[参考译文] RTOS/AM3359:EtherCAT 从站编译问题
Guru**** 2582215 points
Other Parts Discussed in Thread: TLK110, SYSBIOS
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/617070/rtos-am3359-ethercat-slave-compilation-issue
器件型号:AM3359
Thread 中讨论的其他器件:TLK110SYSBIOS
工具/软件:TI-RTOS
我已经安装 了 PRU-ICSS-EtherCAT-SLAVE 并使用批处理文件创建了项目并将其导入到 CCSV7、但它给出了以下错误:
Makefile:167:目标'EtherCAT_SLAVE_DEMO_AM335x_ARM.out'的配方失败
/tiescphy_tlk110.o:在函数`bsp_ethphy_init'中:
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:52:对`Board_getPhyIdentifyStat'的引用未定义
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:57:对`Board_getPhyIdentifyStat'的引用未定义
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:70:对`Board_phyExtFDEnable'的引用未定义
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:72:对`Board_phyExtFDEnable'的引用未定义
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:74:未定义对`Board_phyODDNibbleDetEnable'的引用
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:76:未定义对`Board_phyODDNibbleDetEnable'的引用
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:100:对`Board_phyLedBlinkConfig'的引用未定义
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:102:对`Board_phyLedBlinkConfig'的引用未定义
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:104:未`对 Board_phyFastLinkDownDetEnable'的引用
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/protocols/ethercat_slave/ecat_appl/iceAM335x/tiescphy_tlk110.c:107:对`Board_phyFastLinkDownDetEnable'的引用未定义
C:/ti/PRU-ICSS-EtherCAT_Slave_01.00.03.01/third_party/protocols/ethercat_slave/stack_lib/am335x/a8 \libethercat_slave_stack_am335x_arm.a (tisebsp.o):在函数中`bsp_pruss_mdio_init':
/home/gtbldadm/nightlybuilds/industrial_communications_dev/public/sdk/protocols/ethercat_slave/ecat_appl/EcatStack/tiescbsp.c:1348:对`Board_enablePhyAutoMDIX'的引用未定义
/home/gtbldadm/nightlybuilds/industrial_communications_dev/public/sdk/protocols/ethercat_slave/ecat_appl/EcatStack/tiescbsp.c:1350:未`对 Board_enablePhyAutoMDIX'的引用
/home/gtbldadm/nightlybuilds/industrial_communications_dev/public/sdk/protocols/ethercat_slave/ecat_appl/EcatStack/tiescbsp.c:1397:对`MDIO_enableLinkInterrupt'的引用未定义
/home/gtbldadm/nightlybuilds/industrial_communications_dev/public/sdk/protocols/ethercat_slave/ecat_appl/EcatStack/tiescbsp.c:1400:未`M对 DIO_enableLinkInterrupt'的引用
/home/gtbldadm/nightlybuilds/industrial_communications_dev/public/sdk/protocols/ethercat_slave/ecat_appl/EcatStack/tiescbsp.c:1387:对`MDIO_enableLinkInterrupt'的引用未定义
/home/gtbldadm/nightlybuilds/industrial_communications_dev/public/sdk/protocols/ethercat_slave/ecat_appl/EcatStack/tiescbsp.c:1390:对`MDIO_enableLinkInterrupt'的引用未定义
collect2.exe:错误:LD 返回1退出状态
gmaked[1]:***[EtherCAT_SLAVE_DEMO_AM335x_ARM.OUT]错误1.
gmake:***[全部]错误2.
Makefile:163:目标“全部”的配方失败
****构建完成****
那么、问题出在哪呢?
    RTOS 团队已收到通知。 他们将在这里作出回应。
    您好、Ashok、在应用修补程序(PRU-ICSS-EtherCAT_Slave_01.00.03.01\third_party\protocol\EtherCAT_slave\patch\README.txt 中提到的步骤)后、您是否确定将所有.c 和.h 文件从 SSC_V5i11\SlaveFiles\src 复制到 C:\TI\PRU-ICU\README_Stack\EtherCAT_App_App\EtherEC00.01.03.01\EtherCAT 从 SSC_SlaveFiles\EtherCAT 从\App_Appli\EtherNet\EtherNet_App_
    我按照自述文件步骤进行了构建、并能够构建"EtherCAT_SLAVE_DEMO_AM335x_ARM"。 我遇到的唯一问题是、为了正确编译、我必须更改 RTSC PDK 路径(工程属性->常规-> RTSC->其他库)。 不确定"其他存储库"中的 PDK 路径为何"未定"
    Paula
    您好 Ashok、您能试试 PRU-ICSS-ETHERCAT_Slave_01.00.04.02吗 ? 另一位用户报告了使用 CCSv7和 PRU-ICSS-ETHERCAT_Slave_01.00.03.01的类似问题(E2E)、并确认1.0.4.2版本已解决。
    注意:我昨天使用 CCS6.13对其进行了测试
    Paula
    感谢 Paula 的即时响应。
    正如您在上面的邮件中提到   的、我已经下载了 PRU-ICSS-EtherCAT_Slave_01.00.04.02并成功编译和构建。
    谢谢、此致、
    Ashok Wakode
    如上所述、PRU-ICSS-EtherCAT_Slave_01.00.04.02的问题已解决、但 PRU-ICSS-EthernetIP_Adapter-01.00.02.00和 PRU-ICSS-HSR-PRP-DAN-01.00.02.00的编译问题仍然存在。如果您需要详细日志、我将提供但这两个软件仍不能使用 CCSv7进行编译。
    您好、Ashok、 请 打开另一个 E2E 并附加日志。 供参考、我使用  CCS 7.0.0.00042尝试了 EthernetIP (PRU-ICSS-ETHERNETIP_Adapter_01.00.02.00)、并且编译成功
    Paula
    谢谢 Paula、
    以下是编译 n 日志:
    ****为项目 EtherNetIP_ADAPTER_AM335x_ARM 构建配置 AM335x_debug ****
    "C:\\ti\\ccsv7\\utils\\bin\\gmake"-k -j 4 all -O
    gmake[1]:输入目录'C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm/AM335x_debug
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/am335x_app.cfg '
    '调用:XDCtools '
    "c:/ti/xdctools_3_32_01_22_core/xs "--xdcpath="C:/ti/bios_6_46_05_55/packages;C:/ti/pdk_am335x_1_0_7/packages;C:/ti/ndk_2_25_01_11/packages;C:/ti/edma3_lld_2_12_04_28/packages;C:/ti/ccsv7/ccs_base;" xdc.tools.configuro configPkg -t GNU.targets.arM.A8F -p ti.platforms.evmAM3359 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/am335x_app.cfg -r release -c "C:/ti/gcc-arm-none-eabi-4_9-2015q3 -dconfig.importPath=C:\ti\PRU-netvertages\con.ip_projects./examples/ethernetip_adapter。
    正在制作 package.mak (由于 package.bld)...
    正在为软件包 configPkg 生成接口(因为 package/package.xdc.inc 比 package.XDC 旧)...
    从 package/cfg/am335x_app_pa8fg.cfg 配置 AM335x_app.xa8fg ...
    正在生成自定义 ti.sysbios 库 makefile ...
    EDMA3驱动器采样 getLib 内
    将与 ti.sdo.EDMA3.drv.sample:lib/AM335x-EVM/A8/release/EDMA3_LLD_drv_sample.aa8fg 链接
    链接库 ti.drv.SPI:./lib/am335x/a8/release/ti.drv.spi.aa8fg
    链接库 ti.board:./lib/icev2AM335x/a8/release/ti.board.aa8fg
    链接库 ti.drv.icss_emac:./lib/a8/release/ti.drv.icss_emac.aa8fg
    链接库 ti.csl:./lib/am335x/a8/release/ti.csl.aa8fg
    链接库 ti.drv.gpio:./lib/a8/release/ti.drv.gpio.aa8fg
    链接库 ti.drv.pruss:./lib/a8/release/ti.drv.pruss.aa8fg
    链接库 ti.drv.i2c:./lib/a8/release/ti.drv.i2c.aa8fg
    链接库 ti.drv.UART:./lib/a8/release/ti.drv.uart.aa8fg
    链接库 ti.osal:/lib/tirtos/a8/release/ti.osal.aa8fg
    EDMA3 Drv getLibs 内
    将与 ti.sdo.EDMA3.drv:lib/A8/release/EDMA3_LLD_drv.aa8fg 链接
    EDMA3 RM get库 中
    将与 ti.sdo EDMA3.rm:lib/AM335x-EVM/A8/release/EDMA3_LLD_rm.aa8fg 链接
    正在开始构建库源...
    制作 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/src/sysbios/sysbios.aa8fg ...
    gmake[1]:输入目录`C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/src/sysbios
    gmake[1]:没有为`all '执行任何操作。
    gmake[1]:离开目录`C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/src/sysbios
    已完成库构建。
    cla8fg 封装/cfg/AM335x_app_pa8fg.c ...
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/am335x_app.cfg '
    gmake[1]:离开目录'C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm/AM335x_debug
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/app_restart.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_detch-i="C:mf_ab=hard -mpu /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm -dcpu-dus-/ti/pdk_am335x_1_0_7/packages -dunchine-/ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/app_restart.c -mf-ng"/ti/ndk_2_25_01_11 -mf-nv/i:-chintrab-unchina.i"i-unchina.i"-c:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -mf-ng"-dmf"-unchintrab-ex"/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-nateg"-ex"-mf-nategrob.c @:-ex"-ex"-ex"-mf-ng.c:-ex"-mf-nategrob.c:-unchintrab-ex"-ex"-ex"-mf-nategrob.c:-ex"-ex-df-nec
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/app_restart.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/acd_arp_filter.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/acd_arp_filter.c -c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i="C:mf_intrab-/ti/pdk_am335x_1_0_7/packages -i_influ_ab-/ti/ndk_2_25_01_11 -dac"-i_i -mf-nategrob"-dac"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -d_ab-mf-nateg"-intrab-influ.c @:/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-nateg"-dac_i -ab-dac-mf-nategrob.c:-dac"-dac"-mf-nateg"-dac"-mf-nateg"-dac"-d_ab-dac"-influ.c:-ab-ab-ab-ab-mf-nategrob.c:-ab-ab-ab-ab-ab-ab-d
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/acd_arp_filter.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_ndk.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_ndk.c "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i"i-cn"Demp"-i=npf-npf-nv"-/ti/pdk_am335x_1_0_7/packages -/ti/ndk_2_25_01_11 -dweg"-intrab-df-ngm -df-ngm @:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -ex"-df /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -infl"-mf-nvi-t"-dmf-nvi-t"-ex"-dmf -inc:-dmf -inc:-inc:-mf -dmf -mf -dmf -dmf -mf -dmf -intrab-intrab-inc:-inc:-inc:-inc:-infl"-mf -df -mf -df -mf -df -mf -
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_ndk.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_main.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_main.c "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -marm -mfloat-abi=hard -mfpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_test-i"i-mf_intrab-i="c:/ti/pdk_am335x_1_0_7/packages -mf-nom-ex"-mf-nv/cn"/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mfrom-intrab-cn"-cn"-cn"-cn"-cn"-cn-cn-cn-cn-cn-dmfrom-t.c:-cn"-cn"-cn"-cn"-cn"-cn-cn-cn"-cn-cn-cn-tex-cn-cn-tex-cn-cn"-cn"-cn-cn"-cn-cn-cn"-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn @
    subdir_rules.mk:44:目标'eip_main.o'的配方失败
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/device.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/device.c "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dSOC_AM335x -Dicev2AM335x -Dcore0 -dpt_test-i"i-mf-nex-mf-nex"-/ti/pdk_am335x_1_0_7/packages -dwarf"-ex"-c:/ti/ndk_2_25_01_11 -mf-n"-dmf-nex"-ex"-dmf-ngm @:i:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -dmf-ngm -unord"-inc:-ex"-dmf-nex"-ex"-dmf-ngm -dmf-nex"-inc:-ex"-ex"-dmf-ngm -dmf-nex"-dmf-nex"-dmf-ngm:-dmf-nex"/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -dmf-nex"-cn"-dmf-inc:-cn"-dmf-inc:-cn.c:-cn"-
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_main.c:62:65:致命错误:TI/drv/SPI/example/QSPI_flash/src/Flash_s25FL/S25FL.h:无此类文件或目录
    #include
    ^μ A
    编译已终止。
    gmake:***[EIP 主域.o]错误1
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/device.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_tools.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_tools.c "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -marm -mfloat-abi=hard -mfpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_testing -i"i-mfrom"-ex-intrab-/ti/pdk_am335x_1_0_7/packages -i="i /ti/ndk_2_25_01_11 -mf-node-t"-ex-intrab-ex-ex-mf-neg"-ex-ines"-/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -mf-neg"-intrab-ines"-c @:"i-t"-mf-ngmf-intrab-ex"i-t"-ex"-ex-ex-mf-ngmf-influ.c:/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -dmf-neg"-ex"-ex-ex-ex-ex-intrab-ex"-ex-ex-ex-intrab-ex-ex-dmf-ines"--dmf-ines"--dmf-intrab-ex
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_tools.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_utils.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -marm -mfloat-abi=hard -utilpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm -dpt_test-i"i-cn"i-tex"-/ti/pdk_am335x_1_0_7/packages -i="C:i="i-from"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 -intrab"-ex-/ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_utils.c -dempf-nateg"@-ex"-inc:/ti/ndk_2_25_01_11 -mf -mf -intrab-ex"-mf /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -mf -mf -mf -mf"-mf"-unordintrab-ex"-inc:/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -ex-inc:-mf -mf -mf"-mf -mf -mf -mf"-intrab-mf -t"-mf"-t"-intrab-mf -mf -t.c:-mf -mf -mf -mf -mf -
    subdir_rules.mk:72:目标'eip_utils.o'的配方失败
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/hal.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/hal.c "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i"i-mf-nex"-c:/ti/pdk_am335x_1_0_7/packages -dwar"-i-f"-/ti/ndk_2_25_01_11 -mf-ng"-mf-ngm /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -chintrab"-mf-ng"-df-ngm @:-mf-ngm -dmf /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-ng"-dmf-ng"-dmf-ng"-dmf:-mf-ngm -dmf:-chintrab"-cn"-cn"-df-neg"-cn"-cn"-cn"-cn"-cn"-cn"-cn"-cn.cn.cn.cn.cn.cn.cn.cn.cn.cn.cn.cn.cn"-cn.cn.cn.cn
    subdir_rules.mk:79:目标'hal.o'的配方失败
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_utils.c:46:65:致命错误:TI/drv/SPI/example/QSPI_flash/src/Flash_s25FL/S25FL.h:无此类文件或目录
    #include
    ^μ A
    编译已终止。
    gmake:***[EIP 实用程序.o]错误1.
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/AM335x/eip_soc.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/AM335x/eip_soc.c "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -marm -mfloat-abi=hard -mfpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_test-i"i-mfrom"-ex-i="C:/ti/pdk_am335x_1_0_7/packages -intrab-soc"-/ti/ndk_2_25_01_11 -ex-mc"i-tex"-mci-unordintrab-ex"-ex"-ex"-mci-dosc @:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -dosc:-ex-ex"-ex"-mci-dosc:-ex"-ex"-mci-tex-ex"-mci-dosc:-ex"-ex-ex-dosc -dov.c:-intrab-dosc -ex"-ex"-ex"-cn"-cn"-cn.c -cn"-cn.c -cn.c -cn.c -cn.c -cn"-cn
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/hal.c:46:65:致命错误:TI/drv/SPI/example/QSPI_flash/src/Flash_s25FL/S25FL.h:无此类文件或目录
    #include
    ^μ A
    编译已终止。
    gmake:***[hal.o]错误1.
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/AM335x/eip_soc.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c -c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i="C:dicpf-nterm -ex"-/ti/pdk_am335x_1_0_7/packages -dicf"-ex-mf-nterm -/ti/ndk_2_25_01_11 -mf-ngds-unord"-ex-ex-ex"-mf-ngdich-ex"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -dich-intrab-ex-ex-df-ngds-un-df-ngmf /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -df-ngds.com -ex-df-ngdf-ngds.com -ex"-dich-ex-df-nv-ex-df-nvs -df-ngdf-ngdf-ngdf-nvs -ex"-dich-dich-df-dich-dich"-dich-df-nv"@-
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/AM335x/eip_soc.c:在函数'EIP _socHwinIT'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/AM335x/eip_soc.c:85:5:警告:函数'Board_phyReset'的隐式声明[-Wimplice-function-declaration]
    Board_phyReset (2);
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/AM335x/eip_soc.c:在函数'EIP _socgetMACAddress'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/AM335x/eip_soc.c:106:5:警告:函数'OCCtrlGetPortMacAddr'的隐式声明[-Wimplice-function-declaration]
    SOCCtrlGetPortMacAddr (1、lclMac);
    ^μ A
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -mfloat-abi=hard -mpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i="C:ipf_intrab"-ex-mf-nex-mcus.c @:/ti/pdk_am335x_1_0_7/packages -mf-nec_driver -/ti/ndk_2_25_01_11 -/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -cn"-cn"-mcov.c -mf-nec"-cn"-cn"-cn"-cn-cn-cn"-cn"-cn-ov.c:-cn-cn-cn-cn"-ov.c:-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn-cn/sec_decodec/cn"-cn"-cn"-cn"-cn"-cn"-cn"-
    在包含在 C:/ti/ndk_2_25_01_11/packages/ti/ndk/inc/nettools/nettools.h:86:0的文件中、
    发件人:/ti/ndk_2_25_01_11/packages/ti/ndk/inc/_nettool.h:39、
    来自 C:/ti/ndk_2_25_01_11/packages/ti/ndk/inc/netmain.h:40、
    来自 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include/os_inc.h:48、
    发件人:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include/adt_config.h:245、
    从 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include/app_api.h:27、
    来自 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/eip_main.h:40、
    从 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:41:
    C:/ti/ndk_2_25_01_11/packages/ti/ndk/inc/nettools/inc/dnsif.h:54:0:警告:重新定义了"溢出"
    #define overflow 16 /* buffer overflow */
    ^μ A
    在 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include/icss_timeSync.h:17:0文件中、
    来自 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include/icss_eip_driver.h:149、
    从 C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:23:
    C:\ti\gcc-arm-none-eabi-4_9-2015q3\arm-no-eabi\include\math.h:552:0:注意:这是先前定义的位置
    #define 溢出3.
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:在函数'EIP DLR_INIT'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:174:5:警告:函数'addMACID'的隐式声明[-Wimplice-function-declaration]
    addMACID (dlrHandle->dlrEmptyFrame + DLR_SRC_MAC_OFFSET、ifMacID);
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:181:5:警告:函数'addWord'的隐式声明[-Wimplice-function-declaration]
    addWord (dlrHandle->dlrEmptyFrame + DLR_SOURCE _IP_OFFSET、dlrHandle->deviceIP);
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:在函数'EIP DLR_port0ISR'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:402:9:警告:函数'getMACId'的隐式声明[-Wimpliced-function-declaration]
    getMACId ((uint8_t *) wordPtr、actSupAddrPtr->supMACAddress);
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:408:9:警告:函数'ConvBigEndianToLittleEndianWord'的隐式声明[-Wimplice-function-declaration]
    actSupAddrPtr->supIPAddress = ConvBigEndianToLittleEndianWord (
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:在函数'EIP DLR_processDLRFram'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_dlr.c:1458:9:警告:函数'ConvBigEndianToLittleEndianHalfWord'的隐式声明[-Wimplice-function-declaration]
    NumNodes = BigConvendianToLittleEndianHalfWord (dlrSrc +
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c:在函数'eip_drvInit'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c:82:5:警告:函数'Timesync_drvInit'的隐式声明[-Wimplicit-function-declaration]
    Timesync_drvInit (icssEipHandle->timeSyncHandle);
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c:88:5:警告:函数'Timesync_addIP'的隐式声明[-Wimplicite-function-declaration]
    Timesync_addIP (icssEipHandle->timeSyncHandle、
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c:在函数'eip_drvStart'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c:109:5:警告:函数'Timesync_drvEnable'的隐式声明[-Wimplicit-function-declaration]
    Timesync_drvEnable (icssEipHandle->timeSyncHandle);
    ^μ A
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c:在函数'eip_drvStop'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c:129:5:警告:函数'Timesync_drvDisable'的隐式声明[-Wimplicit-function-declaration]
    Timesync_drvDisable (icssEipHandle->timeSyncHandle);
    ^μ A
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/drivers/icss_eip_driver.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/main.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dSOC_AM335x -Dicev2AM335x -Dcore0 -dpt_test-i"i-mfp -i="C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages -dwar"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 -/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include -dc-intrab"-dmf -/ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/main.c -mf /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -mf -mf /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf -mf -mf -unordintrab"-mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf -mf @-
    subdir_rules.mk:100:目标'main.o'的配方失败
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/user_acd_ndk.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe -c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -ndpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i="C:ndcp"-mci-dwap_ex"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm -/ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x -mci-dweg"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 -/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/user_acd_ndk.c -unus.c @:-dac"/ti/pdk_am335x_1_0_7/packages -dk.c -mf-ngd_unus.c:-dam.c -dac"-df /ti/ndk_2_25_01_11 -mf-ngm -mf-ngdf /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -mf /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -md -dac"-mf-ng.c:-mc"-mc"-mf-nd_unus.c:-dam.c -dac"-d_unchintrab-mf -mf -dam.c:-mf -dac"-mf -d_unchinf -dam.c:
    subdir_rules.mk:107:目标'user_ACD_NDK.o'的配方失败
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/main.c:103:65:致命错误:TI/drv/SPI/example/QSPI_flash/src/Flash_S25FL/S25FL.h:无此类文件或目录
    #include
    ^μ A
    编译已终止。
    gmake:***[main.o]错误1.
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_gpioLed.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -pipu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpote_test-i"i-"c:c:c:-mc"-mc"-mc"-mc"-tex-am35x"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -mc"-mf-nateg"-mf-nateg"-tb -ine-tb -am335"-/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-ngi"-b -mf"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"i-tex-mf-nateg"i-tex-mf-nateg"i-tex-mf-nateg"i-tex-/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_gpioLed.c @
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter/user_acd_ndk.c:60:65:致命错误:TI/drv/SPI/example/QSPI_flash/src/Flash_s25FL/S25FL.h:无此类文件或目录
    #include
    ^μ A
    编译已终止。
    gmake:***[USER_ACD_NDK.o]错误1.
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_gpioLed.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_i2cLed.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i"C:"c:c:i_mc"-tex-am35x"-ine-tex-i_i_i_am3mf-nateg"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm -/ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include -mf-nateg"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -mf-nateg"-mf-nateg/i:/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-nateg"-mf-nateg/i_i_i_i_intrab-mf-nateg"i-tex"-ine-tex-am3mf-nateg/i_ine-tex-ine-ine-ine-ine-ine-ine-control-mf-nateg"i-tex-ine-control-mf-nateg"i-tex-ine-control-mf-nateg"-mf-nateg"-in /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_i2cLed.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_i2cLed.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_mcspi.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dspt_test-i"i-"c:c:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm mspi_mc"i-board-/ti/pdk_am335x_1_0_7/packages -mspi_unchine"-mspi_mspi_mc"-intrab-/ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -mspi"-mspi_ine-tex"-mspi_i -mspi_mspi_i -mspi_beg"i-board.c:/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mspi_mspi_mspi_mspi_mspi"-overview"-mc"-mspi_ine-tex-inateg"-mc"-mc"-mc"-ina-mspi_mspi_mspi_mspi_mspi_mspi_intrad /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_mcspi.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_mcspi.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_oled.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dipt_test-i""C:mf-nex"-am35x"-intrad_am/am3mf-nateg"-/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -mf-nateg/am3mf-nateg"-mf-nateg/am3mf-nateg/i:/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-nateg"i-board-mf-nateg/am/am3mf-nateg"-mf-nateg/am/am33v/i:-mf-nateg"i-tex-ine-tex-mf-nateg"i-board-ov-mf-nateg/am3mf-nateg/am/am3mf-nateg/am3mf-nateg"e-tex"-ine-tex-/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_oled.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_oled.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_platform.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -mtp_test-i"i-"c:mfrom-board-/ti/pdk_am335x_1_0_7/packages -intrab-mf-nateg"-mf-nateg"-mf-nateg/i /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep:/ti/ndk_2_25_01_11 -mf-nateg/i -intrab-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg/i:-mf-nateg"i-board.c:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-nateg/am335i-board-mf-nateg"-mf-nateg"-mf-nateg"-intrab-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_platform.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_platform.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_phy.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -mtp_test-i"i-"c:c:mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-intrad-am35x /ti/pdk_am335x_1_0_7/packages -ine-board-am35x -intrad-am335"-am/am-intrab-ine"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 -mf-nateg"-mf-nateg"-mf-nateg"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_phy.c @/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/ndk_2_25_01_11
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_phy.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_spi.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -spi pu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dspt_test-i"i-"c:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep c:-msp"-i_i -dam35x -tex/i -dspi"-/ti/pdk_am335x_1_0_7/packages -intrab/am3mf-nateg"-mf-nateg"i-board.c:-am/am/am335i-t"-mf-nateg/am/i -intrab-mf-nateg/am3mf-nateg/am/am/am/am3mf-nateg"-mf-nateg/am/i:/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-nateg/am/am3mf-nateg/am/i -intrab-mf-nateg/am/am/i -ine-si-tex"-mf-nateg-/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_spi.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/iceAM335x/board_spi.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/board_misc.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -mpt_test-i"i="C:mc"mc"-mc"-mc"-mc"-common -dw_board.c:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages -mce-tex"-mce-tex"-mci-common.c /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00:/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mc"-dmc"-dmc"-mfrom-board.c @:-/ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/board_misc.c -mc"-mc"-mc"-mc"-mc"-unordintrab-t"-t"-t"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mce-
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/board_misc.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/delay_us.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/delay_us.c "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=dam3359 -dsoc_am335x -dicev2am335x -dcore0 -mflo_test-i"i="C:mf_common.c:/ti/pdk_am335x_1_0_7/packages -delive-de-t"-mf-ngmce-d_delay -deleg"-t"-ce-ta-ce-dmce-dmf-ngm -delt"-delay -deleg"-ta-c"i-t"-ta-c"i-ta-ce-ta-ce-tex:/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-ngmce-t"-delta-ce-t"-dmce-ta-ce-t"-delt"-ta-ce-ta-ce-t"-delta-ce-ta-c"i-ta-ce-t"-delta-c"i-ta-ce-ta-ce-ta-ce-t @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/delay_us.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/board_tlkphy.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -tmpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_testing -i"c:tl -i="c:mc"i-common.c:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep tb -mc"e-board/dtrab-df-nateg"-ex"-mfrom.c @:/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mce-board.c -mf-nodr -tex-tex-tb -msp"-tex-mf_unchintrab-msp"-t.c:-mf-nodr -tex-tex-tex-mf-nateg"-mf-nateg"-mf-nateg"-mf-nateg"-tb -mf-nateg"-tb -tb -mf-nateg"-mf-nateg"-mf-n /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/board_tlkphy.c
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/board_tlkphy.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/icss_emac_osal.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_test-i"i-mospu -i=hard -dospu -dac -dac"-mce-dosf"-mce-t"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -ex"-mcrom-inc:/ti/pdk_am335x_1_0_7/packages -intrab-inc:-inc -inc -dac/cn"-mce-tex-dosfrom-inc:/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -intrab-inc:-inc -dos/cn"-dosfrom-inc -inc:-inc -dos/cn"-dos-inc:-inc -ex-dac-ex-inc:-inc -intrab-mce-tex-inc -dos/cn"-dos/cn"-dos /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/icss_emac_osal.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/icss_emac_osal.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/mdio_drv.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i"i-mfrom_common.c:/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mc"i-tex-mc"-mc"-mc"-mc"-mv/mv-mv-mv-mv_unordintrab-drom-ine"-ex-ex"-mc"-mv/mv-mv-mc"-mv-mv-mv-mv-mv-mv-mv-mv-mv-mc"-mv-mv-mf"-mv-mc"-mc"-mc"-mv-mv-unordintrab-intrab-intrab-mc"-mc"-mc"-d /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/mdio_drv.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/mdio_drv.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/osdrv_ndkdeviceconfig.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include -c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -cepu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dctp_test-i"i-c"v_device-dov_ec_decnode-tex"-/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -cn"-cn"-dov-dov_ecnodnodec/cn"-tog/cn"-tog-cn-cn-cn-cn/secdov-dov-dov-cn"-cn/secdov-dov-dov-cn"-cn/secdov-dov-cn/secnodecnodec_dec/cn"-tog/cn"-cn/secdov-tog/cn/secdov-cn/secdov-cn/secnodecnodecnodec/cn"-cn"-cn/secnodecnodecnodecnec /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/osdrv_ndkdeviceconfig.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/board/common/osdrv_ndkdeviceconfig.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/ClockP_tirtos.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -lockpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i"i-cn"i-lockpf-nex"-/ti/pdk_am335x_1_0_7/packages /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -dosf"-tos/cn"-tos-tos-tos -tos -tos -/ti/ndk_2_25_01_11 -tos"-tos -tos -tos -tos.c:i /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -tos"-tos -tos -tos -tos"-tos -tos -tos"-tos -tos -tos"-tos -tos.c -tos -tos -tos"-tex -tida-ci-tos"-tos"-tos -tos -tos"-tos -tos -tos -tos -tina-tos -tos -tos -tos -tina-tos /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/ClockP_tirtos.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/ClockP_tirtos.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/EventP_tirtos.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_testing -i"i:c:tosf/cn"/ti/pdk_am335x_1_0_7/packages /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -tos/i -dosf"-tos -tos/i:/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -tos/i:-dosf"-tos/i:-tosf"-tos -tos -tog.c -tog.c -tos"-tos -tos/i -tog.c -tos -tos -tex-tos -toc.c -tex-tex-tos -tex-tex-tex-tex-toc.c -tos"-toc.c -toc.c -tos -tex-tos -tex-am.c -tos -am.c -tex-am.c /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/EventP_tirtos.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/EventP_tirtos.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/MailboxP_tirtos.c '
    '调用:GNU 编译器'
    "C:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i"C:boxp=none.com /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -dos/dospr-mf-nateg"-dos/dospr-mf-nateg.c @:/ti/pdk_am335x_1_0_7/packages -dos/i /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -dospr-dos/dos/dosf.iptos -mf-nateg"-mf-nategr -mf-nateg"-mf-natrim -mf-nategr -mos-mf-natrim -mf-nategr -m.ti.com.cn -mf-natr -tos -tos -tos -tos -tos -tos -tos -tos -tos -tos -tos -tos -tos -tos -tos -d /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/MailboxP_tirtos.c
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/EventP_tirtos.c:在函数'EventP_getPostedEvents'中:
    C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/EventP_tirtos.c:91:1:警告:控制到达非空函数的末尾[-Wreturn-type]
    ^μ A
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/MailboxP_tirtos.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/SwiP_tirtos.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -swipu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dpt_test-i"C:mospr-i="ce-dos/cn"/ti/pdk_am335x_1_0_7/packages /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -dospr-tos/cn"-dos/dospr-tos/cn"/ti/ndk_2_25_01_11 -dos/cn"-dospr-tos/cn"-dos/cn"-dospr-dos/cn"-dos/cn-dos/cn"-dospr-tos/cn"-dos/cn"-dtos/cn-dos/cn-dtos/dos/cn"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include -dos/dospr-dos/cn"-dos/cn"-dos/cn"-dospr-dos/cn-dos/cn-dos/cn"/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -dtex-dos//ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/SwiP_tirtos.c @
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/SwiP_tirtos.c '
    '生成文件:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/TaskP_tirtos.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mcpu=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_testing -i"i-tos/i /ti/pdk_am335x_1_0_7/packages /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -dosf"-tos/i /ti/ndk_2_25_01_11 -dtos/tos"-tos/i -tos"-dtos -tos"-dtos/i:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -dtos"-tos -tos/i -tog.c -tos"-dtos/i -tos"-dtos"-tos/i -tos"-dtos"-tog.c:-tos/i -tos"-tog.c -dtos"-dtos/i -tog.c -tog.c @-tos -tos"-tos"-dtos/i -dtos/tos"-dtos//ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/TaskP_tirtos.c
    '完成的建筑:C:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/osal/TaskP_tirtos.c '
    '生成文件:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/gpio/soc/am335x/GPIO_soc.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dosc_am335x -dicev2am335x -dcore0 -dtp_test-i""C:mos"-i_mosc -/ti/pdk_am335x_1_0_7/packages -mc"-mc"-mc"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -mosc -mf_unchintrab-mf-nateg"-mf-ngov.c @:/ti/ndk_2_25_01_11 -mf-ngov-mf-nompio.c -mf-ngov.c -mf-ngov.c -mf-ngpio"-mf-nompio"-mf-ngov.c:/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mf-ngpio.c -ex-mf-ngov.c -mf-nompio.c -mf-ngov.c -mf-ngov.c -mf-ngov.c -mf-ngov.c /ti/pdk_am335x_1_0_7/packages/ti/drv/gpio/soc/am335x/GPIO_soc.c
    '完成的建筑:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/gpio/soc/am335x/GPIO_soc.c '
    '生成文件:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/i2c/soc/am335x/I2C_soc.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dosC_AM335x -dicev2AM335x -Dcore0 -dtp_test-i"C:mos"-i_mosc -/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mc"-mc"-mc"-mosc -mc"-mc -mc"-mc -mc"-mc"-mc"-mc"-mc"-mc -mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc -mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"-mc"/ti/pdk_am335x_1_0_7/packages/ti/drv/i2c/soc/am335x/I2C_soc.c @
    '完成的建筑:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/i2c/soc/am335x/I2C_soc.c '
    '生成文件:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/spi/soc/am335x/SPI_soc.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_test-i"C:spi_mos"-i_unchinspi_mspi"-dspi_mc"/ti/pdk_am335x_1_0_7/packages -mc"-mc"-mc"-mos"-mc"-mc"-mc"-mc"-mspi_mc"-mc"-mf_mc"-mc"-mc"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 -mc"-mspi_mf_mc"-mc"-mf_mc"-mf"-mf_mc"-mc"-mc"-mc"-mc"-mc"-mc"-mf_mc"-mf"-mf_mf_mf_mf_/ti/pdk_am335x_1_0_7/packages/ti/drv/spi/soc/am335x/SPI_soc.c @/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/ndk_2_25_01_11
    '完成的建筑:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/spi/soc/am335x/SPI_soc.c '
    '生成文件:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/uart/soc/am335x/UART_soc.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/pdk_am335x_1_0_7/packages /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include "-c -mcpu=cortex-A8 -mtun=cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dsoc_am335x -dicev2am335x -dcore0 -dtp_test-i""C:i_mos"-/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm -mc"-mc"/ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep -mosc -mc"-mc"-mc"-unchintrab-mc"-mc"-mos"-mu.c -mu.c -mu.c -mc"-mc"-mu.c -mu.c -mc"-mu.c -mf_unchintrab-inc -dus.c -intrab-dus.c -am/am3v-am.c -am/nateg"/ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -am.c -am.c -am/am.c -unchinc -am.c -am.c -am.c -am.c /ti/pdk_am335x_1_0_7/packages/ti/drv/uart/soc/am335x/UART_soc.c @
    '完成的建筑:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/uart/soc/am335x/UART_soc.c '
    '生成文件:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/icss_emac/soc/am335x/icss_emacSoc.c '
    '调用:GNU 编译器'
    "ctex-a8=cortex-a8=cortex-a8=armv7-a /ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe -marm -float abi=hard -mpu=neon -Dam335x -evm2am35x -dcoreexTp_testing -"c:c:mcus-inc -inc /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm -inc -inc:-inc -inc -inc -inc -inc -inc -inc:-inc -inc -inc /ti/pdk_am335x_1_0_7/packages -inc -inc -ex-inc -inc -inc -inc -inc -inc -inc -inc -mc -am335c /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x -ex"-inc -inc -inc -mc -inc -inc -mf -mc -inc -mc -inc -inc -inc /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 -inc -mc -inc -inc -mc -inc -inc /ti/ndk_2_25_01_11 -mf -inc -mc -am33c -inc -inc -inc -inc /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter -inc -inc -mf -am /ti/pdk_am335x_1_0_7/packages/ti/drv/icss_emac/soc/am335x/icss_emacSoc.c @/ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include
    '完成的建筑:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/icss_emac/soc/am335x/icss_emacSoc.c '
    '生成文件:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/pruss/soc/am335x/pruicss_soc.c '
    '调用:GNU 编译器'
    "c:/ti/gcc-arm-none-eabi-4_9-2015q3/bin/arm-none-eabi-gcc.exe /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/projects/ethernetip_adapter_AM335x_arm /ti/pdk_am335x_1_0_7/packages/ti/starterware/include/am335x /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/examples/ethernetip_adapter /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/protocols/timeSync/include -c -mcpu=cortex-A8 -mtune =cortex-A8 -March =armv7-a -mfloat-abi=hard -mfloat=neon -Dam3359 -dsto_-dmsoc_am335x -dicev2am335x -dcore0 -dtp_test-i"c -i"c:c -i_prpf-nosc -ab"-/ti/pdk_am335x_1_0_7/packages /ti/ndk_2_25_01_11 /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ethernetip_adapter/include /ti/PRU-ICSS-EthernetIP_Adapter_01.00.02.00/third_party/protocols/ptp/ptpd/dep /ti/gcc-arm-none-eabi-4_9-2015q3/arm-none-eabi/include -mc"-mc"-mc"-mc"-mc"-mc"-mc"-unicnec"-intrab"-mos"-mc"-mc"-mc"-mc"-mos"-mc-mc-mce-dus.c:-mc-ine-dus.c -amus.c -am335"-intrab"-intrab"-mc"-ine-dus.c:-mf-nich-mc"-mf-nec"-mc"-mf-nich-am /ti/pdk_am335x_1_0_7/packages/ti/drv/pruss/soc/am335x/pruicss_soc.c @
    '完成的建筑:C:/ti/pdk_am335x_1_0_7/packages/ti/drv/pruss/soc/am335x/pruicss_soc.c '
    gmake:目标"全部"不会由于错误而重新生成。
    ****构建完成****
    我已经使用 CCS 7.1.0.00016编译了 PRU-ICSS-EthernetIP_Adapter_01.00.02.00 、但无法编译。
    再次提前感谢。
    Ashok Wakode
    您好、Ashok、请检查您是否正在属性->常规-> RTSC 以及属性->编译->变量中使用 PDK 1.0.6
    构建错误似乎是由于到 S25FL.h 的路径错误造成的、如下所示:
    #IF SPI_DRV_VERSION_ID =(0x01000006)
    #include
    其他
    #include
    #endif
    如果您使用 PDK 1.0.6、则路径应为#include ,您的应用程序应正确构建。
    Paula
