[参考译文] AM3352:AM3352-创建 WL_display 失败(无此类文件或目录)
Guru**** 2660255 points
Other Parts Discussed in Thread: AM3352
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1178430/am3352-am3352--failed-to-create-wl_display-no-such-file-or-directory
器件型号:AM3352
我们正在基于 AM3352的电路板上运行 Qt 应用。
当我们尝试执行任何 Qt 应用程序时、会出现以下错误:
root@am335x-evm:~# cd /usr/share/qt5/examples/gui/analogclock/
root@am335x-evm:/usr/share/qt5/examples/gui/analogclock# ./analogclock
Failed to create wl_display (No such file or directory)
qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland.
Aborted (core dumped)
我们还观察到 Weston 未运行。
root@AM335x-EVM:/proc #  cat /var/log/weston.log
日期:2000-01-01 UTC
[00:00:18.753] Weston 8.0.0
               https://wayland.freedesktop.org
               故障报告发送至: https://gitlab.freedesktop.org/wayland/weston/issues/
               编译:8.0.0
[00:00:18.753]命令行:Weston --idle-time=0
[00:00:18.753]操作系统:Linux、5.10.100-g7a7a3af903、#1挤占 Thu Dece 8 11:45:20 IST 2022、armv7l
[00:00:18.768]使用配置文件'/etc/weston.ini'
[00:00:18.775]重新喷漆窗口最长为7ms。
[00:00:18.789]正在加载模块"/usr/lib/libweston-8/drm-backend.so
[00:00:18.945]正在初始化 DRM 后端
[00:00:18.977] logind:未在系统会话中运行
[00:00:18.977] logind:无法使用传统回退设置 systemd-logind helper (-61)
[00:00:19.093]使用/dev/dri/card0
[00:00:19.093] DRM:支持通用平面
[00:00:19.093] DRM:支持原子模式设置
[00:00:19.093] DRM:支持图片宽高比
[00:00:19.170]加载模块"/usr/lib/libweston-8/gl-renderer.so
Mesa 加载程序:无法打开 kms_swast (搜索路径/usr/lib/dri)
无法加载驱动程序:kms_swrast
Mesa 加载程序:无法打开 swrast (搜索路径/usr/lib/dri)
无法加载 swrast 驱动程序
[00:00:19.830]初始化 EGL 失败
[00:00:19.858]致命:创建合成器后端失败
内部警告:未销毁调试范围"rm-backend"。
PVR:(错误):OpenServices:PVRDRMOpenRender 失败[0、]
PVR:(错误):PVRSRVConnect:无法打开连接。 [0、]
PVR:(错误):无法连接到服务[0、]
PVR:(错误):PVRDRIEGLGlobalDataInit: PVR 服务初始化失败[0、]
PVR:(错误):PVRDRICreateScreenImpl:无法创建 EGL 全局数据[0、]
执行 kmscube 时观察到以下情况:
root@am335x-evm:/usr/share/qt5/examples/gui/analogclock# kmscube
PVR:(Error): OpenServices: PVRDRMOpenRender failed [0, ]
PVR:(Error): PVRSRVConnect: Unable to open connection. [0, ]
PVR:(Error): Couldn't connect to services [0, ]
PVR:(Error): PVRDRIEGLGlobalDataInit: PVR Services initialisation failed [0, ]
PVR:(Error): PVRDRICreateScreenImpl: Couldn't create EGL global data [0, ]
MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast (search paths /usr/lib/dri)
failed to load swrast driver
Segmentation fault (core dumped)
请注意、我们能够通过将 RGB 数据直接写入帧缓冲器来在 LCD 上显示图像。
CAT IMAGE_NAME.RAW >/dev/fb0
我们能够在启动时看到 TI 的启动屏幕。
LCD 驱动程序和 DRM 似乎已正确初始化。 但是、我们无法执行任何 Qt 应用程序。
更多信息:
AM3352BZCZ SoC
512MB Samsung K4B4G1646B DDR3 RAM
SDK 版本:08_02_00_24
内核版本:5.10.100
U-Boot 版本:U-boot-2021.01
RFS:tisdk-default-image-am335x-evm
U-Boot SPL 2021.01-00003-gebb601d2e2-dirty (Oct 04 2022 - 12:12:52 +0530)
Trying to boot from MMC1
U-Boot 2021.01-00003-gebb601d2e2-dirty (Oct 04 2022 - 12:12:52 +0530)
CPU  : AM335X-GP rev 2.1
Model: Custom AM335x Custom
DRAM:  512 MiB
WDT:   Started with servicing (60s timeout)
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Loading Environment from FAT... *** Warning - bad CRC, using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net:   eth2: ethernet@4a100000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Failed to load 'boot.scr'
366 bytes read in 2 ms (178.7 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
Running uenvcmd ...
4997696 bytes read in 849 ms (5.6 MiB/s)
62038 bytes read in 16 ms (3.7 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
   Image Name:   Linux-5.10.100-g7a7a3af903
   Created:      2022-12-08   6:18:46 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    4997632 Bytes = 4.8 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 88000000
   Booting using the fdt blob at 0x88000000
   Loading Kernel Image
   Loading Device Tree to 8ffed000, end 8ffff255 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.100-g7a7a3af903 (vishwambhark@31197-427773) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Tool2
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Baxter AK98
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 48 MiB at 0x84800000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000080000000-0x0000000087efffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x0000000087efffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000087efffff]
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM335X ES2.1 (neon)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32226
[    0.000000] Kernel command line: console=ttyO0,115200n8 noinitrd rw rootfstype=ext3 root=/dev/mmcblk0p2 rootwait mem=128M
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 62976K/130048K available (10240K kernel code, 695K rwdata, 3408K rodata, 1024K init, 280K bss, 17920K reserved, 49152K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
[    0.000000] random: get_random_bytes called from start_kernel+0x30c/0x4c8 with crng_init=0
[    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
[    0.000009] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000028] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000349] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
[    0.001265] Console: colour dummy device 80x30
[    0.001306] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001314] This ensures that you still see kernel messages. Please
[    0.001320] update your kernel commandline.
[    0.001376] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[    0.090422] pid_max: default: 32768 minimum: 301
[    0.090582] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.090599] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.091485] CPU: Testing write buffer coherency: ok
[    0.091567] CPU0: Spectre v2: using BPIALL workaround
[    0.092444] Setting up static identity map for 0x80100000 - 0x80100060
[    0.092590] rcu: Hierarchical SRCU implementation.
[    0.092686] EFI services will not be available.
[    0.093053] devtmpfs: initialized
[    0.102611] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    0.102875] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.102903] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.106344] pinctrl core: initialized pinctrl subsystem
[    0.107355] DMI not present or invalid.
[    0.107837] NET: Registered protocol family 16
[    0.110115] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.127690] l3-aon-clkctrl:0000:0: failed to disable
[    0.128910] thermal_sys: Registered thermal governor 'fair_share'
[    0.128920] thermal_sys: Registered thermal governor 'bang_bang'
[    0.128935] thermal_sys: Registered thermal governor 'step_wise'
[    0.128942] thermal_sys: Registered thermal governor 'user_space'
[    0.129284] cpuidle: using governor ladder
[    0.129317] cpuidle: using governor menu
[    0.705143] No ATAGs?
[    0.705175] hw-breakpoint: debug architecture 0x4 unsupported.
[    0.728083] iommu: Default domain type: Translated
[    0.730069] SCSI subsystem initialized
[    0.730770] mc: Linux media interface: v0.10
[    0.730822] videodev: Linux video capture interface: v2.00
[    0.730936] pps_core: LinuxPPS API ver. 1 registered
[    0.730945] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.730969] PTP clock support registered
[    0.731032] EDAC MC: Ver: 3.0.0
[    0.732235] Advanced Linux Sound Architecture Driver Initialized.
[    0.733628] clocksource: Switched to clocksource dmtimer
[    0.741274] NET: Registered protocol family 2
[    0.741458] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
[    0.742355] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.742390] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.742410] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.742428] TCP: Hash tables configured (established 1024 bind 1024)
[    0.742549] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.742572] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.742698] NET: Registered protocol family 1
[    0.743268] RPC: Registered named UNIX socket transport module.
[    0.743283] RPC: Registered udp transport module.
[    0.743290] RPC: Registered tcp transport module.
[    0.743297] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.743316] PCI: CLS 0 bytes, default 64
[    0.744436] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[    0.745684] Initialise system trusted keyrings
[    0.746069] workingset: timestamp_bits=14 max_order=15 bucket_order=1
[    0.749681] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.750498] NFS: Registering the id_resolver key type
[    0.750552] Key type id_resolver registered
[    0.750562] Key type id_legacy registered
[    0.750656] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.750669] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.750710] ntfs: driver 2.1.32 [Flags: R/O].
[    0.751338] Key type asymmetric registered
[    0.751357] Asymmetric key parser 'x509' registered
[    0.751416] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.751428] io scheduler mq-deadline registered
[    0.751437] io scheduler kyber registered
[    1.075089] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    1.178327] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
[    1.178378] edma 49000000.dma: TI EDMA DMA engine driver
[    1.190501] pinctrl-single 44e10800.pinmux: 142 pins, size 568
[    1.194571] pwm-backlight backlight: supply power not found, using dummy regulator
[    1.243464] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    1.248314] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
[    1.927975] printk: console [ttyS0] enabled
[    1.935498] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.943721] random: fast init done
[    1.947428] random: crng init done
[    1.968243] panel-simple panel: supply power not found, using dummy regulator
[    1.975944] panel-simple panel: Specify missing connector_type
[    1.995456] brd: module loaded
[    2.005902] loop: module loaded
[    2.073670] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    2.083291] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI TLK10X 10/100 Mbps PHY
[    2.093282] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    2.099760] cpsw 4a100000.ethernet: ALE Table size 1024
[    2.105178] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    2.112410] cpsw 4a100000.ethernet: Detected MACID = 98:f0:7b:12:f6:85
[    2.121375] i2c /dev entries driver
[    2.128391] cpuidle: enable-method property 'ti,am3352' found operations
[    2.136064] sdhci: Secure Digital Host Controller Interface driver
[    2.142280] sdhci: Copyright(c) Pierre Ossman
[    2.147877] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.155431] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
[    2.164572] ledtrig-cpu: registered to indicate activity on CPUs
[    2.174315] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
[    2.197385] davinci-mcasp 4803c000.mcasp: IRQ common not found
[    2.225309] NET: Registered protocol family 10
[    2.234233] Segment Routing with IPv6
[    2.238005] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.259762] NET: Registered protocol family 17
[    2.269546] Key type dns_resolver registered
[    2.281698] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
[    2.290366] omap_voltage_late_init: Voltage driver support not added
[    2.301826] Loading compiled-in X.509 certificates
[    2.331511] OMAP GPIO hardware version 0.1
[    2.337822] mmc0: new high speed SDXC card at address 59b4
[    2.344897] mmcblk0: mmc0:59b4 SD64G 59.4 GiB
[    2.349434] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
[    2.360110]  mmcblk0: p1 p2
[    2.374787] tps65217-pmic: Failed to locate of_node [id: -1]
[    2.398978] tps65217-bl: Failed to locate of_node [id: -1]
[    2.408938] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[    2.414973] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 100 kHz
[    2.425957] mmc1: new high speed MMC card at address 0001
[    2.441925] omap_reset_deassert: timedout waiting for gfx:0
[    2.448084] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
[    2.453009] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
[    2.459358] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
[    2.465456] ti-sysc: probe of 5600fe00.target-module failed with error -110
[    2.474042] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB, chardev (243:0)
[    2.483340] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[    2.493462]  mmcblk1: p1 p2 p3 < p5 >
[    2.551114] Console: switching to colour frame buffer device 100x37
[    2.571845] tilcdc 4830e000.lcdc: [drm] fb0: tilcdcdrmfb frame buffer device
[    2.581368] ALSA device list:
[    2.584688]   No soundcards found.
[    2.590180] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[    2.664845] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.673137] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    2.687750] devtmpfs: mounted
[    2.692662] Freeing unused kernel memory: 1024K
[    2.697933] Run /sbin/init as init process
[    3.057068] systemd[1]: System time before build time, advancing clock.
[    3.110657] systemd[1]: systemd 244 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN)
[    3.133440] systemd[1]: Detected architecture arm.
Welcome to Arago 2021.09!
[    3.175153] systemd[1]: Set hostname to <am335x-evm>.
[    3.980567] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[    3.993248] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[    4.006761] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    4.049121] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    4.086037] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.125456] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password …ts to Console Directory Watch.
[    4.165206] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password R…uests to Wall Directory Watch.
[    4.204625] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    4.244507] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.284110] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    4.324528] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    4.384791] systemd[1]: Listening on RPCbind Server Activation Socket.
[  OK  ] Listening on RPCbind Server Activation Socket.
[    4.424104] systemd[1]: Reached target RPC Port Mapper.
[  OK  ] Reached target RPC Port Mapper.
[    4.483109] systemd[1]: Listening on Process Core Dump Socket.
[  OK  ] Listening on Process Core Dump Socket.
[    4.524657] systemd[1]: Listening on initctl Compatibility Named Pipe.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[    4.620606] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[    4.631604] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.676677] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.715834] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.756635] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    4.795801] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    4.835121] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    4.853153] systemd[1]: Mounting POSIX Message Queue File System...
[    4.913041] systemd[1]: Mounting Kernel Debug File System...
[    4.986008] systemd[1]: Mounting Temporary Directory (/tmp)...
[    5.005317] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
[    5.027053] systemd[1]: Starting Start psplash boot splash screen...
[    5.084742] systemd[1]: Starting RPC Bind...
[    5.124388] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[    5.177894] systemd[1]: Starting Journal Service...
[    5.234923] systemd[1]: Starting Load Kernel Modules...
[    5.276558] systemd[1]: Starting Remount Root and Kernel File Systems...
[    5.300557] cryptodev: loading out-of-tree module taints kernel.
         Starting Remount Root and Kernel File Systems   5.327575] cryptodev: driver 1.10 loaded.
[0m...
[    5.351112] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    5.370959] systemd[1]: Starting udev Coldplug all Devices...
[    5.487305] systemd[1]: Started Start psplash boot splash screen.
[  OK  ] Started Start psplash boot splash screen.
[    5.544904] systemd[1]: Started RPC Bind.
[  OK  ] Started RPC Bind.
[    5.565602] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    5.595762] systemd[1]: Mounted Kernel Debug File System.
[  OK  ] Mounted Kernel Debug File System.
[    5.615358] systemd[1]: Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Temporary Directory (/tmp).
[    5.648769] systemd[1]: Started Load Kernel Modules.
[  OK  ] Started Load Kernel Modules.
[    5.705173] systemd[1]: Started Remount Root and Kernel File Systems.
[  OK  ] Started Remount Root and Kernel File Systems.
[    5.736485] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
[    5.777986] systemd[1]: Mounting Kernel Configuration File System...
[    5.850304] systemd[1]: Started Start psplash-systemd progress communication helper.
[  OK  ] Started Start psplash-syst…progress communication helper.
[    5.907320] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[    5.926177] systemd[1]: Starting Apply Kernel Variables...
[    5.941689] systemd[1]: Condition check resulted in Create System Users being skipped.
[    5.978800] systemd[1]: Starting Create Static Device Nodes in /dev...
[    6.039626] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Mounted Kernel Configuration File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /media/ram...
         Mounting /var/volatile...
         Starting Flush Journal to Persistent Storage...
[    6.436727] systemd-journald[86]: Received client request to flush runtime journal.
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /media/ram.
[  OK  ] Mounted /var/volatile.
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Set.
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen …ness of backlight:backlight...
[    8.974960] remoteproc remoteproc0: wkup_m3 is available
[  OK  ] Started Load/Save Screen B…htness of backlight:backlight.
[  OK  ] Started udev Coldplug all Devices.
[    9.632115] omap_rtc 44e3e000.rtc: already running
[    9.637525] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
         Starting udev Wait for Complete Device Initialization...
[    9.735135] omap_rtc 44e3e000.rtc: registered as rtc0
[    9.780679] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:14:26 UTC (946685666)
[   10.403249] remoteproc remoteproc0: powering up wkup_m3
[   10.503286] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 243276
[   10.599376] remoteproc remoteproc0: remote processor wkup_m3 is now up
[   10.599409] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[   10.901389] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
[   10.976851] usbcore: registered new interface driver usbfs
[   10.982447] usbcore: registered new interface driver hub
[   11.007951] usbcore: registered new device driver usb
[   11.025519] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
[   11.141520] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[   11.292062] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[   11.354072] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   11.362401] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   11.553787] usb usb1: Product: MUSB HDRC host driver
[   11.558804] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 musb-hcd
[   11.686647] usb usb1: SerialNumber: musb-hdrc.0
[   11.730832] hub 1-0:1.0: USB hub found
[   11.784095] hub 1-0:1.0: 1 port detected
[   11.900944] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[   12.021954] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
[   12.124293] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[   12.194153] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   12.201436] usb usb2: Product: MUSB HDRC host driver
[   12.350318] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 musb-hcd
[   12.434649] usb usb2: SerialNumber: musb-hdrc.1
[   12.484989] hub 2-0:1.0: USB hub found
[   12.530082] hub 2-0:1.0: 1 port detected
[   12.905831] CAN device driver interface
[   13.045018] c_can_platform 481cc000.can: c_can_platform device registered (regs=93453c1c, irq=39)
[   14.401192] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[   14.475231] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[   14.517353] omap-sham 53100000.sham: will run requests pump with realtime priority
[   14.553862] omap-aes 53500000.aes: will run requests pump with realtime priority
[   15.066025] PM: bootloader does not support rtc-only!
[ ***  ] A start job is running for udev Wai…ice Initialization (18s / 3min 5s)
[  OK  ] Started udev Wait for Complete Device Initialization.
[  OK  ] Created slice system-systemd\x2dfsck.slice.
[  OK  ] Reached target Hardware activated USB gadget.
[  OK  ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
[  OK  ] Started Hardware RNG Entropy Gatherer Daemon.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily rotation of log files.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started Job spooling tools.
[  OK  ] Started Periodic Command Scheduler.
[  OK  ] Started D-Bus System Message Bus.
         Starting Print notice about GPLv3 packages...
         Starting IPv6 Packet Filtering Framework...
         Starting IPv4 Packet Filtering Framework...
         Starting Reboot and dump vmcore via kexec...
         Starting rc.pvr.service...
         Starting File System Check on /dev/mmcblk0p1...
         Starting File System Check on /dev/mmcblk1p2...
         Starting File System Check on /dev/mmcblk1p5...
         Starting Login Service...
[  OK  ] Started IPv6 Packet Filtering Framework.
[  OK  ] Started IPv4 Packet Filtering Framework.
[  OK  ] Started Reboot and dump vmcore via kexec.
[  OK  ] Started rc.pvr.service.
[  OK  ] Started File System Check on /dev/mmcblk1p5.
[  OK  ] Reached target Network (Pre).
         Mounting /run/media/mmcblk1p5...
         Starting Network Service...
         Starting weston.service...
[FAILED] Failed to mount /run/media/mmcblk1p5.
See 'systemctl status run-media-mmcblk1p5.mount' for details.
[  OK  ] Started File System Check on /dev/mmcblk0p1.
[  OK  ] Started File System Check on /dev/mmcblk1p2.
         Mounting /run/media/mmcblk0p1...
         Mounting /run/media/mmcblk1p2...
[  OK  ] Started weston.service.
         Starting Matrix GUI...
         Starting telnetd.service...
[  OK  ] Mounted /run/media/mmcblk0p1.
[  OK  ] Mounted /run/media/mmcblk1p2.
[  OK  ] Started Matrix GUI.
[  OK  ] Started telnetd.service.
[  OK  ] Started Network Service.
         Starting Wait for Network to be Configured...
[   28.918181] cpsw 4a100000.ethernet: initializing cpsw version 1.12 (0)
         Starting Network Name Resolution...
[   29.085255] TI TLK10X 10/100 Mbps PHY 4a101000.mdio:01: attached PHY driver [TI TLK10X 10/100 Mbps PHY] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
[  OK  ] Started Login Service.
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Network.
[  OK  ] Reached target Host and Network Name Lookups.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Enable and configure wl18xx bluetooth stack...
[  OK  ] Started NFS status monitor for NFSv2/3 locking..
         Starting Simple Network Ma…ent Protocol (SNMP) Daemon....
         Starting Permit User Sessions...
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Serial Getty on ttyS3.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Created slice system-systemd\x2dcoredump.slice.
[  OK  ] Started Process Core Dump (PID 809/UID 0).
[  OK  ] Started Simple Network Man…ement Protocol (SNMP) Daemon..
[   33.123821] vmmcsd_fixed: disabling
[  OK  ] Started Synchronize System and HW clocks.
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        bash-dev
        bash
        bc
        binutils
        cifs-utils
        coreutils-stdbuf
        coreutils
        cpio
        cpp-symlinks
        cpp
        dosfstools
        elfutils
        g++-symlinks
        g++
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        gettext
        glmark2
        gstreamer1.0-libav
        gzip
        hidapi
        less
        libasm1
        libbfd
        libdw1
        libelf1
        libgdbm-compat4
        libgdbm-dev
        libgdbm6
        libgettextlib
        libgettextsrc
        libgmp10
        libidn2-0
        libmpc3
        libmpfr6
        libreadline-dev
        libreadline8
        libunistring2
        m4-dev
        m4
        make
        nettle
        parted
        pdm-anomaly-detection
        tar
        which
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
[  OK  ] Started Print notice about GPLv3 packages.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am335x-evm ttyS0
am335x-evm login: [  150.199663] cryptd: max_cpu_qlen set to 1000
[  150.554785] Initializing XFRM netlink socket
am335x-evm login: root
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7.1 | VT102 | Offline | ttyUSB0
Arago 2021.09 am335x-evm ttyS0
am335x-evm login:
/* This file was auto-generated by TI PinMux on 14/09/2022 at 12:44:06. */
/* This file should only be used as a reference. Some pins/peripherals, */
/* depending on your use case, may need additional configuration. */
&am33xx_pinmux {
	/*pinmux for mcasp1 interface - sound card*/
	mcasp_pins_default: mcasp_pins_default {
		pinctrl-single,pins = <
			AM33XX_IOPAD(0x918, PIN_OUTPUT | MUX_MODE4) /* (J17) gmii1_rxdv.mcasp1_aclkx */
			AM33XX_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE4) /* (J18) gmii1_txd3.mcasp1_fsx */
			AM33XX_IOPAD(0x920, PIN_OUTPUT | MUX_MODE4) /* (K15) gmii1_txd2.mcasp1_axr0 */
			AM33XX_IOPAD(0x908, PIN_OUTPUT | MUX_MODE4) /* (H16) gmii1_col.mcasp1_axr2 */
	/*pinmux for mmc0 interface - sd card*/
	mmc0_pins_default: mmc0_pins_default {
			AM33XX_IOPAD(0x900, PIN_INPUT | MUX_MODE0) /* (G17) mmc0_clk.mmc0_clk */
			AM33XX_IOPAD(0x904, PIN_INPUT | MUX_MODE0) /* (G18) mmc0_cmd.mmc0_cmd */
			AM33XX_IOPAD(0x8fc, PIN_INPUT | MUX_MODE0) /* (G16) mmc0_dat0.mmc0_dat0 */
			AM33XX_IOPAD(0x8f8, PIN_INPUT | MUX_MODE0) /* (G15) mmc0_dat1.mmc0_dat1 */
			AM33XX_IOPAD(0x8f4, PIN_INPUT | MUX_MODE0) /* (F18) mmc0_dat2.mmc0_dat2 */
			AM33XX_IOPAD(0x8f0, PIN_INPUT | MUX_MODE0) /* (F17) mmc0_dat3.mmc0_dat3 */
	/*pinmux for mmc1 interface - eMMC*/
	mmc1_pins_default: mmc1_pins_default {
			AM33XX_IOPAD(0x880, PIN_INPUT | MUX_MODE2) /* (U9) gpmc_csn1.mmc1_clk */
			AM33XX_IOPAD(0x884, PIN_INPUT | MUX_MODE2) /* (V9) gpmc_csn2.mmc1_cmd */
			AM33XX_IOPAD(0x800, PIN_INPUT | MUX_MODE1) /* (U7) gpmc_ad0.mmc1_dat0 */
			AM33XX_IOPAD(0x804, PIN_INPUT | MUX_MODE1) /* (V7) gpmc_ad1.mmc1_dat1 */
			AM33XX_IOPAD(0x808, PIN_INPUT | MUX_MODE1) /* (R8) gpmc_ad2.mmc1_dat2 */
			AM33XX_IOPAD(0x80c, PIN_INPUT | MUX_MODE1) /* (T8) gpmc_ad3.mmc1_dat3 */
			AM33XX_IOPAD(0x810, PIN_INPUT | MUX_MODE1) /* (U8) gpmc_ad4.mmc1_dat4 */
			AM33XX_IOPAD(0x814, PIN_INPUT | MUX_MODE1) /* (V8) gpmc_ad5.mmc1_dat5 */
			AM33XX_IOPAD(0x818, PIN_INPUT | MUX_MODE1) /* (R9) gpmc_ad6.mmc1_dat6 */
			AM33XX_IOPAD(0x81c, PIN_INPUT | MUX_MODE1) /* (T9) gpmc_ad7.mmc1_dat7 */
	/*pinmux for uart0 interface - Console UART*/
	uart0_pins_default: uart0_pins_default {
			AM33XX_IOPAD(0x970, PIN_INPUT | MUX_MODE0) /* (E15) uart0_rxd.uart0_rxd */
			AM33XX_IOPAD(0x974, PIN_OUTPUT | MUX_MODE0) /* (E16) uart0_txd.uart0_txd */
	/*pinmux for i2c0 interface */
	myi2c0_pins_default: myi2c0_pins_default {
			AM33XX_IOPAD(0x98c, PIN_INPUT_PULLUP | MUX_MODE0) /* (C16) I2C0_SCL.I2C0_SCL */
			AM33XX_IOPAD(0x988, PIN_INPUT_PULLUP | MUX_MODE0) /* (C17) I2C0_SDA.I2C0_SDA */
	/*pinmux for can1 interface */
    /*CAN DTS configuration*/
    mydcan0_pins_default: mydcan0_pins_default {
            AM33XX_IOPAD(0x97c, PIN_INPUT | MUX_MODE2) /* (D17) uart1_rtsn.dcan0_rx */
            AM33XX_IOPAD(0x978, PIN_OUTPUT | MUX_MODE2) /* (D18) uart1_ctsn.dcan0_tx */
	/*pinmux for gpio pins - user leds*/
	mygpio2_pins_default: mygpio2_pins_default {
			AM33XX_IOPAD(0x890, PIN_INPUT | MUX_MODE7) /* (R7) gpmc_advn_ale.gpio2[2] */
			AM33XX_IOPAD(0x894, PIN_INPUT | MUX_MODE7) /* (T7) gpmc_oen_ren.gpio2[3] */
			AM33XX_IOPAD(0x898, PIN_INPUT | MUX_MODE7) /* (U6) gpmc_wen.gpio2[4] */
			AM33XX_IOPAD(0x89c, PIN_INPUT | MUX_MODE7) /* (T6) gpmc_be0n_cle.gpio2[5] */
	/*pinmux for PWM*/
	myecap0_pins_default: myecap0_pins_default {
			AM33XX_IOPAD(0x964, PIN_OUTPUT | MUX_MODE0) /* (C18) eCAP0_in_PWM0_out.eCAP0_in_PWM0_out */
	/*pinmux for LCD*/
	lcdc0_pins_default: lcdc0_pins_default {
			AM33XX_IOPAD(0x8e0, PIN_OUTPUT | MUX_MODE0) /* (U5) lcd_vsync.lcd_vsync */
			AM33XX_IOPAD(0x8e4, PIN_OUTPUT | MUX_MODE0) /* (R5) lcd_hsync.lcd_hsync */
			AM33XX_IOPAD(0x8e8, PIN_OUTPUT | MUX_MODE0) /* (V5) lcd_pclk.lcd_pclk */
			AM33XX_IOPAD(0x8ec, PIN_OUTPUT | MUX_MODE0) /* (R6) lcd_ac_bias_en.lcd_ac_bias_en */
			AM33XX_IOPAD(0x8a0, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (R1) lcd_data0.lcd_data0 */
			AM33XX_IOPAD(0x8a4, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (R2) lcd_data1.lcd_data1 */
			AM33XX_IOPAD(0x8a8, PIN_OUTPUT_PULLUP | MUX_MODE0) /* (R3) lcd_data2.lcd_data2 */
			AM33XX_IOPAD(0x8ac, PIN_OUTPUT_PULLUP | MUX_MODE0) /* (R4) lcd_data3.lcd_data3 */
			AM33XX_IOPAD(0x8b0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* (T1) lcd_data4.lcd_data4 */
			AM33XX_IOPAD(0x8b4, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (T2) lcd_data5.lcd_data5 */
			AM33XX_IOPAD(0x8b8, PIN_OUTPUT_PULLUP | MUX_MODE0) /* (T3) lcd_data6.lcd_data6 */
			AM33XX_IOPAD(0x8bc, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (T4) lcd_data7.lcd_data7 */
			AM33XX_IOPAD(0x8c0, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (U1) lcd_data8.lcd_data8 */
			AM33XX_IOPAD(0x8c4, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (U2) lcd_data9.lcd_data9 */
			AM33XX_IOPAD(0x8c8, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (U3) lcd_data10.lcd_data10 */
			AM33XX_IOPAD(0x8cc, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (U4) lcd_data11.lcd_data11 */
			AM33XX_IOPAD(0x8d0, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (V2) lcd_data12.lcd_data12 */
			AM33XX_IOPAD(0x8d4, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (V3) lcd_data13.lcd_data13 */
			AM33XX_IOPAD(0x8d8, PIN_OUTPUT_PULLUP | MUX_MODE0) /* (V4) lcd_data14.lcd_data14 */
			AM33XX_IOPAD(0x8dc, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* (T5) lcd_data15.lcd_data15 */
			AM33XX_IOPAD(0x83c, PIN_OUTPUT | MUX_MODE1) /* (U13) gpmc_ad15.lcd_data16 */
			AM33XX_IOPAD(0x838, PIN_OUTPUT | MUX_MODE1) /* (V13) gpmc_ad14.lcd_data17 */
 * Copyright (C) 2020 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
/dts-v1/;
#include "am33xx.dtsi"
#include "am335x-custom-pinmux.dtsi"
	model = "Custom Board";
	compatible = "ti,am335x-bone-black", "ti,am335x-bone", "ti,am33xx";
    memory@80000000 {
        device_type = "memory";
        reg = <0x80000000 0x10000000>; /* 512 MB */
    }; /*memory@80000000*/
    chosen {
        stdout-path = &uart0;
    }; /*chosen*/
	/*Regulator DTS configs*/
    vmmcsd_fixed: fixedregulator0 {
        compatible = "regulator-fixed";
        regulator-name = "vmmcsd_fixed";
        regulator-min-microvolt = <3300000>;
        regulator-max-microvolt = <3300000>;
    }; /*vmmcsd_fixed*/
    /*Sound Card DTS configs*/
	sound {
		compatible = "simple-audio-card";
		simple-audio-card,name = "Sound";
		simple-audio-card,format = "i2s";
		simple-audio-card,bitclock-master = <&sound_master>;
		simple-audio-card,frame-master = <&sound_master>;
		simple-audio-card,codec {
			sound-dai = <&amp>;
		sound_master: simple-audio-card,cpu {
			sound-dai = <&mcasp1>;
			bitclock-master;
			frame-master;
			system-clock-frequency = <24576000>;
			system-clock-direction-out;
	backlight: backlight {
		compatible = "pwm-backlight";
		pwms = <&ecap0 0 50000 0>;
		brightness-levels = <0 51 53 56 62 75 101 152 255>;
		default-brightness-level = <8>;
	/*LCD Panel DTS Configs*/
	panel {
		compatible = "sharp,lq121s1lg88";
		pinctrl-names = "default";
		pinctrl-0 = <&lcdc0_pins_default>;
		backlight = <&backlight>;
		port {
			panel_0: endpoint@0 {
				remote-endpoint = <&lcdc_0>;
}; /*root node */
/*LCDC DTS configs*/
&lcdc {
	status = "okay";
	port {
		lcdc_0: endpoint@0 {
			remote-endpoint = <&panel_0>;
/*UARTO DTS configs*/
&uart0 {
        pinctrl-0 = <&uart0_pins_default>;
        status = "okay";
/*SD DTS configs*/
&mmc1 {
		status = "okay";
/*eMMC DTS configs*/
&mmc2 {
		bus-width = <8>;
		status = "okay";
/*I2C0 DTS configs*/
&i2c0 {
	pinctrl-0 = <&myi2c0_pins_default>;
	status = "okay";
	tps: tps@24 {
		reg = <0x24>;
	amp: amp@6c {
		#sound-dai-cells = <0>;
		compatible = "nxp,tfa9879";
		reg = <0x6c>;
&dcan0 {
    status = "okay";
    pinctrl-0 = <&mydcan0_pins_default>;
/*User LED DTS configs*/
&gpio2 {
	pinctrl-0 = <&mygpio2_pins_default>;
	status = "okay";
/*Ethernet DTS configs*/
&mac {
	status = "okay";
	slaves = <1>;
&davinci_mdio {
	status = "okay";
	ethphy0: ethernet-phy@1 {
		reg = <1>;
&cpsw_emac0 {
	phy-handle = <&ethphy0>;
	phy-mode = "rmii";
/*USB Host DTS configs*/
&usb {
status = "okay";
&usb_ctrl_mod {
status = "okay";
&usb0_phy {
status = "okay";
&usb0 {
status = "okay";
dr_mode = "host";
/*McASP DTS configs*/
&mcasp1 {
	compatible = "ti,am33xx-mcasp-audio";
	pinctrl-0 = <&mcasp_pins_default>;
	status = "okay";
	op-mode = <0>;          /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	/* 4 serializers */
	num-serializer = <4>;
	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
		1 0 1 0
/*ADC Voltage Monitoring and Touchscreen DTS configs*/
&tscadc{
        compatible = "ti,am3359-tscadc";
        status = "okay";
        tsc {
            ti,wires = <5>;
            ti,x-plate-resistance = <200>;
            ti,coordinate-readouts = <5>;
            ti,wire-config = <0x00 0x11 0x22 0x33>;
            ti,charge-delay = <0x400>;
        adc {
            ti,adc-channels = <5 6 7>;
/*PWM DTS configs*/
&epwmss0 {
	status = "okay";
&ecap0{
	status = "okay";
	pinctrl-0 = <&myecap0_pins_default>;
/*Volatge regulator DTS configs*/
/include/ "tps65217.dtsi"
&tps {
	interrupts = <7>; /* NMI */
	interrupt-parent = <&intc>;
	ti,pmic-shutdown-controller;
	charger {
		status = "okay";
	regulators {
		dcdc1_reg: regulator@0 {
			regulator-name = "Z1V5PMIC";
			regulator-always-on;
		dcdc2_reg: regulator@1 {
			/* VDD_MPU voltage limits 0.95V - 1.26V with +/-4% tolerance */
			regulator-name = "Z1V1PMIC2";
			regulator-min-microvolt = <925000>;
			regulator-max-microvolt = <1351500>;
			regulator-boot-on;
		dcdc3_reg: regulator@2 {
			/* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */
			regulator-name = "Z1V1PMIC1";
			regulator-max-microvolt = <1150000>;
			regulator-boot-on;
		ldo1_reg: regulator@3 {
			regulator-name = "Z1V8PMIC1";
		ldo2_reg: regulator@4 {
			regulator-name = "Z3V3PMIC2";
		ldo3_reg: regulator@5 {
			regulator-name = "Z1V8PMIC2";
		ldo4_reg: regulator@6 {
			regulator-name = "Z3V3PMIC1";
    在引导日志中、我看不到 GPU 已初始化。 如果未加载 GPU (pvrsrvkm.ko)模块、则不会运行 Weston 或其他应用程序。 我不确定您是如何构建文件系统的、但请确保包含以下库:
    UM 库: https://git.ti.com/cgit/graphics/omap5-sgx-ddk-um-linux/
    2.内核模块: https://git.ti.com/cgit/graphics/omap5-sgx-ddk-linux/
    Krunal
    Krunal、您好!
    执行 lsmod 会显示已加载 pvrsrvkm.ko 模块。 但是、在执行 kmscube 命令时不会生成所需的输出。
    Module                  Size  Used by
    xfrm_user              36864  2
    xfrm_algo              16384  1 xfrm_user
    sha512_generic         20480  0
    sha512_arm             24576  0
    sha256_generic         16384  0
    libsha256              20480  1 sha256_generic
    md5                    16384  0
    aes_arm_bs             24576  0
    crypto_simd            16384  1 aes_arm_bs
    cryptd                 24576  1 crypto_simd
    aes_arm                16384  0
    aes_generic            40960  1 aes_arm
    cbc                    16384  0
    pvrsrvkm              405504  0
    ti_am335x_adc          16384  0
    snd_soc_simple_card    20480  0
    snd_soc_simple_card_utils    24576  1 snd_soc_simple_card
    omap_aes_driver        24576  0
    omap_crypto            16384  1 omap_aes_driver
    libaes                 16384  4 omap_aes_driver,aes_arm_bs,aes_arm,aes_generic
    pm33xx                 16384  0
    omap_sham              28672  0
    crypto_engine          16384  2 omap_aes_driver,omap_sham
    ti_emif_sram           16384  1 pm33xx
    c_can_platform         16384  0
    c_can                  20480  1 c_can_platform
    can_dev                32768  1 c_can
    musb_dsps              20480  0
    musb_hdrc             110592  1 musb_dsps
    udc_core               28672  1 musb_hdrc
    usbcore               241664  1 musb_hdrc
    wkup_m3_ipc            16384  1 pm33xx
    phy_am335x             16384  2
    phy_am335x_control     16384  1 phy_am335x
    rtc_omap               20480  4 pm33xx
    phy_generic            16384  1 phy_am335x
    usb_common             16384  5 phy_am335x,udc_core,musb_hdrc,musb_dsps,usbcore
    omap_wdt               16384  0
    ti_am335x_tscadc       16384  1 ti_am335x_adc
    wkup_m3_rproc          16384  1
    sch_fq_codel           20480  2
    uio_module_drv         16384  0
    uio                    20480  1 uio_module_drv
    cryptodev              53248  1
    我们使用以下 defconfig 文件(tisdk_AM335x-evm_defconfig)来构建内核映像。 这是从 Processor SDK 版本08_02_00_24获取的、该文件未修改。
    # Automatically generated file; DO NOT EDIT.
    # Linux/arm 5.10.100 Kernel Configuration
    CONFIG_CC_VERSION_TEXT="arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025"
    CONFIG_CC_IS_GCC=y
    CONFIG_GCC_VERSION=90201
    CONFIG_LD_VERSION=233010000
    CONFIG_CLANG_VERSION=0
    CONFIG_LLD_VERSION=0
    CONFIG_CC_CAN_LINK=y
    CONFIG_CC_CAN_LINK_STATIC=y
    CONFIG_CC_HAS_ASM_GOTO=y
    CONFIG_CC_HAS_ASM_INLINE=y
    CONFIG_IRQ_WORK=y
    CONFIG_BUILDTIME_TABLE_SORT=y
    # General setup
    CONFIG_BROKEN_ON_SMP=y
    CONFIG_INIT_ENV_ARG_LIMIT=32
    # CONFIG_COMPILE_TEST is not set
    CONFIG_LOCALVERSION=""
    CONFIG_LOCALVERSION_AUTO=y
    CONFIG_BUILD_SALT=""
    CONFIG_HAVE_KERNEL_GZIP=y
    CONFIG_HAVE_KERNEL_LZMA=y
    CONFIG_HAVE_KERNEL_XZ=y
    CONFIG_HAVE_KERNEL_LZO=y
    CONFIG_HAVE_KERNEL_LZ4=y
    # CONFIG_KERNEL_GZIP is not set
    CONFIG_KERNEL_LZMA=y
    # CONFIG_KERNEL_XZ is not set
    # CONFIG_KERNEL_LZO is not set
    # CONFIG_KERNEL_LZ4 is not set
    CONFIG_DEFAULT_INIT=""
    CONFIG_DEFAULT_HOSTNAME="(none)"
    CONFIG_SWAP=y
    CONFIG_SYSVIPC=y
    CONFIG_SYSVIPC_SYSCTL=y
    CONFIG_POSIX_MQUEUE=y
    CONFIG_POSIX_MQUEUE_SYSCTL=y
    # CONFIG_WATCH_QUEUE is not set
    CONFIG_CROSS_MEMORY_ATTACH=y
    # CONFIG_USELIB is not set
    # CONFIG_AUDIT is not set
    CONFIG_HAVE_ARCH_AUDITSYSCALL=y
    # IRQ subsystem
    CONFIG_GENERIC_IRQ_PROBE=y
    CONFIG_GENERIC_IRQ_SHOW=y
    CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
    CONFIG_HARDIRQS_SW_RESEND=y
    CONFIG_GENERIC_IRQ_CHIP=y
    CONFIG_IRQ_DOMAIN=y
    CONFIG_IRQ_DOMAIN_HIERARCHY=y
    CONFIG_GENERIC_MSI_IRQ=y
    CONFIG_GENERIC_MSI_IRQ_DOMAIN=y
    CONFIG_HANDLE_DOMAIN_IRQ=y
    CONFIG_IRQ_FORCED_THREADING=y
    CONFIG_SPARSE_IRQ=y
    # CONFIG_GENERIC_IRQ_DEBUGFS is not set
    # end of IRQ subsystem
    CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
    CONFIG_GENERIC_CLOCKEVENTS=y
    # Timers subsystem
    CONFIG_TICK_ONESHOT=y
    CONFIG_NO_HZ_COMMON=y
    # CONFIG_HZ_PERIODIC is not set
    CONFIG_NO_HZ_IDLE=y
    CONFIG_NO_HZ=y
    CONFIG_HIGH_RES_TIMERS=y
    # end of Timers subsystem
    # CONFIG_PREEMPT_NONE is not set
    # CONFIG_PREEMPT_VOLUNTARY is not set
    CONFIG_PREEMPT=y
    CONFIG_PREEMPT_COUNT=y
    CONFIG_PREEMPTION=y
    # CPU/Task time and stats accounting
    CONFIG_TICK_CPU_ACCOUNTING=y
    # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
    # CONFIG_IRQ_TIME_ACCOUNTING is not set
    CONFIG_BSD_PROCESS_ACCT=y
    # CONFIG_BSD_PROCESS_ACCT_V3 is not set
    # CONFIG_TASKSTATS is not set
    # CONFIG_PSI is not set
    # end of CPU/Task time and stats accounting
    # RCU Subsystem
    CONFIG_TREE_RCU=y
    CONFIG_PREEMPT_RCU=y
    # CONFIG_RCU_EXPERT is not set
    CONFIG_SRCU=y
    CONFIG_TREE_SRCU=y
    CONFIG_TASKS_RCU_GENERIC=y
    CONFIG_TASKS_RCU=y
    CONFIG_RCU_STALL_COMMON=y
    CONFIG_RCU_NEED_SEGCBLIST=y
    # end of RCU Subsystem
    CONFIG_IKCONFIG=y
    CONFIG_IKCONFIG_PROC=y
    # CONFIG_IKHEADERS is not set
    CONFIG_LOG_BUF_SHIFT=17
    CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
    CONFIG_GENERIC_SCHED_CLOCK=y
    # Scheduler features
    # end of Scheduler features
    CONFIG_CGROUPS=y
    CONFIG_PAGE_COUNTER=y
    CONFIG_MEMCG=y
    CONFIG_MEMCG_SWAP=y
    CONFIG_MEMCG_KMEM=y
    CONFIG_BLK_CGROUP=y
    CONFIG_CGROUP_WRITEBACK=y
    CONFIG_CGROUP_SCHED=y
    CONFIG_FAIR_GROUP_SCHED=y
    CONFIG_CFS_BANDWIDTH=y
    # CONFIG_RT_GROUP_SCHED is not set
    CONFIG_CGROUP_PIDS=y
    # CONFIG_CGROUP_RDMA is not set
    CONFIG_CGROUP_FREEZER=y
    CONFIG_CGROUP_DEVICE=y
    CONFIG_CGROUP_CPUACCT=y
    CONFIG_CGROUP_PERF=y
    # CONFIG_CGROUP_DEBUG is not set
    CONFIG_NAMESPACES=y
    CONFIG_UTS_NS=y
    CONFIG_IPC_NS=y
    # CONFIG_USER_NS is not set
    CONFIG_PID_NS=y
    CONFIG_NET_NS=y
    CONFIG_CHECKPOINT_RESTORE=y
    # CONFIG_SCHED_AUTOGROUP is not set
    # CONFIG_SYSFS_DEPRECATED is not set
    # CONFIG_RELAY is not set
    CONFIG_BLK_DEV_INITRD=y
    CONFIG_INITRAMFS_SOURCE=""
    CONFIG_RD_GZIP=y
    CONFIG_RD_BZIP2=y
    CONFIG_RD_LZMA=y
    CONFIG_RD_XZ=y
    CONFIG_RD_LZO=y
    CONFIG_RD_LZ4=y
    CONFIG_RD_ZSTD=y
    # CONFIG_BOOT_CONFIG is not set
    CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
    # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
    CONFIG_LD_ORPHAN_WARN=y
    CONFIG_SYSCTL=y
    CONFIG_HAVE_UID16=y
    CONFIG_BPF=y
    CONFIG_EXPERT=y
    CONFIG_UID16=y
    CONFIG_MULTIUSER=y
    # CONFIG_SGETMASK_SYSCALL is not set
    CONFIG_SYSFS_SYSCALL=y
    CONFIG_FHANDLE=y
    CONFIG_POSIX_TIMERS=y
    CONFIG_PRINTK=y
    CONFIG_PRINTK_NMI=y
    CONFIG_BUG=y
    CONFIG_ELF_CORE=y
    CONFIG_BASE_FULL=y
    CONFIG_FUTEX=y
    CONFIG_FUTEX_PI=y
    CONFIG_HAVE_FUTEX_CMPXCHG=y
    CONFIG_EPOLL=y
    CONFIG_SIGNALFD=y
    CONFIG_TIMERFD=y
    CONFIG_EVENTFD=y
    CONFIG_SHMEM=y
    CONFIG_AIO=y
    CONFIG_IO_URING=y
    CONFIG_ADVISE_SYSCALLS=y
    CONFIG_MEMBARRIER=y
    CONFIG_KALLSYMS=y
    CONFIG_KALLSYMS_ALL=y
    CONFIG_KALLSYMS_BASE_RELATIVE=y
    # CONFIG_BPF_SYSCALL is not set
    # CONFIG_USERFAULTFD is not set
    CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
    CONFIG_KCMP=y
    CONFIG_RSEQ=y
    # CONFIG_DEBUG_RSEQ is not set
    CONFIG_EMBEDDED=y
    CONFIG_HAVE_PERF_EVENTS=y
    CONFIG_PERF_USE_VMALLOC=y
    # CONFIG_PC104 is not set
    # Kernel Performance Events And Counters
    CONFIG_PERF_EVENTS=y
    # CONFIG_DEBUG_PERF_USE_VMALLOC is not set
    # end of Kernel Performance Events And Counters
    CONFIG_VM_EVENT_COUNTERS=y
    # CONFIG_SLUB_DEBUG is not set
    # CONFIG_SLUB_MEMCG_SYSFS_ON is not set
    CONFIG_COMPAT_BRK=y
    # CONFIG_SLAB is not set
    CONFIG_SLUB=y
    # CONFIG_SLOB is not set
    CONFIG_SLAB_MERGE_DEFAULT=y
    # CONFIG_SLAB_FREELIST_RANDOM is not set
    # CONFIG_SLAB_FREELIST_HARDENED is not set
    # CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
    CONFIG_SYSTEM_DATA_VERIFICATION=y
    # CONFIG_PROFILING is not set
    # end of General setup
    CONFIG_ARM=y
    CONFIG_ARM_HAS_SG_CHAIN=y
    CONFIG_SYS_SUPPORTS_APM_EMULATION=y
    CONFIG_HAVE_PROC_CPU=y
    CONFIG_STACKTRACE_SUPPORT=y
    CONFIG_LOCKDEP_SUPPORT=y
    CONFIG_TRACE_IRQFLAGS_SUPPORT=y
    CONFIG_ARCH_HAS_BANDGAP=y
    CONFIG_FIX_EARLYCON_MEM=y
    CONFIG_GENERIC_HWEIGHT=y
    CONFIG_GENERIC_CALIBRATE_DELAY=y
    CONFIG_ARCH_SUPPORTS_UPROBES=y
    CONFIG_ARM_PATCH_PHYS_VIRT=y
    CONFIG_GENERIC_BUG=y
    CONFIG_PGTABLE_LEVELS=2
    # System Type
    CONFIG_MMU=y
    CONFIG_ARCH_MMAP_RND_BITS_MIN=8
    CONFIG_ARCH_MMAP_RND_BITS_MAX=16
    CONFIG_ARCH_MULTIPLATFORM=y
    # CONFIG_ARCH_EBSA110 is not set
    # CONFIG_ARCH_EP93XX is not set
    # CONFIG_ARCH_FOOTBRIDGE is not set
    # CONFIG_ARCH_IOP32X is not set
    # CONFIG_ARCH_IXP4XX is not set
    # CONFIG_ARCH_DOVE is not set
    # CONFIG_ARCH_PXA is not set
    # CONFIG_ARCH_RPC is not set
    # CONFIG_ARCH_SA1100 is not set
    # CONFIG_ARCH_S3C24XX is not set
    # CONFIG_ARCH_OMAP1 is not set
    # Multiple platform selection
    # CPU Core family selection
    # CONFIG_ARCH_MULTI_V6 is not set
    CONFIG_ARCH_MULTI_V7=y
    CONFIG_ARCH_MULTI_V6_V7=y
    # end of Multiple platform selection
    # CONFIG_ARCH_VIRT is not set
    # CONFIG_ARCH_ACTIONS is not set
    # CONFIG_ARCH_ALPINE is not set
    # CONFIG_ARCH_ARTPEC is not set
    # CONFIG_ARCH_ASPEED is not set
    # CONFIG_ARCH_AT91 is not set
    # CONFIG_ARCH_BCM is not set
    # CONFIG_ARCH_BERLIN is not set
    # CONFIG_ARCH_DIGICOLOR is not set
    # CONFIG_ARCH_EXYNOS is not set
    # CONFIG_ARCH_HIGHBANK is not set
    # CONFIG_ARCH_HISI is not set
    # CONFIG_ARCH_MXC is not set
    # CONFIG_ARCH_KEYSTONE is not set
    # CONFIG_ARCH_MEDIATEK is not set
    # CONFIG_ARCH_MESON is not set
    # CONFIG_ARCH_MILBEAUT is not set
    # CONFIG_ARCH_MMP is not set
    # CONFIG_ARCH_MSTARV7 is not set
    # CONFIG_ARCH_MVEBU is not set
    # CONFIG_ARCH_NPCM is not set
    CONFIG_ARCH_OMAP=y
    # TI OMAP Common Features
    # OMAP Feature Selections
    CONFIG_OMAP_RESET_CLOCKS=y
    CONFIG_OMAP_32K_TIMER=y
    # end of TI OMAP Common Features
    CONFIG_MACH_OMAP_GENERIC=y
    # TI OMAP/AM/DM/DRA Family
    # CONFIG_ARCH_OMAP3 is not set
    # CONFIG_ARCH_OMAP4 is not set
    # CONFIG_SOC_OMAP5 is not set
    CONFIG_SOC_AM33XX=y
    # CONFIG_SOC_AM43XX is not set
    # CONFIG_SOC_DRA7XX is not set
    CONFIG_ARCH_OMAP2PLUS=y
    # TI OMAP2/3/4 Specific Features
    CONFIG_ARCH_OMAP2PLUS_TYPICAL=y
    # CONFIG_SOC_HAS_OMAP2_SDRC is not set
    # OMAP Legacy Platform Data Board Type
    # end of TI OMAP2/3/4 Specific Features
    # end of TI OMAP/AM/DM/DRA Family
    # CONFIG_ARCH_SIRF is not set
    # CONFIG_ARCH_QCOM is not set
    # CONFIG_ARCH_RDA is not set
    # CONFIG_ARCH_REALTEK is not set
    # CONFIG_ARCH_REALVIEW is not set
    # CONFIG_ARCH_ROCKCHIP is not set
    # CONFIG_ARCH_S5PV210 is not set
    # CONFIG_ARCH_RENESAS is not set
    # CONFIG_ARCH_SOCFPGA is not set
    # CONFIG_PLAT_SPEAR is not set
    # CONFIG_ARCH_STI is not set
    # CONFIG_ARCH_STM32 is not set
    # CONFIG_ARCH_SUNXI is not set
    # CONFIG_ARCH_TANGO is not set
    # CONFIG_ARCH_TEGRA is not set
    # CONFIG_ARCH_UNIPHIER is not set
    # CONFIG_ARCH_U8500 is not set
    # CONFIG_ARCH_VEXPRESS is not set
    # CONFIG_ARCH_WM8850 is not set
    # CONFIG_ARCH_ZX is not set
    # CONFIG_ARCH_ZYNQ is not set
    # Processor Type
    CONFIG_CPU_V7=y
    CONFIG_CPU_THUMB_CAPABLE=y
    CONFIG_CPU_32v6K=y
    CONFIG_CPU_32v7=y
    CONFIG_CPU_ABRT_EV7=y
    CONFIG_CPU_PABRT_V7=y
    CONFIG_CPU_CACHE_V7=y
    CONFIG_CPU_CACHE_VIPT=y
    CONFIG_CPU_COPY_V6=y
    CONFIG_CPU_TLB_V7=y
    CONFIG_CPU_HAS_ASID=y
    CONFIG_CPU_CP15=y
    CONFIG_CPU_CP15_MMU=y
    # Processor Features
    # CONFIG_ARM_LPAE is not set
    CONFIG_ARM_THUMB=y
    # CONFIG_ARM_THUMBEE is not set
    CONFIG_ARM_VIRT_EXT=y
    # CONFIG_SWP_EMULATE is not set
    # CONFIG_CPU_ICACHE_DISABLE is not set
    # CONFIG_CPU_DCACHE_DISABLE is not set
    # CONFIG_CPU_BPREDICT_DISABLE is not set
    CONFIG_CPU_SPECTRE=y
    CONFIG_HARDEN_BRANCH_PREDICTOR=y
    CONFIG_KUSER_HELPERS=y
    # CONFIG_VDSO is not set
    CONFIG_OUTER_CACHE=y
    CONFIG_OUTER_CACHE_SYNC=y
    CONFIG_MIGHT_HAVE_CACHE_L2X0=y
    CONFIG_CACHE_L2X0=y
    # CONFIG_CACHE_L2X0_PMU is not set
    # CONFIG_PL310_ERRATA_588369 is not set
    # CONFIG_PL310_ERRATA_727915 is not set
    # CONFIG_PL310_ERRATA_753970 is not set
    # CONFIG_PL310_ERRATA_769419 is not set
    CONFIG_ARM_L1_CACHE_SHIFT_6=y
    CONFIG_ARM_L1_CACHE_SHIFT=6
    CONFIG_ARM_DMA_MEM_BUFFERABLE=y
    CONFIG_ARM_HEAVY_MB=y
    CONFIG_DEBUG_ALIGN_RODATA=y
    # CONFIG_ARM_ERRATA_430973 is not set
    # CONFIG_ARM_ERRATA_720789 is not set
    # CONFIG_ARM_ERRATA_754322 is not set
    # CONFIG_ARM_ERRATA_775420 is not set
    # CONFIG_ARM_ERRATA_773022 is not set
    # CONFIG_ARM_ERRATA_818325_852422 is not set
    # CONFIG_ARM_ERRATA_821420 is not set
    # CONFIG_ARM_ERRATA_825619 is not set
    # CONFIG_ARM_ERRATA_857271 is not set
    # CONFIG_ARM_ERRATA_852421 is not set
    # CONFIG_ARM_ERRATA_852423 is not set
    # CONFIG_ARM_ERRATA_857272 is not set
    # end of System Type
    # Bus support
    # CONFIG_ARM_ERRATA_814220 is not set
    # end of Bus support
    # Kernel Features
    CONFIG_HAVE_SMP=y
    # CONFIG_SMP is not set
    # CONFIG_HAVE_ARM_ARCH_TIMER is not set
    CONFIG_VMSPLIT_3G=y
    # CONFIG_VMSPLIT_3G_OPT is not set
    # CONFIG_VMSPLIT_2G is not set
    # CONFIG_VMSPLIT_1G is not set
    CONFIG_PAGE_OFFSET=0xC0000000
    # CONFIG_ARM_PSCI is not set
    CONFIG_ARCH_NR_GPIO=0
    CONFIG_HZ_FIXED=0
    CONFIG_HZ_100=y
    # CONFIG_HZ_200 is not set
    # CONFIG_HZ_250 is not set
    # CONFIG_HZ_300 is not set
    # CONFIG_HZ_500 is not set
    # CONFIG_HZ_1000 is not set
    CONFIG_HZ=100
    CONFIG_SCHED_HRTICK=y
    # CONFIG_THUMB2_KERNEL is not set
    CONFIG_ARM_PATCH_IDIV=y
    CONFIG_AEABI=y
    # CONFIG_OABI_COMPAT is not set
    CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y
    CONFIG_ARCH_SELECT_MEMORY_MODEL=y
    CONFIG_ARCH_FLATMEM_ENABLE=y
    CONFIG_ARCH_SPARSEMEM_ENABLE=y
    CONFIG_HAVE_ARCH_PFN_VALID=y
    CONFIG_HIGHMEM=y
    CONFIG_HIGHPTE=y
    CONFIG_CPU_SW_DOMAIN_PAN=y
    CONFIG_HW_PERF_EVENTS=y
    CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
    CONFIG_ARM_MODULE_PLTS=y
    CONFIG_FORCE_MAX_ZONEORDER=12
    CONFIG_ALIGNMENT_TRAP=y
    # CONFIG_UACCESS_WITH_MEMCPY is not set
    # CONFIG_PARAVIRT is not set
    # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
    # CONFIG_XEN is not set
    # end of Kernel Features
    # Boot options
    CONFIG_USE_OF=y
    CONFIG_ATAGS=y
    # CONFIG_DEPRECATED_PARAM_STRUCT is not set
    CONFIG_ZBOOT_ROM_TEXT=0x0
    CONFIG_ZBOOT_ROM_BSS=0x0
    CONFIG_ARM_APPENDED_DTB=y
    CONFIG_ARM_ATAG_DTB_COMPAT=y
    CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
    # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
    CONFIG_CMDLINE=""
    CONFIG_KEXEC=y
    CONFIG_ATAGS_PROC=y
    # CONFIG_CRASH_DUMP is not set
    CONFIG_AUTO_ZRELADDR=y
    CONFIG_EFI_STUB=y
    CONFIG_EFI=y
    CONFIG_DMI=y
    # end of Boot options
    # CPU Power Management
    # CPU Frequency scaling
    CONFIG_CPU_FREQ=y
    CONFIG_CPU_FREQ_GOV_ATTR_SET=y
    CONFIG_CPU_FREQ_GOV_COMMON=y
    CONFIG_CPU_FREQ_STAT=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
    # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
    CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND=y
    # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
    CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
    CONFIG_CPU_FREQ_GOV_POWERSAVE=y
    CONFIG_CPU_FREQ_GOV_USERSPACE=y
    CONFIG_CPU_FREQ_GOV_ONDEMAND=y
    CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
    # CPU frequency scaling drivers
    CONFIG_CPUFREQ_DT=y
    CONFIG_CPUFREQ_DT_PLATDEV=y
    # CONFIG_ARM_OMAP2PLUS_CPUFREQ is not set
    CONFIG_ARM_TI_CPUFREQ=y
    # end of CPU Frequency scaling
    # CPU Idle
    CONFIG_CPU_IDLE=y
    CONFIG_CPU_IDLE_MULTIPLE_DRIVERS=y
    CONFIG_CPU_IDLE_GOV_LADDER=y
    CONFIG_CPU_IDLE_GOV_MENU=y
    # CONFIG_CPU_IDLE_GOV_TEO is not set
    CONFIG_DT_IDLE_STATES=y
    # ARM CPU Idle Drivers
    CONFIG_ARM_CPUIDLE=y
    # end of ARM CPU Idle Drivers
    # end of CPU Idle
    # end of CPU Power Management
    # Floating point emulation
    # At least one emulation must be selected
    CONFIG_VFP=y
    CONFIG_VFPv3=y
    CONFIG_NEON=y
    CONFIG_KERNEL_MODE_NEON=y
    # end of Floating point emulation
    # Power management options
    CONFIG_SUSPEND=y
    CONFIG_SUSPEND_FREEZER=y
    # CONFIG_SUSPEND_SKIP_SYNC is not set
    # CONFIG_HIBERNATION is not set
    CONFIG_PM_SLEEP=y
    # CONFIG_PM_AUTOSLEEP is not set
    # CONFIG_PM_WAKELOCKS is not set
    CONFIG_PM=y
    CONFIG_PM_DEBUG=y
    # CONFIG_PM_ADVANCED_DEBUG is not set
    # CONFIG_PM_TEST_SUSPEND is not set
    CONFIG_PM_SLEEP_DEBUG=y
    # CONFIG_DPM_WATCHDOG is not set
    # CONFIG_APM_EMULATION is not set
    CONFIG_PM_CLK=y
    CONFIG_PM_GENERIC_DOMAINS=y
    # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
    CONFIG_PM_GENERIC_DOMAINS_SLEEP=y
    CONFIG_PM_GENERIC_DOMAINS_OF=y
    CONFIG_CPU_PM=y
    CONFIG_ARCH_SUSPEND_POSSIBLE=y
    CONFIG_ARM_CPU_SUSPEND=y
    CONFIG_ARCH_HIBERNATION_POSSIBLE=y
    # end of Power management options
    # Firmware Drivers
    # CONFIG_ARM_SCMI_PROTOCOL is not set
    # CONFIG_ARM_SCPI_PROTOCOL is not set
    # CONFIG_FIRMWARE_MEMMAP is not set
    # CONFIG_DMIID is not set
    # CONFIG_DMI_SYSFS is not set
    # CONFIG_FW_CFG_SYSFS is not set
    CONFIG_TRUSTED_FOUNDATIONS=y
    # CONFIG_GOOGLE_FIRMWARE is not set
    # EFI (Extensible Firmware Interface) Support
    CONFIG_EFI_ESRT=y
    CONFIG_EFI_VARS_PSTORE=y
    # CONFIG_EFI_VARS_PSTORE_DEFAULT_DISABLE is not set
    CONFIG_EFI_PARAMS_FROM_FDT=y
    CONFIG_EFI_RUNTIME_WRAPPERS=y
    CONFIG_EFI_GENERIC_STUB=y
    CONFIG_EFI_ARMSTUB_DTB_LOADER=y
    CONFIG_EFI_GENERIC_STUB_INITRD_CMDLINE_LOADER=y
    # CONFIG_EFI_BOOTLOADER_CONTROL is not set
    CONFIG_EFI_CAPSULE_LOADER=m
    # CONFIG_EFI_TEST is not set
    # CONFIG_RESET_ATTACK_MITIGATION is not set
    # CONFIG_EFI_DISABLE_PCI_DMA is not set
    # end of EFI (Extensible Firmware Interface) Support
    CONFIG_HAVE_ARM_SMCCC=y
    # Tegra firmware driver
    # end of Tegra firmware driver
    # end of Firmware Drivers
    CONFIG_ARM_CRYPTO=y
    CONFIG_CRYPTO_SHA1_ARM=m
    CONFIG_CRYPTO_SHA1_ARM_NEON=m
    CONFIG_CRYPTO_SHA1_ARM_CE=m
    CONFIG_CRYPTO_SHA2_ARM_CE=m
    CONFIG_CRYPTO_SHA256_ARM=m
    CONFIG_CRYPTO_SHA512_ARM=m
    CONFIG_CRYPTO_AES_ARM=m
    CONFIG_CRYPTO_AES_ARM_BS=m
    CONFIG_CRYPTO_AES_ARM_CE=m
    CONFIG_CRYPTO_GHASH_ARM_CE=m
    CONFIG_CRYPTO_CRC32_ARM_CE=m
    CONFIG_CRYPTO_CHACHA20_NEON=m
    # CONFIG_CRYPTO_POLY1305_ARM is not set
    # CONFIG_CRYPTO_NHPOLY1305_NEON is not set
    # CONFIG_CRYPTO_CURVE25519_NEON is not set
    CONFIG_AS_VFP_VMRS_FPINST=y
    # General architecture-dependent options
    CONFIG_CRASH_CORE=y
    CONFIG_KEXEC_CORE=y
    CONFIG_SET_FS=y
    CONFIG_HAVE_OPROFILE=y
    # CONFIG_KPROBES is not set
    CONFIG_JUMP_LABEL=y
    # CONFIG_STATIC_KEYS_SELFTEST is not set
    CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
    CONFIG_ARCH_USE_BUILTIN_BSWAP=y
    CONFIG_HAVE_KPROBES=y
    CONFIG_HAVE_KRETPROBES=y
    CONFIG_HAVE_OPTPROBES=y
    CONFIG_HAVE_NMI=y
    CONFIG_HAVE_ARCH_TRACEHOOK=y
    CONFIG_HAVE_DMA_CONTIGUOUS=y
    CONFIG_GENERIC_SMP_IDLE_THREAD=y
    CONFIG_GENERIC_IDLE_POLL_SETUP=y
    CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
    CONFIG_ARCH_HAS_KEEPINITRD=y
    CONFIG_ARCH_HAS_SET_MEMORY=y
    CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
    CONFIG_ARCH_32BIT_OFF_T=y
    CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
    CONFIG_HAVE_RSEQ=y
    CONFIG_HAVE_HW_BREAKPOINT=y
    CONFIG_HAVE_PERF_REGS=y
    CONFIG_HAVE_PERF_USER_STACK_DUMP=y
    CONFIG_HAVE_ARCH_JUMP_LABEL=y
    CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
    CONFIG_HAVE_ARCH_SECCOMP=y
    CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
    CONFIG_SECCOMP=y
    CONFIG_SECCOMP_FILTER=y
    CONFIG_HAVE_STACKPROTECTOR=y
    CONFIG_STACKPROTECTOR=y
    CONFIG_STACKPROTECTOR_STRONG=y
    CONFIG_HAVE_CONTEXT_TRACKING=y
    CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
    CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
    CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
    CONFIG_MODULES_USE_ELF_REL=y
    CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
    CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
    CONFIG_HAVE_EXIT_THREAD=y
    CONFIG_ARCH_MMAP_RND_BITS=8
    CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
    CONFIG_CLONE_BACKWARDS=y
    CONFIG_OLD_SIGSUSPEND3=y
    CONFIG_OLD_SIGACTION=y
    CONFIG_COMPAT_32BIT_TIME=y
    CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
    CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
    CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
    CONFIG_STRICT_KERNEL_RWX=y
    CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
    CONFIG_STRICT_MODULE_RWX=y
    CONFIG_ARCH_HAS_PHYS_TO_DMA=y
    # CONFIG_LOCK_EVENT_COUNTS is not set
    CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y
    # GCOV-based kernel profiling
    # CONFIG_GCOV_KERNEL is not set
    CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
    # end of GCOV-based kernel profiling
    CONFIG_HAVE_GCC_PLUGINS=y
    CONFIG_GCC_PLUGINS=y
    # CONFIG_GCC_PLUGIN_CYC_COMPLEXITY is not set
    # CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
    # CONFIG_GCC_PLUGIN_RANDSTRUCT is not set
    # end of General architecture-dependent options
    CONFIG_RT_MUTEXES=y
    CONFIG_BASE_SMALL=0
    CONFIG_MODULES=y
    CONFIG_MODULE_FORCE_LOAD=y
    CONFIG_MODULE_UNLOAD=y
    CONFIG_MODULE_FORCE_UNLOAD=y
    CONFIG_MODVERSIONS=y
    CONFIG_MODULE_SRCVERSION_ALL=y
    # CONFIG_MODULE_SIG is not set
    # CONFIG_MODULE_COMPRESS is not set
    # CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
    # CONFIG_UNUSED_SYMBOLS is not set
    # CONFIG_TRIM_UNUSED_KSYMS is not set
    CONFIG_MODULES_TREE_LOOKUP=y
    CONFIG_BLOCK=y
    CONFIG_BLK_SCSI_REQUEST=y
    CONFIG_BLK_DEV_BSG=y
    CONFIG_BLK_DEV_BSGLIB=y
    # CONFIG_BLK_DEV_INTEGRITY is not set
    # CONFIG_BLK_DEV_ZONED is not set
    # CONFIG_BLK_DEV_THROTTLING is not set
    CONFIG_BLK_CMDLINE_PARSER=y
    # CONFIG_BLK_WBT is not set
    # CONFIG_BLK_CGROUP_IOLATENCY is not set
    # CONFIG_BLK_CGROUP_IOCOST is not set
    CONFIG_BLK_DEBUG_FS=y
    # CONFIG_BLK_SED_OPAL is not set
    # CONFIG_BLK_INLINE_ENCRYPTION is not set
    # Partition Types
    CONFIG_PARTITION_ADVANCED=y
    # CONFIG_ACORN_PARTITION is not set
    # CONFIG_AIX_PARTITION is not set
    # CONFIG_OSF_PARTITION is not set
    # CONFIG_AMIGA_PARTITION is not set
    # CONFIG_ATARI_PARTITION is not set
    # CONFIG_MAC_PARTITION is not set
    CONFIG_MSDOS_PARTITION=y
    # CONFIG_BSD_DISKLABEL is not set
    # CONFIG_MINIX_SUBPARTITION is not set
    # CONFIG_SOLARIS_X86_PARTITION is not set
    # CONFIG_UNIXWARE_DISKLABEL is not set
    # CONFIG_LDM_PARTITION is not set
    # CONFIG_SGI_PARTITION is not set
    # CONFIG_ULTRIX_PARTITION is not set
    # CONFIG_SUN_PARTITION is not set
    # CONFIG_KARMA_PARTITION is not set
    CONFIG_EFI_PARTITION=y
    # CONFIG_SYSV68_PARTITION is not set
    CONFIG_CMDLINE_PARTITION=y
    # end of Partition Types
    CONFIG_BLK_MQ_PCI=y
    CONFIG_BLK_MQ_VIRTIO=y
    CONFIG_BLK_PM=y
    # IO Schedulers
    CONFIG_MQ_IOSCHED_DEADLINE=y
    CONFIG_MQ_IOSCHED_KYBER=y
    # CONFIG_IOSCHED_BFQ is not set
    # end of IO Schedulers
    CONFIG_ASN1=y
    CONFIG_UNINLINE_SPIN_UNLOCK=y
    CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
    CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y
    CONFIG_FREEZER=y
    # Executable file formats
    CONFIG_BINFMT_ELF=y
    # CONFIG_BINFMT_ELF_FDPIC is not set
    CONFIG_ELFCORE=y
    CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
    CONFIG_BINFMT_SCRIPT=y
    CONFIG_ARCH_HAS_BINFMT_FLAT=y
    # CONFIG_BINFMT_FLAT is not set
    CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
    # CONFIG_BINFMT_MISC is not set
    CONFIG_COREDUMP=y
    # end of Executable file formats
    # Memory Management options
    CONFIG_SELECT_MEMORY_MODEL=y
    CONFIG_FLATMEM_MANUAL=y
    # CONFIG_SPARSEMEM_MANUAL is not set
    CONFIG_FLATMEM=y
    CONFIG_FLAT_NODE_MEM_MAP=y
    CONFIG_ARCH_KEEP_MEMBLOCK=y
    CONFIG_MEMORY_ISOLATION=y
    CONFIG_SPLIT_PTLOCK_CPUS=4
    CONFIG_COMPACTION=y
    # CONFIG_PAGE_REPORTING is not set
    CONFIG_MIGRATION=y
    CONFIG_CONTIG_ALLOC=y
    CONFIG_BOUNCE=y
    # CONFIG_KSM is not set
    CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
    CONFIG_NEED_PER_CPU_KM=y
    # CONFIG_CLEANCACHE is not set
    # CONFIG_FRONTSWAP is not set
    CONFIG_CMA=y
    # CONFIG_CMA_DEBUG is not set
    # CONFIG_CMA_DEBUGFS is not set
    CONFIG_CMA_AREAS=7
    # CONFIG_ZPOOL is not set
    # CONFIG_ZBUD is not set
    # CONFIG_ZSMALLOC is not set
    CONFIG_GENERIC_EARLY_IOREMAP=y
    # CONFIG_IDLE_PAGE_TRACKING is not set
    CONFIG_FRAME_VECTOR=y
    # CONFIG_PERCPU_STATS is not set
    # CONFIG_GUP_BENCHMARK is not set
    # end of Memory Management options
    CONFIG_NET=y
    CONFIG_NET_INGRESS=y
    CONFIG_NET_EGRESS=y
    CONFIG_SKB_EXTENSIONS=y
    # Networking options
    CONFIG_PACKET=y
    # CONFIG_PACKET_DIAG is not set
    CONFIG_UNIX=y
    CONFIG_UNIX_SCM=y
    # CONFIG_UNIX_DIAG is not set
    # CONFIG_TLS is not set
    CONFIG_XFRM=y
    CONFIG_XFRM_ALGO=m
    CONFIG_XFRM_USER=m
    # CONFIG_XFRM_INTERFACE is not set
    # CONFIG_XFRM_SUB_POLICY is not set
    # CONFIG_XFRM_MIGRATE is not set
    # CONFIG_XFRM_STATISTICS is not set
    CONFIG_XFRM_AH=m
    CONFIG_XFRM_ESP=m
    CONFIG_XFRM_IPCOMP=m
    CONFIG_NET_KEY=m
    # CONFIG_NET_KEY_MIGRATE is not set
    CONFIG_INET=y
    CONFIG_IP_MULTICAST=y
    # CONFIG_IP_ADVANCED_ROUTER is not set
    CONFIG_IP_ROUTE_CLASSID=y
    CONFIG_IP_PNP=y
    CONFIG_IP_PNP_DHCP=y
    CONFIG_IP_PNP_BOOTP=y
    CONFIG_IP_PNP_RARP=y
    # CONFIG_NET_IPIP is not set
    # CONFIG_NET_IPGRE_DEMUX is not set
    CONFIG_NET_IP_TUNNEL=y
    # CONFIG_IP_MROUTE is not set
    # CONFIG_SYN_COOKIES is not set
    # CONFIG_NET_IPVTI is not set
    # CONFIG_NET_FOU is not set
    # CONFIG_NET_FOU_IP_TUNNELS is not set
    CONFIG_INET_AH=m
    CONFIG_INET_ESP=m
    # CONFIG_INET_ESP_OFFLOAD is not set
    # CONFIG_INET_ESPINTCP is not set
    CONFIG_INET_IPCOMP=m
    CONFIG_INET_XFRM_TUNNEL=m
    CONFIG_INET_TUNNEL=y
    CONFIG_INET_DIAG=y
    CONFIG_INET_TCP_DIAG=y
    # CONFIG_INET_UDP_DIAG is not set
    # CONFIG_INET_RAW_DIAG is not set
    # CONFIG_INET_DIAG_DESTROY is not set
    # CONFIG_TCP_CONG_ADVANCED is not set
    CONFIG_TCP_CONG_CUBIC=y
    CONFIG_DEFAULT_TCP_CONG="cubic"
    # CONFIG_TCP_MD5SIG is not set
    CONFIG_IPV6=y
    CONFIG_IPV6_ROUTER_PREF=y
    # CONFIG_IPV6_ROUTE_INFO is not set
    CONFIG_IPV6_OPTIMISTIC_DAD=y
    CONFIG_INET6_AH=m
    CONFIG_INET6_ESP=m
    # CONFIG_INET6_ESP_OFFLOAD is not set
    # CONFIG_INET6_ESPINTCP is not set
    CONFIG_INET6_IPCOMP=m
    CONFIG_IPV6_MIP6=m
    # CONFIG_IPV6_ILA is not set
    CONFIG_INET6_XFRM_TUNNEL=m
    CONFIG_INET6_TUNNEL=m
    # CONFIG_IPV6_VTI is not set
    CONFIG_IPV6_SIT=y
    # CONFIG_IPV6_SIT_6RD is not set
    CONFIG_IPV6_NDISC_NODETYPE=y
    CONFIG_IPV6_TUNNEL=m
    CONFIG_IPV6_MULTIPLE_TABLES=y
    # CONFIG_IPV6_SUBTREES is not set
    # CONFIG_IPV6_MROUTE is not set
    # CONFIG_IPV6_SEG6_LWTUNNEL is not set
    # CONFIG_IPV6_SEG6_HMAC is not set
    # CONFIG_IPV6_RPL_LWTUNNEL is not set
    # CONFIG_MPTCP is not set
    # CONFIG_NETWORK_SECMARK is not set
    CONFIG_NET_PTP_CLASSIFY=y
    # CONFIG_NETWORK_PHY_TIMESTAMPING is not set
    CONFIG_NETFILTER=y
    CONFIG_NETFILTER_ADVANCED=y
    # CONFIG_BRIDGE_NETFILTER is not set
    # Core Netfilter Configuration
    CONFIG_NETFILTER_INGRESS=y
    CONFIG_NETFILTER_FAMILY_BRIDGE=y
    CONFIG_NETFILTER_FAMILY_ARP=y
    # CONFIG_NETFILTER_NETLINK_ACCT is not set
    # CONFIG_NETFILTER_NETLINK_QUEUE is not set
    # CONFIG_NETFILTER_NETLINK_LOG is not set
    # CONFIG_NETFILTER_NETLINK_OSF is not set
    CONFIG_NF_CONNTRACK=m
    # CONFIG_NF_LOG_NETDEV is not set
    # CONFIG_NF_CONNTRACK_MARK is not set
    # CONFIG_NF_CONNTRACK_ZONES is not set
    CONFIG_NF_CONNTRACK_PROCFS=y
    # CONFIG_NF_CONNTRACK_EVENTS is not set
    # CONFIG_NF_CONNTRACK_TIMEOUT is not set
    # CONFIG_NF_CONNTRACK_TIMESTAMP is not set
    # CONFIG_NF_CONNTRACK_LABELS is not set
    CONFIG_NF_CT_PROTO_DCCP=y
    CONFIG_NF_CT_PROTO_SCTP=y
    CONFIG_NF_CT_PROTO_UDPLITE=y
    # CONFIG_NF_CONNTRACK_AMANDA is not set
    # CONFIG_NF_CONNTRACK_FTP is not set
    # CONFIG_NF_CONNTRACK_H323 is not set
    # CONFIG_NF_CONNTRACK_IRC is not set
    # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
    # CONFIG_NF_CONNTRACK_SNMP is not set
    # CONFIG_NF_CONNTRACK_PPTP is not set
    # CONFIG_NF_CONNTRACK_SANE is not set
    # CONFIG_NF_CONNTRACK_SIP is not set
    # CONFIG_NF_CONNTRACK_TFTP is not set
    # CONFIG_NF_CT_NETLINK is not set
    CONFIG_NF_NAT=m
    CONFIG_NF_NAT_MASQUERADE=y
    # CONFIG_NF_TABLES is not set
    CONFIG_NETFILTER_XTABLES=m
    # Xtables combined modules
    CONFIG_NETFILTER_XT_MARK=m
    # CONFIG_NETFILTER_XT_CONNMARK is not set
    # Xtables targets
    CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
    # CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
    # CONFIG_NETFILTER_XT_TARGET_HMARK is not set
    CONFIG_NETFILTER_XT_TARGET_IDLETIMER=m
    # CONFIG_NETFILTER_XT_TARGET_LED is not set
    # CONFIG_NETFILTER_XT_TARGET_LOG is not set
    CONFIG_NETFILTER_XT_TARGET_MARK=m
    CONFIG_NETFILTER_XT_NAT=m
    # CONFIG_NETFILTER_XT_TARGET_NETMAP is not set
    # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set
    # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set
    # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set
    # CONFIG_NETFILTER_XT_TARGET_REDIRECT is not set
    CONFIG_NETFILTER_XT_TARGET_MASQUERADE=m
    # CONFIG_NETFILTER_XT_TARGET_TEE is not set
    # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set
    # Xtables matches
    # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE is not set
    # CONFIG_NETFILTER_XT_MATCH_BPF is not set
    # CONFIG_NETFILTER_XT_MATCH_CGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_CLUSTER is not set
    CONFIG_NETFILTER_XT_MATCH_COMMENT=m
    # CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLABEL is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
    # CONFIG_NETFILTER_XT_MATCH_CONNTRACK is not set
    CONFIG_NETFILTER_XT_MATCH_CPU=m
    # CONFIG_NETFILTER_XT_MATCH_DCCP is not set
    # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set
    # CONFIG_NETFILTER_XT_MATCH_DSCP is not set
    # CONFIG_NETFILTER_XT_MATCH_ECN is not set
    # CONFIG_NETFILTER_XT_MATCH_ESP is not set
    # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set
    # CONFIG_NETFILTER_XT_MATCH_HELPER is not set
    # CONFIG_NETFILTER_XT_MATCH_HL is not set
    # CONFIG_NETFILTER_XT_MATCH_IPCOMP is not set
    CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
    # CONFIG_NETFILTER_XT_MATCH_L2TP is not set
    CONFIG_NETFILTER_XT_MATCH_LENGTH=m
    CONFIG_NETFILTER_XT_MATCH_LIMIT=m
    CONFIG_NETFILTER_XT_MATCH_MAC=m
    CONFIG_NETFILTER_XT_MATCH_MARK=m
    CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
    # CONFIG_NETFILTER_XT_MATCH_NFACCT is not set
    # CONFIG_NETFILTER_XT_MATCH_OSF is not set
    # CONFIG_NETFILTER_XT_MATCH_OWNER is not set
    CONFIG_NETFILTER_XT_MATCH_POLICY=m
    CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
    # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set
    # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set
    # CONFIG_NETFILTER_XT_MATCH_REALM is not set
    # CONFIG_NETFILTER_XT_MATCH_RECENT is not set
    CONFIG_NETFILTER_XT_MATCH_SCTP=m
    # CONFIG_NETFILTER_XT_MATCH_SOCKET is not set
    # CONFIG_NETFILTER_XT_MATCH_STATE is not set
    # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set
    # CONFIG_NETFILTER_XT_MATCH_STRING is not set
    # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set
    # CONFIG_NETFILTER_XT_MATCH_TIME is not set
    # CONFIG_NETFILTER_XT_MATCH_U32 is not set
    # end of Core Netfilter Configuration
    # CONFIG_IP_SET is not set
    # CONFIG_IP_VS is not set
    # IP: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV4=m
    # CONFIG_NF_SOCKET_IPV4 is not set
    # CONFIG_NF_TPROXY_IPV4 is not set
    # CONFIG_NF_DUP_IPV4 is not set
    # CONFIG_NF_LOG_ARP is not set
    # CONFIG_NF_LOG_IPV4 is not set
    # CONFIG_NF_REJECT_IPV4 is not set
    CONFIG_IP_NF_IPTABLES=m
    # CONFIG_IP_NF_MATCH_AH is not set
    # CONFIG_IP_NF_MATCH_ECN is not set
    # CONFIG_IP_NF_MATCH_TTL is not set
    CONFIG_IP_NF_FILTER=m
    # CONFIG_IP_NF_TARGET_REJECT is not set
    # CONFIG_IP_NF_TARGET_SYNPROXY is not set
    CONFIG_IP_NF_NAT=m
    CONFIG_IP_NF_TARGET_MASQUERADE=m
    # CONFIG_IP_NF_TARGET_NETMAP is not set
    # CONFIG_IP_NF_TARGET_REDIRECT is not set
    # CONFIG_IP_NF_MANGLE is not set
    # CONFIG_IP_NF_RAW is not set
    CONFIG_IP_NF_ARPTABLES=m
    CONFIG_IP_NF_ARPFILTER=m
    CONFIG_IP_NF_ARP_MANGLE=m
    # end of IP: Netfilter Configuration
    # IPv6: Netfilter Configuration
    # CONFIG_NF_SOCKET_IPV6 is not set
    # CONFIG_NF_TPROXY_IPV6 is not set
    # CONFIG_NF_DUP_IPV6 is not set
    # CONFIG_NF_REJECT_IPV6 is not set
    # CONFIG_NF_LOG_IPV6 is not set
    # CONFIG_IP6_NF_IPTABLES is not set
    # end of IPv6: Netfilter Configuration
    CONFIG_NF_DEFRAG_IPV6=m
    # CONFIG_NF_CONNTRACK_BRIDGE is not set
    CONFIG_BRIDGE_NF_EBTABLES=m
    CONFIG_BRIDGE_EBT_BROUTE=m
    CONFIG_BRIDGE_EBT_T_FILTER=m
    CONFIG_BRIDGE_EBT_T_NAT=m
    CONFIG_BRIDGE_EBT_802_3=m
    CONFIG_BRIDGE_EBT_AMONG=m
    CONFIG_BRIDGE_EBT_ARP=m
    CONFIG_BRIDGE_EBT_IP=m
    CONFIG_BRIDGE_EBT_IP6=m
    CONFIG_BRIDGE_EBT_LIMIT=m
    CONFIG_BRIDGE_EBT_MARK=m
    CONFIG_BRIDGE_EBT_PKTTYPE=m
    CONFIG_BRIDGE_EBT_STP=m
    CONFIG_BRIDGE_EBT_VLAN=m
    CONFIG_BRIDGE_EBT_ARPREPLY=m
    CONFIG_BRIDGE_EBT_DNAT=m
    CONFIG_BRIDGE_EBT_MARK_T=m
    CONFIG_BRIDGE_EBT_REDIRECT=m
    CONFIG_BRIDGE_EBT_SNAT=m
    CONFIG_BRIDGE_EBT_LOG=m
    CONFIG_BRIDGE_EBT_NFLOG=m
    # CONFIG_BPFILTER is not set
    # CONFIG_IP_DCCP is not set
    CONFIG_IP_SCTP=m
    # CONFIG_SCTP_DBG_OBJCNT is not set
    CONFIG_SCTP_DEFAULT_COOKIE_HMAC_MD5=y
    # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_SHA1 is not set
    # CONFIG_SCTP_DEFAULT_COOKIE_HMAC_NONE is not set
    CONFIG_SCTP_COOKIE_HMAC_MD5=y
    # CONFIG_SCTP_COOKIE_HMAC_SHA1 is not set
    CONFIG_INET_SCTP_DIAG=m
    # CONFIG_RDS is not set
    # CONFIG_TIPC is not set
    # CONFIG_ATM is not set
    # CONFIG_L2TP is not set
    CONFIG_STP=m
    CONFIG_BRIDGE=m
    CONFIG_BRIDGE_IGMP_SNOOPING=y
    # CONFIG_BRIDGE_VLAN_FILTERING is not set
    # CONFIG_BRIDGE_MRP is not set
    CONFIG_HAVE_NET_DSA=y
    CONFIG_NET_DSA=m
    # CONFIG_NET_DSA_TAG_AR9331 is not set
    # CONFIG_NET_DSA_TAG_BRCM is not set
    # CONFIG_NET_DSA_TAG_BRCM_PREPEND is not set
    # CONFIG_NET_DSA_TAG_GSWIP is not set
    # CONFIG_NET_DSA_TAG_DSA is not set
    # CONFIG_NET_DSA_TAG_EDSA is not set
    # CONFIG_NET_DSA_TAG_MTK is not set
    # CONFIG_NET_DSA_TAG_KSZ is not set
    # CONFIG_NET_DSA_TAG_RTL4_A is not set
    # CONFIG_NET_DSA_TAG_OCELOT is not set
    # CONFIG_NET_DSA_TAG_QCA is not set
    # CONFIG_NET_DSA_TAG_LAN9303 is not set
    # CONFIG_NET_DSA_TAG_SJA1105 is not set
    # CONFIG_NET_DSA_TAG_TRAILER is not set
    CONFIG_VLAN_8021Q=m
    # CONFIG_VLAN_8021Q_GVRP is not set
    # CONFIG_VLAN_8021Q_MVRP is not set
    # CONFIG_DECNET is not set
    CONFIG_LLC=m
    # CONFIG_LLC2 is not set
    # CONFIG_ATALK is not set
    # CONFIG_X25 is not set
    # CONFIG_LAPB is not set
    # CONFIG_PHONET is not set
    # CONFIG_6LOWPAN is not set
    # CONFIG_IEEE802154 is not set
    CONFIG_NET_SCHED=y
    # Queueing/Scheduling
    CONFIG_NET_SCH_CBQ=m
    CONFIG_NET_SCH_HTB=m
    CONFIG_NET_SCH_HFSC=m
    CONFIG_NET_SCH_PRIO=m
    CONFIG_NET_SCH_MULTIQ=m
    CONFIG_NET_SCH_RED=m
    CONFIG_NET_SCH_SFB=m
    CONFIG_NET_SCH_SFQ=m
    CONFIG_NET_SCH_TEQL=m
    CONFIG_NET_SCH_TBF=m
    # CONFIG_NET_SCH_CBS is not set
    # CONFIG_NET_SCH_ETF is not set
    CONFIG_NET_SCH_TAPRIO=m
    CONFIG_NET_SCH_GRED=m
    CONFIG_NET_SCH_DSMARK=m
    CONFIG_NET_SCH_NETEM=m
    CONFIG_NET_SCH_DRR=m
    CONFIG_NET_SCH_MQPRIO=m
    # CONFIG_NET_SCH_SKBPRIO is not set
    CONFIG_NET_SCH_CHOKE=m
    CONFIG_NET_SCH_QFQ=m
    CONFIG_NET_SCH_CODEL=m
    CONFIG_NET_SCH_FQ_CODEL=m
    # CONFIG_NET_SCH_CAKE is not set
    # CONFIG_NET_SCH_FQ is not set
    # CONFIG_NET_SCH_HHF is not set
    # CONFIG_NET_SCH_PIE is not set
    CONFIG_NET_SCH_INGRESS=m
    # CONFIG_NET_SCH_PLUG is not set
    # CONFIG_NET_SCH_ETS is not set
    # CONFIG_NET_SCH_DEFAULT is not set
    # Classification
    CONFIG_NET_CLS=y
    CONFIG_NET_CLS_BASIC=m
    CONFIG_NET_CLS_TCINDEX=m
    CONFIG_NET_CLS_ROUTE4=m
    CONFIG_NET_CLS_FW=m
    CONFIG_NET_CLS_U32=m
    # CONFIG_CLS_U32_PERF is not set
    CONFIG_CLS_U32_MARK=y
    CONFIG_NET_CLS_RSVP=m
    CONFIG_NET_CLS_RSVP6=m
    CONFIG_NET_CLS_FLOW=m
    # CONFIG_NET_CLS_CGROUP is not set
    # CONFIG_NET_CLS_BPF is not set
    # CONFIG_NET_CLS_FLOWER is not set
    # CONFIG_NET_CLS_MATCHALL is not set
    CONFIG_NET_EMATCH=y
    CONFIG_NET_EMATCH_STACK=32
    CONFIG_NET_EMATCH_CMP=m
    CONFIG_NET_EMATCH_NBYTE=m
    CONFIG_NET_EMATCH_U32=m
    CONFIG_NET_EMATCH_META=m
    CONFIG_NET_EMATCH_TEXT=m
    # CONFIG_NET_EMATCH_CANID is not set
    # CONFIG_NET_EMATCH_IPT is not set
    CONFIG_NET_CLS_ACT=y
    CONFIG_NET_ACT_POLICE=m
    CONFIG_NET_ACT_GACT=m
    CONFIG_GACT_PROB=y
    CONFIG_NET_ACT_MIRRED=m
    # CONFIG_NET_ACT_SAMPLE is not set
    CONFIG_NET_ACT_IPT=m
    CONFIG_NET_ACT_NAT=m
    CONFIG_NET_ACT_PEDIT=m
    CONFIG_NET_ACT_SIMP=m
    CONFIG_NET_ACT_SKBEDIT=m
    CONFIG_NET_ACT_CSUM=m
    # CONFIG_NET_ACT_MPLS is not set
    # CONFIG_NET_ACT_VLAN is not set
    # CONFIG_NET_ACT_BPF is not set
    # CONFIG_NET_ACT_SKBMOD is not set
    # CONFIG_NET_ACT_IFE is not set
    # CONFIG_NET_ACT_TUNNEL_KEY is not set
    # CONFIG_NET_ACT_GATE is not set
    # CONFIG_NET_TC_SKB_EXT is not set
    CONFIG_NET_SCH_FIFO=y
    # CONFIG_DCB is not set
    CONFIG_DNS_RESOLVER=y
    # CONFIG_BATMAN_ADV is not set
    # CONFIG_OPENVSWITCH is not set
    # CONFIG_VSOCKETS is not set
    # CONFIG_NETLINK_DIAG is not set
    # CONFIG_MPLS is not set
    # CONFIG_NET_NSH is not set
    CONFIG_HSR=m
    CONFIG_NET_SWITCHDEV=y
    # CONFIG_NET_L3_MASTER_DEV is not set
    # CONFIG_QRTR is not set
    # CONFIG_NET_NCSI is not set
    # CONFIG_CGROUP_NET_PRIO is not set
    # CONFIG_CGROUP_NET_CLASSID is not set
    CONFIG_NET_RX_BUSY_POLL=y
    CONFIG_BQL=y
    # CONFIG_BPF_JIT is not set
    # Network testing
    # CONFIG_NET_PKTGEN is not set
    # end of Network testing
    # end of Networking options
    # CONFIG_HAMRADIO is not set
    CONFIG_CAN=m
    CONFIG_CAN_RAW=m
    CONFIG_CAN_BCM=m
    CONFIG_CAN_GW=m
    # CONFIG_CAN_J1939 is not set
    # CONFIG_CAN_ISOTP is not set
    # CAN Device Drivers
    # CONFIG_CAN_VCAN is not set
    # CONFIG_CAN_VXCAN is not set
    # CONFIG_CAN_SLCAN is not set
    CONFIG_CAN_DEV=m
    CONFIG_CAN_CALC_BITTIMING=y
    CONFIG_CAN_FLEXCAN=m
    # CONFIG_CAN_GRCAN is not set
    # CONFIG_CAN_KVASER_PCIEFD is not set
    # CONFIG_CAN_TI_HECC is not set
    CONFIG_CAN_C_CAN=m
    CONFIG_CAN_C_CAN_PLATFORM=m
    # CONFIG_CAN_C_CAN_PCI is not set
    # CONFIG_CAN_CC770 is not set
    # CONFIG_CAN_IFI_CANFD is not set
    CONFIG_CAN_M_CAN=m
    CONFIG_CAN_M_CAN_PLATFORM=m
    # CONFIG_CAN_M_CAN_TCAN4X5X is not set
    # CONFIG_CAN_PEAK_PCIEFD is not set
    CONFIG_CAN_RCAR=m
    # CONFIG_CAN_RCAR_CANFD is not set
    # CONFIG_CAN_SJA1000 is not set
    # CONFIG_CAN_SOFTING is not set
    # CAN SPI interfaces
    # CONFIG_CAN_HI311X is not set
    CONFIG_CAN_MCP251X=m
    # CONFIG_CAN_MCP251XFD is not set
    # end of CAN SPI interfaces
    # CAN USB interfaces
    # CONFIG_CAN_8DEV_USB is not set
    # CONFIG_CAN_EMS_USB is not set
    # CONFIG_CAN_ESD_USB2 is not set
    # CONFIG_CAN_GS_USB is not set
    # CONFIG_CAN_KVASER_USB is not set
    # CONFIG_CAN_MCBA_USB is not set
    # CONFIG_CAN_PEAK_USB is not set
    # CONFIG_CAN_UCAN is not set
    # end of CAN USB interfaces
    # CONFIG_CAN_DEBUG_DEVICES is not set
    # end of CAN Device Drivers
    CONFIG_BT=m
    CONFIG_BT_BREDR=y
    # CONFIG_BT_RFCOMM is not set
    # CONFIG_BT_BNEP is not set
    # CONFIG_BT_HIDP is not set
    # CONFIG_BT_HS is not set
    CONFIG_BT_LE=y
    # CONFIG_BT_LEDS is not set
    # CONFIG_BT_MSFTEXT is not set
    CONFIG_BT_DEBUGFS=y
    # CONFIG_BT_SELFTEST is not set
    # CONFIG_BT_FEATURE_DEBUG is not set
    # Bluetooth device drivers
    CONFIG_BT_BCM=m
    # CONFIG_BT_HCIBTUSB is not set
    # CONFIG_BT_HCIBTSDIO is not set
    CONFIG_BT_HCIUART=m
    CONFIG_BT_HCIUART_SERDEV=y
    CONFIG_BT_HCIUART_H4=y
    # CONFIG_BT_HCIUART_NOKIA is not set
    # CONFIG_BT_HCIUART_BCSP is not set
    # CONFIG_BT_HCIUART_ATH3K is not set
    # CONFIG_BT_HCIUART_LL is not set
    # CONFIG_BT_HCIUART_3WIRE is not set
    # CONFIG_BT_HCIUART_INTEL is not set
    CONFIG_BT_HCIUART_BCM=y
    # CONFIG_BT_HCIUART_RTL is not set
    # CONFIG_BT_HCIUART_QCA is not set
    # CONFIG_BT_HCIUART_AG6XX is not set
    # CONFIG_BT_HCIUART_MRVL is not set
    # CONFIG_BT_HCIBCM203X is not set
    # CONFIG_BT_HCIBPA10X is not set
    # CONFIG_BT_HCIBFUSB is not set
    # CONFIG_BT_HCIVHCI is not set
    CONFIG_BT_MRVL=m
    CONFIG_BT_MRVL_SDIO=m
    # CONFIG_BT_MTKSDIO is not set
    # CONFIG_BT_MTKUART is not set
    # end of Bluetooth device drivers
    # CONFIG_AF_RXRPC is not set
    # CONFIG_AF_KCM is not set
    CONFIG_FIB_RULES=y
    CONFIG_WIRELESS=y
    CONFIG_CFG80211=m
    CONFIG_NL80211_TESTMODE=y
    # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
    # CONFIG_CFG80211_CERTIFICATION_ONUS is not set
    CONFIG_CFG80211_REQUIRE_SIGNED_REGDB=y
    CONFIG_CFG80211_USE_KERNEL_REGDB_KEYS=y
    CONFIG_CFG80211_DEFAULT_PS=y
    # CONFIG_CFG80211_DEBUGFS is not set
    CONFIG_CFG80211_CRDA_SUPPORT=y
    # CONFIG_CFG80211_WEXT is not set
    CONFIG_MAC80211=m
    CONFIG_MAC80211_HAS_RC=y
    CONFIG_MAC80211_RC_MINSTREL=y
    CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
    CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
    CONFIG_MAC80211_MESH=y
    CONFIG_MAC80211_LEDS=y
    # CONFIG_MAC80211_DEBUGFS is not set
    # CONFIG_MAC80211_MESSAGE_TRACING is not set
    # CONFIG_MAC80211_DEBUG_MENU is not set
    CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
    # CONFIG_WIMAX is not set
    CONFIG_RFKILL=y
    CONFIG_RFKILL_LEDS=y
    CONFIG_RFKILL_INPUT=y
    CONFIG_RFKILL_GPIO=y
    # CONFIG_NET_9P is not set
    # CONFIG_CAIF is not set
    CONFIG_RPMSG_PROTO=m
    # CONFIG_CEPH_LIB is not set
    CONFIG_NFC=m
    CONFIG_NFC_DIGITAL=m
    CONFIG_NFC_NCI=m
    CONFIG_NFC_NCI_SPI=m
    CONFIG_NFC_NCI_UART=m
    CONFIG_NFC_HCI=m
    CONFIG_NFC_SHDLC=y
    # Near Field Communication (NFC) devices
    # CONFIG_NFC_TRF7970A is not set
    # CONFIG_NFC_SIM is not set
    # CONFIG_NFC_PORT100 is not set
    # CONFIG_NFC_FDP is not set
    # CONFIG_NFC_PN544_I2C is not set
    # CONFIG_NFC_PN533_USB is not set
    # CONFIG_NFC_PN533_I2C is not set
    # CONFIG_NFC_PN532_UART is not set
    # CONFIG_NFC_MICROREAD_I2C is not set
    # CONFIG_NFC_MRVL_USB is not set
    # CONFIG_NFC_MRVL_UART is not set
    # CONFIG_NFC_ST21NFCA_I2C is not set
    # CONFIG_NFC_ST_NCI_I2C is not set
    # CONFIG_NFC_ST_NCI_SPI is not set
    # CONFIG_NFC_NXP_NCI is not set
    CONFIG_NFC_S3FWRN5=m
    CONFIG_NFC_S3FWRN5_I2C=m
    # CONFIG_NFC_ST95HF is not set
    # end of Near Field Communication (NFC) devices
    # CONFIG_PSAMPLE is not set
    # CONFIG_NET_IFE is not set
    # CONFIG_LWTUNNEL is not set
    CONFIG_DST_CACHE=y
    CONFIG_GRO_CELLS=y
    CONFIG_NET_DEVLINK=y
    CONFIG_PAGE_POOL=y
    CONFIG_FAILOVER=y
    CONFIG_ETHTOOL_NETLINK=y
    CONFIG_HAVE_EBPF_JIT=y
    # Device Drivers
    CONFIG_HAVE_PCI=y
    CONFIG_PCI=y
    CONFIG_PCI_DOMAINS=y
    CONFIG_PCI_DOMAINS_GENERIC=y
    CONFIG_PCI_SYSCALL=y
    CONFIG_PCIEPORTBUS=y
    # CONFIG_PCIEAER is not set
    CONFIG_PCIEASPM=y
    CONFIG_PCIEASPM_DEFAULT=y
    # CONFIG_PCIEASPM_POWERSAVE is not set
    # CONFIG_PCIEASPM_POWER_SUPERSAVE is not set
    # CONFIG_PCIEASPM_PERFORMANCE is not set
    CONFIG_PCIE_PME=y
    # CONFIG_PCIE_PTM is not set
    CONFIG_PCI_MSI=y
    CONFIG_PCI_MSI_IRQ_DOMAIN=y
    CONFIG_PCI_QUIRKS=y
    # CONFIG_PCI_DEBUG is not set
    # CONFIG_PCI_STUB is not set
    # CONFIG_PCI_IOV is not set
    # CONFIG_PCI_PRI is not set
    # CONFIG_PCI_PASID is not set
    CONFIG_PCI_LABEL=y
    # CONFIG_PCIE_BUS_TUNE_OFF is not set
    CONFIG_PCIE_BUS_DEFAULT=y
    # CONFIG_PCIE_BUS_SAFE is not set
    # CONFIG_PCIE_BUS_PERFORMANCE is not set
    # CONFIG_PCIE_BUS_PEER2PEER is not set
    # CONFIG_HOTPLUG_PCI is not set
    # PCI controller drivers
    # CONFIG_PCI_FTPCI100 is not set
    # CONFIG_PCI_HOST_GENERIC is not set
    # CONFIG_PCIE_XILINX is not set
    # CONFIG_PCI_V3_SEMI is not set
    # CONFIG_PCIE_ALTERA is not set
    # DesignWare PCI Core Support
    # CONFIG_PCIE_DW_PLAT_HOST is not set
    # CONFIG_PCIE_DW_PLAT_EP is not set
    # CONFIG_PCI_LAYERSCAPE is not set
    # CONFIG_PCI_LAYERSCAPE_EP is not set
    # CONFIG_PCI_MESON is not set
    # end of DesignWare PCI Core Support
    # Mobiveil PCIe Core Support
    # end of Mobiveil PCIe Core Support
    # Cadence PCIe controllers support
    CONFIG_PCIE_CADENCE=y
    CONFIG_PCIE_CADENCE_HOST=y
    CONFIG_PCIE_CADENCE_EP=y
    # CONFIG_PCIE_CADENCE_PLAT_HOST is not set
    # CONFIG_PCIE_CADENCE_PLAT_EP is not set
    CONFIG_PCI_J721E=y
    CONFIG_PCI_J721E_HOST=y
    CONFIG_PCI_J721E_EP=y
    # end of Cadence PCIe controllers support
    # end of PCI controller drivers
    # PCI Endpoint
    CONFIG_PCI_ENDPOINT=y
    CONFIG_PCI_ENDPOINT_CONFIGFS=y
    CONFIG_PCI_EPF_TEST=y
    CONFIG_PCI_EPF_NTB=y
    # end of PCI Endpoint
    # PCI switch controller drivers
    # CONFIG_PCI_SW_SWITCHTEC is not set
    # end of PCI switch controller drivers
    # CONFIG_PCCARD is not set
    # CONFIG_RAPIDIO is not set
    # Generic Driver Options
    # CONFIG_UEVENT_HELPER is not set
    CONFIG_DEVTMPFS=y
    CONFIG_DEVTMPFS_MOUNT=y
    CONFIG_STANDALONE=y
    CONFIG_PREVENT_FIRMWARE_BUILD=y
    # Firmware loader
    CONFIG_FW_LOADER=y
    CONFIG_EXTRA_FIRMWARE=""
    # CONFIG_FW_LOADER_USER_HELPER is not set
    # CONFIG_FW_LOADER_COMPRESS is not set
    CONFIG_FW_CACHE=y
    # end of Firmware loader
    CONFIG_WANT_DEV_COREDUMP=y
    CONFIG_ALLOW_DEV_COREDUMP=y
    CONFIG_DEV_COREDUMP=y
    # CONFIG_DEBUG_DRIVER is not set
    # CONFIG_DEBUG_DEVRES is not set
    # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
    # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
    CONFIG_GENERIC_CPU_AUTOPROBE=y
    CONFIG_SOC_BUS=y
    CONFIG_REGMAP=y
    CONFIG_REGMAP_I2C=y
    CONFIG_REGMAP_SPI=y
    CONFIG_REGMAP_MMIO=y
    CONFIG_REGMAP_IRQ=y
    CONFIG_DMA_SHARED_BUFFER=y
    # CONFIG_DMA_FENCE_TRACE is not set
    # end of Generic Driver Options
    # Bus devices
    # CONFIG_BRCMSTB_GISB_ARB is not set
    # CONFIG_MOXTET is not set
    # CONFIG_OMAP_INTERCONNECT is not set
    CONFIG_OMAP_OCP2SCP=y
    CONFIG_SIMPLE_PM_BUS=y
    CONFIG_TI_PWMSS=y
    CONFIG_TI_SYSC=y
    # CONFIG_VEXPRESS_CONFIG is not set
    # CONFIG_MHI_BUS is not set
    # end of Bus devices
    # CONFIG_CONNECTOR is not set
    # CONFIG_GNSS is not set
    CONFIG_MTD=y
    CONFIG_MTD_TESTS=m
    # Partition parsers
    # CONFIG_MTD_AR7_PARTS is not set
    CONFIG_MTD_CMDLINE_PARTS=y
    CONFIG_MTD_OF_PARTS=y
    # CONFIG_MTD_AFS_PARTS is not set
    # CONFIG_MTD_REDBOOT_PARTS is not set
    # end of Partition parsers
    # User Modules And Translation Layers
    CONFIG_MTD_BLKDEVS=y
    CONFIG_MTD_BLOCK=y
    # CONFIG_FTL is not set
    # CONFIG_NFTL is not set
    # CONFIG_INFTL is not set
    # CONFIG_RFD_FTL is not set
    # CONFIG_SSFDC is not set
    # CONFIG_SM_FTL is not set
    # CONFIG_MTD_OOPS is not set
    # CONFIG_MTD_SWAP is not set
    # CONFIG_MTD_PARTITIONED_MASTER is not set
    # RAM/ROM/Flash chip drivers
    CONFIG_MTD_CFI=y
    # CONFIG_MTD_JEDECPROBE is not set
    CONFIG_MTD_GEN_PROBE=y
    # CONFIG_MTD_CFI_ADV_OPTIONS is not set
    CONFIG_MTD_MAP_BANK_WIDTH_1=y
    CONFIG_MTD_MAP_BANK_WIDTH_2=y
    CONFIG_MTD_MAP_BANK_WIDTH_4=y
    CONFIG_MTD_CFI_I1=y
    CONFIG_MTD_CFI_I2=y
    CONFIG_MTD_CFI_INTELEXT=y
    CONFIG_MTD_CFI_AMDSTD=y
    # CONFIG_MTD_CFI_STAA is not set
    CONFIG_MTD_CFI_UTIL=y
    # CONFIG_MTD_RAM is not set
    # CONFIG_MTD_ROM is not set
    # CONFIG_MTD_ABSENT is not set
    # end of RAM/ROM/Flash chip drivers
    # Mapping drivers for chip access
    CONFIG_MTD_COMPLEX_MAPPINGS=y
    CONFIG_MTD_PHYSMAP=y
    # CONFIG_MTD_PHYSMAP_COMPAT is not set
    CONFIG_MTD_PHYSMAP_OF=y
    # CONFIG_MTD_PHYSMAP_VERSATILE is not set
    # CONFIG_MTD_PHYSMAP_GEMINI is not set
    # CONFIG_MTD_PHYSMAP_IXP4XX is not set
    # CONFIG_MTD_PHYSMAP_GPIO_ADDR is not set
    # CONFIG_MTD_PCI is not set
    # CONFIG_MTD_INTEL_VR_NOR is not set
    # CONFIG_MTD_PLATRAM is not set
    # end of Mapping drivers for chip access
    # Self-contained MTD device drivers
    # CONFIG_MTD_PMC551 is not set
    # CONFIG_MTD_DATAFLASH is not set
    # CONFIG_MTD_MCHP23K256 is not set
    # CONFIG_MTD_SST25L is not set
    # CONFIG_MTD_BCM47XXSFLASH is not set
    # CONFIG_MTD_SLRAM is not set
    # CONFIG_MTD_PHRAM is not set
    # CONFIG_MTD_MTDRAM is not set
    # CONFIG_MTD_BLOCK2MTD is not set
    # Disk-On-Chip Device Drivers
    # CONFIG_MTD_DOCG3 is not set
    # end of Self-contained MTD device drivers
    # NAND
    CONFIG_MTD_NAND_CORE=y
    # CONFIG_MTD_ONENAND is not set
    CONFIG_MTD_NAND_ECC_SW_HAMMING=y
    # CONFIG_MTD_NAND_ECC_SW_HAMMING_SMC is not set
    CONFIG_MTD_RAW_NAND=y
    # CONFIG_MTD_NAND_ECC_SW_BCH is not set
    # Raw/parallel NAND flash controllers
    CONFIG_MTD_NAND_DENALI=y
    # CONFIG_MTD_NAND_DENALI_PCI is not set
    CONFIG_MTD_NAND_DENALI_DT=y
    CONFIG_MTD_NAND_OMAP2=y
    CONFIG_MTD_NAND_OMAP_BCH=y
    CONFIG_MTD_NAND_OMAP_BCH_BUILD=y
    # CONFIG_MTD_NAND_CAFE is not set
    CONFIG_MTD_NAND_BRCMNAND=y
    # CONFIG_MTD_NAND_MXIC is not set
    # CONFIG_MTD_NAND_GPIO is not set
    # CONFIG_MTD_NAND_PLATFORM is not set
    # CONFIG_MTD_NAND_CADENCE is not set
    # CONFIG_MTD_NAND_ARASAN is not set
    # Misc
    # CONFIG_MTD_NAND_NANDSIM is not set
    # CONFIG_MTD_NAND_RICOH is not set
    # CONFIG_MTD_NAND_DISKONCHIP is not set
    # CONFIG_MTD_SPI_NAND is not set
    # ECC engine support
    CONFIG_MTD_NAND_ECC=y
    # end of ECC engine support
    # end of NAND
    # LPDDR & LPDDR2 PCM memory drivers
    # CONFIG_MTD_LPDDR is not set
    # CONFIG_MTD_LPDDR2_NVM is not set
    # end of LPDDR & LPDDR2 PCM memory drivers
    CONFIG_MTD_SPI_NOR=y
    # CONFIG_MTD_SPI_NOR_USE_4K_SECTORS is not set
    CONFIG_MTD_UBI=y
    CONFIG_MTD_UBI_WL_THRESHOLD=4096
    CONFIG_MTD_UBI_BEB_LIMIT=20
    # CONFIG_MTD_UBI_FASTMAP is not set
    # CONFIG_MTD_UBI_GLUEBI is not set
    # CONFIG_MTD_UBI_BLOCK is not set
    CONFIG_MTD_HYPERBUS=y
    CONFIG_DTC=y
    CONFIG_OF=y
    # CONFIG_OF_UNITTEST is not set
    CONFIG_OF_FLATTREE=y
    CONFIG_OF_EARLY_FLATTREE=y
    CONFIG_OF_KOBJ=y
    CONFIG_OF_DYNAMIC=y
    CONFIG_OF_ADDRESS=y
    CONFIG_OF_IRQ=y
    CONFIG_OF_NET=y
    CONFIG_OF_RESERVED_MEM=y
    # CONFIG_OF_OVERLAY is not set
    CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
    # CONFIG_PARPORT is not set
    CONFIG_BLK_DEV=y
    # CONFIG_BLK_DEV_NULL_BLK is not set
    CONFIG_CDROM=y
    # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set
    # CONFIG_BLK_DEV_UMEM is not set
    CONFIG_BLK_DEV_LOOP=y
    CONFIG_BLK_DEV_LOOP_MIN_COUNT=8
    # CONFIG_BLK_DEV_CRYPTOLOOP is not set
    # CONFIG_BLK_DEV_DRBD is not set
    # CONFIG_BLK_DEV_NBD is not set
    # CONFIG_BLK_DEV_SX8 is not set
    CONFIG_BLK_DEV_RAM=y
    CONFIG_BLK_DEV_RAM_COUNT=16
    CONFIG_BLK_DEV_RAM_SIZE=65536
    # CONFIG_CDROM_PKTCDVD is not set
    # CONFIG_ATA_OVER_ETH is not set
    CONFIG_VIRTIO_BLK=y
    # CONFIG_BLK_DEV_RBD is not set
    # CONFIG_BLK_DEV_RSXX is not set
    # NVME Support
    CONFIG_NVME_CORE=m
    CONFIG_BLK_DEV_NVME=m
    # CONFIG_NVME_MULTIPATH is not set
    # CONFIG_NVME_HWMON is not set
    # CONFIG_NVME_FC is not set
    # CONFIG_NVME_TCP is not set
    # CONFIG_NVME_TARGET is not set
    # end of NVME Support
    # Misc devices
    CONFIG_AD525X_DPOT=y
    CONFIG_AD525X_DPOT_I2C=y
    # CONFIG_AD525X_DPOT_SPI is not set
    # CONFIG_DUMMY_IRQ is not set
    # CONFIG_PHANTOM is not set
    # CONFIG_TIFM_CORE is not set
    CONFIG_ICS932S401=y
    # CONFIG_ENCLOSURE_SERVICES is not set
    # CONFIG_HP_ILO is not set
    CONFIG_APDS9802ALS=y
    CONFIG_ISL29003=y
    # CONFIG_ISL29020 is not set
    # CONFIG_SENSORS_TSL2550 is not set
    # CONFIG_SENSORS_BH1770 is not set
    # CONFIG_SENSORS_APDS990X is not set
    # CONFIG_HMC6352 is not set
    # CONFIG_DS1682 is not set
    # CONFIG_LATTICE_ECP3_CONFIG is not set
    CONFIG_SRAM=y
    CONFIG_SRAM_EXEC=y
    CONFIG_SRAM_DMA_HEAP=y
    CONFIG_PCI_ENDPOINT_TEST=m
    # CONFIG_XILINX_SDFEC is not set
    # CONFIG_PVPANIC is not set
    # CONFIG_HISI_HIKEY_USB is not set
    # CONFIG_C2PORT is not set
    # EEPROM support
    CONFIG_EEPROM_AT24=m
    # CONFIG_EEPROM_AT25 is not set
    # CONFIG_EEPROM_LEGACY is not set
    # CONFIG_EEPROM_MAX6875 is not set
    CONFIG_EEPROM_93CX6=y
    CONFIG_EEPROM_93XX46=m
    # CONFIG_EEPROM_IDT_89HPESX is not set
    # CONFIG_EEPROM_EE1004 is not set
    # end of EEPROM support
    # CONFIG_CB710_CORE is not set
    # Texas Instruments shared transport line discipline
    # CONFIG_TI_ST is not set
    # end of Texas Instruments shared transport line discipline
    # CONFIG_SENSORS_LIS3_SPI is not set
    # CONFIG_SENSORS_LIS3_I2C is not set
    # CONFIG_ALTERA_STAPL is not set
    # CONFIG_ECHO is not set
    # CONFIG_MISC_ALCOR_PCI is not set
    # CONFIG_MISC_RTSX_PCI is not set
    # CONFIG_MISC_RTSX_USB is not set
    # CONFIG_HABANA_AI is not set
    # CONFIG_UACCE is not set
    # end of Misc devices
    CONFIG_HAVE_IDE=y
    # CONFIG_IDE is not set
    # SCSI device support
    CONFIG_SCSI_MOD=y
    # CONFIG_RAID_ATTRS is not set
    CONFIG_SCSI=y
    CONFIG_SCSI_DMA=y
    CONFIG_SCSI_PROC_FS=y
    # SCSI support type (disk, tape, CD-ROM)
    CONFIG_BLK_DEV_SD=y
    # CONFIG_CHR_DEV_ST is not set
    CONFIG_BLK_DEV_SR=y
    # CONFIG_CHR_DEV_SG is not set
    # CONFIG_CHR_DEV_SCH is not set
    # CONFIG_SCSI_CONSTANTS is not set
    # CONFIG_SCSI_LOGGING is not set
    # CONFIG_SCSI_SCAN_ASYNC is not set
    # SCSI Transports
    # CONFIG_SCSI_SPI_ATTRS is not set
    # CONFIG_SCSI_FC_ATTRS is not set
    # CONFIG_SCSI_ISCSI_ATTRS is not set
    # CONFIG_SCSI_SAS_ATTRS is not set
    # CONFIG_SCSI_SAS_LIBSAS is not set
    # CONFIG_SCSI_SRP_ATTRS is not set
    # end of SCSI Transports
    CONFIG_SCSI_LOWLEVEL=y
    # CONFIG_ISCSI_TCP is not set
    # CONFIG_ISCSI_BOOT_SYSFS is not set
    # CONFIG_SCSI_CXGB3_ISCSI is not set
    # CONFIG_SCSI_CXGB4_ISCSI is not set
    # CONFIG_SCSI_BNX2_ISCSI is not set
    # CONFIG_BE2ISCSI is not set
    # CONFIG_BLK_DEV_3W_XXXX_RAID is not set
    # CONFIG_SCSI_HPSA is not set
    # CONFIG_SCSI_3W_9XXX is not set
    # CONFIG_SCSI_3W_SAS is not set
    # CONFIG_SCSI_ACARD is not set
    # CONFIG_SCSI_AACRAID is not set
    # CONFIG_SCSI_AIC7XXX is not set
    # CONFIG_SCSI_AIC79XX is not set
    # CONFIG_SCSI_AIC94XX is not set
    # CONFIG_SCSI_MVSAS is not set
    # CONFIG_SCSI_MVUMI is not set
    # CONFIG_SCSI_ADVANSYS is not set
    # CONFIG_SCSI_ARCMSR is not set
    # CONFIG_SCSI_ESAS2R is not set
    # CONFIG_MEGARAID_NEWGEN is not set
    # CONFIG_MEGARAID_LEGACY is not set
    # CONFIG_MEGARAID_SAS is not set
    # CONFIG_SCSI_MPT3SAS is not set
    # CONFIG_SCSI_MPT2SAS is not set
    # CONFIG_SCSI_SMARTPQI is not set
    CONFIG_SCSI_UFSHCD=y
    # CONFIG_SCSI_UFSHCD_PCI is not set
    CONFIG_SCSI_UFSHCD_PLATFORM=y
    CONFIG_SCSI_UFS_CDNS_PLATFORM=y
    # CONFIG_SCSI_UFS_DWC_TC_PLATFORM is not set
    CONFIG_SCSI_UFS_BSG=y
    # CONFIG_SCSI_HPTIOP is not set
    # CONFIG_SCSI_MYRB is not set
    # CONFIG_SCSI_MYRS is not set
    # CONFIG_SCSI_SNIC is not set
    # CONFIG_SCSI_DMX3191D is not set
    # CONFIG_SCSI_FDOMAIN_PCI is not set
    # CONFIG_SCSI_GDTH is not set
    # CONFIG_SCSI_IPS is not set
    # CONFIG_SCSI_INITIO is not set
    # CONFIG_SCSI_INIA100 is not set
    # CONFIG_SCSI_STEX is not set
    # CONFIG_SCSI_SYM53C8XX_2 is not set
    # CONFIG_SCSI_IPR is not set
    # CONFIG_SCSI_QLOGIC_1280 is not set
    # CONFIG_SCSI_QLA_ISCSI is not set
    # CONFIG_SCSI_DC395x is not set
    # CONFIG_SCSI_AM53C974 is not set
    # CONFIG_SCSI_NSP32 is not set
    # CONFIG_SCSI_WD719X is not set
    # CONFIG_SCSI_DEBUG is not set
    # CONFIG_SCSI_PMCRAID is not set
    # CONFIG_SCSI_PM8001 is not set
    # CONFIG_SCSI_VIRTIO is not set
    # CONFIG_SCSI_DH is not set
    # end of SCSI device support
    CONFIG_ATA=m
    CONFIG_SATA_HOST=y
    CONFIG_ATA_VERBOSE_ERROR=y
    CONFIG_ATA_FORCE=y
    CONFIG_SATA_PMP=y
    # Controllers with non-SFF native interface
    CONFIG_SATA_AHCI=m
    CONFIG_SATA_MOBILE_LPM_POLICY=0
    CONFIG_SATA_AHCI_PLATFORM=m
    CONFIG_AHCI_DM816=m
    # CONFIG_AHCI_CEVA is not set
    # CONFIG_AHCI_QORIQ is not set
    # CONFIG_SATA_INIC162X is not set
    # CONFIG_SATA_ACARD_AHCI is not set
    # CONFIG_SATA_SIL24 is not set
    CONFIG_ATA_SFF=y
    # SFF controllers with custom DMA interface
    # CONFIG_PDC_ADMA is not set
    # CONFIG_SATA_QSTOR is not set
    # CONFIG_SATA_SX4 is not set
    CONFIG_ATA_BMDMA=y
    # SATA SFF controllers with BMDMA
    # CONFIG_ATA_PIIX is not set
    # CONFIG_SATA_DWC is not set
    CONFIG_SATA_MV=m
    # CONFIG_SATA_NV is not set
    # CONFIG_SATA_PROMISE is not set
    # CONFIG_SATA_SIL is not set
    # CONFIG_SATA_SIS is not set
    # CONFIG_SATA_SVW is not set
    # CONFIG_SATA_ULI is not set
    # CONFIG_SATA_VIA is not set
    # CONFIG_SATA_VITESSE is not set
    # PATA SFF controllers with BMDMA
    # CONFIG_PATA_ALI is not set
    # CONFIG_PATA_AMD is not set
    # CONFIG_PATA_ARTOP is not set
    # CONFIG_PATA_ATIIXP is not set
    # CONFIG_PATA_ATP867X is not set
    # CONFIG_PATA_CMD64X is not set
    # CONFIG_PATA_CYPRESS is not set
    # CONFIG_PATA_EFAR is not set
    # CONFIG_PATA_HPT366 is not set
    # CONFIG_PATA_HPT37X is not set
    # CONFIG_PATA_HPT3X2N is not set
    # CONFIG_PATA_HPT3X3 is not set
    # CONFIG_PATA_IT8213 is not set
    # CONFIG_PATA_IT821X is not set
    # CONFIG_PATA_JMICRON is not set
    # CONFIG_PATA_MARVELL is not set
    # CONFIG_PATA_NETCELL is not set
    # CONFIG_PATA_NINJA32 is not set
    # CONFIG_PATA_NS87415 is not set
    # CONFIG_PATA_OLDPIIX is not set
    # CONFIG_PATA_OPTIDMA is not set
    # CONFIG_PATA_PDC2027X is not set
    # CONFIG_PATA_PDC_OLD is not set
    # CONFIG_PATA_RADISYS is not set
    # CONFIG_PATA_RDC is not set
    # CONFIG_PATA_SCH is not set
    # CONFIG_PATA_SERVERWORKS is not set
    # CONFIG_PATA_SIL680 is not set
    # CONFIG_PATA_SIS is not set
    # CONFIG_PATA_TOSHIBA is not set
    # CONFIG_PATA_TRIFLEX is not set
    # CONFIG_PATA_VIA is not set
    # CONFIG_PATA_WINBOND is not set
    # PIO-only SFF controllers
    # CONFIG_PATA_CMD640_PCI is not set
    # CONFIG_PATA_MPIIX is not set
    # CONFIG_PATA_NS87410 is not set
    # CONFIG_PATA_OPTI is not set
    # CONFIG_PATA_PLATFORM is not set
    # CONFIG_PATA_RZ1000 is not set
    # Generic fallback / legacy drivers
    # CONFIG_ATA_GENERIC is not set
    # CONFIG_PATA_LEGACY is not set
    # CONFIG_MD is not set
    # CONFIG_TARGET_CORE is not set
    # CONFIG_FUSION is not set
    # IEEE 1394 (FireWire) support
    # CONFIG_FIREWIRE is not set
    # CONFIG_FIREWIRE_NOSY is not set
    # end of IEEE 1394 (FireWire) support
    CONFIG_NETDEVICES=y
    CONFIG_MII=y
    CONFIG_NET_CORE=y
    # CONFIG_BONDING is not set
    # CONFIG_DUMMY is not set
    # CONFIG_WIREGUARD is not set
    # CONFIG_EQUALIZER is not set
    # CONFIG_NET_FC is not set
    # CONFIG_IFB is not set
    # CONFIG_NET_TEAM is not set
    # CONFIG_MACVLAN is not set
    # CONFIG_IPVLAN is not set
    # CONFIG_VXLAN is not set
    # CONFIG_GENEVE is not set
    # CONFIG_BAREUDP is not set
    # CONFIG_GTP is not set
    # CONFIG_MACSEC is not set
    # CONFIG_NETCONSOLE is not set
    CONFIG_NTB_NETDEV=m
    # CONFIG_TUN is not set
    # CONFIG_TUN_VNET_CROSS_LE is not set
    # CONFIG_VETH is not set
    CONFIG_VIRTIO_NET=y
    # CONFIG_NLMON is not set
    # CONFIG_ARCNET is not set
    # Distributed Switch Architecture drivers
    # CONFIG_B53 is not set
    # CONFIG_NET_DSA_BCM_SF2 is not set
    # CONFIG_NET_DSA_LOOP is not set
    # CONFIG_NET_DSA_LANTIQ_GSWIP is not set
    # CONFIG_NET_DSA_MT7530 is not set
    # CONFIG_NET_DSA_MV88E6060 is not set
    # CONFIG_NET_DSA_MICROCHIP_KSZ9477 is not set
    # CONFIG_NET_DSA_MICROCHIP_KSZ8795 is not set
    # CONFIG_NET_DSA_MV88E6XXX is not set
    # CONFIG_NET_DSA_MSCC_SEVILLE is not set
    # CONFIG_NET_DSA_AR9331 is not set
    # CONFIG_NET_DSA_SJA1105 is not set
    # CONFIG_NET_DSA_QCA8K is not set
    # CONFIG_NET_DSA_REALTEK_SMI is not set
    # CONFIG_NET_DSA_SMSC_LAN9303_I2C is not set
    # CONFIG_NET_DSA_SMSC_LAN9303_MDIO is not set
    # CONFIG_NET_DSA_VITESSE_VSC73XX_SPI is not set
    # CONFIG_NET_DSA_VITESSE_VSC73XX_PLATFORM is not set
    # end of Distributed Switch Architecture drivers
    CONFIG_ETHERNET=y
    # CONFIG_NET_VENDOR_3COM is not set
    # CONFIG_NET_VENDOR_ADAPTEC is not set
    # CONFIG_NET_VENDOR_AGERE is not set
    CONFIG_NET_VENDOR_ALACRITECH=y
    # CONFIG_SLICOSS is not set
    # CONFIG_NET_VENDOR_ALTEON is not set
    # CONFIG_ALTERA_TSE is not set
    # CONFIG_NET_VENDOR_AMAZON is not set
    # CONFIG_NET_VENDOR_AMD is not set
    CONFIG_NET_VENDOR_AQUANTIA=y
    # CONFIG_NET_VENDOR_ARC is not set
    # CONFIG_NET_VENDOR_ATHEROS is not set
    CONFIG_NET_VENDOR_AURORA=y
    # CONFIG_AURORA_NB8800 is not set
    CONFIG_NET_VENDOR_BROADCOM=y
    # CONFIG_B44 is not set
    # CONFIG_BCMGENET is not set
    # CONFIG_BNX2 is not set
    # CONFIG_CNIC is not set
    CONFIG_TIGON3=m
    CONFIG_TIGON3_HWMON=y
    # CONFIG_BNX2X is not set
    # CONFIG_SYSTEMPORT is not set
    # CONFIG_BNXT is not set
    # CONFIG_NET_VENDOR_BROCADE is not set
    CONFIG_NET_VENDOR_CADENCE=y
    CONFIG_MACB=y
    CONFIG_MACB_USE_HWSTAMP=y
    # CONFIG_MACB_PCI is not set
    # CONFIG_NET_VENDOR_CAVIUM is not set
    # CONFIG_NET_VENDOR_CHELSIO is not set
    # CONFIG_NET_VENDOR_CIRRUS is not set
    # CONFIG_NET_VENDOR_CISCO is not set
    CONFIG_NET_VENDOR_CORTINA=y
    # CONFIG_GEMINI_ETHERNET is not set
    # CONFIG_DM9000 is not set
    # CONFIG_DNET is not set
    # CONFIG_NET_VENDOR_DEC is not set
    # CONFIG_NET_VENDOR_DLINK is not set
    # CONFIG_NET_VENDOR_EMULEX is not set
    # CONFIG_NET_VENDOR_EZCHIP is not set
    # CONFIG_NET_VENDOR_FARADAY is not set
    CONFIG_NET_VENDOR_GOOGLE=y
    # CONFIG_GVE is not set
    # CONFIG_NET_VENDOR_HISILICON is not set
    CONFIG_NET_VENDOR_HUAWEI=y
    # CONFIG_NET_VENDOR_I825XX is not set
    CONFIG_NET_VENDOR_INTEL=y
    # CONFIG_E100 is not set
    CONFIG_E1000=m
    CONFIG_E1000E=m
    # CONFIG_IGB is not set
    # CONFIG_IGBVF is not set
    # CONFIG_IXGB is not set
    # CONFIG_IXGBE is not set
    # CONFIG_IXGBEVF is not set
    # CONFIG_I40E is not set
    # CONFIG_I40EVF is not set
    # CONFIG_ICE is not set
    # CONFIG_FM10K is not set
    # CONFIG_IGC is not set
    # CONFIG_JME is not set
    CONFIG_NET_VENDOR_MARVELL=y
    # CONFIG_MVMDIO is not set
    CONFIG_SKGE=m
    # CONFIG_SKGE_DEBUG is not set
    # CONFIG_SKGE_GENESIS is not set
    # CONFIG_SKY2 is not set
    # CONFIG_PRESTERA is not set
    # CONFIG_NET_VENDOR_MELLANOX is not set
    CONFIG_NET_VENDOR_MICREL=y
    # CONFIG_KS8842 is not set
    CONFIG_KS8851=y
    # CONFIG_KS8851_MLL is not set
    # CONFIG_KSZ884X_PCI is not set
    # CONFIG_NET_VENDOR_MICROCHIP is not set
    CONFIG_NET_VENDOR_MICROSEMI=y
    # CONFIG_MSCC_OCELOT_SWITCH is not set
    # CONFIG_NET_VENDOR_MYRI is not set
    # CONFIG_FEALNX is not set
    # CONFIG_NET_VENDOR_NATSEMI is not set
    CONFIG_NET_VENDOR_NETERION=y
    # CONFIG_S2IO is not set
    # CONFIG_VXGE is not set
    # CONFIG_NET_VENDOR_NETRONOME is not set
    CONFIG_NET_VENDOR_NI=y
    # CONFIG_NI_XGE_MANAGEMENT_ENET is not set
    # CONFIG_NET_VENDOR_NVIDIA is not set
    # CONFIG_NET_VENDOR_OKI is not set
    # CONFIG_ETHOC is not set
    CONFIG_NET_VENDOR_PACKET_ENGINES=y
    # CONFIG_HAMACHI is not set
    # CONFIG_YELLOWFIN is not set
    CONFIG_NET_VENDOR_PENSANDO=y
    # CONFIG_NET_VENDOR_QLOGIC is not set
    # CONFIG_NET_VENDOR_QUALCOMM is not set
    # CONFIG_NET_VENDOR_RDC is not set
    # CONFIG_NET_VENDOR_REALTEK is not set
    # CONFIG_NET_VENDOR_RENESAS is not set
    # CONFIG_NET_VENDOR_ROCKER is not set
    # CONFIG_NET_VENDOR_SAMSUNG is not set
    # CONFIG_NET_VENDOR_SEEQ is not set
    CONFIG_NET_VENDOR_SOLARFLARE=y
    # CONFIG_SFC is not set
    # CONFIG_SFC_FALCON is not set
    # CONFIG_NET_VENDOR_SILAN is not set
    # CONFIG_NET_VENDOR_SIS is not set
    CONFIG_NET_VENDOR_SMSC=y
    # CONFIG_SMC91X is not set
    # CONFIG_EPIC100 is not set
    # CONFIG_SMC911X is not set
    CONFIG_SMSC911X=y
    # CONFIG_SMSC9420 is not set
    CONFIG_NET_VENDOR_SOCIONEXT=y
    # CONFIG_NET_VENDOR_STMICRO is not set
    # CONFIG_NET_VENDOR_SUN is not set
    # CONFIG_NET_VENDOR_SYNOPSYS is not set
    # CONFIG_NET_VENDOR_TEHUTI is not set
    CONFIG_NET_VENDOR_TI=y
    CONFIG_TI_DAVINCI_MDIO=y
    # CONFIG_TI_CPSW_PHY_SEL is not set
    CONFIG_TI_CPSW=y
    CONFIG_TI_CPSW_SWITCHDEV=y
    CONFIG_TI_CPTS=y
    # CONFIG_TLAN is not set
    CONFIG_TI_PRUETH=m
    CONFIG_TI_ICSS_IEP=m
    # CONFIG_NET_VENDOR_VIA is not set
    # CONFIG_NET_VENDOR_WIZNET is not set
    CONFIG_NET_VENDOR_XILINX=y
    # CONFIG_XILINX_AXI_EMAC is not set
    # CONFIG_XILINX_LL_TEMAC is not set
    # CONFIG_FDDI is not set
    # CONFIG_HIPPI is not set
    CONFIG_PHYLINK=y
    CONFIG_PHYLIB=y
    CONFIG_SWPHY=y
    # CONFIG_LED_TRIGGER_PHY is not set
    CONFIG_FIXED_PHY=y
    # CONFIG_SFP is not set
    # MII PHY device drivers
    # CONFIG_AMD_PHY is not set
    # CONFIG_ADIN_PHY is not set
    # CONFIG_AQUANTIA_PHY is not set
    # CONFIG_AX88796B_PHY is not set
    # CONFIG_BROADCOM_PHY is not set
    # CONFIG_BCM54140_PHY is not set
    # CONFIG_BCM7XXX_PHY is not set
    # CONFIG_BCM84881_PHY is not set
    # CONFIG_BCM87XX_PHY is not set
    # CONFIG_CICADA_PHY is not set
    # CONFIG_CORTINA_PHY is not set
    # CONFIG_DAVICOM_PHY is not set
    # CONFIG_ICPLUS_PHY is not set
    # CONFIG_LXT_PHY is not set
    # CONFIG_INTEL_XWAY_PHY is not set
    # CONFIG_LSI_ET1011C_PHY is not set
    CONFIG_MARVELL_PHY=y
    # CONFIG_MARVELL_10G_PHY is not set
    CONFIG_MICREL_PHY=y
    CONFIG_MICROCHIP_PHY=m
    # CONFIG_MICROCHIP_T1_PHY is not set
    # CONFIG_MICROSEMI_PHY is not set
    # CONFIG_NATIONAL_PHY is not set
    # CONFIG_NXP_TJA11XX_PHY is not set
    CONFIG_AT803X_PHY=y
    # CONFIG_QSEMI_PHY is not set
    # CONFIG_REALTEK_PHY is not set
    # CONFIG_RENESAS_PHY is not set
    CONFIG_ROCKCHIP_PHY=y
    CONFIG_SMSC_PHY=y
    # CONFIG_STE10XP is not set
    # CONFIG_TERANETICS_PHY is not set
    # CONFIG_DP83822_PHY is not set
    # CONFIG_DP83TC811_PHY is not set
    CONFIG_DP83848_PHY=y
    CONFIG_DP83867_PHY=y
    CONFIG_DP83869_PHY=y
    # CONFIG_VITESSE_PHY is not set
    # CONFIG_XILINX_GMII2RGMII is not set
    # CONFIG_MICREL_KS8995MA is not set
    CONFIG_MDIO_DEVICE=y
    CONFIG_MDIO_BUS=y
    CONFIG_OF_MDIO=y
    CONFIG_MDIO_DEVRES=y
    # CONFIG_MDIO_BITBANG is not set
    # CONFIG_MDIO_BCM_UNIMAC is not set
    # CONFIG_MDIO_HISI_FEMAC is not set
    # CONFIG_MDIO_MVUSB is not set
    # CONFIG_MDIO_MSCC_MIIM is not set
    # CONFIG_MDIO_IPQ4019 is not set
    # CONFIG_MDIO_IPQ8064 is not set
    # MDIO Multiplexers
    CONFIG_MDIO_BUS_MUX=y
    # CONFIG_MDIO_BUS_MUX_GPIO is not set
    CONFIG_MDIO_BUS_MUX_MULTIPLEXER=y
    # CONFIG_MDIO_BUS_MUX_MMIOREG is not set
    # PCS device drivers
    # CONFIG_PCS_XPCS is not set
    # end of PCS device drivers
    # CONFIG_PPP is not set
    # CONFIG_SLIP is not set
    # Host-side USB support is needed for USB Network Adapter support
    CONFIG_USB_NET_DRIVERS=m
    # CONFIG_USB_CATC is not set
    # CONFIG_USB_KAWETH is not set
    CONFIG_USB_PEGASUS=m
    CONFIG_USB_RTL8150=m
    CONFIG_USB_RTL8152=m
    CONFIG_USB_LAN78XX=m
    CONFIG_USB_USBNET=m
    CONFIG_USB_NET_AX8817X=m
    CONFIG_USB_NET_AX88179_178A=m
    CONFIG_USB_NET_CDCETHER=m
    CONFIG_USB_NET_CDC_EEM=m
    CONFIG_USB_NET_CDC_NCM=m
    # CONFIG_USB_NET_HUAWEI_CDC_NCM is not set
    # CONFIG_USB_NET_CDC_MBIM is not set
    # CONFIG_USB_NET_DM9601 is not set
    # CONFIG_USB_NET_SR9700 is not set
    # CONFIG_USB_NET_SR9800 is not set
    CONFIG_USB_NET_SMSC75XX=m
    CONFIG_USB_NET_SMSC95XX=m
    # CONFIG_USB_NET_GL620A is not set
    CONFIG_USB_NET_NET1080=m
    # CONFIG_USB_NET_PLUSB is not set
    # CONFIG_USB_NET_MCS7830 is not set
    # CONFIG_USB_NET_RNDIS_HOST is not set
    CONFIG_USB_NET_CDC_SUBSET_ENABLE=m
    CONFIG_USB_NET_CDC_SUBSET=m
    # CONFIG_USB_ALI_M5632 is not set
    # CONFIG_USB_AN2720 is not set
    CONFIG_USB_BELKIN=y
    CONFIG_USB_ARMLINUX=y
    # CONFIG_USB_EPSON2888 is not set
    # CONFIG_USB_KC2190 is not set
    CONFIG_USB_NET_ZAURUS=m
    # CONFIG_USB_NET_CX82310_ETH is not set
    # CONFIG_USB_NET_KALMIA is not set
    # CONFIG_USB_NET_QMI_WWAN is not set
    # CONFIG_USB_HSO is not set
    # CONFIG_USB_NET_INT51X1 is not set
    # CONFIG_USB_IPHETH is not set
    # CONFIG_USB_SIERRA_NET is not set
    # CONFIG_USB_VL600 is not set
    # CONFIG_USB_NET_CH9200 is not set
    # CONFIG_USB_NET_AQC111 is not set
    CONFIG_WLAN=y
    # CONFIG_WIRELESS_WDS is not set
    CONFIG_WLAN_VENDOR_ADMTEK=y
    # CONFIG_ADM8211 is not set
    CONFIG_WLAN_VENDOR_ATH=y
    # CONFIG_ATH_DEBUG is not set
    # CONFIG_ATH5K is not set
    # CONFIG_ATH5K_PCI is not set
    # CONFIG_ATH9K is not set
    # CONFIG_ATH9K_HTC is not set
    # CONFIG_CARL9170 is not set
    # CONFIG_ATH6KL is not set
    # CONFIG_AR5523 is not set
    # CONFIG_WIL6210 is not set
    # CONFIG_ATH10K is not set
    # CONFIG_WCN36XX is not set
    CONFIG_WLAN_VENDOR_ATMEL=y
    # CONFIG_ATMEL is not set
    # CONFIG_AT76C50X_USB is not set
    CONFIG_WLAN_VENDOR_BROADCOM=y
    CONFIG_B43=m
    CONFIG_B43_BCMA=y
    CONFIG_B43_SSB=y
    CONFIG_B43_BUSES_BCMA_AND_SSB=y
    # CONFIG_B43_BUSES_BCMA is not set
    # CONFIG_B43_BUSES_SSB is not set
    CONFIG_B43_PCI_AUTOSELECT=y
    CONFIG_B43_PCICORE_AUTOSELECT=y
    # CONFIG_B43_SDIO is not set
    CONFIG_B43_BCMA_PIO=y
    CONFIG_B43_PIO=y
    CONFIG_B43_PHY_G=y
    CONFIG_B43_PHY_N=y
    CONFIG_B43_PHY_LP=y
    CONFIG_B43_PHY_HT=y
    CONFIG_B43_LEDS=y
    CONFIG_B43_HWRNG=y
    # CONFIG_B43_DEBUG is not set
    # CONFIG_B43LEGACY is not set
    CONFIG_BRCMUTIL=m
    # CONFIG_BRCMSMAC is not set
    CONFIG_BRCMFMAC=m
    CONFIG_BRCMFMAC_PROTO_BCDC=y
    CONFIG_BRCMFMAC_SDIO=y
    # CONFIG_BRCMFMAC_USB is not set
    # CONFIG_BRCMFMAC_PCIE is not set
    # CONFIG_BRCM_TRACING is not set
    # CONFIG_BRCMDBG is not set
    CONFIG_WLAN_VENDOR_CISCO=y
    CONFIG_WLAN_VENDOR_INTEL=y
    # CONFIG_IPW2100 is not set
    # CONFIG_IPW2200 is not set
    # CONFIG_IWL4965 is not set
    # CONFIG_IWL3945 is not set
    CONFIG_IWLWIFI=m
    CONFIG_IWLWIFI_LEDS=y
    CONFIG_IWLDVM=m
    CONFIG_IWLMVM=m
    CONFIG_IWLWIFI_OPMODE_MODULAR=y
    # CONFIG_IWLWIFI_BCAST_FILTERING is not set
    # Debugging Options
    # CONFIG_IWLWIFI_DEBUG is not set
    # end of Debugging Options
    CONFIG_WLAN_VENDOR_INTERSIL=y
    # CONFIG_HOSTAP is not set
    # CONFIG_HERMES is not set
    # CONFIG_P54_COMMON is not set
    # CONFIG_PRISM54 is not set
    CONFIG_WLAN_VENDOR_MARVELL=y
    # CONFIG_LIBERTAS is not set
    # CONFIG_LIBERTAS_THINFIRM is not set
    CONFIG_MWIFIEX=m
    CONFIG_MWIFIEX_SDIO=m
    # CONFIG_MWIFIEX_PCIE is not set
    # CONFIG_MWIFIEX_USB is not set
    # CONFIG_MWL8K is not set
    CONFIG_WLAN_VENDOR_MEDIATEK=y
    # CONFIG_MT7601U is not set
    # CONFIG_MT76x0U is not set
    # CONFIG_MT76x0E is not set
    # CONFIG_MT76x2E is not set
    # CONFIG_MT76x2U is not set
    # CONFIG_MT7603E is not set
    # CONFIG_MT7615E is not set
    # CONFIG_MT7663U is not set
    # CONFIG_MT7663S is not set
    # CONFIG_MT7915E is not set
    CONFIG_WLAN_VENDOR_MICROCHIP=y
    # CONFIG_WILC1000_SDIO is not set
    # CONFIG_WILC1000_SPI is not set
    CONFIG_WLAN_VENDOR_RALINK=y
    CONFIG_RT2X00=m
    # CONFIG_RT2400PCI is not set
    # CONFIG_RT2500PCI is not set
    # CONFIG_RT61PCI is not set
    # CONFIG_RT2800PCI is not set
    # CONFIG_RT2500USB is not set
    # CONFIG_RT73USB is not set
    CONFIG_RT2800USB=m
    CONFIG_RT2800USB_RT33XX=y
    CONFIG_RT2800USB_RT35XX=y
    # CONFIG_RT2800USB_RT3573 is not set
    # CONFIG_RT2800USB_RT53XX is not set
    # CONFIG_RT2800USB_RT55XX is not set
    # CONFIG_RT2800USB_UNKNOWN is not set
    CONFIG_RT2800_LIB=m
    CONFIG_RT2X00_LIB_USB=m
    CONFIG_RT2X00_LIB=m
    CONFIG_RT2X00_LIB_FIRMWARE=y
    CONFIG_RT2X00_LIB_CRYPTO=y
    CONFIG_RT2X00_LIB_LEDS=y
    # CONFIG_RT2X00_DEBUG is not set
    CONFIG_WLAN_VENDOR_REALTEK=y
    # CONFIG_RTL8180 is not set
    # CONFIG_RTL8187 is not set
    CONFIG_RTL_CARDS=m
    # CONFIG_RTL8192CE is not set
    # CONFIG_RTL8192SE is not set
    # CONFIG_RTL8192DE is not set
    # CONFIG_RTL8723AE is not set
    # CONFIG_RTL8723BE is not set
    # CONFIG_RTL8188EE is not set
    # CONFIG_RTL8192EE is not set
    # CONFIG_RTL8821AE is not set
    # CONFIG_RTL8192CU is not set
    # CONFIG_RTL8XXXU is not set
    # CONFIG_RTW88 is not set
    CONFIG_WLAN_VENDOR_RSI=y
    # CONFIG_RSI_91X is not set
    CONFIG_WLAN_VENDOR_ST=y
    # CONFIG_CW1200 is not set
    CONFIG_WLAN_VENDOR_TI=y
    # CONFIG_WL1251 is not set
    # CONFIG_WL12XX is not set
    CONFIG_WL18XX=m
    CONFIG_WLCORE=m
    # CONFIG_WLCORE_SPI is not set
    CONFIG_WLCORE_SDIO=m
    CONFIG_WILINK_PLATFORM_DATA=y
    CONFIG_WLAN_VENDOR_ZYDAS=y
    # CONFIG_USB_ZD1201 is not set
    # CONFIG_ZD1211RW is not set
    CONFIG_WLAN_VENDOR_QUANTENNA=y
    # CONFIG_QTNFMAC_PCIE is not set
    # CONFIG_MAC80211_HWSIM is not set
    # CONFIG_USB_NET_RNDIS_WLAN is not set
    # CONFIG_VIRT_WIFI is not set
    # Enable WiMAX (Networking options) to see the WiMAX drivers
    # CONFIG_WAN is not set
    # CONFIG_VMXNET3 is not set
    # CONFIG_NETDEVSIM is not set
    CONFIG_NET_FAILOVER=y
    # CONFIG_ISDN is not set
    # CONFIG_NVM is not set
    # Input device support
    CONFIG_INPUT=y
    CONFIG_INPUT_LEDS=y
    # CONFIG_INPUT_FF_MEMLESS is not set
    # CONFIG_INPUT_POLLDEV is not set
    # CONFIG_INPUT_SPARSEKMAP is not set
    CONFIG_INPUT_MATRIXKMAP=m
    # Userland interfaces
    # CONFIG_INPUT_MOUSEDEV is not set
    CONFIG_INPUT_JOYDEV=y
    CONFIG_INPUT_EVDEV=y
    # CONFIG_INPUT_EVBUG is not set
    # Input Device Drivers
    CONFIG_INPUT_KEYBOARD=y
    # CONFIG_KEYBOARD_ADC is not set
    # CONFIG_KEYBOARD_ADP5588 is not set
    # CONFIG_KEYBOARD_ADP5589 is not set
    CONFIG_KEYBOARD_ATKBD=y
    # CONFIG_KEYBOARD_QT1050 is not set
    CONFIG_KEYBOARD_QT1070=m
    # CONFIG_KEYBOARD_QT2160 is not set
    # CONFIG_KEYBOARD_DLINK_DIR685 is not set
    # CONFIG_KEYBOARD_LKKBD is not set
    CONFIG_KEYBOARD_GPIO=y
    # CONFIG_KEYBOARD_GPIO_POLLED is not set
    # CONFIG_KEYBOARD_TCA6416 is not set
    # CONFIG_KEYBOARD_TCA8418 is not set
    CONFIG_KEYBOARD_MATRIX=m
    # CONFIG_KEYBOARD_LM8323 is not set
    # CONFIG_KEYBOARD_LM8333 is not set
    # CONFIG_KEYBOARD_MAX7359 is not set
    # CONFIG_KEYBOARD_MCS is not set
    # CONFIG_KEYBOARD_MPR121 is not set
    # CONFIG_KEYBOARD_NEWTON is not set
    # CONFIG_KEYBOARD_OPENCORES is not set
    CONFIG_KEYBOARD_SAMSUNG=m
    # CONFIG_KEYBOARD_STOWAWAY is not set
    # CONFIG_KEYBOARD_SUNKBD is not set
    # CONFIG_KEYBOARD_OMAP4 is not set
    # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
    # CONFIG_KEYBOARD_XTKBD is not set
    # CONFIG_KEYBOARD_CAP11XX is not set
    # CONFIG_KEYBOARD_BCM is not set
    CONFIG_INPUT_MOUSE=y
    CONFIG_MOUSE_PS2=y
    CONFIG_MOUSE_PS2_ALPS=y
    CONFIG_MOUSE_PS2_BYD=y
    CONFIG_MOUSE_PS2_LOGIPS2PP=y
    CONFIG_MOUSE_PS2_SYNAPTICS=y
    CONFIG_MOUSE_PS2_SYNAPTICS_SMBUS=y
    CONFIG_MOUSE_PS2_CYPRESS=y
    CONFIG_MOUSE_PS2_TRACKPOINT=y
    CONFIG_MOUSE_PS2_ELANTECH=y
    CONFIG_MOUSE_PS2_ELANTECH_SMBUS=y
    # CONFIG_MOUSE_PS2_SENTELIC is not set
    # CONFIG_MOUSE_PS2_TOUCHKIT is not set
    CONFIG_MOUSE_PS2_FOCALTECH=y
    CONFIG_MOUSE_PS2_SMBUS=y
    # CONFIG_MOUSE_SERIAL is not set
    # CONFIG_MOUSE_APPLETOUCH is not set
    # CONFIG_MOUSE_BCM5974 is not set
    CONFIG_MOUSE_CYAPA=m
    CONFIG_MOUSE_ELAN_I2C=y
    CONFIG_MOUSE_ELAN_I2C_I2C=y
    # CONFIG_MOUSE_ELAN_I2C_SMBUS is not set
    # CONFIG_MOUSE_VSXXXAA is not set
    # CONFIG_MOUSE_GPIO is not set
    # CONFIG_MOUSE_SYNAPTICS_I2C is not set
    # CONFIG_MOUSE_SYNAPTICS_USB is not set
    # CONFIG_INPUT_JOYSTICK is not set
    # CONFIG_INPUT_TABLET is not set
    CONFIG_INPUT_TOUCHSCREEN=y
    CONFIG_TOUCHSCREEN_PROPERTIES=y
    # CONFIG_TOUCHSCREEN_ADS7846 is not set
    # CONFIG_TOUCHSCREEN_AD7877 is not set
    # CONFIG_TOUCHSCREEN_AD7879 is not set
    CONFIG_TOUCHSCREEN_ADC=m
    # CONFIG_TOUCHSCREEN_AR1021_I2C is not set
    CONFIG_TOUCHSCREEN_ATMEL_MXT=m
    # CONFIG_TOUCHSCREEN_ATMEL_MXT_T37 is not set
    # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
    # CONFIG_TOUCHSCREEN_BU21013 is not set
    # CONFIG_TOUCHSCREEN_BU21029 is not set
    # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMA140 is not set
    # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
    # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
    # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
    # CONFIG_TOUCHSCREEN_DYNAPRO is not set
    # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
    # CONFIG_TOUCHSCREEN_EETI is not set
    # CONFIG_TOUCHSCREEN_EGALAX is not set
    # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
    # CONFIG_TOUCHSCREEN_EXC3000 is not set
    # CONFIG_TOUCHSCREEN_FUJITSU is not set
    CONFIG_TOUCHSCREEN_GOODIX=m
    # CONFIG_TOUCHSCREEN_HIDEEP is not set
    # CONFIG_TOUCHSCREEN_ILI210X is not set
    # CONFIG_TOUCHSCREEN_S6SY761 is not set
    # CONFIG_TOUCHSCREEN_GUNZE is not set
    # CONFIG_TOUCHSCREEN_EKTF2127 is not set
    CONFIG_TOUCHSCREEN_ELAN=m
    # CONFIG_TOUCHSCREEN_ELO is not set
    # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
    # CONFIG_TOUCHSCREEN_WACOM_I2C is not set
    # CONFIG_TOUCHSCREEN_MAX11801 is not set
    # CONFIG_TOUCHSCREEN_MCS5000 is not set
    CONFIG_TOUCHSCREEN_MMS114=m
    # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
    # CONFIG_TOUCHSCREEN_MTOUCH is not set
    # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
    # CONFIG_TOUCHSCREEN_INEXIO is not set
    # CONFIG_TOUCHSCREEN_MK712 is not set
    # CONFIG_TOUCHSCREEN_PENMOUNT is not set
    CONFIG_TOUCHSCREEN_EDT_FT5X06=m
    # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
    # CONFIG_TOUCHSCREEN_TOUCHWIN is not set
    CONFIG_TOUCHSCREEN_TI_AM335X_TSC=m
    CONFIG_TOUCHSCREEN_PIXCIR=m
    # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
    # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
    # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
    # CONFIG_TOUCHSCREEN_TSC_SERIO is not set
    # CONFIG_TOUCHSCREEN_TSC2004 is not set
    # CONFIG_TOUCHSCREEN_TSC2005 is not set
    # CONFIG_TOUCHSCREEN_TSC2007 is not set
    # CONFIG_TOUCHSCREEN_RM_TS is not set
    # CONFIG_TOUCHSCREEN_SILEAD is not set
    # CONFIG_TOUCHSCREEN_SIS_I2C is not set
    CONFIG_TOUCHSCREEN_ST1232=m
    # CONFIG_TOUCHSCREEN_STMFTS is not set
    # CONFIG_TOUCHSCREEN_SUR40 is not set
    # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
    # CONFIG_TOUCHSCREEN_SX8654 is not set
    # CONFIG_TOUCHSCREEN_TPS6507X is not set
    # CONFIG_TOUCHSCREEN_ZET6223 is not set
    # CONFIG_TOUCHSCREEN_ZFORCE is not set
    # CONFIG_TOUCHSCREEN_COLIBRI_VF50 is not set
    # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
    # CONFIG_TOUCHSCREEN_IQS5XX is not set
    # CONFIG_TOUCHSCREEN_ZINITIX is not set
    CONFIG_INPUT_MISC=y
    # CONFIG_INPUT_AD714X is not set
    # CONFIG_INPUT_ATMEL_CAPTOUCH is not set
    # CONFIG_INPUT_BMA150 is not set
    # CONFIG_INPUT_E3X0_BUTTON is not set
    # CONFIG_INPUT_MMA8450 is not set
    # CONFIG_INPUT_GPIO_BEEPER is not set
    CONFIG_INPUT_GPIO_DECODER=m
    # CONFIG_INPUT_GPIO_VIBRA is not set
    CONFIG_INPUT_CPCAP_PWRBUTTON=m
    # CONFIG_INPUT_ATI_REMOTE2 is not set
    # CONFIG_INPUT_KEYSPAN_REMOTE is not set
    # CONFIG_INPUT_KXTJ9 is not set
    # CONFIG_INPUT_POWERMATE is not set
    # CONFIG_INPUT_YEALINK is not set
    # CONFIG_INPUT_CM109 is not set
    # CONFIG_INPUT_REGULATOR_HAPTIC is not set
    # CONFIG_INPUT_TPS65218_PWRBUTTON is not set
    # CONFIG_INPUT_TWL6040_VIBRA is not set
    # CONFIG_INPUT_UINPUT is not set
    # CONFIG_INPUT_PALMAS_PWRBUTTON is not set
    # CONFIG_INPUT_PCF8574 is not set
    # CONFIG_INPUT_PWM_BEEPER is not set
    # CONFIG_INPUT_PWM_VIBRA is not set
    # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
    CONFIG_INPUT_ADXL34X=m
    CONFIG_INPUT_ADXL34X_I2C=m
    CONFIG_INPUT_ADXL34X_SPI=m
    # CONFIG_INPUT_IMS_PCU is not set
    # CONFIG_INPUT_IQS269A is not set
    # CONFIG_INPUT_CMA3000 is not set
    # CONFIG_INPUT_DRV260X_HAPTICS is not set
    # CONFIG_INPUT_DRV2665_HAPTICS is not set
    # CONFIG_INPUT_DRV2667_HAPTICS is not set
    CONFIG_INPUT_STPMIC1_ONKEY=y
    # CONFIG_RMI4_CORE is not set
    # Hardware I/O ports
    CONFIG_SERIO=y
    CONFIG_SERIO_SERPORT=y
    # CONFIG_SERIO_PCIPS2 is not set
    CONFIG_SERIO_LIBPS2=y
    # CONFIG_SERIO_RAW is not set
    # CONFIG_SERIO_ALTERA_PS2 is not set
    # CONFIG_SERIO_PS2MULT is not set
    # CONFIG_SERIO_ARC_PS2 is not set
    # CONFIG_SERIO_APBPS2 is not set
    # CONFIG_SERIO_GPIO_PS2 is not set
    # CONFIG_USERIO is not set
    # CONFIG_GAMEPORT is not set
    # end of Hardware I/O ports
    # end of Input device support
    # Character devices
    CONFIG_TTY=y
    CONFIG_VT=y
    CONFIG_CONSOLE_TRANSLATIONS=y
    CONFIG_VT_CONSOLE=y
    CONFIG_VT_CONSOLE_SLEEP=y
    CONFIG_HW_CONSOLE=y
    CONFIG_VT_HW_CONSOLE_BINDING=y
    CONFIG_UNIX98_PTYS=y
    CONFIG_LEGACY_PTYS=y
    CONFIG_LEGACY_PTY_COUNT=256
    CONFIG_LDISC_AUTOLOAD=y
    # Serial drivers
    CONFIG_SERIAL_EARLYCON=y
    CONFIG_SERIAL_8250=y
    CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
    CONFIG_SERIAL_8250_16550A_VARIANTS=y
    # CONFIG_SERIAL_8250_FINTEK is not set
    CONFIG_SERIAL_8250_CONSOLE=y
    CONFIG_SERIAL_8250_DMA=y
    CONFIG_SERIAL_8250_PCI=y
    CONFIG_SERIAL_8250_EXAR=y
    CONFIG_SERIAL_8250_NR_UARTS=10
    CONFIG_SERIAL_8250_RUNTIME_UARTS=10
    CONFIG_SERIAL_8250_EXTENDED=y
    CONFIG_SERIAL_8250_MANY_PORTS=y
    CONFIG_SERIAL_8250_ASPEED_VUART=m
    CONFIG_SERIAL_8250_SHARE_IRQ=y
    # CONFIG_SERIAL_8250_DETECT_IRQ is not set
    # CONFIG_SERIAL_8250_RSA is not set
    CONFIG_SERIAL_8250_FSL=y
    # CONFIG_SERIAL_8250_DW is not set
    # CONFIG_SERIAL_8250_EM is not set
    # CONFIG_SERIAL_8250_RT288X is not set
    CONFIG_SERIAL_8250_OMAP=y
    CONFIG_SERIAL_8250_OMAP_TTYO_FIXUP=y
    CONFIG_SERIAL_8250_PRUSS=m
    CONFIG_SERIAL_OF_PLATFORM=y
    # Non-8250 serial port support
    # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
    # CONFIG_SERIAL_MAX3100 is not set
    # CONFIG_SERIAL_MAX310X is not set
    # CONFIG_SERIAL_UARTLITE is not set
    CONFIG_SERIAL_CORE=y
    CONFIG_SERIAL_CORE_CONSOLE=y
    # CONFIG_SERIAL_JSM is not set
    # CONFIG_SERIAL_OMAP is not set
    # CONFIG_SERIAL_SIFIVE is not set
    # CONFIG_SERIAL_SCCNXP is not set
    # CONFIG_SERIAL_SC16IS7XX is not set
    CONFIG_SERIAL_BCM63XX=y
    CONFIG_SERIAL_BCM63XX_CONSOLE=y
    # CONFIG_SERIAL_ALTERA_JTAGUART is not set
    # CONFIG_SERIAL_ALTERA_UART is not set
    # CONFIG_SERIAL_IFX6X60 is not set
    # CONFIG_SERIAL_XILINX_PS_UART is not set
    # CONFIG_SERIAL_ARC is not set
    # CONFIG_SERIAL_RP2 is not set
    # CONFIG_SERIAL_FSL_LPUART is not set
    # CONFIG_SERIAL_FSL_LINFLEXUART is not set
    # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
    # CONFIG_SERIAL_ST_ASC is not set
    # CONFIG_SERIAL_SPRD is not set
    CONFIG_SERIAL_PRU_SWUART=m
    # end of Serial drivers
    CONFIG_SERIAL_MCTRL_GPIO=y
    # CONFIG_SERIAL_NONSTANDARD is not set
    # CONFIG_N_GSM is not set
    # CONFIG_NOZOMI is not set
    # CONFIG_NULL_TTY is not set
    # CONFIG_TRACE_SINK is not set
    CONFIG_HVC_DRIVER=y
    # CONFIG_HVC_DCC is not set
    CONFIG_SERIAL_DEV_BUS=y
    CONFIG_SERIAL_DEV_CTRL_TTYPORT=y
    # CONFIG_TTY_PRINTK is not set
    CONFIG_VIRTIO_CONSOLE=y
    # CONFIG_IPMI_HANDLER is not set
    # CONFIG_IPMB_DEVICE_INTERFACE is not set
    CONFIG_HW_RANDOM=y
    # CONFIG_HW_RANDOM_TIMERIOMEM is not set
    # CONFIG_HW_RANDOM_BA431 is not set
    CONFIG_HW_RANDOM_OMAP=y
    # CONFIG_HW_RANDOM_VIRTIO is not set
    CONFIG_HW_RANDOM_OPTEE=y
    # CONFIG_HW_RANDOM_CCTRNG is not set
    # CONFIG_HW_RANDOM_XIPHERA is not set
    # CONFIG_APPLICOM is not set
    CONFIG_DEVMEM=y
    # CONFIG_DEVKMEM is not set
    # CONFIG_RAW_DRIVER is not set
    CONFIG_DEVPORT=y
    CONFIG_TCG_TPM=m
    CONFIG_HW_RANDOM_TPM=y
    # CONFIG_TCG_TIS is not set
    # CONFIG_TCG_TIS_SPI is not set
    # CONFIG_TCG_TIS_I2C_ATMEL is not set
    CONFIG_TCG_TIS_I2C_INFINEON=m
    # CONFIG_TCG_TIS_I2C_NUVOTON is not set
    # CONFIG_TCG_ATMEL is not set
    # CONFIG_TCG_VTPM_PROXY is not set
    # CONFIG_TCG_FTPM_TEE is not set
    # CONFIG_TCG_TIS_ST33ZP24_I2C is not set
    # CONFIG_TCG_TIS_ST33ZP24_SPI is not set
    # CONFIG_XILLYBUS is not set
    # end of Character devices
    # CONFIG_RANDOM_TRUST_BOOTLOADER is not set
    # I2C support
    CONFIG_I2C=y
    CONFIG_I2C_BOARDINFO=y
    CONFIG_I2C_COMPAT=y
    CONFIG_I2C_CHARDEV=y
    CONFIG_I2C_MUX=y
    # Multiplexer I2C Chip support
    CONFIG_I2C_ARB_GPIO_CHALLENGE=m
    # CONFIG_I2C_MUX_GPIO is not set
    # CONFIG_I2C_MUX_GPMUX is not set
    # CONFIG_I2C_MUX_LTC4306 is not set
    # CONFIG_I2C_MUX_PCA9541 is not set
    CONFIG_I2C_MUX_PCA954x=y
    CONFIG_I2C_MUX_PINCTRL=y
    # CONFIG_I2C_MUX_REG is not set
    CONFIG_I2C_DEMUX_PINCTRL=y
    # CONFIG_I2C_MUX_MLXCPLD is not set
    # end of Multiplexer I2C Chip support
    CONFIG_I2C_HELPER_AUTO=y
    CONFIG_I2C_ALGOBIT=y
    # I2C Hardware Bus support
    # PC SMBus host controller drivers
    # CONFIG_I2C_ALI1535 is not set
    # CONFIG_I2C_ALI1563 is not set
    # CONFIG_I2C_ALI15X3 is not set
    # CONFIG_I2C_AMD756 is not set
    # CONFIG_I2C_AMD8111 is not set
    # CONFIG_I2C_I801 is not set
    # CONFIG_I2C_ISCH is not set
    # CONFIG_I2C_PIIX4 is not set
    # CONFIG_I2C_NFORCE2 is not set
    # CONFIG_I2C_NVIDIA_GPU is not set
    # CONFIG_I2C_SIS5595 is not set
    # CONFIG_I2C_SIS630 is not set
    # CONFIG_I2C_SIS96X is not set
    # CONFIG_I2C_VIA is not set
    # CONFIG_I2C_VIAPRO is not set
    # I2C system bus drivers (mostly embedded / system-on-chip)
    # CONFIG_I2C_CBUS_GPIO is not set
    # CONFIG_I2C_DESIGNWARE_PLATFORM is not set
    # CONFIG_I2C_DESIGNWARE_PCI is not set
    CONFIG_I2C_EMEV2=m
    # CONFIG_I2C_GPIO is not set
    # CONFIG_I2C_OCORES is not set
    CONFIG_I2C_OMAP=y
    # CONFIG_I2C_PCA_PLATFORM is not set
    # CONFIG_I2C_RK3X is not set
    # CONFIG_I2C_SIMTEC is not set
    # CONFIG_I2C_XILINX is not set
    # External I2C/SMBus adapter drivers
    # CONFIG_I2C_DIOLAN_U2C is not set
    # CONFIG_I2C_ROBOTFUZZ_OSIF is not set
    # CONFIG_I2C_TAOS_EVM is not set
    # CONFIG_I2C_TINY_USB is not set
    # Other I2C/SMBus bus drivers
    # CONFIG_I2C_FSI is not set
    # end of I2C Hardware Bus support
    # CONFIG_I2C_STUB is not set
    CONFIG_I2C_SLAVE=y
    CONFIG_I2C_SLAVE_EEPROM=y
    # CONFIG_I2C_SLAVE_TESTUNIT is not set
    # CONFIG_I2C_DEBUG_CORE is not set
    # CONFIG_I2C_DEBUG_ALGO is not set
    # CONFIG_I2C_DEBUG_BUS is not set
    # end of I2C support
    # CONFIG_I3C is not set
    CONFIG_SPI=y
    # CONFIG_SPI_DEBUG is not set
    CONFIG_SPI_MASTER=y
    CONFIG_SPI_MEM=y
    # SPI Master Controller Drivers
    # CONFIG_SPI_ALTERA is not set
    # CONFIG_SPI_AXI_SPI_ENGINE is not set
    CONFIG_SPI_BITBANG=m
    # CONFIG_SPI_CADENCE is not set
    CONFIG_SPI_CADENCE_QUADSPI=y
    # CONFIG_SPI_DESIGNWARE is not set
    # CONFIG_SPI_FSI is not set
    # CONFIG_SPI_NXP_FLEXSPI is not set
    CONFIG_SPI_GPIO=m
    # CONFIG_SPI_FSL_SPI is not set
    # CONFIG_SPI_OC_TINY is not set
    CONFIG_SPI_OMAP24XX=y
    CONFIG_SPI_TI_QSPI=y
    # CONFIG_SPI_PXA2XX is not set
    # CONFIG_SPI_ROCKCHIP is not set
    # CONFIG_SPI_SC18IS602 is not set
    # CONFIG_SPI_SIFIVE is not set
    # CONFIG_SPI_MXIC is not set
    # CONFIG_SPI_XCOMM is not set
    # CONFIG_SPI_XILINX is not set
    # CONFIG_SPI_ZYNQMP_GQSPI is not set
    # CONFIG_SPI_AMD is not set
    # SPI Multiplexer support
    # CONFIG_SPI_MUX is not set
    # SPI Protocol Masters
    # CONFIG_SPI_SPIDEV is not set
    # CONFIG_SPI_LOOPBACK_TEST is not set
    # CONFIG_SPI_TLE62X0 is not set
    # CONFIG_SPI_SLAVE is not set
    CONFIG_SPI_DYNAMIC=y
    CONFIG_SPMI=y
    # CONFIG_HSI is not set
    CONFIG_PPS=y
    # CONFIG_PPS_DEBUG is not set
    # PPS clients support
    # CONFIG_PPS_CLIENT_KTIMER is not set
    # CONFIG_PPS_CLIENT_LDISC is not set
    # CONFIG_PPS_CLIENT_GPIO is not set
    # PPS generators support
    # PTP clock support
    CONFIG_PTP_1588_CLOCK=y
    # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
    # CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
    # CONFIG_PTP_1588_CLOCK_IDTCM is not set
    # end of PTP clock support
    CONFIG_PINCTRL=y
    CONFIG_GENERIC_PINCTRL_GROUPS=y
    CONFIG_PINMUX=y
    CONFIG_GENERIC_PINMUX_FUNCTIONS=y
    CONFIG_PINCONF=y
    CONFIG_GENERIC_PINCONF=y
    # CONFIG_DEBUG_PINCTRL is not set
    # CONFIG_PINCTRL_MCP23S08 is not set
    CONFIG_PINCTRL_SINGLE=y
    # CONFIG_PINCTRL_SX150X is not set
    CONFIG_PINCTRL_STMFX=y
    CONFIG_PINCTRL_PALMAS=y
    # CONFIG_PINCTRL_OCELOT is not set
    # Renesas pinctrl drivers
    # end of Renesas pinctrl drivers
    CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
    CONFIG_GPIOLIB=y
    CONFIG_GPIOLIB_FASTPATH_LIMIT=512
    CONFIG_OF_GPIO=y
    CONFIG_GPIOLIB_IRQCHIP=y
    CONFIG_DEBUG_GPIO=y
    CONFIG_GPIO_SYSFS=y
    CONFIG_GPIO_CDEV=y
    CONFIG_GPIO_CDEV_V1=y
    # Memory mapped GPIO drivers
    # CONFIG_GPIO_74XX_MMIO is not set
    # CONFIG_GPIO_ALTERA is not set
    # CONFIG_GPIO_CADENCE is not set
    # CONFIG_GPIO_DWAPB is not set
    # CONFIG_GPIO_EXAR is not set
    # CONFIG_GPIO_FTGPIO010 is not set
    # CONFIG_GPIO_GENERIC_PLATFORM is not set
    # CONFIG_GPIO_GRGPIO is not set
    # CONFIG_GPIO_HLWD is not set
    # CONFIG_GPIO_LOGICVC is not set
    # CONFIG_GPIO_MB86S7X is not set
    # CONFIG_GPIO_MPC8XXX is not set
    CONFIG_GPIO_OMAP=y
    # CONFIG_GPIO_SAMA5D2_PIOBU is not set
    # CONFIG_GPIO_SIFIVE is not set
    CONFIG_GPIO_SYSCON=y
    # CONFIG_GPIO_XILINX is not set
    # CONFIG_GPIO_ZEVIO is not set
    # CONFIG_GPIO_AMD_FCH is not set
    # end of Memory mapped GPIO drivers
    # I2C GPIO expanders
    # CONFIG_GPIO_ADP5588 is not set
    # CONFIG_GPIO_ADNP is not set
    # CONFIG_GPIO_GW_PLD is not set
    # CONFIG_GPIO_MAX7300 is not set
    # CONFIG_GPIO_MAX732X is not set
    CONFIG_GPIO_PCA953X=y
    CONFIG_GPIO_PCA953X_IRQ=y
    # CONFIG_GPIO_PCA9570 is not set
    CONFIG_GPIO_PCF857X=y
    CONFIG_GPIO_TPIC2810=m
    # end of I2C GPIO expanders
    # MFD GPIO expanders
    # CONFIG_HTC_EGPIO is not set
    # CONFIG_GPIO_LP873X is not set
    # CONFIG_GPIO_LP87565 is not set
    CONFIG_GPIO_PALMAS=y
    # CONFIG_GPIO_TPS65218 is not set
    # CONFIG_GPIO_TPS6586X is not set
    CONFIG_GPIO_TPS65910=y
    # CONFIG_GPIO_TWL6040 is not set
    # end of MFD GPIO expanders
    # PCI GPIO expanders
    # CONFIG_GPIO_BT8XX is not set
    # CONFIG_GPIO_PCI_IDIO_16 is not set
    # CONFIG_GPIO_PCIE_IDIO_24 is not set
    # CONFIG_GPIO_RDC321X is not set
    # end of PCI GPIO expanders
    # SPI GPIO expanders
    # CONFIG_GPIO_74X164 is not set
    # CONFIG_GPIO_MAX3191X is not set
    # CONFIG_GPIO_MAX7301 is not set
    # CONFIG_GPIO_MC33880 is not set
    CONFIG_GPIO_PISOSR=m
    # CONFIG_GPIO_XRA1403 is not set
    # end of SPI GPIO expanders
    # USB GPIO expanders
    # end of USB GPIO expanders
    # CONFIG_GPIO_AGGREGATOR is not set
    # CONFIG_GPIO_MOCKUP is not set
    CONFIG_W1=m
    # 1-wire Bus Masters
    # CONFIG_W1_MASTER_MATROX is not set
    # CONFIG_W1_MASTER_DS2490 is not set
    # CONFIG_W1_MASTER_DS2482 is not set
    # CONFIG_W1_MASTER_DS1WM is not set
    # CONFIG_W1_MASTER_GPIO is not set
    CONFIG_HDQ_MASTER_OMAP=m
    # CONFIG_W1_MASTER_SGI is not set
    # end of 1-wire Bus Masters
    # 1-wire Slaves
    # CONFIG_W1_SLAVE_THERM is not set
    # CONFIG_W1_SLAVE_SMEM is not set
    # CONFIG_W1_SLAVE_DS2405 is not set
    # CONFIG_W1_SLAVE_DS2408 is not set
    # CONFIG_W1_SLAVE_DS2413 is not set
    # CONFIG_W1_SLAVE_DS2406 is not set
    # CONFIG_W1_SLAVE_DS2423 is not set
    # CONFIG_W1_SLAVE_DS2805 is not set
    # CONFIG_W1_SLAVE_DS2430 is not set
    # CONFIG_W1_SLAVE_DS2431 is not set
    # CONFIG_W1_SLAVE_DS2433 is not set
    # CONFIG_W1_SLAVE_DS2438 is not set
    # CONFIG_W1_SLAVE_DS250X is not set
    # CONFIG_W1_SLAVE_DS2780 is not set
    # CONFIG_W1_SLAVE_DS2781 is not set
    # CONFIG_W1_SLAVE_DS28E04 is not set
    # CONFIG_W1_SLAVE_DS28E17 is not set
    # end of 1-wire Slaves
    CONFIG_POWER_RESET=y
    # CONFIG_POWER_RESET_BRCMKONA is not set
    # CONFIG_POWER_RESET_BRCMSTB is not set
    CONFIG_POWER_RESET_GPIO=y
    CONFIG_POWER_RESET_GPIO_RESTART=y
    # CONFIG_POWER_RESET_LTC2952 is not set
    # CONFIG_POWER_RESET_RESTART is not set
    # CONFIG_POWER_RESET_VERSATILE is not set
    # CONFIG_POWER_RESET_SYSCON is not set
    # CONFIG_POWER_RESET_SYSCON_POWEROFF is not set
    # CONFIG_SYSCON_REBOOT_MODE is not set
    # CONFIG_NVMEM_REBOOT_MODE is not set
    CONFIG_POWER_SUPPLY=y
    # CONFIG_POWER_SUPPLY_DEBUG is not set
    CONFIG_POWER_SUPPLY_HWMON=y
    # CONFIG_PDA_POWER is not set
    # CONFIG_GENERIC_ADC_BATTERY is not set
    # CONFIG_TEST_POWER is not set
    # CONFIG_CHARGER_ADP5061 is not set
    CONFIG_BATTERY_ACT8945A=y
    CONFIG_BATTERY_CPCAP=m
    # CONFIG_BATTERY_CW2015 is not set
    # CONFIG_BATTERY_DS2760 is not set
    # CONFIG_BATTERY_DS2780 is not set
    # CONFIG_BATTERY_DS2781 is not set
    # CONFIG_BATTERY_DS2782 is not set
    CONFIG_BATTERY_SBS=y
    # CONFIG_CHARGER_SBS is not set
    # CONFIG_MANAGER_SBS is not set
    CONFIG_BATTERY_BQ27XXX=m
    CONFIG_BATTERY_BQ27XXX_I2C=m
    CONFIG_BATTERY_BQ27XXX_HDQ=m
    # CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set
    CONFIG_BATTERY_MAX17040=m
    CONFIG_BATTERY_MAX17042=m
    # CONFIG_BATTERY_MAX1721X is not set
    CONFIG_CHARGER_CPCAP=m
    # CONFIG_CHARGER_ISP1704 is not set
    # CONFIG_CHARGER_MAX8903 is not set
    # CONFIG_CHARGER_LP8727 is not set
    CONFIG_CHARGER_GPIO=m
    # CONFIG_CHARGER_MANAGER is not set
    # CONFIG_CHARGER_LT3651 is not set
    # CONFIG_CHARGER_DETECTOR_MAX14656 is not set
    # CONFIG_CHARGER_BQ2415X is not set
    # CONFIG_CHARGER_BQ24190 is not set
    # CONFIG_CHARGER_BQ24257 is not set
    # CONFIG_CHARGER_BQ24735 is not set
    # CONFIG_CHARGER_BQ2515X is not set
    # CONFIG_CHARGER_BQ25890 is not set
    # CONFIG_CHARGER_BQ25980 is not set
    # CONFIG_CHARGER_SMB347 is not set
    CONFIG_CHARGER_TPS65090=y
    # CONFIG_CHARGER_TPS65217 is not set
    # CONFIG_BATTERY_GAUGE_LTC2941 is not set
    # CONFIG_BATTERY_RT5033 is not set
    # CONFIG_CHARGER_RT9455 is not set
    # CONFIG_CHARGER_UCS1002 is not set
    # CONFIG_CHARGER_BD99954 is not set
    CONFIG_HWMON=y
    # CONFIG_HWMON_DEBUG_CHIP is not set
    # Native drivers
    # CONFIG_SENSORS_AD7314 is not set
    # CONFIG_SENSORS_AD7414 is not set
    # CONFIG_SENSORS_AD7418 is not set
    # CONFIG_SENSORS_ADM1021 is not set
    # CONFIG_SENSORS_ADM1025 is not set
    # CONFIG_SENSORS_ADM1026 is not set
    # CONFIG_SENSORS_ADM1029 is not set
    # CONFIG_SENSORS_ADM1031 is not set
    # CONFIG_SENSORS_ADM1177 is not set
    # CONFIG_SENSORS_ADM9240 is not set
    # CONFIG_SENSORS_ADT7310 is not set
    # CONFIG_SENSORS_ADT7410 is not set
    # CONFIG_SENSORS_ADT7411 is not set
    # CONFIG_SENSORS_ADT7462 is not set
    # CONFIG_SENSORS_ADT7470 is not set
    # CONFIG_SENSORS_ADT7475 is not set
    # CONFIG_SENSORS_AS370 is not set
    # CONFIG_SENSORS_ASC7621 is not set
    # CONFIG_SENSORS_AXI_FAN_CONTROL is not set
    CONFIG_SENSORS_ASPEED=m
    # CONFIG_SENSORS_ATXP1 is not set
    # CONFIG_SENSORS_CORSAIR_CPRO is not set
    # CONFIG_SENSORS_DRIVETEMP is not set
    # CONFIG_SENSORS_DS620 is not set
    # CONFIG_SENSORS_DS1621 is not set
    # CONFIG_SENSORS_I5K_AMB is not set
    # CONFIG_SENSORS_F71805F is not set
    # CONFIG_SENSORS_F71882FG is not set
    # CONFIG_SENSORS_F75375S is not set
    # CONFIG_SENSORS_FTSTEUTATES is not set
    # CONFIG_SENSORS_GL518SM is not set
    # CONFIG_SENSORS_GL520SM is not set
    # CONFIG_SENSORS_G760A is not set
    # CONFIG_SENSORS_G762 is not set
    CONFIG_SENSORS_GPIO_FAN=y
    # CONFIG_SENSORS_HIH6130 is not set
    CONFIG_SENSORS_IIO_HWMON=y
    # CONFIG_SENSORS_IT87 is not set
    # CONFIG_SENSORS_JC42 is not set
    # CONFIG_SENSORS_POWR1220 is not set
    # CONFIG_SENSORS_LINEAGE is not set
    # CONFIG_SENSORS_LTC2945 is not set
    # CONFIG_SENSORS_LTC2947_I2C is not set
    # CONFIG_SENSORS_LTC2947_SPI is not set
    # CONFIG_SENSORS_LTC2990 is not set
    # CONFIG_SENSORS_LTC4151 is not set
    # CONFIG_SENSORS_LTC4215 is not set
    # CONFIG_SENSORS_LTC4222 is not set
    # CONFIG_SENSORS_LTC4245 is not set
    # CONFIG_SENSORS_LTC4260 is not set
    # CONFIG_SENSORS_LTC4261 is not set
    # CONFIG_SENSORS_MAX1111 is not set
    # CONFIG_SENSORS_MAX16065 is not set
    # CONFIG_SENSORS_MAX1619 is not set
    # CONFIG_SENSORS_MAX1668 is not set
    # CONFIG_SENSORS_MAX197 is not set
    # CONFIG_SENSORS_MAX31722 is not set
    # CONFIG_SENSORS_MAX31730 is not set
    # CONFIG_SENSORS_MAX6621 is not set
    # CONFIG_SENSORS_MAX6639 is not set
    # CONFIG_SENSORS_MAX6642 is not set
    # CONFIG_SENSORS_MAX6650 is not set
    # CONFIG_SENSORS_MAX6697 is not set
    # CONFIG_SENSORS_MAX31790 is not set
    # CONFIG_SENSORS_MCP3021 is not set
    # CONFIG_SENSORS_TC654 is not set
    # CONFIG_SENSORS_MR75203 is not set
    # CONFIG_SENSORS_ADCXX is not set
    # CONFIG_SENSORS_LM63 is not set
    # CONFIG_SENSORS_LM70 is not set
    # CONFIG_SENSORS_LM73 is not set
    # CONFIG_SENSORS_LM75 is not set
    # CONFIG_SENSORS_LM77 is not set
    # CONFIG_SENSORS_LM78 is not set
    # CONFIG_SENSORS_LM80 is not set
    # CONFIG_SENSORS_LM83 is not set
    # CONFIG_SENSORS_LM85 is not set
    # CONFIG_SENSORS_LM87 is not set
    CONFIG_SENSORS_LM90=y
    # CONFIG_SENSORS_LM92 is not set
    # CONFIG_SENSORS_LM93 is not set
    # CONFIG_SENSORS_LM95234 is not set
    # CONFIG_SENSORS_LM95241 is not set
    CONFIG_SENSORS_LM95245=y
    # CONFIG_SENSORS_PC87360 is not set
    # CONFIG_SENSORS_PC87427 is not set
    CONFIG_SENSORS_NTC_THERMISTOR=m
    # CONFIG_SENSORS_NCT6683 is not set
    # CONFIG_SENSORS_NCT6775 is not set
    # CONFIG_SENSORS_NCT7802 is not set
    # CONFIG_SENSORS_NCT7904 is not set
    # CONFIG_SENSORS_NPCM7XX is not set
    # CONFIG_SENSORS_OCC_P8_I2C is not set
    # CONFIG_SENSORS_OCC_P9_SBE is not set
    # CONFIG_SENSORS_PCF8591 is not set
    # CONFIG_PMBUS is not set
    CONFIG_SENSORS_PWM_FAN=m
    # CONFIG_SENSORS_SHT15 is not set
    # CONFIG_SENSORS_SHT21 is not set
    # CONFIG_SENSORS_SHT3x is not set
    # CONFIG_SENSORS_SHTC1 is not set
    # CONFIG_SENSORS_SIS5595 is not set
    # CONFIG_SENSORS_DME1737 is not set
    # CONFIG_SENSORS_EMC1403 is not set
    # CONFIG_SENSORS_EMC2103 is not set
    # CONFIG_SENSORS_EMC6W201 is not set
    # CONFIG_SENSORS_SMSC47M1 is not set
    # CONFIG_SENSORS_SMSC47M192 is not set
    # CONFIG_SENSORS_SMSC47B397 is not set
    # CONFIG_SENSORS_SCH5627 is not set
    # CONFIG_SENSORS_SCH5636 is not set
    # CONFIG_SENSORS_STTS751 is not set
    # CONFIG_SENSORS_SMM665 is not set
    # CONFIG_SENSORS_ADC128D818 is not set
    # CONFIG_SENSORS_ADS7828 is not set
    # CONFIG_SENSORS_ADS7871 is not set
    # CONFIG_SENSORS_AMC6821 is not set
    # CONFIG_SENSORS_INA209 is not set
    CONFIG_SENSORS_INA2XX=m
    # CONFIG_SENSORS_INA3221 is not set
    # CONFIG_SENSORS_TC74 is not set
    # CONFIG_SENSORS_THMC50 is not set
    CONFIG_SENSORS_TMP102=y
    # CONFIG_SENSORS_TMP103 is not set
    # CONFIG_SENSORS_TMP108 is not set
    # CONFIG_SENSORS_TMP401 is not set
    # CONFIG_SENSORS_TMP421 is not set
    # CONFIG_SENSORS_TMP513 is not set
    # CONFIG_SENSORS_VIA686A is not set
    # CONFIG_SENSORS_VT1211 is not set
    # CONFIG_SENSORS_VT8231 is not set
    # CONFIG_SENSORS_W83773G is not set
    # CONFIG_SENSORS_W83781D is not set
    # CONFIG_SENSORS_W83791D is not set
    # CONFIG_SENSORS_W83792D is not set
    # CONFIG_SENSORS_W83793 is not set
    # CONFIG_SENSORS_W83795 is not set
    # CONFIG_SENSORS_W83L785TS is not set
    # CONFIG_SENSORS_W83L786NG is not set
    # CONFIG_SENSORS_W83627HF is not set
    # CONFIG_SENSORS_W83627EHF is not set
    CONFIG_THERMAL=y
    # CONFIG_THERMAL_NETLINK is not set
    # CONFIG_THERMAL_STATISTICS is not set
    CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
    CONFIG_THERMAL_HWMON=y
    CONFIG_THERMAL_OF=y
    CONFIG_THERMAL_WRITABLE_TRIPS=y
    CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
    # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
    # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
    CONFIG_THERMAL_GOV_FAIR_SHARE=y
    CONFIG_THERMAL_GOV_STEP_WISE=y
    CONFIG_THERMAL_GOV_BANG_BANG=y
    CONFIG_THERMAL_GOV_USER_SPACE=y
    CONFIG_CPU_THERMAL=y
    CONFIG_CPU_FREQ_THERMAL=y
    CONFIG_DEVFREQ_THERMAL=y
    CONFIG_THERMAL_EMULATION=y
    # CONFIG_THERMAL_MMIO is not set
    # Texas Instruments thermal drivers
    CONFIG_TI_SOC_THERMAL=y
    CONFIG_TI_THERMAL=y
    # end of Texas Instruments thermal drivers
    # CONFIG_GENERIC_ADC_THERMAL is not set
    CONFIG_WATCHDOG=y
    CONFIG_WATCHDOG_CORE=y
    # CONFIG_WATCHDOG_NOWAYOUT is not set
    CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
    CONFIG_WATCHDOG_OPEN_TIMEOUT=0
    # CONFIG_WATCHDOG_SYSFS is not set
    # Watchdog Pretimeout Governors
    # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
    # Watchdog Device Drivers
    # CONFIG_SOFT_WATCHDOG is not set
    # CONFIG_GPIO_WATCHDOG is not set
    # CONFIG_XILINX_WATCHDOG is not set
    # CONFIG_ZIIRAVE_WATCHDOG is not set
    # CONFIG_CADENCE_WATCHDOG is not set
    # CONFIG_FTWDT010_WATCHDOG is not set
    # CONFIG_DW_WATCHDOG is not set
    CONFIG_OMAP_WATCHDOG=m
    # CONFIG_MAX63XX_WATCHDOG is not set
    # CONFIG_ARM_SMC_WATCHDOG is not set
    CONFIG_STPMIC1_WATCHDOG=y
    # CONFIG_ALIM7101_WDT is not set
    # CONFIG_I6300ESB_WDT is not set
    # CONFIG_MEN_A21_WDT is not set
    # PCI-based Watchdog Cards
    # CONFIG_PCIPCWATCHDOG is not set
    # CONFIG_WDTPCI is not set
    # USB-based Watchdog Cards
    # CONFIG_USBPCWATCHDOG is not set
    CONFIG_SSB_POSSIBLE=y
    CONFIG_SSB=m
    CONFIG_SSB_SPROM=y
    CONFIG_SSB_BLOCKIO=y
    CONFIG_SSB_PCIHOST_POSSIBLE=y
    CONFIG_SSB_PCIHOST=y
    CONFIG_SSB_B43_PCI_BRIDGE=y
    CONFIG_SSB_SDIOHOST_POSSIBLE=y
    # CONFIG_SSB_SDIOHOST is not set
    CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
    CONFIG_SSB_DRIVER_PCICORE=y
    # CONFIG_SSB_DRIVER_GPIO is not set
    CONFIG_BCMA_POSSIBLE=y
    CONFIG_BCMA=m
    CONFIG_BCMA_BLOCKIO=y
    CONFIG_BCMA_HOST_PCI_POSSIBLE=y
    CONFIG_BCMA_HOST_PCI=y
    CONFIG_BCMA_HOST_SOC=y
    CONFIG_BCMA_DRIVER_PCI=y
    CONFIG_BCMA_SFLASH=y
    CONFIG_BCMA_DRIVER_GMAC_CMN=y
    CONFIG_BCMA_DRIVER_GPIO=y
    # CONFIG_BCMA_DEBUG is not set
    # Multifunction device drivers
    CONFIG_MFD_CORE=y
    CONFIG_MFD_ACT8945A=y
    # CONFIG_MFD_AS3711 is not set
    # CONFIG_MFD_AS3722 is not set
    # CONFIG_PMIC_ADP5520 is not set
    # CONFIG_MFD_AAT2870_CORE is not set
    # CONFIG_MFD_ATMEL_FLEXCOM is not set
    # CONFIG_MFD_ATMEL_HLCDC is not set
    # CONFIG_MFD_BCM590XX is not set
    # CONFIG_MFD_BD9571MWV is not set
    # CONFIG_MFD_AXP20X_I2C is not set
    # CONFIG_MFD_MADERA is not set
    # CONFIG_MFD_ASIC3 is not set
    # CONFIG_PMIC_DA903X is not set
    # CONFIG_MFD_DA9052_SPI is not set
    # CONFIG_MFD_DA9052_I2C is not set
    # CONFIG_MFD_DA9055 is not set
    # CONFIG_MFD_DA9062 is not set
    # CONFIG_MFD_DA9063 is not set
    # CONFIG_MFD_DA9150 is not set
    # CONFIG_MFD_DLN2 is not set
    # CONFIG_MFD_GATEWORKS_GSC is not set
    # CONFIG_MFD_MC13XXX_SPI is not set
    # CONFIG_MFD_MC13XXX_I2C is not set
    # CONFIG_MFD_MP2629 is not set
    # CONFIG_MFD_HI6421_PMIC is not set
    # CONFIG_HTC_PASIC3 is not set
    # CONFIG_HTC_I2CPLD is not set
    # CONFIG_LPC_ICH is not set
    # CONFIG_LPC_SCH is not set
    # CONFIG_MFD_IQS62X is not set
    # CONFIG_MFD_JANZ_CMODIO is not set
    # CONFIG_MFD_KEMPLD is not set
    # CONFIG_MFD_88PM800 is not set
    # CONFIG_MFD_88PM805 is not set
    # CONFIG_MFD_88PM860X is not set
    # CONFIG_MFD_MAX14577 is not set
    # CONFIG_MFD_MAX77620 is not set
    # CONFIG_MFD_MAX77650 is not set
    # CONFIG_MFD_MAX77686 is not set
    # CONFIG_MFD_MAX77693 is not set
    # CONFIG_MFD_MAX77843 is not set
    # CONFIG_MFD_MAX8907 is not set
    # CONFIG_MFD_MAX8925 is not set
    # CONFIG_MFD_MAX8997 is not set
    # CONFIG_MFD_MAX8998 is not set
    # CONFIG_MFD_MT6360 is not set
    # CONFIG_MFD_MT6397 is not set
    # CONFIG_MFD_MENF21BMC is not set
    # CONFIG_EZX_PCAP is not set
    CONFIG_MFD_CPCAP=y
    # CONFIG_MFD_VIPERBOARD is not set
    # CONFIG_MFD_RETU is not set
    # CONFIG_MFD_PCF50633 is not set
    # CONFIG_MFD_PM8XXX is not set
    # CONFIG_MFD_RDC321X is not set
    # CONFIG_MFD_RT5033 is not set
    # CONFIG_MFD_RC5T583 is not set
    # CONFIG_MFD_RK808 is not set
    # CONFIG_MFD_RN5T618 is not set
    # CONFIG_MFD_SEC_CORE is not set
    # CONFIG_MFD_SI476X_CORE is not set
    # CONFIG_MFD_SM501 is not set
    # CONFIG_MFD_SKY81452 is not set
    # CONFIG_ABX500_CORE is not set
    # CONFIG_MFD_STMPE is not set
    CONFIG_MFD_SYSCON=y
    CONFIG_MFD_TI_AM335X_TSCADC=m
    # CONFIG_MFD_LP3943 is not set
    # CONFIG_MFD_LP8788 is not set
    # CONFIG_MFD_TI_LMU is not set
    CONFIG_MFD_OMAP_USB_HOST=y
    CONFIG_MFD_PALMAS=y
    # CONFIG_TPS6105X is not set
    # CONFIG_TPS65010 is not set
    # CONFIG_TPS6507X is not set
    # CONFIG_MFD_TPS65086 is not set
    CONFIG_MFD_TPS65090=y
    CONFIG_MFD_TPS65217=y
    CONFIG_MFD_TI_LP873X=y
    CONFIG_MFD_TI_LP87565=y
    CONFIG_MFD_TPS65218=y
    CONFIG_MFD_TPS6586X=y
    CONFIG_MFD_TPS65910=y
    # CONFIG_MFD_TPS65912_I2C is not set
    # CONFIG_MFD_TPS65912_SPI is not set
    # CONFIG_MFD_TPS80031 is not set
    # CONFIG_TWL4030_CORE is not set
    CONFIG_TWL6040_CORE=y
    # CONFIG_MFD_WL1273_CORE is not set
    # CONFIG_MFD_LM3533 is not set
    # CONFIG_MFD_TC3589X is not set
    # CONFIG_MFD_T7L66XB is not set
    # CONFIG_MFD_TC6387XB is not set
    # CONFIG_MFD_TC6393XB is not set
    # CONFIG_MFD_TQMX86 is not set
    # CONFIG_MFD_VX855 is not set
    # CONFIG_MFD_LOCHNAGAR is not set
    # CONFIG_MFD_ARIZONA_I2C is not set
    # CONFIG_MFD_ARIZONA_SPI is not set
    # CONFIG_MFD_WM8400 is not set
    # CONFIG_MFD_WM831X_I2C is not set
    # CONFIG_MFD_WM831X_SPI is not set
    # CONFIG_MFD_WM8350_I2C is not set
    # CONFIG_MFD_WM8994 is not set
    # CONFIG_MFD_ROHM_BD718XX is not set
    # CONFIG_MFD_ROHM_BD70528 is not set
    # CONFIG_MFD_ROHM_BD71828 is not set
    CONFIG_MFD_STPMIC1=y
    CONFIG_MFD_STMFX=y
    # CONFIG_RAVE_SP_CORE is not set
    # CONFIG_MFD_INTEL_M10_BMC is not set
    # end of Multifunction device drivers
    CONFIG_REGULATOR=y
    # CONFIG_REGULATOR_DEBUG is not set
    CONFIG_REGULATOR_FIXED_VOLTAGE=y
    # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
    # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
    # CONFIG_REGULATOR_88PG86X is not set
    # CONFIG_REGULATOR_ACT8865 is not set
    CONFIG_REGULATOR_ACT8945A=y
    # CONFIG_REGULATOR_AD5398 is not set
    CONFIG_REGULATOR_CPCAP=y
    # CONFIG_REGULATOR_DA9210 is not set
    # CONFIG_REGULATOR_DA9211 is not set
    # CONFIG_REGULATOR_FAN53555 is not set
    # CONFIG_REGULATOR_FAN53880 is not set
    CONFIG_REGULATOR_GPIO=y
    # CONFIG_REGULATOR_ISL9305 is not set
    # CONFIG_REGULATOR_ISL6271A is not set
    # CONFIG_REGULATOR_LP3971 is not set
    # CONFIG_REGULATOR_LP3972 is not set
    # CONFIG_REGULATOR_LP872X is not set
    CONFIG_REGULATOR_LP873X=y
    # CONFIG_REGULATOR_LP8755 is not set
    CONFIG_REGULATOR_LP87565=y
    # CONFIG_REGULATOR_LTC3589 is not set
    # CONFIG_REGULATOR_LTC3676 is not set
    # CONFIG_REGULATOR_MAX1586 is not set
    # CONFIG_REGULATOR_MAX8649 is not set
    # CONFIG_REGULATOR_MAX8660 is not set
    # CONFIG_REGULATOR_MAX8952 is not set
    # CONFIG_REGULATOR_MAX8973 is not set
    # CONFIG_REGULATOR_MAX77826 is not set
    # CONFIG_REGULATOR_MCP16502 is not set
    # CONFIG_REGULATOR_MP5416 is not set
    # CONFIG_REGULATOR_MP8859 is not set
    # CONFIG_REGULATOR_MP886X is not set
    # CONFIG_REGULATOR_MPQ7920 is not set
    # CONFIG_REGULATOR_MT6311 is not set
    CONFIG_REGULATOR_PALMAS=y
    CONFIG_REGULATOR_PBIAS=y
    # CONFIG_REGULATOR_PCA9450 is not set
    # CONFIG_REGULATOR_PFUZE100 is not set
    # CONFIG_REGULATOR_PV88060 is not set
    # CONFIG_REGULATOR_PV88080 is not set
    # CONFIG_REGULATOR_PV88090 is not set
    # CONFIG_REGULATOR_PWM is not set
    # CONFIG_REGULATOR_QCOM_SPMI is not set
    # CONFIG_REGULATOR_QCOM_USB_VBUS is not set
    # CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set
    # CONFIG_REGULATOR_RT4801 is not set
    # CONFIG_REGULATOR_RTMV20 is not set
    # CONFIG_REGULATOR_SLG51000 is not set
    CONFIG_REGULATOR_STPMIC1=y
    CONFIG_REGULATOR_TI_ABB=y
    # CONFIG_REGULATOR_SY8106A is not set
    # CONFIG_REGULATOR_SY8824X is not set
    # CONFIG_REGULATOR_SY8827N is not set
    # CONFIG_REGULATOR_TPS51632 is not set
    CONFIG_REGULATOR_TPS62360=y
    CONFIG_REGULATOR_TPS65023=y
    CONFIG_REGULATOR_TPS6507X=y
    CONFIG_REGULATOR_TPS65090=y
    # CONFIG_REGULATOR_TPS65132 is not set
    CONFIG_REGULATOR_TPS65217=y
    CONFIG_REGULATOR_TPS65218=y
    CONFIG_REGULATOR_TPS6524X=y
    CONFIG_REGULATOR_TPS6586X=y
    CONFIG_REGULATOR_TPS65910=y
    # CONFIG_REGULATOR_VCTRL is not set
    # CONFIG_REGULATOR_QCOM_LABIBB is not set
    # CONFIG_RC_CORE is not set
    CONFIG_CEC_CORE=y
    CONFIG_MEDIA_CEC_SUPPORT=y
    # CONFIG_CEC_CH7322 is not set
    # CONFIG_CEC_GPIO is not set
    # CONFIG_USB_PULSE8_CEC is not set
    # CONFIG_USB_RAINSHADOW_CEC is not set
    CONFIG_MEDIA_SUPPORT=y
    # CONFIG_MEDIA_SUPPORT_FILTER is not set
    # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
    # Media device types
    CONFIG_MEDIA_CAMERA_SUPPORT=y
    CONFIG_MEDIA_ANALOG_TV_SUPPORT=y
    CONFIG_MEDIA_DIGITAL_TV_SUPPORT=y
    CONFIG_MEDIA_RADIO_SUPPORT=y
    CONFIG_MEDIA_SDR_SUPPORT=y
    CONFIG_MEDIA_PLATFORM_SUPPORT=y
    CONFIG_MEDIA_TEST_SUPPORT=y
    # end of Media device types
    # Media core support
    CONFIG_VIDEO_DEV=y
    CONFIG_MEDIA_CONTROLLER=y
    CONFIG_DVB_CORE=y
    # end of Media core support
    # Video4Linux options
    CONFIG_VIDEO_V4L2=y
    CONFIG_VIDEO_V4L2_I2C=y
    CONFIG_VIDEO_V4L2_SUBDEV_API=y
    # CONFIG_VIDEO_ADV_DEBUG is not set
    # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
    CONFIG_V4L2_MEM2MEM_DEV=y
    # CONFIG_V4L2_FLASH_LED_CLASS is not set
    CONFIG_V4L2_FWNODE=m
    # end of Video4Linux options
    # Media controller options
    # CONFIG_MEDIA_CONTROLLER_DVB is not set
    CONFIG_MEDIA_CONTROLLER_REQUEST_API=y
    # Please notice that the enabled Media controller Request API is EXPERIMENTAL
    # end of Media controller options
    # Digital TV options
    # CONFIG_DVB_MMAP is not set
    CONFIG_DVB_NET=y
    CONFIG_DVB_MAX_ADAPTERS=16
    CONFIG_DVB_DYNAMIC_MINORS=y
    # CONFIG_DVB_DEMUX_SECTION_LOSS_LOG is not set
    # CONFIG_DVB_ULE_DEBUG is not set
    # end of Digital TV options
    # Media drivers
    CONFIG_MEDIA_USB_SUPPORT=y
    # Webcam devices
    CONFIG_USB_VIDEO_CLASS=m
    CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
    CONFIG_USB_GSPCA=m
    # CONFIG_USB_M5602 is not set
    # CONFIG_USB_STV06XX is not set
    # CONFIG_USB_GL860 is not set
    # CONFIG_USB_GSPCA_BENQ is not set
    # CONFIG_USB_GSPCA_CONEX is not set
    # CONFIG_USB_GSPCA_CPIA1 is not set
    # CONFIG_USB_GSPCA_DTCS033 is not set
    # CONFIG_USB_GSPCA_ETOMS is not set
    # CONFIG_USB_GSPCA_FINEPIX is not set
    # CONFIG_USB_GSPCA_JEILINJ is not set
    # CONFIG_USB_GSPCA_JL2005BCD is not set
    # CONFIG_USB_GSPCA_KINECT is not set
    # CONFIG_USB_GSPCA_KONICA is not set
    # CONFIG_USB_GSPCA_MARS is not set
    # CONFIG_USB_GSPCA_MR97310A is not set
    # CONFIG_USB_GSPCA_NW80X is not set
    # CONFIG_USB_GSPCA_OV519 is not set
    # CONFIG_USB_GSPCA_OV534 is not set
    # CONFIG_USB_GSPCA_OV534_9 is not set
    # CONFIG_USB_GSPCA_PAC207 is not set
    # CONFIG_USB_GSPCA_PAC7302 is not set
    # CONFIG_USB_GSPCA_PAC7311 is not set
    # CONFIG_USB_GSPCA_SE401 is not set
    # CONFIG_USB_GSPCA_SN9C2028 is not set
    # CONFIG_USB_GSPCA_SN9C20X is not set
    # CONFIG_USB_GSPCA_SONIXB is not set
    # CONFIG_USB_GSPCA_SONIXJ is not set
    # CONFIG_USB_GSPCA_SPCA500 is not set
    # CONFIG_USB_GSPCA_SPCA501 is not set
    # CONFIG_USB_GSPCA_SPCA505 is not set
    # CONFIG_USB_GSPCA_SPCA506 is not set
    # CONFIG_USB_GSPCA_SPCA508 is not set
    # CONFIG_USB_GSPCA_SPCA561 is not set
    # CONFIG_USB_GSPCA_SPCA1528 is not set
    # CONFIG_USB_GSPCA_SQ905 is not set
    # CONFIG_USB_GSPCA_SQ905C is not set
    # CONFIG_USB_GSPCA_SQ930X is not set
    # CONFIG_USB_GSPCA_STK014 is not set
    # CONFIG_USB_GSPCA_STK1135 is not set
    # CONFIG_USB_GSPCA_STV0680 is not set
    # CONFIG_USB_GSPCA_SUNPLUS is not set
    # CONFIG_USB_GSPCA_T613 is not set
    # CONFIG_USB_GSPCA_TOPRO is not set
    # CONFIG_USB_GSPCA_TOUPTEK is not set
    # CONFIG_USB_GSPCA_TV8532 is not set
    # CONFIG_USB_GSPCA_VC032X is not set
    # CONFIG_USB_GSPCA_VICAM is not set
    # CONFIG_USB_GSPCA_XIRLINK_CIT is not set
    # CONFIG_USB_GSPCA_ZC3XX is not set
    # CONFIG_USB_PWC is not set
    # CONFIG_VIDEO_CPIA2 is not set
    # CONFIG_USB_ZR364XX is not set
    # CONFIG_USB_STKWEBCAM is not set
    # CONFIG_USB_S2255 is not set
    # CONFIG_VIDEO_USBTV is not set
    # Analog TV USB devices
    # CONFIG_VIDEO_PVRUSB2 is not set
    # CONFIG_VIDEO_HDPVR is not set
    # CONFIG_VIDEO_STK1160_COMMON is not set
    # CONFIG_VIDEO_GO7007 is not set
    # Analog/digital TV USB devices
    # CONFIG_VIDEO_AU0828 is not set
    # CONFIG_VIDEO_CX231XX is not set
    # Digital TV USB devices
    # CONFIG_DVB_USB_V2 is not set
    # CONFIG_DVB_TTUSB_BUDGET is not set
    # CONFIG_DVB_TTUSB_DEC is not set
    # CONFIG_SMS_USB_DRV is not set
    # CONFIG_DVB_B2C2_FLEXCOP_USB is not set
    # CONFIG_DVB_AS102 is not set
    # Webcam, TV (analog/digital) USB devices
    # CONFIG_VIDEO_EM28XX is not set
    # Software defined radio USB devices
    # CONFIG_USB_AIRSPY is not set
    # CONFIG_USB_HACKRF is not set
    # CONFIG_USB_MSI2500 is not set
    # CONFIG_MEDIA_PCI_SUPPORT is not set
    CONFIG_RADIO_ADAPTERS=y
    # CONFIG_RADIO_SI470X is not set
    # CONFIG_RADIO_SI4713 is not set
    # CONFIG_USB_MR800 is not set
    # CONFIG_USB_DSBR is not set
    # CONFIG_RADIO_MAXIRADIO is not set
    # CONFIG_RADIO_SHARK is not set
    # CONFIG_RADIO_SHARK2 is not set
    # CONFIG_USB_KEENE is not set
    # CONFIG_USB_RAREMONO is not set
    # CONFIG_USB_MA901 is not set
    # CONFIG_RADIO_TEA5764 is not set
    # CONFIG_RADIO_SAA7706H is not set
    # CONFIG_RADIO_TEF6862 is not set
    # CONFIG_RADIO_WL1273 is not set
    CONFIG_VIDEOBUF2_CORE=y
    CONFIG_VIDEOBUF2_V4L2=y
    CONFIG_VIDEOBUF2_MEMOPS=y
    CONFIG_VIDEOBUF2_DMA_CONTIG=y
    CONFIG_VIDEOBUF2_VMALLOC=m
    CONFIG_VIDEO_V4L2_TPG=m
    CONFIG_V4L_PLATFORM_DRIVERS=y
    # CONFIG_VIDEO_CAFE_CCIC is not set
    CONFIG_VIDEO_CADENCE=y
    CONFIG_VIDEO_CADENCE_CSI2RX=m
    # CONFIG_VIDEO_CADENCE_CSI2TX is not set
    CONFIG_VIDEO_ASPEED=m
    # CONFIG_VIDEO_MUX is not set
    # CONFIG_VIDEO_XILINX is not set
    CONFIG_V4L_MEM2MEM_DRIVERS=y
    # CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
    # CONFIG_DVB_PLATFORM_DRIVERS is not set
    # CONFIG_SDR_PLATFORM_DRIVERS is not set
    # MMC/SDIO DVB adapters
    # CONFIG_SMS_SDIO_DRV is not set
    CONFIG_V4L_TEST_DRIVERS=y
    # CONFIG_VIDEO_VIMC is not set
    CONFIG_VIDEO_VIVID=m
    # CONFIG_VIDEO_VIVID_CEC is not set
    CONFIG_VIDEO_VIVID_MAX_DEVS=64
    # CONFIG_VIDEO_VIM2M is not set
    # CONFIG_VIDEO_VICODEC is not set
    # CONFIG_DVB_TEST_DRIVERS is not set
    # end of Media drivers
    # Media ancillary drivers
    CONFIG_MEDIA_ATTACH=y
    # Audio decoders, processors and mixers
    # CONFIG_VIDEO_TVAUDIO is not set
    # CONFIG_VIDEO_TDA7432 is not set
    # CONFIG_VIDEO_TDA9840 is not set
    # CONFIG_VIDEO_TDA1997X is not set
    # CONFIG_VIDEO_TEA6415C is not set
    # CONFIG_VIDEO_TEA6420 is not set
    # CONFIG_VIDEO_MSP3400 is not set
    # CONFIG_VIDEO_CS3308 is not set
    # CONFIG_VIDEO_CS5345 is not set
    # CONFIG_VIDEO_CS53L32A is not set
    # CONFIG_VIDEO_TLV320AIC23B is not set
    # CONFIG_VIDEO_UDA1342 is not set
    # CONFIG_VIDEO_WM8775 is not set
    # CONFIG_VIDEO_WM8739 is not set
    # CONFIG_VIDEO_VP27SMPX is not set
    # CONFIG_VIDEO_SONY_BTF_MPX is not set
    # end of Audio decoders, processors and mixers
    # RDS decoders
    # CONFIG_VIDEO_SAA6588 is not set
    # end of RDS decoders
    # Video decoders
    CONFIG_VIDEO_ADV7180=m
    # CONFIG_VIDEO_ADV7183 is not set
    # CONFIG_VIDEO_ADV748X is not set
    CONFIG_VIDEO_ADV7604=m
    CONFIG_VIDEO_ADV7604_CEC=y
    # CONFIG_VIDEO_ADV7842 is not set
    # CONFIG_VIDEO_BT819 is not set
    # CONFIG_VIDEO_BT856 is not set
    # CONFIG_VIDEO_BT866 is not set
    # CONFIG_VIDEO_KS0127 is not set
    CONFIG_VIDEO_ML86V7667=m
    # CONFIG_VIDEO_SAA7110 is not set
    # CONFIG_VIDEO_SAA711X is not set
    # CONFIG_VIDEO_TC358743 is not set
    # CONFIG_VIDEO_TVP514X is not set
    # CONFIG_VIDEO_TVP5150 is not set
    # CONFIG_VIDEO_TVP7002 is not set
    # CONFIG_VIDEO_TW2804 is not set
    # CONFIG_VIDEO_TW9903 is not set
    # CONFIG_VIDEO_TW9906 is not set
    # CONFIG_VIDEO_TW9910 is not set
    # CONFIG_VIDEO_VPX3220 is not set
    # CONFIG_VIDEO_MAX9286 is not set
    # Video and audio decoders
    # CONFIG_VIDEO_SAA717X is not set
    # CONFIG_VIDEO_CX25840 is not set
    # end of Video decoders
    # Video encoders
    # CONFIG_VIDEO_SAA7127 is not set
    # CONFIG_VIDEO_SAA7185 is not set
    # CONFIG_VIDEO_ADV7170 is not set
    # CONFIG_VIDEO_ADV7175 is not set
    # CONFIG_VIDEO_ADV7343 is not set
    # CONFIG_VIDEO_ADV7393 is not set
    # CONFIG_VIDEO_ADV7511 is not set
    # CONFIG_VIDEO_AD9389B is not set
    # CONFIG_VIDEO_AK881X is not set
    # CONFIG_VIDEO_THS8200 is not set
    # end of Video encoders
    # Video improvement chips
    # CONFIG_VIDEO_UPD64031A is not set
    # CONFIG_VIDEO_UPD64083 is not set
    # end of Video improvement chips
    # Audio/Video compression chips
    # CONFIG_VIDEO_SAA6752HS is not set
    # end of Audio/Video compression chips
    # SDR tuner chips
    # CONFIG_SDR_MAX2175 is not set
    # end of SDR tuner chips
    # Miscellaneous helper chips
    # CONFIG_VIDEO_THS7303 is not set
    # CONFIG_VIDEO_M52790 is not set
    # CONFIG_VIDEO_I2C is not set
    # CONFIG_VIDEO_ST_MIPID02 is not set
    # end of Miscellaneous helper chips
    # Camera sensor devices
    # CONFIG_VIDEO_HI556 is not set
    # CONFIG_VIDEO_IMX214 is not set
    # CONFIG_VIDEO_IMX219 is not set
    # CONFIG_VIDEO_IMX258 is not set
    # CONFIG_VIDEO_IMX274 is not set
    # CONFIG_VIDEO_IMX290 is not set
    # CONFIG_VIDEO_IMX319 is not set
    # CONFIG_VIDEO_IMX355 is not set
    # CONFIG_VIDEO_OV2640 is not set
    CONFIG_VIDEO_OV2659=m
    # CONFIG_VIDEO_OV2680 is not set
    # CONFIG_VIDEO_OV2685 is not set
    CONFIG_VIDEO_OV5640=m
    # CONFIG_VIDEO_OV5645 is not set
    # CONFIG_VIDEO_OV5647 is not set
    # CONFIG_VIDEO_OV6650 is not set
    # CONFIG_VIDEO_OV5670 is not set
    # CONFIG_VIDEO_OV5675 is not set
    # CONFIG_VIDEO_OV5695 is not set
    # CONFIG_VIDEO_OV7251 is not set
    # CONFIG_VIDEO_OV772X is not set
    # CONFIG_VIDEO_OV7640 is not set
    # CONFIG_VIDEO_OV7670 is not set
    # CONFIG_VIDEO_OV7740 is not set
    # CONFIG_VIDEO_OV8856 is not set
    # CONFIG_VIDEO_OV9640 is not set
    # CONFIG_VIDEO_OV9650 is not set
    # CONFIG_VIDEO_OV13858 is not set
    CONFIG_VIDEO_OV1063X=m
    # CONFIG_VIDEO_VS6624 is not set
    # CONFIG_VIDEO_MT9M001 is not set
    # CONFIG_VIDEO_MT9M032 is not set
    # CONFIG_VIDEO_MT9M111 is not set
    # CONFIG_VIDEO_MT9P031 is not set
    # CONFIG_VIDEO_MT9T001 is not set
    # CONFIG_VIDEO_MT9T112 is not set
    # CONFIG_VIDEO_MT9V011 is not set
    # CONFIG_VIDEO_MT9V032 is not set
    # CONFIG_VIDEO_MT9V111 is not set
    # CONFIG_VIDEO_SR030PC30 is not set
    # CONFIG_VIDEO_NOON010PC30 is not set
    # CONFIG_VIDEO_M5MOLS is not set
    # CONFIG_VIDEO_RDACM20 is not set
    # CONFIG_VIDEO_RJ54N1 is not set
    # CONFIG_VIDEO_S5K6AA is not set
    # CONFIG_VIDEO_S5K6A3 is not set
    # CONFIG_VIDEO_S5K4ECGX is not set
    # CONFIG_VIDEO_S5K5BAF is not set
    # CONFIG_VIDEO_SMIAPP is not set
    # CONFIG_VIDEO_ET8EK8 is not set
    # CONFIG_VIDEO_S5C73M3 is not set
    # end of Camera sensor devices
    # Lens drivers
    # CONFIG_VIDEO_AD5820 is not set
    # CONFIG_VIDEO_AK7375 is not set
    # CONFIG_VIDEO_DW9714 is not set
    # CONFIG_VIDEO_DW9768 is not set
    # CONFIG_VIDEO_DW9807_VCM is not set
    # end of Lens drivers
    # Flash devices
    # CONFIG_VIDEO_ADP1653 is not set
    # CONFIG_VIDEO_LM3560 is not set
    # CONFIG_VIDEO_LM3646 is not set
    # end of Flash devices
    # SPI helper chips
    # CONFIG_VIDEO_GS1662 is not set
    # end of SPI helper chips
    # Media SPI Adapters
    CONFIG_CXD2880_SPI_DRV=m
    # end of Media SPI Adapters
    CONFIG_MEDIA_TUNER=y
    # Customize TV tuners
    CONFIG_MEDIA_TUNER_SIMPLE=m
    CONFIG_MEDIA_TUNER_TDA18250=m
    CONFIG_MEDIA_TUNER_TDA8290=m
    CONFIG_MEDIA_TUNER_TDA827X=m
    CONFIG_MEDIA_TUNER_TDA18271=m
    CONFIG_MEDIA_TUNER_TDA9887=m
    CONFIG_MEDIA_TUNER_TEA5761=m
    CONFIG_MEDIA_TUNER_TEA5767=m
    CONFIG_MEDIA_TUNER_MSI001=m
    CONFIG_MEDIA_TUNER_MT20XX=m
    CONFIG_MEDIA_TUNER_MT2060=m
    CONFIG_MEDIA_TUNER_MT2063=m
    CONFIG_MEDIA_TUNER_MT2266=m
    CONFIG_MEDIA_TUNER_MT2131=m
    CONFIG_MEDIA_TUNER_QT1010=m
    CONFIG_MEDIA_TUNER_XC2028=m
    CONFIG_MEDIA_TUNER_XC5000=m
    CONFIG_MEDIA_TUNER_XC4000=m
    CONFIG_MEDIA_TUNER_MXL5005S=m
    CONFIG_MEDIA_TUNER_MXL5007T=m
    CONFIG_MEDIA_TUNER_MC44S803=m
    CONFIG_MEDIA_TUNER_MAX2165=m
    CONFIG_MEDIA_TUNER_TDA18218=m
    CONFIG_MEDIA_TUNER_FC0011=m
    CONFIG_MEDIA_TUNER_FC0012=m
    CONFIG_MEDIA_TUNER_FC0013=m
    CONFIG_MEDIA_TUNER_TDA18212=m
    CONFIG_MEDIA_TUNER_E4000=m
    CONFIG_MEDIA_TUNER_FC2580=m
    CONFIG_MEDIA_TUNER_M88RS6000T=m
    CONFIG_MEDIA_TUNER_TUA9001=m
    CONFIG_MEDIA_TUNER_SI2157=m
    CONFIG_MEDIA_TUNER_IT913X=m
    CONFIG_MEDIA_TUNER_R820T=m
    CONFIG_MEDIA_TUNER_MXL301RF=m
    CONFIG_MEDIA_TUNER_QM1D1C0042=m
    CONFIG_MEDIA_TUNER_QM1D1B0004=m
    # end of Customize TV tuners
    # Customise DVB Frontends
    # Multistandard (satellite) frontends
    CONFIG_DVB_STB0899=m
    CONFIG_DVB_STB6100=m
    CONFIG_DVB_STV090x=m
    CONFIG_DVB_STV0910=m
    CONFIG_DVB_STV6110x=m
    CONFIG_DVB_STV6111=m
    CONFIG_DVB_MXL5XX=m
    CONFIG_DVB_M88DS3103=m
    # Multistandard (cable + terrestrial) frontends
    CONFIG_DVB_DRXK=m
    CONFIG_DVB_TDA18271C2DD=m
    CONFIG_DVB_SI2165=m
    CONFIG_DVB_MN88472=m
    CONFIG_DVB_MN88473=m
    # DVB-S (satellite) frontends
    CONFIG_DVB_CX24110=m
    CONFIG_DVB_CX24123=m
    CONFIG_DVB_MT312=m
    CONFIG_DVB_ZL10036=m
    CONFIG_DVB_ZL10039=m
    CONFIG_DVB_S5H1420=m
    CONFIG_DVB_STV0288=m
    CONFIG_DVB_STB6000=m
    CONFIG_DVB_STV0299=m
    CONFIG_DVB_STV6110=m
    CONFIG_DVB_STV0900=m
    CONFIG_DVB_TDA8083=m
    CONFIG_DVB_TDA10086=m
    CONFIG_DVB_TDA8261=m
    CONFIG_DVB_VES1X93=m
    CONFIG_DVB_TUNER_ITD1000=m
    CONFIG_DVB_TUNER_CX24113=m
    CONFIG_DVB_TDA826X=m
    CONFIG_DVB_TUA6100=m
    CONFIG_DVB_CX24116=m
    CONFIG_DVB_CX24117=m
    CONFIG_DVB_CX24120=m
    CONFIG_DVB_SI21XX=m
    CONFIG_DVB_TS2020=m
    CONFIG_DVB_DS3000=m
    CONFIG_DVB_MB86A16=m
    CONFIG_DVB_TDA10071=m
    # DVB-T (terrestrial) frontends
    CONFIG_DVB_SP8870=m
    CONFIG_DVB_SP887X=m
    CONFIG_DVB_CX22700=m
    CONFIG_DVB_CX22702=m
    CONFIG_DVB_S5H1432=m
    CONFIG_DVB_DRXD=m
    CONFIG_DVB_L64781=m
    CONFIG_DVB_TDA1004X=m
    CONFIG_DVB_NXT6000=m
    CONFIG_DVB_MT352=m
    CONFIG_DVB_ZL10353=m
    CONFIG_DVB_DIB3000MB=m
    CONFIG_DVB_DIB3000MC=m
    CONFIG_DVB_DIB7000M=m
    CONFIG_DVB_DIB7000P=m
    CONFIG_DVB_DIB9000=m
    CONFIG_DVB_TDA10048=m
    CONFIG_DVB_AF9013=m
    CONFIG_DVB_EC100=m
    CONFIG_DVB_STV0367=m
    CONFIG_DVB_CXD2820R=m
    CONFIG_DVB_CXD2841ER=m
    CONFIG_DVB_RTL2830=m
    CONFIG_DVB_RTL2832=m
    CONFIG_DVB_RTL2832_SDR=m
    CONFIG_DVB_SI2168=m
    CONFIG_DVB_ZD1301_DEMOD=m
    CONFIG_DVB_CXD2880=m
    # DVB-C (cable) frontends
    CONFIG_DVB_VES1820=m
    CONFIG_DVB_TDA10021=m
    CONFIG_DVB_TDA10023=m
    CONFIG_DVB_STV0297=m
    # ATSC (North American/Korean Terrestrial/Cable DTV) frontends
    CONFIG_DVB_NXT200X=m
    CONFIG_DVB_OR51211=m
    CONFIG_DVB_OR51132=m
    CONFIG_DVB_BCM3510=m
    CONFIG_DVB_LGDT330X=m
    CONFIG_DVB_LGDT3305=m
    CONFIG_DVB_LGDT3306A=m
    CONFIG_DVB_LG2160=m
    CONFIG_DVB_S5H1409=m
    CONFIG_DVB_AU8522=m
    CONFIG_DVB_AU8522_DTV=m
    CONFIG_DVB_AU8522_V4L=m
    CONFIG_DVB_S5H1411=m
    # ISDB-T (terrestrial) frontends
    CONFIG_DVB_S921=m
    CONFIG_DVB_DIB8000=m
    CONFIG_DVB_MB86A20S=m
    # ISDB-S (satellite) & ISDB-T (terrestrial) frontends
    CONFIG_DVB_TC90522=m
    CONFIG_DVB_MN88443X=m
    # Digital terrestrial only tuners/PLL
    CONFIG_DVB_PLL=m
    CONFIG_DVB_TUNER_DIB0070=m
    CONFIG_DVB_TUNER_DIB0090=m
    # SEC control devices for DVB-S
    CONFIG_DVB_DRX39XYJ=m
    CONFIG_DVB_LNBH25=m
    CONFIG_DVB_LNBH29=m
    CONFIG_DVB_LNBP21=m
    CONFIG_DVB_LNBP22=m
    CONFIG_DVB_ISL6405=m
    CONFIG_DVB_ISL6421=m
    CONFIG_DVB_ISL6423=m
    CONFIG_DVB_A8293=m
    CONFIG_DVB_LGS8GL5=m
    CONFIG_DVB_LGS8GXX=m
    CONFIG_DVB_ATBM8830=m
    CONFIG_DVB_TDA665x=m
    CONFIG_DVB_IX2505V=m
    CONFIG_DVB_M88RS2000=m
    CONFIG_DVB_AF9033=m
    CONFIG_DVB_HORUS3A=m
    CONFIG_DVB_ASCOT2E=m
    CONFIG_DVB_HELENE=m
    # Common Interface (EN50221) controller drivers
    CONFIG_DVB_CXD2099=m
    CONFIG_DVB_SP2=m
    # end of Customise DVB Frontends
    # Tools to develop new frontends
    # CONFIG_DVB_DUMMY_FE is not set
    # end of Media ancillary drivers
    # Graphics support
    # CONFIG_VGA_ARB is not set
    CONFIG_IMX_IPUV3_CORE=m
    CONFIG_DRM=y
    CONFIG_DRM_MIPI_DSI=y
    # CONFIG_DRM_DP_AUX_CHARDEV is not set
    # CONFIG_DRM_DEBUG_MM is not set
    # CONFIG_DRM_DEBUG_SELFTEST is not set
    CONFIG_DRM_KMS_HELPER=y
    CONFIG_DRM_KMS_FB_HELPER=y
    # CONFIG_DRM_DEBUG_DP_MST_TOPOLOGY_REFS is not set
    CONFIG_DRM_FBDEV_EMULATION=y
    CONFIG_DRM_FBDEV_OVERALLOC=100
    # CONFIG_DRM_FBDEV_LEAK_PHYS_SMEM is not set
    # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
    # CONFIG_DRM_DP_CEC is not set
    CONFIG_DRM_GEM_CMA_HELPER=y
    CONFIG_DRM_KMS_CMA_HELPER=y
    CONFIG_DRM_VM=y
    # I2C encoder or helper chips
    # CONFIG_DRM_I2C_CH7006 is not set
    # CONFIG_DRM_I2C_SIL164 is not set
    CONFIG_DRM_I2C_NXP_TDA998X=y
    # CONFIG_DRM_I2C_NXP_TDA9950 is not set
    # end of I2C encoder or helper chips
    # ARM devices
    # CONFIG_DRM_HDLCD is not set
    # CONFIG_DRM_MALI_DISPLAY is not set
    # CONFIG_DRM_KOMEDA is not set
    # end of ARM devices
    # CONFIG_DRM_RADEON is not set
    # CONFIG_DRM_AMDGPU is not set
    # CONFIG_DRM_NOUVEAU is not set
    # CONFIG_DRM_VGEM is not set
    # CONFIG_DRM_VKMS is not set
    # CONFIG_DRM_EXYNOS is not set
    # CONFIG_DRM_UDL is not set
    # CONFIG_DRM_AST is not set
    # CONFIG_DRM_MGAG200 is not set
    # CONFIG_DRM_ARMADA is not set
    # CONFIG_DRM_RCAR_DW_HDMI is not set
    # CONFIG_DRM_RCAR_LVDS is not set
    CONFIG_DRM_OMAP=y
    CONFIG_DRM_OMAP_WB=y
    CONFIG_OMAP2_DSS_INIT=y
    CONFIG_OMAP_DSS_BASE=y
    CONFIG_OMAP2_DSS=y
    # CONFIG_OMAP2_DSS_DEBUG is not set
    CONFIG_OMAP2_DSS_DEBUGFS=y
    # CONFIG_OMAP2_DSS_COLLECT_IRQ_STATS is not set
    CONFIG_OMAP2_DSS_DPI=y
    # CONFIG_OMAP2_DSS_VENC is not set
    CONFIG_OMAP2_DSS_HDMI_COMMON=y
    CONFIG_OMAP4_DSS_HDMI=y
    CONFIG_OMAP4_DSS_HDMI_CEC=y
    CONFIG_OMAP5_DSS_HDMI=y
    # CONFIG_OMAP2_DSS_SDI is not set
    # CONFIG_OMAP2_DSS_DSI is not set
    CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=0
    CONFIG_OMAP2_DSS_SLEEP_AFTER_VENC_RESET=y
    # OMAPDRM External Display Device Drivers
    # CONFIG_DRM_OMAP_PANEL_DSI_CM is not set
    # end of OMAPDRM External Display Device Drivers
    CONFIG_DRM_TILCDC=y
    # CONFIG_DRM_QXL is not set
    # CONFIG_DRM_BOCHS is not set
    # CONFIG_DRM_VIRTIO_GPU is not set
    # CONFIG_DRM_FSL_DCU is not set
    # CONFIG_DRM_STM is not set
    CONFIG_DRM_PANEL=y
    # Display Panels
    # CONFIG_DRM_PANEL_ARM_VERSATILE is not set
    # CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set
    # CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set
    # CONFIG_DRM_PANEL_BOE_TV101WUM_NL6 is not set
    # CONFIG_DRM_PANEL_LVDS is not set
    CONFIG_DRM_PANEL_SIMPLE=y
    # CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set
    # CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set
    # CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
    # CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
    # CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
    # CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
    # CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
    # CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
    # CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set
    # CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
    # CONFIG_DRM_PANEL_LG_LB035Q02 is not set
    # CONFIG_DRM_PANEL_LG_LG4573 is not set
    # CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set
    # CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
    # CONFIG_DRM_PANEL_MANTIX_MLAF057WE51 is not set
    # CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
    # CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
    CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS=y
    # CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
    # CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
    # CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
    # CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
    # CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
    # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
    # CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
    # CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
    # CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
    # CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
    # CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
    # CONFIG_DRM_PANEL_SITRONIX_ST7703 is not set
    # CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
    # CONFIG_DRM_PANEL_SONY_ACX424AKP is not set
    # CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
    # CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
    # CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
    # CONFIG_DRM_PANEL_TPO_TPG110 is not set
    # CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
    # CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set
    # CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set
    # end of Display Panels
    CONFIG_DRM_BRIDGE=y
    CONFIG_DRM_PANEL_BRIDGE=y
    # Display Interface Bridges
    # CONFIG_DRM_CDNS_DSI is not set
    # CONFIG_DRM_CHRONTEL_CH7033 is not set
    CONFIG_DRM_DISPLAY_CONNECTOR=y
    # CONFIG_DRM_LONTIUM_LT9611 is not set
    CONFIG_DRM_LVDS_CODEC=y
    # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
    # CONFIG_DRM_NWL_MIPI_DSI is not set
    # CONFIG_DRM_NXP_PTN3460 is not set
    # CONFIG_DRM_PARADE_PS8622 is not set
    # CONFIG_DRM_PARADE_PS8640 is not set
    # CONFIG_DRM_SIL_SII8620 is not set
    CONFIG_DRM_SII902X=y
    # CONFIG_DRM_SII9234 is not set
    CONFIG_DRM_SIMPLE_BRIDGE=m
    # CONFIG_DRM_THINE_THC63LVD1024 is not set
    # CONFIG_DRM_TOSHIBA_TC358762 is not set
    # CONFIG_DRM_TOSHIBA_TC358764 is not set
    CONFIG_DRM_TOSHIBA_TC358767=y
    CONFIG_DRM_TOSHIBA_TC358768=y
    # CONFIG_DRM_TOSHIBA_TC358775 is not set
    CONFIG_DRM_TI_TFP410=y
    # CONFIG_DRM_TI_SN65DSI86 is not set
    CONFIG_DRM_TI_TPD12S015=y
    # CONFIG_DRM_ANALOGIX_ANX6345 is not set
    # CONFIG_DRM_ANALOGIX_ANX78XX is not set
    # CONFIG_DRM_I2C_ADV7511 is not set
    CONFIG_DRM_CDNS_MHDP8546=m
    CONFIG_DRM_DW_HDMI=m
    # CONFIG_DRM_DW_HDMI_AHB_AUDIO is not set
    # CONFIG_DRM_DW_HDMI_I2S_AUDIO is not set
    # CONFIG_DRM_DW_HDMI_CEC is not set
    # end of Display Interface Bridges
    # CONFIG_DRM_STI is not set
    CONFIG_DRM_IMX=m
    CONFIG_DRM_IMX_PARALLEL_DISPLAY=m
    CONFIG_DRM_IMX_TVE=m
    CONFIG_DRM_IMX_LDB=m
    CONFIG_DRM_IMX_HDMI=m
    # CONFIG_DRM_ETNAVIV is not set
    # CONFIG_DRM_ARCPGU is not set
    # CONFIG_DRM_MXSFB is not set
    # CONFIG_DRM_CIRRUS_QEMU is not set
    # CONFIG_DRM_GM12U320 is not set
    # CONFIG_TINYDRM_HX8357D is not set
    # CONFIG_TINYDRM_ILI9225 is not set
    # CONFIG_TINYDRM_ILI9341 is not set
    # CONFIG_TINYDRM_ILI9486 is not set
    # CONFIG_TINYDRM_MI0283QT is not set
    # CONFIG_TINYDRM_REPAPER is not set
    # CONFIG_TINYDRM_ST7586 is not set
    # CONFIG_TINYDRM_ST7735R is not set
    # CONFIG_DRM_PL111 is not set
    # CONFIG_DRM_TVE200 is not set
    # CONFIG_DRM_LIMA is not set
    # CONFIG_DRM_PANFROST is not set
    # CONFIG_DRM_MCDE is not set
    CONFIG_DRM_TIDSS=y
    CONFIG_DRM_LEGACY=y
    # CONFIG_DRM_TDFX is not set
    # CONFIG_DRM_R128 is not set
    # CONFIG_DRM_MGA is not set
    # CONFIG_DRM_VIA is not set
    # CONFIG_DRM_SAVAGE is not set
    CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
    # Frame buffer Devices
    CONFIG_FB_CMDLINE=y
    CONFIG_FB_NOTIFY=y
    CONFIG_FB=y
    # CONFIG_FIRMWARE_EDID is not set
    CONFIG_FB_CFB_FILLRECT=y
    CONFIG_FB_CFB_COPYAREA=y
    CONFIG_FB_CFB_IMAGEBLIT=y
    CONFIG_FB_SYS_FILLRECT=y
    CONFIG_FB_SYS_COPYAREA=y
    CONFIG_FB_SYS_IMAGEBLIT=y
    # CONFIG_FB_FOREIGN_ENDIAN is not set
    CONFIG_FB_SYS_FOPS=y
    CONFIG_FB_DEFERRED_IO=y
    CONFIG_FB_BACKLIGHT=y
    # CONFIG_FB_MODE_HELPERS is not set
    # CONFIG_FB_TILEBLITTING is not set
    # Frame buffer hardware drivers
    # CONFIG_FB_CIRRUS is not set
    # CONFIG_FB_PM2 is not set
    # CONFIG_FB_CYBER2000 is not set
    # CONFIG_FB_ASILIANT is not set
    # CONFIG_FB_IMSTT is not set
    # CONFIG_FB_EFI is not set
    # CONFIG_FB_OPENCORES is not set
    # CONFIG_FB_S1D13XXX is not set
    # CONFIG_FB_NVIDIA is not set
    # CONFIG_FB_RIVA is not set
    # CONFIG_FB_I740 is not set
    # CONFIG_FB_MATROX is not set
    # CONFIG_FB_RADEON is not set
    # CONFIG_FB_ATY128 is not set
    # CONFIG_FB_ATY is not set
    # CONFIG_FB_S3 is not set
    # CONFIG_FB_SAVAGE is not set
    # CONFIG_FB_SIS is not set
    # CONFIG_FB_NEOMAGIC is not set
    # CONFIG_FB_KYRO is not set
    # CONFIG_FB_3DFX is not set
    # CONFIG_FB_VOODOO1 is not set
    # CONFIG_FB_VT8623 is not set
    # CONFIG_FB_TRIDENT is not set
    # CONFIG_FB_ARK is not set
    # CONFIG_FB_PM3 is not set
    # CONFIG_FB_CARMINE is not set
    # CONFIG_FB_SMSCUFX is not set
    # CONFIG_FB_UDL is not set
    # CONFIG_FB_IBM_GXT4500 is not set
    # CONFIG_FB_DA8XX is not set
    # CONFIG_FB_VIRTUAL is not set
    # CONFIG_FB_METRONOME is not set
    # CONFIG_FB_MB862XX is not set
    # CONFIG_FB_SIMPLE is not set
    CONFIG_FB_SSD1307=y
    # CONFIG_FB_SM712 is not set
    # end of Frame buffer Devices
    # Backlight & LCD device support
    # CONFIG_LCD_CLASS_DEVICE is not set
    CONFIG_BACKLIGHT_CLASS_DEVICE=y
    # CONFIG_BACKLIGHT_KTD253 is not set
    CONFIG_BACKLIGHT_PWM=y
    # CONFIG_BACKLIGHT_QCOM_WLED is not set
    # CONFIG_BACKLIGHT_ADP8860 is not set
    # CONFIG_BACKLIGHT_ADP8870 is not set
    # CONFIG_BACKLIGHT_LM3630A is not set
    # CONFIG_BACKLIGHT_LM3639 is not set
    # CONFIG_BACKLIGHT_LP855X is not set
    # CONFIG_BACKLIGHT_TPS65217 is not set
    CONFIG_BACKLIGHT_GPIO=y
    # CONFIG_BACKLIGHT_LV5207LP is not set
    # CONFIG_BACKLIGHT_BD6107 is not set
    # CONFIG_BACKLIGHT_ARCXCNN is not set
    CONFIG_BACKLIGHT_LED=y
    # end of Backlight & LCD device support
    CONFIG_VIDEOMODE_HELPERS=y
    CONFIG_HDMI=y
    # Console display driver support
    CONFIG_DUMMY_CONSOLE=y
    CONFIG_FRAMEBUFFER_CONSOLE=y
    # CONFIG_FRAMEBUFFER_CONSOLE_LEGACY_ACCELERATION is not set
    CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
    # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
    # CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
    # end of Console display driver support
    # CONFIG_LOGO is not set
    # end of Graphics support
    CONFIG_SOUND=y
    CONFIG_SND=y
    CONFIG_SND_TIMER=y
    CONFIG_SND_PCM=y
    CONFIG_SND_PCM_ELD=y
    CONFIG_SND_PCM_IEC958=y
    CONFIG_SND_DMAENGINE_PCM=y
    CONFIG_SND_HWDEP=m
    CONFIG_SND_RAWMIDI=m
    CONFIG_SND_JACK=y
    CONFIG_SND_JACK_INPUT_DEV=y
    # CONFIG_SND_OSSEMUL is not set
    CONFIG_SND_PCM_TIMER=y
    # CONFIG_SND_HRTIMER is not set
    # CONFIG_SND_DYNAMIC_MINORS is not set
    CONFIG_SND_SUPPORT_OLD_API=y
    CONFIG_SND_PROC_FS=y
    CONFIG_SND_VERBOSE_PROCFS=y
    # CONFIG_SND_VERBOSE_PRINTK is not set
    # CONFIG_SND_DEBUG is not set
    # CONFIG_SND_SEQUENCER is not set
    CONFIG_SND_DRIVERS=y
    # CONFIG_SND_DUMMY is not set
    # CONFIG_SND_ALOOP is not set
    # CONFIG_SND_MTPAV is not set
    # CONFIG_SND_SERIAL_U16550 is not set
    # CONFIG_SND_MPU401 is not set
    CONFIG_SND_PCI=y
    # CONFIG_SND_AD1889 is not set
    # CONFIG_SND_ATIIXP is not set
    # CONFIG_SND_ATIIXP_MODEM is not set
    # CONFIG_SND_AU8810 is not set
    # CONFIG_SND_AU8820 is not set
    # CONFIG_SND_AU8830 is not set
    # CONFIG_SND_AW2 is not set
    # CONFIG_SND_BT87X is not set
    # CONFIG_SND_CA0106 is not set
    # CONFIG_SND_CMIPCI is not set
    # CONFIG_SND_OXYGEN is not set
    # CONFIG_SND_CS4281 is not set
    # CONFIG_SND_CS46XX is not set
    # CONFIG_SND_CTXFI is not set
    # CONFIG_SND_DARLA20 is not set
    # CONFIG_SND_GINA20 is not set
    # CONFIG_SND_LAYLA20 is not set
    # CONFIG_SND_DARLA24 is not set
    # CONFIG_SND_GINA24 is not set
    # CONFIG_SND_LAYLA24 is not set
    # CONFIG_SND_MONA is not set
    # CONFIG_SND_MIA is not set
    # CONFIG_SND_ECHO3G is not set
    # CONFIG_SND_INDIGO is not set
    # CONFIG_SND_INDIGOIO is not set
    # CONFIG_SND_INDIGODJ is not set
    # CONFIG_SND_INDIGOIOX is not set
    # CONFIG_SND_INDIGODJX is not set
    # CONFIG_SND_ENS1370 is not set
    # CONFIG_SND_ENS1371 is not set
    # CONFIG_SND_FM801 is not set
    # CONFIG_SND_HDSP is not set
    # CONFIG_SND_HDSPM is not set
    # CONFIG_SND_ICE1724 is not set
    # CONFIG_SND_INTEL8X0 is not set
    # CONFIG_SND_INTEL8X0M is not set
    # CONFIG_SND_KORG1212 is not set
    # CONFIG_SND_LOLA is not set
    # CONFIG_SND_LX6464ES is not set
    # CONFIG_SND_MIXART is not set
    # CONFIG_SND_NM256 is not set
    # CONFIG_SND_PCXHR is not set
    # CONFIG_SND_RIPTIDE is not set
    # CONFIG_SND_RME32 is not set
    # CONFIG_SND_RME96 is not set
    # CONFIG_SND_RME9652 is not set
    # CONFIG_SND_SE6X is not set
    # CONFIG_SND_VIA82XX is not set
    # CONFIG_SND_VIA82XX_MODEM is not set
    # CONFIG_SND_VIRTUOSO is not set
    # CONFIG_SND_VX222 is not set
    # CONFIG_SND_YMFPCI is not set
    # HD-Audio
    # CONFIG_SND_HDA_INTEL is not set
    # end of HD-Audio
    CONFIG_SND_HDA_PREALLOC_SIZE=64
    # CONFIG_SND_ARM is not set
    # CONFIG_SND_SPI is not set
    CONFIG_SND_USB=y
    CONFIG_SND_USB_AUDIO=m
    CONFIG_SND_USB_AUDIO_USE_MEDIA_CONTROLLER=y
    # CONFIG_SND_USB_UA101 is not set
    # CONFIG_SND_USB_CAIAQ is not set
    # CONFIG_SND_USB_6FIRE is not set
    # CONFIG_SND_USB_HIFACE is not set
    # CONFIG_SND_BCD2000 is not set
    # CONFIG_SND_USB_POD is not set
    # CONFIG_SND_USB_PODHD is not set
    # CONFIG_SND_USB_TONEPORT is not set
    # CONFIG_SND_USB_VARIAX is not set
    CONFIG_SND_SOC=y
    CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
    # CONFIG_SND_SOC_AMD_ACP is not set
    # CONFIG_SND_ATMEL_SOC is not set
    # CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
    # CONFIG_SND_DESIGNWARE_I2S is not set
    # SoC Audio for Freescale CPUs
    # Common SoC Audio options for Freescale CPUs:
    # CONFIG_SND_SOC_FSL_ASRC is not set
    # CONFIG_SND_SOC_FSL_SAI is not set
    # CONFIG_SND_SOC_FSL_AUDMIX is not set
    # CONFIG_SND_SOC_FSL_SSI is not set
    # CONFIG_SND_SOC_FSL_SPDIF is not set
    # CONFIG_SND_SOC_FSL_ESAI is not set
    # CONFIG_SND_SOC_FSL_MICFIL is not set
    # CONFIG_SND_SOC_IMX_AUDMUX is not set
    # end of SoC Audio for Freescale CPUs
    # CONFIG_SND_I2S_HI6210_I2S is not set
    # CONFIG_SND_SOC_IMG is not set
    # CONFIG_SND_SOC_MTK_BTCVSD is not set
    # CONFIG_SND_SOC_SOF_TOPLEVEL is not set
    # STMicroelectronics STM32 SOC audio support
    # end of STMicroelectronics STM32 SOC audio support
    # Audio support for Texas Instruments SoCs
    CONFIG_SND_SOC_TI_EDMA_PCM=y
    CONFIG_SND_SOC_TI_SDMA_PCM=y
    CONFIG_SND_SOC_TI_UDMA_PCM=y
    # Texas Instruments DAI support for:
    CONFIG_SND_SOC_DAVINCI_MCASP=y
    # CONFIG_SND_SOC_OMAP_MCBSP is not set
    # Audio support for boards with Texas Instruments SoCs
    CONFIG_SND_SOC_OMAP_HDMI=m
    # end of Audio support for Texas Instruments SoCs
    # CONFIG_SND_SOC_XILINX_I2S is not set
    # CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
    # CONFIG_SND_SOC_XILINX_SPDIF is not set
    # CONFIG_SND_SOC_XTFPGA_I2S is not set
    # CONFIG_ZX_TDM is not set
    CONFIG_SND_SOC_I2C_AND_SPI=y
    # CODEC drivers
    # CONFIG_SND_SOC_AC97_CODEC is not set
    # CONFIG_SND_SOC_ADAU1701 is not set
    # CONFIG_SND_SOC_ADAU1761_I2C is not set
    # CONFIG_SND_SOC_ADAU1761_SPI is not set
    # CONFIG_SND_SOC_ADAU7002 is not set
    # CONFIG_SND_SOC_ADAU7118_HW is not set
    # CONFIG_SND_SOC_ADAU7118_I2C is not set
    # CONFIG_SND_SOC_AK4104 is not set
    # CONFIG_SND_SOC_AK4118 is not set
    # CONFIG_SND_SOC_AK4458 is not set
    # CONFIG_SND_SOC_AK4554 is not set
    # CONFIG_SND_SOC_AK4613 is not set
    # CONFIG_SND_SOC_AK4642 is not set
    # CONFIG_SND_SOC_AK5386 is not set
    # CONFIG_SND_SOC_AK5558 is not set
    # CONFIG_SND_SOC_ALC5623 is not set
    # CONFIG_SND_SOC_BD28623 is not set
    # CONFIG_SND_SOC_BT_SCO is not set
    # CONFIG_SND_SOC_CPCAP is not set
    # CONFIG_SND_SOC_CS35L32 is not set
    # CONFIG_SND_SOC_CS35L33 is not set
    # CONFIG_SND_SOC_CS35L34 is not set
    # CONFIG_SND_SOC_CS35L35 is not set
    # CONFIG_SND_SOC_CS35L36 is not set
    # CONFIG_SND_SOC_CS42L42 is not set
    CONFIG_SND_SOC_CS42L51=m
    CONFIG_SND_SOC_CS42L51_I2C=m
    # CONFIG_SND_SOC_CS42L52 is not set
    # CONFIG_SND_SOC_CS42L56 is not set
    # CONFIG_SND_SOC_CS42L73 is not set
    # CONFIG_SND_SOC_CS4234 is not set
    # CONFIG_SND_SOC_CS4265 is not set
    # CONFIG_SND_SOC_CS4270 is not set
    # CONFIG_SND_SOC_CS4271_I2C is not set
    # CONFIG_SND_SOC_CS4271_SPI is not set
    # CONFIG_SND_SOC_CS42XX8_I2C is not set
    # CONFIG_SND_SOC_CS43130 is not set
    # CONFIG_SND_SOC_CS4341 is not set
    # CONFIG_SND_SOC_CS4349 is not set
    # CONFIG_SND_SOC_CS53L30 is not set
    # CONFIG_SND_SOC_CX2072X is not set
    # CONFIG_SND_SOC_DA7213 is not set
    # CONFIG_SND_SOC_DMIC is not set
    CONFIG_SND_SOC_HDMI_CODEC=y
    # CONFIG_SND_SOC_ES7134 is not set
    # CONFIG_SND_SOC_ES7241 is not set
    # CONFIG_SND_SOC_ES8316 is not set
    # CONFIG_SND_SOC_ES8328_I2C is not set
    # CONFIG_SND_SOC_ES8328_SPI is not set
    # CONFIG_SND_SOC_GTM601 is not set
    # CONFIG_SND_SOC_INNO_RK3036 is not set
    # CONFIG_SND_SOC_MAX98088 is not set
    # CONFIG_SND_SOC_MAX98357A is not set
    # CONFIG_SND_SOC_MAX98504 is not set
    # CONFIG_SND_SOC_MAX9867 is not set
    # CONFIG_SND_SOC_MAX98927 is not set
    # CONFIG_SND_SOC_MAX98373_I2C is not set
    # CONFIG_SND_SOC_MAX98390 is not set
    # CONFIG_SND_SOC_MAX9860 is not set
    # CONFIG_SND_SOC_MSM8916_WCD_ANALOG is not set
    # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
    # CONFIG_SND_SOC_PCM1681 is not set
    # CONFIG_SND_SOC_PCM1789_I2C is not set
    # CONFIG_SND_SOC_PCM179X_I2C is not set
    # CONFIG_SND_SOC_PCM179X_SPI is not set
    # CONFIG_SND_SOC_PCM186X_I2C is not set
    # CONFIG_SND_SOC_PCM186X_SPI is not set
    # CONFIG_SND_SOC_PCM3060_I2C is not set
    # CONFIG_SND_SOC_PCM3060_SPI is not set
    CONFIG_SND_SOC_PCM3168A=m
    CONFIG_SND_SOC_PCM3168A_I2C=m
    # CONFIG_SND_SOC_PCM3168A_SPI is not set
    # CONFIG_SND_SOC_PCM512x_I2C is not set
    # CONFIG_SND_SOC_PCM512x_SPI is not set
    # CONFIG_SND_SOC_RK3328 is not set
    # CONFIG_SND_SOC_RT5616 is not set
    # CONFIG_SND_SOC_RT5631 is not set
    # CONFIG_SND_SOC_SGTL5000 is not set
    # CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
    # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
    CONFIG_SND_SOC_SPDIF=m
    # CONFIG_SND_SOC_SSM2305 is not set
    # CONFIG_SND_SOC_SSM2602_SPI is not set
    # CONFIG_SND_SOC_SSM2602_I2C is not set
    # CONFIG_SND_SOC_SSM4567 is not set
    # CONFIG_SND_SOC_STA32X is not set
    # CONFIG_SND_SOC_STA350 is not set
    # CONFIG_SND_SOC_STI_SAS is not set
    # CONFIG_SND_SOC_TAS2552 is not set
    # CONFIG_SND_SOC_TAS2562 is not set
    # CONFIG_SND_SOC_TAS2764 is not set
    # CONFIG_SND_SOC_TAS2770 is not set
    # CONFIG_SND_SOC_TAS5086 is not set
    # CONFIG_SND_SOC_TAS571X is not set
    # CONFIG_SND_SOC_TAS5720 is not set
    # CONFIG_SND_SOC_TAS6424 is not set
    # CONFIG_SND_SOC_TDA7419 is not set
    # CONFIG_SND_SOC_TFA9879 is not set
    # CONFIG_SND_SOC_TLV320AIC23_I2C is not set
    # CONFIG_SND_SOC_TLV320AIC23_SPI is not set
    CONFIG_SND_SOC_TLV320AIC31XX=m
    # CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
    # CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
    CONFIG_SND_SOC_TLV320AIC3X=m
    # CONFIG_SND_SOC_TLV320ADCX140 is not set
    # CONFIG_SND_SOC_TS3A227E is not set
    # CONFIG_SND_SOC_TSCS42XX is not set
    # CONFIG_SND_SOC_TSCS454 is not set
    # CONFIG_SND_SOC_UDA1334 is not set
    # CONFIG_SND_SOC_WM8510 is not set
    # CONFIG_SND_SOC_WM8523 is not set
    # CONFIG_SND_SOC_WM8524 is not set
    # CONFIG_SND_SOC_WM8580 is not set
    # CONFIG_SND_SOC_WM8711 is not set
    # CONFIG_SND_SOC_WM8728 is not set
    # CONFIG_SND_SOC_WM8731 is not set
    # CONFIG_SND_SOC_WM8737 is not set
    # CONFIG_SND_SOC_WM8741 is not set
    # CONFIG_SND_SOC_WM8750 is not set
    # CONFIG_SND_SOC_WM8753 is not set
    # CONFIG_SND_SOC_WM8770 is not set
    # CONFIG_SND_SOC_WM8776 is not set
    # CONFIG_SND_SOC_WM8782 is not set
    # CONFIG_SND_SOC_WM8804_I2C is not set
    # CONFIG_SND_SOC_WM8804_SPI is not set
    # CONFIG_SND_SOC_WM8903 is not set
    # CONFIG_SND_SOC_WM8904 is not set
    # CONFIG_SND_SOC_WM8960 is not set
    # CONFIG_SND_SOC_WM8962 is not set
    # CONFIG_SND_SOC_WM8974 is not set
    # CONFIG_SND_SOC_WM8978 is not set
    # CONFIG_SND_SOC_WM8985 is not set
    # CONFIG_SND_SOC_ZL38060 is not set
    # CONFIG_SND_SOC_ZX_AUD96P22 is not set
    # CONFIG_SND_SOC_MAX9759 is not set
    # CONFIG_SND_SOC_MT6351 is not set
    # CONFIG_SND_SOC_MT6358 is not set
    # CONFIG_SND_SOC_MT6660 is not set
    # CONFIG_SND_SOC_NAU8540 is not set
    # CONFIG_SND_SOC_NAU8810 is not set
    # CONFIG_SND_SOC_NAU8822 is not set
    # CONFIG_SND_SOC_NAU8824 is not set
    # CONFIG_SND_SOC_TPA6130A2 is not set
    # end of CODEC drivers
    CONFIG_SND_SIMPLE_CARD_UTILS=m
    CONFIG_SND_SIMPLE_CARD=m
    CONFIG_SND_AUDIO_GRAPH_CARD=m
    # HID support
    CONFIG_HID=y
    # CONFIG_HID_BATTERY_STRENGTH is not set
    # CONFIG_HIDRAW is not set
    # CONFIG_UHID is not set
    CONFIG_HID_GENERIC=y
    # Special HID drivers
    # CONFIG_HID_A4TECH is not set
    # CONFIG_HID_ACCUTOUCH is not set
    # CONFIG_HID_ACRUX is not set
    # CONFIG_HID_APPLE is not set
    # CONFIG_HID_APPLEIR is not set
    # CONFIG_HID_ASUS is not set
    # CONFIG_HID_AUREAL is not set
    # CONFIG_HID_BELKIN is not set
    # CONFIG_HID_BETOP_FF is not set
    # CONFIG_HID_BIGBEN_FF is not set
    # CONFIG_HID_CHERRY is not set
    # CONFIG_HID_CHICONY is not set
    # CONFIG_HID_CORSAIR is not set
    # CONFIG_HID_COUGAR is not set
    # CONFIG_HID_MACALLY is not set
    # CONFIG_HID_PRODIKEYS is not set
    # CONFIG_HID_CMEDIA is not set
    # CONFIG_HID_CREATIVE_SB0540 is not set
    # CONFIG_HID_CYPRESS is not set
    # CONFIG_HID_DRAGONRISE is not set
    # CONFIG_HID_EMS_FF is not set
    # CONFIG_HID_ELAN is not set
    # CONFIG_HID_ELECOM is not set
    # CONFIG_HID_ELO is not set
    # CONFIG_HID_EZKEY is not set
    # CONFIG_HID_GEMBIRD is not set
    # CONFIG_HID_GFRM is not set
    # CONFIG_HID_GLORIOUS is not set
    # CONFIG_HID_HOLTEK is not set
    # CONFIG_HID_VIVALDI is not set
    # CONFIG_HID_GT683R is not set
    # CONFIG_HID_KEYTOUCH is not set
    # CONFIG_HID_KYE is not set
    # CONFIG_HID_UCLOGIC is not set
    # CONFIG_HID_WALTOP is not set
    # CONFIG_HID_VIEWSONIC is not set
    # CONFIG_HID_GYRATION is not set
    # CONFIG_HID_ICADE is not set
    # CONFIG_HID_ITE is not set
    # CONFIG_HID_JABRA is not set
    # CONFIG_HID_TWINHAN is not set
    # CONFIG_HID_KENSINGTON is not set
    # CONFIG_HID_LCPOWER is not set
    # CONFIG_HID_LED is not set
    # CONFIG_HID_LENOVO is not set
    # CONFIG_HID_LOGITECH is not set
    # CONFIG_HID_MAGICMOUSE is not set
    # CONFIG_HID_MALTRON is not set
    # CONFIG_HID_MAYFLASH is not set
    # CONFIG_HID_REDRAGON is not set
    # CONFIG_HID_MICROSOFT is not set
    # CONFIG_HID_MONTEREY is not set
    CONFIG_HID_MULTITOUCH=m
    # CONFIG_HID_NTI is not set
    # CONFIG_HID_NTRIG is not set
    # CONFIG_HID_ORTEK is not set
    # CONFIG_HID_PANTHERLORD is not set
    # CONFIG_HID_PENMOUNT is not set
    # CONFIG_HID_PETALYNX is not set
    # CONFIG_HID_PICOLCD is not set
    # CONFIG_HID_PLANTRONICS is not set
    # CONFIG_HID_PRIMAX is not set
    # CONFIG_HID_RETRODE is not set
    # CONFIG_HID_ROCCAT is not set
    # CONFIG_HID_SAITEK is not set
    # CONFIG_HID_SAMSUNG is not set
    # CONFIG_HID_SONY is not set
    # CONFIG_HID_SPEEDLINK is not set
    # CONFIG_HID_STEAM is not set
    # CONFIG_HID_STEELSERIES is not set
    # CONFIG_HID_SUNPLUS is not set
    # CONFIG_HID_RMI is not set
    # CONFIG_HID_GREENASIA is not set
    # CONFIG_HID_SMARTJOYPLUS is not set
    # CONFIG_HID_TIVO is not set
    # CONFIG_HID_TOPSEED is not set
    # CONFIG_HID_THINGM is not set
    # CONFIG_HID_THRUSTMASTER is not set
    # CONFIG_HID_UDRAW_PS3 is not set
    # CONFIG_HID_U2FZERO is not set
    # CONFIG_HID_WACOM is not set
    # CONFIG_HID_WIIMOTE is not set
    # CONFIG_HID_XINMO is not set
    # CONFIG_HID_ZEROPLUS is not set
    # CONFIG_HID_ZYDACRON is not set
    # CONFIG_HID_SENSOR_HUB is not set
    # CONFIG_HID_ALPS is not set
    # CONFIG_HID_MCP2221 is not set
    # end of Special HID drivers
    # USB HID support
    CONFIG_USB_HID=m
    # CONFIG_HID_PID is not set
    # CONFIG_USB_HIDDEV is not set
    # USB HID Boot Protocol drivers
    # CONFIG_USB_KBD is not set
    # CONFIG_USB_MOUSE is not set
    # end of USB HID Boot Protocol drivers
    # end of USB HID support
    # I2C HID support
    # CONFIG_I2C_HID is not set
    # end of I2C HID support
    # end of HID support
    CONFIG_USB_OHCI_LITTLE_ENDIAN=y
    CONFIG_USB_SUPPORT=y
    CONFIG_USB_COMMON=m
    # CONFIG_USB_LED_TRIG is not set
    # CONFIG_USB_ULPI_BUS is not set
    # CONFIG_USB_CONN_GPIO is not set
    CONFIG_USB_ARCH_HAS_HCD=y
    CONFIG_USB=m
    CONFIG_USB_PCI=y
    CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
    # Miscellaneous USB options
    CONFIG_USB_DEFAULT_PERSIST=y
    # CONFIG_USB_FEW_INIT_RETRIES is not set
    # CONFIG_USB_DYNAMIC_MINORS is not set
    CONFIG_USB_OTG=y
    # CONFIG_USB_OTG_PRODUCTLIST is not set
    # CONFIG_USB_OTG_DISABLE_EXTERNAL_HUB is not set
    # CONFIG_USB_OTG_FSM is not set
    # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
    CONFIG_USB_AUTOSUSPEND_DELAY=2
    # CONFIG_USB_MON is not set
    # USB Host Controller Drivers
    # CONFIG_USB_C67X00_HCD is not set
    CONFIG_USB_XHCI_HCD=m
    # CONFIG_USB_XHCI_DBGCAP is not set
    CONFIG_USB_XHCI_PCI=m
    # CONFIG_USB_XHCI_PCI_RENESAS is not set
    CONFIG_USB_XHCI_PLATFORM=m
    CONFIG_USB_EHCI_HCD=m
    # CONFIG_USB_EHCI_ROOT_HUB_TT is not set
    CONFIG_USB_EHCI_TT_NEWSCHED=y
    CONFIG_USB_EHCI_PCI=m
    # CONFIG_USB_EHCI_FSL is not set
    CONFIG_USB_EHCI_HCD_OMAP=m
    # CONFIG_USB_EHCI_HCD_PLATFORM is not set
    # CONFIG_USB_OXU210HP_HCD is not set
    # CONFIG_USB_ISP116X_HCD is not set
    # CONFIG_USB_FOTG210_HCD is not set
    # CONFIG_USB_MAX3421_HCD is not set
    CONFIG_USB_OHCI_HCD=m
    CONFIG_USB_OHCI_HCD_PCI=m
    # CONFIG_USB_OHCI_HCD_SSB is not set
    # CONFIG_USB_OHCI_HCD_PLATFORM is not set
    # CONFIG_USB_UHCI_HCD is not set
    # CONFIG_USB_SL811_HCD is not set
    CONFIG_USB_R8A66597_HCD=m
    # CONFIG_USB_HCD_BCMA is not set
    # CONFIG_USB_HCD_SSB is not set
    # CONFIG_USB_HCD_TEST_MODE is not set
    # USB Device Class drivers
    CONFIG_USB_ACM=m
    # CONFIG_USB_PRINTER is not set
    # CONFIG_USB_WDM is not set
    # CONFIG_USB_TMC is not set
    # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
    # also be needed; see USB_STORAGE Help for more info
    CONFIG_USB_STORAGE=m
    # CONFIG_USB_STORAGE_DEBUG is not set
    # CONFIG_USB_STORAGE_REALTEK is not set
    # CONFIG_USB_STORAGE_DATAFAB is not set
    # CONFIG_USB_STORAGE_FREECOM is not set
    # CONFIG_USB_STORAGE_ISD200 is not set
    # CONFIG_USB_STORAGE_USBAT is not set
    # CONFIG_USB_STORAGE_SDDR09 is not set
    # CONFIG_USB_STORAGE_SDDR55 is not set
    # CONFIG_USB_STORAGE_JUMPSHOT is not set
    # CONFIG_USB_STORAGE_ALAUDA is not set
    # CONFIG_USB_STORAGE_ONETOUCH is not set
    # CONFIG_USB_STORAGE_KARMA is not set
    # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
    # CONFIG_USB_STORAGE_ENE_UB6250 is not set
    CONFIG_USB_UAS=m
    # USB Imaging devices
    # CONFIG_USB_MDC800 is not set
    # CONFIG_USB_MICROTEK is not set
    # CONFIG_USBIP_CORE is not set
    CONFIG_USB_CDNS3=m
    CONFIG_USB_CDNS3_GADGET=y
    CONFIG_USB_CDNS3_HOST=y
    CONFIG_USB_MUSB_HDRC=m
    # CONFIG_USB_MUSB_HOST is not set
    # CONFIG_USB_MUSB_GADGET is not set
    CONFIG_USB_MUSB_DUAL_ROLE=y
    # Platform Glue Layer
    CONFIG_USB_MUSB_TUSB6010=m
    CONFIG_USB_MUSB_OMAP2PLUS=m
    CONFIG_USB_MUSB_AM35X=m
    CONFIG_USB_MUSB_DSPS=m
    # MUSB DMA mode
    # CONFIG_MUSB_PIO_ONLY is not set
    CONFIG_USB_INVENTRA_DMA=y
    CONFIG_USB_TI_CPPI41_DMA=y
    CONFIG_USB_TUSB_OMAP_DMA=y
    CONFIG_USB_DWC3=m
    # CONFIG_USB_DWC3_HOST is not set
    # CONFIG_USB_DWC3_GADGET is not set
    CONFIG_USB_DWC3_DUAL_ROLE=y
    # Platform Glue Driver Support
    CONFIG_USB_DWC3_OMAP=m
    CONFIG_USB_DWC3_HAPS=m
    CONFIG_USB_DWC3_OF_SIMPLE=m
    # CONFIG_USB_DWC2 is not set
    # CONFIG_USB_CHIPIDEA is not set
    CONFIG_USB_ISP1760=m
    CONFIG_USB_ISP1760_HCD=y
    CONFIG_USB_ISP1761_UDC=y
    # CONFIG_USB_ISP1760_HOST_ROLE is not set
    # CONFIG_USB_ISP1760_GADGET_ROLE is not set
    CONFIG_USB_ISP1760_DUAL_ROLE=y
    # USB port drivers
    CONFIG_USB_SERIAL=m
    # CONFIG_USB_SERIAL_GENERIC is not set
    # CONFIG_USB_SERIAL_SIMPLE is not set
    # CONFIG_USB_SERIAL_AIRCABLE is not set
    # CONFIG_USB_SERIAL_ARK3116 is not set
    # CONFIG_USB_SERIAL_BELKIN is not set
    # CONFIG_USB_SERIAL_CH341 is not set
    # CONFIG_USB_SERIAL_WHITEHEAT is not set
    # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
    CONFIG_USB_SERIAL_CP210X=m
    # CONFIG_USB_SERIAL_CYPRESS_M8 is not set
    # CONFIG_USB_SERIAL_EMPEG is not set
    CONFIG_USB_SERIAL_FTDI_SIO=m
    # CONFIG_USB_SERIAL_VISOR is not set
    # CONFIG_USB_SERIAL_IPAQ is not set
    # CONFIG_USB_SERIAL_IR is not set
    # CONFIG_USB_SERIAL_EDGEPORT is not set
    # CONFIG_USB_SERIAL_EDGEPORT_TI is not set
    # CONFIG_USB_SERIAL_F81232 is not set
    # CONFIG_USB_SERIAL_F8153X is not set
    # CONFIG_USB_SERIAL_GARMIN is not set
    # CONFIG_USB_SERIAL_IPW is not set
    # CONFIG_USB_SERIAL_IUU is not set
    # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
    # CONFIG_USB_SERIAL_KEYSPAN is not set
    # CONFIG_USB_SERIAL_KLSI is not set
    # CONFIG_USB_SERIAL_KOBIL_SCT is not set
    # CONFIG_USB_SERIAL_MCT_U232 is not set
    # CONFIG_USB_SERIAL_METRO is not set
    # CONFIG_USB_SERIAL_MOS7720 is not set
    # CONFIG_USB_SERIAL_MOS7840 is not set
    # CONFIG_USB_SERIAL_MXUPORT is not set
    # CONFIG_USB_SERIAL_NAVMAN is not set
    CONFIG_USB_SERIAL_PL2303=m
    # CONFIG_USB_SERIAL_OTI6858 is not set
    # CONFIG_USB_SERIAL_QCAUX is not set
    # CONFIG_USB_SERIAL_QUALCOMM is not set
    # CONFIG_USB_SERIAL_SPCP8X5 is not set
    # CONFIG_USB_SERIAL_SAFE is not set
    # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
    # CONFIG_USB_SERIAL_SYMBOL is not set
    # CONFIG_USB_SERIAL_TI is not set
    # CONFIG_USB_SERIAL_CYBERJACK is not set
    # CONFIG_USB_SERIAL_XIRCOM is not set
    CONFIG_USB_SERIAL_WWAN=m
    CONFIG_USB_SERIAL_OPTION=m
    # CONFIG_USB_SERIAL_OMNINET is not set
    # CONFIG_USB_SERIAL_OPTICON is not set
    # CONFIG_USB_SERIAL_XSENS_MT is not set
    # CONFIG_USB_SERIAL_WISHBONE is not set
    # CONFIG_USB_SERIAL_SSU100 is not set
    # CONFIG_USB_SERIAL_QT2 is not set
    # CONFIG_USB_SERIAL_UPD78F0730 is not set
    # CONFIG_USB_SERIAL_DEBUG is not set
    # USB Miscellaneous drivers
    # CONFIG_USB_EMI62 is not set
    # CONFIG_USB_EMI26 is not set
    # CONFIG_USB_ADUTUX is not set
    # CONFIG_USB_SEVSEG is not set
    # CONFIG_USB_LEGOTOWER is not set
    # CONFIG_USB_LCD is not set
    # CONFIG_USB_CYPRESS_CY7C63 is not set
    # CONFIG_USB_CYTHERM is not set
    # CONFIG_USB_IDMOUSE is not set
    # CONFIG_USB_FTDI_ELAN is not set
    # CONFIG_USB_APPLEDISPLAY is not set
    # CONFIG_APPLE_MFI_FASTCHARGE is not set
    # CONFIG_USB_SISUSBVGA is not set
    # CONFIG_USB_LD is not set
    # CONFIG_USB_TRANCEVIBRATOR is not set
    # CONFIG_USB_IOWARRIOR is not set
    CONFIG_USB_TEST=m
    # CONFIG_USB_EHSET_TEST_FIXTURE is not set
    # CONFIG_USB_ISIGHTFW is not set
    # CONFIG_USB_YUREX is not set
    # CONFIG_USB_EZUSB_FX2 is not set
    # CONFIG_USB_HUB_USB251XB is not set
    CONFIG_USB_HSIC_USB3503=m
    # CONFIG_USB_HSIC_USB4604 is not set
    # CONFIG_USB_LINK_LAYER_TEST is not set
    # CONFIG_USB_CHAOSKEY is not set
    # USB Physical Layer drivers
    CONFIG_USB_PHY=y
    CONFIG_NOP_USB_XCEIV=m
    CONFIG_AM335X_CONTROL_USB=m
    CONFIG_AM335X_PHY_USB=m
    CONFIG_USB_GPIO_VBUS=m
    CONFIG_USB_ISP1301=m
    # CONFIG_USB_ULPI is not set
    # end of USB Physical Layer drivers
    CONFIG_USB_GADGET=m
    # CONFIG_USB_GADGET_DEBUG is not set
    # CONFIG_USB_GADGET_DEBUG_FILES is not set
    # CONFIG_USB_GADGET_DEBUG_FS is not set
    CONFIG_USB_GADGET_VBUS_DRAW=2
    CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=32
    # CONFIG_U_SERIAL_CONSOLE is not set
    # USB Peripheral Controller
    # CONFIG_USB_FUSB300 is not set
    # CONFIG_USB_FOTG210_UDC is not set
    # CONFIG_USB_GR_UDC is not set
    # CONFIG_USB_R8A66597 is not set
    # CONFIG_USB_PXA27X is not set
    # CONFIG_USB_MV_UDC is not set
    # CONFIG_USB_MV_U3D is not set
    # CONFIG_USB_SNP_UDC_PLAT is not set
    # CONFIG_USB_M66592 is not set
    # CONFIG_USB_BDC_UDC is not set
    # CONFIG_USB_AMD5536UDC is not set
    # CONFIG_USB_NET2272 is not set
    # CONFIG_USB_NET2280 is not set
    # CONFIG_USB_GOKU is not set
    # CONFIG_USB_EG20T is not set
    # CONFIG_USB_GADGET_XILINX is not set
    # CONFIG_USB_MAX3420_UDC is not set
    # CONFIG_USB_DUMMY_HCD is not set
    # end of USB Peripheral Controller
    CONFIG_USB_LIBCOMPOSITE=m
    CONFIG_USB_F_ACM=m
    CONFIG_USB_F_SS_LB=m
    CONFIG_USB_U_SERIAL=m
    CONFIG_USB_U_ETHER=m
    CONFIG_USB_U_AUDIO=m
    CONFIG_USB_F_SERIAL=m
    CONFIG_USB_F_OBEX=m
    CONFIG_USB_F_NCM=m
    CONFIG_USB_F_ECM=m
    CONFIG_USB_F_EEM=m
    CONFIG_USB_F_SUBSET=m
    CONFIG_USB_F_RNDIS=m
    CONFIG_USB_F_MASS_STORAGE=m
    CONFIG_USB_F_FS=m
    CONFIG_USB_F_UAC1=m
    CONFIG_USB_F_UAC1_LEGACY=m
    CONFIG_USB_F_UAC2=m
    CONFIG_USB_F_UVC=m
    CONFIG_USB_F_MIDI=m
    CONFIG_USB_F_HID=m
    CONFIG_USB_F_PRINTER=m
    CONFIG_USB_CONFIGFS=m
    CONFIG_USB_CONFIGFS_SERIAL=y
    CONFIG_USB_CONFIGFS_ACM=y
    CONFIG_USB_CONFIGFS_OBEX=y
    CONFIG_USB_CONFIGFS_NCM=y
    CONFIG_USB_CONFIGFS_ECM=y
    CONFIG_USB_CONFIGFS_ECM_SUBSET=y
    CONFIG_USB_CONFIGFS_RNDIS=y
    CONFIG_USB_CONFIGFS_EEM=y
    CONFIG_USB_CONFIGFS_MASS_STORAGE=y
    CONFIG_USB_CONFIGFS_F_LB_SS=y
    CONFIG_USB_CONFIGFS_F_FS=y
    CONFIG_USB_CONFIGFS_F_UAC1=y
    CONFIG_USB_CONFIGFS_F_UAC1_LEGACY=y
    CONFIG_USB_CONFIGFS_F_UAC2=y
    CONFIG_USB_CONFIGFS_F_MIDI=y
    CONFIG_USB_CONFIGFS_F_HID=y
    CONFIG_USB_CONFIGFS_F_UVC=y
    CONFIG_USB_CONFIGFS_F_PRINTER=y
    # USB Gadget precomposed configurations
    CONFIG_USB_ZERO=m
    # CONFIG_USB_ZERO_HNPTEST is not set
    CONFIG_USB_AUDIO=m
    # CONFIG_GADGET_UAC1 is not set
    CONFIG_USB_ETH=m
    CONFIG_USB_ETH_RNDIS=y
    # CONFIG_USB_ETH_EEM is not set
    CONFIG_USB_G_NCM=m
    CONFIG_USB_GADGETFS=m
    CONFIG_USB_FUNCTIONFS=m
    CONFIG_USB_FUNCTIONFS_ETH=y
    CONFIG_USB_FUNCTIONFS_RNDIS=y
    CONFIG_USB_FUNCTIONFS_GENERIC=y
    CONFIG_USB_MASS_STORAGE=m
    CONFIG_USB_G_SERIAL=m
    CONFIG_USB_MIDI_GADGET=m
    CONFIG_USB_G_PRINTER=m
    CONFIG_USB_CDC_COMPOSITE=m
    CONFIG_USB_G_ACM_MS=m
    CONFIG_USB_G_MULTI=m
    CONFIG_USB_G_MULTI_RNDIS=y
    CONFIG_USB_G_MULTI_CDC=y
    CONFIG_USB_G_HID=m
    CONFIG_USB_G_DBGP=m
    # CONFIG_USB_G_DBGP_PRINTK is not set
    CONFIG_USB_G_DBGP_SERIAL=y
    CONFIG_USB_G_WEBCAM=m
    # CONFIG_USB_RAW_GADGET is not set
    # end of USB Gadget precomposed configurations
    # CONFIG_TYPEC is not set
    CONFIG_USB_ROLE_SWITCH=m
    CONFIG_MMC=y
    CONFIG_PWRSEQ_EMMC=y
    # CONFIG_PWRSEQ_SD8787 is not set
    CONFIG_PWRSEQ_SIMPLE=y
    CONFIG_MMC_BLOCK=y
    CONFIG_MMC_BLOCK_MINORS=16
    # CONFIG_SDIO_UART is not set
    # CONFIG_MMC_TEST is not set
    # MMC/SD/SDIO Host Controller Drivers
    # CONFIG_MMC_DEBUG is not set
    CONFIG_MMC_SDHCI=y
    CONFIG_MMC_SDHCI_IO_ACCESSORS=y
    # CONFIG_MMC_SDHCI_PCI is not set
    CONFIG_MMC_SDHCI_PLTFM=y
    CONFIG_MMC_SDHCI_OF_ARASAN=y
    # CONFIG_MMC_SDHCI_OF_ASPEED is not set
    CONFIG_MMC_SDHCI_OF_AT91=y
    # CONFIG_MMC_SDHCI_OF_DWCMSHC is not set
    # CONFIG_MMC_SDHCI_CADENCE is not set
    # CONFIG_MMC_SDHCI_F_SDH30 is not set
    # CONFIG_MMC_SDHCI_MILBEAUT is not set
    CONFIG_MMC_OMAP=y
    CONFIG_MMC_OMAP_HS=y
    # CONFIG_MMC_TIFM_SD is not set
    # CONFIG_MMC_SPI is not set
    # CONFIG_MMC_CB710 is not set
    # CONFIG_MMC_VIA_SDMMC is not set
    # CONFIG_MMC_DW is not set
    # CONFIG_MMC_VUB300 is not set
    # CONFIG_MMC_USHC is not set
    # CONFIG_MMC_USDHI6ROL0 is not set
    CONFIG_MMC_CQHCI=y
    # CONFIG_MMC_HSQ is not set
    # CONFIG_MMC_TOSHIBA_PCI is not set
    # CONFIG_MMC_MTK is not set
    # CONFIG_MMC_SDHCI_XENON is not set
    CONFIG_MMC_SDHCI_OMAP=y
    CONFIG_MMC_SDHCI_AM654=y
    CONFIG_MMC_SDHCI_EXTERNAL_DMA=y
    # CONFIG_MEMSTICK is not set
    CONFIG_NEW_LEDS=y
    CONFIG_LEDS_CLASS=y
    CONFIG_LEDS_CLASS_FLASH=m
    # CONFIG_LEDS_CLASS_MULTICOLOR is not set
    # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
    # LED drivers
    # CONFIG_LEDS_AAT1290 is not set
    # CONFIG_LEDS_AN30259A is not set
    # CONFIG_LEDS_AS3645A is not set
    # CONFIG_LEDS_AW2013 is not set
    # CONFIG_LEDS_BCM6328 is not set
    # CONFIG_LEDS_BCM6358 is not set
    CONFIG_LEDS_CPCAP=m
    # CONFIG_LEDS_CR0014114 is not set
    # CONFIG_LEDS_EL15203000 is not set
    # CONFIG_LEDS_LM3530 is not set
    # CONFIG_LEDS_LM3532 is not set
    # CONFIG_LEDS_LM3642 is not set
    # CONFIG_LEDS_LM3692X is not set
    # CONFIG_LEDS_LM3601X is not set
    # CONFIG_LEDS_PCA9532 is not set
    CONFIG_LEDS_GPIO=y
    # CONFIG_LEDS_LP3944 is not set
    # CONFIG_LEDS_LP3952 is not set
    # CONFIG_LEDS_LP50XX is not set
    # CONFIG_LEDS_LP55XX_COMMON is not set
    # CONFIG_LEDS_LP8860 is not set
    # CONFIG_LEDS_PCA955X is not set
    # CONFIG_LEDS_PCA963X is not set
    # CONFIG_LEDS_DAC124S085 is not set
    CONFIG_LEDS_PWM=y
    # CONFIG_LEDS_REGULATOR is not set
    # CONFIG_LEDS_BD2802 is not set
    # CONFIG_LEDS_LT3593 is not set
    # CONFIG_LEDS_TCA6507 is not set
    CONFIG_LEDS_TLC591XX=y
    # CONFIG_LEDS_LM355x is not set
    # CONFIG_LEDS_KTD2692 is not set
    # CONFIG_LEDS_IS31FL319X is not set
    # CONFIG_LEDS_IS31FL32XX is not set
    # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
    # CONFIG_LEDS_BLINKM is not set
    # CONFIG_LEDS_SYSCON is not set
    # CONFIG_LEDS_MLXREG is not set
    # CONFIG_LEDS_USER is not set
    # CONFIG_LEDS_SPI_BYTE is not set
    # CONFIG_LEDS_TI_LMU_COMMON is not set
    # CONFIG_LEDS_SGM3140 is not set
    # LED Triggers
    CONFIG_LEDS_TRIGGERS=y
    CONFIG_LEDS_TRIGGER_TIMER=y
    CONFIG_LEDS_TRIGGER_ONESHOT=y
    # CONFIG_LEDS_TRIGGER_DISK is not set
    # CONFIG_LEDS_TRIGGER_MTD is not set
    CONFIG_LEDS_TRIGGER_HEARTBEAT=y
    CONFIG_LEDS_TRIGGER_BACKLIGHT=y
    CONFIG_LEDS_TRIGGER_CPU=y
    # CONFIG_LEDS_TRIGGER_ACTIVITY is not set
    CONFIG_LEDS_TRIGGER_GPIO=y
    CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
    # iptables trigger is under Netfilter config (LED target)
    CONFIG_LEDS_TRIGGER_TRANSIENT=y
    CONFIG_LEDS_TRIGGER_CAMERA=y
    # CONFIG_LEDS_TRIGGER_PANIC is not set
    # CONFIG_LEDS_TRIGGER_NETDEV is not set
    # CONFIG_LEDS_TRIGGER_PATTERN is not set
    # CONFIG_LEDS_TRIGGER_AUDIO is not set
    # CONFIG_ACCESSIBILITY is not set
    # CONFIG_INFINIBAND is not set
    CONFIG_EDAC_ATOMIC_SCRUB=y
    CONFIG_EDAC_SUPPORT=y
    CONFIG_EDAC=y
    CONFIG_EDAC_LEGACY_SYSFS=y
    # CONFIG_EDAC_DEBUG is not set
    CONFIG_RTC_LIB=y
    CONFIG_RTC_CLASS=y
    CONFIG_RTC_HCTOSYS=y
    CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
    CONFIG_RTC_SYSTOHC=y
    CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
    CONFIG_RTC_DEBUG=y
    CONFIG_RTC_NVMEM=y
    # RTC interfaces
    CONFIG_RTC_INTF_SYSFS=y
    CONFIG_RTC_INTF_PROC=y
    CONFIG_RTC_INTF_DEV=y
    # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
    # CONFIG_RTC_DRV_TEST is not set
    # I2C RTC drivers
    # CONFIG_RTC_DRV_ABB5ZES3 is not set
    # CONFIG_RTC_DRV_ABEOZ9 is not set
    # CONFIG_RTC_DRV_ABX80X is not set
    CONFIG_RTC_DRV_DS1307=m
    # CONFIG_RTC_DRV_DS1307_CENTURY is not set
    # CONFIG_RTC_DRV_DS1374 is not set
    # CONFIG_RTC_DRV_DS1672 is not set
    # CONFIG_RTC_DRV_HYM8563 is not set
    # CONFIG_RTC_DRV_MAX6900 is not set
    # CONFIG_RTC_DRV_RS5C372 is not set
    # CONFIG_RTC_DRV_ISL1208 is not set
    # CONFIG_RTC_DRV_ISL12022 is not set
    # CONFIG_RTC_DRV_ISL12026 is not set
    # CONFIG_RTC_DRV_X1205 is not set
    # CONFIG_RTC_DRV_PCF8523 is not set
    # CONFIG_RTC_DRV_PCF85063 is not set
    CONFIG_RTC_DRV_PCF85363=m
    # CONFIG_RTC_DRV_PCF8563 is not set
    # CONFIG_RTC_DRV_PCF8583 is not set
    # CONFIG_RTC_DRV_M41T80 is not set
    # CONFIG_RTC_DRV_BQ32K is not set
    CONFIG_RTC_DRV_PALMAS=m
    CONFIG_RTC_DRV_TPS6586X=m
    CONFIG_RTC_DRV_TPS65910=m
    # CONFIG_RTC_DRV_S35390A is not set
    # CONFIG_RTC_DRV_FM3130 is not set
    # CONFIG_RTC_DRV_RX8010 is not set
    # CONFIG_RTC_DRV_RX8581 is not set
    # CONFIG_RTC_DRV_RX8025 is not set
    # CONFIG_RTC_DRV_EM3027 is not set
    # CONFIG_RTC_DRV_RV3028 is not set
    # CONFIG_RTC_DRV_RV3032 is not set
    # CONFIG_RTC_DRV_RV8803 is not set
    # CONFIG_RTC_DRV_SD3078 is not set
    # SPI RTC drivers
    # CONFIG_RTC_DRV_M41T93 is not set
    # CONFIG_RTC_DRV_M41T94 is not set
    # CONFIG_RTC_DRV_DS1302 is not set
    # CONFIG_RTC_DRV_DS1305 is not set
    # CONFIG_RTC_DRV_DS1343 is not set
    # CONFIG_RTC_DRV_DS1347 is not set
    # CONFIG_RTC_DRV_DS1390 is not set
    # CONFIG_RTC_DRV_MAX6916 is not set
    # CONFIG_RTC_DRV_R9701 is not set
    # CONFIG_RTC_DRV_RX4581 is not set
    # CONFIG_RTC_DRV_RX6110 is not set
    # CONFIG_RTC_DRV_RS5C348 is not set
    # CONFIG_RTC_DRV_MAX6902 is not set
    # CONFIG_RTC_DRV_PCF2123 is not set
    # CONFIG_RTC_DRV_MCP795 is not set
    CONFIG_RTC_I2C_AND_SPI=y
    # SPI and I2C RTC drivers
    # CONFIG_RTC_DRV_DS3232 is not set
    # CONFIG_RTC_DRV_PCF2127 is not set
    # CONFIG_RTC_DRV_RV3029C2 is not set
    # Platform RTC drivers
    # CONFIG_RTC_DRV_CMOS is not set
    # CONFIG_RTC_DRV_DS1286 is not set
    # CONFIG_RTC_DRV_DS1511 is not set
    # CONFIG_RTC_DRV_DS1553 is not set
    # CONFIG_RTC_DRV_DS1685_FAMILY is not set
    # CONFIG_RTC_DRV_DS1742 is not set
    # CONFIG_RTC_DRV_DS2404 is not set
    CONFIG_RTC_DRV_EFI=m
    # CONFIG_RTC_DRV_STK17TA8 is not set
    # CONFIG_RTC_DRV_M48T86 is not set
    # CONFIG_RTC_DRV_M48T35 is not set
    # CONFIG_RTC_DRV_M48T59 is not set
    # CONFIG_RTC_DRV_MSM6242 is not set
    # CONFIG_RTC_DRV_BQ4802 is not set
    # CONFIG_RTC_DRV_RP5C01 is not set
    # CONFIG_RTC_DRV_V3020 is not set
    # CONFIG_RTC_DRV_ZYNQMP is not set
    # on-CPU RTC drivers
    CONFIG_RTC_DRV_OMAP=m
    # CONFIG_RTC_DRV_CADENCE is not set
    # CONFIG_RTC_DRV_FTRTC010 is not set
    # CONFIG_RTC_DRV_R7301 is not set
    CONFIG_RTC_DRV_CPCAP=m
    # HID Sensor RTC drivers
    CONFIG_DMADEVICES=y
    # CONFIG_DMADEVICES_DEBUG is not set
    # DMA Devices
    CONFIG_DMA_ENGINE=y
    CONFIG_DMA_VIRTUAL_CHANNELS=y
    CONFIG_DMA_OF=y
    # CONFIG_ALTERA_MSGDMA is not set
    # CONFIG_DW_AXI_DMAC is not set
    CONFIG_FSL_EDMA=y
    # CONFIG_FSL_QDMA is not set
    # CONFIG_INTEL_IDMA64 is not set
    # CONFIG_NBPFAXI_DMA is not set
    # CONFIG_PLX_DMA is not set
    # CONFIG_XILINX_ZYNQMP_DPDMA is not set
    # CONFIG_QCOM_HIDMA_MGMT is not set
    # CONFIG_QCOM_HIDMA is not set
    CONFIG_DW_DMAC_CORE=y
    CONFIG_DW_DMAC=y
    # CONFIG_DW_DMAC_PCI is not set
    # CONFIG_DW_EDMA is not set
    # CONFIG_DW_EDMA_PCIE is not set
    # CONFIG_SF_PDMA is not set
    CONFIG_TI_CPPI41=y
    CONFIG_TI_EDMA=y
    CONFIG_DMA_OMAP=y
    CONFIG_TI_DMA_CROSSBAR=y
    # DMA Clients
    # CONFIG_ASYNC_TX_DMA is not set
    # CONFIG_DMATEST is not set
    # DMABUF options
    CONFIG_SYNC_FILE=y
    # CONFIG_SW_SYNC is not set
    # CONFIG_UDMABUF is not set
    # CONFIG_DMABUF_MOVE_NOTIFY is not set
    # CONFIG_DMABUF_SELFTESTS is not set
    CONFIG_DMABUF_HEAPS=y
    CONFIG_DMABUF_HEAPS_SYSTEM=y
    CONFIG_DMABUF_HEAPS_CMA=y
    CONFIG_DMABUF_HEAPS_CARVEOUT=y
    # end of DMABUF options
    # CONFIG_AUXDISPLAY is not set
    CONFIG_UIO=m
    # CONFIG_UIO_CIF is not set
    # CONFIG_UIO_PDRV_GENIRQ is not set
    # CONFIG_UIO_DMEM_GENIRQ is not set
    # CONFIG_UIO_AEC is not set
    # CONFIG_UIO_SERCOS3 is not set
    # CONFIG_UIO_PCI_GENERIC is not set
    # CONFIG_UIO_NETX is not set
    # CONFIG_UIO_PRUSS is not set
    # CONFIG_UIO_MF624 is not set
    # CONFIG_VFIO is not set
    # CONFIG_VIRT_DRIVERS is not set
    CONFIG_VIRTIO=y
    CONFIG_VIRTIO_MENU=y
    CONFIG_VIRTIO_PCI=y
    CONFIG_VIRTIO_PCI_LEGACY=y
    # CONFIG_VIRTIO_BALLOON is not set
    # CONFIG_VIRTIO_INPUT is not set
    CONFIG_VIRTIO_MMIO=y
    # CONFIG_VIRTIO_MMIO_CMDLINE_DEVICES is not set
    # CONFIG_VDPA is not set
    CONFIG_VHOST_MENU=y
    # CONFIG_VHOST_NET is not set
    # CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set
    # Microsoft Hyper-V guest support
    # end of Microsoft Hyper-V guest support
    # CONFIG_GREYBUS is not set
    # CONFIG_STAGING is not set
    # CONFIG_GOLDFISH is not set
    # CONFIG_CHROME_PLATFORMS is not set
    # CONFIG_MELLANOX_PLATFORM is not set
    CONFIG_HAVE_CLK=y
    CONFIG_CLKDEV_LOOKUP=y
    CONFIG_HAVE_CLK_PREPARE=y
    CONFIG_COMMON_CLK=y
    # CONFIG_COMMON_CLK_MAX9485 is not set
    # CONFIG_COMMON_CLK_SI5341 is not set
    # CONFIG_COMMON_CLK_SI5351 is not set
    # CONFIG_COMMON_CLK_SI514 is not set
    # CONFIG_COMMON_CLK_SI544 is not set
    # CONFIG_COMMON_CLK_SI570 is not set
    # CONFIG_COMMON_CLK_CDCE706 is not set
    # CONFIG_COMMON_CLK_CDCE925 is not set
    # CONFIG_COMMON_CLK_CS2000_CP is not set
    # CONFIG_CLK_TWL6040 is not set
    # CONFIG_CLK_QORIQ is not set
    CONFIG_COMMON_CLK_PALMAS=y
    # CONFIG_COMMON_CLK_PWM is not set
    # CONFIG_COMMON_CLK_VC5 is not set
    # CONFIG_COMMON_CLK_FIXED_MMIO is not set
    # CONFIG_COMMON_CLK_TI_ADPLL is not set
    CONFIG_HWSPINLOCK=y
    CONFIG_HWSPINLOCK_OMAP=y
    # Clock Source drivers
    CONFIG_TIMER_OF=y
    CONFIG_TIMER_PROBE=y
    CONFIG_OMAP_DM_TIMER=y
    CONFIG_CLKSRC_MMIO=y
    CONFIG_CLKSRC_TI_32K=y
    # CONFIG_MICROCHIP_PIT64B is not set
    # end of Clock Source drivers
    CONFIG_MAILBOX=y
    # CONFIG_PLATFORM_MHU is not set
    CONFIG_OMAP2PLUS_MBOX=y
    CONFIG_OMAP_MBOX_KFIFO_SIZE=256
    # CONFIG_ALTERA_MBOX is not set
    # CONFIG_MAILBOX_TEST is not set
    CONFIG_IOMMU_API=y
    CONFIG_IOMMU_SUPPORT=y
    # Generic IOMMU Pagetable Support
    # CONFIG_IOMMU_IO_PGTABLE_LPAE is not set
    # CONFIG_IOMMU_IO_PGTABLE_ARMV7S is not set
    # end of Generic IOMMU Pagetable Support
    # CONFIG_IOMMU_DEBUGFS is not set
    # CONFIG_IOMMU_DEFAULT_PASSTHROUGH is not set
    CONFIG_OF_IOMMU=y
    CONFIG_OMAP_IOMMU=y
    CONFIG_OMAP_IOMMU_DEBUG=y
    # CONFIG_ARM_SMMU is not set
    # Remoteproc drivers
    CONFIG_REMOTEPROC=y
    # CONFIG_REMOTEPROC_CDEV is not set
    CONFIG_WKUP_M3_RPROC=m
    CONFIG_PRU_REMOTEPROC=m
    # end of Remoteproc drivers
    # Rpmsg drivers
    CONFIG_RPMSG=y
    CONFIG_RPMSG_CHAR=m
    # CONFIG_RPMSG_QCOM_GLINK_RPM is not set
    CONFIG_RPMSG_VIRTIO=m
    CONFIG_RPMSG_PRU=m
    # end of Rpmsg drivers
    # Rpmsg virtual device drivers
    CONFIG_RPMSG_KDRV=y
    # CONFIG_RPMSG_KDRV_DEMO is not set
    CONFIG_RPMSG_KDRV_DISPLAY=y
    CONFIG_RPMSG_KDRV_ETH_SWITCH=m
    # end of Rpmsg virtual device drivers
    # CONFIG_SOUNDWIRE is not set
    # SOC (System On Chip) specific Drivers
    # Amlogic SoC drivers
    # end of Amlogic SoC drivers
    # Aspeed SoC drivers
    # end of Aspeed SoC drivers
    # Broadcom SoC drivers
    # CONFIG_SOC_BRCMSTB is not set
    # end of Broadcom SoC drivers
    # NXP/Freescale QorIQ SoC drivers
    # CONFIG_QUICC_ENGINE is not set
    # CONFIG_FSL_RCPM is not set
    # end of NXP/Freescale QorIQ SoC drivers
    # i.MX SoC drivers
    # end of i.MX SoC drivers
    # Qualcomm SoC drivers
    # end of Qualcomm SoC drivers
    CONFIG_SOC_TI=y
    CONFIG_AMX3_PM=m
    CONFIG_WKUP_M3_IPC=m
    CONFIG_TI_PRUSS=m
    # Xilinx SoC drivers
    # CONFIG_XILINX_VCU is not set
    # end of Xilinx SoC drivers
    # end of SOC (System On Chip) specific Drivers
    CONFIG_PM_DEVFREQ=y
    # DEVFREQ Governors
    CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
    # CONFIG_DEVFREQ_GOV_PERFORMANCE is not set
    # CONFIG_DEVFREQ_GOV_POWERSAVE is not set
    # CONFIG_DEVFREQ_GOV_USERSPACE is not set
    # CONFIG_DEVFREQ_GOV_PASSIVE is not set
    # DEVFREQ Drivers
    # CONFIG_PM_DEVFREQ_EVENT is not set
    CONFIG_EXTCON=y
    # Extcon Device Drivers
    # CONFIG_EXTCON_ADC_JACK is not set
    # CONFIG_EXTCON_FSA9480 is not set
    # CONFIG_EXTCON_GPIO is not set
    # CONFIG_EXTCON_MAX3355 is not set
    CONFIG_EXTCON_PALMAS=m
    # CONFIG_EXTCON_PTN5150 is not set
    # CONFIG_EXTCON_RT8973A is not set
    # CONFIG_EXTCON_SM5502 is not set
    CONFIG_EXTCON_USB_GPIO=m
    CONFIG_MEMORY=y
    # CONFIG_TI_EMIF is not set
    CONFIG_OMAP_GPMC=y
    # CONFIG_OMAP_GPMC_DEBUG is not set
    CONFIG_TI_EMIF_SRAM=m
    CONFIG_IIO=y
    CONFIG_IIO_BUFFER=y
    CONFIG_IIO_BUFFER_CB=m
    # CONFIG_IIO_BUFFER_DMA is not set
    # CONFIG_IIO_BUFFER_DMAENGINE is not set
    # CONFIG_IIO_BUFFER_HW_CONSUMER is not set
    CONFIG_IIO_KFIFO_BUF=y
    CONFIG_IIO_TRIGGERED_BUFFER=y
    CONFIG_IIO_CONFIGFS=y
    CONFIG_IIO_TRIGGER=y
    CONFIG_IIO_CONSUMERS_PER_TRIGGER=2
    # CONFIG_IIO_SW_DEVICE is not set
    CONFIG_IIO_SW_TRIGGER=y
    # CONFIG_IIO_TRIGGERED_EVENT is not set
    # Accelerometers
    # CONFIG_ADIS16201 is not set
    # CONFIG_ADIS16209 is not set
    # CONFIG_ADXL372_SPI is not set
    # CONFIG_ADXL372_I2C is not set
    # CONFIG_BMA180 is not set
    # CONFIG_BMA220 is not set
    # CONFIG_BMA400 is not set
    # CONFIG_BMC150_ACCEL is not set
    # CONFIG_DA280 is not set
    # CONFIG_DA311 is not set
    # CONFIG_DMARD06 is not set
    # CONFIG_DMARD09 is not set
    # CONFIG_DMARD10 is not set
    # CONFIG_IIO_ST_ACCEL_3AXIS is not set
    # CONFIG_KXSD9 is not set
    # CONFIG_KXCJK1013 is not set
    # CONFIG_MC3230 is not set
    # CONFIG_MMA7455_I2C is not set
    # CONFIG_MMA7455_SPI is not set
    # CONFIG_MMA7660 is not set
    # CONFIG_MMA8452 is not set
    # CONFIG_MMA9551 is not set
    # CONFIG_MMA9553 is not set
    # CONFIG_MXC4005 is not set
    # CONFIG_MXC6255 is not set
    # CONFIG_SCA3000 is not set
    # CONFIG_STK8312 is not set
    # CONFIG_STK8BA50 is not set
    # end of Accelerometers
    # Analog to digital converters
    # CONFIG_AD7091R5 is not set
    # CONFIG_AD7124 is not set
    # CONFIG_AD7192 is not set
    # CONFIG_AD7266 is not set
    # CONFIG_AD7291 is not set
    # CONFIG_AD7292 is not set
    # CONFIG_AD7298 is not set
    # CONFIG_AD7476 is not set
    # CONFIG_AD7606_IFACE_PARALLEL is not set
    # CONFIG_AD7606_IFACE_SPI is not set
    # CONFIG_AD7766 is not set
    # CONFIG_AD7768_1 is not set
    # CONFIG_AD7780 is not set
    # CONFIG_AD7791 is not set
    # CONFIG_AD7793 is not set
    # CONFIG_AD7887 is not set
    # CONFIG_AD7923 is not set
    # CONFIG_AD7949 is not set
    # CONFIG_AD799X is not set
    # CONFIG_ADI_AXI_ADC is not set
    # CONFIG_CC10001_ADC is not set
    CONFIG_CPCAP_ADC=m
    # CONFIG_ENVELOPE_DETECTOR is not set
    # CONFIG_HI8435 is not set
    # CONFIG_HX711 is not set
    # CONFIG_INA2XX_ADC is not set
    # CONFIG_LTC2471 is not set
    # CONFIG_LTC2485 is not set
    # CONFIG_LTC2496 is not set
    # CONFIG_LTC2497 is not set
    # CONFIG_MAX1027 is not set
    # CONFIG_MAX11100 is not set
    # CONFIG_MAX1118 is not set
    # CONFIG_MAX1241 is not set
    # CONFIG_MAX1363 is not set
    # CONFIG_MAX9611 is not set
    # CONFIG_MCP320X is not set
    # CONFIG_MCP3422 is not set
    # CONFIG_MCP3911 is not set
    # CONFIG_NAU7802 is not set
    # CONFIG_PALMAS_GPADC is not set
    # CONFIG_QCOM_SPMI_IADC is not set
    # CONFIG_QCOM_SPMI_VADC is not set
    # CONFIG_QCOM_SPMI_ADC5 is not set
    # CONFIG_SD_ADC_MODULATOR is not set
    # CONFIG_TI_ADC081C is not set
    # CONFIG_TI_ADC0832 is not set
    # CONFIG_TI_ADC084S021 is not set
    # CONFIG_TI_ADC12138 is not set
    # CONFIG_TI_ADC108S102 is not set
    # CONFIG_TI_ADC128S052 is not set
    # CONFIG_TI_ADC161S626 is not set
    # CONFIG_TI_ADS1015 is not set
    # CONFIG_TI_ADS7950 is not set
    # CONFIG_TI_ADS8344 is not set
    # CONFIG_TI_ADS8688 is not set
    # CONFIG_TI_ADS124S08 is not set
    CONFIG_TI_AM335X_ADC=m
    # CONFIG_TI_TLC4541 is not set
    CONFIG_VF610_ADC=m
    CONFIG_XILINX_XADC=y
    # end of Analog to digital converters
    # Analog Front Ends
    # CONFIG_IIO_RESCALE is not set
    # end of Analog Front Ends
    # Amplifiers
    # CONFIG_AD8366 is not set
    # CONFIG_HMC425 is not set
    # end of Amplifiers
    # Chemical Sensors
    # CONFIG_ATLAS_PH_SENSOR is not set
    # CONFIG_ATLAS_EZO_SENSOR is not set
    # CONFIG_BME680 is not set
    # CONFIG_CCS811 is not set
    # CONFIG_IAQCORE is not set
    # CONFIG_PMS7003 is not set
    # CONFIG_SCD30_CORE is not set
    # CONFIG_SENSIRION_SGP30 is not set
    # CONFIG_SPS30 is not set
    # CONFIG_VZ89X is not set
    # end of Chemical Sensors
    # Hid Sensor IIO Common
    # end of Hid Sensor IIO Common
    # SSP Sensor Common
    # CONFIG_IIO_SSP_SENSORHUB is not set
    # end of SSP Sensor Common
    # Digital to analog converters
    # CONFIG_AD5064 is not set
    # CONFIG_AD5360 is not set
    # CONFIG_AD5380 is not set
    # CONFIG_AD5421 is not set
    # CONFIG_AD5446 is not set
    # CONFIG_AD5449 is not set
    # CONFIG_AD5592R is not set
    # CONFIG_AD5593R is not set
    # CONFIG_AD5504 is not set
    # CONFIG_AD5624R_SPI is not set
    # CONFIG_AD5686_SPI is not set
    # CONFIG_AD5696_I2C is not set
    # CONFIG_AD5755 is not set
    # CONFIG_AD5758 is not set
    # CONFIG_AD5761 is not set
    # CONFIG_AD5764 is not set
    # CONFIG_AD5770R is not set
    # CONFIG_AD5791 is not set
    # CONFIG_AD7303 is not set
    # CONFIG_AD8801 is not set
    # CONFIG_DPOT_DAC is not set
    # CONFIG_DS4424 is not set
    # CONFIG_LTC1660 is not set
    # CONFIG_LTC2632 is not set
    # CONFIG_M62332 is not set
    # CONFIG_MAX517 is not set
    # CONFIG_MAX5821 is not set
    # CONFIG_MCP4725 is not set
    # CONFIG_MCP4922 is not set
    # CONFIG_TI_DAC082S085 is not set
    # CONFIG_TI_DAC5571 is not set
    # CONFIG_TI_DAC7311 is not set
    # CONFIG_TI_DAC7612 is not set
    # CONFIG_VF610_DAC is not set
    # end of Digital to analog converters
    # IIO dummy driver
    # end of IIO dummy driver
    # Frequency Synthesizers DDS/PLL
    # Clock Generator/Distribution
    # CONFIG_AD9523 is not set
    # end of Clock Generator/Distribution
    # Phase-Locked Loop (PLL) frequency synthesizers
    # CONFIG_ADF4350 is not set
    # CONFIG_ADF4371 is not set
    # end of Phase-Locked Loop (PLL) frequency synthesizers
    # end of Frequency Synthesizers DDS/PLL
    # Digital gyroscope sensors
    # CONFIG_ADIS16080 is not set
    # CONFIG_ADIS16130 is not set
    # CONFIG_ADIS16136 is not set
    # CONFIG_ADIS16260 is not set
    # CONFIG_ADXRS290 is not set
    # CONFIG_ADXRS450 is not set
    # CONFIG_BMG160 is not set
    # CONFIG_FXAS21002C is not set
    CONFIG_MPU3050=y
    CONFIG_MPU3050_I2C=y
    # CONFIG_IIO_ST_GYRO_3AXIS is not set
    # CONFIG_ITG3200 is not set
    # end of Digital gyroscope sensors
    # Health Sensors
    # Heart Rate Monitors
    # CONFIG_AFE4403 is not set
    # CONFIG_AFE4404 is not set
    # CONFIG_MAX30100 is not set
    # CONFIG_MAX30102 is not set
    # end of Heart Rate Monitors
    # end of Health Sensors
    # Humidity sensors
    # CONFIG_AM2315 is not set
    # CONFIG_DHT11 is not set
    # CONFIG_HDC100X is not set
    # CONFIG_HDC2010 is not set
    # CONFIG_HTS221 is not set
    # CONFIG_HTU21 is not set
    # CONFIG_SI7005 is not set
    # CONFIG_SI7020 is not set
    # end of Humidity sensors
    # Inertial measurement units
    # CONFIG_ADIS16400 is not set
    # CONFIG_ADIS16460 is not set
    # CONFIG_ADIS16475 is not set
    # CONFIG_ADIS16480 is not set
    # CONFIG_BMI160_I2C is not set
    # CONFIG_BMI160_SPI is not set
    # CONFIG_FXOS8700_I2C is not set
    # CONFIG_FXOS8700_SPI is not set
    # CONFIG_KMX61 is not set
    # CONFIG_INV_ICM42600_I2C is not set
    # CONFIG_INV_ICM42600_SPI is not set
    # CONFIG_INV_MPU6050_I2C is not set
    # CONFIG_INV_MPU6050_SPI is not set
    # CONFIG_IIO_ST_LSM6DSX is not set
    # end of Inertial measurement units
    # Light sensors
    # CONFIG_ADJD_S311 is not set
    # CONFIG_ADUX1020 is not set
    # CONFIG_AL3010 is not set
    # CONFIG_AL3320A is not set
    # CONFIG_APDS9300 is not set
    # CONFIG_APDS9960 is not set
    # CONFIG_AS73211 is not set
    # CONFIG_BH1750 is not set
    # CONFIG_BH1780 is not set
    # CONFIG_CM32181 is not set
    # CONFIG_CM3232 is not set
    # CONFIG_CM3323 is not set
    # CONFIG_CM3605 is not set
    CONFIG_CM36651=m
    # CONFIG_GP2AP002 is not set
    # CONFIG_GP2AP020A00F is not set
    CONFIG_SENSORS_ISL29018=y
    CONFIG_SENSORS_ISL29028=y
    # CONFIG_ISL29125 is not set
    # CONFIG_JSA1212 is not set
    # CONFIG_RPR0521 is not set
    # CONFIG_LTR501 is not set
    # CONFIG_LV0104CS is not set
    # CONFIG_MAX44000 is not set
    # CONFIG_MAX44009 is not set
    # CONFIG_NOA1305 is not set
    # CONFIG_OPT3001 is not set
    # CONFIG_PA12203001 is not set
    # CONFIG_SI1133 is not set
    # CONFIG_SI1145 is not set
    # CONFIG_STK3310 is not set
    # CONFIG_ST_UVIS25 is not set
    # CONFIG_TCS3414 is not set
    # CONFIG_TCS3472 is not set
    # CONFIG_SENSORS_TSL2563 is not set
    # CONFIG_TSL2583 is not set
    # CONFIG_TSL2772 is not set
    # CONFIG_TSL4531 is not set
    # CONFIG_US5182D is not set
    # CONFIG_VCNL4000 is not set
    # CONFIG_VCNL4035 is not set
    # CONFIG_VEML6030 is not set
    # CONFIG_VEML6070 is not set
    # CONFIG_VL6180 is not set
    # CONFIG_ZOPT2201 is not set
    # end of Light sensors
    # Magnetometer sensors
    # CONFIG_AK8974 is not set
    CONFIG_AK8975=y
    # CONFIG_AK09911 is not set
    # CONFIG_BMC150_MAGN_I2C is not set
    # CONFIG_BMC150_MAGN_SPI is not set
    # CONFIG_MAG3110 is not set
    # CONFIG_MMC35240 is not set
    # CONFIG_IIO_ST_MAGN_3AXIS is not set
    # CONFIG_SENSORS_HMC5843_I2C is not set
    # CONFIG_SENSORS_HMC5843_SPI is not set
    # CONFIG_SENSORS_RM3100_I2C is not set
    # CONFIG_SENSORS_RM3100_SPI is not set
    # end of Magnetometer sensors
    # Multiplexers
    # CONFIG_IIO_MUX is not set
    # end of Multiplexers
    # Inclinometer sensors
    # end of Inclinometer sensors
    # Triggers - standalone
    CONFIG_IIO_HRTIMER_TRIGGER=y
    # CONFIG_IIO_INTERRUPT_TRIGGER is not set
    # CONFIG_IIO_TIGHTLOOP_TRIGGER is not set
    # CONFIG_IIO_SYSFS_TRIGGER is not set
    # end of Triggers - standalone
    # Linear and angular position sensors
    # end of Linear and angular position sensors
    # Digital potentiometers
    # CONFIG_AD5272 is not set
    # CONFIG_DS1803 is not set
    # CONFIG_MAX5432 is not set
    # CONFIG_MAX5481 is not set
    # CONFIG_MAX5487 is not set
    # CONFIG_MCP4018 is not set
    # CONFIG_MCP4131 is not set
    # CONFIG_MCP4531 is not set
    # CONFIG_MCP41010 is not set
    # CONFIG_TPL0102 is not set
    # end of Digital potentiometers
    # Digital potentiostats
    # CONFIG_LMP91000 is not set
    # end of Digital potentiostats
    # Pressure sensors
    # CONFIG_ABP060MG is not set
    # CONFIG_BMP280 is not set
    # CONFIG_DLHL60D is not set
    # CONFIG_DPS310 is not set
    # CONFIG_HP03 is not set
    # CONFIG_ICP10100 is not set
    # CONFIG_MPL115_I2C is not set
    # CONFIG_MPL115_SPI is not set
    # CONFIG_MPL3115 is not set
    # CONFIG_MS5611 is not set
    # CONFIG_MS5637 is not set
    # CONFIG_IIO_ST_PRESS is not set
    # CONFIG_T5403 is not set
    # CONFIG_HP206C is not set
    # CONFIG_ZPA2326 is not set
    # end of Pressure sensors
    # Lightning sensors
    # CONFIG_AS3935 is not set
    # end of Lightning sensors
    # Proximity and distance sensors
    # CONFIG_ISL29501 is not set
    # CONFIG_LIDAR_LITE_V2 is not set
    # CONFIG_MB1232 is not set
    # CONFIG_PING is not set
    # CONFIG_RFD77402 is not set
    # CONFIG_SRF04 is not set
    # CONFIG_SX9310 is not set
    # CONFIG_SX9500 is not set
    # CONFIG_SRF08 is not set
    # CONFIG_VCNL3020 is not set
    # CONFIG_VL53L0X_I2C is not set
    # end of Proximity and distance sensors
    # Resolver to digital converters
    # CONFIG_AD2S90 is not set
    # CONFIG_AD2S1200 is not set
    # end of Resolver to digital converters
    # Temperature sensors
    # CONFIG_LTC2983 is not set
    # CONFIG_MAXIM_THERMOCOUPLE is not set
    # CONFIG_MLX90614 is not set
    # CONFIG_MLX90632 is not set
    # CONFIG_TMP006 is not set
    # CONFIG_TMP007 is not set
    # CONFIG_TSYS01 is not set
    # CONFIG_TSYS02D is not set
    # CONFIG_MAX31856 is not set
    # end of Temperature sensors
    CONFIG_NTB=m
    # CONFIG_NTB_MSI is not set
    # CONFIG_NTB_IDT is not set
    CONFIG_NTB_EPF=m
    # CONFIG_NTB_SWITCHTEC is not set
    # CONFIG_NTB_PINGPONG is not set
    # CONFIG_NTB_TOOL is not set
    # CONFIG_NTB_PERF is not set
    CONFIG_NTB_TRANSPORT=m
    # CONFIG_VME_BUS is not set
    CONFIG_PWM=y
    CONFIG_PWM_SYSFS=y
    # CONFIG_PWM_DEBUG is not set
    CONFIG_PWM_FSL_FTM=m
    CONFIG_PWM_OMAP_DMTIMER=y
    # CONFIG_PWM_PCA9685 is not set
    CONFIG_PWM_TIECAP=y
    CONFIG_PWM_TIEHRPWM=y
    # IRQ chip support
    CONFIG_IRQCHIP=y
    # CONFIG_AL_FIC is not set
    CONFIG_OMAP_IRQCHIP=y
    CONFIG_TI_PRUSS_INTC=m
    # end of IRQ chip support
    # CONFIG_IPACK_BUS is not set
    CONFIG_ARCH_HAS_RESET_CONTROLLER=y
    CONFIG_RESET_CONTROLLER=y
    CONFIG_RESET_TI_SYSCON=y
    # PHY Subsystem
    CONFIG_GENERIC_PHY=y
    CONFIG_GENERIC_PHY_MIPI_DPHY=y
    CONFIG_PHY_CAN_TRANSCEIVER=m
    # CONFIG_BCM_KONA_USB2_PHY is not set
    CONFIG_PHY_CADENCE_TORRENT=y
    CONFIG_PHY_CADENCE_DPHY=m
    CONFIG_PHY_CADENCE_SIERRA=y
    # CONFIG_PHY_CADENCE_SALVO is not set
    # CONFIG_PHY_FSL_IMX8MQ_USB is not set
    # CONFIG_PHY_MIXEL_MIPI_DPHY is not set
    # CONFIG_PHY_PXA_28NM_HSIC is not set
    # CONFIG_PHY_PXA_28NM_USB2 is not set
    CONFIG_PHY_CPCAP_USB=m
    # CONFIG_PHY_MAPPHONE_MDM6600 is not set
    # CONFIG_PHY_OCELOT_SERDES is not set
    CONFIG_PHY_DM816X_USB=m
    CONFIG_OMAP_CONTROL_PHY=y
    CONFIG_OMAP_USB2=m
    CONFIG_TI_PIPE3=y
    CONFIG_PHY_TI_GMII_SEL=y
    # end of PHY Subsystem
    # CONFIG_POWERCAP is not set
    # CONFIG_MCB is not set
    # Performance monitor support
    # CONFIG_ARM_CCI_PMU is not set
    # CONFIG_ARM_CCN is not set
    CONFIG_ARM_PMU=y
    # end of Performance monitor support
    CONFIG_RAS=y
    # CONFIG_USB4 is not set
    # Android
    # CONFIG_ANDROID is not set
    # end of Android
    # CONFIG_DAX is not set
    CONFIG_NVMEM=y
    CONFIG_NVMEM_SYSFS=y
    # CONFIG_NVMEM_SPMI_SDAM is not set
    # HW tracing support
    # CONFIG_STM is not set
    # CONFIG_INTEL_TH is not set
    # end of HW tracing support
    # CONFIG_FPGA is not set
    CONFIG_FSI=m
    # CONFIG_FSI_NEW_DEV_NODE is not set
    CONFIG_FSI_MASTER_GPIO=m
    CONFIG_FSI_MASTER_HUB=m
    CONFIG_FSI_MASTER_ASPEED=m
    CONFIG_FSI_SCOM=m
    CONFIG_FSI_SBEFIFO=m
    CONFIG_FSI_OCC=m
    CONFIG_TEE=y
    # TEE drivers
    CONFIG_OPTEE=y
    CONFIG_OPTEE_SHM_NUM_PRIV_PAGES=1
    # end of TEE drivers
    CONFIG_MULTIPLEXER=y
    # Multiplexer drivers
    # CONFIG_MUX_ADG792A is not set
    # CONFIG_MUX_ADGS1408 is not set
    CONFIG_MUX_GPIO=y
    # CONFIG_MUX_MMIO is not set
    # end of Multiplexer drivers
    CONFIG_PM_OPP=y
    # CONFIG_SIOX is not set
    # CONFIG_SLIMBUS is not set
    # CONFIG_INTERCONNECT is not set
    # CONFIG_COUNTER is not set
    # CONFIG_MOST is not set
    # end of Device Drivers
    # File systems
    CONFIG_DCACHE_WORD_ACCESS=y
    # CONFIG_VALIDATE_FS_PARSER is not set
    CONFIG_FS_IOMAP=y
    # CONFIG_EXT2_FS is not set
    # CONFIG_EXT3_FS is not set
    CONFIG_EXT4_FS=y
    CONFIG_EXT4_USE_FOR_EXT2=y
    CONFIG_EXT4_FS_POSIX_ACL=y
    CONFIG_EXT4_FS_SECURITY=y
    # CONFIG_EXT4_DEBUG is not set
    CONFIG_JBD2=y
    # CONFIG_JBD2_DEBUG is not set
    CONFIG_FS_MBCACHE=y
    # CONFIG_REISERFS_FS is not set
    # CONFIG_JFS_FS is not set
    # CONFIG_XFS_FS is not set
    # CONFIG_GFS2_FS is not set
    # CONFIG_OCFS2_FS is not set
    # CONFIG_BTRFS_FS is not set
    # CONFIG_NILFS2_FS is not set
    # CONFIG_F2FS_FS is not set
    CONFIG_FS_POSIX_ACL=y
    CONFIG_EXPORTFS=y
    # CONFIG_EXPORTFS_BLOCK_OPS is not set
    CONFIG_FILE_LOCKING=y
    CONFIG_MANDATORY_FILE_LOCKING=y
    # CONFIG_FS_ENCRYPTION is not set
    # CONFIG_FS_VERITY is not set
    CONFIG_FSNOTIFY=y
    CONFIG_DNOTIFY=y
    CONFIG_INOTIFY_USER=y
    # CONFIG_FANOTIFY is not set
    # CONFIG_QUOTA is not set
    CONFIG_AUTOFS4_FS=y
    CONFIG_AUTOFS_FS=y
    # CONFIG_FUSE_FS is not set
    # CONFIG_OVERLAY_FS is not set
    # Caches
    # CONFIG_FSCACHE is not set
    # end of Caches
    # CD-ROM/DVD Filesystems
    # CONFIG_ISO9660_FS is not set
    # CONFIG_UDF_FS is not set
    # end of CD-ROM/DVD Filesystems
    # DOS/FAT/EXFAT/NT Filesystems
    CONFIG_FAT_FS=y
    CONFIG_MSDOS_FS=y
    CONFIG_VFAT_FS=y
    CONFIG_FAT_DEFAULT_CODEPAGE=437
    CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
    # CONFIG_FAT_DEFAULT_UTF8 is not set
    # CONFIG_EXFAT_FS is not set
    CONFIG_NTFS_FS=y
    # CONFIG_NTFS_DEBUG is not set
    # CONFIG_NTFS_RW is not set
    # end of DOS/FAT/EXFAT/NT Filesystems
    # Pseudo filesystems
    CONFIG_PROC_FS=y
    CONFIG_PROC_SYSCTL=y
    CONFIG_PROC_PAGE_MONITOR=y
    CONFIG_PROC_CHILDREN=y
    CONFIG_KERNFS=y
    CONFIG_SYSFS=y
    CONFIG_TMPFS=y
    CONFIG_TMPFS_POSIX_ACL=y
    CONFIG_TMPFS_XATTR=y
    CONFIG_MEMFD_CREATE=y
    CONFIG_CONFIGFS_FS=y
    CONFIG_EFIVAR_FS=m
    # end of Pseudo filesystems
    CONFIG_MISC_FILESYSTEMS=y
    # CONFIG_ORANGEFS_FS is not set
    # CONFIG_ADFS_FS is not set
    # CONFIG_AFFS_FS is not set
    # CONFIG_ECRYPT_FS is not set
    # CONFIG_HFS_FS is not set
    # CONFIG_HFSPLUS_FS is not set
    # CONFIG_BEFS_FS is not set
    # CONFIG_BFS_FS is not set
    # CONFIG_EFS_FS is not set
    # CONFIG_JFFS2_FS is not set
    CONFIG_UBIFS_FS=y
    # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set
    CONFIG_UBIFS_FS_LZO=y
    CONFIG_UBIFS_FS_ZLIB=y
    CONFIG_UBIFS_FS_ZSTD=y
    # CONFIG_UBIFS_ATIME_SUPPORT is not set
    CONFIG_UBIFS_FS_XATTR=y
    CONFIG_UBIFS_FS_SECURITY=y
    # CONFIG_UBIFS_FS_AUTHENTICATION is not set
    # CONFIG_CRAMFS is not set
    CONFIG_SQUASHFS=y
    CONFIG_SQUASHFS_FILE_CACHE=y
    # CONFIG_SQUASHFS_FILE_DIRECT is not set
    CONFIG_SQUASHFS_DECOMP_SINGLE=y
    # CONFIG_SQUASHFS_DECOMP_MULTI is not set
    # CONFIG_SQUASHFS_DECOMP_MULTI_PERCPU is not set
    # CONFIG_SQUASHFS_XATTR is not set
    CONFIG_SQUASHFS_ZLIB=y
    # CONFIG_SQUASHFS_LZ4 is not set
    CONFIG_SQUASHFS_LZO=y
    CONFIG_SQUASHFS_XZ=y
    # CONFIG_SQUASHFS_ZSTD is not set
    # CONFIG_SQUASHFS_4K_DEVBLK_SIZE is not set
    # CONFIG_SQUASHFS_EMBEDDED is not set
    CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
    # CONFIG_VXFS_FS is not set
    # CONFIG_MINIX_FS is not set
    # CONFIG_OMFS_FS is not set
    # CONFIG_HPFS_FS is not set
    # CONFIG_QNX4FS_FS is not set
    # CONFIG_QNX6FS_FS is not set
    # CONFIG_ROMFS_FS is not set
    CONFIG_PSTORE=y
    CONFIG_PSTORE_DEFLATE_COMPRESS=y
    # CONFIG_PSTORE_LZO_COMPRESS is not set
    # CONFIG_PSTORE_LZ4_COMPRESS is not set
    # CONFIG_PSTORE_LZ4HC_COMPRESS is not set
    # CONFIG_PSTORE_842_COMPRESS is not set
    # CONFIG_PSTORE_ZSTD_COMPRESS is not set
    CONFIG_PSTORE_COMPRESS=y
    CONFIG_PSTORE_DEFLATE_COMPRESS_DEFAULT=y
    CONFIG_PSTORE_COMPRESS_DEFAULT="deflate"
    CONFIG_PSTORE_CONSOLE=y
    CONFIG_PSTORE_PMSG=y
    CONFIG_PSTORE_RAM=y
    # CONFIG_SYSV_FS is not set
    # CONFIG_UFS_FS is not set
    # CONFIG_EROFS_FS is not set
    CONFIG_NETWORK_FILESYSTEMS=y
    CONFIG_NFS_FS=y
    CONFIG_NFS_V2=y
    CONFIG_NFS_V3=y
    CONFIG_NFS_V3_ACL=y
    CONFIG_NFS_V4=y
    # CONFIG_NFS_SWAP is not set
    CONFIG_NFS_V4_1=y
    CONFIG_NFS_V4_2=y
    CONFIG_PNFS_FILE_LAYOUT=y
    CONFIG_PNFS_FLEXFILE_LAYOUT=y
    CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org"
    # CONFIG_NFS_V4_1_MIGRATION is not set
    CONFIG_ROOT_NFS=y
    # CONFIG_NFS_USE_LEGACY_DNS is not set
    CONFIG_NFS_USE_KERNEL_DNS=y
    CONFIG_NFS_DISABLE_UDP_SUPPORT=y
    # CONFIG_NFS_V4_2_READ_PLUS is not set
    # CONFIG_NFSD is not set
    CONFIG_GRACE_PERIOD=y
    CONFIG_LOCKD=y
    CONFIG_LOCKD_V4=y
    CONFIG_NFS_ACL_SUPPORT=y
    CONFIG_NFS_COMMON=y
    CONFIG_SUNRPC=y
    CONFIG_SUNRPC_GSS=y
    CONFIG_SUNRPC_BACKCHANNEL=y
    # CONFIG_SUNRPC_DEBUG is not set
    # CONFIG_CEPH_FS is not set
    CONFIG_CIFS=m
    # CONFIG_CIFS_STATS2 is not set
    CONFIG_CIFS_ALLOW_INSECURE_LEGACY=y
    # CONFIG_CIFS_WEAK_PW_HASH is not set
    # CONFIG_CIFS_UPCALL is not set
    CONFIG_CIFS_XATTR=y
    CONFIG_CIFS_POSIX=y
    CONFIG_CIFS_DEBUG=y
    # CONFIG_CIFS_DEBUG2 is not set
    # CONFIG_CIFS_DEBUG_DUMP_KEYS is not set
    # CONFIG_CIFS_DFS_UPCALL is not set
    # CONFIG_CODA_FS is not set
    # CONFIG_AFS_FS is not set
    CONFIG_NLS=y
    CONFIG_NLS_DEFAULT="iso8859-1"
    CONFIG_NLS_CODEPAGE_437=y
    # CONFIG_NLS_CODEPAGE_737 is not set
    # CONFIG_NLS_CODEPAGE_775 is not set
    # CONFIG_NLS_CODEPAGE_850 is not set
    # CONFIG_NLS_CODEPAGE_852 is not set
    # CONFIG_NLS_CODEPAGE_855 is not set
    # CONFIG_NLS_CODEPAGE_857 is not set
    # CONFIG_NLS_CODEPAGE_860 is not set
    # CONFIG_NLS_CODEPAGE_861 is not set
    # CONFIG_NLS_CODEPAGE_862 is not set
    # CONFIG_NLS_CODEPAGE_863 is not set
    # CONFIG_NLS_CODEPAGE_864 is not set
    # CONFIG_NLS_CODEPAGE_865 is not set
    # CONFIG_NLS_CODEPAGE_866 is not set
    # CONFIG_NLS_CODEPAGE_869 is not set
    # CONFIG_NLS_CODEPAGE_936 is not set
    # CONFIG_NLS_CODEPAGE_950 is not set
    # CONFIG_NLS_CODEPAGE_932 is not set
    # CONFIG_NLS_CODEPAGE_949 is not set
    # CONFIG_NLS_CODEPAGE_874 is not set
    # CONFIG_NLS_ISO8859_8 is not set
    # CONFIG_NLS_CODEPAGE_1250 is not set
    # CONFIG_NLS_CODEPAGE_1251 is not set
    # CONFIG_NLS_ASCII is not set
    CONFIG_NLS_ISO8859_1=y
    # CONFIG_NLS_ISO8859_2 is not set
    # CONFIG_NLS_ISO8859_3 is not set
    # CONFIG_NLS_ISO8859_4 is not set
    # CONFIG_NLS_ISO8859_5 is not set
    # CONFIG_NLS_ISO8859_6 is not set
    # CONFIG_NLS_ISO8859_7 is not set
    # CONFIG_NLS_ISO8859_9 is not set
    # CONFIG_NLS_ISO8859_13 is not set
    # CONFIG_NLS_ISO8859_14 is not set
    # CONFIG_NLS_ISO8859_15 is not set
    # CONFIG_NLS_KOI8_R is not set
    # CONFIG_NLS_KOI8_U is not set
    # CONFIG_NLS_MAC_ROMAN is not set
    # CONFIG_NLS_MAC_CELTIC is not set
    # CONFIG_NLS_MAC_CENTEURO is not set
    # CONFIG_NLS_MAC_CROATIAN is not set
    # CONFIG_NLS_MAC_CYRILLIC is not set
    # CONFIG_NLS_MAC_GAELIC is not set
    # CONFIG_NLS_MAC_GREEK is not set
    # CONFIG_NLS_MAC_ICELAND is not set
    # CONFIG_NLS_MAC_INUIT is not set
    # CONFIG_NLS_MAC_ROMANIAN is not set
    # CONFIG_NLS_MAC_TURKISH is not set
    CONFIG_NLS_UTF8=y
    # CONFIG_DLM is not set
    # CONFIG_UNICODE is not set
    CONFIG_IO_WQ=y
    # end of File systems
    # Security options
    CONFIG_KEYS=y
    # CONFIG_KEYS_REQUEST_CACHE is not set
    # CONFIG_PERSISTENT_KEYRINGS is not set
    # CONFIG_TRUSTED_KEYS is not set
    # CONFIG_ENCRYPTED_KEYS is not set
    # CONFIG_KEY_DH_OPERATIONS is not set
    # CONFIG_SECURITY_DMESG_RESTRICT is not set
    # CONFIG_SECURITY is not set
    CONFIG_SECURITYFS=y
    CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
    # CONFIG_HARDENED_USERCOPY is not set
    # CONFIG_FORTIFY_SOURCE is not set
    # CONFIG_STATIC_USERMODEHELPER is not set
    CONFIG_DEFAULT_SECURITY_DAC=y
    CONFIG_LSM="lockdown,yama,loadpin,safesetid,integrity,bpf"
    # Kernel hardening options
    # Memory initialization
    CONFIG_INIT_STACK_NONE=y
    # CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set
    # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set
    # CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set
    # CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
    # CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
    # end of Memory initialization
    # end of Kernel hardening options
    # end of Security options
    CONFIG_CRYPTO=y
    # Crypto core or helper
    CONFIG_CRYPTO_ALGAPI=y
    CONFIG_CRYPTO_ALGAPI2=y
    CONFIG_CRYPTO_AEAD=m
    CONFIG_CRYPTO_AEAD2=y
    CONFIG_CRYPTO_SKCIPHER=m
    CONFIG_CRYPTO_SKCIPHER2=y
    CONFIG_CRYPTO_HASH=y
    CONFIG_CRYPTO_HASH2=y
    CONFIG_CRYPTO_RNG=m
    CONFIG_CRYPTO_RNG2=y
    CONFIG_CRYPTO_RNG_DEFAULT=m
    CONFIG_CRYPTO_AKCIPHER2=y
    CONFIG_CRYPTO_AKCIPHER=y
    CONFIG_CRYPTO_KPP2=y
    CONFIG_CRYPTO_KPP=m
    CONFIG_CRYPTO_ACOMP2=y
    CONFIG_CRYPTO_MANAGER=y
    CONFIG_CRYPTO_MANAGER2=y
    CONFIG_CRYPTO_USER=m
    CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
    CONFIG_CRYPTO_GF128MUL=m
    CONFIG_CRYPTO_NULL=m
    CONFIG_CRYPTO_NULL2=y
    CONFIG_CRYPTO_CRYPTD=m
    CONFIG_CRYPTO_AUTHENC=m
    CONFIG_CRYPTO_TEST=m
    CONFIG_CRYPTO_SIMD=m
    CONFIG_CRYPTO_ENGINE=m
    # Public-key cryptography
    CONFIG_CRYPTO_RSA=y
    # CONFIG_CRYPTO_DH is not set
    CONFIG_CRYPTO_ECC=m
    CONFIG_CRYPTO_ECDH=m
    # CONFIG_CRYPTO_ECRDSA is not set
    # CONFIG_CRYPTO_SM2 is not set
    # CONFIG_CRYPTO_CURVE25519 is not set
    # Authenticated Encryption with Associated Data
    CONFIG_CRYPTO_CCM=m
    CONFIG_CRYPTO_GCM=m
    # CONFIG_CRYPTO_CHACHA20POLY1305 is not set
    # CONFIG_CRYPTO_AEGIS128 is not set
    CONFIG_CRYPTO_SEQIV=m
    CONFIG_CRYPTO_ECHAINIV=m
    # Block modes
    CONFIG_CRYPTO_CBC=m
    # CONFIG_CRYPTO_CFB is not set
    CONFIG_CRYPTO_CTR=m
    # CONFIG_CRYPTO_CTS is not set
    CONFIG_CRYPTO_ECB=m
    # CONFIG_CRYPTO_LRW is not set
    # CONFIG_CRYPTO_OFB is not set
    # CONFIG_CRYPTO_PCBC is not set
    # CONFIG_CRYPTO_XTS is not set
    # CONFIG_CRYPTO_KEYWRAP is not set
    # CONFIG_CRYPTO_ADIANTUM is not set
    # CONFIG_CRYPTO_ESSIV is not set
    # Hash modes
    CONFIG_CRYPTO_CMAC=m
    CONFIG_CRYPTO_HMAC=m
    # CONFIG_CRYPTO_XCBC is not set
    # CONFIG_CRYPTO_VMAC is not set
    # Digest
    CONFIG_CRYPTO_CRC32C=y
    # CONFIG_CRYPTO_CRC32 is not set
    # CONFIG_CRYPTO_XXHASH is not set
    # CONFIG_CRYPTO_BLAKE2B is not set
    # CONFIG_CRYPTO_BLAKE2S is not set
    # CONFIG_CRYPTO_CRCT10DIF is not set
    CONFIG_CRYPTO_GHASH=m
    # CONFIG_CRYPTO_POLY1305 is not set
    CONFIG_CRYPTO_MD4=m
    CONFIG_CRYPTO_MD5=m
    # CONFIG_CRYPTO_MICHAEL_MIC is not set
    # CONFIG_CRYPTO_RMD128 is not set
    # CONFIG_CRYPTO_RMD160 is not set
    # CONFIG_CRYPTO_RMD256 is not set
    # CONFIG_CRYPTO_RMD320 is not set
    CONFIG_CRYPTO_SHA1=y
    CONFIG_CRYPTO_SHA256=m
    CONFIG_CRYPTO_SHA512=m
    # CONFIG_CRYPTO_SHA3 is not set
    # CONFIG_CRYPTO_SM3 is not set
    # CONFIG_CRYPTO_STREEBOG is not set
    # CONFIG_CRYPTO_TGR192 is not set
    # CONFIG_CRYPTO_WP512 is not set
    # Ciphers
    CONFIG_CRYPTO_AES=m
    # CONFIG_CRYPTO_AES_TI is not set
    # CONFIG_CRYPTO_ANUBIS is not set
    # CONFIG_CRYPTO_ARC4 is not set
    # CONFIG_CRYPTO_BLOWFISH is not set
    # CONFIG_CRYPTO_CAMELLIA is not set
    # CONFIG_CRYPTO_CAST5 is not set
    # CONFIG_CRYPTO_CAST6 is not set
    # CONFIG_CRYPTO_DES is not set
    # CONFIG_CRYPTO_FCRYPT is not set
    # CONFIG_CRYPTO_KHAZAD is not set
    # CONFIG_CRYPTO_SALSA20 is not set
    # CONFIG_CRYPTO_CHACHA20 is not set
    # CONFIG_CRYPTO_SEED is not set
    # CONFIG_CRYPTO_SERPENT is not set
    # CONFIG_CRYPTO_SM4 is not set
    # CONFIG_CRYPTO_TEA is not set
    # CONFIG_CRYPTO_TWOFISH is not set
    # Compression
    CONFIG_CRYPTO_DEFLATE=y
    CONFIG_CRYPTO_LZO=y
    # CONFIG_CRYPTO_842 is not set
    # CONFIG_CRYPTO_LZ4 is not set
    # CONFIG_CRYPTO_LZ4HC is not set
    CONFIG_CRYPTO_ZSTD=y
    # Random Number Generation
    # CONFIG_CRYPTO_ANSI_CPRNG is not set
    CONFIG_CRYPTO_DRBG_MENU=m
    CONFIG_CRYPTO_DRBG_HMAC=y
    # CONFIG_CRYPTO_DRBG_HASH is not set
    # CONFIG_CRYPTO_DRBG_CTR is not set
    CONFIG_CRYPTO_DRBG=m
    CONFIG_CRYPTO_JITTERENTROPY=m
    CONFIG_CRYPTO_USER_API=m
    CONFIG_CRYPTO_USER_API_HASH=m
    CONFIG_CRYPTO_USER_API_SKCIPHER=m
    CONFIG_CRYPTO_USER_API_RNG=m
    # CONFIG_CRYPTO_USER_API_RNG_CAVP is not set
    CONFIG_CRYPTO_USER_API_AEAD=m
    CONFIG_CRYPTO_USER_API_ENABLE_OBSOLETE=y
    # CONFIG_CRYPTO_STATS is not set
    CONFIG_CRYPTO_HASH_INFO=y
    # Crypto library routines
    CONFIG_CRYPTO_LIB_AES=m
    CONFIG_CRYPTO_LIB_ARC4=m
    # CONFIG_CRYPTO_LIB_BLAKE2S is not set
    CONFIG_CRYPTO_ARCH_HAVE_LIB_CHACHA=m
    # CONFIG_CRYPTO_LIB_CHACHA is not set
    # CONFIG_CRYPTO_LIB_CURVE25519 is not set
    CONFIG_CRYPTO_LIB_DES=m
    CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
    # CONFIG_CRYPTO_LIB_POLY1305 is not set
    # CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
    CONFIG_CRYPTO_LIB_SHA256=m
    CONFIG_CRYPTO_HW=y
    # CONFIG_CRYPTO_DEV_HIFN_795X is not set
    CONFIG_CRYPTO_DEV_OMAP=m
    CONFIG_CRYPTO_DEV_OMAP_SHAM=m
    CONFIG_CRYPTO_DEV_OMAP_AES=m
    CONFIG_CRYPTO_DEV_OMAP_DES=m
    # CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
    # CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
    # CONFIG_CRYPTO_DEV_VIRTIO is not set
    # CONFIG_CRYPTO_DEV_SAFEXCEL is not set
    # CONFIG_CRYPTO_DEV_CCREE is not set
    # CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set
    CONFIG_ASYMMETRIC_KEY_TYPE=y
    CONFIG_ASYMMETRIC_PUBLIC_KEY_SUBTYPE=y
    CONFIG_X509_CERTIFICATE_PARSER=y
    # CONFIG_PKCS8_PRIVATE_KEY_PARSER is not set
    CONFIG_PKCS7_MESSAGE_PARSER=y
    # CONFIG_PKCS7_TEST_KEY is not set
    # CONFIG_SIGNED_PE_FILE_VERIFICATION is not set
    # Certificates for signature checking
    CONFIG_SYSTEM_TRUSTED_KEYRING=y
    CONFIG_SYSTEM_TRUSTED_KEYS=""
    # CONFIG_SYSTEM_EXTRA_CERTIFICATE is not set
    # CONFIG_SECONDARY_TRUSTED_KEYRING is not set
    # CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
    # end of Certificates for signature checking
    # Library routines
    CONFIG_LINEAR_RANGES=y
    # CONFIG_PACKING is not set
    CONFIG_BITREVERSE=y
    CONFIG_HAVE_ARCH_BITREVERSE=y
    CONFIG_GENERIC_STRNCPY_FROM_USER=y
    CONFIG_GENERIC_STRNLEN_USER=y
    CONFIG_GENERIC_NET_UTILS=y
    CONFIG_CORDIC=m
    # CONFIG_PRIME_NUMBERS is not set
    CONFIG_RATIONAL=y
    CONFIG_GENERIC_PCI_IOMAP=y
    CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
    CONFIG_CRC_CCITT=m
    CONFIG_CRC16=y
    # CONFIG_CRC_T10DIF is not set
    CONFIG_CRC_ITU_T=m
    CONFIG_CRC32=y
    # CONFIG_CRC32_SELFTEST is not set
    CONFIG_CRC32_SLICEBY8=y
    # CONFIG_CRC32_SLICEBY4 is not set
    # CONFIG_CRC32_SARWATE is not set
    # CONFIG_CRC32_BIT is not set
    # CONFIG_CRC64 is not set
    CONFIG_CRC4=m
    # CONFIG_CRC7 is not set
    CONFIG_LIBCRC32C=m
    # CONFIG_CRC8 is not set
    CONFIG_XXHASH=y
    # CONFIG_RANDOM32_SELFTEST is not set
    CONFIG_ZLIB_INFLATE=y
    CONFIG_ZLIB_DEFLATE=y
    CONFIG_LZO_COMPRESS=y
    CONFIG_LZO_DECOMPRESS=y
    CONFIG_LZ4_DECOMPRESS=y
    CONFIG_ZSTD_COMPRESS=y
    CONFIG_ZSTD_DECOMPRESS=y
    CONFIG_XZ_DEC=y
    CONFIG_XZ_DEC_X86=y
    CONFIG_XZ_DEC_POWERPC=y
    CONFIG_XZ_DEC_IA64=y
    CONFIG_XZ_DEC_ARM=y
    CONFIG_XZ_DEC_ARMTHUMB=y
    CONFIG_XZ_DEC_SPARC=y
    CONFIG_XZ_DEC_BCJ=y
    # CONFIG_XZ_DEC_TEST is not set
    CONFIG_DECOMPRESS_GZIP=y
    CONFIG_DECOMPRESS_BZIP2=y
    CONFIG_DECOMPRESS_LZMA=y
    CONFIG_DECOMPRESS_XZ=y
    CONFIG_DECOMPRESS_LZO=y
    CONFIG_DECOMPRESS_LZ4=y
    CONFIG_DECOMPRESS_ZSTD=y
    CONFIG_GENERIC_ALLOCATOR=y
    CONFIG_REED_SOLOMON=y
    CONFIG_REED_SOLOMON_ENC8=y
    CONFIG_REED_SOLOMON_DEC8=y
    CONFIG_BCH=y
    CONFIG_TEXTSEARCH=y
    CONFIG_TEXTSEARCH_KMP=m
    CONFIG_TEXTSEARCH_BM=m
    CONFIG_TEXTSEARCH_FSM=m
    CONFIG_ASSOCIATIVE_ARRAY=y
    CONFIG_HAS_IOMEM=y
    CONFIG_HAS_IOPORT_MAP=y
    CONFIG_HAS_DMA=y
    CONFIG_DMA_OPS=y
    CONFIG_NEED_DMA_MAP_STATE=y
    CONFIG_DMA_DECLARE_COHERENT=y
    CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
    CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
    CONFIG_DMA_NONCOHERENT_MMAP=y
    CONFIG_DMA_REMAP=y
    CONFIG_DMA_CMA=y
    # CONFIG_DMA_PERNUMA_CMA is not set
    # Default contiguous memory area size:
    CONFIG_CMA_SIZE_MBYTES=48
    CONFIG_CMA_SIZE_SEL_MBYTES=y
    # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
    # CONFIG_CMA_SIZE_SEL_MIN is not set
    # CONFIG_CMA_SIZE_SEL_MAX is not set
    CONFIG_CMA_ALIGNMENT=8
    # CONFIG_DMA_API_DEBUG is not set
    CONFIG_SGL_ALLOC=y
    CONFIG_DQL=y
    CONFIG_GLOB=y
    # CONFIG_GLOB_SELFTEST is not set
    CONFIG_NLATTR=y
    CONFIG_CLZ_TAB=y
    # CONFIG_IRQ_POLL is not set
    CONFIG_MPILIB=y
    CONFIG_LIBFDT=y
    CONFIG_OID_REGISTRY=y
    CONFIG_UCS2_STRING=y
    CONFIG_FONT_SUPPORT=y
    # CONFIG_FONTS is not set
    CONFIG_FONT_8x8=y
    CONFIG_FONT_8x16=y
    CONFIG_SG_SPLIT=y
    CONFIG_SG_POOL=y
    CONFIG_SBITMAP=y
    # CONFIG_STRING_SELFTEST is not set
    # end of Library routines
    # Kernel hacking
    # printk and dmesg options
    CONFIG_PRINTK_TIME=y
    # CONFIG_PRINTK_CALLER is not set
    CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
    CONFIG_CONSOLE_LOGLEVEL_QUIET=4
    CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
    # CONFIG_BOOT_PRINTK_DELAY is not set
    # CONFIG_DYNAMIC_DEBUG is not set
    # CONFIG_DYNAMIC_DEBUG_CORE is not set
    CONFIG_SYMBOLIC_ERRNAME=y
    # CONFIG_DEBUG_BUGVERBOSE is not set
    # end of printk and dmesg options
    # Compile-time checks and compiler options
    # CONFIG_DEBUG_INFO is not set
    CONFIG_ENABLE_MUST_CHECK=y
    CONFIG_FRAME_WARN=1024
    # CONFIG_STRIP_ASM_SYMS is not set
    # CONFIG_READABLE_ASM is not set
    # CONFIG_HEADERS_INSTALL is not set
    # CONFIG_DEBUG_SECTION_MISMATCH is not set
    CONFIG_SECTION_MISMATCH_WARN_ONLY=y
    # CONFIG_DEBUG_FORCE_FUNCTION_ALIGN_32B is not set
    # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
    # end of Compile-time checks and compiler options
    # Generic Kernel Debugging Instruments
    CONFIG_MAGIC_SYSRQ=y
    CONFIG_MAGIC_SYSRQ_DEFAULT_ENABLE=0x1
    CONFIG_MAGIC_SYSRQ_SERIAL=y
    CONFIG_MAGIC_SYSRQ_SERIAL_SEQUENCE=""
    CONFIG_DEBUG_FS=y
    CONFIG_DEBUG_FS_ALLOW_ALL=y
    # CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
    # CONFIG_DEBUG_FS_ALLOW_NONE is not set
    CONFIG_HAVE_ARCH_KGDB=y
    # CONFIG_KGDB is not set
    # CONFIG_UBSAN is not set
    # end of Generic Kernel Debugging Instruments
    CONFIG_DEBUG_KERNEL=y
    CONFIG_DEBUG_MISC=y
    # Memory Debugging
    # CONFIG_PAGE_EXTENSION is not set
    # CONFIG_DEBUG_PAGEALLOC is not set
    # CONFIG_PAGE_OWNER is not set
    # CONFIG_PAGE_POISONING is not set
    # CONFIG_DEBUG_RODATA_TEST is not set
    # CONFIG_DEBUG_WX is not set
    # CONFIG_DEBUG_OBJECTS is not set
    # CONFIG_SLUB_STATS is not set
    CONFIG_HAVE_DEBUG_KMEMLEAK=y
    # CONFIG_DEBUG_KMEMLEAK is not set
    # CONFIG_DEBUG_STACK_USAGE is not set
    # CONFIG_SCHED_STACK_END_CHECK is not set
    # CONFIG_DEBUG_VM is not set
    CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
    # CONFIG_DEBUG_VIRTUAL is not set
    # CONFIG_DEBUG_MEMORY_INIT is not set
    # CONFIG_DEBUG_HIGHMEM is not set
    CONFIG_CC_HAS_KASAN_GENERIC=y
    CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
    # end of Memory Debugging
    # CONFIG_DEBUG_SHIRQ is not set
    # Debug Oops, Lockups and Hangs
    # CONFIG_PANIC_ON_OOPS is not set
    CONFIG_PANIC_ON_OOPS_VALUE=0
    CONFIG_PANIC_TIMEOUT=0
    # CONFIG_SOFTLOCKUP_DETECTOR is not set
    # CONFIG_DETECT_HUNG_TASK is not set
    # CONFIG_WQ_WATCHDOG is not set
    # CONFIG_TEST_LOCKUP is not set
    # end of Debug Oops, Lockups and Hangs
    # Scheduler Debugging
    CONFIG_SCHED_DEBUG=y
    CONFIG_SCHED_INFO=y
    CONFIG_SCHEDSTATS=y
    # end of Scheduler Debugging
    # CONFIG_DEBUG_TIMEKEEPING is not set
    # CONFIG_DEBUG_PREEMPT is not set
    # Lock Debugging (spinlocks, mutexes, etc...)
    CONFIG_LOCK_DEBUGGING_SUPPORT=y
    # CONFIG_PROVE_LOCKING is not set
    # CONFIG_LOCK_STAT is not set
    # CONFIG_DEBUG_RT_MUTEXES is not set
    # CONFIG_DEBUG_SPINLOCK is not set
    # CONFIG_DEBUG_MUTEXES is not set
    # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
    # CONFIG_DEBUG_RWSEMS is not set
    # CONFIG_DEBUG_LOCK_ALLOC is not set
    # CONFIG_DEBUG_ATOMIC_SLEEP is not set
    # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
    # CONFIG_LOCK_TORTURE_TEST is not set
    # CONFIG_WW_MUTEX_SELFTEST is not set
    # CONFIG_SCF_TORTURE_TEST is not set
    # end of Lock Debugging (spinlocks, mutexes, etc...)
    # CONFIG_STACKTRACE is not set
    # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
    # CONFIG_DEBUG_KOBJECT is not set
    # Debug kernel data structures
    # CONFIG_DEBUG_LIST is not set
    # CONFIG_DEBUG_PLIST is not set
    # CONFIG_DEBUG_SG is not set
    # CONFIG_DEBUG_NOTIFIERS is not set
    # CONFIG_BUG_ON_DATA_CORRUPTION is not set
    # end of Debug kernel data structures
    # CONFIG_DEBUG_CREDENTIALS is not set
    # RCU Debugging
    # CONFIG_RCU_SCALE_TEST is not set
    # CONFIG_RCU_TORTURE_TEST is not set
    # CONFIG_RCU_REF_SCALE_TEST is not set
    CONFIG_RCU_CPU_STALL_TIMEOUT=21
    CONFIG_RCU_TRACE=y
    # CONFIG_RCU_EQS_DEBUG is not set
    # end of RCU Debugging
    # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
    # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
    # CONFIG_LATENCYTOP is not set
    CONFIG_HAVE_FUNCTION_TRACER=y
    CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
    CONFIG_HAVE_DYNAMIC_FTRACE=y
    CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
    CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
    CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
    CONFIG_HAVE_C_RECORDMCOUNT=y
    CONFIG_TRACE_CLOCK=y
    CONFIG_TRACING_SUPPORT=y
    # CONFIG_FTRACE is not set
    # CONFIG_SAMPLES is not set
    CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
    # CONFIG_STRICT_DEVMEM is not set
    # arm Debugging
    # CONFIG_ARM_PTDUMP_DEBUGFS is not set
    # CONFIG_UNWINDER_FRAME_POINTER is not set
    CONFIG_UNWINDER_ARM=y
    CONFIG_ARM_UNWIND=y
    # CONFIG_DEBUG_USER is not set
    # CONFIG_DEBUG_LL is not set
    CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
    CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
    # CONFIG_PID_IN_CONTEXTIDR is not set
    # CONFIG_CORESIGHT is not set
    # end of arm Debugging
    # Kernel Testing and Coverage
    # CONFIG_KUNIT is not set
    # CONFIG_NOTIFIER_ERROR_INJECTION is not set
    # CONFIG_FAULT_INJECTION is not set
    CONFIG_ARCH_HAS_KCOV=y
    CONFIG_CC_HAS_SANCOV_TRACE_PC=y
    # CONFIG_KCOV is not set
    CONFIG_RUNTIME_TESTING_MENU=y
    # CONFIG_LKDTM is not set
    # CONFIG_TEST_LIST_SORT is not set
    # CONFIG_TEST_MIN_HEAP is not set
    # CONFIG_TEST_SORT is not set
    # CONFIG_BACKTRACE_SELF_TEST is not set
    # CONFIG_RBTREE_TEST is not set
    # CONFIG_REED_SOLOMON_TEST is not set
    # CONFIG_INTERVAL_TREE_TEST is not set
    # CONFIG_PERCPU_TEST is not set
    # CONFIG_ATOMIC64_SELFTEST is not set
    # CONFIG_TEST_HEXDUMP is not set
    # CONFIG_TEST_STRING_HELPERS is not set
    # CONFIG_TEST_STRSCPY is not set
    # CONFIG_TEST_KSTRTOX is not set
    # CONFIG_TEST_PRINTF is not set
    # CONFIG_TEST_BITMAP is not set
    # CONFIG_TEST_UUID is not set
    # CONFIG_TEST_XARRAY is not set
    # CONFIG_TEST_OVERFLOW is not set
    # CONFIG_TEST_RHASHTABLE is not set
    # CONFIG_TEST_HASH is not set
    # CONFIG_TEST_IDA is not set
    # CONFIG_TEST_LKM is not set
    # CONFIG_TEST_BITOPS is not set
    # CONFIG_TEST_VMALLOC is not set
    # CONFIG_TEST_USER_COPY is not set
    # CONFIG_TEST_BPF is not set
    # CONFIG_TEST_BLACKHOLE_DEV is not set
    # CONFIG_FIND_BIT_BENCHMARK is not set
    # CONFIG_TEST_FIRMWARE is not set
    # CONFIG_TEST_SYSCTL is not set
    # CONFIG_TEST_UDELAY is not set
    # CONFIG_TEST_STATIC_KEYS is not set
    # CONFIG_TEST_KMOD is not set
    # CONFIG_TEST_MEMCAT_P is not set
    # CONFIG_TEST_STACKINIT is not set
    # CONFIG_TEST_MEMINIT is not set
    # CONFIG_TEST_FREE_PAGES is not set
    # CONFIG_MEMTEST is not set
    # end of Kernel Testing and Coverage
    # end of Kernel hacking
    我们没有从头开始构建根文件系统。 我们使用的是从 Processor SDK 版本08_02_00_24获取的以下 rootfs、未进行任何修改
    tisdk-default-image-am335x-evm
    您提到过的库、
    UM 库: git.ti.com/.../
    2.内核模块: git.ti.com/.../
    它们是否已集成到 tisdk-default-image-am335x-evm rootfs 中。 如果不是、请指导我们如何集成它们。
    您能否尝试以下命令:
    modprobe -r pvrsrvkm
    modprobe pvrsrvkm
    在您先前共享的引导日志中、我看不到 GPU 模块已初始化、因此可能不是完整的日志。 基于 kmscube 错误共享的耳塞、看起来仍然像 GPU 未初始化。 此外、您可能正在使用默认文件系统、但如果您重建了内核、您是否在/lib/modules 下看到 GPU 模块 /extra/pvrsrvkm.ko?
    Krunal
    Krunal、您好!
    我们按顺序执行了以下命令、
    modprobe pvrsrvkm
    root@am335x-evm:/home# modprobe -r pvrsrvkm
    root@am335x-evm:/home# modprobe pvrsrvkm
    dmesg 执行上述命令后、不显示任何特定操作
    root@am335x-evm:/home# dmesg
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 5.10.100-g7a7a3af903 (oe-user@oe-host) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025, GNU ld (GNU Toolchain for 2
    [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt: Machine model: Baxter AK98
    [    0.000000] Memory policy: Data cache writeback
    [    0.000000] efi: UEFI not found.
    [    0.000000] cma: Reserved 48 MiB at 0x9c800000
    [    0.000000] Zone ranges:
    [    0.000000]   Normal   [mem 0x0000000080000000-0x000000009fefffff]
    [    0.000000]   HighMem  empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000009fefffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009fefffff]
    [    0.000000] On node 0 totalpages: 130816
    [    0.000000]   Normal zone: 1150 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 130816 pages, LIFO batch:31
    [    0.000000] CPU: All CPU(s) started in SVC mode.
    [    0.000000] AM335X ES2.1 (neon)
    [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
    [    0.000000] pcpu-alloc: [0] 0
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129666
    [    0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=bff3ae51-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
    [    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
    [    0.000000] Memory: 452384K/523264K available (10240K kernel code, 695K rwdata, 3404K rodata, 1024K init, 280K bss, 21728K reserved, 49152K cma-reserved, 0K highmem)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000]  Trampoline variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] IRQ: Found an INTC at 0x(ptrval) (revision 5.0) with 128 interrupts
    [    0.000000] random: get_random_bytes called from start_kernel+0x30c/0x4c8 with crng_init=0
    [    0.000000] TI gptimer clocksource: always-on /ocp/interconnect@44c00000/segment@200000/target-module@31000
    [    0.000009] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [    0.000028] clocksource: dmtimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000352] TI gptimer clockevent: 24000000 Hz at /ocp/interconnect@48000000/segment@0/target-module@40000
    [    0.001266] Console: colour dummy device 80x30
    [    0.001307] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [    0.001314] This ensures that you still see kernel messages. Please
    [    0.001320] update your kernel commandline.
    [    0.001378] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
    [    0.090425] pid_max: default: 32768 minimum: 301
    [    0.090592] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.090608] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
    [    0.091500] CPU: Testing write buffer coherency: ok
    [    0.091578] CPU0: Spectre v2: using BPIALL workaround
    [    0.092454] Setting up static identity map for 0x80100000 - 0x80100060
    [    0.092597] rcu: Hierarchical SRCU implementation.
    [    0.092694] EFI services will not be available.
    [    0.093091] devtmpfs: initialized
    [    0.102596] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    0.102861] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.102888] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
    [    0.106391] pinctrl core: initialized pinctrl subsystem
    [    0.107398] DMI not present or invalid.
    [    0.107873] NET: Registered protocol family 16
    [    0.110160] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.127745] l3-aon-clkctrl:0000:0: failed to disable
    [    0.128965] thermal_sys: Registered thermal governor 'fair_share'
    [    0.128976] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.128993] thermal_sys: Registered thermal governor 'step_wise'
    [    0.129000] thermal_sys: Registered thermal governor 'user_space'
    [    0.129347] cpuidle: using governor ladder
    [    0.129384] cpuidle: using governor menu
    [    0.705160] No ATAGs?
    [    0.705192] hw-breakpoint: debug architecture 0x4 unsupported.
    [    0.727098] reg-fixed-voltage fixedregulator0: GPIO lookup for consumer (null)
    [    0.727115] reg-fixed-voltage fixedregulator0: using device tree for GPIO lookup
    [    0.727154] of_get_named_gpiod_flags: can't parse 'gpios' property of node '/fixedregulator0[0]'
    [    0.727170] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator0[0]'
    [    0.727181] reg-fixed-voltage fixedregulator0: using lookup tables for GPIO lookup
    [    0.727190] reg-fixed-voltage fixedregulator0: No GPIO consumer (null) found
    [    0.728189] iommu: Default domain type: Translated
    [    0.730169] SCSI subsystem initialized
    [    0.730858] mc: Linux media interface: v0.10
    [    0.730910] videodev: Linux video capture interface: v2.00
    [    0.731025] pps_core: LinuxPPS API ver. 1 registered
    [    0.731035] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.731058] PTP clock support registered
    [    0.731123] EDAC MC: Ver: 3.0.0
    [    0.732331] Advanced Linux Sound Architecture Driver Initialized.
    [    0.733694] clocksource: Switched to clocksource dmtimer
    [    0.741371] NET: Registered protocol family 2
    [    0.741605] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.742650] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
    [    0.742687] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
    [    0.742728] TCP bind hash table entries: 4096 (order: 2, 16384 bytes, linear)
    [    0.742767] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.742891] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
    [    0.742914] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
    [    0.743041] NET: Registered protocol family 1
    [    0.743611] RPC: Registered named UNIX socket transport module.
    [    0.743626] RPC: Registered udp transport module.
    [    0.743633] RPC: Registered tcp transport module.
    [    0.743640] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.743659] PCI: CLS 0 bytes, default 64
    [    0.744740] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
    [    0.745972] Initialise system trusted keyrings
    [    0.746365] workingset: timestamp_bits=14 max_order=17 bucket_order=3
    [    0.750018] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.750845] NFS: Registering the id_resolver key type
    [    0.750891] Key type id_resolver registered
    [    0.750901] Key type id_legacy registered
    [    0.750992] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.751004] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.751043] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.751658] Key type asymmetric registered
    [    0.751680] Asymmetric key parser 'x509' registered
    [    0.751736] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.751749] io scheduler mq-deadline registered
    [    0.751758] io scheduler kyber registered
    [    1.075307] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [    1.178374] debugfs: Directory '49000000.dma' with parent 'dmaengine' already present!
    [    1.178426] edma 49000000.dma: TI EDMA DMA engine driver
    [    1.190554] pinctrl-single 44e10800.pinmux: 142 pins, size 568
    [    1.194484] pwm-backlight backlight: GPIO lookup for consumer enable
    [    1.194505] pwm-backlight backlight: using device tree for GPIO lookup
    [    1.194543] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
    [    1.194560] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
    [    1.194574] pwm-backlight backlight: using lookup tables for GPIO lookup
    [    1.194582] pwm-backlight backlight: No GPIO consumer enable found
    [    1.194606] pwm-backlight backlight: supply power not found, using dummy regulator
    [    1.243387] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    1.248093] omap8250 44e09000.serial: GPIO lookup for consumer rs485-term
    [    1.248115] omap8250 44e09000.serial: using device tree for GPIO lookup
    [    1.248160] of_get_named_gpiod_flags: can't parse 'rs485-term-gpios' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]'
    [    1.248183] of_get_named_gpiod_flags: can't parse 'rs485-term-gpio' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@9000/serial@0[0]'
    [    1.248197] omap8250 44e09000.serial: using lookup tables for GPIO lookup
    [    1.248205] omap8250 44e09000.serial: No GPIO consumer rs485-term found
    [    1.248255] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 20, base_baud = 3000000) is a 8250
    [    1.926683] printk: console [ttyS0] enabled
    [    1.934195] omap_rng 48310000.rng: Random Number Generator ver. 20
    [    1.942960] random: fast init done
    [    1.946756] random: crng init done
    [    1.968180] panel-simple panel: GPIO lookup for consumer hpd
    [    1.968198] panel-simple panel: using device tree for GPIO lookup
    [    1.968238] of_get_named_gpiod_flags: can't parse 'hpd-gpios' property of node '/panel[0]'
    [    1.968255] of_get_named_gpiod_flags: can't parse 'hpd-gpio' property of node '/panel[0]'
    [    1.968267] panel-simple panel: using lookup tables for GPIO lookup
    [    1.968276] panel-simple panel: No GPIO consumer hpd found
    [    1.968305] panel-simple panel: supply power not found, using dummy regulator
    [    1.975916] panel-simple panel: GPIO lookup for consumer enable
    [    1.975927] panel-simple panel: using device tree for GPIO lookup
    [    1.975954] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/panel[0]'
    [    1.975970] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/panel[0]'
    [    1.975981] panel-simple panel: using lookup tables for GPIO lookup
    [    1.975988] panel-simple panel: No GPIO consumer enable found
    [    1.976003] panel-simple panel: Specify missing connector_type
    [    1.995551] brd: module loaded
    [    2.005968] loop: module loaded
    [    2.013907] mdio_bus fixed-0: GPIO lookup for consumer reset
    [    2.013928] mdio_bus fixed-0: using lookup tables for GPIO lookup
    [    2.013938] mdio_bus fixed-0: No GPIO consumer reset found
    [    2.018255] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset
    [    2.018275] mdio_bus 4a101000.mdio: using device tree for GPIO lookup
    [    2.018312] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000[0]'
    [    2.018335] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000[0]'
    [    2.018348] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup
    [    2.018356] mdio_bus 4a101000.mdio: No GPIO consumer reset found
    [    2.073735] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    2.082663] mdio_bus 4a101000.mdio:01: GPIO lookup for consumer reset
    [    2.082677] mdio_bus 4a101000.mdio:01: using device tree for GPIO lookup
    [    2.082721] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000/ethernet-phy@1[0]'
    [    2.082746] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/interconnect@4a000000/segment@0/target-module@100000/ethernet@0/mdio@1000/ethernet-phy@1[0]'
    [    2.082757] mdio_bus 4a101000.mdio:01: using lookup tables for GPIO lookup
    [    2.082764] mdio_bus 4a101000.mdio:01: No GPIO consumer reset found
    [    2.083344] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI TLK10X 10/100 Mbps PHY
    [    2.093334] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
    [    2.099812] cpsw 4a100000.ethernet: ALE Table size 1024
    [    2.105227] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
    [    2.112459] cpsw 4a100000.ethernet: Detected MACID = 98:f0:7b:12:f6:85
    [    2.121428] i2c /dev entries driver
    [    2.128412] cpuidle: enable-method property 'ti,am3352' found operations
    [    2.136093] sdhci: Secure Digital Host Controller Interface driver
    [    2.142311] sdhci: Copyright(c) Pierre Ossman
    [    2.147918] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.155146] sdhci-omap 48060000.mmc: GPIO lookup for consumer cd
    [    2.155161] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    2.155205] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    2.155228] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    2.155240] sdhci-omap 48060000.mmc: using lookup tables for GPIO lookup
    [    2.155249] sdhci-omap 48060000.mmc: No GPIO consumer cd found
    [    2.155257] sdhci-omap 48060000.mmc: GPIO lookup for consumer wp
    [    2.155264] sdhci-omap 48060000.mmc: using device tree for GPIO lookup
    [    2.155284] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    2.155304] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@0/target-module@60000/mmc@0[0]'
    [    2.155313] sdhci-omap 48060000.mmc: using lookup tables for GPIO lookup
    [    2.155320] sdhci-omap 48060000.mmc: No GPIO consumer wp found
    [    2.155494] sdhci-omap 48060000.mmc: supply vqmmc not found, using dummy regulator
    [    2.164664] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.174065] sdhci-omap 481d8000.mmc: GPIO lookup for consumer cd
    [    2.174079] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup
    [    2.174119] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    2.174141] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    2.174153] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup
    [    2.174161] sdhci-omap 481d8000.mmc: No GPIO consumer cd found
    [    2.174169] sdhci-omap 481d8000.mmc: GPIO lookup for consumer wp
    [    2.174175] sdhci-omap 481d8000.mmc: using device tree for GPIO lookup
    [    2.174195] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    2.174215] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@48000000/segment@100000/target-module@d8000/mmc@0[0]'
    [    2.174223] sdhci-omap 481d8000.mmc: using lookup tables for GPIO lookup
    [    2.174230] sdhci-omap 481d8000.mmc: No GPIO consumer wp found
    [    2.174378] sdhci-omap 481d8000.mmc: supply vqmmc not found, using dummy regulator
    [    2.197493] davinci-mcasp 4803c000.mcasp: IRQ common not found
    [    2.215458] NET: Registered protocol family 10
    [    2.221339] Segment Routing with IPv6
    [    2.228283] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.234314] mmc1: SDHCI controller on 481d8000.mmc [481d8000.mmc] using External DMA
    [    2.244158] NET: Registered protocol family 17
    [    2.249172] Key type dns_resolver registered
    [    2.254306] omap_voltage_late_init: Voltage driver support not added
    [    2.261844] Loading compiled-in X.509 certificates
    [    2.273629] mmc0: SDHCI controller on 48060000.mmc [48060000.mmc] using External DMA
    [    2.289754] gpio gpiochip0: (gpio-0-31): created GPIO range 0->7 ==> 44e10800.pinmux PIN 82->89
    [    2.289781] gpio gpiochip0: (gpio-0-31): created GPIO range 8->11 ==> 44e10800.pinmux PIN 52->55
    [    2.289793] gpio gpiochip0: (gpio-0-31): created GPIO range 12->15 ==> 44e10800.pinmux PIN 94->97
    [    2.289804] gpio gpiochip0: (gpio-0-31): created GPIO range 16->17 ==> 44e10800.pinmux PIN 71->72
    [    2.289815] gpio gpiochip0: (gpio-0-31): created GPIO range 18->18 ==> 44e10800.pinmux PIN 135->135
    [    2.289825] gpio gpiochip0: (gpio-0-31): created GPIO range 19->20 ==> 44e10800.pinmux PIN 108->109
    [    2.289842] gpio gpiochip0: (gpio-0-31): created GPIO range 21->21 ==> 44e10800.pinmux PIN 73->73
    [    2.289854] gpio gpiochip0: (gpio-0-31): created GPIO range 22->23 ==> 44e10800.pinmux PIN 8->9
    [    2.289865] gpio gpiochip0: (gpio-0-31): created GPIO range 26->27 ==> 44e10800.pinmux PIN 10->11
    [    2.289877] gpio gpiochip0: (gpio-0-31): created GPIO range 28->28 ==> 44e10800.pinmux PIN 74->74
    [    2.289888] gpio gpiochip0: (gpio-0-31): created GPIO range 29->29 ==> 44e10800.pinmux PIN 81->81
    [    2.289902] gpio gpiochip0: (gpio-0-31): created GPIO range 30->31 ==> 44e10800.pinmux PIN 28->29
    [    2.290274] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
    [    2.290365] gpio gpiochip0: registered GPIOs 0 to 31 on gpio-0-31
    [    2.290515] OMAP GPIO hardware version 0.1
    [    2.296084] i2c i2c-0: GPIO lookup for consumer scl
    [    2.296102] i2c i2c-0: using device tree for GPIO lookup
    [    2.296141] of_get_named_gpiod_flags: can't parse 'scl-gpios' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    2.296164] of_get_named_gpiod_flags: can't parse 'scl-gpio' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    2.296178] i2c i2c-0: using lookup tables for GPIO lookup
    [    2.296185] i2c i2c-0: No GPIO consumer scl found
    [    2.296205] i2c i2c-0: GPIO lookup for consumer sda
    [    2.296211] i2c i2c-0: using device tree for GPIO lookup
    [    2.296232] of_get_named_gpiod_flags: can't parse 'sda-gpios' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    2.296252] of_get_named_gpiod_flags: can't parse 'sda-gpio' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@b000/i2c@0[0]'
    [    2.296260] i2c i2c-0: using lookup tables for GPIO lookup
    [    2.296267] i2c i2c-0: No GPIO consumer sda found
    [    2.316252] mmc1: new high speed MMC card at address 0001
    [    2.324011] mmcblk1: mmc1:0001 Q2J54A 3.64 GiB
    [    2.329025] mmc0: new high speed SDXC card at address 59b4
    [    2.335250] tps65217-pmic: Failed to locate of_node [id: -1]
    [    2.343044] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB
    [    2.349920] mmcblk0: mmc0:59b4 SD64G 59.4 GiB
    [    2.355942] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB
    [    2.363219] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB, chardev (243:0)
    [    2.373818]  mmcblk0: p1 p2
    [    2.378710]  mmcblk1: p1 p2 p3 < p5 >
    [    2.392181] tps65217-bl: Failed to locate of_node [id: -1]
    [    2.401915] tps65217 0-0024: TPS65217 ID 0xe version 1.2
    [    2.407954] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 100 kHz
    [    2.414281] gpio gpiochip1: (gpio-32-63): created GPIO range 0->7 ==> 44e10800.pinmux PIN 0->7
    [    2.414304] gpio gpiochip1: (gpio-32-63): created GPIO range 8->11 ==> 44e10800.pinmux PIN 90->93
    [    2.414319] gpio gpiochip1: (gpio-32-63): created GPIO range 12->27 ==> 44e10800.pinmux PIN 12->27
    [    2.414333] gpio gpiochip1: (gpio-32-63): created GPIO range 28->31 ==> 44e10800.pinmux PIN 30->33
    [    2.414702] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
    [    2.414822] gpio gpiochip1: registered GPIOs 32 to 63 on gpio-32-63
    [    2.415357] gpio gpiochip2: (gpio-64-95): created GPIO range 0->17 ==> 44e10800.pinmux PIN 34->51
    [    2.415377] gpio gpiochip2: (gpio-64-95): created GPIO range 18->21 ==> 44e10800.pinmux PIN 77->80
    [    2.415391] gpio gpiochip2: (gpio-64-95): created GPIO range 22->31 ==> 44e10800.pinmux PIN 56->65
    [    2.415675] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
    [    2.415765] gpio gpiochip2: registered GPIOs 64 to 95 on gpio-64-95
    [    2.416223] gpio gpiochip3: (gpio-96-127): created GPIO range 0->4 ==> 44e10800.pinmux PIN 66->70
    [    2.416241] gpio gpiochip3: (gpio-96-127): created GPIO range 5->6 ==> 44e10800.pinmux PIN 98->99
    [    2.416255] gpio gpiochip3: (gpio-96-127): created GPIO range 7->8 ==> 44e10800.pinmux PIN 75->76
    [    2.416269] gpio gpiochip3: (gpio-96-127): created GPIO range 13->13 ==> 44e10800.pinmux PIN 141->141
    [    2.416282] gpio gpiochip3: (gpio-96-127): created GPIO range 14->21 ==> 44e10800.pinmux PIN 100->107
    [    2.416542] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3)
    [    2.416638] gpio gpiochip3: registered GPIOs 96 to 127 on gpio-96-127
    [    2.427196] omap_reset_deassert: timedout waiting for gfx:0
    [    2.432888] ti-sysc: probe of 5600fe00.target-module failed with error -110
    [    2.442930] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
    [    2.502392] Console: switching to colour frame buffer device 100x37
    [    2.523185] tilcdc 4830e000.lcdc: [drm] fb0: tilcdcdrmfb frame buffer device
    [    2.532600] ALSA device list:
    [    2.535752]   No soundcards found.
    [    2.614051] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    2.622345] VFS: Mounted root (ext4 filesystem) on device 179:34.
    [    2.637004] devtmpfs: mounted
    [    2.641873] Freeing unused kernel memory: 1024K
    [    2.647144] Run /sbin/init as init process
    [    2.651259]   with arguments:
    [    2.651265]     /sbin/init
    [    2.651270]   with environment:
    [    2.651275]     HOME=/
    [    2.651280]     TERM=linux
    [    3.010129] systemd[1]: System time before build time, advancing clock.
    [    3.061034] systemd[1]: systemd 244 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR -SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN)
    [    3.084118] systemd[1]: Detected architecture arm.
    [    3.125439] systemd[1]: Set hostname to <am335x-evm>.
    [    3.949038] systemd[1]: system-getty.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
    [    3.961718] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
    [    3.975316] systemd[1]: Created slice system-getty.slice.
    [    4.019117] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [    4.056113] systemd[1]: Created slice User and Session Slice.
    [    4.095495] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    4.135287] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    4.174737] systemd[1]: Reached target Paths.
    [    4.214526] systemd[1]: Reached target Remote File Systems.
    [    4.254186] systemd[1]: Reached target Slices.
    [    4.294696] systemd[1]: Reached target Swap.
    [    4.346742] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    4.384162] systemd[1]: Reached target RPC Port Mapper.
    [    4.443163] systemd[1]: Listening on Process Core Dump Socket.
    [    4.484901] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    4.581192] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
    [    4.592071] systemd[1]: Listening on Journal Socket (/dev/log).
    [    4.636628] systemd[1]: Listening on Journal Socket.
    [    4.677287] systemd[1]: Listening on Network Service Netlink Socket.
    [    4.715605] systemd[1]: Listening on udev Control Socket.
    [    4.755913] systemd[1]: Listening on udev Kernel Socket.
    [    4.796183] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
    [    4.813567] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.873207] systemd[1]: Mounting Kernel Debug File System...
    [    4.946071] systemd[1]: Mounting Temporary Directory (/tmp)...
    [    4.965399] systemd[1]: Condition check resulted in Create list of static device nodes for the current kernel being skipped.
    [    4.986796] systemd[1]: Starting Start psplash boot splash screen...
    [    5.049807] systemd[1]: Starting RPC Bind...
    [    5.094941] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
    [    5.146500] systemd[1]: Starting Journal Service...
    [    5.195289] systemd[1]: Starting Load Kernel Modules...
    [    5.231080] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    5.258131] cryptodev: loading out-of-tree module taints kernel.
    [    5.288954] cryptodev: driver 1.10 loaded.
    [    5.300942] systemd[1]: Starting udev Coldplug all Devices...
    [    5.363218] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    5.448484] systemd[1]: Started Start psplash boot splash screen.
    [    5.515029] systemd[1]: Started RPC Bind.
    [    5.535608] systemd[1]: Mounted POSIX Message Queue File System.
    [    5.555371] systemd[1]: Mounted Kernel Debug File System.
    [    5.585825] systemd[1]: Mounted Temporary Directory (/tmp).
    [    5.614524] systemd[1]: Started Load Kernel Modules.
    [    5.648183] systemd[1]: Started Remount Root and Kernel File Systems.
    [    5.705897] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
    [    5.757873] systemd[1]: Mounting Kernel Configuration File System...
    [    5.820503] systemd[1]: Started Start psplash-systemd progress communication helper.
    [    5.878706] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
    [    5.896731] systemd[1]: Starting Apply Kernel Variables...
    [    5.911778] systemd[1]: Condition check resulted in Create System Users being skipped.
    [    5.945096] systemd[1]: Starting Create Static Device Nodes in /dev...
    [    5.981895] systemd[1]: Started Journal Service.
    [    6.423124] systemd-journald[86]: Received client request to flush runtime journal.
    [    8.942357] remoteproc remoteproc0: wkup_m3 is available
    [    9.653434] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    9.662109] omap_rtc 44e3e000.rtc: char device (252:0)
    [    9.662143] omap_rtc 44e3e000.rtc: registered as rtc0
    [    9.733945] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
    [    9.742645] omap_rtc 44e3e000.rtc: GPIO lookup for consumer wp
    [    9.742653] omap_rtc 44e3e000.rtc: using device tree for GPIO lookup
    [    9.742715] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@3e000/rtc@0[0]'
    [    9.742739] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/interconnect@44c00000/segment@200000/target-module@3e000/rtc@0[0]'
    [    9.742755] omap_rtc 44e3e000.rtc: using lookup tables for GPIO lookup
    [    9.742764] omap_rtc 44e3e000.rtc: No GPIO consumer wp found
    [   10.370390] remoteproc remoteproc0: powering up wkup_m3
    [   10.474792] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 243276
    [   10.483255] remoteproc remoteproc0: remote processor wkup_m3 is now up
    [   10.489831] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
    [   10.820781] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer reset
    [   10.820807] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup
    [   10.820859] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/target-module@47400000/usb-phy@1300[0]'
    [   10.820882] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/target-module@47400000/usb-phy@1300[0]'
    [   10.820897] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup
    [   10.820906] am335x-phy-driver 47401300.usb-phy: No GPIO consumer reset found
    [   10.820914] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer vbus-detect
    [   10.820921] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup
    [   10.820941] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/target-module@47400000/usb-phy@1300[0]'
    [   10.820959] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/target-module@47400000/usb-phy@1300[0]'
    [   10.820967] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup
    [   10.820974] am335x-phy-driver 47401300.usb-phy: No GPIO consumer vbus-detect found
    [   10.821105] am335x-phy-driver 47401300.usb-phy: supply vcc not found, using dummy regulator
    [   10.905545] usbcore: registered new interface driver usbfs
    [   10.911144] usbcore: registered new interface driver hub
    [   10.945090] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer reset
    [   10.945117] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup
    [   10.945162] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/target-module@47400000/usb-phy@1b00[0]'
    [   10.945183] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/target-module@47400000/usb-phy@1b00[0]'
    [   10.945197] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup
    [   10.945206] am335x-phy-driver 47401b00.usb-phy: No GPIO consumer reset found
    [   10.945214] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer vbus-detect
    [   10.945220] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup
    [   10.945238] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/target-module@47400000/usb-phy@1b00[0]'
    [   10.945256] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/target-module@47400000/usb-phy@1b00[0]'
    [   10.945264] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup
    [   10.945272] am335x-phy-driver 47401b00.usb-phy: No GPIO consumer vbus-detect found
    [   10.945408] am335x-phy-driver 47401b00.usb-phy: supply vcc not found, using dummy regulator
    [   10.984106] usbcore: registered new device driver usb
    [   11.059804] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [   11.243924] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [   11.344104] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   11.352436] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   11.547282] usb usb1: Product: MUSB HDRC host driver
    [   11.552327] usb usb1: Manufacturer: Linux 5.10.100-g7a7a3af903 musb-hcd
    [   11.704032] usb usb1: SerialNumber: musb-hdrc.0
    [   11.754654] hub 1-0:1.0: USB hub found
    [   11.799450] hub 1-0:1.0: 1 port detected
    [   11.950938] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    [   12.042196] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
    [   12.144027] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
    [   12.152380] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [   12.334006] usb usb2: Product: MUSB HDRC host driver
    [   12.339044] usb usb2: Manufacturer: Linux 5.10.100-g7a7a3af903 musb-hcd
    [   12.502237] usb usb2: SerialNumber: musb-hdrc.1
    [   12.563085] hub 2-0:1.0: USB hub found
    [   12.599011] hub 2-0:1.0: 1 port detected
    [   12.774800] CAN device driver interface
    [   12.895376] c_can_platform 481cc000.can: c_can_platform device registered (regs=13b60fa0, irq=39)
    [   14.306521] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
    [   14.321847] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
    [   14.403386] omap-sham 53100000.sham: will run requests pump with realtime priority
    [   14.440177] omap-aes 53500000.aes: will run requests pump with realtime priority
    [   14.948166] PM: bootloader does not support rtc-only!
    [   22.653400] input: ti-tsc as /devices/platform/ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0d000.target-module/44e0d000.tscadc/TI-am335x-tsc.0.auto/input/input0
    [   28.666090] cpsw 4a100000.ethernet: initializing cpsw version 1.12 (0)
    [   28.838451] TI TLK10X 10/100 Mbps PHY 4a101000.mdio:01: attached PHY driver [TI TLK10X 10/100 Mbps PHY] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL)
    [   33.123840] vmmcsd_fixed: disabling
    [  150.302867] cryptd: max_cpu_qlen set to 1000
    [  150.786100] Initializing XFRM netlink socket
    是的、我们能够在/lib/modules 下看到 GPU 模块 /extra
    root@am335x-evm:/home# ls -al /lib/modules/5.10.100-g7a7a3af903/extra/
    total 436
    drwxr-xr-x 2 root root   4096 May 15  2022 .
    drwxr-xr-x 4 root root   4096 May 15  2022 ..
    -rw-r--r-- 1 root root  62768 May 14  2022 cryptodev.ko
    -rw-r--r-- 1 root root 342328 May 14  2022 pvrsrvkm.ko
    -rw-r--r-- 1 root root  17648 May 14  2022 uio_module_drv.ko
    今天、我们还尝试使用 Processor SDK 版本08_02_00_24中提供的预构建映像
    • 内核映像
    • tisdk-default-image-am335x-evm
    我们只更改了以下内容以启动我们的定制器件、
    • u-boot.img
    • MLO
    • DTB
    因此,内核和 rootfs 都没有重新构建,我们仍然面临着这一问题。
    正如您所说的、我们还认为问题是图形驱动程序未被初始化。
    挖掘后、找到此主题(e2e.ti.com/.../will-sgx-pvr-work-in-am3352-without-the-graphics-acceleration)
    提及 SGX (PVR)在 AM3352中不起作用、因为它没有图形加速器。
    这也许是图形驱动程序未被初始化的原因。 您能就此发表评论吗?
    是的、您是正确的、AM3352上没有 GPU、因此您将无法使用各种应用程序、如 kmscube/Weston。 我们在默认 SDK 中不支持软件 rasterization。
    Krunal
    感谢您的确认。
    我们能够使用'linuxfb'平台运行 QT 应用程序。
    ./QT_TEST_APP -platform linuxfb
    但是、在使用 linuxfb 平台时、触摸屏界面会遇到一些问题。 将为此增加一个单独的螺纹。
    将此标记为回答、以便将来访问此主题的其他人受益。
