[参考译文] AM4376:定制 U-boot 和内核组合以及 BuildRoot 上的 rtcwake 故障
Guru**** 678420 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1229330/am4376-rtcwake-failure-on-top-of-custom-u-boot-and-kernel-combination-along-with-buildroot
器件型号:AM4376
您好 TI
即使 TI PSDK 官方发布适用于 rtcwake 函数。 客户报告在基于 Uboot 2020.01和 Kernel 5.4.188的定制平台上出现 rtcwake 故障。
以下是在目标电路板上捕获的故障日志。 此外、待机模式也具有相同的结果。 (例如-m standby)
$ rtcwake -s 10 -d /dev/rtc0 -m mem
(Kernel stop, unable to wake upas below)
root@INSCOBEE-MSU:/sys/power# rtcwake -s 10 -d /dev/rtc0 -m mem
wakeup from "mem" at Mon Aug  1 00:17:55 2022
[ 1087.224065] PM: suspend entry (deep)
[ 1087.229389] Filesystems sync: 0.001 seconds
[ 1087.238484] Freezing user space processes ... (elapsed 0.002 seconds) done.
[ 1087.248009] OOM killer disabled.
[ 1087.251375] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
[ 1087.273439] cpsw 4a100000.ethernet eth0: Link is Down
[ 1087.281272] cpsw 4a100000.ethernet eth1: Link is Down
[ 1087.295067] PM: suspend devices took 0.030 seconds
当它们启用内核电源驱动程序的调试模式时、也会显示以下错误消息。
完整的日志随附于"mem_suspend_resume_log_230410.txt")
[  231.588300] pm33xx pm33xx: PM: Kernel suspend failure
e2e.ti.com/.../mem_5F00_suspend_5F00_resume_5F00_log_5F00_230410.txt
以下是/sys/power/state 目录列表。
root@INSCOBEE-MSU:/sys/kernel/debug/pm_debug# cd /sys/
root@INSCOBEE-MSU:/sys# ls
block     class     devices   fs        module
bus       dev       firmware  kernel    power
root@INSCOBEE-MSU:/sys# cd power/
root@INSCOBEE-MSU:/sys/power# ls
mem_sleep          pm_freeze_timeout  pm_wakeup_irq      wake_lock
pm_async           pm_print_times     state              wake_unlock
pm_debug_messages  pm_test            suspend_stats      wakeup_count
root@INSCOBEE-MSU:/sys/power# cat state
freeze standby mem
这是 dmesg 编写的内核日志、
root@INSCOBEE-MSU:/# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.188 (am437x@4bfebc466fc7) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16554-1d4dea6d4f)) #0 PREEMPT Sat A2
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: KDCU MSU V1.0
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 48 MiB at 0xfcc00000
[    0.000000] On node 0 totalpages: 524287
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:63
[    0.000000]   HighMem zone: 327679 pages, LIFO batch:63
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM437x ES1.2 (neon)
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522559
[    0.000000] Kernel command line: consoleblank=0 no_console_suspend=1 console=ttyS0,115200n8 root=/dev/mmcblk0p2 noinitrd rootwait 4
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 2015600K/2097148K available (8192K kernel code, 325K rwdata, 2148K rodata, 1024K init, 248K bss, 32396K reserv)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] OMAP L2C310: ROM does not support power control setting
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[    0.000000] random: get_random_bytes called from start_kernel+0x2b0/0x458 with crng_init=0
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000012] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000029] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000037] OMAP clocksource: timer1 at 24000000 Hz
[    0.000452] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000460] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000910] Console: colour dummy device 80x30
[    0.000975] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
[    0.060179] pid_max: default: 32768 minimum: 301
[    0.060352] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.060375] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.061191] CPU: Testing write buffer coherency: ok
[    0.061252] CPU0: Spectre v2: using BPIALL workaround
[    0.062069] Setting up static identity map for 0x80100000 - 0x80100060
[    0.062208] rcu: Hierarchical SRCU implementation.
[    0.073375] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.073750] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.073773] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[    0.076877] pinctrl core: initialized pinctrl subsystem
[    0.078020] NET: Registered protocol family 16
[    0.079676] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.100499] cpuidle: using governor ladder
[    0.100532] cpuidle: using governor menu
[    0.118410] No ATAGs?
[    0.132773] edma 49000000.edma: TI EDMA DMA engine driver
[    0.134308] iommu: Default domain type: Translated
[    0.135774] SCSI subsystem initialized
[    0.135990] usbcore: registered new interface driver usbfs
[    0.136034] usbcore: registered new interface driver hub
[    0.136079] usbcore: registered new device driver usb
[    0.136609] pps_core: LinuxPPS API ver. 1 registered
[    0.136617] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[    0.136638] PTP clock support registered
[    0.136671] EDAC MC: Ver: 3.0.0
[    0.138557] clocksource: Switched to clocksource timer1
[    0.143296] thermal_sys: Registered thermal governor 'fair_share'
[    0.143302] thermal_sys: Registered thermal governor 'bang_bang'
[    0.143316] thermal_sys: Registered thermal governor 'step_wise'
[    0.143321] thermal_sys: Registered thermal governor 'user_space'
[    0.143326] thermal_sys: Registered thermal governor 'power_allocator'
[    0.143947] NET: Registered protocol family 2
[    0.144276] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.145210] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    0.145238] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.145297] TCP bind hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.145369] TCP: Hash tables configured (established 8192 bind 8192)
[    0.145543] UDP hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.145565] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes, linear)
[    0.145687] NET: Registered protocol family 1
[    0.146210] RPC: Registered named UNIX socket transport module.
[    0.146222] RPC: Registered udp transport module.
[    0.146227] RPC: Registered tcp transport module.
[    0.146232] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.147500] Initialise system trusted keyrings
[    0.147775] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    0.152445] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.153163] NFS: Registering the id_resolver key type
[    0.153200] Key type id_resolver registered
[    0.153206] Key type id_legacy registered
[    0.153246] ntfs: driver 2.1.32 [Flags: R/O].
[    0.153799] Key type asymmetric registered
[    0.153809] Asymmetric key parser 'x509' registered
[    0.153857] bounce: pool size: 64 pages
[    0.153902] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.154099] io scheduler mq-deadline registered
[    0.154113] io scheduler kyber registered
[    0.158348] OMAP GPIO hardware version 0.1
[    0.183069] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.217479] pinctrl-single 44e10800.pinmux: 199 pins, size 796
[    0.246286] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.249423] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.250075] printk: console [ttyS0] disabled
[    0.250173] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 66, base_baud = 3000000) is a 8250
[    0.864636] printk: console [ttyS0] enabled
[    0.869504] omap8250 48022000.serial: No clock speed specified: using default: 48000000
[    0.878145] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 72, base_baud = 3000000) is a 8250
[    0.887503] omap8250 48024000.serial: No clock speed specified: using default: 48000000
[    0.896190] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 73, base_baud = 3000000) is a 8250
[    0.905548] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[    0.914222] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 80, base_baud = 3000000) is a 8250
[    0.923536] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
[    0.932154] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 81, base_baud = 3000000) is a 8250
[    0.941469] omap8250 481aa000.serial: No clock speed specified: using default: 48000000
[    0.950135] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 82, base_baud = 3000000) is a 8250
[    0.961216] omap_rng 48310000.rng: Random Number Generator ver. 20
[    0.968794] random: fast init done
[    0.972450] crng init done
[    0.984316] brd: module loaded
[    0.996254] loop: module loaded
[    1.058591] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.067307] Probing for 175d address: 4
[    1.072130] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver ICPlus IP175D
[    1.080799] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
[    1.089166] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.095554] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.100973] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.108186] cpsw 4a100000.ethernet: Detected MACID = e0:ff:f1:ae:fc:bb
[    1.115528] cpsw 4a100000.ethernet: cpsw: Detected MACID = e0:ff:f1:ae:fc:bd
[    1.123490] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.131024] usbcore: registered new interface driver cdc_acm
[    1.136712] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.146818] omap_rtc 44e3e000.rtc: char device (253:0)
[    1.146837] omap_rtc 44e3e000.rtc: registered as rtc0
[    1.152220] i2c /dev entries driver
[    1.159510] /cpus/cpu@0: unsupported enable-method property: ti,am4372
[    1.166607] sdhci: Secure Digital Host Controller Interface driver
[    1.172859] sdhci: Copyright(c) Pierre Ossman
[    1.178364] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    1.187144] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.199149] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
[    1.207980] omap_hsmmc 481d8000.mmc: Got CD GPIO
[    1.219186] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    1.225671] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.232737] ledtrig-cpu: registered to indicate activity on CPUs
[    1.241789] NET: Registered protocol family 10
[    1.247475] Segment Routing with IPv6
[    1.251361] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.257931] NET: Registered protocol family 17
[    1.262553] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if .
[    1.275647] 8021q: 802.1Q VLAN Support v1.8
[    1.279912] Key type dns_resolver registered
[    1.284373] omap_voltage_late_init: Voltage driver support not added
[    1.291260] Loading compiled-in X.509 certificates
[    1.341278] tps6521x_pwrbutton tps65218-pwrbutton.1.auto: DMA mask not set
[    1.349000] input: tps65218_pwrbutton as /devices/platform/44000000.ocp/44c00000.interconnect/44c00000.interconnect:segment@2000000
[    1.383089] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
[    1.390021] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
[    1.396509] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 400 kHz
[    1.404873] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
[    1.413739] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.445472] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
[    1.454363] omap_hsmmc 481d8000.mmc: Got CD GPIO
[    1.490925] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
[    1.503046] Waiting for root device /dev/mmcblk0p2...
[    1.559188] mmc0: new high speed MMC card at address 0001
[    1.565957] mmcblk0: mmc0:0001 eMMC   3.64 GiB
[    1.571167] mmcblk0boot0: mmc0:0001 eMMC   partition 1 4.00 MiB
[    1.577633] mmcblk0boot1: mmc0:0001 eMMC   partition 2 4.00 MiB
[    1.583915] mmcblk0rpmb: mmc0:0001 eMMC   partition 3 4.00 MiB, chardev (246:0)
[    1.595873]  mmcblk0: p1 p2 p3
[    1.629507] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[    1.637116] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.646371] Freeing unused kernel memory: 1024K
[    1.651121] Run /sbin/init as init process
[    1.755915] init: Console is alive
[    1.907330] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    1.919515] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[    1.937237] init: - preinit -
[    2.169155] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
[    2.178816] Resetting master bus...
[    2.182331] Found my OF Node
[    2.185223] VLAN Setup is 1
[    2.211175] Full reset performed
[    2.214478] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
[    2.232788] 8021q: adding VLAN 0 to HW filter on device eth0
[    4.329080] Link is OK
[    4.329089] 100M/Full
[    4.334831] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[    4.342952] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    6.387544] mount_root: mounting /dev/root
[    6.392467] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
[    6.441853] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.449123] urandom-seed: Seeding with /etc/urandom.seed
[    6.493641] cpsw 4a100000.ethernet eth0: Link is Down
[    6.504487] procd: - early -
[    7.268420] procd: - ubus -
[    7.324247] procd: - init -
[    7.706014] kmodloader: loading kernel modules from /etc/modules.d/*
[    7.723668] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    7.743189] remoteproc remoteproc0: wkup_m3 is available
[    7.763233] remoteproc remoteproc0: powering up wkup_m3
[    7.774403] PM: Cannot get wkup_m3_ipc handle
[    7.785643] urngd: v1.0.2 started.
[    7.803228] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
[    7.835756] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    7.842413] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
[    7.964901] GACT probability on
[    7.969667] Mirror/redirect action on
[    7.982633] u32 classifier
[    7.985367]     input device check on
[    7.993380]     Actions configured
[    8.024290] Bridge firewalling registered
[    8.094256] xt_time: kernel timezone is -0000
[    8.107196] PPP generic driver version 2.4.2
[    8.113606] NET: Registered protocol family 24
[    8.125904] kmodloader: done loading kernel modules from /etc/modules.d/*
[   10.145526] xt_CT: No such helper "snmp"
[   11.461674] net eth1: initializing cpsw version 1.15 (0)
[   11.498840] Generic PHY 4a101000.mdio:05: attached PHY driver [Generic PHY] (mii_bus:phy_addr=4a101000.mdio:05, irq=POLL)
[   11.522203] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
[   11.535320] 8021q: adding VLAN 0 to HW filter on device eth1
[   11.561489] net eth1: Adding vlanid 3 to vlan filter
[   11.607591] net eth1: Adding vlanid 4 to vlan filter
[   11.705688] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
[   11.744203] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
[   11.799454] Link is OK
[   11.799459] 100M/Full
[   11.805455] 8021q: adding VLAN 0 to HW filter on device eth0
[   11.822831] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[   11.883931] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   12.768026] xt_CT: No such helper "snmp"
[   13.548417] xt_CT: No such helper "snmp"
[   13.679592] INSCOBEE MSU Starting...
[   13.694267] mount mmcblk0p3
[   13.930758] EXT4-fs (mmcblk0p3): recovery complete
[   13.944586] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[   14.487828] xt_CT: No such helper "snmp"
[   15.024244] kmcu run...
[   31.848708] vmmcwl_fixed: disabling
另随附/lib/firmware 和/lib/modules.列表
root@INSCOBEE-MSU:/lib/firmware# ll
drwxr-xr-x    5 root     root          4096 Apr 16 21:59 ./
drwxr-xr-x   11 root     root          4096 Apr 16 21:59 ../
-rw-r--r--    1 root     root          2046 Apr 16 21:59 LICENCE.iwlwifi_firmware
-rw-r--r--    1 root     root            73 Apr 16 21:59 am335x-bone-scale-data.bin
-rw-r--r--    1 root     root            17 Apr 16 21:59 am335x-evm-scale-data.bin
-rw-r--r--    1 root     root        217168 Apr 16 21:59 am335x-pm-firmware.elf
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru0_0-fw ->/lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_0.out
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru0_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt0_1.out
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru1_0-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_0.out
lrwxrwxrwx    1 root     root            49 Apr 16 21:59 am437x-pru1_1-fw -> /lib/firmware/pru/PRU_RPMsg_Echo_Interrupt1_1.out
-rw-r--r--    1 root     root            41 Apr 16 21:59 am43x-evm-scale-data.bin
-rw-r--r--    1 root     root        918268 Apr 16 21:59 iwlwifi-3160-17.ucode
-rw-r--r--    1 root     root       1745176 Apr 16 21:59 iwlwifi-8000C-13.ucode
-rw-r--r--    1 root     root       2351636 Apr 16 21:59 iwlwifi-8000C-16.ucode
-rw-r--r--    1 root     root       2394060 Apr 16 21:59 iwlwifi-8000C-21.ucode
-rw-r--r--    1 root     root       2120860 Apr 16 21:59 iwlwifi-8000C-22.ucode
-rw-r--r--    1 root     root       2227284 Apr 16 21:59 iwlwifi-8000C-27.ucode
-rw-r--r--    1 root     root       2310116 Apr 16 21:59 iwlwifi-8000C-31.ucode
-rw-r--r--    1 root     root       2448976 Apr 16 21:59 iwlwifi-8000C-34.ucode
-rw-r--r--    1 root     root       2428004 Apr 16 21:59 iwlwifi-8000C-36.ucode
-rw-r--r--    1 root     root       2389968 Apr 16 21:59 iwlwifi-8265-21.ucode
-rw-r--r--    1 root     root       1811984 Apr 16 21:59 iwlwifi-8265-22.ucode
-rw-r--r--    1 root     root       2234528 Apr 16 21:59 iwlwifi-8265-27.ucode
-rw-r--r--    1 root     root       2307104 Apr 16 21:59 iwlwifi-8265-31.ucode
-rw-r--r--    1 root     root       2440780 Apr 16 21:59 iwlwifi-8265-34.ucode
-rw-r--r--    1 root     root       2436632 Apr 16 21:59 iwlwifi-8265-36.ucode
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 pru/
-rw-r--r--    1 root     root          3940 Apr 16 21:59 regulatory.db
-rw-r--r--    1 root     root          1182 Apr 16 21:59 regulatory.db.p7s
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 ti-connectivity/
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 ti-pruss/
root@INSCOBEE-MSU:/lib# cd modules/
root@INSCOBEE-MSU:/lib/modules# ls
5.4.188
root@INSCOBEE-MSU:/lib/modules# cd 5.4.188/
root@INSCOBEE-MSU:/lib/modules/5.4.188# ll
drwxr-xr-x    2 root     root          4096 Apr 16 21:59 ./
drwxr-xr-x    3 root     root          4096 Apr 16 21:59 ../
-rw-r--r--    1 root     root          9956 Apr 16 21:59 act_gact.ko
-rw-r--r--    1 root     root         14520 Apr 16 21:59 act_mirred.ko
-rw-r--r--    1 root     root         10844 Apr 16 21:59 act_skbedit.ko
-rw-r--r--    1 root     root         24168 Apr 16 21:59 br_netfilter.ko
-rw-r--r--    1 root     root         10968 Apr 16 21:59 cls_basic.ko
-rw-r--r--    1 root     root         14736 Apr 16 21:59 cls_flow.ko
-rw-r--r--    1 root     root         11160 Apr 16 21:59 cls_fw.ko
-rw-r--r--    1 root     root         11516 Apr 16 21:59 cls_matchall.ko
-rw-r--r--    1 root     root         12384 Apr 16 21:59 cls_route.ko
-rw-r--r--    1 root     root         13268 Apr 16 21:59 cls_tcindex.ko
-rw-r--r--    1 root     root         20820 Apr 16 21:59 cls_u32.ko
-rw-r--r--    1 root     root          4360 Apr 16 21:59 crc-ccitt.ko
-rw-r--r--    1 root     root          5992 Apr 16 21:59 em_ipset.ko
-rw-r--r--    1 root     root          3604 Apr 16 21:59 em_u32.ko
-rw-r--r--    1 root     root         10232 Apr 16 21:59 ifb.ko
-rw-r--r--    1 root     root         17876 Apr 16 21:59 ip17xx.ko
-rw-r--r--    1 root     root         21888 Apr 16 21:59 ip6_tables.ko
-rw-r--r--    1 root     root          5380 Apr 16 21:59 ip6t_NPT.ko
-rw-r--r--    1 root     root          5240 Apr 16 21:59 ip6t_REJECT.ko
-rw-r--r--    1 root     root          5644 Apr 16 21:59 ip6table_filter.ko
-rw-r--r--    1 root     root          6024 Apr 16 21:59 ip6table_mangle.ko
-rw-r--r--    1 root     root          5444 Apr 16 21:59 ip6table_nat.ko
-rw-r--r--    1 root     root         42180 Apr 16 21:59 ip_set.ko
-rw-r--r--    1 root     root         13592 Apr 16 21:59 ip_set_bitmap_ip.ko
-rw-r--r--    1 root     root         13448 Apr 16 21:59 ip_set_bitmap_ipmac.ko
-rw-r--r--    1 root     root         12464 Apr 16 21:59 ip_set_bitmap_port.ko
-rw-r--r--    1 root     root         34836 Apr 16 21:59 ip_set_hash_ip.ko
-rw-r--r--    1 root     root         35004 Apr 16 21:59 ip_set_hash_ipmark.ko
-rw-r--r--    1 root     root         35796 Apr 16 21:59 ip_set_hash_ipport.ko
-rw-r--r--    1 root     root         36812 Apr 16 21:59 ip_set_hash_ipportip.ko
-rw-r--r--    1 root     root         41864 Apr 16 21:59 ip_set_hash_ipportnet.ko
-rw-r--r--    1 root     root         21040 Apr 16 21:59 ip_set_hash_mac.ko
-rw-r--r--    1 root     root         38740 Apr 16 21:59 ip_set_hash_net.ko
-rw-r--r--    1 root     root         40708 Apr 16 21:59 ip_set_hash_netiface.ko
-rw-r--r--    1 root     root         41172 Apr 16 21:59 ip_set_hash_netnet.ko
-rw-r--r--    1 root     root         40440 Apr 16 21:59 ip_set_hash_netport.ko
-rw-r--r--    1 root     root         42696 Apr 16 21:59 ip_set_hash_netportnet.ko
-rw-r--r--    1 root     root         14412 Apr 16 21:59 ip_set_list_set.ko
-rw-r--r--    1 root     root         21952 Apr 16 21:59 ip_tables.ko
-rw-r--r--    1 root     root          5240 Apr 16 21:59 ipt_ECN.ko
-rw-r--r--    1 root     root          5172 Apr 16 21:59 ipt_REJECT.ko
-rw-r--r--    1 root     root          5604 Apr 16 21:59 iptable_filter.ko
-rw-r--r--    1 root     root          5540 Apr 16 21:59 iptable_mangle.ko
-rw-r--r--    1 root     root          5436 Apr 16 21:59 iptable_nat.ko
-rw-r--r--    1 root     root          5916 Apr 16 21:59 iptable_raw.ko
-rw-r--r--    1 root     root          4672 Apr 16 21:59 libcrc32c.ko
-rw-r--r--    1 root     root         13900 Apr 16 21:59 nf_conncount.ko
-rw-r--r--    1 root     root        122512 Apr 16 21:59 nf_conntrack.ko
-rw-r--r--    1 root     root         39260 Apr 16 21:59 nf_conntrack_netlink.ko
-rw-r--r--    1 root     root          5428 Apr 16 21:59 nf_defrag_ipv4.ko
-rw-r--r--    1 root     root         14668 Apr 16 21:59 nf_defrag_ipv6.ko
-rw-r--r--    1 root     root         27320 Apr 16 21:59 nf_flow_table.ko
-rw-r--r--    1 root     root          6968 Apr 16 21:59 nf_flow_table_hw.ko
-rw-r--r--    1 root     root          8796 Apr 16 21:59 nf_log_common.ko
-rw-r--r--    1 root     root         10632 Apr 16 21:59 nf_log_ipv4.ko
-rw-r--r--    1 root     root         12284 Apr 16 21:59 nf_log_ipv6.ko
-rw-r--r--    1 root     root         37948 Apr 16 21:59 nf_nat.ko
-rw-r--r--    1 root     root          5856 Apr 16 21:59 nf_reject_ipv4.ko
-rw-r--r--    1 root     root          7452 Apr 16 21:59 nf_reject_ipv6.ko
-rw-r--r--    1 root     root         13092 Apr 16 21:59 nfnetlink.ko
-rw-r--r--    1 root     root         12684 Apr 16 21:59 pm33xx.ko
-rw-r--r--    1 root     root         15732 Apr 16 21:59 ppp_async.ko
-rw-r--r--    1 root     root         46724 Apr 16 21:59 ppp_generic.ko
-rw-r--r--    1 root     root         20816 Apr 16 21:59 pppoe.ko
-rw-r--r--    1 root     root          6052 Apr 16 21:59 pppox.ko
-rw-r--r--    1 root     root         37204 Apr 16 21:59 sch_cake.ko
-rw-r--r--    1 root     root         23528 Apr 16 21:59 sch_hfsc.ko
-rw-r--r--    1 root     root         26060 Apr 16 21:59 sch_htb.ko
-rw-r--r--    1 root     root          6972 Apr 16 21:59 sch_ingress.ko
-rw-r--r--    1 root     root         13604 Apr 16 21:59 sch_tbf.ko
-rw-r--r--    1 root     root          8252 Apr 16 21:59 slhc.ko
-rw-r--r--    1 root     root         12784 Apr 16 21:59 wkup_m3_ipc.ko
-rw-r--r--    1 root     root          8132 Apr 16 21:59 wkup_m3_rproc.ko
-rw-r--r--    1 root     root         30228 Apr 16 21:59 x_tables.ko
-rw-r--r--    1 root     root          3752 Apr 16 21:59 xt_CLASSIFY.ko
-rw-r--r--    1 root     root          8820 Apr 16 21:59 xt_CT.ko
-rw-r--r--    1 root     root          4936 Apr 16 21:59 xt_DSCP.ko
-rw-r--r--    1 root     root         10144 Apr 16 21:59 xt_FLOWOFFLOAD.ko
-rw-r--r--    1 root     root          4584 Apr 16 21:59 xt_HL.ko
-rw-r--r--    1 root     root          4468 Apr 16 21:59 xt_LOG.ko
-rw-r--r--    1 root     root          5316 Apr 16 21:59 xt_MASQUERADE.ko
-rw-r--r--    1 root     root          4672 Apr 16 21:59 xt_REDIRECT.ko
-rw-r--r--    1 root     root          8236 Apr 16 21:59 xt_TCPMSS.ko
-rw-r--r--    1 root     root          3604 Apr 16 21:59 xt_comment.ko
-rw-r--r--    1 root     root          5440 Apr 16 21:59 xt_connbytes.ko
-rw-r--r--    1 root     root          5028 Apr 16 21:59 xt_connlimit.ko
-rw-r--r--    1 root     root          6472 Apr 16 21:59 xt_connmark.ko
-rw-r--r--    1 root     root          6528 Apr 16 21:59 xt_conntrack.ko
-rw-r--r--    1 root     root          4284 Apr 16 21:59 xt_dscp.ko
-rw-r--r--    1 root     root          5380 Apr 16 21:59 xt_ecn.ko
-rw-r--r--    1 root     root          5032 Apr 16 21:59 xt_helper.ko
-rw-r--r--    1 root     root          4148 Apr 16 21:59 xt_hl.ko
-rw-r--r--    1 root     root          3848 Apr 16 21:59 xt_length.ko
-rw-r--r--    1 root     root          5528 Apr 16 21:59 xt_limit.ko
-rw-r--r--    1 root     root          3664 Apr 16 21:59 xt_mac.ko
-rw-r--r--    1 root     root          4168 Apr 16 21:59 xt_mark.ko
-rw-r--r--    1 root     root          4584 Apr 16 21:59 xt_multiport.ko
-rw-r--r--    1 root     root          7312 Apr 16 21:59 xt_nat.ko
-rw-r--r--    1 root     root         17536 Apr 16 21:59 xt_recent.ko
-rw-r--r--    1 root     root         13720 Apr 16 21:59 xt_set.ko
-rw-r--r--    1 root     root          4712 Apr 16 21:59 xt_state.ko
-rw-r--r--    1 root     root          4424 Apr 16 21:59 xt_statistic.ko
-rw-r--r--    1 root     root          4512 Apr 16 21:59 xt_tcpmss.ko
-rw-r--r--    1 root     root          5436 Apr 16 21:59 xt_tcpudp.ko
-rw-r--r--    1 root     root          6228 Apr 16 21:59 xt_time.ko
OpwnWRT BuildRoot RootFS 顶部的 GCC 信息
$ ./arm-openwrt-linux-gcc -v
Reading specs from /home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/lib/gcc/arm-openwrt-linux-muslgnueabi/8.4.0/specs
COLLECT_GCC=./arm-openwrt-linux-gcc
COLLECT_LTO_WRAPPER=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/libexec/gcc/arm-openwrt-linux-muslgnueabi/8.4.0/lto-wrapper
Target: arm-openwrt-linux-muslgnueabi
Configured with: /home/am437x/work/openwrt/build_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/gcc-8.4.0/configure --with-bugurl=http://bugs.openwrt.org/ --with-pkgversion='OpenWrt GCC 8.4.0 r16554-1d4dea6d4f' --prefix=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi --build=x86_64-pc-linux-gnu --host=x86_64-pc-linux-gnu --target=arm-openwrt-linux-muslgnueabi --with-gnu-ld --enable-target-optspace --disable-libgomp --disable-libmudflap --disable-multilib --disable-libmpx --disable-nls --disable-libssp --without-isl --without-cloog --with-host-libstdcxx=-lstdc++ --with-gmp=/home/am437x/work/openwrt/staging_dir/host --with-mpfr=/home/am437x/work/openwrt/staging_dir/host --with-mpc=/home/am437x/work/openwrt/staging_dir/host --disable-decimal-float --with-diagnostics-color=auto-if-env --enable-__cxa_atexit --disable-libstdcxx-dual-abi --with-default-libstdcxx-abi=new --with-cpu=cortex-a9 --with-fpu=vfpv3 --with-float=hard --with-headers=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/include --enable-languages=c,c++ --enable-shared --enable-threads --with-slibdir=/home/am437x/work/openwrt/staging_dir/toolchain-arm_cortex-a9+vfpv3_gcc-8.4.0_musl_eabi/lib --enable-lto --with-libelf=/home/am437x/work/openwrt/staging_dir/host --disable-libsanitizer
Thread model: posix
e2e.ti.com/.../0535.dts.zip
您能帮助我们在定制引导加载程序和内核组合中解决这个 rtcwake 错误吗?
插孔
    您好、Jack、
    [报价 userid="477602" url="~/support/processors-group/processors/f/processors-forum/1229330/am4376-rtcwake-failure-on-top-of-custom-u-boot-and-kernel-combination-along-with-buildroot ]即使 TI PSDK 正式发布对 rtcwake 函数起作用。 客户报告了基于 Uboot 2020.01和 Kernel 5.4.188的定制平台上的 rtcwake 故障。
    我不确定我是否完全理解这一点。 客户是否有通过和失败的案例? 请详细说明。
    您能否为发生故障的情况附加完整的内核启动日志?
    您好、刘斌。
    他们的问题100%重现。 当我今天不在办公室时、我会在明天附上完整的启动日志。
    插孔
    刘斌
    请查看完整的启动日志。
    <debug_uart>
    U-Boot SPL 2020.01-dirty (Apr 16 2022 - 12:59:34 +0000)
    WDT:   Not found!
    Trying to boot from MMC1
    N: mmc_dev=0
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
                    MMC_RSP_R3,4             0x40ff8080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
                    MMC_RSP_R3,4             0xc0ff8080
    CMD_SEND:2
                    ARG                      0x00000000
                    MMC_RSP_R2               0x89010065
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
                    MMC_RSP_R1,5,6,7         0x00000500
    CMD_SEND:9
                    ARG                      0x00010000
                    MMC_RSP_R2               0xd0270132
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
                    MMC_RSP_R1,5,6,7         0x00000700
    CMD_SEND:8
                    ARG                      0x00000000
                    MMC_RSP_R1,5,6,7         0x00000900
    CMD_SEND:6
                    ARG                      0x03b70100
                    MMC_RSP_R1b              0x00000900
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    N: boot_mode=2
    spl: mmc boot mode: fs
    N: __func__ 1
    SPL: Please implement spl_start_uboot() for your board
    SPL: Direct Linux boot not active!
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    N: spl_load_image_fat 1, devnum=0, partition=1, err=0
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000958
    N: file_fat_read ret=64
    N: Found FIT
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000958
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x0000095b
    fit read sector 0, sectors=1604, dst=807ff980, count=1604, size=0x644
    N: images=140
    N: spl_load_fit_image 1
    N: spl_load_fit_image 2, external_data=1
    N: spl_load_fit_image 3
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000958
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x0000095c
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000cf0
    N: External data: dst=80800000, offset=644, size=72ac4
    Image OS is U-Boot
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000d34
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000d38
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000d82
    N: External data: dst=80872b00, offset=7bca0, size=9864
    N: spl_load_simple_fit 1
    N: spl_load_simple_fit 2
    N:spl_mmc_load, 111 err=0
    U-Boot 2020.01-dirty (Apr 16 2022 - 12:59:34 +0000)
    CPU  : AM437X-GP rev 1.2
    Model: TI AM437x SK EVM
    DRAM:  2 GiB
    PMIC:  TPS65218
    MMC:   OMAP SD/MMC: 0
    Loading Environment from FAT... CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    *** Warning - bad CRC, using default environment
    Net:
    Warning: ethernet@4a100000 using MAC address from ROM
    eth0: ethernet@4a100000
    Hit any key to stop autoboot:  0
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    switch to partitions #0, OK
    mmc0(part 0) is current device
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:8
                    ARG                      0x000001aa
                    RET                      -110
    CMD_SEND:55
                    ARG                      0x00000000
                    RET                      -110
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x00000000
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:0
                    ARG                      0x00000000
                    MMC_RSP_NONE
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:1
                    ARG                      0x40300080
    CMD_SEND:2
                    ARG                      0x00000000
                                             0x4d4d4320
                                             0x20012618
                                             0x01212553
                                            DUMPING DATA
                                            000 - 89 01 00 65
                                            004 - 4d 4d 43 20
                                            008 - 20 01 26 18
                                            012 - 01 21 25 53
    CMD_SEND:3
                    ARG                      0x00010000
    CMD_SEND:9
                    ARG                      0x00010000
                                             0x0f5903ff
                                             0xffffffef
                                             0x8a4040d3
                                            DUMPING DATA
                                            000 - d0 27 01 32
                                            004 - 0f 59 03 ff
                                            008 - ff ff ff ef
                                            012 - 8a 40 40 d3
    CMD_SEND:7
                    ARG                      0x00010000
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:6
                    ARG                      0x03b70100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:6
                    ARG                      0x03b90100
    CMD_SEND:13
                    ARG                      0x00010000
    CURR STATE:4
    CMD_SEND:8
                    ARG                      0x00000000
    CMD_SEND:8
                    ARG                      0x00000000
    SD/MMC found on device 0
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00002c20
    358 bytes read in 46 ms (6.8 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    Running uenvcmd ...
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000e20
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000e24
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000eac
    69934 bytes read in 106 ms (643.6 KiB/s)
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00000800
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x000008a4
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000804
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x0000080a
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:18
                    ARG                      0x00000eb0
    CMD_SEND:12
                    ARG                      0x00000000
    CMD_SEND:16
                    ARG                      0x00000200
    CMD_SEND:17
                    ARG                      0x00002c09
    3846736 bytes read in 295 ms (12.4 MiB/s)
    ## Flattened Device Tree blob at 88000000
       Booting using the fdt blob at 0x88000000
       Loading Device Tree to 8ffeb000, end 8ffff12d ... OK
    Starting kernel ...
    [    0.000000] Linux version 5.4.188 (am437x@4bfebc466fc7) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16554-1d4dea6d4f)) #0 PREEMPT Sat Apr 16 12:59:34 2022
    [    0.000000] Kernel command line: consoleblank=0 no_console_suspend=1 console=ttyS0,115200n8 root=/dev/mmcblk0p2 noinitrd rootwait rootfstype=ext4
    [    0.000000] Memory: 2015600K/2097148K available (8192K kernel code, 325K rwdata, 2148K rodata, 1024K init, 248K bss, 32396K reserved, 49152K cma-reserved, 1261564K highmem)
    [    0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [    0.000030] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000039] OMAP clocksource: timer1 at 24000000 Hz
    [    0.000454] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000463] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000911] Console: colour dummy device 80x30
    [    0.000972] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
    [    0.060356] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.060377] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
    [    0.061193] CPU: Testing write buffer coherency: ok
    [    0.062073] Setting up static identity map for 0x80100000 - 0x80100060
    [    0.062213] rcu: Hierarchical SRCU implementation.
    [    0.073457] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    0.073832] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.073855] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
    [    0.076947] pinctrl core: initialized pinctrl subsystem
    [    0.078086] NET: Registered protocol family 16
    [    0.079727] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.100598] cpuidle: using governor ladder
    [    0.100635] cpuidle: using governor menu
    [    0.118503] No ATAGs?
    [    0.132821] edma 49000000.edma: TI EDMA DMA engine driver
    [    0.134353] iommu: Default domain type: Translated
    [    0.135820] SCSI subsystem initialized
    [    0.136043] usbcore: registered new interface driver usbfs
    [    0.136086] usbcore: registered new interface driver hub
    [    0.136129] usbcore: registered new device driver usb
    [    0.136658] pps_core: LinuxPPS API ver. 1 registered
    [    0.136666] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.136686] PTP clock support registered
    [    0.136720] EDAC MC: Ver: 3.0.0
    [    0.138626] clocksource: Switched to clocksource timer1
    [    0.143381] thermal_sys: Registered thermal governor 'fair_share'
    [    0.143387] thermal_sys: Registered thermal governor 'bang_bang'
    [    0.143401] thermal_sys: Registered thermal governor 'step_wise'
    [    0.143405] thermal_sys: Registered thermal governor 'user_space'
    [    0.143410] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.144023] NET: Registered protocol family 2
    [    0.144353] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
    [    0.145290] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
    [    0.145319] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.145378] TCP bind hash table entries: 8192 (order: 3, 32768 bytes, linear)
    [    0.145451] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.145625] UDP hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.145648] UDP-Lite hash table entries: 512 (order: 1, 8192 bytes, linear)
    [    0.145771] NET: Registered protocol family 1
    [    0.146298] RPC: Registered named UNIX socket transport module.
    [    0.146309] RPC: Registered udp transport module.
    [    0.146314] RPC: Registered tcp transport module.
    [    0.146319] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.147600] Initialise system trusted keyrings
    [    0.147881] workingset: timestamp_bits=14 max_order=19 bucket_order=5
    [    0.152559] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.153260] NFS: Registering the id_resolver key type
    [    0.153300] Key type id_resolver registered
    [    0.153306] Key type id_legacy registered
    [    0.153345] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.153894] Key type asymmetric registered
    [    0.153906] Asymmetric key parser 'x509' registered
    [    0.153954] bounce: pool size: 64 pages
    [    0.153999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    0.154197] io scheduler mq-deadline registered
    [    0.154208] io scheduler kyber registered
    [    0.158459] OMAP GPIO hardware version 0.1
    [    0.183241] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [    0.217585] pinctrl-single 44e10800.pinmux: 199 pins, size 796
    [    0.246482] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.249607] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
    [    0.250255] printk: console [ttyS0] disabled
    [    0.250354] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 66, base_baud = 3000000) is a 8250
    [    0.864814] printk: console [ttyS0] enabled
    [    0.869687] omap8250 48022000.serial: No clock speed specified: using default: 48000000
    [    0.878330] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 72, base_baud = 3000000) is a 8250
    [    0.887674] omap8250 48024000.serial: No clock speed specified: using default: 48000000
    [    0.896359] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 73, base_baud = 3000000) is a 8250
    [    0.905721] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
    [    0.914399] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 80, base_baud = 3000000) is a 8250
    [    0.923706] omap8250 481a8000.serial: No clock speed specified: using default: 48000000
    [    0.932332] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 81, base_baud = 3000000) is a 8250
    [    0.941655] omap8250 481aa000.serial: No clock speed specified: using default: 48000000
    [    0.950316] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 82, base_baud = 3000000) is a 8250
    [    0.961389] omap_rng 48310000.rng: Random Number Generator ver. 20
    [    0.968875] random: fast init done
    [    0.972531] crng init done
    [    0.984435] brd: module loaded
    [    0.996379] loop: module loaded
    [    1.058658] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    1.067372] Probing for 175d address: 4
    [    1.072190] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver ICPlus IP175D
    [    1.080852] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
    [    1.089208] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
    [    1.095594] cpsw 4a100000.ethernet: ALE Table size 1024
    [    1.101014] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
    [    1.108230] cpsw 4a100000.ethernet: Detected MACID = e0:ff:f1:af:02:f1
    [    1.115565] cpsw 4a100000.ethernet: cpsw: Detected MACID = e0:ff:f1:af:02:f3
    [    1.123519] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.131056] usbcore: registered new interface driver cdc_acm
    [    1.136744] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    1.146867] omap_rtc 44e3e000.rtc: registered as rtc0
    [    1.152244] i2c /dev entries driver
    [    1.159524] /cpus/cpu@0: unsupported enable-method property: ti,am4372
    [    1.166617] sdhci: Secure Digital Host Controller Interface driver
    [    1.172866] sdhci: Copyright(c) Pierre Ossman
    [    1.178372] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
    [    1.187152] omap_hsmmc 48060000.mmc: Got CD GPIO
    [    1.199213] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
    [    1.208046] omap_hsmmc 481d8000.mmc: Got CD GPIO
    [    1.219264] omap_hsmmc 47810000.mmc: RX DMA channel request failed
    [    1.225747] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.232822] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.241877] NET: Registered protocol family 10
    [    1.247575] Segment Routing with IPv6
    [    1.251459] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    1.258030] NET: Registered protocol family 17
    [    1.262643] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
    [    1.275739] 8021q: 802.1Q VLAN Support v1.8
    [    1.280001] Key type dns_resolver registered
    [    1.284463] omap_voltage_late_init: Voltage driver support not added
    [    1.291349] Loading compiled-in X.509 certificates
    [    1.341338] tps6521x_pwrbutton tps65218-pwrbutton.1.auto: DMA mask not set
    [    1.349072] input: tps65218_pwrbutton as /devices/platform/44000000.ocp/44c00000.interconnect/44c00000.interconnect:segment@200000/44e0b000.target-module/44e0b000.i2c/i2c-0/0-0024/tps65218-pwrbutton.1.auto/input/input0
    [    1.383176] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
    [    1.390102] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
    [    1.396581] omap_i2c 4819c000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.404922] omap_gpio 44e07000.gpio: Could not set line 6 debounce to 200000 microseconds (-22)
    [    1.413786] omap_hsmmc 48060000.mmc: Got CD GPIO
    [    1.445529] omap_gpio 481ae000.gpio: Could not set line 15 debounce to 200000 microseconds (-22)
    [    1.454420] omap_hsmmc 481d8000.mmc: Got CD GPIO
    [    1.491003] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01T00:00:00 UTC (946684800)
    [    1.503161] Waiting for root device /dev/mmcblk0p2...
    [    1.559241] mmc0: new high speed MMC card at address 0001
    [    1.566000] mmcblk0: mmc0:0001 eMMC   3.64 GiB
    [    1.571220] mmcblk0boot0: mmc0:0001 eMMC   partition 1 4.00 MiB
    [    1.577681] mmcblk0boot1: mmc0:0001 eMMC   partition 2 4.00 MiB
    [    1.583956] mmcblk0rpmb: mmc0:0001 eMMC   partition 3 4.00 MiB, chardev (246:0)
    [    1.595894]  mmcblk0: p1 p2 p3
    [    1.629578] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
    [    1.637185] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.646444] Freeing unused kernel memory: 1024K
    [    1.651195] Run /sbin/init as init process
    [    1.755701] init: Console is alive
    [    1.907412] kmodloader: loading kernel modules from /etc/modules-boot.d/*
    [    1.919668] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
    [    1.937390] init: - preinit -
    [    2.167456] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
    [    2.177306] Resetting master bus...
    [    2.180901] Found my OF Node
    [    2.183797] VLAN Setup is 1
    [    2.208885] Full reset performed
    [    2.212251] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
    [    2.230640] 8021q: adding VLAN 0 to HW filter on device eth0
    Press the [f] key and hit [enter] to enter failsafe mode
    Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
    [    6.385812] mount_root: mounting /dev/root
    [    6.390710] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
    [    6.461189] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    6.468165] urandom-seed: Seeding with /etc/urandom.seed
    [    6.515042] procd: - early -
    [    7.282078] procd: - ubus -
    [    7.340288] procd: - init -
    Please press Enter to activate this console.
    [    7.720064] kmodloader: loading kernel modules from /etc/modules.d/*
    [    7.741152] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
    [    7.763179] remoteproc remoteproc0: wkup_m3 is available
    [    7.776930] urngd: v1.0.2 started.
    [    7.781779] remoteproc remoteproc0: powering up wkup_m3
    [    7.795150] PM: Cannot get wkup_m3_ipc handle
    [    7.810943] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217168
    [    7.844988] remoteproc remoteproc0: remote processor wkup_m3 is now up
    [    7.851630] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x193
    [    7.971474] GACT probability on
    [    7.976027] Mirror/redirect action on
    [    7.993421] u32 classifier
    [    7.996156]     input device check on
    [    7.999953]     Actions configured
    [    8.031330] Bridge firewalling registered
    [    8.105269] xt_time: kernel timezone is -0000
    [    8.118084] PPP generic driver version 2.4.2
    [    8.124483] NET: Registered protocol family 24
    [    8.132549] kmodloader: done loading kernel modules from /etc/modules.d/*
    [   10.171079] xt_CT: No such helper "snmp"
    [   11.516372] net eth1: initializing cpsw version 1.15 (0)
    [   11.554590] Generic PHY 4a101000.mdio:05: attached PHY driver [Generic PHY] (mii_bus:phy_addr=4a101000.mdio:05, irq=POLL)
    [   11.580261] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control off
    [   11.595745] 8021q: adding VLAN 0 to HW filter on device eth1
    [   11.614875] net eth1: Adding vlanid 3 to vlan filter
    [   11.682595] net eth1: Adding vlanid 4 to vlan filter
    [   11.781104] cpsw 4a100000.ethernet: initializing cpsw version 1.15 (0)
    [   11.823700] ICPlus IP175D 4a101000.mdio:04: attached PHY driver [ICPlus IP175D] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
    [   11.890709] 8021q: adding VLAN 0 to HW filter on device eth0
    [   12.795300] xt_CT: No such helper "snmp"
    [   13.565213] xt_CT: No such helper "snmp"
    [   13.659350] INSCOBEE MSU Starting...
    [   13.673638] mount mmcblk0p3
    [   13.897287] EXT4-fs (mmcblk0p3): recovery complete
    [   13.977689] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    [   14.475697] xt_CT: No such helper "snmp"
    [   15.044849] kmcu run...
    [   31.849015] vmmcwl_fixed: disabling
    BusyBox v1.33.2 (2022-04-16 12:59:34 UTC) built-in shell (ash)
    | This system have to access authorized user and only use for  |
    | officially. During using equipment, privacy of individuals   |
    | is not guaranteed.                                           |
    | All access and usage is monitored and recorded and can be    |
    | provided evidance as court or related organization.          |
    | Use of this system constitutes consent to monitoring for     |
    | these purposed.                                              |
        INSCOBEE MSU V1.0 by OpenWrt 21.02.3, r16554-1d4dea6d4f
    APHOME set to /data/kmcu
    APREL set to /data/kmcu/r10
    APUSER set to root
    kernel.core_pattern = /data/kmcu/core.%e
    root@INSCOBEE-MSU:/# rtcwake -s 10 -d /dev/rtc0 -m mem
    wakeup from "mem" at Mon Aug  1 00:04:34 2022
    [  286.559058] PM: suspend entry (deep)
    [  286.564768] Filesystems sync: 0.001 seconds
    [  286.575656] Freezing user space processes ... (elapsed 0.003 seconds) done.
    [  286.586199] OOM killer disabled.
    [  286.589705] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
    [  286.613730] cpsw 4a100000.ethernet eth1: Link is Down
    [  286.627439] PM: suspend devices took 0.020 seconds
    e2e.ti.com/.../rtcwake-failure-log.txt
    插孔
