[参考译文] TDA4VM:生成查找表以消除失真
Guru**** 2539500 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1181777/tda4vm-generate-look-up-table-to-remove-distortion
器件型号:TDA4VM
我使用 TDA4平台和 SDK 08.04。
我的摄像头是 FoV 119。
分辨率为1920x1080。
因为摄像机的 FOV 为119。
它需要查找表来消除失真。
请访问 e2e.ti.com/.../faq-tda4vm-how-to-create-a-ldc-mesh-lut-for-fisheye-distortion-correction-on-tda4
我从相机公司获得了相机失真表(distortion_table_FOV _ ParaxialHeight_RealHeight.xlsx)。
e2e.ti.com/.../distortion_5F00_table_5F00_fov_5F00_ParaxialHeight_5F00_RealHeight.xlsx
spec_file.txt 从 distortion_table_fov_ParaxialHeight_RealHeight.xlsx 的 A 和 C 列获取。
/* spec_file.txt */
e2e.ti.com/.../7418.spec_5F00_file.txt
gen_run.m、gen_lut.m 和 spec_file.txt 放置在同一目录中。
对于我的摄像机、Pit_in_mm 为0.003
F_IN_mm 对于我的摄像头为2.29
/* gen_run.m */
    s = 2;
    m = 4;
    pitch_in_mm = 0.003;
    f_in_mm = 2.29;
    W = 1920;
    H = 1080;
    hc = W/2;
    vc = H/2;
    Wmesh = ceil(W / 2^m) * 2^m;
    Hmesh = ceil(H / 2^m) * 2^m;
    gen_lut("spec_file.txt", pitch_in_mm, f_in_mm, Wmesh, Hmesh, hc, vc, s, m);
/* gen_lut.m */
function [] = gen_lut(spec_file, pitch_in_mm,f_in_mm, W, H, hc, vc,s ,m)
f = f_in_mm/pitch_in_mm ;
[h_p , v_p] = meshgrid( 0:W, 0:H);
[h_d,v_d] = xyz2distorted(h_p,v_p, f/s, hc, vc,spec_file, pitch_in_mm);
h_delta = round((h_d-h_p) * 8);
v_delta = round((v_d-v_p) * 8);
mh = h_delta(1:2^m:end, 1:2^m:end)';
mv = v_delta(1:2^m:end, 1:2^m:end)';
dlmwrite('mesh.txt', [mh(:), mv(:)],  'delimiter', ' ');
function [h_d, v_d] = xyz2distorted(x, y, z, hc, vc, spec_file, pitch_in_mm)
[phi, r] = cart2pol(x-hc, y-vc);
theta = atan2(r, z);
lut = read_spec(spec_file, pitch_in_mm);
r = interp1(lut(:,1), lut(:,2), theta);
[h_d, v_d] = pol2cart(phi, r);
h_d = h_d + hc;
v_d = v_d + vc;
function lut = read_spec(spec_file, pitch_in_mm)
lut0 = dlmread(spec_file);
theta = lut0(:,1)/180*pi;
lut = [theta, lut0(:,2)/pitch_in_mm];
我在 Octave 上运行 gen_run.m。
它生成 mesh.txt。
/* mesh.txt */
e2e.ti.com/.../1588.mesh.txt
/*生成 mesh.txt.bin */
Jason:~μ C/processor_sdk_vision_03_08_00_00/vision_sdk/apps/tools/LDC_mesh_table_convert$./convert.sh mesh.txt 1920 1080 16.
/* bin 至 win 10上的头文件、获取 mesh_lut_fov119.h */
D:\bin2c>bin2c.exe mesh.txt.bin mesh_lut_fov119.h fov119
/* mesh_lut_fov119.h */
e2e.ti.com/.../mesh_5F00_lut_5F00_fov119.h
我修改了 vision_apps\modules_src\app_LDC_modules.c
LCD_LUT_1920_1080替换为 FOV119DCC_CFG。
#include "app_ldc_module.h"
#include "ldc_lut_1920x1080.h"
#include "mesh_lut_fov119.h"
//static uint8_t  g_ldc_lut[] = LDC_LUT_1920_1080;
static uint8_t  g_ldc_lut[] = FOV119DCC_CFG;
当运行 run_app_tidl_od_cam.sh 时、它将导致分段故障。
我想问题是 FOV119DCC_CFG 的大小。
FOV119DCC_CFG 的大小仅为35328。
但 LCD_LUT_1920_1080的大小为537664。
如何生成537664尺寸查找表?
我是否有任何步进错误?
-Jason
    您好 Jason、
    首先、在"mesh.txt"中、有 nA 条目、这意味着输出视图超出摄像头 FOV 119度。
      不适用
      不适用
      -189-110
      -264 - 156
    您必须减少"s"、以便"mesh.txt"中的所有条目都有效。
    常见问题解答中的摄像头的 FOV 大于180度。
    [引用 userid="450304" URL"~/support/processors-group/processors/f/processors-forum/1181777/tda4vm-generate-look-up-table-to-remove-distortion ]我认为问题是 FOV119DCC_CFG 的大小。
    但 LCD_LUT_1920_1080的大小为537664。[/引用]
    35328是1920x1080且 m=4时的正确大小。
    537664适用于 m=2。
    尊敬的 Gang:
    感谢您的回复。
    我遵循你的建议。
    我将 gen_run.m 的"s"更改为1。
    我将 gen_run.m 的"m"更改为2。
    我获得了新的 mesh.txt
    /* mesh.txt */
    由于"M"从4更改为2、因此我使用新的 convert.sh 命令参数
    Jason:~μ C/processor_sdk_vision_03_08_00_00/vision_sdk/apps/tools/LDC_mesh_table_convert$./convert.sh mesh.txt 1920 1080 4.
    我不更改其他步骤。
    最后、我获得了新的 mesh_lut_fov119.h
    查找表的大小为  537664。
    我通过以下代码(app_LDC_module.c)使用新的查找表。
    static vx_status configure_dcc_params(vx_context context, LDCObj *ldcObj, SensorObj *sensorObj)
    我使用两个摄像头。
    摄像机0:FOV 61 (这使用虚拟查找表)
    摄像机1:FOV 119 (这使用新的查找表)
    请访问  /cfs-file/__key/communityserver-discussions-components-files/791/DifferentLDCTableForEachReplicatedNode.zip
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1027625/tda4vm-how-to-provide-different-set-of-parameters-in-replicated-node-like-two-look-up-table-for-ldc-module/3805717?tisearch=e2e-sitesearch&keymatch=LDC%25252520look%25252520up%25252520table#3805717
    我附上修改后的代码。
    e2e.ti.com/.../4370.app_5F00_ldc_5F00_module.h
    e2e.ti.com/.../3731.app_5F00_ldc_5F00_module.c
    但失真 不会消除。
    以下是 使用新查找表后的图像(摄像头1:FOV 119)。
    生成新的查找表时、我是否有任何错误步骤?
    为什么新的查找表不能消除失真?
    可以给我建议吗?
    -Jason
    您好 Jason、
    在上述步骤中、我没有发现任何明显的错误。
    您在运行应用程序时是否遇到任何错误?
    您能否共享新的"mesh.txt"和 LDC 输入/输出 YUV 图像?
    尊敬的 Gang:
    我的新 mesh.txt 文件。
    1408 792
    1391 786
    1374 779
    1357 773
    1340 766
    1323 760
    1306 754
    1290 747
    1273 741
    1257 734
    1240 728
    1224 721
    1208 715
    1191 709
    1175 702
    1159 696
    1143 689
    1127 683
    1112 676
    1096 670
    1080 663
    1065 656
    1049 650
    1034 643
    1019 637
    1004 630
    989 624
    974 617
    959 611
    944 604
    929 597
    915 591
    900 584
    886 578
    871 571
    857 564
    843 558
    829 551
    815 544
    801 538
    787 531
    773 524
    759 518
    746 511
    732 504
    719 498
    706 491
    693 484
    679 478
    667 471
    654 464
    641 458
    628 451
    616 444
    603 438
    591 431
    578 424
    566 418
    554 411
    542 404
    530 398
    518 391
    507 384
    495 378
    483 371
    472 364
    461 357
    450 351
    438 344
    427 337
    417 331
    406 324
    395 317
    384 311
    374 304
    364 297
    353 291
    343 284
    333 278
    323 271
    313 264
    304 258
    294 251
    284 245
    275 238
    266 231
    256 225
    247 218
    238 212
    229 205
    221 199
    212 192
    203 186
    195 179
    187 173
    178 166
    170 160
    162 153
    154 147
    146 140
    139 134
    131 127
    124 121
    116 115
    109 108
    102 102
    95 96
    88 89
    81 83
    74 77
    68 70
    61 64
    55 58
    49 52
    43 46
    36 39
    31 33
    25 27
    19 21
    13 15
    8 9
    3 3
    -3 -3
    -8 -9
    -13 -15
    -18 -21
    -23 -27
    -27 -33
    -32 -39
    -37 -45
    -41 -50
    -45 -56
    -49 -62
    -54 -68
    -58 -73
    -61 -79
    -65 -85
    -69 -90
    -72 -96
    -76 -101
    -79 -107
    -82 -112
    -85 -118
    -88 -123
    -91 -128
    -94 -134
    -97 -139
    -99 -144
    -102 -150
    -104 -155
    -107 -160
    -109 -165
    -111 -170
    -113 -175
    -115 -180
    -117 -185
    -118 -190
    -120 -195
    -121 -200
    -123 -205
    -124 -209
    -125 -214
    -126 -219
    -127 -223
    -128 -228
    -129 -232
    -130 -237
    -131 -241
    -131 -246
    -132 -250
    -132 -254
    -132 -259
    -132 -263
    -133 -267
    -133 -271
    -133 -275
    -132 -279
    -132 -283
    -132 -287
    -131 -291
    -131 -295
    -130 -298
    -130 -302
    -129 -306
    -128 -309
    -127 -313
    -127 -316
    -126 -320
    -124 -323
    -123 -326
    -122 -330
    -121 -333
    -119 -336
    -118 -339
    -117 -342
    -115 -345
    -113 -348
    -112 -351
    -110 -354
    -108 -356
    -106 -359
    -104 -362
    -103 -364
    -100 -367
    -98 -369
    -96 -371
    -94 -374
    -92 -376
    -90 -378
    -87 -380
    -85 -382
    -83 -384
    -80 -386
    -78 -388
    -75 -390
    -72 -391
    -70 -393
    -67 -395
    -65 -396
    -62 -398
    -59 -399
    -56 -400
    -54 -402
    -51 -403
    -48 -404
    -45 -405
    -42 -406
    -39 -407
    -36 -408
    -33 -408
    -30 -409
    -27 -410
    -24 -410
    -21 -411
    -18 -411
    -15 -412
    -12 -412
    -9 -412
    -6 -412
    -3 -413
    0 -413
    3 -413
    6 -412
    9 -412
    12 -412
    15 -412
    18 -411
    21 -411
    24 -410
    27 -410
    30 -409
    33 -408
    36 -408
    39 -407
    42 -406
    45 -405
    48 -404
    51 -403
    54 -402
    56 -400
    59 -399
    62 -398
    65 -396
    67 -395
    70 -393
    72 -391
    75 -390
    78 -388
    80 -386
    83 -384
    85 -382
    87 -380
    90 -378
    92 -376
    94 -374
    96 -371
    98 -369
    100 -367
    103 -364
    104 -362
    106 -359
    108 -356
    110 -354
    112 -351
    113 -348
    115 -345
    117 -342
    118 -339
    119 -336
    121 -333
    122 -330
    123 -326
    124 -323
    126 -320
    127 -316
    127 -313
    128 -309
    129 -306
    130 -302
    130 -298
    131 -295
    131 -291
    132 -287
    132 -283
    132 -279
    133 -275
    133 -271
    133 -267
    132 -263
    132 -259
    132 -254
    132 -250
    131 -246
    131 -241
    130 -237
    129 -232
    128 -228
    127 -223
    126 -219
    125 -214
    124 -209
    123 -205
    121 -200
    120 -195
    118 -190
    117 -185
    115 -180
    113 -175
    111 -170
    109 -165
    107 -160
    104 -155
    102 -150
    99 -144
    97 -139
    94 -134
    91 -128
    88 -123
    85 -118
    82 -112
    79 -107
    76 -101
    72 -96
    69 -90
    65 -85
    61 -79
    58 -73
    54 -68
    49 -62
    45 -56
    41 -50
    37 -45
    32 -39
    27 -33
    23 -27
    18 -21
    13 -15
    8 -9
    3 -3
    -3 3
    -8 9
    -13 15
    -19 21
    -25 27
    -31 33
    -36 39
    -43 46
    -49 52
    -55 58
    -61 64
    -68 70
    -74 77
    -81 83
    -88 89
    -95 96
    -102 102
    -109 108
    -116 115
    -124 121
    -131 127
    -139 134
    -146 140
    -154 147
    -162 153
    -170 160
    -178 166
    -187 173
    -195 179
    -203 186
    -212 192
    -221 199
    -229 205
    -238 212
    -247 218
    -256 225
    -266 231
    -275 238
    -284 245
    -294 251
    -304 258
    -313 264
    -323 271
    -333 278
    -343 284
    -353 291
    -364 297
    -374 304
    -384 311
    -395 317
    -406 324
    -417 331
    -427 337
    -438 344
    -450 351
    -461 357
    -472 364
    -483 371
    -495 378
    -507 384
    -518 391
    -530 398
    -542 404
    -554 411
    -566 418
    -578 424
    -591 431
    -603 438
    -616 444
    -628 451
    -641 458
    -654 464
    -667 471
    -679 478
    -693 484
    -706 491
    -719 498
    -732 504
    -746 511
    -759 518
    -773 524
    -787 531
    -801 538
    -815 544
    -829 551
    -843 558
    -857 564
    -871 571
    -886 578
    -900 584
    -915 591
    -929 597
    -944 604
    -959 611
    -974 617
    -989 624
    -1004 630
    -1019 637
    -1034 643
    -1049 650
    -1065 656
    -1080 663
    -1096 670
    -1112 676
    -1127 683
    -1143 689
    -1159 696
    -1175 702
    -1191 709
    -1208 715
    -1224 721
    -1240 728
    -1257 734
    -1273 741
    -1290 747
    -1306 754
    -1323 760
    -1340 766
    -1357 773
    -1374 779
    -1391 786
    -1408 792
    1402 783
    1384 776
    1367 770
    1350 764
    1334 757
    1317 751
    1300 744
    1283 738
    1267 732
    1250 725
    1234 719
    1217 712
    1201 706
    1185 699
    1169 693
    1153 687
    1137 680
    1121 674
    1105 667
    1090 661
    1074 654
    1058 648
    1043 641
    1028 635
    1012 628
    997 621
    982 615
    967 608
    952 602
    937 595
    923 589
    908 582
    893 576
    879 569
    865 562
    850 556
    836 549
    822 543
    808 536
    794 529
    780 523
    766 516
    753 509
    739 503
    726 496
    712 490
    699 483
    686 476
    673 470
    660 463
    647 456
    634 450
    621 443
    609 436
    596 430
    584 423
    572 416
    559 410
    547 403
    535 396
    523 390
    512 383
    500 376
    488 370
    477 363
    465 356
    454 350
    443 343
    432 336
    421 330
    410 323
    399 316
    388 310
    378 303
    367 297
    357 290
    347 283
    337 277
    326 270
    317 263
    307 257
    297 250
    287 244
    278 237
    268 231
    259 224
    250 217
    241 211
    232 204
    223 198
    214 191
    205 185
    197 178
    188 172
    180 165
    172 159
    164 152
    156 146
    148 139
    140 133
    132 127
    125 120
    117 114
    110 108
    103 101
    96 95
    89 89
    82 82
    75 76
    68 70
    62 63
    55 57
    49 51
    43 45
    36 39
    30 33
    24 26
    19 20
    13 14
    7 8
    2 2
    -3 -4
    -9 -10
    -14 -16
    -19 -22
    -24 -28
    -29 -34
    -33 -40
    -38 -45
    -42 -51
    -47 -57
    -51 -63
    -55 -69
    -59 -74
    -63 -80
    -67 -86
    -71 -91
    -74 -97
    -78 -102
    -81 -108
    -85 -113
    -88 -119
    -91 -124
    -94 -130
    -97 -135
    -99 -140
    -102 -146
    -105 -151
    -107 -156
    -110 -161
    -112 -166
    -114 -172
    -116 -177
    -118 -182
    -120 -187
    -122 -192
    -123 -196
    -125 -201
    -126 -206
    -128 -211
    -129 -216
    -130 -220
    -131 -225
    -132 -230
    -133 -234
    -134 -239
    -134 -243
    -135 -248
    -135 -252
    -136 -256
    -136 -261
    -136 -265
    -137 -269
    -137 -273
    -137 -277
    -137 -281
    -136 -285
    -136 -289
    -136 -293
    -135 -297
    -135 -301
    -134 -305
    -133 -308
    -133 -312
    -132 -316
    -131 -319
    -130 -323
    -129 -326
    -128 -329
    -127 -333
    -125 -336
    -124 -339
    -123 -342
    -121 -345
    -120 -348
    -118 -351
    -116 -354
    -115 -357
    -113 -360
    -111 -363
    -109 -365
    -107 -368
    -105 -370
    -103 -373
    -101 -375
    -99 -378
    -96 -380
    -94 -382
    -92 -384
    -89 -386
    -87 -388
    -84 -390
    -82 -392
    -79 -394
    -77 -396
    -74 -398
    -71 -399
    -69 -401
    -66 -402
    -63 -404
    -60 -405
    -58 -406
    -55 -408
    -52 -409
    -49 -410
    -46 -411
    -43 -412
    -40 -413
    -37 -414
    -34 -415
    -31 -415
    -28 -416
    -25 -417
    -22 -417
    -19 -417
    -16 -418
    -12 -418
    -9 -418
    -6 -419
    -3 -419
    0 -419
    3 -419
    6 -419
    9 -418
    12 -418
    16 -418
    19 -417
    22 -417
    25 -417
    28 -416
    31 -415
    34 -415
    37 -414
    40 -413
    43 -412
    46 -411
    49 -410
    52 -409
    55 -408
    58 -406
    60 -405
    63 -404
    66 -402
    69 -401
    71 -399
    74 -398
    77 -396
    79 -394
    82 -392
    84 -390
    87 -388
    89 -386
    92 -384
    94 -382
    96 -380
    99 -378
    101 -375
    103 -373
    105 -370
    107 -368
    109 -365
    111 -363
    113 -360
    115 -357
    116 -354
    118 -351
    120 -348
    121 -345
    123 -342
    124 -339
    125 -336
    127 -333
    128 -329
    129 -326
    130 -323
    131 -319
    132 -316
    133 -312
    133 -308
    134 -305
    135 -301
    135 -297
    136 -293
    136 -289
    136 -285
    137 -281
    137 -277
    137 -273
    137 -269
    136 -265
    136 -261
    136 -256
    135 -252
    135 -248
    134 -243
    134 -239
    133 -234
    132 -230
    131 -225
    130 -220
    129 -216
    128 -211
    126 -206
    125 -201
    123 -196
    122 -192
    120 -187
    118 -182
    116 -177
    114 -172
    112 -166
    110 -161
    107 -156
    105 -151
    102 -146
    99 -140
    97 -135
    94 -130
    91 -124
    88 -119
    85 -113
    81 -108
    78 -102
    74 -97
    71 -91
    67 -86
    63 -80
    59 -74
    55 -69
    51 -63
    47 -57
    42 -51
    38 -45
    33 -40
    29 -34
    24 -28
    19 -22
    14 -16
    9 -10
    3 -4
    -2 2
    -7 8
    -13 14
    -19 20
    -24 26
    -30 33
    -36 39
    -43 45
    -49 51
    -55 57
    -62 63
    -68 70
    -75 76
    -82 82
    -89 89
    -96 95
    -103 101
    -110 108
    -117 114
    -125 120
    -132 127
    -140 133
    -148 139
    -156 146
    -164 152
    -172 159
    -180 165
    -188 172
    -197 178
    -205 185
    -214 191
    -223 198
    -232 204
    -241 211
    -250 217
    -259 224
    -268 231
    -278 237
    -287 244
    -297 250
    -307 257
    -317 263
    -326 270
    -337 277
    -347 283
    -357 290
    -367 297
    -378 303
    -388 310
    -399 316
    -410 323
    -421 330
    -432 336
    -443 343
    -454 350
    -465 356
    -477 363
    -488 370
    -500 376
    -512 383
    -523 390
    -535 396
    -547 403
    -559 410
    -572 416
    -584 423
    -596 430
    -609 436
    -621 443
    -634 450
    -647 456
    -660 463
    -673 470
    -686 476
    -699 483
    -712 490
    -726 496
    -739 503
    -753 509
    -766 516
    -780 523
    -794 529
    -808 536
    -822 543
    -836 549
    -850 556
    -865 562
    -879 569
    -893 576
    -908 582
    -923 589
    -937 595
    -952 602
    -967 608
    -982 615
    -997 621
    -1012 628
    -1028 635
    -1043 641
    -1058 648
    -1074 654
    -1090 661
    -1105 667
    -1121 674
    -1137 680
    -1153 687
    -1169 693
    -1185 699
    -1201 706
    -1217 712
    -1234 719
    -1250 725
    -1267 732
    -1283 738
    -1300 744
    -1317 751
    -1334 757
    -1350 764
    -1367 770
    -1384 776
    -1402 783
    1395 773
    1378 767
    1361 761
    1344 754
    1327 748
    1310 742
    1294 735
    1277 729
    1260 722
    1244 716
    1227 710
    1211 703
    1195 697
    1178 690
    1162 684
    1146 678
    1130 671
    1115 665
    1099 658
    1083 652
    1067 645
    1052 639
    1036 632
    1021 626
    1006 619
    991 613
    976 606
    961 600
    946 593
    931 587
    916 580
    901 574
    887 567
    872 560
    858 554
    844 547
    829 541
    815 534
    801 528
    787 521
    774 514
    760 508
    746 501
    733 495
    719 488
    706 481
    692 475
    679 468
    666 461
    653 455
    640 448
    628 442
    615 435
    602 428
    590 422
    577 415
    565 408
    553 402
    541 395
    529 388
    517 382
    505 375
    493 369
    482 362
    470 355
    459 349
    447 342
    436 335
    425 329
    414 322
    403 315
    392 309
    382 302
    371 296
    361 289
    350 282
    340 276
    330 269
    320 263
    310 256
    300 249
    290 243
    281 236
    271 230
    262 223
    252 217
    243 210
    234 204
    225 197
    216 191
    208 184
    199 178
    190 171
    182 165
    174 158
    165 152
    157 145
    149 139
    141 132
    134 126
    126 120
    118 113
    111 107
    104 101
    96 94
    89 88
    82 82
    75 75
    69 69
    62 63
    55 57
    49 50
    43 44
    36 38
    30 32
    24 26
    18 20
    13 14
    7 7
    1 1
    -4 -5
    -9 -11
    -15 -17
    -20 -23
    -25 -28
    -30 -34
    -35 -40
    -39 -46
    -44 -52
    -48 -58
    -53 -64
    -57 -69
    -61 -75
    -65 -81
    -69 -86
    -73 -92
    -76 -98
    -80 -103
    -83 -109
    -87 -114
    -90 -120
    -93 -125
    -96 -131
    -99 -136
    -102 -141
    -105 -147
    -107 -152
    -110 -157
    -112 -162
    -115 -168
    -117 -173
    -119 -178
    -121 -183
    -123 -188
    -125 -193
    -126 -198
    -128 -203
    -130 -208
    -131 -212
    -132 -217
    -134 -222
    -135 -227
    -136 -231
    -137 -236
    -137 -240
    -138 -245
    -139 -249
    -139 -254
    -140 -258
    -140 -263
    -140 -267
    -141 -271
    -141 -275
    -141 -279
    -141 -284
    -141 -288
    -140 -292
    -140 -296
    -140 -299
    -139 -303
    -139 -307
    -138 -311
    -137 -314
    -136 -318
    -135 -322
    -134 -325
    -133 -329
    -132 -332
    -131 -335
    -130 -339
    -129 -342
    -127 -345
    -126 -348
    -124 -351
    -123 -354
    -121 -357
    -119 -360
    -117 -363
    -116 -366
    -114 -369
    -112 -371
    -110 -374
    -108 -376
    -105 -379
    -103 -381
    -101 -384
    -99 -386
    -96 -388
    -94 -390
    -91 -392
    -89 -394
    -86 -396
    -84 -398
    -81 -400
    -79 -402
    -76 -404
    -73 -405
    -70 -407
    -68 -408
    -65 -410
    -62 -411
    -59 -412
    -56 -414
    -53 -415
    -50 -416
    -47 -417
    -44 -418
    -41 -419
    -38 -420
    -35 -421
    -32 -421
    -29 -422
    -25 -422
    -22 -423
    -19 -423
    -16 -424
    -13 -424
    -10 -424
    -6 -425
    -3 -425
    0 -425
    3 -425
    6 -425
    10 -424
    13 -424
    16 -424
    19 -423
    22 -423
    25 -422
    29 -422
    32 -421
    35 -421
    38 -420
    41 -419
    44 -418
    47 -417
    50 -416
    53 -415
    56 -414
    59 -412
    62 -411
    65 -410
    68 -408
    70 -407
    73 -405
    76 -404
    79 -402
    81 -400
    84 -398
    86 -396
    89 -394
    91 -392
    94 -390
    96 -388
    99 -386
    101 -384
    103 -381
    105 -379
    108 -376
    110 -374
    112 -371
    114 -369
    116 -366
    117 -363
    119 -360
    121 -357
    123 -354
    124 -351
    126 -348
    127 -345
    129 -342
    130 -339
    131 -335
    132 -332
    133 -329
    134 -325
    135 -322
    136 -318
    137 -314
    138 -311
    139 -307
    139 -303
    140 -299
    140 -296
    140 -292
    141 -288
    141 -284
    141 -279
    141 -275
    141 -271
    140 -267
    140 -263
    140 -258
    139 -254
    139 -249
    138 -245
    137 -240
    137 -236
    136 -231
    135 -227
    134 -222
    132 -217
    131 -212
    130 -208
    128 -203
    126 -198
    125 -193
    123 -188
    121 -183
    119 -178
    117 -173
    115 -168
    112 -162
    110 -157
    107 -152
    105 -147
    102 -141
    99 -136
    96 -131
    93 -125
    90 -120
    87 -114
    83 -109
    80 -103
    76 -98
    73 -92
    69 -86
    65 -81
    61 -75
    57 -69
    53 -64
    48 -58
    44 -52
    39 -46
    35 -40
    30 -34
    25 -28
    20 -23
    15 -17
    9 -11
    4 -5
    -1 1
    -7 7
    -13 14
    -18 20
    -24 26
    -30 32
    -36 38
    -43 44
    -49 50
    -55 57
    -62 63
    -69 69
    -75 75
    -82 82
    -89 88
    -96 94
    -104 101
    -111 107
    -118 113
    -126 120
    -134 126
    -141 132
    -149 139
    -157 145
    -165 152
    -174 158
    -182 165
    -190 171
    -199 178
    -208 184
    -216 191
    -225 197
    -234 204
    -243 210
    -252 217
    -262 223
    -271 230
    -281 236
    -290 243
    -300 249
    -310 256
    -320 263
    -330 269
    -340 276
    -350 282
    -361 289
    -371 296
    -382 302
    -392 309
    -403 315
    -414 322
    -425 329
    -436 335
    -447 342
    -459 349
    -470 355
    -482 362
    -493 369
    -505 375
    -517 382
    -529 388
    -541 395
    -553 402
    -565 408
    -577 415
    -590 422
    -602 428
    -615 435
    -628 442
    -640 448
    -653 455
    -666 461
    -679 468
    -692 475
    -706 481
    -719 488
    -733 495
    -746 501
    -760 508
    -774 514
    -787 521
    -801 528
    -815 534
    -829 541
    -844 547
    -858 554
    -872 560
    -887 567
    -901 574
    -916 580
    -931 587
    -946 593
    -961 600
    -976 606
    -991 613
    -1006 619
    -1021 626
    -1036 632
    -1052 639
    -1067 645
    -1083 652
    -1099 658
    -1115 665
    -1130 671
    -1146 678
    -1162 684
    -1178 690
    -1195 697
    -1211 703
    -1227 710
    -1244 716
    -1260 722
    -1277 729
    -1294 735
    -1310 742
    -1327 748
    -1344 754
    -1361 761
    -1378 767
    -1395 773
    1389 764
    1372 758
    1355 751
    1338 745
    1321 739
    1304 732
    1287 726
    1271 720
    1254 713
    1237 707
    1221 701
    1205 694
    1188 688
    1172 682
    1156 675
    1140 669
    1124 662
    1108 656
    1092 649
    1077 643
    1061 637
    1045 630
    1030 624
    1015 617
    999 611
    984 604
    969 598
    954 591
    939 585
    924 578
    909 572
    895 565
    880 559
    866 552
    851 546
    837 539
    823 532
    809 526
    795 519
    781 513
    767 506
    753 500
    740 493
    726 486
    712 480
    699 473
    686 467
    673 460
    660 453
    647 447
    634 440
    621 434
    608 427
    596 420
    583 414
    571 407
    558 401
    546 394
    534 387
    522 381
    510 374
    498 367
    487 361
    475 354
    464 348
    452 341
    441 334
    430 328
    419 321
    408 315
    397 308
    386 301
    375 295
    365 288
    354 282
    344 275
    334 268
    323 262
    313 255
    303 249
    294 242
    284 236
    274 229
    265 223
    255 216
    246 209
    237 203
    228 196
    219 190
    210 183
    201 177
    192 170
    184 164
    175 158
    167 151
    159 145
    151 138
    143 132
    135 125
    127 119
    120 113
    112 106
    105 100
    97 94
    90 87
    83 81
    76 75
    69 69
    62 62
    56 56
    49 50
    43 44
    36 38
    30 31
    24 25
    18 19
    12 13
    6 7
    1 1
    -5 -5
    -10 -11
    -15 -17
    -21 -23
    -26 -29
    -31 -35
    -36 -41
    -40 -47
    -45 -53
    -50 -58
    -54 -64
    -58 -70
    -63 -76
    -67 -81
    -71 -87
    -75 -93
    -78 -98
    -82 -104
    -86 -110
    -89 -115
    -92 -121
    -96 -126
    -99 -132
    -102 -137
    -105 -142
    -107 -148
    -110 -153
    -113 -158
    -115 -163
    -118 -169
    -120 -174
    -122 -179
    -124 -184
    -126 -189
    -128 -194
    -130 -199
    -131 -204
    -133 -209
    -134 -214
    -136 -219
    -137 -223
    -138 -228
    -139 -233
    -140 -237
    -141 -242
    -142 -247
    -143 -251
    -143 -256
    -144 -260
    -144 -264
    -145 -269
    -145 -273
    -145 -277
    -145 -281
    -145 -285
    -145 -290
    -145 -294
    -144 -298
    -144 -302
    -143 -305
    -143 -309
    -142 -313
    -142 -317
    -141 -320
    -140 -324
    -139 -328
    -138 -331
    -137 -335
    -136 -338
    -134 -341
    -133 -345
    -132 -348
    -130 -351
    -129 -354
    -127 -357
    -126 -360
    -124 -363
    -122 -366
    -120 -369
    -118 -372
    -116 -374
    -114 -377
    -112 -380
    -110 -382
    -108 -385
    -106 -387
    -103 -389
    -101 -392
    -98 -394
    -96 -396
    -93 -398
    -91 -400
    -88 -402
    -86 -404
    -83 -406
    -80 -408
    -78 -409
    -75 -411
    -72 -413
    -69 -414
    -66 -416
    -63 -417
    -60 -418
    -57 -419
    -54 -421
    -51 -422
    -48 -423
    -45 -424
    -42 -425
    -39 -426
    -36 -426
    -32 -427
    -29 -428
    -26 -428
    -23 -429
    -20 -429
    -16 -430
    -13 -430
    -10 -430
    -7 -430
    -3 -430
    0 -430
    3 -430
    7 -430
    10 -430
    13 -430
    16 -430
    20 -429
    23 -429
    26 -428
    29 -428
    32 -427
    36 -426
    39 -426
    42 -425
    45 -424
    48 -423
    51 -422
    54 -421
    57 -419
    60 -418
    63 -417
    66 -416
    69 -414
    72 -413
    75 -411
    78 -409
    80 -408
    83 -406
    86 -404
    88 -402
    91 -400
    93 -398
    96 -396
    98 -394
    101 -392
    103 -389
    106 -387
    108 -385
    110 -382
    112 -380
    114 -377
    116 -374
    118 -372
    120 -369
    122 -366
    124 -363
    126 -360
    127 -357
    129 -354
    130 -351
    132 -348
    133 -345
    134 -341
    136 -338
    137 -335
    138 -331
    139 -328
    140 -324
    141 -320
    142 -317
    142 -313
    143 -309
    143 -305
    144 -302
    144 -298
    145 -294
    145 -290
    145 -285
    145 -281
    145 -277
    145 -273
    145 -269
    144 -264
    144 -260
    143 -256
    143 -251
    142 -247
    141 -242
    140 -237
    139 -233
    138 -228
    137 -223
    136 -219
    134 -214
    133 -209
    131 -204
    130 -199
    128 -194
    126 -189
    124 -184
    122 -179
    120 -174
    118 -169
    115 -163
    113 -158
    110 -153
    107 -148
    105 -142
    102 -137
    99 -132
    96 -126
    92 -121
    89 -115
    86 -110
    82 -104
    78 -98
    75 -93
    71 -87
    67 -81
    63 -76
    58 -70
    54 -64
    50 -58
    45 -53
    40 -47
    36 -41
    31 -35
    26 -29
    21 -23
    15 -17
    10 -11
    5 -5
    -1 1
    -6 7
    -12 13
    -18 19
    -24 25
    -30 31
    -36 38
    -43 44
    -49 50
    -56 56
    -62 62
    -69 69
    -76 75
    -83 81
    -90 87
    -97 94
    -105 100
    -112 106
    -120 113
    -127 119
    -135 125
    -143 132
    -151 138
    -159 145
    -167 151
    -175 158
    -184 164
    -192 170
    -201 177
    -210 183
    -219 190
    -228 196
    -237 203
    -246 209
    -255 216
    -265 223
    -274 229
    -284 236
    -294 242
    -303 249
    -313 255
    -323 262
    -334 268
    -344 275
    -354 282
    -365 288
    -375 295
    -386 301
    -397 308
    -408 315
    -419 321
    -430 328
    -441 334
    -452 341
    -464 348
    -475 354
    -487 361
    -498 367
    -510 374
    -522 381
    -534 387
    -546 394
    -558 401
    -571 407
    -583 414
    -596 420
    -608 427
    -621 434
    -634 440
    -647 447
    -660 453
    -673 460
    -686 467
    -699 473
    -712 480
    -726 486
    -740 493
    -753 500
    -767 506
    -781 513
    -795 519
    -809 526
    -823 532
    -837 539
    -851 546
    -866 552
    -880 559
    -895 565
    -909 572
    -924 578
    -939 585
    -954 591
    -969 598
    -984 604
    -999 611
    -1015 617
    -1030 624
    -1045 630
    -1061 637
    -1077 643
    -1092 649
    -1108 656
    -1124 662
    -1140 669
    -1156 675
    -1172 682
    -1188 688
    -1205 694
    -1221 701
    -1237 707
    -1254 713
    -1271 720
    -1287 726
    -1304 732
    -1321 739
    -1338 745
    -1355 751
    -1372 758
    -1389 764
    1383 755
    1366 748
    1348 742
    1331 736
    1315 730
    1298 723
    1281 717
    1264 711
    1248 704
    1231 698
    1215 692
    1198 685
    1182 679
    1166 673
    1150 666
    1134 660
    1118 654
    1102 647
    1086 641
    1070 634
    1055 628
    1039 621
    1024 615
    1008 609
    993 602
    978 596
    963 589
    948 583
    933 576
    918 570
    903 563
    888 557
    874 550
    859 544
    845 537
    831 531
    816 524
    802 518
    788 511
    774 505
    760 498
    747 491
    733 485
    719 478
    706 472
    693 465
    679 459
    666 452
    653 446
    640 439
    627 432
    614 426
    602 419
    589 413
    576 406
    564 399
    552 393
    540 386
    527 380
    515 373
    504 366
    492 360
    480 353
    468 347
    457 340
    446 333
    434 327
    423 320
    412 314
    401 307
    390 301
    379 294
    369 287
    358 281
    348 274
    337 268
    327 261
    317 255
    307 248
    297 242
    287 235
    277 228
    268 222
    258 215
    249 209
    239 202
    230 196
    221 189
    212 183
    203 176
    195 170
    186 164
    177 157
    169 151
    161 144
    153 138
    144 131
    136 125
    129 119
    121 112
    113 106
    106 100
    98 93
    91 87
    84 81
    77 74
    70 68
    63 62
    56 56
    49 49
    43 43
    37 37
    30 31
    24 25
    18 19
    12 13
    6 6
    0 0
    -5 -6
    -11 -12
    -16 -18
    -21 -24
    -27 -30
    -32 -35
    -37 -41
    -42 -47
    -46 -53
    -51 -59
    -55 -65
    -60 -71
    -64 -76
    -68 -82
    -72 -88
    -76 -93
    -80 -99
    -84 -105
    -88 -110
    -91 -116
    -94 -121
    -98 -127
    -101 -132
    -104 -138
    -107 -143
    -110 -148
    -113 -154
    -115 -159
    -118 -164
    -120 -170
    -123 -175
    -125 -180
    -127 -185
    -129 -190
    -131 -195
    -133 -200
    -135 -205
    -136 -210
    -138 -215
    -139 -220
    -141 -225
    -142 -229
    -143 -234
    -144 -239
    -145 -243
    -146 -248
    -146 -252
    -147 -257
    -148 -261
    -148 -266
    -149 -270
    -149 -275
    -149 -279
    -149 -283
    -149 -287
    -149 -291
    -149 -295
    -149 -299
    -148 -303
    -148 -307
    -147 -311
    -147 -315
    -146 -319
    -145 -323
    -144 -326
    -144 -330
    -143 -333
    -141 -337
    -140 -340
    -139 -344
    -138 -347
    -136 -350
    -135 -354
    -133 -357
    -132 -360
    -130 -363
    -129 -366
    -127 -369
    -125 -372
    -123 -375
    -121 -377
    -119 -380
    -117 -383
    -115 -385
    -113 -388
    -110 -390
    -108 -393
    -106 -395
    -103 -397
    -101 -400
    -98 -402
    -96 -404
    -93 -406
    -90 -408
    -88 -410
    -85 -412
    -82 -413
    -79 -415
    -76 -417
    -73 -418
    -70 -420
    -68 -421
    -65 -423
    -61 -424
    -58 -425
    -55 -426
    -52 -427
    -49 -428
    -46 -429
    -43 -430
    -39 -431
    -36 -432
    -33 -433
    -30 -433
    -26 -434
    -23 -434
    -20 -435
    -17 -435
    -13 -436
    -10 -436
    -7 -436
    -3 -436
    0 -436
    3 -436
    7 -436
    10 -436
    13 -436
    17 -435
    20 -435
    23 -434
    26 -434
    30 -433
    33 -433
    36 -432
    39 -431
    43 -430
    46 -429
    49 -428
    52 -427
    55 -426
    58 -425
    61 -424
    65 -423
    68 -421
    70 -420
    73 -418
    76 -417
    79 -415
    82 -413
    85 -412
    88 -410
    90 -408
    93 -406
    96 -404
    98 -402
    101 -400
    103 -397
    106 -395
    108 -393
    110 -390
    113 -388
    115 -385
    117 -383
    119 -380
    121 -377
    123 -375
    125 -372
    127 -369
    129 -366
    130 -363
    132 -360
    133 -357
    135 -354
    136 -350
    138 -347
    139 -344
    140 -340
    141 -337
    143 -333
    144 -330
    144 -326
    145 -323
    146 -319
    147 -315
    147 -311
    148 -307
    148 -303
    149 -299
    149 -295
    149 -291
    149 -287
    149 -283
    149 -279
    149 -275
    149 -270
    148 -266
    148 -261
    147 -257
    146 -252
    146 -248
    145 -243
    144 -239
    143 -234
    142 -229
    141 -225
    139 -220
    138 -215
    136 -210
    135 -205
    133 -200
    131 -195
    129 -190
    127 -185
    125 -180
    123 -175
    120 -170
    118 -164
    115 -159
    113 -154
    110 -148
    107 -143
    104 -138
    101 -132
    98 -127
    94 -121
    91 -116
    88 -110
    84 -105
    80 -99
    76 -93
    72 -88
    68 -82
    64 -76
    60 -71
    55 -65
    51 -59
    46 -53
    42 -47
    37 -41
    32 -35
    27 -30
    21 -24
    16 -18
    11 -12
    5 -6
    -0 0
    -6 6
    -12 13
    -18 19
    -24 25
    -30 31
    -37 37
    -43 43
    -49 49
    -56 56
    -63 62
    -70 68
    -77 74
    -84 81
    -91 87
    -98 93
    -106 100
    -113 106
    -121 112
    -129 119
    -136 125
    -144 131
    -153 138
    -161 144
    -169 151
    -177 157
    -186 164
    -195 170
    -203 176
    -212 183
    -221 189
    -230 196
    -239 202
    -249 209
    -258 215
    -268 222
    -277 228
    -287 235
    -297 242
    -307 248
    -317 255
    -327 261
    -337 268
    -348 274
    -358 281
    -369 287
    -379 294
    -390 301
    -401 307
    -412 314
    -423 320
    -434 327
    -446 333
    -457 340
    -468 347
    -480 353
    -492 360
    -504 366
    -515 373
    -527 380
    -540 386
    -552 393
    -564 399
    -576 406
    -589 413
    -602 419
    -614 426
    -627 432
    -640 439
    -653 446
    -666 452
    -679 459
    -693 465
    -706 472
    -719 478
    -733 485
    -747 491
    -760 498
    -774 505
    -788 511
    -802 518
    -816 524
    -831 531
    -845 537
    -859 544
    -874 550
    -888 557
    -903 563
    -918 570
    -933 576
    -948 583
    -963 589
    -978 596
    -993 602
    -1008 609
    -1024 615
    -1039 621
    -1055 628
    -1070 634
    -1086 641
    -1102 647
    -1118 654
    -1134 660
    -1150 666
    -1166 673
    -1182 679
    -1198 685
    -1215 692
    -1231 698
    -1248 704
    -1264 711
    -1281 717
    -1298 723
    -1315 730
    -1331 736
    -1348 742
    -1366 748
    -1383 755
    1376 746
    1359 739
    1342 733
    1325 727
    1308 721
    1291 714
    1275 708
    1258 702
    1241 696
    1225 689
    1208 683
    1192 677
    1176 670
    1159 664
    1143 658
    1127 651
    1111 645
    1095 638
    1079 632
    1064 626
    1048 619
    1033 613
    1017 607
    1002 600
    986 594
    971 587
    956 581
    941 574
    926 568
    911 561
    896 555
    882 548
    867 542
    853 536
    838 529
    824 523
    810 516
    796 510
    782 503
    768 497
    754 490
    740 483
    726 477
    713 470
    699 464
    686 457
    673 451
    660 444
    646 438
    633 431
    621 425
    608 418
    595 411
    582 405
    570 398
    557 392
    545 385
    533 379
    521 372
    509 365
    497 359
    485 352
    473 346
    462 339
    450 333
    439 326
    428 319
    416 313
    405 306
    394 300
    383 293
    373 287
    362 280
    351 274
    341 267
    331 261
    320 254
    310 247
    300 241
    290 234
    280 228
    271 221
    261 215
    252 208
    242 202
    233 195
    224 189
    215 182
    206 176
    197 170
    188 163
    180 157
    171 150
    163 144
    154 137
    146 131
    138 125
    130 118
    122 112
    115 106
    107 99
    99 93
    92 87
    85 80
    78 74
    70 68
    63 62
    57 55
    50 49
    43 43
    37 37
    30 31
    24 24
    18 18
    12 12
    6 6
    0 0
    -6 -6
    -11 -12
    -17 -18
    -22 -24
    -27 -30
    -33 -36
    -38 -42
    -43 -48
    -47 -54
    -52 -59
    -57 -65
    -61 -71
    -66 -77
    -70 -83
    -74 -88
    -78 -94
    -82 -100
    -86 -105
    -89 -111
    -93 -116
    -97 -122
    -100 -127
    -103 -133
    -106 -138
    -109 -144
    -112 -149
    -115 -154
    -118 -160
    -121 -165
    -123 -170
    -126 -176
    -128 -181
    -130 -186
    -132 -191
    -134 -196
    -136 -201
    -138 -206
    -140 -211
    -141 -216
    -143 -221
    -144 -226
    -145 -230
    -147 -235
    -148 -240
    -149 -245
    -150 -249
    -150 -254
    -151 -258
    -152 -263
    -152 -267
    -153 -272
    -153 -276
    -153 -280
    -153 -285
    -153 -289
    -153 -293
    -153 -297
    -153 -301
    -153 -305
    -152 -309
    -152 -313
    -151 -317
    -151 -321
    -150 -325
    -149 -328
    -148 -332
    -147 -336
    -146 -339
    -145 -343
    -144 -346
    -142 -349
    -141 -353
    -140 -356
    -138 -359
    -137 -362
    -135 -366
    -133 -369
    -131 -372
    -130 -375
    -128 -377
    -126 -380
    -124 -383
    -122 -386
    -119 -388
    -117 -391
    -115 -393
    -113 -396
    -110 -398
    -108 -401
    -105 -403
    -103 -405
    -100 -407
    -98 -409
    -95 -411
    -92 -413
    -89 -415
    -87 -417
    -84 -419
    -81 -421
    -78 -422
    -75 -424
    -72 -425
    -69 -427
    -66 -428
    -63 -429
    -60 -431
    -56 -432
    -53 -433
    -50 -434
    -47 -435
    -44 -436
    -40 -437
    -37 -437
    -34 -438
    -30 -439
    -27 -439
    -24 -440
    -20 -440
    -17 -441
    -14 -441
    -10 -441
    -7 -441
    -3 -442
    0 -442
    3 -442
    7 -441
    10 -441
    14 -441
    17 -441
    20 -440
    24 -440
    27 -439
    30 -439
    34 -438
    37 -437
    40 -437
    44 -436
    47 -435
    50 -434
    53 -433
    56 -432
    60 -431
    63 -429
    66 -428
    69 -427
    72 -425
    75 -424
    78 -422
    81 -421
    84 -419
    87 -417
    89 -415
    92 -413
    95 -411
    98 -409
    100 -407
    103 -405
    105 -403
    108 -401
    110 -398
    113 -396
    115 -393
    117 -391
    119 -388
    122 -386
    124 -383
    126 -380
    128 -377
    130 -375
    131 -372
    133 -369
    135 -366
    137 -362
    138 -359
    140 -356
    141 -353
    142 -349
    144 -346
    145 -343
    146 -339
    147 -336
    148 -332
    149 -328
    150 -325
    151 -321
    151 -317
    152 -313
    152 -309
    153 -305
    153 -301
    153 -297
    153 -293
    153 -289
    153 -285
    153 -280
    153 -276
    153 -272
    152 -267
    152 -263
    151 -258
    150 -254
    150 -249
    149 -245
    148 -240
    147 -235
    145 -230
    144 -226
    143 -221
    141 -216
    140 -211
    138 -206
    136 -201
    134 -196
    132 -191
    130 -186
    128 -181
    126 -176
    123 -170
    121 -165
    118 -160
    115 -154
    112 -149
    109 -144
    106 -138
    103 -133
    100 -127
    97 -122
    93 -116
    89 -111
    86 -105
    82 -100
    78 -94
    74 -88
    70 -83
    66 -77
    61 -71
    57 -65
    52 -59
    47 -54
    43 -48
    38 -42
    33 -36
    27 -30
    22 -24
    17 -18
    11 -12
    6 -6
    -0 0
    -6 6
    -12 12
    -18 18
    -24 24
    -30 31
    -37 37
    -43 43
    -50 49
    -57 55
    -63 62
    -70 68
    -78 74
    -85 80
    -92 87
    -99 93
    -107 99
    -115 106
    -122 112
    -130 118
    -138 125
    -146 131
    -154 137
    -163 144
    -171 150
    -180 157
    -188 163
    -197 170
    -206 176
    -215 182
    -224 189
    -233 195
    -242 202
    -252 208
    -261 215
    -271 221
    -280 228
    -290 234
    -300 241
    -310 247
    -320 254
    -331 261
    -341 267
    -351 274
    -362 280
    -373 287
    -383 293
    -394 300
    -405 306
    -416 313
    -428 319
    -439 326
    -450 333
    -462 339
    -473 346
    -485 352
    -497 359
    -509 365
    -521 372
    -533 379
    -545 385
    -557 392
    -570 398
    -582 405
    -595 411
    -608 418
    -621 425
    -633 431
    -646 438
    -660 444
    -673 451
    -686 457
    -699 464
    -713 470
    -726 477
    -740 483
    -754 490
    -768 497
    -782 503
    -796 510
    -810 516
    -824 523
    -838 529
    -853 536
    -867 542
    -882 548
    -896 555
    -911 561
    -926 568
    -941 574
    -956 581
    -971 587
    -986 594
    -1002 600
    -1017 607
    -1033 613
    -1048 619
    -1064 626
    -1079 632
    -1095 638
    -1111 645
    -1127 651
    -1143 658
    -1159 664
    -1176 670
    -1192 677
    -1208 683
    -1225 689
    -1241 696
    -1258 702
    -1275 708
    -1291 714
    -1308 721
    -1325 727
    -1342 733
    -1359 739
    -1376 746
    1370 737
    1353 730
    1336 724
    1319 718
    1302 712
    1285 705
    1268 699
    1252 693
    1235 687
    1218 680
    1202 674
    1186 668
    1169 662
    1153 655
    1137 649
    1121 643
    1105 636
    1089 630
    1073 624
    1057 617
    1042 611
    1026 604
    1011 598
    995 592
    980 585
    965 579
    950 572
    935 566
    920 560
    905 553
    890 547
    875 540
    861 534
    846 527
    832 521
    818 514
    803 508
    789 501
    775 495
    761 489
    747 482
    734 476
    720 469
    706 463
    693 456
    679 449
    666 443
    653 436
    640 430
    627 423
    614 417
    601 410
    588 404
    576 397
    563 391
    551 384
    539 378
    526 371
    514 365
    502 358
    490 351
    479 345
    467 338
    455 332
    444 325
    432 319
    421 312
    410 306
    399 299
    388 293
    377 286
    366 279
    355 273
    345 266
    334 260
    324 253
    314 247
    304 240
    294 234
    284 227
    274 221
    264 214
    255 208
    245 201
    236 195
    226 189
    217 182
    208 176
    199 169
    190 163
    182 156
    173 150
    165 144
    156 137
    148 131
    140 124
    132 118
    124 112
    116 105
    108 99
    101 93
    93 86
    86 80
    78 74
    71 68
    64 61
    57 55
    50 49
    44 43
    37 37
    31 30
    24 24
    18 18
    12 12
    6 6
    -0 -0
    -6 -6
    -12 -12
    -17 -18
    -23 -24
    -28 -30
    -33 -36
    -38 -42
    -44 -48
    -48 -54
    -53 -60
    -58 -66
    -62 -71
    -67 -77
    -71 -83
    -76 -89
    -80 -94
    -84 -100
    -88 -106
    -91 -111
    -95 -117
    -99 -122
    -102 -128
    -105 -133
    -109 -139
    -112 -144
    -115 -150
    -118 -155
    -121 -160
    -123 -166
    -126 -171
    -128 -176
    -131 -181
    -133 -187
    -135 -192
    -137 -197
    -139 -202
    -141 -207
    -143 -212
    -145 -217
    -146 -222
    -148 -227
    -149 -231
    -150 -236
    -151 -241
    -152 -246
    -153 -250
    -154 -255
    -155 -259
    -156 -264
    -156 -268
    -157 -273
    -157 -277
    -157 -282
    -157 -286
    -157 -290
    -157 -294
    -157 -299
    -157 -303
    -157 -307
    -157 -311
    -156 -315
    -156 -319
    -155 -322
    -154 -326
    -154 -330
    -153 -334
    -152 -337
    -151 -341
    -150 -345
    -148 -348
    -147 -352
    -146 -355
    -144 -358
    -143 -362
    -141 -365
    -140 -368
    -138 -371
    -136 -374
    -134 -377
    -133 -380
    -131 -383
    -129 -386
    -126 -388
    -124 -391
    -122 -394
    -120 -396
    -117 -399
    -115 -401
    -113 -404
    -110 -406
    -108 -408
    -105 -411
    -102 -413
    -100 -415
    -97 -417
    -94 -419
    -91 -421
    -88 -422
    -85 -424
    -83 -426
    -80 -428
    -77 -429
    -73 -431
    -70 -432
    -67 -433
    -64 -435
    -61 -436
    -58 -437
    -54 -438
    -51 -439
    -48 -440
    -44 -441
    -41 -442
    -38 -443
    -34 -444
    -31 -444
    -28 -445
    -24 -445
    -21 -446
    -17 -446
    -14 -446
    -10 -447
    -7 -447
    -3 -447
    0 -447
    3 -447
    7 -447
    10 -447
    14 -446
    17 -446
    21 -446
    24 -445
    28 -445
    31 -444
    34 -444
    38 -443
    41 -442
    44 -441
    48 -440
    51 -439
    54 -438
    58 -437
    61 -436
    64 -435
    67 -433
    70 -432
    73 -431
    77 -429
    80 -428
    83 -426
    85 -424
    88 -422
    91 -421
    94 -419
    97 -417
    100 -415
    102 -413
    105 -411
    108 -408
    110 -406
    113 -404
    115 -401
    117 -399
    120 -396
    122 -394
    124 -391
    126 -388
    129 -386
    131 -383
    133 -380
    134 -377
    136 -374
    138 -371
    140 -368
    141 -365
    143 -362
    144 -358
    146 -355
    147 -352
    148 -348
    150 -345
    151 -341
    152 -337
    153 -334
    154 -330
    154 -326
    155 -322
    156 -319
    156 -315
    157 -311
    157 -307
    157 -303
    157 -299
    157 -294
    157 -290
    157 -286
    157 -282
    157 -277
    157 -273
    156 -268
    156 -264
    155 -259
    154 -255
    153 -250
    152 -246
    151 -241
    150 -236
    149 -231
    148 -227
    146 -222
    145 -217
    143 -212
    141 -207
    139 -202
    137 -197
    135 -192
    133 -187
    131 -181
    128 -176
    126 -171
    123 -166
    121 -160
    118 -155
    115 -150
    112 -144
    109 -139
    105 -133
    102 -128
    99 -122
    95 -117
    91 -111
    88 -106
    84 -100
    80 -94
    76 -89
    71 -83
    67 -77
    62 -71
    58 -66
    53 -60
    48 -54
    44 -48
    38 -42
    33 -36
    28 -30
    23 -24
    17 -18
    12 -12
    6 -6
    0 -0
    -6 6
    -12 12
    -18 18
    -24 24
    -31 30
    -37 37
    -44 43
    -50 49
    -57 55
    -64 61
    -71 68
    -78 74
    -86 80
    -93 86
    -101 93
    -108 99
    -116 105
    -124 112
    -132 118
    -140 124
    -148 131
    -156 137
    -165 144
    -173 150
    -182 156
    -190 163
    -199 169
    -208 176
    -217 182
    -226 189
    -236 195
    -245 201
    -255 208
    -264 214
    -274 221
    -284 227
    -294 234
    -304 240
    -314 247
    -324 253
    -334 260
    -345 266
    -355 273
    -366 279
    -377 286
    -388 293
    -399 299
    -410 306
    -421 312
    -432 319
    -444 325
    -455 332
    -467 338
    -479 345
    -490 351
    -502 358
    -514 365
    -526 371
    -539 378
    -551 384
    -563 391
    -576 397
    -588 404
    -601 410
    -614 417
    -627 423
    -640 430
    -653 436
    -666 443
    -679 449
    -693 456
    -706 463
    -720 469
    -734 476
    -747 482
    -761 489
    -775 495
    -789 501
    -803 508
    -818 514
    -832 521
    -846 527
    -861 534
    -875 540
    -890 547
    -905 553
    -920 560
    -935 566
    -950 572
    -965 579
    -980 585
    -995 592
    -1011 598
    -1026 604
    -1042 611
    -1057 617
    -1073 624
    -1089 630
    -1105 636
    -1121 643
    -1137 649
    -1153 655
    -1169 662
    -1186 668
    -1202 674
    -1218 680
    -1235 687
    -1252 693
    -1268 699
    -1285 705
    -1302 712
    -1319 718
    -1336 724
    -1353 730
    -1370 737
    1364 728
    1347 721
    1330 715
    1313 709
    1296 703
    1279 697
    1262 690
    1245 684
    1229 678
    1212 672
    1196 665
    1179 659
    1163 653
    1147 647
    1131 640
    1114 634
    1098 628
    1083 621
    1067 615
    1051 609
    1035 602
    1020 596
    1004 590
    989 583
    974 577
    958 571
    943 564
    928 558
    913 551
    898 545
    884 539
    869 532
    854 526
    840 519
    825 513
    811 506
    797 500
    783 494
    769 487
    755 481
    741 474
    727 468
    713 461
    700 455
    686 448
    673 442
    660 435
    646 429
    633 422
    620 416
    607 409
    595 403
    582 396
    569 390
    557 383
    544 377
    532 370
    520 364
    508 357
    496 351
    484 344
    472 338
    460 331
    449 325
    437 318
    426 311
    415 305
    403 298
    392 292
    381 285
    370 279
    360 272
    349 266
    338 259
    328 253
    318 246
    307 240
    297 233
    287 227
    277 220
    267 214
    258 208
    248 201
    239 195
    229 188
    220 182
    211 175
    202 169
    193 162
    184 156
    175 150
    167 143
    158 137
    150 130
    142 124
    133 118
    125 111
    117 105
    110 99
    102 93
    94 86
    87 80
    79 74
    72 67
    65 61
    58 55
    51 49
    44 43
    38 36
    31 30
    24 24
    18 18
    12 12
    6 6
    -0 -0
    -6 -6
    -12 -12
    -18 -18
    -23 -24
    -29 -30
    -34 -36
    -39 -42
    -44 -48
    -49 -54
    -54 -60
    -59 -66
    -64 -72
    -68 -77
    -73 -83
    -77 -89
    -81 -95
    -85 -100
    -89 -106
    -93 -111
    -97 -117
    -101 -123
    -104 -128
    -108 -134
    -111 -139
    -114 -145
    -117 -150
    -120 -155
    -123 -161
    -126 -166
    -129 -171
    -131 -177
    -134 -182
    -136 -187
    -138 -192
    -140 -197
    -142 -202
    -144 -208
    -146 -213
    -148 -217
    -149 -222
    -151 -227
    -152 -232
    -154 -237
    -155 -242
    -156 -246
    -157 -251
    -158 -256
    -159 -260
    -159 -265
    -160 -270
    -161 -274
    -161 -278
    -161 -283
    -162 -287
    -162 -291
    -162 -296
    -162 -300
    -162 -304
    -161 -308
    -161 -312
    -161 -316
    -160 -320
    -159 -324
    -159 -328
    -158 -332
    -157 -335
    -156 -339
    -155 -343
    -154 -346
    -153 -350
    -152 -353
    -151 -357
    -149 -360
    -148 -364
    -146 -367
    -145 -370
    -143 -373
    -141 -376
    -139 -379
    -137 -382
    -135 -385
    -133 -388
    -131 -391
    -129 -394
    -127 -396
    -125 -399
    -122 -402
    -120 -404
    -118 -407
    -115 -409
    -112 -411
    -110 -414
    -107 -416
    -104 -418
    -102 -420
    -99 -422
    -96 -424
    -93 -426
    -90 -428
    -87 -429
    -84 -431
    -81 -433
    -78 -434
    -75 -436
    -72 -437
    -69 -439
    -65 -440
    -62 -441
    -59 -442
    -55 -443
    -52 -445
    -49 -445
    -45 -446
    -42 -447
    -39 -448
    -35 -449
    -32 -449
    -28 -450
    -25 -450
    -21 -451
    -18 -451
    -14 -452
    -11 -452
    -7 -452
    -4 -452
    0 -452
    4 -452
    7 -452
    11 -452
    14 -452
    18 -451
    21 -451
    25 -450
    28 -450
    32 -449
    35 -449
    39 -448
    42 -447
    45 -446
    49 -445
    52 -445
    55 -443
    59 -442
    62 -441
    65 -440
    69 -439
    72 -437
    75 -436
    78 -434
    81 -433
    84 -431
    87 -429
    90 -428
    93 -426
    96 -424
    99 -422
    102 -420
    104 -418
    107 -416
    110 -414
    112 -411
    115 -409
    118 -407
    120 -404
    122 -402
    125 -399
    127 -396
    129 -394
    131 -391
    133 -388
    135 -385
    137 -382
    139 -379
    141 -376
    143 -373
    145 -370
    146 -367
    148 -364
    149 -360
    151 -357
    152 -353
    153 -350
    154 -346
    155 -343
    156 -339
    157 -335
    158 -332
    159 -328
    159 -324
    160 -320
    161 -316
    161 -312
    161 -308
    162 -304
    162 -300
    162 -296
    162 -291
    162 -287
    161 -283
    161 -278
    161 -274
    160 -270
    159 -265
    159 -260
    158 -256
    157 -251
    156 -246
    155 -242
    154 -237
    152 -232
    151 -227
    149 -222
    148 -217
    146 -213
    144 -208
    142 -202
    140 -197
    138 -192
    136 -187
    134 -182
    131 -177
    129 -171
    126 -166
    123 -161
    120 -155
    117 -150
    114 -145
    111 -139
    108 -134
    104 -128
    101 -123
    97 -117
    93 -111
    89 -106
    85 -100
    81 -95
    77 -89
    73 -83
    68 -77
    64 -72
    59 -66
    54 -60
    49 -54
    44 -48
    39 -42
    34 -36
    29 -30
    23 -24
    18 -18
    12 -12
    6 -6
    0 -0
    -6 6
    -12 12
    -18 18
    -24 24
    -31 30
    -38 36
    -44 43
    -51 49
    -58 55
    -65 61
    -72 67
    -79 74
    -87 80
    -94 86
    -102 93
    -110 99
    -117 105
    -125 111
    -133 118
    -142 124
    -150 130
    -158 137
    -167 143
    -175 150
    -184 156
    -193 162
    -202 169
    -211 175
    -220 182
    -229 188
    -239 195
    -248 201
    -258 208
    -267 214
    -277 220
    -287 227
    -297 233
    -307 240
    -318 246
    -328 253
    -338 259
    -349 266
    -360 272
    -370 279
    -381 285
    -392 292
    -403 298
    -415 305
    -426 311
    -437 318
    -449 325
    -460 331
    -472 338
    -484 344
    -496 351
    -508 357
    -520 364
    -532 370
    -544 377
    -557 383
    -569 390
    -582 396
    -595 403
    -607 409
    -620 416
    -633 422
    -646 429
    -660 435
    -673 442
    -686 448
    -700 455
    -713 461
    -727 468
    -741 474
    -755 481
    -769 487
    -783 494
    -797 500
    -811 506
    -825 513
    -840 519
    -854 526
    -869 532
    -884 539
    -898 545
    -913 551
    -928 558
    -943 564
    -958 571
    -974 577
    -989 583
    -1004 590
    -1020 596
    -1035 602
    -1051 609
    -1067 615
    -1083 621
    -1098 628
    -1114 634
    -1131 640
    -1147 647
    -1163 653
    -1179 659
    -1196 665
    -1212 672
    -1229 678
    -1245 684
    -1262 690
    -1279 697
    -1296 703
    -1313 709
    -1330 715
    -1347 721
    -1364 728
    1358 719
    1341 712
    1324 706
    1307 700
    1290 694
    1273 688
    1256 682
    1239 675
    1222 669
    1206 663
    1189 657
    1173 651
    1157 644
    1140 638
    1124 632
    1108 626
    1092 619
    1076 613
    1060 607
    1045 600
    1029 594
    1013 588
    998 581
    983 575
    967 569
    952 562
    937 556
    922 550
    907 543
    892 537
    877 531
    863 524
    848 518
    833 511
    819 505
    805 498
    790 492
    776 486
    762 479
    748 473
    734 466
    721 460
    707 453
    693 447
    680 441
    666 434
    653 428
    640 421
    627 415
    614 408
    601 402
    588 395
    575 389
    563 382
    550 376
    538 369
    526 363
    513 356
    501 350
    489 343
    477 337
    466 330
    454 324
    442 317
    431 311
    419 304
    408 298
    397 291
    386 285
    375 278
    364 272
    353 265
    342 259
    332 252
    321 246
    311 239
    301 233
    291 227
    281 220
    271 214
    261 207
    251 201
    242 194
    232 188
    223 181
    214 175
    204 169
    195 162
    187 156
    178 149
    169 143
    160 137
    152 130
    144 124
    135 118
    127 111
    119 105
    111 99
    103 92
    96 86
    88 80
    81 74
    73 67
    66 61
    59 55
    52 49
    45 43
    38 36
    31 30
    25 24
    18 18
    12 12
    6 6
    -0 -0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -29 -30
    -35 -36
    -40 -42
    -45 -48
    -50 -54
    -55 -60
    -60 -66
    -65 -72
    -69 -77
    -74 -83
    -78 -89
    -83 -95
    -87 -100
    -91 -106
    -95 -112
    -99 -117
    -103 -123
    -106 -128
    -110 -134
    -113 -139
    -116 -145
    -120 -150
    -123 -156
    -126 -161
    -128 -166
    -131 -172
    -134 -177
    -136 -182
    -139 -188
    -141 -193
    -143 -198
    -145 -203
    -147 -208
    -149 -213
    -151 -218
    -153 -223
    -154 -228
    -156 -233
    -157 -238
    -158 -242
    -160 -247
    -161 -252
    -162 -257
    -163 -261
    -163 -266
    -164 -270
    -165 -275
    -165 -279
    -165 -284
    -166 -288
    -166 -292
    -166 -297
    -166 -301
    -166 -305
    -166 -309
    -165 -313
    -165 -317
    -165 -321
    -164 -325
    -163 -329
    -163 -333
    -162 -337
    -161 -341
    -160 -344
    -159 -348
    -158 -352
    -157 -355
    -155 -359
    -154 -362
    -153 -365
    -151 -369
    -149 -372
    -148 -375
    -146 -378
    -144 -382
    -142 -385
    -140 -388
    -138 -390
    -136 -393
    -134 -396
    -132 -399
    -130 -402
    -127 -404
    -125 -407
    -122 -409
    -120 -412
    -117 -414
    -115 -416
    -112 -419
    -109 -421
    -107 -423
    -104 -425
    -101 -427
    -98 -429
    -95 -431
    -92 -433
    -89 -435
    -86 -436
    -83 -438
    -80 -439
    -76 -441
    -73 -442
    -70 -444
    -67 -445
    -63 -446
    -60 -447
    -57 -449
    -53 -450
    -50 -451
    -46 -451
    -43 -452
    -39 -453
    -36 -454
    -32 -454
    -29 -455
    -25 -456
    -22 -456
    -18 -456
    -14 -457
    -11 -457
    -7 -457
    -4 -457
    0 -457
    4 -457
    7 -457
    11 -457
    14 -457
    18 -456
    22 -456
    25 -456
    29 -455
    32 -454
    36 -454
    39 -453
    43 -452
    46 -451
    50 -451
    53 -450
    57 -449
    60 -447
    63 -446
    67 -445
    70 -444
    73 -442
    76 -441
    80 -439
    83 -438
    86 -436
    89 -435
    92 -433
    95 -431
    98 -429
    101 -427
    104 -425
    107 -423
    109 -421
    112 -419
    115 -416
    117 -414
    120 -412
    122 -409
    125 -407
    127 -404
    130 -402
    132 -399
    134 -396
    136 -393
    138 -390
    140 -388
    142 -385
    144 -382
    146 -378
    148 -375
    149 -372
    151 -369
    153 -365
    154 -362
    155 -359
    157 -355
    158 -352
    159 -348
    160 -344
    161 -341
    162 -337
    163 -333
    163 -329
    164 -325
    165 -321
    165 -317
    165 -313
    166 -309
    166 -305
    166 -301
    166 -297
    166 -292
    166 -288
    165 -284
    165 -279
    165 -275
    164 -270
    163 -266
    163 -261
    162 -257
    161 -252
    160 -247
    158 -242
    157 -238
    156 -233
    154 -228
    153 -223
    151 -218
    149 -213
    147 -208
    145 -203
    143 -198
    141 -193
    139 -188
    136 -182
    134 -177
    131 -172
    128 -166
    126 -161
    123 -156
    120 -150
    116 -145
    113 -139
    110 -134
    106 -128
    103 -123
    99 -117
    95 -112
    91 -106
    87 -100
    83 -95
    78 -89
    74 -83
    69 -77
    65 -72
    60 -66
    55 -60
    50 -54
    45 -48
    40 -42
    35 -36
    29 -30
    24 -24
    18 -18
    12 -12
    6 -6
    0 -0
    -6 6
    -12 12
    -18 18
    -25 24
    -31 30
    -38 36
    -45 43
    -52 49
    -59 55
    -66 61
    -73 67
    -81 74
    -88 80
    -96 86
    -103 92
    -111 99
    -119 105
    -127 111
    -135 118
    -144 124
    -152 130
    -160 137
    -169 143
    -178 149
    -187 156
    -195 162
    -204 169
    -214 175
    -223 181
    -232 188
    -242 194
    -251 201
    -261 207
    -271 214
    -281 220
    -291 227
    -301 233
    -311 239
    -321 246
    -332 252
    -342 259
    -353 265
    -364 272
    -375 278
    -386 285
    -397 291
    -408 298
    -419 304
    -431 311
    -442 317
    -454 324
    -466 330
    -477 337
    -489 343
    -501 350
    -513 356
    -526 363
    -538 369
    -550 376
    -563 382
    -575 389
    -588 395
    -601 402
    -614 408
    -627 415
    -640 421
    -653 428
    -666 434
    -680 441
    -693 447
    -707 453
    -721 460
    -734 466
    -748 473
    -762 479
    -776 486
    -790 492
    -805 498
    -819 505
    -833 511
    -848 518
    -863 524
    -877 531
    -892 537
    -907 543
    -922 550
    -937 556
    -952 562
    -967 569
    -983 575
    -998 581
    -1013 588
    -1029 594
    -1045 600
    -1060 607
    -1076 613
    -1092 619
    -1108 626
    -1124 632
    -1140 638
    -1157 644
    -1173 651
    -1189 657
    -1206 663
    -1222 669
    -1239 675
    -1256 682
    -1273 688
    -1290 694
    -1307 700
    -1324 706
    -1341 712
    -1358 719
    1352 710
    1335 704
    1317 697
    1300 691
    1283 685
    1267 679
    1250 673
    1233 667
    1216 661
    1200 654
    1183 648
    1167 642
    1150 636
    1134 630
    1118 623
    1102 617
    1086 611
    1070 605
    1054 598
    1038 592
    1023 586
    1007 579
    992 573
    976 567
    961 561
    946 554
    931 548
    915 542
    901 535
    886 529
    871 523
    856 516
    842 510
    827 503
    813 497
    798 491
    784 484
    770 478
    756 471
    742 465
    728 459
    714 452
    700 446
    687 439
    673 433
    660 426
    647 420
    634 414
    620 407
    607 401
    594 394
    582 388
    569 381
    556 375
    544 368
    531 362
    519 355
    507 349
    495 343
    483 336
    471 330
    459 323
    447 317
    436 310
    424 304
    413 297
    402 291
    390 284
    379 278
    368 271
    357 265
    347 258
    336 252
    325 246
    315 239
    305 233
    294 226
    284 220
    274 213
    264 207
    255 200
    245 194
    235 188
    226 181
    216 175
    207 168
    198 162
    189 156
    180 149
    171 143
    163 137
    154 130
    146 124
    137 118
    129 111
    121 105
    113 99
    105 92
    97 86
    89 80
    82 74
    74 67
    67 61
    60 55
    53 49
    46 43
    39 36
    32 30
    25 24
    19 18
    12 12
    6 6
    -0 -0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -30 -30
    -35 -36
    -41 -42
    -46 -48
    -51 -54
    -56 -60
    -61 -66
    -66 -72
    -71 -77
    -75 -83
    -80 -89
    -84 -95
    -88 -100
    -93 -106
    -97 -112
    -101 -117
    -104 -123
    -108 -129
    -112 -134
    -115 -140
    -119 -145
    -122 -151
    -125 -156
    -128 -161
    -131 -167
    -134 -172
    -137 -177
    -139 -183
    -142 -188
    -144 -193
    -146 -198
    -148 -203
    -151 -208
    -152 -213
    -154 -218
    -156 -223
    -158 -228
    -159 -233
    -161 -238
    -162 -243
    -163 -248
    -164 -253
    -165 -257
    -166 -262
    -167 -267
    -168 -271
    -168 -276
    -169 -280
    -169 -285
    -170 -289
    -170 -293
    -170 -298
    -170 -302
    -170 -306
    -170 -310
    -170 -315
    -169 -319
    -169 -323
    -169 -327
    -168 -331
    -167 -334
    -166 -338
    -166 -342
    -165 -346
    -164 -350
    -163 -353
    -161 -357
    -160 -360
    -159 -364
    -157 -367
    -156 -371
    -154 -374
    -153 -377
    -151 -380
    -149 -383
    -147 -387
    -145 -390
    -143 -393
    -141 -395
    -139 -398
    -137 -401
    -135 -404
    -132 -407
    -130 -409
    -127 -412
    -125 -414
    -122 -417
    -120 -419
    -117 -421
    -114 -424
    -112 -426
    -109 -428
    -106 -430
    -103 -432
    -100 -434
    -97 -436
    -94 -438
    -91 -439
    -88 -441
    -84 -443
    -81 -444
    -78 -446
    -75 -447
    -71 -449
    -68 -450
    -64 -451
    -61 -452
    -58 -453
    -54 -454
    -51 -455
    -47 -456
    -44 -457
    -40 -458
    -36 -459
    -33 -459
    -29 -460
    -26 -460
    -22 -461
    -18 -461
    -15 -462
    -11 -462
    -7 -462
    -4 -462
    0 -462
    4 -462
    7 -462
    11 -462
    15 -462
    18 -461
    22 -461
    26 -460
    29 -460
    33 -459
    36 -459
    40 -458
    44 -457
    47 -456
    51 -455
    54 -454
    58 -453
    61 -452
    64 -451
    68 -450
    71 -449
    75 -447
    78 -446
    81 -444
    84 -443
    88 -441
    91 -439
    94 -438
    97 -436
    100 -434
    103 -432
    106 -430
    109 -428
    112 -426
    114 -424
    117 -421
    120 -419
    122 -417
    125 -414
    127 -412
    130 -409
    132 -407
    135 -404
    137 -401
    139 -398
    141 -395
    143 -393
    145 -390
    147 -387
    149 -383
    151 -380
    153 -377
    154 -374
    156 -371
    157 -367
    159 -364
    160 -360
    161 -357
    163 -353
    164 -350
    165 -346
    166 -342
    166 -338
    167 -334
    168 -331
    169 -327
    169 -323
    169 -319
    170 -315
    170 -310
    170 -306
    170 -302
    170 -298
    170 -293
    170 -289
    169 -285
    169 -280
    168 -276
    168 -271
    167 -267
    166 -262
    165 -257
    164 -253
    163 -248
    162 -243
    161 -238
    159 -233
    158 -228
    156 -223
    154 -218
    152 -213
    151 -208
    148 -203
    146 -198
    144 -193
    142 -188
    139 -183
    137 -177
    134 -172
    131 -167
    128 -161
    125 -156
    122 -151
    119 -145
    115 -140
    112 -134
    108 -129
    104 -123
    101 -117
    97 -112
    93 -106
    88 -100
    84 -95
    80 -89
    75 -83
    71 -77
    66 -72
    61 -66
    56 -60
    51 -54
    46 -48
    41 -42
    35 -36
    30 -30
    24 -24
    18 -18
    12 -12
    6 -6
    0 -0
    -6 6
    -12 12
    -19 18
    -25 24
    -32 30
    -39 36
    -46 43
    -53 49
    -60 55
    -67 61
    -74 67
    -82 74
    -89 80
    -97 86
    -105 92
    -113 99
    -121 105
    -129 111
    -137 118
    -146 124
    -154 130
    -163 137
    -171 143
    -180 149
    -189 156
    -198 162
    -207 168
    -216 175
    -226 181
    -235 188
    -245 194
    -255 200
    -264 207
    -274 213
    -284 220
    -294 226
    -305 233
    -315 239
    -325 246
    -336 252
    -347 258
    -357 265
    -368 271
    -379 278
    -390 284
    -402 291
    -413 297
    -424 304
    -436 310
    -447 317
    -459 323
    -471 330
    -483 336
    -495 343
    -507 349
    -519 355
    -531 362
    -544 368
    -556 375
    -569 381
    -582 388
    -594 394
    -607 401
    -620 407
    -634 414
    -647 420
    -660 426
    -673 433
    -687 439
    -700 446
    -714 452
    -728 459
    -742 465
    -756 471
    -770 478
    -784 484
    -798 491
    -813 497
    -827 503
    -842 510
    -856 516
    -871 523
    -886 529
    -901 535
    -915 542
    -931 548
    -946 554
    -961 561
    -976 567
    -992 573
    -1007 579
    -1023 586
    -1038 592
    -1054 598
    -1070 605
    -1086 611
    -1102 617
    -1118 623
    -1134 630
    -1150 636
    -1167 642
    -1183 648
    -1200 654
    -1216 661
    -1233 667
    -1250 673
    -1267 679
    -1283 685
    -1300 691
    -1317 697
    -1335 704
    -1352 710
    1346 701
    1329 695
    1311 689
    1294 683
    1277 677
    1260 670
    1244 664
    1227 658
    1210 652
    1194 646
    1177 640
    1161 634
    1144 627
    1128 621
    1112 615
    1096 609
    1080 602
    1064 596
    1048 590
    1032 584
    1016 578
    1001 571
    985 565
    970 559
    955 552
    939 546
    924 540
    909 534
    894 527
    879 521
    864 515
    850 508
    835 502
    821 496
    806 489
    792 483
    778 476
    763 470
    749 464
    735 457
    722 451
    708 445
    694 438
    680 432
    667 425
    654 419
    640 413
    627 406
    614 400
    601 393
    588 387
    575 380
    563 374
    550 368
    537 361
    525 355
    513 348
    500 342
    488 335
    476 329
    464 323
    453 316
    441 310
    429 303
    418 297
    406 290
    395 284
    384 277
    373 271
    362 265
    351 258
    340 252
    330 245
    319 239
    309 232
    298 226
    288 220
    278 213
    268 207
    258 200
    248 194
    238 187
    229 181
    219 175
    210 168
    201 162
    192 156
    183 149
    174 143
    165 137
    156 130
    148 124
    139 118
    131 111
    123 105
    114 99
    106 92
    99 86
    91 80
    83 74
    76 67
    68 61
    61 55
    54 49
    46 43
    39 36
    33 30
    26 24
    19 18
    13 12
    6 6
    -0 -0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -30 -30
    -36 -36
    -41 -42
    -47 -48
    -52 -54
    -57 -60
    -62 -66
    -67 -71
    -72 -77
    -76 -83
    -81 -89
    -86 -95
    -90 -100
    -94 -106
    -98 -112
    -102 -117
    -106 -123
    -110 -128
    -114 -134
    -117 -140
    -121 -145
    -124 -151
    -127 -156
    -130 -161
    -133 -167
    -136 -172
    -139 -177
    -142 -183
    -144 -188
    -147 -193
    -149 -198
    -151 -204
    -154 -209
    -156 -214
    -157 -219
    -159 -224
    -161 -229
    -163 -234
    -164 -239
    -166 -243
    -167 -248
    -168 -253
    -169 -258
    -170 -262
    -171 -267
    -172 -272
    -172 -276
    -173 -281
    -173 -285
    -174 -290
    -174 -294
    -174 -298
    -174 -303
    -174 -307
    -174 -311
    -174 -315
    -174 -320
    -173 -324
    -173 -328
    -172 -332
    -172 -336
    -171 -339
    -170 -343
    -169 -347
    -168 -351
    -167 -355
    -166 -358
    -165 -362
    -164 -365
    -162 -369
    -161 -372
    -159 -375
    -158 -379
    -156 -382
    -154 -385
    -152 -388
    -150 -391
    -148 -394
    -146 -397
    -144 -400
    -142 -403
    -140 -406
    -137 -409
    -135 -411
    -132 -414
    -130 -417
    -127 -419
    -125 -422
    -122 -424
    -119 -426
    -117 -428
    -114 -431
    -111 -433
    -108 -435
    -105 -437
    -102 -439
    -99 -441
    -96 -443
    -92 -444
    -89 -446
    -86 -448
    -83 -449
    -79 -451
    -76 -452
    -73 -453
    -69 -455
    -66 -456
    -62 -457
    -59 -458
    -55 -459
    -52 -460
    -48 -461
    -44 -462
    -41 -463
    -37 -463
    -33 -464
    -30 -465
    -26 -465
    -22 -466
    -19 -466
    -15 -466
    -11 -466
    -7 -467
    -4 -467
    0 -467
    4 -467
    7 -467
    11 -466
    15 -466
    19 -466
    22 -466
    26 -465
    30 -465
    33 -464
    37 -463
    41 -463
    44 -462
    48 -461
    52 -460
    55 -459
    59 -458
    62 -457
    66 -456
    69 -455
    73 -453
    76 -452
    79 -451
    83 -449
    86 -448
    89 -446
    92 -444
    96 -443
    99 -441
    102 -439
    105 -437
    108 -435
    111 -433
    114 -431
    117 -428
    119 -426
    122 -424
    125 -422
    127 -419
    130 -417
    132 -414
    135 -411
    137 -409
    140 -406
    142 -403
    144 -400
    146 -397
    148 -394
    150 -391
    152 -388
    154 -385
    156 -382
    158 -379
    159 -375
    161 -372
    162 -369
    164 -365
    165 -362
    166 -358
    167 -355
    168 -351
    169 -347
    170 -343
    171 -339
    172 -336
    172 -332
    173 -328
    173 -324
    174 -320
    174 -315
    174 -311
    174 -307
    174 -303
    174 -298
    174 -294
    174 -290
    173 -285
    173 -281
    172 -276
    172 -272
    171 -267
    170 -262
    169 -258
    168 -253
    167 -248
    166 -243
    164 -239
    163 -234
    161 -229
    159 -224
    157 -219
    156 -214
    154 -209
    151 -204
    149 -198
    147 -193
    144 -188
    142 -183
    139 -177
    136 -172
    133 -167
    130 -161
    127 -156
    124 -151
    121 -145
    117 -140
    114 -134
    110 -128
    106 -123
    102 -117
    98 -112
    94 -106
    90 -100
    86 -95
    81 -89
    76 -83
    72 -77
    67 -71
    62 -66
    57 -60
    52 -54
    47 -48
    41 -42
    36 -36
    30 -30
    24 -24
    18 -18
    12 -12
    6 -6
    0 -0
    -6 6
    -13 12
    -19 18
    -26 24
    -33 30
    -39 36
    -46 43
    -54 49
    -61 55
    -68 61
    -76 67
    -83 74
    -91 80
    -99 86
    -106 92
    -114 99
    -123 105
    -131 111
    -139 118
    -148 124
    -156 130
    -165 137
    -174 143
    -183 149
    -192 156
    -201 162
    -210 168
    -219 175
    -229 181
    -238 187
    -248 194
    -258 200
    -268 207
    -278 213
    -288 220
    -298 226
    -309 232
    -319 239
    -330 245
    -340 252
    -351 258
    -362 265
    -373 271
    -384 277
    -395 284
    -406 290
    -418 297
    -429 303
    -441 310
    -453 316
    -464 323
    -476 329
    -488 335
    -500 342
    -513 348
    -525 355
    -537 361
    -550 368
    -563 374
    -575 380
    -588 387
    -601 393
    -614 400
    -627 406
    -640 413
    -654 419
    -667 425
    -680 432
    -694 438
    -708 445
    -722 451
    -735 457
    -749 464
    -763 470
    -778 476
    -792 483
    -806 489
    -821 496
    -835 502
    -850 508
    -864 515
    -879 521
    -894 527
    -909 534
    -924 540
    -939 546
    -955 552
    -970 559
    -985 565
    -1001 571
    -1016 578
    -1032 584
    -1048 590
    -1064 596
    -1080 602
    -1096 609
    -1112 615
    -1128 621
    -1144 627
    -1161 634
    -1177 640
    -1194 646
    -1210 652
    -1227 658
    -1244 664
    -1260 670
    -1277 677
    -1294 683
    -1311 689
    -1329 695
    -1346 701
    1340 692
    1322 686
    1305 680
    1288 674
    1271 668
    1254 662
    1237 656
    1221 650
    1204 644
    1187 637
    1171 631
    1154 625
    1138 619
    1122 613
    1106 607
    1089 600
    1073 594
    1058 588
    1042 582
    1026 576
    1010 569
    995 563
    979 557
    964 551
    948 544
    933 538
    918 532
    903 526
    888 519
    873 513
    858 507
    843 500
    829 494
    814 488
    800 481
    786 475
    771 469
    757 462
    743 456
    729 450
    715 443
    701 437
    688 431
    674 424
    661 418
    647 412
    634 405
    621 399
    608 392
    595 386
    582 380
    569 373
    556 367
    543 360
    531 354
    519 348
    506 341
    494 335
    482 328
    470 322
    458 315
    446 309
    434 303
    423 296
    411 290
    400 283
    389 277
    377 271
    366 264
    355 258
    345 251
    334 245
    323 239
    313 232
    302 226
    292 219
    282 213
    271 207
    261 200
    252 194
    242 187
    232 181
    223 175
    213 168
    204 162
    194 156
    185 149
    176 143
    167 137
    159 130
    150 124
    141 118
    133 111
    125 105
    116 99
    108 93
    100 86
    92 80
    85 74
    77 68
    69 61
    62 55
    55 49
    47 43
    40 37
    33 31
    26 24
    20 18
    13 12
    6 6
    0 0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -30 -30
    -36 -36
    -42 -42
    -47 -48
    -52 -54
    -58 -60
    -63 -65
    -68 -71
    -73 -77
    -78 -83
    -82 -89
    -87 -94
    -91 -100
    -96 -106
    -100 -111
    -104 -117
    -108 -123
    -112 -128
    -116 -134
    -119 -139
    -123 -145
    -126 -150
    -129 -156
    -133 -161
    -136 -167
    -139 -172
    -142 -177
    -144 -183
    -147 -188
    -150 -193
    -152 -198
    -154 -204
    -157 -209
    -159 -214
    -161 -219
    -163 -224
    -164 -229
    -166 -234
    -168 -239
    -169 -244
    -170 -249
    -172 -253
    -173 -258
    -174 -263
    -175 -267
    -176 -272
    -176 -277
    -177 -281
    -177 -286
    -178 -290
    -178 -295
    -179 -299
    -179 -303
    -179 -308
    -179 -312
    -179 -316
    -178 -320
    -178 -324
    -178 -329
    -177 -333
    -176 -337
    -176 -340
    -175 -344
    -174 -348
    -173 -352
    -172 -356
    -171 -359
    -170 -363
    -168 -367
    -167 -370
    -166 -373
    -164 -377
    -163 -380
    -161 -384
    -159 -387
    -157 -390
    -155 -393
    -153 -396
    -151 -399
    -149 -402
    -147 -405
    -145 -408
    -142 -411
    -140 -413
    -138 -416
    -135 -419
    -133 -421
    -130 -424
    -127 -426
    -124 -429
    -122 -431
    -119 -433
    -116 -435
    -113 -437
    -110 -440
    -107 -442
    -104 -443
    -101 -445
    -97 -447
    -94 -449
    -91 -451
    -88 -452
    -84 -454
    -81 -455
    -77 -457
    -74 -458
    -70 -459
    -67 -461
    -63 -462
    -60 -463
    -56 -464
    -52 -465
    -49 -466
    -45 -467
    -41 -467
    -38 -468
    -34 -469
    -30 -469
    -27 -470
    -23 -470
    -19 -471
    -15 -471
    -11 -471
    -8 -471
    -4 -471
    0 -471
    4 -471
    8 -471
    11 -471
    15 -471
    19 -471
    23 -470
    27 -470
    30 -469
    34 -469
    38 -468
    41 -467
    45 -467
    49 -466
    52 -465
    56 -464
    60 -463
    63 -462
    67 -461
    70 -459
    74 -458
    77 -457
    81 -455
    84 -454
    88 -452
    91 -451
    94 -449
    97 -447
    101 -445
    104 -443
    107 -442
    110 -440
    113 -437
    116 -435
    119 -433
    122 -431
    124 -429
    127 -426
    130 -424
    133 -421
    135 -419
    138 -416
    140 -413
    142 -411
    145 -408
    147 -405
    149 -402
    151 -399
    153 -396
    155 -393
    157 -390
    159 -387
    161 -384
    163 -380
    164 -377
    166 -373
    167 -370
    168 -367
    170 -363
    171 -359
    172 -356
    173 -352
    174 -348
    175 -344
    176 -340
    176 -337
    177 -333
    178 -329
    178 -324
    178 -320
    179 -316
    179 -312
    179 -308
    179 -303
    179 -299
    178 -295
    178 -290
    177 -286
    177 -281
    176 -277
    176 -272
    175 -267
    174 -263
    173 -258
    172 -253
    170 -249
    169 -244
    168 -239
    166 -234
    164 -229
    163 -224
    161 -219
    159 -214
    157 -209
    154 -204
    152 -198
    150 -193
    147 -188
    144 -183
    142 -177
    139 -172
    136 -167
    133 -161
    129 -156
    126 -150
    123 -145
    119 -139
    116 -134
    112 -128
    108 -123
    104 -117
    100 -111
    96 -106
    91 -100
    87 -94
    82 -89
    78 -83
    73 -77
    68 -71
    63 -65
    58 -60
    52 -54
    47 -48
    42 -42
    36 -36
    30 -30
    24 -24
    18 -18
    12 -12
    6 -6
    -0 0
    -6 6
    -13 12
    -20 18
    -26 24
    -33 31
    -40 37
    -47 43
    -55 49
    -62 55
    -69 61
    -77 68
    -85 74
    -92 80
    -100 86
    -108 93
    -116 99
    -125 105
    -133 111
    -141 118
    -150 124
    -159 130
    -167 137
    -176 143
    -185 149
    -194 156
    -204 162
    -213 168
    -223 175
    -232 181
    -242 187
    -252 194
    -261 200
    -271 207
    -282 213
    -292 219
    -302 226
    -313 232
    -323 239
    -334 245
    -345 251
    -355 258
    -366 264
    -377 271
    -389 277
    -400 283
    -411 290
    -423 296
    -434 303
    -446 309
    -458 315
    -470 322
    -482 328
    -494 335
    -506 341
    -519 348
    -531 354
    -543 360
    -556 367
    -569 373
    -582 380
    -595 386
    -608 392
    -621 399
    -634 405
    -647 412
    -661 418
    -674 424
    -688 431
    -701 437
    -715 443
    -729 450
    -743 456
    -757 462
    -771 469
    -786 475
    -800 481
    -814 488
    -829 494
    -843 500
    -858 507
    -873 513
    -888 519
    -903 526
    -918 532
    -933 538
    -948 544
    -964 551
    -979 557
    -995 563
    -1010 569
    -1026 576
    -1042 582
    -1058 588
    -1073 594
    -1089 600
    -1106 607
    -1122 613
    -1138 619
    -1154 625
    -1171 631
    -1187 637
    -1204 644
    -1221 650
    -1237 656
    -1254 662
    -1271 668
    -1288 674
    -1305 680
    -1322 686
    -1340 692
    1334 684
    1316 677
    1299 671
    1282 665
    1265 659
    1248 653
    1231 647
    1215 641
    1198 635
    1181 629
    1165 623
    1148 617
    1132 611
    1116 605
    1099 598
    1083 592
    1067 586
    1051 580
    1035 574
    1020 568
    1004 561
    988 555
    973 549
    957 543
    942 536
    927 530
    912 524
    897 518
    882 511
    867 505
    852 499
    837 493
    823 486
    808 480
    794 474
    779 468
    765 461
    751 455
    737 449
    723 442
    709 436
    695 430
    681 423
    668 417
    654 411
    641 404
    628 398
    614 391
    601 385
    588 379
    575 372
    562 366
    550 360
    537 353
    525 347
    512 341
    500 334
    488 328
    475 321
    463 315
    452 309
    440 302
    428 296
    416 289
    405 283
    394 277
    382 270
    371 264
    360 257
    349 251
    338 245
    327 238
    317 232
    306 226
    296 219
    285 213
    275 206
    265 200
    255 194
    245 187
    235 181
    226 175
    216 168
    207 162
    197 156
    188 149
    179 143
    170 137
    161 130
    152 124
    144 118
    135 112
    127 105
    118 99
    110 93
    102 87
    94 80
    86 74
    78 68
    71 62
    63 55
    56 49
    48 43
    41 37
    34 31
    27 25
    20 19
    14 13
    7 6
    0 0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -30 -30
    -36 -36
    -42 -42
    -47 -47
    -53 -53
    -58 -59
    -64 -65
    -69 -71
    -74 -77
    -79 -83
    -83 -88
    -88 -94
    -92 -100
    -97 -106
    -101 -111
    -105 -117
    -110 -122
    -113 -128
    -117 -134
    -121 -139
    -125 -145
    -128 -150
    -132 -156
    -135 -161
    -138 -167
    -141 -172
    -144 -177
    -147 -183
    -150 -188
    -152 -193
    -155 -198
    -157 -204
    -159 -209
    -162 -214
    -164 -219
    -166 -224
    -168 -229
    -169 -234
    -171 -239
    -172 -244
    -174 -249
    -175 -253
    -176 -258
    -177 -263
    -178 -268
    -179 -272
    -180 -277
    -181 -282
    -181 -286
    -182 -291
    -182 -295
    -183 -300
    -183 -304
    -183 -308
    -183 -313
    -183 -317
    -183 -321
    -182 -325
    -182 -329
    -182 -333
    -181 -337
    -180 -341
    -180 -345
    -179 -349
    -178 -353
    -177 -357
    -176 -360
    -175 -364
    -173 -368
    -172 -371
    -171 -375
    -169 -378
    -168 -382
    -166 -385
    -164 -388
    -162 -391
    -160 -395
    -158 -398
    -156 -401
    -154 -404
    -152 -407
    -150 -410
    -148 -413
    -145 -415
    -143 -418
    -140 -421
    -138 -423
    -135 -426
    -132 -428
    -130 -431
    -127 -433
    -124 -435
    -121 -438
    -118 -440
    -115 -442
    -112 -444
    -109 -446
    -106 -448
    -102 -450
    -99 -452
    -96 -453
    -92 -455
    -89 -457
    -86 -458
    -82 -460
    -79 -461
    -75 -463
    -72 -464
    -68 -465
    -64 -466
    -61 -467
    -57 -468
    -53 -469
    -50 -470
    -46 -471
    -42 -472
    -38 -473
    -35 -473
    -31 -474
    -27 -474
    -23 -475
    -19 -475
    -15 -475
    -12 -476
    -8 -476
    -4 -476
    0 -476
    4 -476
    8 -476
    12 -476
    15 -475
    19 -475
    23 -475
    27 -474
    31 -474
    35 -473
    38 -473
    42 -472
    46 -471
    50 -470
    53 -469
    57 -468
    61 -467
    64 -466
    68 -465
    72 -464
    75 -463
    79 -461
    82 -460
    86 -458
    89 -457
    92 -455
    96 -453
    99 -452
    102 -450
    106 -448
    109 -446
    112 -444
    115 -442
    118 -440
    121 -438
    124 -435
    127 -433
    130 -431
    132 -428
    135 -426
    138 -423
    140 -421
    143 -418
    145 -415
    148 -413
    150 -410
    152 -407
    154 -404
    156 -401
    158 -398
    160 -395
    162 -391
    164 -388
    166 -385
    168 -382
    169 -378
    171 -375
    172 -371
    173 -368
    175 -364
    176 -360
    177 -357
    178 -353
    179 -349
    180 -345
    180 -341
    181 -337
    182 -333
    182 -329
    182 -325
    183 -321
    183 -317
    183 -313
    183 -308
    183 -304
    183 -300
    182 -295
    182 -291
    181 -286
    181 -282
    180 -277
    179 -272
    178 -268
    177 -263
    176 -258
    175 -253
    174 -249
    172 -244
    171 -239
    169 -234
    168 -229
    166 -224
    164 -219
    162 -214
    159 -209
    157 -204
    155 -198
    152 -193
    150 -188
    147 -183
    144 -177
    141 -172
    138 -167
    135 -161
    132 -156
    128 -150
    125 -145
    121 -139
    117 -134
    113 -128
    110 -122
    105 -117
    101 -111
    97 -106
    92 -100
    88 -94
    83 -88
    79 -83
    74 -77
    69 -71
    64 -65
    58 -59
    53 -53
    47 -47
    42 -42
    36 -36
    30 -30
    24 -24
    18 -18
    12 -12
    6 -6
    -0 0
    -7 6
    -14 13
    -20 19
    -27 25
    -34 31
    -41 37
    -48 43
    -56 49
    -63 55
    -71 62
    -78 68
    -86 74
    -94 80
    -102 87
    -110 93
    -118 99
    -127 105
    -135 112
    -144 118
    -152 124
    -161 130
    -170 137
    -179 143
    -188 149
    -197 156
    -207 162
    -216 168
    -226 175
    -235 181
    -245 187
    -255 194
    -265 200
    -275 206
    -285 213
    -296 219
    -306 226
    -317 232
    -327 238
    -338 245
    -349 251
    -360 257
    -371 264
    -382 270
    -394 277
    -405 283
    -416 289
    -428 296
    -440 302
    -452 309
    -463 315
    -475 321
    -488 328
    -500 334
    -512 341
    -525 347
    -537 353
    -550 360
    -562 366
    -575 372
    -588 379
    -601 385
    -614 391
    -628 398
    -641 404
    -654 411
    -668 417
    -681 423
    -695 430
    -709 436
    -723 442
    -737 449
    -751 455
    -765 461
    -779 468
    -794 474
    -808 480
    -823 486
    -837 493
    -852 499
    -867 505
    -882 511
    -897 518
    -912 524
    -927 530
    -942 536
    -957 543
    -973 549
    -988 555
    -1004 561
    -1020 568
    -1035 574
    -1051 580
    -1067 586
    -1083 592
    -1099 598
    -1116 605
    -1132 611
    -1148 617
    -1165 623
    -1181 629
    -1198 635
    -1215 641
    -1231 647
    -1248 653
    -1265 659
    -1282 665
    -1299 671
    -1316 677
    -1334 684
    1328 675
    1310 669
    1293 663
    1276 657
    1259 651
    1242 645
    1225 639
    1209 633
    1192 627
    1175 621
    1159 615
    1142 608
    1126 602
    1110 596
    1093 590
    1077 584
    1061 578
    1045 572
    1029 566
    1014 559
    998 553
    982 547
    967 541
    951 535
    936 529
    921 522
    905 516
    890 510
    875 504
    860 498
    846 491
    831 485
    816 479
    802 473
    787 466
    773 460
    759 454
    744 447
    730 441
    716 435
    703 429
    689 422
    675 416
    661 410
    648 403
    634 397
    621 391
    608 384
    595 378
    582 372
    569 365
    556 359
    543 353
    531 346
    518 340
    506 334
    493 327
    481 321
    469 314
    457 308
    445 302
    433 295
    422 289
    410 283
    399 276
    387 270
    376 264
    365 257
    354 251
    343 244
    332 238
    321 232
    310 225
    300 219
    289 213
    279 206
    269 200
    259 194
    249 187
    239 181
    229 175
    219 168
    210 162
    200 156
    191 149
    182 143
    173 137
    164 131
    155 124
    146 118
    137 112
    129 105
    120 99
    112 93
    104 87
    96 81
    88 74
    80 68
    72 62
    64 56
    57 50
    50 43
    42 37
    35 31
    28 25
    21 19
    14 13
    7 7
    1 1
    -6 -5
    -12 -11
    -18 -17
    -24 -23
    -30 -29
    -36 -35
    -42 -41
    -48 -47
    -53 -53
    -59 -59
    -64 -65
    -69 -71
    -74 -76
    -79 -82
    -84 -88
    -89 -94
    -94 -99
    -98 -105
    -103 -111
    -107 -116
    -111 -122
    -115 -128
    -119 -133
    -123 -139
    -127 -144
    -130 -150
    -134 -155
    -137 -161
    -140 -166
    -143 -172
    -147 -177
    -149 -182
    -152 -188
    -155 -193
    -158 -198
    -160 -203
    -162 -208
    -165 -214
    -167 -219
    -169 -224
    -171 -229
    -173 -234
    -174 -239
    -176 -244
    -177 -249
    -179 -253
    -180 -258
    -181 -263
    -182 -268
    -183 -273
    -184 -277
    -185 -282
    -185 -286
    -186 -291
    -186 -295
    -187 -300
    -187 -304
    -187 -309
    -187 -313
    -187 -317
    -187 -321
    -187 -326
    -187 -330
    -186 -334
    -186 -338
    -185 -342
    -184 -346
    -184 -350
    -183 -354
    -182 -357
    -181 -361
    -179 -365
    -178 -369
    -177 -372
    -176 -376
    -174 -379
    -173 -383
    -171 -386
    -169 -389
    -167 -393
    -166 -396
    -164 -399
    -162 -402
    -159 -405
    -157 -408
    -155 -411
    -153 -414
    -150 -417
    -148 -420
    -145 -422
    -143 -425
    -140 -428
    -138 -430
    -135 -433
    -132 -435
    -129 -438
    -126 -440
    -123 -442
    -120 -444
    -117 -446
    -114 -448
    -111 -450
    -108 -452
    -104 -454
    -101 -456
    -98 -458
    -94 -459
    -91 -461
    -87 -463
    -84 -464
    -80 -465
    -77 -467
    -73 -468
    -69 -469
    -66 -471
    -62 -472
    -58 -473
    -54 -474
    -51 -475
    -47 -475
    -43 -476
    -39 -477
    -35 -477
    -31 -478
    -27 -479
    -24 -479
    -20 -479
    -16 -480
    -12 -480
    -8 -480
    -4 -480
    0 -480
    4 -480
    8 -480
    12 -480
    16 -480
    20 -479
    24 -479
    27 -479
    31 -478
    35 -477
    39 -477
    43 -476
    47 -475
    51 -475
    54 -474
    58 -473
    62 -472
    66 -471
    69 -469
    73 -468
    77 -467
    80 -465
    84 -464
    87 -463
    91 -461
    94 -459
    98 -458
    101 -456
    104 -454
    108 -452
    111 -450
    114 -448
    117 -446
    120 -444
    123 -442
    126 -440
    129 -438
    132 -435
    135 -433
    138 -430
    140 -428
    143 -425
    145 -422
    148 -420
    150 -417
    153 -414
    155 -411
    157 -408
    159 -405
    162 -402
    164 -399
    166 -396
    167 -393
    169 -389
    171 -386
    173 -383
    174 -379
    176 -376
    177 -372
    178 -369
    179 -365
    181 -361
    182 -357
    183 -354
    184 -350
    184 -346
    185 -342
    186 -338
    186 -334
    187 -330
    187 -326
    187 -321
    187 -317
    187 -313
    187 -309
    187 -304
    187 -300
    186 -295
    186 -291
    185 -286
    185 -282
    184 -277
    183 -273
    182 -268
    181 -263
    180 -258
    179 -253
    177 -249
    176 -244
    174 -239
    173 -234
    171 -229
    169 -224
    167 -219
    165 -214
    162 -208
    160 -203
    158 -198
    155 -193
    152 -188
    149 -182
    147 -177
    143 -172
    140 -166
    137 -161
    134 -155
    130 -150
    127 -144
    123 -139
    119 -133
    115 -128
    111 -122
    107 -116
    103 -111
    98 -105
    94 -99
    89 -94
    84 -88
    79 -82
    74 -76
    69 -71
    64 -65
    59 -59
    53 -53
    48 -47
    42 -41
    36 -35
    30 -29
    24 -23
    18 -17
    12 -11
    6 -5
    -1 1
    -7 7
    -14 13
    -21 19
    -28 25
    -35 31
    -42 37
    -50 43
    -57 50
    -64 56
    -72 62
    -80 68
    -88 74
    -96 81
    -104 87
    -112 93
    -120 99
    -129 105
    -137 112
    -146 118
    -155 124
    -164 131
    -173 137
    -182 143
    -191 149
    -200 156
    -210 162
    -219 168
    -229 175
    -239 181
    -249 187
    -259 194
    -269 200
    -279 206
    -289 213
    -300 219
    -310 225
    -321 232
    -332 238
    -343 244
    -354 251
    -365 257
    -376 264
    -387 270
    -399 276
    -410 283
    -422 289
    -433 295
    -445 302
    -457 308
    -469 314
    -481 321
    -493 327
    -506 334
    -518 340
    -531 346
    -543 353
    -556 359
    -569 365
    -582 372
    -595 378
    -608 384
    -621 391
    -634 397
    -648 403
    -661 410
    -675 416
    -689 422
    -703 429
    -716 435
    -730 441
    -744 447
    -759 454
    -773 460
    -787 466
    -802 473
    -816 479
    -831 485
    -846 491
    -860 498
    -875 504
    -890 510
    -905 516
    -921 522
    -936 529
    -951 535
    -967 541
    -982 547
    -998 553
    -1014 559
    -1029 566
    -1045 572
    -1061 578
    -1077 584
    -1093 590
    -1110 596
    -1126 602
    -1142 608
    -1159 615
    -1175 621
    -1192 627
    -1209 633
    -1225 639
    -1242 645
    -1259 651
    -1276 657
    -1293 663
    -1310 669
    -1328 675
    1322 666
    1304 660
    1287 654
    1270 648
    1253 642
    1236 636
    1219 630
    1202 624
    1186 618
    1169 612
    1153 606
    1136 600
    1120 594
    1103 588
    1087 582
    1071 576
    1055 570
    1039 564
    1023 558
    1007 552
    992 545
    976 539
    961 533
    945 527
    930 521
    914 515
    899 508
    884 502
    869 496
    854 490
    839 484
    825 477
    810 471
    795 465
    781 459
    767 453
    752 446
    738 440
    724 434
    710 427
    696 421
    682 415
    669 409
    655 402
    642 396
    628 390
    615 383
    602 377
    589 371
    575 365
    563 358
    550 352
    537 346
    524 339
    512 333
    499 327
    487 320
    475 314
    463 308
    451 301
    439 295
    427 289
    415 282
    404 276
    392 270
    381 263
    370 257
    358 251
    347 244
    336 238
    325 232
    315 225
    304 219
    294 213
    283 206
    273 200
    263 194
    252 187
    242 181
    233 175
    223 168
    213 162
    204 156
    194 150
    185 143
    176 137
    166 131
    157 125
    149 118
    140 112
    131 106
    123 100
    114 93
    106 87
    98 81
    90 75
    82 69
    74 62
    66 56
    58 50
    51 44
    43 38
    36 32
    29 26
    22 19
    15 13
    8 7
    1 1
    -5 -5
    -12 -11
    -18 -17
    -24 -23
    -30 -29
    -36 -35
    -42 -41
    -48 -47
    -54 -52
    -59 -58
    -65 -64
    -70 -70
    -75 -76
    -80 -82
    -85 -87
    -90 -93
    -95 -99
    -99 -105
    -104 -110
    -108 -116
    -113 -122
    -117 -127
    -121 -133
    -125 -138
    -128 -144
    -132 -149
    -136 -155
    -139 -160
    -142 -166
    -146 -171
    -149 -177
    -152 -182
    -155 -187
    -158 -193
    -160 -198
    -163 -203
    -165 -208
    -167 -213
    -170 -218
    -172 -224
    -174 -229
    -176 -234
    -177 -239
    -179 -244
    -181 -248
    -182 -253
    -184 -258
    -185 -263
    -186 -268
    -187 -273
    -188 -277
    -189 -282
    -189 -286
    -190 -291
    -191 -296
    -191 -300
    -191 -304
    -191 -309
    -192 -313
    -192 -318
    -191 -322
    -191 -326
    -191 -330
    -191 -334
    -190 -338
    -190 -342
    -189 -346
    -188 -350
    -187 -354
    -186 -358
    -185 -362
    -184 -366
    -183 -369
    -182 -373
    -181 -377
    -179 -380
    -178 -384
    -176 -387
    -174 -390
    -172 -394
    -171 -397
    -169 -400
    -167 -403
    -165 -407
    -162 -410
    -160 -413
    -158 -416
    -156 -418
    -153 -421
    -151 -424
    -148 -427
    -145 -429
    -143 -432
    -140 -434
    -137 -437
    -134 -439
    -131 -442
    -128 -444
    -125 -446
    -122 -448
    -119 -451
    -116 -453
    -113 -455
    -109 -457
    -106 -458
    -103 -460
    -99 -462
    -96 -464
    -92 -465
    -89 -467
    -85 -468
    -82 -470
    -78 -471
    -74 -472
    -70 -474
    -67 -475
    -63 -476
    -59 -477
    -55 -478
    -51 -479
    -48 -479
    -44 -480
    -40 -481
    -36 -482
    -32 -482
    -28 -483
    -24 -483
    -20 -483
    -16 -484
    -12 -484
    -8 -484
    -4 -484
    0 -484
    4 -484
    8 -484
    12 -484
    16 -484
    20 -483
    24 -483
    28 -483
    32 -482
    36 -482
    40 -481
    44 -480
    48 -479
    51 -479
    55 -478
    59 -477
    63 -476
    67 -475
    70 -474
    74 -472
    78 -471
    82 -470
    85 -468
    89 -467
    92 -465
    96 -464
    99 -462
    103 -460
    106 -458
    109 -457
    113 -455
    116 -453
    119 -451
    122 -448
    125 -446
    128 -444
    131 -442
    134 -439
    137 -437
    140 -434
    143 -432
    145 -429
    148 -427
    151 -424
    153 -421
    156 -418
    158 -416
    160 -413
    162 -410
    165 -407
    167 -403
    169 -400
    171 -397
    172 -394
    174 -390
    176 -387
    178 -384
    179 -380
    181 -377
    182 -373
    183 -369
    184 -366
    185 -362
    186 -358
    187 -354
    188 -350
    189 -346
    190 -342
    190 -338
    191 -334
    191 -330
    191 -326
    191 -322
    192 -318
    192 -313
    191 -309
    191 -304
    191 -300
    191 -296
    190 -291
    189 -286
    189 -282
    188 -277
    187 -273
    186 -268
    185 -263
    184 -258
    182 -253
    181 -248
    179 -244
    177 -239
    176 -234
    174 -229
    172 -224
    170 -218
    167 -213
    165 -208
    163 -203
    160 -198
    158 -193
    155 -187
    152 -182
    149 -177
    146 -171
    142 -166
    139 -160
    136 -155
    132 -149
    128 -144
    125 -138
    121 -133
    117 -127
    113 -122
    108 -116
    104 -110
    99 -105
    95 -99
    90 -93
    85 -87
    80 -82
    75 -76
    70 -70
    65 -64
    59 -58
    54 -52
    48 -47
    42 -41
    36 -35
    30 -29
    24 -23
    18 -17
    12 -11
    5 -5
    -1 1
    -8 7
    -15 13
    -22 19
    -29 26
    -36 32
    -43 38
    -51 44
    -58 50
    -66 56
    -74 62
    -82 69
    -90 75
    -98 81
    -106 87
    -114 93
    -123 100
    -131 106
    -140 112
    -149 118
    -157 125
    -166 131
    -176 137
    -185 143
    -194 150
    -204 156
    -213 162
    -223 168
    -233 175
    -242 181
    -252 187
    -263 194
    -273 200
    -283 206
    -294 213
    -304 219
    -315 225
    -325 232
    -336 238
    -347 244
    -358 251
    -370 257
    -381 263
    -392 270
    -404 276
    -415 282
    -427 289
    -439 295
    -451 301
    -463 308
    -475 314
    -487 320
    -499 327
    -512 333
    -524 339
    -537 346
    -550 352
    -563 358
    -575 365
    -589 371
    -602 377
    -615 383
    -628 390
    -642 396
    -655 402
    -669 409
    -682 415
    -696 421
    -710 427
    -724 434
    -738 440
    -752 446
    -767 453
    -781 459
    -795 465
    -810 471
    -825 477
    -839 484
    -854 490
    -869 496
    -884 502
    -899 508
    -914 515
    -930 521
    -945 527
    -961 533
    -976 539
    -992 545
    -1007 552
    -1023 558
    -1039 564
    -1055 570
    -1071 576
    -1087 582
    -1103 588
    -1120 594
    -1136 600
    -1153 606
    -1169 612
    -1186 618
    -1202 624
    -1219 630
    -1236 636
    -1253 642
    -1270 648
    -1287 654
    -1304 660
    -1322 666
    1316 658
    1298 652
    1281 646
    1264 640
    1247 634
    1230 628
    1213 622
    1196 616
    1180 610
    1163 604
    1147 598
    1130 592
    1114 586
    1097 580
    1081 574
    1065 568
    1049 562
    1033 556
    1017 550
    1001 544
    986 538
    970 531
    954 525
    939 519
    924 513
    908 507
    893 501
    878 495
    863 488
    848 482
    833 476
    818 470
    804 464
    789 458
    775 451
    760 445
    746 439
    732 433
    718 426
    704 420
    690 414
    676 408
    662 401
    649 395
    635 389
    622 383
    609 376
    595 370
    582 364
    569 358
    556 351
    543 345
    531 339
    518 332
    506 326
    493 320
    481 314
    469 307
    456 301
    444 295
    433 288
    421 282
    409 276
    397 269
    386 263
    375 257
    363 250
    352 244
    341 238
    330 232
    319 225
    308 219
    298 213
    287 206
    277 200
    266 194
    256 187
    246 181
    236 175
    226 169
    216 162
    207 156
    197 150
    188 144
    179 137
    169 131
    160 125
    151 119
    142 112
    134 106
    125 100
    116 94
    108 88
    100 81
    91 75
    83 69
    75 63
    68 57
    60 51
    52 44
    45 38
    37 32
    30 26
    23 20
    16 14
    9 8
    2 2
    -5 -4
    -11 -10
    -18 -16
    -24 -22
    -30 -28
    -36 -34
    -42 -40
    -48 -46
    -54 -52
    -60 -58
    -65 -64
    -71 -69
    -76 -75
    -81 -81
    -86 -87
    -91 -93
    -96 -98
    -100 -104
    -105 -110
    -110 -115
    -114 -121
    -118 -127
    -122 -132
    -126 -138
    -130 -143
    -134 -149
    -138 -154
    -141 -160
    -145 -165
    -148 -171
    -151 -176
    -154 -181
    -157 -187
    -160 -192
    -163 -197
    -165 -203
    -168 -208
    -170 -213
    -173 -218
    -175 -223
    -177 -228
    -179 -233
    -181 -238
    -182 -243
    -184 -248
    -186 -253
    -187 -258
    -188 -263
    -190 -268
    -191 -272
    -192 -277
    -193 -282
    -193 -286
    -194 -291
    -195 -296
    -195 -300
    -195 -304
    -196 -309
    -196 -313
    -196 -318
    -196 -322
    -196 -326
    -195 -330
    -195 -335
    -195 -339
    -194 -343
    -194 -347
    -193 -351
    -192 -355
    -191 -359
    -190 -362
    -189 -366
    -188 -370
    -187 -374
    -185 -377
    -184 -381
    -183 -384
    -181 -388
    -179 -391
    -178 -395
    -176 -398
    -174 -401
    -172 -404
    -170 -408
    -168 -411
    -166 -414
    -163 -417
    -161 -420
    -158 -423
    -156 -425
    -153 -428
    -151 -431
    -148 -433
    -145 -436
    -143 -439
    -140 -441
    -137 -443
    -134 -446
    -131 -448
    -128 -450
    -124 -453
    -121 -455
    -118 -457
    -115 -459
    -111 -461
    -108 -462
    -104 -464
    -101 -466
    -97 -468
    -94 -469
    -90 -471
    -87 -472
    -83 -474
    -79 -475
    -75 -476
    -72 -478
    -68 -479
    -64 -480
    -60 -481
    -56 -482
    -52 -483
    -48 -483
    -44 -484
    -40 -485
    -36 -486
    -32 -486
    -28 -487
    -24 -487
    -20 -487
    -16 -488
    -12 -488
    -8 -488
    -4 -488
    0 -488
    4 -488
    8 -488
    12 -488
    16 -488
    20 -487
    24 -487
    28 -487
    32 -486
    36 -486
    40 -485
    44 -484
    48 -483
    52 -483
    56 -482
    60 -481
    64 -480
    68 -479
    72 -478
    75 -476
    79 -475
    83 -474
    87 -472
    90 -471
    94 -469
    97 -468
    101 -466
    104 -464
    108 -462
    111 -461
    115 -459
    118 -457
    121 -455
    124 -453
    128 -450
    131 -448
    134 -446
    137 -443
    140 -441
    143 -439
    145 -436
    148 -433
    151 -431
    153 -428
    156 -425
    158 -423
    161 -420
    163 -417
    166 -414
    168 -411
    170 -408
    172 -404
    174 -401
    176 -398
    178 -395
    179 -391
    181 -388
    183 -384
    184 -381
    185 -377
    187 -374
    188 -370
    189 -366
    190 -362
    191 -359
    192 -355
    193 -351
    194 -347
    194 -343
    195 -339
    195 -335
    195 -330
    196 -326
    196 -322
    196 -318
    196 -313
    196 -309
    195 -304
    195 -300
    195 -296
    194 -291
    193 -286
    193 -282
    192 -277
    191 -272
    190 -268
    188 -263
    187 -258
    186 -253
    184 -248
    182 -243
    181 -238
    179 -233
    177 -228
    175 -223
    173 -218
    170 -213
    168 -208
    165 -203
    163 -197
    160 -192
    157 -187
    154 -181
    151 -176
    148 -171
    145 -165
    141 -160
    138 -154
    134 -149
    130 -143
    126 -138
    122 -132
    118 -127
    114 -121
    110 -115
    105 -110
    100 -104
    96 -98
    91 -93
    86 -87
    81 -81
    76 -75
    71 -69
    65 -64
    60 -58
    54 -52
    48 -46
    42 -40
    36 -34
    30 -28
    24 -22
    18 -16
    11 -10
    5 -4
    -2 2
    -9 8
    -16 14
    -23 20
    -30 26
    -37 32
    -45 38
    -52 44
    -60 51
    -68 57
    -75 63
    -83 69
    -91 75
    -100 81
    -108 88
    -116 94
    -125 100
    -134 106
    -142 112
    -151 119
    -160 125
    -169 131
    -179 137
    -188 144
    -197 150
    -207 156
    -216 162
    -226 169
    -236 175
    -246 181
    -256 187
    -266 194
    -277 200
    -287 206
    -298 213
    -308 219
    -319 225
    -330 232
    -341 238
    -352 244
    -363 250
    -375 257
    -386 263
    -397 269
    -409 276
    -421 282
    -433 288
    -444 295
    -456 301
    -469 307
    -481 314
    -493 320
    -506 326
    -518 332
    -531 339
    -543 345
    -556 351
    -569 358
    -582 364
    -595 370
    -609 376
    -622 383
    -635 389
    -649 395
    -662 401
    -676 408
    -690 414
    -704 420
    -718 426
    -732 433
    -746 439
    -760 445
    -775 451
    -789 458
    -804 464
    -818 470
    -833 476
    -848 482
    -863 488
    -878 495
    -893 501
    -908 507
    -924 513
    -939 519
    -954 525
    -970 531
    -986 538
    -1001 544
    -1017 550
    -1033 556
    -1049 562
    -1065 568
    -1081 574
    -1097 580
    -1114 586
    -1130 592
    -1147 598
    -1163 604
    -1180 610
    -1196 616
    -1213 622
    -1230 628
    -1247 634
    -1264 640
    -1281 646
    -1298 652
    -1316 658
    1310 649
    1293 644
    1275 638
    1258 632
    1241 626
    1224 620
    1207 614
    1190 608
    1174 602
    1157 596
    1141 590
    1124 584
    1108 578
    1091 572
    1075 566
    1059 560
    1043 554
    1027 548
    1011 542
    995 536
    979 530
    964 524
    948 518
    933 512
    917 505
    902 499
    887 493
    872 487
    857 481
    842 475
    827 469
    812 462
    798 456
    783 450
    769 444
    754 438
    740 432
    726 425
    712 419
    698 413
    684 407
    670 401
    656 394
    643 388
    629 382
    616 376
    602 369
    589 363
    576 357
    563 351
    550 344
    537 338
    524 332
    512 326
    499 319
    487 313
    475 307
    462 301
    450 294
    438 288
    426 282
    414 276
    403 269
    391 263
    380 257
    368 250
    357 244
    346 238
    335 232
    324 225
    313 219
    302 213
    291 206
    281 200
    270 194
    260 188
    250 181
    240 175
    230 169
    220 163
    210 156
    201 150
    191 144
    182 138
    172 131
    163 125
    154 119
    145 113
    136 107
    127 100
    119 94
    110 88
    102 82
    93 76
    85 70
    77 63
    69 57
    61 51
    54 45
    46 39
    39 33
    31 27
    24 21
    17 15
    10 9
    3 3
    -4 -3
    -11 -9
    -17 -15
    -24 -21
    -30 -27
    -36 -33
    -42 -39
    -48 -45
    -54 -51
    -60 -57
    -65 -63
    -71 -69
    -76 -74
    -82 -80
    -87 -86
    -92 -92
    -97 -98
    -102 -103
    -106 -109
    -111 -115
    -115 -120
    -120 -126
    -124 -131
    -128 -137
    -132 -143
    -136 -148
    -139 -154
    -143 -159
    -147 -165
    -150 -170
    -153 -175
    -156 -181
    -160 -186
    -162 -191
    -165 -197
    -168 -202
    -171 -207
    -173 -212
    -175 -218
    -178 -223
    -180 -228
    -182 -233
    -184 -238
    -186 -243
    -187 -248
    -189 -253
    -190 -258
    -192 -262
    -193 -267
    -194 -272
    -195 -277
    -196 -281
    -197 -286
    -198 -291
    -199 -295
    -199 -300
    -199 -304
    -200 -309
    -200 -313
    -200 -318
    -200 -322
    -200 -326
    -200 -330
    -200 -335
    -199 -339
    -199 -343
    -198 -347
    -198 -351
    -197 -355
    -196 -359
    -195 -363
    -194 -367
    -193 -370
    -192 -374
    -190 -378
    -189 -381
    -188 -385
    -186 -388
    -184 -392
    -183 -395
    -181 -399
    -179 -402
    -177 -405
    -175 -408
    -173 -412
    -171 -415
    -169 -418
    -166 -421
    -164 -424
    -161 -427
    -159 -429
    -156 -432
    -153 -435
    -151 -437
    -148 -440
    -145 -443
    -142 -445
    -139 -447
    -136 -450
    -133 -452
    -130 -454
    -127 -456
    -123 -459
    -120 -461
    -117 -463
    -113 -464
    -110 -466
    -106 -468
    -103 -470
    -99 -472
    -95 -473
    -92 -475
    -88 -476
    -84 -478
    -80 -479
    -77 -480
    -73 -481
    -69 -483
    -65 -484
    -61 -485
    -57 -486
    -53 -487
    -49 -487
    -45 -488
    -41 -489
    -37 -489
    -33 -490
    -29 -490
    -25 -491
    -21 -491
    -17 -492
    -12 -492
    -8 -492
    -4 -492
    0 -492
    4 -492
    8 -492
    12 -492
    17 -492
    21 -491
    25 -491
    29 -490
    33 -490
    37 -489
    41 -489
    45 -488
    49 -487
    53 -487
    57 -486
    61 -485
    65 -484
    69 -483
    73 -481
    77 -480
    80 -479
    84 -478
    88 -476
    92 -475
    95 -473
    99 -472
    103 -470
    106 -468
    110 -466
    113 -464
    117 -463
    120 -461
    123 -459
    127 -456
    130 -454
    133 -452
    136 -450
    139 -447
    142 -445
    145 -443
    148 -440
    151 -437
    153 -435
    156 -432
    159 -429
    161 -427
    164 -424
    166 -421
    169 -418
    171 -415
    173 -412
    175 -408
    177 -405
    179 -402
    181 -399
    183 -395
    184 -392
    186 -388
    188 -385
    189 -381
    190 -378
    192 -374
    193 -370
    194 -367
    195 -363
    196 -359
    197 -355
    198 -351
    198 -347
    199 -343
    199 -339
    200 -335
    200 -330
    200 -326
    200 -322
    200 -318
    200 -313
    200 -309
    199 -304
    199 -300
    199 -295
    198 -291
    197 -286
    196 -281
    195 -277
    194 -272
    193 -267
    192 -262
    190 -258
    189 -253
    187 -248
    186 -243
    184 -238
    182 -233
    180 -228
    178 -223
    175 -218
    173 -212
    171 -207
    168 -202
    165 -197
    162 -191
    160 -186
    156 -181
    153 -175
    150 -170
    147 -165
    143 -159
    139 -154
    136 -148
    132 -143
    128 -137
    124 -131
    120 -126
    115 -120
    111 -115
    106 -109
    102 -103
    97 -98
    92 -92
    87 -86
    82 -80
    76 -74
    71 -69
    65 -63
    60 -57
    54 -51
    48 -45
    42 -39
    36 -33
    30 -27
    24 -21
    17 -15
    11 -9
    4 -3
    -3 3
    -10 9
    -17 15
    -24 21
    -31 27
    -39 33
    -46 39
    -54 45
    -61 51
    -69 57
    -77 63
    -85 70
    -93 76
    -102 82
    -110 88
    -119 94
    -127 100
    -136 107
    -145 113
    -154 119
    -163 125
    -172 131
    -182 138
    -191 144
    -201 150
    -210 156
    -220 163
    -230 169
    -240 175
    -250 181
    -260 188
    -270 194
    -281 200
    -291 206
    -302 213
    -313 219
    -324 225
    -335 232
    -346 238
    -357 244
    -368 250
    -380 257
    -391 263
    -403 269
    -414 276
    -426 282
    -438 288
    -450 294
    -462 301
    -475 307
    -487 313
    -499 319
    -512 326
    -524 332
    -537 338
    -550 344
    -563 351
    -576 357
    -589 363
    -602 369
    -616 376
    -629 382
    -643 388
    -656 394
    -670 401
    -684 407
    -698 413
    -712 419
    -726 425
    -740 432
    -754 438
    -769 444
    -783 450
    -798 456
    -812 462
    -827 469
    -842 475
    -857 481
    -872 487
    -887 493
    -902 499
    -917 505
    -933 512
    -948 518
    -964 524
    -979 530
    -995 536
    -1011 542
    -1027 548
    -1043 554
    -1059 560
    -1075 566
    -1091 572
    -1108 578
    -1124 584
    -1141 590
    -1157 596
    -1174 602
    -1190 608
    -1207 614
    -1224 620
    -1241 626
    -1258 632
    -1275 638
    -1293 644
    -1310 649
    1304 641
    1287 635
    1269 629
    1252 624
    1235 618
    1218 612
    1201 606
    1185 600
    1168 594
    1151 588
    1135 582
    1118 576
    1102 570
    1085 564
    1069 558
    1053 552
    1037 546
    1021 540
    1005 534
    989 528
    973 522
    958 516
    942 510
    927 504
    911 498
    896 492
    881 486
    866 480
    851 473
    836 467
    821 461
    806 455
    791 449
    777 443
    762 437
    748 431
    734 424
    720 418
    705 412
    691 406
    678 400
    664 394
    650 387
    636 381
    623 375
    609 369
    596 363
    583 356
    570 350
    557 344
    544 338
    531 331
    518 325
    506 319
    493 313
    481 307
    468 300
    456 294
    444 288
    432 282
    420 275
    408 269
    396 263
    385 257
    373 250
    362 244
    351 238
    339 232
    328 225
    317 219
    307 213
    296 207
    285 200
    275 194
    264 188
    254 182
    244 175
    234 169
    224 163
    214 157
    204 150
    194 144
    185 138
    175 132
    166 126
    157 119
    148 113
    139 107
    130 101
    121 95
    113 89
    104 82
    96 76
    87 70
    79 64
    71 58
    63 52
    55 46
    48 40
    40 33
    33 27
    25 21
    18 15
    11 9
    4 3
    -3 -3
    -10 -9
    -17 -15
    -23 -21
    -30 -27
    -36 -33
    -42 -38
    -48 -44
    -54 -50
    -60 -56
    -66 -62
    -71 -68
    -77 -74
    -82 -79
    -87 -85
    -93 -91
    -98 -97
    -102 -102
    -107 -108
    -112 -114
    -116 -119
    -121 -125
    -125 -131
    -129 -136
    -133 -142
    -137 -147
    -141 -153
    -145 -158
    -149 -164
    -152 -169
    -155 -175
    -159 -180
    -162 -185
    -165 -191
    -168 -196
    -171 -201
    -173 -206
    -176 -212
    -178 -217
    -181 -222
    -183 -227
    -185 -232
    -187 -237
    -189 -242
    -191 -247
    -192 -252
    -194 -257
    -195 -262
    -197 -267
    -198 -272
    -199 -276
    -200 -281
    -201 -286
    -202 -290
    -202 -295
    -203 -300
    -204 -304
    -204 -309
    -204 -313
    -204 -317
    -205 -322
    -204 -326
    -204 -330
    -204 -335
    -204 -339
    -203 -343
    -203 -347
    -202 -351
    -202 -355
    -201 -359
    -200 -363
    -199 -367
    -198 -371
    -197 -374
    -195 -378
    -194 -382
    -193 -385
    -191 -389
    -190 -392
    -188 -396
    -186 -399
    -184 -403
    -182 -406
    -180 -409
    -178 -412
    -176 -416
    -174 -419
    -172 -422
    -169 -425
    -167 -428
    -164 -430
    -162 -433
    -159 -436
    -156 -439
    -153 -441
    -150 -444
    -148 -446
    -145 -449
    -141 -451
    -138 -454
    -135 -456
    -132 -458
    -129 -460
    -125 -462
    -122 -464
    -119 -466
    -115 -468
    -112 -470
    -108 -472
    -104 -474
    -101 -475
    -97 -477
    -93 -478
    -89 -480
    -86 -481
    -82 -483
    -78 -484
    -74 -485
    -70 -486
    -66 -487
    -62 -488
    -58 -489
    -54 -490
    -50 -491
    -46 -492
    -42 -493
    -38 -493
    -33 -494
    -29 -494
    -25 -495
    -21 -495
    -17 -495
    -13 -496
    -8 -496
    -4 -496
    0 -496
    4 -496
    8 -496
    13 -496
    17 -495
    21 -495
    25 -495
    29 -494
    33 -494
    38 -493
    42 -493
    46 -492
    50 -491
    54 -490
    58 -489
    62 -488
    66 -487
    70 -486
    74 -485
    78 -484
    82 -483
    86 -481
    89 -480
    93 -478
    97 -477
    101 -475
    104 -474
    108 -472
    112 -470
    115 -468
    119 -466
    122 -464
    125 -462
    129 -460
    132 -458
    135 -456
    138 -454
    141 -451
    145 -449
    148 -446
    150 -444
    153 -441
    156 -439
    159 -436
    162 -433
    164 -430
    167 -428
    169 -425
    172 -422
    174 -419
    176 -416
    178 -412
    180 -409
    182 -406
    184 -403
    186 -399
    188 -396
    190 -392
    191 -389
    193 -385
    194 -382
    195 -378
    197 -374
    198 -371
    199 -367
    200 -363
    201 -359
    202 -355
    202 -351
    203 -347
    203 -343
    204 -339
    204 -335
    204 -330
    204 -326
    205 -322
    204 -317
    204 -313
    204 -309
    204 -304
    203 -300
    202 -295
    202 -290
    201 -286
    200 -281
    199 -276
    198 -272
    197 -267
    195 -262
    194 -257
    192 -252
    191 -247
    189 -242
    187 -237
    185 -232
    183 -227
    181 -222
    178 -217
    176 -212
    173 -206
    171 -201
    168 -196
    165 -191
    162 -185
    159 -180
    155 -175
    152 -169
    149 -164
    145 -158
    141 -153
    137 -147
    133 -142
    129 -136
    125 -131
    121 -125
    116 -119
    112 -114
    107 -108
    102 -102
    98 -97
    93 -91
    87 -85
    82 -79
    77 -74
    71 -68
    66 -62
    60 -56
    54 -50
    48 -44
    42 -38
    36 -33
    30 -27
    23 -21
    17 -15
    10 -9
    3 -3
    -4 3
    -11 9
    -18 15
    -25 21
    -33 27
    -40 33
    -48 40
    -55 46
    -63 52
    -71 58
    -79 64
    -87 70
    -96 76
    -104 82
    -113 89
    -121 95
    -130 101
    -139 107
    -148 113
    -157 119
    -166 126
    -175 132
    -185 138
    -194 144
    -204 150
    -214 157
    -224 163
    -234 169
    -244 175
    -254 182
    -264 188
    -275 194
    -285 200
    -296 207
    -307 213
    -317 219
    -328 225
    -339 232
    -351 238
    -362 244
    -373 250
    -385 257
    -396 263
    -408 269
    -420 275
    -432 282
    -444 288
    -456 294
    -468 300
    -481 307
    -493 313
    -506 319
    -518 325
    -531 331
    -544 338
    -557 344
    -570 350
    -583 356
    -596 363
    -609 369
    -623 375
    -636 381
    -650 387
    -664 394
    -678 400
    -691 406
    -705 412
    -720 418
    -734 424
    -748 431
    -762 437
    -777 443
    -791 449
    -806 455
    -821 461
    -836 467
    -851 473
    -866 480
    -881 486
    -896 492
    -911 498
    -927 504
    -942 510
    -958 516
    -973 522
    -989 528
    -1005 534
    -1021 540
    -1037 546
    -1053 552
    -1069 558
    -1085 564
    -1102 570
    -1118 576
    -1135 582
    -1151 588
    -1168 594
    -1185 600
    -1201 606
    -1218 612
    -1235 618
    -1252 624
    -1269 629
    -1287 635
    -1304 641
    1298 633
    1281 627
    1264 621
    1246 615
    1229 609
    1212 604
    1195 598
    1179 592
    1162 586
    1145 580
    1129 574
    1112 568
    1096 562
    1079 556
    1063 550
    1047 544
    1031 538
    1015 532
    999 526
    983 520
    967 514
    952 508
    936 502
    921 496
    905 490
    890 484
    875 478
    860 472
    845 466
    830 460
    815 454
    800 448
    785 442
    771 436
    756 430
    742 423
    728 417
    713 411
    699 405
    685 399
    671 393
    658 387
    644 380
    630 374
    617 368
    603 362
    590 356
    577 350
    564 343
    550 337
    538 331
    525 325
    512 319
    499 312
    487 306
    474 300
    462 294
    450 288
    438 281
    426 275
    414 269
    402 263
    390 256
    379 250
    367 244
    356 238
    344 232
    333 225
    322 219
    311 213
    300 207
    290 200
    279 194
    268 188
    258 182
    248 176
    237 169
    227 163
    217 157
    208 151
    198 145
    188 138
    179 132
    169 126
    160 120
    151 114
    142 108
    133 101
    124 95
    115 89
    106 83
    98 77
    89 71
    81 65
    73 59
    65 52
    57 46
    49 40
    42 34
    34 28
    26 22
    19 16
    12 10
    5 4
    -2 -2
    -9 -8
    -16 -14
    -23 -20
    -29 -26
    -35 -32
    -42 -38
    -48 -44
    -54 -49
    -60 -55
    -66 -61
    -71 -67
    -77 -73
    -83 -79
    -88 -84
    -93 -90
    -98 -96
    -103 -102
    -108 -107
    -113 -113
    -118 -119
    -122 -124
    -126 -130
    -131 -135
    -135 -141
    -139 -146
    -143 -152
    -147 -157
    -150 -163
    -154 -168
    -157 -174
    -161 -179
    -164 -185
    -167 -190
    -170 -195
    -173 -200
    -176 -206
    -178 -211
    -181 -216
    -183 -221
    -186 -226
    -188 -231
    -190 -237
    -192 -242
    -194 -247
    -196 -251
    -197 -256
    -199 -261
    -200 -266
    -201 -271
    -203 -276
    -204 -281
    -205 -285
    -206 -290
    -206 -295
    -207 -299
    -208 -304
    -208 -308
    -208 -313
    -209 -317
    -209 -321
    -209 -326
    -209 -330
    -209 -334
    -208 -339
    -208 -343
    -208 -347
    -207 -351
    -206 -355
    -206 -359
    -205 -363
    -204 -367
    -203 -371
    -202 -374
    -200 -378
    -199 -382
    -198 -386
    -196 -389
    -195 -393
    -193 -396
    -191 -400
    -189 -403
    -188 -406
    -186 -410
    -184 -413
    -181 -416
    -179 -419
    -177 -422
    -175 -425
    -172 -428
    -170 -431
    -167 -434
    -164 -437
    -162 -440
    -159 -442
    -156 -445
    -153 -448
    -150 -450
    -147 -453
    -144 -455
    -141 -457
    -137 -460
    -134 -462
    -131 -464
    -127 -466
    -124 -468
    -121 -470
    -117 -472
    -113 -474
    -110 -475
    -106 -477
    -102 -479
    -99 -480
    -95 -482
    -91 -483
    -87 -485
    -83 -486
    -79 -487
    -75 -489
    -71 -490
    -67 -491
    -63 -492
    -59 -493
    -55 -494
    -51 -495
    -47 -495
    -42 -496
    -38 -497
    -34 -497
    -30 -498
    -26 -498
    -21 -499
    -17 -499
    -13 -499
    -9 -499
    -4 -499
    0 -499
    4 -499
    9 -499
    13 -499
    17 -499
    21 -499
    26 -498
    30 -498
    34 -497
    38 -497
    42 -496
    47 -495
    51 -495
    55 -494
    59 -493
    63 -492
    67 -491
    71 -490
    75 -489
    79 -487
    83 -486
    87 -485
    91 -483
    95 -482
    99 -480
    102 -479
    106 -477
    110 -475
    113 -474
    117 -472
    121 -470
    124 -468
    127 -466
    131 -464
    134 -462
    137 -460
    141 -457
    144 -455
    147 -453
    150 -450
    153 -448
    156 -445
    159 -442
    162 -440
    164 -437
    167 -434
    170 -431
    172 -428
    175 -425
    177 -422
    179 -419
    181 -416
    184 -413
    186 -410
    188 -406
    189 -403
    191 -400
    193 -396
    195 -393
    196 -389
    198 -386
    199 -382
    200 -378
    202 -374
    203 -371
    204 -367
    205 -363
    206 -359
    206 -355
    207 -351
    208 -347
    208 -343
    208 -339
    209 -334
    209 -330
    209 -326
    209 -321
    209 -317
    208 -313
    208 -308
    208 -304
    207 -299
    206 -295
    206 -290
    205 -285
    204 -281
    203 -276
    201 -271
    200 -266
    199 -261
    197 -256
    196 -251
    194 -247
    192 -242
    190 -237
    188 -231
    186 -226
    183 -221
    181 -216
    178 -211
    176 -206
    173 -200
    170 -195
    167 -190
    164 -185
    161 -179
    157 -174
    154 -168
    150 -163
    147 -157
    143 -152
    139 -146
    135 -141
    131 -135
    126 -130
    122 -124
    118 -119
    113 -113
    108 -107
    103 -102
    98 -96
    93 -90
    88 -84
    83 -79
    77 -73
    71 -67
    66 -61
    60 -55
    54 -49
    48 -44
    42 -38
    35 -32
    29 -26
    23 -20
    16 -14
    9 -8
    2 -2
    -5 4
    -12 10
    -19 16
    -26 22
    -34 28
    -42 34
    -49 40
    -57 46
    -65 52
    -73 59
    -81 65
    -89 71
    -98 77
    -106 83
    -115 89
    -124 95
    -133 101
    -142 108
    -151 114
    -160 120
    -169 126
    -179 132
    -188 138
    -198 145
    -208 151
    -217 157
    -227 163
    -237 169
    -248 176
    -258 182
    -268 188
    -279 194
    -290 200
    -300 207
    -311 213
    -322 219
    -333 225
    -344 232
    -356 238
    -367 244
    -379 250
    -390 256
    -402 263
    -414 269
    -426 275
    -438 281
    -450 288
    -462 294
    -474 300
    -487 306
    -499 312
    -512 319
    -525 325
    -538 331
    -550 337
    -564 343
    -577 350
    -590 356
    -603 362
    -617 368
    -630 374
    -644 380
    -658 387
    -671 393
    -685 399
    -699 405
    -713 411
    -728 417
    -742 423
    -756 430
    -771 436
    -785 442
    -800 448
    -815 454
    -830 460
    -845 466
    -860 472
    -875 478
    -890 484
    -905 490
    -921 496
    -936 502
    -952 508
    -967 514
    -983 520
    -999 526
    -1015 532
    -1031 538
    -1047 544
    -1063 550
    -1079 556
    -1096 562
    -1112 568
    -1129 574
    -1145 580
    -1162 586
    -1179 592
    -1195 598
    -1212 604
    -1229 609
    -1246 615
    -1264 621
    -1281 627
    -1298 633
    1292 625
    1275 619
    1258 613
    1241 607
    1224 601
    1207 596
    1190 590
    1173 584
    1156 578
    1139 572
    1123 566
    1106 560
    1090 554
    1073 549
    1057 543
    1041 537
    1025 531
    1009 525
    993 519
    977 513
    961 507
    946 501
    930 495
    915 489
    899 483
    884 477
    869 471
    854 465
    839 459
    824 453
    809 447
    794 441
    779 435
    765 429
    750 422
    736 416
    722 410
    707 404
    693 398
    679 392
    665 386
    651 380
    638 374
    624 367
    611 361
    597 355
    584 349
    570 343
    557 337
    544 331
    531 324
    519 318
    506 312
    493 306
    481 300
    468 294
    456 287
    444 281
    431 275
    419 269
    408 263
    396 256
    384 250
    372 244
    361 238
    350 232
    338 225
    327 219
    316 213
    305 207
    294 201
    283 195
    273 188
    262 182
    252 176
    242 170
    231 164
    221 157
    211 151
    201 145
    192 139
    182 133
    172 127
    163 120
    154 114
    145 108
    135 102
    126 96
    118 90
    109 84
    100 78
    92 71
    83 65
    75 59
    67 53
    59 47
    51 41
    43 35
    35 29
    28 23
    20 17
    13 11
    6 5
    -1 -1
    -8 -7
    -15 -13
    -22 -19
    -28 -25
    -35 -31
    -41 -37
    -48 -43
    -54 -48
    -60 -54
    -66 -60
    -72 -66
    -77 -72
    -83 -78
    -88 -83
    -94 -89
    -99 -95
    -104 -100
    -109 -106
    -114 -112
    -119 -118
    -123 -123
    -128 -129
    -132 -134
    -136 -140
    -140 -145
    -144 -151
    -148 -156
    -152 -162
    -156 -167
    -159 -173
    -163 -178
    -166 -184
    -169 -189
    -172 -194
    -175 -199
    -178 -205
    -181 -210
    -184 -215
    -186 -220
    -189 -225
    -191 -231
    -193 -236
    -195 -241
    -197 -246
    -199 -251
    -201 -256
    -202 -261
    -204 -265
    -205 -270
    -206 -275
    -207 -280
    -209 -285
    -209 -289
    -210 -294
    -211 -299
    -212 -303
    -212 -308
    -213 -312
    -213 -317
    -213 -321
    -213 -325
    -213 -330
    -213 -334
    -213 -338
    -213 -342
    -212 -347
    -212 -351
    -211 -355
    -210 -359
    -210 -363
    -209 -367
    -208 -371
    -207 -374
    -205 -378
    -204 -382
    -203 -386
    -201 -389
    -200 -393
    -198 -396
    -197 -400
    -195 -403
    -193 -407
    -191 -410
    -189 -413
    -187 -417
    -185 -420
    -182 -423
    -180 -426
    -178 -429
    -175 -432
    -172 -435
    -170 -438
    -167 -440
    -164 -443
    -161 -446
    -159 -449
    -156 -451
    -152 -454
    -149 -456
    -146 -458
    -143 -461
    -140 -463
    -136 -465
    -133 -467
    -129 -469
    -126 -471
    -122 -473
    -119 -475
    -115 -477
    -111 -479
    -108 -481
    -104 -482
    -100 -484
    -96 -485
    -92 -487
    -88 -488
    -84 -490
    -80 -491
    -76 -492
    -72 -493
    -68 -494
    -64 -495
    -60 -496
    -56 -497
    -52 -498
    -47 -499
    -43 -499
    -39 -500
    -35 -501
    -30 -501
    -26 -502
    -22 -502
    -17 -502
    -13 -502
    -9 -503
    -4 -503
    0 -503
    4 -503
    9 -503
    13 -502
    17 -502
    22 -502
    26 -502
    30 -501
    35 -501
    39 -500
    43 -499
    47 -499
    52 -498
    56 -497
    60 -496
    64 -495
    68 -494
    72 -493
    76 -492
    80 -491
    84 -490
    88 -488
    92 -487
    96 -485
    100 -484
    104 -482
    108 -481
    111 -479
    115 -477
    119 -475
    122 -473
    126 -471
    129 -469
    133 -467
    136 -465
    140 -463
    143 -461
    146 -458
    149 -456
    152 -454
    156 -451
    159 -449
    161 -446
    164 -443
    167 -440
    170 -438
    172 -435
    175 -432
    178 -429
    180 -426
    182 -423
    185 -420
    187 -417
    189 -413
    191 -410
    193 -407
    195 -403
    197 -400
    198 -396
    200 -393
    201 -389
    203 -386
    204 -382
    205 -378
    207 -374
    208 -371
    209 -367
    210 -363
    210 -359
    211 -355
    212 -351
    212 -347
    213 -342
    213 -338
    213 -334
    213 -330
    213 -325
    213 -321
    213 -317
    213 -312
    212 -308
    212 -303
    211 -299
    210 -294
    209 -289
    209 -285
    207 -280
    206 -275
    205 -270
    204 -265
    202 -261
    201 -256
    199 -251
    197 -246
    195 -241
    193 -236
    191 -231
    189 -225
    186 -220
    184 -215
    181 -210
    178 -205
    175 -199
    172 -194
    169 -189
    166 -184
    163 -178
    159 -173
    156 -167
    152 -162
    148 -156
    144 -151
    140 -145
    136 -140
    132 -134
    128 -129
    123 -123
    119 -118
    114 -112
    109 -106
    104 -100
    99 -95
    94 -89
    88 -83
    83 -78
    77 -72
    72 -66
    66 -60
    60 -54
    54 -48
    48 -43
    41 -37
    35 -31
    28 -25
    22 -19
    15 -13
    8 -7
    1 -1
    -6 5
    -13 11
    -20 17
    -28 23
    -35 29
    -43 35
    -51 41
    -59 47
    -67 53
    -75 59
    -83 65
    -92 71
    -100 78
    -109 84
    -118 90
    -126 96
    -135 102
    -145 108
    -154 114
    -163 120
    -172 127
    -182 133
    -192 139
    -201 145
    -211 151
    -221 157
    -231 164
    -242 170
    -252 176
    -262 182
    -273 188
    -283 195
    -294 201
    -305 207
    -316 213
    -327 219
    -338 225
    -350 232
    -361 238
    -372 244
    -384 250
    -396 256
    -408 263
    -419 269
    -431 275
    -444 281
    -456 287
    -468 294
    -481 300
    -493 306
    -506 312
    -519 318
    -531 324
    -544 331
    -557 337
    -570 343
    -584 349
    -597 355
    -611 361
    -624 367
    -638 374
    -651 380
    -665 386
    -679 392
    -693 398
    -707 404
    -722 410
    -736 416
    -750 422
    -765 429
    -779 435
    -794 441
    -809 447
    -824 453
    -839 459
    -854 465
    -869 471
    -884 477
    -899 483
    -915 489
    -930 495
    -946 501
    -961 507
    -977 513
    -993 519
    -1009 525
    -1025 531
    -1041 537
    -1057 543
    -1073 549
    -1090 554
    -1106 560
    -1123 566
    -1139 572
    -1156 578
    -1173 584
    -1190 590
    -1207 596
    -1224 601
    -1241 607
    -1258 613
    -1275 619
    -1292 625
    1287 616
    1269 611
    1252 605
    1235 599
    1218 593
    1201 588
    1184 582
    1167 576
    1150 570
    1133 564
    1117 558
    1100 553
    1084 547
    1068 541
    1051 535
    1035 529
    1019 523
    1003 517
    987 511
    971 505
    955 499
    940 493
    924 488
    909 482
    893 476
    878 470
    863 464
    848 458
    833 452
    818 446
    803 440
    788 434
    773 428
    759 421
    744 415
    730 409
    715 403
    701 397
    687 391
    673 385
    659 379
    645 373
    632 367
    618 361
    604 355
    591 349
    578 342
    564 336
    551 330
    538 324
    525 318
    512 312
    500 306
    487 299
    474 293
    462 287
    450 281
    437 275
    425 269
    413 263
    401 256
    390 250
    378 244
    366 238
    355 232
    343 226
    332 219
    321 213
    310 207
    299 201
    288 195
    277 189
    267 182
    256 176
    246 170
    235 164
    225 158
    215 152
    205 146
    195 139
    185 133
    176 127
    166 121
    157 115
    148 109
    138 103
    129 97
    120 90
    112 84
    103 78
    94 72
    86 66
    77 60
    69 54
    61 48
    53 42
    45 36
    37 30
    29 24
    22 18
    14 12
    7 6
    -0 -0
    -7 -6
    -14 -12
    -21 -18
    -28 -24
    -34 -30
    -41 -36
    -47 -42
    -54 -47
    -60 -53
    -66 -59
    -72 -65
    -77 -71
    -83 -76
    -89 -82
    -94 -88
    -99 -94
    -105 -99
    -110 -105
    -115 -111
    -119 -116
    -124 -122
    -129 -128
    -133 -133
    -138 -139
    -142 -144
    -146 -150
    -150 -155
    -154 -161
    -158 -166
    -161 -172
    -165 -177
    -168 -182
    -171 -188
    -175 -193
    -178 -198
    -181 -204
    -184 -209
    -186 -214
    -189 -219
    -191 -224
    -194 -230
    -196 -235
    -198 -240
    -200 -245
    -202 -250
    -204 -255
    -205 -260
    -207 -265
    -208 -269
    -210 -274
    -211 -279
    -212 -284
    -213 -288
    -214 -293
    -215 -298
    -216 -302
    -216 -307
    -217 -311
    -217 -316
    -217 -320
    -217 -325
    -218 -329
    -217 -333
    -217 -338
    -217 -342
    -217 -346
    -216 -350
    -216 -354
    -215 -358
    -214 -362
    -213 -366
    -213 -370
    -212 -374
    -210 -378
    -209 -382
    -208 -386
    -206 -389
    -205 -393
    -203 -396
    -202 -400
    -200 -403
    -198 -407
    -196 -410
    -194 -414
    -192 -417
    -190 -420
    -188 -423
    -185 -426
    -183 -429
    -180 -432
    -178 -435
    -175 -438
    -173 -441
    -170 -444
    -167 -447
    -164 -449
    -161 -452
    -158 -454
    -155 -457
    -152 -459
    -149 -462
    -145 -464
    -142 -466
    -139 -469
    -135 -471
    -132 -473
    -128 -475
    -124 -477
    -121 -479
    -117 -480
    -113 -482
    -109 -484
    -106 -486
    -102 -487
    -98 -489
    -94 -490
    -90 -492
    -86 -493
    -82 -494
    -78 -495
    -73 -497
    -69 -498
    -65 -499
    -61 -500
    -57 -500
    -52 -501
    -48 -502
    -44 -503
    -39 -503
    -35 -504
    -31 -504
    -26 -505
    -22 -505
    -18 -505
    -13 -506
    -9 -506
    -4 -506
    0 -506
    4 -506
    9 -506
    13 -506
    18 -505
    22 -505
    26 -505
    31 -504
    35 -504
    39 -503
    44 -503
    48 -502
    52 -501
    57 -500
    61 -500
    65 -499
    69 -498
    73 -497
    78 -495
    82 -494
    86 -493
    90 -492
    94 -490
    98 -489
    102 -487
    106 -486
    109 -484
    113 -482
    117 -480
    121 -479
    124 -477
    128 -475
    132 -473
    135 -471
    139 -469
    142 -466
    145 -464
    149 -462
    152 -459
    155 -457
    158 -454
    161 -452
    164 -449
    167 -447
    170 -444
    173 -441
    175 -438
    178 -435
    180 -432
    183 -429
    185 -426
    188 -423
    190 -420
    192 -417
    194 -414
    196 -410
    198 -407
    200 -403
    202 -400
    203 -396
    205 -393
    206 -389
    208 -386
    209 -382
    210 -378
    212 -374
    213 -370
    213 -366
    214 -362
    215 -358
    216 -354
    216 -350
    217 -346
    217 -342
    217 -338
    217 -333
    218 -329
    217 -325
    217 -320
    217 -316
    217 -311
    216 -307
    216 -302
    215 -298
    214 -293
    213 -288
    212 -284
    211 -279
    210 -274
    208 -269
    207 -265
    205 -260
    204 -255
    202 -250
    200 -245
    198 -240
    196 -235
    194 -230
    191 -224
    189 -219
    186 -214
    184 -209
    181 -204
    178 -198
    175 -193
    171 -188
    168 -182
    165 -177
    161 -172
    158 -166
    154 -161
    150 -155
    146 -150
    142 -144
    138 -139
    133 -133
    129 -128
    124 -122
    119 -116
    115 -111
    110 -105
    105 -99
    99 -94
    94 -88
    89 -82
    83 -76
    77 -71
    72 -65
    66 -59
    60 -53
    54 -47
    47 -42
    41 -36
    34 -30
    28 -24
    21 -18
    14 -12
    7 -6
    0 -0
    -7 6
    -14 12
    -22 18
    -29 24
    -37 30
    -45 36
    -53 42
    -61 48
    -69 54
    -77 60
    -86 66
    -94 72
    -103 78
    -112 84
    -120 90
    -129 97
    -138 103
    -148 109
    -157 115
    -166 121
    -176 127
    -185 133
    -195 139
    -205 146
    -215 152
    -225 158
    -235 164
    -246 170
    -256 176
    -267 182
    -277 189
    -288 195
    -299 201
    -310 207
    -321 213
    -332 219
    -343 226
    -355 232
    -366 238
    -378 244
    -390 250
    -401 256
    -413 263
    -425 269
    -437 275
    -450 281
    -462 287
    -474 293
    -487 299
    -500 306
    -512 312
    -525 318
    -538 324
    -551 330
    -564 336
    -578 342
    -591 349
    -604 355
    -618 361
    -632 367
    -645 373
    -659 379
    -673 385
    -687 391
    -701 397
    -715 403
    -730 409
    -744 415
    -759 421
    -773 428
    -788 434
    -803 440
    -818 446
    -833 452
    -848 458
    -863 464
    -878 470
    -893 476
    -909 482
    -924 488
    -940 493
    -955 499
    -971 505
    -987 511
    -1003 517
    -1019 523
    -1035 529
    -1051 535
    -1068 541
    -1084 547
    -1100 553
    -1117 558
    -1133 564
    -1150 570
    -1167 576
    -1184 582
    -1201 588
    -1218 593
    -1235 599
    -1252 605
    -1269 611
    -1287 616
    1281 608
    1264 603
    1246 597
    1229 591
    1212 585
    1195 580
    1178 574
    1161 568
    1144 562
    1128 556
    1111 551
    1094 545
    1078 539
    1062 533
    1045 527
    1029 521
    1013 516
    997 510
    981 504
    965 498
    949 492
    934 486
    918 480
    903 474
    887 468
    872 462
    857 456
    842 450
    827 444
    812 438
    797 432
    782 426
    767 420
    753 414
    738 408
    724 402
    709 396
    695 390
    681 384
    667 378
    653 372
    639 366
    625 360
    612 354
    598 348
    585 342
    572 336
    558 330
    545 324
    532 318
    519 311
    506 305
    494 299
    481 293
    468 287
    456 281
    444 275
    431 269
    419 263
    407 256
    395 250
    383 244
    372 238
    360 232
    349 226
    337 220
    326 214
    315 207
    304 201
    293 195
    282 189
    271 183
    260 177
    250 171
    240 164
    229 158
    219 152
    209 146
    199 140
    189 134
    179 128
    170 122
    160 116
    151 109
    141 103
    132 97
    123 91
    114 85
    105 79
    97 73
    88 67
    80 61
    71 55
    63 49
    55 43
    47 37
    39 31
    31 25
    23 19
    16 13
    8 7
    1 1
    -6 -5
    -13 -11
    -20 -17
    -27 -23
    -34 -29
    -40 -35
    -47 -40
    -53 -46
    -59 -52
    -66 -58
    -72 -64
    -77 -69
    -83 -75
    -89 -81
    -94 -87
    -100 -92
    -105 -98
    -110 -104
    -115 -110
    -120 -115
    -125 -121
    -130 -126
    -134 -132
    -139 -138
    -143 -143
    -147 -149
    -151 -154
    -155 -160
    -159 -165
    -163 -171
    -167 -176
    -170 -181
    -174 -187
    -177 -192
    -180 -197
    -183 -203
    -186 -208
    -189 -213
    -191 -218
    -194 -223
    -196 -228
    -199 -234
    -201 -239
    -203 -244
    -205 -249
    -207 -254
    -209 -259
    -210 -264
    -212 -268
    -213 -273
    -215 -278
    -216 -283
    -217 -288
    -218 -292
    -219 -297
    -220 -302
    -220 -306
    -221 -311
    -221 -315
    -221 -320
    -222 -324
    -222 -328
    -222 -333
    -222 -337
    -222 -341
    -221 -346
    -221 -350
    -220 -354
    -220 -358
    -219 -362
    -218 -366
    -217 -370
    -216 -374
    -215 -378
    -214 -382
    -213 -385
    -212 -389
    -210 -393
    -209 -396
    -207 -400
    -205 -403
    -203 -407
    -202 -410
    -200 -414
    -198 -417
    -195 -420
    -193 -423
    -191 -427
    -188 -430
    -186 -433
    -183 -436
    -181 -439
    -178 -442
    -175 -444
    -173 -447
    -170 -450
    -167 -453
    -164 -455
    -161 -458
    -157 -460
    -154 -463
    -151 -465
    -148 -467
    -144 -470
    -141 -472
    -137 -474
    -134 -476
    -130 -478
    -126 -480
    -123 -482
    -119 -484
    -115 -485
    -111 -487
    -107 -489
    -103 -490
    -99 -492
    -95 -493
    -91 -495
    -87 -496
    -83 -497
    -79 -498
    -75 -500
    -70 -501
    -66 -502
    -62 -503
    -57 -504
    -53 -504
    -49 -505
    -44 -506
    -40 -506
    -36 -507
    -31 -507
    -27 -508
    -22 -508
    -18 -509
    -13 -509
    -9 -509
    -4 -509
    0 -509
    4 -509
    9 -509
    13 -509
    18 -509
    22 -508
    27 -508
    31 -507
    36 -507
    40 -506
    44 -506
    49 -505
    53 -504
    57 -504
    62 -503
    66 -502
    70 -501
    75 -500
    79 -498
    83 -497
    87 -496
    91 -495
    95 -493
    99 -492
    103 -490
    107 -489
    111 -487
    115 -485
    119 -484
    123 -482
    126 -480
    130 -478
    134 -476
    137 -474
    141 -472
    144 -470
    148 -467
    151 -465
    154 -463
    157 -460
    161 -458
    164 -455
    167 -453
    170 -450
    173 -447
    175 -444
    178 -442
    181 -439
    183 -436
    186 -433
    188 -430
    191 -427
    193 -423
    195 -420
    198 -417
    200 -414
    202 -410
    203 -407
    205 -403
    207 -400
    209 -396
    210 -393
    212 -389
    213 -385
    214 -382
    215 -378
    216 -374
    217 -370
    218 -366
    219 -362
    220 -358
    220 -354
    221 -350
    221 -346
    222 -341
    222 -337
    222 -333
    222 -328
    222 -324
    221 -320
    221 -315
    221 -311
    220 -306
    220 -302
    219 -297
    218 -292
    217 -288
    216 -283
    215 -278
    213 -273
    212 -268
    210 -264
    209 -259
    207 -254
    205 -249
    203 -244
    201 -239
    199 -234
    196 -228
    194 -223
    191 -218
    189 -213
    186 -208
    183 -203
    180 -197
    177 -192
    174 -187
    170 -181
    167 -176
    163 -171
    159 -165
    155 -160
    151 -154
    147 -149
    143 -143
    139 -138
    134 -132
    130 -126
    125 -121
    120 -115
    115 -110
    110 -104
    105 -98
    100 -92
    94 -87
    89 -81
    83 -75
    77 -69
    72 -64
    66 -58
    59 -52
    53 -46
    47 -40
    40 -35
    34 -29
    27 -23
    20 -17
    13 -11
    6 -5
    -1 1
    -8 7
    -16 13
    -23 19
    -31 25
    -39 31
    -47 37
    -55 43
    -63 49
    -71 55
    -80 61
    -88 67
    -97 73
    -105 79
    -114 85
    -123 91
    -132 97
    -141 103
    -151 109
    -160 116
    -170 122
    -179 128
    -189 134
    -199 140
    -209 146
    -219 152
    -229 158
    -240 164
    -250 171
    -260 177
    -271 183
    -282 189
    -293 195
    -304 201
    -315 207
    -326 214
    -337 220
    -349 226
    -360 232
    -372 238
    -383 244
    -395 250
    -407 256
    -419 263
    -431 269
    -444 275
    -456 281
    -468 287
    -481 293
    -494 299
    -506 305
    -519 311
    -532 318
    -545 324
    -558 330
    -572 336
    -585 342
    -598 348
    -612 354
    -625 360
    -639 366
    -653 372
    -667 378
    -681 384
    -695 390
    -709 396
    -724 402
    -738 408
    -753 414
    -767 420
    -782 426
    -797 432
    -812 438
    -827 444
    -842 450
    -857 456
    -872 462
    -887 468
    -903 474
    -918 480
    -934 486
    -949 492
    -965 498
    -981 504
    -997 510
    -1013 516
    -1029 521
    -1045 527
    -1062 533
    -1078 539
    -1094 545
    -1111 551
    -1128 556
    -1144 562
    -1161 568
    -1178 574
    -1195 580
    -1212 585
    -1229 591
    -1246 597
    -1264 603
    -1281 608
    1275 600
    1258 595
    1241 589
    1223 583
    1206 578
    1189 572
    1172 566
    1155 560
    1139 555
    1122 549
    1105 543
    1089 537
    1072 531
    1056 526
    1040 520
    1023 514
    1007 508
    991 502
    975 496
    959 491
    944 485
    928 479
    912 473
    897 467
    881 461
    866 455
    851 449
    836 443
    821 437
    806 431
    791 425
    776 420
    761 414
    747 408
    732 402
    718 396
    703 390
    689 384
    675 378
    661 372
    647 366
    633 360
    619 354
    606 347
    592 341
    579 335
    565 329
    552 323
    539 317
    526 311
    513 305
    500 299
    487 293
    475 287
    462 281
    450 275
    437 269
    425 263
    413 256
    401 250
    389 244
    377 238
    366 232
    354 226
    342 220
    331 214
    320 208
    309 202
    298 195
    287 189
    276 183
    265 177
    254 171
    244 165
    233 159
    223 153
    213 147
    203 141
    193 135
    183 128
    173 122
    164 116
    154 110
    145 104
    135 98
    126 92
    117 86
    108 80
    99 74
    91 68
    82 62
    74 56
    65 50
    57 44
    49 38
    41 32
    33 26
    25 20
    18 14
    10 8
    3 2
    -5 -4
    -12 -10
    -19 -16
    -26 -22
    -33 -27
    -40 -33
    -46 -39
    -53 -45
    -59 -51
    -65 -57
    -71 -62
    -77 -68
    -83 -74
    -89 -80
    -95 -86
    -100 -91
    -106 -97
    -111 -103
    -116 -108
    -121 -114
    -126 -120
    -131 -125
    -135 -131
    -140 -136
    -144 -142
    -149 -147
    -153 -153
    -157 -158
    -161 -164
    -165 -169
    -168 -175
    -172 -180
    -176 -185
    -179 -191
    -182 -196
    -185 -201
    -188 -207
    -191 -212
    -194 -217
    -197 -222
    -199 -227
    -202 -232
    -204 -237
    -206 -242
    -208 -248
    -210 -253
    -212 -257
    -214 -262
    -215 -267
    -217 -272
    -218 -277
    -219 -282
    -221 -286
    -222 -291
    -223 -296
    -223 -301
    -224 -305
    -225 -310
    -225 -314
    -226 -319
    -226 -323
    -226 -328
    -226 -332
    -226 -336
    -226 -341
    -226 -345
    -225 -349
    -225 -353
    -224 -357
    -224 -361
    -223 -365
    -222 -369
    -221 -373
    -220 -377
    -219 -381
    -218 -385
    -217 -389
    -215 -392
    -214 -396
    -212 -400
    -210 -403
    -209 -407
    -207 -410
    -205 -414
    -203 -417
    -201 -420
    -199 -423
    -196 -427
    -194 -430
    -192 -433
    -189 -436
    -186 -439
    -184 -442
    -181 -445
    -178 -448
    -175 -450
    -172 -453
    -169 -456
    -166 -458
    -163 -461
    -160 -463
    -157 -466
    -153 -468
    -150 -470
    -146 -473
    -143 -475
    -139 -477
    -136 -479
    -132 -481
    -128 -483
    -124 -485
    -121 -487
    -117 -488
    -113 -490
    -109 -492
    -105 -493
    -101 -495
    -97 -496
    -92 -498
    -88 -499
    -84 -500
    -80 -501
    -76 -503
    -71 -504
    -67 -505
    -63 -506
    -58 -506
    -54 -507
    -49 -508
    -45 -509
    -41 -509
    -36 -510
    -32 -510
    -27 -511
    -23 -511
    -18 -511
    -14 -512
    -9 -512
    -5 -512
    0 -512
    5 -512
    9 -512
    14 -512
    18 -511
    23 -511
    27 -511
    32 -510
    36 -510
    41 -509
    45 -509
    49 -508
    54 -507
    58 -506
    63 -506
    67 -505
    71 -504
    76 -503
    80 -501
    84 -500
    88 -499
    92 -498
    97 -496
    101 -495
    105 -493
    109 -492
    113 -490
    117 -488
    121 -487
    124 -485
    128 -483
    132 -481
    136 -479
    139 -477
    143 -475
    146 -473
    150 -470
    153 -468
    157 -466
    160 -463
    163 -461
    166 -458
    169 -456
    172 -453
    175 -450
    178 -448
    181 -445
    184 -442
    186 -439
    189 -436
    192 -433
    194 -430
    196 -427
    199 -423
    201 -420
    203 -417
    205 -414
    207 -410
    209 -407
    210 -403
    212 -400
    214 -396
    215 -392
    217 -389
    218 -385
    219 -381
    220 -377
    221 -373
    222 -369
    223 -365
    224 -361
    224 -357
    225 -353
    225 -349
    226 -345
    226 -341
    226 -336
    226 -332
    226 -328
    226 -323
    226 -319
    225 -314
    225 -310
    224 -305
    223 -301
    223 -296
    222 -291
    221 -286
    219 -282
    218 -277
    217 -272
    215 -267
    214 -262
    212 -257
    210 -253
    208 -248
    206 -242
    204 -237
    202 -232
    199 -227
    197 -222
    194 -217
    191 -212
    188 -207
    185 -201
    182 -196
    179 -191
    176 -185
    172 -180
    168 -175
    165 -169
    161 -164
    157 -158
    153 -153
    149 -147
    144 -142
    140 -136
    135 -131
    131 -125
    126 -120
    121 -114
    116 -108
    111 -103
    106 -97
    100 -91
    95 -86
    89 -80
    83 -74
    77 -68
    71 -62
    65 -57
    59 -51
    53 -45
    46 -39
    40 -33
    33 -27
    26 -22
    19 -16
    12 -10
    5 -4
    -3 2
    -10 8
    -18 14
    -25 20
    -33 26
    -41 32
    -49 38
    -57 44
    -65 50
    -74 56
    -82 62
    -91 68
    -99 74
    -108 80
    -117 86
    -126 92
    -135 98
    -145 104
    -154 110
    -164 116
    -173 122
    -183 128
    -193 135
    -203 141
    -213 147
    -223 153
    -233 159
    -244 165
    -254 171
    -265 177
    -276 183
    -287 189
    -298 195
    -309 202
    -320 208
    -331 214
    -342 220
    -354 226
    -366 232
    -377 238
    -389 244
    -401 250
    -413 256
    -425 263
    -437 269
    -450 275
    -462 281
    -475 287
    -487 293
    -500 299
    -513 305
    -526 311
    -539 317
    -552 323
    -565 329
    -579 335
    -592 341
    -606 347
    -619 354
    -633 360
    -647 366
    -661 372
    -675 378
    -689 384
    -703 390
    -718 396
    -732 402
    -747 408
    -761 414
    -776 420
    -791 425
    -806 431
    -821 437
    -836 443
    -851 449
    -866 455
    -881 461
    -897 467
    -912 473
    -928 479
    -944 485
    -959 491
    -975 496
    -991 502
    -1007 508
    -1023 514
    -1040 520
    -1056 526
    -1072 531
    -1089 537
    -1105 543
    -1122 549
    -1139 555
    -1155 560
    -1172 566
    -1189 572
    -1206 578
    -1223 583
    -1241 589
    -1258 595
    -1275 600
    1269 592
    1252 587
    1235 581
    1218 575
    1200 570
    1183 564
    1166 558
    1150 553
    1133 547
    1116 541
    1099 535
    1083 530
    1066 524
    1050 518
    1034 512
    1018 506
    1001 501
    985 495
    969 489
    954 483
    938 477
    922 472
    906 466
    891 460
    875 454
    860 448
    845 442
    830 436
    815 430
    800 424
    785 419
    770 413
    755 407
    741 401
    726 395
    712 389
    697 383
    683 377
    669 371
    655 365
    641 359
    627 353
    613 347
    600 341
    586 335
    573 329
    559 323
    546 317
    533 311
    520 305
    507 299
    494 293
    481 287
    469 281
    456 275
    444 269
    431 263
    419 257
    407 250
    395 244
    383 238
    371 232
    359 226
    348 220
    336 214
    325 208
    314 202
    303 196
    291 190
    280 184
    270 178
    259 172
    248 166
    238 159
    227 153
    217 147
    207 141
    197 135
    187 129
    177 123
    167 117
    158 111
    148 105
    139 99
    129 93
    120 87
    111 81
    102 75
    93 69
    85 63
    76 57
    68 51
    59 45
    51 39
    43 33
    35 27
    27 21
    19 15
    12 9
    4 3
    -3 -3
    -11 -9
    -18 -14
    -25 -20
    -32 -26
    -39 -32
    -45 -38
    -52 -44
    -58 -50
    -65 -55
    -71 -61
    -77 -67
    -83 -73
    -89 -78
    -95 -84
    -100 -90
    -106 -96
    -111 -101
    -116 -107
    -122 -113
    -127 -118
    -131 -124
    -136 -129
    -141 -135
    -145 -140
    -150 -146
    -154 -151
    -158 -157
    -162 -162
    -166 -168
    -170 -173
    -174 -179
    -177 -184
    -181 -189
    -184 -195
    -187 -200
    -191 -205
    -193 -210
    -196 -216
    -199 -221
    -202 -226
    -204 -231
    -207 -236
    -209 -241
    -211 -246
    -213 -251
    -215 -256
    -217 -261
    -219 -266
    -220 -271
    -222 -276
    -223 -281
    -224 -285
    -225 -290
    -226 -295
    -227 -299
    -228 -304
    -229 -309
    -229 -313
    -230 -318
    -230 -322
    -230 -327
    -230 -331
    -231 -335
    -230 -340
    -230 -344
    -230 -348
    -230 -352
    -229 -356
    -229 -361
    -228 -365
    -227 -369
    -226 -373
    -225 -377
    -224 -380
    -223 -384
    -222 -388
    -220 -392
    -219 -395
    -217 -399
    -216 -403
    -214 -406
    -212 -410
    -210 -413
    -208 -417
    -206 -420
    -204 -423
    -202 -426
    -199 -430
    -197 -433
    -195 -436
    -192 -439
    -189 -442
    -187 -445
    -184 -448
    -181 -450
    -178 -453
    -175 -456
    -172 -459
    -169 -461
    -166 -464
    -162 -466
    -159 -469
    -156 -471
    -152 -473
    -149 -475
    -145 -478
    -141 -480
    -138 -482
    -134 -484
    -130 -486
    -126 -488
    -122 -489
    -118 -491
    -114 -493
    -110 -495
    -106 -496
    -102 -498
    -98 -499
    -94 -500
    -90 -502
    -85 -503
    -81 -504
    -77 -505
    -72 -506
    -68 -507
    -64 -508
    -59 -509
    -55 -510
    -50 -511
    -46 -511
    -41 -512
    -37 -513
    -32 -513
    -28 -514
    -23 -514
    -18 -514
    -14 -514
    -9 -515
    -5 -515
    0 -515
    5 -515
    9 -515
    14 -514
    18 -514
    23 -514
    28 -514
    32 -513
    37 -513
    41 -512
    46 -511
    50 -511
    55 -510
    59 -509
    64 -508
    68 -507
    72 -506
    77 -505
    81 -504
    85 -503
    90 -502
    94 -500
    98 -499
    102 -498
    106 -496
    110 -495
    114 -493
    118 -491
    122 -489
    126 -488
    130 -486
    134 -484
    138 -482
    141 -480
    145 -478
    149 -475
    152 -473
    156 -471
    159 -469
    162 -466
    166 -464
    169 -461
    172 -459
    175 -456
    178 -453
    181 -450
    184 -448
    187 -445
    189 -442
    192 -439
    195 -436
    197 -433
    199 -430
    202 -426
    204 -423
    206 -420
    208 -417
    210 -413
    212 -410
    214 -406
    216 -403
    217 -399
    219 -395
    220 -392
    222 -388
    223 -384
    224 -380
    225 -377
    226 -373
    227 -369
    228 -365
    229 -361
    229 -356
    230 -352
    230 -348
    230 -344
    230 -340
    231 -335
    230 -331
    230 -327
    230 -322
    230 -318
    229 -313
    229 -309
    228 -304
    227 -299
    226 -295
    225 -290
    224 -285
    223 -281
    222 -276
    220 -271
    219 -266
    217 -261
    215 -256
    213 -251
    211 -246
    209 -241
    207 -236
    204 -231
    202 -226
    199 -221
    196 -216
    193 -210
    191 -205
    187 -200
    184 -195
    181 -189
    177 -184
    174 -179
    170 -173
    166 -168
    162 -162
    158 -157
    154 -151
    150 -146
    145 -140
    141 -135
    136 -129
    131 -124
    127 -118
    122 -113
    116 -107
    111 -101
    106 -96
    100 -90
    95 -84
    89 -78
    83 -73
    77 -67
    71 -61
    65 -55
    58 -50
    52 -44
    45 -38
    39 -32
    32 -26
    25 -20
    18 -14
    11 -9
    3 -3
    -4 3
    -12 9
    -19 15
    -27 21
    -35 27
    -43 33
    -51 39
    -59 45
    -68 51
    -76 57
    -85 63
    -93 69
    -102 75
    -111 81
    -120 87
    -129 93
    -139 99
    -148 105
    -158 111
    -167 117
    -177 123
    -187 129
    -197 135
    -207 141
    -217 147
    -227 153
    -238 159
    -248 166
    -259 172
    -270 178
    -280 184
    -291 190
    -303 196
    -314 202
    -325 208
    -336 214
    -348 220
    -359 226
    -371 232
    -383 238
    -395 244
    -407 250
    -419 257
    -431 263
    -444 269
    -456 275
    -469 281
    -481 287
    -494 293
    -507 299
    -520 305
    -533 311
    -546 317
    -559 323
    -573 329
    -586 335
    -600 341
    -613 347
    -627 353
    -641 359
    -655 365
    -669 371
    -683 377
    -697 383
    -712 389
    -726 395
    -741 401
    -755 407
    -770 413
    -785 419
    -800 424
    -815 430
    -830 436
    -845 442
    -860 448
    -875 454
    -891 460
    -906 466
    -922 472
    -938 477
    -954 483
    -969 489
    -985 495
    -1001 501
    -1018 506
    -1034 512
    -1050 518
    -1066 524
    -1083 530
    -1099 535
    -1116 541
    -1133 547
    -1150 553
    -1166 558
    -1183 564
    -1200 570
    -1218 575
    -1235 581
    -1252 587
    -1269 592
    1264 585
    1246 579
    1229 573
    1212 568
    1195 562
    1178 556
    1161 551
    1144 545
    1127 539
    1110 534
    1094 528
    1077 522
    1061 516
    1044 511
    1028 505
    1012 499
    996 493
    980 488
    964 482
    948 476
    932 470
    916 464
    901 459
    885 453
    870 447
    854 441
    839 435
    824 429
    809 423
    794 418
    779 412
    764 406
    749 400
    735 394
    720 388
    706 382
    691 376
    677 370
    663 364
    649 358
    635 352
    621 346
    607 341
    594 335
    580 329
    567 323
    553 317
    540 311
    527 305
    514 299
    501 293
    488 287
    475 281
    463 275
    450 269
    438 263
    425 257
    413 251
    401 245
    389 238
    377 232
    365 226
    353 220
    342 214
    330 208
    319 202
    308 196
    296 190
    285 184
    274 178
    264 172
    253 166
    242 160
    232 154
    221 148
    211 142
    201 136
    191 130
    181 124
    171 118
    161 112
    152 106
    142 100
    133 94
    123 88
    114 82
    105 76
    96 70
    87 64
    79 58
    70 52
    62 46
    53 40
    45 34
    37 28
    29 22
    21 16
    13 10
    6 4
    -2 -1
    -9 -7
    -17 -13
    -24 -19
    -31 -25
    -38 -31
    -45 -37
    -51 -42
    -58 -48
    -64 -54
    -71 -60
    -77 -66
    -83 -71
    -89 -77
    -95 -83
    -100 -88
    -106 -94
    -111 -100
    -117 -105
    -122 -111
    -127 -117
    -132 -122
    -137 -128
    -142 -133
    -146 -139
    -151 -144
    -155 -150
    -160 -155
    -164 -161
    -168 -166
    -172 -172
    -176 -177
    -179 -182
    -183 -188
    -186 -193
    -189 -198
    -193 -204
    -196 -209
    -199 -214
    -202 -219
    -204 -224
    -207 -230
    -209 -235
    -212 -240
    -214 -245
    -216 -250
    -218 -255
    -220 -260
    -222 -265
    -223 -270
    -225 -274
    -226 -279
    -228 -284
    -229 -289
    -230 -293
    -231 -298
    -232 -303
    -233 -307
    -233 -312
    -234 -316
    -234 -321
    -235 -325
    -235 -330
    -235 -334
    -235 -339
    -235 -343
    -235 -347
    -234 -351
    -234 -356
    -233 -360
    -233 -364
    -232 -368
    -231 -372
    -230 -376
    -229 -380
    -228 -384
    -227 -387
    -225 -391
    -224 -395
    -223 -399
    -221 -402
    -219 -406
    -218 -409
    -216 -413
    -214 -416
    -212 -420
    -210 -423
    -207 -426
    -205 -429
    -203 -433
    -200 -436
    -198 -439
    -195 -442
    -192 -445
    -190 -448
    -187 -451
    -184 -453
    -181 -456
    -178 -459
    -175 -461
    -171 -464
    -168 -466
    -165 -469
    -161 -471
    -158 -474
    -154 -476
    -151 -478
    -147 -480
    -143 -483
    -140 -485
    -136 -487
    -132 -488
    -128 -490
    -124 -492
    -120 -494
    -116 -496
    -112 -497
    -108 -499
    -104 -500
    -99 -502
    -95 -503
    -91 -504
    -87 -506
    -82 -507
    -78 -508
    -73 -509
    -69 -510
    -64 -511
    -60 -512
    -55 -513
    -51 -513
    -46 -514
    -42 -515
    -37 -515
    -33 -516
    -28 -516
    -23 -517
    -19 -517
    -14 -517
    -9 -517
    -5 -517
    0 -517
    5 -517
    9 -517
    14 -517
    19 -517
    23 -517
    28 -516
    33 -516
    37 -515
    42 -515
    46 -514
    51 -513
    55 -513
    60 -512
    64 -511
    69 -510
    73 -509
    78 -508
    82 -507
    87 -506
    91 -504
    95 -503
    99 -502
    104 -500
    108 -499
    112 -497
    116 -496
    120 -494
    124 -492
    128 -490
    132 -488
    136 -487
    140 -485
    143 -483
    147 -480
    151 -478
    154 -476
    158 -474
    161 -471
    165 -469
    168 -466
    171 -464
    175 -461
    178 -459
    181 -456
    184 -453
    187 -451
    190 -448
    192 -445
    195 -442
    198 -439
    200 -436
    203 -433
    205 -429
    207 -426
    210 -423
    212 -420
    214 -416
    216 -413
    218 -409
    219 -406
    221 -402
    223 -399
    224 -395
    225 -391
    227 -387
    228 -384
    229 -380
    230 -376
    231 -372
    232 -368
    233 -364
    233 -360
    234 -356
    234 -351
    235 -347
    235 -343
    235 -339
    235 -334
    235 -330
    235 -325
    234 -321
    234 -316
    233 -312
    233 -307
    232 -303
    231 -298
    230 -293
    229 -289
    228 -284
    226 -279
    225 -274
    223 -270
    222 -265
    220 -260
    218 -255
    216 -250
    214 -245
    212 -240
    209 -235
    207 -230
    204 -224
    202 -219
    199 -214
    196 -209
    193 -204
    189 -198
    186 -193
    183 -188
    179 -182
    176 -177
    172 -172
    168 -166
    164 -161
    160 -155
    155 -150
    151 -144
    146 -139
    142 -133
    137 -128
    132 -122
    127 -117
    122 -111
    117 -105
    111 -100
    106 -94
    100 -88
    95 -83
    89 -77
    83 -71
    77 -66
    71 -60
    64 -54
    58 -48
    51 -42
    45 -37
    38 -31
    31 -25
    24 -19
    17 -13
    9 -7
    2 -1
    -6 4
    -13 10
    -21 16
    -29 22
    -37 28
    -45 34
    -53 40
    -62 46
    -70 52
    -79 58
    -87 64
    -96 70
    -105 76
    -114 82
    -123 88
    -133 94
    -142 100
    -152 106
    -161 112
    -171 118
    -181 124
    -191 130
    -201 136
    -211 142
    -221 148
    -232 154
    -242 160
    -253 166
    -264 172
    -274 178
    -285 184
    -296 190
    -308 196
    -319 202
    -330 208
    -342 214
    -353 220
    -365 226
    -377 232
    -389 238
    -401 245
    -413 251
    -425 257
    -438 263
    -450 269
    -463 275
    -475 281
    -488 287
    -501 293
    -514 299
    -527 305
    -540 311
    -553 317
    -567 323
    -580 329
    -594 335
    -607 341
    -621 346
    -635 352
    -649 358
    -663 364
    -677 370
    -691 376
    -706 382
    -720 388
    -735 394
    -749 400
    -764 406
    -779 412
    -794 418
    -809 423
    -824 429
    -839 435
    -854 441
    -870 447
    -885 453
    -901 459
    -916 464
    -932 470
    -948 476
    -964 482
    -980 488
    -996 493
    -1012 499
    -1028 505
    -1044 511
    -1061 516
    -1077 522
    -1094 528
    -1110 534
    -1127 539
    -1144 545
    -1161 551
    -1178 556
    -1195 562
    -1212 568
    -1229 573
    -1246 579
    -1264 585
    1258 577
    1241 571
    1224 566
    1206 560
    1189 554
    1172 549
    1155 543
    1138 537
    1121 532
    1105 526
    1088 520
    1071 515
    1055 509
    1039 503
    1022 498
    1006 492
    990 486
    974 480
    958 475
    942 469
    926 463
    910 457
    895 451
    879 446
    864 440
    848 434
    833 428
    818 422
    803 417
    788 411
    773 405
    758 399
    743 393
    729 387
    714 381
    700 376
    686 370
    671 364
    657 358
    643 352
    629 346
    615 340
    601 334
    588 328
    574 322
    561 316
    547 310
    534 304
    521 298
    508 293
    495 287
    482 281
    469 275
    457 269
    444 263
    432 257
    419 251
    407 245
    395 239
    383 233
    371 227
    359 221
    347 215
    336 209
    324 203
    313 197
    302 191
    290 185
    279 179
    268 173
    258 167
    247 161
    236 155
    226 149
    215 143
    205 137
    195 131
    185 125
    175 119
    165 113
    155 107
    146 101
    136 95
    127 89
    117 83
    108 77
    99 71
    90 65
    81 59
    73 53
    64 47
    56 41
    47 35
    39 29
    31 23
    23 17
    15 12
    7 6
    -0 -0
    -8 -6
    -15 -12
    -22 -18
    -30 -24
    -37 -29
    -44 -35
    -50 -41
    -57 -47
    -64 -53
    -70 -58
    -76 -64
    -83 -70
    -89 -76
    -95 -81
    -100 -87
    -106 -93
    -112 -98
    -117 -104
    -122 -110
    -128 -115
    -133 -121
    -138 -126
    -143 -132
    -147 -137
    -152 -143
    -156 -148
    -161 -154
    -165 -159
    -169 -165
    -173 -170
    -177 -176
    -181 -181
    -185 -186
    -188 -192
    -191 -197
    -195 -202
    -198 -207
    -201 -213
    -204 -218
    -207 -223
    -209 -228
    -212 -233
    -214 -238
    -217 -243
    -219 -248
    -221 -253
    -223 -258
    -225 -263
    -227 -268
    -228 -273
    -230 -278
    -231 -283
    -232 -287
    -234 -292
    -235 -297
    -236 -301
    -236 -306
    -237 -311
    -238 -315
    -238 -320
    -239 -324
    -239 -329
    -239 -333
    -239 -337
    -239 -342
    -239 -346
    -239 -350
    -238 -354
    -238 -359
    -237 -363
    -237 -367
    -236 -371
    -235 -375
    -234 -379
    -233 -383
    -232 -386
    -231 -390
    -229 -394
    -228 -398
    -226 -401
    -225 -405
    -223 -409
    -221 -412
    -219 -416
    -217 -419
    -215 -422
    -213 -426
    -211 -429
    -208 -432
    -206 -435
    -203 -438
    -201 -442
    -198 -445
    -195 -447
    -192 -450
    -190 -453
    -187 -456
    -183 -459
    -180 -461
    -177 -464
    -174 -467
    -171 -469
    -167 -472
    -164 -474
    -160 -476
    -157 -479
    -153 -481
    -149 -483
    -146 -485
    -142 -487
    -138 -489
    -134 -491
    -130 -493
    -126 -495
    -122 -496
    -118 -498
    -114 -500
    -109 -501
    -105 -503
    -101 -504
    -97 -506
    -92 -507
    -88 -508
    -83 -509
    -79 -511
    -74 -512
    -70 -513
    -65 -514
    -61 -514
    -56 -515
    -52 -516
    -47 -517
    -42 -517
    -38 -518
    -33 -518
    -28 -519
    -24 -519
    -19 -519
    -14 -520
    -9 -520
    -5 -520
    0 -520
    5 -520
    9 -520
    14 -520
    19 -519
    24 -519
    28 -519
    33 -518
    38 -518
    42 -517
    47 -517
    52 -516
    56 -515
    61 -514
    65 -514
    70 -513
    74 -512
    79 -511
    83 -509
    88 -508
    92 -507
    97 -506
    101 -504
    105 -503
    109 -501
    114 -500
    118 -498
    122 -496
    126 -495
    130 -493
    134 -491
    138 -489
    142 -487
    146 -485
    149 -483
    153 -481
    157 -479
    160 -476
    164 -474
    167 -472
    171 -469
    174 -467
    177 -464
    180 -461
    183 -459
    187 -456
    190 -453
    192 -450
    195 -447
    198 -445
    201 -442
    203 -438
    206 -435
    208 -432
    211 -429
    213 -426
    215 -422
    217 -419
    219 -416
    221 -412
    223 -409
    225 -405
    226 -401
    228 -398
    229 -394
    231 -390
    232 -386
    233 -383
    234 -379
    235 -375
    236 -371
    237 -367
    237 -363
    238 -359
    238 -354
    239 -350
    239 -346
    239 -342
    239 -337
    239 -333
    239 -329
    239 -324
    238 -320
    238 -315
    237 -311
    236 -306
    236 -301
    235 -297
    234 -292
    232 -287
    231 -283
    230 -278
    228 -273
    227 -268
    225 -263
    223 -258
    221 -253
    219 -248
    217 -243
    214 -238
    212 -233
    209 -228
    207 -223
    204 -218
    201 -213
    198 -207
    195 -202
    191 -197
    188 -192
    185 -186
    181 -181
    177 -176
    173 -170
    169 -165
    165 -159
    161 -154
    156 -148
    152 -143
    147 -137
    143 -132
    138 -126
    133 -121
    128 -115
    122 -110
    117 -104
    112 -98
    106 -93
    100 -87
    95 -81
    89 -76
    83 -70
    76 -64
    70 -58
    64 -53
    57 -47
    50 -41
    44 -35
    37 -29
    30 -24
    22 -18
    15 -12
    8 -6
    0 -0
    -7 6
    -15 12
    -23 17
    -31 23
    -39 29
    -47 35
    -56 41
    -64 47
    -73 53
    -81 59
    -90 65
    -99 71
    -108 77
    -117 83
    -127 89
    -136 95
    -146 101
    -155 107
    -165 113
    -175 119
    -185 125
    -195 131
    -205 137
    -215 143
    -226 149
    -236 155
    -247 161
    -258 167
    -268 173
    -279 179
    -290 185
    -302 191
    -313 197
    -324 203
    -336 209
    -347 215
    -359 221
    -371 227
    -383 233
    -395 239
    -407 245
    -419 251
    -432 257
    -444 263
    -457 269
    -469 275
    -482 281
    -495 287
    -508 293
    -521 298
    -534 304
    -547 310
    -561 316
    -574 322
    -588 328
    -601 334
    -615 340
    -629 346
    -643 352
    -657 358
    -671 364
    -686 370
    -700 376
    -714 381
    -729 387
    -743 393
    -758 399
    -773 405
    -788 411
    -803 417
    -818 422
    -833 428
    -848 434
    -864 440
    -879 446
    -895 451
    -910 457
    -926 463
    -942 469
    -958 475
    -974 480
    -990 486
    -1006 492
    -1022 498
    -1039 503
    -1055 509
    -1071 515
    -1088 520
    -1105 526
    -1121 532
    -1138 537
    -1155 543
    -1172 549
    -1189 554
    -1206 560
    -1224 566
    -1241 571
    -1258 577
    1253 569
    1235 563
    1218 558
    1201 552
    1184 547
    1166 541
    1149 535
    1133 530
    1116 524
    1099 519
    1082 513
    1066 507
    1049 502
    1033 496
    1017 490
    1000 485
    984 479
    968 473
    952 467
    936 462
    920 456
    905 450
    889 444
    873 439
    858 433
    843 427
    827 421
    812 416
    797 410
    782 404
    767 398
    752 392
    738 387
    723 381
    708 375
    694 369
    680 363
    665 357
    651 351
    637 346
    623 340
    609 334
    596 328
    582 322
    568 316
    555 310
    541 304
    528 298
    515 292
    502 286
    489 281
    476 275
    463 269
    451 263
    438 257
    426 251
    413 245
    401 239
    389 233
    377 227
    365 221
    353 215
    341 209
    330 203
    318 197
    307 191
    296 185
    284 179
    273 173
    262 167
    252 161
    241 155
    230 149
    220 143
    209 137
    199 131
    189 125
    179 120
    169 114
    159 108
    149 102
    140 96
    130 90
    121 84
    111 78
    102 72
    93 66
    84 60
    76 54
    67 48
    58 42
    50 36
    41 31
    33 25
    25 19
    17 13
    9 7
    2 1
    -6 -5
    -14 -11
    -21 -16
    -28 -22
    -35 -28
    -42 -34
    -49 -40
    -56 -45
    -63 -51
    -69 -57
    -76 -63
    -82 -68
    -88 -74
    -94 -80
    -100 -85
    -106 -91
    -112 -97
    -117 -102
    -123 -108
    -128 -113
    -133 -119
    -138 -125
    -143 -130
    -148 -136
    -153 -141
    -157 -147
    -162 -152
    -166 -158
    -171 -163
    -175 -168
    -179 -174
    -182 -179
    -186 -185
    -190 -190
    -193 -195
    -197 -200
    -200 -206
    -203 -211
    -206 -216
    -209 -221
    -212 -226
    -214 -231
    -217 -237
    -219 -242
    -222 -247
    -224 -252
    -226 -257
    -228 -262
    -230 -266
    -231 -271
    -233 -276
    -235 -281
    -236 -286
    -237 -290
    -238 -295
    -239 -300
    -240 -305
    -241 -309
    -242 -314
    -242 -318
    -243 -323
    -243 -327
    -243 -332
    -244 -336
    -244 -340
    -243 -345
    -243 -349
    -243 -353
    -243 -357
    -242 -361
    -241 -366
    -241 -370
    -240 -374
    -239 -378
    -238 -382
    -237 -385
    -236 -389
    -234 -393
    -233 -397
    -231 -400
    -230 -404
    -228 -408
    -226 -411
    -225 -415
    -223 -418
    -220 -422
    -218 -425
    -216 -428
    -214 -432
    -211 -435
    -209 -438
    -206 -441
    -204 -444
    -201 -447
    -198 -450
    -195 -453
    -192 -456
    -189 -459
    -186 -461
    -183 -464
    -180 -467
    -176 -469
    -173 -472
    -170 -474
    -166 -476
    -163 -479
    -159 -481
    -155 -483
    -151 -485
    -148 -488
    -144 -490
    -140 -492
    -136 -493
    -132 -495
    -128 -497
    -124 -499
    -119 -501
    -115 -502
    -111 -504
    -107 -505
    -102 -507
    -98 -508
    -93 -509
    -89 -511
    -85 -512
    -80 -513
    -75 -514
    -71 -515
    -66 -516
    -62 -517
    -57 -518
    -52 -518
    -48 -519
    -43 -520
    -38 -520
    -33 -521
    -29 -521
    -24 -521
    -19 -522
    -14 -522
    -10 -522
    -5 -522
    0 -522
    5 -522
    10 -522
    14 -522
    19 -522
    24 -521
    29 -521
    33 -521
    38 -520
    43 -520
    48 -519
    52 -518
    57 -518
    62 -517
    66 -516
    71 -515
    75 -514
    80 -513
    85 -512
    89 -511
    93 -509
    98 -508
    102 -507
    107 -505
    111 -504
    115 -502
    119 -501
    124 -499
    128 -497
    132 -495
    136 -493
    140 -492
    144 -490
    148 -488
    151 -485
    155 -483
    159 -481
    163 -479
    166 -476
    170 -474
    173 -472
    176 -469
    180 -467
    183 -464
    186 -461
    189 -459
    192 -456
    195 -453
    198 -450
    201 -447
    204 -444
    206 -441
    209 -438
    211 -435
    214 -432
    216 -428
    218 -425
    220 -422
    223 -418
    225 -415
    226 -411
    228 -408
    230 -404
    231 -400
    233 -397
    234 -393
    236 -389
    237 -385
    238 -382
    239 -378
    240 -374
    241 -370
    241 -366
    242 -361
    243 -357
    243 -353
    243 -349
    243 -345
    244 -340
    244 -336
    243 -332
    243 -327
    243 -323
    242 -318
    242 -314
    241 -309
    240 -305
    239 -300
    238 -295
    237 -290
    236 -286
    235 -281
    233 -276
    231 -271
    230 -266
    228 -262
    226 -257
    224 -252
    222 -247
    219 -242
    217 -237
    214 -231
    212 -226
    209 -221
    206 -216
    203 -211
    200 -206
    197 -200
    193 -195
    190 -190
    186 -185
    182 -179
    179 -174
    175 -168
    171 -163
    166 -158
    162 -152
    157 -147
    153 -141
    148 -136
    143 -130
    138 -125
    133 -119
    128 -113
    123 -108
    117 -102
    112 -97
    106 -91
    100 -85
    94 -80
    88 -74
    82 -68
    76 -63
    69 -57
    63 -51
    56 -45
    49 -40
    42 -34
    35 -28
    28 -22
    21 -16
    14 -11
    6 -5
    -2 1
    -9 7
    -17 13
    -25 19
    -33 25
    -41 31
    -50 36
    -58 42
    -67 48
    -76 54
    -84 60
    -93 66
    -102 72
    -111 78
    -121 84
    -130 90
    -140 96
    -149 102
    -159 108
    -169 114
    -179 120
    -189 125
    -199 131
    -209 137
    -220 143
    -230 149
    -241 155
    -252 161
    -262 167
    -273 173
    -284 179
    -296 185
    -307 191
    -318 197
    -330 203
    -341 209
    -353 215
    -365 221
    -377 227
    -389 233
    -401 239
    -413 245
    -426 251
    -438 257
    -451 263
    -463 269
    -476 275
    -489 281
    -502 286
    -515 292
    -528 298
    -541 304
    -555 310
    -568 316
    -582 322
    -596 328
    -609 334
    -623 340
    -637 346
    -651 351
    -665 357
    -680 363
    -694 369
    -708 375
    -723 381
    -738 387
    -752 392
    -767 398
    -782 404
    -797 410
    -812 416
    -827 421
    -843 427
    -858 433
    -873 439
    -889 444
    -905 450
    -920 456
    -936 462
    -952 467
    -968 473
    -984 479
    -1000 485
    -1017 490
    -1033 496
    -1049 502
    -1066 507
    -1082 513
    -1099 519
    -1116 524
    -1133 530
    -1149 535
    -1166 541
    -1184 547
    -1201 552
    -1218 558
    -1235 563
    -1253 569
    1247 561
    1230 556
    1212 550
    1195 545
    1178 539
    1161 534
    1144 528
    1127 522
    1110 517
    1093 511
    1077 506
    1060 500
    1044 494
    1027 489
    1011 483
    995 477
    978 472
    962 466
    946 460
    930 455
    915 449
    899 443
    883 438
    868 432
    852 426
    837 420
    822 415
    806 409
    791 403
    776 397
    761 392
    747 386
    732 380
    717 374
    703 368
    688 363
    674 357
    660 351
    645 345
    631 339
    617 333
    603 328
    590 322
    576 316
    562 310
    549 304
    536 298
    522 292
    509 286
    496 280
    483 275
    470 269
    457 263
    445 257
    432 251
    420 245
    407 239
    395 233
    383 227
    371 221
    359 215
    347 209
    335 204
    324 198
    312 192
    301 186
    290 180
    278 174
    267 168
    256 162
    246 156
    235 150
    224 144
    214 138
    203 132
    193 126
    183 120
    173 114
    163 109
    153 103
    143 97
    134 91
    124 85
    115 79
    106 73
    96 67
    87 61
    78 55
    70 49
    61 44
    52 38
    44 32
    36 26
    27 20
    19 14
    11 8
    3 3
    -4 -3
    -12 -9
    -19 -15
    -27 -21
    -34 -26
    -41 -32
    -48 -38
    -55 -44
    -62 -49
    -69 -55
    -75 -61
    -81 -67
    -88 -72
    -94 -78
    -100 -84
    -106 -89
    -112 -95
    -117 -101
    -123 -106
    -128 -112
    -134 -117
    -139 -123
    -144 -128
    -149 -134
    -154 -139
    -158 -145
    -163 -150
    -167 -156
    -172 -161
    -176 -167
    -180 -172
    -184 -177
    -188 -183
    -192 -188
    -195 -193
    -199 -199
    -202 -204
    -205 -209
    -208 -214
    -211 -219
    -214 -225
    -217 -230
    -220 -235
    -222 -240
    -224 -245
    -227 -250
    -229 -255
    -231 -260
    -233 -265
    -235 -270
    -236 -274
    -238 -279
    -239 -284
    -241 -289
    -242 -294
    -243 -298
    -244 -303
    -245 -308
    -246 -312
    -246 -317
    -247 -321
    -247 -326
    -248 -330
    -248 -334
    -248 -339
    -248 -343
    -248 -347
    -248 -352
    -247 -356
    -247 -360
    -246 -364
    -246 -368
    -245 -372
    -244 -376
    -243 -380
    -242 -384
    -241 -388
    -239 -392
    -238 -396
    -237 -399
    -235 -403
    -233 -407
    -232 -410
    -230 -414
    -228 -417
    -226 -421
    -224 -424
    -222 -428
    -219 -431
    -217 -434
    -215 -437
    -212 -440
    -209 -444
    -207 -447
    -204 -450
    -201 -452
    -198 -455
    -195 -458
    -192 -461
    -189 -464
    -186 -466
    -182 -469
    -179 -471
    -176 -474
    -172 -476
    -168 -479
    -165 -481
    -161 -483
    -157 -486
    -154 -488
    -150 -490
    -146 -492
    -142 -494
    -138 -496
    -134 -498
    -129 -499
    -125 -501
    -121 -503
    -117 -504
    -112 -506
    -108 -507
    -104 -509
    -99 -510
    -95 -512
    -90 -513
    -86 -514
    -81 -515
    -76 -516
    -72 -517
    -67 -518
    -62 -519
    -58 -520
    -53 -520
    -48 -521
    -43 -522
    -39 -522
    -34 -523
    -29 -523
    -24 -523
    -19 -524
    -15 -524
    -10 -524
    -5 -524
    0 -524
    5 -524
    10 -524
    15 -524
    19 -524
    24 -523
    29 -523
    34 -523
    39 -522
    43 -522
    48 -521
    53 -520
    58 -520
    62 -519
    67 -518
    72 -517
    76 -516
    81 -515
    86 -514
    90 -513
    95 -512
    99 -510
    104 -509
    108 -507
    112 -506
    117 -504
    121 -503
    125 -501
    129 -499
    134 -498
    138 -496
    142 -494
    146 -492
    150 -490
    154 -488
    157 -486
    161 -483
    165 -481
    168 -479
    172 -476
    176 -474
    179 -471
    182 -469
    186 -466
    189 -464
    192 -461
    195 -458
    198 -455
    201 -452
    204 -450
    207 -447
    209 -444
    212 -440
    215 -437
    217 -434
    219 -431
    222 -428
    224 -424
    226 -421
    228 -417
    230 -414
    232 -410
    233 -407
    235 -403
    237 -399
    238 -396
    239 -392
    241 -388
    242 -384
    243 -380
    244 -376
    245 -372
    246 -368
    246 -364
    247 -360
    247 -356
    248 -352
    248 -347
    248 -343
    248 -339
    248 -334
    248 -330
    247 -326
    247 -321
    246 -317
    246 -312
    245 -308
    244 -303
    243 -298
    242 -294
    241 -289
    239 -284
    238 -279
    236 -274
    235 -270
    233 -265
    231 -260
    229 -255
    227 -250
    224 -245
    222 -240
    220 -235
    217 -230
    214 -225
    211 -219
    208 -214
    205 -209
    202 -204
    199 -199
    195 -193
    192 -188
    188 -183
    184 -177
    180 -172
    176 -167
    172 -161
    167 -156
    163 -150
    158 -145
    154 -139
    149 -134
    144 -128
    139 -123
    134 -117
    128 -112
    123 -106
    117 -101
    112 -95
    106 -89
    100 -84
    94 -78
    88 -72
    81 -67
    75 -61
    69 -55
    62 -49
    55 -44
    48 -38
    41 -32
    34 -26
    27 -21
    19 -15
    12 -9
    4 -3
    -3 3
    -11 8
    -19 14
    -27 20
    -36 26
    -44 32
    -52 38
    -61 44
    -70 49
    -78 55
    -87 61
    -96 67
    -106 73
    -115 79
    -124 85
    -134 91
    -143 97
    -153 103
    -163 109
    -173 114
    -183 120
    -193 126
    -203 132
    -214 138
    -224 144
    -235 150
    -246 156
    -256 162
    -267 168
    -278 174
    -290 180
    -301 186
    -312 192
    -324 198
    -335 204
    -347 209
    -359 215
    -371 221
    -383 227
    -395 233
    -407 239
    -420 245
    -432 251
    -445 257
    -457 263
    -470 269
    -483 275
    -496 280
    -509 286
    -522 292
    -536 298
    -549 304
    -562 310
    -576 316
    -590 322
    -603 328
    -617 333
    -631 339
    -645 345
    -660 351
    -674 357
    -688 363
    -703 368
    -717 374
    -732 380
    -747 386
    -761 392
    -776 397
    -791 403
    -806 409
    -822 415
    -837 420
    -852 426
    -868 432
    -883 438
    -899 443
    -915 449
    -930 455
    -946 460
    -962 466
    -978 472
    -995 477
    -1011 483
    -1027 489
    -1044 494
    -1060 500
    -1077 506
    -1093 511
    -1110 517
    -1127 522
    -1144 528
    -1161 534
    -1178 539
    -1195 545
    -1212 550
    -1230 556
    -1247 561
    1242 554
    1224 548
    1207 543
    1190 537
    1172 532
    1155 526
    1138 521
    1121 515
    1105 509
    1088 504
    1071 498
    1055 493
    1038 487
    1022 482
    1005 476
    989 470
    973 465
    957 459
    941 453
    925 448
    909 442
    893 436
    878 431
    862 425
    847 419
    831 414
    816 408
    801 402
    786 396
    771 391
    756 385
    741 379
    726 373
    711 368
    697 362
    682 356
    668 350
    654 345
    640 339
    625 333
    612 327
    598 321
    584 316
    570 310
    557 304
    543 298
    530 292
    516 286
    503 280
    490 275
    477 269
    464 263
    452 257
    439 251
    426 245
    414 239
    401 233
    389 228
    377 222
    365 216
    353 210
    341 204
    330 198
    318 192
    306 186
    295 180
    284 174
    273 169
    261 163
    251 157
    240 151
    229 145
    218 139
    208 133
    197 127
    187 121
    177 115
    167 110
    157 104
    147 98
    137 92
    128 86
    118 80
    109 74
    100 68
    90 62
    81 57
    73 51
    64 45
    55 39
    46 33
    38 27
    30 21
    22 16
    13 10
    5 4
    -2 -2
    -10 -8
    -18 -13
    -25 -19
    -33 -25
    -40 -31
    -47 -36
    -54 -42
    -61 -48
    -68 -54
    -74 -59
    -81 -65
    -87 -71
    -93 -76
    -100 -82
    -106 -88
    -111 -93
    -117 -99
    -123 -104
    -128 -110
    -134 -116
    -139 -121
    -144 -127
    -149 -132
    -154 -138
    -159 -143
    -164 -149
    -168 -154
    -173 -159
    -177 -165
    -181 -170
    -185 -176
    -189 -181
    -193 -186
    -197 -191
    -200 -197
    -204 -202
    -207 -207
    -210 -212
    -213 -218
    -216 -223
    -219 -228
    -222 -233
    -225 -238
    -227 -243
    -229 -248
    -232 -253
    -234 -258
    -236 -263
    -238 -268
    -240 -273
    -241 -277
    -243 -282
    -244 -287
    -245 -292
    -247 -296
    -248 -301
    -249 -306
    -249 -310
    -250 -315
    -251 -319
    -251 -324
    -252 -328
    -252 -333
    -252 -337
    -252 -342
    -252 -346
    -252 -350
    -252 -354
    -251 -359
    -251 -363
    -250 -367
    -250 -371
    -249 -375
    -248 -379
    -247 -383
    -246 -387
    -245 -391
    -243 -394
    -242 -398
    -240 -402
    -239 -406
    -237 -409
    -235 -413
    -233 -416
    -231 -420
    -229 -423
    -227 -427
    -225 -430
    -223 -433
    -220 -436
    -218 -440
    -215 -443
    -212 -446
    -210 -449
    -207 -452
    -204 -455
    -201 -458
    -198 -460
    -195 -463
    -192 -466
    -188 -469
    -185 -471
    -182 -474
    -178 -476
    -174 -479
    -171 -481
    -167 -483
    -163 -486
    -160 -488
    -156 -490
    -152 -492
    -148 -494
    -144 -496
    -140 -498
    -135 -500
    -131 -501
    -127 -503
    -123 -505
    -118 -506
    -114 -508
    -110 -509
    -105 -511
    -101 -512
    -96 -514
    -91 -515
    -87 -516
    -82 -517
    -77 -518
    -73 -519
    -68 -520
    -63 -521
    -59 -522
    -54 -522
    -49 -523
    -44 -524
    -39 -524
    -34 -525
    -29 -525
    -25 -525
    -20 -526
    -15 -526
    -10 -526
    -5 -526
    0 -526
    5 -526
    10 -526
    15 -526
    20 -526
    25 -525
    29 -525
    34 -525
    39 -524
    44 -524
    49 -523
    54 -522
    59 -522
    63 -521
    68 -520
    73 -519
    77 -518
    82 -517
    87 -516
    91 -515
    96 -514
    101 -512
    105 -511
    110 -509
    114 -508
    118 -506
    123 -505
    127 -503
    131 -501
    135 -500
    140 -498
    144 -496
    148 -494
    152 -492
    156 -490
    160 -488
    163 -486
    167 -483
    171 -481
    174 -479
    178 -476
    182 -474
    185 -471
    188 -469
    192 -466
    195 -463
    198 -460
    201 -458
    204 -455
    207 -452
    210 -449
    212 -446
    215 -443
    218 -440
    220 -436
    223 -433
    225 -430
    227 -427
    229 -423
    231 -420
    233 -416
    235 -413
    237 -409
    239 -406
    240 -402
    242 -398
    243 -394
    245 -391
    246 -387
    247 -383
    248 -379
    249 -375
    250 -371
    250 -367
    251 -363
    251 -359
    252 -354
    252 -350
    252 -346
    252 -342
    252 -337
    252 -333
    252 -328
    251 -324
    251 -319
    250 -315
    249 -310
    249 -306
    248 -301
    247 -296
    245 -292
    244 -287
    243 -282
    241 -277
    240 -273
    238 -268
    236 -263
    234 -258
    232 -253
    229 -248
    227 -243
    225 -238
    222 -233
    219 -228
    216 -223
    213 -218
    210 -212
    207 -207
    204 -202
    200 -197
    197 -191
    193 -186
    189 -181
    185 -176
    181 -170
    177 -165
    173 -159
    168 -154
    164 -149
    159 -143
    154 -138
    149 -132
    144 -127
    139 -121
    134 -116
    128 -110
    123 -104
    117 -99
    111 -93
    106 -88
    100 -82
    93 -76
    87 -71
    81 -65
    74 -59
    68 -54
    61 -48
    54 -42
    47 -36
    40 -31
    33 -25
    25 -19
    18 -13
    10 -8
    2 -2
    -5 4
    -13 10
    -22 16
    -30 21
    -38 27
    -46 33
    -55 39
    -64 45
    -73 51
    -81 57
    -90 62
    -100 68
    -109 74
    -118 80
    -128 86
    -137 92
    -147 98
    -157 104
    -167 110
    -177 115
    -187 121
    -197 127
    -208 133
    -218 139
    -229 145
    -240 151
    -251 157
    -261 163
    -273 169
    -284 174
    -295 180
    -306 186
    -318 192
    -330 198
    -341 204
    -353 210
    -365 216
    -377 222
    -389 228
    -401 233
    -414 239
    -426 245
    -439 251
    -452 257
    -464 263
    -477 269
    -490 275
    -503 280
    -516 286
    -530 292
    -543 298
    -557 304
    -570 310
    -584 316
    -598 321
    -612 327
    -625 333
    -640 339
    -654 345
    -668 350
    -682 356
    -697 362
    -711 368
    -726 373
    -741 379
    -756 385
    -771 391
    -786 396
    -801 402
    -816 408
    -831 414
    -847 419
    -862 425
    -878 431
    -893 436
    -909 442
    -925 448
    -941 453
    -957 459
    -973 465
    -989 470
    -1005 476
    -1022 482
    -1038 487
    -1055 493
    -1071 498
    -1088 504
    -1105 509
    -1121 515
    -1138 521
    -1155 526
    -1172 532
    -1190 537
    -1207 543
    -1224 548
    -1242 554
    1236 546
    1219 541
    1201 535
    1184 530
    1167 524
    1150 519
    1133 513
    1116 508
    1099 502
    1082 497
    1066 491
    1049 486
    1032 480
    1016 474
    1000 469
    983 463
    967 458
    951 452
    935 446
    919 441
    903 435
    888 430
    872 424
    856 418
    841 413
    825 407
    810 401
    795 396
    780 390
    765 384
    750 378
    735 373
    720 367
    706 361
    691 356
    677 350
    662 344
    648 338
    634 333
    620 327
    606 321
    592 315
    578 309
    564 304
    551 298
    537 292
    524 286
    511 280
    497 275
    484 269
    471 263
    458 257
    446 251
    433 245
    420 240
    408 234
    396 228
    383 222
    371 216
    359 210
    347 204
    335 199
    324 193
    312 187
    301 181
    289 175
    278 169
    267 163
    256 158
    245 152
    234 146
    223 140
    212 134
    202 128
    192 122
    181 116
    171 111
    161 105
    151 99
    141 93
    131 87
    122 81
    112 75
    103 70
    94 64
    85 58
    76 52
    67 46
    58 40
    49 35
    41 29
    32 23
    24 17
    16 11
    8 6
    -0 -0
    -8 -6
    -16 -12
    -23 -18
    -31 -23
    -38 -29
    -46 -35
    -53 -40
    -60 -46
    -67 -52
    -73 -58
    -80 -63
    -86 -69
    -93 -75
    -99 -80
    -105 -86
    -111 -91
    -117 -97
    -123 -103
    -129 -108
    -134 -114
    -139 -119
    -145 -125
    -150 -130
    -155 -136
    -160 -141
    -165 -147
    -169 -152
    -174 -157
    -178 -163
    -182 -168
    -187 -174
    -191 -179
    -195 -184
    -198 -189
    -202 -195
    -206 -200
    -209 -205
    -212 -210
    -216 -216
    -219 -221
    -222 -226
    -224 -231
    -227 -236
    -230 -241
    -232 -246
    -234 -251
    -237 -256
    -239 -261
    -241 -266
    -243 -271
    -244 -276
    -246 -280
    -247 -285
    -249 -290
    -250 -295
    -251 -299
    -252 -304
    -253 -309
    -254 -313
    -255 -318
    -255 -322
    -256 -327
    -256 -331
    -256 -336
    -257 -340
    -257 -344
    -256 -348
    -256 -353
    -256 -357
    -256 -361
    -255 -365
    -254 -369
    -254 -373
    -253 -377
    -252 -381
    -251 -385
    -250 -389
    -248 -393
    -247 -397
    -246 -401
    -244 -404
    -242 -408
    -241 -411
    -239 -415
    -237 -419
    -235 -422
    -233 -425
    -231 -429
    -228 -432
    -226 -435
    -223 -439
    -221 -442
    -218 -445
    -216 -448
    -213 -451
    -210 -454
    -207 -457
    -204 -460
    -201 -463
    -198 -465
    -194 -468
    -191 -471
    -187 -473
    -184 -476
    -180 -478
    -177 -481
    -173 -483
    -169 -485
    -166 -488
    -162 -490
    -158 -492
    -154 -494
    -150 -496
    -146 -498
    -141 -500
    -137 -502
    -133 -503
    -129 -505
    -124 -507
    -120 -508
    -115 -510
    -111 -511
    -106 -513
    -102 -514
    -97 -515
    -93 -517
    -88 -518
    -83 -519
    -78 -520
    -74 -521
    -69 -522
    -64 -523
    -59 -524
    -54 -524
    -50 -525
    -45 -526
    -40 -526
    -35 -527
    -30 -527
    -25 -527
    -20 -528
    -15 -528
    -10 -528
    -5 -528
    0 -528
    5 -528
    10 -528
    15 -528
    20 -528
    25 -527
    30 -527
    35 -527
    40 -526
    45 -526
    50 -525
    54 -524
    59 -524
    64 -523
    69 -522
    74 -521
    78 -520
    83 -519
    88 -518
    93 -517
    97 -515
    102 -514
    106 -513
    111 -511
    115 -510
    120 -508
    124 -507
    129 -505
    133 -503
    137 -502
    141 -500
    146 -498
    150 -496
    154 -494
    158 -492
    162 -490
    166 -488
    169 -485
    173 -483
    177 -481
    180 -478
    184 -476
    187 -473
    191 -471
    194 -468
    198 -465
    201 -463
    204 -460
    207 -457
    210 -454
    213 -451
    216 -448
    218 -445
    221 -442
    223 -439
    226 -435
    228 -432
    231 -429
    233 -425
    235 -422
    237 -419
    239 -415
    241 -411
    242 -408
    244 -404
    246 -401
    247 -397
    248 -393
    250 -389
    251 -385
    252 -381
    253 -377
    254 -373
    254 -369
    255 -365
    256 -361
    256 -357
    256 -353
    256 -348
    257 -344
    257 -340
    256 -336
    256 -331
    256 -327
    255 -322
    255 -318
    254 -313
    253 -309
    252 -304
    251 -299
    250 -295
    249 -290
    247 -285
    246 -280
    244 -276
    243 -271
    241 -266
    239 -261
    237 -256
    234 -251
    232 -246
    230 -241
    227 -236
    224 -231
    222 -226
    219 -221
    216 -216
    212 -210
    209 -205
    206 -200
    202 -195
    198 -189
    195 -184
    191 -179
    187 -174
    182 -168
    178 -163
    174 -157
    169 -152
    165 -147
    160 -141
    155 -136
    150 -130
    145 -125
    139 -119
    134 -114
    129 -108
    123 -103
    117 -97
    111 -91
    105 -86
    99 -80
    93 -75
    86 -69
    80 -63
    73 -58
    67 -52
    60 -46
    53 -40
    46 -35
    38 -29
    31 -23
    23 -18
    16 -12
    8 -6
    0 -0
    -8 6
    -16 11
    -24 17
    -32 23
    -41 29
    -49 35
    -58 40
    -67 46
    -76 52
    -85 58
    -94 64
    -103 70
    -112 75
    -122 81
    -131 87
    -141 93
    -151 99
    -161 105
    -171 111
    -181 116
    -192 122
    -202 128
    -212 134
    -223 140
    -234 146
    -245 152
    -256 158
    -267 163
    -278 169
    -289 175
    -301 181
    -312 187
    -324 193
    -335 199
    -347 204
    -359 210
    -371 216
    -383 222
    -396 228
    -408 234
    -420 240
    -433 245
    -446 251
    -458 257
    -471 263
    -484 269
    -497 275
    -511 280
    -524 286
    -537 292
    -551 298
    -564 304
    -578 309
    -592 315
    -606 321
    -620 327
    -634 333
    -648 338
    -662 344
    -677 350
    -691 356
    -706 361
    -720 367
    -735 373
    -750 378
    -765 384
    -780 390
    -795 396
    -810 401
    -825 407
    -841 413
    -856 418
    -872 424
    -888 430
    -903 435
    -919 441
    -935 446
    -951 452
    -967 458
    -983 463
    -1000 469
    -1016 474
    -1032 480
    -1049 486
    -1066 491
    -1082 497
    -1099 502
    -1116 508
    -1133 513
    -1150 519
    -1167 524
    -1184 530
    -1201 535
    -1219 541
    -1236 546
    1231 538
    1213 533
    1196 528
    1179 522
    1162 517
    1144 511
    1127 506
    1110 500
    1094 495
    1077 489
    1060 484
    1043 478
    1027 473
    1010 467
    994 462
    978 456
    962 451
    945 445
    929 440
    914 434
    898 428
    882 423
    866 417
    851 412
    835 406
    820 400
    804 395
    789 389
    774 383
    759 378
    744 372
    729 366
    715 361
    700 355
    685 349
    671 344
    656 338
    642 332
    628 326
    614 321
    600 315
    586 309
    572 303
    559 298
    545 292
    531 286
    518 280
    505 275
    492 269
    479 263
    466 257
    453 251
    440 246
    427 240
    415 234
    402 228
    390 222
    378 217
    365 211
    353 205
    341 199
    330 193
    318 187
    306 182
    295 176
    283 170
    272 164
    261 158
    250 152
    239 147
    228 141
    217 135
    207 129
    196 123
    186 117
    175 112
    165 106
    155 100
    145 94
    135 88
    126 82
    116 77
    107 71
    97 65
    88 59
    79 53
    70 48
    61 42
    52 36
    43 30
    35 24
    26 19
    18 13
    10 7
    2 1
    -6 -4
    -14 -10
    -22 -16
    -29 -22
    -37 -27
    -44 -33
    -51 -39
    -58 -44
    -65 -50
    -72 -56
    -79 -61
    -86 -67
    -92 -73
    -98 -78
    -105 -84
    -111 -89
    -117 -95
    -123 -101
    -128 -106
    -134 -112
    -140 -117
    -145 -123
    -150 -128
    -155 -134
    -160 -139
    -165 -145
    -170 -150
    -175 -155
    -179 -161
    -184 -166
    -188 -171
    -192 -177
    -196 -182
    -200 -187
    -204 -193
    -207 -198
    -211 -203
    -214 -208
    -218 -213
    -221 -219
    -224 -224
    -227 -229
    -229 -234
    -232 -239
    -235 -244
    -237 -249
    -239 -254
    -242 -259
    -244 -264
    -246 -269
    -247 -274
    -249 -278
    -251 -283
    -252 -288
    -254 -293
    -255 -297
    -256 -302
    -257 -307
    -258 -311
    -259 -316
    -259 -320
    -260 -325
    -260 -329
    -261 -334
    -261 -338
    -261 -342
    -261 -347
    -261 -351
    -260 -355
    -260 -359
    -260 -364
    -259 -368
    -258 -372
    -258 -376
    -257 -380
    -256 -384
    -255 -388
    -254 -391
    -252 -395
    -251 -399
    -249 -403
    -248 -406
    -246 -410
    -244 -414
    -242 -417
    -240 -421
    -238 -424
    -236 -428
    -234 -431
    -232 -434
    -229 -437
    -227 -441
    -224 -444
    -221 -447
    -219 -450
    -216 -453
    -213 -456
    -210 -459
    -207 -462
    -203 -464
    -200 -467
    -197 -470
    -194 -473
    -190 -475
    -187 -478
    -183 -480
    -179 -483
    -175 -485
    -172 -487
    -168 -489
    -164 -492
    -160 -494
    -156 -496
    -152 -498
    -148 -500
    -143 -502
    -139 -503
    -135 -505
    -130 -507
    -126 -509
    -121 -510
    -117 -512
    -112 -513
    -108 -515
    -103 -516
    -99 -517
    -94 -518
    -89 -520
    -84 -521
    -80 -522
    -75 -523
    -70 -524
    -65 -524
    -60 -525
    -55 -526
    -50 -527
    -45 -527
    -40 -528
    -35 -528
    -30 -529
    -25 -529
    -20 -529
    -15 -530
    -10 -530
    -5 -530
    0 -530
    5 -530
    10 -530
    15 -530
    20 -529
    25 -529
    30 -529
    35 -528
    40 -528
    45 -527
    50 -527
    55 -526
    60 -525
    65 -524
    70 -524
    75 -523
    80 -522
    84 -521
    89 -520
    94 -518
    99 -517
    103 -516
    108 -515
    112 -513
    117 -512
    121 -510
    126 -509
    130 -507
    135 -505
    139 -503
    143 -502
    148 -500
    152 -498
    156 -496
    160 -494
    164 -492
    168 -489
    172 -487
    175 -485
    179 -483
    183 -480
    187 -478
    190 -475
    194 -473
    197 -470
    200 -467
    203 -464
    207 -462
    210 -459
    213 -456
    216 -453
    219 -450
    221 -447
    224 -444
    227 -441
    229 -437
    232 -434
    234 -431
    236 -428
    238 -424
    240 -421
    242 -417
    244 -414
    246 -410
    248 -406
    249 -403
    251 -399
    252 -395
    254 -391
    255 -388
    256 -384
    257 -380
    258 -376
    258 -372
    259 -368
    260 -364
    260 -359
    260 -355
    261 -351
    261 -347
    261 -342
    261 -338
    261 -334
    260 -329
    260 -325
    259 -320
    259 -316
    258 -311
    257 -307
    256 -302
    255 -297
    254 -293
    252 -288
    251 -283
    249 -278
    247 -274
    246 -269
    244 -264
    242 -259
    239 -254
    237 -249
    235 -244
    232 -239
    229 -234
    227 -229
    224 -224
    221 -219
    218 -213
    214 -208
    211 -203
    207 -198
    204 -193
    200 -187
    196 -182
    192 -177
    188 -171
    184 -166
    179 -161
    175 -155
    170 -150
    165 -145
    160 -139
    155 -134
    150 -128
    145 -123
    140 -117
    134 -112
    128 -106
    123 -101
    117 -95
    111 -89
    105 -84
    98 -78
    92 -73
    86 -67
    79 -61
    72 -56
    65 -50
    58 -44
    51 -39
    44 -33
    37 -27
    29 -22
    22 -16
    14 -10
    6 -4
    -2 1
    -10 7
    -18 13
    -26 19
    -35 24
    -43 30
    -52 36
    -61 42
    -70 48
    -79 53
    -88 59
    -97 65
    -107 71
    -116 77
    -126 82
    -135 88
    -145 94
    -155 100
    -165 106
    -175 112
    -186 117
    -196 123
    -207 129
    -217 135
    -228 141
    -239 147
    -250 152
    -261 158
    -272 164
    -283 170
    -295 176
    -306 182
    -318 187
    -330 193
    -341 199
    -353 205
    -365 211
    -378 217
    -390 222
    -402 228
    -415 234
    -427 240
    -440 246
    -453 251
    -466 257
    -479 263
    -492 269
    -505 275
    -518 280
    -531 286
    -545 292
    -559 298
    -572 303
    -586 309
    -600 315
    -614 321
    -628 326
    -642 332
    -656 338
    -671 344
    -685 349
    -700 355
    -715 361
    -729 366
    -744 372
    -759 378
    -774 383
    -789 389
    -804 395
    -820 400
    -835 406
    -851 412
    -866 417
    -882 423
    -898 428
    -914 434
    -929 440
    -945 445
    -962 451
    -978 456
    -994 462
    -1010 467
    -1027 473
    -1043 478
    -1060 484
    -1077 489
    -1094 495
    -1110 500
    -1127 506
    -1144 511
    -1162 517
    -1179 522
    -1196 528
    -1213 533
    -1231 538
    1225 531
    1208 526
    1191 520
    1173 515
    1156 509
    1139 504
    1122 499
    1105 493
    1088 488
    1071 482
    1055 477
    1038 471
    1021 466
    1005 460
    989 455
    972 449
    956 444
    940 438
    924 433
    908 427
    892 422
    876 416
    861 411
    845 405
    830 399
    814 394
    799 388
    784 383
    768 377
    753 371
    739 366
    724 360
    709 354
    694 349
    680 343
    665 337
    651 332
    637 326
    622 320
    608 315
    594 309
    580 303
    567 298
    553 292
    539 286
    526 280
    512 275
    499 269
    486 263
    473 257
    460 252
    447 246
    434 240
    421 234
    409 229
    396 223
    384 217
    372 211
    360 205
    348 200
    336 194
    324 188
    312 182
    300 177
    289 171
    277 165
    266 159
    255 153
    244 147
    233 142
    222 136
    211 130
    201 124
    190 118
    180 113
    170 107
    159 101
    149 95
    139 89
    130 84
    120 78
    110 72
    101 66
    91 61
    82 55
    73 49
    64 43
    55 37
    46 32
    38 26
    29 20
    21 14
    12 9
    4 3
    -4 -3
    -12 -8
    -20 -14
    -27 -20
    -35 -26
    -42 -31
    -50 -37
    -57 -43
    -64 -48
    -71 -54
    -78 -60
    -85 -65
    -91 -71
    -98 -76
    -104 -82
    -110 -88
    -116 -93
    -122 -99
    -128 -104
    -134 -110
    -140 -115
    -145 -121
    -150 -126
    -156 -132
    -161 -137
    -166 -142
    -171 -148
    -175 -153
    -180 -159
    -185 -164
    -189 -169
    -193 -175
    -197 -180
    -201 -185
    -205 -191
    -209 -196
    -213 -201
    -216 -206
    -219 -211
    -223 -216
    -226 -222
    -229 -227
    -232 -232
    -235 -237
    -237 -242
    -240 -247
    -242 -252
    -244 -257
    -247 -262
    -249 -266
    -250 -271
    -252 -276
    -254 -281
    -256 -286
    -257 -290
    -258 -295
    -259 -300
    -261 -304
    -262 -309
    -262 -314
    -263 -318
    -264 -323
    -264 -327
    -265 -332
    -265 -336
    -265 -340
    -265 -345
    -265 -349
    -265 -353
    -265 -357
    -264 -362
    -264 -366
    -263 -370
    -262 -374
    -262 -378
    -261 -382
    -260 -386
    -259 -390
    -257 -394
    -256 -397
    -255 -401
    -253 -405
    -251 -409
    -250 -412
    -248 -416
    -246 -419
    -244 -423
    -242 -426
    -240 -430
    -237 -433
    -235 -436
    -232 -439
    -230 -443
    -227 -446
    -224 -449
    -222 -452
    -219 -455
    -216 -458
    -213 -461
    -209 -464
    -206 -466
    -203 -469
    -200 -472
    -196 -474
    -193 -477
    -189 -479
    -185 -482
    -182 -484
    -178 -487
    -174 -489
    -170 -491
    -166 -493
    -162 -495
    -158 -497
    -154 -499
    -149 -501
    -145 -503
    -141 -505
    -136 -507
    -132 -509
    -128 -510
    -123 -512
    -118 -513
    -114 -515
    -109 -516
    -105 -518
    -100 -519
    -95 -520
    -90 -521
    -85 -522
    -81 -523
    -76 -524
    -71 -525
    -66 -526
    -61 -527
    -56 -528
    -51 -528
    -46 -529
    -41 -529
    -36 -530
    -31 -530
    -26 -531
    -20 -531
    -15 -531
    -10 -531
    -5 -531
    0 -531
    5 -531
    10 -531
    15 -531
    20 -531
    26 -531
    31 -530
    36 -530
    41 -529
    46 -529
    51 -528
    56 -528
    61 -527
    66 -526
    71 -525
    76 -524
    81 -523
    85 -522
    90 -521
    95 -520
    100 -519
    105 -518
    109 -516
    114 -515
    118 -513
    123 -512
    128 -510
    132 -509
    136 -507
    141 -505
    145 -503
    149 -501
    154 -499
    158 -497
    162 -495
    166 -493
    170 -491
    174 -489
    178 -487
    182 -484
    185 -482
    189 -479
    193 -477
    196 -474
    200 -472
    203 -469
    206 -466
    209 -464
    213 -461
    216 -458
    219 -455
    222 -452
    224 -449
    227 -446
    230 -443
    232 -439
    235 -436
    237 -433
    240 -430
    242 -426
    244 -423
    246 -419
    248 -416
    250 -412
    251 -409
    253 -405
    255 -401
    256 -397
    257 -394
    259 -390
    260 -386
    261 -382
    262 -378
    262 -374
    263 -370
    264 -366
    264 -362
    265 -357
    265 -353
    265 -349
    265 -345
    265 -340
    265 -336
    265 -332
    264 -327
    264 -323
    263 -318
    262 -314
    262 -309
    261 -304
    259 -300
    258 -295
    257 -290
    256 -286
    254 -281
    252 -276
    250 -271
    249 -266
    247 -262
    244 -257
    242 -252
    240 -247
    237 -242
    235 -237
    232 -232
    229 -227
    226 -222
    223 -216
    219 -211
    216 -206
    213 -201
    209 -196
    205 -191
    201 -185
    197 -180
    193 -175
    189 -169
    185 -164
    180 -159
    175 -153
    171 -148
    166 -142
    161 -137
    156 -132
    150 -126
    145 -121
    140 -115
    134 -110
    128 -104
    122 -99
    116 -93
    110 -88
    104 -82
    98 -76
    91 -71
    85 -65
    78 -60
    71 -54
    64 -48
    57 -43
    50 -37
    42 -31
    35 -26
    27 -20
    20 -14
    12 -8
    4 -3
    -4 3
    -12 9
    -21 14
    -29 20
    -38 26
    -46 32
    -55 37
    -64 43
    -73 49
    -82 55
    -91 61
    -101 66
    -110 72
    -120 78
    -130 84
    -139 89
    -149 95
    -159 101
    -170 107
    -180 113
    -190 118
    -201 124
    -211 130
    -222 136
    -233 142
    -244 147
    -255 153
    -266 159
    -277 165
    -289 171
    -300 177
    -312 182
    -324 188
    -336 194
    -348 200
    -360 205
    -372 211
    -384 217
    -396 223
    -409 229
    -421 234
    -434 240
    -447 246
    -460 252
    -473 257
    -486 263
    -499 269
    -512 275
    -526 280
    -539 286
    -553 292
    -567 298
    -580 303
    -594 309
    -608 315
    -622 320
    -637 326
    -651 332
    -665 337
    -680 343
    -694 349
    -709 354
    -724 360
    -739 366
    -753 371
    -768 377
    -784 383
    -799 388
    -814 394
    -830 399
    -845 405
    -861 411
    -876 416
    -892 422
    -908 427
    -924 433
    -940 438
    -956 444
    -972 449
    -989 455
    -1005 460
    -1021 466
    -1038 471
    -1055 477
    -1071 482
    -1088 488
    -1105 493
    -1122 499
    -1139 504
    -1156 509
    -1173 515
    -1191 520
    -1208 526
    -1225 531
    1220 524
    1203 518
    1185 513
    1168 508
    1151 502
    1134 497
    1116 491
    1100 486
    1083 481
    1066 475
    1049 470
    1032 464
    1016 459
    999 453
    983 448
    967 443
    951 437
    934 432
    918 426
    902 421
    887 415
    871 410
    855 404
    840 398
    824 393
    809 387
    793 382
    778 376
    763 371
    748 365
    733 359
    718 354
    703 348
    689 343
    674 337
    660 331
    645 326
    631 320
    617 314
    603 309
    589 303
    575 297
    561 292
    547 286
    534 280
    520 275
    507 269
    493 263
    480 258
    467 252
    454 246
    441 240
    428 235
    416 229
    403 223
    391 217
    378 212
    366 206
    354 200
    342 194
    330 189
    318 183
    306 177
    295 171
    283 166
    272 160
    260 154
    249 148
    238 143
    227 137
    216 131
    206 125
    195 120
    184 114
    174 108
    164 102
    154 96
    144 91
    134 85
    124 79
    114 73
    104 68
    95 62
    86 56
    76 50
    67 45
    58 39
    49 33
    41 27
    32 22
    23 16
    15 10
    7 5
    -2 -1
    -10 -7
    -18 -12
    -25 -18
    -33 -24
    -41 -29
    -48 -35
    -55 -41
    -63 -46
    -70 -52
    -77 -58
    -83 -63
    -90 -69
    -97 -74
    -103 -80
    -110 -86
    -116 -91
    -122 -97
    -128 -102
    -134 -108
    -139 -113
    -145 -119
    -151 -124
    -156 -129
    -161 -135
    -166 -140
    -171 -146
    -176 -151
    -181 -156
    -185 -162
    -190 -167
    -194 -172
    -198 -178
    -203 -183
    -207 -188
    -210 -193
    -214 -199
    -218 -204
    -221 -209
    -225 -214
    -228 -219
    -231 -224
    -234 -229
    -237 -235
    -240 -240
    -242 -245
    -245 -249
    -247 -254
    -249 -259
    -251 -264
    -253 -269
    -255 -274
    -257 -279
    -259 -283
    -260 -288
    -262 -293
    -263 -298
    -264 -302
    -265 -307
    -266 -311
    -267 -316
    -268 -321
    -268 -325
    -269 -329
    -269 -334
    -269 -338
    -269 -343
    -269 -347
    -269 -351
    -269 -355
    -269 -360
    -268 -364
    -268 -368
    -267 -372
    -266 -376
    -266 -380
    -265 -384
    -264 -388
    -262 -392
    -261 -396
    -260 -399
    -258 -403
    -257 -407
    -255 -410
    -253 -414
    -251 -418
    -249 -421
    -247 -425
    -245 -428
    -243 -431
    -241 -435
    -238 -438
    -236 -441
    -233 -444
    -230 -448
    -227 -451
    -225 -454
    -222 -457
    -219 -460
    -215 -462
    -212 -465
    -209 -468
    -206 -471
    -202 -473
    -199 -476
    -195 -479
    -191 -481
    -188 -483
    -184 -486
    -180 -488
    -176 -490
    -172 -493
    -168 -495
    -164 -497
    -160 -499
    -156 -501
    -151 -503
    -147 -505
    -143 -507
    -138 -508
    -134 -510
    -129 -512
    -125 -513
    -120 -515
    -115 -516
    -111 -518
    -106 -519
    -101 -520
    -96 -521
    -91 -523
    -86 -524
    -82 -525
    -77 -526
    -72 -527
    -67 -527
    -62 -528
    -56 -529
    -51 -530
    -46 -530
    -41 -531
    -36 -531
    -31 -532
    -26 -532
    -21 -532
    -16 -532
    -10 -533
    -5 -533
    0 -533
    5 -533
    10 -533
    16 -532
    21 -532
    26 -532
    31 -532
    36 -531
    41 -531
    46 -530
    51 -530
    56 -529
    62 -528
    67 -527
    72 -527
    77 -526
    82 -525
    86 -524
    91 -523
    96 -521
    101 -520
    106 -519
    111 -518
    115 -516
    120 -515
    125 -513
    129 -512
    134 -510
    138 -508
    143 -507
    147 -505
    151 -503
    156 -501
    160 -499
    164 -497
    168 -495
    172 -493
    176 -490
    180 -488
    184 -486
    188 -483
    191 -481
    195 -479
    199 -476
    202 -473
    206 -471
    209 -468
    212 -465
    215 -462
    219 -460
    222 -457
    225 -454
    227 -451
    230 -448
    233 -444
    236 -441
    238 -438
    241 -435
    243 -431
    245 -428
    247 -425
    249 -421
    251 -418
    253 -414
    255 -410
    257 -407
    258 -403
    260 -399
    261 -396
    262 -392
    264 -388
    265 -384
    266 -380
    266 -376
    267 -372
    268 -368
    268 -364
    269 -360
    269 -355
    269 -351
    269 -347
    269 -343
    269 -338
    269 -334
    269 -329
    268 -325
    268 -321
    267 -316
    266 -311
    265 -307
    264 -302
    263 -298
    262 -293
    260 -288
    259 -283
    257 -279
    255 -274
    253 -269
    251 -264
    249 -259
    247 -254
    245 -249
    242 -245
    240 -240
    237 -235
    234 -229
    231 -224
    228 -219
    225 -214
    221 -209
    218 -204
    214 -199
    210 -193
    207 -188
    203 -183
    198 -178
    194 -172
    190 -167
    185 -162
    181 -156
    176 -151
    171 -146
    166 -140
    161 -135
    156 -129
    151 -124
    145 -119
    139 -113
    134 -108
    128 -102
    122 -97
    116 -91
    110 -86
    103 -80
    97 -74
    90 -69
    83 -63
    77 -58
    70 -52
    63 -46
    55 -41
    48 -35
    41 -29
    33 -24
    25 -18
    18 -12
    10 -7
    2 -1
    -7 5
    -15 10
    -23 16
    -32 22
    -41 27
    -49 33
    -58 39
    -67 45
    -76 50
    -86 56
    -95 62
    -104 68
    -114 73
    -124 79
    -134 85
    -144 91
    -154 96
    -164 102
    -174 108
    -184 114
    -195 120
    -206 125
    -216 131
    -227 137
    -238 143
    -249 148
    -260 154
    -272 160
    -283 166
    -295 171
    -306 177
    -318 183
    -330 189
    -342 194
    -354 200
    -366 206
    -378 212
    -391 217
    -403 223
    -416 229
    -428 235
    -441 240
    -454 246
    -467 252
    -480 258
    -493 263
    -507 269
    -520 275
    -534 280
    -547 286
    -561 292
    -575 297
    -589 303
    -603 309
    -617 314
    -631 320
    -645 326
    -660 331
    -674 337
    -689 343
    -703 348
    -718 354
    -733 359
    -748 365
    -763 371
    -778 376
    -793 382
    -809 387
    -824 393
    -840 398
    -855 404
    -871 410
    -887 415
    -902 421
    -918 426
    -934 432
    -951 437
    -967 443
    -983 448
    -999 453
    -1016 459
    -1032 464
    -1049 470
    -1066 475
    -1083 481
    -1100 486
    -1116 491
    -1134 497
    -1151 502
    -1168 508
    -1185 513
    -1203 518
    -1220 524
    1215 516
    1197 511
    1180 506
    1163 500
    1145 495
    1128 490
    1111 484
    1094 479
    1077 474
    1060 468
    1044 463
    1027 457
    1010 452
    994 447
    978 441
    961 436
    945 430
    929 425
    913 419
    897 414
    881 408
    865 403
    850 398
    834 392
    818 386
    803 381
    788 375
    772 370
    757 364
    742 359
    727 353
    712 348
    698 342
    683 337
    668 331
    654 325
    640 320
    625 314
    611 309
    597 303
    583 297
    569 292
    555 286
    541 280
    528 275
    514 269
    501 263
    488 258
    474 252
    461 246
    448 241
    435 235
    423 229
    410 224
    397 218
    385 212
    372 206
    360 201
    348 195
    336 189
    324 184
    312 178
    300 172
    289 166
    277 161
    266 155
    255 149
    243 144
    232 138
    221 132
    211 126
    200 121
    189 115
    179 109
    168 103
    158 98
    148 92
    138 86
    128 81
    118 75
    108 69
    99 63
    89 58
    80 52
    71 46
    62 40
    53 35
    44 29
    35 23
    26 18
    18 12
    9 6
    1 1
    -7 -5
    -15 -11
    -23 -16
    -31 -22
    -39 -28
    -46 -33
    -54 -39
    -61 -44
    -68 -50
    -75 -56
    -82 -61
    -89 -67
    -96 -72
    -102 -78
    -109 -83
    -115 -89
    -121 -94
    -127 -100
    -133 -105
    -139 -111
    -145 -116
    -151 -122
    -156 -127
    -161 -133
    -167 -138
    -172 -143
    -177 -149
    -181 -154
    -186 -160
    -191 -165
    -195 -170
    -199 -175
    -204 -181
    -208 -186
    -212 -191
    -216 -196
    -219 -202
    -223 -207
    -226 -212
    -230 -217
    -233 -222
    -236 -227
    -239 -232
    -242 -237
    -245 -242
    -247 -247
    -250 -252
    -252 -257
    -254 -262
    -256 -267
    -258 -272
    -260 -276
    -262 -281
    -263 -286
    -265 -291
    -266 -295
    -268 -300
    -269 -305
    -270 -309
    -271 -314
    -271 -318
    -272 -323
    -273 -327
    -273 -332
    -273 -336
    -274 -340
    -274 -345
    -274 -349
    -274 -353
    -273 -357
    -273 -362
    -273 -366
    -272 -370
    -271 -374
    -270 -378
    -270 -382
    -269 -386
    -267 -390
    -266 -394
    -265 -397
    -264 -401
    -262 -405
    -260 -409
    -259 -412
    -257 -416
    -255 -419
    -253 -423
    -251 -426
    -249 -430
    -246 -433
    -244 -436
    -241 -440
    -239 -443
    -236 -446
    -233 -449
    -231 -452
    -228 -455
    -225 -458
    -221 -461
    -218 -464
    -215 -467
    -212 -469
    -208 -472
    -205 -475
    -201 -477
    -198 -480
    -194 -482
    -190 -485
    -186 -487
    -182 -490
    -178 -492
    -174 -494
    -170 -496
    -166 -498
    -162 -500
    -158 -502
    -153 -504
    -149 -506
    -144 -508
    -140 -510
    -135 -511
    -131 -513
    -126 -515
    -121 -516
    -117 -518
    -112 -519
    -107 -520
    -102 -522
    -97 -523
    -92 -524
    -87 -525
    -83 -526
    -77 -527
    -72 -528
    -67 -529
    -62 -530
    -57 -530
    -52 -531
    -47 -531
    -42 -532
    -37 -532
    -31 -533
    -26 -533
    -21 -534
    -16 -534
    -10 -534
    -5 -534
    0 -534
    5 -534
    10 -534
    16 -534
    21 -534
    26 -533
    31 -533
    37 -532
    42 -532
    47 -531
    52 -531
    57 -530
    62 -530
    67 -529
    72 -528
    77 -527
    83 -526
    87 -525
    92 -524
    97 -523
    102 -522
    107 -520
    112 -519
    117 -518
    121 -516
    126 -515
    131 -513
    135 -511
    140 -510
    144 -508
    149 -506
    153 -504
    158 -502
    162 -500
    166 -498
    170 -496
    174 -494
    178 -492
    182 -490
    186 -487
    190 -485
    194 -482
    198 -480
    201 -477
    205 -475
    208 -472
    212 -469
    215 -467
    218 -464
    221 -461
    225 -458
    228 -455
    231 -452
    233 -449
    236 -446
    239 -443
    241 -440
    244 -436
    246 -433
    249 -430
    251 -426
    253 -423
    255 -419
    257 -416
    259 -412
    260 -409
    262 -405
    264 -401
    265 -397
    266 -394
    267 -390
    269 -386
    270 -382
    270 -378
    271 -374
    272 -370
    273 -366
    273 -362
    273 -357
    274 -353
    274 -349
    274 -345
    274 -340
    273 -336
    273 -332
    273 -327
    272 -323
    271 -318
    271 -314
    270 -309
    269 -305
    268 -300
    266 -295
    265 -291
    263 -286
    262 -281
    260 -276
    258 -272
    256 -267
    254 -262
    252 -257
    250 -252
    247 -247
    245 -242
    242 -237
    239 -232
    236 -227
    233 -222
    230 -217
    226 -212
    223 -207
    219 -202
    216 -196
    212 -191
    208 -186
    204 -181
    199 -175
    195 -170
    191 -165
    186 -160
    181 -154
    177 -149
    172 -143
    167 -138
    161 -133
    156 -127
    151 -122
    145 -116
    139 -111
    133 -105
    127 -100
    121 -94
    115 -89
    109 -83
    102 -78
    96 -72
    89 -67
    82 -61
    75 -56
    68 -50
    61 -44
    54 -39
    46 -33
    39 -28
    31 -22
    23 -16
    15 -11
    7 -5
    -1 1
    -9 6
    -18 12
    -26 18
    -35 23
    -44 29
    -53 35
    -62 40
    -71 46
    -80 52
    -89 58
    -99 63
    -108 69
    -118 75
    -128 81
    -138 86
    -148 92
    -158 98
    -168 103
    -179 109
    -189 115
    -200 121
    -211 126
    -221 132
    -232 138
    -243 144
    -255 149
    -266 155
    -277 161
    -289 166
    -300 172
    -312 178
    -324 184
    -336 189
    -348 195
    -360 201
    -372 206
    -385 212
    -397 218
    -410 224
    -423 229
    -435 235
    -448 241
    -461 246
    -474 252
    -488 258
    -501 263
    -514 269
    -528 275
    -541 280
    -555 286
    -569 292
    -583 297
    -597 303
    -611 309
    -625 314
    -640 320
    -654 325
    -668 331
    -683 337
    -698 342
    -712 348
    -727 353
    -742 359
    -757 364
    -772 370
    -788 375
    -803 381
    -818 386
    -834 392
    -850 398
    -865 403
    -881 408
    -897 414
    -913 419
    -929 425
    -945 430
    -961 436
    -978 441
    -994 447
    -1010 452
    -1027 457
    -1044 463
    -1060 468
    -1077 474
    -1094 479
    -1111 484
    -1128 490
    -1145 495
    -1163 500
    -1180 506
    -1197 511
    -1215 516
    1209 509
    1192 504
    1175 498
    1157 493
    1140 488
    1123 483
    1106 477
    1089 472
    1072 467
    1055 461
    1038 456
    1022 451
    1005 445
    989 440
    972 434
    956 429
    940 424
    924 418
    907 413
    891 407
    876 402
    860 397
    844 391
    828 386
    813 380
    798 375
    782 369
    767 364
    752 358
    737 353
    722 347
    707 342
    692 336
    677 331
    663 325
    648 319
    634 314
    620 308
    605 303
    591 297
    577 292
    563 286
    550 280
    536 275
    522 269
    509 263
    495 258
    482 252
    469 247
    456 241
    443 235
    430 230
    417 224
    404 218
    392 213
    379 207
    367 201
    355 196
    342 190
    330 184
    318 179
    307 173
    295 167
    283 162
    272 156
    260 150
    249 144
    238 139
    227 133
    216 127
    205 122
    194 116
    184 110
    173 105
    163 99
    152 93
    142 88
    132 82
    122 76
    112 70
    103 65
    93 59
    84 53
    74 48
    65 42
    56 36
    47 31
    38 25
    29 19
    21 14
    12 8
    4 2
    -5 -3
    -13 -9
    -21 -14
    -29 -20
    -37 -26
    -44 -31
    -52 -37
    -59 -42
    -67 -48
    -74 -54
    -81 -59
    -88 -65
    -95 -70
    -101 -76
    -108 -81
    -114 -87
    -121 -92
    -127 -98
    -133 -103
    -139 -109
    -145 -114
    -150 -120
    -156 -125
    -161 -130
    -167 -136
    -172 -141
    -177 -147
    -182 -152
    -187 -157
    -191 -162
    -196 -168
    -200 -173
    -205 -178
    -209 -184
    -213 -189
    -217 -194
    -221 -199
    -224 -204
    -228 -209
    -231 -214
    -235 -220
    -238 -225
    -241 -230
    -244 -235
    -247 -240
    -249 -245
    -252 -250
    -255 -255
    -257 -259
    -259 -264
    -261 -269
    -263 -274
    -265 -279
    -267 -283
    -268 -288
    -270 -293
    -271 -298
    -272 -302
    -273 -307
    -274 -311
    -275 -316
    -276 -320
    -277 -325
    -277 -329
    -278 -334
    -278 -338
    -278 -342
    -278 -347
    -278 -351
    -278 -355
    -278 -359
    -277 -364
    -277 -368
    -276 -372
    -275 -376
    -274 -380
    -274 -384
    -272 -388
    -271 -392
    -270 -395
    -269 -399
    -267 -403
    -266 -407
    -264 -410
    -262 -414
    -260 -417
    -258 -421
    -256 -424
    -254 -428
    -252 -431
    -250 -435
    -247 -438
    -245 -441
    -242 -444
    -239 -447
    -236 -451
    -234 -454
    -231 -457
    -228 -460
    -224 -462
    -221 -465
    -218 -468
    -214 -471
    -211 -474
    -207 -476
    -204 -479
    -200 -481
    -196 -484
    -193 -486
    -189 -489
    -185 -491
    -181 -493
    -177 -495
    -172 -497
    -168 -500
    -164 -502
    -160 -504
    -155 -505
    -151 -507
    -146 -509
    -142 -511
    -137 -513
    -132 -514
    -128 -516
    -123 -517
    -118 -519
    -113 -520
    -108 -521
    -104 -523
    -99 -524
    -94 -525
    -89 -526
    -84 -527
    -78 -528
    -73 -529
    -68 -530
    -63 -531
    -58 -531
    -53 -532
    -47 -533
    -42 -533
    -37 -534
    -32 -534
    -26 -534
    -21 -535
    -16 -535
    -11 -535
    -5 -535
    0 -535
    5 -535
    11 -535
    16 -535
    21 -535
    26 -534
    32 -534
    37 -534
    42 -533
    47 -533
    53 -532
    58 -531
    63 -531
    68 -530
    73 -529
    78 -528
    84 -527
    89 -526
    94 -525
    99 -524
    104 -523
    108 -521
    113 -520
    118 -519
    123 -517
    128 -516
    132 -514
    137 -513
    142 -511
    146 -509
    151 -507
    155 -505
    160 -504
    164 -502
    168 -500
    172 -497
    177 -495
    181 -493
    185 -491
    189 -489
    193 -486
    196 -484
    200 -481
    204 -479
    207 -476
    211 -474
    214 -471
    218 -468
    221 -465
    224 -462
    228 -460
    231 -457
    234 -454
    236 -451
    239 -447
    242 -444
    245 -441
    247 -438
    250 -435
    252 -431
    254 -428
    256 -424
    258 -421
    260 -417
    262 -414
    264 -410
    266 -407
    267 -403
    269 -399
    270 -395
    271 -392
    272 -388
    274 -384
    274 -380
    275 -376
    276 -372
    277 -368
    277 -364
    278 -359
    278 -355
    278 -351
    278 -347
    278 -342
    278 -338
    278 -334
    277 -329
    277 -325
    276 -320
    275 -316
    274 -311
    273 -307
    272 -302
    271 -298
    270 -293
    268 -288
    267 -283
    265 -279
    263 -274
    261 -269
    259 -264
    257 -259
    255 -255
    252 -250
    249 -245
    247 -240
    244 -235
    241 -230
    238 -225
    235 -220
    231 -214
    228 -209
    224 -204
    221 -199
    217 -194
    213 -189
    209 -184
    205 -178
    200 -173
    196 -168
    191 -162
    187 -157
    182 -152
    177 -147
    172 -141
    167 -136
    161 -130
    156 -125
    150 -120
    145 -114
    139 -109
    133 -103
    127 -98
    121 -92
    114 -87
    108 -81
    101 -76
    95 -70
    88 -65
    81 -59
    74 -54
    67 -48
    59 -42
    52 -37
    44 -31
    37 -26
    29 -20
    21 -14
    13 -9
    5 -3
    -4 2
    -12 8
    -21 14
    -29 19
    -38 25
    -47 31
    -56 36
    -65 42
    -74 48
    -84 53
    -93 59
    -103 65
    -112 70
    -122 76
    -132 82
    -142 88
    -152 93
    -163 99
    -173 105
    -184 110
    -194 116
    -205 122
    -216 127
    -227 133
    -238 139
    -249 144
    -260 150
    -272 156
    -283 162
    -295 167
    -307 173
    -318 179
    -330 184
    -342 190
    -355 196
    -367 201
    -379 207
    -392 213
    -404 218
    -417 224
    -430 230
    -443 235
    -456 241
    -469 247
    -482 252
    -495 258
    -509 263
    -522 269
    -536 275
    -550 280
    -563 286
    -577 292
    -591 297
    -605 303
    -620 308
    -634 314
    -648 319
    -663 325
    -677 331
    -692 336
    -707 342
    -722 347
    -737 353
    -752 358
    -767 364
    -782 369
    -798 375
    -813 380
    -828 386
    -844 391
    -860 397
    -876 402
    -891 407
    -907 413
    -924 418
    -940 424
    -956 429
    -972 434
    -989 440
    -1005 445
    -1022 451
    -1038 456
    -1055 461
    -1072 467
    -1089 472
    -1106 477
    -1123 483
    -1140 488
    -1157 493
    -1175 498
    -1192 504
    -1209 509
    1204 502
    1187 497
    1169 491
    1152 486
    1135 481
    1118 476
    1101 470
    1084 465
    1067 460
    1050 454
    1033 449
    1016 444
    1000 438
    983 433
    967 428
    951 422
    934 417
    918 412
    902 406
    886 401
    870 396
    854 390
    839 385
    823 379
    808 374
    792 368
    777 363
    761 357
    746 352
    731 347
    716 341
    701 336
    687 330
    672 325
    657 319
    643 314
    628 308
    614 302
    600 297
    586 291
    572 286
    558 280
    544 275
    530 269
    517 264
    503 258
    490 252
    476 247
    463 241
    450 236
    437 230
    424 224
    411 219
    399 213
    386 208
    374 202
    361 196
    349 191
    337 185
    325 179
    313 174
    301 168
    289 162
    277 157
    266 151
    255 145
    243 140
    232 134
    221 128
    210 123
    199 117
    188 112
    178 106
    167 100
    157 95
    147 89
    136 83
    126 78
    116 72
    107 66
    97 61
    87 55
    78 49
    69 44
    59 38
    50 32
    41 27
    32 21
    24 15
    15 10
    6 4
    -2 -1
    -10 -7
    -18 -13
    -26 -18
    -34 -24
    -42 -29
    -50 -35
    -57 -40
    -65 -46
    -72 -52
    -79 -57
    -86 -63
    -93 -68
    -100 -74
    -107 -79
    -113 -85
    -120 -90
    -126 -96
    -132 -101
    -138 -106
    -144 -112
    -150 -117
    -156 -123
    -161 -128
    -167 -133
    -172 -139
    -177 -144
    -182 -149
    -187 -155
    -192 -160
    -197 -165
    -201 -171
    -206 -176
    -210 -181
    -214 -186
    -218 -191
    -222 -197
    -226 -202
    -230 -207
    -233 -212
    -237 -217
    -240 -222
    -243 -227
    -246 -232
    -249 -237
    -252 -242
    -254 -247
    -257 -252
    -259 -257
    -262 -262
    -264 -267
    -266 -271
    -268 -276
    -270 -281
    -271 -286
    -273 -290
    -274 -295
    -276 -300
    -277 -304
    -278 -309
    -279 -313
    -280 -318
    -280 -322
    -281 -327
    -282 -331
    -282 -336
    -282 -340
    -282 -344
    -282 -349
    -282 -353
    -282 -357
    -282 -361
    -281 -365
    -281 -369
    -280 -373
    -279 -377
    -278 -381
    -277 -385
    -276 -389
    -275 -393
    -274 -397
    -272 -401
    -271 -404
    -269 -408
    -268 -412
    -266 -415
    -264 -419
    -262 -422
    -260 -426
    -258 -429
    -255 -433
    -253 -436
    -250 -439
    -248 -443
    -245 -446
    -242 -449
    -240 -452
    -237 -455
    -234 -458
    -230 -461
    -227 -464
    -224 -467
    -221 -469
    -217 -472
    -214 -475
    -210 -477
    -206 -480
    -203 -482
    -199 -485
    -195 -487
    -191 -490
    -187 -492
    -183 -494
    -179 -496
    -175 -499
    -170 -501
    -166 -503
    -161 -505
    -157 -507
    -153 -508
    -148 -510
    -143 -512
    -139 -514
    -134 -515
    -129 -517
    -124 -518
    -120 -520
    -115 -521
    -110 -522
    -105 -524
    -100 -525
    -95 -526
    -90 -527
    -84 -528
    -79 -529
    -74 -530
    -69 -531
    -64 -532
    -59 -532
    -53 -533
    -48 -534
    -43 -534
    -37 -535
    -32 -535
    -27 -535
    -21 -536
    -16 -536
    -11 -536
    -5 -536
    0 -536
    5 -536
    11 -536
    16 -536
    21 -536
    27 -535
    32 -535
    37 -535
    43 -534
    48 -534
    53 -533
    59 -532
    64 -532
    69 -531
    74 -530
    79 -529
    84 -528
    90 -527
    95 -526
    100 -525
    105 -524
    110 -522
    115 -521
    120 -520
    124 -518
    129 -517
    134 -515
    139 -514
    143 -512
    148 -510
    153 -508
    157 -507
    161 -505
    166 -503
    170 -501
    175 -499
    179 -496
    183 -494
    187 -492
    191 -490
    195 -487
    199 -485
    203 -482
    206 -480
    210 -477
    214 -475
    217 -472
    221 -469
    224 -467
    227 -464
    230 -461
    234 -458
    237 -455
    240 -452
    242 -449
    245 -446
    248 -443
    250 -439
    253 -436
    255 -433
    258 -429
    260 -426
    262 -422
    264 -419
    266 -415
    268 -412
    269 -408
    271 -404
    272 -401
    274 -397
    275 -393
    276 -389
    277 -385
    278 -381
    279 -377
    280 -373
    281 -369
    281 -365
    282 -361
    282 -357
    282 -353
    282 -349
    282 -344
    282 -340
    282 -336
    282 -331
    281 -327
    280 -322
    280 -318
    279 -313
    278 -309
    277 -304
    276 -300
    274 -295
    273 -290
    271 -286
    270 -281
    268 -276
    266 -271
    264 -267
    262 -262
    259 -257
    257 -252
    254 -247
    252 -242
    249 -237
    246 -232
    243 -227
    240 -222
    237 -217
    233 -212
    230 -207
    226 -202
    222 -197
    218 -191
    214 -186
    210 -181
    206 -176
    201 -171
    197 -165
    192 -160
    187 -155
    182 -149
    177 -144
    172 -139
    167 -133
    161 -128
    156 -123
    150 -117
    144 -112
    138 -106
    132 -101
    126 -96
    120 -90
    113 -85
    107 -79
    100 -74
    93 -68
    86 -63
    79 -57
    72 -52
    65 -46
    57 -40
    50 -35
    42 -29
    34 -24
    26 -18
    18 -13
    10 -7
    2 -1
    -6 4
    -15 10
    -24 15
    -32 21
    -41 27
    -50 32
    -59 38
    -69 44
    -78 49
    -87 55
    -97 61
    -107 66
    -116 72
    -126 78
    -136 83
    -147 89
    -157 95
    -167 100
    -178 106
    -188 112
    -199 117
    -210 123
    -221 128
    -232 134
    -243 140
    -255 145
    -266 151
    -277 157
    -289 162
    -301 168
    -313 174
    -325 179
    -337 185
    -349 191
    -361 196
    -374 202
    -386 208
    -399 213
    -411 219
    -424 224
    -437 230
    -450 236
    -463 241
    -476 247
    -490 252
    -503 258
    -517 264
    -530 269
    -544 275
    -558 280
    -572 286
    -586 291
    -600 297
    -614 302
    -628 308
    -643 314
    -657 319
    -672 325
    -687 330
    -701 336
    -716 341
    -731 347
    -746 352
    -761 357
    -777 363
    -792 368
    -808 374
    -823 379
    -839 385
    -854 390
    -870 396
    -886 401
    -902 406
    -918 412
    -934 417
    -951 422
    -967 428
    -983 433
    -1000 438
    -1016 444
    -1033 449
    -1050 454
    -1067 460
    -1084 465
    -1101 470
    -1118 476
    -1135 481
    -1152 486
    -1169 491
    -1187 497
    -1204 502
    1199 495
    1182 489
    1164 484
    1147 479
    1130 474
    1112 469
    1095 463
    1078 458
    1061 453
    1044 448
    1028 442
    1011 437
    994 432
    978 426
    962 421
    945 416
    929 411
    913 405
    897 400
    881 395
    865 389
    849 384
    833 378
    818 373
    802 368
    787 362
    771 357
    756 351
    741 346
    726 341
    711 335
    696 330
    681 324
    666 319
    652 313
    637 308
    623 302
    609 297
    594 291
    580 286
    566 280
    552 275
    538 269
    525 264
    511 258
    498 253
    484 247
    471 241
    458 236
    444 230
    431 225
    419 219
    406 214
    393 208
    380 202
    368 197
    356 191
    343 186
    331 180
    319 174
    307 169
    295 163
    283 158
    272 152
    260 146
    249 141
    238 135
    226 130
    215 124
    204 118
    194 113
    183 107
    172 101
    162 96
    151 90
    141 85
    131 79
    121 73
    111 68
    101 62
    91 57
    82 51
    72 45
    63 40
    54 34
    45 28
    36 23
    27 17
    18 12
    9 6
    1 1
    -8 -5
    -16 -11
    -24 -16
    -32 -22
    -40 -27
    -48 -33
    -55 -38
    -63 -44
    -70 -49
    -78 -55
    -85 -60
    -92 -66
    -99 -71
    -106 -77
    -112 -82
    -119 -88
    -125 -93
    -132 -99
    -138 -104
    -144 -109
    -150 -115
    -155 -120
    -161 -126
    -167 -131
    -172 -136
    -177 -142
    -183 -147
    -188 -152
    -193 -158
    -197 -163
    -202 -168
    -206 -173
    -211 -178
    -215 -184
    -219 -189
    -223 -194
    -227 -199
    -231 -204
    -235 -209
    -238 -214
    -242 -219
    -245 -224
    -248 -229
    -251 -234
    -254 -239
    -257 -244
    -259 -249
    -262 -254
    -264 -259
    -267 -264
    -269 -269
    -271 -273
    -273 -278
    -274 -283
    -276 -288
    -278 -292
    -279 -297
    -280 -302
    -281 -306
    -282 -311
    -283 -315
    -284 -320
    -285 -324
    -285 -329
    -286 -333
    -286 -337
    -286 -342
    -287 -346
    -287 -350
    -286 -354
    -286 -359
    -286 -363
    -285 -367
    -285 -371
    -284 -375
    -283 -379
    -282 -383
    -281 -387
    -280 -391
    -279 -395
    -278 -398
    -276 -402
    -275 -406
    -273 -410
    -271 -413
    -269 -417
    -267 -420
    -265 -424
    -263 -427
    -261 -431
    -259 -434
    -256 -437
    -254 -441
    -251 -444
    -248 -447
    -245 -450
    -243 -453
    -240 -456
    -236 -459
    -233 -462
    -230 -465
    -227 -468
    -223 -470
    -220 -473
    -216 -476
    -213 -478
    -209 -481
    -205 -484
    -201 -486
    -197 -488
    -193 -491
    -189 -493
    -185 -495
    -181 -497
    -177 -500
    -172 -502
    -168 -504
    -163 -506
    -159 -507
    -154 -509
    -150 -511
    -145 -513
    -140 -514
    -136 -516
    -131 -518
    -126 -519
    -121 -521
    -116 -522
    -111 -523
    -106 -525
    -101 -526
    -96 -527
    -91 -528
    -85 -529
    -80 -530
    -75 -531
    -70 -532
    -65 -532
    -59 -533
    -54 -534
    -49 -534
    -43 -535
    -38 -535
    -32 -536
    -27 -536
    -22 -536
    -16 -537
    -11 -537
    -5 -537
    0 -537
    5 -537
    11 -537
    16 -537
    22 -536
    27 -536
    32 -536
    38 -535
    43 -535
    49 -534
    54 -534
    59 -533
    65 -532
    70 -532
    75 -531
    80 -530
    85 -529
    91 -528
    96 -527
    101 -526
    106 -525
    111 -523
    116 -522
    121 -521
    126 -519
    131 -518
    136 -516
    140 -514
    145 -513
    150 -511
    154 -509
    159 -507
    163 -506
    168 -504
    172 -502
    177 -500
    181 -497
    185 -495
    189 -493
    193 -491
    197 -488
    201 -486
    205 -484
    209 -481
    213 -478
    216 -476
    220 -473
    223 -470
    227 -468
    230 -465
    233 -462
    236 -459
    240 -456
    243 -453
    245 -450
    248 -447
    251 -444
    254 -441
    256 -437
    259 -434
    261 -431
    263 -427
    265 -424
    267 -420
    269 -417
    271 -413
    273 -410
    275 -406
    276 -402
    278 -398
    279 -395
    280 -391
    281 -387
    282 -383
    283 -379
    284 -375
    285 -371
    285 -367
    286 -363
    286 -359
    286 -354
    287 -350
    287 -346
    286 -342
    286 -337
    286 -333
    285 -329
    285 -324
    284 -320
    283 -315
    282 -311
    281 -306
    280 -302
    279 -297
    278 -292
    276 -288
    274 -283
    273 -278
    271 -273
    269 -269
    267 -264
    264 -259
    262 -254
    259 -249
    257 -244
    254 -239
    251 -234
    248 -229
    245 -224
    242 -219
    238 -214
    235 -209
    231 -204
    227 -199
    223 -194
    219 -189
    215 -184
    211 -178
    206 -173
    202 -168
    197 -163
    193 -158
    188 -152
    183 -147
    177 -142
    172 -136
    167 -131
    161 -126
    155 -120
    150 -115
    144 -109
    138 -104
    132 -99
    125 -93
    119 -88
    112 -82
    106 -77
    99 -71
    92 -66
    85 -60
    78 -55
    70 -49
    63 -44
    55 -38
    48 -33
    40 -27
    32 -22
    24 -16
    16 -11
    8 -5
    -1 1
    -9 6
    -18 12
    -27 17
    -36 23
    -45 28
    -54 34
    -63 40
    -72 45
    -82 51
    -91 57
    -101 62
    -111 68
    -121 73
    -131 79
    -141 85
    -151 90
    -162 96
    -172 101
    -183 107
    -194 113
    -204 118
    -215 124
    -226 130
    -238 135
    -249 141
    -260 146
    -272 152
    -283 158
    -295 163
    -307 169
    -319 174
    -331 180
    -343 186
    -356 191
    -368 197
    -380 202
    -393 208
    -406 214
    -419 219
    -431 225
    -444 230
    -458 236
    -471 241
    -484 247
    -498 253
    -511 258
    -525 264
    -538 269
    -552 275
    -566 280
    -580 286
    -594 291
    -609 297
    -623 302
    -637 308
    -652 313
    -666 319
    -681 324
    -696 330
    -711 335
    -726 341
    -741 346
    -756 351
    -771 357
    -787 362
    -802 368
    -818 373
    -833 378
    -849 384
    -865 389
    -881 395
    -897 400
    -913 405
    -929 411
    -945 416
    -962 421
    -978 426
    -994 432
    -1011 437
    -1028 442
    -1044 448
    -1061 453
    -1078 458
    -1095 463
    -1112 469
    -1130 474
    -1147 479
    -1164 484
    -1182 489
    -1199 495
    1194 488
    1176 482
    1159 477
    1142 472
    1124 467
    1107 462
    1090 457
    1073 451
    1056 446
    1039 441
    1022 436
    1006 430
    989 425
    973 420
    956 415
    940 409
    924 404
    907 399
    891 393
    875 388
    859 383
    844 378
    828 372
    812 367
    797 361
    781 356
    766 351
    751 345
    735 340
    720 335
    705 329
    690 324
    676 318
    661 313
    646 307
    632 302
    617 297
    603 291
    589 286
    575 280
    561 275
    547 269
    533 264
    519 258
    506 253
    492 247
    479 242
    465 236
    452 231
    439 225
    426 220
    413 214
    400 209
    387 203
    375 198
    362 192
    350 186
    338 181
    326 175
    313 170
    301 164
    290 159
    278 153
    266 147
    255 142
    243 136
    232 131
    221 125
    210 120
    199 114
    188 108
    177 103
    167 97
    156 92
    146 86
    135 80
    125 75
    115 69
    105 64
    95 58
    86 53
    76 47
    67 41
    57 36
    48 30
    39 25
    30 19
    21 14
    12 8
    4 2
    -5 -3
    -13 -9
    -21 -14
    -30 -20
    -38 -25
    -45 -31
    -53 -36
    -61 -42
    -68 -47
    -76 -53
    -83 -58
    -90 -64
    -97 -69
    -104 -75
    -111 -80
    -118 -85
    -124 -91
    -131 -96
    -137 -102
    -143 -107
    -149 -112
    -155 -118
    -161 -123
    -166 -128
    -172 -134
    -177 -139
    -183 -144
    -188 -150
    -193 -155
    -198 -160
    -203 -165
    -207 -171
    -212 -176
    -216 -181
    -220 -186
    -224 -191
    -228 -196
    -232 -202
    -236 -207
    -240 -212
    -243 -217
    -247 -222
    -250 -227
    -253 -232
    -256 -237
    -259 -242
    -262 -247
    -264 -251
    -267 -256
    -269 -261
    -271 -266
    -273 -271
    -275 -275
    -277 -280
    -279 -285
    -281 -290
    -282 -294
    -284 -299
    -285 -303
    -286 -308
    -287 -313
    -288 -317
    -289 -321
    -289 -326
    -290 -330
    -290 -335
    -291 -339
    -291 -343
    -291 -348
    -291 -352
    -291 -356
    -290 -360
    -290 -364
    -289 -368
    -289 -372
    -288 -376
    -287 -380
    -286 -384
    -285 -388
    -284 -392
    -283 -396
    -281 -400
    -280 -403
    -278 -407
    -277 -411
    -275 -414
    -273 -418
    -271 -421
    -269 -425
    -267 -428
    -264 -432
    -262 -435
    -259 -438
    -257 -442
    -254 -445
    -251 -448
    -249 -451
    -246 -454
    -243 -457
    -239 -460
    -236 -463
    -233 -466
    -230 -469
    -226 -471
    -223 -474
    -219 -477
    -215 -479
    -211 -482
    -208 -484
    -204 -487
    -200 -489
    -196 -492
    -191 -494
    -187 -496
    -183 -498
    -179 -500
    -174 -502
    -170 -504
    -165 -506
    -161 -508
    -156 -510
    -151 -512
    -147 -514
    -142 -515
    -137 -517
    -132 -518
    -127 -520
    -122 -521
    -117 -523
    -112 -524
    -107 -525
    -102 -526
    -97 -528
    -92 -529
    -86 -530
    -81 -531
    -76 -531
    -71 -532
    -65 -533
    -60 -534
    -55 -534
    -49 -535
    -44 -535
    -38 -536
    -33 -536
    -27 -537
    -22 -537
    -16 -537
    -11 -537
    -5 -537
    0 -537
    5 -537
    11 -537
    16 -537
    22 -537
    27 -537
    33 -536
    38 -536
    44 -535
    49 -535
    55 -534
    60 -534
    65 -533
    71 -532
    76 -531
    81 -531
    86 -530
    92 -529
    97 -528
    102 -526
    107 -525
    112 -524
    117 -523
    122 -521
    127 -520
    132 -518
    137 -517
    142 -515
    147 -514
    151 -512
    156 -510
    161 -508
    165 -506
    170 -504
    174 -502
    179 -500
    183 -498
    187 -496
    191 -494
    196 -492
    200 -489
    204 -487
    208 -484
    211 -482
    215 -479
    219 -477
    223 -474
    226 -471
    230 -469
    233 -466
    236 -463
    239 -460
    243 -457
    246 -454
    249 -451
    251 -448
    254 -445
    257 -442
    259 -438
    262 -435
    264 -432
    267 -428
    269 -425
    271 -421
    273 -418
    275 -414
    277 -411
    278 -407
    280 -403
    281 -400
    283 -396
    284 -392
    285 -388
    286 -384
    287 -380
    288 -376
    289 -372
    289 -368
    290 -364
    290 -360
    291 -356
    291 -352
    291 -348
    291 -343
    291 -339
    290 -335
    290 -330
    289 -326
    289 -321
    288 -317
    287 -313
    286 -308
    285 -303
    284 -299
    282 -294
    281 -290
    279 -285
    277 -280
    275 -275
    273 -271
    271 -266
    269 -261
    267 -256
    264 -251
    262 -247
    259 -242
    256 -237
    253 -232
    250 -227
    247 -222
    243 -217
    240 -212
    236 -207
    232 -202
    228 -196
    224 -191
    220 -186
    216 -181
    212 -176
    207 -171
    203 -165
    198 -160
    193 -155
    188 -150
    183 -144
    177 -139
    172 -134
    166 -128
    161 -123
    155 -118
    149 -112
    143 -107
    137 -102
    131 -96
    124 -91
    118 -85
    111 -80
    104 -75
    97 -69
    90 -64
    83 -58
    76 -53
    68 -47
    61 -42
    53 -36
    45 -31
    38 -25
    30 -20
    21 -14
    13 -9
    5 -3
    -4 2
    -12 8
    -21 14
    -30 19
    -39 25
    -48 30
    -57 36
    -67 41
    -76 47
    -86 53
    -95 58
    -105 64
    -115 69
    -125 75
    -135 80
    -146 86
    -156 92
    -167 97
    -177 103
    -188 108
    -199 114
    -210 120
    -221 125
    -232 131
    -243 136
    -255 142
    -266 147
    -278 153
    -290 159
    -301 164
    -313 170
    -326 175
    -338 181
    -350 186
    -362 192
    -375 198
    -387 203
    -400 209
    -413 214
    -426 220
    -439 225
    -452 231
    -465 236
    -479 242
    -492 247
    -506 253
    -519 258
    -533 264
    -547 269
    -561 275
    -575 280
    -589 286
    -603 291
    -617 297
    -632 302
    -646 307
    -661 313
    -676 318
    -690 324
    -705 329
    -720 335
    -735 340
    -751 345
    -766 351
    -781 356
    -797 361
    -812 367
    -828 372
    -844 378
    -859 383
    -875 388
    -891 393
    -907 399
    -924 404
    -940 409
    -956 415
    -973 420
    -989 425
    -1006 430
    -1022 436
    -1039 441
    -1056 446
    -1073 451
    -1090 457
    -1107 462
    -1124 467
    -1142 472
    -1159 477
    -1176 482
    -1194 488
    1189 480
    1171 475
    1154 470
    1136 465
    1119 460
    1102 455
    1085 450
    1068 445
    1051 439
    1034 434
    1017 429
    1001 424
    984 419
    967 413
    951 408
    935 403
    918 398
    902 392
    886 387
    870 382
    854 377
    838 371
    823 366
    807 361
    791 355
    776 350
    761 345
    745 339
    730 334
    715 329
    700 323
    685 318
    670 313
    656 307
    641 302
    626 296
    612 291
    598 286
    583 280
    569 275
    555 269
    541 264
    527 258
    514 253
    500 247
    487 242
    473 237
    460 231
    447 226
    433 220
    420 215
    407 209
    395 204
    382 198
    369 193
    357 187
    344 182
    332 176
    320 171
    308 165
    296 159
    284 154
    272 148
    261 143
    249 137
    238 132
    226 126
    215 121
    204 115
    193 110
    182 104
    172 99
    161 93
    151 87
    140 82
    130 76
    120 71
    110 65
    100 60
    90 54
    80 49
    71 43
    61 38
    52 32
    43 26
    33 21
    24 15
    16 10
    7 4
    -2 -1
    -10 -7
    -19 -12
    -27 -18
    -35 -23
    -43 -29
    -51 -34
    -59 -40
    -66 -45
    -74 -50
    -81 -56
    -89 -61
    -96 -67
    -103 -72
    -110 -78
    -116 -83
    -123 -88
    -130 -94
    -136 -99
    -142 -105
    -148 -110
    -154 -115
    -160 -121
    -166 -126
    -172 -131
    -177 -137
    -183 -142
    -188 -147
    -193 -152
    -198 -158
    -203 -163
    -208 -168
    -212 -173
    -217 -178
    -221 -183
    -225 -189
    -230 -194
    -234 -199
    -237 -204
    -241 -209
    -245 -214
    -248 -219
    -252 -224
    -255 -229
    -258 -234
    -261 -239
    -264 -244
    -266 -249
    -269 -253
    -272 -258
    -274 -263
    -276 -268
    -278 -273
    -280 -277
    -282 -282
    -284 -287
    -285 -291
    -287 -296
    -288 -301
    -289 -305
    -291 -310
    -292 -314
    -292 -319
    -293 -323
    -294 -328
    -294 -332
    -295 -336
    -295 -341
    -295 -345
    -295 -349
    -295 -353
    -295 -357
    -294 -362
    -294 -366
    -294 -370
    -293 -374
    -292 -378
    -291 -382
    -290 -386
    -289 -390
    -288 -393
    -287 -397
    -285 -401
    -284 -405
    -282 -408
    -280 -412
    -278 -415
    -276 -419
    -274 -423
    -272 -426
    -270 -429
    -268 -433
    -265 -436
    -263 -439
    -260 -443
    -257 -446
    -255 -449
    -252 -452
    -249 -455
    -246 -458
    -242 -461
    -239 -464
    -236 -467
    -232 -469
    -229 -472
    -225 -475
    -222 -478
    -218 -480
    -214 -483
    -210 -485
    -206 -488
    -202 -490
    -198 -492
    -194 -495
    -189 -497
    -185 -499
    -181 -501
    -176 -503
    -172 -505
    -167 -507
    -163 -509
    -158 -511
    -153 -512
    -148 -514
    -144 -516
    -139 -517
    -134 -519
    -129 -520
    -124 -522
    -119 -523
    -114 -524
    -108 -526
    -103 -527
    -98 -528
    -93 -529
    -87 -530
    -82 -531
    -77 -532
    -71 -533
    -66 -534
    -61 -534
    -55 -535
    -50 -535
    -44 -536
    -39 -536
    -33 -537
    -28 -537
    -22 -537
    -17 -538
    -11 -538
    -6 -538
    0 -538
    6 -538
    11 -538
    17 -538
    22 -537
    28 -537
    33 -537
    39 -536
    44 -536
    50 -535
    55 -535
    61 -534
    66 -534
    71 -533
    77 -532
    82 -531
    87 -530
    93 -529
    98 -528
    103 -527
    108 -526
    114 -524
    119 -523
    124 -522
    129 -520
    134 -519
    139 -517
    144 -516
    148 -514
    153 -512
    158 -511
    163 -509
    167 -507
    172 -505
    176 -503
    181 -501
    185 -499
    189 -497
    194 -495
    198 -492
    202 -490
    206 -488
    210 -485
    214 -483
    218 -480
    222 -478
    225 -475
    229 -472
    232 -469
    236 -467
    239 -464
    242 -461
    246 -458
    249 -455
    252 -452
    255 -449
    257 -446
    260 -443
    263 -439
    265 -436
    268 -433
    270 -429
    272 -426
    274 -423
    276 -419
    278 -415
    280 -412
    282 -408
    284 -405
    285 -401
    287 -397
    288 -393
    289 -390
    290 -386
    291 -382
    292 -378
    293 -374
    294 -370
    294 -366
    294 -362
    295 -357
    295 -353
    295 -349
    295 -345
    295 -341
    295 -336
    294 -332
    294 -328
    293 -323
    292 -319
    292 -314
    291 -310
    289 -305
    288 -301
    287 -296
    285 -291
    284 -287
    282 -282
    280 -277
    278 -273
    276 -268
    274 -263
    272 -258
    269 -253
    266 -249
    264 -244
    261 -239
    258 -234
    255 -229
    252 -224
    248 -219
    245 -214
    241 -209
    237 -204
    234 -199
    230 -194
    225 -189
    221 -183
    217 -178
    212 -173
    208 -168
    203 -163
    198 -158
    193 -152
    188 -147
    183 -142
    177 -137
    172 -131
    166 -126
    160 -121
    154 -115
    148 -110
    142 -105
    136 -99
    130 -94
    123 -88
    116 -83
    110 -78
    103 -72
    96 -67
    89 -61
    81 -56
    74 -50
    66 -45
    59 -40
    51 -34
    43 -29
    35 -23
    27 -18
    19 -12
    10 -7
    2 -1
    -7 4
    -16 10
    -24 15
    -33 21
    -43 26
    -52 32
    -61 38
    -71 43
    -80 49
    -90 54
    -100 60
    -110 65
    -120 71
    -130 76
    -140 82
    -151 87
    -161 93
    -172 99
    -182 104
    -193 110
    -204 115
    -215 121
    -226 126
    -238 132
    -249 137
    -261 143
    -272 148
    -284 154
    -296 159
    -308 165
    -320 171
    -332 176
    -344 182
    -357 187
    -369 193
    -382 198
    -395 204
    -407 209
    -420 215
    -433 220
    -447 226
    -460 231
    -473 237
    -487 242
    -500 247
    -514 253
    -527 258
    -541 264
    -555 269
    -569 275
    -583 280
    -598 286
    -612 291
    -626 296
    -641 302
    -656 307
    -670 313
    -685 318
    -700 323
    -715 329
    -730 334
    -745 339
    -761 345
    -776 350
    -791 355
    -807 361
    -823 366
    -838 371
    -854 377
    -870 382
    -886 387
    -902 392
    -918 398
    -935 403
    -951 408
    -967 413
    -984 419
    -1001 424
    -1017 429
    -1034 434
    -1051 439
    -1068 445
    -1085 450
    -1102 455
    -1119 460
    -1136 465
    -1154 470
    -1171 475
    -1189 480
    1184 473
    1166 468
    1149 463
    1131 458
    1114 453
    1097 448
    1080 443
    1063 438
    1046 433
    1029 428
    1012 422
    995 417
    979 412
    962 407
    946 402
    929 397
    913 391
    897 386
    881 381
    865 376
    849 370
    833 365
    817 360
    802 355
    786 349
    771 344
    755 339
    740 333
    725 328
    710 323
    695 318
    680 312
    665 307
    650 302
    636 296
    621 291
    607 285
    592 280
    578 275
    564 269
    550 264
    536 259
    522 253
    508 248
    495 242
    481 237
    468 231
    454 226
    441 221
    428 215
    415 210
    402 204
    389 199
    376 193
    364 188
    351 182
    339 177
    327 171
    314 166
    302 160
    290 155
    279 149
    267 144
    255 138
    244 133
    232 127
    221 122
    210 116
    199 111
    188 105
    177 100
    166 94
    155 89
    145 83
    135 78
    124 72
    114 67
    104 61
    94 56
    84 50
    75 45
    65 39
    56 34
    46 28
    37 23
    28 17
    19 12
    10 6
    1 1
    -7 -5
    -16 -10
    -24 -16
    -32 -21
    -41 -26
    -49 -32
    -56 -37
    -64 -43
    -72 -48
    -79 -54
    -87 -59
    -94 -64
    -101 -70
    -108 -75
    -115 -81
    -122 -86
    -128 -91
    -135 -97
    -141 -102
    -148 -107
    -154 -113
    -160 -118
    -166 -123
    -171 -129
    -177 -134
    -183 -139
    -188 -144
    -193 -150
    -198 -155
    -203 -160
    -208 -165
    -213 -170
    -218 -175
    -222 -181
    -226 -186
    -231 -191
    -235 -196
    -239 -201
    -242 -206
    -246 -211
    -250 -216
    -253 -221
    -257 -226
    -260 -231
    -263 -236
    -266 -241
    -269 -246
    -271 -250
    -274 -255
    -276 -260
    -279 -265
    -281 -270
    -283 -274
    -285 -279
    -287 -284
    -288 -288
    -290 -293
    -291 -298
    -293 -302
    -294 -307
    -295 -311
    -296 -316
    -297 -320
    -298 -325
    -298 -329
    -299 -333
    -299 -338
    -299 -342
    -299 -346
    -299 -350
    -299 -355
    -299 -359
    -299 -363
    -298 -367
    -298 -371
    -297 -375
    -296 -379
    -295 -383
    -294 -387
    -293 -391
    -292 -394
    -290 -398
    -289 -402
    -287 -406
    -286 -409
    -284 -413
    -282 -416
    -280 -420
    -278 -423
    -276 -427
    -273 -430
    -271 -434
    -269 -437
    -266 -440
    -263 -443
    -261 -447
    -258 -450
    -255 -453
    -252 -456
    -248 -459
    -245 -462
    -242 -465
    -239 -467
    -235 -470
    -232 -473
    -228 -476
    -224 -478
    -220 -481
    -216 -483
    -213 -486
    -208 -488
    -204 -491
    -200 -493
    -196 -495
    -192 -497
    -187 -499
    -183 -502
    -178 -504
    -174 -506
    -169 -507
    -164 -509
    -160 -511
    -155 -513
    -150 -515
    -145 -516
    -140 -518
    -135 -519
    -130 -521
    -125 -522
    -120 -524
    -115 -525
    -110 -526
    -104 -527
    -99 -528
    -94 -529
    -88 -530
    -83 -531
    -78 -532
    -72 -533
    -67 -534
    -61 -535
    -56 -535
    -50 -536
    -45 -536
    -39 -537
    -34 -537
    -28 -537
    -22 -538
    -17 -538
    -11 -538
    -6 -538
    0 -538
    6 -538
    11 -538
    17 -538
    22 -538
    28 -537
    34 -537
    39 -537
    45 -536
    50 -536
    56 -535
    61 -535
    67 -534
    72 -533
    78 -532
    83 -531
    88 -530
    94 -529
    99 -528
    104 -527
    110 -526
    115 -525
    120 -524
    125 -522
    130 -521
    135 -519
    140 -518
    145 -516
    150 -515
    155 -513
    160 -511
    164 -509
    169 -507
    174 -506
    178 -504
    183 -502
    187 -499
    192 -497
    196 -495
    200 -493
    204 -491
    208 -488
    213 -486
    216 -483
    220 -481
    224 -478
    228 -476
    232 -473
    235 -470
    239 -467
    242 -465
    245 -462
    248 -459
    252 -456
    255 -453
    258 -450
    261 -447
    263 -443
    266 -440
    269 -437
    271 -434
    273 -430
    276 -427
    278 -423
    280 -420
    282 -416
    284 -413
    286 -409
    287 -406
    289 -402
    290 -398
    292 -394
    293 -391
    294 -387
    295 -383
    296 -379
    297 -375
    298 -371
    298 -367
    299 -363
    299 -359
    299 -355
    299 -350
    299 -346
    299 -342
    299 -338
    299 -333
    298 -329
    298 -325
    297 -320
    296 -316
    295 -311
    294 -307
    293 -302
    291 -298
    290 -293
    288 -288
    287 -284
    285 -279
    283 -274
    281 -270
    279 -265
    276 -260
    274 -255
    271 -250
    269 -246
    266 -241
    263 -236
    260 -231
    257 -226
    253 -221
    250 -216
    246 -211
    242 -206
    239 -201
    235 -196
    231 -191
    226 -186
    222 -181
    218 -175
    213 -170
    208 -165
    203 -160
    198 -155
    193 -150
    188 -144
    183 -139
    177 -134
    171 -129
    166 -123
    160 -118
    154 -113
    148 -107
    141 -102
    135 -97
    128 -91
    122 -86
    115 -81
    108 -75
    101 -70
    94 -64
    87 -59
    79 -54
    72 -48
    64 -43
    56 -37
    49 -32
    41 -26
    32 -21
    24 -16
    16 -10
    7 -5
    -1 1
    -10 6
    -19 12
    -28 17
    -37 23
    -46 28
    -56 34
    -65 39
    -75 45
    -84 50
    -94 56
    -104 61
    -114 67
    -124 72
    -135 78
    -145 83
    -155 89
    -166 94
    -177 100
    -188 105
    -199 111
    -210 116
    -221 122
    -232 127
    -244 133
    -255 138
    -267 144
    -279 149
    -290 155
    -302 160
    -314 166
    -327 171
    -339 177
    -351 182
    -364 188
    -376 193
    -389 199
    -402 204
    -415 210
    -428 215
    -441 221
    -454 226
    -468 231
    -481 237
    -495 242
    -508 248
    -522 253
    -536 259
    -550 264
    -564 269
    -578 275
    -592 280
    -607 285
    -621 291
    -636 296
    -650 302
    -665 307
    -680 312
    -695 318
    -710 323
    -725 328
    -740 333
    -755 339
    -771 344
    -786 349
    -802 355
    -817 360
    -833 365
    -849 370
    -865 376
    -881 381
    -897 386
    -913 391
    -929 397
    -946 402
    -962 407
    -979 412
    -995 417
    -1012 422
    -1029 428
    -1046 433
    -1063 438
    -1080 443
    -1097 448
    -1114 453
    -1131 458
    -1149 463
    -1166 468
    -1184 473
    1179 467
    1161 462
    1144 457
    1126 451
    1109 446
    1092 441
    1075 436
    1058 431
    1041 426
    1024 421
    1007 416
    990 411
    974 406
    957 401
    941 395
    924 390
    908 385
    892 380
    876 375
    860 370
    844 364
    828 359
    812 354
    796 349
    781 343
    765 338
    750 333
    735 328
    719 322
    704 317
    689 312
    674 307
    660 301
    645 296
    630 291
    616 285
    601 280
    587 275
    573 269
    558 264
    544 259
    530 253
    517 248
    503 242
    489 237
    476 232
    462 226
    449 221
    436 216
    422 210
    409 205
    397 199
    384 194
    371 188
    358 183
    346 178
    333 172
    321 167
    309 161
    297 156
    285 150
    273 145
    261 139
    250 134
    238 129
    227 123
    215 118
    204 112
    193 107
    182 101
    171 96
    161 90
    150 85
    139 79
    129 74
    119 68
    109 63
    99 57
    89 52
    79 47
    69 41
    60 36
    50 30
    41 25
    32 19
    22 14
    13 8
    5 3
    -4 -3
    -13 -8
    -21 -13
    -30 -19
    -38 -24
    -46 -30
    -54 -35
    -62 -41
    -70 -46
    -77 -51
    -85 -57
    -92 -62
    -99 -67
    -107 -73
    -114 -78
    -120 -84
    -127 -89
    -134 -94
    -140 -99
    -147 -105
    -153 -110
    -159 -115
    -165 -121
    -171 -126
    -177 -131
    -182 -136
    -188 -142
    -193 -147
    -198 -152
    -204 -157
    -208 -162
    -213 -167
    -218 -173
    -223 -178
    -227 -183
    -231 -188
    -236 -193
    -240 -198
    -244 -203
    -248 -208
    -251 -213
    -255 -218
    -258 -223
    -262 -228
    -265 -233
    -268 -238
    -271 -243
    -274 -247
    -276 -252
    -279 -257
    -281 -262
    -283 -267
    -286 -271
    -288 -276
    -290 -281
    -291 -285
    -293 -290
    -295 -295
    -296 -299
    -297 -304
    -298 -308
    -300 -313
    -300 -317
    -301 -322
    -302 -326
    -302 -330
    -303 -335
    -303 -339
    -303 -343
    -304 -347
    -303 -352
    -303 -356
    -303 -360
    -303 -364
    -302 -368
    -302 -372
    -301 -376
    -300 -380
    -299 -384
    -298 -388
    -297 -392
    -296 -395
    -294 -399
    -293 -403
    -291 -407
    -289 -410
    -287 -414
    -286 -417
    -283 -421
    -281 -424
    -279 -428
    -277 -431
    -274 -434
    -272 -438
    -269 -441
    -266 -444
    -264 -447
    -261 -450
    -258 -453
    -255 -456
    -251 -459
    -248 -462
    -245 -465
    -241 -468
    -238 -471
    -234 -473
    -231 -476
    -227 -479
    -223 -481
    -219 -484
    -215 -486
    -211 -489
    -207 -491
    -202 -493
    -198 -495
    -194 -498
    -189 -500
    -185 -502
    -180 -504
    -176 -506
    -171 -508
    -166 -510
    -162 -511
    -157 -513
    -152 -515
    -147 -517
    -142 -518
    -137 -520
    -132 -521
    -126 -522
    -121 -524
    -116 -525
    -111 -526
    -106 -528
    -100 -529
    -95 -530
    -89 -531
    -84 -532
    -78 -532
    -73 -533
    -67 -534
    -62 -535
    -56 -535
    -51 -536
    -45 -536
    -40 -537
    -34 -537
    -28 -538
    -23 -538
    -17 -538
    -11 -538
    -6 -538
    0 -538
    6 -538
    11 -538
    17 -538
    23 -538
    28 -538
    34 -537
    40 -537
    45 -536
    51 -536
    56 -535
    62 -535
    67 -534
    73 -533
    78 -532
    84 -532
    89 -531
    95 -530
    100 -529
    106 -528
    111 -526
    116 -525
    121 -524
    126 -522
    132 -521
    137 -520
    142 -518
    147 -517
    152 -515
    157 -513
    162 -511
    166 -510
    171 -508
    176 -506
    180 -504
    185 -502
    189 -500
    194 -498
    198 -495
    202 -493
    207 -491
    211 -489
    215 -486
    219 -484
    223 -481
    227 -479
    231 -476
    234 -473
    238 -471
    241 -468
    245 -465
    248 -462
    251 -459
    255 -456
    258 -453
    261 -450
    264 -447
    266 -444
    269 -441
    272 -438
    274 -434
    277 -431
    279 -428
    281 -424
    283 -421
    286 -417
    287 -414
    289 -410
    291 -407
    293 -403
    294 -399
    296 -395
    297 -392
    298 -388
    299 -384
    300 -380
    301 -376
    302 -372
    302 -368
    303 -364
    303 -360
    303 -356
    303 -352
    304 -347
    303 -343
    303 -339
    303 -335
    302 -330
    302 -326
    301 -322
    300 -317
    300 -313
    298 -308
    297 -304
    296 -299
    295 -295
    293 -290
    291 -285
    290 -281
    288 -276
    286 -271
    283 -267
    281 -262
    279 -257
    276 -252
    274 -247
    271 -243
    268 -238
    265 -233
    262 -228
    258 -223
    255 -218
    251 -213
    248 -208
    244 -203
    240 -198
    236 -193
    231 -188
    227 -183
    223 -178
    218 -173
    213 -167
    208 -162
    204 -157
    198 -152
    193 -147
    188 -142
    182 -136
    177 -131
    171 -126
    165 -121
    159 -115
    153 -110
    147 -105
    140 -99
    134 -94
    127 -89
    120 -84
    114 -78
    107 -73
    99 -67
    92 -62
    85 -57
    77 -51
    70 -46
    62 -41
    54 -35
    46 -30
    38 -24
    30 -19
    21 -13
    13 -8
    4 -3
    -5 3
    -13 8
    -22 14
    -32 19
    -41 25
    -50 30
    -60 36
    -69 41
    -79 47
    -89 52
    -99 57
    -109 63
    -119 68
    -129 74
    -139 79
    -150 85
    -161 90
    -171 96
    -182 101
    -193 107
    -204 112
    -215 118
    -227 123
    -238 129
    -250 134
    -261 139
    -273 145
    -285 150
    -297 156
    -309 161
    -321 167
    -333 172
    -346 178
    -358 183
    -371 188
    -384 194
    -397 199
    -409 205
    -422 210
    -436 216
    -449 221
    -462 226
    -476 232
    -489 237
    -503 242
    -517 248
    -530 253
    -544 259
    -558 264
    -573 269
    -587 275
    -601 280
    -616 285
    -630 291
    -645 296
    -660 301
    -674 307
    -689 312
    -704 317
    -719 322
    -735 328
    -750 333
    -765 338
    -781 343
    -796 349
    -812 354
    -828 359
    -844 364
    -860 370
    -876 375
    -892 380
    -908 385
    -924 390
    -941 395
    -957 401
    -974 406
    -990 411
    -1007 416
    -1024 421
    -1041 426
    -1058 431
    -1075 436
    -1092 441
    -1109 446
    -1126 451
    -1144 457
    -1161 462
    -1179 467
    1174 460
    1156 455
    1139 450
    1121 445
    1104 440
    1087 435
    1070 430
    1053 425
    1036 420
    1019 415
    1002 409
    985 404
    968 399
    952 394
    935 389
    919 384
    903 379
    887 374
    870 369
    854 363
    838 358
    823 353
    807 348
    791 343
    776 338
    760 332
    745 327
    729 322
    714 317
    699 311
    684 306
    669 301
    654 296
    640 290
    625 285
    610 280
    596 275
    582 269
    567 264
    553 259
    539 253
    525 248
    511 243
    498 237
    484 232
    470 227
    457 221
    443 216
    430 211
    417 205
    404 200
    391 195
    378 189
    366 184
    353 178
    340 173
    328 168
    316 162
    304 157
    291 151
    280 146
    268 141
    256 135
    244 130
    233 124
    221 119
    210 113
    199 108
    188 103
    177 97
    166 92
    155 86
    145 81
    134 75
    124 70
    113 65
    103 59
    93 54
    83 48
    73 43
    64 37
    54 32
    45 27
    35 21
    26 16
    17 10
    8 5
    -1 -0
    -10 -6
    -18 -11
    -27 -17
    -35 -22
    -43 -27
    -51 -33
    -59 -38
    -67 -44
    -75 -49
    -83 -54
    -90 -60
    -97 -65
    -105 -70
    -112 -76
    -119 -81
    -126 -86
    -133 -92
    -139 -97
    -146 -102
    -152 -107
    -158 -113
    -164 -118
    -170 -123
    -176 -128
    -182 -134
    -188 -139
    -193 -144
    -198 -149
    -204 -154
    -209 -159
    -214 -165
    -218 -170
    -223 -175
    -228 -180
    -232 -185
    -237 -190
    -241 -195
    -245 -200
    -249 -205
    -253 -210
    -256 -215
    -260 -220
    -263 -225
    -266 -230
    -270 -235
    -273 -240
    -276 -244
    -278 -249
    -281 -254
    -283 -259
    -286 -263
    -288 -268
    -290 -273
    -292 -278
    -294 -282
    -296 -287
    -298 -291
    -299 -296
    -301 -301
    -302 -305
    -303 -310
    -304 -314
    -305 -318
    -306 -323
    -306 -327
    -307 -331
    -307 -336
    -308 -340
    -308 -344
    -308 -349
    -308 -353
    -307 -357
    -307 -361
    -307 -365
    -306 -369
    -306 -373
    -305 -377
    -304 -381
    -303 -385
    -302 -389
    -301 -392
    -299 -396
    -298 -400
    -296 -404
    -295 -407
    -293 -411
    -291 -414
    -289 -418
    -287 -421
    -285 -425
    -282 -428
    -280 -432
    -278 -435
    -275 -438
    -272 -441
    -270 -445
    -267 -448
    -264 -451
    -261 -454
    -258 -457
    -254 -460
    -251 -463
    -248 -466
    -244 -468
    -241 -471
    -237 -474
    -233 -476
    -229 -479
    -225 -482
    -221 -484
    -217 -486
    -213 -489
    -209 -491
    -205 -493
    -200 -496
    -196 -498
    -191 -500
    -187 -502
    -182 -504
    -178 -506
    -173 -508
    -168 -510
    -163 -512
    -158 -513
    -153 -515
    -148 -517
    -143 -518
    -138 -520
    -133 -521
    -128 -523
    -123 -524
    -117 -525
    -112 -526
    -107 -528
    -101 -529
    -96 -530
    -90 -531
    -85 -532
    -79 -533
    -74 -533
    -68 -534
    -63 -535
    -57 -535
    -51 -536
    -46 -536
    -40 -537
    -34 -537
    -29 -538
    -23 -538
    -17 -538
    -11 -538
    -6 -538
    0 -538
    6 -538
    11 -538
    17 -538
    23 -538
    29 -538
    34 -537
    40 -537
    46 -536
    51 -536
    57 -535
    63 -535
    68 -534
    74 -533
    79 -533
    85 -532
    90 -531
    96 -530
    101 -529
    107 -528
    112 -526
    117 -525
    123 -524
    128 -523
    133 -521
    138 -520
    143 -518
    148 -517
    153 -515
    158 -513
    163 -512
    168 -510
    173 -508
    178 -506
    182 -504
    187 -502
    191 -500
    196 -498
    200 -496
    205 -493
    209 -491
    213 -489
    217 -486
    221 -484
    225 -482
    229 -479
    233 -476
    237 -474
    241 -471
    244 -468
    248 -466
    251 -463
    254 -460
    258 -457
    261 -454
    264 -451
    267 -448
    270 -445
    272 -441
    275 -438
    278 -435
    280 -432
    282 -428
    285 -425
    287 -421
    289 -418
    291 -414
    293 -411
    295 -407
    296 -404
    298 -400
    299 -396
    301 -392
    302 -389
    303 -385
    304 -381
    305 -377
    306 -373
    306 -369
    307 -365
    307 -361
    307 -357
    308 -353
    308 -349
    308 -344
    308 -340
    307 -336
    307 -331
    306 -327
    306 -323
    305 -318
    304 -314
    303 -310
    302 -305
    301 -301
    299 -296
    298 -291
    296 -287
    294 -282
    292 -278
    290 -273
    288 -268
    286 -263
    283 -259
    281 -254
    278 -249
    276 -244
    273 -240
    270 -235
    266 -230
    263 -225
    260 -220
    256 -215
    253 -210
    249 -205
    245 -200
    241 -195
    237 -190
    232 -185
    228 -180
    223 -175
    218 -170
    214 -165
    209 -159
    204 -154
    198 -149
    193 -144
    188 -139
    182 -134
    176 -128
    170 -123
    164 -118
    158 -113
    152 -107
    146 -102
    139 -97
    133 -92
    126 -86
    119 -81
    112 -76
    105 -70
    97 -65
    90 -60
    83 -54
    75 -49
    67 -44
    59 -38
    51 -33
    43 -27
    35 -22
    27 -17
    18 -11
    10 -6
    1 -0
    -8 5
    -17 10
    -26 16
    -35 21
    -45 27
    -54 32
    -64 37
    -73 43
    -83 48
    -93 54
    -103 59
    -113 65
    -124 70
    -134 75
    -145 81
    -155 86
    -166 92
    -177 97
    -188 103
    -199 108
    -210 113
    -221 119
    -233 124
    -244 130
    -256 135
    -268 141
    -280 146
    -291 151
    -304 157
    -316 162
    -328 168
    -340 173
    -353 178
    -366 184
    -378 189
    -391 195
    -404 200
    -417 205
    -430 211
    -443 216
    -457 221
    -470 227
    -484 232
    -498 237
    -511 243
    -525 248
    -539 253
    -553 259
    -567 264
    -582 269
    -596 275
    -610 280
    -625 285
    -640 290
    -654 296
    -669 301
    -684 306
    -699 311
    -714 317
    -729 322
    -745 327
    -760 332
    -776 338
    -791 343
    -807 348
    -823 353
    -838 358
    -854 363
    -870 369
    -887 374
    -903 379
    -919 384
    -935 389
    -952 394
    -968 399
    -985 404
    -1002 409
    -1019 415
    -1036 420
    -1053 425
    -1070 430
    -1087 435
    -1104 440
    -1121 445
    -1139 450
    -1156 455
    -1174 460
    1169 453
    1151 448
    1134 443
    1116 438
    1099 433
    1082 428
    1065 423
    1047 418
    1031 413
    1014 408
    997 403
    980 398
    963 393
    947 388
    930 383
    914 378
    898 373
    881 368
    865 362
    849 357
    833 352
    817 347
    802 342
    786 337
    770 332
    755 327
    740 321
    724 316
    709 311
    694 306
    679 301
    664 295
    649 290
    634 285
    620 280
    605 275
    591 269
    576 264
    562 259
    548 253
    534 248
    520 243
    506 238
    492 232
    479 227
    465 222
    452 216
    438 211
    425 206
    412 200
    399 195
    386 190
    373 184
    360 179
    348 174
    335 168
    323 163
    310 158
    298 152
    286 147
    274 142
    262 136
    251 131
    239 126
    227 120
    216 115
    205 109
    193 104
    182 99
    171 93
    160 88
    150 82
    139 77
    129 72
    118 66
    108 61
    98 55
    88 50
    78 45
    68 39
    58 34
    49 29
    39 23
    30 18
    21 12
    12 7
    3 2
    -6 -4
    -15 -9
    -24 -14
    -32 -20
    -40 -25
    -49 -31
    -57 -36
    -65 -41
    -73 -47
    -80 -52
    -88 -57
    -95 -63
    -103 -68
    -110 -73
    -117 -78
    -124 -84
    -131 -89
    -138 -94
    -144 -99
    -151 -105
    -157 -110
    -163 -115
    -170 -120
    -176 -126
    -181 -131
    -187 -136
    -193 -141
    -198 -146
    -204 -151
    -209 -157
    -214 -162
    -219 -167
    -224 -172
    -228 -177
    -233 -182
    -237 -187
    -242 -192
    -246 -197
    -250 -202
    -254 -207
    -257 -212
    -261 -217
    -265 -222
    -268 -227
    -271 -231
    -274 -236
    -277 -241
    -280 -246
    -283 -251
    -286 -256
    -288 -260
    -291 -265
    -293 -270
    -295 -274
    -297 -279
    -299 -284
    -301 -288
    -302 -293
    -304 -297
    -305 -302
    -306 -306
    -307 -311
    -308 -315
    -309 -320
    -310 -324
    -311 -328
    -311 -333
    -311 -337
    -312 -341
    -312 -345
    -312 -349
    -312 -354
    -312 -358
    -311 -362
    -311 -366
    -310 -370
    -310 -374
    -309 -378
    -308 -382
    -307 -386
    -306 -389
    -304 -393
    -303 -397
    -302 -401
    -300 -404
    -298 -408
    -296 -411
    -295 -415
    -293 -419
    -290 -422
    -288 -425
    -286 -429
    -283 -432
    -281 -435
    -278 -439
    -276 -442
    -273 -445
    -270 -448
    -267 -451
    -264 -454
    -261 -457
    -257 -460
    -254 -463
    -250 -466
    -247 -469
    -243 -471
    -240 -474
    -236 -477
    -232 -479
    -228 -482
    -224 -484
    -220 -487
    -216 -489
    -211 -491
    -207 -494
    -203 -496
    -198 -498
    -194 -500
    -189 -502
    -184 -504
    -180 -506
    -175 -508
    -170 -510
    -165 -512
    -160 -513
    -155 -515
    -150 -517
    -145 -518
    -140 -520
    -134 -521
    -129 -523
    -124 -524
    -119 -525
    -113 -526
    -108 -527
    -102 -529
    -97 -530
    -91 -531
    -86 -532
    -80 -532
    -75 -533
    -69 -534
    -63 -535
    -58 -535
    -52 -536
    -46 -536
    -40 -537
    -35 -537
    -29 -538
    -23 -538
    -17 -538
    -12 -538
    -6 -538
    0 -538
    6 -538
    12 -538
    17 -538
    23 -538
    29 -538
    35 -537
    40 -537
    46 -536
    52 -536
    58 -535
    63 -535
    69 -534
    75 -533
    80 -532
    86 -532
    91 -531
    97 -530
    102 -529
    108 -527
    113 -526
    119 -525
    124 -524
    129 -523
    134 -521
    140 -520
    145 -518
    150 -517
    155 -515
    160 -513
    165 -512
    170 -510
    175 -508
    180 -506
    184 -504
    189 -502
    194 -500
    198 -498
    203 -496
    207 -494
    211 -491
    216 -489
    220 -487
    224 -484
    228 -482
    232 -479
    236 -477
    240 -474
    243 -471
    247 -469
    250 -466
    254 -463
    257 -460
    261 -457
    264 -454
    267 -451
    270 -448
    273 -445
    276 -442
    278 -439
    281 -435
    283 -432
    286 -429
    288 -425
    290 -422
    293 -419
    295 -415
    296 -411
    298 -408
    300 -404
    302 -401
    303 -397
    304 -393
    306 -389
    307 -386
    308 -382
    309 -378
    310 -374
    310 -370
    311 -366
    311 -362
    312 -358
    312 -354
    312 -349
    312 -345
    312 -341
    311 -337
    311 -333
    311 -328
    310 -324
    309 -320
    308 -315
    307 -311
    306 -306
    305 -302
    304 -297
    302 -293
    301 -288
    299 -284
    297 -279
    295 -274
    293 -270
    291 -265
    288 -260
    286 -256
    283 -251
    280 -246
    277 -241
    274 -236
    271 -231
    268 -227
    265 -222
    261 -217
    257 -212
    254 -207
    250 -202
    246 -197
    242 -192
    237 -187
    233 -182
    228 -177
    224 -172
    219 -167
    214 -162
    209 -157
    204 -151
    198 -146
    193 -141
    187 -136
    181 -131
    176 -126
    170 -120
    163 -115
    157 -110
    151 -105
    144 -99
    138 -94
    131 -89
    124 -84
    117 -78
    110 -73
    103 -68
    95 -63
    88 -57
    80 -52
    73 -47
    65 -41
    57 -36
    49 -31
    40 -25
    32 -20
    24 -14
    15 -9
    6 -4
    -3 2
    -12 7
    -21 12
    -30 18
    -39 23
    -49 29
    -58 34
    -68 39
    -78 45
    -88 50
    -98 55
    -108 61
    -118 66
    -129 72
    -139 77
    -150 82
    -160 88
    -171 93
    -182 99
    -193 104
    -205 109
    -216 115
    -227 120
    -239 126
    -251 131
    -262 136
    -274 142
    -286 147
    -298 152
    -310 158
    -323 163
    -335 168
    -348 174
    -360 179
    -373 184
    -386 190
    -399 195
    -412 200
    -425 206
    -438 211
    -452 216
    -465 222
    -479 227
    -492 232
    -506 238
    -520 243
    -534 248
    -548 253
    -562 259
    -576 264
    -591 269
    -605 275
    -620 280
    -634 285
    -649 290
    -664 295
    -679 301
    -694 306
    -709 311
    -724 316
    -740 321
    -755 327
    -770 332
    -786 337
    -802 342
    -817 347
    -833 352
    -849 357
    -865 362
    -881 368
    -898 373
    -914 378
    -930 383
    -947 388
    -963 393
    -980 398
    -997 403
    -1014 408
    -1031 413
    -1047 418
    -1065 423
    -1082 428
    -1099 433
    -1116 438
    -1134 443
    -1151 448
    -1169 453
    1164 446
    1146 441
    1129 436
    1111 431
    1094 426
    1077 422
    1060 417
    1043 412
    1026 407
    1009 402
    992 397
    975 392
    958 387
    942 382
    925 377
    909 372
    893 367
    876 362
    860 356
    844 351
    828 346
    812 341
    797 336
    781 331
    765 326
    750 321
    734 316
    719 311
    704 305
    689 300
    674 295
    659 290
    644 285
    629 280
    614 274
    600 269
    585 264
    571 259
    557 254
    543 248
    529 243
    515 238
    501 233
    487 227
    473 222
    460 217
    446 212
    433 206
    420 201
    406 196
    393 190
    380 185
    368 180
    355 175
    342 169
    330 164
    317 159
    305 153
    293 148
    281 143
    269 137
    257 132
    245 127
    234 121
    222 116
    211 111
    199 105
    188 100
    177 95
    166 89
    155 84
    144 79
    134 73
    123 68
    113 63
    103 57
    92 52
    82 46
    72 41
    63 36
    53 30
    43 25
    34 20
    25 14
    15 9
    6 4
    -3 -2
    -12 -7
    -20 -12
    -29 -18
    -37 -23
    -46 -28
    -54 -34
    -62 -39
    -70 -44
    -78 -49
    -86 -55
    -93 -60
    -101 -65
    -108 -71
    -115 -76
    -122 -81
    -129 -86
    -136 -92
    -143 -97
    -150 -102
    -156 -107
    -162 -112
    -169 -118
    -175 -123
    -181 -128
    -187 -133
    -192 -138
    -198 -143
    -203 -148
    -209 -154
    -214 -159
    -219 -164
    -224 -169
    -229 -174
    -233 -179
    -238 -184
    -242 -189
    -247 -194
    -251 -199
    -255 -204
    -259 -209
    -262 -214
    -266 -219
    -270 -223
    -273 -228
    -276 -233
    -279 -238
    -282 -243
    -285 -247
    -288 -252
    -290 -257
    -293 -262
    -295 -266
    -298 -271
    -300 -276
    -302 -280
    -303 -285
    -305 -289
    -307 -294
    -308 -298
    -310 -303
    -311 -307
    -312 -312
    -313 -316
    -314 -321
    -314 -325
    -315 -329
    -315 -334
    -316 -338
    -316 -342
    -316 -346
    -316 -350
    -316 -354
    -316 -359
    -315 -363
    -315 -367
    -314 -371
    -313 -375
    -313 -378
    -312 -382
    -311 -386
    -309 -390
    -308 -394
    -307 -397
    -305 -401
    -304 -405
    -302 -408
    -300 -412
    -298 -415
    -296 -419
    -294 -422
    -292 -426
    -289 -429
    -287 -432
    -284 -436
    -282 -439
    -279 -442
    -276 -445
    -273 -448
    -270 -451
    -267 -454
    -263 -457
    -260 -460
    -257 -463
    -253 -466
    -250 -469
    -246 -471
    -242 -474
    -238 -477
    -234 -479
    -230 -482
    -226 -484
    -222 -487
    -218 -489
    -214 -491
    -209 -494
    -205 -496
    -200 -498
    -196 -500
    -191 -502
    -186 -504
    -182 -506
    -177 -508
    -172 -510
    -167 -511
    -162 -513
    -157 -515
    -152 -516
    -146 -518
    -141 -520
    -136 -521
    -131 -522
    -125 -524
    -120 -525
    -114 -526
    -109 -527
    -103 -528
    -98 -529
    -92 -530
    -87 -531
    -81 -532
    -75 -533
    -70 -534
    -64 -534
    -58 -535
    -52 -536
    -47 -536
    -41 -537
    -35 -537
    -29 -537
    -23 -537
    -18 -538
    -12 -538
    -6 -538
    0 -538
    6 -538
    12 -538
    18 -538
    23 -537
    29 -537
    35 -537
    41 -537
    47 -536
    52 -536
    58 -535
    64 -534
    70 -534
    75 -533
    81 -532
    87 -531
    92 -530
    98 -529
    103 -528
    109 -527
    114 -526
    120 -525
    125 -524
    131 -522
    136 -521
    141 -520
    146 -518
    152 -516
    157 -515
    162 -513
    167 -511
    172 -510
    177 -508
    182 -506
    186 -504
    191 -502
    196 -500
    200 -498
    205 -496
    209 -494
    214 -491
    218 -489
    222 -487
    226 -484
    230 -482
    234 -479
    238 -477
    242 -474
    246 -471
    250 -469
    253 -466
    257 -463
    260 -460
    263 -457
    267 -454
    270 -451
    273 -448
    276 -445
    279 -442
    282 -439
    284 -436
    287 -432
    289 -429
    292 -426
    294 -422
    296 -419
    298 -415
    300 -412
    302 -408
    304 -405
    305 -401
    307 -397
    308 -394
    309 -390
    311 -386
    312 -382
    313 -378
    313 -375
    314 -371
    315 -367
    315 -363
    316 -359
    316 -354
    316 -350
    316 -346
    316 -342
    316 -338
    315 -334
    315 -329
    314 -325
    314 -321
    313 -316
    312 -312
    311 -307
    310 -303
    308 -298
    307 -294
    305 -289
    303 -285
    302 -280
    300 -276
    298 -271
    295 -266
    293 -262
    290 -257
    288 -252
    285 -247
    282 -243
    279 -238
    276 -233
    273 -228
    270 -223
    266 -219
    262 -214
    259 -209
    255 -204
    251 -199
    247 -194
    242 -189
    238 -184
    233 -179
    229 -174
    224 -169
    219 -164
    214 -159
    209 -154
    203 -148
    198 -143
    192 -138
    187 -133
    181 -128
    175 -123
    169 -118
    162 -112
    156 -107
    150 -102
    143 -97
    136 -92
    129 -86
    122 -81
    115 -76
    108 -71
    101 -65
    93 -60
    86 -55
    78 -49
    70 -44
    62 -39
    54 -34
    46 -28
    37 -23
    29 -18
    20 -12
    12 -7
    3 -2
    -6 4
    -15 9
    -25 14
    -34 20
    -43 25
    -53 30
    -63 36
    -72 41
    -82 46
    -92 52
    -103 57
    -113 63
    -123 68
    -134 73
    -144 79
    -155 84
    -166 89
    -177 95
    -188 100
    -199 105
    -211 111
    -222 116
    -234 121
    -245 127
    -257 132
    -269 137
    -281 143
    -293 148
    -305 153
    -317 159
    -330 164
    -342 169
    -355 175
    -368 180
    -380 185
    -393 190
    -406 196
    -420 201
    -433 206
    -446 212
    -460 217
    -473 222
    -487 227
    -501 233
    -515 238
    -529 243
    -543 248
    -557 254
    -571 259
    -585 264
    -600 269
    -614 274
    -629 280
    -644 285
    -659 290
    -674 295
    -689 300
    -704 305
    -719 311
    -734 316
    -750 321
    -765 326
    -781 331
    -797 336
    -812 341
    -828 346
    -844 351
    -860 356
    -876 362
    -893 367
    -909 372
    -925 377
    -942 382
    -958 387
    -975 392
    -992 397
    -1009 402
    -1026 407
    -1043 412
    -1060 417
    -1077 422
    -1094 426
    -1111 431
    -1129 436
    -1146 441
    -1164 446
    1159 439
    1141 435
    1124 430
    1106 425
    1089 420
    1072 415
    1055 410
    1038 405
    1021 400
    1004 395
    987 390
    970 385
    953 381
    937 376
    920 371
    904 366
    888 361
    871 356
    855 351
    839 346
    823 340
    807 335
    791 330
    776 325
    760 320
    745 315
    729 310
    714 305
    699 300
    684 295
    668 290
    654 285
    639 279
    624 274
    609 269
    595 264
    580 259
    566 254
    552 248
    537 243
    523 238
    509 233
    495 228
    482 223
    468 217
    454 212
    441 207
    428 202
    414 196
    401 191
    388 186
    375 181
    362 175
    350 170
    337 165
    324 160
    312 154
    300 149
    288 144
    275 138
    263 133
    252 128
    240 123
    228 117
    217 112
    205 107
    194 101
    183 96
    172 91
    161 85
    150 80
    139 75
    128 70
    118 64
    108 59
    97 54
    87 48
    77 43
    67 38
    57 32
    48 27
    38 22
    29 16
    19 11
    10 6
    1 1
    -8 -5
    -17 -10
    -26 -15
    -34 -21
    -43 -26
    -51 -31
    -59 -36
    -67 -42
    -75 -47
    -83 -52
    -91 -57
    -99 -63
    -106 -68
    -113 -73
    -121 -78
    -128 -84
    -135 -89
    -141 -94
    -148 -99
    -155 -104
    -161 -110
    -168 -115
    -174 -120
    -180 -125
    -186 -130
    -192 -135
    -197 -140
    -203 -145
    -208 -151
    -214 -156
    -219 -161
    -224 -166
    -229 -171
    -234 -176
    -238 -181
    -243 -186
    -247 -191
    -251 -196
    -256 -201
    -260 -205
    -264 -210
    -267 -215
    -271 -220
    -274 -225
    -278 -230
    -281 -235
    -284 -239
    -287 -244
    -290 -249
    -293 -254
    -295 -258
    -298 -263
    -300 -268
    -302 -272
    -304 -277
    -306 -281
    -308 -286
    -310 -291
    -311 -295
    -313 -300
    -314 -304
    -315 -308
    -316 -313
    -317 -317
    -318 -321
    -319 -326
    -319 -330
    -320 -334
    -320 -339
    -320 -343
    -320 -347
    -320 -351
    -320 -355
    -320 -359
    -319 -363
    -319 -367
    -318 -371
    -317 -375
    -317 -379
    -316 -383
    -314 -387
    -313 -390
    -312 -394
    -310 -398
    -309 -402
    -307 -405
    -305 -409
    -304 -412
    -302 -416
    -299 -419
    -297 -423
    -295 -426
    -293 -429
    -290 -433
    -287 -436
    -285 -439
    -282 -442
    -279 -445
    -276 -448
    -273 -451
    -270 -454
    -266 -457
    -263 -460
    -260 -463
    -256 -466
    -252 -469
    -249 -471
    -245 -474
    -241 -477
    -237 -479
    -233 -482
    -229 -484
    -225 -487
    -220 -489
    -216 -491
    -211 -493
    -207 -496
    -202 -498
    -198 -500
    -193 -502
    -188 -504
    -183 -506
    -179 -508
    -174 -509
    -169 -511
    -163 -513
    -158 -515
    -153 -516
    -148 -518
    -143 -519
    -137 -521
    -132 -522
    -127 -523
    -121 -525
    -116 -526
    -110 -527
    -104 -528
    -99 -529
    -93 -530
    -88 -531
    -82 -532
    -76 -533
    -70 -533
    -65 -534
    -59 -535
    -53 -535
    -47 -536
    -41 -536
    -35 -536
    -29 -537
    -24 -537
    -18 -537
    -12 -537
    -6 -538
    0 -538
    6 -538
    12 -537
    18 -537
    24 -537
    29 -537
    35 -536
    41 -536
    47 -536
    53 -535
    59 -535
    65 -534
    70 -533
    76 -533
    82 -532
    88 -531
    93 -530
    99 -529
    104 -528
    110 -527
    116 -526
    121 -525
    127 -523
    132 -522
    137 -521
    143 -519
    148 -518
    153 -516
    158 -515
    163 -513
    169 -511
    174 -509
    179 -508
    183 -506
    188 -504
    193 -502
    198 -500
    202 -498
    207 -496
    211 -493
    216 -491
    220 -489
    225 -487
    229 -484
    233 -482
    237 -479
    241 -477
    245 -474
    249 -471
    252 -469
    256 -466
    260 -463
    263 -460
    266 -457
    270 -454
    273 -451
    276 -448
    279 -445
    282 -442
    285 -439
    287 -436
    290 -433
    293 -429
    295 -426
    297 -423
    299 -419
    302 -416
    304 -412
    305 -409
    307 -405
    309 -402
    310 -398
    312 -394
    313 -390
    314 -387
    316 -383
    317 -379
    317 -375
    318 -371
    319 -367
    319 -363
    320 -359
    320 -355
    320 -351
    320 -347
    320 -343
    320 -339
    320 -334
    319 -330
    319 -326
    318 -321
    317 -317
    316 -313
    315 -308
    314 -304
    313 -300
    311 -295
    310 -291
    308 -286
    306 -281
    304 -277
    302 -272
    300 -268
    298 -263
    295 -258
    293 -254
    290 -249
    287 -244
    284 -239
    281 -235
    278 -230
    274 -225
    271 -220
    267 -215
    264 -210
    260 -205
    256 -201
    251 -196
    247 -191
    243 -186
    238 -181
    234 -176
    229 -171
    224 -166
    219 -161
    214 -156
    208 -151
    203 -145
    197 -140
    192 -135
    186 -130
    180 -125
    174 -120
    168 -115
    161 -110
    155 -104
    148 -99
    141 -94
    135 -89
    128 -84
    121 -78
    113 -73
    106 -68
    99 -63
    91 -57
    83 -52
    75 -47
    67 -42
    59 -36
    51 -31
    43 -26
    34 -21
    26 -15
    17 -10
    8 -5
    -1 1
    -10 6
    -19 11
    -29 16
    -38 22
    -48 27
    -57 32
    -67 38
    -77 43
    -87 48
    -97 54
    -108 59
    -118 64
    -128 70
    -139 75
    -150 80
    -161 85
    -172 91
    -183 96
    -194 101
    -205 107
    -217 112
    -228 117
    -240 123
    -252 128
    -263 133
    -275 138
    -288 144
    -300 149
    -312 154
    -324 160
    -337 165
    -350 170
    -362 175
    -375 181
    -388 186
    -401 191
    -414 196
    -428 202
    -441 207
    -454 212
    -468 217
    -482 223
    -495 228
    -509 233
    -523 238
    -537 243
    -552 248
    -566 254
    -580 259
    -595 264
    -609 269
    -624 274
    -639 279
    -654 285
    -668 290
    -684 295
    -699 300
    -714 305
    -729 310
    -745 315
    -760 320
    -776 325
    -791 330
    -807 335
    -823 340
    -839 346
    -855 351
    -871 356
    -888 361
    -904 366
    -920 371
    -937 376
    -953 381
    -970 385
    -987 390
    -1004 395
    -1021 400
    -1038 405
    -1055 410
    -1072 415
    -1089 420
    -1106 425
    -1124 430
    -1141 435
    -1159 439
    1154 433
    1137 428
    1119 423
    1102 418
    1084 413
    1067 409
    1050 404
    1033 399
    1016 394
    999 389
    982 384
    965 379
    948 374
    932 369
    915 365
    899 360
    883 355
    866 350
    850 345
    834 340
    818 335
    802 330
    786 325
    771 320
    755 315
    740 310
    724 305
    709 300
    694 294
    678 289
    663 284
    648 279
    634 274
    619 269
    604 264
    590 259
    575 254
    561 249
    546 243
    532 238
    518 233
    504 228
    490 223
    477 218
    463 213
    449 207
    436 202
    422 197
    409 192
    396 187
    383 181
    370 176
    357 171
    344 166
    332 161
    319 155
    307 150
    294 145
    282 140
    270 134
    258 129
    246 124
    235 119
    223 113
    211 108
    200 103
    189 98
    177 92
    166 87
    155 82
    145 77
    134 71
    123 66
    113 61
    102 55
    92 50
    82 45
    72 40
    62 34
    52 29
    42 24
    33 19
    23 13
    14 8
    5 3
    -4 -2
    -13 -8
    -22 -13
    -31 -18
    -39 -23
    -48 -29
    -56 -34
    -64 -39
    -73 -44
    -81 -50
    -88 -55
    -96 -60
    -104 -65
    -111 -70
    -119 -76
    -126 -81
    -133 -86
    -140 -91
    -147 -96
    -153 -102
    -160 -107
    -166 -112
    -173 -117
    -179 -122
    -185 -127
    -191 -132
    -197 -137
    -202 -142
    -208 -147
    -213 -152
    -219 -157
    -224 -163
    -229 -168
    -234 -173
    -239 -177
    -243 -182
    -248 -187
    -252 -192
    -256 -197
    -261 -202
    -265 -207
    -268 -212
    -272 -217
    -276 -222
    -279 -226
    -283 -231
    -286 -236
    -289 -241
    -292 -245
    -295 -250
    -297 -255
    -300 -259
    -302 -264
    -305 -269
    -307 -273
    -309 -278
    -311 -282
    -313 -287
    -314 -292
    -316 -296
    -317 -300
    -318 -305
    -320 -309
    -321 -314
    -321 -318
    -322 -322
    -323 -327
    -323 -331
    -324 -335
    -324 -339
    -324 -343
    -324 -348
    -324 -352
    -324 -356
    -324 -360
    -323 -364
    -323 -368
    -322 -372
    -321 -376
    -320 -379
    -319 -383
    -318 -387
    -317 -391
    -316 -394
    -314 -398
    -312 -402
    -311 -405
    -309 -409
    -307 -412
    -305 -416
    -303 -419
    -301 -423
    -298 -426
    -296 -429
    -293 -433
    -291 -436
    -288 -439
    -285 -442
    -282 -445
    -279 -448
    -276 -451
    -273 -454
    -269 -457
    -266 -460
    -262 -463
    -259 -466
    -255 -469
    -251 -471
    -247 -474
    -243 -476
    -239 -479
    -235 -481
    -231 -484
    -227 -486
    -223 -489
    -218 -491
    -214 -493
    -209 -495
    -204 -497
    -200 -499
    -195 -501
    -190 -503
    -185 -505
    -180 -507
    -175 -509
    -170 -511
    -165 -512
    -160 -514
    -155 -516
    -149 -517
    -144 -519
    -139 -520
    -133 -521
    -128 -523
    -122 -524
    -117 -525
    -111 -526
    -105 -527
    -100 -528
    -94 -529
    -88 -530
    -83 -531
    -77 -532
    -71 -533
    -65 -533
    -59 -534
    -53 -535
    -48 -535
    -42 -535
    -36 -536
    -30 -536
    -24 -536
    -18 -537
    -12 -537
    -6 -537
    0 -537
    6 -537
    12 -537
    18 -537
    24 -536
    30 -536
    36 -536
    42 -535
    48 -535
    53 -535
    59 -534
    65 -533
    71 -533
    77 -532
    83 -531
    88 -530
    94 -529
    100 -528
    105 -527
    111 -526
    117 -525
    122 -524
    128 -523
    133 -521
    139 -520
    144 -519
    149 -517
    155 -516
    160 -514
    165 -512
    170 -511
    175 -509
    180 -507
    185 -505
    190 -503
    195 -501
    200 -499
    204 -497
    209 -495
    214 -493
    218 -491
    223 -489
    227 -486
    231 -484
    235 -481
    239 -479
    243 -476
    247 -474
    251 -471
    255 -469
    259 -466
    262 -463
    266 -460
    269 -457
    273 -454
    276 -451
    279 -448
    282 -445
    285 -442
    288 -439
    291 -436
    293 -433
    296 -429
    298 -426
    301 -423
    303 -419
    305 -416
    307 -412
    309 -409
    311 -405
    312 -402
    314 -398
    316 -394
    317 -391
    318 -387
    319 -383
    320 -379
    321 -376
    322 -372
    323 -368
    323 -364
    324 -360
    324 -356
    324 -352
    324 -348
    324 -343
    324 -339
    324 -335
    323 -331
    323 -327
    322 -322
    321 -318
    321 -314
    320 -309
    318 -305
    317 -300
    316 -296
    314 -292
    313 -287
    311 -282
    309 -278
    307 -273
    305 -269
    302 -264
    300 -259
    297 -255
    295 -250
    292 -245
    289 -241
    286 -236
    283 -231
    279 -226
    276 -222
    272 -217
    268 -212
    265 -207
    261 -202
    256 -197
    252 -192
    248 -187
    243 -182
    239 -177
    234 -173
    229 -168
    224 -163
    219 -157
    213 -152
    208 -147
    202 -142
    197 -137
    191 -132
    185 -127
    179 -122
    173 -117
    166 -112
    160 -107
    153 -102
    147 -96
    140 -91
    133 -86
    126 -81
    119 -76
    111 -70
    104 -65
    96 -60
    88 -55
    81 -50
    73 -44
    64 -39
    56 -34
    48 -29
    39 -23
    31 -18
    22 -13
    13 -8
    4 -2
    -5 3
    -14 8
    -23 13
    -33 19
    -42 24
    -52 29
    -62 34
    -72 40
    -82 45
    -92 50
    -102 55
    -113 61
    -123 66
    -134 71
    -145 77
    -155 82
    -166 87
    -177 92
    -189 98
    -200 103
    -211 108
    -223 113
    -235 119
    -246 124
    -258 129
    -270 134
    -282 140
    -294 145
    -307 150
    -319 155
    -332 161
    -344 166
    -357 171
    -370 176
    -383 181
    -396 187
    -409 192
    -422 197
    -436 202
    -449 207
    -463 213
    -477 218
    -490 223
    -504 228
    -518 233
    -532 238
    -546 243
    -561 249
    -575 254
    -590 259
    -604 264
    -619 269
    -634 274
    -648 279
    -663 284
    -678 289
    -694 294
    -709 300
    -724 305
    -740 310
    -755 315
    -771 320
    -786 325
    -802 330
    -818 335
    -834 340
    -850 345
    -866 350
    -883 355
    -899 360
    -915 365
    -932 369
    -948 374
    -965 379
    -982 384
    -999 389
    -1016 394
    -1033 399
    -1050 404
    -1067 409
    -1084 413
    -1102 418
    -1119 423
    -1137 428
    -1154 433
    1149 426
    1132 421
    1114 417
    1097 412
    1079 407
    1062 402
    1045 397
    1028 393
    1011 388
    994 383
    977 378
    960 373
    944 368
    927 363
    910 359
    894 354
    878 349
    861 344
    845 339
    829 334
    813 329
    797 324
    781 319
    766 314
    750 309
    735 304
    719 299
    704 294
    689 289
    673 284
    658 279
    643 274
    628 269
    614 264
    599 259
    584 254
    570 249
    556 244
    541 238
    527 233
    513 228
    499 223
    485 218
    471 213
    458 208
    444 203
    431 198
    417 192
    404 187
    391 182
    378 177
    365 172
    352 167
    339 161
    327 156
    314 151
    302 146
    289 141
    277 135
    265 130
    253 125
    241 120
    229 115
    218 109
    206 104
    195 99
    183 94
    172 89
    161 83
    150 78
    139 73
    129 68
    118 62
    107 57
    97 52
    87 47
    77 42
    66 36
    57 31
    47 26
    37 21
    28 15
    18 10
    9 5
    -0 -0
    -10 -5
    -19 -11
    -27 -16
    -36 -21
    -45 -26
    -53 -32
    -61 -37
    -70 -42
    -78 -47
    -86 -52
    -94 -57
    -101 -63
    -109 -68
    -116 -73
    -124 -78
    -131 -83
    -138 -88
    -145 -93
    -152 -99
    -159 -104
    -165 -109
    -172 -114
    -178 -119
    -184 -124
    -190 -129
    -196 -134
    -202 -139
    -208 -144
    -213 -149
    -218 -154
    -224 -159
    -229 -164
    -234 -169
    -239 -174
    -244 -179
    -248 -184
    -253 -189
    -257 -194
    -261 -199
    -265 -204
    -269 -208
    -273 -213
    -277 -218
    -281 -223
    -284 -228
    -287 -232
    -290 -237
    -294 -242
    -296 -247
    -299 -251
    -302 -256
    -304 -261
    -307 -265
    -309 -270
    -311 -274
    -313 -279
    -315 -283
    -317 -288
    -319 -292
    -320 -297
    -322 -301
    -323 -306
    -324 -310
    -325 -314
    -326 -319
    -327 -323
    -327 -327
    -328 -331
    -328 -336
    -328 -340
    -328 -344
    -328 -348
    -328 -352
    -328 -356
    -328 -360
    -327 -364
    -327 -368
    -326 -372
    -325 -376
    -324 -380
    -323 -383
    -322 -387
    -321 -391
    -319 -395
    -318 -398
    -316 -402
    -314 -405
    -313 -409
    -311 -413
    -308 -416
    -306 -419
    -304 -423
    -302 -426
    -299 -429
    -297 -433
    -294 -436
    -291 -439
    -288 -442
    -285 -445
    -282 -448
    -279 -451
    -276 -454
    -272 -457
    -269 -460
    -265 -463
    -262 -465
    -258 -468
    -254 -471
    -250 -473
    -246 -476
    -242 -479
    -238 -481
    -234 -483
    -229 -486
    -225 -488
    -220 -490
    -216 -493
    -211 -495
    -207 -497
    -202 -499
    -197 -501
    -192 -503
    -187 -505
    -182 -507
    -177 -508
    -172 -510
    -167 -512
    -162 -514
    -156 -515
    -151 -517
    -146 -518
    -140 -519
    -135 -521
    -129 -522
    -123 -523
    -118 -525
    -112 -526
    -107 -527
    -101 -528
    -95 -529
    -89 -530
    -83 -530
    -78 -531
    -72 -532
    -66 -533
    -60 -533
    -54 -534
    -48 -534
    -42 -535
    -36 -535
    -30 -535
    -24 -536
    -18 -536
    -12 -536
    -6 -536
    0 -536
    6 -536
    12 -536
    18 -536
    24 -536
    30 -535
    36 -535
    42 -535
    48 -534
    54 -534
    60 -533
    66 -533
    72 -532
    78 -531
    83 -530
    89 -530
    95 -529
    101 -528
    107 -527
    112 -526
    118 -525
    123 -523
    129 -522
    135 -521
    140 -519
    146 -518
    151 -517
    156 -515
    162 -514
    167 -512
    172 -510
    177 -508
    182 -507
    187 -505
    192 -503
    197 -501
    202 -499
    207 -497
    211 -495
    216 -493
    220 -490
    225 -488
    229 -486
    234 -483
    238 -481
    242 -479
    246 -476
    250 -473
    254 -471
    258 -468
    262 -465
    265 -463
    269 -460
    272 -457
    276 -454
    279 -451
    282 -448
    285 -445
    288 -442
    291 -439
    294 -436
    297 -433
    299 -429
    302 -426
    304 -423
    306 -419
    308 -416
    311 -413
    313 -409
    314 -405
    316 -402
    318 -398
    319 -395
    321 -391
    322 -387
    323 -383
    324 -380
    325 -376
    326 -372
    327 -368
    327 -364
    328 -360
    328 -356
    328 -352
    328 -348
    328 -344
    328 -340
    328 -336
    328 -331
    327 -327
    327 -323
    326 -319
    325 -314
    324 -310
    323 -306
    322 -301
    320 -297
    319 -292
    317 -288
    315 -283
    313 -279
    311 -274
    309 -270
    307 -265
    304 -261
    302 -256
    299 -251
    296 -247
    294 -242
    290 -237
    287 -232
    284 -228
    281 -223
    277 -218
    273 -213
    269 -208
    265 -204
    261 -199
    257 -194
    253 -189
    248 -184
    244 -179
    239 -174
    234 -169
    229 -164
    224 -159
    218 -154
    213 -149
    208 -144
    202 -139
    196 -134
    190 -129
    184 -124
    178 -119
    172 -114
    165 -109
    159 -104
    152 -99
    145 -93
    138 -88
    131 -83
    124 -78
    116 -73
    109 -68
    101 -63
    94 -57
    86 -52
    78 -47
    70 -42
    61 -37
    53 -32
    45 -26
    36 -21
    27 -16
    19 -11
    10 -5
    0 -0
    -9 5
    -18 10
    -28 15
    -37 21
    -47 26
    -57 31
    -66 36
    -77 42
    -87 47
    -97 52
    -107 57
    -118 62
    -129 68
    -139 73
    -150 78
    -161 83
    -172 89
    -183 94
    -195 99
    -206 104
    -218 109
    -229 115
    -241 120
    -253 125
    -265 130
    -277 135
    -289 141
    -302 146
    -314 151
    -327 156
    -339 161
    -352 167
    -365 172
    -378 177
    -391 182
    -404 187
    -417 192
    -431 198
    -444 203
    -458 208
    -471 213
    -485 218
    -499 223
    -513 228
    -527 233
    -541 238
    -556 244
    -570 249
    -584 254
    -599 259
    -614 264
    -628 269
    -643 274
    -658 279
    -673 284
    -689 289
    -704 294
    -719 299
    -735 304
    -750 309
    -766 314
    -781 319
    -797 324
    -813 329
    -829 334
    -845 339
    -861 344
    -878 349
    -894 354
    -910 359
    -927 363
    -944 368
    -960 373
    -977 378
    -994 383
    -1011 388
    -1028 393
    -1045 397
    -1062 402
    -1079 407
    -1097 412
    -1114 417
    -1132 421
    -1149 426
    1145 420
    1127 415
    1109 410
    1092 405
    1075 401
    1057 396
    1040 391
    1023 386
    1006 382
    989 377
    972 372
    955 367
    939 362
    922 357
    906 353
    889 348
    873 343
    856 338
    840 333
    824 328
    808 323
    792 318
    777 313
    761 309
    745 304
    730 299
    714 294
    699 289
    684 284
    668 279
    653 274
    638 269
    623 264
    609 259
    594 254
    579 249
    565 244
    551 239
    536 234
    522 229
    508 223
    494 218
    480 213
    466 208
    453 203
    439 198
    425 193
    412 188
    399 183
    386 178
    373 173
    360 167
    347 162
    334 157
    321 152
    309 147
    296 142
    284 137
    272 131
    260 126
    248 121
    236 116
    224 111
    212 106
    201 100
    190 95
    178 90
    167 85
    156 80
    145 75
    134 69
    123 64
    113 59
    102 54
    92 49
    81 43
    71 38
    61 33
    51 28
    42 23
    32 18
    22 12
    13 7
    4 2
    -6 -3
    -15 -8
    -24 -14
    -33 -19
    -41 -24
    -50 -29
    -58 -34
    -67 -39
    -75 -45
    -83 -50
    -91 -55
    -99 -60
    -106 -65
    -114 -70
    -122 -75
    -129 -80
    -136 -86
    -143 -91
    -150 -96
    -157 -101
    -164 -106
    -170 -111
    -177 -116
    -183 -121
    -189 -126
    -195 -131
    -201 -136
    -207 -141
    -213 -146
    -218 -151
    -223 -156
    -229 -161
    -234 -166
    -239 -171
    -244 -176
    -248 -181
    -253 -186
    -258 -190
    -262 -195
    -266 -200
    -270 -205
    -274 -210
    -278 -215
    -282 -219
    -285 -224
    -289 -229
    -292 -234
    -295 -238
    -298 -243
    -301 -248
    -304 -252
    -307 -257
    -309 -262
    -311 -266
    -314 -271
    -316 -275
    -318 -280
    -320 -284
    -321 -289
    -323 -293
    -325 -298
    -326 -302
    -327 -306
    -328 -311
    -329 -315
    -330 -319
    -331 -323
    -331 -328
    -332 -332
    -332 -336
    -332 -340
    -333 -344
    -333 -348
    -332 -352
    -332 -356
    -332 -360
    -331 -364
    -331 -368
    -330 -372
    -329 -376
    -328 -380
    -327 -384
    -326 -387
    -324 -391
    -323 -395
    -321 -398
    -320 -402
    -318 -405
    -316 -409
    -314 -412
    -312 -416
    -310 -419
    -307 -423
    -305 -426
    -302 -429
    -300 -432
    -297 -436
    -294 -439
    -291 -442
    -288 -445
    -285 -448
    -282 -451
    -278 -454
    -275 -457
    -272 -460
    -268 -462
    -264 -465
    -260 -468
    -257 -470
    -253 -473
    -249 -476
    -244 -478
    -240 -480
    -236 -483
    -232 -485
    -227 -488
    -223 -490
    -218 -492
    -213 -494
    -209 -496
    -204 -498
    -199 -500
    -194 -502
    -189 -504
    -184 -506
    -179 -508
    -174 -509
    -168 -511
    -163 -513
    -158 -514
    -152 -516
    -147 -517
    -141 -519
    -136 -520
    -130 -521
    -125 -523
    -119 -524
    -113 -525
    -108 -526
    -102 -527
    -96 -528
    -90 -529
    -84 -530
    -78 -530
    -72 -531
    -66 -532
    -61 -532
    -55 -533
    -48 -533
    -42 -534
    -36 -534
    -30 -535
    -24 -535
    -18 -535
    -12 -535
    -6 -535
    0 -535
    6 -535
    12 -535
    18 -535
    24 -535
    30 -535
    36 -534
    42 -534
    48 -533
    55 -533
    61 -532
    66 -532
    72 -531
    78 -530
    84 -530
    90 -529
    96 -528
    102 -527
    108 -526
    113 -525
    119 -524
    125 -523
    130 -521
    136 -520
    141 -519
    147 -517
    152 -516
    158 -514
    163 -513
    168 -511
    174 -509
    179 -508
    184 -506
    189 -504
    194 -502
    199 -500
    204 -498
    209 -496
    213 -494
    218 -492
    223 -490
    227 -488
    232 -485
    236 -483
    240 -480
    244 -478
    249 -476
    253 -473
    257 -470
    260 -468
    264 -465
    268 -462
    272 -460
    275 -457
    278 -454
    282 -451
    285 -448
    288 -445
    291 -442
    294 -439
    297 -436
    300 -432
    302 -429
    305 -426
    307 -423
    310 -419
    312 -416
    314 -412
    316 -409
    318 -405
    320 -402
    321 -398
    323 -395
    324 -391
    326 -387
    327 -384
    328 -380
    329 -376
    330 -372
    331 -368
    331 -364
    332 -360
    332 -356
    332 -352
    333 -348
    333 -344
    332 -340
    332 -336
    332 -332
    331 -328
    331 -323
    330 -319
    329 -315
    328 -311
    327 -306
    326 -302
    325 -298
    323 -293
    321 -289
    320 -284
    318 -280
    316 -275
    314 -271
    311 -266
    309 -262
    307 -257
    304 -252
    301 -248
    298 -243
    295 -238
    292 -234
    289 -229
    285 -224
    282 -219
    278 -215
    274 -210
    270 -205
    266 -200
    262 -195
    258 -190
    253 -186
    248 -181
    244 -176
    239 -171
    234 -166
    229 -161
    223 -156
    218 -151
    213 -146
    207 -141
    201 -136
    195 -131
    189 -126
    183 -121
    177 -116
    170 -111
    164 -106
    157 -101
    150 -96
    143 -91
    136 -86
    129 -80
    122 -75
    114 -70
    106 -65
    99 -60
    91 -55
    83 -50
    75 -45
    67 -39
    58 -34
    50 -29
    41 -24
    33 -19
    24 -14
    15 -8
    6 -3
    -4 2
    -13 7
    -22 12
    -32 18
    -42 23
    -51 28
    -61 33
    -71 38
    -81 43
    -92 49
    -102 54
    -113 59
    -123 64
    -134 69
    -145 75
    -156 80
    -167 85
    -178 90
    -190 95
    -201 100
    -212 106
    -224 111
    -236 116
    -248 121
    -260 126
    -272 131
    -284 137
    -296 142
    -309 147
    -321 152
    -334 157
    -347 162
    -360 167
    -373 173
    -386 178
    -399 183
    -412 188
    -425 193
    -439 198
    -453 203
    -466 208
    -480 213
    -494 218
    -508 223
    -522 229
    -536 234
    -551 239
    -565 244
    -579 249
    -594 254
    -609 259
    -623 264
    -638 269
    -653 274
    -668 279
    -684 284
    -699 289
    -714 294
    -730 299
    -745 304
    -761 309
    -777 313
    -792 318
    -808 323
    -824 328
    -840 333
    -856 338
    -873 343
    -889 348
    -906 353
    -922 357
    -939 362
    -955 367
    -972 372
    -989 377
    -1006 382
    -1023 386
    -1040 391
    -1057 396
    -1075 401
    -1092 405
    -1109 410
    -1127 415
    -1145 420
    1140 413
    1122 409
    1105 404
    1087 399
    1070 394
    1053 390
    1035 385
    1018 380
    1001 375
    984 371
    967 366
    951 361
    934 356
    917 352
    901 347
    884 342
    868 337
    852 332
    835 327
    819 323
    803 318
    787 313
    772 308
    756 303
    740 298
    725 293
    709 288
    694 283
    679 278
    663 274
    648 269
    633 264
    618 259
    604 254
    589 249
    574 244
    560 239
    546 234
    531 229
    517 224
    503 219
    489 214
    475 209
    461 204
    447 199
    434 194
    420 189
    407 183
    394 178
    381 173
    367 168
    355 163
    342 158
    329 153
    316 148
    304 143
    291 138
    279 133
    267 128
    255 122
    243 117
    231 112
    219 107
    207 102
    196 97
    184 92
    173 87
    162 81
    151 76
    140 71
    129 66
    118 61
    108 56
    97 51
    87 45
    76 40
    66 35
    56 30
    46 25
    36 20
    27 15
    17 9
    8 4
    -2 -1
    -11 -6
    -20 -11
    -29 -16
    -38 -21
    -46 -27
    -55 -32
    -63 -37
    -72 -42
    -80 -47
    -88 -52
    -96 -57
    -104 -62
    -112 -67
    -119 -72
    -127 -78
    -134 -83
    -141 -88
    -148 -93
    -155 -98
    -162 -103
    -169 -108
    -175 -113
    -182 -118
    -188 -123
    -194 -128
    -200 -133
    -206 -138
    -212 -143
    -217 -148
    -223 -153
    -228 -158
    -234 -163
    -239 -168
    -244 -172
    -249 -177
    -253 -182
    -258 -187
    -262 -192
    -267 -197
    -271 -201
    -275 -206
    -279 -211
    -283 -216
    -286 -221
    -290 -225
    -293 -230
    -297 -235
    -300 -239
    -303 -244
    -306 -249
    -309 -253
    -311 -258
    -314 -262
    -316 -267
    -318 -271
    -320 -276
    -322 -280
    -324 -285
    -326 -289
    -328 -294
    -329 -298
    -330 -302
    -331 -307
    -333 -311
    -334 -315
    -334 -320
    -335 -324
    -336 -328
    -336 -332
    -336 -336
    -337 -340
    -337 -345
    -337 -349
    -336 -353
    -336 -357
    -336 -361
    -335 -364
    -334 -368
    -334 -372
    -333 -376
    -332 -380
    -331 -384
    -329 -387
    -328 -391
    -327 -395
    -325 -398
    -323 -402
    -321 -405
    -319 -409
    -317 -412
    -315 -416
    -313 -419
    -311 -422
    -308 -426
    -306 -429
    -303 -432
    -300 -435
    -297 -438
    -294 -441
    -291 -444
    -288 -447
    -285 -450
    -281 -453
    -278 -456
    -274 -459
    -271 -462
    -267 -464
    -263 -467
    -259 -470
    -255 -472
    -251 -475
    -247 -477
    -243 -480
    -238 -482
    -234 -485
    -229 -487
    -225 -489
    -220 -491
    -215 -493
    -211 -495
    -206 -497
    -201 -499
    -196 -501
    -191 -503
    -186 -505
    -181 -507
    -175 -509
    -170 -510
    -165 -512
    -159 -513
    -154 -515
    -148 -516
    -143 -518
    -137 -519
    -132 -520
    -126 -522
    -120 -523
    -114 -524
    -109 -525
    -103 -526
    -97 -527
    -91 -528
    -85 -529
    -79 -529
    -73 -530
    -67 -531
    -61 -531
    -55 -532
    -49 -532
    -43 -533
    -37 -533
    -31 -534
    -25 -534
    -18 -534
    -12 -534
    -6 -534
    0 -534
    6 -534
    12 -534
    18 -534
    25 -534
    31 -534
    37 -533
    43 -533
    49 -532
    55 -532
    61 -531
    67 -531
    73 -530
    79 -529
    85 -529
    91 -528
    97 -527
    103 -526
    109 -525
    114 -524
    120 -523
    126 -522
    132 -520
    137 -519
    143 -518
    148 -516
    154 -515
    159 -513
    165 -512
    170 -510
    175 -509
    181 -507
    186 -505
    191 -503
    196 -501
    201 -499
    206 -497
    211 -495
    215 -493
    220 -491
    225 -489
    229 -487
    234 -485
    238 -482
    243 -480
    247 -477
    251 -475
    255 -472
    259 -470
    263 -467
    267 -464
    271 -462
    274 -459
    278 -456
    281 -453
    285 -450
    288 -447
    291 -444
    294 -441
    297 -438
    300 -435
    303 -432
    306 -429
    308 -426
    311 -422
    313 -419
    315 -416
    317 -412
    319 -409
    321 -405
    323 -402
    325 -398
    327 -395
    328 -391
    329 -387
    331 -384
    332 -380
    333 -376
    334 -372
    334 -368
    335 -364
    336 -361
    336 -357
    336 -353
    337 -349
    337 -345
    337 -340
    336 -336
    336 -332
    336 -328
    335 -324
    334 -320
    334 -315
    333 -311
    331 -307
    330 -302
    329 -298
    328 -294
    326 -289
    324 -285
    322 -280
    320 -276
    318 -271
    316 -267
    314 -262
    311 -258
    309 -253
    306 -249
    303 -244
    300 -239
    297 -235
    293 -230
    290 -225
    286 -221
    283 -216
    279 -211
    275 -206
    271 -201
    267 -197
    262 -192
    258 -187
    253 -182
    249 -177
    244 -172
    239 -168
    234 -163
    228 -158
    223 -153
    217 -148
    212 -143
    206 -138
    200 -133
    194 -128
    188 -123
    182 -118
    175 -113
    169 -108
    162 -103
    155 -98
    148 -93
    141 -88
    134 -83
    127 -78
    119 -72
    112 -67
    104 -62
    96 -57
    88 -52
    80 -47
    72 -42
    63 -37
    55 -32
    46 -27
    38 -21
    29 -16
    20 -11
    11 -6
    2 -1
    -8 4
    -17 9
    -27 15
    -36 20
    -46 25
    -56 30
    -66 35
    -76 40
    -87 45
    -97 51
    -108 56
    -118 61
    -129 66
    -140 71
    -151 76
    -162 81
    -173 87
    -184 92
    -196 97
    -207 102
    -219 107
    -231 112
    -243 117
    -255 122
    -267 128
    -279 133
    -291 138
    -304 143
    -316 148
    -329 153
    -342 158
    -355 163
    -367 168
    -381 173
    -394 178
    -407 183
    -420 189
    -434 194
    -447 199
    -461 204
    -475 209
    -489 214
    -503 219
    -517 224
    -531 229
    -546 234
    -560 239
    -574 244
    -589 249
    -604 254
    -618 259
    -633 264
    -648 269
    -663 274
    -679 278
    -694 283
    -709 288
    -725 293
    -740 298
    -756 303
    -772 308
    -787 313
    -803 318
    -819 323
    -835 327
    -852 332
    -868 337
    -884 342
    -901 347
    -917 352
    -934 356
    -951 361
    -967 366
    -984 371
    -1001 375
    -1018 380
    -1035 385
    -1053 390
    -1070 394
    -1087 399
    -1105 404
    -1122 409
    -1140 413
    1135 407
    1118 402
    1100 397
    1083 393
    1065 388
    1048 383
    1031 379
    1014 374
    996 369
    979 365
    963 360
    946 355
    929 350
    912 346
    896 341
    879 336
    863 331
    847 327
    831 322
    815 317
    799 312
    783 307
    767 302
    751 298
    735 293
    720 288
    704 283
    689 278
    674 273
    659 268
    643 264
    628 259
    614 254
    599 249
    584 244
    569 239
    555 234
    541 229
    526 224
    512 219
    498 214
    484 209
    470 204
    456 199
    442 194
    429 189
    415 184
    402 179
    389 174
    376 169
    362 164
    349 159
    337 154
    324 149
    311 144
    299 139
    286 134
    274 129
    262 124
    250 119
    238 113
    226 108
    214 103
    202 98
    191 93
    179 88
    168 83
    157 78
    146 73
    135 68
    124 63
    113 58
    102 52
    92 47
    81 42
    71 37
    61 32
    51 27
    41 22
    31 17
    22 12
    12 7
    3 1
    -7 -4
    -16 -9
    -25 -14
    -34 -19
    -43 -24
    -51 -29
    -60 -34
    -69 -39
    -77 -44
    -85 -49
    -93 -54
    -101 -60
    -109 -65
    -117 -70
    -124 -75
    -132 -80
    -139 -85
    -146 -90
    -153 -95
    -160 -100
    -167 -105
    -174 -110
    -180 -115
    -187 -120
    -193 -125
    -199 -130
    -205 -135
    -211 -140
    -217 -145
    -222 -149
    -228 -154
    -233 -159
    -239 -164
    -244 -169
    -249 -174
    -253 -179
    -258 -184
    -263 -188
    -267 -193
    -272 -198
    -276 -203
    -280 -207
    -284 -212
    -288 -217
    -291 -222
    -295 -226
    -298 -231
    -301 -236
    -305 -240
    -308 -245
    -310 -249
    -313 -254
    -316 -259
    -318 -263
    -321 -268
    -323 -272
    -325 -277
    -327 -281
    -329 -285
    -330 -290
    -332 -294
    -333 -299
    -335 -303
    -336 -307
    -337 -311
    -338 -316
    -339 -320
    -339 -324
    -340 -328
    -340 -332
    -340 -337
    -341 -341
    -341 -345
    -341 -349
    -340 -353
    -340 -357
    -340 -361
    -339 -364
    -338 -368
    -338 -372
    -337 -376
    -336 -380
    -334 -383
    -333 -387
    -332 -391
    -330 -394
    -329 -398
    -327 -401
    -325 -405
    -323 -408
    -321 -412
    -319 -415
    -316 -419
    -314 -422
    -311 -425
    -309 -428
    -306 -432
    -303 -435
    -300 -438
    -297 -441
    -294 -444
    -291 -447
    -288 -450
    -284 -453
    -281 -456
    -277 -458
    -273 -461
    -270 -464
    -266 -466
    -262 -469
    -258 -472
    -254 -474
    -249 -477
    -245 -479
    -241 -481
    -236 -484
    -232 -486
    -227 -488
    -222 -490
    -218 -492
    -213 -495
    -208 -497
    -203 -499
    -198 -500
    -193 -502
    -188 -504
    -182 -506
    -177 -508
    -172 -509
    -166 -511
    -161 -512
    -155 -514
    -150 -515
    -144 -517
    -139 -518
    -133 -519
    -127 -521
    -121 -522
    -115 -523
    -110 -524
    -104 -525
    -98 -526
    -92 -527
    -86 -527
    -80 -528
    -74 -529
    -68 -530
    -62 -530
    -56 -531
    -49 -531
    -43 -532
    -37 -532
    -31 -532
    -25 -533
    -19 -533
    -12 -533
    -6 -533
    0 -533
    6 -533
    12 -533
    19 -533
    25 -533
    31 -532
    37 -532
    43 -532
    49 -531
    56 -531
    62 -530
    68 -530
    74 -529
    80 -528
    86 -527
    92 -527
    98 -526
    104 -525
    110 -524
    115 -523
    121 -522
    127 -521
    133 -519
    139 -518
    144 -517
    150 -515
    155 -514
    161 -512
    166 -511
    172 -509
    177 -508
    182 -506
    188 -504
    193 -502
    198 -500
    203 -499
    208 -497
    213 -495
    218 -492
    222 -490
    227 -488
    232 -486
    236 -484
    241 -481
    245 -479
    249 -477
    254 -474
    258 -472
    262 -469
    266 -466
    270 -464
    273 -461
    277 -458
    281 -456
    284 -453
    288 -450
    291 -447
    294 -444
    297 -441
    300 -438
    303 -435
    306 -432
    309 -428
    311 -425
    314 -422
    316 -419
    319 -415
    321 -412
    323 -408
    325 -405
    327 -401
    329 -398
    330 -394
    332 -391
    333 -387
    334 -383
    336 -380
    337 -376
    338 -372
    338 -368
    339 -364
    340 -361
    340 -357
    340 -353
    341 -349
    341 -345
    341 -341
    340 -337
    340 -332
    340 -328
    339 -324
    339 -320
    338 -316
    337 -311
    336 -307
    335 -303
    333 -299
    332 -294
    330 -290
    329 -285
    327 -281
    325 -277
    323 -272
    321 -268
    318 -263
    316 -259
    313 -254
    310 -249
    308 -245
    305 -240
    301 -236
    298 -231
    295 -226
    291 -222
    288 -217
    284 -212
    280 -207
    276 -203
    272 -198
    267 -193
    263 -188
    258 -184
    253 -179
    249 -174
    244 -169
    239 -164
    233 -159
    228 -154
    222 -149
    217 -145
    211 -140
    205 -135
    199 -130
    193 -125
    187 -120
    180 -115
    174 -110
    167 -105
    160 -100
    153 -95
    146 -90
    139 -85
    132 -80
    124 -75
    117 -70
    109 -65
    101 -60
    93 -54
    85 -49
    77 -44
    69 -39
    60 -34
    51 -29
    43 -24
    34 -19
    25 -14
    16 -9
    7 -4
    -3 1
    -12 7
    -22 12
    -31 17
    -41 22
    -51 27
    -61 32
    -71 37
    -81 42
    -92 47
    -102 52
    -113 58
    -124 63
    -135 68
    -146 73
    -157 78
    -168 83
    -179 88
    -191 93
    -202 98
    -214 103
    -226 108
    -238 113
    -250 119
    -262 124
    -274 129
    -286 134
    -299 139
    -311 144
    -324 149
    -337 154
    -349 159
    -362 164
    -376 169
    -389 174
    -402 179
    -415 184
    -429 189
    -442 194
    -456 199
    -470 204
    -484 209
    -498 214
    -512 219
    -526 224
    -541 229
    -555 234
    -569 239
    -584 244
    -599 249
    -614 254
    -628 259
    -643 264
    -659 268
    -674 273
    -689 278
    -704 283
    -720 288
    -735 293
    -751 298
    -767 302
    -783 307
    -799 312
    -815 317
    -831 322
    -847 327
    -863 331
    -879 336
    -896 341
    -912 346
    -929 350
    -946 355
    -963 360
    -979 365
    -996 369
    -1014 374
    -1031 379
    -1048 383
    -1065 388
    -1083 393
    -1100 397
    -1118 402
    -1135 407
    1131 400
    1113 396
    1095 391
    1078 387
    1061 382
    1043 377
    1026 373
    1009 368
    992 363
    975 359
    958 354
    941 349
    924 345
    908 340
    891 335
    875 330
    858 326
    842 321
    826 316
    810 311
    794 307
    778 302
    762 297
    746 292
    731 287
    715 283
    699 278
    684 273
    669 268
    654 263
    639 258
    624 254
    609 249
    594 244
    579 239
    565 234
    550 229
    536 224
    521 219
    507 214
    493 210
    479 205
    465 200
    451 195
    437 190
    424 185
    410 180
    397 175
    384 170
    371 165
    357 160
    344 155
    332 150
    319 145
    306 140
    294 135
    281 130
    269 125
    257 120
    244 115
    232 110
    221 105
    209 100
    197 95
    186 90
    174 85
    163 80
    152 75
    141 69
    130 64
    119 59
    108 54
    97 49
    87 44
    76 39
    66 34
    56 29
    46 24
    36 19
    26 14
    17 9
    7 4
    -2 -1
    -12 -6
    -21 -11
    -30 -16
    -39 -22
    -48 -27
    -57 -32
    -65 -37
    -74 -42
    -82 -47
    -90 -52
    -98 -57
    -106 -62
    -114 -67
    -122 -72
    -129 -77
    -137 -82
    -144 -87
    -151 -92
    -158 -97
    -165 -102
    -172 -107
    -179 -112
    -185 -117
    -192 -122
    -198 -126
    -204 -131
    -210 -136
    -216 -141
    -222 -146
    -227 -151
    -233 -156
    -238 -161
    -243 -166
    -249 -170
    -253 -175
    -258 -180
    -263 -185
    -268 -190
    -272 -194
    -276 -199
    -281 -204
    -285 -209
    -288 -213
    -292 -218
    -296 -223
    -299 -227
    -303 -232
    -306 -236
    -309 -241
    -312 -246
    -315 -250
    -318 -255
    -320 -259
    -323 -264
    -325 -268
    -327 -273
    -329 -277
    -331 -282
    -333 -286
    -335 -290
    -336 -295
    -338 -299
    -339 -303
    -340 -308
    -341 -312
    -342 -316
    -343 -320
    -343 -324
    -344 -328
    -344 -333
    -345 -337
    -345 -341
    -345 -345
    -345 -349
    -344 -353
    -344 -357
    -343 -360
    -343 -364
    -342 -368
    -341 -372
    -340 -376
    -339 -379
    -338 -383
    -337 -387
    -335 -390
    -334 -394
    -332 -398
    -330 -401
    -328 -405
    -326 -408
    -324 -411
    -322 -415
    -320 -418
    -317 -421
    -315 -425
    -312 -428
    -309 -431
    -306 -434
    -303 -437
    -300 -440
    -297 -443
    -294 -446
    -291 -449
    -287 -452
    -284 -455
    -280 -458
    -276 -460
    -272 -463
    -268 -466
    -264 -468
    -260 -471
    -256 -473
    -252 -476
    -247 -478
    -243 -480
    -239 -483
    -234 -485
    -229 -487
    -225 -489
    -220 -491
    -215 -493
    -210 -495
    -205 -497
    -200 -499
    -195 -501
    -189 -503
    -184 -505
    -179 -506
    -173 -508
    -168 -510
    -162 -511
    -157 -513
    -151 -514
    -146 -515
    -140 -517
    -134 -518
    -128 -519
    -122 -520
    -117 -522
    -111 -523
    -105 -524
    -99 -524
    -93 -525
    -87 -526
    -81 -527
    -74 -528
    -68 -528
    -62 -529
    -56 -529
    -50 -530
    -44 -530
    -37 -531
    -31 -531
    -25 -531
    -19 -531
    -13 -532
    -6 -532
    0 -532
    6 -532
    13 -532
    19 -531
    25 -531
    31 -531
    37 -531
    44 -530
    50 -530
    56 -529
    62 -529
    68 -528
    74 -528
    81 -527
    87 -526
    93 -525
    99 -524
    105 -524
    111 -523
    117 -522
    122 -520
    128 -519
    134 -518
    140 -517
    146 -515
    151 -514
    157 -513
    162 -511
    168 -510
    173 -508
    179 -506
    184 -505
    189 -503
    195 -501
    200 -499
    205 -497
    210 -495
    215 -493
    220 -491
    225 -489
    229 -487
    234 -485
    239 -483
    243 -480
    247 -478
    252 -476
    256 -473
    260 -471
    264 -468
    268 -466
    272 -463
    276 -460
    280 -458
    284 -455
    287 -452
    291 -449
    294 -446
    297 -443
    300 -440
    303 -437
    306 -434
    309 -431
    312 -428
    315 -425
    317 -421
    320 -418
    322 -415
    324 -411
    326 -408
    328 -405
    330 -401
    332 -398
    334 -394
    335 -390
    337 -387
    338 -383
    339 -379
    340 -376
    341 -372
    342 -368
    343 -364
    343 -360
    344 -357
    344 -353
    345 -349
    345 -345
    345 -341
    345 -337
    344 -333
    344 -328
    343 -324
    343 -320
    342 -316
    341 -312
    340 -308
    339 -303
    338 -299
    336 -295
    335 -290
    333 -286
    331 -282
    329 -277
    327 -273
    325 -268
    323 -264
    320 -259
    318 -255
    315 -250
    312 -246
    309 -241
    306 -236
    303 -232
    299 -227
    296 -223
    292 -218
    288 -213
    285 -209
    281 -204
    276 -199
    272 -194
    268 -190
    263 -185
    258 -180
    253 -175
    249 -170
    243 -166
    238 -161
    233 -156
    227 -151
    222 -146
    216 -141
    210 -136
    204 -131
    198 -126
    192 -122
    185 -117
    179 -112
    172 -107
    165 -102
    158 -97
    151 -92
    144 -87
    137 -82
    129 -77
    122 -72
    114 -67
    106 -62
    98 -57
    90 -52
    82 -47
    74 -42
    65 -37
    57 -32
    48 -27
    39 -22
    30 -16
    21 -11
    12 -6
    2 -1
    -7 4
    -17 9
    -26 14
    -36 19
    -46 24
    -56 29
    -66 34
    -76 39
    -87 44
    -97 49
    -108 54
    -119 59
    -130 64
    -141 69
    -152 75
    -163 80
    -174 85
    -186 90
    -197 95
    -209 100
    -221 105
    -232 110
    -244 115
    -257 120
    -269 125
    -281 130
    -294 135
    -306 140
    -319 145
    -332 150
    -344 155
    -357 160
    -371 165
    -384 170
    -397 175
    -410 180
    -424 185
    -437 190
    -451 195
    -465 200
    -479 205
    -493 210
    -507 214
    -521 219
    -536 224
    -550 229
    -565 234
    -579 239
    -594 244
    -609 249
    -624 254
    -639 258
    -654 263
    -669 268
    -684 273
    -699 278
    -715 283
    -731 287
    -746 292
    -762 297
    -778 302
    -794 307
    -810 311
    -826 316
    -842 321
    -858 326
    -875 330
    -891 335
    -908 340
    -924 345
    -941 349
    -958 354
    -975 359
    -992 363
    -1009 368
    -1026 373
    -1043 377
    -1061 382
    -1078 387
    -1095 391
    -1113 396
    -1131 400
    1126 394
    1108 390
    1091 385
    1073 380
    1056 376
    1039 371
    1021 367
    1004 362
    987 357
    970 353
    953 348
    936 343
    920 339
    903 334
    886 329
    870 325
    854 320
    837 315
    821 311
    805 306
    789 301
    773 296
    757 292
    741 287
    726 282
    710 277
    695 273
    679 268
    664 263
    649 258
    634 253
    619 249
    604 244
    589 239
    574 234
    560 229
    545 224
    531 220
    516 215
    502 210
    488 205
    474 200
    460 195
    446 190
    433 185
    419 180
    405 176
    392 171
    379 166
    366 161
    352 156
    339 151
    327 146
    314 141
    301 136
    289 131
    276 126
    264 121
    252 116
    239 111
    227 106
    216 101
    204 96
    192 91
    181 86
    169 81
    158 76
    147 71
    136 66
    125 61
    114 56
    103 51
    92 46
    82 41
    71 36
    61 31
    51 26
    41 21
    31 16
    21 11
    11 6
    2 1
    -8 -4
    -17 -9
    -26 -14
    -35 -19
    -44 -24
    -53 -29
    -62 -34
    -70 -39
    -79 -44
    -87 -49
    -95 -54
    -103 -59
    -111 -64
    -119 -69
    -127 -74
    -134 -79
    -142 -84
    -149 -89
    -156 -94
    -163 -99
    -170 -104
    -177 -108
    -184 -113
    -190 -118
    -196 -123
    -203 -128
    -209 -133
    -215 -138
    -221 -143
    -227 -148
    -232 -152
    -238 -157
    -243 -162
    -248 -167
    -253 -172
    -258 -176
    -263 -181
    -268 -186
    -272 -191
    -277 -195
    -281 -200
    -285 -205
    -289 -209
    -293 -214
    -297 -219
    -301 -223
    -304 -228
    -307 -233
    -311 -237
    -314 -242
    -317 -246
    -319 -251
    -322 -255
    -325 -260
    -327 -264
    -329 -269
    -332 -273
    -334 -278
    -336 -282
    -337 -286
    -339 -291
    -341 -295
    -342 -299
    -343 -303
    -344 -308
    -345 -312
    -346 -316
    -347 -320
    -348 -324
    -348 -328
    -348 -333
    -349 -337
    -349 -341
    -349 -345
    -349 -349
    -348 -352
    -348 -356
    -347 -360
    -347 -364
    -346 -368
    -345 -372
    -344 -375
    -343 -379
    -342 -383
    -340 -386
    -339 -390
    -337 -394
    -336 -397
    -334 -401
    -332 -404
    -330 -407
    -328 -411
    -325 -414
    -323 -417
    -321 -421
    -318 -424
    -315 -427
    -312 -430
    -309 -433
    -306 -436
    -303 -439
    -300 -442
    -297 -445
    -293 -448
    -290 -451
    -286 -454
    -283 -457
    -279 -459
    -275 -462
    -271 -465
    -267 -467
    -263 -470
    -259 -472
    -254 -475
    -250 -477
    -245 -479
    -241 -482
    -236 -484
    -231 -486
    -227 -488
    -222 -490
    -217 -492
    -212 -494
    -207 -496
    -202 -498
    -196 -500
    -191 -502
    -186 -503
    -180 -505
    -175 -507
    -169 -508
    -164 -510
    -158 -511
    -153 -513
    -147 -514
    -141 -515
    -135 -517
    -129 -518
    -124 -519
    -118 -520
    -112 -521
    -106 -522
    -100 -523
    -94 -524
    -87 -525
    -81 -525
    -75 -526
    -69 -527
    -63 -527
    -57 -528
    -50 -528
    -44 -529
    -38 -529
    -32 -530
    -25 -530
    -19 -530
    -13 -530
    -6 -530
    0 -530
    6 -530
    13 -530
    19 -530
    25 -530
    32 -530
    38 -529
    44 -529
    50 -528
    57 -528
    63 -527
    69 -527
    75 -526
    81 -525
    87 -525
    94 -524
    100 -523
    106 -522
    112 -521
    118 -520
    124 -519
    129 -518
    135 -517
    141 -515
    147 -514
    153 -513
    158 -511
    164 -510
    169 -508
    175 -507
    180 -505
    186 -503
    191 -502
    196 -500
    202 -498
    207 -496
    212 -494
    217 -492
    222 -490
    227 -488
    231 -486
    236 -484
    241 -482
    245 -479
    250 -477
    254 -475
    259 -472
    263 -470
    267 -467
    271 -465
    275 -462
    279 -459
    283 -457
    286 -454
    290 -451
    293 -448
    297 -445
    300 -442
    303 -439
    306 -436
    309 -433
    312 -430
    315 -427
    318 -424
    321 -421
    323 -417
    325 -414
    328 -411
    330 -407
    332 -404
    334 -401
    336 -397
    337 -394
    339 -390
    340 -386
    342 -383
    343 -379
    344 -375
    345 -372
    346 -368
    347 -364
    347 -360
    348 -356
    348 -352
    349 -349
    349 -345
    349 -341
    349 -337
    348 -333
    348 -328
    348 -324
    347 -320
    346 -316
    345 -312
    344 -308
    343 -303
    342 -299
    341 -295
    339 -291
    337 -286
    336 -282
    334 -278
    332 -273
    329 -269
    327 -264
    325 -260
    322 -255
    319 -251
    317 -246
    314 -242
    311 -237
    307 -233
    304 -228
    301 -223
    297 -219
    293 -214
    289 -209
    285 -205
    281 -200
    277 -195
    272 -191
    268 -186
    263 -181
    258 -176
    253 -172
    248 -167
    243 -162
    238 -157
    232 -152
    227 -148
    221 -143
    215 -138
    209 -133
    203 -128
    196 -123
    190 -118
    184 -113
    177 -108
    170 -104
    163 -99
    156 -94
    149 -89
    142 -84
    134 -79
    127 -74
    119 -69
    111 -64
    103 -59
    95 -54
    87 -49
    79 -44
    70 -39
    62 -34
    53 -29
    44 -24
    35 -19
    26 -14
    17 -9
    8 -4
    -2 1
    -11 6
    -21 11
    -31 16
    -41 21
    -51 26
    -61 31
    -71 36
    -82 41
    -92 46
    -103 51
    -114 56
    -125 61
    -136 66
    -147 71
    -158 76
    -169 81
    -181 86
    -192 91
    -204 96
    -216 101
    -227 106
    -239 111
    -252 116
    -264 121
    -276 126
    -289 131
    -301 136
    -314 141
    -327 146
    -339 151
    -352 156
    -366 161
    -379 166
    -392 171
    -405 176
    -419 180
    -433 185
    -446 190
    -460 195
    -474 200
    -488 205
    -502 210
    -516 215
    -531 220
    -545 224
    -560 229
    -574 234
    -589 239
    -604 244
    -619 249
    -634 253
    -649 258
    -664 263
    -679 268
    -695 273
    -710 277
    -726 282
    -741 287
    -757 292
    -773 296
    -789 301
    -805 306
    -821 311
    -837 315
    -854 320
    -870 325
    -886 329
    -903 334
    -920 339
    -936 343
    -953 348
    -970 353
    -987 357
    -1004 362
    -1021 367
    -1039 371
    -1056 376
    -1073 380
    -1091 385
    -1108 390
    -1126 394
    1121 388
    1104 383
    1086 379
    1069 374
    1051 370
    1034 365
    1017 361
    1000 356
    983 352
    966 347
    949 342
    932 338
    915 333
    898 328
    882 324
    865 319
    849 315
    833 310
    816 305
    800 301
    784 296
    768 291
    752 286
    737 282
    721 277
    705 272
    690 268
    675 263
    659 258
    644 253
    629 249
    614 244
    599 239
    584 234
    569 229
    555 225
    540 220
    526 215
    512 210
    497 205
    483 201
    469 196
    455 191
    441 186
    428 181
    414 176
    401 171
    387 166
    374 162
    361 157
    348 152
    335 147
    322 142
    309 137
    296 132
    284 127
    271 122
    259 117
    247 112
    235 108
    223 103
    211 98
    199 93
    187 88
    176 83
    164 78
    153 73
    142 68
    131 63
    120 58
    109 53
    98 48
    87 43
    77 38
    66 33
    56 28
    46 23
    36 18
    26 13
    16 8
    6 3
    -3 -2
    -13 -7
    -22 -12
    -31 -16
    -40 -21
    -49 -26
    -58 -31
    -67 -36
    -75 -41
    -84 -46
    -92 -51
    -100 -56
    -108 -61
    -116 -66
    -124 -71
    -132 -76
    -139 -81
    -147 -86
    -154 -91
    -161 -95
    -168 -100
    -175 -105
    -182 -110
    -188 -115
    -195 -120
    -201 -125
    -208 -130
    -214 -134
    -220 -139
    -226 -144
    -231 -149
    -237 -154
    -242 -158
    -248 -163
    -253 -168
    -258 -173
    -263 -177
    -268 -182
    -273 -187
    -277 -192
    -281 -196
    -286 -201
    -290 -206
    -294 -210
    -298 -215
    -302 -220
    -305 -224
    -309 -229
    -312 -233
    -315 -238
    -318 -242
    -321 -247
    -324 -251
    -327 -256
    -329 -260
    -332 -265
    -334 -269
    -336 -273
    -338 -278
    -340 -282
    -342 -286
    -343 -291
    -345 -295
    -346 -299
    -347 -304
    -349 -308
    -349 -312
    -350 -316
    -351 -320
    -352 -324
    -352 -328
    -352 -332
    -353 -336
    -353 -340
    -353 -344
    -352 -348
    -352 -352
    -352 -356
    -351 -360
    -351 -364
    -350 -367
    -349 -371
    -348 -375
    -347 -379
    -345 -382
    -344 -386
    -342 -389
    -341 -393
    -339 -396
    -337 -400
    -335 -403
    -333 -407
    -331 -410
    -329 -413
    -326 -417
    -324 -420
    -321 -423
    -318 -426
    -316 -429
    -313 -432
    -310 -435
    -306 -438
    -303 -441
    -300 -444
    -296 -447
    -293 -450
    -289 -453
    -285 -455
    -282 -458
    -278 -461
    -274 -463
    -269 -466
    -265 -468
    -261 -471
    -257 -473
    -252 -476
    -248 -478
    -243 -480
    -238 -482
    -234 -485
    -229 -487
    -224 -489
    -219 -491
    -214 -493
    -209 -495
    -203 -497
    -198 -498
    -193 -500
    -187 -502
    -182 -504
    -177 -505
    -171 -507
    -165 -508
    -160 -510
    -154 -511
    -148 -513
    -142 -514
    -137 -515
    -131 -516
    -125 -517
    -119 -519
    -113 -520
    -107 -521
    -101 -521
    -94 -522
    -88 -523
    -82 -524
    -76 -525
    -70 -525
    -63 -526
    -57 -526
    -51 -527
    -44 -527
    -38 -528
    -32 -528
    -25 -528
    -19 -528
    -13 -528
    -6 -529
    0 -529
    6 -529
    13 -528
    19 -528
    25 -528
    32 -528
    38 -528
    44 -527
    51 -527
    57 -526
    63 -526
    70 -525
    76 -525
    82 -524
    88 -523
    94 -522
    101 -521
    107 -521
    113 -520
    119 -519
    125 -517
    131 -516
    137 -515
    142 -514
    148 -513
    154 -511
    160 -510
    165 -508
    171 -507
    177 -505
    182 -504
    187 -502
    193 -500
    198 -498
    203 -497
    209 -495
    214 -493
    219 -491
    224 -489
    229 -487
    234 -485
    238 -482
    243 -480
    248 -478
    252 -476
    257 -473
    261 -471
    265 -468
    269 -466
    274 -463
    278 -461
    282 -458
    285 -455
    289 -453
    293 -450
    296 -447
    300 -444
    303 -441
    306 -438
    310 -435
    313 -432
    316 -429
    318 -426
    321 -423
    324 -420
    326 -417
    329 -413
    331 -410
    333 -407
    335 -403
    337 -400
    339 -396
    341 -393
    342 -389
    344 -386
    345 -382
    347 -379
    348 -375
    349 -371
    350 -367
    351 -364
    351 -360
    352 -356
    352 -352
    352 -348
    353 -344
    353 -340
    353 -336
    352 -332
    352 -328
    352 -324
    351 -320
    350 -316
    349 -312
    349 -308
    347 -304
    346 -299
    345 -295
    343 -291
    342 -286
    340 -282
    338 -278
    336 -273
    334 -269
    332 -265
    329 -260
    327 -256
    324 -251
    321 -247
    318 -242
    315 -238
    312 -233
    309 -229
    305 -224
    302 -220
    298 -215
    294 -210
    290 -206
    286 -201
    281 -196
    277 -192
    273 -187
    268 -182
    263 -177
    258 -173
    253 -168
    248 -163
    242 -158
    237 -154
    231 -149
    226 -144
    220 -139
    214 -134
    208 -130
    201 -125
    195 -120
    188 -115
    182 -110
    175 -105
    168 -100
    161 -95
    154 -91
    147 -86
    139 -81
    132 -76
    124 -71
    116 -66
    108 -61
    100 -56
    92 -51
    84 -46
    75 -41
    67 -36
    58 -31
    49 -26
    40 -21
    31 -16
    22 -12
    13 -7
    3 -2
    -6 3
    -16 8
    -26 13
    -36 18
    -46 23
    -56 28
    -66 33
    -77 38
    -87 43
    -98 48
    -109 53
    -120 58
    -131 63
    -142 68
    -153 73
    -164 78
    -176 83
    -187 88
    -199 93
    -211 98
    -223 103
    -235 108
    -247 112
    -259 117
    -271 122
    -284 127
    -296 132
    -309 137
    -322 142
    -335 147
    -348 152
    -361 157
    -374 162
    -387 166
    -401 171
    -414 176
    -428 181
    -441 186
    -455 191
    -469 196
    -483 201
    -497 205
    -512 210
    -526 215
    -540 220
    -555 225
    -569 229
    -584 234
    -599 239
    -614 244
    -629 249
    -644 253
    -659 258
    -675 263
    -690 268
    -705 272
    -721 277
    -737 282
    -752 286
    -768 291
    -784 296
    -800 301
    -816 305
    -833 310
    -849 315
    -865 319
    -882 324
    -898 328
    -915 333
    -932 338
    -949 342
    -966 347
    -983 352
    -1000 356
    -1017 361
    -1034 365
    -1051 370
    -1069 374
    -1086 379
    -1104 383
    -1121 388
    1117 382
    1099 377
    1082 373
    1064 368
    1047 364
    1029 359
    1012 355
    995 350
    978 346
    961 341
    944 337
    927 332
    910 327
    894 323
    877 318
    861 314
    844 309
    828 304
    812 300
    796 295
    780 291
    764 286
    748 281
    732 277
    716 272
    701 267
    685 263
    670 258
    655 253
    639 248
    624 244
    609 239
    594 234
    579 230
    565 225
    550 220
    536 215
    521 210
    507 206
    492 201
    478 196
    464 191
    450 187
    437 182
    423 177
    409 172
    396 167
    382 162
    369 158
    356 153
    343 148
    330 143
    317 138
    304 133
    291 128
    279 124
    266 119
    254 114
    242 109
    230 104
    218 99
    206 94
    194 89
    182 84
    171 80
    159 75
    148 70
    137 65
    126 60
    115 55
    104 50
    93 45
    82 40
    72 35
    61 30
    51 25
    41 20
    31 16
    21 11
    11 6
    2 1
    -8 -4
    -17 -9
    -27 -14
    -36 -19
    -45 -24
    -54 -29
    -63 -34
    -71 -39
    -80 -43
    -88 -48
    -97 -53
    -105 -58
    -113 -63
    -121 -68
    -129 -73
    -136 -78
    -144 -83
    -151 -87
    -159 -92
    -166 -97
    -173 -102
    -180 -107
    -187 -112
    -193 -117
    -200 -121
    -206 -126
    -212 -131
    -219 -136
    -225 -141
    -230 -145
    -236 -150
    -242 -155
    -247 -160
    -253 -164
    -258 -169
    -263 -174
    -268 -178
    -273 -183
    -277 -188
    -282 -193
    -286 -197
    -290 -202
    -295 -206
    -299 -211
    -302 -216
    -306 -220
    -310 -225
    -313 -229
    -316 -234
    -320 -238
    -323 -243
    -326 -247
    -328 -252
    -331 -256
    -334 -261
    -336 -265
    -338 -269
    -340 -274
    -342 -278
    -344 -282
    -346 -287
    -348 -291
    -349 -295
    -350 -299
    -352 -303
    -353 -308
    -354 -312
    -354 -316
    -355 -320
    -356 -324
    -356 -328
    -356 -332
    -357 -336
    -357 -340
    -357 -344
    -356 -348
    -356 -352
    -356 -356
    -355 -359
    -354 -363
    -353 -367
    -353 -371
    -351 -374
    -350 -378
    -349 -382
    -348 -385
    -346 -389
    -344 -392
    -343 -396
    -341 -399
    -339 -402
    -337 -406
    -334 -409
    -332 -412
    -329 -416
    -327 -419
    -324 -422
    -321 -425
    -319 -428
    -316 -431
    -313 -434
    -309 -437
    -306 -440
    -303 -443
    -299 -446
    -296 -449
    -292 -452
    -288 -454
    -284 -457
    -280 -460
    -276 -462
    -272 -465
    -268 -467
    -263 -470
    -259 -472
    -255 -474
    -250 -477
    -245 -479
    -241 -481
    -236 -483
    -231 -485
    -226 -487
    -221 -489
    -216 -491
    -211 -493
    -205 -495
    -200 -497
    -195 -499
    -189 -500
    -184 -502
    -178 -504
    -173 -505
    -167 -507
    -161 -508
    -155 -510
    -150 -511
    -144 -512
    -138 -513
    -132 -515
    -126 -516
    -120 -517
    -114 -518
    -108 -519
    -101 -520
    -95 -521
    -89 -521
    -83 -522
    -77 -523
    -70 -523
    -64 -524
    -58 -525
    -51 -525
    -45 -525
    -38 -526
    -32 -526
    -26 -526
    -19 -527
    -13 -527
    -6 -527
    0 -527
    6 -527
    13 -527
    19 -527
    26 -526
    32 -526
    38 -526
    45 -525
    51 -525
    58 -525
    64 -524
    70 -523
    77 -523
    83 -522
    89 -521
    95 -521
    101 -520
    108 -519
    114 -518
    120 -517
    126 -516
    132 -515
    138 -513
    144 -512
    150 -511
    155 -510
    161 -508
    167 -507
    173 -505
    178 -504
    184 -502
    189 -500
    195 -499
    200 -497
    205 -495
    211 -493
    216 -491
    221 -489
    226 -487
    231 -485
    236 -483
    241 -481
    245 -479
    250 -477
    255 -474
    259 -472
    263 -470
    268 -467
    272 -465
    276 -462
    280 -460
    284 -457
    288 -454
    292 -452
    296 -449
    299 -446
    303 -443
    306 -440
    309 -437
    313 -434
    316 -431
    319 -428
    321 -425
    324 -422
    327 -419
    329 -416
    332 -412
    334 -409
    337 -406
    339 -402
    341 -399
    343 -396
    344 -392
    346 -389
    348 -385
    349 -382
    350 -378
    351 -374
    353 -371
    353 -367
    354 -363
    355 -359
    356 -356
    356 -352
    356 -348
    357 -344
    357 -340
    357 -336
    356 -332
    356 -328
    356 -324
    355 -320
    354 -316
    354 -312
    353 -308
    352 -303
    350 -299
    349 -295
    348 -291
    346 -287
    344 -282
    342 -278
    340 -274
    338 -269
    336 -265
    334 -261
    331 -256
    328 -252
    326 -247
    323 -243
    320 -238
    316 -234
    313 -229
    310 -225
    306 -220
    302 -216
    299 -211
    295 -206
    290 -202
    286 -197
    282 -193
    277 -188
    273 -183
    268 -178
    263 -174
    258 -169
    253 -164
    247 -160
    242 -155
    236 -150
    230 -145
    225 -141
    219 -136
    212 -131
    206 -126
    200 -121
    193 -117
    187 -112
    180 -107
    173 -102
    166 -97
    159 -92
    151 -87
    144 -83
    136 -78
    129 -73
    121 -68
    113 -63
    105 -58
    97 -53
    88 -48
    80 -43
    71 -39
    63 -34
    54 -29
    45 -24
    36 -19
    27 -14
    17 -9
    8 -4
    -2 1
    -11 6
    -21 11
    -31 16
    -41 20
    -51 25
    -61 30
    -72 35
    -82 40
    -93 45
    -104 50
    -115 55
    -126 60
    -137 65
    -148 70
    -159 75
    -171 80
    -182 84
    -194 89
    -206 94
    -218 99
    -230 104
    -242 109
    -254 114
    -266 119
    -279 124
    -291 128
    -304 133
    -317 138
    -330 143
    -343 148
    -356 153
    -369 158
    -382 162
    -396 167
    -409 172
    -423 177
    -437 182
    -450 187
    -464 191
    -478 196
    -492 201
    -507 206
    -521 210
    -536 215
    -550 220
    -565 225
    -579 230
    -594 234
    -609 239
    -624 244
    -639 248
    -655 253
    -670 258
    -685 263
    -701 267
    -716 272
    -732 277
    -748 281
    -764 286
    -780 291
    -796 295
    -812 300
    -828 304
    -844 309
    -861 314
    -877 318
    -894 323
    -910 327
    -927 332
    -944 337
    -961 341
    -978 346
    -995 350
    -1012 355
    -1029 359
    -1047 364
    -1064 368
    -1082 373
    -1099 377
    -1117 382
    1113 375
    1095 371
    1077 367
    1060 362
    1042 358
    1025 353
    1008 349
    991 344
    973 340
    956 335
    939 331
    923 326
    906 322
    889 317
    873 313
    856 308
    840 304
    823 299
    807 294
    791 290
    775 285
    759 281
    743 276
    727 271
    712 267
    696 262
    681 258
    665 253
    650 248
    635 244
    619 239
    604 234
    590 230
    575 225
    560 220
    545 215
    531 211
    516 206
    502 201
    488 197
    474 192
    460 187
    446 182
    432 178
    418 173
    404 168
    391 163
    377 158
    364 154
    351 149
    338 144
    325 139
    312 134
    299 130
    286 125
    274 120
    261 115
    249 110
    237 105
    225 101
    213 96
    201 91
    189 86
    177 81
    166 76
    154 71
    143 67
    132 62
    121 57
    110 52
    99 47
    88 42
    77 37
    67 32
    57 28
    46 23
    36 18
    26 13
    16 8
    6 3
    -3 -2
    -13 -7
    -22 -11
    -32 -16
    -41 -21
    -50 -26
    -59 -31
    -68 -36
    -76 -41
    -85 -46
    -93 -50
    -102 -55
    -110 -60
    -118 -65
    -126 -70
    -134 -75
    -141 -80
    -149 -84
    -156 -89
    -164 -94
    -171 -99
    -178 -104
    -185 -108
    -191 -113
    -198 -118
    -205 -123
    -211 -128
    -217 -132
    -223 -137
    -229 -142
    -235 -147
    -241 -151
    -246 -156
    -252 -161
    -257 -165
    -262 -170
    -267 -175
    -272 -179
    -277 -184
    -282 -189
    -286 -193
    -291 -198
    -295 -202
    -299 -207
    -303 -212
    -307 -216
    -311 -221
    -314 -225
    -318 -230
    -321 -234
    -324 -239
    -327 -243
    -330 -248
    -333 -252
    -336 -256
    -338 -261
    -340 -265
    -343 -269
    -345 -274
    -347 -278
    -349 -282
    -350 -287
    -352 -291
    -353 -295
    -355 -299
    -356 -303
    -357 -307
    -358 -312
    -359 -316
    -359 -320
    -360 -324
    -360 -328
    -360 -332
    -361 -336
    -361 -340
    -360 -343
    -360 -347
    -360 -351
    -359 -355
    -359 -359
    -358 -363
    -357 -366
    -356 -370
    -355 -374
    -354 -377
    -353 -381
    -351 -384
    -349 -388
    -348 -391
    -346 -395
    -344 -398
    -342 -401
    -340 -405
    -338 -408
    -335 -411
    -333 -415
    -330 -418
    -327 -421
    -325 -424
    -322 -427
    -319 -430
    -315 -433
    -312 -436
    -309 -439
    -305 -442
    -302 -445
    -298 -447
    -295 -450
    -291 -453
    -287 -456
    -283 -458
    -279 -461
    -274 -463
    -270 -466
    -266 -468
    -261 -470
    -257 -473
    -252 -475
    -247 -477
    -243 -479
    -238 -482
    -233 -484
    -228 -486
    -223 -488
    -218 -490
    -212 -492
    -207 -493
    -202 -495
    -196 -497
    -191 -499
    -185 -500
    -180 -502
    -174 -503
    -168 -505
    -163 -506
    -157 -508
    -151 -509
    -145 -510
    -139 -512
    -133 -513
    -127 -514
    -121 -515
    -115 -516
    -108 -517
    -102 -518
    -96 -519
    -90 -519
    -83 -520
    -77 -521
    -71 -522
    -64 -522
    -58 -523
    -52 -523
    -45 -524
    -39 -524
    -32 -524
    -26 -524
    -19 -525
    -13 -525
    -6 -525
    0 -525
    6 -525
    13 -525
    19 -525
    26 -524
    32 -524
    39 -524
    45 -524
    52 -523
    58 -523
    64 -522
    71 -522
    77 -521
    83 -520
    90 -519
    96 -519
    102 -518
    108 -517
    115 -516
    121 -515
    127 -514
    133 -513
    139 -512
    145 -510
    151 -509
    157 -508
    163 -506
    168 -505
    174 -503
    180 -502
    185 -500
    191 -499
    196 -497
    202 -495
    207 -493
    212 -492
    218 -490
    223 -488
    228 -486
    233 -484
    238 -482
    243 -479
    247 -477
    252 -475
    257 -473
    261 -470
    266 -468
    270 -466
    274 -463
    279 -461
    283 -458
    287 -456
    291 -453
    295 -450
    298 -447
    302 -445
    305 -442
    309 -439
    312 -436
    315 -433
    319 -430
    322 -427
    325 -424
    327 -421
    330 -418
    333 -415
    335 -411
    338 -408
    340 -405
    342 -401
    344 -398
    346 -395
    348 -391
    349 -388
    351 -384
    353 -381
    354 -377
    355 -374
    356 -370
    357 -366
    358 -363
    359 -359
    359 -355
    360 -351
    360 -347
    360 -343
    361 -340
    361 -336
    360 -332
    360 -328
    360 -324
    359 -320
    359 -316
    358 -312
    357 -307
    356 -303
    355 -299
    353 -295
    352 -291
    350 -287
    349 -282
    347 -278
    345 -274
    343 -269
    340 -265
    338 -261
    336 -256
    333 -252
    330 -248
    327 -243
    324 -239
    321 -234
    318 -230
    314 -225
    311 -221
    307 -216
    303 -212
    299 -207
    295 -202
    291 -198
    286 -193
    282 -189
    277 -184
    272 -179
    267 -175
    262 -170
    257 -165
    252 -161
    246 -156
    241 -151
    235 -147
    229 -142
    223 -137
    217 -132
    211 -128
    205 -123
    198 -118
    191 -113
    185 -108
    178 -104
    171 -99
    164 -94
    156 -89
    149 -84
    141 -80
    134 -75
    126 -70
    118 -65
    110 -60
    102 -55
    93 -50
    85 -46
    76 -41
    68 -36
    59 -31
    50 -26
    41 -21
    32 -16
    22 -11
    13 -7
    3 -2
    -6 3
    -16 8
    -26 13
    -36 18
    -46 23
    -57 28
    -67 32
    -77 37
    -88 42
    -99 47
    -110 52
    -121 57
    -132 62
    -143 67
    -154 71
    -166 76
    -177 81
    -189 86
    -201 91
    -213 96
    -225 101
    -237 105
    -249 110
    -261 115
    -274 120
    -286 125
    -299 130
    -312 134
    -325 139
    -338 144
    -351 149
    -364 154
    -377 158
    -391 163
    -404 168
    -418 173
    -432 178
    -446 182
    -460 187
    -474 192
    -488 197
    -502 201
    -516 206
    -531 211
    -545 215
    -560 220
    -575 225
    -590 230
    -604 234
    -619 239
    -635 244
    -650 248
    -665 253
    -681 258
    -696 262
    -712 267
    -727 271
    -743 276
    -759 281
    -775 285
    -791 290
    -807 294
    -823 299
    -840 304
    -856 308
    -873 313
    -889 317
    -906 322
    -923 326
    -939 331
    -956 335
    -973 340
    -991 344
    -1008 349
    -1025 353
    -1042 358
    -1060 362
    -1077 367
    -1095 371
    -1113 375
    1108 369
    1090 365
    1073 361
    1055 356
    1038 352
    1021 347
    1003 343
    986 339
    969 334
    952 330
    935 325
    918 321
    901 316
    885 312
    868 307
    852 303
    835 298
    819 294
    803 289
    786 285
    770 280
    754 276
    739 271
    723 266
    707 262
    691 257
    676 253
    661 248
    645 243
    630 239
    615 234
    600 230
    585 225
    570 220
    555 216
    541 211
    526 206
    512 202
    497 197
    483 192
    469 188
    455 183
    441 178
    427 173
    413 169
    400 164
    386 159
    373 154
    359 150
    346 145
    333 140
    320 135
    307 131
    294 126
    282 121
    269 116
    257 112
    244 107
    232 102
    220 97
    208 92
    196 88
    184 83
    173 78
    161 73
    150 68
    138 64
    127 59
    116 54
    105 49
    94 44
    83 39
    73 35
    62 30
    52 25
    41 20
    31 15
    21 10
    11 6
    1 1
    -8 -4
    -18 -9
    -27 -14
    -37 -19
    -46 -23
    -55 -28
    -64 -33
    -73 -38
    -81 -43
    -90 -48
    -98 -52
    -107 -57
    -115 -62
    -123 -67
    -131 -72
    -138 -76
    -146 -81
    -154 -86
    -161 -91
    -168 -96
    -176 -100
    -183 -105
    -189 -110
    -196 -115
    -203 -119
    -209 -124
    -216 -129
    -222 -134
    -228 -138
    -234 -143
    -240 -148
    -246 -152
    -251 -157
    -257 -162
    -262 -166
    -267 -171
    -272 -176
    -277 -180
    -282 -185
    -286 -189
    -291 -194
    -295 -199
    -300 -203
    -304 -208
    -308 -212
    -311 -217
    -315 -221
    -319 -226
    -322 -230
    -325 -235
    -329 -239
    -332 -243
    -334 -248
    -337 -252
    -340 -257
    -342 -261
    -345 -265
    -347 -269
    -349 -274
    -351 -278
    -353 -282
    -354 -286
    -356 -291
    -357 -295
    -359 -299
    -360 -303
    -361 -307
    -362 -311
    -363 -315
    -363 -319
    -364 -323
    -364 -327
    -364 -331
    -364 -335
    -364 -339
    -364 -343
    -364 -347
    -364 -351
    -363 -354
    -363 -358
    -362 -362
    -361 -365
    -360 -369
    -359 -373
    -357 -376
    -356 -380
    -355 -383
    -353 -387
    -351 -390
    -349 -394
    -347 -397
    -345 -400
    -343 -404
    -341 -407
    -338 -410
    -336 -413
    -333 -417
    -331 -420
    -328 -423
    -325 -426
    -322 -429
    -318 -432
    -315 -435
    -312 -438
    -308 -440
    -305 -443
    -301 -446
    -297 -449
    -293 -451
    -289 -454
    -285 -457
    -281 -459
    -277 -462
    -273 -464
    -268 -466
    -264 -469
    -259 -471
    -254 -473
    -250 -476
    -245 -478
    -240 -480
    -235 -482
    -230 -484
    -225 -486
    -220 -488
    -214 -490
    -209 -492
    -204 -493
    -198 -495
    -193 -497
    -187 -498
    -181 -500
    -176 -502
    -170 -503
    -164 -504
    -158 -506
    -152 -507
    -146 -508
    -140 -510
    -134 -511
    -128 -512
    -122 -513
    -116 -514
    -109 -515
    -103 -516
    -97 -517
    -91 -517
    -84 -518
    -78 -519
    -71 -520
    -65 -520
    -59 -521
    -52 -521
    -46 -521
    -39 -522
    -33 -522
    -26 -522
    -20 -523
    -13 -523
    -7 -523
    0 -523
    7 -523
    13 -523
    20 -523
    26 -522
    33 -522
    39 -522
    46 -521
    52 -521
    59 -521
    65 -520
    71 -520
    78 -519
    84 -518
    91 -517
    97 -517
    103 -516
    109 -515
    116 -514
    122 -513
    128 -512
    134 -511
    140 -510
    146 -508
    152 -507
    158 -506
    164 -504
    170 -503
    176 -502
    181 -500
    187 -498
    193 -497
    198 -495
    204 -493
    209 -492
    214 -490
    220 -488
    225 -486
    230 -484
    235 -482
    240 -480
    245 -478
    250 -476
    254 -473
    259 -471
    264 -469
    268 -466
    273 -464
    277 -462
    281 -459
    285 -457
    289 -454
    293 -451
    297 -449
    301 -446
    305 -443
    308 -440
    312 -438
    315 -435
    318 -432
    322 -429
    325 -426
    328 -423
    331 -420
    333 -417
    336 -413
    338 -410
    341 -407
    343 -404
    345 -400
    347 -397
    349 -394
    351 -390
    353 -387
    355 -383
    356 -380
    357 -376
    359 -373
    360 -369
    361 -365
    362 -362
    363 -358
    363 -354
    364 -351
    364 -347
    364 -343
    364 -339
    364 -335
    364 -331
    364 -327
    364 -323
    363 -319
    363 -315
    362 -311
    361 -307
    360 -303
    359 -299
    357 -295
    356 -291
    354 -286
    353 -282
    351 -278
    349 -274
    347 -269
    345 -265
    342 -261
    340 -257
    337 -252
    334 -248
    332 -243
    329 -239
    325 -235
    322 -230
    319 -226
    315 -221
    311 -217
    308 -212
    304 -208
    300 -203
    295 -199
    291 -194
    286 -189
    282 -185
    277 -180
    272 -176
    267 -171
    262 -166
    257 -162
    251 -157
    246 -152
    240 -148
    234 -143
    228 -138
    222 -134
    216 -129
    209 -124
    203 -119
    196 -115
    189 -110
    183 -105
    176 -100
    168 -96
    161 -91
    154 -86
    146 -81
    138 -76
    131 -72
    123 -67
    115 -62
    107 -57
    98 -52
    90 -48
    81 -43
    73 -38
    64 -33
    55 -28
    46 -23
    37 -19
    27 -14
    18 -9
    8 -4
    -1 1
    -11 6
    -21 10
    -31 15
    -41 20
    -52 25
    -62 30
    -73 35
    -83 39
    -94 44
    -105 49
    -116 54
    -127 59
    -138 64
    -150 68
    -161 73
    -173 78
    -184 83
    -196 88
    -208 92
    -220 97
    -232 102
    -244 107
    -257 112
    -269 116
    -282 121
    -294 126
    -307 131
    -320 135
    -333 140
    -346 145
    -359 150
    -373 154
    -386 159
    -400 164
    -413 169
    -427 173
    -441 178
    -455 183
    -469 188
    -483 192
    -497 197
    -512 202
    -526 206
    -541 211
    -555 216
    -570 220
    -585 225
    -600 230
    -615 234
    -630 239
    -645 243
    -661 248
    -676 253
    -691 257
    -707 262
    -723 266
    -739 271
    -754 276
    -770 280
    -786 285
    -803 289
    -819 294
    -835 298
    -852 303
    -868 307
    -885 312
    -901 316
    -918 321
    -935 325
    -952 330
    -969 334
    -986 339
    -1003 343
    -1021 347
    -1038 352
    -1055 356
    -1073 361
    -1090 365
    -1108 369
    1104 363
    1086 359
    1069 355
    1051 350
    1034 346
    1016 342
    999 337
    982 333
    965 328
    948 324
    931 320
    914 315
    897 311
    880 306
    864 302
    847 297
    831 293
    814 288
    798 284
    782 280
    766 275
    750 270
    734 266
    718 261
    702 257
    687 252
    671 248
    656 243
    641 239
    625 234
    610 230
    595 225
    580 220
    565 216
    551 211
    536 207
    521 202
    507 197
    493 193
    478 188
    464 183
    450 179
    436 174
    422 169
    409 165
    395 160
    381 155
    368 151
    355 146
    341 141
    328 137
    315 132
    302 127
    290 122
    277 118
    264 113
    252 108
    240 103
    227 99
    215 94
    203 89
    191 84
    179 80
    168 75
    156 70
    145 65
    133 61
    122 56
    111 51
    100 46
    89 41
    78 37
    68 32
    57 27
    47 22
    37 18
    26 13
    16 8
    6 3
    -3 -2
    -13 -6
    -23 -11
    -32 -16
    -41 -21
    -51 -26
    -60 -30
    -69 -35
    -77 -40
    -86 -45
    -95 -49
    -103 -54
    -111 -59
    -119 -64
    -128 -69
    -135 -73
    -143 -78
    -151 -83
    -158 -88
    -166 -92
    -173 -97
    -180 -102
    -187 -106
    -194 -111
    -201 -116
    -208 -121
    -214 -125
    -220 -130
    -227 -135
    -233 -139
    -239 -144
    -245 -149
    -250 -153
    -256 -158
    -261 -163
    -267 -167
    -272 -172
    -277 -176
    -282 -181
    -286 -185
    -291 -190
    -296 -195
    -300 -199
    -304 -204
    -308 -208
    -312 -213
    -316 -217
    -320 -221
    -323 -226
    -327 -230
    -330 -235
    -333 -239
    -336 -244
    -339 -248
    -342 -252
    -344 -257
    -347 -261
    -349 -265
    -351 -269
    -353 -274
    -355 -278
    -357 -282
    -359 -286
    -360 -290
    -362 -294
    -363 -299
    -364 -303
    -365 -307
    -366 -311
    -367 -315
    -367 -319
    -368 -323
    -368 -327
    -368 -331
    -368 -334
    -368 -338
    -368 -342
    -368 -346
    -367 -350
    -367 -353
    -366 -357
    -365 -361
    -364 -364
    -363 -368
    -362 -372
    -361 -375
    -360 -379
    -358 -382
    -356 -386
    -355 -389
    -353 -393
    -351 -396
    -349 -399
    -346 -402
    -344 -406
    -342 -409
    -339 -412
    -336 -415
    -334 -418
    -331 -421
    -328 -424
    -325 -427
    -321 -430
    -318 -433
    -315 -436
    -311 -439
    -307 -442
    -304 -444
    -300 -447
    -296 -450
    -292 -452
    -288 -455
    -284 -457
    -279 -460
    -275 -462
    -271 -465
    -266 -467
    -261 -469
    -257 -472
    -252 -474
    -247 -476
    -242 -478
    -237 -480
    -232 -482
    -227 -484
    -221 -486
    -216 -488
    -211 -490
    -205 -491
    -200 -493
    -194 -495
    -189 -496
    -183 -498
    -177 -500
    -171 -501
    -165 -502
    -159 -504
    -153 -505
    -147 -506
    -141 -508
    -135 -509
    -129 -510
    -123 -511
    -117 -512
    -110 -513
    -104 -514
    -98 -515
    -91 -515
    -85 -516
    -78 -517
    -72 -517
    -66 -518
    -59 -518
    -53 -519
    -46 -519
    -39 -520
    -33 -520
    -26 -520
    -20 -520
    -13 -521
    -7 -521
    0 -521
    7 -521
    13 -521
    20 -520
    26 -520
    33 -520
    39 -520
    46 -519
    53 -519
    59 -518
    66 -518
    72 -517
    78 -517
    85 -516
    91 -515
    98 -515
    104 -514
    110 -513
    117 -512
    123 -511
    129 -510
    135 -509
    141 -508
    147 -506
    153 -505
    159 -504
    165 -502
    171 -501
    177 -500
    183 -498
    189 -496
    194 -495
    200 -493
    205 -491
    211 -490
    216 -488
    221 -486
    227 -484
    232 -482
    237 -480
    242 -478
    247 -476
    252 -474
    257 -472
    261 -469
    266 -467
    271 -465
    275 -462
    279 -460
    284 -457
    288 -455
    292 -452
    296 -450
    300 -447
    304 -444
    307 -442
    311 -439
    315 -436
    318 -433
    321 -430
    325 -427
    328 -424
    331 -421
    334 -418
    336 -415
    339 -412
    342 -409
    344 -406
    346 -402
    349 -399
    351 -396
    353 -393
    355 -389
    356 -386
    358 -382
    360 -379
    361 -375
    362 -372
    363 -368
    364 -364
    365 -361
    366 -357
    367 -353
    367 -350
    368 -346
    368 -342
    368 -338
    368 -334
    368 -331
    368 -327
    368 -323
    367 -319
    367 -315
    366 -311
    365 -307
    364 -303
    363 -299
    362 -294
    360 -290
    359 -286
    357 -282
    355 -278
    353 -274
    351 -269
    349 -265
    347 -261
    344 -257
    342 -252
    339 -248
    336 -244
    333 -239
    330 -235
    327 -230
    323 -226
    320 -221
    316 -217
    312 -213
    308 -208
    304 -204
    300 -199
    296 -195
    291 -190
    286 -185
    282 -181
    277 -176
    272 -172
    267 -167
    261 -163
    256 -158
    250 -153
    245 -149
    239 -144
    233 -139
    227 -135
    220 -130
    214 -125
    208 -121
    201 -116
    194 -111
    187 -106
    180 -102
    173 -97
    166 -92
    158 -88
    151 -83
    143 -78
    135 -73
    128 -69
    119 -64
    111 -59
    103 -54
    95 -49
    86 -45
    77 -40
    69 -35
    60 -30
    51 -26
    41 -21
    32 -16
    23 -11
    13 -6
    3 -2
    -6 3
    -16 8
    -26 13
    -37 18
    -47 22
    -57 27
    -68 32
    -78 37
    -89 41
    -100 46
    -111 51
    -122 56
    -133 61
    -145 65
    -156 70
    -168 75
    -179 80
    -191 84
    -203 89
    -215 94
    -227 99
    -240 103
    -252 108
    -264 113
    -277 118
    -290 122
    -302 127
    -315 132
    -328 137
    -341 141
    -355 146
    -368 151
    -381 155
    -395 160
    -409 165
    -422 169
    -436 174
    -450 179
    -464 183
    -478 188
    -493 193
    -507 197
    -521 202
    -536 207
    -551 211
    -565 216
    -580 220
    -595 225
    -610 230
    -625 234
    -641 239
    -656 243
    -671 248
    -687 252
    -702 257
    -718 261
    -734 266
    -750 270
    -766 275
    -782 280
    -798 284
    -814 288
    -831 293
    -847 297
    -864 302
    -880 306
    -897 311
    -914 315
    -931 320
    -948 324
    -965 328
    -982 333
    -999 337
    -1016 342
    -1034 346
    -1051 350
    -1069 355
    -1086 359
    -1104 363
    1100 357
    1082 353
    1064 349
    1047 344
    1029 340
    1012 336
    995 332
    977 327
    960 323
    943 318
    926 314
    909 310
    893 305
    876 301
    859 297
    843 292
    826 288
    810 283
    794 279
    777 274
    761 270
    745 265
    729 261
    714 257
    698 252
    682 248
    667 243
    651 239
    636 234
    621 229
    606 225
    591 220
    576 216
    561 211
    546 207
    531 202
    517 198
    502 193
    488 188
    474 184
    460 179
    445 175
    432 170
    418 165
    404 161
    390 156
    377 151
    363 147
    350 142
    337 138
    324 133
    311 128
    298 124
    285 119
    272 114
    260 109
    247 105
    235 100
    223 95
    210 91
    198 86
    186 81
    175 77
    163 72
    151 67
    140 62
    129 58
    117 53
    106 48
    95 43
    84 39
    74 34
    63 29
    52 25
    42 20
    32 15
    22 10
    12 6
    2 1
    -8 -4
    -18 -9
    -27 -13
    -37 -18
    -46 -23
    -55 -28
    -64 -32
    -73 -37
    -82 -42
    -91 -47
    -99 -51
    -108 -56
    -116 -61
    -124 -65
    -132 -70
    -140 -75
    -148 -80
    -156 -84
    -163 -89
    -171 -94
    -178 -98
    -185 -103
    -192 -108
    -199 -112
    -206 -117
    -212 -122
    -219 -126
    -225 -131
    -231 -136
    -237 -140
    -243 -145
    -249 -150
    -255 -154
    -260 -159
    -266 -163
    -271 -168
    -276 -172
    -281 -177
    -286 -181
    -291 -186
    -296 -191
    -300 -195
    -304 -199
    -309 -204
    -313 -208
    -317 -213
    -320 -217
    -324 -222
    -328 -226
    -331 -230
    -334 -235
    -337 -239
    -340 -244
    -343 -248
    -346 -252
    -348 -256
    -351 -261
    -353 -265
    -355 -269
    -357 -273
    -359 -278
    -361 -282
    -363 -286
    -364 -290
    -366 -294
    -367 -298
    -368 -302
    -369 -306
    -370 -310
    -371 -314
    -371 -318
    -372 -322
    -372 -326
    -372 -330
    -372 -334
    -372 -338
    -372 -341
    -372 -345
    -371 -349
    -371 -353
    -370 -356
    -369 -360
    -368 -363
    -367 -367
    -366 -371
    -365 -374
    -363 -378
    -362 -381
    -360 -384
    -358 -388
    -356 -391
    -354 -395
    -352 -398
    -350 -401
    -347 -404
    -345 -408
    -342 -411
    -339 -414
    -337 -417
    -334 -420
    -331 -423
    -328 -426
    -324 -429
    -321 -432
    -317 -434
    -314 -437
    -310 -440
    -306 -443
    -303 -445
    -299 -448
    -295 -451
    -290 -453
    -286 -456
    -282 -458
    -277 -460
    -273 -463
    -268 -465
    -264 -467
    -259 -470
    -254 -472
    -249 -474
    -244 -476
    -239 -478
    -234 -480
    -229 -482
    -223 -484
    -218 -486
    -213 -488
    -207 -489
    -201 -491
    -196 -493
    -190 -494
    -184 -496
    -179 -497
    -173 -499
    -167 -500
    -161 -502
    -155 -503
    -149 -504
    -143 -505
    -136 -506
    -130 -508
    -124 -509
    -118 -510
    -111 -510
    -105 -511
    -98 -512
    -92 -513
    -86 -514
    -79 -514
    -73 -515
    -66 -516
    -60 -516
    -53 -517
    -46 -517
    -40 -517
    -33 -518
    -27 -518
    -20 -518
    -13 -518
    -7 -518
    0 -518
    7 -518
    13 -518
    20 -518
    27 -518
    33 -518
    40 -517
    46 -517
    53 -517
    60 -516
    66 -516
    73 -515
    79 -514
    86 -514
    92 -513
    98 -512
    105 -511
    111 -510
    118 -510
    124 -509
    130 -508
    136 -506
    143 -505
    149 -504
    155 -503
    161 -502
    167 -500
    173 -499
    179 -497
    184 -496
    190 -494
    196 -493
    201 -491
    207 -489
    213 -488
    218 -486
    223 -484
    229 -482
    234 -480
    239 -478
    244 -476
    249 -474
    254 -472
    259 -470
    264 -467
    268 -465
    273 -463
    277 -460
    282 -458
    286 -456
    290 -453
    295 -451
    299 -448
    303 -445
    306 -443
    310 -440
    314 -437
    317 -434
    321 -432
    324 -429
    328 -426
    331 -423
    334 -420
    337 -417
    339 -414
    342 -411
    345 -408
    347 -404
    350 -401
    352 -398
    354 -395
    356 -391
    358 -388
    360 -384
    362 -381
    363 -378
    365 -374
    366 -371
    367 -367
    368 -363
    369 -360
    370 -356
    371 -353
    371 -349
    372 -345
    372 -341
    372 -338
    372 -334
    372 -330
    372 -326
    372 -322
    371 -318
    371 -314
    370 -310
    369 -306
    368 -302
    367 -298
    366 -294
    364 -290
    363 -286
    361 -282
    359 -278
    357 -273
    355 -269
    353 -265
    351 -261
    348 -256
    346 -252
    343 -248
    340 -244
    337 -239
    334 -235
    331 -230
    328 -226
    324 -222
    320 -217
    317 -213
    313 -208
    309 -204
    304 -199
    300 -195
    296 -191
    291 -186
    286 -181
    281 -177
    276 -172
    271 -168
    266 -163
    260 -159
    255 -154
    249 -150
    243 -145
    237 -140
    231 -136
    225 -131
    219 -126
    212 -122
    206 -117
    199 -112
    192 -108
    185 -103
    178 -98
    171 -94
    163 -89
    156 -84
    148 -80
    140 -75
    132 -70
    124 -65
    116 -61
    108 -56
    99 -51
    91 -47
    82 -42
    73 -37
    64 -32
    55 -28
    46 -23
    37 -18
    27 -13
    18 -9
    8 -4
    -2 1
    -12 6
    -22 10
    -32 15
    -42 20
    -52 25
    -63 29
    -74 34
    -84 39
    -95 43
    -106 48
    -117 53
    -129 58
    -140 62
    -151 67
    -163 72
    -175 77
    -186 81
    -198 86
    -210 91
    -223 95
    -235 100
    -247 105
    -260 109
    -272 114
    -285 119
    -298 124
    -311 128
    -324 133
    -337 138
    -350 142
    -363 147
    -377 151
    -390 156
    -404 161
    -418 165
    -432 170
    -445 175
    -460 179
    -474 184
    -488 188
    -502 193
    -517 198
    -531 202
    -546 207
    -561 211
    -576 216
    -591 220
    -606 225
    -621 229
    -636 234
    -651 239
    -667 243
    -682 248
    -698 252
    -714 257
    -729 261
    -745 265
    -761 270
    -777 274
    -794 279
    -810 283
    -826 288
    -843 292
    -859 297
    -876 301
    -893 305
    -909 310
    -926 314
    -943 318
    -960 323
    -977 327
    -995 332
    -1012 336
    -1029 340
    -1047 344
    -1064 349
    -1082 353
    -1100 357
    1095 351
    1078 347
    1060 343
    1042 339
    1025 334
    1008 330
    990 326
    973 322
    956 317
    939 313
    922 309
    905 304
    888 300
    871 296
    855 291
    838 287
    822 283
    805 278
    789 274
    773 269
    757 265
    741 261
    725 256
    709 252
    693 247
    678 243
    662 238
    647 234
    632 229
    616 225
    601 220
    586 216
    571 211
    556 207
    541 202
    527 198
    512 193
    498 189
    483 184
    469 180
    455 175
    441 171
    427 166
    413 161
    399 157
    386 152
    372 148
    359 143
    345 138
    332 134
    319 129
    306 125
    293 120
    280 115
    268 111
    255 106
    242 101
    230 97
    218 92
    206 88
    194 83
    182 78
    170 74
    158 69
    147 64
    135 60
    124 55
    113 50
    102 45
    91 41
    80 36
    69 31
    58 27
    48 22
    37 17
    27 13
    17 8
    7 3
    -3 -1
    -13 -6
    -23 -11
    -32 -16
    -41 -20
    -51 -25
    -60 -30
    -69 -34
    -78 -39
    -87 -44
    -95 -48
    -104 -53
    -112 -58
    -121 -62
    -129 -67
    -137 -72
    -145 -76
    -153 -81
    -160 -86
    -168 -90
    -175 -95
    -183 -100
    -190 -104
    -197 -109
    -204 -114
    -210 -118
    -217 -123
    -223 -127
    -230 -132
    -236 -137
    -242 -141
    -248 -146
    -254 -150
    -259 -155
    -265 -159
    -270 -164
    -276 -168
    -281 -173
    -286 -177
    -291 -182
    -295 -186
    -300 -191
    -304 -195
    -309 -200
    -313 -204
    -317 -209
    -321 -213
    -325 -217
    -328 -222
    -332 -226
    -335 -231
    -339 -235
    -342 -239
    -345 -243
    -347 -248
    -350 -252
    -353 -256
    -355 -260
    -357 -265
    -360 -269
    -362 -273
    -364 -277
    -365 -281
    -367 -285
    -368 -289
    -370 -294
    -371 -298
    -372 -302
    -373 -306
    -374 -310
    -375 -313
    -375 -317
    -376 -321
    -376 -325
    -376 -329
    -376 -333
    -376 -337
    -376 -340
    -375 -344
    -375 -348
    -374 -351
    -374 -355
    -373 -359
    -372 -362
    -371 -366
    -369 -369
    -368 -373
    -367 -376
    -365 -380
    -363 -383
    -361 -387
    -359 -390
    -357 -393
    -355 -396
    -353 -400
    -350 -403
    -348 -406
    -345 -409
    -343 -412
    -340 -415
    -337 -418
    -334 -421
    -330 -424
    -327 -427
    -324 -430
    -320 -433
    -317 -435
    -313 -438
    -309 -441
    -305 -443
    -301 -446
    -297 -449
    -293 -451
    -289 -454
    -284 -456
    -280 -458
    -275 -461
    -271 -463
    -266 -465
    -261 -468
    -256 -470
    -251 -472
    -246 -474
    -241 -476
    -236 -478
    -231 -480
    -225 -482
    -220 -484
    -214 -485
    -209 -487
    -203 -489
    -197 -490
    -192 -492
    -186 -494
    -180 -495
    -174 -496
    -168 -498
    -162 -499
    -156 -500
    -150 -502
    -144 -503
    -137 -504
    -131 -505
    -125 -506
    -119 -507
    -112 -508
    -106 -509
    -99 -510
    -93 -511
    -86 -511
    -80 -512
    -73 -513
    -67 -513
    -60 -514
    -53 -514
    -47 -514
    -40 -515
    -33 -515
    -27 -515
    -20 -516
    -13 -516
    -7 -516
    0 -516
    7 -516
    13 -516
    20 -516
    27 -515
    33 -515
    40 -515
    47 -514
    53 -514
    60 -514
    67 -513
    73 -513
    80 -512
    86 -511
    93 -511
    99 -510
    106 -509
    112 -508
    119 -507
    125 -506
    131 -505
    137 -504
    144 -503
    150 -502
    156 -500
    162 -499
    168 -498
    174 -496
    180 -495
    186 -494
    192 -492
    197 -490
    203 -489
    209 -487
    214 -485
    220 -484
    225 -482
    231 -480
    236 -478
    241 -476
    246 -474
    251 -472
    256 -470
    261 -468
    266 -465
    271 -463
    275 -461
    280 -458
    284 -456
    289 -454
    293 -451
    297 -449
    301 -446
    305 -443
    309 -441
    313 -438
    317 -435
    320 -433
    324 -430
    327 -427
    330 -424
    334 -421
    337 -418
    340 -415
    343 -412
    345 -409
    348 -406
    350 -403
    353 -400
    355 -396
    357 -393
    359 -390
    361 -387
    363 -383
    365 -380
    367 -376
    368 -373
    369 -369
    371 -366
    372 -362
    373 -359
    374 -355
    374 -351
    375 -348
    375 -344
    376 -340
    376 -337
    376 -333
    376 -329
    376 -325
    376 -321
    375 -317
    375 -313
    374 -310
    373 -306
    372 -302
    371 -298
    370 -294
    368 -289
    367 -285
    365 -281
    364 -277
    362 -273
    360 -269
    357 -265
    355 -260
    353 -256
    350 -252
    347 -248
    345 -243
    342 -239
    339 -235
    335 -231
    332 -226
    328 -222
    325 -217
    321 -213
    317 -209
    313 -204
    309 -200
    304 -195
    300 -191
    295 -186
    291 -182
    286 -177
    281 -173
    276 -168
    270 -164
    265 -159
    259 -155
    254 -150
    248 -146
    242 -141
    236 -137
    230 -132
    223 -127
    217 -123
    210 -118
    204 -114
    197 -109
    190 -104
    183 -100
    175 -95
    168 -90
    160 -86
    153 -81
    145 -76
    137 -72
    129 -67
    121 -62
    112 -58
    104 -53
    95 -48
    87 -44
    78 -39
    69 -34
    60 -30
    51 -25
    41 -20
    32 -16
    23 -11
    13 -6
    3 -1
    -7 3
    -17 8
    -27 13
    -37 17
    -48 22
    -58 27
    -69 31
    -80 36
    -91 41
    -102 45
    -113 50
    -124 55
    -135 60
    -147 64
    -158 69
    -170 74
    -182 78
    -194 83
    -206 88
    -218 92
    -230 97
    -242 101
    -255 106
    -268 111
    -280 115
    -293 120
    -306 125
    -319 129
    -332 134
    -345 138
    -359 143
    -372 148
    -386 152
    -399 157
    -413 161
    -427 166
    -441 171
    -455 175
    -469 180
    -483 184
    -498 189
    -512 193
    -527 198
    -541 202
    -556 207
    -571 211
    -586 216
    -601 220
    -616 225
    -632 229
    -647 234
    -662 238
    -678 243
    -693 247
    -709 252
    -725 256
    -741 261
    -757 265
    -773 269
    -789 274
    -805 278
    -822 283
    -838 287
    -855 291
    -871 296
    -888 300
    -905 304
    -922 309
    -939 313
    -956 317
    -973 322
    -990 326
    -1008 330
    -1025 334
    -1042 339
    -1060 343
    -1078 347
    -1095 351
    1091 346
    1073 341
    1056 337
    1038 333
    1021 329
    1003 324
    986 320
    969 316
    952 312
    934 307
    918 303
    901 299
    884 295
    867 290
    850 286
    834 282
    817 277
    801 273
    785 269
    769 264
    753 260
    737 256
    721 251
    705 247
    689 242
    673 238
    658 234
    642 229
    627 225
    612 220
    597 216
    582 211
    567 207
    552 203
    537 198
    522 194
    508 189
    493 185
    479 180
    465 176
    450 171
    436 167
    422 162
    409 158
    395 153
    381 149
    368 144
    354 139
    341 135
    328 130
    314 126
    301 121
    288 117
    276 112
    263 107
    250 103
    238 98
    226 94
    213 89
    201 84
    189 80
    177 75
    165 71
    154 66
    142 61
    131 57
    119 52
    108 47
    97 43
    86 38
    75 34
    64 29
    54 24
    43 20
    33 15
    22 10
    12 6
    2 1
    -8 -4
    -18 -8
    -27 -13
    -37 -18
    -46 -22
    -55 -27
    -65 -31
    -74 -36
    -83 -41
    -91 -45
    -100 -50
    -109 -55
    -117 -59
    -125 -64
    -134 -69
    -142 -73
    -150 -78
    -157 -82
    -165 -87
    -172 -92
    -180 -96
    -187 -101
    -194 -105
    -201 -110
    -208 -115
    -215 -119
    -221 -124
    -228 -128
    -234 -133
    -240 -137
    -247 -142
    -252 -146
    -258 -151
    -264 -156
    -270 -160
    -275 -165
    -280 -169
    -285 -173
    -290 -178
    -295 -182
    -300 -187
    -304 -191
    -309 -196
    -313 -200
    -317 -204
    -321 -209
    -325 -213
    -329 -218
    -333 -222
    -336 -226
    -340 -230
    -343 -235
    -346 -239
    -349 -243
    -352 -248
    -354 -252
    -357 -256
    -359 -260
    -362 -264
    -364 -268
    -366 -273
    -368 -277
    -369 -281
    -371 -285
    -372 -289
    -374 -293
    -375 -297
    -376 -301
    -377 -305
    -378 -309
    -378 -313
    -379 -317
    -379 -320
    -380 -324
    -380 -328
    -380 -332
    -380 -336
    -379 -339
    -379 -343
    -379 -347
    -378 -350
    -377 -354
    -376 -357
    -375 -361
    -374 -365
    -373 -368
    -371 -371
    -370 -375
    -368 -378
    -367 -382
    -365 -385
    -363 -388
    -361 -392
    -358 -395
    -356 -398
    -354 -401
    -351 -404
    -348 -407
    -346 -410
    -343 -413
    -340 -416
    -337 -419
    -333 -422
    -330 -425
    -327 -428
    -323 -431
    -319 -433
    -316 -436
    -312 -439
    -308 -441
    -304 -444
    -300 -447
    -295 -449
    -291 -452
    -287 -454
    -282 -456
    -278 -459
    -273 -461
    -268 -463
    -263 -465
    -258 -467
    -253 -470
    -248 -472
    -243 -474
    -238 -476
    -232 -477
    -227 -479
    -222 -481
    -216 -483
    -210 -485
    -205 -486
    -199 -488
    -193 -490
    -187 -491
    -181 -493
    -175 -494
    -169 -495
    -163 -497
    -157 -498
    -151 -499
    -145 -500
    -139 -501
    -132 -503
    -126 -504
    -119 -505
    -113 -505
    -107 -506
    -100 -507
    -94 -508
    -87 -509
    -80 -509
    -74 -510
    -67 -510
    -61 -511
    -54 -511
    -47 -512
    -40 -512
    -34 -512
    -27 -513
    -20 -513
    -13 -513
    -7 -513
    0 -513
    7 -513
    13 -513
    20 -513
    27 -513
    34 -512
    40 -512
    47 -512
    54 -511
    61 -511
    67 -510
    74 -510
    80 -509
    87 -509
    94 -508
    100 -507
    107 -506
    113 -505
    119 -505
    126 -504
    132 -503
    139 -501
    145 -500
    151 -499
    157 -498
    163 -497
    169 -495
    175 -494
    181 -493
    187 -491
    193 -490
    199 -488
    205 -486
    210 -485
    216 -483
    222 -481
    227 -479
    232 -477
    238 -476
    243 -474
    248 -472
    253 -470
    258 -467
    263 -465
    268 -463
    273 -461
    278 -459
    282 -456
    287 -454
    291 -452
    295 -449
    300 -447
    304 -444
    308 -441
    312 -439
    316 -436
    319 -433
    323 -431
    327 -428
    330 -425
    333 -422
    337 -419
    340 -416
    343 -413
    346 -410
    348 -407
    351 -404
    354 -401
    356 -398
    358 -395
    361 -392
    363 -388
    365 -385
    367 -382
    368 -378
    370 -375
    371 -371
    373 -368
    374 -365
    375 -361
    376 -357
    377 -354
    378 -350
    379 -347
    379 -343
    379 -339
    380 -336
    380 -332
    380 -328
    380 -324
    379 -320
    379 -317
    378 -313
    378 -309
    377 -305
    376 -301
    375 -297
    374 -293
    372 -289
    371 -285
    369 -281
    368 -277
    366 -273
    364 -268
    362 -264
    359 -260
    357 -256
    354 -252
    352 -248
    349 -243
    346 -239
    343 -235
    340 -230
    336 -226
    333 -222
    329 -218
    325 -213
    321 -209
    317 -204
    313 -200
    309 -196
    304 -191
    300 -187
    295 -182
    290 -178
    285 -173
    280 -169
    275 -165
    270 -160
    264 -156
    258 -151
    252 -146
    247 -142
    240 -137
    234 -133
    228 -128
    221 -124
    215 -119
    208 -115
    201 -110
    194 -105
    187 -101
    180 -96
    172 -92
    165 -87
    157 -82
    150 -78
    142 -73
    134 -69
    125 -64
    117 -59
    109 -55
    100 -50
    91 -45
    83 -41
    74 -36
    65 -31
    55 -27
    46 -22
    37 -18
    27 -13
    18 -8
    8 -4
    -2 1
    -12 6
    -22 10
    -33 15
    -43 20
    -54 24
    -64 29
    -75 34
    -86 38
    -97 43
    -108 47
    -119 52
    -131 57
    -142 61
    -154 66
    -165 71
    -177 75
    -189 80
    -201 84
    -213 89
    -226 94
    -238 98
    -250 103
    -263 107
    -276 112
    -288 117
    -301 121
    -314 126
    -328 130
    -341 135
    -354 139
    -368 144
    -381 149
    -395 153
    -409 158
    -422 162
    -436 167
    -450 171
    -465 176
    -479 180
    -493 185
    -508 189
    -522 194
    -537 198
    -552 203
    -567 207
    -582 211
    -597 216
    -612 220
    -627 225
    -642 229
    -658 234
    -673 238
    -689 242
    -705 247
    -721 251
    -737 256
    -753 260
    -769 264
    -785 269
    -801 273
    -817 277
    -834 282
    -850 286
    -867 290
    -884 295
    -901 299
    -918 303
    -934 307
    -952 312
    -969 316
    -986 320
    -1003 324
    -1021 329
    -1038 333
    -1056 337
    -1073 341
    -1091 346
    1087 340
    1069 336
    1052 331
    1034 327
    1016 323
    999 319
    982 315
    964 310
    947 306
    930 302
    913 298
    896 294
    880 289
    863 285
    846 281
    830 277
    813 272
    797 268
    781 264
    764 259
    748 255
    732 251
    716 246
    700 242
    685 238
    669 233
    654 229
    638 225
    623 220
    607 216
    592 212
    577 207
    562 203
    547 198
    533 194
    518 189
    503 185
    489 181
    474 176
    460 172
    446 167
    432 163
    418 158
    404 154
    390 149
    377 145
    363 140
    350 136
    336 131
    323 127
    310 122
    297 118
    284 113
    271 109
    258 104
    246 100
    233 95
    221 91
    209 86
    197 81
    184 77
    173 72
    161 68
    149 63
    137 59
    126 54
    115 49
    103 45
    92 40
    81 36
    70 31
    60 26
    49 22
    38 17
    28 13
    18 8
    8 3
    -2 -1
    -12 -6
    -22 -10
    -32 -15
    -41 -20
    -51 -24
    -60 -29
    -69 -33
    -78 -38
    -87 -42
    -96 -47
    -105 -52
    -113 -56
    -122 -61
    -130 -65
    -138 -70
    -146 -75
    -154 -79
    -162 -84
    -170 -88
    -177 -93
    -184 -97
    -192 -102
    -199 -107
    -206 -111
    -213 -116
    -219 -120
    -226 -125
    -232 -129
    -239 -134
    -245 -138
    -251 -143
    -257 -147
    -263 -152
    -268 -156
    -274 -161
    -279 -165
    -285 -169
    -290 -174
    -295 -178
    -300 -183
    -304 -187
    -309 -191
    -313 -196
    -318 -200
    -322 -205
    -326 -209
    -330 -213
    -333 -217
    -337 -222
    -341 -226
    -344 -230
    -347 -235
    -350 -239
    -353 -243
    -356 -247
    -359 -251
    -361 -256
    -364 -260
    -366 -264
    -368 -268
    -370 -272
    -372 -276
    -373 -280
    -375 -284
    -376 -288
    -378 -292
    -379 -296
    -380 -300
    -381 -304
    -382 -308
    -382 -312
    -383 -316
    -383 -319
    -383 -323
    -384 -327
    -384 -331
    -383 -334
    -383 -338
    -383 -342
    -382 -345
    -382 -349
    -381 -353
    -380 -356
    -379 -360
    -378 -363
    -376 -367
    -375 -370
    -373 -373
    -372 -377
    -370 -380
    -368 -383
    -366 -387
    -364 -390
    -362 -393
    -359 -396
    -357 -399
    -354 -402
    -351 -406
    -349 -409
    -346 -412
    -343 -414
    -339 -417
    -336 -420
    -333 -423
    -329 -426
    -326 -429
    -322 -431
    -318 -434
    -314 -437
    -310 -439
    -306 -442
    -302 -444
    -298 -447
    -294 -449
    -289 -452
    -285 -454
    -280 -456
    -275 -459
    -270 -461
    -265 -463
    -260 -465
    -255 -467
    -250 -469
    -245 -471
    -240 -473
    -234 -475
    -229 -477
    -223 -479
    -218 -480
    -212 -482
    -206 -484
    -201 -485
    -195 -487
    -189 -488
    -183 -490
    -177 -491
    -171 -493
    -165 -494
    -158 -495
    -152 -497
    -146 -498
    -140 -499
    -133 -500
    -127 -501
    -120 -502
    -114 -503
    -107 -504
    -101 -504
    -94 -505
    -88 -506
    -81 -507
    -74 -507
    -68 -508
    -61 -508
    -54 -509
    -48 -509
    -41 -509
    -34 -510
    -27 -510
    -20 -510
    -14 -510
    -7 -510
    0 -510
    7 -510
    14 -510
    20 -510
    27 -510
    34 -510
    41 -509
    48 -509
    54 -509
    61 -508
    68 -508
    74 -507
    81 -507
    88 -506
    94 -505
    101 -504
    107 -504
    114 -503
    120 -502
    127 -501
    133 -500
    140 -499
    146 -498
    152 -497
    158 -495
    165 -494
    171 -493
    177 -491
    183 -490
    189 -488
    195 -487
    201 -485
    206 -484
    212 -482
    218 -480
    223 -479
    229 -477
    234 -475
    240 -473
    245 -471
    250 -469
    255 -467
    260 -465
    265 -463
    270 -461
    275 -459
    280 -456
    285 -454
    289 -452
    294 -449
    298 -447
    302 -444
    306 -442
    310 -439
    314 -437
    318 -434
    322 -431
    326 -429
    329 -426
    333 -423
    336 -420
    339 -417
    343 -414
    346 -412
    349 -409
    351 -406
    354 -402
    357 -399
    359 -396
    362 -393
    364 -390
    366 -387
    368 -383
    370 -380
    372 -377
    373 -373
    375 -370
    376 -367
    378 -363
    379 -360
    380 -356
    381 -353
    382 -349
    382 -345
    383 -342
    383 -338
    383 -334
    384 -331
    384 -327
    383 -323
    383 -319
    383 -316
    382 -312
    382 -308
    381 -304
    380 -300
    379 -296
    378 -292
    376 -288
    375 -284
    373 -280
    372 -276
    370 -272
    368 -268
    366 -264
    364 -260
    361 -256
    359 -251
    356 -247
    353 -243
    350 -239
    347 -235
    344 -230
    341 -226
    337 -222
    333 -217
    330 -213
    326 -209
    322 -205
    318 -200
    313 -196
    309 -191
    304 -187
    300 -183
    295 -178
    290 -174
    285 -169
    279 -165
    274 -161
    268 -156
    263 -152
    257 -147
    251 -143
    245 -138
    239 -134
    232 -129
    226 -125
    219 -120
    213 -116
    206 -111
    199 -107
    192 -102
    184 -97
    177 -93
    170 -88
    162 -84
    154 -79
    146 -75
    138 -70
    130 -65
    122 -61
    113 -56
    105 -52
    96 -47
    87 -42
    78 -38
    69 -33
    60 -29
    51 -24
    41 -20
    32 -15
    22 -10
    12 -6
    2 -1
    -8 3
    -18 8
    -28 13
    -38 17
    -49 22
    -60 26
    -70 31
    -81 36
    -92 40
    -103 45
    -115 49
    -126 54
    -137 59
    -149 63
    -161 68
    -173 72
    -184 77
    -197 81
    -209 86
    -221 91
    -233 95
    -246 100
    -258 104
    -271 109
    -284 113
    -297 118
    -310 122
    -323 127
    -336 131
    -350 136
    -363 140
    -377 145
    -390 149
    -404 154
    -418 158
    -432 163
    -446 167
    -460 172
    -474 176
    -489 181
    -503 185
    -518 189
    -533 194
    -547 198
    -562 203
    -577 207
    -592 212
    -607 216
    -623 220
    -638 225
    -654 229
    -669 233
    -685 238
    -700 242
    -716 246
    -732 251
    -748 255
    -764 259
    -781 264
    -797 268
    -813 272
    -830 277
    -846 281
    -863 285
    -880 289
    -896 294
    -913 298
    -930 302
    -947 306
    -964 310
    -982 315
    -999 319
    -1016 323
    -1034 327
    -1052 331
    -1069 336
    -1087 340
    1083 334
    1065 330
    1047 326
    1030 322
    1012 317
    995 313
    978 309
    960 305
    943 301
    926 297
    909 292
    892 288
    875 284
    859 280
    842 276
    825 271
    809 267
    793 263
    776 259
    760 254
    744 250
    728 246
    712 242
    696 237
    680 233
    665 229
    649 224
    634 220
    618 216
    603 212
    588 207
    573 203
    558 198
    543 194
    528 190
    513 185
    499 181
    484 177
    470 172
    456 168
    442 163
    427 159
    413 155
    400 150
    386 146
    372 141
    359 137
    345 132
    332 128
    318 123
    305 119
    292 114
    279 110
    267 105
    254 101
    241 97
    229 92
    216 88
    204 83
    192 78
    180 74
    168 69
    156 65
    145 60
    133 56
    121 51
    110 47
    99 42
    88 38
    77 33
    66 29
    55 24
    44 20
    34 15
    24 10
    13 6
    3 1
    -7 -3
    -17 -8
    -27 -12
    -36 -17
    -46 -21
    -55 -26
    -65 -30
    -74 -35
    -83 -40
    -92 -44
    -101 -49
    -109 -53
    -118 -58
    -126 -62
    -135 -67
    -143 -71
    -151 -76
    -159 -80
    -166 -85
    -174 -89
    -182 -94
    -189 -98
    -196 -103
    -203 -107
    -210 -112
    -217 -116
    -224 -121
    -231 -125
    -237 -130
    -243 -134
    -249 -139
    -256 -143
    -261 -148
    -267 -152
    -273 -157
    -278 -161
    -284 -165
    -289 -170
    -294 -174
    -299 -179
    -304 -183
    -309 -187
    -313 -192
    -318 -196
    -322 -200
    -326 -204
    -330 -209
    -334 -213
    -338 -217
    -341 -222
    -345 -226
    -348 -230
    -351 -234
    -354 -238
    -357 -243
    -360 -247
    -363 -251
    -365 -255
    -368 -259
    -370 -263
    -372 -267
    -374 -271
    -376 -275
    -377 -279
    -379 -283
    -380 -287
    -382 -291
    -383 -295
    -384 -299
    -385 -303
    -386 -307
    -386 -311
    -387 -314
    -387 -318
    -387 -322
    -387 -326
    -387 -329
    -387 -333
    -387 -337
    -386 -340
    -386 -344
    -385 -348
    -384 -351
    -383 -355
    -382 -358
    -381 -362
    -380 -365
    -378 -368
    -377 -372
    -375 -375
    -373 -378
    -371 -382
    -369 -385
    -367 -388
    -365 -391
    -362 -394
    -360 -397
    -357 -401
    -354 -404
    -352 -407
    -349 -410
    -346 -412
    -342 -415
    -339 -418
    -336 -421
    -332 -424
    -329 -426
    -325 -429
    -321 -432
    -317 -434
    -313 -437
    -309 -440
    -305 -442
    -300 -444
    -296 -447
    -291 -449
    -287 -452
    -282 -454
    -277 -456
    -273 -458
    -268 -460
    -263 -463
    -257 -465
    -252 -467
    -247 -469
    -242 -471
    -236 -472
    -231 -474
    -225 -476
    -220 -478
    -214 -479
    -208 -481
    -202 -483
    -196 -484
    -190 -486
    -184 -487
    -178 -489
    -172 -490
    -166 -491
    -160 -492
    -153 -494
    -147 -495
    -141 -496
    -134 -497
    -128 -498
    -121 -499
    -115 -500
    -108 -501
    -102 -502
    -95 -502
    -88 -503
    -82 -504
    -75 -504
    -68 -505
    -61 -505
    -55 -506
    -48 -506
    -41 -506
    -34 -507
    -27 -507
    -21 -507
    -14 -507
    -7 -507
    0 -507
    7 -507
    14 -507
    21 -507
    27 -507
    34 -507
    41 -506
    48 -506
    55 -506
    61 -505
    68 -505
    75 -504
    82 -504
    88 -503
    95 -502
    102 -502
    108 -501
    115 -500
    121 -499
    128 -498
    134 -497
    141 -496
    147 -495
    153 -494
    160 -492
    166 -491
    172 -490
    178 -489
    184 -487
    190 -486
    196 -484
    202 -483
    208 -481
    214 -479
    220 -478
    225 -476
    231 -474
    236 -472
    242 -471
    247 -469
    252 -467
    257 -465
    263 -463
    268 -460
    273 -458
    277 -456
    282 -454
    287 -452
    291 -449
    296 -447
    300 -444
    305 -442
    309 -440
    313 -437
    317 -434
    321 -432
    325 -429
    329 -426
    332 -424
    336 -421
    339 -418
    342 -415
    346 -412
    349 -410
    352 -407
    354 -404
    357 -401
    360 -397
    362 -394
    365 -391
    367 -388
    369 -385
    371 -382
    373 -378
    375 -375
    377 -372
    378 -368
    380 -365
    381 -362
    382 -358
    383 -355
    384 -351
    385 -348
    386 -344
    386 -340
    387 -337
    387 -333
    387 -329
    387 -326
    387 -322
    387 -318
    387 -314
    386 -311
    386 -307
    385 -303
    384 -299
    383 -295
    382 -291
    380 -287
    379 -283
    377 -279
    376 -275
    374 -271
    372 -267
    370 -263
    368 -259
    365 -255
    363 -251
    360 -247
    357 -243
    354 -238
    351 -234
    348 -230
    345 -226
    341 -222
    338 -217
    334 -213
    330 -209
    326 -204
    322 -200
    318 -196
    313 -192
    309 -187
    304 -183
    299 -179
    294 -174
    289 -170
    284 -165
    278 -161
    273 -157
    267 -152
    261 -148
    256 -143
    249 -139
    243 -134
    237 -130
    231 -125
    224 -121
    217 -116
    210 -112
    203 -107
    196 -103
    189 -98
    182 -94
    174 -89
    166 -85
    159 -80
    151 -76
    143 -71
    135 -67
    126 -62
    118 -58
    109 -53
    101 -49
    92 -44
    83 -40
    74 -35
    65 -30
    55 -26
    46 -21
    36 -17
    27 -12
    17 -8
    7 -3
    -3 1
    -13 6
    -24 10
    -34 15
    -44 20
    -55 24
    -66 29
    -77 33
    -88 38
    -99 42
    -110 47
    -121 51
    -133 56
    -145 60
    -156 65
    -168 69
    -180 74
    -192 78
    -204 83
    -216 88
    -229 92
    -241 97
    -254 101
    -267 105
    -279 110
    -292 114
    -305 119
    -318 123
    -332 128
    -345 132
    -359 137
    -372 141
    -386 146
    -400 150
    -413 155
    -427 159
    -442 163
    -456 168
    -470 172
    -484 177
    -499 181
    -513 185
    -528 190
    -543 194
    -558 198
    -573 203
    -588 207
    -603 212
    -618 216
    -634 220
    -649 224
    -665 229
    -680 233
    -696 237
    -712 242
    -728 246
    -744 250
    -760 254
    -776 259
    -793 263
    -809 267
    -825 271
    -842 276
    -859 280
    -875 284
    -892 288
    -909 292
    -926 297
    -943 301
    -960 305
    -978 309
    -995 313
    -1012 317
    -1030 322
    -1047 326
    -1065 330
    -1083 334
    1079 328
    1061 324
    1043 320
    1026 316
    1008 312
    991 308
    973 304
    956 300
    939 295
    922 291
    905 287
    888 283
    871 279
    854 275
    838 271
    821 266
    805 262
    788 258
    772 254
    756 250
    740 245
    724 241
    708 237
    692 233
    676 228
    660 224
    645 220
    629 216
    614 211
    599 207
    584 203
    568 199
    553 194
    539 190
    524 186
    509 181
    495 177
    480 173
    466 168
    451 164
    437 160
    423 155
    409 151
    395 146
    381 142
    368 138
    354 133
    341 129
    327 124
    314 120
    301 116
    288 111
    275 107
    262 102
    249 98
    237 93
    224 89
    212 85
    200 80
    187 76
    175 71
    164 67
    152 62
    140 58
    128 53
    117 49
    106 44
    94 40
    83 35
    72 31
    61 26
    51 22
    40 17
    29 13
    19 8
    9 4
    -1 -1
    -12 -5
    -21 -10
    -31 -14
    -41 -19
    -50 -23
    -60 -28
    -69 -32
    -78 -37
    -87 -41
    -96 -46
    -105 -50
    -114 -55
    -122 -59
    -131 -64
    -139 -68
    -147 -73
    -155 -77
    -163 -82
    -171 -86
    -179 -91
    -186 -95
    -193 -99
    -201 -104
    -208 -108
    -215 -113
    -222 -117
    -228 -122
    -235 -126
    -241 -131
    -248 -135
    -254 -139
    -260 -144
    -266 -148
    -272 -153
    -277 -157
    -283 -161
    -288 -166
    -293 -170
    -298 -174
    -303 -179
    -308 -183
    -313 -187
    -318 -192
    -322 -196
    -326 -200
    -330 -204
    -334 -209
    -338 -213
    -342 -217
    -346 -221
    -349 -225
    -352 -230
    -356 -234
    -359 -238
    -361 -242
    -364 -246
    -367 -250
    -369 -254
    -372 -258
    -374 -262
    -376 -266
    -378 -270
    -380 -274
    -381 -278
    -383 -282
    -384 -286
    -386 -290
    -387 -294
    -388 -298
    -389 -302
    -389 -306
    -390 -309
    -390 -313
    -391 -317
    -391 -321
    -391 -324
    -391 -328
    -391 -332
    -390 -335
    -390 -339
    -389 -342
    -389 -346
    -388 -349
    -387 -353
    -386 -356
    -384 -360
    -383 -363
    -382 -367
    -380 -370
    -378 -373
    -377 -377
    -375 -380
    -372 -383
    -370 -386
    -368 -389
    -365 -392
    -363 -395
    -360 -398
    -357 -401
    -355 -404
    -352 -407
    -348 -410
    -345 -413
    -342 -416
    -338 -419
    -335 -421
    -331 -424
    -327 -427
    -324 -429
    -320 -432
    -316 -435
    -311 -437
    -307 -440
    -303 -442
    -298 -444
    -294 -447
    -289 -449
    -284 -451
    -280 -454
    -275 -456
    -270 -458
    -265 -460
    -259 -462
    -254 -464
    -249 -466
    -244 -468
    -238 -470
    -233 -471
    -227 -473
    -221 -475
    -215 -477
    -210 -478
    -204 -480
    -198 -481
    -192 -483
    -186 -484
    -180 -486
    -173 -487
    -167 -488
    -161 -490
    -155 -491
    -148 -492
    -142 -493
    -135 -494
    -129 -495
    -122 -496
    -116 -497
    -109 -498
    -102 -499
    -96 -499
    -89 -500
    -82 -501
    -76 -501
    -69 -502
    -62 -502
    -55 -503
    -48 -503
    -41 -503
    -34 -504
    -28 -504
    -21 -504
    -14 -504
    -7 -504
    0 -504
    7 -504
    14 -504
    21 -504
    28 -504
    34 -504
    41 -503
    48 -503
    55 -503
    62 -502
    69 -502
    76 -501
    82 -501
    89 -500
    96 -499
    102 -499
    109 -498
    116 -497
    122 -496
    129 -495
    135 -494
    142 -493
    148 -492
    155 -491
    161 -490
    167 -488
    173 -487
    180 -486
    186 -484
    192 -483
    198 -481
    204 -480
    210 -478
    215 -477
    221 -475
    227 -473
    233 -471
    238 -470
    244 -468
    249 -466
    254 -464
    259 -462
    265 -460
    270 -458
    275 -456
    280 -454
    284 -451
    289 -449
    294 -447
    298 -444
    303 -442
    307 -440
    311 -437
    316 -435
    320 -432
    324 -429
    327 -427
    331 -424
    335 -421
    338 -419
    342 -416
    345 -413
    348 -410
    352 -407
    355 -404
    357 -401
    360 -398
    363 -395
    365 -392
    368 -389
    370 -386
    372 -383
    375 -380
    377 -377
    378 -373
    380 -370
    382 -367
    383 -363
    384 -360
    386 -356
    387 -353
    388 -349
    389 -346
    389 -342
    390 -339
    390 -335
    391 -332
    391 -328
    391 -324
    391 -321
    391 -317
    390 -313
    390 -309
    389 -306
    389 -302
    388 -298
    387 -294
    386 -290
    384 -286
    383 -282
    381 -278
    380 -274
    378 -270
    376 -266
    374 -262
    372 -258
    369 -254
    367 -250
    364 -246
    361 -242
    359 -238
    356 -234
    352 -230
    349 -225
    346 -221
    342 -217
    338 -213
    334 -209
    330 -204
    326 -200
    322 -196
    318 -192
    313 -187
    308 -183
    303 -179
    298 -174
    293 -170
    288 -166
    283 -161
    277 -157
    272 -153
    266 -148
    260 -144
    254 -139
    248 -135
    241 -131
    235 -126
    228 -122
    222 -117
    215 -113
    208 -108
    201 -104
    193 -99
    186 -95
    179 -91
    171 -86
    163 -82
    155 -77
    147 -73
    139 -68
    131 -64
    122 -59
    114 -55
    105 -50
    96 -46
    87 -41
    78 -37
    69 -32
    60 -28
    50 -23
    41 -19
    31 -14
    21 -10
    12 -5
    1 -1
    -9 4
    -19 8
    -29 13
    -40 17
    -51 22
    -61 26
    -72 31
    -83 35
    -94 40
    -106 44
    -117 49
    -128 53
    -140 58
    -152 62
    -164 67
    -175 71
    -187 76
    -200 80
    -212 85
    -224 89
    -237 93
    -249 98
    -262 102
    -275 107
    -288 111
    -301 116
    -314 120
    -327 124
    -341 129
    -354 133
    -368 138
    -381 142
    -395 146
    -409 151
    -423 155
    -437 160
    -451 164
    -466 168
    -480 173
    -495 177
    -509 181
    -524 186
    -539 190
    -553 194
    -568 199
    -584 203
    -599 207
    -614 211
    -629 216
    -645 220
    -660 224
    -676 228
    -692 233
    -708 237
    -724 241
    -740 245
    -756 250
    -772 254
    -788 258
    -805 262
    -821 266
    -838 271
    -854 275
    -871 279
    -888 283
    -905 287
    -922 291
    -939 295
    -956 300
    -973 304
    -991 308
    -1008 312
    -1026 316
    -1043 320
    -1061 324
    -1079 328
    1075 322
    1057 318
    1039 314
    1022 310
    1004 306
    987 302
    969 298
    952 294
    935 290
    918 286
    901 282
    884 278
    867 274
    850 270
    834 266
    817 261
    801 257
    784 253
    768 249
    752 245
    735 241
    719 237
    703 232
    688 228
    672 224
    656 220
    641 216
    625 211
    610 207
    594 203
    579 199
    564 194
    549 190
    534 186
    519 182
    505 177
    490 173
    476 169
    461 164
    447 160
    433 156
    419 151
    405 147
    391 143
    377 138
    363 134
    350 130
    336 125
    323 121
    310 117
    296 112
    283 108
    271 104
    258 99
    245 95
    232 90
    220 86
    207 82
    195 77
    183 73
    171 68
    159 64
    147 60
    136 55
    124 51
    112 46
    101 42
    90 37
    79 33
    68 29
    57 24
    46 20
    35 15
    25 11
    15 6
    4 2
    -6 -3
    -16 -7
    -26 -12
    -36 -16
    -45 -20
    -55 -25
    -64 -29
    -74 -34
    -83 -38
    -92 -43
    -101 -47
    -110 -52
    -118 -56
    -127 -60
    -135 -65
    -144 -69
    -152 -74
    -160 -78
    -168 -83
    -175 -87
    -183 -92
    -191 -96
    -198 -100
    -205 -105
    -212 -109
    -219 -114
    -226 -118
    -233 -122
    -239 -127
    -246 -131
    -252 -135
    -258 -140
    -264 -144
    -270 -149
    -276 -153
    -282 -157
    -287 -162
    -292 -166
    -298 -170
    -303 -174
    -308 -179
    -313 -183
    -317 -187
    -322 -191
    -326 -196
    -330 -200
    -335 -204
    -339 -208
    -342 -213
    -346 -217
    -350 -221
    -353 -225
    -356 -229
    -360 -233
    -363 -237
    -366 -241
    -368 -246
    -371 -250
    -373 -254
    -376 -258
    -378 -262
    -380 -266
    -382 -270
    -384 -274
    -385 -277
    -387 -281
    -388 -285
    -390 -289
    -391 -293
    -392 -297
    -392 -301
    -393 -304
    -394 -308
    -394 -312
    -394 -316
    -395 -319
    -395 -323
    -395 -327
    -394 -330
    -394 -334
    -394 -337
    -393 -341
    -392 -344
    -391 -348
    -390 -351
    -389 -355
    -388 -358
    -387 -361
    -385 -365
    -383 -368
    -382 -371
    -380 -375
    -378 -378
    -376 -381
    -373 -384
    -371 -387
    -369 -390
    -366 -393
    -363 -396
    -360 -399
    -358 -402
    -354 -405
    -351 -408
    -348 -411
    -345 -414
    -341 -416
    -338 -419
    -334 -422
    -330 -424
    -326 -427
    -322 -430
    -318 -432
    -314 -435
    -310 -437
    -305 -439
    -301 -442
    -296 -444
    -291 -446
    -287 -449
    -282 -451
    -277 -453
    -272 -455
    -267 -457
    -261 -459
    -256 -461
    -251 -463
    -245 -465
    -240 -467
    -234 -469
    -229 -470
    -223 -472
    -217 -474
    -211 -475
    -205 -477
    -199 -478
    -193 -480
    -187 -481
    -181 -483
    -175 -484
    -168 -485
    -162 -486
    -156 -488
    -149 -489
    -143 -490
    -136 -491
    -130 -492
    -123 -493
    -117 -494
    -110 -495
    -103 -495
    -96 -496
    -90 -497
    -83 -497
    -76 -498
    -69 -499
    -62 -499
    -55 -499
    -49 -500
    -42 -500
    -35 -500
    -28 -501
    -21 -501
    -14 -501
    -7 -501
    0 -501
    7 -501
    14 -501
    21 -501
    28 -501
    35 -500
    42 -500
    49 -500
    55 -499
    62 -499
    69 -499
    76 -498
    83 -497
    90 -497
    96 -496
    103 -495
    110 -495
    117 -494
    123 -493
    130 -492
    136 -491
    143 -490
    149 -489
    156 -488
    162 -486
    168 -485
    175 -484
    181 -483
    187 -481
    193 -480
    199 -478
    205 -477
    211 -475
    217 -474
    223 -472
    229 -470
    234 -469
    240 -467
    245 -465
    251 -463
    256 -461
    261 -459
    267 -457
    272 -455
    277 -453
    282 -451
    287 -449
    291 -446
    296 -444
    301 -442
    305 -439
    310 -437
    314 -435
    318 -432
    322 -430
    326 -427
    330 -424
    334 -422
    338 -419
    341 -416
    345 -414
    348 -411
    351 -408
    354 -405
    358 -402
    360 -399
    363 -396
    366 -393
    369 -390
    371 -387
    373 -384
    376 -381
    378 -378
    380 -375
    382 -371
    383 -368
    385 -365
    387 -361
    388 -358
    389 -355
    390 -351
    391 -348
    392 -344
    393 -341
    394 -337
    394 -334
    394 -330
    395 -327
    395 -323
    395 -319
    394 -316
    394 -312
    394 -308
    393 -304
    392 -301
    392 -297
    391 -293
    390 -289
    388 -285
    387 -281
    385 -277
    384 -274
    382 -270
    380 -266
    378 -262
    376 -258
    373 -254
    371 -250
    368 -246
    366 -241
    363 -237
    360 -233
    356 -229
    353 -225
    350 -221
    346 -217
    342 -213
    339 -208
    335 -204
    330 -200
    326 -196
    322 -191
    317 -187
    313 -183
    308 -179
    303 -174
    298 -170
    292 -166
    287 -162
    282 -157
    276 -153
    270 -149
    264 -144
    258 -140
    252 -135
    246 -131
    239 -127
    233 -122
    226 -118
    219 -114
    212 -109
    205 -105
    198 -100
    191 -96
    183 -92
    175 -87
    168 -83
    160 -78
    152 -74
    144 -69
    135 -65
    127 -60
    118 -56
    110 -52
    101 -47
    92 -43
    83 -38
    74 -34
    64 -29
    55 -25
    45 -20
    36 -16
    26 -12
    16 -7
    6 -3
    -4 2
    -15 6
    -25 11
    -35 15
    -46 20
    -57 24
    -68 29
    -79 33
    -90 37
    -101 42
    -112 46
    -124 51
    -136 55
    -147 60
    -159 64
    -171 68
    -183 73
    -195 77
    -207 82
    -220 86
    -232 90
    -245 95
    -258 99
    -271 104
    -283 108
    -296 112
    -310 117
    -323 121
    -336 125
    -350 130
    -363 134
    -377 138
    -391 143
    -405 147
    -419 151
    -433 156
    -447 160
    -461 164
    -476 169
    -490 173
    -505 177
    -519 182
    -534 186
    -549 190
    -564 194
    -579 199
    -594 203
    -610 207
    -625 211
    -641 216
    -656 220
    -672 224
    -688 228
    -703 232
    -719 237
    -735 241
    -752 245
    -768 249
    -784 253
    -801 257
    -817 261
    -834 266
    -850 270
    -867 274
    -884 278
    -901 282
    -918 286
    -935 290
    -952 294
    -969 298
    -987 302
    -1004 306
    -1022 310
    -1039 314
    -1057 318
    -1075 322
    1071 317
    1053 313
    1035 309
    1018 305
    1000 301
    983 297
    965 293
    948 289
    931 285
    914 281
    897 277
    880 273
    863 269
    846 265
    830 261
    813 257
    796 252
    780 248
    764 244
    747 240
    731 236
    715 232
    699 228
    683 224
    668 219
    652 215
    636 211
    621 207
    606 203
    590 199
    575 194
    560 190
    545 186
    530 182
    515 178
    501 173
    486 169
    471 165
    457 161
    443 156
    428 152
    414 148
    400 144
    386 139
    373 135
    359 131
    345 126
    332 122
    319 118
    305 113
    292 109
    279 105
    266 101
    253 96
    241 92
    228 88
    216 83
    203 79
    191 74
    179 70
    167 66
    155 61
    143 57
    131 53
    120 48
    108 44
    97 39
    85 35
    74 31
    63 26
    52 22
    42 18
    31 13
    20 9
    10 4
    -0 -0
    -10 -4
    -20 -9
    -30 -13
    -40 -18
    -50 -22
    -59 -27
    -69 -31
    -78 -35
    -87 -40
    -96 -44
    -105 -49
    -114 -53
    -123 -57
    -131 -62
    -140 -66
    -148 -70
    -156 -75
    -164 -79
    -172 -84
    -180 -88
    -187 -92
    -195 -97
    -202 -101
    -210 -106
    -217 -110
    -224 -114
    -230 -119
    -237 -123
    -244 -127
    -250 -132
    -256 -136
    -263 -140
    -269 -145
    -275 -149
    -280 -153
    -286 -157
    -291 -162
    -297 -166
    -302 -170
    -307 -174
    -312 -179
    -317 -183
    -321 -187
    -326 -191
    -330 -195
    -335 -200
    -339 -204
    -343 -208
    -347 -212
    -350 -216
    -354 -220
    -357 -224
    -361 -229
    -364 -233
    -367 -237
    -370 -241
    -372 -245
    -375 -249
    -377 -253
    -380 -257
    -382 -261
    -384 -265
    -386 -269
    -388 -272
    -389 -276
    -391 -280
    -392 -284
    -393 -288
    -394 -292
    -395 -296
    -396 -299
    -397 -303
    -397 -307
    -398 -310
    -398 -314
    -398 -318
    -398 -321
    -398 -325
    -398 -329
    -398 -332
    -397 -336
    -396 -339
    -396 -343
    -395 -346
    -394 -349
    -393 -353
    -391 -356
    -390 -359
    -388 -363
    -387 -366
    -385 -369
    -383 -372
    -381 -376
    -379 -379
    -377 -382
    -374 -385
    -372 -388
    -369 -391
    -366 -394
    -363 -397
    -360 -400
    -357 -403
    -354 -406
    -351 -408
    -347 -411
    -344 -414
    -340 -417
    -337 -419
    -333 -422
    -329 -424
    -325 -427
    -321 -429
    -316 -432
    -312 -434
    -308 -437
    -303 -439
    -298 -441
    -294 -444
    -289 -446
    -284 -448
    -279 -450
    -274 -452
    -269 -454
    -263 -456
    -258 -458
    -253 -460
    -247 -462
    -242 -464
    -236 -466
    -230 -467
    -225 -469
    -219 -471
    -213 -472
    -207 -474
    -201 -475
    -195 -477
    -189 -478
    -182 -479
    -176 -481
    -170 -482
    -163 -483
    -157 -484
    -150 -486
    -144 -487
    -137 -488
    -131 -489
    -124 -490
    -117 -490
    -111 -491
    -104 -492
    -97 -493
    -90 -493
    -84 -494
    -77 -495
    -70 -495
    -63 -496
    -56 -496
    -49 -497
    -42 -497
    -35 -497
    -28 -497
    -21 -498
    -14 -498
    -7 -498
    0 -498
    7 -498
    14 -498
    21 -498
    28 -497
    35 -497
    42 -497
    49 -497
    56 -496
    63 -496
    70 -495
    77 -495
    84 -494
    90 -493
    97 -493
    104 -492
    111 -491
    117 -490
    124 -490
    131 -489
    137 -488
    144 -487
    150 -486
    157 -484
    163 -483
    170 -482
    176 -481
    182 -479
    189 -478
    195 -477
    201 -475
    207 -474
    213 -472
    219 -471
    225 -469
    230 -467
    236 -466
    242 -464
    247 -462
    253 -460
    258 -458
    263 -456
    269 -454
    274 -452
    279 -450
    284 -448
    289 -446
    294 -444
    298 -441
    303 -439
    308 -437
    312 -434
    316 -432
    321 -429
    325 -427
    329 -424
    333 -422
    337 -419
    340 -417
    344 -414
    347 -411
    351 -408
    354 -406
    357 -403
    360 -400
    363 -397
    366 -394
    369 -391
    372 -388
    374 -385
    377 -382
    379 -379
    381 -376
    383 -372
    385 -369
    387 -366
    388 -363
    390 -359
    391 -356
    393 -353
    394 -349
    395 -346
    396 -343
    396 -339
    397 -336
    398 -332
    398 -329
    398 -325
    398 -321
    398 -318
    398 -314
    398 -310
    397 -307
    397 -303
    396 -299
    395 -296
    394 -292
    393 -288
    392 -284
    391 -280
    389 -276
    388 -272
    386 -269
    384 -265
    382 -261
    380 -257
    377 -253
    375 -249
    372 -245
    370 -241
    367 -237
    364 -233
    361 -229
    357 -224
    354 -220
    350 -216
    347 -212
    343 -208
    339 -204
    335 -200
    330 -195
    326 -191
    321 -187
    317 -183
    312 -179
    307 -174
    302 -170
    297 -166
    291 -162
    286 -157
    280 -153
    275 -149
    269 -145
    263 -140
    256 -136
    250 -132
    244 -127
    237 -123
    230 -119
    224 -114
    217 -110
    210 -106
    202 -101
    195 -97
    187 -92
    180 -88
    172 -84
    164 -79
    156 -75
    148 -70
    140 -66
    131 -62
    123 -57
    114 -53
    105 -49
    96 -44
    87 -40
    78 -35
    69 -31
    59 -27
    50 -22
    40 -18
    30 -13
    20 -9
    10 -4
    0 -0
    -10 4
    -20 9
    -31 13
    -42 18
    -52 22
    -63 26
    -74 31
    -85 35
    -97 39
    -108 44
    -120 48
    -131 53
    -143 57
    -155 61
    -167 66
    -179 70
    -191 74
    -203 79
    -216 83
    -228 88
    -241 92
    -253 96
    -266 101
    -279 105
    -292 109
    -305 113
    -319 118
    -332 122
    -345 126
    -359 131
    -373 135
    -386 139
    -400 144
    -414 148
    -428 152
    -443 156
    -457 161
    -471 165
    -486 169
    -501 173
    -515 178
    -530 182
    -545 186
    -560 190
    -575 194
    -590 199
    -606 203
    -621 207
    -636 211
    -652 215
    -668 219
    -683 224
    -699 228
    -715 232
    -731 236
    -747 240
    -764 244
    -780 248
    -796 252
    -813 257
    -830 261
    -846 265
    -863 269
    -880 273
    -897 277
    -914 281
    -931 285
    -948 289
    -965 293
    -983 297
    -1000 301
    -1018 305
    -1035 309
    -1053 313
    -1071 317
    1067 311
    1049 307
    1031 303
    1014 299
    996 295
    979 292
    961 288
    944 284
    927 280
    910 276
    893 272
    876 268
    859 264
    842 260
    825 256
    809 252
    792 248
    776 244
    760 240
    743 235
    727 231
    711 227
    695 223
    679 219
    664 215
    648 211
    632 207
    617 203
    601 199
    586 194
    571 190
    556 186
    541 182
    526 178
    511 174
    496 169
    482 165
    467 161
    453 157
    438 153
    424 148
    410 144
    396 140
    382 136
    368 132
    355 127
    341 123
    328 119
    314 115
    301 110
    288 106
    275 102
    262 98
    249 93
    236 89
    224 85
    211 80
    199 76
    187 72
    174 67
    162 63
    150 59
    139 54
    127 50
    115 46
    104 41
    92 37
    81 33
    70 28
    59 24
    48 20
    37 15
    27 11
    16 7
    6 2
    -5 -2
    -15 -6
    -25 -11
    -35 -15
    -45 -19
    -54 -24
    -64 -28
    -73 -32
    -82 -37
    -92 -41
    -101 -45
    -110 -50
    -118 -54
    -127 -59
    -136 -63
    -144 -67
    -152 -72
    -160 -76
    -168 -80
    -176 -85
    -184 -89
    -192 -93
    -199 -98
    -207 -102
    -214 -106
    -221 -110
    -228 -115
    -235 -119
    -241 -123
    -248 -128
    -254 -132
    -261 -136
    -267 -140
    -273 -145
    -279 -149
    -285 -153
    -290 -157
    -296 -162
    -301 -166
    -306 -170
    -311 -174
    -316 -179
    -321 -183
    -326 -187
    -330 -191
    -335 -195
    -339 -199
    -343 -203
    -347 -208
    -351 -212
    -354 -216
    -358 -220
    -361 -224
    -365 -228
    -368 -232
    -371 -236
    -374 -240
    -376 -244
    -379 -248
    -381 -252
    -384 -256
    -386 -260
    -388 -264
    -390 -267
    -392 -271
    -393 -275
    -395 -279
    -396 -283
    -397 -287
    -398 -290
    -399 -294
    -400 -298
    -401 -302
    -401 -305
    -402 -309
    -402 -312
    -402 -316
    -402 -320
    -402 -323
    -401 -327
    -401 -330
    -401 -334
    -400 -337
    -399 -341
    -398 -344
    -397 -347
    -396 -351
    -395 -354
    -393 -357
    -392 -361
    -390 -364
    -388 -367
    -386 -370
    -384 -373
    -382 -377
    -380 -380
    -377 -383
    -375 -386
    -372 -389
    -369 -392
    -366 -394
    -363 -397
    -360 -400
    -357 -403
    -354 -406
    -350 -409
    -347 -411
    -343 -414
    -339 -416
    -335 -419
    -331 -422
    -327 -424
    -323 -427
    -319 -429
    -314 -431
    -310 -434
    -305 -436
    -301 -438
    -296 -441
    -291 -443
    -286 -445
    -281 -447
    -276 -449
    -271 -451
    -265 -453
    -260 -455
    -255 -457
    -249 -459
    -243 -461
    -238 -462
    -232 -464
    -226 -466
    -220 -467
    -214 -469
    -208 -471
    -202 -472
    -196 -473
    -190 -475
    -184 -476
    -177 -477
    -171 -479
    -165 -480
    -158 -481
    -152 -482
    -145 -483
    -138 -484
    -132 -485
    -125 -486
    -118 -487
    -112 -488
    -105 -489
    -98 -489
    -91 -490
    -84 -491
    -77 -491
    -70 -492
    -63 -492
    -56 -493
    -49 -493
    -42 -493
    -35 -494
    -28 -494
    -21 -494
    -14 -494
    -7 -494
    0 -494
    7 -494
    14 -494
    21 -494
    28 -494
    35 -494
    42 -493
    49 -493
    56 -493
    63 -492
    70 -492
    77 -491
    84 -491
    91 -490
    98 -489
    105 -489
    112 -488
    118 -487
    125 -486
    132 -485
    138 -484
    145 -483
    152 -482
    158 -481
    165 -480
    171 -479
    177 -477
    184 -476
    190 -475
    196 -473
    202 -472
    208 -471
    214 -469
    220 -467
    226 -466
    232 -464
    238 -462
    243 -461
    249 -459
    255 -457
    260 -455
    265 -453
    271 -451
    276 -449
    281 -447
    286 -445
    291 -443
    296 -441
    301 -438
    305 -436
    310 -434
    314 -431
    319 -429
    323 -427
    327 -424
    331 -422
    335 -419
    339 -416
    343 -414
    347 -411
    350 -409
    354 -406
    357 -403
    360 -400
    363 -397
    366 -394
    369 -392
    372 -389
    375 -386
    377 -383
    380 -380
    382 -377
    384 -373
    386 -370
    388 -367
    390 -364
    392 -361
    393 -357
    395 -354
    396 -351
    397 -347
    398 -344
    399 -341
    400 -337
    401 -334
    401 -330
    401 -327
    402 -323
    402 -320
    402 -316
    402 -312
    402 -309
    401 -305
    401 -302
    400 -298
    399 -294
    398 -290
    397 -287
    396 -283
    395 -279
    393 -275
    392 -271
    390 -267
    388 -264
    386 -260
    384 -256
    381 -252
    379 -248
    376 -244
    374 -240
    371 -236
    368 -232
    365 -228
    361 -224
    358 -220
    354 -216
    351 -212
    347 -208
    343 -203
    339 -199
    335 -195
    330 -191
    326 -187
    321 -183
    316 -179
    311 -174
    306 -170
    301 -166
    296 -162
    290 -157
    285 -153
    279 -149
    273 -145
    267 -140
    261 -136
    254 -132
    248 -128
    241 -123
    235 -119
    228 -115
    221 -110
    214 -106
    207 -102
    199 -98
    192 -93
    184 -89
    176 -85
    168 -80
    160 -76
    152 -72
    144 -67
    136 -63
    127 -59
    118 -54
    110 -50
    101 -45
    92 -41
    82 -37
    73 -32
    64 -28
    54 -24
    45 -19
    35 -15
    25 -11
    15 -6
    5 -2
    -6 2
    -16 7
    -27 11
    -37 15
    -48 20
    -59 24
    -70 28
    -81 33
    -92 37
    -104 41
    -115 46
    -127 50
    -139 54
    -150 59
    -162 63
    -174 67
    -187 72
    -199 76
    -211 80
    -224 85
    -236 89
    -249 93
    -262 98
    -275 102
    -288 106
    -301 110
    -314 115
    -328 119
    -341 123
    -355 127
    -368 132
    -382 136
    -396 140
    -410 144
    -424 148
    -438 153
    -453 157
    -467 161
    -482 165
    -496 169
    -511 174
    -526 178
    -541 182
    -556 186
    -571 190
    -586 194
    -601 199
    -617 203
    -632 207
    -648 211
    -664 215
    -679 219
    -695 223
    -711 227
    -727 231
    -743 235
    -760 240
    -776 244
    -792 248
    -809 252
    -825 256
    -842 260
    -859 264
    -876 268
    -893 272
    -910 276
    -927 280
    -944 284
    -961 288
    -979 292
    -996 295
    -1014 299
    -1031 303
    -1049 307
    -1067 311
    1063 306
    1045 302
    1027 298
    1010 294
    992 290
    975 286
    957 282
    940 278
    923 274
    906 271
    889 267
    872 263
    855 259
    838 255
    821 251
    805 247
    788 243
    772 239
    756 235
    739 231
    723 227
    707 223
    691 219
    675 215
    659 211
    644 207
    628 203
    613 198
    597 194
    582 190
    567 186
    552 182
    537 178
    522 174
    507 170
    492 166
    478 162
    463 157
    449 153
    434 149
    420 145
    406 141
    392 137
    378 132
    364 128
    351 124
    337 120
    323 116
    310 111
    297 107
    284 103
    271 99
    258 95
    245 90
    232 86
    219 82
    207 78
    195 73
    182 69
    170 65
    158 61
    146 56
    134 52
    122 48
    111 43
    99 39
    88 35
    77 31
    66 26
    55 22
    44 18
    33 13
    22 9
    12 5
    1 1
    -9 -4
    -19 -8
    -29 -12
    -39 -17
    -49 -21
    -59 -25
    -68 -30
    -78 -34
    -87 -38
    -96 -42
    -105 -47
    -114 -51
    -123 -55
    -131 -60
    -140 -64
    -148 -68
    -157 -73
    -165 -77
    -173 -81
    -181 -85
    -188 -90
    -196 -94
    -204 -98
    -211 -102
    -218 -107
    -225 -111
    -232 -115
    -239 -120
    -246 -124
    -252 -128
    -259 -132
    -265 -136
    -271 -141
    -277 -145
    -283 -149
    -289 -153
    -294 -157
    -300 -162
    -305 -166
    -310 -170
    -315 -174
    -320 -178
    -325 -182
    -330 -187
    -334 -191
    -339 -195
    -343 -199
    -347 -203
    -351 -207
    -355 -211
    -358 -215
    -362 -219
    -365 -223
    -369 -227
    -372 -231
    -375 -235
    -378 -239
    -380 -243
    -383 -247
    -385 -251
    -388 -255
    -390 -259
    -392 -262
    -394 -266
    -395 -270
    -397 -274
    -398 -278
    -400 -281
    -401 -285
    -402 -289
    -403 -293
    -404 -296
    -404 -300
    -405 -304
    -405 -307
    -405 -311
    -405 -314
    -405 -318
    -405 -321
    -405 -325
    -405 -328
    -404 -332
    -403 -335
    -402 -339
    -401 -342
    -400 -345
    -399 -349
    -398 -352
    -396 -355
    -395 -358
    -393 -362
    -391 -365
    -389 -368
    -387 -371
    -385 -374
    -383 -377
    -380 -380
    -378 -383
    -375 -386
    -372 -389
    -369 -392
    -366 -395
    -363 -398
    -360 -400
    -356 -403
    -353 -406
    -349 -408
    -346 -411
    -342 -414
    -338 -416
    -334 -419
    -330 -421
    -325 -424
    -321 -426
    -317 -428
    -312 -431
    -308 -433
    -303 -435
    -298 -438
    -293 -440
    -288 -442
    -283 -444
    -278 -446
    -273 -448
    -267 -450
    -262 -452
    -256 -454
    -251 -456
    -245 -457
    -240 -459
    -234 -461
    -228 -462
    -222 -464
    -216 -466
    -210 -467
    -204 -469
    -198 -470
    -191 -471
    -185 -473
    -179 -474
    -172 -475
    -166 -476
    -159 -478
    -153 -479
    -146 -480
    -139 -481
    -133 -482
    -126 -483
    -119 -484
    -112 -484
    -105 -485
    -99 -486
    -92 -486
    -85 -487
    -78 -488
    -71 -488
    -64 -489
    -57 -489
    -50 -489
    -43 -490
    -36 -490
    -28 -490
    -21 -490
    -14 -491
    -7 -491
    0 -491
    7 -491
    14 -491
    21 -490
    28 -490
    36 -490
    43 -490
    50 -489
    57 -489
    64 -489
    71 -488
    78 -488
    85 -487
    92 -486
    99 -486
    105 -485
    112 -484
    119 -484
    126 -483
    133 -482
    139 -481
    146 -480
    153 -479
    159 -478
    166 -476
    172 -475
    179 -474
    185 -473
    191 -471
    198 -470
    204 -469
    210 -467
    216 -466
    222 -464
    228 -462
    234 -461
    240 -459
    245 -457
    251 -456
    256 -454
    262 -452
    267 -450
    273 -448
    278 -446
    283 -444
    288 -442
    293 -440
    298 -438
    303 -435
    308 -433
    312 -431
    317 -428
    321 -426
    325 -424
    330 -421
    334 -419
    338 -416
    342 -414
    346 -411
    349 -408
    353 -406
    356 -403
    360 -400
    363 -398
    366 -395
    369 -392
    372 -389
    375 -386
    378 -383
    380 -380
    383 -377
    385 -374
    387 -371
    389 -368
    391 -365
    393 -362
    395 -358
    396 -355
    398 -352
    399 -349
    400 -345
    401 -342
    402 -339
    403 -335
    404 -332
    405 -328
    405 -325
    405 -321
    405 -318
    405 -314
    405 -311
    405 -307
    405 -304
    404 -300
    404 -296
    403 -293
    402 -289
    401 -285
    400 -281
    398 -278
    397 -274
    395 -270
    394 -266
    392 -262
    390 -259
    388 -255
    385 -251
    383 -247
    380 -243
    378 -239
    375 -235
    372 -231
    369 -227
    365 -223
    362 -219
    358 -215
    355 -211
    351 -207
    347 -203
    343 -199
    339 -195
    334 -191
    330 -187
    325 -182
    320 -178
    315 -174
    310 -170
    305 -166
    300 -162
    294 -157
    289 -153
    283 -149
    277 -145
    271 -141
    265 -136
    259 -132
    252 -128
    246 -124
    239 -120
    232 -115
    225 -111
    218 -107
    211 -102
    204 -98
    196 -94
    188 -90
    181 -85
    173 -81
    165 -77
    157 -73
    148 -68
    140 -64
    131 -60
    123 -55
    114 -51
    105 -47
    96 -42
    87 -38
    78 -34
    68 -30
    59 -25
    49 -21
    39 -17
    29 -12
    19 -8
    9 -4
    -1 1
    -12 5
    -22 9
    -33 13
    -44 18
    -55 22
    -66 26
    -77 31
    -88 35
    -99 39
    -111 43
    -122 48
    -134 52
    -146 56
    -158 61
    -170 65
    -182 69
    -195 73
    -207 78
    -219 82
    -232 86
    -245 90
    -258 95
    -271 99
    -284 103
    -297 107
    -310 111
    -323 116
    -337 120
    -351 124
    -364 128
    -378 132
    -392 137
    -406 141
    -420 145
    -434 149
    -449 153
    -463 157
    -478 162
    -492 166
    -507 170
    -522 174
    -537 178
    -552 182
    -567 186
    -582 190
    -597 194
    -613 198
    -628 203
    -644 207
    -659 211
    -675 215
    -691 219
    -707 223
    -723 227
    -739 231
    -756 235
    -772 239
    -788 243
    -805 247
    -821 251
    -838 255
    -855 259
    -872 263
    -889 267
    -906 271
    -923 274
    -940 278
    -957 282
    -975 286
    -992 290
    -1010 294
    -1027 298
    -1045 302
    -1063 306
    1059 300
    1041 296
    1024 292
    1006 289
    988 285
    971 281
    954 277
    936 273
    919 269
    902 265
    885 262
    868 258
    851 254
    834 250
    818 246
    801 242
    784 238
    768 234
    752 230
    735 226
    719 222
    703 218
    687 214
    671 210
    655 206
    640 202
    624 198
    609 194
    593 190
    578 186
    563 182
    548 178
    533 174
    518 170
    503 166
    488 162
    473 158
    459 154
    444 150
    430 146
    416 141
    402 137
    388 133
    374 129
    360 125
    346 121
    333 117
    319 112
    306 108
    293 104
    279 100
    266 96
    253 92
    241 87
    228 83
    215 79
    203 75
    190 71
    178 67
    166 62
    154 58
    142 54
    130 50
    118 45
    107 41
    95 37
    84 33
    73 29
    61 24
    50 20
    39 16
    29 12
    18 7
    8 3
    -3 -1
    -13 -5
    -23 -10
    -33 -14
    -43 -18
    -53 -22
    -63 -27
    -72 -31
    -82 -35
    -91 -39
    -100 -44
    -109 -48
    -118 -52
    -127 -56
    -136 -61
    -144 -65
    -153 -69
    -161 -73
    -169 -78
    -177 -82
    -185 -86
    -193 -90
    -200 -95
    -208 -99
    -215 -103
    -222 -107
    -229 -111
    -236 -116
    -243 -120
    -250 -124
    -256 -128
    -263 -132
    -269 -137
    -275 -141
    -281 -145
    -287 -149
    -293 -153
    -299 -157
    -304 -162
    -309 -166
    -315 -170
    -320 -174
    -324 -178
    -329 -182
    -334 -186
    -338 -190
    -343 -194
    -347 -198
    -351 -202
    -355 -206
    -359 -210
    -362 -214
    -366 -218
    -369 -222
    -373 -226
    -376 -230
    -379 -234
    -382 -238
    -384 -242
    -387 -246
    -389 -250
    -391 -254
    -394 -257
    -396 -261
    -397 -265
    -399 -269
    -401 -272
    -402 -276
    -403 -280
    -405 -284
    -406 -287
    -407 -291
    -407 -295
    -408 -298
    -408 -302
    -409 -305
    -409 -309
    -409 -313
    -409 -316
    -409 -319
    -408 -323
    -408 -326
    -407 -330
    -407 -333
    -406 -337
    -405 -340
    -404 -343
    -402 -346
    -401 -350
    -400 -353
    -398 -356
    -396 -359
    -394 -362
    -392 -365
    -390 -369
    -388 -372
    -386 -375
    -383 -378
    -381 -381
    -378 -383
    -375 -386
    -372 -389
    -369 -392
    -366 -395
    -362 -398
    -359 -400
    -356 -403
    -352 -406
    -348 -408
    -344 -411
    -340 -413
    -336 -416
    -332 -418
    -328 -421
    -324 -423
    -319 -425
    -314 -428
    -310 -430
    -305 -432
    -300 -434
    -295 -437
    -290 -439
    -285 -441
    -280 -443
    -275 -445
    -269 -447
    -264 -449
    -258 -450
    -253 -452
    -247 -454
    -241 -456
    -235 -457
    -229 -459
    -224 -461
    -217 -462
    -211 -464
    -205 -465
    -199 -466
    -193 -468
    -186 -469
    -180 -470
    -173 -472
    -167 -473
    -160 -474
    -154 -475
    -147 -476
    -140 -477
    -134 -478
    -127 -479
    -120 -480
    -113 -481
    -106 -481
    -99 -482
    -92 -483
    -85 -483
    -78 -484
    -71 -484
    -64 -485
    -57 -485
    -50 -486
    -43 -486
    -36 -486
    -29 -486
    -21 -487
    -14 -487
    -7 -487
    0 -487
    7 -487
    14 -487
    21 -487
    29 -486
    36 -486
    43 -486
    50 -486
    57 -485
    64 -485
    71 -484
    78 -484
    85 -483
    92 -483
    99 -482
    106 -481
    113 -481
    120 -480
    127 -479
    134 -478
    140 -477
    147 -476
    154 -475
    160 -474
    167 -473
    173 -472
    180 -470
    186 -469
    193 -468
    199 -466
    205 -465
    211 -464
    217 -462
    224 -461
    229 -459
    235 -457
    241 -456
    247 -454
    253 -452
    258 -450
    264 -449
    269 -447
    275 -445
    280 -443
    285 -441
    290 -439
    295 -437
    300 -434
    305 -432
    310 -430
    314 -428
    319 -425
    324 -423
    328 -421
    332 -418
    336 -416
    340 -413
    344 -411
    348 -408
    352 -406
    356 -403
    359 -400
    362 -398
    366 -395
    369 -392
    372 -389
    375 -386
    378 -383
    381 -381
    383 -378
    386 -375
    388 -372
    390 -369
    392 -365
    394 -362
    396 -359
    398 -356
    400 -353
    401 -350
    402 -346
    404 -343
    405 -340
    406 -337
    407 -333
    407 -330
    408 -326
    408 -323
    409 -319
    409 -316
    409 -313
    409 -309
    409 -305
    408 -302
    408 -298
    407 -295
    407 -291
    406 -287
    405 -284
    403 -280
    402 -276
    401 -272
    399 -269
    397 -265
    396 -261
    394 -257
    391 -254
    389 -250
    387 -246
    384 -242
    382 -238
    379 -234
    376 -230
    373 -226
    369 -222
    366 -218
    362 -214
    359 -210
    355 -206
    351 -202
    347 -198
    343 -194
    338 -190
    334 -186
    329 -182
    324 -178
    320 -174
    315 -170
    309 -166
    304 -162
    299 -157
    293 -153
    287 -149
    281 -145
    275 -141
    269 -137
    263 -132
    256 -128
    250 -124
    243 -120
    236 -116
    229 -111
    222 -107
    215 -103
    208 -99
    200 -95
    193 -90
    185 -86
    177 -82
    169 -78
    161 -73
    153 -69
    144 -65
    136 -61
    127 -56
    118 -52
    109 -48
    100 -44
    91 -39
    82 -35
    72 -31
    63 -27
    53 -22
    43 -18
    33 -14
    23 -10
    13 -5
    3 -1
    -8 3
    -18 7
    -29 12
    -39 16
    -50 20
    -61 24
    -73 29
    -84 33
    -95 37
    -107 41
    -118 45
    -130 50
    -142 54
    -154 58
    -166 62
    -178 67
    -190 71
    -203 75
    -215 79
    -228 83
    -241 87
    -253 92
    -266 96
    -279 100
    -293 104
    -306 108
    -319 112
    -333 117
    -346 121
    -360 125
    -374 129
    -388 133
    -402 137
    -416 141
    -430 146
    -444 150
    -459 154
    -473 158
    -488 162
    -503 166
    -518 170
    -533 174
    -548 178
    -563 182
    -578 186
    -593 190
    -609 194
    -624 198
    -640 202
    -655 206
    -671 210
    -687 214
    -703 218
    -719 222
    -735 226
    -752 230
    -768 234
    -784 238
    -801 242
    -818 246
    -834 250
    -851 254
    -868 258
    -885 262
    -902 265
    -919 269
    -936 273
    -954 277
    -971 281
    -988 285
    -1006 289
    -1024 292
    -1041 296
    -1059 300
    1055 295
    1038 291
    1020 287
    1002 283
    985 280
    967 276
    950 272
    932 268
    915 264
    898 260
    881 257
    864 253
    847 249
    830 245
    814 241
    797 237
    780 233
    764 230
    748 226
    731 222
    715 218
    699 214
    683 210
    667 206
    651 202
    636 198
    620 194
    605 190
    589 186
    574 182
    559 178
    544 174
    529 170
    514 166
    499 162
    484 158
    469 154
    455 150
    440 146
    426 142
    412 138
    398 134
    384 130
    370 126
    356 122
    342 118
    329 113
    315 109
    302 105
    288 101
    275 97
    262 93
    249 89
    236 85
    224 81
    211 76
    199 72
    186 68
    174 64
    162 60
    150 56
    138 52
    126 47
    114 43
    102 39
    91 35
    80 31
    68 26
    57 22
    46 18
    35 14
    24 10
    14 6
    3 1
    -7 -3
    -17 -7
    -28 -11
    -38 -15
    -48 -20
    -57 -24
    -67 -28
    -77 -32
    -86 -36
    -95 -41
    -104 -45
    -114 -49
    -122 -53
    -131 -57
    -140 -62
    -148 -66
    -157 -70
    -165 -74
    -173 -78
    -181 -83
    -189 -87
    -197 -91
    -205 -95
    -212 -99
    -219 -103
    -227 -108
    -234 -112
    -241 -116
    -247 -120
    -254 -124
    -261 -128
    -267 -133
    -273 -137
    -279 -141
    -285 -145
    -291 -149
    -297 -153
    -303 -157
    -308 -161
    -313 -165
    -319 -169
    -324 -173
    -329 -178
    -333 -182
    -338 -186
    -342 -190
    -347 -194
    -351 -198
    -355 -202
    -359 -206
    -363 -210
    -366 -213
    -370 -217
    -373 -221
    -377 -225
    -380 -229
    -383 -233
    -385 -237
    -388 -241
    -391 -245
    -393 -248
    -395 -252
    -397 -256
    -399 -260
    -401 -264
    -403 -267
    -404 -271
    -406 -275
    -407 -278
    -408 -282
    -409 -286
    -410 -289
    -411 -293
    -411 -296
    -412 -300
    -412 -304
    -412 -307
    -413 -311
    -412 -314
    -412 -317
    -412 -321
    -411 -324
    -411 -328
    -410 -331
    -409 -334
    -408 -338
    -407 -341
    -406 -344
    -404 -347
    -403 -350
    -401 -354
    -399 -357
    -397 -360
    -395 -363
    -393 -366
    -391 -369
    -389 -372
    -386 -375
    -383 -378
    -381 -381
    -378 -384
    -375 -386
    -372 -389
    -369 -392
    -365 -395
    -362 -397
    -358 -400
    -355 -403
    -351 -405
    -347 -408
    -343 -410
    -339 -413
    -335 -415
    -330 -417
    -326 -420
    -321 -422
    -317 -424
    -312 -427
    -307 -429
    -302 -431
    -297 -433
    -292 -435
    -287 -437
    -282 -439
    -277 -441
    -271 -443
    -266 -445
    -260 -447
    -254 -449
    -249 -450
    -243 -452
    -237 -454
    -231 -455
    -225 -457
    -219 -459
    -213 -460
    -207 -461
    -200 -463
    -194 -464
    -188 -465
    -181 -467
    -175 -468
    -168 -469
    -161 -470
    -155 -471
    -148 -472
    -141 -473
    -134 -474
    -128 -475
    -121 -476
    -114 -477
    -107 -478
    -100 -478
    -93 -479
    -86 -480
    -79 -480
    -72 -481
    -65 -481
    -57 -481
    -50 -482
    -43 -482
    -36 -482
    -29 -483
    -22 -483
    -14 -483
    -7 -483
    0 -483
    7 -483
    14 -483
    22 -483
    29 -483
    36 -482
    43 -482
    50 -482
    57 -481
    65 -481
    72 -481
    79 -480
    86 -480
    93 -479
    100 -478
    107 -478
    114 -477
    121 -476
    128 -475
    134 -474
    141 -473
    148 -472
    155 -471
    161 -470
    168 -469
    175 -468
    181 -467
    188 -465
    194 -464
    200 -463
    207 -461
    213 -460
    219 -459
    225 -457
    231 -455
    237 -454
    243 -452
    249 -450
    254 -449
    260 -447
    266 -445
    271 -443
    277 -441
    282 -439
    287 -437
    292 -435
    297 -433
    302 -431
    307 -429
    312 -427
    317 -424
    321 -422
    326 -420
    330 -417
    335 -415
    339 -413
    343 -410
    347 -408
    351 -405
    355 -403
    358 -400
    362 -397
    365 -395
    369 -392
    372 -389
    375 -386
    378 -384
    381 -381
    383 -378
    386 -375
    389 -372
    391 -369
    393 -366
    395 -363
    397 -360
    399 -357
    401 -354
    403 -350
    404 -347
    406 -344
    407 -341
    408 -338
    409 -334
    410 -331
    411 -328
    411 -324
    412 -321
    412 -317
    412 -314
    413 -311
    412 -307
    412 -304
    412 -300
    411 -296
    411 -293
    410 -289
    409 -286
    408 -282
    407 -278
    406 -275
    404 -271
    403 -267
    401 -264
    399 -260
    397 -256
    395 -252
    393 -248
    391 -245
    388 -241
    385 -237
    383 -233
    380 -229
    377 -225
    373 -221
    370 -217
    366 -213
    363 -210
    359 -206
    355 -202
    351 -198
    347 -194
    342 -190
    338 -186
    333 -182
    329 -178
    324 -173
    319 -169
    313 -165
    308 -161
    303 -157
    297 -153
    291 -149
    285 -145
    279 -141
    273 -137
    267 -133
    261 -128
    254 -124
    247 -120
    241 -116
    234 -112
    227 -108
    219 -103
    212 -99
    205 -95
    197 -91
    189 -87
    181 -83
    173 -78
    165 -74
    157 -70
    148 -66
    140 -62
    131 -57
    122 -53
    114 -49
    104 -45
    95 -41
    86 -36
    77 -32
    67 -28
    57 -24
    48 -20
    38 -15
    28 -11
    17 -7
    7 -3
    -3 1
    -14 6
    -24 10
    -35 14
    -46 18
    -57 22
    -68 26
    -80 31
    -91 35
    -102 39
    -114 43
    -126 47
    -138 52
    -150 56
    -162 60
    -174 64
    -186 68
    -199 72
    -211 76
    -224 81
    -236 85
    -249 89
    -262 93
    -275 97
    -288 101
    -302 105
    -315 109
    -329 113
    -342 118
    -356 122
    -370 126
    -384 130
    -398 134
    -412 138
    -426 142
    -440 146
    -455 150
    -469 154
    -484 158
    -499 162
    -514 166
    -529 170
    -544 174
    -559 178
    -574 182
    -589 186
    -605 190
    -620 194
    -636 198
    -651 202
    -667 206
    -683 210
    -699 214
    -715 218
    -731 222
    -748 226
    -764 230
    -780 233
    -797 237
    -814 241
    -830 245
    -847 249
    -864 253
    -881 257
    -898 260
    -915 264
    -932 268
    -950 272
    -967 276
    -985 280
    -1002 283
    -1020 287
    -1038 291
    -1055 295
    1052 289
    1034 285
    1016 282
    998 278
    981 274
    963 271
    946 267
    929 263
    911 259
    894 255
    877 252
    860 248
    843 244
    826 240
    810 236
    793 233
    777 229
    760 225
    744 221
    728 217
    711 213
    695 210
    679 206
    663 202
    648 198
    632 194
    616 190
    601 186
    585 182
    570 178
    555 174
    540 170
    525 166
    510 162
    495 159
    480 155
    465 151
    451 147
    436 143
    422 139
    408 135
    394 131
    380 127
    366 123
    352 118
    338 114
    325 110
    311 106
    298 102
    284 98
    271 94
    258 90
    245 86
    232 82
    220 78
    207 74
    194 70
    182 66
    170 62
    157 57
    145 53
    133 49
    122 45
    110 41
    98 37
    87 33
    75 29
    64 24
    53 20
    42 16
    31 12
    20 8
    10 4
    -1 -0
    -11 -4
    -22 -9
    -32 -13
    -42 -17
    -52 -21
    -62 -25
    -71 -29
    -81 -34
    -90 -38
    -99 -42
    -109 -46
    -118 -50
    -127 -54
    -135 -58
    -144 -63
    -153 -67
    -161 -71
    -169 -75
    -177 -79
    -185 -83
    -193 -87
    -201 -92
    -209 -96
    -216 -100
    -223 -104
    -231 -108
    -238 -112
    -245 -116
    -252 -120
    -258 -124
    -265 -128
    -271 -133
    -277 -137
    -284 -141
    -290 -145
    -295 -149
    -301 -153
    -307 -157
    -312 -161
    -317 -165
    -323 -169
    -328 -173
    -333 -177
    -337 -181
    -342 -185
    -346 -189
    -351 -193
    -355 -197
    -359 -201
    -363 -205
    -367 -209
    -370 -213
    -374 -216
    -377 -220
    -380 -224
    -384 -228
    -386 -232
    -389 -236
    -392 -239
    -394 -243
    -397 -247
    -399 -251
    -401 -255
    -403 -258
    -405 -262
    -407 -266
    -408 -269
    -410 -273
    -411 -277
    -412 -280
    -413 -284
    -414 -287
    -414 -291
    -415 -295
    -415 -298
    -416 -302
    -416 -305
    -416 -308
    -416 -312
    -416 -315
    -415 -319
    -415 -322
    -414 -325
    -413 -329
    -412 -332
    -411 -335
    -410 -338
    -409 -342
    -408 -345
    -406 -348
    -404 -351
    -402 -354
    -401 -357
    -398 -360
    -396 -363
    -394 -366
    -392 -369
    -389 -372
    -386 -375
    -384 -378
    -381 -381
    -378 -383
    -374 -386
    -371 -389
    -368 -392
    -364 -394
    -361 -397
    -357 -399
    -353 -402
    -349 -405
    -345 -407
    -341 -409
    -337 -412
    -333 -414
    -328 -417
    -324 -419
    -319 -421
    -314 -423
    -309 -425
    -305 -428
    -299 -430
    -294 -432
    -289 -434
    -284 -436
    -279 -438
    -273 -440
    -268 -441
    -262 -443
    -256 -445
    -250 -447
    -245 -448
    -239 -450
    -233 -452
    -227 -453
    -220 -455
    -214 -456
    -208 -458
    -202 -459
    -195 -460
    -189 -462
    -182 -463
    -176 -464
    -169 -465
    -163 -466
    -156 -467
    -149 -468
    -142 -469
    -135 -470
    -129 -471
    -122 -472
    -115 -473
    -108 -474
    -101 -474
    -94 -475
    -86 -476
    -79 -476
    -72 -477
    -65 -477
    -58 -477
    -51 -478
    -43 -478
    -36 -478
    -29 -479
    -22 -479
    -15 -479
    -7 -479
    0 -479
    7 -479
    15 -479
    22 -479
    29 -479
    36 -478
    43 -478
    51 -478
    58 -477
    65 -477
    72 -477
    79 -476
    86 -476
    94 -475
    101 -474
    108 -474
    115 -473
    122 -472
    129 -471
    135 -470
    142 -469
    149 -468
    156 -467
    163 -466
    169 -465
    176 -464
    182 -463
    189 -462
    195 -460
    202 -459
    208 -458
    214 -456
    220 -455
    227 -453
    233 -452
    239 -450
    245 -448
    250 -447
    256 -445
    262 -443
    268 -441
    273 -440
    279 -438
    284 -436
    289 -434
    294 -432
    299 -430
    305 -428
    309 -425
    314 -423
    319 -421
    324 -419
    328 -417
    333 -414
    337 -412
    341 -409
    345 -407
    349 -405
    353 -402
    357 -399
    361 -397
    364 -394
    368 -392
    371 -389
    374 -386
    378 -383
    381 -381
    384 -378
    386 -375
    389 -372
    392 -369
    394 -366
    396 -363
    398 -360
    401 -357
    402 -354
    404 -351
    406 -348
    408 -345
    409 -342
    410 -338
    411 -335
    412 -332
    413 -329
    414 -325
    415 -322
    415 -319
    416 -315
    416 -312
    416 -308
    416 -305
    416 -302
    415 -298
    415 -295
    414 -291
    414 -287
    413 -284
    412 -280
    411 -277
    410 -273
    408 -269
    407 -266
    405 -262
    403 -258
    401 -255
    399 -251
    397 -247
    394 -243
    392 -239
    389 -236
    386 -232
    384 -228
    380 -224
    377 -220
    374 -216
    370 -213
    367 -209
    363 -205
    359 -201
    355 -197
    351 -193
    346 -189
    342 -185
    337 -181
    333 -177
    328 -173
    323 -169
    317 -165
    312 -161
    307 -157
    301 -153
    295 -149
    290 -145
    284 -141
    277 -137
    271 -133
    265 -128
    258 -124
    252 -120
    245 -116
    238 -112
    231 -108
    223 -104
    216 -100
    209 -96
    201 -92
    193 -87
    185 -83
    177 -79
    169 -75
    161 -71
    153 -67
    144 -63
    135 -58
    127 -54
    118 -50
    109 -46
    99 -42
    90 -38
    81 -34
    71 -29
    62 -25
    52 -21
    42 -17
    32 -13
    22 -9
    11 -4
    1 -0
    -10 4
    -20 8
    -31 12
    -42 16
    -53 20
    -64 24
    -75 29
    -87 33
    -98 37
    -110 41
    -122 45
    -133 49
    -145 53
    -157 57
    -170 62
    -182 66
    -194 70
    -207 74
    -220 78
    -232 82
    -245 86
    -258 90
    -271 94
    -284 98
    -298 102
    -311 106
    -325 110
    -338 114
    -352 118
    -366 123
    -380 127
    -394 131
    -408 135
    -422 139
    -436 143
    -451 147
    -465 151
    -480 155
    -495 159
    -510 162
    -525 166
    -540 170
    -555 174
    -570 178
    -585 182
    -601 186
    -616 190
    -632 194
    -648 198
    -663 202
    -679 206
    -695 210
    -711 213
    -728 217
    -744 221
    -760 225
    -777 229
    -793 233
    -810 236
    -826 240
    -843 244
    -860 248
    -877 252
    -894 255
    -911 259
    -929 263
    -946 267
    -963 271
    -981 274
    -998 278
    -1016 282
    -1034 285
    -1052 289
    1048 284
    1030 280
    1012 276
    995 273
    977 269
    960 265
    942 262
    925 258
    908 254
    890 251
    873 247
    856 243
    840 239
    823 236
    806 232
    789 228
    773 224
    756 220
    740 217
    724 213
    708 209
    691 205
    675 201
    660 198
    644 194
    628 190
    612 186
    597 182
    581 178
    566 174
    551 170
    536 167
    521 163
    506 159
    491 155
    476 151
    461 147
    447 143
    432 139
    418 135
    404 131
    390 127
    376 123
    362 119
    348 115
    334 111
    321 107
    307 103
    294 99
    280 95
    267 91
    254 87
    241 83
    228 79
    215 75
    203 71
    190 67
    178 63
    166 59
    153 55
    141 51
    129 47
    118 43
    106 39
    94 35
    83 31
    71 27
    60 23
    49 18
    38 14
    27 10
    16 6
    6 2
    -5 -2
    -15 -6
    -26 -10
    -36 -14
    -46 -18
    -56 -22
    -66 -27
    -75 -31
    -85 -35
    -94 -39
    -104 -43
    -113 -47
    -122 -51
    -131 -55
    -140 -59
    -148 -63
    -157 -67
    -165 -72
    -173 -76
    -182 -80
    -190 -84
    -197 -88
    -205 -92
    -213 -96
    -220 -100
    -228 -104
    -235 -108
    -242 -112
    -249 -116
    -256 -120
    -262 -124
    -269 -128
    -275 -133
    -281 -137
    -288 -141
    -294 -145
    -299 -149
    -305 -153
    -311 -157
    -316 -161
    -321 -165
    -327 -169
    -332 -172
    -337 -176
    -341 -180
    -346 -184
    -350 -188
    -355 -192
    -359 -196
    -363 -200
    -367 -204
    -371 -208
    -374 -212
    -378 -215
    -381 -219
    -384 -223
    -387 -227
    -390 -231
    -393 -234
    -396 -238
    -398 -242
    -401 -246
    -403 -249
    -405 -253
    -407 -257
    -409 -260
    -410 -264
    -412 -268
    -413 -271
    -414 -275
    -415 -278
    -416 -282
    -417 -286
    -418 -289
    -419 -293
    -419 -296
    -419 -299
    -419 -303
    -419 -306
    -419 -310
    -419 -313
    -419 -316
    -418 -320
    -417 -323
    -417 -326
    -416 -329
    -415 -333
    -413 -336
    -412 -339
    -411 -342
    -409 -345
    -407 -348
    -406 -351
    -404 -354
    -401 -357
    -399 -360
    -397 -363
    -394 -366
    -392 -369
    -389 -372
    -386 -375
    -383 -378
    -380 -380
    -377 -383
    -374 -386
    -371 -388
    -367 -391
    -363 -394
    -360 -396
    -356 -399
    -352 -401
    -348 -404
    -344 -406
    -339 -408
    -335 -411
    -330 -413
    -326 -415
    -321 -418
    -316 -420
    -312 -422
    -307 -424
    -302 -426
    -296 -428
    -291 -430
    -286 -432
    -280 -434
    -275 -436
    -269 -438
    -264 -440
    -258 -441
    -252 -443
    -246 -445
    -240 -446
    -234 -448
    -228 -449
    -222 -451
    -216 -452
    -209 -454
    -203 -455
    -197 -456
    -190 -458
    -184 -459
    -177 -460
    -170 -461
    -164 -462
    -157 -463
    -150 -464
    -143 -465
    -136 -466
    -129 -467
    -122 -468
    -115 -469
    -108 -469
    -101 -470
    -94 -471
    -87 -471
    -80 -472
    -73 -472
    -65 -473
    -58 -473
    -51 -474
    -44 -474
    -36 -474
    -29 -474
    -22 -475
    -15 -475
    -7 -475
    0 -475
    7 -475
    15 -475
    22 -475
    29 -474
    36 -474
    44 -474
    51 -474
    58 -473
    65 -473
    73 -472
    80 -472
    87 -471
    94 -471
    101 -470
    108 -469
    115 -469
    122 -468
    129 -467
    136 -466
    143 -465
    150 -464
    157 -463
    164 -462
    170 -461
    177 -460
    184 -459
    190 -458
    197 -456
    203 -455
    209 -454
    216 -452
    222 -451
    228 -449
    234 -448
    240 -446
    246 -445
    252 -443
    258 -441
    264 -440
    269 -438
    275 -436
    280 -434
    286 -432
    291 -430
    296 -428
    302 -426
    307 -424
    312 -422
    316 -420
    321 -418
    326 -415
    330 -413
    335 -411
    339 -408
    344 -406
    348 -404
    352 -401
    356 -399
    360 -396
    363 -394
    367 -391
    371 -388
    374 -386
    377 -383
    380 -380
    383 -378
    386 -375
    389 -372
    392 -369
    394 -366
    397 -363
    399 -360
    401 -357
    404 -354
    406 -351
    407 -348
    409 -345
    411 -342
    412 -339
    413 -336
    415 -333
    416 -329
    417 -326
    417 -323
    418 -320
    419 -316
    419 -313
    419 -310
    419 -306
    419 -303
    419 -299
    419 -296
    419 -293
    418 -289
    417 -286
    416 -282
    415 -278
    414 -275
    413 -271
    412 -268
    410 -264
    409 -260
    407 -257
    405 -253
    403 -249
    401 -246
    398 -242
    396 -238
    393 -234
    390 -231
    387 -227
    384 -223
    381 -219
    378 -215
    374 -212
    371 -208
    367 -204
    363 -200
    359 -196
    355 -192
    350 -188
    346 -184
    341 -180
    337 -176
    332 -172
    327 -169
    321 -165
    316 -161
    311 -157
    305 -153
    299 -149
    294 -145
    288 -141
    281 -137
    275 -133
    269 -128
    262 -124
    256 -120
    249 -116
    242 -112
    235 -108
    228 -104
    220 -100
    213 -96
    205 -92
    197 -88
    190 -84
    182 -80
    173 -76
    165 -72
    157 -67
    148 -63
    140 -59
    131 -55
    122 -51
    113 -47
    104 -43
    94 -39
    85 -35
    75 -31
    66 -27
    56 -22
    46 -18
    36 -14
    26 -10
    15 -6
    5 -2
    -6 2
    -16 6
    -27 10
    -38 14
    -49 18
    -60 23
    -71 27
    -83 31
    -94 35
    -106 39
    -118 43
    -129 47
    -141 51
    -153 55
    -166 59
    -178 63
    -190 67
    -203 71
    -215 75
    -228 79
    -241 83
    -254 87
    -267 91
    -280 95
    -294 99
    -307 103
    -321 107
    -334 111
    -348 115
    -362 119
    -376 123
    -390 127
    -404 131
    -418 135
    -432 139
    -447 143
    -461 147
    -476 151
    -491 155
    -506 159
    -521 163
    -536 167
    -551 170
    -566 174
    -581 178
    -597 182
    -612 186
    -628 190
    -644 194
    -660 198
    -675 201
    -691 205
    -708 209
    -724 213
    -740 217
    -756 220
    -773 224
    -789 228
    -806 232
    -823 236
    -840 239
    -856 243
    -873 247
    -890 251
    -908 254
    -925 258
    -942 262
    -960 265
    -977 269
    -995 273
    -1012 276
    -1030 280
    -1048 284
    1044 278
    1026 275
    1009 271
    991 268
    973 264
    956 260
    939 257
    921 253
    904 249
    887 246
    870 242
    853 238
    836 235
    819 231
    802 227
    786 223
    769 220
    753 216
    736 212
    720 208
    704 205
    688 201
    672 197
    656 193
    640 190
    624 186
    609 182
    593 178
    578 174
    562 171
    547 167
    532 163
    517 159
    502 155
    487 151
    472 147
    458 144
    443 140
    428 136
    414 132
    400 128
    386 124
    372 120
    358 116
    344 112
    330 108
    317 104
    303 100
    290 97
    276 93
    263 89
    250 85
    237 81
    224 77
    211 73
    199 69
    186 65
    174 61
    162 57
    149 53
    137 49
    125 45
    114 41
    102 37
    90 33
    79 29
    67 25
    56 21
    45 17
    34 13
    23 9
    12 5
    1 1
    -9 -3
    -19 -8
    -30 -12
    -40 -16
    -50 -20
    -60 -24
    -70 -28
    -79 -32
    -89 -36
    -98 -40
    -108 -44
    -117 -48
    -126 -52
    -135 -56
    -144 -60
    -152 -64
    -161 -68
    -169 -72
    -177 -76
    -186 -80
    -194 -84
    -201 -88
    -209 -92
    -217 -96
    -224 -100
    -232 -104
    -239 -108
    -246 -112
    -253 -116
    -260 -120
    -266 -124
    -273 -128
    -279 -132
    -285 -136
    -292 -140
    -298 -144
    -303 -148
    -309 -152
    -315 -156
    -320 -160
    -325 -164
    -331 -168
    -336 -172
    -340 -176
    -345 -180
    -350 -184
    -354 -187
    -359 -191
    -363 -195
    -367 -199
    -371 -203
    -374 -207
    -378 -210
    -382 -214
    -385 -218
    -388 -222
    -391 -225
    -394 -229
    -397 -233
    -399 -237
    -402 -240
    -404 -244
    -406 -248
    -409 -251
    -410 -255
    -412 -259
    -414 -262
    -415 -266
    -417 -269
    -418 -273
    -419 -276
    -420 -280
    -421 -283
    -421 -287
    -422 -290
    -422 -294
    -423 -297
    -423 -301
    -423 -304
    -423 -307
    -422 -311
    -422 -314
    -421 -317
    -421 -321
    -420 -324
    -419 -327
    -418 -330
    -417 -333
    -415 -336
    -414 -339
    -412 -343
    -410 -346
    -409 -349
    -407 -352
    -404 -355
    -402 -358
    -400 -360
    -397 -363
    -395 -366
    -392 -369
    -389 -372
    -386 -374
    -383 -377
    -380 -380
    -377 -383
    -373 -385
    -370 -388
    -366 -390
    -362 -393
    -358 -395
    -354 -398
    -350 -400
    -346 -403
    -342 -405
    -337 -407
    -333 -410
    -328 -412
    -323 -414
    -319 -416
    -314 -418
    -309 -420
    -304 -422
    -298 -424
    -293 -426
    -288 -428
    -282 -430
    -277 -432
    -271 -434
    -265 -436
    -260 -437
    -254 -439
    -248 -441
    -242 -442
    -236 -444
    -230 -445
    -223 -447
    -217 -448
    -211 -450
    -204 -451
    -198 -452
    -191 -454
    -185 -455
    -178 -456
    -171 -457
    -165 -458
    -158 -459
    -151 -460
    -144 -461
    -137 -462
    -130 -463
    -123 -464
    -116 -465
    -109 -465
    -102 -466
    -95 -467
    -88 -467
    -80 -468
    -73 -468
    -66 -469
    -59 -469
    -51 -469
    -44 -470
    -37 -470
    -29 -470
    -22 -470
    -15 -470
    -7 -470
    0 -471
    7 -470
    15 -470
    22 -470
    29 -470
    37 -470
    44 -470
    51 -469
    59 -469
    66 -469
    73 -468
    80 -468
    88 -467
    95 -467
    102 -466
    109 -465
    116 -465
    123 -464
    130 -463
    137 -462
    144 -461
    151 -460
    158 -459
    165 -458
    171 -457
    178 -456
    185 -455
    191 -454
    198 -452
    204 -451
    211 -450
    217 -448
    223 -447
    230 -445
    236 -444
    242 -442
    248 -441
    254 -439
    260 -437
    265 -436
    271 -434
    277 -432
    282 -430
    288 -428
    293 -426
    298 -424
    304 -422
    309 -420
    314 -418
    319 -416
    323 -414
    328 -412
    333 -410
    337 -407
    342 -405
    346 -403
    350 -400
    354 -398
    358 -395
    362 -393
    366 -390
    370 -388
    373 -385
    377 -383
    380 -380
    383 -377
    386 -374
    389 -372
    392 -369
    395 -366
    397 -363
    400 -360
    402 -358
    404 -355
    407 -352
    409 -349
    410 -346
    412 -343
    414 -339
    415 -336
    417 -333
    418 -330
    419 -327
    420 -324
    421 -321
    421 -317
    422 -314
    422 -311
    423 -307
    423 -304
    423 -301
    423 -297
    422 -294
    422 -290
    421 -287
    421 -283
    420 -280
    419 -276
    418 -273
    417 -269
    415 -266
    414 -262
    412 -259
    410 -255
    409 -251
    406 -248
    404 -244
    402 -240
    399 -237
    397 -233
    394 -229
    391 -225
    388 -222
    385 -218
    382 -214
    378 -210
    374 -207
    371 -203
    367 -199
    363 -195
    359 -191
    354 -187
    350 -184
    345 -180
    340 -176
    336 -172
    331 -168
    325 -164
    320 -160
    315 -156
    309 -152
    303 -148
    298 -144
    292 -140
    285 -136
    279 -132
    273 -128
    266 -124
    260 -120
    253 -116
    246 -112
    239 -108
    232 -104
    224 -100
    217 -96
    209 -92
    201 -88
    194 -84
    186 -80
    177 -76
    169 -72
    161 -68
    152 -64
    144 -60
    135 -56
    126 -52
    117 -48
    108 -44
    98 -40
    89 -36
    79 -32
    70 -28
    60 -24
    50 -20
    40 -16
    30 -12
    19 -8
    9 -3
    -1 1
    -12 5
    -23 9
    -34 13
    -45 17
    -56 21
    -67 25
    -79 29
    -90 33
    -102 37
    -114 41
    -125 45
    -137 49
    -149 53
    -162 57
    -174 61
    -186 65
    -199 69
    -211 73
    -224 77
    -237 81
    -250 85
    -263 89
    -276 93
    -290 97
    -303 100
    -317 104
    -330 108
    -344 112
    -358 116
    -372 120
    -386 124
    -400 128
    -414 132
    -428 136
    -443 140
    -458 144
    -472 147
    -487 151
    -502 155
    -517 159
    -532 163
    -547 167
    -562 171
    -578 174
    -593 178
    -609 182
    -624 186
    -640 190
    -656 193
    -672 197
    -688 201
    -704 205
    -720 208
    -736 212
    -753 216
    -769 220
    -786 223
    -802 227
    -819 231
    -836 235
    -853 238
    -870 242
    -887 246
    -904 249
    -921 253
    -939 257
    -956 260
    -973 264
    -991 268
    -1009 271
    -1026 275
    -1044 278
    1041 273
    1023 270
    1005 266
    987 262
    970 259
    952 255
    935 252
    918 248
    900 244
    883 241
    866 237
    849 234
    832 230
    815 226
    799 223
    782 219
    765 215
    749 212
    732 208
    716 204
    700 200
    684 197
    668 193
    652 189
    636 186
    620 182
    605 178
    589 174
    574 170
    558 167
    543 163
    528 159
    513 155
    498 152
    483 148
    468 144
    454 140
    439 136
    425 132
    410 129
    396 125
    382 121
    368 117
    354 113
    340 109
    326 105
    313 102
    299 98
    286 94
    272 90
    259 86
    246 82
    233 78
    220 74
    208 70
    195 66
    182 62
    170 58
    158 55
    145 51
    133 47
    121 43
    110 39
    98 35
    86 31
    75 27
    63 23
    52 19
    41 15
    30 11
    19 7
    8 3
    -3 -1
    -13 -5
    -23 -9
    -34 -13
    -44 -17
    -54 -21
    -64 -25
    -74 -29
    -83 -33
    -93 -37
    -102 -41
    -112 -45
    -121 -49
    -130 -53
    -139 -57
    -148 -61
    -156 -65
    -165 -69
    -173 -73
    -181 -77
    -190 -81
    -198 -85
    -205 -89
    -213 -93
    -221 -97
    -228 -101
    -236 -105
    -243 -108
    -250 -112
    -257 -116
    -264 -120
    -270 -124
    -277 -128
    -283 -132
    -289 -136
    -296 -140
    -302 -144
    -307 -148
    -313 -152
    -319 -156
    -324 -159
    -329 -163
    -334 -167
    -339 -171
    -344 -175
    -349 -179
    -354 -183
    -358 -186
    -362 -190
    -367 -194
    -371 -198
    -374 -202
    -378 -205
    -382 -209
    -385 -213
    -389 -217
    -392 -220
    -395 -224
    -398 -228
    -400 -231
    -403 -235
    -406 -239
    -408 -242
    -410 -246
    -412 -250
    -414 -253
    -416 -257
    -417 -260
    -419 -264
    -420 -267
    -421 -271
    -423 -274
    -423 -278
    -424 -281
    -425 -285
    -425 -288
    -426 -292
    -426 -295
    -426 -298
    -426 -302
    -426 -305
    -426 -308
    -425 -311
    -425 -315
    -424 -318
    -423 -321
    -422 -324
    -421 -327
    -420 -331
    -418 -334
    -417 -337
    -415 -340
    -413 -343
    -412 -346
    -410 -349
    -407 -352
    -405 -354
    -403 -357
    -400 -360
    -398 -363
    -395 -366
    -392 -369
    -389 -371
    -386 -374
    -383 -377
    -379 -379
    -376 -382
    -372 -384
    -368 -387
    -365 -389
    -361 -392
    -357 -394
    -353 -397
    -348 -399
    -344 -401
    -340 -404
    -335 -406
    -330 -408
    -326 -410
    -321 -412
    -316 -414
    -311 -417
    -306 -419
    -300 -421
    -295 -422
    -290 -424
    -284 -426
    -279 -428
    -273 -430
    -267 -432
    -261 -433
    -255 -435
    -250 -437
    -243 -438
    -237 -440
    -231 -441
    -225 -443
    -219 -444
    -212 -446
    -206 -447
    -199 -448
    -193 -449
    -186 -451
    -179 -452
    -173 -453
    -166 -454
    -159 -455
    -152 -456
    -145 -457
    -138 -458
    -131 -459
    -124 -459
    -117 -460
    -110 -461
    -103 -462
    -95 -462
    -88 -463
    -81 -463
    -74 -464
    -66 -464
    -59 -465
    -52 -465
    -44 -465
    -37 -466
    -30 -466
    -22 -466
    -15 -466
    -7 -466
    0 -466
    7 -466
    15 -466
    22 -466
    30 -466
    37 -466
    44 -465
    52 -465
    59 -465
    66 -464
    74 -464
    81 -463
    88 -463
    95 -462
    103 -462
    110 -461
    117 -460
    124 -459
    131 -459
    138 -458
    145 -457
    152 -456
    159 -455
    166 -454
    173 -453
    179 -452
    186 -451
    193 -449
    199 -448
    206 -447
    212 -446
    219 -444
    225 -443
    231 -441
    237 -440
    243 -438
    250 -437
    255 -435
    261 -433
    267 -432
    273 -430
    279 -428
    284 -426
    290 -424
    295 -422
    300 -421
    306 -419
    311 -417
    316 -414
    321 -412
    326 -410
    330 -408
    335 -406
    340 -404
    344 -401
    348 -399
    353 -397
    357 -394
    361 -392
    365 -389
    368 -387
    372 -384
    376 -382
    379 -379
    383 -377
    386 -374
    389 -371
    392 -369
    395 -366
    398 -363
    400 -360
    403 -357
    405 -354
    407 -352
    410 -349
    412 -346
    413 -343
    415 -340
    417 -337
    418 -334
    420 -331
    421 -327
    422 -324
    423 -321
    424 -318
    425 -315
    425 -311
    426 -308
    426 -305
    426 -302
    426 -298
    426 -295
    426 -292
    425 -288
    425 -285
    424 -281
    423 -278
    423 -274
    421 -271
    420 -267
    419 -264
    417 -260
    416 -257
    414 -253
    412 -250
    410 -246
    408 -242
    406 -239
    403 -235
    400 -231
    398 -228
    395 -224
    392 -220
    389 -217
    385 -213
    382 -209
    378 -205
    374 -202
    371 -198
    367 -194
    362 -190
    358 -186
    354 -183
    349 -179
    344 -175
    339 -171
    334 -167
    329 -163
    324 -159
    319 -156
    313 -152
    307 -148
    302 -144
    296 -140
    289 -136
    283 -132
    277 -128
    270 -124
    264 -120
    257 -116
    250 -112
    243 -108
    236 -105
    228 -101
    221 -97
    213 -93
    205 -89
    198 -85
    190 -81
    181 -77
    173 -73
    165 -69
    156 -65
    148 -61
    139 -57
    130 -53
    121 -49
    112 -45
    102 -41
    93 -37
    83 -33
    74 -29
    64 -25
    54 -21
    44 -17
    34 -13
    23 -9
    13 -5
    3 -1
    -8 3
    -19 7
    -30 11
    -41 15
    -52 19
    -63 23
    -75 27
    -86 31
    -98 35
    -110 39
    -121 43
    -133 47
    -145 51
    -158 55
    -170 58
    -182 62
    -195 66
    -208 70
    -220 74
    -233 78
    -246 82
    -259 86
    -272 90
    -286 94
    -299 98
    -313 102
    -326 105
    -340 109
    -354 113
    -368 117
    -382 121
    -396 125
    -410 129
    -425 132
    -439 136
    -454 140
    -468 144
    -483 148
    -498 152
    -513 155
    -528 159
    -543 163
    -558 167
    -574 170
    -589 174
    -605 178
    -620 182
    -636 186
    -652 189
    -668 193
    -684 197
    -700 200
    -716 204
    -732 208
    -749 212
    -765 215
    -782 219
    -799 223
    -815 226
    -832 230
    -849 234
    -866 237
    -883 241
    -900 244
    -918 248
    -935 252
    -952 255
    -970 259
    -987 262
    -1005 266
    -1023 270
    -1041 273
    1037 268
    1019 264
    1002 261
    984 257
    966 254
    949 250
    931 247
    914 243
    897 240
    879 236
    862 232
    845 229
    828 225
    812 222
    795 218
    778 214
    762 211
    745 207
    729 204
    712 200
    696 196
    680 193
    664 189
    648 185
    632 182
    617 178
    601 174
    585 170
    570 167
    555 163
    539 159
    524 156
    509 152
    494 148
    479 144
    465 140
    450 137
    435 133
    421 129
    406 125
    392 122
    378 118
    364 114
    350 110
    336 106
    322 103
    309 99
    295 95
    282 91
    269 87
    255 83
    242 79
    229 76
    216 72
    204 68
    191 64
    178 60
    166 56
    154 52
    142 48
    129 45
    117 41
    106 37
    94 33
    82 29
    71 25
    59 21
    48 17
    37 13
    26 9
    15 5
    4 2
    -6 -2
    -17 -6
    -27 -10
    -38 -14
    -48 -18
    -58 -22
    -68 -26
    -78 -30
    -87 -34
    -97 -38
    -106 -42
    -116 -46
    -125 -50
    -134 -54
    -143 -57
    -152 -61
    -160 -65
    -169 -69
    -177 -73
    -185 -77
    -194 -81
    -202 -85
    -209 -89
    -217 -93
    -225 -97
    -232 -101
    -240 -105
    -247 -108
    -254 -112
    -261 -116
    -268 -120
    -274 -124
    -281 -128
    -287 -132
    -293 -136
    -299 -140
    -305 -143
    -311 -147
    -317 -151
    -322 -155
    -328 -159
    -333 -163
    -338 -166
    -343 -170
    -348 -174
    -353 -178
    -357 -182
    -362 -185
    -366 -189
    -370 -193
    -374 -197
    -378 -200
    -382 -204
    -386 -208
    -389 -212
    -392 -215
    -395 -219
    -399 -223
    -401 -226
    -404 -230
    -407 -233
    -409 -237
    -411 -241
    -414 -244
    -416 -248
    -418 -251
    -419 -255
    -421 -258
    -422 -262
    -424 -265
    -425 -269
    -426 -272
    -427 -276
    -428 -279
    -428 -282
    -429 -286
    -429 -289
    -429 -293
    -429 -296
    -429 -299
    -429 -302
    -429 -306
    -428 -309
    -428 -312
    -427 -315
    -426 -318
    -425 -321
    -424 -325
    -423 -328
    -421 -331
    -420 -334
    -418 -337
    -416 -340
    -414 -343
    -412 -346
    -410 -348
    -408 -351
    -406 -354
    -403 -357
    -400 -360
    -398 -362
    -395 -365
    -392 -368
    -388 -371
    -385 -373
    -382 -376
    -378 -378
    -375 -381
    -371 -383
    -367 -386
    -363 -388
    -359 -391
    -355 -393
    -351 -395
    -346 -398
    -342 -400
    -337 -402
    -333 -404
    -328 -406
    -323 -408
    -318 -411
    -313 -413
    -308 -415
    -302 -417
    -297 -418
    -292 -420
    -286 -422
    -280 -424
    -275 -426
    -269 -428
    -263 -429
    -257 -431
    -251 -432
    -245 -434
    -239 -436
    -233 -437
    -226 -438
    -220 -440
    -214 -441
    -207 -443
    -200 -444
    -194 -445
    -187 -446
    -180 -447
    -174 -448
    -167 -450
    -160 -451
    -153 -452
    -146 -452
    -139 -453
    -132 -454
    -125 -455
    -118 -456
    -110 -456
    -103 -457
    -96 -458
    -89 -458
    -81 -459
    -74 -459
    -67 -460
    -59 -460
    -52 -460
    -45 -461
    -37 -461
    -30 -461
    -22 -461
    -15 -461
    -7 -462
    0 -462
    7 -462
    15 -461
    22 -461
    30 -461
    37 -461
    45 -461
    52 -460
    59 -460
    67 -460
    74 -459
    81 -459
    89 -458
    96 -458
    103 -457
    110 -456
    118 -456
    125 -455
    132 -454
    139 -453
    146 -452
    153 -452
    160 -451
    167 -450
    174 -448
    180 -447
    187 -446
    194 -445
    200 -444
    207 -443
    214 -441
    220 -440
    226 -438
    233 -437
    239 -436
    245 -434
    251 -432
    257 -431
    263 -429
    269 -428
    275 -426
    280 -424
    286 -422
    292 -420
    297 -418
    302 -417
    308 -415
    313 -413
    318 -411
    323 -408
    328 -406
    333 -404
    337 -402
    342 -400
    346 -398
    351 -395
    355 -393
    359 -391
    363 -388
    367 -386
    371 -383
    375 -381
    378 -378
    382 -376
    385 -373
    388 -371
    392 -368
    395 -365
    398 -362
    400 -360
    403 -357
    406 -354
    408 -351
    410 -348
    412 -346
    414 -343
    416 -340
    418 -337
    420 -334
    421 -331
    423 -328
    424 -325
    425 -321
    426 -318
    427 -315
    428 -312
    428 -309
    429 -306
    429 -302
    429 -299
    429 -296
    429 -293
    429 -289
    429 -286
    428 -282
    428 -279
    427 -276
    426 -272
    425 -269
    424 -265
    422 -262
    421 -258
    419 -255
    418 -251
    416 -248
    414 -244
    411 -241
    409 -237
    407 -233
    404 -230
    401 -226
    399 -223
    395 -219
    392 -215
    389 -212
    386 -208
    382 -204
    378 -200
    374 -197
    370 -193
    366 -189
    362 -185
    357 -182
    353 -178
    348 -174
    343 -170
    338 -166
    333 -163
    328 -159
    322 -155
    317 -151
    311 -147
    305 -143
    299 -140
    293 -136
    287 -132
    281 -128
    274 -124
    268 -120
    261 -116
    254 -112
    247 -108
    240 -105
    232 -101
    225 -97
    217 -93
    209 -89
    202 -85
    194 -81
    185 -77
    177 -73
    169 -69
    160 -65
    152 -61
    143 -57
    134 -54
    125 -50
    116 -46
    106 -42
    97 -38
    87 -34
    78 -30
    68 -26
    58 -22
    48 -18
    38 -14
    27 -10
    17 -6
    6 -2
    -4 2
    -15 5
    -26 9
    -37 13
    -48 17
    -59 21
    -71 25
    -82 29
    -94 33
    -106 37
    -117 41
    -129 45
    -142 48
    -154 52
    -166 56
    -178 60
    -191 64
    -204 68
    -216 72
    -229 76
    -242 79
    -255 83
    -269 87
    -282 91
    -295 95
    -309 99
    -322 103
    -336 106
    -350 110
    -364 114
    -378 118
    -392 122
    -406 125
    -421 129
    -435 133
    -450 137
    -465 140
    -479 144
    -494 148
    -509 152
    -524 156
    -539 159
    -555 163
    -570 167
    -585 170
    -601 174
    -617 178
    -632 182
    -648 185
    -664 189
    -680 193
    -696 196
    -712 200
    -729 204
    -745 207
    -762 211
    -778 214
    -795 218
    -812 222
    -828 225
    -845 229
    -862 232
    -879 236
    -897 240
    -914 243
    -931 247
    -949 250
    -966 254
    -984 257
    -1002 261
    -1019 264
    -1037 268
    1034 263
    1016 259
    998 256
    980 252
    963 249
    945 245
    928 242
    910 238
    893 235
    876 231
    859 228
    842 224
    825 221
    808 217
    791 214
    775 210
    758 206
    742 203
    725 199
    709 196
    693 192
    677 188
    660 185
    645 181
    629 178
    613 174
    597 170
    582 167
    566 163
    551 159
    536 156
    520 152
    505 148
    490 145
    476 141
    461 137
    446 133
    432 130
    417 126
    403 122
    388 118
    374 115
    360 111
    346 107
    332 103
    319 100
    305 96
    291 92
    278 88
    265 85
    252 81
    238 77
    225 73
    213 69
    200 66
    187 62
    175 58
    162 54
    150 50
    138 46
    126 43
    114 39
    102 35
    90 31
    78 27
    67 23
    55 19
    44 16
    33 12
    22 8
    11 4
    0 0
    -10 -4
    -21 -8
    -31 -12
    -42 -15
    -52 -19
    -62 -23
    -72 -27
    -82 -31
    -91 -35
    -101 -39
    -110 -43
    -120 -46
    -129 -50
    -138 -54
    -147 -58
    -155 -62
    -164 -66
    -173 -70
    -181 -74
    -189 -78
    -197 -81
    -205 -85
    -213 -89
    -221 -93
    -229 -97
    -236 -101
    -243 -105
    -251 -108
    -258 -112
    -265 -116
    -271 -120
    -278 -124
    -285 -128
    -291 -131
    -297 -135
    -303 -139
    -309 -143
    -315 -147
    -321 -151
    -326 -154
    -332 -158
    -337 -162
    -342 -166
    -347 -169
    -352 -173
    -357 -177
    -361 -181
    -366 -184
    -370 -188
    -374 -192
    -378 -195
    -382 -199
    -386 -203
    -389 -206
    -393 -210
    -396 -214
    -399 -217
    -402 -221
    -405 -225
    -408 -228
    -410 -232
    -413 -235
    -415 -239
    -417 -242
    -419 -246
    -421 -249
    -423 -253
    -424 -256
    -426 -260
    -427 -263
    -428 -267
    -429 -270
    -430 -273
    -431 -277
    -432 -280
    -432 -283
    -432 -287
    -433 -290
    -433 -293
    -433 -297
    -432 -300
    -432 -303
    -432 -306
    -431 -309
    -430 -312
    -429 -316
    -428 -319
    -427 -322
    -426 -325
    -424 -328
    -423 -331
    -421 -334
    -419 -337
    -417 -339
    -415 -342
    -413 -345
    -411 -348
    -408 -351
    -406 -354
    -403 -356
    -400 -359
    -397 -362
    -394 -364
    -391 -367
    -388 -370
    -384 -372
    -381 -375
    -377 -377
    -373 -380
    -370 -382
    -366 -384
    -361 -387
    -357 -389
    -353 -391
    -349 -394
    -344 -396
    -339 -398
    -335 -400
    -330 -402
    -325 -404
    -320 -407
    -315 -409
    -310 -411
    -304 -412
    -299 -414
    -293 -416
    -288 -418
    -282 -420
    -276 -422
    -271 -423
    -265 -425
    -259 -427
    -253 -428
    -247 -430
    -240 -431
    -234 -433
    -228 -434
    -221 -435
    -215 -437
    -208 -438
    -202 -439
    -195 -441
    -188 -442
    -182 -443
    -175 -444
    -168 -445
    -161 -446
    -154 -447
    -147 -448
    -140 -449
    -133 -450
    -126 -450
    -118 -451
    -111 -452
    -104 -452
    -97 -453
    -89 -454
    -82 -454
    -75 -455
    -67 -455
    -60 -455
    -52 -456
    -45 -456
    -37 -456
    -30 -457
    -22 -457
    -15 -457
    -7 -457
    0 -457
    7 -457
    15 -457
    22 -457
    30 -457
    37 -456
    45 -456
    52 -456
    60 -455
    67 -455
    75 -455
    82 -454
    89 -454
    97 -453
    104 -452
    111 -452
    118 -451
    126 -450
    133 -450
    140 -449
    147 -448
    154 -447
    161 -446
    168 -445
    175 -444
    182 -443
    188 -442
    195 -441
    202 -439
    208 -438
    215 -437
    221 -435
    228 -434
    234 -433
    240 -431
    247 -430
    253 -428
    259 -427
    265 -425
    271 -423
    276 -422
    282 -420
    288 -418
    293 -416
    299 -414
    304 -412
    310 -411
    315 -409
    320 -407
    325 -404
    330 -402
    335 -400
    339 -398
    344 -396
    349 -394
    353 -391
    357 -389
    361 -387
    366 -384
    370 -382
    373 -380
    377 -377
    381 -375
    384 -372
    388 -370
    391 -367
    394 -364
    397 -362
    400 -359
    403 -356
    406 -354
    408 -351
    411 -348
    413 -345
    415 -342
    417 -339
    419 -337
    421 -334
    423 -331
    424 -328
    426 -325
    427 -322
    428 -319
    429 -316
    430 -312
    431 -309
    432 -306
    432 -303
    432 -300
    433 -297
    433 -293
    433 -290
    432 -287
    432 -283
    432 -280
    431 -277
    430 -273
    429 -270
    428 -267
    427 -263
    426 -260
    424 -256
    423 -253
    421 -249
    419 -246
    417 -242
    415 -239
    413 -235
    410 -232
    408 -228
    405 -225
    402 -221
    399 -217
    396 -214
    393 -210
    389 -206
    386 -203
    382 -199
    378 -195
    374 -192
    370 -188
    366 -184
    361 -181
    357 -177
    352 -173
    347 -169
    342 -166
    337 -162
    332 -158
    326 -154
    321 -151
    315 -147
    309 -143
    303 -139
    297 -135
    291 -131
    285 -128
    278 -124
    271 -120
    265 -116
    258 -112
    251 -108
    243 -105
    236 -101
    229 -97
    221 -93
    213 -89
    205 -85
    197 -81
    189 -78
    181 -74
    173 -70
    164 -66
    155 -62
    147 -58
    138 -54
    129 -50
    120 -46
    110 -43
    101 -39
    91 -35
    82 -31
    72 -27
    62 -23
    52 -19
    42 -15
    31 -12
    21 -8
    10 -4
    -0 0
    -11 4
    -22 8
    -33 12
    -44 16
    -55 19
    -67 23
    -78 27
    -90 31
    -102 35
    -114 39
    -126 43
    -138 46
    -150 50
    -162 54
    -175 58
    -187 62
    -200 66
    -213 69
    -225 73
    -238 77
    -252 81
    -265 85
    -278 88
    -291 92
    -305 96
    -319 100
    -332 103
    -346 107
    -360 111
    -374 115
    -388 118
    -403 122
    -417 126
    -432 130
    -446 133
    -461 137
    -476 141
    -490 145
    -505 148
    -520 152
    -536 156
    -551 159
    -566 163
    -582 167
    -597 170
    -613 174
    -629 178
    -645 181
    -660 185
    -677 188
    -693 192
    -709 196
    -725 199
    -742 203
    -758 206
    -775 210
    -791 214
    -808 217
    -825 221
    -842 224
    -859 228
    -876 231
    -893 235
    -910 238
    -928 242
    -945 245
    -963 249
    -980 252
    -998 256
    -1016 259
    -1034 263
    1030 258
    1012 254
    995 251
    977 247
    959 244
    942 240
    924 237
    907 234
    890 230
    872 227
    855 223
    838 220
    821 216
    805 213
    788 209
    771 206
    755 202
    738 199
    722 195
    705 191
    689 188
    673 184
    657 181
    641 177
    625 174
    609 170
    594 166
    578 163
    563 159
    547 156
    532 152
    517 148
    502 145
    487 141
    472 137
    457 134
    442 130
    428 126
    413 123
    399 119
    385 115
    371 112
    356 108
    343 104
    329 101
    315 97
    301 93
    288 89
    274 86
    261 82
    248 78
    235 74
    222 71
    209 67
    196 63
    183 59
    171 56
    158 52
    146 48
    134 44
    122 41
    110 37
    98 33
    86 29
    75 25
    63 22
    52 18
    40 14
    29 10
    18 6
    7 3
    -4 -1
    -14 -5
    -25 -9
    -35 -13
    -45 -17
    -56 -20
    -66 -24
    -76 -28
    -85 -32
    -95 -36
    -105 -40
    -114 -43
    -123 -47
    -133 -51
    -142 -55
    -151 -59
    -159 -62
    -168 -66
    -177 -70
    -185 -74
    -193 -78
    -201 -82
    -209 -85
    -217 -89
    -225 -93
    -232 -97
    -240 -101
    -247 -104
    -254 -108
    -261 -112
    -268 -116
    -275 -120
    -282 -123
    -288 -127
    -295 -131
    -301 -135
    -307 -139
    -313 -142
    -319 -146
    -325 -150
    -330 -154
    -335 -157
    -341 -161
    -346 -165
    -351 -168
    -356 -172
    -360 -176
    -365 -179
    -369 -183
    -374 -187
    -378 -190
    -382 -194
    -386 -198
    -389 -201
    -393 -205
    -396 -209
    -400 -212
    -403 -216
    -406 -219
    -409 -223
    -411 -226
    -414 -230
    -416 -233
    -419 -237
    -421 -240
    -423 -244
    -425 -247
    -426 -251
    -428 -254
    -429 -258
    -431 -261
    -432 -264
    -433 -268
    -434 -271
    -434 -274
    -435 -278
    -435 -281
    -436 -284
    -436 -287
    -436 -291
    -436 -294
    -436 -297
    -435 -300
    -435 -303
    -434 -306
    -433 -309
    -432 -313
    -431 -316
    -430 -319
    -429 -322
    -427 -325
    -426 -328
    -424 -330
    -422 -333
    -420 -336
    -418 -339
    -416 -342
    -414 -345
    -411 -347
    -409 -350
    -406 -353
    -403 -356
    -400 -358
    -397 -361
    -394 -363
    -390 -366
    -387 -368
    -383 -371
    -380 -373
    -376 -376
    -372 -378
    -368 -381
    -364 -383
    -360 -385
    -355 -388
    -351 -390
    -346 -392
    -342 -394
    -337 -396
    -332 -398
    -327 -400
    -322 -402
    -317 -404
    -312 -406
    -306 -408
    -301 -410
    -295 -412
    -290 -414
    -284 -416
    -278 -417
    -272 -419
    -266 -421
    -260 -422
    -254 -424
    -248 -425
    -242 -427
    -236 -428
    -229 -430
    -223 -431
    -216 -432
    -210 -434
    -203 -435
    -196 -436
    -189 -437
    -183 -438
    -176 -439
    -169 -440
    -162 -441
    -155 -442
    -148 -443
    -141 -444
    -133 -445
    -126 -446
    -119 -446
    -112 -447
    -104 -448
    -97 -448
    -90 -449
    -82 -449
    -75 -450
    -68 -450
    -60 -451
    -53 -451
    -45 -451
    -38 -452
    -30 -452
    -23 -452
    -15 -452
    -8 -452
    0 -452
    8 -452
    15 -452
    23 -452
    30 -452
    38 -452
    45 -451
    53 -451
    60 -451
    68 -450
    75 -450
    82 -449
    90 -449
    97 -448
    104 -448
    112 -447
    119 -446
    126 -446
    133 -445
    141 -444
    148 -443
    155 -442
    162 -441
    169 -440
    176 -439
    183 -438
    189 -437
    196 -436
    203 -435
    210 -434
    216 -432
    223 -431
    229 -430
    236 -428
    242 -427
    248 -425
    254 -424
    260 -422
    266 -421
    272 -419
    278 -417
    284 -416
    290 -414
    295 -412
    301 -410
    306 -408
    312 -406
    317 -404
    322 -402
    327 -400
    332 -398
    337 -396
    342 -394
    346 -392
    351 -390
    355 -388
    360 -385
    364 -383
    368 -381
    372 -378
    376 -376
    380 -373
    383 -371
    387 -368
    390 -366
    394 -363
    397 -361
    400 -358
    403 -356
    406 -353
    409 -350
    411 -347
    414 -345
    416 -342
    418 -339
    420 -336
    422 -333
    424 -330
    426 -328
    427 -325
    429 -322
    430 -319
    431 -316
    432 -313
    433 -309
    434 -306
    435 -303
    435 -300
    436 -297
    436 -294
    436 -291
    436 -287
    436 -284
    435 -281
    435 -278
    434 -274
    434 -271
    433 -268
    432 -264
    431 -261
    429 -258
    428 -254
    426 -251
    425 -247
    423 -244
    421 -240
    419 -237
    416 -233
    414 -230
    411 -226
    409 -223
    406 -219
    403 -216
    400 -212
    396 -209
    393 -205
    389 -201
    386 -198
    382 -194
    378 -190
    374 -187
    369 -183
    365 -179
    360 -176
    356 -172
    351 -168
    346 -165
    341 -161
    335 -157
    330 -154
    325 -150
    319 -146
    313 -142
    307 -139
    301 -135
    295 -131
    288 -127
    282 -123
    275 -120
    268 -116
    261 -112
    254 -108
    247 -104
    240 -101
    232 -97
    225 -93
    217 -89
    209 -85
    201 -82
    193 -78
    185 -74
    177 -70
    168 -66
    159 -62
    151 -59
    142 -55
    133 -51
    123 -47
    114 -43
    105 -40
    95 -36
    85 -32
    76 -28
    66 -24
    56 -20
    45 -17
    35 -13
    25 -9
    14 -5
    4 -1
    -7 3
    -18 6
    -29 10
    -40 14
    -52 18
    -63 22
    -75 25
    -86 29
    -98 33
    -110 37
    -122 41
    -134 44
    -146 48
    -158 52
    -171 56
    -183 59
    -196 63
    -209 67
    -222 71
    -235 74
    -248 78
    -261 82
    -274 86
    -288 89
    -301 93
    -315 97
    -329 101
    -343 104
    -356 108
    -371 112
    -385 115
    -399 119
    -413 123
    -428 126
    -442 130
    -457 134
    -472 137
    -487 141
    -502 145
    -517 148
    -532 152
    -547 156
    -563 159
    -578 163
    -594 166
    -609 170
    -625 174
    -641 177
    -657 181
    -673 184
    -689 188
    -705 191
    -722 195
    -738 199
    -755 202
    -771 206
    -788 209
    -805 213
    -821 216
    -838 220
    -855 223
    -872 227
    -890 230
    -907 234
    -924 237
    -942 240
    -959 244
    -977 247
    -995 251
    -1012 254
    -1030 258
    1027 252
    1009 249
    991 246
    973 242
    956 239
    938 236
    921 232
    903 229
    886 225
    869 222
    852 219
    835 215
    818 212
    801 208
    784 205
    768 201
    751 198
    734 194
    718 191
    702 187
    686 184
    669 180
    653 177
    637 173
    622 170
    606 166
    590 163
    575 159
    559 156
    544 152
    528 148
    513 145
    498 141
    483 138
    468 134
    453 131
    439 127
    424 123
    410 120
    395 116
    381 112
    367 109
    353 105
    339 101
    325 98
    311 94
    298 90
    284 87
    271 83
    257 79
    244 76
    231 72
    218 68
    205 65
    192 61
    180 57
    167 54
    155 50
    142 46
    130 42
    118 39
    106 35
    94 31
    82 27
    71 24
    59 20
    48 16
    37 12
    25 9
    14 5
    3 1
    -7 -3
    -18 -6
    -29 -10
    -39 -14
    -49 -18
    -59 -21
    -70 -25
    -79 -29
    -89 -33
    -99 -36
    -109 -40
    -118 -44
    -127 -48
    -136 -52
    -145 -55
    -154 -59
    -163 -63
    -172 -67
    -180 -70
    -189 -74
    -197 -78
    -205 -82
    -213 -86
    -221 -89
    -229 -93
    -236 -97
    -244 -101
    -251 -104
    -258 -108
    -265 -112
    -272 -116
    -279 -119
    -286 -123
    -292 -127
    -298 -130
    -305 -134
    -311 -138
    -317 -142
    -323 -145
    -328 -149
    -334 -153
    -339 -156
    -344 -160
    -350 -164
    -355 -167
    -359 -171
    -364 -175
    -369 -178
    -373 -182
    -377 -185
    -381 -189
    -385 -193
    -389 -196
    -393 -200
    -396 -203
    -400 -207
    -403 -210
    -406 -214
    -409 -218
    -412 -221
    -415 -225
    -417 -228
    -420 -231
    -422 -235
    -424 -238
    -426 -242
    -428 -245
    -430 -249
    -431 -252
    -433 -255
    -434 -259
    -435 -262
    -436 -265
    -437 -269
    -438 -272
    -438 -275
    -439 -278
    -439 -282
    -439 -285
    -439 -288
    -439 -291
    -439 -294
    -438 -297
    -438 -300
    -437 -303
    -436 -306
    -435 -310
    -434 -313
    -433 -315
    -432 -318
    -430 -321
    -429 -324
    -427 -327
    -425 -330
    -423 -333
    -421 -336
    -419 -338
    -416 -341
    -414 -344
    -411 -347
    -408 -349
    -406 -352
    -403 -355
    -399 -357
    -396 -360
    -393 -362
    -389 -365
    -386 -367
    -382 -370
    -378 -372
    -374 -374
    -370 -377
    -366 -379
    -362 -381
    -357 -383
    -353 -386
    -348 -388
    -344 -390
    -339 -392
    -334 -394
    -329 -396
    -324 -398
    -319 -400
    -313 -402
    -308 -404
    -303 -406
    -297 -408
    -291 -409
    -286 -411
    -280 -413
    -274 -414
    -268 -416
    -262 -418
    -256 -419
    -250 -421
    -243 -422
    -237 -424
    -230 -425
    -224 -426
    -217 -428
    -211 -429
    -204 -430
    -197 -431
    -191 -432
    -184 -434
    -177 -435
    -170 -436
    -163 -437
    -156 -438
    -149 -438
    -141 -439
    -134 -440
    -127 -441
    -120 -442
    -112 -442
    -105 -443
    -98 -443
    -90 -444
    -83 -445
    -75 -445
    -68 -445
    -60 -446
    -53 -446
    -45 -446
    -38 -447
    -30 -447
    -23 -447
    -15 -447
    -8 -447
    0 -447
    8 -447
    15 -447
    23 -447
    30 -447
    38 -447
    45 -446
    53 -446
    60 -446
    68 -445
    75 -445
    83 -445
    90 -444
    98 -443
    105 -443
    112 -442
    120 -442
    127 -441
    134 -440
    141 -439
    149 -438
    156 -438
    163 -437
    170 -436
    177 -435
    184 -434
    191 -432
    197 -431
    204 -430
    211 -429
    217 -428
    224 -426
    230 -425
    237 -424
    243 -422
    250 -421
    256 -419
    262 -418
    268 -416
    274 -414
    280 -413
    286 -411
    291 -409
    297 -408
    303 -406
    308 -404
    313 -402
    319 -400
    324 -398
    329 -396
    334 -394
    339 -392
    344 -390
    348 -388
    353 -386
    357 -383
    362 -381
    366 -379
    370 -377
    374 -374
    378 -372
    382 -370
    386 -367
    389 -365
    393 -362
    396 -360
    399 -357
    403 -355
    406 -352
    408 -349
    411 -347
    414 -344
    416 -341
    419 -338
    421 -336
    423 -333
    425 -330
    427 -327
    429 -324
    430 -321
    432 -318
    433 -315
    434 -313
    435 -310
    436 -306
    437 -303
    438 -300
    438 -297
    439 -294
    439 -291
    439 -288
    439 -285
    439 -282
    439 -278
    438 -275
    438 -272
    437 -269
    436 -265
    435 -262
    434 -259
    433 -255
    431 -252
    430 -249
    428 -245
    426 -242
    424 -238
    422 -235
    420 -231
    417 -228
    415 -225
    412 -221
    409 -218
    406 -214
    403 -210
    400 -207
    396 -203
    393 -200
    389 -196
    385 -193
    381 -189
    377 -185
    373 -182
    369 -178
    364 -175
    359 -171
    355 -167
    350 -164
    344 -160
    339 -156
    334 -153
    328 -149
    323 -145
    317 -142
    311 -138
    305 -134
    298 -130
    292 -127
    286 -123
    279 -119
    272 -116
    265 -112
    258 -108
    251 -104
    244 -101
    236 -97
    229 -93
    221 -89
    213 -86
    205 -82
    197 -78
    189 -74
    180 -70
    172 -67
    163 -63
    154 -59
    145 -55
    136 -52
    127 -48
    118 -44
    109 -40
    99 -36
    89 -33
    79 -29
    70 -25
    59 -21
    49 -18
    39 -14
    29 -10
    18 -6
    7 -3
    -3 1
    -14 5
    -25 9
    -37 12
    -48 16
    -59 20
    -71 24
    -82 27
    -94 31
    -106 35
    -118 39
    -130 42
    -142 46
    -155 50
    -167 54
    -180 57
    -192 61
    -205 65
    -218 68
    -231 72
    -244 76
    -257 79
    -271 83
    -284 87
    -298 90
    -311 94
    -325 98
    -339 101
    -353 105
    -367 109
    -381 112
    -395 116
    -410 120
    -424 123
    -439 127
    -453 131
    -468 134
    -483 138
    -498 141
    -513 145
    -528 148
    -544 152
    -559 156
    -575 159
    -590 163
    -606 166
    -622 170
    -637 173
    -653 177
    -669 180
    -686 184
    -702 187
    -718 191
    -734 194
    -751 198
    -768 201
    -784 205
    -801 208
    -818 212
    -835 215
    -852 219
    -869 222
    -886 225
    -903 229
    -921 232
    -938 236
    -956 239
    -973 242
    -991 246
    -1009 249
    -1027 252
    1024 247
    1006 244
    988 241
    970 237
    953 234
    935 231
    917 227
    900 224
    883 221
    866 217
    848 214
    831 211
    814 207
    798 204
    781 200
    764 197
    748 194
    731 190
    715 187
    698 183
    682 180
    666 176
    650 173
    634 169
    618 166
    602 162
    587 159
    571 155
    556 152
    540 148
    525 145
    510 141
    495 138
    480 134
    465 131
    450 127
    435 124
    421 120
    406 117
    392 113
    377 109
    363 106
    349 102
    335 99
    321 95
    308 91
    294 88
    280 84
    267 81
    254 77
    240 73
    227 70
    214 66
    201 62
    189 59
    176 55
    163 51
    151 48
    139 44
    126 40
    114 37
    102 33
    90 29
    79 26
    67 22
    56 18
    44 15
    33 11
    22 7
    11 4
    -0 -0
    -11 -4
    -22 -8
    -32 -11
    -43 -15
    -53 -19
    -63 -22
    -73 -26
    -83 -30
    -93 -34
    -103 -37
    -112 -41
    -122 -45
    -131 -48
    -140 -52
    -149 -56
    -158 -60
    -167 -63
    -176 -67
    -184 -71
    -192 -74
    -201 -78
    -209 -82
    -217 -86
    -225 -89
    -232 -93
    -240 -97
    -247 -100
    -255 -104
    -262 -108
    -269 -111
    -276 -115
    -283 -119
    -289 -122
    -296 -126
    -302 -130
    -308 -133
    -314 -137
    -320 -141
    -326 -144
    -332 -148
    -337 -152
    -343 -155
    -348 -159
    -353 -163
    -358 -166
    -363 -170
    -368 -173
    -372 -177
    -377 -181
    -381 -184
    -385 -188
    -389 -191
    -393 -195
    -396 -198
    -400 -202
    -403 -205
    -407 -209
    -410 -212
    -413 -216
    -416 -219
    -418 -223
    -421 -226
    -423 -229
    -425 -233
    -428 -236
    -430 -240
    -431 -243
    -433 -246
    -435 -250
    -436 -253
    -437 -256
    -438 -259
    -439 -263
    -440 -266
    -441 -269
    -441 -272
    -442 -276
    -442 -279
    -442 -282
    -442 -285
    -442 -288
    -442 -291
    -441 -294
    -441 -297
    -440 -300
    -439 -303
    -438 -306
    -437 -309
    -436 -312
    -435 -315
    -433 -318
    -432 -321
    -430 -324
    -428 -327
    -426 -329
    -424 -332
    -421 -335
    -419 -338
    -417 -340
    -414 -343
    -411 -346
    -408 -348
    -405 -351
    -402 -353
    -399 -356
    -395 -358
    -392 -361
    -388 -363
    -384 -366
    -381 -368
    -377 -370
    -373 -373
    -368 -375
    -364 -377
    -360 -379
    -355 -381
    -351 -384
    -346 -386
    -341 -388
    -336 -390
    -331 -392
    -326 -394
    -321 -396
    -315 -398
    -310 -399
    -304 -401
    -299 -403
    -293 -405
    -287 -407
    -282 -408
    -276 -410
    -270 -411
    -263 -413
    -257 -415
    -251 -416
    -245 -417
    -238 -419
    -232 -420
    -225 -422
    -219 -423
    -212 -424
    -205 -425
    -199 -426
    -192 -428
    -185 -429
    -178 -430
    -171 -431
    -164 -432
    -157 -433
    -149 -433
    -142 -434
    -135 -435
    -128 -436
    -120 -437
    -113 -437
    -106 -438
    -98 -438
    -91 -439
    -83 -440
    -76 -440
    -68 -440
    -61 -441
    -53 -441
    -46 -441
    -38 -442
    -30 -442
    -23 -442
    -15 -442
    -8 -442
    0 -442
    8 -442
    15 -442
    23 -442
    30 -442
    38 -442
    46 -441
    53 -441
    61 -441
    68 -440
    76 -440
    83 -440
    91 -439
    98 -438
    106 -438
    113 -437
    120 -437
    128 -436
    135 -435
    142 -434
    149 -433
    157 -433
    164 -432
    171 -431
    178 -430
    185 -429
    192 -428
    199 -426
    205 -425
    212 -424
    219 -423
    225 -422
    232 -420
    238 -419
    245 -417
    251 -416
    257 -415
    263 -413
    270 -411
    276 -410
    282 -408
    287 -407
    293 -405
    299 -403
    304 -401
    310 -399
    315 -398
    321 -396
    326 -394
    331 -392
    336 -390
    341 -388
    346 -386
    351 -384
    355 -381
    360 -379
    364 -377
    368 -375
    373 -373
    377 -370
    381 -368
    384 -366
    388 -363
    392 -361
    395 -358
    399 -356
    402 -353
    405 -351
    408 -348
    411 -346
    414 -343
    417 -340
    419 -338
    421 -335
    424 -332
    426 -329
    428 -327
    430 -324
    432 -321
    433 -318
    435 -315
    436 -312
    437 -309
    438 -306
    439 -303
    440 -300
    441 -297
    441 -294
    442 -291
    442 -288
    442 -285
    442 -282
    442 -279
    442 -276
    441 -272
    441 -269
    440 -266
    439 -263
    438 -259
    437 -256
    436 -253
    435 -250
    433 -246
    431 -243
    430 -240
    428 -236
    425 -233
    423 -229
    421 -226
    418 -223
    416 -219
    413 -216
    410 -212
    407 -209
    403 -205
    400 -202
    396 -198
    393 -195
    389 -191
    385 -188
    381 -184
    377 -181
    372 -177
    368 -173
    363 -170
    358 -166
    353 -163
    348 -159
    343 -155
    337 -152
    332 -148
    326 -144
    320 -141
    314 -137
    308 -133
    302 -130
    296 -126
    289 -122
    283 -119
    276 -115
    269 -111
    262 -108
    255 -104
    247 -100
    240 -97
    232 -93
    225 -89
    217 -86
    209 -82
    201 -78
    192 -74
    184 -71
    176 -67
    167 -63
    158 -60
    149 -56
    140 -52
    131 -48
    122 -45
    112 -41
    103 -37
    93 -34
    83 -30
    73 -26
    63 -22
    53 -19
    43 -15
    32 -11
    22 -8
    11 -4
    0 -0
    -11 4
    -22 7
    -33 11
    -44 15
    -56 18
    -67 22
    -79 26
    -90 29
    -102 33
    -114 37
    -126 40
    -139 44
    -151 48
    -163 51
    -176 55
    -189 59
    -201 62
    -214 66
    -227 70
    -240 73
    -254 77
    -267 81
    -280 84
    -294 88
    -308 91
    -321 95
    -335 99
    -349 102
    -363 106
    -377 109
    -392 113
    -406 117
    -421 120
    -435 124
    -450 127
    -465 131
    -480 134
    -495 138
    -510 141
    -525 145
    -540 148
    -556 152
    -571 155
    -587 159
    -602 162
    -618 166
    -634 169
    -650 173
    -666 176
    -682 180
    -698 183
    -715 187
    -731 190
    -748 194
    -764 197
    -781 200
    -798 204
    -814 207
    -831 211
    -848 214
    -866 217
    -883 221
    -900 224
    -917 227
    -935 231
    -953 234
    -970 237
    -988 241
    -1006 244
    -1024 247
    1020 242
    1002 239
    985 236
    967 233
    949 229
    932 226
    914 223
    897 219
    879 216
    862 213
    845 209
    828 206
    811 203
    794 199
    777 196
    761 193
    744 189
    728 186
    711 183
    695 179
    679 176
    662 172
    646 169
    630 166
    615 162
    599 159
    583 155
    568 152
    552 148
    537 145
    521 142
    506 138
    491 135
    476 131
    461 128
    446 124
    432 121
    417 117
    403 114
    388 110
    374 107
    360 103
    346 99
    332 96
    318 92
    304 89
    290 85
    277 82
    263 78
    250 75
    237 71
    224 67
    211 64
    198 60
    185 57
    172 53
    160 49
    147 46
    135 42
    123 39
    111 35
    99 31
    87 28
    75 24
    63 21
    52 17
    40 13
    29 10
    18 6
    7 2
    -4 -1
    -15 -5
    -25 -9
    -36 -12
    -46 -16
    -57 -20
    -67 -23
    -77 -27
    -87 -31
    -97 -34
    -106 -38
    -116 -42
    -125 -45
    -135 -49
    -144 -53
    -153 -56
    -162 -60
    -171 -64
    -179 -67
    -188 -71
    -196 -75
    -204 -78
    -212 -82
    -220 -85
    -228 -89
    -236 -93
    -244 -96
    -251 -100
    -258 -104
    -266 -107
    -273 -111
    -280 -115
    -286 -118
    -293 -122
    -299 -126
    -306 -129
    -312 -133
    -318 -136
    -324 -140
    -330 -144
    -336 -147
    -341 -151
    -346 -154
    -352 -158
    -357 -161
    -362 -165
    -367 -168
    -371 -172
    -376 -176
    -380 -179
    -384 -183
    -388 -186
    -392 -190
    -396 -193
    -400 -197
    -403 -200
    -407 -203
    -410 -207
    -413 -210
    -416 -214
    -419 -217
    -422 -220
    -424 -224
    -427 -227
    -429 -231
    -431 -234
    -433 -237
    -435 -241
    -436 -244
    -438 -247
    -439 -250
    -441 -254
    -442 -257
    -443 -260
    -443 -263
    -444 -266
    -445 -270
    -445 -273
    -445 -276
    -445 -279
    -445 -282
    -445 -285
    -445 -288
    -444 -291
    -444 -294
    -443 -297
    -442 -300
    -441 -303
    -440 -306
    -439 -309
    -438 -312
    -436 -315
    -434 -317
    -433 -320
    -431 -323
    -429 -326
    -426 -329
    -424 -331
    -422 -334
    -419 -337
    -416 -339
    -414 -342
    -411 -344
    -408 -347
    -405 -349
    -401 -352
    -398 -354
    -394 -357
    -391 -359
    -387 -361
    -383 -364
    -379 -366
    -375 -368
    -371 -371
    -366 -373
    -362 -375
    -357 -377
    -353 -379
    -348 -381
    -343 -383
    -338 -385
    -333 -387
    -328 -389
    -323 -391
    -317 -393
    -312 -395
    -306 -397
    -301 -398
    -295 -400
    -289 -402
    -283 -404
    -277 -405
    -271 -407
    -265 -408
    -259 -410
    -252 -411
    -246 -413
    -240 -414
    -233 -415
    -227 -417
    -220 -418
    -213 -419
    -207 -420
    -200 -422
    -193 -423
    -186 -424
    -179 -425
    -172 -426
    -165 -427
    -158 -428
    -150 -428
    -143 -429
    -136 -430
    -128 -431
    -121 -432
    -114 -432
    -106 -433
    -99 -433
    -91 -434
    -84 -434
    -76 -435
    -69 -435
    -61 -436
    -54 -436
    -46 -436
    -38 -436
    -31 -437
    -23 -437
    -15 -437
    -8 -437
    0 -437
    8 -437
    15 -437
    23 -437
    31 -437
    38 -436
    46 -436
    54 -436
    61 -436
    69 -435
    76 -435
    84 -434
    91 -434
    99 -433
    106 -433
    114 -432
    121 -432
    128 -431
    136 -430
    143 -429
    150 -428
    158 -428
    165 -427
    172 -426
    179 -425
    186 -424
    193 -423
    200 -422
    207 -420
    213 -419
    220 -418
    227 -417
    233 -415
    240 -414
    246 -413
    252 -411
    259 -410
    265 -408
    271 -407
    277 -405
    283 -404
    289 -402
    295 -400
    301 -398
    306 -397
    312 -395
    317 -393
    323 -391
    328 -389
    333 -387
    338 -385
    343 -383
    348 -381
    353 -379
    357 -377
    362 -375
    366 -373
    371 -371
    375 -368
    379 -366
    383 -364
    387 -361
    391 -359
    394 -357
    398 -354
    401 -352
    405 -349
    408 -347
    411 -344
    414 -342
    416 -339
    419 -337
    422 -334
    424 -331
    426 -329
    429 -326
    431 -323
    433 -320
    434 -317
    436 -315
    438 -312
    439 -309
    440 -306
    441 -303
    442 -300
    443 -297
    444 -294
    444 -291
    445 -288
    445 -285
    445 -282
    445 -279
    445 -276
    445 -273
    445 -270
    444 -266
    443 -263
    443 -260
    442 -257
    441 -254
    439 -250
    438 -247
    436 -244
    435 -241
    433 -237
    431 -234
    429 -231
    427 -227
    424 -224
    422 -220
    419 -217
    416 -214
    413 -210
    410 -207
    407 -203
    403 -200
    400 -197
    396 -193
    392 -190
    388 -186
    384 -183
    380 -179
    376 -176
    371 -172
    367 -168
    362 -165
    357 -161
    352 -158
    346 -154
    341 -151
    336 -147
    330 -144
    324 -140
    318 -136
    312 -133
    306 -129
    299 -126
    293 -122
    286 -118
    280 -115
    273 -111
    266 -107
    258 -104
    251 -100
    244 -96
    236 -93
    228 -89
    220 -85
    212 -82
    204 -78
    196 -75
    188 -71
    179 -67
    171 -64
    162 -60
    153 -56
    144 -53
    135 -49
    125 -45
    116 -42
    106 -38
    97 -34
    87 -31
    77 -27
    67 -23
    57 -20
    46 -16
    36 -12
    25 -9
    15 -5
    4 -1
    -7 2
    -18 6
    -29 10
    -40 13
    -52 17
    -63 21
    -75 24
    -87 28
    -99 31
    -111 35
    -123 39
    -135 42
    -147 46
    -160 49
    -172 53
    -185 57
    -198 60
    -211 64
    -224 67
    -237 71
    -250 75
    -263 78
    -277 82
    -290 85
    -304 89
    -318 92
    -332 96
    -346 99
    -360 103
    -374 107
    -388 110
    -403 114
    -417 117
    -432 121
    -446 124
    -461 128
    -476 131
    -491 135
    -506 138
    -521 142
    -537 145
    -552 148
    -568 152
    -583 155
    -599 159
    -615 162
    -630 166
    -646 169
    -662 172
    -679 176
    -695 179
    -711 183
    -728 186
    -744 189
    -761 193
    -777 196
    -794 199
    -811 203
    -828 206
    -845 209
    -862 213
    -879 216
    -897 219
    -914 223
    -932 226
    -949 229
    -967 233
    -985 236
    -1002 239
    -1020 242
    1017 237
    999 234
    981 231
    964 228
    946 224
    928 221
    911 218
    894 215
    876 211
    859 208
    842 205
    825 202
    808 198
    791 195
    774 192
    757 189
    741 185
    724 182
    708 179
    692 175
    675 172
    659 169
    643 165
    627 162
    611 158
    595 155
    580 152
    564 148
    549 145
    533 142
    518 138
    503 135
    488 131
    473 128
    458 124
    443 121
    428 118
    414 114
    399 111
    385 107
    370 104
    356 100
    342 97
    328 93
    314 90
    300 86
    287 83
    273 79
    260 76
    246 72
    233 69
    220 65
    207 62
    194 58
    181 55
    169 51
    156 48
    144 44
    131 40
    119 37
    107 33
    95 30
    83 26
    71 23
    60 19
    48 15
    37 12
    26 8
    14 5
    3 1
    -8 -2
    -18 -6
    -29 -10
    -40 -13
    -50 -17
    -60 -20
    -71 -24
    -81 -28
    -91 -31
    -100 -35
    -110 -39
    -120 -42
    -129 -46
    -138 -49
    -147 -53
    -157 -57
    -165 -60
    -174 -64
    -183 -67
    -191 -71
    -200 -75
    -208 -78
    -216 -82
    -224 -85
    -232 -89
    -240 -93
    -247 -96
    -255 -100
    -262 -103
    -269 -107
    -276 -110
    -283 -114
    -290 -118
    -297 -121
    -303 -125
    -309 -128
    -316 -132
    -322 -135
    -328 -139
    -333 -143
    -339 -146
    -345 -150
    -350 -153
    -355 -157
    -360 -160
    -365 -164
    -370 -167
    -375 -171
    -379 -174
    -384 -178
    -388 -181
    -392 -184
    -396 -188
    -400 -191
    -403 -195
    -407 -198
    -410 -202
    -414 -205
    -417 -208
    -420 -212
    -422 -215
    -425 -218
    -428 -222
    -430 -225
    -432 -228
    -434 -232
    -436 -235
    -438 -238
    -440 -241
    -441 -245
    -443 -248
    -444 -251
    -445 -254
    -446 -257
    -447 -261
    -447 -264
    -448 -267
    -448 -270
    -448 -273
    -448 -276
    -448 -279
    -448 -282
    -448 -285
    -447 -288
    -447 -291
    -446 -294
    -445 -297
    -444 -300
    -443 -303
    -442 -305
    -440 -308
    -439 -311
    -437 -314
    -435 -317
    -433 -319
    -431 -322
    -429 -325
    -427 -327
    -424 -330
    -422 -333
    -419 -335
    -416 -338
    -413 -340
    -410 -343
    -407 -345
    -404 -348
    -400 -350
    -397 -353
    -393 -355
    -389 -357
    -385 -360
    -381 -362
    -377 -364
    -373 -366
    -368 -368
    -364 -371
    -359 -373
    -355 -375
    -350 -377
    -345 -379
    -340 -381
    -335 -383
    -330 -385
    -324 -387
    -319 -388
    -314 -390
    -308 -392
    -302 -394
    -297 -395
    -291 -397
    -285 -399
    -279 -400
    -273 -402
    -267 -403
    -260 -405
    -254 -406
    -248 -408
    -241 -409
    -235 -410
    -228 -412
    -221 -413
    -214 -414
    -208 -415
    -201 -416
    -194 -418
    -187 -419
    -180 -420
    -173 -421
    -166 -422
    -158 -422
    -151 -423
    -144 -424
    -137 -425
    -129 -426
    -122 -426
    -114 -427
    -107 -428
    -99 -428
    -92 -429
    -84 -429
    -77 -430
    -69 -430
    -61 -430
    -54 -431
    -46 -431
    -38 -431
    -31 -431
    -23 -431
    -15 -432
    -8 -432
    0 -432
    8 -432
    15 -432
    23 -431
    31 -431
    38 -431
    46 -431
    54 -431
    61 -430
    69 -430
    77 -430
    84 -429
    92 -429
    99 -428
    107 -428
    114 -427
    122 -426
    129 -426
    137 -425
    144 -424
    151 -423
    158 -422
    166 -422
    173 -421
    180 -420
    187 -419
    194 -418
    201 -416
    208 -415
    214 -414
    221 -413
    228 -412
    235 -410
    241 -409
    248 -408
    254 -406
    260 -405
    267 -403
    273 -402
    279 -400
    285 -399
    291 -397
    297 -395
    302 -394
    308 -392
    314 -390
    319 -388
    324 -387
    330 -385
    335 -383
    340 -381
    345 -379
    350 -377
    355 -375
    359 -373
    364 -371
    368 -368
    373 -366
    377 -364
    381 -362
    385 -360
    389 -357
    393 -355
    397 -353
    400 -350
    404 -348
    407 -345
    410 -343
    413 -340
    416 -338
    419 -335
    422 -333
    424 -330
    427 -327
    429 -325
    431 -322
    433 -319
    435 -317
    437 -314
    439 -311
    440 -308
    442 -305
    443 -303
    444 -300
    445 -297
    446 -294
    447 -291
    447 -288
    448 -285
    448 -282
    448 -279
    448 -276
    448 -273
    448 -270
    448 -267
    447 -264
    447 -261
    446 -257
    445 -254
    444 -251
    443 -248
    441 -245
    440 -241
    438 -238
    436 -235
    434 -232
    432 -228
    430 -225
    428 -222
    425 -218
    422 -215
    420 -212
    417 -208
    414 -205
    410 -202
    407 -198
    403 -195
    400 -191
    396 -188
    392 -184
    388 -181
    384 -178
    379 -174
    375 -171
    370 -167
    365 -164
    360 -160
    355 -157
    350 -153
    345 -150
    339 -146
    333 -143
    328 -139
    322 -135
    316 -132
    309 -128
    303 -125
    297 -121
    290 -118
    283 -114
    276 -110
    269 -107
    262 -103
    255 -100
    247 -96
    240 -93
    232 -89
    224 -85
    216 -82
    208 -78
    200 -75
    191 -71
    183 -67
    174 -64
    165 -60
    157 -57
    147 -53
    138 -49
    129 -46
    120 -42
    110 -39
    100 -35
    91 -31
    81 -28
    71 -24
    60 -20
    50 -17
    40 -13
    29 -10
    18 -6
    8 -2
    -3 1
    -14 5
    -26 8
    -37 12
    -48 15
    -60 19
    -71 23
    -83 26
    -95 30
    -107 33
    -119 37
    -131 40
    -144 44
    -156 48
    -169 51
    -181 55
    -194 58
    -207 62
    -220 65
    -233 69
    -246 72
    -260 76
    -273 79
    -287 83
    -300 86
    -314 90
    -328 93
    -342 97
    -356 100
    -370 104
    -385 107
    -399 111
    -414 114
    -428 118
    -443 121
    -458 124
    -473 128
    -488 131
    -503 135
    -518 138
    -533 142
    -549 145
    -564 148
    -580 152
    -595 155
    -611 158
    -627 162
    -643 165
    -659 169
    -675 172
    -692 175
    -708 179
    -724 182
    -741 185
    -757 189
    -774 192
    -791 195
    -808 198
    -825 202
    -842 205
    -859 208
    -876 211
    -894 215
    -911 218
    -928 221
    -946 224
    -964 228
    -981 231
    -999 234
    -1017 237
    1014 232
    996 229
    978 226
    960 223
    943 220
    925 217
    908 213
    890 210
    873 207
    856 204
    839 201
    822 197
    805 194
    788 191
    771 188
    754 184
    738 181
    721 178
    705 175
    688 171
    672 168
    656 165
    640 161
    624 158
    608 155
    592 151
    576 148
    561 145
    545 141
    530 138
    515 135
    499 131
    484 128
    469 125
    454 121
    439 118
    425 115
    410 111
    396 108
    381 104
    367 101
    353 97
    339 94
    325 91
    311 87
    297 84
    283 80
    270 77
    256 73
    243 70
    230 66
    217 63
    204 60
    191 56
    178 53
    165 49
    153 46
    140 42
    128 39
    116 35
    103 32
    92 28
    80 25
    68 21
    56 18
    45 14
    33 11
    22 7
    11 3
    -0 -0
    -11 -4
    -22 -7
    -33 -11
    -43 -14
    -54 -18
    -64 -21
    -74 -25
    -84 -28
    -94 -32
    -104 -36
    -114 -39
    -123 -43
    -133 -46
    -142 -50
    -151 -53
    -160 -57
    -169 -60
    -178 -64
    -186 -67
    -195 -71
    -203 -75
    -212 -78
    -220 -82
    -228 -85
    -236 -89
    -243 -92
    -251 -96
    -258 -99
    -266 -103
    -273 -106
    -280 -110
    -287 -113
    -293 -117
    -300 -120
    -307 -124
    -313 -127
    -319 -131
    -325 -134
    -331 -138
    -337 -141
    -343 -145
    -348 -148
    -353 -152
    -359 -155
    -364 -159
    -369 -162
    -373 -166
    -378 -169
    -383 -173
    -387 -176
    -391 -179
    -395 -183
    -399 -186
    -403 -189
    -407 -193
    -410 -196
    -414 -200
    -417 -203
    -420 -206
    -423 -210
    -426 -213
    -428 -216
    -431 -219
    -433 -223
    -435 -226
    -437 -229
    -439 -232
    -441 -236
    -443 -239
    -444 -242
    -446 -245
    -447 -248
    -448 -251
    -449 -255
    -450 -258
    -450 -261
    -451 -264
    -451 -267
    -451 -270
    -451 -273
    -451 -276
    -451 -279
    -451 -282
    -450 -285
    -450 -288
    -449 -291
    -448 -293
    -447 -296
    -446 -299
    -445 -302
    -443 -305
    -442 -307
    -440 -310
    -438 -313
    -436 -316
    -434 -318
    -432 -321
    -429 -324
    -427 -326
    -424 -329
    -422 -331
    -419 -334
    -416 -336
    -413 -339
    -409 -341
    -406 -344
    -403 -346
    -399 -348
    -395 -351
    -391 -353
    -388 -355
    -383 -357
    -379 -360
    -375 -362
    -371 -364
    -366 -366
    -361 -368
    -357 -370
    -352 -372
    -347 -374
    -342 -376
    -337 -378
    -332 -380
    -326 -382
    -321 -384
    -315 -385
    -310 -387
    -304 -389
    -298 -391
    -292 -392
    -286 -394
    -280 -395
    -274 -397
    -268 -398
    -262 -400
    -255 -401
    -249 -403
    -242 -404
    -236 -405
    -229 -407
    -222 -408
    -216 -409
    -209 -410
    -202 -411
    -195 -412
    -188 -413
    -181 -414
    -174 -415
    -167 -416
    -159 -417
    -152 -418
    -145 -419
    -137 -420
    -130 -420
    -122 -421
    -115 -422
    -107 -422
    -100 -423
    -92 -423
    -85 -424
    -77 -424
    -69 -425
    -62 -425
    -54 -425
    -46 -426
    -39 -426
    -31 -426
    -23 -426
    -15 -426
    -8 -426
    0 -426
    8 -426
    15 -426
    23 -426
    31 -426
    39 -426
    46 -426
    54 -425
    62 -425
    69 -425
    77 -424
    85 -424
    92 -423
    100 -423
    107 -422
    115 -422
    122 -421
    130 -420
    137 -420
    145 -419
    152 -418
    159 -417
    167 -416
    174 -415
    181 -414
    188 -413
    195 -412
    202 -411
    209 -410
    216 -409
    222 -408
    229 -407
    236 -405
    242 -404
    249 -403
    255 -401
    262 -400
    268 -398
    274 -397
    280 -395
    286 -394
    292 -392
    298 -391
    304 -389
    310 -387
    315 -385
    321 -384
    326 -382
    332 -380
    337 -378
    342 -376
    347 -374
    352 -372
    357 -370
    361 -368
    366 -366
    371 -364
    375 -362
    379 -360
    383 -357
    388 -355
    391 -353
    395 -351
    399 -348
    403 -346
    406 -344
    409 -341
    413 -339
    416 -336
    419 -334
    422 -331
    424 -329
    427 -326
    429 -324
    432 -321
    434 -318
    436 -316
    438 -313
    440 -310
    442 -307
    443 -305
    445 -302
    446 -299
    447 -296
    448 -293
    449 -291
    450 -288
    450 -285
    451 -282
    451 -279
    451 -276
    451 -273
    451 -270
    451 -267
    451 -264
    450 -261
    450 -258
    449 -255
    448 -251
    447 -248
    446 -245
    444 -242
    443 -239
    441 -236
    439 -232
    437 -229
    435 -226
    433 -223
    431 -219
    428 -216
    426 -213
    423 -210
    420 -206
    417 -203
    414 -200
    410 -196
    407 -193
    403 -189
    399 -186
    395 -183
    391 -179
    387 -176
    383 -173
    378 -169
    373 -166
    369 -162
    364 -159
    359 -155
    353 -152
    348 -148
    343 -145
    337 -141
    331 -138
    325 -134
    319 -131
    313 -127
    307 -124
    300 -120
    293 -117
    287 -113
    280 -110
    273 -106
    266 -103
    258 -99
    251 -96
    243 -92
    236 -89
    228 -85
    220 -82
    212 -78
    203 -75
    195 -71
    186 -67
    178 -64
    169 -60
    160 -57
    151 -53
    142 -50
    133 -46
    123 -43
    114 -39
    104 -36
    94 -32
    84 -28
    74 -25
    64 -21
    54 -18
    43 -14
    33 -11
    22 -7
    11 -4
    0 -0
    -11 3
    -22 7
    -33 11
    -45 14
    -56 18
    -68 21
    -80 25
    -92 28
    -103 32
    -116 35
    -128 39
    -140 42
    -153 46
    -165 49
    -178 53
    -191 56
    -204 60
    -217 63
    -230 66
    -243 70
    -256 73
    -270 77
    -283 80
    -297 84
    -311 87
    -325 91
    -339 94
    -353 97
    -367 101
    -381 104
    -396 108
    -410 111
    -425 115
    -439 118
    -454 121
    -469 125
    -484 128
    -499 131
    -515 135
    -530 138
    -545 141
    -561 145
    -576 148
    -592 151
    -608 155
    -624 158
    -640 161
    -656 165
    -672 168
    -688 171
    -705 175
    -721 178
    -738 181
    -754 184
    -771 188
    -788 191
    -805 194
    -822 197
    -839 201
    -856 204
    -873 207
    -890 210
    -908 213
    -925 217
    -943 220
    -960 223
    -978 226
    -996 229
    -1014 232
    1011 227
    993 224
    975 221
    957 218
    940 215
    922 212
    905 209
    887 206
    870 202
    853 199
    835 196
    818 193
    801 190
    784 187
    768 183
    751 180
    734 177
    718 174
    701 171
    685 167
    669 164
    653 161
    636 158
    620 154
    605 151
    589 148
    573 145
    557 141
    542 138
    527 135
    511 131
    496 128
    481 125
    466 122
    451 118
    436 115
    421 112
    407 108
    392 105
    378 102
    364 98
    349 95
    335 91
    321 88
    307 85
    294 81
    280 78
    266 75
    253 71
    240 68
    226 64
    213 61
    200 57
    187 54
    174 51
    162 47
    149 44
    137 40
    124 37
    112 33
    100 30
    88 27
    76 23
    64 20
    53 16
    41 13
    30 9
    19 6
    7 2
    -4 -1
    -15 -5
    -25 -8
    -36 -12
    -47 -15
    -57 -19
    -67 -22
    -78 -26
    -88 -29
    -98 -33
    -107 -36
    -117 -40
    -127 -43
    -136 -47
    -145 -50
    -155 -54
    -164 -57
    -173 -60
    -181 -64
    -190 -67
    -198 -71
    -207 -74
    -215 -78
    -223 -81
    -231 -85
    -239 -88
    -247 -92
    -254 -95
    -262 -99
    -269 -102
    -276 -106
    -283 -109
    -290 -113
    -297 -116
    -304 -120
    -310 -123
    -316 -127
    -323 -130
    -329 -133
    -335 -137
    -340 -140
    -346 -144
    -352 -147
    -357 -151
    -362 -154
    -367 -157
    -372 -161
    -377 -164
    -382 -168
    -386 -171
    -390 -174
    -395 -178
    -399 -181
    -403 -184
    -406 -188
    -410 -191
    -414 -194
    -417 -198
    -420 -201
    -423 -204
    -426 -207
    -429 -211
    -432 -214
    -434 -217
    -436 -220
    -439 -223
    -441 -227
    -443 -230
    -444 -233
    -446 -236
    -447 -239
    -449 -242
    -450 -245
    -451 -249
    -452 -252
    -453 -255
    -453 -258
    -454 -261
    -454 -264
    -454 -267
    -454 -270
    -454 -273
    -454 -276
    -454 -278
    -453 -281
    -453 -284
    -452 -287
    -451 -290
    -450 -293
    -449 -296
    -447 -298
    -446 -301
    -444 -304
    -443 -306
    -441 -309
    -439 -312
    -437 -314
    -434 -317
    -432 -320
    -430 -322
    -427 -325
    -424 -327
    -421 -330
    -418 -332
    -415 -335
    -412 -337
    -408 -339
    -405 -342
    -401 -344
    -398 -346
    -394 -349
    -390 -351
    -386 -353
    -381 -355
    -377 -357
    -373 -359
    -368 -361
    -364 -364
    -359 -366
    -354 -368
    -349 -369
    -344 -371
    -339 -373
    -333 -375
    -328 -377
    -323 -379
    -317 -380
    -311 -382
    -306 -384
    -300 -386
    -294 -387
    -288 -389
    -282 -390
    -276 -392
    -269 -393
    -263 -395
    -257 -396
    -250 -397
    -244 -399
    -237 -400
    -230 -401
    -224 -403
    -217 -404
    -210 -405
    -203 -406
    -196 -407
    -189 -408
    -182 -409
    -175 -410
    -167 -411
    -160 -412
    -153 -413
    -145 -413
    -138 -414
    -131 -415
    -123 -416
    -116 -416
    -108 -417
    -100 -417
    -93 -418
    -85 -418
    -78 -419
    -70 -419
    -62 -419
    -54 -420
    -47 -420
    -39 -420
    -31 -420
    -23 -421
    -16 -421
    -8 -421
    0 -421
    8 -421
    16 -421
    23 -421
    31 -420
    39 -420
    47 -420
    54 -420
    62 -419
    70 -419
    78 -419
    85 -418
    93 -418
    100 -417
    108 -417
    116 -416
    123 -416
    131 -415
    138 -414
    145 -413
    153 -413
    160 -412
    167 -411
    175 -410
    182 -409
    189 -408
    196 -407
    203 -406
    210 -405
    217 -404
    224 -403
    230 -401
    237 -400
    244 -399
    250 -397
    257 -396
    263 -395
    269 -393
    276 -392
    282 -390
    288 -389
    294 -387
    300 -386
    306 -384
    311 -382
    317 -380
    323 -379
    328 -377
    333 -375
    339 -373
    344 -371
    349 -369
    354 -368
    359 -366
    364 -364
    368 -361
    373 -359
    377 -357
    381 -355
    386 -353
    390 -351
    394 -349
    398 -346
    401 -344
    405 -342
    408 -339
    412 -337
    415 -335
    418 -332
    421 -330
    424 -327
    427 -325
    430 -322
    432 -320
    434 -317
    437 -314
    439 -312
    441 -309
    443 -306
    444 -304
    446 -301
    447 -298
    449 -296
    450 -293
    451 -290
    452 -287
    453 -284
    453 -281
    454 -278
    454 -276
    454 -273
    454 -270
    454 -267
    454 -264
    454 -261
    453 -258
    453 -255
    452 -252
    451 -249
    450 -245
    449 -242
    447 -239
    446 -236
    444 -233
    443 -230
    441 -227
    439 -223
    436 -220
    434 -217
    432 -214
    429 -211
    426 -207
    423 -204
    420 -201
    417 -198
    414 -194
    410 -191
    406 -188
    403 -184
    399 -181
    395 -178
    390 -174
    386 -171
    382 -168
    377 -164
    372 -161
    367 -157
    362 -154
    357 -151
    352 -147
    346 -144
    340 -140
    335 -137
    329 -133
    323 -130
    316 -127
    310 -123
    304 -120
    297 -116
    290 -113
    283 -109
    276 -106
    269 -102
    262 -99
    254 -95
    247 -92
    239 -88
    231 -85
    223 -81
    215 -78
    207 -74
    198 -71
    190 -67
    181 -64
    173 -60
    164 -57
    155 -54
    145 -50
    136 -47
    127 -43
    117 -40
    107 -36
    98 -33
    88 -29
    78 -26
    67 -22
    57 -19
    47 -15
    36 -12
    25 -8
    15 -5
    4 -1
    -7 2
    -19 6
    -30 9
    -41 13
    -53 16
    -64 20
    -76 23
    -88 27
    -100 30
    -112 33
    -124 37
    -137 40
    -149 44
    -162 47
    -174 51
    -187 54
    -200 57
    -213 61
    -226 64
    -240 68
    -253 71
    -266 75
    -280 78
    -294 81
    -307 85
    -321 88
    -335 91
    -349 95
    -364 98
    -378 102
    -392 105
    -407 108
    -421 112
    -436 115
    -451 118
    -466 122
    -481 125
    -496 128
    -511 131
    -527 135
    -542 138
    -557 141
    -573 145
    -589 148
    -605 151
    -620 154
    -636 158
    -653 161
    -669 164
    -685 167
    -701 171
    -718 174
    -734 177
    -751 180
    -768 183
    -784 187
    -801 190
    -818 193
    -835 196
    -853 199
    -870 202
    -887 206
    -905 209
    -922 212
    -940 215
    -957 218
    -975 221
    -993 224
    -1011 227
    1008 223
    990 219
    972 216
    954 213
    937 210
    919 207
    901 204
    884 201
    867 198
    849 195
    832 192
    815 189
    798 186
    781 182
    764 179
    748 176
    731 173
    715 170
    698 167
    682 163
    665 160
    649 157
    633 154
    617 151
    601 148
    586 144
    570 141
    554 138
    539 135
    523 131
    508 128
    493 125
    478 122
    463 118
    448 115
    433 112
    418 109
    403 105
    389 102
    375 99
    360 95
    346 92
    332 89
    318 86
    304 82
    290 79
    277 76
    263 72
    250 69
    236 66
    223 62
    210 59
    197 55
    184 52
    171 49
    158 45
    146 42
    133 39
    121 35
    109 32
    97 28
    85 25
    73 22
    61 18
    49 15
    38 11
    26 8
    15 5
    4 1
    -7 -2
    -18 -6
    -29 -9
    -40 -12
    -50 -16
    -61 -19
    -71 -23
    -81 -26
    -91 -30
    -101 -33
    -111 -37
    -121 -40
    -130 -43
    -140 -47
    -149 -50
    -158 -54
    -167 -57
    -176 -61
    -185 -64
    -193 -67
    -202 -71
    -210 -74
    -219 -78
    -227 -81
    -235 -85
    -242 -88
    -250 -91
    -258 -95
    -265 -98
    -273 -102
    -280 -105
    -287 -109
    -294 -112
    -300 -115
    -307 -119
    -313 -122
    -320 -126
    -326 -129
    -332 -132
    -338 -136
    -344 -139
    -349 -142
    -355 -146
    -360 -149
    -365 -153
    -371 -156
    -375 -159
    -380 -163
    -385 -166
    -389 -169
    -394 -172
    -398 -176
    -402 -179
    -406 -182
    -410 -186
    -413 -189
    -417 -192
    -420 -195
    -423 -199
    -426 -202
    -429 -205
    -432 -208
    -435 -211
    -437 -215
    -440 -218
    -442 -221
    -444 -224
    -446 -227
    -448 -230
    -449 -233
    -451 -236
    -452 -240
    -453 -243
    -454 -246
    -455 -249
    -456 -252
    -456 -255
    -457 -258
    -457 -261
    -457 -263
    -457 -266
    -457 -269
    -457 -272
    -457 -275
    -456 -278
    -456 -281
    -455 -284
    -454 -286
    -453 -289
    -452 -292
    -450 -295
    -449 -297
    -447 -300
    -445 -303
    -443 -305
    -441 -308
    -439 -310
    -437 -313
    -435 -316
    -432 -318
    -429 -321
    -427 -323
    -424 -325
    -421 -328
    -417 -330
    -414 -333
    -411 -335
    -407 -337
    -404 -340
    -400 -342
    -396 -344
    -392 -346
    -388 -348
    -384 -351
    -379 -353
    -375 -355
    -370 -357
    -366 -359
    -361 -361
    -356 -363
    -351 -365
    -346 -367
    -341 -368
    -335 -370
    -330 -372
    -324 -374
    -319 -375
    -313 -377
    -307 -379
    -301 -380
    -296 -382
    -290 -384
    -283 -385
    -277 -387
    -271 -388
    -265 -389
    -258 -391
    -252 -392
    -245 -394
    -238 -395
    -232 -396
    -225 -397
    -218 -398
    -211 -399
    -204 -401
    -197 -402
    -190 -403
    -183 -404
    -176 -405
    -168 -405
    -161 -406
    -154 -407
    -146 -408
    -139 -409
    -131 -409
    -124 -410
    -116 -411
    -109 -411
    -101 -412
    -93 -412
    -86 -413
    -78 -413
    -70 -413
    -62 -414
    -55 -414
    -47 -414
    -39 -415
    -31 -415
    -23 -415
    -16 -415
    -8 -415
    0 -415
    8 -415
    16 -415
    23 -415
    31 -415
    39 -415
    47 -414
    55 -414
    62 -414
    70 -413
    78 -413
    86 -413
    93 -412
    101 -412
    109 -411
    116 -411
    124 -410
    131 -409
    139 -409
    146 -408
    154 -407
    161 -406
    168 -405
    176 -405
    183 -404
    190 -403
    197 -402
    204 -401
    211 -399
    218 -398
    225 -397
    232 -396
    238 -395
    245 -394
    252 -392
    258 -391
    265 -389
    271 -388
    277 -387
    283 -385
    290 -384
    296 -382
    301 -380
    307 -379
    313 -377
    319 -375
    324 -374
    330 -372
    335 -370
    341 -368
    346 -367
    351 -365
    356 -363
    361 -361
    366 -359
    370 -357
    375 -355
    379 -353
    384 -351
    388 -348
    392 -346
    396 -344
    400 -342
    404 -340
    407 -337
    411 -335
    414 -333
    417 -330
    421 -328
    424 -325
    427 -323
    429 -321
    432 -318
    435 -316
    437 -313
    439 -310
    441 -308
    443 -305
    445 -303
    447 -300
    449 -297
    450 -295
    452 -292
    453 -289
    454 -286
    455 -284
    456 -281
    456 -278
    457 -275
    457 -272
    457 -269
    457 -266
    457 -263
    457 -261
    457 -258
    456 -255
    456 -252
    455 -249
    454 -246
    453 -243
    452 -240
    451 -236
    449 -233
    448 -230
    446 -227
    444 -224
    442 -221
    440 -218
    437 -215
    435 -211
    432 -208
    429 -205
    426 -202
    423 -199
    420 -195
    417 -192
    413 -189
    410 -186
    406 -182
    402 -179
    398 -176
    394 -172
    389 -169
    385 -166
    380 -163
    375 -159
    371 -156
    365 -153
    360 -149
    355 -146
    349 -142
    344 -139
    338 -136
    332 -132
    326 -129
    320 -126
    313 -122
    307 -119
    300 -115
    294 -112
    287 -109
    280 -105
    273 -102
    265 -98
    258 -95
    250 -91
    242 -88
    235 -85
    227 -81
    219 -78
    210 -74
    202 -71
    193 -67
    185 -64
    176 -61
    167 -57
    158 -54
    149 -50
    140 -47
    130 -43
    121 -40
    111 -37
    101 -33
    91 -30
    81 -26
    71 -23
    61 -19
    50 -16
    40 -12
    29 -9
    18 -6
    7 -2
    -4 1
    -15 5
    -26 8
    -38 11
    -49 15
    -61 18
    -73 22
    -85 25
    -97 28
    -109 32
    -121 35
    -133 39
    -146 42
    -158 45
    -171 49
    -184 52
    -197 55
    -210 59
    -223 62
    -236 66
    -250 69
    -263 72
    -277 76
    -290 79
    -304 82
    -318 86
    -332 89
    -346 92
    -360 95
    -375 99
    -389 102
    -403 105
    -418 109
    -433 112
    -448 115
    -463 118
    -478 122
    -493 125
    -508 128
    -523 131
    -539 135
    -554 138
    -570 141
    -586 144
    -601 148
    -617 151
    -633 154
    -649 157
    -665 160
    -682 163
    -698 167
    -715 170
    -731 173
    -748 176
    -764 179
    -781 182
    -798 186
    -815 189
    -832 192
    -849 195
    -867 198
    -884 201
    -901 204
    -919 207
    -937 210
    -954 213
    -972 216
    -990 219
    -1008 223
    1005 218
    987 215
    969 212
    951 209
    933 206
    916 203
    898 200
    881 197
    864 194
    846 191
    829 187
    812 184
    795 181
    778 178
    761 175
    745 172
    728 169
    711 166
    695 163
    679 160
    662 157
    646 153
    630 150
    614 147
    598 144
    582 141
    567 138
    551 135
    535 131
    520 128
    505 125
    489 122
    474 119
    459 115
    444 112
    430 109
    415 106
    400 103
    386 99
    371 96
    357 93
    343 90
    329 86
    315 83
    301 80
    287 77
    273 73
    260 70
    246 67
    233 63
    220 60
    206 57
    193 53
    180 50
    168 47
    155 44
    142 40
    130 37
    118 34
    105 30
    93 27
    81 24
    69 20
    58 17
    46 14
    34 10
    23 7
    12 4
    0 0
    -11 -3
    -21 -7
    -32 -10
    -43 -13
    -54 -17
    -64 -20
    -74 -23
    -84 -27
    -95 -30
    -104 -34
    -114 -37
    -124 -40
    -134 -44
    -143 -47
    -152 -50
    -161 -54
    -170 -57
    -179 -61
    -188 -64
    -197 -67
    -205 -71
    -214 -74
    -222 -77
    -230 -81
    -238 -84
    -246 -88
    -254 -91
    -261 -94
    -269 -98
    -276 -101
    -283 -104
    -290 -108
    -297 -111
    -304 -114
    -310 -118
    -317 -121
    -323 -124
    -329 -128
    -335 -131
    -341 -134
    -347 -138
    -353 -141
    -358 -144
    -364 -148
    -369 -151
    -374 -154
    -379 -158
    -384 -161
    -388 -164
    -393 -167
    -397 -171
    -401 -174
    -405 -177
    -409 -180
    -413 -184
    -417 -187
    -420 -190
    -423 -193
    -427 -196
    -430 -199
    -433 -203
    -435 -206
    -438 -209
    -440 -212
    -443 -215
    -445 -218
    -447 -221
    -449 -224
    -451 -227
    -452 -231
    -454 -234
    -455 -237
    -456 -240
    -457 -243
    -458 -246
    -459 -248
    -459 -251
    -460 -254
    -460 -257
    -460 -260
    -460 -263
    -460 -266
    -460 -269
    -460 -272
    -459 -274
    -458 -277
    -458 -280
    -457 -283
    -455 -285
    -454 -288
    -453 -291
    -451 -293
    -450 -296
    -448 -299
    -446 -301
    -444 -304
    -442 -306
    -440 -309
    -437 -311
    -435 -314
    -432 -316
    -429 -319
    -426 -321
    -423 -324
    -420 -326
    -417 -328
    -413 -330
    -410 -333
    -406 -335
    -402 -337
    -398 -339
    -394 -342
    -390 -344
    -386 -346
    -381 -348
    -377 -350
    -372 -352
    -368 -354
    -363 -356
    -358 -358
    -353 -360
    -348 -362
    -342 -363
    -337 -365
    -332 -367
    -326 -369
    -320 -370
    -315 -372
    -309 -374
    -303 -375
    -297 -377
    -291 -378
    -285 -380
    -279 -381
    -272 -383
    -266 -384
    -259 -385
    -253 -387
    -246 -388
    -240 -389
    -233 -391
    -226 -392
    -219 -393
    -212 -394
    -205 -395
    -198 -396
    -191 -397
    -184 -398
    -176 -399
    -169 -400
    -162 -401
    -154 -401
    -147 -402
    -139 -403
    -132 -404
    -124 -404
    -117 -405
    -109 -405
    -102 -406
    -94 -407
    -86 -407
    -78 -407
    -71 -408
    -63 -408
    -55 -408
    -47 -409
    -39 -409
    -31 -409
    -24 -409
    -16 -409
    -8 -409
    0 -409
    8 -409
    16 -409
    24 -409
    31 -409
    39 -409
    47 -409
    55 -408
    63 -408
    71 -408
    78 -407
    86 -407
    94 -407
    102 -406
    109 -405
    117 -405
    124 -404
    132 -404
    139 -403
    147 -402
    154 -401
    162 -401
    169 -400
    176 -399
    184 -398
    191 -397
    198 -396
    205 -395
    212 -394
    219 -393
    226 -392
    233 -391
    240 -389
    246 -388
    253 -387
    259 -385
    266 -384
    272 -383
    279 -381
    285 -380
    291 -378
    297 -377
    303 -375
    309 -374
    315 -372
    320 -370
    326 -369
    332 -367
    337 -365
    342 -363
    348 -362
    353 -360
    358 -358
    363 -356
    368 -354
    372 -352
    377 -350
    381 -348
    386 -346
    390 -344
    394 -342
    398 -339
    402 -337
    406 -335
    410 -333
    413 -330
    417 -328
    420 -326
    423 -324
    426 -321
    429 -319
    432 -316
    435 -314
    437 -311
    440 -309
    442 -306
    444 -304
    446 -301
    448 -299
    450 -296
    451 -293
    453 -291
    454 -288
    455 -285
    457 -283
    458 -280
    458 -277
    459 -274
    460 -272
    460 -269
    460 -266
    460 -263
    460 -260
    460 -257
    460 -254
    459 -251
    459 -248
    458 -246
    457 -243
    456 -240
    455 -237
    454 -234
    452 -231
    451 -227
    449 -224
    447 -221
    445 -218
    443 -215
    440 -212
    438 -209
    435 -206
    433 -203
    430 -199
    427 -196
    423 -193
    420 -190
    417 -187
    413 -184
    409 -180
    405 -177
    401 -174
    397 -171
    393 -167
    388 -164
    384 -161
    379 -158
    374 -154
    369 -151
    364 -148
    358 -144
    353 -141
    347 -138
    341 -134
    335 -131
    329 -128
    323 -124
    317 -121
    310 -118
    304 -114
    297 -111
    290 -108
    283 -104
    276 -101
    269 -98
    261 -94
    254 -91
    246 -88
    238 -84
    230 -81
    222 -77
    214 -74
    205 -71
    197 -67
    188 -64
    179 -61
    170 -57
    161 -54
    152 -50
    143 -47
    134 -44
    124 -40
    114 -37
    104 -34
    95 -30
    84 -27
    74 -23
    64 -20
    54 -17
    43 -13
    32 -10
    21 -7
    11 -3
    -0 0
    -12 4
    -23 7
    -34 10
    -46 14
    -58 17
    -69 20
    -81 24
    -93 27
    -105 30
    -118 34
    -130 37
    -142 40
    -155 44
    -168 47
    -180 50
    -193 53
    -206 57
    -220 60
    -233 63
    -246 67
    -260 70
    -273 73
    -287 77
    -301 80
    -315 83
    -329 86
    -343 90
    -357 93
    -371 96
    -386 99
    -400 103
    -415 106
    -430 109
    -444 112
    -459 115
    -474 119
    -489 122
    -505 125
    -520 128
    -535 131
    -551 135
    -567 138
    -582 141
    -598 144
    -614 147
    -630 150
    -646 153
    -662 157
    -679 160
    -695 163
    -711 166
    -728 169
    -745 172
    -761 175
    -778 178
    -795 181
    -812 184
    -829 187
    -846 191
    -864 194
    -881 197
    -898 200
    -916 203
    -933 206
    -951 209
    -969 212
    -987 215
    -1005 218
    1002 213
    984 210
    966 207
    948 204
    930 201
    913 198
    895 195
    878 192
    861 189
    843 186
    826 183
    809 180
    792 177
    775 174
    758 171
    742 168
    725 165
    708 162
    692 159
    676 156
    659 153
    643 150
    627 147
    611 144
    595 140
    579 137
    563 134
    548 131
    532 128
    517 125
    502 122
    486 119
    471 116
    456 112
    441 109
    426 106
    412 103
    397 100
    382 97
    368 93
    354 90
    340 87
    325 84
    311 81
    297 77
    284 74
    270 71
    256 68
    243 65
    230 61
    216 58
    203 55
    190 52
    177 48
    164 45
    152 42
    139 39
    127 35
    114 32
    102 29
    90 25
    78 22
    66 19
    54 16
    43 12
    31 9
    20 6
    8 2
    -3 -1
    -14 -4
    -25 -7
    -36 -11
    -46 -14
    -57 -17
    -67 -21
    -78 -24
    -88 -27
    -98 -31
    -108 -34
    -118 -37
    -127 -41
    -137 -44
    -146 -47
    -156 -51
    -165 -54
    -174 -57
    -183 -61
    -192 -64
    -200 -67
    -209 -70
    -217 -74
    -225 -77
    -233 -80
    -241 -84
    -249 -87
    -257 -90
    -265 -94
    -272 -97
    -279 -100
    -286 -104
    -293 -107
    -300 -110
    -307 -113
    -314 -117
    -320 -120
    -326 -123
    -333 -127
    -339 -130
    -345 -133
    -350 -136
    -356 -140
    -362 -143
    -367 -146
    -372 -149
    -377 -153
    -382 -156
    -387 -159
    -391 -162
    -396 -166
    -400 -169
    -404 -172
    -408 -175
    -412 -178
    -416 -181
    -420 -185
    -423 -188
    -427 -191
    -430 -194
    -433 -197
    -436 -200
    -438 -203
    -441 -206
    -444 -209
    -446 -212
    -448 -216
    -450 -219
    -452 -222
    -454 -225
    -455 -228
    -457 -231
    -458 -234
    -459 -236
    -460 -239
    -461 -242
    -462 -245
    -462 -248
    -463 -251
    -463 -254
    -463 -257
    -463 -260
    -463 -262
    -463 -265
    -462 -268
    -462 -271
    -461 -273
    -460 -276
    -459 -279
    -458 -282
    -457 -284
    -456 -287
    -454 -289
    -452 -292
    -451 -295
    -449 -297
    -447 -300
    -444 -302
    -442 -305
    -440 -307
    -437 -310
    -434 -312
    -431 -314
    -428 -317
    -425 -319
    -422 -321
    -419 -324
    -415 -326
    -412 -328
    -408 -330
    -404 -333
    -400 -335
    -396 -337
    -392 -339
    -388 -341
    -383 -343
    -379 -345
    -374 -347
    -369 -349
    -365 -351
    -360 -353
    -355 -355
    -349 -356
    -344 -358
    -339 -360
    -333 -362
    -328 -363
    -322 -365
    -316 -367
    -311 -368
    -305 -370
    -299 -371
    -293 -373
    -286 -374
    -280 -376
    -274 -377
    -267 -379
    -261 -380
    -254 -381
    -248 -383
    -241 -384
    -234 -385
    -227 -386
    -220 -387
    -213 -388
    -206 -389
    -199 -390
    -192 -391
    -185 -392
    -177 -393
    -170 -394
    -163 -395
    -155 -396
    -148 -396
    -140 -397
    -133 -398
    -125 -399
    -117 -399
    -110 -400
    -102 -400
    -94 -401
    -87 -401
    -79 -402
    -71 -402
    -63 -402
    -55 -403
    -47 -403
    -40 -403
    -32 -403
    -24 -403
    -16 -403
    -8 -403
    0 -403
    8 -403
    16 -403
    24 -403
    32 -403
    40 -403
    47 -403
    55 -403
    63 -402
    71 -402
    79 -402
    87 -401
    94 -401
    102 -400
    110 -400
    117 -399
    125 -399
    133 -398
    140 -397
    148 -396
    155 -396
    163 -395
    170 -394
    177 -393
    185 -392
    192 -391
    199 -390
    206 -389
    213 -388
    220 -387
    227 -386
    234 -385
    241 -384
    248 -383
    254 -381
    261 -380
    267 -379
    274 -377
    280 -376
    286 -374
    293 -373
    299 -371
    305 -370
    311 -368
    316 -367
    322 -365
    328 -363
    333 -362
    339 -360
    344 -358
    349 -356
    355 -355
    360 -353
    365 -351
    369 -349
    374 -347
    379 -345
    383 -343
    388 -341
    392 -339
    396 -337
    400 -335
    404 -333
    408 -330
    412 -328
    415 -326
    419 -324
    422 -321
    425 -319
    428 -317
    431 -314
    434 -312
    437 -310
    440 -307
    442 -305
    444 -302
    447 -300
    449 -297
    451 -295
    452 -292
    454 -289
    456 -287
    457 -284
    458 -282
    459 -279
    460 -276
    461 -273
    462 -271
    462 -268
    463 -265
    463 -262
    463 -260
    463 -257
    463 -254
    463 -251
    462 -248
    462 -245
    461 -242
    460 -239
    459 -236
    458 -234
    457 -231
    455 -228
    454 -225
    452 -222
    450 -219
    448 -216
    446 -212
    444 -209
    441 -206
    438 -203
    436 -200
    433 -197
    430 -194
    427 -191
    423 -188
    420 -185
    416 -181
    412 -178
    408 -175
    404 -172
    400 -169
    396 -166
    391 -162
    387 -159
    382 -156
    377 -153
    372 -149
    367 -146
    362 -143
    356 -140
    350 -136
    345 -133
    339 -130
    333 -127
    326 -123
    320 -120
    314 -117
    307 -113
    300 -110
    293 -107
    286 -104
    279 -100
    272 -97
    265 -94
    257 -90
    249 -87
    241 -84
    233 -80
    225 -77
    217 -74
    209 -70
    200 -67
    192 -64
    183 -61
    174 -57
    165 -54
    156 -51
    146 -47
    137 -44
    127 -41
    118 -37
    108 -34
    98 -31
    88 -27
    78 -24
    67 -21
    57 -17
    46 -14
    36 -11
    25 -7
    14 -4
    3 -1
    -8 2
    -20 6
    -31 9
    -43 12
    -54 16
    -66 19
    -78 22
    -90 25
    -102 29
    -114 32
    -127 35
    -139 39
    -152 42
    -164 45
    -177 48
    -190 52
    -203 55
    -216 58
    -230 61
    -243 65
    -256 68
    -270 71
    -284 74
    -297 77
    -311 81
    -325 84
    -340 87
    -354 90
    -368 93
    -382 97
    -397 100
    -412 103
    -426 106
    -441 109
    -456 112
    -471 116
    -486 119
    -502 122
    -517 125
    -532 128
    -548 131
    -563 134
    -579 137
    -595 140
    -611 144
    -627 147
    -643 150
    -659 153
    -676 156
    -692 159
    -708 162
    -725 165
    -742 168
    -758 171
    -775 174
    -792 177
    -809 180
    -826 183
    -843 186
    -861 189
    -878 192
    -895 195
    -913 198
    -930 201
    -948 204
    -966 207
    -984 210
    -1002 213
    999 208
    981 205
    963 202
    945 199
    928 197
    910 194
    892 191
    875 188
    858 185
    840 182
    823 179
    806 176
    789 173
    772 170
    755 167
    739 164
    722 161
    705 158
    689 155
    672 152
    656 149
    640 146
    624 143
    608 140
    592 137
    576 134
    560 131
    545 128
    529 125
    514 122
    498 119
    483 116
    468 113
    453 109
    438 106
    423 103
    409 100
    394 97
    379 94
    365 91
    351 88
    336 85
    322 81
    308 78
    294 75
    280 72
    267 69
    253 66
    240 62
    226 59
    213 56
    200 53
    187 50
    174 47
    161 43
    148 40
    136 37
    123 34
    111 31
    99 27
    87 24
    75 21
    63 18
    51 14
    39 11
    28 8
    16 5
    5 1
    -6 -2
    -17 -5
    -28 -8
    -39 -12
    -50 -15
    -60 -18
    -71 -21
    -81 -25
    -91 -28
    -101 -31
    -111 -34
    -121 -38
    -131 -41
    -140 -44
    -150 -47
    -159 -51
    -168 -54
    -177 -57
    -186 -60
    -195 -64
    -203 -67
    -212 -70
    -220 -73
    -229 -77
    -237 -80
    -245 -83
    -253 -86
    -260 -90
    -268 -93
    -275 -96
    -283 -99
    -290 -103
    -297 -106
    -304 -109
    -310 -112
    -317 -116
    -323 -119
    -330 -122
    -336 -125
    -342 -129
    -348 -132
    -354 -135
    -359 -138
    -365 -141
    -370 -145
    -375 -148
    -380 -151
    -385 -154
    -390 -157
    -395 -160
    -399 -164
    -403 -167
    -408 -170
    -412 -173
    -416 -176
    -419 -179
    -423 -182
    -426 -185
    -430 -188
    -433 -192
    -436 -195
    -439 -198
    -442 -201
    -444 -204
    -447 -207
    -449 -210
    -451 -213
    -453 -216
    -455 -219
    -457 -222
    -458 -225
    -460 -228
    -461 -230
    -462 -233
    -463 -236
    -464 -239
    -465 -242
    -465 -245
    -466 -248
    -466 -250
    -466 -253
    -466 -256
    -466 -259
    -465 -262
    -465 -264
    -464 -267
    -464 -270
    -463 -272
    -462 -275
    -461 -278
    -460 -280
    -458 -283
    -457 -285
    -455 -288
    -453 -290
    -451 -293
    -449 -295
    -447 -298
    -444 -300
    -442 -303
    -439 -305
    -437 -308
    -434 -310
    -431 -312
    -428 -314
    -424 -317
    -421 -319
    -418 -321
    -414 -323
    -410 -326
    -406 -328
    -402 -330
    -398 -332
    -394 -334
    -390 -336
    -385 -338
    -381 -340
    -376 -342
    -371 -344
    -367 -346
    -362 -348
    -356 -349
    -351 -351
    -346 -353
    -341 -355
    -335 -356
    -329 -358
    -324 -360
    -318 -361
    -312 -363
    -306 -365
    -300 -366
    -294 -368
    -288 -369
    -281 -370
    -275 -372
    -269 -373
    -262 -374
    -255 -376
    -249 -377
    -242 -378
    -235 -379
    -228 -380
    -221 -382
    -214 -383
    -207 -384
    -200 -385
    -193 -386
    -186 -387
    -178 -387
    -171 -388
    -163 -389
    -156 -390
    -148 -391
    -141 -391
    -133 -392
    -126 -393
    -118 -393
    -110 -394
    -103 -394
    -95 -395
    -87 -395
    -79 -396
    -71 -396
    -63 -396
    -56 -397
    -48 -397
    -40 -397
    -32 -397
    -24 -397
    -16 -397
    -8 -397
    0 -398
    8 -397
    16 -397
    24 -397
    32 -397
    40 -397
    48 -397
    56 -397
    63 -396
    71 -396
    79 -396
    87 -395
    95 -395
    103 -394
    110 -394
    118 -393
    126 -393
    133 -392
    141 -391
    148 -391
    156 -390
    163 -389
    171 -388
    178 -387
    186 -387
    193 -386
    200 -385
    207 -384
    214 -383
    221 -382
    228 -380
    235 -379
    242 -378
    249 -377
    255 -376
    262 -374
    269 -373
    275 -372
    281 -370
    288 -369
    294 -368
    300 -366
    306 -365
    312 -363
    318 -361
    324 -360
    329 -358
    335 -356
    341 -355
    346 -353
    351 -351
    356 -349
    362 -348
    367 -346
    371 -344
    376 -342
    381 -340
    385 -338
    390 -336
    394 -334
    398 -332
    402 -330
    406 -328
    410 -326
    414 -323
    418 -321
    421 -319
    424 -317
    428 -314
    431 -312
    434 -310
    437 -308
    439 -305
    442 -303
    444 -300
    447 -298
    449 -295
    451 -293
    453 -290
    455 -288
    457 -285
    458 -283
    460 -280
    461 -278
    462 -275
    463 -272
    464 -270
    464 -267
    465 -264
    465 -262
    466 -259
    466 -256
    466 -253
    466 -250
    466 -248
    465 -245
    465 -242
    464 -239
    463 -236
    462 -233
    461 -230
    460 -228
    458 -225
    457 -222
    455 -219
    453 -216
    451 -213
    449 -210
    447 -207
    444 -204
    442 -201
    439 -198
    436 -195
    433 -192
    430 -188
    426 -185
    423 -182
    419 -179
    416 -176
    412 -173
    408 -170
    403 -167
    399 -164
    395 -160
    390 -157
    385 -154
    380 -151
    375 -148
    370 -145
    365 -141
    359 -138
    354 -135
    348 -132
    342 -129
    336 -125
    330 -122
    323 -119
    317 -116
    310 -112
    304 -109
    297 -106
    290 -103
    283 -99
    275 -96
    268 -93
    260 -90
    253 -86
    245 -83
    237 -80
    229 -77
    220 -73
    212 -70
    203 -67
    195 -64
    186 -60
    177 -57
    168 -54
    159 -51
    150 -47
    140 -44
    131 -41
    121 -38
    111 -34
    101 -31
    91 -28
    81 -25
    71 -21
    60 -18
    50 -15
    39 -12
    28 -8
    17 -5
    6 -2
    -5 1
    -16 5
    -28 8
    -39 11
    -51 14
    -63 18
    -75 21
    -87 24
    -99 27
    -111 31
    -123 34
    -136 37
    -148 40
    -161 43
    -174 47
    -187 50
    -200 53
    -213 56
    -226 59
    -240 62
    -253 66
    -267 69
    -280 72
    -294 75
    -308 78
    -322 81
    -336 85
    -351 88
    -365 91
    -379 94
    -394 97
    -409 100
    -423 103
    -438 106
    -453 109
    -468 113
    -483 116
    -498 119
    -514 122
    -529 125
    -545 128
    -560 131
    -576 134
    -592 137
    -608 140
    -624 143
    -640 146
    -656 149
    -672 152
    -689 155
    -705 158
    -722 161
    -739 164
    -755 167
    -772 170
    -789 173
    -806 176
    -823 179
    -840 182
    -858 185
    -875 188
    -892 191
    -910 194
    -928 197
    -945 199
    -963 202
    -981 205
    -999 208
    996 203
    978 201
    960 198
    942 195
    925 192
    907 189
    890 186
    872 183
    855 181
    837 178
    820 175
    803 172
    786 169
    769 166
    752 163
    736 160
    719 157
    702 154
    686 151
    669 148
    653 145
    637 143
    621 140
    605 137
    589 134
    573 131
    557 128
    542 125
    526 122
    511 119
    495 116
    480 113
    465 110
    450 107
    435 103
    420 100
    405 97
    391 94
    376 91
    362 88
    347 85
    333 82
    319 79
    305 76
    291 73
    277 70
    264 67
    250 63
    237 60
    223 57
    210 54
    197 51
    184 48
    171 45
    158 42
    145 38
    133 35
    120 32
    108 29
    96 26
    83 23
    71 20
    60 16
    48 13
    36 10
    25 7
    13 4
    2 1
    -9 -3
    -20 -6
    -31 -9
    -42 -12
    -53 -15
    -63 -19
    -74 -22
    -84 -25
    -94 -28
    -104 -31
    -114 -35
    -124 -38
    -134 -41
    -143 -44
    -153 -47
    -162 -51
    -171 -54
    -180 -57
    -189 -60
    -198 -63
    -207 -67
    -215 -70
    -224 -73
    -232 -76
    -240 -79
    -248 -83
    -256 -86
    -263 -89
    -271 -92
    -278 -95
    -286 -99
    -293 -102
    -300 -105
    -307 -108
    -314 -111
    -320 -115
    -327 -118
    -333 -121
    -339 -124
    -345 -127
    -351 -130
    -357 -133
    -362 -137
    -368 -140
    -373 -143
    -378 -146
    -383 -149
    -388 -152
    -393 -155
    -398 -158
    -402 -162
    -407 -165
    -411 -168
    -415 -171
    -419 -174
    -422 -177
    -426 -180
    -429 -183
    -433 -186
    -436 -189
    -439 -192
    -442 -195
    -445 -198
    -447 -201
    -450 -204
    -452 -207
    -454 -210
    -456 -213
    -458 -216
    -460 -219
    -461 -221
    -462 -224
    -464 -227
    -465 -230
    -466 -233
    -467 -236
    -467 -239
    -468 -241
    -468 -244
    -469 -247
    -469 -250
    -469 -252
    -469 -255
    -468 -258
    -468 -260
    -467 -263
    -466 -266
    -466 -268
    -465 -271
    -463 -274
    -462 -276
    -461 -279
    -459 -281
    -457 -284
    -456 -286
    -454 -289
    -452 -291
    -449 -294
    -447 -296
    -444 -298
    -442 -301
    -439 -303
    -436 -305
    -433 -308
    -430 -310
    -427 -312
    -423 -314
    -420 -316
    -416 -319
    -412 -321
    -408 -323
    -404 -325
    -400 -327
    -396 -329
    -392 -331
    -387 -333
    -383 -335
    -378 -337
    -373 -339
    -368 -341
    -363 -342
    -358 -344
    -353 -346
    -348 -348
    -342 -349
    -337 -351
    -331 -353
    -325 -354
    -320 -356
    -314 -357
    -308 -359
    -302 -360
    -295 -362
    -289 -363
    -283 -365
    -276 -366
    -270 -367
    -263 -369
    -257 -370
    -250 -371
    -243 -372
    -236 -374
    -229 -375
    -222 -376
    -215 -377
    -208 -378
    -201 -379
    -194 -380
    -186 -381
    -179 -382
    -172 -382
    -164 -383
    -157 -384
    -149 -385
    -142 -385
    -134 -386
    -126 -387
    -119 -387
    -111 -388
    -103 -388
    -95 -389
    -87 -389
    -79 -390
    -72 -390
    -64 -390
    -56 -391
    -48 -391
    -40 -391
    -32 -391
    -24 -391
    -16 -391
    -8 -391
    0 -391
    8 -391
    16 -391
    24 -391
    32 -391
    40 -391
    48 -391
    56 -391
    64 -390
    72 -390
    79 -390
    87 -389
    95 -389
    103 -388
    111 -388
    119 -387
    126 -387
    134 -386
    142 -385
    149 -385
    157 -384
    164 -383
    172 -382
    179 -382
    186 -381
    194 -380
    201 -379
    208 -378
    215 -377
    222 -376
    229 -375
    236 -374
    243 -372
    250 -371
    257 -370
    263 -369
    270 -367
    276 -366
    283 -365
    289 -363
    295 -362
    302 -360
    308 -359
    314 -357
    320 -356
    325 -354
    331 -353
    337 -351
    342 -349
    348 -348
    353 -346
    358 -344
    363 -342
    368 -341
    373 -339
    378 -337
    383 -335
    387 -333
    392 -331
    396 -329
    400 -327
    404 -325
    408 -323
    412 -321
    416 -319
    420 -316
    423 -314
    427 -312
    430 -310
    433 -308
    436 -305
    439 -303
    442 -301
    444 -298
    447 -296
    449 -294
    452 -291
    454 -289
    456 -286
    457 -284
    459 -281
    461 -279
    462 -276
    463 -274
    465 -271
    466 -268
    466 -266
    467 -263
    468 -260
    468 -258
    469 -255
    469 -252
    469 -250
    469 -247
    468 -244
    468 -241
    467 -239
    467 -236
    466 -233
    465 -230
    464 -227
    462 -224
    461 -221
    460 -219
    458 -216
    456 -213
    454 -210
    452 -207
    450 -204
    447 -201
    445 -198
    442 -195
    439 -192
    436 -189
    433 -186
    429 -183
    426 -180
    422 -177
    419 -174
    415 -171
    411 -168
    407 -165
    402 -162
    398 -158
    393 -155
    388 -152
    383 -149
    378 -146
    373 -143
    368 -140
    362 -137
    357 -133
    351 -130
    345 -127
    339 -124
    333 -121
    327 -118
    320 -115
    314 -111
    307 -108
    300 -105
    293 -102
    286 -99
    278 -95
    271 -92
    263 -89
    256 -86
    248 -83
    240 -79
    232 -76
    224 -73
    215 -70
    207 -67
    198 -63
    189 -60
    180 -57
    171 -54
    162 -51
    153 -47
    143 -44
    134 -41
    124 -38
    114 -35
    104 -31
    94 -28
    84 -25
    74 -22
    63 -19
    53 -15
    42 -12
    31 -9
    20 -6
    9 -3
    -2 1
    -13 4
    -25 7
    -36 10
    -48 13
    -60 16
    -71 20
    -83 23
    -96 26
    -108 29
    -120 32
    -133 35
    -145 38
    -158 42
    -171 45
    -184 48
    -197 51
    -210 54
    -223 57
    -237 60
    -250 63
    -264 67
    -277 70
    -291 73
    -305 76
    -319 79
    -333 82
    -347 85
    -362 88
    -376 91
    -391 94
    -405 97
    -420 100
    -435 103
    -450 107
    -465 110
    -480 113
    -495 116
    -511 119
    -526 122
    -542 125
    -557 128
    -573 131
    -589 134
    -605 137
    -621 140
    -637 143
    -653 145
    -669 148
    -686 151
    -702 154
    -719 157
    -736 160
    -752 163
    -769 166
    -786 169
    -803 172
    -820 175
    -837 178
    -855 181
    -872 183
    -890 186
    -907 189
    -925 192
    -942 195
    -960 198
    -978 201
    -996 203
    993 199
    975 196
    957 193
    940 190
    922 187
    904 185
    887 182
    869 179
    852 176
    835 173
    817 171
    800 168
    783 165
    766 162
    749 159
    733 156
    716 153
    699 151
    683 148
    667 145
    650 142
    634 139
    618 136
    602 133
    586 130
    570 127
    554 124
    539 121
    523 118
    508 116
    492 113
    477 110
    462 107
    447 104
    432 101
    417 98
    402 95
    388 92
    373 89
    359 86
    344 83
    330 80
    316 77
    302 74
    288 71
    274 68
    261 64
    247 61
    234 58
    220 55
    207 52
    194 49
    181 46
    168 43
    155 40
    142 37
    130 34
    117 31
    105 28
    92 25
    80 21
    68 18
    56 15
    45 12
    33 9
    21 6
    10 3
    -1 -0
    -12 -3
    -24 -7
    -34 -10
    -45 -13
    -56 -16
    -67 -19
    -77 -22
    -87 -25
    -98 -29
    -108 -32
    -118 -35
    -127 -38
    -137 -41
    -147 -44
    -156 -47
    -165 -51
    -174 -54
    -184 -57
    -192 -60
    -201 -63
    -210 -66
    -218 -69
    -227 -73
    -235 -76
    -243 -79
    -251 -82
    -259 -85
    -267 -88
    -274 -91
    -282 -95
    -289 -98
    -296 -101
    -303 -104
    -310 -107
    -317 -110
    -323 -113
    -330 -116
    -336 -119
    -342 -123
    -348 -126
    -354 -129
    -360 -132
    -366 -135
    -371 -138
    -376 -141
    -382 -144
    -387 -147
    -391 -150
    -396 -153
    -401 -156
    -405 -159
    -410 -162
    -414 -166
    -418 -169
    -422 -172
    -425 -175
    -429 -178
    -432 -180
    -436 -183
    -439 -186
    -442 -189
    -445 -192
    -447 -195
    -450 -198
    -452 -201
    -455 -204
    -457 -207
    -459 -210
    -461 -213
    -462 -215
    -464 -218
    -465 -221
    -467 -224
    -468 -227
    -469 -230
    -469 -232
    -470 -235
    -471 -238
    -471 -241
    -471 -243
    -471 -246
    -471 -249
    -471 -251
    -471 -254
    -470 -257
    -470 -259
    -469 -262
    -468 -264
    -467 -267
    -466 -269
    -465 -272
    -463 -274
    -462 -277
    -460 -279
    -458 -282
    -456 -284
    -454 -287
    -452 -289
    -449 -291
    -447 -294
    -444 -296
    -441 -298
    -438 -301
    -435 -303
    -432 -305
    -429 -307
    -425 -309
    -422 -312
    -418 -314
    -414 -316
    -411 -318
    -407 -320
    -402 -322
    -398 -324
    -394 -326
    -389 -328
    -385 -330
    -380 -332
    -375 -333
    -370 -335
    -365 -337
    -360 -339
    -355 -341
    -349 -342
    -344 -344
    -338 -346
    -333 -347
    -327 -349
    -321 -350
    -315 -352
    -309 -353
    -303 -355
    -297 -356
    -291 -358
    -284 -359
    -278 -360
    -271 -362
    -265 -363
    -258 -364
    -251 -365
    -244 -367
    -237 -368
    -230 -369
    -223 -370
    -216 -371
    -209 -372
    -202 -373
    -195 -374
    -187 -375
    -180 -376
    -172 -376
    -165 -377
    -157 -378
    -150 -379
    -142 -379
    -135 -380
    -127 -381
    -119 -381
    -111 -382
    -103 -382
    -96 -383
    -88 -383
    -80 -383
    -72 -384
    -64 -384
    -56 -384
    -48 -385
    -40 -385
    -32 -385
    -24 -385
    -16 -385
    -8 -385
    0 -385
    8 -385
    16 -385
    24 -385
    32 -385
    40 -385
    48 -385
    56 -384
    64 -384
    72 -384
    80 -383
    88 -383
    96 -383
    103 -382
    111 -382
    119 -381
    127 -381
    135 -380
    142 -379
    150 -379
    157 -378
    165 -377
    172 -376
    180 -376
    187 -375
    195 -374
    202 -373
    209 -372
    216 -371
    223 -370
    230 -369
    237 -368
    244 -367
    251 -365
    258 -364
    265 -363
    271 -362
    278 -360
    284 -359
    291 -358
    297 -356
    303 -355
    309 -353
    315 -352
    321 -350
    327 -349
    333 -347
    338 -346
    344 -344
    349 -342
    355 -341
    360 -339
    365 -337
    370 -335
    375 -333
    380 -332
    385 -330
    389 -328
    394 -326
    398 -324
    402 -322
    407 -320
    411 -318
    414 -316
    418 -314
    422 -312
    425 -309
    429 -307
    432 -305
    435 -303
    438 -301
    441 -298
    444 -296
    447 -294
    449 -291
    452 -289
    454 -287
    456 -284
    458 -282
    460 -279
    462 -277
    463 -274
    465 -272
    466 -269
    467 -267
    468 -264
    469 -262
    470 -259
    470 -257
    471 -254
    471 -251
    471 -249
    471 -246
    471 -243
    471 -241
    471 -238
    470 -235
    469 -232
    469 -230
    468 -227
    467 -224
    465 -221
    464 -218
    462 -215
    461 -213
    459 -210
    457 -207
    455 -204
    452 -201
    450 -198
    447 -195
    445 -192
    442 -189
    439 -186
    436 -183
    432 -180
    429 -178
    425 -175
    422 -172
    418 -169
    414 -166
    410 -162
    405 -159
    401 -156
    396 -153
    391 -150
    387 -147
    382 -144
    376 -141
    371 -138
    366 -135
    360 -132
    354 -129
    348 -126
    342 -123
    336 -119
    330 -116
    323 -113
    317 -110
    310 -107
    303 -104
    296 -101
    289 -98
    282 -95
    274 -91
    267 -88
    259 -85
    251 -82
    243 -79
    235 -76
    227 -73
    218 -69
    210 -66
    201 -63
    192 -60
    184 -57
    174 -54
    165 -51
    156 -47
    147 -44
    137 -41
    127 -38
    118 -35
    108 -32
    98 -29
    87 -25
    77 -22
    67 -19
    56 -16
    45 -13
    34 -10
    24 -7
    12 -3
    1 -0
    -10 3
    -21 6
    -33 9
    -45 12
    -56 15
    -68 18
    -80 21
    -92 25
    -105 28
    -117 31
    -130 34
    -142 37
    -155 40
    -168 43
    -181 46
    -194 49
    -207 52
    -220 55
    -234 58
    -247 61
    -261 64
    -274 68
    -288 71
    -302 74
    -316 77
    -330 80
    -344 83
    -359 86
    -373 89
    -388 92
    -402 95
    -417 98
    -432 101
    -447 104
    -462 107
    -477 110
    -492 113
    -508 116
    -523 118
    -539 121
    -554 124
    -570 127
    -586 130
    -602 133
    -618 136
    -634 139
    -650 142
    -667 145
    -683 148
    -699 151
    -716 153
    -733 156
    -749 159
    -766 162
    -783 165
    -800 168
    -817 171
    -835 173
    -852 176
    -869 179
    -887 182
    -904 185
    -922 187
    -940 190
    -957 193
    -975 196
    -993 199
    990 194
    972 191
    955 189
    937 186
    919 183
    901 180
    884 178
    866 175
    849 172
    832 169
    815 166
    797 164
    780 161
    763 158
    747 155
    730 152
    713 150
    697 147
    680 144
    664 141
    647 138
    631 135
    615 133
    599 130
    583 127
    567 124
    552 121
    536 118
    520 115
    505 112
    489 110
    474 107
    459 104
    444 101
    429 98
    414 95
    399 92
    385 89
    370 86
    356 83
    341 80
    327 77
    313 74
    299 71
    285 68
    271 65
    258 62
    244 59
    230 56
    217 53
    204 50
    191 47
    178 44
    165 41
    152 38
    139 35
    127 32
    114 29
    102 26
    89 23
    77 20
    65 17
    53 14
    42 11
    30 8
    18 5
    7 2
    -4 -1
    -16 -4
    -27 -7
    -38 -10
    -48 -13
    -59 -17
    -70 -20
    -80 -23
    -90 -26
    -101 -29
    -111 -32
    -121 -35
    -130 -38
    -140 -41
    -150 -44
    -159 -47
    -168 -50
    -178 -54
    -187 -57
    -196 -60
    -204 -63
    -213 -66
    -221 -69
    -230 -72
    -238 -75
    -246 -78
    -254 -81
    -262 -84
    -270 -87
    -277 -91
    -285 -94
    -292 -97
    -299 -100
    -306 -103
    -313 -106
    -320 -109
    -326 -112
    -333 -115
    -339 -118
    -345 -121
    -351 -124
    -357 -127
    -363 -130
    -369 -133
    -374 -136
    -379 -139
    -385 -142
    -390 -145
    -394 -148
    -399 -151
    -404 -154
    -408 -157
    -413 -160
    -417 -163
    -421 -166
    -425 -169
    -428 -172
    -432 -175
    -435 -178
    -439 -181
    -442 -184
    -445 -187
    -448 -190
    -450 -192
    -453 -195
    -455 -198
    -458 -201
    -460 -204
    -462 -207
    -464 -209
    -465 -212
    -467 -215
    -468 -218
    -469 -221
    -470 -223
    -471 -226
    -472 -229
    -473 -232
    -473 -234
    -474 -237
    -474 -240
    -474 -242
    -474 -245
    -474 -247
    -473 -250
    -473 -253
    -472 -255
    -472 -258
    -471 -260
    -470 -263
    -468 -265
    -467 -268
    -466 -270
    -464 -273
    -462 -275
    -460 -277
    -458 -280
    -456 -282
    -454 -285
    -452 -287
    -449 -289
    -446 -291
    -444 -294
    -441 -296
    -438 -298
    -434 -300
    -431 -302
    -428 -305
    -424 -307
    -420 -309
    -417 -311
    -413 -313
    -409 -315
    -404 -317
    -400 -319
    -396 -321
    -391 -323
    -387 -324
    -382 -326
    -377 -328
    -372 -330
    -367 -332
    -362 -333
    -356 -335
    -351 -337
    -346 -338
    -340 -340
    -334 -342
    -329 -343
    -323 -345
    -317 -346
    -311 -348
    -305 -349
    -298 -351
    -292 -352
    -286 -353
    -279 -355
    -273 -356
    -266 -357
    -259 -358
    -252 -359
    -246 -361
    -239 -362
    -232 -363
    -224 -364
    -217 -365
    -210 -366
    -203 -367
    -196 -368
    -188 -369
    -181 -369
    -173 -370
    -166 -371
    -158 -372
    -151 -372
    -143 -373
    -135 -374
    -127 -374
    -120 -375
    -112 -375
    -104 -376
    -96 -376
    -88 -377
    -80 -377
    -72 -377
    -64 -378
    -56 -378
    -48 -378
    -40 -378
    -32 -379
    -24 -379
    -16 -379
    -8 -379
    0 -379
    8 -379
    16 -379
    24 -379
    32 -379
    40 -378
    48 -378
    56 -378
    64 -378
    72 -377
    80 -377
    88 -377
    96 -376
    104 -376
    112 -375
    120 -375
    127 -374
    135 -374
    143 -373
    151 -372
    158 -372
    166 -371
    173 -370
    181 -369
    188 -369
    196 -368
    203 -367
    210 -366
    217 -365
    224 -364
    232 -363
    239 -362
    246 -361
    252 -359
    259 -358
    266 -357
    273 -356
    279 -355
    286 -353
    292 -352
    298 -351
    305 -349
    311 -348
    317 -346
    323 -345
    329 -343
    334 -342
    340 -340
    346 -338
    351 -337
    356 -335
    362 -333
    367 -332
    372 -330
    377 -328
    382 -326
    387 -324
    391 -323
    396 -321
    400 -319
    404 -317
    409 -315
    413 -313
    417 -311
    420 -309
    424 -307
    428 -305
    431 -302
    434 -300
    438 -298
    441 -296
    444 -294
    446 -291
    449 -289
    452 -287
    454 -285
    456 -282
    458 -280
    460 -277
    462 -275
    464 -273
    466 -270
    467 -268
    468 -265
    470 -263
    471 -260
    472 -258
    472 -255
    473 -253
    473 -250
    474 -247
    474 -245
    474 -242
    474 -240
    474 -237
    473 -234
    473 -232
    472 -229
    471 -226
    470 -223
    469 -221
    468 -218
    467 -215
    465 -212
    464 -209
    462 -207
    460 -204
    458 -201
    455 -198
    453 -195
    450 -192
    448 -190
    445 -187
    442 -184
    439 -181
    435 -178
    432 -175
    428 -172
    425 -169
    421 -166
    417 -163
    413 -160
    408 -157
    404 -154
    399 -151
    394 -148
    390 -145
    385 -142
    379 -139
    374 -136
    369 -133
    363 -130
    357 -127
    351 -124
    345 -121
    339 -118
    333 -115
    326 -112
    320 -109
    313 -106
    306 -103
    299 -100
    292 -97
    285 -94
    277 -91
    270 -87
    262 -84
    254 -81
    246 -78
    238 -75
    230 -72
    221 -69
    213 -66
    204 -63
    196 -60
    187 -57
    178 -54
    168 -50
    159 -47
    150 -44
    140 -41
    130 -38
    121 -35
    111 -32
    101 -29
    90 -26
    80 -23
    70 -20
    59 -17
    48 -13
    38 -10
    27 -7
    16 -4
    4 -1
    -7 2
    -18 5
    -30 8
    -42 11
    -53 14
    -65 17
    -77 20
    -89 23
    -102 26
    -114 29
    -127 32
    -139 35
    -152 38
    -165 41
    -178 44
    -191 47
    -204 50
    -217 53
    -230 56
    -244 59
    -258 62
    -271 65
    -285 68
    -299 71
    -313 74
    -327 77
    -341 80
    -356 83
    -370 86
    -385 89
    -399 92
    -414 95
    -429 98
    -444 101
    -459 104
    -474 107
    -489 110
    -505 112
    -520 115
    -536 118
    -552 121
    -567 124
    -583 127
    -599 130
    -615 133
    -631 135
    -647 138
    -664 141
    -680 144
    -697 147
    -713 150
    -730 152
    -747 155
    -763 158
    -780 161
    -797 164
    -815 166
    -832 169
    -849 172
    -866 175
    -884 178
    -901 180
    -919 183
    -937 186
    -955 189
    -972 191
    -990 194
    988 189
    970 187
    952 184
    934 181
    916 179
    899 176
    881 173
    864 171
    846 168
    829 165
    812 162
    795 160
    778 157
    761 154
    744 151
    727 149
    710 146
    694 143
    677 140
    661 138
    645 135
    628 132
    612 129
    596 126
    580 124
    564 121
    549 118
    533 115
    517 112
    502 109
    487 107
    471 104
    456 101
    441 98
    426 95
    411 92
    397 89
    382 87
    367 84
    353 81
    339 78
    324 75
    310 72
    296 69
    282 66
    268 63
    255 60
    241 57
    228 55
    214 52
    201 49
    188 46
    175 43
    162 40
    149 37
    136 34
    124 31
    111 28
    99 25
    86 22
    74 19
    62 16
    50 13
    39 10
    27 7
    15 4
    4 1
    -7 -2
    -19 -5
    -30 -8
    -41 -11
    -51 -14
    -62 -17
    -73 -20
    -83 -23
    -93 -26
    -104 -29
    -114 -32
    -124 -35
    -134 -38
    -143 -41
    -153 -44
    -162 -47
    -172 -50
    -181 -53
    -190 -56
    -199 -59
    -207 -62
    -216 -65
    -225 -68
    -233 -71
    -241 -74
    -249 -77
    -257 -80
    -265 -84
    -273 -87
    -280 -90
    -288 -93
    -295 -96
    -302 -99
    -309 -102
    -316 -105
    -323 -108
    -329 -111
    -336 -114
    -342 -117
    -348 -120
    -354 -123
    -360 -126
    -366 -129
    -372 -131
    -377 -134
    -382 -137
    -388 -140
    -393 -143
    -397 -146
    -402 -149
    -407 -152
    -411 -155
    -416 -158
    -420 -161
    -424 -164
    -428 -167
    -431 -170
    -435 -172
    -438 -175
    -442 -178
    -445 -181
    -448 -184
    -451 -187
    -453 -190
    -456 -192
    -458 -195
    -460 -198
    -463 -201
    -464 -203
    -466 -206
    -468 -209
    -469 -212
    -471 -214
    -472 -217
    -473 -220
    -474 -223
    -475 -225
    -476 -228
    -476 -231
    -476 -233
    -477 -236
    -477 -238
    -477 -241
    -476 -243
    -476 -246
    -476 -249
    -475 -251
    -474 -254
    -473 -256
    -472 -259
    -471 -261
    -470 -263
    -468 -266
    -466 -268
    -465 -271
    -463 -273
    -461 -275
    -459 -278
    -456 -280
    -454 -282
    -451 -284
    -449 -287
    -446 -289
    -443 -291
    -440 -293
    -437 -295
    -433 -297
    -430 -299
    -426 -302
    -422 -304
    -419 -306
    -415 -308
    -411 -310
    -406 -312
    -402 -313
    -398 -315
    -393 -317
    -388 -319
    -384 -321
    -379 -323
    -374 -324
    -369 -326
    -363 -328
    -358 -329
    -353 -331
    -347 -333
    -342 -334
    -336 -336
    -330 -337
    -324 -339
    -318 -340
    -312 -342
    -306 -343
    -300 -345
    -293 -346
    -287 -347
    -280 -349
    -274 -350
    -267 -351
    -260 -352
    -254 -353
    -247 -355
    -240 -356
    -233 -357
    -226 -358
    -218 -359
    -211 -360
    -204 -361
    -196 -361
    -189 -362
    -182 -363
    -174 -364
    -166 -365
    -159 -365
    -151 -366
    -144 -367
    -136 -367
    -128 -368
    -120 -369
    -112 -369
    -104 -370
    -97 -370
    -89 -370
    -81 -371
    -73 -371
    -65 -371
    -57 -372
    -49 -372
    -40 -372
    -32 -372
    -24 -372
    -16 -372
    -8 -373
    0 -373
    8 -373
    16 -372
    24 -372
    32 -372
    40 -372
    49 -372
    57 -372
    65 -371
    73 -371
    81 -371
    89 -370
    97 -370
    104 -370
    112 -369
    120 -369
    128 -368
    136 -367
    144 -367
    151 -366
    159 -365
    166 -365
    174 -364
    182 -363
    189 -362
    196 -361
    204 -361
    211 -360
    218 -359
    226 -358
    233 -357
    240 -356
    247 -355
    254 -353
    260 -352
    267 -351
    274 -350
    280 -349
    287 -347
    293 -346
    300 -345
    306 -343
    312 -342
    318 -340
    324 -339
    330 -337
    336 -336
    342 -334
    347 -333
    353 -331
    358 -329
    363 -328
    369 -326
    374 -324
    379 -323
    384 -321
    388 -319
    393 -317
    398 -315
    402 -313
    406 -312
    411 -310
    415 -308
    419 -306
    422 -304
    426 -302
    430 -299
    433 -297
    437 -295
    440 -293
    443 -291
    446 -289
    449 -287
    451 -284
    454 -282
    456 -280
    459 -278
    461 -275
    463 -273
    465 -271
    466 -268
    468 -266
    470 -263
    471 -261
    472 -259
    473 -256
    474 -254
    475 -251
    476 -249
    476 -246
    476 -243
    477 -241
    477 -238
    477 -236
    476 -233
    476 -231
    476 -228
    475 -225
    474 -223
    473 -220
    472 -217
    471 -214
    469 -212
    468 -209
    466 -206
    464 -203
    463 -201
    460 -198
    458 -195
    456 -192
    453 -190
    451 -187
    448 -184
    445 -181
    442 -178
    438 -175
    435 -172
    431 -170
    428 -167
    424 -164
    420 -161
    416 -158
    411 -155
    407 -152
    402 -149
    397 -146
    393 -143
    388 -140
    382 -137
    377 -134
    372 -131
    366 -129
    360 -126
    354 -123
    348 -120
    342 -117
    336 -114
    329 -111
    323 -108
    316 -105
    309 -102
    302 -99
    295 -96
    288 -93
    280 -90
    273 -87
    265 -84
    257 -80
    249 -77
    241 -74
    233 -71
    225 -68
    216 -65
    207 -62
    199 -59
    190 -56
    181 -53
    172 -50
    162 -47
    153 -44
    143 -41
    134 -38
    124 -35
    114 -32
    104 -29
    93 -26
    83 -23
    73 -20
    62 -17
    51 -14
    41 -11
    30 -8
    19 -5
    7 -2
    -4 1
    -15 4
    -27 7
    -39 10
    -50 13
    -62 16
    -74 19
    -86 22
    -99 25
    -111 28
    -124 31
    -136 34
    -149 37
    -162 40
    -175 43
    -188 46
    -201 49
    -214 52
    -228 55
    -241 57
    -255 60
    -268 63
    -282 66
    -296 69
    -310 72
    -324 75
    -339 78
    -353 81
    -367 84
    -382 87
    -397 89
    -411 92
    -426 95
    -441 98
    -456 101
    -471 104
    -487 107
    -502 109
    -517 112
    -533 115
    -549 118
    -564 121
    -580 124
    -596 126
    -612 129
    -628 132
    -645 135
    -661 138
    -677 140
    -694 143
    -710 146
    -727 149
    -744 151
    -761 154
    -778 157
    -795 160
    -812 162
    -829 165
    -846 168
    -864 171
    -881 173
    -899 176
    -916 179
    -934 181
    -952 184
    -970 187
    -988 189
    985 185
    967 182
    949 179
    931 177
    914 174
    896 172
    878 169
    861 166
    844 164
    826 161
    809 158
    792 156
    775 153
    758 150
    741 148
    724 145
    708 142
    691 139
    675 137
    658 134
    642 131
    626 129
    609 126
    593 123
    577 120
    562 118
    546 115
    530 112
    515 109
    499 106
    484 104
    469 101
    453 98
    438 95
    423 92
    408 90
    394 87
    379 84
    364 81
    350 78
    336 76
    321 73
    307 70
    293 67
    279 64
    265 61
    252 58
    238 56
    225 53
    211 50
    198 47
    185 44
    172 41
    159 38
    146 35
    133 32
    121 29
    108 27
    96 24
    83 21
    71 18
    59 15
    47 12
    36 9
    24 6
    12 3
    1 0
    -10 -3
    -22 -6
    -33 -9
    -44 -12
    -54 -14
    -65 -17
    -76 -20
    -86 -23
    -96 -26
    -107 -29
    -117 -32
    -127 -35
    -137 -38
    -146 -41
    -156 -44
    -165 -47
    -174 -50
    -184 -53
    -193 -56
    -202 -59
    -210 -62
    -219 -65
    -228 -68
    -236 -71
    -244 -74
    -252 -77
    -260 -80
    -268 -83
    -276 -86
    -283 -89
    -291 -91
    -298 -94
    -305 -97
    -312 -100
    -319 -103
    -326 -106
    -332 -109
    -339 -112
    -345 -115
    -351 -118
    -357 -121
    -363 -124
    -369 -127
    -375 -130
    -380 -133
    -385 -135
    -390 -138
    -395 -141
    -400 -144
    -405 -147
    -410 -150
    -414 -153
    -418 -156
    -423 -158
    -427 -161
    -430 -164
    -434 -167
    -438 -170
    -441 -173
    -444 -175
    -448 -178
    -450 -181
    -453 -184
    -456 -187
    -459 -189
    -461 -192
    -463 -195
    -465 -198
    -467 -200
    -469 -203
    -471 -206
    -472 -208
    -474 -211
    -475 -214
    -476 -216
    -477 -219
    -478 -222
    -478 -224
    -479 -227
    -479 -229
    -479 -232
    -479 -234
    -479 -237
    -479 -239
    -479 -242
    -478 -244
    -477 -247
    -477 -249
    -476 -252
    -475 -254
    -473 -257
    -472 -259
    -470 -261
    -469 -264
    -467 -266
    -465 -268
    -463 -271
    -461 -273
    -459 -275
    -456 -277
    -454 -280
    -451 -282
    -448 -284
    -445 -286
    -442 -288
    -439 -290
    -435 -292
    -432 -294
    -428 -296
    -424 -298
    -421 -300
    -417 -302
    -412 -304
    -408 -306
    -404 -308
    -399 -310
    -395 -312
    -390 -314
    -385 -315
    -380 -317
    -375 -319
    -370 -320
    -365 -322
    -360 -324
    -354 -325
    -349 -327
    -343 -329
    -337 -330
    -332 -332
    -326 -333
    -320 -335
    -314 -336
    -307 -337
    -301 -339
    -295 -340
    -288 -341
    -282 -343
    -275 -344
    -268 -345
    -262 -346
    -255 -347
    -248 -348
    -241 -349
    -234 -350
    -227 -351
    -219 -352
    -212 -353
    -205 -354
    -197 -355
    -190 -356
    -182 -357
    -175 -358
    -167 -358
    -160 -359
    -152 -360
    -144 -360
    -136 -361
    -129 -362
    -121 -362
    -113 -363
    -105 -363
    -97 -364
    -89 -364
    -81 -364
    -73 -365
    -65 -365
    -57 -365
    -49 -365
    -41 -366
    -33 -366
    -24 -366
    -16 -366
    -8 -366
    0 -366
    8 -366
    16 -366
    24 -366
    33 -366
    41 -366
    49 -365
    57 -365
    65 -365
    73 -365
    81 -364
    89 -364
    97 -364
    105 -363
    113 -363
    121 -362
    129 -362
    136 -361
    144 -360
    152 -360
    160 -359
    167 -358
    175 -358
    182 -357
    190 -356
    197 -355
    205 -354
    212 -353
    219 -352
    227 -351
    234 -350
    241 -349
    248 -348
    255 -347
    262 -346
    268 -345
    275 -344
    282 -343
    288 -341
    295 -340
    301 -339
    307 -337
    314 -336
    320 -335
    326 -333
    332 -332
    337 -330
    343 -329
    349 -327
    354 -325
    360 -324
    365 -322
    370 -320
    375 -319
    380 -317
    385 -315
    390 -314
    395 -312
    399 -310
    404 -308
    408 -306
    412 -304
    417 -302
    421 -300
    424 -298
    428 -296
    432 -294
    435 -292
    439 -290
    442 -288
    445 -286
    448 -284
    451 -282
    454 -280
    456 -277
    459 -275
    461 -273
    463 -271
    465 -268
    467 -266
    469 -264
    470 -261
    472 -259
    473 -257
    475 -254
    476 -252
    477 -249
    477 -247
    478 -244
    479 -242
    479 -239
    479 -237
    479 -234
    479 -232
    479 -229
    479 -227
    478 -224
    478 -222
    477 -219
    476 -216
    475 -214
    474 -211
    472 -208
    471 -206
    469 -203
    467 -200
    465 -198
    463 -195
    461 -192
    459 -189
    456 -187
    453 -184
    450 -181
    448 -178
    444 -175
    441 -173
    438 -170
    434 -167
    430 -164
    427 -161
    423 -158
    418 -156
    414 -153
    410 -150
    405 -147
    400 -144
    395 -141
    390 -138
    385 -135
    380 -133
    375 -130
    369 -127
    363 -124
    357 -121
    351 -118
    345 -115
    339 -112
    332 -109
    326 -106
    319 -103
    312 -100
    305 -97
    298 -94
    291 -91
    283 -89
    276 -86
    268 -83
    260 -80
    252 -77
    244 -74
    236 -71
    228 -68
    219 -65
    210 -62
    202 -59
    193 -56
    184 -53
    174 -50
    165 -47
    156 -44
    146 -41
    137 -38
    127 -35
    117 -32
    107 -29
    96 -26
    86 -23
    76 -20
    65 -17
    54 -14
    44 -12
    33 -9
    22 -6
    10 -3
    -1 0
    -12 3
    -24 6
    -36 9
    -47 12
    -59 15
    -71 18
    -83 21
    -96 24
    -108 27
    -121 29
    -133 32
    -146 35
    -159 38
    -172 41
    -185 44
    -198 47
    -211 50
    -225 53
    -238 56
    -252 58
    -265 61
    -279 64
    -293 67
    -307 70
    -321 73
    -336 76
    -350 78
    -364 81
    -379 84
    -394 87
    -408 90
    -423 92
    -438 95
    -453 98
    -469 101
    -484 104
    -499 106
    -515 109
    -530 112
    -546 115
    -562 118
    -577 120
    -593 123
    -609 126
    -626 129
    -642 131
    -658 134
    -675 137
    -691 139
    -708 142
    -724 145
    -741 148
    -758 150
    -775 153
    -792 156
    -809 158
    -826 161
    -844 164
    -861 166
    -878 169
    -896 172
    -914 174
    -931 177
    -949 179
    -967 182
    -985 185
    983 180
    965 178
    947 175
    929 172
    911 170
    893 167
    876 165
    858 162
    841 159
    824 157
    806 154
    789 152
    772 149
    755 146
    738 144
    722 141
    705 138
    688 136
    672 133
    655 130
    639 128
    623 125
    607 122
    591 120
    575 117
    559 114
    543 112
    527 109
    512 106
    496 104
    481 101
    466 98
    451 95
    436 93
    421 90
    406 87
    391 84
    376 82
    362 79
    347 76
    333 73
    319 70
    304 68
    290 65
    276 62
    263 59
    249 56
    235 54
    222 51
    208 48
    195 45
    182 42
    169 40
    156 37
    143 34
    130 31
    118 28
    105 25
    93 22
    81 20
    68 17
    56 14
    44 11
    33 8
    21 5
    9 2
    -2 -1
    -13 -3
    -24 -6
    -36 -9
    -47 -12
    -57 -15
    -68 -18
    -79 -21
    -89 -24
    -99 -27
    -110 -29
    -120 -32
    -130 -35
    -139 -38
    -149 -41
    -159 -44
    -168 -47
    -177 -50
    -187 -53
    -196 -56
    -205 -58
    -213 -61
    -222 -64
    -230 -67
    -239 -70
    -247 -73
    -255 -76
    -263 -79
    -271 -82
    -279 -85
    -286 -87
    -294 -90
    -301 -93
    -308 -96
    -315 -99
    -322 -102
    -329 -105
    -335 -108
    -342 -111
    -348 -113
    -354 -116
    -360 -119
    -366 -122
    -372 -125
    -377 -128
    -383 -131
    -388 -133
    -393 -136
    -398 -139
    -403 -142
    -408 -145
    -413 -148
    -417 -150
    -421 -153
    -425 -156
    -429 -159
    -433 -162
    -437 -164
    -440 -167
    -444 -170
    -447 -173
    -450 -175
    -453 -178
    -456 -181
    -459 -183
    -461 -186
    -464 -189
    -466 -192
    -468 -194
    -470 -197
    -472 -200
    -473 -202
    -475 -205
    -476 -207
    -477 -210
    -478 -213
    -479 -215
    -480 -218
    -481 -220
    -481 -223
    -482 -225
    -482 -228
    -482 -230
    -482 -233
    -481 -235
    -481 -238
    -480 -240
    -480 -243
    -479 -245
    -478 -247
    -477 -250
    -476 -252
    -474 -255
    -473 -257
    -471 -259
    -469 -261
    -467 -264
    -465 -266
    -463 -268
    -461 -270
    -458 -273
    -456 -275
    -453 -277
    -450 -279
    -447 -281
    -444 -283
    -441 -285
    -437 -287
    -434 -289
    -430 -291
    -426 -293
    -422 -295
    -418 -297
    -414 -299
    -410 -301
    -406 -303
    -401 -304
    -397 -306
    -392 -308
    -387 -310
    -382 -311
    -377 -313
    -372 -315
    -367 -316
    -361 -318
    -356 -320
    -350 -321
    -345 -323
    -339 -324
    -333 -326
    -327 -327
    -321 -329
    -315 -330
    -309 -331
    -302 -333
    -296 -334
    -289 -335
    -283 -336
    -276 -338
    -269 -339
    -263 -340
    -256 -341
    -249 -342
    -242 -343
    -235 -344
    -227 -345
    -220 -346
    -213 -347
    -206 -348
    -198 -349
    -191 -350
    -183 -350
    -176 -351
    -168 -352
    -160 -353
    -153 -353
    -145 -354
    -137 -354
    -129 -355
    -121 -356
    -113 -356
    -105 -357
    -97 -357
    -89 -357
    -81 -358
    -73 -358
    -65 -358
    -57 -359
    -49 -359
    -41 -359
    -33 -359
    -24 -359
    -16 -359
    -8 -359
    0 -359
    8 -359
    16 -359
    24 -359
    33 -359
    41 -359
    49 -359
    57 -359
    65 -358
    73 -358
    81 -358
    89 -357
    97 -357
    105 -357
    113 -356
    121 -356
    129 -355
    137 -354
    145 -354
    153 -353
    160 -353
    168 -352
    176 -351
    183 -350
    191 -350
    198 -349
    206 -348
    213 -347
    220 -346
    227 -345
    235 -344
    242 -343
    249 -342
    256 -341
    263 -340
    269 -339
    276 -338
    283 -336
    289 -335
    296 -334
    302 -333
    309 -331
    315 -330
    321 -329
    327 -327
    333 -326
    339 -324
    345 -323
    350 -321
    356 -320
    361 -318
    367 -316
    372 -315
    377 -313
    382 -311
    387 -310
    392 -308
    397 -306
    401 -304
    406 -303
    410 -301
    414 -299
    418 -297
    422 -295
    426 -293
    430 -291
    434 -289
    437 -287
    441 -285
    444 -283
    447 -281
    450 -279
    453 -277
    456 -275
    458 -273
    461 -270
    463 -268
    465 -266
    467 -264
    469 -261
    471 -259
    473 -257
    474 -255
    476 -252
    477 -250
    478 -247
    479 -245
    480 -243
    480 -240
    481 -238
    481 -235
    482 -233
    482 -230
    482 -228
    482 -225
    481 -223
    481 -220
    480 -218
    479 -215
    478 -213
    477 -210
    476 -207
    475 -205
    473 -202
    472 -200
    470 -197
    468 -194
    466 -192
    464 -189
    461 -186
    459 -183
    456 -181
    453 -178
    450 -175
    447 -173
    444 -170
    440 -167
    437 -164
    433 -162
    429 -159
    425 -156
    421 -153
    417 -150
    413 -148
    408 -145
    403 -142
    398 -139
    393 -136
    388 -133
    383 -131
    377 -128
    372 -125
    366 -122
    360 -119
    354 -116
    348 -113
    342 -111
    335 -108
    329 -105
    322 -102
    315 -99
    308 -96
    301 -93
    294 -90
    286 -87
    279 -85
    271 -82
    263 -79
    255 -76
    247 -73
    239 -70
    230 -67
    222 -64
    213 -61
    205 -58
    196 -56
    187 -53
    177 -50
    168 -47
    159 -44
    149 -41
    139 -38
    130 -35
    120 -32
    110 -29
    99 -27
    89 -24
    79 -21
    68 -18
    57 -15
    47 -12
    36 -9
    24 -6
    13 -3
    2 -1
    -9 2
    -21 5
    -33 8
    -44 11
    -56 14
    -68 17
    -81 20
    -93 22
    -105 25
    -118 28
    -130 31
    -143 34
    -156 37
    -169 40
    -182 42
    -195 45
    -208 48
    -222 51
    -235 54
    -249 56
    -263 59
    -276 62
    -290 65
    -304 68
    -319 70
    -333 73
    -347 76
    -362 79
    -376 82
    -391 84
    -406 87
    -421 90
    -436 93
    -451 95
    -466 98
    -481 101
    -496 104
    -512 106
    -527 109
    -543 112
    -559 114
    -575 117
    -591 120
    -607 122
    -623 125
    -639 128
    -655 130
    -672 133
    -688 136
    -705 138
    -722 141
    -738 144
    -755 146
    -772 149
    -789 152
    -806 154
    -824 157
    -841 159
    -858 162
    -876 165
    -893 167
    -911 170
    -929 172
    -947 175
    -965 178
    -983 180
    980 176
    962 173
    944 171
    926 168
    909 166
    891 163
    873 160
    856 158
    838 155
    821 153
    804 150
    787 148
    770 145
    753 143
    736 140
    719 137
    702 135
    686 132
    669 130
    653 127
    636 124
    620 122
    604 119
    588 117
    572 114
    556 111
    540 109
    525 106
    509 103
    494 101
    478 98
    463 95
    448 93
    433 90
    418 87
    403 85
    388 82
    373 79
    359 76
    344 74
    330 71
    316 68
    302 66
    288 63
    274 60
    260 57
    246 55
    232 52
    219 49
    206 46
    192 44
    179 41
    166 38
    153 35
    140 32
    128 30
    115 27
    102 24
    90 21
    78 18
    66 16
    54 13
    42 10
    30 7
    18 4
    7 2
    -5 -1
    -16 -4
    -27 -7
    -38 -10
    -49 -12
    -60 -15
    -71 -18
    -81 -21
    -92 -24
    -102 -27
    -112 -29
    -123 -32
    -132 -35
    -142 -38
    -152 -41
    -162 -44
    -171 -47
    -180 -49
    -189 -52
    -199 -55
    -207 -58
    -216 -61
    -225 -64
    -233 -66
    -242 -69
    -250 -72
    -258 -75
    -266 -78
    -274 -81
    -282 -83
    -289 -86
    -297 -89
    -304 -92
    -311 -95
    -318 -98
    -325 -100
    -332 -103
    -338 -106
    -345 -109
    -351 -112
    -357 -115
    -363 -117
    -369 -120
    -375 -123
    -380 -126
    -386 -129
    -391 -131
    -396 -134
    -401 -137
    -406 -140
    -411 -142
    -415 -145
    -420 -148
    -424 -151
    -428 -153
    -432 -156
    -436 -159
    -440 -162
    -443 -164
    -447 -167
    -450 -170
    -453 -172
    -456 -175
    -459 -178
    -461 -180
    -464 -183
    -466 -186
    -469 -188
    -471 -191
    -473 -194
    -474 -196
    -476 -199
    -477 -201
    -479 -204
    -480 -206
    -481 -209
    -482 -211
    -483 -214
    -483 -216
    -484 -219
    -484 -221
    -484 -224
    -484 -226
    -484 -229
    -484 -231
    -483 -234
    -483 -236
    -482 -238
    -481 -241
    -480 -243
    -479 -245
    -478 -248
    -477 -250
    -475 -252
    -473 -254
    -472 -257
    -470 -259
    -468 -261
    -465 -263
    -463 -265
    -460 -268
    -458 -270
    -455 -272
    -452 -274
    -449 -276
    -446 -278
    -443 -280
    -439 -282
    -436 -284
    -432 -286
    -428 -288
    -424 -290
    -420 -292
    -416 -293
    -412 -295
    -408 -297
    -403 -299
    -398 -301
    -394 -302
    -389 -304
    -384 -306
    -379 -307
    -374 -309
    -368 -311
    -363 -312
    -357 -314
    -352 -315
    -346 -317
    -340 -318
    -335 -320
    -329 -321
    -322 -322
    -316 -324
    -310 -325
    -304 -326
    -297 -328
    -291 -329
    -284 -330
    -277 -331
    -271 -332
    -264 -334
    -257 -335
    -250 -336
    -243 -337
    -236 -338
    -228 -339
    -221 -340
    -214 -341
    -206 -341
    -199 -342
    -191 -343
    -184 -344
    -176 -345
    -169 -345
    -161 -346
    -153 -347
    -145 -347
    -138 -348
    -130 -348
    -122 -349
    -114 -349
    -106 -350
    -98 -350
    -90 -351
    -82 -351
    -74 -351
    -65 -352
    -57 -352
    -49 -352
    -41 -352
    -33 -352
    -25 -353
    -16 -353
    -8 -353
    0 -353
    8 -353
    16 -353
    25 -353
    33 -352
    41 -352
    49 -352
    57 -352
    65 -352
    74 -351
    82 -351
    90 -351
    98 -350
    106 -350
    114 -349
    122 -349
    130 -348
    138 -348
    145 -347
    153 -347
    161 -346
    169 -345
    176 -345
    184 -344
    191 -343
    199 -342
    206 -341
    214 -341
    221 -340
    228 -339
    236 -338
    243 -337
    250 -336
    257 -335
    264 -334
    271 -332
    277 -331
    284 -330
    291 -329
    297 -328
    304 -326
    310 -325
    316 -324
    322 -322
    329 -321
    335 -320
    340 -318
    346 -317
    352 -315
    357 -314
    363 -312
    368 -311
    374 -309
    379 -307
    384 -306
    389 -304
    394 -302
    398 -301
    403 -299
    408 -297
    412 -295
    416 -293
    420 -292
    424 -290
    428 -288
    432 -286
    436 -284
    439 -282
    443 -280
    446 -278
    449 -276
    452 -274
    455 -272
    458 -270
    460 -268
    463 -265
    465 -263
    468 -261
    470 -259
    472 -257
    473 -254
    475 -252
    477 -250
    478 -248
    479 -245
    480 -243
    481 -241
    482 -238
    483 -236
    483 -234
    484 -231
    484 -229
    484 -226
    484 -224
    484 -221
    484 -219
    483 -216
    483 -214
    482 -211
    481 -209
    480 -206
    479 -204
    477 -201
    476 -199
    474 -196
    473 -194
    471 -191
    469 -188
    466 -186
    464 -183
    461 -180
    459 -178
    456 -175
    453 -172
    450 -170
    447 -167
    443 -164
    440 -162
    436 -159
    432 -156
    428 -153
    424 -151
    420 -148
    415 -145
    411 -142
    406 -140
    401 -137
    396 -134
    391 -131
    386 -129
    380 -126
    375 -123
    369 -120
    363 -117
    357 -115
    351 -112
    345 -109
    338 -106
    332 -103
    325 -100
    318 -98
    311 -95
    304 -92
    297 -89
    289 -86
    282 -83
    274 -81
    266 -78
    258 -75
    250 -72
    242 -69
    233 -66
    225 -64
    216 -61
    207 -58
    199 -55
    189 -52
    180 -49
    171 -47
    162 -44
    152 -41
    142 -38
    132 -35
    123 -32
    112 -29
    102 -27
    92 -24
    81 -21
    71 -18
    60 -15
    49 -12
    38 -10
    27 -7
    16 -4
    5 -1
    -7 2
    -18 4
    -30 7
    -42 10
    -54 13
    -66 16
    -78 18
    -90 21
    -102 24
    -115 27
    -128 30
    -140 32
    -153 35
    -166 38
    -179 41
    -192 44
    -206 46
    -219 49
    -232 52
    -246 55
    -260 57
    -274 60
    -288 63
    -302 66
    -316 68
    -330 71
    -344 74
    -359 76
    -373 79
    -388 82
    -403 85
    -418 87
    -433 90
    -448 93
    -463 95
    -478 98
    -494 101
    -509 103
    -525 106
    -540 109
    -556 111
    -572 114
    -588 117
    -604 119
    -620 122
    -636 124
    -653 127
    -669 130
    -686 132
    -702 135
    -719 137
    -736 140
    -753 143
    -770 145
    -787 148
    -804 150
    -821 153
    -838 155
    -856 158
    -873 160
    -891 163
    -909 166
    -926 168
    -944 171
    -962 173
    -980 176
    978 171
    960 169
    942 166
    924 164
    906 161
    888 159
    871 156
    853 154
    836 151
    819 149
    801 146
    784 144
    767 141
    750 139
    733 136
    716 134
    700 131
    683 129
    667 126
    650 124
    634 121
    618 118
    601 116
    585 113
    569 111
    554 108
    538 106
    522 103
    507 100
    491 98
    476 95
    460 93
    445 90
    430 87
    415 85
    400 82
    385 79
    371 77
    356 74
    342 71
    327 69
    313 66
    299 63
    285 61
    271 58
    257 55
    243 53
    230 50
    216 47
    203 45
    190 42
    176 39
    163 36
    150 34
    137 31
    125 28
    112 26
    100 23
    87 20
    75 17
    63 15
    51 12
    39 9
    27 6
    15 4
    4 1
    -8 -2
    -19 -5
    -30 -7
    -41 -10
    -52 -13
    -63 -16
    -74 -18
    -84 -21
    -95 -24
    -105 -27
    -115 -30
    -125 -32
    -135 -35
    -145 -38
    -155 -41
    -164 -43
    -174 -46
    -183 -49
    -192 -52
    -201 -55
    -210 -57
    -219 -60
    -228 -63
    -236 -66
    -245 -68
    -253 -71
    -261 -74
    -269 -77
    -277 -80
    -284 -82
    -292 -85
    -299 -88
    -307 -91
    -314 -93
    -321 -96
    -328 -99
    -334 -102
    -341 -105
    -347 -107
    -354 -110
    -360 -113
    -366 -116
    -372 -118
    -377 -121
    -383 -124
    -388 -126
    -394 -129
    -399 -132
    -404 -135
    -409 -137
    -413 -140
    -418 -143
    -422 -145
    -427 -148
    -431 -151
    -435 -153
    -439 -156
    -442 -159
    -446 -161
    -449 -164
    -453 -167
    -456 -169
    -459 -172
    -461 -175
    -464 -177
    -467 -180
    -469 -182
    -471 -185
    -473 -187
    -475 -190
    -477 -193
    -479 -195
    -480 -198
    -481 -200
    -482 -203
    -484 -205
    -484 -208
    -485 -210
    -486 -213
    -486 -215
    -486 -217
    -487 -220
    -487 -222
    -487 -225
    -486 -227
    -486 -229
    -485 -232
    -485 -234
    -484 -236
    -483 -239
    -482 -241
    -480 -243
    -479 -245
    -477 -247
    -476 -250
    -474 -252
    -472 -254
    -470 -256
    -467 -258
    -465 -260
    -463 -263
    -460 -265
    -457 -267
    -454 -269
    -451 -271
    -448 -273
    -445 -275
    -441 -277
    -438 -279
    -434 -280
    -430 -282
    -426 -284
    -422 -286
    -418 -288
    -414 -290
    -409 -291
    -405 -293
    -400 -295
    -395 -297
    -391 -298
    -386 -300
    -380 -301
    -375 -303
    -370 -305
    -365 -306
    -359 -308
    -353 -309
    -348 -311
    -342 -312
    -336 -314
    -330 -315
    -324 -316
    -318 -318
    -311 -319
    -305 -320
    -298 -321
    -292 -323
    -285 -324
    -279 -325
    -272 -326
    -265 -327
    -258 -328
    -251 -329
    -244 -330
    -237 -331
    -229 -332
    -222 -333
    -215 -334
    -207 -335
    -200 -336
    -192 -336
    -185 -337
    -177 -338
    -169 -339
    -162 -339
    -154 -340
    -146 -341
    -138 -341
    -130 -342
    -122 -342
    -114 -343
    -106 -343
    -98 -344
    -90 -344
    -82 -344
    -74 -345
    -66 -345
    -58 -345
    -49 -345
    -41 -345
    -33 -346
    -25 -346
    -16 -346
    -8 -346
    0 -346
    8 -346
    16 -346
    25 -346
    33 -346
    41 -345
    49 -345
    58 -345
    66 -345
    74 -345
    82 -344
    90 -344
    98 -344
    106 -343
    114 -343
    122 -342
    130 -342
    138 -341
    146 -341
    154 -340
    162 -339
    169 -339
    177 -338
    185 -337
    192 -336
    200 -336
    207 -335
    215 -334
    222 -333
    229 -332
    237 -331
    244 -330
    251 -329
    258 -328
    265 -327
    272 -326
    279 -325
    285 -324
    292 -323
    298 -321
    305 -320
    311 -319
    318 -318
    324 -316
    330 -315
    336 -314
    342 -312
    348 -311
    353 -309
    359 -308
    365 -306
    370 -305
    375 -303
    380 -301
    386 -300
    391 -298
    395 -297
    400 -295
    405 -293
    409 -291
    414 -290
    418 -288
    422 -286
    426 -284
    430 -282
    434 -280
    438 -279
    441 -277
    445 -275
    448 -273
    451 -271
    454 -269
    457 -267
    460 -265
    463 -263
    465 -260
    467 -258
    470 -256
    472 -254
    474 -252
    476 -250
    477 -247
    479 -245
    480 -243
    482 -241
    483 -239
    484 -236
    485 -234
    485 -232
    486 -229
    486 -227
    487 -225
    487 -222
    487 -220
    486 -217
    486 -215
    486 -213
    485 -210
    484 -208
    484 -205
    482 -203
    481 -200
    480 -198
    479 -195
    477 -193
    475 -190
    473 -187
    471 -185
    469 -182
    467 -180
    464 -177
    461 -175
    459 -172
    456 -169
    453 -167
    449 -164
    446 -161
    442 -159
    439 -156
    435 -153
    431 -151
    427 -148
    422 -145
    418 -143
    413 -140
    409 -137
    404 -135
    399 -132
    394 -129
    388 -126
    383 -124
    377 -121
    372 -118
    366 -116
    360 -113
    354 -110
    347 -107
    341 -105
    334 -102
    328 -99
    321 -96
    314 -93
    307 -91
    299 -88
    292 -85
    284 -82
    277 -80
    269 -77
    261 -74
    253 -71
    245 -68
    236 -66
    228 -63
    219 -60
    210 -57
    201 -55
    192 -52
    183 -49
    174 -46
    164 -43
    155 -41
    145 -38
    135 -35
    125 -32
    115 -30
    105 -27
    95 -24
    84 -21
    74 -18
    63 -16
    52 -13
    41 -10
    30 -7
    19 -5
    8 -2
    -4 1
    -15 4
    -27 6
    -39 9
    -51 12
    -63 15
    -75 17
    -87 20
    -100 23
    -112 26
    -125 28
    -137 31
    -150 34
    -163 36
    -176 39
    -190 42
    -203 45
    -216 47
    -230 50
    -243 53
    -257 55
    -271 58
    -285 61
    -299 63
    -313 66
    -327 69
    -342 71
    -356 74
    -371 77
    -385 79
    -400 82
    -415 85
    -430 87
    -445 90
    -460 93
    -476 95
    -491 98
    -507 100
    -522 103
    -538 106
    -554 108
    -569 111
    -585 113
    -601 116
    -618 118
    -634 121
    -650 124
    -667 126
    -683 129
    -700 131
    -716 134
    -733 136
    -750 139
    -767 141
    -784 144
    -801 146
    -819 149
    -836 151
    -853 154
    -871 156
    -888 159
    -906 161
    -924 164
    -942 166
    -960 169
    -978 171
    975 167
    957 164
    939 162
    921 159
    904 157
    886 155
    868 152
    851 150
    833 147
    816 145
    799 142
    782 140
    765 138
    748 135
    731 133
    714 130
    697 128
    681 125
    664 123
    648 120
    631 118
    615 115
    599 113
    583 110
    567 108
    551 105
    535 103
    520 100
    504 97
    489 95
    473 92
    458 90
    443 87
    428 85
    413 82
    398 80
    383 77
    368 74
    354 72
    339 69
    325 67
    310 64
    296 61
    282 59
    268 56
    254 54
    241 51
    227 48
    214 46
    200 43
    187 40
    174 38
    161 35
    148 32
    135 30
    122 27
    109 24
    97 22
    85 19
    72 16
    60 14
    48 11
    36 8
    24 6
    13 3
    1 0
    -10 -2
    -22 -5
    -33 -8
    -44 -11
    -55 -13
    -66 -16
    -76 -19
    -87 -21
    -97 -24
    -108 -27
    -118 -30
    -128 -32
    -138 -35
    -148 -38
    -158 -40
    -167 -43
    -177 -46
    -186 -49
    -195 -51
    -204 -54
    -213 -57
    -222 -59
    -230 -62
    -239 -65
    -247 -68
    -256 -70
    -264 -73
    -272 -76
    -279 -78
    -287 -81
    -295 -84
    -302 -87
    -309 -89
    -316 -92
    -323 -95
    -330 -97
    -337 -100
    -344 -103
    -350 -106
    -356 -108
    -363 -111
    -369 -114
    -374 -116
    -380 -119
    -386 -122
    -391 -124
    -396 -127
    -402 -130
    -407 -132
    -411 -135
    -416 -138
    -421 -140
    -425 -143
    -429 -145
    -433 -148
    -437 -151
    -441 -153
    -445 -156
    -449 -159
    -452 -161
    -455 -164
    -458 -166
    -461 -169
    -464 -171
    -467 -174
    -469 -176
    -471 -179
    -474 -182
    -476 -184
    -478 -187
    -479 -189
    -481 -191
    -482 -194
    -484 -196
    -485 -199
    -486 -201
    -487 -204
    -488 -206
    -488 -208
    -489 -211
    -489 -213
    -489 -216
    -489 -218
    -489 -220
    -489 -223
    -488 -225
    -488 -227
    -487 -229
    -486 -232
    -485 -234
    -484 -236
    -482 -238
    -481 -241
    -479 -243
    -478 -245
    -476 -247
    -474 -249
    -472 -251
    -470 -253
    -467 -255
    -465 -257
    -462 -259
    -459 -261
    -456 -263
    -453 -265
    -450 -267
    -447 -269
    -443 -271
    -440 -273
    -436 -275
    -432 -277
    -428 -279
    -424 -280
    -420 -282
    -416 -284
    -411 -286
    -407 -287
    -402 -289
    -397 -291
    -392 -292
    -387 -294
    -382 -296
    -377 -297
    -371 -299
    -366 -300
    -360 -302
    -355 -303
    -349 -305
    -343 -306
    -337 -307
    -331 -309
    -325 -310
    -319 -311
    -313 -313
    -306 -314
    -300 -315
    -293 -316
    -286 -317
    -280 -319
    -273 -320
    -266 -321
    -259 -322
    -252 -323
    -245 -324
    -238 -325
    -230 -326
    -223 -327
    -216 -327
    -208 -328
    -201 -329
    -193 -330
    -185 -331
    -178 -331
    -170 -332
    -162 -333
    -154 -333
    -147 -334
    -139 -334
    -131 -335
    -123 -335
    -115 -336
    -107 -336
    -99 -337
    -90 -337
    -82 -337
    -74 -338
    -66 -338
    -58 -338
    -50 -338
    -41 -339
    -33 -339
    -25 -339
    -17 -339
    -8 -339
    0 -339
    8 -339
    17 -339
    25 -339
    33 -339
    41 -339
    50 -338
    58 -338
    66 -338
    74 -338
    82 -337
    90 -337
    99 -337
    107 -336
    115 -336
    123 -335
    131 -335
    139 -334
    147 -334
    154 -333
    162 -333
    170 -332
    178 -331
    185 -331
    193 -330
    201 -329
    208 -328
    216 -327
    223 -327
    230 -326
    238 -325
    245 -324
    252 -323
    259 -322
    266 -321
    273 -320
    280 -319
    286 -317
    293 -316
    300 -315
    306 -314
    313 -313
    319 -311
    325 -310
    331 -309
    337 -307
    343 -306
    349 -305
    355 -303
    360 -302
    366 -300
    371 -299
    377 -297
    382 -296
    387 -294
    392 -292
    397 -291
    402 -289
    407 -287
    411 -286
    416 -284
    420 -282
    424 -280
    428 -279
    432 -277
    436 -275
    440 -273
    443 -271
    447 -269
    450 -267
    453 -265
    456 -263
    459 -261
    462 -259
    465 -257
    467 -255
    470 -253
    472 -251
    474 -249
    476 -247
    478 -245
    479 -243
    481 -241
    482 -238
    484 -236
    485 -234
    486 -232
    487 -229
    488 -227
    488 -225
    489 -223
    489 -220
    489 -218
    489 -216
    489 -213
    489 -211
    488 -208
    488 -206
    487 -204
    486 -201
    485 -199
    484 -196
    482 -194
    481 -191
    479 -189
    478 -187
    476 -184
    474 -182
    471 -179
    469 -176
    467 -174
    464 -171
    461 -169
    458 -166
    455 -164
    452 -161
    449 -159
    445 -156
    441 -153
    437 -151
    433 -148
    429 -145
    425 -143
    421 -140
    416 -138
    411 -135
    407 -132
    402 -130
    396 -127
    391 -124
    386 -122
    380 -119
    374 -116
    369 -114
    363 -111
    356 -108
    350 -106
    344 -103
    337 -100
    330 -97
    323 -95
    316 -92
    309 -89
    302 -87
    295 -84
    287 -81
    279 -78
    272 -76
    264 -73
    256 -70
    247 -68
    239 -65
    230 -62
    222 -59
    213 -57
    204 -54
    195 -51
    186 -49
    177 -46
    167 -43
    158 -40
    148 -38
    138 -35
    128 -32
    118 -30
    108 -27
    97 -24
    87 -21
    76 -19
    66 -16
    55 -13
    44 -11
    33 -8
    22 -5
    10 -2
    -1 0
    -13 3
    -24 6
    -36 8
    -48 11
    -60 14
    -72 16
    -85 19
    -97 22
    -109 24
    -122 27
    -135 30
    -148 32
    -161 35
    -174 38
    -187 40
    -200 43
    -214 46
    -227 48
    -241 51
    -254 54
    -268 56
    -282 59
    -296 61
    -310 64
    -325 67
    -339 69
    -354 72
    -368 74
    -383 77
    -398 80
    -413 82
    -428 85
    -443 87
    -458 90
    -473 92
    -489 95
    -504 97
    -520 100
    -535 103
    -551 105
    -567 108
    -583 110
    -599 113
    -615 115
    -631 118
    -648 120
    -664 123
    -681 125
    -697 128
    -714 130
    -731 133
    -748 135
    -765 138
    -782 140
    -799 142
    -816 145
    -833 147
    -851 150
    -868 152
    -886 155
    -904 157
    -921 159
    -939 162
    -957 164
    -975 167
    973 162
    955 160
    937 157
    919 155
    901 153
    884 150
    866 148
    848 146
    831 143
    814 141
    796 139
    779 136
    762 134
    745 131
    728 129
    712 126
    695 124
    678 122
    662 119
    645 117
    629 114
    613 112
    596 109
    580 107
    564 105
    549 102
    533 100
    517 97
    501 95
    486 92
    471 90
    455 87
    440 85
    425 82
    410 80
    395 77
    380 75
    366 72
    351 70
    337 67
    322 64
    308 62
    294 59
    280 57
    266 54
    252 52
    238 49
    224 47
    211 44
    198 41
    184 39
    171 36
    158 34
    145 31
    132 28
    119 26
    107 23
    94 21
    82 18
    70 15
    57 13
    45 10
    33 8
    22 5
    10 2
    -2 -0
    -13 -3
    -24 -6
    -36 -8
    -47 -11
    -58 -14
    -68 -16
    -79 -19
    -90 -21
    -100 -24
    -111 -27
    -121 -29
    -131 -32
    -141 -35
    -151 -37
    -160 -40
    -170 -43
    -179 -45
    -189 -48
    -198 -51
    -207 -53
    -216 -56
    -224 -59
    -233 -61
    -242 -64
    -250 -67
    -258 -69
    -266 -72
    -274 -75
    -282 -77
    -290 -80
    -297 -83
    -305 -85
    -312 -88
    -319 -91
    -326 -93
    -333 -96
    -340 -98
    -346 -101
    -353 -104
    -359 -106
    -365 -109
    -371 -112
    -377 -114
    -383 -117
    -388 -119
    -394 -122
    -399 -125
    -404 -127
    -409 -130
    -414 -132
    -419 -135
    -423 -138
    -428 -140
    -432 -143
    -436 -145
    -440 -148
    -444 -150
    -448 -153
    -451 -156
    -454 -158
    -458 -161
    -461 -163
    -464 -166
    -466 -168
    -469 -171
    -472 -173
    -474 -176
    -476 -178
    -478 -180
    -480 -183
    -482 -185
    -483 -188
    -485 -190
    -486 -193
    -487 -195
    -488 -197
    -489 -200
    -490 -202
    -491 -204
    -491 -207
    -491 -209
    -491 -211
    -491 -214
    -491 -216
    -491 -218
    -490 -220
    -490 -223
    -489 -225
    -488 -227
    -487 -229
    -486 -231
    -485 -234
    -483 -236
    -482 -238
    -480 -240
    -478 -242
    -476 -244
    -474 -246
    -472 -248
    -469 -250
    -467 -252
    -464 -254
    -461 -256
    -458 -258
    -455 -260
    -452 -262
    -449 -264
    -445 -266
    -441 -268
    -438 -269
    -434 -271
    -430 -273
    -426 -275
    -422 -276
    -417 -278
    -413 -280
    -408 -282
    -404 -283
    -399 -285
    -394 -286
    -389 -288
    -384 -290
    -378 -291
    -373 -293
    -368 -294
    -362 -295
    -356 -297
    -351 -298
    -345 -300
    -339 -301
    -333 -302
    -326 -304
    -320 -305
    -314 -306
    -307 -307
    -301 -309
    -294 -310
    -288 -311
    -281 -312
    -274 -313
    -267 -314
    -260 -315
    -253 -316
    -246 -317
    -239 -318
    -231 -319
    -224 -320
    -216 -321
    -209 -321
    -201 -322
    -194 -323
    -186 -324
    -178 -324
    -171 -325
    -163 -326
    -155 -326
    -147 -327
    -139 -327
    -131 -328
    -123 -328
    -115 -329
    -107 -329
    -99 -330
    -91 -330
    -83 -330
    -74 -331
    -66 -331
    -58 -331
    -50 -331
    -41 -332
    -33 -332
    -25 -332
    -17 -332
    -8 -332
    0 -332
    8 -332
    17 -332
    25 -332
    33 -332
    41 -332
    50 -331
    58 -331
    66 -331
    74 -331
    83 -330
    91 -330
    99 -330
    107 -329
    115 -329
    123 -328
    131 -328
    139 -327
    147 -327
    155 -326
    163 -326
    171 -325
    178 -324
    186 -324
    194 -323
    201 -322
    209 -321
    216 -321
    224 -320
    231 -319
    239 -318
    246 -317
    253 -316
    260 -315
    267 -314
    274 -313
    281 -312
    288 -311
    294 -310
    301 -309
    307 -307
    314 -306
    320 -305
    326 -304
    333 -302
    339 -301
    345 -300
    351 -298
    356 -297
    362 -295
    368 -294
    373 -293
    378 -291
    384 -290
    389 -288
    394 -286
    399 -285
    404 -283
    408 -282
    413 -280
    417 -278
    422 -276
    426 -275
    430 -273
    434 -271
    438 -269
    441 -268
    445 -266
    449 -264
    452 -262
    455 -260
    458 -258
    461 -256
    464 -254
    467 -252
    469 -250
    472 -248
    474 -246
    476 -244
    478 -242
    480 -240
    482 -238
    483 -236
    485 -234
    486 -231
    487 -229
    488 -227
    489 -225
    490 -223
    490 -220
    491 -218
    491 -216
    491 -214
    491 -211
    491 -209
    491 -207
    491 -204
    490 -202
    489 -200
    488 -197
    487 -195
    486 -193
    485 -190
    483 -188
    482 -185
    480 -183
    478 -180
    476 -178
    474 -176
    472 -173
    469 -171
    466 -168
    464 -166
    461 -163
    458 -161
    454 -158
    451 -156
    448 -153
    444 -150
    440 -148
    436 -145
    432 -143
    428 -140
    423 -138
    419 -135
    414 -132
    409 -130
    404 -127
    399 -125
    394 -122
    388 -119
    383 -117
    377 -114
    371 -112
    365 -109
    359 -106
    353 -104
    346 -101
    340 -98
    333 -96
    326 -93
    319 -91
    312 -88
    305 -85
    297 -83
    290 -80
    282 -77
    274 -75
    266 -72
    258 -69
    250 -67
    242 -64
    233 -61
    224 -59
    216 -56
    207 -53
    198 -51
    189 -48
    179 -45
    170 -43
    160 -40
    151 -37
    141 -35
    131 -32
    121 -29
    111 -27
    100 -24
    90 -21
    79 -19
    68 -16
    58 -14
    47 -11
    36 -8
    24 -6
    13 -3
    2 -0
    -10 2
    -22 5
    -33 8
    -45 10
    -57 13
    -70 15
    -82 18
    -94 21
    -107 23
    -119 26
    -132 28
    -145 31
    -158 34
    -171 36
    -184 39
    -198 41
    -211 44
    -224 47
    -238 49
    -252 52
    -266 54
    -280 57
    -294 59
    -308 62
    -322 64
    -337 67
    -351 70
    -366 72
    -380 75
    -395 77
    -410 80
    -425 82
    -440 85
    -455 87
    -471 90
    -486 92
    -501 95
    -517 97
    -533 100
    -549 102
    -564 105
    -580 107
    -596 109
    -613 112
    -629 114
    -645 117
    -662 119
    -678 122
    -695 124
    -712 126
    -728 129
    -745 131
    -762 134
    -779 136
    -796 139
    -814 141
    -831 143
    -848 146
    -866 148
    -884 150
    -901 153
    -919 155
    -937 157
    -955 160
    -973 162
    970 158
    952 155
    934 153
    917 151
    899 149
    881 146
    864 144
    846 142
    829 139
    811 137
    794 135
    777 132
    760 130
    743 128
    726 125
    709 123
    692 121
    676 118
    659 116
    643 113
    626 111
    610 109
    594 106
    578 104
    562 101
    546 99
    530 97
    515 94
    499 92
    484 89
    468 87
    453 84
    438 82
    423 80
    408 77
    393 75
    378 72
    363 70
    349 67
    334 65
    320 62
    305 60
    291 57
    277 55
    263 52
    249 50
    236 47
    222 45
    208 42
    195 40
    182 37
    169 35
    155 32
    142 30
    130 27
    117 25
    104 22
    92 20
    79 17
    67 14
    55 12
    43 9
    31 7
    19 4
    7 2
    -4 -1
    -16 -4
    -27 -6
    -38 -9
    -49 -11
    -60 -14
    -71 -16
    -82 -19
    -92 -22
    -103 -24
    -113 -27
    -123 -29
    -133 -32
    -143 -35
    -153 -37
    -163 -40
    -172 -42
    -182 -45
    -191 -47
    -200 -50
    -209 -53
    -218 -55
    -227 -58
    -236 -60
    -244 -63
    -253 -66
    -261 -68
    -269 -71
    -277 -73
    -285 -76
    -292 -79
    -300 -81
    -307 -84
    -315 -86
    -322 -89
    -329 -92
    -336 -94
    -342 -97
    -349 -99
    -355 -102
    -362 -104
    -368 -107
    -374 -110
    -380 -112
    -385 -115
    -391 -117
    -396 -120
    -402 -122
    -407 -125
    -412 -127
    -417 -130
    -421 -133
    -426 -135
    -430 -138
    -434 -140
    -439 -143
    -443 -145
    -446 -148
    -450 -150
    -454 -152
    -457 -155
    -460 -157
    -463 -160
    -466 -162
    -469 -165
    -472 -167
    -474 -170
    -476 -172
    -479 -174
    -481 -177
    -483 -179
    -484 -182
    -486 -184
    -487 -186
    -489 -189
    -490 -191
    -491 -193
    -492 -196
    -492 -198
    -493 -200
    -493 -202
    -493 -205
    -494 -207
    -494 -209
    -493 -211
    -493 -214
    -493 -216
    -492 -218
    -491 -220
    -490 -222
    -489 -225
    -488 -227
    -487 -229
    -485 -231
    -484 -233
    -482 -235
    -480 -237
    -478 -239
    -476 -241
    -474 -243
    -471 -245
    -469 -247
    -466 -249
    -463 -251
    -460 -253
    -457 -255
    -454 -256
    -450 -258
    -447 -260
    -443 -262
    -440 -264
    -436 -265
    -432 -267
    -428 -269
    -423 -271
    -419 -272
    -414 -274
    -410 -276
    -405 -277
    -400 -279
    -395 -280
    -390 -282
    -385 -283
    -380 -285
    -374 -286
    -369 -288
    -363 -289
    -358 -291
    -352 -292
    -346 -293
    -340 -295
    -334 -296
    -328 -297
    -321 -298
    -315 -300
    -309 -301
    -302 -302
    -295 -303
    -289 -304
    -282 -305
    -275 -306
    -268 -307
    -261 -308
    -254 -309
    -247 -310
    -239 -311
    -232 -312
    -225 -313
    -217 -314
    -210 -315
    -202 -315
    -195 -316
    -187 -317
    -179 -318
    -171 -318
    -163 -319
    -156 -319
    -148 -320
    -140 -320
    -132 -321
    -124 -321
    -116 -322
    -107 -322
    -99 -323
    -91 -323
    -83 -323
    -75 -324
    -66 -324
    -58 -324
    -50 -324
    -42 -325
    -33 -325
    -25 -325
    -17 -325
    -8 -325
    0 -325
    8 -325
    17 -325
    25 -325
    33 -325
    42 -325
    50 -324
    58 -324
    66 -324
    75 -324
    83 -323
    91 -323
    99 -323
    107 -322
    116 -322
    124 -321
    132 -321
    140 -320
    148 -320
    156 -319
    163 -319
    171 -318
    179 -318
    187 -317
    195 -316
    202 -315
    210 -315
    217 -314
    225 -313
    232 -312
    239 -311
    247 -310
    254 -309
    261 -308
    268 -307
    275 -306
    282 -305
    289 -304
    295 -303
    302 -302
    309 -301
    315 -300
    321 -298
    328 -297
    334 -296
    340 -295
    346 -293
    352 -292
    358 -291
    363 -289
    369 -288
    374 -286
    380 -285
    385 -283
    390 -282
    395 -280
    400 -279
    405 -277
    410 -276
    414 -274
    419 -272
    423 -271
    428 -269
    432 -267
    436 -265
    440 -264
    443 -262
    447 -260
    450 -258
    454 -256
    457 -255
    460 -253
    463 -251
    466 -249
    469 -247
    471 -245
    474 -243
    476 -241
    478 -239
    480 -237
    482 -235
    484 -233
    485 -231
    487 -229
    488 -227
    489 -225
    490 -222
    491 -220
    492 -218
    493 -216
    493 -214
    493 -211
    494 -209
    494 -207
    493 -205
    493 -202
    493 -200
    492 -198
    492 -196
    491 -193
    490 -191
    489 -189
    487 -186
    486 -184
    484 -182
    483 -179
    481 -177
    479 -174
    476 -172
    474 -170
    472 -167
    469 -165
    466 -162
    463 -160
    460 -157
    457 -155
    454 -152
    450 -150
    446 -148
    443 -145
    439 -143
    434 -140
    430 -138
    426 -135
    421 -133
    417 -130
    412 -127
    407 -125
    402 -122
    396 -120
    391 -117
    385 -115
    380 -112
    374 -110
    368 -107
    362 -104
    355 -102
    349 -99
    342 -97
    336 -94
    329 -92
    322 -89
    315 -86
    307 -84
    300 -81
    292 -79
    285 -76
    277 -73
    269 -71
    261 -68
    253 -66
    244 -63
    236 -60
    227 -58
    218 -55
    209 -53
    200 -50
    191 -47
    182 -45
    172 -42
    163 -40
    153 -37
    143 -35
    133 -32
    123 -29
    113 -27
    103 -24
    92 -22
    82 -19
    71 -16
    60 -14
    49 -11
    38 -9
    27 -6
    16 -4
    4 -1
    -7 2
    -19 4
    -31 7
    -43 9
    -55 12
    -67 14
    -79 17
    -92 20
    -104 22
    -117 25
    -130 27
    -142 30
    -155 32
    -169 35
    -182 37
    -195 40
    -208 42
    -222 45
    -236 47
    -249 50
    -263 52
    -277 55
    -291 57
    -305 60
    -320 62
    -334 65
    -349 67
    -363 70
    -378 72
    -393 75
    -408 77
    -423 80
    -438 82
    -453 84
    -468 87
    -484 89
    -499 92
    -515 94
    -530 97
    -546 99
    -562 101
    -578 104
    -594 106
    -610 109
    -626 111
    -643 113
    -659 116
    -676 118
    -692 121
    -709 123
    -726 125
    -743 128
    -760 130
    -777 132
    -794 135
    -811 137
    -829 139
    -846 142
    -864 144
    -881 146
    -899 149
    -917 151
    -934 153
    -952 155
    -970 158
    968 153
    950 151
    932 149
    914 147
    897 144
    879 142
    861 140
    844 138
    826 135
    809 133
    792 131
    775 129
    758 126
    741 124
    724 122
    707 119
    690 117
    673 115
    657 112
    640 110
    624 108
    608 105
    592 103
    576 101
    560 98
    544 96
    528 94
    512 91
    497 89
    481 87
    466 84
    450 82
    435 80
    420 77
    405 75
    390 72
    375 70
    361 68
    346 65
    332 63
    317 60
    303 58
    289 55
    275 53
    261 51
    247 48
    233 46
    219 43
    206 41
    193 38
    179 36
    166 33
    153 31
    140 28
    127 26
    114 23
    102 21
    89 19
    77 16
    65 14
    52 11
    40 9
    28 6
    17 4
    5 1
    -7 -1
    -18 -4
    -29 -6
    -41 -9
    -52 -12
    -63 -14
    -74 -17
    -84 -19
    -95 -22
    -105 -24
    -116 -27
    -126 -29
    -136 -32
    -146 -34
    -156 -37
    -165 -39
    -175 -42
    -184 -44
    -194 -47
    -203 -49
    -212 -52
    -221 -55
    -230 -57
    -238 -60
    -247 -62
    -255 -65
    -263 -67
    -272 -70
    -279 -72
    -287 -75
    -295 -77
    -303 -80
    -310 -82
    -317 -85
    -324 -87
    -331 -90
    -338 -92
    -345 -95
    -351 -97
    -358 -100
    -364 -103
    -370 -105
    -376 -108
    -382 -110
    -388 -113
    -393 -115
    -399 -117
    -404 -120
    -409 -122
    -414 -125
    -419 -127
    -424 -130
    -428 -132
    -433 -135
    -437 -137
    -441 -140
    -445 -142
    -449 -145
    -453 -147
    -456 -149
    -459 -152
    -463 -154
    -466 -157
    -469 -159
    -471 -161
    -474 -164
    -476 -166
    -479 -168
    -481 -171
    -483 -173
    -485 -175
    -487 -178
    -488 -180
    -490 -182
    -491 -185
    -492 -187
    -493 -189
    -494 -191
    -495 -194
    -495 -196
    -495 -198
    -496 -200
    -496 -203
    -496 -205
    -496 -207
    -495 -209
    -495 -211
    -494 -213
    -493 -215
    -492 -218
    -491 -220
    -490 -222
    -489 -224
    -487 -226
    -486 -228
    -484 -230
    -482 -232
    -480 -234
    -478 -236
    -476 -238
    -473 -240
    -471 -242
    -468 -244
    -465 -245
    -462 -247
    -459 -249
    -456 -251
    -452 -253
    -449 -254
    -445 -256
    -441 -258
    -437 -260
    -433 -261
    -429 -263
    -425 -265
    -421 -266
    -416 -268
    -411 -270
    -407 -271
    -402 -273
    -397 -274
    -392 -276
    -387 -277
    -381 -279
    -376 -280
    -370 -281
    -365 -283
    -359 -284
    -353 -286
    -347 -287
    -341 -288
    -335 -289
    -329 -291
    -323 -292
    -316 -293
    -310 -294
    -303 -295
    -296 -296
    -290 -298
    -283 -299
    -276 -300
    -269 -301
    -262 -302
    -255 -303
    -248 -303
    -240 -304
    -233 -305
    -226 -306
    -218 -307
    -211 -308
    -203 -308
    -195 -309
    -188 -310
    -180 -311
    -172 -311
    -164 -312
    -156 -312
    -148 -313
    -140 -313
    -132 -314
    -124 -314
    -116 -315
    -108 -315
    -100 -316
    -91 -316
    -83 -316
    -75 -317
    -67 -317
    -58 -317
    -50 -317
    -42 -317
    -33 -318
    -25 -318
    -17 -318
    -8 -318
    0 -318
    8 -318
    17 -318
    25 -318
    33 -318
    42 -317
    50 -317
    58 -317
    67 -317
    75 -317
    83 -316
    91 -316
    100 -316
    108 -315
    116 -315
    124 -314
    132 -314
    140 -313
    148 -313
    156 -312
    164 -312
    172 -311
    180 -311
    188 -310
    195 -309
    203 -308
    211 -308
    218 -307
    226 -306
    233 -305
    240 -304
    248 -303
    255 -303
    262 -302
    269 -301
    276 -300
    283 -299
    290 -298
    296 -296
    303 -295
    310 -294
    316 -293
    323 -292
    329 -291
    335 -289
    341 -288
    347 -287
    353 -286
    359 -284
    365 -283
    370 -281
    376 -280
    381 -279
    387 -277
    392 -276
    397 -274
    402 -273
    407 -271
    411 -270
    416 -268
    421 -266
    425 -265
    429 -263
    433 -261
    437 -260
    441 -258
    445 -256
    449 -254
    452 -253
    456 -251
    459 -249
    462 -247
    465 -245
    468 -244
    471 -242
    473 -240
    476 -238
    478 -236
    480 -234
    482 -232
    484 -230
    486 -228
    487 -226
    489 -224
    490 -222
    491 -220
    492 -218
    493 -215
    494 -213
    495 -211
    495 -209
    496 -207
    496 -205
    496 -203
    496 -200
    495 -198
    495 -196
    495 -194
    494 -191
    493 -189
    492 -187
    491 -185
    490 -182
    488 -180
    487 -178
    485 -175
    483 -173
    481 -171
    479 -168
    476 -166
    474 -164
    471 -161
    469 -159
    466 -157
    463 -154
    459 -152
    456 -149
    453 -147
    449 -145
    445 -142
    441 -140
    437 -137
    433 -135
    428 -132
    424 -130
    419 -127
    414 -125
    409 -122
    404 -120
    399 -117
    393 -115
    388 -113
    382 -110
    376 -108
    370 -105
    364 -103
    358 -100
    351 -97
    345 -95
    338 -92
    331 -90
    324 -87
    317 -85
    310 -82
    303 -80
    295 -77
    287 -75
    279 -72
    272 -70
    263 -67
    255 -65
    247 -62
    238 -60
    230 -57
    221 -55
    212 -52
    203 -49
    194 -47
    184 -44
    175 -42
    165 -39
    156 -37
    146 -34
    136 -32
    126 -29
    116 -27
    105 -24
    95 -22
    84 -19
    74 -17
    63 -14
    52 -12
    41 -9
    29 -6
    18 -4
    7 -1
    -5 1
    -17 4
    -28 6
    -40 9
    -52 11
    -65 14
    -77 16
    -89 19
    -102 21
    -114 23
    -127 26
    -140 28
    -153 31
    -166 33
    -179 36
    -193 38
    -206 41
    -219 43
    -233 46
    -247 48
    -261 51
    -275 53
    -289 55
    -303 58
    -317 60
    -332 63
    -346 65
    -361 68
    -375 70
    -390 72
    -405 75
    -420 77
    -435 80
    -450 82
    -466 84
    -481 87
    -497 89
    -512 91
    -528 94
    -544 96
    -560 98
    -576 101
    -592 103
    -608 105
    -624 108
    -640 110
    -657 112
    -673 115
    -690 117
    -707 119
    -724 122
    -741 124
    -758 126
    -775 129
    -792 131
    -809 133
    -826 135
    -844 138
    -861 140
    -879 142
    -897 144
    -914 147
    -932 149
    -950 151
    -968 153
    966 149
    948 147
    930 145
    912 142
    894 140
    877 138
    859 136
    842 134
    824 131
    807 129
    790 127
    772 125
    755 123
    738 120
    721 118
    705 116
    688 114
    671 111
    655 109
    638 107
    622 105
    606 102
    589 100
    573 98
    557 95
    541 93
    526 91
    510 89
    494 86
    479 84
    463 82
    448 79
    433 77
    418 75
    403 72
    388 70
    373 68
    358 65
    344 63
    329 61
    315 58
    301 56
    286 54
    272 51
    258 49
    244 46
    231 44
    217 42
    204 39
    190 37
    177 34
    164 32
    150 30
    138 27
    125 25
    112 22
    99 20
    87 18
    74 15
    62 13
    50 10
    38 8
    26 5
    14 3
    2 1
    -9 -2
    -21 -4
    -32 -7
    -43 -9
    -54 -12
    -65 -14
    -76 -17
    -87 -19
    -97 -22
    -108 -24
    -118 -27
    -128 -29
    -138 -31
    -148 -34
    -158 -36
    -168 -39
    -178 -41
    -187 -44
    -196 -46
    -205 -49
    -214 -51
    -223 -54
    -232 -56
    -241 -59
    -249 -61
    -258 -64
    -266 -66
    -274 -69
    -282 -71
    -290 -73
    -297 -76
    -305 -78
    -312 -81
    -320 -83
    -327 -86
    -334 -88
    -341 -91
    -347 -93
    -354 -96
    -360 -98
    -367 -100
    -373 -103
    -379 -105
    -385 -108
    -390 -110
    -396 -113
    -401 -115
    -407 -118
    -412 -120
    -417 -122
    -422 -125
    -426 -127
    -431 -130
    -435 -132
    -439 -134
    -443 -137
    -447 -139
    -451 -141
    -455 -144
    -458 -146
    -462 -149
    -465 -151
    -468 -153
    -471 -156
    -474 -158
    -476 -160
    -479 -163
    -481 -165
    -483 -167
    -485 -169
    -487 -172
    -489 -174
    -490 -176
    -492 -178
    -493 -181
    -494 -183
    -495 -185
    -496 -187
    -497 -189
    -497 -192
    -498 -194
    -498 -196
    -498 -198
    -498 -200
    -498 -202
    -497 -204
    -497 -207
    -496 -209
    -495 -211
    -495 -213
    -493 -215
    -492 -217
    -491 -219
    -489 -221
    -488 -223
    -486 -225
    -484 -227
    -482 -229
    -480 -231
    -477 -232
    -475 -234
    -472 -236
    -470 -238
    -467 -240
    -464 -242
    -461 -243
    -457 -245
    -454 -247
    -450 -249
    -447 -250
    -443 -252
    -439 -254
    -435 -255
    -431 -257
    -427 -259
    -422 -260
    -418 -262
    -413 -263
    -408 -265
    -403 -267
    -398 -268
    -393 -269
    -388 -271
    -383 -272
    -377 -274
    -372 -275
    -366 -276
    -360 -278
    -355 -279
    -349 -280
    -343 -282
    -336 -283
    -330 -284
    -324 -285
    -317 -286
    -311 -288
    -304 -289
    -298 -290
    -291 -291
    -284 -292
    -277 -293
    -270 -294
    -263 -295
    -256 -296
    -248 -297
    -241 -297
    -234 -298
    -226 -299
    -219 -300
    -211 -301
    -204 -301
    -196 -302
    -188 -303
    -180 -303
    -173 -304
    -165 -305
    -157 -305
    -149 -306
    -141 -306
    -133 -307
    -125 -307
    -116 -308
    -108 -308
    -100 -308
    -92 -309
    -84 -309
    -75 -309
    -67 -310
    -59 -310
    -50 -310
    -42 -310
    -34 -310
    -25 -310
    -17 -310
    -8 -310
    0 -310
    8 -310
    17 -310
    25 -310
    34 -310
    42 -310
    50 -310
    59 -310
    67 -310
    75 -309
    84 -309
    92 -309
    100 -308
    108 -308
    116 -308
    125 -307
    133 -307
    141 -306
    149 -306
    157 -305
    165 -305
    173 -304
    180 -303
    188 -303
    196 -302
    204 -301
    211 -301
    219 -300
    226 -299
    234 -298
    241 -297
    248 -297
    256 -296
    263 -295
    270 -294
    277 -293
    284 -292
    291 -291
    298 -290
    304 -289
    311 -288
    317 -286
    324 -285
    330 -284
    336 -283
    343 -282
    349 -280
    355 -279
    360 -278
    366 -276
    372 -275
    377 -274
    383 -272
    388 -271
    393 -269
    398 -268
    403 -267
    408 -265
    413 -263
    418 -262
    422 -260
    427 -259
    431 -257
    435 -255
    439 -254
    443 -252
    447 -250
    450 -249
    454 -247
    457 -245
    461 -243
    464 -242
    467 -240
    470 -238
    472 -236
    475 -234
    477 -232
    480 -231
    482 -229
    484 -227
    486 -225
    488 -223
    489 -221
    491 -219
    492 -217
    493 -215
    495 -213
    495 -211
    496 -209
    497 -207
    497 -204
    498 -202
    498 -200
    498 -198
    498 -196
    498 -194
    497 -192
    497 -189
    496 -187
    495 -185
    494 -183
    493 -181
    492 -178
    490 -176
    489 -174
    487 -172
    485 -169
    483 -167
    481 -165
    479 -163
    476 -160
    474 -158
    471 -156
    468 -153
    465 -151
    462 -149
    458 -146
    455 -144
    451 -141
    447 -139
    443 -137
    439 -134
    435 -132
    431 -130
    426 -127
    422 -125
    417 -122
    412 -120
    407 -118
    401 -115
    396 -113
    390 -110
    385 -108
    379 -105
    373 -103
    367 -100
    360 -98
    354 -96
    347 -93
    341 -91
    334 -88
    327 -86
    320 -83
    312 -81
    305 -78
    297 -76
    290 -73
    282 -71
    274 -69
    266 -66
    258 -64
    249 -61
    241 -59
    232 -56
    223 -54
    214 -51
    205 -49
    196 -46
    187 -44
    178 -41
    168 -39
    158 -36
    148 -34
    138 -31
    128 -29
    118 -27
    108 -24
    97 -22
    87 -19
    76 -17
    65 -14
    54 -12
    43 -9
    32 -7
    21 -4
    9 -2
    -2 1
    -14 3
    -26 5
    -38 8
    -50 10
    -62 13
    -74 15
    -87 18
    -99 20
    -112 22
    -125 25
    -138 27
    -150 30
    -164 32
    -177 34
    -190 37
    -204 39
    -217 42
    -231 44
    -244 46
    -258 49
    -272 51
    -286 54
    -301 56
    -315 58
    -329 61
    -344 63
    -358 65
    -373 68
    -388 70
    -403 72
    -418 75
    -433 77
    -448 79
    -463 82
    -479 84
    -494 86
    -510 89
    -526 91
    -541 93
    -557 95
    -573 98
    -589 100
    -606 102
    -622 105
    -638 107
    -655 109
    -671 111
    -688 114
    -705 116
    -721 118
    -738 120
    -755 123
    -772 125
    -790 127
    -807 129
    -824 131
    -842 134
    -859 136
    -877 138
    -894 140
    -912 142
    -930 145
    -948 147
    -966 149
    964 145
    946 142
    928 140
    910 138
    892 136
    875 134
    857 132
    839 130
    822 128
    805 125
    787 123
    770 121
    753 119
    736 117
    719 115
    702 112
    686 110
    669 108
    652 106
    636 104
    620 101
    603 99
    587 97
    571 95
    555 93
    539 90
    523 88
    508 86
    492 84
    476 81
    461 79
    446 77
    431 75
    415 72
    400 70
    386 68
    371 65
    356 63
    341 61
    327 59
    312 56
    298 54
    284 52
    270 49
    256 47
    242 45
    228 42
    215 40
    201 38
    188 35
    174 33
    161 31
    148 28
    135 26
    122 24
    110 21
    97 19
    84 17
    72 14
    60 12
    47 9
    35 7
    23 5
    12 2
    -0 -0
    -12 -2
    -23 -5
    -34 -7
    -46 -10
    -57 -12
    -68 -14
    -79 -17
    -89 -19
    -100 -22
    -110 -24
    -121 -26
    -131 -29
    -141 -31
    -151 -34
    -161 -36
    -170 -38
    -180 -41
    -189 -43
    -199 -46
    -208 -48
    -217 -50
    -226 -53
    -235 -55
    -243 -58
    -252 -60
    -260 -62
    -268 -65
    -276 -67
    -284 -70
    -292 -72
    -300 -74
    -307 -77
    -315 -79
    -322 -82
    -329 -84
    -336 -86
    -343 -89
    -350 -91
    -356 -94
    -363 -96
    -369 -98
    -375 -101
    -381 -103
    -387 -106
    -393 -108
    -398 -110
    -404 -113
    -409 -115
    -414 -117
    -419 -120
    -424 -122
    -429 -124
    -433 -127
    -438 -129
    -442 -131
    -446 -134
    -450 -136
    -454 -138
    -457 -141
    -461 -143
    -464 -145
    -467 -148
    -470 -150
    -473 -152
    -476 -154
    -479 -157
    -481 -159
    -483 -161
    -486 -163
    -488 -166
    -489 -168
    -491 -170
    -493 -172
    -494 -174
    -495 -177
    -496 -179
    -497 -181
    -498 -183
    -499 -185
    -499 -187
    -500 -189
    -500 -191
    -500 -194
    -500 -196
    -500 -198
    -499 -200
    -499 -202
    -498 -204
    -497 -206
    -497 -208
    -495 -210
    -494 -212
    -493 -214
    -491 -216
    -490 -218
    -488 -220
    -486 -221
    -484 -223
    -482 -225
    -479 -227
    -477 -229
    -474 -231
    -471 -233
    -469 -234
    -466 -236
    -462 -238
    -459 -240
    -456 -241
    -452 -243
    -448 -245
    -445 -246
    -441 -248
    -437 -250
    -432 -251
    -428 -253
    -424 -254
    -419 -256
    -415 -257
    -410 -259
    -405 -260
    -400 -262
    -395 -263
    -389 -265
    -384 -266
    -379 -267
    -373 -269
    -367 -270
    -362 -271
    -356 -273
    -350 -274
    -344 -275
    -338 -276
    -331 -277
    -325 -279
    -319 -280
    -312 -281
    -305 -282
    -299 -283
    -292 -284
    -285 -285
    -278 -286
    -271 -287
    -264 -288
    -257 -289
    -249 -290
    -242 -290
    -235 -291
    -227 -292
    -220 -293
    -212 -294
    -204 -294
    -197 -295
    -189 -296
    -181 -296
    -173 -297
    -165 -297
    -157 -298
    -149 -299
    -141 -299
    -133 -299
    -125 -300
    -117 -300
    -109 -301
    -100 -301
    -92 -301
    -84 -302
    -75 -302
    -67 -302
    -59 -302
    -50 -303
    -42 -303
    -34 -303
    -25 -303
    -17 -303
    -8 -303
    0 -303
    8 -303
    17 -303
    25 -303
    34 -303
    42 -303
    50 -303
    59 -302
    67 -302
    75 -302
    84 -302
    92 -301
    100 -301
    109 -301
    117 -300
    125 -300
    133 -299
    141 -299
    149 -299
    157 -298
    165 -297
    173 -297
    181 -296
    189 -296
    197 -295
    204 -294
    212 -294
    220 -293
    227 -292
    235 -291
    242 -290
    249 -290
    257 -289
    264 -288
    271 -287
    278 -286
    285 -285
    292 -284
    299 -283
    305 -282
    312 -281
    319 -280
    325 -279
    331 -277
    338 -276
    344 -275
    350 -274
    356 -273
    362 -271
    367 -270
    373 -269
    379 -267
    384 -266
    389 -265
    395 -263
    400 -262
    405 -260
    410 -259
    415 -257
    419 -256
    424 -254
    428 -253
    432 -251
    437 -250
    441 -248
    445 -246
    448 -245
    452 -243
    456 -241
    459 -240
    462 -238
    466 -236
    469 -234
    471 -233
    474 -231
    477 -229
    479 -227
    482 -225
    484 -223
    486 -221
    488 -220
    490 -218
    491 -216
    493 -214
    494 -212
    495 -210
    497 -208
    497 -206
    498 -204
    499 -202
    499 -200
    500 -198
    500 -196
    500 -194
    500 -191
    500 -189
    499 -187
    499 -185
    498 -183
    497 -181
    496 -179
    495 -177
    494 -174
    493 -172
    491 -170
    489 -168
    488 -166
    486 -163
    483 -161
    481 -159
    479 -157
    476 -154
    473 -152
    470 -150
    467 -148
    464 -145
    461 -143
    457 -141
    454 -138
    450 -136
    446 -134
    442 -131
    438 -129
    433 -127
    429 -124
    424 -122
    419 -120
    414 -117
    409 -115
    404 -113
    398 -110
    393 -108
    387 -106
    381 -103
    375 -101
    369 -98
    363 -96
    356 -94
    350 -91
    343 -89
    336 -86
    329 -84
    322 -82
    315 -79
    307 -77
    300 -74
    292 -72
    284 -70
    276 -67
    268 -65
    260 -62
    252 -60
    243 -58
    235 -55
    226 -53
    217 -50
    208 -48
    199 -46
    189 -43
    180 -41
    170 -38
    161 -36
    151 -34
    141 -31
    131 -29
    121 -26
    110 -24
    100 -22
    89 -19
    79 -17
    68 -14
    57 -12
    46 -10
    34 -7
    23 -5
    12 -2
    0 -0
    -12 2
    -23 5
    -35 7
    -47 9
    -60 12
    -72 14
    -84 17
    -97 19
    -110 21
    -122 24
    -135 26
    -148 28
    -161 31
    -174 33
    -188 35
    -201 38
    -215 40
    -228 42
    -242 45
    -256 47
    -270 49
    -284 52
    -298 54
    -312 56
    -327 59
    -341 61
    -356 63
    -371 65
    -386 68
    -400 70
    -415 72
    -431 75
    -446 77
    -461 79
    -476 81
    -492 84
    -508 86
    -523 88
    -539 90
    -555 93
    -571 95
    -587 97
    -603 99
    -620 101
    -636 104
    -652 106
    -669 108
    -686 110
    -702 112
    -719 115
    -736 117
    -753 119
    -770 121
    -787 123
    -805 125
    -822 128
    -839 130
    -857 132
    -875 134
    -892 136
    -910 138
    -928 140
    -946 142
    -964 145
    962 140
    944 138
    926 136
    908 134
    890 132
    872 130
    855 128
    837 126
    820 124
    802 122
    785 119
    768 117
    751 115
    734 113
    717 111
    700 109
    683 107
    667 105
    650 103
    634 100
    617 98
    601 96
    585 94
    569 92
    553 90
    537 87
    521 85
    505 83
    490 81
    474 79
    459 76
    444 74
    428 72
    413 70
    398 68
    383 65
    368 63
    354 61
    339 59
    325 57
    310 54
    296 52
    282 50
    268 48
    254 45
    240 43
    226 41
    212 39
    199 36
    185 34
    172 32
    159 29
    146 27
    133 25
    120 23
    107 20
    95 18
    82 16
    70 13
    57 11
    45 9
    33 6
    21 4
    9 2
    -2 -0
    -14 -3
    -25 -5
    -37 -7
    -48 -10
    -59 -12
    -70 -14
    -81 -17
    -92 -19
    -102 -21
    -113 -24
    -123 -26
    -133 -28
    -143 -31
    -153 -33
    -163 -35
    -173 -38
    -182 -40
    -192 -42
    -201 -45
    -210 -47
    -219 -50
    -228 -52
    -237 -54
    -246 -57
    -254 -59
    -262 -61
    -271 -64
    -279 -66
    -287 -68
    -295 -71
    -302 -73
    -310 -75
    -317 -78
    -324 -80
    -332 -82
    -339 -85
    -345 -87
    -352 -89
    -359 -92
    -365 -94
    -371 -96
    -378 -99
    -384 -101
    -389 -103
    -395 -106
    -401 -108
    -406 -110
    -411 -112
    -416 -115
    -421 -117
    -426 -119
    -431 -122
    -435 -124
    -440 -126
    -444 -128
    -448 -131
    -452 -133
    -456 -135
    -460 -137
    -463 -140
    -466 -142
    -470 -144
    -473 -146
    -475 -149
    -478 -151
    -481 -153
    -483 -155
    -486 -157
    -488 -160
    -490 -162
    -492 -164
    -493 -166
    -495 -168
    -496 -170
    -497 -172
    -499 -175
    -500 -177
    -500 -179
    -501 -181
    -502 -183
    -502 -185
    -502 -187
    -502 -189
    -502 -191
    -502 -193
    -501 -195
    -501 -197
    -500 -199
    -499 -201
    -499 -203
    -497 -205
    -496 -207
    -495 -209
    -493 -211
    -492 -212
    -490 -214
    -488 -216
    -486 -218
    -484 -220
    -481 -222
    -479 -223
    -476 -225
    -473 -227
    -470 -229
    -467 -230
    -464 -232
    -461 -234
    -457 -235
    -454 -237
    -450 -239
    -446 -240
    -442 -242
    -438 -243
    -434 -245
    -430 -247
    -425 -248
    -421 -250
    -416 -251
    -411 -252
    -406 -254
    -401 -255
    -396 -257
    -391 -258
    -385 -259
    -380 -261
    -374 -262
    -369 -263
    -363 -265
    -357 -266
    -351 -267
    -345 -268
    -339 -269
    -332 -271
    -326 -272
    -320 -273
    -313 -274
    -306 -275
    -300 -276
    -293 -277
    -286 -278
    -279 -279
    -272 -280
    -265 -281
    -257 -282
    -250 -282
    -243 -283
    -235 -284
    -228 -285
    -220 -286
    -213 -286
    -205 -287
    -197 -288
    -190 -288
    -182 -289
    -174 -290
    -166 -290
    -158 -291
    -150 -291
    -142 -292
    -134 -292
    -125 -293
    -117 -293
    -109 -293
    -101 -294
    -92 -294
    -84 -294
    -76 -295
    -67 -295
    -59 -295
    -51 -295
    -42 -295
    -34 -295
    -25 -296
    -17 -296
    -8 -296
    0 -296
    8 -296
    17 -296
    25 -296
    34 -295
    42 -295
    51 -295
    59 -295
    67 -295
    76 -295
    84 -294
    92 -294
    101 -294
    109 -293
    117 -293
    125 -293
    134 -292
    142 -292
    150 -291
    158 -291
    166 -290
    174 -290
    182 -289
    190 -288
    197 -288
    205 -287
    213 -286
    220 -286
    228 -285
    235 -284
    243 -283
    250 -282
    257 -282
    265 -281
    272 -280
    279 -279
    286 -278
    293 -277
    300 -276
    306 -275
    313 -274
    320 -273
    326 -272
    332 -271
    339 -269
    345 -268
    351 -267
    357 -266
    363 -265
    369 -263
    374 -262
    380 -261
    385 -259
    391 -258
    396 -257
    401 -255
    406 -254
    411 -252
    416 -251
    421 -250
    425 -248
    430 -247
    434 -245
    438 -243
    442 -242
    446 -240
    450 -239
    454 -237
    457 -235
    461 -234
    464 -232
    467 -230
    470 -229
    473 -227
    476 -225
    479 -223
    481 -222
    484 -220
    486 -218
    488 -216
    490 -214
    492 -212
    493 -211
    495 -209
    496 -207
    497 -205
    499 -203
    499 -201
    500 -199
    501 -197
    501 -195
    502 -193
    502 -191
    502 -189
    502 -187
    502 -185
    502 -183
    501 -181
    500 -179
    500 -177
    499 -175
    497 -172
    496 -170
    495 -168
    493 -166
    492 -164
    490 -162
    488 -160
    486 -157
    483 -155
    481 -153
    478 -151
    475 -149
    473 -146
    470 -144
    466 -142
    463 -140
    460 -137
    456 -135
    452 -133
    448 -131
    444 -128
    440 -126
    435 -124
    431 -122
    426 -119
    421 -117
    416 -115
    411 -112
    406 -110
    401 -108
    395 -106
    389 -103
    384 -101
    378 -99
    371 -96
    365 -94
    359 -92
    352 -89
    345 -87
    339 -85
    332 -82
    324 -80
    317 -78
    310 -75
    302 -73
    295 -71
    287 -68
    279 -66
    271 -64
    262 -61
    254 -59
    246 -57
    237 -54
    228 -52
    219 -50
    210 -47
    201 -45
    192 -42
    182 -40
    173 -38
    163 -35
    153 -33
    143 -31
    133 -28
    123 -26
    113 -24
    102 -21
    92 -19
    81 -17
    70 -14
    59 -12
    48 -10
    37 -7
    25 -5
    14 -3
    2 -0
    -9 2
    -21 4
    -33 6
    -45 9
    -57 11
    -70 13
    -82 16
    -95 18
    -107 20
    -120 23
    -133 25
    -146 27
    -159 29
    -172 32
    -185 34
    -199 36
    -212 39
    -226 41
    -240 43
    -254 45
    -268 48
    -282 50
    -296 52
    -310 54
    -325 57
    -339 59
    -354 61
    -368 63
    -383 65
    -398 68
    -413 70
    -428 72
    -444 74
    -459 76
    -474 79
    -490 81
    -505 83
    -521 85
    -537 87
    -553 90
    -569 92
    -585 94
    -601 96
    -617 98
    -634 100
    -650 103
    -667 105
    -683 107
    -700 109
    -717 111
    -734 113
    -751 115
    -768 117
    -785 119
    -802 122
    -820 124
    -837 126
    -855 128
    -872 130
    -890 132
    -908 134
    -926 136
    -944 138
    -962 140
    960 136
    942 134
    924 132
    906 130
    888 128
    870 126
    853 124
    835 122
    818 120
    800 118
    783 116
    766 114
    749 112
    732 110
    715 108
    698 105
    681 103
    665 101
    648 99
    632 97
    615 95
    599 93
    583 91
    567 89
    551 87
    535 85
    519 82
    503 80
    488 78
    472 76
    457 74
    441 72
    426 70
    411 68
    396 65
    381 63
    366 61
    352 59
    337 57
    322 55
    308 52
    294 50
    280 48
    265 46
    251 44
    238 41
    224 39
    210 37
    197 35
    183 33
    170 30
    157 28
    144 26
    131 24
    118 22
    105 19
    92 17
    80 15
    67 13
    55 10
    43 8
    31 6
    19 4
    7 1
    -5 -1
    -16 -3
    -28 -5
    -39 -8
    -50 -10
    -61 -12
    -72 -14
    -83 -17
    -94 -19
    -104 -21
    -115 -24
    -125 -26
    -136 -28
    -146 -30
    -156 -33
    -165 -35
    -175 -37
    -185 -39
    -194 -42
    -203 -44
    -213 -46
    -222 -49
    -231 -51
    -239 -53
    -248 -55
    -256 -58
    -265 -60
    -273 -62
    -281 -65
    -289 -67
    -297 -69
    -305 -71
    -312 -74
    -320 -76
    -327 -78
    -334 -81
    -341 -83
    -348 -85
    -354 -87
    -361 -90
    -367 -92
    -374 -94
    -380 -96
    -386 -99
    -392 -101
    -397 -103
    -403 -105
    -408 -108
    -414 -110
    -419 -112
    -424 -114
    -428 -117
    -433 -119
    -438 -121
    -442 -123
    -446 -125
    -450 -128
    -454 -130
    -458 -132
    -462 -134
    -465 -136
    -469 -139
    -472 -141
    -475 -143
    -478 -145
    -480 -147
    -483 -149
    -485 -151
    -488 -154
    -490 -156
    -492 -158
    -494 -160
    -495 -162
    -497 -164
    -498 -166
    -500 -168
    -501 -170
    -502 -172
    -502 -174
    -503 -176
    -504 -178
    -504 -180
    -504 -182
    -504 -184
    -504 -186
    -504 -188
    -503 -190
    -503 -192
    -502 -194
    -501 -196
    -500 -198
    -499 -200
    -498 -202
    -497 -203
    -495 -205
    -493 -207
    -492 -209
    -490 -211
    -488 -213
    -485 -214
    -483 -216
    -480 -218
    -478 -220
    -475 -221
    -472 -223
    -469 -225
    -466 -226
    -462 -228
    -459 -229
    -455 -231
    -452 -233
    -448 -234
    -444 -236
    -440 -237
    -436 -239
    -431 -240
    -427 -242
    -422 -243
    -417 -245
    -413 -246
    -408 -248
    -403 -249
    -397 -250
    -392 -252
    -387 -253
    -381 -254
    -376 -255
    -370 -257
    -364 -258
    -358 -259
    -352 -260
    -346 -262
    -340 -263
    -334 -264
    -327 -265
    -321 -266
    -314 -267
    -307 -268
    -301 -269
    -294 -270
    -287 -271
    -280 -272
    -273 -273
    -266 -274
    -258 -275
    -251 -275
    -244 -276
    -236 -277
    -229 -278
    -221 -278
    -213 -279
    -206 -280
    -198 -280
    -190 -281
    -182 -282
    -174 -282
    -166 -283
    -158 -283
    -150 -284
    -142 -284
    -134 -285
    -126 -285
    -118 -286
    -109 -286
    -101 -286
    -93 -287
    -84 -287
    -76 -287
    -68 -287
    -59 -288
    -51 -288
    -42 -288
    -34 -288
    -25 -288
    -17 -288
    -8 -288
    0 -288
    8 -288
    17 -288
    25 -288
    34 -288
    42 -288
    51 -288
    59 -288
    68 -287
    76 -287
    84 -287
    93 -287
    101 -286
    109 -286
    118 -286
    126 -285
    134 -285
    142 -284
    150 -284
    158 -283
    166 -283
    174 -282
    182 -282
    190 -281
    198 -280
    206 -280
    213 -279
    221 -278
    229 -278
    236 -277
    244 -276
    251 -275
    258 -275
    266 -274
    273 -273
    280 -272
    287 -271
    294 -270
    301 -269
    307 -268
    314 -267
    321 -266
    327 -265
    334 -264
    340 -263
    346 -262
    352 -260
    358 -259
    364 -258
    370 -257
    376 -255
    381 -254
    387 -253
    392 -252
    397 -250
    403 -249
    408 -248
    413 -246
    417 -245
    422 -243
    427 -242
    431 -240
    436 -239
    440 -237
    444 -236
    448 -234
    452 -233
    455 -231
    459 -229
    462 -228
    466 -226
    469 -225
    472 -223
    475 -221
    478 -220
    480 -218
    483 -216
    485 -214
    488 -213
    490 -211
    492 -209
    493 -207
    495 -205
    497 -203
    498 -202
    499 -200
    500 -198
    501 -196
    502 -194
    503 -192
    503 -190
    504 -188
    504 -186
    504 -184
    504 -182
    504 -180
    504 -178
    503 -176
    502 -174
    502 -172
    501 -170
    500 -168
    498 -166
    497 -164
    495 -162
    494 -160
    492 -158
    490 -156
    488 -154
    485 -151
    483 -149
    480 -147
    478 -145
    475 -143
    472 -141
    469 -139
    465 -136
    462 -134
    458 -132
    454 -130
    450 -128
    446 -125
    442 -123
    438 -121
    433 -119
    428 -117
    424 -114
    419 -112
    414 -110
    408 -108
    403 -105
    397 -103
    392 -101
    386 -99
    380 -96
    374 -94
    367 -92
    361 -90
    354 -87
    348 -85
    341 -83
    334 -81
    327 -78
    320 -76
    312 -74
    305 -71
    297 -69
    289 -67
    281 -65
    273 -62
    265 -60
    256 -58
    248 -55
    239 -53
    231 -51
    222 -49
    213 -46
    203 -44
    194 -42
    185 -39
    175 -37
    165 -35
    156 -33
    146 -30
    136 -28
    125 -26
    115 -24
    104 -21
    94 -19
    83 -17
    72 -14
    61 -12
    50 -10
    39 -8
    28 -5
    16 -3
    5 -1
    -7 1
    -19 4
    -31 6
    -43 8
    -55 10
    -67 13
    -80 15
    -92 17
    -105 19
    -118 22
    -131 24
    -144 26
    -157 28
    -170 30
    -183 33
    -197 35
    -210 37
    -224 39
    -238 41
    -251 44
    -265 46
    -280 48
    -294 50
    -308 52
    -322 55
    -337 57
    -352 59
    -366 61
    -381 63
    -396 65
    -411 68
    -426 70
    -441 72
    -457 74
    -472 76
    -488 78
    -503 80
    -519 82
    -535 85
    -551 87
    -567 89
    -583 91
    -599 93
    -615 95
    -632 97
    -648 99
    -665 101
    -681 103
    -698 105
    -715 108
    -732 110
    -749 112
    -766 114
    -783 116
    -800 118
    -818 120
    -835 122
    -853 124
    -870 126
    -888 128
    -906 130
    -924 132
    -942 134
    -960 136
    958 132
    940 130
    922 128
    904 126
    886 124
    868 122
    851 120
    833 118
    816 116
    798 114
    781 112
    764 110
    747 108
    730 106
    713 104
    696 102
    679 100
    663 98
    646 96
    630 94
    613 92
    597 90
    581 88
    565 86
    549 84
    533 82
    517 80
    501 78
    486 76
    470 74
    455 71
    439 69
    424 67
    409 65
    394 63
    379 61
    364 59
    349 57
    335 55
    320 53
    306 50
    292 48
    277 46
    263 44
    249 42
    235 40
    222 38
    208 36
    194 33
    181 31
    168 29
    154 27
    141 25
    128 23
    115 20
    103 18
    90 16
    78 14
    65 12
    53 10
    41 7
    29 5
    17 3
    5 1
    -7 -1
    -18 -3
    -30 -6
    -41 -8
    -52 -10
    -64 -12
    -75 -14
    -85 -17
    -96 -19
    -107 -21
    -117 -23
    -128 -26
    -138 -28
    -148 -30
    -158 -32
    -168 -34
    -177 -37
    -187 -39
    -196 -41
    -206 -43
    -215 -45
    -224 -48
    -233 -50
    -242 -52
    -250 -54
    -259 -57
    -267 -59
    -275 -61
    -283 -63
    -291 -65
    -299 -68
    -307 -70
    -314 -72
    -322 -74
    -329 -76
    -336 -79
    -343 -81
    -350 -83
    -357 -85
    -363 -87
    -370 -90
    -376 -92
    -382 -94
    -388 -96
    -394 -98
    -400 -101
    -405 -103
    -411 -105
    -416 -107
    -421 -109
    -426 -112
    -431 -114
    -435 -116
    -440 -118
    -444 -120
    -448 -122
    -453 -124
    -456 -127
    -460 -129
    -464 -131
    -467 -133
    -471 -135
    -474 -137
    -477 -139
    -480 -141
    -483 -143
    -485 -146
    -488 -148
    -490 -150
    -492 -152
    -494 -154
    -496 -156
    -497 -158
    -499 -160
    -500 -162
    -502 -164
    -503 -166
    -504 -168
    -504 -170
    -505 -172
    -506 -174
    -506 -176
    -506 -178
    -506 -180
    -506 -182
    -506 -183
    -505 -185
    -505 -187
    -504 -189
    -503 -191
    -502 -193
    -501 -195
    -500 -196
    -498 -198
    -497 -200
    -495 -202
    -493 -204
    -491 -205
    -489 -207
    -487 -209
    -485 -210
    -482 -212
    -479 -214
    -477 -215
    -474 -217
    -471 -219
    -467 -220
    -464 -222
    -461 -224
    -457 -225
    -453 -227
    -449 -228
    -445 -230
    -441 -231
    -437 -233
    -433 -234
    -428 -236
    -424 -237
    -419 -238
    -414 -240
    -409 -241
    -404 -242
    -399 -244
    -394 -245
    -388 -246
    -383 -248
    -377 -249
    -371 -250
    -365 -251
    -359 -252
    -353 -254
    -347 -255
    -341 -256
    -335 -257
    -328 -258
    -322 -259
    -315 -260
    -308 -261
    -302 -262
    -295 -263
    -288 -264
    -281 -265
    -274 -266
    -266 -266
    -259 -267
    -252 -268
    -244 -269
    -237 -270
    -229 -270
    -222 -271
    -214 -272
    -206 -272
    -199 -273
    -191 -274
    -183 -274
    -175 -275
    -167 -275
    -159 -276
    -151 -276
    -143 -277
    -134 -277
    -126 -278
    -118 -278
    -110 -278
    -101 -279
    -93 -279
    -85 -279
    -76 -280
    -68 -280
    -59 -280
    -51 -280
    -42 -280
    -34 -280
    -25 -280
    -17 -281
    -9 -281
    0 -281
    9 -281
    17 -281
    25 -280
    34 -280
    42 -280
    51 -280
    59 -280
    68 -280
    76 -280
    85 -279
    93 -279
    101 -279
    110 -278
    118 -278
    126 -278
    134 -277
    143 -277
    151 -276
    159 -276
    167 -275
    175 -275
    183 -274
    191 -274
    199 -273
    206 -272
    214 -272
    222 -271
    229 -270
    237 -270
    244 -269
    252 -268
    259 -267
    266 -266
    274 -266
    281 -265
    288 -264
    295 -263
    302 -262
    308 -261
    315 -260
    322 -259
    328 -258
    335 -257
    341 -256
    347 -255
    353 -254
    359 -252
    365 -251
    371 -250
    377 -249
    383 -248
    388 -246
    394 -245
    399 -244
    404 -242
    409 -241
    414 -240
    419 -238
    424 -237
    428 -236
    433 -234
    437 -233
    441 -231
    445 -230
    449 -228
    453 -227
    457 -225
    461 -224
    464 -222
    467 -220
    471 -219
    474 -217
    477 -215
    479 -214
    482 -212
    485 -210
    487 -209
    489 -207
    491 -205
    493 -204
    495 -202
    497 -200
    498 -198
    500 -196
    501 -195
    502 -193
    503 -191
    504 -189
    505 -187
    505 -185
    506 -183
    506 -182
    506 -180
    506 -178
    506 -176
    506 -174
    505 -172
    504 -170
    504 -168
    503 -166
    502 -164
    500 -162
    499 -160
    497 -158
    496 -156
    494 -154
    492 -152
    490 -150
    488 -148
    485 -146
    483 -143
    480 -141
    477 -139
    474 -137
    471 -135
    467 -133
    464 -131
    460 -129
    456 -127
    453 -124
    448 -122
    444 -120
    440 -118
    435 -116
    431 -114
    426 -112
    421 -109
    416 -107
    411 -105
    405 -103
    400 -101
    394 -98
    388 -96
    382 -94
    376 -92
    370 -90
    363 -87
    357 -85
    350 -83
    343 -81
    336 -79
    329 -76
    322 -74
    314 -72
    307 -70
    299 -68
    291 -65
    283 -63
    275 -61
    267 -59
    259 -57
    250 -54
    242 -52
    233 -50
    224 -48
    215 -45
    206 -43
    196 -41
    187 -39
    177 -37
    168 -34
    158 -32
    148 -30
    138 -28
    128 -26
    117 -23
    107 -21
    96 -19
    85 -17
    75 -14
    64 -12
    52 -10
    41 -8
    30 -6
    18 -3
    7 -1
    -5 1
    -17 3
    -29 5
    -41 7
    -53 10
    -65 12
    -78 14
    -90 16
    -103 18
    -115 20
    -128 23
    -141 25
    -154 27
    -168 29
    -181 31
    -194 33
    -208 36
    -222 38
    -235 40
    -249 42
    -263 44
    -277 46
    -292 48
    -306 50
    -320 53
    -335 55
    -349 57
    -364 59
    -379 61
    -394 63
    -409 65
    -424 67
    -439 69
    -455 71
    -470 74
    -486 76
    -501 78
    -517 80
    -533 82
    -549 84
    -565 86
    -581 88
    -597 90
    -613 92
    -630 94
    -646 96
    -663 98
    -679 100
    -696 102
    -713 104
    -730 106
    -747 108
    -764 110
    -781 112
    -798 114
    -816 116
    -833 118
    -851 120
    -868 122
    -886 124
    -904 126
    -922 128
    -940 130
    -958 132
    956 127
    938 126
    920 124
    902 122
    884 120
    866 118
    849 116
    831 114
    814 112
    796 110
    779 108
    762 106
    745 105
    728 103
    711 101
    694 99
    677 97
    661 95
    644 93
    628 91
    611 89
    595 87
    579 85
    563 83
    547 81
    531 79
    515 77
    499 75
    483 73
    468 71
    453 69
    437 67
    422 65
    407 63
    392 61
    377 59
    362 57
    347 55
    333 53
    318 51
    304 49
    289 47
    275 44
    261 42
    247 40
    233 38
    220 36
    206 34
    192 32
    179 30
    166 28
    152 26
    139 24
    126 22
    113 20
    101 17
    88 15
    75 13
    63 11
    51 9
    39 7
    26 5
    14 3
    3 0
    -9 -2
    -21 -4
    -32 -6
    -43 -8
    -55 -10
    -66 -12
    -77 -14
    -88 -17
    -98 -19
    -109 -21
    -119 -23
    -130 -25
    -140 -27
    -150 -29
    -160 -32
    -170 -34
    -180 -36
    -189 -38
    -199 -40
    -208 -42
    -217 -45
    -226 -47
    -235 -49
    -244 -51
    -252 -53
    -261 -55
    -269 -57
    -277 -60
    -286 -62
    -294 -64
    -301 -66
    -309 -68
    -317 -70
    -324 -72
    -331 -75
    -338 -77
    -345 -79
    -352 -81
    -359 -83
    -365 -85
    -372 -87
    -378 -90
    -384 -92
    -390 -94
    -396 -96
    -402 -98
    -407 -100
    -413 -102
    -418 -104
    -423 -107
    -428 -109
    -433 -111
    -437 -113
    -442 -115
    -446 -117
    -451 -119
    -455 -121
    -459 -123
    -462 -125
    -466 -127
    -469 -129
    -473 -132
    -476 -134
    -479 -136
    -482 -138
    -485 -140
    -487 -142
    -490 -144
    -492 -146
    -494 -148
    -496 -150
    -498 -152
    -499 -154
    -501 -156
    -502 -158
    -504 -160
    -505 -161
    -506 -163
    -506 -165
    -507 -167
    -507 -169
    -508 -171
    -508 -173
    -508 -175
    -508 -177
    -508 -179
    -507 -180
    -507 -182
    -506 -184
    -505 -186
    -504 -188
    -503 -189
    -502 -191
    -500 -193
    -499 -195
    -497 -196
    -495 -198
    -493 -200
    -491 -201
    -489 -203
    -486 -205
    -484 -206
    -481 -208
    -478 -210
    -475 -211
    -472 -213
    -469 -214
    -466 -216
    -462 -217
    -459 -219
    -455 -220
    -451 -222
    -447 -223
    -443 -225
    -438 -226
    -434 -228
    -430 -229
    -425 -230
    -420 -232
    -415 -233
    -410 -235
    -405 -236
    -400 -237
    -395 -238
    -389 -240
    -384 -241
    -378 -242
    -372 -243
    -367 -244
    -361 -246
    -355 -247
    -348 -248
    -342 -249
    -336 -250
    -329 -251
    -323 -252
    -316 -253
    -309 -254
    -303 -255
    -296 -256
    -289 -257
    -282 -257
    -275 -258
    -267 -259
    -260 -260
    -253 -261
    -245 -262
    -238 -262
    -230 -263
    -222 -264
    -215 -264
    -207 -265
    -199 -266
    -191 -266
    -183 -267
    -175 -267
    -167 -268
    -159 -268
    -151 -269
    -143 -269
    -135 -270
    -127 -270
    -118 -270
    -110 -271
    -102 -271
    -93 -271
    -85 -272
    -76 -272
    -68 -272
    -60 -272
    -51 -272
    -43 -273
    -34 -273
    -26 -273
    -17 -273
    -9 -273
    0 -273
    9 -273
    17 -273
    26 -273
    34 -273
    43 -273
    51 -272
    60 -272
    68 -272
    76 -272
    85 -272
    93 -271
    102 -271
    110 -271
    118 -270
    127 -270
    135 -270
    143 -269
    151 -269
    159 -268
    167 -268
    175 -267
    183 -267
    191 -266
    199 -266
    207 -265
    215 -264
    222 -264
    230 -263
    238 -262
    245 -262
    253 -261
    260 -260
    267 -259
    275 -258
    282 -257
    289 -257
    296 -256
    303 -255
    309 -254
    316 -253
    323 -252
    329 -251
    336 -250
    342 -249
    348 -248
    355 -247
    361 -246
    367 -244
    372 -243
    378 -242
    384 -241
    389 -240
    395 -238
    400 -237
    405 -236
    410 -235
    415 -233
    420 -232
    425 -230
    430 -229
    434 -228
    438 -226
    443 -225
    447 -223
    451 -222
    455 -220
    459 -219
    462 -217
    466 -216
    469 -214
    472 -213
    475 -211
    478 -210
    481 -208
    484 -206
    486 -205
    489 -203
    491 -201
    493 -200
    495 -198
    497 -196
    499 -195
    500 -193
    502 -191
    503 -189
    504 -188
    505 -186
    506 -184
    507 -182
    507 -180
    508 -179
    508 -177
    508 -175
    508 -173
    508 -171
    507 -169
    507 -167
    506 -165
    506 -163
    505 -161
    504 -160
    502 -158
    501 -156
    499 -154
    498 -152
    496 -150
    494 -148
    492 -146
    490 -144
    487 -142
    485 -140
    482 -138
    479 -136
    476 -134
    473 -132
    469 -129
    466 -127
    462 -125
    459 -123
    455 -121
    451 -119
    446 -117
    442 -115
    437 -113
    433 -111
    428 -109
    423 -107
    418 -104
    413 -102
    407 -100
    402 -98
    396 -96
    390 -94
    384 -92
    378 -90
    372 -87
    365 -85
    359 -83
    352 -81
    345 -79
    338 -77
    331 -75
    324 -72
    317 -70
    309 -68
    301 -66
    294 -64
    286 -62
    277 -60
    269 -57
    261 -55
    252 -53
    244 -51
    235 -49
    226 -47
    217 -45
    208 -42
    199 -40
    189 -38
    180 -36
    170 -34
    160 -32
    150 -29
    140 -27
    130 -25
    119 -23
    109 -21
    98 -19
    88 -17
    77 -14
    66 -12
    55 -10
    43 -8
    32 -6
    21 -4
    9 -2
    -3 0
    -14 3
    -26 5
    -39 7
    -51 9
    -63 11
    -75 13
    -88 15
    -101 17
    -113 20
    -126 22
    -139 24
    -152 26
    -166 28
    -179 30
    -192 32
    -206 34
    -220 36
    -233 38
    -247 40
    -261 42
    -275 44
    -289 47
    -304 49
    -318 51
    -333 53
    -347 55
    -362 57
    -377 59
    -392 61
    -407 63
    -422 65
    -437 67
    -453 69
    -468 71
    -483 73
    -499 75
    -515 77
    -531 79
    -547 81
    -563 83
    -579 85
    -595 87
    -611 89
    -628 91
    -644 93
    -661 95
    -677 97
    -694 99
    -711 101
    -728 103
    -745 105
    -762 106
    -779 108
    -796 110
    -814 112
    -831 114
    -849 116
    -866 118
    -884 120
    -902 122
    -920 124
    -938 126
    -956 127
    954 123
    936 121
    918 120
    900 118
    882 116
    865 114
    847 112
    829 110
    812 108
    795 107
    777 105
    760 103
    743 101
    726 99
    709 97
    692 95
    675 93
    659 92
    642 90
    626 88
    609 86
    593 84
    577 82
    561 80
    545 78
    529 76
    513 74
    497 72
    482 70
    466 68
    451 67
    435 65
    420 63
    405 61
    390 59
    375 57
    360 55
    345 53
    331 51
    316 49
    302 47
    287 45
    273 43
    259 41
    245 39
    231 37
    217 35
    204 33
    190 31
    177 29
    164 27
    150 25
    137 23
    124 21
    111 19
    99 17
    86 14
    73 12
    61 10
    49 8
    36 6
    24 4
    12 2
    1 0
    -11 -2
    -23 -4
    -34 -6
    -46 -8
    -57 -10
    -68 -12
    -79 -14
    -90 -16
    -100 -19
    -111 -21
    -121 -23
    -132 -25
    -142 -27
    -152 -29
    -162 -31
    -172 -33
    -182 -35
    -191 -37
    -201 -39
    -210 -41
    -219 -44
    -228 -46
    -237 -48
    -246 -50
    -254 -52
    -263 -54
    -271 -56
    -280 -58
    -288 -60
    -296 -62
    -303 -64
    -311 -67
    -319 -69
    -326 -71
    -333 -73
    -340 -75
    -347 -77
    -354 -79
    -361 -81
    -368 -83
    -374 -85
    -380 -87
    -386 -89
    -392 -91
    -398 -93
    -404 -96
    -409 -98
    -415 -100
    -420 -102
    -425 -104
    -430 -106
    -435 -108
    -440 -110
    -444 -112
    -448 -114
    -453 -116
    -457 -118
    -461 -120
    -464 -122
    -468 -124
    -471 -126
    -475 -128
    -478 -130
    -481 -132
    -484 -134
    -487 -136
    -489 -138
    -492 -140
    -494 -142
    -496 -144
    -498 -146
    -500 -148
    -501 -149
    -503 -151
    -504 -153
    -505 -155
    -507 -157
    -507 -159
    -508 -161
    -509 -163
    -509 -164
    -510 -166
    -510 -168
    -510 -170
    -510 -172
    -509 -174
    -509 -175
    -508 -177
    -508 -179
    -507 -181
    -506 -182
    -505 -184
    -503 -186
    -502 -187
    -500 -189
    -499 -191
    -497 -193
    -495 -194
    -493 -196
    -490 -197
    -488 -199
    -485 -201
    -483 -202
    -480 -204
    -477 -205
    -474 -207
    -471 -208
    -467 -210
    -464 -211
    -460 -213
    -456 -214
    -452 -216
    -448 -217
    -444 -219
    -440 -220
    -435 -221
    -431 -223
    -426 -224
    -422 -225
    -417 -227
    -412 -228
    -407 -229
    -401 -230
    -396 -232
    -391 -233
    -385 -234
    -379 -235
    -374 -236
    -368 -237
    -362 -239
    -356 -240
    -349 -241
    -343 -242
    -337 -243
    -330 -244
    -324 -245
    -317 -246
    -310 -247
    -303 -248
    -297 -248
    -290 -249
    -282 -250
    -275 -251
    -268 -252
    -261 -253
    -253 -253
    -246 -254
    -238 -255
    -231 -256
    -223 -256
    -215 -257
    -208 -257
    -200 -258
    -192 -259
    -184 -259
    -176 -260
    -168 -260
    -160 -261
    -152 -261
    -143 -262
    -135 -262
    -127 -262
    -119 -263
    -110 -263
    -102 -263
    -94 -264
    -85 -264
    -77 -264
    -68 -264
    -60 -265
    -51 -265
    -43 -265
    -34 -265
    -26 -265
    -17 -265
    -9 -265
    0 -265
    9 -265
    17 -265
    26 -265
    34 -265
    43 -265
    51 -265
    60 -265
    68 -264
    77 -264
    85 -264
    94 -264
    102 -263
    110 -263
    119 -263
    127 -262
    135 -262
    143 -262
    152 -261
    160 -261
    168 -260
    176 -260
    184 -259
    192 -259
    200 -258
    208 -257
    215 -257
    223 -256
    231 -256
    238 -255
    246 -254
    253 -253
    261 -253
    268 -252
    275 -251
    282 -250
    290 -249
    297 -248
    303 -248
    310 -247
    317 -246
    324 -245
    330 -244
    337 -243
    343 -242
    349 -241
    356 -240
    362 -239
    368 -237
    374 -236
    379 -235
    385 -234
    391 -233
    396 -232
    401 -230
    407 -229
    412 -228
    417 -227
    422 -225
    426 -224
    431 -223
    435 -221
    440 -220
    444 -219
    448 -217
    452 -216
    456 -214
    460 -213
    464 -211
    467 -210
    471 -208
    474 -207
    477 -205
    480 -204
    483 -202
    485 -201
    488 -199
    490 -197
    493 -196
    495 -194
    497 -193
    499 -191
    500 -189
    502 -187
    503 -186
    505 -184
    506 -182
    507 -181
    508 -179
    508 -177
    509 -175
    509 -174
    510 -172
    510 -170
    510 -168
    510 -166
    509 -164
    509 -163
    508 -161
    507 -159
    507 -157
    505 -155
    504 -153
    503 -151
    501 -149
    500 -148
    498 -146
    496 -144
    494 -142
    492 -140
    489 -138
    487 -136
    484 -134
    481 -132
    478 -130
    475 -128
    471 -126
    468 -124
    464 -122
    461 -120
    457 -118
    453 -116
    448 -114
    444 -112
    440 -110
    435 -108
    430 -106
    425 -104
    420 -102
    415 -100
    409 -98
    404 -96
    398 -93
    392 -91
    386 -89
    380 -87
    374 -85
    368 -83
    361 -81
    354 -79
    347 -77
    340 -75
    333 -73
    326 -71
    319 -69
    311 -67
    303 -64
    296 -62
    288 -60
    280 -58
    271 -56
    263 -54
    254 -52
    246 -50
    237 -48
    228 -46
    219 -44
    210 -41
    201 -39
    191 -37
    182 -35
    172 -33
    162 -31
    152 -29
    142 -27
    132 -25
    121 -23
    111 -21
    100 -19
    90 -16
    79 -14
    68 -12
    57 -10
    46 -8
    34 -6
    23 -4
    11 -2
    -1 0
    -12 2
    -24 4
    -36 6
    -49 8
    -61 10
    -73 12
    -86 14
    -99 17
    -111 19
    -124 21
    -137 23
    -150 25
    -164 27
    -177 29
    -190 31
    -204 33
    -217 35
    -231 37
    -245 39
    -259 41
    -273 43
    -287 45
    -302 47
    -316 49
    -331 51
    -345 53
    -360 55
    -375 57
    -390 59
    -405 61
    -420 63
    -435 65
    -451 67
    -466 68
    -482 70
    -497 72
    -513 74
    -529 76
    -545 78
    -561 80
    -577 82
    -593 84
    -609 86
    -626 88
    -642 90
    -659 92
    -675 93
    -692 95
    -709 97
    -726 99
    -743 101
    -760 103
    -777 105
    -795 107
    -812 108
    -829 110
    -847 112
    -865 114
    -882 116
    -900 118
    -918 120
    -936 121
    -954 123
    952 119
    934 117
    916 115
    898 114
    881 112
    863 110
    845 108
    828 107
    810 105
    793 103
    775 101
    758 99
    741 98
    724 96
    707 94
    690 92
    674 90
    657 88
    640 87
    624 85
    607 83
    591 81
    575 79
    559 77
    543 75
    527 74
    511 72
    495 70
    480 68
    464 66
    449 64
    433 62
    418 60
    403 58
    388 56
    373 55
    358 53
    343 51
    329 49
    314 47
    300 45
    285 43
    271 41
    257 39
    243 37
    229 35
    216 33
    202 31
    188 29
    175 27
    162 26
    148 24
    135 22
    122 20
    109 18
    97 16
    84 14
    71 12
    59 10
    47 8
    34 6
    22 4
    10 2
    -1 -0
    -13 -2
    -25 -4
    -36 -6
    -48 -8
    -59 -10
    -70 -12
    -81 -14
    -92 -16
    -102 -18
    -113 -20
    -124 -22
    -134 -24
    -144 -26
    -154 -28
    -164 -30
    -174 -32
    -184 -34
    -193 -36
    -203 -38
    -212 -41
    -221 -43
    -230 -45
    -239 -47
    -248 -49
    -257 -51
    -265 -53
    -273 -55
    -282 -57
    -290 -59
    -298 -61
    -306 -63
    -313 -65
    -321 -67
    -328 -69
    -335 -71
    -343 -73
    -349 -75
    -356 -77
    -363 -79
    -370 -81
    -376 -83
    -382 -85
    -388 -87
    -394 -89
    -400 -91
    -406 -93
    -411 -95
    -417 -97
    -422 -99
    -427 -101
    -432 -103
    -437 -105
    -442 -107
    -446 -109
    -450 -111
    -455 -113
    -459 -115
    -463 -117
    -466 -119
    -470 -121
    -473 -122
    -477 -124
    -480 -126
    -483 -128
    -486 -130
    -488 -132
    -491 -134
    -493 -136
    -496 -138
    -498 -140
    -500 -141
    -502 -143
    -503 -145
    -505 -147
    -506 -149
    -507 -151
    -508 -153
    -509 -154
    -510 -156
    -511 -158
    -511 -160
    -511 -162
    -512 -163
    -512 -165
    -511 -167
    -511 -169
    -511 -170
    -510 -172
    -509 -174
    -509 -175
    -508 -177
    -506 -179
    -505 -180
    -504 -182
    -502 -184
    -500 -185
    -498 -187
    -496 -189
    -494 -190
    -492 -192
    -490 -193
    -487 -195
    -484 -196
    -481 -198
    -478 -199
    -475 -201
    -472 -202
    -469 -204
    -465 -205
    -461 -207
    -458 -208
    -454 -209
    -450 -211
    -446 -212
    -441 -214
    -437 -215
    -432 -216
    -428 -217
    -423 -219
    -418 -220
    -413 -221
    -408 -222
    -403 -224
    -397 -225
    -392 -226
    -386 -227
    -380 -228
    -375 -229
    -369 -230
    -363 -232
    -357 -233
    -350 -234
    -344 -235
    -338 -236
    -331 -237
    -325 -238
    -318 -239
    -311 -239
    -304 -240
    -297 -241
    -290 -242
    -283 -243
    -276 -244
    -269 -244
    -262 -245
    -254 -246
    -247 -247
    -239 -247
    -231 -248
    -224 -249
    -216 -249
    -208 -250
    -200 -250
    -192 -251
    -184 -252
    -176 -252
    -168 -253
    -160 -253
    -152 -253
    -144 -254
    -136 -254
    -127 -255
    -119 -255
    -111 -255
    -102 -256
    -94 -256
    -85 -256
    -77 -256
    -68 -257
    -60 -257
    -51 -257
    -43 -257
    -34 -257
    -26 -257
    -17 -257
    -9 -257
    0 -257
    9 -257
    17 -257
    26 -257
    34 -257
    43 -257
    51 -257
    60 -257
    68 -257
    77 -256
    85 -256
    94 -256
    102 -256
    111 -255
    119 -255
    127 -255
    136 -254
    144 -254
    152 -253
    160 -253
    168 -253
    176 -252
    184 -252
    192 -251
    200 -250
    208 -250
    216 -249
    224 -249
    231 -248
    239 -247
    247 -247
    254 -246
    262 -245
    269 -244
    276 -244
    283 -243
    290 -242
    297 -241
    304 -240
    311 -239
    318 -239
    325 -238
    331 -237
    338 -236
    344 -235
    350 -234
    357 -233
    363 -232
    369 -230
    375 -229
    380 -228
    386 -227
    392 -226
    397 -225
    403 -224
    408 -222
    413 -221
    418 -220
    423 -219
    428 -217
    432 -216
    437 -215
    441 -214
    446 -212
    450 -211
    454 -209
    458 -208
    461 -207
    465 -205
    469 -204
    472 -202
    475 -201
    478 -199
    481 -198
    484 -196
    487 -195
    490 -193
    492 -192
    494 -190
    496 -189
    498 -187
    500 -185
    502 -184
    504 -182
    505 -180
    506 -179
    508 -177
    509 -175
    509 -174
    510 -172
    511 -170
    511 -169
    511 -167
    512 -165
    512 -163
    511 -162
    511 -160
    511 -158
    510 -156
    509 -154
    508 -153
    507 -151
    506 -149
    505 -147
    503 -145
    502 -143
    500 -141
    498 -140
    496 -138
    493 -136
    491 -134
    488 -132
    486 -130
    483 -128
    480 -126
    477 -124
    473 -122
    470 -121
    466 -119
    463 -117
    459 -115
    455 -113
    450 -111
    446 -109
    442 -107
    437 -105
    432 -103
    427 -101
    422 -99
    417 -97
    411 -95
    406 -93
    400 -91
    394 -89
    388 -87
    382 -85
    376 -83
    370 -81
    363 -79
    356 -77
    349 -75
    343 -73
    335 -71
    328 -69
    321 -67
    313 -65
    306 -63
    298 -61
    290 -59
    282 -57
    273 -55
    265 -53
    257 -51
    248 -49
    239 -47
    230 -45
    221 -43
    212 -41
    203 -38
    193 -36
    184 -34
    174 -32
    164 -30
    154 -28
    144 -26
    134 -24
    124 -22
    113 -20
    102 -18
    92 -16
    81 -14
    70 -12
    59 -10
    48 -8
    36 -6
    25 -4
    13 -2
    1 -0
    -10 2
    -22 4
    -34 6
    -47 8
    -59 10
    -71 12
    -84 14
    -97 16
    -109 18
    -122 20
    -135 22
    -148 24
    -162 26
    -175 27
    -188 29
    -202 31
    -216 33
    -229 35
    -243 37
    -257 39
    -271 41
    -285 43
    -300 45
    -314 47
    -329 49
    -343 51
    -358 53
    -373 55
    -388 56
    -403 58
    -418 60
    -433 62
    -449 64
    -464 66
    -480 68
    -495 70
    -511 72
    -527 74
    -543 75
    -559 77
    -575 79
    -591 81
    -607 83
    -624 85
    -640 87
    -657 88
    -674 90
    -690 92
    -707 94
    -724 96
    -741 98
    -758 99
    -775 101
    -793 103
    -810 105
    -828 107
    -845 108
    -863 110
    -881 112
    -898 114
    -916 115
    -934 117
    -952 119
    950 115
    932 113
    914 111
    897 110
    879 108
    861 106
    843 105
    826 103
    808 101
    791 99
    774 98
    756 96
    739 94
    722 92
    705 91
    688 89
    672 87
    655 85
    638 83
    622 82
    606 80
    589 78
    573 76
    557 74
    541 73
    525 71
    509 69
    493 67
    478 65
    462 64
    447 62
    431 60
    416 58
    401 56
    386 54
    371 52
    356 51
    341 49
    327 47
    312 45
    298 43
    284 41
    269 39
    255 38
    241 36
    227 34
    214 32
    200 30
    186 28
    173 26
    160 24
    146 22
    133 21
    120 19
    107 17
    95 15
    82 13
    69 11
    57 9
    45 7
    32 5
    20 3
    8 1
    -3 -1
    -15 -2
    -27 -4
    -38 -6
    -50 -8
    -61 -10
    -72 -12
    -83 -14
    -94 -16
    -104 -18
    -115 -20
    -126 -22
    -136 -24
    -146 -26
    -156 -28
    -166 -30
    -176 -32
    -186 -34
    -195 -36
    -205 -38
    -214 -40
    -223 -41
    -232 -43
    -241 -45
    -250 -47
    -259 -49
    -267 -51
    -275 -53
    -284 -55
    -292 -57
    -300 -59
    -308 -61
    -315 -63
    -323 -65
    -330 -67
    -337 -69
    -344 -71
    -351 -73
    -358 -75
    -365 -77
    -372 -79
    -378 -81
    -384 -83
    -390 -84
    -396 -86
    -402 -88
    -408 -90
    -413 -92
    -419 -94
    -424 -96
    -429 -98
    -434 -100
    -439 -102
    -443 -104
    -448 -106
    -452 -108
    -457 -109
    -461 -111
    -464 -113
    -468 -115
    -472 -117
    -475 -119
    -479 -121
    -482 -123
    -485 -124
    -488 -126
    -490 -128
    -493 -130
    -495 -132
    -498 -134
    -500 -135
    -502 -137
    -503 -139
    -505 -141
    -507 -143
    -508 -144
    -509 -146
    -510 -148
    -511 -150
    -512 -151
    -512 -153
    -513 -155
    -513 -157
    -513 -158
    -513 -160
    -513 -162
    -513 -163
    -512 -165
    -512 -167
    -511 -168
    -510 -170
    -509 -172
    -508 -173
    -507 -175
    -505 -177
    -504 -178
    -502 -180
    -500 -181
    -498 -183
    -496 -184
    -494 -186
    -491 -187
    -488 -189
    -486 -190
    -483 -192
    -480 -193
    -477 -195
    -473 -196
    -470 -198
    -466 -199
    -463 -200
    -459 -202
    -455 -203
    -451 -204
    -447 -206
    -443 -207
    -438 -208
    -434 -210
    -429 -211
    -424 -212
    -419 -213
    -414 -214
    -409 -216
    -404 -217
    -398 -218
    -393 -219
    -387 -220
    -382 -221
    -376 -222
    -370 -223
    -364 -224
    -358 -226
    -351 -227
    -345 -227
    -339 -228
    -332 -229
    -326 -230
    -319 -231
    -312 -232
    -305 -233
    -298 -234
    -291 -235
    -284 -235
    -277 -236
    -270 -237
    -262 -238
    -255 -238
    -247 -239
    -240 -240
    -232 -240
    -224 -241
    -217 -242
    -209 -242
    -201 -243
    -193 -243
    -185 -244
    -177 -244
    -169 -245
    -161 -245
    -153 -246
    -144 -246
    -136 -246
    -128 -247
    -119 -247
    -111 -248
    -103 -248
    -94 -248
    -86 -248
    -77 -249
    -69 -249
    -60 -249
    -52 -249
    -43 -249
    -34 -249
    -26 -249
    -17 -249
    -9 -249
    0 -249
    9 -249
    17 -249
    26 -249
    34 -249
    43 -249
    52 -249
    60 -249
    69 -249
    77 -249
    86 -248
    94 -248
    103 -248
    111 -248
    119 -247
    128 -247
    136 -246
    144 -246
    153 -246
    161 -245
    169 -245
    177 -244
    185 -244
    193 -243
    201 -243
    209 -242
    217 -242
    224 -241
    232 -240
    240 -240
    247 -239
    255 -238
    262 -238
    270 -237
    277 -236
    284 -235
    291 -235
    298 -234
    305 -233
    312 -232
    319 -231
    326 -230
    332 -229
    339 -228
    345 -227
    351 -227
    358 -226
    364 -224
    370 -223
    376 -222
    382 -221
    387 -220
    393 -219
    398 -218
    404 -217
    409 -216
    414 -214
    419 -213
    424 -212
    429 -211
    434 -210
    438 -208
    443 -207
    447 -206
    451 -204
    455 -203
    459 -202
    463 -200
    466 -199
    470 -198
    473 -196
    477 -195
    480 -193
    483 -192
    486 -190
    488 -189
    491 -187
    494 -186
    496 -184
    498 -183
    500 -181
    502 -180
    504 -178
    505 -177
    507 -175
    508 -173
    509 -172
    510 -170
    511 -168
    512 -167
    512 -165
    513 -163
    513 -162
    513 -160
    513 -158
    513 -157
    513 -155
    512 -153
    512 -151
    511 -150
    510 -148
    509 -146
    508 -144
    507 -143
    505 -141
    503 -139
    502 -137
    500 -135
    498 -134
    495 -132
    493 -130
    490 -128
    488 -126
    485 -124
    482 -123
    479 -121
    475 -119
    472 -117
    468 -115
    464 -113
    461 -111
    457 -109
    452 -108
    448 -106
    443 -104
    439 -102
    434 -100
    429 -98
    424 -96
    419 -94
    413 -92
    408 -90
    402 -88
    396 -86
    390 -84
    384 -83
    378 -81
    372 -79
    365 -77
    358 -75
    351 -73
    344 -71
    337 -69
    330 -67
    323 -65
    315 -63
    308 -61
    300 -59
    292 -57
    284 -55
    275 -53
    267 -51
    259 -49
    250 -47
    241 -45
    232 -43
    223 -41
    214 -40
    205 -38
    195 -36
    186 -34
    176 -32
    166 -30
    156 -28
    146 -26
    136 -24
    126 -22
    115 -20
    104 -18
    94 -16
    83 -14
    72 -12
    61 -10
    50 -8
    38 -6
    27 -4
    15 -2
    3 -1
    -8 1
    -20 3
    -32 5
    -45 7
    -57 9
    -69 11
    -82 13
    -95 15
    -107 17
    -120 19
    -133 21
    -146 22
    -160 24
    -173 26
    -186 28
    -200 30
    -214 32
    -227 34
    -241 36
    -255 38
    -269 39
    -284 41
    -298 43
    -312 45
    -327 47
    -341 49
    -356 51
    -371 52
    -386 54
    -401 56
    -416 58
    -431 60
    -447 62
    -462 64
    -478 65
    -493 67
    -509 69
    -525 71
    -541 73
    -557 74
    -573 76
    -589 78
    -606 80
    -622 82
    -638 83
    -655 85
    -672 87
    -688 89
    -705 91
    -722 92
    -739 94
    -756 96
    -774 98
    -791 99
    -808 101
    -826 103
    -843 105
    -861 106
    -879 108
    -897 110
    -914 111
    -932 113
    -950 115
    949 111
    931 109
    913 107
    895 106
    877 104
    859 102
    842 101
    824 99
    807 97
    789 96
    772 94
    755 92
    738 91
    721 89
    704 87
    687 85
    670 84
    653 82
    637 80
    620 79
    604 77
    587 75
    571 73
    555 72
    539 70
    523 68
    507 66
    492 65
    476 63
    460 61
    445 59
    430 58
    414 56
    399 54
    384 52
    369 50
    354 49
    340 47
    325 45
    310 43
    296 41
    282 40
    268 38
    253 36
    239 34
    226 32
    212 31
    198 29
    185 27
    171 25
    158 23
    144 21
    131 20
    118 18
    105 16
    93 14
    80 12
    67 10
    55 8
    43 7
    31 5
    18 3
    7 1
    -5 -1
    -17 -3
    -29 -5
    -40 -6
    -51 -8
    -63 -10
    -74 -12
    -85 -14
    -96 -16
    -106 -18
    -117 -20
    -127 -21
    -138 -23
    -148 -25
    -158 -27
    -168 -29
    -178 -31
    -188 -33
    -197 -35
    -207 -37
    -216 -39
    -225 -40
    -234 -42
    -243 -44
    -252 -46
    -260 -48
    -269 -50
    -277 -52
    -286 -54
    -294 -56
    -302 -57
    -309 -59
    -317 -61
    -325 -63
    -332 -65
    -339 -67
    -346 -69
    -353 -71
    -360 -73
    -367 -74
    -373 -76
    -380 -78
    -386 -80
    -392 -82
    -398 -84
    -404 -86
    -410 -88
    -415 -89
    -421 -91
    -426 -93
    -431 -95
    -436 -97
    -441 -99
    -445 -101
    -450 -102
    -454 -104
    -458 -106
    -462 -108
    -466 -110
    -470 -112
    -474 -113
    -477 -115
    -480 -117
    -484 -119
    -487 -121
    -489 -122
    -492 -124
    -495 -126
    -497 -128
    -499 -129
    -501 -131
    -503 -133
    -505 -135
    -507 -136
    -508 -138
    -510 -140
    -511 -142
    -512 -143
    -513 -145
    -514 -147
    -514 -148
    -515 -150
    -515 -152
    -515 -153
    -515 -155
    -515 -157
    -515 -158
    -514 -160
    -514 -162
    -513 -163
    -512 -165
    -511 -166
    -510 -168
    -508 -169
    -507 -171
    -505 -173
    -503 -174
    -502 -176
    -500 -177
    -497 -179
    -495 -180
    -493 -181
    -490 -183
    -487 -184
    -484 -186
    -481 -187
    -478 -189
    -475 -190
    -471 -191
    -468 -193
    -464 -194
    -460 -195
    -456 -197
    -452 -198
    -448 -199
    -444 -200
    -439 -202
    -435 -203
    -430 -204
    -425 -205
    -420 -207
    -415 -208
    -410 -209
    -405 -210
    -399 -211
    -394 -212
    -388 -213
    -383 -214
    -377 -215
    -371 -216
    -365 -217
    -359 -218
    -352 -219
    -346 -220
    -340 -221
    -333 -222
    -327 -223
    -320 -224
    -313 -225
    -306 -226
    -299 -226
    -292 -227
    -285 -228
    -278 -229
    -270 -229
    -263 -230
    -256 -231
    -248 -231
    -240 -232
    -233 -233
    -225 -233
    -217 -234
    -209 -235
    -201 -235
    -194 -236
    -185 -236
    -177 -237
    -169 -237
    -161 -237
    -153 -238
    -145 -238
    -136 -239
    -128 -239
    -120 -239
    -111 -240
    -103 -240
    -94 -240
    -86 -240
    -77 -241
    -69 -241
    -60 -241
    -52 -241
    -43 -241
    -34 -241
    -26 -241
    -17 -241
    -9 -242
    0 -242
    9 -242
    17 -241
    26 -241
    34 -241
    43 -241
    52 -241
    60 -241
    69 -241
    77 -241
    86 -240
    94 -240
    103 -240
    111 -240
    120 -239
    128 -239
    136 -239
    145 -238
    153 -238
    161 -237
    169 -237
    177 -237
    185 -236
    194 -236
    201 -235
    209 -235
    217 -234
    225 -233
    233 -233
    240 -232
    248 -231
    256 -231
    263 -230
    270 -229
    278 -229
    285 -228
    292 -227
    299 -226
    306 -226
    313 -225
    320 -224
    327 -223
    333 -222
    340 -221
    346 -220
    352 -219
    359 -218
    365 -217
    371 -216
    377 -215
    383 -214
    388 -213
    394 -212
    399 -211
    405 -210
    410 -209
    415 -208
    420 -207
    425 -205
    430 -204
    435 -203
    439 -202
    444 -200
    448 -199
    452 -198
    456 -197
    460 -195
    464 -194
    468 -193
    471 -191
    475 -190
    478 -189
    481 -187
    484 -186
    487 -184
    490 -183
    493 -181
    495 -180
    497 -179
    500 -177
    502 -176
    503 -174
    505 -173
    507 -171
    508 -169
    510 -168
    511 -166
    512 -165
    513 -163
    514 -162
    514 -160
    515 -158
    515 -157
    515 -155
    515 -153
    515 -152
    515 -150
    514 -148
    514 -147
    513 -145
    512 -143
    511 -142
    510 -140
    508 -138
    507 -136
    505 -135
    503 -133
    501 -131
    499 -129
    497 -128
    495 -126
    492 -124
    489 -122
    487 -121
    484 -119
    480 -117
    477 -115
    474 -113
    470 -112
    466 -110
    462 -108
    458 -106
    454 -104
    450 -102
    445 -101
    441 -99
    436 -97
    431 -95
    426 -93
    421 -91
    415 -89
    410 -88
    404 -86
    398 -84
    392 -82
    386 -80
    380 -78
    373 -76
    367 -74
    360 -73
    353 -71
    346 -69
    339 -67
    332 -65
    325 -63
    317 -61
    309 -59
    302 -57
    294 -56
    286 -54
    277 -52
    269 -50
    260 -48
    252 -46
    243 -44
    234 -42
    225 -40
    216 -39
    207 -37
    197 -35
    188 -33
    178 -31
    168 -29
    158 -27
    148 -25
    138 -23
    127 -21
    117 -20
    106 -18
    96 -16
    85 -14
    74 -12
    63 -10
    51 -8
    40 -6
    29 -5
    17 -3
    5 -1
    -7 1
    -18 3
    -31 5
    -43 7
    -55 8
    -67 10
    -80 12
    -93 14
    -105 16
    -118 18
    -131 20
    -144 21
    -158 23
    -171 25
    -185 27
    -198 29
    -212 31
    -226 32
    -239 34
    -253 36
    -268 38
    -282 40
    -296 41
    -310 43
    -325 45
    -340 47
    -354 49
    -369 50
    -384 52
    -399 54
    -414 56
    -430 58
    -445 59
    -460 61
    -476 63
    -492 65
    -507 66
    -523 68
    -539 70
    -555 72
    -571 73
    -587 75
    -604 77
    -620 79
    -637 80
    -653 82
    -670 84
    -687 85
    -704 87
    -721 89
    -738 91
    -755 92
    -772 94
    -789 96
    -807 97
    -824 99
    -842 101
    -859 102
    -877 104
    -895 106
    -913 107
    -931 109
    -949 111
    947 107
    929 105
    911 103
    893 102
    875 100
    858 99
    840 97
    822 95
    805 94
    788 92
    770 90
    753 89
    736 87
    719 86
    702 84
    685 82
    668 81
    652 79
    635 77
    618 76
    602 74
    586 72
    570 71
    553 69
    537 67
    521 65
    506 64
    490 62
    474 60
    459 59
    443 57
    428 55
    413 54
    397 52
    382 50
    367 48
    353 47
    338 45
    323 43
    309 41
    294 40
    280 38
    266 36
    252 34
    238 33
    224 31
    210 29
    196 27
    183 26
    169 24
    156 22
    143 20
    130 19
    117 17
    104 15
    91 13
    78 11
    66 10
    53 8
    41 6
    29 4
    17 3
    5 1
    -7 -1
    -19 -3
    -30 -5
    -42 -7
    -53 -8
    -65 -10
    -76 -12
    -87 -14
    -97 -16
    -108 -17
    -119 -19
    -129 -21
    -140 -23
    -150 -25
    -160 -26
    -170 -28
    -180 -30
    -189 -32
    -199 -34
    -208 -36
    -218 -37
    -227 -39
    -236 -41
    -245 -43
    -254 -45
    -262 -47
    -271 -48
    -279 -50
    -287 -52
    -296 -54
    -303 -56
    -311 -58
    -319 -59
    -326 -61
    -334 -63
    -341 -65
    -348 -67
    -355 -69
    -362 -70
    -369 -72
    -375 -74
    -382 -76
    -388 -78
    -394 -79
    -400 -81
    -406 -83
    -412 -85
    -417 -87
    -422 -88
    -428 -90
    -433 -92
    -438 -94
    -443 -96
    -447 -97
    -452 -99
    -456 -101
    -460 -103
    -464 -104
    -468 -106
    -472 -108
    -475 -110
    -479 -111
    -482 -113
    -485 -115
    -488 -117
    -491 -118
    -494 -120
    -496 -122
    -499 -124
    -501 -125
    -503 -127
    -505 -129
    -507 -130
    -509 -132
    -510 -134
    -511 -135
    -513 -137
    -514 -139
    -514 -140
    -515 -142
    -516 -144
    -516 -145
    -517 -147
    -517 -148
    -517 -150
    -516 -152
    -516 -153
    -516 -155
    -515 -156
    -514 -158
    -513 -159
    -512 -161
    -511 -162
    -510 -164
    -508 -165
    -507 -167
    -505 -168
    -503 -170
    -501 -171
    -499 -173
    -496 -174
    -494 -175
    -491 -177
    -489 -178
    -486 -180
    -483 -181
    -479 -182
    -476 -184
    -473 -185
    -469 -186
    -465 -188
    -462 -189
    -458 -190
    -454 -191
    -449 -193
    -445 -194
    -441 -195
    -436 -196
    -431 -197
    -426 -199
    -422 -200
    -416 -201
    -411 -202
    -406 -203
    -401 -204
    -395 -205
    -389 -206
    -384 -207
    -378 -208
    -372 -209
    -366 -210
    -360 -211
    -353 -212
    -347 -213
    -341 -214
    -334 -215
    -327 -216
    -321 -216
    -314 -217
    -307 -218
    -300 -219
    -293 -220
    -286 -220
    -278 -221
    -271 -222
    -264 -222
    -256 -223
    -249 -224
    -241 -224
    -233 -225
    -226 -226
    -218 -226
    -210 -227
    -202 -227
    -194 -228
    -186 -228
    -178 -229
    -170 -229
    -162 -230
    -153 -230
    -145 -230
    -137 -231
    -128 -231
    -120 -231
    -112 -232
    -103 -232
    -95 -232
    -86 -232
    -78 -233
    -69 -233
    -60 -233
    -52 -233
    -43 -233
    -35 -233
    -26 -233
    -17 -233
    -9 -233
    0 -233
    9 -233
    17 -233
    26 -233
    35 -233
    43 -233
    52 -233
    60 -233
    69 -233
    78 -233
    86 -232
    95 -232
    103 -232
    112 -232
    120 -231
    128 -231
    137 -231
    145 -230
    153 -230
    162 -230
    170 -229
    178 -229
    186 -228
    194 -228
    202 -227
    210 -227
    218 -226
    226 -226
    233 -225
    241 -224
    249 -224
    256 -223
    264 -222
    271 -222
    278 -221
    286 -220
    293 -220
    300 -219
    307 -218
    314 -217
    321 -216
    327 -216
    334 -215
    341 -214
    347 -213
    353 -212
    360 -211
    366 -210
    372 -209
    378 -208
    384 -207
    389 -206
    395 -205
    401 -204
    406 -203
    411 -202
    416 -201
    422 -200
    426 -199
    431 -197
    436 -196
    441 -195
    445 -194
    449 -193
    454 -191
    458 -190
    462 -189
    465 -188
    469 -186
    473 -185
    476 -184
    479 -182
    483 -181
    486 -180
    489 -178
    491 -177
    494 -175
    496 -174
    499 -173
    501 -171
    503 -170
    505 -168
    507 -167
    508 -165
    510 -164
    511 -162
    512 -161
    513 -159
    514 -158
    515 -156
    516 -155
    516 -153
    516 -152
    517 -150
    517 -148
    517 -147
    516 -145
    516 -144
    515 -142
    514 -140
    514 -139
    513 -137
    511 -135
    510 -134
    509 -132
    507 -130
    505 -129
    503 -127
    501 -125
    499 -124
    496 -122
    494 -120
    491 -118
    488 -117
    485 -115
    482 -113
    479 -111
    475 -110
    472 -108
    468 -106
    464 -104
    460 -103
    456 -101
    452 -99
    447 -97
    443 -96
    438 -94
    433 -92
    428 -90
    422 -88
    417 -87
    412 -85
    406 -83
    400 -81
    394 -79
    388 -78
    382 -76
    375 -74
    369 -72
    362 -70
    355 -69
    348 -67
    341 -65
    334 -63
    326 -61
    319 -59
    311 -58
    303 -56
    296 -54
    287 -52
    279 -50
    271 -48
    262 -47
    254 -45
    245 -43
    236 -41
    227 -39
    218 -37
    208 -36
    199 -34
    189 -32
    180 -30
    170 -28
    160 -26
    150 -25
    140 -23
    129 -21
    119 -19
    108 -17
    97 -16
    87 -14
    76 -12
    65 -10
    53 -8
    42 -7
    30 -5
    19 -3
    7 -1
    -5 1
    -17 3
    -29 4
    -41 6
    -53 8
    -66 10
    -78 11
    -91 13
    -104 15
    -117 17
    -130 19
    -143 20
    -156 22
    -169 24
    -183 26
    -196 27
    -210 29
    -224 31
    -238 33
    -252 34
    -266 36
    -280 38
    -294 40
    -309 41
    -323 43
    -338 45
    -353 47
    -367 48
    -382 50
    -397 52
    -413 54
    -428 55
    -443 57
    -459 59
    -474 60
    -490 62
    -506 64
    -521 65
    -537 67
    -553 69
    -570 71
    -586 72
    -602 74
    -618 76
    -635 77
    -652 79
    -668 81
    -685 82
    -702 84
    -719 86
    -736 87
    -753 89
    -770 90
    -788 92
    -805 94
    -822 95
    -840 97
    -858 99
    -875 100
    -893 102
    -911 103
    -929 105
    -947 107
    946 102
    928 101
    910 99
    892 98
    874 96
    856 95
    838 93
    821 92
    803 90
    786 88
    769 87
    751 85
    734 84
    717 82
    700 81
    683 79
    667 77
    650 76
    633 74
    617 73
    600 71
    584 69
    568 68
    552 66
    536 64
    520 63
    504 61
    488 60
    473 58
    457 56
    442 55
    426 53
    411 51
    396 50
    381 48
    366 46
    351 45
    336 43
    322 41
    307 40
    293 38
    278 36
    264 35
    250 33
    236 31
    222 30
    208 28
    195 26
    181 25
    168 23
    154 21
    141 19
    128 18
    115 16
    102 14
    89 13
    76 11
    64 9
    51 7
    39 6
    27 4
    15 2
    3 0
    -9 -1
    -21 -3
    -32 -5
    -44 -7
    -55 -8
    -66 -10
    -77 -12
    -88 -14
    -99 -15
    -110 -17
    -121 -19
    -131 -21
    -141 -22
    -152 -24
    -162 -26
    -172 -28
    -182 -29
    -191 -31
    -201 -33
    -210 -35
    -220 -36
    -229 -38
    -238 -40
    -247 -42
    -255 -43
    -264 -45
    -273 -47
    -281 -49
    -289 -50
    -297 -52
    -305 -54
    -313 -56
    -321 -58
    -328 -59
    -336 -61
    -343 -63
    -350 -65
    -357 -66
    -364 -68
    -371 -70
    -377 -72
    -383 -73
    -390 -75
    -396 -77
    -402 -79
    -408 -80
    -413 -82
    -419 -84
    -424 -85
    -429 -87
    -435 -89
    -439 -91
    -444 -92
    -449 -94
    -453 -96
    -458 -98
    -462 -99
    -466 -101
    -470 -103
    -474 -104
    -477 -106
    -481 -108
    -484 -109
    -487 -111
    -490 -113
    -493 -114
    -496 -116
    -498 -118
    -501 -119
    -503 -121
    -505 -123
    -507 -124
    -509 -126
    -510 -128
    -512 -129
    -513 -131
    -514 -132
    -515 -134
    -516 -136
    -517 -137
    -517 -139
    -518 -140
    -518 -142
    -518 -143
    -518 -145
    -518 -146
    -518 -148
    -517 -149
    -517 -151
    -516 -152
    -515 -154
    -514 -155
    -513 -157
    -511 -158
    -510 -160
    -508 -161
    -506 -163
    -504 -164
    -502 -165
    -500 -167
    -498 -168
    -495 -169
    -493 -171
    -490 -172
    -487 -173
    -484 -175
    -481 -176
    -477 -177
    -474 -179
    -470 -180
    -467 -181
    -463 -182
    -459 -184
    -455 -185
    -451 -186
    -446 -187
    -442 -188
    -437 -189
    -432 -191
    -428 -192
    -423 -193
    -418 -194
    -412 -195
    -407 -196
    -402 -197
    -396 -198
    -390 -199
    -385 -200
    -379 -201
    -373 -202
    -367 -203
    -361 -204
    -354 -205
    -348 -206
    -341 -206
    -335 -207
    -328 -208
    -321 -209
    -315 -210
    -308 -211
    -301 -211
    -294 -212
    -286 -213
    -279 -213
    -272 -214
    -264 -215
    -257 -215
    -249 -216
    -242 -217
    -234 -217
    -226 -218
    -218 -218
    -210 -219
    -203 -219
    -195 -220
    -186 -220
    -178 -221
    -170 -221
    -162 -222
    -154 -222
    -145 -222
    -137 -223
    -129 -223
    -120 -223
    -112 -224
    -103 -224
    -95 -224
    -86 -224
    -78 -225
    -69 -225
    -61 -225
    -52 -225
    -43 -225
    -35 -225
    -26 -225
    -17 -225
    -9 -225
    0 -225
    9 -225
    17 -225
    26 -225
    35 -225
    43 -225
    52 -225
    61 -225
    69 -225
    78 -225
    86 -224
    95 -224
    103 -224
    112 -224
    120 -223
    129 -223
    137 -223
    145 -222
    154 -222
    162 -222
    170 -221
    178 -221
    186 -220
    195 -220
    203 -219
    210 -219
    218 -218
    226 -218
    234 -217
    242 -217
    249 -216
    257 -215
    264 -215
    272 -214
    279 -213
    286 -213
    294 -212
    301 -211
    308 -211
    315 -210
    321 -209
    328 -208
    335 -207
    341 -206
    348 -206
    354 -205
    361 -204
    367 -203
    373 -202
    379 -201
    385 -200
    390 -199
    396 -198
    402 -197
    407 -196
    412 -195
    418 -194
    423 -193
    428 -192
    432 -191
    437 -189
    442 -188
    446 -187
    451 -186
    455 -185
    459 -184
    463 -182
    467 -181
    470 -180
    474 -179
    477 -177
    481 -176
    484 -175
    487 -173
    490 -172
    493 -171
    495 -169
    498 -168
    500 -167
    502 -165
    504 -164
    506 -163
    508 -161
    510 -160
    511 -158
    513 -157
    514 -155
    515 -154
    516 -152
    517 -151
    517 -149
    518 -148
    518 -146
    518 -145
    518 -143
    518 -142
    518 -140
    517 -139
    517 -137
    516 -136
    515 -134
    514 -132
    513 -131
    512 -129
    510 -128
    509 -126
    507 -124
    505 -123
    503 -121
    501 -119
    498 -118
    496 -116
    493 -114
    490 -113
    487 -111
    484 -109
    481 -108
    477 -106
    474 -104
    470 -103
    466 -101
    462 -99
    458 -98
    453 -96
    449 -94
    444 -92
    439 -91
    435 -89
    429 -87
    424 -85
    419 -84
    413 -82
    408 -80
    402 -79
    396 -77
    390 -75
    383 -73
    377 -72
    371 -70
    364 -68
    357 -66
    350 -65
    343 -63
    336 -61
    328 -59
    321 -58
    313 -56
    305 -54
    297 -52
    289 -50
    281 -49
    273 -47
    264 -45
    255 -43
    247 -42
    238 -40
    229 -38
    220 -36
    210 -35
    201 -33
    191 -31
    182 -29
    172 -28
    162 -26
    152 -24
    141 -22
    131 -21
    121 -19
    110 -17
    99 -15
    88 -14
    77 -12
    66 -10
    55 -8
    44 -7
    32 -5
    21 -3
    9 -1
    -3 0
    -15 2
    -27 4
    -39 6
    -51 7
    -64 9
    -76 11
    -89 13
    -102 14
    -115 16
    -128 18
    -141 19
    -154 21
    -168 23
    -181 25
    -195 26
    -208 28
    -222 30
    -236 31
    -250 33
    -264 35
    -278 36
    -293 38
    -307 40
    -322 41
    -336 43
    -351 45
    -366 46
    -381 48
    -396 50
    -411 51
    -426 53
    -442 55
    -457 56
    -473 58
    -488 60
    -504 61
    -520 63
    -536 64
    -552 66
    -568 68
    -584 69
    -600 71
    -617 73
    -633 74
    -650 76
    -667 77
    -683 79
    -700 81
    -717 82
    -734 84
    -751 85
    -769 87
    -786 88
    -803 90
    -821 92
    -838 93
    -856 95
    -874 96
    -892 98
    -910 99
    -928 101
    -946 102
    944 98
    926 97
    908 95
    890 94
    872 92
    855 91
    837 89
    819 88
    802 86
    784 85
    767 83
    750 82
    733 80
    716 79
    699 77
    682 76
    665 74
    648 73
    632 71
    615 70
    599 68
    583 66
    566 65
    550 63
    534 62
    518 60
    502 59
    487 57
    471 56
    455 54
    440 52
    425 51
    409 49
    394 48
    379 46
    364 44
    349 43
    335 41
    320 40
    305 38
    291 36
    277 35
    262 33
    248 32
    234 30
    220 28
    207 27
    193 25
    179 23
    166 22
    152 20
    139 18
    126 17
    113 15
    100 13
    87 12
    75 10
    62 8
    50 7
    37 5
    25 4
    13 2
    1 0
    -11 -2
    -22 -3
    -34 -5
    -45 -7
    -57 -8
    -68 -10
    -79 -12
    -90 -13
    -101 -15
    -112 -17
    -122 -18
    -133 -20
    -143 -22
    -153 -23
    -163 -25
    -173 -27
    -183 -28
    -193 -30
    -203 -32
    -212 -34
    -221 -35
    -230 -37
    -240 -39
    -248 -40
    -257 -42
    -266 -44
    -274 -45
    -283 -47
    -291 -49
    -299 -51
    -307 -52
    -315 -54
    -322 -56
    -330 -57
    -337 -59
    -345 -61
    -352 -62
    -359 -64
    -366 -66
    -372 -67
    -379 -69
    -385 -71
    -391 -72
    -398 -74
    -404 -76
    -409 -78
    -415 -79
    -421 -81
    -426 -83
    -431 -84
    -436 -86
    -441 -88
    -446 -89
    -451 -91
    -455 -92
    -459 -94
    -464 -96
    -468 -97
    -472 -99
    -475 -101
    -479 -102
    -482 -104
    -486 -106
    -489 -107
    -492 -109
    -495 -110
    -497 -112
    -500 -114
    -502 -115
    -504 -117
    -506 -118
    -508 -120
    -510 -121
    -512 -123
    -513 -125
    -515 -126
    -516 -128
    -517 -129
    -518 -131
    -518 -132
    -519 -134
    -519 -135
    -520 -137
    -520 -138
    -520 -140
    -520 -141
    -519 -143
    -519 -144
    -518 -146
    -517 -147
    -516 -148
    -515 -150
    -514 -151
    -513 -153
    -511 -154
    -510 -155
    -508 -157
    -506 -158
    -504 -159
    -502 -161
    -499 -162
    -497 -163
    -494 -165
    -491 -166
    -488 -167
    -485 -168
    -482 -170
    -479 -171
    -475 -172
    -472 -173
    -468 -175
    -464 -176
    -460 -177
    -456 -178
    -452 -179
    -447 -180
    -443 -182
    -438 -183
    -434 -184
    -429 -185
    -424 -186
    -419 -187
    -413 -188
    -408 -189
    -403 -190
    -397 -191
    -391 -192
    -386 -193
    -380 -194
    -374 -195
    -368 -196
    -361 -196
    -355 -197
    -349 -198
    -342 -199
    -336 -200
    -329 -201
    -322 -201
    -315 -202
    -308 -203
    -301 -204
    -294 -204
    -287 -205
    -280 -206
    -272 -206
    -265 -207
    -257 -208
    -250 -208
    -242 -209
    -235 -209
    -227 -210
    -219 -210
    -211 -211
    -203 -211
    -195 -212
    -187 -212
    -179 -213
    -171 -213
    -162 -214
    -154 -214
    -146 -214
    -137 -215
    -129 -215
    -121 -215
    -112 -216
    -104 -216
    -95 -216
    -86 -216
    -78 -216
    -69 -217
    -61 -217
    -52 -217
    -43 -217
    -35 -217
    -26 -217
    -17 -217
    -9 -217
    0 -217
    9 -217
    17 -217
    26 -217
    35 -217
    43 -217
    52 -217
    61 -217
    69 -217
    78 -216
    86 -216
    95 -216
    104 -216
    112 -216
    121 -215
    129 -215
    137 -215
    146 -214
    154 -214
    162 -214
    171 -213
    179 -213
    187 -212
    195 -212
    203 -211
    211 -211
    219 -210
    227 -210
    235 -209
    242 -209
    250 -208
    257 -208
    265 -207
    272 -206
    280 -206
    287 -205
    294 -204
    301 -204
    308 -203
    315 -202
    322 -201
    329 -201
    336 -200
    342 -199
    349 -198
    355 -197
    361 -196
    368 -196
    374 -195
    380 -194
    386 -193
    391 -192
    397 -191
    403 -190
    408 -189
    413 -188
    419 -187
    424 -186
    429 -185
    434 -184
    438 -183
    443 -182
    447 -180
    452 -179
    456 -178
    460 -177
    464 -176
    468 -175
    472 -173
    475 -172
    479 -171
    482 -170
    485 -168
    488 -167
    491 -166
    494 -165
    497 -163
    499 -162
    502 -161
    504 -159
    506 -158
    508 -157
    510 -155
    511 -154
    513 -153
    514 -151
    515 -150
    516 -148
    517 -147
    518 -146
    519 -144
    519 -143
    520 -141
    520 -140
    520 -138
    520 -137
    519 -135
    519 -134
    518 -132
    518 -131
    517 -129
    516 -128
    515 -126
    513 -125
    512 -123
    510 -121
    508 -120
    506 -118
    504 -117
    502 -115
    500 -114
    497 -112
    495 -110
    492 -109
    489 -107
    486 -106
    482 -104
    479 -102
    475 -101
    472 -99
    468 -97
    464 -96
    459 -94
    455 -92
    451 -91
    446 -89
    441 -88
    436 -86
    431 -84
    426 -83
    421 -81
    415 -79
    409 -78
    404 -76
    398 -74
    391 -72
    385 -71
    379 -69
    372 -67
    366 -66
    359 -64
    352 -62
    345 -61
    337 -59
    330 -57
    322 -56
    315 -54
    307 -52
    299 -51
    291 -49
    283 -47
    274 -45
    266 -44
    257 -42
    248 -40
    240 -39
    230 -37
    221 -35
    212 -34
    203 -32
    193 -30
    183 -28
    173 -27
    163 -25
    153 -23
    143 -22
    133 -20
    122 -18
    112 -17
    101 -15
    90 -13
    79 -12
    68 -10
    57 -8
    45 -7
    34 -5
    22 -3
    11 -2
    -1 0
    -13 2
    -25 4
    -37 5
    -50 7
    -62 8
    -75 10
    -87 12
    -100 13
    -113 15
    -126 17
    -139 18
    -152 20
    -166 22
    -179 23
    -193 25
    -207 27
    -220 28
    -234 30
    -248 32
    -262 33
    -277 35
    -291 36
    -305 38
    -320 40
    -335 41
    -349 43
    -364 44
    -379 46
    -394 48
    -409 49
    -425 51
    -440 52
    -455 54
    -471 56
    -487 57
    -502 59
    -518 60
    -534 62
    -550 63
    -566 65
    -583 66
    -599 68
    -615 70
    -632 71
    -648 73
    -665 74
    -682 76
    -699 77
    -716 79
    -733 80
    -750 82
    -767 83
    -784 85
    -802 86
    -819 88
    -837 89
    -855 91
    -872 92
    -890 94
    -908 95
    -926 97
    -944 98
    943 94
    925 93
    907 91
    889 90
    871 89
    853 87
    835 86
    818 84
    800 83
    783 81
    766 80
    748 78
    731 77
    714 76
    697 74
    680 73
    664 71
    647 70
    630 68
    614 67
    597 65
    581 64
    565 62
    549 61
    533 59
    517 58
    501 56
    485 55
    469 53
    454 52
    438 50
    423 49
    408 47
    393 46
    378 44
    363 42
    348 41
    333 39
    318 38
    304 36
    289 35
    275 33
    261 32
    247 30
    233 28
    219 27
    205 25
    191 24
    178 22
    164 21
    151 19
    138 17
    125 16
    111 14
    99 13
    86 11
    73 10
    61 8
    48 6
    36 5
    24 3
    12 2
    -0 -0
    -12 -2
    -24 -3
    -36 -5
    -47 -6
    -58 -8
    -70 -10
    -81 -11
    -92 -13
    -103 -15
    -113 -16
    -124 -18
    -134 -19
    -145 -21
    -155 -23
    -165 -24
    -175 -26
    -185 -28
    -195 -29
    -204 -31
    -214 -32
    -223 -34
    -232 -36
    -241 -37
    -250 -39
    -259 -41
    -268 -42
    -276 -44
    -284 -46
    -293 -47
    -301 -49
    -309 -50
    -316 -52
    -324 -54
    -332 -55
    -339 -57
    -346 -59
    -353 -60
    -360 -62
    -367 -63
    -374 -65
    -380 -67
    -387 -68
    -393 -70
    -399 -71
    -405 -73
    -411 -75
    -417 -76
    -422 -78
    -428 -80
    -433 -81
    -438 -83
    -443 -84
    -448 -86
    -452 -88
    -457 -89
    -461 -91
    -465 -92
    -469 -94
    -473 -95
    -477 -97
    -480 -99
    -484 -100
    -487 -102
    -490 -103
    -493 -105
    -496 -106
    -499 -108
    -501 -109
    -504 -111
    -506 -112
    -508 -114
    -510 -115
    -512 -117
    -513 -118
    -515 -120
    -516 -121
    -517 -123
    -518 -124
    -519 -126
    -520 -127
    -520 -129
    -521 -130
    -521 -132
    -521 -133
    -521 -134
    -521 -136
    -521 -137
    -520 -139
    -519 -140
    -519 -141
    -518 -143
    -517 -144
    -515 -146
    -514 -147
    -513 -148
    -511 -150
    -509 -151
    -507 -152
    -505 -153
    -503 -155
    -500 -156
    -498 -157
    -495 -158
    -492 -160
    -490 -161
    -486 -162
    -483 -163
    -480 -165
    -476 -166
    -473 -167
    -469 -168
    -465 -169
    -461 -170
    -457 -171
    -453 -173
    -448 -174
    -444 -175
    -439 -176
    -435 -177
    -430 -178
    -425 -179
    -420 -180
    -414 -181
    -409 -182
    -404 -183
    -398 -184
    -392 -185
    -387 -186
    -381 -186
    -375 -187
    -369 -188
    -362 -189
    -356 -190
    -350 -191
    -343 -191
    -336 -192
    -330 -193
    -323 -194
    -316 -195
    -309 -195
    -302 -196
    -295 -197
    -288 -197
    -280 -198
    -273 -199
    -266 -199
    -258 -200
    -250 -200
    -243 -201
    -235 -201
    -227 -202
    -219 -203
    -211 -203
    -203 -203
    -195 -204
    -187 -204
    -179 -205
    -171 -205
    -163 -206
    -154 -206
    -146 -206
    -138 -207
    -129 -207
    -121 -207
    -112 -207
    -104 -208
    -95 -208
    -87 -208
    -78 -208
    -69 -208
    -61 -209
    -52 -209
    -43 -209
    -35 -209
    -26 -209
    -17 -209
    -9 -209
    0 -209
    9 -209
    17 -209
    26 -209
    35 -209
    43 -209
    52 -209
    61 -209
    69 -208
    78 -208
    87 -208
    95 -208
    104 -208
    112 -207
    121 -207
    129 -207
    138 -207
    146 -206
    154 -206
    163 -206
    171 -205
    179 -205
    187 -204
    195 -204
    203 -203
    211 -203
    219 -203
    227 -202
    235 -201
    243 -201
    250 -200
    258 -200
    266 -199
    273 -199
    280 -198
    288 -197
    295 -197
    302 -196
    309 -195
    316 -195
    323 -194
    330 -193
    336 -192
    343 -191
    350 -191
    356 -190
    362 -189
    369 -188
    375 -187
    381 -186
    387 -186
    392 -185
    398 -184
    404 -183
    409 -182
    414 -181
    420 -180
    425 -179
    430 -178
    435 -177
    439 -176
    444 -175
    448 -174
    453 -173
    457 -171
    461 -170
    465 -169
    469 -168
    473 -167
    476 -166
    480 -165
    483 -163
    486 -162
    490 -161
    492 -160
    495 -158
    498 -157
    500 -156
    503 -155
    505 -153
    507 -152
    509 -151
    511 -150
    513 -148
    514 -147
    515 -146
    517 -144
    518 -143
    519 -141
    519 -140
    520 -139
    521 -137
    521 -136
    521 -134
    521 -133
    521 -132
    521 -130
    520 -129
    520 -127
    519 -126
    518 -124
    517 -123
    516 -121
    515 -120
    513 -118
    512 -117
    510 -115
    508 -114
    506 -112
    504 -111
    501 -109
    499 -108
    496 -106
    493 -105
    490 -103
    487 -102
    484 -100
    480 -99
    477 -97
    473 -95
    469 -94
    465 -92
    461 -91
    457 -89
    452 -88
    448 -86
    443 -84
    438 -83
    433 -81
    428 -80
    422 -78
    417 -76
    411 -75
    405 -73
    399 -71
    393 -70
    387 -68
    380 -67
    374 -65
    367 -63
    360 -62
    353 -60
    346 -59
    339 -57
    332 -55
    324 -54
    316 -52
    309 -50
    301 -49
    293 -47
    284 -46
    276 -44
    268 -42
    259 -41
    250 -39
    241 -37
    232 -36
    223 -34
    214 -32
    204 -31
    195 -29
    185 -28
    175 -26
    165 -24
    155 -23
    145 -21
    134 -19
    124 -18
    113 -16
    103 -15
    92 -13
    81 -11
    70 -10
    58 -8
    47 -6
    36 -5
    24 -3
    12 -2
    0 -0
    -12 2
    -24 3
    -36 5
    -48 6
    -61 8
    -73 10
    -86 11
    -99 13
    -111 14
    -125 16
    -138 17
    -151 19
    -164 21
    -178 22
    -191 24
    -205 25
    -219 27
    -233 28
    -247 30
    -261 32
    -275 33
    -289 35
    -304 36
    -318 38
    -333 39
    -348 41
    -363 42
    -378 44
    -393 46
    -408 47
    -423 49
    -438 50
    -454 52
    -469 53
    -485 55
    -501 56
    -517 58
    -533 59
    -549 61
    -565 62
    -581 64
    -597 65
    -614 67
    -630 68
    -647 70
    -664 71
    -680 73
    -697 74
    -714 76
    -731 77
    -748 78
    -766 80
    -783 81
    -800 83
    -818 84
    -835 86
    -853 87
    -871 89
    -889 90
    -907 91
    -925 93
    -943 94
    941 90
    923 89
    905 87
    887 86
    869 85
    852 83
    834 82
    816 81
    799 79
    782 78
    764 76
    747 75
    730 74
    713 72
    696 71
    679 69
    662 68
    645 67
    629 65
    612 64
    596 62
    580 61
    563 59
    547 58
    531 57
    515 55
    499 54
    484 52
    468 51
    452 49
    437 48
    422 46
    406 45
    391 43
    376 42
    361 41
    346 39
    331 38
    317 36
    302 35
    288 33
    273 32
    259 30
    245 29
    231 27
    217 26
    203 24
    190 23
    176 21
    163 20
    149 18
    136 17
    123 15
    110 14
    97 12
    84 10
    72 9
    59 7
    47 6
    34 4
    22 3
    10 1
    -2 -0
    -14 -2
    -26 -3
    -37 -5
    -49 -6
    -60 -8
    -71 -10
    -82 -11
    -93 -13
    -104 -14
    -115 -16
    -126 -17
    -136 -19
    -146 -20
    -157 -22
    -167 -24
    -177 -25
    -187 -27
    -196 -28
    -206 -30
    -215 -31
    -225 -33
    -234 -34
    -243 -36
    -252 -38
    -260 -39
    -269 -41
    -278 -42
    -286 -44
    -294 -45
    -302 -47
    -310 -49
    -318 -50
    -326 -52
    -333 -53
    -341 -55
    -348 -56
    -355 -58
    -362 -59
    -369 -61
    -375 -63
    -382 -64
    -388 -66
    -395 -67
    -401 -69
    -407 -70
    -413 -72
    -418 -73
    -424 -75
    -429 -77
    -434 -78
    -439 -80
    -444 -81
    -449 -83
    -454 -84
    -458 -86
    -463 -87
    -467 -89
    -471 -90
    -475 -92
    -478 -93
    -482 -95
    -485 -96
    -489 -98
    -492 -99
    -495 -101
    -498 -102
    -500 -104
    -503 -105
    -505 -107
    -507 -108
    -509 -110
    -511 -111
    -513 -112
    -515 -114
    -516 -115
    -518 -117
    -519 -118
    -520 -120
    -521 -121
    -521 -122
    -522 -124
    -522 -125
    -522 -126
    -523 -128
    -523 -129
    -522 -131
    -522 -132
    -521 -133
    -521 -135
    -520 -136
    -519 -137
    -518 -139
    -517 -140
    -515 -141
    -514 -142
    -512 -144
    -510 -145
    -508 -146
    -506 -147
    -504 -149
    -502 -150
    -499 -151
    -497 -152
    -494 -153
    -491 -155
    -488 -156
    -484 -157
    -481 -158
    -478 -159
    -474 -160
    -470 -161
    -466 -163
    -462 -164
    -458 -165
    -454 -166
    -450 -167
    -445 -168
    -440 -169
    -436 -170
    -431 -171
    -426 -172
    -421 -173
    -415 -174
    -410 -175
    -405 -176
    -399 -176
    -393 -177
    -387 -178
    -382 -179
    -376 -180
    -369 -181
    -363 -182
    -357 -182
    -350 -183
    -344 -184
    -337 -185
    -331 -185
    -324 -186
    -317 -187
    -310 -188
    -303 -188
    -296 -189
    -288 -190
    -281 -190
    -274 -191
    -266 -191
    -259 -192
    -251 -192
    -243 -193
    -236 -194
    -228 -194
    -220 -195
    -212 -195
    -204 -195
    -196 -196
    -188 -196
    -180 -197
    -171 -197
    -163 -197
    -155 -198
    -146 -198
    -138 -198
    -130 -199
    -121 -199
    -113 -199
    -104 -199
    -95 -200
    -87 -200
    -78 -200
    -70 -200
    -61 -200
    -52 -200
    -44 -201
    -35 -201
    -26 -201
    -17 -201
    -9 -201
    0 -201
    9 -201
    17 -201
    26 -201
    35 -201
    44 -201
    52 -200
    61 -200
    70 -200
    78 -200
    87 -200
    95 -200
    104 -199
    113 -199
    121 -199
    130 -199
    138 -198
    146 -198
    155 -198
    163 -197
    171 -197
    180 -197
    188 -196
    196 -196
    204 -195
    212 -195
    220 -195
    228 -194
    236 -194
    243 -193
    251 -192
    259 -192
    266 -191
    274 -191
    281 -190
    288 -190
    296 -189
    303 -188
    310 -188
    317 -187
    324 -186
    331 -185
    337 -185
    344 -184
    350 -183
    357 -182
    363 -182
    369 -181
    376 -180
    382 -179
    387 -178
    393 -177
    399 -176
    405 -176
    410 -175
    415 -174
    421 -173
    426 -172
    431 -171
    436 -170
    440 -169
    445 -168
    450 -167
    454 -166
    458 -165
    462 -164
    466 -163
    470 -161
    474 -160
    478 -159
    481 -158
    484 -157
    488 -156
    491 -155
    494 -153
    497 -152
    499 -151
    502 -150
    504 -149
    506 -147
    508 -146
    510 -145
    512 -144
    514 -142
    515 -141
    517 -140
    518 -139
    519 -137
    520 -136
    521 -135
    521 -133
    522 -132
    522 -131
    523 -129
    523 -128
    522 -126
    522 -125
    522 -124
    521 -122
    521 -121
    520 -120
    519 -118
    518 -117
    516 -115
    515 -114
    513 -112
    511 -111
    509 -110
    507 -108
    505 -107
    503 -105
    500 -104
    498 -102
    495 -101
    492 -99
    489 -98
    485 -96
    482 -95
    478 -93
    475 -92
    471 -90
    467 -89
    463 -87
    458 -86
    454 -84
    449 -83
    444 -81
    439 -80
    434 -78
    429 -77
    424 -75
    418 -73
    413 -72
    407 -70
    401 -69
    395 -67
    388 -66
    382 -64
    375 -63
    369 -61
    362 -59
    355 -58
    348 -56
    341 -55
    333 -53
    326 -52
    318 -50
    310 -49
    302 -47
    294 -45
    286 -44
    278 -42
    269 -41
    260 -39
    252 -38
    243 -36
    234 -34
    225 -33
    215 -31
    206 -30
    196 -28
    187 -27
    177 -25
    167 -24
    157 -22
    146 -20
    136 -19
    126 -17
    115 -16
    104 -14
    93 -13
    82 -11
    71 -10
    60 -8
    49 -6
    37 -5
    26 -3
    14 -2
    2 -0
    -10 1
    -22 3
    -34 4
    -47 6
    -59 7
    -72 9
    -84 10
    -97 12
    -110 14
    -123 15
    -136 17
    -149 18
    -163 20
    -176 21
    -190 23
    -203 24
    -217 26
    -231 27
    -245 29
    -259 30
    -273 32
    -288 33
    -302 35
    -317 36
    -331 38
    -346 39
    -361 41
    -376 42
    -391 43
    -406 45
    -422 46
    -437 48
    -452 49
    -468 51
    -484 52
    -499 54
    -515 55
    -531 57
    -547 58
    -563 59
    -580 61
    -596 62
    -612 64
    -629 65
    -645 67
    -662 68
    -679 69
    -696 71
    -713 72
    -730 74
    -747 75
    -764 76
    -782 78
    -799 79
    -816 81
    -834 82
    -852 83
    -869 85
    -887 86
    -905 87
    -923 89
    -941 90
    940 86
    922 85
    904 84
    886 82
    868 81
    850 80
    833 78
    815 77
    798 76
    780 74
    763 73
    746 72
    728 70
    711 69
    694 68
    678 66
    661 65
    644 64
    627 62
    611 61
    594 59
    578 58
    562 57
    546 55
    530 54
    514 53
    498 51
    482 50
    466 48
    451 47
    435 46
    420 44
    405 43
    390 41
    375 40
    360 39
    345 37
    330 36
    315 34
    301 33
    286 31
    272 30
    258 29
    244 27
    230 26
    216 24
    202 23
    188 21
    175 20
    161 19
    148 17
    135 16
    121 14
    108 13
    96 11
    83 10
    70 8
    58 7
    45 5
    33 4
    21 3
    8 1
    -4 -0
    -15 -2
    -27 -3
    -39 -5
    -50 -6
    -62 -8
    -73 -9
    -84 -11
    -95 -12
    -106 -14
    -116 -15
    -127 -17
    -138 -18
    -148 -20
    -158 -21
    -168 -23
    -178 -24
    -188 -26
    -198 -27
    -207 -29
    -217 -30
    -226 -32
    -235 -33
    -244 -35
    -253 -36
    -262 -38
    -271 -39
    -279 -41
    -288 -42
    -296 -44
    -304 -45
    -312 -47
    -320 -48
    -327 -50
    -335 -51
    -342 -53
    -349 -54
    -357 -56
    -364 -57
    -370 -59
    -377 -60
    -384 -62
    -390 -63
    -396 -65
    -402 -66
    -408 -68
    -414 -69
    -420 -70
    -425 -72
    -431 -73
    -436 -75
    -441 -76
    -446 -78
    -451 -79
    -455 -81
    -460 -82
    -464 -84
    -468 -85
    -472 -87
    -476 -88
    -480 -89
    -483 -91
    -487 -92
    -490 -94
    -493 -95
    -496 -97
    -499 -98
    -502 -99
    -504 -101
    -507 -102
    -509 -104
    -511 -105
    -513 -106
    -515 -108
    -516 -109
    -518 -111
    -519 -112
    -520 -113
    -521 -115
    -522 -116
    -523 -117
    -523 -119
    -524 -120
    -524 -121
    -524 -123
    -524 -124
    -524 -125
    -523 -127
    -523 -128
    -522 -129
    -521 -130
    -520 -132
    -519 -133
    -518 -134
    -517 -135
    -515 -137
    -513 -138
    -512 -139
    -510 -140
    -508 -141
    -505 -143
    -503 -144
    -500 -145
    -498 -146
    -495 -147
    -492 -148
    -489 -149
    -486 -150
    -482 -152
    -479 -153
    -475 -154
    -471 -155
    -467 -156
    -463 -157
    -459 -158
    -455 -159
    -451 -160
    -446 -161
    -441 -162
    -437 -163
    -432 -164
    -427 -165
    -422 -166
    -416 -167
    -411 -167
    -405 -168
    -400 -169
    -394 -170
    -388 -171
    -382 -172
    -376 -172
    -370 -173
    -364 -174
    -358 -175
    -351 -176
    -345 -176
    -338 -177
    -331 -178
    -324 -178
    -318 -179
    -311 -180
    -303 -180
    -296 -181
    -289 -182
    -282 -182
    -274 -183
    -267 -183
    -259 -184
    -252 -184
    -244 -185
    -236 -185
    -228 -186
    -220 -186
    -212 -187
    -204 -187
    -196 -188
    -188 -188
    -180 -189
    -172 -189
    -163 -189
    -155 -190
    -147 -190
    -138 -190
    -130 -190
    -121 -191
    -113 -191
    -104 -191
    -96 -191
    -87 -192
    -78 -192
    -70 -192
    -61 -192
    -52 -192
    -44 -192
    -35 -192
    -26 -192
    -17 -192
    -9 -192
    0 -192
    9 -192
    17 -192
    26 -192
    35 -192
    44 -192
    52 -192
    61 -192
    70 -192
    78 -192
    87 -192
    96 -191
    104 -191
    113 -191
    121 -191
    130 -190
    138 -190
    147 -190
    155 -190
    163 -189
    172 -189
    180 -189
    188 -188
    196 -188
    204 -187
    212 -187
    220 -186
    228 -186
    236 -185
    244 -185
    252 -184
    259 -184
    267 -183
    274 -183
    282 -182
    289 -182
    296 -181
    303 -180
    311 -180
    318 -179
    324 -178
    331 -178
    338 -177
    345 -176
    351 -176
    358 -175
    364 -174
    370 -173
    376 -172
    382 -172
    388 -171
    394 -170
    400 -169
    405 -168
    411 -167
    416 -167
    422 -166
    427 -165
    432 -164
    437 -163
    441 -162
    446 -161
    451 -160
    455 -159
    459 -158
    463 -157
    467 -156
    471 -155
    475 -154
    479 -153
    482 -152
    486 -150
    489 -149
    492 -148
    495 -147
    498 -146
    500 -145
    503 -144
    505 -143
    508 -141
    510 -140
    512 -139
    513 -138
    515 -137
    517 -135
    518 -134
    519 -133
    520 -132
    521 -130
    522 -129
    523 -128
    523 -127
    524 -125
    524 -124
    524 -123
    524 -121
    524 -120
    523 -119
    523 -117
    522 -116
    521 -115
    520 -113
    519 -112
    518 -111
    516 -109
    515 -108
    513 -106
    511 -105
    509 -104
    507 -102
    504 -101
    502 -99
    499 -98
    496 -97
    493 -95
    490 -94
    487 -92
    483 -91
    480 -89
    476 -88
    472 -87
    468 -85
    464 -84
    460 -82
    455 -81
    451 -79
    446 -78
    441 -76
    436 -75
    431 -73
    425 -72
    420 -70
    414 -69
    408 -68
    402 -66
    396 -65
    390 -63
    384 -62
    377 -60
    370 -59
    364 -57
    357 -56
    349 -54
    342 -53
    335 -51
    327 -50
    320 -48
    312 -47
    304 -45
    296 -44
    288 -42
    279 -41
    271 -39
    262 -38
    253 -36
    244 -35
    235 -33
    226 -32
    217 -30
    207 -29
    198 -27
    188 -26
    178 -24
    168 -23
    158 -21
    148 -20
    138 -18
    127 -17
    116 -15
    106 -14
    95 -12
    84 -11
    73 -9
    62 -8
    50 -6
    39 -5
    27 -3
    15 -2
    4 -0
    -8 1
    -21 3
    -33 4
    -45 5
    -58 7
    -70 8
    -83 10
    -96 11
    -108 13
    -121 14
    -135 16
    -148 17
    -161 19
    -175 20
    -188 21
    -202 23
    -216 24
    -230 26
    -244 27
    -258 29
    -272 30
    -286 31
    -301 33
    -315 34
    -330 36
    -345 37
    -360 39
    -375 40
    -390 41
    -405 43
    -420 44
    -435 46
    -451 47
    -466 48
    -482 50
    -498 51
    -514 53
    -530 54
    -546 55
    -562 57
    -578 58
    -594 59
    -611 61
    -627 62
    -644 64
    -661 65
    -678 66
    -694 68
    -711 69
    -728 70
    -746 72
    -763 73
    -780 74
    -798 76
    -815 77
    -833 78
    -850 80
    -868 81
    -886 82
    -904 84
    -922 85
    -940 86
    939 82
    921 81
    903 80
    885 78
    867 77
    849 76
    831 75
    814 73
    796 72
    779 71
    762 70
    744 68
    727 67
    710 66
    693 64
    676 63
    659 62
    643 61
    626 59
    610 58
    593 57
    577 55
    561 54
    544 53
    528 51
    512 50
    497 49
    481 47
    465 46
    450 45
    434 43
    419 42
    403 41
    388 39
    373 38
    358 37
    343 35
    329 34
    314 33
    299 31
    285 30
    271 29
    256 27
    242 26
    228 24
    214 23
    201 22
    187 20
    173 19
    160 18
    146 16
    133 15
    120 13
    107 12
    94 11
    81 9
    69 8
    56 6
    44 5
    31 4
    19 2
    7 1
    -5 -1
    -17 -2
    -29 -3
    -40 -5
    -52 -6
    -63 -8
    -74 -9
    -85 -10
    -96 -12
    -107 -13
    -118 -15
    -129 -16
    -139 -18
    -149 -19
    -160 -20
    -170 -22
    -180 -23
    -190 -25
    -199 -26
    -209 -28
    -218 -29
    -228 -30
    -237 -32
    -246 -33
    -255 -35
    -263 -36
    -272 -38
    -281 -39
    -289 -40
    -297 -42
    -305 -43
    -313 -45
    -321 -46
    -329 -48
    -336 -49
    -344 -50
    -351 -52
    -358 -53
    -365 -55
    -372 -56
    -378 -58
    -385 -59
    -391 -60
    -398 -62
    -404 -63
    -410 -65
    -416 -66
    -421 -68
    -427 -69
    -432 -70
    -437 -72
    -442 -73
    -447 -75
    -452 -76
    -457 -77
    -461 -79
    -465 -80
    -470 -82
    -474 -83
    -478 -84
    -481 -86
    -485 -87
    -488 -88
    -492 -90
    -495 -91
    -498 -92
    -500 -94
    -503 -95
    -506 -97
    -508 -98
    -510 -99
    -512 -101
    -514 -102
    -516 -103
    -518 -105
    -519 -106
    -520 -107
    -521 -108
    -522 -110
    -523 -111
    -524 -112
    -524 -114
    -525 -115
    -525 -116
    -525 -117
    -525 -119
    -525 -120
    -525 -121
    -524 -122
    -523 -123
    -523 -125
    -522 -126
    -521 -127
    -519 -128
    -518 -129
    -516 -131
    -515 -132
    -513 -133
    -511 -134
    -509 -135
    -506 -136
    -504 -137
    -501 -139
    -499 -140
    -496 -141
    -493 -142
    -490 -143
    -487 -144
    -483 -145
    -480 -146
    -476 -147
    -472 -148
    -468 -149
    -464 -150
    -460 -151
    -456 -152
    -452 -153
    -447 -154
    -442 -155
    -438 -156
    -433 -157
    -428 -158
    -422 -158
    -417 -159
    -412 -160
    -406 -161
    -401 -162
    -395 -163
    -389 -163
    -383 -164
    -377 -165
    -371 -166
    -365 -166
    -358 -167
    -352 -168
    -345 -169
    -339 -169
    -332 -170
    -325 -171
    -318 -171
    -311 -172
    -304 -173
    -297 -173
    -290 -174
    -282 -174
    -275 -175
    -267 -175
    -260 -176
    -252 -176
    -244 -177
    -237 -177
    -229 -178
    -221 -178
    -213 -179
    -205 -179
    -197 -180
    -189 -180
    -180 -180
    -172 -181
    -164 -181
    -155 -181
    -147 -182
    -139 -182
    -130 -182
    -122 -182
    -113 -183
    -104 -183
    -96 -183
    -87 -183
    -79 -183
    -70 -184
    -61 -184
    -52 -184
    -44 -184
    -35 -184
    -26 -184
    -18 -184
    -9 -184
    0 -184
    9 -184
    18 -184
    26 -184
    35 -184
    44 -184
    52 -184
    61 -184
    70 -184
    79 -183
    87 -183
    96 -183
    104 -183
    113 -183
    122 -182
    130 -182
    139 -182
    147 -182
    155 -181
    164 -181
    172 -181
    180 -180
    189 -180
    197 -180
    205 -179
    213 -179
    221 -178
    229 -178
    237 -177
    244 -177
    252 -176
    260 -176
    267 -175
    275 -175
    282 -174
    290 -174
    297 -173
    304 -173
    311 -172
    318 -171
    325 -171
    332 -170
    339 -169
    345 -169
    352 -168
    358 -167
    365 -166
    371 -166
    377 -165
    383 -164
    389 -163
    395 -163
    401 -162
    406 -161
    412 -160
    417 -159
    422 -158
    428 -158
    433 -157
    438 -156
    442 -155
    447 -154
    452 -153
    456 -152
    460 -151
    464 -150
    468 -149
    472 -148
    476 -147
    480 -146
    483 -145
    487 -144
    490 -143
    493 -142
    496 -141
    499 -140
    501 -139
    504 -137
    506 -136
    509 -135
    511 -134
    513 -133
    515 -132
    516 -131
    518 -129
    519 -128
    521 -127
    522 -126
    523 -125
    523 -123
    524 -122
    525 -121
    525 -120
    525 -119
    525 -117
    525 -116
    525 -115
    524 -114
    524 -112
    523 -111
    522 -110
    521 -108
    520 -107
    519 -106
    518 -105
    516 -103
    514 -102
    512 -101
    510 -99
    508 -98
    506 -97
    503 -95
    500 -94
    498 -92
    495 -91
    492 -90
    488 -88
    485 -87
    481 -86
    478 -84
    474 -83
    470 -82
    465 -80
    461 -79
    457 -77
    452 -76
    447 -75
    442 -73
    437 -72
    432 -70
    427 -69
    421 -68
    416 -66
    410 -65
    404 -63
    398 -62
    391 -60
    385 -59
    378 -58
    372 -56
    365 -55
    358 -53
    351 -52
    344 -50
    336 -49
    329 -48
    321 -46
    313 -45
    305 -43
    297 -42
    289 -40
    281 -39
    272 -38
    263 -36
    255 -35
    246 -33
    237 -32
    228 -30
    218 -29
    209 -28
    199 -26
    190 -25
    180 -23
    170 -22
    160 -20
    149 -19
    139 -18
    129 -16
    118 -15
    107 -13
    96 -12
    85 -10
    74 -9
    63 -8
    52 -6
    40 -5
    29 -3
    17 -2
    5 -1
    -7 1
    -19 2
    -31 4
    -44 5
    -56 6
    -69 8
    -81 9
    -94 11
    -107 12
    -120 13
    -133 15
    -146 16
    -160 18
    -173 19
    -187 20
    -201 22
    -214 23
    -228 24
    -242 26
    -256 27
    -271 29
    -285 30
    -299 31
    -314 33
    -329 34
    -343 35
    -358 37
    -373 38
    -388 39
    -403 41
    -419 42
    -434 43
    -450 45
    -465 46
    -481 47
    -497 49
    -512 50
    -528 51
    -544 53
    -561 54
    -577 55
    -593 57
    -610 58
    -626 59
    -643 61
    -659 62
    -676 63
    -693 64
    -710 66
    -727 67
    -744 68
    -762 70
    -779 71
    -796 72
    -814 73
    -831 75
    -849 76
    -867 77
    -885 78
    -903 80
    -921 81
    -939 82
    937 78
    919 77
    901 76
    883 75
    866 73
    848 72
    830 71
    813 70
    795 69
    778 67
    760 66
    743 65
    726 64
    709 62
    692 61
    675 60
    658 59
    641 58
    625 56
    608 55
    592 54
    576 53
    559 51
    543 50
    527 49
    511 48
    495 46
    479 45
    464 44
    448 42
    433 41
    417 40
    402 39
    387 37
    372 36
    357 35
    342 34
    327 32
    313 31
    298 30
    284 28
    269 27
    255 26
    241 24
    227 23
    213 22
    199 21
    185 19
    172 18
    158 17
    145 15
    132 14
    119 13
    106 11
    93 10
    80 9
    67 7
    55 6
    42 5
    30 3
    18 2
    6 1
    -6 -1
    -18 -2
    -30 -3
    -42 -5
    -53 -6
    -64 -7
    -76 -9
    -87 -10
    -98 -11
    -109 -13
    -119 -14
    -130 -16
    -140 -17
    -151 -18
    -161 -20
    -171 -21
    -181 -22
    -191 -24
    -201 -25
    -210 -26
    -220 -28
    -229 -29
    -238 -31
    -247 -32
    -256 -33
    -265 -35
    -274 -36
    -282 -37
    -290 -39
    -299 -40
    -307 -41
    -315 -43
    -322 -44
    -330 -46
    -338 -47
    -345 -48
    -352 -50
    -359 -51
    -366 -52
    -373 -54
    -380 -55
    -386 -56
    -393 -58
    -399 -59
    -405 -60
    -411 -62
    -417 -63
    -423 -65
    -428 -66
    -433 -67
    -439 -69
    -444 -70
    -449 -71
    -453 -73
    -458 -74
    -463 -75
    -467 -77
    -471 -78
    -475 -79
    -479 -80
    -483 -82
    -486 -83
    -490 -84
    -493 -86
    -496 -87
    -499 -88
    -502 -90
    -504 -91
    -507 -92
    -509 -93
    -512 -95
    -514 -96
    -515 -97
    -517 -99
    -519 -100
    -520 -101
    -522 -102
    -523 -104
    -524 -105
    -525 -106
    -525 -107
    -526 -108
    -526 -110
    -526 -111
    -526 -112
    -526 -113
    -526 -114
    -526 -116
    -525 -117
    -525 -118
    -524 -119
    -523 -120
    -522 -121
    -520 -122
    -519 -124
    -517 -125
    -516 -126
    -514 -127
    -512 -128
    -510 -129
    -508 -130
    -505 -131
    -503 -132
    -500 -133
    -497 -134
    -494 -135
    -491 -136
    -488 -137
    -484 -138
    -481 -139
    -477 -140
    -473 -141
    -469 -142
    -465 -143
    -461 -144
    -457 -145
    -452 -146
    -448 -147
    -443 -148
    -438 -149
    -433 -149
    -428 -150
    -423 -151
    -418 -152
    -413 -153
    -407 -154
    -401 -154
    -396 -155
    -390 -156
    -384 -157
    -378 -157
    -372 -158
    -365 -159
    -359 -160
    -353 -160
    -346 -161
    -339 -162
    -333 -162
    -326 -163
    -319 -163
    -312 -164
    -305 -165
    -297 -165
    -290 -166
    -283 -166
    -275 -167
    -268 -167
    -260 -168
    -253 -168
    -245 -169
    -237 -169
    -229 -170
    -221 -170
    -213 -171
    -205 -171
    -197 -171
    -189 -172
    -181 -172
    -172 -172
    -164 -173
    -156 -173
    -147 -173
    -139 -174
    -130 -174
    -122 -174
    -113 -174
    -105 -174
    -96 -175
    -87 -175
    -79 -175
    -70 -175
    -61 -175
    -53 -175
    -44 -175
    -35 -175
    -26 -176
    -18 -176
    -9 -176
    0 -176
    9 -176
    18 -176
    26 -176
    35 -175
    44 -175
    53 -175
    61 -175
    70 -175
    79 -175
    87 -175
    96 -175
    105 -174
    113 -174
    122 -174
    130 -174
    139 -174
    147 -173
    156 -173
    164 -173
    172 -172
    181 -172
    189 -172
    197 -171
    205 -171
    213 -171
    221 -170
    229 -170
    237 -169
    245 -169
    253 -168
    260 -168
    268 -167
    275 -167
    283 -166
    290 -166
    297 -165
    305 -165
    312 -164
    319 -163
    326 -163
    333 -162
    339 -162
    346 -161
    353 -160
    359 -160
    365 -159
    372 -158
    378 -157
    384 -157
    390 -156
    396 -155
    401 -154
    407 -154
    413 -153
    418 -152
    423 -151
    428 -150
    433 -149
    438 -149
    443 -148
    448 -147
    452 -146
    457 -145
    461 -144
    465 -143
    469 -142
    473 -141
    477 -140
    481 -139
    484 -138
    488 -137
    491 -136
    494 -135
    497 -134
    500 -133
    503 -132
    505 -131
    508 -130
    510 -129
    512 -128
    514 -127
    516 -126
    517 -125
    519 -124
    520 -122
    522 -121
    523 -120
    524 -119
    525 -118
    525 -117
    526 -116
    526 -114
    526 -113
    526 -112
    526 -111
    526 -110
    526 -108
    525 -107
    525 -106
    524 -105
    523 -104
    522 -102
    520 -101
    519 -100
    517 -99
    515 -97
    514 -96
    512 -95
    509 -93
    507 -92
    504 -91
    502 -90
    499 -88
    496 -87
    493 -86
    490 -84
    486 -83
    483 -82
    479 -80
    475 -79
    471 -78
    467 -77
    463 -75
    458 -74
    453 -73
    449 -71
    444 -70
    439 -69
    433 -67
    428 -66
    423 -65
    417 -63
    411 -62
    405 -60
    399 -59
    393 -58
    386 -56
    380 -55
    373 -54
    366 -52
    359 -51
    352 -50
    345 -48
    338 -47
    330 -46
    322 -44
    315 -43
    307 -41
    299 -40
    290 -39
    282 -37
    274 -36
    265 -35
    256 -33
    247 -32
    238 -31
    229 -29
    220 -28
    210 -26
    201 -25
    191 -24
    181 -22
    171 -21
    161 -20
    151 -18
    140 -17
    130 -16
    119 -14
    109 -13
    98 -11
    87 -10
    76 -9
    64 -7
    53 -6
    42 -5
    30 -3
    18 -2
    6 -1
    -6 1
    -18 2
    -30 3
    -42 5
    -55 6
    -67 7
    -80 9
    -93 10
    -106 11
    -119 13
    -132 14
    -145 15
    -158 17
    -172 18
    -185 19
    -199 21
    -213 22
    -227 23
    -241 24
    -255 26
    -269 27
    -284 28
    -298 30
    -313 31
    -327 32
    -342 34
    -357 35
    -372 36
    -387 37
    -402 39
    -417 40
    -433 41
    -448 42
    -464 44
    -479 45
    -495 46
    -511 48
    -527 49
    -543 50
    -559 51
    -576 53
    -592 54
    -608 55
    -625 56
    -641 58
    -658 59
    -675 60
    -692 61
    -709 62
    -726 64
    -743 65
    -760 66
    -778 67
    -795 69
    -813 70
    -830 71
    -848 72
    -866 73
    -883 75
    -901 76
    -919 77
    -937 78
    936 74
    918 73
    900 72
    882 71
    864 70
    847 68
    829 67
    811 66
    794 65
    776 64
    759 63
    742 62
    725 60
    708 59
    691 58
    674 57
    657 56
    640 55
    624 53
    607 52
    591 51
    574 50
    558 49
    542 47
    526 46
    510 45
    494 44
    478 43
    463 41
    447 40
    432 39
    416 38
    401 37
    386 35
    371 34
    356 33
    341 32
    326 31
    311 29
    297 28
    282 27
    268 26
    254 24
    240 23
    226 22
    212 21
    198 19
    184 18
    171 17
    157 16
    144 14
    131 13
    117 12
    104 11
    91 9
    79 8
    66 7
    53 6
    41 4
    29 3
    16 2
    4 0
    -8 -1
    -19 -2
    -31 -3
    -43 -5
    -54 -6
    -66 -7
    -77 -8
    -88 -10
    -99 -11
    -110 -12
    -121 -14
    -131 -15
    -142 -16
    -152 -18
    -162 -19
    -172 -20
    -182 -21
    -192 -23
    -202 -24
    -212 -25
    -221 -27
    -230 -28
    -239 -29
    -249 -30
    -257 -32
    -266 -33
    -275 -34
    -283 -36
    -292 -37
    -300 -38
    -308 -40
    -316 -41
    -324 -42
    -331 -43
    -339 -45
    -346 -46
    -354 -47
    -361 -49
    -368 -50
    -375 -51
    -381 -52
    -388 -54
    -394 -55
    -400 -56
    -406 -58
    -412 -59
    -418 -60
    -424 -61
    -429 -63
    -435 -64
    -440 -65
    -445 -67
    -450 -68
    -455 -69
    -459 -70
    -464 -72
    -468 -73
    -472 -74
    -476 -75
    -480 -77
    -484 -78
    -487 -79
    -491 -80
    -494 -82
    -497 -83
    -500 -84
    -503 -85
    -506 -87
    -508 -88
    -511 -89
    -513 -90
    -515 -91
    -517 -93
    -518 -94
    -520 -95
    -521 -96
    -523 -97
    -524 -99
    -525 -100
    -526 -101
    -526 -102
    -527 -103
    -527 -104
    -528 -106
    -528 -107
    -527 -108
    -527 -109
    -527 -110
    -526 -111
    -526 -112
    -525 -113
    -524 -114
    -523 -115
    -522 -117
    -520 -118
    -519 -119
    -517 -120
    -515 -121
    -513 -122
    -511 -123
    -509 -124
    -506 -125
    -504 -126
    -501 -127
    -498 -128
    -495 -129
    -492 -130
    -489 -131
    -485 -132
    -482 -133
    -478 -134
    -474 -134
    -470 -135
    -466 -136
    -462 -137
    -458 -138
    -453 -139
    -449 -140
    -444 -141
    -439 -141
    -434 -142
    -429 -143
    -424 -144
    -419 -145
    -413 -145
    -408 -146
    -402 -147
    -396 -148
    -391 -148
    -385 -149
    -379 -150
    -372 -151
    -366 -151
    -360 -152
    -353 -153
    -347 -153
    -340 -154
    -333 -154
    -326 -155
    -319 -156
    -312 -156
    -305 -157
    -298 -157
    -291 -158
    -283 -158
    -276 -159
    -268 -159
    -261 -160
    -253 -160
    -245 -161
    -237 -161
    -230 -162
    -222 -162
    -214 -162
    -206 -163
    -197 -163
    -189 -163
    -181 -164
    -173 -164
    -164 -164
    -156 -165
    -148 -165
    -139 -165
    -131 -165
    -122 -166
    -113 -166
    -105 -166
    -96 -166
    -88 -166
    -79 -167
    -70 -167
    -61 -167
    -53 -167
    -44 -167
    -35 -167
    -26 -167
    -18 -167
    -9 -167
    0 -167
    9 -167
    18 -167
    26 -167
    35 -167
    44 -167
    53 -167
    61 -167
    70 -167
    79 -167
    88 -166
    96 -166
    105 -166
    113 -166
    122 -166
    131 -165
    139 -165
    148 -165
    156 -165
    164 -164
    173 -164
    181 -164
    189 -163
    197 -163
    206 -163
    214 -162
    222 -162
    230 -162
    237 -161
    245 -161
    253 -160
    261 -160
    268 -159
    276 -159
    283 -158
    291 -158
    298 -157
    305 -157
    312 -156
    319 -156
    326 -155
    333 -154
    340 -154
    347 -153
    353 -153
    360 -152
    366 -151
    372 -151
    379 -150
    385 -149
    391 -148
    396 -148
    402 -147
    408 -146
    413 -145
    419 -145
    424 -144
    429 -143
    434 -142
    439 -141
    444 -141
    449 -140
    453 -139
    458 -138
    462 -137
    466 -136
    470 -135
    474 -134
    478 -134
    482 -133
    485 -132
    489 -131
    492 -130
    495 -129
    498 -128
    501 -127
    504 -126
    506 -125
    509 -124
    511 -123
    513 -122
    515 -121
    517 -120
    519 -119
    520 -118
    522 -117
    523 -115
    524 -114
    525 -113
    526 -112
    526 -111
    527 -110
    527 -109
    527 -108
    528 -107
    528 -106
    527 -104
    527 -103
    526 -102
    526 -101
    525 -100
    524 -99
    523 -97
    521 -96
    520 -95
    518 -94
    517 -93
    515 -91
    513 -90
    511 -89
    508 -88
    506 -87
    503 -85
    500 -84
    497 -83
    494 -82
    491 -80
    487 -79
    484 -78
    480 -77
    476 -75
    472 -74
    468 -73
    464 -72
    459 -70
    455 -69
    450 -68
    445 -67
    440 -65
    435 -64
    429 -63
    424 -61
    418 -60
    412 -59
    406 -58
    400 -56
    394 -55
    388 -54
    381 -52
    375 -51
    368 -50
    361 -49
    354 -47
    346 -46
    339 -45
    331 -43
    324 -42
    316 -41
    308 -40
    300 -38
    292 -37
    283 -36
    275 -34
    266 -33
    257 -32
    249 -30
    239 -29
    230 -28
    221 -27
    212 -25
    202 -24
    192 -23
    182 -21
    172 -20
    162 -19
    152 -18
    142 -16
    131 -15
    121 -14
    110 -12
    99 -11
    88 -10
    77 -8
    66 -7
    54 -6
    43 -5
    31 -3
    19 -2
    8 -1
    -4 0
    -16 2
    -29 3
    -41 4
    -53 6
    -66 7
    -79 8
    -91 9
    -104 11
    -117 12
    -131 13
    -144 14
    -157 16
    -171 17
    -184 18
    -198 19
    -212 21
    -226 22
    -240 23
    -254 24
    -268 26
    -282 27
    -297 28
    -311 29
    -326 31
    -341 32
    -356 33
    -371 34
    -386 35
    -401 37
    -416 38
    -432 39
    -447 40
    -463 41
    -478 43
    -494 44
    -510 45
    -526 46
    -542 47
    -558 49
    -574 50
    -591 51
    -607 52
    -624 53
    -640 55
    -657 56
    -674 57
    -691 58
    -708 59
    -725 60
    -742 62
    -759 63
    -776 64
    -794 65
    -811 66
    -829 67
    -847 68
    -864 70
    -882 71
    -900 72
    -918 73
    -936 74
    935 70
    917 69
    899 68
    881 67
    863 66
    846 65
    828 64
    810 63
    793 62
    775 60
    758 59
    741 58
    724 57
    706 56
    690 55
    673 54
    656 53
    639 52
    622 50
    606 49
    590 48
    573 47
    557 46
    541 45
    525 44
    509 43
    493 41
    477 40
    461 39
    446 38
    430 37
    415 36
    400 35
    385 33
    369 32
    354 31
    340 30
    325 29
    310 28
    296 26
    281 25
    267 24
    253 23
    238 22
    224 21
    211 19
    197 18
    183 17
    169 16
    156 15
    143 14
    129 12
    116 11
    103 10
    90 9
    77 8
    65 6
    52 5
    40 4
    27 3
    15 2
    3 0
    -9 -1
    -21 -2
    -32 -3
    -44 -5
    -56 -6
    -67 -7
    -78 -8
    -89 -9
    -100 -11
    -111 -12
    -122 -13
    -133 -14
    -143 -16
    -153 -17
    -164 -18
    -174 -19
    -184 -20
    -194 -22
    -203 -23
    -213 -24
    -222 -25
    -232 -27
    -241 -28
    -250 -29
    -259 -30
    -267 -31
    -276 -33
    -285 -34
    -293 -35
    -301 -36
    -309 -38
    -317 -39
    -325 -40
    -333 -41
    -340 -43
    -348 -44
    -355 -45
    -362 -46
    -369 -47
    -376 -49
    -382 -50
    -389 -51
    -395 -52
    -402 -54
    -408 -55
    -414 -56
    -419 -57
    -425 -58
    -431 -60
    -436 -61
    -441 -62
    -446 -63
    -451 -64
    -456 -66
    -461 -67
    -465 -68
    -469 -69
    -474 -70
    -478 -72
    -481 -73
    -485 -74
    -489 -75
    -492 -76
    -495 -78
    -498 -79
    -501 -80
    -504 -81
    -507 -82
    -509 -83
    -512 -85
    -514 -86
    -516 -87
    -518 -88
    -520 -89
    -521 -90
    -523 -91
    -524 -92
    -525 -94
    -526 -95
    -527 -96
    -528 -97
    -528 -98
    -528 -99
    -529 -100
    -529 -101
    -529 -102
    -528 -103
    -528 -104
    -527 -105
    -527 -107
    -526 -108
    -525 -109
    -524 -110
    -523 -111
    -521 -112
    -520 -113
    -518 -114
    -516 -115
    -514 -116
    -512 -117
    -510 -118
    -507 -119
    -505 -119
    -502 -120
    -499 -121
    -496 -122
    -493 -123
    -490 -124
    -486 -125
    -483 -126
    -479 -127
    -475 -128
    -471 -129
    -467 -129
    -463 -130
    -459 -131
    -454 -132
    -450 -133
    -445 -133
    -440 -134
    -435 -135
    -430 -136
    -425 -137
    -420 -137
    -414 -138
    -409 -139
    -403 -139
    -397 -140
    -391 -141
    -385 -142
    -379 -142
    -373 -143
    -367 -144
    -360 -144
    -354 -145
    -347 -145
    -341 -146
    -334 -147
    -327 -147
    -320 -148
    -313 -148
    -306 -149
    -299 -149
    -291 -150
    -284 -150
    -276 -151
    -269 -151
    -261 -152
    -253 -152
    -246 -153
    -238 -153
    -230 -153
    -222 -154
    -214 -154
    -206 -154
    -198 -155
    -190 -155
    -181 -155
    -173 -156
    -165 -156
    -156 -156
    -148 -157
    -139 -157
    -131 -157
    -122 -157
    -114 -157
    -105 -158
    -96 -158
    -88 -158
    -79 -158
    -70 -158
    -62 -158
    -53 -158
    -44 -158
    -35 -159
    -26 -159
    -18 -159
    -9 -159
    0 -159
    9 -159
    18 -159
    26 -159
    35 -159
    44 -158
    53 -158
    62 -158
    70 -158
    79 -158
    88 -158
    96 -158
    105 -158
    114 -157
    122 -157
    131 -157
    139 -157
    148 -157
    156 -156
    165 -156
    173 -156
    181 -155
    190 -155
    198 -155
    206 -154
    214 -154
    222 -154
    230 -153
    238 -153
    246 -153
    253 -152
    261 -152
    269 -151
    276 -151
    284 -150
    291 -150
    299 -149
    306 -149
    313 -148
    320 -148
    327 -147
    334 -147
    341 -146
    347 -145
    354 -145
    360 -144
    367 -144
    373 -143
    379 -142
    385 -142
    391 -141
    397 -140
    403 -139
    409 -139
    414 -138
    420 -137
    425 -137
    430 -136
    435 -135
    440 -134
    445 -133
    450 -133
    454 -132
    459 -131
    463 -130
    467 -129
    471 -129
    475 -128
    479 -127
    483 -126
    486 -125
    490 -124
    493 -123
    496 -122
    499 -121
    502 -120
    505 -119
    507 -119
    510 -118
    512 -117
    514 -116
    516 -115
    518 -114
    520 -113
    521 -112
    523 -111
    524 -110
    525 -109
    526 -108
    527 -107
    527 -105
    528 -104
    528 -103
    529 -102
    529 -101
    529 -100
    528 -99
    528 -98
    528 -97
    527 -96
    526 -95
    525 -94
    524 -92
    523 -91
    521 -90
    520 -89
    518 -88
    516 -87
    514 -86
    512 -85
    509 -83
    507 -82
    504 -81
    501 -80
    498 -79
    495 -78
    492 -76
    489 -75
    485 -74
    481 -73
    478 -72
    474 -70
    469 -69
    465 -68
    461 -67
    456 -66
    451 -64
    446 -63
    441 -62
    436 -61
    431 -60
    425 -58
    419 -57
    414 -56
    408 -55
    402 -54
    395 -52
    389 -51
    382 -50
    376 -49
    369 -47
    362 -46
    355 -45
    348 -44
    340 -43
    333 -41
    325 -40
    317 -39
    309 -38
    301 -36
    293 -35
    285 -34
    276 -33
    267 -31
    259 -30
    250 -29
    241 -28
    232 -27
    222 -25
    213 -24
    203 -23
    194 -22
    184 -20
    174 -19
    164 -18
    153 -17
    143 -16
    133 -14
    122 -13
    111 -12
    100 -11
    89 -9
    78 -8
    67 -7
    56 -6
    44 -5
    32 -3
    21 -2
    9 -1
    -3 0
    -15 2
    -27 3
    -40 4
    -52 5
    -65 6
    -77 8
    -90 9
    -103 10
    -116 11
    -129 12
    -143 14
    -156 15
    -169 16
    -183 17
    -197 18
    -211 19
    -224 21
    -238 22
    -253 23
    -267 24
    -281 25
    -296 26
    -310 28
    -325 29
    -340 30
    -354 31
    -369 32
    -385 33
    -400 35
    -415 36
    -430 37
    -446 38
    -461 39
    -477 40
    -493 41
    -509 43
    -525 44
    -541 45
    -557 46
    -573 47
    -590 48
    -606 49
    -622 50
    -639 52
    -656 53
    -673 54
    -690 55
    -706 56
    -724 57
    -741 58
    -758 59
    -775 60
    -793 62
    -810 63
    -828 64
    -846 65
    -863 66
    -881 67
    -899 68
    -917 69
    -935 70
    934 66
    916 65
    898 64
    880 63
    862 62
    844 61
    827 60
    809 59
    792 58
    774 57
    757 56
    740 55
    722 54
    705 53
    688 52
    672 51
    655 50
    638 49
    621 48
    605 47
    588 45
    572 44
    556 43
    540 42
    524 41
    508 40
    492 39
    476 38
    460 37
    445 36
    429 35
    414 34
    399 33
    383 31
    368 30
    353 29
    338 28
    324 27
    309 26
    294 25
    280 24
    266 23
    251 22
    237 20
    223 19
    209 18
    196 17
    182 16
    168 15
    155 14
    141 13
    128 12
    115 10
    102 9
    89 8
    76 7
    64 6
    51 5
    39 4
    26 2
    14 1
    2 0
    -10 -1
    -22 -2
    -34 -3
    -45 -4
    -57 -6
    -68 -7
    -79 -8
    -90 -9
    -101 -10
    -112 -11
    -123 -12
    -134 -14
    -144 -15
    -155 -16
    -165 -17
    -175 -18
    -185 -19
    -195 -21
    -204 -22
    -214 -23
    -223 -24
    -233 -25
    -242 -26
    -251 -28
    -260 -29
    -269 -30
    -277 -31
    -286 -32
    -294 -33
    -302 -35
    -310 -36
    -318 -37
    -326 -38
    -334 -39
    -341 -40
    -349 -41
    -356 -43
    -363 -44
    -370 -45
    -377 -46
    -384 -47
    -390 -48
    -397 -50
    -403 -51
    -409 -52
    -415 -53
    -421 -54
    -426 -55
    -432 -56
    -437 -58
    -442 -59
    -447 -60
    -452 -61
    -457 -62
    -462 -63
    -466 -64
    -471 -66
    -475 -67
    -479 -68
    -483 -69
    -486 -70
    -490 -71
    -493 -72
    -497 -73
    -500 -75
    -503 -76
    -505 -77
    -508 -78
    -511 -79
    -513 -80
    -515 -81
    -517 -82
    -519 -83
    -521 -84
    -522 -85
    -524 -86
    -525 -87
    -526 -89
    -527 -90
    -528 -91
    -529 -92
    -529 -93
    -529 -94
    -530 -95
    -530 -96
    -530 -97
    -529 -98
    -529 -99
    -528 -100
    -528 -101
    -527 -102
    -526 -103
    -525 -104
    -524 -105
    -522 -106
    -521 -107
    -519 -108
    -517 -108
    -515 -109
    -513 -110
    -510 -111
    -508 -112
    -505 -113
    -503 -114
    -500 -115
    -497 -116
    -494 -117
    -490 -117
    -487 -118
    -484 -119
    -480 -120
    -476 -121
    -472 -122
    -468 -122
    -464 -123
    -459 -124
    -455 -125
    -450 -126
    -446 -126
    -441 -127
    -436 -128
    -431 -128
    -426 -129
    -420 -130
    -415 -131
    -409 -131
    -404 -132
    -398 -133
    -392 -133
    -386 -134
    -380 -135
    -374 -135
    -367 -136
    -361 -136
    -354 -137
    -348 -138
    -341 -138
    -334 -139
    -327 -139
    -320 -140
    -313 -140
    -306 -141
    -299 -141
    -292 -142
    -284 -142
    -277 -143
    -269 -143
    -262 -143
    -254 -144
    -246 -144
    -238 -145
    -230 -145
    -222 -145
    -214 -146
    -206 -146
    -198 -146
    -190 -147
    -182 -147
    -173 -147
    -165 -148
    -157 -148
    -148 -148
    -140 -148
    -131 -148
    -122 -149
    -114 -149
    -105 -149
    -97 -149
    -88 -149
    -79 -149
    -70 -150
    -62 -150
    -53 -150
    -44 -150
    -35 -150
    -26 -150
    -18 -150
    -9 -150
    0 -150
    9 -150
    18 -150
    26 -150
    35 -150
    44 -150
    53 -150
    62 -150
    70 -150
    79 -149
    88 -149
    97 -149
    105 -149
    114 -149
    122 -149
    131 -148
    140 -148
    148 -148
    157 -148
    165 -148
    173 -147
    182 -147
    190 -147
    198 -146
    206 -146
    214 -146
    222 -145
    230 -145
    238 -145
    246 -144
    254 -144
    262 -143
    269 -143
    277 -143
    284 -142
    292 -142
    299 -141
    306 -141
    313 -140
    320 -140
    327 -139
    334 -139
    341 -138
    348 -138
    354 -137
    361 -136
    367 -136
    374 -135
    380 -135
    386 -134
    392 -133
    398 -133
    404 -132
    409 -131
    415 -131
    420 -130
    426 -129
    431 -128
    436 -128
    441 -127
    446 -126
    450 -126
    455 -125
    459 -124
    464 -123
    468 -122
    472 -122
    476 -121
    480 -120
    484 -119
    487 -118
    490 -117
    494 -117
    497 -116
    500 -115
    503 -114
    505 -113
    508 -112
    510 -111
    513 -110
    515 -109
    517 -108
    519 -108
    521 -107
    522 -106
    524 -105
    525 -104
    526 -103
    527 -102
    528 -101
    528 -100
    529 -99
    529 -98
    530 -97
    530 -96
    530 -95
    529 -94
    529 -93
    529 -92
    528 -91
    527 -90
    526 -89
    525 -87
    524 -86
    522 -85
    521 -84
    519 -83
    517 -82
    515 -81
    513 -80
    511 -79
    508 -78
    505 -77
    503 -76
    500 -75
    497 -73
    493 -72
    490 -71
    486 -70
    483 -69
    479 -68
    475 -67
    471 -66
    466 -64
    462 -63
    457 -62
    452 -61
    447 -60
    442 -59
    437 -58
    432 -56
    426 -55
    421 -54
    415 -53
    409 -52
    403 -51
    397 -50
    390 -48
    384 -47
    377 -46
    370 -45
    363 -44
    356 -43
    349 -41
    341 -40
    334 -39
    326 -38
    318 -37
    310 -36
    302 -35
    294 -33
    286 -32
    277 -31
    269 -30
    260 -29
    251 -28
    242 -26
    233 -25
    223 -24
    214 -23
    204 -22
    195 -21
    185 -19
    175 -18
    165 -17
    155 -16
    144 -15
    134 -14
    123 -12
    112 -11
    101 -10
    90 -9
    79 -8
    68 -7
    57 -6
    45 -4
    34 -3
    22 -2
    10 -1
    -2 0
    -14 1
    -26 2
    -39 4
    -51 5
    -64 6
    -76 7
    -89 8
    -102 9
    -115 10
    -128 12
    -141 13
    -155 14
    -168 15
    -182 16
    -196 17
    -209 18
    -223 19
    -237 20
    -251 22
    -266 23
    -280 24
    -294 25
    -309 26
    -324 27
    -338 28
    -353 29
    -368 30
    -383 31
    -399 33
    -414 34
    -429 35
    -445 36
    -460 37
    -476 38
    -492 39
    -508 40
    -524 41
    -540 42
    -556 43
    -572 44
    -588 45
    -605 47
    -621 48
    -638 49
    -655 50
    -672 51
    -688 52
    -705 53
    -722 54
    -740 55
    -757 56
    -774 57
    -792 58
    -809 59
    -827 60
    -844 61
    -862 62
    -880 63
    -898 64
    -916 65
    -934 66
    933 62
    915 61
    897 60
    879 59
    861 58
    843 57
    826 56
    808 55
    791 55
    773 54
    756 53
    739 52
    721 51
    704 50
    687 49
    671 48
    654 47
    637 46
    620 45
    604 44
    587 43
    571 42
    555 41
    539 40
    523 39
    507 38
    491 37
    475 36
    459 35
    444 34
    428 33
    413 32
    398 31
    382 30
    367 29
    352 27
    337 26
    323 25
    308 24
    293 23
    279 22
    265 21
    250 20
    236 19
    222 18
    208 17
    194 16
    181 15
    167 14
    154 13
    140 12
    127 11
    114 10
    101 9
    88 8
    75 7
    62 5
    50 4
    37 3
    25 2
    13 1
    1 0
    -11 -1
    -23 -2
    -35 -3
    -46 -4
    -58 -5
    -69 -6
    -80 -7
    -92 -9
    -103 -10
    -113 -11
    -124 -12
    -135 -13
    -145 -14
    -156 -15
    -166 -16
    -176 -17
    -186 -18
    -196 -19
    -206 -21
    -215 -22
    -225 -23
    -234 -24
    -243 -25
    -252 -26
    -261 -27
    -270 -28
    -278 -29
    -287 -30
    -295 -31
    -304 -33
    -312 -34
    -320 -35
    -327 -36
    -335 -37
    -343 -38
    -350 -39
    -357 -40
    -364 -41
    -371 -42
    -378 -44
    -385 -45
    -391 -46
    -398 -47
    -404 -48
    -410 -49
    -416 -50
    -422 -51
    -427 -52
    -433 -53
    -438 -54
    -443 -55
    -449 -57
    -453 -58
    -458 -59
    -463 -60
    -467 -61
    -472 -62
    -476 -63
    -480 -64
    -484 -65
    -487 -66
    -491 -67
    -494 -68
    -498 -69
    -501 -70
    -504 -71
    -506 -72
    -509 -73
    -512 -74
    -514 -75
    -516 -76
    -518 -77
    -520 -78
    -522 -80
    -523 -81
    -525 -82
    -526 -83
    -527 -84
    -528 -84
    -529 -85
    -530 -86
    -530 -87
    -530 -88
    -531 -89
    -531 -90
    -531 -91
    -530 -92
    -530 -93
    -529 -94
    -529 -95
    -528 -96
    -527 -97
    -526 -98
    -524 -99
    -523 -100
    -521 -101
    -520 -101
    -518 -102
    -516 -103
    -514 -104
    -511 -105
    -509 -106
    -506 -107
    -504 -107
    -501 -108
    -498 -109
    -495 -110
    -491 -111
    -488 -112
    -484 -112
    -481 -113
    -477 -114
    -473 -115
    -469 -115
    -465 -116
    -460 -117
    -456 -118
    -451 -118
    -446 -119
    -442 -120
    -437 -120
    -432 -121
    -426 -122
    -421 -122
    -416 -123
    -410 -124
    -404 -124
    -399 -125
    -393 -126
    -387 -126
    -381 -127
    -374 -127
    -368 -128
    -362 -129
    -355 -129
    -348 -130
    -342 -130
    -335 -131
    -328 -131
    -321 -132
    -314 -132
    -307 -133
    -299 -133
    -292 -134
    -285 -134
    -277 -134
    -270 -135
    -262 -135
    -254 -136
    -246 -136
    -239 -136
    -231 -137
    -223 -137
    -215 -137
    -207 -138
    -198 -138
    -190 -138
    -182 -139
    -174 -139
    -165 -139
    -157 -139
    -148 -140
    -140 -140
    -131 -140
    -123 -140
    -114 -140
    -105 -141
    -97 -141
    -88 -141
    -79 -141
    -71 -141
    -62 -141
    -53 -141
    -44 -141
    -35 -141
    -27 -141
    -18 -141
    -9 -141
    0 -141
    9 -141
    18 -141
    27 -141
    35 -141
    44 -141
    53 -141
    62 -141
    71 -141
    79 -141
    88 -141
    97 -141
    105 -141
    114 -140
    123 -140
    131 -140
    140 -140
    148 -140
    157 -139
    165 -139
    174 -139
    182 -139
    190 -138
    198 -138
    207 -138
    215 -137
    223 -137
    231 -137
    239 -136
    246 -136
    254 -136
    262 -135
    270 -135
    277 -134
    285 -134
    292 -134
    299 -133
    307 -133
    314 -132
    321 -132
    328 -131
    335 -131
    342 -130
    348 -130
    355 -129
    362 -129
    368 -128
    374 -127
    381 -127
    387 -126
    393 -126
    399 -125
    404 -124
    410 -124
    416 -123
    421 -122
    426 -122
    432 -121
    437 -120
    442 -120
    446 -119
    451 -118
    456 -118
    460 -117
    465 -116
    469 -115
    473 -115
    477 -114
    481 -113
    484 -112
    488 -112
    491 -111
    495 -110
    498 -109
    501 -108
    504 -107
    506 -107
    509 -106
    511 -105
    514 -104
    516 -103
    518 -102
    520 -101
    521 -101
    523 -100
    524 -99
    526 -98
    527 -97
    528 -96
    529 -95
    529 -94
    530 -93
    530 -92
    531 -91
    531 -90
    531 -89
    530 -88
    530 -87
    530 -86
    529 -85
    528 -84
    527 -84
    526 -83
    525 -82
    523 -81
    522 -80
    520 -78
    518 -77
    516 -76
    514 -75
    512 -74
    509 -73
    506 -72
    504 -71
    501 -70
    498 -69
    494 -68
    491 -67
    487 -66
    484 -65
    480 -64
    476 -63
    472 -62
    467 -61
    463 -60
    458 -59
    453 -58
    449 -57
    443 -55
    438 -54
    433 -53
    427 -52
    422 -51
    416 -50
    410 -49
    404 -48
    398 -47
    391 -46
    385 -45
    378 -44
    371 -42
    364 -41
    357 -40
    350 -39
    343 -38
    335 -37
    327 -36
    320 -35
    312 -34
    304 -33
    295 -31
    287 -30
    278 -29
    270 -28
    261 -27
    252 -26
    243 -25
    234 -24
    225 -23
    215 -22
    206 -21
    196 -19
    186 -18
    176 -17
    166 -16
    156 -15
    145 -14
    135 -13
    124 -12
    113 -11
    103 -10
    92 -9
    80 -7
    69 -6
    58 -5
    46 -4
    35 -3
    23 -2
    11 -1
    -1 0
    -13 1
    -25 2
    -37 3
    -50 4
    -62 5
    -75 7
    -88 8
    -101 9
    -114 10
    -127 11
    -140 12
    -154 13
    -167 14
    -181 15
    -194 16
    -208 17
    -222 18
    -236 19
    -250 20
    -265 21
    -279 22
    -293 23
    -308 24
    -323 25
    -337 26
    -352 27
    -367 29
    -382 30
    -398 31
    -413 32
    -428 33
    -444 34
    -459 35
    -475 36
    -491 37
    -507 38
    -523 39
    -539 40
    -555 41
    -571 42
    -587 43
    -604 44
    -620 45
    -637 46
    -654 47
    -671 48
    -687 49
    -704 50
    -721 51
    -739 52
    -756 53
    -773 54
    -791 55
    -808 55
    -826 56
    -843 57
    -861 58
    -879 59
    -897 60
    -915 61
    -933 62
    932 58
    914 57
    896 56
    878 56
    860 55
    843 54
    825 53
    807 52
    790 51
    772 50
    755 49
    738 48
    721 47
    703 46
    686 46
    670 45
    653 44
    636 43
    619 42
    603 41
    586 40
    570 39
    554 38
    538 37
    522 36
    506 35
    490 34
    474 33
    458 32
    443 31
    427 31
    412 30
    397 29
    381 28
    366 27
    351 26
    336 25
    322 24
    307 23
    292 22
    278 21
    264 20
    249 19
    235 18
    221 17
    207 16
    193 15
    180 14
    166 13
    153 12
    139 11
    126 10
    113 9
    100 8
    87 7
    74 6
    61 5
    49 4
    36 3
    24 2
    12 1
    -0 -0
    -12 -1
    -24 -2
    -36 -3
    -47 -4
    -59 -5
    -70 -6
    -82 -7
    -93 -8
    -104 -9
    -115 -10
    -125 -11
    -136 -12
    -146 -13
    -157 -14
    -167 -15
    -177 -16
    -187 -17
    -197 -18
    -207 -19
    -216 -20
    -226 -21
    -235 -22
    -244 -23
    -253 -24
    -262 -26
    -271 -27
    -279 -28
    -288 -29
    -296 -30
    -305 -31
    -313 -32
    -321 -33
    -328 -34
    -336 -35
    -344 -36
    -351 -37
    -358 -38
    -365 -39
    -372 -40
    -379 -41
    -386 -42
    -392 -43
    -399 -44
    -405 -45
    -411 -46
    -417 -47
    -423 -48
    -428 -49
    -434 -50
    -439 -51
    -445 -52
    -450 -53
    -454 -54
    -459 -55
    -464 -56
    -468 -57
    -473 -58
    -477 -59
    -481 -60
    -485 -61
    -488 -62
    -492 -63
    -495 -64
    -499 -65
    -502 -66
    -505 -67
    -507 -68
    -510 -69
    -513 -70
    -515 -71
    -517 -72
    -519 -73
    -521 -74
    -523 -75
    -524 -76
    -526 -77
    -527 -77
    -528 -78
    -529 -79
    -530 -80
    -531 -81
    -531 -82
    -531 -83
    -532 -84
    -532 -85
    -532 -86
    -531 -87
    -531 -88
    -530 -88
    -530 -89
    -529 -90
    -528 -91
    -527 -92
    -525 -93
    -524 -94
    -522 -94
    -521 -95
    -519 -96
    -517 -97
    -515 -98
    -512 -98
    -510 -99
    -507 -100
    -504 -101
    -502 -102
    -499 -102
    -495 -103
    -492 -104
    -489 -105
    -485 -105
    -481 -106
    -478 -107
    -474 -108
    -469 -108
    -465 -109
    -461 -110
    -456 -110
    -452 -111
    -447 -112
    -442 -112
    -437 -113
    -432 -114
    -427 -114
    -422 -115
    -416 -116
    -411 -116
    -405 -117
    -399 -117
    -393 -118
    -387 -119
    -381 -119
    -375 -120
    -369 -120
    -362 -121
    -356 -121
    -349 -122
    -342 -122
    -335 -123
    -328 -123
    -321 -124
    -314 -124
    -307 -125
    -300 -125
    -293 -125
    -285 -126
    -278 -126
    -270 -127
    -262 -127
    -255 -127
    -247 -128
    -239 -128
    -231 -128
    -223 -129
    -215 -129
    -207 -129
    -199 -130
    -190 -130
    -182 -130
    -174 -130
    -165 -131
    -157 -131
    -148 -131
    -140 -131
    -131 -131
    -123 -132
    -114 -132
    -106 -132
    -97 -132
    -88 -132
    -79 -132
    -71 -132
    -62 -132
    -53 -133
    -44 -133
    -35 -133
    -27 -133
    -18 -133
    -9 -133
    0 -133
    9 -133
    18 -133
    27 -133
    35 -133
    44 -133
    53 -133
    62 -132
    71 -132
    79 -132
    88 -132
    97 -132
    106 -132
    114 -132
    123 -132
    131 -131
    140 -131
    148 -131
    157 -131
    165 -131
    174 -130
    182 -130
    190 -130
    199 -130
    207 -129
    215 -129
    223 -129
    231 -128
    239 -128
    247 -128
    255 -127
    262 -127
    270 -127
    278 -126
    285 -126
    293 -125
    300 -125
    307 -125
    314 -124
    321 -124
    328 -123
    335 -123
    342 -122
    349 -122
    356 -121
    362 -121
    369 -120
    375 -120
    381 -119
    387 -119
    393 -118
    399 -117
    405 -117
    411 -116
    416 -116
    422 -115
    427 -114
    432 -114
    437 -113
    442 -112
    447 -112
    452 -111
    456 -110
    461 -110
    465 -109
    469 -108
    474 -108
    478 -107
    481 -106
    485 -105
    489 -105
    492 -104
    495 -103
    499 -102
    502 -102
    504 -101
    507 -100
    510 -99
    512 -98
    515 -98
    517 -97
    519 -96
    521 -95
    522 -94
    524 -94
    525 -93
    527 -92
    528 -91
    529 -90
    530 -89
    530 -88
    531 -88
    531 -87
    532 -86
    532 -85
    532 -84
    531 -83
    531 -82
    531 -81
    530 -80
    529 -79
    528 -78
    527 -77
    526 -77
    524 -76
    523 -75
    521 -74
    519 -73
    517 -72
    515 -71
    513 -70
    510 -69
    507 -68
    505 -67
    502 -66
    499 -65
    495 -64
    492 -63
    488 -62
    485 -61
    481 -60
    477 -59
    473 -58
    468 -57
    464 -56
    459 -55
    454 -54
    450 -53
    445 -52
    439 -51
    434 -50
    428 -49
    423 -48
    417 -47
    411 -46
    405 -45
    399 -44
    392 -43
    386 -42
    379 -41
    372 -40
    365 -39
    358 -38
    351 -37
    344 -36
    336 -35
    328 -34
    321 -33
    313 -32
    305 -31
    296 -30
    288 -29
    279 -28
    271 -27
    262 -26
    253 -24
    244 -23
    235 -22
    226 -21
    216 -20
    207 -19
    197 -18
    187 -17
    177 -16
    167 -15
    157 -14
    146 -13
    136 -12
    125 -11
    115 -10
    104 -9
    93 -8
    82 -7
    70 -6
    59 -5
    47 -4
    36 -3
    24 -2
    12 -1
    0 -0
    -12 1
    -24 2
    -36 3
    -49 4
    -61 5
    -74 6
    -87 7
    -100 8
    -113 9
    -126 10
    -139 11
    -153 12
    -166 13
    -180 14
    -193 15
    -207 16
    -221 17
    -235 18
    -249 19
    -264 20
    -278 21
    -292 22
    -307 23
    -322 24
    -336 25
    -351 26
    -366 27
    -381 28
    -397 29
    -412 30
    -427 31
    -443 31
    -458 32
    -474 33
    -490 34
    -506 35
    -522 36
    -538 37
    -554 38
    -570 39
    -586 40
    -603 41
    -619 42
    -636 43
    -653 44
    -670 45
    -686 46
    -703 46
    -721 47
    -738 48
    -755 49
    -772 50
    -790 51
    -807 52
    -825 53
    -843 54
    -860 55
    -878 56
    -896 56
    -914 57
    -932 58
    931 54
    913 53
    895 53
    877 52
    859 51
    842 50
    824 49
    806 48
    789 48
    771 47
    754 46
    737 45
    720 44
    703 43
    686 42
    669 42
    652 41
    635 40
    618 39
    602 38
    586 37
    569 36
    553 36
    537 35
    521 34
    505 33
    489 32
    473 31
    457 30
    442 29
    426 28
    411 28
    396 27
    380 26
    365 25
    350 24
    335 23
    321 22
    306 21
    291 20
    277 19
    263 18
    248 18
    234 17
    220 16
    206 15
    192 14
    179 13
    165 12
    152 11
    138 10
    125 9
    112 8
    99 7
    86 6
    73 6
    60 5
    48 4
    35 3
    23 2
    11 1
    -1 -0
    -13 -1
    -25 -2
    -37 -3
    -48 -4
    -60 -5
    -71 -6
    -83 -7
    -94 -8
    -105 -9
    -115 -10
    -126 -11
    -137 -11
    -147 -12
    -158 -13
    -168 -14
    -178 -15
    -188 -16
    -198 -17
    -208 -18
    -217 -19
    -227 -20
    -236 -21
    -245 -22
    -254 -23
    -263 -24
    -272 -25
    -280 -26
    -289 -27
    -297 -28
    -306 -29
    -314 -30
    -322 -31
    -329 -32
    -337 -33
    -345 -34
    -352 -34
    -359 -35
    -366 -36
    -373 -37
    -380 -38
    -387 -39
    -393 -40
    -400 -41
    -406 -42
    -412 -43
    -418 -44
    -424 -45
    -429 -46
    -435 -47
    -440 -48
    -445 -49
    -451 -50
    -455 -51
    -460 -52
    -465 -52
    -469 -53
    -474 -54
    -478 -55
    -482 -56
    -486 -57
    -489 -58
    -493 -59
    -496 -60
    -500 -61
    -503 -62
    -506 -63
    -508 -64
    -511 -64
    -514 -65
    -516 -66
    -518 -67
    -520 -68
    -522 -69
    -524 -70
    -525 -71
    -527 -72
    -528 -72
    -529 -73
    -530 -74
    -531 -75
    -531 -76
    -532 -77
    -532 -78
    -532 -78
    -533 -79
    -532 -80
    -532 -81
    -532 -82
    -531 -83
    -530 -83
    -530 -84
    -529 -85
    -527 -86
    -526 -87
    -525 -87
    -523 -88
    -521 -89
    -519 -90
    -517 -91
    -515 -91
    -513 -92
    -511 -93
    -508 -94
    -505 -94
    -502 -95
    -499 -96
    -496 -96
    -493 -97
    -489 -98
    -486 -99
    -482 -99
    -478 -100
    -474 -101
    -470 -101
    -466 -102
    -462 -103
    -457 -103
    -452 -104
    -448 -104
    -443 -105
    -438 -106
    -433 -106
    -428 -107
    -422 -107
    -417 -108
    -411 -109
    -405 -109
    -400 -110
    -394 -110
    -388 -111
    -382 -111
    -375 -112
    -369 -112
    -363 -113
    -356 -113
    -349 -114
    -343 -114
    -336 -115
    -329 -115
    -322 -116
    -315 -116
    -308 -116
    -300 -117
    -293 -117
    -286 -118
    -278 -118
    -270 -118
    -263 -119
    -255 -119
    -247 -119
    -239 -120
    -231 -120
    -223 -120
    -215 -121
    -207 -121
    -199 -121
    -191 -121
    -182 -122
    -174 -122
    -166 -122
    -157 -122
    -149 -122
    -140 -123
    -132 -123
    -123 -123
    -114 -123
    -106 -123
    -97 -123
    -88 -124
    -79 -124
    -71 -124
    -62 -124
    -53 -124
    -44 -124
    -35 -124
    -27 -124
    -18 -124
    -9 -124
    0 -124
    9 -124
    18 -124
    27 -124
    35 -124
    44 -124
    53 -124
    62 -124
    71 -124
    79 -124
    88 -124
    97 -123
    106 -123
    114 -123
    123 -123
    132 -123
    140 -123
    149 -122
    157 -122
    166 -122
    174 -122
    182 -122
    191 -121
    199 -121
    207 -121
    215 -121
    223 -120
    231 -120
    239 -120
    247 -119
    255 -119
    263 -119
    270 -118
    278 -118
    286 -118
    293 -117
    300 -117
    308 -116
    315 -116
    322 -116
    329 -115
    336 -115
    343 -114
    349 -114
    356 -113
    363 -113
    369 -112
    375 -112
    382 -111
    388 -111
    394 -110
    400 -110
    405 -109
    411 -109
    417 -108
    422 -107
    428 -107
    433 -106
    438 -106
    443 -105
    448 -104
    452 -104
    457 -103
    462 -103
    466 -102
    470 -101
    474 -101
    478 -100
    482 -99
    486 -99
    489 -98
    493 -97
    496 -96
    499 -96
    502 -95
    505 -94
    508 -94
    511 -93
    513 -92
    515 -91
    517 -91
    519 -90
    521 -89
    523 -88
    525 -87
    526 -87
    527 -86
    529 -85
    530 -84
    530 -83
    531 -83
    532 -82
    532 -81
    532 -80
    533 -79
    532 -78
    532 -78
    532 -77
    531 -76
    531 -75
    530 -74
    529 -73
    528 -72
    527 -72
    525 -71
    524 -70
    522 -69
    520 -68
    518 -67
    516 -66
    514 -65
    511 -64
    508 -64
    506 -63
    503 -62
    500 -61
    496 -60
    493 -59
    489 -58
    486 -57
    482 -56
    478 -55
    474 -54
    469 -53
    465 -52
    460 -52
    455 -51
    451 -50
    445 -49
    440 -48
    435 -47
    429 -46
    424 -45
    418 -44
    412 -43
    406 -42
    400 -41
    393 -40
    387 -39
    380 -38
    373 -37
    366 -36
    359 -35
    352 -34
    345 -34
    337 -33
    329 -32
    322 -31
    314 -30
    306 -29
    297 -28
    289 -27
    280 -26
    272 -25
    263 -24
    254 -23
    245 -22
    236 -21
    227 -20
    217 -19
    208 -18
    198 -17
    188 -16
    178 -15
    168 -14
    158 -13
    147 -12
    137 -11
    126 -11
    115 -10
    105 -9
    94 -8
    83 -7
    71 -6
    60 -5
    48 -4
    37 -3
    25 -2
    13 -1
    1 -0
    -11 1
    -23 2
    -35 3
    -48 4
    -60 5
    -73 6
    -86 6
    -99 7
    -112 8
    -125 9
    -138 10
    -152 11
    -165 12
    -179 13
    -192 14
    -206 15
    -220 16
    -234 17
    -248 18
    -263 18
    -277 19
    -291 20
    -306 21
    -321 22
    -335 23
    -350 24
    -365 25
    -380 26
    -396 27
    -411 28
    -426 28
    -442 29
    -457 30
    -473 31
    -489 32
    -505 33
    -521 34
    -537 35
    -553 36
    -569 36
    -586 37
    -602 38
    -618 39
    -635 40
    -652 41
    -669 42
    -686 42
    -703 43
    -720 44
    -737 45
    -754 46
    -771 47
    -789 48
    -806 48
    -824 49
    -842 50
    -859 51
    -877 52
    -895 53
    -913 53
    -931 54
    931 50
    912 50
    894 49
    877 48
    859 47
    841 47
    823 46
    806 45
    788 44
    771 43
    753 43
    736 42
    719 41
    702 40
    685 39
    668 39
    651 38
    634 37
    618 36
    601 35
    585 35
    568 34
    552 33
    536 32
    520 31
    504 30
    488 30
    472 29
    456 28
    441 27
    425 26
    410 26
    395 25
    380 24
    364 23
    349 22
    335 21
    320 20
    305 20
    291 19
    276 18
    262 17
    248 16
    233 15
    219 15
    205 14
    192 13
    178 12
    164 11
    151 10
    137 9
    124 9
    111 8
    98 7
    85 6
    72 5
    60 4
    47 3
    35 2
    22 2
    10 1
    -2 -0
    -14 -1
    -26 -2
    -38 -3
    -49 -4
    -61 -5
    -72 -5
    -83 -6
    -95 -7
    -106 -8
    -116 -9
    -127 -10
    -138 -11
    -148 -12
    -159 -12
    -169 -13
    -179 -14
    -189 -15
    -199 -16
    -209 -17
    -218 -18
    -228 -19
    -237 -20
    -246 -21
    -255 -21
    -264 -22
    -273 -23
    -281 -24
    -290 -25
    -298 -26
    -307 -27
    -315 -28
    -323 -29
    -330 -29
    -338 -30
    -346 -31
    -353 -32
    -360 -33
    -367 -34
    -374 -35
    -381 -36
    -388 -37
    -394 -37
    -401 -38
    -407 -39
    -413 -40
    -419 -41
    -425 -42
    -430 -43
    -436 -44
    -441 -44
    -446 -45
    -451 -46
    -456 -47
    -461 -48
    -466 -49
    -470 -50
    -475 -51
    -479 -51
    -483 -52
    -487 -53
    -490 -54
    -494 -55
    -497 -56
    -500 -57
    -504 -57
    -506 -58
    -509 -59
    -512 -60
    -514 -61
    -517 -62
    -519 -62
    -521 -63
    -523 -64
    -524 -65
    -526 -66
    -527 -67
    -529 -67
    -530 -68
    -531 -69
    -532 -70
    -532 -71
    -533 -71
    -533 -72
    -533 -73
    -533 -74
    -533 -75
    -533 -75
    -533 -76
    -532 -77
    -531 -78
    -530 -78
    -529 -79
    -528 -80
    -527 -81
    -525 -81
    -524 -82
    -522 -83
    -520 -83
    -518 -84
    -516 -85
    -514 -86
    -511 -86
    -509 -87
    -506 -88
    -503 -88
    -500 -89
    -497 -90
    -493 -90
    -490 -91
    -486 -92
    -483 -92
    -479 -93
    -475 -94
    -471 -94
    -467 -95
    -462 -95
    -458 -96
    -453 -97
    -448 -97
    -443 -98
    -438 -98
    -433 -99
    -428 -99
    -423 -100
    -417 -100
    -412 -101
    -406 -102
    -400 -102
    -394 -103
    -388 -103
    -382 -103
    -376 -104
    -370 -104
    -363 -105
    -357 -105
    -350 -106
    -343 -106
    -336 -107
    -329 -107
    -322 -107
    -315 -108
    -308 -108
    -301 -109
    -293 -109
    -286 -109
    -278 -110
    -271 -110
    -263 -110
    -255 -111
    -248 -111
    -240 -111
    -232 -112
    -224 -112
    -216 -112
    -207 -112
    -199 -113
    -191 -113
    -183 -113
    -174 -113
    -166 -113
    -157 -114
    -149 -114
    -140 -114
    -132 -114
    -123 -114
    -114 -114
    -106 -115
    -97 -115
    -88 -115
    -80 -115
    -71 -115
    -62 -115
    -53 -115
    -44 -115
    -35 -115
    -27 -115
    -18 -115
    -9 -115
    0 -115
    9 -115
    18 -115
    27 -115
    35 -115
    44 -115
    53 -115
    62 -115
    71 -115
    80 -115
    88 -115
    97 -115
    106 -115
    114 -114
    123 -114
    132 -114
    140 -114
    149 -114
    157 -114
    166 -113
    174 -113
    183 -113
    191 -113
    199 -113
    207 -112
    216 -112
    224 -112
    232 -112
    240 -111
    248 -111
    255 -111
    263 -110
    271 -110
    278 -110
    286 -109
    293 -109
    301 -109
    308 -108
    315 -108
    322 -107
    329 -107
    336 -107
    343 -106
    350 -106
    357 -105
    363 -105
    370 -104
    376 -104
    382 -103
    388 -103
    394 -103
    400 -102
    406 -102
    412 -101
    417 -100
    423 -100
    428 -99
    433 -99
    438 -98
    443 -98
    448 -97
    453 -97
    458 -96
    462 -95
    467 -95
    471 -94
    475 -94
    479 -93
    483 -92
    486 -92
    490 -91
    493 -90
    497 -90
    500 -89
    503 -88
    506 -88
    509 -87
    511 -86
    514 -86
    516 -85
    518 -84
    520 -83
    522 -83
    524 -82
    525 -81
    527 -81
    528 -80
    529 -79
    530 -78
    531 -78
    532 -77
    533 -76
    533 -75
    533 -75
    533 -74
    533 -73
    533 -72
    533 -71
    532 -71
    532 -70
    531 -69
    530 -68
    529 -67
    527 -67
    526 -66
    524 -65
    523 -64
    521 -63
    519 -62
    517 -62
    514 -61
    512 -60
    509 -59
    506 -58
    504 -57
    500 -57
    497 -56
    494 -55
    490 -54
    487 -53
    483 -52
    479 -51
    475 -51
    470 -50
    466 -49
    461 -48
    456 -47
    451 -46
    446 -45
    441 -44
    436 -44
    430 -43
    425 -42
    419 -41
    413 -40
    407 -39
    401 -38
    394 -37
    388 -37
    381 -36
    374 -35
    367 -34
    360 -33
    353 -32
    346 -31
    338 -30
    330 -29
    323 -29
    315 -28
    307 -27
    298 -26
    290 -25
    281 -24
    273 -23
    264 -22
    255 -21
    246 -21
    237 -20
    228 -19
    218 -18
    209 -17
    199 -16
    189 -15
    179 -14
    169 -13
    159 -12
    148 -12
    138 -11
    127 -10
    116 -9
    106 -8
    95 -7
    83 -6
    72 -5
    61 -5
    49 -4
    38 -3
    26 -2
    14 -1
    2 -0
    -10 1
    -22 2
    -35 2
    -47 3
    -60 4
    -72 5
    -85 6
    -98 7
    -111 8
    -124 9
    -137 9
    -151 10
    -164 11
    -178 12
    -192 13
    -205 14
    -219 15
    -233 15
    -248 16
    -262 17
    -276 18
    -291 19
    -305 20
    -320 20
    -335 21
    -349 22
    -364 23
    -380 24
    -395 25
    -410 26
    -425 26
    -441 27
    -456 28
    -472 29
    -488 30
    -504 30
    -520 31
    -536 32
    -552 33
    -568 34
    -585 35
    -601 35
    -618 36
    -634 37
    -651 38
    -668 39
    -685 39
    -702 40
    -719 41
    -736 42
    -753 43
    -771 43
    -788 44
    -806 45
    -823 46
    -841 47
    -859 47
    -877 48
    -894 49
    -912 50
    -931 50
    930 46
    912 46
    894 45
    876 44
    858 44
    840 43
    822 42
    805 41
    787 41
    770 40
    752 39
    735 39
    718 38
    701 37
    684 36
    667 36
    650 35
    634 34
    617 33
    600 33
    584 32
    568 31
    551 30
    535 30
    519 29
    503 28
    487 27
    471 27
    456 26
    440 25
    425 24
    409 23
    394 23
    379 22
    364 21
    349 20
    334 20
    319 19
    304 18
    290 17
    275 17
    261 16
    247 15
    233 14
    219 13
    205 13
    191 12
    177 11
    163 10
    150 9
    137 9
    123 8
    110 7
    97 6
    84 5
    71 5
    59 4
    46 3
    34 2
    21 1
    9 1
    -3 -0
    -15 -1
    -27 -2
    -39 -3
    -50 -3
    -62 -4
    -73 -5
    -84 -6
    -95 -7
    -106 -8
    -117 -8
    -128 -9
    -139 -10
    -149 -11
    -159 -12
    -170 -12
    -180 -13
    -190 -14
    -200 -15
    -209 -16
    -219 -17
    -228 -17
    -238 -18
    -247 -19
    -256 -20
    -265 -21
    -274 -21
    -282 -22
    -291 -23
    -299 -24
    -307 -25
    -315 -26
    -323 -26
    -331 -27
    -339 -28
    -346 -29
    -354 -30
    -361 -31
    -368 -31
    -375 -32
    -382 -33
    -389 -34
    -395 -35
    -401 -35
    -408 -36
    -414 -37
    -420 -38
    -426 -39
    -431 -39
    -437 -40
    -442 -41
    -447 -42
    -452 -43
    -457 -44
    -462 -44
    -467 -45
    -471 -46
    -475 -47
    -479 -48
    -483 -48
    -487 -49
    -491 -50
    -495 -51
    -498 -52
    -501 -52
    -504 -53
    -507 -54
    -510 -55
    -513 -55
    -515 -56
    -518 -57
    -520 -58
    -522 -59
    -524 -59
    -525 -60
    -527 -61
    -528 -62
    -530 -62
    -531 -63
    -532 -64
    -532 -65
    -533 -65
    -534 -66
    -534 -67
    -534 -67
    -534 -68
    -534 -69
    -534 -70
    -533 -70
    -533 -71
    -532 -72
    -531 -72
    -530 -73
    -529 -74
    -528 -74
    -526 -75
    -525 -76
    -523 -77
    -521 -77
    -519 -78
    -517 -78
    -514 -79
    -512 -80
    -509 -80
    -507 -81
    -504 -82
    -501 -82
    -497 -83
    -494 -84
    -491 -84
    -487 -85
    -483 -85
    -480 -86
    -476 -86
    -471 -87
    -467 -88
    -463 -88
    -458 -89
    -454 -89
    -449 -90
    -444 -90
    -439 -91
    -434 -91
    -429 -92
    -423 -92
    -418 -93
    -412 -93
    -407 -94
    -401 -94
    -395 -95
    -389 -95
    -383 -96
    -376 -96
    -370 -97
    -364 -97
    -357 -97
    -350 -98
    -344 -98
    -337 -99
    -330 -99
    -323 -99
    -316 -100
    -308 -100
    -301 -100
    -294 -101
    -286 -101
    -279 -101
    -271 -102
    -263 -102
    -256 -102
    -248 -103
    -240 -103
    -232 -103
    -224 -103
    -216 -104
    -208 -104
    -199 -104
    -191 -104
    -183 -104
    -174 -105
    -166 -105
    -158 -105
    -149 -105
    -141 -105
    -132 -106
    -123 -106
    -115 -106
    -106 -106
    -97 -106
    -88 -106
    -80 -106
    -71 -106
    -62 -106
    -53 -106
    -44 -107
    -36 -107
    -27 -107
    -18 -107
    -9 -107
    0 -107
    9 -107
    18 -107
    27 -107
    36 -107
    44 -107
    53 -106
    62 -106
    71 -106
    80 -106
    88 -106
    97 -106
    106 -106
    115 -106
    123 -106
    132 -106
    141 -105
    149 -105
    158 -105
    166 -105
    174 -105
    183 -104
    191 -104
    199 -104
    208 -104
    216 -104
    224 -103
    232 -103
    240 -103
    248 -103
    256 -102
    263 -102
    271 -102
    279 -101
    286 -101
    294 -101
    301 -100
    308 -100
    316 -100
    323 -99
    330 -99
    337 -99
    344 -98
    350 -98
    357 -97
    364 -97
    370 -97
    376 -96
    383 -96
    389 -95
    395 -95
    401 -94
    407 -94
    412 -93
    418 -93
    423 -92
    429 -92
    434 -91
    439 -91
    444 -90
    449 -90
    454 -89
    458 -89
    463 -88
    467 -88
    471 -87
    476 -86
    480 -86
    483 -85
    487 -85
    491 -84
    494 -84
    497 -83
    501 -82
    504 -82
    507 -81
    509 -80
    512 -80
    514 -79
    517 -78
    519 -78
    521 -77
    523 -77
    525 -76
    526 -75
    528 -74
    529 -74
    530 -73
    531 -72
    532 -72
    533 -71
    533 -70
    534 -70
    534 -69
    534 -68
    534 -67
    534 -67
    534 -66
    533 -65
    532 -65
    532 -64
    531 -63
    530 -62
    528 -62
    527 -61
    525 -60
    524 -59
    522 -59
    520 -58
    518 -57
    515 -56
    513 -55
    510 -55
    507 -54
    504 -53
    501 -52
    498 -52
    495 -51
    491 -50
    487 -49
    483 -48
    479 -48
    475 -47
    471 -46
    467 -45
    462 -44
    457 -44
    452 -43
    447 -42
    442 -41
    437 -40
    431 -39
    426 -39
    420 -38
    414 -37
    408 -36
    401 -35
    395 -35
    389 -34
    382 -33
    375 -32
    368 -31
    361 -31
    354 -30
    346 -29
    339 -28
    331 -27
    323 -26
    315 -26
    307 -25
    299 -24
    291 -23
    282 -22
    274 -21
    265 -21
    256 -20
    247 -19
    238 -18
    228 -17
    219 -17
    209 -16
    200 -15
    190 -14
    180 -13
    170 -12
    159 -12
    149 -11
    139 -10
    128 -9
    117 -8
    106 -8
    95 -7
    84 -6
    73 -5
    62 -4
    50 -3
    39 -3
    27 -2
    15 -1
    3 -0
    -9 1
    -21 1
    -34 2
    -46 3
    -59 4
    -71 5
    -84 5
    -97 6
    -110 7
    -123 8
    -137 9
    -150 9
    -163 10
    -177 11
    -191 12
    -205 13
    -219 13
    -233 14
    -247 15
    -261 16
    -275 17
    -290 17
    -304 18
    -319 19
    -334 20
    -349 20
    -364 21
    -379 22
    -394 23
    -409 23
    -425 24
    -440 25
    -456 26
    -471 27
    -487 27
    -503 28
    -519 29
    -535 30
    -551 30
    -568 31
    -584 32
    -600 33
    -617 33
    -634 34
    -650 35
    -667 36
    -684 36
    -701 37
    -718 38
    -735 39
    -752 39
    -770 40
    -787 41
    -805 41
    -822 42
    -840 43
    -858 44
    -876 44
    -894 45
    -912 46
    -930 46
    929 43
    911 42
    893 41
    875 41
    857 40
    839 39
    822 39
    804 38
    787 37
    769 37
    752 36
    735 35
    717 35
    700 34
    683 33
    666 33
    650 32
    633 31
    616 31
    600 30
    583 29
    567 28
    551 28
    534 27
    518 26
    502 26
    486 25
    471 24
    455 24
    439 23
    424 22
    408 21
    393 21
    378 20
    363 19
    348 19
    333 18
    318 17
    304 17
    289 16
    275 15
    260 14
    246 14
    232 13
    218 12
    204 11
    190 11
    176 10
    163 9
    149 9
    136 8
    123 7
    109 6
    96 6
    83 5
    71 4
    58 3
    45 3
    33 2
    21 1
    8 1
    -4 -0
    -16 -1
    -28 -2
    -39 -2
    -51 -3
    -62 -4
    -74 -5
    -85 -5
    -96 -6
    -107 -7
    -118 -8
    -129 -8
    -139 -9
    -150 -10
    -160 -11
    -171 -11
    -181 -12
    -191 -13
    -200 -14
    -210 -14
    -220 -15
    -229 -16
    -239 -17
    -248 -17
    -257 -18
    -266 -19
    -274 -20
    -283 -20
    -292 -21
    -300 -22
    -308 -23
    -316 -24
    -324 -24
    -332 -25
    -340 -26
    -347 -27
    -355 -27
    -362 -28
    -369 -29
    -376 -30
    -383 -30
    -389 -31
    -396 -32
    -402 -33
    -408 -33
    -415 -34
    -421 -35
    -426 -36
    -432 -36
    -437 -37
    -443 -38
    -448 -39
    -453 -39
    -458 -40
    -463 -41
    -467 -41
    -472 -42
    -476 -43
    -480 -44
    -484 -44
    -488 -45
    -492 -46
    -495 -47
    -499 -47
    -502 -48
    -505 -49
    -508 -49
    -511 -50
    -513 -51
    -516 -52
    -518 -52
    -520 -53
    -522 -54
    -524 -54
    -526 -55
    -528 -56
    -529 -56
    -530 -57
    -531 -58
    -532 -59
    -533 -59
    -534 -60
    -534 -61
    -535 -61
    -535 -62
    -535 -63
    -535 -63
    -534 -64
    -534 -65
    -533 -65
    -533 -66
    -532 -66
    -531 -67
    -530 -68
    -528 -68
    -527 -69
    -525 -70
    -523 -70
    -522 -71
    -520 -71
    -517 -72
    -515 -73
    -513 -73
    -510 -74
    -507 -74
    -504 -75
    -501 -76
    -498 -76
    -495 -77
    -491 -77
    -488 -78
    -484 -78
    -480 -79
    -476 -79
    -472 -80
    -468 -80
    -463 -81
    -459 -81
    -454 -82
    -449 -82
    -445 -83
    -440 -83
    -434 -84
    -429 -84
    -424 -85
    -418 -85
    -413 -86
    -407 -86
    -401 -87
    -395 -87
    -389 -87
    -383 -88
    -377 -88
    -370 -89
    -364 -89
    -357 -89
    -351 -90
    -344 -90
    -337 -90
    -330 -91
    -323 -91
    -316 -91
    -309 -92
    -301 -92
    -294 -92
    -287 -93
    -279 -93
    -271 -93
    -264 -94
    -256 -94
    -248 -94
    -240 -94
    -232 -95
    -224 -95
    -216 -95
    -208 -95
    -200 -95
    -191 -96
    -183 -96
    -175 -96
    -166 -96
    -158 -96
    -149 -97
    -141 -97
    -132 -97
    -123 -97
    -115 -97
    -106 -97
    -97 -97
    -89 -97
    -80 -97
    -71 -98
    -62 -98
    -53 -98
    -44 -98
    -36 -98
    -27 -98
    -18 -98
    -9 -98
    0 -98
    9 -98
    18 -98
    27 -98
    36 -98
    44 -98
    53 -98
    62 -98
    71 -98
    80 -97
    89 -97
    97 -97
    106 -97
    115 -97
    123 -97
    132 -97
    141 -97
    149 -97
    158 -96
    166 -96
    175 -96
    183 -96
    191 -96
    200 -95
    208 -95
    216 -95
    224 -95
    232 -95
    240 -94
    248 -94
    256 -94
    264 -94
    271 -93
    279 -93
    287 -93
    294 -92
    301 -92
    309 -92
    316 -91
    323 -91
    330 -91
    337 -90
    344 -90
    351 -90
    357 -89
    364 -89
    370 -89
    377 -88
    383 -88
    389 -87
    395 -87
    401 -87
    407 -86
    413 -86
    418 -85
    424 -85
    429 -84
    434 -84
    440 -83
    445 -83
    449 -82
    454 -82
    459 -81
    463 -81
    468 -80
    472 -80
    476 -79
    480 -79
    484 -78
    488 -78
    491 -77
    495 -77
    498 -76
    501 -76
    504 -75
    507 -74
    510 -74
    513 -73
    515 -73
    517 -72
    520 -71
    522 -71
    523 -70
    525 -70
    527 -69
    528 -68
    530 -68
    531 -67
    532 -66
    533 -66
    533 -65
    534 -65
    534 -64
    535 -63
    535 -63
    535 -62
    535 -61
    534 -61
    534 -60
    533 -59
    532 -59
    531 -58
    530 -57
    529 -56
    528 -56
    526 -55
    524 -54
    522 -54
    520 -53
    518 -52
    516 -52
    513 -51
    511 -50
    508 -49
    505 -49
    502 -48
    499 -47
    495 -47
    492 -46
    488 -45
    484 -44
    480 -44
    476 -43
    472 -42
    467 -41
    463 -41
    458 -40
    453 -39
    448 -39
    443 -38
    437 -37
    432 -36
    426 -36
    421 -35
    415 -34
    408 -33
    402 -33
    396 -32
    389 -31
    383 -30
    376 -30
    369 -29
    362 -28
    355 -27
    347 -27
    340 -26
    332 -25
    324 -24
    316 -24
    308 -23
    300 -22
    292 -21
    283 -20
    274 -20
    266 -19
    257 -18
    248 -17
    239 -17
    229 -16
    220 -15
    210 -14
    200 -14
    191 -13
    181 -12
    171 -11
    160 -11
    150 -10
    139 -9
    129 -8
    118 -8
    107 -7
    96 -6
    85 -5
    74 -5
    62 -4
    51 -3
    39 -2
    28 -2
    16 -1
    4 -0
    -8 1
    -21 1
    -33 2
    -45 3
    -58 3
    -71 4
    -83 5
    -96 6
    -109 6
    -123 7
    -136 8
    -149 9
    -163 9
    -176 10
    -190 11
    -204 11
    -218 12
    -232 13
    -246 14
    -260 14
    -275 15
    -289 16
    -304 17
    -318 17
    -333 18
    -348 19
    -363 19
    -378 20
    -393 21
    -408 21
    -424 22
    -439 23
    -455 24
    -471 24
    -486 25
    -502 26
    -518 26
    -534 27
    -551 28
    -567 28
    -583 29
    -600 30
    -616 31
    -633 31
    -650 32
    -666 33
    -683 33
    -700 34
    -717 35
    -735 35
    -752 36
    -769 37
    -787 37
    -804 38
    -822 39
    -839 39
    -857 40
    -875 41
    -893 41
    -911 42
    -929 43
    929 39
    910 38
    892 37
    874 37
    857 36
    839 36
    821 35
    803 34
    786 34
    769 33
    751 33
    734 32
    717 31
    700 31
    683 30
    666 30
    649 29
    632 28
    616 28
    599 27
    583 26
    566 26
    550 25
    534 25
    518 24
    502 23
    486 23
    470 22
    454 21
    439 21
    423 20
    408 20
    393 19
    377 18
    362 18
    347 17
    332 16
    318 16
    303 15
    288 14
    274 14
    260 13
    245 12
    231 12
    217 11
    203 10
    189 10
    176 9
    162 8
    149 8
    135 7
    122 6
    109 6
    96 5
    83 4
    70 4
    57 3
    45 2
    32 2
    20 1
    8 0
    -4 -0
    -16 -1
    -28 -2
    -40 -2
    -52 -3
    -63 -4
    -75 -4
    -86 -5
    -97 -6
    -108 -6
    -119 -7
    -130 -8
    -140 -8
    -151 -9
    -161 -10
    -171 -10
    -181 -11
    -191 -12
    -201 -12
    -211 -13
    -220 -14
    -230 -15
    -239 -15
    -248 -16
    -257 -17
    -266 -17
    -275 -18
    -284 -19
    -292 -19
    -301 -20
    -309 -21
    -317 -21
    -325 -22
    -333 -23
    -340 -23
    -348 -24
    -355 -25
    -363 -26
    -370 -26
    -377 -27
    -383 -28
    -390 -28
    -397 -29
    -403 -30
    -409 -30
    -415 -31
    -421 -32
    -427 -32
    -433 -33
    -438 -34
    -444 -34
    -449 -35
    -454 -36
    -459 -36
    -463 -37
    -468 -38
    -473 -38
    -477 -39
    -481 -40
    -485 -40
    -489 -41
    -493 -42
    -496 -42
    -499 -43
    -503 -44
    -506 -44
    -509 -45
    -511 -46
    -514 -46
    -517 -47
    -519 -48
    -521 -48
    -523 -49
    -525 -50
    -527 -50
    -528 -51
    -530 -51
    -531 -52
    -532 -53
    -533 -53
    -534 -54
    -534 -55
    -535 -55
    -535 -56
    -535 -56
    -535 -57
    -535 -58
    -535 -58
    -535 -59
    -534 -59
    -533 -60
    -532 -61
    -531 -61
    -530 -62
    -529 -62
    -527 -63
    -526 -63
    -524 -64
    -522 -64
    -520 -65
    -518 -66
    -516 -66
    -513 -67
    -510 -67
    -508 -68
    -505 -68
    -502 -69
    -499 -69
    -495 -70
    -492 -70
    -488 -71
    -484 -71
    -481 -72
    -477 -72
    -472 -73
    -468 -73
    -464 -74
    -459 -74
    -455 -75
    -450 -75
    -445 -75
    -440 -76
    -435 -76
    -430 -77
    -424 -77
    -419 -78
    -413 -78
    -407 -78
    -402 -79
    -396 -79
    -390 -79
    -383 -80
    -377 -80
    -371 -81
    -364 -81
    -358 -81
    -351 -82
    -344 -82
    -337 -82
    -330 -83
    -323 -83
    -316 -83
    -309 -84
    -302 -84
    -294 -84
    -287 -84
    -279 -85
    -272 -85
    -264 -85
    -256 -85
    -248 -86
    -240 -86
    -232 -86
    -224 -86
    -216 -86
    -208 -87
    -200 -87
    -192 -87
    -183 -87
    -175 -87
    -166 -88
    -158 -88
    -149 -88
    -141 -88
    -132 -88
    -124 -88
    -115 -88
    -106 -88
    -97 -89
    -89 -89
    -80 -89
    -71 -89
    -62 -89
    -53 -89
    -44 -89
    -36 -89
    -27 -89
    -18 -89
    -9 -89
    0 -89
    9 -89
    18 -89
    27 -89
    36 -89
    44 -89
    53 -89
    62 -89
    71 -89
    80 -89
    89 -89
    97 -89
    106 -88
    115 -88
    124 -88
    132 -88
    141 -88
    149 -88
    158 -88
    166 -88
    175 -87
    183 -87
    192 -87
    200 -87
    208 -87
    216 -86
    224 -86
    232 -86
    240 -86
    248 -86
    256 -85
    264 -85
    272 -85
    279 -85
    287 -84
    294 -84
    302 -84
    309 -84
    316 -83
    323 -83
    330 -83
    337 -82
    344 -82
    351 -82
    358 -81
    364 -81
    371 -81
    377 -80
    383 -80
    390 -79
    396 -79
    402 -79
    407 -78
    413 -78
    419 -78
    424 -77
    430 -77
    435 -76
    440 -76
    445 -75
    450 -75
    455 -75
    459 -74
    464 -74
    468 -73
    472 -73
    477 -72
    481 -72
    484 -71
    488 -71
    492 -70
    495 -70
    499 -69
    502 -69
    505 -68
    508 -68
    510 -67
    513 -67
    516 -66
    518 -66
    520 -65
    522 -64
    524 -64
    526 -63
    527 -63
    529 -62
    530 -62
    531 -61
    532 -61
    533 -60
    534 -59
    535 -59
    535 -58
    535 -58
    535 -57
    535 -56
    535 -56
    535 -55
    534 -55
    534 -54
    533 -53
    532 -53
    531 -52
    530 -51
    528 -51
    527 -50
    525 -50
    523 -49
    521 -48
    519 -48
    517 -47
    514 -46
    511 -46
    509 -45
    506 -44
    503 -44
    499 -43
    496 -42
    493 -42
    489 -41
    485 -40
    481 -40
    477 -39
    473 -38
    468 -38
    463 -37
    459 -36
    454 -36
    449 -35
    444 -34
    438 -34
    433 -33
    427 -32
    421 -32
    415 -31
    409 -30
    403 -30
    397 -29
    390 -28
    383 -28
    377 -27
    370 -26
    363 -26
    355 -25
    348 -24
    340 -23
    333 -23
    325 -22
    317 -21
    309 -21
    301 -20
    292 -19
    284 -19
    275 -18
    266 -17
    257 -17
    248 -16
    239 -15
    230 -15
    220 -14
    211 -13
    201 -12
    191 -12
    181 -11
    171 -10
    161 -10
    151 -9
    140 -8
    130 -8
    119 -7
    108 -6
    97 -6
    86 -5
    75 -4
    63 -4
    52 -3
    40 -2
    28 -2
    16 -1
    4 -0
    -8 0
    -20 1
    -32 2
    -45 2
    -57 3
    -70 4
    -83 4
    -96 5
    -109 6
    -122 6
    -135 7
    -149 8
    -162 8
    -176 9
    -189 10
    -203 10
    -217 11
    -231 12
    -245 12
    -260 13
    -274 14
    -288 14
    -303 15
    -318 16
    -332 16
    -347 17
    -362 18
    -377 18
    -393 19
    -408 20
    -423 20
    -439 21
    -454 21
    -470 22
    -486 23
    -502 23
    -518 24
    -534 25
    -550 25
    -566 26
    -583 26
    -599 27
    -616 28
    -632 28
    -649 29
    -666 30
    -683 30
    -700 31
    -717 31
    -734 32
    -751 33
    -769 33
    -786 34
    -803 34
    -821 35
    -839 36
    -857 36
    -874 37
    -892 37
    -910 38
    -929 39
    928 35
    910 34
    892 34
    874 33
    856 33
    838 32
    821 32
    803 31
    785 30
    768 30
    751 29
    733 29
    716 28
    699 28
    682 27
    665 27
    648 26
    632 25
    615 25
    598 24
    582 24
    566 23
    549 23
    533 22
    517 22
    501 21
    485 20
    469 20
    454 19
    438 19
    423 18
    407 18
    392 17
    377 16
    362 16
    347 15
    332 15
    317 14
    302 13
    288 13
    273 12
    259 12
    245 11
    230 11
    216 10
    203 9
    189 9
    175 8
    161 8
    148 7
    135 6
    121 6
    108 5
    95 5
    82 4
    69 3
    57 3
    44 2
    32 2
    19 1
    7 0
    -5 -0
    -17 -1
    -29 -1
    -41 -2
    -52 -3
    -64 -3
    -75 -4
    -86 -5
    -98 -5
    -109 -6
    -119 -6
    -130 -7
    -141 -8
    -151 -8
    -162 -9
    -172 -9
    -182 -10
    -192 -11
    -202 -11
    -212 -12
    -221 -13
    -231 -13
    -240 -14
    -249 -14
    -258 -15
    -267 -16
    -276 -16
    -284 -17
    -293 -17
    -301 -18
    -310 -19
    -318 -19
    -326 -20
    -333 -21
    -341 -21
    -349 -22
    -356 -22
    -363 -23
    -370 -24
    -377 -24
    -384 -25
    -391 -25
    -397 -26
    -404 -27
    -410 -27
    -416 -28
    -422 -29
    -428 -29
    -433 -30
    -439 -30
    -444 -31
    -449 -32
    -454 -32
    -459 -33
    -464 -33
    -469 -34
    -473 -35
    -477 -35
    -482 -36
    -486 -36
    -489 -37
    -493 -38
    -497 -38
    -500 -39
    -503 -39
    -506 -40
    -509 -41
    -512 -41
    -515 -42
    -517 -42
    -520 -43
    -522 -43
    -524 -44
    -526 -45
    -527 -45
    -529 -46
    -530 -46
    -531 -47
    -533 -47
    -534 -48
    -534 -49
    -535 -49
    -535 -50
    -536 -50
    -536 -51
    -536 -51
    -536 -52
    -536 -52
    -535 -53
    -535 -53
    -534 -54
    -533 -55
    -532 -55
    -531 -56
    -529 -56
    -528 -57
    -526 -57
    -525 -58
    -523 -58
    -521 -59
    -518 -59
    -516 -60
    -514 -60
    -511 -61
    -508 -61
    -505 -61
    -502 -62
    -499 -62
    -496 -63
    -492 -63
    -489 -64
    -485 -64
    -481 -65
    -477 -65
    -473 -65
    -469 -66
    -464 -66
    -460 -67
    -455 -67
    -450 -68
    -445 -68
    -440 -68
    -435 -69
    -430 -69
    -425 -69
    -419 -70
    -413 -70
    -408 -71
    -402 -71
    -396 -71
    -390 -72
    -384 -72
    -377 -72
    -371 -73
    -365 -73
    -358 -73
    -351 -74
    -345 -74
    -338 -74
    -331 -74
    -324 -75
    -317 -75
    -309 -75
    -302 -75
    -295 -76
    -287 -76
    -280 -76
    -272 -76
    -264 -77
    -256 -77
    -249 -77
    -241 -77
    -233 -78
    -225 -78
    -216 -78
    -208 -78
    -200 -78
    -192 -78
    -183 -79
    -175 -79
    -167 -79
    -158 -79
    -149 -79
    -141 -79
    -132 -79
    -124 -79
    -115 -80
    -106 -80
    -97 -80
    -89 -80
    -80 -80
    -71 -80
    -62 -80
    -53 -80
    -45 -80
    -36 -80
    -27 -80
    -18 -80
    -9 -80
    0 -80
    9 -80
    18 -80
    27 -80
    36 -80
    45 -80
    53 -80
    62 -80
    71 -80
    80 -80
    89 -80
    97 -80
    106 -80
    115 -80
    124 -79
    132 -79
    141 -79
    149 -79
    158 -79
    167 -79
    175 -79
    183 -79
    192 -78
    200 -78
    208 -78
    216 -78
    225 -78
    233 -78
    241 -77
    249 -77
    256 -77
    264 -77
    272 -76
    280 -76
    287 -76
    295 -76
    302 -75
    309 -75
    317 -75
    324 -75
    331 -74
    338 -74
    345 -74
    351 -74
    358 -73
    365 -73
    371 -73
    377 -72
    384 -72
    390 -72
    396 -71
    402 -71
    408 -71
    413 -70
    419 -70
    425 -69
    430 -69
    435 -69
    440 -68
    445 -68
    450 -68
    455 -67
    460 -67
    464 -66
    469 -66
    473 -65
    477 -65
    481 -65
    485 -64
    489 -64
    492 -63
    496 -63
    499 -62
    502 -62
    505 -61
    508 -61
    511 -61
    514 -60
    516 -60
    518 -59
    521 -59
    523 -58
    525 -58
    526 -57
    528 -57
    529 -56
    531 -56
    532 -55
    533 -55
    534 -54
    535 -53
    535 -53
    536 -52
    536 -52
    536 -51
    536 -51
    536 -50
    535 -50
    535 -49
    534 -49
    534 -48
    533 -47
    531 -47
    530 -46
    529 -46
    527 -45
    526 -45
    524 -44
    522 -43
    520 -43
    517 -42
    515 -42
    512 -41
    509 -41
    506 -40
    503 -39
    500 -39
    497 -38
    493 -38
    489 -37
    486 -36
    482 -36
    477 -35
    473 -35
    469 -34
    464 -33
    459 -33
    454 -32
    449 -32
    444 -31
    439 -30
    433 -30
    428 -29
    422 -29
    416 -28
    410 -27
    404 -27
    397 -26
    391 -25
    384 -25
    377 -24
    370 -24
    363 -23
    356 -22
    349 -22
    341 -21
    333 -21
    326 -20
    318 -19
    310 -19
    301 -18
    293 -17
    284 -17
    276 -16
    267 -16
    258 -15
    249 -14
    240 -14
    231 -13
    221 -13
    212 -12
    202 -11
    192 -11
    182 -10
    172 -9
    162 -9
    151 -8
    141 -8
    130 -7
    119 -6
    109 -6
    98 -5
    86 -5
    75 -4
    64 -3
    52 -3
    41 -2
    29 -1
    17 -1
    5 -0
    -7 0
    -19 1
    -32 2
    -44 2
    -57 3
    -69 3
    -82 4
    -95 5
    -108 5
    -121 6
    -135 6
    -148 7
    -161 8
    -175 8
    -189 9
    -203 9
    -216 10
    -230 11
    -245 11
    -259 12
    -273 12
    -288 13
    -302 13
    -317 14
    -332 15
    -347 15
    -362 16
    -377 16
    -392 17
    -407 18
    -423 18
    -438 19
    -454 19
    -469 20
    -485 20
    -501 21
    -517 22
    -533 22
    -549 23
    -566 23
    -582 24
    -598 24
    -615 25
    -632 25
    -648 26
    -665 27
    -682 27
    -699 28
    -716 28
    -733 29
    -751 29
    -768 30
    -785 30
    -803 31
    -821 32
    -838 32
    -856 33
    -874 33
    -892 34
    -910 34
    -928 35
    927 31
    909 30
    891 30
    873 29
    855 29
    838 29
    820 28
    802 28
    785 27
    767 27
    750 26
    733 26
    716 25
    699 25
    682 24
    665 24
    648 23
    631 23
    614 22
    598 22
    581 21
    565 21
    549 20
    533 20
    516 19
    501 19
    485 18
    469 18
    453 17
    438 17
    422 16
    407 16
    391 15
    376 15
    361 14
    346 14
    331 13
    316 12
    302 12
    287 11
    273 11
    258 10
    244 10
    230 9
    216 9
    202 8
    188 8
    174 7
    161 7
    147 6
    134 6
    121 5
    108 5
    94 4
    82 4
    69 3
    56 2
    43 2
    31 1
    19 1
    6 0
    -6 -0
    -18 -1
    -29 -1
    -41 -2
    -53 -2
    -64 -3
    -76 -4
    -87 -4
    -98 -5
    -109 -5
    -120 -6
    -131 -6
    -141 -7
    -152 -7
    -162 -8
    -172 -8
    -183 -9
    -193 -10
    -202 -10
    -212 -11
    -222 -11
    -231 -12
    -240 -12
    -250 -13
    -259 -13
    -268 -14
    -276 -14
    -285 -15
    -294 -16
    -302 -16
    -310 -17
    -318 -17
    -326 -18
    -334 -18
    -342 -19
    -349 -19
    -357 -20
    -364 -20
    -371 -21
    -378 -22
    -385 -22
    -391 -23
    -398 -23
    -404 -24
    -410 -24
    -417 -25
    -422 -25
    -428 -26
    -434 -26
    -439 -27
    -445 -28
    -450 -28
    -455 -29
    -460 -29
    -465 -30
    -469 -30
    -474 -31
    -478 -31
    -482 -32
    -486 -32
    -490 -33
    -494 -33
    -497 -34
    -501 -35
    -504 -35
    -507 -36
    -510 -36
    -513 -37
    -515 -37
    -518 -38
    -520 -38
    -522 -39
    -524 -39
    -526 -40
    -528 -40
    -529 -41
    -531 -41
    -532 -42
    -533 -42
    -534 -43
    -535 -43
    -535 -44
    -536 -44
    -536 -45
    -536 -45
    -536 -46
    -536 -46
    -536 -47
    -536 -47
    -535 -48
    -534 -48
    -533 -48
    -532 -49
    -531 -49
    -530 -50
    -528 -50
    -527 -51
    -525 -51
    -523 -52
    -521 -52
    -519 -53
    -517 -53
    -514 -53
    -511 -54
    -509 -54
    -506 -55
    -503 -55
    -499 -55
    -496 -56
    -493 -56
    -489 -57
    -485 -57
    -481 -57
    -477 -58
    -473 -58
    -469 -59
    -465 -59
    -460 -59
    -455 -60
    -451 -60
    -446 -60
    -441 -61
    -436 -61
    -430 -61
    -425 -62
    -419 -62
    -414 -62
    -408 -63
    -402 -63
    -396 -63
    -390 -64
    -384 -64
    -378 -64
    -371 -65
    -365 -65
    -358 -65
    -352 -65
    -345 -66
    -338 -66
    -331 -66
    -324 -66
    -317 -67
    -310 -67
    -302 -67
    -295 -67
    -287 -68
    -280 -68
    -272 -68
    -264 -68
    -257 -68
    -249 -69
    -241 -69
    -233 -69
    -225 -69
    -217 -69
    -208 -69
    -200 -70
    -192 -70
    -184 -70
    -175 -70
    -167 -70
    -158 -70
    -150 -70
    -141 -71
    -132 -71
    -124 -71
    -115 -71
    -106 -71
    -98 -71
    -89 -71
    -80 -71
    -71 -71
    -62 -71
    -53 -71
    -45 -71
    -36 -71
    -27 -71
    -18 -71
    -9 -71
    0 -71
    9 -71
    18 -71
    27 -71
    36 -71
    45 -71
    53 -71
    62 -71
    71 -71
    80 -71
    89 -71
    98 -71
    106 -71
    115 -71
    124 -71
    132 -71
    141 -71
    150 -70
    158 -70
    167 -70
    175 -70
    184 -70
    192 -70
    200 -70
    208 -69
    217 -69
    225 -69
    233 -69
    241 -69
    249 -69
    257 -68
    264 -68
    272 -68
    280 -68
    287 -68
    295 -67
    302 -67
    310 -67
    317 -67
    324 -66
    331 -66
    338 -66
    345 -66
    352 -65
    358 -65
    365 -65
    371 -65
    378 -64
    384 -64
    390 -64
    396 -63
    402 -63
    408 -63
    414 -62
    419 -62
    425 -62
    430 -61
    436 -61
    441 -61
    446 -60
    451 -60
    455 -60
    460 -59
    465 -59
    469 -59
    473 -58
    477 -58
    481 -57
    485 -57
    489 -57
    493 -56
    496 -56
    499 -55
    503 -55
    506 -55
    509 -54
    511 -54
    514 -53
    517 -53
    519 -53
    521 -52
    523 -52
    525 -51
    527 -51
    528 -50
    530 -50
    531 -49
    532 -49
    533 -48
    534 -48
    535 -48
    536 -47
    536 -47
    536 -46
    536 -46
    536 -45
    536 -45
    536 -44
    535 -44
    535 -43
    534 -43
    533 -42
    532 -42
    531 -41
    529 -41
    528 -40
    526 -40
    524 -39
    522 -39
    520 -38
    518 -38
    515 -37
    513 -37
    510 -36
    507 -36
    504 -35
    501 -35
    497 -34
    494 -33
    490 -33
    486 -32
    482 -32
    478 -31
    474 -31
    469 -30
    465 -30
    460 -29
    455 -29
    450 -28
    445 -28
    439 -27
    434 -26
    428 -26
    422 -25
    417 -25
    410 -24
    404 -24
    398 -23
    391 -23
    385 -22
    378 -22
    371 -21
    364 -20
    357 -20
    349 -19
    342 -19
    334 -18
    326 -18
    318 -17
    310 -17
    302 -16
    294 -16
    285 -15
    276 -14
    268 -14
    259 -13
    250 -13
    240 -12
    231 -12
    222 -11
    212 -11
    202 -10
    193 -10
    183 -9
    172 -8
    162 -8
    152 -7
    141 -7
    131 -6
    120 -6
    109 -5
    98 -5
    87 -4
    76 -4
    64 -3
    53 -2
    41 -2
    29 -1
    18 -1
    6 -0
    -6 0
    -19 1
    -31 1
    -43 2
    -56 2
    -69 3
    -82 4
    -94 4
    -108 5
    -121 5
    -134 6
    -147 6
    -161 7
    -174 7
    -188 8
    -202 8
    -216 9
    -230 9
    -244 10
    -258 10
    -273 11
    -287 11
    -302 12
    -316 12
    -331 13
    -346 14
    -361 14
    -376 15
    -391 15
    -407 16
    -422 16
    -438 17
    -453 17
    -469 18
    -485 18
    -501 19
    -516 19
    -533 20
    -549 20
    -565 21
    -581 21
    -598 22
    -614 22
    -631 23
    -648 23
    -665 24
    -682 24
    -699 25
    -716 25
    -733 26
    -750 26
    -767 27
    -785 27
    -802 28
    -820 28
    -838 29
    -855 29
    -873 29
    -891 30
    -909 30
    -927 31
    927 27
    909 27
    891 26
    873 26
    855 25
    837 25
    820 25
    802 24
    784 24
    767 23
    750 23
    732 22
    715 22
    698 22
    681 21
    664 21
    647 20
    631 20
    614 19
    597 19
    581 18
    565 18
    548 18
    532 17
    516 17
    500 16
    484 16
    468 15
    453 15
    437 15
    422 14
    406 14
    391 13
    376 13
    361 12
    346 12
    331 11
    316 11
    301 10
    287 10
    272 10
    258 9
    244 9
    229 8
    215 8
    201 7
    188 7
    174 6
    160 6
    147 5
    133 5
    120 4
    107 4
    94 4
    81 3
    68 3
    56 2
    43 2
    31 1
    18 1
    6 0
    -6 -0
    -18 -1
    -30 -1
    -42 -2
    -53 -2
    -65 -3
    -76 -3
    -87 -4
    -99 -4
    -110 -5
    -121 -5
    -131 -5
    -142 -6
    -152 -6
    -163 -7
    -173 -7
    -183 -8
    -193 -8
    -203 -9
    -213 -9
    -222 -10
    -232 -10
    -241 -11
    -250 -11
    -259 -12
    -268 -12
    -277 -13
    -286 -13
    -294 -14
    -302 -14
    -311 -15
    -319 -15
    -327 -16
    -334 -16
    -342 -17
    -350 -17
    -357 -17
    -364 -18
    -371 -18
    -378 -19
    -385 -19
    -392 -20
    -398 -20
    -405 -21
    -411 -21
    -417 -22
    -423 -22
    -429 -23
    -434 -23
    -440 -24
    -445 -24
    -450 -25
    -456 -25
    -460 -26
    -465 -26
    -470 -27
    -474 -27
    -479 -27
    -483 -28
    -487 -28
    -490 -29
    -494 -29
    -498 -30
    -501 -30
    -504 -31
    -507 -31
    -510 -32
    -513 -32
    -516 -33
    -518 -33
    -521 -33
    -523 -34
    -525 -34
    -527 -35
    -528 -35
    -530 -36
    -531 -36
    -532 -37
    -534 -37
    -535 -37
    -535 -38
    -536 -38
    -536 -39
    -537 -39
    -537 -40
    -537 -40
    -537 -40
    -537 -41
    -536 -41
    -535 -42
    -535 -42
    -534 -42
    -533 -43
    -532 -43
    -530 -44
    -529 -44
    -527 -44
    -525 -45
    -524 -45
    -521 -46
    -519 -46
    -517 -46
    -514 -47
    -512 -47
    -509 -48
    -506 -48
    -503 -48
    -500 -49
    -497 -49
    -493 -49
    -489 -50
    -486 -50
    -482 -50
    -478 -51
    -474 -51
    -469 -51
    -465 -52
    -460 -52
    -456 -52
    -451 -53
    -446 -53
    -441 -53
    -436 -54
    -431 -54
    -425 -54
    -420 -54
    -414 -55
    -408 -55
    -403 -55
    -397 -56
    -391 -56
    -384 -56
    -378 -56
    -372 -57
    -365 -57
    -359 -57
    -352 -57
    -345 -58
    -338 -58
    -331 -58
    -324 -58
    -317 -58
    -310 -59
    -302 -59
    -295 -59
    -288 -59
    -280 -59
    -272 -60
    -265 -60
    -257 -60
    -249 -60
    -241 -60
    -233 -60
    -225 -61
    -217 -61
    -209 -61
    -200 -61
    -192 -61
    -184 -61
    -175 -61
    -167 -61
    -158 -62
    -150 -62
    -141 -62
    -132 -62
    -124 -62
    -115 -62
    -106 -62
    -98 -62
    -89 -62
    -80 -62
    -71 -62
    -62 -62
    -53 -62
    -45 -62
    -36 -62
    -27 -62
    -18 -62
    -9 -62
    0 -62
    9 -62
    18 -62
    27 -62
    36 -62
    45 -62
    53 -62
    62 -62
    71 -62
    80 -62
    89 -62
    98 -62
    106 -62
    115 -62
    124 -62
    132 -62
    141 -62
    150 -62
    158 -62
    167 -61
    175 -61
    184 -61
    192 -61
    200 -61
    209 -61
    217 -61
    225 -61
    233 -60
    241 -60
    249 -60
    257 -60
    265 -60
    272 -60
    280 -59
    288 -59
    295 -59
    302 -59
    310 -59
    317 -58
    324 -58
    331 -58
    338 -58
    345 -58
    352 -57
    359 -57
    365 -57
    372 -57
    378 -56
    384 -56
    391 -56
    397 -56
    403 -55
    408 -55
    414 -55
    420 -54
    425 -54
    431 -54
    436 -54
    441 -53
    446 -53
    451 -53
    456 -52
    460 -52
    465 -52
    469 -51
    474 -51
    478 -51
    482 -50
    486 -50
    489 -50
    493 -49
    497 -49
    500 -49
    503 -48
    506 -48
    509 -48
    512 -47
    514 -47
    517 -46
    519 -46
    521 -46
    524 -45
    525 -45
    527 -44
    529 -44
    530 -44
    532 -43
    533 -43
    534 -42
    535 -42
    535 -42
    536 -41
    537 -41
    537 -40
    537 -40
    537 -40
    537 -39
    536 -39
    536 -38
    535 -38
    535 -37
    534 -37
    532 -37
    531 -36
    530 -36
    528 -35
    527 -35
    525 -34
    523 -34
    521 -33
    518 -33
    516 -33
    513 -32
    510 -32
    507 -31
    504 -31
    501 -30
    498 -30
    494 -29
    490 -29
    487 -28
    483 -28
    479 -27
    474 -27
    470 -27
    465 -26
    460 -26
    456 -25
    450 -25
    445 -24
    440 -24
    434 -23
    429 -23
    423 -22
    417 -22
    411 -21
    405 -21
    398 -20
    392 -20
    385 -19
    378 -19
    371 -18
    364 -18
    357 -17
    350 -17
    342 -17
    334 -16
    327 -16
    319 -15
    311 -15
    302 -14
    294 -14
    286 -13
    277 -13
    268 -12
    259 -12
    250 -11
    241 -11
    232 -10
    222 -10
    213 -9
    203 -9
    193 -8
    183 -8
    173 -7
    163 -7
    152 -6
    142 -6
    131 -5
    121 -5
    110 -5
    99 -4
    87 -4
    76 -3
    65 -3
    53 -2
    42 -2
    30 -1
    18 -1
    6 -0
    -6 0
    -18 1
    -31 1
    -43 2
    -56 2
    -68 3
    -81 3
    -94 4
    -107 4
    -120 4
    -133 5
    -147 5
    -160 6
    -174 6
    -188 7
    -201 7
    -215 8
    -229 8
    -244 9
    -258 9
    -272 10
    -287 10
    -301 10
    -316 11
    -331 11
    -346 12
    -361 12
    -376 13
    -391 13
    -406 14
    -422 14
    -437 15
    -453 15
    -468 15
    -484 16
    -500 16
    -516 17
    -532 17
    -548 18
    -565 18
    -581 18
    -597 19
    -614 19
    -631 20
    -647 20
    -664 21
    -681 21
    -698 22
    -715 22
    -732 22
    -750 23
    -767 23
    -784 24
    -802 24
    -820 25
    -837 25
    -855 25
    -873 26
    -891 26
    -909 27
    -927 27
    927 23
    909 23
    890 22
    873 22
    855 22
    837 21
    819 21
    802 21
    784 20
    767 20
    749 20
    732 19
    715 19
    698 18
    681 18
    664 18
    647 17
    630 17
    614 17
    597 16
    581 16
    564 15
    548 15
    532 15
    516 14
    500 14
    484 14
    468 13
    452 13
    437 12
    421 12
    406 12
    390 11
    375 11
    360 10
    345 10
    330 10
    316 9
    301 9
    286 9
    272 8
    257 8
    243 7
    229 7
    215 7
    201 6
    187 6
    174 5
    160 5
    146 5
    133 4
    120 4
    107 3
    94 3
    81 3
    68 2
    55 2
    43 1
    30 1
    18 1
    6 0
    -7 -0
    -19 -1
    -30 -1
    -42 -1
    -54 -2
    -65 -2
    -77 -3
    -88 -3
    -99 -3
    -110 -4
    -121 -4
    -132 -5
    -142 -5
    -153 -6
    -163 -6
    -173 -6
    -184 -7
    -194 -7
    -203 -8
    -213 -8
    -223 -8
    -232 -9
    -241 -9
    -251 -10
    -260 -10
    -269 -10
    -277 -11
    -286 -11
    -294 -12
    -303 -12
    -311 -13
    -319 -13
    -327 -13
    -335 -14
    -343 -14
    -350 -15
    -357 -15
    -365 -15
    -372 -16
    -379 -16
    -386 -17
    -392 -17
    -399 -17
    -405 -18
    -411 -18
    -417 -19
    -423 -19
    -429 -20
    -435 -20
    -440 -20
    -446 -21
    -451 -21
    -456 -22
    -461 -22
    -466 -22
    -470 -23
    -475 -23
    -479 -24
    -483 -24
    -487 -24
    -491 -25
    -495 -25
    -498 -26
    -502 -26
    -505 -26
    -508 -27
    -511 -27
    -514 -28
    -516 -28
    -519 -28
    -521 -29
    -523 -29
    -525 -29
    -527 -30
    -529 -30
    -530 -31
    -532 -31
    -533 -31
    -534 -32
    -535 -32
    -536 -32
    -536 -33
    -537 -33
    -537 -34
    -537 -34
    -537 -34
    -537 -35
    -537 -35
    -536 -35
    -536 -36
    -535 -36
    -534 -36
    -533 -37
    -532 -37
    -531 -37
    -529 -38
    -528 -38
    -526 -38
    -524 -39
    -522 -39
    -520 -39
    -517 -40
    -515 -40
    -512 -40
    -509 -41
    -506 -41
    -503 -41
    -500 -42
    -497 -42
    -493 -42
    -490 -43
    -486 -43
    -482 -43
    -478 -43
    -474 -44
    -470 -44
    -465 -44
    -461 -45
    -456 -45
    -451 -45
    -446 -45
    -441 -46
    -436 -46
    -431 -46
    -426 -46
    -420 -47
    -414 -47
    -409 -47
    -403 -47
    -397 -48
    -391 -48
    -385 -48
    -378 -48
    -372 -49
    -365 -49
    -359 -49
    -352 -49
    -345 -49
    -338 -50
    -331 -50
    -324 -50
    -317 -50
    -310 -50
    -303 -50
    -295 -51
    -288 -51
    -280 -51
    -272 -51
    -265 -51
    -257 -51
    -249 -52
    -241 -52
    -233 -52
    -225 -52
    -217 -52
    -209 -52
    -200 -52
    -192 -52
    -184 -52
    -175 -53
    -167 -53
    -158 -53
    -150 -53
    -141 -53
    -133 -53
    -124 -53
    -115 -53
    -106 -53
    -98 -53
    -89 -53
    -80 -53
    -71 -53
    -62 -53
    -53 -53
    -45 -54
    -36 -54
    -27 -54
    -18 -54
    -9 -54
    0 -54
    9 -54
    18 -54
    27 -54
    36 -54
    45 -54
    53 -53
    62 -53
    71 -53
    80 -53
    89 -53
    98 -53
    106 -53
    115 -53
    124 -53
    133 -53
    141 -53
    150 -53
    158 -53
    167 -53
    175 -53
    184 -52
    192 -52
    200 -52
    209 -52
    217 -52
    225 -52
    233 -52
    241 -52
    249 -52
    257 -51
    265 -51
    272 -51
    280 -51
    288 -51
    295 -51
    303 -50
    310 -50
    317 -50
    324 -50
    331 -50
    338 -50
    345 -49
    352 -49
    359 -49
    365 -49
    372 -49
    378 -48
    385 -48
    391 -48
    397 -48
    403 -47
    409 -47
    414 -47
    420 -47
    426 -46
    431 -46
    436 -46
    441 -46
    446 -45
    451 -45
    456 -45
    461 -45
    465 -44
    470 -44
    474 -44
    478 -43
    482 -43
    486 -43
    490 -43
    493 -42
    497 -42
    500 -42
    503 -41
    506 -41
    509 -41
    512 -40
    515 -40
    517 -40
    520 -39
    522 -39
    524 -39
    526 -38
    528 -38
    529 -38
    531 -37
    532 -37
    533 -37
    534 -36
    535 -36
    536 -36
    536 -35
    537 -35
    537 -35
    537 -34
    537 -34
    537 -34
    537 -33
    536 -33
    536 -32
    535 -32
    534 -32
    533 -31
    532 -31
    530 -31
    529 -30
    527 -30
    525 -29
    523 -29
    521 -29
    519 -28
    516 -28
    514 -28
    511 -27
    508 -27
    505 -26
    502 -26
    498 -26
    495 -25
    491 -25
    487 -24
    483 -24
    479 -24
    475 -23
    470 -23
    466 -22
    461 -22
    456 -22
    451 -21
    446 -21
    440 -20
    435 -20
    429 -20
    423 -19
    417 -19
    411 -18
    405 -18
    399 -17
    392 -17
    386 -17
    379 -16
    372 -16
    365 -15
    357 -15
    350 -15
    343 -14
    335 -14
    327 -13
    319 -13
    311 -13
    303 -12
    294 -12
    286 -11
    277 -11
    269 -10
    260 -10
    251 -10
    241 -9
    232 -9
    223 -8
    213 -8
    203 -8
    194 -7
    184 -7
    173 -6
    163 -6
    153 -6
    142 -5
    132 -5
    121 -4
    110 -4
    99 -3
    88 -3
    77 -3
    65 -2
    54 -2
    42 -1
    30 -1
    19 -1
    7 -0
    -6 0
    -18 1
    -30 1
    -43 1
    -55 2
    -68 2
    -81 3
    -94 3
    -107 3
    -120 4
    -133 4
    -146 5
    -160 5
    -174 5
    -187 6
    -201 6
    -215 7
    -229 7
    -243 7
    -257 8
    -272 8
    -286 9
    -301 9
    -316 9
    -330 10
    -345 10
    -360 10
    -375 11
    -390 11
    -406 12
    -421 12
    -437 12
    -452 13
    -468 13
    -484 14
    -500 14
    -516 14
    -532 15
    -548 15
    -564 15
    -581 16
    -597 16
    -614 17
    -630 17
    -647 17
    -664 18
    -681 18
    -698 18
    -715 19
    -732 19
    -749 20
    -767 20
    -784 20
    -802 21
    -819 21
    -837 21
    -855 22
    -873 22
    -890 22
    -909 23
    -927 23
    926 19
    908 19
    890 19
    872 18
    854 18
    837 18
    819 17
    801 17
    784 17
    766 17
    749 16
    732 16
    714 16
    697 15
    680 15
    663 15
    647 14
    630 14
    613 14
    597 13
    580 13
    564 13
    548 13
    531 12
    515 12
    499 12
    483 11
    468 11
    452 11
    436 10
    421 10
    405 10
    390 9
    375 9
    360 9
    345 8
    330 8
    315 8
    300 7
    286 7
    271 7
    257 6
    243 6
    229 6
    215 5
    201 5
    187 5
    173 4
    160 4
    146 4
    133 3
    119 3
    106 3
    93 2
    80 2
    67 2
    55 1
    42 1
    30 1
    17 0
    5 0
    -7 -0
    -19 -1
    -31 -1
    -43 -1
    -54 -2
    -66 -2
    -77 -2
    -88 -3
    -99 -3
    -110 -3
    -121 -4
    -132 -4
    -143 -4
    -153 -5
    -164 -5
    -174 -5
    -184 -6
    -194 -6
    -204 -6
    -213 -7
    -223 -7
    -232 -7
    -242 -8
    -251 -8
    -260 -8
    -269 -9
    -278 -9
    -286 -9
    -295 -10
    -303 -10
    -311 -10
    -320 -11
    -327 -11
    -335 -11
    -343 -12
    -350 -12
    -358 -13
    -365 -13
    -372 -13
    -379 -14
    -386 -14
    -393 -14
    -399 -15
    -406 -15
    -412 -15
    -418 -16
    -424 -16
    -430 -16
    -435 -17
    -441 -17
    -446 -17
    -451 -18
    -456 -18
    -461 -18
    -466 -19
    -471 -19
    -475 -19
    -479 -20
    -483 -20
    -487 -20
    -491 -21
    -495 -21
    -499 -21
    -502 -22
    -505 -22
    -508 -22
    -511 -23
    -514 -23
    -517 -23
    -519 -24
    -521 -24
    -523 -24
    -525 -25
    -527 -25
    -529 -25
    -531 -26
    -532 -26
    -533 -26
    -534 -26
    -535 -27
    -536 -27
    -537 -27
    -537 -28
    -537 -28
    -538 -28
    -538 -29
    -538 -29
    -537 -29
    -537 -29
    -536 -30
    -535 -30
    -535 -30
    -534 -31
    -532 -31
    -531 -31
    -530 -32
    -528 -32
    -526 -32
    -524 -32
    -522 -33
    -520 -33
    -518 -33
    -515 -33
    -512 -34
    -510 -34
    -507 -34
    -504 -34
    -500 -35
    -497 -35
    -494 -35
    -490 -36
    -486 -36
    -482 -36
    -478 -36
    -474 -36
    -470 -37
    -466 -37
    -461 -37
    -456 -37
    -452 -38
    -447 -38
    -442 -38
    -436 -38
    -431 -38
    -426 -39
    -420 -39
    -415 -39
    -409 -39
    -403 -40
    -397 -40
    -391 -40
    -385 -40
    -378 -40
    -372 -40
    -366 -41
    -359 -41
    -352 -41
    -345 -41
    -339 -41
    -332 -41
    -325 -42
    -317 -42
    -310 -42
    -303 -42
    -295 -42
    -288 -42
    -280 -42
    -273 -43
    -265 -43
    -257 -43
    -249 -43
    -241 -43
    -233 -43
    -225 -43
    -217 -43
    -209 -43
    -201 -44
    -192 -44
    -184 -44
    -175 -44
    -167 -44
    -158 -44
    -150 -44
    -141 -44
    -133 -44
    -124 -44
    -115 -44
    -107 -44
    -98 -44
    -89 -44
    -80 -45
    -71 -45
    -62 -45
    -54 -45
    -45 -45
    -36 -45
    -27 -45
    -18 -45
    -9 -45
    0 -45
    9 -45
    18 -45
    27 -45
    36 -45
    45 -45
    54 -45
    62 -45
    71 -45
    80 -45
    89 -44
    98 -44
    107 -44
    115 -44
    124 -44
    133 -44
    141 -44
    150 -44
    158 -44
    167 -44
    175 -44
    184 -44
    192 -44
    201 -44
    209 -43
    217 -43
    225 -43
    233 -43
    241 -43
    249 -43
    257 -43
    265 -43
    273 -43
    280 -42
    288 -42
    295 -42
    303 -42
    310 -42
    317 -42
    325 -42
    332 -41
    339 -41
    345 -41
    352 -41
    359 -41
    366 -41
    372 -40
    378 -40
    385 -40
    391 -40
    397 -40
    403 -40
    409 -39
    415 -39
    420 -39
    426 -39
    431 -38
    436 -38
    442 -38
    447 -38
    452 -38
    456 -37
    461 -37
    466 -37
    470 -37
    474 -36
    478 -36
    482 -36
    486 -36
    490 -36
    494 -35
    497 -35
    500 -35
    504 -34
    507 -34
    510 -34
    512 -34
    515 -33
    518 -33
    520 -33
    522 -33
    524 -32
    526 -32
    528 -32
    530 -32
    531 -31
    532 -31
    534 -31
    535 -30
    535 -30
    536 -30
    537 -29
    537 -29
    538 -29
    538 -29
    538 -28
    537 -28
    537 -28
    537 -27
    536 -27
    535 -27
    534 -26
    533 -26
    532 -26
    531 -26
    529 -25
    527 -25
    525 -25
    523 -24
    521 -24
    519 -24
    517 -23
    514 -23
    511 -23
    508 -22
    505 -22
    502 -22
    499 -21
    495 -21
    491 -21
    487 -20
    483 -20
    479 -20
    475 -19
    471 -19
    466 -19
    461 -18
    456 -18
    451 -18
    446 -17
    441 -17
    435 -17
    430 -16
    424 -16
    418 -16
    412 -15
    406 -15
    399 -15
    393 -14
    386 -14
    379 -14
    372 -13
    365 -13
    358 -13
    350 -12
    343 -12
    335 -11
    327 -11
    320 -11
    311 -10
    303 -10
    295 -10
    286 -9
    278 -9
    269 -9
    260 -8
    251 -8
    242 -8
    232 -7
    223 -7
    213 -7
    204 -6
    194 -6
    184 -6
    174 -5
    164 -5
    153 -5
    143 -4
    132 -4
    121 -4
    110 -3
    99 -3
    88 -3
    77 -2
    66 -2
    54 -2
    43 -1
    31 -1
    19 -1
    7 -0
    -5 0
    -17 0
    -30 1
    -42 1
    -55 1
    -67 2
    -80 2
    -93 2
    -106 3
    -119 3
    -133 3
    -146 4
    -160 4
    -173 4
    -187 5
    -201 5
    -215 5
    -229 6
    -243 6
    -257 6
    -271 7
    -286 7
    -300 7
    -315 8
    -330 8
    -345 8
    -360 9
    -375 9
    -390 9
    -405 10
    -421 10
    -436 10
    -452 11
    -468 11
    -483 11
    -499 12
    -515 12
    -531 12
    -548 13
    -564 13
    -580 13
    -597 13
    -613 14
    -630 14
    -647 14
    -663 15
    -680 15
    -697 15
    -714 16
    -732 16
    -749 16
    -766 17
    -784 17
    -801 17
    -819 17
    -837 18
    -854 18
    -872 18
    -890 19
    -908 19
    -926 19
    926 15
    908 15
    890 15
    872 15
    854 14
    836 14
    819 14
    801 14
    783 14
    766 13
    749 13
    731 13
    714 13
    697 12
    680 12
    663 12
    646 12
    630 11
    613 11
    596 11
    580 11
    564 10
    547 10
    531 10
    515 10
    499 9
    483 9
    467 9
    452 9
    436 8
    421 8
    405 8
    390 7
    375 7
    360 7
    345 7
    330 6
    315 6
    300 6
    286 6
    271 5
    257 5
    243 5
    228 5
    214 4
    200 4
    187 4
    173 4
    159 3
    146 3
    132 3
    119 3
    106 2
    93 2
    80 2
    67 1
    54 1
    42 1
    29 1
    17 0
    5 0
    -7 -0
    -19 -0
    -31 -1
    -43 -1
    -54 -1
    -66 -2
    -77 -2
    -89 -2
    -100 -2
    -111 -3
    -122 -3
    -132 -3
    -143 -3
    -153 -4
    -164 -4
    -174 -4
    -184 -5
    -194 -5
    -204 -5
    -214 -5
    -223 -6
    -233 -6
    -242 -6
    -251 -6
    -260 -7
    -269 -7
    -278 -7
    -287 -8
    -295 -8
    -304 -8
    -312 -8
    -320 -9
    -328 -9
    -336 -9
    -343 -9
    -351 -10
    -358 -10
    -365 -10
    -373 -11
    -379 -11
    -386 -11
    -393 -11
    -399 -12
    -406 -12
    -412 -12
    -418 -12
    -424 -13
    -430 -13
    -436 -13
    -441 -14
    -446 -14
    -452 -14
    -457 -14
    -462 -15
    -466 -15
    -471 -15
    -475 -15
    -480 -16
    -484 -16
    -488 -16
    -492 -17
    -495 -17
    -499 -17
    -502 -17
    -505 -18
    -509 -18
    -511 -18
    -514 -18
    -517 -19
    -519 -19
    -522 -19
    -524 -19
    -526 -20
    -528 -20
    -529 -20
    -531 -20
    -532 -21
    -534 -21
    -535 -21
    -536 -21
    -536 -22
    -537 -22
    -537 -22
    -538 -22
    -538 -23
    -538 -23
    -538 -23
    -537 -23
    -537 -24
    -536 -24
    -536 -24
    -535 -24
    -534 -25
    -533 -25
    -531 -25
    -530 -25
    -528 -25
    -526 -26
    -524 -26
    -522 -26
    -520 -26
    -518 -27
    -515 -27
    -513 -27
    -510 -27
    -507 -27
    -504 -28
    -501 -28
    -497 -28
    -494 -28
    -490 -28
    -486 -29
    -483 -29
    -479 -29
    -474 -29
    -470 -29
    -466 -30
    -461 -30
    -457 -30
    -452 -30
    -447 -30
    -442 -30
    -437 -31
    -431 -31
    -426 -31
    -420 -31
    -415 -31
    -409 -31
    -403 -32
    -397 -32
    -391 -32
    -385 -32
    -379 -32
    -372 -32
    -366 -33
    -359 -33
    -352 -33
    -346 -33
    -339 -33
    -332 -33
    -325 -33
    -318 -33
    -310 -34
    -303 -34
    -295 -34
    -288 -34
    -280 -34
    -273 -34
    -265 -34
    -257 -34
    -249 -34
    -241 -34
    -233 -35
    -225 -35
    -217 -35
    -209 -35
    -201 -35
    -192 -35
    -184 -35
    -175 -35
    -167 -35
    -159 -35
    -150 -35
    -141 -35
    -133 -35
    -124 -35
    -115 -35
    -107 -36
    -98 -36
    -89 -36
    -80 -36
    -71 -36
    -62 -36
    -54 -36
    -45 -36
    -36 -36
    -27 -36
    -18 -36
    -9 -36
    0 -36
    9 -36
    18 -36
    27 -36
    36 -36
    45 -36
    54 -36
    62 -36
    71 -36
    80 -36
    89 -36
    98 -36
    107 -36
    115 -35
    124 -35
    133 -35
    141 -35
    150 -35
    159 -35
    167 -35
    175 -35
    184 -35
    192 -35
    201 -35
    209 -35
    217 -35
    225 -35
    233 -35
    241 -34
    249 -34
    257 -34
    265 -34
    273 -34
    280 -34
    288 -34
    295 -34
    303 -34
    310 -34
    318 -33
    325 -33
    332 -33
    339 -33
    346 -33
    352 -33
    359 -33
    366 -33
    372 -32
    379 -32
    385 -32
    391 -32
    397 -32
    403 -32
    409 -31
    415 -31
    420 -31
    426 -31
    431 -31
    437 -31
    442 -30
    447 -30
    452 -30
    457 -30
    461 -30
    466 -30
    470 -29
    474 -29
    479 -29
    483 -29
    486 -29
    490 -28
    494 -28
    497 -28
    501 -28
    504 -28
    507 -27
    510 -27
    513 -27
    515 -27
    518 -27
    520 -26
    522 -26
    524 -26
    526 -26
    528 -25
    530 -25
    531 -25
    533 -25
    534 -25
    535 -24
    536 -24
    536 -24
    537 -24
    537 -23
    538 -23
    538 -23
    538 -23
    538 -22
    537 -22
    537 -22
    536 -22
    536 -21
    535 -21
    534 -21
    532 -21
    531 -20
    529 -20
    528 -20
    526 -20
    524 -19
    522 -19
    519 -19
    517 -19
    514 -18
    511 -18
    509 -18
    505 -18
    502 -17
    499 -17
    495 -17
    492 -17
    488 -16
    484 -16
    480 -16
    475 -15
    471 -15
    466 -15
    462 -15
    457 -14
    452 -14
    446 -14
    441 -14
    436 -13
    430 -13
    424 -13
    418 -12
    412 -12
    406 -12
    399 -12
    393 -11
    386 -11
    379 -11
    373 -11
    365 -10
    358 -10
    351 -10
    343 -9
    336 -9
    328 -9
    320 -9
    312 -8
    304 -8
    295 -8
    287 -8
    278 -7
    269 -7
    260 -7
    251 -6
    242 -6
    233 -6
    223 -6
    214 -5
    204 -5
    194 -5
    184 -5
    174 -4
    164 -4
    153 -4
    143 -3
    132 -3
    122 -3
    111 -3
    100 -2
    89 -2
    77 -2
    66 -2
    54 -1
    43 -1
    31 -1
    19 -0
    7 -0
    -5 0
    -17 0
    -29 1
    -42 1
    -54 1
    -67 1
    -80 2
    -93 2
    -106 2
    -119 3
    -132 3
    -146 3
    -159 3
    -173 4
    -187 4
    -200 4
    -214 4
    -228 5
    -243 5
    -257 5
    -271 5
    -286 6
    -300 6
    -315 6
    -330 6
    -345 7
    -360 7
    -375 7
    -390 7
    -405 8
    -421 8
    -436 8
    -452 9
    -467 9
    -483 9
    -499 9
    -515 10
    -531 10
    -547 10
    -564 10
    -580 11
    -596 11
    -613 11
    -630 11
    -646 12
    -663 12
    -680 12
    -697 12
    -714 13
    -731 13
    -749 13
    -766 13
    -783 14
    -801 14
    -819 14
    -836 14
    -854 14
    -872 15
    -890 15
    -908 15
    -926 15
    926 12
    908 11
    890 11
    872 11
    854 11
    836 11
    818 10
    801 10
    783 10
    766 10
    748 10
    731 10
    714 9
    697 9
    680 9
    663 9
    646 9
    629 8
    613 8
    596 8
    580 8
    563 8
    547 8
    531 7
    515 7
    499 7
    483 7
    467 7
    451 6
    436 6
    420 6
    405 6
    390 6
    374 5
    359 5
    344 5
    329 5
    315 5
    300 4
    285 4
    271 4
    257 4
    242 4
    228 3
    214 3
    200 3
    186 3
    173 3
    159 2
    146 2
    132 2
    119 2
    106 2
    93 1
    80 1
    67 1
    54 1
    42 1
    29 0
    17 0
    5 0
    -8 -0
    -19 -0
    -31 -1
    -43 -1
    -55 -1
    -66 -1
    -78 -1
    -89 -2
    -100 -2
    -111 -2
    -122 -2
    -133 -2
    -143 -3
    -154 -3
    -164 -3
    -174 -3
    -184 -3
    -194 -4
    -204 -4
    -214 -4
    -224 -4
    -233 -4
    -242 -5
    -252 -5
    -261 -5
    -269 -5
    -278 -5
    -287 -6
    -295 -6
    -304 -6
    -312 -6
    -320 -6
    -328 -7
    -336 -7
    -344 -7
    -351 -7
    -358 -8
    -366 -8
    -373 -8
    -380 -8
    -387 -8
    -393 -9
    -400 -9
    -406 -9
    -412 -9
    -418 -9
    -424 -10
    -430 -10
    -436 -10
    -441 -10
    -447 -10
    -452 -11
    -457 -11
    -462 -11
    -466 -11
    -471 -11
    -476 -12
    -480 -12
    -484 -12
    -488 -12
    -492 -12
    -496 -13
    -499 -13
    -502 -13
    -506 -13
    -509 -13
    -512 -14
    -514 -14
    -517 -14
    -520 -14
    -522 -14
    -524 -15
    -526 -15
    -528 -15
    -530 -15
    -531 -15
    -532 -16
    -534 -16
    -535 -16
    -536 -16
    -537 -16
    -537 -16
    -538 -17
    -538 -17
    -538 -17
    -538 -17
    -538 -17
    -538 -18
    -537 -18
    -537 -18
    -536 -18
    -535 -18
    -534 -18
    -533 -19
    -531 -19
    -530 -19
    -528 -19
    -527 -19
    -525 -19
    -523 -20
    -520 -20
    -518 -20
    -516 -20
    -513 -20
    -510 -20
    -507 -21
    -504 -21
    -501 -21
    -498 -21
    -494 -21
    -490 -21
    -487 -21
    -483 -22
    -479 -22
    -475 -22
    -470 -22
    -466 -22
    -461 -22
    -457 -22
    -452 -23
    -447 -23
    -442 -23
    -437 -23
    -431 -23
    -426 -23
    -421 -23
    -415 -23
    -409 -24
    -403 -24
    -397 -24
    -391 -24
    -385 -24
    -379 -24
    -372 -24
    -366 -24
    -359 -24
    -353 -25
    -346 -25
    -339 -25
    -332 -25
    -325 -25
    -318 -25
    -310 -25
    -303 -25
    -296 -25
    -288 -25
    -280 -25
    -273 -26
    -265 -26
    -257 -26
    -249 -26
    -241 -26
    -233 -26
    -225 -26
    -217 -26
    -209 -26
    -201 -26
    -192 -26
    -184 -26
    -176 -26
    -167 -26
    -159 -26
    -150 -26
    -141 -27
    -133 -27
    -124 -27
    -115 -27
    -107 -27
    -98 -27
    -89 -27
    -80 -27
    -71 -27
    -62 -27
    -54 -27
    -45 -27
    -36 -27
    -27 -27
    -18 -27
    -9 -27
    0 -27
    9 -27
    18 -27
    27 -27
    36 -27
    45 -27
    54 -27
    62 -27
    71 -27
    80 -27
    89 -27
    98 -27
    107 -27
    115 -27
    124 -27
    133 -27
    141 -27
    150 -26
    159 -26
    167 -26
    176 -26
    184 -26
    192 -26
    201 -26
    209 -26
    217 -26
    225 -26
    233 -26
    241 -26
    249 -26
    257 -26
    265 -26
    273 -26
    280 -25
    288 -25
    296 -25
    303 -25
    310 -25
    318 -25
    325 -25
    332 -25
    339 -25
    346 -25
    353 -25
    359 -24
    366 -24
    372 -24
    379 -24
    385 -24
    391 -24
    397 -24
    403 -24
    409 -24
    415 -23
    421 -23
    426 -23
    431 -23
    437 -23
    442 -23
    447 -23
    452 -23
    457 -22
    461 -22
    466 -22
    470 -22
    475 -22
    479 -22
    483 -22
    487 -21
    490 -21
    494 -21
    498 -21
    501 -21
    504 -21
    507 -21
    510 -20
    513 -20
    516 -20
    518 -20
    520 -20
    523 -20
    525 -19
    527 -19
    528 -19
    530 -19
    531 -19
    533 -19
    534 -18
    535 -18
    536 -18
    537 -18
    537 -18
    538 -18
    538 -17
    538 -17
    538 -17
    538 -17
    538 -17
    537 -16
    537 -16
    536 -16
    535 -16
    534 -16
    532 -16
    531 -15
    530 -15
    528 -15
    526 -15
    524 -15
    522 -14
    520 -14
    517 -14
    514 -14
    512 -14
    509 -13
    506 -13
    502 -13
    499 -13
    496 -13
    492 -12
    488 -12
    484 -12
    480 -12
    476 -12
    471 -11
    466 -11
    462 -11
    457 -11
    452 -11
    447 -10
    441 -10
    436 -10
    430 -10
    424 -10
    418 -9
    412 -9
    406 -9
    400 -9
    393 -9
    387 -8
    380 -8
    373 -8
    366 -8
    358 -8
    351 -7
    344 -7
    336 -7
    328 -7
    320 -6
    312 -6
    304 -6
    295 -6
    287 -6
    278 -5
    269 -5
    261 -5
    252 -5
    242 -5
    233 -4
    224 -4
    214 -4
    204 -4
    194 -4
    184 -3
    174 -3
    164 -3
    154 -3
    143 -3
    133 -2
    122 -2
    111 -2
    100 -2
    89 -2
    78 -1
    66 -1
    55 -1
    43 -1
    31 -1
    19 -0
    8 -0
    -5 0
    -17 0
    -29 0
    -42 1
    -54 1
    -67 1
    -80 1
    -93 1
    -106 2
    -119 2
    -132 2
    -146 2
    -159 2
    -173 3
    -186 3
    -200 3
    -214 3
    -228 3
    -242 4
    -257 4
    -271 4
    -285 4
    -300 4
    -315 5
    -329 5
    -344 5
    -359 5
    -374 5
    -390 6
    -405 6
    -420 6
    -436 6
    -451 6
    -467 7
    -483 7
    -499 7
    -515 7
    -531 7
    -547 8
    -563 8
    -580 8
    -596 8
    -613 8
    -629 8
    -646 9
    -663 9
    -680 9
    -697 9
    -714 9
    -731 10
    -748 10
    -766 10
    -783 10
    -801 10
    -818 10
    -836 11
    -854 11
    -872 11
    -890 11
    -908 11
    -926 12
    926 8
    908 8
    890 7
    872 7
    854 7
    836 7
    818 7
    801 7
    783 7
    766 7
    748 7
    731 6
    714 6
    697 6
    680 6
    663 6
    646 6
    629 6
    613 6
    596 5
    580 5
    563 5
    547 5
    531 5
    515 5
    499 5
    483 5
    467 4
    451 4
    436 4
    420 4
    405 4
    389 4
    374 4
    359 3
    344 3
    329 3
    314 3
    300 3
    285 3
    271 3
    256 3
    242 2
    228 2
    214 2
    200 2
    186 2
    172 2
    159 2
    145 2
    132 1
    119 1
    106 1
    92 1
    80 1
    67 1
    54 1
    41 0
    29 0
    17 0
    4 0
    -8 -0
    -20 -0
    -32 -0
    -43 -0
    -55 -1
    -66 -1
    -78 -1
    -89 -1
    -100 -1
    -111 -1
    -122 -1
    -133 -2
    -143 -2
    -154 -2
    -164 -2
    -175 -2
    -185 -2
    -195 -2
    -204 -3
    -214 -3
    -224 -3
    -233 -3
    -243 -3
    -252 -3
    -261 -3
    -270 -4
    -278 -4
    -287 -4
    -296 -4
    -304 -4
    -312 -4
    -320 -4
    -328 -4
    -336 -5
    -344 -5
    -351 -5
    -359 -5
    -366 -5
    -373 -5
    -380 -5
    -387 -6
    -393 -6
    -400 -6
    -406 -6
    -412 -6
    -419 -6
    -425 -6
    -430 -7
    -436 -7
    -441 -7
    -447 -7
    -452 -7
    -457 -7
    -462 -7
    -467 -7
    -471 -8
    -476 -8
    -480 -8
    -484 -8
    -488 -8
    -492 -8
    -496 -8
    -499 -9
    -503 -9
    -506 -9
    -509 -9
    -512 -9
    -515 -9
    -517 -9
    -520 -9
    -522 -10
    -524 -10
    -526 -10
    -528 -10
    -530 -10
    -531 -10
    -533 -10
    -534 -10
    -535 -11
    -536 -11
    -537 -11
    -537 -11
    -538 -11
    -538 -11
    -538 -11
    -538 -11
    -538 -12
    -538 -12
    -537 -12
    -537 -12
    -536 -12
    -535 -12
    -534 -12
    -533 -12
    -532 -13
    -530 -13
    -528 -13
    -527 -13
    -525 -13
    -523 -13
    -521 -13
    -518 -13
    -516 -13
    -513 -13
    -510 -14
    -507 -14
    -504 -14
    -501 -14
    -498 -14
    -494 -14
    -491 -14
    -487 -14
    -483 -14
    -479 -15
    -475 -15
    -470 -15
    -466 -15
    -461 -15
    -457 -15
    -452 -15
    -447 -15
    -442 -15
    -437 -15
    -432 -15
    -426 -15
    -421 -16
    -415 -16
    -409 -16
    -403 -16
    -397 -16
    -391 -16
    -385 -16
    -379 -16
    -372 -16
    -366 -16
    -359 -16
    -353 -16
    -346 -16
    -339 -17
    -332 -17
    -325 -17
    -318 -17
    -310 -17
    -303 -17
    -296 -17
    -288 -17
    -281 -17
    -273 -17
    -265 -17
    -257 -17
    -249 -17
    -241 -17
    -233 -17
    -225 -17
    -217 -17
    -209 -17
    -201 -17
    -192 -17
    -184 -18
    -176 -18
    -167 -18
    -159 -18
    -150 -18
    -141 -18
    -133 -18
    -124 -18
    -115 -18
    -107 -18
    -98 -18
    -89 -18
    -80 -18
    -71 -18
    -62 -18
    -54 -18
    -45 -18
    -36 -18
    -27 -18
    -18 -18
    -9 -18
    0 -18
    9 -18
    18 -18
    27 -18
    36 -18
    45 -18
    54 -18
    62 -18
    71 -18
    80 -18
    89 -18
    98 -18
    107 -18
    115 -18
    124 -18
    133 -18
    141 -18
    150 -18
    159 -18
    167 -18
    176 -18
    184 -18
    192 -17
    201 -17
    209 -17
    217 -17
    225 -17
    233 -17
    241 -17
    249 -17
    257 -17
    265 -17
    273 -17
    281 -17
    288 -17
    296 -17
    303 -17
    310 -17
    318 -17
    325 -17
    332 -17
    339 -17
    346 -16
    353 -16
    359 -16
    366 -16
    372 -16
    379 -16
    385 -16
    391 -16
    397 -16
    403 -16
    409 -16
    415 -16
    421 -16
    426 -15
    432 -15
    437 -15
    442 -15
    447 -15
    452 -15
    457 -15
    461 -15
    466 -15
    470 -15
    475 -15
    479 -15
    483 -14
    487 -14
    491 -14
    494 -14
    498 -14
    501 -14
    504 -14
    507 -14
    510 -14
    513 -13
    516 -13
    518 -13
    521 -13
    523 -13
    525 -13
    527 -13
    528 -13
    530 -13
    532 -13
    533 -12
    534 -12
    535 -12
    536 -12
    537 -12
    537 -12
    538 -12
    538 -12
    538 -11
    538 -11
    538 -11
    538 -11
    537 -11
    537 -11
    536 -11
    535 -11
    534 -10
    533 -10
    531 -10
    530 -10
    528 -10
    526 -10
    524 -10
    522 -10
    520 -9
    517 -9
    515 -9
    512 -9
    509 -9
    506 -9
    503 -9
    499 -9
    496 -8
    492 -8
    488 -8
    484 -8
    480 -8
    476 -8
    471 -8
    467 -7
    462 -7
    457 -7
    452 -7
    447 -7
    441 -7
    436 -7
    430 -7
    425 -6
    419 -6
    412 -6
    406 -6
    400 -6
    393 -6
    387 -6
    380 -5
    373 -5
    366 -5
    359 -5
    351 -5
    344 -5
    336 -5
    328 -4
    320 -4
    312 -4
    304 -4
    296 -4
    287 -4
    278 -4
    270 -4
    261 -3
    252 -3
    243 -3
    233 -3
    224 -3
    214 -3
    204 -3
    195 -2
    185 -2
    175 -2
    164 -2
    154 -2
    143 -2
    133 -2
    122 -1
    111 -1
    100 -1
    89 -1
    78 -1
    66 -1
    55 -1
    43 -0
    32 -0
    20 -0
    8 -0
    -4 0
    -17 0
    -29 0
    -41 0
    -54 1
    -67 1
    -80 1
    -92 1
    -106 1
    -119 1
    -132 1
    -145 2
    -159 2
    -172 2
    -186 2
    -200 2
    -214 2
    -228 2
    -242 2
    -256 3
    -271 3
    -285 3
    -300 3
    -314 3
    -329 3
    -344 3
    -359 3
    -374 4
    -389 4
    -405 4
    -420 4
    -436 4
    -451 4
    -467 4
    -483 5
    -499 5
    -515 5
    -531 5
    -547 5
    -563 5
    -580 5
    -596 5
    -613 6
    -629 6
    -646 6
    -663 6
    -680 6
    -697 6
    -714 6
    -731 6
    -748 7
    -766 7
    -783 7
    -801 7
    -818 7
    -836 7
    -854 7
    -872 7
    -890 7
    -908 8
    -926 8
    926 4
    907 4
    889 4
    871 4
    854 4
    836 4
    818 3
    800 3
    783 3
    765 3
    748 3
    731 3
    714 3
    697 3
    680 3
    663 3
    646 3
    629 3
    612 3
    596 3
    579 3
    563 3
    547 3
    531 2
    515 2
    499 2
    483 2
    467 2
    451 2
    436 2
    420 2
    405 2
    389 2
    374 2
    359 2
    344 2
    329 2
    314 2
    300 1
    285 1
    271 1
    256 1
    242 1
    228 1
    214 1
    200 1
    186 1
    172 1
    159 1
    145 1
    132 1
    119 1
    105 1
    92 0
    79 0
    67 0
    54 0
    41 0
    29 0
    17 0
    4 0
    -8 -0
    -20 -0
    -32 -0
    -43 -0
    -55 -0
    -66 -0
    -78 -0
    -89 -1
    -100 -1
    -111 -1
    -122 -1
    -133 -1
    -144 -1
    -154 -1
    -164 -1
    -175 -1
    -185 -1
    -195 -1
    -205 -1
    -214 -1
    -224 -1
    -233 -1
    -243 -2
    -252 -2
    -261 -2
    -270 -2
    -279 -2
    -287 -2
    -296 -2
    -304 -2
    -312 -2
    -320 -2
    -328 -2
    -336 -2
    -344 -2
    -351 -2
    -359 -3
    -366 -3
    -373 -3
    -380 -3
    -387 -3
    -393 -3
    -400 -3
    -406 -3
    -413 -3
    -419 -3
    -425 -3
    -430 -3
    -436 -3
    -442 -3
    -447 -3
    -452 -4
    -457 -4
    -462 -4
    -467 -4
    -471 -4
    -476 -4
    -480 -4
    -484 -4
    -488 -4
    -492 -4
    -496 -4
    -499 -4
    -503 -4
    -506 -4
    -509 -4
    -512 -5
    -515 -5
    -517 -5
    -520 -5
    -522 -5
    -524 -5
    -526 -5
    -528 -5
    -530 -5
    -531 -5
    -533 -5
    -534 -5
    -535 -5
    -536 -5
    -537 -5
    -537 -5
    -538 -6
    -538 -6
    -538 -6
    -538 -6
    -538 -6
    -538 -6
    -538 -6
    -537 -6
    -536 -6
    -535 -6
    -534 -6
    -533 -6
    -532 -6
    -530 -6
    -529 -6
    -527 -6
    -525 -6
    -523 -7
    -521 -7
    -518 -7
    -516 -7
    -513 -7
    -510 -7
    -507 -7
    -504 -7
    -501 -7
    -498 -7
    -494 -7
    -491 -7
    -487 -7
    -483 -7
    -479 -7
    -475 -7
    -470 -7
    -466 -7
    -462 -7
    -457 -7
    -452 -8
    -447 -8
    -442 -8
    -437 -8
    -432 -8
    -426 -8
    -421 -8
    -415 -8
    -409 -8
    -403 -8
    -397 -8
    -391 -8
    -385 -8
    -379 -8
    -373 -8
    -366 -8
    -359 -8
    -353 -8
    -346 -8
    -339 -8
    -332 -8
    -325 -8
    -318 -8
    -310 -8
    -303 -8
    -296 -8
    -288 -8
    -281 -9
    -273 -9
    -265 -9
    -257 -9
    -249 -9
    -242 -9
    -233 -9
    -225 -9
    -217 -9
    -209 -9
    -201 -9
    -192 -9
    -184 -9
    -176 -9
    -167 -9
    -159 -9
    -150 -9
    -141 -9
    -133 -9
    -124 -9
    -115 -9
    -107 -9
    -98 -9
    -89 -9
    -80 -9
    -71 -9
    -62 -9
    -54 -9
    -45 -9
    -36 -9
    -27 -9
    -18 -9
    -9 -9
    0 -9
    9 -9
    18 -9
    27 -9
    36 -9
    45 -9
    54 -9
    62 -9
    71 -9
    80 -9
    89 -9
    98 -9
    107 -9
    115 -9
    124 -9
    133 -9
    141 -9
    150 -9
    159 -9
    167 -9
    176 -9
    184 -9
    192 -9
    201 -9
    209 -9
    217 -9
    225 -9
    233 -9
    242 -9
    249 -9
    257 -9
    265 -9
    273 -9
    281 -9
    288 -8
    296 -8
    303 -8
    310 -8
    318 -8
    325 -8
    332 -8
    339 -8
    346 -8
    353 -8
    359 -8
    366 -8
    373 -8
    379 -8
    385 -8
    391 -8
    397 -8
    403 -8
    409 -8
    415 -8
    421 -8
    426 -8
    432 -8
    437 -8
    442 -8
    447 -8
    452 -8
    457 -7
    462 -7
    466 -7
    470 -7
    475 -7
    479 -7
    483 -7
    487 -7
    491 -7
    494 -7
    498 -7
    501 -7
    504 -7
    507 -7
    510 -7
    513 -7
    516 -7
    518 -7
    521 -7
    523 -7
    525 -6
    527 -6
    529 -6
    530 -6
    532 -6
    533 -6
    534 -6
    535 -6
    536 -6
    537 -6
    538 -6
    538 -6
    538 -6
    538 -6
    538 -6
    538 -6
    538 -6
    537 -5
    537 -5
    536 -5
    535 -5
    534 -5
    533 -5
    531 -5
    530 -5
    528 -5
    526 -5
    524 -5
    522 -5
    520 -5
    517 -5
    515 -5
    512 -5
    509 -4
    506 -4
    503 -4
    499 -4
    496 -4
    492 -4
    488 -4
    484 -4
    480 -4
    476 -4
    471 -4
    467 -4
    462 -4
    457 -4
    452 -4
    447 -3
    442 -3
    436 -3
    430 -3
    425 -3
    419 -3
    413 -3
    406 -3
    400 -3
    393 -3
    387 -3
    380 -3
    373 -3
    366 -3
    359 -3
    351 -2
    344 -2
    336 -2
    328 -2
    320 -2
    312 -2
    304 -2
    296 -2
    287 -2
    279 -2
    270 -2
    261 -2
    252 -2
    243 -2
    233 -1
    224 -1
    214 -1
    205 -1
    195 -1
    185 -1
    175 -1
    164 -1
    154 -1
    144 -1
    133 -1
    122 -1
    111 -1
    100 -1
    89 -1
    78 -0
    66 -0
    55 -0
    43 -0
    32 -0
    20 -0
    8 -0
    -4 0
    -17 0
    -29 0
    -41 0
    -54 0
    -67 0
    -79 0
    -92 0
    -105 1
    -119 1
    -132 1
    -145 1
    -159 1
    -172 1
    -186 1
    -200 1
    -214 1
    -228 1
    -242 1
    -256 1
    -271 1
    -285 1
    -300 1
    -314 2
    -329 2
    -344 2
    -359 2
    -374 2
    -389 2
    -405 2
    -420 2
    -436 2
    -451 2
    -467 2
    -483 2
    -499 2
    -515 2
    -531 2
    -547 3
    -563 3
    -579 3
    -596 3
    -612 3
    -629 3
    -646 3
    -663 3
    -680 3
    -697 3
    -714 3
    -731 3
    -748 3
    -765 3
    -783 3
    -800 3
    -818 3
    -836 4
    -854 4
    -871 4
    -889 4
    -907 4
    -926 4
    926 0
    907 0
    889 0
    871 0
    854 0
    836 0
    818 0
    800 0
    783 0
    765 0
    748 0
    731 0
    714 0
    697 0
    680 0
    663 0
    646 0
    629 0
    612 0
    596 0
    579 0
    563 0
    547 0
    531 0
    514 0
    498 0
    483 0
    467 0
    451 0
    436 0
    420 0
    405 0
    389 0
    374 0
    359 0
    344 0
    329 0
    314 0
    300 0
    285 0
    271 0
    256 0
    242 0
    228 0
    214 0
    200 0
    186 0
    172 0
    159 0
    145 0
    132 0
    119 0
    105 0
    92 0
    79 0
    67 0
    54 0
    41 0
    29 0
    17 0
    4 0
    -8 0
    -20 0
    -32 0
    -43 0
    -55 0
    -67 0
    -78 0
    -89 0
    -100 0
    -111 0
    -122 0
    -133 0
    -144 0
    -154 0
    -164 0
    -175 0
    -185 0
    -195 0
    -205 0
    -214 0
    -224 0
    -233 0
    -243 0
    -252 0
    -261 0
    -270 0
    -279 0
    -287 0
    -296 0
    -304 0
    -312 0
    -320 0
    -328 0
    -336 0
    -344 0
    -351 0
    -359 0
    -366 0
    -373 0
    -380 0
    -387 0
    -393 0
    -400 0
    -406 0
    -413 0
    -419 0
    -425 0
    -430 0
    -436 0
    -442 0
    -447 0
    -452 0
    -457 0
    -462 0
    -467 0
    -471 0
    -476 0
    -480 0
    -484 0
    -488 0
    -492 0
    -496 0
    -499 0
    -503 0
    -506 0
    -509 0
    -512 0
    -515 0
    -517 0
    -520 0
    -522 0
    -524 0
    -526 0
    -528 0
    -530 0
    -531 0
    -533 0
    -534 0
    -535 0
    -536 0
    -537 0
    -537 0
    -538 0
    -538 0
    -538 0
    -538 0
    -538 0
    -538 0
    -538 0
    -537 0
    -536 0
    -535 0
    -534 0
    -533 0
    -532 0
    -530 0
    -529 0
    -527 0
    -525 0
    -523 0
    -521 0
    -518 0
    -516 0
    -513 0
    -510 0
    -507 0
    -504 0
    -501 0
    -498 0
    -494 0
    -491 0
    -487 0
    -483 0
    -479 0
    -475 0
    -471 0
    -466 0
    -462 0
    -457 0
    -452 0
    -447 0
    -442 0
    -437 0
    -432 0
    -426 0
    -421 0
    -415 0
    -409 0
    -403 0
    -398 0
    -391 0
    -385 0
    -379 0
    -373 0
    -366 0
    -359 0
    -353 0
    -346 0
    -339 0
    -332 0
    -325 0
    -318 0
    -310 0
    -303 0
    -296 0
    -288 0
    -281 0
    -273 0
    -265 0
    -257 0
    -249 0
    -242 0
    -233 0
    -225 0
    -217 0
    -209 0
    -201 0
    -192 0
    -184 0
    -176 0
    -167 0
    -159 0
    -150 0
    -141 0
    -133 0
    -124 0
    -115 0
    -107 0
    -98 0
    -89 0
    -80 0
    -71 0
    -62 0
    -54 0
    -45 0
    -36 0
    -27 0
    -18 0
    -9 0
    NA NA
    9 0
    18 0
    27 0
    36 0
    45 0
    54 0
    62 0
    71 0
    80 0
    89 0
    98 0
    107 0
    115 0
    124 0
    133 0
    141 0
    150 0
    159 0
    167 0
    176 0
    184 0
    192 0
    201 0
    209 0
    217 0
    225 0
    233 0
    242 0
    249 0
    257 0
    265 0
    273 0
    281 0
    288 0
    296 0
    303 0
    310 0
    318 0
    325 0
    332 0
    339 0
    346 0
    353 0
    359 0
    366 0
    373 0
    379 0
    385 0
    391 0
    398 0
    403 0
    409 0
    415 0
    421 0
    426 0
    432 0
    437 0
    442 0
    447 0
    452 0
    457 0
    462 0
    466 0
    471 0
    475 0
    479 0
    483 0
    487 0
    491 0
    494 0
    498 0
    501 0
    504 0
    507 0
    510 0
    513 0
    516 0
    518 0
    521 0
    523 0
    525 0
    527 0
    529 0
    530 0
    532 0
    533 0
    534 0
    535 0
    536 0
    537 0
    538 0
    538 0
    538 0
    538 0
    538 0
    538 0
    538 0
    537 0
    537 0
    536 0
    535 0
    534 0
    533 0
    531 0
    530 0
    528 0
    526 0
    524 0
    522 0
    520 0
    517 0
    515 0
    512 0
    509 0
    506 0
    503 0
    499 0
    496 0
    492 0
    488 0
    484 0
    480 0
    476 0
    471 0
    467 0
    462 0
    457 0
    452 0
    447 0
    442 0
    436 0
    430 0
    425 0
    419 0
    413 0
    406 0
    400 0
    393 0
    387 0
    380 0
    373 0
    366 0
    359 0
    351 0
    344 0
    336 0
    328 0
    320 0
    312 0
    304 0
    296 0
    287 0
    279 0
    270 0
    261 0
    252 0
    243 0
    233 0
    224 0
    214 0
    205 0
    195 0
    185 0
    175 0
    164 0
    154 0
    144 0
    133 0
    122 0
    111 0
    100 0
    89 0
    78 0
    67 0
    55 0
    43 0
    32 0
    20 0
    8 0
    -4 0
    -17 0
    -29 0
    -41 0
    -54 0
    -67 0
    -79 0
    -92 0
    -105 0
    -119 0
    -132 0
    -145 0
    -159 0
    -172 0
    -186 0
    -200 0
    -214 0
    -228 0
    -242 0
    -256 0
    -271 0
    -285 0
    -300 0
    -314 0
    -329 0
    -344 0
    -359 0
    -374 0
    -389 0
    -405 0
    -420 0
    -436 0
    -451 0
    -467 0
    -483 0
    -498 0
    -514 0
    -531 0
    -547 0
    -563 0
    -579 0
    -596 0
    -612 0
    -629 0
    -646 0
    -663 0
    -680 0
    -697 0
    -714 0
    -731 0
    -748 0
    -765 0
    -783 0
    -800 0
    -818 0
    -836 0
    -854 0
    -871 0
    -889 0
    -907 0
    -926 0
    926 -4
    907 -4
    889 -4
    871 -4
    854 -4
    836 -4
    818 -3
    800 -3
    783 -3
    765 -3
    748 -3
    731 -3
    714 -3
    697 -3
    680 -3
    663 -3
    646 -3
    629 -3
    612 -3
    596 -3
    579 -3
    563 -3
    547 -3
    531 -2
    515 -2
    499 -2
    483 -2
    467 -2
    451 -2
    436 -2
    420 -2
    405 -2
    389 -2
    374 -2
    359 -2
    344 -2
    329 -2
    314 -2
    300 -1
    285 -1
    271 -1
    256 -1
    242 -1
    228 -1
    214 -1
    200 -1
    186 -1
    172 -1
    159 -1
    145 -1
    132 -1
    119 -1
    105 -1
    92 -0
    79 -0
    67 -0
    54 -0
    41 -0
    29 -0
    17 -0
    4 -0
    -8 0
    -20 0
    -32 0
    -43 0
    -55 0
    -66 0
    -78 0
    -89 1
    -100 1
    -111 1
    -122 1
    -133 1
    -144 1
    -154 1
    -164 1
    -175 1
    -185 1
    -195 1
    -205 1
    -214 1
    -224 1
    -233 1
    -243 2
    -252 2
    -261 2
    -270 2
    -279 2
    -287 2
    -296 2
    -304 2
    -312 2
    -320 2
    -328 2
    -336 2
    -344 2
    -351 2
    -359 3
    -366 3
    -373 3
    -380 3
    -387 3
    -393 3
    -400 3
    -406 3
    -413 3
    -419 3
    -425 3
    -430 3
    -436 3
    -442 3
    -447 3
    -452 4
    -457 4
    -462 4
    -467 4
    -471 4
    -476 4
    -480 4
    -484 4
    -488 4
    -492 4
    -496 4
    -499 4
    -503 4
    -506 4
    -509 4
    -512 5
    -515 5
    -517 5
    -520 5
    -522 5
    -524 5
    -526 5
    -528 5
    -530 5
    -531 5
    -533 5
    -534 5
    -535 5
    -536 5
    -537 5
    -537 5
    -538 6
    -538 6
    -538 6
    -538 6
    -538 6
    -538 6
    -538 6
    -537 6
    -536 6
    -535 6
    -534 6
    -533 6
    -532 6
    -530 6
    -529 6
    -527 6
    -525 6
    -523 7
    -521 7
    -518 7
    -516 7
    -513 7
    -510 7
    -507 7
    -504 7
    -501 7
    -498 7
    -494 7
    -491 7
    -487 7
    -483 7
    -479 7
    -475 7
    -470 7
    -466 7
    -462 7
    -457 7
    -452 8
    -447 8
    -442 8
    -437 8
    -432 8
    -426 8
    -421 8
    -415 8
    -409 8
    -403 8
    -397 8
    -391 8
    -385 8
    -379 8
    -373 8
    -366 8
    -359 8
    -353 8
    -346 8
    -339 8
    -332 8
    -325 8
    -318 8
    -310 8
    -303 8
    -296 8
    -288 8
    -281 9
    -273 9
    -265 9
    -257 9
    -249 9
    -242 9
    -233 9
    -225 9
    -217 9
    -209 9
    -201 9
    -192 9
    -184 9
    -176 9
    -167 9
    -159 9
    -150 9
    -141 9
    -133 9
    -124 9
    -115 9
    -107 9
    -98 9
    -89 9
    -80 9
    -71 9
    -62 9
    -54 9
    -45 9
    -36 9
    -27 9
    -18 9
    -9 9
    0 9
    9 9
    18 9
    27 9
    36 9
    45 9
    54 9
    62 9
    71 9
    80 9
    89 9
    98 9
    107 9
    115 9
    124 9
    133 9
    141 9
    150 9
    159 9
    167 9
    176 9
    184 9
    192 9
    201 9
    209 9
    217 9
    225 9
    233 9
    242 9
    249 9
    257 9
    265 9
    273 9
    281 9
    288 8
    296 8
    303 8
    310 8
    318 8
    325 8
    332 8
    339 8
    346 8
    353 8
    359 8
    366 8
    373 8
    379 8
    385 8
    391 8
    397 8
    403 8
    409 8
    415 8
    421 8
    426 8
    432 8
    437 8
    442 8
    447 8
    452 8
    457 7
    462 7
    466 7
    470 7
    475 7
    479 7
    483 7
    487 7
    491 7
    494 7
    498 7
    501 7
    504 7
    507 7
    510 7
    513 7
    516 7
    518 7
    521 7
    523 7
    525 6
    527 6
    529 6
    530 6
    532 6
    533 6
    534 6
    535 6
    536 6
    537 6
    538 6
    538 6
    538 6
    538 6
    538 6
    538 6
    538 6
    537 5
    537 5
    536 5
    535 5
    534 5
    533 5
    531 5
    530 5
    528 5
    526 5
    524 5
    522 5
    520 5
    517 5
    515 5
    512 5
    509 4
    506 4
    503 4
    499 4
    496 4
    492 4
    488 4
    484 4
    480 4
    476 4
    471 4
    467 4
    462 4
    457 4
    452 4
    447 3
    442 3
    436 3
    430 3
    425 3
    419 3
    413 3
    406 3
    400 3
    393 3
    387 3
    380 3
    373 3
    366 3
    359 3
    351 2
    344 2
    336 2
    328 2
    320 2
    312 2
    304 2
    296 2
    287 2
    279 2
    270 2
    261 2
    252 2
    243 2
    233 1
    224 1
    214 1
    205 1
    195 1
    185 1
    175 1
    164 1
    154 1
    144 1
    133 1
    122 1
    111 1
    100 1
    89 1
    78 0
    66 0
    55 0
    43 0
    32 0
    20 0
    8 0
    -4 -0
    -17 -0
    -29 -0
    -41 -0
    -54 -0
    -67 -0
    -79 -0
    -92 -0
    -105 -1
    -119 -1
    -132 -1
    -145 -1
    -159 -1
    -172 -1
    -186 -1
    -200 -1
    -214 -1
    -228 -1
    -242 -1
    -256 -1
    -271 -1
    -285 -1
    -300 -1
    -314 -2
    -329 -2
    -344 -2
    -359 -2
    -374 -2
    -389 -2
    -405 -2
    -420 -2
    -436 -2
    -451 -2
    -467 -2
    -483 -2
    -499 -2
    -515 -2
    -531 -2
    -547 -3
    -563 -3
    -579 -3
    -596 -3
    -612 -3
    -629 -3
    -646 -3
    -663 -3
    -680 -3
    -697 -3
    -714 -3
    -731 -3
    -748 -3
    -765 -3
    -783 -3
    -800 -3
    -818 -3
    -836 -4
    -854 -4
    -871 -4
    -889 -4
    -907 -4
    -926 -4
    926 -8
    908 -8
    890 -7
    872 -7
    854 -7
    836 -7
    818 -7
    801 -7
    783 -7
    766 -7
    748 -7
    731 -6
    714 -6
    697 -6
    680 -6
    663 -6
    646 -6
    629 -6
    613 -6
    596 -5
    580 -5
    563 -5
    547 -5
    531 -5
    515 -5
    499 -5
    483 -5
    467 -4
    451 -4
    436 -4
    420 -4
    405 -4
    389 -4
    374 -4
    359 -3
    344 -3
    329 -3
    314 -3
    300 -3
    285 -3
    271 -3
    256 -3
    242 -2
    228 -2
    214 -2
    200 -2
    186 -2
    172 -2
    159 -2
    145 -2
    132 -1
    119 -1
    106 -1
    92 -1
    80 -1
    67 -1
    54 -1
    41 -0
    29 -0
    17 -0
    4 -0
    -8 0
    -20 0
    -32 0
    -43 0
    -55 1
    -66 1
    -78 1
    -89 1
    -100 1
    -111 1
    -122 1
    -133 2
    -143 2
    -154 2
    -164 2
    -175 2
    -185 2
    -195 2
    -204 3
    -214 3
    -224 3
    -233 3
    -243 3
    -252 3
    -261 3
    -270 4
    -278 4
    -287 4
    -296 4
    -304 4
    -312 4
    -320 4
    -328 4
    -336 5
    -344 5
    -351 5
    -359 5
    -366 5
    -373 5
    -380 5
    -387 6
    -393 6
    -400 6
    -406 6
    -412 6
    -419 6
    -425 6
    -430 7
    -436 7
    -441 7
    -447 7
    -452 7
    -457 7
    -462 7
    -467 7
    -471 8
    -476 8
    -480 8
    -484 8
    -488 8
    -492 8
    -496 8
    -499 9
    -503 9
    -506 9
    -509 9
    -512 9
    -515 9
    -517 9
    -520 9
    -522 10
    -524 10
    -526 10
    -528 10
    -530 10
    -531 10
    -533 10
    -534 10
    -535 11
    -536 11
    -537 11
    -537 11
    -538 11
    -538 11
    -538 11
    -538 11
    -538 12
    -538 12
    -537 12
    -537 12
    -536 12
    -535 12
    -534 12
    -533 12
    -532 13
    -530 13
    -528 13
    -527 13
    -525 13
    -523 13
    -521 13
    -518 13
    -516 13
    -513 13
    -510 14
    -507 14
    -504 14
    -501 14
    -498 14
    -494 14
    -491 14
    -487 14
    -483 14
    -479 15
    -475 15
    -470 15
    -466 15
    -461 15
    -457 15
    -452 15
    -447 15
    -442 15
    -437 15
    -432 15
    -426 15
    -421 16
    -415 16
    -409 16
    -403 16
    -397 16
    -391 16
    -385 16
    -379 16
    -372 16
    -366 16
    -359 16
    -353 16
    -346 16
    -339 17
    -332 17
    -325 17
    -318 17
    -310 17
    -303 17
    -296 17
    -288 17
    -281 17
    -273 17
    -265 17
    -257 17
    -249 17
    -241 17
    -233 17
    -225 17
    -217 17
    -209 17
    -201 17
    -192 17
    -184 18
    -176 18
    -167 18
    -159 18
    -150 18
    -141 18
    -133 18
    -124 18
    -115 18
    -107 18
    -98 18
    -89 18
    -80 18
    -71 18
    -62 18
    -54 18
    -45 18
    -36 18
    -27 18
    -18 18
    -9 18
    0 18
    9 18
    18 18
    27 18
    36 18
    45 18
    54 18
    62 18
    71 18
    80 18
    89 18
    98 18
    107 18
    115 18
    124 18
    133 18
    141 18
    150 18
    159 18
    167 18
    176 18
    184 18
    192 17
    201 17
    209 17
    217 17
    225 17
    233 17
    241 17
    249 17
    257 17
    265 17
    273 17
    281 17
    288 17
    296 17
    303 17
    310 17
    318 17
    325 17
    332 17
    339 17
    346 16
    353 16
    359 16
    366 16
    372 16
    379 16
    385 16
    391 16
    397 16
    403 16
    409 16
    415 16
    421 16
    426 15
    432 15
    437 15
    442 15
    447 15
    452 15
    457 15
    461 15
    466 15
    470 15
    475 15
    479 15
    483 14
    487 14
    491 14
    494 14
    498 14
    501 14
    504 14
    507 14
    510 14
    513 13
    516 13
    518 13
    521 13
    523 13
    525 13
    527 13
    528 13
    530 13
    532 13
    533 12
    534 12
    535 12
    536 12
    537 12
    537 12
    538 12
    538 12
    538 11
    538 11
    538 11
    538 11
    537 11
    537 11
    536 11
    535 11
    534 10
    533 10
    531 10
    530 10
    528 10
    526 10
    524 10
    522 10
    520 9
    517 9
    515 9
    512 9
    509 9
    506 9
    503 9
    499 9
    496 8
    492 8
    488 8
    484 8
    480 8
    476 8
    471 8
    467 7
    462 7
    457 7
    452 7
    447 7
    441 7
    436 7
    430 7
    425 6
    419 6
    412 6
    406 6
    400 6
    393 6
    387 6
    380 5
    373 5
    366 5
    359 5
    351 5
    344 5
    336 5
    328 4
    320 4
    312 4
    304 4
    296 4
    287 4
    278 4
    270 4
    261 3
    252 3
    243 3
    233 3
    224 3
    214 3
    204 3
    195 2
    185 2
    175 2
    164 2
    154 2
    143 2
    133 2
    122 1
    111 1
    100 1
    89 1
    78 1
    66 1
    55 1
    43 0
    32 0
    20 0
    8 0
    -4 -0
    -17 -0
    -29 -0
    -41 -0
    -54 -1
    -67 -1
    -80 -1
    -92 -1
    -106 -1
    -119 -1
    -132 -1
    -145 -2
    -159 -2
    -172 -2
    -186 -2
    -200 -2
    -214 -2
    -228 -2
    -242 -2
    -256 -3
    -271 -3
    -285 -3
    -300 -3
    -314 -3
    -329 -3
    -344 -3
    -359 -3
    -374 -4
    -389 -4
    -405 -4
    -420 -4
    -436 -4
    -451 -4
    -467 -4
    -483 -5
    -499 -5
    -515 -5
    -531 -5
    -547 -5
    -563 -5
    -580 -5
    -596 -5
    -613 -6
    -629 -6
    -646 -6
    -663 -6
    -680 -6
    -697 -6
    -714 -6
    -731 -6
    -748 -7
    -766 -7
    -783 -7
    -801 -7
    -818 -7
    -836 -7
    -854 -7
    -872 -7
    -890 -7
    -908 -8
    -926 -8
    926 -12
    908 -11
    890 -11
    872 -11
    854 -11
    836 -11
    818 -10
    801 -10
    783 -10
    766 -10
    748 -10
    731 -10
    714 -9
    697 -9
    680 -9
    663 -9
    646 -9
    629 -8
    613 -8
    596 -8
    580 -8
    563 -8
    547 -8
    531 -7
    515 -7
    499 -7
    483 -7
    467 -7
    451 -6
    436 -6
    420 -6
    405 -6
    390 -6
    374 -5
    359 -5
    344 -5
    329 -5
    315 -5
    300 -4
    285 -4
    271 -4
    257 -4
    242 -4
    228 -3
    214 -3
    200 -3
    186 -3
    173 -3
    159 -2
    146 -2
    132 -2
    119 -2
    106 -2
    93 -1
    80 -1
    67 -1
    54 -1
    42 -1
    29 -0
    17 -0
    5 -0
    -8 0
    -19 0
    -31 1
    -43 1
    -55 1
    -66 1
    -78 1
    -89 2
    -100 2
    -111 2
    -122 2
    -133 2
    -143 3
    -154 3
    -164 3
    -174 3
    -184 3
    -194 4
    -204 4
    -214 4
    -224 4
    -233 4
    -242 5
    -252 5
    -261 5
    -269 5
    -278 5
    -287 6
    -295 6
    -304 6
    -312 6
    -320 6
    -328 7
    -336 7
    -344 7
    -351 7
    -358 8
    -366 8
    -373 8
    -380 8
    -387 8
    -393 9
    -400 9
    -406 9
    -412 9
    -418 9
    -424 10
    -430 10
    -436 10
    -441 10
    -447 10
    -452 11
    -457 11
    -462 11
    -466 11
    -471 11
    -476 12
    -480 12
    -484 12
    -488 12
    -492 12
    -496 13
    -499 13
    -502 13
    -506 13
    -509 13
    -512 14
    -514 14
    -517 14
    -520 14
    -522 14
    -524 15
    -526 15
    -528 15
    -530 15
    -531 15
    -532 16
    -534 16
    -535 16
    -536 16
    -537 16
    -537 16
    -538 17
    -538 17
    -538 17
    -538 17
    -538 17
    -538 18
    -537 18
    -537 18
    -536 18
    -535 18
    -534 18
    -533 19
    -531 19
    -530 19
    -528 19
    -527 19
    -525 19
    -523 20
    -520 20
    -518 20
    -516 20
    -513 20
    -510 20
    -507 21
    -504 21
    -501 21
    -498 21
    -494 21
    -490 21
    -487 21
    -483 22
    -479 22
    -475 22
    -470 22
    -466 22
    -461 22
    -457 22
    -452 23
    -447 23
    -442 23
    -437 23
    -431 23
    -426 23
    -421 23
    -415 23
    -409 24
    -403 24
    -397 24
    -391 24
    -385 24
    -379 24
    -372 24
    -366 24
    -359 24
    -353 25
    -346 25
    -339 25
    -332 25
    -325 25
    -318 25
    -310 25
    -303 25
    -296 25
    -288 25
    -280 25
    -273 26
    -265 26
    -257 26
    -249 26
    -241 26
    -233 26
    -225 26
    -217 26
    -209 26
    -201 26
    -192 26
    -184 26
    -176 26
    -167 26
    -159 26
    -150 26
    -141 27
    -133 27
    -124 27
    -115 27
    -107 27
    -98 27
    -89 27
    -80 27
    -71 27
    -62 27
    -54 27
    -45 27
    -36 27
    -27 27
    -18 27
    -9 27
    0 27
    9 27
    18 27
    27 27
    36 27
    45 27
    54 27
    62 27
    71 27
    80 27
    89 27
    98 27
    107 27
    115 27
    124 27
    133 27
    141 27
    150 26
    159 26
    167 26
    176 26
    184 26
    192 26
    201 26
    209 26
    217 26
    225 26
    233 26
    241 26
    249 26
    257 26
    265 26
    273 26
    280 25
    288 25
    296 25
    303 25
    310 25
    318 25
    325 25
    332 25
    339 25
    346 25
    353 25
    359 24
    366 24
    372 24
    379 24
    385 24
    391 24
    397 24
    403 24
    409 24
    415 23
    421 23
    426 23
    431 23
    437 23
    442 23
    447 23
    452 23
    457 22
    461 22
    466 22
    470 22
    475 22
    479 22
    483 22
    487 21
    490 21
    494 21
    498 21
    501 21
    504 21
    507 21
    510 20
    513 20
    516 20
    518 20
    520 20
    523 20
    525 19
    527 19
    528 19
    530 19
    531 19
    533 19
    534 18
    535 18
    536 18
    537 18
    537 18
    538 18
    538 17
    538 17
    538 17
    538 17
    538 17
    537 16
    537 16
    536 16
    535 16
    534 16
    532 16
    531 15
    530 15
    528 15
    526 15
    524 15
    522 14
    520 14
    517 14
    514 14
    512 14
    509 13
    506 13
    502 13
    499 13
    496 13
    492 12
    488 12
    484 12
    480 12
    476 12
    471 11
    466 11
    462 11
    457 11
    452 11
    447 10
    441 10
    436 10
    430 10
    424 10
    418 9
    412 9
    406 9
    400 9
    393 9
    387 8
    380 8
    373 8
    366 8
    358 8
    351 7
    344 7
    336 7
    328 7
    320 6
    312 6
    304 6
    295 6
    287 6
    278 5
    269 5
    261 5
    252 5
    242 5
    233 4
    224 4
    214 4
    204 4
    194 4
    184 3
    174 3
    164 3
    154 3
    143 3
    133 2
    122 2
    111 2
    100 2
    89 2
    78 1
    66 1
    55 1
    43 1
    31 1
    19 0
    8 0
    -5 -0
    -17 -0
    -29 -0
    -42 -1
    -54 -1
    -67 -1
    -80 -1
    -93 -1
    -106 -2
    -119 -2
    -132 -2
    -146 -2
    -159 -2
    -173 -3
    -186 -3
    -200 -3
    -214 -3
    -228 -3
    -242 -4
    -257 -4
    -271 -4
    -285 -4
    -300 -4
    -315 -5
    -329 -5
    -344 -5
    -359 -5
    -374 -5
    -390 -6
    -405 -6
    -420 -6
    -436 -6
    -451 -6
    -467 -7
    -483 -7
    -499 -7
    -515 -7
    -531 -7
    -547 -8
    -563 -8
    -580 -8
    -596 -8
    -613 -8
    -629 -8
    -646 -9
    -663 -9
    -680 -9
    -697 -9
    -714 -9
    -731 -10
    -748 -10
    -766 -10
    -783 -10
    -801 -10
    -818 -10
    -836 -11
    -854 -11
    -872 -11
    -890 -11
    -908 -11
    -926 -12
    926 -15
    908 -15
    890 -15
    872 -15
    854 -14
    836 -14
    819 -14
    801 -14
    783 -14
    766 -13
    749 -13
    731 -13
    714 -13
    697 -12
    680 -12
    663 -12
    646 -12
    630 -11
    613 -11
    596 -11
    580 -11
    564 -10
    547 -10
    531 -10
    515 -10
    499 -9
    483 -9
    467 -9
    452 -9
    436 -8
    421 -8
    405 -8
    390 -7
    375 -7
    360 -7
    345 -7
    330 -6
    315 -6
    300 -6
    286 -6
    271 -5
    257 -5
    243 -5
    228 -5
    214 -4
    200 -4
    187 -4
    173 -4
    159 -3
    146 -3
    132 -3
    119 -3
    106 -2
    93 -2
    80 -2
    67 -1
    54 -1
    42 -1
    29 -1
    17 -0
    5 -0
    -7 0
    -19 0
    -31 1
    -43 1
    -54 1
    -66 2
    -77 2
    -89 2
    -100 2
    -111 3
    -122 3
    -132 3
    -143 3
    -153 4
    -164 4
    -174 4
    -184 5
    -194 5
    -204 5
    -214 5
    -223 6
    -233 6
    -242 6
    -251 6
    -260 7
    -269 7
    -278 7
    -287 8
    -295 8
    -304 8
    -312 8
    -320 9
    -328 9
    -336 9
    -343 9
    -351 10
    -358 10
    -365 10
    -373 11
    -379 11
    -386 11
    -393 11
    -399 12
    -406 12
    -412 12
    -418 12
    -424 13
    -430 13
    -436 13
    -441 14
    -446 14
    -452 14
    -457 14
    -462 15
    -466 15
    -471 15
    -475 15
    -480 16
    -484 16
    -488 16
    -492 17
    -495 17
    -499 17
    -502 17
    -505 18
    -509 18
    -511 18
    -514 18
    -517 19
    -519 19
    -522 19
    -524 19
    -526 20
    -528 20
    -529 20
    -531 20
    -532 21
    -534 21
    -535 21
    -536 21
    -536 22
    -537 22
    -537 22
    -538 22
    -538 23
    -538 23
    -538 23
    -537 23
    -537 24
    -536 24
    -536 24
    -535 24
    -534 25
    -533 25
    -531 25
    -530 25
    -528 25
    -526 26
    -524 26
    -522 26
    -520 26
    -518 27
    -515 27
    -513 27
    -510 27
    -507 27
    -504 28
    -501 28
    -497 28
    -494 28
    -490 28
    -486 29
    -483 29
    -479 29
    -474 29
    -470 29
    -466 30
    -461 30
    -457 30
    -452 30
    -447 30
    -442 30
    -437 31
    -431 31
    -426 31
    -420 31
    -415 31
    -409 31
    -403 32
    -397 32
    -391 32
    -385 32
    -379 32
    -372 32
    -366 33
    -359 33
    -352 33
    -346 33
    -339 33
    -332 33
    -325 33
    -318 33
    -310 34
    -303 34
    -295 34
    -288 34
    -280 34
    -273 34
    -265 34
    -257 34
    -249 34
    -241 34
    -233 35
    -225 35
    -217 35
    -209 35
    -201 35
    -192 35
    -184 35
    -175 35
    -167 35
    -159 35
    -150 35
    -141 35
    -133 35
    -124 35
    -115 35
    -107 36
    -98 36
    -89 36
    -80 36
    -71 36
    -62 36
    -54 36
    -45 36
    -36 36
    -27 36
    -18 36
    -9 36
    0 36
    9 36
    18 36
    27 36
    36 36
    45 36
    54 36
    62 36
    71 36
    80 36
    89 36
    98 36
    107 36
    115 35
    124 35
    133 35
    141 35
    150 35
    159 35
    167 35
    175 35
    184 35
    192 35
    201 35
    209 35
    217 35
    225 35
    233 35
    241 34
    249 34
    257 34
    265 34
    273 34
    280 34
    288 34
    295 34
    303 34
    310 34
    318 33
    325 33
    332 33
    339 33
    346 33
    352 33
    359 33
    366 33
    372 32
    379 32
    385 32
    391 32
    397 32
    403 32
    409 31
    415 31
    420 31
    426 31
    431 31
    437 31
    442 30
    447 30
    452 30
    457 30
    461 30
    466 30
    470 29
    474 29
    479 29
    483 29
    486 29
    490 28
    494 28
    497 28
    501 28
    504 28
    507 27
    510 27
    513 27
    515 27
    518 27
    520 26
    522 26
    524 26
    526 26
    528 25
    530 25
    531 25
    533 25
    534 25
    535 24
    536 24
    536 24
    537 24
    537 23
    538 23
    538 23
    538 23
    538 22
    537 22
    537 22
    536 22
    536 21
    535 21
    534 21
    532 21
    531 20
    529 20
    528 20
    526 20
    524 19
    522 19
    519 19
    517 19
    514 18
    511 18
    509 18
    505 18
    502 17
    499 17
    495 17
    492 17
    488 16
    484 16
    480 16
    475 15
    471 15
    466 15
    462 15
    457 14
    452 14
    446 14
    441 14
    436 13
    430 13
    424 13
    418 12
    412 12
    406 12
    399 12
    393 11
    386 11
    379 11
    373 11
    365 10
    358 10
    351 10
    343 9
    336 9
    328 9
    320 9
    312 8
    304 8
    295 8
    287 8
    278 7
    269 7
    260 7
    251 6
    242 6
    233 6
    223 6
    214 5
    204 5
    194 5
    184 5
    174 4
    164 4
    153 4
    143 3
    132 3
    122 3
    111 3
    100 2
    89 2
    77 2
    66 2
    54 1
    43 1
    31 1
    19 0
    7 0
    -5 -0
    -17 -0
    -29 -1
    -42 -1
    -54 -1
    -67 -1
    -80 -2
    -93 -2
    -106 -2
    -119 -3
    -132 -3
    -146 -3
    -159 -3
    -173 -4
    -187 -4
    -200 -4
    -214 -4
    -228 -5
    -243 -5
    -257 -5
    -271 -5
    -286 -6
    -300 -6
    -315 -6
    -330 -6
    -345 -7
    -360 -7
    -375 -7
    -390 -7
    -405 -8
    -421 -8
    -436 -8
    -452 -9
    -467 -9
    -483 -9
    -499 -9
    -515 -10
    -531 -10
    -547 -10
    -564 -10
    -580 -11
    -596 -11
    -613 -11
    -630 -11
    -646 -12
    -663 -12
    -680 -12
    -697 -12
    -714 -13
    -731 -13
    -749 -13
    -766 -13
    -783 -14
    -801 -14
    -819 -14
    -836 -14
    -854 -14
    -872 -15
    -890 -15
    -908 -15
    -926 -15
    926 -19
    908 -19
    890 -19
    872 -18
    854 -18
    837 -18
    819 -17
    801 -17
    784 -17
    766 -17
    749 -16
    732 -16
    714 -16
    697 -15
    680 -15
    663 -15
    647 -14
    630 -14
    613 -14
    597 -13
    580 -13
    564 -13
    548 -13
    531 -12
    515 -12
    499 -12
    483 -11
    468 -11
    452 -11
    436 -10
    421 -10
    405 -10
    390 -9
    375 -9
    360 -9
    345 -8
    330 -8
    315 -8
    300 -7
    286 -7
    271 -7
    257 -6
    243 -6
    229 -6
    215 -5
    201 -5
    187 -5
    173 -4
    160 -4
    146 -4
    133 -3
    119 -3
    106 -3
    93 -2
    80 -2
    67 -2
    55 -1
    42 -1
    30 -1
    17 -0
    5 -0
    -7 0
    -19 1
    -31 1
    -43 1
    -54 2
    -66 2
    -77 2
    -88 3
    -99 3
    -110 3
    -121 4
    -132 4
    -143 4
    -153 5
    -164 5
    -174 5
    -184 6
    -194 6
    -204 6
    -213 7
    -223 7
    -232 7
    -242 8
    -251 8
    -260 8
    -269 9
    -278 9
    -286 9
    -295 10
    -303 10
    -311 10
    -320 11
    -327 11
    -335 11
    -343 12
    -350 12
    -358 13
    -365 13
    -372 13
    -379 14
    -386 14
    -393 14
    -399 15
    -406 15
    -412 15
    -418 16
    -424 16
    -430 16
    -435 17
    -441 17
    -446 17
    -451 18
    -456 18
    -461 18
    -466 19
    -471 19
    -475 19
    -479 20
    -483 20
    -487 20
    -491 21
    -495 21
    -499 21
    -502 22
    -505 22
    -508 22
    -511 23
    -514 23
    -517 23
    -519 24
    -521 24
    -523 24
    -525 25
    -527 25
    -529 25
    -531 26
    -532 26
    -533 26
    -534 26
    -535 27
    -536 27
    -537 27
    -537 28
    -537 28
    -538 28
    -538 29
    -538 29
    -537 29
    -537 29
    -536 30
    -535 30
    -535 30
    -534 31
    -532 31
    -531 31
    -530 32
    -528 32
    -526 32
    -524 32
    -522 33
    -520 33
    -518 33
    -515 33
    -512 34
    -510 34
    -507 34
    -504 34
    -500 35
    -497 35
    -494 35
    -490 36
    -486 36
    -482 36
    -478 36
    -474 36
    -470 37
    -466 37
    -461 37
    -456 37
    -452 38
    -447 38
    -442 38
    -436 38
    -431 38
    -426 39
    -420 39
    -415 39
    -409 39
    -403 40
    -397 40
    -391 40
    -385 40
    -378 40
    -372 40
    -366 41
    -359 41
    -352 41
    -345 41
    -339 41
    -332 41
    -325 42
    -317 42
    -310 42
    -303 42
    -295 42
    -288 42
    -280 42
    -273 43
    -265 43
    -257 43
    -249 43
    -241 43
    -233 43
    -225 43
    -217 43
    -209 43
    -201 44
    -192 44
    -184 44
    -175 44
    -167 44
    -158 44
    -150 44
    -141 44
    -133 44
    -124 44
    -115 44
    -107 44
    -98 44
    -89 44
    -80 45
    -71 45
    -62 45
    -54 45
    -45 45
    -36 45
    -27 45
    -18 45
    -9 45
    0 45
    9 45
    18 45
    27 45
    36 45
    45 45
    54 45
    62 45
    71 45
    80 45
    89 44
    98 44
    107 44
    115 44
    124 44
    133 44
    141 44
    150 44
    158 44
    167 44
    175 44
    184 44
    192 44
    201 44
    209 43
    217 43
    225 43
    233 43
    241 43
    249 43
    257 43
    265 43
    273 43
    280 42
    288 42
    295 42
    303 42
    310 42
    317 42
    325 42
    332 41
    339 41
    345 41
    352 41
    359 41
    366 41
    372 40
    378 40
    385 40
    391 40
    397 40
    403 40
    409 39
    415 39
    420 39
    426 39
    431 38
    436 38
    442 38
    447 38
    452 38
    456 37
    461 37
    466 37
    470 37
    474 36
    478 36
    482 36
    486 36
    490 36
    494 35
    497 35
    500 35
    504 34
    507 34
    510 34
    512 34
    515 33
    518 33
    520 33
    522 33
    524 32
    526 32
    528 32
    530 32
    531 31
    532 31
    534 31
    535 30
    535 30
    536 30
    537 29
    537 29
    538 29
    538 29
    538 28
    537 28
    537 28
    537 27
    536 27
    535 27
    534 26
    533 26
    532 26
    531 26
    529 25
    527 25
    525 25
    523 24
    521 24
    519 24
    517 23
    514 23
    511 23
    508 22
    505 22
    502 22
    499 21
    495 21
    491 21
    487 20
    483 20
    479 20
    475 19
    471 19
    466 19
    461 18
    456 18
    451 18
    446 17
    441 17
    435 17
    430 16
    424 16
    418 16
    412 15
    406 15
    399 15
    393 14
    386 14
    379 14
    372 13
    365 13
    358 13
    350 12
    343 12
    335 11
    327 11
    320 11
    311 10
    303 10
    295 10
    286 9
    278 9
    269 9
    260 8
    251 8
    242 8
    232 7
    223 7
    213 7
    204 6
    194 6
    184 6
    174 5
    164 5
    153 5
    143 4
    132 4
    121 4
    110 3
    99 3
    88 3
    77 2
    66 2
    54 2
    43 1
    31 1
    19 1
    7 0
    -5 -0
    -17 -0
    -30 -1
    -42 -1
    -55 -1
    -67 -2
    -80 -2
    -93 -2
    -106 -3
    -119 -3
    -133 -3
    -146 -4
    -160 -4
    -173 -4
    -187 -5
    -201 -5
    -215 -5
    -229 -6
    -243 -6
    -257 -6
    -271 -7
    -286 -7
    -300 -7
    -315 -8
    -330 -8
    -345 -8
    -360 -9
    -375 -9
    -390 -9
    -405 -10
    -421 -10
    -436 -10
    -452 -11
    -468 -11
    -483 -11
    -499 -12
    -515 -12
    -531 -12
    -548 -13
    -564 -13
    -580 -13
    -597 -13
    -613 -14
    -630 -14
    -647 -14
    -663 -15
    -680 -15
    -697 -15
    -714 -16
    -732 -16
    -749 -16
    -766 -17
    -784 -17
    -801 -17
    -819 -17
    -837 -18
    -854 -18
    -872 -18
    -890 -19
    -908 -19
    -926 -19
    927 -23
    909 -23
    890 -22
    873 -22
    855 -22
    837 -21
    819 -21
    802 -21
    784 -20
    767 -20
    749 -20
    732 -19
    715 -19
    698 -18
    681 -18
    664 -18
    647 -17
    630 -17
    614 -17
    597 -16
    581 -16
    564 -15
    548 -15
    532 -15
    516 -14
    500 -14
    484 -14
    468 -13
    452 -13
    437 -12
    421 -12
    406 -12
    390 -11
    375 -11
    360 -10
    345 -10
    330 -10
    316 -9
    301 -9
    286 -9
    272 -8
    257 -8
    243 -7
    229 -7
    215 -7
    201 -6
    187 -6
    174 -5
    160 -5
    146 -5
    133 -4
    120 -4
    107 -3
    94 -3
    81 -3
    68 -2
    55 -2
    43 -1
    30 -1
    18 -1
    6 -0
    -7 0
    -19 1
    -30 1
    -42 1
    -54 2
    -65 2
    -77 3
    -88 3
    -99 3
    -110 4
    -121 4
    -132 5
    -142 5
    -153 6
    -163 6
    -173 6
    -184 7
    -194 7
    -203 8
    -213 8
    -223 8
    -232 9
    -241 9
    -251 10
    -260 10
    -269 10
    -277 11
    -286 11
    -294 12
    -303 12
    -311 13
    -319 13
    -327 13
    -335 14
    -343 14
    -350 15
    -357 15
    -365 15
    -372 16
    -379 16
    -386 17
    -392 17
    -399 17
    -405 18
    -411 18
    -417 19
    -423 19
    -429 20
    -435 20
    -440 20
    -446 21
    -451 21
    -456 22
    -461 22
    -466 22
    -470 23
    -475 23
    -479 24
    -483 24
    -487 24
    -491 25
    -495 25
    -498 26
    -502 26
    -505 26
    -508 27
    -511 27
    -514 28
    -516 28
    -519 28
    -521 29
    -523 29
    -525 29
    -527 30
    -529 30
    -530 31
    -532 31
    -533 31
    -534 32
    -535 32
    -536 32
    -536 33
    -537 33
    -537 34
    -537 34
    -537 34
    -537 35
    -537 35
    -536 35
    -536 36
    -535 36
    -534 36
    -533 37
    -532 37
    -531 37
    -529 38
    -528 38
    -526 38
    -524 39
    -522 39
    -520 39
    -517 40
    -515 40
    -512 40
    -509 41
    -506 41
    -503 41
    -500 42
    -497 42
    -493 42
    -490 43
    -486 43
    -482 43
    -478 43
    -474 44
    -470 44
    -465 44
    -461 45
    -456 45
    -451 45
    -446 45
    -441 46
    -436 46
    -431 46
    -426 46
    -420 47
    -414 47
    -409 47
    -403 47
    -397 48
    -391 48
    -385 48
    -378 48
    -372 49
    -365 49
    -359 49
    -352 49
    -345 49
    -338 50
    -331 50
    -324 50
    -317 50
    -310 50
    -303 50
    -295 51
    -288 51
    -280 51
    -272 51
    -265 51
    -257 51
    -249 52
    -241 52
    -233 52
    -225 52
    -217 52
    -209 52
    -200 52
    -192 52
    -184 52
    -175 53
    -167 53
    -158 53
    -150 53
    -141 53
    -133 53
    -124 53
    -115 53
    -106 53
    -98 53
    -89 53
    -80 53
    -71 53
    -62 53
    -53 53
    -45 54
    -36 54
    -27 54
    -18 54
    -9 54
    0 54
    9 54
    18 54
    27 54
    36 54
    45 54
    53 53
    62 53
    71 53
    80 53
    89 53
    98 53
    106 53
    115 53
    124 53
    133 53
    141 53
    150 53
    158 53
    167 53
    175 53
    184 52
    192 52
    200 52
    209 52
    217 52
    225 52
    233 52
    241 52
    249 52
    257 51
    265 51
    272 51
    280 51
    288 51
    295 51
    303 50
    310 50
    317 50
    324 50
    331 50
    338 50
    345 49
    352 49
    359 49
    365 49
    372 49
    378 48
    385 48
    391 48
    397 48
    403 47
    409 47
    414 47
    420 47
    426 46
    431 46
    436 46
    441 46
    446 45
    451 45
    456 45
    461 45
    465 44
    470 44
    474 44
    478 43
    482 43
    486 43
    490 43
    493 42
    497 42
    500 42
    503 41
    506 41
    509 41
    512 40
    515 40
    517 40
    520 39
    522 39
    524 39
    526 38
    528 38
    529 38
    531 37
    532 37
    533 37
    534 36
    535 36
    536 36
    536 35
    537 35
    537 35
    537 34
    537 34
    537 34
    537 33
    536 33
    536 32
    535 32
    534 32
    533 31
    532 31
    530 31
    529 30
    527 30
    525 29
    523 29
    521 29
    519 28
    516 28
    514 28
    511 27
    508 27
    505 26
    502 26
    498 26
    495 25
    491 25
    487 24
    483 24
    479 24
    475 23
    470 23
    466 22
    461 22
    456 22
    451 21
    446 21
    440 20
    435 20
    429 20
    423 19
    417 19
    411 18
    405 18
    399 17
    392 17
    386 17
    379 16
    372 16
    365 15
    357 15
    350 15
    343 14
    335 14
    327 13
    319 13
    311 13
    303 12
    294 12
    286 11
    277 11
    269 10
    260 10
    251 10
    241 9
    232 9
    223 8
    213 8
    203 8
    194 7
    184 7
    173 6
    163 6
    153 6
    142 5
    132 5
    121 4
    110 4
    99 3
    88 3
    77 3
    65 2
    54 2
    42 1
    30 1
    19 1
    7 0
    -6 -0
    -18 -1
    -30 -1
    -43 -1
    -55 -2
    -68 -2
    -81 -3
    -94 -3
    -107 -3
    -120 -4
    -133 -4
    -146 -5
    -160 -5
    -174 -5
    -187 -6
    -201 -6
    -215 -7
    -229 -7
    -243 -7
    -257 -8
    -272 -8
    -286 -9
    -301 -9
    -316 -9
    -330 -10
    -345 -10
    -360 -10
    -375 -11
    -390 -11
    -406 -12
    -421 -12
    -437 -12
    -452 -13
    -468 -13
    -484 -14
    -500 -14
    -516 -14
    -532 -15
    -548 -15
    -564 -15
    -581 -16
    -597 -16
    -614 -17
    -630 -17
    -647 -17
    -664 -18
    -681 -18
    -698 -18
    -715 -19
    -732 -19
    -749 -20
    -767 -20
    -784 -20
    -802 -21
    -819 -21
    -837 -21
    -855 -22
    -873 -22
    -890 -22
    -909 -23
    -927 -23
    927 -27
    909 -27
    891 -26
    873 -26
    855 -25
    837 -25
    820 -25
    802 -24
    784 -24
    767 -23
    750 -23
    732 -22
    715 -22
    698 -22
    681 -21
    664 -21
    647 -20
    631 -20
    614 -19
    597 -19
    581 -18
    565 -18
    548 -18
    532 -17
    516 -17
    500 -16
    484 -16
    468 -15
    453 -15
    437 -15
    422 -14
    406 -14
    391 -13
    376 -13
    361 -12
    346 -12
    331 -11
    316 -11
    301 -10
    287 -10
    272 -10
    258 -9
    244 -9
    229 -8
    215 -8
    201 -7
    188 -7
    174 -6
    160 -6
    147 -5
    133 -5
    120 -4
    107 -4
    94 -4
    81 -3
    68 -3
    56 -2
    43 -2
    31 -1
    18 -1
    6 -0
    -6 0
    -18 1
    -30 1
    -42 2
    -53 2
    -65 3
    -76 3
    -87 4
    -99 4
    -110 5
    -121 5
    -131 5
    -142 6
    -152 6
    -163 7
    -173 7
    -183 8
    -193 8
    -203 9
    -213 9
    -222 10
    -232 10
    -241 11
    -250 11
    -259 12
    -268 12
    -277 13
    -286 13
    -294 14
    -302 14
    -311 15
    -319 15
    -327 16
    -334 16
    -342 17
    -350 17
    -357 17
    -364 18
    -371 18
    -378 19
    -385 19
    -392 20
    -398 20
    -405 21
    -411 21
    -417 22
    -423 22
    -429 23
    -434 23
    -440 24
    -445 24
    -450 25
    -456 25
    -460 26
    -465 26
    -470 27
    -474 27
    -479 27
    -483 28
    -487 28
    -490 29
    -494 29
    -498 30
    -501 30
    -504 31
    -507 31
    -510 32
    -513 32
    -516 33
    -518 33
    -521 33
    -523 34
    -525 34
    -527 35
    -528 35
    -530 36
    -531 36
    -532 37
    -534 37
    -535 37
    -535 38
    -536 38
    -536 39
    -537 39
    -537 40
    -537 40
    -537 40
    -537 41
    -536 41
    -535 42
    -535 42
    -534 42
    -533 43
    -532 43
    -530 44
    -529 44
    -527 44
    -525 45
    -524 45
    -521 46
    -519 46
    -517 46
    -514 47
    -512 47
    -509 48
    -506 48
    -503 48
    -500 49
    -497 49
    -493 49
    -489 50
    -486 50
    -482 50
    -478 51
    -474 51
    -469 51
    -465 52
    -460 52
    -456 52
    -451 53
    -446 53
    -441 53
    -436 54
    -431 54
    -425 54
    -420 54
    -414 55
    -408 55
    -403 55
    -397 56
    -391 56
    -384 56
    -378 56
    -372 57
    -365 57
    -359 57
    -352 57
    -345 58
    -338 58
    -331 58
    -324 58
    -317 58
    -310 59
    -302 59
    -295 59
    -288 59
    -280 59
    -272 60
    -265 60
    -257 60
    -249 60
    -241 60
    -233 60
    -225 61
    -217 61
    -209 61
    -200 61
    -192 61
    -184 61
    -175 61
    -167 61
    -158 62
    -150 62
    -141 62
    -132 62
    -124 62
    -115 62
    -106 62
    -98 62
    -89 62
    -80 62
    -71 62
    -62 62
    -53 62
    -45 62
    -36 62
    -27 62
    -18 62
    -9 62
    0 62
    9 62
    18 62
    27 62
    36 62
    45 62
    53 62
    62 62
    71 62
    80 62
    89 62
    98 62
    106 62
    115 62
    124 62
    132 62
    141 62
    150 62
    158 62
    167 61
    175 61
    184 61
    192 61
    200 61
    209 61
    217 61
    225 61
    233 60
    241 60
    249 60
    257 60
    265 60
    272 60
    280 59
    288 59
    295 59
    302 59
    310 59
    317 58
    324 58
    331 58
    338 58
    345 58
    352 57
    359 57
    365 57
    372 57
    378 56
    384 56
    391 56
    397 56
    403 55
    408 55
    414 55
    420 54
    425 54
    431 54
    436 54
    441 53
    446 53
    451 53
    456 52
    460 52
    465 52
    469 51
    474 51
    478 51
    482 50
    486 50
    489 50
    493 49
    497 49
    500 49
    503 48
    506 48
    509 48
    512 47
    514 47
    517 46
    519 46
    521 46
    524 45
    525 45
    527 44
    529 44
    530 44
    532 43
    533 43
    534 42
    535 42
    535 42
    536 41
    537 41
    537 40
    537 40
    537 40
    537 39
    536 39
    536 38
    535 38
    535 37
    534 37
    532 37
    531 36
    530 36
    528 35
    527 35
    525 34
    523 34
    521 33
    518 33
    516 33
    513 32
    510 32
    507 31
    504 31
    501 30
    498 30
    494 29
    490 29
    487 28
    483 28
    479 27
    474 27
    470 27
    465 26
    460 26
    456 25
    450 25
    445 24
    440 24
    434 23
    429 23
    423 22
    417 22
    411 21
    405 21
    398 20
    392 20
    385 19
    378 19
    371 18
    364 18
    357 17
    350 17
    342 17
    334 16
    327 16
    319 15
    311 15
    302 14
    294 14
    286 13
    277 13
    268 12
    259 12
    250 11
    241 11
    232 10
    222 10
    213 9
    203 9
    193 8
    183 8
    173 7
    163 7
    152 6
    142 6
    131 5
    121 5
    110 5
    99 4
    87 4
    76 3
    65 3
    53 2
    42 2
    30 1
    18 1
    6 0
    -6 -0
    -18 -1
    -31 -1
    -43 -2
    -56 -2
    -68 -3
    -81 -3
    -94 -4
    -107 -4
    -120 -4
    -133 -5
    -147 -5
    -160 -6
    -174 -6
    -188 -7
    -201 -7
    -215 -8
    -229 -8
    -244 -9
    -258 -9
    -272 -10
    -287 -10
    -301 -10
    -316 -11
    -331 -11
    -346 -12
    -361 -12
    -376 -13
    -391 -13
    -406 -14
    -422 -14
    -437 -15
    -453 -15
    -468 -15
    -484 -16
    -500 -16
    -516 -17
    -532 -17
    -548 -18
    -565 -18
    -581 -18
    -597 -19
    -614 -19
    -631 -20
    -647 -20
    -664 -21
    -681 -21
    -698 -22
    -715 -22
    -732 -22
    -750 -23
    -767 -23
    -784 -24
    -802 -24
    -820 -25
    -837 -25
    -855 -25
    -873 -26
    -891 -26
    -909 -27
    -927 -27
    927 -31
    909 -30
    891 -30
    873 -29
    855 -29
    838 -29
    820 -28
    802 -28
    785 -27
    767 -27
    750 -26
    733 -26
    716 -25
    699 -25
    682 -24
    665 -24
    648 -23
    631 -23
    614 -22
    598 -22
    581 -21
    565 -21
    549 -20
    533 -20
    516 -19
    501 -19
    485 -18
    469 -18
    453 -17
    438 -17
    422 -16
    407 -16
    391 -15
    376 -15
    361 -14
    346 -14
    331 -13
    316 -12
    302 -12
    287 -11
    273 -11
    258 -10
    244 -10
    230 -9
    216 -9
    202 -8
    188 -8
    174 -7
    161 -7
    147 -6
    134 -6
    121 -5
    108 -5
    94 -4
    82 -4
    69 -3
    56 -2
    43 -2
    31 -1
    19 -1
    6 -0
    -6 0
    -18 1
    -29 1
    -41 2
    -53 2
    -64 3
    -76 4
    -87 4
    -98 5
    -109 5
    -120 6
    -131 6
    -141 7
    -152 7
    -162 8
    -172 8
    -183 9
    -193 10
    -202 10
    -212 11
    -222 11
    -231 12
    -240 12
    -250 13
    -259 13
    -268 14
    -276 14
    -285 15
    -294 16
    -302 16
    -310 17
    -318 17
    -326 18
    -334 18
    -342 19
    -349 19
    -357 20
    -364 20
    -371 21
    -378 22
    -385 22
    -391 23
    -398 23
    -404 24
    -410 24
    -417 25
    -422 25
    -428 26
    -434 26
    -439 27
    -445 28
    -450 28
    -455 29
    -460 29
    -465 30
    -469 30
    -474 31
    -478 31
    -482 32
    -486 32
    -490 33
    -494 33
    -497 34
    -501 35
    -504 35
    -507 36
    -510 36
    -513 37
    -515 37
    -518 38
    -520 38
    -522 39
    -524 39
    -526 40
    -528 40
    -529 41
    -531 41
    -532 42
    -533 42
    -534 43
    -535 43
    -535 44
    -536 44
    -536 45
    -536 45
    -536 46
    -536 46
    -536 47
    -536 47
    -535 48
    -534 48
    -533 48
    -532 49
    -531 49
    -530 50
    -528 50
    -527 51
    -525 51
    -523 52
    -521 52
    -519 53
    -517 53
    -514 53
    -511 54
    -509 54
    -506 55
    -503 55
    -499 55
    -496 56
    -493 56
    -489 57
    -485 57
    -481 57
    -477 58
    -473 58
    -469 59
    -465 59
    -460 59
    -455 60
    -451 60
    -446 60
    -441 61
    -436 61
    -430 61
    -425 62
    -419 62
    -414 62
    -408 63
    -402 63
    -396 63
    -390 64
    -384 64
    -378 64
    -371 65
    -365 65
    -358 65
    -352 65
    -345 66
    -338 66
    -331 66
    -324 66
    -317 67
    -310 67
    -302 67
    -295 67
    -287 68
    -280 68
    -272 68
    -264 68
    -257 68
    -249 69
    -241 69
    -233 69
    -225 69
    -217 69
    -208 69
    -200 70
    -192 70
    -184 70
    -175 70
    -167 70
    -158 70
    -150 70
    -141 71
    -132 71
    -124 71
    -115 71
    -106 71
    -98 71
    -89 71
    -80 71
    -71 71
    -62 71
    -53 71
    -45 71
    -36 71
    -27 71
    -18 71
    -9 71
    0 71
    9 71
    18 71
    27 71
    36 71
    45 71
    53 71
    62 71
    71 71
    80 71
    89 71
    98 71
    106 71
    115 71
    124 71
    132 71
    141 71
    150 70
    158 70
    167 70
    175 70
    184 70
    192 70
    200 70
    208 69
    217 69
    225 69
    233 69
    241 69
    249 69
    257 68
    264 68
    272 68
    280 68
    287 68
    295 67
    302 67
    310 67
    317 67
    324 66
    331 66
    338 66
    345 66
    352 65
    358 65
    365 65
    371 65
    378 64
    384 64
    390 64
    396 63
    402 63
    408 63
    414 62
    419 62
    425 62
    430 61
    436 61
    441 61
    446 60
    451 60
    455 60
    460 59
    465 59
    469 59
    473 58
    477 58
    481 57
    485 57
    489 57
    493 56
    496 56
    499 55
    503 55
    506 55
    509 54
    511 54
    514 53
    517 53
    519 53
    521 52
    523 52
    525 51
    527 51
    528 50
    530 50
    531 49
    532 49
    533 48
    534 48
    535 48
    536 47
    536 47
    536 46
    536 46
    536 45
    536 45
    536 44
    535 44
    535 43
    534 43
    533 42
    532 42
    531 41
    529 41
    528 40
    526 40
    524 39
    522 39
    520 38
    518 38
    515 37
    513 37
    510 36
    507 36
    504 35
    501 35
    497 34
    494 33
    490 33
    486 32
    482 32
    478 31
    474 31
    469 30
    465 30
    460 29
    455 29
    450 28
    445 28
    439 27
    434 26
    428 26
    422 25
    417 25
    410 24
    404 24
    398 23
    391 23
    385 22
    378 22
    371 21
    364 20
    357 20
    349 19
    342 19
    334 18
    326 18
    318 17
    310 17
    302 16
    294 16
    285 15
    276 14
    268 14
    259 13
    250 13
    240 12
    231 12
    222 11
    212 11
    202 10
    193 10
    183 9
    172 8
    162 8
    152 7
    141 7
    131 6
    120 6
    109 5
    98 5
    87 4
    76 4
    64 3
    53 2
    41 2
    29 1
    18 1
    6 0
    -6 -0
    -19 -1
    -31 -1
    -43 -2
    -56 -2
    -69 -3
    -82 -4
    -94 -4
    -108 -5
    -121 -5
    -134 -6
    -147 -6
    -161 -7
    -174 -7
    -188 -8
    -202 -8
    -216 -9
    -230 -9
    -244 -10
    -258 -10
    -273 -11
    -287 -11
    -302 -12
    -316 -12
    -331 -13
    -346 -14
    -361 -14
    -376 -15
    -391 -15
    -407 -16
    -422 -16
    -438 -17
    -453 -17
    -469 -18
    -485 -18
    -501 -19
    -516 -19
    -533 -20
    -549 -20
    -565 -21
    -581 -21
    -598 -22
    -614 -22
    -631 -23
    -648 -23
    -665 -24
    -682 -24
    -699 -25
    -716 -25
    -733 -26
    -750 -26
    -767 -27
    -785 -27
    -802 -28
    -820 -28
    -838 -29
    -855 -29
    -873 -29
    -891 -30
    -909 -30
    -927 -31
    928 -35
    910 -34
    892 -34
    874 -33
    856 -33
    838 -32
    821 -32
    803 -31
    785 -30
    768 -30
    751 -29
    733 -29
    716 -28
    699 -28
    682 -27
    665 -27
    648 -26
    632 -25
    615 -25
    598 -24
    582 -24
    566 -23
    549 -23
    533 -22
    517 -22
    501 -21
    485 -20
    469 -20
    454 -19
    438 -19
    423 -18
    407 -18
    392 -17
    377 -16
    362 -16
    347 -15
    332 -15
    317 -14
    302 -13
    288 -13
    273 -12
    259 -12
    245 -11
    230 -11
    216 -10
    203 -9
    189 -9
    175 -8
    161 -8
    148 -7
    135 -6
    121 -6
    108 -5
    95 -5
    82 -4
    69 -3
    57 -3
    44 -2
    32 -2
    19 -1
    7 -0
    -5 0
    -17 1
    -29 1
    -41 2
    -52 3
    -64 3
    -75 4
    -86 5
    -98 5
    -109 6
    -119 6
    -130 7
    -141 8
    -151 8
    -162 9
    -172 9
    -182 10
    -192 11
    -202 11
    -212 12
    -221 13
    -231 13
    -240 14
    -249 14
    -258 15
    -267 16
    -276 16
    -284 17
    -293 17
    -301 18
    -310 19
    -318 19
    -326 20
    -333 21
    -341 21
    -349 22
    -356 22
    -363 23
    -370 24
    -377 24
    -384 25
    -391 25
    -397 26
    -404 27
    -410 27
    -416 28
    -422 29
    -428 29
    -433 30
    -439 30
    -444 31
    -449 32
    -454 32
    -459 33
    -464 33
    -469 34
    -473 35
    -477 35
    -482 36
    -486 36
    -489 37
    -493 38
    -497 38
    -500 39
    -503 39
    -506 40
    -509 41
    -512 41
    -515 42
    -517 42
    -520 43
    -522 43
    -524 44
    -526 45
    -527 45
    -529 46
    -530 46
    -531 47
    -533 47
    -534 48
    -534 49
    -535 49
    -535 50
    -536 50
    -536 51
    -536 51
    -536 52
    -536 52
    -535 53
    -535 53
    -534 54
    -533 55
    -532 55
    -531 56
    -529 56
    -528 57
    -526 57
    -525 58
    -523 58
    -521 59
    -518 59
    -516 60
    -514 60
    -511 61
    -508 61
    -505 61
    -502 62
    -499 62
    -496 63
    -492 63
    -489 64
    -485 64
    -481 65
    -477 65
    -473 65
    -469 66
    -464 66
    -460 67
    -455 67
    -450 68
    -445 68
    -440 68
    -435 69
    -430 69
    -425 69
    -419 70
    -413 70
    -408 71
    -402 71
    -396 71
    -390 72
    -384 72
    -377 72
    -371 73
    -365 73
    -358 73
    -351 74
    -345 74
    -338 74
    -331 74
    -324 75
    -317 75
    -309 75
    -302 75
    -295 76
    -287 76
    -280 76
    -272 76
    -264 77
    -256 77
    -249 77
    -241 77
    -233 78
    -225 78
    -216 78
    -208 78
    -200 78
    -192 78
    -183 79
    -175 79
    -167 79
    -158 79
    -149 79
    -141 79
    -132 79
    -124 79
    -115 80
    -106 80
    -97 80
    -89 80
    -80 80
    -71 80
    -62 80
    -53 80
    -45 80
    -36 80
    -27 80
    -18 80
    -9 80
    0 80
    9 80
    18 80
    27 80
    36 80
    45 80
    53 80
    62 80
    71 80
    80 80
    89 80
    97 80
    106 80
    115 80
    124 79
    132 79
    141 79
    149 79
    158 79
    167 79
    175 79
    183 79
    192 78
    200 78
    208 78
    216 78
    225 78
    233 78
    241 77
    249 77
    256 77
    264 77
    272 76
    280 76
    287 76
    295 76
    302 75
    309 75
    317 75
    324 75
    331 74
    338 74
    345 74
    351 74
    358 73
    365 73
    371 73
    377 72
    384 72
    390 72
    396 71
    402 71
    408 71
    413 70
    419 70
    425 69
    430 69
    435 69
    440 68
    445 68
    450 68
    455 67
    460 67
    464 66
    469 66
    473 65
    477 65
    481 65
    485 64
    489 64
    492 63
    496 63
    499 62
    502 62
    505 61
    508 61
    511 61
    514 60
    516 60
    518 59
    521 59
    523 58
    525 58
    526 57
    528 57
    529 56
    531 56
    532 55
    533 55
    534 54
    535 53
    535 53
    536 52
    536 52
    536 51
    536 51
    536 50
    535 50
    535 49
    534 49
    534 48
    533 47
    531 47
    530 46
    529 46
    527 45
    526 45
    524 44
    522 43
    520 43
    517 42
    515 42
    512 41
    509 41
    506 40
    503 39
    500 39
    497 38
    493 38
    489 37
    486 36
    482 36
    477 35
    473 35
    469 34
    464 33
    459 33
    454 32
    449 32
    444 31
    439 30
    433 30
    428 29
    422 29
    416 28
    410 27
    404 27
    397 26
    391 25
    384 25
    377 24
    370 24
    363 23
    356 22
    349 22
    341 21
    333 21
    326 20
    318 19
    310 19
    301 18
    293 17
    284 17
    276 16
    267 16
    258 15
    249 14
    240 14
    231 13
    221 13
    212 12
    202 11
    192 11
    182 10
    172 9
    162 9
    151 8
    141 8
    130 7
    119 6
    109 6
    98 5
    86 5
    75 4
    64 3
    52 3
    41 2
    29 1
    17 1
    5 0
    -7 -0
    -19 -1
    -32 -2
    -44 -2
    -57 -3
    -69 -3
    -82 -4
    -95 -5
    -108 -5
    -121 -6
    -135 -6
    -148 -7
    -161 -8
    -175 -8
    -189 -9
    -203 -9
    -216 -10
    -230 -11
    -245 -11
    -259 -12
    -273 -12
    -288 -13
    -302 -13
    -317 -14
    -332 -15
    -347 -15
    -362 -16
    -377 -16
    -392 -17
    -407 -18
    -423 -18
    -438 -19
    -454 -19
    -469 -20
    -485 -20
    -501 -21
    -517 -22
    -533 -22
    -549 -23
    -566 -23
    -582 -24
    -598 -24
    -615 -25
    -632 -25
    -648 -26
    -665 -27
    -682 -27
    -699 -28
    -716 -28
    -733 -29
    -751 -29
    -768 -30
    -785 -30
    -803 -31
    -821 -32
    -838 -32
    -856 -33
    -874 -33
    -892 -34
    -910 -34
    -928 -35
    929 -39
    910 -38
    892 -37
    874 -37
    857 -36
    839 -36
    821 -35
    803 -34
    786 -34
    769 -33
    751 -33
    734 -32
    717 -31
    700 -31
    683 -30
    666 -30
    649 -29
    632 -28
    616 -28
    599 -27
    583 -26
    566 -26
    550 -25
    534 -25
    518 -24
    502 -23
    486 -23
    470 -22
    454 -21
    439 -21
    423 -20
    408 -20
    393 -19
    377 -18
    362 -18
    347 -17
    332 -16
    318 -16
    303 -15
    288 -14
    274 -14
    260 -13
    245 -12
    231 -12
    217 -11
    203 -10
    189 -10
    176 -9
    162 -8
    149 -8
    135 -7
    122 -6
    109 -6
    96 -5
    83 -4
    70 -4
    57 -3
    45 -2
    32 -2
    20 -1
    8 -0
    -4 0
    -16 1
    -28 2
    -40 2
    -52 3
    -63 4
    -75 4
    -86 5
    -97 6
    -108 6
    -119 7
    -130 8
    -140 8
    -151 9
    -161 10
    -171 10
    -181 11
    -191 12
    -201 12
    -211 13
    -220 14
    -230 15
    -239 15
    -248 16
    -257 17
    -266 17
    -275 18
    -284 19
    -292 19
    -301 20
    -309 21
    -317 21
    -325 22
    -333 23
    -340 23
    -348 24
    -355 25
    -363 26
    -370 26
    -377 27
    -383 28
    -390 28
    -397 29
    -403 30
    -409 30
    -415 31
    -421 32
    -427 32
    -433 33
    -438 34
    -444 34
    -449 35
    -454 36
    -459 36
    -463 37
    -468 38
    -473 38
    -477 39
    -481 40
    -485 40
    -489 41
    -493 42
    -496 42
    -499 43
    -503 44
    -506 44
    -509 45
    -511 46
    -514 46
    -517 47
    -519 48
    -521 48
    -523 49
    -525 50
    -527 50
    -528 51
    -530 51
    -531 52
    -532 53
    -533 53
    -534 54
    -534 55
    -535 55
    -535 56
    -535 56
    -535 57
    -535 58
    -535 58
    -535 59
    -534 59
    -533 60
    -532 61
    -531 61
    -530 62
    -529 62
    -527 63
    -526 63
    -524 64
    -522 64
    -520 65
    -518 66
    -516 66
    -513 67
    -510 67
    -508 68
    -505 68
    -502 69
    -499 69
    -495 70
    -492 70
    -488 71
    -484 71
    -481 72
    -477 72
    -472 73
    -468 73
    -464 74
    -459 74
    -455 75
    -450 75
    -445 75
    -440 76
    -435 76
    -430 77
    -424 77
    -419 78
    -413 78
    -407 78
    -402 79
    -396 79
    -390 79
    -383 80
    -377 80
    -371 81
    -364 81
    -358 81
    -351 82
    -344 82
    -337 82
    -330 83
    -323 83
    -316 83
    -309 84
    -302 84
    -294 84
    -287 84
    -279 85
    -272 85
    -264 85
    -256 85
    -248 86
    -240 86
    -232 86
    -224 86
    -216 86
    -208 87
    -200 87
    -192 87
    -183 87
    -175 87
    -166 88
    -158 88
    -149 88
    -141 88
    -132 88
    -124 88
    -115 88
    -106 88
    -97 89
    -89 89
    -80 89
    -71 89
    -62 89
    -53 89
    -44 89
    -36 89
    -27 89
    -18 89
    -9 89
    0 89
    9 89
    18 89
    27 89
    36 89
    44 89
    53 89
    62 89
    71 89
    80 89
    89 89
    97 89
    106 88
    115 88
    124 88
    132 88
    141 88
    149 88
    158 88
    166 88
    175 87
    183 87
    192 87
    200 87
    208 87
    216 86
    224 86
    232 86
    240 86
    248 86
    256 85
    264 85
    272 85
    279 85
    287 84
    294 84
    302 84
    309 84
    316 83
    323 83
    330 83
    337 82
    344 82
    351 82
    358 81
    364 81
    371 81
    377 80
    383 80
    390 79
    396 79
    402 79
    407 78
    413 78
    419 78
    424 77
    430 77
    435 76
    440 76
    445 75
    450 75
    455 75
    459 74
    464 74
    468 73
    472 73
    477 72
    481 72
    484 71
    488 71
    492 70
    495 70
    499 69
    502 69
    505 68
    508 68
    510 67
    513 67
    516 66
    518 66
    520 65
    522 64
    524 64
    526 63
    527 63
    529 62
    530 62
    531 61
    532 61
    533 60
    534 59
    535 59
    535 58
    535 58
    535 57
    535 56
    535 56
    535 55
    534 55
    534 54
    533 53
    532 53
    531 52
    530 51
    528 51
    527 50
    525 50
    523 49
    521 48
    519 48
    517 47
    514 46
    511 46
    509 45
    506 44
    503 44
    499 43
    496 42
    493 42
    489 41
    485 40
    481 40
    477 39
    473 38
    468 38
    463 37
    459 36
    454 36
    449 35
    444 34
    438 34
    433 33
    427 32
    421 32
    415 31
    409 30
    403 30
    397 29
    390 28
    383 28
    377 27
    370 26
    363 26
    355 25
    348 24
    340 23
    333 23
    325 22
    317 21
    309 21
    301 20
    292 19
    284 19
    275 18
    266 17
    257 17
    248 16
    239 15
    230 15
    220 14
    211 13
    201 12
    191 12
    181 11
    171 10
    161 10
    151 9
    140 8
    130 8
    119 7
    108 6
    97 6
    86 5
    75 4
    63 4
    52 3
    40 2
    28 2
    16 1
    4 0
    -8 -0
    -20 -1
    -32 -2
    -45 -2
    -57 -3
    -70 -4
    -83 -4
    -96 -5
    -109 -6
    -122 -6
    -135 -7
    -149 -8
    -162 -8
    -176 -9
    -189 -10
    -203 -10
    -217 -11
    -231 -12
    -245 -12
    -260 -13
    -274 -14
    -288 -14
    -303 -15
    -318 -16
    -332 -16
    -347 -17
    -362 -18
    -377 -18
    -393 -19
    -408 -20
    -423 -20
    -439 -21
    -454 -21
    -470 -22
    -486 -23
    -502 -23
    -518 -24
    -534 -25
    -550 -25
    -566 -26
    -583 -26
    -599 -27
    -616 -28
    -632 -28
    -649 -29
    -666 -30
    -683 -30
    -700 -31
    -717 -31
    -734 -32
    -751 -33
    -769 -33
    -786 -34
    -803 -34
    -821 -35
    -839 -36
    -857 -36
    -874 -37
    -892 -37
    -910 -38
    -929 -39
    929 -43
    911 -42
    893 -41
    875 -41
    857 -40
    839 -39
    822 -39
    804 -38
    787 -37
    769 -37
    752 -36
    735 -35
    717 -35
    700 -34
    683 -33
    666 -33
    650 -32
    633 -31
    616 -31
    600 -30
    583 -29
    567 -28
    551 -28
    534 -27
    518 -26
    502 -26
    486 -25
    471 -24
    455 -24
    439 -23
    424 -22
    408 -21
    393 -21
    378 -20
    363 -19
    348 -19
    333 -18
    318 -17
    304 -17
    289 -16
    275 -15
    260 -14
    246 -14
    232 -13
    218 -12
    204 -11
    190 -11
    176 -10
    163 -9
    149 -9
    136 -8
    123 -7
    109 -6
    96 -6
    83 -5
    71 -4
    58 -3
    45 -3
    33 -2
    21 -1
    8 -1
    -4 0
    -16 1
    -28 2
    -39 2
    -51 3
    -62 4
    -74 5
    -85 5
    -96 6
    -107 7
    -118 8
    -129 8
    -139 9
    -150 10
    -160 11
    -171 11
    -181 12
    -191 13
    -200 14
    -210 14
    -220 15
    -229 16
    -239 17
    -248 17
    -257 18
    -266 19
    -274 20
    -283 20
    -292 21
    -300 22
    -308 23
    -316 24
    -324 24
    -332 25
    -340 26
    -347 27
    -355 27
    -362 28
    -369 29
    -376 30
    -383 30
    -389 31
    -396 32
    -402 33
    -408 33
    -415 34
    -421 35
    -426 36
    -432 36
    -437 37
    -443 38
    -448 39
    -453 39
    -458 40
    -463 41
    -467 41
    -472 42
    -476 43
    -480 44
    -484 44
    -488 45
    -492 46
    -495 47
    -499 47
    -502 48
    -505 49
    -508 49
    -511 50
    -513 51
    -516 52
    -518 52
    -520 53
    -522 54
    -524 54
    -526 55
    -528 56
    -529 56
    -530 57
    -531 58
    -532 59
    -533 59
    -534 60
    -534 61
    -535 61
    -535 62
    -535 63
    -535 63
    -534 64
    -534 65
    -533 65
    -533 66
    -532 66
    -531 67
    -530 68
    -528 68
    -527 69
    -525 70
    -523 70
    -522 71
    -520 71
    -517 72
    -515 73
    -513 73
    -510 74
    -507 74
    -504 75
    -501 76
    -498 76
    -495 77
    -491 77
    -488 78
    -484 78
    -480 79
    -476 79
    -472 80
    -468 80
    -463 81
    -459 81
    -454 82
    -449 82
    -445 83
    -440 83
    -434 84
    -429 84
    -424 85
    -418 85
    -413 86
    -407 86
    -401 87
    -395 87
    -389 87
    -383 88
    -377 88
    -370 89
    -364 89
    -357 89
    -351 90
    -344 90
    -337 90
    -330 91
    -323 91
    -316 91
    -309 92
    -301 92
    -294 92
    -287 93
    -279 93
    -271 93
    -264 94
    -256 94
    -248 94
    -240 94
    -232 95
    -224 95
    -216 95
    -208 95
    -200 95
    -191 96
    -183 96
    -175 96
    -166 96
    -158 96
    -149 97
    -141 97
    -132 97
    -123 97
    -115 97
    -106 97
    -97 97
    -89 97
    -80 97
    -71 98
    -62 98
    -53 98
    -44 98
    -36 98
    -27 98
    -18 98
    -9 98
    0 98
    9 98
    18 98
    27 98
    36 98
    44 98
    53 98
    62 98
    71 98
    80 97
    89 97
    97 97
    106 97
    115 97
    123 97
    132 97
    141 97
    149 97
    158 96
    166 96
    175 96
    183 96
    191 96
    200 95
    208 95
    216 95
    224 95
    232 95
    240 94
    248 94
    256 94
    264 94
    271 93
    279 93
    287 93
    294 92
    301 92
    309 92
    316 91
    323 91
    330 91
    337 90
    344 90
    351 90
    357 89
    364 89
    370 89
    377 88
    383 88
    389 87
    395 87
    401 87
    407 86
    413 86
    418 85
    424 85
    429 84
    434 84
    440 83
    445 83
    449 82
    454 82
    459 81
    463 81
    468 80
    472 80
    476 79
    480 79
    484 78
    488 78
    491 77
    495 77
    498 76
    501 76
    504 75
    507 74
    510 74
    513 73
    515 73
    517 72
    520 71
    522 71
    523 70
    525 70
    527 69
    528 68
    530 68
    531 67
    532 66
    533 66
    533 65
    534 65
    534 64
    535 63
    535 63
    535 62
    535 61
    534 61
    534 60
    533 59
    532 59
    531 58
    530 57
    529 56
    528 56
    526 55
    524 54
    522 54
    520 53
    518 52
    516 52
    513 51
    511 50
    508 49
    505 49
    502 48
    499 47
    495 47
    492 46
    488 45
    484 44
    480 44
    476 43
    472 42
    467 41
    463 41
    458 40
    453 39
    448 39
    443 38
    437 37
    432 36
    426 36
    421 35
    415 34
    408 33
    402 33
    396 32
    389 31
    383 30
    376 30
    369 29
    362 28
    355 27
    347 27
    340 26
    332 25
    324 24
    316 24
    308 23
    300 22
    292 21
    283 20
    274 20
    266 19
    257 18
    248 17
    239 17
    229 16
    220 15
    210 14
    200 14
    191 13
    181 12
    171 11
    160 11
    150 10
    139 9
    129 8
    118 8
    107 7
    96 6
    85 5
    74 5
    62 4
    51 3
    39 2
    28 2
    16 1
    4 0
    -8 -1
    -21 -1
    -33 -2
    -45 -3
    -58 -3
    -71 -4
    -83 -5
    -96 -6
    -109 -6
    -123 -7
    -136 -8
    -149 -9
    -163 -9
    -176 -10
    -190 -11
    -204 -11
    -218 -12
    -232 -13
    -246 -14
    -260 -14
    -275 -15
    -289 -16
    -304 -17
    -318 -17
    -333 -18
    -348 -19
    -363 -19
    -378 -20
    -393 -21
    -408 -21
    -424 -22
    -439 -23
    -455 -24
    -471 -24
    -486 -25
    -502 -26
    -518 -26
    -534 -27
    -551 -28
    -567 -28
    -583 -29
    -600 -30
    -616 -31
    -633 -31
    -650 -32
    -666 -33
    -683 -33
    -700 -34
    -717 -35
    -735 -35
    -752 -36
    -769 -37
    -787 -37
    -804 -38
    -822 -39
    -839 -39
    -857 -40
    -875 -41
    -893 -41
    -911 -42
    -929 -43
    930 -46
    912 -46
    894 -45
    876 -44
    858 -44
    840 -43
    822 -42
    805 -41
    787 -41
    770 -40
    752 -39
    735 -39
    718 -38
    701 -37
    684 -36
    667 -36
    650 -35
    634 -34
    617 -33
    600 -33
    584 -32
    568 -31
    551 -30
    535 -30
    519 -29
    503 -28
    487 -27
    471 -27
    456 -26
    440 -25
    425 -24
    409 -23
    394 -23
    379 -22
    364 -21
    349 -20
    334 -20
    319 -19
    304 -18
    290 -17
    275 -17
    261 -16
    247 -15
    233 -14
    219 -13
    205 -13
    191 -12
    177 -11
    163 -10
    150 -9
    137 -9
    123 -8
    110 -7
    97 -6
    84 -5
    71 -5
    59 -4
    46 -3
    34 -2
    21 -1
    9 -1
    -3 0
    -15 1
    -27 2
    -39 3
    -50 3
    -62 4
    -73 5
    -84 6
    -95 7
    -106 8
    -117 8
    -128 9
    -139 10
    -149 11
    -159 12
    -170 12
    -180 13
    -190 14
    -200 15
    -209 16
    -219 17
    -228 17
    -238 18
    -247 19
    -256 20
    -265 21
    -274 21
    -282 22
    -291 23
    -299 24
    -307 25
    -315 26
    -323 26
    -331 27
    -339 28
    -346 29
    -354 30
    -361 31
    -368 31
    -375 32
    -382 33
    -389 34
    -395 35
    -401 35
    -408 36
    -414 37
    -420 38
    -426 39
    -431 39
    -437 40
    -442 41
    -447 42
    -452 43
    -457 44
    -462 44
    -467 45
    -471 46
    -475 47
    -479 48
    -483 48
    -487 49
    -491 50
    -495 51
    -498 52
    -501 52
    -504 53
    -507 54
    -510 55
    -513 55
    -515 56
    -518 57
    -520 58
    -522 59
    -524 59
    -525 60
    -527 61
    -528 62
    -530 62
    -531 63
    -532 64
    -532 65
    -533 65
    -534 66
    -534 67
    -534 67
    -534 68
    -534 69
    -534 70
    -533 70
    -533 71
    -532 72
    -531 72
    -530 73
    -529 74
    -528 74
    -526 75
    -525 76
    -523 77
    -521 77
    -519 78
    -517 78
    -514 79
    -512 80
    -509 80
    -507 81
    -504 82
    -501 82
    -497 83
    -494 84
    -491 84
    -487 85
    -483 85
    -480 86
    -476 86
    -471 87
    -467 88
    -463 88
    -458 89
    -454 89
    -449 90
    -444 90
    -439 91
    -434 91
    -429 92
    -423 92
    -418 93
    -412 93
    -407 94
    -401 94
    -395 95
    -389 95
    -383 96
    -376 96
    -370 97
    -364 97
    -357 97
    -350 98
    -344 98
    -337 99
    -330 99
    -323 99
    -316 100
    -308 100
    -301 100
    -294 101
    -286 101
    -279 101
    -271 102
    -263 102
    -256 102
    -248 103
    -240 103
    -232 103
    -224 103
    -216 104
    -208 104
    -199 104
    -191 104
    -183 104
    -174 105
    -166 105
    -158 105
    -149 105
    -141 105
    -132 106
    -123 106
    -115 106
    -106 106
    -97 106
    -88 106
    -80 106
    -71 106
    -62 106
    -53 106
    -44 107
    -36 107
    -27 107
    -18 107
    -9 107
    0 107
    9 107
    18 107
    27 107
    36 107
    44 107
    53 106
    62 106
    71 106
    80 106
    88 106
    97 106
    106 106
    115 106
    123 106
    132 106
    141 105
    149 105
    158 105
    166 105
    174 105
    183 104
    191 104
    199 104
    208 104
    216 104
    224 103
    232 103
    240 103
    248 103
    256 102
    263 102
    271 102
    279 101
    286 101
    294 101
    301 100
    308 100
    316 100
    323 99
    330 99
    337 99
    344 98
    350 98
    357 97
    364 97
    370 97
    376 96
    383 96
    389 95
    395 95
    401 94
    407 94
    412 93
    418 93
    423 92
    429 92
    434 91
    439 91
    444 90
    449 90
    454 89
    458 89
    463 88
    467 88
    471 87
    476 86
    480 86
    483 85
    487 85
    491 84
    494 84
    497 83
    501 82
    504 82
    507 81
    509 80
    512 80
    514 79
    517 78
    519 78
    521 77
    523 77
    525 76
    526 75
    528 74
    529 74
    530 73
    531 72
    532 72
    533 71
    533 70
    534 70
    534 69
    534 68
    534 67
    534 67
    534 66
    533 65
    532 65
    532 64
    531 63
    530 62
    528 62
    527 61
    525 60
    524 59
    522 59
    520 58
    518 57
    515 56
    513 55
    510 55
    507 54
    504 53
    501 52
    498 52
    495 51
    491 50
    487 49
    483 48
    479 48
    475 47
    471 46
    467 45
    462 44
    457 44
    452 43
    447 42
    442 41
    437 40
    431 39
    426 39
    420 38
    414 37
    408 36
    401 35
    395 35
    389 34
    382 33
    375 32
    368 31
    361 31
    354 30
    346 29
    339 28
    331 27
    323 26
    315 26
    307 25
    299 24
    291 23
    282 22
    274 21
    265 21
    256 20
    247 19
    238 18
    228 17
    219 17
    209 16
    200 15
    190 14
    180 13
    170 12
    159 12
    149 11
    139 10
    128 9
    117 8
    106 8
    95 7
    84 6
    73 5
    62 4
    50 3
    39 3
    27 2
    15 1
    3 0
    -9 -1
    -21 -1
    -34 -2
    -46 -3
    -59 -4
    -71 -5
    -84 -5
    -97 -6
    -110 -7
    -123 -8
    -137 -9
    -150 -9
    -163 -10
    -177 -11
    -191 -12
    -205 -13
    -219 -13
    -233 -14
    -247 -15
    -261 -16
    -275 -17
    -290 -17
    -304 -18
    -319 -19
    -334 -20
    -349 -20
    -364 -21
    -379 -22
    -394 -23
    -409 -23
    -425 -24
    -440 -25
    -456 -26
    -471 -27
    -487 -27
    -503 -28
    -519 -29
    -535 -30
    -551 -30
    -568 -31
    -584 -32
    -600 -33
    -617 -33
    -634 -34
    -650 -35
    -667 -36
    -684 -36
    -701 -37
    -718 -38
    -735 -39
    -752 -39
    -770 -40
    -787 -41
    -805 -41
    -822 -42
    -840 -43
    -858 -44
    -876 -44
    -894 -45
    -912 -46
    -930 -46
    931 -50
    912 -50
    894 -49
    877 -48
    859 -47
    841 -47
    823 -46
    806 -45
    788 -44
    771 -43
    753 -43
    736 -42
    719 -41
    702 -40
    685 -39
    668 -39
    651 -38
    634 -37
    618 -36
    601 -35
    585 -35
    568 -34
    552 -33
    536 -32
    520 -31
    504 -30
    488 -30
    472 -29
    456 -28
    441 -27
    425 -26
    410 -26
    395 -25
    380 -24
    364 -23
    349 -22
    335 -21
    320 -20
    305 -20
    291 -19
    276 -18
    262 -17
    248 -16
    233 -15
    219 -15
    205 -14
    192 -13
    178 -12
    164 -11
    151 -10
    137 -9
    124 -9
    111 -8
    98 -7
    85 -6
    72 -5
    60 -4
    47 -3
    35 -2
    22 -2
    10 -1
    -2 0
    -14 1
    -26 2
    -38 3
    -49 4
    -61 5
    -72 5
    -83 6
    -95 7
    -106 8
    -116 9
    -127 10
    -138 11
    -148 12
    -159 12
    -169 13
    -179 14
    -189 15
    -199 16
    -209 17
    -218 18
    -228 19
    -237 20
    -246 21
    -255 21
    -264 22
    -273 23
    -281 24
    -290 25
    -298 26
    -307 27
    -315 28
    -323 29
    -330 29
    -338 30
    -346 31
    -353 32
    -360 33
    -367 34
    -374 35
    -381 36
    -388 37
    -394 37
    -401 38
    -407 39
    -413 40
    -419 41
    -425 42
    -430 43
    -436 44
    -441 44
    -446 45
    -451 46
    -456 47
    -461 48
    -466 49
    -470 50
    -475 51
    -479 51
    -483 52
    -487 53
    -490 54
    -494 55
    -497 56
    -500 57
    -504 57
    -506 58
    -509 59
    -512 60
    -514 61
    -517 62
    -519 62
    -521 63
    -523 64
    -524 65
    -526 66
    -527 67
    -529 67
    -530 68
    -531 69
    -532 70
    -532 71
    -533 71
    -533 72
    -533 73
    -533 74
    -533 75
    -533 75
    -533 76
    -532 77
    -531 78
    -530 78
    -529 79
    -528 80
    -527 81
    -525 81
    -524 82
    -522 83
    -520 83
    -518 84
    -516 85
    -514 86
    -511 86
    -509 87
    -506 88
    -503 88
    -500 89
    -497 90
    -493 90
    -490 91
    -486 92
    -483 92
    -479 93
    -475 94
    -471 94
    -467 95
    -462 95
    -458 96
    -453 97
    -448 97
    -443 98
    -438 98
    -433 99
    -428 99
    -423 100
    -417 100
    -412 101
    -406 102
    -400 102
    -394 103
    -388 103
    -382 103
    -376 104
    -370 104
    -363 105
    -357 105
    -350 106
    -343 106
    -336 107
    -329 107
    -322 107
    -315 108
    -308 108
    -301 109
    -293 109
    -286 109
    -278 110
    -271 110
    -263 110
    -255 111
    -248 111
    -240 111
    -232 112
    -224 112
    -216 112
    -207 112
    -199 113
    -191 113
    -183 113
    -174 113
    -166 113
    -157 114
    -149 114
    -140 114
    -132 114
    -123 114
    -114 114
    -106 115
    -97 115
    -88 115
    -80 115
    -71 115
    -62 115
    -53 115
    -44 115
    -35 115
    -27 115
    -18 115
    -9 115
    0 115
    9 115
    18 115
    27 115
    35 115
    44 115
    53 115
    62 115
    71 115
    80 115
    88 115
    97 115
    106 115
    114 114
    123 114
    132 114
    140 114
    149 114
    157 114
    166 113
    174 113
    183 113
    191 113
    199 113
    207 112
    216 112
    224 112
    232 112
    240 111
    248 111
    255 111
    263 110
    271 110
    278 110
    286 109
    293 109
    301 109
    308 108
    315 108
    322 107
    329 107
    336 107
    343 106
    350 106
    357 105
    363 105
    370 104
    376 104
    382 103
    388 103
    394 103
    400 102
    406 102
    412 101
    417 100
    423 100
    428 99
    433 99
    438 98
    443 98
    448 97
    453 97
    458 96
    462 95
    467 95
    471 94
    475 94
    479 93
    483 92
    486 92
    490 91
    493 90
    497 90
    500 89
    503 88
    506 88
    509 87
    511 86
    514 86
    516 85
    518 84
    520 83
    522 83
    524 82
    525 81
    527 81
    528 80
    529 79
    530 78
    531 78
    532 77
    533 76
    533 75
    533 75
    533 74
    533 73
    533 72
    533 71
    532 71
    532 70
    531 69
    530 68
    529 67
    527 67
    526 66
    524 65
    523 64
    521 63
    519 62
    517 62
    514 61
    512 60
    509 59
    506 58
    504 57
    500 57
    497 56
    494 55
    490 54
    487 53
    483 52
    479 51
    475 51
    470 50
    466 49
    461 48
    456 47
    451 46
    446 45
    441 44
    436 44
    430 43
    425 42
    419 41
    413 40
    407 39
    401 38
    394 37
    388 37
    381 36
    374 35
    367 34
    360 33
    353 32
    346 31
    338 30
    330 29
    323 29
    315 28
    307 27
    298 26
    290 25
    281 24
    273 23
    264 22
    255 21
    246 21
    237 20
    228 19
    218 18
    209 17
    199 16
    189 15
    179 14
    169 13
    159 12
    148 12
    138 11
    127 10
    116 9
    106 8
    95 7
    83 6
    72 5
    61 5
    49 4
    38 3
    26 2
    14 1
    2 0
    -10 -1
    -22 -2
    -35 -2
    -47 -3
    -60 -4
    -72 -5
    -85 -6
    -98 -7
    -111 -8
    -124 -9
    -137 -9
    -151 -10
    -164 -11
    -178 -12
    -192 -13
    -205 -14
    -219 -15
    -233 -15
    -248 -16
    -262 -17
    -276 -18
    -291 -19
    -305 -20
    -320 -20
    -335 -21
    -349 -22
    -364 -23
    -380 -24
    -395 -25
    -410 -26
    -425 -26
    -441 -27
    -456 -28
    -472 -29
    -488 -30
    -504 -30
    -520 -31
    -536 -32
    -552 -33
    -568 -34
    -585 -35
    -601 -35
    -618 -36
    -634 -37
    -651 -38
    -668 -39
    -685 -39
    -702 -40
    -719 -41
    -736 -42
    -753 -43
    -771 -43
    -788 -44
    -806 -45
    -823 -46
    -841 -47
    -859 -47
    -877 -48
    -894 -49
    -912 -50
    -931 -50
    931 -54
    913 -53
    895 -53
    877 -52
    859 -51
    842 -50
    824 -49
    806 -48
    789 -48
    771 -47
    754 -46
    737 -45
    720 -44
    703 -43
    686 -42
    669 -42
    652 -41
    635 -40
    618 -39
    602 -38
    586 -37
    569 -36
    553 -36
    537 -35
    521 -34
    505 -33
    489 -32
    473 -31
    457 -30
    442 -29
    426 -28
    411 -28
    396 -27
    380 -26
    365 -25
    350 -24
    335 -23
    321 -22
    306 -21
    291 -20
    277 -19
    263 -18
    248 -18
    234 -17
    220 -16
    206 -15
    192 -14
    179 -13
    165 -12
    152 -11
    138 -10
    125 -9
    112 -8
    99 -7
    86 -6
    73 -6
    60 -5
    48 -4
    35 -3
    23 -2
    11 -1
    -1 0
    -13 1
    -25 2
    -37 3
    -48 4
    -60 5
    -71 6
    -83 7
    -94 8
    -105 9
    -115 10
    -126 11
    -137 11
    -147 12
    -158 13
    -168 14
    -178 15
    -188 16
    -198 17
    -208 18
    -217 19
    -227 20
    -236 21
    -245 22
    -254 23
    -263 24
    -272 25
    -280 26
    -289 27
    -297 28
    -306 29
    -314 30
    -322 31
    -329 32
    -337 33
    -345 34
    -352 34
    -359 35
    -366 36
    -373 37
    -380 38
    -387 39
    -393 40
    -400 41
    -406 42
    -412 43
    -418 44
    -424 45
    -429 46
    -435 47
    -440 48
    -445 49
    -451 50
    -455 51
    -460 52
    -465 52
    -469 53
    -474 54
    -478 55
    -482 56
    -486 57
    -489 58
    -493 59
    -496 60
    -500 61
    -503 62
    -506 63
    -508 64
    -511 64
    -514 65
    -516 66
    -518 67
    -520 68
    -522 69
    -524 70
    -525 71
    -527 72
    -528 72
    -529 73
    -530 74
    -531 75
    -531 76
    -532 77
    -532 78
    -532 78
    -533 79
    -532 80
    -532 81
    -532 82
    -531 83
    -530 83
    -530 84
    -529 85
    -527 86
    -526 87
    -525 87
    -523 88
    -521 89
    -519 90
    -517 91
    -515 91
    -513 92
    -511 93
    -508 94
    -505 94
    -502 95
    -499 96
    -496 96
    -493 97
    -489 98
    -486 99
    -482 99
    -478 100
    -474 101
    -470 101
    -466 102
    -462 103
    -457 103
    -452 104
    -448 104
    -443 105
    -438 106
    -433 106
    -428 107
    -422 107
    -417 108
    -411 109
    -405 109
    -400 110
    -394 110
    -388 111
    -382 111
    -375 112
    -369 112
    -363 113
    -356 113
    -349 114
    -343 114
    -336 115
    -329 115
    -322 116
    -315 116
    -308 116
    -300 117
    -293 117
    -286 118
    -278 118
    -270 118
    -263 119
    -255 119
    -247 119
    -239 120
    -231 120
    -223 120
    -215 121
    -207 121
    -199 121
    -191 121
    -182 122
    -174 122
    -166 122
    -157 122
    -149 122
    -140 123
    -132 123
    -123 123
    -114 123
    -106 123
    -97 123
    -88 124
    -79 124
    -71 124
    -62 124
    -53 124
    -44 124
    -35 124
    -27 124
    -18 124
    -9 124
    0 124
    9 124
    18 124
    27 124
    35 124
    44 124
    53 124
    62 124
    71 124
    79 124
    88 124
    97 123
    106 123
    114 123
    123 123
    132 123
    140 123
    149 122
    157 122
    166 122
    174 122
    182 122
    191 121
    199 121
    207 121
    215 121
    223 120
    231 120
    239 120
    247 119
    255 119
    263 119
    270 118
    278 118
    286 118
    293 117
    300 117
    308 116
    315 116
    322 116
    329 115
    336 115
    343 114
    349 114
    356 113
    363 113
    369 112
    375 112
    382 111
    388 111
    394 110
    400 110
    405 109
    411 109
    417 108
    422 107
    428 107
    433 106
    438 106
    443 105
    448 104
    452 104
    457 103
    462 103
    466 102
    470 101
    474 101
    478 100
    482 99
    486 99
    489 98
    493 97
    496 96
    499 96
    502 95
    505 94
    508 94
    511 93
    513 92
    515 91
    517 91
    519 90
    521 89
    523 88
    525 87
    526 87
    527 86
    529 85
    530 84
    530 83
    531 83
    532 82
    532 81
    532 80
    533 79
    532 78
    532 78
    532 77
    531 76
    531 75
    530 74
    529 73
    528 72
    527 72
    525 71
    524 70
    522 69
    520 68
    518 67
    516 66
    514 65
    511 64
    508 64
    506 63
    503 62
    500 61
    496 60
    493 59
    489 58
    486 57
    482 56
    478 55
    474 54
    469 53
    465 52
    460 52
    455 51
    451 50
    445 49
    440 48
    435 47
    429 46
    424 45
    418 44
    412 43
    406 42
    400 41
    393 40
    387 39
    380 38
    373 37
    366 36
    359 35
    352 34
    345 34
    337 33
    329 32
    322 31
    314 30
    306 29
    297 28
    289 27
    280 26
    272 25
    263 24
    254 23
    245 22
    236 21
    227 20
    217 19
    208 18
    198 17
    188 16
    178 15
    168 14
    158 13
    147 12
    137 11
    126 11
    115 10
    105 9
    94 8
    83 7
    71 6
    60 5
    48 4
    37 3
    25 2
    13 1
    1 0
    -11 -1
    -23 -2
    -35 -3
    -48 -4
    -60 -5
    -73 -6
    -86 -6
    -99 -7
    -112 -8
    -125 -9
    -138 -10
    -152 -11
    -165 -12
    -179 -13
    -192 -14
    -206 -15
    -220 -16
    -234 -17
    -248 -18
    -263 -18
    -277 -19
    -291 -20
    -306 -21
    -321 -22
    -335 -23
    -350 -24
    -365 -25
    -380 -26
    -396 -27
    -411 -28
    -426 -28
    -442 -29
    -457 -30
    -473 -31
    -489 -32
    -505 -33
    -521 -34
    -537 -35
    -553 -36
    -569 -36
    -586 -37
    -602 -38
    -618 -39
    -635 -40
    -652 -41
    -669 -42
    -686 -42
    -703 -43
    -720 -44
    -737 -45
    -754 -46
    -771 -47
    -789 -48
    -806 -48
    -824 -49
    -842 -50
    -859 -51
    -877 -52
    -895 -53
    -913 -53
    -931 -54
    932 -58
    914 -57
    896 -56
    878 -56
    860 -55
    843 -54
    825 -53
    807 -52
    790 -51
    772 -50
    755 -49
    738 -48
    721 -47
    703 -46
    686 -46
    670 -45
    653 -44
    636 -43
    619 -42
    603 -41
    586 -40
    570 -39
    554 -38
    538 -37
    522 -36
    506 -35
    490 -34
    474 -33
    458 -32
    443 -31
    427 -31
    412 -30
    397 -29
    381 -28
    366 -27
    351 -26
    336 -25
    322 -24
    307 -23
    292 -22
    278 -21
    264 -20
    249 -19
    235 -18
    221 -17
    207 -16
    193 -15
    180 -14
    166 -13
    153 -12
    139 -11
    126 -10
    113 -9
    100 -8
    87 -7
    74 -6
    61 -5
    49 -4
    36 -3
    24 -2
    12 -1
    -0 0
    -12 1
    -24 2
    -36 3
    -47 4
    -59 5
    -70 6
    -82 7
    -93 8
    -104 9
    -115 10
    -125 11
    -136 12
    -146 13
    -157 14
    -167 15
    -177 16
    -187 17
    -197 18
    -207 19
    -216 20
    -226 21
    -235 22
    -244 23
    -253 24
    -262 26
    -271 27
    -279 28
    -288 29
    -296 30
    -305 31
    -313 32
    -321 33
    -328 34
    -336 35
    -344 36
    -351 37
    -358 38
    -365 39
    -372 40
    -379 41
    -386 42
    -392 43
    -399 44
    -405 45
    -411 46
    -417 47
    -423 48
    -428 49
    -434 50
    -439 51
    -445 52
    -450 53
    -454 54
    -459 55
    -464 56
    -468 57
    -473 58
    -477 59
    -481 60
    -485 61
    -488 62
    -492 63
    -495 64
    -499 65
    -502 66
    -505 67
    -507 68
    -510 69
    -513 70
    -515 71
    -517 72
    -519 73
    -521 74
    -523 75
    -524 76
    -526 77
    -527 77
    -528 78
    -529 79
    -530 80
    -531 81
    -531 82
    -531 83
    -532 84
    -532 85
    -532 86
    -531 87
    -531 88
    -530 88
    -530 89
    -529 90
    -528 91
    -527 92
    -525 93
    -524 94
    -522 94
    -521 95
    -519 96
    -517 97
    -515 98
    -512 98
    -510 99
    -507 100
    -504 101
    -502 102
    -499 102
    -495 103
    -492 104
    -489 105
    -485 105
    -481 106
    -478 107
    -474 108
    -469 108
    -465 109
    -461 110
    -456 110
    -452 111
    -447 112
    -442 112
    -437 113
    -432 114
    -427 114
    -422 115
    -416 116
    -411 116
    -405 117
    -399 117
    -393 118
    -387 119
    -381 119
    -375 120
    -369 120
    -362 121
    -356 121
    -349 122
    -342 122
    -335 123
    -328 123
    -321 124
    -314 124
    -307 125
    -300 125
    -293 125
    -285 126
    -278 126
    -270 127
    -262 127
    -255 127
    -247 128
    -239 128
    -231 128
    -223 129
    -215 129
    -207 129
    -199 130
    -190 130
    -182 130
    -174 130
    -165 131
    -157 131
    -148 131
    -140 131
    -131 131
    -123 132
    -114 132
    -106 132
    -97 132
    -88 132
    -79 132
    -71 132
    -62 132
    -53 133
    -44 133
    -35 133
    -27 133
    -18 133
    -9 133
    0 133
    9 133
    18 133
    27 133
    35 133
    44 133
    53 133
    62 132
    71 132
    79 132
    88 132
    97 132
    106 132
    114 132
    123 132
    131 131
    140 131
    148 131
    157 131
    165 131
    174 130
    182 130
    190 130
    199 130
    207 129
    215 129
    223 129
    231 128
    239 128
    247 128
    255 127
    262 127
    270 127
    278 126
    285 126
    293 125
    300 125
    307 125
    314 124
    321 124
    328 123
    335 123
    342 122
    349 122
    356 121
    362 121
    369 120
    375 120
    381 119
    387 119
    393 118
    399 117
    405 117
    411 116
    416 116
    422 115
    427 114
    432 114
    437 113
    442 112
    447 112
    452 111
    456 110
    461 110
    465 109
    469 108
    474 108
    478 107
    481 106
    485 105
    489 105
    492 104
    495 103
    499 102
    502 102
    504 101
    507 100
    510 99
    512 98
    515 98
    517 97
    519 96
    521 95
    522 94
    524 94
    525 93
    527 92
    528 91
    529 90
    530 89
    530 88
    531 88
    531 87
    532 86
    532 85
    532 84
    531 83
    531 82
    531 81
    530 80
    529 79
    528 78
    527 77
    526 77
    524 76
    523 75
    521 74
    519 73
    517 72
    515 71
    513 70
    510 69
    507 68
    505 67
    502 66
    499 65
    495 64
    492 63
    488 62
    485 61
    481 60
    477 59
    473 58
    468 57
    464 56
    459 55
    454 54
    450 53
    445 52
    439 51
    434 50
    428 49
    423 48
    417 47
    411 46
    405 45
    399 44
    392 43
    386 42
    379 41
    372 40
    365 39
    358 38
    351 37
    344 36
    336 35
    328 34
    321 33
    313 32
    305 31
    296 30
    288 29
    279 28
    271 27
    262 26
    253 24
    244 23
    235 22
    226 21
    216 20
    207 19
    197 18
    187 17
    177 16
    167 15
    157 14
    146 13
    136 12
    125 11
    115 10
    104 9
    93 8
    82 7
    70 6
    59 5
    47 4
    36 3
    24 2
    12 1
    0 0
    -12 -1
    -24 -2
    -36 -3
    -49 -4
    -61 -5
    -74 -6
    -87 -7
    -100 -8
    -113 -9
    -126 -10
    -139 -11
    -153 -12
    -166 -13
    -180 -14
    -193 -15
    -207 -16
    -221 -17
    -235 -18
    -249 -19
    -264 -20
    -278 -21
    -292 -22
    -307 -23
    -322 -24
    -336 -25
    -351 -26
    -366 -27
    -381 -28
    -397 -29
    -412 -30
    -427 -31
    -443 -31
    -458 -32
    -474 -33
    -490 -34
    -506 -35
    -522 -36
    -538 -37
    -554 -38
    -570 -39
    -586 -40
    -603 -41
    -619 -42
    -636 -43
    -653 -44
    -670 -45
    -686 -46
    -703 -46
    -721 -47
    -738 -48
    -755 -49
    -772 -50
    -790 -51
    -807 -52
    -825 -53
    -843 -54
    -860 -55
    -878 -56
    -896 -56
    -914 -57
    -932 -58
    933 -62
    915 -61
    897 -60
    879 -59
    861 -58
    843 -57
    826 -56
    808 -55
    791 -55
    773 -54
    756 -53
    739 -52
    721 -51
    704 -50
    687 -49
    671 -48
    654 -47
    637 -46
    620 -45
    604 -44
    587 -43
    571 -42
    555 -41
    539 -40
    523 -39
    507 -38
    491 -37
    475 -36
    459 -35
    444 -34
    428 -33
    413 -32
    398 -31
    382 -30
    367 -29
    352 -27
    337 -26
    323 -25
    308 -24
    293 -23
    279 -22
    265 -21
    250 -20
    236 -19
    222 -18
    208 -17
    194 -16
    181 -15
    167 -14
    154 -13
    140 -12
    127 -11
    114 -10
    101 -9
    88 -8
    75 -7
    62 -5
    50 -4
    37 -3
    25 -2
    13 -1
    1 -0
    -11 1
    -23 2
    -35 3
    -46 4
    -58 5
    -69 6
    -80 7
    -92 9
    -103 10
    -113 11
    -124 12
    -135 13
    -145 14
    -156 15
    -166 16
    -176 17
    -186 18
    -196 19
    -206 21
    -215 22
    -225 23
    -234 24
    -243 25
    -252 26
    -261 27
    -270 28
    -278 29
    -287 30
    -295 31
    -304 33
    -312 34
    -320 35
    -327 36
    -335 37
    -343 38
    -350 39
    -357 40
    -364 41
    -371 42
    -378 44
    -385 45
    -391 46
    -398 47
    -404 48
    -410 49
    -416 50
    -422 51
    -427 52
    -433 53
    -438 54
    -443 55
    -449 57
    -453 58
    -458 59
    -463 60
    -467 61
    -472 62
    -476 63
    -480 64
    -484 65
    -487 66
    -491 67
    -494 68
    -498 69
    -501 70
    -504 71
    -506 72
    -509 73
    -512 74
    -514 75
    -516 76
    -518 77
    -520 78
    -522 80
    -523 81
    -525 82
    -526 83
    -527 84
    -528 84
    -529 85
    -530 86
    -530 87
    -530 88
    -531 89
    -531 90
    -531 91
    -530 92
    -530 93
    -529 94
    -529 95
    -528 96
    -527 97
    -526 98
    -524 99
    -523 100
    -521 101
    -520 101
    -518 102
    -516 103
    -514 104
    -511 105
    -509 106
    -506 107
    -504 107
    -501 108
    -498 109
    -495 110
    -491 111
    -488 112
    -484 112
    -481 113
    -477 114
    -473 115
    -469 115
    -465 116
    -460 117
    -456 118
    -451 118
    -446 119
    -442 120
    -437 120
    -432 121
    -426 122
    -421 122
    -416 123
    -410 124
    -404 124
    -399 125
    -393 126
    -387 126
    -381 127
    -374 127
    -368 128
    -362 129
    -355 129
    -348 130
    -342 130
    -335 131
    -328 131
    -321 132
    -314 132
    -307 133
    -299 133
    -292 134
    -285 134
    -277 134
    -270 135
    -262 135
    -254 136
    -246 136
    -239 136
    -231 137
    -223 137
    -215 137
    -207 138
    -198 138
    -190 138
    -182 139
    -174 139
    -165 139
    -157 139
    -148 140
    -140 140
    -131 140
    -123 140
    -114 140
    -105 141
    -97 141
    -88 141
    -79 141
    -71 141
    -62 141
    -53 141
    -44 141
    -35 141
    -27 141
    -18 141
    -9 141
    0 141
    9 141
    18 141
    27 141
    35 141
    44 141
    53 141
    62 141
    71 141
    79 141
    88 141
    97 141
    105 141
    114 140
    123 140
    131 140
    140 140
    148 140
    157 139
    165 139
    174 139
    182 139
    190 138
    198 138
    207 138
    215 137
    223 137
    231 137
    239 136
    246 136
    254 136
    262 135
    270 135
    277 134
    285 134
    292 134
    299 133
    307 133
    314 132
    321 132
    328 131
    335 131
    342 130
    348 130
    355 129
    362 129
    368 128
    374 127
    381 127
    387 126
    393 126
    399 125
    404 124
    410 124
    416 123
    421 122
    426 122
    432 121
    437 120
    442 120
    446 119
    451 118
    456 118
    460 117
    465 116
    469 115
    473 115
    477 114
    481 113
    484 112
    488 112
    491 111
    495 110
    498 109
    501 108
    504 107
    506 107
    509 106
    511 105
    514 104
    516 103
    518 102
    520 101
    521 101
    523 100
    524 99
    526 98
    527 97
    528 96
    529 95
    529 94
    530 93
    530 92
    531 91
    531 90
    531 89
    530 88
    530 87
    530 86
    529 85
    528 84
    527 84
    526 83
    525 82
    523 81
    522 80
    520 78
    518 77
    516 76
    514 75
    512 74
    509 73
    506 72
    504 71
    501 70
    498 69
    494 68
    491 67
    487 66
    484 65
    480 64
    476 63
    472 62
    467 61
    463 60
    458 59
    453 58
    449 57
    443 55
    438 54
    433 53
    427 52
    422 51
    416 50
    410 49
    404 48
    398 47
    391 46
    385 45
    378 44
    371 42
    364 41
    357 40
    350 39
    343 38
    335 37
    327 36
    320 35
    312 34
    304 33
    295 31
    287 30
    278 29
    270 28
    261 27
    252 26
    243 25
    234 24
    225 23
    215 22
    206 21
    196 19
    186 18
    176 17
    166 16
    156 15
    145 14
    135 13
    124 12
    113 11
    103 10
    92 9
    80 7
    69 6
    58 5
    46 4
    35 3
    23 2
    11 1
    -1 -0
    -13 -1
    -25 -2
    -37 -3
    -50 -4
    -62 -5
    -75 -7
    -88 -8
    -101 -9
    -114 -10
    -127 -11
    -140 -12
    -154 -13
    -167 -14
    -181 -15
    -194 -16
    -208 -17
    -222 -18
    -236 -19
    -250 -20
    -265 -21
    -279 -22
    -293 -23
    -308 -24
    -323 -25
    -337 -26
    -352 -27
    -367 -29
    -382 -30
    -398 -31
    -413 -32
    -428 -33
    -444 -34
    -459 -35
    -475 -36
    -491 -37
    -507 -38
    -523 -39
    -539 -40
    -555 -41
    -571 -42
    -587 -43
    -604 -44
    -620 -45
    -637 -46
    -654 -47
    -671 -48
    -687 -49
    -704 -50
    -721 -51
    -739 -52
    -756 -53
    -773 -54
    -791 -55
    -808 -55
    -826 -56
    -843 -57
    -861 -58
    -879 -59
    -897 -60
    -915 -61
    -933 -62
    934 -66
    916 -65
    898 -64
    880 -63
    862 -62
    844 -61
    827 -60
    809 -59
    792 -58
    774 -57
    757 -56
    740 -55
    722 -54
    705 -53
    688 -52
    672 -51
    655 -50
    638 -49
    621 -48
    605 -47
    588 -45
    572 -44
    556 -43
    540 -42
    524 -41
    508 -40
    492 -39
    476 -38
    460 -37
    445 -36
    429 -35
    414 -34
    399 -33
    383 -31
    368 -30
    353 -29
    338 -28
    324 -27
    309 -26
    294 -25
    280 -24
    266 -23
    251 -22
    237 -20
    223 -19
    209 -18
    196 -17
    182 -16
    168 -15
    155 -14
    141 -13
    128 -12
    115 -10
    102 -9
    89 -8
    76 -7
    64 -6
    51 -5
    39 -4
    26 -2
    14 -1
    2 -0
    -10 1
    -22 2
    -34 3
    -45 4
    -57 6
    -68 7
    -79 8
    -90 9
    -101 10
    -112 11
    -123 12
    -134 14
    -144 15
    -155 16
    -165 17
    -175 18
    -185 19
    -195 21
    -204 22
    -214 23
    -223 24
    -233 25
    -242 26
    -251 28
    -260 29
    -269 30
    -277 31
    -286 32
    -294 33
    -302 35
    -310 36
    -318 37
    -326 38
    -334 39
    -341 40
    -349 41
    -356 43
    -363 44
    -370 45
    -377 46
    -384 47
    -390 48
    -397 50
    -403 51
    -409 52
    -415 53
    -421 54
    -426 55
    -432 56
    -437 58
    -442 59
    -447 60
    -452 61
    -457 62
    -462 63
    -466 64
    -471 66
    -475 67
    -479 68
    -483 69
    -486 70
    -490 71
    -493 72
    -497 73
    -500 75
    -503 76
    -505 77
    -508 78
    -511 79
    -513 80
    -515 81
    -517 82
    -519 83
    -521 84
    -522 85
    -524 86
    -525 87
    -526 89
    -527 90
    -528 91
    -529 92
    -529 93
    -529 94
    -530 95
    -530 96
    -530 97
    -529 98
    -529 99
    -528 100
    -528 101
    -527 102
    -526 103
    -525 104
    -524 105
    -522 106
    -521 107
    -519 108
    -517 108
    -515 109
    -513 110
    -510 111
    -508 112
    -505 113
    -503 114
    -500 115
    -497 116
    -494 117
    -490 117
    -487 118
    -484 119
    -480 120
    -476 121
    -472 122
    -468 122
    -464 123
    -459 124
    -455 125
    -450 126
    -446 126
    -441 127
    -436 128
    -431 128
    -426 129
    -420 130
    -415 131
    -409 131
    -404 132
    -398 133
    -392 133
    -386 134
    -380 135
    -374 135
    -367 136
    -361 136
    -354 137
    -348 138
    -341 138
    -334 139
    -327 139
    -320 140
    -313 140
    -306 141
    -299 141
    -292 142
    -284 142
    -277 143
    -269 143
    -262 143
    -254 144
    -246 144
    -238 145
    -230 145
    -222 145
    -214 146
    -206 146
    -198 146
    -190 147
    -182 147
    -173 147
    -165 148
    -157 148
    -148 148
    -140 148
    -131 148
    -122 149
    -114 149
    -105 149
    -97 149
    -88 149
    -79 149
    -70 150
    -62 150
    -53 150
    -44 150
    -35 150
    -26 150
    -18 150
    -9 150
    0 150
    9 150
    18 150
    26 150
    35 150
    44 150
    53 150
    62 150
    70 150
    79 149
    88 149
    97 149
    105 149
    114 149
    122 149
    131 148
    140 148
    148 148
    157 148
    165 148
    173 147
    182 147
    190 147
    198 146
    206 146
    214 146
    222 145
    230 145
    238 145
    246 144
    254 144
    262 143
    269 143
    277 143
    284 142
    292 142
    299 141
    306 141
    313 140
    320 140
    327 139
    334 139
    341 138
    348 138
    354 137
    361 136
    367 136
    374 135
    380 135
    386 134
    392 133
    398 133
    404 132
    409 131
    415 131
    420 130
    426 129
    431 128
    436 128
    441 127
    446 126
    450 126
    455 125
    459 124
    464 123
    468 122
    472 122
    476 121
    480 120
    484 119
    487 118
    490 117
    494 117
    497 116
    500 115
    503 114
    505 113
    508 112
    510 111
    513 110
    515 109
    517 108
    519 108
    521 107
    522 106
    524 105
    525 104
    526 103
    527 102
    528 101
    528 100
    529 99
    529 98
    530 97
    530 96
    530 95
    529 94
    529 93
    529 92
    528 91
    527 90
    526 89
    525 87
    524 86
    522 85
    521 84
    519 83
    517 82
    515 81
    513 80
    511 79
    508 78
    505 77
    503 76
    500 75
    497 73
    493 72
    490 71
    486 70
    483 69
    479 68
    475 67
    471 66
    466 64
    462 63
    457 62
    452 61
    447 60
    442 59
    437 58
    432 56
    426 55
    421 54
    415 53
    409 52
    403 51
    397 50
    390 48
    384 47
    377 46
    370 45
    363 44
    356 43
    349 41
    341 40
    334 39
    326 38
    318 37
    310 36
    302 35
    294 33
    286 32
    277 31
    269 30
    260 29
    251 28
    242 26
    233 25
    223 24
    214 23
    204 22
    195 21
    185 19
    175 18
    165 17
    155 16
    144 15
    134 14
    123 12
    112 11
    101 10
    90 9
    79 8
    68 7
    57 6
    45 4
    34 3
    22 2
    10 1
    -2 -0
    -14 -1
    -26 -2
    -39 -4
    -51 -5
    -64 -6
    -76 -7
    -89 -8
    -102 -9
    -115 -10
    -128 -12
    -141 -13
    -155 -14
    -168 -15
    -182 -16
    -196 -17
    -209 -18
    -223 -19
    -237 -20
    -251 -22
    -266 -23
    -280 -24
    -294 -25
    -309 -26
    -324 -27
    -338 -28
    -353 -29
    -368 -30
    -383 -31
    -399 -33
    -414 -34
    -429 -35
    -445 -36
    -460 -37
    -476 -38
    -492 -39
    -508 -40
    -524 -41
    -540 -42
    -556 -43
    -572 -44
    -588 -45
    -605 -47
    -621 -48
    -638 -49
    -655 -50
    -672 -51
    -688 -52
    -705 -53
    -722 -54
    -740 -55
    -757 -56
    -774 -57
    -792 -58
    -809 -59
    -827 -60
    -844 -61
    -862 -62
    -880 -63
    -898 -64
    -916 -65
    -934 -66
    935 -70
    917 -69
    899 -68
    881 -67
    863 -66
    846 -65
    828 -64
    810 -63
    793 -62
    775 -60
    758 -59
    741 -58
    724 -57
    706 -56
    690 -55
    673 -54
    656 -53
    639 -52
    622 -50
    606 -49
    590 -48
    573 -47
    557 -46
    541 -45
    525 -44
    509 -43
    493 -41
    477 -40
    461 -39
    446 -38
    430 -37
    415 -36
    400 -35
    385 -33
    369 -32
    354 -31
    340 -30
    325 -29
    310 -28
    296 -26
    281 -25
    267 -24
    253 -23
    238 -22
    224 -21
    211 -19
    197 -18
    183 -17
    169 -16
    156 -15
    143 -14
    129 -12
    116 -11
    103 -10
    90 -9
    77 -8
    65 -6
    52 -5
    40 -4
    27 -3
    15 -2
    3 -0
    -9 1
    -21 2
    -32 3
    -44 5
    -56 6
    -67 7
    -78 8
    -89 9
    -100 11
    -111 12
    -122 13
    -133 14
    -143 16
    -153 17
    -164 18
    -174 19
    -184 20
    -194 22
    -203 23
    -213 24
    -222 25
    -232 27
    -241 28
    -250 29
    -259 30
    -267 31
    -276 33
    -285 34
    -293 35
    -301 36
    -309 38
    -317 39
    -325 40
    -333 41
    -340 43
    -348 44
    -355 45
    -362 46
    -369 47
    -376 49
    -382 50
    -389 51
    -395 52
    -402 54
    -408 55
    -414 56
    -419 57
    -425 58
    -431 60
    -436 61
    -441 62
    -446 63
    -451 64
    -456 66
    -461 67
    -465 68
    -469 69
    -474 70
    -478 72
    -481 73
    -485 74
    -489 75
    -492 76
    -495 78
    -498 79
    -501 80
    -504 81
    -507 82
    -509 83
    -512 85
    -514 86
    -516 87
    -518 88
    -520 89
    -521 90
    -523 91
    -524 92
    -525 94
    -526 95
    -527 96
    -528 97
    -528 98
    -528 99
    -529 100
    -529 101
    -529 102
    -528 103
    -528 104
    -527 105
    -527 107
    -526 108
    -525 109
    -524 110
    -523 111
    -521 112
    -520 113
    -518 114
    -516 115
    -514 116
    -512 117
    -510 118
    -507 119
    -505 119
    -502 120
    -499 121
    -496 122
    -493 123
    -490 124
    -486 125
    -483 126
    -479 127
    -475 128
    -471 129
    -467 129
    -463 130
    -459 131
    -454 132
    -450 133
    -445 133
    -440 134
    -435 135
    -430 136
    -425 137
    -420 137
    -414 138
    -409 139
    -403 139
    -397 140
    -391 141
    -385 142
    -379 142
    -373 143
    -367 144
    -360 144
    -354 145
    -347 145
    -341 146
    -334 147
    -327 147
    -320 148
    -313 148
    -306 149
    -299 149
    -291 150
    -284 150
    -276 151
    -269 151
    -261 152
    -253 152
    -246 153
    -238 153
    -230 153
    -222 154
    -214 154
    -206 154
    -198 155
    -190 155
    -181 155
    -173 156
    -165 156
    -156 156
    -148 157
    -139 157
    -131 157
    -122 157
    -114 157
    -105 158
    -96 158
    -88 158
    -79 158
    -70 158
    -62 158
    -53 158
    -44 158
    -35 159
    -26 159
    -18 159
    -9 159
    0 159
    9 159
    18 159
    26 159
    35 159
    44 158
    53 158
    62 158
    70 158
    79 158
    88 158
    96 158
    105 158
    114 157
    122 157
    131 157
    139 157
    148 157
    156 156
    165 156
    173 156
    181 155
    190 155
    198 155
    206 154
    214 154
    222 154
    230 153
    238 153
    246 153
    253 152
    261 152
    269 151
    276 151
    284 150
    291 150
    299 149
    306 149
    313 148
    320 148
    327 147
    334 147
    341 146
    347 145
    354 145
    360 144
    367 144
    373 143
    379 142
    385 142
    391 141
    397 140
    403 139
    409 139
    414 138
    420 137
    425 137
    430 136
    435 135
    440 134
    445 133
    450 133
    454 132
    459 131
    463 130
    467 129
    471 129
    475 128
    479 127
    483 126
    486 125
    490 124
    493 123
    496 122
    499 121
    502 120
    505 119
    507 119
    510 118
    512 117
    514 116
    516 115
    518 114
    520 113
    521 112
    523 111
    524 110
    525 109
    526 108
    527 107
    527 105
    528 104
    528 103
    529 102
    529 101
    529 100
    528 99
    528 98
    528 97
    527 96
    526 95
    525 94
    524 92
    523 91
    521 90
    520 89
    518 88
    516 87
    514 86
    512 85
    509 83
    507 82
    504 81
    501 80
    498 79
    495 78
    492 76
    489 75
    485 74
    481 73
    478 72
    474 70
    469 69
    465 68
    461 67
    456 66
    451 64
    446 63
    441 62
    436 61
    431 60
    425 58
    419 57
    414 56
    408 55
    402 54
    395 52
    389 51
    382 50
    376 49
    369 47
    362 46
    355 45
    348 44
    340 43
    333 41
    325 40
    317 39
    309 38
    301 36
    293 35
    285 34
    276 33
    267 31
    259 30
    250 29
    241 28
    232 27
    222 25
    213 24
    203 23
    194 22
    184 20
    174 19
    164 18
    153 17
    143 16
    133 14
    122 13
    111 12
    100 11
    89 9
    78 8
    67 7
    56 6
    44 5
    32 3
    21 2
    9 1
    -3 -0
    -15 -2
    -27 -3
    -40 -4
    -52 -5
    -65 -6
    -77 -8
    -90 -9
    -103 -10
    -116 -11
    -129 -12
    -143 -14
    -156 -15
    -169 -16
    -183 -17
    -197 -18
    -211 -19
    -224 -21
    -238 -22
    -253 -23
    -267 -24
    -281 -25
    -296 -26
    -310 -28
    -325 -29
    -340 -30
    -354 -31
    -369 -32
    -385 -33
    -400 -35
    -415 -36
    -430 -37
    -446 -38
    -461 -39
    -477 -40
    -493 -41
    -509 -43
    -525 -44
    -541 -45
    -557 -46
    -573 -47
    -590 -48
    -606 -49
    -622 -50
    -639 -52
    -656 -53
    -673 -54
    -690 -55
    -706 -56
    -724 -57
    -741 -58
    -758 -59
    -775 -60
    -793 -62
    -810 -63
    -828 -64
    -846 -65
    -863 -66
    -881 -67
    -899 -68
    -917 -69
    -935 -70
    936 -74
    918 -73
    900 -72
    882 -71
    864 -70
    847 -68
    829 -67
    811 -66
    794 -65
    776 -64
    759 -63
    742 -62
    725 -60
    708 -59
    691 -58
    674 -57
    657 -56
    640 -55
    624 -53
    607 -52
    591 -51
    574 -50
    558 -49
    542 -47
    526 -46
    510 -45
    494 -44
    478 -43
    463 -41
    447 -40
    432 -39
    416 -38
    401 -37
    386 -35
    371 -34
    356 -33
    341 -32
    326 -31
    311 -29
    297 -28
    282 -27
    268 -26
    254 -24
    240 -23
    226 -22
    212 -21
    198 -19
    184 -18
    171 -17
    157 -16
    144 -14
    131 -13
    117 -12
    104 -11
    91 -9
    79 -8
    66 -7
    53 -6
    41 -4
    29 -3
    16 -2
    4 -0
    -8 1
    -19 2
    -31 3
    -43 5
    -54 6
    -66 7
    -77 8
    -88 10
    -99 11
    -110 12
    -121 14
    -131 15
    -142 16
    -152 18
    -162 19
    -172 20
    -182 21
    -192 23
    -202 24
    -212 25
    -221 27
    -230 28
    -239 29
    -249 30
    -257 32
    -266 33
    -275 34
    -283 36
    -292 37
    -300 38
    -308 40
    -316 41
    -324 42
    -331 43
    -339 45
    -346 46
    -354 47
    -361 49
    -368 50
    -375 51
    -381 52
    -388 54
    -394 55
    -400 56
    -406 58
    -412 59
    -418 60
    -424 61
    -429 63
    -435 64
    -440 65
    -445 67
    -450 68
    -455 69
    -459 70
    -464 72
    -468 73
    -472 74
    -476 75
    -480 77
    -484 78
    -487 79
    -491 80
    -494 82
    -497 83
    -500 84
    -503 85
    -506 87
    -508 88
    -511 89
    -513 90
    -515 91
    -517 93
    -518 94
    -520 95
    -521 96
    -523 97
    -524 99
    -525 100
    -526 101
    -526 102
    -527 103
    -527 104
    -528 106
    -528 107
    -527 108
    -527 109
    -527 110
    -526 111
    -526 112
    -525 113
    -524 114
    -523 115
    -522 117
    -520 118
    -519 119
    -517 120
    -515 121
    -513 122
    -511 123
    -509 124
    -506 125
    -504 126
    -501 127
    -498 128
    -495 129
    -492 130
    -489 131
    -485 132
    -482 133
    -478 134
    -474 134
    -470 135
    -466 136
    -462 137
    -458 138
    -453 139
    -449 140
    -444 141
    -439 141
    -434 142
    -429 143
    -424 144
    -419 145
    -413 145
    -408 146
    -402 147
    -396 148
    -391 148
    -385 149
    -379 150
    -372 151
    -366 151
    -360 152
    -353 153
    -347 153
    -340 154
    -333 154
    -326 155
    -319 156
    -312 156
    -305 157
    -298 157
    -291 158
    -283 158
    -276 159
    -268 159
    -261 160
    -253 160
    -245 161
    -237 161
    -230 162
    -222 162
    -214 162
    -206 163
    -197 163
    -189 163
    -181 164
    -173 164
    -164 164
    -156 165
    -148 165
    -139 165
    -131 165
    -122 166
    -113 166
    -105 166
    -96 166
    -88 166
    -79 167
    -70 167
    -61 167
    -53 167
    -44 167
    -35 167
    -26 167
    -18 167
    -9 167
    0 167
    9 167
    18 167
    26 167
    35 167
    44 167
    53 167
    61 167
    70 167
    79 167
    88 166
    96 166
    105 166
    113 166
    122 166
    131 165
    139 165
    148 165
    156 165
    164 164
    173 164
    181 164
    189 163
    197 163
    206 163
    214 162
    222 162
    230 162
    237 161
    245 161
    253 160
    261 160
    268 159
    276 159
    283 158
    291 158
    298 157
    305 157
    312 156
    319 156
    326 155
    333 154
    340 154
    347 153
    353 153
    360 152
    366 151
    372 151
    379 150
    385 149
    391 148
    396 148
    402 147
    408 146
    413 145
    419 145
    424 144
    429 143
    434 142
    439 141
    444 141
    449 140
    453 139
    458 138
    462 137
    466 136
    470 135
    474 134
    478 134
    482 133
    485 132
    489 131
    492 130
    495 129
    498 128
    501 127
    504 126
    506 125
    509 124
    511 123
    513 122
    515 121
    517 120
    519 119
    520 118
    522 117
    523 115
    524 114
    525 113
    526 112
    526 111
    527 110
    527 109
    527 108
    528 107
    528 106
    527 104
    527 103
    526 102
    526 101
    525 100
    524 99
    523 97
    521 96
    520 95
    518 94
    517 93
    515 91
    513 90
    511 89
    508 88
    506 87
    503 85
    500 84
    497 83
    494 82
    491 80
    487 79
    484 78
    480 77
    476 75
    472 74
    468 73
    464 72
    459 70
    455 69
    450 68
    445 67
    440 65
    435 64
    429 63
    424 61
    418 60
    412 59
    406 58
    400 56
    394 55
    388 54
    381 52
    375 51
    368 50
    361 49
    354 47
    346 46
    339 45
    331 43
    324 42
    316 41
    308 40
    300 38
    292 37
    283 36
    275 34
    266 33
    257 32
    249 30
    239 29
    230 28
    221 27
    212 25
    202 24
    192 23
    182 21
    172 20
    162 19
    152 18
    142 16
    131 15
    121 14
    110 12
    99 11
    88 10
    77 8
    66 7
    54 6
    43 5
    31 3
    19 2
    8 1
    -4 -0
    -16 -2
    -29 -3
    -41 -4
    -53 -6
    -66 -7
    -79 -8
    -91 -9
    -104 -11
    -117 -12
    -131 -13
    -144 -14
    -157 -16
    -171 -17
    -184 -18
    -198 -19
    -212 -21
    -226 -22
    -240 -23
    -254 -24
    -268 -26
    -282 -27
    -297 -28
    -311 -29
    -326 -31
    -341 -32
    -356 -33
    -371 -34
    -386 -35
    -401 -37
    -416 -38
    -432 -39
    -447 -40
    -463 -41
    -478 -43
    -494 -44
    -510 -45
    -526 -46
    -542 -47
    -558 -49
    -574 -50
    -591 -51
    -607 -52
    -624 -53
    -640 -55
    -657 -56
    -674 -57
    -691 -58
    -708 -59
    -725 -60
    -742 -62
    -759 -63
    -776 -64
    -794 -65
    -811 -66
    -829 -67
    -847 -68
    -864 -70
    -882 -71
    -900 -72
    -918 -73
    -936 -74
    937 -78
    919 -77
    901 -76
    883 -75
    866 -73
    848 -72
    830 -71
    813 -70
    795 -69
    778 -67
    760 -66
    743 -65
    726 -64
    709 -62
    692 -61
    675 -60
    658 -59
    641 -58
    625 -56
    608 -55
    592 -54
    576 -53
    559 -51
    543 -50
    527 -49
    511 -48
    495 -46
    479 -45
    464 -44
    448 -42
    433 -41
    417 -40
    402 -39
    387 -37
    372 -36
    357 -35
    342 -34
    327 -32
    313 -31
    298 -30
    284 -28
    269 -27
    255 -26
    241 -24
    227 -23
    213 -22
    199 -21
    185 -19
    172 -18
    158 -17
    145 -15
    132 -14
    119 -13
    106 -11
    93 -10
    80 -9
    67 -7
    55 -6
    42 -5
    30 -3
    18 -2
    6 -1
    -6 1
    -18 2
    -30 3
    -42 5
    -53 6
    -64 7
    -76 9
    -87 10
    -98 11
    -109 13
    -119 14
    -130 16
    -140 17
    -151 18
    -161 20
    -171 21
    -181 22
    -191 24
    -201 25
    -210 26
    -220 28
    -229 29
    -238 31
    -247 32
    -256 33
    -265 35
    -274 36
    -282 37
    -290 39
    -299 40
    -307 41
    -315 43
    -322 44
    -330 46
    -338 47
    -345 48
    -352 50
    -359 51
    -366 52
    -373 54
    -380 55
    -386 56
    -393 58
    -399 59
    -405 60
    -411 62
    -417 63
    -423 65
    -428 66
    -433 67
    -439 69
    -444 70
    -449 71
    -453 73
    -458 74
    -463 75
    -467 77
    -471 78
    -475 79
    -479 80
    -483 82
    -486 83
    -490 84
    -493 86
    -496 87
    -499 88
    -502 90
    -504 91
    -507 92
    -509 93
    -512 95
    -514 96
    -515 97
    -517 99
    -519 100
    -520 101
    -522 102
    -523 104
    -524 105
    -525 106
    -525 107
    -526 108
    -526 110
    -526 111
    -526 112
    -526 113
    -526 114
    -526 116
    -525 117
    -525 118
    -524 119
    -523 120
    -522 121
    -520 122
    -519 124
    -517 125
    -516 126
    -514 127
    -512 128
    -510 129
    -508 130
    -505 131
    -503 132
    -500 133
    -497 134
    -494 135
    -491 136
    -488 137
    -484 138
    -481 139
    -477 140
    -473 141
    -469 142
    -465 143
    -461 144
    -457 145
    -452 146
    -448 147
    -443 148
    -438 149
    -433 149
    -428 150
    -423 151
    -418 152
    -413 153
    -407 154
    -401 154
    -396 155
    -390 156
    -384 157
    -378 157
    -372 158
    -365 159
    -359 160
    -353 160
    -346 161
    -339 162
    -333 162
    -326 163
    -319 163
    -312 164
    -305 165
    -297 165
    -290 166
    -283 166
    -275 167
    -268 167
    -260 168
    -253 168
    -245 169
    -237 169
    -229 170
    -221 170
    -213 171
    -205 171
    -197 171
    -189 172
    -181 172
    -172 172
    -164 173
    -156 173
    -147 173
    -139 174
    -130 174
    -122 174
    -113 174
    -105 174
    -96 175
    -87 175
    -79 175
    -70 175
    -61 175
    -53 175
    -44 175
    -35 175
    -26 176
    -18 176
    -9 176
    0 176
    9 176
    18 176
    26 176
    35 175
    44 175
    53 175
    61 175
    70 175
    79 175
    87 175
    96 175
    105 174
    113 174
    122 174
    130 174
    139 174
    147 173
    156 173
    164 173
    172 172
    181 172
    189 172
    197 171
    205 171
    213 171
    221 170
    229 170
    237 169
    245 169
    253 168
    260 168
    268 167
    275 167
    283 166
    290 166
    297 165
    305 165
    312 164
    319 163
    326 163
    333 162
    339 162
    346 161
    353 160
    359 160
    365 159
    372 158
    378 157
    384 157
    390 156
    396 155
    401 154
    407 154
    413 153
    418 152
    423 151
    428 150
    433 149
    438 149
    443 148
    448 147
    452 146
    457 145
    461 144
    465 143
    469 142
    473 141
    477 140
    481 139
    484 138
    488 137
    491 136
    494 135
    497 134
    500 133
    503 132
    505 131
    508 130
    510 129
    512 128
    514 127
    516 126
    517 125
    519 124
    520 122
    522 121
    523 120
    524 119
    525 118
    525 117
    526 116
    526 114
    526 113
    526 112
    526 111
    526 110
    526 108
    525 107
    525 106
    524 105
    523 104
    522 102
    520 101
    519 100
    517 99
    515 97
    514 96
    512 95
    509 93
    507 92
    504 91
    502 90
    499 88
    496 87
    493 86
    490 84
    486 83
    483 82
    479 80
    475 79
    471 78
    467 77
    463 75
    458 74
    453 73
    449 71
    444 70
    439 69
    433 67
    428 66
    423 65
    417 63
    411 62
    405 60
    399 59
    393 58
    386 56
    380 55
    373 54
    366 52
    359 51
    352 50
    345 48
    338 47
    330 46
    322 44
    315 43
    307 41
    299 40
    290 39
    282 37
    274 36
    265 35
    256 33
    247 32
    238 31
    229 29
    220 28
    210 26
    201 25
    191 24
    181 22
    171 21
    161 20
    151 18
    140 17
    130 16
    119 14
    109 13
    98 11
    87 10
    76 9
    64 7
    53 6
    42 5
    30 3
    18 2
    6 1
    -6 -1
    -18 -2
    -30 -3
    -42 -5
    -55 -6
    -67 -7
    -80 -9
    -93 -10
    -106 -11
    -119 -13
    -132 -14
    -145 -15
    -158 -17
    -172 -18
    -185 -19
    -199 -21
    -213 -22
    -227 -23
    -241 -24
    -255 -26
    -269 -27
    -284 -28
    -298 -30
    -313 -31
    -327 -32
    -342 -34
    -357 -35
    -372 -36
    -387 -37
    -402 -39
    -417 -40
    -433 -41
    -448 -42
    -464 -44
    -479 -45
    -495 -46
    -511 -48
    -527 -49
    -543 -50
    -559 -51
    -576 -53
    -592 -54
    -608 -55
    -625 -56
    -641 -58
    -658 -59
    -675 -60
    -692 -61
    -709 -62
    -726 -64
    -743 -65
    -760 -66
    -778 -67
    -795 -69
    -813 -70
    -830 -71
    -848 -72
    -866 -73
    -883 -75
    -901 -76
    -919 -77
    -937 -78
    939 -82
    921 -81
    903 -80
    885 -78
    867 -77
    849 -76
    831 -75
    814 -73
    796 -72
    779 -71
    762 -70
    744 -68
    727 -67
    710 -66
    693 -64
    676 -63
    659 -62
    643 -61
    626 -59
    610 -58
    593 -57
    577 -55
    561 -54
    544 -53
    528 -51
    512 -50
    497 -49
    481 -47
    465 -46
    450 -45
    434 -43
    419 -42
    403 -41
    388 -39
    373 -38
    358 -37
    343 -35
    329 -34
    314 -33
    299 -31
    285 -30
    271 -29
    256 -27
    242 -26
    228 -24
    214 -23
    201 -22
    187 -20
    173 -19
    160 -18
    146 -16
    133 -15
    120 -13
    107 -12
    94 -11
    81 -9
    69 -8
    56 -6
    44 -5
    31 -4
    19 -2
    7 -1
    -5 1
    -17 2
    -29 3
    -40 5
    -52 6
    -63 8
    -74 9
    -85 10
    -96 12
    -107 13
    -118 15
    -129 16
    -139 18
    -149 19
    -160 20
    -170 22
    -180 23
    -190 25
    -199 26
    -209 28
    -218 29
    -228 30
    -237 32
    -246 33
    -255 35
    -263 36
    -272 38
    -281 39
    -289 40
    -297 42
    -305 43
    -313 45
    -321 46
    -329 48
    -336 49
    -344 50
    -351 52
    -358 53
    -365 55
    -372 56
    -378 58
    -385 59
    -391 60
    -398 62
    -404 63
    -410 65
    -416 66
    -421 68
    -427 69
    -432 70
    -437 72
    -442 73
    -447 75
    -452 76
    -457 77
    -461 79
    -465 80
    -470 82
    -474 83
    -478 84
    -481 86
    -485 87
    -488 88
    -492 90
    -495 91
    -498 92
    -500 94
    -503 95
    -506 97
    -508 98
    -510 99
    -512 101
    -514 102
    -516 103
    -518 105
    -519 106
    -520 107
    -521 108
    -522 110
    -523 111
    -524 112
    -524 114
    -525 115
    -525 116
    -525 117
    -525 119
    -525 120
    -525 121
    -524 122
    -523 123
    -523 125
    -522 126
    -521 127
    -519 128
    -518 129
    -516 131
    -515 132
    -513 133
    -511 134
    -509 135
    -506 136
    -504 137
    -501 139
    -499 140
    -496 141
    -493 142
    -490 143
    -487 144
    -483 145
    -480 146
    -476 147
    -472 148
    -468 149
    -464 150
    -460 151
    -456 152
    -452 153
    -447 154
    -442 155
    -438 156
    -433 157
    -428 158
    -422 158
    -417 159
    -412 160
    -406 161
    -401 162
    -395 163
    -389 163
    -383 164
    -377 165
    -371 166
    -365 166
    -358 167
    -352 168
    -345 169
    -339 169
    -332 170
    -325 171
    -318 171
    -311 172
    -304 173
    -297 173
    -290 174
    -282 174
    -275 175
    -267 175
    -260 176
    -252 176
    -244 177
    -237 177
    -229 178
    -221 178
    -213 179
    -205 179
    -197 180
    -189 180
    -180 180
    -172 181
    -164 181
    -155 181
    -147 182
    -139 182
    -130 182
    -122 182
    -113 183
    -104 183
    -96 183
    -87 183
    -79 183
    -70 184
    -61 184
    -52 184
    -44 184
    -35 184
    -26 184
    -18 184
    -9 184
    0 184
    9 184
    18 184
    26 184
    35 184
    44 184
    52 184
    61 184
    70 184
    79 183
    87 183
    96 183
    104 183
    113 183
    122 182
    130 182
    139 182
    147 182
    155 181
    164 181
    172 181
    180 180
    189 180
    197 180
    205 179
    213 179
    221 178
    229 178
    237 177
    244 177
    252 176
    260 176
    267 175
    275 175
    282 174
    290 174
    297 173
    304 173
    311 172
    318 171
    325 171
    332 170
    339 169
    345 169
    352 168
    358 167
    365 166
    371 166
    377 165
    383 164
    389 163
    395 163
    401 162
    406 161
    412 160
    417 159
    422 158
    428 158
    433 157
    438 156
    442 155
    447 154
    452 153
    456 152
    460 151
    464 150
    468 149
    472 148
    476 147
    480 146
    483 145
    487 144
    490 143
    493 142
    496 141
    499 140
    501 139
    504 137
    506 136
    509 135
    511 134
    513 133
    515 132
    516 131
    518 129
    519 128
    521 127
    522 126
    523 125
    523 123
    524 122
    525 121
    525 120
    525 119
    525 117
    525 116
    525 115
    524 114
    524 112
    523 111
    522 110
    521 108
    520 107
    519 106
    518 105
    516 103
    514 102
    512 101
    510 99
    508 98
    506 97
    503 95
    500 94
    498 92
    495 91
    492 90
    488 88
    485 87
    481 86
    478 84
    474 83
    470 82
    465 80
    461 79
    457 77
    452 76
    447 75
    442 73
    437 72
    432 70
    427 69
    421 68
    416 66
    410 65
    404 63
    398 62
    391 60
    385 59
    378 58
    372 56
    365 55
    358 53
    351 52
    344 50
    336 49
    329 48
    321 46
    313 45
    305 43
    297 42
    289 40
    281 39
    272 38
    263 36
    255 35
    246 33
    237 32
    228 30
    218 29
    209 28
    199 26
    190 25
    180 23
    170 22
    160 20
    149 19
    139 18
    129 16
    118 15
    107 13
    96 12
    85 10
    74 9
    63 8
    52 6
    40 5
    29 3
    17 2
    5 1
    -7 -1
    -19 -2
    -31 -4
    -44 -5
    -56 -6
    -69 -8
    -81 -9
    -94 -11
    -107 -12
    -120 -13
    -133 -15
    -146 -16
    -160 -18
    -173 -19
    -187 -20
    -201 -22
    -214 -23
    -228 -24
    -242 -26
    -256 -27
    -271 -29
    -285 -30
    -299 -31
    -314 -33
    -329 -34
    -343 -35
    -358 -37
    -373 -38
    -388 -39
    -403 -41
    -419 -42
    -434 -43
    -450 -45
    -465 -46
    -481 -47
    -497 -49
    -512 -50
    -528 -51
    -544 -53
    -561 -54
    -577 -55
    -593 -57
    -610 -58
    -626 -59
    -643 -61
    -659 -62
    -676 -63
    -693 -64
    -710 -66
    -727 -67
    -744 -68
    -762 -70
    -779 -71
    -796 -72
    -814 -73
    -831 -75
    -849 -76
    -867 -77
    -885 -78
    -903 -80
    -921 -81
    -939 -82
    940 -86
    922 -85
    904 -84
    886 -82
    868 -81
    850 -80
    833 -78
    815 -77
    798 -76
    780 -74
    763 -73
    746 -72
    728 -70
    711 -69
    694 -68
    678 -66
    661 -65
    644 -64
    627 -62
    611 -61
    594 -59
    578 -58
    562 -57
    546 -55
    530 -54
    514 -53
    498 -51
    482 -50
    466 -48
    451 -47
    435 -46
    420 -44
    405 -43
    390 -41
    375 -40
    360 -39
    345 -37
    330 -36
    315 -34
    301 -33
    286 -31
    272 -30
    258 -29
    244 -27
    230 -26
    216 -24
    202 -23
    188 -21
    175 -20
    161 -19
    148 -17
    135 -16
    121 -14
    108 -13
    96 -11
    83 -10
    70 -8
    58 -7
    45 -5
    33 -4
    21 -3
    8 -1
    -4 0
    -15 2
    -27 3
    -39 5
    -50 6
    -62 8
    -73 9
    -84 11
    -95 12
    -106 14
    -116 15
    -127 17
    -138 18
    -148 20
    -158 21
    -168 23
    -178 24
    -188 26
    -198 27
    -207 29
    -217 30
    -226 32
    -235 33
    -244 35
    -253 36
    -262 38
    -271 39
    -279 41
    -288 42
    -296 44
    -304 45
    -312 47
    -320 48
    -327 50
    -335 51
    -342 53
    -349 54
    -357 56
    -364 57
    -370 59
    -377 60
    -384 62
    -390 63
    -396 65
    -402 66
    -408 68
    -414 69
    -420 70
    -425 72
    -431 73
    -436 75
    -441 76
    -446 78
    -451 79
    -455 81
    -460 82
    -464 84
    -468 85
    -472 87
    -476 88
    -480 89
    -483 91
    -487 92
    -490 94
    -493 95
    -496 97
    -499 98
    -502 99
    -504 101
    -507 102
    -509 104
    -511 105
    -513 106
    -515 108
    -516 109
    -518 111
    -519 112
    -520 113
    -521 115
    -522 116
    -523 117
    -523 119
    -524 120
    -524 121
    -524 123
    -524 124
    -524 125
    -523 127
    -523 128
    -522 129
    -521 130
    -520 132
    -519 133
    -518 134
    -517 135
    -515 137
    -513 138
    -512 139
    -510 140
    -508 141
    -505 143
    -503 144
    -500 145
    -498 146
    -495 147
    -492 148
    -489 149
    -486 150
    -482 152
    -479 153
    -475 154
    -471 155
    -467 156
    -463 157
    -459 158
    -455 159
    -451 160
    -446 161
    -441 162
    -437 163
    -432 164
    -427 165
    -422 166
    -416 167
    -411 167
    -405 168
    -400 169
    -394 170
    -388 171
    -382 172
    -376 172
    -370 173
    -364 174
    -358 175
    -351 176
    -345 176
    -338 177
    -331 178
    -324 178
    -318 179
    -311 180
    -303 180
    -296 181
    -289 182
    -282 182
    -274 183
    -267 183
    -259 184
    -252 184
    -244 185
    -236 185
    -228 186
    -220 186
    -212 187
    -204 187
    -196 188
    -188 188
    -180 189
    -172 189
    -163 189
    -155 190
    -147 190
    -138 190
    -130 190
    -121 191
    -113 191
    -104 191
    -96 191
    -87 192
    -78 192
    -70 192
    -61 192
    -52 192
    -44 192
    -35 192
    -26 192
    -17 192
    -9 192
    0 192
    9 192
    17 192
    26 192
    35 192
    44 192
    52 192
    61 192
    70 192
    78 192
    87 192
    96 191
    104 191
    113 191
    121 191
    130 190
    138 190
    147 190
    155 190
    163 189
    172 189
    180 189
    188 188
    196 188
    204 187
    212 187
    220 186
    228 186
    236 185
    244 185
    252 184
    259 184
    267 183
    274 183
    282 182
    289 182
    296 181
    303 180
    311 180
    318 179
    324 178
    331 178
    338 177
    345 176
    351 176
    358 175
    364 174
    370 173
    376 172
    382 172
    388 171
    394 170
    400 169
    405 168
    411 167
    416 167
    422 166
    427 165
    432 164
    437 163
    441 162
    446 161
    451 160
    455 159
    459 158
    463 157
    467 156
    471 155
    475 154
    479 153
    482 152
    486 150
    489 149
    492 148
    495 147
    498 146
    500 145
    503 144
    505 143
    508 141
    510 140
    512 139
    513 138
    515 137
    517 135
    518 134
    519 133
    520 132
    521 130
    522 129
    523 128
    523 127
    524 125
    524 124
    524 123
    524 121
    524 120
    523 119
    523 117
    522 116
    521 115
    520 113
    519 112
    518 111
    516 109
    515 108
    513 106
    511 105
    509 104
    507 102
    504 101
    502 99
    499 98
    496 97
    493 95
    490 94
    487 92
    483 91
    480 89
    476 88
    472 87
    468 85
    464 84
    460 82
    455 81
    451 79
    446 78
    441 76
    436 75
    431 73
    425 72
    420 70
    414 69
    408 68
    402 66
    396 65
    390 63
    384 62
    377 60
    370 59
    364 57
    357 56
    349 54
    342 53
    335 51
    327 50
    320 48
    312 47
    304 45
    296 44
    288 42
    279 41
    271 39
    262 38
    253 36
    244 35
    235 33
    226 32
    217 30
    207 29
    198 27
    188 26
    178 24
    168 23
    158 21
    148 20
    138 18
    127 17
    116 15
    106 14
    95 12
    84 11
    73 9
    62 8
    50 6
    39 5
    27 3
    15 2
    4 0
    -8 -1
    -21 -3
    -33 -4
    -45 -5
    -58 -7
    -70 -8
    -83 -10
    -96 -11
    -108 -13
    -121 -14
    -135 -16
    -148 -17
    -161 -19
    -175 -20
    -188 -21
    -202 -23
    -216 -24
    -230 -26
    -244 -27
    -258 -29
    -272 -30
    -286 -31
    -301 -33
    -315 -34
    -330 -36
    -345 -37
    -360 -39
    -375 -40
    -390 -41
    -405 -43
    -420 -44
    -435 -46
    -451 -47
    -466 -48
    -482 -50
    -498 -51
    -514 -53
    -530 -54
    -546 -55
    -562 -57
    -578 -58
    -594 -59
    -611 -61
    -627 -62
    -644 -64
    -661 -65
    -678 -66
    -694 -68
    -711 -69
    -728 -70
    -746 -72
    -763 -73
    -780 -74
    -798 -76
    -815 -77
    -833 -78
    -850 -80
    -868 -81
    -886 -82
    -904 -84
    -922 -85
    -940 -86
    941 -90
    923 -89
    905 -87
    887 -86
    869 -85
    852 -83
    834 -82
    816 -81
    799 -79
    782 -78
    764 -76
    747 -75
    730 -74
    713 -72
    696 -71
    679 -69
    662 -68
    645 -67
    629 -65
    612 -64
    596 -62
    580 -61
    563 -59
    547 -58
    531 -57
    515 -55
    499 -54
    484 -52
    468 -51
    452 -49
    437 -48
    422 -46
    406 -45
    391 -43
    376 -42
    361 -41
    346 -39
    331 -38
    317 -36
    302 -35
    288 -33
    273 -32
    259 -30
    245 -29
    231 -27
    217 -26
    203 -24
    190 -23
    176 -21
    163 -20
    149 -18
    136 -17
    123 -15
    110 -14
    97 -12
    84 -10
    72 -9
    59 -7
    47 -6
    34 -4
    22 -3
    10 -1
    -2 0
    -14 2
    -26 3
    -37 5
    -49 6
    -60 8
    -71 10
    -82 11
    -93 13
    -104 14
    -115 16
    -126 17
    -136 19
    -146 20
    -157 22
    -167 24
    -177 25
    -187 27
    -196 28
    -206 30
    -215 31
    -225 33
    -234 34
    -243 36
    -252 38
    -260 39
    -269 41
    -278 42
    -286 44
    -294 45
    -302 47
    -310 49
    -318 50
    -326 52
    -333 53
    -341 55
    -348 56
    -355 58
    -362 59
    -369 61
    -375 63
    -382 64
    -388 66
    -395 67
    -401 69
    -407 70
    -413 72
    -418 73
    -424 75
    -429 77
    -434 78
    -439 80
    -444 81
    -449 83
    -454 84
    -458 86
    -463 87
    -467 89
    -471 90
    -475 92
    -478 93
    -482 95
    -485 96
    -489 98
    -492 99
    -495 101
    -498 102
    -500 104
    -503 105
    -505 107
    -507 108
    -509 110
    -511 111
    -513 112
    -515 114
    -516 115
    -518 117
    -519 118
    -520 120
    -521 121
    -521 122
    -522 124
    -522 125
    -522 126
    -523 128
    -523 129
    -522 131
    -522 132
    -521 133
    -521 135
    -520 136
    -519 137
    -518 139
    -517 140
    -515 141
    -514 142
    -512 144
    -510 145
    -508 146
    -506 147
    -504 149
    -502 150
    -499 151
    -497 152
    -494 153
    -491 155
    -488 156
    -484 157
    -481 158
    -478 159
    -474 160
    -470 161
    -466 163
    -462 164
    -458 165
    -454 166
    -450 167
    -445 168
    -440 169
    -436 170
    -431 171
    -426 172
    -421 173
    -415 174
    -410 175
    -405 176
    -399 176
    -393 177
    -387 178
    -382 179
    -376 180
    -369 181
    -363 182
    -357 182
    -350 183
    -344 184
    -337 185
    -331 185
    -324 186
    -317 187
    -310 188
    -303 188
    -296 189
    -288 190
    -281 190
    -274 191
    -266 191
    -259 192
    -251 192
    -243 193
    -236 194
    -228 194
    -220 195
    -212 195
    -204 195
    -196 196
    -188 196
    -180 197
    -171 197
    -163 197
    -155 198
    -146 198
    -138 198
    -130 199
    -121 199
    -113 199
    -104 199
    -95 200
    -87 200
    -78 200
    -70 200
    -61 200
    -52 200
    -44 201
    -35 201
    -26 201
    -17 201
    -9 201
    0 201
    9 201
    17 201
    26 201
    35 201
    44 201
    52 200
    61 200
    70 200
    78 200
    87 200
    95 200
    104 199
    113 199
    121 199
    130 199
    138 198
    146 198
    155 198
    163 197
    171 197
    180 197
    188 196
    196 196
    204 195
    212 195
    220 195
    228 194
    236 194
    243 193
    251 192
    259 192
    266 191
    274 191
    281 190
    288 190
    296 189
    303 188
    310 188
    317 187
    324 186
    331 185
    337 185
    344 184
    350 183
    357 182
    363 182
    369 181
    376 180
    382 179
    387 178
    393 177
    399 176
    405 176
    410 175
    415 174
    421 173
    426 172
    431 171
    436 170
    440 169
    445 168
    450 167
    454 166
    458 165
    462 164
    466 163
    470 161
    474 160
    478 159
    481 158
    484 157
    488 156
    491 155
    494 153
    497 152
    499 151
    502 150
    504 149
    506 147
    508 146
    510 145
    512 144
    514 142
    515 141
    517 140
    518 139
    519 137
    520 136
    521 135
    521 133
    522 132
    522 131
    523 129
    523 128
    522 126
    522 125
    522 124
    521 122
    521 121
    520 120
    519 118
    518 117
    516 115
    515 114
    513 112
    511 111
    509 110
    507 108
    505 107
    503 105
    500 104
    498 102
    495 101
    492 99
    489 98
    485 96
    482 95
    478 93
    475 92
    471 90
    467 89
    463 87
    458 86
    454 84
    449 83
    444 81
    439 80
    434 78
    429 77
    424 75
    418 73
    413 72
    407 70
    401 69
    395 67
    388 66
    382 64
    375 63
    369 61
    362 59
    355 58
    348 56
    341 55
    333 53
    326 52
    318 50
    310 49
    302 47
    294 45
    286 44
    278 42
    269 41
    260 39
    252 38
    243 36
    234 34
    225 33
    215 31
    206 30
    196 28
    187 27
    177 25
    167 24
    157 22
    146 20
    136 19
    126 17
    115 16
    104 14
    93 13
    82 11
    71 10
    60 8
    49 6
    37 5
    26 3
    14 2
    2 0
    -10 -1
    -22 -3
    -34 -4
    -47 -6
    -59 -7
    -72 -9
    -84 -10
    -97 -12
    -110 -14
    -123 -15
    -136 -17
    -149 -18
    -163 -20
    -176 -21
    -190 -23
    -203 -24
    -217 -26
    -231 -27
    -245 -29
    -259 -30
    -273 -32
    -288 -33
    -302 -35
    -317 -36
    -331 -38
    -346 -39
    -361 -41
    -376 -42
    -391 -43
    -406 -45
    -422 -46
    -437 -48
    -452 -49
    -468 -51
    -484 -52
    -499 -54
    -515 -55
    -531 -57
    -547 -58
    -563 -59
    -580 -61
    -596 -62
    -612 -64
    -629 -65
    -645 -67
    -662 -68
    -679 -69
    -696 -71
    -713 -72
    -730 -74
    -747 -75
    -764 -76
    -782 -78
    -799 -79
    -816 -81
    -834 -82
    -852 -83
    -869 -85
    -887 -86
    -905 -87
    -923 -89
    -941 -90
    943 -94
    925 -93
    907 -91
    889 -90
    871 -89
    853 -87
    835 -86
    818 -84
    800 -83
    783 -81
    766 -80
    748 -78
    731 -77
    714 -76
    697 -74
    680 -73
    664 -71
    647 -70
    630 -68
    614 -67
    597 -65
    581 -64
    565 -62
    549 -61
    533 -59
    517 -58
    501 -56
    485 -55
    469 -53
    454 -52
    438 -50
    423 -49
    408 -47
    393 -46
    378 -44
    363 -42
    348 -41
    333 -39
    318 -38
    304 -36
    289 -35
    275 -33
    261 -32
    247 -30
    233 -28
    219 -27
    205 -25
    191 -24
    178 -22
    164 -21
    151 -19
    138 -17
    125 -16
    111 -14
    99 -13
    86 -11
    73 -10
    61 -8
    48 -6
    36 -5
    24 -3
    12 -2
    -0 0
    -12 2
    -24 3
    -36 5
    -47 6
    -58 8
    -70 10
    -81 11
    -92 13
    -103 15
    -113 16
    -124 18
    -134 19
    -145 21
    -155 23
    -165 24
    -175 26
    -185 28
    -195 29
    -204 31
    -214 32
    -223 34
    -232 36
    -241 37
    -250 39
    -259 41
    -268 42
    -276 44
    -284 46
    -293 47
    -301 49
    -309 50
    -316 52
    -324 54
    -332 55
    -339 57
    -346 59
    -353 60
    -360 62
    -367 63
    -374 65
    -380 67
    -387 68
    -393 70
    -399 71
    -405 73
    -411 75
    -417 76
    -422 78
    -428 80
    -433 81
    -438 83
    -443 84
    -448 86
    -452 88
    -457 89
    -461 91
    -465 92
    -469 94
    -473 95
    -477 97
    -480 99
    -484 100
    -487 102
    -490 103
    -493 105
    -496 106
    -499 108
    -501 109
    -504 111
    -506 112
    -508 114
    -510 115
    -512 117
    -513 118
    -515 120
    -516 121
    -517 123
    -518 124
    -519 126
    -520 127
    -520 129
    -521 130
    -521 132
    -521 133
    -521 134
    -521 136
    -521 137
    -520 139
    -519 140
    -519 141
    -518 143
    -517 144
    -515 146
    -514 147
    -513 148
    -511 150
    -509 151
    -507 152
    -505 153
    -503 155
    -500 156
    -498 157
    -495 158
    -492 160
    -490 161
    -486 162
    -483 163
    -480 165
    -476 166
    -473 167
    -469 168
    -465 169
    -461 170
    -457 171
    -453 173
    -448 174
    -444 175
    -439 176
    -435 177
    -430 178
    -425 179
    -420 180
    -414 181
    -409 182
    -404 183
    -398 184
    -392 185
    -387 186
    -381 186
    -375 187
    -369 188
    -362 189
    -356 190
    -350 191
    -343 191
    -336 192
    -330 193
    -323 194
    -316 195
    -309 195
    -302 196
    -295 197
    -288 197
    -280 198
    -273 199
    -266 199
    -258 200
    -250 200
    -243 201
    -235 201
    -227 202
    -219 203
    -211 203
    -203 203
    -195 204
    -187 204
    -179 205
    -171 205
    -163 206
    -154 206
    -146 206
    -138 207
    -129 207
    -121 207
    -112 207
    -104 208
    -95 208
    -87 208
    -78 208
    -69 208
    -61 209
    -52 209
    -43 209
    -35 209
    -26 209
    -17 209
    -9 209
    0 209
    9 209
    17 209
    26 209
    35 209
    43 209
    52 209
    61 209
    69 208
    78 208
    87 208
    95 208
    104 208
    112 207
    121 207
    129 207
    138 207
    146 206
    154 206
    163 206
    171 205
    179 205
    187 204
    195 204
    203 203
    211 203
    219 203
    227 202
    235 201
    243 201
    250 200
    258 200
    266 199
    273 199
    280 198
    288 197
    295 197
    302 196
    309 195
    316 195
    323 194
    330 193
    336 192
    343 191
    350 191
    356 190
    362 189
    369 188
    375 187
    381 186
    387 186
    392 185
    398 184
    404 183
    409 182
    414 181
    420 180
    425 179
    430 178
    435 177
    439 176
    444 175
    448 174
    453 173
    457 171
    461 170
    465 169
    469 168
    473 167
    476 166
    480 165
    483 163
    486 162
    490 161
    492 160
    495 158
    498 157
    500 156
    503 155
    505 153
    507 152
    509 151
    511 150
    513 148
    514 147
    515 146
    517 144
    518 143
    519 141
    519 140
    520 139
    521 137
    521 136
    521 134
    521 133
    521 132
    521 130
    520 129
    520 127
    519 126
    518 124
    517 123
    516 121
    515 120
    513 118
    512 117
    510 115
    508 114
    506 112
    504 111
    501 109
    499 108
    496 106
    493 105
    490 103
    487 102
    484 100
    480 99
    477 97
    473 95
    469 94
    465 92
    461 91
    457 89
    452 88
    448 86
    443 84
    438 83
    433 81
    428 80
    422 78
    417 76
    411 75
    405 73
    399 71
    393 70
    387 68
    380 67
    374 65
    367 63
    360 62
    353 60
    346 59
    339 57
    332 55
    324 54
    316 52
    309 50
    301 49
    293 47
    284 46
    276 44
    268 42
    259 41
    250 39
    241 37
    232 36
    223 34
    214 32
    204 31
    195 29
    185 28
    175 26
    165 24
    155 23
    145 21
    134 19
    124 18
    113 16
    103 15
    92 13
    81 11
    70 10
    58 8
    47 6
    36 5
    24 3
    12 2
    0 0
    -12 -2
    -24 -3
    -36 -5
    -48 -6
    -61 -8
    -73 -10
    -86 -11
    -99 -13
    -111 -14
    -125 -16
    -138 -17
    -151 -19
    -164 -21
    -178 -22
    -191 -24
    -205 -25
    -219 -27
    -233 -28
    -247 -30
    -261 -32
    -275 -33
    -289 -35
    -304 -36
    -318 -38
    -333 -39
    -348 -41
    -363 -42
    -378 -44
    -393 -46
    -408 -47
    -423 -49
    -438 -50
    -454 -52
    -469 -53
    -485 -55
    -501 -56
    -517 -58
    -533 -59
    -549 -61
    -565 -62
    -581 -64
    -597 -65
    -614 -67
    -630 -68
    -647 -70
    -664 -71
    -680 -73
    -697 -74
    -714 -76
    -731 -77
    -748 -78
    -766 -80
    -783 -81
    -800 -83
    -818 -84
    -835 -86
    -853 -87
    -871 -89
    -889 -90
    -907 -91
    -925 -93
    -943 -94
    944 -98
    926 -97
    908 -95
    890 -94
    872 -92
    855 -91
    837 -89
    819 -88
    802 -86
    784 -85
    767 -83
    750 -82
    733 -80
    716 -79
    699 -77
    682 -76
    665 -74
    648 -73
    632 -71
    615 -70
    599 -68
    583 -66
    566 -65
    550 -63
    534 -62
    518 -60
    502 -59
    487 -57
    471 -56
    455 -54
    440 -52
    425 -51
    409 -49
    394 -48
    379 -46
    364 -44
    349 -43
    335 -41
    320 -40
    305 -38
    291 -36
    277 -35
    262 -33
    248 -32
    234 -30
    220 -28
    207 -27
    193 -25
    179 -23
    166 -22
    152 -20
    139 -18
    126 -17
    113 -15
    100 -13
    87 -12
    75 -10
    62 -8
    50 -7
    37 -5
    25 -4
    13 -2
    1 -0
    -11 2
    -22 3
    -34 5
    -45 7
    -57 8
    -68 10
    -79 12
    -90 13
    -101 15
    -112 17
    -122 18
    -133 20
    -143 22
    -153 23
    -163 25
    -173 27
    -183 28
    -193 30
    -203 32
    -212 34
    -221 35
    -230 37
    -240 39
    -248 40
    -257 42
    -266 44
    -274 45
    -283 47
    -291 49
    -299 51
    -307 52
    -315 54
    -322 56
    -330 57
    -337 59
    -345 61
    -352 62
    -359 64
    -366 66
    -372 67
    -379 69
    -385 71
    -391 72
    -398 74
    -404 76
    -409 78
    -415 79
    -421 81
    -426 83
    -431 84
    -436 86
    -441 88
    -446 89
    -451 91
    -455 92
    -459 94
    -464 96
    -468 97
    -472 99
    -475 101
    -479 102
    -482 104
    -486 106
    -489 107
    -492 109
    -495 110
    -497 112
    -500 114
    -502 115
    -504 117
    -506 118
    -508 120
    -510 121
    -512 123
    -513 125
    -515 126
    -516 128
    -517 129
    -518 131
    -518 132
    -519 134
    -519 135
    -520 137
    -520 138
    -520 140
    -520 141
    -519 143
    -519 144
    -518 146
    -517 147
    -516 148
    -515 150
    -514 151
    -513 153
    -511 154
    -510 155
    -508 157
    -506 158
    -504 159
    -502 161
    -499 162
    -497 163
    -494 165
    -491 166
    -488 167
    -485 168
    -482 170
    -479 171
    -475 172
    -472 173
    -468 175
    -464 176
    -460 177
    -456 178
    -452 179
    -447 180
    -443 182
    -438 183
    -434 184
    -429 185
    -424 186
    -419 187
    -413 188
    -408 189
    -403 190
    -397 191
    -391 192
    -386 193
    -380 194
    -374 195
    -368 196
    -361 196
    -355 197
    -349 198
    -342 199
    -336 200
    -329 201
    -322 201
    -315 202
    -308 203
    -301 204
    -294 204
    -287 205
    -280 206
    -272 206
    -265 207
    -257 208
    -250 208
    -242 209
    -235 209
    -227 210
    -219 210
    -211 211
    -203 211
    -195 212
    -187 212
    -179 213
    -171 213
    -162 214
    -154 214
    -146 214
    -137 215
    -129 215
    -121 215
    -112 216
    -104 216
    -95 216
    -86 216
    -78 216
    -69 217
    -61 217
    -52 217
    -43 217
    -35 217
    -26 217
    -17 217
    -9 217
    0 217
    9 217
    17 217
    26 217
    35 217
    43 217
    52 217
    61 217
    69 217
    78 216
    86 216
    95 216
    104 216
    112 216
    121 215
    129 215
    137 215
    146 214
    154 214
    162 214
    171 213
    179 213
    187 212
    195 212
    203 211
    211 211
    219 210
    227 210
    235 209
    242 209
    250 208
    257 208
    265 207
    272 206
    280 206
    287 205
    294 204
    301 204
    308 203
    315 202
    322 201
    329 201
    336 200
    342 199
    349 198
    355 197
    361 196
    368 196
    374 195
    380 194
    386 193
    391 192
    397 191
    403 190
    408 189
    413 188
    419 187
    424 186
    429 185
    434 184
    438 183
    443 182
    447 180
    452 179
    456 178
    460 177
    464 176
    468 175
    472 173
    475 172
    479 171
    482 170
    485 168
    488 167
    491 166
    494 165
    497 163
    499 162
    502 161
    504 159
    506 158
    508 157
    510 155
    511 154
    513 153
    514 151
    515 150
    516 148
    517 147
    518 146
    519 144
    519 143
    520 141
    520 140
    520 138
    520 137
    519 135
    519 134
    518 132
    518 131
    517 129
    516 128
    515 126
    513 125
    512 123
    510 121
    508 120
    506 118
    504 117
    502 115
    500 114
    497 112
    495 110
    492 109
    489 107
    486 106
    482 104
    479 102
    475 101
    472 99
    468 97
    464 96
    459 94
    455 92
    451 91
    446 89
    441 88
    436 86
    431 84
    426 83
    421 81
    415 79
    409 78
    404 76
    398 74
    391 72
    385 71
    379 69
    372 67
    366 66
    359 64
    352 62
    345 61
    337 59
    330 57
    322 56
    315 54
    307 52
    299 51
    291 49
    283 47
    274 45
    266 44
    257 42
    248 40
    240 39
    230 37
    221 35
    212 34
    203 32
    193 30
    183 28
    173 27
    163 25
    153 23
    143 22
    133 20
    122 18
    112 17
    101 15
    90 13
    79 12
    68 10
    57 8
    45 7
    34 5
    22 3
    11 2
    -1 -0
    -13 -2
    -25 -4
    -37 -5
    -50 -7
    -62 -8
    -75 -10
    -87 -12
    -100 -13
    -113 -15
    -126 -17
    -139 -18
    -152 -20
    -166 -22
    -179 -23
    -193 -25
    -207 -27
    -220 -28
    -234 -30
    -248 -32
    -262 -33
    -277 -35
    -291 -36
    -305 -38
    -320 -40
    -335 -41
    -349 -43
    -364 -44
    -379 -46
    -394 -48
    -409 -49
    -425 -51
    -440 -52
    -455 -54
    -471 -56
    -487 -57
    -502 -59
    -518 -60
    -534 -62
    -550 -63
    -566 -65
    -583 -66
    -599 -68
    -615 -70
    -632 -71
    -648 -73
    -665 -74
    -682 -76
    -699 -77
    -716 -79
    -733 -80
    -750 -82
    -767 -83
    -784 -85
    -802 -86
    -819 -88
    -837 -89
    -855 -91
    -872 -92
    -890 -94
    -908 -95
    -926 -97
    -944 -98
    946 -102
    928 -101
    910 -99
    892 -98
    874 -96
    856 -95
    838 -93
    821 -92
    803 -90
    786 -88
    769 -87
    751 -85
    734 -84
    717 -82
    700 -81
    683 -79
    667 -77
    650 -76
    633 -74
    617 -73
    600 -71
    584 -69
    568 -68
    552 -66
    536 -64
    520 -63
    504 -61
    488 -60
    473 -58
    457 -56
    442 -55
    426 -53
    411 -51
    396 -50
    381 -48
    366 -46
    351 -45
    336 -43
    322 -41
    307 -40
    293 -38
    278 -36
    264 -35
    250 -33
    236 -31
    222 -30
    208 -28
    195 -26
    181 -25
    168 -23
    154 -21
    141 -19
    128 -18
    115 -16
    102 -14
    89 -13
    76 -11
    64 -9
    51 -7
    39 -6
    27 -4
    15 -2
    3 -0
    -9 1
    -21 3
    -32 5
    -44 7
    -55 8
    -66 10
    -77 12
    -88 14
    -99 15
    -110 17
    -121 19
    -131 21
    -141 22
    -152 24
    -162 26
    -172 28
    -182 29
    -191 31
    -201 33
    -210 35
    -220 36
    -229 38
    -238 40
    -247 42
    -255 43
    -264 45
    -273 47
    -281 49
    -289 50
    -297 52
    -305 54
    -313 56
    -321 58
    -328 59
    -336 61
    -343 63
    -350 65
    -357 66
    -364 68
    -371 70
    -377 72
    -383 73
    -390 75
    -396 77
    -402 79
    -408 80
    -413 82
    -419 84
    -424 85
    -429 87
    -435 89
    -439 91
    -444 92
    -449 94
    -453 96
    -458 98
    -462 99
    -466 101
    -470 103
    -474 104
    -477 106
    -481 108
    -484 109
    -487 111
    -490 113
    -493 114
    -496 116
    -498 118
    -501 119
    -503 121
    -505 123
    -507 124
    -509 126
    -510 128
    -512 129
    -513 131
    -514 132
    -515 134
    -516 136
    -517 137
    -517 139
    -518 140
    -518 142
    -518 143
    -518 145
    -518 146
    -518 148
    -517 149
    -517 151
    -516 152
    -515 154
    -514 155
    -513 157
    -511 158
    -510 160
    -508 161
    -506 163
    -504 164
    -502 165
    -500 167
    -498 168
    -495 169
    -493 171
    -490 172
    -487 173
    -484 175
    -481 176
    -477 177
    -474 179
    -470 180
    -467 181
    -463 182
    -459 184
    -455 185
    -451 186
    -446 187
    -442 188
    -437 189
    -432 191
    -428 192
    -423 193
    -418 194
    -412 195
    -407 196
    -402 197
    -396 198
    -390 199
    -385 200
    -379 201
    -373 202
    -367 203
    -361 204
    -354 205
    -348 206
    -341 206
    -335 207
    -328 208
    -321 209
    -315 210
    -308 211
    -301 211
    -294 212
    -286 213
    -279 213
    -272 214
    -264 215
    -257 215
    -249 216
    -242 217
    -234 217
    -226 218
    -218 218
    -210 219
    -203 219
    -195 220
    -186 220
    -178 221
    -170 221
    -162 222
    -154 222
    -145 222
    -137 223
    -129 223
    -120 223
    -112 224
    -103 224
    -95 224
    -86 224
    -78 225
    -69 225
    -61 225
    -52 225
    -43 225
    -35 225
    -26 225
    -17 225
    -9 225
    0 225
    9 225
    17 225
    26 225
    35 225
    43 225
    52 225
    61 225
    69 225
    78 225
    86 224
    95 224
    103 224
    112 224
    120 223
    129 223
    137 223
    145 222
    154 222
    162 222
    170 221
    178 221
    186 220
    195 220
    203 219
    210 219
    218 218
    226 218
    234 217
    242 217
    249 216
    257 215
    264 215
    272 214
    279 213
    286 213
    294 212
    301 211
    308 211
    315 210
    321 209
    328 208
    335 207
    341 206
    348 206
    354 205
    361 204
    367 203
    373 202
    379 201
    385 200
    390 199
    396 198
    402 197
    407 196
    412 195
    418 194
    423 193
    428 192
    432 191
    437 189
    442 188
    446 187
    451 186
    455 185
    459 184
    463 182
    467 181
    470 180
    474 179
    477 177
    481 176
    484 175
    487 173
    490 172
    493 171
    495 169
    498 168
    500 167
    502 165
    504 164
    506 163
    508 161
    510 160
    511 158
    513 157
    514 155
    515 154
    516 152
    517 151
    517 149
    518 148
    518 146
    518 145
    518 143
    518 142
    518 140
    517 139
    517 137
    516 136
    515 134
    514 132
    513 131
    512 129
    510 128
    509 126
    507 124
    505 123
    503 121
    501 119
    498 118
    496 116
    493 114
    490 113
    487 111
    484 109
    481 108
    477 106
    474 104
    470 103
    466 101
    462 99
    458 98
    453 96
    449 94
    444 92
    439 91
    435 89
    429 87
    424 85
    419 84
    413 82
    408 80
    402 79
    396 77
    390 75
    383 73
    377 72
    371 70
    364 68
    357 66
    350 65
    343 63
    336 61
    328 59
    321 58
    313 56
    305 54
    297 52
    289 50
    281 49
    273 47
    264 45
    255 43
    247 42
    238 40
    229 38
    220 36
    210 35
    201 33
    191 31
    182 29
    172 28
    162 26
    152 24
    141 22
    131 21
    121 19
    110 17
    99 15
    88 14
    77 12
    66 10
    55 8
    44 7
    32 5
    21 3
    9 1
    -3 -0
    -15 -2
    -27 -4
    -39 -6
    -51 -7
    -64 -9
    -76 -11
    -89 -13
    -102 -14
    -115 -16
    -128 -18
    -141 -19
    -154 -21
    -168 -23
    -181 -25
    -195 -26
    -208 -28
    -222 -30
    -236 -31
    -250 -33
    -264 -35
    -278 -36
    -293 -38
    -307 -40
    -322 -41
    -336 -43
    -351 -45
    -366 -46
    -381 -48
    -396 -50
    -411 -51
    -426 -53
    -442 -55
    -457 -56
    -473 -58
    -488 -60
    -504 -61
    -520 -63
    -536 -64
    -552 -66
    -568 -68
    -584 -69
    -600 -71
    -617 -73
    -633 -74
    -650 -76
    -667 -77
    -683 -79
    -700 -81
    -717 -82
    -734 -84
    -751 -85
    -769 -87
    -786 -88
    -803 -90
    -821 -92
    -838 -93
    -856 -95
    -874 -96
    -892 -98
    -910 -99
    -928 -101
    -946 -102
    947 -107
    929 -105
    911 -103
    893 -102
    875 -100
    858 -99
    840 -97
    822 -95
    805 -94
    788 -92
    770 -90
    753 -89
    736 -87
    719 -86
    702 -84
    685 -82
    668 -81
    652 -79
    635 -77
    618 -76
    602 -74
    586 -72
    570 -71
    553 -69
    537 -67
    521 -65
    506 -64
    490 -62
    474 -60
    459 -59
    443 -57
    428 -55
    413 -54
    397 -52
    382 -50
    367 -48
    353 -47
    338 -45
    323 -43
    309 -41
    294 -40
    280 -38
    266 -36
    252 -34
    238 -33
    224 -31
    210 -29
    196 -27
    183 -26
    169 -24
    156 -22
    143 -20
    130 -19
    117 -17
    104 -15
    91 -13
    78 -11
    66 -10
    53 -8
    41 -6
    29 -4
    17 -3
    5 -1
    -7 1
    -19 3
    -30 5
    -42 7
    -53 8
    -65 10
    -76 12
    -87 14
    -97 16
    -108 17
    -119 19
    -129 21
    -140 23
    -150 25
    -160 26
    -170 28
    -180 30
    -189 32
    -199 34
    -208 36
    -218 37
    -227 39
    -236 41
    -245 43
    -254 45
    -262 47
    -271 48
    -279 50
    -287 52
    -296 54
    -303 56
    -311 58
    -319 59
    -326 61
    -334 63
    -341 65
    -348 67
    -355 69
    -362 70
    -369 72
    -375 74
    -382 76
    -388 78
    -394 79
    -400 81
    -406 83
    -412 85
    -417 87
    -422 88
    -428 90
    -433 92
    -438 94
    -443 96
    -447 97
    -452 99
    -456 101
    -460 103
    -464 104
    -468 106
    -472 108
    -475 110
    -479 111
    -482 113
    -485 115
    -488 117
    -491 118
    -494 120
    -496 122
    -499 124
    -501 125
    -503 127
    -505 129
    -507 130
    -509 132
    -510 134
    -511 135
    -513 137
    -514 139
    -514 140
    -515 142
    -516 144
    -516 145
    -517 147
    -517 148
    -517 150
    -516 152
    -516 153
    -516 155
    -515 156
    -514 158
    -513 159
    -512 161
    -511 162
    -510 164
    -508 165
    -507 167
    -505 168
    -503 170
    -501 171
    -499 173
    -496 174
    -494 175
    -491 177
    -489 178
    -486 180
    -483 181
    -479 182
    -476 184
    -473 185
    -469 186
    -465 188
    -462 189
    -458 190
    -454 191
    -449 193
    -445 194
    -441 195
    -436 196
    -431 197
    -426 199
    -422 200
    -416 201
    -411 202
    -406 203
    -401 204
    -395 205
    -389 206
    -384 207
    -378 208
    -372 209
    -366 210
    -360 211
    -353 212
    -347 213
    -341 214
    -334 215
    -327 216
    -321 216
    -314 217
    -307 218
    -300 219
    -293 220
    -286 220
    -278 221
    -271 222
    -264 222
    -256 223
    -249 224
    -241 224
    -233 225
    -226 226
    -218 226
    -210 227
    -202 227
    -194 228
    -186 228
    -178 229
    -170 229
    -162 230
    -153 230
    -145 230
    -137 231
    -128 231
    -120 231
    -112 232
    -103 232
    -95 232
    -86 232
    -78 233
    -69 233
    -60 233
    -52 233
    -43 233
    -35 233
    -26 233
    -17 233
    -9 233
    0 233
    9 233
    17 233
    26 233
    35 233
    43 233
    52 233
    60 233
    69 233
    78 233
    86 232
    95 232
    103 232
    112 232
    120 231
    128 231
    137 231
    145 230
    153 230
    162 230
    170 229
    178 229
    186 228
    194 228
    202 227
    210 227
    218 226
    226 226
    233 225
    241 224
    249 224
    256 223
    264 222
    271 222
    278 221
    286 220
    293 220
    300 219
    307 218
    314 217
    321 216
    327 216
    334 215
    341 214
    347 213
    353 212
    360 211
    366 210
    372 209
    378 208
    384 207
    389 206
    395 205
    401 204
    406 203
    411 202
    416 201
    422 200
    426 199
    431 197
    436 196
    441 195
    445 194
    449 193
    454 191
    458 190
    462 189
    465 188
    469 186
    473 185
    476 184
    479 182
    483 181
    486 180
    489 178
    491 177
    494 175
    496 174
    499 173
    501 171
    503 170
    505 168
    507 167
    508 165
    510 164
    511 162
    512 161
    513 159
    514 158
    515 156
    516 155
    516 153
    516 152
    517 150
    517 148
    517 147
    516 145
    516 144
    515 142
    514 140
    514 139
    513 137
    511 135
    510 134
    509 132
    507 130
    505 129
    503 127
    501 125
    499 124
    496 122
    494 120
    491 118
    488 117
    485 115
    482 113
    479 111
    475 110
    472 108
    468 106
    464 104
    460 103
    456 101
    452 99
    447 97
    443 96
    438 94
    433 92
    428 90
    422 88
    417 87
    412 85
    406 83
    400 81
    394 79
    388 78
    382 76
    375 74
    369 72
    362 70
    355 69
    348 67
    341 65
    334 63
    326 61
    319 59
    311 58
    303 56
    296 54
    287 52
    279 50
    271 48
    262 47
    254 45
    245 43
    236 41
    227 39
    218 37
    208 36
    199 34
    189 32
    180 30
    170 28
    160 26
    150 25
    140 23
    129 21
    119 19
    108 17
    97 16
    87 14
    76 12
    65 10
    53 8
    42 7
    30 5
    19 3
    7 1
    -5 -1
    -17 -3
    -29 -4
    -41 -6
    -53 -8
    -66 -10
    -78 -11
    -91 -13
    -104 -15
    -117 -17
    -130 -19
    -143 -20
    -156 -22
    -169 -24
    -183 -26
    -196 -27
    -210 -29
    -224 -31
    -238 -33
    -252 -34
    -266 -36
    -280 -38
    -294 -40
    -309 -41
    -323 -43
    -338 -45
    -353 -47
    -367 -48
    -382 -50
    -397 -52
    -413 -54
    -428 -55
    -443 -57
    -459 -59
    -474 -60
    -490 -62
    -506 -64
    -521 -65
    -537 -67
    -553 -69
    -570 -71
    -586 -72
    -602 -74
    -618 -76
    -635 -77
    -652 -79
    -668 -81
    -685 -82
    -702 -84
    -719 -86
    -736 -87
    -753 -89
    -770 -90
    -788 -92
    -805 -94
    -822 -95
    -840 -97
    -858 -99
    -875 -100
    -893 -102
    -911 -103
    -929 -105
    -947 -107
    949 -111
    931 -109
    913 -107
    895 -106
    877 -104
    859 -102
    842 -101
    824 -99
    807 -97
    789 -96
    772 -94
    755 -92
    738 -91
    721 -89
    704 -87
    687 -85
    670 -84
    653 -82
    637 -80
    620 -79
    604 -77
    587 -75
    571 -73
    555 -72
    539 -70
    523 -68
    507 -66
    492 -65
    476 -63
    460 -61
    445 -59
    430 -58
    414 -56
    399 -54
    384 -52
    369 -50
    354 -49
    340 -47
    325 -45
    310 -43
    296 -41
    282 -40
    268 -38
    253 -36
    239 -34
    226 -32
    212 -31
    198 -29
    185 -27
    171 -25
    158 -23
    144 -21
    131 -20
    118 -18
    105 -16
    93 -14
    80 -12
    67 -10
    55 -8
    43 -7
    31 -5
    18 -3
    7 -1
    -5 1
    -17 3
    -29 5
    -40 6
    -51 8
    -63 10
    -74 12
    -85 14
    -96 16
    -106 18
    -117 20
    -127 21
    -138 23
    -148 25
    -158 27
    -168 29
    -178 31
    -188 33
    -197 35
    -207 37
    -216 39
    -225 40
    -234 42
    -243 44
    -252 46
    -260 48
    -269 50
    -277 52
    -286 54
    -294 56
    -302 57
    -309 59
    -317 61
    -325 63
    -332 65
    -339 67
    -346 69
    -353 71
    -360 73
    -367 74
    -373 76
    -380 78
    -386 80
    -392 82
    -398 84
    -404 86
    -410 88
    -415 89
    -421 91
    -426 93
    -431 95
    -436 97
    -441 99
    -445 101
    -450 102
    -454 104
    -458 106
    -462 108
    -466 110
    -470 112
    -474 113
    -477 115
    -480 117
    -484 119
    -487 121
    -489 122
    -492 124
    -495 126
    -497 128
    -499 129
    -501 131
    -503 133
    -505 135
    -507 136
    -508 138
    -510 140
    -511 142
    -512 143
    -513 145
    -514 147
    -514 148
    -515 150
    -515 152
    -515 153
    -515 155
    -515 157
    -515 158
    -514 160
    -514 162
    -513 163
    -512 165
    -511 166
    -510 168
    -508 169
    -507 171
    -505 173
    -503 174
    -502 176
    -500 177
    -497 179
    -495 180
    -493 181
    -490 183
    -487 184
    -484 186
    -481 187
    -478 189
    -475 190
    -471 191
    -468 193
    -464 194
    -460 195
    -456 197
    -452 198
    -448 199
    -444 200
    -439 202
    -435 203
    -430 204
    -425 205
    -420 207
    -415 208
    -410 209
    -405 210
    -399 211
    -394 212
    -388 213
    -383 214
    -377 215
    -371 216
    -365 217
    -359 218
    -352 219
    -346 220
    -340 221
    -333 222
    -327 223
    -320 224
    -313 225
    -306 226
    -299 226
    -292 227
    -285 228
    -278 229
    -270 229
    -263 230
    -256 231
    -248 231
    -240 232
    -233 233
    -225 233
    -217 234
    -209 235
    -201 235
    -194 236
    -185 236
    -177 237
    -169 237
    -161 237
    -153 238
    -145 238
    -136 239
    -128 239
    -120 239
    -111 240
    -103 240
    -94 240
    -86 240
    -77 241
    -69 241
    -60 241
    -52 241
    -43 241
    -34 241
    -26 241
    -17 241
    -9 242
    0 242
    9 242
    17 241
    26 241
    34 241
    43 241
    52 241
    60 241
    69 241
    77 241
    86 240
    94 240
    103 240
    111 240
    120 239
    128 239
    136 239
    145 238
    153 238
    161 237
    169 237
    177 237
    185 236
    194 236
    201 235
    209 235
    217 234
    225 233
    233 233
    240 232
    248 231
    256 231
    263 230
    270 229
    278 229
    285 228
    292 227
    299 226
    306 226
    313 225
    320 224
    327 223
    333 222
    340 221
    346 220
    352 219
    359 218
    365 217
    371 216
    377 215
    383 214
    388 213
    394 212
    399 211
    405 210
    410 209
    415 208
    420 207
    425 205
    430 204
    435 203
    439 202
    444 200
    448 199
    452 198
    456 197
    460 195
    464 194
    468 193
    471 191
    475 190
    478 189
    481 187
    484 186
    487 184
    490 183
    493 181
    495 180
    497 179
    500 177
    502 176
    503 174
    505 173
    507 171
    508 169
    510 168
    511 166
    512 165
    513 163
    514 162
    514 160
    515 158
    515 157
    515 155
    515 153
    515 152
    515 150
    514 148
    514 147
    513 145
    512 143
    511 142
    510 140
    508 138
    507 136
    505 135
    503 133
    501 131
    499 129
    497 128
    495 126
    492 124
    489 122
    487 121
    484 119
    480 117
    477 115
    474 113
    470 112
    466 110
    462 108
    458 106
    454 104
    450 102
    445 101
    441 99
    436 97
    431 95
    426 93
    421 91
    415 89
    410 88
    404 86
    398 84
    392 82
    386 80
    380 78
    373 76
    367 74
    360 73
    353 71
    346 69
    339 67
    332 65
    325 63
    317 61
    309 59
    302 57
    294 56
    286 54
    277 52
    269 50
    260 48
    252 46
    243 44
    234 42
    225 40
    216 39
    207 37
    197 35
    188 33
    178 31
    168 29
    158 27
    148 25
    138 23
    127 21
    117 20
    106 18
    96 16
    85 14
    74 12
    63 10
    51 8
    40 6
    29 5
    17 3
    5 1
    -7 -1
    -18 -3
    -31 -5
    -43 -7
    -55 -8
    -67 -10
    -80 -12
    -93 -14
    -105 -16
    -118 -18
    -131 -20
    -144 -21
    -158 -23
    -171 -25
    -185 -27
    -198 -29
    -212 -31
    -226 -32
    -239 -34
    -253 -36
    -268 -38
    -282 -40
    -296 -41
    -310 -43
    -325 -45
    -340 -47
    -354 -49
    -369 -50
    -384 -52
    -399 -54
    -414 -56
    -430 -58
    -445 -59
    -460 -61
    -476 -63
    -492 -65
    -507 -66
    -523 -68
    -539 -70
    -555 -72
    -571 -73
    -587 -75
    -604 -77
    -620 -79
    -637 -80
    -653 -82
    -670 -84
    -687 -85
    -704 -87
    -721 -89
    -738 -91
    -755 -92
    -772 -94
    -789 -96
    -807 -97
    -824 -99
    -842 -101
    -859 -102
    -877 -104
    -895 -106
    -913 -107
    -931 -109
    -949 -111
    950 -115
    932 -113
    914 -111
    897 -110
    879 -108
    861 -106
    843 -105
    826 -103
    808 -101
    791 -99
    774 -98
    756 -96
    739 -94
    722 -92
    705 -91
    688 -89
    672 -87
    655 -85
    638 -83
    622 -82
    606 -80
    589 -78
    573 -76
    557 -74
    541 -73
    525 -71
    509 -69
    493 -67
    478 -65
    462 -64
    447 -62
    431 -60
    416 -58
    401 -56
    386 -54
    371 -52
    356 -51
    341 -49
    327 -47
    312 -45
    298 -43
    284 -41
    269 -39
    255 -38
    241 -36
    227 -34
    214 -32
    200 -30
    186 -28
    173 -26
    160 -24
    146 -22
    133 -21
    120 -19
    107 -17
    95 -15
    82 -13
    69 -11
    57 -9
    45 -7
    32 -5
    20 -3
    8 -1
    -3 1
    -15 2
    -27 4
    -38 6
    -50 8
    -61 10
    -72 12
    -83 14
    -94 16
    -104 18
    -115 20
    -126 22
    -136 24
    -146 26
    -156 28
    -166 30
    -176 32
    -186 34
    -195 36
    -205 38
    -214 40
    -223 41
    -232 43
    -241 45
    -250 47
    -259 49
    -267 51
    -275 53
    -284 55
    -292 57
    -300 59
    -308 61
    -315 63
    -323 65
    -330 67
    -337 69
    -344 71
    -351 73
    -358 75
    -365 77
    -372 79
    -378 81
    -384 83
    -390 84
    -396 86
    -402 88
    -408 90
    -413 92
    -419 94
    -424 96
    -429 98
    -434 100
    -439 102
    -443 104
    -448 106
    -452 108
    -457 109
    -461 111
    -464 113
    -468 115
    -472 117
    -475 119
    -479 121
    -482 123
    -485 124
    -488 126
    -490 128
    -493 130
    -495 132
    -498 134
    -500 135
    -502 137
    -503 139
    -505 141
    -507 143
    -508 144
    -509 146
    -510 148
    -511 150
    -512 151
    -512 153
    -513 155
    -513 157
    -513 158
    -513 160
    -513 162
    -513 163
    -512 165
    -512 167
    -511 168
    -510 170
    -509 172
    -508 173
    -507 175
    -505 177
    -504 178
    -502 180
    -500 181
    -498 183
    -496 184
    -494 186
    -491 187
    -488 189
    -486 190
    -483 192
    -480 193
    -477 195
    -473 196
    -470 198
    -466 199
    -463 200
    -459 202
    -455 203
    -451 204
    -447 206
    -443 207
    -438 208
    -434 210
    -429 211
    -424 212
    -419 213
    -414 214
    -409 216
    -404 217
    -398 218
    -393 219
    -387 220
    -382 221
    -376 222
    -370 223
    -364 224
    -358 226
    -351 227
    -345 227
    -339 228
    -332 229
    -326 230
    -319 231
    -312 232
    -305 233
    -298 234
    -291 235
    -284 235
    -277 236
    -270 237
    -262 238
    -255 238
    -247 239
    -240 240
    -232 240
    -224 241
    -217 242
    -209 242
    -201 243
    -193 243
    -185 244
    -177 244
    -169 245
    -161 245
    -153 246
    -144 246
    -136 246
    -128 247
    -119 247
    -111 248
    -103 248
    -94 248
    -86 248
    -77 249
    -69 249
    -60 249
    -52 249
    -43 249
    -34 249
    -26 249
    -17 249
    -9 249
    0 249
    9 249
    17 249
    26 249
    34 249
    43 249
    52 249
    60 249
    69 249
    77 249
    86 248
    94 248
    103 248
    111 248
    119 247
    128 247
    136 246
    144 246
    153 246
    161 245
    169 245
    177 244
    185 244
    193 243
    201 243
    209 242
    217 242
    224 241
    232 240
    240 240
    247 239
    255 238
    262 238
    270 237
    277 236
    284 235
    291 235
    298 234
    305 233
    312 232
    319 231
    326 230
    332 229
    339 228
    345 227
    351 227
    358 226
    364 224
    370 223
    376 222
    382 221
    387 220
    393 219
    398 218
    404 217
    409 216
    414 214
    419 213
    424 212
    429 211
    434 210
    438 208
    443 207
    447 206
    451 204
    455 203
    459 202
    463 200
    466 199
    470 198
    473 196
    477 195
    480 193
    483 192
    486 190
    488 189
    491 187
    494 186
    496 184
    498 183
    500 181
    502 180
    504 178
    505 177
    507 175
    508 173
    509 172
    510 170
    511 168
    512 167
    512 165
    513 163
    513 162
    513 160
    513 158
    513 157
    513 155
    512 153
    512 151
    511 150
    510 148
    509 146
    508 144
    507 143
    505 141
    503 139
    502 137
    500 135
    498 134
    495 132
    493 130
    490 128
    488 126
    485 124
    482 123
    479 121
    475 119
    472 117
    468 115
    464 113
    461 111
    457 109
    452 108
    448 106
    443 104
    439 102
    434 100
    429 98
    424 96
    419 94
    413 92
    408 90
    402 88
    396 86
    390 84
    384 83
    378 81
    372 79
    365 77
    358 75
    351 73
    344 71
    337 69
    330 67
    323 65
    315 63
    308 61
    300 59
    292 57
    284 55
    275 53
    267 51
    259 49
    250 47
    241 45
    232 43
    223 41
    214 40
    205 38
    195 36
    186 34
    176 32
    166 30
    156 28
    146 26
    136 24
    126 22
    115 20
    104 18
    94 16
    83 14
    72 12
    61 10
    50 8
    38 6
    27 4
    15 2
    3 1
    -8 -1
    -20 -3
    -32 -5
    -45 -7
    -57 -9
    -69 -11
    -82 -13
    -95 -15
    -107 -17
    -120 -19
    -133 -21
    -146 -22
    -160 -24
    -173 -26
    -186 -28
    -200 -30
    -214 -32
    -227 -34
    -241 -36
    -255 -38
    -269 -39
    -284 -41
    -298 -43
    -312 -45
    -327 -47
    -341 -49
    -356 -51
    -371 -52
    -386 -54
    -401 -56
    -416 -58
    -431 -60
    -447 -62
    -462 -64
    -478 -65
    -493 -67
    -509 -69
    -525 -71
    -541 -73
    -557 -74
    -573 -76
    -589 -78
    -606 -80
    -622 -82
    -638 -83
    -655 -85
    -672 -87
    -688 -89
    -705 -91
    -722 -92
    -739 -94
    -756 -96
    -774 -98
    -791 -99
    -808 -101
    -826 -103
    -843 -105
    -861 -106
    -879 -108
    -897 -110
    -914 -111
    -932 -113
    -950 -115
    952 -119
    934 -117
    916 -115
    898 -114
    881 -112
    863 -110
    845 -108
    828 -107
    810 -105
    793 -103
    775 -101
    758 -99
    741 -98
    724 -96
    707 -94
    690 -92
    674 -90
    657 -88
    640 -87
    624 -85
    607 -83
    591 -81
    575 -79
    559 -77
    543 -75
    527 -74
    511 -72
    495 -70
    480 -68
    464 -66
    449 -64
    433 -62
    418 -60
    403 -58
    388 -56
    373 -55
    358 -53
    343 -51
    329 -49
    314 -47
    300 -45
    285 -43
    271 -41
    257 -39
    243 -37
    229 -35
    216 -33
    202 -31
    188 -29
    175 -27
    162 -26
    148 -24
    135 -22
    122 -20
    109 -18
    97 -16
    84 -14
    71 -12
    59 -10
    47 -8
    34 -6
    22 -4
    10 -2
    -1 0
    -13 2
    -25 4
    -36 6
    -48 8
    -59 10
    -70 12
    -81 14
    -92 16
    -102 18
    -113 20
    -124 22
    -134 24
    -144 26
    -154 28
    -164 30
    -174 32
    -184 34
    -193 36
    -203 38
    -212 41
    -221 43
    -230 45
    -239 47
    -248 49
    -257 51
    -265 53
    -273 55
    -282 57
    -290 59
    -298 61
    -306 63
    -313 65
    -321 67
    -328 69
    -335 71
    -343 73
    -349 75
    -356 77
    -363 79
    -370 81
    -376 83
    -382 85
    -388 87
    -394 89
    -400 91
    -406 93
    -411 95
    -417 97
    -422 99
    -427 101
    -432 103
    -437 105
    -442 107
    -446 109
    -450 111
    -455 113
    -459 115
    -463 117
    -466 119
    -470 121
    -473 122
    -477 124
    -480 126
    -483 128
    -486 130
    -488 132
    -491 134
    -493 136
    -496 138
    -498 140
    -500 141
    -502 143
    -503 145
    -505 147
    -506 149
    -507 151
    -508 153
    -509 154
    -510 156
    -511 158
    -511 160
    -511 162
    -512 163
    -512 165
    -511 167
    -511 169
    -511 170
    -510 172
    -509 174
    -509 175
    -508 177
    -506 179
    -505 180
    -504 182
    -502 184
    -500 185
    -498 187
    -496 189
    -494 190
    -492 192
    -490 193
    -487 195
    -484 196
    -481 198
    -478 199
    -475 201
    -472 202
    -469 204
    -465 205
    -461 207
    -458 208
    -454 209
    -450 211
    -446 212
    -441 214
    -437 215
    -432 216
    -428 217
    -423 219
    -418 220
    -413 221
    -408 222
    -403 224
    -397 225
    -392 226
    -386 227
    -380 228
    -375 229
    -369 230
    -363 232
    -357 233
    -350 234
    -344 235
    -338 236
    -331 237
    -325 238
    -318 239
    -311 239
    -304 240
    -297 241
    -290 242
    -283 243
    -276 244
    -269 244
    -262 245
    -254 246
    -247 247
    -239 247
    -231 248
    -224 249
    -216 249
    -208 250
    -200 250
    -192 251
    -184 252
    -176 252
    -168 253
    -160 253
    -152 253
    -144 254
    -136 254
    -127 255
    -119 255
    -111 255
    -102 256
    -94 256
    -85 256
    -77 256
    -68 257
    -60 257
    -51 257
    -43 257
    -34 257
    -26 257
    -17 257
    -9 257
    0 257
    9 257
    17 257
    26 257
    34 257
    43 257
    51 257
    60 257
    68 257
    77 256
    85 256
    94 256
    102 256
    111 255
    119 255
    127 255
    136 254
    144 254
    152 253
    160 253
    168 253
    176 252
    184 252
    192 251
    200 250
    208 250
    216 249
    224 249
    231 248
    239 247
    247 247
    254 246
    262 245
    269 244
    276 244
    283 243
    290 242
    297 241
    304 240
    311 239
    318 239
    325 238
    331 237
    338 236
    344 235
    350 234
    357 233
    363 232
    369 230
    375 229
    380 228
    386 227
    392 226
    397 225
    403 224
    408 222
    413 221
    418 220
    423 219
    428 217
    432 216
    437 215
    441 214
    446 212
    450 211
    454 209
    458 208
    461 207
    465 205
    469 204
    472 202
    475 201
    478 199
    481 198
    484 196
    487 195
    490 193
    492 192
    494 190
    496 189
    498 187
    500 185
    502 184
    504 182
    505 180
    506 179
    508 177
    509 175
    509 174
    510 172
    511 170
    511 169
    511 167
    512 165
    512 163
    511 162
    511 160
    511 158
    510 156
    509 154
    508 153
    507 151
    506 149
    505 147
    503 145
    502 143
    500 141
    498 140
    496 138
    493 136
    491 134
    488 132
    486 130
    483 128
    480 126
    477 124
    473 122
    470 121
    466 119
    463 117
    459 115
    455 113
    450 111
    446 109
    442 107
    437 105
    432 103
    427 101
    422 99
    417 97
    411 95
    406 93
    400 91
    394 89
    388 87
    382 85
    376 83
    370 81
    363 79
    356 77
    349 75
    343 73
    335 71
    328 69
    321 67
    313 65
    306 63
    298 61
    290 59
    282 57
    273 55
    265 53
    257 51
    248 49
    239 47
    230 45
    221 43
    212 41
    203 38
    193 36
    184 34
    174 32
    164 30
    154 28
    144 26
    134 24
    124 22
    113 20
    102 18
    92 16
    81 14
    70 12
    59 10
    48 8
    36 6
    25 4
    13 2
    1 0
    -10 -2
    -22 -4
    -34 -6
    -47 -8
    -59 -10
    -71 -12
    -84 -14
    -97 -16
    -109 -18
    -122 -20
    -135 -22
    -148 -24
    -162 -26
    -175 -27
    -188 -29
    -202 -31
    -216 -33
    -229 -35
    -243 -37
    -257 -39
    -271 -41
    -285 -43
    -300 -45
    -314 -47
    -329 -49
    -343 -51
    -358 -53
    -373 -55
    -388 -56
    -403 -58
    -418 -60
    -433 -62
    -449 -64
    -464 -66
    -480 -68
    -495 -70
    -511 -72
    -527 -74
    -543 -75
    -559 -77
    -575 -79
    -591 -81
    -607 -83
    -624 -85
    -640 -87
    -657 -88
    -674 -90
    -690 -92
    -707 -94
    -724 -96
    -741 -98
    -758 -99
    -775 -101
    -793 -103
    -810 -105
    -828 -107
    -845 -108
    -863 -110
    -881 -112
    -898 -114
    -916 -115
    -934 -117
    -952 -119
    954 -123
    936 -121
    918 -120
    900 -118
    882 -116
    865 -114
    847 -112
    829 -110
    812 -108
    795 -107
    777 -105
    760 -103
    743 -101
    726 -99
    709 -97
    692 -95
    675 -93
    659 -92
    642 -90
    626 -88
    609 -86
    593 -84
    577 -82
    561 -80
    545 -78
    529 -76
    513 -74
    497 -72
    482 -70
    466 -68
    451 -67
    435 -65
    420 -63
    405 -61
    390 -59
    375 -57
    360 -55
    345 -53
    331 -51
    316 -49
    302 -47
    287 -45
    273 -43
    259 -41
    245 -39
    231 -37
    217 -35
    204 -33
    190 -31
    177 -29
    164 -27
    150 -25
    137 -23
    124 -21
    111 -19
    99 -17
    86 -14
    73 -12
    61 -10
    49 -8
    36 -6
    24 -4
    12 -2
    1 -0
    -11 2
    -23 4
    -34 6
    -46 8
    -57 10
    -68 12
    -79 14
    -90 16
    -100 19
    -111 21
    -121 23
    -132 25
    -142 27
    -152 29
    -162 31
    -172 33
    -182 35
    -191 37
    -201 39
    -210 41
    -219 44
    -228 46
    -237 48
    -246 50
    -254 52
    -263 54
    -271 56
    -280 58
    -288 60
    -296 62
    -303 64
    -311 67
    -319 69
    -326 71
    -333 73
    -340 75
    -347 77
    -354 79
    -361 81
    -368 83
    -374 85
    -380 87
    -386 89
    -392 91
    -398 93
    -404 96
    -409 98
    -415 100
    -420 102
    -425 104
    -430 106
    -435 108
    -440 110
    -444 112
    -448 114
    -453 116
    -457 118
    -461 120
    -464 122
    -468 124
    -471 126
    -475 128
    -478 130
    -481 132
    -484 134
    -487 136
    -489 138
    -492 140
    -494 142
    -496 144
    -498 146
    -500 148
    -501 149
    -503 151
    -504 153
    -505 155
    -507 157
    -507 159
    -508 161
    -509 163
    -509 164
    -510 166
    -510 168
    -510 170
    -510 172
    -509 174
    -509 175
    -508 177
    -508 179
    -507 181
    -506 182
    -505 184
    -503 186
    -502 187
    -500 189
    -499 191
    -497 193
    -495 194
    -493 196
    -490 197
    -488 199
    -485 201
    -483 202
    -480 204
    -477 205
    -474 207
    -471 208
    -467 210
    -464 211
    -460 213
    -456 214
    -452 216
    -448 217
    -444 219
    -440 220
    -435 221
    -431 223
    -426 224
    -422 225
    -417 227
    -412 228
    -407 229
    -401 230
    -396 232
    -391 233
    -385 234
    -379 235
    -374 236
    -368 237
    -362 239
    -356 240
    -349 241
    -343 242
    -337 243
    -330 244
    -324 245
    -317 246
    -310 247
    -303 248
    -297 248
    -290 249
    -282 250
    -275 251
    -268 252
    -261 253
    -253 253
    -246 254
    -238 255
    -231 256
    -223 256
    -215 257
    -208 257
    -200 258
    -192 259
    -184 259
    -176 260
    -168 260
    -160 261
    -152 261
    -143 262
    -135 262
    -127 262
    -119 263
    -110 263
    -102 263
    -94 264
    -85 264
    -77 264
    -68 264
    -60 265
    -51 265
    -43 265
    -34 265
    -26 265
    -17 265
    -9 265
    0 265
    9 265
    17 265
    26 265
    34 265
    43 265
    51 265
    60 265
    68 264
    77 264
    85 264
    94 264
    102 263
    110 263
    119 263
    127 262
    135 262
    143 262
    152 261
    160 261
    168 260
    176 260
    184 259
    192 259
    200 258
    208 257
    215 257
    223 256
    231 256
    238 255
    246 254
    253 253
    261 253
    268 252
    275 251
    282 250
    290 249
    297 248
    303 248
    310 247
    317 246
    324 245
    330 244
    337 243
    343 242
    349 241
    356 240
    362 239
    368 237
    374 236
    379 235
    385 234
    391 233
    396 232
    401 230
    407 229
    412 228
    417 227
    422 225
    426 224
    431 223
    435 221
    440 220
    444 219
    448 217
    452 216
    456 214
    460 213
    464 211
    467 210
    471 208
    474 207
    477 205
    480 204
    483 202
    485 201
    488 199
    490 197
    493 196
    495 194
    497 193
    499 191
    500 189
    502 187
    503 186
    505 184
    506 182
    507 181
    508 179
    508 177
    509 175
    509 174
    510 172
    510 170
    510 168
    510 166
    509 164
    509 163
    508 161
    507 159
    507 157
    505 155
    504 153
    503 151
    501 149
    500 148
    498 146
    496 144
    494 142
    492 140
    489 138
    487 136
    484 134
    481 132
    478 130
    475 128
    471 126
    468 124
    464 122
    461 120
    457 118
    453 116
    448 114
    444 112
    440 110
    435 108
    430 106
    425 104
    420 102
    415 100
    409 98
    404 96
    398 93
    392 91
    386 89
    380 87
    374 85
    368 83
    361 81
    354 79
    347 77
    340 75
    333 73
    326 71
    319 69
    311 67
    303 64
    296 62
    288 60
    280 58
    271 56
    263 54
    254 52
    246 50
    237 48
    228 46
    219 44
    210 41
    201 39
    191 37
    182 35
    172 33
    162 31
    152 29
    142 27
    132 25
    121 23
    111 21
    100 19
    90 16
    79 14
    68 12
    57 10
    46 8
    34 6
    23 4
    11 2
    -1 -0
    -12 -2
    -24 -4
    -36 -6
    -49 -8
    -61 -10
    -73 -12
    -86 -14
    -99 -17
    -111 -19
    -124 -21
    -137 -23
    -150 -25
    -164 -27
    -177 -29
    -190 -31
    -204 -33
    -217 -35
    -231 -37
    -245 -39
    -259 -41
    -273 -43
    -287 -45
    -302 -47
    -316 -49
    -331 -51
    -345 -53
    -360 -55
    -375 -57
    -390 -59
    -405 -61
    -420 -63
    -435 -65
    -451 -67
    -466 -68
    -482 -70
    -497 -72
    -513 -74
    -529 -76
    -545 -78
    -561 -80
    -577 -82
    -593 -84
    -609 -86
    -626 -88
    -642 -90
    -659 -92
    -675 -93
    -692 -95
    -709 -97
    -726 -99
    -743 -101
    -760 -103
    -777 -105
    -795 -107
    -812 -108
    -829 -110
    -847 -112
    -865 -114
    -882 -116
    -900 -118
    -918 -120
    -936 -121
    -954 -123
    956 -127
    938 -126
    920 -124
    902 -122
    884 -120
    866 -118
    849 -116
    831 -114
    814 -112
    796 -110
    779 -108
    762 -106
    745 -105
    728 -103
    711 -101
    694 -99
    677 -97
    661 -95
    644 -93
    628 -91
    611 -89
    595 -87
    579 -85
    563 -83
    547 -81
    531 -79
    515 -77
    499 -75
    483 -73
    468 -71
    453 -69
    437 -67
    422 -65
    407 -63
    392 -61
    377 -59
    362 -57
    347 -55
    333 -53
    318 -51
    304 -49
    289 -47
    275 -44
    261 -42
    247 -40
    233 -38
    220 -36
    206 -34
    192 -32
    179 -30
    166 -28
    152 -26
    139 -24
    126 -22
    113 -20
    101 -17
    88 -15
    75 -13
    63 -11
    51 -9
    39 -7
    26 -5
    14 -3
    3 -0
    -9 2
    -21 4
    -32 6
    -43 8
    -55 10
    -66 12
    -77 14
    -88 17
    -98 19
    -109 21
    -119 23
    -130 25
    -140 27
    -150 29
    -160 32
    -170 34
    -180 36
    -189 38
    -199 40
    -208 42
    -217 45
    -226 47
    -235 49
    -244 51
    -252 53
    -261 55
    -269 57
    -277 60
    -286 62
    -294 64
    -301 66
    -309 68
    -317 70
    -324 72
    -331 75
    -338 77
    -345 79
    -352 81
    -359 83
    -365 85
    -372 87
    -378 90
    -384 92
    -390 94
    -396 96
    -402 98
    -407 100
    -413 102
    -418 104
    -423 107
    -428 109
    -433 111
    -437 113
    -442 115
    -446 117
    -451 119
    -455 121
    -459 123
    -462 125
    -466 127
    -469 129
    -473 132
    -476 134
    -479 136
    -482 138
    -485 140
    -487 142
    -490 144
    -492 146
    -494 148
    -496 150
    -498 152
    -499 154
    -501 156
    -502 158
    -504 160
    -505 161
    -506 163
    -506 165
    -507 167
    -507 169
    -508 171
    -508 173
    -508 175
    -508 177
    -508 179
    -507 180
    -507 182
    -506 184
    -505 186
    -504 188
    -503 189
    -502 191
    -500 193
    -499 195
    -497 196
    -495 198
    -493 200
    -491 201
    -489 203
    -486 205
    -484 206
    -481 208
    -478 210
    -475 211
    -472 213
    -469 214
    -466 216
    -462 217
    -459 219
    -455 220
    -451 222
    -447 223
    -443 225
    -438 226
    -434 228
    -430 229
    -425 230
    -420 232
    -415 233
    -410 235
    -405 236
    -400 237
    -395 238
    -389 240
    -384 241
    -378 242
    -372 243
    -367 244
    -361 246
    -355 247
    -348 248
    -342 249
    -336 250
    -329 251
    -323 252
    -316 253
    -309 254
    -303 255
    -296 256
    -289 257
    -282 257
    -275 258
    -267 259
    -260 260
    -253 261
    -245 262
    -238 262
    -230 263
    -222 264
    -215 264
    -207 265
    -199 266
    -191 266
    -183 267
    -175 267
    -167 268
    -159 268
    -151 269
    -143 269
    -135 270
    -127 270
    -118 270
    -110 271
    -102 271
    -93 271
    -85 272
    -76 272
    -68 272
    -60 272
    -51 272
    -43 273
    -34 273
    -26 273
    -17 273
    -9 273
    0 273
    9 273
    17 273
    26 273
    34 273
    43 273
    51 272
    60 272
    68 272
    76 272
    85 272
    93 271
    102 271
    110 271
    118 270
    127 270
    135 270
    143 269
    151 269
    159 268
    167 268
    175 267
    183 267
    191 266
    199 266
    207 265
    215 264
    222 264
    230 263
    238 262
    245 262
    253 261
    260 260
    267 259
    275 258
    282 257
    289 257
    296 256
    303 255
    309 254
    316 253
    323 252
    329 251
    336 250
    342 249
    348 248
    355 247
    361 246
    367 244
    372 243
    378 242
    384 241
    389 240
    395 238
    400 237
    405 236
    410 235
    415 233
    420 232
    425 230
    430 229
    434 228
    438 226
    443 225
    447 223
    451 222
    455 220
    459 219
    462 217
    466 216
    469 214
    472 213
    475 211
    478 210
    481 208
    484 206
    486 205
    489 203
    491 201
    493 200
    495 198
    497 196
    499 195
    500 193
    502 191
    503 189
    504 188
    505 186
    506 184
    507 182
    507 180
    508 179
    508 177
    508 175
    508 173
    508 171
    507 169
    507 167
    506 165
    506 163
    505 161
    504 160
    502 158
    501 156
    499 154
    498 152
    496 150
    494 148
    492 146
    490 144
    487 142
    485 140
    482 138
    479 136
    476 134
    473 132
    469 129
    466 127
    462 125
    459 123
    455 121
    451 119
    446 117
    442 115
    437 113
    433 111
    428 109
    423 107
    418 104
    413 102
    407 100
    402 98
    396 96
    390 94
    384 92
    378 90
    372 87
    365 85
    359 83
    352 81
    345 79
    338 77
    331 75
    324 72
    317 70
    309 68
    301 66
    294 64
    286 62
    277 60
    269 57
    261 55
    252 53
    244 51
    235 49
    226 47
    217 45
    208 42
    199 40
    189 38
    180 36
    170 34
    160 32
    150 29
    140 27
    130 25
    119 23
    109 21
    98 19
    88 17
    77 14
    66 12
    55 10
    43 8
    32 6
    21 4
    9 2
    -3 -0
    -14 -3
    -26 -5
    -39 -7
    -51 -9
    -63 -11
    -75 -13
    -88 -15
    -101 -17
    -113 -20
    -126 -22
    -139 -24
    -152 -26
    -166 -28
    -179 -30
    -192 -32
    -206 -34
    -220 -36
    -233 -38
    -247 -40
    -261 -42
    -275 -44
    -289 -47
    -304 -49
    -318 -51
    -333 -53
    -347 -55
    -362 -57
    -377 -59
    -392 -61
    -407 -63
    -422 -65
    -437 -67
    -453 -69
    -468 -71
    -483 -73
    -499 -75
    -515 -77
    -531 -79
    -547 -81
    -563 -83
    -579 -85
    -595 -87
    -611 -89
    -628 -91
    -644 -93
    -661 -95
    -677 -97
    -694 -99
    -711 -101
    -728 -103
    -745 -105
    -762 -106
    -779 -108
    -796 -110
    -814 -112
    -831 -114
    -849 -116
    -866 -118
    -884 -120
    -902 -122
    -920 -124
    -938 -126
    -956 -127
    958 -132
    940 -130
    922 -128
    904 -126
    886 -124
    868 -122
    851 -120
    833 -118
    816 -116
    798 -114
    781 -112
    764 -110
    747 -108
    730 -106
    713 -104
    696 -102
    679 -100
    663 -98
    646 -96
    630 -94
    613 -92
    597 -90
    581 -88
    565 -86
    549 -84
    533 -82
    517 -80
    501 -78
    486 -76
    470 -74
    455 -71
    439 -69
    424 -67
    409 -65
    394 -63
    379 -61
    364 -59
    349 -57
    335 -55
    320 -53
    306 -50
    292 -48
    277 -46
    263 -44
    249 -42
    235 -40
    222 -38
    208 -36
    194 -33
    181 -31
    168 -29
    154 -27
    141 -25
    128 -23
    115 -20
    103 -18
    90 -16
    78 -14
    65 -12
    53 -10
    41 -7
    29 -5
    17 -3
    5 -1
    -7 1
    -18 3
    -30 6
    -41 8
    -52 10
    -64 12
    -75 14
    -85 17
    -96 19
    -107 21
    -117 23
    -128 26
    -138 28
    -148 30
    -158 32
    -168 34
    -177 37
    -187 39
    -196 41
    -206 43
    -215 45
    -224 48
    -233 50
    -242 52
    -250 54
    -259 57
    -267 59
    -275 61
    -283 63
    -291 65
    -299 68
    -307 70
    -314 72
    -322 74
    -329 76
    -336 79
    -343 81
    -350 83
    -357 85
    -363 87
    -370 90
    -376 92
    -382 94
    -388 96
    -394 98
    -400 101
    -405 103
    -411 105
    -416 107
    -421 109
    -426 112
    -431 114
    -435 116
    -440 118
    -444 120
    -448 122
    -453 124
    -456 127
    -460 129
    -464 131
    -467 133
    -471 135
    -474 137
    -477 139
    -480 141
    -483 143
    -485 146
    -488 148
    -490 150
    -492 152
    -494 154
    -496 156
    -497 158
    -499 160
    -500 162
    -502 164
    -503 166
    -504 168
    -504 170
    -505 172
    -506 174
    -506 176
    -506 178
    -506 180
    -506 182
    -506 183
    -505 185
    -505 187
    -504 189
    -503 191
    -502 193
    -501 195
    -500 196
    -498 198
    -497 200
    -495 202
    -493 204
    -491 205
    -489 207
    -487 209
    -485 210
    -482 212
    -479 214
    -477 215
    -474 217
    -471 219
    -467 220
    -464 222
    -461 224
    -457 225
    -453 227
    -449 228
    -445 230
    -441 231
    -437 233
    -433 234
    -428 236
    -424 237
    -419 238
    -414 240
    -409 241
    -404 242
    -399 244
    -394 245
    -388 246
    -383 248
    -377 249
    -371 250
    -365 251
    -359 252
    -353 254
    -347 255
    -341 256
    -335 257
    -328 258
    -322 259
    -315 260
    -308 261
    -302 262
    -295 263
    -288 264
    -281 265
    -274 266
    -266 266
    -259 267
    -252 268
    -244 269
    -237 270
    -229 270
    -222 271
    -214 272
    -206 272
    -199 273
    -191 274
    -183 274
    -175 275
    -167 275
    -159 276
    -151 276
    -143 277
    -134 277
    -126 278
    -118 278
    -110 278
    -101 279
    -93 279
    -85 279
    -76 280
    -68 280
    -59 280
    -51 280
    -42 280
    -34 280
    -25 280
    -17 281
    -9 281
    0 281
    9 281
    17 281
    25 280
    34 280
    42 280
    51 280
    59 280
    68 280
    76 280
    85 279
    93 279
    101 279
    110 278
    118 278
    126 278
    134 277
    143 277
    151 276
    159 276
    167 275
    175 275
    183 274
    191 274
    199 273
    206 272
    214 272
    222 271
    229 270
    237 270
    244 269
    252 268
    259 267
    266 266
    274 266
    281 265
    288 264
    295 263
    302 262
    308 261
    315 260
    322 259
    328 258
    335 257
    341 256
    347 255
    353 254
    359 252
    365 251
    371 250
    377 249
    383 248
    388 246
    394 245
    399 244
    404 242
    409 241
    414 240
    419 238
    424 237
    428 236
    433 234
    437 233
    441 231
    445 230
    449 228
    453 227
    457 225
    461 224
    464 222
    467 220
    471 219
    474 217
    477 215
    479 214
    482 212
    485 210
    487 209
    489 207
    491 205
    493 204
    495 202
    497 200
    498 198
    500 196
    501 195
    502 193
    503 191
    504 189
    505 187
    505 185
    506 183
    506 182
    506 180
    506 178
    506 176
    506 174
    505 172
    504 170
    504 168
    503 166
    502 164
    500 162
    499 160
    497 158
    496 156
    494 154
    492 152
    490 150
    488 148
    485 146
    483 143
    480 141
    477 139
    474 137
    471 135
    467 133
    464 131
    460 129
    456 127
    453 124
    448 122
    444 120
    440 118
    435 116
    431 114
    426 112
    421 109
    416 107
    411 105
    405 103
    400 101
    394 98
    388 96
    382 94
    376 92
    370 90
    363 87
    357 85
    350 83
    343 81
    336 79
    329 76
    322 74
    314 72
    307 70
    299 68
    291 65
    283 63
    275 61
    267 59
    259 57
    250 54
    242 52
    233 50
    224 48
    215 45
    206 43
    196 41
    187 39
    177 37
    168 34
    158 32
    148 30
    138 28
    128 26
    117 23
    107 21
    96 19
    85 17
    75 14
    64 12
    52 10
    41 8
    30 6
    18 3
    7 1
    -5 -1
    -17 -3
    -29 -5
    -41 -7
    -53 -10
    -65 -12
    -78 -14
    -90 -16
    -103 -18
    -115 -20
    -128 -23
    -141 -25
    -154 -27
    -168 -29
    -181 -31
    -194 -33
    -208 -36
    -222 -38
    -235 -40
    -249 -42
    -263 -44
    -277 -46
    -292 -48
    -306 -50
    -320 -53
    -335 -55
    -349 -57
    -364 -59
    -379 -61
    -394 -63
    -409 -65
    -424 -67
    -439 -69
    -455 -71
    -470 -74
    -486 -76
    -501 -78
    -517 -80
    -533 -82
    -549 -84
    -565 -86
    -581 -88
    -597 -90
    -613 -92
    -630 -94
    -646 -96
    -663 -98
    -679 -100
    -696 -102
    -713 -104
    -730 -106
    -747 -108
    -764 -110
    -781 -112
    -798 -114
    -816 -116
    -833 -118
    -851 -120
    -868 -122
    -886 -124
    -904 -126
    -922 -128
    -940 -130
    -958 -132
    960 -136
    942 -134
    924 -132
    906 -130
    888 -128
    870 -126
    853 -124
    835 -122
    818 -120
    800 -118
    783 -116
    766 -114
    749 -112
    732 -110
    715 -108
    698 -105
    681 -103
    665 -101
    648 -99
    632 -97
    615 -95
    599 -93
    583 -91
    567 -89
    551 -87
    535 -85
    519 -82
    503 -80
    488 -78
    472 -76
    457 -74
    441 -72
    426 -70
    411 -68
    396 -65
    381 -63
    366 -61
    352 -59
    337 -57
    322 -55
    308 -52
    294 -50
    280 -48
    265 -46
    251 -44
    238 -41
    224 -39
    210 -37
    197 -35
    183 -33
    170 -30
    157 -28
    144 -26
    131 -24
    118 -22
    105 -19
    92 -17
    80 -15
    67 -13
    55 -10
    43 -8
    31 -6
    19 -4
    7 -1
    -5 1
    -16 3
    -28 5
    -39 8
    -50 10
    -61 12
    -72 14
    -83 17
    -94 19
    -104 21
    -115 24
    -125 26
    -136 28
    -146 30
    -156 33
    -165 35
    -175 37
    -185 39
    -194 42
    -203 44
    -213 46
    -222 49
    -231 51
    -239 53
    -248 55
    -256 58
    -265 60
    -273 62
    -281 65
    -289 67
    -297 69
    -305 71
    -312 74
    -320 76
    -327 78
    -334 81
    -341 83
    -348 85
    -354 87
    -361 90
    -367 92
    -374 94
    -380 96
    -386 99
    -392 101
    -397 103
    -403 105
    -408 108
    -414 110
    -419 112
    -424 114
    -428 117
    -433 119
    -438 121
    -442 123
    -446 125
    -450 128
    -454 130
    -458 132
    -462 134
    -465 136
    -469 139
    -472 141
    -475 143
    -478 145
    -480 147
    -483 149
    -485 151
    -488 154
    -490 156
    -492 158
    -494 160
    -495 162
    -497 164
    -498 166
    -500 168
    -501 170
    -502 172
    -502 174
    -503 176
    -504 178
    -504 180
    -504 182
    -504 184
    -504 186
    -504 188
    -503 190
    -503 192
    -502 194
    -501 196
    -500 198
    -499 200
    -498 202
    -497 203
    -495 205
    -493 207
    -492 209
    -490 211
    -488 213
    -485 214
    -483 216
    -480 218
    -478 220
    -475 221
    -472 223
    -469 225
    -466 226
    -462 228
    -459 229
    -455 231
    -452 233
    -448 234
    -444 236
    -440 237
    -436 239
    -431 240
    -427 242
    -422 243
    -417 245
    -413 246
    -408 248
    -403 249
    -397 250
    -392 252
    -387 253
    -381 254
    -376 255
    -370 257
    -364 258
    -358 259
    -352 260
    -346 262
    -340 263
    -334 264
    -327 265
    -321 266
    -314 267
    -307 268
    -301 269
    -294 270
    -287 271
    -280 272
    -273 273
    -266 274
    -258 275
    -251 275
    -244 276
    -236 277
    -229 278
    -221 278
    -213 279
    -206 280
    -198 280
    -190 281
    -182 282
    -174 282
    -166 283
    -158 283
    -150 284
    -142 284
    -134 285
    -126 285
    -118 286
    -109 286
    -101 286
    -93 287
    -84 287
    -76 287
    -68 287
    -59 288
    -51 288
    -42 288
    -34 288
    -25 288
    -17 288
    -8 288
    0 288
    8 288
    17 288
    25 288
    34 288
    42 288
    51 288
    59 288
    68 287
    76 287
    84 287
    93 287
    101 286
    109 286
    118 286
    126 285
    134 285
    142 284
    150 284
    158 283
    166 283
    174 282
    182 282
    190 281
    198 280
    206 280
    213 279
    221 278
    229 278
    236 277
    244 276
    251 275
    258 275
    266 274
    273 273
    280 272
    287 271
    294 270
    301 269
    307 268
    314 267
    321 266
    327 265
    334 264
    340 263
    346 262
    352 260
    358 259
    364 258
    370 257
    376 255
    381 254
    387 253
    392 252
    397 250
    403 249
    408 248
    413 246
    417 245
    422 243
    427 242
    431 240
    436 239
    440 237
    444 236
    448 234
    452 233
    455 231
    459 229
    462 228
    466 226
    469 225
    472 223
    475 221
    478 220
    480 218
    483 216
    485 214
    488 213
    490 211
    492 209
    493 207
    495 205
    497 203
    498 202
    499 200
    500 198
    501 196
    502 194
    503 192
    503 190
    504 188
    504 186
    504 184
    504 182
    504 180
    504 178
    503 176
    502 174
    502 172
    501 170
    500 168
    498 166
    497 164
    495 162
    494 160
    492 158
    490 156
    488 154
    485 151
    483 149
    480 147
    478 145
    475 143
    472 141
    469 139
    465 136
    462 134
    458 132
    454 130
    450 128
    446 125
    442 123
    438 121
    433 119
    428 117
    424 114
    419 112
    414 110
    408 108
    403 105
    397 103
    392 101
    386 99
    380 96
    374 94
    367 92
    361 90
    354 87
    348 85
    341 83
    334 81
    327 78
    320 76
    312 74
    305 71
    297 69
    289 67
    281 65
    273 62
    265 60
    256 58
    248 55
    239 53
    231 51
    222 49
    213 46
    203 44
    194 42
    185 39
    175 37
    165 35
    156 33
    146 30
    136 28
    125 26
    115 24
    104 21
    94 19
    83 17
    72 14
    61 12
    50 10
    39 8
    28 5
    16 3
    5 1
    -7 -1
    -19 -4
    -31 -6
    -43 -8
    -55 -10
    -67 -13
    -80 -15
    -92 -17
    -105 -19
    -118 -22
    -131 -24
    -144 -26
    -157 -28
    -170 -30
    -183 -33
    -197 -35
    -210 -37
    -224 -39
    -238 -41
    -251 -44
    -265 -46
    -280 -48
    -294 -50
    -308 -52
    -322 -55
    -337 -57
    -352 -59
    -366 -61
    -381 -63
    -396 -65
    -411 -68
    -426 -70
    -441 -72
    -457 -74
    -472 -76
    -488 -78
    -503 -80
    -519 -82
    -535 -85
    -551 -87
    -567 -89
    -583 -91
    -599 -93
    -615 -95
    -632 -97
    -648 -99
    -665 -101
    -681 -103
    -698 -105
    -715 -108
    -732 -110
    -749 -112
    -766 -114
    -783 -116
    -800 -118
    -818 -120
    -835 -122
    -853 -124
    -870 -126
    -888 -128
    -906 -130
    -924 -132
    -942 -134
    -960 -136
    962 -140
    944 -138
    926 -136
    908 -134
    890 -132
    872 -130
    855 -128
    837 -126
    820 -124
    802 -122
    785 -119
    768 -117
    751 -115
    734 -113
    717 -111
    700 -109
    683 -107
    667 -105
    650 -103
    634 -100
    617 -98
    601 -96
    585 -94
    569 -92
    553 -90
    537 -87
    521 -85
    505 -83
    490 -81
    474 -79
    459 -76
    444 -74
    428 -72
    413 -70
    398 -68
    383 -65
    368 -63
    354 -61
    339 -59
    325 -57
    310 -54
    296 -52
    282 -50
    268 -48
    254 -45
    240 -43
    226 -41
    212 -39
    199 -36
    185 -34
    172 -32
    159 -29
    146 -27
    133 -25
    120 -23
    107 -20
    95 -18
    82 -16
    70 -13
    57 -11
    45 -9
    33 -6
    21 -4
    9 -2
    -2 0
    -14 3
    -25 5
    -37 7
    -48 10
    -59 12
    -70 14
    -81 17
    -92 19
    -102 21
    -113 24
    -123 26
    -133 28
    -143 31
    -153 33
    -163 35
    -173 38
    -182 40
    -192 42
    -201 45
    -210 47
    -219 50
    -228 52
    -237 54
    -246 57
    -254 59
    -262 61
    -271 64
    -279 66
    -287 68
    -295 71
    -302 73
    -310 75
    -317 78
    -324 80
    -332 82
    -339 85
    -345 87
    -352 89
    -359 92
    -365 94
    -371 96
    -378 99
    -384 101
    -389 103
    -395 106
    -401 108
    -406 110
    -411 112
    -416 115
    -421 117
    -426 119
    -431 122
    -435 124
    -440 126
    -444 128
    -448 131
    -452 133
    -456 135
    -460 137
    -463 140
    -466 142
    -470 144
    -473 146
    -475 149
    -478 151
    -481 153
    -483 155
    -486 157
    -488 160
    -490 162
    -492 164
    -493 166
    -495 168
    -496 170
    -497 172
    -499 175
    -500 177
    -500 179
    -501 181
    -502 183
    -502 185
    -502 187
    -502 189
    -502 191
    -502 193
    -501 195
    -501 197
    -500 199
    -499 201
    -499 203
    -497 205
    -496 207
    -495 209
    -493 211
    -492 212
    -490 214
    -488 216
    -486 218
    -484 220
    -481 222
    -479 223
    -476 225
    -473 227
    -470 229
    -467 230
    -464 232
    -461 234
    -457 235
    -454 237
    -450 239
    -446 240
    -442 242
    -438 243
    -434 245
    -430 247
    -425 248
    -421 250
    -416 251
    -411 252
    -406 254
    -401 255
    -396 257
    -391 258
    -385 259
    -380 261
    -374 262
    -369 263
    -363 265
    -357 266
    -351 267
    -345 268
    -339 269
    -332 271
    -326 272
    -320 273
    -313 274
    -306 275
    -300 276
    -293 277
    -286 278
    -279 279
    -272 280
    -265 281
    -257 282
    -250 282
    -243 283
    -235 284
    -228 285
    -220 286
    -213 286
    -205 287
    -197 288
    -190 288
    -182 289
    -174 290
    -166 290
    -158 291
    -150 291
    -142 292
    -134 292
    -125 293
    -117 293
    -109 293
    -101 294
    -92 294
    -84 294
    -76 295
    -67 295
    -59 295
    -51 295
    -42 295
    -34 295
    -25 296
    -17 296
    -8 296
    0 296
    8 296
    17 296
    25 296
    34 295
    42 295
    51 295
    59 295
    67 295
    76 295
    84 294
    92 294
    101 294
    109 293
    117 293
    125 293
    134 292
    142 292
    150 291
    158 291
    166 290
    174 290
    182 289
    190 288
    197 288
    205 287
    213 286
    220 286
    228 285
    235 284
    243 283
    250 282
    257 282
    265 281
    272 280
    279 279
    286 278
    293 277
    300 276
    306 275
    313 274
    320 273
    326 272
    332 271
    339 269
    345 268
    351 267
    357 266
    363 265
    369 263
    374 262
    380 261
    385 259
    391 258
    396 257
    401 255
    406 254
    411 252
    416 251
    421 250
    425 248
    430 247
    434 245
    438 243
    442 242
    446 240
    450 239
    454 237
    457 235
    461 234
    464 232
    467 230
    470 229
    473 227
    476 225
    479 223
    481 222
    484 220
    486 218
    488 216
    490 214
    492 212
    493 211
    495 209
    496 207
    497 205
    499 203
    499 201
    500 199
    501 197
    501 195
    502 193
    502 191
    502 189
    502 187
    502 185
    502 183
    501 181
    500 179
    500 177
    499 175
    497 172
    496 170
    495 168
    493 166
    492 164
    490 162
    488 160
    486 157
    483 155
    481 153
    478 151
    475 149
    473 146
    470 144
    466 142
    463 140
    460 137
    456 135
    452 133
    448 131
    444 128
    440 126
    435 124
    431 122
    426 119
    421 117
    416 115
    411 112
    406 110
    401 108
    395 106
    389 103
    384 101
    378 99
    371 96
    365 94
    359 92
    352 89
    345 87
    339 85
    332 82
    324 80
    317 78
    310 75
    302 73
    295 71
    287 68
    279 66
    271 64
    262 61
    254 59
    246 57
    237 54
    228 52
    219 50
    210 47
    201 45
    192 42
    182 40
    173 38
    163 35
    153 33
    143 31
    133 28
    123 26
    113 24
    102 21
    92 19
    81 17
    70 14
    59 12
    48 10
    37 7
    25 5
    14 3
    2 0
    -9 -2
    -21 -4
    -33 -6
    -45 -9
    -57 -11
    -70 -13
    -82 -16
    -95 -18
    -107 -20
    -120 -23
    -133 -25
    -146 -27
    -159 -29
    -172 -32
    -185 -34
    -199 -36
    -212 -39
    -226 -41
    -240 -43
    -254 -45
    -268 -48
    -282 -50
    -296 -52
    -310 -54
    -325 -57
    -339 -59
    -354 -61
    -368 -63
    -383 -65
    -398 -68
    -413 -70
    -428 -72
    -444 -74
    -459 -76
    -474 -79
    -490 -81
    -505 -83
    -521 -85
    -537 -87
    -553 -90
    -569 -92
    -585 -94
    -601 -96
    -617 -98
    -634 -100
    -650 -103
    -667 -105
    -683 -107
    -700 -109
    -717 -111
    -734 -113
    -751 -115
    -768 -117
    -785 -119
    -802 -122
    -820 -124
    -837 -126
    -855 -128
    -872 -130
    -890 -132
    -908 -134
    -926 -136
    -944 -138
    -962 -140
    964 -145
    946 -142
    928 -140
    910 -138
    892 -136
    875 -134
    857 -132
    839 -130
    822 -128
    805 -125
    787 -123
    770 -121
    753 -119
    736 -117
    719 -115
    702 -112
    686 -110
    669 -108
    652 -106
    636 -104
    620 -101
    603 -99
    587 -97
    571 -95
    555 -93
    539 -90
    523 -88
    508 -86
    492 -84
    476 -81
    461 -79
    446 -77
    431 -75
    415 -72
    400 -70
    386 -68
    371 -65
    356 -63
    341 -61
    327 -59
    312 -56
    298 -54
    284 -52
    270 -49
    256 -47
    242 -45
    228 -42
    215 -40
    201 -38
    188 -35
    174 -33
    161 -31
    148 -28
    135 -26
    122 -24
    110 -21
    97 -19
    84 -17
    72 -14
    60 -12
    47 -9
    35 -7
    23 -5
    12 -2
    -0 0
    -12 2
    -23 5
    -34 7
    -46 10
    -57 12
    -68 14
    -79 17
    -89 19
    -100 22
    -110 24
    -121 26
    -131 29
    -141 31
    -151 34
    -161 36
    -170 38
    -180 41
    -189 43
    -199 46
    -208 48
    -217 50
    -226 53
    -235 55
    -243 58
    -252 60
    -260 62
    -268 65
    -276 67
    -284 70
    -292 72
    -300 74
    -307 77
    -315 79
    -322 82
    -329 84
    -336 86
    -343 89
    -350 91
    -356 94
    -363 96
    -369 98
    -375 101
    -381 103
    -387 106
    -393 108
    -398 110
    -404 113
    -409 115
    -414 117
    -419 120
    -424 122
    -429 124
    -433 127
    -438 129
    -442 131
    -446 134
    -450 136
    -454 138
    -457 141
    -461 143
    -464 145
    -467 148
    -470 150
    -473 152
    -476 154
    -479 157
    -481 159
    -483 161
    -486 163
    -488 166
    -489 168
    -491 170
    -493 172
    -494 174
    -495 177
    -496 179
    -497 181
    -498 183
    -499 185
    -499 187
    -500 189
    -500 191
    -500 194
    -500 196
    -500 198
    -499 200
    -499 202
    -498 204
    -497 206
    -497 208
    -495 210
    -494 212
    -493 214
    -491 216
    -490 218
    -488 220
    -486 221
    -484 223
    -482 225
    -479 227
    -477 229
    -474 231
    -471 233
    -469 234
    -466 236
    -462 238
    -459 240
    -456 241
    -452 243
    -448 245
    -445 246
    -441 248
    -437 250
    -432 251
    -428 253
    -424 254
    -419 256
    -415 257
    -410 259
    -405 260
    -400 262
    -395 263
    -389 265
    -384 266
    -379 267
    -373 269
    -367 270
    -362 271
    -356 273
    -350 274
    -344 275
    -338 276
    -331 277
    -325 279
    -319 280
    -312 281
    -305 282
    -299 283
    -292 284
    -285 285
    -278 286
    -271 287
    -264 288
    -257 289
    -249 290
    -242 290
    -235 291
    -227 292
    -220 293
    -212 294
    -204 294
    -197 295
    -189 296
    -181 296
    -173 297
    -165 297
    -157 298
    -149 299
    -141 299
    -133 299
    -125 300
    -117 300
    -109 301
    -100 301
    -92 301
    -84 302
    -75 302
    -67 302
    -59 302
    -50 303
    -42 303
    -34 303
    -25 303
    -17 303
    -8 303
    0 303
    8 303
    17 303
    25 303
    34 303
    42 303
    50 303
    59 302
    67 302
    75 302
    84 302
    92 301
    100 301
    109 301
    117 300
    125 300
    133 299
    141 299
    149 299
    157 298
    165 297
    173 297
    181 296
    189 296
    197 295
    204 294
    212 294
    220 293
    227 292
    235 291
    242 290
    249 290
    257 289
    264 288
    271 287
    278 286
    285 285
    292 284
    299 283
    305 282
    312 281
    319 280
    325 279
    331 277
    338 276
    344 275
    350 274
    356 273
    362 271
    367 270
    373 269
    379 267
    384 266
    389 265
    395 263
    400 262
    405 260
    410 259
    415 257
    419 256
    424 254
    428 253
    432 251
    437 250
    441 248
    445 246
    448 245
    452 243
    456 241
    459 240
    462 238
    466 236
    469 234
    471 233
    474 231
    477 229
    479 227
    482 225
    484 223
    486 221
    488 220
    490 218
    491 216
    493 214
    494 212
    495 210
    497 208
    497 206
    498 204
    499 202
    499 200
    500 198
    500 196
    500 194
    500 191
    500 189
    499 187
    499 185
    498 183
    497 181
    496 179
    495 177
    494 174
    493 172
    491 170
    489 168
    488 166
    486 163
    483 161
    481 159
    479 157
    476 154
    473 152
    470 150
    467 148
    464 145
    461 143
    457 141
    454 138
    450 136
    446 134
    442 131
    438 129
    433 127
    429 124
    424 122
    419 120
    414 117
    409 115
    404 113
    398 110
    393 108
    387 106
    381 103
    375 101
    369 98
    363 96
    356 94
    350 91
    343 89
    336 86
    329 84
    322 82
    315 79
    307 77
    300 74
    292 72
    284 70
    276 67
    268 65
    260 62
    252 60
    243 58
    235 55
    226 53
    217 50
    208 48
    199 46
    189 43
    180 41
    170 38
    161 36
    151 34
    141 31
    131 29
    121 26
    110 24
    100 22
    89 19
    79 17
    68 14
    57 12
    46 10
    34 7
    23 5
    12 2
    0 0
    -12 -2
    -23 -5
    -35 -7
    -47 -9
    -60 -12
    -72 -14
    -84 -17
    -97 -19
    -110 -21
    -122 -24
    -135 -26
    -148 -28
    -161 -31
    -174 -33
    -188 -35
    -201 -38
    -215 -40
    -228 -42
    -242 -45
    -256 -47
    -270 -49
    -284 -52
    -298 -54
    -312 -56
    -327 -59
    -341 -61
    -356 -63
    -371 -65
    -386 -68
    -400 -70
    -415 -72
    -431 -75
    -446 -77
    -461 -79
    -476 -81
    -492 -84
    -508 -86
    -523 -88
    -539 -90
    -555 -93
    -571 -95
    -587 -97
    -603 -99
    -620 -101
    -636 -104
    -652 -106
    -669 -108
    -686 -110
    -702 -112
    -719 -115
    -736 -117
    -753 -119
    -770 -121
    -787 -123
    -805 -125
    -822 -128
    -839 -130
    -857 -132
    -875 -134
    -892 -136
    -910 -138
    -928 -140
    -946 -142
    -964 -145
    966 -149
    948 -147
    930 -145
    912 -142
    894 -140
    877 -138
    859 -136
    842 -134
    824 -131
    807 -129
    790 -127
    772 -125
    755 -123
    738 -120
    721 -118
    705 -116
    688 -114
    671 -111
    655 -109
    638 -107
    622 -105
    606 -102
    589 -100
    573 -98
    557 -95
    541 -93
    526 -91
    510 -89
    494 -86
    479 -84
    463 -82
    448 -79
    433 -77
    418 -75
    403 -72
    388 -70
    373 -68
    358 -65
    344 -63
    329 -61
    315 -58
    301 -56
    286 -54
    272 -51
    258 -49
    244 -46
    231 -44
    217 -42
    204 -39
    190 -37
    177 -34
    164 -32
    150 -30
    138 -27
    125 -25
    112 -22
    99 -20
    87 -18
    74 -15
    62 -13
    50 -10
    38 -8
    26 -5
    14 -3
    2 -1
    -9 2
    -21 4
    -32 7
    -43 9
    -54 12
    -65 14
    -76 17
    -87 19
    -97 22
    -108 24
    -118 27
    -128 29
    -138 31
    -148 34
    -158 36
    -168 39
    -178 41
    -187 44
    -196 46
    -205 49
    -214 51
    -223 54
    -232 56
    -241 59
    -249 61
    -258 64
    -266 66
    -274 69
    -282 71
    -290 73
    -297 76
    -305 78
    -312 81
    -320 83
    -327 86
    -334 88
    -341 91
    -347 93
    -354 96
    -360 98
    -367 100
    -373 103
    -379 105
    -385 108
    -390 110
    -396 113
    -401 115
    -407 118
    -412 120
    -417 122
    -422 125
    -426 127
    -431 130
    -435 132
    -439 134
    -443 137
    -447 139
    -451 141
    -455 144
    -458 146
    -462 149
    -465 151
    -468 153
    -471 156
    -474 158
    -476 160
    -479 163
    -481 165
    -483 167
    -485 169
    -487 172
    -489 174
    -490 176
    -492 178
    -493 181
    -494 183
    -495 185
    -496 187
    -497 189
    -497 192
    -498 194
    -498 196
    -498 198
    -498 200
    -498 202
    -497 204
    -497 207
    -496 209
    -495 211
    -495 213
    -493 215
    -492 217
    -491 219
    -489 221
    -488 223
    -486 225
    -484 227
    -482 229
    -480 231
    -477 232
    -475 234
    -472 236
    -470 238
    -467 240
    -464 242
    -461 243
    -457 245
    -454 247
    -450 249
    -447 250
    -443 252
    -439 254
    -435 255
    -431 257
    -427 259
    -422 260
    -418 262
    -413 263
    -408 265
    -403 267
    -398 268
    -393 269
    -388 271
    -383 272
    -377 274
    -372 275
    -366 276
    -360 278
    -355 279
    -349 280
    -343 282
    -336 283
    -330 284
    -324 285
    -317 286
    -311 288
    -304 289
    -298 290
    -291 291
    -284 292
    -277 293
    -270 294
    -263 295
    -256 296
    -248 297
    -241 297
    -234 298
    -226 299
    -219 300
    -211 301
    -204 301
    -196 302
    -188 303
    -180 303
    -173 304
    -165 305
    -157 305
    -149 306
    -141 306
    -133 307
    -125 307
    -116 308
    -108 308
    -100 308
    -92 309
    -84 309
    -75 309
    -67 310
    -59 310
    -50 310
    -42 310
    -34 310
    -25 310
    -17 310
    -8 310
    0 310
    8 310
    17 310
    25 310
    34 310
    42 310
    50 310
    59 310
    67 310
    75 309
    84 309
    92 309
    100 308
    108 308
    116 308
    125 307
    133 307
    141 306
    149 306
    157 305
    165 305
    173 304
    180 303
    188 303
    196 302
    204 301
    211 301
    219 300
    226 299
    234 298
    241 297
    248 297
    256 296
    263 295
    270 294
    277 293
    284 292
    291 291
    298 290
    304 289
    311 288
    317 286
    324 285
    330 284
    336 283
    343 282
    349 280
    355 279
    360 278
    366 276
    372 275
    377 274
    383 272
    388 271
    393 269
    398 268
    403 267
    408 265
    413 263
    418 262
    422 260
    427 259
    431 257
    435 255
    439 254
    443 252
    447 250
    450 249
    454 247
    457 245
    461 243
    464 242
    467 240
    470 238
    472 236
    475 234
    477 232
    480 231
    482 229
    484 227
    486 225
    488 223
    489 221
    491 219
    492 217
    493 215
    495 213
    495 211
    496 209
    497 207
    497 204
    498 202
    498 200
    498 198
    498 196
    498 194
    497 192
    497 189
    496 187
    495 185
    494 183
    493 181
    492 178
    490 176
    489 174
    487 172
    485 169
    483 167
    481 165
    479 163
    476 160
    474 158
    471 156
    468 153
    465 151
    462 149
    458 146
    455 144
    451 141
    447 139
    443 137
    439 134
    435 132
    431 130
    426 127
    422 125
    417 122
    412 120
    407 118
    401 115
    396 113
    390 110
    385 108
    379 105
    373 103
    367 100
    360 98
    354 96
    347 93
    341 91
    334 88
    327 86
    320 83
    312 81
    305 78
    297 76
    290 73
    282 71
    274 69
    266 66
    258 64
    249 61
    241 59
    232 56
    223 54
    214 51
    205 49
    196 46
    187 44
    178 41
    168 39
    158 36
    148 34
    138 31
    128 29
    118 27
    108 24
    97 22
    87 19
    76 17
    65 14
    54 12
    43 9
    32 7
    21 4
    9 2
    -2 -1
    -14 -3
    -26 -5
    -38 -8
    -50 -10
    -62 -13
    -74 -15
    -87 -18
    -99 -20
    -112 -22
    -125 -25
    -138 -27
    -150 -30
    -164 -32
    -177 -34
    -190 -37
    -204 -39
    -217 -42
    -231 -44
    -244 -46
    -258 -49
    -272 -51
    -286 -54
    -301 -56
    -315 -58
    -329 -61
    -344 -63
    -358 -65
    -373 -68
    -388 -70
    -403 -72
    -418 -75
    -433 -77
    -448 -79
    -463 -82
    -479 -84
    -494 -86
    -510 -89
    -526 -91
    -541 -93
    -557 -95
    -573 -98
    -589 -100
    -606 -102
    -622 -105
    -638 -107
    -655 -109
    -671 -111
    -688 -114
    -705 -116
    -721 -118
    -738 -120
    -755 -123
    -772 -125
    -790 -127
    -807 -129
    -824 -131
    -842 -134
    -859 -136
    -877 -138
    -894 -140
    -912 -142
    -930 -145
    -948 -147
    -966 -149
    968 -153
    950 -151
    932 -149
    914 -147
    897 -144
    879 -142
    861 -140
    844 -138
    826 -135
    809 -133
    792 -131
    775 -129
    758 -126
    741 -124
    724 -122
    707 -119
    690 -117
    673 -115
    657 -112
    640 -110
    624 -108
    608 -105
    592 -103
    576 -101
    560 -98
    544 -96
    528 -94
    512 -91
    497 -89
    481 -87
    466 -84
    450 -82
    435 -80
    420 -77
    405 -75
    390 -72
    375 -70
    361 -68
    346 -65
    332 -63
    317 -60
    303 -58
    289 -55
    275 -53
    261 -51
    247 -48
    233 -46
    219 -43
    206 -41
    193 -38
    179 -36
    166 -33
    153 -31
    140 -28
    127 -26
    114 -23
    102 -21
    89 -19
    77 -16
    65 -14
    52 -11
    40 -9
    28 -6
    17 -4
    5 -1
    -7 1
    -18 4
    -29 6
    -41 9
    -52 12
    -63 14
    -74 17
    -84 19
    -95 22
    -105 24
    -116 27
    -126 29
    -136 32
    -146 34
    -156 37
    -165 39
    -175 42
    -184 44
    -194 47
    -203 49
    -212 52
    -221 55
    -230 57
    -238 60
    -247 62
    -255 65
    -263 67
    -272 70
    -279 72
    -287 75
    -295 77
    -303 80
    -310 82
    -317 85
    -324 87
    -331 90
    -338 92
    -345 95
    -351 97
    -358 100
    -364 103
    -370 105
    -376 108
    -382 110
    -388 113
    -393 115
    -399 117
    -404 120
    -409 122
    -414 125
    -419 127
    -424 130
    -428 132
    -433 135
    -437 137
    -441 140
    -445 142
    -449 145
    -453 147
    -456 149
    -459 152
    -463 154
    -466 157
    -469 159
    -471 161
    -474 164
    -476 166
    -479 168
    -481 171
    -483 173
    -485 175
    -487 178
    -488 180
    -490 182
    -491 185
    -492 187
    -493 189
    -494 191
    -495 194
    -495 196
    -495 198
    -496 200
    -496 203
    -496 205
    -496 207
    -495 209
    -495 211
    -494 213
    -493 215
    -492 218
    -491 220
    -490 222
    -489 224
    -487 226
    -486 228
    -484 230
    -482 232
    -480 234
    -478 236
    -476 238
    -473 240
    -471 242
    -468 244
    -465 245
    -462 247
    -459 249
    -456 251
    -452 253
    -449 254
    -445 256
    -441 258
    -437 260
    -433 261
    -429 263
    -425 265
    -421 266
    -416 268
    -411 270
    -407 271
    -402 273
    -397 274
    -392 276
    -387 277
    -381 279
    -376 280
    -370 281
    -365 283
    -359 284
    -353 286
    -347 287
    -341 288
    -335 289
    -329 291
    -323 292
    -316 293
    -310 294
    -303 295
    -296 296
    -290 298
    -283 299
    -276 300
    -269 301
    -262 302
    -255 303
    -248 303
    -240 304
    -233 305
    -226 306
    -218 307
    -211 308
    -203 308
    -195 309
    -188 310
    -180 311
    -172 311
    -164 312
    -156 312
    -148 313
    -140 313
    -132 314
    -124 314
    -116 315
    -108 315
    -100 316
    -91 316
    -83 316
    -75 317
    -67 317
    -58 317
    -50 317
    -42 317
    -33 318
    -25 318
    -17 318
    -8 318
    0 318
    8 318
    17 318
    25 318
    33 318
    42 317
    50 317
    58 317
    67 317
    75 317
    83 316
    91 316
    100 316
    108 315
    116 315
    124 314
    132 314
    140 313
    148 313
    156 312
    164 312
    172 311
    180 311
    188 310
    195 309
    203 308
    211 308
    218 307
    226 306
    233 305
    240 304
    248 303
    255 303
    262 302
    269 301
    276 300
    283 299
    290 298
    296 296
    303 295
    310 294
    316 293
    323 292
    329 291
    335 289
    341 288
    347 287
    353 286
    359 284
    365 283
    370 281
    376 280
    381 279
    387 277
    392 276
    397 274
    402 273
    407 271
    411 270
    416 268
    421 266
    425 265
    429 263
    433 261
    437 260
    441 258
    445 256
    449 254
    452 253
    456 251
    459 249
    462 247
    465 245
    468 244
    471 242
    473 240
    476 238
    478 236
    480 234
    482 232
    484 230
    486 228
    487 226
    489 224
    490 222
    491 220
    492 218
    493 215
    494 213
    495 211
    495 209
    496 207
    496 205
    496 203
    496 200
    495 198
    495 196
    495 194
    494 191
    493 189
    492 187
    491 185
    490 182
    488 180
    487 178
    485 175
    483 173
    481 171
    479 168
    476 166
    474 164
    471 161
    469 159
    466 157
    463 154
    459 152
    456 149
    453 147
    449 145
    445 142
    441 140
    437 137
    433 135
    428 132
    424 130
    419 127
    414 125
    409 122
    404 120
    399 117
    393 115
    388 113
    382 110
    376 108
    370 105
    364 103
    358 100
    351 97
    345 95
    338 92
    331 90
    324 87
    317 85
    310 82
    303 80
    295 77
    287 75
    279 72
    272 70
    263 67
    255 65
    247 62
    238 60
    230 57
    221 55
    212 52
    203 49
    194 47
    184 44
    175 42
    165 39
    156 37
    146 34
    136 32
    126 29
    116 27
    105 24
    95 22
    84 19
    74 17
    63 14
    52 12
    41 9
    29 6
    18 4
    7 1
    -5 -1
    -17 -4
    -28 -6
    -40 -9
    -52 -11
    -65 -14
    -77 -16
    -89 -19
    -102 -21
    -114 -23
    -127 -26
    -140 -28
    -153 -31
    -166 -33
    -179 -36
    -193 -38
    -206 -41
    -219 -43
    -233 -46
    -247 -48
    -261 -51
    -275 -53
    -289 -55
    -303 -58
    -317 -60
    -332 -63
    -346 -65
    -361 -68
    -375 -70
    -390 -72
    -405 -75
    -420 -77
    -435 -80
    -450 -82
    -466 -84
    -481 -87
    -497 -89
    -512 -91
    -528 -94
    -544 -96
    -560 -98
    -576 -101
    -592 -103
    -608 -105
    -624 -108
    -640 -110
    -657 -112
    -673 -115
    -690 -117
    -707 -119
    -724 -122
    -741 -124
    -758 -126
    -775 -129
    -792 -131
    -809 -133
    -826 -135
    -844 -138
    -861 -140
    -879 -142
    -897 -144
    -914 -147
    -932 -149
    -950 -151
    -968 -153
    970 -158
    952 -155
    934 -153
    917 -151
    899 -149
    881 -146
    864 -144
    846 -142
    829 -139
    811 -137
    794 -135
    777 -132
    760 -130
    743 -128
    726 -125
    709 -123
    692 -121
    676 -118
    659 -116
    643 -113
    626 -111
    610 -109
    594 -106
    578 -104
    562 -101
    546 -99
    530 -97
    515 -94
    499 -92
    484 -89
    468 -87
    453 -84
    438 -82
    423 -80
    408 -77
    393 -75
    378 -72
    363 -70
    349 -67
    334 -65
    320 -62
    305 -60
    291 -57
    277 -55
    263 -52
    249 -50
    236 -47
    222 -45
    208 -42
    195 -40
    182 -37
    169 -35
    155 -32
    142 -30
    130 -27
    117 -25
    104 -22
    92 -20
    79 -17
    67 -14
    55 -12
    43 -9
    31 -7
    19 -4
    7 -2
    -4 1
    -16 4
    -27 6
    -38 9
    -49 11
    -60 14
    -71 16
    -82 19
    -92 22
    -103 24
    -113 27
    -123 29
    -133 32
    -143 35
    -153 37
    -163 40
    -172 42
    -182 45
    -191 47
    -200 50
    -209 53
    -218 55
    -227 58
    -236 60
    -244 63
    -253 66
    -261 68
    -269 71
    -277 73
    -285 76
    -292 79
    -300 81
    -307 84
    -315 86
    -322 89
    -329 92
    -336 94
    -342 97
    -349 99
    -355 102
    -362 104
    -368 107
    -374 110
    -380 112
    -385 115
    -391 117
    -396 120
    -402 122
    -407 125
    -412 127
    -417 130
    -421 133
    -426 135
    -430 138
    -434 140
    -439 143
    -443 145
    -446 148
    -450 150
    -454 152
    -457 155
    -460 157
    -463 160
    -466 162
    -469 165
    -472 167
    -474 170
    -476 172
    -479 174
    -481 177
    -483 179
    -484 182
    -486 184
    -487 186
    -489 189
    -490 191
    -491 193
    -492 196
    -492 198
    -493 200
    -493 202
    -493 205
    -494 207
    -494 209
    -493 211
    -493 214
    -493 216
    -492 218
    -491 220
    -490 222
    -489 225
    -488 227
    -487 229
    -485 231
    -484 233
    -482 235
    -480 237
    -478 239
    -476 241
    -474 243
    -471 245
    -469 247
    -466 249
    -463 251
    -460 253
    -457 255
    -454 256
    -450 258
    -447 260
    -443 262
    -440 264
    -436 265
    -432 267
    -428 269
    -423 271
    -419 272
    -414 274
    -410 276
    -405 277
    -400 279
    -395 280
    -390 282
    -385 283
    -380 285
    -374 286
    -369 288
    -363 289
    -358 291
    -352 292
    -346 293
    -340 295
    -334 296
    -328 297
    -321 298
    -315 300
    -309 301
    -302 302
    -295 303
    -289 304
    -282 305
    -275 306
    -268 307
    -261 308
    -254 309
    -247 310
    -239 311
    -232 312
    -225 313
    -217 314
    -210 315
    -202 315
    -195 316
    -187 317
    -179 318
    -171 318
    -163 319
    -156 319
    -148 320
    -140 320
    -132 321
    -124 321
    -116 322
    -107 322
    -99 323
    -91 323
    -83 323
    -75 324
    -66 324
    -58 324
    -50 324
    -42 325
    -33 325
    -25 325
    -17 325
    -8 325
    0 325
    8 325
    17 325
    25 325
    33 325
    42 325
    50 324
    58 324
    66 324
    75 324
    83 323
    91 323
    99 323
    107 322
    116 322
    124 321
    132 321
    140 320
    148 320
    156 319
    163 319
    171 318
    179 318
    187 317
    195 316
    202 315
    210 315
    217 314
    225 313
    232 312
    239 311
    247 310
    254 309
    261 308
    268 307
    275 306
    282 305
    289 304
    295 303
    302 302
    309 301
    315 300
    321 298
    328 297
    334 296
    340 295
    346 293
    352 292
    358 291
    363 289
    369 288
    374 286
    380 285
    385 283
    390 282
    395 280
    400 279
    405 277
    410 276
    414 274
    419 272
    423 271
    428 269
    432 267
    436 265
    440 264
    443 262
    447 260
    450 258
    454 256
    457 255
    460 253
    463 251
    466 249
    469 247
    471 245
    474 243
    476 241
    478 239
    480 237
    482 235
    484 233
    485 231
    487 229
    488 227
    489 225
    490 222
    491 220
    492 218
    493 216
    493 214
    493 211
    494 209
    494 207
    493 205
    493 202
    493 200
    492 198
    492 196
    491 193
    490 191
    489 189
    487 186
    486 184
    484 182
    483 179
    481 177
    479 174
    476 172
    474 170
    472 167
    469 165
    466 162
    463 160
    460 157
    457 155
    454 152
    450 150
    446 148
    443 145
    439 143
    434 140
    430 138
    426 135
    421 133
    417 130
    412 127
    407 125
    402 122
    396 120
    391 117
    385 115
    380 112
    374 110
    368 107
    362 104
    355 102
    349 99
    342 97
    336 94
    329 92
    322 89
    315 86
    307 84
    300 81
    292 79
    285 76
    277 73
    269 71
    261 68
    253 66
    244 63
    236 60
    227 58
    218 55
    209 53
    200 50
    191 47
    182 45
    172 42
    163 40
    153 37
    143 35
    133 32
    123 29
    113 27
    103 24
    92 22
    82 19
    71 16
    60 14
    49 11
    38 9
    27 6
    16 4
    4 1
    -7 -2
    -19 -4
    -31 -7
    -43 -9
    -55 -12
    -67 -14
    -79 -17
    -92 -20
    -104 -22
    -117 -25
    -130 -27
    -142 -30
    -155 -32
    -169 -35
    -182 -37
    -195 -40
    -208 -42
    -222 -45
    -236 -47
    -249 -50
    -263 -52
    -277 -55
    -291 -57
    -305 -60
    -320 -62
    -334 -65
    -349 -67
    -363 -70
    -378 -72
    -393 -75
    -408 -77
    -423 -80
    -438 -82
    -453 -84
    -468 -87
    -484 -89
    -499 -92
    -515 -94
    -530 -97
    -546 -99
    -562 -101
    -578 -104
    -594 -106
    -610 -109
    -626 -111
    -643 -113
    -659 -116
    -676 -118
    -692 -121
    -709 -123
    -726 -125
    -743 -128
    -760 -130
    -777 -132
    -794 -135
    -811 -137
    -829 -139
    -846 -142
    -864 -144
    -881 -146
    -899 -149
    -917 -151
    -934 -153
    -952 -155
    -970 -158
    973 -162
    955 -160
    937 -157
    919 -155
    901 -153
    884 -150
    866 -148
    848 -146
    831 -143
    814 -141
    796 -139
    779 -136
    762 -134
    745 -131
    728 -129
    712 -126
    695 -124
    678 -122
    662 -119
    645 -117
    629 -114
    613 -112
    596 -109
    580 -107
    564 -105
    549 -102
    533 -100
    517 -97
    501 -95
    486 -92
    471 -90
    455 -87
    440 -85
    425 -82
    410 -80
    395 -77
    380 -75
    366 -72
    351 -70
    337 -67
    322 -64
    308 -62
    294 -59
    280 -57
    266 -54
    252 -52
    238 -49
    224 -47
    211 -44
    198 -41
    184 -39
    171 -36
    158 -34
    145 -31
    132 -28
    119 -26
    107 -23
    94 -21
    82 -18
    70 -15
    57 -13
    45 -10
    33 -8
    22 -5
    10 -2
    -2 0
    -13 3
    -24 6
    -36 8
    -47 11
    -58 14
    -68 16
    -79 19
    -90 21
    -100 24
    -111 27
    -121 29
    -131 32
    -141 35
    -151 37
    -160 40
    -170 43
    -179 45
    -189 48
    -198 51
    -207 53
    -216 56
    -224 59
    -233 61
    -242 64
    -250 67
    -258 69
    -266 72
    -274 75
    -282 77
    -290 80
    -297 83
    -305 85
    -312 88
    -319 91
    -326 93
    -333 96
    -340 98
    -346 101
    -353 104
    -359 106
    -365 109
    -371 112
    -377 114
    -383 117
    -388 119
    -394 122
    -399 125
    -404 127
    -409 130
    -414 132
    -419 135
    -423 138
    -428 140
    -432 143
    -436 145
    -440 148
    -444 150
    -448 153
    -451 156
    -454 158
    -458 161
    -461 163
    -464 166
    -466 168
    -469 171
    -472 173
    -474 176
    -476 178
    -478 180
    -480 183
    -482 185
    -483 188
    -485 190
    -486 193
    -487 195
    -488 197
    -489 200
    -490 202
    -491 204
    -491 207
    -491 209
    -491 211
    -491 214
    -491 216
    -491 218
    -490 220
    -490 223
    -489 225
    -488 227
    -487 229
    -486 231
    -485 234
    -483 236
    -482 238
    -480 240
    -478 242
    -476 244
    -474 246
    -472 248
    -469 250
    -467 252
    -464 254
    -461 256
    -458 258
    -455 260
    -452 262
    -449 264
    -445 266
    -441 268
    -438 269
    -434 271
    -430 273
    -426 275
    -422 276
    -417 278
    -413 280
    -408 282
    -404 283
    -399 285
    -394 286
    -389 288
    -384 290
    -378 291
    -373 293
    -368 294
    -362 295
    -356 297
    -351 298
    -345 300
    -339 301
    -333 302
    -326 304
    -320 305
    -314 306
    -307 307
    -301 309
    -294 310
    -288 311
    -281 312
    -274 313
    -267 314
    -260 315
    -253 316
    -246 317
    -239 318
    -231 319
    -224 320
    -216 321
    -209 321
    -201 322
    -194 323
    -186 324
    -178 324
    -171 325
    -163 326
    -155 326
    -147 327
    -139 327
    -131 328
    -123 328
    -115 329
    -107 329
    -99 330
    -91 330
    -83 330
    -74 331
    -66 331
    -58 331
    -50 331
    -41 332
    -33 332
    -25 332
    -17 332
    -8 332
    0 332
    8 332
    17 332
    25 332
    33 332
    41 332
    50 331
    58 331
    66 331
    74 331
    83 330
    91 330
    99 330
    107 329
    115 329
    123 328
    131 328
    139 327
    147 327
    155 326
    163 326
    171 325
    178 324
    186 324
    194 323
    201 322
    209 321
    216 321
    224 320
    231 319
    239 318
    246 317
    253 316
    260 315
    267 314
    274 313
    281 312
    288 311
    294 310
    301 309
    307 307
    314 306
    320 305
    326 304
    333 302
    339 301
    345 300
    351 298
    356 297
    362 295
    368 294
    373 293
    378 291
    384 290
    389 288
    394 286
    399 285
    404 283
    408 282
    413 280
    417 278
    422 276
    426 275
    430 273
    434 271
    438 269
    441 268
    445 266
    449 264
    452 262
    455 260
    458 258
    461 256
    464 254
    467 252
    469 250
    472 248
    474 246
    476 244
    478 242
    480 240
    482 238
    483 236
    485 234
    486 231
    487 229
    488 227
    489 225
    490 223
    490 220
    491 218
    491 216
    491 214
    491 211
    491 209
    491 207
    491 204
    490 202
    489 200
    488 197
    487 195
    486 193
    485 190
    483 188
    482 185
    480 183
    478 180
    476 178
    474 176
    472 173
    469 171
    466 168
    464 166
    461 163
    458 161
    454 158
    451 156
    448 153
    444 150
    440 148
    436 145
    432 143
    428 140
    423 138
    419 135
    414 132
    409 130
    404 127
    399 125
    394 122
    388 119
    383 117
    377 114
    371 112
    365 109
    359 106
    353 104
    346 101
    340 98
    333 96
    326 93
    319 91
    312 88
    305 85
    297 83
    290 80
    282 77
    274 75
    266 72
    258 69
    250 67
    242 64
    233 61
    224 59
    216 56
    207 53
    198 51
    189 48
    179 45
    170 43
    160 40
    151 37
    141 35
    131 32
    121 29
    111 27
    100 24
    90 21
    79 19
    68 16
    58 14
    47 11
    36 8
    24 6
    13 3
    2 0
    -10 -2
    -22 -5
    -33 -8
    -45 -10
    -57 -13
    -70 -15
    -82 -18
    -94 -21
    -107 -23
    -119 -26
    -132 -28
    -145 -31
    -158 -34
    -171 -36
    -184 -39
    -198 -41
    -211 -44
    -224 -47
    -238 -49
    -252 -52
    -266 -54
    -280 -57
    -294 -59
    -308 -62
    -322 -64
    -337 -67
    -351 -70
    -366 -72
    -380 -75
    -395 -77
    -410 -80
    -425 -82
    -440 -85
    -455 -87
    -471 -90
    -486 -92
    -501 -95
    -517 -97
    -533 -100
    -549 -102
    -564 -105
    -580 -107
    -596 -109
    -613 -112
    -629 -114
    -645 -117
    -662 -119
    -678 -122
    -695 -124
    -712 -126
    -728 -129
    -745 -131
    -762 -134
    -779 -136
    -796 -139
    -814 -141
    -831 -143
    -848 -146
    -866 -148
    -884 -150
    -901 -153
    -919 -155
    -937 -157
    -955 -160
    -973 -162
    975 -167
    957 -164
    939 -162
    921 -159
    904 -157
    886 -155
    868 -152
    851 -150
    833 -147
    816 -145
    799 -142
    782 -140
    765 -138
    748 -135
    731 -133
    714 -130
    697 -128
    681 -125
    664 -123
    648 -120
    631 -118
    615 -115
    599 -113
    583 -110
    567 -108
    551 -105
    535 -103
    520 -100
    504 -97
    489 -95
    473 -92
    458 -90
    443 -87
    428 -85
    413 -82
    398 -80
    383 -77
    368 -74
    354 -72
    339 -69
    325 -67
    310 -64
    296 -61
    282 -59
    268 -56
    254 -54
    241 -51
    227 -48
    214 -46
    200 -43
    187 -40
    174 -38
    161 -35
    148 -32
    135 -30
    122 -27
    109 -24
    97 -22
    85 -19
    72 -16
    60 -14
    48 -11
    36 -8
    24 -6
    13 -3
    1 -0
    -10 2
    -22 5
    -33 8
    -44 11
    -55 13
    -66 16
    -76 19
    -87 21
    -97 24
    -108 27
    -118 30
    -128 32
    -138 35
    -148 38
    -158 40
    -167 43
    -177 46
    -186 49
    -195 51
    -204 54
    -213 57
    -222 59
    -230 62
    -239 65
    -247 68
    -256 70
    -264 73
    -272 76
    -279 78
    -287 81
    -295 84
    -302 87
    -309 89
    -316 92
    -323 95
    -330 97
    -337 100
    -344 103
    -350 106
    -356 108
    -363 111
    -369 114
    -374 116
    -380 119
    -386 122
    -391 124
    -396 127
    -402 130
    -407 132
    -411 135
    -416 138
    -421 140
    -425 143
    -429 145
    -433 148
    -437 151
    -441 153
    -445 156
    -449 159
    -452 161
    -455 164
    -458 166
    -461 169
    -464 171
    -467 174
    -469 176
    -471 179
    -474 182
    -476 184
    -478 187
    -479 189
    -481 191
    -482 194
    -484 196
    -485 199
    -486 201
    -487 204
    -488 206
    -488 208
    -489 211
    -489 213
    -489 216
    -489 218
    -489 220
    -489 223
    -488 225
    -488 227
    -487 229
    -486 232
    -485 234
    -484 236
    -482 238
    -481 241
    -479 243
    -478 245
    -476 247
    -474 249
    -472 251
    -470 253
    -467 255
    -465 257
    -462 259
    -459 261
    -456 263
    -453 265
    -450 267
    -447 269
    -443 271
    -440 273
    -436 275
    -432 277
    -428 279
    -424 280
    -420 282
    -416 284
    -411 286
    -407 287
    -402 289
    -397 291
    -392 292
    -387 294
    -382 296
    -377 297
    -371 299
    -366 300
    -360 302
    -355 303
    -349 305
    -343 306
    -337 307
    -331 309
    -325 310
    -319 311
    -313 313
    -306 314
    -300 315
    -293 316
    -286 317
    -280 319
    -273 320
    -266 321
    -259 322
    -252 323
    -245 324
    -238 325
    -230 326
    -223 327
    -216 327
    -208 328
    -201 329
    -193 330
    -185 331
    -178 331
    -170 332
    -162 333
    -154 333
    -147 334
    -139 334
    -131 335
    -123 335
    -115 336
    -107 336
    -99 337
    -90 337
    -82 337
    -74 338
    -66 338
    -58 338
    -50 338
    -41 339
    -33 339
    -25 339
    -17 339
    -8 339
    0 339
    8 339
    17 339
    25 339
    33 339
    41 339
    50 338
    58 338
    66 338
    74 338
    82 337
    90 337
    99 337
    107 336
    115 336
    123 335
    131 335
    139 334
    147 334
    154 333
    162 333
    170 332
    178 331
    185 331
    193 330
    201 329
    208 328
    216 327
    223 327
    230 326
    238 325
    245 324
    252 323
    259 322
    266 321
    273 320
    280 319
    286 317
    293 316
    300 315
    306 314
    313 313
    319 311
    325 310
    331 309
    337 307
    343 306
    349 305
    355 303
    360 302
    366 300
    371 299
    377 297
    382 296
    387 294
    392 292
    397 291
    402 289
    407 287
    411 286
    416 284
    420 282
    424 280
    428 279
    432 277
    436 275
    440 273
    443 271
    447 269
    450 267
    453 265
    456 263
    459 261
    462 259
    465 257
    467 255
    470 253
    472 251
    474 249
    476 247
    478 245
    479 243
    481 241
    482 238
    484 236
    485 234
    486 232
    487 229
    488 227
    488 225
    489 223
    489 220
    489 218
    489 216
    489 213
    489 211
    488 208
    488 206
    487 204
    486 201
    485 199
    484 196
    482 194
    481 191
    479 189
    478 187
    476 184
    474 182
    471 179
    469 176
    467 174
    464 171
    461 169
    458 166
    455 164
    452 161
    449 159
    445 156
    441 153
    437 151
    433 148
    429 145
    425 143
    421 140
    416 138
    411 135
    407 132
    402 130
    396 127
    391 124
    386 122
    380 119
    374 116
    369 114
    363 111
    356 108
    350 106
    344 103
    337 100
    330 97
    323 95
    316 92
    309 89
    302 87
    295 84
    287 81
    279 78
    272 76
    264 73
    256 70
    247 68
    239 65
    230 62
    222 59
    213 57
    204 54
    195 51
    186 49
    177 46
    167 43
    158 40
    148 38
    138 35
    128 32
    118 30
    108 27
    97 24
    87 21
    76 19
    66 16
    55 13
    44 11
    33 8
    22 5
    10 2
    -1 -0
    -13 -3
    -24 -6
    -36 -8
    -48 -11
    -60 -14
    -72 -16
    -85 -19
    -97 -22
    -109 -24
    -122 -27
    -135 -30
    -148 -32
    -161 -35
    -174 -38
    -187 -40
    -200 -43
    -214 -46
    -227 -48
    -241 -51
    -254 -54
    -268 -56
    -282 -59
    -296 -61
    -310 -64
    -325 -67
    -339 -69
    -354 -72
    -368 -74
    -383 -77
    -398 -80
    -413 -82
    -428 -85
    -443 -87
    -458 -90
    -473 -92
    -489 -95
    -504 -97
    -520 -100
    -535 -103
    -551 -105
    -567 -108
    -583 -110
    -599 -113
    -615 -115
    -631 -118
    -648 -120
    -664 -123
    -681 -125
    -697 -128
    -714 -130
    -731 -133
    -748 -135
    -765 -138
    -782 -140
    -799 -142
    -816 -145
    -833 -147
    -851 -150
    -868 -152
    -886 -155
    -904 -157
    -921 -159
    -939 -162
    -957 -164
    -975 -167
    978 -171
    960 -169
    942 -166
    924 -164
    906 -161
    888 -159
    871 -156
    853 -154
    836 -151
    819 -149
    801 -146
    784 -144
    767 -141
    750 -139
    733 -136
    716 -134
    700 -131
    683 -129
    667 -126
    650 -124
    634 -121
    618 -118
    601 -116
    585 -113
    569 -111
    554 -108
    538 -106
    522 -103
    507 -100
    491 -98
    476 -95
    460 -93
    445 -90
    430 -87
    415 -85
    400 -82
    385 -79
    371 -77
    356 -74
    342 -71
    327 -69
    313 -66
    299 -63
    285 -61
    271 -58
    257 -55
    243 -53
    230 -50
    216 -47
    203 -45
    190 -42
    176 -39
    163 -36
    150 -34
    137 -31
    125 -28
    112 -26
    100 -23
    87 -20
    75 -17
    63 -15
    51 -12
    39 -9
    27 -6
    15 -4
    4 -1
    -8 2
    -19 5
    -30 7
    -41 10
    -52 13
    -63 16
    -74 18
    -84 21
    -95 24
    -105 27
    -115 30
    -125 32
    -135 35
    -145 38
    -155 41
    -164 43
    -174 46
    -183 49
    -192 52
    -201 55
    -210 57
    -219 60
    -228 63
    -236 66
    -245 68
    -253 71
    -261 74
    -269 77
    -277 80
    -284 82
    -292 85
    -299 88
    -307 91
    -314 93
    -321 96
    -328 99
    -334 102
    -341 105
    -347 107
    -354 110
    -360 113
    -366 116
    -372 118
    -377 121
    -383 124
    -388 126
    -394 129
    -399 132
    -404 135
    -409 137
    -413 140
    -418 143
    -422 145
    -427 148
    -431 151
    -435 153
    -439 156
    -442 159
    -446 161
    -449 164
    -453 167
    -456 169
    -459 172
    -461 175
    -464 177
    -467 180
    -469 182
    -471 185
    -473 187
    -475 190
    -477 193
    -479 195
    -480 198
    -481 200
    -482 203
    -484 205
    -484 208
    -485 210
    -486 213
    -486 215
    -486 217
    -487 220
    -487 222
    -487 225
    -486 227
    -486 229
    -485 232
    -485 234
    -484 236
    -483 239
    -482 241
    -480 243
    -479 245
    -477 247
    -476 250
    -474 252
    -472 254
    -470 256
    -467 258
    -465 260
    -463 263
    -460 265
    -457 267
    -454 269
    -451 271
    -448 273
    -445 275
    -441 277
    -438 279
    -434 280
    -430 282
    -426 284
    -422 286
    -418 288
    -414 290
    -409 291
    -405 293
    -400 295
    -395 297
    -391 298
    -386 300
    -380 301
    -375 303
    -370 305
    -365 306
    -359 308
    -353 309
    -348 311
    -342 312
    -336 314
    -330 315
    -324 316
    -318 318
    -311 319
    -305 320
    -298 321
    -292 323
    -285 324
    -279 325
    -272 326
    -265 327
    -258 328
    -251 329
    -244 330
    -237 331
    -229 332
    -222 333
    -215 334
    -207 335
    -200 336
    -192 336
    -185 337
    -177 338
    -169 339
    -162 339
    -154 340
    -146 341
    -138 341
    -130 342
    -122 342
    -114 343
    -106 343
    -98 344
    -90 344
    -82 344
    -74 345
    -66 345
    -58 345
    -49 345
    -41 345
    -33 346
    -25 346
    -16 346
    -8 346
    0 346
    8 346
    16 346
    25 346
    33 346
    41 345
    49 345
    58 345
    66 345
    74 345
    82 344
    90 344
    98 344
    106 343
    114 343
    122 342
    130 342
    138 341
    146 341
    154 340
    162 339
    169 339
    177 338
    185 337
    192 336
    200 336
    207 335
    215 334
    222 333
    229 332
    237 331
    244 330
    251 329
    258 328
    265 327
    272 326
    279 325
    285 324
    292 323
    298 321
    305 320
    311 319
    318 318
    324 316
    330 315
    336 314
    342 312
    348 311
    353 309
    359 308
    365 306
    370 305
    375 303
    380 301
    386 300
    391 298
    395 297
    400 295
    405 293
    409 291
    414 290
    418 288
    422 286
    426 284
    430 282
    434 280
    438 279
    441 277
    445 275
    448 273
    451 271
    454 269
    457 267
    460 265
    463 263
    465 260
    467 258
    470 256
    472 254
    474 252
    476 250
    477 247
    479 245
    480 243
    482 241
    483 239
    484 236
    485 234
    485 232
    486 229
    486 227
    487 225
    487 222
    487 220
    486 217
    486 215
    486 213
    485 210
    484 208
    484 205
    482 203
    481 200
    480 198
    479 195
    477 193
    475 190
    473 187
    471 185
    469 182
    467 180
    464 177
    461 175
    459 172
    456 169
    453 167
    449 164
    446 161
    442 159
    439 156
    435 153
    431 151
    427 148
    422 145
    418 143
    413 140
    409 137
    404 135
    399 132
    394 129
    388 126
    383 124
    377 121
    372 118
    366 116
    360 113
    354 110
    347 107
    341 105
    334 102
    328 99
    321 96
    314 93
    307 91
    299 88
    292 85
    284 82
    277 80
    269 77
    261 74
    253 71
    245 68
    236 66
    228 63
    219 60
    210 57
    201 55
    192 52
    183 49
    174 46
    164 43
    155 41
    145 38
    135 35
    125 32
    115 30
    105 27
    95 24
    84 21
    74 18
    63 16
    52 13
    41 10
    30 7
    19 5
    8 2
    -4 -1
    -15 -4
    -27 -6
    -39 -9
    -51 -12
    -63 -15
    -75 -17
    -87 -20
    -100 -23
    -112 -26
    -125 -28
    -137 -31
    -150 -34
    -163 -36
    -176 -39
    -190 -42
    -203 -45
    -216 -47
    -230 -50
    -243 -53
    -257 -55
    -271 -58
    -285 -61
    -299 -63
    -313 -66
    -327 -69
    -342 -71
    -356 -74
    -371 -77
    -385 -79
    -400 -82
    -415 -85
    -430 -87
    -445 -90
    -460 -93
    -476 -95
    -491 -98
    -507 -100
    -522 -103
    -538 -106
    -554 -108
    -569 -111
    -585 -113
    -601 -116
    -618 -118
    -634 -121
    -650 -124
    -667 -126
    -683 -129
    -700 -131
    -716 -134
    -733 -136
    -750 -139
    -767 -141
    -784 -144
    -801 -146
    -819 -149
    -836 -151
    -853 -154
    -871 -156
    -888 -159
    -906 -161
    -924 -164
    -942 -166
    -960 -169
    -978 -171
    980 -176
    962 -173
    944 -171
    926 -168
    909 -166
    891 -163
    873 -160
    856 -158
    838 -155
    821 -153
    804 -150
    787 -148
    770 -145
    753 -143
    736 -140
    719 -137
    702 -135
    686 -132
    669 -130
    653 -127
    636 -124
    620 -122
    604 -119
    588 -117
    572 -114
    556 -111
    540 -109
    525 -106
    509 -103
    494 -101
    478 -98
    463 -95
    448 -93
    433 -90
    418 -87
    403 -85
    388 -82
    373 -79
    359 -76
    344 -74
    330 -71
    316 -68
    302 -66
    288 -63
    274 -60
    260 -57
    246 -55
    232 -52
    219 -49
    206 -46
    192 -44
    179 -41
    166 -38
    153 -35
    140 -32
    128 -30
    115 -27
    102 -24
    90 -21
    78 -18
    66 -16
    54 -13
    42 -10
    30 -7
    18 -4
    7 -2
    -5 1
    -16 4
    -27 7
    -38 10
    -49 12
    -60 15
    -71 18
    -81 21
    -92 24
    -102 27
    -112 29
    -123 32
    -132 35
    -142 38
    -152 41
    -162 44
    -171 47
    -180 49
    -189 52
    -199 55
    -207 58
    -216 61
    -225 64
    -233 66
    -242 69
    -250 72
    -258 75
    -266 78
    -274 81
    -282 83
    -289 86
    -297 89
    -304 92
    -311 95
    -318 98
    -325 100
    -332 103
    -338 106
    -345 109
    -351 112
    -357 115
    -363 117
    -369 120
    -375 123
    -380 126
    -386 129
    -391 131
    -396 134
    -401 137
    -406 140
    -411 142
    -415 145
    -420 148
    -424 151
    -428 153
    -432 156
    -436 159
    -440 162
    -443 164
    -447 167
    -450 170
    -453 172
    -456 175
    -459 178
    -461 180
    -464 183
    -466 186
    -469 188
    -471 191
    -473 194
    -474 196
    -476 199
    -477 201
    -479 204
    -480 206
    -481 209
    -482 211
    -483 214
    -483 216
    -484 219
    -484 221
    -484 224
    -484 226
    -484 229
    -484 231
    -483 234
    -483 236
    -482 238
    -481 241
    -480 243
    -479 245
    -478 248
    -477 250
    -475 252
    -473 254
    -472 257
    -470 259
    -468 261
    -465 263
    -463 265
    -460 268
    -458 270
    -455 272
    -452 274
    -449 276
    -446 278
    -443 280
    -439 282
    -436 284
    -432 286
    -428 288
    -424 290
    -420 292
    -416 293
    -412 295
    -408 297
    -403 299
    -398 301
    -394 302
    -389 304
    -384 306
    -379 307
    -374 309
    -368 311
    -363 312
    -357 314
    -352 315
    -346 317
    -340 318
    -335 320
    -329 321
    -322 322
    -316 324
    -310 325
    -304 326
    -297 328
    -291 329
    -284 330
    -277 331
    -271 332
    -264 334
    -257 335
    -250 336
    -243 337
    -236 338
    -228 339
    -221 340
    -214 341
    -206 341
    -199 342
    -191 343
    -184 344
    -176 345
    -169 345
    -161 346
    -153 347
    -145 347
    -138 348
    -130 348
    -122 349
    -114 349
    -106 350
    -98 350
    -90 351
    -82 351
    -74 351
    -65 352
    -57 352
    -49 352
    -41 352
    -33 352
    -25 353
    -16 353
    -8 353
    0 353
    8 353
    16 353
    25 353
    33 352
    41 352
    49 352
    57 352
    65 352
    74 351
    82 351
    90 351
    98 350
    106 350
    114 349
    122 349
    130 348
    138 348
    145 347
    153 347
    161 346
    169 345
    176 345
    184 344
    191 343
    199 342
    206 341
    214 341
    221 340
    228 339
    236 338
    243 337
    250 336
    257 335
    264 334
    271 332
    277 331
    284 330
    291 329
    297 328
    304 326
    310 325
    316 324
    322 322
    329 321
    335 320
    340 318
    346 317
    352 315
    357 314
    363 312
    368 311
    374 309
    379 307
    384 306
    389 304
    394 302
    398 301
    403 299
    408 297
    412 295
    416 293
    420 292
    424 290
    428 288
    432 286
    436 284
    439 282
    443 280
    446 278
    449 276
    452 274
    455 272
    458 270
    460 268
    463 265
    465 263
    468 261
    470 259
    472 257
    473 254
    475 252
    477 250
    478 248
    479 245
    480 243
    481 241
    482 238
    483 236
    483 234
    484 231
    484 229
    484 226
    484 224
    484 221
    484 219
    483 216
    483 214
    482 211
    481 209
    480 206
    479 204
    477 201
    476 199
    474 196
    473 194
    471 191
    469 188
    466 186
    464 183
    461 180
    459 178
    456 175
    453 172
    450 170
    447 167
    443 164
    440 162
    436 159
    432 156
    428 153
    424 151
    420 148
    415 145
    411 142
    406 140
    401 137
    396 134
    391 131
    386 129
    380 126
    375 123
    369 120
    363 117
    357 115
    351 112
    345 109
    338 106
    332 103
    325 100
    318 98
    311 95
    304 92
    297 89
    289 86
    282 83
    274 81
    266 78
    258 75
    250 72
    242 69
    233 66
    225 64
    216 61
    207 58
    199 55
    189 52
    180 49
    171 47
    162 44
    152 41
    142 38
    132 35
    123 32
    112 29
    102 27
    92 24
    81 21
    71 18
    60 15
    49 12
    38 10
    27 7
    16 4
    5 1
    -7 -2
    -18 -4
    -30 -7
    -42 -10
    -54 -13
    -66 -16
    -78 -18
    -90 -21
    -102 -24
    -115 -27
    -128 -30
    -140 -32
    -153 -35
    -166 -38
    -179 -41
    -192 -44
    -206 -46
    -219 -49
    -232 -52
    -246 -55
    -260 -57
    -274 -60
    -288 -63
    -302 -66
    -316 -68
    -330 -71
    -344 -74
    -359 -76
    -373 -79
    -388 -82
    -403 -85
    -418 -87
    -433 -90
    -448 -93
    -463 -95
    -478 -98
    -494 -101
    -509 -103
    -525 -106
    -540 -109
    -556 -111
    -572 -114
    -588 -117
    -604 -119
    -620 -122
    -636 -124
    -653 -127
    -669 -130
    -686 -132
    -702 -135
    -719 -137
    -736 -140
    -753 -143
    -770 -145
    -787 -148
    -804 -150
    -821 -153
    -838 -155
    -856 -158
    -873 -160
    -891 -163
    -909 -166
    -926 -168
    -944 -171
    -962 -173
    -980 -176
    983 -180
    965 -178
    947 -175
    929 -172
    911 -170
    893 -167
    876 -165
    858 -162
    841 -159
    824 -157
    806 -154
    789 -152
    772 -149
    755 -146
    738 -144
    722 -141
    705 -138
    688 -136
    672 -133
    655 -130
    639 -128
    623 -125
    607 -122
    591 -120
    575 -117
    559 -114
    543 -112
    527 -109
    512 -106
    496 -104
    481 -101
    466 -98
    451 -95
    436 -93
    421 -90
    406 -87
    391 -84
    376 -82
    362 -79
    347 -76
    333 -73
    319 -70
    304 -68
    290 -65
    276 -62
    263 -59
    249 -56
    235 -54
    222 -51
    208 -48
    195 -45
    182 -42
    169 -40
    156 -37
    143 -34
    130 -31
    118 -28
    105 -25
    93 -22
    81 -20
    68 -17
    56 -14
    44 -11
    33 -8
    21 -5
    9 -2
    -2 1
    -13 3
    -24 6
    -36 9
    -47 12
    -57 15
    -68 18
    -79 21
    -89 24
    -99 27
    -110 29
    -120 32
    -130 35
    -139 38
    -149 41
    -159 44
    -168 47
    -177 50
    -187 53
    -196 56
    -205 58
    -213 61
    -222 64
    -230 67
    -239 70
    -247 73
    -255 76
    -263 79
    -271 82
    -279 85
    -286 87
    -294 90
    -301 93
    -308 96
    -315 99
    -322 102
    -329 105
    -335 108
    -342 111
    -348 113
    -354 116
    -360 119
    -366 122
    -372 125
    -377 128
    -383 131
    -388 133
    -393 136
    -398 139
    -403 142
    -408 145
    -413 148
    -417 150
    -421 153
    -425 156
    -429 159
    -433 162
    -437 164
    -440 167
    -444 170
    -447 173
    -450 175
    -453 178
    -456 181
    -459 183
    -461 186
    -464 189
    -466 192
    -468 194
    -470 197
    -472 200
    -473 202
    -475 205
    -476 207
    -477 210
    -478 213
    -479 215
    -480 218
    -481 220
    -481 223
    -482 225
    -482 228
    -482 230
    -482 233
    -481 235
    -481 238
    -480 240
    -480 243
    -479 245
    -478 247
    -477 250
    -476 252
    -474 255
    -473 257
    -471 259
    -469 261
    -467 264
    -465 266
    -463 268
    -461 270
    -458 273
    -456 275
    -453 277
    -450 279
    -447 281
    -444 283
    -441 285
    -437 287
    -434 289
    -430 291
    -426 293
    -422 295
    -418 297
    -414 299
    -410 301
    -406 303
    -401 304
    -397 306
    -392 308
    -387 310
    -382 311
    -377 313
    -372 315
    -367 316
    -361 318
    -356 320
    -350 321
    -345 323
    -339 324
    -333 326
    -327 327
    -321 329
    -315 330
    -309 331
    -302 333
    -296 334
    -289 335
    -283 336
    -276 338
    -269 339
    -263 340
    -256 341
    -249 342
    -242 343
    -235 344
    -227 345
    -220 346
    -213 347
    -206 348
    -198 349
    -191 350
    -183 350
    -176 351
    -168 352
    -160 353
    -153 353
    -145 354
    -137 354
    -129 355
    -121 356
    -113 356
    -105 357
    -97 357
    -89 357
    -81 358
    -73 358
    -65 358
    -57 359
    -49 359
    -41 359
    -33 359
    -24 359
    -16 359
    -8 359
    0 359
    8 359
    16 359
    24 359
    33 359
    41 359
    49 359
    57 359
    65 358
    73 358
    81 358
    89 357
    97 357
    105 357
    113 356
    121 356
    129 355
    137 354
    145 354
    153 353
    160 353
    168 352
    176 351
    183 350
    191 350
    198 349
    206 348
    213 347
    220 346
    227 345
    235 344
    242 343
    249 342
    256 341
    263 340
    269 339
    276 338
    283 336
    289 335
    296 334
    302 333
    309 331
    315 330
    321 329
    327 327
    333 326
    339 324
    345 323
    350 321
    356 320
    361 318
    367 316
    372 315
    377 313
    382 311
    387 310
    392 308
    397 306
    401 304
    406 303
    410 301
    414 299
    418 297
    422 295
    426 293
    430 291
    434 289
    437 287
    441 285
    444 283
    447 281
    450 279
    453 277
    456 275
    458 273
    461 270
    463 268
    465 266
    467 264
    469 261
    471 259
    473 257
    474 255
    476 252
    477 250
    478 247
    479 245
    480 243
    480 240
    481 238
    481 235
    482 233
    482 230
    482 228
    482 225
    481 223
    481 220
    480 218
    479 215
    478 213
    477 210
    476 207
    475 205
    473 202
    472 200
    470 197
    468 194
    466 192
    464 189
    461 186
    459 183
    456 181
    453 178
    450 175
    447 173
    444 170
    440 167
    437 164
    433 162
    429 159
    425 156
    421 153
    417 150
    413 148
    408 145
    403 142
    398 139
    393 136
    388 133
    383 131
    377 128
    372 125
    366 122
    360 119
    354 116
    348 113
    342 111
    335 108
    329 105
    322 102
    315 99
    308 96
    301 93
    294 90
    286 87
    279 85
    271 82
    263 79
    255 76
    247 73
    239 70
    230 67
    222 64
    213 61
    205 58
    196 56
    187 53
    177 50
    168 47
    159 44
    149 41
    139 38
    130 35
    120 32
    110 29
    99 27
    89 24
    79 21
    68 18
    57 15
    47 12
    36 9
    24 6
    13 3
    2 1
    -9 -2
    -21 -5
    -33 -8
    -44 -11
    -56 -14
    -68 -17
    -81 -20
    -93 -22
    -105 -25
    -118 -28
    -130 -31
    -143 -34
    -156 -37
    -169 -40
    -182 -42
    -195 -45
    -208 -48
    -222 -51
    -235 -54
    -249 -56
    -263 -59
    -276 -62
    -290 -65
    -304 -68
    -319 -70
    -333 -73
    -347 -76
    -362 -79
    -376 -82
    -391 -84
    -406 -87
    -421 -90
    -436 -93
    -451 -95
    -466 -98
    -481 -101
    -496 -104
    -512 -106
    -527 -109
    -543 -112
    -559 -114
    -575 -117
    -591 -120
    -607 -122
    -623 -125
    -639 -128
    -655 -130
    -672 -133
    -688 -136
    -705 -138
    -722 -141
    -738 -144
    -755 -146
    -772 -149
    -789 -152
    -806 -154
    -824 -157
    -841 -159
    -858 -162
    -876 -165
    -893 -167
    -911 -170
    -929 -172
    -947 -175
    -965 -178
    -983 -180
    985 -185
    967 -182
    949 -179
    931 -177
    914 -174
    896 -172
    878 -169
    861 -166
    844 -164
    826 -161
    809 -158
    792 -156
    775 -153
    758 -150
    741 -148
    724 -145
    708 -142
    691 -139
    675 -137
    658 -134
    642 -131
    626 -129
    609 -126
    593 -123
    577 -120
    562 -118
    546 -115
    530 -112
    515 -109
    499 -106
    484 -104
    469 -101
    453 -98
    438 -95
    423 -92
    408 -90
    394 -87
    379 -84
    364 -81
    350 -78
    336 -76
    321 -73
    307 -70
    293 -67
    279 -64
    265 -61
    252 -58
    238 -56
    225 -53
    211 -50
    198 -47
    185 -44
    172 -41
    159 -38
    146 -35
    133 -32
    121 -29
    108 -27
    96 -24
    83 -21
    71 -18
    59 -15
    47 -12
    36 -9
    24 -6
    12 -3
    1 -0
    -10 3
    -22 6
    -33 9
    -44 12
    -54 14
    -65 17
    -76 20
    -86 23
    -96 26
    -107 29
    -117 32
    -127 35
    -137 38
    -146 41
    -156 44
    -165 47
    -174 50
    -184 53
    -193 56
    -202 59
    -210 62
    -219 65
    -228 68
    -236 71
    -244 74
    -252 77
    -260 80
    -268 83
    -276 86
    -283 89
    -291 91
    -298 94
    -305 97
    -312 100
    -319 103
    -326 106
    -332 109
    -339 112
    -345 115
    -351 118
    -357 121
    -363 124
    -369 127
    -375 130
    -380 133
    -385 135
    -390 138
    -395 141
    -400 144
    -405 147
    -410 150
    -414 153
    -418 156
    -423 158
    -427 161
    -430 164
    -434 167
    -438 170
    -441 173
    -444 175
    -448 178
    -450 181
    -453 184
    -456 187
    -459 189
    -461 192
    -463 195
    -465 198
    -467 200
    -469 203
    -471 206
    -472 208
    -474 211
    -475 214
    -476 216
    -477 219
    -478 222
    -478 224
    -479 227
    -479 229
    -479 232
    -479 234
    -479 237
    -479 239
    -479 242
    -478 244
    -477 247
    -477 249
    -476 252
    -475 254
    -473 257
    -472 259
    -470 261
    -469 264
    -467 266
    -465 268
    -463 271
    -461 273
    -459 275
    -456 277
    -454 280
    -451 282
    -448 284
    -445 286
    -442 288
    -439 290
    -435 292
    -432 294
    -428 296
    -424 298
    -421 300
    -417 302
    -412 304
    -408 306
    -404 308
    -399 310
    -395 312
    -390 314
    -385 315
    -380 317
    -375 319
    -370 320
    -365 322
    -360 324
    -354 325
    -349 327
    -343 329
    -337 330
    -332 332
    -326 333
    -320 335
    -314 336
    -307 337
    -301 339
    -295 340
    -288 341
    -282 343
    -275 344
    -268 345
    -262 346
    -255 347
    -248 348
    -241 349
    -234 350
    -227 351
    -219 352
    -212 353
    -205 354
    -197 355
    -190 356
    -182 357
    -175 358
    -167 358
    -160 359
    -152 360
    -144 360
    -136 361
    -129 362
    -121 362
    -113 363
    -105 363
    -97 364
    -89 364
    -81 364
    -73 365
    -65 365
    -57 365
    -49 365
    -41 366
    -33 366
    -24 366
    -16 366
    -8 366
    0 366
    8 366
    16 366
    24 366
    33 366
    41 366
    49 365
    57 365
    65 365
    73 365
    81 364
    89 364
    97 364
    105 363
    113 363
    121 362
    129 362
    136 361
    144 360
    152 360
    160 359
    167 358
    175 358
    182 357
    190 356
    197 355
    205 354
    212 353
    219 352
    227 351
    234 350
    241 349
    248 348
    255 347
    262 346
    268 345
    275 344
    282 343
    288 341
    295 340
    301 339
    307 337
    314 336
    320 335
    326 333
    332 332
    337 330
    343 329
    349 327
    354 325
    360 324
    365 322
    370 320
    375 319
    380 317
    385 315
    390 314
    395 312
    399 310
    404 308
    408 306
    412 304
    417 302
    421 300
    424 298
    428 296
    432 294
    435 292
    439 290
    442 288
    445 286
    448 284
    451 282
    454 280
    456 277
    459 275
    461 273
    463 271
    465 268
    467 266
    469 264
    470 261
    472 259
    473 257
    475 254
    476 252
    477 249
    477 247
    478 244
    479 242
    479 239
    479 237
    479 234
    479 232
    479 229
    479 227
    478 224
    478 222
    477 219
    476 216
    475 214
    474 211
    472 208
    471 206
    469 203
    467 200
    465 198
    463 195
    461 192
    459 189
    456 187
    453 184
    450 181
    448 178
    444 175
    441 173
    438 170
    434 167
    430 164
    427 161
    423 158
    418 156
    414 153
    410 150
    405 147
    400 144
    395 141
    390 138
    385 135
    380 133
    375 130
    369 127
    363 124
    357 121
    351 118
    345 115
    339 112
    332 109
    326 106
    319 103
    312 100
    305 97
    298 94
    291 91
    283 89
    276 86
    268 83
    260 80
    252 77
    244 74
    236 71
    228 68
    219 65
    210 62
    202 59
    193 56
    184 53
    174 50
    165 47
    156 44
    146 41
    137 38
    127 35
    117 32
    107 29
    96 26
    86 23
    76 20
    65 17
    54 14
    44 12
    33 9
    22 6
    10 3
    -1 -0
    -12 -3
    -24 -6
    -36 -9
    -47 -12
    -59 -15
    -71 -18
    -83 -21
    -96 -24
    -108 -27
    -121 -29
    -133 -32
    -146 -35
    -159 -38
    -172 -41
    -185 -44
    -198 -47
    -211 -50
    -225 -53
    -238 -56
    -252 -58
    -265 -61
    -279 -64
    -293 -67
    -307 -70
    -321 -73
    -336 -76
    -350 -78
    -364 -81
    -379 -84
    -394 -87
    -408 -90
    -423 -92
    -438 -95
    -453 -98
    -469 -101
    -484 -104
    -499 -106
    -515 -109
    -530 -112
    -546 -115
    -562 -118
    -577 -120
    -593 -123
    -609 -126
    -626 -129
    -642 -131
    -658 -134
    -675 -137
    -691 -139
    -708 -142
    -724 -145
    -741 -148
    -758 -150
    -775 -153
    -792 -156
    -809 -158
    -826 -161
    -844 -164
    -861 -166
    -878 -169
    -896 -172
    -914 -174
    -931 -177
    -949 -179
    -967 -182
    -985 -185
    988 -189
    970 -187
    952 -184
    934 -181
    916 -179
    899 -176
    881 -173
    864 -171
    846 -168
    829 -165
    812 -162
    795 -160
    778 -157
    761 -154
    744 -151
    727 -149
    710 -146
    694 -143
    677 -140
    661 -138
    645 -135
    628 -132
    612 -129
    596 -126
    580 -124
    564 -121
    549 -118
    533 -115
    517 -112
    502 -109
    487 -107
    471 -104
    456 -101
    441 -98
    426 -95
    411 -92
    397 -89
    382 -87
    367 -84
    353 -81
    339 -78
    324 -75
    310 -72
    296 -69
    282 -66
    268 -63
    255 -60
    241 -57
    228 -55
    214 -52
    201 -49
    188 -46
    175 -43
    162 -40
    149 -37
    136 -34
    124 -31
    111 -28
    99 -25
    86 -22
    74 -19
    62 -16
    50 -13
    39 -10
    27 -7
    15 -4
    4 -1
    -7 2
    -19 5
    -30 8
    -41 11
    -51 14
    -62 17
    -73 20
    -83 23
    -93 26
    -104 29
    -114 32
    -124 35
    -134 38
    -143 41
    -153 44
    -162 47
    -172 50
    -181 53
    -190 56
    -199 59
    -207 62
    -216 65
    -225 68
    -233 71
    -241 74
    -249 77
    -257 80
    -265 84
    -273 87
    -280 90
    -288 93
    -295 96
    -302 99
    -309 102
    -316 105
    -323 108
    -329 111
    -336 114
    -342 117
    -348 120
    -354 123
    -360 126
    -366 129
    -372 131
    -377 134
    -382 137
    -388 140
    -393 143
    -397 146
    -402 149
    -407 152
    -411 155
    -416 158
    -420 161
    -424 164
    -428 167
    -431 170
    -435 172
    -438 175
    -442 178
    -445 181
    -448 184
    -451 187
    -453 190
    -456 192
    -458 195
    -460 198
    -463 201
    -464 203
    -466 206
    -468 209
    -469 212
    -471 214
    -472 217
    -473 220
    -474 223
    -475 225
    -476 228
    -476 231
    -476 233
    -477 236
    -477 238
    -477 241
    -476 243
    -476 246
    -476 249
    -475 251
    -474 254
    -473 256
    -472 259
    -471 261
    -470 263
    -468 266
    -466 268
    -465 271
    -463 273
    -461 275
    -459 278
    -456 280
    -454 282
    -451 284
    -449 287
    -446 289
    -443 291
    -440 293
    -437 295
    -433 297
    -430 299
    -426 302
    -422 304
    -419 306
    -415 308
    -411 310
    -406 312
    -402 313
    -398 315
    -393 317
    -388 319
    -384 321
    -379 323
    -374 324
    -369 326
    -363 328
    -358 329
    -353 331
    -347 333
    -342 334
    -336 336
    -330 337
    -324 339
    -318 340
    -312 342
    -306 343
    -300 345
    -293 346
    -287 347
    -280 349
    -274 350
    -267 351
    -260 352
    -254 353
    -247 355
    -240 356
    -233 357
    -226 358
    -218 359
    -211 360
    -204 361
    -196 361
    -189 362
    -182 363
    -174 364
    -166 365
    -159 365
    -151 366
    -144 367
    -136 367
    -128 368
    -120 369
    -112 369
    -104 370
    -97 370
    -89 370
    -81 371
    -73 371
    -65 371
    -57 372
    -49 372
    -40 372
    -32 372
    -24 372
    -16 372
    -8 373
    0 373
    8 373
    16 372
    24 372
    32 372
    40 372
    49 372
    57 372
    65 371
    73 371
    81 371
    89 370
    97 370
    104 370
    112 369
    120 369
    128 368
    136 367
    144 367
    151 366
    159 365
    166 365
    174 364
    182 363
    189 362
    196 361
    204 361
    211 360
    218 359
    226 358
    233 357
    240 356
    247 355
    254 353
    260 352
    267 351
    274 350
    280 349
    287 347
    293 346
    300 345
    306 343
    312 342
    318 340
    324 339
    330 337
    336 336
    342 334
    347 333
    353 331
    358 329
    363 328
    369 326
    374 324
    379 323
    384 321
    388 319
    393 317
    398 315
    402 313
    406 312
    411 310
    415 308
    419 306
    422 304
    426 302
    430 299
    433 297
    437 295
    440 293
    443 291
    446 289
    449 287
    451 284
    454 282
    456 280
    459 278
    461 275
    463 273
    465 271
    466 268
    468 266
    470 263
    471 261
    472 259
    473 256
    474 254
    475 251
    476 249
    476 246
    476 243
    477 241
    477 238
    477 236
    476 233
    476 231
    476 228
    475 225
    474 223
    473 220
    472 217
    471 214
    469 212
    468 209
    466 206
    464 203
    463 201
    460 198
    458 195
    456 192
    453 190
    451 187
    448 184
    445 181
    442 178
    438 175
    435 172
    431 170
    428 167
    424 164
    420 161
    416 158
    411 155
    407 152
    402 149
    397 146
    393 143
    388 140
    382 137
    377 134
    372 131
    366 129
    360 126
    354 123
    348 120
    342 117
    336 114
    329 111
    323 108
    316 105
    309 102
    302 99
    295 96
    288 93
    280 90
    273 87
    265 84
    257 80
    249 77
    241 74
    233 71
    225 68
    216 65
    207 62
    199 59
    190 56
    181 53
    172 50
    162 47
    153 44
    143 41
    134 38
    124 35
    114 32
    104 29
    93 26
    83 23
    73 20
    62 17
    51 14
    41 11
    30 8
    19 5
    7 2
    -4 -1
    -15 -4
    -27 -7
    -39 -10
    -50 -13
    -62 -16
    -74 -19
    -86 -22
    -99 -25
    -111 -28
    -124 -31
    -136 -34
    -149 -37
    -162 -40
    -175 -43
    -188 -46
    -201 -49
    -214 -52
    -228 -55
    -241 -57
    -255 -60
    -268 -63
    -282 -66
    -296 -69
    -310 -72
    -324 -75
    -339 -78
    -353 -81
    -367 -84
    -382 -87
    -397 -89
    -411 -92
    -426 -95
    -441 -98
    -456 -101
    -471 -104
    -487 -107
    -502 -109
    -517 -112
    -533 -115
    -549 -118
    -564 -121
    -580 -124
    -596 -126
    -612 -129
    -628 -132
    -645 -135
    -661 -138
    -677 -140
    -694 -143
    -710 -146
    -727 -149
    -744 -151
    -761 -154
    -778 -157
    -795 -160
    -812 -162
    -829 -165
    -846 -168
    -864 -171
    -881 -173
    -899 -176
    -916 -179
    -934 -181
    -952 -184
    -970 -187
    -988 -189
    990 -194
    972 -191
    955 -189
    937 -186
    919 -183
    901 -180
    884 -178
    866 -175
    849 -172
    832 -169
    815 -166
    797 -164
    780 -161
    763 -158
    747 -155
    730 -152
    713 -150
    697 -147
    680 -144
    664 -141
    647 -138
    631 -135
    615 -133
    599 -130
    583 -127
    567 -124
    552 -121
    536 -118
    520 -115
    505 -112
    489 -110
    474 -107
    459 -104
    444 -101
    429 -98
    414 -95
    399 -92
    385 -89
    370 -86
    356 -83
    341 -80
    327 -77
    313 -74
    299 -71
    285 -68
    271 -65
    258 -62
    244 -59
    230 -56
    217 -53
    204 -50
    191 -47
    178 -44
    165 -41
    152 -38
    139 -35
    127 -32
    114 -29
    102 -26
    89 -23
    77 -20
    65 -17
    53 -14
    42 -11
    30 -8
    18 -5
    7 -2
    -4 1
    -16 4
    -27 7
    -38 10
    -48 13
    -59 17
    -70 20
    -80 23
    -90 26
    -101 29
    -111 32
    -121 35
    -130 38
    -140 41
    -150 44
    -159 47
    -168 50
    -178 54
    -187 57
    -196 60
    -204 63
    -213 66
    -221 69
    -230 72
    -238 75
    -246 78
    -254 81
    -262 84
    -270 87
    -277 91
    -285 94
    -292 97
    -299 100
    -306 103
    -313 106
    -320 109
    -326 112
    -333 115
    -339 118
    -345 121
    -351 124
    -357 127
    -363 130
    -369 133
    -374 136
    -379 139
    -385 142
    -390 145
    -394 148
    -399 151
    -404 154
    -408 157
    -413 160
    -417 163
    -421 166
    -425 169
    -428 172
    -432 175
    -435 178
    -439 181
    -442 184
    -445 187
    -448 190
    -450 192
    -453 195
    -455 198
    -458 201
    -460 204
    -462 207
    -464 209
    -465 212
    -467 215
    -468 218
    -469 221
    -470 223
    -471 226
    -472 229
    -473 232
    -473 234
    -474 237
    -474 240
    -474 242
    -474 245
    -474 247
    -473 250
    -473 253
    -472 255
    -472 258
    -471 260
    -470 263
    -468 265
    -467 268
    -466 270
    -464 273
    -462 275
    -460 277
    -458 280
    -456 282
    -454 285
    -452 287
    -449 289
    -446 291
    -444 294
    -441 296
    -438 298
    -434 300
    -431 302
    -428 305
    -424 307
    -420 309
    -417 311
    -413 313
    -409 315
    -404 317
    -400 319
    -396 321
    -391 323
    -387 324
    -382 326
    -377 328
    -372 330
    -367 332
    -362 333
    -356 335
    -351 337
    -346 338
    -340 340
    -334 342
    -329 343
    -323 345
    -317 346
    -311 348
    -305 349
    -298 351
    -292 352
    -286 353
    -279 355
    -273 356
    -266 357
    -259 358
    -252 359
    -246 361
    -239 362
    -232 363
    -224 364
    -217 365
    -210 366
    -203 367
    -196 368
    -188 369
    -181 369
    -173 370
    -166 371
    -158 372
    -151 372
    -143 373
    -135 374
    -127 374
    -120 375
    -112 375
    -104 376
    -96 376
    -88 377
    -80 377
    -72 377
    -64 378
    -56 378
    -48 378
    -40 378
    -32 379
    -24 379
    -16 379
    -8 379
    0 379
    8 379
    16 379
    24 379
    32 379
    40 378
    48 378
    56 378
    64 378
    72 377
    80 377
    88 377
    96 376
    104 376
    112 375
    120 375
    127 374
    135 374
    143 373
    151 372
    158 372
    166 371
    173 370
    181 369
    188 369
    196 368
    203 367
    210 366
    217 365
    224 364
    232 363
    239 362
    246 361
    252 359
    259 358
    266 357
    273 356
    279 355
    286 353
    292 352
    298 351
    305 349
    311 348
    317 346
    323 345
    329 343
    334 342
    340 340
    346 338
    351 337
    356 335
    362 333
    367 332
    372 330
    377 328
    382 326
    387 324
    391 323
    396 321
    400 319
    404 317
    409 315
    413 313
    417 311
    420 309
    424 307
    428 305
    431 302
    434 300
    438 298
    441 296
    444 294
    446 291
    449 289
    452 287
    454 285
    456 282
    458 280
    460 277
    462 275
    464 273
    466 270
    467 268
    468 265
    470 263
    471 260
    472 258
    472 255
    473 253
    473 250
    474 247
    474 245
    474 242
    474 240
    474 237
    473 234
    473 232
    472 229
    471 226
    470 223
    469 221
    468 218
    467 215
    465 212
    464 209
    462 207
    460 204
    458 201
    455 198
    453 195
    450 192
    448 190
    445 187
    442 184
    439 181
    435 178
    432 175
    428 172
    425 169
    421 166
    417 163
    413 160
    408 157
    404 154
    399 151
    394 148
    390 145
    385 142
    379 139
    374 136
    369 133
    363 130
    357 127
    351 124
    345 121
    339 118
    333 115
    326 112
    320 109
    313 106
    306 103
    299 100
    292 97
    285 94
    277 91
    270 87
    262 84
    254 81
    246 78
    238 75
    230 72
    221 69
    213 66
    204 63
    196 60
    187 57
    178 54
    168 50
    159 47
    150 44
    140 41
    130 38
    121 35
    111 32
    101 29
    90 26
    80 23
    70 20
    59 17
    48 13
    38 10
    27 7
    16 4
    4 1
    -7 -2
    -18 -5
    -30 -8
    -42 -11
    -53 -14
    -65 -17
    -77 -20
    -89 -23
    -102 -26
    -114 -29
    -127 -32
    -139 -35
    -152 -38
    -165 -41
    -178 -44
    -191 -47
    -204 -50
    -217 -53
    -230 -56
    -244 -59
    -258 -62
    -271 -65
    -285 -68
    -299 -71
    -313 -74
    -327 -77
    -341 -80
    -356 -83
    -370 -86
    -385 -89
    -399 -92
    -414 -95
    -429 -98
    -444 -101
    -459 -104
    -474 -107
    -489 -110
    -505 -112
    -520 -115
    -536 -118
    -552 -121
    -567 -124
    -583 -127
    -599 -130
    -615 -133
    -631 -135
    -647 -138
    -664 -141
    -680 -144
    -697 -147
    -713 -150
    -730 -152
    -747 -155
    -763 -158
    -780 -161
    -797 -164
    -815 -166
    -832 -169
    -849 -172
    -866 -175
    -884 -178
    -901 -180
    -919 -183
    -937 -186
    -955 -189
    -972 -191
    -990 -194
    993 -199
    975 -196
    957 -193
    940 -190
    922 -187
    904 -185
    887 -182
    869 -179
    852 -176
    835 -173
    817 -171
    800 -168
    783 -165
    766 -162
    749 -159
    733 -156
    716 -153
    699 -151
    683 -148
    667 -145
    650 -142
    634 -139
    618 -136
    602 -133
    586 -130
    570 -127
    554 -124
    539 -121
    523 -118
    508 -116
    492 -113
    477 -110
    462 -107
    447 -104
    432 -101
    417 -98
    402 -95
    388 -92
    373 -89
    359 -86
    344 -83
    330 -80
    316 -77
    302 -74
    288 -71
    274 -68
    261 -64
    247 -61
    234 -58
    220 -55
    207 -52
    194 -49
    181 -46
    168 -43
    155 -40
    142 -37
    130 -34
    117 -31
    105 -28
    92 -25
    80 -21
    68 -18
    56 -15
    45 -12
    33 -9
    21 -6
    10 -3
    -1 0
    -12 3
    -24 7
    -34 10
    -45 13
    -56 16
    -67 19
    -77 22
    -87 25
    -98 29
    -108 32
    -118 35
    -127 38
    -137 41
    -147 44
    -156 47
    -165 51
    -174 54
    -184 57
    -192 60
    -201 63
    -210 66
    -218 69
    -227 73
    -235 76
    -243 79
    -251 82
    -259 85
    -267 88
    -274 91
    -282 95
    -289 98
    -296 101
    -303 104
    -310 107
    -317 110
    -323 113
    -330 116
    -336 119
    -342 123
    -348 126
    -354 129
    -360 132
    -366 135
    -371 138
    -376 141
    -382 144
    -387 147
    -391 150
    -396 153
    -401 156
    -405 159
    -410 162
    -414 166
    -418 169
    -422 172
    -425 175
    -429 178
    -432 180
    -436 183
    -439 186
    -442 189
    -445 192
    -447 195
    -450 198
    -452 201
    -455 204
    -457 207
    -459 210
    -461 213
    -462 215
    -464 218
    -465 221
    -467 224
    -468 227
    -469 230
    -469 232
    -470 235
    -471 238
    -471 241
    -471 243
    -471 246
    -471 249
    -471 251
    -471 254
    -470 257
    -470 259
    -469 262
    -468 264
    -467 267
    -466 269
    -465 272
    -463 274
    -462 277
    -460 279
    -458 282
    -456 284
    -454 287
    -452 289
    -449 291
    -447 294
    -444 296
    -441 298
    -438 301
    -435 303
    -432 305
    -429 307
    -425 309
    -422 312
    -418 314
    -414 316
    -411 318
    -407 320
    -402 322
    -398 324
    -394 326
    -389 328
    -385 330
    -380 332
    -375 333
    -370 335
    -365 337
    -360 339
    -355 341
    -349 342
    -344 344
    -338 346
    -333 347
    -327 349
    -321 350
    -315 352
    -309 353
    -303 355
    -297 356
    -291 358
    -284 359
    -278 360
    -271 362
    -265 363
    -258 364
    -251 365
    -244 367
    -237 368
    -230 369
    -223 370
    -216 371
    -209 372
    -202 373
    -195 374
    -187 375
    -180 376
    -172 376
    -165 377
    -157 378
    -150 379
    -142 379
    -135 380
    -127 381
    -119 381
    -111 382
    -103 382
    -96 383
    -88 383
    -80 383
    -72 384
    -64 384
    -56 384
    -48 385
    -40 385
    -32 385
    -24 385
    -16 385
    -8 385
    0 385
    8 385
    16 385
    24 385
    32 385
    40 385
    48 385
    56 384
    64 384
    72 384
    80 383
    88 383
    96 383
    103 382
    111 382
    119 381
    127 381
    135 380
    142 379
    150 379
    157 378
    165 377
    172 376
    180 376
    187 375
    195 374
    202 373
    209 372
    216 371
    223 370
    230 369
    237 368
    244 367
    251 365
    258 364
    265 363
    271 362
    278 360
    284 359
    291 358
    297 356
    303 355
    309 353
    315 352
    321 350
    327 349
    333 347
    338 346
    344 344
    349 342
    355 341
    360 339
    365 337
    370 335
    375 333
    380 332
    385 330
    389 328
    394 326
    398 324
    402 322
    407 320
    411 318
    414 316
    418 314
    422 312
    425 309
    429 307
    432 305
    435 303
    438 301
    441 298
    444 296
    447 294
    449 291
    452 289
    454 287
    456 284
    458 282
    460 279
    462 277
    463 274
    465 272
    466 269
    467 267
    468 264
    469 262
    470 259
    470 257
    471 254
    471 251
    471 249
    471 246
    471 243
    471 241
    471 238
    470 235
    469 232
    469 230
    468 227
    467 224
    465 221
    464 218
    462 215
    461 213
    459 210
    457 207
    455 204
    452 201
    450 198
    447 195
    445 192
    442 189
    439 186
    436 183
    432 180
    429 178
    425 175
    422 172
    418 169
    414 166
    410 162
    405 159
    401 156
    396 153
    391 150
    387 147
    382 144
    376 141
    371 138
    366 135
    360 132
    354 129
    348 126
    342 123
    336 119
    330 116
    323 113
    317 110
    310 107
    303 104
    296 101
    289 98
    282 95
    274 91
    267 88
    259 85
    251 82
    243 79
    235 76
    227 73
    218 69
    210 66
    201 63
    192 60
    184 57
    174 54
    165 51
    156 47
    147 44
    137 41
    127 38
    118 35
    108 32
    98 29
    87 25
    77 22
    67 19
    56 16
    45 13
    34 10
    24 7
    12 3
    1 0
    -10 -3
    -21 -6
    -33 -9
    -45 -12
    -56 -15
    -68 -18
    -80 -21
    -92 -25
    -105 -28
    -117 -31
    -130 -34
    -142 -37
    -155 -40
    -168 -43
    -181 -46
    -194 -49
    -207 -52
    -220 -55
    -234 -58
    -247 -61
    -261 -64
    -274 -68
    -288 -71
    -302 -74
    -316 -77
    -330 -80
    -344 -83
    -359 -86
    -373 -89
    -388 -92
    -402 -95
    -417 -98
    -432 -101
    -447 -104
    -462 -107
    -477 -110
    -492 -113
    -508 -116
    -523 -118
    -539 -121
    -554 -124
    -570 -127
    -586 -130
    -602 -133
    -618 -136
    -634 -139
    -650 -142
    -667 -145
    -683 -148
    -699 -151
    -716 -153
    -733 -156
    -749 -159
    -766 -162
    -783 -165
    -800 -168
    -817 -171
    -835 -173
    -852 -176
    -869 -179
    -887 -182
    -904 -185
    -922 -187
    -940 -190
    -957 -193
    -975 -196
    -993 -199
    996 -203
    978 -201
    960 -198
    942 -195
    925 -192
    907 -189
    890 -186
    872 -183
    855 -181
    837 -178
    820 -175
    803 -172
    786 -169
    769 -166
    752 -163
    736 -160
    719 -157
    702 -154
    686 -151
    669 -148
    653 -145
    637 -143
    621 -140
    605 -137
    589 -134
    573 -131
    557 -128
    542 -125
    526 -122
    511 -119
    495 -116
    480 -113
    465 -110
    450 -107
    435 -103
    420 -100
    405 -97
    391 -94
    376 -91
    362 -88
    347 -85
    333 -82
    319 -79
    305 -76
    291 -73
    277 -70
    264 -67
    250 -63
    237 -60
    223 -57
    210 -54
    197 -51
    184 -48
    171 -45
    158 -42
    145 -38
    133 -35
    120 -32
    108 -29
    96 -26
    83 -23
    71 -20
    60 -16
    48 -13
    36 -10
    25 -7
    13 -4
    2 -1
    -9 3
    -20 6
    -31 9
    -42 12
    -53 15
    -63 19
    -74 22
    -84 25
    -94 28
    -104 31
    -114 35
    -124 38
    -134 41
    -143 44
    -153 47
    -162 51
    -171 54
    -180 57
    -189 60
    -198 63
    -207 67
    -215 70
    -224 73
    -232 76
    -240 79
    -248 83
    -256 86
    -263 89
    -271 92
    -278 95
    -286 99
    -293 102
    -300 105
    -307 108
    -314 111
    -320 115
    -327 118
    -333 121
    -339 124
    -345 127
    -351 130
    -357 133
    -362 137
    -368 140
    -373 143
    -378 146
    -383 149
    -388 152
    -393 155
    -398 158
    -402 162
    -407 165
    -411 168
    -415 171
    -419 174
    -422 177
    -426 180
    -429 183
    -433 186
    -436 189
    -439 192
    -442 195
    -445 198
    -447 201
    -450 204
    -452 207
    -454 210
    -456 213
    -458 216
    -460 219
    -461 221
    -462 224
    -464 227
    -465 230
    -466 233
    -467 236
    -467 239
    -468 241
    -468 244
    -469 247
    -469 250
    -469 252
    -469 255
    -468 258
    -468 260
    -467 263
    -466 266
    -466 268
    -465 271
    -463 274
    -462 276
    -461 279
    -459 281
    -457 284
    -456 286
    -454 289
    -452 291
    -449 294
    -447 296
    -444 298
    -442 301
    -439 303
    -436 305
    -433 308
    -430 310
    -427 312
    -423 314
    -420 316
    -416 319
    -412 321
    -408 323
    -404 325
    -400 327
    -396 329
    -392 331
    -387 333
    -383 335
    -378 337
    -373 339
    -368 341
    -363 342
    -358 344
    -353 346
    -348 348
    -342 349
    -337 351
    -331 353
    -325 354
    -320 356
    -314 357
    -308 359
    -302 360
    -295 362
    -289 363
    -283 365
    -276 366
    -270 367
    -263 369
    -257 370
    -250 371
    -243 372
    -236 374
    -229 375
    -222 376
    -215 377
    -208 378
    -201 379
    -194 380
    -186 381
    -179 382
    -172 382
    -164 383
    -157 384
    -149 385
    -142 385
    -134 386
    -126 387
    -119 387
    -111 388
    -103 388
    -95 389
    -87 389
    -79 390
    -72 390
    -64 390
    -56 391
    -48 391
    -40 391
    -32 391
    -24 391
    -16 391
    -8 391
    0 391
    8 391
    16 391
    24 391
    32 391
    40 391
    48 391
    56 391
    64 390
    72 390
    79 390
    87 389
    95 389
    103 388
    111 388
    119 387
    126 387
    134 386
    142 385
    149 385
    157 384
    164 383
    172 382
    179 382
    186 381
    194 380
    201 379
    208 378
    215 377
    222 376
    229 375
    236 374
    243 372
    250 371
    257 370
    263 369
    270 367
    276 366
    283 365
    289 363
    295 362
    302 360
    308 359
    314 357
    320 356
    325 354
    331 353
    337 351
    342 349
    348 348
    353 346
    358 344
    363 342
    368 341
    373 339
    378 337
    383 335
    387 333
    392 331
    396 329
    400 327
    404 325
    408 323
    412 321
    416 319
    420 316
    423 314
    427 312
    430 310
    433 308
    436 305
    439 303
    442 301
    444 298
    447 296
    449 294
    452 291
    454 289
    456 286
    457 284
    459 281
    461 279
    462 276
    463 274
    465 271
    466 268
    466 266
    467 263
    468 260
    468 258
    469 255
    469 252
    469 250
    469 247
    468 244
    468 241
    467 239
    467 236
    466 233
    465 230
    464 227
    462 224
    461 221
    460 219
    458 216
    456 213
    454 210
    452 207
    450 204
    447 201
    445 198
    442 195
    439 192
    436 189
    433 186
    429 183
    426 180
    422 177
    419 174
    415 171
    411 168
    407 165
    402 162
    398 158
    393 155
    388 152
    383 149
    378 146
    373 143
    368 140
    362 137
    357 133
    351 130
    345 127
    339 124
    333 121
    327 118
    320 115
    314 111
    307 108
    300 105
    293 102
    286 99
    278 95
    271 92
    263 89
    256 86
    248 83
    240 79
    232 76
    224 73
    215 70
    207 67
    198 63
    189 60
    180 57
    171 54
    162 51
    153 47
    143 44
    134 41
    124 38
    114 35
    104 31
    94 28
    84 25
    74 22
    63 19
    53 15
    42 12
    31 9
    20 6
    9 3
    -2 -1
    -13 -4
    -25 -7
    -36 -10
    -48 -13
    -60 -16
    -71 -20
    -83 -23
    -96 -26
    -108 -29
    -120 -32
    -133 -35
    -145 -38
    -158 -42
    -171 -45
    -184 -48
    -197 -51
    -210 -54
    -223 -57
    -237 -60
    -250 -63
    -264 -67
    -277 -70
    -291 -73
    -305 -76
    -319 -79
    -333 -82
    -347 -85
    -362 -88
    -376 -91
    -391 -94
    -405 -97
    -420 -100
    -435 -103
    -450 -107
    -465 -110
    -480 -113
    -495 -116
    -511 -119
    -526 -122
    -542 -125
    -557 -128
    -573 -131
    -589 -134
    -605 -137
    -621 -140
    -637 -143
    -653 -145
    -669 -148
    -686 -151
    -702 -154
    -719 -157
    -736 -160
    -752 -163
    -769 -166
    -786 -169
    -803 -172
    -820 -175
    -837 -178
    -855 -181
    -872 -183
    -890 -186
    -907 -189
    -925 -192
    -942 -195
    -960 -198
    -978 -201
    -996 -203
    999 -208
    981 -205
    963 -202
    945 -199
    928 -197
    910 -194
    892 -191
    875 -188
    858 -185
    840 -182
    823 -179
    806 -176
    789 -173
    772 -170
    755 -167
    739 -164
    722 -161
    705 -158
    689 -155
    672 -152
    656 -149
    640 -146
    624 -143
    608 -140
    592 -137
    576 -134
    560 -131
    545 -128
    529 -125
    514 -122
    498 -119
    483 -116
    468 -113
    453 -109
    438 -106
    423 -103
    409 -100
    394 -97
    379 -94
    365 -91
    351 -88
    336 -85
    322 -81
    308 -78
    294 -75
    280 -72
    267 -69
    253 -66
    240 -62
    226 -59
    213 -56
    200 -53
    187 -50
    174 -47
    161 -43
    148 -40
    136 -37
    123 -34
    111 -31
    99 -27
    87 -24
    75 -21
    63 -18
    51 -14
    39 -11
    28 -8
    16 -5
    5 -1
    -6 2
    -17 5
    -28 8
    -39 12
    -50 15
    -60 18
    -71 21
    -81 25
    -91 28
    -101 31
    -111 34
    -121 38
    -131 41
    -140 44
    -150 47
    -159 51
    -168 54
    -177 57
    -186 60
    -195 64
    -203 67
    -212 70
    -220 73
    -229 77
    -237 80
    -245 83
    -253 86
    -260 90
    -268 93
    -275 96
    -283 99
    -290 103
    -297 106
    -304 109
    -310 112
    -317 116
    -323 119
    -330 122
    -336 125
    -342 129
    -348 132
    -354 135
    -359 138
    -365 141
    -370 145
    -375 148
    -380 151
    -385 154
    -390 157
    -395 160
    -399 164
    -403 167
    -408 170
    -412 173
    -416 176
    -419 179
    -423 182
    -426 185
    -430 188
    -433 192
    -436 195
    -439 198
    -442 201
    -444 204
    -447 207
    -449 210
    -451 213
    -453 216
    -455 219
    -457 222
    -458 225
    -460 228
    -461 230
    -462 233
    -463 236
    -464 239
    -465 242
    -465 245
    -466 248
    -466 250
    -466 253
    -466 256
    -466 259
    -465 262
    -465 264
    -464 267
    -464 270
    -463 272
    -462 275
    -461 278
    -460 280
    -458 283
    -457 285
    -455 288
    -453 290
    -451 293
    -449 295
    -447 298
    -444 300
    -442 303
    -439 305
    -437 308
    -434 310
    -431 312
    -428 314
    -424 317
    -421 319
    -418 321
    -414 323
    -410 326
    -406 328
    -402 330
    -398 332
    -394 334
    -390 336
    -385 338
    -381 340
    -376 342
    -371 344
    -367 346
    -362 348
    -356 349
    -351 351
    -346 353
    -341 355
    -335 356
    -329 358
    -324 360
    -318 361
    -312 363
    -306 365
    -300 366
    -294 368
    -288 369
    -281 370
    -275 372
    -269 373
    -262 374
    -255 376
    -249 377
    -242 378
    -235 379
    -228 380
    -221 382
    -214 383
    -207 384
    -200 385
    -193 386
    -186 387
    -178 387
    -171 388
    -163 389
    -156 390
    -148 391
    -141 391
    -133 392
    -126 393
    -118 393
    -110 394
    -103 394
    -95 395
    -87 395
    -79 396
    -71 396
    -63 396
    -56 397
    -48 397
    -40 397
    -32 397
    -24 397
    -16 397
    -8 397
    0 398
    8 397
    16 397
    24 397
    32 397
    40 397
    48 397
    56 397
    63 396
    71 396
    79 396
    87 395
    95 395
    103 394
    110 394
    118 393
    126 393
    133 392
    141 391
    148 391
    156 390
    163 389
    171 388
    178 387
    186 387
    193 386
    200 385
    207 384
    214 383
    221 382
    228 380
    235 379
    242 378
    249 377
    255 376
    262 374
    269 373
    275 372
    281 370
    288 369
    294 368
    300 366
    306 365
    312 363
    318 361
    324 360
    329 358
    335 356
    341 355
    346 353
    351 351
    356 349
    362 348
    367 346
    371 344
    376 342
    381 340
    385 338
    390 336
    394 334
    398 332
    402 330
    406 328
    410 326
    414 323
    418 321
    421 319
    424 317
    428 314
    431 312
    434 310
    437 308
    439 305
    442 303
    444 300
    447 298
    449 295
    451 293
    453 290
    455 288
    457 285
    458 283
    460 280
    461 278
    462 275
    463 272
    464 270
    464 267
    465 264
    465 262
    466 259
    466 256
    466 253
    466 250
    466 248
    465 245
    465 242
    464 239
    463 236
    462 233
    461 230
    460 228
    458 225
    457 222
    455 219
    453 216
    451 213
    449 210
    447 207
    444 204
    442 201
    439 198
    436 195
    433 192
    430 188
    426 185
    423 182
    419 179
    416 176
    412 173
    408 170
    403 167
    399 164
    395 160
    390 157
    385 154
    380 151
    375 148
    370 145
    365 141
    359 138
    354 135
    348 132
    342 129
    336 125
    330 122
    323 119
    317 116
    310 112
    304 109
    297 106
    290 103
    283 99
    275 96
    268 93
    260 90
    253 86
    245 83
    237 80
    229 77
    220 73
    212 70
    203 67
    195 64
    186 60
    177 57
    168 54
    159 51
    150 47
    140 44
    131 41
    121 38
    111 34
    101 31
    91 28
    81 25
    71 21
    60 18
    50 15
    39 12
    28 8
    17 5
    6 2
    -5 -1
    -16 -5
    -28 -8
    -39 -11
    -51 -14
    -63 -18
    -75 -21
    -87 -24
    -99 -27
    -111 -31
    -123 -34
    -136 -37
    -148 -40
    -161 -43
    -174 -47
    -187 -50
    -200 -53
    -213 -56
    -226 -59
    -240 -62
    -253 -66
    -267 -69
    -280 -72
    -294 -75
    -308 -78
    -322 -81
    -336 -85
    -351 -88
    -365 -91
    -379 -94
    -394 -97
    -409 -100
    -423 -103
    -438 -106
    -453 -109
    -468 -113
    -483 -116
    -498 -119
    -514 -122
    -529 -125
    -545 -128
    -560 -131
    -576 -134
    -592 -137
    -608 -140
    -624 -143
    -640 -146
    -656 -149
    -672 -152
    -689 -155
    -705 -158
    -722 -161
    -739 -164
    -755 -167
    -772 -170
    -789 -173
    -806 -176
    -823 -179
    -840 -182
    -858 -185
    -875 -188
    -892 -191
    -910 -194
    -928 -197
    -945 -199
    -963 -202
    -981 -205
    -999 -208
    1002 -213
    984 -210
    966 -207
    948 -204
    930 -201
    913 -198
    895 -195
    878 -192
    861 -189
    843 -186
    826 -183
    809 -180
    792 -177
    775 -174
    758 -171
    742 -168
    725 -165
    708 -162
    692 -159
    676 -156
    659 -153
    643 -150
    627 -147
    611 -144
    595 -140
    579 -137
    563 -134
    548 -131
    532 -128
    517 -125
    502 -122
    486 -119
    471 -116
    456 -112
    441 -109
    426 -106
    412 -103
    397 -100
    382 -97
    368 -93
    354 -90
    340 -87
    325 -84
    311 -81
    297 -77
    284 -74
    270 -71
    256 -68
    243 -65
    230 -61
    216 -58
    203 -55
    190 -52
    177 -48
    164 -45
    152 -42
    139 -39
    127 -35
    114 -32
    102 -29
    90 -25
    78 -22
    66 -19
    54 -16
    43 -12
    31 -9
    20 -6
    8 -2
    -3 1
    -14 4
    -25 7
    -36 11
    -46 14
    -57 17
    -67 21
    -78 24
    -88 27
    -98 31
    -108 34
    -118 37
    -127 41
    -137 44
    -146 47
    -156 51
    -165 54
    -174 57
    -183 61
    -192 64
    -200 67
    -209 70
    -217 74
    -225 77
    -233 80
    -241 84
    -249 87
    -257 90
    -265 94
    -272 97
    -279 100
    -286 104
    -293 107
    -300 110
    -307 113
    -314 117
    -320 120
    -326 123
    -333 127
    -339 130
    -345 133
    -350 136
    -356 140
    -362 143
    -367 146
    -372 149
    -377 153
    -382 156
    -387 159
    -391 162
    -396 166
    -400 169
    -404 172
    -408 175
    -412 178
    -416 181
    -420 185
    -423 188
    -427 191
    -430 194
    -433 197
    -436 200
    -438 203
    -441 206
    -444 209
    -446 212
    -448 216
    -450 219
    -452 222
    -454 225
    -455 228
    -457 231
    -458 234
    -459 236
    -460 239
    -461 242
    -462 245
    -462 248
    -463 251
    -463 254
    -463 257
    -463 260
    -463 262
    -463 265
    -462 268
    -462 271
    -461 273
    -460 276
    -459 279
    -458 282
    -457 284
    -456 287
    -454 289
    -452 292
    -451 295
    -449 297
    -447 300
    -444 302
    -442 305
    -440 307
    -437 310
    -434 312
    -431 314
    -428 317
    -425 319
    -422 321
    -419 324
    -415 326
    -412 328
    -408 330
    -404 333
    -400 335
    -396 337
    -392 339
    -388 341
    -383 343
    -379 345
    -374 347
    -369 349
    -365 351
    -360 353
    -355 355
    -349 356
    -344 358
    -339 360
    -333 362
    -328 363
    -322 365
    -316 367
    -311 368
    -305 370
    -299 371
    -293 373
    -286 374
    -280 376
    -274 377
    -267 379
    -261 380
    -254 381
    -248 383
    -241 384
    -234 385
    -227 386
    -220 387
    -213 388
    -206 389
    -199 390
    -192 391
    -185 392
    -177 393
    -170 394
    -163 395
    -155 396
    -148 396
    -140 397
    -133 398
    -125 399
    -117 399
    -110 400
    -102 400
    -94 401
    -87 401
    -79 402
    -71 402
    -63 402
    -55 403
    -47 403
    -40 403
    -32 403
    -24 403
    -16 403
    -8 403
    0 403
    8 403
    16 403
    24 403
    32 403
    40 403
    47 403
    55 403
    63 402
    71 402
    79 402
    87 401
    94 401
    102 400
    110 400
    117 399
    125 399
    133 398
    140 397
    148 396
    155 396
    163 395
    170 394
    177 393
    185 392
    192 391
    199 390
    206 389
    213 388
    220 387
    227 386
    234 385
    241 384
    248 383
    254 381
    261 380
    267 379
    274 377
    280 376
    286 374
    293 373
    299 371
    305 370
    311 368
    316 367
    322 365
    328 363
    333 362
    339 360
    344 358
    349 356
    355 355
    360 353
    365 351
    369 349
    374 347
    379 345
    383 343
    388 341
    392 339
    396 337
    400 335
    404 333
    408 330
    412 328
    415 326
    419 324
    422 321
    425 319
    428 317
    431 314
    434 312
    437 310
    440 307
    442 305
    444 302
    447 300
    449 297
    451 295
    452 292
    454 289
    456 287
    457 284
    458 282
    459 279
    460 276
    461 273
    462 271
    462 268
    463 265
    463 262
    463 260
    463 257
    463 254
    463 251
    462 248
    462 245
    461 242
    460 239
    459 236
    458 234
    457 231
    455 228
    454 225
    452 222
    450 219
    448 216
    446 212
    444 209
    441 206
    438 203
    436 200
    433 197
    430 194
    427 191
    423 188
    420 185
    416 181
    412 178
    408 175
    404 172
    400 169
    396 166
    391 162
    387 159
    382 156
    377 153
    372 149
    367 146
    362 143
    356 140
    350 136
    345 133
    339 130
    333 127
    326 123
    320 120
    314 117
    307 113
    300 110
    293 107
    286 104
    279 100
    272 97
    265 94
    257 90
    249 87
    241 84
    233 80
    225 77
    217 74
    209 70
    200 67
    192 64
    183 61
    174 57
    165 54
    156 51
    146 47
    137 44
    127 41
    118 37
    108 34
    98 31
    88 27
    78 24
    67 21
    57 17
    46 14
    36 11
    25 7
    14 4
    3 1
    -8 -2
    -20 -6
    -31 -9
    -43 -12
    -54 -16
    -66 -19
    -78 -22
    -90 -25
    -102 -29
    -114 -32
    -127 -35
    -139 -39
    -152 -42
    -164 -45
    -177 -48
    -190 -52
    -203 -55
    -216 -58
    -230 -61
    -243 -65
    -256 -68
    -270 -71
    -284 -74
    -297 -77
    -311 -81
    -325 -84
    -340 -87
    -354 -90
    -368 -93
    -382 -97
    -397 -100
    -412 -103
    -426 -106
    -441 -109
    -456 -112
    -471 -116
    -486 -119
    -502 -122
    -517 -125
    -532 -128
    -548 -131
    -563 -134
    -579 -137
    -595 -140
    -611 -144
    -627 -147
    -643 -150
    -659 -153
    -676 -156
    -692 -159
    -708 -162
    -725 -165
    -742 -168
    -758 -171
    -775 -174
    -792 -177
    -809 -180
    -826 -183
    -843 -186
    -861 -189
    -878 -192
    -895 -195
    -913 -198
    -930 -201
    -948 -204
    -966 -207
    -984 -210
    -1002 -213
    1005 -218
    987 -215
    969 -212
    951 -209
    933 -206
    916 -203
    898 -200
    881 -197
    864 -194
    846 -191
    829 -187
    812 -184
    795 -181
    778 -178
    761 -175
    745 -172
    728 -169
    711 -166
    695 -163
    679 -160
    662 -157
    646 -153
    630 -150
    614 -147
    598 -144
    582 -141
    567 -138
    551 -135
    535 -131
    520 -128
    505 -125
    489 -122
    474 -119
    459 -115
    444 -112
    430 -109
    415 -106
    400 -103
    386 -99
    371 -96
    357 -93
    343 -90
    329 -86
    315 -83
    301 -80
    287 -77
    273 -73
    260 -70
    246 -67
    233 -63
    220 -60
    206 -57
    193 -53
    180 -50
    168 -47
    155 -44
    142 -40
    130 -37
    118 -34
    105 -30
    93 -27
    81 -24
    69 -20
    58 -17
    46 -14
    34 -10
    23 -7
    12 -4
    0 -0
    -11 3
    -21 7
    -32 10
    -43 13
    -54 17
    -64 20
    -74 23
    -84 27
    -95 30
    -104 34
    -114 37
    -124 40
    -134 44
    -143 47
    -152 50
    -161 54
    -170 57
    -179 61
    -188 64
    -197 67
    -205 71
    -214 74
    -222 77
    -230 81
    -238 84
    -246 88
    -254 91
    -261 94
    -269 98
    -276 101
    -283 104
    -290 108
    -297 111
    -304 114
    -310 118
    -317 121
    -323 124
    -329 128
    -335 131
    -341 134
    -347 138
    -353 141
    -358 144
    -364 148
    -369 151
    -374 154
    -379 158
    -384 161
    -388 164
    -393 167
    -397 171
    -401 174
    -405 177
    -409 180
    -413 184
    -417 187
    -420 190
    -423 193
    -427 196
    -430 199
    -433 203
    -435 206
    -438 209
    -440 212
    -443 215
    -445 218
    -447 221
    -449 224
    -451 227
    -452 231
    -454 234
    -455 237
    -456 240
    -457 243
    -458 246
    -459 248
    -459 251
    -460 254
    -460 257
    -460 260
    -460 263
    -460 266
    -460 269
    -460 272
    -459 274
    -458 277
    -458 280
    -457 283
    -455 285
    -454 288
    -453 291
    -451 293
    -450 296
    -448 299
    -446 301
    -444 304
    -442 306
    -440 309
    -437 311
    -435 314
    -432 316
    -429 319
    -426 321
    -423 324
    -420 326
    -417 328
    -413 330
    -410 333
    -406 335
    -402 337
    -398 339
    -394 342
    -390 344
    -386 346
    -381 348
    -377 350
    -372 352
    -368 354
    -363 356
    -358 358
    -353 360
    -348 362
    -342 363
    -337 365
    -332 367
    -326 369
    -320 370
    -315 372
    -309 374
    -303 375
    -297 377
    -291 378
    -285 380
    -279 381
    -272 383
    -266 384
    -259 385
    -253 387
    -246 388
    -240 389
    -233 391
    -226 392
    -219 393
    -212 394
    -205 395
    -198 396
    -191 397
    -184 398
    -176 399
    -169 400
    -162 401
    -154 401
    -147 402
    -139 403
    -132 404
    -124 404
    -117 405
    -109 405
    -102 406
    -94 407
    -86 407
    -78 407
    -71 408
    -63 408
    -55 408
    -47 409
    -39 409
    -31 409
    -24 409
    -16 409
    -8 409
    0 409
    8 409
    16 409
    24 409
    31 409
    39 409
    47 409
    55 408
    63 408
    71 408
    78 407
    86 407
    94 407
    102 406
    109 405
    117 405
    124 404
    132 404
    139 403
    147 402
    154 401
    162 401
    169 400
    176 399
    184 398
    191 397
    198 396
    205 395
    212 394
    219 393
    226 392
    233 391
    240 389
    246 388
    253 387
    259 385
    266 384
    272 383
    279 381
    285 380
    291 378
    297 377
    303 375
    309 374
    315 372
    320 370
    326 369
    332 367
    337 365
    342 363
    348 362
    353 360
    358 358
    363 356
    368 354
    372 352
    377 350
    381 348
    386 346
    390 344
    394 342
    398 339
    402 337
    406 335
    410 333
    413 330
    417 328
    420 326
    423 324
    426 321
    429 319
    432 316
    435 314
    437 311
    440 309
    442 306
    444 304
    446 301
    448 299
    450 296
    451 293
    453 291
    454 288
    455 285
    457 283
    458 280
    458 277
    459 274
    460 272
    460 269
    460 266
    460 263
    460 260
    460 257
    460 254
    459 251
    459 248
    458 246
    457 243
    456 240
    455 237
    454 234
    452 231
    451 227
    449 224
    447 221
    445 218
    443 215
    440 212
    438 209
    435 206
    433 203
    430 199
    427 196
    423 193
    420 190
    417 187
    413 184
    409 180
    405 177
    401 174
    397 171
    393 167
    388 164
    384 161
    379 158
    374 154
    369 151
    364 148
    358 144
    353 141
    347 138
    341 134
    335 131
    329 128
    323 124
    317 121
    310 118
    304 114
    297 111
    290 108
    283 104
    276 101
    269 98
    261 94
    254 91
    246 88
    238 84
    230 81
    222 77
    214 74
    205 71
    197 67
    188 64
    179 61
    170 57
    161 54
    152 50
    143 47
    134 44
    124 40
    114 37
    104 34
    95 30
    84 27
    74 23
    64 20
    54 17
    43 13
    32 10
    21 7
    11 3
    -0 -0
    -12 -4
    -23 -7
    -34 -10
    -46 -14
    -58 -17
    -69 -20
    -81 -24
    -93 -27
    -105 -30
    -118 -34
    -130 -37
    -142 -40
    -155 -44
    -168 -47
    -180 -50
    -193 -53
    -206 -57
    -220 -60
    -233 -63
    -246 -67
    -260 -70
    -273 -73
    -287 -77
    -301 -80
    -315 -83
    -329 -86
    -343 -90
    -357 -93
    -371 -96
    -386 -99
    -400 -103
    -415 -106
    -430 -109
    -444 -112
    -459 -115
    -474 -119
    -489 -122
    -505 -125
    -520 -128
    -535 -131
    -551 -135
    -567 -138
    -582 -141
    -598 -144
    -614 -147
    -630 -150
    -646 -153
    -662 -157
    -679 -160
    -695 -163
    -711 -166
    -728 -169
    -745 -172
    -761 -175
    -778 -178
    -795 -181
    -812 -184
    -829 -187
    -846 -191
    -864 -194
    -881 -197
    -898 -200
    -916 -203
    -933 -206
    -951 -209
    -969 -212
    -987 -215
    -1005 -218
    1008 -223
    990 -219
    972 -216
    954 -213
    937 -210
    919 -207
    901 -204
    884 -201
    867 -198
    849 -195
    832 -192
    815 -189
    798 -186
    781 -182
    764 -179
    748 -176
    731 -173
    715 -170
    698 -167
    682 -163
    665 -160
    649 -157
    633 -154
    617 -151
    601 -148
    586 -144
    570 -141
    554 -138
    539 -135
    523 -131
    508 -128
    493 -125
    478 -122
    463 -118
    448 -115
    433 -112
    418 -109
    403 -105
    389 -102
    375 -99
    360 -95
    346 -92
    332 -89
    318 -86
    304 -82
    290 -79
    277 -76
    263 -72
    250 -69
    236 -66
    223 -62
    210 -59
    197 -55
    184 -52
    171 -49
    158 -45
    146 -42
    133 -39
    121 -35
    109 -32
    97 -28
    85 -25
    73 -22
    61 -18
    49 -15
    38 -11
    26 -8
    15 -5
    4 -1
    -7 2
    -18 6
    -29 9
    -40 12
    -50 16
    -61 19
    -71 23
    -81 26
    -91 30
    -101 33
    -111 37
    -121 40
    -130 43
    -140 47
    -149 50
    -158 54
    -167 57
    -176 61
    -185 64
    -193 67
    -202 71
    -210 74
    -219 78
    -227 81
    -235 85
    -242 88
    -250 91
    -258 95
    -265 98
    -273 102
    -280 105
    -287 109
    -294 112
    -300 115
    -307 119
    -313 122
    -320 126
    -326 129
    -332 132
    -338 136
    -344 139
    -349 142
    -355 146
    -360 149
    -365 153
    -371 156
    -375 159
    -380 163
    -385 166
    -389 169
    -394 172
    -398 176
    -402 179
    -406 182
    -410 186
    -413 189
    -417 192
    -420 195
    -423 199
    -426 202
    -429 205
    -432 208
    -435 211
    -437 215
    -440 218
    -442 221
    -444 224
    -446 227
    -448 230
    -449 233
    -451 236
    -452 240
    -453 243
    -454 246
    -455 249
    -456 252
    -456 255
    -457 258
    -457 261
    -457 263
    -457 266
    -457 269
    -457 272
    -457 275
    -456 278
    -456 281
    -455 284
    -454 286
    -453 289
    -452 292
    -450 295
    -449 297
    -447 300
    -445 303
    -443 305
    -441 308
    -439 310
    -437 313
    -435 316
    -432 318
    -429 321
    -427 323
    -424 325
    -421 328
    -417 330
    -414 333
    -411 335
    -407 337
    -404 340
    -400 342
    -396 344
    -392 346
    -388 348
    -384 351
    -379 353
    -375 355
    -370 357
    -366 359
    -361 361
    -356 363
    -351 365
    -346 367
    -341 368
    -335 370
    -330 372
    -324 374
    -319 375
    -313 377
    -307 379
    -301 380
    -296 382
    -290 384
    -283 385
    -277 387
    -271 388
    -265 389
    -258 391
    -252 392
    -245 394
    -238 395
    -232 396
    -225 397
    -218 398
    -211 399
    -204 401
    -197 402
    -190 403
    -183 404
    -176 405
    -168 405
    -161 406
    -154 407
    -146 408
    -139 409
    -131 409
    -124 410
    -116 411
    -109 411
    -101 412
    -93 412
    -86 413
    -78 413
    -70 413
    -62 414
    -55 414
    -47 414
    -39 415
    -31 415
    -23 415
    -16 415
    -8 415
    0 415
    8 415
    16 415
    23 415
    31 415
    39 415
    47 414
    55 414
    62 414
    70 413
    78 413
    86 413
    93 412
    101 412
    109 411
    116 411
    124 410
    131 409
    139 409
    146 408
    154 407
    161 406
    168 405
    176 405
    183 404
    190 403
    197 402
    204 401
    211 399
    218 398
    225 397
    232 396
    238 395
    245 394
    252 392
    258 391
    265 389
    271 388
    277 387
    283 385
    290 384
    296 382
    301 380
    307 379
    313 377
    319 375
    324 374
    330 372
    335 370
    341 368
    346 367
    351 365
    356 363
    361 361
    366 359
    370 357
    375 355
    379 353
    384 351
    388 348
    392 346
    396 344
    400 342
    404 340
    407 337
    411 335
    414 333
    417 330
    421 328
    424 325
    427 323
    429 321
    432 318
    435 316
    437 313
    439 310
    441 308
    443 305
    445 303
    447 300
    449 297
    450 295
    452 292
    453 289
    454 286
    455 284
    456 281
    456 278
    457 275
    457 272
    457 269
    457 266
    457 263
    457 261
    457 258
    456 255
    456 252
    455 249
    454 246
    453 243
    452 240
    451 236
    449 233
    448 230
    446 227
    444 224
    442 221
    440 218
    437 215
    435 211
    432 208
    429 205
    426 202
    423 199
    420 195
    417 192
    413 189
    410 186
    406 182
    402 179
    398 176
    394 172
    389 169
    385 166
    380 163
    375 159
    371 156
    365 153
    360 149
    355 146
    349 142
    344 139
    338 136
    332 132
    326 129
    320 126
    313 122
    307 119
    300 115
    294 112
    287 109
    280 105
    273 102
    265 98
    258 95
    250 91
    242 88
    235 85
    227 81
    219 78
    210 74
    202 71
    193 67
    185 64
    176 61
    167 57
    158 54
    149 50
    140 47
    130 43
    121 40
    111 37
    101 33
    91 30
    81 26
    71 23
    61 19
    50 16
    40 12
    29 9
    18 6
    7 2
    -4 -1
    -15 -5
    -26 -8
    -38 -11
    -49 -15
    -61 -18
    -73 -22
    -85 -25
    -97 -28
    -109 -32
    -121 -35
    -133 -39
    -146 -42
    -158 -45
    -171 -49
    -184 -52
    -197 -55
    -210 -59
    -223 -62
    -236 -66
    -250 -69
    -263 -72
    -277 -76
    -290 -79
    -304 -82
    -318 -86
    -332 -89
    -346 -92
    -360 -95
    -375 -99
    -389 -102
    -403 -105
    -418 -109
    -433 -112
    -448 -115
    -463 -118
    -478 -122
    -493 -125
    -508 -128
    -523 -131
    -539 -135
    -554 -138
    -570 -141
    -586 -144
    -601 -148
    -617 -151
    -633 -154
    -649 -157
    -665 -160
    -682 -163
    -698 -167
    -715 -170
    -731 -173
    -748 -176
    -764 -179
    -781 -182
    -798 -186
    -815 -189
    -832 -192
    -849 -195
    -867 -198
    -884 -201
    -901 -204
    -919 -207
    -937 -210
    -954 -213
    -972 -216
    -990 -219
    -1008 -223
    1011 -227
    993 -224
    975 -221
    957 -218
    940 -215
    922 -212
    905 -209
    887 -206
    870 -202
    853 -199
    835 -196
    818 -193
    801 -190
    784 -187
    768 -183
    751 -180
    734 -177
    718 -174
    701 -171
    685 -167
    669 -164
    653 -161
    636 -158
    620 -154
    605 -151
    589 -148
    573 -145
    557 -141
    542 -138
    527 -135
    511 -131
    496 -128
    481 -125
    466 -122
    451 -118
    436 -115
    421 -112
    407 -108
    392 -105
    378 -102
    364 -98
    349 -95
    335 -91
    321 -88
    307 -85
    294 -81
    280 -78
    266 -75
    253 -71
    240 -68
    226 -64
    213 -61
    200 -57
    187 -54
    174 -51
    162 -47
    149 -44
    137 -40
    124 -37
    112 -33
    100 -30
    88 -27
    76 -23
    64 -20
    53 -16
    41 -13
    30 -9
    19 -6
    7 -2
    -4 1
    -15 5
    -25 8
    -36 12
    -47 15
    -57 19
    -67 22
    -78 26
    -88 29
    -98 33
    -107 36
    -117 40
    -127 43
    -136 47
    -145 50
    -155 54
    -164 57
    -173 60
    -181 64
    -190 67
    -198 71
    -207 74
    -215 78
    -223 81
    -231 85
    -239 88
    -247 92
    -254 95
    -262 99
    -269 102
    -276 106
    -283 109
    -290 113
    -297 116
    -304 120
    -310 123
    -316 127
    -323 130
    -329 133
    -335 137
    -340 140
    -346 144
    -352 147
    -357 151
    -362 154
    -367 157
    -372 161
    -377 164
    -382 168
    -386 171
    -390 174
    -395 178
    -399 181
    -403 184
    -406 188
    -410 191
    -414 194
    -417 198
    -420 201
    -423 204
    -426 207
    -429 211
    -432 214
    -434 217
    -436 220
    -439 223
    -441 227
    -443 230
    -444 233
    -446 236
    -447 239
    -449 242
    -450 245
    -451 249
    -452 252
    -453 255
    -453 258
    -454 261
    -454 264
    -454 267
    -454 270
    -454 273
    -454 276
    -454 278
    -453 281
    -453 284
    -452 287
    -451 290
    -450 293
    -449 296
    -447 298
    -446 301
    -444 304
    -443 306
    -441 309
    -439 312
    -437 314
    -434 317
    -432 320
    -430 322
    -427 325
    -424 327
    -421 330
    -418 332
    -415 335
    -412 337
    -408 339
    -405 342
    -401 344
    -398 346
    -394 349
    -390 351
    -386 353
    -381 355
    -377 357
    -373 359
    -368 361
    -364 364
    -359 366
    -354 368
    -349 369
    -344 371
    -339 373
    -333 375
    -328 377
    -323 379
    -317 380
    -311 382
    -306 384
    -300 386
    -294 387
    -288 389
    -282 390
    -276 392
    -269 393
    -263 395
    -257 396
    -250 397
    -244 399
    -237 400
    -230 401
    -224 403
    -217 404
    -210 405
    -203 406
    -196 407
    -189 408
    -182 409
    -175 410
    -167 411
    -160 412
    -153 413
    -145 413
    -138 414
    -131 415
    -123 416
    -116 416
    -108 417
    -100 417
    -93 418
    -85 418
    -78 419
    -70 419
    -62 419
    -54 420
    -47 420
    -39 420
    -31 420
    -23 421
    -16 421
    -8 421
    0 421
    8 421
    16 421
    23 421
    31 420
    39 420
    47 420
    54 420
    62 419
    70 419
    78 419
    85 418
    93 418
    100 417
    108 417
    116 416
    123 416
    131 415
    138 414
    145 413
    153 413
    160 412
    167 411
    175 410
    182 409
    189 408
    196 407
    203 406
    210 405
    217 404
    224 403
    230 401
    237 400
    244 399
    250 397
    257 396
    263 395
    269 393
    276 392
    282 390
    288 389
    294 387
    300 386
    306 384
    311 382
    317 380
    323 379
    328 377
    333 375
    339 373
    344 371
    349 369
    354 368
    359 366
    364 364
    368 361
    373 359
    377 357
    381 355
    386 353
    390 351
    394 349
    398 346
    401 344
    405 342
    408 339
    412 337
    415 335
    418 332
    421 330
    424 327
    427 325
    430 322
    432 320
    434 317
    437 314
    439 312
    441 309
    443 306
    444 304
    446 301
    447 298
    449 296
    450 293
    451 290
    452 287
    453 284
    453 281
    454 278
    454 276
    454 273
    454 270
    454 267
    454 264
    454 261
    453 258
    453 255
    452 252
    451 249
    450 245
    449 242
    447 239
    446 236
    444 233
    443 230
    441 227
    439 223
    436 220
    434 217
    432 214
    429 211
    426 207
    423 204
    420 201
    417 198
    414 194
    410 191
    406 188
    403 184
    399 181
    395 178
    390 174
    386 171
    382 168
    377 164
    372 161
    367 157
    362 154
    357 151
    352 147
    346 144
    340 140
    335 137
    329 133
    323 130
    316 127
    310 123
    304 120
    297 116
    290 113
    283 109
    276 106
    269 102
    262 99
    254 95
    247 92
    239 88
    231 85
    223 81
    215 78
    207 74
    198 71
    190 67
    181 64
    173 60
    164 57
    155 54
    145 50
    136 47
    127 43
    117 40
    107 36
    98 33
    88 29
    78 26
    67 22
    57 19
    47 15
    36 12
    25 8
    15 5
    4 1
    -7 -2
    -19 -6
    -30 -9
    -41 -13
    -53 -16
    -64 -20
    -76 -23
    -88 -27
    -100 -30
    -112 -33
    -124 -37
    -137 -40
    -149 -44
    -162 -47
    -174 -51
    -187 -54
    -200 -57
    -213 -61
    -226 -64
    -240 -68
    -253 -71
    -266 -75
    -280 -78
    -294 -81
    -307 -85
    -321 -88
    -335 -91
    -349 -95
    -364 -98
    -378 -102
    -392 -105
    -407 -108
    -421 -112
    -436 -115
    -451 -118
    -466 -122
    -481 -125
    -496 -128
    -511 -131
    -527 -135
    -542 -138
    -557 -141
    -573 -145
    -589 -148
    -605 -151
    -620 -154
    -636 -158
    -653 -161
    -669 -164
    -685 -167
    -701 -171
    -718 -174
    -734 -177
    -751 -180
    -768 -183
    -784 -187
    -801 -190
    -818 -193
    -835 -196
    -853 -199
    -870 -202
    -887 -206
    -905 -209
    -922 -212
    -940 -215
    -957 -218
    -975 -221
    -993 -224
    -1011 -227
    1014 -232
    996 -229
    978 -226
    960 -223
    943 -220
    925 -217
    908 -213
    890 -210
    873 -207
    856 -204
    839 -201
    822 -197
    805 -194
    788 -191
    771 -188
    754 -184
    738 -181
    721 -178
    705 -175
    688 -171
    672 -168
    656 -165
    640 -161
    624 -158
    608 -155
    592 -151
    576 -148
    561 -145
    545 -141
    530 -138
    515 -135
    499 -131
    484 -128
    469 -125
    454 -121
    439 -118
    425 -115
    410 -111
    396 -108
    381 -104
    367 -101
    353 -97
    339 -94
    325 -91
    311 -87
    297 -84
    283 -80
    270 -77
    256 -73
    243 -70
    230 -66
    217 -63
    204 -60
    191 -56
    178 -53
    165 -49
    153 -46
    140 -42
    128 -39
    116 -35
    103 -32
    92 -28
    80 -25
    68 -21
    56 -18
    45 -14
    33 -11
    22 -7
    11 -3
    -0 0
    -11 4
    -22 7
    -33 11
    -43 14
    -54 18
    -64 21
    -74 25
    -84 28
    -94 32
    -104 36
    -114 39
    -123 43
    -133 46
    -142 50
    -151 53
    -160 57
    -169 60
    -178 64
    -186 67
    -195 71
    -203 75
    -212 78
    -220 82
    -228 85
    -236 89
    -243 92
    -251 96
    -258 99
    -266 103
    -273 106
    -280 110
    -287 113
    -293 117
    -300 120
    -307 124
    -313 127
    -319 131
    -325 134
    -331 138
    -337 141
    -343 145
    -348 148
    -353 152
    -359 155
    -364 159
    -369 162
    -373 166
    -378 169
    -383 173
    -387 176
    -391 179
    -395 183
    -399 186
    -403 189
    -407 193
    -410 196
    -414 200
    -417 203
    -420 206
    -423 210
    -426 213
    -428 216
    -431 219
    -433 223
    -435 226
    -437 229
    -439 232
    -441 236
    -443 239
    -444 242
    -446 245
    -447 248
    -448 251
    -449 255
    -450 258
    -450 261
    -451 264
    -451 267
    -451 270
    -451 273
    -451 276
    -451 279
    -451 282
    -450 285
    -450 288
    -449 291
    -448 293
    -447 296
    -446 299
    -445 302
    -443 305
    -442 307
    -440 310
    -438 313
    -436 316
    -434 318
    -432 321
    -429 324
    -427 326
    -424 329
    -422 331
    -419 334
    -416 336
    -413 339
    -409 341
    -406 344
    -403 346
    -399 348
    -395 351
    -391 353
    -388 355
    -383 357
    -379 360
    -375 362
    -371 364
    -366 366
    -361 368
    -357 370
    -352 372
    -347 374
    -342 376
    -337 378
    -332 380
    -326 382
    -321 384
    -315 385
    -310 387
    -304 389
    -298 391
    -292 392
    -286 394
    -280 395
    -274 397
    -268 398
    -262 400
    -255 401
    -249 403
    -242 404
    -236 405
    -229 407
    -222 408
    -216 409
    -209 410
    -202 411
    -195 412
    -188 413
    -181 414
    -174 415
    -167 416
    -159 417
    -152 418
    -145 419
    -137 420
    -130 420
    -122 421
    -115 422
    -107 422
    -100 423
    -92 423
    -85 424
    -77 424
    -69 425
    -62 425
    -54 425
    -46 426
    -39 426
    -31 426
    -23 426
    -15 426
    -8 426
    0 426
    8 426
    15 426
    23 426
    31 426
    39 426
    46 426
    54 425
    62 425
    69 425
    77 424
    85 424
    92 423
    100 423
    107 422
    115 422
    122 421
    130 420
    137 420
    145 419
    152 418
    159 417
    167 416
    174 415
    181 414
    188 413
    195 412
    202 411
    209 410
    216 409
    222 408
    229 407
    236 405
    242 404
    249 403
    255 401
    262 400
    268 398
    274 397
    280 395
    286 394
    292 392
    298 391
    304 389
    310 387
    315 385
    321 384
    326 382
    332 380
    337 378
    342 376
    347 374
    352 372
    357 370
    361 368
    366 366
    371 364
    375 362
    379 360
    383 357
    388 355
    391 353
    395 351
    399 348
    403 346
    406 344
    409 341
    413 339
    416 336
    419 334
    422 331
    424 329
    427 326
    429 324
    432 321
    434 318
    436 316
    438 313
    440 310
    442 307
    443 305
    445 302
    446 299
    447 296
    448 293
    449 291
    450 288
    450 285
    451 282
    451 279
    451 276
    451 273
    451 270
    451 267
    451 264
    450 261
    450 258
    449 255
    448 251
    447 248
    446 245
    444 242
    443 239
    441 236
    439 232
    437 229
    435 226
    433 223
    431 219
    428 216
    426 213
    423 210
    420 206
    417 203
    414 200
    410 196
    407 193
    403 189
    399 186
    395 183
    391 179
    387 176
    383 173
    378 169
    373 166
    369 162
    364 159
    359 155
    353 152
    348 148
    343 145
    337 141
    331 138
    325 134
    319 131
    313 127
    307 124
    300 120
    293 117
    287 113
    280 110
    273 106
    266 103
    258 99
    251 96
    243 92
    236 89
    228 85
    220 82
    212 78
    203 75
    195 71
    186 67
    178 64
    169 60
    160 57
    151 53
    142 50
    133 46
    123 43
    114 39
    104 36
    94 32
    84 28
    74 25
    64 21
    54 18
    43 14
    33 11
    22 7
    11 4
    0 0
    -11 -3
    -22 -7
    -33 -11
    -45 -14
    -56 -18
    -68 -21
    -80 -25
    -92 -28
    -103 -32
    -116 -35
    -128 -39
    -140 -42
    -153 -46
    -165 -49
    -178 -53
    -191 -56
    -204 -60
    -217 -63
    -230 -66
    -243 -70
    -256 -73
    -270 -77
    -283 -80
    -297 -84
    -311 -87
    -325 -91
    -339 -94
    -353 -97
    -367 -101
    -381 -104
    -396 -108
    -410 -111
    -425 -115
    -439 -118
    -454 -121
    -469 -125
    -484 -128
    -499 -131
    -515 -135
    -530 -138
    -545 -141
    -561 -145
    -576 -148
    -592 -151
    -608 -155
    -624 -158
    -640 -161
    -656 -165
    -672 -168
    -688 -171
    -705 -175
    -721 -178
    -738 -181
    -754 -184
    -771 -188
    -788 -191
    -805 -194
    -822 -197
    -839 -201
    -856 -204
    -873 -207
    -890 -210
    -908 -213
    -925 -217
    -943 -220
    -960 -223
    -978 -226
    -996 -229
    -1014 -232
    1017 -237
    999 -234
    981 -231
    964 -228
    946 -224
    928 -221
    911 -218
    894 -215
    876 -211
    859 -208
    842 -205
    825 -202
    808 -198
    791 -195
    774 -192
    757 -189
    741 -185
    724 -182
    708 -179
    692 -175
    675 -172
    659 -169
    643 -165
    627 -162
    611 -158
    595 -155
    580 -152
    564 -148
    549 -145
    533 -142
    518 -138
    503 -135
    488 -131
    473 -128
    458 -124
    443 -121
    428 -118
    414 -114
    399 -111
    385 -107
    370 -104
    356 -100
    342 -97
    328 -93
    314 -90
    300 -86
    287 -83
    273 -79
    260 -76
    246 -72
    233 -69
    220 -65
    207 -62
    194 -58
    181 -55
    169 -51
    156 -48
    144 -44
    131 -40
    119 -37
    107 -33
    95 -30
    83 -26
    71 -23
    60 -19
    48 -15
    37 -12
    26 -8
    14 -5
    3 -1
    -8 2
    -18 6
    -29 10
    -40 13
    -50 17
    -60 20
    -71 24
    -81 28
    -91 31
    -100 35
    -110 39
    -120 42
    -129 46
    -138 49
    -147 53
    -157 57
    -165 60
    -174 64
    -183 67
    -191 71
    -200 75
    -208 78
    -216 82
    -224 85
    -232 89
    -240 93
    -247 96
    -255 100
    -262 103
    -269 107
    -276 110
    -283 114
    -290 118
    -297 121
    -303 125
    -309 128
    -316 132
    -322 135
    -328 139
    -333 143
    -339 146
    -345 150
    -350 153
    -355 157
    -360 160
    -365 164
    -370 167
    -375 171
    -379 174
    -384 178
    -388 181
    -392 184
    -396 188
    -400 191
    -403 195
    -407 198
    -410 202
    -414 205
    -417 208
    -420 212
    -422 215
    -425 218
    -428 222
    -430 225
    -432 228
    -434 232
    -436 235
    -438 238
    -440 241
    -441 245
    -443 248
    -444 251
    -445 254
    -446 257
    -447 261
    -447 264
    -448 267
    -448 270
    -448 273
    -448 276
    -448 279
    -448 282
    -448 285
    -447 288
    -447 291
    -446 294
    -445 297
    -444 300
    -443 303
    -442 305
    -440 308
    -439 311
    -437 314
    -435 317
    -433 319
    -431 322
    -429 325
    -427 327
    -424 330
    -422 333
    -419 335
    -416 338
    -413 340
    -410 343
    -407 345
    -404 348
    -400 350
    -397 353
    -393 355
    -389 357
    -385 360
    -381 362
    -377 364
    -373 366
    -368 368
    -364 371
    -359 373
    -355 375
    -350 377
    -345 379
    -340 381
    -335 383
    -330 385
    -324 387
    -319 388
    -314 390
    -308 392
    -302 394
    -297 395
    -291 397
    -285 399
    -279 400
    -273 402
    -267 403
    -260 405
    -254 406
    -248 408
    -241 409
    -235 410
    -228 412
    -221 413
    -214 414
    -208 415
    -201 416
    -194 418
    -187 419
    -180 420
    -173 421
    -166 422
    -158 422
    -151 423
    -144 424
    -137 425
    -129 426
    -122 426
    -114 427
    -107 428
    -99 428
    -92 429
    -84 429
    -77 430
    -69 430
    -61 430
    -54 431
    -46 431
    -38 431
    -31 431
    -23 431
    -15 432
    -8 432
    0 432
    8 432
    15 432
    23 431
    31 431
    38 431
    46 431
    54 431
    61 430
    69 430
    77 430
    84 429
    92 429
    99 428
    107 428
    114 427
    122 426
    129 426
    137 425
    144 424
    151 423
    158 422
    166 422
    173 421
    180 420
    187 419
    194 418
    201 416
    208 415
    214 414
    221 413
    228 412
    235 410
    241 409
    248 408
    254 406
    260 405
    267 403
    273 402
    279 400
    285 399
    291 397
    297 395
    302 394
    308 392
    314 390
    319 388
    324 387
    330 385
    335 383
    340 381
    345 379
    350 377
    355 375
    359 373
    364 371
    368 368
    373 366
    377 364
    381 362
    385 360
    389 357
    393 355
    397 353
    400 350
    404 348
    407 345
    410 343
    413 340
    416 338
    419 335
    422 333
    424 330
    427 327
    429 325
    431 322
    433 319
    435 317
    437 314
    439 311
    440 308
    442 305
    443 303
    444 300
    445 297
    446 294
    447 291
    447 288
    448 285
    448 282
    448 279
    448 276
    448 273
    448 270
    448 267
    447 264
    447 261
    446 257
    445 254
    444 251
    443 248
    441 245
    440 241
    438 238
    436 235
    434 232
    432 228
    430 225
    428 222
    425 218
    422 215
    420 212
    417 208
    414 205
    410 202
    407 198
    403 195
    400 191
    396 188
    392 184
    388 181
    384 178
    379 174
    375 171
    370 167
    365 164
    360 160
    355 157
    350 153
    345 150
    339 146
    333 143
    328 139
    322 135
    316 132
    309 128
    303 125
    297 121
    290 118
    283 114
    276 110
    269 107
    262 103
    255 100
    247 96
    240 93
    232 89
    224 85
    216 82
    208 78
    200 75
    191 71
    183 67
    174 64
    165 60
    157 57
    147 53
    138 49
    129 46
    120 42
    110 39
    100 35
    91 31
    81 28
    71 24
    60 20
    50 17
    40 13
    29 10
    18 6
    8 2
    -3 -1
    -14 -5
    -26 -8
    -37 -12
    -48 -15
    -60 -19
    -71 -23
    -83 -26
    -95 -30
    -107 -33
    -119 -37
    -131 -40
    -144 -44
    -156 -48
    -169 -51
    -181 -55
    -194 -58
    -207 -62
    -220 -65
    -233 -69
    -246 -72
    -260 -76
    -273 -79
    -287 -83
    -300 -86
    -314 -90
    -328 -93
    -342 -97
    -356 -100
    -370 -104
    -385 -107
    -399 -111
    -414 -114
    -428 -118
    -443 -121
    -458 -124
    -473 -128
    -488 -131
    -503 -135
    -518 -138
    -533 -142
    -549 -145
    -564 -148
    -580 -152
    -595 -155
    -611 -158
    -627 -162
    -643 -165
    -659 -169
    -675 -172
    -692 -175
    -708 -179
    -724 -182
    -741 -185
    -757 -189
    -774 -192
    -791 -195
    -808 -198
    -825 -202
    -842 -205
    -859 -208
    -876 -211
    -894 -215
    -911 -218
    -928 -221
    -946 -224
    -964 -228
    -981 -231
    -999 -234
    -1017 -237
    1020 -242
    1002 -239
    985 -236
    967 -233
    949 -229
    932 -226
    914 -223
    897 -219
    879 -216
    862 -213
    845 -209
    828 -206
    811 -203
    794 -199
    777 -196
    761 -193
    744 -189
    728 -186
    711 -183
    695 -179
    679 -176
    662 -172
    646 -169
    630 -166
    615 -162
    599 -159
    583 -155
    568 -152
    552 -148
    537 -145
    521 -142
    506 -138
    491 -135
    476 -131
    461 -128
    446 -124
    432 -121
    417 -117
    403 -114
    388 -110
    374 -107
    360 -103
    346 -99
    332 -96
    318 -92
    304 -89
    290 -85
    277 -82
    263 -78
    250 -75
    237 -71
    224 -67
    211 -64
    198 -60
    185 -57
    172 -53
    160 -49
    147 -46
    135 -42
    123 -39
    111 -35
    99 -31
    87 -28
    75 -24
    63 -21
    52 -17
    40 -13
    29 -10
    18 -6
    7 -2
    -4 1
    -15 5
    -25 9
    -36 12
    -46 16
    -57 20
    -67 23
    -77 27
    -87 31
    -97 34
    -106 38
    -116 42
    -125 45
    -135 49
    -144 53
    -153 56
    -162 60
    -171 64
    -179 67
    -188 71
    -196 75
    -204 78
    -212 82
    -220 85
    -228 89
    -236 93
    -244 96
    -251 100
    -258 104
    -266 107
    -273 111
    -280 115
    -286 118
    -293 122
    -299 126
    -306 129
    -312 133
    -318 136
    -324 140
    -330 144
    -336 147
    -341 151
    -346 154
    -352 158
    -357 161
    -362 165
    -367 168
    -371 172
    -376 176
    -380 179
    -384 183
    -388 186
    -392 190
    -396 193
    -400 197
    -403 200
    -407 203
    -410 207
    -413 210
    -416 214
    -419 217
    -422 220
    -424 224
    -427 227
    -429 231
    -431 234
    -433 237
    -435 241
    -436 244
    -438 247
    -439 250
    -441 254
    -442 257
    -443 260
    -443 263
    -444 266
    -445 270
    -445 273
    -445 276
    -445 279
    -445 282
    -445 285
    -445 288
    -444 291
    -444 294
    -443 297
    -442 300
    -441 303
    -440 306
    -439 309
    -438 312
    -436 315
    -434 317
    -433 320
    -431 323
    -429 326
    -426 329
    -424 331
    -422 334
    -419 337
    -416 339
    -414 342
    -411 344
    -408 347
    -405 349
    -401 352
    -398 354
    -394 357
    -391 359
    -387 361
    -383 364
    -379 366
    -375 368
    -371 371
    -366 373
    -362 375
    -357 377
    -353 379
    -348 381
    -343 383
    -338 385
    -333 387
    -328 389
    -323 391
    -317 393
    -312 395
    -306 397
    -301 398
    -295 400
    -289 402
    -283 404
    -277 405
    -271 407
    -265 408
    -259 410
    -252 411
    -246 413
    -240 414
    -233 415
    -227 417
    -220 418
    -213 419
    -207 420
    -200 422
    -193 423
    -186 424
    -179 425
    -172 426
    -165 427
    -158 428
    -150 428
    -143 429
    -136 430
    -128 431
    -121 432
    -114 432
    -106 433
    -99 433
    -91 434
    -84 434
    -76 435
    -69 435
    -61 436
    -54 436
    -46 436
    -38 436
    -31 437
    -23 437
    -15 437
    -8 437
    0 437
    8 437
    15 437
    23 437
    31 437
    38 436
    46 436
    54 436
    61 436
    69 435
    76 435
    84 434
    91 434
    99 433
    106 433
    114 432
    121 432
    128 431
    136 430
    143 429
    150 428
    158 428
    165 427
    172 426
    179 425
    186 424
    193 423
    200 422
    207 420
    213 419
    220 418
    227 417
    233 415
    240 414
    246 413
    252 411
    259 410
    265 408
    271 407
    277 405
    283 404
    289 402
    295 400
    301 398
    306 397
    312 395
    317 393
    323 391
    328 389
    333 387
    338 385
    343 383
    348 381
    353 379
    357 377
    362 375
    366 373
    371 371
    375 368
    379 366
    383 364
    387 361
    391 359
    394 357
    398 354
    401 352
    405 349
    408 347
    411 344
    414 342
    416 339
    419 337
    422 334
    424 331
    426 329
    429 326
    431 323
    433 320
    434 317
    436 315
    438 312
    439 309
    440 306
    441 303
    442 300
    443 297
    444 294
    444 291
    445 288
    445 285
    445 282
    445 279
    445 276
    445 273
    445 270
    444 266
    443 263
    443 260
    442 257
    441 254
    439 250
    438 247
    436 244
    435 241
    433 237
    431 234
    429 231
    427 227
    424 224
    422 220
    419 217
    416 214
    413 210
    410 207
    407 203
    403 200
    400 197
    396 193
    392 190
    388 186
    384 183
    380 179
    376 176
    371 172
    367 168
    362 165
    357 161
    352 158
    346 154
    341 151
    336 147
    330 144
    324 140
    318 136
    312 133
    306 129
    299 126
    293 122
    286 118
    280 115
    273 111
    266 107
    258 104
    251 100
    244 96
    236 93
    228 89
    220 85
    212 82
    204 78
    196 75
    188 71
    179 67
    171 64
    162 60
    153 56
    144 53
    135 49
    125 45
    116 42
    106 38
    97 34
    87 31
    77 27
    67 23
    57 20
    46 16
    36 12
    25 9
    15 5
    4 1
    -7 -2
    -18 -6
    -29 -10
    -40 -13
    -52 -17
    -63 -21
    -75 -24
    -87 -28
    -99 -31
    -111 -35
    -123 -39
    -135 -42
    -147 -46
    -160 -49
    -172 -53
    -185 -57
    -198 -60
    -211 -64
    -224 -67
    -237 -71
    -250 -75
    -263 -78
    -277 -82
    -290 -85
    -304 -89
    -318 -92
    -332 -96
    -346 -99
    -360 -103
    -374 -107
    -388 -110
    -403 -114
    -417 -117
    -432 -121
    -446 -124
    -461 -128
    -476 -131
    -491 -135
    -506 -138
    -521 -142
    -537 -145
    -552 -148
    -568 -152
    -583 -155
    -599 -159
    -615 -162
    -630 -166
    -646 -169
    -662 -172
    -679 -176
    -695 -179
    -711 -183
    -728 -186
    -744 -189
    -761 -193
    -777 -196
    -794 -199
    -811 -203
    -828 -206
    -845 -209
    -862 -213
    -879 -216
    -897 -219
    -914 -223
    -932 -226
    -949 -229
    -967 -233
    -985 -236
    -1002 -239
    -1020 -242
    1024 -247
    1006 -244
    988 -241
    970 -237
    953 -234
    935 -231
    917 -227
    900 -224
    883 -221
    866 -217
    848 -214
    831 -211
    814 -207
    798 -204
    781 -200
    764 -197
    748 -194
    731 -190
    715 -187
    698 -183
    682 -180
    666 -176
    650 -173
    634 -169
    618 -166
    602 -162
    587 -159
    571 -155
    556 -152
    540 -148
    525 -145
    510 -141
    495 -138
    480 -134
    465 -131
    450 -127
    435 -124
    421 -120
    406 -117
    392 -113
    377 -109
    363 -106
    349 -102
    335 -99
    321 -95
    308 -91
    294 -88
    280 -84
    267 -81
    254 -77
    240 -73
    227 -70
    214 -66
    201 -62
    189 -59
    176 -55
    163 -51
    151 -48
    139 -44
    126 -40
    114 -37
    102 -33
    90 -29
    79 -26
    67 -22
    56 -18
    44 -15
    33 -11
    22 -7
    11 -4
    -0 0
    -11 4
    -22 8
    -32 11
    -43 15
    -53 19
    -63 22
    -73 26
    -83 30
    -93 34
    -103 37
    -112 41
    -122 45
    -131 48
    -140 52
    -149 56
    -158 60
    -167 63
    -176 67
    -184 71
    -192 74
    -201 78
    -209 82
    -217 86
    -225 89
    -232 93
    -240 97
    -247 100
    -255 104
    -262 108
    -269 111
    -276 115
    -283 119
    -289 122
    -296 126
    -302 130
    -308 133
    -314 137
    -320 141
    -326 144
    -332 148
    -337 152
    -343 155
    -348 159
    -353 163
    -358 166
    -363 170
    -368 173
    -372 177
    -377 181
    -381 184
    -385 188
    -389 191
    -393 195
    -396 198
    -400 202
    -403 205
    -407 209
    -410 212
    -413 216
    -416 219
    -418 223
    -421 226
    -423 229
    -425 233
    -428 236
    -430 240
    -431 243
    -433 246
    -435 250
    -436 253
    -437 256
    -438 259
    -439 263
    -440 266
    -441 269
    -441 272
    -442 276
    -442 279
    -442 282
    -442 285
    -442 288
    -442 291
    -441 294
    -441 297
    -440 300
    -439 303
    -438 306
    -437 309
    -436 312
    -435 315
    -433 318
    -432 321
    -430 324
    -428 327
    -426 329
    -424 332
    -421 335
    -419 338
    -417 340
    -414 343
    -411 346
    -408 348
    -405 351
    -402 353
    -399 356
    -395 358
    -392 361
    -388 363
    -384 366
    -381 368
    -377 370
    -373 373
    -368 375
    -364 377
    -360 379
    -355 381
    -351 384
    -346 386
    -341 388
    -336 390
    -331 392
    -326 394
    -321 396
    -315 398
    -310 399
    -304 401
    -299 403
    -293 405
    -287 407
    -282 408
    -276 410
    -270 411
    -263 413
    -257 415
    -251 416
    -245 417
    -238 419
    -232 420
    -225 422
    -219 423
    -212 424
    -205 425
    -199 426
    -192 428
    -185 429
    -178 430
    -171 431
    -164 432
    -157 433
    -149 433
    -142 434
    -135 435
    -128 436
    -120 437
    -113 437
    -106 438
    -98 438
    -91 439
    -83 440
    -76 440
    -68 440
    -61 441
    -53 441
    -46 441
    -38 442
    -30 442
    -23 442
    -15 442
    -8 442
    0 442
    8 442
    15 442
    23 442
    30 442
    38 442
    46 441
    53 441
    61 441
    68 440
    76 440
    83 440
    91 439
    98 438
    106 438
    113 437
    120 437
    128 436
    135 435
    142 434
    149 433
    157 433
    164 432
    171 431
    178 430
    185 429
    192 428
    199 426
    205 425
    212 424
    219 423
    225 422
    232 420
    238 419
    245 417
    251 416
    257 415
    263 413
    270 411
    276 410
    282 408
    287 407
    293 405
    299 403
    304 401
    310 399
    315 398
    321 396
    326 394
    331 392
    336 390
    341 388
    346 386
    351 384
    355 381
    360 379
    364 377
    368 375
    373 373
    377 370
    381 368
    384 366
    388 363
    392 361
    395 358
    399 356
    402 353
    405 351
    408 348
    411 346
    414 343
    417 340
    419 338
    421 335
    424 332
    426 329
    428 327
    430 324
    432 321
    433 318
    435 315
    436 312
    437 309
    438 306
    439 303
    440 300
    441 297
    441 294
    442 291
    442 288
    442 285
    442 282
    442 279
    442 276
    441 272
    441 269
    440 266
    439 263
    438 259
    437 256
    436 253
    435 250
    433 246
    431 243
    430 240
    428 236
    425 233
    423 229
    421 226
    418 223
    416 219
    413 216
    410 212
    407 209
    403 205
    400 202
    396 198
    393 195
    389 191
    385 188
    381 184
    377 181
    372 177
    368 173
    363 170
    358 166
    353 163
    348 159
    343 155
    337 152
    332 148
    326 144
    320 141
    314 137
    308 133
    302 130
    296 126
    289 122
    283 119
    276 115
    269 111
    262 108
    255 104
    247 100
    240 97
    232 93
    225 89
    217 86
    209 82
    201 78
    192 74
    184 71
    176 67
    167 63
    158 60
    149 56
    140 52
    131 48
    122 45
    112 41
    103 37
    93 34
    83 30
    73 26
    63 22
    53 19
    43 15
    32 11
    22 8
    11 4
    0 0
    -11 -4
    -22 -7
    -33 -11
    -44 -15
    -56 -18
    -67 -22
    -79 -26
    -90 -29
    -102 -33
    -114 -37
    -126 -40
    -139 -44
    -151 -48
    -163 -51
    -176 -55
    -189 -59
    -201 -62
    -214 -66
    -227 -70
    -240 -73
    -254 -77
    -267 -81
    -280 -84
    -294 -88
    -308 -91
    -321 -95
    -335 -99
    -349 -102
    -363 -106
    -377 -109
    -392 -113
    -406 -117
    -421 -120
    -435 -124
    -450 -127
    -465 -131
    -480 -134
    -495 -138
    -510 -141
    -525 -145
    -540 -148
    -556 -152
    -571 -155
    -587 -159
    -602 -162
    -618 -166
    -634 -169
    -650 -173
    -666 -176
    -682 -180
    -698 -183
    -715 -187
    -731 -190
    -748 -194
    -764 -197
    -781 -200
    -798 -204
    -814 -207
    -831 -211
    -848 -214
    -866 -217
    -883 -221
    -900 -224
    -917 -227
    -935 -231
    -953 -234
    -970 -237
    -988 -241
    -1006 -244
    -1024 -247
    1027 -252
    1009 -249
    991 -246
    973 -242
    956 -239
    938 -236
    921 -232
    903 -229
    886 -225
    869 -222
    852 -219
    835 -215
    818 -212
    801 -208
    784 -205
    768 -201
    751 -198
    734 -194
    718 -191
    702 -187
    686 -184
    669 -180
    653 -177
    637 -173
    622 -170
    606 -166
    590 -163
    575 -159
    559 -156
    544 -152
    528 -148
    513 -145
    498 -141
    483 -138
    468 -134
    453 -131
    439 -127
    424 -123
    410 -120
    395 -116
    381 -112
    367 -109
    353 -105
    339 -101
    325 -98
    311 -94
    298 -90
    284 -87
    271 -83
    257 -79
    244 -76
    231 -72
    218 -68
    205 -65
    192 -61
    180 -57
    167 -54
    155 -50
    142 -46
    130 -42
    118 -39
    106 -35
    94 -31
    82 -27
    71 -24
    59 -20
    48 -16
    37 -12
    25 -9
    14 -5
    3 -1
    -7 3
    -18 6
    -29 10
    -39 14
    -49 18
    -59 21
    -70 25
    -79 29
    -89 33
    -99 36
    -109 40
    -118 44
    -127 48
    -136 52
    -145 55
    -154 59
    -163 63
    -172 67
    -180 70
    -189 74
    -197 78
    -205 82
    -213 86
    -221 89
    -229 93
    -236 97
    -244 101
    -251 104
    -258 108
    -265 112
    -272 116
    -279 119
    -286 123
    -292 127
    -298 130
    -305 134
    -311 138
    -317 142
    -323 145
    -328 149
    -334 153
    -339 156
    -344 160
    -350 164
    -355 167
    -359 171
    -364 175
    -369 178
    -373 182
    -377 185
    -381 189
    -385 193
    -389 196
    -393 200
    -396 203
    -400 207
    -403 210
    -406 214
    -409 218
    -412 221
    -415 225
    -417 228
    -420 231
    -422 235
    -424 238
    -426 242
    -428 245
    -430 249
    -431 252
    -433 255
    -434 259
    -435 262
    -436 265
    -437 269
    -438 272
    -438 275
    -439 278
    -439 282
    -439 285
    -439 288
    -439 291
    -439 294
    -438 297
    -438 300
    -437 303
    -436 306
    -435 310
    -434 313
    -433 315
    -432 318
    -430 321
    -429 324
    -427 327
    -425 330
    -423 333
    -421 336
    -419 338
    -416 341
    -414 344
    -411 347
    -408 349
    -406 352
    -403 355
    -399 357
    -396 360
    -393 362
    -389 365
    -386 367
    -382 370
    -378 372
    -374 374
    -370 377
    -366 379
    -362 381
    -357 383
    -353 386
    -348 388
    -344 390
    -339 392
    -334 394
    -329 396
    -324 398
    -319 400
    -313 402
    -308 404
    -303 406
    -297 408
    -291 409
    -286 411
    -280 413
    -274 414
    -268 416
    -262 418
    -256 419
    -250 421
    -243 422
    -237 424
    -230 425
    -224 426
    -217 428
    -211 429
    -204 430
    -197 431
    -191 432
    -184 434
    -177 435
    -170 436
    -163 437
    -156 438
    -149 438
    -141 439
    -134 440
    -127 441
    -120 442
    -112 442
    -105 443
    -98 443
    -90 444
    -83 445
    -75 445
    -68 445
    -60 446
    -53 446
    -45 446
    -38 447
    -30 447
    -23 447
    -15 447
    -8 447
    0 447
    8 447
    15 447
    23 447
    30 447
    38 447
    45 446
    53 446
    60 446
    68 445
    75 445
    83 445
    90 444
    98 443
    105 443
    112 442
    120 442
    127 441
    134 440
    141 439
    149 438
    156 438
    163 437
    170 436
    177 435
    184 434
    191 432
    197 431
    204 430
    211 429
    217 428
    224 426
    230 425
    237 424
    243 422
    250 421
    256 419
    262 418
    268 416
    274 414
    280 413
    286 411
    291 409
    297 408
    303 406
    308 404
    313 402
    319 400
    324 398
    329 396
    334 394
    339 392
    344 390
    348 388
    353 386
    357 383
    362 381
    366 379
    370 377
    374 374
    378 372
    382 370
    386 367
    389 365
    393 362
    396 360
    399 357
    403 355
    406 352
    408 349
    411 347
    414 344
    416 341
    419 338
    421 336
    423 333
    425 330
    427 327
    429 324
    430 321
    432 318
    433 315
    434 313
    435 310
    436 306
    437 303
    438 300
    438 297
    439 294
    439 291
    439 288
    439 285
    439 282
    439 278
    438 275
    438 272
    437 269
    436 265
    435 262
    434 259
    433 255
    431 252
    430 249
    428 245
    426 242
    424 238
    422 235
    420 231
    417 228
    415 225
    412 221
    409 218
    406 214
    403 210
    400 207
    396 203
    393 200
    389 196
    385 193
    381 189
    377 185
    373 182
    369 178
    364 175
    359 171
    355 167
    350 164
    344 160
    339 156
    334 153
    328 149
    323 145
    317 142
    311 138
    305 134
    298 130
    292 127
    286 123
    279 119
    272 116
    265 112
    258 108
    251 104
    244 101
    236 97
    229 93
    221 89
    213 86
    205 82
    197 78
    189 74
    180 70
    172 67
    163 63
    154 59
    145 55
    136 52
    127 48
    118 44
    109 40
    99 36
    89 33
    79 29
    70 25
    59 21
    49 18
    39 14
    29 10
    18 6
    7 3
    -3 -1
    -14 -5
    -25 -9
    -37 -12
    -48 -16
    -59 -20
    -71 -24
    -82 -27
    -94 -31
    -106 -35
    -118 -39
    -130 -42
    -142 -46
    -155 -50
    -167 -54
    -180 -57
    -192 -61
    -205 -65
    -218 -68
    -231 -72
    -244 -76
    -257 -79
    -271 -83
    -284 -87
    -298 -90
    -311 -94
    -325 -98
    -339 -101
    -353 -105
    -367 -109
    -381 -112
    -395 -116
    -410 -120
    -424 -123
    -439 -127
    -453 -131
    -468 -134
    -483 -138
    -498 -141
    -513 -145
    -528 -148
    -544 -152
    -559 -156
    -575 -159
    -590 -163
    -606 -166
    -622 -170
    -637 -173
    -653 -177
    -669 -180
    -686 -184
    -702 -187
    -718 -191
    -734 -194
    -751 -198
    -768 -201
    -784 -205
    -801 -208
    -818 -212
    -835 -215
    -852 -219
    -869 -222
    -886 -225
    -903 -229
    -921 -232
    -938 -236
    -956 -239
    -973 -242
    -991 -246
    -1009 -249
    -1027 -252
    1030 -258
    1012 -254
    995 -251
    977 -247
    959 -244
    942 -240
    924 -237
    907 -234
    890 -230
    872 -227
    855 -223
    838 -220
    821 -216
    805 -213
    788 -209
    771 -206
    755 -202
    738 -199
    722 -195
    705 -191
    689 -188
    673 -184
    657 -181
    641 -177
    625 -174
    609 -170
    594 -166
    578 -163
    563 -159
    547 -156
    532 -152
    517 -148
    502 -145
    487 -141
    472 -137
    457 -134
    442 -130
    428 -126
    413 -123
    399 -119
    385 -115
    371 -112
    356 -108
    343 -104
    329 -101
    315 -97
    301 -93
    288 -89
    274 -86
    261 -82
    248 -78
    235 -74
    222 -71
    209 -67
    196 -63
    183 -59
    171 -56
    158 -52
    146 -48
    134 -44
    122 -41
    110 -37
    98 -33
    86 -29
    75 -25
    63 -22
    52 -18
    40 -14
    29 -10
    18 -6
    7 -3
    -4 1
    -14 5
    -25 9
    -35 13
    -45 17
    -56 20
    -66 24
    -76 28
    -85 32
    -95 36
    -105 40
    -114 43
    -123 47
    -133 51
    -142 55
    -151 59
    -159 62
    -168 66
    -177 70
    -185 74
    -193 78
    -201 82
    -209 85
    -217 89
    -225 93
    -232 97
    -240 101
    -247 104
    -254 108
    -261 112
    -268 116
    -275 120
    -282 123
    -288 127
    -295 131
    -301 135
    -307 139
    -313 142
    -319 146
    -325 150
    -330 154
    -335 157
    -341 161
    -346 165
    -351 168
    -356 172
    -360 176
    -365 179
    -369 183
    -374 187
    -378 190
    -382 194
    -386 198
    -389 201
    -393 205
    -396 209
    -400 212
    -403 216
    -406 219
    -409 223
    -411 226
    -414 230
    -416 233
    -419 237
    -421 240
    -423 244
    -425 247
    -426 251
    -428 254
    -429 258
    -431 261
    -432 264
    -433 268
    -434 271
    -434 274
    -435 278
    -435 281
    -436 284
    -436 287
    -436 291
    -436 294
    -436 297
    -435 300
    -435 303
    -434 306
    -433 309
    -432 313
    -431 316
    -430 319
    -429 322
    -427 325
    -426 328
    -424 330
    -422 333
    -420 336
    -418 339
    -416 342
    -414 345
    -411 347
    -409 350
    -406 353
    -403 356
    -400 358
    -397 361
    -394 363
    -390 366
    -387 368
    -383 371
    -380 373
    -376 376
    -372 378
    -368 381
    -364 383
    -360 385
    -355 388
    -351 390
    -346 392
    -342 394
    -337 396
    -332 398
    -327 400
    -322 402
    -317 404
    -312 406
    -306 408
    -301 410
    -295 412
    -290 414
    -284 416
    -278 417
    -272 419
    -266 421
    -260 422
    -254 424
    -248 425
    -242 427
    -236 428
    -229 430
    -223 431
    -216 432
    -210 434
    -203 435
    -196 436
    -189 437
    -183 438
    -176 439
    -169 440
    -162 441
    -155 442
    -148 443
    -141 444
    -133 445
    -126 446
    -119 446
    -112 447
    -104 448
    -97 448
    -90 449
    -82 449
    -75 450
    -68 450
    -60 451
    -53 451
    -45 451
    -38 452
    -30 452
    -23 452
    -15 452
    -8 452
    0 452
    8 452
    15 452
    23 452
    30 452
    38 452
    45 451
    53 451
    60 451
    68 450
    75 450
    82 449
    90 449
    97 448
    104 448
    112 447
    119 446
    126 446
    133 445
    141 444
    148 443
    155 442
    162 441
    169 440
    176 439
    183 438
    189 437
    196 436
    203 435
    210 434
    216 432
    223 431
    229 430
    236 428
    242 427
    248 425
    254 424
    260 422
    266 421
    272 419
    278 417
    284 416
    290 414
    295 412
    301 410
    306 408
    312 406
    317 404
    322 402
    327 400
    332 398
    337 396
    342 394
    346 392
    351 390
    355 388
    360 385
    364 383
    368 381
    372 378
    376 376
    380 373
    383 371
    387 368
    390 366
    394 363
    397 361
    400 358
    403 356
    406 353
    409 350
    411 347
    414 345
    416 342
    418 339
    420 336
    422 333
    424 330
    426 328
    427 325
    429 322
    430 319
    431 316
    432 313
    433 309
    434 306
    435 303
    435 300
    436 297
    436 294
    436 291
    436 287
    436 284
    435 281
    435 278
    434 274
    434 271
    433 268
    432 264
    431 261
    429 258
    428 254
    426 251
    425 247
    423 244
    421 240
    419 237
    416 233
    414 230
    411 226
    409 223
    406 219
    403 216
    400 212
    396 209
    393 205
    389 201
    386 198
    382 194
    378 190
    374 187
    369 183
    365 179
    360 176
    356 172
    351 168
    346 165
    341 161
    335 157
    330 154
    325 150
    319 146
    313 142
    307 139
    301 135
    295 131
    288 127
    282 123
    275 120
    268 116
    261 112
    254 108
    247 104
    240 101
    232 97
    225 93
    217 89
    209 85
    201 82
    193 78
    185 74
    177 70
    168 66
    159 62
    151 59
    142 55
    133 51
    123 47
    114 43
    105 40
    95 36
    85 32
    76 28
    66 24
    56 20
    45 17
    35 13
    25 9
    14 5
    4 1
    -7 -3
    -18 -6
    -29 -10
    -40 -14
    -52 -18
    -63 -22
    -75 -25
    -86 -29
    -98 -33
    -110 -37
    -122 -41
    -134 -44
    -146 -48
    -158 -52
    -171 -56
    -183 -59
    -196 -63
    -209 -67
    -222 -71
    -235 -74
    -248 -78
    -261 -82
    -274 -86
    -288 -89
    -301 -93
    -315 -97
    -329 -101
    -343 -104
    -356 -108
    -371 -112
    -385 -115
    -399 -119
    -413 -123
    -428 -126
    -442 -130
    -457 -134
    -472 -137
    -487 -141
    -502 -145
    -517 -148
    -532 -152
    -547 -156
    -563 -159
    -578 -163
    -594 -166
    -609 -170
    -625 -174
    -641 -177
    -657 -181
    -673 -184
    -689 -188
    -705 -191
    -722 -195
    -738 -199
    -755 -202
    -771 -206
    -788 -209
    -805 -213
    -821 -216
    -838 -220
    -855 -223
    -872 -227
    -890 -230
    -907 -234
    -924 -237
    -942 -240
    -959 -244
    -977 -247
    -995 -251
    -1012 -254
    -1030 -258
    1034 -263
    1016 -259
    998 -256
    980 -252
    963 -249
    945 -245
    928 -242
    910 -238
    893 -235
    876 -231
    859 -228
    842 -224
    825 -221
    808 -217
    791 -214
    775 -210
    758 -206
    742 -203
    725 -199
    709 -196
    693 -192
    677 -188
    660 -185
    645 -181
    629 -178
    613 -174
    597 -170
    582 -167
    566 -163
    551 -159
    536 -156
    520 -152
    505 -148
    490 -145
    476 -141
    461 -137
    446 -133
    432 -130
    417 -126
    403 -122
    388 -118
    374 -115
    360 -111
    346 -107
    332 -103
    319 -100
    305 -96
    291 -92
    278 -88
    265 -85
    252 -81
    238 -77
    225 -73
    213 -69
    200 -66
    187 -62
    175 -58
    162 -54
    150 -50
    138 -46
    126 -43
    114 -39
    102 -35
    90 -31
    78 -27
    67 -23
    55 -19
    44 -16
    33 -12
    22 -8
    11 -4
    0 -0
    -10 4
    -21 8
    -31 12
    -42 15
    -52 19
    -62 23
    -72 27
    -82 31
    -91 35
    -101 39
    -110 43
    -120 46
    -129 50
    -138 54
    -147 58
    -155 62
    -164 66
    -173 70
    -181 74
    -189 78
    -197 81
    -205 85
    -213 89
    -221 93
    -229 97
    -236 101
    -243 105
    -251 108
    -258 112
    -265 116
    -271 120
    -278 124
    -285 128
    -291 131
    -297 135
    -303 139
    -309 143
    -315 147
    -321 151
    -326 154
    -332 158
    -337 162
    -342 166
    -347 169
    -352 173
    -357 177
    -361 181
    -366 184
    -370 188
    -374 192
    -378 195
    -382 199
    -386 203
    -389 206
    -393 210
    -396 214
    -399 217
    -402 221
    -405 225
    -408 228
    -410 232
    -413 235
    -415 239
    -417 242
    -419 246
    -421 249
    -423 253
    -424 256
    -426 260
    -427 263
    -428 267
    -429 270
    -430 273
    -431 277
    -432 280
    -432 283
    -432 287
    -433 290
    -433 293
    -433 297
    -432 300
    -432 303
    -432 306
    -431 309
    -430 312
    -429 316
    -428 319
    -427 322
    -426 325
    -424 328
    -423 331
    -421 334
    -419 337
    -417 339
    -415 342
    -413 345
    -411 348
    -408 351
    -406 354
    -403 356
    -400 359
    -397 362
    -394 364
    -391 367
    -388 370
    -384 372
    -381 375
    -377 377
    -373 380
    -370 382
    -366 384
    -361 387
    -357 389
    -353 391
    -349 394
    -344 396
    -339 398
    -335 400
    -330 402
    -325 404
    -320 407
    -315 409
    -310 411
    -304 412
    -299 414
    -293 416
    -288 418
    -282 420
    -276 422
    -271 423
    -265 425
    -259 427
    -253 428
    -247 430
    -240 431
    -234 433
    -228 434
    -221 435
    -215 437
    -208 438
    -202 439
    -195 441
    -188 442
    -182 443
    -175 444
    -168 445
    -161 446
    -154 447
    -147 448
    -140 449
    -133 450
    -126 450
    -118 451
    -111 452
    -104 452
    -97 453
    -89 454
    -82 454
    -75 455
    -67 455
    -60 455
    -52 456
    -45 456
    -37 456
    -30 457
    -22 457
    -15 457
    -7 457
    0 457
    7 457
    15 457
    22 457
    30 457
    37 456
    45 456
    52 456
    60 455
    67 455
    75 455
    82 454
    89 454
    97 453
    104 452
    111 452
    118 451
    126 450
    133 450
    140 449
    147 448
    154 447
    161 446
    168 445
    175 444
    182 443
    188 442
    195 441
    202 439
    208 438
    215 437
    221 435
    228 434
    234 433
    240 431
    247 430
    253 428
    259 427
    265 425
    271 423
    276 422
    282 420
    288 418
    293 416
    299 414
    304 412
    310 411
    315 409
    320 407
    325 404
    330 402
    335 400
    339 398
    344 396
    349 394
    353 391
    357 389
    361 387
    366 384
    370 382
    373 380
    377 377
    381 375
    384 372
    388 370
    391 367
    394 364
    397 362
    400 359
    403 356
    406 354
    408 351
    411 348
    413 345
    415 342
    417 339
    419 337
    421 334
    423 331
    424 328
    426 325
    427 322
    428 319
    429 316
    430 312
    431 309
    432 306
    432 303
    432 300
    433 297
    433 293
    433 290
    432 287
    432 283
    432 280
    431 277
    430 273
    429 270
    428 267
    427 263
    426 260
    424 256
    423 253
    421 249
    419 246
    417 242
    415 239
    413 235
    410 232
    408 228
    405 225
    402 221
    399 217
    396 214
    393 210
    389 206
    386 203
    382 199
    378 195
    374 192
    370 188
    366 184
    361 181
    357 177
    352 173
    347 169
    342 166
    337 162
    332 158
    326 154
    321 151
    315 147
    309 143
    303 139
    297 135
    291 131
    285 128
    278 124
    271 120
    265 116
    258 112
    251 108
    243 105
    236 101
    229 97
    221 93
    213 89
    205 85
    197 81
    189 78
    181 74
    173 70
    164 66
    155 62
    147 58
    138 54
    129 50
    120 46
    110 43
    101 39
    91 35
    82 31
    72 27
    62 23
    52 19
    42 15
    31 12
    21 8
    10 4
    -0 -0
    -11 -4
    -22 -8
    -33 -12
    -44 -16
    -55 -19
    -67 -23
    -78 -27
    -90 -31
    -102 -35
    -114 -39
    -126 -43
    -138 -46
    -150 -50
    -162 -54
    -175 -58
    -187 -62
    -200 -66
    -213 -69
    -225 -73
    -238 -77
    -252 -81
    -265 -85
    -278 -88
    -291 -92
    -305 -96
    -319 -100
    -332 -103
    -346 -107
    -360 -111
    -374 -115
    -388 -118
    -403 -122
    -417 -126
    -432 -130
    -446 -133
    -461 -137
    -476 -141
    -490 -145
    -505 -148
    -520 -152
    -536 -156
    -551 -159
    -566 -163
    -582 -167
    -597 -170
    -613 -174
    -629 -178
    -645 -181
    -660 -185
    -677 -188
    -693 -192
    -709 -196
    -725 -199
    -742 -203
    -758 -206
    -775 -210
    -791 -214
    -808 -217
    -825 -221
    -842 -224
    -859 -228
    -876 -231
    -893 -235
    -910 -238
    -928 -242
    -945 -245
    -963 -249
    -980 -252
    -998 -256
    -1016 -259
    -1034 -263
    1037 -268
    1019 -264
    1002 -261
    984 -257
    966 -254
    949 -250
    931 -247
    914 -243
    897 -240
    879 -236
    862 -232
    845 -229
    828 -225
    812 -222
    795 -218
    778 -214
    762 -211
    745 -207
    729 -204
    712 -200
    696 -196
    680 -193
    664 -189
    648 -185
    632 -182
    617 -178
    601 -174
    585 -170
    570 -167
    555 -163
    539 -159
    524 -156
    509 -152
    494 -148
    479 -144
    465 -140
    450 -137
    435 -133
    421 -129
    406 -125
    392 -122
    378 -118
    364 -114
    350 -110
    336 -106
    322 -103
    309 -99
    295 -95
    282 -91
    269 -87
    255 -83
    242 -79
    229 -76
    216 -72
    204 -68
    191 -64
    178 -60
    166 -56
    154 -52
    142 -48
    129 -45
    117 -41
    106 -37
    94 -33
    82 -29
    71 -25
    59 -21
    48 -17
    37 -13
    26 -9
    15 -5
    4 -2
    -6 2
    -17 6
    -27 10
    -38 14
    -48 18
    -58 22
    -68 26
    -78 30
    -87 34
    -97 38
    -106 42
    -116 46
    -125 50
    -134 54
    -143 57
    -152 61
    -160 65
    -169 69
    -177 73
    -185 77
    -194 81
    -202 85
    -209 89
    -217 93
    -225 97
    -232 101
    -240 105
    -247 108
    -254 112
    -261 116
    -268 120
    -274 124
    -281 128
    -287 132
    -293 136
    -299 140
    -305 143
    -311 147
    -317 151
    -322 155
    -328 159
    -333 163
    -338 166
    -343 170
    -348 174
    -353 178
    -357 182
    -362 185
    -366 189
    -370 193
    -374 197
    -378 200
    -382 204
    -386 208
    -389 212
    -392 215
    -395 219
    -399 223
    -401 226
    -404 230
    -407 233
    -409 237
    -411 241
    -414 244
    -416 248
    -418 251
    -419 255
    -421 258
    -422 262
    -424 265
    -425 269
    -426 272
    -427 276
    -428 279
    -428 282
    -429 286
    -429 289
    -429 293
    -429 296
    -429 299
    -429 302
    -429 306
    -428 309
    -428 312
    -427 315
    -426 318
    -425 321
    -424 325
    -423 328
    -421 331
    -420 334
    -418 337
    -416 340
    -414 343
    -412 346
    -410 348
    -408 351
    -406 354
    -403 357
    -400 360
    -398 362
    -395 365
    -392 368
    -388 371
    -385 373
    -382 376
    -378 378
    -375 381
    -371 383
    -367 386
    -363 388
    -359 391
    -355 393
    -351 395
    -346 398
    -342 400
    -337 402
    -333 404
    -328 406
    -323 408
    -318 411
    -313 413
    -308 415
    -302 417
    -297 418
    -292 420
    -286 422
    -280 424
    -275 426
    -269 428
    -263 429
    -257 431
    -251 432
    -245 434
    -239 436
    -233 437
    -226 438
    -220 440
    -214 441
    -207 443
    -200 444
    -194 445
    -187 446
    -180 447
    -174 448
    -167 450
    -160 451
    -153 452
    -146 452
    -139 453
    -132 454
    -125 455
    -118 456
    -110 456
    -103 457
    -96 458
    -89 458
    -81 459
    -74 459
    -67 460
    -59 460
    -52 460
    -45 461
    -37 461
    -30 461
    -22 461
    -15 461
    -7 462
    0 462
    7 462
    15 461
    22 461
    30 461
    37 461
    45 461
    52 460
    59 460
    67 460
    74 459
    81 459
    89 458
    96 458
    103 457
    110 456
    118 456
    125 455
    132 454
    139 453
    146 452
    153 452
    160 451
    167 450
    174 448
    180 447
    187 446
    194 445
    200 444
    207 443
    214 441
    220 440
    226 438
    233 437
    239 436
    245 434
    251 432
    257 431
    263 429
    269 428
    275 426
    280 424
    286 422
    292 420
    297 418
    302 417
    308 415
    313 413
    318 411
    323 408
    328 406
    333 404
    337 402
    342 400
    346 398
    351 395
    355 393
    359 391
    363 388
    367 386
    371 383
    375 381
    378 378
    382 376
    385 373
    388 371
    392 368
    395 365
    398 362
    400 360
    403 357
    406 354
    408 351
    410 348
    412 346
    414 343
    416 340
    418 337
    420 334
    421 331
    423 328
    424 325
    425 321
    426 318
    427 315
    428 312
    428 309
    429 306
    429 302
    429 299
    429 296
    429 293
    429 289
    429 286
    428 282
    428 279
    427 276
    426 272
    425 269
    424 265
    422 262
    421 258
    419 255
    418 251
    416 248
    414 244
    411 241
    409 237
    407 233
    404 230
    401 226
    399 223
    395 219
    392 215
    389 212
    386 208
    382 204
    378 200
    374 197
    370 193
    366 189
    362 185
    357 182
    353 178
    348 174
    343 170
    338 166
    333 163
    328 159
    322 155
    317 151
    311 147
    305 143
    299 140
    293 136
    287 132
    281 128
    274 124
    268 120
    261 116
    254 112
    247 108
    240 105
    232 101
    225 97
    217 93
    209 89
    202 85
    194 81
    185 77
    177 73
    169 69
    160 65
    152 61
    143 57
    134 54
    125 50
    116 46
    106 42
    97 38
    87 34
    78 30
    68 26
    58 22
    48 18
    38 14
    27 10
    17 6
    6 2
    -4 -2
    -15 -5
    -26 -9
    -37 -13
    -48 -17
    -59 -21
    -71 -25
    -82 -29
    -94 -33
    -106 -37
    -117 -41
    -129 -45
    -142 -48
    -154 -52
    -166 -56
    -178 -60
    -191 -64
    -204 -68
    -216 -72
    -229 -76
    -242 -79
    -255 -83
    -269 -87
    -282 -91
    -295 -95
    -309 -99
    -322 -103
    -336 -106
    -350 -110
    -364 -114
    -378 -118
    -392 -122
    -406 -125
    -421 -129
    -435 -133
    -450 -137
    -465 -140
    -479 -144
    -494 -148
    -509 -152
    -524 -156
    -539 -159
    -555 -163
    -570 -167
    -585 -170
    -601 -174
    -617 -178
    -632 -182
    -648 -185
    -664 -189
    -680 -193
    -696 -196
    -712 -200
    -729 -204
    -745 -207
    -762 -211
    -778 -214
    -795 -218
    -812 -222
    -828 -225
    -845 -229
    -862 -232
    -879 -236
    -897 -240
    -914 -243
    -931 -247
    -949 -250
    -966 -254
    -984 -257
    -1002 -261
    -1019 -264
    -1037 -268
    1041 -273
    1023 -270
    1005 -266
    987 -262
    970 -259
    952 -255
    935 -252
    918 -248
    900 -244
    883 -241
    866 -237
    849 -234
    832 -230
    815 -226
    799 -223
    782 -219
    765 -215
    749 -212
    732 -208
    716 -204
    700 -200
    684 -197
    668 -193
    652 -189
    636 -186
    620 -182
    605 -178
    589 -174
    574 -170
    558 -167
    543 -163
    528 -159
    513 -155
    498 -152
    483 -148
    468 -144
    454 -140
    439 -136
    425 -132
    410 -129
    396 -125
    382 -121
    368 -117
    354 -113
    340 -109
    326 -105
    313 -102
    299 -98
    286 -94
    272 -90
    259 -86
    246 -82
    233 -78
    220 -74
    208 -70
    195 -66
    182 -62
    170 -58
    158 -55
    145 -51
    133 -47
    121 -43
    110 -39
    98 -35
    86 -31
    75 -27
    63 -23
    52 -19
    41 -15
    30 -11
    19 -7
    8 -3
    -3 1
    -13 5
    -23 9
    -34 13
    -44 17
    -54 21
    -64 25
    -74 29
    -83 33
    -93 37
    -102 41
    -112 45
    -121 49
    -130 53
    -139 57
    -148 61
    -156 65
    -165 69
    -173 73
    -181 77
    -190 81
    -198 85
    -205 89
    -213 93
    -221 97
    -228 101
    -236 105
    -243 108
    -250 112
    -257 116
    -264 120
    -270 124
    -277 128
    -283 132
    -289 136
    -296 140
    -302 144
    -307 148
    -313 152
    -319 156
    -324 159
    -329 163
    -334 167
    -339 171
    -344 175
    -349 179
    -354 183
    -358 186
    -362 190
    -367 194
    -371 198
    -374 202
    -378 205
    -382 209
    -385 213
    -389 217
    -392 220
    -395 224
    -398 228
    -400 231
    -403 235
    -406 239
    -408 242
    -410 246
    -412 250
    -414 253
    -416 257
    -417 260
    -419 264
    -420 267
    -421 271
    -423 274
    -423 278
    -424 281
    -425 285
    -425 288
    -426 292
    -426 295
    -426 298
    -426 302
    -426 305
    -426 308
    -425 311
    -425 315
    -424 318
    -423 321
    -422 324
    -421 327
    -420 331
    -418 334
    -417 337
    -415 340
    -413 343
    -412 346
    -410 349
    -407 352
    -405 354
    -403 357
    -400 360
    -398 363
    -395 366
    -392 369
    -389 371
    -386 374
    -383 377
    -379 379
    -376 382
    -372 384
    -368 387
    -365 389
    -361 392
    -357 394
    -353 397
    -348 399
    -344 401
    -340 404
    -335 406
    -330 408
    -326 410
    -321 412
    -316 414
    -311 417
    -306 419
    -300 421
    -295 422
    -290 424
    -284 426
    -279 428
    -273 430
    -267 432
    -261 433
    -255 435
    -250 437
    -243 438
    -237 440
    -231 441
    -225 443
    -219 444
    -212 446
    -206 447
    -199 448
    -193 449
    -186 451
    -179 452
    -173 453
    -166 454
    -159 455
    -152 456
    -145 457
    -138 458
    -131 459
    -124 459
    -117 460
    -110 461
    -103 462
    -95 462
    -88 463
    -81 463
    -74 464
    -66 464
    -59 465
    -52 465
    -44 465
    -37 466
    -30 466
    -22 466
    -15 466
    -7 466
    0 466
    7 466
    15 466
    22 466
    30 466
    37 466
    44 465
    52 465
    59 465
    66 464
    74 464
    81 463
    88 463
    95 462
    103 462
    110 461
    117 460
    124 459
    131 459
    138 458
    145 457
    152 456
    159 455
    166 454
    173 453
    179 452
    186 451
    193 449
    199 448
    206 447
    212 446
    219 444
    225 443
    231 441
    237 440
    243 438
    250 437
    255 435
    261 433
    267 432
    273 430
    279 428
    284 426
    290 424
    295 422
    300 421
    306 419
    311 417
    316 414
    321 412
    326 410
    330 408
    335 406
    340 404
    344 401
    348 399
    353 397
    357 394
    361 392
    365 389
    368 387
    372 384
    376 382
    379 379
    383 377
    386 374
    389 371
    392 369
    395 366
    398 363
    400 360
    403 357
    405 354
    407 352
    410 349
    412 346
    413 343
    415 340
    417 337
    418 334
    420 331
    421 327
    422 324
    423 321
    424 318
    425 315
    425 311
    426 308
    426 305
    426 302
    426 298
    426 295
    426 292
    425 288
    425 285
    424 281
    423 278
    423 274
    421 271
    420 267
    419 264
    417 260
    416 257
    414 253
    412 250
    410 246
    408 242
    406 239
    403 235
    400 231
    398 228
    395 224
    392 220
    389 217
    385 213
    382 209
    378 205
    374 202
    371 198
    367 194
    362 190
    358 186
    354 183
    349 179
    344 175
    339 171
    334 167
    329 163
    324 159
    319 156
    313 152
    307 148
    302 144
    296 140
    289 136
    283 132
    277 128
    270 124
    264 120
    257 116
    250 112
    243 108
    236 105
    228 101
    221 97
    213 93
    205 89
    198 85
    190 81
    181 77
    173 73
    165 69
    156 65
    148 61
    139 57
    130 53
    121 49
    112 45
    102 41
    93 37
    83 33
    74 29
    64 25
    54 21
    44 17
    34 13
    23 9
    13 5
    3 1
    -8 -3
    -19 -7
    -30 -11
    -41 -15
    -52 -19
    -63 -23
    -75 -27
    -86 -31
    -98 -35
    -110 -39
    -121 -43
    -133 -47
    -145 -51
    -158 -55
    -170 -58
    -182 -62
    -195 -66
    -208 -70
    -220 -74
    -233 -78
    -246 -82
    -259 -86
    -272 -90
    -286 -94
    -299 -98
    -313 -102
    -326 -105
    -340 -109
    -354 -113
    -368 -117
    -382 -121
    -396 -125
    -410 -129
    -425 -132
    -439 -136
    -454 -140
    -468 -144
    -483 -148
    -498 -152
    -513 -155
    -528 -159
    -543 -163
    -558 -167
    -574 -170
    -589 -174
    -605 -178
    -620 -182
    -636 -186
    -652 -189
    -668 -193
    -684 -197
    -700 -200
    -716 -204
    -732 -208
    -749 -212
    -765 -215
    -782 -219
    -799 -223
    -815 -226
    -832 -230
    -849 -234
    -866 -237
    -883 -241
    -900 -244
    -918 -248
    -935 -252
    -952 -255
    -970 -259
    -987 -262
    -1005 -266
    -1023 -270
    -1041 -273
    1044 -278
    1026 -275
    1009 -271
    991 -268
    973 -264
    956 -260
    939 -257
    921 -253
    904 -249
    887 -246
    870 -242
    853 -238
    836 -235
    819 -231
    802 -227
    786 -223
    769 -220
    753 -216
    736 -212
    720 -208
    704 -205
    688 -201
    672 -197
    656 -193
    640 -190
    624 -186
    609 -182
    593 -178
    578 -174
    562 -171
    547 -167
    532 -163
    517 -159
    502 -155
    487 -151
    472 -147
    458 -144
    443 -140
    428 -136
    414 -132
    400 -128
    386 -124
    372 -120
    358 -116
    344 -112
    330 -108
    317 -104
    303 -100
    290 -97
    276 -93
    263 -89
    250 -85
    237 -81
    224 -77
    211 -73
    199 -69
    186 -65
    174 -61
    162 -57
    149 -53
    137 -49
    125 -45
    114 -41
    102 -37
    90 -33
    79 -29
    67 -25
    56 -21
    45 -17
    34 -13
    23 -9
    12 -5
    1 -1
    -9 3
    -19 8
    -30 12
    -40 16
    -50 20
    -60 24
    -70 28
    -79 32
    -89 36
    -98 40
    -108 44
    -117 48
    -126 52
    -135 56
    -144 60
    -152 64
    -161 68
    -169 72
    -177 76
    -186 80
    -194 84
    -201 88
    -209 92
    -217 96
    -224 100
    -232 104
    -239 108
    -246 112
    -253 116
    -260 120
    -266 124
    -273 128
    -279 132
    -285 136
    -292 140
    -298 144
    -303 148
    -309 152
    -315 156
    -320 160
    -325 164
    -331 168
    -336 172
    -340 176
    -345 180
    -350 184
    -354 187
    -359 191
    -363 195
    -367 199
    -371 203
    -374 207
    -378 210
    -382 214
    -385 218
    -388 222
    -391 225
    -394 229
    -397 233
    -399 237
    -402 240
    -404 244
    -406 248
    -409 251
    -410 255
    -412 259
    -414 262
    -415 266
    -417 269
    -418 273
    -419 276
    -420 280
    -421 283
    -421 287
    -422 290
    -422 294
    -423 297
    -423 301
    -423 304
    -423 307
    -422 311
    -422 314
    -421 317
    -421 321
    -420 324
    -419 327
    -418 330
    -417 333
    -415 336
    -414 339
    -412 343
    -410 346
    -409 349
    -407 352
    -404 355
    -402 358
    -400 360
    -397 363
    -395 366
    -392 369
    -389 372
    -386 374
    -383 377
    -380 380
    -377 383
    -373 385
    -370 388
    -366 390
    -362 393
    -358 395
    -354 398
    -350 400
    -346 403
    -342 405
    -337 407
    -333 410
    -328 412
    -323 414
    -319 416
    -314 418
    -309 420
    -304 422
    -298 424
    -293 426
    -288 428
    -282 430
    -277 432
    -271 434
    -265 436
    -260 437
    -254 439
    -248 441
    -242 442
    -236 444
    -230 445
    -223 447
    -217 448
    -211 450
    -204 451
    -198 452
    -191 454
    -185 455
    -178 456
    -171 457
    -165 458
    -158 459
    -151 460
    -144 461
    -137 462
    -130 463
    -123 464
    -116 465
    -109 465
    -102 466
    -95 467
    -88 467
    -80 468
    -73 468
    -66 469
    -59 469
    -51 469
    -44 470
    -37 470
    -29 470
    -22 470
    -15 470
    -7 470
    0 471
    7 470
    15 470
    22 470
    29 470
    37 470
    44 470
    51 469
    59 469
    66 469
    73 468
    80 468
    88 467
    95 467
    102 466
    109 465
    116 465
    123 464
    130 463
    137 462
    144 461
    151 460
    158 459
    165 458
    171 457
    178 456
    185 455
    191 454
    198 452
    204 451
    211 450
    217 448
    223 447
    230 445
    236 444
    242 442
    248 441
    254 439
    260 437
    265 436
    271 434
    277 432
    282 430
    288 428
    293 426
    298 424
    304 422
    309 420
    314 418
    319 416
    323 414
    328 412
    333 410
    337 407
    342 405
    346 403
    350 400
    354 398
    358 395
    362 393
    366 390
    370 388
    373 385
    377 383
    380 380
    383 377
    386 374
    389 372
    392 369
    395 366
    397 363
    400 360
    402 358
    404 355
    407 352
    409 349
    410 346
    412 343
    414 339
    415 336
    417 333
    418 330
    419 327
    420 324
    421 321
    421 317
    422 314
    422 311
    423 307
    423 304
    423 301
    423 297
    422 294
    422 290
    421 287
    421 283
    420 280
    419 276
    418 273
    417 269
    415 266
    414 262
    412 259
    410 255
    409 251
    406 248
    404 244
    402 240
    399 237
    397 233
    394 229
    391 225
    388 222
    385 218
    382 214
    378 210
    374 207
    371 203
    367 199
    363 195
    359 191
    354 187
    350 184
    345 180
    340 176
    336 172
    331 168
    325 164
    320 160
    315 156
    309 152
    303 148
    298 144
    292 140
    285 136
    279 132
    273 128
    266 124
    260 120
    253 116
    246 112
    239 108
    232 104
    224 100
    217 96
    209 92
    201 88
    194 84
    186 80
    177 76
    169 72
    161 68
    152 64
    144 60
    135 56
    126 52
    117 48
    108 44
    98 40
    89 36
    79 32
    70 28
    60 24
    50 20
    40 16
    30 12
    19 8
    9 3
    -1 -1
    -12 -5
    -23 -9
    -34 -13
    -45 -17
    -56 -21
    -67 -25
    -79 -29
    -90 -33
    -102 -37
    -114 -41
    -125 -45
    -137 -49
    -149 -53
    -162 -57
    -174 -61
    -186 -65
    -199 -69
    -211 -73
    -224 -77
    -237 -81
    -250 -85
    -263 -89
    -276 -93
    -290 -97
    -303 -100
    -317 -104
    -330 -108
    -344 -112
    -358 -116
    -372 -120
    -386 -124
    -400 -128
    -414 -132
    -428 -136
    -443 -140
    -458 -144
    -472 -147
    -487 -151
    -502 -155
    -517 -159
    -532 -163
    -547 -167
    -562 -171
    -578 -174
    -593 -178
    -609 -182
    -624 -186
    -640 -190
    -656 -193
    -672 -197
    -688 -201
    -704 -205
    -720 -208
    -736 -212
    -753 -216
    -769 -220
    -786 -223
    -802 -227
    -819 -231
    -836 -235
    -853 -238
    -870 -242
    -887 -246
    -904 -249
    -921 -253
    -939 -257
    -956 -260
    -973 -264
    -991 -268
    -1009 -271
    -1026 -275
    -1044 -278
    1048 -284
    1030 -280
    1012 -276
    995 -273
    977 -269
    960 -265
    942 -262
    925 -258
    908 -254
    890 -251
    873 -247
    856 -243
    840 -239
    823 -236
    806 -232
    789 -228
    773 -224
    756 -220
    740 -217
    724 -213
    708 -209
    691 -205
    675 -201
    660 -198
    644 -194
    628 -190
    612 -186
    597 -182
    581 -178
    566 -174
    551 -170
    536 -167
    521 -163
    506 -159
    491 -155
    476 -151
    461 -147
    447 -143
    432 -139
    418 -135
    404 -131
    390 -127
    376 -123
    362 -119
    348 -115
    334 -111
    321 -107
    307 -103
    294 -99
    280 -95
    267 -91
    254 -87
    241 -83
    228 -79
    215 -75
    203 -71
    190 -67
    178 -63
    166 -59
    153 -55
    141 -51
    129 -47
    118 -43
    106 -39
    94 -35
    83 -31
    71 -27
    60 -23
    49 -18
    38 -14
    27 -10
    16 -6
    6 -2
    -5 2
    -15 6
    -26 10
    -36 14
    -46 18
    -56 22
    -66 27
    -75 31
    -85 35
    -94 39
    -104 43
    -113 47
    -122 51
    -131 55
    -140 59
    -148 63
    -157 67
    -165 72
    -173 76
    -182 80
    -190 84
    -197 88
    -205 92
    -213 96
    -220 100
    -228 104
    -235 108
    -242 112
    -249 116
    -256 120
    -262 124
    -269 128
    -275 133
    -281 137
    -288 141
    -294 145
    -299 149
    -305 153
    -311 157
    -316 161
    -321 165
    -327 169
    -332 172
    -337 176
    -341 180
    -346 184
    -350 188
    -355 192
    -359 196
    -363 200
    -367 204
    -371 208
    -374 212
    -378 215
    -381 219
    -384 223
    -387 227
    -390 231
    -393 234
    -396 238
    -398 242
    -401 246
    -403 249
    -405 253
    -407 257
    -409 260
    -410 264
    -412 268
    -413 271
    -414 275
    -415 278
    -416 282
    -417 286
    -418 289
    -419 293
    -419 296
    -419 299
    -419 303
    -419 306
    -419 310
    -419 313
    -419 316
    -418 320
    -417 323
    -417 326
    -416 329
    -415 333
    -413 336
    -412 339
    -411 342
    -409 345
    -407 348
    -406 351
    -404 354
    -401 357
    -399 360
    -397 363
    -394 366
    -392 369
    -389 372
    -386 375
    -383 378
    -380 380
    -377 383
    -374 386
    -371 388
    -367 391
    -363 394
    -360 396
    -356 399
    -352 401
    -348 404
    -344 406
    -339 408
    -335 411
    -330 413
    -326 415
    -321 418
    -316 420
    -312 422
    -307 424
    -302 426
    -296 428
    -291 430
    -286 432
    -280 434
    -275 436
    -269 438
    -264 440
    -258 441
    -252 443
    -246 445
    -240 446
    -234 448
    -228 449
    -222 451
    -216 452
    -209 454
    -203 455
    -197 456
    -190 458
    -184 459
    -177 460
    -170 461
    -164 462
    -157 463
    -150 464
    -143 465
    -136 466
    -129 467
    -122 468
    -115 469
    -108 469
    -101 470
    -94 471
    -87 471
    -80 472
    -73 472
    -65 473
    -58 473
    -51 474
    -44 474
    -36 474
    -29 474
    -22 475
    -15 475
    -7 475
    0 475
    7 475
    15 475
    22 475
    29 474
    36 474
    44 474
    51 474
    58 473
    65 473
    73 472
    80 472
    87 471
    94 471
    101 470
    108 469
    115 469
    122 468
    129 467
    136 466
    143 465
    150 464
    157 463
    164 462
    170 461
    177 460
    184 459
    190 458
    197 456
    203 455
    209 454
    216 452
    222 451
    228 449
    234 448
    240 446
    246 445
    252 443
    258 441
    264 440
    269 438
    275 436
    280 434
    286 432
    291 430
    296 428
    302 426
    307 424
    312 422
    316 420
    321 418
    326 415
    330 413
    335 411
    339 408
    344 406
    348 404
    352 401
    356 399
    360 396
    363 394
    367 391
    371 388
    374 386
    377 383
    380 380
    383 378
    386 375
    389 372
    392 369
    394 366
    397 363
    399 360
    401 357
    404 354
    406 351
    407 348
    409 345
    411 342
    412 339
    413 336
    415 333
    416 329
    417 326
    417 323
    418 320
    419 316
    419 313
    419 310
    419 306
    419 303
    419 299
    419 296
    419 293
    418 289
    417 286
    416 282
    415 278
    414 275
    413 271
    412 268
    410 264
    409 260
    407 257
    405 253
    403 249
    401 246
    398 242
    396 238
    393 234
    390 231
    387 227
    384 223
    381 219
    378 215
    374 212
    371 208
    367 204
    363 200
    359 196
    355 192
    350 188
    346 184
    341 180
    337 176
    332 172
    327 169
    321 165
    316 161
    311 157
    305 153
    299 149
    294 145
    288 141
    281 137
    275 133
    269 128
    262 124
    256 120
    249 116
    242 112
    235 108
    228 104
    220 100
    213 96
    205 92
    197 88
    190 84
    182 80
    173 76
    165 72
    157 67
    148 63
    140 59
    131 55
    122 51
    113 47
    104 43
    94 39
    85 35
    75 31
    66 27
    56 22
    46 18
    36 14
    26 10
    15 6
    5 2
    -6 -2
    -16 -6
    -27 -10
    -38 -14
    -49 -18
    -60 -23
    -71 -27
    -83 -31
    -94 -35
    -106 -39
    -118 -43
    -129 -47
    -141 -51
    -153 -55
    -166 -59
    -178 -63
    -190 -67
    -203 -71
    -215 -75
    -228 -79
    -241 -83
    -254 -87
    -267 -91
    -280 -95
    -294 -99
    -307 -103
    -321 -107
    -334 -111
    -348 -115
    -362 -119
    -376 -123
    -390 -127
    -404 -131
    -418 -135
    -432 -139
    -447 -143
    -461 -147
    -476 -151
    -491 -155
    -506 -159
    -521 -163
    -536 -167
    -551 -170
    -566 -174
    -581 -178
    -597 -182
    -612 -186
    -628 -190
    -644 -194
    -660 -198
    -675 -201
    -691 -205
    -708 -209
    -724 -213
    -740 -217
    -756 -220
    -773 -224
    -789 -228
    -806 -232
    -823 -236
    -840 -239
    -856 -243
    -873 -247
    -890 -251
    -908 -254
    -925 -258
    -942 -262
    -960 -265
    -977 -269
    -995 -273
    -1012 -276
    -1030 -280
    -1048 -284
    1052 -289
    1034 -285
    1016 -282
    998 -278
    981 -274
    963 -271
    946 -267
    929 -263
    911 -259
    894 -255
    877 -252
    860 -248
    843 -244
    826 -240
    810 -236
    793 -233
    777 -229
    760 -225
    744 -221
    728 -217
    711 -213
    695 -210
    679 -206
    663 -202
    648 -198
    632 -194
    616 -190
    601 -186
    585 -182
    570 -178
    555 -174
    540 -170
    525 -166
    510 -162
    495 -159
    480 -155
    465 -151
    451 -147
    436 -143
    422 -139
    408 -135
    394 -131
    380 -127
    366 -123
    352 -118
    338 -114
    325 -110
    311 -106
    298 -102
    284 -98
    271 -94
    258 -90
    245 -86
    232 -82
    220 -78
    207 -74
    194 -70
    182 -66
    170 -62
    157 -57
    145 -53
    133 -49
    122 -45
    110 -41
    98 -37
    87 -33
    75 -29
    64 -24
    53 -20
    42 -16
    31 -12
    20 -8
    10 -4
    -1 0
    -11 4
    -22 9
    -32 13
    -42 17
    -52 21
    -62 25
    -71 29
    -81 34
    -90 38
    -99 42
    -109 46
    -118 50
    -127 54
    -135 58
    -144 63
    -153 67
    -161 71
    -169 75
    -177 79
    -185 83
    -193 87
    -201 92
    -209 96
    -216 100
    -223 104
    -231 108
    -238 112
    -245 116
    -252 120
    -258 124
    -265 128
    -271 133
    -277 137
    -284 141
    -290 145
    -295 149
    -301 153
    -307 157
    -312 161
    -317 165
    -323 169
    -328 173
    -333 177
    -337 181
    -342 185
    -346 189
    -351 193
    -355 197
    -359 201
    -363 205
    -367 209
    -370 213
    -374 216
    -377 220
    -380 224
    -384 228
    -386 232
    -389 236
    -392 239
    -394 243
    -397 247
    -399 251
    -401 255
    -403 258
    -405 262
    -407 266
    -408 269
    -410 273
    -411 277
    -412 280
    -413 284
    -414 287
    -414 291
    -415 295
    -415 298
    -416 302
    -416 305
    -416 308
    -416 312
    -416 315
    -415 319
    -415 322
    -414 325
    -413 329
    -412 332
    -411 335
    -410 338
    -409 342
    -408 345
    -406 348
    -404 351
    -402 354
    -401 357
    -398 360
    -396 363
    -394 366
    -392 369
    -389 372
    -386 375
    -384 378
    -381 381
    -378 383
    -374 386
    -371 389
    -368 392
    -364 394
    -361 397
    -357 399
    -353 402
    -349 405
    -345 407
    -341 409
    -337 412
    -333 414
    -328 417
    -324 419
    -319 421
    -314 423
    -309 425
    -305 428
    -299 430
    -294 432
    -289 434
    -284 436
    -279 438
    -273 440
    -268 441
    -262 443
    -256 445
    -250 447
    -245 448
    -239 450
    -233 452
    -227 453
    -220 455
    -214 456
    -208 458
    -202 459
    -195 460
    -189 462
    -182 463
    -176 464
    -169 465
    -163 466
    -156 467
    -149 468
    -142 469
    -135 470
    -129 471
    -122 472
    -115 473
    -108 474
    -101 474
    -94 475
    -86 476
    -79 476
    -72 477
    -65 477
    -58 477
    -51 478
    -43 478
    -36 478
    -29 479
    -22 479
    -15 479
    -7 479
    0 479
    7 479
    15 479
    22 479
    29 479
    36 478
    43 478
    51 478
    58 477
    65 477
    72 477
    79 476
    86 476
    94 475
    101 474
    108 474
    115 473
    122 472
    129 471
    135 470
    142 469
    149 468
    156 467
    163 466
    169 465
    176 464
    182 463
    189 462
    195 460
    202 459
    208 458
    214 456
    220 455
    227 453
    233 452
    239 450
    245 448
    250 447
    256 445
    262 443
    268 441
    273 440
    279 438
    284 436
    289 434
    294 432
    299 430
    305 428
    309 425
    314 423
    319 421
    324 419
    328 417
    333 414
    337 412
    341 409
    345 407
    349 405
    353 402
    357 399
    361 397
    364 394
    368 392
    371 389
    374 386
    378 383
    381 381
    384 378
    386 375
    389 372
    392 369
    394 366
    396 363
    398 360
    401 357
    402 354
    404 351
    406 348
    408 345
    409 342
    410 338
    411 335
    412 332
    413 329
    414 325
    415 322
    415 319
    416 315
    416 312
    416 308
    416 305
    416 302
    415 298
    415 295
    414 291
    414 287
    413 284
    412 280
    411 277
    410 273
    408 269
    407 266
    405 262
    403 258
    401 255
    399 251
    397 247
    394 243
    392 239
    389 236
    386 232
    384 228
    380 224
    377 220
    374 216
    370 213
    367 209
    363 205
    359 201
    355 197
    351 193
    346 189
    342 185
    337 181
    333 177
    328 173
    323 169
    317 165
    312 161
    307 157
    301 153
    295 149
    290 145
    284 141
    277 137
    271 133
    265 128
    258 124
    252 120
    245 116
    238 112
    231 108
    223 104
    216 100
    209 96
    201 92
    193 87
    185 83
    177 79
    169 75
    161 71
    153 67
    144 63
    135 58
    127 54
    118 50
    109 46
    99 42
    90 38
    81 34
    71 29
    62 25
    52 21
    42 17
    32 13
    22 9
    11 4
    1 0
    -10 -4
    -20 -8
    -31 -12
    -42 -16
    -53 -20
    -64 -24
    -75 -29
    -87 -33
    -98 -37
    -110 -41
    -122 -45
    -133 -49
    -145 -53
    -157 -57
    -170 -62
    -182 -66
    -194 -70
    -207 -74
    -220 -78
    -232 -82
    -245 -86
    -258 -90
    -271 -94
    -284 -98
    -298 -102
    -311 -106
    -325 -110
    -338 -114
    -352 -118
    -366 -123
    -380 -127
    -394 -131
    -408 -135
    -422 -139
    -436 -143
    -451 -147
    -465 -151
    -480 -155
    -495 -159
    -510 -162
    -525 -166
    -540 -170
    -555 -174
    -570 -178
    -585 -182
    -601 -186
    -616 -190
    -632 -194
    -648 -198
    -663 -202
    -679 -206
    -695 -210
    -711 -213
    -728 -217
    -744 -221
    -760 -225
    -777 -229
    -793 -233
    -810 -236
    -826 -240
    -843 -244
    -860 -248
    -877 -252
    -894 -255
    -911 -259
    -929 -263
    -946 -267
    -963 -271
    -981 -274
    -998 -278
    -1016 -282
    -1034 -285
    -1052 -289
    1055 -295
    1038 -291
    1020 -287
    1002 -283
    985 -280
    967 -276
    950 -272
    932 -268
    915 -264
    898 -260
    881 -257
    864 -253
    847 -249
    830 -245
    814 -241
    797 -237
    780 -233
    764 -230
    748 -226
    731 -222
    715 -218
    699 -214
    683 -210
    667 -206
    651 -202
    636 -198
    620 -194
    605 -190
    589 -186
    574 -182
    559 -178
    544 -174
    529 -170
    514 -166
    499 -162
    484 -158
    469 -154
    455 -150
    440 -146
    426 -142
    412 -138
    398 -134
    384 -130
    370 -126
    356 -122
    342 -118
    329 -113
    315 -109
    302 -105
    288 -101
    275 -97
    262 -93
    249 -89
    236 -85
    224 -81
    211 -76
    199 -72
    186 -68
    174 -64
    162 -60
    150 -56
    138 -52
    126 -47
    114 -43
    102 -39
    91 -35
    80 -31
    68 -26
    57 -22
    46 -18
    35 -14
    24 -10
    14 -6
    3 -1
    -7 3
    -17 7
    -28 11
    -38 15
    -48 20
    -57 24
    -67 28
    -77 32
    -86 36
    -95 41
    -104 45
    -114 49
    -122 53
    -131 57
    -140 62
    -148 66
    -157 70
    -165 74
    -173 78
    -181 83
    -189 87
    -197 91
    -205 95
    -212 99
    -219 103
    -227 108
    -234 112
    -241 116
    -247 120
    -254 124
    -261 128
    -267 133
    -273 137
    -279 141
    -285 145
    -291 149
    -297 153
    -303 157
    -308 161
    -313 165
    -319 169
    -324 173
    -329 178
    -333 182
    -338 186
    -342 190
    -347 194
    -351 198
    -355 202
    -359 206
    -363 210
    -366 213
    -370 217
    -373 221
    -377 225
    -380 229
    -383 233
    -385 237
    -388 241
    -391 245
    -393 248
    -395 252
    -397 256
    -399 260
    -401 264
    -403 267
    -404 271
    -406 275
    -407 278
    -408 282
    -409 286
    -410 289
    -411 293
    -411 296
    -412 300
    -412 304
    -412 307
    -413 311
    -412 314
    -412 317
    -412 321
    -411 324
    -411 328
    -410 331
    -409 334
    -408 338
    -407 341
    -406 344
    -404 347
    -403 350
    -401 354
    -399 357
    -397 360
    -395 363
    -393 366
    -391 369
    -389 372
    -386 375
    -383 378
    -381 381
    -378 384
    -375 386
    -372 389
    -369 392
    -365 395
    -362 397
    -358 400
    -355 403
    -351 405
    -347 408
    -343 410
    -339 413
    -335 415
    -330 417
    -326 420
    -321 422
    -317 424
    -312 427
    -307 429
    -302 431
    -297 433
    -292 435
    -287 437
    -282 439
    -277 441
    -271 443
    -266 445
    -260 447
    -254 449
    -249 450
    -243 452
    -237 454
    -231 455
    -225 457
    -219 459
    -213 460
    -207 461
    -200 463
    -194 464
    -188 465
    -181 467
    -175 468
    -168 469
    -161 470
    -155 471
    -148 472
    -141 473
    -134 474
    -128 475
    -121 476
    -114 477
    -107 478
    -100 478
    -93 479
    -86 480
    -79 480
    -72 481
    -65 481
    -57 481
    -50 482
    -43 482
    -36 482
    -29 483
    -22 483
    -14 483
    -7 483
    0 483
    7 483
    14 483
    22 483
    29 483
    36 482
    43 482
    50 482
    57 481
    65 481
    72 481
    79 480
    86 480
    93 479
    100 478
    107 478
    114 477
    121 476
    128 475
    134 474
    141 473
    148 472
    155 471
    161 470
    168 469
    175 468
    181 467
    188 465
    194 464
    200 463
    207 461
    213 460
    219 459
    225 457
    231 455
    237 454
    243 452
    249 450
    254 449
    260 447
    266 445
    271 443
    277 441
    282 439
    287 437
    292 435
    297 433
    302 431
    307 429
    312 427
    317 424
    321 422
    326 420
    330 417
    335 415
    339 413
    343 410
    347 408
    351 405
    355 403
    358 400
    362 397
    365 395
    369 392
    372 389
    375 386
    378 384
    381 381
    383 378
    386 375
    389 372
    391 369
    393 366
    395 363
    397 360
    399 357
    401 354
    403 350
    404 347
    406 344
    407 341
    408 338
    409 334
    410 331
    411 328
    411 324
    412 321
    412 317
    412 314
    413 311
    412 307
    412 304
    412 300
    411 296
    411 293
    410 289
    409 286
    408 282
    407 278
    406 275
    404 271
    403 267
    401 264
    399 260
    397 256
    395 252
    393 248
    391 245
    388 241
    385 237
    383 233
    380 229
    377 225
    373 221
    370 217
    366 213
    363 210
    359 206
    355 202
    351 198
    347 194
    342 190
    338 186
    333 182
    329 178
    324 173
    319 169
    313 165
    308 161
    303 157
    297 153
    291 149
    285 145
    279 141
    273 137
    267 133
    261 128
    254 124
    247 120
    241 116
    234 112
    227 108
    219 103
    212 99
    205 95
    197 91
    189 87
    181 83
    173 78
    165 74
    157 70
    148 66
    140 62
    131 57
    122 53
    114 49
    104 45
    95 41
    86 36
    77 32
    67 28
    57 24
    48 20
    38 15
    28 11
    17 7
    7 3
    -3 -1
    -14 -6
    -24 -10
    -35 -14
    -46 -18
    -57 -22
    -68 -26
    -80 -31
    -91 -35
    -102 -39
    -114 -43
    -126 -47
    -138 -52
    -150 -56
    -162 -60
    -174 -64
    -186 -68
    -199 -72
    -211 -76
    -224 -81
    -236 -85
    -249 -89
    -262 -93
    -275 -97
    -288 -101
    -302 -105
    -315 -109
    -329 -113
    -342 -118
    -356 -122
    -370 -126
    -384 -130
    -398 -134
    -412 -138
    -426 -142
    -440 -146
    -455 -150
    -469 -154
    -484 -158
    -499 -162
    -514 -166
    -529 -170
    -544 -174
    -559 -178
    -574 -182
    -589 -186
    -605 -190
    -620 -194
    -636 -198
    -651 -202
    -667 -206
    -683 -210
    -699 -214
    -715 -218
    -731 -222
    -748 -226
    -764 -230
    -780 -233
    -797 -237
    -814 -241
    -830 -245
    -847 -249
    -864 -253
    -881 -257
    -898 -260
    -915 -264
    -932 -268
    -950 -272
    -967 -276
    -985 -280
    -1002 -283
    -1020 -287
    -1038 -291
    -1055 -295
    1059 -300
    1041 -296
    1024 -292
    1006 -289
    988 -285
    971 -281
    954 -277
    936 -273
    919 -269
    902 -265
    885 -262
    868 -258
    851 -254
    834 -250
    818 -246
    801 -242
    784 -238
    768 -234
    752 -230
    735 -226
    719 -222
    703 -218
    687 -214
    671 -210
    655 -206
    640 -202
    624 -198
    609 -194
    593 -190
    578 -186
    563 -182
    548 -178
    533 -174
    518 -170
    503 -166
    488 -162
    473 -158
    459 -154
    444 -150
    430 -146
    416 -141
    402 -137
    388 -133
    374 -129
    360 -125
    346 -121
    333 -117
    319 -112
    306 -108
    293 -104
    279 -100
    266 -96
    253 -92
    241 -87
    228 -83
    215 -79
    203 -75
    190 -71
    178 -67
    166 -62
    154 -58
    142 -54
    130 -50
    118 -45
    107 -41
    95 -37
    84 -33
    73 -29
    61 -24
    50 -20
    39 -16
    29 -12
    18 -7
    8 -3
    -3 1
    -13 5
    -23 10
    -33 14
    -43 18
    -53 22
    -63 27
    -72 31
    -82 35
    -91 39
    -100 44
    -109 48
    -118 52
    -127 56
    -136 61
    -144 65
    -153 69
    -161 73
    -169 78
    -177 82
    -185 86
    -193 90
    -200 95
    -208 99
    -215 103
    -222 107
    -229 111
    -236 116
    -243 120
    -250 124
    -256 128
    -263 132
    -269 137
    -275 141
    -281 145
    -287 149
    -293 153
    -299 157
    -304 162
    -309 166
    -315 170
    -320 174
    -324 178
    -329 182
    -334 186
    -338 190
    -343 194
    -347 198
    -351 202
    -355 206
    -359 210
    -362 214
    -366 218
    -369 222
    -373 226
    -376 230
    -379 234
    -382 238
    -384 242
    -387 246
    -389 250
    -391 254
    -394 257
    -396 261
    -397 265
    -399 269
    -401 272
    -402 276
    -403 280
    -405 284
    -406 287
    -407 291
    -407 295
    -408 298
    -408 302
    -409 305
    -409 309
    -409 313
    -409 316
    -409 319
    -408 323
    -408 326
    -407 330
    -407 333
    -406 337
    -405 340
    -404 343
    -402 346
    -401 350
    -400 353
    -398 356
    -396 359
    -394 362
    -392 365
    -390 369
    -388 372
    -386 375
    -383 378
    -381 381
    -378 383
    -375 386
    -372 389
    -369 392
    -366 395
    -362 398
    -359 400
    -356 403
    -352 406
    -348 408
    -344 411
    -340 413
    -336 416
    -332 418
    -328 421
    -324 423
    -319 425
    -314 428
    -310 430
    -305 432
    -300 434
    -295 437
    -290 439
    -285 441
    -280 443
    -275 445
    -269 447
    -264 449
    -258 450
    -253 452
    -247 454
    -241 456
    -235 457
    -229 459
    -224 461
    -217 462
    -211 464
    -205 465
    -199 466
    -193 468
    -186 469
    -180 470
    -173 472
    -167 473
    -160 474
    -154 475
    -147 476
    -140 477
    -134 478
    -127 479
    -120 480
    -113 481
    -106 481
    -99 482
    -92 483
    -85 483
    -78 484
    -71 484
    -64 485
    -57 485
    -50 486
    -43 486
    -36 486
    -29 486
    -21 487
    -14 487
    -7 487
    0 487
    7 487
    14 487
    21 487
    29 486
    36 486
    43 486
    50 486
    57 485
    64 485
    71 484
    78 484
    85 483
    92 483
    99 482
    106 481
    113 481
    120 480
    127 479
    134 478
    140 477
    147 476
    154 475
    160 474
    167 473
    173 472
    180 470
    186 469
    193 468
    199 466
    205 465
    211 464
    217 462
    224 461
    229 459
    235 457
    241 456
    247 454
    253 452
    258 450
    264 449
    269 447
    275 445
    280 443
    285 441
    290 439
    295 437
    300 434
    305 432
    310 430
    314 428
    319 425
    324 423
    328 421
    332 418
    336 416
    340 413
    344 411
    348 408
    352 406
    356 403
    359 400
    362 398
    366 395
    369 392
    372 389
    375 386
    378 383
    381 381
    383 378
    386 375
    388 372
    390 369
    392 365
    394 362
    396 359
    398 356
    400 353
    401 350
    402 346
    404 343
    405 340
    406 337
    407 333
    407 330
    408 326
    408 323
    409 319
    409 316
    409 313
    409 309
    409 305
    408 302
    408 298
    407 295
    407 291
    406 287
    405 284
    403 280
    402 276
    401 272
    399 269
    397 265
    396 261
    394 257
    391 254
    389 250
    387 246
    384 242
    382 238
    379 234
    376 230
    373 226
    369 222
    366 218
    362 214
    359 210
    355 206
    351 202
    347 198
    343 194
    338 190
    334 186
    329 182
    324 178
    320 174
    315 170
    309 166
    304 162
    299 157
    293 153
    287 149
    281 145
    275 141
    269 137
    263 132
    256 128
    250 124
    243 120
    236 116
    229 111
    222 107
    215 103
    208 99
    200 95
    193 90
    185 86
    177 82
    169 78
    161 73
    153 69
    144 65
    136 61
    127 56
    118 52
    109 48
    100 44
    91 39
    82 35
    72 31
    63 27
    53 22
    43 18
    33 14
    23 10
    13 5
    3 1
    -8 -3
    -18 -7
    -29 -12
    -39 -16
    -50 -20
    -61 -24
    -73 -29
    -84 -33
    -95 -37
    -107 -41
    -118 -45
    -130 -50
    -142 -54
    -154 -58
    -166 -62
    -178 -67
    -190 -71
    -203 -75
    -215 -79
    -228 -83
    -241 -87
    -253 -92
    -266 -96
    -279 -100
    -293 -104
    -306 -108
    -319 -112
    -333 -117
    -346 -121
    -360 -125
    -374 -129
    -388 -133
    -402 -137
    -416 -141
    -430 -146
    -444 -150
    -459 -154
    -473 -158
    -488 -162
    -503 -166
    -518 -170
    -533 -174
    -548 -178
    -563 -182
    -578 -186
    -593 -190
    -609 -194
    -624 -198
    -640 -202
    -655 -206
    -671 -210
    -687 -214
    -703 -218
    -719 -222
    -735 -226
    -752 -230
    -768 -234
    -784 -238
    -801 -242
    -818 -246
    -834 -250
    -851 -254
    -868 -258
    -885 -262
    -902 -265
    -919 -269
    -936 -273
    -954 -277
    -971 -281
    -988 -285
    -1006 -289
    -1024 -292
    -1041 -296
    -1059 -300
    1063 -306
    1045 -302
    1027 -298
    1010 -294
    992 -290
    975 -286
    957 -282
    940 -278
    923 -274
    906 -271
    889 -267
    872 -263
    855 -259
    838 -255
    821 -251
    805 -247
    788 -243
    772 -239
    756 -235
    739 -231
    723 -227
    707 -223
    691 -219
    675 -215
    659 -211
    644 -207
    628 -203
    613 -198
    597 -194
    582 -190
    567 -186
    552 -182
    537 -178
    522 -174
    507 -170
    492 -166
    478 -162
    463 -157
    449 -153
    434 -149
    420 -145
    406 -141
    392 -137
    378 -132
    364 -128
    351 -124
    337 -120
    323 -116
    310 -111
    297 -107
    284 -103
    271 -99
    258 -95
    245 -90
    232 -86
    219 -82
    207 -78
    195 -73
    182 -69
    170 -65
    158 -61
    146 -56
    134 -52
    122 -48
    111 -43
    99 -39
    88 -35
    77 -31
    66 -26
    55 -22
    44 -18
    33 -13
    22 -9
    12 -5
    1 -1
    -9 4
    -19 8
    -29 12
    -39 17
    -49 21
    -59 25
    -68 30
    -78 34
    -87 38
    -96 42
    -105 47
    -114 51
    -123 55
    -131 60
    -140 64
    -148 68
    -157 73
    -165 77
    -173 81
    -181 85
    -188 90
    -196 94
    -204 98
    -211 102
    -218 107
    -225 111
    -232 115
    -239 120
    -246 124
    -252 128
    -259 132
    -265 136
    -271 141
    -277 145
    -283 149
    -289 153
    -294 157
    -300 162
    -305 166
    -310 170
    -315 174
    -320 178
    -325 182
    -330 187
    -334 191
    -339 195
    -343 199
    -347 203
    -351 207
    -355 211
    -358 215
    -362 219
    -365 223
    -369 227
    -372 231
    -375 235
    -378 239
    -380 243
    -383 247
    -385 251
    -388 255
    -390 259
    -392 262
    -394 266
    -395 270
    -397 274
    -398 278
    -400 281
    -401 285
    -402 289
    -403 293
    -404 296
    -404 300
    -405 304
    -405 307
    -405 311
    -405 314
    -405 318
    -405 321
    -405 325
    -405 328
    -404 332
    -403 335
    -402 339
    -401 342
    -400 345
    -399 349
    -398 352
    -396 355
    -395 358
    -393 362
    -391 365
    -389 368
    -387 371
    -385 374
    -383 377
    -380 380
    -378 383
    -375 386
    -372 389
    -369 392
    -366 395
    -363 398
    -360 400
    -356 403
    -353 406
    -349 408
    -346 411
    -342 414
    -338 416
    -334 419
    -330 421
    -325 424
    -321 426
    -317 428
    -312 431
    -308 433
    -303 435
    -298 438
    -293 440
    -288 442
    -283 444
    -278 446
    -273 448
    -267 450
    -262 452
    -256 454
    -251 456
    -245 457
    -240 459
    -234 461
    -228 462
    -222 464
    -216 466
    -210 467
    -204 469
    -198 470
    -191 471
    -185 473
    -179 474
    -172 475
    -166 476
    -159 478
    -153 479
    -146 480
    -139 481
    -133 482
    -126 483
    -119 484
    -112 484
    -105 485
    -99 486
    -92 486
    -85 487
    -78 488
    -71 488
    -64 489
    -57 489
    -50 489
    -43 490
    -36 490
    -28 490
    -21 490
    -14 491
    -7 491
    0 491
    7 491
    14 491
    21 490
    28 490
    36 490
    43 490
    50 489
    57 489
    64 489
    71 488
    78 488
    85 487
    92 486
    99 486
    105 485
    112 484
    119 484
    126 483
    133 482
    139 481
    146 480
    153 479
    159 478
    166 476
    172 475
    179 474
    185 473
    191 471
    198 470
    204 469
    210 467
    216 466
    222 464
    228 462
    234 461
    240 459
    245 457
    251 456
    256 454
    262 452
    267 450
    273 448
    278 446
    283 444
    288 442
    293 440
    298 438
    303 435
    308 433
    312 431
    317 428
    321 426
    325 424
    330 421
    334 419
    338 416
    342 414
    346 411
    349 408
    353 406
    356 403
    360 400
    363 398
    366 395
    369 392
    372 389
    375 386
    378 383
    380 380
    383 377
    385 374
    387 371
    389 368
    391 365
    393 362
    395 358
    396 355
    398 352
    399 349
    400 345
    401 342
    402 339
    403 335
    404 332
    405 328
    405 325
    405 321
    405 318
    405 314
    405 311
    405 307
    405 304
    404 300
    404 296
    403 293
    402 289
    401 285
    400 281
    398 278
    397 274
    395 270
    394 266
    392 262
    390 259
    388 255
    385 251
    383 247
    380 243
    378 239
    375 235
    372 231
    369 227
    365 223
    362 219
    358 215
    355 211
    351 207
    347 203
    343 199
    339 195
    334 191
    330 187
    325 182
    320 178
    315 174
    310 170
    305 166
    300 162
    294 157
    289 153
    283 149
    277 145
    271 141
    265 136
    259 132
    252 128
    246 124
    239 120
    232 115
    225 111
    218 107
    211 102
    204 98
    196 94
    188 90
    181 85
    173 81
    165 77
    157 73
    148 68
    140 64
    131 60
    123 55
    114 51
    105 47
    96 42
    87 38
    78 34
    68 30
    59 25
    49 21
    39 17
    29 12
    19 8
    9 4
    -1 -1
    -12 -5
    -22 -9
    -33 -13
    -44 -18
    -55 -22
    -66 -26
    -77 -31
    -88 -35
    -99 -39
    -111 -43
    -122 -48
    -134 -52
    -146 -56
    -158 -61
    -170 -65
    -182 -69
    -195 -73
    -207 -78
    -219 -82
    -232 -86
    -245 -90
    -258 -95
    -271 -99
    -284 -103
    -297 -107
    -310 -111
    -323 -116
    -337 -120
    -351 -124
    -364 -128
    -378 -132
    -392 -137
    -406 -141
    -420 -145
    -434 -149
    -449 -153
    -463 -157
    -478 -162
    -492 -166
    -507 -170
    -522 -174
    -537 -178
    -552 -182
    -567 -186
    -582 -190
    -597 -194
    -613 -198
    -628 -203
    -644 -207
    -659 -211
    -675 -215
    -691 -219
    -707 -223
    -723 -227
    -739 -231
    -756 -235
    -772 -239
    -788 -243
    -805 -247
    -821 -251
    -838 -255
    -855 -259
    -872 -263
    -889 -267
    -906 -271
    -923 -274
    -940 -278
    -957 -282
    -975 -286
    -992 -290
    -1010 -294
    -1027 -298
    -1045 -302
    -1063 -306
    1067 -311
    1049 -307
    1031 -303
    1014 -299
    996 -295
    979 -292
    961 -288
    944 -284
    927 -280
    910 -276
    893 -272
    876 -268
    859 -264
    842 -260
    825 -256
    809 -252
    792 -248
    776 -244
    760 -240
    743 -235
    727 -231
    711 -227
    695 -223
    679 -219
    664 -215
    648 -211
    632 -207
    617 -203
    601 -199
    586 -194
    571 -190
    556 -186
    541 -182
    526 -178
    511 -174
    496 -169
    482 -165
    467 -161
    453 -157
    438 -153
    424 -148
    410 -144
    396 -140
    382 -136
    368 -132
    355 -127
    341 -123
    328 -119
    314 -115
    301 -110
    288 -106
    275 -102
    262 -98
    249 -93
    236 -89
    224 -85
    211 -80
    199 -76
    187 -72
    174 -67
    162 -63
    150 -59
    139 -54
    127 -50
    115 -46
    104 -41
    92 -37
    81 -33
    70 -28
    59 -24
    48 -20
    37 -15
    27 -11
    16 -7
    6 -2
    -5 2
    -15 6
    -25 11
    -35 15
    -45 19
    -54 24
    -64 28
    -73 32
    -82 37
    -92 41
    -101 45
    -110 50
    -118 54
    -127 59
    -136 63
    -144 67
    -152 72
    -160 76
    -168 80
    -176 85
    -184 89
    -192 93
    -199 98
    -207 102
    -214 106
    -221 110
    -228 115
    -235 119
    -241 123
    -248 128
    -254 132
    -261 136
    -267 140
    -273 145
    -279 149
    -285 153
    -290 157
    -296 162
    -301 166
    -306 170
    -311 174
    -316 179
    -321 183
    -326 187
    -330 191
    -335 195
    -339 199
    -343 203
    -347 208
    -351 212
    -354 216
    -358 220
    -361 224
    -365 228
    -368 232
    -371 236
    -374 240
    -376 244
    -379 248
    -381 252
    -384 256
    -386 260
    -388 264
    -390 267
    -392 271
    -393 275
    -395 279
    -396 283
    -397 287
    -398 290
    -399 294
    -400 298
    -401 302
    -401 305
    -402 309
    -402 312
    -402 316
    -402 320
    -402 323
    -401 327
    -401 330
    -401 334
    -400 337
    -399 341
    -398 344
    -397 347
    -396 351
    -395 354
    -393 357
    -392 361
    -390 364
    -388 367
    -386 370
    -384 373
    -382 377
    -380 380
    -377 383
    -375 386
    -372 389
    -369 392
    -366 394
    -363 397
    -360 400
    -357 403
    -354 406
    -350 409
    -347 411
    -343 414
    -339 416
    -335 419
    -331 422
    -327 424
    -323 427
    -319 429
    -314 431
    -310 434
    -305 436
    -301 438
    -296 441
    -291 443
    -286 445
    -281 447
    -276 449
    -271 451
    -265 453
    -260 455
    -255 457
    -249 459
    -243 461
    -238 462
    -232 464
    -226 466
    -220 467
    -214 469
    -208 471
    -202 472
    -196 473
    -190 475
    -184 476
    -177 477
    -171 479
    -165 480
    -158 481
    -152 482
    -145 483
    -138 484
    -132 485
    -125 486
    -118 487
    -112 488
    -105 489
    -98 489
    -91 490
    -84 491
    -77 491
    -70 492
    -63 492
    -56 493
    -49 493
    -42 493
    -35 494
    -28 494
    -21 494
    -14 494
    -7 494
    0 494
    7 494
    14 494
    21 494
    28 494
    35 494
    42 493
    49 493
    56 493
    63 492
    70 492
    77 491
    84 491
    91 490
    98 489
    105 489
    112 488
    118 487
    125 486
    132 485
    138 484
    145 483
    152 482
    158 481
    165 480
    171 479
    177 477
    184 476
    190 475
    196 473
    202 472
    208 471
    214 469
    220 467
    226 466
    232 464
    238 462
    243 461
    249 459
    255 457
    260 455
    265 453
    271 451
    276 449
    281 447
    286 445
    291 443
    296 441
    301 438
    305 436
    310 434
    314 431
    319 429
    323 427
    327 424
    331 422
    335 419
    339 416
    343 414
    347 411
    350 409
    354 406
    357 403
    360 400
    363 397
    366 394
    369 392
    372 389
    375 386
    377 383
    380 380
    382 377
    384 373
    386 370
    388 367
    390 364
    392 361
    393 357
    395 354
    396 351
    397 347
    398 344
    399 341
    400 337
    401 334
    401 330
    401 327
    402 323
    402 320
    402 316
    402 312
    402 309
    401 305
    401 302
    400 298
    399 294
    398 290
    397 287
    396 283
    395 279
    393 275
    392 271
    390 267
    388 264
    386 260
    384 256
    381 252
    379 248
    376 244
    374 240
    371 236
    368 232
    365 228
    361 224
    358 220
    354 216
    351 212
    347 208
    343 203
    339 199
    335 195
    330 191
    326 187
    321 183
    316 179
    311 174
    306 170
    301 166
    296 162
    290 157
    285 153
    279 149
    273 145
    267 140
    261 136
    254 132
    248 128
    241 123
    235 119
    228 115
    221 110
    214 106
    207 102
    199 98
    192 93
    184 89
    176 85
    168 80
    160 76
    152 72
    144 67
    136 63
    127 59
    118 54
    110 50
    101 45
    92 41
    82 37
    73 32
    64 28
    54 24
    45 19
    35 15
    25 11
    15 6
    5 2
    -6 -2
    -16 -7
    -27 -11
    -37 -15
    -48 -20
    -59 -24
    -70 -28
    -81 -33
    -92 -37
    -104 -41
    -115 -46
    -127 -50
    -139 -54
    -150 -59
    -162 -63
    -174 -67
    -187 -72
    -199 -76
    -211 -80
    -224 -85
    -236 -89
    -249 -93
    -262 -98
    -275 -102
    -288 -106
    -301 -110
    -314 -115
    -328 -119
    -341 -123
    -355 -127
    -368 -132
    -382 -136
    -396 -140
    -410 -144
    -424 -148
    -438 -153
    -453 -157
    -467 -161
    -482 -165
    -496 -169
    -511 -174
    -526 -178
    -541 -182
    -556 -186
    -571 -190
    -586 -194
    -601 -199
    -617 -203
    -632 -207
    -648 -211
    -664 -215
    -679 -219
    -695 -223
    -711 -227
    -727 -231
    -743 -235
    -760 -240
    -776 -244
    -792 -248
    -809 -252
    -825 -256
    -842 -260
    -859 -264
    -876 -268
    -893 -272
    -910 -276
    -927 -280
    -944 -284
    -961 -288
    -979 -292
    -996 -295
    -1014 -299
    -1031 -303
    -1049 -307
    -1067 -311
    1071 -317
    1053 -313
    1035 -309
    1018 -305
    1000 -301
    983 -297
    965 -293
    948 -289
    931 -285
    914 -281
    897 -277
    880 -273
    863 -269
    846 -265
    830 -261
    813 -257
    796 -252
    780 -248
    764 -244
    747 -240
    731 -236
    715 -232
    699 -228
    683 -224
    668 -219
    652 -215
    636 -211
    621 -207
    606 -203
    590 -199
    575 -194
    560 -190
    545 -186
    530 -182
    515 -178
    501 -173
    486 -169
    471 -165
    457 -161
    443 -156
    428 -152
    414 -148
    400 -144
    386 -139
    373 -135
    359 -131
    345 -126
    332 -122
    319 -118
    305 -113
    292 -109
    279 -105
    266 -101
    253 -96
    241 -92
    228 -88
    216 -83
    203 -79
    191 -74
    179 -70
    167 -66
    155 -61
    143 -57
    131 -53
    120 -48
    108 -44
    97 -39
    85 -35
    74 -31
    63 -26
    52 -22
    42 -18
    31 -13
    20 -9
    10 -4
    -0 0
    -10 4
    -20 9
    -30 13
    -40 18
    -50 22
    -59 27
    -69 31
    -78 35
    -87 40
    -96 44
    -105 49
    -114 53
    -123 57
    -131 62
    -140 66
    -148 70
    -156 75
    -164 79
    -172 84
    -180 88
    -187 92
    -195 97
    -202 101
    -210 106
    -217 110
    -224 114
    -230 119
    -237 123
    -244 127
    -250 132
    -256 136
    -263 140
    -269 145
    -275 149
    -280 153
    -286 157
    -291 162
    -297 166
    -302 170
    -307 174
    -312 179
    -317 183
    -321 187
    -326 191
    -330 195
    -335 200
    -339 204
    -343 208
    -347 212
    -350 216
    -354 220
    -357 224
    -361 229
    -364 233
    -367 237
    -370 241
    -372 245
    -375 249
    -377 253
    -380 257
    -382 261
    -384 265
    -386 269
    -388 272
    -389 276
    -391 280
    -392 284
    -393 288
    -394 292
    -395 296
    -396 299
    -397 303
    -397 307
    -398 310
    -398 314
    -398 318
    -398 321
    -398 325
    -398 329
    -398 332
    -397 336
    -396 339
    -396 343
    -395 346
    -394 349
    -393 353
    -391 356
    -390 359
    -388 363
    -387 366
    -385 369
    -383 372
    -381 376
    -379 379
    -377 382
    -374 385
    -372 388
    -369 391
    -366 394
    -363 397
    -360 400
    -357 403
    -354 406
    -351 408
    -347 411
    -344 414
    -340 417
    -337 419
    -333 422
    -329 424
    -325 427
    -321 429
    -316 432
    -312 434
    -308 437
    -303 439
    -298 441
    -294 444
    -289 446
    -284 448
    -279 450
    -274 452
    -269 454
    -263 456
    -258 458
    -253 460
    -247 462
    -242 464
    -236 466
    -230 467
    -225 469
    -219 471
    -213 472
    -207 474
    -201 475
    -195 477
    -189 478
    -182 479
    -176 481
    -170 482
    -163 483
    -157 484
    -150 486
    -144 487
    -137 488
    -131 489
    -124 490
    -117 490
    -111 491
    -104 492
    -97 493
    -90 493
    -84 494
    -77 495
    -70 495
    -63 496
    -56 496
    -49 497
    -42 497
    -35 497
    -28 497
    -21 498
    -14 498
    -7 498
    0 498
    7 498
    14 498
    21 498
    28 497
    35 497
    42 497
    49 497
    56 496
    63 496
    70 495
    77 495
    84 494
    90 493
    97 493
    104 492
    111 491
    117 490
    124 490
    131 489
    137 488
    144 487
    150 486
    157 484
    163 483
    170 482
    176 481
    182 479
    189 478
    195 477
    201 475
    207 474
    213 472
    219 471
    225 469
    230 467
    236 466
    242 464
    247 462
    253 460
    258 458
    263 456
    269 454
    274 452
    279 450
    284 448
    289 446
    294 444
    298 441
    303 439
    308 437
    312 434
    316 432
    321 429
    325 427
    329 424
    333 422
    337 419
    340 417
    344 414
    347 411
    351 408
    354 406
    357 403
    360 400
    363 397
    366 394
    369 391
    372 388
    374 385
    377 382
    379 379
    381 376
    383 372
    385 369
    387 366
    388 363
    390 359
    391 356
    393 353
    394 349
    395 346
    396 343
    396 339
    397 336
    398 332
    398 329
    398 325
    398 321
    398 318
    398 314
    398 310
    397 307
    397 303
    396 299
    395 296
    394 292
    393 288
    392 284
    391 280
    389 276
    388 272
    386 269
    384 265
    382 261
    380 257
    377 253
    375 249
    372 245
    370 241
    367 237
    364 233
    361 229
    357 224
    354 220
    350 216
    347 212
    343 208
    339 204
    335 200
    330 195
    326 191
    321 187
    317 183
    312 179
    307 174
    302 170
    297 166
    291 162
    286 157
    280 153
    275 149
    269 145
    263 140
    256 136
    250 132
    244 127
    237 123
    230 119
    224 114
    217 110
    210 106
    202 101
    195 97
    187 92
    180 88
    172 84
    164 79
    156 75
    148 70
    140 66
    131 62
    123 57
    114 53
    105 49
    96 44
    87 40
    78 35
    69 31
    59 27
    50 22
    40 18
    30 13
    20 9
    10 4
    0 0
    -10 -4
    -20 -9
    -31 -13
    -42 -18
    -52 -22
    -63 -26
    -74 -31
    -85 -35
    -97 -39
    -108 -44
    -120 -48
    -131 -53
    -143 -57
    -155 -61
    -167 -66
    -179 -70
    -191 -74
    -203 -79
    -216 -83
    -228 -88
    -241 -92
    -253 -96
    -266 -101
    -279 -105
    -292 -109
    -305 -113
    -319 -118
    -332 -122
    -345 -126
    -359 -131
    -373 -135
    -386 -139
    -400 -144
    -414 -148
    -428 -152
    -443 -156
    -457 -161
    -471 -165
    -486 -169
    -501 -173
    -515 -178
    -530 -182
    -545 -186
    -560 -190
    -575 -194
    -590 -199
    -606 -203
    -621 -207
    -636 -211
    -652 -215
    -668 -219
    -683 -224
    -699 -228
    -715 -232
    -731 -236
    -747 -240
    -764 -244
    -780 -248
    -796 -252
    -813 -257
    -830 -261
    -846 -265
    -863 -269
    -880 -273
    -897 -277
    -914 -281
    -931 -285
    -948 -289
    -965 -293
    -983 -297
    -1000 -301
    -1018 -305
    -1035 -309
    -1053 -313
    -1071 -317
    1075 -322
    1057 -318
    1039 -314
    1022 -310
    1004 -306
    987 -302
    969 -298
    952 -294
    935 -290
    918 -286
    901 -282
    884 -278
    867 -274
    850 -270
    834 -266
    817 -261
    801 -257
    784 -253
    768 -249
    752 -245
    735 -241
    719 -237
    703 -232
    688 -228
    672 -224
    656 -220
    641 -216
    625 -211
    610 -207
    594 -203
    579 -199
    564 -194
    549 -190
    534 -186
    519 -182
    505 -177
    490 -173
    476 -169
    461 -164
    447 -160
    433 -156
    419 -151
    405 -147
    391 -143
    377 -138
    363 -134
    350 -130
    336 -125
    323 -121
    310 -117
    296 -112
    283 -108
    271 -104
    258 -99
    245 -95
    232 -90
    220 -86
    207 -82
    195 -77
    183 -73
    171 -68
    159 -64
    147 -60
    136 -55
    124 -51
    112 -46
    101 -42
    90 -37
    79 -33
    68 -29
    57 -24
    46 -20
    35 -15
    25 -11
    15 -6
    4 -2
    -6 3
    -16 7
    -26 12
    -36 16
    -45 20
    -55 25
    -64 29
    -74 34
    -83 38
    -92 43
    -101 47
    -110 52
    -118 56
    -127 60
    -135 65
    -144 69
    -152 74
    -160 78
    -168 83
    -175 87
    -183 92
    -191 96
    -198 100
    -205 105
    -212 109
    -219 114
    -226 118
    -233 122
    -239 127
    -246 131
    -252 135
    -258 140
    -264 144
    -270 149
    -276 153
    -282 157
    -287 162
    -292 166
    -298 170
    -303 174
    -308 179
    -313 183
    -317 187
    -322 191
    -326 196
    -330 200
    -335 204
    -339 208
    -342 213
    -346 217
    -350 221
    -353 225
    -356 229
    -360 233
    -363 237
    -366 241
    -368 246
    -371 250
    -373 254
    -376 258
    -378 262
    -380 266
    -382 270
    -384 274
    -385 277
    -387 281
    -388 285
    -390 289
    -391 293
    -392 297
    -392 301
    -393 304
    -394 308
    -394 312
    -394 316
    -395 319
    -395 323
    -395 327
    -394 330
    -394 334
    -394 337
    -393 341
    -392 344
    -391 348
    -390 351
    -389 355
    -388 358
    -387 361
    -385 365
    -383 368
    -382 371
    -380 375
    -378 378
    -376 381
    -373 384
    -371 387
    -369 390
    -366 393
    -363 396
    -360 399
    -358 402
    -354 405
    -351 408
    -348 411
    -345 414
    -341 416
    -338 419
    -334 422
    -330 424
    -326 427
    -322 430
    -318 432
    -314 435
    -310 437
    -305 439
    -301 442
    -296 444
    -291 446
    -287 449
    -282 451
    -277 453
    -272 455
    -267 457
    -261 459
    -256 461
    -251 463
    -245 465
    -240 467
    -234 469
    -229 470
    -223 472
    -217 474
    -211 475
    -205 477
    -199 478
    -193 480
    -187 481
    -181 483
    -175 484
    -168 485
    -162 486
    -156 488
    -149 489
    -143 490
    -136 491
    -130 492
    -123 493
    -117 494
    -110 495
    -103 495
    -96 496
    -90 497
    -83 497
    -76 498
    -69 499
    -62 499
    -55 499
    -49 500
    -42 500
    -35 500
    -28 501
    -21 501
    -14 501
    -7 501
    0 501
    7 501
    14 501
    21 501
    28 501
    35 500
    42 500
    49 500
    55 499
    62 499
    69 499
    76 498
    83 497
    90 497
    96 496
    103 495
    110 495
    117 494
    123 493
    130 492
    136 491
    143 490
    149 489
    156 488
    162 486
    168 485
    175 484
    181 483
    187 481
    193 480
    199 478
    205 477
    211 475
    217 474
    223 472
    229 470
    234 469
    240 467
    245 465
    251 463
    256 461
    261 459
    267 457
    272 455
    277 453
    282 451
    287 449
    291 446
    296 444
    301 442
    305 439
    310 437
    314 435
    318 432
    322 430
    326 427
    330 424
    334 422
    338 419
    341 416
    345 414
    348 411
    351 408
    354 405
    358 402
    360 399
    363 396
    366 393
    369 390
    371 387
    373 384
    376 381
    378 378
    380 375
    382 371
    383 368
    385 365
    387 361
    388 358
    389 355
    390 351
    391 348
    392 344
    393 341
    394 337
    394 334
    394 330
    395 327
    395 323
    395 319
    394 316
    394 312
    394 308
    393 304
    392 301
    392 297
    391 293
    390 289
    388 285
    387 281
    385 277
    384 274
    382 270
    380 266
    378 262
    376 258
    373 254
    371 250
    368 246
    366 241
    363 237
    360 233
    356 229
    353 225
    350 221
    346 217
    342 213
    339 208
    335 204
    330 200
    326 196
    322 191
    317 187
    313 183
    308 179
    303 174
    298 170
    292 166
    287 162
    282 157
    276 153
    270 149
    264 144
    258 140
    252 135
    246 131
    239 127
    233 122
    226 118
    219 114
    212 109
    205 105
    198 100
    191 96
    183 92
    175 87
    168 83
    160 78
    152 74
    144 69
    135 65
    127 60
    118 56
    110 52
    101 47
    92 43
    83 38
    74 34
    64 29
    55 25
    45 20
    36 16
    26 12
    16 7
    6 3
    -4 -2
    -15 -6
    -25 -11
    -35 -15
    -46 -20
    -57 -24
    -68 -29
    -79 -33
    -90 -37
    -101 -42
    -112 -46
    -124 -51
    -136 -55
    -147 -60
    -159 -64
    -171 -68
    -183 -73
    -195 -77
    -207 -82
    -220 -86
    -232 -90
    -245 -95
    -258 -99
    -271 -104
    -283 -108
    -296 -112
    -310 -117
    -323 -121
    -336 -125
    -350 -130
    -363 -134
    -377 -138
    -391 -143
    -405 -147
    -419 -151
    -433 -156
    -447 -160
    -461 -164
    -476 -169
    -490 -173
    -505 -177
    -519 -182
    -534 -186
    -549 -190
    -564 -194
    -579 -199
    -594 -203
    -610 -207
    -625 -211
    -641 -216
    -656 -220
    -672 -224
    -688 -228
    -703 -232
    -719 -237
    -735 -241
    -752 -245
    -768 -249
    -784 -253
    -801 -257
    -817 -261
    -834 -266
    -850 -270
    -867 -274
    -884 -278
    -901 -282
    -918 -286
    -935 -290
    -952 -294
    -969 -298
    -987 -302
    -1004 -306
    -1022 -310
    -1039 -314
    -1057 -318
    -1075 -322
    1079 -328
    1061 -324
    1043 -320
    1026 -316
    1008 -312
    991 -308
    973 -304
    956 -300
    939 -295
    922 -291
    905 -287
    888 -283
    871 -279
    854 -275
    838 -271
    821 -266
    805 -262
    788 -258
    772 -254
    756 -250
    740 -245
    724 -241
    708 -237
    692 -233
    676 -228
    660 -224
    645 -220
    629 -216
    614 -211
    599 -207
    584 -203
    568 -199
    553 -194
    539 -190
    524 -186
    509 -181
    495 -177
    480 -173
    466 -168
    451 -164
    437 -160
    423 -155
    409 -151
    395 -146
    381 -142
    368 -138
    354 -133
    341 -129
    327 -124
    314 -120
    301 -116
    288 -111
    275 -107
    262 -102
    249 -98
    237 -93
    224 -89
    212 -85
    200 -80
    187 -76
    175 -71
    164 -67
    152 -62
    140 -58
    128 -53
    117 -49
    106 -44
    94 -40
    83 -35
    72 -31
    61 -26
    51 -22
    40 -17
    29 -13
    19 -8
    9 -4
    -1 1
    -12 5
    -21 10
    -31 14
    -41 19
    -50 23
    -60 28
    -69 32
    -78 37
    -87 41
    -96 46
    -105 50
    -114 55
    -122 59
    -131 64
    -139 68
    -147 73
    -155 77
    -163 82
    -171 86
    -179 91
    -186 95
    -193 99
    -201 104
    -208 108
    -215 113
    -222 117
    -228 122
    -235 126
    -241 131
    -248 135
    -254 139
    -260 144
    -266 148
    -272 153
    -277 157
    -283 161
    -288 166
    -293 170
    -298 174
    -303 179
    -308 183
    -313 187
    -318 192
    -322 196
    -326 200
    -330 204
    -334 209
    -338 213
    -342 217
    -346 221
    -349 225
    -352 230
    -356 234
    -359 238
    -361 242
    -364 246
    -367 250
    -369 254
    -372 258
    -374 262
    -376 266
    -378 270
    -380 274
    -381 278
    -383 282
    -384 286
    -386 290
    -387 294
    -388 298
    -389 302
    -389 306
    -390 309
    -390 313
    -391 317
    -391 321
    -391 324
    -391 328
    -391 332
    -390 335
    -390 339
    -389 342
    -389 346
    -388 349
    -387 353
    -386 356
    -384 360
    -383 363
    -382 367
    -380 370
    -378 373
    -377 377
    -375 380
    -372 383
    -370 386
    -368 389
    -365 392
    -363 395
    -360 398
    -357 401
    -355 404
    -352 407
    -348 410
    -345 413
    -342 416
    -338 419
    -335 421
    -331 424
    -327 427
    -324 429
    -320 432
    -316 435
    -311 437
    -307 440
    -303 442
    -298 444
    -294 447
    -289 449
    -284 451
    -280 454
    -275 456
    -270 458
    -265 460
    -259 462
    -254 464
    -249 466
    -244 468
    -238 470
    -233 471
    -227 473
    -221 475
    -215 477
    -210 478
    -204 480
    -198 481
    -192 483
    -186 484
    -180 486
    -173 487
    -167 488
    -161 490
    -155 491
    -148 492
    -142 493
    -135 494
    -129 495
    -122 496
    -116 497
    -109 498
    -102 499
    -96 499
    -89 500
    -82 501
    -76 501
    -69 502
    -62 502
    -55 503
    -48 503
    -41 503
    -34 504
    -28 504
    -21 504
    -14 504
    -7 504
    0 504
    7 504
    14 504
    21 504
    28 504
    34 504
    41 503
    48 503
    55 503
    62 502
    69 502
    76 501
    82 501
    89 500
    96 499
    102 499
    109 498
    116 497
    122 496
    129 495
    135 494
    142 493
    148 492
    155 491
    161 490
    167 488
    173 487
    180 486
    186 484
    192 483
    198 481
    204 480
    210 478
    215 477
    221 475
    227 473
    233 471
    238 470
    244 468
    249 466
    254 464
    259 462
    265 460
    270 458
    275 456
    280 454
    284 451
    289 449
    294 447
    298 444
    303 442
    307 440
    311 437
    316 435
    320 432
    324 429
    327 427
    331 424
    335 421
    338 419
    342 416
    345 413
    348 410
    352 407
    355 404
    357 401
    360 398
    363 395
    365 392
    368 389
    370 386
    372 383
    375 380
    377 377
    378 373
    380 370
    382 367
    383 363
    384 360
    386 356
    387 353
    388 349
    389 346
    389 342
    390 339
    390 335
    391 332
    391 328
    391 324
    391 321
    391 317
    390 313
    390 309
    389 306
    389 302
    388 298
    387 294
    386 290
    384 286
    383 282
    381 278
    380 274
    378 270
    376 266
    374 262
    372 258
    369 254
    367 250
    364 246
    361 242
    359 238
    356 234
    352 230
    349 225
    346 221
    342 217
    338 213
    334 209
    330 204
    326 200
    322 196
    318 192
    313 187
    308 183
    303 179
    298 174
    293 170
    288 166
    283 161
    277 157
    272 153
    266 148
    260 144
    254 139
    248 135
    241 131
    235 126
    228 122
    222 117
    215 113
    208 108
    201 104
    193 99
    186 95
    179 91
    171 86
    163 82
    155 77
    147 73
    139 68
    131 64
    122 59
    114 55
    105 50
    96 46
    87 41
    78 37
    69 32
    60 28
    50 23
    41 19
    31 14
    21 10
    12 5
    1 1
    -9 -4
    -19 -8
    -29 -13
    -40 -17
    -51 -22
    -61 -26
    -72 -31
    -83 -35
    -94 -40
    -106 -44
    -117 -49
    -128 -53
    -140 -58
    -152 -62
    -164 -67
    -175 -71
    -187 -76
    -200 -80
    -212 -85
    -224 -89
    -237 -93
    -249 -98
    -262 -102
    -275 -107
    -288 -111
    -301 -116
    -314 -120
    -327 -124
    -341 -129
    -354 -133
    -368 -138
    -381 -142
    -395 -146
    -409 -151
    -423 -155
    -437 -160
    -451 -164
    -466 -168
    -480 -173
    -495 -177
    -509 -181
    -524 -186
    -539 -190
    -553 -194
    -568 -199
    -584 -203
    -599 -207
    -614 -211
    -629 -216
    -645 -220
    -660 -224
    -676 -228
    -692 -233
    -708 -237
    -724 -241
    -740 -245
    -756 -250
    -772 -254
    -788 -258
    -805 -262
    -821 -266
    -838 -271
    -854 -275
    -871 -279
    -888 -283
    -905 -287
    -922 -291
    -939 -295
    -956 -300
    -973 -304
    -991 -308
    -1008 -312
    -1026 -316
    -1043 -320
    -1061 -324
    -1079 -328
    1083 -334
    1065 -330
    1047 -326
    1030 -322
    1012 -317
    995 -313
    978 -309
    960 -305
    943 -301
    926 -297
    909 -292
    892 -288
    875 -284
    859 -280
    842 -276
    825 -271
    809 -267
    793 -263
    776 -259
    760 -254
    744 -250
    728 -246
    712 -242
    696 -237
    680 -233
    665 -229
    649 -224
    634 -220
    618 -216
    603 -212
    588 -207
    573 -203
    558 -198
    543 -194
    528 -190
    513 -185
    499 -181
    484 -177
    470 -172
    456 -168
    442 -163
    427 -159
    413 -155
    400 -150
    386 -146
    372 -141
    359 -137
    345 -132
    332 -128
    318 -123
    305 -119
    292 -114
    279 -110
    267 -105
    254 -101
    241 -97
    229 -92
    216 -88
    204 -83
    192 -78
    180 -74
    168 -69
    156 -65
    145 -60
    133 -56
    121 -51
    110 -47
    99 -42
    88 -38
    77 -33
    66 -29
    55 -24
    44 -20
    34 -15
    24 -10
    13 -6
    3 -1
    -7 3
    -17 8
    -27 12
    -36 17
    -46 21
    -55 26
    -65 30
    -74 35
    -83 40
    -92 44
    -101 49
    -109 53
    -118 58
    -126 62
    -135 67
    -143 71
    -151 76
    -159 80
    -166 85
    -174 89
    -182 94
    -189 98
    -196 103
    -203 107
    -210 112
    -217 116
    -224 121
    -231 125
    -237 130
    -243 134
    -249 139
    -256 143
    -261 148
    -267 152
    -273 157
    -278 161
    -284 165
    -289 170
    -294 174
    -299 179
    -304 183
    -309 187
    -313 192
    -318 196
    -322 200
    -326 204
    -330 209
    -334 213
    -338 217
    -341 222
    -345 226
    -348 230
    -351 234
    -354 238
    -357 243
    -360 247
    -363 251
    -365 255
    -368 259
    -370 263
    -372 267
    -374 271
    -376 275
    -377 279
    -379 283
    -380 287
    -382 291
    -383 295
    -384 299
    -385 303
    -386 307
    -386 311
    -387 314
    -387 318
    -387 322
    -387 326
    -387 329
    -387 333
    -387 337
    -386 340
    -386 344
    -385 348
    -384 351
    -383 355
    -382 358
    -381 362
    -380 365
    -378 368
    -377 372
    -375 375
    -373 378
    -371 382
    -369 385
    -367 388
    -365 391
    -362 394
    -360 397
    -357 401
    -354 404
    -352 407
    -349 410
    -346 412
    -342 415
    -339 418
    -336 421
    -332 424
    -329 426
    -325 429
    -321 432
    -317 434
    -313 437
    -309 440
    -305 442
    -300 444
    -296 447
    -291 449
    -287 452
    -282 454
    -277 456
    -273 458
    -268 460
    -263 463
    -257 465
    -252 467
    -247 469
    -242 471
    -236 472
    -231 474
    -225 476
    -220 478
    -214 479
    -208 481
    -202 483
    -196 484
    -190 486
    -184 487
    -178 489
    -172 490
    -166 491
    -160 492
    -153 494
    -147 495
    -141 496
    -134 497
    -128 498
    -121 499
    -115 500
    -108 501
    -102 502
    -95 502
    -88 503
    -82 504
    -75 504
    -68 505
    -61 505
    -55 506
    -48 506
    -41 506
    -34 507
    -27 507
    -21 507
    -14 507
    -7 507
    0 507
    7 507
    14 507
    21 507
    27 507
    34 507
    41 506
    48 506
    55 506
    61 505
    68 505
    75 504
    82 504
    88 503
    95 502
    102 502
    108 501
    115 500
    121 499
    128 498
    134 497
    141 496
    147 495
    153 494
    160 492
    166 491
    172 490
    178 489
    184 487
    190 486
    196 484
    202 483
    208 481
    214 479
    220 478
    225 476
    231 474
    236 472
    242 471
    247 469
    252 467
    257 465
    263 463
    268 460
    273 458
    277 456
    282 454
    287 452
    291 449
    296 447
    300 444
    305 442
    309 440
    313 437
    317 434
    321 432
    325 429
    329 426
    332 424
    336 421
    339 418
    342 415
    346 412
    349 410
    352 407
    354 404
    357 401
    360 397
    362 394
    365 391
    367 388
    369 385
    371 382
    373 378
    375 375
    377 372
    378 368
    380 365
    381 362
    382 358
    383 355
    384 351
    385 348
    386 344
    386 340
    387 337
    387 333
    387 329
    387 326
    387 322
    387 318
    387 314
    386 311
    386 307
    385 303
    384 299
    383 295
    382 291
    380 287
    379 283
    377 279
    376 275
    374 271
    372 267
    370 263
    368 259
    365 255
    363 251
    360 247
    357 243
    354 238
    351 234
    348 230
    345 226
    341 222
    338 217
    334 213
    330 209
    326 204
    322 200
    318 196
    313 192
    309 187
    304 183
    299 179
    294 174
    289 170
    284 165
    278 161
    273 157
    267 152
    261 148
    256 143
    249 139
    243 134
    237 130
    231 125
    224 121
    217 116
    210 112
    203 107
    196 103
    189 98
    182 94
    174 89
    166 85
    159 80
    151 76
    143 71
    135 67
    126 62
    118 58
    109 53
    101 49
    92 44
    83 40
    74 35
    65 30
    55 26
    46 21
    36 17
    27 12
    17 8
    7 3
    -3 -1
    -13 -6
    -24 -10
    -34 -15
    -44 -20
    -55 -24
    -66 -29
    -77 -33
    -88 -38
    -99 -42
    -110 -47
    -121 -51
    -133 -56
    -145 -60
    -156 -65
    -168 -69
    -180 -74
    -192 -78
    -204 -83
    -216 -88
    -229 -92
    -241 -97
    -254 -101
    -267 -105
    -279 -110
    -292 -114
    -305 -119
    -318 -123
    -332 -128
    -345 -132
    -359 -137
    -372 -141
    -386 -146
    -400 -150
    -413 -155
    -427 -159
    -442 -163
    -456 -168
    -470 -172
    -484 -177
    -499 -181
    -513 -185
    -528 -190
    -543 -194
    -558 -198
    -573 -203
    -588 -207
    -603 -212
    -618 -216
    -634 -220
    -649 -224
    -665 -229
    -680 -233
    -696 -237
    -712 -242
    -728 -246
    -744 -250
    -760 -254
    -776 -259
    -793 -263
    -809 -267
    -825 -271
    -842 -276
    -859 -280
    -875 -284
    -892 -288
    -909 -292
    -926 -297
    -943 -301
    -960 -305
    -978 -309
    -995 -313
    -1012 -317
    -1030 -322
    -1047 -326
    -1065 -330
    -1083 -334
    1087 -340
    1069 -336
    1052 -331
    1034 -327
    1016 -323
    999 -319
    982 -315
    964 -310
    947 -306
    930 -302
    913 -298
    896 -294
    880 -289
    863 -285
    846 -281
    830 -277
    813 -272
    797 -268
    781 -264
    764 -259
    748 -255
    732 -251
    716 -246
    700 -242
    685 -238
    669 -233
    654 -229
    638 -225
    623 -220
    607 -216
    592 -212
    577 -207
    562 -203
    547 -198
    533 -194
    518 -189
    503 -185
    489 -181
    474 -176
    460 -172
    446 -167
    432 -163
    418 -158
    404 -154
    390 -149
    377 -145
    363 -140
    350 -136
    336 -131
    323 -127
    310 -122
    297 -118
    284 -113
    271 -109
    258 -104
    246 -100
    233 -95
    221 -91
    209 -86
    197 -81
    184 -77
    173 -72
    161 -68
    149 -63
    137 -59
    126 -54
    115 -49
    103 -45
    92 -40
    81 -36
    70 -31
    60 -26
    49 -22
    38 -17
    28 -13
    18 -8
    8 -3
    -2 1
    -12 6
    -22 10
    -32 15
    -41 20
    -51 24
    -60 29
    -69 33
    -78 38
    -87 42
    -96 47
    -105 52
    -113 56
    -122 61
    -130 65
    -138 70
    -146 75
    -154 79
    -162 84
    -170 88
    -177 93
    -184 97
    -192 102
    -199 107
    -206 111
    -213 116
    -219 120
    -226 125
    -232 129
    -239 134
    -245 138
    -251 143
    -257 147
    -263 152
    -268 156
    -274 161
    -279 165
    -285 169
    -290 174
    -295 178
    -300 183
    -304 187
    -309 191
    -313 196
    -318 200
    -322 205
    -326 209
    -330 213
    -333 217
    -337 222
    -341 226
    -344 230
    -347 235
    -350 239
    -353 243
    -356 247
    -359 251
    -361 256
    -364 260
    -366 264
    -368 268
    -370 272
    -372 276
    -373 280
    -375 284
    -376 288
    -378 292
    -379 296
    -380 300
    -381 304
    -382 308
    -382 312
    -383 316
    -383 319
    -383 323
    -384 327
    -384 331
    -383 334
    -383 338
    -383 342
    -382 345
    -382 349
    -381 353
    -380 356
    -379 360
    -378 363
    -376 367
    -375 370
    -373 373
    -372 377
    -370 380
    -368 383
    -366 387
    -364 390
    -362 393
    -359 396
    -357 399
    -354 402
    -351 406
    -349 409
    -346 412
    -343 414
    -339 417
    -336 420
    -333 423
    -329 426
    -326 429
    -322 431
    -318 434
    -314 437
    -310 439
    -306 442
    -302 444
    -298 447
    -294 449
    -289 452
    -285 454
    -280 456
    -275 459
    -270 461
    -265 463
    -260 465
    -255 467
    -250 469
    -245 471
    -240 473
    -234 475
    -229 477
    -223 479
    -218 480
    -212 482
    -206 484
    -201 485
    -195 487
    -189 488
    -183 490
    -177 491
    -171 493
    -165 494
    -158 495
    -152 497
    -146 498
    -140 499
    -133 500
    -127 501
    -120 502
    -114 503
    -107 504
    -101 504
    -94 505
    -88 506
    -81 507
    -74 507
    -68 508
    -61 508
    -54 509
    -48 509
    -41 509
    -34 510
    -27 510
    -20 510
    -14 510
    -7 510
    0 510
    7 510
    14 510
    20 510
    27 510
    34 510
    41 509
    48 509
    54 509
    61 508
    68 508
    74 507
    81 507
    88 506
    94 505
    101 504
    107 504
    114 503
    120 502
    127 501
    133 500
    140 499
    146 498
    152 497
    158 495
    165 494
    171 493
    177 491
    183 490
    189 488
    195 487
    201 485
    206 484
    212 482
    218 480
    223 479
    229 477
    234 475
    240 473
    245 471
    250 469
    255 467
    260 465
    265 463
    270 461
    275 459
    280 456
    285 454
    289 452
    294 449
    298 447
    302 444
    306 442
    310 439
    314 437
    318 434
    322 431
    326 429
    329 426
    333 423
    336 420
    339 417
    343 414
    346 412
    349 409
    351 406
    354 402
    357 399
    359 396
    362 393
    364 390
    366 387
    368 383
    370 380
    372 377
    373 373
    375 370
    376 367
    378 363
    379 360
    380 356
    381 353
    382 349
    382 345
    383 342
    383 338
    383 334
    384 331
    384 327
    383 323
    383 319
    383 316
    382 312
    382 308
    381 304
    380 300
    379 296
    378 292
    376 288
    375 284
    373 280
    372 276
    370 272
    368 268
    366 264
    364 260
    361 256
    359 251
    356 247
    353 243
    350 239
    347 235
    344 230
    341 226
    337 222
    333 217
    330 213
    326 209
    322 205
    318 200
    313 196
    309 191
    304 187
    300 183
    295 178
    290 174
    285 169
    279 165
    274 161
    268 156
    263 152
    257 147
    251 143
    245 138
    239 134
    232 129
    226 125
    219 120
    213 116
    206 111
    199 107
    192 102
    184 97
    177 93
    170 88
    162 84
    154 79
    146 75
    138 70
    130 65
    122 61
    113 56
    105 52
    96 47
    87 42
    78 38
    69 33
    60 29
    51 24
    41 20
    32 15
    22 10
    12 6
    2 1
    -8 -3
    -18 -8
    -28 -13
    -38 -17
    -49 -22
    -60 -26
    -70 -31
    -81 -36
    -92 -40
    -103 -45
    -115 -49
    -126 -54
    -137 -59
    -149 -63
    -161 -68
    -173 -72
    -184 -77
    -197 -81
    -209 -86
    -221 -91
    -233 -95
    -246 -100
    -258 -104
    -271 -109
    -284 -113
    -297 -118
    -310 -122
    -323 -127
    -336 -131
    -350 -136
    -363 -140
    -377 -145
    -390 -149
    -404 -154
    -418 -158
    -432 -163
    -446 -167
    -460 -172
    -474 -176
    -489 -181
    -503 -185
    -518 -189
    -533 -194
    -547 -198
    -562 -203
    -577 -207
    -592 -212
    -607 -216
    -623 -220
    -638 -225
    -654 -229
    -669 -233
    -685 -238
    -700 -242
    -716 -246
    -732 -251
    -748 -255
    -764 -259
    -781 -264
    -797 -268
    -813 -272
    -830 -277
    -846 -281
    -863 -285
    -880 -289
    -896 -294
    -913 -298
    -930 -302
    -947 -306
    -964 -310
    -982 -315
    -999 -319
    -1016 -323
    -1034 -327
    -1052 -331
    -1069 -336
    -1087 -340
    1091 -346
    1073 -341
    1056 -337
    1038 -333
    1021 -329
    1003 -324
    986 -320
    969 -316
    952 -312
    934 -307
    918 -303
    901 -299
    884 -295
    867 -290
    850 -286
    834 -282
    817 -277
    801 -273
    785 -269
    769 -264
    753 -260
    737 -256
    721 -251
    705 -247
    689 -242
    673 -238
    658 -234
    642 -229
    627 -225
    612 -220
    597 -216
    582 -211
    567 -207
    552 -203
    537 -198
    522 -194
    508 -189
    493 -185
    479 -180
    465 -176
    450 -171
    436 -167
    422 -162
    409 -158
    395 -153
    381 -149
    368 -144
    354 -139
    341 -135
    328 -130
    314 -126
    301 -121
    288 -117
    276 -112
    263 -107
    250 -103
    238 -98
    226 -94
    213 -89
    201 -84
    189 -80
    177 -75
    165 -71
    154 -66
    142 -61
    131 -57
    119 -52
    108 -47
    97 -43
    86 -38
    75 -34
    64 -29
    54 -24
    43 -20
    33 -15
    22 -10
    12 -6
    2 -1
    -8 4
    -18 8
    -27 13
    -37 18
    -46 22
    -55 27
    -65 31
    -74 36
    -83 41
    -91 45
    -100 50
    -109 55
    -117 59
    -125 64
    -134 69
    -142 73
    -150 78
    -157 82
    -165 87
    -172 92
    -180 96
    -187 101
    -194 105
    -201 110
    -208 115
    -215 119
    -221 124
    -228 128
    -234 133
    -240 137
    -247 142
    -252 146
    -258 151
    -264 156
    -270 160
    -275 165
    -280 169
    -285 173
    -290 178
    -295 182
    -300 187
    -304 191
    -309 196
    -313 200
    -317 204
    -321 209
    -325 213
    -329 218
    -333 222
    -336 226
    -340 230
    -343 235
    -346 239
    -349 243
    -352 248
    -354 252
    -357 256
    -359 260
    -362 264
    -364 268
    -366 273
    -368 277
    -369 281
    -371 285
    -372 289
    -374 293
    -375 297
    -376 301
    -377 305
    -378 309
    -378 313
    -379 317
    -379 320
    -380 324
    -380 328
    -380 332
    -380 336
    -379 339
    -379 343
    -379 347
    -378 350
    -377 354
    -376 357
    -375 361
    -374 365
    -373 368
    -371 371
    -370 375
    -368 378
    -367 382
    -365 385
    -363 388
    -361 392
    -358 395
    -356 398
    -354 401
    -351 404
    -348 407
    -346 410
    -343 413
    -340 416
    -337 419
    -333 422
    -330 425
    -327 428
    -323 431
    -319 433
    -316 436
    -312 439
    -308 441
    -304 444
    -300 447
    -295 449
    -291 452
    -287 454
    -282 456
    -278 459
    -273 461
    -268 463
    -263 465
    -258 467
    -253 470
    -248 472
    -243 474
    -238 476
    -232 477
    -227 479
    -222 481
    -216 483
    -210 485
    -205 486
    -199 488
    -193 490
    -187 491
    -181 493
    -175 494
    -169 495
    -163 497
    -157 498
    -151 499
    -145 500
    -139 501
    -132 503
    -126 504
    -119 505
    -113 505
    -107 506
    -100 507
    -94 508
    -87 509
    -80 509
    -74 510
    -67 510
    -61 511
    -54 511
    -47 512
    -40 512
    -34 512
    -27 513
    -20 513
    -13 513
    -7 513
    0 513
    7 513
    13 513
    20 513
    27 513
    34 512
    40 512
    47 512
    54 511
    61 511
    67 510
    74 510
    80 509
    87 509
    94 508
    100 507
    107 506
    113 505
    119 505
    126 504
    132 503
    139 501
    145 500
    151 499
    157 498
    163 497
    169 495
    175 494
    181 493
    187 491
    193 490
    199 488
    205 486
    210 485
    216 483
    222 481
    227 479
    232 477
    238 476
    243 474
    248 472
    253 470
    258 467
    263 465
    268 463
    273 461
    278 459
    282 456
    287 454
    291 452
    295 449
    300 447
    304 444
    308 441
    312 439
    316 436
    319 433
    323 431
    327 428
    330 425
    333 422
    337 419
    340 416
    343 413
    346 410
    348 407
    351 404
    354 401
    356 398
    358 395
    361 392
    363 388
    365 385
    367 382
    368 378
    370 375
    371 371
    373 368
    374 365
    375 361
    376 357
    377 354
    378 350
    379 347
    379 343
    379 339
    380 336
    380 332
    380 328
    380 324
    379 320
    379 317
    378 313
    378 309
    377 305
    376 301
    375 297
    374 293
    372 289
    371 285
    369 281
    368 277
    366 273
    364 268
    362 264
    359 260
    357 256
    354 252
    352 248
    349 243
    346 239
    343 235
    340 230
    336 226
    333 222
    329 218
    325 213
    321 209
    317 204
    313 200
    309 196
    304 191
    300 187
    295 182
    290 178
    285 173
    280 169
    275 165
    270 160
    264 156
    258 151
    252 146
    247 142
    240 137
    234 133
    228 128
    221 124
    215 119
    208 115
    201 110
    194 105
    187 101
    180 96
    172 92
    165 87
    157 82
    150 78
    142 73
    134 69
    125 64
    117 59
    109 55
    100 50
    91 45
    83 41
    74 36
    65 31
    55 27
    46 22
    37 18
    27 13
    18 8
    8 4
    -2 -1
    -12 -6
    -22 -10
    -33 -15
    -43 -20
    -54 -24
    -64 -29
    -75 -34
    -86 -38
    -97 -43
    -108 -47
    -119 -52
    -131 -57
    -142 -61
    -154 -66
    -165 -71
    -177 -75
    -189 -80
    -201 -84
    -213 -89
    -226 -94
    -238 -98
    -250 -103
    -263 -107
    -276 -112
    -288 -117
    -301 -121
    -314 -126
    -328 -130
    -341 -135
    -354 -139
    -368 -144
    -381 -149
    -395 -153
    -409 -158
    -422 -162
    -436 -167
    -450 -171
    -465 -176
    -479 -180
    -493 -185
    -508 -189
    -522 -194
    -537 -198
    -552 -203
    -567 -207
    -582 -211
    -597 -216
    -612 -220
    -627 -225
    -642 -229
    -658 -234
    -673 -238
    -689 -242
    -705 -247
    -721 -251
    -737 -256
    -753 -260
    -769 -264
    -785 -269
    -801 -273
    -817 -277
    -834 -282
    -850 -286
    -867 -290
    -884 -295
    -901 -299
    -918 -303
    -934 -307
    -952 -312
    -969 -316
    -986 -320
    -1003 -324
    -1021 -329
    -1038 -333
    -1056 -337
    -1073 -341
    -1091 -346
    1095 -351
    1078 -347
    1060 -343
    1042 -339
    1025 -334
    1008 -330
    990 -326
    973 -322
    956 -317
    939 -313
    922 -309
    905 -304
    888 -300
    871 -296
    855 -291
    838 -287
    822 -283
    805 -278
    789 -274
    773 -269
    757 -265
    741 -261
    725 -256
    709 -252
    693 -247
    678 -243
    662 -238
    647 -234
    632 -229
    616 -225
    601 -220
    586 -216
    571 -211
    556 -207
    541 -202
    527 -198
    512 -193
    498 -189
    483 -184
    469 -180
    455 -175
    441 -171
    427 -166
    413 -161
    399 -157
    386 -152
    372 -148
    359 -143
    345 -138
    332 -134
    319 -129
    306 -125
    293 -120
    280 -115
    268 -111
    255 -106
    242 -101
    230 -97
    218 -92
    206 -88
    194 -83
    182 -78
    170 -74
    158 -69
    147 -64
    135 -60
    124 -55
    113 -50
    102 -45
    91 -41
    80 -36
    69 -31
    58 -27
    48 -22
    37 -17
    27 -13
    17 -8
    7 -3
    -3 1
    -13 6
    -23 11
    -32 16
    -41 20
    -51 25
    -60 30
    -69 34
    -78 39
    -87 44
    -95 48
    -104 53
    -112 58
    -121 62
    -129 67
    -137 72
    -145 76
    -153 81
    -160 86
    -168 90
    -175 95
    -183 100
    -190 104
    -197 109
    -204 114
    -210 118
    -217 123
    -223 127
    -230 132
    -236 137
    -242 141
    -248 146
    -254 150
    -259 155
    -265 159
    -270 164
    -276 168
    -281 173
    -286 177
    -291 182
    -295 186
    -300 191
    -304 195
    -309 200
    -313 204
    -317 209
    -321 213
    -325 217
    -328 222
    -332 226
    -335 231
    -339 235
    -342 239
    -345 243
    -347 248
    -350 252
    -353 256
    -355 260
    -357 265
    -360 269
    -362 273
    -364 277
    -365 281
    -367 285
    -368 289
    -370 294
    -371 298
    -372 302
    -373 306
    -374 310
    -375 313
    -375 317
    -376 321
    -376 325
    -376 329
    -376 333
    -376 337
    -376 340
    -375 344
    -375 348
    -374 351
    -374 355
    -373 359
    -372 362
    -371 366
    -369 369
    -368 373
    -367 376
    -365 380
    -363 383
    -361 387
    -359 390
    -357 393
    -355 396
    -353 400
    -350 403
    -348 406
    -345 409
    -343 412
    -340 415
    -337 418
    -334 421
    -330 424
    -327 427
    -324 430
    -320 433
    -317 435
    -313 438
    -309 441
    -305 443
    -301 446
    -297 449
    -293 451
    -289 454
    -284 456
    -280 458
    -275 461
    -271 463
    -266 465
    -261 468
    -256 470
    -251 472
    -246 474
    -241 476
    -236 478
    -231 480
    -225 482
    -220 484
    -214 485
    -209 487
    -203 489
    -197 490
    -192 492
    -186 494
    -180 495
    -174 496
    -168 498
    -162 499
    -156 500
    -150 502
    -144 503
    -137 504
    -131 505
    -125 506
    -119 507
    -112 508
    -106 509
    -99 510
    -93 511
    -86 511
    -80 512
    -73 513
    -67 513
    -60 514
    -53 514
    -47 514
    -40 515
    -33 515
    -27 515
    -20 516
    -13 516
    -7 516
    0 516
    7 516
    13 516
    20 516
    27 515
    33 515
    40 515
    47 514
    53 514
    60 514
    67 513
    73 513
    80 512
    86 511
    93 511
    99 510
    106 509
    112 508
    119 507
    125 506
    131 505
    137 504
    144 503
    150 502
    156 500
    162 499
    168 498
    174 496
    180 495
    186 494
    192 492
    197 490
    203 489
    209 487
    214 485
    220 484
    225 482
    231 480
    236 478
    241 476
    246 474
    251 472
    256 470
    261 468
    266 465
    271 463
    275 461
    280 458
    284 456
    289 454
    293 451
    297 449
    301 446
    305 443
    309 441
    313 438
    317 435
    320 433
    324 430
    327 427
    330 424
    334 421
    337 418
    340 415
    343 412
    345 409
    348 406
    350 403
    353 400
    355 396
    357 393
    359 390
    361 387
    363 383
    365 380
    367 376
    368 373
    369 369
    371 366
    372 362
    373 359
    374 355
    374 351
    375 348
    375 344
    376 340
    376 337
    376 333
    376 329
    376 325
    376 321
    375 317
    375 313
    374 310
    373 306
    372 302
    371 298
    370 294
    368 289
    367 285
    365 281
    364 277
    362 273
    360 269
    357 265
    355 260
    353 256
    350 252
    347 248
    345 243
    342 239
    339 235
    335 231
    332 226
    328 222
    325 217
    321 213
    317 209
    313 204
    309 200
    304 195
    300 191
    295 186
    291 182
    286 177
    281 173
    276 168
    270 164
    265 159
    259 155
    254 150
    248 146
    242 141
    236 137
    230 132
    223 127
    217 123
    210 118
    204 114
    197 109
    190 104
    183 100
    175 95
    168 90
    160 86
    153 81
    145 76
    137 72
    129 67
    121 62
    112 58
    104 53
    95 48
    87 44
    78 39
    69 34
    60 30
    51 25
    41 20
    32 16
    23 11
    13 6
    3 1
    -7 -3
    -17 -8
    -27 -13
    -37 -17
    -48 -22
    -58 -27
    -69 -31
    -80 -36
    -91 -41
    -102 -45
    -113 -50
    -124 -55
    -135 -60
    -147 -64
    -158 -69
    -170 -74
    -182 -78
    -194 -83
    -206 -88
    -218 -92
    -230 -97
    -242 -101
    -255 -106
    -268 -111
    -280 -115
    -293 -120
    -306 -125
    -319 -129
    -332 -134
    -345 -138
    -359 -143
    -372 -148
    -386 -152
    -399 -157
    -413 -161
    -427 -166
    -441 -171
    -455 -175
    -469 -180
    -483 -184
    -498 -189
    -512 -193
    -527 -198
    -541 -202
    -556 -207
    -571 -211
    -586 -216
    -601 -220
    -616 -225
    -632 -229
    -647 -234
    -662 -238
    -678 -243
    -693 -247
    -709 -252
    -725 -256
    -741 -261
    -757 -265
    -773 -269
    -789 -274
    -805 -278
    -822 -283
    -838 -287
    -855 -291
    -871 -296
    -888 -300
    -905 -304
    -922 -309
    -939 -313
    -956 -317
    -973 -322
    -990 -326
    -1008 -330
    -1025 -334
    -1042 -339
    -1060 -343
    -1078 -347
    -1095 -351
    1100 -357
    1082 -353
    1064 -349
    1047 -344
    1029 -340
    1012 -336
    995 -332
    977 -327
    960 -323
    943 -318
    926 -314
    909 -310
    893 -305
    876 -301
    859 -297
    843 -292
    826 -288
    810 -283
    794 -279
    777 -274
    761 -270
    745 -265
    729 -261
    714 -257
    698 -252
    682 -248
    667 -243
    651 -239
    636 -234
    621 -229
    606 -225
    591 -220
    576 -216
    561 -211
    546 -207
    531 -202
    517 -198
    502 -193
    488 -188
    474 -184
    460 -179
    445 -175
    432 -170
    418 -165
    404 -161
    390 -156
    377 -151
    363 -147
    350 -142
    337 -138
    324 -133
    311 -128
    298 -124
    285 -119
    272 -114
    260 -109
    247 -105
    235 -100
    223 -95
    210 -91
    198 -86
    186 -81
    175 -77
    163 -72
    151 -67
    140 -62
    129 -58
    117 -53
    106 -48
    95 -43
    84 -39
    74 -34
    63 -29
    52 -25
    42 -20
    32 -15
    22 -10
    12 -6
    2 -1
    -8 4
    -18 9
    -27 13
    -37 18
    -46 23
    -55 28
    -64 32
    -73 37
    -82 42
    -91 47
    -99 51
    -108 56
    -116 61
    -124 65
    -132 70
    -140 75
    -148 80
    -156 84
    -163 89
    -171 94
    -178 98
    -185 103
    -192 108
    -199 112
    -206 117
    -212 122
    -219 126
    -225 131
    -231 136
    -237 140
    -243 145
    -249 150
    -255 154
    -260 159
    -266 163
    -271 168
    -276 172
    -281 177
    -286 181
    -291 186
    -296 191
    -300 195
    -304 199
    -309 204
    -313 208
    -317 213
    -320 217
    -324 222
    -328 226
    -331 230
    -334 235
    -337 239
    -340 244
    -343 248
    -346 252
    -348 256
    -351 261
    -353 265
    -355 269
    -357 273
    -359 278
    -361 282
    -363 286
    -364 290
    -366 294
    -367 298
    -368 302
    -369 306
    -370 310
    -371 314
    -371 318
    -372 322
    -372 326
    -372 330
    -372 334
    -372 338
    -372 341
    -372 345
    -371 349
    -371 353
    -370 356
    -369 360
    -368 363
    -367 367
    -366 371
    -365 374
    -363 378
    -362 381
    -360 384
    -358 388
    -356 391
    -354 395
    -352 398
    -350 401
    -347 404
    -345 408
    -342 411
    -339 414
    -337 417
    -334 420
    -331 423
    -328 426
    -324 429
    -321 432
    -317 434
    -314 437
    -310 440
    -306 443
    -303 445
    -299 448
    -295 451
    -290 453
    -286 456
    -282 458
    -277 460
    -273 463
    -268 465
    -264 467
    -259 470
    -254 472
    -249 474
    -244 476
    -239 478
    -234 480
    -229 482
    -223 484
    -218 486
    -213 488
    -207 489
    -201 491
    -196 493
    -190 494
    -184 496
    -179 497
    -173 499
    -167 500
    -161 502
    -155 503
    -149 504
    -143 505
    -136 506
    -130 508
    -124 509
    -118 510
    -111 510
    -105 511
    -98 512
    -92 513
    -86 514
    -79 514
    -73 515
    -66 516
    -60 516
    -53 517
    -46 517
    -40 517
    -33 518
    -27 518
    -20 518
    -13 518
    -7 518
    0 518
    7 518
    13 518
    20 518
    27 518
    33 518
    40 517
    46 517
    53 517
    60 516
    66 516
    73 515
    79 514
    86 514
    92 513
    98 512
    105 511
    111 510
    118 510
    124 509
    130 508
    136 506
    143 505
    149 504
    155 503
    161 502
    167 500
    173 499
    179 497
    184 496
    190 494
    196 493
    201 491
    207 489
    213 488
    218 486
    223 484
    229 482
    234 480
    239 478
    244 476
    249 474
    254 472
    259 470
    264 467
    268 465
    273 463
    277 460
    282 458
    286 456
    290 453
    295 451
    299 448
    303 445
    306 443
    310 440
    314 437
    317 434
    321 432
    324 429
    328 426
    331 423
    334 420
    337 417
    339 414
    342 411
    345 408
    347 404
    350 401
    352 398
    354 395
    356 391
    358 388
    360 384
    362 381
    363 378
    365 374
    366 371
    367 367
    368 363
    369 360
    370 356
    371 353
    371 349
    372 345
    372 341
    372 338
    372 334
    372 330
    372 326
    372 322
    371 318
    371 314
    370 310
    369 306
    368 302
    367 298
    366 294
    364 290
    363 286
    361 282
    359 278
    357 273
    355 269
    353 265
    351 261
    348 256
    346 252
    343 248
    340 244
    337 239
    334 235
    331 230
    328 226
    324 222
    320 217
    317 213
    313 208
    309 204
    304 199
    300 195
    296 191
    291 186
    286 181
    281 177
    276 172
    271 168
    266 163
    260 159
    255 154
    249 150
    243 145
    237 140
    231 136
    225 131
    219 126
    212 122
    206 117
    199 112
    192 108
    185 103
    178 98
    171 94
    163 89
    156 84
    148 80
    140 75
    132 70
    124 65
    116 61
    108 56
    99 51
    91 47
    82 42
    73 37
    64 32
    55 28
    46 23
    37 18
    27 13
    18 9
    8 4
    -2 -1
    -12 -6
    -22 -10
    -32 -15
    -42 -20
    -52 -25
    -63 -29
    -74 -34
    -84 -39
    -95 -43
    -106 -48
    -117 -53
    -129 -58
    -140 -62
    -151 -67
    -163 -72
    -175 -77
    -186 -81
    -198 -86
    -210 -91
    -223 -95
    -235 -100
    -247 -105
    -260 -109
    -272 -114
    -285 -119
    -298 -124
    -311 -128
    -324 -133
    -337 -138
    -350 -142
    -363 -147
    -377 -151
    -390 -156
    -404 -161
    -418 -165
    -432 -170
    -445 -175
    -460 -179
    -474 -184
    -488 -188
    -502 -193
    -517 -198
    -531 -202
    -546 -207
    -561 -211
    -576 -216
    -591 -220
    -606 -225
    -621 -229
    -636 -234
    -651 -239
    -667 -243
    -682 -248
    -698 -252
    -714 -257
    -729 -261
    -745 -265
    -761 -270
    -777 -274
    -794 -279
    -810 -283
    -826 -288
    -843 -292
    -859 -297
    -876 -301
    -893 -305
    -909 -310
    -926 -314
    -943 -318
    -960 -323
    -977 -327
    -995 -332
    -1012 -336
    -1029 -340
    -1047 -344
    -1064 -349
    -1082 -353
    -1100 -357
    1104 -363
    1086 -359
    1069 -355
    1051 -350
    1034 -346
    1016 -342
    999 -337
    982 -333
    965 -328
    948 -324
    931 -320
    914 -315
    897 -311
    880 -306
    864 -302
    847 -297
    831 -293
    814 -288
    798 -284
    782 -280
    766 -275
    750 -270
    734 -266
    718 -261
    702 -257
    687 -252
    671 -248
    656 -243
    641 -239
    625 -234
    610 -230
    595 -225
    580 -220
    565 -216
    551 -211
    536 -207
    521 -202
    507 -197
    493 -193
    478 -188
    464 -183
    450 -179
    436 -174
    422 -169
    409 -165
    395 -160
    381 -155
    368 -151
    355 -146
    341 -141
    328 -137
    315 -132
    302 -127
    290 -122
    277 -118
    264 -113
    252 -108
    240 -103
    227 -99
    215 -94
    203 -89
    191 -84
    179 -80
    168 -75
    156 -70
    145 -65
    133 -61
    122 -56
    111 -51
    100 -46
    89 -41
    78 -37
    68 -32
    57 -27
    47 -22
    37 -18
    26 -13
    16 -8
    6 -3
    -3 2
    -13 6
    -23 11
    -32 16
    -41 21
    -51 26
    -60 30
    -69 35
    -77 40
    -86 45
    -95 49
    -103 54
    -111 59
    -119 64
    -128 69
    -135 73
    -143 78
    -151 83
    -158 88
    -166 92
    -173 97
    -180 102
    -187 106
    -194 111
    -201 116
    -208 121
    -214 125
    -220 130
    -227 135
    -233 139
    -239 144
    -245 149
    -250 153
    -256 158
    -261 163
    -267 167
    -272 172
    -277 176
    -282 181
    -286 185
    -291 190
    -296 195
    -300 199
    -304 204
    -308 208
    -312 213
    -316 217
    -320 221
    -323 226
    -327 230
    -330 235
    -333 239
    -336 244
    -339 248
    -342 252
    -344 257
    -347 261
    -349 265
    -351 269
    -353 274
    -355 278
    -357 282
    -359 286
    -360 290
    -362 294
    -363 299
    -364 303
    -365 307
    -366 311
    -367 315
    -367 319
    -368 323
    -368 327
    -368 331
    -368 334
    -368 338
    -368 342
    -368 346
    -367 350
    -367 353
    -366 357
    -365 361
    -364 364
    -363 368
    -362 372
    -361 375
    -360 379
    -358 382
    -356 386
    -355 389
    -353 393
    -351 396
    -349 399
    -346 402
    -344 406
    -342 409
    -339 412
    -336 415
    -334 418
    -331 421
    -328 424
    -325 427
    -321 430
    -318 433
    -315 436
    -311 439
    -307 442
    -304 444
    -300 447
    -296 450
    -292 452
    -288 455
    -284 457
    -279 460
    -275 462
    -271 465
    -266 467
    -261 469
    -257 472
    -252 474
    -247 476
    -242 478
    -237 480
    -232 482
    -227 484
    -221 486
    -216 488
    -211 490
    -205 491
    -200 493
    -194 495
    -189 496
    -183 498
    -177 500
    -171 501
    -165 502
    -159 504
    -153 505
    -147 506
    -141 508
    -135 509
    -129 510
    -123 511
    -117 512
    -110 513
    -104 514
    -98 515
    -91 515
    -85 516
    -78 517
    -72 517
    -66 518
    -59 518
    -53 519
    -46 519
    -39 520
    -33 520
    -26 520
    -20 520
    -13 521
    -7 521
    0 521
    7 521
    13 521
    20 520
    26 520
    33 520
    39 520
    46 519
    53 519
    59 518
    66 518
    72 517
    78 517
    85 516
    91 515
    98 515
    104 514
    110 513
    117 512
    123 511
    129 510
    135 509
    141 508
    147 506
    153 505
    159 504
    165 502
    171 501
    177 500
    183 498
    189 496
    194 495
    200 493
    205 491
    211 490
    216 488
    221 486
    227 484
    232 482
    237 480
    242 478
    247 476
    252 474
    257 472
    261 469
    266 467
    271 465
    275 462
    279 460
    284 457
    288 455
    292 452
    296 450
    300 447
    304 444
    307 442
    311 439
    315 436
    318 433
    321 430
    325 427
    328 424
    331 421
    334 418
    336 415
    339 412
    342 409
    344 406
    346 402
    349 399
    351 396
    353 393
    355 389
    356 386
    358 382
    360 379
    361 375
    362 372
    363 368
    364 364
    365 361
    366 357
    367 353
    367 350
    368 346
    368 342
    368 338
    368 334
    368 331
    368 327
    368 323
    367 319
    367 315
    366 311
    365 307
    364 303
    363 299
    362 294
    360 290
    359 286
    357 282
    355 278
    353 274
    351 269
    349 265
    347 261
    344 257
    342 252
    339 248
    336 244
    333 239
    330 235
    327 230
    323 226
    320 221
    316 217
    312 213
    308 208
    304 204
    300 199
    296 195
    291 190
    286 185
    282 181
    277 176
    272 172
    267 167
    261 163
    256 158
    250 153
    245 149
    239 144
    233 139
    227 135
    220 130
    214 125
    208 121
    201 116
    194 111
    187 106
    180 102
    173 97
    166 92
    158 88
    151 83
    143 78
    135 73
    128 69
    119 64
    111 59
    103 54
    95 49
    86 45
    77 40
    69 35
    60 30
    51 26
    41 21
    32 16
    23 11
    13 6
    3 2
    -6 -3
    -16 -8
    -26 -13
    -37 -18
    -47 -22
    -57 -27
    -68 -32
    -78 -37
    -89 -41
    -100 -46
    -111 -51
    -122 -56
    -133 -61
    -145 -65
    -156 -70
    -168 -75
    -179 -80
    -191 -84
    -203 -89
    -215 -94
    -227 -99
    -240 -103
    -252 -108
    -264 -113
    -277 -118
    -290 -122
    -302 -127
    -315 -132
    -328 -137
    -341 -141
    -355 -146
    -368 -151
    -381 -155
    -395 -160
    -409 -165
    -422 -169
    -436 -174
    -450 -179
    -464 -183
    -478 -188
    -493 -193
    -507 -197
    -521 -202
    -536 -207
    -551 -211
    -565 -216
    -580 -220
    -595 -225
    -610 -230
    -625 -234
    -641 -239
    -656 -243
    -671 -248
    -687 -252
    -702 -257
    -718 -261
    -734 -266
    -750 -270
    -766 -275
    -782 -280
    -798 -284
    -814 -288
    -831 -293
    -847 -297
    -864 -302
    -880 -306
    -897 -311
    -914 -315
    -931 -320
    -948 -324
    -965 -328
    -982 -333
    -999 -337
    -1016 -342
    -1034 -346
    -1051 -350
    -1069 -355
    -1086 -359
    -1104 -363
    1108 -369
    1090 -365
    1073 -361
    1055 -356
    1038 -352
    1021 -347
    1003 -343
    986 -339
    969 -334
    952 -330
    935 -325
    918 -321
    901 -316
    885 -312
    868 -307
    852 -303
    835 -298
    819 -294
    803 -289
    786 -285
    770 -280
    754 -276
    739 -271
    723 -266
    707 -262
    691 -257
    676 -253
    661 -248
    645 -243
    630 -239
    615 -234
    600 -230
    585 -225
    570 -220
    555 -216
    541 -211
    526 -206
    512 -202
    497 -197
    483 -192
    469 -188
    455 -183
    441 -178
    427 -173
    413 -169
    400 -164
    386 -159
    373 -154
    359 -150
    346 -145
    333 -140
    320 -135
    307 -131
    294 -126
    282 -121
    269 -116
    257 -112
    244 -107
    232 -102
    220 -97
    208 -92
    196 -88
    184 -83
    173 -78
    161 -73
    150 -68
    138 -64
    127 -59
    116 -54
    105 -49
    94 -44
    83 -39
    73 -35
    62 -30
    52 -25
    41 -20
    31 -15
    21 -10
    11 -6
    1 -1
    -8 4
    -18 9
    -27 14
    -37 19
    -46 23
    -55 28
    -64 33
    -73 38
    -81 43
    -90 48
    -98 52
    -107 57
    -115 62
    -123 67
    -131 72
    -138 76
    -146 81
    -154 86
    -161 91
    -168 96
    -176 100
    -183 105
    -189 110
    -196 115
    -203 119
    -209 124
    -216 129
    -222 134
    -228 138
    -234 143
    -240 148
    -246 152
    -251 157
    -257 162
    -262 166
    -267 171
    -272 176
    -277 180
    -282 185
    -286 189
    -291 194
    -295 199
    -300 203
    -304 208
    -308 212
    -311 217
    -315 221
    -319 226
    -322 230
    -325 235
    -329 239
    -332 243
    -334 248
    -337 252
    -340 257
    -342 261
    -345 265
    -347 269
    -349 274
    -351 278
    -353 282
    -354 286
    -356 291
    -357 295
    -359 299
    -360 303
    -361 307
    -362 311
    -363 315
    -363 319
    -364 323
    -364 327
    -364 331
    -364 335
    -364 339
    -364 343
    -364 347
    -364 351
    -363 354
    -363 358
    -362 362
    -361 365
    -360 369
    -359 373
    -357 376
    -356 380
    -355 383
    -353 387
    -351 390
    -349 394
    -347 397
    -345 400
    -343 404
    -341 407
    -338 410
    -336 413
    -333 417
    -331 420
    -328 423
    -325 426
    -322 429
    -318 432
    -315 435
    -312 438
    -308 440
    -305 443
    -301 446
    -297 449
    -293 451
    -289 454
    -285 457
    -281 459
    -277 462
    -273 464
    -268 466
    -264 469
    -259 471
    -254 473
    -250 476
    -245 478
    -240 480
    -235 482
    -230 484
    -225 486
    -220 488
    -214 490
    -209 492
    -204 493
    -198 495
    -193 497
    -187 498
    -181 500
    -176 502
    -170 503
    -164 504
    -158 506
    -152 507
    -146 508
    -140 510
    -134 511
    -128 512
    -122 513
    -116 514
    -109 515
    -103 516
    -97 517
    -91 517
    -84 518
    -78 519
    -71 520
    -65 520
    -59 521
    -52 521
    -46 521
    -39 522
    -33 522
    -26 522
    -20 523
    -13 523
    -7 523
    0 523
    7 523
    13 523
    20 523
    26 522
    33 522
    39 522
    46 521
    52 521
    59 521
    65 520
    71 520
    78 519
    84 518
    91 517
    97 517
    103 516
    109 515
    116 514
    122 513
    128 512
    134 511
    140 510
    146 508
    152 507
    158 506
    164 504
    170 503
    176 502
    181 500
    187 498
    193 497
    198 495
    204 493
    209 492
    214 490
    220 488
    225 486
    230 484
    235 482
    240 480
    245 478
    250 476
    254 473
    259 471
    264 469
    268 466
    273 464
    277 462
    281 459
    285 457
    289 454
    293 451
    297 449
    301 446
    305 443
    308 440
    312 438
    315 435
    318 432
    322 429
    325 426
    328 423
    331 420
    333 417
    336 413
    338 410
    341 407
    343 404
    345 400
    347 397
    349 394
    351 390
    353 387
    355 383
    356 380
    357 376
    359 373
    360 369
    361 365
    362 362
    363 358
    363 354
    364 351
    364 347
    364 343
    364 339
    364 335
    364 331
    364 327
    364 323
    363 319
    363 315
    362 311
    361 307
    360 303
    359 299
    357 295
    356 291
    354 286
    353 282
    351 278
    349 274
    347 269
    345 265
    342 261
    340 257
    337 252
    334 248
    332 243
    329 239
    325 235
    322 230
    319 226
    315 221
    311 217
    308 212
    304 208
    300 203
    295 199
    291 194
    286 189
    282 185
    277 180
    272 176
    267 171
    262 166
    257 162
    251 157
    246 152
    240 148
    234 143
    228 138
    222 134
    216 129
    209 124
    203 119
    196 115
    189 110
    183 105
    176 100
    168 96
    161 91
    154 86
    146 81
    138 76
    131 72
    123 67
    115 62
    107 57
    98 52
    90 48
    81 43
    73 38
    64 33
    55 28
    46 23
    37 19
    27 14
    18 9
    8 4
    -1 -1
    -11 -6
    -21 -10
    -31 -15
    -41 -20
    -52 -25
    -62 -30
    -73 -35
    -83 -39
    -94 -44
    -105 -49
    -116 -54
    -127 -59
    -138 -64
    -150 -68
    -161 -73
    -173 -78
    -184 -83
    -196 -88
    -208 -92
    -220 -97
    -232 -102
    -244 -107
    -257 -112
    -269 -116
    -282 -121
    -294 -126
    -307 -131
    -320 -135
    -333 -140
    -346 -145
    -359 -150
    -373 -154
    -386 -159
    -400 -164
    -413 -169
    -427 -173
    -441 -178
    -455 -183
    -469 -188
    -483 -192
    -497 -197
    -512 -202
    -526 -206
    -541 -211
    -555 -216
    -570 -220
    -585 -225
    -600 -230
    -615 -234
    -630 -239
    -645 -243
    -661 -248
    -676 -253
    -691 -257
    -707 -262
    -723 -266
    -739 -271
    -754 -276
    -770 -280
    -786 -285
    -803 -289
    -819 -294
    -835 -298
    -852 -303
    -868 -307
    -885 -312
    -901 -316
    -918 -321
    -935 -325
    -952 -330
    -969 -334
    -986 -339
    -1003 -343
    -1021 -347
    -1038 -352
    -1055 -356
    -1073 -361
    -1090 -365
    -1108 -369
    1113 -375
    1095 -371
    1077 -367
    1060 -362
    1042 -358
    1025 -353
    1008 -349
    991 -344
    973 -340
    956 -335
    939 -331
    923 -326
    906 -322
    889 -317
    873 -313
    856 -308
    840 -304
    823 -299
    807 -294
    791 -290
    775 -285
    759 -281
    743 -276
    727 -271
    712 -267
    696 -262
    681 -258
    665 -253
    650 -248
    635 -244
    619 -239
    604 -234
    590 -230
    575 -225
    560 -220
    545 -215
    531 -211
    516 -206
    502 -201
    488 -197
    474 -192
    460 -187
    446 -182
    432 -178
    418 -173
    404 -168
    391 -163
    377 -158
    364 -154
    351 -149
    338 -144
    325 -139
    312 -134
    299 -130
    286 -125
    274 -120
    261 -115
    249 -110
    237 -105
    225 -101
    213 -96
    201 -91
    189 -86
    177 -81
    166 -76
    154 -71
    143 -67
    132 -62
    121 -57
    110 -52
    99 -47
    88 -42
    77 -37
    67 -32
    57 -28
    46 -23
    36 -18
    26 -13
    16 -8
    6 -3
    -3 2
    -13 7
    -22 11
    -32 16
    -41 21
    -50 26
    -59 31
    -68 36
    -76 41
    -85 46
    -93 50
    -102 55
    -110 60
    -118 65
    -126 70
    -134 75
    -141 80
    -149 84
    -156 89
    -164 94
    -171 99
    -178 104
    -185 108
    -191 113
    -198 118
    -205 123
    -211 128
    -217 132
    -223 137
    -229 142
    -235 147
    -241 151
    -246 156
    -252 161
    -257 165
    -262 170
    -267 175
    -272 179
    -277 184
    -282 189
    -286 193
    -291 198
    -295 202
    -299 207
    -303 212
    -307 216
    -311 221
    -314 225
    -318 230
    -321 234
    -324 239
    -327 243
    -330 248
    -333 252
    -336 256
    -338 261
    -340 265
    -343 269
    -345 274
    -347 278
    -349 282
    -350 287
    -352 291
    -353 295
    -355 299
    -356 303
    -357 307
    -358 312
    -359 316
    -359 320
    -360 324
    -360 328
    -360 332
    -361 336
    -361 340
    -360 343
    -360 347
    -360 351
    -359 355
    -359 359
    -358 363
    -357 366
    -356 370
    -355 374
    -354 377
    -353 381
    -351 384
    -349 388
    -348 391
    -346 395
    -344 398
    -342 401
    -340 405
    -338 408
    -335 411
    -333 415
    -330 418
    -327 421
    -325 424
    -322 427
    -319 430
    -315 433
    -312 436
    -309 439
    -305 442
    -302 445
    -298 447
    -295 450
    -291 453
    -287 456
    -283 458
    -279 461
    -274 463
    -270 466
    -266 468
    -261 470
    -257 473
    -252 475
    -247 477
    -243 479
    -238 482
    -233 484
    -228 486
    -223 488
    -218 490
    -212 492
    -207 493
    -202 495
    -196 497
    -191 499
    -185 500
    -180 502
    -174 503
    -168 505
    -163 506
    -157 508
    -151 509
    -145 510
    -139 512
    -133 513
    -127 514
    -121 515
    -115 516
    -108 517
    -102 518
    -96 519
    -90 519
    -83 520
    -77 521
    -71 522
    -64 522
    -58 523
    -52 523
    -45 524
    -39 524
    -32 524
    -26 524
    -19 525
    -13 525
    -6 525
    0 525
    6 525
    13 525
    19 525
    26 524
    32 524
    39 524
    45 524
    52 523
    58 523
    64 522
    71 522
    77 521
    83 520
    90 519
    96 519
    102 518
    108 517
    115 516
    121 515
    127 514
    133 513
    139 512
    145 510
    151 509
    157 508
    163 506
    168 505
    174 503
    180 502
    185 500
    191 499
    196 497
    202 495
    207 493
    212 492
    218 490
    223 488
    228 486
    233 484
    238 482
    243 479
    247 477
    252 475
    257 473
    261 470
    266 468
    270 466
    274 463
    279 461
    283 458
    287 456
    291 453
    295 450
    298 447
    302 445
    305 442
    309 439
    312 436
    315 433
    319 430
    322 427
    325 424
    327 421
    330 418
    333 415
    335 411
    338 408
    340 405
    342 401
    344 398
    346 395
    348 391
    349 388
    351 384
    353 381
    354 377
    355 374
    356 370
    357 366
    358 363
    359 359
    359 355
    360 351
    360 347
    360 343
    361 340
    361 336
    360 332
    360 328
    360 324
    359 320
    359 316
    358 312
    357 307
    356 303
    355 299
    353 295
    352 291
    350 287
    349 282
    347 278
    345 274
    343 269
    340 265
    338 261
    336 256
    333 252
    330 248
    327 243
    324 239
    321 234
    318 230
    314 225
    311 221
    307 216
    303 212
    299 207
    295 202
    291 198
    286 193
    282 189
    277 184
    272 179
    267 175
    262 170
    257 165
    252 161
    246 156
    241 151
    235 147
    229 142
    223 137
    217 132
    211 128
    205 123
    198 118
    191 113
    185 108
    178 104
    171 99
    164 94
    156 89
    149 84
    141 80
    134 75
    126 70
    118 65
    110 60
    102 55
    93 50
    85 46
    76 41
    68 36
    59 31
    50 26
    41 21
    32 16
    22 11
    13 7
    3 2
    -6 -3
    -16 -8
    -26 -13
    -36 -18
    -46 -23
    -57 -28
    -67 -32
    -77 -37
    -88 -42
    -99 -47
    -110 -52
    -121 -57
    -132 -62
    -143 -67
    -154 -71
    -166 -76
    -177 -81
    -189 -86
    -201 -91
    -213 -96
    -225 -101
    -237 -105
    -249 -110
    -261 -115
    -274 -120
    -286 -125
    -299 -130
    -312 -134
    -325 -139
    -338 -144
    -351 -149
    -364 -154
    -377 -158
    -391 -163
    -404 -168
    -418 -173
    -432 -178
    -446 -182
    -460 -187
    -474 -192
    -488 -197
    -502 -201
    -516 -206
    -531 -211
    -545 -215
    -560 -220
    -575 -225
    -590 -230
    -604 -234
    -619 -239
    -635 -244
    -650 -248
    -665 -253
    -681 -258
    -696 -262
    -712 -267
    -727 -271
    -743 -276
    -759 -281
    -775 -285
    -791 -290
    -807 -294
    -823 -299
    -840 -304
    -856 -308
    -873 -313
    -889 -317
    -906 -322
    -923 -326
    -939 -331
    -956 -335
    -973 -340
    -991 -344
    -1008 -349
    -1025 -353
    -1042 -358
    -1060 -362
    -1077 -367
    -1095 -371
    -1113 -375
    1117 -382
    1099 -377
    1082 -373
    1064 -368
    1047 -364
    1029 -359
    1012 -355
    995 -350
    978 -346
    961 -341
    944 -337
    927 -332
    910 -327
    894 -323
    877 -318
    861 -314
    844 -309
    828 -304
    812 -300
    796 -295
    780 -291
    764 -286
    748 -281
    732 -277
    716 -272
    701 -267
    685 -263
    670 -258
    655 -253
    639 -248
    624 -244
    609 -239
    594 -234
    579 -230
    565 -225
    550 -220
    536 -215
    521 -210
    507 -206
    492 -201
    478 -196
    464 -191
    450 -187
    437 -182
    423 -177
    409 -172
    396 -167
    382 -162
    369 -158
    356 -153
    343 -148
    330 -143
    317 -138
    304 -133
    291 -128
    279 -124
    266 -119
    254 -114
    242 -109
    230 -104
    218 -99
    206 -94
    194 -89
    182 -84
    171 -80
    159 -75
    148 -70
    137 -65
    126 -60
    115 -55
    104 -50
    93 -45
    82 -40
    72 -35
    61 -30
    51 -25
    41 -20
    31 -16
    21 -11
    11 -6
    2 -1
    -8 4
    -17 9
    -27 14
    -36 19
    -45 24
    -54 29
    -63 34
    -71 39
    -80 43
    -88 48
    -97 53
    -105 58
    -113 63
    -121 68
    -129 73
    -136 78
    -144 83
    -151 87
    -159 92
    -166 97
    -173 102
    -180 107
    -187 112
    -193 117
    -200 121
    -206 126
    -212 131
    -219 136
    -225 141
    -230 145
    -236 150
    -242 155
    -247 160
    -253 164
    -258 169
    -263 174
    -268 178
    -273 183
    -277 188
    -282 193
    -286 197
    -290 202
    -295 206
    -299 211
    -302 216
    -306 220
    -310 225
    -313 229
    -316 234
    -320 238
    -323 243
    -326 247
    -328 252
    -331 256
    -334 261
    -336 265
    -338 269
    -340 274
    -342 278
    -344 282
    -346 287
    -348 291
    -349 295
    -350 299
    -352 303
    -353 308
    -354 312
    -354 316
    -355 320
    -356 324
    -356 328
    -356 332
    -357 336
    -357 340
    -357 344
    -356 348
    -356 352
    -356 356
    -355 359
    -354 363
    -353 367
    -353 371
    -351 374
    -350 378
    -349 382
    -348 385
    -346 389
    -344 392
    -343 396
    -341 399
    -339 402
    -337 406
    -334 409
    -332 412
    -329 416
    -327 419
    -324 422
    -321 425
    -319 428
    -316 431
    -313 434
    -309 437
    -306 440
    -303 443
    -299 446
    -296 449
    -292 452
    -288 454
    -284 457
    -280 460
    -276 462
    -272 465
    -268 467
    -263 470
    -259 472
    -255 474
    -250 477
    -245 479
    -241 481
    -236 483
    -231 485
    -226 487
    -221 489
    -216 491
    -211 493
    -205 495
    -200 497
    -195 499
    -189 500
    -184 502
    -178 504
    -173 505
    -167 507
    -161 508
    -155 510
    -150 511
    -144 512
    -138 513
    -132 515
    -126 516
    -120 517
    -114 518
    -108 519
    -101 520
    -95 521
    -89 521
    -83 522
    -77 523
    -70 523
    -64 524
    -58 525
    -51 525
    -45 525
    -38 526
    -32 526
    -26 526
    -19 527
    -13 527
    -6 527
    0 527
    6 527
    13 527
    19 527
    26 526
    32 526
    38 526
    45 525
    51 525
    58 525
    64 524
    70 523
    77 523
    83 522
    89 521
    95 521
    101 520
    108 519
    114 518
    120 517
    126 516
    132 515
    138 513
    144 512
    150 511
    155 510
    161 508
    167 507
    173 505
    178 504
    184 502
    189 500
    195 499
    200 497
    205 495
    211 493
    216 491
    221 489
    226 487
    231 485
    236 483
    241 481
    245 479
    250 477
    255 474
    259 472
    263 470
    268 467
    272 465
    276 462
    280 460
    284 457
    288 454
    292 452
    296 449
    299 446
    303 443
    306 440
    309 437
    313 434
    316 431
    319 428
    321 425
    324 422
    327 419
    329 416
    332 412
    334 409
    337 406
    339 402
    341 399
    343 396
    344 392
    346 389
    348 385
    349 382
    350 378
    351 374
    353 371
    353 367
    354 363
    355 359
    356 356
    356 352
    356 348
    357 344
    357 340
    357 336
    356 332
    356 328
    356 324
    355 320
    354 316
    354 312
    353 308
    352 303
    350 299
    349 295
    348 291
    346 287
    344 282
    342 278
    340 274
    338 269
    336 265
    334 261
    331 256
    328 252
    326 247
    323 243
    320 238
    316 234
    313 229
    310 225
    306 220
    302 216
    299 211
    295 206
    290 202
    286 197
    282 193
    277 188
    273 183
    268 178
    263 174
    258 169
    253 164
    247 160
    242 155
    236 150
    230 145
    225 141
    219 136
    212 131
    206 126
    200 121
    193 117
    187 112
    180 107
    173 102
    166 97
    159 92
    151 87
    144 83
    136 78
    129 73
    121 68
    113 63
    105 58
    97 53
    88 48
    80 43
    71 39
    63 34
    54 29
    45 24
    36 19
    27 14
    17 9
    8 4
    -2 -1
    -11 -6
    -21 -11
    -31 -16
    -41 -20
    -51 -25
    -61 -30
    -72 -35
    -82 -40
    -93 -45
    -104 -50
    -115 -55
    -126 -60
    -137 -65
    -148 -70
    -159 -75
    -171 -80
    -182 -84
    -194 -89
    -206 -94
    -218 -99
    -230 -104
    -242 -109
    -254 -114
    -266 -119
    -279 -124
    -291 -128
    -304 -133
    -317 -138
    -330 -143
    -343 -148
    -356 -153
    -369 -158
    -382 -162
    -396 -167
    -409 -172
    -423 -177
    -437 -182
    -450 -187
    -464 -191
    -478 -196
    -492 -201
    -507 -206
    -521 -210
    -536 -215
    -550 -220
    -565 -225
    -579 -230
    -594 -234
    -609 -239
    -624 -244
    -639 -248
    -655 -253
    -670 -258
    -685 -263
    -701 -267
    -716 -272
    -732 -277
    -748 -281
    -764 -286
    -780 -291
    -796 -295
    -812 -300
    -828 -304
    -844 -309
    -861 -314
    -877 -318
    -894 -323
    -910 -327
    -927 -332
    -944 -337
    -961 -341
    -978 -346
    -995 -350
    -1012 -355
    -1029 -359
    -1047 -364
    -1064 -368
    -1082 -373
    -1099 -377
    -1117 -382
    1121 -388
    1104 -383
    1086 -379
    1069 -374
    1051 -370
    1034 -365
    1017 -361
    1000 -356
    983 -352
    966 -347
    949 -342
    932 -338
    915 -333
    898 -328
    882 -324
    865 -319
    849 -315
    833 -310
    816 -305
    800 -301
    784 -296
    768 -291
    752 -286
    737 -282
    721 -277
    705 -272
    690 -268
    675 -263
    659 -258
    644 -253
    629 -249
    614 -244
    599 -239
    584 -234
    569 -229
    555 -225
    540 -220
    526 -215
    512 -210
    497 -205
    483 -201
    469 -196
    455 -191
    441 -186
    428 -181
    414 -176
    401 -171
    387 -166
    374 -162
    361 -157
    348 -152
    335 -147
    322 -142
    309 -137
    296 -132
    284 -127
    271 -122
    259 -117
    247 -112
    235 -108
    223 -103
    211 -98
    199 -93
    187 -88
    176 -83
    164 -78
    153 -73
    142 -68
    131 -63
    120 -58
    109 -53
    98 -48
    87 -43
    77 -38
    66 -33
    56 -28
    46 -23
    36 -18
    26 -13
    16 -8
    6 -3
    -3 2
    -13 7
    -22 12
    -31 16
    -40 21
    -49 26
    -58 31
    -67 36
    -75 41
    -84 46
    -92 51
    -100 56
    -108 61
    -116 66
    -124 71
    -132 76
    -139 81
    -147 86
    -154 91
    -161 95
    -168 100
    -175 105
    -182 110
    -188 115
    -195 120
    -201 125
    -208 130
    -214 134
    -220 139
    -226 144
    -231 149
    -237 154
    -242 158
    -248 163
    -253 168
    -258 173
    -263 177
    -268 182
    -273 187
    -277 192
    -281 196
    -286 201
    -290 206
    -294 210
    -298 215
    -302 220
    -305 224
    -309 229
    -312 233
    -315 238
    -318 242
    -321 247
    -324 251
    -327 256
    -329 260
    -332 265
    -334 269
    -336 273
    -338 278
    -340 282
    -342 286
    -343 291
    -345 295
    -346 299
    -347 304
    -349 308
    -349 312
    -350 316
    -351 320
    -352 324
    -352 328
    -352 332
    -353 336
    -353 340
    -353 344
    -352 348
    -352 352
    -352 356
    -351 360
    -351 364
    -350 367
    -349 371
    -348 375
    -347 379
    -345 382
    -344 386
    -342 389
    -341 393
    -339 396
    -337 400
    -335 403
    -333 407
    -331 410
    -329 413
    -326 417
    -324 420
    -321 423
    -318 426
    -316 429
    -313 432
    -310 435
    -306 438
    -303 441
    -300 444
    -296 447
    -293 450
    -289 453
    -285 455
    -282 458
    -278 461
    -274 463
    -269 466
    -265 468
    -261 471
    -257 473
    -252 476
    -248 478
    -243 480
    -238 482
    -234 485
    -229 487
    -224 489
    -219 491
    -214 493
    -209 495
    -203 497
    -198 498
    -193 500
    -187 502
    -182 504
    -177 505
    -171 507
    -165 508
    -160 510
    -154 511
    -148 513
    -142 514
    -137 515
    -131 516
    -125 517
    -119 519
    -113 520
    -107 521
    -101 521
    -94 522
    -88 523
    -82 524
    -76 525
    -70 525
    -63 526
    -57 526
    -51 527
    -44 527
    -38 528
    -32 528
    -25 528
    -19 528
    -13 528
    -6 529
    0 529
    6 529
    13 528
    19 528
    25 528
    32 528
    38 528
    44 527
    51 527
    57 526
    63 526
    70 525
    76 525
    82 524
    88 523
    94 522
    101 521
    107 521
    113 520
    119 519
    125 517
    131 516
    137 515
    142 514
    148 513
    154 511
    160 510
    165 508
    171 507
    177 505
    182 504
    187 502
    193 500
    198 498
    203 497
    209 495
    214 493
    219 491
    224 489
    229 487
    234 485
    238 482
    243 480
    248 478
    252 476
    257 473
    261 471
    265 468
    269 466
    274 463
    278 461
    282 458
    285 455
    289 453
    293 450
    296 447
    300 444
    303 441
    306 438
    310 435
    313 432
    316 429
    318 426
    321 423
    324 420
    326 417
    329 413
    331 410
    333 407
    335 403
    337 400
    339 396
    341 393
    342 389
    344 386
    345 382
    347 379
    348 375
    349 371
    350 367
    351 364
    351 360
    352 356
    352 352
    352 348
    353 344
    353 340
    353 336
    352 332
    352 328
    352 324
    351 320
    350 316
    349 312
    349 308
    347 304
    346 299
    345 295
    343 291
    342 286
    340 282
    338 278
    336 273
    334 269
    332 265
    329 260
    327 256
    324 251
    321 247
    318 242
    315 238
    312 233
    309 229
    305 224
    302 220
    298 215
    294 210
    290 206
    286 201
    281 196
    277 192
    273 187
    268 182
    263 177
    258 173
    253 168
    248 163
    242 158
    237 154
    231 149
    226 144
    220 139
    214 134
    208 130
    201 125
    195 120
    188 115
    182 110
    175 105
    168 100
    161 95
    154 91
    147 86
    139 81
    132 76
    124 71
    116 66
    108 61
    100 56
    92 51
    84 46
    75 41
    67 36
    58 31
    49 26
    40 21
    31 16
    22 12
    13 7
    3 2
    -6 -3
    -16 -8
    -26 -13
    -36 -18
    -46 -23
    -56 -28
    -66 -33
    -77 -38
    -87 -43
    -98 -48
    -109 -53
    -120 -58
    -131 -63
    -142 -68
    -153 -73
    -164 -78
    -176 -83
    -187 -88
    -199 -93
    -211 -98
    -223 -103
    -235 -108
    -247 -112
    -259 -117
    -271 -122
    -284 -127
    -296 -132
    -309 -137
    -322 -142
    -335 -147
    -348 -152
    -361 -157
    -374 -162
    -387 -166
    -401 -171
    -414 -176
    -428 -181
    -441 -186
    -455 -191
    -469 -196
    -483 -201
    -497 -205
    -512 -210
    -526 -215
    -540 -220
    -555 -225
    -569 -229
    -584 -234
    -599 -239
    -614 -244
    -629 -249
    -644 -253
    -659 -258
    -675 -263
    -690 -268
    -705 -272
    -721 -277
    -737 -282
    -752 -286
    -768 -291
    -784 -296
    -800 -301
    -816 -305
    -833 -310
    -849 -315
    -865 -319
    -882 -324
    -898 -328
    -915 -333
    -932 -338
    -949 -342
    -966 -347
    -983 -352
    -1000 -356
    -1017 -361
    -1034 -365
    -1051 -370
    -1069 -374
    -1086 -379
    -1104 -383
    -1121 -388
    1126 -394
    1108 -390
    1091 -385
    1073 -380
    1056 -376
    1039 -371
    1021 -367
    1004 -362
    987 -357
    970 -353
    953 -348
    936 -343
    920 -339
    903 -334
    886 -329
    870 -325
    854 -320
    837 -315
    821 -311
    805 -306
    789 -301
    773 -296
    757 -292
    741 -287
    726 -282
    710 -277
    695 -273
    679 -268
    664 -263
    649 -258
    634 -253
    619 -249
    604 -244
    589 -239
    574 -234
    560 -229
    545 -224
    531 -220
    516 -215
    502 -210
    488 -205
    474 -200
    460 -195
    446 -190
    433 -185
    419 -180
    405 -176
    392 -171
    379 -166
    366 -161
    352 -156
    339 -151
    327 -146
    314 -141
    301 -136
    289 -131
    276 -126
    264 -121
    252 -116
    239 -111
    227 -106
    216 -101
    204 -96
    192 -91
    181 -86
    169 -81
    158 -76
    147 -71
    136 -66
    125 -61
    114 -56
    103 -51
    92 -46
    82 -41
    71 -36
    61 -31
    51 -26
    41 -21
    31 -16
    21 -11
    11 -6
    2 -1
    -8 4
    -17 9
    -26 14
    -35 19
    -44 24
    -53 29
    -62 34
    -70 39
    -79 44
    -87 49
    -95 54
    -103 59
    -111 64
    -119 69
    -127 74
    -134 79
    -142 84
    -149 89
    -156 94
    -163 99
    -170 104
    -177 108
    -184 113
    -190 118
    -196 123
    -203 128
    -209 133
    -215 138
    -221 143
    -227 148
    -232 152
    -238 157
    -243 162
    -248 167
    -253 172
    -258 176
    -263 181
    -268 186
    -272 191
    -277 195
    -281 200
    -285 205
    -289 209
    -293 214
    -297 219
    -301 223
    -304 228
    -307 233
    -311 237
    -314 242
    -317 246
    -319 251
    -322 255
    -325 260
    -327 264
    -329 269
    -332 273
    -334 278
    -336 282
    -337 286
    -339 291
    -341 295
    -342 299
    -343 303
    -344 308
    -345 312
    -346 316
    -347 320
    -348 324
    -348 328
    -348 333
    -349 337
    -349 341
    -349 345
    -349 349
    -348 352
    -348 356
    -347 360
    -347 364
    -346 368
    -345 372
    -344 375
    -343 379
    -342 383
    -340 386
    -339 390
    -337 394
    -336 397
    -334 401
    -332 404
    -330 407
    -328 411
    -325 414
    -323 417
    -321 421
    -318 424
    -315 427
    -312 430
    -309 433
    -306 436
    -303 439
    -300 442
    -297 445
    -293 448
    -290 451
    -286 454
    -283 457
    -279 459
    -275 462
    -271 465
    -267 467
    -263 470
    -259 472
    -254 475
    -250 477
    -245 479
    -241 482
    -236 484
    -231 486
    -227 488
    -222 490
    -217 492
    -212 494
    -207 496
    -202 498
    -196 500
    -191 502
    -186 503
    -180 505
    -175 507
    -169 508
    -164 510
    -158 511
    -153 513
    -147 514
    -141 515
    -135 517
    -129 518
    -124 519
    -118 520
    -112 521
    -106 522
    -100 523
    -94 524
    -87 525
    -81 525
    -75 526
    -69 527
    -63 527
    -57 528
    -50 528
    -44 529
    -38 529
    -32 530
    -25 530
    -19 530
    -13 530
    -6 530
    0 530
    6 530
    13 530
    19 530
    25 530
    32 530
    38 529
    44 529
    50 528
    57 528
    63 527
    69 527
    75 526
    81 525
    87 525
    94 524
    100 523
    106 522
    112 521
    118 520
    124 519
    129 518
    135 517
    141 515
    147 514
    153 513
    158 511
    164 510
    169 508
    175 507
    180 505
    186 503
    191 502
    196 500
    202 498
    207 496
    212 494
    217 492
    222 490
    227 488
    231 486
    236 484
    241 482
    245 479
    250 477
    254 475
    259 472
    263 470
    267 467
    271 465
    275 462
    279 459
    283 457
    286 454
    290 451
    293 448
    297 445
    300 442
    303 439
    306 436
    309 433
    312 430
    315 427
    318 424
    321 421
    323 417
    325 414
    328 411
    330 407
    332 404
    334 401
    336 397
    337 394
    339 390
    340 386
    342 383
    343 379
    344 375
    345 372
    346 368
    347 364
    347 360
    348 356
    348 352
    349 349
    349 345
    349 341
    349 337
    348 333
    348 328
    348 324
    347 320
    346 316
    345 312
    344 308
    343 303
    342 299
    341 295
    339 291
    337 286
    336 282
    334 278
    332 273
    329 269
    327 264
    325 260
    322 255
    319 251
    317 246
    314 242
    311 237
    307 233
    304 228
    301 223
    297 219
    293 214
    289 209
    285 205
    281 200
    277 195
    272 191
    268 186
    263 181
    258 176
    253 172
    248 167
    243 162
    238 157
    232 152
    227 148
    221 143
    215 138
    209 133
    203 128
    196 123
    190 118
    184 113
    177 108
    170 104
    163 99
    156 94
    149 89
    142 84
    134 79
    127 74
    119 69
    111 64
    103 59
    95 54
    87 49
    79 44
    70 39
    62 34
    53 29
    44 24
    35 19
    26 14
    17 9
    8 4
    -2 -1
    -11 -6
    -21 -11
    -31 -16
    -41 -21
    -51 -26
    -61 -31
    -71 -36
    -82 -41
    -92 -46
    -103 -51
    -114 -56
    -125 -61
    -136 -66
    -147 -71
    -158 -76
    -169 -81
    -181 -86
    -192 -91
    -204 -96
    -216 -101
    -227 -106
    -239 -111
    -252 -116
    -264 -121
    -276 -126
    -289 -131
    -301 -136
    -314 -141
    -327 -146
    -339 -151
    -352 -156
    -366 -161
    -379 -166
    -392 -171
    -405 -176
    -419 -180
    -433 -185
    -446 -190
    -460 -195
    -474 -200
    -488 -205
    -502 -210
    -516 -215
    -531 -220
    -545 -224
    -560 -229
    -574 -234
    -589 -239
    -604 -244
    -619 -249
    -634 -253
    -649 -258
    -664 -263
    -679 -268
    -695 -273
    -710 -277
    -726 -282
    -741 -287
    -757 -292
    -773 -296
    -789 -301
    -805 -306
    -821 -311
    -837 -315
    -854 -320
    -870 -325
    -886 -329
    -903 -334
    -920 -339
    -936 -343
    -953 -348
    -970 -353
    -987 -357
    -1004 -362
    -1021 -367
    -1039 -371
    -1056 -376
    -1073 -380
    -1091 -385
    -1108 -390
    -1126 -394
    1131 -400
    1113 -396
    1095 -391
    1078 -387
    1061 -382
    1043 -377
    1026 -373
    1009 -368
    992 -363
    975 -359
    958 -354
    941 -349
    924 -345
    908 -340
    891 -335
    875 -330
    858 -326
    842 -321
    826 -316
    810 -311
    794 -307
    778 -302
    762 -297
    746 -292
    731 -287
    715 -283
    699 -278
    684 -273
    669 -268
    654 -263
    639 -258
    624 -254
    609 -249
    594 -244
    579 -239
    565 -234
    550 -229
    536 -224
    521 -219
    507 -214
    493 -210
    479 -205
    465 -200
    451 -195
    437 -190
    424 -185
    410 -180
    397 -175
    384 -170
    371 -165
    357 -160
    344 -155
    332 -150
    319 -145
    306 -140
    294 -135
    281 -130
    269 -125
    257 -120
    244 -115
    232 -110
    221 -105
    209 -100
    197 -95
    186 -90
    174 -85
    163 -80
    152 -75
    141 -69
    130 -64
    119 -59
    108 -54
    97 -49
    87 -44
    76 -39
    66 -34
    56 -29
    46 -24
    36 -19
    26 -14
    17 -9
    7 -4
    -2 1
    -12 6
    -21 11
    -30 16
    -39 22
    -48 27
    -57 32
    -65 37
    -74 42
    -82 47
    -90 52
    -98 57
    -106 62
    -114 67
    -122 72
    -129 77
    -137 82
    -144 87
    -151 92
    -158 97
    -165 102
    -172 107
    -179 112
    -185 117
    -192 122
    -198 126
    -204 131
    -210 136
    -216 141
    -222 146
    -227 151
    -233 156
    -238 161
    -243 166
    -249 170
    -253 175
    -258 180
    -263 185
    -268 190
    -272 194
    -276 199
    -281 204
    -285 209
    -288 213
    -292 218
    -296 223
    -299 227
    -303 232
    -306 236
    -309 241
    -312 246
    -315 250
    -318 255
    -320 259
    -323 264
    -325 268
    -327 273
    -329 277
    -331 282
    -333 286
    -335 290
    -336 295
    -338 299
    -339 303
    -340 308
    -341 312
    -342 316
    -343 320
    -343 324
    -344 328
    -344 333
    -345 337
    -345 341
    -345 345
    -345 349
    -344 353
    -344 357
    -343 360
    -343 364
    -342 368
    -341 372
    -340 376
    -339 379
    -338 383
    -337 387
    -335 390
    -334 394
    -332 398
    -330 401
    -328 405
    -326 408
    -324 411
    -322 415
    -320 418
    -317 421
    -315 425
    -312 428
    -309 431
    -306 434
    -303 437
    -300 440
    -297 443
    -294 446
    -291 449
    -287 452
    -284 455
    -280 458
    -276 460
    -272 463
    -268 466
    -264 468
    -260 471
    -256 473
    -252 476
    -247 478
    -243 480
    -239 483
    -234 485
    -229 487
    -225 489
    -220 491
    -215 493
    -210 495
    -205 497
    -200 499
    -195 501
    -189 503
    -184 505
    -179 506
    -173 508
    -168 510
    -162 511
    -157 513
    -151 514
    -146 515
    -140 517
    -134 518
    -128 519
    -122 520
    -117 522
    -111 523
    -105 524
    -99 524
    -93 525
    -87 526
    -81 527
    -74 528
    -68 528
    -62 529
    -56 529
    -50 530
    -44 530
    -37 531
    -31 531
    -25 531
    -19 531
    -13 532
    -6 532
    0 532
    6 532
    13 532
    19 531
    25 531
    31 531
    37 531
    44 530
    50 530
    56 529
    62 529
    68 528
    74 528
    81 527
    87 526
    93 525
    99 524
    105 524
    111 523
    117 522
    122 520
    128 519
    134 518
    140 517
    146 515
    151 514
    157 513
    162 511
    168 510
    173 508
    179 506
    184 505
    189 503
    195 501
    200 499
    205 497
    210 495
    215 493
    220 491
    225 489
    229 487
    234 485
    239 483
    243 480
    247 478
    252 476
    256 473
    260 471
    264 468
    268 466
    272 463
    276 460
    280 458
    284 455
    287 452
    291 449
    294 446
    297 443
    300 440
    303 437
    306 434
    309 431
    312 428
    315 425
    317 421
    320 418
    322 415
    324 411
    326 408
    328 405
    330 401
    332 398
    334 394
    335 390
    337 387
    338 383
    339 379
    340 376
    341 372
    342 368
    343 364
    343 360
    344 357
    344 353
    345 349
    345 345
    345 341
    345 337
    344 333
    344 328
    343 324
    343 320
    342 316
    341 312
    340 308
    339 303
    338 299
    336 295
    335 290
    333 286
    331 282
    329 277
    327 273
    325 268
    323 264
    320 259
    318 255
    315 250
    312 246
    309 241
    306 236
    303 232
    299 227
    296 223
    292 218
    288 213
    285 209
    281 204
    276 199
    272 194
    268 190
    263 185
    258 180
    253 175
    249 170
    243 166
    238 161
    233 156
    227 151
    222 146
    216 141
    210 136
    204 131
    198 126
    192 122
    185 117
    179 112
    172 107
    165 102
    158 97
    151 92
    144 87
    137 82
    129 77
    122 72
    114 67
    106 62
    98 57
    90 52
    82 47
    74 42
    65 37
    57 32
    48 27
    39 22
    30 16
    21 11
    12 6
    2 1
    -7 -4
    -17 -9
    -26 -14
    -36 -19
    -46 -24
    -56 -29
    -66 -34
    -76 -39
    -87 -44
    -97 -49
    -108 -54
    -119 -59
    -130 -64
    -141 -69
    -152 -75
    -163 -80
    -174 -85
    -186 -90
    -197 -95
    -209 -100
    -221 -105
    -232 -110
    -244 -115
    -257 -120
    -269 -125
    -281 -130
    -294 -135
    -306 -140
    -319 -145
    -332 -150
    -344 -155
    -357 -160
    -371 -165
    -384 -170
    -397 -175
    -410 -180
    -424 -185
    -437 -190
    -451 -195
    -465 -200
    -479 -205
    -493 -210
    -507 -214
    -521 -219
    -536 -224
    -550 -229
    -565 -234
    -579 -239
    -594 -244
    -609 -249
    -624 -254
    -639 -258
    -654 -263
    -669 -268
    -684 -273
    -699 -278
    -715 -283
    -731 -287
    -746 -292
    -762 -297
    -778 -302
    -794 -307
    -810 -311
    -826 -316
    -842 -321
    -858 -326
    -875 -330
    -891 -335
    -908 -340
    -924 -345
    -941 -349
    -958 -354
    -975 -359
    -992 -363
    -1009 -368
    -1026 -373
    -1043 -377
    -1061 -382
    -1078 -387
    -1095 -391
    -1113 -396
    -1131 -400
    1135 -407
    1118 -402
    1100 -397
    1083 -393
    1065 -388
    1048 -383
    1031 -379
    1014 -374
    996 -369
    979 -365
    963 -360
    946 -355
    929 -350
    912 -346
    896 -341
    879 -336
    863 -331
    847 -327
    831 -322
    815 -317
    799 -312
    783 -307
    767 -302
    751 -298
    735 -293
    720 -288
    704 -283
    689 -278
    674 -273
    659 -268
    643 -264
    628 -259
    614 -254
    599 -249
    584 -244
    569 -239
    555 -234
    541 -229
    526 -224
    512 -219
    498 -214
    484 -209
    470 -204
    456 -199
    442 -194
    429 -189
    415 -184
    402 -179
    389 -174
    376 -169
    362 -164
    349 -159
    337 -154
    324 -149
    311 -144
    299 -139
    286 -134
    274 -129
    262 -124
    250 -119
    238 -113
    226 -108
    214 -103
    202 -98
    191 -93
    179 -88
    168 -83
    157 -78
    146 -73
    135 -68
    124 -63
    113 -58
    102 -52
    92 -47
    81 -42
    71 -37
    61 -32
    51 -27
    41 -22
    31 -17
    22 -12
    12 -7
    3 -1
    -7 4
    -16 9
    -25 14
    -34 19
    -43 24
    -51 29
    -60 34
    -69 39
    -77 44
    -85 49
    -93 54
    -101 60
    -109 65
    -117 70
    -124 75
    -132 80
    -139 85
    -146 90
    -153 95
    -160 100
    -167 105
    -174 110
    -180 115
    -187 120
    -193 125
    -199 130
    -205 135
    -211 140
    -217 145
    -222 149
    -228 154
    -233 159
    -239 164
    -244 169
    -249 174
    -253 179
    -258 184
    -263 188
    -267 193
    -272 198
    -276 203
    -280 207
    -284 212
    -288 217
    -291 222
    -295 226
    -298 231
    -301 236
    -305 240
    -308 245
    -310 249
    -313 254
    -316 259
    -318 263
    -321 268
    -323 272
    -325 277
    -327 281
    -329 285
    -330 290
    -332 294
    -333 299
    -335 303
    -336 307
    -337 311
    -338 316
    -339 320
    -339 324
    -340 328
    -340 332
    -340 337
    -341 341
    -341 345
    -341 349
    -340 353
    -340 357
    -340 361
    -339 364
    -338 368
    -338 372
    -337 376
    -336 380
    -334 383
    -333 387
    -332 391
    -330 394
    -329 398
    -327 401
    -325 405
    -323 408
    -321 412
    -319 415
    -316 419
    -314 422
    -311 425
    -309 428
    -306 432
    -303 435
    -300 438
    -297 441
    -294 444
    -291 447
    -288 450
    -284 453
    -281 456
    -277 458
    -273 461
    -270 464
    -266 466
    -262 469
    -258 472
    -254 474
    -249 477
    -245 479
    -241 481
    -236 484
    -232 486
    -227 488
    -222 490
    -218 492
    -213 495
    -208 497
    -203 499
    -198 500
    -193 502
    -188 504
    -182 506
    -177 508
    -172 509
    -166 511
    -161 512
    -155 514
    -150 515
    -144 517
    -139 518
    -133 519
    -127 521
    -121 522
    -115 523
    -110 524
    -104 525
    -98 526
    -92 527
    -86 527
    -80 528
    -74 529
    -68 530
    -62 530
    -56 531
    -49 531
    -43 532
    -37 532
    -31 532
    -25 533
    -19 533
    -12 533
    -6 533
    0 533
    6 533
    12 533
    19 533
    25 533
    31 532
    37 532
    43 532
    49 531
    56 531
    62 530
    68 530
    74 529
    80 528
    86 527
    92 527
    98 526
    104 525
    110 524
    115 523
    121 522
    127 521
    133 519
    139 518
    144 517
    150 515
    155 514
    161 512
    166 511
    172 509
    177 508
    182 506
    188 504
    193 502
    198 500
    203 499
    208 497
    213 495
    218 492
    222 490
    227 488
    232 486
    236 484
    241 481
    245 479
    249 477
    254 474
    258 472
    262 469
    266 466
    270 464
    273 461
    277 458
    281 456
    284 453
    288 450
    291 447
    294 444
    297 441
    300 438
    303 435
    306 432
    309 428
    311 425
    314 422
    316 419
    319 415
    321 412
    323 408
    325 405
    327 401
    329 398
    330 394
    332 391
    333 387
    334 383
    336 380
    337 376
    338 372
    338 368
    339 364
    340 361
    340 357
    340 353
    341 349
    341 345
    341 341
    340 337
    340 332
    340 328
    339 324
    339 320
    338 316
    337 311
    336 307
    335 303
    333 299
    332 294
    330 290
    329 285
    327 281
    325 277
    323 272
    321 268
    318 263
    316 259
    313 254
    310 249
    308 245
    305 240
    301 236
    298 231
    295 226
    291 222
    288 217
    284 212
    280 207
    276 203
    272 198
    267 193
    263 188
    258 184
    253 179
    249 174
    244 169
    239 164
    233 159
    228 154
    222 149
    217 145
    211 140
    205 135
    199 130
    193 125
    187 120
    180 115
    174 110
    167 105
    160 100
    153 95
    146 90
    139 85
    132 80
    124 75
    117 70
    109 65
    101 60
    93 54
    85 49
    77 44
    69 39
    60 34
    51 29
    43 24
    34 19
    25 14
    16 9
    7 4
    -3 -1
    -12 -7
    -22 -12
    -31 -17
    -41 -22
    -51 -27
    -61 -32
    -71 -37
    -81 -42
    -92 -47
    -102 -52
    -113 -58
    -124 -63
    -135 -68
    -146 -73
    -157 -78
    -168 -83
    -179 -88
    -191 -93
    -202 -98
    -214 -103
    -226 -108
    -238 -113
    -250 -119
    -262 -124
    -274 -129
    -286 -134
    -299 -139
    -311 -144
    -324 -149
    -337 -154
    -349 -159
    -362 -164
    -376 -169
    -389 -174
    -402 -179
    -415 -184
    -429 -189
    -442 -194
    -456 -199
    -470 -204
    -484 -209
    -498 -214
    -512 -219
    -526 -224
    -541 -229
    -555 -234
    -569 -239
    -584 -244
    -599 -249
    -614 -254
    -628 -259
    -643 -264
    -659 -268
    -674 -273
    -689 -278
    -704 -283
    -720 -288
    -735 -293
    -751 -298
    -767 -302
    -783 -307
    -799 -312
    -815 -317
    -831 -322
    -847 -327
    -863 -331
    -879 -336
    -896 -341
    -912 -346
    -929 -350
    -946 -355
    -963 -360
    -979 -365
    -996 -369
    -1014 -374
    -1031 -379
    -1048 -383
    -1065 -388
    -1083 -393
    -1100 -397
    -1118 -402
    -1135 -407
    1140 -413
    1122 -409
    1105 -404
    1087 -399
    1070 -394
    1053 -390
    1035 -385
    1018 -380
    1001 -375
    984 -371
    967 -366
    951 -361
    934 -356
    917 -352
    901 -347
    884 -342
    868 -337
    852 -332
    835 -327
    819 -323
    803 -318
    787 -313
    772 -308
    756 -303
    740 -298
    725 -293
    709 -288
    694 -283
    679 -278
    663 -274
    648 -269
    633 -264
    618 -259
    604 -254
    589 -249
    574 -244
    560 -239
    546 -234
    531 -229
    517 -224
    503 -219
    489 -214
    475 -209
    461 -204
    447 -199
    434 -194
    420 -189
    407 -183
    394 -178
    381 -173
    367 -168
    355 -163
    342 -158
    329 -153
    316 -148
    304 -143
    291 -138
    279 -133
    267 -128
    255 -122
    243 -117
    231 -112
    219 -107
    207 -102
    196 -97
    184 -92
    173 -87
    162 -81
    151 -76
    140 -71
    129 -66
    118 -61
    108 -56
    97 -51
    87 -45
    76 -40
    66 -35
    56 -30
    46 -25
    36 -20
    27 -15
    17 -9
    8 -4
    -2 1
    -11 6
    -20 11
    -29 16
    -38 21
    -46 27
    -55 32
    -63 37
    -72 42
    -80 47
    -88 52
    -96 57
    -104 62
    -112 67
    -119 72
    -127 78
    -134 83
    -141 88
    -148 93
    -155 98
    -162 103
    -169 108
    -175 113
    -182 118
    -188 123
    -194 128
    -200 133
    -206 138
    -212 143
    -217 148
    -223 153
    -228 158
    -234 163
    -239 168
    -244 172
    -249 177
    -253 182
    -258 187
    -262 192
    -267 197
    -271 201
    -275 206
    -279 211
    -283 216
    -286 221
    -290 225
    -293 230
    -297 235
    -300 239
    -303 244
    -306 249
    -309 253
    -311 258
    -314 262
    -316 267
    -318 271
    -320 276
    -322 280
    -324 285
    -326 289
    -328 294
    -329 298
    -330 302
    -331 307
    -333 311
    -334 315
    -334 320
    -335 324
    -336 328
    -336 332
    -336 336
    -337 340
    -337 345
    -337 349
    -336 353
    -336 357
    -336 361
    -335 364
    -334 368
    -334 372
    -333 376
    -332 380
    -331 384
    -329 387
    -328 391
    -327 395
    -325 398
    -323 402
    -321 405
    -319 409
    -317 412
    -315 416
    -313 419
    -311 422
    -308 426
    -306 429
    -303 432
    -300 435
    -297 438
    -294 441
    -291 444
    -288 447
    -285 450
    -281 453
    -278 456
    -274 459
    -271 462
    -267 464
    -263 467
    -259 470
    -255 472
    -251 475
    -247 477
    -243 480
    -238 482
    -234 485
    -229 487
    -225 489
    -220 491
    -215 493
    -211 495
    -206 497
    -201 499
    -196 501
    -191 503
    -186 505
    -181 507
    -175 509
    -170 510
    -165 512
    -159 513
    -154 515
    -148 516
    -143 518
    -137 519
    -132 520
    -126 522
    -120 523
    -114 524
    -109 525
    -103 526
    -97 527
    -91 528
    -85 529
    -79 529
    -73 530
    -67 531
    -61 531
    -55 532
    -49 532
    -43 533
    -37 533
    -31 534
    -25 534
    -18 534
    -12 534
    -6 534
    0 534
    6 534
    12 534
    18 534
    25 534
    31 534
    37 533
    43 533
    49 532
    55 532
    61 531
    67 531
    73 530
    79 529
    85 529
    91 528
    97 527
    103 526
    109 525
    114 524
    120 523
    126 522
    132 520
    137 519
    143 518
    148 516
    154 515
    159 513
    165 512
    170 510
    175 509
    181 507
    186 505
    191 503
    196 501
    201 499
    206 497
    211 495
    215 493
    220 491
    225 489
    229 487
    234 485
    238 482
    243 480
    247 477
    251 475
    255 472
    259 470
    263 467
    267 464
    271 462
    274 459
    278 456
    281 453
    285 450
    288 447
    291 444
    294 441
    297 438
    300 435
    303 432
    306 429
    308 426
    311 422
    313 419
    315 416
    317 412
    319 409
    321 405
    323 402
    325 398
    327 395
    328 391
    329 387
    331 384
    332 380
    333 376
    334 372
    334 368
    335 364
    336 361
    336 357
    336 353
    337 349
    337 345
    337 340
    336 336
    336 332
    336 328
    335 324
    334 320
    334 315
    333 311
    331 307
    330 302
    329 298
    328 294
    326 289
    324 285
    322 280
    320 276
    318 271
    316 267
    314 262
    311 258
    309 253
    306 249
    303 244
    300 239
    297 235
    293 230
    290 225
    286 221
    283 216
    279 211
    275 206
    271 201
    267 197
    262 192
    258 187
    253 182
    249 177
    244 172
    239 168
    234 163
    228 158
    223 153
    217 148
    212 143
    206 138
    200 133
    194 128
    188 123
    182 118
    175 113
    169 108
    162 103
    155 98
    148 93
    141 88
    134 83
    127 78
    119 72
    112 67
    104 62
    96 57
    88 52
    80 47
    72 42
    63 37
    55 32
    46 27
    38 21
    29 16
    20 11
    11 6
    2 1
    -8 -4
    -17 -9
    -27 -15
    -36 -20
    -46 -25
    -56 -30
    -66 -35
    -76 -40
    -87 -45
    -97 -51
    -108 -56
    -118 -61
    -129 -66
    -140 -71
    -151 -76
    -162 -81
    -173 -87
    -184 -92
    -196 -97
    -207 -102
    -219 -107
    -231 -112
    -243 -117
    -255 -122
    -267 -128
    -279 -133
    -291 -138
    -304 -143
    -316 -148
    -329 -153
    -342 -158
    -355 -163
    -367 -168
    -381 -173
    -394 -178
    -407 -183
    -420 -189
    -434 -194
    -447 -199
    -461 -204
    -475 -209
    -489 -214
    -503 -219
    -517 -224
    -531 -229
    -546 -234
    -560 -239
    -574 -244
    -589 -249
    -604 -254
    -618 -259
    -633 -264
    -648 -269
    -663 -274
    -679 -278
    -694 -283
    -709 -288
    -725 -293
    -740 -298
    -756 -303
    -772 -308
    -787 -313
    -803 -318
    -819 -323
    -835 -327
    -852 -332
    -868 -337
    -884 -342
    -901 -347
    -917 -352
    -934 -356
    -951 -361
    -967 -366
    -984 -371
    -1001 -375
    -1018 -380
    -1035 -385
    -1053 -390
    -1070 -394
    -1087 -399
    -1105 -404
    -1122 -409
    -1140 -413
    1145 -420
    1127 -415
    1109 -410
    1092 -405
    1075 -401
    1057 -396
    1040 -391
    1023 -386
    1006 -382
    989 -377
    972 -372
    955 -367
    939 -362
    922 -357
    906 -353
    889 -348
    873 -343
    856 -338
    840 -333
    824 -328
    808 -323
    792 -318
    777 -313
    761 -309
    745 -304
    730 -299
    714 -294
    699 -289
    684 -284
    668 -279
    653 -274
    638 -269
    623 -264
    609 -259
    594 -254
    579 -249
    565 -244
    551 -239
    536 -234
    522 -229
    508 -223
    494 -218
    480 -213
    466 -208
    453 -203
    439 -198
    425 -193
    412 -188
    399 -183
    386 -178
    373 -173
    360 -167
    347 -162
    334 -157
    321 -152
    309 -147
    296 -142
    284 -137
    272 -131
    260 -126
    248 -121
    236 -116
    224 -111
    212 -106
    201 -100
    190 -95
    178 -90
    167 -85
    156 -80
    145 -75
    134 -69
    123 -64
    113 -59
    102 -54
    92 -49
    81 -43
    71 -38
    61 -33
    51 -28
    42 -23
    32 -18
    22 -12
    13 -7
    4 -2
    -6 3
    -15 8
    -24 14
    -33 19
    -41 24
    -50 29
    -58 34
    -67 39
    -75 45
    -83 50
    -91 55
    -99 60
    -106 65
    -114 70
    -122 75
    -129 80
    -136 86
    -143 91
    -150 96
    -157 101
    -164 106
    -170 111
    -177 116
    -183 121
    -189 126
    -195 131
    -201 136
    -207 141
    -213 146
    -218 151
    -223 156
    -229 161
    -234 166
    -239 171
    -244 176
    -248 181
    -253 186
    -258 190
    -262 195
    -266 200
    -270 205
    -274 210
    -278 215
    -282 219
    -285 224
    -289 229
    -292 234
    -295 238
    -298 243
    -301 248
    -304 252
    -307 257
    -309 262
    -311 266
    -314 271
    -316 275
    -318 280
    -320 284
    -321 289
    -323 293
    -325 298
    -326 302
    -327 306
    -328 311
    -329 315
    -330 319
    -331 323
    -331 328
    -332 332
    -332 336
    -332 340
    -333 344
    -333 348
    -332 352
    -332 356
    -332 360
    -331 364
    -331 368
    -330 372
    -329 376
    -328 380
    -327 384
    -326 387
    -324 391
    -323 395
    -321 398
    -320 402
    -318 405
    -316 409
    -314 412
    -312 416
    -310 419
    -307 423
    -305 426
    -302 429
    -300 432
    -297 436
    -294 439
    -291 442
    -288 445
    -285 448
    -282 451
    -278 454
    -275 457
    -272 460
    -268 462
    -264 465
    -260 468
    -257 470
    -253 473
    -249 476
    -244 478
    -240 480
    -236 483
    -232 485
    -227 488
    -223 490
    -218 492
    -213 494
    -209 496
    -204 498
    -199 500
    -194 502
    -189 504
    -184 506
    -179 508
    -174 509
    -168 511
    -163 513
    -158 514
    -152 516
    -147 517
    -141 519
    -136 520
    -130 521
    -125 523
    -119 524
    -113 525
    -108 526
    -102 527
    -96 528
    -90 529
    -84 530
    -78 530
    -72 531
    -66 532
    -61 532
    -55 533
    -48 533
    -42 534
    -36 534
    -30 535
    -24 535
    -18 535
    -12 535
    -6 535
    0 535
    6 535
    12 535
    18 535
    24 535
    30 535
    36 534
    42 534
    48 533
    55 533
    61 532
    66 532
    72 531
    78 530
    84 530
    90 529
    96 528
    102 527
    108 526
    113 525
    119 524
    125 523
    130 521
    136 520
    141 519
    147 517
    152 516
    158 514
    163 513
    168 511
    174 509
    179 508
    184 506
    189 504
    194 502
    199 500
    204 498
    209 496
    213 494
    218 492
    223 490
    227 488
    232 485
    236 483
    240 480
    244 478
    249 476
    253 473
    257 470
    260 468
    264 465
    268 462
    272 460
    275 457
    278 454
    282 451
    285 448
    288 445
    291 442
    294 439
    297 436
    300 432
    302 429
    305 426
    307 423
    310 419
    312 416
    314 412
    316 409
    318 405
    320 402
    321 398
    323 395
    324 391
    326 387
    327 384
    328 380
    329 376
    330 372
    331 368
    331 364
    332 360
    332 356
    332 352
    333 348
    333 344
    332 340
    332 336
    332 332
    331 328
    331 323
    330 319
    329 315
    328 311
    327 306
    326 302
    325 298
    323 293
    321 289
    320 284
    318 280
    316 275
    314 271
    311 266
    309 262
    307 257
    304 252
    301 248
    298 243
    295 238
    292 234
    289 229
    285 224
    282 219
    278 215
    274 210
    270 205
    266 200
    262 195
    258 190
    253 186
    248 181
    244 176
    239 171
    234 166
    229 161
    223 156
    218 151
    213 146
    207 141
    201 136
    195 131
    189 126
    183 121
    177 116
    170 111
    164 106
    157 101
    150 96
    143 91
    136 86
    129 80
    122 75
    114 70
    106 65
    99 60
    91 55
    83 50
    75 45
    67 39
    58 34
    50 29
    41 24
    33 19
    24 14
    15 8
    6 3
    -4 -2
    -13 -7
    -22 -12
    -32 -18
    -42 -23
    -51 -28
    -61 -33
    -71 -38
    -81 -43
    -92 -49
    -102 -54
    -113 -59
    -123 -64
    -134 -69
    -145 -75
    -156 -80
    -167 -85
    -178 -90
    -190 -95
    -201 -100
    -212 -106
    -224 -111
    -236 -116
    -248 -121
    -260 -126
    -272 -131
    -284 -137
    -296 -142
    -309 -147
    -321 -152
    -334 -157
    -347 -162
    -360 -167
    -373 -173
    -386 -178
    -399 -183
    -412 -188
    -425 -193
    -439 -198
    -453 -203
    -466 -208
    -480 -213
    -494 -218
    -508 -223
    -522 -229
    -536 -234
    -551 -239
    -565 -244
    -579 -249
    -594 -254
    -609 -259
    -623 -264
    -638 -269
    -653 -274
    -668 -279
    -684 -284
    -699 -289
    -714 -294
    -730 -299
    -745 -304
    -761 -309
    -777 -313
    -792 -318
    -808 -323
    -824 -328
    -840 -333
    -856 -338
    -873 -343
    -889 -348
    -906 -353
    -922 -357
    -939 -362
    -955 -367
    -972 -372
    -989 -377
    -1006 -382
    -1023 -386
    -1040 -391
    -1057 -396
    -1075 -401
    -1092 -405
    -1109 -410
    -1127 -415
    -1145 -420
    1149 -426
    1132 -421
    1114 -417
    1097 -412
    1079 -407
    1062 -402
    1045 -397
    1028 -393
    1011 -388
    994 -383
    977 -378
    960 -373
    944 -368
    927 -363
    910 -359
    894 -354
    878 -349
    861 -344
    845 -339
    829 -334
    813 -329
    797 -324
    781 -319
    766 -314
    750 -309
    735 -304
    719 -299
    704 -294
    689 -289
    673 -284
    658 -279
    643 -274
    628 -269
    614 -264
    599 -259
    584 -254
    570 -249
    556 -244
    541 -238
    527 -233
    513 -228
    499 -223
    485 -218
    471 -213
    458 -208
    444 -203
    431 -198
    417 -192
    404 -187
    391 -182
    378 -177
    365 -172
    352 -167
    339 -161
    327 -156
    314 -151
    302 -146
    289 -141
    277 -135
    265 -130
    253 -125
    241 -120
    229 -115
    218 -109
    206 -104
    195 -99
    183 -94
    172 -89
    161 -83
    150 -78
    139 -73
    129 -68
    118 -62
    107 -57
    97 -52
    87 -47
    77 -42
    66 -36
    57 -31
    47 -26
    37 -21
    28 -15
    18 -10
    9 -5
    -0 0
    -10 5
    -19 11
    -27 16
    -36 21
    -45 26
    -53 32
    -61 37
    -70 42
    -78 47
    -86 52
    -94 57
    -101 63
    -109 68
    -116 73
    -124 78
    -131 83
    -138 88
    -145 93
    -152 99
    -159 104
    -165 109
    -172 114
    -178 119
    -184 124
    -190 129
    -196 134
    -202 139
    -208 144
    -213 149
    -218 154
    -224 159
    -229 164
    -234 169
    -239 174
    -244 179
    -248 184
    -253 189
    -257 194
    -261 199
    -265 204
    -269 208
    -273 213
    -277 218
    -281 223
    -284 228
    -287 232
    -290 237
    -294 242
    -296 247
    -299 251
    -302 256
    -304 261
    -307 265
    -309 270
    -311 274
    -313 279
    -315 283
    -317 288
    -319 292
    -320 297
    -322 301
    -323 306
    -324 310
    -325 314
    -326 319
    -327 323
    -327 327
    -328 331
    -328 336
    -328 340
    -328 344
    -328 348
    -328 352
    -328 356
    -328 360
    -327 364
    -327 368
    -326 372
    -325 376
    -324 380
    -323 383
    -322 387
    -321 391
    -319 395
    -318 398
    -316 402
    -314 405
    -313 409
    -311 413
    -308 416
    -306 419
    -304 423
    -302 426
    -299 429
    -297 433
    -294 436
    -291 439
    -288 442
    -285 445
    -282 448
    -279 451
    -276 454
    -272 457
    -269 460
    -265 463
    -262 465
    -258 468
    -254 471
    -250 473
    -246 476
    -242 479
    -238 481
    -234 483
    -229 486
    -225 488
    -220 490
    -216 493
    -211 495
    -207 497
    -202 499
    -197 501
    -192 503
    -187 505
    -182 507
    -177 508
    -172 510
    -167 512
    -162 514
    -156 515
    -151 517
    -146 518
    -140 519
    -135 521
    -129 522
    -123 523
    -118 525
    -112 526
    -107 527
    -101 528
    -95 529
    -89 530
    -83 530
    -78 531
    -72 532
    -66 533
    -60 533
    -54 534
    -48 534
    -42 535
    -36 535
    -30 535
    -24 536
    -18 536
    -12 536
    -6 536
    0 536
    6 536
    12 536
    18 536
    24 536
    30 535
    36 535
    42 535
    48 534
    54 534
    60 533
    66 533
    72 532
    78 531
    83 530
    89 530
    95 529
    101 528
    107 527
    112 526
    118 525
    123 523
    129 522
    135 521
    140 519
    146 518
    151 517
    156 515
    162 514
    167 512
    172 510
    177 508
    182 507
    187 505
    192 503
    197 501
    202 499
    207 497
    211 495
    216 493
    220 490
    225 488
    229 486
    234 483
    238 481
    242 479
    246 476
    250 473
    254 471
    258 468
    262 465
    265 463
    269 460
    272 457
    276 454
    279 451
    282 448
    285 445
    288 442
    291 439
    294 436
    297 433
    299 429
    302 426
    304 423
    306 419
    308 416
    311 413
    313 409
    314 405
    316 402
    318 398
    319 395
    321 391
    322 387
    323 383
    324 380
    325 376
    326 372
    327 368
    327 364
    328 360
    328 356
    328 352
    328 348
    328 344
    328 340
    328 336
    328 331
    327 327
    327 323
    326 319
    325 314
    324 310
    323 306
    322 301
    320 297
    319 292
    317 288
    315 283
    313 279
    311 274
    309 270
    307 265
    304 261
    302 256
    299 251
    296 247
    294 242
    290 237
    287 232
    284 228
    281 223
    277 218
    273 213
    269 208
    265 204
    261 199
    257 194
    253 189
    248 184
    244 179
    239 174
    234 169
    229 164
    224 159
    218 154
    213 149
    208 144
    202 139
    196 134
    190 129
    184 124
    178 119
    172 114
    165 109
    159 104
    152 99
    145 93
    138 88
    131 83
    124 78
    116 73
    109 68
    101 63
    94 57
    86 52
    78 47
    70 42
    61 37
    53 32
    45 26
    36 21
    27 16
    19 11
    10 5
    0 0
    -9 -5
    -18 -10
    -28 -15
    -37 -21
    -47 -26
    -57 -31
    -66 -36
    -77 -42
    -87 -47
    -97 -52
    -107 -57
    -118 -62
    -129 -68
    -139 -73
    -150 -78
    -161 -83
    -172 -89
    -183 -94
    -195 -99
    -206 -104
    -218 -109
    -229 -115
    -241 -120
    -253 -125
    -265 -130
    -277 -135
    -289 -141
    -302 -146
    -314 -151
    -327 -156
    -339 -161
    -352 -167
    -365 -172
    -378 -177
    -391 -182
    -404 -187
    -417 -192
    -431 -198
    -444 -203
    -458 -208
    -471 -213
    -485 -218
    -499 -223
    -513 -228
    -527 -233
    -541 -238
    -556 -244
    -570 -249
    -584 -254
    -599 -259
    -614 -264
    -628 -269
    -643 -274
    -658 -279
    -673 -284
    -689 -289
    -704 -294
    -719 -299
    -735 -304
    -750 -309
    -766 -314
    -781 -319
    -797 -324
    -813 -329
    -829 -334
    -845 -339
    -861 -344
    -878 -349
    -894 -354
    -910 -359
    -927 -363
    -944 -368
    -960 -373
    -977 -378
    -994 -383
    -1011 -388
    -1028 -393
    -1045 -397
    -1062 -402
    -1079 -407
    -1097 -412
    -1114 -417
    -1132 -421
    -1149 -426
    1154 -433
    1137 -428
    1119 -423
    1102 -418
    1084 -413
    1067 -409
    1050 -404
    1033 -399
    1016 -394
    999 -389
    982 -384
    965 -379
    948 -374
    932 -369
    915 -365
    899 -360
    883 -355
    866 -350
    850 -345
    834 -340
    818 -335
    802 -330
    786 -325
    771 -320
    755 -315
    740 -310
    724 -305
    709 -300
    694 -294
    678 -289
    663 -284
    648 -279
    634 -274
    619 -269
    604 -264
    590 -259
    575 -254
    561 -249
    546 -243
    532 -238
    518 -233
    504 -228
    490 -223
    477 -218
    463 -213
    449 -207
    436 -202
    422 -197
    409 -192
    396 -187
    383 -181
    370 -176
    357 -171
    344 -166
    332 -161
    319 -155
    307 -150
    294 -145
    282 -140
    270 -134
    258 -129
    246 -124
    235 -119
    223 -113
    211 -108
    200 -103
    189 -98
    177 -92
    166 -87
    155 -82
    145 -77
    134 -71
    123 -66
    113 -61
    102 -55
    92 -50
    82 -45
    72 -40
    62 -34
    52 -29
    42 -24
    33 -19
    23 -13
    14 -8
    5 -3
    -4 2
    -13 8
    -22 13
    -31 18
    -39 23
    -48 29
    -56 34
    -64 39
    -73 44
    -81 50
    -88 55
    -96 60
    -104 65
    -111 70
    -119 76
    -126 81
    -133 86
    -140 91
    -147 96
    -153 102
    -160 107
    -166 112
    -173 117
    -179 122
    -185 127
    -191 132
    -197 137
    -202 142
    -208 147
    -213 152
    -219 157
    -224 163
    -229 168
    -234 173
    -239 177
    -243 182
    -248 187
    -252 192
    -256 197
    -261 202
    -265 207
    -268 212
    -272 217
    -276 222
    -279 226
    -283 231
    -286 236
    -289 241
    -292 245
    -295 250
    -297 255
    -300 259
    -302 264
    -305 269
    -307 273
    -309 278
    -311 282
    -313 287
    -314 292
    -316 296
    -317 300
    -318 305
    -320 309
    -321 314
    -321 318
    -322 322
    -323 327
    -323 331
    -324 335
    -324 339
    -324 343
    -324 348
    -324 352
    -324 356
    -324 360
    -323 364
    -323 368
    -322 372
    -321 376
    -320 379
    -319 383
    -318 387
    -317 391
    -316 394
    -314 398
    -312 402
    -311 405
    -309 409
    -307 412
    -305 416
    -303 419
    -301 423
    -298 426
    -296 429
    -293 433
    -291 436
    -288 439
    -285 442
    -282 445
    -279 448
    -276 451
    -273 454
    -269 457
    -266 460
    -262 463
    -259 466
    -255 469
    -251 471
    -247 474
    -243 476
    -239 479
    -235 481
    -231 484
    -227 486
    -223 489
    -218 491
    -214 493
    -209 495
    -204 497
    -200 499
    -195 501
    -190 503
    -185 505
    -180 507
    -175 509
    -170 511
    -165 512
    -160 514
    -155 516
    -149 517
    -144 519
    -139 520
    -133 521
    -128 523
    -122 524
    -117 525
    -111 526
    -105 527
    -100 528
    -94 529
    -88 530
    -83 531
    -77 532
    -71 533
    -65 533
    -59 534
    -53 535
    -48 535
    -42 535
    -36 536
    -30 536
    -24 536
    -18 537
    -12 537
    -6 537
    0 537
    6 537
    12 537
    18 537
    24 536
    30 536
    36 536
    42 535
    48 535
    53 535
    59 534
    65 533
    71 533
    77 532
    83 531
    88 530
    94 529
    100 528
    105 527
    111 526
    117 525
    122 524
    128 523
    133 521
    139 520
    144 519
    149 517
    155 516
    160 514
    165 512
    170 511
    175 509
    180 507
    185 505
    190 503
    195 501
    200 499
    204 497
    209 495
    214 493
    218 491
    223 489
    227 486
    231 484
    235 481
    239 479
    243 476
    247 474
    251 471
    255 469
    259 466
    262 463
    266 460
    269 457
    273 454
    276 451
    279 448
    282 445
    285 442
    288 439
    291 436
    293 433
    296 429
    298 426
    301 423
    303 419
    305 416
    307 412
    309 409
    311 405
    312 402
    314 398
    316 394
    317 391
    318 387
    319 383
    320 379
    321 376
    322 372
    323 368
    323 364
    324 360
    324 356
    324 352
    324 348
    324 343
    324 339
    324 335
    323 331
    323 327
    322 322
    321 318
    321 314
    320 309
    318 305
    317 300
    316 296
    314 292
    313 287
    311 282
    309 278
    307 273
    305 269
    302 264
    300 259
    297 255
    295 250
    292 245
    289 241
    286 236
    283 231
    279 226
    276 222
    272 217
    268 212
    265 207
    261 202
    256 197
    252 192
    248 187
    243 182
    239 177
    234 173
    229 168
    224 163
    219 157
    213 152
    208 147
    202 142
    197 137
    191 132
    185 127
    179 122
    173 117
    166 112
    160 107
    153 102
    147 96
    140 91
    133 86
    126 81
    119 76
    111 70
    104 65
    96 60
    88 55
    81 50
    73 44
    64 39
    56 34
    48 29
    39 23
    31 18
    22 13
    13 8
    4 2
    -5 -3
    -14 -8
    -23 -13
    -33 -19
    -42 -24
    -52 -29
    -62 -34
    -72 -40
    -82 -45
    -92 -50
    -102 -55
    -113 -61
    -123 -66
    -134 -71
    -145 -77
    -155 -82
    -166 -87
    -177 -92
    -189 -98
    -200 -103
    -211 -108
    -223 -113
    -235 -119
    -246 -124
    -258 -129
    -270 -134
    -282 -140
    -294 -145
    -307 -150
    -319 -155
    -332 -161
    -344 -166
    -357 -171
    -370 -176
    -383 -181
    -396 -187
    -409 -192
    -422 -197
    -436 -202
    -449 -207
    -463 -213
    -477 -218
    -490 -223
    -504 -228
    -518 -233
    -532 -238
    -546 -243
    -561 -249
    -575 -254
    -590 -259
    -604 -264
    -619 -269
    -634 -274
    -648 -279
    -663 -284
    -678 -289
    -694 -294
    -709 -300
    -724 -305
    -740 -310
    -755 -315
    -771 -320
    -786 -325
    -802 -330
    -818 -335
    -834 -340
    -850 -345
    -866 -350
    -883 -355
    -899 -360
    -915 -365
    -932 -369
    -948 -374
    -965 -379
    -982 -384
    -999 -389
    -1016 -394
    -1033 -399
    -1050 -404
    -1067 -409
    -1084 -413
    -1102 -418
    -1119 -423
    -1137 -428
    -1154 -433
    1159 -439
    1141 -435
    1124 -430
    1106 -425
    1089 -420
    1072 -415
    1055 -410
    1038 -405
    1021 -400
    1004 -395
    987 -390
    970 -385
    953 -381
    937 -376
    920 -371
    904 -366
    888 -361
    871 -356
    855 -351
    839 -346
    823 -340
    807 -335
    791 -330
    776 -325
    760 -320
    745 -315
    729 -310
    714 -305
    699 -300
    684 -295
    668 -290
    654 -285
    639 -279
    624 -274
    609 -269
    595 -264
    580 -259
    566 -254
    552 -248
    537 -243
    523 -238
    509 -233
    495 -228
    482 -223
    468 -217
    454 -212
    441 -207
    428 -202
    414 -196
    401 -191
    388 -186
    375 -181
    362 -175
    350 -170
    337 -165
    324 -160
    312 -154
    300 -149
    288 -144
    275 -138
    263 -133
    252 -128
    240 -123
    228 -117
    217 -112
    205 -107
    194 -101
    183 -96
    172 -91
    161 -85
    150 -80
    139 -75
    128 -70
    118 -64
    108 -59
    97 -54
    87 -48
    77 -43
    67 -38
    57 -32
    48 -27
    38 -22
    29 -16
    19 -11
    10 -6
    1 -1
    -8 5
    -17 10
    -26 15
    -34 21
    -43 26
    -51 31
    -59 36
    -67 42
    -75 47
    -83 52
    -91 57
    -99 63
    -106 68
    -113 73
    -121 78
    -128 84
    -135 89
    -141 94
    -148 99
    -155 104
    -161 110
    -168 115
    -174 120
    -180 125
    -186 130
    -192 135
    -197 140
    -203 145
    -208 151
    -214 156
    -219 161
    -224 166
    -229 171
    -234 176
    -238 181
    -243 186
    -247 191
    -251 196
    -256 201
    -260 205
    -264 210
    -267 215
    -271 220
    -274 225
    -278 230
    -281 235
    -284 239
    -287 244
    -290 249
    -293 254
    -295 258
    -298 263
    -300 268
    -302 272
    -304 277
    -306 281
    -308 286
    -310 291
    -311 295
    -313 300
    -314 304
    -315 308
    -316 313
    -317 317
    -318 321
    -319 326
    -319 330
    -320 334
    -320 339
    -320 343
    -320 347
    -320 351
    -320 355
    -320 359
    -319 363
    -319 367
    -318 371
    -317 375
    -317 379
    -316 383
    -314 387
    -313 390
    -312 394
    -310 398
    -309 402
    -307 405
    -305 409
    -304 412
    -302 416
    -299 419
    -297 423
    -295 426
    -293 429
    -290 433
    -287 436
    -285 439
    -282 442
    -279 445
    -276 448
    -273 451
    -270 454
    -266 457
    -263 460
    -260 463
    -256 466
    -252 469
    -249 471
    -245 474
    -241 477
    -237 479
    -233 482
    -229 484
    -225 487
    -220 489
    -216 491
    -211 493
    -207 496
    -202 498
    -198 500
    -193 502
    -188 504
    -183 506
    -179 508
    -174 509
    -169 511
    -163 513
    -158 515
    -153 516
    -148 518
    -143 519
    -137 521
    -132 522
    -127 523
    -121 525
    -116 526
    -110 527
    -104 528
    -99 529
    -93 530
    -88 531
    -82 532
    -76 533
    -70 533
    -65 534
    -59 535
    -53 535
    -47 536
    -41 536
    -35 536
    -29 537
    -24 537
    -18 537
    -12 537
    -6 538
    0 538
    6 538
    12 537
    18 537
    24 537
    29 537
    35 536
    41 536
    47 536
    53 535
    59 535
    65 534
    70 533
    76 533
    82 532
    88 531
    93 530
    99 529
    104 528
    110 527
    116 526
    121 525
    127 523
    132 522
    137 521
    143 519
    148 518
    153 516
    158 515
    163 513
    169 511
    174 509
    179 508
    183 506
    188 504
    193 502
    198 500
    202 498
    207 496
    211 493
    216 491
    220 489
    225 487
    229 484
    233 482
    237 479
    241 477
    245 474
    249 471
    252 469
    256 466
    260 463
    263 460
    266 457
    270 454
    273 451
    276 448
    279 445
    282 442
    285 439
    287 436
    290 433
    293 429
    295 426
    297 423
    299 419
    302 416
    304 412
    305 409
    307 405
    309 402
    310 398
    312 394
    313 390
    314 387
    316 383
    317 379
    317 375
    318 371
    319 367
    319 363
    320 359
    320 355
    320 351
    320 347
    320 343
    320 339
    320 334
    319 330
    319 326
    318 321
    317 317
    316 313
    315 308
    314 304
    313 300
    311 295
    310 291
    308 286
    306 281
    304 277
    302 272
    300 268
    298 263
    295 258
    293 254
    290 249
    287 244
    284 239
    281 235
    278 230
    274 225
    271 220
    267 215
    264 210
    260 205
    256 201
    251 196
    247 191
    243 186
    238 181
    234 176
    229 171
    224 166
    219 161
    214 156
    208 151
    203 145
    197 140
    192 135
    186 130
    180 125
    174 120
    168 115
    161 110
    155 104
    148 99
    141 94
    135 89
    128 84
    121 78
    113 73
    106 68
    99 63
    91 57
    83 52
    75 47
    67 42
    59 36
    51 31
    43 26
    34 21
    26 15
    17 10
    8 5
    -1 -1
    -10 -6
    -19 -11
    -29 -16
    -38 -22
    -48 -27
    -57 -32
    -67 -38
    -77 -43
    -87 -48
    -97 -54
    -108 -59
    -118 -64
    -128 -70
    -139 -75
    -150 -80
    -161 -85
    -172 -91
    -183 -96
    -194 -101
    -205 -107
    -217 -112
    -228 -117
    -240 -123
    -252 -128
    -263 -133
    -275 -138
    -288 -144
    -300 -149
    -312 -154
    -324 -160
    -337 -165
    -350 -170
    -362 -175
    -375 -181
    -388 -186
    -401 -191
    -414 -196
    -428 -202
    -441 -207
    -454 -212
    -468 -217
    -482 -223
    -495 -228
    -509 -233
    -523 -238
    -537 -243
    -552 -248
    -566 -254
    -580 -259
    -595 -264
    -609 -269
    -624 -274
    -639 -279
    -654 -285
    -668 -290
    -684 -295
    -699 -300
    -714 -305
    -729 -310
    -745 -315
    -760 -320
    -776 -325
    -791 -330
    -807 -335
    -823 -340
    -839 -346
    -855 -351
    -871 -356
    -888 -361
    -904 -366
    -920 -371
    -937 -376
    -953 -381
    -970 -385
    -987 -390
    -1004 -395
    -1021 -400
    -1038 -405
    -1055 -410
    -1072 -415
    -1089 -420
    -1106 -425
    -1124 -430
    -1141 -435
    -1159 -439
    1164 -446
    1146 -441
    1129 -436
    1111 -431
    1094 -426
    1077 -422
    1060 -417
    1043 -412
    1026 -407
    1009 -402
    992 -397
    975 -392
    958 -387
    942 -382
    925 -377
    909 -372
    893 -367
    876 -362
    860 -356
    844 -351
    828 -346
    812 -341
    797 -336
    781 -331
    765 -326
    750 -321
    734 -316
    719 -311
    704 -305
    689 -300
    674 -295
    659 -290
    644 -285
    629 -280
    614 -274
    600 -269
    585 -264
    571 -259
    557 -254
    543 -248
    529 -243
    515 -238
    501 -233
    487 -227
    473 -222
    460 -217
    446 -212
    433 -206
    420 -201
    406 -196
    393 -190
    380 -185
    368 -180
    355 -175
    342 -169
    330 -164
    317 -159
    305 -153
    293 -148
    281 -143
    269 -137
    257 -132
    245 -127
    234 -121
    222 -116
    211 -111
    199 -105
    188 -100
    177 -95
    166 -89
    155 -84
    144 -79
    134 -73
    123 -68
    113 -63
    103 -57
    92 -52
    82 -46
    72 -41
    63 -36
    53 -30
    43 -25
    34 -20
    25 -14
    15 -9
    6 -4
    -3 2
    -12 7
    -20 12
    -29 18
    -37 23
    -46 28
    -54 34
    -62 39
    -70 44
    -78 49
    -86 55
    -93 60
    -101 65
    -108 71
    -115 76
    -122 81
    -129 86
    -136 92
    -143 97
    -150 102
    -156 107
    -162 112
    -169 118
    -175 123
    -181 128
    -187 133
    -192 138
    -198 143
    -203 148
    -209 154
    -214 159
    -219 164
    -224 169
    -229 174
    -233 179
    -238 184
    -242 189
    -247 194
    -251 199
    -255 204
    -259 209
    -262 214
    -266 219
    -270 223
    -273 228
    -276 233
    -279 238
    -282 243
    -285 247
    -288 252
    -290 257
    -293 262
    -295 266
    -298 271
    -300 276
    -302 280
    -303 285
    -305 289
    -307 294
    -308 298
    -310 303
    -311 307
    -312 312
    -313 316
    -314 321
    -314 325
    -315 329
    -315 334
    -316 338
    -316 342
    -316 346
    -316 350
    -316 354
    -316 359
    -315 363
    -315 367
    -314 371
    -313 375
    -313 378
    -312 382
    -311 386
    -309 390
    -308 394
    -307 397
    -305 401
    -304 405
    -302 408
    -300 412
    -298 415
    -296 419
    -294 422
    -292 426
    -289 429
    -287 432
    -284 436
    -282 439
    -279 442
    -276 445
    -273 448
    -270 451
    -267 454
    -263 457
    -260 460
    -257 463
    -253 466
    -250 469
    -246 471
    -242 474
    -238 477
    -234 479
    -230 482
    -226 484
    -222 487
    -218 489
    -214 491
    -209 494
    -205 496
    -200 498
    -196 500
    -191 502
    -186 504
    -182 506
    -177 508
    -172 510
    -167 511
    -162 513
    -157 515
    -152 516
    -146 518
    -141 520
    -136 521
    -131 522
    -125 524
    -120 525
    -114 526
    -109 527
    -103 528
    -98 529
    -92 530
    -87 531
    -81 532
    -75 533
    -70 534
    -64 534
    -58 535
    -52 536
    -47 536
    -41 537
    -35 537
    -29 537
    -23 537
    -18 538
    -12 538
    -6 538
    0 538
    6 538
    12 538
    18 538
    23 537
    29 537
    35 537
    41 537
    47 536
    52 536
    58 535
    64 534
    70 534
    75 533
    81 532
    87 531
    92 530
    98 529
    103 528
    109 527
    114 526
    120 525
    125 524
    131 522
    136 521
    141 520
    146 518
    152 516
    157 515
    162 513
    167 511
    172 510
    177 508
    182 506
    186 504
    191 502
    196 500
    200 498
    205 496
    209 494
    214 491
    218 489
    222 487
    226 484
    230 482
    234 479
    238 477
    242 474
    246 471
    250 469
    253 466
    257 463
    260 460
    263 457
    267 454
    270 451
    273 448
    276 445
    279 442
    282 439
    284 436
    287 432
    289 429
    292 426
    294 422
    296 419
    298 415
    300 412
    302 408
    304 405
    305 401
    307 397
    308 394
    309 390
    311 386
    312 382
    313 378
    313 375
    314 371
    315 367
    315 363
    316 359
    316 354
    316 350
    316 346
    316 342
    316 338
    315 334
    315 329
    314 325
    314 321
    313 316
    312 312
    311 307
    310 303
    308 298
    307 294
    305 289
    303 285
    302 280
    300 276
    298 271
    295 266
    293 262
    290 257
    288 252
    285 247
    282 243
    279 238
    276 233
    273 228
    270 223
    266 219
    262 214
    259 209
    255 204
    251 199
    247 194
    242 189
    238 184
    233 179
    229 174
    224 169
    219 164
    214 159
    209 154
    203 148
    198 143
    192 138
    187 133
    181 128
    175 123
    169 118
    162 112
    156 107
    150 102
    143 97
    136 92
    129 86
    122 81
    115 76
    108 71
    101 65
    93 60
    86 55
    78 49
    70 44
    62 39
    54 34
    46 28
    37 23
    29 18
    20 12
    12 7
    3 2
    -6 -4
    -15 -9
    -25 -14
    -34 -20
    -43 -25
    -53 -30
    -63 -36
    -72 -41
    -82 -46
    -92 -52
    -103 -57
    -113 -63
    -123 -68
    -134 -73
    -144 -79
    -155 -84
    -166 -89
    -177 -95
    -188 -100
    -199 -105
    -211 -111
    -222 -116
    -234 -121
    -245 -127
    -257 -132
    -269 -137
    -281 -143
    -293 -148
    -305 -153
    -317 -159
    -330 -164
    -342 -169
    -355 -175
    -368 -180
    -380 -185
    -393 -190
    -406 -196
    -420 -201
    -433 -206
    -446 -212
    -460 -217
    -473 -222
    -487 -227
    -501 -233
    -515 -238
    -529 -243
    -543 -248
    -557 -254
    -571 -259
    -585 -264
    -600 -269
    -614 -274
    -629 -280
    -644 -285
    -659 -290
    -674 -295
    -689 -300
    -704 -305
    -719 -311
    -734 -316
    -750 -321
    -765 -326
    -781 -331
    -797 -336
    -812 -341
    -828 -346
    -844 -351
    -860 -356
    -876 -362
    -893 -367
    -909 -372
    -925 -377
    -942 -382
    -958 -387
    -975 -392
    -992 -397
    -1009 -402
    -1026 -407
    -1043 -412
    -1060 -417
    -1077 -422
    -1094 -426
    -1111 -431
    -1129 -436
    -1146 -441
    -1164 -446
    1169 -453
    1151 -448
    1134 -443
    1116 -438
    1099 -433
    1082 -428
    1065 -423
    1047 -418
    1031 -413
    1014 -408
    997 -403
    980 -398
    963 -393
    947 -388
    930 -383
    914 -378
    898 -373
    881 -368
    865 -362
    849 -357
    833 -352
    817 -347
    802 -342
    786 -337
    770 -332
    755 -327
    740 -321
    724 -316
    709 -311
    694 -306
    679 -301
    664 -295
    649 -290
    634 -285
    620 -280
    605 -275
    591 -269
    576 -264
    562 -259
    548 -253
    534 -248
    520 -243
    506 -238
    492 -232
    479 -227
    465 -222
    452 -216
    438 -211
    425 -206
    412 -200
    399 -195
    386 -190
    373 -184
    360 -179
    348 -174
    335 -168
    323 -163
    310 -158
    298 -152
    286 -147
    274 -142
    262 -136
    251 -131
    239 -126
    227 -120
    216 -115
    205 -109
    193 -104
    182 -99
    171 -93
    160 -88
    150 -82
    139 -77
    129 -72
    118 -66
    108 -61
    98 -55
    88 -50
    78 -45
    68 -39
    58 -34
    49 -29
    39 -23
    30 -18
    21 -12
    12 -7
    3 -2
    -6 4
    -15 9
    -24 14
    -32 20
    -40 25
    -49 31
    -57 36
    -65 41
    -73 47
    -80 52
    -88 57
    -95 63
    -103 68
    -110 73
    -117 78
    -124 84
    -131 89
    -138 94
    -144 99
    -151 105
    -157 110
    -163 115
    -170 120
    -176 126
    -181 131
    -187 136
    -193 141
    -198 146
    -204 151
    -209 157
    -214 162
    -219 167
    -224 172
    -228 177
    -233 182
    -237 187
    -242 192
    -246 197
    -250 202
    -254 207
    -257 212
    -261 217
    -265 222
    -268 227
    -271 231
    -274 236
    -277 241
    -280 246
    -283 251
    -286 256
    -288 260
    -291 265
    -293 270
    -295 274
    -297 279
    -299 284
    -301 288
    -302 293
    -304 297
    -305 302
    -306 306
    -307 311
    -308 315
    -309 320
    -310 324
    -311 328
    -311 333
    -311 337
    -312 341
    -312 345
    -312 349
    -312 354
    -312 358
    -311 362
    -311 366
    -310 370
    -310 374
    -309 378
    -308 382
    -307 386
    -306 389
    -304 393
    -303 397
    -302 401
    -300 404
    -298 408
    -296 411
    -295 415
    -293 419
    -290 422
    -288 425
    -286 429
    -283 432
    -281 435
    -278 439
    -276 442
    -273 445
    -270 448
    -267 451
    -264 454
    -261 457
    -257 460
    -254 463
    -250 466
    -247 469
    -243 471
    -240 474
    -236 477
    -232 479
    -228 482
    -224 484
    -220 487
    -216 489
    -211 491
    -207 494
    -203 496
    -198 498
    -194 500
    -189 502
    -184 504
    -180 506
    -175 508
    -170 510
    -165 512
    -160 513
    -155 515
    -150 517
    -145 518
    -140 520
    -134 521
    -129 523
    -124 524
    -119 525
    -113 526
    -108 527
    -102 529
    -97 530
    -91 531
    -86 532
    -80 532
    -75 533
    -69 534
    -63 535
    -58 535
    -52 536
    -46 536
    -40 537
    -35 537
    -29 538
    -23 538
    -17 538
    -12 538
    -6 538
    0 538
    6 538
    12 538
    17 538
    23 538
    29 538
    35 537
    40 537
    46 536
    52 536
    58 535
    63 535
    69 534
    75 533
    80 532
    86 532
    91 531
    97 530
    102 529
    108 527
    113 526
    119 525
    124 524
    129 523
    134 521
    140 520
    145 518
    150 517
    155 515
    160 513
    165 512
    170 510
    175 508
    180 506
    184 504
    189 502
    194 500
    198 498
    203 496
    207 494
    211 491
    216 489
    220 487
    224 484
    228 482
    232 479
    236 477
    240 474
    243 471
    247 469
    250 466
    254 463
    257 460
    261 457
    264 454
    267 451
    270 448
    273 445
    276 442
    278 439
    281 435
    283 432
    286 429
    288 425
    290 422
    293 419
    295 415
    296 411
    298 408
    300 404
    302 401
    303 397
    304 393
    306 389
    307 386
    308 382
    309 378
    310 374
    310 370
    311 366
    311 362
    312 358
    312 354
    312 349
    312 345
    312 341
    311 337
    311 333
    311 328
    310 324
    309 320
    308 315
    307 311
    306 306
    305 302
    304 297
    302 293
    301 288
    299 284
    297 279
    295 274
    293 270
    291 265
    288 260
    286 256
    283 251
    280 246
    277 241
    274 236
    271 231
    268 227
    265 222
    261 217
    257 212
    254 207
    250 202
    246 197
    242 192
    237 187
    233 182
    228 177
    224 172
    219 167
    214 162
    209 157
    204 151
    198 146
    193 141
    187 136
    181 131
    176 126
    170 120
    163 115
    157 110
    151 105
    144 99
    138 94
    131 89
    124 84
    117 78
    110 73
    103 68
    95 63
    88 57
    80 52
    73 47
    65 41
    57 36
    49 31
    40 25
    32 20
    24 14
    15 9
    6 4
    -3 -2
    -12 -7
    -21 -12
    -30 -18
    -39 -23
    -49 -29
    -58 -34
    -68 -39
    -78 -45
    -88 -50
    -98 -55
    -108 -61
    -118 -66
    -129 -72
    -139 -77
    -150 -82
    -160 -88
    -171 -93
    -182 -99
    -193 -104
    -205 -109
    -216 -115
    -227 -120
    -239 -126
    -251 -131
    -262 -136
    -274 -142
    -286 -147
    -298 -152
    -310 -158
    -323 -163
    -335 -168
    -348 -174
    -360 -179
    -373 -184
    -386 -190
    -399 -195
    -412 -200
    -425 -206
    -438 -211
    -452 -216
    -465 -222
    -479 -227
    -492 -232
    -506 -238
    -520 -243
    -534 -248
    -548 -253
    -562 -259
    -576 -264
    -591 -269
    -605 -275
    -620 -280
    -634 -285
    -649 -290
    -664 -295
    -679 -301
    -694 -306
    -709 -311
    -724 -316
    -740 -321
    -755 -327
    -770 -332
    -786 -337
    -802 -342
    -817 -347
    -833 -352
    -849 -357
    -865 -362
    -881 -368
    -898 -373
    -914 -378
    -930 -383
    -947 -388
    -963 -393
    -980 -398
    -997 -403
    -1014 -408
    -1031 -413
    -1047 -418
    -1065 -423
    -1082 -428
    -1099 -433
    -1116 -438
    -1134 -443
    -1151 -448
    -1169 -453
    1174 -460
    1156 -455
    1139 -450
    1121 -445
    1104 -440
    1087 -435
    1070 -430
    1053 -425
    1036 -420
    1019 -415
    1002 -409
    985 -404
    968 -399
    952 -394
    935 -389
    919 -384
    903 -379
    887 -374
    870 -369
    854 -363
    838 -358
    823 -353
    807 -348
    791 -343
    776 -338
    760 -332
    745 -327
    729 -322
    714 -317
    699 -311
    684 -306
    669 -301
    654 -296
    640 -290
    625 -285
    610 -280
    596 -275
    582 -269
    567 -264
    553 -259
    539 -253
    525 -248
    511 -243
    498 -237
    484 -232
    470 -227
    457 -221
    443 -216
    430 -211
    417 -205
    404 -200
    391 -195
    378 -189
    366 -184
    353 -178
    340 -173
    328 -168
    316 -162
    304 -157
    291 -151
    280 -146
    268 -141
    256 -135
    244 -130
    233 -124
    221 -119
    210 -113
    199 -108
    188 -103
    177 -97
    166 -92
    155 -86
    145 -81
    134 -75
    124 -70
    113 -65
    103 -59
    93 -54
    83 -48
    73 -43
    64 -37
    54 -32
    45 -27
    35 -21
    26 -16
    17 -10
    8 -5
    -1 0
    -10 6
    -18 11
    -27 17
    -35 22
    -43 27
    -51 33
    -59 38
    -67 44
    -75 49
    -83 54
    -90 60
    -97 65
    -105 70
    -112 76
    -119 81
    -126 86
    -133 92
    -139 97
    -146 102
    -152 107
    -158 113
    -164 118
    -170 123
    -176 128
    -182 134
    -188 139
    -193 144
    -198 149
    -204 154
    -209 159
    -214 165
    -218 170
    -223 175
    -228 180
    -232 185
    -237 190
    -241 195
    -245 200
    -249 205
    -253 210
    -256 215
    -260 220
    -263 225
    -266 230
    -270 235
    -273 240
    -276 244
    -278 249
    -281 254
    -283 259
    -286 263
    -288 268
    -290 273
    -292 278
    -294 282
    -296 287
    -298 291
    -299 296
    -301 301
    -302 305
    -303 310
    -304 314
    -305 318
    -306 323
    -306 327
    -307 331
    -307 336
    -308 340
    -308 344
    -308 349
    -308 353
    -307 357
    -307 361
    -307 365
    -306 369
    -306 373
    -305 377
    -304 381
    -303 385
    -302 389
    -301 392
    -299 396
    -298 400
    -296 404
    -295 407
    -293 411
    -291 414
    -289 418
    -287 421
    -285 425
    -282 428
    -280 432
    -278 435
    -275 438
    -272 441
    -270 445
    -267 448
    -264 451
    -261 454
    -258 457
    -254 460
    -251 463
    -248 466
    -244 468
    -241 471
    -237 474
    -233 476
    -229 479
    -225 482
    -221 484
    -217 486
    -213 489
    -209 491
    -205 493
    -200 496
    -196 498
    -191 500
    -187 502
    -182 504
    -178 506
    -173 508
    -168 510
    -163 512
    -158 513
    -153 515
    -148 517
    -143 518
    -138 520
    -133 521
    -128 523
    -123 524
    -117 525
    -112 526
    -107 528
    -101 529
    -96 530
    -90 531
    -85 532
    -79 533
    -74 533
    -68 534
    -63 535
    -57 535
    -51 536
    -46 536
    -40 537
    -34 537
    -29 538
    -23 538
    -17 538
    -11 538
    -6 538
    0 538
    6 538
    11 538
    17 538
    23 538
    29 538
    34 537
    40 537
    46 536
    51 536
    57 535
    63 535
    68 534
    74 533
    79 533
    85 532
    90 531
    96 530
    101 529
    107 528
    112 526
    117 525
    123 524
    128 523
    133 521
    138 520
    143 518
    148 517
    153 515
    158 513
    163 512
    168 510
    173 508
    178 506
    182 504
    187 502
    191 500
    196 498
    200 496
    205 493
    209 491
    213 489
    217 486
    221 484
    225 482
    229 479
    233 476
    237 474
    241 471
    244 468
    248 466
    251 463
    254 460
    258 457
    261 454
    264 451
    267 448
    270 445
    272 441
    275 438
    278 435
    280 432
    282 428
    285 425
    287 421
    289 418
    291 414
    293 411
    295 407
    296 404
    298 400
    299 396
    301 392
    302 389
    303 385
    304 381
    305 377
    306 373
    306 369
    307 365
    307 361
    307 357
    308 353
    308 349
    308 344
    308 340
    307 336
    307 331
    306 327
    306 323
    305 318
    304 314
    303 310
    302 305
    301 301
    299 296
    298 291
    296 287
    294 282
    292 278
    290 273
    288 268
    286 263
    283 259
    281 254
    278 249
    276 244
    273 240
    270 235
    266 230
    263 225
    260 220
    256 215
    253 210
    249 205
    245 200
    241 195
    237 190
    232 185
    228 180
    223 175
    218 170
    214 165
    209 159
    204 154
    198 149
    193 144
    188 139
    182 134
    176 128
    170 123
    164 118
    158 113
    152 107
    146 102
    139 97
    133 92
    126 86
    119 81
    112 76
    105 70
    97 65
    90 60
    83 54
    75 49
    67 44
    59 38
    51 33
    43 27
    35 22
    27 17
    18 11
    10 6
    1 0
    -8 -5
    -17 -10
    -26 -16
    -35 -21
    -45 -27
    -54 -32
    -64 -37
    -73 -43
    -83 -48
    -93 -54
    -103 -59
    -113 -65
    -124 -70
    -134 -75
    -145 -81
    -155 -86
    -166 -92
    -177 -97
    -188 -103
    -199 -108
    -210 -113
    -221 -119
    -233 -124
    -244 -130
    -256 -135
    -268 -141
    -280 -146
    -291 -151
    -304 -157
    -316 -162
    -328 -168
    -340 -173
    -353 -178
    -366 -184
    -378 -189
    -391 -195
    -404 -200
    -417 -205
    -430 -211
    -443 -216
    -457 -221
    -470 -227
    -484 -232
    -498 -237
    -511 -243
    -525 -248
    -539 -253
    -553 -259
    -567 -264
    -582 -269
    -596 -275
    -610 -280
    -625 -285
    -640 -290
    -654 -296
    -669 -301
    -684 -306
    -699 -311
    -714 -317
    -729 -322
    -745 -327
    -760 -332
    -776 -338
    -791 -343
    -807 -348
    -823 -353
    -838 -358
    -854 -363
    -870 -369
    -887 -374
    -903 -379
    -919 -384
    -935 -389
    -952 -394
    -968 -399
    -985 -404
    -1002 -409
    -1019 -415
    -1036 -420
    -1053 -425
    -1070 -430
    -1087 -435
    -1104 -440
    -1121 -445
    -1139 -450
    -1156 -455
    -1174 -460
    1179 -467
    1161 -462
    1144 -457
    1126 -451
    1109 -446
    1092 -441
    1075 -436
    1058 -431
    1041 -426
    1024 -421
    1007 -416
    990 -411
    974 -406
    957 -401
    941 -395
    924 -390
    908 -385
    892 -380
    876 -375
    860 -370
    844 -364
    828 -359
    812 -354
    796 -349
    781 -343
    765 -338
    750 -333
    735 -328
    719 -322
    704 -317
    689 -312
    674 -307
    660 -301
    645 -296
    630 -291
    616 -285
    601 -280
    587 -275
    573 -269
    558 -264
    544 -259
    530 -253
    517 -248
    503 -242
    489 -237
    476 -232
    462 -226
    449 -221
    436 -216
    422 -210
    409 -205
    397 -199
    384 -194
    371 -188
    358 -183
    346 -178
    333 -172
    321 -167
    309 -161
    297 -156
    285 -150
    273 -145
    261 -139
    250 -134
    238 -129
    227 -123
    215 -118
    204 -112
    193 -107
    182 -101
    171 -96
    161 -90
    150 -85
    139 -79
    129 -74
    119 -68
    109 -63
    99 -57
    89 -52
    79 -47
    69 -41
    60 -36
    50 -30
    41 -25
    32 -19
    22 -14
    13 -8
    5 -3
    -4 3
    -13 8
    -21 13
    -30 19
    -38 24
    -46 30
    -54 35
    -62 41
    -70 46
    -77 51
    -85 57
    -92 62
    -99 67
    -107 73
    -114 78
    -120 84
    -127 89
    -134 94
    -140 99
    -147 105
    -153 110
    -159 115
    -165 121
    -171 126
    -177 131
    -182 136
    -188 142
    -193 147
    -198 152
    -204 157
    -208 162
    -213 167
    -218 173
    -223 178
    -227 183
    -231 188
    -236 193
    -240 198
    -244 203
    -248 208
    -251 213
    -255 218
    -258 223
    -262 228
    -265 233
    -268 238
    -271 243
    -274 247
    -276 252
    -279 257
    -281 262
    -283 267
    -286 271
    -288 276
    -290 281
    -291 285
    -293 290
    -295 295
    -296 299
    -297 304
    -298 308
    -300 313
    -300 317
    -301 322
    -302 326
    -302 330
    -303 335
    -303 339
    -303 343
    -304 347
    -303 352
    -303 356
    -303 360
    -303 364
    -302 368
    -302 372
    -301 376
    -300 380
    -299 384
    -298 388
    -297 392
    -296 395
    -294 399
    -293 403
    -291 407
    -289 410
    -287 414
    -286 417
    -283 421
    -281 424
    -279 428
    -277 431
    -274 434
    -272 438
    -269 441
    -266 444
    -264 447
    -261 450
    -258 453
    -255 456
    -251 459
    -248 462
    -245 465
    -241 468
    -238 471
    -234 473
    -231 476
    -227 479
    -223 481
    -219 484
    -215 486
    -211 489
    -207 491
    -202 493
    -198 495
    -194 498
    -189 500
    -185 502
    -180 504
    -176 506
    -171 508
    -166 510
    -162 511
    -157 513
    -152 515
    -147 517
    -142 518
    -137 520
    -132 521
    -126 522
    -121 524
    -116 525
    -111 526
    -106 528
    -100 529
    -95 530
    -89 531
    -84 532
    -78 532
    -73 533
    -67 534
    -62 535
    -56 535
    -51 536
    -45 536
    -40 537
    -34 537
    -28 538
    -23 538
    -17 538
    -11 538
    -6 538
    0 538
    6 538
    11 538
    17 538
    23 538
    28 538
    34 537
    40 537
    45 536
    51 536
    56 535
    62 535
    67 534
    73 533
    78 532
    84 532
    89 531
    95 530
    100 529
    106 528
    111 526
    116 525
    121 524
    126 522
    132 521
    137 520
    142 518
    147 517
    152 515
    157 513
    162 511
    166 510
    171 508
    176 506
    180 504
    185 502
    189 500
    194 498
    198 495
    202 493
    207 491
    211 489
    215 486
    219 484
    223 481
    227 479
    231 476
    234 473
    238 471
    241 468
    245 465
    248 462
    251 459
    255 456
    258 453
    261 450
    264 447
    266 444
    269 441
    272 438
    274 434
    277 431
    279 428
    281 424
    283 421
    286 417
    287 414
    289 410
    291 407
    293 403
    294 399
    296 395
    297 392
    298 388
    299 384
    300 380
    301 376
    302 372
    302 368
    303 364
    303 360
    303 356
    303 352
    304 347
    303 343
    303 339
    303 335
    302 330
    302 326
    301 322
    300 317
    300 313
    298 308
    297 304
    296 299
    295 295
    293 290
    291 285
    290 281
    288 276
    286 271
    283 267
    281 262
    279 257
    276 252
    274 247
    271 243
    268 238
    265 233
    262 228
    258 223
    255 218
    251 213
    248 208
    244 203
    240 198
    236 193
    231 188
    227 183
    223 178
    218 173
    213 167
    208 162
    204 157
    198 152
    193 147
    188 142
    182 136
    177 131
    171 126
    165 121
    159 115
    153 110
    147 105
    140 99
    134 94
    127 89
    120 84
    114 78
    107 73
    99 67
    92 62
    85 57
    77 51
    70 46
    62 41
    54 35
    46 30
    38 24
    30 19
    21 13
    13 8
    4 3
    -5 -3
    -13 -8
    -22 -14
    -32 -19
    -41 -25
    -50 -30
    -60 -36
    -69 -41
    -79 -47
    -89 -52
    -99 -57
    -109 -63
    -119 -68
    -129 -74
    -139 -79
    -150 -85
    -161 -90
    -171 -96
    -182 -101
    -193 -107
    -204 -112
    -215 -118
    -227 -123
    -238 -129
    -250 -134
    -261 -139
    -273 -145
    -285 -150
    -297 -156
    -309 -161
    -321 -167
    -333 -172
    -346 -178
    -358 -183
    -371 -188
    -384 -194
    -397 -199
    -409 -205
    -422 -210
    -436 -216
    -449 -221
    -462 -226
    -476 -232
    -489 -237
    -503 -242
    -517 -248
    -530 -253
    -544 -259
    -558 -264
    -573 -269
    -587 -275
    -601 -280
    -616 -285
    -630 -291
    -645 -296
    -660 -301
    -674 -307
    -689 -312
    -704 -317
    -719 -322
    -735 -328
    -750 -333
    -765 -338
    -781 -343
    -796 -349
    -812 -354
    -828 -359
    -844 -364
    -860 -370
    -876 -375
    -892 -380
    -908 -385
    -924 -390
    -941 -395
    -957 -401
    -974 -406
    -990 -411
    -1007 -416
    -1024 -421
    -1041 -426
    -1058 -431
    -1075 -436
    -1092 -441
    -1109 -446
    -1126 -451
    -1144 -457
    -1161 -462
    -1179 -467
    1184 -473
    1166 -468
    1149 -463
    1131 -458
    1114 -453
    1097 -448
    1080 -443
    1063 -438
    1046 -433
    1029 -428
    1012 -422
    995 -417
    979 -412
    962 -407
    946 -402
    929 -397
    913 -391
    897 -386
    881 -381
    865 -376
    849 -370
    833 -365
    817 -360
    802 -355
    786 -349
    771 -344
    755 -339
    740 -333
    725 -328
    710 -323
    695 -318
    680 -312
    665 -307
    650 -302
    636 -296
    621 -291
    607 -285
    592 -280
    578 -275
    564 -269
    550 -264
    536 -259
    522 -253
    508 -248
    495 -242
    481 -237
    468 -231
    454 -226
    441 -221
    428 -215
    415 -210
    402 -204
    389 -199
    376 -193
    364 -188
    351 -182
    339 -177
    327 -171
    314 -166
    302 -160
    290 -155
    279 -149
    267 -144
    255 -138
    244 -133
    232 -127
    221 -122
    210 -116
    199 -111
    188 -105
    177 -100
    166 -94
    155 -89
    145 -83
    135 -78
    124 -72
    114 -67
    104 -61
    94 -56
    84 -50
    75 -45
    65 -39
    56 -34
    46 -28
    37 -23
    28 -17
    19 -12
    10 -6
    1 -1
    -7 5
    -16 10
    -24 16
    -32 21
    -41 26
    -49 32
    -56 37
    -64 43
    -72 48
    -79 54
    -87 59
    -94 64
    -101 70
    -108 75
    -115 81
    -122 86
    -128 91
    -135 97
    -141 102
    -148 107
    -154 113
    -160 118
    -166 123
    -171 129
    -177 134
    -183 139
    -188 144
    -193 150
    -198 155
    -203 160
    -208 165
    -213 170
    -218 175
    -222 181
    -226 186
    -231 191
    -235 196
    -239 201
    -242 206
    -246 211
    -250 216
    -253 221
    -257 226
    -260 231
    -263 236
    -266 241
    -269 246
    -271 250
    -274 255
    -276 260
    -279 265
    -281 270
    -283 274
    -285 279
    -287 284
    -288 288
    -290 293
    -291 298
    -293 302
    -294 307
    -295 311
    -296 316
    -297 320
    -298 325
    -298 329
    -299 333
    -299 338
    -299 342
    -299 346
    -299 350
    -299 355
    -299 359
    -299 363
    -298 367
    -298 371
    -297 375
    -296 379
    -295 383
    -294 387
    -293 391
    -292 394
    -290 398
    -289 402
    -287 406
    -286 409
    -284 413
    -282 416
    -280 420
    -278 423
    -276 427
    -273 430
    -271 434
    -269 437
    -266 440
    -263 443
    -261 447
    -258 450
    -255 453
    -252 456
    -248 459
    -245 462
    -242 465
    -239 467
    -235 470
    -232 473
    -228 476
    -224 478
    -220 481
    -216 483
    -213 486
    -208 488
    -204 491
    -200 493
    -196 495
    -192 497
    -187 499
    -183 502
    -178 504
    -174 506
    -169 507
    -164 509
    -160 511
    -155 513
    -150 515
    -145 516
    -140 518
    -135 519
    -130 521
    -125 522
    -120 524
    -115 525
    -110 526
    -104 527
    -99 528
    -94 529
    -88 530
    -83 531
    -78 532
    -72 533
    -67 534
    -61 535
    -56 535
    -50 536
    -45 536
    -39 537
    -34 537
    -28 537
    -22 538
    -17 538
    -11 538
    -6 538
    0 538
    6 538
    11 538
    17 538
    22 538
    28 537
    34 537
    39 537
    45 536
    50 536
    56 535
    61 535
    67 534
    72 533
    78 532
    83 531
    88 530
    94 529
    99 528
    104 527
    110 526
    115 525
    120 524
    125 522
    130 521
    135 519
    140 518
    145 516
    150 515
    155 513
    160 511
    164 509
    169 507
    174 506
    178 504
    183 502
    187 499
    192 497
    196 495
    200 493
    204 491
    208 488
    213 486
    216 483
    220 481
    224 478
    228 476
    232 473
    235 470
    239 467
    242 465
    245 462
    248 459
    252 456
    255 453
    258 450
    261 447
    263 443
    266 440
    269 437
    271 434
    273 430
    276 427
    278 423
    280 420
    282 416
    284 413
    286 409
    287 406
    289 402
    290 398
    292 394
    293 391
    294 387
    295 383
    296 379
    297 375
    298 371
    298 367
    299 363
    299 359
    299 355
    299 350
    299 346
    299 342
    299 338
    299 333
    298 329
    298 325
    297 320
    296 316
    295 311
    294 307
    293 302
    291 298
    290 293
    288 288
    287 284
    285 279
    283 274
    281 270
    279 265
    276 260
    274 255
    271 250
    269 246
    266 241
    263 236
    260 231
    257 226
    253 221
    250 216
    246 211
    242 206
    239 201
    235 196
    231 191
    226 186
    222 181
    218 175
    213 170
    208 165
    203 160
    198 155
    193 150
    188 144
    183 139
    177 134
    171 129
    166 123
    160 118
    154 113
    148 107
    141 102
    135 97
    128 91
    122 86
    115 81
    108 75
    101 70
    94 64
    87 59
    79 54
    72 48
    64 43
    56 37
    49 32
    41 26
    32 21
    24 16
    16 10
    7 5
    -1 -1
    -10 -6
    -19 -12
    -28 -17
    -37 -23
    -46 -28
    -56 -34
    -65 -39
    -75 -45
    -84 -50
    -94 -56
    -104 -61
    -114 -67
    -124 -72
    -135 -78
    -145 -83
    -155 -89
    -166 -94
    -177 -100
    -188 -105
    -199 -111
    -210 -116
    -221 -122
    -232 -127
    -244 -133
    -255 -138
    -267 -144
    -279 -149
    -290 -155
    -302 -160
    -314 -166
    -327 -171
    -339 -177
    -351 -182
    -364 -188
    -376 -193
    -389 -199
    -402 -204
    -415 -210
    -428 -215
    -441 -221
    -454 -226
    -468 -231
    -481 -237
    -495 -242
    -508 -248
    -522 -253
    -536 -259
    -550 -264
    -564 -269
    -578 -275
    -592 -280
    -607 -285
    -621 -291
    -636 -296
    -650 -302
    -665 -307
    -680 -312
    -695 -318
    -710 -323
    -725 -328
    -740 -333
    -755 -339
    -771 -344
    -786 -349
    -802 -355
    -817 -360
    -833 -365
    -849 -370
    -865 -376
    -881 -381
    -897 -386
    -913 -391
    -929 -397
    -946 -402
    -962 -407
    -979 -412
    -995 -417
    -1012 -422
    -1029 -428
    -1046 -433
    -1063 -438
    -1080 -443
    -1097 -448
    -1114 -453
    -1131 -458
    -1149 -463
    -1166 -468
    -1184 -473
    1189 -480
    1171 -475
    1154 -470
    1136 -465
    1119 -460
    1102 -455
    1085 -450
    1068 -445
    1051 -439
    1034 -434
    1017 -429
    1001 -424
    984 -419
    967 -413
    951 -408
    935 -403
    918 -398
    902 -392
    886 -387
    870 -382
    854 -377
    838 -371
    823 -366
    807 -361
    791 -355
    776 -350
    761 -345
    745 -339
    730 -334
    715 -329
    700 -323
    685 -318
    670 -313
    656 -307
    641 -302
    626 -296
    612 -291
    598 -286
    583 -280
    569 -275
    555 -269
    541 -264
    527 -258
    514 -253
    500 -247
    487 -242
    473 -237
    460 -231
    447 -226
    433 -220
    420 -215
    407 -209
    395 -204
    382 -198
    369 -193
    357 -187
    344 -182
    332 -176
    320 -171
    308 -165
    296 -159
    284 -154
    272 -148
    261 -143
    249 -137
    238 -132
    226 -126
    215 -121
    204 -115
    193 -110
    182 -104
    172 -99
    161 -93
    151 -87
    140 -82
    130 -76
    120 -71
    110 -65
    100 -60
    90 -54
    80 -49
    71 -43
    61 -38
    52 -32
    43 -26
    33 -21
    24 -15
    16 -10
    7 -4
    -2 1
    -10 7
    -19 12
    -27 18
    -35 23
    -43 29
    -51 34
    -59 40
    -66 45
    -74 50
    -81 56
    -89 61
    -96 67
    -103 72
    -110 78
    -116 83
    -123 88
    -130 94
    -136 99
    -142 105
    -148 110
    -154 115
    -160 121
    -166 126
    -172 131
    -177 137
    -183 142
    -188 147
    -193 152
    -198 158
    -203 163
    -208 168
    -212 173
    -217 178
    -221 183
    -225 189
    -230 194
    -234 199
    -237 204
    -241 209
    -245 214
    -248 219
    -252 224
    -255 229
    -258 234
    -261 239
    -264 244
    -266 249
    -269 253
    -272 258
    -274 263
    -276 268
    -278 273
    -280 277
    -282 282
    -284 287
    -285 291
    -287 296
    -288 301
    -289 305
    -291 310
    -292 314
    -292 319
    -293 323
    -294 328
    -294 332
    -295 336
    -295 341
    -295 345
    -295 349
    -295 353
    -295 357
    -294 362
    -294 366
    -294 370
    -293 374
    -292 378
    -291 382
    -290 386
    -289 390
    -288 393
    -287 397
    -285 401
    -284 405
    -282 408
    -280 412
    -278 415
    -276 419
    -274 423
    -272 426
    -270 429
    -268 433
    -265 436
    -263 439
    -260 443
    -257 446
    -255 449
    -252 452
    -249 455
    -246 458
    -242 461
    -239 464
    -236 467
    -232 469
    -229 472
    -225 475
    -222 478
    -218 480
    -214 483
    -210 485
    -206 488
    -202 490
    -198 492
    -194 495
    -189 497
    -185 499
    -181 501
    -176 503
    -172 505
    -167 507
    -163 509
    -158 511
    -153 512
    -148 514
    -144 516
    -139 517
    -134 519
    -129 520
    -124 522
    -119 523
    -114 524
    -108 526
    -103 527
    -98 528
    -93 529
    -87 530
    -82 531
    -77 532
    -71 533
    -66 534
    -61 534
    -55 535
    -50 535
    -44 536
    -39 536
    -33 537
    -28 537
    -22 537
    -17 538
    -11 538
    -6 538
    0 538
    6 538
    11 538
    17 538
    22 537
    28 537
    33 537
    39 536
    44 536
    50 535
    55 535
    61 534
    66 534
    71 533
    77 532
    82 531
    87 530
    93 529
    98 528
    103 527
    108 526
    114 524
    119 523
    124 522
    129 520
    134 519
    139 517
    144 516
    148 514
    153 512
    158 511
    163 509
    167 507
    172 505
    176 503
    181 501
    185 499
    189 497
    194 495
    198 492
    202 490
    206 488
    210 485
    214 483
    218 480
    222 478
    225 475
    229 472
    232 469
    236 467
    239 464
    242 461
    246 458
    249 455
    252 452
    255 449
    257 446
    260 443
    263 439
    265 436
    268 433
    270 429
    272 426
    274 423
    276 419
    278 415
    280 412
    282 408
    284 405
    285 401
    287 397
    288 393
    289 390
    290 386
    291 382
    292 378
    293 374
    294 370
    294 366
    294 362
    295 357
    295 353
    295 349
    295 345
    295 341
    295 336
    294 332
    294 328
    293 323
    292 319
    292 314
    291 310
    289 305
    288 301
    287 296
    285 291
    284 287
    282 282
    280 277
    278 273
    276 268
    274 263
    272 258
    269 253
    266 249
    264 244
    261 239
    258 234
    255 229
    252 224
    248 219
    245 214
    241 209
    237 204
    234 199
    230 194
    225 189
    221 183
    217 178
    212 173
    208 168
    203 163
    198 158
    193 152
    188 147
    183 142
    177 137
    172 131
    166 126
    160 121
    154 115
    148 110
    142 105
    136 99
    130 94
    123 88
    116 83
    110 78
    103 72
    96 67
    89 61
    81 56
    74 50
    66 45
    59 40
    51 34
    43 29
    35 23
    27 18
    19 12
    10 7
    2 1
    -7 -4
    -16 -10
    -24 -15
    -33 -21
    -43 -26
    -52 -32
    -61 -38
    -71 -43
    -80 -49
    -90 -54
    -100 -60
    -110 -65
    -120 -71
    -130 -76
    -140 -82
    -151 -87
    -161 -93
    -172 -99
    -182 -104
    -193 -110
    -204 -115
    -215 -121
    -226 -126
    -238 -132
    -249 -137
    -261 -143
    -272 -148
    -284 -154
    -296 -159
    -308 -165
    -320 -171
    -332 -176
    -344 -182
    -357 -187
    -369 -193
    -382 -198
    -395 -204
    -407 -209
    -420 -215
    -433 -220
    -447 -226
    -460 -231
    -473 -237
    -487 -242
    -500 -247
    -514 -253
    -527 -258
    -541 -264
    -555 -269
    -569 -275
    -583 -280
    -598 -286
    -612 -291
    -626 -296
    -641 -302
    -656 -307
    -670 -313
    -685 -318
    -700 -323
    -715 -329
    -730 -334
    -745 -339
    -761 -345
    -776 -350
    -791 -355
    -807 -361
    -823 -366
    -838 -371
    -854 -377
    -870 -382
    -886 -387
    -902 -392
    -918 -398
    -935 -403
    -951 -408
    -967 -413
    -984 -419
    -1001 -424
    -1017 -429
    -1034 -434
    -1051 -439
    -1068 -445
    -1085 -450
    -1102 -455
    -1119 -460
    -1136 -465
    -1154 -470
    -1171 -475
    -1189 -480
    1194 -488
    1176 -482
    1159 -477
    1142 -472
    1124 -467
    1107 -462
    1090 -457
    1073 -451
    1056 -446
    1039 -441
    1022 -436
    1006 -430
    989 -425
    973 -420
    956 -415
    940 -409
    924 -404
    907 -399
    891 -393
    875 -388
    859 -383
    844 -378
    828 -372
    812 -367
    797 -361
    781 -356
    766 -351
    751 -345
    735 -340
    720 -335
    705 -329
    690 -324
    676 -318
    661 -313
    646 -307
    632 -302
    617 -297
    603 -291
    589 -286
    575 -280
    561 -275
    547 -269
    533 -264
    519 -258
    506 -253
    492 -247
    479 -242
    465 -236
    452 -231
    439 -225
    426 -220
    413 -214
    400 -209
    387 -203
    375 -198
    362 -192
    350 -186
    338 -181
    326 -175
    313 -170
    301 -164
    290 -159
    278 -153
    266 -147
    255 -142
    243 -136
    232 -131
    221 -125
    210 -120
    199 -114
    188 -108
    177 -103
    167 -97
    156 -92
    146 -86
    135 -80
    125 -75
    115 -69
    105 -64
    95 -58
    86 -53
    76 -47
    67 -41
    57 -36
    48 -30
    39 -25
    30 -19
    21 -14
    12 -8
    4 -2
    -5 3
    -13 9
    -21 14
    -30 20
    -38 25
    -45 31
    -53 36
    -61 42
    -68 47
    -76 53
    -83 58
    -90 64
    -97 69
    -104 75
    -111 80
    -118 85
    -124 91
    -131 96
    -137 102
    -143 107
    -149 112
    -155 118
    -161 123
    -166 128
    -172 134
    -177 139
    -183 144
    -188 150
    -193 155
    -198 160
    -203 165
    -207 171
    -212 176
    -216 181
    -220 186
    -224 191
    -228 196
    -232 202
    -236 207
    -240 212
    -243 217
    -247 222
    -250 227
    -253 232
    -256 237
    -259 242
    -262 247
    -264 251
    -267 256
    -269 261
    -271 266
    -273 271
    -275 275
    -277 280
    -279 285
    -281 290
    -282 294
    -284 299
    -285 303
    -286 308
    -287 313
    -288 317
    -289 321
    -289 326
    -290 330
    -290 335
    -291 339
    -291 343
    -291 348
    -291 352
    -291 356
    -290 360
    -290 364
    -289 368
    -289 372
    -288 376
    -287 380
    -286 384
    -285 388
    -284 392
    -283 396
    -281 400
    -280 403
    -278 407
    -277 411
    -275 414
    -273 418
    -271 421
    -269 425
    -267 428
    -264 432
    -262 435
    -259 438
    -257 442
    -254 445
    -251 448
    -249 451
    -246 454
    -243 457
    -239 460
    -236 463
    -233 466
    -230 469
    -226 471
    -223 474
    -219 477
    -215 479
    -211 482
    -208 484
    -204 487
    -200 489
    -196 492
    -191 494
    -187 496
    -183 498
    -179 500
    -174 502
    -170 504
    -165 506
    -161 508
    -156 510
    -151 512
    -147 514
    -142 515
    -137 517
    -132 518
    -127 520
    -122 521
    -117 523
    -112 524
    -107 525
    -102 526
    -97 528
    -92 529
    -86 530
    -81 531
    -76 531
    -71 532
    -65 533
    -60 534
    -55 534
    -49 535
    -44 535
    -38 536
    -33 536
    -27 537
    -22 537
    -16 537
    -11 537
    -5 537
    0 537
    5 537
    11 537
    16 537
    22 537
    27 537
    33 536
    38 536
    44 535
    49 535
    55 534
    60 534
    65 533
    71 532
    76 531
    81 531
    86 530
    92 529
    97 528
    102 526
    107 525
    112 524
    117 523
    122 521
    127 520
    132 518
    137 517
    142 515
    147 514
    151 512
    156 510
    161 508
    165 506
    170 504
    174 502
    179 500
    183 498
    187 496
    191 494
    196 492
    200 489
    204 487
    208 484
    211 482
    215 479
    219 477
    223 474
    226 471
    230 469
    233 466
    236 463
    239 460
    243 457
    246 454
    249 451
    251 448
    254 445
    257 442
    259 438
    262 435
    264 432
    267 428
    269 425
    271 421
    273 418
    275 414
    277 411
    278 407
    280 403
    281 400
    283 396
    284 392
    285 388
    286 384
    287 380
    288 376
    289 372
    289 368
    290 364
    290 360
    291 356
    291 352
    291 348
    291 343
    291 339
    290 335
    290 330
    289 326
    289 321
    288 317
    287 313
    286 308
    285 303
    284 299
    282 294
    281 290
    279 285
    277 280
    275 275
    273 271
    271 266
    269 261
    267 256
    264 251
    262 247
    259 242
    256 237
    253 232
    250 227
    247 222
    243 217
    240 212
    236 207
    232 202
    228 196
    224 191
    220 186
    216 181
    212 176
    207 171
    203 165
    198 160
    193 155
    188 150
    183 144
    177 139
    172 134
    166 128
    161 123
    155 118
    149 112
    143 107
    137 102
    131 96
    124 91
    118 85
    111 80
    104 75
    97 69
    90 64
    83 58
    76 53
    68 47
    61 42
    53 36
    45 31
    38 25
    30 20
    21 14
    13 9
    5 3
    -4 -2
    -12 -8
    -21 -14
    -30 -19
    -39 -25
    -48 -30
    -57 -36
    -67 -41
    -76 -47
    -86 -53
    -95 -58
    -105 -64
    -115 -69
    -125 -75
    -135 -80
    -146 -86
    -156 -92
    -167 -97
    -177 -103
    -188 -108
    -199 -114
    -210 -120
    -221 -125
    -232 -131
    -243 -136
    -255 -142
    -266 -147
    -278 -153
    -290 -159
    -301 -164
    -313 -170
    -326 -175
    -338 -181
    -350 -186
    -362 -192
    -375 -198
    -387 -203
    -400 -209
    -413 -214
    -426 -220
    -439 -225
    -452 -231
    -465 -236
    -479 -242
    -492 -247
    -506 -253
    -519 -258
    -533 -264
    -547 -269
    -561 -275
    -575 -280
    -589 -286
    -603 -291
    -617 -297
    -632 -302
    -646 -307
    -661 -313
    -676 -318
    -690 -324
    -705 -329
    -720 -335
    -735 -340
    -751 -345
    -766 -351
    -781 -356
    -797 -361
    -812 -367
    -828 -372
    -844 -378
    -859 -383
    -875 -388
    -891 -393
    -907 -399
    -924 -404
    -940 -409
    -956 -415
    -973 -420
    -989 -425
    -1006 -430
    -1022 -436
    -1039 -441
    -1056 -446
    -1073 -451
    -1090 -457
    -1107 -462
    -1124 -467
    -1142 -472
    -1159 -477
    -1176 -482
    -1194 -488
    1199 -495
    1182 -489
    1164 -484
    1147 -479
    1130 -474
    1112 -469
    1095 -463
    1078 -458
    1061 -453
    1044 -448
    1028 -442
    1011 -437
    994 -432
    978 -426
    962 -421
    945 -416
    929 -411
    913 -405
    897 -400
    881 -395
    865 -389
    849 -384
    833 -378
    818 -373
    802 -368
    787 -362
    771 -357
    756 -351
    741 -346
    726 -341
    711 -335
    696 -330
    681 -324
    666 -319
    652 -313
    637 -308
    623 -302
    609 -297
    594 -291
    580 -286
    566 -280
    552 -275
    538 -269
    525 -264
    511 -258
    498 -253
    484 -247
    471 -241
    458 -236
    444 -230
    431 -225
    419 -219
    406 -214
    393 -208
    380 -202
    368 -197
    356 -191
    343 -186
    331 -180
    319 -174
    307 -169
    295 -163
    283 -158
    272 -152
    260 -146
    249 -141
    238 -135
    226 -130
    215 -124
    204 -118
    194 -113
    183 -107
    172 -101
    162 -96
    151 -90
    141 -85
    131 -79
    121 -73
    111 -68
    101 -62
    91 -57
    82 -51
    72 -45
    63 -40
    54 -34
    45 -28
    36 -23
    27 -17
    18 -12
    9 -6
    1 -1
    -8 5
    -16 11
    -24 16
    -32 22
    -40 27
    -48 33
    -55 38
    -63 44
    -70 49
    -78 55
    -85 60
    -92 66
    -99 71
    -106 77
    -112 82
    -119 88
    -125 93
    -132 99
    -138 104
    -144 109
    -150 115
    -155 120
    -161 126
    -167 131
    -172 136
    -177 142
    -183 147
    -188 152
    -193 158
    -197 163
    -202 168
    -206 173
    -211 178
    -215 184
    -219 189
    -223 194
    -227 199
    -231 204
    -235 209
    -238 214
    -242 219
    -245 224
    -248 229
    -251 234
    -254 239
    -257 244
    -259 249
    -262 254
    -264 259
    -267 264
    -269 269
    -271 273
    -273 278
    -274 283
    -276 288
    -278 292
    -279 297
    -280 302
    -281 306
    -282 311
    -283 315
    -284 320
    -285 324
    -285 329
    -286 333
    -286 337
    -286 342
    -287 346
    -287 350
    -286 354
    -286 359
    -286 363
    -285 367
    -285 371
    -284 375
    -283 379
    -282 383
    -281 387
    -280 391
    -279 395
    -278 398
    -276 402
    -275 406
    -273 410
    -271 413
    -269 417
    -267 420
    -265 424
    -263 427
    -261 431
    -259 434
    -256 437
    -254 441
    -251 444
    -248 447
    -245 450
    -243 453
    -240 456
    -236 459
    -233 462
    -230 465
    -227 468
    -223 470
    -220 473
    -216 476
    -213 478
    -209 481
    -205 484
    -201 486
    -197 488
    -193 491
    -189 493
    -185 495
    -181 497
    -177 500
    -172 502
    -168 504
    -163 506
    -159 507
    -154 509
    -150 511
    -145 513
    -140 514
    -136 516
    -131 518
    -126 519
    -121 521
    -116 522
    -111 523
    -106 525
    -101 526
    -96 527
    -91 528
    -85 529
    -80 530
    -75 531
    -70 532
    -65 532
    -59 533
    -54 534
    -49 534
    -43 535
    -38 535
    -32 536
    -27 536
    -22 536
    -16 537
    -11 537
    -5 537
    0 537
    5 537
    11 537
    16 537
    22 536
    27 536
    32 536
    38 535
    43 535
    49 534
    54 534
    59 533
    65 532
    70 532
    75 531
    80 530
    85 529
    91 528
    96 527
    101 526
    106 525
    111 523
    116 522
    121 521
    126 519
    131 518
    136 516
    140 514
    145 513
    150 511
    154 509
    159 507
    163 506
    168 504
    172 502
    177 500
    181 497
    185 495
    189 493
    193 491
    197 488
    201 486
    205 484
    209 481
    213 478
    216 476
    220 473
    223 470
    227 468
    230 465
    233 462
    236 459
    240 456
    243 453
    245 450
    248 447
    251 444
    254 441
    256 437
    259 434
    261 431
    263 427
    265 424
    267 420
    269 417
    271 413
    273 410
    275 406
    276 402
    278 398
    279 395
    280 391
    281 387
    282 383
    283 379
    284 375
    285 371
    285 367
    286 363
    286 359
    286 354
    287 350
    287 346
    286 342
    286 337
    286 333
    285 329
    285 324
    284 320
    283 315
    282 311
    281 306
    280 302
    279 297
    278 292
    276 288
    274 283
    273 278
    271 273
    269 269
    267 264
    264 259
    262 254
    259 249
    257 244
    254 239
    251 234
    248 229
    245 224
    242 219
    238 214
    235 209
    231 204
    227 199
    223 194
    219 189
    215 184
    211 178
    206 173
    202 168
    197 163
    193 158
    188 152
    183 147
    177 142
    172 136
    167 131
    161 126
    155 120
    150 115
    144 109
    138 104
    132 99
    125 93
    119 88
    112 82
    106 77
    99 71
    92 66
    85 60
    78 55
    70 49
    63 44
    55 38
    48 33
    40 27
    32 22
    24 16
    16 11
    8 5
    -1 -1
    -9 -6
    -18 -12
    -27 -17
    -36 -23
    -45 -28
    -54 -34
    -63 -40
    -72 -45
    -82 -51
    -91 -57
    -101 -62
    -111 -68
    -121 -73
    -131 -79
    -141 -85
    -151 -90
    -162 -96
    -172 -101
    -183 -107
    -194 -113
    -204 -118
    -215 -124
    -226 -130
    -238 -135
    -249 -141
    -260 -146
    -272 -152
    -283 -158
    -295 -163
    -307 -169
    -319 -174
    -331 -180
    -343 -186
    -356 -191
    -368 -197
    -380 -202
    -393 -208
    -406 -214
    -419 -219
    -431 -225
    -444 -230
    -458 -236
    -471 -241
    -484 -247
    -498 -253
    -511 -258
    -525 -264
    -538 -269
    -552 -275
    -566 -280
    -580 -286
    -594 -291
    -609 -297
    -623 -302
    -637 -308
    -652 -313
    -666 -319
    -681 -324
    -696 -330
    -711 -335
    -726 -341
    -741 -346
    -756 -351
    -771 -357
    -787 -362
    -802 -368
    -818 -373
    -833 -378
    -849 -384
    -865 -389
    -881 -395
    -897 -400
    -913 -405
    -929 -411
    -945 -416
    -962 -421
    -978 -426
    -994 -432
    -1011 -437
    -1028 -442
    -1044 -448
    -1061 -453
    -1078 -458
    -1095 -463
    -1112 -469
    -1130 -474
    -1147 -479
    -1164 -484
    -1182 -489
    -1199 -495
    1204 -502
    1187 -497
    1169 -491
    1152 -486
    1135 -481
    1118 -476
    1101 -470
    1084 -465
    1067 -460
    1050 -454
    1033 -449
    1016 -444
    1000 -438
    983 -433
    967 -428
    951 -422
    934 -417
    918 -412
    902 -406
    886 -401
    870 -396
    854 -390
    839 -385
    823 -379
    808 -374
    792 -368
    777 -363
    761 -357
    746 -352
    731 -347
    716 -341
    701 -336
    687 -330
    672 -325
    657 -319
    643 -314
    628 -308
    614 -302
    600 -297
    586 -291
    572 -286
    558 -280
    544 -275
    530 -269
    517 -264
    503 -258
    490 -252
    476 -247
    463 -241
    450 -236
    437 -230
    424 -224
    411 -219
    399 -213
    386 -208
    374 -202
    361 -196
    349 -191
    337 -185
    325 -179
    313 -174
    301 -168
    289 -162
    277 -157
    266 -151
    255 -145
    243 -140
    232 -134
    221 -128
    210 -123
    199 -117
    188 -112
    178 -106
    167 -100
    157 -95
    147 -89
    136 -83
    126 -78
    116 -72
    107 -66
    97 -61
    87 -55
    78 -49
    69 -44
    59 -38
    50 -32
    41 -27
    32 -21
    24 -15
    15 -10
    6 -4
    -2 1
    -10 7
    -18 13
    -26 18
    -34 24
    -42 29
    -50 35
    -57 40
    -65 46
    -72 52
    -79 57
    -86 63
    -93 68
    -100 74
    -107 79
    -113 85
    -120 90
    -126 96
    -132 101
    -138 106
    -144 112
    -150 117
    -156 123
    -161 128
    -167 133
    -172 139
    -177 144
    -182 149
    -187 155
    -192 160
    -197 165
    -201 171
    -206 176
    -210 181
    -214 186
    -218 191
    -222 197
    -226 202
    -230 207
    -233 212
    -237 217
    -240 222
    -243 227
    -246 232
    -249 237
    -252 242
    -254 247
    -257 252
    -259 257
    -262 262
    -264 267
    -266 271
    -268 276
    -270 281
    -271 286
    -273 290
    -274 295
    -276 300
    -277 304
    -278 309
    -279 313
    -280 318
    -280 322
    -281 327
    -282 331
    -282 336
    -282 340
    -282 344
    -282 349
    -282 353
    -282 357
    -282 361
    -281 365
    -281 369
    -280 373
    -279 377
    -278 381
    -277 385
    -276 389
    -275 393
    -274 397
    -272 401
    -271 404
    -269 408
    -268 412
    -266 415
    -264 419
    -262 422
    -260 426
    -258 429
    -255 433
    -253 436
    -250 439
    -248 443
    -245 446
    -242 449
    -240 452
    -237 455
    -234 458
    -230 461
    -227 464
    -224 467
    -221 469
    -217 472
    -214 475
    -210 477
    -206 480
    -203 482
    -199 485
    -195 487
    -191 490
    -187 492
    -183 494
    -179 496
    -175 499
    -170 501
    -166 503
    -161 505
    -157 507
    -153 508
    -148 510
    -143 512
    -139 514
    -134 515
    -129 517
    -124 518
    -120 520
    -115 521
    -110 522
    -105 524
    -100 525
    -95 526
    -90 527
    -84 528
    -79 529
    -74 530
    -69 531
    -64 532
    -59 532
    -53 533
    -48 534
    -43 534
    -37 535
    -32 535
    -27 535
    -21 536
    -16 536
    -11 536
    -5 536
    0 536
    5 536
    11 536
    16 536
    21 536
    27 535
    32 535
    37 535
    43 534
    48 534
    53 533
    59 532
    64 532
    69 531
    74 530
    79 529
    84 528
    90 527
    95 526
    100 525
    105 524
    110 522
    115 521
    120 520
    124 518
    129 517
    134 515
    139 514
    143 512
    148 510
    153 508
    157 507
    161 505
    166 503
    170 501
    175 499
    179 496
    183 494
    187 492
    191 490
    195 487
    199 485
    203 482
    206 480
    210 477
    214 475
    217 472
    221 469
    224 467
    227 464
    230 461
    234 458
    237 455
    240 452
    242 449
    245 446
    248 443
    250 439
    253 436
    255 433
    258 429
    260 426
    262 422
    264 419
    266 415
    268 412
    269 408
    271 404
    272 401
    274 397
    275 393
    276 389
    277 385
    278 381
    279 377
    280 373
    281 369
    281 365
    282 361
    282 357
    282 353
    282 349
    282 344
    282 340
    282 336
    282 331
    281 327
    280 322
    280 318
    279 313
    278 309
    277 304
    276 300
    274 295
    273 290
    271 286
    270 281
    268 276
    266 271
    264 267
    262 262
    259 257
    257 252
    254 247
    252 242
    249 237
    246 232
    243 227
    240 222
    237 217
    233 212
    230 207
    226 202
    222 197
    218 191
    214 186
    210 181
    206 176
    201 171
    197 165
    192 160
    187 155
    182 149
    177 144
    172 139
    167 133
    161 128
    156 123
    150 117
    144 112
    138 106
    132 101
    126 96
    120 90
    113 85
    107 79
    100 74
    93 68
    86 63
    79 57
    72 52
    65 46
    57 40
    50 35
    42 29
    34 24
    26 18
    18 13
    10 7
    2 1
    -6 -4
    -15 -10
    -24 -15
    -32 -21
    -41 -27
    -50 -32
    -59 -38
    -69 -44
    -78 -49
    -87 -55
    -97 -61
    -107 -66
    -116 -72
    -126 -78
    -136 -83
    -147 -89
    -157 -95
    -167 -100
    -178 -106
    -188 -112
    -199 -117
    -210 -123
    -221 -128
    -232 -134
    -243 -140
    -255 -145
    -266 -151
    -277 -157
    -289 -162
    -301 -168
    -313 -174
    -325 -179
    -337 -185
    -349 -191
    -361 -196
    -374 -202
    -386 -208
    -399 -213
    -411 -219
    -424 -224
    -437 -230
    -450 -236
    -463 -241
    -476 -247
    -490 -252
    -503 -258
    -517 -264
    -530 -269
    -544 -275
    -558 -280
    -572 -286
    -586 -291
    -600 -297
    -614 -302
    -628 -308
    -643 -314
    -657 -319
    -672 -325
    -687 -330
    -701 -336
    -716 -341
    -731 -347
    -746 -352
    -761 -357
    -777 -363
    -792 -368
    -808 -374
    -823 -379
    -839 -385
    -854 -390
    -870 -396
    -886 -401
    -902 -406
    -918 -412
    -934 -417
    -951 -422
    -967 -428
    -983 -433
    -1000 -438
    -1016 -444
    -1033 -449
    -1050 -454
    -1067 -460
    -1084 -465
    -1101 -470
    -1118 -476
    -1135 -481
    -1152 -486
    -1169 -491
    -1187 -497
    -1204 -502
    1209 -509
    1192 -504
    1175 -498
    1157 -493
    1140 -488
    1123 -483
    1106 -477
    1089 -472
    1072 -467
    1055 -461
    1038 -456
    1022 -451
    1005 -445
    989 -440
    972 -434
    956 -429
    940 -424
    924 -418
    907 -413
    891 -407
    876 -402
    860 -397
    844 -391
    828 -386
    813 -380
    798 -375
    782 -369
    767 -364
    752 -358
    737 -353
    722 -347
    707 -342
    692 -336
    677 -331
    663 -325
    648 -319
    634 -314
    620 -308
    605 -303
    591 -297
    577 -292
    563 -286
    550 -280
    536 -275
    522 -269
    509 -263
    495 -258
    482 -252
    469 -247
    456 -241
    443 -235
    430 -230
    417 -224
    404 -218
    392 -213
    379 -207
    367 -201
    355 -196
    342 -190
    330 -184
    318 -179
    307 -173
    295 -167
    283 -162
    272 -156
    260 -150
    249 -144
    238 -139
    227 -133
    216 -127
    205 -122
    194 -116
    184 -110
    173 -105
    163 -99
    152 -93
    142 -88
    132 -82
    122 -76
    112 -70
    103 -65
    93 -59
    84 -53
    74 -48
    65 -42
    56 -36
    47 -31
    38 -25
    29 -19
    21 -14
    12 -8
    4 -2
    -5 3
    -13 9
    -21 14
    -29 20
    -37 26
    -44 31
    -52 37
    -59 42
    -67 48
    -74 54
    -81 59
    -88 65
    -95 70
    -101 76
    -108 81
    -114 87
    -121 92
    -127 98
    -133 103
    -139 109
    -145 114
    -150 120
    -156 125
    -161 130
    -167 136
    -172 141
    -177 147
    -182 152
    -187 157
    -191 162
    -196 168
    -200 173
    -205 178
    -209 184
    -213 189
    -217 194
    -221 199
    -224 204
    -228 209
    -231 214
    -235 220
    -238 225
    -241 230
    -244 235
    -247 240
    -249 245
    -252 250
    -255 255
    -257 259
    -259 264
    -261 269
    -263 274
    -265 279
    -267 283
    -268 288
    -270 293
    -271 298
    -272 302
    -273 307
    -274 311
    -275 316
    -276 320
    -277 325
    -277 329
    -278 334
    -278 338
    -278 342
    -278 347
    -278 351
    -278 355
    -278 359
    -277 364
    -277 368
    -276 372
    -275 376
    -274 380
    -274 384
    -272 388
    -271 392
    -270 395
    -269 399
    -267 403
    -266 407
    -264 410
    -262 414
    -260 417
    -258 421
    -256 424
    -254 428
    -252 431
    -250 435
    -247 438
    -245 441
    -242 444
    -239 447
    -236 451
    -234 454
    -231 457
    -228 460
    -224 462
    -221 465
    -218 468
    -214 471
    -211 474
    -207 476
    -204 479
    -200 481
    -196 484
    -193 486
    -189 489
    -185 491
    -181 493
    -177 495
    -172 497
    -168 500
    -164 502
    -160 504
    -155 505
    -151 507
    -146 509
    -142 511
    -137 513
    -132 514
    -128 516
    -123 517
    -118 519
    -113 520
    -108 521
    -104 523
    -99 524
    -94 525
    -89 526
    -84 527
    -78 528
    -73 529
    -68 530
    -63 531
    -58 531
    -53 532
    -47 533
    -42 533
    -37 534
    -32 534
    -26 534
    -21 535
    -16 535
    -11 535
    -5 535
    0 535
    5 535
    11 535
    16 535
    21 535
    26 534
    32 534
    37 534
    42 533
    47 533
    53 532
    58 531
    63 531
    68 530
    73 529
    78 528
    84 527
    89 526
    94 525
    99 524
    104 523
    108 521
    113 520
    118 519
    123 517
    128 516
    132 514
    137 513
    142 511
    146 509
    151 507
    155 505
    160 504
    164 502
    168 500
    172 497
    177 495
    181 493
    185 491
    189 489
    193 486
    196 484
    200 481
    204 479
    207 476
    211 474
    214 471
    218 468
    221 465
    224 462
    228 460
    231 457
    234 454
    236 451
    239 447
    242 444
    245 441
    247 438
    250 435
    252 431
    254 428
    256 424
    258 421
    260 417
    262 414
    264 410
    266 407
    267 403
    269 399
    270 395
    271 392
    272 388
    274 384
    274 380
    275 376
    276 372
    277 368
    277 364
    278 359
    278 355
    278 351
    278 347
    278 342
    278 338
    278 334
    277 329
    277 325
    276 320
    275 316
    274 311
    273 307
    272 302
    271 298
    270 293
    268 288
    267 283
    265 279
    263 274
    261 269
    259 264
    257 259
    255 255
    252 250
    249 245
    247 240
    244 235
    241 230
    238 225
    235 220
    231 214
    228 209
    224 204
    221 199
    217 194
    213 189
    209 184
    205 178
    200 173
    196 168
    191 162
    187 157
    182 152
    177 147
    172 141
    167 136
    161 130
    156 125
    150 120
    145 114
    139 109
    133 103
    127 98
    121 92
    114 87
    108 81
    101 76
    95 70
    88 65
    81 59
    74 54
    67 48
    59 42
    52 37
    44 31
    37 26
    29 20
    21 14
    13 9
    5 3
    -4 -2
    -12 -8
    -21 -14
    -29 -19
    -38 -25
    -47 -31
    -56 -36
    -65 -42
    -74 -48
    -84 -53
    -93 -59
    -103 -65
    -112 -70
    -122 -76
    -132 -82
    -142 -88
    -152 -93
    -163 -99
    -173 -105
    -184 -110
    -194 -116
    -205 -122
    -216 -127
    -227 -133
    -238 -139
    -249 -144
    -260 -150
    -272 -156
    -283 -162
    -295 -167
    -307 -173
    -318 -179
    -330 -184
    -342 -190
    -355 -196
    -367 -201
    -379 -207
    -392 -213
    -404 -218
    -417 -224
    -430 -230
    -443 -235
    -456 -241
    -469 -247
    -482 -252
    -495 -258
    -509 -263
    -522 -269
    -536 -275
    -550 -280
    -563 -286
    -577 -292
    -591 -297
    -605 -303
    -620 -308
    -634 -314
    -648 -319
    -663 -325
    -677 -331
    -692 -336
    -707 -342
    -722 -347
    -737 -353
    -752 -358
    -767 -364
    -782 -369
    -798 -375
    -813 -380
    -828 -386
    -844 -391
    -860 -397
    -876 -402
    -891 -407
    -907 -413
    -924 -418
    -940 -424
    -956 -429
    -972 -434
    -989 -440
    -1005 -445
    -1022 -451
    -1038 -456
    -1055 -461
    -1072 -467
    -1089 -472
    -1106 -477
    -1123 -483
    -1140 -488
    -1157 -493
    -1175 -498
    -1192 -504
    -1209 -509
    1215 -516
    1197 -511
    1180 -506
    1163 -500
    1145 -495
    1128 -490
    1111 -484
    1094 -479
    1077 -474
    1060 -468
    1044 -463
    1027 -457
    1010 -452
    994 -447
    978 -441
    961 -436
    945 -430
    929 -425
    913 -419
    897 -414
    881 -408
    865 -403
    850 -398
    834 -392
    818 -386
    803 -381
    788 -375
    772 -370
    757 -364
    742 -359
    727 -353
    712 -348
    698 -342
    683 -337
    668 -331
    654 -325
    640 -320
    625 -314
    611 -309
    597 -303
    583 -297
    569 -292
    555 -286
    541 -280
    528 -275
    514 -269
    501 -263
    488 -258
    474 -252
    461 -246
    448 -241
    435 -235
    423 -229
    410 -224
    397 -218
    385 -212
    372 -206
    360 -201
    348 -195
    336 -189
    324 -184
    312 -178
    300 -172
    289 -166
    277 -161
    266 -155
    255 -149
    243 -144
    232 -138
    221 -132
    211 -126
    200 -121
    189 -115
    179 -109
    168 -103
    158 -98
    148 -92
    138 -86
    128 -81
    118 -75
    108 -69
    99 -63
    89 -58
    80 -52
    71 -46
    62 -40
    53 -35
    44 -29
    35 -23
    26 -18
    18 -12
    9 -6
    1 -1
    -7 5
    -15 11
    -23 16
    -31 22
    -39 28
    -46 33
    -54 39
    -61 44
    -68 50
    -75 56
    -82 61
    -89 67
    -96 72
    -102 78
    -109 83
    -115 89
    -121 94
    -127 100
    -133 105
    -139 111
    -145 116
    -151 122
    -156 127
    -161 133
    -167 138
    -172 143
    -177 149
    -181 154
    -186 160
    -191 165
    -195 170
    -199 175
    -204 181
    -208 186
    -212 191
    -216 196
    -219 202
    -223 207
    -226 212
    -230 217
    -233 222
    -236 227
    -239 232
    -242 237
    -245 242
    -247 247
    -250 252
    -252 257
    -254 262
    -256 267
    -258 272
    -260 276
    -262 281
    -263 286
    -265 291
    -266 295
    -268 300
    -269 305
    -270 309
    -271 314
    -271 318
    -272 323
    -273 327
    -273 332
    -273 336
    -274 340
    -274 345
    -274 349
    -274 353
    -273 357
    -273 362
    -273 366
    -272 370
    -271 374
    -270 378
    -270 382
    -269 386
    -267 390
    -266 394
    -265 397
    -264 401
    -262 405
    -260 409
    -259 412
    -257 416
    -255 419
    -253 423
    -251 426
    -249 430
    -246 433
    -244 436
    -241 440
    -239 443
    -236 446
    -233 449
    -231 452
    -228 455
    -225 458
    -221 461
    -218 464
    -215 467
    -212 469
    -208 472
    -205 475
    -201 477
    -198 480
    -194 482
    -190 485
    -186 487
    -182 490
    -178 492
    -174 494
    -170 496
    -166 498
    -162 500
    -158 502
    -153 504
    -149 506
    -144 508
    -140 510
    -135 511
    -131 513
    -126 515
    -121 516
    -117 518
    -112 519
    -107 520
    -102 522
    -97 523
    -92 524
    -87 525
    -83 526
    -77 527
    -72 528
    -67 529
    -62 530
    -57 530
    -52 531
    -47 531
    -42 532
    -37 532
    -31 533
    -26 533
    -21 534
    -16 534
    -10 534
    -5 534
    0 534
    5 534
    10 534
    16 534
    21 534
    26 533
    31 533
    37 532
    42 532
    47 531
    52 531
    57 530
    62 530
    67 529
    72 528
    77 527
    83 526
    87 525
    92 524
    97 523
    102 522
    107 520
    112 519
    117 518
    121 516
    126 515
    131 513
    135 511
    140 510
    144 508
    149 506
    153 504
    158 502
    162 500
    166 498
    170 496
    174 494
    178 492
    182 490
    186 487
    190 485
    194 482
    198 480
    201 477
    205 475
    208 472
    212 469
    215 467
    218 464
    221 461
    225 458
    228 455
    231 452
    233 449
    236 446
    239 443
    241 440
    244 436
    246 433
    249 430
    251 426
    253 423
    255 419
    257 416
    259 412
    260 409
    262 405
    264 401
    265 397
    266 394
    267 390
    269 386
    270 382
    270 378
    271 374
    272 370
    273 366
    273 362
    273 357
    274 353
    274 349
    274 345
    274 340
    273 336
    273 332
    273 327
    272 323
    271 318
    271 314
    270 309
    269 305
    268 300
    266 295
    265 291
    263 286
    262 281
    260 276
    258 272
    256 267
    254 262
    252 257
    250 252
    247 247
    245 242
    242 237
    239 232
    236 227
    233 222
    230 217
    226 212
    223 207
    219 202
    216 196
    212 191
    208 186
    204 181
    199 175
    195 170
    191 165
    186 160
    181 154
    177 149
    172 143
    167 138
    161 133
    156 127
    151 122
    145 116
    139 111
    133 105
    127 100
    121 94
    115 89
    109 83
    102 78
    96 72
    89 67
    82 61
    75 56
    68 50
    61 44
    54 39
    46 33
    39 28
    31 22
    23 16
    15 11
    7 5
    -1 -1
    -9 -6
    -18 -12
    -26 -18
    -35 -23
    -44 -29
    -53 -35
    -62 -40
    -71 -46
    -80 -52
    -89 -58
    -99 -63
    -108 -69
    -118 -75
    -128 -81
    -138 -86
    -148 -92
    -158 -98
    -168 -103
    -179 -109
    -189 -115
    -200 -121
    -211 -126
    -221 -132
    -232 -138
    -243 -144
    -255 -149
    -266 -155
    -277 -161
    -289 -166
    -300 -172
    -312 -178
    -324 -184
    -336 -189
    -348 -195
    -360 -201
    -372 -206
    -385 -212
    -397 -218
    -410 -224
    -423 -229
    -435 -235
    -448 -241
    -461 -246
    -474 -252
    -488 -258
    -501 -263
    -514 -269
    -528 -275
    -541 -280
    -555 -286
    -569 -292
    -583 -297
    -597 -303
    -611 -309
    -625 -314
    -640 -320
    -654 -325
    -668 -331
    -683 -337
    -698 -342
    -712 -348
    -727 -353
    -742 -359
    -757 -364
    -772 -370
    -788 -375
    -803 -381
    -818 -386
    -834 -392
    -850 -398
    -865 -403
    -881 -408
    -897 -414
    -913 -419
    -929 -425
    -945 -430
    -961 -436
    -978 -441
    -994 -447
    -1010 -452
    -1027 -457
    -1044 -463
    -1060 -468
    -1077 -474
    -1094 -479
    -1111 -484
    -1128 -490
    -1145 -495
    -1163 -500
    -1180 -506
    -1197 -511
    -1215 -516
    1220 -524
    1203 -518
    1185 -513
    1168 -508
    1151 -502
    1134 -497
    1116 -491
    1100 -486
    1083 -481
    1066 -475
    1049 -470
    1032 -464
    1016 -459
    999 -453
    983 -448
    967 -443
    951 -437
    934 -432
    918 -426
    902 -421
    887 -415
    871 -410
    855 -404
    840 -398
    824 -393
    809 -387
    793 -382
    778 -376
    763 -371
    748 -365
    733 -359
    718 -354
    703 -348
    689 -343
    674 -337
    660 -331
    645 -326
    631 -320
    617 -314
    603 -309
    589 -303
    575 -297
    561 -292
    547 -286
    534 -280
    520 -275
    507 -269
    493 -263
    480 -258
    467 -252
    454 -246
    441 -240
    428 -235
    416 -229
    403 -223
    391 -217
    378 -212
    366 -206
    354 -200
    342 -194
    330 -189
    318 -183
    306 -177
    295 -171
    283 -166
    272 -160
    260 -154
    249 -148
    238 -143
    227 -137
    216 -131
    206 -125
    195 -120
    184 -114
    174 -108
    164 -102
    154 -96
    144 -91
    134 -85
    124 -79
    114 -73
    104 -68
    95 -62
    86 -56
    76 -50
    67 -45
    58 -39
    49 -33
    41 -27
    32 -22
    23 -16
    15 -10
    7 -5
    -2 1
    -10 7
    -18 12
    -25 18
    -33 24
    -41 29
    -48 35
    -55 41
    -63 46
    -70 52
    -77 58
    -83 63
    -90 69
    -97 74
    -103 80
    -110 86
    -116 91
    -122 97
    -128 102
    -134 108
    -139 113
    -145 119
    -151 124
    -156 129
    -161 135
    -166 140
    -171 146
    -176 151
    -181 156
    -185 162
    -190 167
    -194 172
    -198 178
    -203 183
    -207 188
    -210 193
    -214 199
    -218 204
    -221 209
    -225 214
    -228 219
    -231 224
    -234 229
    -237 235
    -240 240
    -242 245
    -245 249
    -247 254
    -249 259
    -251 264
    -253 269
    -255 274
    -257 279
    -259 283
    -260 288
    -262 293
    -263 298
    -264 302
    -265 307
    -266 311
    -267 316
    -268 321
    -268 325
    -269 329
    -269 334
    -269 338
    -269 343
    -269 347
    -269 351
    -269 355
    -269 360
    -268 364
    -268 368
    -267 372
    -266 376
    -266 380
    -265 384
    -264 388
    -262 392
    -261 396
    -260 399
    -258 403
    -257 407
    -255 410
    -253 414
    -251 418
    -249 421
    -247 425
    -245 428
    -243 431
    -241 435
    -238 438
    -236 441
    -233 444
    -230 448
    -227 451
    -225 454
    -222 457
    -219 460
    -215 462
    -212 465
    -209 468
    -206 471
    -202 473
    -199 476
    -195 479
    -191 481
    -188 483
    -184 486
    -180 488
    -176 490
    -172 493
    -168 495
    -164 497
    -160 499
    -156 501
    -151 503
    -147 505
    -143 507
    -138 508
    -134 510
    -129 512
    -125 513
    -120 515
    -115 516
    -111 518
    -106 519
    -101 520
    -96 521
    -91 523
    -86 524
    -82 525
    -77 526
    -72 527
    -67 527
    -62 528
    -56 529
    -51 530
    -46 530
    -41 531
    -36 531
    -31 532
    -26 532
    -21 532
    -16 532
    -10 533
    -5 533
    0 533
    5 533
    10 533
    16 532
    21 532
    26 532
    31 532
    36 531
    41 531
    46 530
    51 530
    56 529
    62 528
    67 527
    72 527
    77 526
    82 525
    86 524
    91 523
    96 521
    101 520
    106 519
    111 518
    115 516
    120 515
    125 513
    129 512
    134 510
    138 508
    143 507
    147 505
    151 503
    156 501
    160 499
    164 497
    168 495
    172 493
    176 490
    180 488
    184 486
    188 483
    191 481
    195 479
    199 476
    202 473
    206 471
    209 468
    212 465
    215 462
    219 460
    222 457
    225 454
    227 451
    230 448
    233 444
    236 441
    238 438
    241 435
    243 431
    245 428
    247 425
    249 421
    251 418
    253 414
    255 410
    257 407
    258 403
    260 399
    261 396
    262 392
    264 388
    265 384
    266 380
    266 376
    267 372
    268 368
    268 364
    269 360
    269 355
    269 351
    269 347
    269 343
    269 338
    269 334
    269 329
    268 325
    268 321
    267 316
    266 311
    265 307
    264 302
    263 298
    262 293
    260 288
    259 283
    257 279
    255 274
    253 269
    251 264
    249 259
    247 254
    245 249
    242 245
    240 240
    237 235
    234 229
    231 224
    228 219
    225 214
    221 209
    218 204
    214 199
    210 193
    207 188
    203 183
    198 178
    194 172
    190 167
    185 162
    181 156
    176 151
    171 146
    166 140
    161 135
    156 129
    151 124
    145 119
    139 113
    134 108
    128 102
    122 97
    116 91
    110 86
    103 80
    97 74
    90 69
    83 63
    77 58
    70 52
    63 46
    55 41
    48 35
    41 29
    33 24
    25 18
    18 12
    10 7
    2 1
    -7 -5
    -15 -10
    -23 -16
    -32 -22
    -41 -27
    -49 -33
    -58 -39
    -67 -45
    -76 -50
    -86 -56
    -95 -62
    -104 -68
    -114 -73
    -124 -79
    -134 -85
    -144 -91
    -154 -96
    -164 -102
    -174 -108
    -184 -114
    -195 -120
    -206 -125
    -216 -131
    -227 -137
    -238 -143
    -249 -148
    -260 -154
    -272 -160
    -283 -166
    -295 -171
    -306 -177
    -318 -183
    -330 -189
    -342 -194
    -354 -200
    -366 -206
    -378 -212
    -391 -217
    -403 -223
    -416 -229
    -428 -235
    -441 -240
    -454 -246
    -467 -252
    -480 -258
    -493 -263
    -507 -269
    -520 -275
    -534 -280
    -547 -286
    -561 -292
    -575 -297
    -589 -303
    -603 -309
    -617 -314
    -631 -320
    -645 -326
    -660 -331
    -674 -337
    -689 -343
    -703 -348
    -718 -354
    -733 -359
    -748 -365
    -763 -371
    -778 -376
    -793 -382
    -809 -387
    -824 -393
    -840 -398
    -855 -404
    -871 -410
    -887 -415
    -902 -421
    -918 -426
    -934 -432
    -951 -437
    -967 -443
    -983 -448
    -999 -453
    -1016 -459
    -1032 -464
    -1049 -470
    -1066 -475
    -1083 -481
    -1100 -486
    -1116 -491
    -1134 -497
    -1151 -502
    -1168 -508
    -1185 -513
    -1203 -518
    -1220 -524
    1225 -531
    1208 -526
    1191 -520
    1173 -515
    1156 -509
    1139 -504
    1122 -499
    1105 -493
    1088 -488
    1071 -482
    1055 -477
    1038 -471
    1021 -466
    1005 -460
    989 -455
    972 -449
    956 -444
    940 -438
    924 -433
    908 -427
    892 -422
    876 -416
    861 -411
    845 -405
    830 -399
    814 -394
    799 -388
    784 -383
    768 -377
    753 -371
    739 -366
    724 -360
    709 -354
    694 -349
    680 -343
    665 -337
    651 -332
    637 -326
    622 -320
    608 -315
    594 -309
    580 -303
    567 -298
    553 -292
    539 -286
    526 -280
    512 -275
    499 -269
    486 -263
    473 -257
    460 -252
    447 -246
    434 -240
    421 -234
    409 -229
    396 -223
    384 -217
    372 -211
    360 -205
    348 -200
    336 -194
    324 -188
    312 -182
    300 -177
    289 -171
    277 -165
    266 -159
    255 -153
    244 -147
    233 -142
    222 -136
    211 -130
    201 -124
    190 -118
    180 -113
    170 -107
    159 -101
    149 -95
    139 -89
    130 -84
    120 -78
    110 -72
    101 -66
    91 -61
    82 -55
    73 -49
    64 -43
    55 -37
    46 -32
    38 -26
    29 -20
    21 -14
    12 -9
    4 -3
    -4 3
    -12 8
    -20 14
    -27 20
    -35 26
    -42 31
    -50 37
    -57 43
    -64 48
    -71 54
    -78 60
    -85 65
    -91 71
    -98 76
    -104 82
    -110 88
    -116 93
    -122 99
    -128 104
    -134 110
    -140 115
    -145 121
    -150 126
    -156 132
    -161 137
    -166 142
    -171 148
    -175 153
    -180 159
    -185 164
    -189 169
    -193 175
    -197 180
    -201 185
    -205 191
    -209 196
    -213 201
    -216 206
    -219 211
    -223 216
    -226 222
    -229 227
    -232 232
    -235 237
    -237 242
    -240 247
    -242 252
    -244 257
    -247 262
    -249 266
    -250 271
    -252 276
    -254 281
    -256 286
    -257 290
    -258 295
    -259 300
    -261 304
    -262 309
    -262 314
    -263 318
    -264 323
    -264 327
    -265 332
    -265 336
    -265 340
    -265 345
    -265 349
    -265 353
    -265 357
    -264 362
    -264 366
    -263 370
    -262 374
    -262 378
    -261 382
    -260 386
    -259 390
    -257 394
    -256 397
    -255 401
    -253 405
    -251 409
    -250 412
    -248 416
    -246 419
    -244 423
    -242 426
    -240 430
    -237 433
    -235 436
    -232 439
    -230 443
    -227 446
    -224 449
    -222 452
    -219 455
    -216 458
    -213 461
    -209 464
    -206 466
    -203 469
    -200 472
    -196 474
    -193 477
    -189 479
    -185 482
    -182 484
    -178 487
    -174 489
    -170 491
    -166 493
    -162 495
    -158 497
    -154 499
    -149 501
    -145 503
    -141 505
    -136 507
    -132 509
    -128 510
    -123 512
    -118 513
    -114 515
    -109 516
    -105 518
    -100 519
    -95 520
    -90 521
    -85 522
    -81 523
    -76 524
    -71 525
    -66 526
    -61 527
    -56 528
    -51 528
    -46 529
    -41 529
    -36 530
    -31 530
    -26 531
    -20 531
    -15 531
    -10 531
    -5 531
    0 531
    5 531
    10 531
    15 531
    20 531
    26 531
    31 530
    36 530
    41 529
    46 529
    51 528
    56 528
    61 527
    66 526
    71 525
    76 524
    81 523
    85 522
    90 521
    95 520
    100 519
    105 518
    109 516
    114 515
    118 513
    123 512
    128 510
    132 509
    136 507
    141 505
    145 503
    149 501
    154 499
    158 497
    162 495
    166 493
    170 491
    174 489
    178 487
    182 484
    185 482
    189 479
    193 477
    196 474
    200 472
    203 469
    206 466
    209 464
    213 461
    216 458
    219 455
    222 452
    224 449
    227 446
    230 443
    232 439
    235 436
    237 433
    240 430
    242 426
    244 423
    246 419
    248 416
    250 412
    251 409
    253 405
    255 401
    256 397
    257 394
    259 390
    260 386
    261 382
    262 378
    262 374
    263 370
    264 366
    264 362
    265 357
    265 353
    265 349
    265 345
    265 340
    265 336
    265 332
    264 327
    264 323
    263 318
    262 314
    262 309
    261 304
    259 300
    258 295
    257 290
    256 286
    254 281
    252 276
    250 271
    249 266
    247 262
    244 257
    242 252
    240 247
    237 242
    235 237
    232 232
    229 227
    226 222
    223 216
    219 211
    216 206
    213 201
    209 196
    205 191
    201 185
    197 180
    193 175
    189 169
    185 164
    180 159
    175 153
    171 148
    166 142
    161 137
    156 132
    150 126
    145 121
    140 115
    134 110
    128 104
    122 99
    116 93
    110 88
    104 82
    98 76
    91 71
    85 65
    78 60
    71 54
    64 48
    57 43
    50 37
    42 31
    35 26
    27 20
    20 14
    12 8
    4 3
    -4 -3
    -12 -9
    -21 -14
    -29 -20
    -38 -26
    -46 -32
    -55 -37
    -64 -43
    -73 -49
    -82 -55
    -91 -61
    -101 -66
    -110 -72
    -120 -78
    -130 -84
    -139 -89
    -149 -95
    -159 -101
    -170 -107
    -180 -113
    -190 -118
    -201 -124
    -211 -130
    -222 -136
    -233 -142
    -244 -147
    -255 -153
    -266 -159
    -277 -165
    -289 -171
    -300 -177
    -312 -182
    -324 -188
    -336 -194
    -348 -200
    -360 -205
    -372 -211
    -384 -217
    -396 -223
    -409 -229
    -421 -234
    -434 -240
    -447 -246
    -460 -252
    -473 -257
    -486 -263
    -499 -269
    -512 -275
    -526 -280
    -539 -286
    -553 -292
    -567 -298
    -580 -303
    -594 -309
    -608 -315
    -622 -320
    -637 -326
    -651 -332
    -665 -337
    -680 -343
    -694 -349
    -709 -354
    -724 -360
    -739 -366
    -753 -371
    -768 -377
    -784 -383
    -799 -388
    -814 -394
    -830 -399
    -845 -405
    -861 -411
    -876 -416
    -892 -422
    -908 -427
    -924 -433
    -940 -438
    -956 -444
    -972 -449
    -989 -455
    -1005 -460
    -1021 -466
    -1038 -471
    -1055 -477
    -1071 -482
    -1088 -488
    -1105 -493
    -1122 -499
    -1139 -504
    -1156 -509
    -1173 -515
    -1191 -520
    -1208 -526
    -1225 -531
    1231 -538
    1213 -533
    1196 -528
    1179 -522
    1162 -517
    1144 -511
    1127 -506
    1110 -500
    1094 -495
    1077 -489
    1060 -484
    1043 -478
    1027 -473
    1010 -467
    994 -462
    978 -456
    962 -451
    945 -445
    929 -440
    914 -434
    898 -428
    882 -423
    866 -417
    851 -412
    835 -406
    820 -400
    804 -395
    789 -389
    774 -383
    759 -378
    744 -372
    729 -366
    715 -361
    700 -355
    685 -349
    671 -344
    656 -338
    642 -332
    628 -326
    614 -321
    600 -315
    586 -309
    572 -303
    559 -298
    545 -292
    531 -286
    518 -280
    505 -275
    492 -269
    479 -263
    466 -257
    453 -251
    440 -246
    427 -240
    415 -234
    402 -228
    390 -222
    378 -217
    365 -211
    353 -205
    341 -199
    330 -193
    318 -187
    306 -182
    295 -176
    283 -170
    272 -164
    261 -158
    250 -152
    239 -147
    228 -141
    217 -135
    207 -129
    196 -123
    186 -117
    175 -112
    165 -106
    155 -100
    145 -94
    135 -88
    126 -82
    116 -77
    107 -71
    97 -65
    88 -59
    79 -53
    70 -48
    61 -42
    52 -36
    43 -30
    35 -24
    26 -19
    18 -13
    10 -7
    2 -1
    -6 4
    -14 10
    -22 16
    -29 22
    -37 27
    -44 33
    -51 39
    -58 44
    -65 50
    -72 56
    -79 61
    -86 67
    -92 73
    -98 78
    -105 84
    -111 89
    -117 95
    -123 101
    -128 106
    -134 112
    -140 117
    -145 123
    -150 128
    -155 134
    -160 139
    -165 145
    -170 150
    -175 155
    -179 161
    -184 166
    -188 171
    -192 177
    -196 182
    -200 187
    -204 193
    -207 198
    -211 203
    -214 208
    -218 213
    -221 219
    -224 224
    -227 229
    -229 234
    -232 239
    -235 244
    -237 249
    -239 254
    -242 259
    -244 264
    -246 269
    -247 274
    -249 278
    -251 283
    -252 288
    -254 293
    -255 297
    -256 302
    -257 307
    -258 311
    -259 316
    -259 320
    -260 325
    -260 329
    -261 334
    -261 338
    -261 342
    -261 347
    -261 351
    -260 355
    -260 359
    -260 364
    -259 368
    -258 372
    -258 376
    -257 380
    -256 384
    -255 388
    -254 391
    -252 395
    -251 399
    -249 403
    -248 406
    -246 410
    -244 414
    -242 417
    -240 421
    -238 424
    -236 428
    -234 431
    -232 434
    -229 437
    -227 441
    -224 444
    -221 447
    -219 450
    -216 453
    -213 456
    -210 459
    -207 462
    -203 464
    -200 467
    -197 470
    -194 473
    -190 475
    -187 478
    -183 480
    -179 483
    -175 485
    -172 487
    -168 489
    -164 492
    -160 494
    -156 496
    -152 498
    -148 500
    -143 502
    -139 503
    -135 505
    -130 507
    -126 509
    -121 510
    -117 512
    -112 513
    -108 515
    -103 516
    -99 517
    -94 518
    -89 520
    -84 521
    -80 522
    -75 523
    -70 524
    -65 524
    -60 525
    -55 526
    -50 527
    -45 527
    -40 528
    -35 528
    -30 529
    -25 529
    -20 529
    -15 530
    -10 530
    -5 530
    0 530
    5 530
    10 530
    15 530
    20 529
    25 529
    30 529
    35 528
    40 528
    45 527
    50 527
    55 526
    60 525
    65 524
    70 524
    75 523
    80 522
    84 521
    89 520
    94 518
    99 517
    103 516
    108 515
    112 513
    117 512
    121 510
    126 509
    130 507
    135 505
    139 503
    143 502
    148 500
    152 498
    156 496
    160 494
    164 492
    168 489
    172 487
    175 485
    179 483
    183 480
    187 478
    190 475
    194 473
    197 470
    200 467
    203 464
    207 462
    210 459
    213 456
    216 453
    219 450
    221 447
    224 444
    227 441
    229 437
    232 434
    234 431
    236 428
    238 424
    240 421
    242 417
    244 414
    246 410
    248 406
    249 403
    251 399
    252 395
    254 391
    255 388
    256 384
    257 380
    258 376
    258 372
    259 368
    260 364
    260 359
    260 355
    261 351
    261 347
    261 342
    261 338
    261 334
    260 329
    260 325
    259 320
    259 316
    258 311
    257 307
    256 302
    255 297
    254 293
    252 288
    251 283
    249 278
    247 274
    246 269
    244 264
    242 259
    239 254
    237 249
    235 244
    232 239
    229 234
    227 229
    224 224
    221 219
    218 213
    214 208
    211 203
    207 198
    204 193
    200 187
    196 182
    192 177
    188 171
    184 166
    179 161
    175 155
    170 150
    165 145
    160 139
    155 134
    150 128
    145 123
    140 117
    134 112
    128 106
    123 101
    117 95
    111 89
    105 84
    98 78
    92 73
    86 67
    79 61
    72 56
    65 50
    58 44
    51 39
    44 33
    37 27
    29 22
    22 16
    14 10
    6 4
    -2 -1
    -10 -7
    -18 -13
    -26 -19
    -35 -24
    -43 -30
    -52 -36
    -61 -42
    -70 -48
    -79 -53
    -88 -59
    -97 -65
    -107 -71
    -116 -77
    -126 -82
    -135 -88
    -145 -94
    -155 -100
    -165 -106
    -175 -112
    -186 -117
    -196 -123
    -207 -129
    -217 -135
    -228 -141
    -239 -147
    -250 -152
    -261 -158
    -272 -164
    -283 -170
    -295 -176
    -306 -182
    -318 -187
    -330 -193
    -341 -199
    -353 -205
    -365 -211
    -378 -217
    -390 -222
    -402 -228
    -415 -234
    -427 -240
    -440 -246
    -453 -251
    -466 -257
    -479 -263
    -492 -269
    -505 -275
    -518 -280
    -531 -286
    -545 -292
    -559 -298
    -572 -303
    -586 -309
    -600 -315
    -614 -321
    -628 -326
    -642 -332
    -656 -338
    -671 -344
    -685 -349
    -700 -355
    -715 -361
    -729 -366
    -744 -372
    -759 -378
    -774 -383
    -789 -389
    -804 -395
    -820 -400
    -835 -406
    -851 -412
    -866 -417
    -882 -423
    -898 -428
    -914 -434
    -929 -440
    -945 -445
    -962 -451
    -978 -456
    -994 -462
    -1010 -467
    -1027 -473
    -1043 -478
    -1060 -484
    -1077 -489
    -1094 -495
    -1110 -500
    -1127 -506
    -1144 -511
    -1162 -517
    -1179 -522
    -1196 -528
    -1213 -533
    -1231 -538
    1236 -546
    1219 -541
    1201 -535
    1184 -530
    1167 -524
    1150 -519
    1133 -513
    1116 -508
    1099 -502
    1082 -497
    1066 -491
    1049 -486
    1032 -480
    1016 -474
    1000 -469
    983 -463
    967 -458
    951 -452
    935 -446
    919 -441
    903 -435
    888 -430
    872 -424
    856 -418
    841 -413
    825 -407
    810 -401
    795 -396
    780 -390
    765 -384
    750 -378
    735 -373
    720 -367
    706 -361
    691 -356
    677 -350
    662 -344
    648 -338
    634 -333
    620 -327
    606 -321
    592 -315
    578 -309
    564 -304
    551 -298
    537 -292
    524 -286
    511 -280
    497 -275
    484 -269
    471 -263
    458 -257
    446 -251
    433 -245
    420 -240
    408 -234
    396 -228
    383 -222
    371 -216
    359 -210
    347 -204
    335 -199
    324 -193
    312 -187
    301 -181
    289 -175
    278 -169
    267 -163
    256 -158
    245 -152
    234 -146
    223 -140
    212 -134
    202 -128
    192 -122
    181 -116
    171 -111
    161 -105
    151 -99
    141 -93
    131 -87
    122 -81
    112 -75
    103 -70
    94 -64
    85 -58
    76 -52
    67 -46
    58 -40
    49 -35
    41 -29
    32 -23
    24 -17
    16 -11
    8 -6
    -0 0
    -8 6
    -16 12
    -23 18
    -31 23
    -38 29
    -46 35
    -53 40
    -60 46
    -67 52
    -73 58
    -80 63
    -86 69
    -93 75
    -99 80
    -105 86
    -111 91
    -117 97
    -123 103
    -129 108
    -134 114
    -139 119
    -145 125
    -150 130
    -155 136
    -160 141
    -165 147
    -169 152
    -174 157
    -178 163
    -182 168
    -187 174
    -191 179
    -195 184
    -198 189
    -202 195
    -206 200
    -209 205
    -212 210
    -216 216
    -219 221
    -222 226
    -224 231
    -227 236
    -230 241
    -232 246
    -234 251
    -237 256
    -239 261
    -241 266
    -243 271
    -244 276
    -246 280
    -247 285
    -249 290
    -250 295
    -251 299
    -252 304
    -253 309
    -254 313
    -255 318
    -255 322
    -256 327
    -256 331
    -256 336
    -257 340
    -257 344
    -256 348
    -256 353
    -256 357
    -256 361
    -255 365
    -254 369
    -254 373
    -253 377
    -252 381
    -251 385
    -250 389
    -248 393
    -247 397
    -246 401
    -244 404
    -242 408
    -241 411
    -239 415
    -237 419
    -235 422
    -233 425
    -231 429
    -228 432
    -226 435
    -223 439
    -221 442
    -218 445
    -216 448
    -213 451
    -210 454
    -207 457
    -204 460
    -201 463
    -198 465
    -194 468
    -191 471
    -187 473
    -184 476
    -180 478
    -177 481
    -173 483
    -169 485
    -166 488
    -162 490
    -158 492
    -154 494
    -150 496
    -146 498
    -141 500
    -137 502
    -133 503
    -129 505
    -124 507
    -120 508
    -115 510
    -111 511
    -106 513
    -102 514
    -97 515
    -93 517
    -88 518
    -83 519
    -78 520
    -74 521
    -69 522
    -64 523
    -59 524
    -54 524
    -50 525
    -45 526
    -40 526
    -35 527
    -30 527
    -25 527
    -20 528
    -15 528
    -10 528
    -5 528
    0 528
    5 528
    10 528
    15 528
    20 528
    25 527
    30 527
    35 527
    40 526
    45 526
    50 525
    54 524
    59 524
    64 523
    69 522
    74 521
    78 520
    83 519
    88 518
    93 517
    97 515
    102 514
    106 513
    111 511
    115 510
    120 508
    124 507
    129 505
    133 503
    137 502
    141 500
    146 498
    150 496
    154 494
    158 492
    162 490
    166 488
    169 485
    173 483
    177 481
    180 478
    184 476
    187 473
    191 471
    194 468
    198 465
    201 463
    204 460
    207 457
    210 454
    213 451
    216 448
    218 445
    221 442
    223 439
    226 435
    228 432
    231 429
    233 425
    235 422
    237 419
    239 415
    241 411
    242 408
    244 404
    246 401
    247 397
    248 393
    250 389
    251 385
    252 381
    253 377
    254 373
    254 369
    255 365
    256 361
    256 357
    256 353
    256 348
    257 344
    257 340
    256 336
    256 331
    256 327
    255 322
    255 318
    254 313
    253 309
    252 304
    251 299
    250 295
    249 290
    247 285
    246 280
    244 276
    243 271
    241 266
    239 261
    237 256
    234 251
    232 246
    230 241
    227 236
    224 231
    222 226
    219 221
    216 216
    212 210
    209 205
    206 200
    202 195
    198 189
    195 184
    191 179
    187 174
    182 168
    178 163
    174 157
    169 152
    165 147
    160 141
    155 136
    150 130
    145 125
    139 119
    134 114
    129 108
    123 103
    117 97
    111 91
    105 86
    99 80
    93 75
    86 69
    80 63
    73 58
    67 52
    60 46
    53 40
    46 35
    38 29
    31 23
    23 18
    16 12
    8 6
    0 0
    -8 -6
    -16 -11
    -24 -17
    -32 -23
    -41 -29
    -49 -35
    -58 -40
    -67 -46
    -76 -52
    -85 -58
    -94 -64
    -103 -70
    -112 -75
    -122 -81
    -131 -87
    -141 -93
    -151 -99
    -161 -105
    -171 -111
    -181 -116
    -192 -122
    -202 -128
    -212 -134
    -223 -140
    -234 -146
    -245 -152
    -256 -158
    -267 -163
    -278 -169
    -289 -175
    -301 -181
    -312 -187
    -324 -193
    -335 -199
    -347 -204
    -359 -210
    -371 -216
    -383 -222
    -396 -228
    -408 -234
    -420 -240
    -433 -245
    -446 -251
    -458 -257
    -471 -263
    -484 -269
    -497 -275
    -511 -280
    -524 -286
    -537 -292
    -551 -298
    -564 -304
    -578 -309
    -592 -315
    -606 -321
    -620 -327
    -634 -333
    -648 -338
    -662 -344
    -677 -350
    -691 -356
    -706 -361
    -720 -367
    -735 -373
    -750 -378
    -765 -384
    -780 -390
    -795 -396
    -810 -401
    -825 -407
    -841 -413
    -856 -418
    -872 -424
    -888 -430
    -903 -435
    -919 -441
    -935 -446
    -951 -452
    -967 -458
    -983 -463
    -1000 -469
    -1016 -474
    -1032 -480
    -1049 -486
    -1066 -491
    -1082 -497
    -1099 -502
    -1116 -508
    -1133 -513
    -1150 -519
    -1167 -524
    -1184 -530
    -1201 -535
    -1219 -541
    -1236 -546
    1242 -554
    1224 -548
    1207 -543
    1190 -537
    1172 -532
    1155 -526
    1138 -521
    1121 -515
    1105 -509
    1088 -504
    1071 -498
    1055 -493
    1038 -487
    1022 -482
    1005 -476
    989 -470
    973 -465
    957 -459
    941 -453
    925 -448
    909 -442
    893 -436
    878 -431
    862 -425
    847 -419
    831 -414
    816 -408
    801 -402
    786 -396
    771 -391
    756 -385
    741 -379
    726 -373
    711 -368
    697 -362
    682 -356
    668 -350
    654 -345
    640 -339
    625 -333
    612 -327
    598 -321
    584 -316
    570 -310
    557 -304
    543 -298
    530 -292
    516 -286
    503 -280
    490 -275
    477 -269
    464 -263
    452 -257
    439 -251
    426 -245
    414 -239
    401 -233
    389 -228
    377 -222
    365 -216
    353 -210
    341 -204
    330 -198
    318 -192
    306 -186
    295 -180
    284 -174
    273 -169
    261 -163
    251 -157
    240 -151
    229 -145
    218 -139
    208 -133
    197 -127
    187 -121
    177 -115
    167 -110
    157 -104
    147 -98
    137 -92
    128 -86
    118 -80
    109 -74
    100 -68
    90 -62
    81 -57
    73 -51
    64 -45
    55 -39
    46 -33
    38 -27
    30 -21
    22 -16
    13 -10
    5 -4
    -2 2
    -10 8
    -18 13
    -25 19
    -33 25
    -40 31
    -47 36
    -54 42
    -61 48
    -68 54
    -74 59
    -81 65
    -87 71
    -93 76
    -100 82
    -106 88
    -111 93
    -117 99
    -123 104
    -128 110
    -134 116
    -139 121
    -144 127
    -149 132
    -154 138
    -159 143
    -164 149
    -168 154
    -173 159
    -177 165
    -181 170
    -185 176
    -189 181
    -193 186
    -197 191
    -200 197
    -204 202
    -207 207
    -210 212
    -213 218
    -216 223
    -219 228
    -222 233
    -225 238
    -227 243
    -229 248
    -232 253
    -234 258
    -236 263
    -238 268
    -240 273
    -241 277
    -243 282
    -244 287
    -245 292
    -247 296
    -248 301
    -249 306
    -249 310
    -250 315
    -251 319
    -251 324
    -252 328
    -252 333
    -252 337
    -252 342
    -252 346
    -252 350
    -252 354
    -251 359
    -251 363
    -250 367
    -250 371
    -249 375
    -248 379
    -247 383
    -246 387
    -245 391
    -243 394
    -242 398
    -240 402
    -239 406
    -237 409
    -235 413
    -233 416
    -231 420
    -229 423
    -227 427
    -225 430
    -223 433
    -220 436
    -218 440
    -215 443
    -212 446
    -210 449
    -207 452
    -204 455
    -201 458
    -198 460
    -195 463
    -192 466
    -188 469
    -185 471
    -182 474
    -178 476
    -174 479
    -171 481
    -167 483
    -163 486
    -160 488
    -156 490
    -152 492
    -148 494
    -144 496
    -140 498
    -135 500
    -131 501
    -127 503
    -123 505
    -118 506
    -114 508
    -110 509
    -105 511
    -101 512
    -96 514
    -91 515
    -87 516
    -82 517
    -77 518
    -73 519
    -68 520
    -63 521
    -59 522
    -54 522
    -49 523
    -44 524
    -39 524
    -34 525
    -29 525
    -25 525
    -20 526
    -15 526
    -10 526
    -5 526
    0 526
    5 526
    10 526
    15 526
    20 526
    25 525
    29 525
    34 525
    39 524
    44 524
    49 523
    54 522
    59 522
    63 521
    68 520
    73 519
    77 518
    82 517
    87 516
    91 515
    96 514
    101 512
    105 511
    110 509
    114 508
    118 506
    123 505
    127 503
    131 501
    135 500
    140 498
    144 496
    148 494
    152 492
    156 490
    160 488
    163 486
    167 483
    171 481
    174 479
    178 476
    182 474
    185 471
    188 469
    192 466
    195 463
    198 460
    201 458
    204 455
    207 452
    210 449
    212 446
    215 443
    218 440
    220 436
    223 433
    225 430
    227 427
    229 423
    231 420
    233 416
    235 413
    237 409
    239 406
    240 402
    242 398
    243 394
    245 391
    246 387
    247 383
    248 379
    249 375
    250 371
    250 367
    251 363
    251 359
    252 354
    252 350
    252 346
    252 342
    252 337
    252 333
    252 328
    251 324
    251 319
    250 315
    249 310
    249 306
    248 301
    247 296
    245 292
    244 287
    243 282
    241 277
    240 273
    238 268
    236 263
    234 258
    232 253
    229 248
    227 243
    225 238
    222 233
    219 228
    216 223
    213 218
    210 212
    207 207
    204 202
    200 197
    197 191
    193 186
    189 181
    185 176
    181 170
    177 165
    173 159
    168 154
    164 149
    159 143
    154 138
    149 132
    144 127
    139 121
    134 116
    128 110
    123 104
    117 99
    111 93
    106 88
    100 82
    93 76
    87 71
    81 65
    74 59
    68 54
    61 48
    54 42
    47 36
    40 31
    33 25
    25 19
    18 13
    10 8
    2 2
    -5 -4
    -13 -10
    -22 -16
    -30 -21
    -38 -27
    -46 -33
    -55 -39
    -64 -45
    -73 -51
    -81 -57
    -90 -62
    -100 -68
    -109 -74
    -118 -80
    -128 -86
    -137 -92
    -147 -98
    -157 -104
    -167 -110
    -177 -115
    -187 -121
    -197 -127
    -208 -133
    -218 -139
    -229 -145
    -240 -151
    -251 -157
    -261 -163
    -273 -169
    -284 -174
    -295 -180
    -306 -186
    -318 -192
    -330 -198
    -341 -204
    -353 -210
    -365 -216
    -377 -222
    -389 -228
    -401 -233
    -414 -239
    -426 -245
    -439 -251
    -452 -257
    -464 -263
    -477 -269
    -490 -275
    -503 -280
    -516 -286
    -530 -292
    -543 -298
    -557 -304
    -570 -310
    -584 -316
    -598 -321
    -612 -327
    -625 -333
    -640 -339
    -654 -345
    -668 -350
    -682 -356
    -697 -362
    -711 -368
    -726 -373
    -741 -379
    -756 -385
    -771 -391
    -786 -396
    -801 -402
    -816 -408
    -831 -414
    -847 -419
    -862 -425
    -878 -431
    -893 -436
    -909 -442
    -925 -448
    -941 -453
    -957 -459
    -973 -465
    -989 -470
    -1005 -476
    -1022 -482
    -1038 -487
    -1055 -493
    -1071 -498
    -1088 -504
    -1105 -509
    -1121 -515
    -1138 -521
    -1155 -526
    -1172 -532
    -1190 -537
    -1207 -543
    -1224 -548
    -1242 -554
    1247 -561
    1230 -556
    1212 -550
    1195 -545
    1178 -539
    1161 -534
    1144 -528
    1127 -522
    1110 -517
    1093 -511
    1077 -506
    1060 -500
    1044 -494
    1027 -489
    1011 -483
    995 -477
    978 -472
    962 -466
    946 -460
    930 -455
    915 -449
    899 -443
    883 -438
    868 -432
    852 -426
    837 -420
    822 -415
    806 -409
    791 -403
    776 -397
    761 -392
    747 -386
    732 -380
    717 -374
    703 -368
    688 -363
    674 -357
    660 -351
    645 -345
    631 -339
    617 -333
    603 -328
    590 -322
    576 -316
    562 -310
    549 -304
    536 -298
    522 -292
    509 -286
    496 -280
    483 -275
    470 -269
    457 -263
    445 -257
    432 -251
    420 -245
    407 -239
    395 -233
    383 -227
    371 -221
    359 -215
    347 -209
    335 -204
    324 -198
    312 -192
    301 -186
    290 -180
    278 -174
    267 -168
    256 -162
    246 -156
    235 -150
    224 -144
    214 -138
    203 -132
    193 -126
    183 -120
    173 -114
    163 -109
    153 -103
    143 -97
    134 -91
    124 -85
    115 -79
    106 -73
    96 -67
    87 -61
    78 -55
    70 -49
    61 -44
    52 -38
    44 -32
    36 -26
    27 -20
    19 -14
    11 -8
    3 -3
    -4 3
    -12 9
    -19 15
    -27 21
    -34 26
    -41 32
    -48 38
    -55 44
    -62 49
    -69 55
    -75 61
    -81 67
    -88 72
    -94 78
    -100 84
    -106 89
    -112 95
    -117 101
    -123 106
    -128 112
    -134 117
    -139 123
    -144 128
    -149 134
    -154 139
    -158 145
    -163 150
    -167 156
    -172 161
    -176 167
    -180 172
    -184 177
    -188 183
    -192 188
    -195 193
    -199 199
    -202 204
    -205 209
    -208 214
    -211 219
    -214 225
    -217 230
    -220 235
    -222 240
    -224 245
    -227 250
    -229 255
    -231 260
    -233 265
    -235 270
    -236 274
    -238 279
    -239 284
    -241 289
    -242 294
    -243 298
    -244 303
    -245 308
    -246 312
    -246 317
    -247 321
    -247 326
    -248 330
    -248 334
    -248 339
    -248 343
    -248 347
    -248 352
    -247 356
    -247 360
    -246 364
    -246 368
    -245 372
    -244 376
    -243 380
    -242 384
    -241 388
    -239 392
    -238 396
    -237 399
    -235 403
    -233 407
    -232 410
    -230 414
    -228 417
    -226 421
    -224 424
    -222 428
    -219 431
    -217 434
    -215 437
    -212 440
    -209 444
    -207 447
    -204 450
    -201 452
    -198 455
    -195 458
    -192 461
    -189 464
    -186 466
    -182 469
    -179 471
    -176 474
    -172 476
    -168 479
    -165 481
    -161 483
    -157 486
    -154 488
    -150 490
    -146 492
    -142 494
    -138 496
    -134 498
    -129 499
    -125 501
    -121 503
    -117 504
    -112 506
    -108 507
    -104 509
    -99 510
    -95 512
    -90 513
    -86 514
    -81 515
    -76 516
    -72 517
    -67 518
    -62 519
    -58 520
    -53 520
    -48 521
    -43 522
    -39 522
    -34 523
    -29 523
    -24 523
    -19 524
    -15 524
    -10 524
    -5 524
    0 524
    5 524
    10 524
    15 524
    19 524
    24 523
    29 523
    34 523
    39 522
    43 522
    48 521
    53 520
    58 520
    62 519
    67 518
    72 517
    76 516
    81 515
    86 514
    90 513
    95 512
    99 510
    104 509
    108 507
    112 506
    117 504
    121 503
    125 501
    129 499
    134 498
    138 496
    142 494
    146 492
    150 490
    154 488
    157 486
    161 483
    165 481
    168 479
    172 476
    176 474
    179 471
    182 469
    186 466
    189 464
    192 461
    195 458
    198 455
    201 452
    204 450
    207 447
    209 444
    212 440
    215 437
    217 434
    219 431
    222 428
    224 424
    226 421
    228 417
    230 414
    232 410
    233 407
    235 403
    237 399
    238 396
    239 392
    241 388
    242 384
    243 380
    244 376
    245 372
    246 368
    246 364
    247 360
    247 356
    248 352
    248 347
    248 343
    248 339
    248 334
    248 330
    247 326
    247 321
    246 317
    246 312
    245 308
    244 303
    243 298
    242 294
    241 289
    239 284
    238 279
    236 274
    235 270
    233 265
    231 260
    229 255
    227 250
    224 245
    222 240
    220 235
    217 230
    214 225
    211 219
    208 214
    205 209
    202 204
    199 199
    195 193
    192 188
    188 183
    184 177
    180 172
    176 167
    172 161
    167 156
    163 150
    158 145
    154 139
    149 134
    144 128
    139 123
    134 117
    128 112
    123 106
    117 101
    112 95
    106 89
    100 84
    94 78
    88 72
    81 67
    75 61
    69 55
    62 49
    55 44
    48 38
    41 32
    34 26
    27 21
    19 15
    12 9
    4 3
    -3 -3
    -11 -8
    -19 -14
    -27 -20
    -36 -26
    -44 -32
    -52 -38
    -61 -44
    -70 -49
    -78 -55
    -87 -61
    -96 -67
    -106 -73
    -115 -79
    -124 -85
    -134 -91
    -143 -97
    -153 -103
    -163 -109
    -173 -114
    -183 -120
    -193 -126
    -203 -132
    -214 -138
    -224 -144
    -235 -150
    -246 -156
    -256 -162
    -267 -168
    -278 -174
    -290 -180
    -301 -186
    -312 -192
    -324 -198
    -335 -204
    -347 -209
    -359 -215
    -371 -221
    -383 -227
    -395 -233
    -407 -239
    -420 -245
    -432 -251
    -445 -257
    -457 -263
    -470 -269
    -483 -275
    -496 -280
    -509 -286
    -522 -292
    -536 -298
    -549 -304
    -562 -310
    -576 -316
    -590 -322
    -603 -328
    -617 -333
    -631 -339
    -645 -345
    -660 -351
    -674 -357
    -688 -363
    -703 -368
    -717 -374
    -732 -380
    -747 -386
    -761 -392
    -776 -397
    -791 -403
    -806 -409
    -822 -415
    -837 -420
    -852 -426
    -868 -432
    -883 -438
    -899 -443
    -915 -449
    -930 -455
    -946 -460
    -962 -466
    -978 -472
    -995 -477
    -1011 -483
    -1027 -489
    -1044 -494
    -1060 -500
    -1077 -506
    -1093 -511
    -1110 -517
    -1127 -522
    -1144 -528
    -1161 -534
    -1178 -539
    -1195 -545
    -1212 -550
    -1230 -556
    -1247 -561
    1253 -569
    1235 -563
    1218 -558
    1201 -552
    1184 -547
    1166 -541
    1149 -535
    1133 -530
    1116 -524
    1099 -519
    1082 -513
    1066 -507
    1049 -502
    1033 -496
    1017 -490
    1000 -485
    984 -479
    968 -473
    952 -467
    936 -462
    920 -456
    905 -450
    889 -444
    873 -439
    858 -433
    843 -427
    827 -421
    812 -416
    797 -410
    782 -404
    767 -398
    752 -392
    738 -387
    723 -381
    708 -375
    694 -369
    680 -363
    665 -357
    651 -351
    637 -346
    623 -340
    609 -334
    596 -328
    582 -322
    568 -316
    555 -310
    541 -304
    528 -298
    515 -292
    502 -286
    489 -281
    476 -275
    463 -269
    451 -263
    438 -257
    426 -251
    413 -245
    401 -239
    389 -233
    377 -227
    365 -221
    353 -215
    341 -209
    330 -203
    318 -197
    307 -191
    296 -185
    284 -179
    273 -173
    262 -167
    252 -161
    241 -155
    230 -149
    220 -143
    209 -137
    199 -131
    189 -125
    179 -120
    169 -114
    159 -108
    149 -102
    140 -96
    130 -90
    121 -84
    111 -78
    102 -72
    93 -66
    84 -60
    76 -54
    67 -48
    58 -42
    50 -36
    41 -31
    33 -25
    25 -19
    17 -13
    9 -7
    2 -1
    -6 5
    -14 11
    -21 16
    -28 22
    -35 28
    -42 34
    -49 40
    -56 45
    -63 51
    -69 57
    -76 63
    -82 68
    -88 74
    -94 80
    -100 85
    -106 91
    -112 97
    -117 102
    -123 108
    -128 113
    -133 119
    -138 125
    -143 130
    -148 136
    -153 141
    -157 147
    -162 152
    -166 158
    -171 163
    -175 168
    -179 174
    -182 179
    -186 185
    -190 190
    -193 195
    -197 200
    -200 206
    -203 211
    -206 216
    -209 221
    -212 226
    -214 231
    -217 237
    -219 242
    -222 247
    -224 252
    -226 257
    -228 262
    -230 266
    -231 271
    -233 276
    -235 281
    -236 286
    -237 290
    -238 295
    -239 300
    -240 305
    -241 309
    -242 314
    -242 318
    -243 323
    -243 327
    -243 332
    -244 336
    -244 340
    -243 345
    -243 349
    -243 353
    -243 357
    -242 361
    -241 366
    -241 370
    -240 374
    -239 378
    -238 382
    -237 385
    -236 389
    -234 393
    -233 397
    -231 400
    -230 404
    -228 408
    -226 411
    -225 415
    -223 418
    -220 422
    -218 425
    -216 428
    -214 432
    -211 435
    -209 438
    -206 441
    -204 444
    -201 447
    -198 450
    -195 453
    -192 456
    -189 459
    -186 461
    -183 464
    -180 467
    -176 469
    -173 472
    -170 474
    -166 476
    -163 479
    -159 481
    -155 483
    -151 485
    -148 488
    -144 490
    -140 492
    -136 493
    -132 495
    -128 497
    -124 499
    -119 501
    -115 502
    -111 504
    -107 505
    -102 507
    -98 508
    -93 509
    -89 511
    -85 512
    -80 513
    -75 514
    -71 515
    -66 516
    -62 517
    -57 518
    -52 518
    -48 519
    -43 520
    -38 520
    -33 521
    -29 521
    -24 521
    -19 522
    -14 522
    -10 522
    -5 522
    0 522
    5 522
    10 522
    14 522
    19 522
    24 521
    29 521
    33 521
    38 520
    43 520
    48 519
    52 518
    57 518
    62 517
    66 516
    71 515
    75 514
    80 513
    85 512
    89 511
    93 509
    98 508
    102 507
    107 505
    111 504
    115 502
    119 501
    124 499
    128 497
    132 495
    136 493
    140 492
    144 490
    148 488
    151 485
    155 483
    159 481
    163 479
    166 476
    170 474
    173 472
    176 469
    180 467
    183 464
    186 461
    189 459
    192 456
    195 453
    198 450
    201 447
    204 444
    206 441
    209 438
    211 435
    214 432
    216 428
    218 425
    220 422
    223 418
    225 415
    226 411
    228 408
    230 404
    231 400
    233 397
    234 393
    236 389
    237 385
    238 382
    239 378
    240 374
    241 370
    241 366
    242 361
    243 357
    243 353
    243 349
    243 345
    244 340
    244 336
    243 332
    243 327
    243 323
    242 318
    242 314
    241 309
    240 305
    239 300
    238 295
    237 290
    236 286
    235 281
    233 276
    231 271
    230 266
    228 262
    226 257
    224 252
    222 247
    219 242
    217 237
    214 231
    212 226
    209 221
    206 216
    203 211
    200 206
    197 200
    193 195
    190 190
    186 185
    182 179
    179 174
    175 168
    171 163
    166 158
    162 152
    157 147
    153 141
    148 136
    143 130
    138 125
    133 119
    128 113
    123 108
    117 102
    112 97
    106 91
    100 85
    94 80
    88 74
    82 68
    76 63
    69 57
    63 51
    56 45
    49 40
    42 34
    35 28
    28 22
    21 16
    14 11
    6 5
    -2 -1
    -9 -7
    -17 -13
    -25 -19
    -33 -25
    -41 -31
    -50 -36
    -58 -42
    -67 -48
    -76 -54
    -84 -60
    -93 -66
    -102 -72
    -111 -78
    -121 -84
    -130 -90
    -140 -96
    -149 -102
    -159 -108
    -169 -114
    -179 -120
    -189 -125
    -199 -131
    -209 -137
    -220 -143
    -230 -149
    -241 -155
    -252 -161
    -262 -167
    -273 -173
    -284 -179
    -296 -185
    -307 -191
    -318 -197
    -330 -203
    -341 -209
    -353 -215
    -365 -221
    -377 -227
    -389 -233
    -401 -239
    -413 -245
    -426 -251
    -438 -257
    -451 -263
    -463 -269
    -476 -275
    -489 -281
    -502 -286
    -515 -292
    -528 -298
    -541 -304
    -555 -310
    -568 -316
    -582 -322
    -596 -328
    -609 -334
    -623 -340
    -637 -346
    -651 -351
    -665 -357
    -680 -363
    -694 -369
    -708 -375
    -723 -381
    -738 -387
    -752 -392
    -767 -398
    -782 -404
    -797 -410
    -812 -416
    -827 -421
    -843 -427
    -858 -433
    -873 -439
    -889 -444
    -905 -450
    -920 -456
    -936 -462
    -952 -467
    -968 -473
    -984 -479
    -1000 -485
    -1017 -490
    -1033 -496
    -1049 -502
    -1066 -507
    -1082 -513
    -1099 -519
    -1116 -524
    -1133 -530
    -1149 -535
    -1166 -541
    -1184 -547
    -1201 -552
    -1218 -558
    -1235 -563
    -1253 -569
    1258 -577
    1241 -571
    1224 -566
    1206 -560
    1189 -554
    1172 -549
    1155 -543
    1138 -537
    1121 -532
    1105 -526
    1088 -520
    1071 -515
    1055 -509
    1039 -503
    1022 -498
    1006 -492
    990 -486
    974 -480
    958 -475
    942 -469
    926 -463
    910 -457
    895 -451
    879 -446
    864 -440
    848 -434
    833 -428
    818 -422
    803 -417
    788 -411
    773 -405
    758 -399
    743 -393
    729 -387
    714 -381
    700 -376
    686 -370
    671 -364
    657 -358
    643 -352
    629 -346
    615 -340
    601 -334
    588 -328
    574 -322
    561 -316
    547 -310
    534 -304
    521 -298
    508 -293
    495 -287
    482 -281
    469 -275
    457 -269
    444 -263
    432 -257
    419 -251
    407 -245
    395 -239
    383 -233
    371 -227
    359 -221
    347 -215
    336 -209
    324 -203
    313 -197
    302 -191
    290 -185
    279 -179
    268 -173
    258 -167
    247 -161
    236 -155
    226 -149
    215 -143
    205 -137
    195 -131
    185 -125
    175 -119
    165 -113
    155 -107
    146 -101
    136 -95
    127 -89
    117 -83
    108 -77
    99 -71
    90 -65
    81 -59
    73 -53
    64 -47
    56 -41
    47 -35
    39 -29
    31 -23
    23 -17
    15 -12
    7 -6
    -0 0
    -8 6
    -15 12
    -22 18
    -30 24
    -37 29
    -44 35
    -50 41
    -57 47
    -64 53
    -70 58
    -76 64
    -83 70
    -89 76
    -95 81
    -100 87
    -106 93
    -112 98
    -117 104
    -122 110
    -128 115
    -133 121
    -138 126
    -143 132
    -147 137
    -152 143
    -156 148
    -161 154
    -165 159
    -169 165
    -173 170
    -177 176
    -181 181
    -185 186
    -188 192
    -191 197
    -195 202
    -198 207
    -201 213
    -204 218
    -207 223
    -209 228
    -212 233
    -214 238
    -217 243
    -219 248
    -221 253
    -223 258
    -225 263
    -227 268
    -228 273
    -230 278
    -231 283
    -232 287
    -234 292
    -235 297
    -236 301
    -236 306
    -237 311
    -238 315
    -238 320
    -239 324
    -239 329
    -239 333
    -239 337
    -239 342
    -239 346
    -239 350
    -238 354
    -238 359
    -237 363
    -237 367
    -236 371
    -235 375
    -234 379
    -233 383
    -232 386
    -231 390
    -229 394
    -228 398
    -226 401
    -225 405
    -223 409
    -221 412
    -219 416
    -217 419
    -215 422
    -213 426
    -211 429
    -208 432
    -206 435
    -203 438
    -201 442
    -198 445
    -195 447
    -192 450
    -190 453
    -187 456
    -183 459
    -180 461
    -177 464
    -174 467
    -171 469
    -167 472
    -164 474
    -160 476
    -157 479
    -153 481
    -149 483
    -146 485
    -142 487
    -138 489
    -134 491
    -130 493
    -126 495
    -122 496
    -118 498
    -114 500
    -109 501
    -105 503
    -101 504
    -97 506
    -92 507
    -88 508
    -83 509
    -79 511
    -74 512
    -70 513
    -65 514
    -61 514
    -56 515
    -52 516
    -47 517
    -42 517
    -38 518
    -33 518
    -28 519
    -24 519
    -19 519
    -14 520
    -9 520
    -5 520
    0 520
    5 520
    9 520
    14 520
    19 519
    24 519
    28 519
    33 518
    38 518
    42 517
    47 517
    52 516
    56 515
    61 514
    65 514
    70 513
    74 512
    79 511
    83 509
    88 508
    92 507
    97 506
    101 504
    105 503
    109 501
    114 500
    118 498
    122 496
    126 495
    130 493
    134 491
    138 489
    142 487
    146 485
    149 483
    153 481
    157 479
    160 476
    164 474
    167 472
    171 469
    174 467
    177 464
    180 461
    183 459
    187 456
    190 453
    192 450
    195 447
    198 445
    201 442
    203 438
    206 435
    208 432
    211 429
    213 426
    215 422
    217 419
    219 416
    221 412
    223 409
    225 405
    226 401
    228 398
    229 394
    231 390
    232 386
    233 383
    234 379
    235 375
    236 371
    237 367
    237 363
    238 359
    238 354
    239 350
    239 346
    239 342
    239 337
    239 333
    239 329
    239 324
    238 320
    238 315
    237 311
    236 306
    236 301
    235 297
    234 292
    232 287
    231 283
    230 278
    228 273
    227 268
    225 263
    223 258
    221 253
    219 248
    217 243
    214 238
    212 233
    209 228
    207 223
    204 218
    201 213
    198 207
    195 202
    191 197
    188 192
    185 186
    181 181
    177 176
    173 170
    169 165
    165 159
    161 154
    156 148
    152 143
    147 137
    143 132
    138 126
    133 121
    128 115
    122 110
    117 104
    112 98
    106 93
    100 87
    95 81
    89 76
    83 70
    76 64
    70 58
    64 53
    57 47
    50 41
    44 35
    37 29
    30 24
    22 18
    15 12
    8 6
    0 0
    -7 -6
    -15 -12
    -23 -17
    -31 -23
    -39 -29
    -47 -35
    -56 -41
    -64 -47
    -73 -53
    -81 -59
    -90 -65
    -99 -71
    -108 -77
    -117 -83
    -127 -89
    -136 -95
    -146 -101
    -155 -107
    -165 -113
    -175 -119
    -185 -125
    -195 -131
    -205 -137
    -215 -143
    -226 -149
    -236 -155
    -247 -161
    -258 -167
    -268 -173
    -279 -179
    -290 -185
    -302 -191
    -313 -197
    -324 -203
    -336 -209
    -347 -215
    -359 -221
    -371 -227
    -383 -233
    -395 -239
    -407 -245
    -419 -251
    -432 -257
    -444 -263
    -457 -269
    -469 -275
    -482 -281
    -495 -287
    -508 -293
    -521 -298
    -534 -304
    -547 -310
    -561 -316
    -574 -322
    -588 -328
    -601 -334
    -615 -340
    -629 -346
    -643 -352
    -657 -358
    -671 -364
    -686 -370
    -700 -376
    -714 -381
    -729 -387
    -743 -393
    -758 -399
    -773 -405
    -788 -411
    -803 -417
    -818 -422
    -833 -428
    -848 -434
    -864 -440
    -879 -446
    -895 -451
    -910 -457
    -926 -463
    -942 -469
    -958 -475
    -974 -480
    -990 -486
    -1006 -492
    -1022 -498
    -1039 -503
    -1055 -509
    -1071 -515
    -1088 -520
    -1105 -526
    -1121 -532
    -1138 -537
    -1155 -543
    -1172 -549
    -1189 -554
    -1206 -560
    -1224 -566
    -1241 -571
    -1258 -577
    1264 -585
    1246 -579
    1229 -573
    1212 -568
    1195 -562
    1178 -556
    1161 -551
    1144 -545
    1127 -539
    1110 -534
    1094 -528
    1077 -522
    1061 -516
    1044 -511
    1028 -505
    1012 -499
    996 -493
    980 -488
    964 -482
    948 -476
    932 -470
    916 -464
    901 -459
    885 -453
    870 -447
    854 -441
    839 -435
    824 -429
    809 -423
    794 -418
    779 -412
    764 -406
    749 -400
    735 -394
    720 -388
    706 -382
    691 -376
    677 -370
    663 -364
    649 -358
    635 -352
    621 -346
    607 -341
    594 -335
    580 -329
    567 -323
    553 -317
    540 -311
    527 -305
    514 -299
    501 -293
    488 -287
    475 -281
    463 -275
    450 -269
    438 -263
    425 -257
    413 -251
    401 -245
    389 -238
    377 -232
    365 -226
    353 -220
    342 -214
    330 -208
    319 -202
    308 -196
    296 -190
    285 -184
    274 -178
    264 -172
    253 -166
    242 -160
    232 -154
    221 -148
    211 -142
    201 -136
    191 -130
    181 -124
    171 -118
    161 -112
    152 -106
    142 -100
    133 -94
    123 -88
    114 -82
    105 -76
    96 -70
    87 -64
    79 -58
    70 -52
    62 -46
    53 -40
    45 -34
    37 -28
    29 -22
    21 -16
    13 -10
    6 -4
    -2 1
    -9 7
    -17 13
    -24 19
    -31 25
    -38 31
    -45 37
    -51 42
    -58 48
    -64 54
    -71 60
    -77 66
    -83 71
    -89 77
    -95 83
    -100 88
    -106 94
    -111 100
    -117 105
    -122 111
    -127 117
    -132 122
    -137 128
    -142 133
    -146 139
    -151 144
    -155 150
    -160 155
    -164 161
    -168 166
    -172 172
    -176 177
    -179 182
    -183 188
    -186 193
    -189 198
    -193 204
    -196 209
    -199 214
    -202 219
    -204 224
    -207 230
    -209 235
    -212 240
    -214 245
    -216 250
    -218 255
    -220 260
    -222 265
    -223 270
    -225 274
    -226 279
    -228 284
    -229 289
    -230 293
    -231 298
    -232 303
    -233 307
    -233 312
    -234 316
    -234 321
    -235 325
    -235 330
    -235 334
    -235 339
    -235 343
    -235 347
    -234 351
    -234 356
    -233 360
    -233 364
    -232 368
    -231 372
    -230 376
    -229 380
    -228 384
    -227 387
    -225 391
    -224 395
    -223 399
    -221 402
    -219 406
    -218 409
    -216 413
    -214 416
    -212 420
    -210 423
    -207 426
    -205 429
    -203 433
    -200 436
    -198 439
    -195 442
    -192 445
    -190 448
    -187 451
    -184 453
    -181 456
    -178 459
    -175 461
    -171 464
    -168 466
    -165 469
    -161 471
    -158 474
    -154 476
    -151 478
    -147 480
    -143 483
    -140 485
    -136 487
    -132 488
    -128 490
    -124 492
    -120 494
    -116 496
    -112 497
    -108 499
    -104 500
    -99 502
    -95 503
    -91 504
    -87 506
    -82 507
    -78 508
    -73 509
    -69 510
    -64 511
    -60 512
    -55 513
    -51 513
    -46 514
    -42 515
    -37 515
    -33 516
    -28 516
    -23 517
    -19 517
    -14 517
    -9 517
    -5 517
    0 517
    5 517
    9 517
    14 517
    19 517
    23 517
    28 516
    33 516
    37 515
    42 515
    46 514
    51 513
    55 513
    60 512
    64 511
    69 510
    73 509
    78 508
    82 507
    87 506
    91 504
    95 503
    99 502
    104 500
    108 499
    112 497
    116 496
    120 494
    124 492
    128 490
    132 488
    136 487
    140 485
    143 483
    147 480
    151 478
    154 476
    158 474
    161 471
    165 469
    168 466
    171 464
    175 461
    178 459
    181 456
    184 453
    187 451
    190 448
    192 445
    195 442
    198 439
    200 436
    203 433
    205 429
    207 426
    210 423
    212 420
    214 416
    216 413
    218 409
    219 406
    221 402
    223 399
    224 395
    225 391
    227 387
    228 384
    229 380
    230 376
    231 372
    232 368
    233 364
    233 360
    234 356
    234 351
    235 347
    235 343
    235 339
    235 334
    235 330
    235 325
    234 321
    234 316
    233 312
    233 307
    232 303
    231 298
    230 293
    229 289
    228 284
    226 279
    225 274
    223 270
    222 265
    220 260
    218 255
    216 250
    214 245
    212 240
    209 235
    207 230
    204 224
    202 219
    199 214
    196 209
    193 204
    189 198
    186 193
    183 188
    179 182
    176 177
    172 172
    168 166
    164 161
    160 155
    155 150
    151 144
    146 139
    142 133
    137 128
    132 122
    127 117
    122 111
    117 105
    111 100
    106 94
    100 88
    95 83
    89 77
    83 71
    77 66
    71 60
    64 54
    58 48
    51 42
    45 37
    38 31
    31 25
    24 19
    17 13
    9 7
    2 1
    -6 -4
    -13 -10
    -21 -16
    -29 -22
    -37 -28
    -45 -34
    -53 -40
    -62 -46
    -70 -52
    -79 -58
    -87 -64
    -96 -70
    -105 -76
    -114 -82
    -123 -88
    -133 -94
    -142 -100
    -152 -106
    -161 -112
    -171 -118
    -181 -124
    -191 -130
    -201 -136
    -211 -142
    -221 -148
    -232 -154
    -242 -160
    -253 -166
    -264 -172
    -274 -178
    -285 -184
    -296 -190
    -308 -196
    -319 -202
    -330 -208
    -342 -214
    -353 -220
    -365 -226
    -377 -232
    -389 -238
    -401 -245
    -413 -251
    -425 -257
    -438 -263
    -450 -269
    -463 -275
    -475 -281
    -488 -287
    -501 -293
    -514 -299
    -527 -305
    -540 -311
    -553 -317
    -567 -323
    -580 -329
    -594 -335
    -607 -341
    -621 -346
    -635 -352
    -649 -358
    -663 -364
    -677 -370
    -691 -376
    -706 -382
    -720 -388
    -735 -394
    -749 -400
    -764 -406
    -779 -412
    -794 -418
    -809 -423
    -824 -429
    -839 -435
    -854 -441
    -870 -447
    -885 -453
    -901 -459
    -916 -464
    -932 -470
    -948 -476
    -964 -482
    -980 -488
    -996 -493
    -1012 -499
    -1028 -505
    -1044 -511
    -1061 -516
    -1077 -522
    -1094 -528
    -1110 -534
    -1127 -539
    -1144 -545
    -1161 -551
    -1178 -556
    -1195 -562
    -1212 -568
    -1229 -573
    -1246 -579
    -1264 -585
    1269 -592
    1252 -587
    1235 -581
    1218 -575
    1200 -570
    1183 -564
    1166 -558
    1150 -553
    1133 -547
    1116 -541
    1099 -535
    1083 -530
    1066 -524
    1050 -518
    1034 -512
    1018 -506
    1001 -501
    985 -495
    969 -489
    954 -483
    938 -477
    922 -472
    906 -466
    891 -460
    875 -454
    860 -448
    845 -442
    830 -436
    815 -430
    800 -424
    785 -419
    770 -413
    755 -407
    741 -401
    726 -395
    712 -389
    697 -383
    683 -377
    669 -371
    655 -365
    641 -359
    627 -353
    613 -347
    600 -341
    586 -335
    573 -329
    559 -323
    546 -317
    533 -311
    520 -305
    507 -299
    494 -293
    481 -287
    469 -281
    456 -275
    444 -269
    431 -263
    419 -257
    407 -250
    395 -244
    383 -238
    371 -232
    359 -226
    348 -220
    336 -214
    325 -208
    314 -202
    303 -196
    291 -190
    280 -184
    270 -178
    259 -172
    248 -166
    238 -159
    227 -153
    217 -147
    207 -141
    197 -135
    187 -129
    177 -123
    167 -117
    158 -111
    148 -105
    139 -99
    129 -93
    120 -87
    111 -81
    102 -75
    93 -69
    85 -63
    76 -57
    68 -51
    59 -45
    51 -39
    43 -33
    35 -27
    27 -21
    19 -15
    12 -9
    4 -3
    -3 3
    -11 9
    -18 14
    -25 20
    -32 26
    -39 32
    -45 38
    -52 44
    -58 50
    -65 55
    -71 61
    -77 67
    -83 73
    -89 78
    -95 84
    -100 90
    -106 96
    -111 101
    -116 107
    -122 113
    -127 118
    -131 124
    -136 129
    -141 135
    -145 140
    -150 146
    -154 151
    -158 157
    -162 162
    -166 168
    -170 173
    -174 179
    -177 184
    -181 189
    -184 195
    -187 200
    -191 205
    -193 210
    -196 216
    -199 221
    -202 226
    -204 231
    -207 236
    -209 241
    -211 246
    -213 251
    -215 256
    -217 261
    -219 266
    -220 271
    -222 276
    -223 281
    -224 285
    -225 290
    -226 295
    -227 299
    -228 304
    -229 309
    -229 313
    -230 318
    -230 322
    -230 327
    -230 331
    -231 335
    -230 340
    -230 344
    -230 348
    -230 352
    -229 356
    -229 361
    -228 365
    -227 369
    -226 373
    -225 377
    -224 380
    -223 384
    -222 388
    -220 392
    -219 395
    -217 399
    -216 403
    -214 406
    -212 410
    -210 413
    -208 417
    -206 420
    -204 423
    -202 426
    -199 430
    -197 433
    -195 436
    -192 439
    -189 442
    -187 445
    -184 448
    -181 450
    -178 453
    -175 456
    -172 459
    -169 461
    -166 464
    -162 466
    -159 469
    -156 471
    -152 473
    -149 475
    -145 478
    -141 480
    -138 482
    -134 484
    -130 486
    -126 488
    -122 489
    -118 491
    -114 493
    -110 495
    -106 496
    -102 498
    -98 499
    -94 500
    -90 502
    -85 503
    -81 504
    -77 505
    -72 506
    -68 507
    -64 508
    -59 509
    -55 510
    -50 511
    -46 511
    -41 512
    -37 513
    -32 513
    -28 514
    -23 514
    -18 514
    -14 514
    -9 515
    -5 515
    0 515
    5 515
    9 515
    14 514
    18 514
    23 514
    28 514
    32 513
    37 513
    41 512
    46 511
    50 511
    55 510
    59 509
    64 508
    68 507
    72 506
    77 505
    81 504
    85 503
    90 502
    94 500
    98 499
    102 498
    106 496
    110 495
    114 493
    118 491
    122 489
    126 488
    130 486
    134 484
    138 482
    141 480
    145 478
    149 475
    152 473
    156 471
    159 469
    162 466
    166 464
    169 461
    172 459
    175 456
    178 453
    181 450
    184 448
    187 445
    189 442
    192 439
    195 436
    197 433
    199 430
    202 426
    204 423
    206 420
    208 417
    210 413
    212 410
    214 406
    216 403
    217 399
    219 395
    220 392
    222 388
    223 384
    224 380
    225 377
    226 373
    227 369
    228 365
    229 361
    229 356
    230 352
    230 348
    230 344
    230 340
    231 335
    230 331
    230 327
    230 322
    230 318
    229 313
    229 309
    228 304
    227 299
    226 295
    225 290
    224 285
    223 281
    222 276
    220 271
    219 266
    217 261
    215 256
    213 251
    211 246
    209 241
    207 236
    204 231
    202 226
    199 221
    196 216
    193 210
    191 205
    187 200
    184 195
    181 189
    177 184
    174 179
    170 173
    166 168
    162 162
    158 157
    154 151
    150 146
    145 140
    141 135
    136 129
    131 124
    127 118
    122 113
    116 107
    111 101
    106 96
    100 90
    95 84
    89 78
    83 73
    77 67
    71 61
    65 55
    58 50
    52 44
    45 38
    39 32
    32 26
    25 20
    18 14
    11 9
    3 3
    -4 -3
    -12 -9
    -19 -15
    -27 -21
    -35 -27
    -43 -33
    -51 -39
    -59 -45
    -68 -51
    -76 -57
    -85 -63
    -93 -69
    -102 -75
    -111 -81
    -120 -87
    -129 -93
    -139 -99
    -148 -105
    -158 -111
    -167 -117
    -177 -123
    -187 -129
    -197 -135
    -207 -141
    -217 -147
    -227 -153
    -238 -159
    -248 -166
    -259 -172
    -270 -178
    -280 -184
    -291 -190
    -303 -196
    -314 -202
    -325 -208
    -336 -214
    -348 -220
    -359 -226
    -371 -232
    -383 -238
    -395 -244
    -407 -250
    -419 -257
    -431 -263
    -444 -269
    -456 -275
    -469 -281
    -481 -287
    -494 -293
    -507 -299
    -520 -305
    -533 -311
    -546 -317
    -559 -323
    -573 -329
    -586 -335
    -600 -341
    -613 -347
    -627 -353
    -641 -359
    -655 -365
    -669 -371
    -683 -377
    -697 -383
    -712 -389
    -726 -395
    -741 -401
    -755 -407
    -770 -413
    -785 -419
    -800 -424
    -815 -430
    -830 -436
    -845 -442
    -860 -448
    -875 -454
    -891 -460
    -906 -466
    -922 -472
    -938 -477
    -954 -483
    -969 -489
    -985 -495
    -1001 -501
    -1018 -506
    -1034 -512
    -1050 -518
    -1066 -524
    -1083 -530
    -1099 -535
    -1116 -541
    -1133 -547
    -1150 -553
    -1166 -558
    -1183 -564
    -1200 -570
    -1218 -575
    -1235 -581
    -1252 -587
    -1269 -592
    1275 -600
    1258 -595
    1241 -589
    1223 -583
    1206 -578
    1189 -572
    1172 -566
    1155 -560
    1139 -555
    1122 -549
    1105 -543
    1089 -537
    1072 -531
    1056 -526
    1040 -520
    1023 -514
    1007 -508
    991 -502
    975 -496
    959 -491
    944 -485
    928 -479
    912 -473
    897 -467
    881 -461
    866 -455
    851 -449
    836 -443
    821 -437
    806 -431
    791 -425
    776 -420
    761 -414
    747 -408
    732 -402
    718 -396
    703 -390
    689 -384
    675 -378
    661 -372
    647 -366
    633 -360
    619 -354
    606 -347
    592 -341
    579 -335
    565 -329
    552 -323
    539 -317
    526 -311
    513 -305
    500 -299
    487 -293
    475 -287
    462 -281
    450 -275
    437 -269
    425 -263
    413 -256
    401 -250
    389 -244
    377 -238
    366 -232
    354 -226
    342 -220
    331 -214
    320 -208
    309 -202
    298 -195
    287 -189
    276 -183
    265 -177
    254 -171
    244 -165
    233 -159
    223 -153
    213 -147
    203 -141
    193 -135
    183 -128
    173 -122
    164 -116
    154 -110
    145 -104
    135 -98
    126 -92
    117 -86
    108 -80
    99 -74
    91 -68
    82 -62
    74 -56
    65 -50
    57 -44
    49 -38
    41 -32
    33 -26
    25 -20
    18 -14
    10 -8
    3 -2
    -5 4
    -12 10
    -19 16
    -26 22
    -33 27
    -40 33
    -46 39
    -53 45
    -59 51
    -65 57
    -71 62
    -77 68
    -83 74
    -89 80
    -95 86
    -100 91
    -106 97
    -111 103
    -116 108
    -121 114
    -126 120
    -131 125
    -135 131
    -140 136
    -144 142
    -149 147
    -153 153
    -157 158
    -161 164
    -165 169
    -168 175
    -172 180
    -176 185
    -179 191
    -182 196
    -185 201
    -188 207
    -191 212
    -194 217
    -197 222
    -199 227
    -202 232
    -204 237
    -206 242
    -208 248
    -210 253
    -212 257
    -214 262
    -215 267
    -217 272
    -218 277
    -219 282
    -221 286
    -222 291
    -223 296
    -223 301
    -224 305
    -225 310
    -225 314
    -226 319
    -226 323
    -226 328
    -226 332
    -226 336
    -226 341
    -226 345
    -225 349
    -225 353
    -224 357
    -224 361
    -223 365
    -222 369
    -221 373
    -220 377
    -219 381
    -218 385
    -217 389
    -215 392
    -214 396
    -212 400
    -210 403
    -209 407
    -207 410
    -205 414
    -203 417
    -201 420
    -199 423
    -196 427
    -194 430
    -192 433
    -189 436
    -186 439
    -184 442
    -181 445
    -178 448
    -175 450
    -172 453
    -169 456
    -166 458
    -163 461
    -160 463
    -157 466
    -153 468
    -150 470
    -146 473
    -143 475
    -139 477
    -136 479
    -132 481
    -128 483
    -124 485
    -121 487
    -117 488
    -113 490
    -109 492
    -105 493
    -101 495
    -97 496
    -92 498
    -88 499
    -84 500
    -80 501
    -76 503
    -71 504
    -67 505
    -63 506
    -58 506
    -54 507
    -49 508
    -45 509
    -41 509
    -36 510
    -32 510
    -27 511
    -23 511
    -18 511
    -14 512
    -9 512
    -5 512
    0 512
    5 512
    9 512
    14 512
    18 511
    23 511
    27 511
    32 510
    36 510
    41 509
    45 509
    49 508
    54 507
    58 506
    63 506
    67 505
    71 504
    76 503
    80 501
    84 500
    88 499
    92 498
    97 496
    101 495
    105 493
    109 492
    113 490
    117 488
    121 487
    124 485
    128 483
    132 481
    136 479
    139 477
    143 475
    146 473
    150 470
    153 468
    157 466
    160 463
    163 461
    166 458
    169 456
    172 453
    175 450
    178 448
    181 445
    184 442
    186 439
    189 436
    192 433
    194 430
    196 427
    199 423
    201 420
    203 417
    205 414
    207 410
    209 407
    210 403
    212 400
    214 396
    215 392
    217 389
    218 385
    219 381
    220 377
    221 373
    222 369
    223 365
    224 361
    224 357
    225 353
    225 349
    226 345
    226 341
    226 336
    226 332
    226 328
    226 323
    226 319
    225 314
    225 310
    224 305
    223 301
    223 296
    222 291
    221 286
    219 282
    218 277
    217 272
    215 267
    214 262
    212 257
    210 253
    208 248
    206 242
    204 237
    202 232
    199 227
    197 222
    194 217
    191 212
    188 207
    185 201
    182 196
    179 191
    176 185
    172 180
    168 175
    165 169
    161 164
    157 158
    153 153
    149 147
    144 142
    140 136
    135 131
    131 125
    126 120
    121 114
    116 108
    111 103
    106 97
    100 91
    95 86
    89 80
    83 74
    77 68
    71 62
    65 57
    59 51
    53 45
    46 39
    40 33
    33 27
    26 22
    19 16
    12 10
    5 4
    -3 -2
    -10 -8
    -18 -14
    -25 -20
    -33 -26
    -41 -32
    -49 -38
    -57 -44
    -65 -50
    -74 -56
    -82 -62
    -91 -68
    -99 -74
    -108 -80
    -117 -86
    -126 -92
    -135 -98
    -145 -104
    -154 -110
    -164 -116
    -173 -122
    -183 -128
    -193 -135
    -203 -141
    -213 -147
    -223 -153
    -233 -159
    -244 -165
    -254 -171
    -265 -177
    -276 -183
    -287 -189
    -298 -195
    -309 -202
    -320 -208
    -331 -214
    -342 -220
    -354 -226
    -366 -232
    -377 -238
    -389 -244
    -401 -250
    -413 -256
    -425 -263
    -437 -269
    -450 -275
    -462 -281
    -475 -287
    -487 -293
    -500 -299
    -513 -305
    -526 -311
    -539 -317
    -552 -323
    -565 -329
    -579 -335
    -592 -341
    -606 -347
    -619 -354
    -633 -360
    -647 -366
    -661 -372
    -675 -378
    -689 -384
    -703 -390
    -718 -396
    -732 -402
    -747 -408
    -761 -414
    -776 -420
    -791 -425
    -806 -431
    -821 -437
    -836 -443
    -851 -449
    -866 -455
    -881 -461
    -897 -467
    -912 -473
    -928 -479
    -944 -485
    -959 -491
    -975 -496
    -991 -502
    -1007 -508
    -1023 -514
    -1040 -520
    -1056 -526
    -1072 -531
    -1089 -537
    -1105 -543
    -1122 -549
    -1139 -555
    -1155 -560
    -1172 -566
    -1189 -572
    -1206 -578
    -1223 -583
    -1241 -589
    -1258 -595
    -1275 -600
    1281 -608
    1264 -603
    1246 -597
    1229 -591
    1212 -585
    1195 -580
    1178 -574
    1161 -568
    1144 -562
    1128 -556
    1111 -551
    1094 -545
    1078 -539
    1062 -533
    1045 -527
    1029 -521
    1013 -516
    997 -510
    981 -504
    965 -498
    949 -492
    934 -486
    918 -480
    903 -474
    887 -468
    872 -462
    857 -456
    842 -450
    827 -444
    812 -438
    797 -432
    782 -426
    767 -420
    753 -414
    738 -408
    724 -402
    709 -396
    695 -390
    681 -384
    667 -378
    653 -372
    639 -366
    625 -360
    612 -354
    598 -348
    585 -342
    572 -336
    558 -330
    545 -324
    532 -318
    519 -311
    506 -305
    494 -299
    481 -293
    468 -287
    456 -281
    444 -275
    431 -269
    419 -263
    407 -256
    395 -250
    383 -244
    372 -238
    360 -232
    349 -226
    337 -220
    326 -214
    315 -207
    304 -201
    293 -195
    282 -189
    271 -183
    260 -177
    250 -171
    240 -164
    229 -158
    219 -152
    209 -146
    199 -140
    189 -134
    179 -128
    170 -122
    160 -116
    151 -109
    141 -103
    132 -97
    123 -91
    114 -85
    105 -79
    97 -73
    88 -67
    80 -61
    71 -55
    63 -49
    55 -43
    47 -37
    39 -31
    31 -25
    23 -19
    16 -13
    8 -7
    1 -1
    -6 5
    -13 11
    -20 17
    -27 23
    -34 29
    -40 35
    -47 40
    -53 46
    -59 52
    -66 58
    -72 64
    -77 69
    -83 75
    -89 81
    -94 87
    -100 92
    -105 98
    -110 104
    -115 110
    -120 115
    -125 121
    -130 126
    -134 132
    -139 138
    -143 143
    -147 149
    -151 154
    -155 160
    -159 165
    -163 171
    -167 176
    -170 181
    -174 187
    -177 192
    -180 197
    -183 203
    -186 208
    -189 213
    -191 218
    -194 223
    -196 228
    -199 234
    -201 239
    -203 244
    -205 249
    -207 254
    -209 259
    -210 264
    -212 268
    -213 273
    -215 278
    -216 283
    -217 288
    -218 292
    -219 297
    -220 302
    -220 306
    -221 311
    -221 315
    -221 320
    -222 324
    -222 328
    -222 333
    -222 337
    -222 341
    -221 346
    -221 350
    -220 354
    -220 358
    -219 362
    -218 366
    -217 370
    -216 374
    -215 378
    -214 382
    -213 385
    -212 389
    -210 393
    -209 396
    -207 400
    -205 403
    -203 407
    -202 410
    -200 414
    -198 417
    -195 420
    -193 423
    -191 427
    -188 430
    -186 433
    -183 436
    -181 439
    -178 442
    -175 444
    -173 447
    -170 450
    -167 453
    -164 455
    -161 458
    -157 460
    -154 463
    -151 465
    -148 467
    -144 470
    -141 472
    -137 474
    -134 476
    -130 478
    -126 480
    -123 482
    -119 484
    -115 485
    -111 487
    -107 489
    -103 490
    -99 492
    -95 493
    -91 495
    -87 496
    -83 497
    -79 498
    -75 500
    -70 501
    -66 502
    -62 503
    -57 504
    -53 504
    -49 505
    -44 506
    -40 506
    -36 507
    -31 507
    -27 508
    -22 508
    -18 509
    -13 509
    -9 509
    -4 509
    0 509
    4 509
    9 509
    13 509
    18 509
    22 508
    27 508
    31 507
    36 507
    40 506
    44 506
    49 505
    53 504
    57 504
    62 503
    66 502
    70 501
    75 500
    79 498
    83 497
    87 496
    91 495
    95 493
    99 492
    103 490
    107 489
    111 487
    115 485
    119 484
    123 482
    126 480
    130 478
    134 476
    137 474
    141 472
    144 470
    148 467
    151 465
    154 463
    157 460
    161 458
    164 455
    167 453
    170 450
    173 447
    175 444
    178 442
    181 439
    183 436
    186 433
    188 430
    191 427
    193 423
    195 420
    198 417
    200 414
    202 410
    203 407
    205 403
    207 400
    209 396
    210 393
    212 389
    213 385
    214 382
    215 378
    216 374
    217 370
    218 366
    219 362
    220 358
    220 354
    221 350
    221 346
    222 341
    222 337
    222 333
    222 328
    222 324
    221 320
    221 315
    221 311
    220 306
    220 302
    219 297
    218 292
    217 288
    216 283
    215 278
    213 273
    212 268
    210 264
    209 259
    207 254
    205 249
    203 244
    201 239
    199 234
    196 228
    194 223
    191 218
    189 213
    186 208
    183 203
    180 197
    177 192
    174 187
    170 181
    167 176
    163 171
    159 165
    155 160
    151 154
    147 149
    143 143
    139 138
    134 132
    130 126
    125 121
    120 115
    115 110
    110 104
    105 98
    100 92
    94 87
    89 81
    83 75
    77 69
    72 64
    66 58
    59 52
    53 46
    47 40
    40 35
    34 29
    27 23
    20 17
    13 11
    6 5
    -1 -1
    -8 -7
    -16 -13
    -23 -19
    -31 -25
    -39 -31
    -47 -37
    -55 -43
    -63 -49
    -71 -55
    -80 -61
    -88 -67
    -97 -73
    -105 -79
    -114 -85
    -123 -91
    -132 -97
    -141 -103
    -151 -109
    -160 -116
    -170 -122
    -179 -128
    -189 -134
    -199 -140
    -209 -146
    -219 -152
    -229 -158
    -240 -164
    -250 -171
    -260 -177
    -271 -183
    -282 -189
    -293 -195
    -304 -201
    -315 -207
    -326 -214
    -337 -220
    -349 -226
    -360 -232
    -372 -238
    -383 -244
    -395 -250
    -407 -256
    -419 -263
    -431 -269
    -444 -275
    -456 -281
    -468 -287
    -481 -293
    -494 -299
    -506 -305
    -519 -311
    -532 -318
    -545 -324
    -558 -330
    -572 -336
    -585 -342
    -598 -348
    -612 -354
    -625 -360
    -639 -366
    -653 -372
    -667 -378
    -681 -384
    -695 -390
    -709 -396
    -724 -402
    -738 -408
    -753 -414
    -767 -420
    -782 -426
    -797 -432
    -812 -438
    -827 -444
    -842 -450
    -857 -456
    -872 -462
    -887 -468
    -903 -474
    -918 -480
    -934 -486
    -949 -492
    -965 -498
    -981 -504
    -997 -510
    -1013 -516
    -1029 -521
    -1045 -527
    -1062 -533
    -1078 -539
    -1094 -545
    -1111 -551
    -1128 -556
    -1144 -562
    -1161 -568
    -1178 -574
    -1195 -580
    -1212 -585
    -1229 -591
    -1246 -597
    -1264 -603
    -1281 -608
    1287 -616
    1269 -611
    1252 -605
    1235 -599
    1218 -593
    1201 -588
    1184 -582
    1167 -576
    1150 -570
    1133 -564
    1117 -558
    1100 -553
    1084 -547
    1068 -541
    1051 -535
    1035 -529
    1019 -523
    1003 -517
    987 -511
    971 -505
    955 -499
    940 -493
    924 -488
    909 -482
    893 -476
    878 -470
    863 -464
    848 -458
    833 -452
    818 -446
    803 -440
    788 -434
    773 -428
    759 -421
    744 -415
    730 -409
    715 -403
    701 -397
    687 -391
    673 -385
    659 -379
    645 -373
    632 -367
    618 -361
    604 -355
    591 -349
    578 -342
    564 -336
    551 -330
    538 -324
    525 -318
    512 -312
    500 -306
    487 -299
    474 -293
    462 -287
    450 -281
    437 -275
    425 -269
    413 -263
    401 -256
    390 -250
    378 -244
    366 -238
    355 -232
    343 -226
    332 -219
    321 -213
    310 -207
    299 -201
    288 -195
    277 -189
    267 -182
    256 -176
    246 -170
    235 -164
    225 -158
    215 -152
    205 -146
    195 -139
    185 -133
    176 -127
    166 -121
    157 -115
    148 -109
    138 -103
    129 -97
    120 -90
    112 -84
    103 -78
    94 -72
    86 -66
    77 -60
    69 -54
    61 -48
    53 -42
    45 -36
    37 -30
    29 -24
    22 -18
    14 -12
    7 -6
    -0 0
    -7 6
    -14 12
    -21 18
    -28 24
    -34 30
    -41 36
    -47 42
    -54 47
    -60 53
    -66 59
    -72 65
    -77 71
    -83 76
    -89 82
    -94 88
    -99 94
    -105 99
    -110 105
    -115 111
    -119 116
    -124 122
    -129 128
    -133 133
    -138 139
    -142 144
    -146 150
    -150 155
    -154 161
    -158 166
    -161 172
    -165 177
    -168 182
    -171 188
    -175 193
    -178 198
    -181 204
    -184 209
    -186 214
    -189 219
    -191 224
    -194 230
    -196 235
    -198 240
    -200 245
    -202 250
    -204 255
    -205 260
    -207 265
    -208 269
    -210 274
    -211 279
    -212 284
    -213 288
    -214 293
    -215 298
    -216 302
    -216 307
    -217 311
    -217 316
    -217 320
    -217 325
    -218 329
    -217 333
    -217 338
    -217 342
    -217 346
    -216 350
    -216 354
    -215 358
    -214 362
    -213 366
    -213 370
    -212 374
    -210 378
    -209 382
    -208 386
    -206 389
    -205 393
    -203 396
    -202 400
    -200 403
    -198 407
    -196 410
    -194 414
    -192 417
    -190 420
    -188 423
    -185 426
    -183 429
    -180 432
    -178 435
    -175 438
    -173 441
    -170 444
    -167 447
    -164 449
    -161 452
    -158 454
    -155 457
    -152 459
    -149 462
    -145 464
    -142 466
    -139 469
    -135 471
    -132 473
    -128 475
    -124 477
    -121 479
    -117 480
    -113 482
    -109 484
    -106 486
    -102 487
    -98 489
    -94 490
    -90 492
    -86 493
    -82 494
    -78 495
    -73 497
    -69 498
    -65 499
    -61 500
    -57 500
    -52 501
    -48 502
    -44 503
    -39 503
    -35 504
    -31 504
    -26 505
    -22 505
    -18 505
    -13 506
    -9 506
    -4 506
    0 506
    4 506
    9 506
    13 506
    18 505
    22 505
    26 505
    31 504
    35 504
    39 503
    44 503
    48 502
    52 501
    57 500
    61 500
    65 499
    69 498
    73 497
    78 495
    82 494
    86 493
    90 492
    94 490
    98 489
    102 487
    106 486
    109 484
    113 482
    117 480
    121 479
    124 477
    128 475
    132 473
    135 471
    139 469
    142 466
    145 464
    149 462
    152 459
    155 457
    158 454
    161 452
    164 449
    167 447
    170 444
    173 441
    175 438
    178 435
    180 432
    183 429
    185 426
    188 423
    190 420
    192 417
    194 414
    196 410
    198 407
    200 403
    202 400
    203 396
    205 393
    206 389
    208 386
    209 382
    210 378
    212 374
    213 370
    213 366
    214 362
    215 358
    216 354
    216 350
    217 346
    217 342
    217 338
    217 333
    218 329
    217 325
    217 320
    217 316
    217 311
    216 307
    216 302
    215 298
    214 293
    213 288
    212 284
    211 279
    210 274
    208 269
    207 265
    205 260
    204 255
    202 250
    200 245
    198 240
    196 235
    194 230
    191 224
    189 219
    186 214
    184 209
    181 204
    178 198
    175 193
    171 188
    168 182
    165 177
    161 172
    158 166
    154 161
    150 155
    146 150
    142 144
    138 139
    133 133
    129 128
    124 122
    119 116
    115 111
    110 105
    105 99
    99 94
    94 88
    89 82
    83 76
    77 71
    72 65
    66 59
    60 53
    54 47
    47 42
    41 36
    34 30
    28 24
    21 18
    14 12
    7 6
    0 0
    -7 -6
    -14 -12
    -22 -18
    -29 -24
    -37 -30
    -45 -36
    -53 -42
    -61 -48
    -69 -54
    -77 -60
    -86 -66
    -94 -72
    -103 -78
    -112 -84
    -120 -90
    -129 -97
    -138 -103
    -148 -109
    -157 -115
    -166 -121
    -176 -127
    -185 -133
    -195 -139
    -205 -146
    -215 -152
    -225 -158
    -235 -164
    -246 -170
    -256 -176
    -267 -182
    -277 -189
    -288 -195
    -299 -201
    -310 -207
    -321 -213
    -332 -219
    -343 -226
    -355 -232
    -366 -238
    -378 -244
    -390 -250
    -401 -256
    -413 -263
    -425 -269
    -437 -275
    -450 -281
    -462 -287
    -474 -293
    -487 -299
    -500 -306
    -512 -312
    -525 -318
    -538 -324
    -551 -330
    -564 -336
    -578 -342
    -591 -349
    -604 -355
    -618 -361
    -632 -367
    -645 -373
    -659 -379
    -673 -385
    -687 -391
    -701 -397
    -715 -403
    -730 -409
    -744 -415
    -759 -421
    -773 -428
    -788 -434
    -803 -440
    -818 -446
    -833 -452
    -848 -458
    -863 -464
    -878 -470
    -893 -476
    -909 -482
    -924 -488
    -940 -493
    -955 -499
    -971 -505
    -987 -511
    -1003 -517
    -1019 -523
    -1035 -529
    -1051 -535
    -1068 -541
    -1084 -547
    -1100 -553
    -1117 -558
    -1133 -564
    -1150 -570
    -1167 -576
    -1184 -582
    -1201 -588
    -1218 -593
    -1235 -599
    -1252 -605
    -1269 -611
    -1287 -616
    1292 -625
    1275 -619
    1258 -613
    1241 -607
    1224 -601
    1207 -596
    1190 -590
    1173 -584
    1156 -578
    1139 -572
    1123 -566
    1106 -560
    1090 -554
    1073 -549
    1057 -543
    1041 -537
    1025 -531
    1009 -525
    993 -519
    977 -513
    961 -507
    946 -501
    930 -495
    915 -489
    899 -483
    884 -477
    869 -471
    854 -465
    839 -459
    824 -453
    809 -447
    794 -441
    779 -435
    765 -429
    750 -422
    736 -416
    722 -410
    707 -404
    693 -398
    679 -392
    665 -386
    651 -380
    638 -374
    624 -367
    611 -361
    597 -355
    584 -349
    570 -343
    557 -337
    544 -331
    531 -324
    519 -318
    506 -312
    493 -306
    481 -300
    468 -294
    456 -287
    444 -281
    431 -275
    419 -269
    408 -263
    396 -256
    384 -250
    372 -244
    361 -238
    350 -232
    338 -225
    327 -219
    316 -213
    305 -207
    294 -201
    283 -195
    273 -188
    262 -182
    252 -176
    242 -170
    231 -164
    221 -157
    211 -151
    201 -145
    192 -139
    182 -133
    172 -127
    163 -120
    154 -114
    145 -108
    135 -102
    126 -96
    118 -90
    109 -84
    100 -78
    92 -71
    83 -65
    75 -59
    67 -53
    59 -47
    51 -41
    43 -35
    35 -29
    28 -23
    20 -17
    13 -11
    6 -5
    -1 1
    -8 7
    -15 13
    -22 19
    -28 25
    -35 31
    -41 37
    -48 43
    -54 48
    -60 54
    -66 60
    -72 66
    -77 72
    -83 78
    -88 83
    -94 89
    -99 95
    -104 100
    -109 106
    -114 112
    -119 118
    -123 123
    -128 129
    -132 134
    -136 140
    -140 145
    -144 151
    -148 156
    -152 162
    -156 167
    -159 173
    -163 178
    -166 184
    -169 189
    -172 194
    -175 199
    -178 205
    -181 210
    -184 215
    -186 220
    -189 225
    -191 231
    -193 236
    -195 241
    -197 246
    -199 251
    -201 256
    -202 261
    -204 265
    -205 270
    -206 275
    -207 280
    -209 285
    -209 289
    -210 294
    -211 299
    -212 303
    -212 308
    -213 312
    -213 317
    -213 321
    -213 325
    -213 330
    -213 334
    -213 338
    -213 342
    -212 347
    -212 351
    -211 355
    -210 359
    -210 363
    -209 367
    -208 371
    -207 374
    -205 378
    -204 382
    -203 386
    -201 389
    -200 393
    -198 396
    -197 400
    -195 403
    -193 407
    -191 410
    -189 413
    -187 417
    -185 420
    -182 423
    -180 426
    -178 429
    -175 432
    -172 435
    -170 438
    -167 440
    -164 443
    -161 446
    -159 449
    -156 451
    -152 454
    -149 456
    -146 458
    -143 461
    -140 463
    -136 465
    -133 467
    -129 469
    -126 471
    -122 473
    -119 475
    -115 477
    -111 479
    -108 481
    -104 482
    -100 484
    -96 485
    -92 487
    -88 488
    -84 490
    -80 491
    -76 492
    -72 493
    -68 494
    -64 495
    -60 496
    -56 497
    -52 498
    -47 499
    -43 499
    -39 500
    -35 501
    -30 501
    -26 502
    -22 502
    -17 502
    -13 502
    -9 503
    -4 503
    0 503
    4 503
    9 503
    13 502
    17 502
    22 502
    26 502
    30 501
    35 501
    39 500
    43 499
    47 499
    52 498
    56 497
    60 496
    64 495
    68 494
    72 493
    76 492
    80 491
    84 490
    88 488
    92 487
    96 485
    100 484
    104 482
    108 481
    111 479
    115 477
    119 475
    122 473
    126 471
    129 469
    133 467
    136 465
    140 463
    143 461
    146 458
    149 456
    152 454
    156 451
    159 449
    161 446
    164 443
    167 440
    170 438
    172 435
    175 432
    178 429
    180 426
    182 423
    185 420
    187 417
    189 413
    191 410
    193 407
    195 403
    197 400
    198 396
    200 393
    201 389
    203 386
    204 382
    205 378
    207 374
    208 371
    209 367
    210 363
    210 359
    211 355
    212 351
    212 347
    213 342
    213 338
    213 334
    213 330
    213 325
    213 321
    213 317
    213 312
    212 308
    212 303
    211 299
    210 294
    209 289
    209 285
    207 280
    206 275
    205 270
    204 265
    202 261
    201 256
    199 251
    197 246
    195 241
    193 236
    191 231
    189 225
    186 220
    184 215
    181 210
    178 205
    175 199
    172 194
    169 189
    166 184
    163 178
    159 173
    156 167
    152 162
    148 156
    144 151
    140 145
    136 140
    132 134
    128 129
    123 123
    119 118
    114 112
    109 106
    104 100
    99 95
    94 89
    88 83
    83 78
    77 72
    72 66
    66 60
    60 54
    54 48
    48 43
    41 37
    35 31
    28 25
    22 19
    15 13
    8 7
    1 1
    -6 -5
    -13 -11
    -20 -17
    -28 -23
    -35 -29
    -43 -35
    -51 -41
    -59 -47
    -67 -53
    -75 -59
    -83 -65
    -92 -71
    -100 -78
    -109 -84
    -118 -90
    -126 -96
    -135 -102
    -145 -108
    -154 -114
    -163 -120
    -172 -127
    -182 -133
    -192 -139
    -201 -145
    -211 -151
    -221 -157
    -231 -164
    -242 -170
    -252 -176
    -262 -182
    -273 -188
    -283 -195
    -294 -201
    -305 -207
    -316 -213
    -327 -219
    -338 -225
    -350 -232
    -361 -238
    -372 -244
    -384 -250
    -396 -256
    -408 -263
    -419 -269
    -431 -275
    -444 -281
    -456 -287
    -468 -294
    -481 -300
    -493 -306
    -506 -312
    -519 -318
    -531 -324
    -544 -331
    -557 -337
    -570 -343
    -584 -349
    -597 -355
    -611 -361
    -624 -367
    -638 -374
    -651 -380
    -665 -386
    -679 -392
    -693 -398
    -707 -404
    -722 -410
    -736 -416
    -750 -422
    -765 -429
    -779 -435
    -794 -441
    -809 -447
    -824 -453
    -839 -459
    -854 -465
    -869 -471
    -884 -477
    -899 -483
    -915 -489
    -930 -495
    -946 -501
    -961 -507
    -977 -513
    -993 -519
    -1009 -525
    -1025 -531
    -1041 -537
    -1057 -543
    -1073 -549
    -1090 -554
    -1106 -560
    -1123 -566
    -1139 -572
    -1156 -578
    -1173 -584
    -1190 -590
    -1207 -596
    -1224 -601
    -1241 -607
    -1258 -613
    -1275 -619
    -1292 -625
    1298 -633
    1281 -627
    1264 -621
    1246 -615
    1229 -609
    1212 -604
    1195 -598
    1179 -592
    1162 -586
    1145 -580
    1129 -574
    1112 -568
    1096 -562
    1079 -556
    1063 -550
    1047 -544
    1031 -538
    1015 -532
    999 -526
    983 -520
    967 -514
    952 -508
    936 -502
    921 -496
    905 -490
    890 -484
    875 -478
    860 -472
    845 -466
    830 -460
    815 -454
    800 -448
    785 -442
    771 -436
    756 -430
    742 -423
    728 -417
    713 -411
    699 -405
    685 -399
    671 -393
    658 -387
    644 -380
    630 -374
    617 -368
    603 -362
    590 -356
    577 -350
    564 -343
    550 -337
    538 -331
    525 -325
    512 -319
    499 -312
    487 -306
    474 -300
    462 -294
    450 -288
    438 -281
    426 -275
    414 -269
    402 -263
    390 -256
    379 -250
    367 -244
    356 -238
    344 -232
    333 -225
    322 -219
    311 -213
    300 -207
    290 -200
    279 -194
    268 -188
    258 -182
    248 -176
    237 -169
    227 -163
    217 -157
    208 -151
    198 -145
    188 -138
    179 -132
    169 -126
    160 -120
    151 -114
    142 -108
    133 -101
    124 -95
    115 -89
    106 -83
    98 -77
    89 -71
    81 -65
    73 -59
    65 -52
    57 -46
    49 -40
    42 -34
    34 -28
    26 -22
    19 -16
    12 -10
    5 -4
    -2 2
    -9 8
    -16 14
    -23 20
    -29 26
    -35 32
    -42 38
    -48 44
    -54 49
    -60 55
    -66 61
    -71 67
    -77 73
    -83 79
    -88 84
    -93 90
    -98 96
    -103 102
    -108 107
    -113 113
    -118 119
    -122 124
    -126 130
    -131 135
    -135 141
    -139 146
    -143 152
    -147 157
    -150 163
    -154 168
    -157 174
    -161 179
    -164 185
    -167 190
    -170 195
    -173 200
    -176 206
    -178 211
    -181 216
    -183 221
    -186 226
    -188 231
    -190 237
    -192 242
    -194 247
    -196 251
    -197 256
    -199 261
    -200 266
    -201 271
    -203 276
    -204 281
    -205 285
    -206 290
    -206 295
    -207 299
    -208 304
    -208 308
    -208 313
    -209 317
    -209 321
    -209 326
    -209 330
    -209 334
    -208 339
    -208 343
    -208 347
    -207 351
    -206 355
    -206 359
    -205 363
    -204 367
    -203 371
    -202 374
    -200 378
    -199 382
    -198 386
    -196 389
    -195 393
    -193 396
    -191 400
    -189 403
    -188 406
    -186 410
    -184 413
    -181 416
    -179 419
    -177 422
    -175 425
    -172 428
    -170 431
    -167 434
    -164 437
    -162 440
    -159 442
    -156 445
    -153 448
    -150 450
    -147 453
    -144 455
    -141 457
    -137 460
    -134 462
    -131 464
    -127 466
    -124 468
    -121 470
    -117 472
    -113 474
    -110 475
    -106 477
    -102 479
    -99 480
    -95 482
    -91 483
    -87 485
    -83 486
    -79 487
    -75 489
    -71 490
    -67 491
    -63 492
    -59 493
    -55 494
    -51 495
    -47 495
    -42 496
    -38 497
    -34 497
    -30 498
    -26 498
    -21 499
    -17 499
    -13 499
    -9 499
    -4 499
    0 499
    4 499
    9 499
    13 499
    17 499
    21 499
    26 498
    30 498
    34 497
    38 497
    42 496
    47 495
    51 495
    55 494
    59 493
    63 492
    67 491
    71 490
    75 489
    79 487
    83 486
    87 485
    91 483
    95 482
    99 480
    102 479
    106 477
    110 475
    113 474
    117 472
    121 470
    124 468
    127 466
    131 464
    134 462
    137 460
    141 457
    144 455
    147 453
    150 450
    153 448
    156 445
    159 442
    162 440
    164 437
    167 434
    170 431
    172 428
    175 425
    177 422
    179 419
    181 416
    184 413
    186 410
    188 406
    189 403
    191 400
    193 396
    195 393
    196 389
    198 386
    199 382
    200 378
    202 374
    203 371
    204 367
    205 363
    206 359
    206 355
    207 351
    208 347
    208 343
    208 339
    209 334
    209 330
    209 326
    209 321
    209 317
    208 313
    208 308
    208 304
    207 299
    206 295
    206 290
    205 285
    204 281
    203 276
    201 271
    200 266
    199 261
    197 256
    196 251
    194 247
    192 242
    190 237
    188 231
    186 226
    183 221
    181 216
    178 211
    176 206
    173 200
    170 195
    167 190
    164 185
    161 179
    157 174
    154 168
    150 163
    147 157
    143 152
    139 146
    135 141
    131 135
    126 130
    122 124
    118 119
    113 113
    108 107
    103 102
    98 96
    93 90
    88 84
    83 79
    77 73
    71 67
    66 61
    60 55
    54 49
    48 44
    42 38
    35 32
    29 26
    23 20
    16 14
    9 8
    2 2
    -5 -4
    -12 -10
    -19 -16
    -26 -22
    -34 -28
    -42 -34
    -49 -40
    -57 -46
    -65 -52
    -73 -59
    -81 -65
    -89 -71
    -98 -77
    -106 -83
    -115 -89
    -124 -95
    -133 -101
    -142 -108
    -151 -114
    -160 -120
    -169 -126
    -179 -132
    -188 -138
    -198 -145
    -208 -151
    -217 -157
    -227 -163
    -237 -169
    -248 -176
    -258 -182
    -268 -188
    -279 -194
    -290 -200
    -300 -207
    -311 -213
    -322 -219
    -333 -225
    -344 -232
    -356 -238
    -367 -244
    -379 -250
    -390 -256
    -402 -263
    -414 -269
    -426 -275
    -438 -281
    -450 -288
    -462 -294
    -474 -300
    -487 -306
    -499 -312
    -512 -319
    -525 -325
    -538 -331
    -550 -337
    -564 -343
    -577 -350
    -590 -356
    -603 -362
    -617 -368
    -630 -374
    -644 -380
    -658 -387
    -671 -393
    -685 -399
    -699 -405
    -713 -411
    -728 -417
    -742 -423
    -756 -430
    -771 -436
    -785 -442
    -800 -448
    -815 -454
    -830 -460
    -845 -466
    -860 -472
    -875 -478
    -890 -484
    -905 -490
    -921 -496
    -936 -502
    -952 -508
    -967 -514
    -983 -520
    -999 -526
    -1015 -532
    -1031 -538
    -1047 -544
    -1063 -550
    -1079 -556
    -1096 -562
    -1112 -568
    -1129 -574
    -1145 -580
    -1162 -586
    -1179 -592
    -1195 -598
    -1212 -604
    -1229 -609
    -1246 -615
    -1264 -621
    -1281 -627
    -1298 -633
    1304 -641
    1287 -635
    1269 -629
    1252 -624
    1235 -618
    1218 -612
    1201 -606
    1185 -600
    1168 -594
    1151 -588
    1135 -582
    1118 -576
    1102 -570
    1085 -564
    1069 -558
    1053 -552
    1037 -546
    1021 -540
    1005 -534
    989 -528
    973 -522
    958 -516
    942 -510
    927 -504
    911 -498
    896 -492
    881 -486
    866 -480
    851 -473
    836 -467
    821 -461
    806 -455
    791 -449
    777 -443
    762 -437
    748 -431
    734 -424
    720 -418
    705 -412
    691 -406
    678 -400
    664 -394
    650 -387
    636 -381
    623 -375
    609 -369
    596 -363
    583 -356
    570 -350
    557 -344
    544 -338
    531 -331
    518 -325
    506 -319
    493 -313
    481 -307
    468 -300
    456 -294
    444 -288
    432 -282
    420 -275
    408 -269
    396 -263
    385 -257
    373 -250
    362 -244
    351 -238
    339 -232
    328 -225
    317 -219
    307 -213
    296 -207
    285 -200
    275 -194
    264 -188
    254 -182
    244 -175
    234 -169
    224 -163
    214 -157
    204 -150
    194 -144
    185 -138
    175 -132
    166 -126
    157 -119
    148 -113
    139 -107
    130 -101
    121 -95
    113 -89
    104 -82
    96 -76
    87 -70
    79 -64
    71 -58
    63 -52
    55 -46
    48 -40
    40 -33
    33 -27
    25 -21
    18 -15
    11 -9
    4 -3
    -3 3
    -10 9
    -17 15
    -23 21
    -30 27
    -36 33
    -42 38
    -48 44
    -54 50
    -60 56
    -66 62
    -71 68
    -77 74
    -82 79
    -87 85
    -93 91
    -98 97
    -102 102
    -107 108
    -112 114
    -116 119
    -121 125
    -125 131
    -129 136
    -133 142
    -137 147
    -141 153
    -145 158
    -149 164
    -152 169
    -155 175
    -159 180
    -162 185
    -165 191
    -168 196
    -171 201
    -173 206
    -176 212
    -178 217
    -181 222
    -183 227
    -185 232
    -187 237
    -189 242
    -191 247
    -192 252
    -194 257
    -195 262
    -197 267
    -198 272
    -199 276
    -200 281
    -201 286
    -202 290
    -202 295
    -203 300
    -204 304
    -204 309
    -204 313
    -204 317
    -205 322
    -204 326
    -204 330
    -204 335
    -204 339
    -203 343
    -203 347
    -202 351
    -202 355
    -201 359
    -200 363
    -199 367
    -198 371
    -197 374
    -195 378
    -194 382
    -193 385
    -191 389
    -190 392
    -188 396
    -186 399
    -184 403
    -182 406
    -180 409
    -178 412
    -176 416
    -174 419
    -172 422
    -169 425
    -167 428
    -164 430
    -162 433
    -159 436
    -156 439
    -153 441
    -150 444
    -148 446
    -145 449
    -141 451
    -138 454
    -135 456
    -132 458
    -129 460
    -125 462
    -122 464
    -119 466
    -115 468
    -112 470
    -108 472
    -104 474
    -101 475
    -97 477
    -93 478
    -89 480
    -86 481
    -82 483
    -78 484
    -74 485
    -70 486
    -66 487
    -62 488
    -58 489
    -54 490
    -50 491
    -46 492
    -42 493
    -38 493
    -33 494
    -29 494
    -25 495
    -21 495
    -17 495
    -13 496
    -8 496
    -4 496
    0 496
    4 496
    8 496
    13 496
    17 495
    21 495
    25 495
    29 494
    33 494
    38 493
    42 493
    46 492
    50 491
    54 490
    58 489
    62 488
    66 487
    70 486
    74 485
    78 484
    82 483
    86 481
    89 480
    93 478
    97 477
    101 475
    104 474
    108 472
    112 470
    115 468
    119 466
    122 464
    125 462
    129 460
    132 458
    135 456
    138 454
    141 451
    145 449
    148 446
    150 444
    153 441
    156 439
    159 436
    162 433
    164 430
    167 428
    169 425
    172 422
    174 419
    176 416
    178 412
    180 409
    182 406
    184 403
    186 399
    188 396
    190 392
    191 389
    193 385
    194 382
    195 378
    197 374
    198 371
    199 367
    200 363
    201 359
    202 355
    202 351
    203 347
    203 343
    204 339
    204 335
    204 330
    204 326
    205 322
    204 317
    204 313
    204 309
    204 304
    203 300
    202 295
    202 290
    201 286
    200 281
    199 276
    198 272
    197 267
    195 262
    194 257
    192 252
    191 247
    189 242
    187 237
    185 232
    183 227
    181 222
    178 217
    176 212
    173 206
    171 201
    168 196
    165 191
    162 185
    159 180
    155 175
    152 169
    149 164
    145 158
    141 153
    137 147
    133 142
    129 136
    125 131
    121 125
    116 119
    112 114
    107 108
    102 102
    98 97
    93 91
    87 85
    82 79
    77 74
    71 68
    66 62
    60 56
    54 50
    48 44
    42 38
    36 33
    30 27
    23 21
    17 15
    10 9
    3 3
    -4 -3
    -11 -9
    -18 -15
    -25 -21
    -33 -27
    -40 -33
    -48 -40
    -55 -46
    -63 -52
    -71 -58
    -79 -64
    -87 -70
    -96 -76
    -104 -82
    -113 -89
    -121 -95
    -130 -101
    -139 -107
    -148 -113
    -157 -119
    -166 -126
    -175 -132
    -185 -138
    -194 -144
    -204 -150
    -214 -157
    -224 -163
    -234 -169
    -244 -175
    -254 -182
    -264 -188
    -275 -194
    -285 -200
    -296 -207
    -307 -213
    -317 -219
    -328 -225
    -339 -232
    -351 -238
    -362 -244
    -373 -250
    -385 -257
    -396 -263
    -408 -269
    -420 -275
    -432 -282
    -444 -288
    -456 -294
    -468 -300
    -481 -307
    -493 -313
    -506 -319
    -518 -325
    -531 -331
    -544 -338
    -557 -344
    -570 -350
    -583 -356
    -596 -363
    -609 -369
    -623 -375
    -636 -381
    -650 -387
    -664 -394
    -678 -400
    -691 -406
    -705 -412
    -720 -418
    -734 -424
    -748 -431
    -762 -437
    -777 -443
    -791 -449
    -806 -455
    -821 -461
    -836 -467
    -851 -473
    -866 -480
    -881 -486
    -896 -492
    -911 -498
    -927 -504
    -942 -510
    -958 -516
    -973 -522
    -989 -528
    -1005 -534
    -1021 -540
    -1037 -546
    -1053 -552
    -1069 -558
    -1085 -564
    -1102 -570
    -1118 -576
    -1135 -582
    -1151 -588
    -1168 -594
    -1185 -600
    -1201 -606
    -1218 -612
    -1235 -618
    -1252 -624
    -1269 -629
    -1287 -635
    -1304 -641
    1310 -649
    1293 -644
    1275 -638
    1258 -632
    1241 -626
    1224 -620
    1207 -614
    1190 -608
    1174 -602
    1157 -596
    1141 -590
    1124 -584
    1108 -578
    1091 -572
    1075 -566
    1059 -560
    1043 -554
    1027 -548
    1011 -542
    995 -536
    979 -530
    964 -524
    948 -518
    933 -512
    917 -505
    902 -499
    887 -493
    872 -487
    857 -481
    842 -475
    827 -469
    812 -462
    798 -456
    783 -450
    769 -444
    754 -438
    740 -432
    726 -425
    712 -419
    698 -413
    684 -407
    670 -401
    656 -394
    643 -388
    629 -382
    616 -376
    602 -369
    589 -363
    576 -357
    563 -351
    550 -344
    537 -338
    524 -332
    512 -326
    499 -319
    487 -313
    475 -307
    462 -301
    450 -294
    438 -288
    426 -282
    414 -276
    403 -269
    391 -263
    380 -257
    368 -250
    357 -244
    346 -238
    335 -232
    324 -225
    313 -219
    302 -213
    291 -206
    281 -200
    270 -194
    260 -188
    250 -181
    240 -175
    230 -169
    220 -163
    210 -156
    201 -150
    191 -144
    182 -138
    172 -131
    163 -125
    154 -119
    145 -113
    136 -107
    127 -100
    119 -94
    110 -88
    102 -82
    93 -76
    85 -70
    77 -63
    69 -57
    61 -51
    54 -45
    46 -39
    39 -33
    31 -27
    24 -21
    17 -15
    10 -9
    3 -3
    -4 3
    -11 9
    -17 15
    -24 21
    -30 27
    -36 33
    -42 39
    -48 45
    -54 51
    -60 57
    -65 63
    -71 69
    -76 74
    -82 80
    -87 86
    -92 92
    -97 98
    -102 103
    -106 109
    -111 115
    -115 120
    -120 126
    -124 131
    -128 137
    -132 143
    -136 148
    -139 154
    -143 159
    -147 165
    -150 170
    -153 175
    -156 181
    -160 186
    -162 191
    -165 197
    -168 202
    -171 207
    -173 212
    -175 218
    -178 223
    -180 228
    -182 233
    -184 238
    -186 243
    -187 248
    -189 253
    -190 258
    -192 262
    -193 267
    -194 272
    -195 277
    -196 281
    -197 286
    -198 291
    -199 295
    -199 300
    -199 304
    -200 309
    -200 313
    -200 318
    -200 322
    -200 326
    -200 330
    -200 335
    -199 339
    -199 343
    -198 347
    -198 351
    -197 355
    -196 359
    -195 363
    -194 367
    -193 370
    -192 374
    -190 378
    -189 381
    -188 385
    -186 388
    -184 392
    -183 395
    -181 399
    -179 402
    -177 405
    -175 408
    -173 412
    -171 415
    -169 418
    -166 421
    -164 424
    -161 427
    -159 429
    -156 432
    -153 435
    -151 437
    -148 440
    -145 443
    -142 445
    -139 447
    -136 450
    -133 452
    -130 454
    -127 456
    -123 459
    -120 461
    -117 463
    -113 464
    -110 466
    -106 468
    -103 470
    -99 472
    -95 473
    -92 475
    -88 476
    -84 478
    -80 479
    -77 480
    -73 481
    -69 483
    -65 484
    -61 485
    -57 486
    -53 487
    -49 487
    -45 488
    -41 489
    -37 489
    -33 490
    -29 490
    -25 491
    -21 491
    -17 492
    -12 492
    -8 492
    -4 492
    0 492
    4 492
    8 492
    12 492
    17 492
    21 491
    25 491
    29 490
    33 490
    37 489
    41 489
    45 488
    49 487
    53 487
    57 486
    61 485
    65 484
    69 483
    73 481
    77 480
    80 479
    84 478
    88 476
    92 475
    95 473
    99 472
    103 470
    106 468
    110 466
    113 464
    117 463
    120 461
    123 459
    127 456
    130 454
    133 452
    136 450
    139 447
    142 445
    145 443
    148 440
    151 437
    153 435
    156 432
    159 429
    161 427
    164 424
    166 421
    169 418
    171 415
    173 412
    175 408
    177 405
    179 402
    181 399
    183 395
    184 392
    186 388
    188 385
    189 381
    190 378
    192 374
    193 370
    194 367
    195 363
    196 359
    197 355
    198 351
    198 347
    199 343
    199 339
    200 335
    200 330
    200 326
    200 322
    200 318
    200 313
    200 309
    199 304
    199 300
    199 295
    198 291
    197 286
    196 281
    195 277
    194 272
    193 267
    192 262
    190 258
    189 253
    187 248
    186 243
    184 238
    182 233
    180 228
    178 223
    175 218
    173 212
    171 207
    168 202
    165 197
    162 191
    160 186
    156 181
    153 175
    150 170
    147 165
    143 159
    139 154
    136 148
    132 143
    128 137
    124 131
    120 126
    115 120
    111 115
    106 109
    102 103
    97 98
    92 92
    87 86
    82 80
    76 74
    71 69
    65 63
    60 57
    54 51
    48 45
    42 39
    36 33
    30 27
    24 21
    17 15
    11 9
    4 3
    -3 -3
    -10 -9
    -17 -15
    -24 -21
    -31 -27
    -39 -33
    -46 -39
    -54 -45
    -61 -51
    -69 -57
    -77 -63
    -85 -70
    -93 -76
    -102 -82
    -110 -88
    -119 -94
    -127 -100
    -136 -107
    -145 -113
    -154 -119
    -163 -125
    -172 -131
    -182 -138
    -191 -144
    -201 -150
    -210 -156
    -220 -163
    -230 -169
    -240 -175
    -250 -181
    -260 -188
    -270 -194
    -281 -200
    -291 -206
    -302 -213
    -313 -219
    -324 -225
    -335 -232
    -346 -238
    -357 -244
    -368 -250
    -380 -257
    -391 -263
    -403 -269
    -414 -276
    -426 -282
    -438 -288
    -450 -294
    -462 -301
    -475 -307
    -487 -313
    -499 -319
    -512 -326
    -524 -332
    -537 -338
    -550 -344
    -563 -351
    -576 -357
    -589 -363
    -602 -369
    -616 -376
    -629 -382
    -643 -388
    -656 -394
    -670 -401
    -684 -407
    -698 -413
    -712 -419
    -726 -425
    -740 -432
    -754 -438
    -769 -444
    -783 -450
    -798 -456
    -812 -462
    -827 -469
    -842 -475
    -857 -481
    -872 -487
    -887 -493
    -902 -499
    -917 -505
    -933 -512
    -948 -518
    -964 -524
    -979 -530
    -995 -536
    -1011 -542
    -1027 -548
    -1043 -554
    -1059 -560
    -1075 -566
    -1091 -572
    -1108 -578
    -1124 -584
    -1141 -590
    -1157 -596
    -1174 -602
    -1190 -608
    -1207 -614
    -1224 -620
    -1241 -626
    -1258 -632
    -1275 -638
    -1293 -644
    -1310 -649
    1316 -658
    1298 -652
    1281 -646
    1264 -640
    1247 -634
    1230 -628
    1213 -622
    1196 -616
    1180 -610
    1163 -604
    1147 -598
    1130 -592
    1114 -586
    1097 -580
    1081 -574
    1065 -568
    1049 -562
    1033 -556
    1017 -550
    1001 -544
    986 -538
    970 -531
    954 -525
    939 -519
    924 -513
    908 -507
    893 -501
    878 -495
    863 -488
    848 -482
    833 -476
    818 -470
    804 -464
    789 -458
    775 -451
    760 -445
    746 -439
    732 -433
    718 -426
    704 -420
    690 -414
    676 -408
    662 -401
    649 -395
    635 -389
    622 -383
    609 -376
    595 -370
    582 -364
    569 -358
    556 -351
    543 -345
    531 -339
    518 -332
    506 -326
    493 -320
    481 -314
    469 -307
    456 -301
    444 -295
    433 -288
    421 -282
    409 -276
    397 -269
    386 -263
    375 -257
    363 -250
    352 -244
    341 -238
    330 -232
    319 -225
    308 -219
    298 -213
    287 -206
    277 -200
    266 -194
    256 -187
    246 -181
    236 -175
    226 -169
    216 -162
    207 -156
    197 -150
    188 -144
    179 -137
    169 -131
    160 -125
    151 -119
    142 -112
    134 -106
    125 -100
    116 -94
    108 -88
    100 -81
    91 -75
    83 -69
    75 -63
    68 -57
    60 -51
    52 -44
    45 -38
    37 -32
    30 -26
    23 -20
    16 -14
    9 -8
    2 -2
    -5 4
    -11 10
    -18 16
    -24 22
    -30 28
    -36 34
    -42 40
    -48 46
    -54 52
    -60 58
    -65 64
    -71 69
    -76 75
    -81 81
    -86 87
    -91 93
    -96 98
    -100 104
    -105 110
    -110 115
    -114 121
    -118 127
    -122 132
    -126 138
    -130 143
    -134 149
    -138 154
    -141 160
    -145 165
    -148 171
    -151 176
    -154 181
    -157 187
    -160 192
    -163 197
    -165 203
    -168 208
    -170 213
    -173 218
    -175 223
    -177 228
    -179 233
    -181 238
    -182 243
    -184 248
    -186 253
    -187 258
    -188 263
    -190 268
    -191 272
    -192 277
    -193 282
    -193 286
    -194 291
    -195 296
    -195 300
    -195 304
    -196 309
    -196 313
    -196 318
    -196 322
    -196 326
    -195 330
    -195 335
    -195 339
    -194 343
    -194 347
    -193 351
    -192 355
    -191 359
    -190 362
    -189 366
    -188 370
    -187 374
    -185 377
    -184 381
    -183 384
    -181 388
    -179 391
    -178 395
    -176 398
    -174 401
    -172 404
    -170 408
    -168 411
    -166 414
    -163 417
    -161 420
    -158 423
    -156 425
    -153 428
    -151 431
    -148 433
    -145 436
    -143 439
    -140 441
    -137 443
    -134 446
    -131 448
    -128 450
    -124 453
    -121 455
    -118 457
    -115 459
    -111 461
    -108 462
    -104 464
    -101 466
    -97 468
    -94 469
    -90 471
    -87 472
    -83 474
    -79 475
    -75 476
    -72 478
    -68 479
    -64 480
    -60 481
    -56 482
    -52 483
    -48 483
    -44 484
    -40 485
    -36 486
    -32 486
    -28 487
    -24 487
    -20 487
    -16 488
    -12 488
    -8 488
    -4 488
    0 488
    4 488
    8 488
    12 488
    16 488
    20 487
    24 487
    28 487
    32 486
    36 486
    40 485
    44 484
    48 483
    52 483
    56 482
    60 481
    64 480
    68 479
    72 478
    75 476
    79 475
    83 474
    87 472
    90 471
    94 469
    97 468
    101 466
    104 464
    108 462
    111 461
    115 459
    118 457
    121 455
    124 453
    128 450
    131 448
    134 446
    137 443
    140 441
    143 439
    145 436
    148 433
    151 431
    153 428
    156 425
    158 423
    161 420
    163 417
    166 414
    168 411
    170 408
    172 404
    174 401
    176 398
    178 395
    179 391
    181 388
    183 384
    184 381
    185 377
    187 374
    188 370
    189 366
    190 362
    191 359
    192 355
    193 351
    194 347
    194 343
    195 339
    195 335
    195 330
    196 326
    196 322
    196 318
    196 313
    196 309
    195 304
    195 300
    195 296
    194 291
    193 286
    193 282
    192 277
    191 272
    190 268
    188 263
    187 258
    186 253
    184 248
    182 243
    181 238
    179 233
    177 228
    175 223
    173 218
    170 213
    168 208
    165 203
    163 197
    160 192
    157 187
    154 181
    151 176
    148 171
    145 165
    141 160
    138 154
    134 149
    130 143
    126 138
    122 132
    118 127
    114 121
    110 115
    105 110
    100 104
    96 98
    91 93
    86 87
    81 81
    76 75
    71 69
    65 64
    60 58
    54 52
    48 46
    42 40
    36 34
    30 28
    24 22
    18 16
    11 10
    5 4
    -2 -2
    -9 -8
    -16 -14
    -23 -20
    -30 -26
    -37 -32
    -45 -38
    -52 -44
    -60 -51
    -68 -57
    -75 -63
    -83 -69
    -91 -75
    -100 -81
    -108 -88
    -116 -94
    -125 -100
    -134 -106
    -142 -112
    -151 -119
    -160 -125
    -169 -131
    -179 -137
    -188 -144
    -197 -150
    -207 -156
    -216 -162
    -226 -169
    -236 -175
    -246 -181
    -256 -187
    -266 -194
    -277 -200
    -287 -206
    -298 -213
    -308 -219
    -319 -225
    -330 -232
    -341 -238
    -352 -244
    -363 -250
    -375 -257
    -386 -263
    -397 -269
    -409 -276
    -421 -282
    -433 -288
    -444 -295
    -456 -301
    -469 -307
    -481 -314
    -493 -320
    -506 -326
    -518 -332
    -531 -339
    -543 -345
    -556 -351
    -569 -358
    -582 -364
    -595 -370
    -609 -376
    -622 -383
    -635 -389
    -649 -395
    -662 -401
    -676 -408
    -690 -414
    -704 -420
    -718 -426
    -732 -433
    -746 -439
    -760 -445
    -775 -451
    -789 -458
    -804 -464
    -818 -470
    -833 -476
    -848 -482
    -863 -488
    -878 -495
    -893 -501
    -908 -507
    -924 -513
    -939 -519
    -954 -525
    -970 -531
    -986 -538
    -1001 -544
    -1017 -550
    -1033 -556
    -1049 -562
    -1065 -568
    -1081 -574
    -1097 -580
    -1114 -586
    -1130 -592
    -1147 -598
    -1163 -604
    -1180 -610
    -1196 -616
    -1213 -622
    -1230 -628
    -1247 -634
    -1264 -640
    -1281 -646
    -1298 -652
    -1316 -658
    1322 -666
    1304 -660
    1287 -654
    1270 -648
    1253 -642
    1236 -636
    1219 -630
    1202 -624
    1186 -618
    1169 -612
    1153 -606
    1136 -600
    1120 -594
    1103 -588
    1087 -582
    1071 -576
    1055 -570
    1039 -564
    1023 -558
    1007 -552
    992 -545
    976 -539
    961 -533
    945 -527
    930 -521
    914 -515
    899 -508
    884 -502
    869 -496
    854 -490
    839 -484
    825 -477
    810 -471
    795 -465
    781 -459
    767 -453
    752 -446
    738 -440
    724 -434
    710 -427
    696 -421
    682 -415
    669 -409
    655 -402
    642 -396
    628 -390
    615 -383
    602 -377
    589 -371
    575 -365
    563 -358
    550 -352
    537 -346
    524 -339
    512 -333
    499 -327
    487 -320
    475 -314
    463 -308
    451 -301
    439 -295
    427 -289
    415 -282
    404 -276
    392 -270
    381 -263
    370 -257
    358 -251
    347 -244
    336 -238
    325 -232
    315 -225
    304 -219
    294 -213
    283 -206
    273 -200
    263 -194
    252 -187
    242 -181
    233 -175
    223 -168
    213 -162
    204 -156
    194 -150
    185 -143
    176 -137
    166 -131
    157 -125
    149 -118
    140 -112
    131 -106
    123 -100
    114 -93
    106 -87
    98 -81
    90 -75
    82 -69
    74 -62
    66 -56
    58 -50
    51 -44
    43 -38
    36 -32
    29 -26
    22 -19
    15 -13
    8 -7
    1 -1
    -5 5
    -12 11
    -18 17
    -24 23
    -30 29
    -36 35
    -42 41
    -48 47
    -54 52
    -59 58
    -65 64
    -70 70
    -75 76
    -80 82
    -85 87
    -90 93
    -95 99
    -99 105
    -104 110
    -108 116
    -113 122
    -117 127
    -121 133
    -125 138
    -128 144
    -132 149
    -136 155
    -139 160
    -142 166
    -146 171
    -149 177
    -152 182
    -155 187
    -158 193
    -160 198
    -163 203
    -165 208
    -167 213
    -170 218
    -172 224
    -174 229
    -176 234
    -177 239
    -179 244
    -181 248
    -182 253
    -184 258
    -185 263
    -186 268
    -187 273
    -188 277
    -189 282
    -189 286
    -190 291
    -191 296
    -191 300
    -191 304
    -191 309
    -192 313
    -192 318
    -191 322
    -191 326
    -191 330
    -191 334
    -190 338
    -190 342
    -189 346
    -188 350
    -187 354
    -186 358
    -185 362
    -184 366
    -183 369
    -182 373
    -181 377
    -179 380
    -178 384
    -176 387
    -174 390
    -172 394
    -171 397
    -169 400
    -167 403
    -165 407
    -162 410
    -160 413
    -158 416
    -156 418
    -153 421
    -151 424
    -148 427
    -145 429
    -143 432
    -140 434
    -137 437
    -134 439
    -131 442
    -128 444
    -125 446
    -122 448
    -119 451
    -116 453
    -113 455
    -109 457
    -106 458
    -103 460
    -99 462
    -96 464
    -92 465
    -89 467
    -85 468
    -82 470
    -78 471
    -74 472
    -70 474
    -67 475
    -63 476
    -59 477
    -55 478
    -51 479
    -48 479
    -44 480
    -40 481
    -36 482
    -32 482
    -28 483
    -24 483
    -20 483
    -16 484
    -12 484
    -8 484
    -4 484
    0 484
    4 484
    8 484
    12 484
    16 484
    20 483
    24 483
    28 483
    32 482
    36 482
    40 481
    44 480
    48 479
    51 479
    55 478
    59 477
    63 476
    67 475
    70 474
    74 472
    78 471
    82 470
    85 468
    89 467
    92 465
    96 464
    99 462
    103 460
    106 458
    109 457
    113 455
    116 453
    119 451
    122 448
    125 446
    128 444
    131 442
    134 439
    137 437
    140 434
    143 432
    145 429
    148 427
    151 424
    153 421
    156 418
    158 416
    160 413
    162 410
    165 407
    167 403
    169 400
    171 397
    172 394
    174 390
    176 387
    178 384
    179 380
    181 377
    182 373
    183 369
    184 366
    185 362
    186 358
    187 354
    188 350
    189 346
    190 342
    190 338
    191 334
    191 330
    191 326
    191 322
    192 318
    192 313
    191 309
    191 304
    191 300
    191 296
    190 291
    189 286
    189 282
    188 277
    187 273
    186 268
    185 263
    184 258
    182 253
    181 248
    179 244
    177 239
    176 234
    174 229
    172 224
    170 218
    167 213
    165 208
    163 203
    160 198
    158 193
    155 187
    152 182
    149 177
    146 171
    142 166
    139 160
    136 155
    132 149
    128 144
    125 138
    121 133
    117 127
    113 122
    108 116
    104 110
    99 105
    95 99
    90 93
    85 87
    80 82
    75 76
    70 70
    65 64
    59 58
    54 52
    48 47
    42 41
    36 35
    30 29
    24 23
    18 17
    12 11
    5 5
    -1 -1
    -8 -7
    -15 -13
    -22 -19
    -29 -26
    -36 -32
    -43 -38
    -51 -44
    -58 -50
    -66 -56
    -74 -62
    -82 -69
    -90 -75
    -98 -81
    -106 -87
    -114 -93
    -123 -100
    -131 -106
    -140 -112
    -149 -118
    -157 -125
    -166 -131
    -176 -137
    -185 -143
    -194 -150
    -204 -156
    -213 -162
    -223 -168
    -233 -175
    -242 -181
    -252 -187
    -263 -194
    -273 -200
    -283 -206
    -294 -213
    -304 -219
    -315 -225
    -325 -232
    -336 -238
    -347 -244
    -358 -251
    -370 -257
    -381 -263
    -392 -270
    -404 -276
    -415 -282
    -427 -289
    -439 -295
    -451 -301
    -463 -308
    -475 -314
    -487 -320
    -499 -327
    -512 -333
    -524 -339
    -537 -346
    -550 -352
    -563 -358
    -575 -365
    -589 -371
    -602 -377
    -615 -383
    -628 -390
    -642 -396
    -655 -402
    -669 -409
    -682 -415
    -696 -421
    -710 -427
    -724 -434
    -738 -440
    -752 -446
    -767 -453
    -781 -459
    -795 -465
    -810 -471
    -825 -477
    -839 -484
    -854 -490
    -869 -496
    -884 -502
    -899 -508
    -914 -515
    -930 -521
    -945 -527
    -961 -533
    -976 -539
    -992 -545
    -1007 -552
    -1023 -558
    -1039 -564
    -1055 -570
    -1071 -576
    -1087 -582
    -1103 -588
    -1120 -594
    -1136 -600
    -1153 -606
    -1169 -612
    -1186 -618
    -1202 -624
    -1219 -630
    -1236 -636
    -1253 -642
    -1270 -648
    -1287 -654
    -1304 -660
    -1322 -666
    1328 -675
    1310 -669
    1293 -663
    1276 -657
    1259 -651
    1242 -645
    1225 -639
    1209 -633
    1192 -627
    1175 -621
    1159 -615
    1142 -608
    1126 -602
    1110 -596
    1093 -590
    1077 -584
    1061 -578
    1045 -572
    1029 -566
    1014 -559
    998 -553
    982 -547
    967 -541
    951 -535
    936 -529
    921 -522
    905 -516
    890 -510
    875 -504
    860 -498
    846 -491
    831 -485
    816 -479
    802 -473
    787 -466
    773 -460
    759 -454
    744 -447
    730 -441
    716 -435
    703 -429
    689 -422
    675 -416
    661 -410
    648 -403
    634 -397
    621 -391
    608 -384
    595 -378
    582 -372
    569 -365
    556 -359
    543 -353
    531 -346
    518 -340
    506 -334
    493 -327
    481 -321
    469 -314
    457 -308
    445 -302
    433 -295
    422 -289
    410 -283
    399 -276
    387 -270
    376 -264
    365 -257
    354 -251
    343 -244
    332 -238
    321 -232
    310 -225
    300 -219
    289 -213
    279 -206
    269 -200
    259 -194
    249 -187
    239 -181
    229 -175
    219 -168
    210 -162
    200 -156
    191 -149
    182 -143
    173 -137
    164 -131
    155 -124
    146 -118
    137 -112
    129 -105
    120 -99
    112 -93
    104 -87
    96 -81
    88 -74
    80 -68
    72 -62
    64 -56
    57 -50
    50 -43
    42 -37
    35 -31
    28 -25
    21 -19
    14 -13
    7 -7
    1 -1
    -6 5
    -12 11
    -18 17
    -24 23
    -30 29
    -36 35
    -42 41
    -48 47
    -53 53
    -59 59
    -64 65
    -69 71
    -74 76
    -79 82
    -84 88
    -89 94
    -94 99
    -98 105
    -103 111
    -107 116
    -111 122
    -115 128
    -119 133
    -123 139
    -127 144
    -130 150
    -134 155
    -137 161
    -140 166
    -143 172
    -147 177
    -149 182
    -152 188
    -155 193
    -158 198
    -160 203
    -162 208
    -165 214
    -167 219
    -169 224
    -171 229
    -173 234
    -174 239
    -176 244
    -177 249
    -179 253
    -180 258
    -181 263
    -182 268
    -183 273
    -184 277
    -185 282
    -185 286
    -186 291
    -186 295
    -187 300
    -187 304
    -187 309
    -187 313
    -187 317
    -187 321
    -187 326
    -187 330
    -186 334
    -186 338
    -185 342
    -184 346
    -184 350
    -183 354
    -182 357
    -181 361
    -179 365
    -178 369
    -177 372
    -176 376
    -174 379
    -173 383
    -171 386
    -169 389
    -167 393
    -166 396
    -164 399
    -162 402
    -159 405
    -157 408
    -155 411
    -153 414
    -150 417
    -148 420
    -145 422
    -143 425
    -140 428
    -138 430
    -135 433
    -132 435
    -129 438
    -126 440
    -123 442
    -120 444
    -117 446
    -114 448
    -111 450
    -108 452
    -104 454
    -101 456
    -98 458
    -94 459
    -91 461
    -87 463
    -84 464
    -80 465
    -77 467
    -73 468
    -69 469
    -66 471
    -62 472
    -58 473
    -54 474
    -51 475
    -47 475
    -43 476
    -39 477
    -35 477
    -31 478
    -27 479
    -24 479
    -20 479
    -16 480
    -12 480
    -8 480
    -4 480
    0 480
    4 480
    8 480
    12 480
    16 480
    20 479
    24 479
    27 479
    31 478
    35 477
    39 477
    43 476
    47 475
    51 475
    54 474
    58 473
    62 472
    66 471
    69 469
    73 468
    77 467
    80 465
    84 464
    87 463
    91 461
    94 459
    98 458
    101 456
    104 454
    108 452
    111 450
    114 448
    117 446
    120 444
    123 442
    126 440
    129 438
    132 435
    135 433
    138 430
    140 428
    143 425
    145 422
    148 420
    150 417
    153 414
    155 411
    157 408
    159 405
    162 402
    164 399
    166 396
    167 393
    169 389
    171 386
    173 383
    174 379
    176 376
    177 372
    178 369
    179 365
    181 361
    182 357
    183 354
    184 350
    184 346
    185 342
    186 338
    186 334
    187 330
    187 326
    187 321
    187 317
    187 313
    187 309
    187 304
    187 300
    186 295
    186 291
    185 286
    185 282
    184 277
    183 273
    182 268
    181 263
    180 258
    179 253
    177 249
    176 244
    174 239
    173 234
    171 229
    169 224
    167 219
    165 214
    162 208
    160 203
    158 198
    155 193
    152 188
    149 182
    147 177
    143 172
    140 166
    137 161
    134 155
    130 150
    127 144
    123 139
    119 133
    115 128
    111 122
    107 116
    103 111
    98 105
    94 99
    89 94
    84 88
    79 82
    74 76
    69 71
    64 65
    59 59
    53 53
    48 47
    42 41
    36 35
    30 29
    24 23
    18 17
    12 11
    6 5
    -1 -1
    -7 -7
    -14 -13
    -21 -19
    -28 -25
    -35 -31
    -42 -37
    -50 -43
    -57 -50
    -64 -56
    -72 -62
    -80 -68
    -88 -74
    -96 -81
    -104 -87
    -112 -93
    -120 -99
    -129 -105
    -137 -112
    -146 -118
    -155 -124
    -164 -131
    -173 -137
    -182 -143
    -191 -149
    -200 -156
    -210 -162
    -219 -168
    -229 -175
    -239 -181
    -249 -187
    -259 -194
    -269 -200
    -279 -206
    -289 -213
    -300 -219
    -310 -225
    -321 -232
    -332 -238
    -343 -244
    -354 -251
    -365 -257
    -376 -264
    -387 -270
    -399 -276
    -410 -283
    -422 -289
    -433 -295
    -445 -302
    -457 -308
    -469 -314
    -481 -321
    -493 -327
    -506 -334
    -518 -340
    -531 -346
    -543 -353
    -556 -359
    -569 -365
    -582 -372
    -595 -378
    -608 -384
    -621 -391
    -634 -397
    -648 -403
    -661 -410
    -675 -416
    -689 -422
    -703 -429
    -716 -435
    -730 -441
    -744 -447
    -759 -454
    -773 -460
    -787 -466
    -802 -473
    -816 -479
    -831 -485
    -846 -491
    -860 -498
    -875 -504
    -890 -510
    -905 -516
    -921 -522
    -936 -529
    -951 -535
    -967 -541
    -982 -547
    -998 -553
    -1014 -559
    -1029 -566
    -1045 -572
    -1061 -578
    -1077 -584
    -1093 -590
    -1110 -596
    -1126 -602
    -1142 -608
    -1159 -615
    -1175 -621
    -1192 -627
    -1209 -633
    -1225 -639
    -1242 -645
    -1259 -651
    -1276 -657
    -1293 -663
    -1310 -669
    -1328 -675
    1334 -684
    1316 -677
    1299 -671
    1282 -665
    1265 -659
    1248 -653
    1231 -647
    1215 -641
    1198 -635
    1181 -629
    1165 -623
    1148 -617
    1132 -611
    1116 -605
    1099 -598
    1083 -592
    1067 -586
    1051 -580
    1035 -574
    1020 -568
    1004 -561
    988 -555
    973 -549
    957 -543
    942 -536
    927 -530
    912 -524
    897 -518
    882 -511
    867 -505
    852 -499
    837 -493
    823 -486
    808 -480
    794 -474
    779 -468
    765 -461
    751 -455
    737 -449
    723 -442
    709 -436
    695 -430
    681 -423
    668 -417
    654 -411
    641 -404
    628 -398
    614 -391
    601 -385
    588 -379
    575 -372
    562 -366
    550 -360
    537 -353
    525 -347
    512 -341
    500 -334
    488 -328
    475 -321
    463 -315
    452 -309
    440 -302
    428 -296
    416 -289
    405 -283
    394 -277
    382 -270
    371 -264
    360 -257
    349 -251
    338 -245
    327 -238
    317 -232
    306 -226
    296 -219
    285 -213
    275 -206
    265 -200
    255 -194
    245 -187
    235 -181
    226 -175
    216 -168
    207 -162
    197 -156
    188 -149
    179 -143
    170 -137
    161 -130
    152 -124
    144 -118
    135 -112
    127 -105
    118 -99
    110 -93
    102 -87
    94 -80
    86 -74
    78 -68
    71 -62
    63 -55
    56 -49
    48 -43
    41 -37
    34 -31
    27 -25
    20 -19
    14 -13
    7 -6
    0 -0
    -6 6
    -12 12
    -18 18
    -24 24
    -30 30
    -36 36
    -42 42
    -47 47
    -53 53
    -58 59
    -64 65
    -69 71
    -74 77
    -79 83
    -83 88
    -88 94
    -92 100
    -97 106
    -101 111
    -105 117
    -110 122
    -113 128
    -117 134
    -121 139
    -125 145
    -128 150
    -132 156
    -135 161
    -138 167
    -141 172
    -144 177
    -147 183
    -150 188
    -152 193
    -155 198
    -157 204
    -159 209
    -162 214
    -164 219
    -166 224
    -168 229
    -169 234
    -171 239
    -172 244
    -174 249
    -175 253
    -176 258
    -177 263
    -178 268
    -179 272
    -180 277
    -181 282
    -181 286
    -182 291
    -182 295
    -183 300
    -183 304
    -183 308
    -183 313
    -183 317
    -183 321
    -182 325
    -182 329
    -182 333
    -181 337
    -180 341
    -180 345
    -179 349
    -178 353
    -177 357
    -176 360
    -175 364
    -173 368
    -172 371
    -171 375
    -169 378
    -168 382
    -166 385
    -164 388
    -162 391
    -160 395
    -158 398
    -156 401
    -154 404
    -152 407
    -150 410
    -148 413
    -145 415
    -143 418
    -140 421
    -138 423
    -135 426
    -132 428
    -130 431
    -127 433
    -124 435
    -121 438
    -118 440
    -115 442
    -112 444
    -109 446
    -106 448
    -102 450
    -99 452
    -96 453
    -92 455
    -89 457
    -86 458
    -82 460
    -79 461
    -75 463
    -72 464
    -68 465
    -64 466
    -61 467
    -57 468
    -53 469
    -50 470
    -46 471
    -42 472
    -38 473
    -35 473
    -31 474
    -27 474
    -23 475
    -19 475
    -15 475
    -12 476
    -8 476
    -4 476
    0 476
    4 476
    8 476
    12 476
    15 475
    19 475
    23 475
    27 474
    31 474
    35 473
    38 473
    42 472
    46 471
    50 470
    53 469
    57 468
    61 467
    64 466
    68 465
    72 464
    75 463
    79 461
    82 460
    86 458
    89 457
    92 455
    96 453
    99 452
    102 450
    106 448
    109 446
    112 444
    115 442
    118 440
    121 438
    124 435
    127 433
    130 431
    132 428
    135 426
    138 423
    140 421
    143 418
    145 415
    148 413
    150 410
    152 407
    154 404
    156 401
    158 398
    160 395
    162 391
    164 388
    166 385
    168 382
    169 378
    171 375
    172 371
    173 368
    175 364
    176 360
    177 357
    178 353
    179 349
    180 345
    180 341
    181 337
    182 333
    182 329
    182 325
    183 321
    183 317
    183 313
    183 308
    183 304
    183 300
    182 295
    182 291
    181 286
    181 282
    180 277
    179 272
    178 268
    177 263
    176 258
    175 253
    174 249
    172 244
    171 239
    169 234
    168 229
    166 224
    164 219
    162 214
    159 209
    157 204
    155 198
    152 193
    150 188
    147 183
    144 177
    141 172
    138 167
    135 161
    132 156
    128 150
    125 145
    121 139
    117 134
    113 128
    110 122
    105 117
    101 111
    97 106
    92 100
    88 94
    83 88
    79 83
    74 77
    69 71
    64 65
    58 59
    53 53
    47 47
    42 42
    36 36
    30 30
    24 24
    18 18
    12 12
    6 6
    -0 -0
    -7 -6
    -14 -13
    -20 -19
    -27 -25
    -34 -31
    -41 -37
    -48 -43
    -56 -49
    -63 -55
    -71 -62
    -78 -68
    -86 -74
    -94 -80
    -102 -87
    -110 -93
    -118 -99
    -127 -105
    -135 -112
    -144 -118
    -152 -124
    -161 -130
    -170 -137
    -179 -143
    -188 -149
    -197 -156
    -207 -162
    -216 -168
    -226 -175
    -235 -181
    -245 -187
    -255 -194
    -265 -200
    -275 -206
    -285 -213
    -296 -219
    -306 -226
    -317 -232
    -327 -238
    -338 -245
    -349 -251
    -360 -257
    -371 -264
    -382 -270
    -394 -277
    -405 -283
    -416 -289
    -428 -296
    -440 -302
    -452 -309
    -463 -315
    -475 -321
    -488 -328
    -500 -334
    -512 -341
    -525 -347
    -537 -353
    -550 -360
    -562 -366
    -575 -372
    -588 -379
    -601 -385
    -614 -391
    -628 -398
    -641 -404
    -654 -411
    -668 -417
    -681 -423
    -695 -430
    -709 -436
    -723 -442
    -737 -449
    -751 -455
    -765 -461
    -779 -468
    -794 -474
    -808 -480
    -823 -486
    -837 -493
    -852 -499
    -867 -505
    -882 -511
    -897 -518
    -912 -524
    -927 -530
    -942 -536
    -957 -543
    -973 -549
    -988 -555
    -1004 -561
    -1020 -568
    -1035 -574
    -1051 -580
    -1067 -586
    -1083 -592
    -1099 -598
    -1116 -605
    -1132 -611
    -1148 -617
    -1165 -623
    -1181 -629
    -1198 -635
    -1215 -641
    -1231 -647
    -1248 -653
    -1265 -659
    -1282 -665
    -1299 -671
    -1316 -677
    -1334 -684
    1340 -692
    1322 -686
    1305 -680
    1288 -674
    1271 -668
    1254 -662
    1237 -656
    1221 -650
    1204 -644
    1187 -637
    1171 -631
    1154 -625
    1138 -619
    1122 -613
    1106 -607
    1089 -600
    1073 -594
    1058 -588
    1042 -582
    1026 -576
    1010 -569
    995 -563
    979 -557
    964 -551
    948 -544
    933 -538
    918 -532
    903 -526
    888 -519
    873 -513
    858 -507
    843 -500
    829 -494
    814 -488
    800 -481
    786 -475
    771 -469
    757 -462
    743 -456
    729 -450
    715 -443
    701 -437
    688 -431
    674 -424
    661 -418
    647 -412
    634 -405
    621 -399
    608 -392
    595 -386
    582 -380
    569 -373
    556 -367
    543 -360
    531 -354
    519 -348
    506 -341
    494 -335
    482 -328
    470 -322
    458 -315
    446 -309
    434 -303
    423 -296
    411 -290
    400 -283
    389 -277
    377 -271
    366 -264
    355 -258
    345 -251
    334 -245
    323 -239
    313 -232
    302 -226
    292 -219
    282 -213
    271 -207
    261 -200
    252 -194
    242 -187
    232 -181
    223 -175
    213 -168
    204 -162
    194 -156
    185 -149
    176 -143
    167 -137
    159 -130
    150 -124
    141 -118
    133 -111
    125 -105
    116 -99
    108 -93
    100 -86
    92 -80
    85 -74
    77 -68
    69 -61
    62 -55
    55 -49
    47 -43
    40 -37
    33 -31
    26 -24
    20 -18
    13 -12
    6 -6
    0 -0
    -6 6
    -12 12
    -18 18
    -24 24
    -30 30
    -36 36
    -42 42
    -47 48
    -52 54
    -58 60
    -63 65
    -68 71
    -73 77
    -78 83
    -82 89
    -87 94
    -91 100
    -96 106
    -100 111
    -104 117
    -108 123
    -112 128
    -116 134
    -119 139
    -123 145
    -126 150
    -129 156
    -133 161
    -136 167
    -139 172
    -142 177
    -144 183
    -147 188
    -150 193
    -152 198
    -154 204
    -157 209
    -159 214
    -161 219
    -163 224
    -164 229
    -166 234
    -168 239
    -169 244
    -170 249
    -172 253
    -173 258
    -174 263
    -175 267
    -176 272
    -176 277
    -177 281
    -177 286
    -178 290
    -178 295
    -179 299
    -179 303
    -179 308
    -179 312
    -179 316
    -178 320
    -178 324
    -178 329
    -177 333
    -176 337
    -176 340
    -175 344
    -174 348
    -173 352
    -172 356
    -171 359
    -170 363
    -168 367
    -167 370
    -166 373
    -164 377
    -163 380
    -161 384
    -159 387
    -157 390
    -155 393
    -153 396
    -151 399
    -149 402
    -147 405
    -145 408
    -142 411
    -140 413
    -138 416
    -135 419
    -133 421
    -130 424
    -127 426
    -124 429
    -122 431
    -119 433
    -116 435
    -113 437
    -110 440
    -107 442
    -104 443
    -101 445
    -97 447
    -94 449
    -91 451
    -88 452
    -84 454
    -81 455
    -77 457
    -74 458
    -70 459
    -67 461
    -63 462
    -60 463
    -56 464
    -52 465
    -49 466
    -45 467
    -41 467
    -38 468
    -34 469
    -30 469
    -27 470
    -23 470
    -19 471
    -15 471
    -11 471
    -8 471
    -4 471
    0 471
    4 471
    8 471
    11 471
    15 471
    19 471
    23 470
    27 470
    30 469
    34 469
    38 468
    41 467
    45 467
    49 466
    52 465
    56 464
    60 463
    63 462
    67 461
    70 459
    74 458
    77 457
    81 455
    84 454
    88 452
    91 451
    94 449
    97 447
    101 445
    104 443
    107 442
    110 440
    113 437
    116 435
    119 433
    122 431
    124 429
    127 426
    130 424
    133 421
    135 419
    138 416
    140 413
    142 411
    145 408
    147 405
    149 402
    151 399
    153 396
    155 393
    157 390
    159 387
    161 384
    163 380
    164 377
    166 373
    167 370
    168 367
    170 363
    171 359
    172 356
    173 352
    174 348
    175 344
    176 340
    176 337
    177 333
    178 329
    178 324
    178 320
    179 316
    179 312
    179 308
    179 303
    179 299
    178 295
    178 290
    177 286
    177 281
    176 277
    176 272
    175 267
    174 263
    173 258
    172 253
    170 249
    169 244
    168 239
    166 234
    164 229
    163 224
    161 219
    159 214
    157 209
    154 204
    152 198
    150 193
    147 188
    144 183
    142 177
    139 172
    136 167
    133 161
    129 156
    126 150
    123 145
    119 139
    116 134
    112 128
    108 123
    104 117
    100 111
    96 106
    91 100
    87 94
    82 89
    78 83
    73 77
    68 71
    63 65
    58 60
    52 54
    47 48
    42 42
    36 36
    30 30
    24 24
    18 18
    12 12
    6 6
    -0 -0
    -6 -6
    -13 -12
    -20 -18
    -26 -24
    -33 -31
    -40 -37
    -47 -43
    -55 -49
    -62 -55
    -69 -61
    -77 -68
    -85 -74
    -92 -80
    -100 -86
    -108 -93
    -116 -99
    -125 -105
    -133 -111
    -141 -118
    -150 -124
    -159 -130
    -167 -137
    -176 -143
    -185 -149
    -194 -156
    -204 -162
    -213 -168
    -223 -175
    -232 -181
    -242 -187
    -252 -194
    -261 -200
    -271 -207
    -282 -213
    -292 -219
    -302 -226
    -313 -232
    -323 -239
    -334 -245
    -345 -251
    -355 -258
    -366 -264
    -377 -271
    -389 -277
    -400 -283
    -411 -290
    -423 -296
    -434 -303
    -446 -309
    -458 -315
    -470 -322
    -482 -328
    -494 -335
    -506 -341
    -519 -348
    -531 -354
    -543 -360
    -556 -367
    -569 -373
    -582 -380
    -595 -386
    -608 -392
    -621 -399
    -634 -405
    -647 -412
    -661 -418
    -674 -424
    -688 -431
    -701 -437
    -715 -443
    -729 -450
    -743 -456
    -757 -462
    -771 -469
    -786 -475
    -800 -481
    -814 -488
    -829 -494
    -843 -500
    -858 -507
    -873 -513
    -888 -519
    -903 -526
    -918 -532
    -933 -538
    -948 -544
    -964 -551
    -979 -557
    -995 -563
    -1010 -569
    -1026 -576
    -1042 -582
    -1058 -588
    -1073 -594
    -1089 -600
    -1106 -607
    -1122 -613
    -1138 -619
    -1154 -625
    -1171 -631
    -1187 -637
    -1204 -644
    -1221 -650
    -1237 -656
    -1254 -662
    -1271 -668
    -1288 -674
    -1305 -680
    -1322 -686
    -1340 -692
    1346 -701
    1329 -695
    1311 -689
    1294 -683
    1277 -677
    1260 -670
    1244 -664
    1227 -658
    1210 -652
    1194 -646
    1177 -640
    1161 -634
    1144 -627
    1128 -621
    1112 -615
    1096 -609
    1080 -602
    1064 -596
    1048 -590
    1032 -584
    1016 -578
    1001 -571
    985 -565
    970 -559
    955 -552
    939 -546
    924 -540
    909 -534
    894 -527
    879 -521
    864 -515
    850 -508
    835 -502
    821 -496
    806 -489
    792 -483
    778 -476
    763 -470
    749 -464
    735 -457
    722 -451
    708 -445
    694 -438
    680 -432
    667 -425
    654 -419
    640 -413
    627 -406
    614 -400
    601 -393
    588 -387
    575 -380
    563 -374
    550 -368
    537 -361
    525 -355
    513 -348
    500 -342
    488 -335
    476 -329
    464 -323
    453 -316
    441 -310
    429 -303
    418 -297
    406 -290
    395 -284
    384 -277
    373 -271
    362 -265
    351 -258
    340 -252
    330 -245
    319 -239
    309 -232
    298 -226
    288 -220
    278 -213
    268 -207
    258 -200
    248 -194
    238 -187
    229 -181
    219 -175
    210 -168
    201 -162
    192 -156
    183 -149
    174 -143
    165 -137
    156 -130
    148 -124
    139 -118
    131 -111
    123 -105
    114 -99
    106 -92
    99 -86
    91 -80
    83 -74
    76 -67
    68 -61
    61 -55
    54 -49
    46 -43
    39 -36
    33 -30
    26 -24
    19 -18
    13 -12
    6 -6
    -0 0
    -6 6
    -12 12
    -18 18
    -24 24
    -30 30
    -36 36
    -41 42
    -47 48
    -52 54
    -57 60
    -62 66
    -67 71
    -72 77
    -76 83
    -81 89
    -86 95
    -90 100
    -94 106
    -98 112
    -102 117
    -106 123
    -110 128
    -114 134
    -117 140
    -121 145
    -124 151
    -127 156
    -130 161
    -133 167
    -136 172
    -139 177
    -142 183
    -144 188
    -147 193
    -149 198
    -151 204
    -154 209
    -156 214
    -157 219
    -159 224
    -161 229
    -163 234
    -164 239
    -166 243
    -167 248
    -168 253
    -169 258
    -170 262
    -171 267
    -172 272
    -172 276
    -173 281
    -173 285
    -174 290
    -174 294
    -174 298
    -174 303
    -174 307
    -174 311
    -174 315
    -174 320
    -173 324
    -173 328
    -172 332
    -172 336
    -171 339
    -170 343
    -169 347
    -168 351
    -167 355
    -166 358
    -165 362
    -164 365
    -162 369
    -161 372
    -159 375
    -158 379
    -156 382
    -154 385
    -152 388
    -150 391
    -148 394
    -146 397
    -144 400
    -142 403
    -140 406
    -137 409
    -135 411
    -132 414
    -130 417
    -127 419
    -125 422
    -122 424
    -119 426
    -117 428
    -114 431
    -111 433
    -108 435
    -105 437
    -102 439
    -99 441
    -96 443
    -92 444
    -89 446
    -86 448
    -83 449
    -79 451
    -76 452
    -73 453
    -69 455
    -66 456
    -62 457
    -59 458
    -55 459
    -52 460
    -48 461
    -44 462
    -41 463
    -37 463
    -33 464
    -30 465
    -26 465
    -22 466
    -19 466
    -15 466
    -11 466
    -7 467
    -4 467
    0 467
    4 467
    7 467
    11 466
    15 466
    19 466
    22 466
    26 465
    30 465
    33 464
    37 463
    41 463
    44 462
    48 461
    52 460
    55 459
    59 458
    62 457
    66 456
    69 455
    73 453
    76 452
    79 451
    83 449
    86 448
    89 446
    92 444
    96 443
    99 441
    102 439
    105 437
    108 435
    111 433
    114 431
    117 428
    119 426
    122 424
    125 422
    127 419
    130 417
    132 414
    135 411
    137 409
    140 406
    142 403
    144 400
    146 397
    148 394
    150 391
    152 388
    154 385
    156 382
    158 379
    159 375
    161 372
    162 369
    164 365
    165 362
    166 358
    167 355
    168 351
    169 347
    170 343
    171 339
    172 336
    172 332
    173 328
    173 324
    174 320
    174 315
    174 311
    174 307
    174 303
    174 298
    174 294
    174 290
    173 285
    173 281
    172 276
    172 272
    171 267
    170 262
    169 258
    168 253
    167 248
    166 243
    164 239
    163 234
    161 229
    159 224
    157 219
    156 214
    154 209
    151 204
    149 198
    147 193
    144 188
    142 183
    139 177
    136 172
    133 167
    130 161
    127 156
    124 151
    121 145
    117 140
    114 134
    110 128
    106 123
    102 117
    98 112
    94 106
    90 100
    86 95
    81 89
    76 83
    72 77
    67 71
    62 66
    57 60
    52 54
    47 48
    41 42
    36 36
    30 30
    24 24
    18 18
    12 12
    6 6
    0 0
    -6 -6
    -13 -12
    -19 -18
    -26 -24
    -33 -30
    -39 -36
    -46 -43
    -54 -49
    -61 -55
    -68 -61
    -76 -67
    -83 -74
    -91 -80
    -99 -86
    -106 -92
    -114 -99
    -123 -105
    -131 -111
    -139 -118
    -148 -124
    -156 -130
    -165 -137
    -174 -143
    -183 -149
    -192 -156
    -201 -162
    -210 -168
    -219 -175
    -229 -181
    -238 -187
    -248 -194
    -258 -200
    -268 -207
    -278 -213
    -288 -220
    -298 -226
    -309 -232
    -319 -239
    -330 -245
    -340 -252
    -351 -258
    -362 -265
    -373 -271
    -384 -277
    -395 -284
    -406 -290
    -418 -297
    -429 -303
    -441 -310
    -453 -316
    -464 -323
    -476 -329
    -488 -335
    -500 -342
    -513 -348
    -525 -355
    -537 -361
    -550 -368
    -563 -374
    -575 -380
    -588 -387
    -601 -393
    -614 -400
    -627 -406
    -640 -413
    -654 -419
    -667 -425
    -680 -432
    -694 -438
    -708 -445
    -722 -451
    -735 -457
    -749 -464
    -763 -470
    -778 -476
    -792 -483
    -806 -489
    -821 -496
    -835 -502
    -850 -508
    -864 -515
    -879 -521
    -894 -527
    -909 -534
    -924 -540
    -939 -546
    -955 -552
    -970 -559
    -985 -565
    -1001 -571
    -1016 -578
    -1032 -584
    -1048 -590
    -1064 -596
    -1080 -602
    -1096 -609
    -1112 -615
    -1128 -621
    -1144 -627
    -1161 -634
    -1177 -640
    -1194 -646
    -1210 -652
    -1227 -658
    -1244 -664
    -1260 -670
    -1277 -677
    -1294 -683
    -1311 -689
    -1329 -695
    -1346 -701
    1352 -710
    1335 -704
    1317 -697
    1300 -691
    1283 -685
    1267 -679
    1250 -673
    1233 -667
    1216 -661
    1200 -654
    1183 -648
    1167 -642
    1150 -636
    1134 -630
    1118 -623
    1102 -617
    1086 -611
    1070 -605
    1054 -598
    1038 -592
    1023 -586
    1007 -579
    992 -573
    976 -567
    961 -561
    946 -554
    931 -548
    915 -542
    901 -535
    886 -529
    871 -523
    856 -516
    842 -510
    827 -503
    813 -497
    798 -491
    784 -484
    770 -478
    756 -471
    742 -465
    728 -459
    714 -452
    700 -446
    687 -439
    673 -433
    660 -426
    647 -420
    634 -414
    620 -407
    607 -401
    594 -394
    582 -388
    569 -381
    556 -375
    544 -368
    531 -362
    519 -355
    507 -349
    495 -343
    483 -336
    471 -330
    459 -323
    447 -317
    436 -310
    424 -304
    413 -297
    402 -291
    390 -284
    379 -278
    368 -271
    357 -265
    347 -258
    336 -252
    325 -246
    315 -239
    305 -233
    294 -226
    284 -220
    274 -213
    264 -207
    255 -200
    245 -194
    235 -188
    226 -181
    216 -175
    207 -168
    198 -162
    189 -156
    180 -149
    171 -143
    163 -137
    154 -130
    146 -124
    137 -118
    129 -111
    121 -105
    113 -99
    105 -92
    97 -86
    89 -80
    82 -74
    74 -67
    67 -61
    60 -55
    53 -49
    46 -43
    39 -36
    32 -30
    25 -24
    19 -18
    12 -12
    6 -6
    -0 0
    -6 6
    -12 12
    -18 18
    -24 24
    -30 30
    -35 36
    -41 42
    -46 48
    -51 54
    -56 60
    -61 66
    -66 72
    -71 77
    -75 83
    -80 89
    -84 95
    -88 100
    -93 106
    -97 112
    -101 117
    -104 123
    -108 129
    -112 134
    -115 140
    -119 145
    -122 151
    -125 156
    -128 161
    -131 167
    -134 172
    -137 177
    -139 183
    -142 188
    -144 193
    -146 198
    -148 203
    -151 208
    -152 213
    -154 218
    -156 223
    -158 228
    -159 233
    -161 238
    -162 243
    -163 248
    -164 253
    -165 257
    -166 262
    -167 267
    -168 271
    -168 276
    -169 280
    -169 285
    -170 289
    -170 293
    -170 298
    -170 302
    -170 306
    -170 310
    -170 315
    -169 319
    -169 323
    -169 327
    -168 331
    -167 334
    -166 338
    -166 342
    -165 346
    -164 350
    -163 353
    -161 357
    -160 360
    -159 364
    -157 367
    -156 371
    -154 374
    -153 377
    -151 380
    -149 383
    -147 387
    -145 390
    -143 393
    -141 395
    -139 398
    -137 401
    -135 404
    -132 407
    -130 409
    -127 412
    -125 414
    -122 417
    -120 419
    -117 421
    -114 424
    -112 426
    -109 428
    -106 430
    -103 432
    -100 434
    -97 436
    -94 438
    -91 439
    -88 441
    -84 443
    -81 444
    -78 446
    -75 447
    -71 449
    -68 450
    -64 451
    -61 452
    -58 453
    -54 454
    -51 455
    -47 456
    -44 457
    -40 458
    -36 459
    -33 459
    -29 460
    -26 460
    -22 461
    -18 461
    -15 462
    -11 462
    -7 462
    -4 462
    0 462
    4 462
    7 462
    11 462
    15 462
    18 461
    22 461
    26 460
    29 460
    33 459
    36 459
    40 458
    44 457
    47 456
    51 455
    54 454
    58 453
    61 452
    64 451
    68 450
    71 449
    75 447
    78 446
    81 444
    84 443
    88 441
    91 439
    94 438
    97 436
    100 434
    103 432
    106 430
    109 428
    112 426
    114 424
    117 421
    120 419
    122 417
    125 414
    127 412
    130 409
    132 407
    135 404
    137 401
    139 398
    141 395
    143 393
    145 390
    147 387
    149 383
    151 380
    153 377
    154 374
    156 371
    157 367
    159 364
    160 360
    161 357
    163 353
    164 350
    165 346
    166 342
    166 338
    167 334
    168 331
    169 327
    169 323
    169 319
    170 315
    170 310
    170 306
    170 302
    170 298
    170 293
    170 289
    169 285
    169 280
    168 276
    168 271
    167 267
    166 262
    165 257
    164 253
    163 248
    162 243
    161 238
    159 233
    158 228
    156 223
    154 218
    152 213
    151 208
    148 203
    146 198
    144 193
    142 188
    139 183
    137 177
    134 172
    131 167
    128 161
    125 156
    122 151
    119 145
    115 140
    112 134
    108 129
    104 123
    101 117
    97 112
    93 106
    88 100
    84 95
    80 89
    75 83
    71 77
    66 72
    61 66
    56 60
    51 54
    46 48
    41 42
    35 36
    30 30
    24 24
    18 18
    12 12
    6 6
    0 0
    -6 -6
    -12 -12
    -19 -18
    -25 -24
    -32 -30
    -39 -36
    -46 -43
    -53 -49
    -60 -55
    -67 -61
    -74 -67
    -82 -74
    -89 -80
    -97 -86
    -105 -92
    -113 -99
    -121 -105
    -129 -111
    -137 -118
    -146 -124
    -154 -130
    -163 -137
    -171 -143
    -180 -149
    -189 -156
    -198 -162
    -207 -168
    -216 -175
    -226 -181
    -235 -188
    -245 -194
    -255 -200
    -264 -207
    -274 -213
    -284 -220
    -294 -226
    -305 -233
    -315 -239
    -325 -246
    -336 -252
    -347 -258
    -357 -265
    -368 -271
    -379 -278
    -390 -284
    -402 -291
    -413 -297
    -424 -304
    -436 -310
    -447 -317
    -459 -323
    -471 -330
    -483 -336
    -495 -343
    -507 -349
    -519 -355
    -531 -362
    -544 -368
    -556 -375
    -569 -381
    -582 -388
    -594 -394
    -607 -401
    -620 -407
    -634 -414
    -647 -420
    -660 -426
    -673 -433
    -687 -439
    -700 -446
    -714 -452
    -728 -459
    -742 -465
    -756 -471
    -770 -478
    -784 -484
    -798 -491
    -813 -497
    -827 -503
    -842 -510
    -856 -516
    -871 -523
    -886 -529
    -901 -535
    -915 -542
    -931 -548
    -946 -554
    -961 -561
    -976 -567
    -992 -573
    -1007 -579
    -1023 -586
    -1038 -592
    -1054 -598
    -1070 -605
    -1086 -611
    -1102 -617
    -1118 -623
    -1134 -630
    -1150 -636
    -1167 -642
    -1183 -648
    -1200 -654
    -1216 -661
    -1233 -667
    -1250 -673
    -1267 -679
    -1283 -685
    -1300 -691
    -1317 -697
    -1335 -704
    -1352 -710
    1358 -719
    1341 -712
    1324 -706
    1307 -700
    1290 -694
    1273 -688
    1256 -682
    1239 -675
    1222 -669
    1206 -663
    1189 -657
    1173 -651
    1157 -644
    1140 -638
    1124 -632
    1108 -626
    1092 -619
    1076 -613
    1060 -607
    1045 -600
    1029 -594
    1013 -588
    998 -581
    983 -575
    967 -569
    952 -562
    937 -556
    922 -550
    907 -543
    892 -537
    877 -531
    863 -524
    848 -518
    833 -511
    819 -505
    805 -498
    790 -492
    776 -486
    762 -479
    748 -473
    734 -466
    721 -460
    707 -453
    693 -447
    680 -441
    666 -434
    653 -428
    640 -421
    627 -415
    614 -408
    601 -402
    588 -395
    575 -389
    563 -382
    550 -376
    538 -369
    526 -363
    513 -356
    501 -350
    489 -343
    477 -337
    466 -330
    454 -324
    442 -317
    431 -311
    419 -304
    408 -298
    397 -291
    386 -285
    375 -278
    364 -272
    353 -265
    342 -259
    332 -252
    321 -246
    311 -239
    301 -233
    291 -227
    281 -220
    271 -214
    261 -207
    251 -201
    242 -194
    232 -188
    223 -181
    214 -175
    204 -169
    195 -162
    187 -156
    178 -149
    169 -143
    160 -137
    152 -130
    144 -124
    135 -118
    127 -111
    119 -105
    111 -99
    103 -92
    96 -86
    88 -80
    81 -74
    73 -67
    66 -61
    59 -55
    52 -49
    45 -43
    38 -36
    31 -30
    25 -24
    18 -18
    12 -12
    6 -6
    -0 0
    -6 6
    -12 12
    -18 18
    -24 24
    -29 30
    -35 36
    -40 42
    -45 48
    -50 54
    -55 60
    -60 66
    -65 72
    -69 77
    -74 83
    -78 89
    -83 95
    -87 100
    -91 106
    -95 112
    -99 117
    -103 123
    -106 128
    -110 134
    -113 139
    -116 145
    -120 150
    -123 156
    -126 161
    -128 166
    -131 172
    -134 177
    -136 182
    -139 188
    -141 193
    -143 198
    -145 203
    -147 208
    -149 213
    -151 218
    -153 223
    -154 228
    -156 233
    -157 238
    -158 242
    -160 247
    -161 252
    -162 257
    -163 261
    -163 266
    -164 270
    -165 275
    -165 279
    -165 284
    -166 288
    -166 292
    -166 297
    -166 301
    -166 305
    -166 309
    -165 313
    -165 317
    -165 321
    -164 325
    -163 329
    -163 333
    -162 337
    -161 341
    -160 344
    -159 348
    -158 352
    -157 355
    -155 359
    -154 362
    -153 365
    -151 369
    -149 372
    -148 375
    -146 378
    -144 382
    -142 385
    -140 388
    -138 390
    -136 393
    -134 396
    -132 399
    -130 402
    -127 404
    -125 407
    -122 409
    -120 412
    -117 414
    -115 416
    -112 419
    -109 421
    -107 423
    -104 425
    -101 427
    -98 429
    -95 431
    -92 433
    -89 435
    -86 436
    -83 438
    -80 439
    -76 441
    -73 442
    -70 444
    -67 445
    -63 446
    -60 447
    -57 449
    -53 450
    -50 451
    -46 451
    -43 452
    -39 453
    -36 454
    -32 454
    -29 455
    -25 456
    -22 456
    -18 456
    -14 457
    -11 457
    -7 457
    -4 457
    0 457
    4 457
    7 457
    11 457
    14 457
    18 456
    22 456
    25 456
    29 455
    32 454
    36 454
    39 453
    43 452
    46 451
    50 451
    53 450
    57 449
    60 447
    63 446
    67 445
    70 444
    73 442
    76 441
    80 439
    83 438
    86 436
    89 435
    92 433
    95 431
    98 429
    101 427
    104 425
    107 423
    109 421
    112 419
    115 416
    117 414
    120 412
    122 409
    125 407
    127 404
    130 402
    132 399
    134 396
    136 393
    138 390
    140 388
    142 385
    144 382
    146 378
    148 375
    149 372
    151 369
    153 365
    154 362
    155 359
    157 355
    158 352
    159 348
    160 344
    161 341
    162 337
    163 333
    163 329
    164 325
    165 321
    165 317
    165 313
    166 309
    166 305
    166 301
    166 297
    166 292
    166 288
    165 284
    165 279
    165 275
    164 270
    163 266
    163 261
    162 257
    161 252
    160 247
    158 242
    157 238
    156 233
    154 228
    153 223
    151 218
    149 213
    147 208
    145 203
    143 198
    141 193
    139 188
    136 182
    134 177
    131 172
    128 166
    126 161
    123 156
    120 150
    116 145
    113 139
    110 134
    106 128
    103 123
    99 117
    95 112
    91 106
    87 100
    83 95
    78 89
    74 83
    69 77
    65 72
    60 66
    55 60
    50 54
    45 48
    40 42
    35 36
    29 30
    24 24
    18 18
    12 12
    6 6
    0 0
    -6 -6
    -12 -12
    -18 -18
    -25 -24
    -31 -30
    -38 -36
    -45 -43
    -52 -49
    -59 -55
    -66 -61
    -73 -67
    -81 -74
    -88 -80
    -96 -86
    -103 -92
    -111 -99
    -119 -105
    -127 -111
    -135 -118
    -144 -124
    -152 -130
    -160 -137
    -169 -143
    -178 -149
    -187 -156
    -195 -162
    -204 -169
    -214 -175
    -223 -181
    -232 -188
    -242 -194
    -251 -201
    -261 -207
    -271 -214
    -281 -220
    -291 -227
    -301 -233
    -311 -239
    -321 -246
    -332 -252
    -342 -259
    -353 -265
    -364 -272
    -375 -278
    -386 -285
    -397 -291
    -408 -298
    -419 -304
    -431 -311
    -442 -317
    -454 -324
    -466 -330
    -477 -337
    -489 -343
    -501 -350
    -513 -356
    -526 -363
    -538 -369
    -550 -376
    -563 -382
    -575 -389
    -588 -395
    -601 -402
    -614 -408
    -627 -415
    -640 -421
    -653 -428
    -666 -434
    -680 -441
    -693 -447
    -707 -453
    -721 -460
    -734 -466
    -748 -473
    -762 -479
    -776 -486
    -790 -492
    -805 -498
    -819 -505
    -833 -511
    -848 -518
    -863 -524
    -877 -531
    -892 -537
    -907 -543
    -922 -550
    -937 -556
    -952 -562
    -967 -569
    -983 -575
    -998 -581
    -1013 -588
    -1029 -594
    -1045 -600
    -1060 -607
    -1076 -613
    -1092 -619
    -1108 -626
    -1124 -632
    -1140 -638
    -1157 -644
    -1173 -651
    -1189 -657
    -1206 -663
    -1222 -669
    -1239 -675
    -1256 -682
    -1273 -688
    -1290 -694
    -1307 -700
    -1324 -706
    -1341 -712
    -1358 -719
    1364 -728
    1347 -721
    1330 -715
    1313 -709
    1296 -703
    1279 -697
    1262 -690
    1245 -684
    1229 -678
    1212 -672
    1196 -665
    1179 -659
    1163 -653
    1147 -647
    1131 -640
    1114 -634
    1098 -628
    1083 -621
    1067 -615
    1051 -609
    1035 -602
    1020 -596
    1004 -590
    989 -583
    974 -577
    958 -571
    943 -564
    928 -558
    913 -551
    898 -545
    884 -539
    869 -532
    854 -526
    840 -519
    825 -513
    811 -506
    797 -500
    783 -494
    769 -487
    755 -481
    741 -474
    727 -468
    713 -461
    700 -455
    686 -448
    673 -442
    660 -435
    646 -429
    633 -422
    620 -416
    607 -409
    595 -403
    582 -396
    569 -390
    557 -383
    544 -377
    532 -370
    520 -364
    508 -357
    496 -351
    484 -344
    472 -338
    460 -331
    449 -325
    437 -318
    426 -311
    415 -305
    403 -298
    392 -292
    381 -285
    370 -279
    360 -272
    349 -266
    338 -259
    328 -253
    318 -246
    307 -240
    297 -233
    287 -227
    277 -220
    267 -214
    258 -208
    248 -201
    239 -195
    229 -188
    220 -182
    211 -175
    202 -169
    193 -162
    184 -156
    175 -150
    167 -143
    158 -137
    150 -130
    142 -124
    133 -118
    125 -111
    117 -105
    110 -99
    102 -93
    94 -86
    87 -80
    79 -74
    72 -67
    65 -61
    58 -55
    51 -49
    44 -43
    38 -36
    31 -30
    24 -24
    18 -18
    12 -12
    6 -6
    -0 0
    -6 6
    -12 12
    -18 18
    -23 24
    -29 30
    -34 36
    -39 42
    -44 48
    -49 54
    -54 60
    -59 66
    -64 72
    -68 77
    -73 83
    -77 89
    -81 95
    -85 100
    -89 106
    -93 111
    -97 117
    -101 123
    -104 128
    -108 134
    -111 139
    -114 145
    -117 150
    -120 155
    -123 161
    -126 166
    -129 171
    -131 177
    -134 182
    -136 187
    -138 192
    -140 197
    -142 202
    -144 208
    -146 213
    -148 217
    -149 222
    -151 227
    -152 232
    -154 237
    -155 242
    -156 246
    -157 251
    -158 256
    -159 260
    -159 265
    -160 270
    -161 274
    -161 278
    -161 283
    -162 287
    -162 291
    -162 296
    -162 300
    -162 304
    -161 308
    -161 312
    -161 316
    -160 320
    -159 324
    -159 328
    -158 332
    -157 335
    -156 339
    -155 343
    -154 346
    -153 350
    -152 353
    -151 357
    -149 360
    -148 364
    -146 367
    -145 370
    -143 373
    -141 376
    -139 379
    -137 382
    -135 385
    -133 388
    -131 391
    -129 394
    -127 396
    -125 399
    -122 402
    -120 404
    -118 407
    -115 409
    -112 411
    -110 414
    -107 416
    -104 418
    -102 420
    -99 422
    -96 424
    -93 426
    -90 428
    -87 429
    -84 431
    -81 433
    -78 434
    -75 436
    -72 437
    -69 439
    -65 440
    -62 441
    -59 442
    -55 443
    -52 445
    -49 445
    -45 446
    -42 447
    -39 448
    -35 449
    -32 449
    -28 450
    -25 450
    -21 451
    -18 451
    -14 452
    -11 452
    -7 452
    -4 452
    0 452
    4 452
    7 452
    11 452
    14 452
    18 451
    21 451
    25 450
    28 450
    32 449
    35 449
    39 448
    42 447
    45 446
    49 445
    52 445
    55 443
    59 442
    62 441
    65 440
    69 439
    72 437
    75 436
    78 434
    81 433
    84 431
    87 429
    90 428
    93 426
    96 424
    99 422
    102 420
    104 418
    107 416
    110 414
    112 411
    115 409
    118 407
    120 404
    122 402
    125 399
    127 396
    129 394
    131 391
    133 388
    135 385
    137 382
    139 379
    141 376
    143 373
    145 370
    146 367
    148 364
    149 360
    151 357
    152 353
    153 350
    154 346
    155 343
    156 339
    157 335
    158 332
    159 328
    159 324
    160 320
    161 316
    161 312
    161 308
    162 304
    162 300
    162 296
    162 291
    162 287
    161 283
    161 278
    161 274
    160 270
    159 265
    159 260
    158 256
    157 251
    156 246
    155 242
    154 237
    152 232
    151 227
    149 222
    148 217
    146 213
    144 208
    142 202
    140 197
    138 192
    136 187
    134 182
    131 177
    129 171
    126 166
    123 161
    120 155
    117 150
    114 145
    111 139
    108 134
    104 128
    101 123
    97 117
    93 111
    89 106
    85 100
    81 95
    77 89
    73 83
    68 77
    64 72
    59 66
    54 60
    49 54
    44 48
    39 42
    34 36
    29 30
    23 24
    18 18
    12 12
    6 6
    0 0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -31 -30
    -38 -36
    -44 -43
    -51 -49
    -58 -55
    -65 -61
    -72 -67
    -79 -74
    -87 -80
    -94 -86
    -102 -93
    -110 -99
    -117 -105
    -125 -111
    -133 -118
    -142 -124
    -150 -130
    -158 -137
    -167 -143
    -175 -150
    -184 -156
    -193 -162
    -202 -169
    -211 -175
    -220 -182
    -229 -188
    -239 -195
    -248 -201
    -258 -208
    -267 -214
    -277 -220
    -287 -227
    -297 -233
    -307 -240
    -318 -246
    -328 -253
    -338 -259
    -349 -266
    -360 -272
    -370 -279
    -381 -285
    -392 -292
    -403 -298
    -415 -305
    -426 -311
    -437 -318
    -449 -325
    -460 -331
    -472 -338
    -484 -344
    -496 -351
    -508 -357
    -520 -364
    -532 -370
    -544 -377
    -557 -383
    -569 -390
    -582 -396
    -595 -403
    -607 -409
    -620 -416
    -633 -422
    -646 -429
    -660 -435
    -673 -442
    -686 -448
    -700 -455
    -713 -461
    -727 -468
    -741 -474
    -755 -481
    -769 -487
    -783 -494
    -797 -500
    -811 -506
    -825 -513
    -840 -519
    -854 -526
    -869 -532
    -884 -539
    -898 -545
    -913 -551
    -928 -558
    -943 -564
    -958 -571
    -974 -577
    -989 -583
    -1004 -590
    -1020 -596
    -1035 -602
    -1051 -609
    -1067 -615
    -1083 -621
    -1098 -628
    -1114 -634
    -1131 -640
    -1147 -647
    -1163 -653
    -1179 -659
    -1196 -665
    -1212 -672
    -1229 -678
    -1245 -684
    -1262 -690
    -1279 -697
    -1296 -703
    -1313 -709
    -1330 -715
    -1347 -721
    -1364 -728
    1370 -737
    1353 -730
    1336 -724
    1319 -718
    1302 -712
    1285 -705
    1268 -699
    1252 -693
    1235 -687
    1218 -680
    1202 -674
    1186 -668
    1169 -662
    1153 -655
    1137 -649
    1121 -643
    1105 -636
    1089 -630
    1073 -624
    1057 -617
    1042 -611
    1026 -604
    1011 -598
    995 -592
    980 -585
    965 -579
    950 -572
    935 -566
    920 -560
    905 -553
    890 -547
    875 -540
    861 -534
    846 -527
    832 -521
    818 -514
    803 -508
    789 -501
    775 -495
    761 -489
    747 -482
    734 -476
    720 -469
    706 -463
    693 -456
    679 -449
    666 -443
    653 -436
    640 -430
    627 -423
    614 -417
    601 -410
    588 -404
    576 -397
    563 -391
    551 -384
    539 -378
    526 -371
    514 -365
    502 -358
    490 -351
    479 -345
    467 -338
    455 -332
    444 -325
    432 -319
    421 -312
    410 -306
    399 -299
    388 -293
    377 -286
    366 -279
    355 -273
    345 -266
    334 -260
    324 -253
    314 -247
    304 -240
    294 -234
    284 -227
    274 -221
    264 -214
    255 -208
    245 -201
    236 -195
    226 -189
    217 -182
    208 -176
    199 -169
    190 -163
    182 -156
    173 -150
    165 -144
    156 -137
    148 -131
    140 -124
    132 -118
    124 -112
    116 -105
    108 -99
    101 -93
    93 -86
    86 -80
    78 -74
    71 -68
    64 -61
    57 -55
    50 -49
    44 -43
    37 -37
    31 -30
    24 -24
    18 -18
    12 -12
    6 -6
    -0 0
    -6 6
    -12 12
    -17 18
    -23 24
    -28 30
    -33 36
    -38 42
    -44 48
    -48 54
    -53 60
    -58 66
    -62 71
    -67 77
    -71 83
    -76 89
    -80 94
    -84 100
    -88 106
    -91 111
    -95 117
    -99 122
    -102 128
    -105 133
    -109 139
    -112 144
    -115 150
    -118 155
    -121 160
    -123 166
    -126 171
    -128 176
    -131 181
    -133 187
    -135 192
    -137 197
    -139 202
    -141 207
    -143 212
    -145 217
    -146 222
    -148 227
    -149 231
    -150 236
    -151 241
    -152 246
    -153 250
    -154 255
    -155 259
    -156 264
    -156 268
    -157 273
    -157 277
    -157 282
    -157 286
    -157 290
    -157 294
    -157 299
    -157 303
    -157 307
    -157 311
    -156 315
    -156 319
    -155 322
    -154 326
    -154 330
    -153 334
    -152 337
    -151 341
    -150 345
    -148 348
    -147 352
    -146 355
    -144 358
    -143 362
    -141 365
    -140 368
    -138 371
    -136 374
    -134 377
    -133 380
    -131 383
    -129 386
    -126 388
    -124 391
    -122 394
    -120 396
    -117 399
    -115 401
    -113 404
    -110 406
    -108 408
    -105 411
    -102 413
    -100 415
    -97 417
    -94 419
    -91 421
    -88 422
    -85 424
    -83 426
    -80 428
    -77 429
    -73 431
    -70 432
    -67 433
    -64 435
    -61 436
    -58 437
    -54 438
    -51 439
    -48 440
    -44 441
    -41 442
    -38 443
    -34 444
    -31 444
    -28 445
    -24 445
    -21 446
    -17 446
    -14 446
    -10 447
    -7 447
    -3 447
    0 447
    3 447
    7 447
    10 447
    14 446
    17 446
    21 446
    24 445
    28 445
    31 444
    34 444
    38 443
    41 442
    44 441
    48 440
    51 439
    54 438
    58 437
    61 436
    64 435
    67 433
    70 432
    73 431
    77 429
    80 428
    83 426
    85 424
    88 422
    91 421
    94 419
    97 417
    100 415
    102 413
    105 411
    108 408
    110 406
    113 404
    115 401
    117 399
    120 396
    122 394
    124 391
    126 388
    129 386
    131 383
    133 380
    134 377
    136 374
    138 371
    140 368
    141 365
    143 362
    144 358
    146 355
    147 352
    148 348
    150 345
    151 341
    152 337
    153 334
    154 330
    154 326
    155 322
    156 319
    156 315
    157 311
    157 307
    157 303
    157 299
    157 294
    157 290
    157 286
    157 282
    157 277
    157 273
    156 268
    156 264
    155 259
    154 255
    153 250
    152 246
    151 241
    150 236
    149 231
    148 227
    146 222
    145 217
    143 212
    141 207
    139 202
    137 197
    135 192
    133 187
    131 181
    128 176
    126 171
    123 166
    121 160
    118 155
    115 150
    112 144
    109 139
    105 133
    102 128
    99 122
    95 117
    91 111
    88 106
    84 100
    80 94
    76 89
    71 83
    67 77
    62 71
    58 66
    53 60
    48 54
    44 48
    38 42
    33 36
    28 30
    23 24
    17 18
    12 12
    6 6
    0 0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -31 -30
    -37 -37
    -44 -43
    -50 -49
    -57 -55
    -64 -61
    -71 -68
    -78 -74
    -86 -80
    -93 -86
    -101 -93
    -108 -99
    -116 -105
    -124 -112
    -132 -118
    -140 -124
    -148 -131
    -156 -137
    -165 -144
    -173 -150
    -182 -156
    -190 -163
    -199 -169
    -208 -176
    -217 -182
    -226 -189
    -236 -195
    -245 -201
    -255 -208
    -264 -214
    -274 -221
    -284 -227
    -294 -234
    -304 -240
    -314 -247
    -324 -253
    -334 -260
    -345 -266
    -355 -273
    -366 -279
    -377 -286
    -388 -293
    -399 -299
    -410 -306
    -421 -312
    -432 -319
    -444 -325
    -455 -332
    -467 -338
    -479 -345
    -490 -351
    -502 -358
    -514 -365
    -526 -371
    -539 -378
    -551 -384
    -563 -391
    -576 -397
    -588 -404
    -601 -410
    -614 -417
    -627 -423
    -640 -430
    -653 -436
    -666 -443
    -679 -449
    -693 -456
    -706 -463
    -720 -469
    -734 -476
    -747 -482
    -761 -489
    -775 -495
    -789 -501
    -803 -508
    -818 -514
    -832 -521
    -846 -527
    -861 -534
    -875 -540
    -890 -547
    -905 -553
    -920 -560
    -935 -566
    -950 -572
    -965 -579
    -980 -585
    -995 -592
    -1011 -598
    -1026 -604
    -1042 -611
    -1057 -617
    -1073 -624
    -1089 -630
    -1105 -636
    -1121 -643
    -1137 -649
    -1153 -655
    -1169 -662
    -1186 -668
    -1202 -674
    -1218 -680
    -1235 -687
    -1252 -693
    -1268 -699
    -1285 -705
    -1302 -712
    -1319 -718
    -1336 -724
    -1353 -730
    -1370 -737
    1376 -746
    1359 -739
    1342 -733
    1325 -727
    1308 -721
    1291 -714
    1275 -708
    1258 -702
    1241 -696
    1225 -689
    1208 -683
    1192 -677
    1176 -670
    1159 -664
    1143 -658
    1127 -651
    1111 -645
    1095 -638
    1079 -632
    1064 -626
    1048 -619
    1033 -613
    1017 -607
    1002 -600
    986 -594
    971 -587
    956 -581
    941 -574
    926 -568
    911 -561
    896 -555
    882 -548
    867 -542
    853 -536
    838 -529
    824 -523
    810 -516
    796 -510
    782 -503
    768 -497
    754 -490
    740 -483
    726 -477
    713 -470
    699 -464
    686 -457
    673 -451
    660 -444
    646 -438
    633 -431
    621 -425
    608 -418
    595 -411
    582 -405
    570 -398
    557 -392
    545 -385
    533 -379
    521 -372
    509 -365
    497 -359
    485 -352
    473 -346
    462 -339
    450 -333
    439 -326
    428 -319
    416 -313
    405 -306
    394 -300
    383 -293
    373 -287
    362 -280
    351 -274
    341 -267
    331 -261
    320 -254
    310 -247
    300 -241
    290 -234
    280 -228
    271 -221
    261 -215
    252 -208
    242 -202
    233 -195
    224 -189
    215 -182
    206 -176
    197 -170
    188 -163
    180 -157
    171 -150
    163 -144
    154 -137
    146 -131
    138 -125
    130 -118
    122 -112
    115 -106
    107 -99
    99 -93
    92 -87
    85 -80
    78 -74
    70 -68
    63 -62
    57 -55
    50 -49
    43 -43
    37 -37
    30 -31
    24 -24
    18 -18
    12 -12
    6 -6
    0 -0
    -6 6
    -11 12
    -17 18
    -22 24
    -27 30
    -33 36
    -38 42
    -43 48
    -47 54
    -52 59
    -57 65
    -61 71
    -66 77
    -70 83
    -74 88
    -78 94
    -82 100
    -86 105
    -89 111
    -93 116
    -97 122
    -100 127
    -103 133
    -106 138
    -109 144
    -112 149
    -115 154
    -118 160
    -121 165
    -123 170
    -126 176
    -128 181
    -130 186
    -132 191
    -134 196
    -136 201
    -138 206
    -140 211
    -141 216
    -143 221
    -144 226
    -145 230
    -147 235
    -148 240
    -149 245
    -150 249
    -150 254
    -151 258
    -152 263
    -152 267
    -153 272
    -153 276
    -153 280
    -153 285
    -153 289
    -153 293
    -153 297
    -153 301
    -153 305
    -152 309
    -152 313
    -151 317
    -151 321
    -150 325
    -149 328
    -148 332
    -147 336
    -146 339
    -145 343
    -144 346
    -142 349
    -141 353
    -140 356
    -138 359
    -137 362
    -135 366
    -133 369
    -131 372
    -130 375
    -128 377
    -126 380
    -124 383
    -122 386
    -119 388
    -117 391
    -115 393
    -113 396
    -110 398
    -108 401
    -105 403
    -103 405
    -100 407
    -98 409
    -95 411
    -92 413
    -89 415
    -87 417
    -84 419
    -81 421
    -78 422
    -75 424
    -72 425
    -69 427
    -66 428
    -63 429
    -60 431
    -56 432
    -53 433
    -50 434
    -47 435
    -44 436
    -40 437
    -37 437
    -34 438
    -30 439
    -27 439
    -24 440
    -20 440
    -17 441
    -14 441
    -10 441
    -7 441
    -3 442
    0 442
    3 442
    7 441
    10 441
    14 441
    17 441
    20 440
    24 440
    27 439
    30 439
    34 438
    37 437
    40 437
    44 436
    47 435
    50 434
    53 433
    56 432
    60 431
    63 429
    66 428
    69 427
    72 425
    75 424
    78 422
    81 421
    84 419
    87 417
    89 415
    92 413
    95 411
    98 409
    100 407
    103 405
    105 403
    108 401
    110 398
    113 396
    115 393
    117 391
    119 388
    122 386
    124 383
    126 380
    128 377
    130 375
    131 372
    133 369
    135 366
    137 362
    138 359
    140 356
    141 353
    142 349
    144 346
    145 343
    146 339
    147 336
    148 332
    149 328
    150 325
    151 321
    151 317
    152 313
    152 309
    153 305
    153 301
    153 297
    153 293
    153 289
    153 285
    153 280
    153 276
    153 272
    152 267
    152 263
    151 258
    150 254
    150 249
    149 245
    148 240
    147 235
    145 230
    144 226
    143 221
    141 216
    140 211
    138 206
    136 201
    134 196
    132 191
    130 186
    128 181
    126 176
    123 170
    121 165
    118 160
    115 154
    112 149
    109 144
    106 138
    103 133
    100 127
    97 122
    93 116
    89 111
    86 105
    82 100
    78 94
    74 88
    70 83
    66 77
    61 71
    57 65
    52 59
    47 54
    43 48
    38 42
    33 36
    27 30
    22 24
    17 18
    11 12
    6 6
    -0 -0
    -6 -6
    -12 -12
    -18 -18
    -24 -24
    -30 -31
    -37 -37
    -43 -43
    -50 -49
    -57 -55
    -63 -62
    -70 -68
    -78 -74
    -85 -80
    -92 -87
    -99 -93
    -107 -99
    -115 -106
    -122 -112
    -130 -118
    -138 -125
    -146 -131
    -154 -137
    -163 -144
    -171 -150
    -180 -157
    -188 -163
    -197 -170
    -206 -176
    -215 -182
    -224 -189
    -233 -195
    -242 -202
    -252 -208
    -261 -215
    -271 -221
    -280 -228
    -290 -234
    -300 -241
    -310 -247
    -320 -254
    -331 -261
    -341 -267
    -351 -274
    -362 -280
    -373 -287
    -383 -293
    -394 -300
    -405 -306
    -416 -313
    -428 -319
    -439 -326
    -450 -333
    -462 -339
    -473 -346
    -485 -352
    -497 -359
    -509 -365
    -521 -372
    -533 -379
    -545 -385
    -557 -392
    -570 -398
    -582 -405
    -595 -411
    -608 -418
    -621 -425
    -633 -431
    -646 -438
    -660 -444
    -673 -451
    -686 -457
    -699 -464
    -713 -470
    -726 -477
    -740 -483
    -754 -490
    -768 -497
    -782 -503
    -796 -510
    -810 -516
    -824 -523
    -838 -529
    -853 -536
    -867 -542
    -882 -548
    -896 -555
    -911 -561
    -926 -568
    -941 -574
    -956 -581
    -971 -587
    -986 -594
    -1002 -600
    -1017 -607
    -1033 -613
    -1048 -619
    -1064 -626
    -1079 -632
    -1095 -638
    -1111 -645
    -1127 -651
    -1143 -658
    -1159 -664
    -1176 -670
    -1192 -677
    -1208 -683
    -1225 -689
    -1241 -696
    -1258 -702
    -1275 -708
    -1291 -714
    -1308 -721
    -1325 -727
    -1342 -733
    -1359 -739
    -1376 -746
    1383 -755
    1366 -748
    1348 -742
    1331 -736
    1315 -730
    1298 -723
    1281 -717
    1264 -711
    1248 -704
    1231 -698
    1215 -692
    1198 -685
    1182 -679
    1166 -673
    1150 -666
    1134 -660
    1118 -654
    1102 -647
    1086 -641
    1070 -634
    1055 -628
    1039 -621
    1024 -615
    1008 -609
    993 -602
    978 -596
    963 -589
    948 -583
    933 -576
    918 -570
    903 -563
    888 -557
    874 -550
    859 -544
    845 -537
    831 -531
    816 -524
    802 -518
    788 -511
    774 -505
    760 -498
    747 -491
    733 -485
    719 -478
    706 -472
    693 -465
    679 -459
    666 -452
    653 -446
    640 -439
    627 -432
    614 -426
    602 -419
    589 -413
    576 -406
    564 -399
    552 -393
    540 -386
    527 -380
    515 -373
    504 -366
    492 -360
    480 -353
    468 -347
    457 -340
    446 -333
    434 -327
    423 -320
    412 -314
    401 -307
    390 -301
    379 -294
    369 -287
    358 -281
    348 -274
    337 -268
    327 -261
    317 -255
    307 -248
    297 -242
    287 -235
    277 -228
    268 -222
    258 -215
    249 -209
    239 -202
    230 -196
    221 -189
    212 -183
    203 -176
    195 -170
    186 -164
    177 -157
    169 -151
    161 -144
    153 -138
    144 -131
    136 -125
    129 -119
    121 -112
    113 -106
    106 -100
    98 -93
    91 -87
    84 -81
    77 -74
    70 -68
    63 -62
    56 -56
    49 -49
    43 -43
    37 -37
    30 -31
    24 -25
    18 -19
    12 -13
    6 -6
    0 -0
    -5 6
    -11 12
    -16 18
    -21 24
    -27 30
    -32 35
    -37 41
    -42 47
    -46 53
    -51 59
    -55 65
    -60 71
    -64 76
    -68 82
    -72 88
    -76 93
    -80 99
    -84 105
    -88 110
    -91 116
    -94 121
    -98 127
    -101 132
    -104 138
    -107 143
    -110 148
    -113 154
    -115 159
    -118 164
    -120 170
    -123 175
    -125 180
    -127 185
    -129 190
    -131 195
    -133 200
    -135 205
    -136 210
    -138 215
    -139 220
    -141 225
    -142 229
    -143 234
    -144 239
    -145 243
    -146 248
    -146 252
    -147 257
    -148 261
    -148 266
    -149 270
    -149 275
    -149 279
    -149 283
    -149 287
    -149 291
    -149 295
    -149 299
    -148 303
    -148 307
    -147 311
    -147 315
    -146 319
    -145 323
    -144 326
    -144 330
    -143 333
    -141 337
    -140 340
    -139 344
    -138 347
    -136 350
    -135 354
    -133 357
    -132 360
    -130 363
    -129 366
    -127 369
    -125 372
    -123 375
    -121 377
    -119 380
    -117 383
    -115 385
    -113 388
    -110 390
    -108 393
    -106 395
    -103 397
    -101 400
    -98 402
    -96 404
    -93 406
    -90 408
    -88 410
    -85 412
    -82 413
    -79 415
    -76 417
    -73 418
    -70 420
    -68 421
    -65 423
    -61 424
    -58 425
    -55 426
    -52 427
    -49 428
    -46 429
    -43 430
    -39 431
    -36 432
    -33 433
    -30 433
    -26 434
    -23 434
    -20 435
    -17 435
    -13 436
    -10 436
    -7 436
    -3 436
    0 436
    3 436
    7 436
    10 436
    13 436
    17 435
    20 435
    23 434
    26 434
    30 433
    33 433
    36 432
    39 431
    43 430
    46 429
    49 428
    52 427
    55 426
    58 425
    61 424
    65 423
    68 421
    70 420
    73 418
    76 417
    79 415
    82 413
    85 412
    88 410
    90 408
    93 406
    96 404
    98 402
    101 400
    103 397
    106 395
    108 393
    110 390
    113 388
    115 385
    117 383
    119 380
    121 377
    123 375
    125 372
    127 369
    129 366
    130 363
    132 360
    133 357
    135 354
    136 350
    138 347
    139 344
    140 340
    141 337
    143 333
    144 330
    144 326
    145 323
    146 319
    147 315
    147 311
    148 307
    148 303
    149 299
    149 295
    149 291
    149 287
    149 283
    149 279
    149 275
    149 270
    148 266
    148 261
    147 257
    146 252
    146 248
    145 243
    144 239
    143 234
    142 229
    141 225
    139 220
    138 215
    136 210
    135 205
    133 200
    131 195
    129 190
    127 185
    125 180
    123 175
    120 170
    118 164
    115 159
    113 154
    110 148
    107 143
    104 138
    101 132
    98 127
    94 121
    91 116
    88 110
    84 105
    80 99
    76 93
    72 88
    68 82
    64 76
    60 71
    55 65
    51 59
    46 53
    42 47
    37 41
    32 35
    27 30
    21 24
    16 18
    11 12
    5 6
    -0 -0
    -6 -6
    -12 -13
    -18 -19
    -24 -25
    -30 -31
    -37 -37
    -43 -43
    -49 -49
    -56 -56
    -63 -62
    -70 -68
    -77 -74
    -84 -81
    -91 -87
    -98 -93
    -106 -100
    -113 -106
    -121 -112
    -129 -119
    -136 -125
    -144 -131
    -153 -138
    -161 -144
    -169 -151
    -177 -157
    -186 -164
    -195 -170
    -203 -176
    -212 -183
    -221 -189
    -230 -196
    -239 -202
    -249 -209
    -258 -215
    -268 -222
    -277 -228
    -287 -235
    -297 -242
    -307 -248
    -317 -255
    -327 -261
    -337 -268
    -348 -274
    -358 -281
    -369 -287
    -379 -294
    -390 -301
    -401 -307
    -412 -314
    -423 -320
    -434 -327
    -446 -333
    -457 -340
    -468 -347
    -480 -353
    -492 -360
    -504 -366
    -515 -373
    -527 -380
    -540 -386
    -552 -393
    -564 -399
    -576 -406
    -589 -413
    -602 -419
    -614 -426
    -627 -432
    -640 -439
    -653 -446
    -666 -452
    -679 -459
    -693 -465
    -706 -472
    -719 -478
    -733 -485
    -747 -491
    -760 -498
    -774 -505
    -788 -511
    -802 -518
    -816 -524
    -831 -531
    -845 -537
    -859 -544
    -874 -550
    -888 -557
    -903 -563
    -918 -570
    -933 -576
    -948 -583
    -963 -589
    -978 -596
    -993 -602
    -1008 -609
    -1024 -615
    -1039 -621
    -1055 -628
    -1070 -634
    -1086 -641
    -1102 -647
    -1118 -654
    -1134 -660
    -1150 -666
    -1166 -673
    -1182 -679
    -1198 -685
    -1215 -692
    -1231 -698
    -1248 -704
    -1264 -711
    -1281 -717
    -1298 -723
    -1315 -730
    -1331 -736
    -1348 -742
    -1366 -748
    -1383 -755
    1389 -764
    1372 -758
    1355 -751
    1338 -745
    1321 -739
    1304 -732
    1287 -726
    1271 -720
    1254 -713
    1237 -707
    1221 -701
    1205 -694
    1188 -688
    1172 -682
    1156 -675
    1140 -669
    1124 -662
    1108 -656
    1092 -649
    1077 -643
    1061 -637
    1045 -630
    1030 -624
    1015 -617
    999 -611
    984 -604
    969 -598
    954 -591
    939 -585
    924 -578
    909 -572
    895 -565
    880 -559
    866 -552
    851 -546
    837 -539
    823 -532
    809 -526
    795 -519
    781 -513
    767 -506
    753 -500
    740 -493
    726 -486
    712 -480
    699 -473
    686 -467
    673 -460
    660 -453
    647 -447
    634 -440
    621 -434
    608 -427
    596 -420
    583 -414
    571 -407
    558 -401
    546 -394
    534 -387
    522 -381
    510 -374
    498 -367
    487 -361
    475 -354
    464 -348
    452 -341
    441 -334
    430 -328
    419 -321
    408 -315
    397 -308
    386 -301
    375 -295
    365 -288
    354 -282
    344 -275
    334 -268
    323 -262
    313 -255
    303 -249
    294 -242
    284 -236
    274 -229
    265 -223
    255 -216
    246 -209
    237 -203
    228 -196
    219 -190
    210 -183
    201 -177
    192 -170
    184 -164
    175 -158
    167 -151
    159 -145
    151 -138
    143 -132
    135 -125
    127 -119
    120 -113
    112 -106
    105 -100
    97 -94
    90 -87
    83 -81
    76 -75
    69 -69
    62 -62
    56 -56
    49 -50
    43 -44
    36 -38
    30 -31
    24 -25
    18 -19
    12 -13
    6 -7
    1 -1
    -5 5
    -10 11
    -15 17
    -21 23
    -26 29
    -31 35
    -36 41
    -40 47
    -45 53
    -50 58
    -54 64
    -58 70
    -63 76
    -67 81
    -71 87
    -75 93
    -78 98
    -82 104
    -86 110
    -89 115
    -92 121
    -96 126
    -99 132
    -102 137
    -105 142
    -107 148
    -110 153
    -113 158
    -115 163
    -118 169
    -120 174
    -122 179
    -124 184
    -126 189
    -128 194
    -130 199
    -131 204
    -133 209
    -134 214
    -136 219
    -137 223
    -138 228
    -139 233
    -140 237
    -141 242
    -142 247
    -143 251
    -143 256
    -144 260
    -144 264
    -145 269
    -145 273
    -145 277
    -145 281
    -145 285
    -145 290
    -145 294
    -144 298
    -144 302
    -143 305
    -143 309
    -142 313
    -142 317
    -141 320
    -140 324
    -139 328
    -138 331
    -137 335
    -136 338
    -134 341
    -133 345
    -132 348
    -130 351
    -129 354
    -127 357
    -126 360
    -124 363
    -122 366
    -120 369
    -118 372
    -116 374
    -114 377
    -112 380
    -110 382
    -108 385
    -106 387
    -103 389
    -101 392
    -98 394
    -96 396
    -93 398
    -91 400
    -88 402
    -86 404
    -83 406
    -80 408
    -78 409
    -75 411
    -72 413
    -69 414
    -66 416
    -63 417
    -60 418
    -57 419
    -54 421
    -51 422
    -48 423
    -45 424
    -42 425
    -39 426
    -36 426
    -32 427
    -29 428
    -26 428
    -23 429
    -20 429
    -16 430
    -13 430
    -10 430
    -7 430
    -3 430
    0 430
    3 430
    7 430
    10 430
    13 430
    16 430
    20 429
    23 429
    26 428
    29 428
    32 427
    36 426
    39 426
    42 425
    45 424
    48 423
    51 422
    54 421
    57 419
    60 418
    63 417
    66 416
    69 414
    72 413
    75 411
    78 409
    80 408
    83 406
    86 404
    88 402
    91 400
    93 398
    96 396
    98 394
    101 392
    103 389
    106 387
    108 385
    110 382
    112 380
    114 377
    116 374
    118 372
    120 369
    122 366
    124 363
    126 360
    127 357
    129 354
    130 351
    132 348
    133 345
    134 341
    136 338
    137 335
    138 331
    139 328
    140 324
    141 320
    142 317
    142 313
    143 309
    143 305
    144 302
    144 298
    145 294
    145 290
    145 285
    145 281
    145 277
    145 273
    145 269
    144 264
    144 260
    143 256
    143 251
    142 247
    141 242
    140 237
    139 233
    138 228
    137 223
    136 219
    134 214
    133 209
    131 204
    130 199
    128 194
    126 189
    124 184
    122 179
    120 174
    118 169
    115 163
    113 158
    110 153
    107 148
    105 142
    102 137
    99 132
    96 126
    92 121
    89 115
    86 110
    82 104
    78 98
    75 93
    71 87
    67 81
    63 76
    58 70
    54 64
    50 58
    45 53
    40 47
    36 41
    31 35
    26 29
    21 23
    15 17
    10 11
    5 5
    -1 -1
    -6 -7
    -12 -13
    -18 -19
    -24 -25
    -30 -31
    -36 -38
    -43 -44
    -49 -50
    -56 -56
    -62 -62
    -69 -69
    -76 -75
    -83 -81
    -90 -87
    -97 -94
    -105 -100
    -112 -106
    -120 -113
    -127 -119
    -135 -125
    -143 -132
    -151 -138
    -159 -145
    -167 -151
    -175 -158
    -184 -164
    -192 -170
    -201 -177
    -210 -183
    -219 -190
    -228 -196
    -237 -203
    -246 -209
    -255 -216
    -265 -223
    -274 -229
    -284 -236
    -294 -242
    -303 -249
    -313 -255
    -323 -262
    -334 -268
    -344 -275
    -354 -282
    -365 -288
    -375 -295
    -386 -301
    -397 -308
    -408 -315
    -419 -321
    -430 -328
    -441 -334
    -452 -341
    -464 -348
    -475 -354
    -487 -361
    -498 -367
    -510 -374
    -522 -381
    -534 -387
    -546 -394
    -558 -401
    -571 -407
    -583 -414
    -596 -420
    -608 -427
    -621 -434
    -634 -440
    -647 -447
    -660 -453
    -673 -460
    -686 -467
    -699 -473
    -712 -480
    -726 -486
    -740 -493
    -753 -500
    -767 -506
    -781 -513
    -795 -519
    -809 -526
    -823 -532
    -837 -539
    -851 -546
    -866 -552
    -880 -559
    -895 -565
    -909 -572
    -924 -578
    -939 -585
    -954 -591
    -969 -598
    -984 -604
    -999 -611
    -1015 -617
    -1030 -624
    -1045 -630
    -1061 -637
    -1077 -643
    -1092 -649
    -1108 -656
    -1124 -662
    -1140 -669
    -1156 -675
    -1172 -682
    -1188 -688
    -1205 -694
    -1221 -701
    -1237 -707
    -1254 -713
    -1271 -720
    -1287 -726
    -1304 -732
    -1321 -739
    -1338 -745
    -1355 -751
    -1372 -758
    -1389 -764
    1395 -773
    1378 -767
    1361 -761
    1344 -754
    1327 -748
    1310 -742
    1294 -735
    1277 -729
    1260 -722
    1244 -716
    1227 -710
    1211 -703
    1195 -697
    1178 -690
    1162 -684
    1146 -678
    1130 -671
    1115 -665
    1099 -658
    1083 -652
    1067 -645
    1052 -639
    1036 -632
    1021 -626
    1006 -619
    991 -613
    976 -606
    961 -600
    946 -593
    931 -587
    916 -580
    901 -574
    887 -567
    872 -560
    858 -554
    844 -547
    829 -541
    815 -534
    801 -528
    787 -521
    774 -514
    760 -508
    746 -501
    733 -495
    719 -488
    706 -481
    692 -475
    679 -468
    666 -461
    653 -455
    640 -448
    628 -442
    615 -435
    602 -428
    590 -422
    577 -415
    565 -408
    553 -402
    541 -395
    529 -388
    517 -382
    505 -375
    493 -369
    482 -362
    470 -355
    459 -349
    447 -342
    436 -335
    425 -329
    414 -322
    403 -315
    392 -309
    382 -302
    371 -296
    361 -289
    350 -282
    340 -276
    330 -269
    320 -263
    310 -256
    300 -249
    290 -243
    281 -236
    271 -230
    262 -223
    252 -217
    243 -210
    234 -204
    225 -197
    216 -191
    208 -184
    199 -178
    190 -171
    182 -165
    174 -158
    165 -152
    157 -145
    149 -139
    141 -132
    134 -126
    126 -120
    118 -113
    111 -107
    104 -101
    96 -94
    89 -88
    82 -82
    75 -75
    69 -69
    62 -63
    55 -57
    49 -50
    43 -44
    36 -38
    30 -32
    24 -26
    18 -20
    13 -14
    7 -7
    1 -1
    -4 5
    -9 11
    -15 17
    -20 23
    -25 28
    -30 34
    -35 40
    -39 46
    -44 52
    -48 58
    -53 64
    -57 69
    -61 75
    -65 81
    -69 86
    -73 92
    -76 98
    -80 103
    -83 109
    -87 114
    -90 120
    -93 125
    -96 131
    -99 136
    -102 141
    -105 147
    -107 152
    -110 157
    -112 162
    -115 168
    -117 173
    -119 178
    -121 183
    -123 188
    -125 193
    -126 198
    -128 203
    -130 208
    -131 212
    -132 217
    -134 222
    -135 227
    -136 231
    -137 236
    -137 240
    -138 245
    -139 249
    -139 254
    -140 258
    -140 263
    -140 267
    -141 271
    -141 275
    -141 279
    -141 284
    -141 288
    -140 292
    -140 296
    -140 299
    -139 303
    -139 307
    -138 311
    -137 314
    -136 318
    -135 322
    -134 325
    -133 329
    -132 332
    -131 335
    -130 339
    -129 342
    -127 345
    -126 348
    -124 351
    -123 354
    -121 357
    -119 360
    -117 363
    -116 366
    -114 369
    -112 371
    -110 374
    -108 376
    -105 379
    -103 381
    -101 384
    -99 386
    -96 388
    -94 390
    -91 392
    -89 394
    -86 396
    -84 398
    -81 400
    -79 402
    -76 404
    -73 405
    -70 407
    -68 408
    -65 410
    -62 411
    -59 412
    -56 414
    -53 415
    -50 416
    -47 417
    -44 418
    -41 419
    -38 420
    -35 421
    -32 421
    -29 422
    -25 422
    -22 423
    -19 423
    -16 424
    -13 424
    -10 424
    -6 425
    -3 425
    0 425
    3 425
    6 425
    10 424
    13 424
    16 424
    19 423
    22 423
    25 422
    29 422
    32 421
    35 421
    38 420
    41 419
    44 418
    47 417
    50 416
    53 415
    56 414
    59 412
    62 411
    65 410
    68 408
    70 407
    73 405
    76 404
    79 402
    81 400
    84 398
    86 396
    89 394
    91 392
    94 390
    96 388
    99 386
    101 384
    103 381
    105 379
    108 376
    110 374
    112 371
    114 369
    116 366
    117 363
    119 360
    121 357
    123 354
    124 351
    126 348
    127 345
    129 342
    130 339
    131 335
    132 332
    133 329
    134 325
    135 322
    136 318
    137 314
    138 311
    139 307
    139 303
    140 299
    140 296
    140 292
    141 288
    141 284
    141 279
    141 275
    141 271
    140 267
    140 263
    140 258
    139 254
    139 249
    138 245
    137 240
    137 236
    136 231
    135 227
    134 222
    132 217
    131 212
    130 208
    128 203
    126 198
    125 193
    123 188
    121 183
    119 178
    117 173
    115 168
    112 162
    110 157
    107 152
    105 147
    102 141
    99 136
    96 131
    93 125
    90 120
    87 114
    83 109
    80 103
    76 98
    73 92
    69 86
    65 81
    61 75
    57 69
    53 64
    48 58
    44 52
    39 46
    35 40
    30 34
    25 28
    20 23
    15 17
    9 11
    4 5
    -1 -1
    -7 -7
    -13 -14
    -18 -20
    -24 -26
    -30 -32
    -36 -38
    -43 -44
    -49 -50
    -55 -57
    -62 -63
    -69 -69
    -75 -75
    -82 -82
    -89 -88
    -96 -94
    -104 -101
    -111 -107
    -118 -113
    -126 -120
    -134 -126
    -141 -132
    -149 -139
    -157 -145
    -165 -152
    -174 -158
    -182 -165
    -190 -171
    -199 -178
    -208 -184
    -216 -191
    -225 -197
    -234 -204
    -243 -210
    -252 -217
    -262 -223
    -271 -230
    -281 -236
    -290 -243
    -300 -249
    -310 -256
    -320 -263
    -330 -269
    -340 -276
    -350 -282
    -361 -289
    -371 -296
    -382 -302
    -392 -309
    -403 -315
    -414 -322
    -425 -329
    -436 -335
    -447 -342
    -459 -349
    -470 -355
    -482 -362
    -493 -369
    -505 -375
    -517 -382
    -529 -388
    -541 -395
    -553 -402
    -565 -408
    -577 -415
    -590 -422
    -602 -428
    -615 -435
    -628 -442
    -640 -448
    -653 -455
    -666 -461
    -679 -468
    -692 -475
    -706 -481
    -719 -488
    -733 -495
    -746 -501
    -760 -508
    -774 -514
    -787 -521
    -801 -528
    -815 -534
    -829 -541
    -844 -547
    -858 -554
    -872 -560
    -887 -567
    -901 -574
    -916 -580
    -931 -587
    -946 -593
    -961 -600
    -976 -606
    -991 -613
    -1006 -619
    -1021 -626
    -1036 -632
    -1052 -639
    -1067 -645
    -1083 -652
    -1099 -658
    -1115 -665
    -1130 -671
    -1146 -678
    -1162 -684
    -1178 -690
    -1195 -697
    -1211 -703
    -1227 -710
    -1244 -716
    -1260 -722
    -1277 -729
    -1294 -735
    -1310 -742
    -1327 -748
    -1344 -754
    -1361 -761
    -1378 -767
    -1395 -773
    1402 -783
    1384 -776
    1367 -770
    1350 -764
    1334 -757
    1317 -751
    1300 -744
    1283 -738
    1267 -732
    1250 -725
    1234 -719
    1217 -712
    1201 -706
    1185 -699
    1169 -693
    1153 -687
    1137 -680
    1121 -674
    1105 -667
    1090 -661
    1074 -654
    1058 -648
    1043 -641
    1028 -635
    1012 -628
    997 -621
    982 -615
    967 -608
    952 -602
    937 -595
    923 -589
    908 -582
    893 -576
    879 -569
    865 -562
    850 -556
    836 -549
    822 -543
    808 -536
    794 -529
    780 -523
    766 -516
    753 -509
    739 -503
    726 -496
    712 -490
    699 -483
    686 -476
    673 -470
    660 -463
    647 -456
    634 -450
    621 -443
    609 -436
    596 -430
    584 -423
    572 -416
    559 -410
    547 -403
    535 -396
    523 -390
    512 -383
    500 -376
    488 -370
    477 -363
    465 -356
    454 -350
    443 -343
    432 -336
    421 -330
    410 -323
    399 -316
    388 -310
    378 -303
    367 -297
    357 -290
    347 -283
    337 -277
    326 -270
    317 -263
    307 -257
    297 -250
    287 -244
    278 -237
    268 -231
    259 -224
    250 -217
    241 -211
    232 -204
    223 -198
    214 -191
    205 -185
    197 -178
    188 -172
    180 -165
    172 -159
    164 -152
    156 -146
    148 -139
    140 -133
    132 -127
    125 -120
    117 -114
    110 -108
    103 -101
    96 -95
    89 -89
    82 -82
    75 -76
    68 -70
    62 -63
    55 -57
    49 -51
    43 -45
    36 -39
    30 -33
    24 -26
    19 -20
    13 -14
    7 -8
    2 -2
    -3 4
    -9 10
    -14 16
    -19 22
    -24 28
    -29 34
    -33 40
    -38 45
    -42 51
    -47 57
    -51 63
    -55 69
    -59 74
    -63 80
    -67 86
    -71 91
    -74 97
    -78 102
    -81 108
    -85 113
    -88 119
    -91 124
    -94 130
    -97 135
    -99 140
    -102 146
    -105 151
    -107 156
    -110 161
    -112 166
    -114 172
    -116 177
    -118 182
    -120 187
    -122 192
    -123 196
    -125 201
    -126 206
    -128 211
    -129 216
    -130 220
    -131 225
    -132 230
    -133 234
    -134 239
    -134 243
    -135 248
    -135 252
    -136 256
    -136 261
    -136 265
    -137 269
    -137 273
    -137 277
    -137 281
    -136 285
    -136 289
    -136 293
    -135 297
    -135 301
    -134 305
    -133 308
    -133 312
    -132 316
    -131 319
    -130 323
    -129 326
    -128 329
    -127 333
    -125 336
    -124 339
    -123 342
    -121 345
    -120 348
    -118 351
    -116 354
    -115 357
    -113 360
    -111 363
    -109 365
    -107 368
    -105 370
    -103 373
    -101 375
    -99 378
    -96 380
    -94 382
    -92 384
    -89 386
    -87 388
    -84 390
    -82 392
    -79 394
    -77 396
    -74 398
    -71 399
    -69 401
    -66 402
    -63 404
    -60 405
    -58 406
    -55 408
    -52 409
    -49 410
    -46 411
    -43 412
    -40 413
    -37 414
    -34 415
    -31 415
    -28 416
    -25 417
    -22 417
    -19 417
    -16 418
    -12 418
    -9 418
    -6 419
    -3 419
    0 419
    3 419
    6 419
    9 418
    12 418
    16 418
    19 417
    22 417
    25 417
    28 416
    31 415
    34 415
    37 414
    40 413
    43 412
    46 411
    49 410
    52 409
    55 408
    58 406
    60 405
    63 404
    66 402
    69 401
    71 399
    74 398
    77 396
    79 394
    82 392
    84 390
    87 388
    89 386
    92 384
    94 382
    96 380
    99 378
    101 375
    103 373
    105 370
    107 368
    109 365
    111 363
    113 360
    115 357
    116 354
    118 351
    120 348
    121 345
    123 342
    124 339
    125 336
    127 333
    128 329
    129 326
    130 323
    131 319
    132 316
    133 312
    133 308
    134 305
    135 301
    135 297
    136 293
    136 289
    136 285
    137 281
    137 277
    137 273
    137 269
    136 265
    136 261
    136 256
    135 252
    135 248
    134 243
    134 239
    133 234
    132 230
    131 225
    130 220
    129 216
    128 211
    126 206
    125 201
    123 196
    122 192
    120 187
    118 182
    116 177
    114 172
    112 166
    110 161
    107 156
    105 151
    102 146
    99 140
    97 135
    94 130
    91 124
    88 119
    85 113
    81 108
    78 102
    74 97
    71 91
    67 86
    63 80
    59 74
    55 69
    51 63
    47 57
    42 51
    38 45
    33 40
    29 34
    24 28
    19 22
    14 16
    9 10
    3 4
    -2 -2
    -7 -8
    -13 -14
    -19 -20
    -24 -26
    -30 -33
    -36 -39
    -43 -45
    -49 -51
    -55 -57
    -62 -63
    -68 -70
    -75 -76
    -82 -82
    -89 -89
    -96 -95
    -103 -101
    -110 -108
    -117 -114
    -125 -120
    -132 -127
    -140 -133
    -148 -139
    -156 -146
    -164 -152
    -172 -159
    -180 -165
    -188 -172
    -197 -178
    -205 -185
    -214 -191
    -223 -198
    -232 -204
    -241 -211
    -250 -217
    -259 -224
    -268 -231
    -278 -237
    -287 -244
    -297 -250
    -307 -257
    -317 -263
    -326 -270
    -337 -277
    -347 -283
    -357 -290
    -367 -297
    -378 -303
    -388 -310
    -399 -316
    -410 -323
    -421 -330
    -432 -336
    -443 -343
    -454 -350
    -465 -356
    -477 -363
    -488 -370
    -500 -376
    -512 -383
    -523 -390
    -535 -396
    -547 -403
    -559 -410
    -572 -416
    -584 -423
    -596 -430
    -609 -436
    -621 -443
    -634 -450
    -647 -456
    -660 -463
    -673 -470
    -686 -476
    -699 -483
    -712 -490
    -726 -496
    -739 -503
    -753 -509
    -766 -516
    -780 -523
    -794 -529
    -808 -536
    -822 -543
    -836 -549
    -850 -556
    -865 -562
    -879 -569
    -893 -576
    -908 -582
    -923 -589
    -937 -595
    -952 -602
    -967 -608
    -982 -615
    -997 -621
    -1012 -628
    -1028 -635
    -1043 -641
    -1058 -648
    -1074 -654
    -1090 -661
    -1105 -667
    -1121 -674
    -1137 -680
    -1153 -687
    -1169 -693
    -1185 -699
    -1201 -706
    -1217 -712
    -1234 -719
    -1250 -725
    -1267 -732
    -1283 -738
    -1300 -744
    -1317 -751
    -1334 -757
    -1350 -764
    -1367 -770
    -1384 -776
    -1402 -783
    1408 -792
    1391 -786
    1374 -779
    1357 -773
    1340 -766
    1323 -760
    1306 -754
    1290 -747
    1273 -741
    1257 -734
    1240 -728
    1224 -721
    1208 -715
    1191 -709
    1175 -702
    1159 -696
    1143 -689
    1127 -683
    1112 -676
    1096 -670
    1080 -663
    1065 -656
    1049 -650
    1034 -643
    1019 -637
    1004 -630
    989 -624
    974 -617
    959 -611
    944 -604
    929 -597
    915 -591
    900 -584
    886 -578
    871 -571
    857 -564
    843 -558
    829 -551
    815 -544
    801 -538
    787 -531
    773 -524
    759 -518
    746 -511
    732 -504
    719 -498
    706 -491
    693 -484
    679 -478
    667 -471
    654 -464
    641 -458
    628 -451
    616 -444
    603 -438
    591 -431
    578 -424
    566 -418
    554 -411
    542 -404
    530 -398
    518 -391
    507 -384
    495 -378
    483 -371
    472 -364
    461 -357
    450 -351
    438 -344
    427 -337
    417 -331
    406 -324
    395 -317
    384 -311
    374 -304
    364 -297
    353 -291
    343 -284
    333 -278
    323 -271
    313 -264
    304 -258
    294 -251
    284 -245
    275 -238
    266 -231
    256 -225
    247 -218
    238 -212
    229 -205
    221 -199
    212 -192
    203 -186
    195 -179
    187 -173
    178 -166
    170 -160
    162 -153
    154 -147
    146 -140
    139 -134
    131 -127
    124 -121
    116 -115
    109 -108
    102 -102
    95 -96
    88 -89
    81 -83
    74 -77
    68 -70
    61 -64
    55 -58
    49 -52
    43 -46
    36 -39
    31 -33
    25 -27
    19 -21
    13 -15
    8 -9
    3 -3
    -3 3
    -8 9
    -13 15
    -18 21
    -23 27
    -27 33
    -32 39
    -37 45
    -41 50
    -45 56
    -49 62
    -54 68
    -58 73
    -61 79
    -65 85
    -69 90
    -72 96
    -76 101
    -79 107
    -82 112
    -85 118
    -88 123
    -91 128
    -94 134
    -97 139
    -99 144
    -102 150
    -104 155
    -107 160
    -109 165
    -111 170
    -113 175
    -115 180
    -117 185
    -118 190
    -120 195
    -121 200
    -123 205
    -124 209
    -125 214
    -126 219
    -127 223
    -128 228
    -129 232
    -130 237
    -131 241
    -131 246
    -132 250
    -132 254
    -132 259
    -132 263
    -133 267
    -133 271
    -133 275
    -132 279
    -132 283
    -132 287
    -131 291
    -131 295
    -130 298
    -130 302
    -129 306
    -128 309
    -127 313
    -127 316
    -126 320
    -124 323
    -123 326
    -122 330
    -121 333
    -119 336
    -118 339
    -117 342
    -115 345
    -113 348
    -112 351
    -110 354
    -108 356
    -106 359
    -104 362
    -103 364
    -100 367
    -98 369
    -96 371
    -94 374
    -92 376
    -90 378
    -87 380
    -85 382
    -83 384
    -80 386
    -78 388
    -75 390
    -72 391
    -70 393
    -67 395
    -65 396
    -62 398
    -59 399
    -56 400
    -54 402
    -51 403
    -48 404
    -45 405
    -42 406
    -39 407
    -36 408
    -33 408
    -30 409
    -27 410
    -24 410
    -21 411
    -18 411
    -15 412
    -12 412
    -9 412
    -6 412
    -3 413
    0 413
    3 413
    6 412
    9 412
    12 412
    15 412
    18 411
    21 411
    24 410
    27 410
    30 409
    33 408
    36 408
    39 407
    42 406
    45 405
    48 404
    51 403
    54 402
    56 400
    59 399
    62 398
    65 396
    67 395
    70 393
    72 391
    75 390
    78 388
    80 386
    83 384
    85 382
    87 380
    90 378
    92 376
    94 374
    96 371
    98 369
    100 367
    103 364
    104 362
    106 359
    108 356
    110 354
    112 351
    113 348
    115 345
    117 342
    118 339
    119 336
    121 333
    122 330
    123 326
    124 323
    126 320
    127 316
    127 313
    128 309
    129 306
    130 302
    130 298
    131 295
    131 291
    132 287
    132 283
    132 279
    133 275
    133 271
    133 267
    132 263
    132 259
    132 254
    132 250
    131 246
    131 241
    130 237
    129 232
    128 228
    127 223
    126 219
    125 214
    124 209
    123 205
    121 200
    120 195
    118 190
    117 185
    115 180
    113 175
    111 170
    109 165
    107 160
    104 155
    102 150
    99 144
    97 139
    94 134
    91 128
    88 123
    85 118
    82 112
    79 107
    76 101
    72 96
    69 90
    65 85
    61 79
    58 73
    54 68
    49 62
    45 56
    41 50
    37 45
    32 39
    27 33
    23 27
    18 21
    13 15
    8 9
    3 3
    -3 -3
    -8 -9
    -13 -15
    -19 -21
    -25 -27
    -31 -33
    -36 -39
    -43 -46
    -49 -52
    -55 -58
    -61 -64
    -68 -70
    -74 -77
    -81 -83
    -88 -89
    -95 -96
    -102 -102
    -109 -108
    -116 -115
    -124 -121
    -131 -127
    -139 -134
    -146 -140
    -154 -147
    -162 -153
    -170 -160
    -178 -166
    -187 -173
    -195 -179
    -203 -186
    -212 -192
    -221 -199
    -229 -205
    -238 -212
    -247 -218
    -256 -225
    -266 -231
    -275 -238
    -284 -245
    -294 -251
    -304 -258
    -313 -264
    -323 -271
    -333 -278
    -343 -284
    -353 -291
    -364 -297
    -374 -304
    -384 -311
    -395 -317
    -406 -324
    -417 -331
    -427 -337
    -438 -344
    -450 -351
    -461 -357
    -472 -364
    -483 -371
    -495 -378
    -507 -384
    -518 -391
    -530 -398
    -542 -404
    -554 -411
    -566 -418
    -578 -424
    -591 -431
    -603 -438
    -616 -444
    -628 -451
    -641 -458
    -654 -464
    -667 -471
    -679 -478
    -693 -484
    -706 -491
    -719 -498
    -732 -504
    -746 -511
    -759 -518
    -773 -524
    -787 -531
    -801 -538
    -815 -544
    -829 -551
    -843 -558
    -857 -564
    -871 -571
    -886 -578
    -900 -584
    -915 -591
    -929 -597
    -944 -604
    -959 -611
    -974 -617
    -989 -624
    -1004 -630
    -1019 -637
    -1034 -643
    -1049 -650
    -1065 -656
    -1080 -663
    -1096 -670
    -1112 -676
    -1127 -683
    -1143 -689
    -1159 -696
    -1175 -702
    -1191 -709
    -1208 -715
    -1224 -721
    -1240 -728
    -1257 -734
    -1273 -741
    -1290 -747
    -1306 -754
    -1323 -760
    -1340 -766
    -1357 -773
    -1374 -779
    -1391 -786
    -1408 -792
    我运行"run_app_single_cam.sh"以获取 YUV 文件。
    它显示"YUV 输入被选择。 将绕过 VISS 和 AEWB 节点。" 运行  “run_app_single_cam.sh" 时。
    以下是我的 YUV 图像文件。
    LDC 的输入:
    e2e.ti.com/.../ldc_5F00_input.zip
    LDC 的输出
    e2e.ti.com/.../ldc_5F00_output.zip
    打开 YUV 命令。
    ffplay -f rawvideo -video_size 1920x1080 -pixel_format uyvy422 cap 0000.yUV
    ffplay -f rawvideo -video_size 1920x1080 -pixel_format nv12 img_LDC_0001.yUV
    LDC 的输出在顶部中间和底部中间具有失真。
    可以给我建议吗?
    -Jason
    您好 Jason、
    感谢您分享 YUV 图像!
    在输出图像中正确纠正镜头失真。
    顶部中间和底部中间部分超出输入图像边界。
    在这种情况下、LDC H/W 重复边界像素。
    尊敬的 Gang:
    感谢您的回复。
    >>顶部中间部分和底部中间部分超出输入图像边界。
    >LDC H/W 在这种情况下重复边界像素。
    如何删除重复的边界像素?
    我可以修改一些参数以消除重复吗?
    可以给我建议吗?
    -Jason
    这些像素位置超出输入图像边界。
    LDC H/W 通过重复边界像素自动填充这些像素。
    如果在输出视图中没有任何内容、则必须减小输出视图的大小、以便整个视图位于输入图像内。
    尊敬的 Gang:
    我遵循你的建议。
    我减小了输出视图的尺寸。
    我修改  了 APP_SINGLE_CAM_COMN.h 的 LDC_TABLE 高度
    LDC_TABLE 高度从1080更改为880。
    #define LDC_TABLE_WIDTH             (1920)
    //#define LDC_TABLE_HEIGHT            (1080)
    #define LDC_TABLE_HEIGHT            (880)
    中下失真消失。
    但中上失真不会消失。
    以下是 YUV 文件
    输入 YUV:
    e2e.ti.com/.../6180.input.zip
    输出 YUV:
    e2e.ti.com/.../5824.output.zip
    打开 YUV 命令:
    ffplay -f rawvideo -video_size 1920x880 -pixel_format nv12 img_LDC_0000.yUV
    如何消除 有关 run_app_single_cam.sh 的中上失真?
    我需要修改什么代码?
    可以给我建议吗?
    非常感谢。
    -Jason
    您好 Jason、
    看起来您正在切断输出图像的底部。
    通过减小输出视图的尺寸、我的意思是在 MATLAB 脚本中使用较小的"s"值。
    例如、您可以尝试 s=1.6、1.7、1.8等
    输出图像尺寸仍然相同、但输出 FoV 更小。
    尊敬的 Gang:
    我将"s"从1更改为0.8。
    它消除了顶部中间和底部中间的失真。
    非常感谢。
    -Jason
