[参考译文] Linux:DRA7xx EVM Linux SDK 64 v.03.04.00.04编译失败
Guru**** 2966500 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/662432/linux-dra7xx-evm-linux-sdk-64-v-03-04-00-04-build-has-failed
工具/软件:Linux
我正在  Ubuntu 16.04上为 DRA7x 评估板构建 DRA7xx EVM Linux SDK 64 v.03.04.00.03。
由于'amsdk-av-files_1.4.tar.gz' tarball 的提取失败,我的构建失败,构建系统能够下载此文件。
我也无法从 TI 存储库 https://gforge.ti.com/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz 手动下载此文件
调试:执行 python 函数 DO 获取
调试:执行 python 函数 base_do 提取
调试:尝试 PREMIRRORS
调试:尝试上游
调试:使用 命令'/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'gforge.ti.com/.../amsdk-av-files_1.4.tar.gz''获取 gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:fetcher 使用命令/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'gforge.ti.com/.../amsdk-av-files_1.4.tar.gz'访问网络
调试:运行 export GIT_PROXY COMMAND_COMMANTI="OE-GIT-PROXY;export NO_PROXY ="192.168.0.*;*。pasa.http.local;127.0.0.1;140.212;http:/.../adfs.panasonicautomotive.com/.../adfs.panasonicautomotive.comlocalhost:3128/";;";export NO_PROXY ="192.168.0.0*;*。pasa.pas.local;127.0.0.1;140.212;https:export= localhost:3128/";;"ftp_proxy= 导出http_proxy="http://localhost:3128/"; 导出路径="/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/usr/bin/env:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/bin:/home/akolesov/.local/bin:/usr/local/sbin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/bin/crossscripts:/usr/sbin:/usr/bin:/sbin:/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin;导出 home=/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/bitbake/bin /home/akolesovgforge.ti.com/.../amsdk-av-files_1.4.tar.gz';wget -t 2 -T 30 -nV - passive-ftp --no-check 'P certificate -/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts /usr/local/bin /snap/bin /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads
警告:无法获取 URL gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball、如果可用、则尝试镜像
调试:fetcher 失败:获取命令失败、退出代码4、无输出
调试:尝试镜像
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'arago-project.org、'/files/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['https?$'、'.*'、'/.*'、''、''、''、 {}]至['http'、'arago-project.org、'/files/sources、''、''、''、 {}]
调试:用于返回 arago-project.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball 的 URL gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'arago-project.org、'/files/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20120328T092752Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20110127T084257Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20090802T004153Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.de.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.au.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.cl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.fi.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hk.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hu.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ie.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.it.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.jp.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.no.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.pl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ro.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.si.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.es.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.se.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.tr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.gnu.org、'/GNU'、''、''、''、 {}]至['ftp'、'irrors.kernel.org、'/GNU'、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'kernel.org、'/pub'、''、''、''、 {}]至['http'、'www.kernel.org、'/pub'、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.franken.de'、'/pub/crypt/mirror/ftp.gnupg.org/gcrypt、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.surfnet.nl、'/pub/security/gnupg、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['http'、'gulus.USherbrooke.ca、'/pub/appl/GnuPG、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/tex/CTAN、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'sunsite.sut.ac.jp、'/pub/archives/ctan、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'ctan.unsw.edu.au'、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnutls.org、'/gcrypt/gnutls、''、''、''、''、 {}]至['ftp'、'ftp.gnupg.org、'/gcrypt/gnutls、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['http'、'irror.switch.ch、'/ftp/mirror/infozip/src、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['ftp'、'unsite.icm.edu.pl'、'/pub/unix/archiving/info-zip/src、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cerias.purdue.edu、'/pub/tools/unix/sysutils/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.ta.ac.il'、'/pub/unix/admin、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cert.dfn.de、'/pub/tools/admin/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/pub/unix/tools/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.kaizo.org、'/pub/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tu-darmstadt.de、'/pub/sysadmin/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tux.org、'/pub/sites/vic.cc.purdue.edu/tools/unix/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'gd.tuwien.ac.at'、'/utils/admin-tools/lsof、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'sunsite.ualberta.ca、'/pub/Mirror/lsof、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'the.wiretapped.net、'/pub/security/host-security/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'www.us.apache.org'、'/dist'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'archive.apache.org、'/dist'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'downloads.sourceforge.net、'/watchdog/'、''、''、''、 {}]至['http'、'fossies.org、'/linux/misc、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.gnu.org、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.gnu.org、'/releases'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.nongnu.org'、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.nongnu.org'、'/releases'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['https?$'、'.*'、'/.*'、''、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于返回 downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball 的 URL arago-project.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'arago-project.org、'/files/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20120328T092752Z/debian/pool、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20110127T084257Z/debian/pool、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20090802T004153Z/debian/pool、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.de.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.au.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.cl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.fi.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hk.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hu.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ie.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.it.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.jp.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.no.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.pl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ro.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.si.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.es.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.se.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.tr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.gnu.org、'/GNU'、''、''、''、 {}]至['ftp'、'irrors.kernel.org、'/GNU'、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'kernel.org、'/pub'、''、''、''、 {}]至['http'、'www.kernel.org、'/pub'、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.franken.de'、'/pub/crypt/mirror/ftp.gnupg.org/gcrypt、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.surfnet.nl、'/pub/security/gnupg、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['http'、'gulus.USherbrooke.ca、'/pub/appl/GnuPG、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/tex/CTAN、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'sunsite.sut.ac.jp、'/pub/archives/ctan、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'ctan.unsw.edu.au'、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnutls.org、'/gcrypt/gnutls、''、''、''、''、 {}]至['ftp'、'ftp.gnupg.org、'/gcrypt/gnutls、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['http'、'irror.switch.ch、'/ftp/mirror/infozip/src、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['ftp'、'unsite.icm.edu.pl'、'/pub/unix/archiving/info-zip/src、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cerias.purdue.edu、'/pub/tools/unix/sysutils/lsof、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.ta.ac.il'、'/pub/unix/admin、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cert.dfn.de、'/pub/tools/admin/lsof、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/pub/unix/tools/lsof、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.kaizo.org、'/pub/lsof、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tu-darmstadt.de、'/pub/sysadmin/lsof、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tux.org、'/pub/sites/vic.cc.purdue.edu/tools/unix/lsof、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'gd.tuwien.ac.at'、'/utils/admin-tools/lsof、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'sunsite.ualberta.ca、'/pub/Mirror/lsof、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'the.wiretapped.net、'/pub/security/host-security/lsof、''、''、''、'、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'www.us.apache.org'、'/dist'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'archive.apache.org、'/dist'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'downloads.sourceforge.net、'/watchdog/'、''、''、''、 {}]至['http'、'fossies.org、'/linux/misc、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.gnu.org、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.gnu.org、'/releases'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.nongnu.org'、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.nongnu.org'、'/releases'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['https?$'、'.*'、'/.*'、''、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于返回 sources.openembedded.org/amsdk-av-files_1.4.tar.gz;name=avfilestarball 的 URL downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'arago-project.org、'/files/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20120328T092752Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20110127T084257Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20090802T004153Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.de.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.au.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.cl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.fi.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hk.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hu.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ie.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.it.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.jp.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.no.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.pl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ro.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.si.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.es.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.se.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.tr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.gnu.org、'/GNU'、''、''、''、 {}]至['ftp'、'irrors.kernel.org、'/GNU'、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'kernel.org、'/pub'、''、''、''、 {}]至['http'、'www.kernel.org、'/pub'、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.franken.de'、'/pub/crypt/mirror/ftp.gnupg.org/gcrypt、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.surfnet.nl、'/pub/security/gnupg、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['http'、'gulus.USherbrooke.ca、'/pub/appl/GnuPG、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/tex/CTAN、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'sunsite.sut.ac.jp、'/pub/archives/ctan、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'ctan.unsw.edu.au'、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnutls.org、'/gcrypt/gnutls、''、''、''、''、 {}]至['ftp'、'ftp.gnupg.org、'/gcrypt/gnutls、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['http'、'irror.switch.ch、'/ftp/mirror/infozip/src、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['ftp'、'unsite.icm.edu.pl'、'/pub/unix/archiving/info-zip/src、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cerias.purdue.edu、'/pub/tools/unix/sysutils/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.ta.ac.il'、'/pub/unix/admin、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cert.dfn.de、'/pub/tools/admin/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/pub/unix/tools/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.kaizo.org、'/pub/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tu-darmstadt.de、'/pub/sysadmin/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tux.org、'/pub/sites/vic.cc.purdue.edu/tools/unix/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'gd.tuwien.ac.at'、'/utils/admin-tools/lsof、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'sunsite.ualberta.ca、'/pub/Mirror/lsof、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'the.wiretapped.net、'/pub/security/host-security/lsof、''、''、''、'、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'www.us.apache.org'、'/dist'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'archive.apache.org、'/dist'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'downloads.sourceforge.net、'/watchdog/'、''、''、''、 {}]至['http'、'fossies.org、'/linux/misc、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.gnu.org、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.gnu.org、'/releases'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.nongnu.org'、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.nongnu.org'、'/releases'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'cpan.metacpan.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'sources.openembedded.org、'/amsdk-av-files_1.4.tar.gz'、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'earch.cpan.org、'/CPAN/'、''、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'cpan.metacpan.org、'/'、''、''、 {}]
调试:用于 URL ['http'、'downloads.yoctoproject.org、'/mirror/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'earch.cpan.org、'/CPAN/'、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['https?$'、'.*'、'/.*'、''、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于返回 sources.openembedded.org/amsdk-av-files_1.4.tar.gz;name=avfilestarball 的 URL arago-project.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'cpan.metacpan.org、'/'、''、''、 {}]
调试:对于 URL ['http'、'arago-project.org、'/files/sources/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'earch.cpan.org、'/CPAN/'、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20120328T092752Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20110127T084257Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['http'、'snapshot.debian.org'、'/archive/debian-archive/20090802T004153Z/debian/pool、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.de.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.au.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.cl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.fi.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hk.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.hu.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ie.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.it.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.jp.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.no.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.pl.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.ro.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.si.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.es.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.se.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.debian.org'、'/debian/pool、''、''、''、 {}]至['ftp'、'ftp.tr.debian.org'、'/debian/pool、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.gnu.org、'/GNU'、''、''、''、 {}]至['ftp'、'irrors.kernel.org、'/GNU'、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'kernel.org、'/pub'、''、''、''、 {}]至['http'、'www.kernel.org、'/pub'、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.franken.de'、'/pub/crypt/mirror/ftp.gnupg.org/gcrypt、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['ftp'、'ftp.surfnet.nl、'/pub/security/gnupg、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnupg.org、'/gcrypt/'、''、''、''、 {}]至['http'、'gulus.USherbrooke.ca、'/pub/appl/GnuPG、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/tex/CTAN、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'sunsite.sut.ac.jp、'/pub/archives/ctan、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'dante.ctan.org、'/tex-archive'、''、''、''、 {}]至['http'、'ctan.unsw.edu.au'、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'ftp.gnutls.org、'/gcrypt/gnutls、''、''、''、''、 {}]至['ftp'、'ftp.gnupg.org、'/gcrypt/gnutls、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['http'、'irror.switch.ch、'/ftp/mirror/infozip/src、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'ftp.info-zip.org'、'/pub/infozip/src、''、''、''、''、 {}]至['ftp'、'unsite.icm.edu.pl'、'/pub/unix/archiving/info-zip/src、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cerias.purdue.edu、'/pub/tools/unix/sysutils/lsof、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.ta.ac.il'、'/pub/unix/admin、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.cert.dfn.de、'/pub/tools/admin/lsof、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.fu-berlin.de、'/pub/unix/tools/lsof、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.kaizo.org、'/pub/lsof、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tu-darmstadt.de、'/pub/sysadmin/lsof、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'ftp.tux.org、'/pub/sites/vic.cc.purdue.edu/tools/unix/lsof、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'gd.tuwien.ac.at'、'/utils/admin-tools/lsof、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'sunsite.ualberta.ca、'/pub/Mirror/lsof、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'lsof.itap.purdue.edu'、'/pub/tools/unix/lsof、''、''、''、''、 {}]至['ftp'、'the.wiretapped.net、'/pub/security/host-security/lsof、''、''、''、'、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'www.us.apache.org'、'/dist'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'archive.apache.org、'/dist'、''、''、''、 {}]至['http'、'archive.apache.org、'/dist'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'downloads.sourceforge.net、'/watchdog/'、''、''、''、 {}]至['http'、'fossies.org、'/linux/misc、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.gnu.org、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.gnu.org、'/releases'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'download.savannah.nongnu.org'、'/releases'、''、''、''、 {}]至['http'、'download-mirror.savannah.nongnu.org'、'/releases'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['https?$'、'.*'、'/.*'、''、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:用于返回 downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball 的 URL gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'downloads.yoctoproject.org、'/mirror/sources、''、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['CVS、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['svn'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['git、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['hg'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['bzr'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['p4'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['osc'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['https?$'、'.*'、'/.*'、''、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:用于返回 sources.openembedded.org/amsdk-av-files_1.4.tar.gz;name=avfilestarball 的 URL gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['ftp'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['np'、'.*'、'/.*'、''、''、 {}]至['http'、'sources.openembedded.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'cpan.metacpan.org、'/'、''、''、 {}]
调试:对于 URL ['https'、'gforge.ti.com、'/gf/download/frsrelease/1279/7769/amsdk-av-files_1.4.tar.gz、''、''、''、 {'name':'avfilestarball '}]比较['http'、'search.cpan.org、'/CPAN'、''、''、''、 {}]至['http'、'earch.cpan.org、'/CPAN/'、''、''、''、 {}]
调试:使用 命令'/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'arago-project.org/.../amsdk-av-files_1.4.tar.gz''获取 arago-project.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:fetcher 使用命令/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'arago-project.org/.../amsdk-av-files_1.4.tar.gz'访问网络
调试:运行 export GIT_PROXY COMMAND_COMMANTI="OE-GIT-PROXY;export NO_PROXY ="192.168.0.*;*。pasa.http.local;127.0.0.1;140.212;http:/.../adfs.panasonicautomotive.com/.../adfs.panasonicautomotive.comlocalhost:3128/";;";export NO_PROXY ="192.168.0.0*;*。pasa.pas.local;127.0.0.1;140.212;https:export= localhost:3128/";;"ftp_proxy= 导出http_proxy="http://localhost:3128/"; 导出路径="/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/usr/bin/env:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/bin:/home/akolesov/.local/bin:/usr/local/sbin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/bin/crossscripts:/usr/sbin:/usr/bin:/sbin:/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin;导出 home=/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/bitbake/bin /home/akolesovarago-project.org/.../amsdk-av-files_1.4.tar.gz';wget -t 2 -T 30 -nV - passive-ftp --no-check 'P certificate -/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts /usr/local/bin /snap/bin /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads
调试:URL arago-project.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball ( 原始 URL: gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball)的镜像获取失败
调试:fetcher 失败:获取命令失败、退出代码8、输出:
arago-project.org/.../amsdk-av-files_1.4.tar.gz:
2018-02-0608:39:16错误404:找不到。
调试:使用 命令'/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz''获取 downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:fetcher 使用命令/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz'访问网络
调试:运行 export GIT_PROXY COMMAND_COMMANTI="OE-GIT-PROXY;export NO_PROXY ="192.168.0.*;*。pasa.http.local;127.0.0.1;140.212;http:/.../adfs.panasonicautomotive.com/.../adfs.panasonicautomotive.comlocalhost:3128/";;";export NO_PROXY ="192.168.0.0*;*。pasa.pas.local;127.0.0.1;140.212;https:export= localhost:3128/";;"ftp_proxy= 导出http_proxy="http://localhost:3128/"; 导出路径="/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/usr/bin/env:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/bin:/home/akolesov/.local/bin:/usr/local/sbin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/bin/crossscripts:/usr/sbin:/usr/bin:/sbin:/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin;导出 home=/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/bitbake/bin /home/akolesovownloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz';wget -t 2 -T 30 -nv --passive-ftp --no-check -d'证书-/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts /usr/local/bin /snap/bin /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads
调试:URL downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball ( 原始 URL: gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball)的镜像获取失败
downloads.yoctoproject.org/.../amsdk-av-files_1.4.tar.gz:
2018-02-0608:39:17错误404:找不到。
调试:使用 命令'/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'sources.openembedded.org/amsdk-av-files_1.4.tar.gz''获取 sources.openembedded.org/amsdk-av-files_1.4.tar.gz;name=avfilestarball
调试:fetcher 使用命令/usr/bin/env wget -t 2 -T 30 -nV --passive-ftp --no-check-certificate -P /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads'ources.openembedded.org/amsdk-av-files_1.4.tar.gz'访问网络
调试:运行 export GIT_PROXY COMMAND_COMMANTI="OE-GIT-PROXY;export NO_PROXY ="192.168.0.*;*。pasa.http.local;127.0.0.1;140.212;http:/.../adfs.panasonicautomotive.com/.../adfs.panasonicautomotive.comlocalhost:3128/";;";export NO_PROXY ="192.168.0.0*;*。pasa.pas.local;127.0.0.1;140.212;https:export= localhost:3128/";;"ftp_proxy= 导出http_proxy="http://localhost:3128/"; 导出路径="/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/usr/bin/env:/home/akolesov/ti_toolchains/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/akolesov/bin:/home/akolesov/.local/bin:/usr/local/sbin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/dra7xx-evm/usr/bin/crossscripts:/usr/sbin:/usr/bin:/sbin:/bin:/home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin;导出 home=/home/akolesov;wget -t 2 -T 30 -nv --passive-ftp --no-check /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/bitbake/binources.openembedded.org/amsdk-av-files_1.4.tar.gz'-sp-certificate -sp-sp-certificate /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/sources/oe-core/scripts /usr/local/bin /snap/bin /home/akolesov/ti-processor-sdk-linux-automotive-dra7xx-evm-03_04_00_03/yocto-layers/downloads
调试:URL sources.openembedded.org/amsdk-av-files_1.4.tar.gz;name=avfilestarball ( 原始 URL: gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball)的镜像获取失败
sources.openembedded.org/amsdk-av-files_1.4.tar.gz:
2018-02-0608:39:26错误404:找不到。
错误:fetcher 失败:获取命令失败、退出代码4、无输出
调试:Python 函数 base_do 提取完成
调试:Python 函数 DO 获取完成
错误:函数失败:URL 的 fetcher 失败:'gforge.ti.com/.../amsdk-av-files_1.4.tar.gz;name=avfilestarball'。 无法从任何源获取 URL。
    您好、Alexander、
    我已将您的问题转交 Yocto 专家。
    Yordan
    您好、Alexander、
    托管此文件的服务器当前已关闭-我们正在进行此操作。
    在此之前、您将遇到一些尝试从此服务器获取文件的其他组件的问题。
    有两种解决方法:
    a.您可以从包装组中删除此配方
    b.如果您已经完成了早期版本(PSDKLA 3.04或更早版本)的构建、您可以将这些文件从下载文件夹复制到新构建的下载文件夹(以及.doone)文件中。
    请告诉我、您需要获得这些建议中的任何一项的帮助。
    服务器应尽快恢复,此时不需要这些变通办法。
    Karthik
    我遇到相同的问题。 何时将恢复服务器?
    您好、Geoff、
    我们已将其恢复、还有一些额外的步骤。
    本文中记录了这些内容: e2e.ti.com/.../667036
    Karthik
