[参考译文] DRA756:DRA756 MMC1的最大 SD 容量是多少?
Guru**** 2576215 points
Other Parts Discussed in Thread: DRA756
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/627957/dra756-what-is-the-biggest-sd-capacity-of-dra756-mmc1
器件型号:DRA756
我是否知道 DRA756 MMC1的最大 SD 容量?
