[参考译文] Linux/AM3352:内核操作系统(AM3352、内核3.14.26–SDK Linux 01.00.00.03)
Guru**** 2589245 points
Other Parts Discussed in Thread: TPS65910
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/610137/linux-am3352-kernel-oops-am3352-kernel-3-14-26-sdk-linux-01-00-00-03
器件型号:AM3352
主题中讨论的其他器件:TPS65910
工具/软件:Linux
大家好、团队、
我的客户已开始在其应用程序中遇到内核错误(示例如下):
[1][33147.453037]无法处理虚拟地址482d030a 上的内核分页请求
[1][33147.453061] PgD = dcc000
[1][33147.453069][482d030A]* PgD=00000000
0>[33147.453088]内部错误:Oops:5 [#1] ARM
7>[33147.453097]链接到的模块:crash_dump (O) mcs7830 dm9601 XT_limit FTDI_SIO XT_conntrack usbserial IPT_reject XT_connlimit Tun XT_tcputcpip plnetemu (O) iptable_NAT power_mon (O) NL_connfrack_ipnfrack_ipnfrack_nv4_ipt_ipt_ipt_ipt_nfrack_iptablet nv4_iptables_nfrack_iptablet nip
<7>[33147.453158] CPU:0 PID:2166 Comm:addax2ip 被污染:G          O 3.14.26RTR8A+#147
<7>[33147.453169]任务:ddec2000 ti:dcd00000 task.ti:dcd00000
7>[33147.453198] PC 处于数据报_poll+0xdc/0xf0
<7>[33147.453220] LR 处于 UDP_POL+0x18/0x5c
7>[33147.453231] PC:[ ]   LR:[ ]   PSR:20090093
7>[33147.453231] sp:dcd01ab0 IP:dcd01ac8 fp:dcd01ac4
7>[33147.453241] R10:00000008 R9:00000007 R8:00000304
7>[33147.453250] r7:00008000 R6:dccc5300 R5:dd341b40 R4:dc9b5080
7>[33147.453259] r3:482d0302 r2:20090013 r1:2054534f r0:00000049
<7>[33147.453270]标志:nzCv 在  模式 SVC_32 ISA ARM 段用户上关闭 FIQ 的 IRQ
<7>[33147.453278]控制:10c5387d 表:9cc019 DAC:00000015
0>[33147.453287]处理 addax2ip (pid:2166、栈限制= 0xdcd00238)
0>[33147.453296]堆栈:(0xdcd01ab0至0xdcd02000)
0>[33147.453307] 1aa0:                                    c0534e3c dd341b40 dcd01ae4 dcd01ac8
0>[33147.453321] 1ac0:c0534e54 c04def80 c0534e3c dd341b40 dccc5300 dcd01b84 dcd01b04 dcd01ae8
0>[33147.453334] 1ae0:c04d2658 c0534e48 00000080 dccc5301 00000020 dcd01e0c dcd01b08
0>[33147.453347] 1b00:c0104638 c04d25d0 00000000 00000304 dccc5300 3b9aca00 fffd98 00000001
0>[33147.453360] 1B20:0007a11b 00000000 dcd01b78 dcd01f68 dcd00000 000001 dcd01e18 00000000
0>[33147.453372] 1b40:00000000 dcd01e74 dcd01e34 dcd01e54 dcd01e94 dcd01ed4 dcd01eb4 00000000
0>[33147.45335] 1b60:00000000 00000000 00000000 00000000 00000080 00000000 704a341d 00001e25
0>[33147.453397] 1b80:FFFFFFFF 00000000 000000db 00000000 ddec2000 00000000 00000000 00000001
0>[33147.453410] 1ba0:dccc5300 000000db 00000000 dcd01b84 c01040f0 dcc40200 dcc40200 dcc40200 dcc40200
0>[33147.453423] 1bc0:9e043000 48022000 dcd01c0c dcd01bd8 c0017728 c00d6870 cd820f80 00000000
0>[33147.453436] 1be0:dd905bb0 00000001 dcd01c04 dcd01bf8 cd820f80 00000001 dcd01c3c dcd01c08
0>[33147.453449] 1c00:c031a7d8 c001ce3c c0017820 dd905bb0 dcd01c54 dcd01c20 c0017728 c00d6870
0>[33147.453462] 1c20:dd905bb0 00000030 dde7f1c0 c0899980 00000001 00000001 c092ce08 60090193
0>[33147.453475] 1c40:d5152400 dd9b40c0 40090113 dda5f210 dde7f1c0 dd905ac0 dcd01c84 dcd01c68
0>[33147.453488] 1c60:c0067f68 c0067eb4 00000004 dcd01c78 c0335c34 cfab4800 dcd01c9c dcd01c88
0>[33147.453501] 1c80:00000000 ce724000 ce724064 dcd01ce4 dcd01cA0 c03e8e70 c004107c
0>[33147.453514] 1ca0:FFFFFFFF 00000000 c09037c0 c09037c0 33d445ef dcd01cdc dcd01cc8
0>[33147.453527] 1cc0:c005cbdc c05f18ec 00000000 00000007 dcd01cf4 dcd01ce0 c005cc04 c005cbcc
0>[33147.453540] 1ce0:00000000 c03e8d54 dcd01d0c dcd01cf8 c0077138 c005cbf0 f5739fe6 00000000
0>[33147.453553] 1d00:dcd01de4 dcd01d10 c00784bc c007711c 00000006 c08f011c dcd01d74 dcd01d28
0>[33147.453566] 1d20:00000000 00ee6b28 c00733f0 dd804e80 0000001c 40400040 0031a987 3b9aca00
0>[33147.453579] 1d40:800f0193 c089d780 002e1b80 00000000 00989680 00000000 c08a90c8 00000400
0>[33147.453592] 1d60:007270e0 00000000 19999800 00000000 000002ea 007270e0 00000000 c08a9080
0>[33147.453605] 1d80:c08a9080 0000cd67 00000000 70f8e960 000002ef ddec2030 dcd01ddc dcd01da8
0>[33147.453618] 1da0:c0065f04 c0065df0 ddec2000 00000001 c08a9080 ddec2030 00000001 ddec2030
0>[33147.453631] 1dc0:00000001 c08a9080 ffffff 00000000 dcd01e04 dcd01de0 c05f192c c0013eb4
0>[33147.453644] 1de0:FFFFFFFF 00000020 dcd01e30 b4bfe18c dcd00000 00000000 00000100 dcd01e30
0>[33147.453657] 1e00:dcd01f5c dcd01e10 c0104b28 c01043a0 dcd01e34 00000000 dcd01e30 dcd01e50
0>[33147.453669] 1e20:dcd01e70 dcd01e90 dcd01eb0 dcd01ed0 00000080 00000000 00000000 00000000
0>[33147.453682] 1e40:00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0>[33147.453693] 1e60:00000000 00000000 00000000 00000000 00000000 00000000 00000000
0>[33147.453706] 1e80:00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0>[33147.453717] 1ea0:00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0>[33147.453730] 1ec0:00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
0>[33147.453742] 1e0:00000000 00000000 00000000 00000006 dcd01f68 1dcd6500 00000000
0>[33147.453755] 1f00:dcd01f30 00000400 00000000 00000000 dcd01f5c dcd01f28 c0104384 c00402e8
0>[33147.453767] 1f20:c0104370 c0076c6c 1dcd6500 00000000 0000817a b4bfe234 dcd01f68 00000000
0>[33147.453780] 1f40:b4bfe18c 00000400 00000000 00000000 dcd01fa4 dcd01f60 c0104df4 c01049fc
0>[33147.453793] 1f60:dcd01f68 b4bfe84c 0000817a 08bbf01d 00000000 0007a120 dcd01fa4 b4bfe234
0>[33147.453807] 1f80:b4bfe850 b4bfe844 0000008e c000e9c4 dcd00000 00000000 dcd01fa8
0>[33147.453819] 1fa0:c000e840 c0104d34 b4bfe234 b4bfe850 00000400 b4bfe18c 00000000 00000000
0>[33147.453833] 1fc0:b4bfe234 b4bfe850 b4bfe844 0000008e b4bfee20 b4bfe268 000564f8 00056654
0>[33147.453845] 1fe0:00000000 b4bfdb90 4c81a958 4c81a968 800f0010 00000400 00000000 00000000
<7>[33147.453851]回溯:
<7>[33147.453871][ ](数据报_poll),来自[ ](UDP_POL+0x18/0x5c)
7>[33147.453878] R4:dd341b40 R3:c0534e3c
<7>[33147.453905][ ](UDP_POLL)、来自[ ](SOCK_POL+0x94/0x114)
7>[33147.453912] R6:dcd01b84 R5:dccc5300 R4:dd341b40 R3:c0534e3c
<7>[33147.453935][ ](SOCK_POLL)从[ ](do_select+0x2a4/0x65c)
7>[33147.453942] r7:00000020 R6:dccc5301 R5:00000080 R4:00000080
<7>[33147.453961][ ](DO _选择)从[ ](CORE_SYS_SELECT+0x138/0x338)
7>[33147.453968] R10:dcd01e30 R9:00000100 R8:00000000 r7:dcd00000 R6:b4bfe18c R5:dcd01e30
<7>[33147.453984] R4:00000020
<7>[33147.453996][ ](core_sys_select)从[ ](SYS_SELECT+0xCC/0x114)
7>[33147.454003] R10:00000000 R9:00000000 R8:00000400 r7:b4bfe18c R6:00000000 R5:dcd01f68
7>[33147.454019] R4:b4bfe234
<7>[33147.454039][ ](sys_select)从[ ](RET_FAST_SYSCALL+0x0/0x30)
7>[33147.454046] R10:00000000 R9:dcd00000 R8:c000e9c4 r7:0000008e R6:b4bfe844 R5:b4bfe850
7>[33147.454062] R4:b4bfe234
0>[33147.454075]代码:e89da818 e5943160 e10f2000 f10c0080 (e5931008)
[4][33147.454103]--[结束线迹97475b76644aef4 ]--
[1][33147.886122]无法处理虚拟地址89c57cf0处的内核分页请求
[1][33147.886145] PgD = dcbf0000
[1][33147.886154][89c57cf0]* PgD=00000000
0>[33147.886172]内部错误:Oops:5 [#2] ARM
7>[33147.886182]链接的模块:crash_dump (O) mcs7830 dm9601 XT_limit FTDI_SIO XT_conntrack usbserial IPT_reject XT_connlimit Tun XT_tcputcpip plnetemu (O) iptable_nat power_mon (O) NL_connfrack_ipnfrack_ipnfrack_nv4_ipt_ipt_ipt_ipt_nfrack_iptablet nfrack_iptables_nipnfrack_ipn
<7>[33147.886242] CPU:0 PID:1468 Comm:ifplugd 被污染:G     D   O 3.14.26R8A+#147
7>[33147.886254]任务:dc850c00 ti:dcbea000 task.ti:dcbea000
7>[33147.886276] PC 位于 inet_ioctl+0x174/0x1c8
<7>[33147.886300] LR 位于 SOCK_ioctl+0x64/0x284
7>[33147.886310]电脑:[ ]   LR:[ ]   PSR:80000013
7>[33147.886310] sp:dcbebec8 IP:dcbebed8 fp:dcbed4
7>[33147.886321] R10:dd28e260 R9:dcbea000 R8:bed77a40
7][33147.886330] r7:bed77a40 r6:bed77a40 r5:dd28e240 r4:00008913
7>[33147.886338] r3:89c57ce0 r2:bed77a40 r1:00008913 r0:dc9b5a80
<7>[33147.886349]标志:   模式 SVC_32 ISA ARM 段用户上 FIQ 上的 Nzcv IRQ
<7>[33147.886358]控制:10c5387d 表:9cbf0019 DAC:00000015
0>[33147.886366]进程 ifplugd (pid:1468、栈限制= 0xdcbea238)
0>[33147.886375]栈:(0xdcbebec8至0xdcbec000)
0>[33147.886387] bec0:                  dcbef4 dcbed8 c04d329c c053fcdc c04d3238 dca6fb00
0>[33147.886400] bee0:00000005 00000000 dcbebf7c dcbef8 c0103384 c04d3244 00000000 00000000
0>[33147.886413] bf00:dcbebf68 dcbebf68 dcbea000 bed77ae8 00000001 bed77ae8 00000008 00000000
0>[33147.886426] bf20:00000000 c0103f5c 00000000 00000000 00000000 00000000 00000000 dcbebf68 bed77ae8
0>[33147.886438] bf40:dcbebf68 00000000 bed77b70 00000400 dcbebfa4 dca6fb00 dca6fb00 00000000
0>[33147.886452] bf60:bed77a40 00008913 dcbea000 00000005 dcbebfa4 dcbebf80 c01038cc c0103310
0>[33147.88644] bf80:00000005 00017008 00000005 00000036 c000e9c4 00000000 00000000 dcbebfa8
0>[33147.886477] bfa0:c000e840 c010386c 00000005 00017008 00000005 00008913 bed77a40 bed77a4e
0>[33147.886489] bfc0:00000005 00017008 00000005 00000036 00000001 00000005 00000000 00000000
0>[33147.886502] bfe0:00015364 bed77a3c 0000b060 4c81962c 60000010 00000005 9fdf2821 9fdf2c21
<7>[33147.886508]回溯:
<7>[33147.886526][ ](inet_ioctl)从[ ](SOCK_ioctl+0x64/0x284)
7][33147.886552][ ](sock_ioctl)从[ ](do_vfs_ioctl+0x80/0x55c)
7>[33147.886559] R6:00000000 R5:00000005 R4:dca6fb00 R3:c04d3238
7][33147.886582][ ](do _vfs_ioctl)、从[ ](sys_ioctl+0x6c/0x7c)
7>[33147.886589] R10:00000005 R9:dcbea000 R8:00008913 r7:bed77a40 R6:00000000 R5:dca6fb00
7>[33147.886605] R4:dca6fb00
7][33147.886627][ ](sys_ioctl)从[ ](RET_FAST_SYSCALL+0x0/0x30)
7>[33147.886634] R10:00000000 R8:c000e9c4 r7:00000036 R6:00000005 R5:00017008 R4:00000005
0>[33147.886657]代码:e59f0058 ebffea41 e89da800 e5903020 (e5933010)
[4][33147.886673]--[结束线迹97475b76644aef5 ]--
CPU:AM3352ZCZD80 ES2.1
CPU 频率:800MHz
NAND:Micron MT29F8G08ABAWP-IT (1024MiB、SLC、页面大小:4096、OOB 大小:224、OMAP_ECC_BCH16_CODE_HW ECC 方案)
PMIC:TPS65910A3A1RSL
RAM:MT41K256M16HA-125 IT (512MiB、DDR3L)
Linux 版本:3.14.26–(SDK Linux 01.00.03)
GCC 版本:4.7.3 -- Linaro GCC 2013.03
/sys/devices/system/cpu/cpufreq/policy0/scaling_governor = 性能
无低功耗模式
这种 Ooops 每周发生一次或两次、但在不同的场合发生。 从我看到的内容来看、它与网络通信的发展有某种关系、您能不能给出一些进一步的想法吗?
Ilya
    您好 Ilya、
    您能否分享一下发生这种情况的条件是什么? 他们使用的是 TI 参考设计还是定制板? 我想这是定制板、对吧?
    他们是否运行某些应用程序? 它在干什么?
    还是这种随机内核崩溃?
    请发布他们的完整引导日志? 也可能是他们的 DTS 文件。
    Yordan
    Yordan、
    这是定制电路板、但基于 TI PLC 直流设计并进行了修改。
    下面是完整日志+有关运行应用程序和进程的一些信息
    [root@Router8:~]# cat /var/log/messages
    7月14日16:34:50 Router8 syslogd 1.5.1:重新启动。
    7月14日16:34:50 Router8内核:klogd 1.5.0,日志源=/proc/kmsg 已启动。
    7月14日16:34:50 Router8内核:找不到映射文件。
    7月14日16:34:50 Router8内核:从23个模块加载68889符号。
    7月14日16:34:50 Router8内核:[0.000000]   在物理 CPU 0x0上引导 Linux
    2016年7月14日16:34:50 Router8内核:[0.000000]   Linux 版本3.14.26RTR8A+(root@UBS)(gcc 版本4.7.3 20130226 (预发布版本)(Crossstad-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03))#147 Tue Oct25 15:12:44 EEST 2016
    7月14日16:34:50 Router8内核:[0.000000]   CPU:ARMv7处理器[413fc082]修订版2 (ARMv7),CR=10c5387d
    7月14日16:34:50 Router8内核:[0.000000]   CPU:PIPT/VIPT 非混叠数据高速缓存、VIPT 别名指令高速缓存
    7月14日16:34:50 Router8内核:[0.000000]   机器型号:AM335x RTR8A -添加技术
    7月14日16:34:50 Router8内核:[0.000000]   CMA:9e000000保留24 MIB
    7月14日16:34:50 Router8内核:[0.000000]   内存策略:数据高速缓存写回
    7月14日16:34:50 Router8内核:[0.000000]   在节点0上总计:130560
    7月14日16:34:50 Router8内核:[0.000000]   free_area_init_node:节点0、pgdat c08e5bc0、node_mem_map df9ee000
    7月14日16:34:50 Router8内核:[0.000000]     正常区域:用于 memmap 的1024页
    7月14日16:34:50 Router8内核:[0.000000]     正常区域:保留0页
    7月14日16:34:50 Router8内核:[0.000000]     正常区域:130560页,LIFO 批处理:31
    7月14日16:34:50 Router8内核:[0.000000]   CPU:所有 CPU 均在 SVC 模式下启动。
    7月14日16:34:50 Router8内核:[0.000000]   AM335X ES2.1 (NEON)
    7月14日16:34:50 Router8内核:[0.000000]   pcpu-alloc:s0 r0 d32768 u32768 alloc=1*32768
    7月14日16:34:50 Router8内核:[0.000000]   pcpu-alloc:[0]
    7月14日16:34:50 Router8内核:[0.000000]   在区域顺序中构建了1个区域列表,移动分组打开。  总页数:129536
    7月14日16:34:50 Router8内核:[0.000000]   内核命令行:console=tty0 root=ubi0:rootfs rw ubi.mtd=2、4096 rootfststrouter=ubifs 等待 RouterID=0xBDD2F7 Hardy1=0x3100001A Hard2=0x230764C0 Adjtime_fv=root0
    7月14日16:34:50 Router8内核:[0.000000]   PID 哈希表条目:2048 (顺序:1,8192字节)
    7月14日16:34:50 Router8内核:[0.000000]   条目高速缓存散列表条目:65536 (订单:6,262144字节)
    7月14日16:34:50 Router8内核:[0.000000]   inode 高速缓存散列表条目:32768 (订单:5,131072字节)
    7月14日16:34:50 Router8内核:[0.000000]   内存:483480K/522240K 可用(6075K 内核代码、386K rwdata、2308K rodata、334K init、356K BSS、 38760K 保留、0K HIGHMEM)
    7月14日16:34:50 Router8内核:[0.000000]   虚拟内核内存布局:
    7月14日16:34:50 Router8内核:[0.000000]       矢量 :0xff0000-0xff1000  (4KB)
    7月14日16:34:50 Router8内核:[0.000000]       fixmap :0xFF00000 - 0xFFE0000  (896 KB)
    7月14日16:34:50 Router8内核:[0.000000]       vmalloc:0xe0800000-0x000000  (488MB )
    7月14日16:34:50 Router8内核:[0.000000]       lowmem :0xC0000000 - 0xe0000000  (512 MB)
    7月14日16:34:50 Router8内核:[0.000000]       pkmap  :bbfe00000 - 0xC0000000  (  2 MB)
    7月14日16:34:50 Router8内核:[0.000000]       模块:bbf000000 - bbbfe00000  ( 14 MB)
    7月14日16:34:50 Router8内核:[0.000000]         .text:0xc0008000 - 0xc0838024  (8385KB)
    7月14日16:34:50 Router8内核:[0.000000]         .init:0xc0839000 - 0xc088c914  (335KB)
    7月14日16:34:50 Router8内核:[0.000000]         .data:0xc088e000 - 0xc08ea00  (387 KB)
    7月14日16:34:50 Router8内核:[0.000000]          .bss:0xc08ea00 - 0xc0947d48  (357KB)
    7月14日16:34:50 Router8内核:[0.000000]   NR_IRQ:16 nr_IRQ:16 16.
    7月14日16:34:50 Router8内核:[0.000000]   IRQ:在0xfa200000 (修订版5.0)处找到一个带有128个中断的 INTC
    7月14日16:34:50 Router8内核:[0.000000]   在1个活动控制器上总共有128个中断
    7月14日16:34:50 Router8内核:[0.000000]   OMAP 时钟事件来源:timer2,240000Hz
    7月14日16:34:50 Router8内核:[0.000013]   sched_clock:32位24MHz,分辨率41ns,每178956969942ns 换行一次
    7月14日16:34:50 Router8内核:[0.000031]   OMAP 时钟源:Timer1为24000000 Hz
    7月14日16:34:50 Router8内核:[0.000291]   控制台:彩色虚拟设备80x30
    7月14日16:34:50 Router8内核:[0.000706]   控制台[tty0]已启用
    7月14日16:34:50 Router8内核:[0.000740]   校准延迟环路... 795.44茂物剪(lpj=3977216)
    7月14日16:34:50 Router8内核:[0.089451]   pid_max:默认值:32768最小值:301
    7月14日16:34:50 Router8内核:[0.089564]   安全框架已初始化
    7月14日16:34:50 Router8内核:[0.089629]   安装高速缓存散列表条目:1024 (顺序:0,4096字节)
    7月14日16:34:50 Router8内核:[0.089655]   mountpoint-cache 哈希表条目:1024 (顺序:0,4096字节)
    7月14日16:34:50 Router8内核:[0.09676767]   CPU:测试写入缓冲区一致性:好的
    7月14日16:34:50 Router8内核:[   0.097162]为0x805f5250 - 0x805f52a8设置静态标识图
    7月14日16:34:50 Router8内核:[0.098267]   devtmpfs:已初始化
    7月14日16:34:50 Router8内核:[0.100351]   VFP 支持 v0.3:Implementor 41体系结构3第30部分变体 c 修订版3
    7月14日16:34:50 Router8内核:[0.107327]   omap_hwmod:tptc0使用 EDMA 中断开的 dt 数据
    7月14日16:34:50 Router8内核:[0.107426]   omap_hwmod:tptc1使用 EDMA 中断开的 dt 数据
    7月14日16:34:50 Router8内核:[0.107511]   omap_hwmod:tptc2使用 EDMA 中断开的 dt 数据
    7月14日16:34:50 Router8内核:[0.111690]   omap_hwmod:debugss:_wait_target_disable 失败
    7月14日16:34:50 Router8内核:[0.154702]   pinctrl 内核:已初始化 pinctrl 子系统
    7月14日16:34:50 Router8内核:[0.155893]   reguler-dummy:无参数
    7月14日16:34:50 Router8内核:[0.158171]   NET:注册协议系列16.
    7月14日16:34:50 Router8内核:[0.160286]   DMA:预分配256 KiB 池用于原子相干分配
    7月14日16:34:50 Router8内核:[0.162654]   空闲:使用调速器梯
    7月14日16:34:50 Router8内核:[0.162689]   cputidle:使用调速器菜单
    7月14日16:34:50 Router8内核:[0.163429]   添加技术,RTR8A 板
    7月14日16:34:50 Router8内核:[0.169377]   SYSCON 44e10000.CONTROL_MODULE:regmap [mem 0x44e10000-0x44e107fb]已注册
    7月14日16:34:50 Router8内核:[0.170972]   平台49000000.EDMA:别名 fck 已存在
    7月14日16:34:50 Router8内核:[0.171018]   平台49000000.EDMA:别名 fck 已存在
    7月14日16:34:50 Router8内核:[0.171044]   平台49000000.EDMA:别名 fck 已存在
    7月14日16:34:50 Router8内核:[0.171930]   gpiochip_add:在器件上注册了 GPIO 0至31
    7月14日16:34:50 Router8内核:[0.172218]   OMAP GPIO 硬件版本0.1
    7月14日16:34:50 Router8内核:[0.173118]   gpiochip_add:在设备:GPIO 上注册了 GPIO 32至63
    7月14日16:34:50 Router8内核:[0.174119]   gpiochip_add:在设备:GPIO 上注册了 GPIO 64至95
    7月14日16:34:50 Router8内核:[0.175136]   gpiochip_add:在器件上注册了 GPIO 96至127
    7月14日16:34:50 Router8内核:[0.183127]   OMAP-GPMC 50000000。GPMC:找不到节点/pinmux@44e10800/nandflash_pins_default 的 pctldev,正在推迟探测
    7月14日16:34:50 Router8内核:[0.183201]   平台50000000.GPMC:驱动程序 OMAP-GPMC 请求探测器延迟
    7月14日16:34:50 Router8内核:[0.185750]   没有 ATAG?
    7月14日16:34:50 Router8内核:[0.185778]   硬件断点:不支持调试架构0x4。
    7月14日16:34:50 Router8内核:[0.207164]   bio:create slab 为0
    7月14日16:34:50 Router8内核:[0.222379]   EDMA-DMA-ENGINE EDMA-DMA-ENGINE。0:TI EDMA DMA 引擎驱动程序
    7月14日16:34:50 Router8内核:[0.223093]   of_get_named_gpiod_flags:无法解析节点'/fixedregulator@0[0]的 GPIO 属性
    7月14日16:34:50 Router8内核:[0.22334]   VBAT:5000mV
    7月14日16:34:50 Router8内核:[0.226429]   i2c-core:使用传统挂起方法的驱动程序[Palmas]
    7月14日16:34:50 Router8内核:[0.226463]   i2c-core:使用传统恢复方法的驱动程序[Palmas]
    7月14日16:34:50 Router8内核:[0.227191]   SCSI 子系统已初始化
    7月14日16:34:50 Router8内核:[0.228157]   usbcore:注册的新接口驱动程序 usbfs
    7月14日16:34:50 Router8内核:[0.228364]   usbcore:注册的新接口驱动程序集线器
    7月14日16:34:50 Router8内核:[0.228590]   usbcore:注册的新设备驱动程序 USB
    7月14日16:34:50 Router8内核:[0.229604]   omap_i2c 4802a000。i2c:找不到节点/pinmux@44e10800/pinmux_i2c1_pins 的 pctldev,正在推迟探测
    7月14日16:34:50 Router8内核:[0.229658]   平台4802a000.i2c:驱动程序 omap_i2c 请求探针延迟
    7月14日16:34:50 Router8内核:[0.230060]   pps_core:LinuxPPS API 版本。 1已注册
    7月14日16:34:50 Router8内核:[0.230084]   pps_core:软件版本 5.3.6 -版权所有2005-2007 Rodolfo Giometti
    7月14日16:34:50 Router8内核:[0.230234]   PTP 时钟支持已注册
    7月14日16:34:50 Router8内核:[0.232199]   OMAP-mailbox 480c8000.mailbox:OMAP mailbox 0x400
    7月14日16:34:50 Router8内核:[0.234213]   切换到时钟源 Timer1
    7月14日16:34:50 Router8内核:[0.272452]   NET:注册协议系列2.
    7月14日16:34:50 Router8内核:[0.273306]   TCP 建立哈希表条目:4096 (顺序:2,16384字节)
    7月14日16:34:50 Router8内核:[0.273380]   TCP 绑定哈希表条目:4096 (顺序:2,16384字节)
    7月14日16:34:50 Router8内核:[0.273437]   TCP:配置哈希表(建立4096 BIND 4096)
    7月14日16:34:50 Router8内核:[0.273514]   TCP:Reno 注册
    7月14日16:34:50 Router8内核:[0.273537]   UDP 哈希表条目:256 (顺序:0,4096字节)
    7月14日16:34:50 Router8内核:[0.273567]   udp-Lite 哈希表条目:256 (顺序:0、4096字节)
    7月14日16:34:50 Router8内核:[0.273794]   NET:注册协议系列1.
    7月14日16:34:50 Router8内核:[0.274194]   RPC:注册后命名为 UNIX 套接字传输模块。
    7月14日16:34:50 Router8内核:[0.274289]   RPC:注册的 UDP 传输模块。
    7月14日16:34:50 Router8内核:[0.274307]   RPC:注册的 TCP 传输模块。
    7月14日16:34:50 Router8内核:[0.274323]   RPC:注册 TCP NFSv4反向通道传输模块。
    7月14日16:34:50 Router8内核:[0.274348]   PCI:CLS 0字节,默认值为64
    7月14日16:34:50 Router8内核:[0.275476]   硬件性能事件:启用 ARMv7 Cortex-A8 PMU 驱动程序、提供5个计数器
    7月14日16:34:50 Router8内核:[0.278769]   futex 散列表条目:256 (顺序:-1,3072字节)
    7月14日16:34:50 Router8内核:[0.458216]   VFS:磁盘配额 dquot_6.5.2
    7月14日16:34:50 Router8内核:[0.458315]   Dquot-cache 哈希表条目:1024 (订单0、4096字节)
    7月14日16:34:50 Router8内核:[0.458876]   NFS:注册 id_resolver 密钥类型
    7月14日16:34:50 Router8内核:[0.458973]   注册了密钥类型 id_resolver
    7月14日16:34:50 Router8内核:[0.458991]   注册的密钥类型 id_legacy
    7月14日16:34:50 Router8内核:[0.459042]   jffs2:版本2.2。 (NAND)(摘要) Copyright2001-2006 Red Hat, Inc.
    7月14日16:34:50 Router8内核:[0.459208]   fuse init (API 版本7.22)
    7月14日16:34:50 Router8内核:[0.459742]   msgmni 已设置为992
    7月14日16:34:50 Router8内核:[0.461712]   NET:注册协议系列38.
    7月14日16:34:50 Router8内核:[0.461748]   注册密钥类型非对称
    7月14日16:34:50 Router8内核:[0.461765]   注册的非对称密钥解析器'x509'
    7月14日16:34:50 Router8内核:[0.461806]   已注册 IO 调度程序 NOOP
    7月14日16:34:50 Router8内核:[0.461823]   已注册 IO 调度程序截止日期
    7月14日16:34:50 Router8内核:[0.461853]   注册的 IO 调度程序 cfq (默认)
    7月14日16:34:50 Router8内核:[0.463525]   pinctrl-single 44e10800.pinmux:142引脚,PA f9e10800大小568
    7月14日16:34:50 Router8内核:[0.464074]   pinctrl-single 44e10800.pinmux:44e10848.0已由44e10800.pinmux 请求;无法申请使能。6.
    7月14日16:34:50 Router8内核:[0.464117]   pinctrl-single 44e10800.pinmux:引脚18 (使能6)状态-22
    7月14日16:34:50 Router8内核:[0.464143]   pinctrl-single 44e10800.pinmux:无法从 器件 pinctrl-single 上的组 pinmux_sEND_pins 请求引脚18 (44e10848.0)
    7月14日16:34:50 Router8内核:[0.464175]   GPIO-of -helper 使能。6:应用设置时出错,反向
    7月14日16:34:50 Router8内核:[0.464330]   pinctrl-single 44e10800.pinmux:44e10848.0已由44e10800.pinmux 请求;无法申请使能。6.
    7月14日16:34:50 Router8内核:[0.464368]   pinctrl-single 44e10800.pinmux:引脚18 (使能6)状态-22
    7月14日16:34:50 Router8内核:[0.464392]   pinctrl-single 44e10800.pinmux:无法从 设备 pinctrl-single 上的组 pinmux_sEND_pins 请求引脚18 (44e10848.0)
    7月14日16:34:50 Router8内核:[0.46423]   GPIO-of -helper 使能。6:应用设置时出错,反向
    7月14日16:34:50 Router8内核:[0.46453]   GPIO-of -helper 使能。6:引脚未从驱动程序配置
    7月14日16:34:50 Router8内核:[0.464534]   of_get_named_gpiod_flags 以状态0退出
    7月14日16:34:50 Router8内核:[0.46492]   GPIO-of-helper 使能。6:分配的 GPIO id=0
    7月14日16:34:50 Router8内核:[0.465008]   GPIO of-helper 使能。6:就绪
    7月14日16:34:50 Router8内核:[0.467580]   串行:8250/16550驱动程序,6个端口,启用 IRQ 共享
    7月14日16:34:50 Router8内核:[0.471440]   44e09000.serial: tmio 0x44e09000处的 ttyO0 (IRQ = 88、base_baud = 3000000)是8250
    7月14日16:34:50 Router8内核:[0.472514]   48022000.serial: tmio 0x48022000 (IRQ = 89、base_baud = 3000000)处的 ttyO1是8250
    7月14日16:34:50 Router8内核:[0.473512]   48024000.serial: tmio 0x48024000 (IRQ = 90、base_baud = 3000000)处的 ttyO2是8250
    7月14日16:34:50 Router8内核:[0.474578]   481a6000.serial: tmio 0x481a6000 (IRQ = 60、base_baud = 3000000)处的 ttyO3是8250
    7月14日16:34:50 Router8内核:[0.475562]   481a8000.serial: tmio 0x481a8000处的 ttyO4 (IRQ = 61、base_baud = 3000000)是8250
    7月14日16:34:50 Router8内核:[0.476544]   481aa000.serial: tmio 0x481aa000处的 ttyO5 (IRQ = 62、base_baud = 3000000)是8250
    7月14日16:34:50 Router8内核:[0.478597]   OMAP_rng 48310000.rng:OMAP 随机数生成器版本。 20.
    7月14日16:34:50 Router8内核:[0.489471]   返修:模块已加载
    7月14日16:34:50 Router8内核:[0.495169]   loop:module loaded
    7月14日16:34:50 Router8内核:[0.495718]   (HCI_TTY):位于 HCI_TTY_INIT 内部
    7月14日16:34:50 Router8内核:[0.496199]   (HCI_TTY):已分配249、0
    7月14日16:34:50 Router8内核:[0.499708]   mtdoops:必须提供 MTD 设备(mtddev=name/number)
    7月14日16:34:50 Router8内核:[0.503328]   libphy:固定 MDIO 总线:探测
    7月14日16:34:50 Router8内核:[0.507199]   PPP 通用驱动程序版本2.4.2
    7月14日16:34:50 Router8内核:[0.507712]   已注册 PPP BSD 压缩模块
    7月14日16:34:50 Router8内核:[0.507743]   已注册 PPP Deflate 压缩模块
    7月14日16:34:50 Router8内核:[0.507762]   NET:注册协议系列24.
    7月14日16:34:50 Router8内核:[0.508054]   usbcore:注册了新的接口驱动程序 aSix
    7月14日16:34:50 Router8内核:[0.508278]   usbcore:注册的新接口驱动程序 ax88179_178a
    7月14日16:34:50 Router8内核:[0.508469]   usbcore:注册了新的接口驱动程序 CDC_ether
    7月14日16:34:50 Router8内核:[0.508688]   usbcore:注册的新接口驱动程序 smsc95xx
    7月14日16:34:50 Router8内核:[0.508872]   usbcore:注册了新的接口驱动程序 net1080
    7月14日16:34:50 Router8内核:[0.509051]   usbcore:注册了新的接口驱动程序 CDC_Subset
    7月14日16:34:50 Router8内核:[0.509281]   usbcore:注册了新的接口驱动程序 CDC_NCM
    7月14日16:34:50 Router8内核:[0.510557]   EHCI_hcd:USB 2.0 "增强型"主机控制器(EHCI)驱动程序
    7月14日16:34:50 Router8内核:[0.510590]   EHCI-PCI:EHCI PCI 平台驱动程序
    7月14日16:34:50 Router8内核:[0.510807]   EHCI 平台:EHCI 通用平台驱动程序
    7月14日16:34:50 Router8内核:[0.511095]   EHCI-OMAP:OMAP-EHCI 主机控制器驱动程序
    7月14日16:34:50 Router8内核:[0.512007]   usbcore:注册了新的接口驱动程序 CDC_ACM
    7月14日16:34:50 Router8内核:[0.512035]   CDC_ACM:USB 调制解调器和 ISDN 适配器的 USB 抽象控制模型驱动程序
    7月14日16:34:50 Router8内核:[0.512250]   usbcore:注册了新的接口驱动程序 USB 存储
    7月14日16:34:50 Router8内核:[0.514516]   of_get_named_gpiod_flags:无法解析节点'/ocp/usb@47400000/USB-phy@47401300[0]的 GPIO 属性
    7月14日16:34:50 Router8内核:[0.514581]   47401300.usb-phy 电源 VCC 未找到,正在使用虚拟稳压器
    7月14日16:34:50 Router8内核:[0.517228]   musb-hdrc musb-hdrc.0.auto:请求 rx1失败。
    7月14日16:34:50 Router8内核:[0.517327]   musb-hdrc musb-hdrc.0.auto: musb_init_controller 失败,状态为-517
    7月14日16:34:50 Router8内核:[0.517400]   平台 musb-hdrc.0.auto:驱动程序 musb-hdrc 请求探测器延迟
    7月14日16:34:50 Router8内核:[0.518161]   of_get_named_gpiod_flags:无法解析节点'/ocp/usb@47400000/USB-phy@47401b00[0]的 GPIO 属性
    7月14日16:34:50 Router8内核:[0.518215]   使用虚拟稳压器未找到47401b00.usb-phy 电源 VCC
    7月14日16:34:50 Router8内核:[0.520706]   musb-hdrc musb-hdrc.1.auto:请求 rx1失败。
    7月14日16:34:50 Router8内核:[0.520785]   musb-hdrc musb-hdrc.1.auto: musb_init_controller 失败,状态为-517
    7月14日16:34:50 Router8内核:[0.520846]   平台 musb-hdrc.1.auto:驱动程序 musb-hdrc 请求探测器延迟
    7月14日16:34:50 Router8内核:[0.534848]   userial_init:注册了4个 ttyGS*设备
    7月14日16:34:50 Router8内核:[0.535144]   i2c-core:使用传统挂起方法的驱动程序[RC-ds1307]
    7月14日16:34:50 Router8内核:[0.535186]   i2c-core:driver [RT-ds1307] Using legacy resume method
    7月14日16:34:51 Router8内核:[0.536512]   i2c /dev/entries 驱动程序
    7月14日16:34:51 Router8内核:[0.538321]   OMAP-WDT:OMAP 看门狗计时器修订版0x01:初始超时60秒
    7月14日16:34:51 Router8内核:[0.540091]   of_get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.540111]   of_get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.540122]   of_get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.540131]   of_get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.540153]   of _get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.540565]   of_get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.540823]   of _get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.541069]   of_get_named_gpiod_flags 以状态0退出
    7月14日16:34:51 Router8内核:[0.541615]   ledtrig-cpu:注册以指示 CPU 上的活动
    7月14日16:34:51 Router8内核:[0.541953]   OMAP-AES 53500000.AES:OMAP AES 硬件加速器版本:3.2
    7月14日16:34:51 Router8内核:[0.54747479]   usbcore:注册了新的接口驱动程序 usbhid
    7月14日16:34:51 Router8内核:[0.547517]   usbhid:USB HID 核心驱动程序
    7月14日16:34:51 Router8内核:[0.547735]   平台44d00000。wkup_m3:驱动程序 wkup_m3请求探测器延迟
    7月14日16:34:51 Router8内核:[0.550243]   配置文件:使用 ARM/armv7
    7月14日16:34:51 Router8内核:[0.550546]   ipipip:IPv4 over IPv4隧道驱动程序
    7月14日16:34:51 Router8内核:[0.551526]   GRE:GRE over IPv4多路信号分离器驱动程序
    7月14日16:34:51 Router8内核:[0.551561]   IP_GRE:GRE over IPv4隧道驱动程序
    7月14日16:34:51 Router8内核:[0.553208]   IPv4 over IPSec 隧道驱动程序
    7月14日16:34:51 Router8内核:[0.554072]   TCP:立方注册
    7月14日16:34:51 Router8内核:[0.554098]   正在初始化 XFRM netlink 套接字
    7月14日16:34:51 Router8内核:[0.554192]   NET:注册协议系列10.
    7月14日16:34:51 Router8内核:[0.557022]   SIT:IPv6 over IPv4隧道驱动程序
    7月14日16:34:51 Router8内核:[0.559102]   ip6_GRE:GRE over IPv6隧道驱动程序
    7月14日16:34:51 Router8内核:[0.560148]   NET:注册协议系列17.
    7月14日16:34:51 Router8内核:[0.560222]   NET: registered protocol family 15.
    7月14日16:34:51 Router8内核:[0.560365]   注册密钥类型 DNS_旋 变传感器
    7月14日16:34:51 Router8内核:[0.561264]   CPU CPU0:of_pm_voltdm_notifier_register:无法获取 CPU0稳压器/voltdm:-517
    7月14日16:34:51 Router8内核:[0.561313]   CPU CPU0:CPU0时钟通知器未就绪、请重试
    7月14日16:34:51 Router8内核:[0.561354]   平台 cpufreq-cpu0.0:驱动程序 cpufreq-cpu0请求探测器延迟
    7月14日16:34:51 Router8内核:[0.561995]   PM:DT 未提供电压调节数据。
    7月14日16:34:51 Router8内核:[0.562119]   PM:无 RTC 可用,仅 RTC 模式禁用。
    7月14日16:34:51 Router8内核:[0.562142]   支持 ThumbEE CPU 扩展。
    7月14日16:34:51 Router8内核:[0.562188]   正在注册 SWP/SWPB 仿真处理程序
    7月14日16:34:51 Router8内核:[0.563795]   VBAT:正在禁用
    7月14日16:34:51 Router8内核:[0.563831]   reguler-dummy:正在禁用
    7月14日16:34:51 Router8内核:[0.564352]   OMAP-GPMC 50000000。GPMC:GPMC 版本6.0
    7月14日16:34:51 Router8内核:[0.564389]   GPMC_mem_init:禁用映射在0x0-0x1000000的 cs 0
    7月14日16:34:51 Router8内核:[0.565592]   nand:找到设备、制造商 ID:0x2C、芯片 ID:0x38
    7月14日16:34:51 Router8内核:[0.565631]   nand:Micron MT29F8G08ABABAWP
    7月14日16:34:51 Router8内核:[0.565648]   nand: 1024Mib, SLC,页码:4096,OOB 大小:224
    7月14日16:34:51 Router8内核:[0.565667]   使用 OMAP-ECC_BCH16_CODE_HW ECC 方案
    7月14日16:34:51 Router8内核:[0.565726]   nand:从写入大小计算 NAND 子页大小:1024
    7月14日16:34:51 Router8内核:[0.565781]   在 MTD 设备 OMAP2-nand.0上找到4个部件分区
    7月14日16:34:51 Router8内核:[0.565801]   在"OMAP2-nand.0"上创建4个 MTD 分区:
    7月14日16:34:51 Router8内核:[0.565827]   0x00000000-0x380000:"U-Boot"
    7月14日16:34:51 Router8内核:[0.567957]0x000000380000-0x000000880000   :“内核”
    7月14日16:34:51 Router8内核:[0.570006]   0x000000880000-0x00000D080000:“rootfs”
    7月14日16:34:51 Router8内核:[0.592078]   0x00000d080000-0x000040000000:“用户”
    7月14日16:34:51 Router8内核:[0.679136]   tps65910 1-002D:不支持中断,不支持内核 IRQ
    7月14日16:34:51 Router8内核:[0.679533]   tps65910-gpio tps65910-gpio:TI、en-gpo-sleep 未指定
    7月14日16:34:51 Router8内核:[0.679550]   gpiochip_find_BASE:找到250的新基址
    7月14日16:34:51 Router8内核:[0.679828]   gpiochip_add:在设备:tps65910上注册了 GPIO 250至255
    7月14日16:34:51 Router8内核:[0.686006]   Vrtc:1800mV
    7月14日16:34:51 Router8内核:[0.686604]   vrtc:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.690191]   VIO:1500 mV
    7月14日16:34:51 Router8内核:[0.690300]   VIO:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.694280]   VDD_MPU:1262mV 时为912 <--> 1375mV
    7月14日16:34:51 Router8内核:[0.694383]   VDD_MPU:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.698342]   VDD_CORE:1137mV 时为912 <--> 1150 mV
    7月14日16:34:51 Router8内核:[0.698447]   VDD_CORE:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.701334]   vdd3:5000mV
    7月14日16:34:51 Router8内核:[0.704547]   vdig1:1800mV
    7月14日16:34:51 Router8内核:[0.7046466]   vdig1:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.707878]   vdig2:1800mV
    7月14日16:34:51 Router8内核:[0.707972]   vdig2:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.711194]   vpll:1800mV
    7月14日16:34:51 Router8内核:[0.711281]   vpll:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.714496]   vdac:1800mV
    7月14日16:34:51 Router8内核:[0.714586]   vdac:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.717833]   vaux1:1800mV
    7月14日16:34:51 Router8内核:[0.717928]   vaux1:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.721145]   vaux2:3300 mV
    7月14日16:34:51 Router8内核:[0.721247]   vaux2:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.724468]   vaux33:3300 mV
    7月14日16:34:51 Router8内核:[0.724561]   vaux33:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.727805]   VMMC:3300 mV 时为1800 <--> 3300 mV
    7月14日16:34:51 Router8内核:[0.727898]   VMMC:由 VBAT 提供
    7月14日16:34:51 Router8内核:[0.739314]   tps65910-RTC tps65910-RTC:RTC 内核:将 tps65910-RTC 注册为 rtc0
    7月14日16:34:51 Router8内核:[0.740307]   kernel_i2c:找到 kerkey 重置引脚:117
    7月14日16:34:51 Router8内核:[0.740717]   omap_i2c 4802a000.i2c:总线1 rev0.11为100kHz
    7月14日16:34:51 Router8内核:[0.744124]   musb-hdrc:ConfigData=0xde (UTMI-8、dyn FIFO、大容量组合、大容量分离、HB-ISO Rx、 HB-ISO Tx、SoftConn)
    7月14日16:34:51 Router8内核:[0.744140]   musb-hdrc:MHDRC RTL 2.0版
    7月14日16:34:51 Router8内核:[0.744148]   musb-hdrc:设置 fifo_mode 4.
    7月14日16:34:51 Router8内核:[0.744163]   musb-hdrc:28/31 max EP,16384/16384内存
    7月14日16:34:51 Router8内核:[0.744439]   musb-hdrc musb-hdrc.0.auto: MUSB HDRC 主机驱动程序
    7月14日16:34:51 Router8内核:[0.744911]   musb-hdrc musb-hdrc.0.auto:注册了新的 USB 总线,分配了总线编号1
    7月14日16:34:51 Router8内核:[0.745118]   USB USB1:找到新的 USB 设备、idVendor=1d6b、idProduct=0002
    7月14日16:34:51 Router8内核:[0.745146]   USB USB1:新的 USB 设备字符串:MFR=3、Product=2、SerialNumber=1
    7月14日16:34:51 Router8内核:[0.745172]   USB USB1:产品:MUSB HDRC 主机驱动程序
    7月14日16:34:51 Router8内核:[0.745191]   USB USB1:制造商:Linux 3.14.26R8A+ musb-hcd
    7月14日16:34:51 Router8内核:[0.745211]   USB USB1:序列号:musb-hdrc.0.auto
    7月14日16:34:51 Router8内核:[0.746267]   hub 1-0:1.0:找到 USB hub
    7月14日16:34:51 Router8内核:[0.746342]   hub 1-0:1.0:1端口
    7月14日16:34:51 Router8内核:[0.750171]   musb-hdrc:ConfigData=0xde (UTMI-8、dyn FIFO、大容量组合、大容量分离、HB-ISO Rx、 HB-ISO Tx、SoftConn)
    7月14日16:34:51 Router8内核:[0.750187]   musb-hdrc:MHDRC RTL 2.0版
    7月14日16:34:51 Router8内核:[0.750195]   musb-hdrc:设置 fifo_mode 4.
    7月14日16:34:51 Router8内核:[0.750210]   musb-hdrc:28/31 max EP,16384/16384内存
    7月14日16:34:51 Router8内核:[0.750312]   musb-hdrc musb-hdrc.1.auto: MUSB HDRC 主机驱动程序
    7月14日16:34:51 Router8内核:[0.750903]   musb-hdrc musb-hdrc.1.auto:新 USB 总线已注册,分配总线编号2
    7月14日16:34:51 Router8内核:[0.751098]   USB USB2:找到新的 USB 设备,idVendor=1d6b,idProduct=0002
    7月14日16:34:51 Router8内核:[0.751126]   USB USB2:新 USB 设备字符串:MFR=3、Product=2、SerialNumber=1
    7月14日16:34:51 Router8内核:[0.751152]   USB USB2:产品:MUSB HDRC 主机驱动程序
    7月14日16:34:51 Router8内核:[0.751171]   USB USB2:制造商:Linux 3.14.26R8A+ musb-hcd
    7月14日16:34:51 Router8内核:[0.751191]   USB USB2:Serial Number:musb-hdrc.1.auto
    7月14日16:34:51 Router8内核:[0.752211]   hub 2-0:1.0:找到 USB hub
    7月14日16:34:51 Router8内核:[0.752276]   hub 2-0:1.0:1端口
    7月14日16:34:51 Router8内核:[0.753697]    remoteproc0:wkup_m3可用
    7月14日16:34:51 Router8内核:[0.753738]    remoteproc0:注意:remoteproc 仍在开发中,并被视为实验。
    7月14日16:34:51 Router8内核:[0.753764]    remoteproc0:二进制格式尚未最终确定,并且无法保证向后兼容性。
    7月14日16:34:51 Router8内核:[0.753936]    remoteproc0:直接固件加载失败,错误-2
    7月14日16:34:51 Router8内核:[0.753960]    remoteproc0:返回到用户帮助程序
    7月14日16:34:51 Router8内核:[0.755607]   UBI:将 mtd2连接到 ubi0
    7月14日16:34:51 Router8内核:[0.898952]   musb-hdrc musb-hdrc.0.auto:在 a_wait_vrise 中出现 VBUS_ERROR (81,<SessEnd), retry #1, port1 00000100
    7月14日16:34:51 Router8内核:[1.051366]   musb-hdrc musb-hdrc.0.auto:在 a_wait_vrise 中出现 VBUS_ERROR (81、<SessEnd), retry #2, port1 00000100
    7月14日16:34:51 Router8内核:[1.146025]   UBI:扫描已完成
    7月14日16:34:51 Router8内核:[1.152744]   UBI 警告:print_rsvd_warning:无法为不良的 PEB 处理保留足够的 PEB,保留3,需要40
    7月14日16:34:51 Router8内核:[1.153910]   UBI:将 mtd2 (名称为"rootfs",大小为200 mib)连接到 ubi0
    7月14日16:34:51 Router8内核:[1.153947]   UBI:PEB 大小:524288字节(512 KiB)、LEB 大小:516096字节
    7月14日16:34:51 Router8内核:[1.153967]   UBI:最小/最大 I/O 单元大小:4096/4096、子页大小1024
    7月14日16:34:51 Router8内核:[1.153986]   UBI:VID 标头偏移:4096 (对齐4096)、数据偏移:8192
    7月14日16:34:51 Router8内核:[1.154005]   UBI:Good PEBs:400、Bad PEBs:0、Corrupted PEBs:0
    7月14日16:34:51 Router8内核:[1.154023]   UBI:用户卷:1,内部卷:1,最大 卷数:128
    7月14日16:34:51 Router8内核:[1.154045]   UBI:最大/平均擦除计数器:3/0、WL 阈值:4096、图像序列编号:337879669
    7月14日16:34:51 Router8内核:[1.154070]   UBI:可用 PEB:0,保留的 PEB 总数:400,保留的 PEB 用于不良 PEB 处理:3.
    7月14日16:34:51 Router8内核:[1.154889]   UBI:后台线程"ubI_bgt0d"已启动、PID 861
    7月14日16:34:51 Router8内核:[1.203829]   musb-hdrc musb-hdrc.0.auto:在 a_wait_vrise 中出现 VBUS_ERROR (81,<SessEnd), retry #3, port1 00000100
    7月14日16:34:51 Router8内核:[1.214246]   DaVinci_MDIO 4a101000.MDIO:达芬奇 MDIO 修订版本1.6
    7月14日16:34:51 Router8内核:[1.214284]   DaVinci_MDIO 4a101000.MDIO:检测到的 phy 掩码 fffffffc
    7月14日16:34:51 Router8内核:[1.215735]   libphy:4a101000.mdio:探测
    7月14日16:34:51 Router8内核:[1.215776]   DaVinci_MDIO 4a101000.MDIO:PHY[0]:device 4a101000.MDIO:00、driver Micrel KSZ8051、KSZ8081或 KSZ8091
    7月14日16:34:51 Router8内核:[1.215807]   DaVinci_MDIO 4a101000.MDIO:PHY[1]:器件4a101000.MDIO:01、驱动程序 Micrel KSZ8051、KSZ8081或 KSZ8091
    7月14日16:34:51 Router8内核:[1.216640]   cpsw 4a100000。以太网:随机 MACID = 72:31:E3:b0:cd:db
    7月14日16:34:51 Router8内核:[1.218089]   cpsw 4a100000。以太网:cpsw:随机 MACID = 12:96:87:50:9f:1c
    7月14日16:34:51 Router8内核:[1.222528]   tps65910-RTC tps65910-RTC:将系统时钟设置为2017-14:34:04 UTC (1500042844)
    7月14日16:34:51 Router8内核:[   1.285420] UBIFS:后台线程"ubifs_bgt0_0"已启动、PID 877
    7月14日16:34:51 Router8内核:[1.348070]   UBIFS:需要恢复
    7月14日16:34:51 Router8内核:[1.356253]   musb-hdrc musb-hdrc.0.auto:在 a_wait_vrise 中出现 VBUS_ERROR (80、<SessEnd), retry #3, port1 00080108
    7月14日16:34:51 Router8内核:[1.654574]   UBIFS:恢复完成
    7月14日16:34:51 Router8内核:[1.654738]   UBIFS:已安装 UBI 设备0,卷0,名称"rootfs"
    7月14日16:34:51 Router8内核:[1.654765]   UBIFS:LEB 大小:516096字节(504 KiB)、最小值/最大值 I/O 单元大小:4096字节/4096字节
    7月14日16:34:51 Router8内核:[1.654796]   UBIFS:FS 大小:197148672字节(188 MIB、382 LEB)、日志大小10452992字节(9 MIB、21 LEB)
    7月14日16:34:51 Router8内核:[1.654822]   UBIFS:为 root 保留:0字节(0 KiB)
    7月14日16:34:51 Router8内核:[   1.654846] UBIFS:媒体格式:W4/r0 (最新版本为 W4/r0),UUID 08A9E5AA-B77F-4C02-9394-86BD42DFC09F,小型 LPT 型号
    7月14日16:34:51 Router8内核:[1.656894]   VFS:在设备0:14上安装了根(ubifs 文件系统)。
    7月14日16:34:51 Router8内核:[1.659383]   devtmpfs:已安装
    7月14日16:34:51 Router8内核:[1.659813]   释放未使用的内核内存:332K (c0839000-c088c000)
    7月14日16:34:51 Router8内核:<30>[2.805417]   udevd[915]:开始版本182
    7月14日16:34:51 Router8内核:[2.961478]    remoteproc0:无法加载 AM335x-pm-firmware.elf
    7月14日16:34:51 Router8内核:[2.961586]    remoteproc0:启动 wkup_m3
    7月14日16:34:51 Router8内核:[2.961648]    remoteproc0:直接固件加载失败,错误-2
    7月14日16:34:51 Router8内核:[2.961667]    remoteproc0:返回到用户帮助程序
    7月14日16:34:51 Router8内核:[3.380084]   musb_proc_reinit 36:停止 USB 控制器
    7月14日16:34:51 Router8内核:[3.8979494]    remoteproc0:Request_firmware failed:-2
    7月14日16:34:51 Router8内核:[3.897521]   wkup_m3 44d00000。wkup_m3:rproc_boot 失败
    7月14日16:34:51 Router8内核:[4.860093]   IP_Tables:(c) 2000-2006 Netfilter 核心小组
    7月14日16:34:51 Router8内核:[5.615199]   NL_conntrack 版本0.5.0 (7943桶、最大31772)
    7月14日16:34:51 Router8内核:[6.359049]   power_mon:power monitor (8.1.5版)正在启动...
    7月14日16:34:51 Router8内核:[   6.359080] power_mon:CPU 类型= 0x2B94402E、partnum = 0x0000B944
    7月14日16:34:51 Router8内核:[6.359089]   power_mon:CPU 复位信息= 0x00000000
    7月14日16:34:51 Router8内核:[6.359310]   power_mon:设备系列版本:3.
    7月14日16:34:51 Router8内核:[6.3593555]   power_mon:硬件构建代码:7.
    7月14日16:34:51 Router8内核:[6.359383]   POWER_mon:器件版本:2.
    7月14日16:34:51 Router8内核:[6.498834]   GPIO-100 (USB_en):gpioD_request:status -16
    7月14日16:34:51 Router8内核:[6.498843]   power_mon:请求引脚100失败
    7月14日16:34:51 Router8内核:[6.558580]   power_mon:系统电源正常!
    7月14日16:34:51 Router8内核:[6.558587]   POWER_MON:无 UPS 电源!
    7月14日16:34:51 Router8内核:[6.845298]   power_mon:已成功启动!
    7月14日16:34:51 Router8内核:[7.1146443]   Tun:通用 TUN/Tap 设备驱动程序,1.6
    7月14日16:34:51 Router8内核:[7.114665]   Tun:(c) 1999-2004 Max Krasnyansky
    7月14日16:34:51 Router8内核:[7.298113]   usbcore:注册了新的接口驱动程序 usbserial
    7月14日16:34:51 Router8内核:[7.298999]   usbcore:注册的新接口驱动程序 usbserial_generic
    7月14日16:34:51 Router8内核:[7.299795]   usbserial:USB Serial Support registered for generic
    7月14日16:34:51 Router8内核:[   7.431766] usbcore:注册了新的接口驱动程序 FTDI_SIO
    7月14日16:34:51 Router8内核:[   7.433032] usbserial:为 FTDI USB 串行设备注册了 USB 串行支持
    7月14日16:34:51 Router8内核:[7.516479]   usbcore:注册的新接口驱动程序 dm9601
    7月14日16:34:51 Router8内核:[   7.572345] usbcore:注册的新接口驱动程序 MOSCHIP USB-Ethernet 驱动程序
    7月14日16:34:51 Router8内核:[7.619866]   [crash_dump] reg kmsg dumper
    7月14日16:34:51 Router8内核:[7.762386]   UBI:将 mtd3连接到 ubi1
    7月14日16:34:51 Router8内核:[8.602315]   UBI:扫描已完成
    7月14日16:34:51 Router8内核:[8.6158666]   UBI:将 mtd3 (名称“用户”,大小为815 MIB)连接到 ubi1.
    7月14日16:34:51 Router8内核:[8.615887]   UBI:PEB 大小:524288字节(512 KiB)、LEB 大小:520192字节
    7月14日16:34:51 Router8内核:[8.615895]   UBI:最小/最大 I/O 单元大小:4096/4096、子页大小1024
    7月14日16:34:51 Router8内核:[8.615904]   UBI:VID 标头偏移:1024 (对齐1024)、数据偏移:4096
    7月14日16:34:51 Router8内核:[8.615911]   UBI:Good PEBs:1631、Bad PEBs:0、Corrupted PEBs:0
    7月14日16:34:51 Router8内核:[8.615918]   UBI:用户卷:1,内部卷:1,最大 卷数:128
    7月14日16:34:51 Router8内核:[8.615928]   UBI:最大/平均擦除计数器:2/1、WL 阈值:4096、图像序列号:843908133
    7月14日16:34:51 Router8内核:[8.615936]   UBI:可用 PEB:0,总保留 PEB:1631,为错误的 PEB 处理保留的 PEB:40
    7月14日16:34:51 Router8内核:[8.623476]   UBI:后台线程"ubI_bgt1d"已启动、PID 1202
    7月14日16:34:51 Router8内核:[8.706977]   UBIFS:后台线程"ubifs_bgt1_0"已启动、PID 1207
    7月14日16:34:51 Router8内核:[8.908218]   UBIFS:已安装 UBI 设备1,卷0,名称"userfs"
    7月14日16:34:51 Router8内核:[8.908242]   UBIFS:LEB 大小:520192字节(508 KiB),最小/最大 I/O 单元大小:4096字节/4096字节
    7月14日16:34:51 Router8内核:[8.908255]   UBIFS:FS 大小:819822592字节(781 MIB、1576 LEB),日志大小33292288字节(31 MIB、64 LEB)
    7月14日16:34:51 Router8内核:[8.908263]   UBIFS:为 root 保留:4952683字节(4836 KiB)
    7月14日16:34:51 Router8内核:[8.908278]   UBIFS:媒体格式:W4/r0 (最新版本为 W4/r0)、UUID 747E0DAE-913F-4F7A-9D86-D1D84AE52BEC、Small LPT 模型
    7月14日16:34:51 Router8内核:[14.801865]  随机:Nginx urandom 读取可用7位熵
    7月14日16:34:51 Router8内核:[37.578112]  net eth0:正在初始化 cpsw 版本1.12 (0)
    7月14日16:34:51 Router8内核:[37.654375]  恢复 Micrel KSZ8051、KSZ8081或 KSZ8091
    7月14日16:34:51 Router8内核:[37.654637]  net eth0: Phy found : id is : 0x221561
    7月14日16:34:51 Router8内核:[  37.664826] IPv6:ADDRCONF (NETDEV_UP):eth0:链路未就绪
    7月14日16:34:51 Router8内核:[38.026775]  挂起 Micrel KSZ8051、KSZ8081或 KSZ8091
    7月14日16:34:51 Router8内核:[38.035165]  恢复 Micrel KSZ8051、KSZ8081或 KSZ8091
    7月14日16:34:51 Router8内核:[40.654797]  libphy: 4a101000.mdio:01 -链路已启动- 100/Full
    7月14日16:34:51 Router8内核:[  40.654855] IPv6:ADDRCONF (NETDEV_CHANGE):eth0:链路就绪
    7月14日16:34:51 Router8 putlogd[1969]:[管道工人]发现事件2
    7月14日16:34:51 Router8 putlogd[1969]:[regex] Regex 匹配:[sshd]服务器在0.0.0.0端口22上侦听。
    7月14日16:34:51 Router8 putlogd[1969]:[regex] Regex 匹配:[sshd]服务器侦听:端口22。
    7月14日16:34:51 Router8 dnsmasq[2036]:已开始,版本2.75高速缓存大小1500
    7月14日16:34:51 Router8 dnsmasq[2036]:编译时间选项:IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack 芯片组 auth no-DNSSEC 循环检测认证
    7月14日16:34:51 Router8 dnsmasq[2036]:警告:接口 lp1当前不存在
    7月14日16:34:51 Router8 dnsmasq[2036]:警告:接口 lp0当前不存在
    7月14日16:34:51 Router8 dnsmasq[2036]:警告:接口 mv0当前不存在
    7月14日16:34:51 Router8 dnsmasq[2036]:警告:接口 lv1当前不存在
    7月14日16:34:51 Router8 dnsmasq[2036]:警告:接口 lv0当前不存在
    7月14日16:34:51 Router8 dnsmasq[2036]:警告:未配置上游服务器
    7月14日16:34:51 Router8 dnsmasq-DHCP[2036]:DHCP,IP 范围172.22.1.2--172.22.2.253,租用时间无限
    7月14日16:34:51 Router8 dnsmasq-DHCP[2036]:DHCP,IP 范围172.22.0.2 -- 172.22.0.253,租用时间无限
    7月14日16:34:51 Router8 dnsmasq-dhcp[2036]:DHCP,IP 范围10.10.0.2-10.10.0.253,租用时间无限
    7月14日16:34:51 Router8 dnsmasq-DHCP[2036]:DHCP,IP 范围172.21.8.2 -- 172.21.15.253,租用时间无限
    7月14日16:34:51 Router8 dnsmasq-DHCP[2036]:DHCP,IP 范围172.20.8.2 -- 172.20.15.253,租用时间无限
    7月14日16:34:51 Router8 dnsmasq[2036]:阅读/etc/hosts - 2个地址
    7月14日16:35:13 Router8 alarmd[1320]:[daemon]检查事件(1)
    7月14日16:35:36 Router8的主节点:############################################################  #### PRIME 数据集中器版本4.0.0.12 #### ####  版权所有 Texas Instruments Inc、2017  #### ####################################
    7月14日16:35:36 Router8 PRIME 基本节点:正在初始化....
    7月14日16:35:36 Router8 Prime 基节点:启动 LNId =<1>....
    7月14日16:35:36 Router8的主节点: 0x003A6B33> msgSize=<24> count=<32>
    7月14日16:35:36 Router8的主节点: 0x0036ABE0> msgSize=<64> count=<128>
    7月14日16:35:36 Router8的主节点: 0x003A6B33> <1500042936:675389> tmoMbs<0>
    7月14日16:35:36 Router8的主节点: 0x003A6B33> <1500042936:666558> tmoMbs<2147483647>
    7月14日16:35:36 Router8的主节点: 0x003A6B33> 0:11313>等待 RC<0>/errno<0>
    7月14日16:35:36 Router8的主节点: 0x003A6B33> <1500042936:677997> tmoMbs<2147483647>
    7月14日16:35:36 Router8的主节点: 0x00142C54> msgSize=<16> count=<64>
    7月14日16:35:36 Router8的主节点: 0x00142CA4> msgSize=<28> count=<128>
    7月14日16:35:36 Router8的主节点: 0x00142B64> msgSize=<6> count=<128>
    7月14日16:35:36 Router8的主节点: 0x00142BB4> msgSize=<12> count=<64>
    7月14日16:35:36 Router8的主节点: 0x00142C04> msgSize=<12> count=<32>
    7月14日16:35:36 Router8的主节点: 0x00142D18> msgSize=<8>count=<128>
    7月14日16:35:36 Router8的主节点: 已尝试 Cnt<1>
    7月14日16:35:36 Router8的主节点: 0x0036ABE0> <1500042936:720457> tmogs <0>
    7月14日16:35:36 Router8的主节点: msgLen<6>
    7月14日16:35:36 Router8的主节点: CNT<10>
    7月14日16:35:36 Router8的主节点:   ::<0x05 0x80 0x06 0x00 0xb9 0x2D 0x00 0x00 >
    7月14日16:35:36 Router8的主节点:   :<0x00 0x00 >
    7月14日16:35:36 Router8的主节点: 0x00142DAC> msgSize=<12> count=<512>
    正在等待 MAC 线程出现...
    7月14日16:35:36 Router8的主节点: Mac 线程已启动...
    7月14日16:35:36 Router8的主节点: 条目...
    7月14日16:35:36 Router8的主节点: 0x00142CA4> <1500042936:727686> tmoMbs<0>
    7月14日16:35:36 Router8的主节点: 0x00142CA4> <1500042936:728459> tmoMbs<0>
    7月14日16:35:36 Router8的主节点: 0x00142CA4> <1500042936:728600> tmoMbs<0>
    7月14日16:35:36 Router8的主节点: 0x00142CA4> <1500042936:728731> tmoMbs<0>
    7月14日16:35:37 Router8 PRIME 基础节点: 0x003A6B33> <1500042937:678264> tmoMbs<0>
    7月14日16:35:37 Router8 PRIME 基础节点: 0x003A6B33> 1:728>等待 RC<0>/errno<0>
    7月14日16:35:37 Router8 PRIME 基础节点: 0x00142BB4> <1500042937:678817> tmoMbs<0>
    7月14日16:35:37 Router8 PRIME 基础节点: 0x003A6B33> <1500042937:678876> tmoMbs<2147483647>
    7月14日16:35:38 Router8的主节点: 0x003A6B33> <1500042938:681901> tmogs<0>
    7月14日16:35:38 Router8的主节点: 0x003A6B33> 1:3498>等待 RC<0>/errno<0>
    7月14日16:35:38 Router8的主节点: 0x00142BB4> <1500042938:682465> tmoMbs<0>
    7月14日16:35:38 Router8的主节点: 0x003A6B33> <1500042938:682520> tmoMbs<2147483647>
    7月14日16:35:39 Router8 putlogd[1969]:[管道工人]发现事件2
    7月14日16:35:39 Router8 putlogd[1969]:[regex] Regex 匹配:[sshd]接受的根密码来自192.168.0.11端口60686 ssh2
    7月14日16:35:39 Router8 PRIME 基础节点: 0x003A6B33> <1500042939:686335> tmoMbs<0>
    7月14日16:35:39 Router8 PRIME 基础节点: 0x003A6B33> 1:10363>等待 RC<0>/errno<0>
    7月14日16:35:39 Router8 PRIME 基础节点: 0x00142BB4> <1500042939:693050> tmoMbs<0>
    7月14日16:35:39 Router8 PRIME 基础节点: 0x003A6B33> <1500042939:693111> tmoMbs<2147483647>
    7月14日16:35:39 Router8 PRIME 基础节点: 发送 LMAC_MODIFY_DSP_PORT_SETTINGS 消息(SCI-A/SCI-B)到 DSP
    7月14日16:35:39 Router8 PRIME 基础节点: 0x0036ABE0> <1500042939:724236> tmoMbs<0>
    7月14日16:35:39 Router8 PRIME 基础节点: msgLen<9>
    7月14日16:35:39 Router8 PRIME 基础节点: 端口设置字节<0x0>
    7月14日16:35:39 Router8 PRIME 基础节点: CNT<13>
    7月14日16:35:39 Router8 PRIME 基础节点:   ::<0x0c 0x80 0x09 0x00 0xf0 0xce 0x61 0x9d>
    7月14日16:35:39 Router8 PRIME 基础节点:   :<0x01 0x00 0x01 0x00 0x00 >
    7月14日16:35:39 Router8 PRIME 基础节点: CNT<1>
    7月14日16:35:39 Router8 PRIME 基础节点:   :<0x00 >
    7月14日16:35:40 Router8 PRIME 基础节点: 0x003A6B33> <1500042940:693289> tmoMbs<0>
    7月14日16:35:40 Router8 PRIME 基础节点: 0x003A6B33> 1:651>等待 RC<0>/errno<0>
    7月14日16:35:40 Router8 PRIME 基础节点: 0x00142BB4> <1500042940:693856> tmoMbs<0>
    7月14日16:35:40 Router8 PRIME 基础节点: 0x003A6B33> <1500042940:693912> tmoMbs<2147483647>
    7月14日16:35:41 Router8的主节点: 0x003A6B33> <1500042941:694078> tmoMbs<0>
    7月14日16:35:41 Router8的主节点: 0x003A6B33> 1:620>等待 RC<0>/errno<0>
    7月14日16:35:41 Router8的主节点: 0x00142BB4> <1500042941:694623> tmoMbs<0>
    7月14日16:35:41 Router8的主节点: 0x003A6B33> <1500042941:694681> tmoMbs<2147483647>
    7月14日16:35:41 Router8的主节点: 0x0036ABE0> <1500042941:724396> tmoMbs<0>
    7月14日16:35:41 Router8的主节点: msgLen<34>
    7月14日16:35:41 Router8的主节点: 将器件模式设置为<0>、将 PRIME 标准版本设置为<0>
    7月14日16:35:41 Router8的主节点: CNT<38>
    7月14日16:35:41 Router8的主节点:   ::<0x0c 0x80 0x22 0x00 0xec 0x14 0x8a 0x0F >
    7月14日16:35:41 Router8的主节点:   ::<0x03 0x00 0x1a 0x00 0x00 0x00 0x00 0x00 0x00 >
    7月14日16:35:41 Router8的主节点:   ::<0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 >
    7月14日16:35:41 Router8的主节点:   :<0x00 0x00 0x00 0x00 0x00 0x00 0x00 >
    7月14日16:35:42 Router8的主节点: 0x003A6B33> <1500042942:694850> tmoMbs<0>
    7月14日16:35:42 Router8的主节点: 0x003A6B33> 1:625>等待 RC<0>/errno<0>
    7月14日16:35:42 Router8的主节点: 0x00142BB4> <1500042942:695393> tmoMbs<0>
    7月14日16:35:42 Router8的主节点: 0x003A6B33> <1500042942:695448> tmoMbs<2147483647>
    7月14日16:35:43 Router8 alarmd[1320]:[daemon]检查事件(1)
    7月14日16:35:43 Router8 PRIME 基础节点: 0x003A6B33> <1500042943:695609> tmoMbs<0>
    7月14日16:35:43 Router8 PRIME 基础节点: 0x003A6B33> 1:629>等待 RC<0>/errno<0>
    7月14日16:35:43 Router8 PRIME 基础节点: 0x00142BB4> <1500042943:696170> tmoMbs<0>
    7月14日16:35:43 Router8 PRIME 基础节点: 0x003A6B33> <1500042943:696229> tmoMbs<2147483647>
    7月14日16:35:43 Router8 PRIME 基础节点: 0x0036ABE0> <1500042943:724589> tmoMbs<0>
    7月14日16:35:43 Router8 PRIME 基础节点: 0x003A6B33> <1500042943:724702> tmoMbs<0>
    7月14日16:35:43 Router8 PRIME 基础节点: 条目...
    7月14日16:35:43 Router8 PRIME 基础节点: CNT<8>
    7月14日16:35:43 Router8 PRIME 基础节点:   :<0x01 0x80 0x04 0x00 0x2a 0x81 0x00 0x00 >
    7月14日16:35:43 Router8 PRIME 基础节点: 0x003A6B33> 0:28756>等待 RC<0>/errno<0>
    7月14日16:35:43 Router8 PRIME 基础节点: 0x003A6B33> <1500042943:725055> tmoMbs<2147483647>
    7月14日16:35:44 Router8 PRIME 基础节点: 0x003A6B33> <1500042944:696402> tmoMbs<0>
    7月14日16:35:44 Router8 PRIME 基础节点: 0x003A6B33> 1:4294939121>等待 RC<0>/errno<0>
    7月14日16:35:44 Router8 PRIME 基础节点: 0x00142BB4> <1500042944:696975> tmoMbs<0>
    7月14日16:35:44 Router8 PRIME 基础节点: 0x003A6B33> <1500042944:697036> tmoMbs<2147483647>
    7月14日16:35:45 Router8的主节点: 0x003A6B33> <1500042945:697184> tmoMbs<0>
    7月14日16:35:45 Router8的主节点: 0x003A6B33> 1:612>等待 RC<0>/errno<0>
    7月14日16:35:45 Router8的主节点: 0x00142BB4> <1500042945:697737> tmoMbs<0>
    7月14日16:35:45 Router8的主节点: 0x003A6B33> <1500042945:697796> tmoMbs<2147483647>
    7月14日16:35:45 Router8的主节点: 将 LMAC 帧 CFG-REQ 发送到 DSP
    7月14日16:35:45 Router8的主节点: CQ2287 CFP = 0
    7月14日16:35:45 Router8的主节点: 0x0036ABE0> <1500042945:726105> tmoMbs<0>
    7月14日16:35:45 Router8的主节点: SNA bcnSlotCnt<5>cfpOff <0>seqNr<0>/ msgLen<18>
    7月14日16:35:45 Router8的主节点: CNT<22>
    7月14日16:35:45 Router8的主节点:   ::<0x31 0x80 0x12 0x00 0x16 0x04 0x2F 0x7d>
    7月14日16:35:45 Router8的主节点:   ::<0x01 0x00 0xa0 0xbf 0x50 0xbd 0xd2 0xf7 >
    7月14日16:35:45 Router8的主节点:   :<0x05 0x00 0x00 0x00 0x00 0x00 0x00 >
    7月14日16:35:45 Router8的主节点: 0x003A6B33> <1500042945:727087> tmoMbs<0>
    7月14日16:35:45 Router8的主节点: 0x003A6B33> 0:29376>等待 RC<0>/errno<0>
    7月14日16:35:45 Router8的主节点: 0x003A6B33> <1500042945:727242> tmoMbs<2147483647>
    7月14日16:35:45 Router8的主节点: evtId<4>、csType<3>、cbFunc_p<0x3f410>
    7月14日16:35:45 Router8的主节点: evtId<6>、csType<3>、cbFunc_p<0x3f410>
    7月14日16:35:45 Router8的主节点: evtId<2>、csType<3>、cbFunc_p<0x3f410>
    7月14日16:35:45 Router8的主节点: 类型/cl<3>
    7月14日16:35:45 Router8的主节点: 加入确认-结果<0>/hndl<1>
    7月14日16:35:45 Router8的主节点: 广播连接句柄<1>
    7月14日16:35:45 Router8的主节点: 退出...
    7月14日16:35:45 Router8的主节点: 0x0032B1F0> msgSize=<20> count=<128>
    7月14日16:35:45 Router8的主节点: 0x0032B240> msgSize=<24> count=<512>
    7月14日16:35:45 Router8的主节点: 正在等待 CL-4-32线程出现...
    7月14日16:35:46 Router8的主节点: 0x003A6B33> <1500042946:698057> tmoMbs<0>
    7月14日16:35:46 Router8的主节点: 0x003A6B33> 1:4294938560>等待 RC<0>/errno<0>
    7月14日16:35:46 Router8的主节点: 0x00142BB4> <1500042946:698622> tmoMbs<0>
    7月14日16:35:46 Router8的主节点: 0x003A6B33> <1500042946:698687> tmoMbs<2147483647>
    7月14日16:35:46 Router8的主节点: 0x003A6B33> <1500042946:725193> tmoMbs<0>
    7月14日16:35:46 Router8的主节点: 0x003A6B33> 0:26757>等待 RC<0>/errno<0>
    7月14日16:35:46 Router8的主节点: 条目...
    7月14日16:35:46 Router8的主节点: 0x00142BB4> <1500042946:72551> tmoMbs<0>
    7月14日16:35:46 Router8的主节点: 0x003A6B33> <1500042946:725630> tmoMbs<2147483647>
    7月14日16:35:46 Router8的主节点: 已尝试 Cnt<2>
    7月14日16:35:46 Router8的主节点: 0x0036ABE0> <1500042946:725743> tmoMbs<0>
    7月14日16:35:46 Router8的主节点: msgLen<6>
    7月14日16:35:46 Router8的主节点: CNT<10>
    7月14日16:35:46 Router8的主节点:   ::<0x05 0x80 0x06 0x00 0xb9 0x2D 0x00 0x00 >
    7月14日16:35:46 Router8的主节点:   :<0x00 0x00 >
    7月14日16:35:46 Router8的主节点: CL-4-32线程已启动...
    7月14日16:35:46 Router8的主节点: 0x0032B1F0> <1500042946:735678>tmoMbs<0>
    7月14日16:35:46 Router8的主节点: 0x0036A4F0> msgSize=<64> count=<16>
    7月14日16:35:46 Router8的主节点: 0x0036A5C0> msgSize=<64> count=<16>
    7月14日16:35:46 Router8的主节点: 0x003A4230> msgSize=<16> count=<128>
    7月14日16:35:46 Router8的主节点: api_cntxt.maxFd<7>
    7月14日16:35:46 Router8的主节点: 0x003A4230> <1500042946:743820> tmoMbs<2147483647>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x003A6B33> <1500042947:700396> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x003A6B33> <1:4294942527>等待 RC<0>/errno<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x00142BB4> <1500042947:700958> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x003A6B33> <1500042947:701017> tmoMbs<2147483647>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x0036AB40> msgSize=<4> count=<16>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x0036AAF0> msgSize=<20> count=<16>
    7月14日16:35:47 Router8 PRIME 基础节点: 条目...
    7月14日16:35:47 Router8 PRIME 基础节点: 退出...
    7月14日16:35:47 Router8 PRIME 基础节点: 0x003696C0> msgSize=<24> count=<8>
    7月14日16:35:47 Router8 PRIME 基础节点: <0x0036972C> msgSize=<4> count=<8>
    7月14日16:35:47 Router8 PRIME 基础节点: <0x0036977C> msgSize=<24> count=<128>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x00142CA4> <1500042947:748981> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x0036A5C0> <1500042947:749240> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 请求绑定 SAP <192>
    7月14日16:35:47 Router8 PRIME 基础节点: SAP 已请求<192>
    7月14日16:35:47 Router8 PRIME 基础节点: SAP 已分配<0>
    7月14日16:35:47 Router8 PRIME 基础节点: App Emu -已分配 SAP <0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x00142CA4> <1500042947:751050> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x0036D284> msgSize=<112> count=<50>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x0036ABE0> <1500042947:752347> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: timer-id<1>
    7月14日16:35:47 Router8 PRIME 基础节点: attrId<69>/msgLen<6>
    7月14日16:35:47 Router8 PRIME 基础节点: CNT<10>
    7月14日16:35:47 Router8 PRIME 基础节点:   ::<0x03 0x80 0x06 0x00 0x20 0x0a 0x39 0xf2 >
    7月14日16:35:47 Router8 PRIME 基础节点:   :<0x45 0x00 >
    7月14日16:35:47 Router8 PRIME 基础节点: 尝试当前<1>/总 TX<1>/Rx<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x003A6B33> <1500042947:752827> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x003A6B33> 0:51866>等待 RC<0>/errno<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x003A6B33> <1500042947:752960> tmoMbs<2147483647>
    7月14日16:35:47 Router8 PRIME 基础节点: 新的 CFP:245
    7月14日16:35:47 Router8 PRIME 基础节点: 0x00142C04> <1500042947:754396> tmoMbs<0>
    7月14日16:35:47 Router8 PRIME 基础节点: 0x0036D284> <1500042947:756215> tmoMbs<2147483647>
    7月14日16:35:48 Router8 PRIME 基础节点: 0x003A6B33> <1500042948:701337> tmoMbs<0>
    7月14日16:35:48 Router8 PRIME 基础节点: 0x003A6B33> 1:4294916204>等待 RC<0>/errno<0>
    7月14日16:35:48 Router8 PRIME 基础节点: 0x00142BB4> <1500042948:701970> tmoMbs<0>
    7月14日16:35:48 Router8 PRIME 基础节点: 0x003A6B33> <1500042948:702028> tmoMbs<2147483647>
    7月14日16:35:48 Router8 PRIME 基础节点: 0x003A6B33> <1500042948:727360> tmoMbs<0>
    7月14日16:35:48 Router8 PRIME 基础节点: 0x003A6B33> 0:25596>等待 RC<0>/errno<0>
    7月14日16:35:48 Router8 PRIME 基础节点: 条目...
    7月14日16:35:48 Router8 PRIME 基础节点: 0x00142BB4> <1500042948:727728> tmoMbs<0>
    7月14日16:35:48 Router8 PRIME 基础节点: 0x003A6B33> <1500042948:727771> tmoMbs<2147483647>
    7月14日16:35:49 Router8的主节点: 0x003A6B33> <1500042949:702210> tmoMbs<0>
    7月14日16:35:49 Router8的主节点: 0x003A6B33> 1:4294942208>等待 RC<0>/errno<0>
    7月14日16:35:49 Router8的主节点: 0x00142BB4> <1500042949:702776> tmoMbs<0>
    7月14日16:35:49 Router8的主节点: 0x003A6B33> <1500042949:702833> tmoMbs<2147483647>
    7月14日16:35:49 Router8的主节点: 发送 LMAC_MODIFY_DSP_PORT_SETTINGS 消息(SCI-A/SCI-B)到 DSP
    7月14日16:35:49 Router8的主节点: 0x0036ABE0> <1500042949:725990> tmoMbs<0>
    7月14日16:35:49 Router8的主节点: msgLen<9>
    7月14日16:35:49 Router8的主节点: 端口设置字节<0x0>
    7月14日16:35:49 Router8的主节点: CNT<13>
    7月14日16:35:49 Router8的主节点:   ::<0x0c 0x80 0x09 0x00 0xf0 0xce 0x61 0x9d>
    7月14日16:35:49 Router8的主节点:   :<0x01 0x00 0x01 0x00 0x00 >
    7月14日16:35:49 Router8的主节点: CNT<1>
    7月14日16:35:49 Router8的主节点:   :<0x00 >
    7月14日16:35:50 Router8的主节点: 0x003A6B33> <1500042950:703011> tmoMbs<0>
    7月14日16:35:50 Router8的主节点: 0x003A6B33> 1:641>等待 RC<0>/errno<0>
    7月14日16:35:50 Router8的主节点: 0x00142BB4> <1500042950:703565> tmoMbs<0>
    7月14日16:35:50 Router8的主节点: 0x003A6B33> <1500042950:703622> tmoMbs<2147483647>
    7月14日16:35:51 Router8 PRIME 基础节点: 0x003A6B33> <1500042951:703799> tmoMbs<0>
    7月14日16:35:51 Router8 PRIME 基础节点: 0x003A6B33> 1:628>等待 RC<0>/errno<0>
    7月14日16:35:51 Router8 PRIME 基础节点: 0x00142BB4> <1500042951:704345> tmoMbs<0>
    7月14日16:35:51 Router8 PRIME 基础节点: 0x003A6B33> <1500042951:704402> tmoMbs<2147483647>
    7月14日16:35:51 Router8 PRIME 基础节点: 0x0036ABE0> <1500042951:726173> tmoMbs<0>
    7月14日16:35:51 Router8 PRIME 基础节点: msgLen<34>
    7月14日16:35:51 Router8 PRIME 基础节点: 将器件模式设置为<0>、将 PRIME 标准版本设置为<0>
    7月14日16:35:51 Router8 PRIME 基础节点: CNT<38>
    7月14日16:35:51 Router8 PRIME 基础节点:   ::<0x0c 0x80 0x22 0x00 0xec 0x14 0x8a 0x0F >
    7月14日16:35:51 Router8 PRIME 基础节点:   ::<0x03 0x00 0x1a 0x00 0x00 0x00 0x00 0x00 0x00 >
    7月14日16:35:51 Router8 PRIME 基础节点:   ::<0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 >
    7月14日16:35:51 Router8 PRIME 基础节点:   :<0x00 0x00 0x00 0x00 0x00 0x00 0x00 >
    7月14日16:35:52 Router8 PRIME 基础节点: 0x003A6B33> <1500042952:704577> tmoMbs<0>
    7月14日16:35:52 Router8 PRIME 基础节点: 0x003A6B33> 1:636>等待 RC<0>/errno<0>
    7月14日16:35:52 Router8 PRIME 基础节点: 0x00142BB4> <1500042952:705130> tmoMbs<0>
    7月14日16:35:52 Router8 PRIME 基础节点: 0x003A6B33> <1500042952:705190> tmoMbs<2147483647>
    [root@Router8:~]# pstree
    init-+-addax2ip_mon--addax2ip---5*[{addax2ip}]
        |-alarmd---alarmd---{alarmd}
        |-bash
        -cron
        |-dcu_mon--rundcu--mono--mono--mono---72*[{mono}]
        |-dnsmasq
        |-2*[ifplugd]
        |-klogd
        |-mf2b
        |-mysqld_safe---mysqld----26*[{mysqld}]
        |-Nginx--Nginx
        |-pcscd---{pcscd}
        |-PDC---15*[{PDC}]
        |-php-fpm --2*[php-fPM]
        -powman_mon--powmand
        |-putlogd
        |-snmpd
        |-sshd---sshd---bash--pstree
        |-syslogd
        -udevd--udevd
        μ`看门狗
    [root@Router8:~]# ps auxwwwfff
    用户      PID %CPU %MEM   VSZ  RSS TTY     STAT 开始  时间命令
    根        2 0.0      0.0 0    0 0 ?        S   16:34  0:00 [kthreadd]
    根        3 0.1 0.0     0    0 ?        S   16:34  0:00 \_[ksoftirqd/0]
    根        4 0.0      0    0 0 ?        S   16:34  0:00 \_[kwork/0:0]
    根        5 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[kworker/0:0H]
    根        6 0.1 0.0     0    0 ?        S   16:34  0:00 \_[kworker/U2:0]
    根        7 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[khelper]
    根        8 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[kdevtmpfs]
    根        9 0.0 0.0     0    0 ?        S   16:34  0:00 \_[kworker/U2:1]
    根       47 0.1 0.0     0    0 ?        S   16:34  0:00 \_[kwork/0:1]
    根      227 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[写回]
    根      230 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[bioset]
    根      231 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[加密]
    根      233 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[kblockd]
    根      330 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[khubd]
    根      441 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[转速]
    根      465 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[kswapd0]
    根      466 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[fsnotify_mark]
    根      467 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[nfsiod]
    根      772 0.0 0.0     0    0?        S   16:34  0:00 \_[IRQ/32-TI-am335]
    根      785 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[IPV6_addrconf]
    根      799 0.0 0.0     0    0 0 ?        S<  16:34  0:00 \_[延迟]
    根      800 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[kworker/U2:2]
    根      818 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[IRQ/87-4802A000]
    根      858 0.0 0.0     0    0?        S   16:34  0:00 \_[kwork/0:2]
    根      861 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[ubI_bgt0d]
    root      877 0.0 0.0     0    0 0 ?        S   16:34  0:00 \_[ubifs_bgt0_0]
    root     1117 0.0      0.0 0    0?        S<  16:34  0:00 \_[power_mon]
    根     1202 0.0      0    0 0 ?        S   16:34  0:00 \_[ubI_bgt1d]
    根     1207 0.0 0.0     0    0 ?        S   16:34  0:00 \_[ubifs_bgt1_0]
    根        部1 0.8 0.1  1688  596?        SS  16:34  0:01初始化[5]
    root      915 0.1 0.2  2716 1080?        SS  16:34  0:00 /lib/udev/udevd --daemon
    root     1064 0.0 0.1  2712  720?        S   16:34  0:00 \_/lib/udev/udevd --daemon
    根     1305 0.0 0.1 10600  752?        SL  16:34  0:00 /sbin/pcscd --APDU --config=/etc/reader.conf.d/libccidkerkey
    根     1311 0.1 0.3  1740 1708?        SLS 16:34  0:00 /usr/sbin/watchdog -c /etc/watchdog.conf
    根     1318 0.0 0.1  3312  512 ?        SS  16:34  0:00 /usr/local/bin/alarmd
    根     1320 0.0 0.1 12528  660?        SL  16:34  0:00 \_/usr/local/bin/alarmd
    根     1327 0.0 0.2  2600 1104?        S   16:34  0:00 /bin/sh /usr/local/bin/powman_mon
    根     1329 0.2   3144 1024?        SS  16:34  0:00 \_/usr/local/bin/powmand
    root     1407 0.0 0.0  1684  424?        SS  16:34  0:00 /usr/sbin/mf2b -c /etc/mf2b.conf
    根     部1413 0.0 0.5 17028 2740?        SS  16:34  0:00 Nginx:主进程/usr/sbin/nginx
    Nginx    3915 0.0 0.3 17028 1680?        S<  16:35  0:00 \_ Nginx:工作流程
    根     1418 0.0 0.4 15188 2436?        SS  16:34  0:00 php-fpm:主进程(/etc/php-fpm.conf)
    www.      1419 0.0 0.4 15188 2060?        S   16:34  0:00 \_ php-fpm:池 www.
    www.      1420 0.0 0.4 15188 2060?        S   16:34  0:00 \_ php-fpm:池 www.
    根     1465 0.0 0.0  1744  496?        S   16:34  0:00 /sbin/ifplugd --iface=eth0 --ignore-FAIL --ignore-retval --delay-up=0 --delay-down=0 --run=/etc/ifplugd/ifplugd.action
    根     1469 0.0 0.0  1744  476?        D   16:34  0:00 /sbin/ifplugd --iface=ppp0 --ignore-FAIL --ignore-retval --delay-up=0 --delay-down=0 --run=/etc/ifplugd/ifplugd.action
    根     1969 0.0 0.1  3120  752?        SS  16:34  0:00 /usr/local/bin/putlogd
    根     1974 0.0 0.1  1816  640?        SS  16:34  0:00 /sbin/syslogd
    root     1978 0.4 0.5  4144 2956?        SS  16:34  0:00 /sbin/klogd
    root     2013 0.0 0.2  5440 1020?        SS  16:34  0:00 /usr/sbin/sshd
    root     3765 0.4 0.4  8040 2440?        SS  16:35  0:00 \_ sshd:root@pts/0
    root     4039 0.0 0.3  2928 1564 pts/0   SS  16:35  0:00     \_-bash
    根     部5204 0.0 0.1  2476  928 pts/0   R+  16:36  0:00         \_ ps auxwwwfff
    根     2036 0.0 0.1  2372  712?        S   16:34  0:00 /usr/local/sbin/dnsmasq
    根     2052 0.0 0.2  2600 1096?        S   16:34  0:00 /bin/sh /usr/local/bin/addax2ip_mon
    根     2055 0.4 0.2 46648 1492?        SL  16:34  0:00 \_/usr/local/bin/addax2ip
    根     2525 0.2   2600 1260?        S   16:34  0:00 /bin/sh /mnt/dcu/mysql/bin/mysqld_safe --datadir=/mnt/db/var --pid-file=/var/run/mysqld.pid
    MySQL    2901 4.6 6.6 266644 33948?        SL  16:34  0:03 \_/mnt/dcu/mysql/bin/mysqld --basedir=/mnt/dcu/mysql --datadir=/mnt/db/var --plugin-dir=/mnt/dcu/mysql/lib/plugin --user=mysql --log-error=/mnt/db/var/Router8.err --pid-file=/var/run/mysqld.pid --socket=/tmp/mysql.sock --port=3306
    根     3128 0.0 0.2  2600 1152?        S   16:35  0:00 /bin/sh /usr/local/bin/dcu_mon
    根     3151 0.0 0.2  2596 1096?        S   16:35  0:00 \_/bin/sh /mnt/dcu/bin/rundcu
    root     3201 0.0 0.2  2596 1136?        S   16:35  0:00     \_/bin/sh /mnt/dcu/mono/bin/mono Add.DCHost.exe
    DCU      3208 31.5 7.9 132704 40184 ?        SL  16:35  0:23         \_/mnt/dcu/mono/bin/Mono --optimize=all、-shared、-fcmov Add.DCHost.exe
    根     3147 0.0 0.1  2044  716?        SS  16:35  0:00 /usr/sbin/cron
    根     3245 0.2 0.5  8360 2796?        S   16:35  0:00 /mnt/dcu/snmpd/sbin/snmpd -d -V -C -c /mnt/dcu/snmpd/share/snmp/snmpd.conf -M /mnt/dcu/snmpd/share/snmp/mibs -p /var/run/snmpd.pid
    根     3252 0.1 0.2  2928 1508 ttyO0   SS+ 16:35  0:00 -bash
    根     3956 0.3 0.7 138684 4016?        SSL 16:35  0:00 /mnt/dcu/prime/pdc -e A0:BF:50:BD:D2:F7 -d -c /dev/ttyO3 -a 1.
    该问题随机出现、很难确定导致故障的条件、但它发生在不同的器件上。 其中一个出现此故障(三次引导尝试):
    root@Router8:~]# dmesg
    [0.000000]在物理 CPU 0x0上引导 Linux
    [0.000000] Linux 版本3.14.26RTR8A+(root@UBS)(gcc 版本4.7.3 20130226 (预发布版本)(Crossstoo-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03))#147 Tue Oct25 15:12:44 EEST 2016
    [0.000000] CPU:ARMv7处理器[413fc082]修订版2 (ARMv7)、CR=10c5387d
    [0.000000]机器型号:AM335x RTR8A -添加了技术
    [0.000000] CMA:CMA:9e000000保留24 MIB
    [0.000000]内存策略:数据高速缓存写回
    [0.000000]在节点0上的总页:130560
    [0.000000]正常区域:用于 memmap 的1024页
    [0.000000]正常区域:保留0页
    [0.000000]正常区域:130560页、LIFO 批处理:31
    [0.000000] pcpu-alloc:[0] 0
    [0.000000]在区域顺序和移动分组中构建了1个区域列表。 总页数:129536
    [0.000000]内核命令行:console=ttyO0、115200n8 root=ubi0:rootfs rw ubi.mtd=2、4096 rootfstype=ubifs RouterWait ID=0xBDD243 RouterHard1=0x3100001A Hard2=0x230764C0 Adjtime_frecv=-2004537=roottime_dicks
    [0.000000] PID 哈希表条目:2048 (顺序:1、8192字节)
    [0.000000]条目高速缓存散列表条目:65536 (顺序:6、262144字节)
    [0.000000] inode 高速缓存散列表条目:32768 (顺序:5、131072字节)
    [0.000000]内存:483480K/522240K 可用(6075K 内核代码、386K rwdata、2308K rodata、334K init、356K BSS、 38760K 保留、0K HIGHMEM)
    [0.000000]虚拟内核内存布局:
    向量:0xff0000-0xff1000 (4KB)
    Fixmap:0xFF00000 - 0xFFE0000 (896 KB)
    vmalloc:0xe0800000 - 0x000000 (488MB)
    低内存:0xC0000000 - 0xe0000000 (512 MB)
    pkmap:bfe00000 - 0xC0000000 (2 MB)
    模块:bbf000000 - bbfe00000 (14 MB)
    init:0xc0839000-0xc088c914 (335KB)
    .bss:0xc08eea00 - 0xc0947d48 (357KB)
    [0.000000] IRQ:在0xfa200000 (修订版5.0)处找到具有128个中断的 INTC
    [0.000000]在1个活动控制器上总共有128个中断
    [0.000000] OMAP 时钟事件源:timer2为24000000 Hz
    [0.000012] sched_clock:24MHz 时为32位、分辨率为41ns、每1789566969942ns 换行一次
    [0.000293]控制台:彩色虚拟设备80x30
    [0.000325]校准延迟环路... 795.44茂物剪(lpj=3977216)
    [0.089443] pid_max:默认值:32768最小值:301
    [0.089545]安全框架已初始化
    [0.08900]安装高速缓存散列表条目:1024 (顺序:0、4096字节)
    [0.089611] mountpoint-cache 哈希表条目:1024 (顺序:0、4096字节)
    [0.096708] CPU:测试写入缓冲区一致性:好的
    [0.097077]为0x805f5250-0x805f52a8设置静态标识映射
    [0.098162] devtmpfs:已初始化
    [0.1002228] VFP 支持 v0.3:实施者41架构3第30部分版本 c 修订版3
    [0.107173] omap_hwmod:tptc0、使用 EDMA 中断开的 dt 数据
    [0.107251] OMAP-hwmod:tptc1、使用 EDMA 中断开的 dt 数据
    [0.107322] omap_hwmod:tptc2、使用 EDMA 中断开的 dt 数据
    [0.111481] OMAP-hwmod:debugss:_wait_target_disable 失败
    [0.154494] pinctrl 内核:已初始化 pinctrl 子系统
    [0.155632]稳压器-虚拟:无参数
    [0.157858] NET:注册协议系列16.
    [0.159961] DMA:为原子相干分配预分配256 K2B 池
    [0.162317]空闲:使用调速器梯
    [0.162335]空闲:使用调速器菜单
    [0.163052] ADD Technology、RTR8A 板
    [0.169010] SYSCON 44e10000.CONTROL_MODULE:regmap [mem 0x44e10000-0x44e107fb] registered
    [0.170555]平台49000000.EDMA:别名 fck 已存在
    [0.170580]平台49000000.EDMA:别名 fck 已存在
    [0.170594]平台49000000.EDMA:别名 fck 已存在
    [0.171443] gpiochip_add:器件上的寄存 GPIO 0至31:GPIO
    [0.171729] OMAP GPIO 硬件版本0.1
    [0.172587] gpiochip_add:在器件上注册了 GPIO 32至63:GPIO
    [0.173573] gpiochip_add:在器件上注册了64至95的 GPIO:GPIO
    [0.174581] gpiochip_add:在器件上注册了 GPIO 96至127:GPIO
    [0.182562] OMAP-GPMC 50000000。GPMC:找不到节点/pinmux@44e10800/nandflash_pins_default 的 pctldev、延迟探测
    [0.182595]平台50000000。GPMC:驱动程序 OMAP-GPMC 请求探测器延迟
    [0.185084]没有 ATAG?
    [0.185404]硬件断点:不支持调试架构0x4。
    [0.206443]生物:创建层块 为0
    [0.221572(2004) EDMA-DMA-ENGINE EDMA-DMA-ENGER.0:TI EDMA DMA 引擎驱动程序
    [0.222243] of _get_named_gpiod_flags:无法解析节点'/fixedregulator@0[0]的 GPIO 属性
    [0.222531] VBAT:5000mV
    [0.225546] i2c 内核:使用传统挂起方法的驱动程序[Palmas]
    [0.225557] i2c 内核:使用传统恢复方法的驱动程序[Palmas]
    [0.226272] SCSI 子系统已初始化
    [0.227223] usbcore:注册的新接口驱动程序 usbfs
    [0.227409] usbcore:注册的新接口驱动程序集线器
    [0.227624] usbcore:注册的新设备驱动程序 USB
    [0.228548] omap_i2c 4802a000.i2c:找不到节点/pinmux@44e10800/pinmux_i2c1_pins 的 pctldev、延迟探针
    [0.228576] platform 4802a000.i2c:驱动程序 omap_i2c 请求探测器延迟
    [0.228946] pps_core:LinuxPPS API 版本。 1已注册
    [0.228955] pps_core:软件版本 5.3.6 -版权所有2005-2007 Rodolfo Giometti
    [0.229084]已注册 PTP 时钟支持
    [0.231112] OMAP-mailbox 480c8000.mailbox:OMAP mailbox 修订版0x400
    [0.233095]切换到时钟源 Timer1
    [0.271358] NET:注册协议系列2.
    [0.272176] TCP 建立哈希表条目:4096 (顺序:2、16384字节)
    [0.272227] TCP 绑定哈希表条目:4096 (顺序:2、16384字节)
    [0.272272] TCP:已配置哈希表(建立4096 BIND 4096)
    [0.272338] TCP:Reno 注册
    [0.272352] UDP 哈希表条目:256 (顺序:0、4096字节)
    [0.272370] UP-Lite 哈希表条目:256 (顺序:0、4096字节)
    [0.272584] NET:注册协议系列1.
    [0.272967] RPC:注册后命名的 UNIX 套接字传输模块。
    [0.272980] RPC:注册的 UDP 传输模块。
    [0.272987] RPC:注册的 TCP 传输模块。
    [0.272993] RPC:注册的 TCP NFSv4 4.1反向通道传输模块。
    [0.273008] PCI:CLS 0字节,默认64
    [0.274194]硬件性能事件:通过 ARMv7 Cortex-A8 PMU 驱动器启用、提供5个计数器
    [0.277429] futex 散列表条目:256 (顺序:-1、3072字节)
    [0.456892] VFS:磁盘配额 dquot_6.5.2
    [0.456957] Dquot 高速缓存散列表条目:1024 (顺序0、4096字节)
    [0.457512] NFS:注册 id_resolver 密钥类型
    [0.457587]注册密钥类型 id_resolver
    [0.457595]注册了密钥类型 id_legacy
    [0.457636] jffs2:版本2.2。 (NAND)(摘要)\xffffffc2\xffffffffa9 2001-2006 Red Hat, Inc.
    [0.457790]熔丝初始化(API 版本7.22)
    [0.458298] msgmni 已设置为992
    [0.460231] NET:注册协议系列38.
    [0.460250]注册密钥类型非对称
    [0.460258]已注册非对称密钥解析器'x509'
    [0.460288]已注册 IO 调度程序 NOP
    [0.460296]已登记 IO 调度程序的截止日期
    [0.460318]注册的 IO 调度程序 cfq (默认值)
    [0.461950] pinctrl-single 44e10800.pinmux:142引脚、PA f9e10800大小568
    [0.462450] pinctrl-single 44e10800.pinmux:44e10800.pinmux 已请求引脚44e10848.0;无法申请使能功能。6.
    [0.462467] pinctrl-single 44e10800.pinmux:引脚18 (启用.6)状态-22
    [0.462482] pinctrl-single 44e10800.pinmux:无法从器件 pinctrl-single 上的组 pinmux_ENSE_Pins 请求引脚18 (44e10848.0)
    [0.462493] GPIO-of -helper 使能.6:应用设置时出错、反向
    [0.462553] pinctrl-single 44e10800.pinmux:44e10800.pinmux 已请求引脚44e10848.0;无法申请使能功能。6.
    [0.462566] pinctrl-single 44e10800.pinmux:引脚18 (启用.6)状态-22
    [0.462578] pinctrl-single 44e10800.pinmux:无法从器件 pinctrl-single 上的组 pinmux_ENSE_Pins 请求引脚18 (44e10848.0)
    [0.462587] GPIO-of -helper 使能.6:应用设置时出错、反向
    [0.462601] GPIO of -helper END.6:引脚不是从驱动程序配置的
    [0.462668] of_get_named_gpiod_flags 以状态0退出
    [0.463161] GPIO-of-helper 使能.6:分配的 GPIO id=0
    [0.463178] GPIO-of -helper 使能。6:就绪
    [0.465762]串行:8250/16550驱动程序,6个端口,启用 IRQ 共享
    [0.469548] 44e09000.serial:在 MMIO 0x44e09000 (IRQ = 88、base_baud = 3000000)处的 ttyO0为8250
    [1.172973]控制台[ttyO0]已启用
    [1.177567] 48022000.serial: tmio 0x48022000 (IRQ = 89、base_baud = 3000000)处的 ttyO1为8250
    [1.187345] 48024000.serial:在 MMIO 0x48024000 (IRQ = 90、base_baud = 3000000)处的 ttyO2是8250
    [1.197068]在 MMIO 0x481a6000 (IRQ = 60、base_baud = 3000000)处的481a6000.serial: ttyO3是8250
    [1.206785] 481a8000.serial:在 MMIO 0x481a8000 (IRQ = 61、base_baud = 3000000)处的 ttyO4是8250
    [1.216499] 481aa000.serial: tmio 0x481aa000处的 ttyO5 (IRQ = 62、base_baud = 3000000)是8250
    [1.22727272] OMAP_rng 48310010.rng:OMAP 随机数生成器版本 20.
    [1.244794]返修:模块已加载
    [1.253463] LOOP:模块已加载
    [1.257136](HCI_TTY):位于 HCI_TTY_INIT 内部
    [1.261700](HCI_TTY):已分配249、0
    [1.269101] mtdoops:必须提供 MTD 器件(mtddev=name/number)
    [1.279256] libphy:固定 MDIO 总线:探测
    [1.287157] PPP 通用驱动程序版本2.4.2
    [1.291917]已注册 PPP BSD 压缩模块
    [1.2966686]已注册 PPP Deflate Compression 模块
    [1.301760] NET:注册协议系列24.
    [1.306519] usbcore:注册的新接口驱动程序 aSix
    [1.312166] usbcore:注册的新接口驱动程序 ax88179_178a
    [1.318455] usbcore:注册的新接口驱动程序 CDC_ether
    [1.324529] usbcore:注册的新接口驱动程序 smsc95xx
    [1.330484] usbcore:注册的新接口驱动程序 net1080
    [1.336323] usbcore:注册了新接口驱动程序 CDC_Subset
    [1.342502] usbcore:注册的新接口驱动程序 CDC_NCM
    [1.349469] EHCI_hcd:USB 2.0 "增强型"主机控制器(EHCI)驱动程序
    [1.356064] EHI-PCI:EHCI PCI 平台驱动程序
    [1.360730] EHCI 平台:EHCI 通用平台驱动程序
    [1.366282] EHI-OMAP:OMAP-EHCI 主机控制器驱动程序
    [1.372420] usbcore:注册的新接口驱动程序 CDC_ACM
    [1.378134] CDC_ACM:用于 USB 调制解调器和 ISDN 适配器的 USB 抽象控制模型驱动程序
    [1.386385] usbcore:注册的新接口驱动程序 USB 存储
    [1.394638] of_get_named_gpio_FLAGS:无法解析节点'/ocp/usb@47400000/USB-phy@47401300[0]的 GPIO 属性
    [1.394702] 47401300.usb-phy 电源 VCC 未找到、使用虚拟稳压器
    [1.404068] musb-hdrc musb-hdrc.0.auto:无法请求 rx1。
    [1.409994] musb-hdrc musb-hdrc.0.auto: musb_init_controller 失败、状态为-517
    [1.417918]平台 musb-hdrc.0.auto:驱动程序 musb-hdrc 请求探测器延迟
    [1.425963] of _get_named_gpio_FLAGS:无法解析节点'/ocp/usb@47400000/USB-phy@47401b00[0]的 GPIO 属性
    [1.426014] 47401b00.usb-phy 电源 VCC 未找到、正在使用虚拟稳压器
    [1.435231] musb-hdrc musb-hdrc.1.auto:无法请求 rx1。
    [1.441140] musb-hdrc musb-hdrc.1.auto: musb_init_controller 失败、状态为-517
    [1.449070]平台 musb-hdrc.1.auto:驱动程序 musb-hdrc 请求探测器延迟
    [1.470219] userial_init:注册的4个 ttyGS*设备
    [1.470507] i2c 内核:使用传统挂起方法的驱动程序[RC-ds1307]
    [1.477043] i2c 内核:使用传统恢复方法的驱动程序[RC-ds1307]
    [1.484647] i2c /dev/entries 驱动程序
    [1.489997] OMAP-WDT:OMAP 看门狗计时器修订版0x01:初始超时60秒
    [1.498713] of_get_named_gpiod_flags 以状态0退出
    [1.498733] of_get_named_gpiod_flags 以状态0退出
    [1.498744] of_get_named_gpiod_flags 以状态0退出
    [1.498754] of_get_named_gpiod_flags 以状态0退出
    [1.498776] of_get_named_gpiod_flags 以状态0退出
    [1.499174] of_get_named_gpiod_flags 以状态0退出
    [1.499431] of_get_named_gpiod_flags 以状态0退出
    [1.499666] of_get_named_gpiod_flags 以状态0退出
    [1.500202] ledtrig-CPU:已注册以指示 CPU 上的活动
    [1.506626] OMAP-AES 53500000。AES:OMAP AES 硬件加速器版本:3.2
    [1.517820] usbcore:注册的新接口驱动程序 usbhid
    [1.523666] usbhid:USB HID 内核驱动程序
    [1.527563]平台44d00000。wkup_m3:驱动器 wkup_m3请求探测器延迟
    [1.537210]轮廓:使用 ARM/armv7
    [1.541158] ipip:IPv4 over IPv4隧道驱动程序
    [1.546891] GRE:GRE over IPv4多路信号分离器驱动程序
    [1.551798] IP_GRE:GRE over IPv4隧道驱动程序
    [1.558289] IPv4 over IPSec 隧道驱动程序
    [1.563454] TCP:立方注册
    [1.566790]正在初始化 XFRM netlink 套接字
    [1.571150] NET:注册协议系列10.
    [1.57839] SIT:IPv6 over IPv4隧道驱动程序
    [1.585061] ip6_GRE:GRE over IPv6隧道驱动程序
    [1.590952] NET:注册协议系列17.
    [1.59551] NET:注册协议系列15.
    [1.600138]注册了密钥类型 DNS_旋 变传感器
    [1.605265] CPU CPU0:of_pm_voltdm_notifier_register:无法获取 CPU0稳压器/voltdm:-517
    [1.614058] CPU CPU0:CPU0时钟通知器未就绪、请重试
    [1.619661]平台 cpufreq-cpu0.0:驱动程序 cpufreq-cpu0请求探测器延迟
    [1.627675] PM:DT 不提供电压调节数据 blob。
    [1.633821] PM:无 RTC 可用、仅 RTC 模式被禁用。
    [1.639247] ThumbEE CPU 扩展支持。
    [1.643585]正在注册 SWP/SWPB 仿真处理程序
    [1.649919] VBAT:正在禁用
    [1.652738]稳压器-虚拟:禁用
    [1.656952] OMAP-GPMC 50000000。GPMC:GPMC 版本6.0
    [1.662124] GPMC_mem_init:禁用映射在0x0-0x1000000的 CS 0
    [1.669474] Nand:device found、Manufacturer ID:0x2C、Chip ID:0x38
    [1.675910] nand:Micron MT29F8G08ABAWP
    [1.679936] nand:1024MiB、SLC、page size:4096、OOB size:224
    [1.685804]使用 OMAP-ECC_BCH16_CODE_HW ECC 方案
    [1.690815] nand:Calc NAND 子页大小从写入大小:1024
    [1.696729]在 MTD 器件 OMAP2-nand.0上找到4个部件分区
    [1.702761]在"OMAP2-nand.0"上创建4个 MTD 分区:
    [1.708118] 0x000000000000-0x380000:"U-Boot"
    [1.715178] 0x000000380000-0x000000880000:“内核”
    [1.722162] 0x000000880000-0x00000d080000:“rootfs”
    [1.749179] 0x00000d080000-0x000040000000:"用户"
    [1.841016] tps65910 1-002D:无中断支持、无内核 IRQ
    [1.847297] tps65910-gpio tps65910-gpio:未指定"TI"、"en-gpi-sleep"
    [1.847316] gpiochip_find_base:找到250的新基座
    [1.847597] gpiochip_add:在器件:tps65910上注册了250至255的 GPIO
    [1.853769] vrtc:1800mV
    [1.857058] vrtc:由 VBAT 供电
    [1.864064] VIO:1500mV
    [1.867034] VIO:由 VBAT 供电
    [1.874329] VDD_MPU:1262mV 时为912 <-> 1375mV
    [1.879126] VDD_MPU:由 VBAT 供电
    [1.886733] VDD_CORE:1137mV 时为912 <-> 1150mV
    [1.891625] VDD_CORE:由 VBAT 供电
    [1.898270] vdd3:5000mV
    [1.904179] vdig1:1800mV
    [1.907324] vdig1:由 VBAT 供电
    [1.914031] vdig2:1800mV
    [1.917171] vdig2:由 VBAT 供电
    [1.92399] Vpll:1800mV
    [1.926959] vpll:由 VBAT 供电
    [1.933578] Vdac:1800mV
    [1.936629] vdac:由 VBAT 供电
    [1.943260] vaux1:1800mV
    [1.946399] vaux1:由 VBAT 供电
    [1.953112] vaux2:3300mV
    [1.956255] vaux2:由 VBAT 供电
    [1.962950] vaux33:3300mV
    [1.966195] vaux33:由 VBAT 供电
    [1.973005] VMMC:3300mV 时为1800 <->3300mV
    [1.977645] VMMC:由 VBAT 供电
    [1.992494] tps65910-RTC tps65910-RTC:RTC 内核:将 tps65910-RTC 注册为 rtc0
    [2.000926] kernel_i2c:找到 kerkey 复位引脚:117
    [2.006266] OMAP_i2c 4802a000.i2c:100kHz 时的总线1修订版0.11
    [2.015345] musb-hdrc:ConfigData=0xde (UTMI-8、dyn FIFO、大容量组合、大容量分离、HB-ISO Rx、 HB-ISO Tx、SoftConn)
    [2.015362] musb-hdrc:MHDRC RTL 版本2.0
    [2.015371] musb-hdrc:设置 fifo_mode 4.
    [2.015386] musb-hdrc:28/31最大 EP、16384/16384存储器
    [2.015496] musb-hdrc musb-hdrc.0.auto: MUSB HDRC 主机驱动程序
    [2.021719] musb-hdrc musb-hdrc.0.auto:新 USB 总线已注册、分配的总线编号1
    [2.029848] USB USB1:找到新的 USB 器件、idVendor=1d6b、idProduct=0002
    [2.036695] USB USB1:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    [2.043972] USB USB1:产品:MUSB HDRC 主机驱动程序
    [2.048957] USB USB1:制造商:Linux 3.14.26RTR8A+ musb-hcd
    [2.055002] USB USB1:串行号:musb-hdrc.0.auto
    [2.061178]集线器1-0:1.0:找到 USB 集线器
    [2.065071]集线器1-0:1.0:检测到1个端口
    [2.072826] musb-hdrc:ConfigData=0xde (UTMI-8、dyn FIFO、大容量组合、大容量分离、HB-ISO Rx、 HB-ISO Tx、SoftConn)
    [2.072843] musb-hdrc:MHDRC RTL 版本2.0
    [2.072850] musb-hdrc:设置 fifo_mode 4.
    [2.072864] musb-hdrc:28/31最大 EP、16384/16384存储器
    [2.072968] musb-hdrc musb-hdrc.1.auto: MUSB HDRC 主机驱动程序
    [2.079285] musb-hdrc musb-hdrc.1.auto:新 USB 总线已注册、分配的总线编号2
    [2.087407] USB USB2:找到新的 USB 器件、idVendor=1d6b、idProduct=0002
    [2.094253] USB USB2:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    [2.101506] USB USB2:产品:MUSB HDRC 主机驱动程序
    [2.106503] USB USB2:制造商:Linux 3.14.26RTR8A+ musb-hcd
    [2.112535] USB USB2:Serial Number:musb-hdrc.1.auto
    [2.118489]集线器2-0:1.0:找到 USB 集线器
    [2.122339]集线器2-0:1.0:检测到1个端口
    [2.127702] remoteproc0:wkup_m3可用
    [2.132176] remoteproc0:注:remoteproc 仍在开发中并被视为实验。
    [2.141226] remoteproc0:二进制格式尚未最终确定、并且尚不能保证向后兼容性。
    [2.151849] remoteproc0:直接固件加载失败,并显示错误-2
    [2.158173] remoteproc0:返回到用户帮助程序
    [2.164477] UBI:将 mtd2连接到 ubi0
    [2.221604] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (81、<SessEnd), retry #1, port1 00000100
    [2.374013] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (81、<SessEnd), retry #2, port1 00000100
    [2.526439] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (81、<SessEnd), retry #3, port1 00000100
    [2.558977] UBI:扫描已完成
    [2.569355] UBI 警告:print_rsvd_warning:无法为不良的 PEB 处理保留足够的 PEB,保留3,需要40
    [2.580820] UBI:将 mtd2 (名称"rootfs",大小为200 mib)附加到 ubi0
    [2.587249] UBI:PEB 大小:524288字节(512 KiB)、LEB 大小:516096字节
    [2.594077] UBI:最小/最大 I/O 单元大小:4096/4096、子页大小1024
    [2.600805] UBI:VID 标头偏移:4096 (对齐4096)、数据偏移:8192
    [2.607717] UBI:良好 PEB:400、不良 PEB:0、损坏 PEB:0
    [2.613669] UBI:用户卷:1、内部卷:1、最大 卷数:128
    [2.620836] UBI:最大/平均擦除计数器:15/2、WL 阈值:4096、图像序列编号:821037718
    [2.629930] UBI:可用 PEB:0、总保留 PEB:400、为不良 PEB 处理保留的 PEB:3.
    [2.639031] UBI:后台线程"ubI_bgt0d"已启动、PID 861
    [2.678907] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (80、<SessEnd), retry #3, port1 00080108
    [2.70314] DaVinci_MDIO 4a101000.MDIO:达芬奇 MDIO 修订版本1.6
    [2.709245] DaVinci_MDIO 4a101000.MDIO:检测到的 phy 掩码 fffffffffc
    [2.716918] libphy: 4a101000.mdio:探测
    [2.720957] DaVinci_MDIO 4a101000.MDIO:PHY[0]:器件4a101000.MDIO:00、驱动程序 Micrel KSZ8051、KSZ8081或 KSZ8091
    [2.731385] DaVinci_MDIO 4a101000.MDIO:PHY[1]:器件4a101000.MDIO:01、驱动器 Micrel KSZ8051、KSZ8081或 KSZ8091
    [2.742617] cpsw 4a100000.以太网:随机 MACID = F6:2c:15:C3:8f:b4
    [2.750462] cpsw 4a100000.以太网:cpsw:随机 MACID = 62:4c:95:ff:61:ae
    [2.761875] tps65910-RTC tps65910-RTC:将系统时钟设置为2017-06-07 05:52:18 UTC (1496814738)
    [2.834178] UBIFS:后台线程"ubifs_bgt0_0"已启动、PID 877
    [2.902227] UBIFS:需要恢复
    [3.261568] UBIFS:恢复完成
    [3.265454] UBIFS:已安装的 UBI 设备0、卷0、名称"rootfs"
    [3.271491] UBIFS:LEB 大小:516096字节(504 KiB)、最小值/最大值 I/O 单元大小:4096字节/4096字节
    [3.280684] UBIFS:FS 大小:197148672字节(188 MIB、382 LEB)、日志大小10452992字节(9 MIB、21 LEB)
    [3.290655] UBIFS:为根保留:0字节(0 KiB)
    [3.295742] UBIFS:媒体格式:W4/r0 (最新版本为 W4/r0)、UUID 0694E8C4-7680-4E3D-ACCB-61FB5171CBED、小型 LPT 模型
    [3.308802] VFS:在设备0:14上安装了根(ubifs 文件系统)。
    [3.317327] devtmpfs:已安装
    [3.320718]释放未使用的内核内存:332K (c0839000 - c088c000)
    [4.515100] udevd[915]:开始版本182
    [4.679971] remoteproc0:无法加载 AM335x-pm-firmware.elf
    [4.686048] remoteproc0:为 wkup_m3加电
    [4.690463] remoteproc0:直接固件加载失败,并显示错误-2
    [4.696781] remoteproc0:返回到用户帮助程序
    [5.131691] musb_proc_reinit 36:停止 USB 控制器
    [5.927844] remoteproc0:Request_firmware failed:-2
    [5.927871] wkup_m3 44d00000。wkup_m3:rproc_boot 失败
    [6.564752] IP_Tables:(c) 2000-2006年 Netfilter 核心小组
    [7.288132] NF_conntrack 版本0.5.0 (7943桶、最大31772)
    [7.953257] POWER_MON:电源监控器(8.1.5版)正在启动...
    [7.953284] POWER_MON:CPU 类型= 0x2B94402E、partnum = 0x0000B944
    [7.953293] POWER_MON:CPU 复位信息= 0x00000002
    [7.953505] POWER_MON:器件系列版本:3.
    [7.953534] power_mon:硬件构建代码:7.
    [7.953569] power_mon:器件版本:2.
    [8.092988] GPIO-100 (USB_en):gpioD_request:status -16
    [8.092997] POWER_MON:请求引脚100失败
    [8.152731] power_mon:系统电源正常!
    [8.152738] power_mon:无 UPS 电源!
    [8.273111] POWER_mon:已成功启动!
    [8.603252] Tun:通用 TUN/Tap 器件驱动程序、1.6
    [8.603272] Tun:(c) 1999-2004 Max Krasnyansky
    [8.782057] usbcore:注册的新接口驱动程序 usbserial
    [8.784611] usbcore:注册的新接口驱动程序 usbserial_generic
    [8.785855] usbserial:USB Serial Support registered for generic
    [8.925203] usbcore:注册的新接口驱动程序 FTDI_SIO
    [8.926192] usbserial:为 FTDI USB Serial Device 注册了 USB Serial Support
    [9.095936] usbcore:注册的新接口驱动程序 dm9601
    [9.195544] usbcore:注册的新接口驱动程序 MOSCHIP USB-Ethernet 驱动程序
    [9.240963][crash_dump] reg kmsg dumper
    [9.387623] UBI:将 mtd3连接到 ubi1
    [10.228631] UBI:扫描完成
    [10.242145] UBI:将 mtd3 (名称"用户"、大小为815 MIB)附加到 ubi1.
    [10.242166] UBI:PEB 大小:524288字节(512 KiB)、LEB 大小:520192字节
    [10.242174] UBI:最小/最大 I/O 单元大小:4096/4096、子页大小1024
    [10.242182] UBI:VID 标头偏移:1024 (对齐1024)、数据偏移:4096
    [10.242189] UBI:良好 PEB:1631、不良 PEB:0、损坏 PEB:0
    [10.242197] UBI:用户卷:1、内部卷:1、最大 卷数:128
    [10.242208] UBI:最大/平均擦除计数器:76/21、WL 阈值:4096、图像序列编号:979960492
    [10.242216] UBI:可用 PEB:0、总保留 PEB:1631、为不良 PEB 处理保留的 PEB:40
    [10.249356] UBI:启动后台线程"ubI_bgt1d"、PID 1204
    [10.332910] UBIFS:后台线程"ubifs_bgt1_0"已启动、PID 1209
    [10.396152] UBIFS:需要恢复
    [10.399208] UBIFS 错误(pid 1208):CHECK_LPT_TYPE:LPT 节点类型1中的无效类型(0)
    [10.399229] CPU:0 PID:1208通信:安装被污染:g o 3.14.26RTR8A+#147
    [10.399239]回扫:
    [10.399284][ ](dump_backtrace)从[ ](show_stack+0x18/0x1c)
    [10.399292] R6:ddfb9000 R5:dc8c9f00 R4:00000001 R3:00000000
    [10.399324][ ](show_stack)从[ ](dump_stack+0x20/0x28)
    [10.399344][ ](dump_stack)从[ ](CHECK_LPT_TYPE+0x5c/0x6c)
    [10.399357][ ](CHECK_LPT_TYPE)从[ ](ubifs_unpack_node+0x3c/0xcc)
    [10.399364] R4:ddfb9000
    [10.399377][ ](ubifs_unpack_nnode)、来自[ ](ubifs_read_node+0x16c/0x1e4)
    [10.399383] r7:00000000 R6:ddfb9000 R5:dc8c9f00 R4:00000000
    [10.399403][ ](ubifs_read_nnode)、来自[ ](ubifs_LPT_lookup_脏 污+0x228/0x2ac)
    [10.399410] R10:ddfb9000 R9:00000000 R8:0007e770 r7:000005ee R6:dc81f300 R5:ddfb9000
    [10.399427] R4:ddfb982c
    [10.399451][ ](ubifs_LPT_lookup_脏)从[ ](ubifs_replay_journa+0x34/0x140c)
    [10.399458] R10:ddfb9000 R8:0007e770 r7:ddfe1000 R6:dc81f300 R5:ddfb9000 R4:ddfb982c
    [10.399483][ ](ubifs_replay_journal)、来自[ ](ubifs_mount+0xe90/0x15b8)
    [10.399490] R10:00000628 R9:00000000 R8:0007e770 r7:ddfe1000 R6:dc81f300 R5:ddfb9000
    [10.399506] R4:00000000
    [10.399532][ ](ubifs_mount)从[ ](LOAD_FS+0x4c/0x180)
    [10.399539] R10:00000000 R9:00000000 R8:c08b84a4 r7:c08b84a4 R6:dc81f500 R5:00000000
    [10.399554] R4:00000000
    [10.399570][ ](LOAD_FS)从[ ](vfs_kern_mount+0x54/0xd4)
    [10.399577] R10:dc81f540 R9:00000000 R8:00000000 r7:c08b84a4 R6:00000000 R5:dc81f500
    [10.399592] R4:ddebdcc0
    [10.399609][ ](vfs_kern_mount)、来自[ ](do_mount + 0x1fC/0x964)
    [10.399615] R8:00000020 r7:dc81f500 R6:00000000 R5:c08a79b4 R4:c08b84a4 R3:00000000
    [10.399638][ ](DO 安装)从[ ](sys_mount+0x8c/0xc0)
    [10.399645] R10:00000000 R9:ddf54000 R8:c000e9c4 r7:c0ed0000 R6:00018898 R5:dd896000
    [10.399661] R4:00000000
    [10.399675][ ](sys_mount)从[ ](RET_FAST_SYSCALL+0x0/0x30)
    [10.399682] r7:00000015 R6:00018898 R5:00000000 R4:00000000
    [10.39999] UBIFS 错误(pid 1208):ubifs_read_nnode:错误-22在8:469553读取 nnode
    [10.399709] CPU:0 PID:1208 Comm:Mount G o 3.14.26RTR8A+#147
    [10.399714]回扫:
    [10.399729][ ](dump_backtrace)从[ ](show_stack+0x18/0x1c)
    [10.399736] R6:ddfb9000 R5:dc8c9f00 R4:00000000 R3:00000000
    [10.399757][ ](show_stack)从[ ](dump_stack+0x20/0x28)
    [10.399770][ ](dump_stack)从[ ](ubifs_read_node+0x1ac/0x1e4)
    [10.399784][ ](ubifs_read_nnode)、来自[ ](ubifs_LPT_lookup_脏 污+0x228/0x2ac)
    [10.399790] R10:ddfb9000 R9:00000000 R8:0007e770 r7:000005ee R6:dc81f300 R5:ddfb9000
    [10.399807] R4:ddfb982c
    [10.399821][ ](ubifs_LPT_lookup_脏)从[ ](ubifs_replay_journa+0x34/0x140c)
    [10.399828] R10:ddfb9000 R8:0007e770 r7:ddfe1000 R6:dc81f300 R5:ddfb9000 R4:ddfb982c
    [10.399853][ ](ubifs_replay_journal)、来自[ ](ubifs_mount+0xe90/0x15b8)
    [10.399859] R10:00000628 R9:00000000 R8:0007e770 r7:ddfe1000 R6:dc81f300 R5:ddfb9000
    [10.399875] R4:00000000
    [10.399890][ ](ubifs_mount)从[ ](LOAD_FS+0x4c/0x180)
    [10.399896] R10:00000000 R9:00000000 R8:c08b84a4 r7:c08b84a4 R6:dc81f500 R5:00000000
    [10.399912] R4:00000000
    [10.399925][ ](LOAD_FS)从[ ](vfs_kern_mount+0x54/0xd4)
    [10.399932] R10:dc81f540 R9:00000000 R8:00000000 r7:c08b84a4 R6:00000000 R5:dc81f500
    [10.399947] R4:ddebdcc0
    [10.399960][ ](vfs_kern_mount)、来自[ ](do_mount + 0x1fC/0x964)
    [10.399966] R8:00000020 r7:dc81f500 R6:00000000 R5:c08a79b4 R4:c08b84a4 R3:00000000
    [10.399989][ ](DO 安装)从[ ](sys_mount+0x8c/0xc0)
    [10.3999999] R10:00000000 R9:ddf54000 R8:c000e9c4 r7:c0ed0000 R6:00018898 R5:dd896000
    [10.400011] R4:00000000
    [10.400024][ ](sys_mount)从[ ](RET_FAST_SYSCALL+0x0/0x30)
    [10.400031] r7:00000015 R6:00018898 R5:00000000 R4:00000000
    [10.400199] UBIFS:后台线程"ubifs_bgt1_0"停止
    [16.274735]随机:可使用16位熵读取 Nginx urandom
    [32.186988] Net eth0:正在初始化 cpsw 版本1.12 (0)
    [32.264066]恢复 Micrel KSZ8051、KSZ8081或 KSZ8091
    [32.264328] net eth0: Phy found : id is : 0x221561
    [32.274511] IPv6:ADDRCONF (NETDEV_UP):eth0:链路未就绪
    [32.637264]挂起 Micrel KSZ8051、KSZ8081或 KSZ8091
    [32.644482]恢复 Micrel KSZ8051、KSZ8081或 KSZ8091
    [1313.763260] random:非阻塞池已初始化
    [root@Router8:~]# cat /ftp/logs/last_kernel_panic.log
    Oops #1 2017-05-30Z13:39:36.206452
    <6>[0.000000]在物理 CPU 0x0上引导 Linux
    5>[0.000000] Linux 版本3.14.26RTR8A+(root@UBS)(gcc 版本4.7.3 20130226 (预发布版本)(crostad-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03))#147 Tue Oct25 15:12:44 EEST 2016
    6>[0.000000] CPU:ARMv7处理器[413fc082]修订版2 (ARMv7)、CR=10c5387d
    <6>[0.000000] CPU:PIPT/VIPT 非混叠数据高速缓存、VIPT 别名指令高速缓存
    <6>[0.000000]机器型号:AM335x RTR8A - ADD 技术
    6>[0.000000] CMA:CMA:9e000000保留24 MIB
    <6>[0.000000]内存策略:数据高速缓存写回
    节点0上的<7>[0.000000]总页:130560
    <7>[0.000000] free_area_init_node:节点0、pgdat c08e5bc0、node_mem_map df9ee000
    <7>[0.000000]正常区域:用于 memmap 的1024页
    <7>[0.000000]正常区域:保留0页
    <7>[0.000000]正常区域:130560页、LIFO 批处理:31
    <6>[0.000000] CPU:所有 CPU 均在 SVC 模式下启动。
    <6>[0.000000] AM335X ES2.1 (NEON)
    <7>[0.000000] pcpu-alloc:s0 r0 d32768 u32768 alloc=1*32768
    <7>[0.000000] pcpu-alloc:[0] 0
    <7>[0.000000]在区域顺序中构建了1个区域列表,移动分组在上。 总页数:129536
    5>[0.000000]内核命令行:console=ttyO0、115200n8 root=ubi0:rootfs rw ubi.mtd=2、4096 rootfstype=ubifs rootwait RouterID=0xBDD243 RouterHard1=0x3100001A RouterHard2=0x230764C0 Adjtime_frecv=-2004537_Adj10000
    <6>[0.000000] PID 哈希表条目:2048 (顺序:1、8192字节)
    <6>[0.000000]条目高速缓存散列表条目:65536 (顺序:6、262144字节)
    <6>[0.000000] inode 高速缓存散列表条目:32768 (顺序:5、131072字节)
    <7>[0.000000]内存:483480K/522240K 可用(6075K 内核代码、386K rwdata、2308K rodata、334K init、356K BSS、 38760K 保留、0K HIGHMEM)
    5>[0.000000]虚拟内核内存布局:
    5>[0.000000] 向量:0xff0000-0xff1000 (4KB)
    5>[0.000000] Fixmap:0xFF00000 - 0xFFE0000 (896 KB)
    5>[0.000000] vmalloc:0xe0800000 - 0x000000 (488MB)
    5>[0.000000] 低内存:0xC0000000 - 0xe0000000 (512 MB)
    5>[0.000000] pkmap:bfe00000 - 0xC0000000 (2 MB)
    5>[0.000000] 模块:bbf000000 - bbfe00000 (14 MB)
    5>[0.000000] .text:0xc0008000 - 0xc0838024 (8385KB)
    5>[0.000000] init:0xc0839000-0xc088c914 (335KB)
    5>[0.000000] .data:0xc088e000 - 0xc08ea00 (387 KB)
    5>[0.000000] .bss:0xc08eea00 - 0xc0947d48 (357KB)
    6>[0.0000] NR_IRQ:16 nr_IRQ:16 16.
    6>[0.000000] IRQ:在0xfa200000 (修订版5.0)处找到一个带有128个中断的 INTC
    <6>[0.000000]在1个活动控制器上总共有128个中断
    <6>[0.000000] OMAP 时钟事件源:24000000 Hz 时的 timer2
    6>[ 0.000012] sched_clock:24MHz 时为32位、分辨率为41ns、每1789566969942ns 换行一次
    6>[0.000029] OMAP 时钟源:Timer1为24000000 Hz
    <6>[0.000290]控制台:彩色虚拟设备80x30
    <6>[0.000321]校准延迟环路... 795.44茂物剪(lpj=3977216)
    <6>[0.089435] pid_max:默认值:32768最小值:301
    已初始化<6>[0.089541]安全框架
    <6>[0.089596]安装高速缓存散列表条目:1024 (顺序:0、4096字节)
    <6>[0.089607] mountpoint-cache 哈希表条目:1024 (顺序:0、4096字节)
    6>[0.096701] CPU:测试写入缓冲区一致性:好
    6>[0.097072]为0x805f5250 - 0x805f52a8设置静态标识映射
    <6>[ 0.098160] devtmpfs:已初始化
    <6>[0.100230] VFP 支持 v0.3:实施方41架构3第30部分版本 c 修订版3
    4>[0.107178] omap_hwmod:tptc0使用 EDMA 中断开的 dt 数据
    4>[0.107257] OMAP-hwmod:tptc1、使用 EDMA 中断开的 dt 数据
    4>[0.107327] omap_hwmod:tptc2、使用 EDMA 中断开的 dt 数据
    4>[0.11111483] OMAP-hwmod:debugss:_wait_target_disable 失败
    <6>[0.154486] pinctrl 内核:已初始化 pinctrl 子系统
    <6>[0.155634]稳压器-虚拟:无参数
    6>[0.157852] NET:注册协议系列16
    <6>[0.159949] DMA:为原子相干分配预分配256 K2B 池
    6>[0.162307]空闲:使用调速器梯
    <6>[0.162323]空闲:使用调速器菜单
    <7>[0.163046] ADD Technology、RTR8A 板
    <6>[0.168987] SYSCON 44e10000.CONTROL_MODULE:已注册 regmap [mem 0x44e10000-0x44e107fb]
    4>[0.170526]平台49000000.EDMA:别名 Fck 已存在
    4>[0.17052]平台49000000.EDMA:别名 Fck 已存在
    4>[0.170566]平台49000000.EDMA:别名 Fck 已存在
    <7>[0.171416] gpiochip_add:器件上的寄存 GPIO 0至31:GPIO
    6>[0.171704] OMAP GPIO 硬件版本0.1
    <7>[0.172567] gpiochip_add:器件上的寄存 GPIO 32至63:GPIO
    <7>[0.173545] gpiochip_add:器件上的寄存 GPIO 64至95:GPIO
    <7>[0.174546] gpiochip_add:器件上的寄存 GPIO 96至127:GPIO
    <6>[0.182517] OMAP-GPMC 50000000。GPMC:找不到节点/pinmux@44e10800/nandflash_pins_default 的 pctldev、延迟探测器
    <6>[0.182550]平台50000000.GPMC:驱动程序 OMAP-GPMC 请求探测器延迟
    <6>[0.185040]无 ATAG?
    <6>[0.185060]硬件断点:不支持调试架构0x4。
    6>[0.206396]生物:创建层块 为0
    <6>[0.221561] EDMA-DMA-engine EDMA-DMA-engine.0:TI EDMA DMA 引擎驱动程序
    <7>[0.222230] of_get_named_gpiod_flags:无法解析节点'/fixedregulator@0[0]的 GPIO 属性
    6>[0.222520] VBAT:5000mV
    4>[0.2255537] i2c-core:使用传统挂起方法的驱动程序[Palmas]
    <4>[0.225550] i2c-core:使用传统恢复方法的驱动程序[Palmas]
    已初始化<5>[0.226271] SCSI 子系统
    <6>[0.227215] usbcore:注册的新接口驱动程序 usbfs
    <6>[0.227404] usbcore:注册的新接口驱动程序集线器
    <6>[0.227616] usbcore:注册了新设备驱动程序 USB
    <6>[0.228547] omap_i2c 4802a000.i2c:找不到节点/pinmux@44e10800/pinmux_i2c1_pins 的 pctldev、延迟探针
    <6>[0.228574]平台4802a000.i2c:驱动程序 omap_i2c 请求探测器延迟
    <6>[0.228929] pps_core:LinuxPPS API 版本。 1已注册
    <6>[0.228938] pps_core:软件版本 5.3.6 -版权所有2005-2007 Rodolfo Giometti
    已注册<6>[0.229067] PTP 时钟支持
    6>[0.231106] OMAP-mailbox 480c8000.mailbox:OMAP mailbox 修订版0x400
    <6>[0.233115]切换到时钟源计时器1
    6>[0.271291] NET:注册协议系列2.
    <6>[0.272115] TCP 建立哈希表条目:4096 (顺序:2、16384字节)
    <6>[0.272167] TCP BIND 散列表条目:4096 (顺序:2、16384字节)
    <6>[0.272213] TCP:已配置哈希表(建立4096 BIND 4096)
    <6>[0.272278] TCP:Reno 注册
    <6>[0.27222] UDP 哈希表条目:256 (顺序:0、4096字节)
    <6>[0.272311] UP-Lite 哈希表条目:256 (顺序:0、4096字节)
    6>[0.2725] NET:注册协议系列1.
    <6>[0.272905] RPC:注册后命名为 UNIX 套接字传输模块。
    <6>[0.272918] RPC:注册的 UDP 传输模块。
    <6>[0.272924] RPC:注册的 TCP 传输模块。
    <6>[0.272931] RPC:注册的 TCP NFSv4.1反向通道传输模块。
    <7>[0.272946] PCI:CLS 0字节、默认64
    <6>[0.274136]硬件性能事件:通过 ARMv7 Cortex-A8 PMU 驱动器启用、提供5个计数器
    <6>[0.27739] futex 散列表条目:256 (顺序:-1、3072字节)
    5>[0.456854] VFS:磁盘配额 dquot_6.5.2
    <7>[0.456922] Dquot-cache 哈希表条目:1024 (顺序0、4096字节)
    5>[0.457470] NFS:注册 id_resolver 密钥类型
    已注册<5>[0.457544]密钥类型 id_resolver
    已注册<5>[0.457553]密钥类型 id_legacy
    <6>[0.457593] jffs2:版本2.2。 (NAND)(摘要)Copyright2001-2006 Red Hat, Inc.
    <6>[0.457749]熔丝初始化(API 版本7.22)
    <6>[0.458259] msgmni 已设置为992
    6>[0.460210] NET:注册协议系列38
    5>[0.460230]注册的密钥类型非对称
    已注册<5>[0.460238]非对称密钥解析器"x509"
    已注册<6>[0.460266] IO 调度程序 NOOP
    已注册<6>[0.460275] IO 调度程序截止日期
    已注册<6>[0.460297] IO 调度程序 cfq (默认值)
    <6>[0.461922] pinctrl-single 44e10800.pinmux:PA f9e10800大小568处142个引脚
    3>[0.462425] pinctrl-single 44e10800.pinmux:44e10800.pinmux 已请求引脚44e10848.0;无法请求使能。6.
    3>[0.462440] pinctrl-single 44e10800.pinmux:引脚18 (启用.6)状态-22
    3>[0.462454] pinctrl-single 44e10800.pinmux:无法从器件 pinctrl-single 上的组 pinmux_ENSE_Pins 请求引脚18 (44e10848.0)
    3>[0.462465] GPIO-of -helper 使能.6:应用设置时出错、反向
    3>[0.462522] pinctrl-single 44e10800.pinmux:44e10800.pinmux 已请求引脚44e10848.0;无法请求使能。6.
    3>[0.462535] pinctrl-single 44e10800.pinmux:引脚18 (启用.6)状态-22
    3>[0.462547] pinctrl-single 44e10800.pinmux:无法从器件 pinctrl-single 上的组 pinmux_ENSE_Pins 请求引脚18 (44e10848.0)
    3>[0.462557] GPIO-of -helper 使能.6:应用设置时出错、反向
    4>[0.462571] GPIO-of -helper 使能.6:引脚不是从驱动程序配置的
    7>[0.462636] of_get_named_gpiod_flags 以状态0退出
    <6>[0.463058] GPIO-of-helper 使能.6:分配的 GPIO id=0
    <6>[0.463073] GPIO-of -helper 使能.6:就绪
    <6>[0.465710]串行:8250/16550驱动程序,6个端口,启用 IRQ 共享
    MMIO 0x44e09000 (IRQ = 88、base_baud = 3000000)处的44e09000.serial: ttyO0为8250
    已启用<6>[1.172954]控制台[ttyO0]
    MMIO 0x48022000 (IRQ = 89、base_baud = 3000000)处的48022000.serial: ttyO1为8250
    MMIO 0x48024000 (IRQ = 90、base_baud = 3000000)处的<6>[1.187308] 48024000.serial: ttyO2是8250
    <6>[1.197054] 481a6000.serial: tmio 0x481a6000 (IRQ = 60、base_baud = 3000000)处的 ttyO3是8250
    MMIO 0x481a8000 (IRQ = 61、base_baud = 3000000)上的<6>[1.206770] 481a8000.serial: ttyO4是8250
    MMIO 0x481aa000 (IRQ = 62、base_baud = 3000000)处的<6>[1.216488] 481aa000.serial: ttyO5是一个8250
    6>[1.227283] OMAP_rng 48310010.rng:OMAP 随机数生成器版本。 20.
    <6>[1.244828]返修:模块已加载
    <6>[1.253528] loop:模块已加载
    <6>[1.257208](HCI_TTY):位于 HCI_TTY_INIT 内部
    <6>[1.261788](HCI_TTY):已分配249、0
    3>[1.269210] mtdoops:必须提供 MTD 器件(mtddev=name/number)
    <6>[1.279376] libphy:固定 MDIO 总线:探测
    6>[1.287281] PPP 通用驱动程序版本2.4.2
    已注册<6>[1.292044] PPP BSD 压缩模块
    已注册<6>[1.296815] PPP 深度压缩模块
    6>[1.30188] NET:注册协议系列24.
    6>[1.306642] usbcore:注册了新接口驱动程序 aSix
    <6>[1.312284] usbcore:注册的新接口驱动程序 ax88179_178a
    <6>[1.318579] usbcore:注册的新接口驱动程序 CDC_E醚
    <6>[1.324662] usbcore:注册的新接口驱动程序 smsc95xx
    <6>[1.330619] usbcore:注册的新接口驱动程序 net1080
    <6>[1.336458] usbcore:注册了新接口驱动程序 CDC_Subset
    <6>[1.342641] usbcore:注册了新接口驱动程序 CDC_NCM
    <6>[1.349617] EHCI_hcd:USB 2.0 "增强型"主机控制器(EHCI)驱动程序
    6>[1.356211] EHCI-PCI:EHCI PCI 平台驱动程序
    6>[1.360879] EHCI 平台:EHCI 通用平台驱动程序
    6>[1.366429] EHI-OMAP:OMAP-EHCI 主机控制器驱动程序
    <6>[1.372573] usbcore:注册了新接口驱动程序 CDC_ACM
    6>[1.378289] CDC_ACM:用于 USB 调制解调器和 ISDN 适配器的 USB 抽象控制模型驱动程序
    <6>[1.386544] usbcore:注册的新接口驱动程序 USB-storage
    7>[1.394816] of_get_named_gpio_FLAGS:无法解析节点'/ocp/usb@47400000/USB-phy@47401300[0]的 GPIO 属性
    <4>[1.394879] 47401300.usb-phy 电源 VCC 未找到、使用虚拟稳压器
    3>[1.404269] musb-hdrc musb-hdrc.0.auto:请求 rx1失败。
    3>[1.410193] musb-hdrc musb-hdrc.0.auto: musb_init_controller 失败、状态为-517
    <6>[1.418117]平台 musb-hdrc.0.auto:驱动程序 musb-hdrc 请求探测器延迟
    7>[1.426171] of_get_named_gpio_FLAGS:无法解析节点'/ocp/usb@47400000/USB-phy@47401b00[0]的 GPIO 属性
    <4>[1.426226] 47401b00.usb-phy 电源 VCC 未找到、使用虚拟稳压器
    3>[1.435492] musb-hdrc musb-hdrc.1.auto:无法请求 rx1。
    3>[1.441403] musb-hdrc musb-hdrc.1.auto: musb_init_controller 失败、状态为-517
    <6>[1.449326]平台 musb-hdrc.1.auto:驱动程序 musb-hdrc 请求探测器延迟
    <7>[1.470493] userial_init:注册的4个 ttyGS*设备
    4>[1.470785] i2c-core:使用传统挂起方法的驱动程序[RC-ds1307]
    4>[1.477315] i2c-core:使用传统恢复方法的驱动程序[RC-ds1307]
    <6>[1.484932] i2c /dev/entries 驱动程序
    6>[1.490300] OMAP-WDT:OMAP 看门狗计时器修订版0x01:初始超时60秒
    <7>[1.498990] of_get_named_gpiod_flags 以状态0退出
    <7>[1.499010] of_get_named_gpiod_flags 以状态0退出
    7>[1.499021] of_get_named_gpio_FLAGS 以状态0退出
    <7>[1.499030] of_get_named_gpiod_flags 以状态0退出
    <7>[1.499052] of_get_named_gpiod_flags 以状态0退出
    7>[1.499454] of_get_named_gpio_FLAGS 以状态0退出
    <7>[1.499714] of_get_named_gpiod_flags 以状态0退出
    <7>[1.499961] of_get_named_gpiod_flags 以状态0退出
    <6>[1.500502] ledtrig-CPU:注册以指示 CPU 上的活动
    6>[1.506934] OMAP-AES 53500000。AES:OMAP AES 硬件加速器版本:3.2
    <6>[1.518134] usbcore:注册的新接口驱动程序 usbhid
    <6>[1.523780] usbhid:USB HID 内核驱动程序
    6>[1.527871]平台44d00000。wkup_m3:驱动器 wkup_m3请求探针延迟
    <6>[1.537535]配置文件:使用 ARM/armv7
    6>[1.541489] ipip:IPv4 over IPv4隧道驱动程序
    6>[1.547230] GRE:基于 IPv4多路信号分离器驱动程序的 GRE
    6>[1.552138] IP_GRE:GRE over IPv4隧道驱动程序
    6>[1.558641] IPv4 over IPSec 隧道驱动程序
    <6>[1.563834] TCP:立方注册
    6>[1.567169]正在初始化 XFRM netlink 套接字
    6>[1.571532] NET:注册协议系列10
    6>[1.578722] SIT:IPv6 over IPv4隧道驱动程序
    6>[1.585468] ip6_GRE:GRE over IPv6隧道驱动程序
    6>[1.591373 ] NET:注册协议系列17.
    6>[1.595991] NET:注册协议系列15.
    已注册<5>[1.600574]密钥类型 DNS_旋 变传感器
    4>[1.605688] CPU CPU0:of_pm_voltdm_notifier_register:无法获取 CPU0稳压器/voltdm:-517
    3>[1.614482] CPU CPU0:CPU0时钟通知器未就绪、请重试
    <6>[1.620080]平台 cpufreq-cpu0.0:驱动程序 cpufreq-cpu0请求探测器延迟
    <4>[1.628100] PM:DT 未提供电压调节数据 blob。
    <4>[1.634249] PM:无 RTC 可用、仅 RTC 模式被禁用。
    支持<6>[1.639673] ThumbEE CPU 扩展。
    5>[1.644010]正在注册 SWP/SWPB 仿真处理程序
    <6>[1.650339] VBAT:正在禁用
    <6>[1.65327]稳压器-虚拟:正在禁用
    6>[1.657391] OMAP-GPMC 50000000。GPMC:GPMC 修订版6.0
    4>[1.662560] GPMC_mem_init:禁用映射在0x0-0x1000000的 CS 0
    6>[1.669896] nand:device found、Manufacturer ID:0x2C、Chip ID:0x38
    6>[1.676332] nand:Micron MT29F8G08ABAWP
    6>[1.680358] nand:1024MiB、SLC、page size:4096、OOB size:224
    <6>[1.686227]使用 OMAP-ECC_BCH16_CODE_HW ECC 方案
    6>[1.691237] nand:Calc NAND 子页大小从写入大小:1024
    5>[1.697152] 4个在 MTD 器件 OMAP2-nand.0上找到的部件分区
    5>[1.703196]在"OMAP2-nand.0"上创建4个 MTD 分区:
    5>[1.708538] 0x000000000000 0x000000380000:"U-Boot"
    5>[1.715603] 0x000000380000-0x000000880000:“内核”
    5>[1.722578] 0x000000880000-0x00000d080000:"rootfs"
    5>[1.749605] 0x00000d080000-0x000040000000:"用户"
    4>[1.841434] tps65910 1-002D:无中断支持、无内核 IRQ
    <7>[ 1.847708] tps65910-gpio tps65910-gpio:未指定 TI、en-gpi-sleep
    7>[ 1.847726] gpiochip_find_BASE:找到250的新基址
    <7>[1.848010] gpiochip_add:器件:tps65910上的寄存 GPIO 250至255
    6>[1.854191] Vrtc:1800mV
    6>[1.857481] vrtc:由 VBAT 供电
    VIO:1500mV 时为<6>[ 1.864446]
    VIO:由 VBAT 供电
    6>[1.874687] VDD_MPU:1262mV 时为912 <--> 1375mV
    VDD_MPU:由 VBAT 供电
    6>[1.887115] VDD_CORE:1137mV 时为912 <--> 1151mV
    VDD_CORE:由 VBAT 提供
    6>[1.898663] vdd3:5000mV
    <6>[1.904569] vdig1:1800mV
    6>[1.907711] vdig1:由 VBAT 供电
    6>[1.914431] vdig2:1800mV
    6>[1.917565] vdig2:由 VBAT 供电
    <6>[1.924277]升压:1800mV 时
    6>[1.927327] vpll:由 VBAT 供电
    Vdac <6>[1.933970]:1800mV
    Vdac:由 VBAT 供电
    6>[1.943659] vaux1:1800mV
    6>[1.946797] vaux1:由 VBAT 供电
    6>[1.953505] vaux2:3300mV
    6>[1.956646] vaux2:由 VBAT 提供
    6>[1.963354] vaux33:3300mV 时
    6>[1.966577] vaux33:由 VBAT 供电
    6>[1.973388] VMMC:3300mV 时为1800 <--> 3300mV
    6>[1.978009] VMMC:由 VBAT 供电
    6>[1.992814] tps65910-RTC tps65910-RTC:RTC 内核:将 tps65910-RTC 注册为 rtc0
    <6>[2.001249] kernel_i2c:找到 kerkey 复位引脚:117
    <6>[2.006579] OMAP-i2c 4802a000.i2c:100kHz 时的总线1 rev0.11
    <7>[2.015665] musb-hdrc:ConfigData=0xde (UTMI-8、dyn FIFO、大容量组合、大容量分离、HB-ISO Rx、 HB-ISO Tx、SoftConn)
    <7>[2.015681] musb-hdrc:MHDRC RTL 版本2.0
    <7>[2.015689] musb-hdrc:设置 fifo_mode 4.
    <7>[2.015704] musb-hdrc:28/31最大 EP、16384/16384存储器
    <6>[2.015814] musb-hdrc musb-hdrc.0.auto: MUSB HDRC 主机驱动程序
    <6>[2.022037] musb-hdrc musb-hdrc.0.auto:已注册新 USB 总线、分配总线编号1
    <6>[2.030173] USB USB1:找到新的 USB 器件、idVendor=1d6b、idProduct=0002
    6>[2.037020] USB USB1:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    <6>[2.044295] USB USB1:产品:MUSB HDRC 主机驱动程序
    6>[2.049281] USB USB1:制造商:Linux 3.14.26RTR8A+ musb-hcd
    <6>[2.055325] USB USB1:序列号:musb-hdrc.0.auto
    <6>[2.061506]集线器1-0:1.0:找到 USB 集线器
    <6>[2.065399]集线器1-0:1.0:检测到1个端口
    <7>[2.073204] musb-hdrc:ConfigData=0xde (UTMI-8、dyn FIFO、大容量组合、大容量分离、HB-ISO Rx、 HB-ISO Tx、SoftConn)
    <7>[2.073221] musb-hdrc:MHDRC RTL 版本2.0
    <7>[2.073229] musb-hdrc:设置 fifo_mode 4.
    <7>[2.073243] musb-hdrc:28/31最大 EP、16384/16384存储器
    <6>[2.073348] musb-hdrc musb-hdrc.1.auto: MUSB HDRC 主机驱动程序
    <6>[2.079622] musb-hdrc musb-hdrc.1.auto:新 USB 总线已注册、分配的总线编号2
    6>[2.087747] USB USB2:找到新的 USB 器件、idVendor=1d6b、idProduct=0002
    6>[2.094593] USB USB2:新 USB 器件字符串:MFR=3、Product=2、SerialNumber=1
    <6>[2.101847] USB USB2:产品:MUSB HDRC 主机驱动程序
    6>[2.106844] USB USB2:制造商:Linux 3.14.26RTR8A+ musb-hcd
    <6>[2.112876] USB USB2:序列号:musb-hdrc.1.auto
    <6>[2.118839]集线器2-0:1.0:找到 USB 集线器
    <6>[2.122694]集线器2-0:1.0:检测到1个端口
    <6>[2.128060] remoteproc0:wkup_m3可用
    <6>[2.132531] remoteproc0:注意:remoteproc 仍在开发中并被视为实验。
    <6>[2.141578] remoteproc0:二进制格式尚未最终确定、并且尚未保证向后兼容性。
    4>[2.152200] remoteproc0:直接固件加载失败、错误-2
    4>[2.158528] remoteproc0:返回到用户帮助程序
    5>[2.164846] UBI:将 mtd2连接到 ubi0
    7>[2.221933] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (81、<SessEnd), retry #1, port1 00000100
    7>[2.374347] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (81、<SessEnd), retry #2, port1 00000100
    7>[2.526771] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (81、<SessEnd), retry #3, port1 00000100
    5>[2.559271] UBI:扫描已完成
    4>[2.569644] UBI 警告:print_rsvd_warning:无法为不良的 PEB 处理保留足够的 PEB,保留3,需要40
    5>[2.581097] UBI:将 mtd2 (名称"rootfs"、大小为200 mib)连接到 ubi0
    5>[2.587533] UBI:PEB 大小:524288字节(512 KiB)、LEB 大小:516096字节
    <5>[2.594361] UBI:最小值/最大值 I/O 单元大小:4096/4096、子页大小1024
    5>[2.601088] UBI:VID 标头偏移:4096 (对齐4096)、数据偏移:8192
    5>[2.608000] UBI:良好 PEB:400、不良 PEB:0、损坏 PEB:0
    5>[2.621118] UBI:最大/平均擦除计数器:4/0、WL 阈值:4096、图像序列编号:821037718
    5>[2.630124] UBI:可用 PEB:0、总保留 PEB:400、为不良 PEB 处理保留 PEB:3.
    5>[2.639225] UBI:后台线程"ubi_bgt0d"已启动、PID 861
    3>[2.679238] musb-hdr musb-hdrc.0.auto:在 a_wait_vrise 中添加了 VBUS_ERROR (80、<SessEnd), retry #3, port1 00080108
    6>[2.703143] DaVinci_MDIO 4a101000.MDIO:达芬奇 MDIO 修订版本1.6
    6>[ 2.709265] DaVinci_MDIO 4a101000.MDIO:检测到的 phy 掩码 fffffffffc
    <6>[2.716847] libphy:4a101000.mdio:探测
    6>[ 2.720889] DaVinci_MDIO 4a101000.MDIO:PHY[0]:器件4a101000.MDIO:00、驱动器 Micrel KSZ8051、KSZ8081或 KSZ8091
    6>[2.731320] DaVinci_MDIO 4a101000.MDIO:PHY[1]:器件4a101000.MDIO:01、驱动器 Micrel KSZ8051、KSZ8081或 KSZ8091
    6>[2.742557] cpsw 4a100000.以太网:随机 MACID = 8a:0d:00:9b:82:34
    <6>[2.750401] cpsw 4a100000.以太网:cpsw:随机 MACID = 7a:21:95:45:C9:41
    <6>[2.761800] tps65910-RTC tps65910-RTC:将系统时钟设置为2017-05-22 07:54:22 UTC (1495439662)
    5>[2.834097] UBIFS:后台线程"ubifs_bgt0_0"已启动、PID 877
    <5>[2.900806] UBIFS:需要恢复
    5>[3.165065] UBIFS:恢复已完成
    5>[3.168897] UBIFS:已安装的 UBI 设备0、卷0、名称"rootfs"
    5>[3.174962] UBIFS:LEB 大小:516096字节(504 KiB)、最小值/最大值 I/O 单元大小:4096字节/4096字节
    5>[3.184149] UBIFS:FS 大小:197148672字节(188 MIB、382 LEB)、日志大小10452992字节(9 MIB、21 LEB)
    5>[3.194114] UBIFS:为根保留:0字节(0 KiB)
    5>[3.199192] UBIFS:媒体格式:W4/r0 (最新版本为 W4/r0)、UUID 0694E8C4-7680-4E3D-ACCB-61FB5171CBED、小型 LPT 模型
    <6>[3.210863] VFS:在设备0:14上安装根(ubifs 文件系统)。
    <6>[3.219390] devtmpfs:已安装
    <6>[3.222781]释放未使用的内核内存:332K (c0839000 - c088c000)
    <30>[4.419597] udevd[915]:开始版本182
    3>[4.579942] remoteproc0:无法加载 AM335x-pm-firmware.elf
    <6>[4.586021] remoteproc0:为 wkup_m3加电
    4>[4.590437] remoteproc0:直接固件加载失败、错误-2
    4>[4.596751] remoteproc0:返回到用户帮助程序
    <6>[4.975415] musb_proc_reinit 36:停止 USB 控制器
    3>[5.831278] remoteproc0:Request_firmware failed:-2
    3>[5.831303] wkup_m3 44d00000。wkup_m3:rproc_boot 失败
    <6>[6.471135] IP_Tables:(c) 2000-2006 Netfilter 核心团队
    <6>[ 7.197812] NP_conntrack 版本0.5.0 (7943桶、最大31772)
    <7>[7.844780] power_mon:功率监控器(8.1.5版)正在启动...
    <7>[ 7.844813] power_mon:CPU 类型= 0x2B94402E、器件型号= 0x0000B944
    <7>[ 7.844822] power_mon:CPU 复位信息= 0x00000002
    7>[7.845075] power_mon:器件系列版本:3.
    7>[7.845108] power_mon:硬件构建代码:7.
    7>[7.845144] power_mon:器件版本:2.
    <7>[7.984595] GPIO-100 (USB_en):gpioD_request:status -16
    <7>[7.984605] POWER_mon:请求引脚100失败
    <7>[8.044357] Power_mon:系统电源正常!
    <7>[8.044363] POWER_MON:无 UPS 电源!
    <7>[8.329644] power_mon:已成功启动!
    <6>[8.585521] Tun:通用 TUN/Tap 器件驱动程序、1.6
    <6>[8.585548] Tun:(c) 1999-2004 Max Krasnyansky
    6>[8.774933] usbcore:注册了新接口驱动程序 usbserial
    <6>[8.775862] usbcore:注册了新接口驱动程序 usbserial_generic
    6>[8.7766686] usbserial:USB Serial Support registered for generic
    6>[8.908176] usbcore:注册了新接口驱动程序 FTDI_SIO
    6>[8.909495] usbserial:为 FTDI USB 串行设备注册的 USB 串行支持
    <6>[9.040736] usbcore:注册的新接口驱动程序 dm9601
    6>[9.095455] usbcore:注册的新接口驱动程序 MOSCHIP USB-Ethernet 驱动程序
    <6>[9.140821][crash_dump] reg kmsg dumper
    5>[9.287031] UBI:将 mtd3连接到 ubi1
    5>[10.128051] UBI:扫描完成
    5>[10.141554] UBI:将 mtd3 (名称"用户"、大小为815 MIB)附加到 ubi1
    5>[10.141574] UBI:PEB 大小:524288字节(512 KiB)、LEB 大小:520192字节
    <5>[10.141583] UBI:最小值/最大值 I/O 单元大小:4096/4096、子页大小1024
    5>[10.141591] UBI:VID 标头偏移:1024 (对齐1024)、数据偏移:4096
    5>[10.141598] UBI:良好 PEB:1631、不良 PEB:0、损坏 PEB:0
    5>[10.141606] UBI:用户卷:1、内部卷:1、最大 卷数:128
    5>[10.141617] UBI:最大/平均擦除计数器:67/12、WL 阈值:4096、图像序列编号:979960492
    5>[10.141625] UBI:可用 PEB:0、总保留 PEB:1631、为不良 PEB 处理保留的 PEB:40
    5>[10.147862] UBI:启动后台线程"ubi_bgt1d"、PID 1202
    5>[10.232247] UBIFS:后台线程"ubifs_bgt1_0"已启动、PID 1207
    5>[10.441880] UBIFS:已安装 UBI 设备1、卷0、名称"userfs"
    5>[10.441904] UBIFS:LEB 大小:520192字节(508 KiB)、最小值/最大值 I/O 单元大小:4096字节/4096字节
    5>[10.441917] UBIFS:FS 大小:819822592字节(781 MIB、1576 LEB)、日志大小33292288字节(31 MIB、64 LEB)
    5>[10.441926] UBIFS:为根保留:4952683字节(4836 KiB)
    5>[10.4419141] UBIFS:媒体格式:W4/r0 (最新版本为 W4/r0)、UUID 6D542196-76dB-46E3-9A24-D81A1AD44017、小型 LPT 模型
    5>[16.314355]随机:可使用14位熵读取 Nginx urandom
    6>[32.227454] net eth0:正在初始化 cpsw 版本1.12 (0)
    <7>[32.304099]恢复 Micrel KSZ8051、KSZ8081或 KSZ8091
    6>[32.304361] net eth0:找到 PHY:id:0x221561
    6>[32.314569] IPv6:ADDRCONF (NETDEV_UP):eth0:链路未就绪
    <7>[32.675405]暂停 Micrel KSZ8051、KSZ8081或 KSZ8091
    <7>[32.682220]恢复 Micrel KSZ8051、KSZ8081或 KSZ8091
    5>[68.507758]随机:非阻塞池已初始化
    [1][711938.533318]无法处理虚拟地址79c38812处的内核分页请求
    [1][711938.533339] PgD = d5058000
    [1][711938.533347][79c38812]* PgD=00000000
    0>[711938.533366]内部错误:Oops:5 [#1] ARM
    7>[711938.533376]链接的模块:crash_dump (O) mcs7830 dm9601 XT_limit XT_conntrack FTDI_SIO IPT_reject usbserial XT_connlimit Tun XT_tcputcputp plnetemu (O) iptable_NAT power_mon (O) NL_connfrack_ip_nfrack_ip_nfrack_ipnv4_ipt_ipt_ipt_iptables_nfrack_iptablet nfrack_niptables_niptablet
    7][711938.533436] CPU:0 PID:4286 Comm:snmpd 被污染:g o 3.14.26RTR8A+#147
    7][711938.533447]任务:dcf8ec00 ti:dce54000 task.ti:dce54000
    7][711938.533476] PC 位于 netlink_autobind+0xe4/0x15c
    7][711938.533487] LR 位于 netlink_autobind+0xdc/0x15c
    7][711938.533498] PC:[ ] LR:[ ] PSR:200f0093
    7][711938.533498] sp:dce55d90 ip:dce55d90 fp:dce55dbc
    7][711938.533508] R10:c08df8f8 R9:ffefff R8:dce27000
    7][711938.533517] r7:dutcfad R6:000010be R5:dd863000 R4:79c3866a
    7][711938.533525] r3:c0503014 r2:001ce267 r1:79c3866a r0:00000001
    <7][711938.533536]标志:nzCv 在模式 SVC_32 ISA ARM 段用户上关闭 FIQ 的 IRQ
    7][711938.533545]控制:10c5387d 表:95058019 DAC:00000015
    0>[711938.533552]处理 snmpd (pid:4286、栈限制= 0xdce54238)
    0>[711938.533562]堆栈:(0xdce55d90至0xdce56000)
    0>[711938.533573] 5d80: 00000000 dce55ecc dce55e58 dce27000
    0>[711938.533587] 5da0:dd354940 00000000 00000000 00000000 dce55e1c dce55dc0 c05060f4 c0504f10
    0>[711938.533600] 5dc0:09697485 0002877c 00000101 00000003 00000018 00000000 0996e600 dcef65c0
    0>[711938.533612] 5de0:00000000 000010be 00000000 c03579e0 c0505f3c dce55e58 dcf8ec00
    0>[711938.533626] 5e00:00000000 befc058 dce54000 00000000 dce55eb4 dce55e20 c04d1f80 c0505f48
    0>[711938.533638] 5e20:00000000 00000000 dce55e58 dcf8ec00 00000000 00000000 00000000 00000000
    0>[711938.533650] 5e40:00000000 00000000 00000000 00000000 00000000 00000000 dce55e7c c08df8f8
    0>[711938.533663] 5e60:00000000 00000018 dd354940 c08df8f8 dce55ddc dce55ecc 00000000 dce55ebc
    0>[711938.533676] 5e80:dce55e9c dce55e90 c010c09c c010c01c dce55eb4 dce55ea0 c04d1c28 dd354940
    0>[711938.533689] 5ea0:00000018 00000000 dce55f8c ce55eb8 c04d3df4 c04d1efc c00eef08 fffffff7
    0>[711938.533701] 5ec0:00000000 befce058 00000018 00000000 00000000 dce55ec4 00000001 00000000
    0>[711938.533714] 5e0:00000000 c00f5000 c0068540 c08971b8 dce55f38 00000003 c066d400
    0>[711938.533727] 5f00:dd354940 00000000 dce55f34 dce55f18 c00f50c8 c00f4f58 c08971b8 dd354940
    0>[711938.533740] 5f20:00000000 0000000c dce55f6c dce55f38 c04d276c c00f50b8 dd81f690 dd745870
    0>[711938.533752] 5f40:00000000 00000007 c08df998 00000000 ce55f6c ce55f60 c010c858 c010c808
    0>[711938.533765] 5f60:dce55fa4 dce55f70 befc04c befd24d0 befc058 00000121 c000e9c4 00000000
    0>[711938.533778] 5f80:dce55fa4 dce55f90 c04d3e38 c04d3d48 00000000 00000000 dce55fa8
    0>[711938.533791] 5fa0:c000e840 c04d3e24 befc04c befd24d0 0000000c befcce058 00000018 00000000
    0>[711938.533804] 5fc0:befc04c befd24d0 befc058 00000121 befc070 00000002 befd24ec 00000000
    0>[711938.533816] 5fe0:00000000 befc03c b6e0e824 4c8228dc 600f0010 0000000c 00000000 00000000
    <7][711938.533823]回溯:
    7][711938.533841][ ](netlink_autobind)从[ ](netlink_sendmsg+0x1b8/0x380)
    7][711938.533849] R10:00000000 R9:00000000 R8:00000000 r7:dd354940 R6:dce27000 R5:dce55e58
    7][711938.533866] R4:dce55ecc R3:00000000
    7][711938.533895][ ](netlink_sendmsg)、来自[ ](SOCK_sendmsg+0x90/0xb0)
    7][711938.533902] R10:00000000 R9:dce54000 R8:befc058 r7:00000000 R6:dcf8ec00 R5:dce55e58
    7][711938.533918] R4:c0505f3c
    7][711938.533932][ ](sock_sendmsg)、来自[ ](sys_sendto+b8/0xdc)
    7][711938.533939] R6:00000000 R5:00000018 R4:dd354940
    7][711938.533955][ ](sys_sendto)从[ ](SYS_SEND+0x20/0x28)
    7][711938.533962] R10:00000000 R8:c000e9c4 r7:00000121 R6:befc058 R5:befd24d0 R4:befc04c
    7][711938.533993][ ](sys_send)、来自[ ](RET_FAST_SYSCALL+0x0/0x30)
    0>[711938.534007]代码:e59f007c e12fff33 e3500000 0a000002 (e59431a8)
    [4][711938.534035]--[末尾线迹 ea99b76d49ed3f49 ]--
    恐慌2 2017-05-30Z13:39:36.404762
    VIO:由 VBAT 供电
    VDD_MPU:由 VBAT 供电
    VDD_CORE:由 VBAT 提供
    Vdac:由 VBAT 供电
    0>[711938.534045][crash_dump]将紧急情况写入日志文件:/ftp/logs/last_kernel_panic.log、原因:2.
    <0>[711938.53677][crash_dump]调用 putlog.sh
    0>[711938.732367][crash_dump]为日志文件写入紧急信息已完成!
    0>[711938.732393]内核严重错误-未同步:致命异常
    dae64 c0103ff8 000000db 00000000 dcedd800 00000000 00000002
    0>[469190.021233] 1ba0:dcea06c0 000000db 00000000 dcfe1b84 c01040f0 dced1b0c dced1b0c dced1b0c dced1b0c
    0>[469190.021246] 1bc0:dcc393c0 000000db 00000000 dcfe1b84 c01040f0 c00693b0 dcfe1c84 acf3e1fd
    0>[469190.021259] 1be0:c05f1570 c006877c c0068780 c00693b0 dcfe1c9c dcfe1c00 c05f1570 c006877c
    0>[469190.021272] 1c00:00000000 00000800 00000000 00000029 001f5d28 dcfe1da8 00000000 00000800
    0>[469190.021284] 1c20:00000000 00000029 dcfe1cd4 dcfe1c38 c05f1570 c006877c 00000001 00000000
    0>[469190.021296] 1c40:00000000 0000000A 00000001 0000000A 00000000 00000000 dc301d58
    0>[469190.021310] 1c60:b6c13000 00000817 b6c13000 dcfe1d58 c05f9058 dcfe1e0c dcfe1c4 dcfe1c88
    0>[469190.021323] 1c80:c05f182c c05f142c 00000007 00000817 c05f17c8 ca1570f9 c07edb68 c07edb68
    0>[469190.021335] 1ca0:dcfe1ccc ca157169 c07edb6e c07edb6e 00000006 c07edb6f 00000000 ca157173
    0>[469190.021348] 1cc0:dcfe1d1c ca157173 ca157173 c02cf9d8 00000000 0000000a 0000000a ffffff
    0>[469190.021361] 1ce0:ca1570f9 00000f07 4c0a0000 ff000a dcfe1d3c ca0a0680 c07edb08 00000000
    0>[469190.021374] 1d00:00000000 00000000 ddafa800 dcfe1d34 dcfe1d20 c01118d4 c02cf6ec
    0>[469190.021386] 1d20:00000000 dcfe1d50 dcfe1d38 478bbced 00000141 dcfe1d5c dcfe1d48
    0>[469190.021399] 1d40:c00baf58 c00ba494 00000141 0000e4c0 dcfe1dec dcfe1d60 c00bc4c c00baf40
    0>[469190.021411] 1d60:00000141 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    0>[469190.021423] 1d80:00000000 00000000 00000000 00000000 000000000020 00000000 00000000 00000000
    0>[469190.021436] 1da0:c08e6680 00000000 00020200 df9d5358 00000000 ffff 00000000 c08e5bc0
    0>[469190.021449] 1dc0:dcfe1dfc dcfe1dd0 c00bc8c8 c00d6870 dfbd6874 dfbd6860 00000000 dfbd6860
    0>[469190.021462] 1de0:00000000 00000004 dcfe1e30 bed0aa20 dcfe0000 bed0aaa8 00000009 dcfe1e30
    0>[469190.021475] 1e00:dcfe1f5c dcfe1e10 c0104b28 c01043a0 dcfe1e44 bed0ab30 dcfe1e30 dcfe1e34
    0>[469190.021488] 1e20:dcfe1e38 dcfe1e3c dcfe1e40 dcfe1e44 00000168 00000000 00000000 00000000
    0>[469190.021501] 1e40:00000000 c066d46c dd72be60 dd72be60 c066d46c c066d46c dd72be60
    0>[469190.021514(XV) 1e60:dcfe1e84 dcfe1e70 c04d1800 c00ed91c c04d17cc dd72be60 dcfe1e9c dcfe1e88
    0>[469190.021527] 1e80:c010a4b8 c04d17d8 00000060 dd72be60 dcfe1eb4 dcfe1ea0 c010a5ac c010a484
    0>[469190.021540] 1ea0:dd74212c dd742100 dd72be60 dd72be60 dcfe1ed4 dcfe1ec0 c0106cd8 c00ed91c
    0>[469190.021553] 1ec0:dd742100 00000000 dcfe1efc dcfe1ed8 c01078f0 c0106ca0 dcfe1f24 dcfe1ee8
    0>[469190.021566] 1e0:c0076cb0 00000001 000728b7 27dc4293 00000006 dcfe1f68 1e1e0988 00000001
    0>[469190.021579] 1f00:dcfe1f30 00000009 00000000 bed0ab30 dcfe1f5c dcfe1f28 c0104384 c00402e8
    0>[469190.021592] 1f20:c0104370 c0076c6c 1e1e0988 dcfe1f38 000728b9 bed0a990 dcfe1f68 bed0aa8
    0][469190.021605] 1f40:bed0aa20 00000009 00000000 bed0ab30 dcfe1fa4 dcfe1f60 c0104df4 c01049fc
    0>[469190.021618] 1f60:dcfe1f68 bed0a8a8 000728b9 0a5f821b 00000001 0007b5c5 00000008 bed0a990
    0][469190.021630] 1f80:bed0a990 bed0ab28 0000008e c000e9c4 dcfe0000 00000000 dcfe1fa8
    0][469190.021643] 1fa0:c000e840 c0104d34 bed0a990 bed0a990 00000009 bed0aa20 bed0aa8 bed0ab30
    0][469190.021656] 1fc0:bed0a990 bed0a990 bed0ab28 0000008e bed0aa0 00000020 bed0a984 0000c916
    0>[469190.021669] 1fe0:00000000 bed0a938 0000b894 4c81a940 600f0010 00000009 00000000 00000000
    <7][469190.021675]回扫:
    7][469190.021692][ ](add_wait_queue)从[ ](_pollwait+0x98/0xf8)
    7][469190.021717][ ](__pollwait)、来自[ ](数据报_poll+0x34/0xf0)
    7>[469190.021724] r7:00008000 R6:dcfe1b84 R5:dcc393c0 R4:dce1dc00
    7][469190.021756][ ](数据报_poll),来自[ ](SOCK_POL+0x94/0x114)
    7>[469190.021763] R4:dd36d940 R3:c04def74
    7][469190.021779][ ](SOCK_POLL)从[ ](do_select+0x2a4/0x65c)
    7>[469190.021786] r7:00000020 R6:dcc393c0 R5:00000168 R4:00000020
    7][469190.021804][ ](DO _选择)从[ ](CORE_SYS_SELECT+0x138/0x338)
    7][469190.021811] R10:dcfe1e30 R9:00000009 R8:bed0aaa8 r7:dcfe0000 R6:bed0aa20 R5:dcfe1e30
    7>[469190.021827] R4:00000004
    7][469190.021839][ ](core_sys_select)从[ ](SYS_SELECT+0xCC/0x114)
    7][469190.021845] R10:bed0ab30 R9:00000000 R8:00000009 r7:bed0aa20 R6:bed0aa8 R5:dcfe1f68
    7][469190.021862] R4:bed0a990
    7][469190.021881][ ](sys_select)从[ ](RET_FAST_SYSCALL+0x0/0x30)
    7][469190.02188] R10:00000000 R9:dcfe0000 R8:c000e9c4 r7:0000008e R6:bed0ab28 R5:bed0a990
    7][469190.01904] R4:bed0a990
    0][469190.021918]代码:e3C22001 e483200c e10f2000 f10c0080 (e590c000)
    [4][469190.02194719a]--[结束线迹18ad3b3c4317266f ]--
    0>[469190.021957][crash_dump]将紧急情况写入日志文件:/ftp/logs/last_kernel_panic.log、原因:2.
    <0>[469190.024526][crash_dump]调用 putlog.sh
    0>[469190.472039][crash_dump]为日志文件写入紧急信息已完成!
    0>[469190.472065]内核严重错误-未同步:致命异常
    我将查看日志、并在遇到任何问题时提供一些反馈。
    Yordan
    我看到最后两个内核崩溃发生在您的以太网 phy 的挂起/恢复之后。
    它看起来像是内存损坏。 值得为您的以太网 DTS 节点加油打气。
    Yordan
    Yordan、
    根据客户信息、他们的应用中不使用以太网接口。
    您能不能建议您为什么认为问题与 DTS 中的以太网配置有关?
    另一点-这些 Oops 不时发生、现场的器件可以在一段时间内工作、然后才能解决问题。
    BR
    Ilya
    您好 Ilya、
    [报价]您能否告知您认为问题与 DTS 中的以太网配置有关的原因?[/报价]
    从日志中可以看到、当恢复 Micrel KSZ8051 phy 时、内核在虚拟地址79c38812崩溃:
    此外、您可以在稍后的内核紧急日志中看到、程序计数器位于 netlink:
    此外、他们在第二次检查他们的日志时、我发现他们有一些 pinmux 冲突:
    这会在提供的所有日志中发生。 确保他们检查这些 GPIO 的用途是什么、它们可以是使能引脚、IRQ 引脚或同步引脚、某些模块驱动程序需要这些引脚、当内核无法初始化这些引脚时、会在以后导致系统崩溃。
    Yordan
    团队、
    44e10800的引脚多路复用器(引脚18)不应影响系统性能、他们知道这种冲突、基本上这个引脚只控制外部模块、它工作正常
    您能再看一下、了解一下他们如何缩小问题的范围吗?
    与此同时、他们还发现另一个设备崩溃、附加的是来自该设备的日志、现在看起来它与以太网无关、而是文件系统(UBIFS)问题-在大多数情况下、客户获得的用户数据(userfs)已损坏。 格式化后、设备将再次正常运行。
    Ilya
    e2e.ti.com/.../3021.zip
