[参考译文] RTOS:RTOS 上缺少 Open CL 库问题
Guru**** 2999690 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/663105/rtos-missing-open-cl-library-problem-on-rtos
工具/软件:TI-RTOS
在 VSDK 3.1中启用 OpenCV 并在下面附上.mk 文件时、我收到此错误。 如何解决此问题。
/home/a0756912/OCL_Release/ti-opencl/packages/ti/opencl/configuration.c:36:对`ti_OpenCL_OpenCL_computeUnitList (void) const'的引用未定义
C:/processor_sdk_vision_03_01_00_00/vision_sdk/。/ti_components/open_comput/OpenCL_rtos_am57xx_01_10_00/packages/ti/OpenCL/packages/lib/ti.OpenCL/configuration.oa15CL:in function `ti_Openfg_get_global_get_ocl':
/home/a0756912/OCL_Release/ti-opencl/packages/ti/opencl/configuration.c:41:对`ti_OpenCL_OpenCL_OCL_global_base (void) const'的引用未定义
C:/processor_sdk_vision_03_01_00_00/vision_sdk/。../ti_components/open_comput/OpenCL_rtos_am57xx_01_10_00/packages/ti/OpenCL/packages/lib/ti.OpenCL/configuration.oa15CL:in function `ti_Openfg_get_global_len_en_get_en_enue_enue_enue_enuest_enuation':
/home/a0756912/OCL_Release/ti-opencl/packages/ti/opencl/configuration.c:46:未`对 ti_OpenCL_OpenCL_OCL_global_len (void) const'的引用
C:/processor_sdk_vision_03_01_00_00/vision_sdk/。/ti_components/open_comput/OpenCL_rtos_am57xx_01_10_00/packages/ti/OpenCL/packages/lib/ti.OpenCL/configuration.oa15CL:in function `ti_OpenCL_hofg_st_get_stfg_oc':
/home/a0756912/OCL_Release/ti-opencl/packages/ti/opencl/configuration.c:51:未`对 ti_OpenCL_OpenCL_OCL_HOSTPROG_base (void) const'的引用
C:/processor_sdk_vision_03_01_00_00/vision_sdk/。/ti_components/open_comput/OpenCL_rtos_am57xx_01_10_00/packages/ti/OpenCL/packages/lib/ti.OpenCL/configuration.oa15CL:in function `ti_OpenCL_get_stfg_en_ot_stlen':
/home/a0756912/OCL_Release/ti-opencl/packages/ti/opencl/configuration.c:56:未`对 ti_OpenCL_OpenCL_OCL_HOSTPROG_len (void) const'的引用
C:/processor_sdk_vision_03_01_00_00/vision_sdk/../ti_components/open_comput/OpenCL_rtos_am57xx_01_10_00/packages/ti/OpenCL/packages/lib/ti.OpenCL/configuration.oa15CL:in function `ti_Openfg_local_get_ocl':
/home/a0756912/OCL_Release/ti-opencl/packages/ti/opencl/configuration.c:61:未`对 ti_OpenCL_OpenCL_OCL_LOCAL_BASE (void) CONST'的引用
C:/processor_sdk_vision_03_01_00_00/vision_sdk/。../ti_components/open_comput/OpenCL_rtos_am57xx_01_10_00/packages/ti/OpenCL/packages/lib/ti.OpenCL/configuration.oa15CL:in function `ti_Openfg_local_get_len_get_cl':
/home/a0756912/OCL_Release/ti-opencl/packages/ti/opencl/configuration.c:66:对`ti_OpenCL_OpenCL_OCL_local_len (void) const'的引用未定义
e2e.ti.com/.../rules_5F00_a15.mk.txt
    我已将您的问题转交给 OpenCL 专家。
    Yordan
    请问您在此处尝试集成/测试什么?
    此致、Shiju
    我尝试在 vsdk 中使用 OpenCV。 但我无法构建它
    您是否尝试使用 VSDK 的现有功能或尝试添加/修改任何新功能?
