[参考译文] Linux/LINUXEZSDK-Sitara:内核编译失败
Guru**** 2875350 points
Other Parts Discussed in Thread: LM90, LM95245, TMP102, TFP410, TPS65217, TPS65218, TPS65910, TWL6040, TPS65090
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/654603/linux-linuxezsdk-sitara-kernel-compilation-fails
器件型号:LINUXEZSDK-Sitara
主题中讨论的其他器件:LM90LM95245TMP102TFP410TPS65217TPS65218TPS65910TWL6040TPS65090
工具/软件:Linux
你(们)好
我正在使用 AM335x 入门套件和 Linux "="">HERE ">SDK
使用以下步骤为源代码编译内核映像时附带 SDK、但如果某个时候失败而没有任何错误、则不确定是什么问题
下面是构建日志
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59导出 arch=arm
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59导出路径=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$path
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59 export cross_compile=arm-linux-gnueabihf-
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59 make clean
root@sdkuser-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59 make tisdk_AM335x-evm_defconfig
 HOSTCC 脚本/基本/固定程序
 HOSTCC 脚本/basic/bin2c
 HOSTCC 脚本/kconfig/conf.o
 HOSTCC 脚本/kconfig/zconf.tab.o
 HOSTLD 脚本/kconfig/Conf
编号
#配置写入.config
编号
root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59 make -J4
scripts/kconfig/conf --silentoldconfig Kconfig
 chk    include/config/kernel.release
 chk    包含/生成/ uapi/linux/version.h
 CHK    包含/生成/ utsrelease.h
 HOSTCC 脚本/DTC/DC.o
 HOSTCC 脚本/DTC/flattree.o
 HOSTCC 脚本/genksyms/genksyms.o
 Gen    include/generated /mach-types.h
 HOSTCC 脚本/DTC/fstree.o
 CC     脚本/mod/empty.o
 HOSTCC 脚本/genksyms/pars.tab.o
 HOSTCC 脚本/DTC/DATA.o
 HOSTCC 脚本/mod/mk_elfconfig
 HOSTCC 脚本/genksys/lex.lex.o
 CC     scripts/mod/devicetable-offsets.s
 HOSTCC 脚本/DTC/livetree.o
 HOSTCC 脚本/kallsyms
 MKELF  脚本/mod/elfconfig.h
 生成    脚本/mod/devicetable-offsets.h
 HOSTCC 脚本/mod/sumversion.o
 HOSTCC 脚本/DTC/treesource.o
 HOSTLD 脚本/genksyms/genksyms
 CC     内核/边界
 HOSTCC 脚本/DTC/srcpos.o
 HOSTCC 脚本/mod/modpost.o
 HOSTCC 脚本/DTC/检查
 CHK    包含/生成/ timeconst.h
 HOSTCC 脚本/DTC/util.o
 HOSTCC 脚本/DTC/DTC-多路复用器.lex.o
 CHK    包含/生成/ bounds.h
 CC     arch/arm/kernel/asm-offsets.s
 HOSTCC 脚本/mod/file2alias.o
 HOSTCC 脚本/DTC/DTC 解析器.tab.o
 HOSTCC 脚本/ makeash
 HOSTLD 脚本/DTC/DTC
 HOSTCC 脚本/可排序文件
 HOSTLD 脚本/mod/modpost
 CHK    包含/生成/ asm-offsets.h
 调用   脚本/checksyscalls.sh
 CC     init/main.o
 CHK    包含/生成/ compile.h
 HOSTCC usr/gen_init_cpio
 CC     arch/arm/vfp/vfpmodule.o
 ARM/ARM/VFP/Entry.o
 arch/arm/vfp/vfphw.o
 Gen    USR/initramfs_data.cpio.gz
 作为     /usr/initramfs_data.o
 CC     arch/arm/kernel/elf.o
 LD     usr/built-in.o
 CC     arch/arm/vfp/vfpsingle.o
 arch/arm/kernel/entry-common.o
 CC     arch/arm/mdma-mapping
 CC     arch/arm/kernel/IRQ.o
 CC     arch/arm/vfp/vfpdouble.o
 CC     arch/arm/kernel/opcodes.o
 LD     arch/arm/VfP/Vfp.o
 LD     arch/arm/vfp/built-in.o
 CC     arch/arm/kernel/process.o
 CC     arch/arm/mm/extable.o
 CC     arch/arm/mm/fault.o
 CC     arch/arm/common/firmware.o
 CC     init/DO_mounts.o
 CC     arch/arm/kernel/ptrace.o
 CC     arch/arm/mm/init.o
 LD     arch/arm/common/built-in.o
 CC     arch/arm/kernel/reboot.o
 CC     init/do_mounts_rd.o
 CC     arch/arm/kernel/return_address.o
 CC     arch/arm/mm/iomap.o
 CC     arch/arm/kernel/setup.o
 CC     init/do_mounts_initrd.o
 CC     arch/arm/mm/fault-armv.o
 CC     拱形/臂形/毫米/齐平
 CC     init/initramfs.o
 CC     arch/arm/kernel/signal.o
 CC     arch/arm/mm/idmap.o
 CC     初始化/校准.o
 arch/arm/kernel/sigretog_codes.o
 LD     arch/arm/probes/built-in.o
 CC     arch/arm/kernel/stacktrace.o
 CC     init/init_task.o
 CC     arch/arm/mm/ioremap.o
 CC     arch/arm/mm/mmap.o
 CC     arch/arm/kernel/sys_arm.o
 CC     arch/arm/kernel/time.o
 CC     init/version.o
 LD     init/mounts.o
 CC     arch/arm/kernel/traps.o
 CC     ARM/ARM/mm/PgD.o
 CC     arch/arm/mm/Mu.o
 LD     init/built-in.o
 LD     arch/arm/net/built-in.o
 CC     arch/arm/kernel/atags_parse.o
 CC     arch/arm/mm/pageattr.o
 CC     arch/arm/proc-syms.o
 LD     arch/arm/crypto/built-in.o
 作为[M] arch/arm/crypto/AES-armv4.o
 CC     arch/arm/kernel/atags_proc.o
 CC [M] arch/arm/crypto/AES_胶 合.o
 作为[M] arch/arm/crypto/aesbs-core.o
 CC     arch/arm/mm/alignment.o
 ARM/ARM/kernel/entry-armv.o
 CC     arch/arm/kernel/cpuidle.o
 CC [M] arch/arm/crypto/aesbs-cine.o
 LD     arch/arm/firmware/built-in.o
 CC     arch/arm/kernel/armksyms.o
 作为[M] arch/arm/crypto/sha1-armv4-large.o
 CC     arch/arm/mm/HIIGHMEM.o
 CC     arch/arm/kernel/module.o
 CC     arch/arm/mach-OMAP2/id.o
 CC [M] arch/arm/crypto/SHA1_cUSe.o
 CC     arch/arm/kernel/bios32.o
 ARM/ARM/mm/abort-ev7.o
 ARM/ARM/mm/pabort-v7.o
 arch/arm/mm/cache-v7.o
 CC     arch/arm/mm/Copypage-v6.o
 作为[M] arch/arm/crypto/sha1-armv7-none.o
 CC [M] arch/arm/crypto/sha1_none_cUSe.o
 CC     arch/arm/mach-omap2/io.o
 CC     arch/arm/kernel/isa.o
 CC     arch/arm/mm/context.o
 arch/arm/kernel/sleep.o
 CC     arch/arm/kernel/suspend.o
 ARM/ARM/mm/tlB-v7.o
 作为[M] arch/arm/crypto/SHA256-core.o
 CC     arch/arm/kernel/jump 标签
 CC [M] arch/arm/crypto/SHA256_胶 合.o
 ARM/ARM/mm/proc-v7.o
 CC     arch/arm/mach-omap2/control.o
 CC     arch/arm/kernel/inn.o
 CC     arch/arm/l2C-common.o
 CC     arch/arm/kernel/patch.o
 CC     arch/arm/mm/cache-l2x0.o
 CC     arch/arm/mach-omap2/mux.o
 CC     arch/arm/kernel/machine_kexec.o
 CC [M] arch/arm/crypto/SHA256_NEon_胶 水.o
 ARM/ARM/mm/L2C-l2x0-RESUE.o
 arch/arm/kernel/relocate_kernel.o
 LD     arch/arm/mm/built-in.o
 作为[M] arch/arm/crypto/SHA512-core.o
 CC     arch/arm/kernel/devtree.o
 CC     arch/arm/mach-omap2/devices.o
 CC [M] arch/arm/crypto/SHA512-cuce.o
 CC [M] arch/arm/crypto/SHA512-NEon-coos.o
 CC     arch/arm/kernel/hw_breakpoint.o
 CC     arch/arm/mach-omap2/fb.o
 CC     arch/arm/kernel/perf_regs.o
 作为[M] arch/arm/crypto/AES-ce-core.o
 CC [M] arch/arm/crypto/AES-ce-coos.o
 CC     arch/arm/mach-OMAP2/serial.o
 作为[M] arch/arm/crypto/SHA1-ce-core.o
 CC     arch/arm/kernel/perf_callchain.o
 CC     arch/arm/mach-omap2/timer.o
 CC [M] arch/arm/crypto/sha1-ce-cucme.o
 作为[M] arch/arm/crypto/SHA2-ce-core.o
 CC     arch/arm/plat-omap/samd.o
 CC     arch/arm/kernel/perf_event_xscale.o
 CC     arch/arm/kernel/perf_event_v6.o
 CC     arch/arm/kernel/perf_event_v7.o
 CC     arch/arm/mach-omap2/pm.o
 CC [M] arch/arm/crypto/SHA2-ce-cucme.o
 CC     arch/arm/plat-omap/dma.o
 CC     arch/arm/mach-omap2/common.o
 作为[M] arch/arm/crypto/Ghash-ce-core.o
 CC [M] arch/arm/crypto/Ghash-ce-ce-cing.o
 CC     arch/arm/kernel/efi.o
 CC     arch/arm/kernel/io.o
 CC     arch/arm/mach-omap2/gpio.o
 LD [M] arch/arm/crypto/AES-arm.o
 LD [M] arch/arm/crypto/AES-arm-bs.o
 LD [M] arch/arm/crypto/SHA1-arm.o
 LD [M] arch/arm/crypto/sha1-arm-none.o
 LD [M] arch/arm/crypto/SHA256-arm.o
 LD [M] arch/arm/crypto/SHA512-arm.o
 LD [M] arch/arm/crypto/AES-arm-ce.o
 LD [M] arch/arm/crypto/sha1-arm-ce.o
 LD [M] arch/arm/crypto/SHA2-arm-ce.o
 LD [M] arch/arm/crypto/Ghash-arm-ce.o
 arch/arm/kernel/hyp-stub.o
 CC     arch/arm/mach-OMAP2/dma.o
 CC     arch/arm/plat-omap/counter_32k.o
 arch/arm/kernel/smccc-call.o
 ARM/ARM/kernel/head.o
 lds    arch/arm/kernel/vmlinux.lds
 LD     arch/arm/kernel/built-in.o
 CC     arch/arm/plat-omap/dmtimer.o
 CC     内核/fork.o
 CC     kernel/exec_domain.o
 CC     arch/arm/mach-omap2/wd_timer.o
 CC     arch/arm/mach-omap2/display.o
 CC     kernel/panel.o
 CC     arch/arm/plat-omap/i2c.o
 CC     arch/arm/mach-omap2/i2c.o
 LD     arch/arm/plat-omap/built-in.o
 CC     arch/arm/mach-omap2/hdq1w.o
 CC     kernel/CPU。o
 CC     arch/arm/mach-omap2/omap_hwmod.o
 CC     kernel/exit.o
 LD     certs/built-in.o
 CC     arch/arm/mach-omap2/omap_device.o
 CC     mm/filemap.o
 cc     kernel/softirq.o
 ARM/ARM/mach-OMAP2/OMAP-headsmp.o
 CC     arch/arm/mach-OMAP2/SRAM.o
 CC     arch/arm/mach-omap2/drm.o
 抄送     MM/mempool.o
 CC     kernel/resource.o
 CC     arch/arm/mach-omap2/omap_hwmod_reset.o
 CC     arch/arm/mach-omap2/omap_hwmod_common_data.o
 CC     arch/arm/mach-omap2/am33xx-restart.o
 CC     FS/OPEN.o
 cc     kernel/sysctl.o
 CC     arch/arm/mach-omap2/opp.o
 CC     mm/om_kill.o
 CC     arch/arm/mach-omap2/omap-pm-noop.o
 CC     arch/arm/mach-omap2/pm33xx-core.o
 CC     mm/maccess.o
 ARM/ARM/mach-OMAP2/slep33xx.o
 CC     FS/READ_WRITE.o
 CC     arch/arm/mach-omap2/pm-debug.o
 cc     mm/page_alloc.o
 CC     kernel/sysctl_binary.o
 CC     arch/arm/mach-omap2/prm_common.o
 CC     kernel/capability。o
 CC     arch/arm/mach-omap2/cm_common.o
 CC     fs/file_table.o
 CC     arch/arm/mach-omap2/prm33xx.o
 CC     arch/arm/mach-omap2/cm33xx.o
 CC     kernel/ptrace.o
 CC     arch/arm/mach-OMAP2/volte.o
 CC     FS/SUB.o
 CC     arch/arm/mach-omap2/vc.o
 CC     arch/arm/mach-OMAP2/vp.o
 cc     mm/page-writeback.o
 CC     kernel/user.o
 CC     FS/char_dev.o
 CC     arch/arm/mach-omap2/powerdomain.o
 CC     内核/信号.o
 CC     arch/arm/mach-omap2/powerdomain-common.o
 CC     FS/STAT.o
 CC     arch/arm/mach-omap2/powerdomains33xx_data.o
 CC     arch/arm/mach-omap2/clockdomain.o
 CC     arch/arm/mach-omap2/clockdomains33xx_data.o
 CC     FS/exec.o
 CC     mm/readahead.o
 CC     arch/arm/mach-omap2/clock.o
 CC     arch/arm/mach-omap2/omap_hwmod_common_ipblock_data.o
 CC     内核/sys.o
 CC     arch/arm/mach-omap2/omap_hwmod_33xx_data.o
 CC     MM/SWAP.o
 CC     arch/arm/mach-omap2/omap_hwmod_33xx_43xx_interconnect_data.o
 CC     FS/PIPE.o
 CC     arch/arm/mach-omap2/omap_hwmod_33xx_43xx_ipblock_data.o
 CC     arch/arm/mach-OMAP2/PMU.o
 抄送     毫米/截断
 cc     kernel/kmod.o
 抄送     FS/namee.o
 CC     arch/arm/mach-omap2/board-generic.o
 CC     arch/arm/mach-omap2/pdata-quirks.o
 CC     内核/workqueue.o
 抄送     MM/vmscan.o
 CC     arch/arm/mach-omap2/board-flash.o
 CC     arch/arm/mach-omap2/hsmmc.o
 CC     arch/arm/mach-OMAP2/USB-musb.o
 CC     arch/arm/mach-omap2/omap_phy_internal.o
 CC     fs/fcntl.o
 CC     arch/arm/mach-OMAP2/USB-host.o
 CC     mm/shme.o
 CC     kernel/pid.o
 CC     arch/arm/mach-OMAP2/GPMC-nand.o
 CC     fs/ioctl.o
 CC     arch/arm/mach-OMAP2/GPMC-smsc911x.o
 CC     kernel/task_work。o
 CC     arch/arm/mach-omap2/common-board-devices.o
 CC     kernel/extable.o
 CC     FS/ readdir.o
 CC     arch/arm/mach-omap2/twL-common.o
 CC     kernel/params.o
 CC     arch/arm/mach-OMAP2/dss-common.o
 CC     FS/SELECT.o
 CC     mm/util.o
 CC     arch/arm/mach-omap2/omap-iommu.o
 cc     kernel/kthread.o
 LD     arch/arm/mach-omap2/built-in.o
 CC     fs/dcache.o
 CC     mm/mmzone.o
 抄送     MM/vmstat.o
 CC     mm/backing-dev.o
 CC     内核/sys_ni.o
 CC     kernel/nsproxy.o
 CC     kernel/notifier.o
 CC     FS/inode
 CC     kernel/ksysfs.o
 CC     mm/mm_init.o
 CC     IPC/util.o
 CC     内核/cred.o
 抄送     MMU/MMU_context.o
 CC     IPC/msguil.o
 CC     FS/ATTR.o
 CC     mm/pu.o
 CC     IPC/msg.o
 CC     kernel/reboot.o
 CC     FS/BAD_INDE.o
 CC     IPC/SEM.o
 CC     kernel/async.o
 CC     fs/file.o
 CC     mm/slab_common.o
 CC     kernel/range.o
 CC     kernel/smpboot.o
 CC     IPC/shm.o
 CC     FS/filesystem.o
 CC     mm/压实
 CC     kernel/ucount.o
 CC     内核/组.o
 CC     FS/namespace.o
 CC     IPC/syscall.o
 CC     IPC/IPC_SYSCTL.o
 CC     kernel/bpf/core.o
 CC     IPC/mqueue.o
 CC     mm/vmacache.o
 CC     mm/interval_tree.o
 CC     IPC/namespace.o
 CC     mm/list_LRU.o
 CC     IPC/MQ_SYSCTL.o
 CC     FS/SEQ_FILE.o
 LD     kernel/bpf/built-in.o
 CC     kernel/events/core.o
 LD     IPC/Built-in.o
 CC     内核/IRQ/irqdesc.o
 抄送     毫米/工作集.o
 CC     MM/DEBUG.o
 CC     FS/xattR.o
 CC     内核/IRQ/Handle.o
 CC     kernel/IRQ/MANAGE.o
 CC     mm/gup.o
 CC     FS/libfs.o
 CC     内核/IRQ/伪 波
 抄送     MM/HIGHMEM.o
 CC     kernel/IRQ/RESERD.o
 CC     FS/FS-writeback.o
 抄送     MM/存储器.o
 CC     内核/IRQ/CHIP.o
 CC     内核/IRQ/dummychip.o
 CC     fs/pnode.o
 CC     内核/IRQ/DevRes.o
 CC     FS/拼 接片
 CC     内核/事件/ring 缓冲区.o
 CC     内核/IRQ/generic-chip.o
 CC     mm/mincore.o
 CC     mm/mlock.o
 CC     内核/事件/callchain.o
 CC     内核/IRQ/autobrobe.o
 CC     FS/SYNC.o
 CC     kernel/events/hw_breakpoint.o
 CC     内核/IRQ/irqdomain.o
 CC     mm/mmap.o
 CC     FS/utimes.o
 LD     kernel/events/built-in.o
 CC     FS/STACT.o
 CC     内核/IRQ/PROC.o
 CC     内核/IRQ/PM.o
 CC     FS/FS_STRUCT.o
 CC     FS/STATFS.o
 CC     kernel/IRQ/msi.o
 CC     安全/密钥/GC.o
 CC     mm/mprotect.o
 CC     FS/FS_PIN.o
 LD     kernel/IRQ/built-in.o
 抄送     安全/密钥/密钥
 LD     kernel/livepatch/built-in.o
 CC     内核/锁定/mutex.o
 CC     FS/nsfs.o
 CC     mm/mremap.o
 CC     内核/锁定/信标.o
 CC     FS/buffer.o
 抄送     安全/密钥/密钥环
 CC     mm/msync.o
 CC     内核/锁闭/rwsem.o
 CC     mm/RMAP.o
 CC     内核/锁定/百分比 rwsem.o
 CC     安全/密钥/keyctl.o
 CC     内核/锁定/rtmutex.o
 抄送     mm/vmalloc.o
 抄送     安全/密钥/权限
 CC     内核/锁定/rwsem-xadd.o
 CC     FS/BLOCK_DEV.o
 抄送     安全/密钥/proc_keys.o
 LD     内核/锁定/内置.o
 CC     kernel/power/qos.o
 CC     安全/密钥/Request_key.o
 CC     kernel/power/main.o
 抄送     毫米/页面
 CC     安全/密钥/Request_key_auth.o
 CC     mm/pgtable-generic.o
 CC     FS/Direct-IO.o
 CC     安全/密钥/USER_Defined.o
 CC     kernel/power/console.o
 抄送     MM/PROCESS_VM_ACCESS.o
 CC     安全/密钥/proc.o
 CC     mm/init-mm.o
 CC     安全/密钥/sysctl.o
 CC     kernel/power/process.o
 CC     mm/nobootme.o
 LD     安全性/密钥/内置
 CC     安全/commoncap.o
 CC     内核/power/suspend.o
 CC     mm/fadvise
 CC     FS/mpage.o
 CC     安全性/min_addr.o
 CC     mm/madvise
 CC     kernel/power/poweroff.o
 cc     security/device_cgroup.o
 LD     kernel/power/built-in.o
 CC     内核/printk/printk.o
 LD     安全性/built-in.o
 CC     kernel/RCU/update.o
 CC     fs/proc_namespace
 CC     mm/memblock.o
 CC     内核/RCU/SYNC.o
 CC     FS/autofs4/init.o
 CC     内核/RCU/SRCU.o
 CC     FS/autofs4/inode.o
 CC     mm/page_io.o
 CC     kernel/RCU/tree.o
 CC     FS/autofs4/root.o
 CC     内核/printk/NMI.o
 CC     mm/swap_state.o
 LD     kernel/printk/built-in.o
 CC     mm/swapfile.o
 CC     FS/autofs4/symlink.o
 CC     FS/autofs4/waitq.o
 CC     FS/autofs4/expire.o
 LD     FS/CIFS/Built-in.o
 CC [M] FS/CIFS/cifsfs.o
 CC     FS/autofs4/dev-ioctl.o
 LD     kernel/RCU/built-in.o
 CC     kernel/sched/core.o
 LD     FS/autofs4/autofs4.o
 LD     FS/autofs4/built-in.o
 CC     kernel/time/time.o
 CC     mm/dmapol.o
 CC [M] FS/CIFSSMB.o
 CC     kernel/timer/timer.o
 CC     mm/slub.o
 cc     kernel/time/hrtimer.o
 CC     内核/sched/loadavg.o
 抄送     MM/migrate.o
 CC     kernel/sched/clock.o
 CC     内核/时间/itimer.o
 CC [M] FS/CIFS/CIFS_DEBUG.o
 CC     kernel/sched/cputime.o
 CC     内核/时间/posix-timers.o
 CC     mm/page_counter.o
 CC     kernel/sched/idle_task.o
 CC     mm/memcontrol.o
 CC     内核/sched/sfel.o
 CC [M] FS/CIFS/CONNECT
 CC     内核/时间/posix-cpu-timers.o
 CC     内核/时间/计时.o
 CC     kernel/sched/rt.o
 CC     kernel/sched/deadline
 CC [M] FS/CIFS/DIR.o
 CC     kernel/sched/stop_task.o
 CC     kernel/time/ntp.o
 CC     kernel/sched/wait.o
 CC     内核/时间/时钟源.o
 抄送     MM/vmpressure.o
 CC [M] FS/CIFS/FILE.o
 CC     kernel/sched/swait.o
 cc     mm/swap_cgroup.o
 CC     kernel/sched/complete.o
 CC     kernel/time/jiffies.o
 CC     mm/page_isolation.o
 CC     kernel/timer/timer_list.o
 CC     kernel/sched/idle.o
 CC     kernel/time/timeconv.o
 CC     mm/earle_ioremap.o
 CC     kernel/time/timecounter.o
 CC     kernel/sched/stats.o
 CC     kernel/time/posix-clock.o
 CC     MM/CC.o
 CC     kernel/sched/debug.o
 cc     mm/frame_vector.o
 CC     内核/时间/alarmtimer.o
 CC [M] FS/CIFS/Inode.o
 LD     MM /内置
 CC [M] FS/CIFS/LINK.o
 CC     内核/时间/时钟事件.o
 cc     kernel/sched/cpuacct.o
 CC     kernel/time/tick-common.o
 cc     kernel/sched/cpufreq.o
 CC     FS/CONFIGFS/INode.o
 抄送[M] FS/CIFS/MISC.o
 LD     kernel/sched/built-in.o
 CC     fs/configfs/file.o
 CC     FS/CONFIGFS/DIR.o
 CC     kernel/time/sched_clock.o
 CC     fs/debugfs/inode.o
 CC     kernel/time/tick-OneShot.o
 CC [M] FS/CIFS/netmisc.o
 CC     kernel/time/tick-sched.o
 CC [M] FS/CIFS/smbencrypt.o
 CC     FS/configfs/symlink.o
 CC     fs/debugfs/file.o
 CC     内核/时间/计时_debug.o
 CC     FS/configfs/mount.o
 LD     kernel/time/built-in.o
 cc     kernel/kcmp.o
 CC [M] FS/CIFS/transport
 CC     FS/configfs/item.o
 CC     kernel/fels.o
 LD     fs/debugfs/debugfs.o
 LD     fs/debugfs/built-in.o
 cc     kernel/futex.o
 LD     fs/configfs/configfs.o
 LD     fs/configfs/built-in.o
 CC     crypto/api.o
 CC [M] FS/CIFS/ASN1.o
 CC     块/bio.o
 CC     加密/密码
 CC     kernel/up.o
 CC     加密/compress.o
 CC [M] FS/CIFS/CIFS_unicode.o
 CC     kernel/uid16.o
 CC     crypto/memneq.o
 CC     块/电梯
 cc     kernel/module.o
 CC [M] FS/CIFS/n.o
 CC     crypto/crypto_wq.o
 CC [M] FS/CIFS/cifsencrypt.o
 CC     crypto/algapi.o
 CC     块/blk-core.o
 CC [M] FS/CIFS/readdir.o
 CC     crypto/scatterwalk
 CC [M] FS/CIFS/ioctl.o
 CC     内核/kallsyms.o
 CC     crypto/proc.o
 CC     kernel/acct.o
 CC [M] FS/CIFS/Sess.o
 CC     加密/aead.o
 CC     块/blk-tag.o
 CC     kernel/kexec_core.o
 CC     block/blk-sysfs.o
 CC [M] FS/CIFS/EXPORT.o
 CC     加密/ablkciphip.o
 CC     块/blk-flush.o
 CC     kernel/kexec.o
 CC [M] FS/CIFS/smb1ops.o
 cc     kernel/cgroup.o
 CC     block/blk-settings.o
 CC     加密/blkciphip.o
 CC [M] FS/CIFS/winucase.o
 CC [M] FS/CIFS/xattR.o
 CC     块/blk-io.o
 CC     加密/密码
 CC [M] FS/CIFS/cifsacl.o
 CC     块/blk-map.o
 CC     加密/ahash.o
 CC [M] FS/CIFS/smb2ops.o
 CC     block/blk-exec.o
 CC     加密/shash.o
 CC     kernel/cgroup_ficles.o
 CC     block/blk-merge.o
 CC     kernel/cgroup_pids.o
 CC [M] FS/CIFS/smb2maperror.o
 CC     加密/密码
 CC     kernel/utsname.o
 CC     kernel/pid_namespace。o
 CC [M] FS/CIFS/smb2transport
 CC     加密/KPP.o
 CC     块/blk-softirq.o
 gzip   内核/config_data.gz
 CC     块/blk-timeout.o
 CC     内核/seccomp.o
 CC     加密/algboss.o
 CC [M] FS/CIFS/smb2Misc.o
 CC     blk/blk-lib.o
 CC     crypto/testmgr.o
 CC     kernel/utsname_sysctl.o
 CC     kernel/elfcore.o
 CC [M] FS/CIFS/smb2pdu.o
 CC     块/blk-mq.o
 CC     crypto/crypto_null。o
 CC     kernel/IRQ_work。o
 CC     kernel/CPU pm.o
 CC     加密/AES_generic.o
 CC     内核/jump 标签.o
 CC     kernel/membarer.o
 cc     block/blk-mQ-tag.o
 CC [M] FS/CIFS/smb2inode
 CC     加密/放气.o
 CC     kernel/memremap.o
 CC     加密/CRC32C_generic.o
 chk    内核/config_data.h
 UPD    内核/config_data.h
 CC     kernel/configs.o
 cc     block/blk-mQ-sysfs.o
 CC [M] FS/CIFS/smb2file.o
 LD     kernel/built-in.o
 LD     DRIVER/amba/Built-in.o
 CC     加密/lzo.o
 LD     驱动程序/Android/built-in.o
 LD     驱动程序/ata/built-in.o
 CC [M] drivers/ata/libata-core.o
 CC     加密/rng.o
 CC     区块/blk-mQ-cpumap.o
 LD [M] FS/CIFS/CIFS.o
 CC     FS/devpts/inode
 CC     块/ioctl.o
 LD     fs/devpts/devpts.o
 LD     fs/devpts/built-in.o
 LD     fs/efivarfs/built-in.o
 CC [M] FS/efivarfs/inode.o
 cc [M] crypto/crypto_engine.o
 CC [M] FS/efivarfs/file.o
 CC     块/genhd.o
 CC [M] FS/efivarfs/super.o
 CC [M] 加密/seqiv.o
 LD [M] FS/efivarfs/efivarfs.o
 LD     FS/exofs/built-in.o
 CC     fs/exportfs/expfs.o
 CC [M] 加密/echainiv.o
 LD     fs/exportfs/exportfs.o
 LD     fs/exportfs/built-in.o
 CC     FS/ext4/balloc.o
 CC     block/scsi_ioctl.o
 CC [M] 加密/CMAC.o
 CC [M] drivers/ata/libata-scsi.o
 CC [M] 加密/HMAC.o
 CC     块/分区-generic.o
 CC     FS/ext4/bitmap.o
 CC [M] 加密/MD4.o
 CC     FS/ext4/dir.o
 CC [M] 加密/MD5.o
 CC     块/iofio.o
 CC [M] drivers/ata/libata-eh.o
 CC     FS/ext4/file.o
 CC [M] 加密/SHA1_generic.o
 CC     block/badblocks.o
 CC     FS/ext4/fsync.o
 CC [M] 加密/SHA256_generic.o
 CC     块/分区/check.o
 CC     fs/ext4/ialloc.o
 cc     block/partitions/cmdline.o
 CC [M] 加密/SHA512_generic.o
 CC     块/分区/msdos.o
 CC     FS/ext4/inode
 cc [M] drivers/ata/libata-transport
 CC     块/分区/EFI.o
 cc [M] crypto/gf128mul.o
 LD     块/分区/built-in.o
 CC     阻止/反弹。o
 CC [M] drivers/ata/libata-trace.o
 CC [M] 加密/ECB.o
 CC [M] drivers/ata/libata-SFF.o
 CC     区块/BSG.o
 CC [M] 加密/CBC.o
 CC [M] 加密/CTR.o
 CC     FS/ext4/page-io.o
 CC     block/blk-cgroup.o
 CC [M] 加密/GCM
 cc [M] drivers/ata/libata-pmp.o
 CC     fs/ext4/ioctl.o
 CC [M] 加密/CM.o
 CC [M] drivers/ata/ahci.o
 CC     块/ NOOP-Iosched.o
 抄送     FS/ext4/namee.o
 CC     阻止/截止日期计划。o
 cc [M] drivers/ata/libahci.o
 CC [M] 加密/加密.o
 CC     区块/cfq-iosched.o
 CC [M] 加密/DES_generic.o
 CC     FS/ext4/super.o
 CC [M] drivers/ata/ahci_platform.o
 cc [M] drivers/ata/libahci_platform.o
 CC [M] 加密/ARC4.o
 CC     block/cmdline-parser.o
 CC [M] 加密/authenc.o
 CC [M] drivers/ata/SATA_MV.o
 CC     块/blk-mQ-pci.o
 CC [M] 加密/验证 n.o
 LD     阻止/内置 o
 CC [M] 加密/drbg.o
 CC     FS/ext4/symlink.o
 CC     FS/ext4/hash-o
 cc [M] crypto/jitterentropy.o
 LD [M] drivers/ata/libata.o
 LD     驱动程序/auxdisplay/built-in.o
 CC     驱动器/底座/组件
 cc [M] crypto/jitterentropy-kcapi.o
 抄送     驱动程序/阻止/返修
 CC     fs/ext4/resize.o
 cc [M] crypto/tcrypt.o
 CC     驱动器/基极/内核.o
 CC     驱动器/块/循环
 CC     FS/ext4/extts.o
 CC [M] 加密/Ghash-generic.o
 CC     驱动器/块/virtio_blk.o
 CC     驱动器/基站/总线
 CC [M] 加密/af_ALG.o
 LD     驱动程序/块/内置.o
 cc [M] crypto/algif_hash-
 CC     驱动程序/基本/dd.o
 CC     驱动器/基极/系统分数。o
 CC [M] crypto/algif_skciped.o
 CC     sound/sound core.o
 CC     fs/ext4/ext4_jbd2.o
 LD     声音/ARM/Built-in.o
 LD     声音/Atmel/Built-in.o
 CC     SOUND / CORE / SOUND
 CC     驱动器/基座/驱动器。o
 CC     FS/ext4/migrate.o
 CC     sound/core/init.o
 CC [M] crypto/ablk_helper.o
 CC     驱动器/基座/class.o
 CC     FS/ext4/mballoc.o
 CC     SOUND / CORE / MEMORe.o
 CC     驱动器/基座/平台.o
 ldo crypto/crypto.o
 LD     crypto/crypto_algapi.o
 ldo crypto/crypto_Blkciphip.o
 ldo crypto/crypto_hash.o
 LD     加密/加密引擎
 LD [M] 加密/jitterentropy_rng.o
 LD     加密/内置
 CC     驱动器/base/cpu.o
 CC     SOUND / CORE / CONTL.o
 LD     固件/built-in.o
 CC     FS/ext4/block_validity.o
 CC     驱动程序/基本/固件.o
 CC     驱动程序/base/init.o
 CC     fs/fat/cache.o
 CC     声音/核心/MISC.o
 CC     驱动器/基站/地图
 CC     驱动器/基极/ DevRes.o
 CC     fs/fat/dir.o
 CC     SOUND / CORE / DEVICE.o
 CC     FS/ext4/move_sext.o
 CC     SOUND / CORE / INFo.o
 CC     驱动程序/base/attribute_container.o
 CC     FS/Fat / Fatent.o
 CC     驱动器/基极/传输类.o
 CC     FS/ext4/MMP.o
 CC     SOUND / CORE / ctljack.o
 CC     SOUND / CORE / JACK
 CC     驱动器/基极/拓扑
 CC     FS/ext4/INDIRECT
 CC     驱动器/底座/容器.o
 CC     SOUND / CORE /定时器.o
 CC     fs/fat/file.o
 CC     驱动程序/基址/属性
 CC     FS/ext4/extTS_STATUS.o
 CC     FS/Fat / inode
 CC     FS/ext4/xattR.o
 CC     SOUND / CORE /PCM.o
 CC     驱动程序/基本/cacheinfo.o
 CC     驱动程序/base/devtmpfs.o
 CC     FS/F脂肪/杂项
 CC     sound/core/pcm_native.o
 CC     FS/ext4/xattr_user.o
 CC     驱动程序/基本/dma-in连。o
 CC     FS/FL/NFS.o
 CC     FS/ext4/xatttr_trusted.o
 CC     fs/fat/namei_vfat.o
 CC     驱动器/基极/电源/sysfs.o
 CC     FS/ext4/inline.o
 CC     fs/fat/namei_msdos.o
 CC     驱动器/基极/电源/通用_ops.o
 LD     Fs/fat/fat.o
 LD     fs/fat/vfat.o
 LD     fs/fat/msdos.o
 LD     Fs/fat/built-in.o
 CC     驱动器/基极/电源/共模
 CC     sound/core/pcm_lib.o
 CC     FS/ext4/readpage.o
 CC     FS/ext4/sysfs.o
 CC     驱动程序/基本/power/qos.o
 CC     驱动器/基极/ regmap/regmap.o
 CC     FS/ext4/ACL.o
 CC     驱动器/基极/电源/运行时.o
 CC     FS/ext4/xattR_security.o
 CC     SOUND / CORE/PCM_MISC.o
 LD     FS/ext4/ext4.o
 LD     FS/ext4/built-in.o
 LD     FS/fsck /built-in.o
 CC [M] FS/fsck /cache.o
 CC     驱动程序/base/regmap/regcache.o
 CC     驱动器/基极/电源/wakeirq.o
 CC     SOUND / CORE/PCM_MEMORe.o
 抄送[M] FS/fsck /Cookie.o
 CC     驱动程序/base/regmap/regcache-rbtree.o
 CC     驱动器/基极/电源/main.o
 CC     sound/core/memalloc.o
 CC     驱动程序/基/ regmap/regcache-lzo.o
 CC [M] FS/fsck /fsdef.o
 CC     驱动器/基极/ regmap/regcache-flat-o
 CC     SOUND / CORE/PCM_TIMER.o
 CC [M] FS/fsck /main.o
 CC     驱动程序/base/regmap/regmap-debugfs.o
 CC [M] FS/fsck /netfs.o
 CC     sound/core/pcm_drm_eld.o
 CC     驱动器/基极/电源/唤醒。o
 CC     驱动程序/base/regmap/regmap-i2c.o
 CC [M] FS/fsck /object.o
 CC     SOUND / CORE/PCM_iec958.o
 CC     驱动器/base/regmap/regmap-spi.o
 CC     SOUND / CORE/PCM_dmaengine.o
 CC     驱动器/基极/电源/ opp/core.o
 CC     驱动器/基极/ regmap/regmap-MMIO.o
 CC [M] FS/fsck / operation.o
 cc [M] sound/core/hwdep.o
 CC     驱动程序/base/regmap/regmap-IRQ.o
 CC     驱动器/基极/电源/opp/cpu.o
 CC [M] FS/fsck /page.o
 CC [M] sound/core/rawmidi.o
 LD     驱动程序/base/regmap/built-in.o
 CC [M] FS/fsck /proc.o
 CC     驱动器/基极/电源/opp/f.o
 LD     声音/驱动程序/mpu401/built-in.o
 LD     声音/驱动程序/opl3/built-in.o
 LD     声音/驱动程序/opl4/built-in.o
 LD     声音/驱动程序/pcsp/built-in.o
 LD     声音/驱动器/vx/built-in.o
 LD     声音/驱动程序/built-in.o
 CC     驱动器/基极/电源/ opp/debugfs.o
 LD [M] FS/fsck /fsck
 cc     fs/jbd2/transaction.o
 CC     fs/jbd2/commit.o
 CC     驱动器/基极/电源/ opp/ti-opp-supply.o
 LD     声音/核心/snd.o
 LD     声音/核心/nd-timer.o
 LD     声音/核心/snd-pcm.o
 LD     声音/核心/snd-pcm-dmaengine.o
 LD [M] 声音/核心/snd-hwdep.o
 LD [M] 声音/核心/snd-rawmidi
 LD     声音/核心/内置
 LD     声音/火线/内置
 LD     声音/hda/built-in.o
 LD     驱动器/基极/电源/opp/built-in.o
 CC     驱动器/基极/电源/时钟_ops.o
 LD     声音/i2c/OTHER 内置
 LD     声音/i2c/built-in.o
 LD     sound/sa/ad1816a/built-in.o
 LD     sound/sa/ad1848/built-in.o
 LD     sound/sa/cs423x/built-in.o
 LD     声音/ISA/es1688/Built-in.o
 LD     声音/ISA/galaxy/built-in.o
 LD     声音/ISA/Gus/Built-in.o
 LD     sound/sa/msnd/built-in.o
 LD     sound/sa/opti9xx/built-in.o
 LD     sound/sa//sb/built-in.o
 LD     声音/ISA/波前/内置
 LD     sound/sa/wss/built-in.o
 LD     sound/sa/built-in.o
 LD     声音/MIPS/Built-in.o
 LD     声音/parisc/built-in.o
 LD     sound/pci/ac97/built-in.o
 LD     sound/spci/ali5451/built-in.o
 LD     sound/spi/phasii/built-in.o
 LD     sound/spi/au88x0/built-in.o
 LD     声音/PCI/aw2/built-in.o
 LD     声音/PCI/Ca0106/Built-in.o
 LD     sound/spci/sc46xx/built-in.o
 LD     声音/PCI/CS5535AUDIO/Built-in.o
 LD     sound/ci/ctxfi/built-in.o
 LD     声音/PCI/回声音频/Built-in.o
 LD     sound/spi/emu10k1/built-in.o
 LD     sound/spi/hda/built-in.o
 LD     声音/PCI/ice1712/built-in.o
 LD     sound/spi/korg1212/built-in.o
 LD     声音/PCI/Lola/Built-in.o
 LD     sound/spi/lx64es/built-in.o
 LD     sound/sPCMCIA/pdaudiocf/built-in.o
 LD     声音/PCI/混音器/内置
 LD     SOUND /PCMCIA/VX/Built-in.o
 LD     声音/PCMCIA/Built-in.o
 LD     sound/spi/nm256/built-in.o
 CC     fs/jbd2/recovery
 LD     声音/PCI/氧气/内置
 LD     sound/spci/pcxhr/built-in.o
 LD     声音/PCI/波纹/内置
 LD     sound/spi/rme9652/built-in.o
 LD     声音/PCI/三叉式/内置
 LD     sound/spi/vx222/built-in.o
 LD     sound/spi/ymfpci/built-in.o
 LD     声音/PCI/内置
 LD     声音/PPC/Built-in.o
 LD     sound/sh 内置.o
 CC     sound/soc/co-core.o
 LD     驱动器/基极/电源/内置
 CC     驱动程序/基地址/dma-mapping。o
 CC     驱动器/基/dma-相干
 cc     fs/jbd2/checkpoint.o
 CC     sound/soc/co-dapm.o
 CC     驱动程序/base/firmware_class.o
 CC     fs/jbd2/reve.o
 CC     FS/jbd2/journal.o
 CC     驱动器/基座/模块.o
 CC     fs/kernfs/mount.o
 CC     驱动器/base/SoC.o
 CC     fs/kernfs/inode.o
 CC     驱动器/底座/pinctrl.o
 CC     驱动器/基极/ devcoredump.o
 CC     fs/kernfs/dir.o
 CC     sound/soc/co-jack.o
 LD     fs/jbd2/jbd2.o
 LD     fs/jbd2/built-in.o
 CC     fs/lockd/clntlock.o
 CC     sound/soc/co-cache.o
 CC     drivers/base/platform-msi.o
 CC     fs/kernfs/file.o
 CC     sound/soc/co-utils.o
 LD     驱动程序/基本/内置
 CC     fs/lockd/clntproc.o
 LD     驱动程序/蓝牙/built-in.o
 CC [M] 驱动程序/Bluetooth/HCI_ldis.o
 CC     sound/soc/co-pcm.o
 CC     fs/kernfs/symlink.o
 CC [M] 驱动程序/Bluetooth/HCI_H4.o
 LD     fs/kernfs/built-in.o
 CC [M] 驱动程序/Bluetooth/HCI_LL.o
 CC     fs/lockd/clntxdr.o
 CC     fs/lockd/host.o
 CC [M] 驱动程序/Bluetooth/HCI_H5.o
 CC     sound/soc/co-io.o
 CC     sound/soc/co-DevRes.o
 CC     FS/lockd/Svc.o
 CC     fs/lockd/svclock.o
 cc [M] drivers/bluetooth/btmrvL_main.o
 CC     sound/soc/co-ops.o
 CC     sound/soc/co-generic-dmaengine-pcm.o
 cc [M] drivers/bluetooth/btmrvL_debugfs.o
 CC     fs/lockd/svcshare.o
 LD     声音/SPARC/Built-in.o
 CC     网/插座
 LD     sound/soc/Adi/built-in.o
 LD     sound/soc/amd/built-in.o
 LD     sound/soc/Atmel/built-in.o
 LD     sound/soc/au1x/built-in.o
 LD     sound/soc/cbc/built-in.o
 LD     sound/soc/blackfin/built-in.o
 CC [M] drivers/bluetooth/btmrvL_SDIO.o
 LD     声音/SoC/Cirrus /内置.o
 CC     sound/soc/codecs/HDMI-codec.o
 CC     fs/lockd/svcproc.o
 CC [M] sound/soc/codecs/ak4642.o
 LD [M] 驱动程序/Bluetooth/HCI_UART.o
 LD [M] 驱动程序/Bluetooth/btmrv1.o
 CC     驱动程序/bus/omap-ocp2scp.o
 CC [M] sound/soc/codecs/sgtl5000.o
 CC     fs/lockd/svcsubs.o
 LD     驱动程序/bus/built-in.o
 LD     驱动程序/cdrom/built-in.o
 CC [M] drivers/cdrom/cdrom.o
 CC [M] sound/soc/codecs/SPDIF_RECEIVER.o
 LD     NET/802/built-in.o
 cc [M] net/802/p8022.o
 CC     fs/lockd/mon.o
 CC [M] sound/soc/codecs/SPDIF_TRANSMER.o
 CC [M] sound/soc/codecs/STI-SAS.o
 CC [M] NET/802/psnap
 CC     驱动程序/char/mem.o
 CC     FS/lockd/XDR.o
 CC [M] sound/soc/codecs/tlv320aic31xx.o
 CC [M] NET/802/STP.o
 CC     驱动程序/char/random.o
 CC     fs/lockd/clnt4xdr.o
 CC [M] sound/soc/codecs/tlv320aic3x.o
 CC     net/8021q/vlan_core.o
 CC     fs/lockd/xdr4.o
 CC [M] sound/soc/codecs/wm8978.o
 CC     驱动程序/char/misc.o
 抄送[M] net/8021q/vlan.o
 CC     fs/lockd/svc4proc.o
 CC     驱动程序/char/virtio_console.o
 LD     sound/soc/codecs/snd-soc HDMI 编解码器.o
 LD [M] sound/soc/codecs/snd-so-ak4642.o
 LD [M] sound/soc/codecs/snd-so-sgtl5000.o
 LD [M] sound/soc/codecs/snd-so-spdif-rx.o
 LD [M] sound/soc/codecs/snd-soc SPDIF-TX.o
 LD [M] sound/soc/codecs/snd-soc - STI-SAS.o
 LD [M] sound/soc/codecs/snd-so-tlv320aic31xx.o
 LD [M] sound/soc/codecs/snd-so-tlv320aic3x.o
 LD [M] sound/soc/codecs/snd-so-wm8978.o
 LD     sound/soc/codecs/built-in.o
 CC     sound/soc/co/Davinci/EDMA-PCM.o
 抄送[M] net/8021q/vlan_dev.o
 CC     sound/soc/co/Davinci/Davinci-McAP.o
 CC     fs/lockd/procfg.o
 抄送[M] net/8021q/vlan_netlink.o
 LD     驱动程序/char/agp/built-in.o
 CC     驱动程序/char/hw_random/core.o
 LD     fs/lockd/lockd.o
 LD     fs/lockd/built-in.o
 CC     FS/NFS/CLIENT.o
 cc [M] net/8021q/vlanproc.o
 CC [M] sound/soc/co/Davinci/Davinci-evm.o
 CC     驱动程序/char/hw_random/omap-rng.o
 LD     声音/SoC/DaVinci/snd-SoC-EDMA.o
 LD     声音/SoC/DaVinci/snd-SoC-DaVincia-McAP.o
 LD [M] sound/soc/cooDaVinci/snd-so-evm.o
 LD     sound/soc/cDaVinci 内置 o
 LD     声音/SoC/DWC/Built-in.o
 LD     sound/soc/fsl/built-in.o
 CC [M] sound/soc/FSL/FSL_SAI.o
 LD     net/8021q/built-in.o
 LD [M] net/8021q/8021q.o
 LD     驱动程序/char/hw_random/rng-core.o
 LD     驱动程序/char/hw_random/built-in.o
 LD     驱动程序/char/built-in.o
 LD     net/bluetooth/built-in.o
 CC [M] Net/Bluetooth/af_Bluetooth.o
 LD     驱动程序/char/ipmi/built-in.o
 CC     驱动器/clk/clk-DevRes.o
 CC     驱动程序/clk/clkdev.o
 CC     FS/NFS/DIR.o
 LD [M] sound/soc/FSL/snd-soc FSL-SAI.o
 LD     sound/soc/cgeneral/built-in.o
 CC [M] sound/soc/general/simple-card-utils.o
 CC     驱动程序/clk/clk.o
 CC [M] Net/Bluetooth/HCI_CORE.o
 CC [M] sound/soc/c通用/简单卡.o
 LD [M] sound/soc/cgeneral/snd-so-simple-card-utils.o
 LD [M] sound/soc/cgeneral/snd-soc 简单卡.o
 LD     sound/soc/img/built-in.o
 LD     sound/soc/intel/boards/built-in.o
 LD     sound/soc/intel/built-in.o
 LD     sound/soc/jz4740/built-in.o
 LD     sound/soc/Kirkwood/built-in.o
 LD     sound/soc/cMediaTek/built-in.o
 LD     sound/soc/MXs/built-in.o
 LD     sound/soc/cnuc900/built-in.o
 CC     sound/soc/comap/omap-pcm.o
 CC     驱动器/clk/clk-divider
 CC [M] sound/soc/comap/OMAP-HDMI-audio.o
 CC     FS/NFS/FILE.o
 LD     sound/soc/omap/snd-so-omap.o
 LD [M] sound/soc/comap/snd-soc OMAP-HDMI-audio.o
 LD     sound/soc/omap/built-in.o
 LD     sound/soc/PXA/built-in.o
 LD     sound/soc/QCOM/built-in.o
 LD     sound/soc/Rockchip/built-in.o
 LD     sound/soc/samsun/built-in.o
 LD     sound/soc/sh/built-in.o
 LD     声音/SoC/SiRF/Built-in.o
 LD     sound/soc/spear/built-in.o
 LD     sound/soc/STI/built-in.o
 LD     sound/soc/sunxi/built-in.o
 LD     声音/SoC/Tegra/Built-in.o
 LD     sound/soc/txx9/built-in.o
 LD     sound/soc/ux500/built-in.o
 LD     sound/soc/xtensa/built-in.o
 LD     声音/SoC/ZTE/Built-in.o
 LD     sound/soc/snd-soc 内核.o
 LD     sound/soc/built-in.o
 LD     声音/SPI/Built-in.o
 LD     声音/合成/内置.o
 LD     声音/USB/6Fire/Built-in.o
 LD     sound/usb/bcd2000/built-in.o
 LD     sound/usb/caaq/built-in.o
 LD     声音/USB/hiface/built-in.o
 LD     声音/USB/MISC/Built-in.o
 LD     SOUND /USB/usx2年/Built-in.o
 CC [M] sound/usb/scard.o
 CC [M] Net/Bluetooth/HCI_conn.o
 CC     驱动器/clk/clk-fix-factor
 CC [M] sound/usb/clock.o
 CC     驱动器/clk/clk-fix-rate
 CC     FS/NFS/getroot.o
 CC [M] sound/USB 端点.o
 CC     驱动器/clk/clk-gate.o
 CC     FS/NFS/inode
 CC [M] Net/Bluetooth/HCI_EVENT.o
 CC     驱动器/clk/clk-multipler.o
 CC [M] sound/usb/format.o
 CC     驱动器/clk/clk-mux.o
 CC [M] sound/usb/shelper.o
 CC [M] sound/usb/smixer.o
 CC     驱动程序/clk/clk-composio.o
 CC     驱动器/clk/clk-分数 分频器.o
 CC     FS/NFS/SUB.o
 CC     驱动器/clk/clk-GPIO.o
 CC [M] sound/usb/smixer_quirks.o
 CC     驱动程序/clk/clk-conf.o
 CC [M] Net/Bluetooth/mgmt.o
 CC     驱动器/clk/clk-Palms.o
 CC [M] sound/usb/smixer_Scarlett
 LD     驱动程序/clk/BCM/Built-in.o
 LD     驱动程序/clk/mvebu/built-in.o
 CC     驱动程序/clk/ti/clk.o
 CC [M] sound/USB PCM.o
 CC     FS/NFS/IO.o
 CC     驱动程序/clk/ti/autobide.o
 CC     驱动程序/clk/ti/clockdomain.o
 CC     驱动器/clk/ti/DPLL.o
 CC     FS/NFS/Direct.o
 CC [M] sound/usb/proc.o
 CC     驱动程序/clk/ti/compose.o
 CC [M] sound/usb/squirks.o
 CC     驱动器/clk/ti/divider
 CC     驱动器/clk/ti/gate.o
 CC [M] sound/usb/sream
 CC     FS/NFS/pagelist.o
 CC [M] Net/Bluetooth/HCI_SOCSOCSOCSOC.o
 CC     驱动器/clk/ti/fix-facter.o
 CC [M] sound/usb/smidi.o
 CC     驱动器/clk/ti/mux.o
 CC     驱动器/clk/ti/apll.o
 CC     驱动器/clk/ti/clkT_DPLL.o
 CC     FS/NFS/Read.o
 CC     驱动程序/clk/ti/clkT_iclk.o
 LD     声音/USB/Built-in.o
 LD [M] sound/usb/snd-usb-audio.o
 LD [M] sound/usb/snd-usbmidi-lib.o
 CC     SOUND / LAN.o
 CC [M] Net/Bluetooth/HCI_sysfs.o
 CC     驱动程序/clk/ti/clkT_dflt.o
 LD     声音/声音核心
 LD     声音/内置
 CC     驱动程序/clk/ti/clk-33xx.o
 ARM/ARM/lib/ashldi3.o
 ARM/ARM/lib/ashrdio.o
 arch/arm/lib/backtrace.o
 CC     驱动程序/clk/ti/dpll3xxx.o
 ARM/ARM/lib/bswapsdi2.o
 ARM/ARM/lib/call_with_stack.o
 ARM/ARM/lib/changebit.o
 CC [M] net/bluetooth/l2cap_core.o
 ARM/ARM/lib/clear_user.o
 ARM/ARM/lib/clearbit.o
 作为     arch/arm/lib/copy_fin_user.o
 ARM/ARM/lib/copy_page.o
 作为     arch/arm/lib/copy_to _user.o
 arch/arm/lib/csumipv6.o
 arch/arm/lib/csumpartial.o
 arch/arm/lib/csumpartialcopy.o
 arch/arm/lib/csumpartialcopyuser.o
 CC     FS/NFS/symlink.o
 ARM/ARM/lib/delay-loop.o
 CC     arch/arm/lib/delay.o
 LD     驱动程序/clk/ti/built-in.o
 LD     驱动程序/clk/built-in.o
 CC     驱动器/时钟源/clksrc-probe.o
 arch/arm/lib/div64.o
 ARM/ARM/lib/findbit.o
 ARM/ARM/lib/getuser.o
 ARM/ARM/lib/IO-readsb.o
 ARM/ARM/lib/IO-readsl.o
 ARM/ARM/lib/IO-readsw-armv4.o
 ARM/ARM/lib/IO-writesb.o
 CC     驱动器/时钟源/MIO.o
 ARM/ARM/lib/IO-writesl.o
 ARM/ARM/lib/IO-writesw-armv4.o
 CC     FS/NFS/unlink.o
 ARM/ARM/lib/lib1funcs.o
 arch/arm/lib/lshrdi3.o
 ARM/ARM/lib/memchr.o
 ARM/ARM/lib/memcpy.o
 ARM/ARM/lib/memmove.o
 ARM/ARM/lib/memset.o
 ARM/ARM/lib/memzero.o
 ARM/ARM/lib/mudi3.o
 ARM/ARM/lib/putuser.o
 ARM/ARM/lib/setbit.o
 CC     驱动器/时钟源/计时器-ti-32k.o
 ARM/ARM/lib/strchr.o
 ARM/ARM/lib/strrchr.o
 ARM/ARM/lib/testchangebit.o
 arch/arm/lib/testclearbit.o
 ARM/ARM/lib/testsetbit.o
 arch/arm/lib/ucmpdi2.o
 AR     ararch/arm/lib.a
 导出 arch/arm/lib/lib-ksyms.o
 LD     arch/arm/lib/built-in.o
 CC     FS/NFS/WRITE.o
 LD     驱动程序/时钟源/内置.o
 CC     驱动器/cpufreq/cpufreq.o
 CC     fs/nfs_common/nfsacl.o
 CC     FS/NFS_common/grace.o
 LD     fs/nfs_common/nfs_acl.o
 LD     FS/NFS_common/built-in.o
 CC     驱动程序/cpufreq/freq_table.o
 LD     net/bridge/netfilter/built-in.o
 CC [M] net/bridge/netfilter/ebtables.o
 CC     驱动器/cpufreq/cpufreq_stats.o
 CC     FS/NFS/namespace.o
 CC     驱动程序/cpufreq/cpufreq_performance.o
 CC [M] Net/Bluetooth/l2cap_sock.o
 CC     驱动程序/cpufreq/cpufreq_powersave.o
 CC     驱动程序/cpufreq/cpufreq_userspace.o
 CC     驱动程序/cpufreq/cpufreq_onDemand。o
 CC     FS/NFS/LOAD_Clnt.o
 CC     驱动程序/cpufreq/cpufreq_concrise.o
 CC [M] net/bridge/netfilter/ebtable_Broute.o
 CC [M] Net/Bluetooth/SMP.o
 CC     驱动器/cpufreq/cpufreq_reguler.o
 CC     FS/NFS/nfstrace.o
 CC [M] net/bridge/netfilter/ebtable_filter.o
 CC     驱动器/cpufreq/cpufreq_reguler_attr_set.o
 CC     FS/NFS/nfsroot.o
 CC     驱动器/cpufreq/cpufreq-dt.o
 CC [M] net/bridge/netfilter/ebtable_NAT.o
 CC     驱动器/cpufreq/cpufreq-dt-platdev.o
 CC     FS/NFS/SYSCTL.o
 CC [M] net/bridge/netfilter/ebt_802_3.o
 cc     drivers/cpufreq/ti-cpufreq.o
 CC [M] net/bluetooth/lib.o
 CC     FS/NFS/nfs2super.o
 CC [M] net/bridge/netfilter/ebt_inter.o
 LD     驱动程序/cpufreq/built-in.o
 CC     驱动程序/cpuidle/cpuidle.o
 CC [M] Net/Bluetooth/EC.o
 CC     FS/NFS/PROC.o
 CC [M] net/bridge/netfilter/ebt_arp.o
 CC     驱动程序/cpuidle/driver.o
 CC [M] Net/Bluetooth/HCI_Request.o
 CC [M] net/bridge /netfilter/ebt_ip.o
 CC     驱动器/空闲/调速器
 CC     FS/NFS/nfs2xdr.o
 CC     驱动程序/cpuidle/sysfs.o
 CC     驱动器/空闲/调速器/梯形调速器
 CC [M] net/bridge/netfilter/ebt_ip6.o
 CC     DRIVERS/cputidle/regulers/menu.o
 CC     FS/NFS/nfs3super.o
 抄送[M] net/bluetooth/mgmt_util.o
 LD     驱动器/空闲/调速器/内置
 CC     驱动器/cpuidle/dt_idle_states.o
 CC [M] net/bridge/netfilter/ebt_limit.o
 CC     FS/NFS/nfs3client.o
 CC     驱动程序/cpuidle/cpuidle-arm.o
 抄送[M] Net/Bluetooth/SCO.o
 LD     驱动程序/cpuidle/built-in.o
 LD     驱动程序/crypto/built-in.o
 CC [M] 驱动程序/crypto/OMAP-AES.o
 CC [M] net/bridge/netfilter/ebt_mark_m.o
 CC     FS/NFS/nfs3proc.o
 cc [M] net/bridge/netfilter/ebt_pkttype.o
 CC [M] 驱动程序/crypto/OMAP-AES-GCM.o
 CC [M] Net/Bluetooth/a2mp.o
 CC [M] net/bridge/netfilter/ebt_stp.o
 CC     FS/NFS/nfs3xdr.o
 CC [M] 驱动程序/crypto/OMAP-DES.o
 CC [M] Net/Bluetooth/Amp.o
 CC [M] net/bridge/netfilter/ebt_vlan.o
 CC [M] drivers/crypto/OMAP-sham.o
 CC     FS/NFS/nfs3acl.o
 CC [M] Net/Bluetooth/HCI_debugfs.o
 CC [M] net/bridge/netfilter/ebt_arpreple.o
 CC     FS/NFS/nfs4proc.o
 CC [M] net/bridge /netfilter/ebt_mark.o
 LD [M] 驱动程序/crypto/OMAP-AES-driver.o
 CC     驱动程序/dma/dmaengine.o
 LD     NET/Bluetooth/RFCOMM/Built-in.o
 CC [M] Net/Bluetooth/RFCOMM/core.o
 CC [M] net/bridge/netfilter/ebt_DNAT.o
 CC [M] Net/Bluetooth/RFCOMM/SOCSOCSOCSOCSON.o
 CC     驱动程序/dma/virt-dma.o
 CC [M] net/bridge /netfilter/ebt_redirect.o
 CC     驱动程序/dma/of-dma.o
 CC [M] net/bridge/netfilter/ebt_sNAT.o
 LD [M] Net/Bluetooth/RFCOMM/RFCOMM.o
 LD [M] Net/Bluetooth/Bluetooth.o
 CC [M] net/bridge/netfilter/ebt_log.o
 CC     驱动程序/DMA/OMAP-DMA.o
 CC     FS/NFS/nfs4xdr.o
 CC     驱动程序/dma/dw/core.o
 CC [M] net/gride/netfilter/ebt_nflog.o
 抄送[M] 网/桥/br.o
 CC [M] net/bridge/br_device.o
 CC     驱动程序/dma/dw/platform.o
 CC     FS/NLS/NLS_BASE.o
 LD     驱动程序/dma/dw/dw_DMAC_core.o
 LD     驱动程序/dma/dw/dw_dmc.o
 LD     驱动程序/dma/dw/built-in.o
 LD     驱动程序/DMA/QCOM/built-in.o
 LD     驱动程序/dma/Xilinx/built-in.o
 CC     驱动器/DMA/FSL-EDMA.o
 CC     FS/NLS/NLS_cp437.o
 CC     FS/NLS/NLS_ISO8859-1.o
 CC [M] net/bridge/br_FDB.o
 CC     FS/NFS/nfs4state.o
 CC     FS/NLS/NLS_utf8.o
 LD     FS/NLS/内置.o
 CC [M] net/bridge/br_forward.o
 CC     驱动程序/dma/ccppi41.o
 抄送     fs/notify/fspnotife.o
 CC     驱动器/dma/ti-dma-crossbar.o
 CC [M] net/bridge/br_if.o
 抄送     FS/NOTIFICE/NOTIFICATION.o
 CC     驱动程序/DMA/EDMA.o
 CC     FS/NFS/nfs4renewd.o
 抄送     FS/NOTIFE/group.o
 CC [M] NET/BRIDE/br_input.o
 CC     FS/NFS/nfs4super.o
 CC     FS/NOTIFE/INDE_MARG.o
 抄送     FS/NOTIFY/MART.o
 LD     驱动程序/dma/built-in.o
 CC     驱动程序/dma-buf/dma-buf.o
 CC     FS/NFS/nfs4file.o
 cc [M] net/bridge/br_ioctl.o
 CC     fs/notify/vfsmount_mark.o
 CC     FS/NFS/Delegation.o
 CC     驱动器/dma-buf/fence.o
 抄送     fs/notif/fdinfo.o
 抄送     fs/notify/dnotify/dnotife.o
 CC [M] net/bridge/br_stp.o
 CC     驱动程序/dma-buf/reservation.o
 LD     fs/notify/dnotify/built-in.o
 LD     Fs/notify/fanoalance/built-in.o
 抄送     FS/NOTIFICE/INOENDE/INOENALOG_fsnotife.o
 抄送     FS/NOTIFICE/INOENDE/INOENALOG_USER.o
 CC     驱动器/dma-buf/seqno-fence.o
 CC     FS/NFS/nfs4idmap.o
 CC [M] net/bridge/br_stp_Bpdu
 LD     FS/NOTIFE/IN认证/Built-in.o
 LD     FS/NOTIFE/Built-in.o
 CC [M] net/bridge/br_stp_if.o
 CC     驱动器/dma-buf/safe-array.o
 CC     驱动器/EDAC/EDAC_stub.o
 LD     驱动程序/dma-buf/built-in.o
 CC     lib/lockref.o
 CC     lib/bcd.o
 CC [M] net/bridge/br_stp_timer.o
 CC     lib/div64.o
 CC     FS/NFS/callback.o
 CC     驱动器/EDAC/EDAC_MC.o
 CC     lib/sort.o
 CC     lib/parser.o
 CC [M] net/bridge/br_netlink.o
 CC     lib/shalmd4.o
 CC     FS/NFS/calling_XDR.o
 CC     lib/debug_locks.o
 CC     lib/Random32.o
 CC     驱动器/EDAC/EDAC_DEVICE.o
 CC     lib/bust_spinlocks.o
 CC     FS/NFS/calling_proc.o
 CC     lib/kasprintf.o
 CC [M] net/bridge/br_sysfs_if.o
 CC     驱动程序/EDAC/EDAC_MC_sysfs.o
 CC     lib/bitmap.o
 CC     FS/NFS/nfs4namespace.o
 CC     驱动器/EDAC/EDAC_MODULE.o
 CC [M] net/bridge/br_sysfs_br.o
 CC     lib/scatterlist.o
 CC     驱动程序/EDAC/EDAC_DEVICE_sysfs.o
 CC     FS/NFS/nfs4getroot.o
 CC     lib/GCD.o
 CC [M] net/bridge/br_nf_core.o
 CC     lib/LCM.o
 CC     驱动器/EDAC/wq.o
 CC     lib/list_sort.o
 cc     lib/uuid.o
 CC     lib/flex_array.o
 CC     FS/NFS/nfs4client.o
 CC [M] net/bridge/br_multiconing.o
 CC     驱动程序/EDAC/EDAC_PCI.o
 CC     lib/IOV_ITER.o
 CC     驱动程序/EDAC/EDAC_PCI_sysfs.o
 CC     FS/NFS/nfs4Session.o
 LD     驱动程序/EDAC/EDAC_CORE.o
 LD     驱动程序/EDAC/Built-in.o
 LD     驱动程序/extcon/built-in.o
 CC [M] drivers/extcon/extcon.o
 CC     lib/clz_ctz.o
 CC     lib/bsearch.o
 CC     lib/find_bit.o
 CC     lib/llist.o
 CC     lib/memweight.o
 CC [M] net/bridge/br_mdb.o
 CC     lib/kfifo.o
 CC     FS/NFS/DNS_Resolve.o
 CC [M] drivers/extCON/DevRes.o
 CC [M] drivers/extcon/extcon-Palmas.o
 CC     lib/perpu-refcount.o
 CC     FS/NFS/nfs4trace.o
 CC [M] net/bridge/br_switchdev.o
 CC [M] 驱动程序/extCON/extCON-USB-GPIO.o
 CC     lib/perpu_ida.o
 LD [M] 驱动程序/extcon/extcon-core.o
 LD     驱动器/firewire /内置 o
 LD     驱动程序/固件/Broadcom/built-in.o
 CC     驱动程序/固件/EFI/EFI.o
 CC [M] net/bridge/br_netfilter_hooks.o
 CC     FS/NFS/nfs4sysctl.o
 CC     lib/rhashtable.o
 CC     驱动程序/固件/efi/vars.o
 LD     FS/NFS/NFS.o
 LD     FS/NFS/NFSv2.o
 LD     FS/NFS/NFSv3
 LD     FS/NFS/NFSv4.o
 LD     FS/NFS/Built-in.o
 CC     FS/NTFS/aops.o
 CC     lib/倒数_div.o
 CC     lib/one.o
 CC     lib/string_Helper。o
 CC [M] net/bridge/br_netfilter_ipv6
 CC     驱动程序/固件/EFI/reboot.o
 CC     FS/NTFS/ATTRIGB.o
 CC     驱动程序/固件/EFI/memattr.o
 CC     驱动程序/固件/EFI/胶囊
 CC     lib/hexdump.o
 LD     网络/桥接/内置
 LD [M] 网络/桥/桥
 LD [M] net/bridge/br_netfilter.o
 LD     net/CAN/built-in.o
 CC     FS/NTFS/自动 分页
 CC [M] net/CAN/af_CAN.o
 CC     lib/kstrtox.o
 CC     FS/NTFS/compress.o
 CC     驱动程序/固件/EFI/memmap.o
 CC     lib/pci_iomap.o
 CC     驱动程序/固件/EFI/esrT.o
 CC     lib/iomap_copy.o
 CC     FS/NTFS/DEBUG.o
 cc [M] net/CN/proc.o
 CC     lib/DevRes.o
 CC     FS/NTFS/DIR.o
 CC     驱动程序/固件/EFI/Runtime-wrapers.o
 CC [M] NET/CAN/RAW.o
 CC     驱动程序/固件/EFI/libstub/arm-stub.o
 CC     lib/hweight.o
 CC     lib/assoc_array.o
 CC     FS/NTFS/FILE.o
 CC     驱动程序/固件/EFI/libstub/arm32-stub.o
 CC     lib/bitrev.o
 CC     lib/rational
 CC     FS/NTFS/index.o
 CC     lib/crc16.o
 CC [M] NET/CAN/BCM.o
 CC     驱动程序/固件/efi/libstub/efi-stub-helper.o
 HOSTCC lib/gen_crc32表
 CC     lib/genalloc.o
 CC     FS/NTFS/inode inode.o
 CC     驱动程序/固件/EFI/libstub/FDT.o
 CC     lib/fonts/fonts.o
 CC     驱动程序/固件/EFI/libstub/GOP.o
 CC [M] NET/CAN/GW.o
 CC     lib/fonts/fonts_8x8.o
 CC     lib/fonts/fonts_8x16.o
 CC     FS/NTFS/MFT.o
 CC     驱动程序/固件/EFI/libstub/lib-FDT.o
 LD     lib/fonts/fonts.o
 LD     lib/fonts/built-in.o
 CC     lib/lz4/lz4_decompress.o
 CC     驱动程序/固件/EFI/libstub/lib-FDT_empty_tree.o
 CC     驱动程序/固件/EFI/libstub/lib-FDT_ro.o
 LD     lib/lz4/built-in.o
 CC     lib/lso/lzo1x_compress.o
 CC     驱动程序/固件/EFI/libstub/lib-FDT_rw.o
 CC     驱动程序/固件/EFI/libstub/lib-FDT_sw.o
 LD [M] NET/CAN/CN.o
 LD [M] NET/CAN/CAN - RAW.o
 LD [M] NET/CAN/CAN - BCM.o
 LD [M] net/CAN/CAN-Gw.o
 CC     net/core/sock.o
 CC     FS/NTFS/mst.o
 CC     驱动程序/固件/EFI/libstub/lib-FDT_WIP
 CC     lib/lzo/lzo1x_decompress_safe.o
 CC     驱动程序/固件/efi/libstub/lib-sort.o
 CC     驱动程序/固件/EFI/libstub/string.o
 STUBCPY 驱动程序/固件/EFI/libstub/arm-stub.stub.o
 抄送     FS/NTFS/namee.o
 STUBCPY 驱动程序/固件/efi/libstub/arm32-stub.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/EFI-stub-helper.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/FDT.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/GOP.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/lib-fdt.stub.o
 STUBCPY 驱动程序/固件/efi/libstub/lib-fdt_empty_tree.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/lib-fdt_ro.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/lib-fdt_rw.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/lib-FDT_SW.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/lib-FDT_WIP .stub.o
 STUBCPY 驱动程序/固件/efi/libstub/lib-sort.stub.o
 STUBCPY 驱动程序/固件/EFI/libstub/string.stub.o
 AR     驱动程序/固件/efi/libstub/lib.a
 导出驱动程序/固件/efi/libstub/lib-ksyms.o
 LD     驱动程序/固件/efi/libstub/built-in.o
 CC     驱动程序/固件/EFI/ARM-init.o
 LD     lib/lzo/lzo_compress.o
 LD     lib/lzo/lzo_decompress.o
 LD     lib/lso/built-in.o
 CC     lib/xz/xz_dec_syms.o
 CC     lib/xz/xz_dec_stream.o
 CC     FS/NTFS/Runlist.o
 CC     驱动程序/固件/EFI/ARM-Runtime.o
 CC     lib/xz/xz_dec_lzma2.o
 CC [M] drivers/firmware/efi/efivars.o
 CC     FS/NTFS/SUB.o
 CC     lib/xz/xz_dec_Bcj.o
 抄送[M] 驱动程序/固件/EFI/c胶囊 加载程序.o
 LD     lib/xz/xz_dec.o
 LD     lib/xz/built-in.o
 CC     lib/zlib_fere/fero.o
 CC     net/core/request_sock.o
 LD     驱动程序/固件/efi/built-in.o
 LD     驱动程序/固件/meson/built-in.o
 LD     驱动程序/固件/built-in.o
 CC     驱动器/GPIO/DevRes.o
 CC     lib/zlib_fed/deftree.o
 CC     FS/NTFS/SYSCTL.o
 CC     FS/NTFS/unist.o
 CC     驱动器/GPIO/gpioib.o
 CC     网络/内核/ skbux.o
 CC     FS/NTFS/upcase.o
 CC     lib/zlib_fed放 气/fiz_syms.o
 LD     lib/zlib_fed/zlib_fed.o
 LD     lib/zlib_fize/built-in.o
 CC     lib/zlib_infly/inffast.o
 LD     FS/NTFS/NTFS.o
 LD     FS/NTFS/Built-in.o
 CC     fs/proc/task_MM4.o
 CC     lib/zlib_infly/inflate.o
 CC     lib/zlib_infly/infutil.o
 CC     lib/zlib_infly/inftrees.o
 CC     fs/proc/inode.o
 CC     lib/zlib_infly/inflate_syms.o
 CC     驱动器/GPIO/gpioib-legacy
 LD     lib/zlib_infly/zlib_inflate.o
 LD     lib/zlib_infly/built-in.o
 CC     lib/Bch.o
 CC     fs/proc/root.o
 CC     驱动器/GPIO/gpioolib-of
 CC     fs/proc/base.o
 CC     lib/textsearch.o
 CC     驱动器/GPIO/gpioib-sysfs.o
 CC     net/core/dat报.o
 CC     lib/swiotlb.o
 CC     驱动程序/GPIO/GPIO-OMAP.o
 CC     fs/proc/generic.o
 CC     net/core/stream.o
 CC     lib/iommu-helper.o
 CC     驱动器/GPIO/GPIO-pcf857x.o
 CC     lib/iommu-common.o
 CC     fs/proc/array.o
 CC     驱动器/GPIO/GPIO-SYSCON.o
 CC     lib/syscall.o
 CC     NET/CORE/SCM.o
 CC     驱动器/GPIO/GPIO-Palmas.o
 CC     lib/nlattr.o
 CC     FS/proc/fd.o
 CC     驱动器/GPIO/GPIO-tps65910.o
 CC [M] DRIVERS/GPIO/GPIO-pca953x.o
 CC     fs/proc/proc_tty.o
 CC     lib/dynamical_queue_limits.o
 CC     net/core/gen_stats.o
 CC     fs/proc/cmdline.o
 CC     lib/glob.o
 CC [M] 驱动器/GPIO/GPIO-pisosr.o
 CC     fs/proc/console.o
 CC     lib/strncpy_fin_user.o
 CC     fs/proc/cpuinfo.o
 CC [M] 驱动器/GPIO/GPIO-tpic2810.o
 CC     fs/proc/devices.o
 CC     lib/strnlen_user.o
 CC     net/core/gen_estimator.o
 CC     fs/proc/interrupts.o
 LD     驱动程序/GPIO/Built-in.o
 CC     驱动程序/GPU/DRM/DRM_CRTC_helper.o
 CC     lib/net_utils.o
 CC     fs/proc/loadavg.o
 CC     fs/proc/meminfo.o
 CC     lib/sG_split.o
 CC     net/core/net_namespace.o
 CC     fs/proc/stat.o
 CC     lib/sg_pool.o
 CC     驱动程序/GPU/DRM/DRM_DP_helper.o
 CC     fs/proc/uponx.o
 生成    lib/OID_registry_data.c
在@INC 中找不到 strict.pm (您可能需要安装严格模块)(@INC 包含://usr/lib/perl/site_perl/5.22.1 //usr/lib/perl/vendor_perl/5.22.1 //usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/site_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/site_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/vendor_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/vendor_perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy/sysroots/x86_64-arago-linux/usr/lib/perl/5.22.1。) 请访问/lib/build_OID_registry 第14行。
开始失败--在./lib/build_OID_registry 行14处中止编译。
lib/Makefile:220:目标'lib/OID_registry_data.c'的配方失败
maked[1]:***[lib/OID_registry_data.c]错误2.
Makefile:991:目标'lib'的配方失败
make:***[lib]错误2.
制作:***等待未完成的作业...
 CC     fs/proc/version.o
 LD     驱动程序/GPU/VGA/Built-in.o
 CC     驱动程序/GPU/DRM/DRM_PROBLE_helper.o
 CC     fs/proc/softirqs.o
 CC     net/core/secure_seq.o
 CC     net/core/flow_dissector.o
 CC     fs/proc/namespace.o
 CC     fs/proc/self.o
 CC     驱动程序/GPU/DRM/DRM_plane_helper.o
 抄送     net/dns_resoler/dns_key.o
 CC     fs/proc/thread_self.o
 CC     fs/proc/proc_sysctl.o
 CC     net/dns_resoler/dns_query.o
 CC     驱动程序/GPU/DRM/DRM_DP_mst_topology.o
 CC     net/core/sysctl_net_core.o
 LD     net/DNS_旋 变传感器/DNS_旋 变传感器
 LD     net/dns_resoler/built-in.o
 CC     net/core/dev.o
 LD     FS/quote/built-in.o
 CC     驱动程序/GPU/DRM/DRM_原子弹 辅助驱动程序.o
 CC     fs/proc/proc_net.o
 CC     fs/proc/kmsg.o
 CC     fs/proc/page.o
 LD     NET/DSA/Built-in.o
 抄送[M] 净/每日生活津贴/DSA.o
 LD     fs/proc/proc.o
 LD     fs/proc/built-in.o
 CC     FS/ramfs/inode.o
 CC     驱动程序/GPU/DRM/DRM_kms_helper_common.o
 CC     FS/ramfs/file-MM4.o
 CC     驱动程序/GPU/DRM/DRM_DP_DUAL_MODE_helper.o
 LD     Fs/ramfs/ramfs.o
 LD     FS/ramfs/built-in.o
 CC     fs/squarasfs/block.o
 CC [M] NET/DSA/从属.o
 CC     fs/squashfs/cache.o
 CC     驱动程序/GPU/DRM/DRM_simple_kms_helper.o
 CC     FS/squashfs/dir.o
 抄送[M] 净/每日生活津贴/DSa2.o
 CC     FS/squashfs/export.o
 CC     驱动程序/GPU/DRM/DRM_modeset_helper.o
 CC     net/core/ethtool.o
 CC     fs/squashfs/file.o
 LD [M] NET/DSA/DSA_CORE.o
 CC     fs/squashfs/fraging.o
 CC     驱动程序/GPU/DRM/DRM_fb_helper.o
 CC     驱动程序/GPU/DRM/DRM_fb_CMA_helper.o
 CC     FS/squarfs/id.o
 CC     FS/squashfs/inode.o
 抄送     FS/squashfs/namee.o
 CC     FS/squashfs/super.o
 CC     net/core/dev_addr_lists.o
 CC     FS/squashfs/symlink.o
 CC     FS/squashfs/decompressor.o
 CC     驱动程序/hid/hid-core.o
 CC     驱动程序/GPU/DRM/DRM_auth.o
 CC     fs/squashfs/file_cache.o
 CC     net/core/dst.o
 CC     FS/squashfs/decompressor_single.o
 CC     驱动程序/GPU/DRM/DRM_bufs.o
 CC     fs/squashfs/lzo_wraper.o
 CC     驱动器/hid/hid-input.o
 CC     fs/squashfs/xz_wraper.o
 CC     net/core/netevent.o
 CC     fs/squashfs/zlib_wraper.o
 CC     驱动程序/GPU/DRM/DRM_Cache.o
 CC     net/core/neighber.o
 LD     fs/squashfs/squashfs.o
 LD     fs/squashfs/built-in.o
 CC     FS/sysfs/file.o
 CC     驱动程序/GPU/DRM/DRM_context.o
 CC     FS/sysfs/dir.o
 CC     FS/sysfs/symlink.o
 CC     驱动程序/hid/hid-debug.o
 CC     驱动程序/GPU/DRM/DRM_DMA.o
 CC     FS/sysfs/mount.o
 CC     驱动程序/GPU/DRM/DRM_FOPS.o
 CC     FS/sysfs/group.o
 CC     驱动程序/hid/hid-generic.o
 LD     驱动程序/hid/usbhid/built-in.o
 cc [M] drivers/hid/usbhid/hid-core.o
 LD     FS/sysfs/built-in.o
 CC     FS/ubifs/shrinker.o
 CC     驱动程序/GPU/DRM/DRM_GER.o
 CC     net/core/rtnetlink.o
 抄送     FS/ubifs/journal.o
 CC [M] drivers/hid/usbhid/hid-quirks.o
 CC     驱动程序/GPU/DRM/DRM_ioctl.o
 抄送     fs/ubifs/file.o
 LD [M] drivers/hid/usbhid/usbhid.o
 LD     驱动程序/hid/hid.o
 LD     驱动程序/hid/built-in.o
 CC     FS/ubifs/dir.o
 CC     驱动程序/GPU/DRM/DRM_IRQ.o
 CC     驱动程序/GPU/DRM/DRM_LOCK.o
 CC     FS/ubifs/super.o
 CC     net/core/utils.o
 cc     fs/ubifs/sb.o
 CC     驱动程序/GPU/DRM/DRM_MEMORe.o
 CC     驱动程序/hwmon/hwmon.o
 CC     FS/ubifs/io.o
 CC     驱动程序/GPU/DRM/DRM_drv.o
 CC     net/core/link_watch.o
 CC     驱动程序/hwmon/GPIO-fan.o
 CC     FS/ubifs/TNC
 CC     驱动程序/hwmon/IIO_hwmon.o
 CC     驱动程序/GPU/DRM/DRM_VM.o
 CC     net/core/filter.o
 CC     驱动程序/hwmon/lm90.o
 CC     驱动程序/GPU/DRM/DRM_散 射
 CC     驱动程序/hwmon/lm95245.o
 CC     驱动程序/hwmon/tmp102.o
 CC     FS/ubifs/master.o
 CC     驱动程序/GPU/DRM/DRM_PCI.o
 cc [M] drivers/hwmon/ina2xx.o
 CC     FS/ubifs/scan.o
 CC     net/core/sock_diag.o
 CC [M] drivers/hwmon/NTC_thermisticer.o
 CC     驱动程序/GPU/DRM/DRM_Platform.o
 CC     FS/ubifs/replay.o
 cc [M] drivers/hwmon/wm-fan.o
 CC     驱动程序/GPU/DRM/DRM_sysfs.o
 LD     驱动程序/hwmon/built-in.o
 CC     FS/ubifs/log.o
 CC     net/core/dev_ioctl.o
 CC     NET/COM/TSo.o
 CC     驱动程序/GPU/DRM/DRM_HITAB.o
 CC     FS/ubifs/commit.o
 CC     FS/ubifs/gc.o
 CC     net/core/sock_reuseport.o
 CC     驱动程序/GPU/DRM/DRM_MM.o
 CC     net/ethernet/eth.o
 CC     FS/ubifs/孤立
 CC     net/core/flow.o
 LD     net/ethernet/built-in.o
 CC     驱动程序/GPU/DRM/DRM_CRTC.o
 CC     FS/eventpoly.o
 抄送     财务/预算/预算
 CC     net/core/net-sysfs.o
 CC     FS/ubifs/find.o
 CC     FS/ubifs/TNC _承诺
 CC     驱动程序/GPU/DRM/DRM_fourcc.o
 CC     驱动程序/GPU/DRM/DRM_MODEs.o
 CC     FS/ubifs/compress.o
 CC     net/core/net-procfg.o
 CC     FS/ubifs/LPT.o
 CC     fs/ubifs/lprops.o
 CC     net/core/fib_rules.o
 CC     驱动程序/GPU/DRM/DRM_EDID.o
 CC     驱动程序/GPU/DRM/DRM_INFo.o
 CC     FS/ubifs/recovery.o
 CC     驱动器/hwspinlock/hwspinlock_core.o
 CC     net/core/ptp 分类器.o
 CC     fs/ubifs/ioctl.o
 CC     驱动程序/hwspinlock/OMA_hwspinlock.o
 CC     FS/ubifs/LPT_COMMIT.o
 CC     驱动程序/GPU/DRM/DRM_debugfs.o
 LD     驱动程序/hwspinlock/built-in.o
 CC     net/core/dst_cache.o
 CC     驱动程序/GPU/DRM/DRM_ENCODER_SLAVE.o
 CC     FS/ubifs/TNC_MISC.o
 LD     net/core/built-in.o
 CC     驱动程序/GPU/DRM/DRM_TRACE_POINS.o
 CC     net/HSR-prp/HSR_prp_main.o
 CC     net/IPv4/route.o
 CC     FS/ubifs/xattr.o
 CC     驱动程序/GPU/DRM/DRM_GLOBAL
 CC     net/HSR-prp/HSR_main.o
 CC     驱动程序/GPU/DRM/DRM_prie.o
 CC     FS/ubifs/debug.o
 CC     net/HSR-prp/prp_main.o
 CC     驱动程序/GPU/DRM/DRM_rect.o
 CC     net/HSR-prp/HSR_prp_fraamereg.o
 CC     驱动程序/GPU/DRM/DRM_vMA_manager.o
 CC     net/IPv4/inetpeer.o
 抄送     FS/ubifs/misc.o
 CC     net/HSR-prp/HSR_prp_device.o
 CC     驱动程序/GPU/DRM/DRM_FLIP_work。o
 LD     Fs/ubifs/ubifs.o
 LD     Fs/ubifs/built-in.o
 CC     FS/anon_inodes.o
 CC     net/HSR-prp/HSR_netlink.o
 CC     FS/signalfd.o
 CC     net/IPv4/protocol.o
 CC     驱动程序/GPU/DRM/DRM_modeset_lock.o
 CC     fs/timerfd.o
 CC     net/HSR-prp/prp_netlink.o
 CC     net/IPv4/IP_input.o
 CC     驱动程序/GPU/DRM/DRM_RATOM.o
 CC     FS/eventfd.o
 CC     net/HSR-prp/HSR_prp_slave.o
 CC     net/IPv4/IP_frages.o
 CC     net/HSR-prp/HSR_prp_forward.o
 CC     FS/AIO
 CC     net/HSR-prp/HSR_prp_debugfs.o
 CC     驱动程序/GPU/DRM/DRM_BRIDE.o
 CC     驱动程序/GPU/DRM/DRM_framebuffer.o
 CC     net/IPv4/IP_forward.o
 LD     net/HSR-prp/HSR-prp.o
 LD     NET/HSR-PRP/Built-in.o
 CC     net/IPv4/IP_options.o
 CC     FS/locks.o
 CC     FS/binfmt_script.o
 CC     驱动程序/GPU/DRM/DRM_CONNECT.o
 CC     FS/binfmt_elf.o
 CC     net/IPv4/IP_output.o
 CC     驱动程序/GPU/DRM/DRM_bling.o
 LD     驱动程序/hwtracing/intel_th/built-in.o
 CC     net/ipv6/af_inet6.o
 CC     FS/mbcache.o
 CC     驱动程序/GPU/DRM/DRM_ENCODER.o
 CC     FS/POSIX_ACL.o
 CC     net/IPv4/IP_sockvel.o
 CC     驱动程序/GPU/DRM/DRM_MODE_OBJECT.o
 CC     Net/IPv6/anycast.o
 CC     FS/coredum.o
 CC     驱动程序/GPU/DRM/DRM_PROTON.o
 CC     net/IPv6/ip6_output.o
 CC     FS/DROP_Caches.o
 CC     net/IPv4/inet_hashtables.o
 CC     FS/fhandle.o
 CC     驱动程序/GPU/DRM/DRM_plane.o
 LD     FS/Built-in.o
 CC     驱动程序/GPU/DRM/DRM_COLOR_mgmt.o
 CC     net/IPv4/inet_timewait_sock.o
 CC     驱动程序/i2c/i2c-boardinfo.o
 CC     net/IPv6/ip6_input.o
 CC     驱动程序/GPU/DRM/DRM_GER_CMA_helper.o
 CC     驱动程序/i2c/i2c-core.o
 CC     net/IPv4/inet_connection_sock.o
 CC     驱动程序/GPU/DRM/ATI_pucigart.o
 CC     net/ipv6/addrconf.o
 CC     驱动程序/GPU/DRM/DRM_OL.o
 CC     驱动器/i2c/i2c-dev.o
 LD     驱动程序/GPU/DRM/BRIDE/BRIDE/Built-in.o
 LD     驱动程序/GPU/DRM/hisilics/built-in.o
 CC     Net/IPv4/TCP-o
 CC     驱动程序/GPU/DRM/i2c/tda998x_drv.o
 CC     驱动器/i2c/algos/i2c-algo-bit.o
 LD     驱动程序/i2c/algos/built-in.o
 CC     驱动器/i2c/Bus/i2c-omap.o
 LD     驱动程序/GPU/DRM/i2c/tda998x.o
 LD     驱动程序/GPU/DRM/i2c/built-in.o
 CC     驱动程序/GPU/DRM/omapdrm/Displays/encoder-tpd12s015.o
 CC [M] drivers/i2c/bes/i2c-emev2.o
 CC     驱动程序/GPU/DRM/omapdrm/Displays/encoder-tc358768.o
 LD     驱动器/i2c/bcs/built-in.o
 LD     驱动程序/i2c/muxs/built-in.o
 CC     驱动器/i2c/i2c-slave-EEPROM.o
 LD     驱动程序/i2c/built-in.o
 LD     驱动程序/GPU/DRM/panel/built-in.o
 LD     net/key/built-in.o
 抄送[M] net/key/af_key.o
 CC     驱动程序/GPU/DRM/omapdrm/Displays/dra7-EVM-encoder-tpd12s015.o
 CC     net/ipv6/addrlabel.o
 CC     net/IPv4/tcp_input.o
 CC     驱动程序/GPU/DRM/omapdrm/Displays/encoder-si9022-video.o
 CC     net/ipv6/route.o
 CC     驱动程序/GPU/DRM/omapdrm/Displays/encoder-si9022-audio.o
 CC     驱动程序/GPU/DRM/omapdrm/Displays/connector-HDMI.o
 CC     驱动程序/GPU/DRM/omapdrm/Displays/panel-dpi.o
 LD     驱动程序/GPU/DRM/omapdrm/Displays/encoder-sii9022.o
 CC     驱动程序/GPU/DRM/tilcdc/tilcdc_slave_compat.o
 LD     驱动程序/GPU/DRM/omapdrm/Displays/built-in.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/omapdss-boot-init.o
 DTC    驱动程序/GPU/DRM/tilcdc/tilcdc_slave_compat.dtb
 CC     驱动器/GPU/DRM/tilcdc/tilcdc_plane.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/base.o
 CC     驱动程序/GPU/DRM/tilcdc/tilcdc_crtc.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/display.o
 CC     net/IPv6/ip6_fib.o
 CC     net/IPv4/tcp_output.o
 CC     驱动程序/GPU/DRM/tilcdc/tilcdc_tfp410.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/DSS-of
 CC     驱动程序/GPU/DRM/tilcdc/tilcdc_panel.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/output.o
 CC     Net/IPv6/IPv6_sockvel.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/core.o
 CC     驱动程序/GPU/DRM/tilcdc/tilcdc_external.o
 CC     驱动程序/GPU/DRM/tilcdc/tilcdc_drv.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/dss.o
 CC     net/IPv4/tcp_timer.o
 dTB    驱动程序/GPU/DRM/tilcdc/tilcdc_slave_compat.dtb.S
 LD     驱动程序/GPU/DRM/tilcdc/tilcdc.o
 驱动     程序/GPU/DRM/tilcdc/tilcdc_slave_compat.dtb.o
 LD     驱动程序/GPU/DRM/tilcdc/built-in.o
rm 驱动程序/GPU/DRM/tilcdc/tilcdc_slave_compat.dtb 驱动程序/GPU/drm/tilcdc/tilcdc_slave_compat.dtb.S
 CC     net/IPv4/tcp_IPv4.o
 CC     net/ipv6/ndis.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/DSS_feature.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/dispc.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/dispc_cefs.o
 CC     net/IPv6/udp.o
 CC     net/IPv4/tcp_minisocks.o
 LD     驱动程序/idle/built-in.o
 CC     驱动程序/GPU/DRM/omapdrm/omapdrm/omap_drv.o
 CC     net/IPv4/tcp_Cong.o
 CC     Net/IPv6/udplite.o
 CC     驱动程序/GPU/DRM/omapdrm/OMA_IRQ.o
 CC     net/ipv6/ray.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/PLL.o
 CC     net/IPv4/tcp_metrics.o
 CC     驱动程序/IIO/industriali-core.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/video-pll.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/dpi.o
 CC     Net/IPv6/icmp.o
 CC     驱动程序/IIO/industrialio-event.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/HDMI_common.o
 CC     net/IPv4/tcp_fastopen.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/HDMI_WP.o
 CC     驱动器/IIO/inkern.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/HDMI_PLL.o
 CC     net/IPv4/tcp_rate
 CC     驱动程序/GPU/DRM/omapdrm/dss/HDMI_phy.o
 CC     net/ipv6/mcast.o
 CC     驱动程序/IIO/industrialio-buffer.o
 CC     net/IPv4/tcp_recovery.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/hdm4.o
 CC     驱动程序/IIO/industrialio-trigger.o
 CC     net/IPv4/tcp_offload.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/hdmi4_core.o
 LD     驱动程序/IIO/accel/built-in.o
 LD     驱动程序/IIO/ADC/Built-in.o
 CC [M] drivers/IIO/ADC/ti_AM335x_ADC.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/hdm5.o
 CC     net/IPv4/dat报.o
 CC     Net/IPv6/re组装。o
 CC [M] drivers/IIO/ADC/vf610_ADC.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/hdmi5_core.o
 LD     驱动器/IIO/amplifiers/built-in.o
 CC     驱动器/IIO/buffer/industrialio 触发缓冲器.o
 CC     net/IPv4/ray.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/DSS6.o
 CC     驱动器/IIO/buffer/kfifo_buf.o
 CC     net/IPv6/tcp_ipv6
 CC     驱动程序/GPU/DRM/omapdrm/dss/dispc6.o
 LD     驱动程序/IIO/buffer/built-in.o
 LD     驱动器/IIO/Chemal/Built-in.o
 LD     驱动程序/IIO/common/hid-ensors/built-in.o
 LD     驱动程序/IIO/common/ms_sensors/built-in.o
 LD     驱动程序/IIO/common/SSP_sensors/built-in.o
 LD     驱动程序/IIO/common/st_sensors/built-in.o
 LD     驱动程序/IIO/common/built-in.o
 LD     驱动程序/IIO/DAC/Built-in.o
 LD     驱动程序/IIO/dummy/built-in.o
 LD     驱动程序/IIO/frequency /内置 o
 LD     驱动程序/IIO/gyro/built-in.o
 LD     驱动程序/IIO/health/built-in.o
 LD     驱动器/IIO/Humid/Built-in.o
 LD     驱动程序/IIO/IMU/bmi160/Built-in.o
 LD     驱动程序/IIO/IMU/INV_mpu6050/built-in.o
 LD     驱动程序/IIO/IMU/Built-in.o
 LD     驱动程序/IIO/light/built-in.o
 CC [M] 驱动器/IIO/light/cm36651.o
 CC     net/IPv4/UDP.o
 CC     驱动程序/GPU/DRM/omapdrm/dss/dpi6.o
 CC     驱动器/IIO/magnetometer/ak8975.o
 LD     驱动程序/GPU/DRM/omapdrm/dss/omapdss-base.o
 LD     驱动程序/GPU/DRM/omapdrm/dss/omapdss.o
 LD     驱动程序/GPU/DRM/omapdrm/dss/omapds6.o
 LD     驱动程序/GPU/DRM/omapdrm/dss/built-in.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_debugfs.o
 CC     net/ipv6/ping.o
 LD     驱动程序/IIO/magnetometer/built-in.o
 LD     驱动程序/IIO/orientation/built-in.o
 LD     驱动器/IIO/电位器/内置
 LD     驱动器/IIO/PRESER/Built-in.o
 LD     驱动器/IIO/Proximity /内置 o
 LD     驱动程序/IIO/temperature /built-in.o
 LD     驱动程序/IIO/TRIGGER/Built-in.o
 LD     驱动程序/IIO/industrialio.o
 LD     驱动程序/IIO/built-in.o
 CC     net/IPv4/udplite.o
 CC     驱动程序/GPU/DRM/omapdrm/OMA_CRTC.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_plan.o
 CC     net/ipv6/exthdrs.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_encoder.o
 CC     net/IPv4/UDP_Offload.o
 CC     net/IPv4/arp.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_connector.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_fb.o
 CC     Net/IPv6/dat报.o
 CC     驱动器/输入/输入
 CC     驱动程序/GPU/DRM/omapdrm/omap_gem.o
 CC     net/IPv4/icmp.o
 CC     net/IPv6/ip6_flowlabel.o
 CC     驱动器/输入/输入- COMPat.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_gem_dmabuf.o
 CC     驱动器/输入/输入- mt.o
 CC     net/IPv4/devinet.o
 CC     驱动程序/GPU/DRM/omapdrm/OMA_DMM_tiler.o
 CC     驱动器/输入/关断内核
 CC     net/ipv6/inet6_connection_sock.o
 CC     驱动器/输入/输入- LED。o
 CC     驱动器/GPU/DRM/omapdrm/TCM-SITA.o
 CC     驱动器/输入/mousedev.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_fbdev.o
 CC     net/IPv6/UDP_Offload.o
 CC     net/IPv4/af_inet.o
 CC     驱动程序/GPU/DRM/omapdrm/omap_wb.o
 CC     驱动器/输入/操纵杆开发
 CC     net/ipv6/sysctl_net_ipv6.o
 CC     驱动程序/GPU/DRM/omapdrm/OMAP-WW_CAP.o
 CC     驱动器/输入/evdev.o
 CC     net/IPv6/xfrm6_policy.o
 CC     驱动程序/GPU/DRM/omapdrm/OMAP-WW_M2M.o
 CC     Net/IPv4/igmp.o
 CC     net/IPv6/xfrm6_state.o
 CC     驱动程序/输入/键盘/atkbd.o
 LD     驱动程序/GPU/DRM/omapdrm/omapdrm.o
 LD     驱动程序/GPU/DRM/omapdrm/built-in.o
 LD     驱动程序/GPU/DRM/DRM_kms_helper.o
 LD     驱动程序/GPU/DRM/DRM.o
 LD     驱动程序/GPU/DRM/built-in.o
 LD     驱动程序/GPU/Built-in.o
 CC     驱动器/输入/键盘/GPIO_keys.o
 CC     net/ipv6/xfrm6_input.o
 LD     NET/LLC/Built-in.o
 CC [M] NET/LLC/LLC_CORE.o
 CC [M] 驱动器/输入/键盘/matrial_keyboard.o
 CC [M] NET/LLC/LLC_INPUT.o
 CC [M] 驱动器/输入/键盘/qt1070.o
 抄送[M] 驱动程序/输入/键盘/Samsung 键盘
 CC     net/ipv6/xfrm6_output.o
 CC     net/IPv4/fib_前端
 CC [M] NET/LLC/LLC_OUTPUS.o
 LD     驱动程序/输入/键盘/内置.o
 CC     驱动器/输入/MISC/mpu3050.o
 CC [M] 驱动器/输入/MISC/adxl34x.o
 CC     net/IPv6/xfrm6_protocol.o
 LD [M] Net/LLC/LLC.o
 CC     net/ipv6/netfilter.o
 CC     net/IPv4/fib_semipario.o
 CC [M] 驱动器/输入/MISC/adxl34x-i2c.o
 CC [M] 驱动器/输入/MISC/adxl34x-SPI.o
 CC     net/ipv6/fib6_rules.o
 CC     net/IPv4/fib_trie.o
 CC [M] 驱动器/输入/MISC/GPIO_DECOer.o
 CC     net/ipv6/proc.o
 CC [M] 驱动器/输入/MISC/axp20x-PEK/o
 CC     net/IPv4/inet_frage.o
 LD     驱动程序/输入/MISC/built-in.o
 CC     驱动器/输入/鼠标/Elan_i2c_core.o
 CC     net/ipv6/xfrm6_mode_transport。o
 CC     驱动器/输入/鼠标/Elan_i2c_i2c.o
 CC     net/IPv6/xfrm6_mode_tun通道
 CC     net/ipv6/xfrm6_mode_beet.o
 CC     net/IPv4/ping.o
 CC     驱动器/输入/鼠标/鼠标悬停-基座。o
 CC     net/IPv4/IP_Tunna_core.o
 LD     net/ipv6/netfilter/built-in.o
 CC     net/ipv6/sit
 CC     驱动器/输入/鼠标/合成器
 CC     net/ipv6/addrconf_core.o
 CC     Net/IPv4/GRE 卸载
 CC     驱动器/输入/鼠标/ focaltech.o
 CC     net/IPv4/IP_tunnel.o
 CC     驱动器/输入/鼠标/alps.o
 CC     net/ipv6/exthdrs_core.o
 CC     驱动器/输入/鼠标/BYD.o
 LD     net/mac80211/built-in.o
 CC [M] net/mac80211-main.o
 CC     驱动器/输入/鼠标/elantech.o
 CC     net/IPv6/ip6_CHECKSUR.o
 CC     net/IPv4/sysctl_net_ipv1.o
 CC [M] net/mac80211/status.o
 CC     驱动器/输入/鼠标/ logips2pp.o
 CC     net/IPv6/ip6_icmp.o
 CC     net/ipv4/proc.o
 CC     驱动程序/输入/鼠标/触控点。o
 CC     驱动器/输入/鼠标/ Cypress_PS2.o
 CC     net/ipv6/output_core.o
 CC     net/IPv4/隧道4.o
 抄送[M] 驱动程序/输入/鼠标/Cyapa.o
 CC [M] net/mac80211/driver-ops.o
 CC     net/ipv6/protocol.o
 CC [M] 驱动器/输入/鼠标/Cyapa_Gen3.o
 CC     net/IPv4/ipconfig.o
 CC [M] net/mac80211/sa_info.o
 CC [M] 驱动器/输入/鼠标/Cyapa_gen5.o
 CC     net/IPv6/ip6_offload.o
 CC     net/IPv4/netfilter.o
 CC [M] 驱动器/输入/鼠标/Cyapa_Gen6.o
 CC     net/ipv6/tcpv6_offload.o
 LD     驱动程序/输入/鼠标/Elan_i2c.o
 LD     驱动程序/输入/鼠标/鼠标
 LD [M] 驱动器/输入/鼠标/细胞 apatp.o
 LD     驱动程序/输入/鼠标/内置.o
 CC     驱动器/输入/触摸屏/of _touchone.o
 CC [M] net/mac80211/WEP.o
 CC     net/ipv6/exthdrs_offload.o
 CC [M] 驱动器/输入/触摸屏/Atmel_mxt_ts.o
 LD     net/IPv4/netfilter/built-in.o
 CC [M] net/IPv4/netfilter/NF_conntrack_l3proTO_IPv4.o
 CC     net/ipv6/inet6_hashtables.o
 CC [M] net/mac80211-WPA.o
 CC [M] NET/IPv4/netfilter/NF_conntrack_proTO_icmp.o
 CC [M] 驱动器/输入/触摸屏/EDT-ft5x06.o
 CC     net/ipv6/mcast_snoop.o
 抄送[M] 驱动程序/输入/触摸屏/goodix.o
 CC [M] net/IPv4/netfilter/NF_NAT_l3proTO_IPv4.o
 CC [M] net/mac80211/scan.o
 CC [M] 驱动器/输入/触摸屏/mms114.o
 抄送[M] Net/IPv6/ah6.o
 CC [M] 驱动器/输入/触摸屏/PIXcir_i2c_ts.o
 CC [M] net/IPv4/netfilter/NF_NAT_PROTO_icmp.o
 CC [M] 驱动器/输入/触摸屏/st1232.o
 CC [M] net/mac80211/offchannel.o
 抄送[M] Net/IPv6/esp6.o
 CC [M] net/IPv4/netfilter/NF_desfrag_IPv4.o
 CC [M] 驱动器/输入/触摸屏/ti_AM335x_TSC.o
 LD     驱动程序/输入/触摸屏/内置.o
 CC [M] 驱动器/输入/输入- polldev.o
 CC [M] Net/IPv6/ipcomp6.o
 CC [M] 驱动器/输入/矩阵-keymap.o
 CC [M] net/IPv4/netfilter/NF_NAT_masquerad_IPv4.o
 CC [M] net/IPv6/xfrm6_tun通道
 LD     驱动器/输入/输入-内核.o
 LD     驱动器/输入/内置
 CC     驱动器/输入/串行器/串行器
 CC [M] net/mac80211/ht.o
 抄送[M] net/IPv4/netfilter/IP_tables.o
 CC     驱动器/输入/串行器/串行端口
 CC [M] Net/IPv6/t隧道6.o
 CC     驱动器/输入/serio/libps2.o
 CC [M] net/mac80211/AGG-TX.o
 LD     驱动器/输入/serio/built-in.o
 CC     驱动器/iommu/iommu.o
 CC [M] Net/IPv6/mip6.o
 CC [M] net/IPv4/netfilter/iptable_filter.o
 CC [M] Net/IPv6/ip6_tun通道
 CC     驱动器/iommu/iommu-Traces.o
 CC [M] net/mac80211/AGG-Rx.o
 CC [M] net/IPv4/netfilter/iptable_NAT.o
 CC     驱动程序/iommu/iommu-sysfs.o
 CC     驱动器/iommu/of _iommu.o
 CC [M] net/mac80211/VHT.o
 CC [M] net/IPv4/netfilter/IPT_masquerad.o
 LD     net/IPv6/IPv6.o
 LD     net/ipv6/built-in.o
 CC [M] net/mac80211/IBSS.o
 CC     驱动器/iommu/OMAP-iommu.o
 CC [M] net/IPv4/netfilter/arp_tables.o
 抄送[M] net/IPv4/netfilter/Arpt_mange.o
 CC     驱动程序/iommu/OMAP-iommu-debug.o
 CC [M] net/mac80211/iface.o
 CC     驱动器/irqchip/irqchip.o
 LD     驱动程序/iommu/built-in.o
 CC     驱动程序/irqchip/IRQ-OMAP-INTC.o
 CC [M] net/IPv4/netfilter/arptable_filter.o
 抄送[M] net/mac80211/速率.o
 LD     驱动程序/irqchip/built-in.o
 CC     驱动器/LED/LED-CORE。o
 LD [M] net/IPv4/netfilter/NF_conntrack_IPv4.o
 LD [M] net/IPv4/netfilter/NF_NAT_IPv4.o
 CC     net/IPv4/inet_diag.o
 CC     驱动器/LED/LED-CLASS.o
 CC     驱动器/LED/LED-TRIGERS.o
 CC     net/netfilter/core.o
 抄送[M] net/mac80211/Michael.o
 CC     驱动器/LED/LED-GPIO.o
 CC     net/IPv4/tcp_diag.o
 抄送[M] Net/mac80211/TKIP.o
 CC     驱动器/LED/LED-tlc591xx.o
 CC     net/netfilter/nf_log.o
 CC     驱动器/LED/LED-PWM.o
 CC     net/IPv4/tcp_立方
 CC     驱动器/LED/触发器/ledtrigg-timer.o
 CC [M] net/mac80211/AES_CCM.o
 CC     驱动器/LED/触发器/ledtrig-OneShot.o
 CC     net/IPv4/xfrm4_policy.o
 CC     net/netfilter/nf_queue.o
 CC     驱动器/LED/触发器/ledtrig-heartbeat.o
 CC     驱动器/LED/触发器/ledtrig-backlight.o
 CC [M] net/mac80211/AES_GCM.o
 CC     net/IPv4/xfrm4_state.o
 CC     驱动器/LED/触发器/ledtrig-gpio.o
 CC     net/netfilter/nf_sockopt.o
 CC [M] net/mac80211/AES_CMAC.o
 CC     驱动器/LED/触发器/ledtrig-cpu.o
 CC     net/IPv4/xfrm4_input.o
 CC     驱动器/LED/触发器/ledtrig-default-on.o
 CC [M] net/mac80211/AES_GMAC.o
 CC     驱动器/LED/触发器/ledtrig-transient。o
 CC [M] net/netfilter/nf_conntrack_core.o
 CC     驱动器/LED/触发器/ledtrig-camera.o
 CC     net/IPv4/xfrm4_output.o
 CC [M] net/mac80211/cfg.o
 LD     驱动器/LED/TRIGGER/Built-in.o
 CC [M] 驱动器/LEDS/LED-CLASS-FLASH.o
 LD     驱动器/LEDS/Built-in.o
 LD     驱动程序/lguest/built-in.o
 LD     驱动程序/Macintosh/Built-in.o
 CC     驱动程序/邮箱/邮箱。o
 CC     net/IPv4/xfrm4_protocol.o
 CC     驱动程序/邮箱/OMAP-mailbox.o
 CC [M] net/netfilter/NF_conntrack_standalone。o
 抄送[M] Net/IPv4/AH4.o
 CC [M] net/mac80211/ethtool.o
 LD     驱动程序/邮箱/内置.o
 CC     驱动程序/介质/CC-EDID.o
 CC [M] net/netfilter/NF_conntrack_al預 期.o
 LD     驱动程序/媒体/公共/b2c2/built-in.o
 LD     驱动程序/介质/公用/ saa7146/built-in.o
 LD     驱动程序/媒体/公共/西亚诺/内置
 LD     驱动程序/媒体/公共/v4l2-TPG/built-in.o
 CC [M] 驱动程序/媒体/公共/v4l2-TPG/v4l2-TPG-core.o
 抄送[M] Net/IPv4/esp4.o
 CC [M] net/mac80211-Rx.o
 CC [M] net/netfilter/NF_conntrack_helper.o
 抄送[M] Net/IPv4/ipcomp.o
 CC [M] 驱动程序/媒体/公共/v4l2-TPG/v4l2-TPG-colors.o
 LD [M] 驱动程序/媒体/公共/v4l2-TPG/v4l2-TPG.o
 LD     驱动程序/媒体/公共/内置.o
 LD     驱动程序/媒体/防火墙/内置
 LD     驱动程序/媒体/i2c/soc_camera/built-in.o
 cc [M] drivers/media/i2c/adv7180.o
 CC [M] net/IPv4/xfrm4_tun通道
 cc [M] drivers/media/i2c/ov1063x.o
 CC [M] net/netfilter/nf_conntrack_proto
 CC [M] net/IPv4/xfrm4_mode_beet.o
 cc [M] drivers/media/i2c/ov490.o
 抄送[M] net/mac80211/sesgmgmt.o
 CC [M] net/IPv4/xfrm4_mode_transport
 cc [M] drivers/media/i2c/mt9t11x.o
 CC [M] net/netfilter/nf_conntrack_l3proto _generic.o
 CC [M] net/mac80211/TX.o
 CC [M] net/IPv4/xfrm4_mode_tun通道
 cc [M] drivers/media/i2c/ml86v7667.o
 CC [M] net/netfilter/nf_conntrack_proto _generic.o
 cc [M] drivers/media/i2c/ov2659.o
 LD     net/IPv4/Built-in.o
 LD     驱动程序/media/MMC/siano/built-in.o
 LD     驱动程序/media/MMC/built-in.o
 LD     驱动程序/media/i2c/built-in.o
 CC     驱动程序/存储器/OMAP-GPMC.o
 CC [M] net/netfilter/nf_conntrack_proto _tcp.o
 LD     驱动程序/介质/pci/b2c2/built-in.o
 LD     驱动程序/介质/pci/ddbridge/built-in.o
 LD     驱动程序/介质/pci/dm1105/built-in.o
 LD     驱动程序/介质/pci/mantis/built-in.o
 LD     驱动程序/介质/pci/netup_unidvb/built-in.o
 LD     驱动程序/介质/pci/ngene/built-in.o
 LD     驱动程序/介质/pci/pluto2/built-in.o
 LD     驱动程序/介质/pci/pt1/built-in.o
 LD     驱动程序/介质/PCI/PT3/Built-in.o
 LD     驱动程序/介质/pci/saa7146/built-in.o
 LD     驱动程序/介质/pci/smipcie/built-in.o
 LD     驱动程序/media/pci/ttpci/built-in.o
 LD     驱动程序/介质/PCI/内置.o
 LD     驱动程序/媒体/平台/OMAP/Built-in.o
 LD     驱动程序/媒体/平台/SoC_camera/built-in.o
 CC [M] 驱动程序/媒体/平台/SoC_camera/SoC_camera.o
 CC [M] 驱动程序/存储器/ti-EMIF-Pm.o
 CC [M] net/netfilter/nf_conntrack_proTO_udp.o
 作为[M] 驱动程序/存储器/ti-EMIF-SRAM-PM.o
 LD     驱动程序/存储器/内置.o
 LD [M] 驱动程序/存储器/ti-EMIF-SRAM.o
 CC [M] net/netfilter/NF_conntrack_extend.o
 CC [M] net/mac80211/ key.o
 CC [M] 驱动程序/媒体/平台/SoC_camera/SoC_mediabs.o
 CC [M] 驱动程序/媒体/平台/SoC_camera/SoC_camera_platform.o
 CC     驱动器/MFD/act8945a.o
 CC [M] net/netfilter/nf_conntrack_acct.o
 CC     驱动器/MFD/lp873x.o
 LD     驱动程序/媒体/平台/ti-VPE/built-in.o
 LD     驱动程序/介质/平台/vIVE/Built-in.o
 CC [M] 驱动程序/媒体/平台/生动/生动的内核.o
 CC     驱动器/MFD/lp87565.o
 CC [M] net/mac80211/util.o
 CC     驱动器/MFD/tps65217.o
 CC [M] net/netfilter/nf_conntrack_seqadj.o
 CC [M] 驱动程序/介质/平台/Vivid / Vivid -CtrlS.o
 CC     驱动器/MFD/tps65218.o
 CC [M] net/netfilter/NF_conntrack_proTO_SCTP.o
 CC     驱动器/MFD/tps65910.o
 CC [M] 驱动程序/媒体/平台/生动/生动-生动-通用.o
 CC     驱动器/MFD/twl6040.o
 CC [M] net/netfilter/NF_NAT_CORE.o
 CC [M] 驱动程序/媒体/平台/生动/生动的 VBI-gen.o
 CC [M] net/mac80211/WME.o
 CC     驱动器/MFD/MFD-COM.o
 CC [M] 驱动程序/媒体/平台/生动/生动的 vid-cap
 CC [M] net/mac80211/cha.o
 CC     驱动器/MFD/tps6586x.o
 CC     驱动程序/MFD/OMAP-USB-HOST.o
 CC [M] net/netfilter/NF_NAT_PROTO_UNKNON.o
 CC [M] 驱动程序/媒体/平台/生动/生动的 vid-out.o
 CC     驱动程序/MFD/OMAP-USB-tl.o
 CC [M] net/netfilter/NF_NAT_PROTO_common.o
 CC     驱动器/MFD/tps65090.o
 CC [M] net/mac80211/trace.o
 CC     驱动器/MFD/PALMAS
 CC [M] 驱动程序/媒体/平台/生动/生动的 kthread-cap.o
 CC [M] net/netfilter/NF_NAT_PROTO_UDP.o
 CC [M] net/mac80211/mlme.o
 CC     驱动器/MFD/SYSCON.o
 CC [M] DRIVERS/MFD/ti_AM335x_tscadc.o
 CC [M] 驱动程序/媒体/平台/vIVIE/vikthread-out.o
 CC [M] net/netfilter/NF_NAT_PROTO_tcp.o
 CC [M] 驱动器/MFD/axp20x.o
 CC [M] 驱动器/媒体/平台/生动/生动的无线电接收器
 CC [M] net/netfilter/NF_NAT_helper.o
 CC [M] 驱动器/MFD/axp20x-i2c.o
 CC [M] 驱动程序/媒体/平台/生动/生动的无线电- TX.o
 LD     驱动程序/MFD/Built-in.o
 CC [M] 驱动程序/媒体/平台/生动/生动的无线电-公共.o
 LD     驱动程序/媒体/无线电广播/内置.o
 CC [M] net/mac80211/tdls.o
 CC [M] net/netfilter/NF_NAT_PROTO_SCTP.o
 CC [M] 驱动器/媒体/平台/生动/生动的 Rds-gen.o
 CC [M] 驱动程序/媒体/平台/生动/生动的 SDR-CAP.o
 CC [M] 驱动程序/媒体/平台/生动/生动的 VBI-CAP.o
 CC [M] net/netfilter/x_tables.o
 LD     驱动程序/媒体/RC/键位映射/内置
 LD     驱动程序/media/RC/内置.o
 CC [M] 驱动程序/媒体/平台/Vivid /Vivid-VBI-out.o
 CC [M] net/netfilter/XT_tcppm.o
 CC [M] 驱动程序/介质/平台/vIVE/vIVE-OSD.o
 CC [M] net/mac80211/ocb.o
 CC [M] net/mac80211/led.o
 CC [M] net/netfilter/XT_mark.o
 LD [M] 驱动程序/介质/平台/vIVE/vIVILE.o
 LD     驱动程序/介质/平台/内置
 LD     驱动程序/media/SPI/built-in.o
 LD     驱动程序/介质/调谐器/内置.o
 LD     驱动程序/media/USB/b2c2/built-in.o
 LD     驱动程序/介质/USB/DVB-USB/Built-in.o
 LD     驱动程序/媒体/USB/DVB-USB-v2/Built-in.o
 LD     驱动程序/介质/USB/gspca/built-in.o
 CC [M] 驱动程序/media/USB/gspca/gspca.o
 CC     驱动程序/media/v4l2-core/v4l2-dev.o
 CC [M] net/netfilter/XT_NAT.o
 CC [M] net/mac80211/pm.o
 CC [M] net/netfilter/XT_Class.o
 CC [M] drivers/media/USB/gspca/autogain_functions.o
 cc     drivers/media/v4l2-core/v4l2-ioctl.o
 CC [M] net/netfilter/XT_IDLETIME.o
 LD [M] 驱动程序/介质/USB/gspca/gspca_main.o
 LD     驱动程序/media/usb/s2255/built-in.o
 LD     驱动程序/介质/USB/siano/built-in.o
 LD     驱动程序/介质/USB/stkwebcam 内置
 cc [M] net/mac80211-rc80211_minstrel.o
 LD     驱动程序/介质/USB/ttusb-budget/built-in.o
 LD     驱动程序/介质/USB/ttusb-d解码/built-in.o
 LD     驱动程序/介质/USB/UVC/Built-in.o
 CC [M] 驱动程序/介质/USB/UVC/UVC_DRIVER.o
 CC [M] net/netfilter/XT_comment.o
 CC [M] net/netfilter/XT_CPU.o
 cc [M] net/mac80211-rc80211_minstrel_ht.o
 cc     drivers/media/v4l2-core/v4l2-device.o
 抄送[M] 驱动程序/介质/USB/UVC/UVC_queue.o
 CC [M] Net/netfilter/XT_IPRange.o
 CC [M] 驱动程序/介质/USB/UVC/UVC_v4l2.o
 CC     驱动程序/介质/v4l2-core/v4l2-fh.o
 CC [M] net/netfilter/XT_length.o
 LD [M] net/mac80211/mac80211.o
 CC [M] net/netfilter/XT_limit.o
 cc     drivers/media/v4l2-core/v4l2-event.o
 CC [M] 驱动程序/媒体/USB/UVC/UVC_VIDO.o
 CC [M] 驱动程序/介质/USB/UVC/UVC_CTRL.o
 cc     drivers/media/v4l2-core/v4l2-Ctrls.o
 CC [M] net/netfilter/XT_mac.o
 CC     驱动程序/media/v4l2-core/v4l2-subdev.o
 CC [M] net/netfilter/XT_multiport.o
 CC [M] 驱动程序/介质/USB/UVC/UVC_STATUS.o
 CC [M] 驱动程序/介质/USB/UVC/UVC_iSIGHT.o
 CC [M] net/netfilter/XT_pkttype.o
 CC     net/netlink/af_netlink.o
 CC [M] drivers/media/USB/UVC/UVC_debugfs.o
 cc     drivers/media/v4l2-core/v4l2-clk.o
 CC [M] 驱动程序/媒体/USB/UVC/UVC_ENTITY.o
 CC [M] net/netfilter/XT_policy.o
 LD [M] 驱动程序/介质/USB/UVC/uvcvideo.o
 CC     驱动程序/媒体/v4l2-core/v4l2-async.o
 LD     驱动程序/media/USB/zr364xx/built-in.o
 LD     驱动程序/介质/USB/Built-in.o
 CC     net/netlink/genetlink.o
 CC [M] net/netfilter/XT_SCTP.o
 CC     驱动程序/media/v4l2-core/v4l2-ov.o
 CC     驱动程序/media/v4l2-core/v4l2-mc.o
 CC     驱动程序/介质/介质设备。o
 LD     net/netfilter/netfilter.o
 LD [M] net/netfilter/nf_conntrack.o
 LD [M] net/netfilter/NF_NAT.o
 LD     net/netfilter/built-in.o
 CC     驱动程序/MISC/ad525x_dpot.o
 LD     net/netlink/built-in.o
 CC     net/packet/af_packet.o
 CC     驱动程序/media/v4l2-core/v4l2-common.o
 CC     驱动程序/MISC/ad525x_dpot-i2c.o
 CC     驱动程序/MISC/ics932s401.o
 CC     net/rfkill/core.o
 cc     drivers/media/v4l2-core/v4l2-dv-timings.o
 CC     驱动程序/MISC/apds9802als.o
 cc     drivers/media/v4l2-core/v4l2-mem2memme.o
 CC     驱动程序/MISC/IS29003.o
 CC     net/rfkill/input.o
 CC     net/rfkill/rfkill-gpio.o
 LD     驱动程序/MISC/cb710/built-in.o
 CC     驱动器/MISC/at24.o
 CC     驱动程序/media/v4l2-core/video/buf2-core.o
 ldnet/rfkill/rfkill.o
 LD     net/rfkill/built-in.o
 CC     驱动程序/media/v4l2-core/video/buf2-v4l2.o
 CC     驱动程序/MISC/EEPROM_93cx6.o
 LD     net/packet/built-in.o
 LD     net/rpmsg/built-in.o
 CC [M] net/rpmsg/rpmsg_proTO.o
 LD     驱动程序/MISC/EEPROM/Built-in.o
 LD     驱动程序/MISC/lis3lv02d/built-in.o
 LD     驱动程序/MISC/麦克风/总线/内置
 LD     驱动程序/MISC/Built-in.o
 LD     驱动程序/MISC/ti-st/built-in.o
 CC     驱动程序/MISC/SRAM.o
 CC [M] 驱动程序/MISC/PCI_Endpoint_test.o
 CC     net/sched/sch_generic.o
 CC     驱动程序/媒体/v4l2-core/video/buf2-memops.o
 CC     驱动程序/介质/介质-设备节点.o
 抄送     驱动程序/媒体/媒体实体
 CC     驱动程序/MMC/CARD/BLOCL.o
 CC     驱动程序/媒体/v4l2-core/video/buf2-dma-contg.o
 cc [M] drivers/media/v4l2-core/video/buf-core.o
 CC     net/sched/sch_mq.o
 cc [M] drivers/media/v4l2-core/video/buf2-vmalloc.o
 CC     net/sched/sch_api.o
 CC     net/sched/sch_blackhole.o
 CC     驱动程序/MMC/CARD/queue.o
 LD     驱动程序/media/v4l2-core/videodev.o
 LD     驱动程序/media/v4l2-core/built-in.o
 LD     驱动程序/媒体/媒体
 LD     驱动程序/介质/built-in.o
 CC     驱动程序/MMC/core/core.o
 CC     驱动程序/MMC/core/bus.o
 LD     驱动程序/MMC/CARD/MMC_BLOCL.o
 LD     驱动程序/MMC/CARD/Built-in.o
 CC     驱动程序/MMC/core/host.o
 LD     NET/SCTP/Built-in.o
 CC [M] NET/SCTP/SM_statetable.o
 CC     驱动程序/MMC/core/MMC.o
 CC [M] Net/SCTP/SM_statefuns.o
 CC     驱动程序/MMC/core/MMC_ops.o
 CC     net/sched/cls_api.o
 CC     net/sched/act_api.o
 CC     驱动程序/MMC/core/sd.o
 CC [M] NET/SCTP/SM_Sideeffect.o
 CC     驱动程序/MMC/core/sd_ops.o
 CC     net/sched/sch_fifo.o
 CC     驱动程序/MMC/COM/SDIO.o
 CC     驱动程序/MMC/CORE/SDIO_ops.o
 CC     Net/SUNPPC/Clnt.o
 CC [M] NET/SCTP/protocol.o
 CC     驱动程序/MMC/CORE/SDIO_BUS.o
 CC     net/sched/ematch.o
 CC     驱动程序/MMC/CORE/SDIO_CIS.o
 cc [M] Net/SCTP/endpointola.o
 抄送[M] net/sched/act_poly.o
 CC     驱动程序/MMC/CORE/SDIO_IO.o
 cc [M] net/sched/act_gact.o
 CC     Net/SUNPPC/XPRT.o
 CC [M] Net/SCTP/associola.o
 CC     驱动程序/MMC/CORE/SDIO_IRQ.o
 CC     驱动程序/MMC/core/quirks.o
 CC [M] net/sched/act_mirred.o
 CC     驱动程序/MMC/core/slot-gpio.o
 CC [M] NET/SCTP/transport
 CC     驱动程序/MMC/core/pwrseq.o
 CC     Net/SUNPc/socklib.o
 CC [M] net/sched/act_ipt.o
 CC     驱动程序/MMC/core/debugfs.o
 CC [M] Net/SCTP/Chunk.o
 CC [M] net/sched/act_NAT.o
 CC     驱动程序/MMC/core/pwrseq_simple.o
 CC     Net/SUNPPC/xprtsock.o
 CC     驱动程序/MMC/core/pwrseq_eMMC.o
 CC [M] Net/SCTP/SM_make_chunk.o
 LD     驱动程序/MMC/core/MMC_core.o
 LD     驱动程序/MMC/core/built-in.o
 CC     驱动程序/MMC/host/omap.o
 CC [M] net/sched/act_pedit.o
 CC     Net/SUNPPC/sched.o
 CC [M] net/sched/act_simple.o
 CC     驱动程序/MMC/host/omap_hmmc.o
 CC [M] net/sched/act_skbedit.o
 CC [M] NET/SCTP/ulpedve.o
 cc [M] net/sched/act_csum.o
 CC     NET/SUNPPC/auth.o
 CC [M] NET/SCTP/INQUEUE.o
 LD     驱动程序/MMC/host/built-in.o
 LD     驱动程序/MMC/Built-in.o
 CC     驱动器/MTD/mtdcore.o
 CC [M] NET/SCTP/outqueue.o
 cc [M] net/sched/sch_cbq.o
 CC     驱动器/MTD/mtdsuper.o
 CC     Net/SUNPPC/auth_null.o
 CC     驱动器/MTD/mtdconnat.o
 抄送[M] Net/SCTP/PLEGLET.o
 CC     net/SUNPPC/auth_UNIX.o
 CC [M] net/sched/sch_HTB.o
 CC     Net/SUNPPC/auth_generic.o
 CC [M] NET/SCTP/tsnmap.o
 CC     驱动器/MTD/mtdpart.o
 CC     NET/SUNPPC/Svc.o
 cc [M] net/sdtp/bind_addr.o
 cc [M] net/sched/sch_hfsc.o
 CC     驱动器/MTD/mtdchar.o
 CC [M] NET/SCTP/SOCKET.o
 CC     Net/SUNPPC/svcsock.o
 CC [M] net/sched/sch_red.o
 CC     驱动器/MTD/ofpart.o
 CC     驱动程序/MTD/cmdlinepart.o
 CC [M] net/sched/sch_gred.o
 CC     驱动器/MTD/MTD_blkdevs.o
 cc     net/sunpc/svcuth.o
 CC     驱动器/MTD/mtdblock。o
 CC     net/sUNPPC/svcuth_UNIX.o
 CC [M] net/sched/sch_inatione.o
 CC     驱动器/MTD/CHICS/chiPREG.o
 CC [M] net/sched/sch_dssmark.o
 LD     驱动程序/MTD/chips/built-in.o
 CC     驱动器/MTD/DEVICes/m25p80.o
 CC     Net/SUNPPC/addr.o
 LD     驱动程序/MTD/DEVICes/built-in.o
 LD     驱动程序/MTD/LPDDR/Built-in.o
 LD     驱动程序/MTD/MAPS/Built-in.o
 CC     驱动器/MTD/nand/nand_base.o
 CC [M] Net/SCTP/Primitive
 CC [M] net/sched/sch_sfb.o
 CC [M] NET/SCTP/OUTP.o
 CC     net/SUNPPC/rpcb_Clnt.o
 cc [M] net/sched/sch_sfq.o
 CC [M] NET/SCTP/INPUT.o
 CC     NET/SUNPPC/TIMER.o
 CC     驱动器/MTD/nand/nand_BBT.o
 cc [M] net/sched/sch_tbf.o
 CC     驱动器/MTD/nand/nand_timings.o
 CC     Net/SUNPPC/XDR.o
 CC [M] NET/SCTP/DEBUG.o
 抄送[M] net/sched/sch_teql.o
 CC     驱动器/MTD/nand/nand_ecc.o
 CC [M] NET/SCTP/ssnMAP.o
 CC     驱动器/MTD/nand/nand_ids.o
 CC [M] net/sched/sch_prio.o
 CC     Net/SUNPPC/SUNPPC_SYMS.o
 CC     驱动器/MTD/nand/Denali.o
 抄送[M] Net/SCTP/auth.o
 cc [M] net/sched/sch_multiq.o
 CC     NET/SUNPPC/cache.o
 CC [M] net/sched/sch_netem.o
 CC [M] NET/SCTP/Offload.o
 CC     驱动器/MTD/nand/Denali_dt.o
 CC     驱动器/MTD/nand/OMAP2.o
 CC [M] NET/SCTP/proc.o
 CC [M] net/sched/sch_DRR.o
 CC     Net/SUNPPC/RPC_PIPE.o
 CC     驱动程序/MTD/nand/omap_elm.o
 CC [M] NET/SCTP/SYSCTL.o
 CC [M] net/sched/sch_mqprio.o
 CC     驱动程序/MTD/nand/brcmnand/ipc_nand.o
 CC [M] Net/SCTP/IPv6.o
 CC     Net/SUNPPC/Svc_XPRT.o
 CC [M] net/sched/sching_c扼 流圈
 CC     驱动器/MTD/nand/brcmnand/bcm63138_nand.o
 CC     驱动器/MTD/nand/brcmnand/bcm6368_nand.o
 CC     驱动器/MTD/nand/brcmnand/brcmstb_nand.o
 CC [M] Net/SCTP/SCTP_diag.o
 cc [M] net/sched/sch_qfq.o
 CC     驱动器/MTD/nand/brcmnand/brcmnand.o
 LD [M] NET/SCTP/SCTP.o
 CC     net/SUNPPC/xprtmultipath.o
 CC     Net/SUNPPC/STATS.o
 cc [M] net/sched/sch_codel.o
 LD     驱动程序/MTD/nand/brcmnand/built-in.o
 LD     驱动程序/MTD/nand/nand.o
 LD     驱动程序/MTD/nand/OMAP2_nand.o
 LD     驱动程序/MTD/nand/built-in.o
 LD     驱动程序/MTD/onenand/built-in.o
 CC     驱动器/MTD/SPI-NOR/SPI-NOR.o
 CC     net/switchdev/switchdev.o
 CC [M] net/sched/sch_FQ_codel.o
 CC     NET/SUNPPC/SYSCTL.o
 CC     驱动器/MTD/SPI-NOR/cadence-quadspi.o
 LD     net/switchdev/built-in.o
 CC     Net/SUNPPC/auth_GS/auth_GSS.o
 Ld     Net/SUNPPC/SUNPC.o
 LD     驱动程序/MTD/tests/built-in.o
 CC [M] drivers/MTD/tests/oobtest.o
 CC [M] net/sched/cls_u32.o
 LD     驱动程序/MTD/SPI-NOR/Built-in.o
 CC     驱动器/MTD/ubi/vtbl.o
 CC [M] drivers/MTD/tests/MTD_test.o
 CC     驱动器/MTD/ubi/VMT.o
 CC [M] drivers/MTD/tests/pagetest.o
 CC     Net/SUNPPC/auth_GSS-general_token.o
 CC [M] net/sched/cls_route.o
 CC [M] drivers/MTD/tests/readtest.o
 CC     Net/SUNPPC/auth_gss/GSS_mech_switch.o
 CC     驱动程序/MTD/ubi/UPD
 抄送[M] net/sched/cls_fw.o
 CC [M] drivers/MTD/tests/speedtest.o
 CC     驱动程序/MTD/ubi/build.o
 CC [M] drivers/MTD/tests/应力 Test.o
 CC [M] net/sched/cls_rsvp.o
 CC     net/SUNPPC/auth_gss/svcuth_gss.o
 CC [M] drivers/MTD/tests/subpagetest.o
 CC     驱动器/MTD/ubi/cdev.o
 CC [M] net/sched/cls_tcindex.o
 CC [M] drivers/MTD/tests/torturete.o
 CC     驱动器/MTD/ubi/kapi.o
 CC     Net/SUNPPC/auth_GSS-RPC_upcall.o
 CC [M] drivers/MTD/tests/MTD_nandectest.o
 CC [M] net/sched/cls_rsvp6.o
 CC [M] drivers/MTD/tests/nandbiterrs.o
 CC     驱动器/MTD/ubi/EBA.o
 CC     Net/SUNPPC/auth_GSS-RPC_XDR.o
 LD [M] 驱动程序/MTD/tests/MTD_oobtest.o
 LD [M] 驱动程序/MTD/tests/MTD_pagetest.o
 LD [M] 驱动程序/MTD/tests/MTD_readtest.o
 LD [M] drivers/MTD/tests/MTD_speedtest.o
 LD [M] drivers/MTD/tests/MTD_StressTest.o
 LD [M] drivers/MTD/tests/MTD_subpagetest.o
 LD [M] drivers/MTD/tests/MTD_torturete.o
 LD [M] 驱动程序/MTD/tests/MTD_nandbiterrs.o
 CC     net/UNIX/af_UNIX.o
 CC [M] net/sched/cls_basic.o
 LD     net/SUNPPC/auth_gss/auth_rpcgss.o
 LD     net/sUNPPC/auth_gss/built-in.o
 Ld     Net/SUNPPC/Built-in.o
 CC     net/UNIX/垃圾
 CC     驱动器/MTD/ubi/io.o
 CC [M] net/sched/cls_flow.o
 CC     驱动器/MTD/ubi/WL.o
 CC [M] net/sched/em_cmp.o
 CC     net/UNIX/sysctl_net_UNIX.o
 CC [M] net/sched/em_nbyte.o
 CC     驱动器/MTD/ubi/attach.o
 CC     驱动器/Net/MII.o
 cc [M] net/sched/em_u32.o
 LD     net/UNIX/UNIX.o
 LD     net/UNIX/Built-in.o
 CC     驱动器/Net/Space.o
 CC     驱动器/MTD/ubi/misc.o
 CC [M] net/sched/em_meta.o
 CC     驱动程序/MTD/ubi/debug.o
 CC     驱动程序/net/loopback.o
 LD     net/wireless/built-in.o
 CC [M] net/wireless/core.o
 LD     驱动程序/MTD/ubi/ubi.o
 LD     驱动程序/MTD/ubi/built-in.o
 LD     驱动程序/MTD/MTD.o
 LD     驱动程序/MTD/Built-in.o
 CC [M] net/wireless/sysfs.o
 LD     驱动程序/net/co_ca/built-in.o
 CC [M] drivers/net/CAN/c_CAN/c_CAN.o
 CC [M] net/sched/em_text.o
 LD     驱动程序/NFC/Built-in.o
 LD     net/sched/built-in.o
 CC [M] drivers/net/CAN/c_CAN/c_CAN_platform.o
 CC [M] 网络/无线/无线电 ap.o
 LD     驱动程序/NVMe/host/built-in.o
 LD     驱动程序/NVMe/TARGET/Built-in.o
 LD     驱动程序/NVMe/Built-in.o
 CC     net/xfrm/xfrm_policy.o
 CC     net/sysctl_net.o
 LD     驱动程序/net/CAN/m_CAN/built-in.o
 CC [M] drivers/net/CAN/m_CAN/m_CAN.o
 抄送[M] 网络/无线/util.o
 抄送[M] 网络/无线/reg.o
 LD     驱动程序/net/CAN/rcar/built-in.o
 CC [M] drivers/net/CAN/rcar/rcar_ca.o
 LD     驱动程序/net/CN/softing/built-in.o
 LD     驱动程序/net/CAN/SPI/Built-in.o
 CC [M] drivers/net/CAN/SPI/mcp251x.o
 CC     net/xfrm/xfrm_state.o
 CC     驱动器/nvmem/core.o
 CC [M] net/wireless/scan.o
 LD     驱动程序/net/USB/Built-in.o
 LD     驱动程序/nvmem/nvmem_core.o
 抄送[M] 驱动程序/net/CAN /开发
 LD     驱动程序/nvmem/built-in.o
 CC     net/xfrm/xfrm_hash.o
 cc [M] net/wireless/nl80211.o
 CC     net/xfrm/xfrm_input.o
 LD     驱动程序/net/CAN/Built-in.o
 LD [M] 驱动程序/net/CN/CAN-dev.o
 LD     驱动程序/net/DSA/B53/Built-in.o
 LD     驱动程序/net/ds/mv88e6xxx/内置
 LD     驱动程序/net/dsa 内置.o
 LD     驱动程序/net/ethernet/Broadcom/built-in.o
 CC [M] drivers/net/ethernet/Broadcom tg3.o
 LD     驱动程序/net/ethernet/intel/built-in.o
 LD     驱动程序/net/ethernet/intel/e1000/built-in.o
 CC [M] drivers/net/ethernet/intel/e1000/e1000_main.o
 CC     net/xfrm/xfrm_output.o
 CC     net/xfrm/xfrm_sysctl.o
 CC     net/xfrm/xfrm_replay.o
 CC [M] drivers/net/ethernet/intel/e1000/e1000_hw.o
 CC [M] net/xfrm/xfrm_algo
 CC [M] drivers/net/ethernet/intel/e1000/e1000_ethtool.o
 抄送[M] net/xfrm/xfrm_user.o
 抄送[M] net/wireless/mlme.o
 CC [M] drivers/net/ethernet/intel/e1000/e1000_param.o
 CC [M] net/xfrm/xfrm_ipcomp.o
 LD [M] 驱动程序/net/ethernet/intel/e1000/e1000.o
 LD     驱动程序/net/ethernet/intel/e1000e/built-in.o
 CC [M] 驱动程序/Net/Ethernet/Intel/e1000e/82571.o
 抄送[M] 网络/无线/IBSS.o
 LD     net/xfrm/built-in.o
 抄送[M] 网络/无线/SME.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/ich8lan.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/80003es2lan.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/mac.o
 抄送[M] 网络/无线/cha.o
 抄送[M] 网络/无线/ethtool.o
 CC [M] net/wireless/mesh.o
 CC     驱动器/net/phy/phy.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/manage
 CC [M] 驱动程序/Net/Ethernet/Intel/e1000e/NVM.o
 抄送[M] 网络/无线/ap.o
 LD     驱动程序/net/ethernet/Marvell/built-in.o
 CC [M] drivers/net/ethernet/Marvell/skge.o
 CC [M] net/wireless/trace.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/phy.o
 CC     驱动程序/net/phy/phy_device.o
 抄送[M] 网络/无线/OCB.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/param.o
 LD [M] net/wireless/cfg80211.o
 LD     net/built-in.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/ethtool.o
 CC     驱动器/net/phy/MDIO_BUS.o
 CC     驱动程序/net/phy/MDIO_DEVICE.o
 CC     驱动器/net/phy/swphy.o
 CC     驱动器/f/base.o
 CC     驱动器/的/设备的.o
 CC     驱动程序/net/phy/at803x.o
 抄送[M] 驱动程序/net/ethernet/intel/e1000e/netdev.o
 CC [M] 驱动程序/Net/Ethernet/Intel/e1000e/PTP.o
 CC     驱动程序/net/phy/dp83848.o
 CC     驱动程序/OF/platform.o
 CC     驱动程序/net/phy/dp83867.o
 CC     驱动程序/net/phy/fixed_phy.o
 CC [M] drivers/net/USB/pegasus.o
 CC     驱动器/1/DYNAMIC
 CC     驱动程序/net/phy/Marvell.o
 CC     驱动器/的/FDT.o
 cc [M] drivers/net/USB/r8152.o
 CC     驱动器/net/phy/Micrel.o
 CC     驱动器/1/FDT_ADDRES.o
 CC     驱动程序/net/phy/Realtek.o
 LD [M] 驱动程序/Net/Ethernet/Intel/e1000e/e1000e.o
 CC     驱动器/net/Micrel/ks8851.o
 CC     驱动程序/1/address.o
 CC     驱动器/net/phy/SMSC.o
 LD     驱动程序/net/ethernet/Micrel/built-in.o
 LD     驱动程序/net/ethernet/packetEngines/built-in.o
 LD     驱动程序/net/phy/libphy.o
 CC     驱动程序/net/ethernet/SMSC/smsc911x.o
 LD     驱动程序/net/phy/built-in.o
 CC     驱动程序/net/ti/cpsw-common.o
 CC     驱动程序/1/IRQ.o
 CC [M] drivers/net/USB/aixel_devices.o
 CC     驱动程序/net/ti/davinci_mdio.o
 CC     驱动程序/of / of _net.o
 CC     驱动程序/net/ti/davinci_cpdma.o
 CC [M] drivers/net/USB/ahixe_common.o
 LD     驱动程序/net/ethernet/SMSC/built-in.o
 CC [M] drivers/net/USB/ax88172a.o
 CC     驱动程序/of / of _mdio.o
 CC     驱动程序/of / of _pci.o
 CC [M] drivers/net/USB/ax88179_178a.o
 CC     驱动程序/net/ti/cpsw-phy-sel.o
 CC     驱动程序/PCI/access.o
 CC     驱动程序/of / of _PCI_IRQ.o
 CC     驱动器/net/ethernet/ti/cpsw_ale.o
 CC [M] drivers/net/USB/CCDC_ete.o
 CC     驱动程序/of / of _ reserved_mem.o
 CC     驱动程序/PCI/bus.o
 CC     驱动器/解析器.o
 CC [M] drivers/net/USB/smsc75xx.o
 CC     驱动程序/PCI/probe.o
 CC     驱动器/的/覆盖的.o
 CC     驱动器/net/ethernet/ti/CPT.o
在 drivers/net/sethernet/ti/CPT.c:36:0中包含的文件中:
drivers/net/ti/ptbc.h:在函数'PTP_bc_clock_unregister'中:
drivers/net/ti/PTP_bc.h:30:1:警告:函数中没有返回语句返回非空[-Wreturn-type]
 ^μ A
 LD     驱动程序/OF/Built-in.o
 CC     驱动程序/net/ti/cpsw.o
顶层:
drivers/net/ti/ptbc.h:28:12:警告:"PTP_bc_clock_unregister"已定义但未使用[-Wunuse-function]
 静态 int PTP_bc_clock_unregister (int clkid)
           ^~~~~~~~~~~~~~~~~~~~~~~μ A
 CC [M] drivers/net/us/smsc95xx.o
 CC     驱动程序/PCI/主机桥接器
 CC [M] drivers/net/USB/net1080/o
 CC     驱动程序/PCI/remove.o
 LD     驱动程序/net/wireless/admtek/built-in.o
 LD     驱动程序/net/wireless/ath/built-in.o
 CC [M] drivers/net/USB/CCDC_Subset
 LD     驱动程序/net/wireless/Atmel/built-in.o
 LD     驱动程序/net/wireless/Broadcom/built-in.o
 LD     驱动程序/net/wireless/Broadca/brcm80211/内置
 LD     驱动程序/net/wireless/Broadca/brcm80211/brcmfmac/built-in.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/cfg80211.o
 CC [M] drivers/net/ethernet/ti/prueth.o
 CC     驱动程序/PCI/PCI-o
 CC [M] drivers/net/USB/zaurus.o
 CC [M] drivers/net/usb/usbnet.o
 CC [M] drivers/net/ti/IEP.o
 CC     驱动程序/PCI/PCI-DRIVER.o
在 drivers/net/ethernet/ti/IEP.c:17:0中包含的文件中:
 ^μ A
 CC [M] drivers/net/USB/CCDC_NCM.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/chip.o
 CC [M] drivers/net/ti/pruss_node_tbl.o
 LD     驱动程序/net/ti/ti_cpsw.o
 LD [M] drivers/net/ethernet/ti/ti_prueth.o
 LD     驱动程序/net/ti/built-in.o
 LD     驱动程序/net/ethernet/built-in.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/fwil.o
 CC     驱动程序/PCI/SEARD.o
 CC     驱动程序/PCI/PCI-sysfs.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/fweh.o
 LD [M] 驱动程序/net/USB/a6.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/fwsignal.o
 CC [M] drivers/net/wireless/Broadcom /brcm80211/brcmfmac/p2p.o
 LD     驱动程序/网络/无线/Broadca/brcm80211/brcmutil/built-in.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmutils/utils.o
 CC     驱动程序/PCI/ROM.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/proto.o
 CC     驱动程序/net/virtio_net.o
 CC     驱动程序/PCI/setup-res.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmutil/D11.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/common.o
 CC     驱动程序/PCI/IRQ.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/core.o
 LD [M] 驱动程序/net/wireless/Broadcom /brcm80211/brcmutil/brcmutil.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/firmware.o
 CC     驱动程序/PCI/VPD.o
 CC     驱动程序/PCI/setup-bus.o
 CC     驱动程序/PCI/DWC/PCIe-designware.o
 CC     驱动程序/PCI/DWC/PCIe-designware-host.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/feature.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/btcoex.o
 CC     驱动程序/PCI/VC.o
 CC     驱动程序/PCI/DWC/PCIe-designware-ep.o
 CC     驱动程序/pci/proc.o
 CC [M] drivers/net/wireless/Broadco/brcm80211/brcmfmac/vendor.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/BCDC.o
 CC     驱动程序/PCI/DWC/PCI-dra7xx.o
 CC     驱动程序/PCI/插槽.o
 CC     驱动程序/PCI/端点/PCI-EPC-core.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/SDIO.o
 LD     驱动程序/PCI/DWC/Built-in.o
 CC     驱动程序/PCI/端点/PCI-EPF-core.o
 CC     驱动程序/PCI/quirks.o
 CC     驱动器/PCI/端点/PCI-EPC-mem.o
 CC     驱动程序/PCI/主机/PCI-host-common.o
 CC     驱动程序/PCI/端点/PCI-EP-CFS.o
 CC     驱动程序/PCI/主机/PCI-host-generic.o
 LD     驱动程序/PCI/主机/built-in.o
 CC     驱动程序/PERF/ARM_PMU.o
 CC     驱动程序/PCI/端点/功能/PCI-EPF-TEST.o
 CC [M] drivers/net/wireless/Broadca/brcm80211/brcmfmac/bcmsdh.o
 CC     驱动程序/PCIe/PCIe/ASPM.o
 LD     驱动程序/PCI/端点/功能/built-in.o
 LD     驱动程序/PCI/端点/内置
 CC     驱动程序/PCI/msi.o
 LD     驱动程序/perf/built-in.o
 CC     驱动程序/PCIe/PCIe/portdrv_core.o
 CC [M] drivers/net/wireless/Broadco/brcm80211/brcmfmac/of.o
 CC     驱动程序/PCI/setup-IRQ.o
 LD [M] 驱动程序/net/wireless/Broadcom /brcm80211/brcmfmac/brcmfmac.o
 LD     驱动程序/net/wireless/cisco/built-in.o
 LD     驱动程序/net/wireless/intel/built-in.o
 LD     驱动程序/网络/无线/英特尔/iwlwii/built-in.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-io.o
 LD     驱动程序/net/wireless/Intersil/built-in.o
 LD     驱动程序/net/wireless/Marvell/built-in.o
 LD     驱动程序/net/wireless/Marvell/mwifiex/built-in.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/main.o
 CC     驱动程序/PCIe/PCIe/portdrv_pci.o
 CC     驱动程序/PCIe/PCIe/portdrv_bus.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/init.o
 CC     驱动器/PCIe/PCIe/aer/aerdrv_errprint.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-drv.o
 CC     驱动器/PCIe/PCIe/aer/aerdrv_core.o
 CC     驱动器/PCIe/PCIe/aer/aerdrv.o
 CC     驱动器/phy/phy-core.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/Cfp.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-debug.o
 LD     驱动器/PCIe/PCIe/aer/aer.o
 LD     驱动程序/PCIe/PCIe/aer/built-in.o
 CC     驱动程序/PCIe/PCIe/PME.o
 CC     驱动程序/phy/phy-omap-control.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/cmdevt.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-notif-wait.o
 LD     驱动程序/PCIe/PCIe/pcieportdrv.o
 LD     驱动程序/PCIe/PCIe/built-in.o
 CC     驱动程序/PCI/syscall.o
 CC     驱动程序/phy/phy-OMAP-USB2.o
 CC     驱动程序/PCI/ecam.o
 CC     驱动器/phy/phy-ti-pipe3.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-EEPROM-read.o
 CC     驱动程序/PCI/ON.o
 LD     驱动程序/phy/built-in.o
 CC [M] drivers/net/wireless/intel/iwlwifi/iwl-EEPROM-parse.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifex/util.o
 LD     驱动程序/PCI/内置.o
 CC     驱动器/pinctrl/core.o
 CC     驱动程序/pinctrl/pinctrl-utils.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/txrx.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-phy-db.o
 CC [M] drivers/net/wireless/intel/iwlwifi/iwl-NVM-parse.o
 CC     驱动器/pinctrl/pinmux.o
 CC     驱动程序/pinctrl/pinconf.o
 LD     驱动程序/平台/built-in.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/PCIe/drv.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/WMM.o
 CC     驱动器/pinctrl/devicetree.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifiex/11n.o
 CC     驱动程序/pinctrl/pinconf-generic.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/PCIe/rx.o
 CC     驱动器/pinctrl/pinctrl-Palms.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/11ac.o
 CC [M] drivers/net/wireless/intel/iwlwifi/PCIe/TX.o
 CC     驱动器/pinctrl/pinctrl-single.o
 LD     驱动程序/pinctrl/BCM/built-in.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifiex/11n_aggr.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/PCIe/transl.o
 LD     驱动程序/pinctrl/Freescale /Built-in.o
 LD     驱动程序/pinctrl/nomadik/built-in.o
 CC     驱动器/pinctrl/ti/pinctrl-ti-iodelay.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/11n_rxreorde.o
 LD     驱动程序/pinctrl/ti/built-in.o
 LD     驱动程序/pinctrl/built-in.o
 LD     驱动程序/net/wireless/MediaTek/built-in.o
 LD     驱动器/power/AVS/Built-in.o
 CC     驱动器/电源/复位/GPIO-POWEROFF.o
 CC     驱动器/电源/复位/GPIO-REST.o
 CC     驱动程序/电源/复位/SYSCON-REBOOT.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/scan.o
 LD     驱动器/电源/复位/内置
 CC     驱动器/电源/电源/电源_电源_内核.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-transl.o
 CC     驱动器/power/supply/power_supply_sysfs.o
 LD     驱动程序/net/无线/Ralink/built-in.o
 LD     驱动程序/网络/无线/Ralink/rt2x00/built-in.o
 cc [M] drivers/net/wireless/Ralink/rt2x00/rt2x00dev.o
 CC     驱动器/电源/电源/电源_SUPPLY_LED.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-1000.o
 CC     驱动器/电源/ act8945a_charger.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/join.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-2000.o
 CC     驱动器/电源/电源/SBS-battery.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-5000.o
 CC     驱动器/电源/电源/ tps65090-charger.o
 cc [M] drivers/net/wireless/ralink/rt2x00/rt2x00mac.o
 CC [M] 驱动器/电源/电源/axp20x_USB_power.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-6000.o
 CC [M] 驱动器/电源/电源/max17040_battery.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifex/sta_ioctl.o
 CC [M] 驱动器/电源/电源/max17042_battery.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-7000.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-8000.o
 cc [M] drivers/net/wireless/Ralink/rt2x00/rt2x00config.o
 LD     驱动器/power/supply/power_supply.o
 LD     驱动器/电源/内置 o
 LD     驱动器/电源/内置
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-9000.o
 LD     驱动程序/net/wireless/Realtek/Built-in.o
 CC     驱动器/pps/pps.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/iwl-a000.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/sta_cmd.o
 cc [M] drivers/net/wireless/Ralink/rt2x00/rt2x00queue.o
 CC     驱动器/pps/kapi.o
 LD     驱动程序/网络/无线/英特尔/iwlwifi/DVM /内置
 CC [M] 驱动程序/net/wireless/intel/iwlwifi/DVM 主页
 CC     驱动程序/pps/sysfs.o
 LD     驱动程序/pps/clients/built-in.o
 LD     驱动器/pps/发生器/built-in.o
 LD     驱动程序/pps/pps_core.o
 LD     驱动程序/pps/built-in.o
 CC     驱动器/PTP/PTP_CLOCL.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/UAP_cmd.o
 cc [M] drivers/net/wireless/Ralink/rt2x00/rt2x00link.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/DVM /rs.o
 CC     驱动器/PTP/PTP_chardev.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifex/e.o
 cc [M] drivers/net/wireless/Ralink/rt2x00/rt2x00crypto.o
 CC     驱动程序/PTP/PTP_sysfs.o
 LD     驱动程序/PTP/PTP.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/sta_cmdresp.o
 LD     驱动程序/PTP/Built-in.o
 CC [M] drivers/net/wireless/Ralink/rt2x00/rt2x00firmware.o
 LD     驱动程序/网络/无线/RSI/内置
 CC [M] drivers/net/wireless/Marvell/mwifiex/sta_event.o
 CC [M] drivers/net/wireless/intel/iwlwifi/DVM /mac80211.o
 cc [M] drivers/net/wireless/ralink/rt2x00/rt2x00leds.o
 CC [M] drivers/net/wireless/intel/iwlwifi/DVM / ucode.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/UAP_event.o
 cc [M] drivers/net/wireless/ralink/rt2x00/rt2x00usb.o
 cc [M] drivers/net/wireless/Ralink/rt2x00/rt2800lib.o
 CC [M] 驱动程序/net/wireless/intel/iwlwifi/DVM / TX
 抄送[M] 驱动程序/net/wireless/Marvell/mwifiex/sta_TX.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifiex/sta_rx.o
 LD     驱动程序/net/wireless/intel/iwlwifi/mvm/built-in.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/fw.o
 CC [M] drivers/net/wireless/intel/iwlwifi/DVM /lib.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/UAP_txrx.o
 CC [M] drivers/net/wireless/intel/iwlwifi/mvm/mac80211.o
 CC [M] 驱动程序/net/wireless/intel/iwlwifi/DVM / calib.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/cfg80211.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/DVM /tt.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/DVM / sta.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/NVM.o
 CC [M] drivers/net/wireless/Marvell/mwifiex/ethtool.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/ops.o
 CC [M] 驱动程序/net/wireless/intel/iwlwifi/DVM / rx.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifiex/11h.o
 CC [M] 驱动程序/net/wireless/intel/iwlwifi/DVM 电源
 cc [M] drivers/net/wireless/intel/iwlwifi/mvm/phy-ctxt.o
 抄送[M] 驱动程序/net/wireless/Marvell/mwifiex/tdls.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/DVM 扫描
 cc [M] drivers/net/wireless/intel/iwlwifi/mvm-ctxt.o
 cc [M] drivers/net/wireless/ralink/rt2x00/rt2800usb.o
 CC [M] drivers/net/wireless/Marvell/mwifex/debugfs.o
 CC [M] drivers/net/wireless/intel/iwlwifi/DVM /rxon.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/utils.o
 LD [M] 驱动程序/net/wireless/Ralink/rt2x00/rt2x00lib.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/DVM 设备。o
 CC [M] drivers/net/wireless/Marvell/mwifiex/SDIO.o
 CC     驱动器/PWM/core.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/rx.o
 CC [M] 驱动程序/net/wireless/intel/iwlwifi/DVM /led.o
 CC     驱动程序/PWM/sysfs.o
 CC     驱动器/PWM/PWM-tiecap.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/rxmq.o
 LD [M] 驱动程序/net/wireless/intel/iwlwifi/dvm/iwldvm.o
 CC     驱动器/PWM/PWM-tiehrpwm.o
 LD [M] 驱动程序/net/wireless/Marvell/mwifiex/mwifiex.o
 LD [M] 驱动程序/net/wireless/Marvell/mwifiex/mwifiex_SDIO.o
 LD [M] 驱动程序/net/wireless/intel/iwlwifi/iwlwifi
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/MVM/TX.o
 CC     驱动器/PWM/PWM-tiwms.o
 CC     驱动程序/RAS/RAS.o
 CC [M] 驱动器/PWM/PWM-FSL-FTM.o
 CC     驱动程序/RAS/debugfs.o
 LD     驱动程序/net/wireless/st/built-in.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/binding.o
 LD     驱动程序/PWM/built-in.o
 CC     驱动程序/net/wireless/ti/WiLink_platform_data.o
 LD     驱动程序/RAS/Built-in.o
 CC     驱动器/稳压器/内核
 LD     驱动程序/net/wireless/ti/wl18xx/built-in.o
 cc [M] drivers/net/wireless/ti/wl18xx/main.o
 cc [M] drivers/net/wireless/ti/wl18xx/acx.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/quota
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/ssta.o
 CC [M] drivers/net/wireless/ti/wl18xx/TX.o
 CC [M] drivers/net/wireless/ti/wl18xx/io.o
 LD     驱动器/net/wireless/zydas/built-in.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/sf.o
 cc [M] drivers/net/wireless/ti/wl18xx/debugfs.o
 CC     驱动器/稳压器/虚拟
 CC     驱动器/稳压器/固定助手。o
 CC [M] drivers/net/wireless/ti/wl18xx/scan.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/sscan.o
 CC     驱动器/稳压器/帮助者。o
 CC     驱动器/稳压器/DevRes.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/time-event.o
 cc [M] drivers/net/wireless/ti/wl18xx/cmd.o
 CC     驱动器/稳压器/of _reguler.o
 CC     驱动器/稳压器/固定输出
 CC [M] drivers/net/wireless/ti/wl18xx/event.o
 LD     驱动程序/remoteproc/built-in.o
 cc [M] drivers/remoteproc/remoteproc_core.o
 CC     驱动器/稳压器/act8945a-reguler.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/MVM/RS.o
 CC     驱动器/稳压器/GPIO-reguler.o
 LD [M] drivers/net/wireless/ti/wl18xx/wl18xx.o
 LD     驱动程序/net/wireless/ti/wlcore/built-in.o
 CC [M] drivers/net/wireless/ti/wlcore/main.o
 CC     驱动器/稳压器/lp873x-reguler.o
 cc [M] drivers/remoteproc/remoteproc_debugfs.o
 CC     驱动器/稳压器/lp87565-reguler.o
 cc [M] drivers/remoteproc/remoteproc_sysfs.o
 CC     驱动器/稳压器/帕尔马斯-稳压器.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/power.o
 cc [M] drivers/remoteproc/remoteproc_virtiio.o
 CC     驱动器/稳压器/pbias 稳压器.o
 cc [M] drivers/remoteproc/remoteproc_elf_loader.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/COEX.o
 CC     驱动器/稳压器/ti-abb-reguler.o
 cc [M] drivers/remoteproc/wkup_m3_rproc.o
 cc [M] drivers/remoteproc/pruss_soc_bus.o
 CC     驱动器/稳压器/tps62360-reguler.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/tt.o
 cc [M] drivers/remoteproc/pruss.o
 CC [M] drivers/net/wireless/ti/wlcore/cmd.o
 CC     驱动器/稳压器/tps65023-reguler.o
 CC     驱动器/稳压器/tps6507x-reguler.o
 cc [M] drivers/remoteproc/pruss_intc.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/loading.o
 CC     驱动器/稳压器/tps65090-reguler.o
 cc [M] drivers/remoteproc/pru_rproc.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/tdls.o
 CC [M] drivers/net/wireless/ti/wlcore/io.o
 CC     驱动器/稳压器/tps65217-reguler.o
 LD [M] 驱动程序/remoteproc/remoteproc.o
 CC [M] drivers/net/wireless/ti/wlcore/event.o
 CC     驱动器/稳压器/tps65218-reguler.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/led.o
 CC     驱动器/稳压器/tps6524x-reguler.o
 CC     驱动器/稳压器/tps6586x-reguler.o
 CC [M] drivers/net/wireless/ti/wlcore/TX.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/tof
 CC [M] drivers/net/wireless/ti/wlcore/rx.o
 CC     驱动器/稳压器/tps65910-reguler.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/mvm/fw-dbg.o
 抄送[M] 驱动程序/net/wireless/intel/iwlwifi/MVM/D3.o
 LD     驱动器/稳压器/built-in.o
 CC     驱动器/复位/内核.o
 LD     驱动器/复位/ hilicon/built-in.o
 CC     驱动器/复位/复位- ti-SYSCON.o
 CC [M] drivers/net/wireless/ti/wlcore/ps.o
 CC [M] drivers/net/wireless/ti/wlcore/acx.o
 LD     驱动程序/复位/内置.o
 CC [M] drivers/net/wireless/ti/wlcore/boot.o
 LD [M] 驱动程序/net/wireless/intel/iwlwifi/mvm/iwlmvm.o
 LD     驱动程序/rpmsg/built-in.o
 cc [M] drivers/rpmsg/rpmsg_core.o
 cc [M] drivers/rpmsg/virtio_rpmsg_fbus.o
 CC [M] drivers/net/wireless/ti/wlcore/init.o
 CC     驱动器/RTC/RTC-lib.o
 CC [M] drivers/rpmsg/rpmsg_PRU.o
 CC     驱动程序/rtc/htosys.o
 CC     驱动器/RTC/系统电阻
 LD     驱动程序/scsi/arm/built-in.o
 CC [M] drivers/scsi/scsi.o
 CC [M] drivers/scsi/hosts.o
 CC     驱动器/RTC/class.o
 cc [M] drivers/net/wireless/ti/wlcore/debugfs.o
 CC     驱动器/RTC/接口
 CC     驱动程序/RTC/RTC-EFI-platform.o
 cc [M] drivers/scsi/scsi_ioctl.o
 CC [M] drivers/scsicam.o
 CC     驱动器/RTC/RTC-DEV.o
 CC [M] drivers/scsi/scsi_error.o
 CC [M] drivers/net/wireless/ti/wlcore/scan.o
 CC     驱动程序/RTC/RTC-proc.o
 CC [M] drivers/net/wireless/ti/wlcore/sysfs.o
 CC     驱动程序/RTC/RTC-sysfs.o
 CC [M] 驱动器/RTC/RTC-ds1307.o
 CC [M] drivers/net/wireless/ti/wlcore/vender_cmd.o
 cc [M] drivers/scsi/scsi_lib.o
 CC [M] DRIVERS/RTC/RTC-EFI.o
 LD     驱动器/SoC/BCM/Built-in.o
 LD     驱动程序/SoC/FSL/Built-in.o
 LD     驱动程序/soc/ti/built-in.o
 cc [M] drivers/soc/ti/pm33xx.o
 CC [M] drivers/net/wireless/ti/wlcore/spi.o
 CC [M] 驱动程序/RTC/RTC-OMAP.o
 CC [M] 驱动器/soc/ti/wkup_m3_ipc.o
 CC [M] DRIVERS/RTC/RTC-PALMAS
 CC [M] drivers/net/wireless/ti/wlcore/SDIO.o
 LD     驱动程序/soc/built-in.o
 CC [M] DRIVERS/RTC/RTC-tps6586x.o
 CC     驱动器/SPI/SPI.o
 CC [M] drivers/scsi/scsi_common.o
 LD [M] drivers/net/wireless/ti/wlcore/wlcore.o
 LD [M] 驱动程序/net/wireless/ti/wlcore/wlcore_spi.o
 LD [M] drivers/net/wireless/ti/wlcore/wlcore_sdio.o
 LD     驱动程序/net/wireless/ti/built-in.o
 LD     驱动程序/net/wireless/built-in.o
 LD     驱动程序/net/built-in.o
 CC [M] drivers/scsi/scsi_lib_dma.o
 CC [M] drivers/scsi/scsi_scan.o
 CC [M] 驱动器/RTC/RTC-tps65910.o
 LD     驱动程序/RTC/RTC-core.o
 LD     驱动程序/rtc/built-in.o
 CC [M] drivers/scsi/scsi_sysfs.o
 CC     驱动器/spmi/spmi.o
 CC     驱动程序/分段/Android/ion/ion.o
 LD     驱动程序/spmi/built-in.o
 CC     驱动程序/分段/android/ion/ion-ioctl.o
 CC [M] drivers/scsi/scsi_DevInfo.o
 CC     驱动程序/SPI/SPI-OMAP2-mcspi.o
 CC     驱动器/TEE/TEE_CORE.o
 CC     驱动程序/分段/Android/ion/ion_heap.o
 cc [M] drivers/scsi/scsi_sysctl.o
 CC     驱动器/SPI/SPI-ti-QSPI.o
 CC     驱动器/TEE/TEE_SHM.o
 cc [M] drivers/scsi/scsi_proc.o
 CC     驱动程序/分段/Android/ion/ion_page_pool.o
 CC [M] drivers/SPI/spidev.o
 CC     驱动器/TEE/TEE_SHM_POB.o
 CC [M] drivers/scsi/scsi_trace.o
 CC     驱动程序/分段/Android/ion/ion_system_heap.o
 CC [M] drivers/scsi/scsi_logging.o
 CC [M] drivers/SPI/SPI-bitbang.o
 CC     驱动器/ TEE / OPTEE / CORE
 CC     驱动程序/分段/Android/ion/ion_carveout_heap.o
 CC     驱动器/ TEE / OPTEE / CAL.O
 CC [M] drivers/SPI/SPI-GPIO.o
 CC     驱动程序/分段/Android/ion/ion_chunch_heap.o
 CC [M] drivers/scsi/scsi_pm.o
 CC     驱动器/ TEE/OPTEE/RPC.o
 CC     驱动程序/分段/Android/ion/ion_CMA_heap.o
 LD     驱动程序/SPI/built-in.o
 CC     驱动器/ TEE / OPTEE /支持 o
 CC     驱动程序/分段/android/ion/ti/ti_ion.o
 CC [M] drivers/scsi/sd.o
 LD     驱动器/ TEE / OPTEE / OPTEE。o
 LD     驱动器/ TEE / OPTEE /内置
 LD     驱动器/ TEE/TEE.o
 LD     驱动器/ TEE/Built-in.o
 cc [M] drivers/scsi/SR.o
 LD     驱动程序/分段/android/ion/ti/built-in.o
 cc [M] drivers/scsi/SR_ioctl.o
 LD     驱动程序/分段/Android/ion/built-in.o
 LD     驱动程序/分段/android/built-in.o
 LD     驱动程序/分段/IIO/accel/built-in.o
 LD     驱动程序/分段/IIO/ADC/Built-in.o
 LD     驱动程序/分段/IIO/addac/built-in.o
 LD     驱动程序/分段/IIO/CDC/Built-in.o
 LD     驱动程序/分段/IIO/frequency /内置
 LD     驱动程序/分段/IIO/gyro/built-in.o
 LD     驱动程序/分段/IIO/Impedance 分析器/内置.o
 LD     驱动程序/分段/IIO/light/built-in.o
 LD     驱动程序/分段/IIO/meter/built-in.o
 LD     驱动程序/分段/IIO/旋 变传感器/Built-in.o
 LD     驱动程序/分段/IIO/TRIGGER/Built-in.o
 LD     驱动程序/分段/IIO/built-in.o
 LD     驱动程序/分段/介质/内置
 LD     驱动程序/分段/内置
 CC     驱动器/thermal/thermal_core.o
 CC     驱动器/thermal/thermal_hwmon.o
 CC     驱动器/散热/散热
 CC     驱动程序/tty/tty_io.o
 CC     驱动器/thermal/fel_share.o
 CC     驱动器/散热/gov_bang_bang.o
 cc [M] drivers/scsi/SR_vendor.o
 CC     驱动程序/tty/n_tty.o
 CC     驱动器/thermal/step_wise.o
 LD     驱动程序/scsi/built-in.o
 LD [M] 驱动程序/scsi/scsi_mod.o
 LD [M] 驱动程序/scsi/sd_mod.o
 LD [M] 驱动程序/scsi/SR_mod.o
 CC     驱动器/thermal/user_space.o
 LD     驱动程序/uio/built-in.o
 抄送[M] 驱动程序/uio/uio.o
 CC     驱动器/thermal/power_allocator.o
 CC     驱动器/thermal/cpu_cooling.o
 CC     驱动程序/tty/tty_ioctl.o
 LD     驱动程序/散热/Samsung /内置.o
 CC     驱动程序/tty/tty_ldiso.o
 LD     驱动程序/USB/class/built-in.o
 CC [M] drivers/USB/class/CDC-ACM.o
 CC     驱动器/散热/ti-soc 热/ti-bandgap.o
 CC     驱动器/thermal/ti-soc 热/ti-thermic-common.o
 CC     驱动程序/tty/tty_buffer.o
 LD     驱动程序/USB/common/built-in.o
 CC [M] 驱动器/USB/common/common.o
 LD     驱动程序/USB/core/built-in.o
 CC [M] drivers/USB/core/usb.o
 CC     驱动程序/tty/tty_port.o
 LD     驱动器/thermal/ti-soc 热/ti-soc 热。o
 LD     驱动器/热/ti-soc -热/built-in.o
 LD     驱动程序/thermal/thermal_sys.o
 LD     驱动器/热性能/内置
 CC [M] drivers/USB/core/hub.o
 LD [M] 驱动程序/USB/common/USB-common.o
 CC [M] drivers/USB/core/hcd.o
 LD     驱动程序/USB/dwc3/built-in.o
 CC [M] 驱动程序/USB/dwc3/core.o
 CC     驱动程序/tty/tty_mutex.o
 CC     驱动程序/tty/tty_ldsem.o
 CC     驱动程序/TTY/Pty.o
 CC [M] 驱动程序/USB/dwc3/debug.o
 CC     驱动程序/视频/HDMI.o
 CC [M] 驱动器/USB/dwc3/trace.o
 CC     驱动程序/tty/sysrq.o
 CC [M] 驱动程序/USB/dwc3/host.o
 CC     驱动器/视频/背光/背光
 抄送[M] 驱动程序/USB/core/话 术
 CC [M] 驱动程序/USB/dwc3/gadget.o
 CC     驱动程序/TTY/HVC/HVC_console.o
 CC     驱动器/视频/背光/通用_BL.o
 CC [M] drivers/USB/core/message.o
 CC     驱动器/视频/背光/GPIO_backlight.o
 LD     驱动程序/TTY/HVC/Built-in.o
 LD     驱动程序/tty/ipwireless/built-in.o
 CC     驱动程序/TTY/串行/serial_core.o
 CC     驱动器/视频/背光/PWM_BL.o
 CC [M] 驱动程序/USB/dwc3/ep0.o
 CC     驱动器/视频/背光/LED_BL.o
 CC [M] drivers/USB/core/driver.o
 CC [M] 驱动程序/USB/dwc3/debugfs.o
 LD     驱动器/视频/背光/内置
 CC     驱动程序/视频/控制台/哑铃
 CC     驱动程序/TTY/串行/Earlycon.o
 CC     驱动程序/视频/控制台/fbcon.o
 CC [M] 驱动程序/USB/dwc3/dwc3-omap.o
 CC [M] drivers/USB/core/config.o
 CC     驱动程序/TTY/串行/8250/8250_core.o
 CC [M] 驱动程序/USB/dwc3/dwc3-of -simple.o
 CC [M] drivers/USB/core/file.o
 LD [M] 驱动程序/USB/dwc3/dwc3.o
 LD     驱动程序/USB/Gadget/built-in.o
 CC [M] 驱动程序/USB/Gadget/usbstring.o
 CC     驱动程序/TTY/串行/8250/8250_port.o
 CC [M] drivers/USB/core/buffer.o
 CC [M] 驱动程序/USB/Gadget/config.o
 CC     驱动程序/视频/控制台/bitblit.o
 CC [M] drivers/USB/core/sysfs.o
 cc [M] drivers/USB/gadget/epautoconx.o
 CC     驱动程序/视频/控制台/软光标
 CC [M] drivers/USB/core/endpoint.o
 CC     驱动程序/TTY/串行/8250/8250_DMA.o
 CC [M] 驱动程序/USB/Gadget/compose.o
 CC     驱动程序/视频/控制台/fbcon_rotate.o
 CC [M] 驱动器/USB/core/devio.o
 CC     驱动程序/TTY/串行/8250/8250_PCI.o
 CC     驱动程序/视频/控制台/fbcon_cw.o
 CC [M] drivers/USB/gadget/functions.o
 CC     驱动程序/视频/控制台/fbcon_ud.o
 CC [M] drivers/USB/core/notife.o
 CC     驱动程序/TTY/串行/8250/8250_EARLY.o
 CC [M] 驱动程序/USB/Gadget/configfs.o
 CC     驱动程序/TTY/串行/8250/8250_FSL.o
 CC [M] 驱动程序/USB/内核/generic.o
 CC     驱动程序/视频/控制台/fbcon_CCS.o
 CC     驱动程序/TTY/串行/8250/8250_omap.o
 CC [M] drivers/USB/core/quirks.o
 cc [M] 驱动程序/USB/Gadget/u_f.o
 CC [M] drivers/USB/core/devices.o
 LD     驱动程序/视频/控制台/内置.o
 CC     驱动程序/video/fbdev/core/fb_cmdline.o
 CC     驱动程序/TTY/串行/8250/8250_for.o
 LD     驱动程序/USB/Gadget/function/built-in.o
 CC [M] 驱动程序/USB/Gadget/function/f_acm.o
 CC     驱动程序/视频/fbdev/core/fb_notife.o
 CC [M] drivers/USB/core/port.o
 LD     驱动程序/TTY/串行/8250/825.o
 LD     驱动程序/TTY/串行/8250/8250_base.o
 LD     驱动程序/TTY/串行/8250/Built-in.o
 CC     驱动程序/TTY/串行/bcm63xx_UART.o
 CC [M] 驱动程序/USB/Gadget/function/f_loopback.o
 CC [M] drivers/USB/core/of
 CC     驱动程序/视频/fbdev/core/fbme.o
 CC [M] drivers/USB/gadget/function/f_sourcesink.o
 CC [M] drivers/USB/core/hcd-pci.o
 LD     驱动程序/TTY/串行/built-in.o
 CC     驱动程序/TTY/VT/VT_ioctl.o
 CC [M] 驱动程序/USB/Gadget/function/u_serial.o
 CC     驱动程序/video/fbdev/core/fbmon.o
 LD [M] 驱动程序/USB/core/usbcore.o
 CC [M] 驱动程序/USB/Gadget/function/f_serial.o
 CC     驱动程序/TTY/VT/VC_SCREEN.o
 CC     驱动程序/TTY/VT/选择
 CC     驱动程序/video/fbdev/core/fbcmap.o
 CC [M] drivers/USB/gadget/function/f_OBEX.o
 CC     驱动程序/TTY/VT/键盘.o
 CC [M] 驱动程序/USB/Gadget/function/u_ete.o
 CC     驱动程序/video/fbdev/core/fbsysfs.o
 CC     驱动程序/video/fbdev/core/modedb.o
 CC     驱动程序/USB/主机/PCI-quirks.o
 CC     驱动程序/video/fbdev/core/fbcvt.o
 CC [M] 驱动程序/USB/Gadget/function/f_NCM
 CC     驱动程序/TTY/VT/控制台 ap.o
 CC     驱动器/视频/fbdev/core/fb_defo.o
 CC [M] 驱动程序/USB/HOST/EHCI-hcd.o
 CC [M] 驱动程序/USB/Gadget/function/f_ecmc.o
 CC     驱动程序/视频/fbdev/core/cfbfillrect.o
 连接  驱动程序/tty/VT/控制台 ap_deftbl.c
 CC     驱动程序/TTY/VT/VT.o
 CC [M] 驱动程序/USB/Gadget/function/f_eem.o
 CC     驱动程序/视频/fbdev/core/cfbcopyarea.o
 CC [M] 驱动程序/USB/Gadget/function/f_subsbe.o
 CC     驱动程序/视频/fbdev/core/cfbimgblt.o
 CC [M] 驱动程序/USB/Gadget/function/f_RNDIS.o
 CC     驱动程序/视频/fbdev/core/sysfillrect.o
 已发货驱动程序/TTY/VT/defkeymap.c
 CC     驱动程序/tty/VT/控制台 ap_deftbl.o
 CC [M] 驱动程序/USB/HOST/EHCI-PCI.o
 CC     驱动程序/TTY/VT/defkeymap.o
 LD     驱动程序/TTY/VT/内置.o
 LD     驱动程序/tty/built-in.o
 CC [M] drivers/USB/host/EHCI-platform.o
 CC     驱动程序/视频/fbdev/core/syscopyarea.o
 CC     驱动器/视频/display_timing.o
 CC [M] 驱动程序/USB/Gadget/function/RNDIS.o
 CC [M] 驱动程序/USB/HOST/EHCI-OMAP.o
 cc [M] drivers/USB/host/ohci-hcd.o
 CC     驱动程序/视频/fbdev/core/sysimgblt.o
 CC     驱动器/视频/fbdev/core/fb_sys_FOPS
 CC [M] drivers/USB/gadget/function/f_mass 存储.o
 CC     驱动程序/视频/视频代码
 cc [M] drivers/USB/host/ohci-pci.o
 LD     驱动程序/视频/fbdev/core/fb.o
 LD     驱动程序/video/fbdev/core/built-in.o
 LD     驱动程序/视频/fbdev/OMAP2/omapfb/Displays/built-in.o
 LD     驱动程序/video/fbdev/OMAP2/omapfb/dss/built-in.o
 LD     驱动程序/视频/fbdev/OMAP2/omapfb/built-in.o
 LD     驱动程序/视频/fbdev/OMAP2/built-in.o
 CC     驱动程序/VIDEO/fbdev/efifb.o
 CC     驱动程序/video/fbdev/ssd1307fb.o
 cc [M] drivers/USB/host/ohci-platform.o
 CC [M] 驱动程序/USB/Gadget/function/storage_common.o
 cc [M] drivers/USB/host/xhci.o
 CC     驱动程序/video/fbdev/simplefb.o
 CC     驱动器/视频/of _display_timing.o
 CC [M] 驱动程序/USB/Gadget/function/f_fs.o
 CC     驱动程序/virtio/virtiio.o
 LD     驱动程序/video/fbdev/built-in.o
 CC     驱动程序/视频/视频/视频代码
 LD     驱动程序/视频/built-in.o
 CC     驱动器/virtio/virtio_ring.o
 LD     驱动程序/USB/Gadget/legal/built-in.o
 CC [M] 驱动程序/USB/Gadget/legal/zero.o
 CC [M] 驱动程序/USB/Gadget/legal/audio.o
 CC     驱动程序/virtio/virtio_MMio.o
 cc [M] drivers/USB/host/xhci-mem.o
 CC [M] 驱动程序/USB/Gadget/legal/ete.o
 CC [M] drivers/USB/gadget/function/f_uac1.o
 CC     驱动程序/virtio/virtio_pci_model.o
 CC [M] 驱动程序/USB/Gadget/legal/inode.o
 cc [M] drivers/USB/gadget/function/u_uac1.o
 CC     驱动程序/virtio/virtio_pci_common.o
 CC [M] drivers/USB/gadget/function/f_uac2.o
 cc [M] drivers/USB/host/xhci-ring
 CC     驱动程序/virtio/virtio_pci_legace.o
 CC [M] 驱动程序/USB/Gadget/legal/g_FFS.o
 CC [M] drivers/USB/gadget/function/f_uvc.o
 LD     驱动程序/virtio/virtio_pci.o
 LD     驱动程序/virtio/built-in.o
 CC [M] drivers/USB/gadget/function/UVC_queue.o
 CC [M] 驱动程序/USB/Gadget/legal/mass 存储.o
 LD     驱动程序/USB/isp1760/Built-in.o
 CC [M] drivers/USB/isp1760/isp1760-core.o
 CC [M] drivers/USB/gadget/function/UVC_v4l2.o
 CC [M] 驱动程序/USB/Gadget/legal/serial.o
 CC [M] drivers/USB/isp1760/isp1760-if.o
 cc [M] drivers/USB/host/xhci-hub.o
 CC [M] 驱动程序/USB/Gadget/legal/printer.o
 CC [M] drivers/USB/gadget/function/UVC_VIDO.o
 CC [M] drivers/usb/isp1760/isp1760-hcd.o
 CC [M] 驱动程序/USB/Gadget/legal/gmidi.o
 CC [M] drivers/USB/gadget/function/UVC_configfs.o
 CC [M] 驱动程序/USB/Gadget/legal/cdc2.o
 cc [M] drivers/USB/host/xhci-dbg.o
 CC [M] 驱动程序/USB/Gadget/legal/hid.o
 cc [M] drivers/USB/host/xhci-trace.o
 CC [M] drivers/USB/isp1760/isp1760-UDC.o
 CC [M] 驱动程序/USB/Gadget/function/f_midi.o
 抄送[M] 驱动程序/USB/Gadget/legal/dbgp.o
 cc [M] drivers/USB/host/xhci-pci.o
 CC [M] 驱动程序/USB/Gadget/legal/multi.o
 cc [M] drivers/USB/host/xhci-plat.o
 CC [M] drivers/USB/gadget/function/f_hid.o
 LD [M] 驱动程序/USB/isp1760/isp1760.o
 CC [M] drivers/USB/gadget/function/f_printer.o
 抄送[M] 驱动程序/USB/Gadget/legal/webcam
 cc [M] drivers/USB/host/r8a66597-hcd.o
 LD     驱动程序/W1/masters/built-in.o
 CC [M] drivers/W1/masters/OMAP_HDQ.o
 CC [M] 驱动程序/USB/Gadget/legal/NCM.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_acm.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_ss_lb.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_serial.o
 LD [M] 驱动程序/USB/Gadget/function/USB_f_OBEX.o
 LD [M] 驱动程序/USB/Gadget/Function/USB_f_NCM.o
 LD [M] 驱动程序/USB/Gadget/Function/USB_f_ECM.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_eem.o
 LD [M] 驱动程序/USB/Gadget/Function/USB_f_ECM_Subset。o
 LD [M] 驱动程序/USB/Gadget/function/USB_f_RNDIS.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_mass 存储.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_f_fs.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_uac1.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_uac2.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_uvc.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_midi.o
 LD [M] 驱动程序/USB/Gadget/function/usb_f_hid.o
 LD [M] 驱动程序/USB/Gadget/function/USB_f_printer.o
 CC [M] 驱动程序/USB/Gadget/legal/ACM_ms.o
 LD     驱动程序/W1/slavers/built-in.o
 CC [M] DRIVERS/W1/W1.o
 LD     驱动程序/USB/Gadget/UDC/Built-in.o
 CC [M] 驱动程序/USB/Gadget/UDC/core.o
 LD [M] 驱动程序/USB/Gadget/legal/g_zero.o
 LD [M] 驱动程序/USB/Gadget/legal/g_audio.o
 LD [M] 驱动程序/USB/Gadget/legal/g_ete.o
 LD [M] 驱动程序/USB/Gadget/legal/gadgetfs.o
 LD [M] 驱动程序/USB/Gadget/legal/g_mass 存储.o
 LD [M] 驱动程序/USB/Gadget/legal/g_serial.o
 LD [M] 驱动程序/USB/Gadget/legal/g_printer.o
 LD [M] 驱动程序/USB/Gadget/legal/g_midi.o
 LD [M] 驱动程序/USB/Gadget/legal/g_CDC.o
 LD [M] 驱动程序/USB/Gadget/legal/g_hid.o
 LD [M] 驱动程序/USB/Gadget/legal/g_dbgp.o
 LD [M] 驱动程序/USB/Gadget/legal/g_multi.o
 LD [M] 驱动程序/USB/Gadget/legal/g_webcam
 LD [M] 驱动程序/USB/Gadget/legal/g_NCM.o
 LD [M] 驱动程序/USB/Gadget/legal/g_ACM_ms.o
 CC     驱动器/看门狗/看门狗_core.o
 LD     驱动程序/USB/主机/built-in.o
 LD [M] 驱动程序/USB/host/xhci-hcd.o
 LD [M] 驱动程序/USB/host/xhci-plat-hcd.o
 LD [M] 驱动程序/USB/Gadget/libcomposy.o
 CC     驱动器/看门狗/看门狗_dev.o
 CC [M] drivers/W1/W1_int.o
 CC [M] 驱动程序/USB/Gadget/UDC/TRACE.o
 LD     驱动程序/USB/MISC/Built-in.o
 CC [M] drivers/USB/MISC/usbtest.o
 CC [M] 驱动程序/安全装置/OMAP_WDT.o
 LD [M] 驱动程序/USB/Gadget/UDC/UDC-core.o
 CC [M] drivers/W1/W1_family.o
 LD     驱动程序/安全装置/安全装置
 LD     驱动程序/安全装置/内置.o
 CC [M] drivers/W1/W1_netlink.o
 CC [M] drivers/W1/W1_IO.o
 LD     驱动程序/USB/MUSB 接口/Built-in.o
 CC [M] 驱动程序/USB/MUSB / MUSB 内核.o
 LD     驱动程序/W1/built-in.o
 LD [M] 驱动器/W1/Wire.o
 CC [M] drivers/USB/MUSB /MUSB B/musb_trace.o
 cc [M] drivers/USB/musb/musb_virthub.o
 CC [M] drivers/USB/MUSB /MUSB b_host.o
 CC     驱动器/USB/phy/phy.o
 CC     驱动器/USB/phy/of
 CC [M] drivers/USB/MUSB /MUSB MUSB MUSB _Gadget_ep0.o
 CC [M] drivers/USB/phy/phy-generic.o
 CC [M] drivers/USB/phy/phy-AM335x-control.o
 CC [M] 驱动程序/USB/MUSB / MUSB MUSB _Gadget.o
 LD     驱动程序/USB/串行/内置
 CC [M] 驱动程序/USB/串行/USB-serial.o
 CC [M] 驱动程序/USB/串行/generic.o
 CC [M] drivers/USB/phy/phy-AM335x.o
 CC [M] drivers/USB/phy/phy-GPIO-VBUS-US.o
 CC [M] drivers/USB/phy/phy-isp1301.o
 CC [M] drivers/USB/MUSB /MUSB b_debugfs.o
 LD     驱动程序/USB/STORAE/Built-in.o
 CC [M] drivers/USB/storage/scsiglue.o
 CC [M] 驱动器/USB/串行/bus.o
 LD     驱动程序/USB/phy/built-in.o
 CC [M] drivers/USB/storage/protocol.o
 CC [M] drivers/USB/MUSB /MUSB b_cppi41.o
 LD [M] 驱动程序/USB/串行/usbserial.o
 CC [M] 驱动程序/USB/MUSB /OMAP2430.o
 CC [M] drivers/USB/MUSB /AM35x.o
 CC [M] 驱动程序/USB/MUSB / MUSB MUSB MUSB _DSP.o
 CC [M] drivers/USB/storage/transport.o
 CC [M] drivers/USB/MUSB /MUSB MUSB MUSB _AM335x.o
 CC [M] drivers/USB/storage/usb.o
 CC [M] drivers/USB/storage/initiizers.o
 LD [M] 驱动程序/USB/MUSB /MUSB b_hdrc.o
 CC [M] drivers/USB/storage/Sierra ms.o
 CC [M] drivers/USB/storage/option_ms.o
 CC [M] drivers/USB/storage/use-tables.o
 LD [M] 驱动程序/USB/STORAE/USB-STORALE.o
 LD     驱动程序/USB/Built-in.o
 LD     驱动程序/built-in.o
编译在此处停止、并且在引导文件夹中不生成映像
    软件团队已收到通知。 他们将在这里作出回应。
    Hi-Hinge、
    [引用 user="Dattatray 铰链"] root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59 # make -J4
    您应该制作 zImage:
    TI-PROCESSOR-SDK-LINUX-AM335x-EVM-04.02.00.09/board-support/linux-4.9.59$ make zImage -J4
    有关详细信息、请参阅以下 wiki:
    您还可以使用 Makefile 文件从主文件夹构建内核(包含模块和 DTS 文件):
    TI-PROCESSOR-SDK-LINUX-AM335x-EVM-04.02.00.09 $make linux
    processors.wiki.ti.com/.../Processor_SDK_Linux_Getting_Started_Guide
    [报价用户="Dattatray 铰链"] root@sdkusr-XPS14-L:/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59出口路径=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$path
    [引用 user="Dattatray 铰链"]在@INC 中找不到 strict.pm (您可能需要安装严格模块)(@INC 包含://usr/lib/perl/site_perl/5.22.1 //usr/lib/perl/vendor_perl/5.22.1 //usr/lib/perl/5.22.1 /tmp/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    如果 Perl strict.pm 有问题,请不要导出 PATH 变量,而只使用以下命令来生成内核映像:
    TI-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59$使 arch=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- distclean
    TI-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59$使 arch=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- tisdk_am335x-evm_defconfig
    TI-processor-sdk-linux-am335x-evm-04.02.00.09/board-support/linux-4.9.59$使 arch=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.02.00.09/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- zImage
    因此、编译过程以下列控制台消息结束:
     objcopy arch/arm/boot/zImage
     内核:arch/arm/boot/zImage 已就绪
    帕维尔
    以下命令显示错误、因为没有目标
    $ ti-processor-sdk-linux-am335x-evm-04.02.00.09美元 make linux
    我认为缺少一些步骤、请向我发送所有需要使用模块和 DTS 文件构建内核的命令
    Dattatray、
    "让 Linux"在我身边工作正常、无需更多。
    您能否测试以下序列?
    TI-PROCESSOR-SDK-LINUX-AM335x-EVM-04.02.00.09$制造清洁
    TI-PROCESSOR-SDK-LINUX-AM335x-EVM-04.02.00.09$打造 Linux
    如果仍然无法正常工作、请提供完整的控制台日志输出(将其放入 txt 文件中并在此处附加 txt 文件)以进行分析。 另请向我提供您的 ti-processor-sdk-linux-am335x-evm-04.02.00.09/Rules.make 文件。
    另请查看以下 wiki 是否将提供帮助:
    processors.wiki.ti.com/.../Processor_Linux_SDK_Top-Level_Makefile
    帕维尔
    您好、Pavel、
    我在 SDK 版本 v04.01.00.06和 v04.02.00.09中尝试过上述命令
    下面是结果、我认为需要构建配置文件
    sdkusr@sdkuser-XPS14-L:~μ C/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- clean
    sdkusr@sdkuser-XPS14-L:~μ C/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- linux
    HOSTCC 脚本/基本/固定程序
    HOSTCC 脚本/kconfig/conf.o
    出厂脚本/kconfig/zconf.tab.c
    出厂脚本/kconfig/zconf.lex.c
    出厂脚本/kconfig/zconf.hash-c
    HOSTCC 脚本/kconfig/zconf.tab.o
    HOSTLD 脚本/kconfig/Conf
    scripts/kconfig/conf --silentoldconfig Kconfig
    ***未找到配置文件".config"!
    ***请运行一些配置程序(例如“make oldconfig”或
    ***"make menuconfig"或"make xconfig")。
    scripts/kconfig/Makefile:37:目标'ilentoldconfig'的配方失败
    maked[2]:***[silentoldconfig]错误1
    Makefile:546:目标'ilentoldconfig'的配方失败
    maked[1]:***[silentoldconfig]错误2.
    make:***没有规则将目标设为"Linux"。 停下。
    请查找附加规则.make 文件
    e2e.ti.com/.../Rules.make.txt
    [引用 USER="Dattatray 铰链]我在 SDK 版本 v04.01.00.06和 v04.02.00.09中尝试过上述命令
    下面是结果、我认为需要构建配置文件
    HOSTCC 脚本/基本/固定程序
    make:***没有规则将目标设为"Linux"。 停止。[/报价]
    Dattatray、
    您正在整理两种方法(从顶级编译和从 Linux 内核源编译)。
    请执行以下序列:
    sdkusr@sdkuser-XPS14-L:~μ C/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- distclean
    sdkusr@sdkuser-XPS14-L:~μ C/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- tisdk_am335x-evm_defconfig
    sdkusr@sdkuser-XPS14-L:~μ C/ti-processor-sdk-linux-am335x-evm-04.01.00.06/board-support/linux-4.9.41$ make ARCH=arm cross_compile=/home/sdkusr/ti-processor-sdk-linux-am335x-evm-04.01.00.06/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-linux-gnueabihf- zImage
    这是从 Linux 内核源编译内核映像(zImage)的正确方法。 您最终应该会生成 zImage。
    另一种方法是从顶层编译 zImage 加模块以及 DTB 文件。 在此方法中、请执行以下命令:
    sdkusr@sdkuser-XPS14-L:~μ C/ti-processor-sdk-linux-am335x-evm-04.01.00.06$ make clean
    sdkusr@sdkuser-XPS14-L:~μ C/ti-processor-sdk-linux-am335x-evm-04.01.00.06$ make linux
    帕维尔
    糟糕的是、我忘记更改目录、
    感谢 Pavel、它现在正在工作。
