器件型号:TDA4VM 主题中讨论的其他器件:DRA821、 TDA4VH、 DRA829
我需要在 TDA4/DRA8器件上查看 CPSW 的以太网统计信息以进行调试。 有没有办法让我读他们?
大家好!
CPSW IP 具有一个统计模块、其中记录了 IP 的所有端口的多个统计信息。 有关各个统计数据的描述和寄存器地址、请参阅 SoC 的 TRM (第12.2.4.6.19节、标题- CPSW 网络统计信息)。 为了轻松阅读这些统计信息、我们准备了以下工具。
MCU_Cortex_R5_0: GEL Output: STATS MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: PORT0 STATS MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: STAT_0_RXGOODFRAMES = 0x0002F960 MCU_Cortex_R5_0: GEL Output: STAT_0_RXBROADCASTFRAMES = 0x0000193B MCU_Cortex_R5_0: GEL Output: STAT_0_RXMULTICASTFRAMES = 0x0000012C MCU_Cortex_R5_0: GEL Output: STAT_0_RXOCTETS = 0x01049D67 MCU_Cortex_R5_0: GEL Output: STAT_0_TXGOODFRAMES = 0x00006AD5 MCU_Cortex_R5_0: GEL Output: STAT_0_TXBROADCASTFRAMES = 0x0000193C MCU_Cortex_R5_0: GEL Output: STAT_0_TXMULTICASTFRAMES = 0x000025A7 MCU_Cortex_R5_0: GEL Output: STAT_0_TXOCTETS = 0x005AAD86 MCU_Cortex_R5_0: GEL Output: STAT_0_OCTETFRAMES64 = 0x000057BB MCU_Cortex_R5_0: GEL Output: STAT_0_OCTETFRAMES65T127 = 0x0002C0DE MCU_Cortex_R5_0: GEL Output: STAT_0_OCTETFRAMES128T255 = 0x00000113 MCU_Cortex_R5_0: GEL Output: STAT_0_OCTETFRAMES256T511 = 0x00004A86 MCU_Cortex_R5_0: GEL Output: STAT_0_OCTETFRAMES512T1023 = 0x00000003 MCU_Cortex_R5_0: GEL Output: STAT_0_NETOCTETS = 0x015F4AED MCU_Cortex_R5_0: GEL Output: STAT_0_TX_PRI_REG [0]= 0x00006AD5 MCU_Cortex_R5_0: GEL Output: STAT_0_TX_PRI_BCNT_REG [0]= 0x005AAD86 MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: PORT1 STATS MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: PORT2 STATS MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: STAT_2_RXGOODFRAMES = 0x0000E330 MCU_Cortex_R5_0: GEL Output: STAT_2_RXBROADCASTFRAMES = 0x00000002 MCU_Cortex_R5_0: GEL Output: STAT_2_RXMULTICASTFRAMES = 0x0000B73C MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_DROP = 0x0000919E MCU_Cortex_R5_0: GEL Output: STAT_2_RXOCTETS = 0x00C4315A MCU_Cortex_R5_0: GEL Output: STAT_2_TXGOODFRAMES = 0x0002DF9A MCU_Cortex_R5_0: GEL Output: STAT_2_TXBROADCASTFRAMES = 0x00000002 MCU_Cortex_R5_0: GEL Output: STAT_2_TXMULTICASTFRAMES = 0x0000009F MCU_Cortex_R5_0: GEL Output: STAT_2_TXOCTETS = 0x00E33C1A MCU_Cortex_R5_0: GEL Output: STAT_2_OCTETFRAMES64 = 0x000057BB MCU_Cortex_R5_0: GEL Output: STAT_2_OCTETFRAMES65T127 = 0x0002CD89 MCU_Cortex_R5_0: GEL Output: STAT_2_OCTETFRAMES128T255 = 0x00006D84 MCU_Cortex_R5_0: GEL Output: STAT_2_OCTETFRAMES256T511 = 0x00002FFC MCU_Cortex_R5_0: GEL Output: STAT_2_OCTETFRAMES512T1023 = 0x00000006 MCU_Cortex_R5_0: GEL Output: STAT_2_NETOCTETS = 0x01A76D74 MCU_Cortex_R5_0: GEL Output: STAT_2_PORTMASK_DROP = 0x0000919E MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_VID_INGRESS_DROP = 0x00005BD0 MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_UNKN_UNI = 0x00002BF2 MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_UNKN_UNI_BCNT = 0x000B13A4 MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_UNKN_MLT = 0x0000B73C MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_UNKN_MLT_BCNT = 0x00B91D36 MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_UNKN_BRD = 0x00000002 MCU_Cortex_R5_0: GEL Output: STAT_2_ALE_UNKN_BRD_BCNT = 0x00000080 MCU_Cortex_R5_0: GEL Output: STAT_2_TX_PRI_REG [0]= 0x0002DF9A MCU_Cortex_R5_0: GEL Output: STAT_2_TX_PRI_BCNT_REG [0]= 0x00E33C1A MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: PORT3 STATS MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: PORT4 STATS MCU_Cortex_R5_0: GEL Output: -------------------------------- MCU_Cortex_R5_0: GEL Output: STAT_4_RXGOODFRAMES = 0x00003389 MCU_Cortex_R5_0: GEL Output: STAT_4_RXBROADCASTFRAMES = 0x00003271 MCU_Cortex_R5_0: GEL Output: STAT_4_RXMULTICASTFRAMES = 0x00000118 MCU_Cortex_R5_0: GEL Output: STAT_4_ALE_DROP = 0x00001A46 MCU_Cortex_R5_0: GEL Output: STAT_4_RXOCTETS = 0x0043BF9D MCU_Cortex_R5_0: GEL Output: STAT_4_TXGOODFRAMES = 0x000019C6 MCU_Cortex_R5_0: GEL Output: STAT_4_TXBROADCASTFRAMES = 0x00001939 MCU_Cortex_R5_0: GEL Output: STAT_4_TXMULTICASTFRAMES = 0x0000008D MCU_Cortex_R5_0: GEL Output: STAT_4_TXOCTETS = 0x0021614D MCU_Cortex_R5_0: GEL Output: STAT_4_OCTETFRAMES65T127 = 0x0000018F MCU_Cortex_R5_0: GEL Output: STAT_4_OCTETFRAMES128T255 = 0x00000016 MCU_Cortex_R5_0: GEL Output: STAT_4_OCTETFRAMES256T511 = 0x00004BAA MCU_Cortex_R5_0: GEL Output: STAT_4_NETOCTETS = 0x006520EA MCU_Cortex_R5_0: GEL Output: STAT_4_PORTMASK_DROP = 0x00001A46 MCU_Cortex_R5_0: GEL Output: STAT_4_ALE_VID_INGRESS_DROP = 0x000019BF MCU_Cortex_R5_0: GEL Output: STAT_4_ALE_UNKN_MLT = 0x00000118 MCU_Cortex_R5_0: GEL Output: STAT_4_ALE_UNKN_MLT_BCNT = 0x00005CA4 MCU_Cortex_R5_0: GEL Output: STAT_4_ALE_UNKN_BRD = 0x00003271 MCU_Cortex_R5_0: GEL Output: STAT_4_ALE_UNKN_BRD_BCNT = 0x004362F9 MCU_Cortex_R5_0: GEL Output: STAT_4_TX_PRI_REG [0]= 0x000019C6 MCU_Cortex_R5_0: GEL Output: STAT_4_TX_PRI_BCNT_REG [0]= 0x0021614D
ethtool -t $IF_NAME
Port 0 Statistics ----------------------------------------- rxGoodFrames = 56 rxBcastFrames = 16 rxMcastFrames = 40 aleDrop = 42 rxOctets = 9712 txGoodFrames = 573 txBcastFrames = 220 txMcastFrames = 353 txOctets = 65372 octetsFrames64 = 210 octetsFrames65to127 = 299 octetsFrames128to255 = 41 octetsFrames256to511 = 71 octetsFrames512to1023 = 8 netOctets = 75084 portMaskDrop = 42 alePolicyMatch = 6 txPri[0] = 573 txPriBcnt[0] = 65372 External Port 0 Statistics ----------------------------------------- External Port 1 Statistics ----------------------------------------- External Port 2 Statistics ----------------------------------------- External Port 3 Statistics ----------------------------------------- rxGoodFrames = 855 rxBcastFrames = 365 rxMcastFrames = 489 aleDrop = 290 rxOctets = 107985 octetsFrames64 = 213 octetsFrames65to127 = 474 octetsFrames128to255 = 26 octetsFrames256to511 = 133 octetsFrames512to1023 = 9 netOctets = 107985 portMaskDrop = 290 aleVidIngressDrop = 289 aleUnknownUcast = 1 aleUnknownUcastBcnt = 96 aleUnknownMcast = 489 aleUnknownMcastBcnt = 57352 aleUnknownBcast = 365 aleUnknownBcastBcnt = 50537 alePolicyMatch = 95 External Port 4 Statistics ----------------------------------------- rxGoodFrames = 29 rxBcastFrames = 7 rxMcastFrames = 22 aleDrop = 15 rxOctets = 5543 txGoodFrames = 14 txBcastFrames = 10 txMcastFrames = 4 txOctets = 4008 octetsFrames65to127 = 13 octetsFrames128to255 = 13 octetsFrames256to511 = 17 netOctets = 9551 portMaskDrop = 15 aleUnknownMcast = 9 aleUnknownMcastBcnt = 1274 aleUnknownBcast = 3 aleUnknownBcastBcnt = 1038 alePolicyMatch = 7 txPri[0] = 10 txPri[2] = 4 txPriBcnt[0] = 2592 txPriBcnt[2] = 1416 External Port 5 Statistics ----------------------------------------- External Port 6 Statistics ----------------------------------------- External Port 7 Statistics -----------------------------------------
在某些情况下、可能电路板上没有 ethfw UART、在这种情况下需要对 ethfw 应用补丁来定期将统计数据转储到 IPC 缓冲区、可以从 Linux 查看。 该补丁可在以下附件中找到、并在 SDK 8.6上进行了测试。
附件: e2e.ti.com/.../6685.CPSW_5F00_Periodic_5F00_stat_5F00_dump.zip
git init -创建一个空的 git 存储库 git add . -添加所有文件到 git 存储库 git commit -m "Initial Commit" -做第一个提交 git am [Path_to_0001-Adds-support-for-periodic-CPSW-stat-collection.patch]""以应用补丁 make ethfw_all BUILD_SOC_LIST=<SOC_NAME>
CPSW Ethernet Firmware
Warning: Using 6 MAC address(es) from static pool
ETHFW: Shared multicasts (software fanout):
01:00:5e:00:00:01
01:00:5e:00:00:fb
01:00:5e:00:00:fc
33:33:00:00:00:01
33:33:ff:1d:92:c2
01:80:c2:00:00:00
01:80:c2:00:00:03
ETHFW: Reserved multicasts:
01:80:c2:00:00:0e
01:1b:19:00:00:00
EnetMcm: CPSW_5G on MAIN NAVSS
Mdio_open: MDIO manual mode enabled
PHY 16 is alive
PHY 17 is alive
PHY 18 is alive
PHY 19 is alive
EnetPhy_bindDriver: PHY 16: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
EnetPhy_bindDriver: PHY 17: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
EnetPhy_bindDriver: PHY 18: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
EnetPhy_bindDriver: PHY 19: OUI:0001c1 Model:27 Ver:00 <-> 'vsc8514' : OK
ETHFW Version : 0.02.00
ETHFW Build Date: Apr 12, 2023
ETHFW Build Time: 10:31:18
ETHFW Commit SHA: 0909933c
NETWORK TASK
Starting lwIP, local interface IP is dhcp-enabled
Host MAC address: 70:ff:76:1d:92:c3
[LWIPIF_LWIP] Enet LLD netif initialized successfully
[LWIPIF_LWIP_IC] Interface started successfully
[LWIPIF_LWIP_IC] NETIF INIT SUCCESS
Added interface 'br4', IP is 0.0.0.0
CpswProxyServer: Virtual port configuration:
mpu_1_0 <-> Switch port 0: mpu_1_0_ethswitch-device-0
mcu_2_1 <-> Switch port 1: mcu_2_1_ethswitch-device-1
mpu_1_0 <-> MAC port 1: mpu_1_0_ethmac-device-1
mcu_2_1 <-> MAC port 4: mcu_2_1_ethmac-device-4
CpswProxyServer: initialization completed (core: mcu2_0)
CpswMacPort_checkSgmiiStatus: MAC 2: SGMII link parter config port: link up: 1-Gbps Full-Duplex
Cpsw_handleLinkUp: Port 2: Link up: 1-Gbps Full-Duplex
====== Iteration 1 =====
Port 0 Statistics
txGoodFrames = 2
txBcastFrames = 2
txOctets = 674
octetsFrames256to511 = 2
netOctets = 674
txPri[0] = 2
txPriBcnt[0] = 674
rxGoodFrames = 9
rxBcastFrames = 2
rxMcastFrames = 7
aleDrop = 7
rxOctets = 1369
octetsFrames65to127 = 6
netOctets = 1369
portMaskDrop = 7
aleUnknownBcast = 1
aleUnknownBcastBcnt = 337
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
Function:CpswProxyServer_attachExtHandlerCb,HostId:0,CpswType:5
Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c2, FlowIdx:85, FlowIdxOf
fset:1
Function:CpswProxyServer_setPromiscModeHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6,mode:disable
Function:CpswProxyServer_registerMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:70:ff:76:1d:92:c1, FlowIdx:84, FlowIdxOf
fset:0
Cpsw_ioctlInternal: CPSW: Registered MAC address. ALE entry:7, Policer Entry:2
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:1, vlanId:0, FlowIdx:84, Fl
owIdOffset:0
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:1:0:5e:0:0:1, vlanId:0, FlowIdx:84, Flo
wIdOffset:0
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:33:33:ff:1d:92:c1, vlanId:0, FlowIdx:84
, FlowIdOffset:0
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:0, vlanId:0, FlowIdx:84, Fl
owIdOffset:0
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:3, vlanId:0, FlowIdx:84, Fl
owIdOffset:0
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:1:80:c2:0:0:e, vlanId:0, FlowIdx:84, Fl
owIdOffset:0
CpswProxyServer_isRsvdMcast: Reserved mcast cannot be added to filter
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:33:33:0:0:0:fb, vlanId:0, FlowIdx:84, F
lowIdOffset:0
====== Iteration 2 =====
Port 0 Statistics
rxGoodFrames = 12
rxBcastFrames = 3
rxMcastFrames = 9
aleDrop = 9
rxOctets = 1886
txGoodFrames = 3
txBcastFrames = 3
txOctets = 1011
octetsFrames65to127 = 9
octetsFrames256to511 = 6
netOctets = 2897
portMaskDrop = 9
alePolicyMatch = 1
txPri[0] = 3
txPriBcnt[0] = 1011
rxGoodFrames = 11
rxBcastFrames = 3
rxMcastFrames = 8
aleDrop = 8
rxOctets = 1780
txGoodFrames = 3
txBcastFrames = 2
txMcastFrames = 1
txOctets = 781
octetsFrames65to127 = 8
octetsFrames256to511 = 5
netOctets = 2561
portMaskDrop = 8
aleUnknownBcast = 2
aleUnknownBcastBcnt = 674
txPri[0] = 2
txPri[2] = 1
txPriBcnt[0] = 427
txPriBcnt[2] = 354
Function:CpswProxyServer_filterAddMacHandlerCb,HostId:0,Handle:a2bbd168,CoreKey:38acb7e6, MacAddress:33:33:0:1:0:3, vlanId:0, FlowIdx:84, Fl
owIdOffset:0
====== Iteration 3 =====
Port 0 Statistics
rxGoodFrames = 43
rxBcastFrames = 8
rxMcastFrames = 34
aleDrop = 30
rxOctets = 6650
txGoodFrames = 6
txBcastFrames = 4
txMcastFrames = 1
txOctets = 1559
octetsFrames65to127 = 30
octetsFrames128to255 = 7
octetsFrames256to511 = 12
netOctets = 8209
portMaskDrop = 30
alePolicyMatch = 14
txPri[0] = 6
txPriBcnt[0] = 1559
rxGoodFrames = 14
rxBcastFrames = 4
rxMcastFrames = 9
aleDrop = 8
rxOctets = 2328
txGoodFrames = 13
txBcastFrames = 5
txMcastFrames = 7
txOctets = 2688
octetsFrames65to127 = 15
octetsFrames128to255 = 3
octetsFrames256to511 = 9
netOctets = 5016
portMaskDrop = 8
aleUnknownMcast = 1
aleUnknownMcastBcnt = 90
aleUnknownBcast = 2
alePolicyMatch = 2
txPri[0] = 11
txPri[2] = 2
txPriBcnt[0] = 1980
txPriBcnt[2] = 708
====== Iteration 4 =====
Port 0 Statistics
rxGoodFrames = 47
rxBcastFrames = 10
rxMcastFrames = 35
aleDrop = 32
rxOctets = 7488
txGoodFrames = 8
txBcastFrames = 5
txMcastFrames = 1
txOctets = 1978
octetsFrames65to127 = 33
octetsFrames256to511 = 15
netOctets = 9466
portMaskDrop = 32
alePolicyMatch = 14
txPri[0] = 8
txPriBcnt[0] = 1978
rxGoodFrames = 17
rxBcastFrames = 5
rxMcastFrames = 10
aleDrop = 9
rxOctets = 2821
txGoodFrames = 15
txBcastFrames = 6
txMcastFrames = 7
txOctets = 3115
octetsFrames65to127 = 18
octetsFrames256to511 = 11
netOctets = 5936
portMaskDrop = 9
aleUnknownUcast = 1
aleUnknownUcastBcnt = 82
aleUnknownMcast = 1
aleUnknownBcast = 3
aleUnknownBcastBcnt = 1011
alePolicyMatch = 3
txPri[0] = 13
txPri[2] = 2
txPriBcnt[0] = 2407
txPriBcnt[2] = 708
-----------------------------------------ethtool -S $IF_NAME
root@j7200-evm:~# ethtool -S eth2
NIC statistics:
p0_rx_good_frames: 345
p0_rx_broadcast_frames: 21
p0_rx_multicast_frames: 98
p0_rx_crc_errors: 0
p0_rx_oversized_frames: 0
p0_rx_undersized_frames: 0
p0_ale_drop: 0
p0_ale_overrun_drop: 0
p0_rx_octets: 39012
p0_tx_good_frames: 59
p0_tx_broadcast_frames: 27
p0_tx_multicast_frames: 17
p0_tx_octets: 13470
p0_tx_64B_frames: 23
p0_tx_65_to_127B_frames: 276
p0_tx_128_to_255B_frames: 51
p0_tx_256_to_511B_frames: 54
p0_tx_512_to_1023B_frames: 0
p0_tx_1024B_frames: 0
p0_net_octets: 52482
p0_rx_bottom_fifo_drop: 0
p0_rx_port_mask_drop: 0
p0_rx_top_fifo_drop: 0
p0_ale_rate_limit_drop: 0
p0_ale_vid_ingress_drop: 0
p0_ale_da_eq_sa_drop: 0
p0_ale_block_drop: 0
p0_ale_secure_drop: 0
p0_ale_auth_drop: 0
p0_ale_unknown_ucast: 0
p0_ale_unknown_ucast_bytes: 0
p0_ale_unknown_mcast: 0
p0_ale_unknown_mcast_bytes: 0
p0_ale_unknown_bcast: 0
p0_ale_unknown_bcast_bytes: 0
p0_ale_pol_match: 0
p0_ale_pol_match_red: 0
p0_ale_pol_match_yellow: 0
p0_ale_mcast_sa_drop: 0
p0_ale_dual_vlan_drop: 0
p0_ale_len_err_drop: 0
p0_ale_ip_next_hdr_drop: 0
p0_ale_ipv4_frag_drop: 0
p0_tx_mem_protect_err: 0
p0_tx_pri0: 59
p0_tx_pri1: 0
p0_tx_pri2: 0
p0_tx_pri3: 0
p0_tx_pri4: 0
p0_tx_pri5: 0
p0_tx_pri6: 0
p0_tx_pri7: 0
p0_tx_pri0_bcnt: 13470
p0_tx_pri1_bcnt: 0
p0_tx_pri2_bcnt: 0
p0_tx_pri3_bcnt: 0
p0_tx_pri4_bcnt: 0
p0_tx_pri5_bcnt: 0
p0_tx_pri6_bcnt: 0
p0_tx_pri7_bcnt: 0
p0_tx_pri0_drop: 0
p0_tx_pri1_drop: 0
p0_tx_pri2_drop: 0
p0_tx_pri3_drop: 0
p0_tx_pri4_drop: 0
p0_tx_pri5_drop: 0
p0_tx_pri6_drop: 0
p0_tx_pri7_drop: 0
p0_tx_pri0_drop_bcnt: 0
p0_tx_pri1_drop_bcnt: 0
p0_tx_pri2_drop_bcnt: 0
p0_tx_pri3_drop_bcnt: 0
p0_tx_pri4_drop_bcnt: 0
p0_tx_pri5_drop_bcnt: 0
p0_tx_pri6_drop_bcnt: 0
p0_tx_pri7_drop_bcnt: 0
rx_good_frames: 70
rx_multicast_frames: 55
rx_pause_frames: 0
rx_crc_errors: 0
rx_align_code_errors: 0
rx_jabber_frames: 0
rx_fragments: 0
ale_drop: 46
ale_overrun_drop: 0
rx_octets: 14584
tx_good_frames: 277
tx_multicast_frames: 51
tx_pause_frames: 0
tx_deferred_frames: 0
tx_collision_frames: 0
tx_single_coll_frames: 0
tx_mult_coll_frames: 0
tx_excessive_collisions: 0
tx_late_collisions: 0
rx_ipg_error: 0
tx_carrier_sense_errors: 0
tx_octets: 26518
tx_64B_frames: 23
tx_65_to_127B_frames: 241
tx_128_to_255B_frames: 66
tx_256_to_511B_frames: 17
tx_1024B_frames: 0
net_octets: 41102
rx_port_mask_drop: 46
rx_top_fifo_drop: 0
ale_vid_ingress_drop: 28
ale_block_drop: 0
ale_secure_drop: 0
ale_auth_drop: 0
ale_unknown_ucast: 13
ale_unknown_ucast_bytes: 1398
ale_unknown_mcast: 55
ale_unknown_mcast_bytes: 13058
ale_unknown_bcast: 2
ale_unknown_bcast_bytes: 128
ale_pol_match: 0
ale_len_err_drop: 0
iet_rx_assembly_err: 0
iet_rx_assembly_ok: 0
iet_rx_smd_err: 0
iet_rx_frag: 0
iet_tx_hold: 0
iet_tx_frag: 0
tx_pri0: 277
tx_pri1: 0
tx_pri2: 0
tx_pri3: 0
tx_pri4: 0
tx_pri5: 0
tx_pri6: 0
tx_pri7: 0
tx_pri0_bcnt: 26518
tx_pri1_bcnt: 0
tx_pri2_bcnt: 0
tx_pri3_bcnt: 0
tx_pri4_bcnt: 0
tx_pri5_bcnt: 0
tx_pri6_bcnt: 0
tx_pri7_bcnt: 0
tx_pri0_drop: 0
tx_pri1_drop: 0
tx_pri2_drop: 0
tx_pri3_drop: 0
tx_pri4_drop: 0
tx_pri5_drop: 0
tx_pri6_drop: 0
tx_pri7_drop: 0
tx_pri7_drop_bcnt: 0此致、
Tanmy.
