40:无法转换为父设备的电源状态 D3HOT (未知)
    [73618.108233] wlp2s0:通过本地选择从38:D5:47:1f:E3:d0进行身份验证(原因:3=DEAUTH_LEFING)
    [73618.130637] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [73618.131124] wlp2s0:无法从硬件(-22)中删除密钥(2,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [73619.997222] PM:正在同步文件系统... 完成。
    [73620.00494] PM:准备系统进入睡眠模式(MEM)
    [73620.008402]冻结用户空间进程... (已过0.002秒)完成。
    [73620.010549]禁用杀手锏。
    [73620.010549]冻结剩余可自由运行的任务... (已用0.001秒)。
    [73620.011819] PM:暂停系统(MEM)
    [73620.011857]暂停控制台(使用 NO_console_suspend 进行调试)
    [73620.014088] SD 3:0:0:[SDA]同步 SCSI 缓存
    [73620.022497] SD 3:0:0:[SDA]停止磁盘
    [73620.033951] e1000e:EEE TX LPI 计时器:00000011
    [73620.034089]删除了 pn544
    [73620.456419] PM:444.394毫秒后器件挂起完成
    [73620.476494] PM:20.072ms 后器件延迟挂起完成
    [73620.503623] PM:27.125ms 后器件挂起完成
    [73620.504690] ACPI:准备进入系统睡眠状态 S3
    [73620.548969] ACPI:EC:事件被阻止
    [73620.548971] ACPI:EC:EC 已停止
    [73620.548972] PM:节省平台 NVS 内存
    [73620.549003]正在禁用非引导 CPU ...
    [73620.565279] IRQ 45:不再与 CPU1关联
    [73620.566443] smpboot:CPU 1现在脱机
    [73620.589436] IRQ 42:不再与 CPU2关联
    [73620.589444] IRQ 43:不再与 CPU2关联
    [73620.590543] smpboot:CPU 2现在脱机
    [73620.613344] IRQ 1:不再与 CPU3关联
    [73620.61336] IRQ 8:不再与 CPU3关联
    [73620.613370] IRQ 9:不再与 CPU3关联
    [73620.613376] IRQ 12:不再与 CPU3关联
    [73620.613382] IRQ 18:不再与 CPU3关联
    [73620.613388] IRQ 21:不再与 CPU3关联
    [73620.613422] IRQ 48:不再与 CPU3关联
    [73620.614472] smpboot:CPU 3现在脱机
    [73620.617813] ACPI:完成低级恢复
    [73620.617883] ACPI:EC:EC 已启动
    [73620.617883] PM:恢复平台 NVS 内存
    [73620.618205]暂停45.645秒
    [73620.619982]正在启用非引导 CPU ...
    [73620.620038] x86:引导 SMP 配置:
    [73620.620039] smpboot:正在引导节点0处理器1 APIC 0x2
    [73620.621487]高速缓存:父 CPU1不应处于睡眠状态
    [73620.621657] CPU1已启动
    [73620.621682] smpboot:正在引导节点0处理器2 APIC 0x1
    [73620.623091]高速缓存:父 CPU2不应处于睡眠状态
    [73620.623230] CPU2已启动
    [73620.623255] smpboot:正在引导节点0处理器3 APIC 0x3
    [73620.624604]高速缓存:父 CPU3不应处于睡眠状态
    [73620.624798] CPU3已启动
    [73620.628205] ACPI:从系统睡眠状态 S3唤醒
    [73621.492886] PM:24.667毫秒后器件恢复完成
    [73621.493523] PM:0.598ms 后器件的早期恢复完成
    [73621.493639] USB USB2:根集线器断电或复位
    [73621.493643] USB USB3:根集线器断电或复位
    [73621.493677] ACPI:EC:事件未被阻止
    [73621.498221] SD 3:0:0:0:[SDA]启动磁盘
    [73621.502163] ME_ME 0000:00:16.0:NFC MEI 版本:IVN 0x1供应商 ID 0x1类型0x1
    [73621.576264] ACPI 错误:索引值0x000000000083溢出字段宽度0x7 (20170531/exfldio-343)
    [73621.576268] ACPI 错误:方法解析/执行失败\NEVT、AE_AML_REGISTER_LIMIT (20170531/ps稀 疏-550)
    [73621.576312] ACPI 错误:方法解析/执行失败\_SB.PCI0.LPCC.ECDV._Q66、AE_AML_REGISTER_LIMIT (20170531/pSPARE-550)
    [73621.735481] USB 1-1:使用 EHI-PCI 重置高速 USB 器件编号2
    [73621.810404] ata1:SATA link down (sStatus 0 SControl 300)
    [73621.810427] AA2:SATA link down (sStatus 0 SControl 300)
    [73621.810549] ATA4:SATA 链路速率高达6.0 Gbps (sStatus 133 SControl 300)
    [73621.812885] ata4.00:不支持 NCQ 发送/接收日志
    [73621.813691] ata4.00:不支持 NCQ 发送/接收日志
    [73621.813778] ata4.00:针对 UDMA/133配置
    [73621.915527] USB 2-4:使用 xhci_hcd 重置高速 USB 器件编号2
    [73622.175528] USB 2-6:使用 xhci_hcd 重置全速 USB 器件编号3
    [73622.395767] PM:902.263毫秒后器件恢复完成
    [73622.395944] PM:正在完成唤醒。
    [73622.395945]启用了室内杀手。
    [73622.395945]正在重新启动任务...
    [73622.399013] PCI_BUS 0000:01:分配资源
    [73622.399032] PCI_BUS 0000:02:分配资源
    [73622.399162] PCI_BUS 0000:03:分配资源
    [73622.404648] PCI_BUS 0000:01:分配资源
    [73622.404662] PCI_BUS 0000:02:分配资源
    [73622.404790] PCI_BUS 0000:03:分配资源
    [73622.407134] PCI_BUS 0000:01:分配资源
    [73622.407144] PCI_BUS 0000:02:分配资源
    [73622.407272] PCI_BUS 0000:03:分配资源
    [73622.409633] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [73622.410373] ACPI PNP0401:00:已枚举
    [73622.410778] ACPI PNP0501:00:仍然不存在
    [73622.413317] PCI_BUS 0000:01:分配资源
    [73622.413335] PCI_BUS 0000:02:分配资源
    [73622.413463] PCI_BUS 0000:03:分配资源
    [73641622.283]探测 NFC pn544
    [73622.417309] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [73622.426645]完成。
    [73622.723717] e1000e:ENO1 NIC 链路已关闭
    [73622.724824] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [73622.974573] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [73622.976961] IPv6:ADDRCONF (NETDEV_UP):ENO1:链路未就绪
    [73623.16369] IPv6:ADDRCONF (NETDEV_UP):ENO1:链路未就绪
    [73623.29705] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [73624.972385] ACPI 错误:索引值0x000000000083溢出字段宽度0x7 (20170531/exfldio-343)
    [73624.972401] ACPI 错误:方法解析/执行失败\NEVT、AE_AML_REGISTER_LIMIT (20170531/ps稀 疏-550)
    [73624.972412] ACPI 错误:方法解析/执行失败\_SB.PCI0.LPCC.ECDV._Q66、AE_AML_REGISTER_LIMIT (20170531/pSPARE-550)
    [73629.853803] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [73629.857401] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (请尝试1/3)
    [73629.860506] wlp2s0:已通过认证
    [73629.867251] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [73629.871355] wlp2s0:来自38:D5:47:1f:E3:d0的 RX 等效值(capab=0x1411 STATUS=0 AID = 3)
    [73629.873092] wlp2s0:已关联
    [73629.873119] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [73660.763611] PCI_BUS 0000:01:分配资源
    [73660.763626] PCI_BUS 0000:02:分配资源
    [73660.763741] PCI_BUS 0000:03:分配资源
    [73660.765150] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [73885.365121] wlp2s0:无法从硬件(-22)中删除密钥(2,ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [73888.454972] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [73888.457879] wlp2s0:将 auth 发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [73888.500380] wlp2s0:将 auth 发送到38:D5:47:1f:E3:d0 (尝试2/3)
    [73888.569936] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (请尝试3/3)
    [73888.655981] wlp2s0:在38:D5:47:1f:E3:d0超时的身份验证
    [73900.850323] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [73906.643349] wlp2s0:使用38:D5:47:1f:E3:d0进行身份验证
    [73906.646791] wlp2s0:将验证发送到38:D5:47:1f:E3:d0 (尝试1/3)
    [73906.649537] wlp2s0:已通过身份验证
    [73906.652557] wlp2s0:与38:D5:47:1f:E3:d0相关联(请尝试1/3)
    [73906.657448] wlp2s0:来自38:D5:47:1f:E3:d0的 RX 等效值(capab=0x1411 STATUS=0 AID = 3)
    [73906.658272] wlp2s0:已关联
    [73906.658294] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [74033.597620] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [74632.437765] wlp2s0:使用38:D5:47:1f:E3:D4进行身份验证
    [74632.441424] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试1/3)
    [74632.442700] wlp2s0:已通过认证
    [74632.450475] wlp2s0:与38:D5:47:1f:E3:D4相关联(请尝试1/3)
    [74632.451428] wlp2s0:来自38:D5:47:1f:E3:D4的 RX 等效值(capab=0x1011 STATUS=0 AID = 1)
    [74632.452645] wlp2s0:已关联
    [74632.452677] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [74651.230118] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [74653.939553] wlp2s0:使用38:D5:47:1f:E3:D4进行身份验证
    [74653.942966] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试1/3)
    [74653.987295] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试2/3)
    [74654.055944] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试3/3)
    [74654.101964] wlp2s0:在38:D5:47:1f:E3:D4超时的身份验证
    [74666.839642] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [75038.171809] wlp2s0:使用38:D5:47:1f:E3:D4进行身份验证
    [75038.174720] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试1/3)
    [75038.236015] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试2/3)
    [75038.293077] wlp2s0:将验证发送到38:D5:47:1f:E3:D4 (尝试3/3)
    [75038.349714] wlp2s0:在38:D5:47:1f:E3:D4超时的身份验证
    [75063.809920] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [75088.812891] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [76267.46366]包括 serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板在字节1处丢失同步
    [76267.465599] psouse serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板在字节1处丢失同步
    [76267.466680] pshouse serio1:DualPoint 触摸板位于 isa0060/serio1/input0在字节1处丢失同步
    [76267.467716] pshouse serio1:DualPoint 触摸板位于 isa0060/serio1/input0在字节1处丢失同步
    [76267.468743]使用 serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板在字节1处丢失同步
    [76267.469739] pshouse serio1:DualPoint 触摸板位于 isa0060/serio1/input0在字节1处丢失同步
    [76267.475900] pshouse serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板-驱动程序已重新同步。
    [76377.423179] psouse serio1:DualPoint 触摸板位于 isa0060/serio1/input0丢失字节1的同步
    [76377.424195]使序列发生器1:位于 isa0060/serio1/input0的 DualPoint 触摸板在字节1处丢失同步
    [76377.425220] psmouse serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板在字节1处丢失同步
    [76377.426220] psmouse serio1:DualPoint 触摸板位于 isa0060/serio1/input0在字节1处丢失同步
    [76377.427251]使用 serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板在字节1处丢失同步
    [76377.428303]使用 serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板在字节1处丢失同步
    [76377.440624] pshouse serio1:位于 isa0060/serio1/input0的 DualPoint 触摸板-驱动程序已重新同步。
    [78232.877389] PCI_BUS 0000:01:分配资源
    [78232.877409] PCI_BUS 0000:02:分配资源
    [78232.877479] PCI_BUS 0000:03:分配资源
    [78232.881437] ACPI 设备:40:无法转换为父设备的电源状态 D3hot (未知)
    [78297.845838] wlp2s0:使用 b4:5d:50:d6:21:f1进行身份验证
    [78297.849285] wlp2s0:将 auth 发送到 b4:5d:50:d6:21:f1 (尝试1/3)
    [78297.850664] wlp2s0:已认证
    [78297.854725] wlp2s0:与 b4:5d:50:d6:21:f1相关联(请尝试1/3)
    [78297.855897] wlp2s0:来自 b4:5d:50:d6:21:f1的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [78297.856961] wlp2s0:已关联
    [78297.856988] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [78303.311006] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f1取消身份验证(原因:3=DEAUTH_LEFING)
    [78323.349038] wlp2s0:使用 b4:5d:50:d6:21:f1进行身份验证
    [78323.351914] wlp2s0:将 auth 发送到 b4:5d:50:d6:21:f1 (尝试1/3)
    [78323.353321] wlp2s0:已通过身份验证
    [78323.353961] wlp2s0:与 b4:5d:50:d6:21:f1相关联(请尝试1/3)
    [78323.355073] wlp2s0:来自 b4:5d:50:d6:21:f1的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [78323.359173] wlp2s0:已关联
    [78327.921011] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f1取消身份验证(原因:3=DEAUTH_LEFING)
    [78352.856655] wlp2s0:使用 b4:5d:50:d6:21:f1进行身份验证
    [78352.860001] wlp2s0:将验证发送到 b4:5d:50:d6:21:f1 (请尝试1/3)
    [78352.861465] wlp2s0:已认证
    [78352.865330] wlp2s0:与 b4:5d:50:d6:21:f1相关联(请尝试1/3)
    [78352.866473] wlp2s0:来自 b4:5d:50:d6:21:f1的 RX 等效值(capab=0x411 status=0 aid=1)
    [78352.874992] wlp2s0:已关联
    [78356.444945] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f1取消身份验证(原因:3=DEAUTH_LEASING)
    [78375.745440] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [78382.866959] wlp2s0:使用 b4:5d:50:d6:21:f1进行身份验证
    [78382.869320] wlp2s0:将 auth 发送到 b4:5d:50:d6:21:f1 (尝试1/3)
    [78382.871165] wlp2s0:已认证
    [78382.873222] wlp2s0:与 b4:5d:50:d6:21:f1相关联(请尝试1/3)
    [78382.874378] wlp2s0:来自 b4:5d:50:d6:21:f1的 RX 等效值(capab=0x411 status = 0 AID = 4)
    [78382.877620] wlp2s0:已关联
    [78382.877649] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [78523.187305] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f1取消身份验证(原因:3=DEAUTH_LEFING)
    [78523.192914] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [78526.694109] wlp2s0:使用 A2:be:05:4e:73:97进行身份验证
    [78526.697153] wlp2s0:将验证发送到 A2:be:05:4e:73:97 (请尝试1/3)
    [78526.710071] wlp2s0:已通过身份验证
    [78526.712850] wlp2s0:与 A2:be:05:4e:73:97相关联(请尝试1/3)
    [78526.725623] wlp2s0:来自 A2:be:05:4e:73:97的 RX 等效值(capab=0x411 status = 0 AID = 1)
    [78526.729005] wlp2s0:已关联
    [78526.741074] wlp2s0:将 TX 功率限制为 A2:be:05:4e:73:97公布的20 (20 - 0) dBm
    [78600.250601] wlp2s0:通过本地选择从 A2:be:05:4e:73:97取消身份验证(原因:3=DEAUTH_LEASING)
    [78600.256370] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [78602.451673] wlp2s0:使用 b4:5d:50:d6:21:f0进行身份验证
    [78602.458524] wlp2s0:将验证发送到 b4:5d:50:d6:21:f0 (尝试1/3)
    [78602.462571] wlp2s0:已通过身份验证
    [78602.466959] wlp2s0:与 b4:5d:50:d6:21:f0相关联(请尝试1/3)
    [78602.468081] wlp2s0:来自 b4:5d:50:d6:21:f0的 RX 等效值(capab=0x411 status = 0 AID = 3)
    [78602.469137] wlp2s0:已关联
    [78609.652580] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f0进行身份验证(原因:3=DEAUTH_LEFING)
    [78630.220229] wlp2s0:使用 b4:5d:50:d6:21:f0进行身份验证
    [78630.22343] wlp2s0:将 auth 发送到 b4:5d:50:d6:21:f0 (尝试1/3)
    [78630.227266] wlp2s0:已认证
    [78630.230372] wlp2s0:与 b4:5d:50:d6:21:f0相关联(请尝试1/3)
    [78630.231495] wlp2s0:来自 b4:5d:50:d6:21:f0的 RX 等效值(capab=0x411 status = 0 AID = 3)
    [78630.234778] wlp2s0:已关联
    [78636.013671] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f0进行身份验证(原因:3=DEAUTH_LEFING)
    [78639.382062] IPv6:ADDRCONF (NETDEV_UP):wlp2s0:链路未就绪
    [78641.671601] wlp2s0:使用 b4:5d:50:d6:21:f1进行身份验证
    [78641.675704] wlp2s0:将验证发送到 b4:5d:50:d6:21:f1 (尝试1/3)
    [78641.678607] wlp2s0:已通过认证
    [78641.681998] wlp2s0:与 b4:5d:50:d6:21:f1相关联(请尝试1/3)
    [78641.683112] wlp2s0:来自 b4:5d:50:d6:21:f1的 RX 等效值(capab=0x411 status = 0 AID = 3)
    [78641.684157] wlp2s0:已关联
    [78641.684190] IPv6:ADDRCONF (NETDEV_CHANGE):wlp2s0:链路就绪
    [88821.756589] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f1取消身份验证(原因:3=DEAUTH_LEASING)
    [88821.762216] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [88832.529798] wlp2s0:使用14:75:90:93:44:bc 进行身份验证
    [88832.533110] wlp2s0:将验证发送到14:75:90:93:44:bc (尝试1/3)
    [88832.538478] wlp2s0:已认证
    [88832.542343] wlp2s0:与14:75:90:93:44:bc 关联(请尝试1/3)
    [88832.545974] wlp2s0:Rx 等效值从14:75:90:93:44:bc (capab=0x431 status=0 AID =10)
    [88832.546828] wlp2s0:已关联
    [96292.718561] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [96295.769646] wlp2s0:使用14:75:90:93:44:bc 进行身份验证
    [96295.773346] wlp2s0:将验证发送到14:75:90:93:44:bc (请尝试1/3)
    [96295.825247] wlp2s0:已认证
    [96295.826421] wlp2s0:与14:75:90:93:44:bc 关联(请尝试1/3)
    [96295.832433] wlp2s0:Rx 等效值从14:75:90:93:44:bc (capab=0x431 status=0 AID =10)
    [96295.840547] wlp2s0:已关联
    [162598.984495] PERF:中断花费的时间过长(4978 > 4968)、将 kernel.perf_event_max_sample_rate 降低到40000
    [176226.456624] wlp2s0:通过本地选择从14:75:90:93:44:bc 取消身份验证(原因:3=DEAUTH_LEFING)
    [176226.482441] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [176229.3555848] wlp2s0:使用 b4:5d:50:d6:21:f1进行身份验证
    [176229.359536] wlp2s0:将 auth 发送到 b4:5d:50:d6:21:f1 (尝试1/3)
    [176229.362938] wlp2s0:已认证
    [176229.365595] wlp2s0:与 b4:5d:50:d6:21:f1相关联(请尝试1/3)
    [176229.366720] wlp2s0:来自 b4:5d:50:d6:21:f1的 RX 等效值(capab=0x411 status = 0 AID = 4)
    [176229.36793] wlp2s0:已关联
    [177668.224156] wlp2s0:通过本地选择从 b4:5d:50:d6:21:f1取消身份验证(原因:3=DEAUTH_LEFING)
    [177668.231180] wlp2s0:无法从硬件(-22)中删除密钥(1、ff:ff:ff:ff:ff:ff:ff:ff:ff:ff:ff)
    [177671.016251] wlp2s0:使用14:75:90:93:44:bc 进行身份验证
    [177671.019605] wlp2s0:将验证发送到14:75:90:93:44:bc (尝试1/3)
    [177671.043695] wlp2s0:已通过认证
    [177671.044237] wlp2s0:与14:75:90:93:44:bc 关联(请尝试1/3)
    [177671.404854] wlp2s0:Rx 等效值从14:75:90:93:44:bc (capab=0x431 status=0 AID =10)
    [177671.413208] wlp2s0:已关联
    [177671.633695] iwlwifi 0000:02:00.0:没有关联、时间事件已经结束...
    [177671.633744] wlp2s0:与 AP 14:75:90:93:44:bc 的连接丢失
    [177674.599241] wlp2s0:使用14:75:90:93:44:bc 进行身份验证
    [177674.602498] wlp2s0:将验证发送到14:75:90:93:44:bc (尝试1/3)
    [177674.607838] wlp2s0:已通过身份验证
    [177674.608259] wlp2s0:与14:75:90:93:44:bc 关联(请尝试1/3)
    [177674.623013] wlp2s0:Rx 等效值从14:75:90:93:44:bc (capab=0x431 status=0 AID =10)
    [177674.625030] wlp2s0:已关联
    您可以使用 wget 下载文件吗?
    $ CD /home/vial/tisdk/downloads
    $ wget -c software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    $ du -b git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    4799138606   git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    $ md5sum git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    48ea2459af6c3631e42347ebf49b37a5 git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    $ sha256sum git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    a54affd17ba0b0f674728a2fe45b9b7432a50f74a70ec06464330f336098888d git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    $轻触 git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz.done
    wget 在开始时运行良好、平均下载速度高达1.5MB/S 但是、当更新过程达到45%时、它会返回服务不可用的错误。 请参阅以下日志。
    小瓶@小瓶-Latitude-E7440:~/tisdk/downloads wget -c software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    2018年1月31日11:27:41 - software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    正在解析主机 software-dl.ti.com (software-dl.ti.com)... 59.39.66.106、59.39.66.113
    正在连接 software-dl.ti.com (software-dl.ti.com)|59.39.66.106|:80)。 已连接。μ A
    已发出 HTTP 请求,正在等待回应…… 302暂时移动
    位置:www.ti.com/.../anonymousproddownload.tsp [跟随至新的 URL]
    2018年1月31日11:27:42 - www.ti.com/.../anonymousproddownload.tsp
    正在解析主机 www.ti.com (www.ti.com)... 27.151.12.195
    正在连接 www.ti.com (www.ti.com)|27.151.12.195|:443)。 已连接。μ A
    位置:software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz [跟随至新的 URL]
    2018年1月31日11:27:42 - software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    已发出 HTTP 请求,正在等待回应…… 200正常
    长度:4799138606 (4.5G)[应用/x-gzip]
    正在保存至:“git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz”
    git2_git.ti.com.ti- 45%[====== >]            2.05g  741kb/s   ,36m 28s
    2018-01-31 12:04:11 (982 kB/s)-在2200577177字节处连接关闭。重试中。
    2018年1月31日12:04:12 - (尝试次数:2) software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    已发出 HTTP 请求,正在等待回应…… 503服务不可用
    2018-01-31 12:04:17错误503:服务不可用。
    2018年1月31日12:06:58 - software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    正在解析主机 software-dl.ti.com (software-dl.ti.com)... 59.39.66.113、59.39.66.106
    正在连接 software-dl.ti.com (software-dl.ti.com)|59.39.66.113|:80)。 已连接。μ A
    2018年1月31日12:07:00 - www.ti.com/.../anonymousproddownload.tsp
    正在解析主机 www.ti.com (www.ti.com)... 183.61.92.241
    正在连接 www.ti.com (www.ti.com)|183.61.92.241|:443)。 已连接。μ A
    2018年1月31日12:07:01 - software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    2018-01-31 12:07:02错误503:服务不可用。
    我已将该文件上传到 Google Drive。 您可以从那里下载它吗?
    drive.google.com/.../view
    不幸的是、到目前为止、我无法访问 google 链接。 我从笔记本电脑中删除了未完成的内核包、并尝试使用快照下载方法。 它现在可以正常工作。 24%的百分比已经完成。 我稍后会更新结果。 谢谢!
    小瓶@小瓶-Latitude-E7440:~/tisdk/downloads AM335x-EVM-Linux-SDK-Arago-src-04.02.00.09/get_build_sources.sh AM
    amsdk-av-files_1.4.tar.gz
    amsdk-av-files_1.4.tar.gz.doe.
    小瓶@小瓶-Latitude-E7440:~/tisdk/downloads AM335x-EVM-Linux-SDK-Arago-src-04.02.00.09/get_build_sources.sh AM335x-EVM-Linux-SDK-Arago-src-04.02.00.09/source_pkg_list.txt
    大小=/0:git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    总下载大小:0 MB
    是否要继续? [y/n] y
    文件“/home/vial/tisdk/downloads/git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz”已经存在;不获取。
    总下载大小:0 MB
    是否要继续? [y/n] y
    2018年1月31日13:20:57 - software-dl.ti.com/.../git2_git.ti.com.ti-linux-kernel.ti-linux-kernel.git.tar.gz
    get_build_sources.sh 还使用 wget、下载将在同一时间停止。 尝试使用 Web 浏览器下载该文件。 这对我很有用。
    同意。 我 使用另一台笔记本电脑从 Web 浏览器下载内核文件。 到目前为止、已下载了3.5GB 数据。 希望它能 为我工作。  谢谢!
    您好、Kemal、
    我下载了您在 Google 驱动器上上传的软件包。 根据您的指令、linux-libc-header-4.9-r0获取失败被修复。
    今天上午我又重新构建了,到目前为止,7小时的构建过程达到了65%。 希望明天上午能够这样做。
    为什么构建过程需要这么长的时间? 在构建期间是否需要下载任何新的软件包?
    最棒的
    William
    根据已知原因、构建过程所需的时间太长、如果您等待下载文件的时间太长、互联网连接会缓慢、如果主机没有可用的处理单元、则会在单个内核上运行许多任务、 如果主机缺少 RAM、并且依赖于 SWaP 分区写入、则内存大小较低;如果使用 HDD 而不是 SSD、则磁盘读取和写入速度较慢。 关于您的第二个问题、我们将等待构建过程中是否需要下载任何新的软件包。
    您好、Kemal、
    感谢您的回答。 SDK 中的顶级 make 文件与基于 Arago 项目的编译过程之间有一点混淆。 根据该指南、顶级 make 可以编译所有组件、内核、引导等、除非文件系统将使用基于 Arago Project 的编译过程。 因此、如果我想向内核中添加新的显示/触摸面板驱动程序、最高级别的 make 适合使用、对吧? 如果为 true,如何为我的无效性指定目标平台 am3358? 如果我想开发一个应用并将其添加到文件系统中、这意味着我必须使用基于 Arago 项目的构建来生成新的文件系统、对吧? 请您帮助我了解一下、在哪种情况下需要使用两种不同的构建方法?
    William
    是的、顶层制造是合适的。 您不需要重建完整的 rootfs。 只需在内核的 menuconfig (arch=arm make menuconfig)中启用驱动程序、并根据在器件树源文件中创建合适的触摸和显示节点 /board-support/linux- /Documentation/devicetree/bindings 文档、将新内核、可加载模块和器件树复制到您的电路板、仅此而已。
