[参考译文] SK-TDA4VM:模型部署错误
Guru**** 2546020 points
https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1242695/sk-tda4vm-model-deployment-error
器件型号:SK-TDA4VM
运行编译的 yolov5s 时、会发生以下错误:
libtidl_onnxrt_EP loaded 0x23ebc470
Final number of subgraphs created are : 3, - Offloaded Nodes - 196, Total Nodes - 236
APP: Init ... !!!
MEM: Init ... !!!
MEM: Initialized DMA HEAP (fd=4) !!!
MEM: Init ... Done !!!
IPC: Init ... !!!
IPC: Init ... Done !!!
REMOTE_SERVICE: Init ... !!!
REMOTE_SERVICE: Init ... Done !!!
165.858162 s: GTC Frequency = 200 MHz
APP: Init ... Done !!!
165.858182 s: VX_ZONE_INIT:Enabled
165.858185 s: VX_ZONE_ERROR:Enabled
165.858187 s: VX_ZONE_WARNING:Enabled
165.858780 s: VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
165.859005 s: VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
165.875596 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
165.875603 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
165.875608 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
165.875611 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
165.875614 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
165.875618 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
165.875625 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
165.875627 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
TIDL_RT_OVX: ERROR: Verifying TIDL graph ... Failed !!!
TIDL_RT_OVX: ERROR: Verify OpenVX graph failed
165.998258 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
165.998265 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
165.998268 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
165.998272 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
165.998274 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
165.998279 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
165.998284 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
165.998287 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
166.019533 s: VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
166.019540 s: VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
166.019544 s: VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
166.019546 s: VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
166.019549 s: VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
166.019552 s: VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
166.019557 s: VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
166.019559 s: VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
您能帮助检查这个问题吗? 谢谢。
切里
    您能否确认您的开发板与网络编译时使用的 SDK 版本相同?
    您是否还可以共享您的网络编译日志?
    普拉蒂克
     Pratik、您好!
    感谢您的支持。
    运行后生成的日志文件如下所示:
    libtidl_onnxrt_EP loaded 0x2d3cc470
    APP: Init ... !!!
    MEM: Init ... !!!
    IPC: Init ... !!!
       305.600825 s: GTC Frequency = 200 MHz
       305.600852 s:  VX_ZONE_INIT:Enabled
       305.600855 s:  VX_ZONE_ERROR:Enabled
       305.600857 s:  VX_ZONE_WARNING:Enabled
       305.601366 s:  VX_ZONE_INIT:[tivxInitLocal:130] Initialization Done !!!
       305.601658 s:  VX_ZONE_INIT:[tivxHostInitLocal:86] Initialization Done for HOST !!!
       305.618095 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       305.618103 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       305.618108 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       305.618110 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       305.618113 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       305.618117 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       305.618123 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       305.618126 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       305.740672 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       305.740679 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       305.740683 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       305.740686 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       305.740689 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       305.740693 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       305.740698 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       305.740701 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       305.761984 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       305.761991 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       305.761994 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       305.761997 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       305.762000 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       305.762004 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       305.762009 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       305.762012 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
    )0[1;67r[m[4l[?7h[H[J
     | Lane Detection[3;77H|
     | Input Src: /opt/edge_ai_apps/data/videos/video_0000_h264.mp4[6;77H|
     | Model Name: yolov5s[7;77H|
     | Model Type: detection[8;77H|
     +--------------------------------------------------------------------------+   306.161757 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       306.161775 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       306.161783 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       306.161788 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       306.161793 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       306.161804 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       306.161817 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       306.161822 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       306.162070 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
       306.162075 s:  VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
       306.162079 s:  VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
    ERROR: Running TIDL graph ... Failed !!!
       306.177924 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       306.177931 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       306.177935 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       306.177938 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       306.177940 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       306.177945 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       306.177951 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       306.177953 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       306.178068 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
       306.178074 s:  VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
       306.178084 s:  VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
       306.220401 s:  VX_ZONE_ERROR:[ownContextSendCmd:815] Command ack message returned failure cmd_status: -1
       306.220408 s:  VX_ZONE_ERROR:[ownContextSendCmd:851] tivxEventWait() failed.
       306.220411 s:  VX_ZONE_ERROR:[ownNodeKernelInit:538] Target kernel, TIVX_CMD_NODE_CREATE failed for node TIDLNode
       306.220415 s:  VX_ZONE_ERROR:[ownNodeKernelInit:539] Please be sure the target callbacks have been registered for this core
       306.220417 s:  VX_ZONE_ERROR:[ownNodeKernelInit:540] If the target callbacks have been registered, please ensure no errors are occurring within the create callback of this kernel
       306.220421 s:  VX_ZONE_ERROR:[ownGraphNodeKernelInit:583] kernel init for node 0, kernel com.ti.tidl ... failed !!!
       306.220427 s:  VX_ZONE_ERROR:[vxVerifyGraph:2055] Node kernel init failed
       306.220430 s:  VX_ZONE_ERROR:[vxVerifyGraph:2109] Graph verify failed
       306.220539 s:  VX_ZONE_ERROR:[ownGraphScheduleGraphWrapper:820] graph is not in a state required to be scheduled
       306.220542 s:  VX_ZONE_ERROR:[vxProcessGraph:755] schedule graph failed
       306.220544 s:  VX_ZONE_ERROR:[vxProcessGraph:760] wait graph failed
    [H[J
     | dl-inference[10;37H:     [0;10;1m  181.26 ms[m   from   1    samples |
     +--------------------------------------------------------------------------+[H[J
    编译日志文件如下:
    Available execution providers :  ['TIDLExecutionProvider', 'TIDLCompilationProvider', 'CPUExecutionProvider']
    Running 1 Models - ['besta']
    Running_Model :  besta
    Running shape inference on model ../../../models/public/yolov5s.onnx
    Preliminary subgraphs created = 5
    /home/leo/code/edgeai-tidl-tools-master/examples/osrt_python/ort/tidl_tools/tidl_graphVisualiser_runtimes.out: error while loading shared libraries: libcgraph.so.6: cannot open shared object file: No such file or directory
     ************** Frame index 1 : Running float import *************
    /home/leo/code/edgeai-tidl-tools-master/examples/osrt_python/ort/tidl_tools/tidl_graphVisualiser.out: error while loading shared libraries: libcgraph.so.6: cannot open shared object file: No such file or directory
    **                ALL MODEL CHECK PASSED          **
    The soft limit is 2048
    The hard limit is 2048
    MEM: Init ... !!!
     0.0s:  VX_ZONE_INIT:Enabled
     0.6s:  VX_ZONE_ERROR:Enabled
     0.7s:  VX_ZONE_WARNING:Enabled
     0.1533s:  VX_ZONE_INIT:[tivxInit:184] Initialization Done !!!
    **********  Frame Index 1 : Running float inference **********
    INFORMATION: [TIDL_ResizeLayer] Resize_118 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    INFORMATION: [TIDL_ResizeLayer] Resize_140 Any resize ratio which is power of 2 and greater than 4 will be placed by combination of 4x4 resize layer and 2x2 resize layer. For example a 8x8 resize will be replaced by 4x4 resize followed by 2x2 resize.
    **          2 WARNINGS          0 ERRORS          **
    **********  Frame Index 2 : Running fixed point mode for calibration **********
    ~~~~~Running TIDL in PC emulation mode to collect Activations range for each layer~~~~~
    Processing config file #0 : /home/leo/code/edgeai-tidl-tools-master/model-artifacts/besta/tempDir/228_tidl_io_.qunat_stats_config.txt
     Freeing memory for user provided Net
     ----------------------- TIDL Process with REF_ONLY FLOW ------------------------
    #    0 . .. T    9640.59  .... ..... ... .... .....
    #    1 . .. T    9591.98  .... ..... ... .... .....
    #    0 . .. T    7122.62  .... ..... ... .... .....
    #    1 . .. T    7123.85  .... ..... ... .... .....
     *****************   Calibration iteration number 0 completed ************************
    #    0 . .. T    7126.32  .... ..... ... .... .....
    #    1 . .. T    7126.64  .... ..... ... .... .....
     *****************   Calibration iteration number 1 completed ************************
    #    0 . .. T    7120.21  .... ..... ... .... .....
    #    1 . .. T    7150.90  .... ..... ... .... .....
     *****************   Calibration iteration number 2 completed ************************
    #    0 . .. T    7168.20  .... ..... ... .... .....
    #    1 . .. T    7163.76  .... ..... ... .... .....
     *****************   Calibration iteration number 3 completed ************************
    #    0 . .. T    7127.88  .... ..... ... .... .....
    #    1 . .. T    7137.15  .... ..... ... .... .....
     *****************   Calibration iteration number 4 completed ************************
    ------------------ Network Compiler Traces -----------------------------
    NC running for device: 1
    Running with OTF buffer optimizations
    successful Memory allocation
    Processing config file #0 : /home/leo/code/edgeai-tidl-tools-master/model-artifacts/besta/tempDir/326365404_tidl_io_.qunat_stats_config.txt
    #    0 . .. T    6665.58  .... ..... ... .... .....
    #    1 . .. T    6647.75  .... ..... ... .... .....
    #    0 . .. T    3502.79  .... ..... ... .... .....
    #    1 . .. T    3493.17  .... ..... ... .... .....
    #    0 . .. T    3507.26  .... ..... ... .... .....
    #    1 . .. T    3513.30  .... ..... ... .... .....
    #    0 . .. T    3498.75  .... ..... ... .... .....
    #    1 . .. T    3507.60  .... ..... ... .... .....
    #    0 . .. T    3488.07  .... ..... ... .... .....
    #    1 . .. T    3495.94  .... ..... ... .... .....
    #    0 . .. T    3499.58  .... ..... ... .... .....
    #    1 . .. T    3488.70  .... ..... ... .... .....
    Processing config file #0 : /home/leo/code/edgeai-tidl-tools-master/model-artifacts/besta/tempDir/output0_tidl_io_.qunat_stats_config.txt
    #    0 . .. T      64.20  .... ..... ... .... .....
    #    1 . .. T      56.35  .... ..... ... .... .....
    #    0 . .. T      68.55  .... ..... ... .... .....
    #    1 . .. T      64.69  .... ..... ... .... .....
    #    0 . .. T      68.72  .... ..... ... .... .....
    #    1 . .. T      64.46  .... ..... ... .... .....
    #    0 . .. T      70.52  .... ..... ... .... .....
    #    1 . .. T      64.40  .... ..... ... .... .....
    #    0 . .. T      68.99  .... ..... ... .... .....
    #    1 . .. T      64.80  .... ..... ... .... .....
    #    0 . .. T      68.09  .... ..... ... .... .....
    #    1 . .. T      64.64  .... ..... ... .... .....
    Completed_Model :     1, Name : besta                                             , Total time :   89329.31, Offload Time :    9685.48 , DDR RW MBs : 0, Output File : py_out_besta_2.jpg
    MEM: Deinit ... !!!
    MEM: Alloc's: 89 alloc's of 1044781908 bytes
    MEM: Free's : 89 free's  of 1044781908 bytes
    MEM: Open's : 0 allocs  of 0 bytes
    MEM: Deinit ... Done !!!
    谢谢。此致、
    切里
    您好
    感谢您共享编译日志。
    您能否确认主板的 SDK 版本与网络编译期间使用的版本相同?
    您电路板上有哪个 SDK 版本、以及您用于 Tidl-tools 来编译上述模型的 SDK 版本?
    普拉蒂克
     Pratik、您好!
    谢谢、但客户不知道如何检查 SDK 版本、您能提供一些指导吗?
    谢谢。此致、
    切里
    电路板 SDK 版本可以是客户在创建 Linux SDK 映像时使用的版本、您可以检查曾用于闪存的 SDK 映像版本。
    关于 tidl 工具版本,可以检查 tidl 工具的标签 git 集线器 repo,理想情况下客户应该使用其 SDK 版本的特定分支。
    普拉蒂克
