尊敬的专家
我使用 RMII phy 与 cpsw9g 连接。 使用 外部参考时钟的 Phy、这是图。
这是我 的"RMII_REF_CLK"引脚多路复用配置。
root@j7-evm:~# devmem2 0x0011c0ac /dev/mem opened. Memory mapped at address 0xffff90a6c000. Read at address 0x0011C0AC (0xffff90a6c0ac): 0x00050005
使用"ethtool -t"和"/opt/vx_app_arm_remote_log.out "收集统计数据
root@j7-evm:~# ethtool -t eth1 The test result is PASS The test extra info: RPMSG Ping test 0 RPMSG Read reg 0 RPMSG Dump stat 0
root@j7-evm:~# /opt/vx_app_arm_remote_log.out [MCU2_0] 15588.688913 s: CIO: Init ... Done !!! [MCU2_0] 15588.689001 s: ### CPU Frequency = 1000000000 Hz [MCU2_0] 15588.689046 s: APP: Init ... !!! [MCU2_0] 15588.689074 s: SCICLIENT: Init ... !!! [MCU2_0] 15588.689355 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [MCU2_0] 15588.689413 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_0] 15588.689450 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_0] 15588.689487 s: SCICLIENT: Init ... Done !!! [MCU2_0] 15588.689516 s: UDMA: Init ... !!! [MCU2_0] 15588.690984 s: UDMA: Init ... Done !!! [MCU2_0] 15588.691062 s: MEM: Init ... !!! [MCU2_0] 15588.691111 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ d9000000 of size 16777216 bytes !!! [MCU2_0] 15588.691192 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000000) @ 3600000 of size 262144 bytes !!! [MCU2_0] 15588.691256 s: MEM: Init ... Done !!! [MCU2_0] 15588.691282 s: IPC: Init ... !!! [MCU2_0] 15588.691347 s: IPC: 6 CPUs participating in IPC !!! [MCU2_0] 15588.691400 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_0] 15601.485555 s: IPC: HLOS is ready !!! [MCU2_0] 15601.501634 s: IPC: Init ... Done !!! [MCU2_0] 15601.501713 s: APP: Syncing with 5 CPUs ... !!! [MCU2_0] 15601.993970 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_0] 15601.994236 s: REMOTE_SERVICE: Init ... !!! [MCU2_0] 15601.996231 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_0] 15601.996306 s: ETHFW: Init ... !!! [MCU2_0] 15601.996340 s: jinmin----- my init [MCU2_0] 15601.996368 s: jinmin--- enetBridgeEnabled=0,gesiEnabled=1,qenetEnabled=0,serdesAllowed=0,uartAllowed=0,i2cAllowed=0 [MCU2_0] 15602.247745 s: jinmin----- Detec gesi qenet=1,0 [MCU2_0] 15602.247828 s: jinmin--- enetBridgeEnabled=0,gesiEnabled=1,qenetEnabled=0,serdesAllowed=0,uartAllowed=0,i2cAllowed=0 [MCU2_0] 15602.247962 s: jinmin--- enetType=6 [MCU2_0] 15602.248592 s: Warning: Using 6 MAC address(es) from static pool [MCU2_0] 15602.248699 s: ETHFW: Shared multicasts (software fanout): [MCU2_0] 15602.248749 s: 01:00:5e:00:00:01 [MCU2_0] 15602.248799 s: 01:00:5e:00:00:fb [MCU2_0] 15602.248845 s: 01:00:5e:00:00:fc [MCU2_0] 15602.248891 s: 33:33:00:00:00:01 [MCU2_0] 15602.248936 s: 33:33:ff:1d:92:c2 [MCU2_0] 15602.248981 s: 01:80:c2:00:00:00 [MCU2_0] 15602.249027 s: 01:80:c2:00:00:03 [MCU2_0] 15602.249074 s: ETHFW: Reserved multicasts: [MCU2_0] 15602.249103 s: 01:80:c2:00:00:0e [MCU2_0] 15602.249149 s: 01:1b:19:00:00:00 [MCU2_0] 15602.249406 s: EnetMcm: CPSW_9G on MAIN NAVSS [MCU2_0] 15602.262484 s: PHY 0 is alive [MCU2_0] 15602.262597 s: PHY 2 is alive [MCU2_0] 15602.262659 s: PHY 4 is alive [MCU2_0] 15602.262714 s: PHY 6 is alive [MCU2_0] 15602.262869 s: jinmin----- macport=3 [MCU2_0] 15602.262906 s: jinmin----- coreID=3 [MCU2_0] 15602.262937 s: jinmin----- numVirtPorts=2 [MCU2_0] 15602.262969 s: jinmin----- numAutosarVirtPorts=1 [MCU2_0] 15602.263003 s: jinmin----- numPorts=1 [MCU2_0] 15602.263033 s: jinmin----- instId=0 [MCU2_0] 15602.263457 s: EnetPhy_bindDriver: PHY 6: OUI:006037 Model:10 Ver:02 <-> 'vsc8514' [MCU2_0] 15602.263554 s: EnetPhy_bindDriver: PHY 6: OUI:006037 Model:10 Ver:02 <-> 'dp83822' [MCU2_0] 15602.263639 s: EnetPhy_bindDriver: PHY 6: OUI:006037 Model:10 Ver:02 <-> 'dp83867' [MCU2_0] 15602.263710 s: EnetPhy_bindDriver: PHY 6: OUI:006037 Model:10 Ver:02 <-> 'tja1101' [MCU2_0] 15602.263778 s: EnetPhy_bindDriver: PHY 6: OUI:006037 Model:10 Ver:02 <-> 'tja1101' : OK [MCU2_0] 15602.265519 s: [MCU2_0] ETHFW Version : 0.02.00 [MCU2_0] 15602.265603 s: ETHFW Build Date: Jan 18, 2023 [MCU2_0] 15602.265639 s: ETHFW Build Time: 11:39:00 [MCU2_0] 15602.265668 s: ETHFW Commit SHA: a2361245 [MCU2_0] 15602.265746 s: ETHFW: Init ... DONE !!! [MCU2_0] 15602.265787 s: ETHFW: Remove server Init ... !!! [MCU2_0] 15602.265981 s: CpswProxyServer: Virtual port configuration: [MCU2_0] 15602.266041 s: mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0 [MCU2_0] 15602.266091 s: mpu_1_0 <-> MAC port 4: mpu_1_0_ethmac-device-4 [MCU2_0] 15602.267036 s: CpswProxyServer: initialization completed (core: mcu2_0) [MCU2_0] 15602.267113 s: ETHFW: Remove server Init ... DONE !!! [MCU2_0] 15602.268358 s: Starting lwIP, local interface IP is dhcp-enabled [MCU2_0] 15602.275186 s: Host MAC address: 70:ff:76:1d:92:c3 [MCU2_0] 15602.279693 s: [LWIPIF_LWIP] Enet LLD netif initialized successfully [MCU2_0] 15602.310326 s: [LWIPIF_LWIP_IC] Interface started successfully [MCU2_0] 15602.310421 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS [MCU2_0] 15602.321597 s: FVID2: Init ... !!! [MCU2_0] 15602.321705 s: FVID2: Init ... Done !!! [MCU2_0] 15602.321762 s: DSS: Init ... !!! [MCU2_0] 15602.321793 s: DSS: Display type is eDP !!! [MCU2_0] 15602.321825 s: DSS: M2M Path is enabled !!! [MCU2_0] 15602.321854 s: DSS: SoC init ... !!! [MCU2_0] 15602.321881 s: SCICLIENT: Sciclient_pmSetModuleState module=152 state=2 [MCU2_0] 15602.322082 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.322129 s: SCICLIENT: Sciclient_pmSetModuleState module=297 state=2 [MCU2_0] 15602.322313 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.322349 s: SCICLIENT: Sciclient_pmSetModuleState module=151 state=2 [MCU2_0] 15602.322500 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.322540 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=9 parent=11 [MCU2_0] 15602.322812 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 15602.322874 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=13 parent=18 [MCU2_0] 15602.322998 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 15602.323039 s: SCICLIENT: Sciclient_pmSetModuleClkParent module=152 clk=1 parent=2 [MCU2_0] 15602.323147 s: SCICLIENT: Sciclient_pmSetModuleClkParent success [MCU2_0] 15602.323187 s: SCICLIENT: Sciclient_pmSetModuleClkFreq module=152 clk=1 freq=148500000 [MCU2_0] 15602.324322 s: SCICLIENT: Sciclient_pmSetModuleClkFreq success [MCU2_0] 15602.324381 s: SCICLIENT: Sciclient_pmModuleClkRequest module=152 clk=1 state=2 flag=0 [MCU2_0] 15602.324569 s: SCICLIENT: Sciclient_pmModuleClkRequest success [MCU2_0] 15602.324723 s: DSS: SoC init ... Done !!! [MCU2_0] 15602.324756 s: DSS: Board init ... !!! [MCU2_0] 15602.324785 s: DSS: Board init ... Done !!! [MCU2_0] 15602.343914 s: DSS: Init ... Done !!! [MCU2_0] 15602.343986 s: VHWA: VPAC Init ... !!! [MCU2_0] 15602.344017 s: SCICLIENT: Sciclient_pmSetModuleState module=290 state=2 [MCU2_0] 15602.344233 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.344281 s: VHWA: LDC Init ... !!! [MCU2_0] 15602.348548 s: VHWA: LDC Init ... Done !!! [MCU2_0] 15602.348748 s: VHWA: MSC Init ... !!! [MCU2_0] 15602.361377 s: VHWA: MSC Init ... Done !!! [MCU2_0] 15602.361453 s: VHWA: NF Init ... !!! [MCU2_0] 15602.363711 s: VHWA: NF Init ... Done !!! [MCU2_0] 15602.363786 s: VHWA: VISS Init ... !!! [MCU2_0] 15602.375988 s: VHWA: VISS Init ... Done !!! [MCU2_0] 15602.376069 s: VHWA: VPAC Init ... Done !!! [MCU2_0] 15602.376119 s: VX_ZONE_INIT:Enabled [MCU2_0] 15602.376150 s: VX_ZONE_ERROR:Enabled [MCU2_0] 15602.376178 s: VX_ZONE_WARNING:Enabled [MCU2_0] 15602.377822 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-0 [MCU2_0] 15602.378109 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_NF [MCU2_0] 15602.378356 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_LDC1 [MCU2_0] 15602.378798 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC1 [MCU2_0] 15602.379089 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_MSC2 [MCU2_0] 15602.379393 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target VPAC_VISS1 [MCU2_0] 15602.379852 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE1 [MCU2_0] 15602.380179 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE2 [MCU2_0] 15602.380467 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY1 [MCU2_0] 15602.380905 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DISPLAY2 [MCU2_0] 15602.381190 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CSITX [MCU2_0] 15602.381498 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE3 [MCU2_0] 15602.381953 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE4 [MCU2_0] 15602.382275 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE5 [MCU2_0] 15602.382570 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE6 [MCU2_0] 15602.383069 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE7 [MCU2_0] 15602.383368 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target CAPTURE8 [MCU2_0] 15602.383828 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M1 [MCU2_0] 15602.384135 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M2 [MCU2_0] 15602.384403 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M3 [MCU2_0] 15602.384874 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DSS_M2M4 [MCU2_0] 15602.384947 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_0] 15602.384986 s: APP: OpenVX Target kernel init ... !!! [MCU2_0] 15602.406544 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_0] 15602.406777 s: CSI2RX: Init ... !!! [MCU2_0] 15602.406813 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 15602.406965 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.407011 s: SCICLIENT: Sciclient_pmSetModuleState module=26 state=2 [MCU2_0] 15602.407166 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.407206 s: SCICLIENT: Sciclient_pmSetModuleState module=27 state=2 [MCU2_0] 15602.407354 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.407393 s: SCICLIENT: Sciclient_pmSetModuleState module=147 state=2 [MCU2_0] 15602.407509 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.407546 s: SCICLIENT: Sciclient_pmSetModuleState module=148 state=2 [MCU2_0] 15602.407782 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.408775 s: CSI2RX: Init ... Done !!! [MCU2_0] 15602.408850 s: CSI2TX: Init ... !!! [MCU2_0] 15602.408885 s: SCICLIENT: Sciclient_pmSetModuleState module=25 state=2 [MCU2_0] 15602.409026 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.409073 s: SCICLIENT: Sciclient_pmSetModuleState module=28 state=2 [MCU2_0] 15602.409241 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.409280 s: SCICLIENT: Sciclient_pmSetModuleState module=296 state=2 [MCU2_0] 15602.409430 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_0] 15602.410228 s: CSI2TX: Init ... Done !!! [MCU2_0] 15602.410302 s: ISS: Init ... !!! [MCU2_0] 15602.410350 s: IssSensor_Init ... Done !!! [MCU2_0] 15602.410494 s: IttRemoteServer_Init ... Done !!! [MCU2_0] 15602.410576 s: VISS REMOTE SERVICE: Init ... !!! [MCU2_0] 15602.410858 s: VISS REMOTE SERVICE: Init ... Done !!! [MCU2_0] 15602.410906 s: UDMA Copy: Init ... !!! [MCU2_0] 15602.412953 s: UDMA Copy: Init ... Done !!! [MCU2_0] 15602.413076 s: APP: Init ... Done !!! [MCU2_0] 15602.413126 s: APP: Run ... !!! [MCU2_0] 15602.413155 s: IPC: Starting echo test ... [MCU2_0] 15602.416193 s: APP: Run ... Done !!! [MCU2_0] 15602.433215 s: [LWIPIF_LWIP_IC] Interface started successfully [MCU2_0] 15602.433301 s: [LWIPIF_LWIP_IC] NETIF INIT SUCCESS [MCU2_0] 15602.433435 s: Added interface 'br4', IP is 0.0.0.0 [MCU2_0] 15602.433504 s: jinmin--- ipaddr->addr=0 [MCU2_0] 15602.435451 s: Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:6 [MCU2_0] 15602.436285 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[.] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 15602.436423 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_0] 15602.436534 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_0] 15602.436941 s: IPC: Echo status: mpu1_0[x] mcu2_0[s] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_0] 15602.569119 s: PHY 6: register0 = 0x2100 [MCU2_0] 15602.569237 s: PHY 6: register1 = 0x01e1 [MCU2_0] 15602.569350 s: PHY 6: register2 = 0x0180 [MCU2_0] 15602.569438 s: PHY 6: register3 = 0xdd02 [MCU2_0] 15602.569526 s: PHY 6: register4 = 0x0000 [MCU2_0] 15602.569744 s: PHY 6: register5 = 0x0000 [MCU2_0] 15602.569859 s: PHY 6: register6 = 0x0000 [MCU2_0] 15602.569973 s: PHY 6: register7 = 0x0000 [MCU2_0] 15602.570062 s: PHY 6: register8 = 0x0000 [MCU2_0] 15602.570149 s: PHY 6: register9 = 0x0000 [MCU2_0] 15602.570239 s: PHY 6: register10 = 0x0000 [MCU2_0] 15602.570327 s: PHY 6: register11 = 0x0000 [MCU2_0] 15602.570417 s: PHY 6: register12 = 0x0000 [MCU2_0] 15602.570502 s: PHY 6: register13 = 0x0000 [MCU2_0] 15602.570721 s: PHY 6: register14 = 0x0000 [MCU2_0] 15602.570839 s: PHY 6: register15 = 0x0080 [MCU2_0] 15602.570952 s: PHY 6: register16 = 0x007a [MCU2_0] 15602.571040 s: PHY 6: register17 = 0x9804 [MCU2_0] 15602.571126 s: PHY 6: register18 = 0xdd05 [MCU2_0] 15602.571216 s: PHY 6: register19 = 0x3245 [MCU2_0] 15602.571308 s: PHY 6: register20 = 0x0000 [MCU2_0] 15602.571395 s: PHY 6: register21 = 0x0000 [MCU2_0] 15602.571484 s: PHY 6: register22 = 0x8000 [MCU2_0] 15602.571573 s: PHY 6: register23 = 0x4004 [MCU2_0] 15602.571823 s: PHY 6: register24 = 0x4200 [MCU2_0] 15602.571937 s: PHY 6: register25 = 0x0000 [MCU2_0] 15602.572051 s: PHY 6: register26 = 0x0000 [MCU2_0] 15602.572138 s: PHY 6: register27 = 0xb020 [MCU2_0] 15602.572225 s: PHY 6: register28 = 0x0001 [MCU2_0] 15602.668769 s: EnetPhy_linkWaitState: jinmin----- linkwaitstate phy 485 bmsr=abababab [MCU2_0] 15602.668850 s: EnetPhy_linkWaitState: jinmin----- link ok set to linked [MCU2_0] 15602.668977 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:0,val:0x2100 [MCU2_0] 15602.669090 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:1,val:0x1e5 [MCU2_0] 15602.669208 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:2,val:0x180 [MCU2_0] 15602.669329 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:3,val:0xdd02 [MCU2_0] 15602.669446 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:4,val:0x0 [MCU2_0] 15602.669535 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:5,val:0x0 [MCU2_0] 15602.669797 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:6,val:0x0 [MCU2_0] 15602.669931 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:7,val:0x0 [MCU2_0] 15602.670041 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:8,val:0x0 [MCU2_0] 15602.670160 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:9,val:0x0 [MCU2_0] 15602.670279 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:10,val:0x0 [MCU2_0] 15602.670397 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:11,val:0x0 [MCU2_0] 15602.670517 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:12,val:0x0 [MCU2_0] 15602.670730 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:13,val:0x0 [MCU2_0] 15602.670847 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:14,val:0x0 [MCU2_0] 15602.670963 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:15,val:0x80 [MCU2_0] 15602.671082 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:16,val:0x7a [MCU2_0] 15602.671200 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:17,val:0x9804 [MCU2_0] 15602.671318 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:18,val:0xdd05 [MCU2_0] 15602.671438 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:19,val:0x3245 [MCU2_0] 15602.671557 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:20,val:0x0 [MCU2_0] 15602.671813 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:21,val:0x200 [MCU2_0] 15602.671949 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:22,val:0x8000 [MCU2_0] 15602.672065 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:23,val:0xbce4 [MCU2_0] 15602.672181 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:24,val:0x4000 [MCU2_0] 15602.672299 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:25,val:0x0 [MCU2_0] 15602.672417 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:26,val:0x0 [MCU2_0] 15602.672538 s: EnetPhy_linkWaitState: jinmin--- phy:6,address:27,val:0xb020 [MCU2_0] 15602.672811 s: Cpsw_handleLinkUp: Port 4: Link up: 100-Mbps Full-Duplex [MCU2_0] 15608.199867 s: Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:172, FlowIdxOffset:0 [MCU2_0] 15608.203045 s: Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:12, Policer Entry:1 [MCU2_0] 15608.224957 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 15608.226966 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 15608.229016 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 15608.279847 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 15608.281921 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 15608.283880 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 15608.284031 s: CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter [MCU2_0] 15608.666377 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 15609.483772 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39888a4,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:172, FlowIdOffset:0
在上面的日志中,连接到 Port4的 phy(tja1101)已链接。 ("Cpsw_handleLinkUp:端口4:链路上行:100Mbps 全双工")
但无法 ping 通连接到 tda4板的主机 PC。
使用以下命令从 A72运行 ping PC
Ping -c 10.
root@j7-evm:~# ifconfig eth1 192.168.1.3 root@j7-evm:~# ping 192.168.1.2 PING 192.168.1.2 (192.168.1.2): 56 data bytes ^C --- 192.168.1.2 ping statistics --- 13 packets transmitted, 0 packets received, 100% packet loss
root@j7-evm:~# /opt/vx_app_arm_remote_log.out [MCU2_0] Function:CpswProxyServer_registerIpv4MacHandlerCb,HostId:0,Handle:a39890a4,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1 IPv4Addr:192.168.1.3 [MCU2_0] 320.372720 s: [MCU2_0] SNo. IP Address MAC Address [MCU2_0] 320.372765 s: ------ ------------- ----------------- [MCU2_0] 320.372805 s: 1 192.168.1.3 70:ff:76:1d:92:c1 [MCU2_0] 320.374398 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39890a4,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:fc, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 320.376468 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39890a4,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:fb, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 384.444576 s: Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c000000 [MCU2_0] 384.444890 s: Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c020000 [MCU2_0] 384.445128 s: Function:CpswProxyServer_clientNotifyHandlerCb,HostId:0,Handle:38acb7e6,CoreKey:a39890a4,NotifyId:RPMSG_KDRV_TP_ETHSWITCH_CLIENTNOTIFY_DUMPSTATS,NotifyLen [MCU2_0] 384.445262 s: [MCU2_0] 384.445338 s: 0: Vlanid: 012c, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445402 s: RAW:[0 212c1f [MCU2_0] 384.445447 s: f1 ff0001ff] [MCU2_0] 384.445578 s: 1: Vlanid: 0190, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445650 s: RAW:[0 21901f [MCU2_0] 384.445697 s: f1 ff0001ff] [MCU2_0] 384.445761 s: 2: Vlanid: 0191, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445819 s: RAW:[0 21911f [MCU2_0] 384.445861 s: f1 ff0001ff] [MCU2_0] 384.445917 s: 3: Vlanid: 0192, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445971 s: RAW:[0 21921f [MCU2_0] 384.446016 s: f1 ff0001ff] [MCU2_0] 384.446070 s: 4: Vlanid: 0000, UTagged: 11, Mult: 11, UMult: 11, Member: 11 [MCU2_0] 384.446126 s: RAW:[0 200001 [MCU2_0] 384.446169 s: 10 11011011] [MCU2_0] 384.446223 s: 5: Vlanid: 0194, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446279 s: RAW:[0 21941f [MCU2_0] 384.446321 s: f1 ff0001ff] [MCU2_0] 384.446376 s: 6: Vlanid: 0195, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446432 s: RAW:[0 21951f [MCU2_0] 384.446474 s: f1 ff0001ff] [MCU2_0] 384.446581 s: 7: Vlanid: 0196, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446641 s: RAW:[0 21961f [MCU2_0] 384.446686 s: f1 ff0001ff] [MCU2_0] 384.446742 s: 8: Vlanid: 0197, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446800 s: RAW:[0 21971f [MCU2_0] 384.446842 s: f1 ff0001ff] [MCU2_0] 384.446918 s: 9: Address: ffffffffffff, Member:1ff Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.446973 s: RAW:[7fc 1000ff [MCU2_0] 384.447015 s: ff ffffffff] [MCU2_0] 384.447098 s: 10: Address: 70ff761d92c3, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 [MCU2_0] 384.447155 s: RAW:[1 100070 [MCU2_0] 384.447196 s: ff 761d92c3] [MCU2_0] 384.447233 s: 11: EtherType: 0806 [MCU2_0] 384.447276 s: RAW:[1 200000 [MCU2_0] 384.447319 s: 00 00000806] [MCU2_0] 384.447397 s: 12: Address: 70ff761d92c1, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 [MCU2_0] 384.447453 s: RAW:[0 100070 [MCU2_0] 384.447537 s: ff 761d92c1] [MCU2_0] 384.447620 s: 13: Address: 333300000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.447678 s: RAW:[4 100033 [MCU2_0] 384.447721 s: 33 00000001] [MCU2_0] 384.447795 s: 14: Address: 01005e000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.447849 s: RAW:[4 100001 [MCU2_0] 384.447891 s: 00 5e000001] [MCU2_0] 384.447962 s: 15: Address: 3333ff1d92c1, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448017 s: RAW:[4 100033 [MCU2_0] 384.448059 s: 33 ff1d92c1] [MCU2_0] 384.448130 s: 16: Address: 0180c2000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448186 s: RAW:[4 100001 [MCU2_0] 384.448227 s: 80 c2000000] [MCU2_0] 384.448297 s: 17: Address: 0180c2000003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448352 s: RAW:[4 100001 [MCU2_0] 384.448393 s: 80 c2000003] [MCU2_0] 384.448462 s: 18: Address: 3333000000fb, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448559 s: RAW:[4 100033 [MCU2_0] 384.448609 s: 33 000000fb] [MCU2_0] 384.448685 s: 19: Address: 333300010003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448739 s: RAW:[4 100033 [MCU2_0] 384.448782 s: 33 00010003] [MCU2_0] 384.448855 s: 20: Address: 01005e0000fc, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448909 s: RAW:[4 100001 [MCU2_0] 384.448951 s: 00 5e0000fc] [MCU2_0] 384.449022 s: 21: Address: 01005e0000fb, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.449075 s: RAW:[4 100001 [MCU2_0] 384.449116 s: 00 5e0000fb] [MCU2_0] 384.450568 s: [MCU2_0] 384.450604 s: 1002 Free Entries [MCU2_0] 384.450642 s: [MCU2_0] 384.450683 s: 0: POLICER_DST_MAC,ALE Index: 9 [MCU2_0] 384.450725 s: 0: POLICER_ETHERTYPE,ALE Index: 11 [MCU2_0] 384.450766 s: 0: POLICER_THREAD,THREAD ID:4 [MCU2_0] 384.450817 s: 0: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.450866 s: 1: POLICER_DST_MAC,ALE Index: 12 [MCU2_0] 384.450904 s: 1: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.450950 s: 1: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0 [MCU2_0] 384.450996 s: 2: POLICER_DST_MAC,ALE Index: 15 [MCU2_0] 384.451035 s: 2: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.451082 s: 2: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.451128 s: 3: POLICER_DST_MAC,ALE Index: 18 [MCU2_0] 384.451166 s: 3: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.451212 s: 3: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.451260 s: 4: POLICER_DST_MAC,ALE Index: 19 [MCU2_0] 384.451298 s: 4: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.451344 s: 4: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.451664 s: [MCU2_0] 384.451702 s: 91 Free Entries [MCU2_0] 384.451798 s: [MCU2_0] Port 0 Statistics [MCU2_0] 384.451829 s: ----------------------------------------- [MCU2_0] 384.451891 s: rxGoodFrames = 68 [MCU2_0] 384.451936 s: rxBcastFrames = 33 [MCU2_0] 384.451977 s: rxMcastFrames = 35 [MCU2_0] 384.452019 s: aleDrop = 52 [MCU2_0] 384.452060 s: rxOctets = 12352 [MCU2_0] 384.452100 s: txGoodFrames = 140 [MCU2_0] 384.452140 s: txBcastFrames = 128 [MCU2_0] 384.452179 s: txMcastFrames = 12 [MCU2_0] 384.452218 s: txOctets = 10844 [MCU2_0] 384.452258 s: octetsFrames64 = 140 [MCU2_0] 384.452297 s: octetsFrames65to127 = 23 [MCU2_0] 384.452371 s: octetsFrames128to255 = 24 [MCU2_0] 384.452411 s: octetsFrames256to511 = 21 [MCU2_0] 384.452479 s: netOctets = 23196 [MCU2_0] 384.452581 s: portMaskDrop = 68 [MCU2_0] 384.452628 s: alePolicyMatch = 19 [MCU2_0] 384.452676 s: txPri[0] = 140 [MCU2_0] 384.452720 s: txPriBcnt[0] = 10844 [MCU2_0] 384.452754 s: [MCU2_0] 384.452857 s: [MCU2_0] External Port 0 Statistics [MCU2_0] 384.452897 s: ----------------------------------------- [MCU2_0] 384.452944 s: [MCU2_0] 384.453034 s: [MCU2_0] External Port 1 Statistics [MCU2_0] 384.453068 s: ----------------------------------------- [MCU2_0] 384.453105 s: [MCU2_0] 384.453188 s: [MCU2_0] External Port 2 Statistics [MCU2_0] 384.453222 s: ----------------------------------------- [MCU2_0] 384.453255 s: [MCU2_0] 384.453333 s: [MCU2_0] External Port 3 Statistics [MCU2_0] 384.453368 s: ----------------------------------------- [MCU2_0] 384.453421 s: rxGoodFrames = 140 [MCU2_0] 384.453468 s: rxBcastFrames = 128 [MCU2_0] 384.453571 s: rxMcastFrames = 12 [MCU2_0] 384.453625 s: rxOctets = 10844 [MCU2_0] 384.453669 s: octetsFrames64 = 128 [MCU2_0] 384.453710 s: octetsFrames128to255 = 12 [MCU2_0] 384.453750 s: netOctets = 10844 [MCU2_0] 384.453793 s: aleUnknownMcast = 12 [MCU2_0] 384.453832 s: aleUnknownMcastBcnt = 2652 [MCU2_0] 384.453871 s: aleUnknownBcast = 128 [MCU2_0] 384.453910 s: aleUnknownBcastBcnt = 8192 [MCU2_0] 384.453950 s: alePolicyMatch = 128 [MCU2_0] 384.453980 s: [MCU2_0] 384.454072 s: [MCU2_0] External Port 4 Statistics [MCU2_0] 384.454107 s: ----------------------------------------- [MCU2_0] 384.454146 s: [MCU2_0] 384.454229 s: [MCU2_0] External Port 5 Statistics [MCU2_0] 384.454265 s: ----------------------------------------- [MCU2_0] 384.454300 s: [MCU2_0] 384.454379 s: [MCU2_0] External Port 6 Statistics [MCU2_0] 384.454414 s: ----------------------------------------- [MCU2_0] 384.454447 s: [MCU2_0] 384.454575 s: [MCU2_0] External Port 7 Statistics [MCU2_0] 384.454618 s: ----------------------------------------- [MCU2_0] 384.454654 s: [MCU2_1] 2.269442 s: CIO: Init ... Done !!! [MCU2_1] 2.269521 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 2.269566 s: APP: Init ... !!! [MCU2_1] 2.269596 s: SCICLIENT: Init ... !!! [MCU2_1] 2.269869 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [MCU2_1] 2.269935 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_1] 2.269977 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 2.270019 s: SCICLIENT: Init ... Done !!! [MCU2_1] 2.270050 s: UDMA: Init ... !!! [MCU2_1] 2.271668 s: UDMA: Init ... Done !!! [MCU2_1] 2.271737 s: MEM: Init ... !!! [MCU2_1] 2.271783 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 2.271860 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!! [MCU2_1] 2.271920 s: MEM: Init ... Done !!! [MCU2_1] 2.271958 s: IPC: Init ... !!! [MCU2_1] 2.272028 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 2.272089 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 14.271650 s: IPC: HLOS is ready !!! [MCU2_1] 14.287641 s: IPC: Init ... Done !!! [MCU2_1] 14.287717 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 14.287770 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 14.287811 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 14.290069 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 14.290141 s: FVID2: Init ... !!! [MCU2_1] 14.290227 s: FVID2: Init ... Done !!! [MCU2_1] 14.290267 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 14.290296 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 14.290848 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 14.290891 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 14.291380 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 14.291420 s: VHWA: DOF Init ... !!! [MCU2_1] 14.299896 s: VHWA: DOF Init ... Done !!! [MCU2_1] 14.299972 s: VHWA: SDE Init ... !!! [MCU2_1] 14.302798 s: VHWA: SDE Init ... Done !!! [MCU2_1] 14.302862 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 14.302916 s: VX_ZONE_INIT:Enabled [MCU2_1] 14.302958 s: VX_ZONE_ERROR:Enabled [MCU2_1] 14.302988 s: VX_ZONE_WARNING:Enabled [MCU2_1] 14.304255 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_SDE [MCU2_1] 14.304517 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_DOF [MCU2_1] 14.304769 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-1 [MCU2_1] 14.304829 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_1] 14.304868 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 14.305200 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 14.305247 s: UDMA Copy: Init ... !!! [MCU2_1] 14.307105 s: UDMA Copy: Init ... Done !!! [MCU2_1] 14.307177 s: APP: Init ... Done !!! [MCU2_1] 14.307211 s: APP: Run ... !!! [MCU2_1] 14.307236 s: IPC: Starting echo test ... [MCU2_1] 14.309796 s: APP: Run ... Done !!! [MCU2_1] 14.311111 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 14.311236 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 14.311340 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 14.729468 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 2.372588 s: CIO: Init ... Done !!! [C6x_1 ] 2.372615 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 2.372626 s: APP: Init ... !!! [C6x_1 ] 2.372634 s: SCICLIENT: Init ... !!! [C6x_1 ] 2.372865 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C6x_1 ] 2.372877 s: SCICLIENT: DMSC FW revision 0x8 [C6x_1 ] 2.372887 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 2.372897 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 2.372907 s: UDMA: Init ... !!! [C6x_1 ] 2.374484 s: UDMA: Init ... Done !!! [C6x_1 ] 2.374508 s: MEM: Init ... !!! [C6x_1 ] 2.374522 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 2.374541 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 2.374557 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!! [C6x_1 ] 2.374573 s: MEM: Init ... Done !!! [C6x_1 ] 2.374582 s: IPC: Init ... !!! [C6x_1 ] 2.374603 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 2.374619 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 12.728484 s: IPC: HLOS is ready !!! [C6x_1 ] 12.732814 s: IPC: Init ... Done !!! [C6x_1 ] 12.732845 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 14.287769 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 14.287787 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 14.288674 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 14.288724 s: VX_ZONE_INIT:Enabled [C6x_1 ] 14.288739 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 14.288749 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 14.289715 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_1 ] 14.289797 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 14.290148 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 14.290170 s: UDMA Copy: Init ... !!! [C6x_1 ] 14.293730 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 14.293750 s: APP: Init ... Done !!! [C6x_1 ] 14.293758 s: APP: Run ... !!! [C6x_1 ] 14.293767 s: IPC: Starting echo test ... [C6x_1 ] 14.295023 s: APP: Run ... Done !!! [C6x_1 ] 14.295375 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 14.295804 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 14.310382 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 14.729325 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 2.466132 s: CIO: Init ... Done !!! [C6x_2 ] 2.466160 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 2.466171 s: APP: Init ... !!! [C6x_2 ] 2.466180 s: SCICLIENT: Init ... !!! [C6x_2 ] 2.466404 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C6x_2 ] 2.466417 s: SCICLIENT: DMSC FW revision 0x8 [C6x_2 ] 2.466427 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 2.466438 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 2.466448 s: UDMA: Init ... !!! [C6x_2 ] 2.468043 s: UDMA: Init ... Done !!! [C6x_2 ] 2.468067 s: MEM: Init ... !!! [C6x_2 ] 2.468082 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 2.468101 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 2.468117 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!! [C6x_2 ] 2.468134 s: MEM: Init ... Done !!! [C6x_2 ] 2.468143 s: IPC: Init ... !!! [C6x_2 ] 2.468165 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 2.468182 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 12.982489 s: IPC: HLOS is ready !!! [C6x_2 ] 12.986608 s: IPC: Init ... Done !!! [C6x_2 ] 12.986637 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 14.287769 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 14.287788 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 14.288693 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 14.288740 s: VX_ZONE_INIT:Enabled [C6x_2 ] 14.288754 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 14.288764 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 14.289730 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_2 ] 14.289817 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 14.290172 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 14.290196 s: UDMA Copy: Init ... !!! [C6x_2 ] 14.294047 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 14.294069 s: APP: Init ... Done !!! [C6x_2 ] 14.294078 s: APP: Run ... !!! [C6x_2 ] 14.294088 s: IPC: Starting echo test ... [C6x_2 ] 14.295453 s: APP: Run ... Done !!! [C6x_2 ] 14.295813 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 14.295858 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 14.310409 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 14.729345 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 2.700794 s: CIO: Init ... Done !!! [C7x_1 ] 2.700810 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 2.700822 s: APP: Init ... !!! [C7x_1 ] 2.700830 s: SCICLIENT: Init ... !!! [C7x_1 ] 2.701078 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C7x_1 ] 2.701092 s: SCICLIENT: DMSC FW revision 0x8 [C7x_1 ] 2.701103 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 2.701114 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 2.701123 s: UDMA: Init ... !!! [C7x_1 ] 2.702329 s: UDMA: Init ... Done !!! [C7x_1 ] 2.702343 s: MEM: Init ... !!! [C7x_1 ] 2.702355 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 2.702375 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 2.702393 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!! [C7x_1 ] 2.702411 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 2.702428 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!! [C7x_1 ] 2.702447 s: MEM: Init ... Done !!! [C7x_1 ] 2.702455 s: IPC: Init ... !!! [C7x_1 ] 2.702471 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 2.702486 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 13.389721 s: IPC: HLOS is ready !!! [C7x_1 ] 13.392074 s: IPC: Init ... Done !!! [C7x_1 ] 13.392091 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 14.287771 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 14.287792 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 14.288003 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 14.288030 s: VX_ZONE_INIT:Enabled [C7x_1 ] 14.288041 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 14.288051 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 14.288269 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1 [C7x_1 ] 14.288394 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2 [C7x_1 ] 14.288519 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3 [C7x_1 ] 14.288611 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4 [C7x_1 ] 14.288720 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5 [C7x_1 ] 14.288853 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6 [C7x_1 ] 14.289036 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7 [C7x_1 ] 14.289125 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8 [C7x_1 ] 14.289148 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C7x_1 ] 14.289161 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 14.289356 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 14.289372 s: APP: Init ... Done !!! [C7x_1 ] 14.289382 s: APP: Run ... !!! [C7x_1 ] 14.289391 s: IPC: Starting echo test ... [C7x_1 ] 14.289636 s: APP: Run ... Done !!! [C7x_1 ] 14.295391 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 14.295820 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 14.310436 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 14.729397 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
4. 使用以下命令从 PC 到 A72运行 ping 命令
Ping -c 10.
root@j7-evm:~# /opt/vx_app_arm_remote_log.out [MCU2_0] Function:CpswProxyServer_registerIpv4MacHandlerCb,HostId:0,Handle:a39890a4,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1 IPv4Addr:192.168.1.3 [MCU2_0] 320.372720 s: [MCU2_0] SNo. IP Address MAC Address [MCU2_0] 320.372765 s: ------ ------------- ----------------- [MCU2_0] 320.372805 s: 1 192.168.1.3 70:ff:76:1d:92:c1 [MCU2_0] 320.374398 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39890a4,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:fc, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 320.376468 s: Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a39890a4,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:fb, vlanId:0, FlowIdx:172, FlowIdOffset:0 [MCU2_0] 384.444576 s: Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c000000 [MCU2_0] 384.444890 s: Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c020000 [MCU2_0] 384.445128 s: Function:CpswProxyServer_clientNotifyHandlerCb,HostId:0,Handle:38acb7e6,CoreKey:a39890a4,NotifyId:RPMSG_KDRV_TP_ETHSWITCH_CLIENTNOTIFY_DUMPSTATS,NotifyLen [MCU2_0] 384.445262 s: [MCU2_0] 384.445338 s: 0: Vlanid: 012c, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445402 s: RAW:[0 212c1f [MCU2_0] 384.445447 s: f1 ff0001ff] [MCU2_0] 384.445578 s: 1: Vlanid: 0190, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445650 s: RAW:[0 21901f [MCU2_0] 384.445697 s: f1 ff0001ff] [MCU2_0] 384.445761 s: 2: Vlanid: 0191, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445819 s: RAW:[0 21911f [MCU2_0] 384.445861 s: f1 ff0001ff] [MCU2_0] 384.445917 s: 3: Vlanid: 0192, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.445971 s: RAW:[0 21921f [MCU2_0] 384.446016 s: f1 ff0001ff] [MCU2_0] 384.446070 s: 4: Vlanid: 0000, UTagged: 11, Mult: 11, UMult: 11, Member: 11 [MCU2_0] 384.446126 s: RAW:[0 200001 [MCU2_0] 384.446169 s: 10 11011011] [MCU2_0] 384.446223 s: 5: Vlanid: 0194, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446279 s: RAW:[0 21941f [MCU2_0] 384.446321 s: f1 ff0001ff] [MCU2_0] 384.446376 s: 6: Vlanid: 0195, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446432 s: RAW:[0 21951f [MCU2_0] 384.446474 s: f1 ff0001ff] [MCU2_0] 384.446581 s: 7: Vlanid: 0196, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446641 s: RAW:[0 21961f [MCU2_0] 384.446686 s: f1 ff0001ff] [MCU2_0] 384.446742 s: 8: Vlanid: 0197, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 384.446800 s: RAW:[0 21971f [MCU2_0] 384.446842 s: f1 ff0001ff] [MCU2_0] 384.446918 s: 9: Address: ffffffffffff, Member:1ff Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.446973 s: RAW:[7fc 1000ff [MCU2_0] 384.447015 s: ff ffffffff] [MCU2_0] 384.447098 s: 10: Address: 70ff761d92c3, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 [MCU2_0] 384.447155 s: RAW:[1 100070 [MCU2_0] 384.447196 s: ff 761d92c3] [MCU2_0] 384.447233 s: 11: EtherType: 0806 [MCU2_0] 384.447276 s: RAW:[1 200000 [MCU2_0] 384.447319 s: 00 00000806] [MCU2_0] 384.447397 s: 12: Address: 70ff761d92c1, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 [MCU2_0] 384.447453 s: RAW:[0 100070 [MCU2_0] 384.447537 s: ff 761d92c1] [MCU2_0] 384.447620 s: 13: Address: 333300000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.447678 s: RAW:[4 100033 [MCU2_0] 384.447721 s: 33 00000001] [MCU2_0] 384.447795 s: 14: Address: 01005e000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.447849 s: RAW:[4 100001 [MCU2_0] 384.447891 s: 00 5e000001] [MCU2_0] 384.447962 s: 15: Address: 3333ff1d92c1, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448017 s: RAW:[4 100033 [MCU2_0] 384.448059 s: 33 ff1d92c1] [MCU2_0] 384.448130 s: 16: Address: 0180c2000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448186 s: RAW:[4 100001 [MCU2_0] 384.448227 s: 80 c2000000] [MCU2_0] 384.448297 s: 17: Address: 0180c2000003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448352 s: RAW:[4 100001 [MCU2_0] 384.448393 s: 80 c2000003] [MCU2_0] 384.448462 s: 18: Address: 3333000000fb, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448559 s: RAW:[4 100033 [MCU2_0] 384.448609 s: 33 000000fb] [MCU2_0] 384.448685 s: 19: Address: 333300010003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448739 s: RAW:[4 100033 [MCU2_0] 384.448782 s: 33 00010003] [MCU2_0] 384.448855 s: 20: Address: 01005e0000fc, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.448909 s: RAW:[4 100001 [MCU2_0] 384.448951 s: 00 5e0000fc] [MCU2_0] 384.449022 s: 21: Address: 01005e0000fb, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 384.449075 s: RAW:[4 100001 [MCU2_0] 384.449116 s: 00 5e0000fb] [MCU2_0] 384.450568 s: [MCU2_0] 384.450604 s: 1002 Free Entries [MCU2_0] 384.450642 s: [MCU2_0] 384.450683 s: 0: POLICER_DST_MAC,ALE Index: 9 [MCU2_0] 384.450725 s: 0: POLICER_ETHERTYPE,ALE Index: 11 [MCU2_0] 384.450766 s: 0: POLICER_THREAD,THREAD ID:4 [MCU2_0] 384.450817 s: 0: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.450866 s: 1: POLICER_DST_MAC,ALE Index: 12 [MCU2_0] 384.450904 s: 1: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.450950 s: 1: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0 [MCU2_0] 384.450996 s: 2: POLICER_DST_MAC,ALE Index: 15 [MCU2_0] 384.451035 s: 2: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.451082 s: 2: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.451128 s: 3: POLICER_DST_MAC,ALE Index: 18 [MCU2_0] 384.451166 s: 3: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.451212 s: 3: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.451260 s: 4: POLICER_DST_MAC,ALE Index: 19 [MCU2_0] 384.451298 s: 4: POLICER_THREAD,THREAD ID:0 [MCU2_0] 384.451344 s: 4: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 384.451664 s: [MCU2_0] 384.451702 s: 91 Free Entries [MCU2_0] 384.451798 s: [MCU2_0] Port 0 Statistics [MCU2_0] 384.451829 s: ----------------------------------------- [MCU2_0] 384.451891 s: rxGoodFrames = 68 [MCU2_0] 384.451936 s: rxBcastFrames = 33 [MCU2_0] 384.451977 s: rxMcastFrames = 35 [MCU2_0] 384.452019 s: aleDrop = 52 [MCU2_0] 384.452060 s: rxOctets = 12352 [MCU2_0] 384.452100 s: txGoodFrames = 140 [MCU2_0] 384.452140 s: txBcastFrames = 128 [MCU2_0] 384.452179 s: txMcastFrames = 12 [MCU2_0] 384.452218 s: txOctets = 10844 [MCU2_0] 384.452258 s: octetsFrames64 = 140 [MCU2_0] 384.452297 s: octetsFrames65to127 = 23 [MCU2_0] 384.452371 s: octetsFrames128to255 = 24 [MCU2_0] 384.452411 s: octetsFrames256to511 = 21 [MCU2_0] 384.452479 s: netOctets = 23196 [MCU2_0] 384.452581 s: portMaskDrop = 68 [MCU2_0] 384.452628 s: alePolicyMatch = 19 [MCU2_0] 384.452676 s: txPri[0] = 140 [MCU2_0] 384.452720 s: txPriBcnt[0] = 10844 [MCU2_0] 384.452754 s: [MCU2_0] 384.452857 s: [MCU2_0] External Port 0 Statistics [MCU2_0] 384.452897 s: ----------------------------------------- [MCU2_0] 384.452944 s: [MCU2_0] 384.453034 s: [MCU2_0] External Port 1 Statistics [MCU2_0] 384.453068 s: ----------------------------------------- [MCU2_0] 384.453105 s: [MCU2_0] 384.453188 s: [MCU2_0] External Port 2 Statistics [MCU2_0] 384.453222 s: ----------------------------------------- [MCU2_0] 384.453255 s: [MCU2_0] 384.453333 s: [MCU2_0] External Port 3 Statistics [MCU2_0] 384.453368 s: ----------------------------------------- [MCU2_0] 384.453421 s: rxGoodFrames = 140 [MCU2_0] 384.453468 s: rxBcastFrames = 128 [MCU2_0] 384.453571 s: rxMcastFrames = 12 [MCU2_0] 384.453625 s: rxOctets = 10844 [MCU2_0] 384.453669 s: octetsFrames64 = 128 [MCU2_0] 384.453710 s: octetsFrames128to255 = 12 [MCU2_0] 384.453750 s: netOctets = 10844 [MCU2_0] 384.453793 s: aleUnknownMcast = 12 [MCU2_0] 384.453832 s: aleUnknownMcastBcnt = 2652 [MCU2_0] 384.453871 s: aleUnknownBcast = 128 [MCU2_0] 384.453910 s: aleUnknownBcastBcnt = 8192 [MCU2_0] 384.453950 s: alePolicyMatch = 128 [MCU2_0] 384.453980 s: [MCU2_0] 384.454072 s: [MCU2_0] External Port 4 Statistics [MCU2_0] 384.454107 s: ----------------------------------------- [MCU2_0] 384.454146 s: [MCU2_0] 384.454229 s: [MCU2_0] External Port 5 Statistics [MCU2_0] 384.454265 s: ----------------------------------------- [MCU2_0] 384.454300 s: [MCU2_0] 384.454379 s: [MCU2_0] External Port 6 Statistics [MCU2_0] 384.454414 s: ----------------------------------------- [MCU2_0] 384.454447 s: [MCU2_0] 384.454575 s: [MCU2_0] External Port 7 Statistics [MCU2_0] 384.454618 s: ----------------------------------------- [MCU2_0] 384.454654 s: [MCU2_0] 575.240581 s: Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c000000 [MCU2_0] 575.240879 s: Function:CpswProxyServer_regrdHandlerCb,HostId:0, RegAddr:c020000 [MCU2_0] 575.241120 s: Function:CpswProxyServer_clientNotifyHandlerCb,HostId:0,Handle:38acb7e6,CoreKey:a39890a4,NotifyId:RPMSG_KDRV_TP_ETHSWITCH_CLIENTNOTIFY_DUMPSTATS,NotifyLen [MCU2_0] 575.241258 s: [MCU2_0] 575.241337 s: 0: Vlanid: 012c, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.241401 s: RAW:[0 212c1f [MCU2_0] 575.241446 s: f1 ff0001ff] [MCU2_0] 575.241574 s: 1: Vlanid: 0190, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.241643 s: RAW:[0 21901f [MCU2_0] 575.241688 s: f1 ff0001ff] [MCU2_0] 575.241747 s: 2: Vlanid: 0191, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.241805 s: RAW:[0 21911f [MCU2_0] 575.241847 s: f1 ff0001ff] [MCU2_0] 575.241903 s: 3: Vlanid: 0192, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.241962 s: RAW:[0 21921f [MCU2_0] 575.242006 s: f1 ff0001ff] [MCU2_0] 575.242060 s: 4: Vlanid: 0000, UTagged: 11, Mult: 11, UMult: 11, Member: 11 [MCU2_0] 575.242118 s: RAW:[0 200001 [MCU2_0] 575.242159 s: 10 11011011] [MCU2_0] 575.242214 s: 5: Vlanid: 0194, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.242271 s: RAW:[0 21941f [MCU2_0] 575.242312 s: f1 ff0001ff] [MCU2_0] 575.242366 s: 6: Vlanid: 0195, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.242424 s: RAW:[0 21951f [MCU2_0] 575.242467 s: f1 ff0001ff] [MCU2_0] 575.242567 s: 7: Vlanid: 0196, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.242629 s: RAW:[0 21961f [MCU2_0] 575.242672 s: f1 ff0001ff] [MCU2_0] 575.242730 s: 8: Vlanid: 0197, UTagged: 1ff, Mult: 1ff, UMult: 0, Member: 1ff [MCU2_0] 575.242786 s: RAW:[0 21971f [MCU2_0] 575.242830 s: f1 ff0001ff] [MCU2_0] 575.242906 s: 9: Address: ffffffffffff, Member:1ff Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.242962 s: RAW:[7fc 1000ff [MCU2_0] 575.243004 s: ff ffffffff] [MCU2_0] 575.243088 s: 10: Address: 70ff761d92c3, Port: 000 Se=1 Bl=0 TOUCH=0 AGE=0 TRUNK=0 [MCU2_0] 575.243144 s: RAW:[1 100070 [MCU2_0] 575.243185 s: ff 761d92c3] [MCU2_0] 575.243223 s: 11: EtherType: 0806 [MCU2_0] 575.243265 s: RAW:[1 200000 [MCU2_0] 575.243307 s: 00 00000806] [MCU2_0] 575.243386 s: 12: Address: 70ff761d92c1, Port: 000 Se=0 Bl=0 TOUCH=0 AGE=0 TRUNK=0 [MCU2_0] 575.243443 s: RAW:[0 100070 [MCU2_0] 575.243484 s: ff 761d92c1] [MCU2_0] 575.243606 s: 13: Address: 333300000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.243667 s: RAW:[4 100033 [MCU2_0] 575.243710 s: 33 00000001] [MCU2_0] 575.243782 s: 14: Address: 01005e000001, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.243837 s: RAW:[4 100001 [MCU2_0] 575.243879 s: 00 5e000001] [MCU2_0] 575.243949 s: 15: Address: 3333ff1d92c1, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.244004 s: RAW:[4 100033 [MCU2_0] 575.244046 s: 33 ff1d92c1] [MCU2_0] 575.244116 s: 16: Address: 0180c2000000, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.244172 s: RAW:[4 100001 [MCU2_0] 575.244213 s: 80 c2000000] [MCU2_0] 575.244283 s: 17: Address: 0180c2000003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.244338 s: RAW:[4 100001 [MCU2_0] 575.244379 s: 80 c2000003] [MCU2_0] 575.244450 s: 18: Address: 3333000000fb, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.244541 s: RAW:[4 100033 [MCU2_0] 575.244592 s: 33 000000fb] [MCU2_0] 575.244667 s: 19: Address: 333300010003, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.244722 s: RAW:[4 100033 [MCU2_0] 575.244763 s: 33 00010003] [MCU2_0] 575.244834 s: 20: Address: 01005e0000fc, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.244889 s: RAW:[4 100001 [MCU2_0] 575.244929 s: 00 5e0000fc] [MCU2_0] 575.245000 s: 21: Address: 01005e0000fb, Member:001 Su=0 FWDSTLVL=0 IGNMBITS=0 [MCU2_0] 575.245054 s: RAW:[4 100001 [MCU2_0] 575.245096 s: 00 5e0000fb] [MCU2_0] 575.246549 s: [MCU2_0] 575.246590 s: 1002 Free Entries [MCU2_0] 575.246631 s: [MCU2_0] 575.246672 s: 0: POLICER_DST_MAC,ALE Index: 9 [MCU2_0] 575.246714 s: 0: POLICER_ETHERTYPE,ALE Index: 11 [MCU2_0] 575.246755 s: 0: POLICER_THREAD,THREAD ID:4 [MCU2_0] 575.246808 s: 0: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 575.246860 s: 1: POLICER_DST_MAC,ALE Index: 12 [MCU2_0] 575.246900 s: 1: POLICER_THREAD,THREAD ID:0 [MCU2_0] 575.246947 s: 1: POLICER_STATS: Hit: 0, RedHit: 0, YellowHit: 0 [MCU2_0] 575.246995 s: 2: POLICER_DST_MAC,ALE Index: 15 [MCU2_0] 575.247033 s: 2: POLICER_THREAD,THREAD ID:0 [MCU2_0] 575.247079 s: 2: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 575.247126 s: 3: POLICER_DST_MAC,ALE Index: 18 [MCU2_0] 575.247165 s: 3: POLICER_THREAD,THREAD ID:0 [MCU2_0] 575.247211 s: 3: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 575.247257 s: 4: POLICER_DST_MAC,ALE Index: 19 [MCU2_0] 575.247297 s: 4: POLICER_THREAD,THREAD ID:0 [MCU2_0] 575.247344 s: 4: POLICER_STATS: Hit: 1, RedHit: 0, YellowHit: 0 [MCU2_0] 575.247658 s: [MCU2_0] 575.247693 s: 91 Free Entries [MCU2_0] 575.247791 s: [MCU2_0] Port 0 Statistics [MCU2_0] 575.247820 s: ----------------------------------------- [MCU2_0] 575.247881 s: rxGoodFrames = 81 [MCU2_0] 575.247927 s: rxBcastFrames = 39 [MCU2_0] 575.247967 s: rxMcastFrames = 38 [MCU2_0] 575.248008 s: aleDrop = 65 [MCU2_0] 575.248049 s: rxOctets = 15014 [MCU2_0] 575.248089 s: txGoodFrames = 248 [MCU2_0] 575.248129 s: txBcastFrames = 232 [MCU2_0] 575.248167 s: txMcastFrames = 16 [MCU2_0] 575.248207 s: txOctets = 18567 [MCU2_0] 575.248247 s: octetsFrames64 = 247 [MCU2_0] 575.248286 s: octetsFrames65to127 = 24 [MCU2_0] 575.248324 s: octetsFrames128to255 = 31 [MCU2_0] 575.248363 s: octetsFrames256to511 = 27 [MCU2_0] 575.248404 s: netOctets = 33581 [MCU2_0] 575.248444 s: portMaskDrop = 81 [MCU2_0] 575.248484 s: alePolicyMatch = 19 [MCU2_0] 575.248591 s: txPri[0] = 248 [MCU2_0] 575.248642 s: txPriBcnt[0] = 18567 [MCU2_0] 575.248674 s: [MCU2_0] 575.248775 s: [MCU2_0] External Port 0 Statistics [MCU2_0] 575.248814 s: ----------------------------------------- [MCU2_0] 575.248861 s: [MCU2_0] 575.248953 s: [MCU2_0] External Port 1 Statistics [MCU2_0] 575.248988 s: ----------------------------------------- [MCU2_0] 575.249025 s: [MCU2_0] 575.249110 s: [MCU2_0] External Port 2 Statistics [MCU2_0] 575.249143 s: ----------------------------------------- [MCU2_0] 575.249178 s: [MCU2_0] 575.249259 s: [MCU2_0] External Port 3 Statistics [MCU2_0] 575.249293 s: ----------------------------------------- [MCU2_0] 575.249345 s: rxGoodFrames = 248 [MCU2_0] 575.249389 s: rxBcastFrames = 232 [MCU2_0] 575.249430 s: rxMcastFrames = 16 [MCU2_0] 575.249471 s: rxOctets = 18567 [MCU2_0] 575.249578 s: octetsFrames64 = 231 [MCU2_0] 575.249624 s: octetsFrames128to255 = 17 [MCU2_0] 575.249666 s: netOctets = 18567 [MCU2_0] 575.249708 s: aleUnknownMcast = 16 [MCU2_0] 575.249748 s: aleUnknownMcastBcnt = 3536 [MCU2_0] 575.249788 s: aleUnknownBcast = 232 [MCU2_0] 575.249827 s: aleUnknownBcastBcnt = 15031 [MCU2_0] 575.249867 s: alePolicyMatch = 231 [MCU2_0] 575.249897 s: [MCU2_0] 575.249993 s: [MCU2_0] External Port 4 Statistics [MCU2_0] 575.250029 s: ----------------------------------------- [MCU2_0] 575.250068 s: [MCU2_0] 575.250153 s: [MCU2_0] External Port 5 Statistics [MCU2_0] 575.250187 s: ----------------------------------------- [MCU2_0] 575.250221 s: [MCU2_0] 575.250304 s: [MCU2_0] External Port 6 Statistics [MCU2_0] 575.250339 s: ----------------------------------------- [MCU2_0] 575.250374 s: [MCU2_0] 575.250454 s: [MCU2_0] External Port 7 Statistics [MCU2_0] 575.250488 s: ----------------------------------------- [MCU2_0] 575.250582 s: [MCU2_1] 2.269442 s: CIO: Init ... Done !!! [MCU2_1] 2.269521 s: ### CPU Frequency = 1000000000 Hz [MCU2_1] 2.269566 s: APP: Init ... !!! [MCU2_1] 2.269596 s: SCICLIENT: Init ... !!! [MCU2_1] 2.269869 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [MCU2_1] 2.269935 s: SCICLIENT: DMSC FW revision 0x8 [MCU2_1] 2.269977 s: SCICLIENT: DMSC FW ABI revision 3.1 [MCU2_1] 2.270019 s: SCICLIENT: Init ... Done !!! [MCU2_1] 2.270050 s: UDMA: Init ... !!! [MCU2_1] 2.271668 s: UDMA: Init ... Done !!! [MCU2_1] 2.271737 s: MEM: Init ... !!! [MCU2_1] 2.271783 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ da000000 of size 16777216 bytes !!! [MCU2_1] 2.271860 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 3640000 of size 262144 bytes !!! [MCU2_1] 2.271920 s: MEM: Init ... Done !!! [MCU2_1] 2.271958 s: IPC: Init ... !!! [MCU2_1] 2.272028 s: IPC: 6 CPUs participating in IPC !!! [MCU2_1] 2.272089 s: IPC: Waiting for HLOS to be ready ... !!! [MCU2_1] 14.271650 s: IPC: HLOS is ready !!! [MCU2_1] 14.287641 s: IPC: Init ... Done !!! [MCU2_1] 14.287717 s: APP: Syncing with 5 CPUs ... !!! [MCU2_1] 14.287770 s: APP: Syncing with 5 CPUs ... Done !!! [MCU2_1] 14.287811 s: REMOTE_SERVICE: Init ... !!! [MCU2_1] 14.290069 s: REMOTE_SERVICE: Init ... Done !!! [MCU2_1] 14.290141 s: FVID2: Init ... !!! [MCU2_1] 14.290227 s: FVID2: Init ... Done !!! [MCU2_1] 14.290267 s: VHWA: DMPAC: Init ... !!! [MCU2_1] 14.290296 s: SCICLIENT: Sciclient_pmSetModuleState module=48 state=2 [MCU2_1] 14.290848 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 14.290891 s: SCICLIENT: Sciclient_pmSetModuleState module=305 state=2 [MCU2_1] 14.291380 s: SCICLIENT: Sciclient_pmSetModuleState success [MCU2_1] 14.291420 s: VHWA: DOF Init ... !!! [MCU2_1] 14.299896 s: VHWA: DOF Init ... Done !!! [MCU2_1] 14.299972 s: VHWA: SDE Init ... !!! [MCU2_1] 14.302798 s: VHWA: SDE Init ... Done !!! [MCU2_1] 14.302862 s: VHWA: DMPAC: Init ... Done !!! [MCU2_1] 14.302916 s: VX_ZONE_INIT:Enabled [MCU2_1] 14.302958 s: VX_ZONE_ERROR:Enabled [MCU2_1] 14.302988 s: VX_ZONE_WARNING:Enabled [MCU2_1] 14.304255 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_SDE [MCU2_1] 14.304517 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target DMPAC_DOF [MCU2_1] 14.304769 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:64] Added target MCU2-1 [MCU2_1] 14.304829 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [MCU2_1] 14.304868 s: APP: OpenVX Target kernel init ... !!! [MCU2_1] 14.305200 s: APP: OpenVX Target kernel init ... Done !!! [MCU2_1] 14.305247 s: UDMA Copy: Init ... !!! [MCU2_1] 14.307105 s: UDMA Copy: Init ... Done !!! [MCU2_1] 14.307177 s: APP: Init ... Done !!! [MCU2_1] 14.307211 s: APP: Run ... !!! [MCU2_1] 14.307236 s: IPC: Starting echo test ... [MCU2_1] 14.309796 s: APP: Run ... Done !!! [MCU2_1] 14.311111 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[.] C7X_1[.] [MCU2_1] 14.311236 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[.] [MCU2_1] 14.311340 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [MCU2_1] 14.729468 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[s] C66X_1[P] C66X_2[P] C7X_1[P] [C6x_1 ] 2.372588 s: CIO: Init ... Done !!! [C6x_1 ] 2.372615 s: ### CPU Frequency = 1350000000 Hz [C6x_1 ] 2.372626 s: APP: Init ... !!! [C6x_1 ] 2.372634 s: SCICLIENT: Init ... !!! [C6x_1 ] 2.372865 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C6x_1 ] 2.372877 s: SCICLIENT: DMSC FW revision 0x8 [C6x_1 ] 2.372887 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_1 ] 2.372897 s: SCICLIENT: Init ... Done !!! [C6x_1 ] 2.372907 s: UDMA: Init ... !!! [C6x_1 ] 2.374484 s: UDMA: Init ... Done !!! [C6x_1 ] 2.374508 s: MEM: Init ... !!! [C6x_1 ] 2.374522 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ dc000000 of size 16777216 bytes !!! [C6x_1 ] 2.374541 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_1 ] 2.374557 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ dd000000 of size 50331648 bytes !!! [C6x_1 ] 2.374573 s: MEM: Init ... Done !!! [C6x_1 ] 2.374582 s: IPC: Init ... !!! [C6x_1 ] 2.374603 s: IPC: 6 CPUs participating in IPC !!! [C6x_1 ] 2.374619 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_1 ] 12.728484 s: IPC: HLOS is ready !!! [C6x_1 ] 12.732814 s: IPC: Init ... Done !!! [C6x_1 ] 12.732845 s: APP: Syncing with 5 CPUs ... !!! [C6x_1 ] 14.287769 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_1 ] 14.287787 s: REMOTE_SERVICE: Init ... !!! [C6x_1 ] 14.288674 s: REMOTE_SERVICE: Init ... Done !!! [C6x_1 ] 14.288724 s: VX_ZONE_INIT:Enabled [C6x_1 ] 14.288739 s: VX_ZONE_ERROR:Enabled [C6x_1 ] 14.288749 s: VX_ZONE_WARNING:Enabled [C6x_1 ] 14.289715 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_1 ] 14.289797 s: APP: OpenVX Target kernel init ... !!! [C6x_1 ] 14.290148 s: APP: OpenVX Target kernel init ... Done !!! [C6x_1 ] 14.290170 s: UDMA Copy: Init ... !!! [C6x_1 ] 14.293730 s: UDMA Copy: Init ... Done !!! [C6x_1 ] 14.293750 s: APP: Init ... Done !!! [C6x_1 ] 14.293758 s: APP: Run ... !!! [C6x_1 ] 14.293767 s: IPC: Starting echo test ... [C6x_1 ] 14.295023 s: APP: Run ... Done !!! [C6x_1 ] 14.295375 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[x] C7X_1[P] [C6x_1 ] 14.295804 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 14.310382 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_1 ] 14.729325 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[s] C66X_2[P] C7X_1[P] [C6x_2 ] 2.466132 s: CIO: Init ... Done !!! [C6x_2 ] 2.466160 s: ### CPU Frequency = 1350000000 Hz [C6x_2 ] 2.466171 s: APP: Init ... !!! [C6x_2 ] 2.466180 s: SCICLIENT: Init ... !!! [C6x_2 ] 2.466404 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C6x_2 ] 2.466417 s: SCICLIENT: DMSC FW revision 0x8 [C6x_2 ] 2.466427 s: SCICLIENT: DMSC FW ABI revision 3.1 [C6x_2 ] 2.466438 s: SCICLIENT: Init ... Done !!! [C6x_2 ] 2.466448 s: UDMA: Init ... !!! [C6x_2 ] 2.468043 s: UDMA: Init ... Done !!! [C6x_2 ] 2.468067 s: MEM: Init ... !!! [C6x_2 ] 2.468082 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ e0000000 of size 16777216 bytes !!! [C6x_2 ] 2.468101 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 800000 of size 229376 bytes !!! [C6x_2 ] 2.468117 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ e1000000 of size 50331648 bytes !!! [C6x_2 ] 2.468134 s: MEM: Init ... Done !!! [C6x_2 ] 2.468143 s: IPC: Init ... !!! [C6x_2 ] 2.468165 s: IPC: 6 CPUs participating in IPC !!! [C6x_2 ] 2.468182 s: IPC: Waiting for HLOS to be ready ... !!! [C6x_2 ] 12.982489 s: IPC: HLOS is ready !!! [C6x_2 ] 12.986608 s: IPC: Init ... Done !!! [C6x_2 ] 12.986637 s: APP: Syncing with 5 CPUs ... !!! [C6x_2 ] 14.287769 s: APP: Syncing with 5 CPUs ... Done !!! [C6x_2 ] 14.287788 s: REMOTE_SERVICE: Init ... !!! [C6x_2 ] 14.288693 s: REMOTE_SERVICE: Init ... Done !!! [C6x_2 ] 14.288740 s: VX_ZONE_INIT:Enabled [C6x_2 ] 14.288754 s: VX_ZONE_ERROR:Enabled [C6x_2 ] 14.288764 s: VX_ZONE_WARNING:Enabled [C6x_2 ] 14.289730 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C6x_2 ] 14.289817 s: APP: OpenVX Target kernel init ... !!! [C6x_2 ] 14.290172 s: APP: OpenVX Target kernel init ... Done !!! [C6x_2 ] 14.290196 s: UDMA Copy: Init ... !!! [C6x_2 ] 14.294047 s: UDMA Copy: Init ... Done !!! [C6x_2 ] 14.294069 s: APP: Init ... Done !!! [C6x_2 ] 14.294078 s: APP: Run ... !!! [C6x_2 ] 14.294088 s: IPC: Starting echo test ... [C6x_2 ] 14.295453 s: APP: Run ... Done !!! [C6x_2 ] 14.295813 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[.] [C6x_2 ] 14.295858 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 14.310409 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C6x_2 ] 14.729345 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[s] C7X_1[P] [C7x_1 ] 2.700794 s: CIO: Init ... Done !!! [C7x_1 ] 2.700810 s: ### CPU Frequency = 1000000000 Hz [C7x_1 ] 2.700822 s: APP: Init ... !!! [C7x_1 ] 2.700830 s: SCICLIENT: Init ... !!! [C7x_1 ] 2.701078 s: SCICLIENT: DMSC FW version [8.4.1--v08.04.01 (Jolly Jellyfi] [C7x_1 ] 2.701092 s: SCICLIENT: DMSC FW revision 0x8 [C7x_1 ] 2.701103 s: SCICLIENT: DMSC FW ABI revision 3.1 [C7x_1 ] 2.701114 s: SCICLIENT: Init ... Done !!! [C7x_1 ] 2.701123 s: UDMA: Init ... !!! [C7x_1 ] 2.702329 s: UDMA: Init ... Done !!! [C7x_1 ] 2.702343 s: MEM: Init ... !!! [C7x_1 ] 2.702355 s: MEM: Created heap (DDR_LOCAL_MEM, id=0, flags=0x00000004) @ 117000000 of size 268435456 bytes !!! [C7x_1 ] 2.702375 s: MEM: Created heap (L3_MEM, id=1, flags=0x00000001) @ 70020000 of size 8159232 bytes !!! [C7x_1 ] 2.702393 s: MEM: Created heap (L2_MEM, id=2, flags=0x00000001) @ 64800000 of size 458752 bytes !!! [C7x_1 ] 2.702411 s: MEM: Created heap (L1_MEM, id=3, flags=0x00000001) @ 64e00000 of size 16384 bytes !!! [C7x_1 ] 2.702428 s: MEM: Created heap (DDR_SCRATCH_MEM, id=4, flags=0x00000001) @ 100000000 of size 385875968 bytes !!! [C7x_1 ] 2.702447 s: MEM: Init ... Done !!! [C7x_1 ] 2.702455 s: IPC: Init ... !!! [C7x_1 ] 2.702471 s: IPC: 6 CPUs participating in IPC !!! [C7x_1 ] 2.702486 s: IPC: Waiting for HLOS to be ready ... !!! [C7x_1 ] 13.389721 s: IPC: HLOS is ready !!! [C7x_1 ] 13.392074 s: IPC: Init ... Done !!! [C7x_1 ] 13.392091 s: APP: Syncing with 5 CPUs ... !!! [C7x_1 ] 14.287771 s: APP: Syncing with 5 CPUs ... Done !!! [C7x_1 ] 14.287792 s: REMOTE_SERVICE: Init ... !!! [C7x_1 ] 14.288003 s: REMOTE_SERVICE: Init ... Done !!! [C7x_1 ] 14.288030 s: VX_ZONE_INIT:Enabled [C7x_1 ] 14.288041 s: VX_ZONE_ERROR:Enabled [C7x_1 ] 14.288051 s: VX_ZONE_WARNING:Enabled [C7x_1 ] 14.288269 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1 [C7x_1 ] 14.288394 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_2 [C7x_1 ] 14.288519 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_3 [C7x_1 ] 14.288611 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_4 [C7x_1 ] 14.288720 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_5 [C7x_1 ] 14.288853 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_6 [C7x_1 ] 14.289036 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_7 [C7x_1 ] 14.289125 s: VX_ZONE_INIT:[tivxPlatformCreateTargetId:59] Added target DSP_C7-1_PRI_8 [C7x_1 ] 14.289148 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!! [C7x_1 ] 14.289161 s: APP: OpenVX Target kernel init ... !!! [C7x_1 ] 14.289356 s: APP: OpenVX Target kernel init ... Done !!! [C7x_1 ] 14.289372 s: APP: Init ... Done !!! [C7x_1 ] 14.289382 s: APP: Run ... !!! [C7x_1 ] 14.289391 s: IPC: Starting echo test ... [C7x_1 ] 14.289636 s: APP: Run ... Done !!! [C7x_1 ] 14.295391 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[x] C7X_1[s] [C7x_1 ] 14.295820 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[x] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 14.310436 s: IPC: Echo status: mpu1_0[x] mcu2_0[x] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s] [C7x_1 ] 14.729397 s: IPC: Echo status: mpu1_0[x] mcu2_0[P] mcu2_1[P] C66X_1[P] C66X_2[P] C7X_1[s]
6.在上述序列中,使用以下命令从 PC 和 A72收集 tcpdump 日志。
#tcpdump -I -xx
我使用 PC ping A72、下面是图片和日志
root@j7-evm:~# tcpdump -i eth1 -xx
[ 707.880418] device eth1 entered promiscuous mode
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth1, link-type EN10MB (Ethernet), capture size 262144 bytes
09:18:29.555451 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 70:ff:76:1d:92:c1 (oui Unknown), length 288
0x0000: ffff ffff ffff 70ff 761d 92c1 0800 45c0
0x0010: 013c 0000 0000 4011 78f2 0000 0000 ffff
0x0020: ffff 0044 0043 0128 26a3 0101 0600 baf8
0x0030: c39c 02c1 0000 0000 0000 0000 0000 0000
0x0040: 0000 0000 0000 70ff 761d 92c1 0000 0000
0x0050: 0000 0000 0000 0000 0000 0000 0000 0000
0x0060: 0000 0000 0000 0000 0000 0000 0000 0000
0x0070: 0000 0000 0000 0000 0000 0000 0000 0000
0x0080: 0000 0000 0000 0000 0000 0000 0000 0000
0x0090: 0000 0000 0000 0000 0000 0000 0000 0000
0x00a0: 0000 0000 0000 0000 0000 0000 0000 0000
0x00b0: 0000 0000 0000 0000 0000 0000 0000 0000
0x00c0: 0000 0000 0000 0000 0000 0000 0000 0000
0x00d0: 0000 0000 0000 0000 0000 0000 0000 0000
0x00e0: 0000 0000 0000 0000 0000 0000 0000 0000
0x00f0: 0000 0000 0000 0000 0000 0000 0000 0000
0x0100: 0000 0000 0000 0000 0000 0000 0000 0000
0x0110: 0000 0000 0000 6382 5363 3501 013d 13ff
0x0120: bb8a 56a3 0002 0000 ab11 a01e b168 e080
0x0130: 5516 3709 0103 0c0f 0621 792a 7839 0202
0x0140: 400c 066a 372d 6576 6dff
09:18:59.626841 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
0x0000: 3333 0000 00fb 902e 16e9 9160 86dd 6005
0x0010: 435a 0024 1101 fe80 0000 0000 0000 de4d
0x0020: d92f 4758 90ee ff02 0000 0000 0000 0000
0x0030: 0000 0000 00fb 14e9 14e9 0024 32df 0000
0x0040: 0000 0001 0000 0000 0000 0477 7061 6405
0x0050: 6c6f 6361 6c00 0001 0001
09:18:59.627342 IP6 fe80::de4d:d92f:4758:90ee.52489 > ff02::1:3.hostmon: UDP, length 22
0x0000: 3333 0001 0003 902e 16e9 9160 86dd 6003
0x0010: f691 001e 1101 fe80 0000 0000 0000 de4d
0x0030: 0000 0001 0003 cd09 14eb 001e 1013 a782
0x0040: 0000 0001 0000 0000 0000 0477 7061 6400
0x0050: 0001 0001
09:19:00.050579 IP6 fe80::de4d:d92f:4758:90ee.52489 > ff02::1:3.hostmon: UDP, length 22
0x0050: 0001 0001
09:19:00.635408 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
09:19:01.623205 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
0x0000: 3333 0000 00fb 902e 16e9 9160 86dd 600a
0x0010: fddf 0024 1101 fe80 0000 0000 0000 de4d
09:19:01.623568 IP6 fe80::de4d:d92f:4758:90ee.63879 > ff02::1:3.hostmon: UDP, length 22
0x0000: 3333 0001 0003 902e 16e9 9160 86dd 6000
0x0010: 08af 001e 1101 fe80 0000 0000 0000 de4d
0x0030: 0000 0001 0003 f987 14eb 001e 6dbd 1d5a
0x0050: 0001 0001
09:19:02.035618 IP6 fe80::de4d:d92f:4758:90ee.63879 > ff02::1:3.hostmon: UDP, length 22
0x0050: 0001 0001
09:19:02.625626 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
09:19:10.639999 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
0x0000: 3333 0000 00fb 902e 16e9 9160 86dd 6000
0x0010: b864 0024 1101 fe80 0000 0000 0000 de4d
09:19:10.639999 IP6 fe80::de4d:d92f:4758:90ee.55498 > ff02::1:3.hostmon: UDP, length 22
0x0000: 3333 0001 0003 902e 16e9 9160 86dd 6002
0x0010: c95f 001e 1101 fe80 0000 0000 0000 de4d
0x0030: 0000 0001 0003 d8ca 14eb 001e 857d 2657
0x0050: 0001 0001
09:19:11.057309 IP6 fe80::de4d:d92f:4758:90ee.55498 > ff02::1:3.hostmon: UDP, length 22
0x0050: 0001 0001
09:19:11.646567 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
09:19:19.712576 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
09:19:19.713983 IP6 fe80::de4d:d92f:4758:90ee.60379 > ff02::1:3.hostmon: UDP, length 22
0x0000: 3333 0001 0003 902e 16e9 9160 86dd 6001
0x0010: f890 001e 1101 fe80 0000 0000 0000 de4d
0x0030: 0000 0001 0003 ebdb 14eb 001e 840f 14b4
0x0050: 0001 0001
09:19:20.131769 IP6 fe80::de4d:d92f:4758:90ee.60379 > ff02::1:3.hostmon: UDP, length 22
0x0050: 0001 0001
09:19:20.715579 IP6 fe80::de4d:d92f:4758:90ee.mdns > ff02::fb.mdns: 0 A (QM)? wpad.local. (28)
09:19:34.177133 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 70:ff:76:1d:92:c1 (oui Unknown), length 288
0x0020: ffff 0044 0043 0128 2662 0101 0600 baf8
0x0030: c39c 0302 0000 0000 0000 0000 0000 0000
09:20:39.062525 IP 0.0.0.0.bootpc > 255.255.255.255.bootps: BOOTP/DHCP, Request from 70:ff:76:1d:92:c1 (oui Unknown), length 288
0x0020: ffff 0044 0043 0128 2621 0101 0600 baf8
0x0030: c39c 0343 0000 0000 0000 0000 0000 0000
^C
19 packets captured
19 packets received by filter
0 packets dr[ 884.436857] device eth1 left promiscuous mode
我使用 A72对 PC 执行 ping 操作。 PC 未接收数据包。
