[参考译文] Linux/processor-SDK-AM335X:需要有关使用最新 SDK 编译和调制及引导 Beage Bone 的帮助
Guru**** 2589280 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/625080/linux-processor-sdk-am335x-need-help-on-compiling-and-modfying-and-booting-the-beage-bone-using-latest-sdk
器件型号:PROCESSOR-SDK-AM335X
工具/软件:Linux
你(们)好
我能够使用最新的 SDK ti-processor-sdk-linux-am335x-evm-04.00.00.04-Linux-x86-Install.bin 启动 Linux
 我已经按照步骤安装 SDK、但现在需要修改内核、ROOTFS 和最新 SDK 以及编译和闪存中的某些配置
请就此提供帮助。
    大家好、团队我已经按照以下链接构建了 SDK
    下面是我所面临的错误
    错误:任务(虚拟:本机:/home/deepak/Desktop/latestsdk/tisdk/sources/oe-core/meta/recipes-extended/unzip/unzip_6.0.bb
    /run/user/1000/keyring-RmBcOW/ssh /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/am335x-evm/usr/bin/crossscripts /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/sbin /../gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin /home/deepak/Desktop/latestsdk/tisdk/sources/bitbake/bin /usr/local/bin /usr/games /home/deepak/Desktop/practical_tech_veda/buildroot-2017.02/output/host/usr/bin:do_fetch)失败、退出代码为"1"警告:linux-libc-headers-4.9-r0.arago2 do_fetch:无法获取 URL git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol=git;branch=ti-lsk-linux-abstract.y;如果可用、尝试镜像错误:linux-libc-libc-dock-out_export=/home/deepak/Desktop/latestsdk/tisdk/sources/oe-core/scripts:/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/sbin:/tmp/dbus-HYqUpJpIsQ:/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/bin:/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin/arm-linux-gnueabi:/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/bin:/home/deepak/Desktop/latestsdk/gcc-linaro-6.2.1-2016.11-x86_64_arm-linux-gnueabihf/bin:rfocture=/home/deepak/Desktop/latestsdk/tisdk/sources/oe-core/scripts:/home/deepak/bin:/usr/sbin:/usr/local/games:/home/deepak/Desktop/latestsdk/tisdk/sources/meta-browser/scripts:/home/deepak:/usr/local/sbin:rgobture=;/usr/bin /home/deepak/Desktop/practical_tech_veda/buildroot-2017.02/output/host/usr/bin::::rgot.fortexport.fortis.fortes=::::rgest_gest_rgest.fordure= lang=C git -c core.fsyncodojectfiles=0 fetch -f --prune --progress git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git refs/*:refs/*失败,退出代码128,输出:
    remote:计数对象:7356377,完成。
    远程:压缩对象:100%(1035155/1035155),完成。
    致命:读取错误:连接超时、5.75 MIB | 10.00 KiB/s
    致命:EOF 早期
    致命:索引包失败
    错误:linux-libc-headers-4.9-r0.arago2 DO 获取:URL 的 fetcher 失败:'Git://git.ti.com/ti-linux-kernel/ti-linux-kernel.git;protocol =git;branch=ti-lsk-linux-4.9.y'。 无法从任何源获取 URL。
    错误:linux-libc-headers-4.9-r0.arago2 do_fetch:功能失败:base_do_fetch
    错误:存储在以下位置的故障日志文件:/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/linux-libc-headers/4.9-r0.arago2/temp/log.do_fetch.5402
    错误:任务(/home/deepak/Desktop/latestsdk/tisdk/sources/meta-arago/meta-arago-distro/recipes-kernel/linux-libc-headers/linux-libc-headers_4.9.bb:do_fetch)失败、退出代码为"1"
    注意:任务摘要:已尝试477个任务、其中471个任务不需要重新运行、3个任务失败。
    摘要:3个任务失败:
    /home/deepak/Desktop/latestsdk/tisdk/sources/oe-core/meta/recipes-devtools/perl/perl-native_5.22.1.bb:DO 提取
    虚拟:本机:/home/deepak/Desktop/latestsdk/tisdk/sources/oe-core/meta/recipes-extended/unzip/unzip_6.0.bb:DO 提取
    /home/deepak/Desktop/latestsdk/tisdk/sources/meta-arago/meta-arago-distro/recipes-kernel/linux-libc-headers/linux-libc-headers_4.9.bb:DO 提取
    摘要:显示了3条警告消息。
    摘要:显示了9条错误消息、返回非零退出代码。
    Deepak@Deepak-VGN-N31S-W:~/Desktop/latestsdk/tisdk/build
    我发现类似错误、请提供帮助
    谢谢你
    Deepak R
    Deepak、您好!
    我可以在终端上使用"git cloning"命令克隆 Linux 内核源代码。 您能否将您的配方中的"git://"替换为"http://"、并查看是否通过?
    Prabhuraj
    Black胡椒 技术
    你好 Prabhu
    您能不能告诉我在运行 bitbake 命令时必须修改的文件、如所示
    机器= 比特烘烤
    如何及在何处将"git (git)"替换为"http"
    谢谢你
    Deepak R
    Deepak、您好!
    您能否打开这个 bb 文件并让我们看看它是否尝试获取 Linux 4.9源代码?
    如果不是上述文件、则您的目录中的类似 bb 文件将执行此操作。
    请告诉我您的观察结果。
    Prabhuraj
    Black胡椒 技术
    您好!在安装 SDK 或编译 SDK 以检查文件后、您可以帮助了解此 Linux ROOTFS 和 uBoot 的源代码
    注:执行 RunQueue 任务
    错误:linux-libc-headers-4.9-r0.arago2 do _fetch:URL:'git.ti.com/.../ti-linux-kernel.git;protocol=git;branch=ti-lsk-linux-4.9.y' 具有无效参数。 无效协议-如果要使用 http 从 git 存储库中获取、则需要使用 git://前缀 with protocol=http
    错误:linux-libc-headers-4.9-r0.arago2 DO:function failed:base_do:fetch
    error:Logfi
    你(们)好
    如  上所述、我将"git://"更改为"http://"
    Deepak、您好!
    您能告诉我您正在为构建执行什么命令吗?
    即,machine= 比特烘烤
    什么是目标配置和构建配置?
    Prabhuraj
    Black胡椒 技术
    Deepak、您好!
    我根据 wiki 页面在我的 PC (Ubuntu 14.04 LTS)中设置 Processor SDK Yocto 环境。
    我能够成功运行 bitbake 并编译 linux-libc-headers。
    我使用 的是 MACHINE=AM335x-EVM bitbake Arago-core-tisdk-image 命令
    我已经附加了一个在 Linux-lib-header 获取即将完成时拍摄的图像。 我可以看到它也会进行编译、配置、打包和安装。
    只需检查您的环境中是否启用了防火墙或其他功能。
    Prabhuraj
    Black胡椒 技术
    你(们)好
    Prabhu
    我将检查并更新您、您能否在编译时还指向内核和 RFS 的源代码、以便添加打印件并检查进一步调试
    模块的启用和禁用
    感谢您的支持
    Deepak R
    Deepak、您好!
    我刚才按照处理器 SDK 中提到的步骤操作、可以编译 Yocto。 供参考:首次构建 Yocto 时,内核和 rootfs 源代码及其依赖项将从远程服务器获取并构建。 只有这样,您才能调试内核和 rootfs 等。
    Prabhuraj
    黑胡椒技术
    你(们)好
    Deepak@Deepak-VGN-N31S-W:~/Desktop/latestsdk/tisdk/build sudo ufw status
    :Inactive
    Deepak@Deepak-VGN-N31S-W:~/Desktop/latestsdk/tisdk/build Deepak
    @Deepak-VGN-N31S-W:~/Desktop/latestsdk/tisdk/build machines=AM335x-EVM bake Arago-core-blayers
    已自动更新备注:bittisdk-dk-ybak-bak-bagdk-dk-yers 已自动更新。
    注意:您的 conf/bblayers.conf 已自动更新。
    正在加载高速缓存:100%|################################ |时间:0:00:03
    从相关性高速缓存加载了3236个条目。
    解析配方:100%|################################################################################################################ |时间:0:01:37
    解析2488 .bb 文件完成(2081缓存、407解析)。 3236个目标、534个跳过、0个屏蔽、0个错误。
    注意:解决任何缺失的任务队列相关性
    生成配置:
    BB_VERSION ="1.32.0"
    BUIL_SYS ="x86_64-Linux"
    NATIVELSBSTRING ="Ubuntu-14.04"
    TARGET_SYS ="arm-linux-gnueabi"
    机器 ="AM335x-EVM"
    发行版 ="Arago "
    distro_version ="2017.05"
    tune 特性 ="arm armv7a VFP thumb NEON callconvention-hard"
    target_FPU ="硬"
    meta-processor-sdk ="头:3d2f620a6a98b1b6abb1103d7dc986921436ed19"
    meta-arago-distro
    meta-arago-ado-ado-extras ="头:b727bf8fce8e9cb5a6b5b5b5b48c45008853
    meta-ebrowser。 ="标题:880a7bd1d3b9a1b2003f5b0620350f03158bbd43"
    meta-qt5 ="标题:3601fd2c5306ac6d5d0d536e0be8cbb90da9b4c1"
    meta-networking
    meta-ruby
    Meta-python
    Meta-OE
    元- gnome ="标题:fe5c83312de11e80b85680ef237f8acb04b4b26e"
    meta-ti ="标题:41d6fdc0fe5ea6054616cfccda13baac3ff33791"
    meta-linaro-toolchain
    meta-optee. ="head:d84874bad834657dd04ea69c35a74dd9dbd535b8"
    meta ="head:ddf907ca95a19f54785079b4396935273b3747f6"
    初始化任务:100%|#################################################################################### |时间:0:01:31
    注意:正在执行 SetScene 任务
    注意:正在执行 RunQueue 任务
    当前2个正在运行的任务(8106的493个) 6%|#### |0
    :linux-libc-headers-4.9-r0.arago2 do_fetch (pid 4646) 98%|########################################################################## |
    1:nativesdk-linux-libc-headers-4.9-r0.arago2 do_fetch - 13027s (pid 23486)
    回溯(最近一次调用最后一次):
    文件"/home/deepak/Desktop/latestsdk/tisdk/sources/bitbake/bin/bitbake-worker、第465行、位于中
    worker.serve ()
    文件"/home/deepak/Desktop/latestsdk/tisdk/sources/bitbake/bin/bitbake-worker,第372行,服务中
    self.build_Pipelines[pipe].read()
    文件"/home/deepak/Desktop/latestsdk/tisdk/sources/bitbake/bin/bitbake-worker,第309行,读
    Worker_Fire_prepickled (self.queue[:index+8])
    文件"/home/deepak/Desktop/latestsdk/tisdk/sources/bitbake/bin/bitbake-worker、第78行、位于 Worker_Fire_prepickled 中
    Worker_queue.put (event)
    文件"/usr/lib/python3.4/queue.py、第148行、输入 Put
    self.not_empty.notify ()
    文件"/usr/lib/python3.4/thrCurrently 2正在运行的任务(8106的493) 6%|###### 错误:工作人员进程(4632)意外退出(0),正在关闭...
    警告:/home/deepak/Desktop/latestsdk/tisdk/sources/bitbake/lib/bb/runqueue.py:1071:ResourceWarning:未关闭的文件 <_io.BufferedWriter name=30>
    self.worker ={}
    注意:任务摘要:已尝试491个任务、其中476不需要重新运行、全部成功。
    摘要:显示了1条警告消息。
    摘要:显示了2条错误消息、返回非零退出代码。
    @Deepak
    @Deepak-VGN-N31S-W:~/Desktop/latestsdk/tisdk/build $ Deepak@Deepak-VGN-N31S-W:~/Desktop/latestsdk/tisdk/build Deepak-Vepak-N Deepak-Vepak
    再次尝试编译如果遇到这种情况、请告诉我
    Deepak、您好!
    我没有遇到这种错误。 实际上、我的构建在第二天继续进行、而您遇到了 kernel-libc-头文件获取问题。 但是、您是否有机会对任何配方进行了修改?
    请告诉我。
    Prabhuraj
    Black胡椒 技术
    你好 Prabhu
    我不确定我使用的命令有什么错误
    | x86_64:linux-libtool:link:gcc -std=gnu99 -fsigned char -fno-common -Wall -Werror=sequence-exuse-declarations -wmission-parameter-type -wmission-copys-wness-field-initiatilers -wdles=seque-wsign-compare -wlos-wlus-wlus-wlus-wlus-wlus-rwlus-rwlus-out-rwlwlwlf-nest-out-rwlwf-nest-参数-rwlf-nest-rwl -rwlf-nest-r-rwl -rwl -rwlf-nest-r-rwl -rwlot-rwlot-wlf-nest-r-r-rwf-nest-r-rwlf-nats-rwlf-nest-r-rwl -r-rwl -r-rwlf-nest-r-rwl /.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib -
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexce-lmissions-parameter-type -Wmission-wny-field-initializers -wredunder-decls -wsign-compare -wlype-wuninitialized -wluser-wloffer-parameter-wlots-wlots-winn -wlow-enchain -wlow-energy/wlus-rwlus-rwlus-r-rwlus-rwlow-logine-r-r-rwl -r-rwlus/rwlus-r-r-r-rwf-ness-rwlus-rwlus-r-r-rwlus-r-r-rwlus-r-r-rwlus-rwlus-r-r-rwlus-r-r-r-rwlus/r-r-r-r-rwlus-rwlus-/.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    mode=link gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexuse-limitations -Wmission-parameter-type -Wmission-wno-mission-field-tisdilers-wdless-decls -wsign-limits -wtype-limits -wunusr -linux/latest/usr outlinest-out-rusr -outlinest/usr -outlinest/usr -r-r-linux-outr/ outr-r-outr-r-r-linux-outr/usr -outr-outr-linux-outr/outr-outr/outse-r-r-linux-outr-r-outr-outr-r-linux-outr/outseptex-r-buildc/-outse-remi/tex-linux-out-out-out-r-out-out-r-r-r-r-r-r-r-r-r-linux/out-/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexce-lmissions-parameter-type -Wmission-wn-timplains-field-initializers -wredunder-decls -wsign-compare -wuninitialized -wluser-wloffer-parameter-wlote-wlots-wlow-enchain -wlow-out-wlow-enchain -wlow-out-rwlow-enchain -wlow-out-wlow-enchain -wlf-nwlow-enchain -wlow-enchain -wlf-nwlow-out-rwlow-enchain -wlow-out-wlow-out-wlf-nwlf-nwlow-enchain -out-wlf-nwlf-nwlf-nwl -out-out-rwless-out-rwlf-nwlf-nwl -out-out-out-out-out-out-/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexte- Wmission-parameter-type -Wmission-trun-wness-field-initializers -wredunder-decls -wsign-compare -wlype-wuninitialized -wlwlwlwlwlwlwl-trade-wlwlwlwlwl-trads-unuser-trade-wlwlwl -out-rwlwl-trade-wlwl -rwldr -rwldr -rwfr -r-r-rwfunusr -r-r-r-r-rwlwfunusr -r-r-rwfunusr -r-r-r-r-rwfunus/r-r-r-rwl-trad-rwfunusr -r-r-r-r-r-wfunusr -r-r-r-r-/.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexce-lmissions-parameter-type -Wmission-wny-find-field-initializers -wredunder-decls -wsign-compare -wuninitialized -wluser-wloffer-parameter-wlote-wlots-wlow-rwlow-rwlow-gh/wlund-rwlots-rwlf-nest-r-rwl -rwlf-nest-r-rwl -rwlf-ness-rwl -r-rwl -r-rwl -rf-nest/r-rwlotr-r-r-r-rwl -rwlf-nest-r-rf-ness-rwlf-ness-rf-nest/wl -r-rf-nest-r-r-r-r-rf-nest/r-r-rf-nest-rf-nest-/.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexte- Wmission-parameter-type -Wmission-parents-wness-field-initiatilers -wredunder-decls -wsign-compare -wuninitialized -wluser-wloffer-parameter-wland-wlow-tradese-wlover-trade-wlow-tradese-wless-wl -wlover-tradese-wlow-trade-wless-out-wless-wl -wless-wlow-tradese-wless-wless-wless-wless-wless-wless-wf-test/wless-wless-r-r-wlover-trand-wless-wless-wless-wless-r-wless-trad-r-wless-r-wf-test-r-r-wless-/.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexce-lmissions-parameter-type -Wmission-wny-field-initializers -wredunder-decls -wsign-compare -wtype-limits -wuninitialized -wluser-wloffer-trade-wlots-wlow-trade-wlow-tradem-wlus/wlow-tradem-wlus-wfs-wlus-rwlus-wlus-wlus/rwlow-gh/rwlus-r-rwfs-r-r-rwfs-r-rwfs-r-rwfs-rwlus-rwfs-rwlus-r-r-rwlf-nest-r-r-rwfs-r-r-rwfs-r-rwfs-r-rwfs-r-rwlf-nest/r-rwfs-rwfs-/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexcluse-declarations -Wmission-parameter-type -Wmission-wny-field-initializers -wredunder-decls -wsign-compare -wuninitialized -wluser-wluser-wless-wlotrwlbut -rwlus-rwlus-rwluser-th-rwlusr -r-r-rwlusr -r-r-rwlusr -r-rwlusr -r-r-rwlusr -r-r-r-rwlusr -r-r-rwlusr -r-r-rwlusr -r-r-r-rwlusr -r-r-r-rwlusr -r-r-r-rwlusr -r-r-r-r-rwlusr -rwf-ness-r-w /.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    Tag=CC --mode=link gcc -std=gnu99 -fsigned char -fno-common -Wall -Werror=sequence-point -Wexuse-declarations -Wmission-parameter-type -Wmission-pinchant样本-wno-mission-field-initializers -wredund-sequate-compare -wtype-wtype-wtype-wdc/example-linux-rontined -out-rents/wak/outlinest-out-linux-out-outse-rents/r-out-r-r-r-rus/west-outse-r-r-r-r-r-linux-outse-linux/outse-r-r-outse-r-out-r-r-r-r-r-r-outseptis/out-r-linux-out-out-r-r-r-r-out-r-r-r-r-r-r-r-r-r-r-r-out-r-r-r-linux//home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexce-lmissions-parameter-type -Wmission-wne-trade-initiatilers -wredunder-decls -wsign-compare -wuninitialized -wluser-wloffer-parameter-but -wwluser-trade-wless-wlow-trade-wlow-trade-wless-wlow-trade-wless-wlow-trade-wless-wlow-gh/rwless-rwless-rwlf-ness-rwless-rwless-wl -rwless-rwless-wfs-rwfs-rwfs-rwlf-ness-rwl -trad-wfs-rwfs-rwlf-ness-rwlese-trad-wfs-r-wfs-r-wl -wlese-wfs-rwfs-/.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexce-lmissions-parameter-type -Wmission-wne-trade-initiatilers -wredunder-decls -wsign-compare -wuninitialized -wluser-wloffer-parameter-wlots-wlots-wlow-trade-wlow-trade-wfs-unuse-wfs-rwless-rwlow-trade-wfs-rwlow-gh/wlf-ness-rwl -rwfs-rwlf-nest-rwlf-ness-rwfs-rwlf-ness-rwl -rwfs-rwfs-rwfs-rwfs-rwlf-nest/rwl -rwfs-rwfs-r-r-rwfs-r-rwfs-r-rwlf-nest-r-r-rwfs-rwlf-nest/r /.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    mode=link gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexuse-limits-Wmission-parameter-type -Wmissing-trains-wno-mission-field-tisdilers-wdlpad/latest/exitude/usr-outlinest/r-linux-outr-outr/linux-outr-outr/outr-r-roots/r-linux-outr-outr-outr-root/outs/secure-linux-outr-buildc/remed/outs/secure-outr-r-r-r-r-linux-outr-outr-r-r-r-r-r-r-r-linux/outr-r-r-r-r-outr-linux-outr-outr-r-r-r-r-r-r-r-r-r-r-r-r-r-linux/outr-r-r-r-r-r-r-r /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    ip./util-linux-2.28.1 -include config.h -I.../util-linux-2.28.1/include -dlOCALEDIR=\"/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/locale -D_path_LOCALSTATEIR="\"/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/var -isch/deepak/Desktop/latestsdk/build/aret-unus-outhere-wranded 参数-west-wrand-wak-west-out-wrand-west-out-wrand-wrand-west-west-out-out-out-wrand-wrand-west-out-wrand-west-out-out-wrand-wrand-west-out-west-out-out-out-out-wrand-wrand-west-out-out-out-out-wrand-wrand-west-west-out-out-out-out-out-out-out-out-out-out-out-out-out-out-out-out-out-out-wr-out-out-out-wrand-w
    gcc -std=gnu99 -fsignated_char -fno-common -Wall -Werror=sequence-point -Wexce-lmissions-parameter-type -Wmissions-wny-mission-field-initializers -wredunder-decls -wsign-compare -wuninitialized -wluser-wloffer-parameter-but -wluser-wlow-out-wlusr -rwlow-gh/rwlow-out-rwlow-gh/wlf-ness-wless-r-rwl -r-rwlf-ness-rwlf-ness-rwlf-ness-wlf-ness-wlf-ness-rwlf-ness-rwlf-ness-rwl -rwlf-ness-wlf-ness-wlf-ness-rwl -out-r-r-wl -r-wl -r-r-r-wlf-ness-r-wlf-ness-r-wlow-/.libs/libcommon.a /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib /home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib
    ip./util-linux-2.28.1 -include config.h -I.../util-linux-2.28.1/include -dlOCALEDIR=\"/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/share/locale -D_path_LOCALSTATEIR="\"/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/var -ischa/deepak/desktop/latestsdk/build/aret-unus-outhere-wranded 参数-west-wrand-west-wak-out-wrands -west-out-west-outrand-wrand-west-west-out-wrand-west-out-out-wrand-out-wrand-west-out-out-wrand-wrand-west-west-out-out-out-out-out-out-out-wrand-wrand-out-wrand-west-out-out-out-out-out-out-out-out-out-wrand-out-wrand-out-wrand-out-wr-out-out-wr-out-out-out-wrand-out-
    /usr/include/x86_64-linux-gnu/sys/syscall.h
    ‘./util-linux-2.28.1/schedutils/chrt.c:63:|./util-linux-2.28.1/schedutils/chert.c:in function‘ssched_setatpid’:|./util-linux-2.28.1/schedutils/schet.c:in function | schattr_setrpid’(r_setr_):17
    :sr:r_retured flags (s/schetr_r_r_r_trs:s/schetr_r_r_r.c:
    ‘|./util-linux-2.28.1/schedutils/chrt.c:88:17:注意:每个未声明的标识符只报告一次,显示在|./util-linux-2.28.1/schedutils/chert.c 中:在函数‘sched_getattr’中:|./util-linux-2.28.1/schetides/sched/getattrles:r.c
    中:unders/schattrl tres/schdured_getr.trl
    ^|./util-linux-2.28.1/schedutils/chrt.c:in function‘s
    ‘s
    ^ sched_setattr’:|./util-linux-2.28.1/schedutils/util.c:89:1:warning: control reaches end of non-schettrattr[-return-type ]||.util-linux-2.981./util:/util.intr:[2.dutr.tr:/util:/es:/getr.true1.dutr.tr:2.1]|.tr.tr.tr.true/es:/udetc.ines:[2.tudet.tr.tr.tr.tr.tr.tr.tr.tr.tr.tr:/es/set.tr.tr.true/es/set.tr.tr.tr.tr.tr.tr.true/udet.tr.tr.tr.tr.tr.tr.tr.tr.tr.tr.
    ***正在等待未完成的作业
    | make[2]:离开目录`/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/util-linux-native/2.28.1-r0/build
    | make[1]:***[all-recursive]错误1
    | make[1]:离开目录`/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/util-linux-native/2.28.1-r0/build
    | make:***[All]错误2
    |警告:从 shell 命令退出代码1。
    |错误:函数失败:do_compile (日志文件位于/home/deepak/Desktop/latestsdk/tisdk/build/arago-tmp-external-linaro-toolchain/work/x86_64-linux/util-linux-native/2.28.1-r0/temp/log.do_compile.5377)
    错误:任务(虚拟:本机:/home/deepak/Desktop/latestsdk/tisdk/sources/oe-core/meta/recipes-core/util-linux/util-linux_2.28.1.bb:do_compile)失败、退出代码为"1"
    注意:任务摘要:尝试执行636项任务、其中633项不需要重新运行、1项失败。
    摘要:1个任务失败:
    虚拟:本机:/home/deepak/Desktop/latestsdk/tisdk/sources/oe-core/meta/recipes-core/util-linux/util-linux_2.28.1.bb:DO 编译
    摘要:显示2条错误消息、返回非零退出代码。
    您能帮您成功编译吗
    谢谢你
    Deepak R
    Deepak、您好!
    在出现此错误之前、您要执行多少个任务? 对我来说、我可以编译 linux-libc、它会一直运行到~1000个任务、我将其终止、因为我只想为您测试 libc。
    如果您正在构建的环境有任何依赖关系、请检查该环境。
    我将再次触发我的 PC 上的构建以查看。
    请告诉我您的观察结果。
    Prabhuraj
    Black胡椒 技术
