[参考译文] Linux/DRA750:DRA750
Guru**** 2555630 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/784185/linux-dra750-dra750
器件型号:DRA750
工具/软件:Linux
我正在执行以下步骤、但遇到错误:
1.遵循第2.4节;make linux;make linux_install (仍不在 targetfs 下获取 EGL)
2.在 Rules.make 中选择 make config
TDA2XX
MAKECONFIG=tda2xx_EVM_Linux_ALL
3.构建 SDK 依赖项
$>make -s -j 取决于
4.构建 SDK
$>make -s -j
/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build make -s -j
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build/rtos/makerules/rules_66.mk:185:在同一规则中多次指定目标'/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignLUT_tda2xx.oe66
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build/rtos/makerules/rules_66.mk:185:在同一规则中多次指定目标'/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/app_alg_plugins/tda2xx-evm/66/release/GAlignExt_tda2xx.oe66
#正在调用配置...
#正在调用配置...
#正在调用配置...
#正在调用配置...
#正在调用配置...
#正在调用配置...
#配置完成!
#生成 tda2xx-EVM:arp32_1:发布:vision_sdk_lib...
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F...
编号
#配置完成!
#配置完成!
#配置完成!
#创建 tda2xx-EVM:c66xdsp_2:发布:vision_sdk_lib...
#配置完成!
#生成 tda2xx-EVM:arp32_4:发布:vision_sdk_lib...
#生成 tda2xx-EVM:arp32_2:发布:vision_sdk_lib...
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66...
#创建 tda2xx-EVM:c66xdsp_1:发布:vision_sdk_lib...
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F...
编号
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F...
编号
#配置完成!
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66...
#生成 tda2xx-EVM:arp32_3:发布:vision_sdk_lib...
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F...
编号
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd、第7行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd、第8行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd、第13行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve1/linker_cmd_eve1_release.cmd、第14行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd、第7行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd、第8行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd、第13行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve4/linker_cmd_eve4_release.cmd、第14行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd、第7行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd、第8行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd、第13行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve2/linker_cmd_eve2_release.cmd、第14行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd、第7行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd、第8行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd、第13行:警告:
  无匹配段
"/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve3/linker_cmd_eve3_release.cmd、第14行:警告:
  无匹配段
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_2_release.xe66已创建。
编号
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_c66xdsp_1_release.xe66已创建。
编号
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F 已创建。
编号
警告:此应用程序支持的运行时版本不可用。
使用默认运行时:v4.0.30319
解析输入目标文件/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_1_release.xearp32F.
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F 已创建。
编号
使用默认运行时:v4.0.30319
解析输入目标文件/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_4_release.xearp32F.
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F 已创建。
编号
使用默认运行时:v4.0.30319
解析输入目标文件/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_2_release.xearp32F.
文件转换完成!
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F 已创建。
编号
使用默认运行时:v4.0.30319
解析输入目标文件/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_arp32_3_release.xearp32F.
文件转换完成!
文件转换完成!
文件转换完成!
 正在将二进制文件[/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/AppImage 转换为 C 数组... 完成。 (1824188字节)
#正在调用配置...
#正在调用配置...
#配置完成!
#配置完成!
#创建 tda2xx-EVM:ipu1_0:release:vision_sdk_lib...
# Making tda2xx-EVM:ipu2:release:vision_sdk_lib...
#编译 tda2xx-EVM:ipu2:release:vision_SDK:src/eve_firmware.c
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4...
编号
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu1_0_release.xem4已创建。
编号
链接到/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4...
编号
编号
#/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/vision_sdk/bin/tda2xx-evm/vision_sdk_ipu2_release.xem4已创建。
编号
'/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/vision_sdk/tda2xx-evm/ipu2/release/vision_sdk_configuro/osa_mem_map.h '->'/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/hlos/osa/include/osa_mem_map.h '
在/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/linux/posix_types.h:4:0中包含的文件中、
                来自/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/linux/types.h:13、
                来自/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/vdrm_controller/v_controller_if.h:6、
                从 dispDistSrcLink_tsk.c:81:
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/../ti_components/os_tools/linux/kernel/omap/include/uapi/linux/stddef.h:1:28:致命错误:linux/compiler.h:无此类文件或目录
编译已终止。
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/build/hlos/makerules/linux/common_footer_a15.mk:81:目标'epend'的配方失败
maked[6]:***[取决于]错误1
Makefile:16:目标'links_a15_dispDistSrc'的配方失败
make[5]:***[links_a15_dispDistSrc]错误2.
maked[5]:***正在等待未完成的作业...
在 sgxRenderKmsCub.h:65:0中包含的文件中、
                从 sgxRenderKmsCub.c:62:
/home/adit/CC/PROCESSOR_SDK_VISION_03_06_00_00/vision_sdk/links_fw/src/hlos/system/system_gl_egl_utils.h:76:21:致命错误:EGL/EGL.h:无此类文件或目录
编译已终止。
在包含在 esTransform.c:103:0中的文件中:
esUtil.h:105:23:致命错误:GLES2/GL2.h:无此类文件或目录
编译已终止。
在 sgxFrmcpyLink_priv.h:99:0中包含的文件中、
                从 sgxFrmcpyLink_tsk.c:86:
编译已终止。
在 sgxRender1x1.h:65:0中包含的文件中、
                从 sgxRender1x1.c:62:
编译已终止。
在 sgxRender3x3.h:72:0中包含的文件中、
                从 sgxRender3x3.c:62:
编译已终止。
                从 sgxFrmcpyLink_drv.c:80:
编译已终止。
在 sgxRender2x4.h:72:0中包含的文件中、
                从 sgxRender2x4.c:62:
编译已终止。
在 sgxRender2x2.h:71:0中包含的文件中、
                从 sgxRender2x2.c:62:
编译已终止。
Makefile:16:目标'links_a15_sgxFrmcpy'的配方失败
make[5]:***[links_a15_sgxFrmcpy]错误2.
在 system_gl_EGL_utils.c:69:0中包含的文件中:
system_gl_EGL_utils.h:76:21:致命错误:EGL/EGL.h:无此类文件或目录
编译已终止。
System_GBM_LOADator.c:74:17:致命错误:drm.h:无此类文件或目录
编译已终止。
Makefile:16:目标"系统"的配方失败
maked[5]:***[system]错误2.
# OSA:tda2xx-EVM:编译 OSA_mem.c
# OSA:tda2xx-EVM:编译 OSA_REMOLE_LOG_server.c
# OSA:tda2xx-EVM:编译 OSA_REMOLE_LOG_CLIENT.c
# OSA:tda2xx-EVM:正在创建归档文件 OSA.A
Makefile.MK:16:目标'vision_sdk_linux_lib'的配方失败
maked[4]:***[vision_sdk_linux_lib]错误2.
Makefile:233:目标'links_FW_libs_HLOS'的配方失败
maked[3]:***[links_FW_libs_HLOS]错误2.
Makefile:68:目标'apps_HLOS'的配方失败
maked[2]:***[APPS_HLOS]错误2.
Makefile:38:目标'apps'的配方失败
maked[1]:***[APPS]错误2.
Makefile:12:目标'vision_sdk'的配方失败
制造:***[VISION_SDK]错误2.
感谢您的任何帮助。 谢谢!
    您好、Adit、
    您能否进入"processor_sdk_vision_03_06_00_00/ti_compons/os_tools/linux/kernel/omap"目录并检查您的内核是否位于正确的标签"REL_vision_sdk_03_06_00_00"上。
    Yordan
    您好、Adit、
    我没有听到您的反馈、我假设您能够解决您的问题。
    如果不是、只需在下面发布回复(如果该线程由于超时而锁定、则创建新线程)。
    Yordan
