[参考译文] AM6442:如何在 MCU+ SDK 08.05中同时启用 ICSSG 和 CPSW
Guru**** 2649475 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1192355/am6442-how-to-enable-icssg-and-cpsw-at-the-same-time-in-mcu-sdk-08-05
器件型号:AM6442
在 E2E 论坛中、有人回复说版本08_04中支持双 NIC 配置。 但是、在 SDK 的版本08_05中、我们注意到、当 ICSSG 和 CPSW 同时配置时、SYSCFG 生成的配置信息仍不会合并、从而导致 Enet 配置部分中存在大量重复的定义、 连接到 LWIP 的接口不支持双 NIC。 如何同时配置 ICSSG 和 CPSW?
以 ti_enet_soc.c 文件为例、以下是生成的 ti_enet_soc.c 文件代码和编译信息:
syscfg/ti_enet_soc.c:1137:10: error: redefinition of 'gEnetSoc_perObj'
Enet_Obj gEnetSoc_perObj[] =
syscfg/ti_enet_soc.c:290:10: note: previous definition is here
syscfg/ti_enet_soc.c:1255:24: error: redefinition of 'gEnetSoc_dmaObjMemInfo'
EnetUdma_DrvObjMemInfo gEnetSoc_dmaObjMemInfo =
syscfg/ti_enet_soc.c:300:24: note: previous definition is here
syscfg/ti_enet_soc.c:1270:9: error: redefinition of 'EnetSoc_init'
int32_t EnetSoc_init(void)
syscfg/ti_enet_soc.c:310:9: note: previous definition is here
syscfg/ti_enet_soc.c:1286:6: error: redefinition of 'EnetSoc_deinit'
void EnetSoc_deinit(void)
syscfg/ti_enet_soc.c:315:6: note: previous definition is here
syscfg/ti_enet_soc.c:1297:16: error: redefinition of 'EnetSoc_getDmaHandle'
EnetDma_Handle EnetSoc_getDmaHandle(Enet_Type enetType,
syscfg/ti_enet_soc.c:320:16: note: previous definition is here
syscfg/ti_enet_soc.c:1325:13: error: redefinition of 'EnetSoc_getEnetHandleByIdx'
Enet_Handle EnetSoc_getEnetHandleByIdx(uint32_t idx)
syscfg/ti_enet_soc.c:342:13: note: previous definition is here
syscfg/ti_enet_soc.c:1338:13: error: redefinition of 'EnetSoc_getEnetHandle'
Enet_Handle EnetSoc_getEnetHandle(Enet_Type enetType,
syscfg/ti_enet_soc.c:355:13: note: previous definition is here
syscfg/ti_enet_soc.c:1401:14: error: redefinition of 'EnetSoc_isValidEnetType'
static bool  EnetSoc_isValidEnetType(Enet_Type enetType)
syscfg/ti_enet_soc.c:379:14: note: previous definition is here
syscfg/ti_enet_soc.c:1413:10: error: redefinition of 'EnetSoc_getEnetNum'
uint32_t EnetSoc_getEnetNum(void)
syscfg/ti_enet_soc.c:390:10: note: previous definition is here
syscfg/ti_enet_soc.c:1418:10: error: redefinition of 'EnetSoc_getMacPortMax'
uint32_t EnetSoc_getMacPortMax(Enet_Type enetType,
syscfg/ti_enet_soc.c:395:10: note: previous definition is here
syscfg/ti_enet_soc.c:1439:10: error: redefinition of 'EnetSoc_isIpSupported'
uint32_t EnetSoc_isIpSupported(Enet_Type enetType,
syscfg/ti_enet_soc.c:412:10: note: previous definition is here
syscfg/ti_enet_soc.c:1455:10: error: redefinition of 'EnetSoc_getCoreId'
uint32_t EnetSoc_getCoreId(void)
syscfg/ti_enet_soc.c:427:10: note: previous definition is here
syscfg/ti_enet_soc.c:1462:10: error: redefinition of 'EnetSoc_getClkFreq'
uint32_t EnetSoc_getClkFreq(Enet_Type enetType,
syscfg/ti_enet_soc.c:444:10: note: previous definition is here
syscfg/ti_enet_soc.c:1486:10: error: redefinition of 'EnetSoc_getIntrTriggerType'
uint32_t EnetSoc_getIntrTriggerType(Enet_Type enetType,
syscfg/ti_enet_soc.c:554:10: note: previous definition is here
syscfg/ti_enet_soc.c:1495:9: error: redefinition of 'EnetSoc_getEFusedMacAddrs'
int32_t EnetSoc_getEFusedMacAddrs(uint8_t macAddr[][ENET_MAC_ADDR_LEN],
syscfg/ti_enet_soc.c:563:9: note: previous definition is here
syscfg/ti_enet_soc.c:1530:10: error: redefinition of 'EnetSoc_getMacPortCaps'
uint32_t EnetSoc_getMacPortCaps(Enet_Type enetType,
syscfg/ti_enet_soc.c:598:10: note: previous definition is here
syscfg/ti_enet_soc.c:1557:9: error: redefinition of 'EnetSoc_getMacPortMii'
int32_t EnetSoc_getMacPortMii(Enet_Type enetType,
syscfg/ti_enet_soc.c:623:9: note: previous definition is here
syscfg/ti_enet_soc.c:1565:9: error: redefinition of 'EnetSoc_validateQsgmiiCfg'
int32_t EnetSoc_validateQsgmiiCfg(Enet_Type enetType,
syscfg/ti_enet_soc.c:708:9: note: previous definition is here
syscfg/ti_enet_soc.c:1571:9: error: redefinition of 'EnetSoc_mapPort2QsgmiiId'
int32_t EnetSoc_mapPort2QsgmiiId(Enet_Type enetType,
syscfg/ti_enet_soc.c:714:9: note: previous definition is here
fatal error: too many errors emitted, stopping now [-ferror-limit=]
6 warnings and 20 errors generated.
gmake: *** [syscfg/ti_enet_soc.o] Error 1
 *  Copyright (c) Texas Instruments Incorporated 2020
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *    Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  \file ti_enet_soc.c
 *  \brief This file contains enet soc config related functionality.
/*                             Include Files                                  */
#include <string.h>
#include <stdint.h>
#include <stdarg.h>
#include <drivers/sciclient.h>
#include <enet.h>
#include <enet_cfg.h>
#include <priv/mod/cpsw_ale_priv.h>
#include <priv/mod/cpsw_cpts_priv.h>
#include <priv/mod/cpsw_hostport_priv.h>
#include <priv/mod/cpsw_macport_priv.h>
#include <priv/mod/cpsw_stats_priv.h>
#include <priv/mod/mdio_priv.h>
#include <priv/mod/cpsw_clks.h>
#include <priv/core/enet_rm_priv.h>
#include <include/core/enet_utils.h>
#include <include/core/enet_osal.h>
#include <include/core/enet_soc.h>
#include <include/core/enet_per.h>
#include <include/per/cpsw.h>
#include <src/dma/udma/enet_udma_priv.h>
#include <soc/k3/cpsw_soc.h>
#include <priv/per/cpsw_priv.h>
#include <utils/include/enet_appsoc.h>
#include <drivers/hw_include/cslr_soc.h>
#include "ti_enet_config.h"
/*                           Macros & Typedefs                                */
/*                         Structure Declarations                             */
/*                          Function Declarations                             */
static uint32_t EnetSoc_getMcuEnetControl(Enet_MacPort macPort,
                                          uint32_t *modeSel);
/*                            Global Variables                                */
/* -------------------------------- CPSW 3G --------------------------------- */
const CpswSoc_Cfg gEnetSoc_cpsw3gSocCfg =
    /* As per the clocking specification the mcu_sysclk0 is 1000MHz with
     * fixed /3 divider. */
    .cppiClkFreqHz = 320000000LLU,
    .dmscDevId = TISCI_DEV_CPSW0,
    .intrs =
        {   /* EVNT_PEND - Event pending interrupt (CPTS) */
            .intrId     = CPSW_INTR_EVNT_PEND,
            .coreIntNum = CSLR_R5FSS0_CORE0_INTR_CPSW0_EVNT_PEND_0,
            .srcIdx     = ENET_SOC_DIRECT_INTR_SRCIDX_INVALID,
        {   /* STATS_PEND - Statistics pending interrupt */
            .intrId     = CPSW_INTR_STATS_PEND0,
            .coreIntNum = CSLR_R5FSS0_CORE0_INTR_CPSW0_STAT_PEND_0,
        {   /* MDIO_PEND - MDIO interrupt */
            .intrId     = CPSW_INTR_MDIO_PEND,
            .coreIntNum = CSLR_R5FSS0_CORE0_INTR_CPSW0_MDIO_PEND_0,
    .clocks =
        .cppiClkId        = TISCI_DEV_CPSW0_CPPI_CLK_CLK,
        .rgmii250MHzClkId = TISCI_DEV_CPSW0_RGMII_MHZ_250_CLK,
        .rgmii50MHzClkId  = TISCI_DEV_CPSW0_RGMII_MHZ_50_CLK,
        .rgmii5MHzClkId   = TISCI_DEV_CPSW0_RGMII_MHZ_5_CLK,
    .txChPeerThreadId = CSL_PSILCFG_DMSS_CPSW2_PSILD_THREAD_OFFSET,
    .rxChPeerThreadId = CSL_PSILCFG_DMSS_CPSW2_PSILS_THREAD_OFFSET,
    .txChCount        = CSL_PSILCFG_DMSS_CPSW2_PSILD_THREAD_CNT,
    /* Note- Though CPSW supports 64 distinct flow Ids, there are only
     * 8 policer/classifier so can effectively assign only 8 flow ids in CPSW3G */
    .rxFlowCount     = 8U,
/* CPSW_3G MAC port template */
#define ENET_SOC_CPSW3G_MACPORT(n)                                    \
    .enetMod =                                                        \
        .name       = "cpsw3G.macport" #n,                            \
        .physAddr   = (CSL_CPSW0_NUSS_BASE + CPSW_NU_OFFSET),         \
        .physAddr2  = (CSL_CPSW0_NUSS_BASE + CPSW_SGMII0_OFFSET(0U)), \
        .features   = (ENET_FEAT_BASE |                               \
                       CPSW_MACPORT_FEATURE_EST |                     \
                       CPSW_MACPORT_FEATURE_SGMII |                   \
                       CPSW_MACPORT_FEATURE_INTERVLAN),               \
        .errata     = ENET_ERRATA_NONE,                               \
        .open       = &CpswMacPort_open,                              \
        .rejoin     = &CpswMacPort_rejoin,                            \
        .ioctl      = &CpswMacPort_ioctl,                             \
        .close      = &CpswMacPort_close,                             \
    .macPort = ENET_MAC_PORT_ ## n,                                   \
/* CPSW_3G MAC ports */
CpswMacPort_Obj gEnetSoc_cpsw3gMacObj[] =
    ENET_SOC_CPSW3G_MACPORT(1),
    ENET_SOC_CPSW3G_MACPORT(2),
/* CPSW 3G Peripheral */
Cpsw_Obj gEnetSoc_cpsw3g =
    .enetPer =
        .name         = "cpsw3g",
        .enetType     = ENET_CPSW_3G,
        .instId       = 0U,
        .magic        = ENET_NO_MAGIC,
        .physAddr2    = (CSL_CPSW0_NUSS_BASE + CPSW_NUSS_OFFSET),
                         CPSW_FEATURE_EST |
                         CPSW_FEATURE_INTERVLAN),
        .initCfg      = &Cpsw_initCfg,
        .open         = &Cpsw_open,
        .rejoin       = &Cpsw_rejoin,
        .ioctl        = &Cpsw_ioctl,
        .poll         = &Cpsw_poll,
        .convertTs    = NULL,
        .periodicTick = &Cpsw_periodicTick,
        .registerEventCb = NULL,
        .unregisterEventCb = NULL,
        .close        = &Cpsw_close,
    /* Host port module object */
    .hostPortObj =
        .enetMod =
            .name       = "cpsw3g.hostport",
            .features   = ENET_FEAT_BASE,
            .open       = &CpswHostPort_open,
            .rejoin     = &CpswHostPort_rejoin,
            .ioctl      = &CpswHostPort_ioctl,
            .close      = &CpswHostPort_close,
    /* MAC port module objects */
    .macPortObj = gEnetSoc_cpsw3gMacObj,
    .macPortNum = ENET_ARRAYSIZE(gEnetSoc_cpsw3gMacObj),
    /* ALE module object */
    .aleObj =
        .enetMod =
            .name       = "cpsw3g.ale",
            .physAddr   = (CSL_CPSW0_NUSS_BASE + CPSW_ALE_OFFSET),
                           CPSW_ALE_FEATURE_FLOW_PRIORITY |
                           CPSW_ALE_FEATURE_IP_HDR_WHITELIST),
            .open       = &CpswAle_open,
            .rejoin     = &CpswAle_rejoin,
            .ioctl      = &CpswAle_ioctl,
            .close      = &CpswAle_close,
    /* CPTS module object */
    .cptsObj =
        .enetMod =
            .name       = "cpsw3g.cpts",
            .physAddr   = (CSL_CPSW0_NUSS_BASE + CPSW_CPTS_OFFSET),
            .open       = &CpswCpts_open,
            .rejoin     = &CpswCpts_rejoin,
            .ioctl      = &CpswCpts_ioctl,
            .close      = &CpswCpts_close,
        .hwPushCnt      = 8U,
    /* MDIO module object */
    .mdioObj =
        .enetMod =
            .name       = "cpsw3g.mdio",
            .physAddr   = (CSL_CPSW0_NUSS_BASE + CPSW_MDIO_OFFSET),
                           MDIO_FEATURE_CLAUSE45),
            .open       = &Mdio_open,
            .rejoin     = &Mdio_rejoin,
            .ioctl      = &Mdio_ioctl,
            .close      = &Mdio_close,
    /* Statistics module object */
    .statsObj =
        .enetMod =
            .name       = "cpsw3g.stats",
            .open       = &CpswStats_open,
            .rejoin     = &CpswStats_rejoin,
            .ioctl      = &CpswStats_ioctl,
            .close      = &CpswStats_close,
    /* RM module object */
    .rmObj =
        .enetMod =
            .name       = "cpsw3g.rm",
            .physAddr   = 0U,
            .open       = &EnetRm_open,
            .rejoin     = &EnetRm_rejoin,
            .ioctl      = &EnetRm_ioctl,
            .close      = &EnetRm_close,
/* ---------------------------- Enet Peripherals ---------------------------- */
    /* CPSW_3G Enet driver/peripheral */
        .enetPer = &gEnetSoc_cpsw3g.enetPer,
EnetUdma_DrvObj gEnetSoc_dmaObj[ENET_ARRAYSIZE(gEnetSoc_perObj)];
    .numObjs = ENET_ARRAYSIZE(gEnetSoc_dmaObj),
    .drvObjMem = &gEnetSoc_dmaObj[0],
/*                          Function Definitions                              */
    return ENET_SOK;
                                    uint32_t instId)
    EnetDma_Handle hDma = NULL;
    switch (enetType)
        case ENET_CPSW_3G:
            if (instId == 0U)
                hDma = &gEnetSoc_dmaObjMemInfo.drvObjMem[0U];
            break;
        default:
            break;
    EnetSoc_assert(hDma != NULL, "Invalid peripheral (eneType=%u instId=%u)\n", enetType, instId);
    return hDma;
    Enet_Handle hEnet = NULL;
    if (idx < ENET_ARRAYSIZE(gEnetSoc_perObj))
        hEnet = &gEnetSoc_perObj[idx];
    EnetSoc_assert((hEnet != NULL), "Unsupported  peripheral index (index=%u )\n", idx);
    return hEnet;
                                  uint32_t instId)
    switch (enetType)
        case ENET_CPSW_3G:
            if (instId == 0U)
                hEnet = &gEnetSoc_perObj[0U];
            break;
        default:
                EnetSoc_assert(false, "Invalid peripheral (eneType=%u instId=%u)\n", enetType, instId);
            break;
    EnetSoc_assert((hEnet != NULL), "Invalid peripheral (eneType=%u instId=%u)\n", enetType, instId);
    return hEnet;
    bool validInstanceType = false;
    if (enetType == ENET_CPSW_3G)
        validInstanceType = true;
    return validInstanceType;
    return ENET_ARRAYSIZE(gEnetSoc_perObj);
                               uint32_t instId)
    uint32_t numPorts = 0U;
    if ((enetType == ENET_CPSW_3G) && (instId == 0U))
        numPorts = 2;
    else
    return numPorts;
                               uint32_t instId)
    bool supported = false;
    if ((enetType == ENET_CPSW_3G) && (0U == instId))
        supported = true;
    EnetSoc_assert((EnetSoc_isValidEnetType(enetType) == true), "Invalid Enet & instId type %d, %d\n", enetType, instId);
    return supported;
    uint32_t coreId = CSL_CORE_ID_R5FSS0_0;
    return coreId;
static uint32_t EnetSoc_getCoreDevId(void)
    uint32_t coreDevId;
    coreDevId = TISCI_DEV_R5FSS0_CORE0;
    return coreDevId;
                            uint32_t instId,
                            uint32_t clkId)
    uint32_t freq = 0U;
    if (clkId == CPSW_CPPI_CLK)
            freq = gEnetSoc_cpsw3gSocCfg.cppiClkFreqHz;
        EnetSoc_assert((EnetSoc_isValidEnetType(enetType) == true), "Invalid Enet type %d\n", enetType);
    else
        EnetSoc_assert(false, "Invalid clk id %u\n", clkId);
    return freq;
int32_t EnetSoc_setupIntrCfg(Enet_Type enetType,
                             uint32_t instId,
                             uint32_t intrId)
    const EnetSoc_IntrConnCfg *socIntrs = NULL;
    uint32_t numSocIntrs = 0U;
    uint16_t coreDevId = EnetSoc_getCoreDevId();
    uint16_t perDevId = 0U;
    int32_t status = ENET_SOK;
        perDevId    = gEnetSoc_cpsw3gSocCfg.dmscDevId;
        socIntrs    = gEnetSoc_cpsw3gSocCfg.intrs;
        numSocIntrs = ENET_ARRAYSIZE(gEnetSoc_cpsw3gSocCfg.intrs);
    else
        status = ENET_EINVALIDPARAMS;
    if (status == ENET_SOK)
        status = EnetSocJ7x_setupIntrCfg(intrId, coreDevId, perDevId, socIntrs, numSocIntrs);
    return status;
int32_t EnetSoc_releaseIntrCfg(Enet_Type enetType,
                               uint32_t instId,
                               uint32_t intrId)
    else
        status = EnetSocJ7x_releaseIntrCfg(intrId, coreDevId, perDevId, socIntrs, numSocIntrs);
    return status;
uint32_t EnetSoc_getIntrNum(Enet_Type enetType,
                            uint32_t instId,
                            uint32_t intrId)
    uint32_t intrNum = 0U;
    else
        intrNum = EnetSocJ7x_getIntrNum(intrId, socIntrs, numSocIntrs);
    return intrNum;
                                    uint32_t instId,
                                    uint32_t intrId)
    return ENETOSAL_ARM_GIC_TRIG_TYPE_LEVEL;
/* Stupid hack to workaround FAE board issues */
//#define ENET_MAC_ADDR_HACK (TRUE)
                                  uint32_t *num)
#ifndef ENET_MAC_ADDR_HACK
    CSL_main_ctrl_mmr_cfg0Regs *mmrRegs;
    uint32_t val;
    if (*num >= 1U)
        mmrRegs = (CSL_main_ctrl_mmr_cfg0Regs *)(uintptr_t)CSL_CTRL_MMR0_CFG0_BASE;
        val = CSL_REG32_RD(&mmrRegs->MAC_ID0);
        macAddr[0][5] = (uint8_t)((val & 0x000000FFU) >> 0U);
        macAddr[0][4] = (uint8_t)((val & 0x0000FF00U) >> 8U);
        macAddr[0][3] = (uint8_t)((val & 0x00FF0000U) >> 16U);
        macAddr[0][2] = (uint8_t)((val & 0xFF000000U) >> 24U);
        val = CSL_REG32_RD(&mmrRegs->MAC_ID1);
        macAddr[0][1] = (uint8_t)((val & 0x000000FFU) >> 0U);
        macAddr[0][0] = (uint8_t)((val & 0x0000FF00U) >> 8U);
        *num = 1U;
#else
    macAddr[0][0] = 0xF4;
    macAddr[0][1] = 0x84;
    macAddr[0][2] = 0x4c;
    macAddr[0][3] = 0xf9;
    macAddr[0][4] = 0x4d;
    macAddr[0][5] = 0x29;
    *num = 1U;
#endif
    return ENET_SOK;
                                uint32_t instId,
                                Enet_MacPort macPort)
    uint32_t linkCaps = 0U;
    switch (enetType)
        case ENET_CPSW_3G:
            if (macPort <= ENET_MAC_PORT_2)
                linkCaps = (ENETPHY_LINK_CAP_HD10 | ENETPHY_LINK_CAP_FD10 |
                            ENETPHY_LINK_CAP_HD100 | ENETPHY_LINK_CAP_FD100 |
                            ENETPHY_LINK_CAP_FD1000);
            break;
        default:
            EnetSoc_assert(false, "Invalid peripheral type: %u\n", enetType);
            break;
    return linkCaps;
                              uint32_t instId,
                              EnetMacPort_Interface *mii)
    EnetMac_LayerType *enetLayer = &mii->layerType;
    EnetMac_SublayerType *enetSublayer = &mii->sublayerType;
    uint32_t modeSel = CPSW_ENET_CTRL_MODE_RGMII;
    int32_t status = ENET_EFAIL;
    switch (enetType)
        case ENET_CPSW_3G:
            status = EnetSoc_getMcuEnetControl(macPort, &modeSel);
            break;
        default:
            break;
        switch (modeSel)
            /* RMII */
            case CPSW_ENET_CTRL_MODE_RMII:
                *enetLayer    = ENET_MAC_LAYER_MII;
                *enetSublayer = ENET_MAC_SUBLAYER_REDUCED;
                break;
            /* RGMII */
            case CPSW_ENET_CTRL_MODE_RGMII:
                *enetLayer    = ENET_MAC_LAYER_GMII;
                break;
            default:
                break;
    return status;
                                          uint32_t *modeSel)
    CSL_main_ctrl_mmr_cfg0Regs *regs =
    switch (macPort)
        case ENET_MAC_PORT_1:
            *modeSel = CSL_FEXT(regs->ENET1_CTRL, MAIN_CTRL_MMR_CFG0_ENET1_CTRL_PORT_MODE_SEL);
            break;
        case ENET_MAC_PORT_2:
            *modeSel = CSL_FEXT(regs->ENET2_CTRL, MAIN_CTRL_MMR_CFG0_ENET2_CTRL_PORT_MODE_SEL);
            break;
        default:
            break;
        switch (*modeSel)
                break;
            default:
                break;
    return status;
                                  uint32_t instId)
    return ENET_ENOTSUPPORTED;
                                 uint32_t instId,
                                 Enet_MacPort portNum,
                                 uint32_t *qsgmiiId)
uint32_t EnetSoc_getRxFlowCount(Enet_Type enetType,
                                uint32_t instId)
    uint32_t rxFlowCount = 0U;
    /* Get SoC array index */
        rxFlowCount = gEnetSoc_cpsw3gSocCfg.rxFlowCount;
    return rxFlowCount;
uint32_t EnetSoc_getTxChPeerId(Enet_Type enetType,
                               uint32_t instId,
                               uint32_t chNum)
    uint32_t peerChNum = 0U;
        peerChNum = gEnetSoc_cpsw3gSocCfg.txChPeerThreadId;
    /* Get PSI-L destination thread offset for Tx channel */
    peerChNum = (peerChNum + chNum);
    return peerChNum;
uint32_t EnetSoc_getRxChPeerId(Enet_Type enetType,
                               uint32_t instId,
                               uint32_t chIdx)
        peerChNum = gEnetSoc_cpsw3gSocCfg.rxChPeerThreadId;
    return peerChNum;
uint32_t EnetSoc_getTxChCount(Enet_Type enetType,
                              uint32_t instId)
    uint32_t txChCount = 0U;
        txChCount = gEnetSoc_cpsw3gSocCfg.txChCount;
    return txChCount;
 *  \brief CPSW3G default configuration
 *   Note: If user wishes to change the Resource Partition the following
 *   things must be considered:
 *   1. Sum of numTxCh allocated to each core should not exceed 8.
 *   2. Sum of numRxFlows allocated to each core should not exceed 7 (not 8),
 *      as one Rx flow is reserved to the master core.
static EnetRm_ResPrms gEnetAppRmDefCfg_3G =
    .coreDmaResInfo =
        [0] =
            .coreId        = CSL_CORE_ID_R5FSS0_0,
            .numTxCh       = ENET_SYSCFG_TX_CHANNELS_NUM,    /* numTxCh */
            .numRxFlows    = (ENET_SYSCFG_RX_FLOWS_NUM + 1),    /* numRxFlows. Need one additional flow for reserved flow  */
            .numMacAddress = 4U,    /* numMacAddress */
    .numCores = 1U,
const EnetRm_ResPrms *EnetAppRm_getResPartInfo(Enet_Type enetType)
    const EnetRm_ResPrms *rmInitPrms = NULL;
    switch (enetType)
        case ENET_CPSW_3G:
            rmInitPrms = &gEnetAppRmDefCfg_3G;
            break;
        default:
            rmInitPrms = NULL;
    return(rmInitPrms);
/* Cores IOCTL Privileges */
static const EnetRm_IoctlPermissionTable gEnetAppIoctlPermission_3G =
    .defaultPermittedCoreMask = (ENET_BIT(CSL_CORE_ID_A53SS0_0) |
                                 ENET_BIT(CSL_CORE_ID_R5FSS0_0) |
                                 ENET_BIT(CSL_CORE_ID_R5FSS0_1) |
                                 ENET_BIT(CSL_CORE_ID_R5FSS1_0) |
                                 ENET_BIT(CSL_CORE_ID_R5FSS1_1)),
    .numEntries = 0,
const EnetRm_IoctlPermissionTable *EnetAppRm_getIoctlPermissionInfo(Enet_Type enetType)
    const EnetRm_IoctlPermissionTable *ioctlPerm = NULL;
    switch (enetType)
        case ENET_CPSW_3G:
            ioctlPerm = &gEnetAppIoctlPermission_3G;
            break;
        default:
            ioctlPerm = NULL;
            break;
    return(ioctlPerm);
/*                             Include Files                                  */
#include <stdint.h>
#include <stdarg.h>
#include <hw_include/cslr_icss.h>
#include <enet.h>
#include <include/per/icssg.h>
#include <priv/per/icssg_priv.h>
#include <soc/k3/icssg_soc.h>
#pragma clang section rodata=".icssfw"
#include <networking/enet/core/src/per/firmware/icssg/dualmac/RX_PRU_SLICE0_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/dualmac/RX_PRU_SLICE1_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/dualmac/RTU0_SLICE0_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/dualmac/RTU0_SLICE1_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/dualmac/TX_PRU_SLICE0_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/dualmac/TX_PRU_SLICE1_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/switch/RX_PRU_SLICE0_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/switch/RX_PRU_SLICE1_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/switch/RTU0_SLICE0_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/switch/RTU0_SLICE1_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/switch/TX_PRU_SLICE0_bin.h>
#include <networking/enet/core/src/per/firmware/icssg/switch/TX_PRU_SLICE1_bin.h>
#pragma clang section rodata=""
/*DUAL MAC MODE*/
 * ICSSG Port buffer pool memory:
 *  - Dual-MAC: Not needed
#define ICSSG_PORT_POOL_TOTAL_SIZE              (0U)
 * ICSSG Host buffer pool memory:
 *  - Dual-MAC:
 *            Gigabit Support: No of pools based on QOS level and 8kB each
 *            100M Support:    No of pools based on QOS level and 4kB each
#define ICSSG_DUALMAC_HOST_POOL_SIZE             ((ENET_SYSCFG_ENABLE_GIGABIT) ? ENET_UTILS_ALIGN((8 * 1024U),ICSSG_CACHELINE_ALIGNMENT) : ENET_UTILS_ALIGN((4 * 1024U),ICSSG_CACHELINE_ALIGNMENT))
#define ICSSG_DUALMAC_HOST_POOL_TOTAL_SIZE       (ICSSG_DUALMAC_HOST_BUFFER_POOL_NUM_CFG * ICSSG_DUALMAC_HOST_POOL_SIZE)
#define ICSSG_HOST_POOL_TOTAL_SIZE               (ICSSG_DUALMAC_HOST_POOL_TOTAL_SIZE)
 * ICSSG Host egress queue memory:
 *  - Dual-MAC:
 *            Gigabit Support: 2 queues of (6kB + 2kB) each
 *            100M Support:    2 queues of (3kB + 2kB) each
#define ICSSG_DUALMAC_HOST_QUEUE_SIZE            ((ENET_SYSCFG_ENABLE_GIGABIT) ? ENET_UTILS_ALIGN((8 * 1024U),ICSSG_CACHELINE_ALIGNMENT) : ENET_UTILS_ALIGN((5 * 1024U),ICSSG_CACHELINE_ALIGNMENT))
#define ICSSG_DUALMAC_HOST_QUEUE_TOTAL_SIZE      ((ICSSG_DUALMAC_HOST_EGRESS_QUEUE_NUM * ICSSG_DUALMAC_HOST_QUEUE_SIZE) + ENET_UTILS_ALIGN(ICSSG_HOST_EGRESS_BUFFER_PADDING,ICSSG_CACHELINE_ALIGNMENT))
#define ICSSG_HOST_QUEUE_TOTAL_SIZE              (ICSSG_DUALMAC_HOST_QUEUE_TOTAL_SIZE)
#define ICSSG_PRE_QUEUE_TOTAL_SIZE               ((ENET_SYSCFG_PREMPTION_ENABLE) ? (ICSSG_DUALMAC_HOST_QUEUE_TOTAL_SIZE) : 0)
/* --------------------------------- ICSS-G --------------------------------- */
/* ICSSG1 memories */
static uint8_t gEnetSoc_icssg1HostPoolMem_0[ICSSG_HOST_POOL_TOTAL_SIZE]
        __attribute__ ((aligned (ICSSG_CACHELINE_ALIGNMENT)));
static uint8_t gEnetSoc_icssg1HostQueueMem_0[ICSSG_HOST_QUEUE_TOTAL_SIZE]
static uint8_t gEnetSoc_icssg1ScratchMem_0[ICSSG_SCRATCH_BUFFER_SIZE]
static Icssg_FwPoolMem gEnetSoc_Icssg1_0_FwPoolMem[] =
    [0] =
            .portBufferPoolMem   = NULL,
            .portBufferPoolSize  = 0U,
            .portBufferPoolNum   = 0U,
            .hostBufferPoolMem   = gEnetSoc_icssg1HostPoolMem_0,
            .hostBufferPoolSize  = ICSSG_DUALMAC_HOST_POOL_SIZE,
            .hostBufferPoolNum   = ICSSG_DUALMAC_HOST_BUFFER_POOL_NUM_CFG,
            .hostEgressQueueMem  = gEnetSoc_icssg1HostQueueMem_0,
            .hostEgressQueueSize = ICSSG_DUALMAC_HOST_QUEUE_SIZE,
            .hostEgressPreQueueMem  = NULL,
            .hostEgressPreQueueSize = ICSSG_PRE_QUEUE_TOTAL_SIZE,
            .hostEgressQueueNum  = ICSSG_DUALMAC_HOST_EGRESS_QUEUE_NUM,
            .scratchBufferMem    = gEnetSoc_icssg1ScratchMem_0,
            .scratchBufferSize   = ICSSG_SCRATCH_BUFFER_SIZE,
/* PRU_ICSSG 0 */
Icssg_Pruss gEnetSoc_PruIcssg0 =
    .instance    = ICSSG_PRUSS_ID_0,
    .initialized = false,
    .iep0InUse   = false,
/* PRU_ICSSG 1 */
Icssg_Pruss gEnetSoc_PruIcssg1 =
    .instance    = ICSSG_PRUSS_ID_1,
    .iep0InUse   = false,
/* ICSSG1 Dual-MAC Port 1 (ENET_ICSSG_DUALMAC, 2) */
static Icssg_Obj gEnetSoc_icssg1DMacp1 =
    .enetPer =
        .name         = "icssg1-1",
        .enetType     = ENET_ICSSG_DUALMAC,
        .instId       = 2U,
        .physAddr     = CSL_PRU_ICSSG1_DRAM0_SLV_RAM_BASE,
        .physAddr2    = 0U,
        .initCfg      = &Icssg_initCfg,
        .open         = &Icssg_open,
        .close        = &Icssg_close,
        .rejoin       = &Icssg_rejoin,
        .ioctl        = &Icssg_ioctl,
        .poll         = &Icssg_poll,
        .convertTs    = &Icssg_convertTs,
        .periodicTick = &Icssg_periodicTick,
        .registerEventCb   = &Icssg_registerEventCb,
        .unregisterEventCb = &Icssg_unregisterEventCb,
    /* Shared between ICSSG1 Port 1 and Port 2 objects */
    .pruss = &gEnetSoc_PruIcssg1,
    /* Dual-MAC firmware for slice 0 */
    .fw =
            .pru       = RX_PRU_SLICE0_b00_DMac,
            .pruSize   = sizeof(RX_PRU_SLICE0_b00_DMac),
            .rtu       = RTU0_SLICE0_b00_DMac,
            .rtuSize   = sizeof(RTU0_SLICE0_b00_DMac),
            .txpru     = TX_PRU_SLICE0_b00_DMac,
            .txpruSize = sizeof(TX_PRU_SLICE0_b00_DMac)
    /* TimeSync module object */
    .timeSyncObj =
        .enetMod =
            .name       = "icssg1-1.timesync",
            .physAddr   = CSL_PRU_ICSSG1_DRAM0_SLV_RAM_BASE + CSL_ICSS_G_PR1_IEP0_SLV_REGS_BASE,
            .physAddr2  = CSL_PRU_ICSSG1_DRAM0_SLV_RAM_BASE + CSL_ICSS_G_RAM_SLV_RAM_REGS_BASE,
            .open       = &IcssgTimeSync_open,
            .rejoin     = &IcssgTimeSync_rejoin,
            .ioctl      = &IcssgTimeSync_ioctl,
            .close      = &IcssgTimeSync_close,
    .mdioObj =
        .enetMod =
            .name       = "icssg1-1.mdio",
            .physAddr   = CSL_PRU_ICSSG1_PR1_MDIO_V1P7_MDIO_BASE,
            .features   = MDIO_FEATURE_CLAUSE45,
            .open       = &Mdio_open,
    /* Stats module object */
    .statsObj =
        .enetMod =
            .name       = "icssg1-1.stats",
            .physAddr2  = 0,
            .open       = &IcssgStats_open,
            .rejoin     = &IcssgStats_rejoin,
            .ioctl      = &IcssgStats_ioctl,
            .close      = &IcssgStats_close,
    /* Tas module object */
    .tasObj =
            .enetMod =
                .name       = "icssg1-1.tas",
                .open       = &IcssgTas_open,
                .rejoin     = &IcssgTas_rejoin,
                .ioctl      = &IcssgTas_ioctl,
                .close      = &IcssgTas_close,
    .rmObj =
        .enetMod =
            .name       = "icssg1-1.rm",
            .physAddr   = 0U,
        .enetPer = NULL,
    /* ICSSG0 Dual-MAC Port 1 Enet driver/peripheral */
        .enetPer = NULL,
        .enetPer = NULL,
        /* ICSSG1 Dual-MAC Port 1 Enet driver/peripheral */
        .enetPer = &gEnetSoc_icssg1DMacp1.enetPer,
        .enetPer = NULL,
        .enetPer = NULL,
        .enetPer = NULL,
EnetUdma_DrvObj gEnetSoc_dmaObj[1U];
/* ICSSG1 Dual-MAC DMA SoC data: 4 TX channels and 9 RX flows per slice */
const IcssgSoc_Cfg gEnetSoc_icssg1DMacSocCfg[ICSSG_MAC_PORT_MAX] =
        .dmscDevId        = TISCI_DEV_PRU_ICSSG1,
        .txChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G1_PSILD_THREAD_OFFSET,
        .rxChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G1_PSILS_THREAD_OFFSET,
        .txChCount        = ICSSG_DUALMAC_TX_CH_NUM,
        .rxFlowCount      = ICSSG_DUALMAC_RX_FLOW_NUM,
        .txChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G1_PSILD_THREAD_OFFSET +
        .rxChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G1_PSILS_THREAD_OFFSET +
                            1U,
/* ICSSG1 Switch DMA SoC data: 4 TX channels and 9 RX flows */
const IcssgSoc_Cfg gEnetSoc_icssg1SwtSocCfg =
    .txChCount        = ICSSG_SWITCH_TX_CH_NUM,
    .rxFlowCount      = ICSSG_SWITCH_RX_FLOW_NUM,
/* ICSSG0 Dual-MAC DMA SoC data: 4 TX channels and 9 RX flows per slice */
const IcssgSoc_Cfg gEnetSoc_icssg0DMacSocCfg[ICSSG_MAC_PORT_MAX] =
        .dmscDevId        = TISCI_DEV_PRU_ICSSG0,
        .txChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G0_PSILD_THREAD_OFFSET,
        .rxChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G0_PSILS_THREAD_OFFSET,
        .txChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G0_PSILD_THREAD_OFFSET +
        .rxChPeerThreadId = CSL_PSILCFG_DMSS_ICSS_G0_PSILS_THREAD_OFFSET +
                            1U,
/* ICSSG0 Switch DMA SoC data: 4 TX channels and 9 RX flows */
const IcssgSoc_Cfg gEnetSoc_icssg0SwtSocCfg =
const  Icssg_FwPoolMem *Icssq_FwPoolMemInfo[2][4] =
    [0] = {
              [0] = NULL,
              [1] = NULL,
              [2] = &gEnetSoc_Icssg1_0_FwPoolMem[0],
              [3] = NULL,
    [1] = {
              [0] = NULL,
              [1] = NULL,
              [2] = NULL,
              [3] = NULL,
/* ------------------------------- DMA objects ------------------------------ */
extern Icssg_Pruss gEnetSoc_PruIcssg0;
extern Icssg_Pruss gEnetSoc_PruIcssg1;
extern EnetUdma_DrvObjMemInfo gEnetSoc_dmaObjMemInfo;
    memset(gEnetSoc_dmaObjMemInfo.drvObjMem, 0,
    gEnetSoc_dmaObjMemInfo.numObjs * sizeof(*(gEnetSoc_dmaObjMemInfo.drvObjMem)));
    gEnetSoc_PruIcssg0.lock = EnetOsal_createMutex();
    EnetSoc_assert((gEnetSoc_PruIcssg0.lock != NULL),
                 "Failed to create PRUICSSG0's mutex\n");
    gEnetSoc_PruIcssg1.lock = EnetOsal_createMutex();
    EnetSoc_assert((gEnetSoc_PruIcssg1.lock != NULL),
                  "Failed to create PRUICSSG1's mutex\n");
    return ENET_SOK;
    gEnetSoc_PruIcssg1.initialized = false;
    EnetOsal_deleteMutex(gEnetSoc_PruIcssg1.lock);
    gEnetSoc_PruIcssg1.lock = NULL;
    gEnetSoc_PruIcssg0.initialized = false;
    EnetOsal_deleteMutex(gEnetSoc_PruIcssg0.lock);
    gEnetSoc_PruIcssg0.lock = NULL;
                                    uint32_t instId)
    switch (enetType)
        case ENET_ICSSG_DUALMAC:
            switch (instId)
                case 2:
                    break;
                default:
                    break;
            break;
        default:
            break;
    return hDma;
    return hEnet;
                                  uint32_t instId)
    switch (enetType)
        case ENET_CPSW_3G:
            if (instId == 0U)
            break;
            switch (instId)
                case 0:
                    hEnet = &gEnetSoc_perObj[1U];
                    break;
                case 1:
                    hEnet = &gEnetSoc_perObj[2U];
                    break;
                case 2:
                    hEnet = &gEnetSoc_perObj[3U];
                    break;
                case 3:
                    hEnet = &gEnetSoc_perObj[4U];
                    break;
                default:
                    break;
            break;
        case ENET_ICSSG_SWITCH:
            switch (instId)
                case 0:
                    hEnet = &gEnetSoc_perObj[5U];
                    break;
                case 1:
                    hEnet = &gEnetSoc_perObj[6U];
                    break;
                case 2:
                    hEnet = &gEnetSoc_perObj[7U];
                    break;
                default:
                    break;
            break;
        default:
            break;
    return hEnet;
    if ((enetType == ENET_ICSSG_DUALMAC)|| (enetType == ENET_ICSSG_SWITCH))
                               uint32_t instId)
    if (enetType == ENET_ICSSG_DUALMAC)
        numPorts = 1U;
    else if (enetType == ENET_ICSSG_SWITCH)
        numPorts = 2U;
    else
    return numPorts;
                               uint32_t instId)
    if (((enetType == ENET_ICSSG_DUALMAC) && (instId < 3U)) ||
             ((enetType == ENET_ICSSG_SWITCH) && (instId < 3U)))
        supported = true;
    return supported;
    return coreId;
                            uint32_t instId,
                            uint32_t clkId)
    uint32_t freq = 0U;
            //TODO: Freq is hard coded here.
            freq = 320000000LLU;
    else
    return freq;
                                    uint32_t instId,
                                    uint32_t intrId)
                                  uint32_t *num)
    uint32_t val;
    if (*num >= 1U)
        *num = 1U;
#else
    *num = 1U;
#endif
    return ENET_SOK;
                                uint32_t instId,
    switch (enetType)
            break;
        default:
            break;
    return linkCaps;
                              uint32_t instId,
                                  uint32_t instId)
                                 uint32_t instId,
                                 uint32_t *qsgmiiId)
                                uint32_t instId)
        switch (instId)
            case 0:
                rxFlowCount = gEnetSoc_icssg0DMacSocCfg[0].rxFlowCount;
                break;
            case 1:
                rxFlowCount = gEnetSoc_icssg0DMacSocCfg[1].rxFlowCount;
                break;
            case 2:
                rxFlowCount = gEnetSoc_icssg1DMacSocCfg[0].rxFlowCount;
                break;
            case 3:
                rxFlowCount = gEnetSoc_icssg1DMacSocCfg[1].rxFlowCount;
                break;
            default:
                break;
        switch (instId)
            case 0:
                rxFlowCount = gEnetSoc_icssg0SwtSocCfg.rxFlowCount;
                break;
            case 1:
                rxFlowCount = gEnetSoc_icssg1SwtSocCfg.rxFlowCount;
                break;
            default:
                break;
    return rxFlowCount;
                               uint32_t instId,
                               uint32_t chNum)
        switch (instId)
            case 0:
                peerChNum = gEnetSoc_icssg0DMacSocCfg[0].txChPeerThreadId;
                break;
            case 1:
                peerChNum = gEnetSoc_icssg0DMacSocCfg[1].txChPeerThreadId;
                break;
            case 2:
                peerChNum = gEnetSoc_icssg1DMacSocCfg[0].txChPeerThreadId;
                break;
            case 3:
                peerChNum = gEnetSoc_icssg1DMacSocCfg[1].txChPeerThreadId;
                break;
            default:
                break;
        switch (instId)
            case 0:
                peerChNum = gEnetSoc_icssg0SwtSocCfg.txChPeerThreadId;
                break;
            case 1:
                peerChNum = gEnetSoc_icssg1SwtSocCfg.txChPeerThreadId;
                break;
            default:
                break;
    return peerChNum;
                               uint32_t instId,
                               uint32_t chIdx)
        switch (instId)
            case 0:
                peerChNum = gEnetSoc_icssg0DMacSocCfg[0].rxChPeerThreadId;
                break;
            case 1:
                peerChNum = gEnetSoc_icssg0DMacSocCfg[1].rxChPeerThreadId;
                break;
            case 2:
                peerChNum = gEnetSoc_icssg1DMacSocCfg[0].rxChPeerThreadId;
                break;
            case 3:
                peerChNum = gEnetSoc_icssg1DMacSocCfg[1].rxChPeerThreadId;
                break;
            default:
                break;
        EnetSoc_assert(((chIdx == 0U) || (chIdx == 1U)), "Invalid channel index %u\n", chIdx);
        switch (instId)
            case 0:
                peerChNum = gEnetSoc_icssg0SwtSocCfg.rxChPeerThreadId + chIdx;
                break;
            case 1:
                peerChNum = gEnetSoc_icssg1SwtSocCfg.rxChPeerThreadId + chIdx;
                break;
            default:
                break;
    return peerChNum;
                              uint32_t instId)
        switch (instId)
            case 0:
                txChCount = gEnetSoc_icssg0DMacSocCfg[0].txChCount;
                break;
            case 1:
                txChCount = gEnetSoc_icssg0DMacSocCfg[1].txChCount;
                break;
            case 2:
                txChCount = gEnetSoc_icssg1DMacSocCfg[0].txChCount;
                break;
            case 3:
                txChCount = gEnetSoc_icssg1DMacSocCfg[1].txChCount;
                break;
            default:
                break;
        switch (instId)
            case 0:
                txChCount = gEnetSoc_icssg0SwtSocCfg.txChCount;
                break;
            case 1:
                txChCount = gEnetSoc_icssg1SwtSocCfg.txChCount;
                break;
            default:
                break;
    return txChCount;
bool EnetSoc_isCoreAllowed(Enet_Type enetType,
                           uint32_t instId,
                           uint32_t coreId)
    return true;
 *  \brief ICSSG default configuration
 *         2. Sum of numRxFlows allocated to each core should not exceed 10 (not 64),
static EnetRm_ResPrms gEnetAppRmDefCfg_iccsgDMac =
    .coreDmaResInfo =
        [0] =
            .numRxFlows    = ENET_SYSCFG_RX_FLOWS_NUM,    /* numRxFlows */
            .numMacAddress = 1U,
    .numCores = 1U,
static EnetRm_ResPrms gEnetAppRmDefCfg_iccsgSwt =
    .coreDmaResInfo =
        [0] =
    .numCores = 1U,
    switch (enetType)
            rmInitPrms = &gEnetAppRmDefCfg_iccsgDMac;
            break;
        default:
            rmInitPrms = &gEnetAppRmDefCfg_iccsgSwt;
            break;
    return(rmInitPrms);
static const EnetRm_IoctlPermissionTable gEnetAppIoctlPermission_iccsg =
                                 ENET_BIT(CSL_CORE_ID_R5FSS0_1)),
    .numEntries = 0,
    switch (enetType)
            ioctlPerm = &gEnetAppIoctlPermission_iccsg;
            break;
        default:
            ioctlPerm = NULL;
            break;
    return(ioctlPerm);
