[参考译文] TDA4VM:sk-tda4vm 8.0 SDK gstream 未安装
Guru**** 2540720 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1242309/tda4vm-sk-tda4vm-8-0-sdk-gstream-not-installing
器件型号:TDA4VM
您好、我无法运行演示应用程序。 当我尝试手动安装 gstream 时、该错误
root@j7-evm:/opt/edge_ai_apps/scripts# ./install_gst_plugins.sh
edgeai-gst-plugins
The Meson build system
Version: 0.53.2
Source dir: /opt/edgeai-gst-plugins
Build dir: /opt/edgeai-gst-plugins/build
Build type: native build
Project name: GstTIOVX
Project version: 0.7.0
C compiler for the host machine: cc (gcc 9.2.1 "cc (GCC) 9.2.1 20191025")
C linker for the host machine: cc ld.bfd 2.34.0.20200220
C++ compiler for the host machine: c++ (gcc 9.2.1 "c++ (GCC) 9.2.1 20191025")
C++ linker for the host machine: c++ ld.bfd 2.34.0.20200220
Host machine cpu family: aarch64
Host machine cpu: aarch64
Found pkg-config: /usr/bin/pkg-config (0.29.2)
Run-time dependency gstreamer-1.0 found: YES 1.16.3
Run-time dependency gstreamer-base-1.0 found: YES 1.16.3
Run-time dependency gstreamer-video-1.0 found: YES 1.16.3
Run-time dependency gstreamer-check-1.0 found: YES 1.16.3
Run-time dependency gstreamer-allocators-1.0 found: YES 1.16.3
meson.build:34:2: ERROR: Problem encountered: MESON_FAIL SOC not set.
A full log can be found at /opt/edgeai-gst-plugins/build/meson-logs/meson-log.txt
/usr/lib/python3.8/site-packages/ninja/data/bin/ninja: /usr/lib/libstdc++.so.6: no version information available (required by /usr/lib/python3.8/site-packages/ninja/data/bin/ninja)
ninja: Entering directory `build'
ninja: error: loading 'build.ninja': No such file or directory
